Diffraction Mosaic
Experiment Guide
Experiments include: Knife Edge
Single-Slit
Double-Slit
Multiple-Slit or Array
Model Number:
IF 508
Industrial Fiber Optics
Copyright © 2008
Previous printings 2006. 2000
by Industrial Fiber Optics, Inc.
Revision - C
Printed in the United States of America
All rights reserved. No part of this publication may be reproduced,
stored in a retrieval system, or transmitted in any form or by any means
(electronic, mechanical, photocopying, recording, or otherwise)
without prior written permission from Industrial Fiber Optics.
Introduction
To a casual observer, light in the world around us seems to travel in a
straight line. The appearance of shadows and reflections in mirrors seems to
support this conclusion. The behavior of light in these instances can be explained
with ordinary geometry. Light is either reflected, absorbed, scattered, or some
combination of the three, but the path it takes can be traced using straight lines
and angles.
In reality, light also has properties normally associated with the motion of
waves observed in nature, such as ripples on a lake or pond. Occasionally we
see evidence of light’s wave properties, such as the colors on a soap bubble or
a thin layer of oil floating on water. The effect of polarized sunglasses to reduce
the glare from water, or the colors we see in a rainbow are further evidence of the
wave characteristics of light.
In this experiment guide we will demonstrate the wave properties of light
using a laser, some ordinary household items and a diffraction mosaic. We will
start with a basic demonstration of diffraction (light bending around a corner)
using a laser and knife (razor) blade edge. Our experiments will then progress to
more dramatic visual effects that result from wave interference (light waves being
added and subtracted) with single-slit, double-slit and multiple-slit apertures.
The wave properties of light, including the phenomenon of interference,
were proven experimentally in 1801 by an English physicist and physician named
Thomas Young (1773-1829). Young assumed that light traveled in a way similar
to sound waves and that different colors were caused by changes in wavelength.
In Young’s experiment, light was passed through a series of narrow slits and
projected onto a screen. The result was a pattern of light and dark regions known
as diffraction fringes. These fringes were caused by the additive and subtractive
effects of interference that could only occur if light was traveling as a wave. His
findings eventually were confirmed by French engineer Augustin Fresnel — but
initially were challenged by contemporary scientists who preferred [the more popular] Isaac Newton’s theory that light was “corpuscular” or particle-like in nature.
The diffraction mosaic pictured on the front cover of this manual is a mounted photographic film containing precisely etched lines or slots. These are arranged as a set of four double-slit lines and three multiple-slit arrays. The mosaic
will greatly aid in demonstrating the wave properties of light by reducing the effort
and errors for experimental setup. The visual results will be more impressive, too.
Using Industrial Fiber Optics’ Diffraction Mosaic and experiment guide you will
learn about the hidden effects in the light around us.
–1–
Knife Edge Diffraction
When a beam of light is partially blocked by some object,
a shadow is created. Under special circumstances it can be
shown that an obstruction actually causes diffractive effects
related to the wave properties of light. Figure 1 shows what
occurs when an obstruction with an opening in it is placed
in the path of a wave front. When the wave passes through
the opening it diffracts or behaves as if a new source of
waves (a secondary wavefront) was created at the obstrucFigure 1.
tion. Notice how the waves spread out beyond the actual size Waves diffracting as they
pass through an aperture.
of the opening.
The following experiment will demonstrate diffraction of a
light beam by showing how light can bend around a corner. Subsequent procedures will
produce increasingly dramatic effects from light’s wave properties.
Equipment Needed:
Helium neon laser with 632.8 nm emission wavelength*
Single-edge razor blade
* Other helium neon lasing wavelengths and other visible gas lasers will work also, but the
examples used in this manual assume the use of the 632.8 nm helium neon laser. (Diode
lasers will also work for this experiment, but the interference fringes will not be as sharp.)
The procedures in this manual are written for use with Industrial Fiber Optics helium
neon lasers. You may need to adjust the steps slightly to accommodate other manufacturers’ lasers.
Procedure:
1.
Review the laser safety rules on the back cover of this manual.
2.
