Consumer Aftermarket
Product Catalog
Fuse Holders and Taps
Consumer Aftermarket Catalog
Fuse Holders & Taps
Cooper Bussmann offers a complete line of fuse holders to install either
blade-type or glass tube fuses. Choose water resistant and/or splash-proof
versions for extra protection in special applications. Four types of connectors
are available to meet the needs of technicians and do-it-yourselfers:
• Wire Loop. To install, simply cut the wire, strip ends and attach each end
to the circuit. Requires the use of additional connectors.
• Crimp-On. Strip wire and insert into fuse holder. Crimp the connections
tightly, and you're done. No additional hardware needed.
• Self-Stripping. Easy to install — simply locate fuse holder at a convenient
spot along the wire. Snap fuse holder closed around wire to pierce
insulation automatically.
• Quick-Connect. Attach fully insulated female push-on terminal onto the
1
/4” quick-connect terminals.
When selecting a fuse holder, always match the device to the wire being
fused. Using an undersized fuse holder will increase electrical resistance in
the circuit and reduce performance. NOTE: Never install a fuse with a larger
amp rating than specified for the holder.
Blade-Type Fuse Holders
HHU
In-Line Fuse Holders for ATM Fuses
Blister Tri-Lingual Maximum
Pack
Blister Volts/Amps
Part No.
HHL
HHM
HHU
ATM-FHID*
X
X
X
X
X
32V/20A
32V/30A
32V/30A
32V/20A
Leadwire Description
2x4”/#16
2x4”/#12
2x4”/#12
2x4”/#16
Holder with cover
Holder with cover
Water-resistant holder
Illuminating holder
HHL
HHM
* For use with regular ATM fuses. For details on the easyID™ line of illuminating ATM blade fuses,
see page 9.
ATM-FHID
In-Line Fuse Holders for ATC Fuses
Part No.
HHC
HHD
HHD-30
HHF
HHG
HHR
HHS
ATC-FHID*
Pack
Blister Volts/Amps
X
X
X
X
X
X
X
X
X
X
X
32V/20A
32V/30A
32V/30A
32V/20A
32V/30A
32V/30A
32V/20A
32V/20A
HHC
HHD
HHF
2x4”/#16
2x4”/#12
2x4”/#12
2x4”/#16
2x4”/#12
2x5”/#12
#18 to #14
2x6”/#16
Yellow water-resistant holder
Heavy-duty fuse holder
Holder with ATC-30A fuse
Holder with protective cover
Heavy-duty holder with cover
Heavy-duty water-resistant holder
Self-stripping fuse holder
Illuminating holder
HHR
HHG
* For use with regular ATC fuses. For details on the easyID™ line of illuminating ATC blade fuses, see page 9.
HHS
ATC-FHID
In-Line Fuse Holders for Maxi Fuses
Part No. Volts/Amps Leadwire
Description
HHX
Fuse holder with cover
32V/20-60A 2x5”/#6
HHX
For product information and data sheets, visit www.cooperbussmann.com
17
Fuse Holders & Taps
Fuse Taps For ATM and ATC Fuses
Tap into an existing circuit to power a mobile phone, stereo components,
etc. with Cooper Bussmann fuse tap accessories.
Part No.
Description
BP/ATM-TAP
5-Count: Taps into existing ATM fuse for additional non-fused
circuit, includes crimp-on connector that attaches easily to the
power lead for electronic gear.
5-Count: Taps into existing ATC fuse by fitting over the leg for
additional non-fused circuit, includes crimp-on connector.
Converts ATM fuse circuit into two fusible circuits. Inserts into
ATM fuse block, added circuit 10A max.
Converts an ATC fuse circuit into two fusible circuits. Inserts into
ATC fuse block, added circuit 10A max.
BP/ATC-TAP
BP/HHH
BP/HHA
BP/ATM-TAP
BP/ATC-TAP
BP/HHH
BP/HHA
Glass Tube In-Line Holders For 1/4" Diameter Fuses
Blister TriPart No. Pack Lingual
Fuse/Size
Ratings
Leads/
Volts/Amps Terminals
HFA
HFB
HHB
HHK
HHN
HMJ
HMK
HRH
HRI
HRJ
/4” x 11/4”
250V/20A
/4” x 11/4”
32V/30A
1
/4” x 7/8” to 11/4”
32V/30A
1
/4” x 5/8” to 11/4” & SFE-20 32V/20A
1
/4” x 11/4”
32V/30A
For SFE-20 (included)
32V/20A
1
/4” x 11/4” & SFE-20
32V/30A
For SFE-9 (included)
32V/9A
For SFE-14 (included)
32V/14A
32V/20A
Crimp #12 to 16 wire
Crimp #12 to 18 wire
#14 leadwire/yellow
#12 leadwire/yellow
8" of #14 leadwire/bk
#12 leadwire/bk
19" of #14 leadwire
19" of #14 leadwire/bk
/4” dia. x 7/8” to 11/4”
#14 leadwire/bk
1
HRK
X
X
X
X
X
X
X
X
X
X
X
X
X
HHK
1
32V/15A
1
HMJ
HHN
Description
Feature
Water-resistant-black body
Water-resistant-yellow body
Universal-yellow body
Universal nylon, twist lock, no fuse-black body
Nylon heavy-duty w/ AGC-30 fuse-white body
With fuse and wire loop leads-black body
No fuse, wire loop leads-black body
With fuse and wire loop leads-gray body
Universal with wire loop leads and
springs for different fuse lengths-black body
HRI
HMK
HRJ
HFB
HFA
HHB
HRK
Panel-Mount Holders For 1/4" x 11/4" Fuses
Part No.
HKP
HKP-HH
HTB-26I
HTB-38I
HTB-68I
HTB-88I
HKP
18
Blister Max. Panel
Pack Thickness
X
X
0.3”
0.3"
0.3"
0.3"
0.3"
0.125"
Knob Type
Knob
Knob
Knob
Screwdriver/slotted
Knob
Knob
HKP-HH
Description/Mounting
Terminals
Ratings
Volts/Amps
High-profile cover knob, rear hexnut
Low-profile cover knob, rear hexnut
Low-profile cover knob, front hexnut
Low-profile cover knob, through-hole snap
Solder terminals
In-line 1/4” quick-connect terminals
Right angle 1/4” quick-connect terminals
250V/30A
250V/15A
250V/20A
250V/20A
250V/20A
250V/20A
HTB-26I
1
HTB-38I
HTB-68I
HTB-88I
很抱歉,暂时无法提供与“BP/HMK”相匹配的价格&库存,您可以联系我们找货
