Main Catalog
24th Edition
Main Catalog
Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM
Equipment Protection Solutions
12/2017
39601-641 © 2012 Pentair Equipment Protection
18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1
10.10.2012 11:15:02
DESIGN WITH CONFIDENCE
Pentair, together with its Hoffman®,
McLean® and Schroff® brands, is a
leading manufacturer of products and
solutions for the housing, protection
and cooling of electrical and electronic
assemblies and components.
Under the slogan "Design with
CONFIDENCE®" the company offers
the highest standards across the
industry for quality, performance
and design. Pentair offers a vast
diversity of off-the-shelf products
as well as modified and customized
solutions for applications in the
measurement and instrumentation,
telecommunications and data
processing, energy and industrial,
transport and medical industries
and for electronic systems for
security and defense.
When you enter a partnership
with Pentair you are drawing on
the capabilities of a company that
has all the necessary financial and
other resources at its disposal to
develop, manufacture and assemble
application-critical systems to your
requirements, down to defined
function testing and prompt delivery
of the goods anywhere in the world.
Regional Headquarters
Anoka, MN, USA
Boituva, Brazil
Straubenhardt, Germany
Singapore
Shanghai, China
Manufacturing and
Logistics Locations
Pharr, TX, USA
Anoka, MN, USA
Mt. Sterling, KY, USA
Radford, VA, USA
Warwick, RI, USA
San Diego, CA, USA
Boituva, Brazil
Melbourne, Australia
Reynosa, Mexico
Betschdorf, France
Dzierzoniow, Poland
Bangalore, India
Qingdao, China
Meiwa, Japan
Pentair Equipment Protection brands
pentairequipmentprotection.com
02
18002_Hautpkatalog_Schroff_EN_AK03.indd 2
17.10.2012 11:18:23
INNOVATIVE, SOPHISTICATED,
CUSTOMER-ORIENTED AND WITH GLOBAL
PRESENCE: Schroff
The Schroff® brand stands for
recognized, globally leading
developments in electronics packaging
components and systems for
applications in measurement,
instrumentation and control systems,
infrastructure, security systems, data
communications, telecommunications
and automation. Our customeroriented thinking and mode of working
is an important element of our
business model.
At a glance: what sets Schroff products apart:
- Certified to global standards
- Global availability
- Outstanding quality
- Innovative solutions
- Comprehensive heat management
- Large off-the-shelf product program
- Modifications to your requirements
- Custom new developments
- Customer-oriented thinking and
operations
- Service quality and competence
- Extensive testing
- Best price-performance ratio
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 3
03
17.10.2012 11:20:01
SIX STEPS
TO THE RIGHT PRODUCT
1. APPLICATION
The choice of enclosure often depends
on the field of application and/or
market segment. Does your product
require a door, shelves, slide rails or a
support arm for a monitor? Is ease of
access important? Do you require
cooling for your components,
redundancy or electromagnetic
2. ENVIRONMENT
Environmental conditions are perhaps
the most important factor when
selecting the correct enclosure.
Is it intended for use in, say,
telecommunications, industry,
measurement and control,
infrastructure or security systems,
or as a data communications system?
You should also consider the main
challenges the enclosure will face,
such as:
- electromagnetic radiation
3. STANDARDS
Select an enclosure that satisfies the
required standard of protection for the
environment and application in
question. The evaluation criteria of
protection classes such as NEMA, UL,
cUL, Telcordia GR-487, CSA, DIN, VDE,
GOST, RoHS, CE, IEC, EN, NFF, BN,
IEEE, PICMG and VITA are a measure of
the capability of an enclosure to
shielding? Many details are required to
enable you to select the correct
enclosure. You can find more technical
information about electromagnetic
compatibility on page 12.6.
- shock and vibration
- corrosion
- the required loading capacity
- dust or sand
- fire
- extreme temperatures
- low atmospheric pressure
Deciding these considerations
simplifies the choice of the best
product for your needs. You can
find further information in the
appendix on pages 12.3-12.6
withstand specific environmental
conditions. Note however that these
protection classes differ from one
another in important aspects. Further
technical information is available in the
appendix on pages 12.1-12.7 and in our
Standards Summary brochure, which
you can order from our website
www.schroff.biz/catalogues.
04
18002_Hautpkatalog_Schroff_EN_AK03.indd 4
17.10.2012 11:20:24
4. SIZE
Several factors must be considered
when specifying the size of the
enclosure. What materials should it
be built from? Where in the enclosure
will the assemblies be fitted?
Will you be installing devices on a
mounting plate? Will you be fitting
operating elements to a door? Does your
application have specific requirements
for the location of the enclosure?
5. MATERIAL
Select the most suitable material for
your product, taking into consideration
the potential environmental risks and
possible contamination by harmful
substances against which you must
protect the enclosure.
– steel
– stainless steel
– aluminum
– fiberglass
– ABS
– polycarbonate
– polyester
We will then help you select the most
suitable surface finish:
– electroplating
– hot-dip galvanizing
– passivation
– anodization
– paint (various compositions)
Further technical information is
available in the appendix on pages
12.4-12.5 and in our Standards
Summary brochure (pages 26-33),
which you can order from our website
6. THERMAL MANAGEMENT
Faster and more powerful assemblies
produce ever more waste heat.
Effective thermal management is
therefore important to ensure optimum
efficiency and service life for the
electronic components. While in most
cases the central task is to monitor and
dissipate the heat generated, there are
also circumstances in which heating is
necessary. Some basic questions for
determining the appropriate cooling
method for your application include:
Which enclosure surfaces allow heat
transfer?
How much heat is generated by each
installed component?
What temperature conditions must be
observed?
Will your application be used in a
closed room or out of doors?
Will the cooling device be fitted on the
top, the side or within the enclosure?
With the help of your Schroff contact,
select the most suitable cooling
solution from our wide product range
in section 4. You will also find more
solutions on the Pentair McLean
website www.mcleancoolingtech.com
or in the McLean catalog, in the
"McLean V-Series" and "McLean
Thermoelectric Coolers" brochures
and in the main Pentair Hoffman
catalog, which you can order from
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 5
05
17.10.2012 11:20:40
ServicePLUS
configuration
Simple. Fast. To the ideal product.
We help you to build your ideal product out of off-the-shelf components quickly, competently and simply with interactive
online configurators, our telephone configuration hotline and Power Search, which lets you select standard components fast
www.schroff.co.uk/configuration
assembly
Built by professionals. Double the benefit.
For turnkey products, ServicePLUS assembly lets you keep your attention on your core activity without interruption, while we
carry out the complete assembly of all your system components, competently and on time; competently and on time
www.schroff.co.uk/assembly
modification
Minor modifications. Large impact.
Quality also means 100% accuracy of fit. We therefore also modify off-the-shelf products to your individual needs, for
example, drilled holes, cut-outs, printing and special colors.
www.schroff.co.uk/modification
solution
Simple. Fast. From one source.
If it is not possible to use off-the-shelf products, we will create a special custom solution - from development and design
through to complete, integrated, functioning systems or even highly specific new developments.
www.schroff.co.uk/solution
express
When fast has to be even faster.
In many projects speed is of the essence, and flexibility a decisive criterion. With us you can select your delivery time from a
range of express options.
support
Support. Solution. Availability.
ServicePLUS support is our after-sales service and sets up an ongoing relationship with you. We offer a modular range of
support options that can be tailored to your specific service requirements.
www.schroff.co.uk/support
academy
Know. Share. Become a partner.
With ServicePLUS academy we offer you straightforward access to our specialist knowledge. This includes:
• Seminars and training about our products
• Modern knowledge transfer using webcasts, white papers and webinars
• Technical reports, technical details and CAD drawings available by download
www.schroff.co.uk/academy
lifecycle
We stay with you. For the entire life of the product.
With ServicePLUS lifecycle you profit from our flexibly configurable, comprehensive support over the entire life of your
products and complete solutions. Select options from our range to your exact needs and create your individual Lifecycle
package.
www.schroff.co.uk/lifecycle
06
18002_Hautpkatalog_Schroff_EN_AK03.indd 6
17.10.2012 11:20:41
HOW TO CONTACT US
Your local contact
ALL CONTACT DETAILS
FOR YOUR PERSONAL CONTACT
PARTNER ARE HERE:
Online at www.schroff.biz/contact or
in the address list at the end of this
catalog.
YOUR ONLINE CONTACT
WITH SCHROFF
At www.schroff.biz you can reach us
round the clock.
Use the inquiry basket to inquire
online about the articles you require,
simply and without complication, and
receive a quotation within 24 hours.
For customers who prefer quick and
reliable processing when ordering
stock products by authorized and
qualified business partners, our
distribution partners are the first
choice. If you are looking for
professional support for adapting
our products to your individual needs,
contact our value-added resellers.
These can of course also supply
off-the-shelf products. Decide together
with us whether you would like support
either from our direct sales department
or through our business partners in
various countries.
See www.schroff.biz/contact for the
advantages of the different sales and
distribution options.
WE WILL ANSWER YOUR INQUIRY
WITHIN 24 HOURS
Just send us an inquiry or order by
e-mail to schroff.uk@pentair.com or
to your personal contact. You can
naturally also send us a fax.
Main Catalog 2016
18002_Hautpkatalog_Schroff_EN_AK03.indd 7
07
17.10.2012 11:20:42
HOW TO OBTAIN OUR PRODUCTS
ONLINE
You will see our oneClick symbol next
to many products in this catalogue.
By entering the order number at
www.schroff.biz/oneclick you can
quickly and easily obtain further
information about the relevant product.
- detailed product description
- scope of delivery information
- detailed drawings
- technical information
- user manuals
- test reports
- downloadable CAD drawings
- certificates
- test reports
You can also use the free text search
available at www.schroff.biz under
"Search" in the function bar:
5. September 2012 6:12 06
Cabinets – VARISTAR Electronics
Apart from the order number, you can
also enter product names or other
terms.
19'' fixed shelf, 75 kg
Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
Mounting height 1 U, for mounting on four panel/slide mounts
With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
Assembly kit incl. GND/earthing
Catalogue
D
c
RAL 7035
For cabinet Usable
xf
depth
surface w x d
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf PU 1 piece
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
Cable ducting with cable ties, see page 1.25
Other sizes, see ServicePLUS, page 1.49
xf
d
c
Order Information
For further information www.schroff.biz/oneclick
To help you get your bearings quickly
and simply, all the ordering tables in
this catalog are uniformly designed:
- The first section contains the
ordering information for the product.
- The next section, indicated by a
separating line, shows suitable
accessories.
- Order numbers printed in bold are
available for shipping in 2 working
days; order numbers in ordinary type
can be shipped within 10 working
days.
- Further information, if available, on
the product or accessories is shown
at the end of the ordering table.
01004067
oneClick search code = Part no.
ounts
sion
08
18002_Hautpkatalog_Schroff_EN_AK03.indd 8
17.10.2012 11:20:46
Cabinets
Overview............................................. 1.0
Varistar Cabinet platform.................. 1.2
Varistar Electronics........................... 1.10
Varistar EMC...................................... 1.54
Varistar Seismic................................ 1.84
Varistar MIL....................................... 1.120
Varistar Data/network systems........ 1.124
Varistar Containment........................ 1.202
LHX 20/40 Air/water heat exchangers..... 1.224
LHX 3 Air/water heat exchangers........... 1.236
Novastar............................................. 1.240
Eurorack............................................ 1.270
Outdoor ............................................. 1.316
Etsirack.............................................. 1.346
19” lab racks...................................... 1.354
PROLINE............................................ 1.362
1
2
Wall mounted case
Overview............................................. 2.0
Epcase................................................ 2.36
LAN wall-mounted distributors........ 2.46
Cabinet and
wall-mounted
case accessories
Overview............................................. 3.0
Mechanics.......................................... 3.2
Telescopic slides............................... 3.24
Electrical............................................ 3.29
Monitors, keyboards, monitoring...... 3.44
Socket strips...................................... 3.50
Power control socket strips.............. 3.72
Climate control
Overview............................................. 4.0
Cooling concepts/service.................. 4.2
19” fan trays....................................... 4.4
Air filtered fans.................................. 4.20
Accessories........................................ 4.58
Desktop enclosures
Overview............................................. 5.0
RatiopacPRO...................................... 5.6
PropacPRO........................................ 5.44
CompacPRO...................................... 5.76
Comptec............................................. 5.100
Accessories........................................ 5.108
Interscale........................................... 5.200
Minipac ............................................. 5.230
5
Subracks/
19” chassis
Overview............................................. 6.0
EuropacPRO...................................... 6.2
EuropacPRO
for railroad applications.......................6.70
EuropacPRO industrial applications.. 6.86
EuropacPRO Rugged......................... 6.92
MultipacPRO...................................... 6.112
Inpac.................................................. 6.128
6
Front panels,
Plug-in-units,
Frame type plug-in-units
Overview............................................. 7.0
Front panels....................................... 7.2
Plug-in units...................................... 7.16
Frame type plug-in units................... 7.64
PCB accessories................................ 7.102
Systems
Overview............................................. 8.0
AdvancedTCA..................................... 8.2
AdvancedMC carriers........................ 8.26
MicroTCA............................................ 8.36
AdvancedMC modules....................... 8.56
CompactPCI, Serial, PlusIO, PSB..... 8.68
VME, VME64x, VXS, VPX..................... 8.88
Accessories........................................ 8.106
8
Power supply systems
Overview............................................. 9.0
19” AC/DC switched-mode PSUs..... 9.2
19” AC/DC linear regulators............. 9.12
19” AC/DC convertors....................... 9.15
19” accessories................................. 9.18
PSUs for MicroTCA............................ 9.20
PSUs for VMEbus.............................. 9.22
PSUs for CompactPCI, VME64x.......... 9.24
9
Backplanes
Overview........................................... 10.0
CompactPCI, Serial, PlusIO............ 10.4
PXI.................................................... 10.11
VXS................................................... 10.14
VME64x, VMEbus............................. 10.15
Power............................................... 10.18
Universal.......................................... 10.19
Test adaptors................................... 10.20
10
Connectors,
Front panel component
systems
Overview........................................... 11.0
Connectors...................................... 11.2
Front panel component system...... 11.12
11
Appendix
Standards abbreviations................. 12.0
Notes on ordering............................ 12.10
Order number index........................ 12.11
Product index................................... 12.62
12
3
4
7
Main Catalogue
Cabinets – Overview
Content
Cabinets . . . . . . 1
VARISTAR
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
쮿 Cabinet platform for many
application areas like electronics,
datacom and networking
technologies
– 19" or metric versions
– EMC shielded
– Earthquake-proof
– Variable cooling concepts
– Air-conditioned cabinets
– Extensive range of innovative cable
routing accessories
쮿 Welded steel frame for static
load-carrying capacity of up to
1200 kg
쮿 Type of protection IP 20 or IP 55
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
NOVASTAR
쮿 19" electronics cabinet for applications
in the measurement and control, audio
and video industries
쮿 Attractive design with visible profile
frame, inset cladding parts and full
glass doors
쮿 Cabinet height from 6 U to 47 U
쮿 Cabinet width only 553 mm
쮿 Screw fixed aluminium rack for static
load-carrying capacity of up to 400 kg
쮿 Type of protection up to IP 40
NEW
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
P
쮿 19" cabinet for electronics applications
쮿 Screw fixed aluminium frame for static
쮿 Type of protection IP 40
Appendix . . . . . 12
36109003 (01006007 01005001 07011036 00105003 )
1.2
SCHROFF Further information: www.varistar.de E 05/2016
ELECTRONICS PROTECTION
Cabinets – Overview
Overview . . . . . . 1.2
Outdoor
VARISTAR . . . . . . 1.2
쮿 Aluminium cabinet for outdoor use
and to accommodate 19", metric or
non-standardized components
쮿 Type of protection IP 55
쮿 Single-wall or double-wall versions
쮿 Static load-carrying capacity up to 400 kg
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
MIL . . . . . . . . . . . . . 1.120
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR
Aisle
Containments . . . . 1.202
VARISTAR
Air/water heat
exchanger . . . . . . . 1.224
Z
쮿 Designed for telecommunications
applications in accordance with
the ETS standard
쮿 Steel construction, 300 mm deep
200 kg
NOVASTAR . . . . . 1.240
eurorack . . . . . . . 1.270
Outdoor . . . . . . . . . 1.316
etsirack . . . . . . . . 1.346
Lab racks . . . . . . . 1.354
Lab Racks
PROLINE . . . . . . . 1.362
쮿 Open 19" frame for lab applications,
stationary or mobile
쮿 Static load-carrying capacity 200 kg
Cabinet
Accessories . . . . 3.0
36109004 (41602001 40012001 05601002 01305003)
SCHROFF.PENTAIR.CO.UK
1.3
VARISTA RMain Catalogue
Cabinets – VARISTAR
Content
Wall mounted
쮿 Open cabinets with decorative
frame
쮿 19" cabinets with IP 20 or IP 55
protection class
Accessories for
cabinets and wall
mounted cases . 3
쮿 Extensive range of innovative
accessories for
electronics cabinets
Climate control . 4
Electronics
VARISTAR EMC
쮿 Shielding up to 60 dB at 1 GHz and 40 dB at 3 GHz
Subracks/
쮿 High shielding also when combined with perforated
doors or fan top covers
쮿 Individual configuration options with ServicePLUS
configuration
Front panels,
VARISTAR Seismic
쮿 Earthquake-resistant cabinets
tested to Bellcore Zone 4
ServicePLUS configuration
Power supply
Backplanes . . . 10
Connectors, front
panel component
VARISTAR MIL
NEW
쮿 Tested and certified to MIL 901D
쮿 With shock absorbers
쮿 Shielded against high-frequency
interference
쮿 IP 55
36108003 (01006007, 01004031, 01007002, 01005018, 01012004)
1.2
SCHROFF Main catalogue
www.schroff.biz E 05/2016
Cabinets – VARISTAR
VARISTAR Data and networking
technology
VARISTAR
Platform . . . . . . . 1.4
쮿 Wide range of network and server cabinet
versions
쮿 Server cabinets with depths up to 1200 mm
쮿 Two standard colors:
light grey (RAL 7035) or
black grey (RAL 7021)
쮿 Extensive, innovative range of cable routing
accessories
VARISTAR
Electronics . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . 1.84
VARISTAR
Aisle containments
NEW
VARISTAR
MIL . . . . . . . . . . . . 1.120
쮿 Cold aisle containments
쮿 Modular standard components
쮿 Extensive range of swing and sliding doors
VARISTAR
Datacom and
Networking
Technology . . . . 1.124
VARISTAR with air/water heat exchangers
VARISTAR Aisle
containment . . . . 1.202
LHX 20/40
VARISTAR
Air/water heat
exchangers . . . . . 1.224
쮿 Versions with single or double
doors and with automatic
door opening
Cabinet
LHX 3
쮿 Electronics cabinets with
LHX 3 air/water heat exchanger
36108004 (01006006, 01006015, 01012006, 01007015, 01006040)
1.3
Cabinets – VARISTAR platform
Two load-carrying classes, one accessory range: The VARISTAR frames
VARISTA R platformMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
VARISTAR is the only cabinet platform that allows identical
accessories to be combined with two basic frames.
The cabinet is available in Slim-Line (narrow) or Heavy-Duty
(robust) profiles.
Slim-Line profile
The Slim-Line version is based on very thin steel profiles in order
to obtain the greatest opening width between the uprights. This
frame can accommodate either 19" equipment or metric
components to ETS 3000-119-3. With a maximum load of 400 kg*
on the 19" plane the frame is still highly robust and suitable for
demanding applications in electronics or data and network
technology.
