ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
Proprietary Abrasion Fabric
E
xtreme, Oversized Hook
And Loop Closure
V
ery Puncture and Tear
Resistant
R
esistant to Water and
Petroleum
S
heds Surface Moisture
Nominal
Size
Part
1 3/8”
1 3/4”
2”
2 1/2”
3”
3 1/2”
4”
4 1/2”
5”
6”
DWG1.38BK
DWG1.75BK
DWG2.00BK
DWG2.50BK
DWG3.00BK
DWG3.50BK
DWG4.00BK
DWG4.50BK
DWG5.00BK
DWG6.00BK
Wall
Hook & Loop
Thickness
Width
0.05”
0.05”
0.05”
0.05”
0.05”
0.05”
0.05”
0.05”
0.05”
0.05”
1
1
1
1
1
1
1
1
1
1
1/2”
1/2”
1/2”
1/2”
1/2”
1/2”
1/2”
1/2”
1/2”
1/2”
Bulk
Spool
Shop
Spool
75’
75’
75’
75’
75’
75’
75’
75’
75’
75’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
BK
BK
BK
BK
BK
BK
BK
BK
BK
BK
Lbs/
100’
15.54
16.90
18.62
21.60
24.93
26.73
29.58
33.45
36.81
42.35
Heavy Duty Abrasion Sleeve With Easy On, Easy Off Hook
& Loop Closure
GATOR WRAP is made of proprietary extreme abrasion fabric. This protection sleeve
is used for bundling and wrapping hoses and cables. The reusable sleeve features
Mil-Spec extreme Hook & Loop closure which allows installation without disconnecting hoses and can reduce labor time by 70%. Gator Wrap (GW) is an excellent
choice for applications requiring protection from the toughest abrasion. This heavy
duty abrasion sleeve is being used in the oil field industry on frac hoses and on drill
rigs, and in the timber industry to replace spiral wrap.
Cut Cleanly
Scissor
Material
Colors Available:
Black (BK)
Grade
DWG
Wall Thickness
.05”
Drawing Number
TF001DWG-WD
This is a non-expandable product. Be sure to
match your application diameter accurately.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
HEAVY
DUTY ENGINEERING
ADVANCED
ABRASION
Maximum Continuous
Mil-I-23053
Extreme!!!
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
69°F
Humidity
50%
No Major Wear
10,000 Test Cycles
Slight Change. Coating
Worn But Still Intact.
50,000 Test Cycles
Pattern Continues. No
Significant Change.
100,000 Test Cycles
Pre-Test Weight
11,673.3 mg
Post-Test Weight
11,673.3 mg
Test End Loss Of Mass
Point Of Destruction
0 mg
CHEMICAL
RESISTANCE
1=No Effect
4=More Affected
2=Little Effect 5=Severely Affected
3=Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 4
Strong Oxidants___________________ 4
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
RoHS___________________________ Yes
Minimum Continuous
-60ºF (-51ºC)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
Recommended Cutting________ Scissor
Colors___________________________ 1
Wall Thickness___________________ .05”
Specific Gravity__________________ 1.3
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
250ºF (121ºC)
Abrasion Resistance
很抱歉,暂时无法提供与“DWG3.50BK25”相匹配的价格&库存,您可以联系我们找货
