DLP-RFIDLP8C
LEAD-FREE
8-Channel Reader/Writer
FEATURES:
ISO 15693, 18000-3, 14443*, Tag-it™ HF-I Compatible
Can read the UID/SID of up to 15 Tags Simultaneously
13.56MHz Reader/Writer
8 Channels for External Antenna Connections
FCC/IC/CE Modular Approvals in Place
USB Port Powered from Windows, CE or Linux PC
Both USB and RS232 Interfaces Provided
USB Interface; No Driver Development Required for Windows, CE or Linux PC
Operating Temperatures: 0°C to 70°C
Dimensions: (L x W x H) 4.36” x 3.32” x 0.6”
APPLICATIONS INCLUDE:
Real-Time Security
Personal Identification
Pharmaceutical Tracking
Inventory/Asset Management & Tracking
Library/Book Management & Tracking
Baggage Tagging
Sports Event Timing
1.0 INTRODUCTION
The DLP-RFID-LP8C is a low-cost, USB-powered module for reading from and writing to ISO 15693, ISO
18000-3, ISO14443* and Tag-it™ intelligent RFID transponder tags via up to eight external antennas. It
has the ability to both read and write up to 256 bytes of data in addition to reading the unique identifier
(UID/SID). All of the DLP-RFID-LP8C’s electronics reside on a single, compact PCB; and all operational
power is taken from the host Windows/Windows CE/Linux PC via the USB interface. Up to eight external
antennas can be connected via standard SMA connectors.
* - Contact DLP Design for ISO14443 implementation information.
Rev. 1.4 (November 2009)
1
© DLP Design, Inc.
2.0 APPLICATION DEVELOPMENT
Demonstration source code written in Visual C++ is provided with the purchase of a DLP-RFID-LP8C
module that demonstrates the communications protocol. Using the Virtual COM Port USB drivers, the
DLP-RFID-LP8C appears to the host PC (Windows, Linux, Mac) as an RS232 port.
3.0 MECHANICAL DIMENSIONS IN INCHES (MM)
2.08 typ
(53.0 typ)
0.45 typ
(11.4typ)
0.12 typ
(3.1 typ)
0.60 typ
(15.1 typ)
0.37 typ
(9.3 typ)
3.0 typ
(76.2typ)
1.55 typ
(39.4typ)
2.70 typ
(68.6typ)
3.84 typ
(97.6typ)
4.36 typ
(111 typ)
2.50 typ
(64 typ)
3.32 typ
(84typ)
2.6 typ
(66typ)
2
© DLP Design, Inc.
4.0 REGULATORY AGENCY CONSIDERATIONS
4.1 AGENCY IDENTIFICATION NUMBERS
Compliance with the appropriate regulatory agencies is essential in the deployment of all intentional
radiators. DLP Design has obtained modular approval for this RF product such that an OEM need only
meet a few basic requirements in order to utilize their end product under this approval. Corresponding
agency identification numbers are listed below:
PART NUMBER
US/FCC
CAN/IC
DLP-RFID-LP8C
SX90LP8C
5675A-0LP8C
4.2 EXTERNAL ANTENNAS
The DLP-RFID1-LP8C is approved for use with selected external antennas. Connection is made via
reverse-polarity SMA connectors.
Two different antennas are available from DLP Design: the DLP-FANT and the DLP-RFID-ANT.
DLP-FANT
DLP-RFID-ANT
The DLP-FANT ferrite-based antenna provides a compact footprint for space-constrained applications
and provides up to a 1.25-inch read range.
The DLP-FANT requires a coax cable with a reverse-polarity SMA connector at one end for connection
to the DLP-RFID-LP8C reader. This coax cable is available in a 3-foot length from DLP Design under
part number DLP-COAX1.
The DLP-RFID-ANT ships with an attached 15-foot coax cable with a reverse-polarity SMA connector
and provides up to 4 inches of read range.
3
© DLP Design, Inc.
4.3 FCC/IC REQUIREMENTS FOR MODULAR APPROVAL
Any changes or modifications to the DLP-RFID-LP8C’s printed circuit board could void the user’s
authority to operate the equipment. Operation of an unapproved antenna could void the user’s authority
4.4 WARNINGS
Operation is subject to the following two conditions: (1) This device may not cause harmful interference;
and (2) this device must accept any interference received, including interference that may cause
undesirable operation.
To reduce potential radio interference with other users, the antenna type and its gain should be so
chosen that the equivalent isotropically-radiated power (e.i.r.p.) is not more than that permitted for
successful communication.
This device is intended for use under the following conditions:
1. The transmitter module may not be co-located with any other transmitter or antenna; and,
2. The module is approved using the FCC “unlicensed modular transmitter approval” method.
As long as these two conditions are met, further transmitter testing will not be required. However, the
OEM integrator is still responsible for testing their end product for any additional compliance measures
necessitated by the installation of this module (i.e. digital device emissions, PC peripheral requirements,
etc.).
Note: In the event that these conditions cannot be met (i.e. co-location with another transmitter), then
the FCC authorization is no longer valid, and the corresponding FCC ID may not be used on the final
product. Under these circumstances, the OEM integrator will be responsible for re-evaluating the end
product (including the transmitter) and obtaining a separate FCC authorization.
4.5 OEM PRODUCT LABELING
The final end product must be labeled in a visible area with the following text:
“Contains TX FCC ID: SX90LP8C”
4.6 RF EXPOSURE
In order to comply with FCC RF exposure-compliance requirements, the antenna used for this transmitter
must not be co-located or operating in conjunction with any other antenna or transmitter.
4
© DLP Design, Inc.
4.7 ADDITIONAL INFORMATION FOR OEM INTEGRATORS
The end user should NOT be provided with any instructions on how to remove or install the DLP-RFIDLP8C. This device has been pre-certified to operate with the antenna models listed below:
DLP Design Large Loop Antenna
DLP Design Small Loop Antenna
DLP Design Ferrite Antenna
5.0 DISCLAMER
Neither the whole nor any part of the information contained herein nor the product described in this
datasheet may be adapted or reproduced in any material or electronic form without the prior written
consent of the copyright holder.
This product and its documentation are supplied on an as-is basis, and no warranty as to their suitability
for any particular purpose is either made or implied. DLP Design will not accept any claim for damages
whatsoever arising as a result of use or failure of this product. Your statutory rights are not affected.
This product or any variant of it is not intended for use in any medical appliance, device or system in
which the failure of the product might reasonably be expected to result in personal injury.
This document provides preliminary information that may be subject to change without notice.
6.0 CONTACT INFORMATION
DLP Design, Inc.
1605 Roma Lane
Allen, TX 75013
Phone:
Fax:
Email:
Internet:
469-964-8027
415-901-4859
support@dlpdesign.com
http://www.dlpdesign.com
5
© DLP Design, Inc.
很抱歉,暂时无法提供与“DLP-RFID-ANT”相匹配的价格&库存,您可以联系我们找货
