ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
V
W-1, Mil-202 Approved
E
conomical And Easy
To Install
C
ut And Abrasion Resistant
R
esists Gasoline And
Engine Chemicals
Nominal
Size
Part
1/2”
3/4”
1 1/4”
2”
2 1/2”
FWF0.50TB
FWF0.75TB
FWF1.25TB
FWF2.00TB
FXF2.50TB
Hook &
Recommended
Loop Width Application Diameter
1/4”
5/8”
5/8”
5/8”
5/8”
0.50”
0.50”
1.00”
1.25”
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
100’
100’
100’
100’
100’
20’
15’
12’
10’
10’
TB
TB
TB
TB
TB
1.30
1.80
2.30
3.20
3.75
H
ook And Loop Closure For
Easy And Repeatable Access
Easy On, Easy Off Access Will Not Support Combustion
Flame Retardant Flexo Wrap (FWF) provides the same hook and loop wire
management flexibility as our standard Flexo Wrap along with the added
safety feature of an organic flame inhibitor to provide an additional level of
security.
FWF is a safe, economical solution for a wide range of cable management
applications where moderate levels of flame protection are needed.
Cut Cleanly
Hot Knife
Material
Polyethylene Terepthalate
Colors Available:
TB = Black with
White Tracer
Grade
FWF
Monofilament Diameter
.010”
Drawing Number
TF001FWFR-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
FLEXO WRAP FR is designed for quick and easy management of wire, cable and
hose assemblies. Just separate the hook and loop fasteners along the edge of the
material... and slip the entire length of FW around or under your harness or component assembly. The wide expandability range allows FW to easily fit around...
odd-shaped connectors and gently constrict around the diameter of your wires.
When the FW is in place, simply seal the hook and loop along the edges.
VW-1
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
Rating________________________ VW-1
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
Humidity
63%
Slight Scuffing And One
Broken Filament
300 Test Cycles
Wear Continues Evenly
Approximately One Dozen
Filaments Broken
500 Test Cycles
Material Destroyed
900 Test Cycles
Pre-Test Weight
3,772.7 mg
Post-Test Weight
3,391.1 mg
Test End Loss Of Mass
Point Of Destruction
381.6 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 2
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .010”
ASTM D-204
Flammability Rating____________ VW-1
FMVSS-302 Approved
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness_________________ .025”
Tensile Strength (Yarn)_____________ 5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .04
WVR___________________________ .06
Smoke D-Max__________________ 275
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 31
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
很抱歉,暂时无法提供与“FWF0.75TB25”相匹配的价格&库存,您可以联系我们找货