Heavy-Duty profile
01004035
The Heavy-Duty frame, on the other hand, is designed for use with
heavy loads or in regions susceptible to earthquakes. It offers on
the one hand maximum stability for a load of up to 800 kg* on the
19" plane and, thanks to its high bending stiffness, can meet the
shock and vibration requirements such as occur in railway and
traffic signal installations, in the control of rotating machines, on
commercial ships or in low-level military installations.
In the IEC 61587-2 earthquake test the Heavy-Duty frame qualified
for use in Bellcore Zone 3. Equipped with very simple, low-cost
strengthening brackets, the VARISTAR Seismic version meets the
demands of Bellcore Zone 4.
01006035
Slim-Line profile
capacity
Type of protection
Shock test
01006034
Heavy-Duty profile
01008062
Heavy-duty profile with strengthening bracket
Standard
IEC 61587-1
Slim-Line
400 kg *
Heavy-Duty
800 kg *
IEC 60529
IEC 61587-1
IP 20, IP 55
Maximum acceleration: 5 g
Duration: 11 ms
Frequency: 5 Hz -100 Hz
Acceleration: 1 g
IP 20, IP 55
Duration: 11 ms
Acceleration: 1 g
Standard: up to Bellcore
With strengthening: up to Bellcore
Zone 3, acceleration: 3 g,
Zone 4, acceleration: 5 g,
Frequency: 1 Hz ... 5 Hz
Frequency: 2 Hz ... 5 Hz
60 dB at 1 GHz, 40 dB at 3 GHz
19"
Vibration test
IEC 61587-1
Earthquake test
IEC 61587-2
EMC shielding
Installing options
IEC 61587-3
19" or ETS
* Figures for static load-carrying capacity are based on the IEC 61587-1 test procedure. In this procedure the cabinet is standing on the floor under its equipment load and
lifted up by its lifting eyes; no significant deformations may occur on the frame or at the 19" panel/slide mounts under maximum carrying capacity. The potential load for the
VARISTAR frame is therefore, under normal operating conditions, considerably higher than the test value given under IEC 61587-1.
1.4
SCHROFF PRODUCT CATALOG D 05/2016
Decidedly different: The VARISTAR sealing and shielding concept
VARISTAR platform
Item
1
2
3
4
5
Description
Frame
Conductive EMC
textile gasket with
CuNi coating
Contact/shielding
Rear panel
Side panel
2
3
In most shielding designs currently available, conductive seals or
springs connect the cover parts to the cabinet frame. The points of
contact have thus to be kept conductive and corrosion-free.
With VARISTAR, however, the conductive textile gaskets link the
cover parts with one another directly, which results in two
advantages:
A considerably better shielding performance of 60 dB at 1 GHz
(and 40 dB at 3 GHz) is obtained than with conventional designs.
There is no longer any need for expensive treatment of the frame
surface. The textile EMC gasket is also a protection against dust
and water to IP 55. If no shielding is required, a rubber gasket is
used offering the same protection to IP 55. Both gaskets are fitted
to the 45°-angled surface of the exterior of the frame.
4
5
1
Shielding up to 3 GHz
[dBµV]
100
90
80
70
60
50
40
1
30
2
1000
1500
2000
2500
3000
[Mhz]
1: Cabinet with solid door
01004141 01008061 01008005
2: Cabinet with perforated door
Smooth-running and absolutely tight: The VARISTAR locking system
The latching system also contributes to protection class and
shielding.
The innovative locking bar accepts a variable number of deadbolts,
depending on the cabinet height, to ensure the most even
compression of the gaskets.
And best of all: Activating the locking bar causes the latches to
move in the opposite direction. Thus the frictional forces of the
bolts are balanced out and a resulting lopsided vertical force on
the door is avoided. The doors close easily and with an absolute
seal.
EMC doors are fitted with 4-point locking, IP and server doors with
3-point locking.
01005080
Part number in bold face type: ready for despatch within 2 working days
Part number in normal type: ready for despatch within 10 working days
1.5
Peerless and efficient: The VARISTAR profile (Slim-Line and Heavy-Duty)
VARISTA R platform
Mounting of the 19" bracket
without depth members
The VARISTAR profile has fixing holes in all three axes (height,
width, depth), following a 25 mm grid. This allows for the greatest
variability in the fitting of components and accessories. Thus for
example 19" panel/slide mounts may be installed in a 600 mm
wide cabinet without additional depth members. This saves costs
and provides stability on the 19" plane.
The intricately shaped form of the profile offers further new
assembly possibilities. Cable eyes, for instance, can be plugged
directly into the frame whilst fixing themselves.
01004034 01006105
Self-fixing cable eyes
dummy
New and well thought out: VARISTAR cable management
Schroff has divided the available space in the VARISTAR into zones
and given a simple description of the position and use of these
zones. The coloured arrows show the direction of the cable
ducting.
Zone 1
Zone 2
01006087
쮿 In front of the 19" plane
쮿 In this zone the patch cables are
ducted horizontally between the
distribution fields
1.6
Zone 3
01006088
쮿 On the right and left hand side, next to
the 19" plane
쮿 In this zone patch cables are ducted
vertically in a kind of channel to the
individual components
For each zone a range of accessories has been developed to suit
the conditions in the cabinet, which simplifies cabling and thus
helps to include as many connections as possible in a
distribution cabinet. The VARISTAR profile with its many fixing
options has thus proved a real boon.
Zone 4
01006085
01006086
쮿 Zone 3 is located laterally behind the 쮿 Zone 4 is located in the rear across
the cabinet width
19" plane across the cabinet depth;
mainly for 800 mm wide cabinets
쮿 Alternative to zone 3 for only
600 mm wide cabinets or when cable
쮿 In this zone entering cable bundles
entry is at the rear of the
are fixed in the cabinet, parted and
cabinet
ducted to the rear of the distribution
fields
Heat dissipation to exact requirements: cooling concepts for VARISTAR
Depending on installed heat dissipation and
the surroundings, VARISTAR offers various
cooling options and also good conditions for
problem-free operation of the installed
equipment.
Either top cover fans are used to assist the
heat dissipation or perforated doors with
78 % air throughput are fitted.
Additionally, VARISTAR LHX 20/40 with
assembled air/water heat exchanger
allows to cool especially strained
appliances with water. And that for up to 40
kW per cabinet.
01105057
up to 2 kW
01105056
up to 6 kW
01106027
Fan unit, positioned inside
0100581
up to 40 kW
41003017
78 % air throughput
01005020
Classic and consistent: VARISTAR colour and design
As well as its functional aspects, in the development of VARISTAR
the design of the individual components and their combined effect
on the appearance of the cabinet was always a priority. The cabinet
gains its characteristic, unmistakable look from the high narrow
door with the memorable hinges and the very thin, almost
inconspicuous top cover edge.
While rack, base and cover are offered in black grey (RAL 7021) for
all standard cabinets, a choice of two colour options are available
- even in our standard programme - for side panels, doors and
rear panels:
Either entirely black grey (RAL 7021), as is the contemporary
look in data centres and recording studios. Or in light grey
(RAL 7035), whereby an attractive combination of mainly light
surfaces with a few dark accents is obtained.
Alternatively, VARISTAR can be supplied in many RAL colours
within 15 working days, or even as a combination of two special
colours. The current range of colours can be seen online
at www.schroff.co.uk/modification.
01006037
Colour RAL 7021 (black grey)
01006036
Colour combination RAL 7035/RAL 7021 (light grey/black grey)
1.7
Frame dimensions
Height
Cabinet height
mm
1200
1400
1600
1800
2000
2200
Frame
H
mm
1192
1392
1592
1792
1992
2192
U
24
29
33
38
42
47
h
mm
1102
1302
1502
1702
1902
2102
Width
Cabinet width
mm
600
800
Frame
W
mm
592
792
Slim-Line
w
mm
535
735
Heavy-Duty
w
mm
502
702
Depth
01005087
Adjustable feet
Cabinet depth
mm
300
600
800
900
1000
1100
1200
D
mm
292
592
792
892
992
1092
1192
Frame
d
mm
128.8
428.8
628.8
728.8
828.8
928.8
1028.8
d1
mm
150
450
650
750
850
950
1050
d2
mm
175
475
675
775
875
975
1075
01004081
Castors with adjustable feet
Locking castors
Height of adjustable feet, castors, base/plinth
Adjustable feet
Locking castors
Base/plinth (feet)
Base/plinth, mobile
20 ... 40 mm
85 mm
85 ... 95 mm
112 ... 132 mm
126.5 ... 134.5 mm
01004082 01004156
Base/plinth
Mobile base/plinth
0100411001004111
1.8
Top cover with cut-out zones
D
600
800
900
1000
1100
1200
a
b
W = 600 mm
c
d
e
a
b
W = 800 mm
c
d
e
01006097
Base plate, multi-piece
b
w
a
W
c
200
50
D
600
800
900
1000
1100
1200
Cabinet width
W
mm
600
800
D
50
Depth in mm
a
300
300
300
300
300
300
b
200
300
200
300
300
c
200
200
300
Opening width
w
mm
426
626
01006096
1.9
Varistar ElectronicsMain C atalogue
Cabinets – Varistar Electronics
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01008004
Subracks/
Front panels,
01009002
19" panel mounts integrated in decorative frame
01005014
All-round gasketing to IP 55
Power supply
Backplanes . . . 10
Connectors, front
panel component
01009002
Side panels with quick-release fastener, optionally
lockable
01005014
3-point locking with contradirectional bolts
1.10
SCHROFF E 08/2017
Overview . . . . 1.10
Varistar ElectronicsMain Catalogue
The universal cabinet for electronics
쮿 Selectable stability, static load-carrying capacity up to 800 kg
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
쮿 Professional solutions for cable ducting
쮿 Variable ventilation concepts, active and passive
쮿 Various versions in ServicePLUS configuration
VARISTAR Deco
VARISTAR IP 20
VARISTAR IP 55
VARISTAR Deco . . 1.12
VARISTAR IP 20 . . 1.13
VARISTAR IP 55 . . 1.14
Accessories
Lever handle . . . . . 1.15
Base plate . . . . . . . 1.15
Base/plinth . . . . . . 1.16
Mounting plate . . . 1.17
19" swing
frame . . . . . . . . . . . . 1.18
19 panel/slide
mount . . . . . . . . . . . 1.19
19" fixing
materials kit,
M6 . . . . . . . . . . . . . . 1.19
Slide rails . . . . . . . . 1.20
19" shelves . . . . . . 1.21
Depth members . . 1.24
C horizontal rail . . 1.24
Cable tie,
Velcro . . . . . . . . . . . 1.25
01004001
쮿 Open at front, with deco frame and
integrated 19" panel mounts
01004002
쮿 With glass door and
single point locking
01004003
쮿 With glass or steel door and
3-point locking
ServicePLUS from page 1.26
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
e.g. custom solutions (special sizes)
ServicePLUS . . . 1.26
ServicePLUS
IP 20 . . . . . . . . . . . . 1.27
ServicePLUS
IP 55 . . . . . . . . . . . . 1.39
ServicePLUS
Interior
configuration . . . . . 1.44
VARISTAR EMC . . .1.54
VARISTAR
VARISTAR
Datacom and
Networking
Technology . . . . . .1.124
VARISTAR air/
water heat
www.schroff.biz/ServicePLUS
30407004
1.11
Varistar Deco
Varistar Electronics Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 Open at front (no door)
쮿 19" panel mounts integrated into decoration frame
쮿 Rear door with single point locking, side panels with quick
release fastener
쮿 Static load-carrying capacity 400 kg (Slim-Line)
Delivery comprises (assembled)
Item
1
Qty
1
2
3
4
1
4
1
5
2
6
1
7
8
2
1
Description
Welded basic frame, Slim-Line, St profile,
zinc-plated, powder-coated, RAL 7021
Adjustable foot, assembled
Raised top cover, St, RAL 7021,
with 10 mm air gap all around
Decorative frame, Al, integrated 19" panel mounts at the
front, RAL 7035
Adapter bracket, St, 2 mm, RAL 7035, front,
for assembling shelves and slide rails
Rear door, St, 180° hinge, single point locking and
key with safety lock, RAL 7035
Side panel, St, with quick-release fastener, RAL 7035
GND/earthing kit, supplied loose
Order Information
10
01004001
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1800
600
600
38
1800
600
800
42
2000
600
600
42
2000
600
800
Castors load-carrying capacity 400 kg, PS/St, PU 4
pieces, 2 locking, 2 non locking
Castors with integrated adjustable feet load-carrying
capacity 400 kg, PU 4 pieces
Lever handle for single point locking with push button, 1
piece
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Lifting eye for raised top cover PU 4 pieces
Part no.
10130-001
10130-002
10130-003
10130-004
23130-077
23130-078
23130-067
25127-995
23130-085
Note
W
D
20 - 45
H
쮿 Lever handle can be added to rear door
쮿 For more dimensions and versions see ServicePLUS IP 20,
starting on page 1.27
쮿 Please order base plate separately, see page 1.15
쮿 Please order base/plinth separately, see page 1.16
쮿 For assembly of shelves and slide rails another pair of panel/
slide mounts is necessary, see page 1.19
01004151
ServicePLUS see page 1.26
1.12
SCHROFF PRODUCT CATALOG E 08/2017
Varistar IP 20
Varistar Electronic s
쮿 With glazed front door
쮿 Doors with single point locking, side panels with quick release
fastener
Item
1
Qty
1
2
3
4
1
4
1
5
1
6
2
7
2
8
1
Description
Raised top cover, St, RAL 7021, with 10 mm air gap all
around
Front door, glazed, safety glass, 6 mm, 180° hinge, RAL
7035, single point locking, key lock cover
Rear door, St, 180° hinge, RAL 7035, single point locking,
Side panel, St, quick-release fastener with safety lock,
RAL 7035
19" panel/slide mount with EIA cut-outs, St, RAL 7035,
assembled at front, depth-adjustable in 25 mm
increments
GND/earthing kit, enclosed loose
Order Information
10
01004002
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1800
600
600
38
1800
600
800
42
2000
600
600
42
2000
600
800
piece
Part no.
10130-005
10130-006
10130-007
10130-008
23130-077
23130-078
23130-067
25127-995
23130-085
Note
W
D
20 - 45
H
쮿 Lever handle can be added to the doors
쮿 For other dimensions and versions see ServicePLUS
configuration IP 20, from page 1.27
01004152
1.13
VARISTAR IP 55
쮿 With glazed or steel front door
쮿 Doors with 3-point locking and screw-fixed side panels
Item
1
Qty
1
2
3
4
4
1
1
5
6
7
1
2
1
8
2
9
1
Description
Welded basic frame, Slim-Line, St profile, zinc-plated,
powder-coated, RAL 7021, with all around rubber seals
Flat top cover, St, RAL 7021
Front door, St or glazed, RAL 7035, 180° hinge,
3-point locking, lever handle
Rear panel, screw fixed, St, RAL 7035
Side panel, screw fixed, St, RAL 7035
Base plate, multi-piece, with cover plate, St, RAL 7021,
with gasket
19" panel/slide mount with EIA cut-outs, AlZn,
assembled at front,
depth-adjustable in 25 mm increments
Order Information
01005006
Height Height H Width W
Depth D Description
U
mm
mm
mm
42
2000
600
600
With glazed door
42
2000
600
600
With steel door
Lifting eye for top cover PU 4 pieces
Part no.
10130-021
10130-022
23130-077
23130-078
25127-995
23130-072
Note
configuration IP 55, from page 1.39
01005014
1.14
Lever handle for
쮿 For installation instead of key lock insert
쮿 To open press push-button
쮿 DIN profile half cylinder retrofittable
Delivery comprises
Item
1
2
Qty
1
1
Description
Assembly kit
Order Information
Description
01005016
Part no.
23130-067
25127-995
Note
쮿 Other locks such as ASSA, KABA or RONIS available on request
쮿 The multi-piece base plate is open at the rear
쮿 The opening may be completed
– with a filter mat
– with a brush strip for the cable entry
– with a cover plate
Delivery comprises (kit)
Item
1
5
Qty
1
1
Description
Multi-piece base plate, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01004050
1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter
kit
Width
Depth
mm
mm
600
600
600
800
Item 2 Cover plate for base plate, multi-piece for 600 mm
wide base plate, 200 mm deep, incl. assembly kit, 1 piece
Item 3 Brush strip for base plate for 600 mm width base
Item 4 Filter mat white, class M1 in accordance with
EN 799-G3, for 600 mm wide base plate, 200 mm deep,
Part no.
23130-001
23130-002
23130-076
23130-074
23130-075
Note
쮿 Is assembled from inside
쮿 Please order cover plate, brush strip or filter mat separately
1.15
Stationary base
쮿 Static load-carrying capacity 1000 kg
쮿 Removable covers allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
2a
H
2b
1
2b
2a
W
D = cabinet depth
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
D
4
01004110
01004053
For cabinet width W
Front/rear trim
mm
600
perforated
600
plain
Item 4 Side trim height 100 mm, depth 600 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-169
23130-170
Note
쮿 Please order side trims (item 4) separately
Base/plinth, mobile
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
For cabinet width
mm
600
600
For cabinet depth
mm
600
800
Part no.
23130-208
23130-209
010041110 1006095
1.16
Mounting plate
쮿 For mounting electrical components and sub-assemblies incl.
cabling
쮿 Mounting pitch 25 mm in depth and 50 mm in height for
partial-height mounting
쮿 Depth members are required for partial-height mounting
쮿 Static load
– 450 kg at full height, mounted to rear
– 600 kg at full height, mounted to rear, with additional
Delivery comprises
Item
1
2
Qty
1
1
Description
Mounting plate, St, 3 mm, zinc-plated
Assembly kit
Order Information
Full height
010080520 1008053
For partial-height mounting
For cabinet height
Width
mm
mm
1200 for partial-height mounting 600
1800
600
2000
600
Strengthening bracket for mounting plate PU 2 pieces
Depth member St, 2 mm, for cabinet depth 600 mm,
2 pieces
Depth member St, 2 mm, for cabinet depth 800 mm,
2 pieces
Part no.
23130-413
23130-405
23130-407
23130-418
23130-081
23130-082
1.17
19" swing frame
쮿 Can accommodate 19" chassis and 19" subracks
2
쮿 For full height or partial-height mounting
쮿 Pivot point can be selected right or left
쮿 Load-carrying capacity 150 kg
h2
h1
Delivery includes (kit)
1
ax.
Tm
Qty
1
2
2
2
1
Description
Swing frame, St, 2 mm, RAL 7021
Support bar, St, 3 mm, RAL 7021
Square lock, 8 mm, incl. 2 keys
120° hinge
Assembly kit
Order Information
4
3
01005055
Item
1
2
3
4
5
01005059
Swing frame stop
For cabinet height
Height h1
mm
U
900 for partial-height mounting
16
24
1400 for partial-height mounting
29
1600 for partial-height mounting
33
1800
38
2000
42
2200
47
Accessories
Swing frame stop max. swing angle 120°, St,
zinc-plated, 1 piece
Security lock to replace the square lock,
PU 1 lock incl. 2 keys
Spare key for security lock, 1 piece
Height h2
U
12
21
25
30
34
39
43
Part no.
