PDTC114E series
NPN resistor-equipped transistors;
R1 = 10 k, R2 = 10 k
Rev. 12 — 21 December 2011
Product data sheet
1. Product profile
1.1 General description
NPN Resistor-Equipped Transistor (RET) family in small Surface-Mounted Device (SMD)
plastic packages.
Table 1.
Product overview
Type number
Package
JEDEC
PNP
complement
Package
configuration
Nexperia
JEITA
PDTC114EE
SOT416
SC-75
PDTA114EE
ultra small
PDTC114EM
SOT883
SC-101
PDTA114EM
leadless ultra small
PDTC114ET
SOT23
TO-236AB PDTA114ET
small
PDTC114EU
SOT323
SC-70
very small
PDTA114EU
1.2 Features and benefits
100 mA output current capability
Built-in bias resistors
Simplifies circuit design
Reduces component count
Reduces pick and place costs
AEC-Q101 qualified
1.3 Applications
Digital application in automotive and
industrial segments
Control of IC inputs
Cost-saving alternative for BC847/857
series in digital applications
Switching loads
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
open base
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
50
V
IO
output current
100
mA
R1
bias resistor 1 (input)
7
10
13
k
R2/R1
bias resistor ratio
0.8
1.0
1.2
PDTC114E series
Nexperia
NPN resistor-equipped transistors; R1 = 10 k, R2 = 10 k
2. Pinning information
Table 3.
Pinning
Pin
Description
Simplified outline
Graphic symbol
SOT23; SOT323; SOT416
1
input (base)
2
GND (emitter)
3
3
3
R1
output (collector)
1
R2
1
2
2
006aaa144
sym007
SOT883
1
input (base)
2
GND (emitter)
3
1
3
3
R1
2
output (collector)
1
Transparent
top view
R2
2
sym007
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
PDTC114EE
SC-75
plastic surface-mounted package; 3 leads
SOT416
PDTC114EM
SC-101
leadless ultra small plastic package; 3 solder lands; SOT883
body 1.0 0.6 0.5 mm
PDTC114ET
SOT23
PDTC114EU
SC-70
SOT323
4. Marking
Table 5.
Type number
Marking code[1]
PDTC114EE
09
PDTC114EM
DS
PDTC114ET
*16
PDTC114EU
*09
[1]
PDTC114E_SER
Product data sheet
Marking codes
* = placeholder for manufacturing site code.
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 17
PDTC114E series
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
PDTC114E_SER
Product data sheet
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
50
V
VCEO
open base
50
V
VEBO
emitter-base voltage
open collector
10
V
VI
input voltage
positive
+40
V
negative
10
V
IO
output current
100
mA
ICM
peak collector current
single pulse; tp 1 ms
100
mA
Ptot
total power dissipation
Tamb 25 C
PDTC114EE (SOT416)
[1][2]
150
mW
PDTC114EM (SOT883)
[2][3]
250
mW
PDTC114ET (SOT23)
[1]
250
mW
PDTC114EU (SOT323)
[1]
200
mW
Tj
junction temperature
150
C
Tamb
ambient temperature
65
+150
C
Tstg
storage temperature
65
+150
C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Reflow soldering is the only recommended soldering method.
[3]
Device mounted on an FR4 PCB with 70 m copper strip line, standard footprint.
3 of 17
PDTC114E series
Nexperia
006aac778
300
Ptot
(mW)
(1)
(2)
200
(3)
100
-25
25
75
125
175
Tamb (°C)
(1) SOT23; FR4 PCB, standard footprint
SOT883; FR4 PCB with 70 m copper strip line, standard footprint
(2) SOT323; FR4 PCB, standard footprint
(3) SOT416; FR4 PCB, standard footprint
Fig 1.
Power derating curves
6. Thermal characteristics
Table 7.
