AS350R550
AS350R550
    MATRIXORBITAL
    ICL0.5OHM25%50A36MM
AS350R550 数据手册
DATA SHEET Part Number: AS35 0R550 D T L A C S B Electrical Specifications: Mechanical Specifications: 0.5   25 % 50.0 A D 36.0 mm Max Max recommended energy rating (Joules) 800.00 J T 8.4 mm Max Actual failure point of instantaneous energy (Joules) 1400.00 J S Straight Leads Coating run down L 19.0mm Nom 22.0 mm Nom A (Lead Width) 2.2 mm Nom B 5.5 mm Nom C (Lead Thickness) 0.8 mm Nom Resistance @ 25°c Max Steady State Current Up to 65°c Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Thermal Time Constant Material Type ROHS Compliant MSL (moisture sensitivity level) 0.008  0.020  210 °C 78.20 mW/°C 55 seconds B Yes #1 Revision Date: 10/21/21 Ametherm, Inc. 961 Fairview Dr. Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 ww.ametherm.com 8.0 mm Max
AS350R550 价格&库存
很抱歉,暂时无法提供与“AS350R550”相匹配的价格&库存,您可以联系我们找货
