SL322R025-B
SL322R025-B
    MATRIXORBITAL
    ICL2OHM20%25A31MM
SL322R025-B 数据手册
Data Sheet SL32 2R025 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 31.0 ± max 7.0 ± max 1.0 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 5.0 ± max B: 7.80 ± nom C: 3.90 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 2.0 Ω ± 20 % 25.00 A Max Rec. Energy Rating: 250 J Actual Failure Instantaneous Energy: 548 J Maximum Capacitance @ 120 VAC: 20,839 µf Maximum Capacitance @ 240 VAC: 5,209 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.06 Ω 236.00 °c 45.4 mw/°c 194 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): G SL32 2R025 Date: 01/07/2016 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Chad Terry Revison: B
SL322R025-B 价格&库存
很抱歉,暂时无法提供与“SL322R025-B”相匹配的价格&库存,您可以联系我们找货
