Technical Data 9000
Effective March 2019
Supersedes January 2019
BUSSMANN
SERIES
UL Class CF branch circuit time-delay CUBEFuse
Electrical characteristics
2011/65/EU
10 seconds minimum operating time at 500%
rated current
Agency information
Catalog symbols
TCF_ (indicating fuse, 6-400 A)
TCF_RN (non-indicating fuse, 1-400 A)
UL Listed Class CF fuse: Guide JDDZ, File
E4273 (up to 400 A)
CSA® Certified fuse: Class 1422-02,
File 053787_C_000 (up to 100 A)
CE (100 A and below)
RoHS compliant
Watts loss at rated current
Fuse amps
Watts
Description
30
3.99
The Bussmann™ series Low-Peak™ CUBEFuse™
is a UL® Class CF current-limiting, dual-element,
time-delay branch circuit fuse with Class J
electrical performance. Available in indicating and
non-indicating versions, this finger-safe fuse has
a very compact, space-saving size and is easily
applied using the CUBEFuse holder (TCFH_N), UL
98 Compact Circuit Protector switch (CCP2-_CF)
or Compact Circuit Protector Base (CCP2B up
to 100 A) used in the Quik-Spec™ Coordination
Panelboard).
60
6.23
100
9.51
200
18.6
225
17.6
400
35.2
Ratings
Volts
600 Vac
300 Vdc
Amps
• 6-400 A (indicating)
1-400 A (non-indicating)
Interrupting rating
• 300 kA RMS Sym. (Up to 100 A UL)
200 kA RMS Sym. (110 to 400 A UL)
200 kA RMS Sym. (Up to 100 A CSA)
100 kA DC (Up to 400 A UL and up to 100 A
CSA)
Operating and storage temperature range
-40 to 80°C (-40°F to 176°F)
Catalog numbers (amps)
Indicating CUBEFuse
TCF6
TCF35
TCF90
TCF225
TCF10
TCF40
TCF100
TCF250
TCF15
TCF45
TCF110
TCF300
TCF17-1/2
TCF50
TCF125
TCF350
TCF20
TCF60
TCF150
TCF400
TCF25
TCF70
TCF175
TCF30
TCF80
TCF200
Non-Indicating CUBEFuse
TCF1RN
TCF25RN
TCF70RN
TCF175RN
TCF3RN
TCF30RN
TCF80RN
TCF200RN
TCF6RN
TCF35RN
TCF90RN
TCF225RN
TCF10RN
TCF40RN
TCF100RN
TCF250RN
TCF15RN
TCF45RN
TCF110RN
TCF300RN
TCF17-1/2RN
TCF50RN
TCF125RN
TCF350RN
TCF20RN
TCF60RN
TCF150RN
TCF400RN
Technical Data 9000
Features
Dimensions — in (mm)
Smallest installed footprint of any UL Class CC, J, or R fuse
solution
Easy application using CUBEFuse holders (TCFH_N), UL 98
Compact Circuit Protector (CCP2) switches and Compact Circuit
Protector Base (CCP2B up to 100 A). See data sheet 9007 for
details on the CUBEFuse holder, 10801 for details on the CCP2-_
CF switch and 1161 for the CCP2B.
B
C
A
Up to 100 A
Holders and switches have an amp rating rejection feature to help
prevent overfusing; 30, 60 and 100 A switches and holders will
hold any CUBEFuse up to its rating, 200 and 400 A switches and
200, 225 and 400 A holders will hold any CUBEFuse 110 A and
above up to its rating
UL Class CF with Class J time-delay electrical performance
Available in indicating and non-indicating versions
The indicating version features local easyID™ open fuse
technology for faster troubleshooting and reduced downtime
B
C
A
Faster response to damaging faults helps reduce destructive
thermal and magnetic forces
True dual-element fuse construction with a minimum 10 seconds
time-delay at 500% of rating
Long time-delay minimizes nuisance openings caused by
temporary overloads and transient surges
Up to 300 kA interrupting rating safely interrupts virtually any fault
Fuse
amps
Robust cycling and inrush current withstand
1-15
Low let-through currents under fault conditions
17-1/2
Provides Type 2 “No Damage” protection for IEC motor starters
when properly sized
Easy selective coordination with any other Bussmann series
Low-Peak Class CC, J, L or RK1 fuse with simple 2:1 amp ratio
between upstream and downstream fuses
* Finger-safe status depends on final, installed application, and will require using
accessory shrouds for 110 to 400 A ratings.
