HALOGEN
6-60 Volt DC Surface Mount, PolyTron™ PTC Devices
Pb HF
FREE
PolyTron™ PTS1812 Series
Agency Information
• cURus: Recognized Card: File E343021 (Ihold 0.1-3.0A)
• TUV File: R 50192872
Part Number System/Ordering
PT
1812 Surface Mount Device
Description
S 1812
8V
110
PolyTron™ PTC Device Series
Surface Mount
Dimension Code
Maximum Voltage
Current Holding (Ihold)
Tape and Reel Packaging/Quantities
• PTS181216V035, PTS181216V050, PTS181213V075,
PTS18128V110, PTS18126V125, PTS18128V150,
PTS18128V160, PTS18128V200 - 2000 PTC devices per reel
• All Others - 1000 PTC devices per reel
PolyTron™ surface mount PTC device
6 to 60 volts
Current ratings from 0.1 to 3.0 amps
Fast time-to-trip
Low resistance
Halogen free
Lead free
RoHS compliant
Applications
• Medical equipment
• Telecommunications
• Rechargeable battery packs
• White goods
• Computers and peripherals
Specifications
Catalog
Number
PTS181230V010
PTS181260V014
PTS181230V020
PTS181216V035
PTS181216V050
PTS181213V075
PTS181224V075
PTS181233V075
PTS18128V110
PTS181216V110
PTS181224V110
PTS181233V110
PTS18126V125
PTS181216V125
PTS18128V150
PTS181212V150
PTS181224V150
PTS18128V160
PTS18128V200
PTS18126V260
PTS18126V300
Notes:
0111
Vmax
(Vdc)
30
60
30
16
16
13.2
24
33
8
16
24
33
6
16
8
12
24
8
8
6
6
Imax
(Amps)
100
10
100
100
100
100
100
100
100
100
100
100
100
100
Ihold
@23°C
(Amps)
0.10
0.14
0.20
0.35
0.50
0.75
0.75
0.75
1.10
1.10
1.10
1.10
1.25
1.25
1.50
1.50
1.50
1.60
2.00
2.60
3.00
Itrip
@23°C
(Amps)
0.30
0.34
0.40
0.70
1.00
1.50
1.50
1.50
2.20
2.20
2.20
2.20
2.50
2.50
3.00
3.00
3.00
3.20
3.50
5.00
5.00
Pd
Typ.
(W)
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.9
0.9
0.9
0.8
1.2
1.2
1.2
Time to Trip (Max.)
(Amps)
(Sec)
0.5
1.5
1.5
0.15
8
0.02
8
0.1
8
0.15
8
0.2
8
0.2
8
0.2
8
0.3
8
0.5
8
0.5
8
0.5
8
0.4
8
0.4
8
0.3
8
0.5
8
1.5
8
1.0
8
2.0
8
2.5
8
4.0
Resistance (Ω)
Initial (Ri) Post Trip (R1)
Min.
Max.
1.6
15
1.5
6
0.8
5
0.32
1.5
0.15
1
0.11
0.45
0.11
0.29
0.11
0.4
0.04
0.21
0.06
0.18
0.06
0.2
0.06
0.2
0.05
0.14
0.05
0.14
0.04
0.11
0.04
0.11
0.04
0.12
0.03
0.1
0.02
0.06
0.015
0.047
0.012
0.04
Ihold – Hold current: Maximum current device will pass without interruption in 23°C still air.
Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in 23°C still air.
Vmax: Maximum continuous voltage device can withstand without damage at rated current.
Imax: Maximum fault current device can withstand without damage at rated voltage.
Pd: Power dissipated from device when in the tripped state in 23°C still air.
Ri (min.): Minimum resistance of device as supplied at 23°C unless otherwise specified.
Ri (max.): Maximum resistance of device as supplied at 23°C unless otherwise specified.
R1(max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at 23C unless otherwise specified.
BU-SB11017
Page 1 of 4
Data Sheet 4398
Agency
Information
cURus TUV
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Dimensions - mm
A
Part Number
PTS181230V010
PTS181260V014
PTS181230V020
PTS181216V035
PTS181216V050
PTS181213V075
PTS181224V075
PTS181233V075
PTS18128V110
PTS181216V110
PTS181224V110
PTS181233V110
PTS18126V125
PTS181216V125
PTS18128V150
PTS181212V150
PTS181224V150
PTS18128V160
PTS18128V200
PTS18126V260
PTS18126V300
Min.
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
4.37
B
Max.
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
4.73
Min.
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
3.07
C
Max.
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
3.41
Min.
0.50
0.50
0.50
0.28
0.28
0.28
0.60
0.60
0.28
0.60
0.60
0.80
0.28
0.30
0.28
0.60
0.70
0.28
0.35
0.35
0.60
Max.
0.90
0.90
0.90
0.68
0.68
0.68
1.20
1.20
0.68
1.00
1.00
1.60
0.68
0.90
0.68
1.00
1.50
0.68
0.90
0.90
1.20
D
Min.