Find a table approximately 600 × 900 cm (2 × 3 feet) or larger in size
from which the laser can be pointed toward a wall or other dull reflecting
surface. The distance from the laser to the surface should be approximately
three meters (10 feet).
3.
Push the laser beam stop handle downward to its closed position and make
sure its ON/OFF switch (SW) is in its OFF position. (The push button
should be in its extended position.)
4.
Plug the 110 VAC-to-DC power adapter (provided with the laser) into an
AC wall outlet.
5.
Insert the cord from the power adapter into the power jack (PWR) located
on the rear of the laser.
–2–
6.
Depress the ON/OFF switch (SW) on the control panel of the laser until it
clicks into the ON position. (The switch should be slightly depressed.)
7.
The pilot light (green LED) just to the right of the ON/OFF switch should
now be lit, showing that the laser is on.
8.
Push the laser’s beam stop handle upward, to its open position.
9.
Observe the red beam striking
the wall, or other surface, in
the direction which the laser is
pointed.
10.
Tape the single-edge razor to a
book or wood block so the sharp
edge is perpendicular to the
tabletop. Make certain the razor
is high enough to block the laser
beam if you slide the razor’s edge
into the path of the beam. The
sharp edge of the blade must
extend past the edge of the book
or block.
Figure 2.
Single-edge razor blade and its
relationship to the laser.
11.
Dim the room lights and slide the razor
blade until its edge almost completely
blocks the beam.
12.
At this point (you must look very carefully) you should see a streak of light
on the wall that is perpendicular to the vertical edge of the razor blade. If
you position the razor blade carefully you will see a pattern of bright and
dark areas in the light streak as shown in Figure 3.
13.
Turn on the room lights, then push the beam stop handle on the laser
down to its closed position. Turn off the laser and put away all the materials used in this experiment.
Results:
When you obstructed the laser beam with the
sharp edge of the razor, you created a secondary wavefront at the edge of the razor. The
light streak you observed was the result of light
waves spreading from the second wavefront
created at the razor’s edge. The light and dark
areas in the streak occur where waves from the
unobstructed portion of the original beam interfere with those from the secondary wavefront.
–3–
Figure 3.
Laser beam pattern from
single-edge razor edge.
Single-slit Diffraction
If you place a second razor blade parallel to the single blade in the previous experiment
and form a single narrow slit between their edges, you will observe a stronger diffraction
pattern of bright and dark areas. When a laser beam passes through a narrow parallel slit,
each razor edge produces an identical diffraction pattern. If the slit edges are close enough
to each other, the diffraction patterns overlap and interference occurs.
The following experiment will demonstrate the change in diffraction pattern when a second knife edge is placed in the laser beam. The resulting pattern will be brighter and more
defined than with a single knife edge.
Equipment Needed:
Single-edge razor blades (2)
Procedure:
1. Review the laser safety rules on the back cover of this manual.
2. Select a table approximately 600 × 900 cm (2 × 3 feet) or larger in size
3.
4. Plug the 110 VAC-to-DC power adapter (provided with the laser) into an
AC wall outlet. Plug the cord from the power adapter into the power jack
(PWR) located on the rear of the laser.
5. Depress the ON/OFF switch (SW) on the control panel of the laser until it
clicks into the ON position. (The switch should be slightly depressed.) The
pilot light (green LED) just to right of the ON/OFF switch should now be
6. Push the laser’s beam stop handle upward, to its open position. Observe
the red beam striking the wall, or other surface, in the direction which the
laser is pointed.
7. Tape a single-edge razor to a book or wood block so the sharp edge is perpendicular to the table top. Make certain the razor is at a height sufficient
–4–
to block the beam when you slide
the razor’s edge into the beam’s path.
The sharp edge of the blade must
extend past the edge of the book or
block.
8. Repeat Step 7 with the second singleedge razor.
9. Dim the room lights and slide the
first razor blade edge sideways until
the laser beam is almost completely
blocked.
Figure 4.
Two single-edge razor blades
positioned properly to create
diffraction pattern from a laser beam.