21130-740
21130-741
21130-742
21130-743
21130-744
21130-745
21130-746
23130-158
60113-267
60220-003
Note
쮿 19" swing frames can be assembled:
– Directly on the cabinet frame
– In 50 mm increments by aid of depth members (depthadjustable)
쮿 For partial-height mounting, depth members are necessary,
see page 1.24
01005061
Security lock
41001517
1.18
19" panel/slide mount with universal pitch (EIA)
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
010041120 1004131
Standard assembly dimension xr = xf = 50 mm
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
RAL 7035 or RAL 7021
Assembly kit, incl. GND/earthing
Order Information
9,6
42,5
Item
1
01005088
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
Partialheight
29
1295
23130-032 23130-022
mounting
Partialheight
33
1495
23130-033 23130-023
mounting
1800
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
쮿 For 19" partial-height mounting depth members are necessary
쮿 Metric panel/slide mounts available on request
19" assembly kit, M6
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.19
Slide rails
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 Wide support surface (48 mm)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Order Information
Static load carrying capacity 25 kg
For cabinet depth
D
mm
600
600
800
800
xf
c
Length L Qty/PU
mm
50
50
50
50
mm
500
500
700
700
mm
456
456
656
656
2
10
2
10
Part no.
23130-096
23130-101
23130-097
23130-102
01005086
Order Information
Static load carrying capacity 100 kg
For cabinet depth
D
mm
600
600
800
800
c
Length L Qty/PU
mm
50
50
50
50
mm
500
500
700
700
mm
458
458
658
658
2
10
2
10
Part no.
23130-118
23130-123
23130-119
23130-124
01004058
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
D
c
xf
c - 130
1.20
xf
01004130
쮿 Static load-carrying capacity 75 kg
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
Item
1
Qty
1
2
1
xr
01004066
Description
c
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
D
d
Order Information
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
xf
w
쮿 Cable ducting with cable ties, see page 1.25
쮿 Other sizes, see ServicePLUS, page 1.49
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
1.21
19'' telescopic shelf, 30 kg
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50 500 22130-343
800
417 x 682
50 700 22130-345
GND/earthing for telescopic 19" shelf PU 1 kit,
for VARISTAR
xf
d
Full depth
RAL 7021
Part no.
21130-343
21130-345
23130-140
Note
01004069
Order Information
Shortened depth
Shortened by 100 mm
w
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50 500 22130-342
800
417 x 582
50 700 22130-344
for VARISTAR
RAL 7021
Part no.
21130-342
21130-344
23130-140
Note
D
c
xr
W
xf
d
c = max. pitch of the 19" panel/slide mounts
1.22
01004070
19'' telescopic shelf, 70 kg
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
Full depth
W
쮿 2 versions
– Full depth
Delivery comprises
xr
w
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 682
50 700 22130-355
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
for VARISTAR
xf
d
Order Information
01004069
c = max. pitch for 19" panel/slidemounts
쮿 Please order T-bar lock (item 4) separately
w
Order Information
21130-355
23130-092
23130-140
Shortened by 100 mm
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 582
50 700 22130-354
for VARISTAR
d
c
Part no.
21130-353
Note
W
xr
Shortened depth
RAL 7021
RAL 7021
Part no.
21130-352
21130-354
23130-092
23130-140
Note
xf
01004070
1.23
Depth member
쮿 For fitting shortened 19" panel/slide mounts and mounting
plates
쮿 Cable ducting by means of cable ties and cable eye
50
Delivery comprises
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
Item
1
2
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
L
Description
010041260 1004079
For cabinet depth
mm
Depth member
600
Depth member
800
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-081
23130-082
21101-151
21101-150
coa43697
Cable eye
C-profile for the cabinet depth
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
,5 x
Ø6
15
- 11
L
50
Part no.
23130-086
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
29,5
L
50
31,5
For cabinet depth
Length L
mm
mm
600
460
800
660
Accessories
Cable retention rail for C-rail Width 75 mm, length 39.5
mm, PU 5 piece
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Slide nut for C-profile, PU 10 piece
쮿 Cable ties and Velcro for cable retention rail see page 1.25
75
01504054
1.24
C-profile
01004132
01006071
C-profile for cabinet width
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
600
550
800
750
Accessories
length 39.5 mm, PU 5 pieces
Slide nut for C-profile, PU 10 pieces
Part no.
23130-333
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable ties, Velcro
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
1.25
Cabinets – Varistar Elektronics ServicePLUS
configuration
Components can be varied and combined
freely
쮿 Configuration tables from page 1.27
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drilling, cut-outs and special colours for
쮿 Download CAD data and send back with modifications
solution
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power supply),
function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
쮿 Further information: www.varistar.co.uk
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
1.26
VARISTAR IP 20 ServicePLUS: configuration and assembly
쮿 Dimensions:
– Height: 29 ... 47 U (1400 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 300, 600 and 800 mm
Page
쮿 2 colour combinations:
– Frame and covers in black grey (RAL 7021)
– Frame, top cover and base in black grey (RAL 7021);
Side panel, door and rear panel in light grey (RAL 7035)
Frames, side-by-side
mounting kits, adjustable
feet, castors
1.28
Side panels, rear panels
1.29
Decorative frames, glazed
1.30
doors
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all
subsequent configuration pages that apply to these dimensions
(see example below)
쮿 The cabinet is assembled by us and
Steel doors
1.31
Double doors
1.32
Flat top covers, lifting
eyes
1.33
Flat top cover assemblies
1.34
with cut-out zones
Fan top covers
1.35
Bases/plinths
1.36
Connecting plates for
short doors/rear panels
1.37
Interior configuration for IP 20 and
IP 55
1.44
ETSI panel/slide mounts
1.45
Swing frames
1.46
Mounting plate, stationary
1.47
shelves, 75 kg
01004077
Example configuration (here: row 10)
Qty
1
1
2
1
1
1
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
Side panel with quick-release fastener, RAL 7021, PU 2 pieces
Safety lock for side panel, PU 4 pieces
Rear panel, screw-fixed, RAL 7021, 1 piece
Glazed door with single point locking, RAL 7021, IP 20, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
21130-051/05
23130-132/05
21130-069/05
21130-129/05
23130-079/05
Telescopic shelves, 70 kg
1.48
19" shelves 1 U, fixed
75 kg, telescopic 30 kg
1.49
19" telescopic shelf, 2 U,
70 kg
1.50
Slide rails, depth
members
1.51
Cable ductings
1.52
Cable ties, Velcro
1.53
1.27
VARISTAR IP 20
Frames, side-by-side mounting kits, adjustable feet, castors
Order Information
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
Side-by-side
mounting kit
IP 20
Side-by-side
mounting kit
IP 55
(with gasketing)
Adjustable feet
Castors
With 2 jacking
feet
With adjustable
feet
Completely in RAL 7021
(black grey)
01004078
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004117
01004081
01004082
01004156
for the frame,
for the frame,
for the frame,
side-by-side
side-by-side
static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: mounting bracket mounting bracket
carrying capacity: carrying capacity: carrying capacity:
(4 pieces), St,
(4 pieces), St;
800 kg,
400 kg,
400 kg,
400 kg,
1000 kg,
RAL 7021, incl.
St, 1.5 mm, zinc- St, 1.5 mm, zinc- RAL 7021, not in
cannot be used
cannot be used
cannot be used
gasketing to
combination with
plated, with
plated, with
with base/plinth with base/plinth with base/plinth
cover the gap
decorative frame
central GND/
central GND/
between two
earthing point;
earthing point;
racks; not in
please order
please order
combination with
adjustable feet or adjustable feet or
decorative frame
castors
castors
separately
separately
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
supplied loose
RAL 7021
RAL 7021
RAL 7021
20130-005
20130-055
20130-006
20130-056
20130-009
20130-059
20130-010
20130-013
20130-060
20130-063
20130-014
20130-064
20130-015
20130-017
20130-065
20130-018
20130-068
20130-019
20130-022
20130-069
20130-072
20130-023
20130-073
20130-026
20130-027
20130-077
20130-028
20130-078
20130-032
20130-082
supplied loose
assembled
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-061
23130-062
23130-062
23130-079
23130-079
23130-077
23130-077
23130-078
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-061
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.28
RAL 7021
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-061
23130-062
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-061
23130-062
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-061
23130-062
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-061
23130-062
42 2000 600
300
20130-017
23130-061
23130-062
42 2000 600
600
20130-018
20130-068
23130-061
23130-062
42 2000 600
800
20130-019
20130-069
42 2000 800
600
20130-022
20130-072
23130-061
23130-062
42 2000 800
800
20130-023
20130-073
47 2200 600
300
20130-026
23130-061
23130-062
47 2200 600
600
20130-027
20130-077
23130-061
23130-062
47 2200 600
800
20130-028
20130-078
47 2200 800
800
20130-032
20130-082
23130-061
23130-062
Other dimensions and configurations online (with basket) at www.schroff.biz/conf
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
VARISTAR IP 20
Order Information
Side panel
With quick
release fastener
Screw-fixed side
panel
Lock
Rear panel
With quick
release fastener
Screw-fixed rear
panel
Lock
(black grey)
01004084
7035 (light grey)/
01004072
for quick-release
St, 1 mm, incl.
fasteners of one
GND/earthing,
side panel;
please order lock
4 locks sufficient
separately
for 2 side panels
01004083
St, 1 mm, incl.
GND/earthing
01004087
01004072
for quick-release
St, 1 mm, incl.
fasteners of rear
GND/earthing,
panel
please order lock
separately
01004085
St, 1 mm, incl.
GND/earthing
Cabinet dimensions
Height
No. U
mm
Width
Depth
PU 2 pieces
PU 4 pieces
PU 2 pieces
1 piece
PU 2 pieces
1 piece
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-043
21130-003
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
21130-044
21130-045
21130-046
21130-047
21130-048
21130-047
23130-132
23130-132
23130-132
21130-004
21130-005
21130-006
21130-007
RAL 7021
21130-093
23130-133
21130-063
21130-095
23130-133
21130-065
21130-097
23130-133
21130-067
23130-132
21130-008
21130-007
21130-098
23130-133
21130-068
21130-049
23130-132
21130-009
21130-099
23130-133
21130-069
21130-050
21130-051
23130-132
21130-010
21130-011
21130-099
23130-133
21130-069
21130-100
23130-133
21130-070
21130-101
23130-133
21130-071
21130-101
23130-133
21130-071
21130-102
23130-133
21130-072
21130-050
21130-051
21130-054
21130-055
21130-056
21130-056
23130-132
23130-132
23130-132
23130-132
21130-010
21130-011
21130-014
21130-015
21130-016
21130-016
RAL 7035
RAL 7035
22130-043
22130-003
22130-044
22130-045
22130-046
22130-047
22130-048
22130-047
23130-132
23130-132
23130-132
22130-004
22130-005
22130-006
22130-007
RAL 7035
RAL 7035
22130-093
23130-133
22130-063
22130-095
23130-133
22130-065
22130-097
23130-133
22130-067
23130-132
22130-008
22130-007
22130-098
23130-133
22130-068
22130-049
23130-132
22130-009
22130-099
23130-133
22130-069
22130-050
22130-051
23130-132
22130-010
22130-011
22130-099
23130-133
22130-069
22130-100
23130-133
22130-070
22130-101
23130-133
22130-071
22130-101
23130-133
22130-071
22130-102
23130-133
22130-072
22130-050
22130-051
22130-054
22130-055
22130-056
22130-056
23130-132
23130-132
23130-132
23130-132
22130-010
22130-011
22130-014
22130-015
22130-016
22130-016
1.29
VARISTAR IP 20
Decorative frames, glazed doors
Order Information
Deco frame
Deco frame
Glazed door
Adapter bracket
Single point
locking
Glazed door
Lever handle
3-point locking
DIN profile half
cylinder
(black grey)
01004086
7035 (light grey)/
Al, 19" plane
integrated,
front open, incl.
GND/earthing,
no door can be
fitted
01004160
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
01004088
St, 1.5 mm,
Sekurit
glass 6 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
01004147
with push button
for doors with
single point
locking
01004091
St, 1.5 mm,
Sekurit
glass, 6 mm,
opening angle
180°, lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.30
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
PU 1 pair
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-232
23130-221
21130-123
23130-067
21130-183
25127-995
21130-233
23130-222
21130-125
23130-067
21130-185
25127-995
21130-234
23130-223
21130-127
23130-067
21130-187
25127-995
RAL 7021
21130-128
23130-067
21130-188
25127-995
21130-235
23130-224
21130-129
23130-067
21130-189
25127-995
21130-235
23130-224
21130-129
23130-067
21130-189
25127-995
21130-130
23130-067
21130-190
25127-995
21130-236
23130-225
21130-131
23130-067
21130-191
25127-995
21130-236
23130-225
21130-131
23130-067
21130-191
25127-995
21130-132
23130-067
21130-192
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-232
23130-231
22130-123
23130-067
22130-183
25127-995
22130-233
23130-232
22130-125
23130-067
22130-185
25127-995
22130-234
23130-233
22130-127
23130-067
22130-187
25127-995
RAL 7035
22130-128
23130-067
22130-188
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-130
23130-067
22130-190
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-132
23130-067
22130-192
25127-995
VARISTAR IP 20
Steel doors
Order Information
Steel door, single point locking
Plain
Solid, inner
surface with
mounting frame
Perforated
Lever handle
Steel door
3-point locking
DIN profile half
cylinder
(black grey)
01004089
7035 (light grey)/
St, 1 mm,
opening angle
180°, key,
incl. GND/
earthing
01008067
St, 1.5 mm,
opening angle
180°, lock cover
incl. GND/
earthing,
designed to carry
extensive cutouts and
assemblies
01004090
St, 1.5 mm,
opening angle
180°, key,
incl. GND/
earthing
01004147
with push button
for doors with
single point
locking
01008085
St, 1.5 mm,
opening angle
180°, inner side
with mounting
frame,
lever handle with
built-in push
button, incl.
GND/earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-108
21130-568
21130-138
23130-067
21130-153
25127-995
21130-110
21130-570
21130-140
23130-067
21130-155
25127-995
21130-112
21130-572
21130-142
23130-067
21130-157
25127-995
21130-113
21130-573
21130-143
23130-067
21130-158
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
25127-995
21130-115
21130-575
21130-145
23130-067
21130-160
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
25127-995
21130-117
21130-577
21130-147
23130-067
21130-162
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-108
22130-568
22130-138
23130-067
22130-153
25127-995
22130-110
22130-570
22130-140
23130-067
22130-155
25127-995
22130-112
22130-572
22130-142
23130-067
22130-157
25127-995
22130-113
22130-573
22130-143
23130-067
22130-158
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
25127-995
22130-115
22130-575
22130-145
23130-067
22130-160
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
25127-995
22130-117
22130-577
22130-147
23130-067
22130-162
25127-995
RAL 7021
RAL 7035
1.31
VARISTAR IP 20
Double doors
Order Information
Double door, 3-point locking
Glazed
Perforated
DIN profile half
cylinder
Plain
(black grey)
01005065
7035 (light grey)/
01005066
01005064
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Securit glass,
lever handle with lever handle with
6 mm,
push button, incl. push button, incl.
opening angle
GND/earthing
GND/earthing
180°,
lever handle with
push button, incl.
GND/earthing
01004148
for lever handle,
common locking
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
21130-454
21130-213
21130-486
25127-995
21130-456
21130-215
21130-488
25127-995
21130-458
21130-217
21130-490
25127-995
21130-459
21130-218
21130-491
25127-995
21130-460
21130-219
21130-492
25127-995
21130-460
21130-219
21130-492
25127-995
21130-461
21130-220
21130-493
25127-995
21130-462
21130-221
21130-494
25127-995
21130-462
21130-221
21130-494
25127-995
21130-463
21130-222
21130-495
25127-995
RAL 7035
RAL 7035
RAL 7035
22130-454
22130-213
22130-486
25127-995
22130-456
22130-215
22130-488
25127-995
22130-458
22130-217
22130-490
25127-995
22130-459
22130-218
22130-491
25127-995
22130-460
22130-219
22130-492
25127-995
22130-460
22130-219
22130-492
25127-995
22130-461
22130-220
22130-493
25127-995
22130-462
22130-221
22130-494
25127-995
22130-462
22130-221
22130-494
25127-995
22130-463
22130-222
22130-495
25127-995
VARISTAR IP 20
Flat top covers, lifting eyes
Order Information
Flat top cover
Plain flush
top cover
Perforated
Spacer
Lifting eye
Spacer
Lifting eye
10
(black grey)
M12
01004096
St, 1.5 mm,
incl. GND/
earthing
7035 (light grey)/
01004097
M12
01004100
01004099
01004100
St, 1.5 mm,
fully perforated,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
St, zinc-plated,
for raising a
top cover by
10 mm
for raised
flat top cover,
application and
in accordance
with DIN 582
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-242
21130-262
21130-243
21130-263
21130-242
21130-243
21130-262
21130-263
21130-242
21130-262
21130-243
21130-246
21130-263
21130-266
23130-072
23130-068
23130-085
21130-241
21130-261
23130-072
23130-068
23130-085
21130-242
21130-243
21130-262
21130-263
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-246
21130-266
21130-247
21130-241
21130-267
21130-261
21130-242
21130-262
21130-243
21130-247
21130-263
21130-267
RAL 7021
RAL 7021
21130-242
21130-262
21130-243
21130-263
21130-242
21130-243
21130-262
21130-263
21130-242
21130-262
21130-243
21130-246
21130-263
21130-266
23130-072
23130-068
23130-085
21130-241
21130-261
23130-072
23130-068
23130-085
21130-242
21130-243
21130-262
21130-263
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
21130-246
21130-266
21130-247
21130-241
21130-267
21130-261
21130-242
21130-262
21130-243
21130-247
21130-263
21130-267
1.33
VARISTAR IP 20
Flat top cover assemblies with cut-out zones
Order Information
Flat top cover
with cut-out
zones
Top cover assemblies
Brush strip
Fan insert
Thermostat
Top cover plate,
perforated
Edge protection
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
M12
300 mm
01004098
7035 (light grey)/
01006092
01004102
W
01108052
D
01009056
230 VAC,
nylon, black, one
with mains cable St, 1.5 mm, 6 mm
St, 1.5 mm,
hole diameter,
brush strip covers with three fans,
230 VAC
incl. GND/
3
incl. GND/
(SCHUKO/UTE
earthing, number a lateral cut-out,
410 m /h,
earthing
two brush strips
plug/
of cut-outs and
completely
cover a center wired, connecting IEC 60320 C13
dimension
cut-out
socket),
drawings
cable IEC 320
adjustment range
see page
0 ... 60°C
1.9
41003065
01004100
PVC, 3 m,
black, for open
cut-out zones
for top cover,
applications
and load in
accordance with
DIN 582
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.34
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
enclosed loose
assembled
RAL 7021
RAL 7021
21130-252
21130-253
21130-252
21130-253
21130-252
21130-253
21130-256
RAL 7021
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-252
21130-253
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-256
21130-257
21130-252
21130-253
21130-257
RAL 7021
21130-252
21130-253
21130-252
21130-253
21130-252
21130-253
21130-256
RAL 7021
RAL 7021
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-252
21130-253
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
23130-069
23130-070
20118-750
23130-071
28127-281
23130-072
21130-256
21130-257
21130-252
21130-253
21130-257
VARISTAR IP 20
Fan top covers
Order Information
Fan top cover
Top cover for
6 fans
Replacement
fan for fan top
Thermostat
Speed control
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
300 mm
01005060
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
kta44844
01108052
01105055
01005085
fully wired,
for fan top cover,
St, 1.5 mm, raised fan with grille for with mains cable
90 ... 264 VAC,
applications and
top assembly,
230 VAC
cover,
static load230 VAC,
(SCHUKO/UTE input SCHUKO/UTE
3 axial fans,
carrying capacity
plug/
plug,
230 VAC,
38x119x119 mm,
3
in accordance
incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 outlet IEC 60320 C1
with DIN 582
socket),
3 socket; external
ND/earthing,
h
adjustment range NTC sensor 1.5 m
connecting cable
0 ... 60°C
2.5 m, SCHUKO/
IEC60320 C12
plug
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
21130-400
21130-401
21130-400
21130-401
21130-400
21130-401
21130-402
23130-165
20118-750
60715-005
23130-090
21130-400
21130-401
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
21130-402
21130-403
21130-400
21130-401
21130-403
RAL 7021
21130-400
21130-401
21130-400
21130-401
21130-400
21130-401
21130-402
23130-165
20118-750
60715-005
23130-090
21130-400
21130-401
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
21130-402
21130-403
21130-400
21130-401
21130-403
1.35
VARISTAR IP 20
Bases/plinths
Order Information
Base plate
Base plate, multipiece
Brush strip
Base/plinth
Dust filter set
Cover plate
Base/plinth,
ventilated
Side covers
Base/plinth,
mobile
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1.36
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004105
01004059
01004106
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm, trim, St,
1.5 mm, static
load-carrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
nylon, black
1 piece
1 piece
1 piece
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-074
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
dimension
drawings
see page 1.9
1 piece
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-074
23130-135
23130-075
23130-136
23130-194
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-074
23130-075
23130-076
23130-187
23130-006
23130-134
23130-135
23130-136
23130-194
RAL 7021
RAL 7021
RAL 7021
RAL 7021
23130-002
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-002
23130-006
23130-074
23130-075
23130-076
23130-187
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-208
23130-170
23130-209
23130-169
23130-166
23130-212
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-170
23130-213
23130-166
23130-169
23130-208
23130-170
23130-209
23130-170
23130-213
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-074
23130-075
23130-076
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-166
23130-169
23130-170
23130-208
23130-209
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-074
23130-075
23130-187
23130-074
23130-075
23130-076
23130-187
23130-134
23130-135
23130-136
23130-194
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-169
23130-212
23130-170
23130-166
23130-213
23130-169
23130-208
23130-170
23130-170
23130-209
23130-213
VARISTAR IP 20
Connecting plates for short doors/rear panels
Order Information
Dimensioning
connecting plate
door/rear panel
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01004066 01004056
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
RAL 7021
RAL 7021
21130-472
21130-473
21130-478
21130-479
rack shelves,
19" shelves,
slide rails,
cable ducting
23130-164
23130-164
from page
1.44
from page
1.44
RAL 7035
RAL 7035
22130-472
22130-478
23130-164
22130-473
22130-479
23130-164
1.37
configuration
Simple. Fast. To the ideal product.
