LM3671 3.3V Buck Converter Breakout 3.3V Output 600mA Max
PRODUCT ID: 2745
DESCRIPTION
Your power supply problems just got SUPER SOLVED! This 3.3V Buck Converter
Breakout board is great for supplying power to low voltage circuits from a single
Li-Ion cell battery or USB power. This chip provides up to 600-mA load current
across the entire input voltage range of 3.5 to 5.5V. Great for your portable
project, we made this "pin compatible" with the LM1117-3.3V TO-220 chip so you
can swap it in for better performance (90-95% efficiency!) There's also an ENable
pin, tie it low to shut down the output completely.
There's a 2-MHz fixed-frequency in PWM mode and PFM mode extends the battery
life by reducing the current during light load or standby operation.
Comes with a fully assembled and tested breakout board. We also include header
to plug it into a breadboard.
https://www.adafruit.com/products/2745
10/22/2015
Technical Details
Specifications:
Weight: 0.9g
Dimensions: 16mm x 10mm x 3mm / 0.6" x 0.4" x 0.1"
很抱歉,暂时无法提供与“2745”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+55.983341+6.77645
