0.200" 4-Character 5 x 7 Dot Matrix
Alphanumeric Intelligent Display® Devices with Memory/Decoder/Driver
Lead (Pb) Free Product - RoHS Compliant
DLR2416, DLO2416, DLG2416
Description
The DLR/DLO/DLG2416 is a four digit 5 x 7 dot matrix display module with a built-in CMOS integrated circuit.This display is X/Y stackable.
The integrated circuit contains memory, ASCII ROM decoder, multiplexing circuitry and drivers. Data entry is asynchronous and can be random. A display system can be built using any number of DLX2416s since each digit can be
addressed independently and will continue to display the character last stored until replaced by another.
System interconnection is very straightforward. The least significant two address bits (A0, A1) are normally connected
to the like-named inputs of all displays in the system. With two chip enables (CE1 and CE2) four displays (16 characters) can easily be interconnected without a decoder.
Data lines are connected to all DLX2416s directly and in parallel, as is the write line (WR). The display will then
behave as a write-only memory.
The cursor function causes all dots of a digit position to illuminate at half brightness. The cursor is not a character, and
when removed the previously displayed character will reappear.
The DLX2416 has several features superior to competitive devices. True ’’blanking“ allows the designer to dim the display for more flexibility of display presentation. Finally the CLR clear function will clear the cursor RAM and the ASCII
character RAM simultaneously.
The character set consists of 128 special ASCII characters for English, German, Italian, Swedish, Danish, and Norwegian.
All products are subjected to out-going AQL’s of 0.25% for brightness matching, visual alignment and dimensions,
0.065% for electrical and functional.
Features
• 0.200" High, Dot Matrix Character
• 128 Special ASCII Characters for English, German,
Italian, Swedish, Danish, and Norwegian Languages
• Wide Viewing Angle: X Axis ±50° Maximum,
Y Axis ±75° Maximum
• Close Multi-line Spacing, 0.8" Centers
• Fast Access Time, 110 ns at 25°C
• Full Size Display for Stationary Equipment
• Built-in Memory
• Built-in Character Generator
• Built-in Multiplex and LED Drive Circuitry
• Direct Access to Each Digit Independently and Asynchronously
2006-01-23
• Independent Cursor Function
• Memory Function: Clears Character and Cursor Memory Simultaneously
• True Blanking for Intensity Dimming Applications
• End Stackable, 4-Character Package
• Intensity Coded for Display Uniformity
• Extended Operating Temperature Range:
–40°C to +85°C
• Superior ESD Immunity
• Wave Solderable
• TTL Compatible over Operating Temperature Range
• Interdigit Blanking
See Appnotes 18, 19, 22, and 23 for additional
information.
1
Ordering Information
Type
Color of Emission
Ordering Code
DLR2416
red
Q68000A8094
DLO2416
high efficiency red
Q68000A8095
DLG2416
green
Q68000A8096
DLX2416 Z
V
OSRAM
YYWW
Luminous
Intensity
Code
0.46 (0.018) ±0.05 (0.002) 18 pl.
2.54 (0.100) 16 pl.
6.6 (0.260) ref.
1.78 (0.070) ±0.08 (0.003)
EIA
0.25 (0.010) 8 pl.
Part No. Date Code
4.06 (0.160) ±0.51 (0.020)
1.27 (0.050) 4 pl.
Pin 1
Indicator
0.3 (0.012) ±0.05 (0.002) 18 pl.
At Seating Plane
2.41 (0.095) ref.
15.24 (0.600) ±0.51 (0.020)
25.4 (1.000) max.
0.79 (0.031)
3.45 (0.136)
5.03 (0.198)
0.79 (0.031)
20.32 (0.800) max.
6.35 (0.250)
Tolerance: ±0.25 (0.010)
IDOD5203
2006-01-23
2
Maximum Ratings
Parameter
Symbol
Value
Unit
Operating temperature range
Top
– 40 … + 85
°C
Storage temperature range
Tstg
– 40 … + 100
°C
DC supply voltage
– 0.5 … + 7.0
V
Input Voltage, Respect to GND (all inputs)
– 0.5 to VCC + 0.5
V
Solder temperature 0.063“ (1.59 mm)
below seating plane, t < 5.0 s
Ts
260
°C
Relative humidity at 85°C
RH
85
Characteristics
(TA = 25 °C)
Wavelength at peak emission
IF = 0 mA
Viewing angle (off normal axis)
(typ.)
hor. (typ.)
ver. (typ.)