D
E
110 to 400 A
D
E
A
B
C
D
1.88 (48)
0.75 (19)
1.0 (25)
0.27 (7)
25-30
0.31 (8)
35-40
0.36 (9)
45-50
2.13 (54)
60
1.13 (29)
3.01 (76)
1.26 (32)
100
0.44 (11)
0.49 (12)
0.51 (13)
125
0.51 (13)
175
3.62 (92)
2.9 (74)
1.34 (34)
1.02 (26)
200
250-400 A
Carton quantity and weight
Amp range
2
Carton qty.
Weight per carton lb (kg)
Up to 30
12
1.39 (0.63)
35-60
12
1.42 (0.64)
70-100
6
1.74 (0.79)
110 to 225
1
0.71 (0.32)
250 to 400
1
1.23 (0.56)
Eaton.com/bussmannseries
0.57 (14.5)
0.63 (16)
250
0.73 (18.5)
350
110-225 A
0.51 (13)
0.57 (14.5)
225
300
70 to 100 A
0.64 (16)
0.57 (14)
110
150
Up to 30 A 35 to 60 A
0.67 (17)
1.0 (25)
70
80-90
E
0.23 (6)
400
4.25 (108)
3.46 (88)
1.69 (43)
1.47 (36)
0.79 (20)
0.86 (21.5)
0.86 (21.5)
Technical Data 9000
400A
1000
200A
225A
250A
110 to 400 A time-current characteristics — average melt
110A
Up to 100 A time-current characteristics — average melt
TIME IN SECONDS
100
10
1
100
1,000
0.01
10,000
0.1
CURRENT IN AMPS
110 to 400 A current let-through curves
B
100,000
400A
250A
225A
200A
110A
10,000
1,000
PROSPECTIVE SHORT CIRCUIT CURRENT
SYMMETRICAL RMS AMPS
100,000
10,000
100
1,000
A
100
INSTANTANEOUS PEAK LET-THRU CURRENT IN AMPS
Up to 100 A current let-through curves
3
Technical Data 9000
Motor sizing table (from NEC Tables 430.248 and 430.250)
Bussmann series TCF Low-Peak time-delay Class CF fuses
Voltage
115 Vac,
1-phase
230 Vac,
1-phase
200 Vac,
3-phase
NEC
code max
(amps)
Heavy
start*
(amps)
Motor size
(Hp)
Motor FLA
(amps)
Min
(amps)
NEC
code max
(amps)
Heavy
start*
(amps)
0.167
4.4
10
10
0.25
5.8
10
15
0.333
7.2
15
15
0.5
9.8
15
13.8
25
25
30
2
7.5
15
15
15
1
16
25
30
35
3
10.6
17.5
35
45
35
2
24
40
45
50
3
34
50
60
5**
56
90
7.5
80
125
10
100
150
0.167
2.2
0.25
2.9
0.333
Motor size
(Hp)
Motor FLA
(amps)
Min
(amps)
10
0.5
2.4
6
6
6
15
0.75
3.5
6
10
10
15
1
4.6
10
10
10
6.6
10
15
15
Voltage
5
16.7
25
30
7.5
24.2
40
45
50
70
20**
59.4
90
110
125
100
125
25
74.8
125
150
150
150
175
30
88
150
175
175
175
225
40
114
175
200
250
6
6
6
50
143
225
300
300
6
6
6
60
169
300
300
350
3.6
6
10
10
0.5
2.2
6
6
6
0.5
4.9
10
10
10
0.75
3.2
6
6
6
0.75
6.9
15
15
15
1
4.2
10
10
10
15
208 Vac,
3-phase
1
8
15
15
17.5
1.5
6
10
15
1.5
10
15
6.8
15
15
15
2
12
25
3
9.6
15
17
25
30
35
5
28
45
50
60
230 Vac,
3-phase
5
15.2
25
30
30
7.5
22
35
40
45
7.5
40
60
70
90
20**
54
90
100
110
10**
50
80
90
110
25
68
110
125
150
0.5
2.5
6
6
6
30
80
125
150
175
0.75
3.7
6
10
10
40
104
175
200
225
1
4.8
10
10
10
50
130
200
250
250
1.5
6.9
15
15
15
60
154
250
300
300
2
7.8
15
15
17.5
75
192
300
350
400
3
11
17.5
1.1
3
3
3
5
17.5
30
35
35
0.75
1.6
3
3
3
7.5
25.3
40
45
50
1
2.1
6
6
6
20**
62.1
100
110
125
1.5
3
6
6
6
25
78.2
125
150
175
2
3.4
6
6
6
30
92
150
175
200
3
4.8
10
10
10
40
120
200
225
250
5
7.6
15
15
15
50
150
225
300
300
7.5
11
17.5
177
300
350
350
Note: Use NEC code max column for low to moderate reverse/jog/
plug applications.
