ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
M
eets UL 2024
V
W-1, FAR 25 Approved
E
xpands Up To 150%
R
esists Gasoline And
Engine Chemicals
C
ut And Abrasion
Resistant
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 3/4”
2”
HTN0.13
HTN0.25
HTN0.38
HTN0.50
HTN0.75
HTN1.00
HTN1.25
HTN1.75
HTN2.00
3/32”
1/8”
3/16”
1/4”
1/2”
5/8”
3/4”
1 1/4”
1 1/2”
1/4”
7/16”
5/8”
3/4”
1 1/4”
1 5/8”
1 3/4”
2 3/4”
3 1/2”
1,000’
1,000’
500’
500’
250’
250’
250’
200’
200’
225’
200’
125’
100’
75’
65’
50’
30’
50’
3
3
3
3
3
3
3
3
3
0.25
0.38
0.86
1.10
1.70
2.20
2.60
4.40
4.60
E
asy To Install
Very Low Outgassing, Self-Extinguishing
UL-2024 Plenum Rated Sleeving
HALAR® (HT) self-extinguishing sleeving is used
where flammability, high temperature endurance
and low outgassing are primary concerns.
HT is braided from 11 mil ethylene
chlorotriflouroethylene (ECTFE)
copolymer monofilament.
Cut Cleanly
Hot Knife
Material HT
Ethylene-chlorotrifluoroethylene
Grade
HTN
Because of its low flame spread and smoke
generation properties, HT has received UL 2024
and NFPA 262 plenum listings, UL flame resistance
rating of VW-1 and exceeds automotive industry
requirements of FMVSS 302, as well as aviation
industry requirements of FAR 25.
HT resists a wide range of corrosive chemicals
and organic solvents, including strong acids,
chlorine and aqueous caustics. HALAR® ECTFE
also maintains useful properties on exposure to
Cobalt 60 radiation at doses up to 200 megarads.
Monofilament Diameter
.011”
Drawing Number
TF001HT-WD
Halar’s low outgassing, as well as its heat, chemical
and radiation properties, make it ideal for use as a
component in technologically advanced applications.
Colors Available:
Black, White with Black Tracer (TW),
and Black with White Tracer (TB).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
Halar® is a registered trademark of the Solvay Solexis Corporation.
VW-1 Plenum
FAR-25
Colors Available:
3=BK, TW & TB
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
Rating_________________ FAR 25, VW-1
482°F (250°C)
Maximum Continuous
Mil-I-23053
302°F (150°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
71°F
Humidity
58%
Material Destroyed
600 Test Cycles
Pre-Test Weight
6,354.9 mg
Post-Test Weight
5,922.8 mg
Test End Loss Of Mass
Point Of Destruction
432.1 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808_________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 1
Strong Oxidants___________________ 1
Esters/Ketones____________________ 2
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC______________________________
Minimum Continuous
-103°F (-75°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .011”
ASTM D-204
Flammability Rating_____ FAR 25, VW-1
FMVSS-302 Approved
Recommended Cutting______Hot Knife
Colors__________________________ 3
Wall Thickness_________________ .028”
Tensile Strength (Yarn)____________ 4.3
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.68
Moisture Absorption_____________ .02
% ASTM D-570
Hard Vacuum Data _________________
ASTM E-595 at 10-5 torr
TML__________________________ .18
CVCM_________________________ .02
WVR____________________________ 0
Smoke D-Max___________________ 94
ASTM E-662
Outgassing___________________ Low
Oxygen Index___________________ 64
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
很抱歉,暂时无法提供与“HTN0.13TB225”相匹配的价格&库存,您可以联系我们找货
