1000 Eaton Boulevard
Cleveland, OH 44122
United States
High-Speed HDMI Cable, Digital Video with
Audio, 4K (M/M), Red Connectors, 3 ft. (0.91 m)
MODEL NUMBER: P568-003-RD
Highlights
Supports UHD video resolutions
up to 3840 x 2160 (4K x 2K)
Supports data transfer speeds
up to 18 Gbps
Backward compatible with
previous HDMI generations
Premium foil and braid shielding
protects against EMI/RFI noise
Gold-plated red connectors for
optimal signal transfer
Package Includes
High-speed premium cable connects two Ultra HD HDMI-enabled devices, including computers, Blu-ray™
players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications
that display Ultra High Resolution (UHD) video and multi-channel audio
High Performance and Wide Compatibility
● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K), including 1080p
Supports data transfer speeds up to 18 Gbps—the fastest bandwidth currently available over HDMI
Supports iPad2 video mirroring when used with Apple digital AV adapter
Backward compatible with previous HDMI generations
Superior Quality Ensures a Flawless Signal
● Corrosion-resistant gold-plated red connectors for optimal signal transfer
Fully molded 30 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
UPC Code
037332196989
Technology
HDMI
1/3
P568-003-RD High-Speed
HDMI Cable with Digital Video
and Audio (M/M), Red, 3 ft.
Cleveland, OH 44122
United States
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 @ 30Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
Bandwidth
10.2 Gbps
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Red
Material of Construction
ABS
Cable Jacket Color
Black
Connector Color
Red
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.0mm
Wire Gauge (AWG)
30
Cable Length (ft.)
3
Cable Length (m)
0.91
Ferrite Core
No
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.15
Shipping Weight (kg)
0.07
ENVIRONMENTAL
2/3
Cleveland, OH 44122
United States
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
Armored Cable
No
Ethernet Support
No
HDCP Specification
1.4; 2.2
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P568-003-RD”相匹配的价格&库存,您可以联系我们找货