* Heavy Start permitted only if NEC code max does not allow motor start-up.
** If equipment terminations are rated for 60°C conductors only, the 60°C
conductor ampacities must be utilized and therefore larger conductor sizes or
conduit sizes may be required.
460 Vac,
3-phase
10
14
25
25
30
15
21
35
40
45
40
50
60
50**
65
100
125
125
60
77
125
150
150
75
96
150
175
200
250
100
124
200
225
125
156
250
300
350
150
180
300
350
400
plug applications.
4
Technical Data 9000
Voltage
575 Vac,
3-phase
Motor size
(Hp)
Motor FLA
(amps)
Min
(amps)
NEC
code max
(amps)
Heavy
start*
(amps)
0.5
0.9
3
3
3
0.75
1.3
3
3
3
1
1.7
3
3
3
1.5
2.4
6
6
6
2
2.7
6
6
6
3
3.9
6
10
10
5
6.1
10
15
15
7.5
9
15
11
17.5
40**
41
70
80
80
50
52
80
100
110
60
62
100
110
125
75
77
125
150
150
100
99
150
175
200
125
125
200
225
250
150
144
225
300
300
200
192
300
350
400
plug applications.
5
Technical Data 9000
CUBEFuse (cat. no. TCFH_N) holders
The CUBEFuse is used in holders that can be dovetail together for
the smallest footprint possible of any Class J fuse solution (see data
sheet no. 9007 for details).
Finger-safe DIN-Rail or panel
mount holders up to 100 A.
30 A holder accepts any
CUBEFuse up to 30 A.
60 amp holder accepts any
CUBEFuse up to 60 A.
100 amp holder accepts any
CUBEFuse up to 100 A.
Panel mount holders from
200 to 400 A.
200 A holder accepts any
CUBEFuse from 110 to 200 A
225 A* holder accepts any
CUBEFuse from 110 to 225 A
400 A holder accepts any
CUBEFuse from 110 to 400 A
200 and 400 A Compact Circuit Protector (cat. no. CCP2-CF)
switches
These panel mounted 1-, 2and 3-pole switches are UL 98
horsepower rated disconnects.
Each CCP2 will accept a fuse
amp rating equal to or less than
its rating (e.g., a 200 A CCP will
accept any CUBEFuse from 110
to 200 A). Complete installation
requires installing various
lugs to meet the application
requirement. Accessories
include side or front rotary
operators and auxiliary contacts
(see data sheet no. 10801 for
details).
Compact Circuit Protector Base (cat. no. CCP2B)
These 1-, 2- and 3-pole switches
are UL 98 horsepower rated
branch circuit disconnects.
Primarily used in the Quik-Spec
Coordination Panelboard, they’re
available in ratings up to 100 A.
The CCP2B has amp rejection
breaks that prevent installing
any CUBEFuse amp rating
greater than that of the switch.
These coincide with standard
conductor ampacities to help
prevent overfusing and are
available at 15, 20, 30, 40, 50,
60, 70, 90 and 100 amps for all
1-, 2- and 3-pole switches.
Finger-safe installation
achievable for three ganged
holders and lug kits with shroud
* 200 A and 225 A holders share the
same overall dimensions, but the
200 A holder will reject a 225 A fuse.
30, 60 and 100 A Compact Circuit Protector (cat. no.CCP2_CF)
switches
These DIN-Rail mounted 1-, 2and 3-pole switches are UL 98
available with front or side
rotary operators. Each CCP2
will accept a fuse amp rating
equal to or less than its rating
(e.g., a 60 A CCP will accept
any CUBEFuse up to 60 A).
Accessories include multi-wire
lug kits with shrouds, auxiliary
contacts and PLC fuse monitor
details).
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document
are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help
the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue
or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 9000 – BU-SB18086
March 2019
Eaton, Bussmann, CUBEFuse, Low-Peak,
easyID and Quik-Spec are valuable trademarks
of Eaton in the US and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group
NEC is a registered trademark of the National
Fire Protection Association
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
