ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
stainless steel
Put-Ups
V
irtually Indestructible
304 Stainless Steel
Nominal
Size
W
ill Not Discolor Or Rust
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
R
esists Abrasion, Chemicals
And UV
E
asy To Install
C
uts With Shears Or Serrated
Scissors
H
alogen Free
Cut Cleanly
Shears
Material
304 Stainless Steel
Grade
SSL
Expansion Range
Min
Max
SSL0.13SV 1/16” 11/32”
SSL0.25SV 3/16” 13/32”
SSL0.38SV 1/4”
5/8”
SSL0.50SV 3/8”
3/4”
SSL0.75SV 1/2” 1 1/4”
SSL1.00SV 5/8” 1 5/16”
SSL1.25SV 3/4” 1 3/4”
SSL1.50SV
1”
2 1/8”
Wall
Thickness
Wire
Thickness
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
.013”
.013”
.013”
.013”
.013”
.025”
.025”
.025”
.005”
.005”
.005”
.005”
.005”
.010”
.010”
.010”
250’
250’
250’
100’
100’
100’
100’
100’
100’
100’
100’
50’
50’
50’
50’
50’
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
1.20
2.20
2.54
3.15
6.90
9.78
13.70
16.60
Braided Stainless Steel XC, Tight Weave
for Extra Coverage
Our new X-tra Coverage product, Stainless Steel XC,
provides fuller coverage with no transparent elements
in the braided construction and results in a continuous
stainless steel shine on any application.
Nothing protects hoses from wear and blowout
quite like real Stainless Steel braid. It looks great
in any application and is as strong as, well, steel.
But, custom hoses overbraided with stainless
steel are expensive, selections are often
limited and production and delivery times
can be an issue.
Now, you can take any stock or custom hose,
slip a length of Flexo® Stainless over it, hide
the cut ends under your clamps and have
the same look and protection as custom
overbraided hoses at a fraction of the cost.
Flexo® Stainless XC is pre-rounded for easy, slip on
installation and is available in diameters and expansion
ranges to accommodate virtually any common hose
or wire application.
Wire Thickness
.005” - .010”
Drawing Number
TF001SS-WD
www.techflex.com
Part
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Braided Stainless Steel XC sleeving is used
in applications where constant movement
and high temperatures require a flexible,
indestructible covering.
Nominal
Size
Part
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
SSL0.13SV
SSL0.25SV
SSL0.38SV
SSL0.50SV
SSL0.75SV
SSL1.00SV
SSL1.25SV
SSL1.50SV
AWG Carriers Wires/
of Ends
Carrier
36
36
36
36
36
30
30
30
24
24
48
48
48
48
48
48
5
13
7
11
15
7
10
12
Total
Ends
120
312
336
528
720
336
480
576
Colors Available:
Silver (SV)
METAL & SHIELDING
ADVANCED
ENGINEERING
stainless steel
Melt Point
ASTM D-2117
2,650°F (1,454°C)
FLAMMABILITY
www.techflex.com
Rating______________________ Non Flammable
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________________ 1
Aliphatic Solvents___________________________ 1
Chlorinated Solvents________________________ 1
Weak Bases________________________________ 1
Salts______________________________________ 2
Strong Bases_______________________________ 2
Salt Water 0-S-1926__________________________ 2
Hydraulic Fluid MIL-H-5606___________________ 1
Lube Oil MIL-L-7808_________________________ 1
De-Icing Fluid MIL-A-8243____________________ 1
Strong Acids_______________________________ 2
Strong Oxidants____________________________ 2
Esters/Ketones_____________________________ 1
UV Light__________________________________ 1
Petroleum_________________________________ 1
Fungus ASTM G-21__________________________ 1
Halogen Free____________________________ Yes
RoHS___________________________________ Yes
PHYSICAL
PROPERTIES
Wire Thickness_______________________ .005”-.010”
ASTM D-204
Flammability Rating______________ Non Flammable
Recommended Cutting___________________ Shears
Colors______________________________________1
Wall Thickness________________________ .013”-.025”
Abrasion_________________________________High
Specific Gravity ASTM D-792__________________ NA
Moisture Absorption________________________ NA
% ASTM D-570
Hard Vacuum Data_____________________________
ASTM E-595
TML______________________________________ .00
CVCM____________________________________ .00
WVR______________________________________ .00
Outgassing___________________________ Very Low
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“SSL1.25SV-BS”相匹配的价格&库存,您可以联系我们找货
