1000 Eaton Boulevard
Cleveland, OH 44122
United States
15-Pin SATA (Male) to 4-Pin (Female) / 4-Pin
(Male) Power Cable - 6-in. (15.24 cm)
MODEL NUMBER: P945-06I
Highlights
Connects a SATA drive’s 15-pin
power port to a standard internal
4-pin Molex power supply
Compatible with 2.5 in. and 3.5
in. SATA hard drives
Female LP4 connector is pass
through to avoid taking up a
power supply connector
Applications
Use power from your computer
via its LP4 connection to
operate your SATA hard drive
Package Includes
4-pin to 15-pin SATA cable powers a Serial ATA hard drive from a standard LP4 connection.
Features
15-Pin SATA to 4-Pin Molex Power Cable Needs Only an LP4 Power Supply ConnectionThis SATA
15-pin to 4-pin power cable connects any Serial ATA drive to any conventional LP4 internal connector.
Ideal for desktops or servers equipped with a 2.5 in. or 3.5 in. SATA hard drive, this six-inch cable
features one 4-pin Molex (LP4) male connector, one 4-pin Molex (LP4) female connector and one 15-pin
SATA power connector. It eliminates the need to upgrade the computer power supply for compatibility with
newer SATA hard drives. The LP4 female pass through connector prevents having to take up a connector
on the SATA drive.
Specifications
OVERVIEW
UPC Code
037332120250
Technology
SATA/eSATA
Country/Region
Global
INPUT
Maximum Input Amps
PHYSICAL
Color
Black; Red; Yellow
Number of Conductors
Wire Gauge (OD - mm²)
Cable Length (ft.)
0.5
1/2
P945-06I 15-Pin SATA (M) to 4Pin (F)/4-Pin (M) Power Cable,
6 in.
Cleveland, OH 44122
United States
Cable Length (m)
0.15
Cable Length (in.)
6
Cable Length (cm)
15.24
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.07
Shipping Weight (kg)
0.03
CONNECTIONS
Side A - Connector 1
15 PIN SATA POWER
Side B - Connector 1
LP4 (MALE)
Side B - Connector 2
LP4 (FEMALE)
FEATURES & SPECIFICATIONS
High Voltage
No
Locking Plug
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P945-06I”相匹配的价格&库存,您可以联系我们找货