freely
쮿 Configuration tables from page 1.39
assembly
modification
off-the-shelf products
solution
Simple. Fast. From one source.
supply), function test
academy
reports
1.38
lifecycle
replacement parts
ELECTRONICS PROTECTION
VARISTAR IP 55 ServicePLUS: configuration and assembly
쮿 Dimensions:
Page
(see example below)
feet, castors
1.40
Side panels, rear panels,
doors, top covers
1.41
eyes
1.42
1.43
IP 55
1.44
1.45
Swing frames
1.46
Mounting plates,
stationary shelves, 75 kg
1.47
1.48
1.49
19" telescopic shelves,
2 U, 70 kg
1.50
Slide rails, depth
members
1.51
Cable ductings
1.52
Cable ties, Velcro
1.53
01004077
Qty
1
1
1
1
1
1
Description
IP 55 gasketing kit, 1 piece
Side panel, screw-fixed, RAL 7021, PU 2 pieces
Glazed door with 3-point locking, RAL 7021, IP 55, 1 piece
SCHROFF.PENTAIR.CO.UK
Part no.
20130-019/05
23130-064/05
21130-011/05
21130-069/05
21130-189/05
23130-079/05
1.39
VARISTAR IP 55
Order Information
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
Gasket kit
IP 55
Side-by-side
mounting kit
IP 55
(with gasketing)
Adjustable feet
Castors
with 2 jacking feet
with adjustable
feet
(black grey)
01004078
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004157
01004120
01004081
01004082
01004158
for the frame,
for the frame,
for the frame,
side-to-side
seals are glued to
static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: the frame, so that mounting bracket
(4 pieces), St,
all cladding parts
800 kg,
400 kg,
400 kg,
400 kg,
1000 kg,
RAL 7021, incl.
conform to
St, 1.5 mm, zinc- St, 1.5 mm, zinccannot be used
cannot be used
cannot be used
gasketing to
protection type
plated, with
plated, with
cover the gap
IP 55
central GND/
central GND/
between two
earthing
earthing
racks; cannot be
point; please
point; please
used with
order adjustable order adjustable
decorative frame
feet or castors
feet or castors
separately
separately
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
assembled
assembled
RAL 7021
RAL 7021
20130-005
20130-055
20130-006
20130-056
20130-009
20130-059
20130-010
20130-013
20130-060
20130-063
20130-014
20130-064
20130-015
20130-017
20130-065
20130-018
20130-068
20130-019
20130-022
20130-069
20130-072
20130-023
20130-073
20130-026
20130-027
20130-077
20130-028
20130-078
20130-032
20130-082
assembled
supplied loose
assembled
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-064
23130-062
23130-062
23130-079
23130-079
23130-077
23130-077
23130-078
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-064
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.40
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-064
23130-062
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-064
23130-062
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-064
23130-062
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-064
23130-062
42 2000 600
300
20130-017
23130-064
23130-062
42 2000 600
600
20130-018
20130-068
23130-064
23130-062
42 2000 600
800
20130-019
20130-069
42 2000 800
600
20130-022
20130-072
23130-064
23130-062
42 2000 800
800
20130-023
20130-073
47 2200 600
300
20130-026
23130-064
23130-062
47 2200 600
600
20130-027
20130-077
23130-064
23130-062
47 2200 600
800
20130-028
20130-078
47 2200 800
800
20130-032
20130-082
23130-064
23130-062
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
VARISTAR IP 55
Side panels, rear panels, doors, top covers
Order Information
Screw-fixed side
panel
Screw-fixed rear
panel
Glazed door
3-point locking
Steel door
3-point locking
DIN profile half
cylinder
Plain flush top cover
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
Cabinet dimensions
Height
No. U
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load
in compliance
with DIN 582
Depth
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-063
21130-183
21130-153
25127-995
21130-065
21130-185
21130-155
25127-995
21130-067
21130-187
21130-157
25127-995
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
01004148
for lever handle,
common locking
Width
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
01008085
St, 1.5 mm,
opening angle
180°,
inner side with
mounting frame,
lever handle
with built-in
push button,
incl. GND/
earthing
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
21130-003
21130-004
21130-005
21130-006
21130-007
21130-008
21130-007
21130-009
21130-010
21130-011
21130-010
21130-011
21130-014
21130-015
21130-016
21130-016
RAL 7035
22130-003
22130-004
22130-005
22130-006
22130-007
22130-008
22130-007
22130-009
22130-010
22130-011
22130-010
22130-011
22130-014
22130-015
22130-016
22130-016
RAL 7021
21130-242
21130-243
21130-242
21130-243
21130-242
23130-072
23130-072
23130-072
21130-068
21130-188
21130-158
25127-995
21130-243
21130-246
21130-069
21130-189
21130-159
25127-995
21130-241
23130-072
21130-242
21130-243
23130-072
21130-069
21130-189
21130-159
25127-995
21130-070
21130-190
21130-160
25127-995
21130-071
21130-191
21130-161
25127-995
21130-071
21130-191
21130-161
25127-995
21130-072
21130-192
21130-162
25127-995
RAL 7035
RAL 7035
RAL 7035
21130-246
21130-247
21130-241
21130-242
21130-243
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
22130-063
22130-183
22130-153
25127-995
22130-065
22130-185
22130-155
25127-995
22130-067
22130-187
22130-157
25127-995
21130-242
21130-243
21130-242
21130-243
21130-242
23130-072
23130-072
23130-072
22130-068
22130-188
22130-158
25127-995
21130-243
21130-246
22130-069
22130-189
22130-159
25127-995
21130-241
23130-072
21130-242
21130-243
23130-072
22130-069
22130-189
22130-159
25127-995
22130-070
22130-190
22130-160
25127-995
22130-071
22130-191
22130-161
25127-995
22130-071
22130-191
22130-161
25127-995
22130-072
22130-192
22130-162
25127-995
21130-246
21130-247
21130-241
21130-242
21130-243
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
Part number in bold face type: ready for despatch within 2 working days
Part number in normal type: ready for despatch within 10 working days
1.41
VARISTAR IP 55
Order Information
Base plate
Cover plate
Seal IP 55
Base plate,
one-piece,
EMC, IP 55
Base/plinth
Base/plinth,
ventilated
Side cover
Base/plinth,
mobile
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1.42
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004106
01004073
for base plate
with cover
01004051
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimension
drawings see
page 1.9
1 piece
St, 1.5 mm,
please order
gasket IP55
separately
1 piece
1 piece
1 piece
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
AlZn
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-076
23130-073
23130-076
23130-073
23130-076
23130-073
23130-036
23130-073
23130-073
23130-076
23130-073
23130-036
23130-073
23130-073
23130-076
23130-073
23130-006
23130-076
23130-073
RAL 7021
RAL 7021
23130-002
23130-001
23130-002
23130-001
23130-002
23130-001
23130-002
23130-005
23130-009
23130-001
23130-002
23130-005
23130-006
23130-009
23130-001
23130-002
23130-006
23130-076
23130-073
23130-076
23130-073
23130-076
23130-073
21130-281
21130-282
21130-281
21130-282
21130-281
21130-282
21130-283
21130-285
21130-281
21130-282
21130-283
21130-284
21130-285
21130-281
21130-282
23130-187
23130-194
23130-187
23130-187
RAL 7021
21130-282
21130-281
21130-282
21130-281
23130-073
23130-073
21130-285
23130-076
23130-073
21130-281
21130-282
23130-036
23130-073
23130-073
23130-073
23130-194
23130-187
AlZn
21130-281
23130-076
23130-187
23130-194
23130-036
23130-073
23130-187
21130-284
21130-282
21130-283
23130-076
23130-187
21130-283
21130-284
21130-285
21130-281
21130-282
21130-284
23130-187
23130-187
23130-187
23130-194
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-208
23130-170
23130-209
23130-169
23130-166
23130-212
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-170
23130-213
23130-166
23130-169
23130-208
23130-170
23130-209
23130-170
23130-213
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-187
23130-166
23130-187
23130-169
23130-170
23130-208
23130-209
23130-194
23130-187
23130-187
23130-194
23130-169
23130-212
23130-170
23130-166
23130-213
23130-169
23130-208
23130-170
23130-170
23130-209
23130-213
VARISTAR IP 55
Order Information
Dimensioning
connecting plate
door/rear panel
Connecting plate
Completely in
RAL 7021
(black grey)
01005071
Colour combination
RAL 7035 (light
grey)/
RAL 7021 (black
grey)
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
01005072
St, 1 mm, can
door and rear
also be fitted in
panel must be
upper part,
selected 400 mm
height 400 mm,
shorter than the
cabinet height; with assembly kit
cannot be used
with double door
1 piece
assembled
RAL 7021
21130-504
21130-505
RAL 7035
22130-504
22130-505
1.43
Interior mounting
Order Information
19" panel/slide mounts EIA
Painted RAL 7021
AIZn
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
U height identification
for 19" panel/
slide mount
c
D
Dimension
Standard fitting
xf = distance
from front
c = pitch of
19" panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
reduced-width adapter bracket
required for 800 mm width;
depth members are required for
00505050
sc128
paper strip, white,
assembly kit:
serial numbered item 1: screws,
from 1 ... 47 H item 2: cage nuts,
item 3: washers
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.44
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
AIZn
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AlZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
AlZn
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
Interior mounting
Order Information
Dimensions
Panel/slide
mount
(black grey)
coa43693
7035 (light grey)/
01004114
St, 2 mm,
in accordance
Al-Zn finish,
with ETS 300119suitable only for
3 and
IEC 60917-211; Slim-Line frame;
shelves available
SU = 25 mm
on request
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
Height
SU
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
AIZn
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 1 pair
assembled
23130-052
23130-053
23130-054
23130-054
23130-055
23130-055
23130-055
23130-056
23130-056
23130-056
AlZn
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
23130-052
23130-053
23130-054
23130-054
23130-055
23130-055
23130-055
23130-056
23130-056
23130-056
1.45
Interior mounting
Swing frames for cabinet width 600 mm
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Spare key
01005061
01015060
St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg,
120° hinge, square locks
incl. 2 keys
(Dimension drawings link)
St; for safety reasons a swing
frame stop is recommended
for swing frame, instead of
square lock, incl. 2 keys
01015059
Usable
height
U
Width
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Swing frames for cabinet width 800 mm
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
1.46
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
(item 2) and cutout for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
PU 1 kit
assembled
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
Usable
height
U
mm
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
Width
SCHROFF PRODUCT CATALOG E 08/2017
Interior mounting
Mounting plate, stationary shelves, 75 kg
Order Information
Mounting plate
Full height
Height 1200 mm
Stationary shelf
Full depth
Strengthening
brackets
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01008052
7035 (light grey)/
01008053
St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear
mounted); strengthening bracket
increases static load-carrying
capacity; please order separately
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
01004142
01004142
St, 1.5 mm, static St, 1.5 mm, static
load-carrying
load-carrying
cap. 75 kg, 1 U,
capacity 75 kg,
depth 479 mm,
1 U, incl. GND/
incl. GND/
earthing
earthing,
for recessed
installation order
depth members
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 2 pieces
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
assembled
assembled
assembled
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
23130-413
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
21130-333
21130-332
23130-081
21130-335
21130-334
23130-082
21130-323
21130-322
23130-081
21130-325
21130-335
21130-324
21130-334
23130-082
23130-082
RAL 7035
RAL 7035
AlZn
22130-323
22130-322
23130-081
22130-325
22130-324
23130-082
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-323
22130-322
23130-081
22130-325
22130-333
22130-324
22130-332
23130-082
23130-081
23130-413
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
22130-333
22130-332
23130-081
22130-335
22130-324
23130-082
22130-323
22130-322
23130-081
22130-325
22130-335
22130-324
22130-334
23130-082
23130-082
1.47
Interior mounting
Order Information
Telescopic shelf, 2 U
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
7035 (light grey)/
01004145
load-carrying
load-carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.48
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-373
21130-354
21130-372
23130-274
23130-092
23130-140
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
21130-373
21130-372
21130-375
21130-374
21130-353
21130-352
21130-355
21130-375
21130-354
21130-374
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
AlZn
RAL 7021
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-373
22130-354
22130-372
23130-274
23130-092
23130-140
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-373
22130-372
22130-375
22130-374
22130-353
22130-352
22130-355
22130-375
22130-354
22130-374
Interior mounting
19" shelves 1 U, stationary 75 kg, telescopic 30 kg
Order Information
19'' stationary shelf,
1 U, 75 kg
Full depth
Shortened by
100 mm
W
xf
(black grey)
01004146
7035 (light grey)/
Full depth
1 U, 30 kg
Shortened by
GND/earthing
100 mm
c
D
Dimension
Standard fitting
01004118
01004119
01004123
01004122
St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static
xf = distance
load-carrying
load-carrying
load-carrying
load-carrying
from front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
GND/earthing kit GND/earthing kit
W = cabinet width
separately
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
1.49
Interior mounting
19" telescopic shelf, 2 U, 70 kg
Order Information
Dimension
Standard fitting
Telescopic shelf, 2 U, 70 kg
W
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004123
1.50
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
01004122
01004125
05904052
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order, T-bar lock
and earthing kit
separately
1 piece
to lock the
telescopic shelf
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
xf
mm
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
22130-353
22130-355
22130-352
22130-354
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
GND/earthing
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order, T-bar lock
and earthing kit
separately
1 piece
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
T-bar lock
xf
(black grey)
7035 (light grey)/
Shortened by
100 mm
c
D
Full depth
for telescopic
shelf
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-352
23130-092
23130-140
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
23130-092
23130-140
21130-353
21130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
21130-353
21130-352
21130-355
21130-354
21130-353
21130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-352
23130-092
23130-140
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
23130-092
23130-140
22130-353
22130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
22130-353
22130-352
22130-355
22130-354
22130-353
22130-352
Interior mounting
Slide rails, depth members
Order Information
Slide rail
25 kg
Depth member,
3 rows
W
xf
(black grey)
01004146
7035 (light grey)/
Short slide rail
100 kg
c
D
Dimension
Standard fitting
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance
finish AlZn, static zinc-plated, static finish AlZn, static
from front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
23130-097
23130-096
23130-119
23130-118
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
50
50
50
50
50
50
150
50
50
50
150
500
700
500
700
500
700
500
200
500
700
500
500
200
500
700
500
23130-097
23130-096
23130-119
23130-118
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-094
23130-081
23130-082
23130-081
23130-096
23130-118
23130-094
23130-099
23130-096
23130-116
23130-118
23130-094
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-099
23130-116
23130-094
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
AlZn
zinc-plated
AlZn
23130-096
23130-118
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
AlZn
23130-081
23130-082
23130-081
23130-082
23130-094
23130-081
23130-082
23130-081
23130-096
23130-118
23130-094
23130-099
23130-096
23130-116
23130-118
23130-094
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-099
23130-116
23130-094
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
23130-094
23130-081
23130-082
23130-081
23130-082
1.51
Cabinets – Varistar Elektronics ServicePLUS
Interior mounting
Cable ductings
Order Information
Cable ducting with C-profile
C-rail for
cabinet depth
C-rail for
cabinet width
Slide nut
Cable shell
Cable support for
C-rail
(black grey)
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
vnt009
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.24
01006110
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.52
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 5 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-087
AlZn
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
AlZn
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
Interior mounting
Cable ties, Velcro
Order Information
Cable tie
Velcro
General
components
Mechanics
Completely in RAL 7021
(black grey)
from page
3.2
01005078
7035 (light grey)/
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.25
01005079
black,
length 300 mm,
further
dimensions
see page
1.25
Electrics
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.29
Power
distribution
from page
3.50
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
300
600
800
600
800
300
600
800
800
Climate control
from page
4.0
1.53
VARISTAR EMCMain Catalogue
Cabinets – VARISTAR EMC
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
01008001
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
41003017
Cooling with perforated HF door with high air
throughput (78 % open area)
01007004
Cooling with HF fan top cover for up to 6 fans
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
01007005
Cable entry in rear section of base plate;
sealing by means of sliding plates
01007003
Cable entry by means of HF connection plate
Appendix . . . . . 12
1.54
Overview . . . . . . 1.54
VARISTAR EMC Main Catalogue
Best performance in HF shielding
쮿 Shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz
(tested to IEC 61587-3)
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
쮿 Cable entry to front or rear or via base
쮿 Cooling with perforated front door or with fan top cover
쮿 Standard cabinets available from stock or individually configurable with appropriate accessory range
VARISTAR EMC,
base plate without
cable ducting . . . . 1.55
VARISTAR EMC
with perforated
door . . . . . . . . . . . . . 1.57
VARISTAR EMC
with fan top cover 1.58
VARISTAR EMC
Accessories
01005017
01007017
쮿 Versions with/without
cable entry through base plate
쮿 With perforated HF front and rear
door
쮿 IP 55
쮿 Base plate with cable ducting
01007018
쮿 With fan top cover and perforated
base plate with cable entry
Base/plinth . . . . . . 1.59
19" swing
frame . . . . . . . . . . . 1.60
19" panel/slide
mount . . . . . . . . . . 1.61
19" fixing
materials kit,
M6 . . . . . . . . . . . . . . 1.61
Slide rails . . . . . . . . 1.62
19" shelves . . . . . . 1.63
Depth members . . 1.66
C horizontal rail . . 1.66
Cable tie,
Velcro . . . . . . . . . . . 1.67
ServicePLUS . . 1.68
ServicePLUS
configuration . . . . 1.69
ServicePLUS from page 1.68
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (special sizes)
www.schroff.biz/ServicePLUS
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR air/
water heat
exchanger . . . . . . . 1.224
30407004
1.55
VARISTAR EMC
VARISTA R EMCMain CataloguePart number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
쮿 Shielding 60 dB at 1 GHz, 40 dB at 3 GHz
쮿 Type of protection IP 55
쮿 Doors with 4-point locking and screw-fixed side panels
쮿 Static load-carrying capacity 400 kg (Slim-Line)
쮿 Base plate versions
– without cable ducting
– with cable ducting
Delivery comprises (assembled)
01005017
Item
1
Qty
1
2
3
4
4
1
1
5
1
6
2
7a
7b
1
1
8
2
9
1
Description
Welded basic frame, Slim-Line, St profile, RAL 7021,
with textile gasket all-around
Adjustable foot, assembled
Flat top cover, St, inner surface AlZn, outside RAL 7021
Front door, St, inner surface AlZn, outside RAL 7035,
180° hinge, 4-point locking, lever handle
Rear door, St, inner surface AlZn, outside RAL 7035,
Side panel, screw-fixed, St, inner surface AlZn,
outside RAL 7035
Base plate, one-piece, St, 1.5 mm, finish AlZn
Base plate with cable ducting, St, 1.5 mm, finish AlZn;
cable entry to rear with conductive seal, 359 mm x 60 mm
opening
19" panel/slide mount with EIA cut-outs, AlZn,
assembled at front, depth-adjustable in 25 mm
increments
GND/earthing kit, enclosed loose
Order Information
Height Height
H
U
mm
01005015
120
100
Description
Base plate without
cable entry
42
2000
600
800
entry
Castors load-carrying capacity 400 kg, PS/St,
PU 4 pieces, 2 locking, 2 non locking
Castors with integrated adjustable feet load-carrying
capacity 400 kg, PU 4 pieces
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Lifting eye for top cover PU 4 pieces
42
[dBµV]
Width W Depth
D
mm
mm
2000
600
800
Part no.
