1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack Premium 42U Server Rack Enclosure,
Secure, Standard-Depth
MODEL NUMBER: SR42UB
Highlights
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimal use of floor space
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors
Locking, removable side panels
keyed alike with doors
Pre-installed casters and
leveling feet; Rolls through
standard 7-ft. (2.13 m) doorway
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
Package Includes
Heavy-duty, locking, 42U Premium Rack Enclosure Cabinet that accommodates all standard 19-inch
rackmount equipment and ships fully assembled for quick and easy deployment in secure, high-density
server and IT networking environments.
Features
Ships fully assembled for rapid deployment and rolls into place on heavy-duty pre-installed casters
(casters are removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Tough textured powder coat finish resists conditions found in non-IT environments such as warehouses
Massive front-to-rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements
Maximum usable internal depth of 37 inches/94 cm (front to rear rail)
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling
Front door is locking, reversible and removable
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 600mm or 24" to match standard data center floor tiles
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable
Compact design allows the enclosure to roll through standard height commercial doorways
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
1/3
SR42UB Rack Enclosure
(4) side panels
(4) side panel locks
(2) door & side panel keys
(50) M6 screws
(50) M6 washers
(50) M6 cage nuts
Owner's Manual
Cleveland, OH 44122
United States
Open bottom for cable access
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance
Compatible with airflow optimization and cable management accessories
Specifications
OVERVIEW
UPC Code
037332123770
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
42U
Rack Depth
Standard
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
85.00 x 26.00 x 45.00
Shipping Dimensions (hwd / cm)
215.90 x 66.04 x 114.30
Shipping Weight (lbs.)
336.00
Shipping Weight (kg)
152.41
Unit Dimensions (hwd / in.)
78.500 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
199.39 x 60.02 x 109.22
Unit Weight (lbs.)
281
Unit Weight (kg)
127.46
Weight Capacity - Rolling (kg)
1,021
2/3
Cleveland, OH 44122
United States
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Details
Front and back door frames
Built-in Cable Management
Yes
Extra Wide
No
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
CE (Europe); EIA/ECA-310-E; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR42UB”相匹配的价格&库存,您可以联系我们找货
