VL-MPEE-V5E
VL-MPEE-V5E
    VERSALOGIC
    MINIPCIE VIDEO EXPAN
VL-MPEE-V5E 数据手册
Product Data Sheet V5/ Video Mini PCIe Module VL-MPEe-V5E Actual Size! Overview Highlights The VL-MPEe-V5 is an extremely small and rugged video module based on the industry-standard Mini PCIe module format. This Mini PCIe module provides an easy and economical way to add VGA and LVDS display outputs to an embedded computing solution. ƒƒ Mini PCIe Module Format Small and flexible. ƒƒ Industrial Temperature -40° to +85°C operation for harsh environments. ƒƒ Video Outputs Analog VGA and/or LVDS (simultaneous / independent). ƒƒ Standard Operating System Drivers (Windows, Linux) No additional drivers needed. ƒƒ PCIe Signaling Compatible with Mini PCIe sockets. This I/O board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. As with all VersaLogic products, the VL-MPEe-V5 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-MPEe-V5 provides a durable video expansion with an excellent cost of ownership. ƒƒ MIL-STD-202G Qualified for high shock / vibration environments. ƒƒ Latching Connector Prevents detachment failures. ƒƒ Class 3 Manufacturing (optional) IPC-A-610 Class 3 for extreme rugged applications. ƒƒ 5+ Year production life guarantee Worry-free availability. C O R P O R A T I O N V5/Video Product Data Sheet Specifications General Board Size Power Requirements Manufacturing Standards Mini PCIe module (full size): 30 mm x 50.95 mm x 6.39 mm 3.3V ±5% @ 1.67W Typical W (supplied by the Mini PCIe socket) Standard IPC-A-610 Class 2 Optional IPC-A-610 Class 3 RoHS (EU 2015/863) Regulatory Compliance Mini PCIe Signal Type PCI Express Base Specification, Rev 1.1 Environmental Operating Temperature Storage Temperature Altitude Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mechanical Shock † -40° to +85°C Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* -40° to +85°C Operating * To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis. MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis. MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis. Video Controller VRAM Desktop Display Interface OEM Flat Panel Interface Silicon Motion SM750. 2D Graphic Accelerator Video core with 128-bit 2D graphic engine. Supports a single display, two cloned displays, or two simultaneous independent displays. 16MB DDR SDRAM (32-bit) embedded in SM750 controller Analog output (VGA). Up to 1920 x 1080 16-bit. Single-channel LVDS interface. Up to 1280 x 1024 18/24-bit Drivers Ordering Information Model Function VL-MPEe-V5E Video Display Adapter. VGA and LVDS Interfaces. VL-MPEe-V5EC § Video Display Adapter. VGA and LVDS Interfaces. Manufactured to IPC-A-610 Class 3. Operating Temp. -40° to +85°C -40° to +85°C § Special Order Product – Contact VersaLogic Sales for minimum order quantities and lead time. Accessories Part Number PC/104-Plus Carrier VL-EPM-P2E Cables VL-CBR-1204 VL-CBR-1206 VL-CBR-2014 VL-CBR-2015 VL-CBR-2016 Hardware VL-HDW-108 VL-HDW-110 Description PC/104-Plus to Dual miniPCIe Adapter 12” VGA Interface Cable, 12-pin PicoClasp Cable to 15-pin VGA, RoHS 18” 12-pin Pico-Clasp / 15-pin VGA, RoHS LVDS to VGA Adaptor Board, RoHS 20” 24-bit LVDS Hirose Cable, RoHS 20” 18-bit LVDS FPD Cable with JAE Connector, RoHS Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Other VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEe-E3E VL-MPEe-FW1 VL-MPEe-U2E VL-MPEe-W2E VL-MPEs-F1Exx VL-MPEs-S3E VL-MPEu-G2E Function Analog input (12-bit resolution) Analog input (16-bit resolution) Gigabit Ethernet adapter 1394 Firewire Module, Industrial Temp. Four Serial ports. Twelve GPIO lines Wi-Fi 802.11 a/b/g/n mSATA drive (4/16/32 GB) SATA adapter GPS receiver Signaling PCIe PCIe PCIe PCIe PCIe PCIe SATA SATA USB Call VersaLogic Sales at (503) 747-2261 for more information! Software BIOS Mini PCIe Module On-board SPI-based video BIOS supports VESA standard graphics modes. Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux using standard software drivers. * For extended altitude information contact VersaLogic Sales Dept. † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. Tailor a Module to Your Exact Requirements Product customization is available, even in low quantities. Options include conformal coating, application-specific testing, BOM revision locks, special labeling, and more. Mini PCIe Modules 04/13/21 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-MPEE-V5E 价格&库存
很抱歉,暂时无法提供与“VL-MPEE-V5E”相匹配的价格&库存,您可以联系我们找货