10. At this point you should see on the
wall a streak of light that is perpendicular to the razor blade edge, as in the previous experiment. If you
position the razor blade carefully, you will see a pattern of bright and dark
areas in the light streak.
11. Slide the second razor blade edge slowly into the other side of the laser
beam. Position the second razor’s edge parallel to the edge of the first
one. Slide the second blade toward the first until a narrow slit is formed
between the two blades. A significant change should occur in the diffraction pattern once the blades are sufficiently close to each other. Change the
blade spacing and observe the brightness and distance between the light
and dark areas in the pattern.
12. Turn on the room lights, then push the laser’s beam stop handle down to its closed
Results:
When you moved another razor blade edge into the
Figure 5.
Diffraction pattern created
laser beam, a secondary wavefront was created, just
by two razor blades.
as with the first razor. The wavefronts from both
razor edges traveled toward the wall and interfered
with each other. Where the interference was constructive (additive), a bright spot appeared
on the wall. The dark regions between the spots were the result of destructive (subtractive)
interference. The patterns of bright and dark spots are known as diffraction fringes.
As you varied the slit widths, the spacing between fringes also changed. The distance
between the razor blade edges changes the location of constructive and destructive interference. The spacing between fringes is related to the distance between the obstructing razor
edges, the laser beam path length to the wall and the wavelength of the laser light. We will
explore this mathematical relationship in the next experiment.
–5–
Double-slit Diffraction
When you placed a razor blade parallel to another in the previous experiment and formed
a single narrow slit, you observed a stronger diffraction pattern of bright and dark areas.
When a laser beam is sent through two equally narrow parallel slits, each slit produces an
identical diffraction pattern. If the slits are close enough together, the diffraction patterns
overlap and interference occurs. A double slit will produce a pattern brighter than either
the knife edge or a single slit.
In the following procedure we will observe and examine the diffraction and interference
patterns produced by a laser beam when it passes through double slits with different widths
and spacing. We will perform some simple measurements that will allow you to accurately
determine the spacing between the parallel slits on the diffraction mosaic.
Equipment Needed:
Helium neon laser, 632.8 nm emission
Diffraction mosaic
Masking tape
Ruler and tape measure (metric or SAE)
Procedure:
1.
Pick a table approximately 600 × 900 cm (2 × 3 feet) or larger in size to
conduct this experiment. Place the laser on the table and point it toward
a vertical wall or dull reflecting surface. The distance from the laser to the
surface should be approximately three meters (10 feet).
2.
3.
4.
5.
Push the beam stop handle upward, to its open position. Observe the red
beam striking the wall, or other surface, in the direction which the laser is
pointed.
6.
Tape the diffraction mosaic fiberboard holder to a book or block so the vertical slits are perpendicular to the table top. Make certain the mosaic is at
a height where the laser beam will pass through the center of the vertical
slits.
7.
Slide the diffraction mosaic so the laser beam passes through the vertical
slits labeled 25 × 25. At this point you should see a series of red dots or
patterns on the wall.
–6–
8.
Measure the distance from the
diffraction mosaic to the wall, r,
with a tape measure and record the
distance in column 2 row 1 of Table
1. Now measure the distance (s)
between the centers of the red dots
on the wall using a ruler. Record the
distance (s) in Table1.
9.
laser beam passes through the remaining slit pairs (25 × 35 through
50 × 50) and complete rows 3
through 5 of Table 1.
Figure 6.
Laser diffraction pattern
from dual slit.
Table 1.
Slit
pair
Distance
(r)
Separation
(s)
Calculated
Width
(d)
Meters
25 x 25
4.5 x 10-5
25 x 35
5.8 x 10-5
25 x 50
7.5 x 10-5
50 x 50
10.0 x 10-5
10.
In his experiment Thomas
Young determined a
well-known equation
that relates the separation
between fringes to the
distance between the slits.
The formula is as follows:
d=
11.
λ = The lasing wavelength passing through
the slits (632.8 x 10-9 for HeNe)
d = The distance in meters between slits
sin f = The separation between fringes on the
screen divided by the distance from the
slits to the screen (s/r)
sinf
From the equation you can see that given any three numbers, the fourth
number can be determined. Calculate the distance between the slits on the
�diffraction mosaic. Record your findings in the fourth column of Table 1.
