Raspberry Pi Model B+ / Pi 2 / Pi 3 Case Lid
- Red
PRODUCT ID: 2335
Description
Now that we have The Single Greatest Raspberry Pi Model B+ / Pi 2 Case Ever - we decided to make it
even better by adding COLORS!!!!!
Mix and match snap-on lids and bases to form your favorite combinations. Buy one base then match
different colored lids to your room or outfit. Or buy all of them so that you can adjust your Pi B+'s case
based on your mood, your favorite sports team, or even your aura.
With 81 unique combinations, the possibilities are fun, colorful and (almost) endless!
This is just the red lid of the Raspberry Pi Model B+ / Pi 2 case. Check out our different colored
bases or select a different color lid.
This enclosure was designed by Mike Doell. It's made of ultra-durable, super-glossy polycarbonate, and is
both good looking and tough enough to toss into your bookbag or toolbox. It has slim openings for all your
cables, an easy-to-remove beveled slot for your Micro SD card, slots for both your Pi Camera and
upcoming Display, and a space for your GPIO cable to extend out from the Pi.
The Pi snaps into the base and the lid fits snugly onto the top. If you want to break out your Pi you can use
your case without the lid and add hats to your B+ with ease.
This case works for the Raspberry Pi Model B+ / Pi 2 only. It does not work for the Raspberry Pi
Model A or B. It does work with the model A+ but there will be a bit of empty space of course, and you'll
need to snake your USB cable or connector through the front holes which may not work if the cable is
bulky.
No Raspberry Pi included. This is just the lid of the case and no base is included.
Technical Details
o
o
Dimensions: 93mm x 65mm x 3mm / 3.7" x 2.6" x 0.1"
Weight: 19g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2335”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.980711+4.10694
