1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Solid Core Plenum-Rated (UTP)
PVC Bulk Ethernet Cable - White, 1000 ft. (304.8
m)
MODEL NUMBER: N024-01K-WH
Highlights
Ideal for all horizontal wiring
applications
Rated for 350 MHz/1 Gbps
communications
High-quality 24 AWG 4-pair
solid copper wire
Plenum-rated PVC jacket
Meets IEEE 802.3ab and
ANSI/EIA/TIA 568 standards
Package Includes
Premium cabling designed for Cat5/5e premise (in-wall) applications in air ducts and drop ceilings, such
as connecting an Ethernet wall jack to a router, patch panel or switch.
Features
Perfect Solution for Cat5/5e Premise Applications in Air Ducts and Drop Ceilings
● Designed for fast transmission and excellent signal quality throughout your LAN
Delivers speeds up to 350 MHz/1 Gbps
Ideal for all horizontal wiring applications, including 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI,
155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications
Premium Construction for Superior Performance
● Made from 24 AWG copper wire
4-pair solid UTP
Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 5e, draft 11)
Specifications
OVERVIEW
UPC Code
037332196736
Technology
Cat5/5e
PHYSICAL
Cable Jacket Color
White
1/3
N024-01K-WH Cat5e 350 MHz
Bulk Solid-Core Plenum-Rated
PVC Cable, White, 1000 ft.
Cleveland, OH 44122
United States
Cable Jacket Material
PVC
Cable Jacket Rating
CMP
Cable Shielding
UTP
Cable Outer Diameter (OD)
5.1 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
1000
Cable Length (m)
304.88
Cable Length (in.)
12000
Cable Length (cm)
30480
Shipping Dimensions (hwd / in.)
10.63 x 14.17 x 13.78
Shipping Dimensions (hwd / cm)
27.00 x 35.99 x 35.00
Shipping Weight (lbs.)
20.00
Shipping Weight (kg)
9.07
ENVIRONMENTAL
Operating Temperature Range
-4° to 167°F (-20° to 75°C)
Storage Temperature Range
32° to 140°F (0° to 60°C)
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab
CONNECTIONS
Side A - Connector 1
BARE WIRE
Side B - Connector 1
BARE WIRE
Crossover Wiring
No
Connector Type
Bare Wire
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
2/3
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Compliance
RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N024-01K-WH”相匹配的价格&库存,您可以联系我们找货