10130-020
10130-192
23130-077
23130-078
25127-995
23130-072
80
1
60
2
40
Note
쮿 For more dimensions and versions see ServicePLUS
configuration, from page 1.69
쮿 Please order base/plinth separately, see page 1.59
쮿 For assembly of shelves and slide rails another pair of panel/
slide mounts is necessary, see page 1.61
200
300
400
500
600
700
800
900
1000
[MHz]
1) Shielding without cable ducting
2) Shielding with cable ducting,
tested to IEC 61587-3,
standard dimensions of test objects 2000 x 600 x 600 mm
01007060
ServicePLUS see page 1.68
1.56
VARISTAR EMC
with perforated doors
VARISTAR EMC
쮿 Shielding 40 dB at 1 GHz (tested to IEC 61587-3)
쮿 Air throughput 78 %
Item
1
Qty
1
2
3
4
4
1
1
5
1
6
2
7
1
8
2
9
1
Description
with textile gasket all around
Front door, perforated, St, inner surface AlZn, outside
RAL 7035, 180° hinge, 4-point locking, lever handle
Rear door, perforated, St, inner surface AlZn, outside
outside RAL 7035
Base plate with cable ducting, St, 1.5 mm, finish Al-Zn;
opening
increments
Order Information
01007017
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2000
600
800
Part no.
10130-190
23130-077
23130-078
25127-995
23130-072
Note
01007019
Perforation
[dBµV]
120
100
80
60
40
200
300
400
500
600
700
800
900
1000
[MHz]
Shielding: Tested to IEC 61587-3,
standard dimensions of test object 2000 x 600 x 600 mm
01007059
1.57
VARISTAR EMC with fan top cover
VARISTA R EMC
쮿 Shielding 50 dB at 1 GHz (tested to IEC 61587-3)
쮿 Fan top cover with 3 fans (up to 6 fans can be mounted)
쮿 Perforated base plate with cable ducting
01007018
Item
1
Qty
1
2
3
4
1
4
1
5
1
6
2
7
1
8
2
9
1
Description
with conductive seal all-around
Raised top cover, St, 1.5 mm, RAL 7021; fan top cover with
3 axial fans, 230 VAC, incl. cabling and GND/
earthing; SCHUKO/UTE plug, cable length 2.5 m,
IEC 60320-C13 socket; assembly space for 3 further fans
outside RAL 7035
Base plate with cable ducting, perforated, St, 1.5 mm,
finish AlZn; cable entry to rear with conductive seal,
359 mm x 60 mm opening
increments
Order Information
01007004
Fan top cover
[dBµV]
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2000
600
800
Lifting eye for fan top PU 4 pieces
Part no.
10130-191
23130-077
23130-078
25127-995
23130-090
Note
120
100
80
60
40
200
300
400
500
600
700
800
900
1000
[MHz]
01007057
1.58
Stationary base
VARISTAR EMC
쮿 Static load-carrying capacity 1000 kg
쮿 Removable trims allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
2a
H
2b
1
2b
2a
D = cabinet depth
W
D
4
01004110
01004053
Delivery comprises (kit)
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
For cabinet width W
Front/rear trim
mm
600
perforated
600
solid
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-170
Note
쮿 Please order side trims (item 4) separately
Base/plinth, mobile
VARISTAR EMC
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
For cabinet width
mm
600
01004111
For cabinet depth
mm
800
Part no.
23130-209
01006095
1.59
19" swing frame
VARISTA R EMC
쮿 Can accommodate 19" chassis and 19" subracks
2
쮿 For full height or partial-height mounting within cabinets
쮿 Pivot point can be selected right or left
쮿 Load-carrying capacity 150 kg
h2
h1
1
Tm
ax.
Qty
1
2
2
2
1
Description
Swing frame, St, 2 mm, RAL 7021
Support bar, St, 3 mm, RAL 7021
Square lock, 8 mm, incl. 2 keys
120° hinge
Assembly kit
Order Information
4
3
01005055
Maximum mounting depth for swing frame
Cabinet
Slim-Line
Heavy-Duty
Item
1
2
3
4
5
01005059
Width 600 mm
220 mm
200 mm
For cabinet height
Height h1
mm
U
900 for partial-height mounting 16
1200 for partial-height mounting 24
1400 for partial-height mounting 29
1600 for partial-height mounting 33
1800 for partial-height mounting 38
2000
42
Swing frame stop max. swing angle 120°, St,
zinc-plated, 1 piece
Security lock to replace the square lock,
PU 1 lock incl. 2 keys
Spare key for security lock, 1 piece
Height h2
U
12
21
25
30
34
39
Part no.
21130-740
21130-741
21130-742
21130-743
21130-744
21130-745
23130-158
60113-267
60220-003
Note
Swing frame stop
쮿 19" swing frames can be assembled:
– Directly on the cabinet frame
– In 50 mm increments by aid of depth members
(depth-adjustable)
쮿 For partial-height mounting, depth members are necessary,
see page 1.66
01005061
Security lock
41001517
1.60
19" panel/slide mount with universal pitch (EIA)
VARISTAR EMC
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish
AlZn, RAL 7035 or RAL 7021
Assembly kit, incl. GND/earthing
Order Information
9,6
42,5
Item
1
01004112
01004131
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
8
395
23130-037 23130-027
12
545
23130-038 23130-028
16
745
23130-039 23130-029
Partial20
895
23130-040 23130-030
height
24
1095
23130-031 23130-021
mounting
29
1295
23130-032 23130-022
33
1495
23130-033 23130-023
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
쮿 For 19" partial-height mounting depth members are necessary
쮿 Metric panel/slide mounts available on request
Standard assembly dimension xr = xf = 50 mm
01005088
19" assembly kit, M6
VARISTAR EMC
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.61
Slide rails
VARISTA R EMC
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 Wide support surface (48 mm)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Assembly kit incl. GND/earthing
Order Information
Static load carrying capacity 25 kg
For cabinet depth
D
mm
800
800
01005086
xf
c
Length L Qty/PU
mm
50
50
mm
700
700
mm
656
656
2
10
Part no.
23130-097
23130-102
Order Information
Static load carrying capacity 100 kg
For cabinet depth
D
mm
800
800
c
Length L Qty/PU
mm
50
50
mm
700
700
mm
658
658
2
10
Part no.
23130-119
23130-124
01004058
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
D
c
xf
c - 130
1.62
xf
01004130
19'' stationary shelf, 75 kg
VARISTAR EMC
쮿 Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
c
For cabinet
Usable
xf
c
RAL 7035
depth
surface w x d
mm
mm
mm mm
Part no.
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf PU 1 piece
D
d
Order Information
RAL 7021
Part no.
21130-305
23130-310
Note
w
xf
쮿 Cable ducting with cable ties, see page 1.67
쮿 Other sizes, see ServicePLUS, page 1.80
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
1.63
19'' telescopic shelf, 30 kg
VARISTA R EMC
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
800
417 x 682
50 700 22130-345
GND/earthing for telescopic 19" shelf PU 1 kit,
for VARISTAR
D
c
d
Full depth
RAL 7021
Part no.
21130-345
23130-140
xf
Note
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
800
417 x 582
50 700 22130-344
for VARISTAR
xr
w
RAL 7021
Part no.
21130-344
23130-140
D
xf
d
c
Note
c = max. pitch of the 19" panel/slide mounts
xf, xr = standard assembly pitch
1.64
01004070
19'' telescopic shelf, 70 kg
VARISTAR EMC
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
800
405 x 682
50 700 22130-355
Item 4 T-bar lock for 1 telescopic shelf
(can be mounted right or left), 1 piece
for VARISTAR
xf
d
Order Information
RAL 7021
Part no.
21130-355
23130-092
23130-140
Note
01004069
c = max. pitch for 19" panel/slide mounts
Shortened depth
W
쮿 Please order T-bar lock (item 4) separately
Order Information
w
Shortened by 100 mm
D
d
c
xr
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
800
405 x 582
50 700 22130-354
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
for VARISTAR
RAL 7021
Part no.
21130-354
23130-092
23130-140
Note
xf
01004070
1.65
Depth member
VARISTA R EMC
쮿 For mounting of shortened 19" panel/slide mounts
쮿 Cable ducting by means of cable ties and cable eyes
36,5
11,5
Delivery comprises
50
100
37,5
121,2
25
25
L - 27
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
12
Description
L
01004126
Item
1
2
01004079
Cable eye
For cabinet depth
mm
Depth member
800
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-082
21101-151
21101-150
coa43697
C-profile for the cabinet depth
VARISTA R EMC
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
15
,5
Ø6
50
11
Part no.
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
L
쮿 Cable ties and Velcro for cable retention rail see page 1.67
39,5
29,5
L-
,5
x 31
For cabinet depth
Length L
mm
mm
800
660
Accessories
Cable retention rail for C-rail
width 75 mm, length 39.5 mm, PU 5 pieces
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Slide nut for C-profile, PU 10 pieces
50
75
01504054
1.66
C-profile
01004132
01006071
C-profile for cabinet width
VARISTAR EMC
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
800
750
Accessories
Part no.
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable ties, Velcro
VARISTAR EMC
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
VARISTAR EMC
VARISTAR EMC ServiceP LUS
1.67
Cabinets – VARISTAR EMC ServicePLUS
configuration
Components can be varied and combined
freely
쮿 Configuration tables from page 1.69
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
쮿 Download CAD data and send back with modifications
solution
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
쮿 Further information: www.varistar.co.uk
1.68
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
VARISTAR ServicePLUS: configuration and assembly
쮿 Dimensions:
– Height: 29 ... 47 U (1400 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 600, 800 and 1000 mm
Page
쮿 2 colour combinations:
– Frame and covers in black grey (RAL 7021)
– Frame, top cover and base in black grey (RAL 7021);
Side panel, door and rear panel in light grey (RAL 7035)
Frames, EMC gasketing,
side-by-side mounting
kits, adjustable feet,
castors
1.70
doors
1.71
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
Top covers, fan top covers,
1.72
lifting eyes
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all subsequent
configuration pages that apply to these dimensions (see example below)
Bases, plinths
1.73
1.74
쮿 The cabinet is assembled by us and ready for despatch
Interior configuration
1.75
ETSI panel/slide mounts
1.76
Swing frames
1.77
Stationary shelves
1.78
Telescopic shelves, 70 kg
1.79
1.80
2 U, 70 kg
1.81
Slide rails, depth
members
1.82
Cable ductings
1.83
01004077
Example configuration (here: row 9)
Qty
1
1
1
1
1
1
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
EMC gasketing kit, 1 piece
Side panel screw-fixing, EMC, PU 2 pieces
Screw-fixed rear panel, EMC, 1 piece
Steel door with 4-point locking, EMC, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
23130-065/05
21130-031/05
21130-084/05
21130-174/05
23130-079/05
1.69
VARISTAR EMC
Frames, EMC gasketing, side-by-side mounting kits, adjustable feet, castors
Order Information
Frame
Slim-Line
400 kg
EMC gasketing kit
Heavy-Duty
800 kg
Side-by-side
mounting kit
EMC
Adjustable feet
Castors
With 2 jacking
feet
With adjustable
feet
Completely
in
RAL 7021
(black grey
01004078
gaskets are glued
static loadstatic loadto the frame,
through which all
800 kg,
400 kg,
the following
St, 1.5 mm, zinc- St, 1.5 mm, zinccover parts are
plated, with
plated, with
conductively
central GND/
central GND/
linked
earthing point;
earthing point;
please order
please order
adjustable feet or adjustable feet or
castors
castors
separately
separately
Colour
combinatio
n RAL
7035 (light
grey)/
RAL 7021 (
black grey)
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
01004157
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
01004120
side-by-side
mounting
brackets
(4 pieces), St
01004081
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 4 pieces
assembled
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-055
20130-006
20130-056
20130-009
20130-010
20130-059
20130-060
20130-013
20130-063
20130-014
20130-015
20130-064
20130-065
20130-018
20130-068
20130-019
20130-021
20130-069
20130-071
01004156
for the frame,
for the frame,
for the frame,
static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity:
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
with base/plinth with base/plinth with base/plinth
assembled
20130-005
01004082
PU 4 pieces
PU 4 pieces
RAL 7021
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
23130-065
23130-063
23130-079
23130-077
23130-078
20130-022
20130-072
20130-023
20130-027
20130-073
20130-077
20130-028
20130-078
23130-065
23130-063
23130-079
23130-077
23130-078
20130-030
20130-032
20130-080
20130-082
23130-065
23130-063
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
23130-079
23130-077
23130-078
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.70
RAL 7021
RAL 7021
29 1400 600
600
20130-005
20130-055
23130-065
23130-063
29 1400 600
800
20130-006
20130-056
33 1600 600
600
20130-009
20130-059
23130-065
23130-063
33 1600 600
800
20130-010
20130-060
38 1800 600
600
20130-013
20130-063
23130-065
23130-063
38 1800 600
800
20130-014
20130-064
38 1800 800
600
20130-015
20130-065
23130-065
23130-063
42 2000 600
600
20130-018
20130-068
42 2000 600
800
20130-019
20130-069
23130-065
23130-063
42 2000 600
1000
20130-021
20130-071
42 2000 800
600
20130-022
20130-072
23130-065
23130-063
42 2000 800
800
20130-023
20130-073
47 2200 600
600
20130-027
20130-077
47 2200 600
800
20130-028
20130-078
23130-065
23130-063
47 2200 600
1000
20130-030
20130-080
47 2200 800
800
20130-032
20130-082
23130-065
23130-063
Other dimensions and configurations online (with basket) at www.schroff.biz/conf
VARISTAR EMC
Order Information
Side panel,
screw fixed,
EMC,
IP 55
Rear panel,
screw fixed,
EMC,
IP 55
Steel door, 4-point locking
Plain, EMC, IP 55 Perforated, EMC
DIN profile half
cylinder
(black grey)
01004083
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004085
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004092
01004093
St, 1.5 mm,
St, 1.5 mm,
painted outside, painted outside,
AlZn inside,
AlZn inside,
opening angle
opening angle
180°,
180°,
lever handle with lever handle with
push button,
push button,
incl. GND/
incl. GND/
earthing
earthing
01004148
for lever handle,
common locking
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-078
21130-168
21130-198
25127-995
21130-080
21130-170
21130-200
25127-995
21130-027
21130-028
21130-082
21130-172
21130-202
25127-995
21130-027
21130-083
21130-173
21130-203
25127-995
21130-030
21130-031
21130-084
21130-174
21130-204
25127-995
21130-085
21130-175
21130-205
25127-995
21130-036
21130-038
21130-086
21130-176
21130-206
25127-995
21130-036
21130-087
21130-177
21130-207
25127-995
RAL 7035
RAL 7035
RAL 7035
RAL 7035
22130-078
22130-168
22130-198
25127-995
22130-080
22130-170
22130-200
25127-995
22130-027
22130-028
22130-082
22130-172
22130-202
25127-995
22130-027
22130-083
22130-173
22130-203
25127-995
22130-030
22130-031
22130-084
22130-174
22130-204
25127-995
22130-085
22130-175
22130-205
25127-995
22130-036
22130-038
22130-086
22130-176
22130-206
25127-995
22130-036
22130-087
22130-177
22130-207
25127-995
21130-023
21130-024
21130-025
21130-026
21130-033
21130-030
21130-031
21130-035
22130-023
22130-024
22130-025
22130-026
22130-033
22130-030
22130-031
22130-035
1.71
VARISTAR EMC
Top covers, fan top covers, lifting eyes
Order Information
Flat top cover
EMC, IP 55
Fan top cover
Lifting eye
EMC top cover for
6 fans
Replacement
fan for fan top
Thermostat
Speed control
Lifting eye
30
10
50
°C
(black grey)
1000 mm
300 mm
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.72
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
300 mm
M12
01004096
01004090
01008050
kta44844
01108052
01105055
St, 1.5 mm,
fully wired,
fan with grille for with mains cable
RAL 7021;
90 ... 264 VAC,
top assembly,
230 VAC
with 3 axial fans
230 VAC,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
incl. cabling and for 50 Hz, 162 m / IEC 60320 C13
socket),
C13 socket;
GND/earthing,
h
adjustment range
external NTC
connector 2.5m,
0 ... 60°C
sensor 1.5 m
SCHUKO/
IEC 60320 C12
plug
01005085
for fan top cover,
applications and
in accordance
with DIN 582
St, 1,5 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
21130-272
21130-273
21130-272
21130-273
21130-272
21130-273
21130-276
RAL 7021
23130-072
23130-072
23130-072
23130-072
21130-272
21130-273
21130-275
21130-276
21130-277
21130-272
21130-273
21130-275
21130-277
23130-395
23130-396
23130-395
23130-396
23130-395
23130-396
23130-397
23130-395
23130-072
23130-072
23130-396
23130-443
23130-397
23130-398
23130-395
23130-072
23130-396
23130-165
20118-750
60715-005
23130-090
23130-072
23130-443
23130-398
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
RAL 7021
21130-272
23130-395
21130-273
21130-272
21130-273
21130-272
21130-273
21130-276
23130-072
23130-072
23130-072
23130-072
21130-272
21130-273
21130-275
21130-276
21130-277
21130-272
21130-273
21130-275
21130-277
23130-396
23130-395
23130-396
23130-395
23130-396
23130-397
23130-395
23130-072
23130-072
23130-396
23130-443
23130-397
23130-398
23130-395
23130-072
23130-396
23130-165
20118-750
60715-005
23130-090
23130-072
23130-443
23130-398
23130-165
20118-750
60715-005
23130-090
ELECTRONICS PROTECTION
VARISTAR EMC
Bases, plinths
Order Information
Base plate
One-piece,
EMC, IP 55
With cable
ducting, EMC
Base/plinth
Perforated, with
cable ducting,
EMC
Plain base/plinth
Base/plinth,
ventilated
Side covers
Base/plinth,
mobile
(black grey)
01004051
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
SCHROFF.PENTAIR.CO.UK
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004108
AlZn, 1.5 mm,
rear opening
60 mm deep,
incl. GND/
earthing,
assembly from
outside
01008051
01004110
support with
AlZn, 1.5 mm,
adjustable feet
incl. GND/
and 2 trims,
earthing;
loadopening at rear: static
for cabinet width carrying capacity
1000 kg; please
of 600 mm:
order side trims
359 x 60 mm,
separately
for cabinet width
of 800 mm:
559 x 60 mm
01004110
support with
adjustable feet
and 2 trims,
perforated, static
load-carrying
capacity 1000 kg;
please order side
trims separately
01004053
St, 1.5 mm
01004111
support, St,
3 mm, trim, St,
1.5 mm, static
load-carrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
1 piece
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 pair
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
assembled
RAL 7021
23130-169