Character Height
Time averaged luminous intensity
(100% brightness, VCC = 5.0 V)
(typ.)
LED to LED intensity matching
(max.)
LED to LED hue matching at VCC = 5.0 V
(max.)
2006-01-23
Unit
DLG2416
Values
DLO2416
Symbol
DLR2416
Parameter
red
high
green
efficiency
red
λpeak
660
630
565
nm
2ϕ
±50
±75
±50
±75
±50
±75
deg
deg.
h
0.200
5.08
0.200
5.08
0.200
5.08
inch
mm
60
100
120
µcd/LED
1.8:1.0
1.8:1.0
1.8:1.0
±2.0
3
nm
Top View
18 17 16 15 14 13 12 11 10
Digit 3
1
2
Digit 2
3
4
Digit 1
5
6
Digit 0
7
8
9
IDPA5111
Pins and Functions
Pin
Function
Pin
Function
Pin
Function
1
CE1 Chip Enable
7
A1 Digit Select
13
D2 Data Input
2
CE2 Chip Enable
8
A0 Digit Select
14
D3 Data Input
3
CLR Clear
9
VCC
15
D6 Data Input
4
CUE Cursor Enable
10
GND
16
D5 Data Input
5
CU Cursor Select
11
D0 Data Input
17
D4 Data Input
6
WR Write
12
D1 Data Input
18
BL Display Blank
Timing Characteristics - Write Cycle Waveforms
2.0 V
0.8 V
CE1, CE2
CU, CLR
TCES
TCUS
TCLRD
TCEH
TCUH
2.0 V
0.8 V
A 0 , A1
TAS
TAH
2.0 V
0.8 V
D0-D6
TDS
WR
2.0 V
0.8 V
TW
TACC
Note: These waveforms are not edge triggered.
2006-01-23
TDH
4
DC Characteristics
Parameter
–40°C
+25°C
+85°C
Unit
Condition
Min.
Typ.
Max.
Min.
Typ.
Max.
Min.
Typ.
Max.
ICC 80 Dots on
135
160
110
130
95
115
mA
VCC=5.0 V
ICC Cursor
all Dots at
50%
135
100
100
mA
VCC=5.0 V
ICC Blank
2.8
4.0
2.3
3.0
2.0
2.5
mA
VCC=5.0 V
BL=0.8 V
IIL (all inputs)
30
60
120
25
50
100
80
µA
VIN=0.8 V,
VCC=5.0 V
VIH
2.0
2.0
2.0
V
VCC=5.0 V
±0.5 V
VIL
0.8
0.8
0.8
V
VCC=5.0 V
±0.5 V
VCC
4.5
5.0
5.5
4.5
5.0
5.5
4.5
5.0
5.5
V
AC Characteristics (guaranteed minimum timing parameters at VCC=5.0 V ±0.5 V)
Parameter
Symbol
–40°C
+25°C
+85°C
Unit
Chip Enable Set Up Time
TCES
ns
Address Set Up Time
TAS
10
10
10
ns
Cursor Set Up Time
TCUS
10
10
10
ns
Chip Enable Hold Time
TCEH
ns
Address Hold Time
TAH
40
ns
Cursor Hold Time
TCUH
40
ns
Clear Disable Time
TCLRD
1.0
1.0
1.0
µs
Write Time
TW
60
70
90
ns
Data Set Up Time
TDS
50
ns
Data Hold Time
TDH
40
ns
Clear Time
TCLR
1.0
1.0
1.0
µs
Access Time
TACC
90
110
140
ns
Note: TACC= Set Up Time + Write Time + Hold Time.
