DATA SHEET
Part Number: AS32 5R020
D
T
L
A
S
C
B
Electrical Specifications:
Resistance @ 25°c
Max Steady State Current Up to 65°c
Max recommended energy rating (Joules)
Max capacitance @
120VAC/240VAC/480VAC/680VAC
Actual failure point of instantaneous energy (Joules)
Resistance @ 100% of Max Current
Resistance @ 50% of Max Current
Body Temperature @ 100% Current rating
Dissipation Constant
Material Type
ROHS Compliant
MSL (moisture sensitivity level)
Mechanical Specifications:
5.0 25 %
20.0 A
300.00 J
20600/5200/1300/640
μF
600.00 J
0.025
0.060
215 °C
78.20 mW/°C
H
Yes
#1
D
32.0 mm Max
T
8.4 mm Max
S
Straight Leads
Coating run down
L
17.1 mm Nom
A (Lead Width)
2.2 mm Nom
B
5.4 mm Nom
C (Lead Thickness)
0.8 mm Nom
Revision Date: 11/1/21
Ametherm, Inc. 961 Fairview Dr. Carson City, NV 89701
Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670
www.ametherm.com
6.0 mm Max
21.0 mm Nom
很抱歉,暂时无法提供与“AS325R020”相匹配的价格&库存,您可以联系我们找货
