VL-EPM-16F
VL-EPM-16F
    VERSALOGIC
    SBC VORTEX 800 MHZ 256MB
VL-EPM-16F 数据手册
Product Data Sheet Tomcat PC/104-Plus Single Board Computer 95 x 96 mm (3.76 x 3.78”) Overview Highlights The Tomcat single board computer features the ultra-low power DMP Vortex86DX processor. Based on the PC/104-Plus industry standard form factor, the Tomcat supports PCI and ISA stackable expansion boards. With mid-range performance (800 MHz) and ultra-low power consumption (3.0W typ.), the Tomcat is well suited to size, weight, and power constrained applications. With no moving parts (fanless operation), full industrial temperature rating, soldered-on RAM, and a compact rugged form factor, it is ideal for operation in harsh, mobile, and/or remote environments. ƒƒ DMP Vortex86DX processor ƒƒ Fanless operation ƒƒ Very low power ƒƒ Extended temperature consumption operation ƒƒ Fast Ethernet ƒƒ Shock and vibration per MIL-STD-202G ƒƒ 256 MB soldered-on RAM ƒƒ USB 2.0 (2 ports) ƒƒ Serial I/O (4 ports) ƒƒ IDE interface ƒƒ CompactFlash® socket The Tomcat is “headless”. It is designed for applications that do not require any type of video output. Like all VersaLogic products, the Tomcat is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its extended production lifecycle, the Tomcat provides a durable embedded computer solution with an excellent cost of ownership. The Tomcat is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. C O R P O R A T I O N Product Data Sheet Features 1 2 PC/104-Plus Form Factor Fanless Operation MIL-STD-202G Supports PCI and ISA expansion on a highly rugged format. No moving parts required for CPU cooling. Qualified for high shock and vibration environments. Vortex86DX Processor 800 MHz performance with ultra-low power consumption. 3 Extended Temperature -40° to +85°C operation for harsh environments. Network Support Fast Ethernet with remote boot support. 4 1 System RAM 256 MB soldered-on RAM for harsh environments. 5 USB I/O Two USB 2.0 ports support keyboard, mouse, and other devices. 6 6c 3 4 Device I/O Four serial ports (6a), IDE (6b), and LPT (6c). 7 Flash Memory CompactFlash socket for solid-state storage. 8 Main Power Input 5V Input ±5% 2 7 5 6b 1 8 Modify Tomcat to Your Exact Requirements COTS modifications are available in quantities as low as 100 pieces. ƒƒ On-board RAM size ƒƒ Standard Temperature Version ƒƒ Conformal Coating ƒƒ Connector & I/O Changes ƒƒ Custom Testing ƒƒ Custom Labeling ƒƒ BGA Underfill ƒƒ BIOS Modifications ƒƒ Software and Drivers ƒƒ Revision Locks ƒƒ Custom Screening ƒƒ Application-Specific Testing ƒƒ Etc. VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com 6a Tomcat PC/104-Plus Single Board Computer Specifications General Board Size Weight Processor Input Voltage Power Requirements System Reset and Hardware Monitors Stackable Bus Manufacturing Standards Regulatory Compliance Mass Storage PC/104-Plus compliant: 95 x 96 mm (3.76 x 3.78”) 99 grams (3.5 oz.) DMP Vortex86DX. 256 KB L2 cache. 5VDC +/- 5% Idle Typical Maximum 0.54A (2.7W) 0.60A (3.0W) 0.65A (3.3W) Watchdog with programmable timeout. Vcc sensing (resets below 4.63V typ.). PC/104-Plus: PCI, ISA IPC-A-610 Class 2 modified Mechanical Shock LPT Interface Counter/Timers Other 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis 256 MB soldered-on DDR2 SDRAM Video Interface None. Use VL-EPM-V7 module or similar during development. One autodetect 10BaseT/100BaseTX port Intel boot agent (downloadable) supports PXE protocol. Argon Managed Boot Agent (optional with royalty fee) supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. Device I/O -40° to +85°C Memory System RAM Ethernet ‡ Network Boot Option USB ‡* COM 1 / 2 Interface* COM 3 / 4 Interface* -40° to +85°C Free air from -40° to +85°C ATA/66 IDE interface. 44-pin 2 mm connector. One CompactFlash socket (Type II) with DMA. Optional latching retention clip available. Network Interface RoHS (EU 2015/863), Conflict Mineral Free Environmental Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Hard Drive   Flash Drive Two USB 2.0/1.1 ports RS-232. 16C550 compatible. 115 Kbps. RS-232/422/485 selectable. 16C550 compatible. 115 Kbps. SPP/EPP/ECP compatible Two general-purpose timer inputs PS/2 keyboard and mouse Software BIOS Operating Systems AMI BIOS. Field reprogrammable. Support for USB keyboard/mouse and USB boot. Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX § All power specifications represent operation at +25°C with +5V supply running Windows XP with Ethernet, keyboard, and mouse. Maximum power as measured with 95% CPU utilization. ‡ TVS protected port (enhanced ESD protection). * Power pins on this port are overload protected. Specifications are subject to change without notification. Vortex is a registered trademark of DMP Electronics, Inc. CompactFlash is a trademark of SanDisk Corp. All other trademarks are the property of their respective owners. C O R P O R A T I O N Tomcat PC/104-Plus Single Board Computer Product Data Sheet Ordering Information Model VL-EPM-16F Processor Vortex86DX Call VersaLogic Sales at (503) 747-2261 for more information! Speed 800 MHz Development Kit Part Number VL-CKR-TOMC VL-CBR-1008 VL-CBR-1013 VL-CBR-2003 VL-CBR-4405 VL-CBR-4406 VL-CBR-5009 VL-HDW-105 Description Development Cable Kit for Tomcat (EPM-16). Includes VL-CBR-5009, 1008, 1013, 2003, 4405, 4406, and HDW-105. Power cable, ATX to 10-pin USB cable and boards, two port LPT cable, 20-pin 2 mm / DB-25F, 12” IDE adapter board, 2 mm to 0.1” IDE cable, 44-pin latching, 18” Front panel I/O cable assembly, 18” Standoff package (metric thread) M3, 0.6” RAM 256 MB Operating Temp. -40° to +85°C Cooling Heat Sink Accessories Part Number VL-EPM-V7E VL-EPM-P2E VL-CF-CLIP1 VL-CFM-xxx VL-ENCL-5C VL-HDW-106 VL-HDW-112 VL-HDW-113 VL-HDW-115 VL-HDW-203 VL-PS200-ATX VL-PS-ATX12-300A VL-CBR-2034 Description Video Expansion Module: VGA and LVDS, Industrial Temperature Mini PCIe socket x2 Adapter, PCIe signaling, Industrial Temperature Retention clip for CompactFlash CompactFlash module Development enclosure Standoff package (English thread) 4-40, 0.6” PC104 (ISA) Spacer PC104 (PCI) Spacer PC104 (blank) Spacer Extractor tool, metal Development power supply ATX development power supply (requires VL-CBR-2034) 6” 20-pin (F) ATX to 24-pin (M) ATX adapter cable (use with PS-ATX12-300A) Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2022 VersaLogic Corporation. All rights reserved. 07/25/22 (503) 747-2261 | info@versalogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPM-16F 价格&库存
很抱歉,暂时无法提供与“VL-EPM-16F”相匹配的价格&库存,您可以联系我们找货
