MBRF1060CT
MBRF1060CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3隔离片
    DIODEARRAYSCHOTTKY60VITO220
MBRF1060CT 数据手册
MBRF1060CT Technical Data Data Sheet N0822, Rev. A Green Products MBRF1060CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions (In mm): SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF1060CT Technical Data Data Sheet N0822, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 10 60 CT SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF1060CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. 60 Units V IF (AV) 50% duty cycle @TC =133°C, rectangular wave form 5(Per leg) 10(Per device) A IFSM 8.3 ms, half Sine pulse 125 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • A MBRF1060CT Technical Data Data Sheet N0822, Rev. A Green Products Electrical Characteristics: * Characteristics Forward Voltage Drop (per leg)* Reverse Current at DC condition (per leg) * Reverse Current (per leg)* Symbol VF1 VF2 IR1 Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) CT IR2 LS dv/dt VISO Condition @ 5A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Typ. 0.66 0.60 0.008 Max. 0.70 0.65 1.0 Units V V mA 3 15 mA 180 220 pF 8.0 - nH - 10,000 4500 V/μs V - 3500 - 1500 Pulse Width < 300µs, Duty Cycle
MBRF1060CT 价格&库存
很抱歉,暂时无法提供与“MBRF1060CT”相匹配的价格&库存,您可以联系我们找货
