EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
E
asy To Install - Cuts With
Scissors
R
esists Damage from
UV, Gasoline & Engine
Chemicals
W
eld Splatter, Hot Slag,
& Welding Spark Protection
S
tays Flexible In Low
Temps
Nominal
Size
Part
Wall
Thickness
Velcro
Width
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1”
1 1/2”
2”
2 3/8”
2 3/4”
3”
3 1/4”
3 1/2”
4”
WWN1.00BK
WWN1.50BK
WWN2.00BK
WWN2.38BK
WWN2.75BK
WWN3.00BK
WWN3.25BK
WWN3.50BK
WWN4.00BK
.04”
.04”
.04”
.04”
.04”
.04”
.04”
.04”
.04”
0.84”
0.84”
1.55”
1.55”
1.55”
1.55”
1.55”
1.55”
1.55”
150’
150’
150’
150’
150’
150’
150’
150’
150’
50’
50’
50’
50’
50’
50’
50’
50’
50’
Black BK
Black BK
Black BK
Black BK
Black BK
Black BK
Black BK
Black BK
Black BK
8.4
11.0
13.8
14.8
16.4
18.4
19.2
20.4
21.7
Protects Vulnerable Welding Hoses From Catastrophic
Failure.
Techflex® Weld Wrap® (WW) is braided from fiberglass yarns with high temperature
coating and velcro closure. Commonly used for protecting welding hoses against
flame and abrasion, when dragging weld slag across the floor. This product will
withstand continuous exposure to temperatures of 400°F/204.4°C, and intermittent
introduction to temperatures of 750°F/399°C.
Cut Cleanly
Scissors
The heavy duty hook and loop closure ensures a tight seal and allows Weld Wrap®
to be installed easily over existing assemblies. Weld Wrap® also provides a high
level of abrasion and penetration protection to increase the useful life of any hoses
exposed to rough or abrasive surfaces.
Material
Fiberglass
Colors Available:
Black (BK)
Grade
WWN
Wall Thickness
.04”
...bundles and protects hoses and cables
on welding robots and static welding
stations.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
EXTREME
TEMPERATURE
ABRASION
High
Rating_______________ Non Flammable
Abrasion Test Machine
Maximum Continuous
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
70%
Material Destroyed Two Small Holes Worn
Through
1,060 Test Cycles
Pre-Test Weight
7,857.40 mg
Post-Test Weight
6,602.20 mg
Test End Loss Of Mass
Point Of Destruction
1,255.20 mg
Intermitten Exposure
750°F (399°C)
Mil-I-23053
400°F (204.4°C)
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
Minimum Continuous
-40°F (-40°C)
4=More Affected
5=Severely Affected
Aromatic Solvents_________________
Aliphatic Solvents__________________
Chlorinated Solvents_______________
Weak Bases_______________________
Salts_____________________________
Strong Bases______________________
Salt Water 0-S-1926_________________
Hydraulic Fluid MIL-H-5606__________
Lube Oil MIL-L-7808________________
De-Icing Fluid MIL-A-8243___________
Strong Acids______________________
Strong Oxidants___________________
Esters/Ketones____________________
UV Light_________________________
Petroleum________________________
Fungus ASTM G-21_________________
PHYSICAL
PROPERTIES
1
1
1
1
1
1
1
1
1
1
2
2
1
1
1
1
Monofilament Diameter__________NA
ASTM D-204
Flammability Rating___ Non Flammable
Recommended Cutting___Scissor/Shears
Colors__________________________ 1
Wall Thickness__________________ .04”
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
很抱歉,暂时无法提供与“WWH1.00SV”相匹配的价格&库存,您可以联系我们找货
