Technical Data 2543
Effective April 2020
Supersedes May 2017
AGC
1/4” x 1-1⁄4” Fast-acting glass tube fuses
Applications
Primary circuit protection
Power supplies
Battery chargers
Monitors
Consumer electronics
Test equipment
Agency information
Product features
Fast-acting
Optional axial leads available
1⁄4” x 1-1⁄4” (6.3 mm x 32 mm) physical size
Glass tube, nickel-plated brass end cap
construction
UL Listed product meets standard 248-14
UL Listed card: File E19180, Guide JDYX (AGC
1⁄10 A - 10 A)
UL Recognition card: File E19180, Guide JDYX2
(AGC 11 A - 40 A)
CSA Component acceptance card (Class No.
1422-30)
CSA Certification acceptance card (Class No.
1422--01)
Ordering code
The ordering code is the part number replacing the
“/” with a “-” plus adding the packaging prefix and
option code.
BK- AGC- V- 1-10- R
Packaging prefix
Product code
Option code
Ampere rating
RoHS compliant
Packaging prefix
Blank (5 ferrule/cartridge parts in a 5 inch tin,
4 axial lead parts in a 5 inch tin)
BK- (100 parts packed into a cardboard carton
with flaps folded)
Option code
-B- (Board washable - Hermetically sealed to
withstand aqueous cleaning)
-V- (Axial leads - copper tinned wire with
nickel-plated brass end caps)
AGC
Technical Data 2543
Electrical characteristics
Amp Rating
% of Amp Rating
Opening Time
1/10 A – 40 A
100%
4 hours minimum
1/10 A – 40 A
135%
60 minutes maximum
1/10 A – 40 A
200%
120 seconds maximum
Product specifications
AC Interrupting rating (A)
Current
rating
(A)
Voltage rating
(Vac)
250 V
125 V
32 V
Typical DC cold
resistance1 (Ω)
Typical melting2
I²t (A2s)
Typical voltage
drop3 (V)
AGC-1⁄10-R
0.1
250
35
10,000
1000
17.55
0.0010
15.168
AGC-1⁄8-R
0.125
250
35
10,000
1000
10.825
0.0020
10.854
AGC-3⁄16-R
0.1875
250
35
10,000
1000
6.050
0.0070
7.652
AGC-2⁄10-R
0.5
250
35
10,000
1000
4.800
0.0080
6.105
AGC-1⁄4-R
0.25
250
35
10,000
1000
1.550
0.0160
0.984
AGC-3⁄10-R
0.3
250
35
10,000
1000
1.084
0.0270
0.886
AGC-3⁄8-R
0.375
250
35
10,000
1000
0.703
0.0900
0.548
AGC-1⁄2-R
0.5
250
35
10,000
1000
0.483
0.3850
0.324
AGC-3⁄4-R
0.75
250
35
10,000
1000
0.272
1.7160
0.309
AGC-1-R
1.0
250
35
10,000
1000
0.167
3.2400
0.256
AGC-1-1⁄4-R
1.25
250
100
10,000
1000
0.122
5.0940
0.222
AGC-1-1⁄2-R
1.5
250
100
10,000
1000
0.077
9.0230
0.218
AGC-2-R
2.0
250
100
10,000
1000
0.063
17.520
0.199
AGC-2-1⁄4-R
2.25
250
100
10,000
1000
0.052
22.832
0.194
AGC-2-1⁄2-R
2.5
250
100
10,000
1000
0.045
28.688
0.193
AGC-3-R
3.0
250
100
10,000
1000
0.035
45.900
0.191
AGC-4-R
4.0
250
200
10,000
1000
0.024
86.560
0.179
AGC-5-R
5.0
250
200
10,000
1000
0.019
131.500
0.170
AGC-6-R
6.0
250
200
10,000
1000
0.015
144.360
0.165
AGC-7-R
7.0
250
200
10,000
1000
0.012
195.02
0.159
AGC-7-1⁄2-R
7.5
250
200
10,000
1000
0.012
216.00
0.155
AGC-8-R
8.0
250
200
10,000
1000
0.009
256.00
0.152
AGC-9-R
9.0
250
200
10,000
1000
0.009
395.28
0.148
AGC-10-R
10
250
200
10,000
1000
0.008
486.00
0.141
AGC-12-R
12
32
1000
0.006
696.96
0.138
AGC-14-R
14
32
1000
0.005
776.16
0.132
AGC-15-R
15
32
1000
0.005
807.75
0.128
AGC-20-R
1000
0.0034
2440.00
0.125
AGC-25-R
25
32
1000
0.0027
3875.00
0.120
AGC-30-R
30
32
1000
0.0024
4950.00
0.135
AGC-35-R
35
32
1000
0.0021
7350.00
0.130
AGC-40-R
40
32
1000
0.0016
11360.00
0.125
Part Number
1. DC cold resistance measured at
很抱歉,暂时无法提供与“BK/AGC-50”相匹配的价格&库存,您可以联系我们找货
