ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
H
igh Chemical Resistance
L ow Outgassing
H
alogen Free
V
ery Light Weight
V
-O Flammability Rating
W
ear Resistant
H
igh Strength Alternative
to Fluoropolymers
Nominal
Size
Part
1/8”
1/4”
3/8”
1/2”
5/8”
3/4”
1”
2”
2 1/2”
PKN0.13BK
PKN0.25BK
PKN0.38BK
PKN0.50BK
PKN0.63BK
PKN0.75BK
PKN1.00BK
PKN2.00BK
PKN2.50BK
Expansion Range
Min
Max
1/16”
7/64”
5/32”
3/16”
1/4”
3/8”
5/16”
9/16”
5/8”
15/16”
1 1/4”
1 3/8”
Bulk
Spool
Shop
Spool
1,000’
1,000’
500’
500’
500’
250’
250’
200’
200’
225’
200’
125’
100’
100’
75’
65’
50’
50’
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
Lbs/
100’
0.16
0.19
0.31
0.44
0.51
0.64
0.71
2.14
Call for more size availability
Secures Performance Of Sensitive
Items in Challenging Environments
Cut Cleanly
Hot Knife
Material
Polyetheretherketone
Grade
PKN
Monofilament Diameter
.010”
Drawing Number
TF001PK-WD
Similar to PPS, but with a substantially expanded operating temperature range, PEEK
(PolyEtherEther-Ketone) is a high performance advanced polymer with outstanding
physical properties. PEEK is inherently flame
retardant, with a V-0 flammability rating, will
withstand continuous use in superheated
water or steam up to 500°F, and resists most
acids, solvents and bases.
PEEK is FDA approved as a food contact product, resists damage from radiation and will
continue to perform in UHV (Ultra High Vacuum) environments. PEEK is extensively used
in the aerospace, automotive, teletronic and
chemical process industries, and is considered
an advanced biomaterial used in medical
implants and other biomedical applications.
PEEK will withstand thousands of sterilization
cycles without damage or degradation.
Flexo PEEK expandable sleeving is tightly
braided from 10 mil filaments of pure, unfilled
PEEK polymer. The sleeving expands to fit over
connectors and splices, and provides a full
coverage over wires hoses and cable bundles
in advanced engineering applications.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
Colors Available:
Black (BK)
PEEK® is a registered trademark of the Victrex Corporation.
HALOGEN
FREE
UL94 V-O
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
633°F (334°C)
FLAMMABILITY
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 3
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil__________________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 1
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
Mil-I-23053
500°F (260°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ .010”
Recommended Cutting______ Hot Knife
Colors___________________________1
Wall Thickness________________.025”
Abrasion Resistance____________ Med
Tensile Strength_____________ 13,300
ASTM D638 (PSI)
Specific Gravity ASTM D-792_______ 1.3
Water Absorption %___________ 500
ASTM D149 (V/Mil)
Volume Resistivity________ >4.9x1016
ASTM D257 (ohm-cm)
Outgassing___________________ Low
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Rating_________________________ V-O
Maximum Continuous
很抱歉,暂时无法提供与“PKN0.75BK”相匹配的价格&库存,您可以联系我们找货
