SMBJ SERIES
Automotive Qualified
Technical Data
Data Sheet N0193, Rev. C
SMBJ SERIES SURFACE MOUNT
TRANSIENT VOLTAGE SUPPRESSOR
Features:
Glass Passivated Die Construction
600W Peak Pulse Power Dissipation
5.0V- 400V Standoff Voltage
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability Classification Rating 94V-O
“-A” is an AEC-Q101 qualified device
This is a Pb − Free Device
All SMC Parts are Traceable to the Wafer Lot
Additional testing can be offered upon request
Mechanical Data:
Case: JEDEC DO-214AA Low Profile Molded Plastic
Terminals: Solder Plated , Solderable per MIL-STD 750, Method 2026
Polarity: Cathode Band or Cathode Notch
Weight:0.093 grams(approx.)
Mechanical Dimensions:In Inches(mm)
SMB/DO-214AA
Dim.
A
B
C
D
E
F
G
H
Min.
Max.
Min.
Max.
3.30
3.94
0.130
0.155
4.06
4.70
0.160
0.185
1.80
2.20
0.071
0.087
0.152
0.305
0.006
0.012
4.80
5.59
0.189
0.220
2.10
2.60
0.083
0.102
0.051
0.203
0.002
0.008
0.76
1.52
0.030
0.060
In mm
In inch
SMB
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SMBJ SERIES
Technical Data
Marking Diagram:
Where XXXXX is YYWWL
KD/AD
YY
WW
L
SMBJ5.0
= Part Name
= Year
= Week
= Lot Number
SMBJ5.0C
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information
Device
Package
SMB
(Pb-Free)
SMBJ SERIES
Shipping
3000pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Parameter
Peak Pulse Power Dissipation at
TA=25°C by 10x1000μs Waveform
(Fig.1)(Note 1), (Note 2)
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave (Note 2),(Note 3)
Operating Junction and Storage
Temperature Range
Symbol
Value
Unit
PPPM
600
W
IFSM
100
A
TJ,TSTG
-55 to 150
°C
Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 5.0mm²(0.013mm thick)land areas.
3. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4pulses per minute maximum.
SMBJ SERIES
Technical Data
SMBJ SERIES
Technical Data
UNI-DIRECTIONAL 600 WATT SURFACE MOUNT TVS
UNIDIRECTIONAL
PART NO.
DEVICE
MARKING
CODE
REVERSE
STAND-OFF
VOLTAGE
VRWM (V)
BREAKDOWN
VOLTAGE
VBR (V) MIN.
@IT
BREAKDOWN
VOLTAGE VBR (V)
MAX.
@IT
TEST
CURREN
T
IT(MA)
MAXMUM
CLAMPING
VOLTAGE
@IPP
VC(V)
PEAK PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
SMBJ5.0
KD
5.00
