LT5-S4-FA-NT
LT5-S4-FA-NT
    TECHFLEX
    LACING TAPE BRD NOMEX 25LB
LT5-S4-FA-NT 数据手册
TERMINATIONS & BUNDLING Long Life Method Of Wire Dressing • Used Extensively Throughout the Aerospace, Electronics, Medical & Many Smaller Specialized Manufacturing Lasts longer than cable ties! Cable ties Industries turn brittle and degrade over time due to en• Increased Knot vironmental exposure and loss of plasticizers. Retention A roll of lacing tape can manage any size cable • Ideal for Applications bundle, from a couple of 22AWG wires to a fistful of Requiring Reductions heavy power cables. in Size and Weight • Good Vibration Cable ties leave a sharp edge where the tail was cut off that can snag or get hung up. Some applications such as aerospace Performance with and aviation may specify laced harnesses as a design require Long Term Integrity ment. Lacing tape is ideal for lashing wires or cables to ladder bars, and Reliability conduit and other wire management solutions. Unlike cable ties, the insulation on wires bundled with lacing tape has less chance of cold flowing and shorting. No sharp edges to cut installer’s hands when reaching into a tightly packed wiring cavity. Lacing tape is available in a wide range of materials, sizes, and finishes to accommodate any engineering requirement. TechLace® lacing tape is packaged in a convenient re-sealable bag to protect against dust and other contaminants. A ¼” vent hole enables the material to be quickly and neatly dispensed without hassle. 114 1 (833) SLEEVING www.techflex.com TERMINATIONS & BUNDLING Polyamide (Nylon) Lacing Tape Width Thickness Part # Mil Spec Size Mil Spec Finish Min Max Min Max LT1-S1-FA-** LT1-S2-FA-** LT1-S3-FA-** LT1-S4-FA-** LT1-S5-FA-** LT1-S1-FB-** LT1-S2-FB-** LT1-S3-FB-** LT1-S4-FB-** LT1-S5-FB-** LT1-S1-FC-** LT1-S2-FC-** LT1-S3-FC-** LT1-S4-FC-** LT1-S5-FC-** 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 A A A A A B B B B B C C C C C .180” .099” .077” .054” .045” .180” .099” .077” .054” .045” .180” .099” .077” .054” .045” .220” .121” .094” .066” .055” .220” .121” .094” .066” .055” .220” .121” .094” .066” .055” .013” .012” .011” .009” .006” .013” .012” .011” .009” .006” .013” .012” .011” .009” .006” .019” .018” .017” .015” .014” .019” .018” .017” .015” .014” .019” .018” .017” .015” .014” Available Colors NT NT NT NT NT NT NT NT NT NT NT NT NT NT NT & & & & & & & & & & & & & & & BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK Bulk Spool Lbs/ Spool 750’ 750’ 1,500’ 1,500’ 1,500’ 750’ 750’ 1,500’ 1,500’ 1,500’ 750’ 750’ 1,500’ 1,500’ 1,500’ 0.80 0.45 0.50 0.40 0.30 0.95 0.50 0.55 0.45 0.30 0.95 0.50 0.55 0.45 0.30 ** Replace the asterisks with color code NT for Natural or BK for Black. A-A-52080 TYPE I • General purpose lacing tape • Available colors: Natural (NT) and Black (BK) Thermal endurance: -67°F to 250°F • Melting point: 478°F • Finishes: A-No Finish, B-Wax or C-Synthetic Rubber Polyester (Dacron®) Lacing Tape Width Thickness Part # Mil Spec Size Mil Spec Finish Min Max Min Max Available Colors Bulk Spool Lbs/ Spool LT2-S1-FA-** LT2-S2-FA-** LT2-S3-FA-** LT2-S4-FA-** LT2-S5-FA-** LT2-S1-FB-** LT2-S2-FB-** LT2-S3-FB-** LT2-S4-FB-** LT2-S5-FB-** LT2-S1-FC-** LT2-S2-FC-** LT2-S3-FC-** LT2-S4-FC-** LT2-S5-FC-** 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 A A A A A B B B B B C C C C C .180” .099” .077” .054” .045” .180” .099” .077” .054” .045” .180” .099” .077” .054” .045” .220” .121” .094” .066” .055” .220” .121” .094” .066” .055” .220” .121” .094” .066” .055” .013” .012” .011” .009” .006” .013” .012” .011” .009” .006” .013” .012” .011” .009” .006” .019” .018” .017” .015” .014” .019” .018” .017” .015” .014” .019” .018” .017” .015” .014” NT & BK NT & BK NT & BK NT & BK NT & BK NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD NT,BK,RD 750’ 750’ 1,500’ 1,500’ 1,500’ 750’ 750’ 1,500’ 1,500’ 1,500’ 750’ 750’ 1,500’ 1,500’ 1,500’ 0.80 0.45 0.50 0.40 0.30 1.00 0.55 0.60 0.45 0.30 1.00 0.55 0.60 0.45 0.30 ** Replace the asterisks with color code NT for Natural, BK for Black or RD for Red. A-A-52081 TYPE II • Superior knot tying properties to nylon • Suitable for aerospace/NASA applications • High temperature performance • Available colors: Natural (NT), Black (BK), and Red (RD) • Thermal endurance: -99°F to 350°F • Melting point: 482°F • Finishes: A-No Finish, B-Wax or C-Synthetic Rubber Dacron® is registered trademarks of DuPont Corporation. 1 (833) SLEEVING www.techflex.com 115 TERMINATIONS & BUNDLING PTFE-Fluorocarbon (Teflon®) Lacing Tape Width Thickness Part # Mil Spec Size Mil Spec Finish Min Max Min Max Available Colors Bulk Spool Lbs/ Spool LT3-S2-FA-BR LT3-S4-FA-BR 2 4 A A .108” .059” .132” .072” .009” .009” .014” .014” BR BR 750’ 1,500’ 0.70 0.65 A-A-52082 TYPE III • High heat resistance • Good resistance to fluids and solvents • Suitable for aircraft engine applications • Available colors: Brown (BR) • Thermal endurance: -99°F to 450°F • Melting point: 620°F • Finishes: A-No Finish Fiberglass (Glass) Lacing Tape Width Thickness Part # Mil Spec Size Mil Spec Finish Min Max Min Max Available Colors Bulk Spool Lbs/ Spool LT4-S1-FD-NT LT4-S2-FD-NT LT4-S3-FD-NT LT4-S4-FD-NT 1 2 3 4 D D D D .203” .099” .077” .054” .248” .121” .094” .066” .013” .013” .013” .013” .019” .019” .019” .019” NT NT NT NT 750’ 750’ 1,500’ 1,500’ 1.40 1.10 1.70 1.20 A-A-52083 TYPE IV • Extremely high temperature performance • Very low elongation • Minimal fiber to fiber abrasion • Produced from continuous filament electrical grade glass (E-glass) • Available colors: Natural (NT) • Thermal endurance: -67°F to 800°F • Melting point: 2,102°F • Finishes: D-TFE-Fluorocarbon Meta Aramid (Nomex®) Lacing Tape Width Thickness Part # Mil Spec Size Mil Spec Finish Min Max Min Max Available Colors Bulk Spool Lbs/ Spool LT5-S1-FA-NT LT5-S2-FA-NT LT5-S3-FA-NT LT5-S4-FA-NT LT5-S1-FC-NT LT5-S2-FC-NT LT5-S3-FC-NT LT5-S4-FC-NT 1 2 3 4 1 2 3 4 A A A A C C C C .180” .099” .068” .050” .180” .099” .068” .050” .220” .121” .083” .061” .220” .121” .083” .061” .013” .011” .009” .007” .013” .011” .009” .007” .019” .017” .015” .013” .019” .017” .015” .013” NT NT NT NT NT NT NT NT 750’ 750’ 1,500’ 1,500’ 750’ 750’ 1,500’ 1,500’ 0.75 0.40 0.45 0.35 0.85 0.45 0.50 0.40 A-A-52084 TYPE V • Extremely high temperature performance • Non-flammable • Highly resistant to fluids and lubricants • Suitable for critical aircraft harness applications • Available colors: Natural (NT) • Thermal endurance: -67°F to 500°F • Melting point: 700°F • Finishes: A-No Finish or C-Synthetic Rubber 116 1 (833) SLEEVING www.techflex.com Teflon® & Nomex® are registered trademarks of DuPont Corporation.
LT5-S4-FA-NT 价格&库存
很抱歉,暂时无法提供与“LT5-S4-FA-NT”相匹配的价格&库存,您可以联系我们找货