PDTC114E_SER
Product data sheet
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from junction
to ambient
in free air
Min
Typ
Max
Unit
PDTC114EE (SOT416)
[1][2]
830
K/W
PDTC114EM (SOT883)
[2][3]
500
K/W
PDTC114ET (SOT23)
[1]
500
K/W
PDTC114EU (SOT323)
[1]
625
K/W
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
4 of 17
PDTC114E series
Nexperia
006aac781
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
0.2
102
0.1
0.05
0.02
10
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse duration for
PDTC114EE (SOT416); typical values
006aac782
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
102
0.33
0.2
0.1
0.05
10
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
FR4 PCB, 70 m copper strip line
Fig 3.
PDTC114EM (SOT883); typical values
PDTC114E_SER
Product data sheet
5 of 17
PDTC114E series
Nexperia
006aac779
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
102
0.2
0.1
0.05
0.02
10
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
Fig 4.
PDTC114ET (SOT23); typical values
006aac780
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
102
0.2
0.1
0.05
0.02
10
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
Fig 5.
PDTC114EU (SOT323); typical values
PDTC114E_SER
Product data sheet
6 of 17
PDTC114E series
Nexperia
7. Characteristics
Table 8.
Characteristics
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base
cut-off current
VCB = 50 V; IE = 0 A
100
nA
ICEO
collector-emitter
cut-off current
VCE = 30 V; IB = 0 A
1
A
VCE = 30 V; IB = 0 A;
Tj = 150 C
5
A
IEBO
emitter-base
cut-off current
VEB = 5 V; IC = 0 A
400
A
hFE
DC current gain
VCE = 5 V; IC = 5 mA
30
VCEsat
collector-emitter
saturation voltage
IC = 10 mA; IB = 0.5 mA
150
mV
VI(off)
off-state input
voltage
VCE = 5 V; IC = 100 A
1.1
0.8
V
VI(on)
on-state input
voltage
VCE = 0.3 V; IC = 10 mA
2.5
1.8
V
R1
7
10
13
k
R2/R1
bias resistor ratio
0.8
1.0
1.2
Cc
collector capacitance VCB = 10 V; IE = ie = 0 A;
f = 1 MHz
2.5
pF
fT
transition frequency
230
MHz
[1]
PDTC114E_SER
Product data sheet
VCE = 5 V; IC = 10 mA;
f = 100 MHz
[1]
Characteristics of built-in transistor.
7 of 17
PDTC114E series
Nexperia
006aac768
103
hFE
006aac769
1
(1)
VCEsat
(V)
(2)
(3)
102
10-1
(1)
10
(2)
(3)
1
10-1
1
102
10
10-2
1
102
10
IC (mA)
IC (mA)
VCE = 5 V
IC/IB = 20
(1) Tamb = 100 C
(1) Tamb = 100 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 40 C
(3) Tamb = 40 C
Fig 6.
DC current gain as a function of collector
current; typical values
Fig 7.
006aac770
10
Collector-emitter saturation voltage as a
function of collector current; typical values
006aac771
10
VI(off)
(V)
VI(on)
(V)
(1)
(1)
(2)
1
(2)
1
(3)
10-1
10-1
1
(3)
102
10
10-1
10-1
IC (mA)
VCE = 0.3 V
VCE = 5 V
(1) Tamb = 40 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 100 C
(3) Tamb = 100 C
On-state input voltage as a function of
PDTC114E_SER
Product data sheet
10
IC (mA)
(1) Tamb = 40 C
Fig 8.
1
Fig 9.