Results:
The HeNe laser has a precisely known wavelength which – along with your measurements
– can be used to determine the separation of the slits with reasonable accuracy. The greater
the distance between the slits and the wall when you measure the spacing between fringes,
the less likely you are to encounter measurement errors. The spacing between slits on the
diffraction mosaic will vary slightly, but the nominal spacing is as shown in the last column
of Table 1.
–7–
Multiple-Slit or Array Diffraction
When a laser beam is transmitted through a group of equally narrow parallel slits, all slits
produce identical diffraction patterns. If the slits are close enough together, the diffraction
patterns overlap and interference occurs. Just as the double slit will give a brighter pattern
than a knife edge or a single slit, the additional light coming from a multiple slit or array
grating will further intensify the brightness of the observed pattern. In the following procedure we will observe the interference patterns generated by three diffraction grating arrays
and calculate the spacing of the slits.
Equipment Needed:
Diffraction mosaic
Masking tape
Ruler and tape measure (metric or English)
Procedure:
1.
Find a table approximately 600 × 900 cm (2 × 3 feet) or larger in size on
which to place the laser and point it toward a wall or other dull reflecting
2.
Push the laser’s beam stop handle downward to its closed position and
make sure its ON/OFF switch (SW) is in its OFF position.
3.
4.
5.
pointed.
6.
On the diffraction mosaic notice there is a set of three rectangular areas.
For the grating experiment you will be using these three rectangular areas.
7.
gratings are perpendicular to the table top. Make sure the mosaic is high
enough so the laser beam will pass through the center of the gratings.
8.
Slide the diffraction mosaic so the laser beam passes through the 25 lines/
mm grating. (Note: this is the grating just above the vertical slits labeled 25
× 25.)
–8–
9.
At this time you should see a series
of red dots or patterns on the wall as
shown in Figure 7.
10.
Measure the distance from the diffraction mosaic to the wall, r, with a tape
measure and record that distance
in column 2 row 1 of Table 2. Now
measure the distance between the
centers of the red dots on the wall
and record the distance in Table 2.
11.
Figure 7.
Optical beam pattern from the
laser beam and the multiple slit array.
laser beam passes through the other
gratings (50 lines/mm and 100 lines/mm), then complete rows 2 and 3 of
Table 2.
Table 1.
Gratings
(lines/mm)
Distance
(r)
Separation
(s)
Calculated
Width
25
50
100
12.
Using the equation from
the previous experiment,
calculate the distance between the slits on the diffraction gratings. Record
your results in Table 2.
d=
sinf
Results:
The intensity of the diffraction pattern on the wall should have been significantly brighter
than with the double slits. As noted before, the HeNe laser has a precisely known wavelength which, along with your measurements, can be used to determine the separation of
the grating slits with reasonable accuracy. The longer the distance between the gratings
and the wall when you measure the spacing between fringes, the less likely you are to
introduce error.
Diffraction gratings are an important optical element used for separating component
wavelengths in an optical source, and for providing a compact method of generating optical
patterns.
–9–
12 0097
Rules for Laser Safety
Lasers produce a very intense beam of light. Treat them with respect. Most educational lasers have an output of less than 3 milliwatts, and will not harm the skin.
Never look into the laser aperture while the laser is turned on! PERMANENT EYE
DAMAGE COULD RESULT.
Never stare into the oncoming beam. Never use magnifiers (such as binoculars or
telescopes) to look at the beam as it travels – or when it strikes a surface.
Never point a laser at anyone’s eyes or face, no matter how far away they are.
When using a laser in the classroom or laboratory, always use a beam stop, or project
the beam to areas, which people won’t enter or pass through.
Never leave a laser unattended while it is turned on – and always unplug it when it’s
not actually being used.
Remove all shiny objects from the area in which you will be working. This includes
rings, watches, metal bands, tools, and glass. Reflections from the beam can be nearly
as intense as the beam itself.
Never disassemble or try to adjust the laser’s internal components. Electric shock
could result.