6.40
7.82
10
9.6
62.5
800
SMBJ5.0A
KE
5.00
6.40
7.07
10
9.2
65.2
800
SMBJ6.0
KF
6.00
6.67
8.15
10
11.4
52.6
800
SMBJ6.0A
KG
6.00
6.67
7.37
10
10.3
58.3
800
SMBJ6.5
KH
6.50
7.22
8.82
10
12.3
48.7
500
SMBJ6.5A
KK
6.50
7.22
7.98
10
11.2
53.6
500
SMBJ7.0
KL
7.00
7.78
9.51
10
13.3
45.1
200
SMBJ7.0A
KM
7.00
7.78
8.60
10
12.0
50.0
200
SMBJ7.5
KN
7.50
8.33
10.18
1
14.3
42.0
100
SMBJ7.5A
KP
7.50
8.33
9.21
1
12.9
46.5
100
SMBJ8.0
KQ
8.00
8.99
10.99
1
15.0
40.0
50
SMBJ8.0A
KR
8.00
8.99
9.94
1
13.6
44.1
50
SMBJ8.5
KS
8.5
9.44
11.54
1
15.9
37.7
10
SMBJ8.5A
KT
8.5
9.44
1.43
1
14.4
41.7
10
SMBJ9.0
KU
9.0
10.00
12.22
1
16.9
35.5
5
SMBJ9.0A
KV
9.0
10.00
11.05
1
15.4
39.0
5
SMBJ10
KW
10
11.10
13.57
1
18.8
31.9
5
SMBJ10A
KX
10
11.10
12.27
1
17.0
35.3
5
SMBJ11
KY
11
12.20
14.91
1
20.1
29.9
5
SMBJ11A
KZ
11
12.20
13.48
1
18.2
33.0
5
SMBJ12
LD
12
13.30
16.26
1
22.0
27.3
5
SMBJ12A
LE
12
13.30
14.70
1
19.9
30.2
5
SMBJ13
LF
13
14.40
17.60
1
23.8
25.2
5
SMBJ13A
LG
13
14.40
15.92
1
21.5
27.9
5
SMBJ14
LH
14
15.60
19.07
1
25.8
23.3
5
SMBJ14A
LK
14
15.60
17.24
1
23.2
25.8
5
SMBJ15
LL
15
16.70
20.41
1
26.9
22.3
5
SMBJ15A
LM
15
16.70
18.46
1
24.4
24.0
5
SMBJ16
LN
16
17.80
21.76
1
28.8
20.8
5
SMBJ16A
LP
16
17.80
19.67
1
26.0
23.1
5
SMBJ17
LQ
17
18.90
23.10
1
30.5
19.7
5
SMBJ17A
LR
17
18.90
20.89
1
27.6
21.7
5
SMBJ18
LS
18
20.00
24.44
1
32.2
18.6
5
SMBJ18A
LT
18
20.00
22.11
1
29.2
20.5
5
SMBJ20
LU
27.13
1
35.8
16.7
5
SMBJ20A
LV
24.54
1
32.4
18.5
5
SMBJ22
LW
22
24.40
29.82
1
39.4
15.2
5
SMBJ22A
LX
22
24.40
26.97
1
35.5
16.9
5
SMBJ24
LY
24
26.70
32.63
1
43.0
14.0
5
SMBJ24A
LZ
24
26.70
29.51
1
38.9
15.4
5
SMBJ26
MD
26
28.90
35.32
1
46.6
12.4
5
SMBJ26A
ME
26
28.90
31.94
1
42.1
14.2
5
SMBJ28
MF
28
31.10
38.01
1
50.0
12.0
5
SMBJ28A
MG
28
31.10
34.37
1
45.4
13.2
5
SMBJ30
MH
30
33.30
40.70
1
53.5
11.2
5
SMBJ30A
MK
30
33.30
36.81
1
48.4
12.4
5
SMBJ33
ML
33
36.70
44.86
1
59.0
10.2
5
SMBJ33A
MM
33
36.70
40.56
1
53.3
13.2
5
SMBJ36
MN
36
40.00
48.89
1
64.3
9.3
5
SMBJ36A
MP
36
40.00
44.21
1
58..1
10.3
5
SMBJ SERIES
Technical Data
UNIDIRECTIONAL
PART NO.
DEVICE
MARKING
CODE
REVERSE
STAND-OFF
VOLTAGE
VRWM (V)
BREAKDOWN
VOLTAGE
VBR (V) MIN.
@IT
BREAKDOWN
VOLTAGE VBR (V)
MAX.