Off-state input voltage as a function of
8 of 17
PDTC114E series
Nexperia
006aac772
3
Cc
(pF)
006aac757
103
fT
(MHz)
2
102
1
40
50
VCB (V)
f = 1 MHz; Tamb = 25 C
10
10-1
1
102
10
IC (mA)
VCE = 5 V; Tamb = 25 C
Fig 10. Collector capacitance as a function of
collector-base voltage; typical values
Fig 11. Transition frequency as a function of collector
current; typical values of built-in transistor
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PDTC114E_SER
Product data sheet
9 of 17
PDTC114E series
Nexperia
9. Package outline
0.62
0.55
0.55
0.47
0.95
0.60
1.8
1.4
3
0.45
0.15
0.50
0.46
3
0.30
0.22
1.75 0.9
1.45 0.7
1.02
0.95
0.65
1
0.30
0.22
2
0.30
0.15
0.25
0.10
2
1
0.20
0.12
1
0.35
Dimensions in mm
04-11-04
Fig 12. Package outline PDTC114EE (SOT416/SC-75)
3.0
2.8
Dimensions in mm
03-04-03
Fig 13. Package outline PDTC114EM (SOT883/SC-101)
1.1
0.9
2.2
1.8
1.1
0.8
0.45
0.15
3
3
0.45
0.15
2.5 1.4
2.1 1.2
2.2 1.35
2.0 1.15
1
1
2
0.48
0.38
1.9
Dimensions in mm
0.25
0.10
1.3
04-11-04
Fig 14. Package outline PDTC114ET (SOT23)
2
0.4
0.3
0.15
0.09
Dimensions in mm
04-11-04
Fig 15. Package outline PDTC114EU (SOT323/SC-70)
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Product data sheet
Description
Packing quantity
3000
10000
PDTC114EE
SOT416
4 mm pitch, 8 mm tape and reel
-115
-135
PDTC114EM
SOT883
2 mm pitch, 8 mm tape and reel
-315
PDTC114ET
SOT23
-215
-235
PDTC114EU
SOT323
-115
-135
[1]
PDTC114E_SER
Package
For further information and the availability of packing methods, see Section 14.
10 of 17
PDTC114E series
Nexperia
11. Soldering
2.2
1.7
solder lands
solder resist
1
0.85
2
solder paste
0.5
(3×)
occupied area
Dimensions in mm
0.6
(3×)
1.3
sot416_fr
Fig 16. Reflow soldering footprint PDTC114EE (SOT416/SC-75)
1.3
0.7
R0.05 (12×)
solder lands
solder resist
0.9
0.6
0.7
solder paste
0.25
(2×)
occupied area
0.3
(2×)
0.3
0.4
(2×)
0.4
Dimensions in mm
sot883_fr
Fig 17. Reflow soldering footprint PDTC114EM (SOT883/SC-101)
PDTC114E_SER
Product data sheet
11 of 17
PDTC114E series
Nexperia
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig 18. Reflow soldering footprint PDTC114ET (SOT23)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig 19. Wave soldering footprint PDTC114ET (SOT23)
PDTC114E_SER
Product data sheet
12 of 17
PDTC114E series
Nexperia
2.65
1.85
1.325
solder lands
solder resist
2
2.35
0.6
(3×)
3
solder paste
1.3
1
occupied area
0.5
(3×)
Dimensions in mm
0.55
(3×)
sot323_fr
Fig 20. Reflow soldering footprint PDTC114EU (SOT323/SC-70)
4.6
2.575
1.425
(3×)
solder lands
solder resist
occupied area
1.8
3.65 2.1
09
(2×)
Dimensions in mm
preferred transport
sot323_fw
Fig 21. Wave soldering footprint PDTC114EU (SOT323/SC-70)
PDTC114E_SER
Product data sheet
13 of 17
PDTC114E series
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PDTC114E_SER v.12
20111221
Product data sheet
PDTC114E_SER v.11
Modifications:
Figure 3 and 5: corrected
PDTC114E_SER v.11
20111121
Product data sheet
PDTC114E_SERIES v.10
20040805
Product specification
PDTC114E_SERIES v.9
PDTC114E_SERIES v.9
20030410
PDTC114E_SER
Product data sheet
14 of 17
PDTC114E series
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
PDTC114E_SER
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
15 of 17
PDTC114E series
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PDTC114E_SER
Product data sheet
16 of 17
PDTC114E series
Nexperia
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9
Quality information . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Packing information . . . . . . . . . . . . . . . . . . . . 10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information. . . . . . . . . . . . . . . . . . . . . 16
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Date of release: 21 December 2011
