The Electromagnetic Spectrum Innovator
CONTACT US
DATA SHEET
Square Surface Mount (SSM) &
Round Surface Mount (RSM) Filters
Low Pass EMI Filters
Pi Insertion Loss
Typical SMT Applications
SSM Series
100
I I
Pi
4000 pf
2500 pf
,3 50 ~ C
7f 40 ~ -
1500 pf
1000 pl
820 pf
470 pf
130pf
100 pf
68 pf
80
!g 70 ~
i 60
_
w
.!: 30 ~
Ground
I
11 11111
* See note
90
Working Voltage
100 VDC
Test Voltage
250 VDC
Current
Max. 10 Amps
Insulation Resistance
Min. 104 MΩ
Terminations
Silver Ni-Tin Plated
Soldering Conditions
Max. 250°C -5 sec.
Marking
None
Packaging
Bulk or tape and reel
1111 11111
10
1111 11111
0. 1
I
I
1,,- .k
1
v/
10
I
,,Y
I
1000 3000
100
Frequency (MHz)
Shielded or Partition Applications
100
90
I 111 11111
I
•- * See11ote
4000 pf
2500 pf
_ 70 -
1500 pf
,_
1000 pf
820 pf
470 pf
135 pf
100pf
68 pf
80
m
i 60
50 ~ ~ 40
.E 30 ~ ~
C
i
10
Note: Insertion loss shown for the following SSM values* only:
[7'7
V /
1111 11111
0. 1
V
I
/; / IVV
vii ,
0.0,
101Z, 501P, and 202P
I
l!.1/
V;
l% / ~
I
I
1,,-
t;:::--
1
10
Frequency (MHz)
V/1 '
100
I
1000 3000
*Capacitance values for IL curves are displayed left to right in the
order shown. Additional IL charts available by request.
RSM Series
SSM
Pi
Input ~ O u t p u t
TIT
Ground
Working Voltage
100 VDC
Test Voltage
250 VDC
Current
Max. 10 Amps
Min. 104 MΩ
Terminations
Max. 250°C -5 sec.
Marking
None
Packaging
Note: Insertion loss shown for the following RSM values only:
152P and 402Z
www.apitech.com | 855.294.3800 | communications@apitech.com |
RSM
NI/SN OVER AG
PLATED TUBE
.315 (8.00) Max .
.083±.004
(2.1 ± 1.0)
j
SOO)M,.1.1l+;'olf{.ll:J 1.100,0
012/ 040 (0 3/1
OJ+I
(>O>! M;o
+ I+ 012/.040 (0.3/1 .0)
Dimensions in inches (111111 )
www.linkedin.com/company/api-technologies-corp-/
1
DATA SHEET
SSM & RSM Ordering Information
Example: SSM1-101Z-05T
SSM
1
101Z
05
T
1
Tape and Reel
1 = 1,000 pieces
6 = 6,000 pieces
Current Rating
05 - 5 Amps
10 - 10 Amps
Circuit
Confguration
1 - Pi
Note: Tape and reel
packaging - 1,000
pieces (7”) and 6,000
pieces (13”)
Style
SSM (Square)
RSM (Round)
Code
101Z
501P
152P
202P
402E
402Z
Value
100pF
500pF
1500pF
2000pF
4000pF
4000pF
Tolerance
+80/-20%
+100/-0%
+100/-0%
100/-0%
±25
+80/-20%
Packaging
T = Tape and reel packaging
R = Bulk packaging
† Also available through APITech’s authorized distributors.
€ Also available through APITech’s authorized European distributors/agents.
† SSM1-152P-05-T1 €
SSM/RSM Tape and Reel Packaging
.157
.295
(4.00)
(7.50)
SSM Recommended Board Pattern
.043 (1.1) 1
-i I
r-
.043 (1.1)
7
.093
(2.36)
-----r
Min .
.315
~~_J
(8.00)
___i_
1-- .102
(2 6)
-I
Dimensions in inches (mm)
APPROVED FOR PUBLIC RELEASE 052521ED
2
很抱歉,暂时无法提供与“SSM1-202P-05B”相匹配的价格&库存,您可以联系我们找货