@IT
TEST
CURREN
T
IT(MA)
MAXMUM
CLAMPING
VOLTAGE
@IPP
VC(V)
PEAK PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
SMBJ40
MQ
40
44.40
54.27
1
71.4
8.4
5
SMBJ40A
MR
40
44.40
49.07
1
64.5
9.3
5
SMBJ43
MS
43
47.80
58.42
1
76.7
7.8
5
SMBJ43A
MT
43
47.80
52.83
1
69.4
8.6
5
SMBJ45
MU
45
50.00
61.11
1
80.3
7.5
5
SMBJ45A
MV
45
50.00
55.26
1
72.7
8.3
5
SMBJ48
MW
48
53.30
65.14
1
85.5
7.0
5
SMBJ48A
MX
48
53.30
58.91
1
77.4
7.7
5
SMBJ51
MY
51
56.70
69.30
1
91.1
6.6
5
SMBJ51A
MZ
51
56.70
62.67
1
82.4
7.3
5
SMBJ54
ND
54
60.00
73.33
1
96.3
6.2
5
SMBJ54A
NE
54
60.00
66.32
1
87.1
6.9
5
SMBJ58
NF
58
64.40
78.71
1
103.0
5.8
5
SMBJ58A
NG
58
64.40
71.18
1
93.6
6.4
5
SMBJ60
NH
60
66.70
81.52
1
107.0
5.6
5
SMBJ60A
NK
60
66.70
73.72
1
96.8
6.2
5
SMBJ64
NL
64
71.10
86.90
1
114.0
5.3
5
SMBJ64A
NM
64
71.10
78.58
1
103.0
5.8
5
SMBJ70
NN
70
77.80
95.09
1
125.0
4.8
5
SMBJ70A
NP
70
77.80
85.99
1
113.0
5.3
5
SMBJ75
NQ
75
83.30
101.81
1
134.0
4.5
5
SMBJ75A
NR
75
83.30
92.07
1
121.0
4.9
5
SMBJ78
NS
78
86.70
105.97
1
139.0
4.3
5
SMBJ78A
NT
78
86.70
95.83
1
126.0
4.7
5
SMBJ85
NU
85
94.40
115.38
1
151.0
3.9
5
SMBJ85A
NV
85
94.40
104.34
1
137.0
4.4
5
SMBJ90
NW
90
100.00
122.22
1
160.0
3.8
5
SMBJ90A
NX
90
10.00
110.53
1
146.0
4.1
5
SMBJ100
NY
100
111.00
135.67
1
179.0
3.4
5
SMBJ100A
NZ
100
111.00
122.68
1
162.0
3.7
5
SMBJ110
PD
110
122.00
149.11
1
196.0
3.0
5
SMBJ110A
PE
110
122.00
134.84
1
177.0
3.4
5
SMBJ120
PF
120
133.00
162.56
1
214.0
2.8
5
SMBJ120A
PG
120
133.00
147.00
1
193.0
3.1
5
SMBJ130
PH
130
144.00
176.00
1
231.0
2.6
5
SMBJ130A
PK
130
144.00
159.16
1
209.0
2.9
5
SMBJ150
PL
150
167.00
204.11
1
269.0
2.2
5
SMBJ150A
PM
150
167.00
184.58
1
243.0
2.5
5
SMBJ160
PN
160
178.00
217.56
1
287.0
2.1
5
SMBJ160A
PP
160
178.00
196.74
1
259.0
2.3
5
SMBJ170
PQ
170
189.00
231.00
1
304.0
2.0
5
SMBJ170A
PR
170
189.00
208.89
1
275.0
2.2
5
SMBJ180A
PT
180
201
222
1
292
2.1
1
SMBJ200A
PV
200
224
247
1
324
1.9
1
SMBJ220A
PX
220
246
272
1
356
1.7
1
SMBJ250A
PZ
250
279
309
1
405
1.5
1
SMBJ300A
QE
300
335
371
1
486
1.3
1
SMBJ350A
QG
350
391
432
1
567
1.1
1
SMBJ400A
QK
400
447
494
1
648
0.9
1
SMBJ440A
QM
440
492
543
1
713
0.9
1
“C” Suffix Designates Bi-directional Devices
“A” Suffix Designates 5% Tolerance Devices
No Suffix Designates 10% Tolerance Devices
“-A” Suffix is an AEC-Q101 qualified device
SMBJ SERIES
Technical Data
BI-DIRECTIONAL 600 WATT SURFACE MOUNT TVS
DEVICE
MARKING
CODE
REVERSE
STAND-OFF
VOLTAGE
VRWM (V)
BREAKDOWN
VOLTAGE
VBR (V) MIN.
@IT
BREAKDOWN
VOLTAGE VBR (V)
MAX.