2006-01-23
5
Internal Block Diagram
Display
Rows 0 to 6
3
2
1
BL
Row Control Logic
Row Drivers
OSC
Columns 0 to 19
128
Counter
Timing and Control Logic
7
Counter
RAM
Memory
4 x 7 bit
7-bit ASCII Code
Cursor
Memory
4 x 1 bit
Address
Lines
WR
A0
A1
2006-01-23
Latches
D6
D5
D4
D3
D2
D1
D0
Row Decoder
Column Decoder
RAM Read Logic
ROM
128 x 35 bit
ASCII
Character
Decode
4480 bits
Column Data
Column
Enable
Latches and
Column
Drivers
Cursor Memory Bits 0 to 3
Write
Address
Decoder
CUE
IDBD5066
6
Loading Data Table
Control
Address
A0
Data
BL
CE1 CE2 CUE CU
WR CLR A1
D6
D5
H
X
X
L
X
H
H
previously loaded display
H
H
X
L
X
X
H
X
X
X
X
H
X
H
L
X
X
H
X
X
X
H
L
L
L
H
L
H
L
L
H
L
L
L
H
L
H
L
H
L
L
L
H
L
H
H
L
L
L
H
L
L
X
X
X
X
H
L
L
L
H
X
X
L
H
L
L
L
Display Digit
D3
D2
D1
D0
X
X
X
X
X
X
X
X
X
X
H
L
L
L
H
H
H
L
H
L
H
L
H
L
L
H
H
H
H
L
L
H
H
X
X
blank display
H
L
H
H
H
H
X
H
L
X
X
clears character displays
H
L
H
X
X
see character code
L
D4
L
3
2
1
G
R
E
Y
G
R
E
Y
X
G
R
E
Y
L
H
G
R
E
E
H
L
H
G
R
U
E
H
H
L
L
G
L
U
E
L
L
H
L
B
L
U
E
L
H
H
H
G
L
U
E
see character set
X=don’t care
Loading Cursor Table
Digit
BL
CE1
CE2
CE3
CE4
CUE
CU
WR
CLR
A1
H
X
X
X
X
L
X
H
H
H
X
X
X
X
H
X
H
H
H
H
L
L
H
L
H
H
H
L
L
H
H
H
H
L
L
H
H
H
L
H
H
H
H
X
H
H
A0
3
2
1
B
E
A
R
H
display previously stored cursors
B
E
A
R
L
H
L
L
X
X
X
X
X
X
H
B
E
A
n
L
L
H
L
H
X
X
X
X
X
X
H
B
E
n
n
H
L
L
H
H
L
X
X
X
X
X
X
H
B
n
n
n
L
H
L
L
H
H
H
X
X
X
X
X
X
H
n
n
n
n
L
L
H
L
L
H
H
L
X
X
X
X
X
X
L
n
E
n
n
X
X
X
L
X
H
H
disable cursor display
B
E
A
R
H
H
L
L
L
L
L
H
H
B
E
A
R
X
X
X
X
H
H
X
H
display stored cursors
B
E
n
n
H
X=don’t care n= all dots on
2006-01-23
7
D6
X
D5
X
D4
X
D3
X
D2
X
D1
X
D0
L
Loading Data
DLX2416—Flashing Circuit Using a 555 and
Flashing (Blanking) Timing
Setting the chip enable (CE1, CE2) to their true state will
enable data loading. The desired data code (D0-D6) and
digit address (A0, A1) must be held stable during the
write cycle for storing new data.
Data entry may be asynchronous and random. Digit 0 is
defined as right hand digit with A1=A2=0.
To clear the entire internal four-digit memory hold the
clear (CLR) low for 1.0 µs. All illuminated dots will be
turned off within one complete display multiplex cycle,
1.0 ms minimum. The clear function will clear both the
ASCII RAM and the cursor RAM.
Loading Cursor
VCC = 5 V
7
2
R2
555
Timer
To BL
Pin on
Display
Setting the chip enables (CE1, CE2) and cursor select
(CU) to their true state will enable cursor loading. A write
(WR) pulse will now store or remove a cursor into the
digit location addressed by A0, A1, as defined in data
entry. A cursor will be stored if D0=1 and will removed if
D0=0. The cursor (CU) pulse width should not be less
than the write (WR) pulse or erroneous data may appear
in the display.
If the cursor is not required, the cursor enable signal
(CUE) may be tied low to disable the cursor function. For
a flashing cursor, simply pulse CUE. If the cursor has
been loaded to any or all positions in the display, then
CUE will control whether the cursor(s) or the characters
will appear. CUE does not affect the contents of cursor
memory.
Display Blanking
R1
4.7 k Ω
8
1
100 k Ω
3
6
4
5
C3
10 µF
C4
0.01 µF
IDCD5033
1
~500 ms
Blanking Pulse Width
~ 50% Duty Factor
~ 2 Hz Blanking Frequency ~
IDCD5035
DLX2416—Dimming Circuit Using a 556 and
Dimming (Blanking) Timing
VCC = 5 V
Blanking the display may be accomplished by loading a
blank or space into each digit of the display or by using
the (BL) display blank input.
