ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
P
lenum Suitable
F
AR 25 Approved
E
xpands Up To 150%
R
esists Gasoline And
Other Chemicals
C
ut And Abrasion
Resistant
Nominal
Size
Part
1/8”
1/4”
3/8”
1/2”
3/4”
1 1/4”
1 3/4”
2”
TFN0.13
TFN0.25
TFN0.38
TFN0.50
TFN0.75
TFN1.25
TFN1.75
TFN2.00
Expansion Range
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
3/32”
3/16”
1/4”
3/8”
5/8”
1 1/8”
1 3/8”
1 11/16”
1/4”
3/8”
3/4”
7/8”
1 1/4”
1 1/2”
1 3/4”
2 1/8”
1,000’
1,000’
500’
500’
250’
200’
200’
200’
225’
200’
125’
100’
75’
50’
50’
25’
NT
NT
NT
NT
NT
NT
NT
NT
0.50
0.68
2.20
2.60
2.90
4.80
5.50
6.40
High Temp Stable, Abrasion Resistant,
Low Outgassing
FLEXO PFA (TFN) expandable sleeving is ideal in
applications where flame, chemical and very
high temperature resistance are significant
considerations. Braided from 16 mil
perfluoroalkoxy (TFN) polymer monofilament.
The high temperature properties of Flexo PFA
make it the ideal choice for aerospace, military
and high-tech applications where thermal
stability and low outgassing are critical.
Flexo PFA is suitable for plenum applications.
Cut Cleanly
Hot Knife
Material
Perfluoroalkoxy
Grade
TFN
BK
BK
BK
BK
BK
BK
BK
BK
Colors Available:
Natural (NT) & Black(BK)
What Makes Flexo PFA So Special?
Flexo PFA is inert to virtually all chemicals
and is considered the most slippery material on
the planet. These properties have made it one of
the most valuable and versatile technologies ever
invented, contributing to advancements in areas
such as aerospace, communications, electronics,
industrial processes and architecture.
Colors Available:
Monofilament Diameter
.016”
Drawing Number
TF001TF-WD
Natural (NT) and Black (BK).
High temperature resistance and low
outgassing allows Flexo PFA sleeving
to function in high-temp environments.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
FAR-25
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
590°F (310°C)
ABRASION
Very High
Taber 5150
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
71°F
Humidity
59%
Slight Rough Surface And
A Few Filaments Broken
1,500 Test Cycles
Visible Wear And Three
Filaments Broken
2,000 Test Cycles
Material Destroyed
3,000 Test Cycles
Pre-Test Weight
13,955.5 mg
Post-Test Weight
12,911.9 mg
Test End Loss Of Mass
Point Of Destruction
1,043.6 mg
Mil-I-23053
550°F (280°C)
Rating_______________________ FAR 25
Abrasion Test Machine
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 1
Strong Oxidants___________________ 1
Esters/Ketones____________________ 2
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ No
RoHS___________________________ Yes
SVHC______________________________
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .016”
ASTM D-204
Flammability Rating___________ FAR 25
Recommended Cutting_____ Hot Knife
Colors___________________________ 2
Wall Thickness___________________ .04”
Tensile Strength (Yarn)____________ 2.1
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 2.15
Moisture Absorption____________ 95
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
很抱歉,暂时无法提供与“TFN1.25NT50”相匹配的价格&库存,您可以联系我们找货