@IT
TEST
CURRE
NT
IT(MA)
MAXMUM
CLAMPING
VOLTAGE
@IPP
VC(V)
PEAK PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
SMBJ5.0C
AD
5.00
6.40
7.82
10
9.6
62.5
1600
SMBJ5.0CA
AE
5.00
6.40
7.07
10
9.2
65.2
1600
SMBJ6.0C
AF
6.00
6.67
8.15
10
11.4
52.6
1600
SMBJ6.0CA
AG
6.00
6.67
7.37
10
10.3
58.3
1600
SMBJ6.5C
AH
6.50
7.22
8.82
10
12.3
48.7
1000
SMBJ6.5CA
AK
6.50
7.22
7.98
10
11.2
53.6
1000
SMBJ7.0C
AL
7.00
7.78
9.51
10
13.3
45.1
400
SMBJ7.0CA
AM
7.00
7.78
8.60
10
12.0
50.0
400
SMBJ7.5C
AN
7.50
8.33
10.18
1
14.3
42.0
200
SMBJ7.5CA
AP
7.50
8.33
9.21
1
12.9
46.5
200
SMBJ8.0C
AQ
8.00
8.99
10.99
1
15.0
40.0
100
SMBJ8.0CA
AR
8.00
8.99
9.94
1
13.6
44.1
100
SMBJ8.5C
AS
8.5
9.44
11.54
1
15.9
37.7
SMBJ8.5CA
AT
8.5
9.44
11.43
1
14.4
41.7
SMBJ9.0C
AU
9.0
10.00
12.22
1
16.9
35.5
10
SMBJ9.0CA
AV
9.0
10.00
11.05
1
15.4
39.0
10
SMBJ10C
AW
10
11.10
13.57
1
18.8
31.9
5
SMBJ10CA
AX
10
11.10
12.27
1
17.0
35.3
5
SMBJ11C
AY
11
12.20
14.91
1
20.1
29.9
5
SMBJ11CA
AZ
11
12.20
13.48
1
18.2
33.0
5
SMBJ12C
BD
12
13.30
16.26
1
22.0
27.3
5
SMBJ12CA
BE
12
13.30
14.70
1
19.9
30.2
5
SMBJ13C
BF
13
14.40
17.60
1
23.8
25.2
5
SMBJ13CA
BG
13
14.40
15.92
1
21.5
27.9
5
BIDIRECTIONA
L PART NO.
SMBJ14C
BH
14
15.60
19.07
1
25.8
23.3
5
SMBJ14CA
BK
14
15.60
17.24
1
23.2
25.8
5
SMBJ15C
BL
15
16.70
20.41
1
26.9
22.3
5
SMBJ15CA
BM
15
16.70
18.46
1
24.4
24.0
5
SMBJ16C
BN
16
17.80
21.76
1
28.8
20.8
5
SMBJ16CA
BP
16
17.80
19.67
1
26.0
23.1
5
SMBJ17C
BQ
17
18.90
23.10
1
30.5
19.7
5
SMBJ17CA
BR
17
18.90
20.89
1
27.6
21.7
5
SMBJ18C
BS
18
20.00
24.44
1
32.2
18.6
5
SMBJ18CA
BT
18
20.00
22.11
1
29.2
20.5
5
SMBJ20C
BU
27.13
1
35.8
16.7
5
SMBJ20CA
BV
24.54
1
32.4
18.5
5
SMBJ22C
BW
22
24.40
29.82
1
39.4
15.2
5
SMBJ22CA
BX
22
24.40
26.97
1
35.5
16.9
5
SMBJ24C
BY
24
26.70
32.63
1
43.0
14.0
5
SMBJ24CA
BZ
24
26.70
29.51
1
38.9
15.4
5
SMBJ26C
CD
26
28.90
35.32
1
46.6
12.4
5
SMBJ26CA
CE
26
28.90
31.94
1
42.1
14.2
5
SMBJ28C
CF
28
31.10
38.01
1
50.0
12.0
5
SMBJ28CA
CG
28
31.10
34.37
1
45.4
13.2
5
SMBJ30C
CH
30
33.30
40.70
1
53.5
11.2
5
SMBJ30CA
CK
30
33.30
36.81
1
48.4
12.4
5
SMBJ33C
CL
33
36.70
44.86
1
59.0
10.2
5
SMBJ33CA
CM
33
36.70
40.56
1
53.3
13.2
5
SMBJ36C
CN
36
40.00
48.89
1
64.3
9.3
5
SMBJ36CA
CP
36
40.00
44.21
1
58..1
10.3
5
SMBJ SERIES
Technical Data
BIDIRECTIONA
L PART NO.
DEVICE
MARKING
CODE
REVERSE
STAND-OFF
VOLTAGE
VRWM (V)
BREAKDOWN
VOLTAGE
VBR (V) MIN.
@IT
BREAKDOWN
VOLTAGE VBR
(V) MAX.