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1812 Package
E
Min.
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
Max.
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
0.65
Time to Trip Curves at 23°C
A
100
B
C
D
E
F
G
H
I
J
K
A : PTS181230V010
B : PTS181260V014
C : PTS181230V020
D : PTS181216V035
10
TIM E IN S E C O N D S
M
E : PTS181216V050
F:PTS181213V075
PTS181224V075
PTS181233V075
L
G : PTS18128V110
PTS181216V110
PTS181224V110
PTS181233V110
1
H : PTS18126V125
PTS181216V125
I: PTS18128V150
PTS181212V150
PTS181224V150
J: PTS18128V160
0 .1
K : PTS18128V200
L : PTS18126V260
M : PTS18126V300
0 .0 1
0 .1
1
10
Fault Current (A )
0111
BU-SB11017
Page 2 of 4
Data Sheet 4398
P e rce n ta g e o f D e ra te d C u rre n t
Thermal Derating Curve
2 0 0 .0
1 7 5 .0
1 5 0 .0
1 2 5 .0
1 0 0 .0
7 5 .0
5 0 .0
2 5 .0
0 .0
-4 0
-2 0
60
Te m p e ra tu re (°C)
80
100
Environmental Specifications
Soldering Methods
Characteristic
Operating Temperature Range
Surface Temperature Trip State
Thermal Shock
• Wave Solder
- Reservoir Temperature: 260°C (500°F)
- Recommended time in reservoir: 10 seconds.
• Infrared Reflow
- Temperature: 260°C
- Time: 10 seconds maximum at peak temperature.
Solvent Resistance
Humidity Age Test
Recommended Wave Solder Profile
Supplier Tp > Tc
Storage Temperature Range
Storage Duration
Storage Relative Humidity
Storage Conditions
User Tp < Tc
Tc
Value
-40°C to +85°C
125°C max.
+85°C to -40°C , 10 cycles,
5% typical resistance change
MIL-STD-202 Method 215, no change
+85°C, 85% RH, 1000 hours
±5% typical resistance change.
Specified temperature (23°C ± 3°C)
-10°C to +40°C
One year
_75%
Keep away from corrosive atmosphere and sunlight
Tc -5°C
Supplier tp
User tp
Recommended Land Pattern - mm (in)
Te m p e r a t u r e
Tp
tp
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
TL
Tc -5°C
t
Tsmax
Preheat Area
Tsmin
ts
A
3.45 (0.136)
25
Time 25°C to Peak
B
1.78 (0.07)
C
3.5 (0.138)
Time
Material Composition
• Terminal material: Nickel/tin-plated copper
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
Preheat & Soak
Temperature min (Tsmin)
100°C
150°C
Temperature max (Tsmax)
150°C
200°C
Time (Tsmin to Tsmax) (ts)
60-120 seconds
60-120 seconds
Average ramp-up rate (Tsmax to Tp)
3°C/second max.
3°C/second max.
Liquidous temperature (TL)
183°C
217°C
Time at liquidous (tL)
60-150 seconds
60-150 seconds
Peak package body temperature (Tp)*
See classification temp in Table 4.1 See classification temp in Table 4.2
Time (tp)** within 5°C of the specified
20** seconds
30** seconds
classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
6°C/second max.
6°C/second max.
Time 25°C to peak temperature
6 minutes max.
8 minutes max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
0111
BU-SB11017
120
Page 3 of 4
Data Sheet 4398
Packaging Specifications
B-B SECTION
A-A SECTION
For PTS181216V035, PTS181216V050, PTS181213V075, PTS18128V110, PTS18126V125, PTS18128V150, PTS18128V160, PTS18128V200
Index
A0
B0
K0
P0
P1
P2
T
E
F
D0
D1
W
10P0
Type
±0.1
±0.1 ±0.06
±0.1
±0.1
±0.05
±0.1
±0.1
±0.05 ±0.05
Min.
±0.3
±0.2
1812 3.58
4.93
0.87
4.0
8.0
2.0
0.25
1.75
5.5
1.55
1.5
12
40
For PTS181230V010, PTS181260V014, PTS181230V020, PTS181224V075, PTS181233V075, PTS181216V110, PTS181224V110,
PTS181233V110, PTS181216V125, PTS181212V150, PTS181224V150, PTS18126V260, PTS18126V300
Index
A0
B0
K0
P0
P1
P2
T
E
F
D0
D1
W
10P0
Type
±0.1
±0.1
±0.1
±0.1
±0.1
±0.05
±0.1
±0.1
±0.05 ±0.05 +0.15/-0 ±0.3
±0.2
1812 3.56
4.94
1.7
4.0
8.0
2.0
0.25
1.75
5.5
1.55
1.5
12
40
Reel Specifications
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result
in significant injury to the user.
© 2011 Cooper Bussmann
www.cooperbussmann.com
0111
BU-SB11017
Page 4 of 4
Data Sheet 4398
很抱歉,暂时无法提供与“PTS181233V110”相匹配的价格&库存,您可以联系我们找货