23130-208
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-281
21130-291
23130-400
21130-282
21130-287
21130-292
21130-296
23130-401
23130-447
23130-387
23130-187
23130-170
23130-209
23130-172
23130-170
23130-211
23130-213
23130-388
23130-194
RAL 7021
RAL 7021
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-281
21130-291
23130-400
21130-282
21130-287
21130-292
21130-296
23130-401
23130-447
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-287
21130-284
21130-296
21130-294
23130-447
23130-403
23130-213
23130-208
23130-187
23130-447
23130-403
23130-400
23130-401
23130-212
23130-170
23130-169
23130-387
23130-401
21130-291
21130-292
23130-169
23130-194
21130-296
21130-294
21130-281
21130-282
23130-209
23130-211
23130-388
21130-292
23130-401
23130-208
23130-170
23130-172
23130-187
21130-287
21130-284
21130-292
23130-169
23130-387
21130-282
21130-282
23130-209
23130-212
23130-194
23130-402
AlZn
23130-208
23130-170
23130-169
23130-388
23130-403
23130-400
23130-400
23130-169
23130-187
21130-293
AlZn
23130-208
23130-209
23130-387
21130-294
21130-291
21130-291
23130-209
23130-187
21130-284
21130-281
AlZn
23130-170
23130-169
23130-170
23130-387
21130-283
21130-281
RAL 7021
23130-387
23130-187
RAL 7021
RAL 7021
23130-169
23130-208
23130-170
23130-209
23130-169
23130-170
23130-208
23130-209
23130-169
23130-208
23130-170
23130-169
23130-209
23130-212
23130-169
23130-208
23130-170
23130-172
23130-209
23130-211
23130-169
23130-212
23130-170
23130-169
23130-213
23130-208
23130-387
23130-187
23130-387
23130-187
23130-388
23130-194
23130-387
23130-187
23130-388
23130-194
23130-387
23130-187
23130-170
23130-209
23130-194
23130-172
23130-170
23130-211
23130-213
23130-388
Part number in normal type: ready for despatch within 10 working days
1.73
VARISTAR EMC
Connecting plates for short doors/rear panels
Order Information
Dimensioning
connecting plate
door/rear panel
EMC connecting plate
Flat plate,
EMC, IP 55
Recessed plate,
EMC, IP 55
(black grey)
01005077
7035 (light grey)/
door and rear
panel must be
selected 400 mm
shorter than
cabinet height
01005075
flat plate,
stainless steel,
1 mm,
height 400 mm,
mounting can be
at top or bottom
Cabinet dimensions
Height
Width Depth
U mm mm
mm
400
400
600
800
Colour combinations
400
400
1.74
600
800
01005074
frame,
stainless steel,
1 mm,
mounting can be
at top or bottom,
height 400 mm,
plate recessed
by 40 mm,
stainless steel,
1 mm
1 piece
1 piece
assembled
assembled
RAL 7021
RAL 7021
21130-578
21130-580
21130-579
21130-581
RAL 7035
RAL 7035
22130-578
22130-580
22130-579
22130-581
Interior mounting
Order Information
Dimension
Painted RAL 7021
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
7035 (light grey)/
U height identification for
19" panel/slide
mount
AIZn
c
D
Standard fitting
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
00505050
sc128
paper strip, white,
assembly kit:
from 1 ... 47 H
item 2: cage nuts,
item 3: washers
other kit
quantities
see page
3.17
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
50
50
50
50
50
50
50
70
50
150
50
50
50
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
700
500
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AIZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
AIZn
AIZn
1.75
Interior mounting
ETSI panel/slide mounts, mounting plates
Order Information
Dimensions
Mounting plates
Panel/slide
mount
Full height
Height 1200 mm
Strengthening
brackets
(black grey)
coa43693
7035 (light grey)/
01004114
St, 2 mm,
in accordance
AlZn finish,
with
suitable only for
ETS 300119-3
and IEC 60917- Slim-Line frame;
211; SU = 25 mm shelves available
on request
01008052
01008053
(rear mounted);
strengthening bracket increases
static load-carrying capacity;
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
Height
SU
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.76
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
50
50
60
60
68
68
68
76
76
76
76
76
84
84
84
84
PU 1 pair
1 piece
1 piece
PU 2 pieces
assembled
assembled
assembled
assembled
AIZn
zinc-plated
zinc-plated
RAL 7021
23130-052
23130-413
23130-418
23130-053
23130-413
23130-418
23130-054
23130-405
23130-413
23130-418
23130-054
23130-406
23130-414
23130-418
23130-055
23130-407
23130-413
23130-418
23130-055
23130-408
23130-414
23130-418
23130-056
23130-413
23130-418
23130-056
23130-414
23130-418
AIZn
verzinkt
verzinkt
RAL 7021
23130-052
23130-413
23130-418
23130-053
23130-413
23130-418
23130-054
23130-405
23130-413
23130-418
23130-054
23130-406
23130-414
23130-418
23130-055
23130-407
23130-413
23130-418
23130-055
23130-408
23130-414
23130-418
23130-056
23130-413
23130-418
23130-056
23130-414
23130-418
Interior mounting
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Width
Spare key
01005061
01015060
incl. 2 keys
01015059
Usable
height
U
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Width
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
Usable
height
U
mm
assembled
PU 1 kit
assembled
PU 2 pieces
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
1.77
Interior mounting
Stationary shelves
Order Information
Stationary shelf
Full depth
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01004142
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
01004142
01004126
St, 1.5 mm, static St, 1.5 mm, static length 460 mm,
St, 1.5 mm, finish
load-carrying
load-carrying
capacity 75 kg, AlZn required for
capacity 75 kg,
recessed shelf
1 U, depth 479
1 U, incl. GND/
mm, incl. GND/
earthing
earthing, for
recessed
installation
please order
depth member
separately
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.78
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-323
21130-324
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-327
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-327
21130-324
23130-082
21130-335
21130-334
23130-082
RAL 7035
RAL 7035
AIZn
22130-323
22130-322
23130-081
22130-325
22130-323
22130-324
22130-322
23130-082
23130-081
22130-325
22130-324
23130-082
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-333
22130-332
23130-081
22130-323
22130-325
22130-322
22130-324
23130-081
23130-082
22130-327
22130-333
22130-335
22130-332
22130-334
23130-081
23130-082
22130-323
22130-322
23130-081
22130-325
22130-327
22130-324
23130-082
22130-335
22130-334
23130-082
Interior mounting
Order Information
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
7035 (light grey)/
01004145
load-carrying
load-carrying
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
please order
please order
mounting bracket mounting bracket
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-373
21130-372
23130-274
23130-092
23130-140
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-373
21130-375
21130-372
21130-374
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
21130-353
21130-352
21130-355
21130-354
21130-375
21130-374
23130-274
23130-092
23130-140
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-373
22130-372
23130-274
23130-092
23130-140
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-373
22130-375
22130-372
22130-374
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-354
22130-375
22130-374
23130-274
23130-092
23130-140
1.79
Interior mounting
Order Information
Dimension
19'' stationary shelf, 1 U, 75 kg
Full depth
19'' telescopic shelf, 1 U, 30 kg
Full depth
Shortened by
100 mm
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Standard fitting
01004118
01004119
01004123
01004122
xf = distance from St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static
load-carrying
load-carrying
load-carrying
load-carrying
front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
W = cabinet width
separatelyy
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.80
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
SCHROFF PRODUCT CATALOG E 08/2017
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
23130-140
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-305
21130-309
21130-304
21130-345
21130-344
21130-303
21130-302
21130-343
21130-342
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
21130-305
21130-304
21130-345
21130-344
21130-309
21130-303
21130-302
21130-343
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-305
22130-309
22130-304
22130-345
22130-344
22130-303
22130-302
22130-343
22130-342
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
22130-305
22130-304
22130-345
22130-344
22130-309
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
Interior mounting
19" telescopic shelves, 2 U, 70 kg
Order Information
Dimension
Shelf, telescopic, 2 U, 70 kg
Full depth
T-bar lock
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Standard fitting
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004123
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
01004122
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-353
21130-352
21130-355
21130-354
21130-353
21130-352
21130-353
21130-353
21130-352
21130-352
21130-355
21130-354
21130-353
21130-352
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-353
22130-352
22130-355
22130-354
22130-353
22130-352
22130-353
22130-353
22130-352
22130-352
22130-355
22130-354
22130-353
22130-352
23130-092
23130-140
1.81
Interior mounting
Order Information
Dimension
Slide rail
25 kg
Short slide rail
100 kg
Depth member,
3 rows
c
D
Standard fitting
W
xf
(black grey)
01004146
7035 (light grey)/
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance from
front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn
required for
shortened shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
50
50
50
50
70
50
150
50
50
70
150
500
700
500
700
500
700
500
500
700
740
500
500
500
700
740
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
1.82
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-097
23130-098
23130-119
23130-120
23130-094
23130-094
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-081
23130-094
23130-082
23130-084
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-094
23130-082
23130-098
23130-096
23130-120
23130-118
23130-094
23130-084
23130-082
AIZn
verzinkt
AIZn
23130-096
23130-118
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-097
23130-098
23130-119
23130-120
23130-094
23130-094
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-081
23130-094
23130-082
23130-084
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-094
23130-082
23130-098
23130-096
23130-120
23130-118
23130-094
23130-084
23130-082
23130-094
23130-081
23130-082
23130-081
Interior mounting
Cable ductings
Order Information
C-rail for
cabinet depth
C-rail for
cabinet width
Cable tie
Slide nut
Velcro
General
components
Cable shell
Mechanics
(black grey)
from page
3.2
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
Cabinet dimensions
Height
No. U
mm
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
Depth
mm
mm
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
Colour combinations
17
18
19
22
23
24
25
26
27
28
29
30
31
32
29
29
33
33
38
38
38
42
42
42
42
42
47
47
47
47
1400
1400
1600
1600
1800
1800
1800
2000
2000
2000
2000
2000
2200
2200
2200
2200
600
600
600
600
600
600
800
600
600
600
800
800
600
600
600
800
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm ;
further
dimensions
see page
1.66
01005078
plastic,
92 mm x 2.5 mm;
further
dimensions
see page
1.67
01005079
black,
length 300 mm
Electrics
AlZn
Width
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
vnt009
600
800
600
800
600
800
600
600
800
1000
600
800
600
800
1000
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-086
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-333
21120-140
20114-731
20118-351
20118-624
23130-089
23130-087
23130-334
21120-140
20114-731
20118-351
20118-624
AIZn
AIZn
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-333
21120-140
20114-731
20118-351
20118-624
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-333
21120-140
20114-731
20118-351
20118-624
23130-089
23130-087
23130-334
21120-140
20114-731
20118-351
20118-624
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-086
23130-087
23130-089
23130-086
23130-087
23130-086
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
from page
3.29
Power
distribution
from page
3.50
Climate control
23130-086
23130-087
23130-089
23130-086
23130-087
23130-086
from page
4.0
1.83
VARISTAR Seism icMain Catalogue
Cabinets – VARISTAR Seismic
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01008007
Subracks/
Front panels,
01008062
Welded basic frame with strengthening brackets
01008008
Bellcore test in laboratory
Power supply
Backplanes . . . 10
Connectors, front
panel component
01008063
Seismic base with NEBS fixing
01005083
Test results
1.84
SCHROFF PRODUCT CATALOG E 07/2017
Overview . . . . . . 1.84
The earthquake-resistant cabinet
쮿 Earthquake resistance tested to Bellcore zone 4 with
a dynamic load-carrying capacity of 250 kg
쮿 Customised solutions with higher loading are available
VARISTAR
Platform . . . . . . . . 1.4
Dimensions . . . . . 1.8
쮿 Optional EMC shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz
Seismic cabinets off-the-shelf
VARISTAR Seismic
쮿 Earthquake-resistant up to Bellcore Zone 4
IP 20 . . . . . . . . . . . . 1.86
IP 55 and EMC . . . 1.87
쮿 Versions
- IP 20
- IP 55 with EMC shielding
Accessories
19" panel/slide
mount . . . . . . . . . . 1.88
19" fixing
materials kit,
M6 . . . . . . . . . . . . . 1.88
Slide rails . . . . . . . . 1.89
19" shelves . . . . . . 1.90
Depth members . . 1.93
C horizontal rails . 1.93
Cable ties,
Velcro . . . . . . . . . . . 1.95
01005018
ServicePLUS . . . 1.96
IP 20 . . . . . . . . . . . . 1.98
IP 55 . . . . . . . . . . . . 1.102
EMC . . . . . . . . . . . . . 1.106
Interior
configuration . . . . 1.110
ServicePLUS from page 1.96
VARISTAR
VARISTAR
EMC. . . . . . . . . . . .
VARISTAR
Datacom and
Networking
VARISTAR air/
water heat
1.10
1.54
1.124
1.224
30407004
1.85
VARISTAR Seismic, IP 20
VARISTA R Seis micMain CatalogueP art number in bold face type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days
쮿 Dynamic load-carrying capacity of 250 kg
쮿 Doors with 3-point locking and screw-fixed side panels
쮿 Static load-carrying capacity 800 kg (Heavy-Duty)
Item
1
Qty
1
2
3
4
1
1
1
5
6
7
8
1
2
1
2
9
1
Description
Welded basic frame, Heavy-Duty, St profile, RAL 7021,
Earthquake base, St, RAL 7021
Top cover, raised, St, RAL 7021
Front door, St, RAL 7035, 180° hinge,
3-point locking, lever handle
Rear panel, screw fixed, St, RAL 7035
Side panel, screw fixed, St, RAL 7035
Base plate, multi-piece, St, RAL 7021, open at the rear
increments
Order Information
01005018
Height
Height H
Width W
Depth D
U
mm
mm
mm
38
1900
600
800
42
2100
600
600
42
2100
600
800
Lifting eye for raised top cover PU 4 pieces
Part no.
10130-189
10130-023
10130-188
25127-995
23130-085
Note
쮿 Other dimensions and versions available on request
slide mounts is necessary, see page 1.88
Bellcore test
01005084
01005083
ServicePLUS see page 1.96
1.86
VARISTAR Seismic, IP 55 and EMC
VARISTAR Sei smic
쮿 Earthquake secure (up) to Bellcore Zone 4
Item
1
Qty
1
2
3
1
1
4
1
5
1
6
2
7
8
1
2
9
1
Description
EMC, flat top cover, flush, St, finish AlZn,
exterior RAL 7021
Front door, St, finish AlZn, powder-coated RAL 7035, 180°
Rear panel, screw fixed, St, finish AlZn, powdercoated RAL 7035
Side panel, screw fixed, St, finish AlZn, powdercoated RAL 7035
Base plate, one-piece, St, finish AlZn
19" panel/slide mount with EIA perforation, St, finish
AlZn, front mounted, depth-adjustable in 25 mm
increments
Order Information
01008030
Height
Height H
Width W
Depth D
U
mm
mm
mm
42
2100
600
800
Part no.
10130-195
25127-995
23130-072
Note
Shielding: Tested to IEC 61587-3, standard dimensions of test
01005084
[dBµV]
120
100
80
60
40
Bellcore test
01005083 01007056
200
300
400
500
600
700
800
900
1000
[MHz]
1.87
VARISTA R Seis mic
Delivery comprises
46
5
44,45
44.45
12,75
15,9
65,1
2
76
25
25
49,5
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
Order Information
9,6
42,5
Item
1
01004112
01004131
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
1400
29
1295
23130-032 23130-022
1600
33
1495
23130-033 23130-023
1800
38
1695
23130-034 23130-024
2000
42
1895
23130-035 23130-025
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
25127-997
Note
01005088
VARISTA R Seis mic
Delivery comprises
Item
1
2
3
Description
Order Information
Description
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
1.88
Slide rails
VARISTAR Sei smic
쮿 2 versions
Delivery comprises
01004056
Item
1
Qty
see Order
information
2
1
Description
Order Information
For cabinet depth D
mm
600
600
800
800
xf
mm
50
50
50
50
c
mm
500
500
700
700
Length L
mm
456
456
656
656
Qty/PU
2
10
2
10
Part no.
23130-096
23130-101
23130-097
23130-102
01005086
Order Information
For cabinet depth D
mm
600
600
800
800
Length L
mm
458
458
658
658
Qty/PU
2
10
2
10
Part no.
23130-118
23130-123
23130-119
23130-124
D
c
xf
c - 130
D = cabinet depth
c
mm
500
500
700
700
01004058
19”
xf
mm
50
50
50
50
01004130
1.89
VARISTA R Seis mic
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
c
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 642
50
700
22130-305
Strengthening rail for stationary 19" shelf, PU 1 piece
D
d
Order Information
RAL 7021
Part no.
21130-303
21130-305
23130-310
Note
xf
w
쮿 Cable ducting with cable ties, see page 1.95
쮿 Other sizes, see ServicePLUS, page 1.114
W
1.90
01004067
VARISTAR Sei smic
1
mounts
2
쮿 2 versions
– Full depth
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50 500 22130-343
800
417 x 682
50 700 22130-345
for VARISTAR
RAL 7021
Part no.
21130-343
21130-345
23130-140
Note
xf
d
Full depth
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50 500 22130-342
800
417 x 582
50 700 22130-344
for VARISTAR
RAL 7021
Part no.
21130-342
21130-344
23130-140
Note
D
c
xr
w
xf
d
01004070
1.91
VARISTA R Seis mic
1
2
mounts
4
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 682
50 700 22130-355
for VARISTAR
xf
d
Order Information
01004069
Shortened depth
RAL 7021
Part no.