@IT
TEST
CURRE
NT
IT(MA)
MAXMUM
CLAMPING
VOLTAGE
@IPP
VC(V)
PEAK PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
SMBJ40C
CQ
40
44.40
54.27
1
71.4
8.4
5
SMBJ40CA
CR
40
44.40
49.07
1
64.5
9.3
5
SMBJ43C
CS
43
47.80
58.42
1
76.7
7.8
5
SMBJ43CA
CT
43
47.80
52.83
1
69.4
8.6
5
SMBJ45C
CU
45
50.00
61.11
1
80.3
7.5
5
SMBJ45CA
CV
45
50.00
55.26
1
72.7
8.3
5
SMBJ48C
CW
48
53.30
65.14
1
85.5
7.0
5
SMBJ48CA
CX
48
53.30
58.91
1
77.4
7.7
5
SMBJ51C
CY
51
56.70
69.30
1
91.1
6.6
5
SMBJ51CA
CZ
51
56.70
62.67
1
82.4
7.3
5
SMBJ54C
DD
54
60.00
73.33
1
96.3
6.2
5
SMBJ54CA
DE
54
60.00
66.32
1
87.1
6.9
5
SMBJ58C
DF
58
64.40
78.71
1
103.0
5.8
5
SMBJ58CA
DG
58
64.40
71.18
1
93.6
6.4
5
SMBJ60C
DH
60
66.70
81.52
1
107.0
5.6
5
SMBJ60CA
DK
60
66.70
73.72
1
96.8
6.2
5
SMBJ64C
DL
64
71.10
86.90
1
114.0
5.3
5
SMBJ64CA
DM
64
71.10
78.58
1
103.0
5.8
5
SMBJ70C
DN
70
77.80
95.09
1
125.0
4.8
5
SMBJ70CA
DP
70
77.80
85.99
1
113.0
5.3
5
SMBJ75C
DQ
75
83.30
101.81
1
134.0
4.5
5
SMBJ75CA
DR
75
83.30
92.07
1
121.0
4.9
5
SMBJ78C
DS
78
86.70
105.97
1
139.0
4.3
5
SMBJ78CA
DT
78
86.70
95.83
1
126.0
4.7
5
SMBJ85C
DU
85
94.40
115.38
1
151.0
3.9
5
SMBJ85CA
DV
85
94.40
104.34
1
137.0
4.4
5
SMBJ90C
DW
90
100.00
122.22
1
160.0
3.8
5
SMBJ90CA
DX
90
10.00
110.53
1
146.0
4.1
5
SMBJ100C
DY
100
111.00
135.67
1
179.0
3.4
5
SMBJ100CA
DZ
100
111.00
122.68
1
162.0
3.7
5
SMBJ110C
ED
110
122.00
149.11
1
196.0
3.0
5
SMBJ110CA
EE
110
122.00
134.84
1
177.0
3.4
5
SMBJ120C
EF
120
133.00
162.56
1
214.0
2.8
5
SMBJ120CA
EG
120
133.00
147.00
1
193.0
3.1
5
SMBJ130C
EH
130
144.00
176.00
1
231.0
2.6
5
SMBJ130CA
EK
130
144.00
159.16
1
209.0
2.9
5
SMBJ150C
EL
150
167.00
204.11
1
269.0
2.2
5
SMBJ150CA
EM
150
167.00
184.58
1
243.0
2.5
5
SMBJ160C
EN
160
178.00
217.56
1
287.0
2.1
5
SMBJ160CA
EP
160
178.00
196.74
1
259.0
2.3
5
SMBJ170C
EQ
170
189.00
231.00
1
304.0
2.0
5
SMBJ170CA
ER
170
189.00
208.89
1
275.0
2.2
5
SMBJ180CA
ET
180
201
222
1
292
2.1
1
SMBJ200CA
EV
200
224
247
1
324
1.9
1
SMBJ220CA
EX
220
246
272
1
356
1.7
1
SMBJ250CA
EZ
250
279
309
1
405
1.5
1
SMBJ300CA
FE
300
335
371
1
486
1.3
1
SMBJ350CA
FG
350
391
432
1
567
1.1
1
SMBJ400CA
FK
400
447
494
1
648
0.9
1
SMBJ440CA
FM
440
492
543
1
713
0.9
1
SMBJ SERIES
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SMBJ350CATR”相匹配的价格&库存,您可以联系我们找货
