XVHCELNANF-24.000000
    TAITIEN(泰艺)
    SMD-4
    陶瓷谐振器 24MHz ±30ppm ±30ppm SMD-4
XVHCELNANF-24.000000 数据手册
XV Type 5.0 x 3.2 mm SMD Crystal Actual Size FEATURE - Typical 5.0 x 3.2 x 0.8 mm ceramic SMD package. - 12 mm width Tape & Reel package for automatic assembly. - Tight tolerance 10 ppm available. TYPICAL APPLICATION - Bluetooth, GPS - Display, TV(FPD/FTF LCD) - Computer Peripherals RoHS Compliant XV DIMENSION (mm) [ TOP VIEW ] #1 #2 [ SIDE VIEW ] [ BOTTOM VIEW ] 3.80±0.10 #1 GND #4 #3 #1 #2 3.80 GND 2.20 #3 #2 and #4 are connected to the cover (please connect to ground) 1.20 #4 0.80±0.20 3.20±0.20 5.00±0.20 #2 1.50 #4 #3 1.20±0.10 0.80±0.10 2.20±0.10 SOLDER PAD L AYOUT (mm) ELECTRICAL SPECIFICATION Parameter Min. Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging Typical Max. -55 12, 16, 20, 25, 27, 28, 40 10 500 M @ DC100V ±3.0 Unit 125 MHz µw pF 300 5.0 - ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E. S. R.) Frequency Range MODE Fo < 11 MHz A1 11 MHz 12 MHz 13 MHz 16 MHz 24 MHz Fo Fo Fo Fo Fo 48 MHz Fo < 53.125 MHz A1 A1 A1 A1 A1 A1 Fo A3 8 MHz < < < < < 12 MHz 13 MHz 16 MHz 24 MHz 48 MHz 80 MHz E.S.R
XVHCELNANF-24.000000 价格&库存
很抱歉,暂时无法提供与“XVHCELNANF-24.000000”相匹配的价格&库存,您可以联系我们找货