21130-353
21130-355
23130-092
23130-140
Note
W
w
xr
Order Information
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 582
50 700 22130-354
for VARISTAR
d
c
Shortened by 100 mm
RAL 7021
Part no.
21130-352
21130-354
23130-092
23130-140
Note
xf
1.92
01004070
Depth member
VARISTAR Sei smic
쮿 For fitting shortened 19" panel/slide mounts and mounting
plates
50
Delivery comprises
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
Item
1
2
Qty
2
1
Description
Order Information
L
0100412601004079
For cabinet depth
Length L
mm
mm
600
460
800
660
Part no.
23130-081
23130-082
21101-151
21101-150
coa43697
Cable eye
VARISTAR Sei smic
Delivery comprises
Item
1
2
Qty
2
1
Description
Order Information
01004129
Slide nut
31,5
,5 x
Ø6
15
50
11
L
50
Part no.
23130-086
23130-087
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
29,5
L-
For cabinet depth
Length L
mm
mm
600
460
800
660
Accessories
Cable retention rail for C-rail width 75 mm,
쮿 Cable ties and Velcro for cable retention rail see page 1.95
75
01504054
C-profile
01004132
01006071
Part number in bold face type: ready for despatch within 2 working days
1.93
Delivery comprises
Item
1
2
Qty
2
1
Description
Order Information
01006063
C-profile
Slide nut
For cabinet width
Length
mm
mm
600
550
Accessories
Part no.
23130-333
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
1.94
01006064
01504054
Cabinet accessories – VARISTAR Seismic
Cable ties, Velcro
VARISTAR Sei smicMain C ataloguePart number in bold face type: ready for des patch within 2 working daysP art number in normal type: ready for despatch within 10 working days
Order Information
Description
Cable tie, plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, plastic, 360 mm x 5 mm, PU 25 pieces
Cable tie
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
VARISTAR EMC
VARISTAR Sei smic ServiceP LUS
1.95
Cabinets – VARISTAR Seismic ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined freely
쮿 Configuration tables from page 1.98
assembly
쮿 Without supplement
modification
for off-the-shelf products
쮿 Download CAD data, modify and send back
solution
Simple. Fast. From one source.
쮿 Climate control, complete construction, cabling
(power supply), function testing
쮿 Ready to despatch within 10 working days
쮿 Special sizes, custom solutions
academy
user reports
1.96
lifecycle
lifecycle
쮿 Delivery to point of use, set-up service, replacement service,
spare parts
VARISTAR Seismic IP 20, IP 50, EMC ServicePLUS: Configuration
Main C atalogue
Page
쮿 Dimensions in catalogue:
– Depth: 600 and 800 mm
Seismic IP 20
Frames, side-by-side
mounting kits, base/plinth
Side panels, rear panels,
doors, top covers
Base plates, brush strips,
filter inserts
쮿 Other dimensions and configurations, sorted by IP 20, IP 55
and EMC online at www.schroff.biz/conf
1.98
1.99
1.100
1.101
Seismic IP 55
Frames, gasketing kits,
kits, base/plinth
doors, top covers
1.102
1.103
Base plates, gasketing
1.104
1.105
Seismic EMC
kits, base/plinth
doors, top covers
1.106
1.107
Base plates
1.108
1.109
Swing frames
1.110
1.111
Mounting plates,
stationary shelves, 75 kg
19" shelves 1 U, stationary
75 kg, telescopic 30 kg
2 U, 70 kg
Slide rails, depth
members
01004077
Example configuration (here: row 12)
Qty
1
1
1
1
1
Description
Frame heavy duty, St profile, with strengthening brackets, height
Side panel, screw fixed, RAL 7021, PU 2 pieces
Rear panel, screw-fixed, RAL 7021, 1 piece
Steel door with 3-point locking, RAL 7021, IP 55, 1 piece
Base/plinth, 1 piece
1.112
1.113
1.114
1.115
1.116
Cable ductings
1.117
Cable ties, Velcro
1.118
ServicePLUS: solution project examples
1.119
Order no.
20130-630/05
21130-011/05
21130-069/05
21130-159/05
23130-455/05
1.97
Seismic IP 20
Frames, side-by-side mounting kits, base/plinth
Seismic frame
Heavy-Duty
800 kg
Side-by-side
mounting kit
IP 20
104,5
Completely in RAL 7021
(black grey)
Base/plinth
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004117
01009062
2 support
side-by-side
St, 1.5 mm, zincmounting bracket profiles, St, 4 mm,
plated, with
lateral; 2 trims,
(4 pieces), St;
8 reinforcing
brackets, central RAL 7021, not in St, 4 mm, front/
rear;
combination with
GND/earthing
point, static load- decorative frame height 104.5 mm;
carrying capacity
800 kg
1000 kg
1 piece
PU 1 kit
1 piece
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-061
23130-454
23130-455
20130-636
23130-061
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-061
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-061
23130-454
23130-455
20130-636
23130-061
23130-457
Further dimensions and configurations online at www.schroff.biz/conf
1.98
Seismic IP 20
Side panels, rear panels, doors, top covers
Screw-fixed
side panel
Screw-fixed
rear panel
Steel door
3-point locking
DIN profile half
cylinder
Plain flush top cover
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01008085
01004148
for lever handle,
St, 1.5 mm,
common locking
opening angle
180°,
inner side with
mounting frame,
lever handle with
built-in push
button, incl. GND/
earthing
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
21130-003
RAL 7021
RAL 7021
21130-242
21130-063
21130-153
25127-995
21130-065
21130-155
25127-995
21130-066
21130-156
25127-995
21130-067
21130-157
25127-995
21130-068
21130-158
25127-995
21130-069
21130-159
25127-995
21130-070
21130-160
25127-995
21130-015
21130-016
21130-071
21130-161
25127-995
21130-242
21130-243
23130-072
21130-016
21130-072
21130-162
25127-995
21130-247
23130-072
RAL 7035
RAL 7035
RAL 7035
21130-004
21130-005
21130-006
21130-005
21130-006
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-010
21130-011
22130-003
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-242
22130-063
22130-153
25127-995
22130-065
22130-155
25127-995
22130-066
22130-156
25127-995
22130-067
22130-157
25127-995
22130-068
22130-158
25127-995
22130-069
22130-159
25127-995
22130-070
22130-160
25127-995
22130-015
22130-016
22130-071
22130-161
25127-995
21130-242
21130-243
23130-072
22130-016
22130-072
22130-162
25127-995
21130-247
23130-072
22130-004
22130-005
22130-006
22130-005
22130-006
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-010
22130-011
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.99
Seismic IP 20
Base plates, brush strips, filter inserts
Base plate
Base plate, multipiece
Brush strip
Dust filter set
Cover plate
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U mm
Width
mm
Depth
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.100
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004105
01004059
01004106
nylon, black
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
23130-001
23130-002
23130-074
23130-075
23130-076
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
Dimension
drawings see
page 1.9
1 piece
RAL 7021
RAL 7021
RAL 7021
23130-001
23130-002
23130-074
23130-075
23130-076
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-074
23130-075
23130-076
23130-034
23130-035
23130-036
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
RAL 7021
Seismic IP 20
Dimensioning
connecting plate
door/rear panel
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
01004066 01004056
e.g.
only required if
stationary shelves,
rear panel
19" shelves,
is assembled
slide rails,
above the
cable ducting
connecting plate
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
RAL 7021
RAL 7021
21130-472
21130-473
21130-478
21130-479
23130-164
23130-164
from page
1.110
from page
1.110
RAL 7035
RAL 7035
22130-472
22130-478
23130-164
22130-473
22130-479
23130-164
1.101
Seismic IP 55
Frames, gasketing kits, side-by-side mounting kits, base/plinth
Seismic frame
Heavy-Duty
800 kg
Gasketing kit
IP 55
Base/plinth
Side-by-side
mounting kit
IP 55
(with gasket)
104,5
(black grey)
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004157
01004117
01009062
2 support
side-by-side
St, 1.5 mm, zinc- seals are glued to
the frame, so that mounting bracket profiles, St, 4 mm,
plated, with
lateral; 2 trims,
(4 pieces), St,
8 strengthening all cladding parts
St, 4 mm, front/
RAL 7021, incl.
conform to
brackets, central
rear;
gasket to cover
protection type
GND/earthing
the gap between height 104.5 mm;
IP 55
point, static loadstatic loadtwo racks; not in
carrying capacity
combination with carrying capacity
800 kg
1000 kg
decorative frame
1 piece
PU 1 kit
PU 1 kit
1 piece
assembled
assembled
supplied loose
assembled
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-064
23130-062
23130-454
23130-455
20130-636
23130-064
23130-062
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-064
23130-062
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-064
23130-062
23130-454
23130-455
20130-636
23130-064
23130-062
23130-457
1.102
Seismic IP 55
Screw-fixed
side panel
Screw-fixed
rear panel
Steel door
3-point locking
DIN profile half
cylinder
Flat top cover
Lifting eye
(black grey)
M12
01004083
St, 1 mm, incl.
GND/earthing
01004085
St, 1 mm, incl.
GND/earthing
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01008085
01004148
for lever handle,
St, 1.5 mm,
common locking
opening angle
180°,
inner side with
mounting frame,
lever handle with
built-in push
button, incl. GND/
earthing
01004096
01004100
St, 1.5 mm, incl.
GND/earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
21130-003
RAL 7021
RAL 7021
21130-242
21130-063
21130-153
25127-995
21130-065
21130-155
25127-995
21130-066
21130-156
25127-995
21130-067
21130-157
25127-995
21130-068
21130-158
25127-995
21130-069
21130-159
25127-995
21130-070
21130-160
25127-995
21130-015
21130-016
21130-071
21130-161
25127-995
21130-242
21130-243
23130-072
21130-016
21130-072
21130-162
25127-995
21130-247
23130-072
RAL 7035
RAL 7035
RAL 7035
21130-004
21130-005
21130-006
21130-005
21130-006
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-010
21130-011
22130-003
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-242
22130-063
22130-153
25127-995
22130-065
22130-155
25127-995
22130-066
22130-156
25127-995
22130-067
22130-157
25127-995
22130-068
22130-158
25127-995
22130-069
22130-159
25127-995
22130-070
22130-160
25127-995
22130-015
22130-016
22130-071
22130-161
25127-995
21130-242
21130-243
23130-072
22130-016
22130-072
22130-162
25127-995
21130-247
23130-072
22130-004
22130-005
22130-006
22130-005
22130-006
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-010
22130-011
21130-243
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.103
Seismic IP 55
Base plate
Cover plate
IP 55 gasket
Base plate,
one-piece,
EMC, IP 55
(black grey)
01004104
7035 (light grey)/
Cabinet dimensions
Height
No. U mm
Width
mm
Depth
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.104
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004106
01004073
for base plate
with cover
01004051
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing ;
Dimension
drawings see
page 1.9
1 piece
St, 1.5 mm,
please order
IP55 gasket
separately
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
AlZn
23130-076
23130-073
21130-281
21130-282
23130-076
23130-073
23130-036
23130-073
23130-001
23130-002
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
RAL 7021
23130-001
23130-002
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-006
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-284
RAL 7021
AlZn
23130-076
23130-073
21130-281
21130-282
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
23130-076
23130-073
23130-036
23130-073
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-283
21130-284
21130-281
21130-282
21130-284
Seismic IP 55
Dimensioning
connecting plate
door/rear panel
Connecting plate
Other VARISTAR
interior mounting
parts
(black grey)
01005071
7035 (light grey)/
Height Width
mm
mm
400
400
600
800
Colour combinations
400
400
600
800
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005072
01004066 01004056
e.g.
St, 1 mm,
can also be fitted stationary shelves,
19" shelves,
in upper part,
slide rails,
height 400 mm,
cable ducting
with assembly kit
1 piece
assembled
RAL 7021
21130-504
21130-505
from page
1.110
RAL 7035
22130-504
22130-505
from page
1.110
1.105
Seismic EMC
Seismic frame
EMC gasketing kit
Heavy-Duty
800 kg
Side-by-side
mounting kit
EMC
104,5
(black grey)
Base/plinth
D
W
01009060
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004157
St, 1.5 mm, zinc- gaskets are glued
to the frame,
plated, with
thus all the
8 strengthening
brackets, central following cover
parts are
GND/earthing
conductively
point, static loadlinked
carrying capacity
800 kg
01004120
side-by-side
mounting
brackets
(4 pieces), St
01009062
2 support
profiles, St, 4 mm,
lateral; 2 trims,
St, 4 mm, front/
rear;
height 104.5 mm;
static loadcarrying capacity
1000 kg
1 piece
PU 1 kit
PU 1 kit
1 piece
assembled
assembled
supplied loose
assembled
RAL 7021
20130-617
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
20130-633
20130-634
20130-636
RAL 7021
RAL 7021
23130-065
23130-063
23130-454
23130-455
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-457
RAL 7021
RAL 7021
20130-617
23130-454
20130-618
20130-621
20130-622
20130-623
20130-624
20130-625
20130-626
20130-627
20130-628
20130-629
20130-630
20130-631
20130-632
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-065
23130-063
23130-455
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
23130-454
23130-455
23130-456
23130-457
20130-633
20130-634
23130-065
23130-063
23130-454
23130-455
20130-636
23130-065
23130-063
23130-457
1.106
Seismic EMC
Side panel,
Rear panel,
Steel door, 4-point locking
screw fixed, EMC, screw fixed, EMC, Plain, EMC, IP 55 Perforated, EMC DIN profile half
IP 55
IP 55
cylinder
Flat top cover
EMC, IP 55
Lifting eye
(black grey)
M12
01004083
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004085
St, 1 mm,
painted outside,
AlZn inside,
incl. GND/
earthing
01004092
01004093
St, 1.5 mm,
St, 1.5 mm,
painted outside, painted outside,
interior AlZn,
interior AlZn,
opening angle
opening angle
180°,
180°,
lever handle with lever handle with
push button, incl. push button, incl.
GND/earthing
GND/earthing
01004148
for lever handle,
common locking
01004096
01004090
St, 1.5 mm,
exterior painted,
interior AlZn,
incl. GND/
earthing
for top cover,
applications
and load in
accordance with
DIN 582
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
PU 4 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
RAL 7021
RAL 7021
RAL 7021
RAL 7021
21130-023
21130-024
21130-078
21130-168
21130-198
25127-995
21130-080
21130-170
21130-200
25127-995
21130-081
21130-171
21130-201
25127-995
21130-082
21130-172
21130-202
25127-995
21130-083
21130-173
21130-203
25127-995
21130-084
21130-174
21130-204
25127-995
21130-085
21130-175
21130-205
25127-995
21130-086
21130-176
21130-206
25127-995
21130-087
21130-177
21130-207
25127-995
21130-025
21130-026
21130-025
21130-026
21130-027
21130-028
21130-027
21130-028
21130-030
21130-031
21130-030
21130-031
21130-035
21130-036
21130-036
RAL 7035
22130-023
RAL 7035
RAL 7021
RAL 7035
21130-272
21130-273
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-277
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
RAL 7021
21130-272
22130-078
22130-168
21130-198
25127-995
22130-080
22130-170
21130-200
25127-995
22130-081
22130-171
21130-201
25127-995
22130-082
22130-172
21130-202
25127-995
22130-083
22130-173
21130-203
25127-995
22130-084
22130-174
21130-204
25127-995
22130-085
22130-175
21130-205
25127-995
22130-035
22130-036
22130-086
22130-176
21130-206
25127-995
21130-272
21130-273
23130-072
22130-036
22130-087
22130-177
21130-207
25127-995
21130-277
23130-072
22130-024
22130-025
22130-026
22130-025
22130-026
22130-027
22130-028
22130-027
22130-028
22130-030
22130-031
22130-030
22130-031
21130-273
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
21130-272
21130-273
21130-276
21130-277
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
23130-072
1.107
Seismic EMC
Base plates
Base plates
one-piece,
EMC, IP 55
with cable
ducting, EMC
perforated, with
cable ducting,
EMC
(black grey)
01004051
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.108
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
AlZn, 1.5 mm,
incl. GND/
earthing,
assembly from
outside
01004108
AlZn, 1.5 mm,
rear opening
60 mm deep,
incl. GND/
earthing,
assembly from
outside
01008051
AlZn, 1.5 mm,
incl. GND/
earthing;
opening at rear
for cabinet width
of 600 mm:
359 x 60 mm,
for cabinet width
of 800 mm:
559 x 60 mm
1 piece
1 piece
1 piece
assembled
assembled
assembled
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-283
21130-284
21130-293
21130-294
23130-402
23130-403
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-284
21130-294
23130-403
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-284
21130-294
23130-403
AlZn
AlZn
AlZn
21130-281
21130-291
23130-400
21130-282
21130-292
23130-401
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-283
21130-293
23130-402
21130-284
21130-281
21130-294
21130-291
23130-403
23130-400
21130-282
21130-292
23130-401
21130-283
21130-284
21130-293
21130-294
23130-402
23130-403
21130-281
21130-291
23130-400
21130-282
21130-283
21130-292
21130-293
23130-401
23130-402
21130-284
21130-294
23130-403
21130-281
21130-282
21130-291
21130-292
23130-400
23130-401
21130-284
21130-294
23130-403
ELECTRONICS PROTECTION
Seismic EMC
Dimensioning
connecting plate
door/rear panel
Flat plate,
EMC, IP 55
Shortened plate,
EMC, IP 55
Other VARISTAR
interior mounting
parts
(black grey)
01005077
7035 (light grey)/
Cabinet dimensions
Height
Width Depth
No. U mm mm
mm
400
400
600
800
Colour combinations
400
400
600
800
SCHROFF.PENTAIR.CO.UK
door and rear
panel must be
selected 400 mm
shorter than
cabinet height
01005075
flat plate,
stainless steel,
1 mm,
height 400 mm,
mounting can be
at top or bottom
01005074
01004066 01004056
e.g.
