Product Data Sheet
mSATA Drive
Mini PCIe Module
VL-MPEs-F1
Actual Size!
Overview
Highlights
The VL-MPEs-F1 is an extremely small and rugged mSATA module based on the industrystandard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows
additional I/O functions to be added to a system with almost no increase in overall system/
package size. Mini PCIe modules provide a simple, economical, and standardized way to
add I/O functions to embedded computer products.
Mini PCIe Module Format
Small and flexible.
Flash Memory
Non-volatile storage up to 256 GB.
Industrial Temperature Operation
-40° to +85°C operation for harsh environments.
MIL-STD-202G
Qualified for high shock/vibration environments.
In a very small package, this board provides up to 256 GB of plug-in flash data storage
for almost any embedded system.
This non-volatile memory drive provides high-capacity data storage. The drive has an
intelligent internal controller which manages interface protocols, data storage, and retrieval.
The wear leveling mechanism assures an equal usage of the Flash memory cells to
maximize the longevity of the device. The hardware BCH-code ECC detects and corrects
internal errors. The voltage detector and power-loss management features prevent data
corruption after power-down.
This rugged product is designed and tested for full industrial temperature operation (-40º
to +85ºC). It also meets MIL-STD-202G specifications for shock and vibration, making it
at home in harsh environments.
This mSATA board is compatible with a variety of popular x86 operating systems including
Windows, Windows Embedded, and Linux.
The module utilizes SATA signaling and can be used in any system that supports SATA
signaling at the Mini PCIe socket.
This 3rd party product has been selected and tested for compatibility with VersaLogic
products, compliance with VersaLogic ruggedness requirements, and is backed
by VersaLogic’s product warranty, world-class technical support, and 5-year
lifecycle guarantee.
C
O
R
P
O
R
A
T
I
O
N
mSATA Drive
Product Data Sheet
Mini PCIe Module
Specifications
Ordering Information
General
Board Size
Mini PCIe module (full size): 29.85 x 50.8 x 3.3 mm
(1.18 x 2.0 x 0.13”)
3.3V ±5% @ 1.39 W (supplied by the Mini PCIe socket)
RoHS
Power Requirements
Regulatory
Compliance
Mini PCIe Signal Type Modules up to 32 GB: SATA 3 Gbit/s
(1.5 Gbit/s compatible)
Modules 64 GB and larger: SATA 6 Gbit/s
(3 & 1.5 Gbit/s compatible)
Environmental
Operating
Temperature ◊
Storage Temperature
Altitude *
Cooling
Airflow
Requirements
Thermal Shock
Humidity
Vibration, Sinusoidal
Sweep †
Vibration, Random †
Mechanical Shock †
-40° to +85°C
-40° to +85°C
Operating
Storage
None (fanless)
None (free air)
To 4,570m (15,000 ft.)
To 12,000m (40,000 ft.)
5°C/min. over operating temperature.
Less than 90%, noncondensing
MIL-STD-202G, Method 204, Modified Condition A: 2g
constant acceleration from 5 to 500 Hz, 20 min. per axis
MIL-STD-202G, Method 214A, Condition A: 5.35g rms,
5 min. per axis
MIL-STD-202G, Method 213B, Condition G: 20g halfsine, 11 msec. duration per axis
Device I/O
Rotating Drives /
Flash / Solid-State
Drives
For mSATA modules up to 32 GB. SLC NAND Flash.
Hardware ECC. Wear leveling. SATA signaling.
Bootable.
Burst Transfer
Up to 300 MB/s
Sustained Write Up to 95 MB/s
Sustained Read Up to 120 MB/s
For mSATA modules 64 GB and larger. pSLC NAND
Flash. Hardware ECC. Wear leveling. SATA signaling.
Bootable.
Burst Transfer
Up to 600 MB/s
Sustained Write Up to 465 MB/s
Sustained Read Up to 555 MB/s
Model
VL-MPEs-F1E4
VL-MPEs-F1E16
VL-MPEs-F1E32
VL-MPEs-F1E64
VL-MPEs-F1E128
VL-MPEs-F1E256
Function
SLC mSATA drive, 4 GB
SLC mSATA drive, 16 GB
SLC mSATA drive, 32 GB
pSLC mSATA drive, 64 GB
pSLC mSATA drive, 128 GB
pSLC mSATA drive, 256 GB
Operating Temp.
-40° to +85°C
-40° to +85°C
-40° to +85°C
-40° to +85°C
-40° to +85°C
-40° to +85°C
Accessories
Part Number
Hardware
VL-HDW-108
VL-HDW-110
Description
Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs.
Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs.
Other VersaLogic Mini PCIe Modules
Model
VL-MPEe-A1E
VL-MPEe-A2E
VL-MPEu-C1
VL-MPEe-E4E
VL-MPEe-E5E
VL-MPEe-E6
VL-MPEe-E6E-P
VL-MPEe-U2E
VL-MPEe-V5E
VL-MPEe-FW1
VL-MPEs-S3E
VL-MPEu-G2E
VL-MPEu-G3E
Function
Analog input (12-bit resolution)
Analog input (16-bit resolution)
Dual CAN Bus Interface
Gigabit Ethernet Over Fiber Module
Dual Channel Gigabit Ethernet Adapter
Gigabit Ethernet
Gigabit Ethernet with POE+
Four Serial ports. Twelve GPIO lines.
Video Display Adapter. VGA and LVDS interfaces
1394 Firewire Module
SATA adapter
GPS receiver
Advanced GPS receiver
Signaling
PCIe
PCIe
USB
PCIe
PCIe
PCIe
PCIe
PCIe
PCIe
PCIe
SATA
USB
USB
Call VersaLogic Sales at (503) 747-2261 for more information!
Software
Operating Systems
Compatible with most x86 operating systems including
* Extended altitude specifications available upon request
† MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general.
Testing to higher levels and/or different types of shock or vibration methods can be accommodated per
the specific requirements of the application. Contact VersaLogic Sales for further information.
Specifications are subject to change without notification. PCI Express is a registered trademark of the
PCI-SIG. All other trademarks are the property of their respective owners.
Mini PCIe Modules
Copyright © 2021 VersaLogic Corporation. All rights reserved.
10/28/21
12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com
C
O
R
P
O
R
A
T
I
O
N
很抱歉,暂时无法提供与“VL-MPES-F1E4”相匹配的价格&库存,您可以联系我们找货
