3164
    ADAFRUIT
    WASHER FLAT #8 FIBRE
3164 数据手册
Silicone Cover Stranded-Core Wire - 50ft 30AWG Black PRODUCT ID: 3164 Description Silicone-sheathing wire is super-flexible and soft, and its also strong! Able to handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out. We like this wire for being extremely supple and flexible, so it is great for wearables or projects where the wire-harness has to be able to deal with a lot of bending Comes with one 50ft spool of black wire. The wire is 30AWG stranded with an outer diameter of 0.8mm. Technical Details Length: 50ft / 15.2 meters Outer Diameter: 0.8mm / 0.03" Resistance: 331 Ω/Km Current Handling Capability: ~0.8 A (depends on length and voltage!) Temperature Range: -60°C ~ 200°C Nominal Voltage: 600V Weight: 21.7g Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3164”相匹配的价格&库存,您可以联系我们找货
    • 1+48.46509
