ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
Put-Ups
E
conomical & Easy To Install
C
ut & Abrasion Resistant
E
xtremely Flexible And
Lightweight
F
lame Retardant
C
uts With Shears
E
xcellent EMI Shielding
(1 MHz To 1 GHz)
Nominal
Size
Part
Wall
Thickness
*1/8”
*3/8”
*1/2”
*3/4”
1”
1 1/4”
1 1/2”
FSN0.13SV
FSN0.38SV
FSN0.50SV
FSN0.75SV
FSN1.00SV
FSN1.25SV
FSN1.50SV
.013”
.013”
.013”
.013”
.025”
.025”
.025”
Expansion Range
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/16”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1/4”
1/2”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
328’
328’
328’
328’
328’
328’
328’
164’
164’
164’
164’
164’
164’
164’
Silver
Silver
Silver
Silver
Silver
Silver
Silver
0.74
1.38
2.09
2.80
2.90
3.40
3.90
High Temperature Shielded Expandable
Sleeving
Flexo® Shield is a high performance EMI (Electromagnetic Interference) shielded, braided expandable sleeving. Flexo® Shield is cut and abrasion
resistant, flexible and lightweight. Our sleeving
can help fulfill the requirements of the
internationally recognized standard CISPR25
for frequencies ranging from 10 KHz to 1 GHz.
It does this by assisting in the shielding of wires
that are attached to these electronic
components which require this rating.
The material is also great for hose covering
on hot rods and motorcycles.
Cut Cleanly
Shears
Material
Aramid & Tinned Copper
Grade
FSN
Monofilament Diameter
.010”
Drawing Number
TF001FSN-WD
* = VW-1 Sizes 1/8" - 3/4"
Colors Available:
Silver (SV)
With its high temperature aramid fiber cores and
low angle braid, Flexo® Shield can expand and
contract to a limited degree to create a perfect
fit. Flexo® Shield braid fibers create a sleeve that
provides good EMI protection and yields a material
with out- standing flex-life.
Flexo® Shield is great for applications where light
weight and high performance are needed such as:
computer systems, electronic office equipment,
medical electronics, communication systems and
many more. Techflex® Flexo® Shield is intended for
high flex, high temperature, and environmentally
tough applications, therefore making it appropriate
for several aerospace applications.
Flexo® Shield sleeving is used where light
weight, high performance, high flex and
high temperature are needed.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
VW-1
METAL & SHIELDING
ADVANCED
ENGINEERING
PHYSICAL
PROPERTIES
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases_____________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
RoHS___________________________Yes
ASTM D-2117
449°F (232°C)
Maximum Continuous
Mil-I-23053
302°F (150°C)
Minimum Continuous
-40°F (40°C)
FLAMMABILITY
Rating_____________________ UL, VW-1
SHIELDING EFFECTIVENESS
(E-FIELD)
* Attenuation levels reduced approximately
20% when used in maximum expanded state
Attenuation data was derived using procedures
defined in Mil-STD-295.
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Monofilament Diameter________ .010"
ASTM D-204
Flammability Rating______________ UL
Recommended Cutting________ Shears
Colors__________________________1
Wall Thickness___________ .013"-.025"
Abrasion_____________________ Low
Melt Point
很抱歉,暂时无法提供与“FSN0.13SV164”相匹配的价格&库存,您可以联系我们找货
