CATALOG 126 backup:CATALOG 126.qxd
9/27/2010
11:57 AM
Page 29
DIN-Based VectorPaktm Subracks
ELECTRONICS
ELECTRONICS && TECHNOLOGY,
TECHNOLOGY, INC.
INC.
AAFINE
FINETECHNOLOGY
TECHNOLOGYGROUP
GROUP
4HP Keyable Card Guides IEEE 1101.10
ESD clip for bottom
ESD clip for top
CG-3 Card Guide with ESD clips shown
P/N CG3-160 Grey Card Guide
VectorPaktm CG3-160 polycarbonate
card guide for .062” to .090” thickness cards.
PCB ESD Contact for CG-3 Card Guides
P/N CG3-ESD/12
DIN
Subracks
ESD clip makes contact with rail
Electrostatic discharge clips (ESD) for VectorPaktm
CG3-Series card guides will provide permanent ES
discharge of the PCB before contact with connector
Part Number
Keys are used for keying plug-in assemblies such as
front panels and prevents them from being used in
incorrect slots. These keys are installed into the front
chambers of VectorPaktm CG3-160 or CG3-220 card
guides and matched with an offsetting key inserted into
type IV injector/ejector handles. By keying upper and
lower card guides, over 4,000 combinations are possible. Available in packs of 25 in red or grey (RAL 7032).
Description
CG3-80/12
CG3-80E/12
CG3-160/12
CG3-160R/12
CG3-160E/12
CG3-220/12
CG3-220E/12
CG3-280/12
CG3-ESD/12
Card Guide 80mm for rear I/O
Same with ESD Clip
Card Guide Grey (RAL 7032) 160mm long
Card Guide Red 160mm long
Card Guide 160mm long - ESD clip
Card Guide 220mm long
Card Guide 220mm long - ESD clip
Card Guide 280mm long
Universal ESD clip (if ordered separately)
can be used on CG3-80, 160, 220 card
guides
Pk
Pk
Pk
Pk
Pk
Pk
Pk
Pk
Pk
CG3-K01/25
CG3-K02/25
Grey Keys (RAL 7032)
Red Keys
Pk 25
Pk 25
www.vectorelect.com
12
12
12
12
12
12
12
12
12
P/N CG3-80 Card Guide
80mm rear I/O card guides are designed for use with
our standard CG3-ESD clips and are fully keyable.
Comes with self-tapping screw for attachment to
horizontal rail.
800-423-5659
29
ELECTRONICS & TECHNOLOGY, INC.
A FINE TECHNOLOGY GROUP
Specification subject to change without notice
29b
www.vectorelect.com
800-423-5659
10/7/2008
11:32 AM
Accessories
Page 30
PCB Retainers and Ejector Levers
For Use Without Front Panels
DIN
Subracks
VectorPaktm non-keyed card guides are designed for use with card retainers when front panels are not used.
Optional levers attach onto .062” thick cards and release when pulled. Retainers are secured beneath the
snap-in card guides and may be used without levers. For use with VectorPaktm CCA46 through CCA52 series
subracks. Custom lengths available (contact factory)
• To secure and extract PCBs without front
panels
• Optional card ejector levers fasten to
0.062” thick PCBs
• VectorPaktm non-keyed card guides
(shown with optional ESD clips
installed)
P/N.
CG4-160/12
CG4-220/12
Description
Card guides with retainers for 160mm cards, 12 non-keyed guides and 12 retainers
Card guides with retainers for 220mm cards, 12 non-keyed guides and 12 retainers
CG3-160S/12
CG4-ESD
Card guides only, non-keyed type, pack of 12
ESD clips for CG3-160S non-keyed card guides, pack of 12
(ESD clips cannot be used with CG4 retainers)
CG4-RET/12
CG4-LEJ/12
Card guide retainers for use with non-keyed guides only
Ejector pull-type lever for retainers, pack of 12 (can be used as lever/pull with all
VectorPaktm subracks)
30
www.vectorelect.com
800-423-5659
很抱歉,暂时无法提供与“CG4-LEJ/12”相匹配的价格&库存,您可以联系我们找货
