1000 Eaton Boulevard
Cleveland, OH 44122
United States
High-Speed HDMI Flat Cable, Digital Video with
Audio, UHD 4K (M/M), Black, 10 ft. (3.05 m)
MODEL NUMBER: P568-010-FL
Highlights
Premium double-shielded digital
audio/video cable
Supports iPad2 Video Mirroring
when used with Apple Digital AV
Adapter
Gold-plated connectors provide
optimal signal transfer
High Speed HDMI and HDCP
compliant
Supports Ultra High Definition
(UHD) 4K video resolutions
Package Includes
Description
Tripp Lite's 10-ft. (3.05 m) Flat High Speed HDMI (High Definition Multimedia Interface) Gold Cable allows
interconnection between digital display devices, such as DTV's (digital television), plasma displays, LCD
TV's, and projectors, to Digital source devices, such as digital set-top boxes, Blu-Ray players, and AV
receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. Utilizing a flat design,
each individual inner conductor is organized differently to reduce cross-talk between the wires, which
produces a cleaner signal than round HDMI cables. Flat HDMI cables also fit closer to walls and better
around bends and turns, as well as under carpeting.
Features
Flat design for better manageability
Flat conductors reduce crosstalk and inductance
Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled
digital video sources
Gold-plated connectors provide optimal signal transfer
Premium double-shielded cable protects against outside noise (EMI/RFI)
Impedance-matched twisted-pair construction reduces cross-talk and interference
Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the
web and display presentations
Supports Ultra High Definition (UHD) 4K video resolutions
Specifications
OVERVIEW
UPC Code
037332137982
Technology
HDMI
1/3
HDMI Gold Cable
Cleveland, OH 44122
United States
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 @ 30Hz
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
No
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
Stereo Audio
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.0*12.0mm
Wire Gauge (AWG)
30
Cable Length (ft.)
10
Cable Length (m)
3.05
Ferrite Core
No
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 1.27
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
-40 to 176 F (-40 to 80 C)
2/3
Cleveland, OH 44122
United States
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
No
HDCP Specification
1.3
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P568-010-FL”相匹配的价格&库存,您可以联系我们找货
