1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack 2-Post Open Frame Rack, 800 lbs
(362.9 kgs) Capacity - Organize and Secure
Network Rack Equipment
MODEL NUMBER: SR2POST
Highlights
45U 2-post open frame rack
Black aluminum with 12-24
threaded and numbered
mounting holes
Toolless button keyhole
mounting slots accept PDUs or
cable managers
Package Includes
Description
Tripp Lite's SR2POST 2-Post SmartRack Open Frame Rack is an economical way to accommodate 45U
of rack space for 19-inch rack mount applications where space is at a premium. Its heavy-duty, aluminum
construction can safely support 800 lbs (362.9 kgs) of rackmount equipment. The black, textured power
coat finish makes it resistant to scratching while giving it a classic, attractive appearance. The SR2POST
is easy to install due to a self-squaring design combined with 12-24 threaded and numbered mounting
holes, and bolt down provisions. Only standard hand tools are required for installation (9/16" wrench and
9/16" socket/ratchet). Multiple units can be bolted together side by side for easy expansion or
customization when required. The SR2POST 2-Post SmartRack Open Frame Rack has been approved by
EIA-310-D, IEC 60297-3-100, and RoHS, and is backed by a 5-year warranty.
Features
Supports 800 lbs (362.9 kgs) of rackmount equipment
Textured powder coat finish
Heavy Duty Aluminum construction
12-24 threaded and numbered mounting positions
Bolt down provisions
Self squaring design
Black finish
Toolless button keyhole mounting slots accept PDUs and cable managers
Easy assembly
Specifications
OVERVIEW
UPC Code
037332127563
1/3
SR2POST
28 pieces each of 12-24 screws
and washers for equipment
mounting
Installation hardware
Cable management hooks
Warranty information
Owner's Manual
Cleveland, OH 44122
United States
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Extra Deep
EIA Mounting Rails
12-24 threaded and numbered vertical mounting rails
Mounting Holes or Slots
Yes
Maximum Device Depth (cm)
121.92
Maximum Device Depth (in.)
48
Maximum Device Depth (mm)
1,219
Shipping Dimensions (hwd / in.)
4.90 x 6.30 x 88.00
Shipping Dimensions (hwd / cm)
12.45 x 16.00 x 223.52
Shipping Weight (lbs.)
33.00
Shipping Weight (kg)
14.97
Unit Dimensions (hwd / in.)
84.010 x 20.300 x 13.500
Unit Dimensions (hwd / cm)
213.36 x 51.56 x 12.07
Unit Weight (lbs.)
29
Unit Weight (kg)
13.15
Weight Capacity - Stationary (kg)
363
Weight Capacity - Stationary (lbs.)
800
Number of Vertical Mounting Rails
2
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
2/3
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR2POST”相匹配的价格&库存,您可以联系我们找货