Setting the (BL) input low does not affect the contents of
either data or cursor memory.
A flashing circuit can easily be constructed using a 555
as table multivibrator. Figure 4 illustrates a circuit in
which varying R2 (100K~10K) will have a flash rate of
1.0 Hz~10 Hz.
The display can be dimmed by pulse width modulating
the (BL) at a frequency sufficiently fast to not interfere
with the internal clock. The dimming signal frequency
should be 2.5 kHz or higher. Dimming the display also
reduces power consumption.
An example of a simple dimming circuit using a 556 is
illustrated in Figure 5. Adjusting potentiometer R3 will
dim the display by changing the blanking pulse duty
cycle.
Design Considerations
R2
47 k Ω
Dimming (Blanking)
Control
1
14
2
13
3
12
4
556
11
Dual Timer
5
10
6
9
7
8
R1
R3
500 k Ω
200 Ω
C3
1000 pF
C2
0.01 µF
C4
0.01 µF
To BL Pin
on Display
C1
4700 pF
IDCD5034
1
For details on design and applications of the DLX2416
using standard bus configurations in multiple display systems, or parallel I/O devices, such as the 8255 with an
8080 or memory mapped addressing on processors such
as the 8080, Z80, 6502, or 6800, refer to Appnote 14 at
www.osram-os.com.
~ 200 µs
~ 5 kHz Blanking Frequency
4 µs min., 196 µs max.
IDCD5036
2006-01-23
8
Character Set
D0
D1
D2
D3
D6 D5 D4 HEX
ASCII
CODE
0 0 0
1
0 1 0
2
0 1 1
3
1 0 0
4
1 0 1
5
1 1 0
6
1 1 1
7
1
1
1
1
1
1
1
8
1
9
A
1
1
B
1
C
1
1
D
1
1
E
1
1
1
1
F
IDCS5087
Notes:
1. High=1 level
2. Low= 0 level
3. Upon power up, the device will initialize in a random state.
Typical Schematic, 16-Character System
+5V
GND
D15
BL
D0-D6
CLR
WR
CU
CUE
A0, A1
CE2
D12 D11
D8 D7
D4 D3
D0
7
14
2
CE2
CE2
CE1
CE1
CE1
IDCD5037
2006-01-23
9
Revision History: 2006-01-23
Previous Version: 2004-11-04
Page
Subjects (major changes since last revision)
Date of change
all
complete rework
2004-09-13
all
Lead free device
2006-01-23
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances. For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs
incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose! Critical
components1) may only be used in life-support devices or systems2) with the express written approval of OSRAM OS.
1)
A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure
of that life-support device or system, or to affect its safety or the effectiveness of that device or system.
2)
Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human
life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered.
2006-01-23
10
Electrical and Mechanical Considerations
Voltage Transient Suppression
We recommend that the same power supply be used for the display and the components that interface with the display to avoid
logic inputs higher than VCC. Additionally, the LEDs may cause
transients in the power supply line while they change display
states. The common practice is to place .01 mF capacitors close to
the displays across VCC and GND, one for each display, and one
10 mF capacitor for every second display.
Optical Considerations
The 0.200" high characters of the DLX2416 gives readability up to
eight feet. Proper filter selection enhances readability over this distance.
Filters enhance the contrast ratio between a lit LED and the character background intensifying the discrimination of different characters. The only limitation is cost. Take into consideration the
ambient lighting environment for the best cost/benefit ratio for filters.
Incandescent (with almost no green) or fluorescent (with almost no
red) lights do not have the flat spectral response of sunlight. Plastic band-pass filters are an inexpensive and effective way to
strengthen contrast ratios.
The DLR2416 is a standard red display and should be matched
with long wavelength pass filter in the 600 nm to 620 nm range.
The DLO2416 is a high efficiency red display and should be
matched with a long wavelength pass filter in the 470 nm to 590
nm range. The DLG2416 should be matched with a yellow-green
band-pass filter that peaks at 565 nm. For displays of multiple colors, neutral density gray filters offer the best compromise.
Additional contrast enhancement is gained by shading the displays. Plastic band-pass filters with built-in louvers offer the next
step up in contrast improvement. Plastic filters can be improved
further with anti-reflective coatings to reduce glare. The trade-off is
fuzzy characters. Mounting the filters close to the display reduces
this effect. Take care not to overheat the plastic filter by allowing for
proper air flow.
Optimal filter enhancements are gained by using circular polarized, anti-reflective, band-pass filters. Circular polarizing further
enhances contrast by reducing the light that travels through the filter and reflects back off the display to less than 1%.
Several filter manufacturers supply quality filter materials. Some of
them are: Panelgraphic Corporation, W. Caldwell, NJ; SGL Homalite, Wilmington, DE; 3M Company, Visual Products Division, St.
Paul, MN; Polaroid Corporation, Polarizer Division, Cambridge,
MA; Marks Polarized Corporation, Deer Park, NY, Hoya Optics,
Inc., Fremont, CA.
One last note on mounting filters: recessing displays and bezel
assemblies is an inexpensive way to provide a shading effect in
overhead lighting situations. Several Bezel manufacturers are:
R.M.F. Products, Batavia, IL; Nobex Components, Griffith Plastic
Corp., Burlingame, CA; Photo Chemical Products of California,
Santa Monica, CA; .E.E.-Atlas, Van Nuys, CA.
Refer to Appnote 23 at www.osram-os.com.
ESD Protection
The silicon gate CMOS IC of the DLX2416 is quite resistant to
ESD damage and capable of withstanding discharges greater than
2.0 kV. However, take all the standard precautions, normal for
CMOS components. These include properly grounding personnel,
tools, tables, and transport carriers that come in contact with
unshielded parts. If these conditions are not, or cannot be met,
keep the leads of the device shorted together or the parts in
anti-static packaging.
Soldering Considerations
The DLX2416 can be hand soldered with SN63 solder using a
grounded iron set to 260°C.
Wave soldering is also possible following these conditions: Preheat that does not exceed 93°C on the solder side of the PC board
or a package surface temperature of 85°C. Water soluble organic
acid flux (except carboxylic acid) or rosin-based RMA flux without
alcohol can be used.
Wave temperature of 245°C ±5°C with a dwell between 1.5 sec. to
3.0 sec. Exposure to the wave should not exceed temperatures
above 260°C for five seconds at 0.063" below the seating plane.
The packages should not be immersed in the wave.
Post Solder Cleaning Procedures
The least offensive cleaning solution is hot D.I. water (60 °C) for
less than 15 minutes. Addition of mild saponifiers is acceptable. Do
not use commercial dishwasher detergents.
For faster cleaning, solvents may be used. Carefully select any solvent as some may chemically attack the nylon package. Maximum
exposure should not exceed two minutes at elevated temperatures. Acceptable solvents are TF (trichorotribluorethane), TA, 111
Trichloroethane, and unheated acetone.
Note:
Acceptable commercial solvents are: Basic TF, Arklone, P.
Genesolv, D. Genesolv DA, Blaco-Tron TF and Blaco-Tron TA.
Unacceptable solvents contain alcohol, methanol, methylene chloride, ethanol, TP35, TCM, TMC, TMS+, TE, or TES. Since many commercial mixtures exist, contact a solvent vendor for chemical
composition information. Some major solvent manufacturers are:
Allied Chemical Corporation, Specialty Chemical Division, Morristown, NJ; Baron-Blakeslee, Chicago, IL; Dow Chemical, Midland, MI;
E.I. DuPont de Nemours & Co., Wilmington, DE.
For further information refer to Appnotes 18 and 19 at
www.osram-os.com.
An alternative to soldering and cleaning the display modules is to use
sockets. Standard pin DIP sockets .600" wide with 0.100" centers
work well for single displays. Multiple display assemblies are best
handled by longer SIP sockets or DIP sockets when available for uniform package alignment. Socket manufacturers are Aries Electronics,
Inc., Frenchtown, NJ; Garry Manufacturing, New Brunswich, NJ; Robinson-Nugent, New Albany, IN; and Samtec Electronic Hardware,
New Albany, IN.
For further information refer to Appnote 22 at www.osram-os.com.
2006-01-23
Published by
OSRAM Opto Semiconductors GmbH
Wernerwerkstrasse 2, D-93049 Regensburg
www.osram-os.com
© All Rights Reserved.
11