frame,
stainless steel, stationary shelves,
19" shelves,
1 mm,
slide rails,
mounting at top
cable ducting
or bottom,
height 400 mm,
plate recessed by
40 mm,
stainless steel,
1 mm
1 piece
1 piece
assembled
assembled
RAL 7021
RAL 7021
21130-578
21130-580
21130-579
21130-581
RAL 7035
RAL 7035
22130-578
22130-580
22130-579
22130-581
from page
1.110
from page
1.110
1.109
Interior mounting
Swing frames for cabinet width 600 mm
Order Information
Swing frame
Stop 120°
Safety lock
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
Spare key
01005061
01015060
St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg,
120° hinge, square locks
incl. 2 keys
(Dimension drawings link)
St; for safety reasons a swing
frame stop is recommended
for swing frame, instead of
square lock, incl. 2 keys
01015059
Usable
height
U
Width
mm
1 piece
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
supplied loose
12
600
21130-740
23130-158
60113-267
60220-003
21
600
21130-741
23130-158
60113-267
60220-003
25
30
34
39
43
600
600
600
600
600
21130-742
23130-158
60113-267
60220-003
21130-743
21130-744
23130-158
23130-158
60113-267
60113-267
60220-003
60220-003
21130-745
23130-158
60113-267
60220-003
21130-746
23130-158
60113-267
60220-003
Interior mounting
Swing frames for cabinet width 800 mm
Order Information
Swing frame 120°
Swing frame 120°
Swing frame 160°
Stop 120°
Swing frame 160°
Swing frame trim
Stop 160°
Asymmetrical
assembly
1
1
2
2
100
200
01005070
Height
U
partial
height
partial
height
29
33
38
42
47
1.110
Width
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
(Dimension
drawings link)
01005061
01005070
01005061
Safety lock
Symmetrical
assembly
100
01005058
01005057
01015060
St; for safety
reasons a swing
frame stop is
recommended
St, 2 mm,
capacity 150 kg,
160° hinge,
square
locks incl. 2 keys
St, swing frame
stop is
recommended
for safety
reasons
St, 1.5 mm,
RAL 7021,
trim (item 1,
width 200 mm)
incl. handle
(item 2) and cutout for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
for swing frame,
instead of
square lock,
incl. 2 keys
Usable
height
U
mm
assembled
PU 1 kit
assembled
PU 2 pieces
assembled
PU 1 kit
assembled
1 piece
assembled
PU 2 pieces
assembled
1 piece
assembled
12
800
21130-747
23130-158
21130-761
23130-159
60113-267
21
800
21130-748
23130-158
21130-762
23130-159
21130-432
21130-442
60113-267
25
30
34
39
43
800
800
800
800
800
21130-749
21130-750
23130-158
23130-158
21130-763
21130-764
23130-159
23130-159
21130-433
21130-434
21130-443
21130-444
60113-267
60113-267
21130-751
23130-158
21130-765
23130-159
21130-435
21130-445
60113-267
21130-752
21130-753
23130-158
23130-158
21130-766
21130-767
23130-159
23130-159
21130-436
21130-437
21130-446
21130-447
60113-267
60113-267
Interior mounting
19" panel/slide mounts EIA
Painted RAL 7021
19" assembly kit
M6
Adapter
bracket for
reduced width
W
xf
(black grey)
01004146
7035 (light grey)/
U height
identification
for 19" panel/
slide mount
AIZn
c
D
Dimension
Standard fitting
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
01004112
St, 1.75 mm;
reduced-width adapter bracket
required for 800 mm width;
depth members are required for
partial-height mounting
00505050
sc128
paper strip, white,
assembly kit:
serial numbered item 1: screws,
from 1 ... 47 U
item 2: cage nuts,
item 3: washers
01004128
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 1 pair
PU 1 pair
PU 4 pieces
PU 50 pieces
PU 4 pieces
assembled
assembled
assembled
supplied loose
assembled
RAL 7021
AIZn
23130-012
23130-032
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-013
23130-033
25127-997
21101-809
23130-091
23130-014
23130-034
25127-997
21101-809
23130-014
23130-034
25127-997
21101-809
23130-091
23130-015
23130-035
25127-997
21101-809
23130-015
23130-035
25127-997
21101-809
23130-091
23130-016
23130-036
25127-997
21101-809
23130-016
23130-036
25127-997
21101-809
23130-091
RAL 7035
AlZn
23130-022
23130-032
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-023
23130-033
25127-997
21101-809
23130-091
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-091
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-091
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-091
AIZn
Part number in normal type: ready for despatch within 10 working days
1.111
Interior mounting
Mounting plates, stationary shelves, 75 kg
Mounting plate
Full height
Height 1200 mm
Strengthening
brackets
Stationary shelf
Full depth
Stationary shelf
Shortened by 100
mm
Depth member,
3 rows
(black grey)
01008052
7035 (light grey)/
01008053
St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear
mounted); strengthening bracket
increases static load-carrying
capacity; please order separately
01008080
St profile,
increases static
load-carrying
capacity of
mounting plate
to 150 kg
01004142
01004142
load-carrying
load-carrying
cap. 75 kg, 1 U,
capacity 75 kg,
depth 479 mm,
1 U, incl. GND/
incl. GND/
earthing
earthing,
for recessed
installation order
depth members
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.112
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
PU 2 pieces
1 piece
1 piece
PU 1 pair
assembled
assembled
assembled
assembled
assembled
assembled
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
RAL 7021
RAL 7021
AIZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-335
21130-323
21130-334
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
21130-335
21130-334
23130-082
21130-322
21130-324
23130-081
23130-082
21130-334
23130-082
23130-413
23130-418
21130-323
21130-325
23130-414
23130-418
21130-335
zinc-plated
zinc-plated
RAL 7021
23130-413
23130-418
23130-413
23130-418
23130-414
23130-418
23130-405
23130-413
23130-418
23130-406
23130-414
23130-418
23130-407
23130-413
23130-418
23130-408
23130-414
23130-418
RAL 7035
RAL 7035
AlZn
21130-323
21130-322
23130-081
21130-325
21130-324
23130-082
21130-323
21130-325
21130-322
21130-324
23130-081
23130-082
21130-333
21130-332
23130-081
21130-335
21130-323
21130-334
21130-322
23130-082
23130-081
21130-325
21130-324
23130-082
21130-333
21130-335
21130-332
21130-334
23130-081
23130-082
21130-323
21130-322
23130-081
21130-325
21130-333
21130-324
21130-332
23130-082
23130-081
21130-335
21130-334
23130-082
21130-322
21130-324
23130-081
23130-082
21130-334
23130-082
23130-413
23130-418
21130-323
21130-325
23130-414
23130-418
21130-335
Interior mounting
Telescopic shelves, 70 kg
Telescopic shelf, 2 U
Full depth
Shortened by 100
mm
Mounting
bracket
T-bar lock
GND/earthing
(black grey)
01004144
Colour combination RAL
7035 (light grey)/
RAL 7021 (black grey)
01004145
load-carrying
load-carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
separately
separately
01005054
St, finish AlZn
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
PU 4 pieces
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
AIZn
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
RAL 7021
RAL 7021
21130-353
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-373
21130-372
21130-375
21130-353
21130-374
21130-352
21130-355
21130-354
21130-373
21130-375
21130-372
21130-374
21130-353
21130-352
21130-355
21130-373
21130-354
21130-372
21130-375
21130-374
21130-353
21130-355
21130-352
21130-354
23130-274
23130-092
23130-140
21130-375
21130-374
23130-274
23130-092
23130-140
AlZn
RAL 7035
RAL 7035
22130-353
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
22130-373
22130-372
22130-375
22130-353
22130-374
22130-352
22130-355
22130-354
22130-373
22130-375
22130-372
22130-374
RAL 7021
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
22130-353
22130-352
22130-355
22130-373
22130-354
22130-372
22130-375
22130-374
22130-353
22130-355
22130-352
22130-354
23130-274
23130-092
23130-140
22130-375
22130-374
23130-274
23130-092
23130-140
1.113
Interior mounting
19" shelves 1 U, stationary 75 kg, telescopic 30 kg
Full depth
Full depth
Shortened by
100 mm
GND/earthing
W
xf
(black grey)
01004146
7035 (light grey)/
Shortened by
100 mm
c
D
Dimension
Standard fitting
01004118
01004119
01004123
01004122
xf = distance
load-carrying
load-carrying
load-carrying
load-carrying
from front
capacity 30 kg,
capacity 30 kg,
capacity 75 kg,
capacity 75 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
depth 500 mm,
depth 600 mm,
panel/slide
slide;
slide;
incl. GND/
incl. GND/
mounts
please order
please order
earthing
earthing
D = cabinet depth
GND/earthing kit GND/earthing kit
W = cabinet width
separately
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
RAL 7021
RAL 7021
RAL 7021
RAL 7021
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
21130-303
21130-302
21130-343
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
RAL 7035
RAL 7035
RAL 7035
RAL 7035
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
22130-303
22130-302
22130-343
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.114
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
21130-303
21130-302
21130-343
21130-342
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
21130-305
21130-304
21130-345
21130-344
21130-303
21130-303
21130-302
21130-302
21130-343
21130-343
21130-342
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
21130-303
21130-302
21130-343
21130-342
21130-305
21130-303
21130-304
21130-302
21130-345
21130-343
21130-344
21130-342
21130-303
21130-302
21130-343
21130-342
21130-303
21130-305
21130-302
21130-304
21130-343
21130-345
21130-342
21130-344
23130-140
21130-303
21130-302
21130-343
21130-342
23130-140
22130-303
22130-302
22130-343
22130-342
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
22130-305
22130-304
22130-345
22130-344
22130-303
22130-303
22130-302
22130-302
22130-343
22130-343
22130-342
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
22130-303
22130-302
22130-343
22130-342
22130-305
22130-303
22130-304
22130-302
22130-345
22130-343
22130-344
22130-342
22130-303
22130-302
22130-343
22130-342
22130-303
22130-305
22130-302
22130-304
22130-343
22130-345
22130-342
22130-344
23130-140
22130-303
22130-302
22130-343
22130-342
23130-140
23130-140
23130-140
Interior mounting
W
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
01004123
GND/earthing
01004122
01004125
05904052
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 400 mm,
depth 682 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
1 piece
to lock the
telescopic shelf
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
c
mm
RAL 7021
RAL 7021
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
21130-353
21130-355
21130-352
21130-354
RAL 7035
RAL 7035
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
22130-353
22130-355
22130-352
22130-354
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
T-bar lock
St, 1.5 mm,
RAL 7021, static
load-carrying
capacity 70 kg,
width 417 mm,
depth 482 mm,
incl. telescopic
slide, please
order T-bar lock
and earthing kit
separately
1 piece
xf
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Shortened by
100 mm
xf
(black grey)
7035 (light grey)/
Telescopic shelf, 2 U, 70 kg
Full depth
c
D
Dimension
Standard fitting
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
21130-355
21130-354
21130-353
21130-355
21130-352
21130-354
21130-353
21130-352
21130-355
21130-353
21130-354
21130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-355
22130-352
22130-354
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
22130-355
22130-354
22130-353
22130-353
22130-352
22130-352
22130-353
22130-352
22130-355
22130-353
22130-354
22130-352
for telescopic
shelf
1.115
Interior mounting
Slide rails, depth members
Slide rail
25 kg
Depth member,
3 rows
W
xf
(black grey)
01004146
7035 (light grey)/
Short slide rail
100 kg
c
D
Dimension
Standard fitting
01004115
01004154
St, 1.5 mm,
St, 2.5 mm,
St, 1.5 mm,
xf = distance
finish AlZn, static zinc-plated, static finish AlZn, static
from front
load-carrying
load-carrying
load-carrying
c = pitch of 19"
capacity 15 kg/
capacity 100 kg/
capacity 25 kg/
panel/slide
pair
pair
pair
mounts
D = cabinet depth
W = cabinet width
01004126
length 460 mm,
St, 1.5 mm,
finish AlZn;
required for
recessed shelf
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
xf
mm
c
mm
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
50
50
50
50
50
150
50
50
50
150
50
50
50
150
50
50
150
500
700
500
700
500
500
500
700
500
500
500
700
500
500
500
700
500
23130-097
23130-119
23130-096
23130-097
23130-118
23130-119
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1.116
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 pair
supplied loose
supplied loose
supplied loose
assembled
AIZn
zinc-plated
AIZn
23130-096
23130-118
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-094
23130-094
23130-094
23130-094
AIZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
AlZn
zinc-plated
AlZn
23130-096
23130-118
23130-096
23130-118
23130-096
23130-096
23130-118
23130-118
23130-097
23130-119
23130-096
23130-096
23130-118
23130-118
23130-094
23130-094
23130-094
23130-094
23130-094
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
AlZn
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-096
23130-118
23130-097
23130-096
23130-119
23130-118
23130-096
23130-118
23130-096
23130-097
23130-118
23130-119
23130-094
23130-081
23130-082
23130-096
23130-118
23130-094
23130-082
23130-094
23130-094
23130-081
23130-082
23130-081
23130-082
Interior mounting
Cable ductings
Cable ducting with C-profile
C-rail for
cabinet depth
C-rail for
cabinet width
Slide nut
Cable shell
Cable support for
C-rail
(black grey)
01006109
St, 1.5 mm,
finish AlZn
01006107
St, 1.5 mm,
finish AlZn
01504054
for C-rail
7035 (light grey)/
vnt009
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.93
01006110
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
PU 2 pieces
PU 2 pieces
PU 10 pieces
PU 10 pieces
PU 5 pieces
supplied loose
supplied loose
supplied loose
supplied loose
supplied loose
AIZn
AIZn
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-333
21120-140
20114-731
60118-472
23130-087
23130-334
21120-140
20114-731
60118-472
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-087
AlZn
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
AlZn
1.117
Interior mounting
Cable ties, Velcro
Cable tie
Velcro
General
components
Mechanics
(black grey)
from page
3.2
01005078
7035 (light grey)/
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.95
01005079
black,
length 300 mm,
further
dimensions
see page
1.95
Electrics
Cabinet dimensions
Height
No. U
mm
Width
Depth
mm
mm
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
Colour combinations
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
1.118
29
29
33
33
33
33
38
38
38
38
42
42
42
42
47
47
47
1400
1400
1600
1600
1600
1600
1800
1800
1800
1800
2000
2000
2000
2000
2200
2200
2200
600
600
600
600
800
800
600
600
800
800
600
600
800
800
600
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
600
800
800
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
AlZn
AlZn
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.29
Power
distribution
from page
3.50
Climate control
from page
4.0
ServicePLUS: solution - project examples
Mobile communications technology
쮿 Slim-Line seismic cabinet with ETSI configuration
쮿 NEBS base mounting
쮿 Dynamic loading: 350 kg
쮿 Shielded version (EMC)
쮿 Complete cabling
쮿 Power distribution
쮿 Special cable entry in top cover
쮿 Doors and side panels with ventilation openings
5430301007023
1.119
VARISTAR MILMain Catalogue
Cabinets – VARISTAR MIL
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
01012005
01010017 01010069
Economic and uncompromising - a tailored standard
Schroff offers robust 19" cabinets that meet the specifications of
MIL-S-901D. Their characteristics allow you to meet the most
stringent shock and vibration resistance requirements on the
high seas:
This cabinet was developed on the basis of the VARISTAR platform
and impresses with its high integration capability.
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
쮿 High-performance elastomer or wire cable shock absorbers
for COTS (commercial off-the-shelf) equipment
쮿 19" standard, in accordance with RoHS
쮿 Various dimensions available (height and depth)
Systems . . . . . . . 8
쮿 Wide range of accessories available
쮿 Reduced development and manufacturing costs
쮿 HF shielding
01010068
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
From the qualification ... to the customer solution
A cabinet for your individual requirements can be quickly and
easily developed. It can be validated by numerical simulation
thereby saving lengthy and expensive tests in laboratory. The
elastic suspension is specially adapted to the mechanical
environment and the resilience of the components. At the same
time, the dimensions and weight of the cabinet are tailored to your
specific integration requirements. The design is validated using a
model that has been calibrated in real tests using a finite element
calculation.
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.120
01010070
Finite element model - mesh and stress
analysis
SCHROFF Further information: www.varistar.de E 05/2016
Overview . . . . . . 1.120
VARISTAR MILMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days
The cabinet for the most demanding situations
쮿 Certified: Tested to MIL 901D
쮿 Capable of handling extreme stresses: Robust and secure for mobile use; dynamic loadcarrying capacity of 150 kg
쮿 Reliable: Shielded against high-frequency interference
쮿 Not susceptible: Type of protection IP 55
VARISTAR with shock absorbers
쮿 Two versions:
4 shock absorbers at bottom and 2 at top, for wall mounting
– With wire cable shock absorbers
– with elastomer shock absorbers
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
VARISTAR MIL
VARISTAR
MIL 901D . . . . . . . . 1.122
쮿 Height 38 U (1800 mm), width 600 mm, depth 800 mm
01012002
ServicePLUS . . . 1.123
ServicePLUS from page 1.123
e.g. special colours
e.g. other cabinet dimensions
e.g. higher dynamic load carrying capacity
e.g. custom solutions
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . 1.54
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR Air/
water heat
exchanger . . . . . . 1.224
www.schroff.biz/ServicePLUS
30407004
1.121
MIL 901D cabinets
VARISTA R MILMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Cabinet for extreme mobile situations
쮿 4 shock absorbers at bottom and 2 shock absorbers at top
쮿 Ingress protection IP 55
쮿 EMC protection
쮿 Tested to MIL-STD-901D
쮿 Rear panel horizontally partitioned for fitting of e.g. cable
ducting
Delivery comprises (assembled)
Wire cable shock absorbers
01011001
Elastomer shock absorbers
01012004
Item
1
Qty
1
2
3
1
1
4
1
5
6
7
8
1
1
2
4
9
1
Description
Welded basic frame, heavy duty, St profile, RAL 7032,
with reinforcement brackets welded on floor frame,
10 mm, St, finish AlZn;
base plate, St; 4 shock absorbers; EMC gasket
Flat top cover, flush, St, finish AlZn, exterior RAL 7032
Front door, St, finish AlZn, RAL 7032, 180° hinge,
4-point locking, lever handle
Rear panel, top, screw fixed, St, finish AlZn, RAL 7032;
2 shock absorbers;
Rear panel, centre, screw fixed, St, finish AlZn, RAL 7032
Rear panel, bottom, screw fixed, St, finish AlZn, RAL 7032
Side panel, screw fixed, St, AlZn, RAL 7032
19" panel/slide mount with EIA perforation,
St, finish AlZn, depth-adjustable in 25 mm increments
GND/earthing kit, assembled
Order Information
Height
U
mm
Width
mm
Depth
mm
38
1800
600
800
38
1800
600
800
01011003
Description
absorbers
absorbers
Part no.
10130-198
10130-201
Note
쮿 Other dimensions and versions on request
Rear view
1.122
SCHROFF Main catalogue
01012003
www.schroff.biz E 05/2016
solution
Integration and custom developments
cabling (power supply), function test
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports,
user reports
쮿 Further information: www.varistar.co.uk
lifecycle
We are with you. For the entire product life. the product.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
Mobile applications for marine use
쮿 Heavy-Duty seismic cabinet with shock absorbers for use on
ships
쮿 Special connection plate for shielded cable entry
쮿 Integrated air filtered fan in the door
쮿 Customer-specific testing (vibration, EMC, climate)
32403011
01008022
1.123
Varistar Datacom /NetworkingMain Catalogue
Cabinets – Varistar Datacom/Networking
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01006049
Subracks/
Front panels,
01006023
Professional cable management
01006033
Robust pull-out tilt protection
Power supply
01006084
Universal mounting possibility: With a
mounting space of 740 mm between
front and rear 19" plane in the standard
version, around 90 % of all server types
can be fitted immediately.
Easy installation of servers with special
dimensions by additional partial-height
mounting and further 19" brackets.
Backplanes . . . 10
Connectors, front
panel component
01006024
Large variety of accessories for all
cabling zones
01006032
Heavy load shelves and slide rails
1.124
SCHROFF PRODUCT CATALOG E 05/2016
Cabinets – VARISTAR Datacom/Networking
Overview . . . . . 1.124
VARISTAR Datacom /NetworkingMain Catalogue
Made for datacom and cabling technology
Varistar Platform 1.4
Dimensions . . . . . 1.8
쮿 Two frames with different stability but identical outer appearance
쮿 Two colour schemes for immediate selection with ServicePLUS
쮿 Wide range of versions and dimensions (depths 600 mm to 1200 mm)
쮿 Unique meander profile with multiple mounting options and
new cable management possibilities
Varistar NET
Varistar NET Plus
01006012
Varistar Server
01006011
쮿 Cabling cabinet with one
19" plane
쮿 Datacom cabinet with two
19" planes and base
쮿 Single and side-by-side cabinets
01006014
쮿 Server cabinet with perforated
front and rear door, up
to 1200 mm deep
Varistar NET. . . . .
Varistar NET Plus
Varistar Server . . .
Assembly kit . . . .
Castors. . . . . . . . .
Lifting eye . . . . . .
Top cover fan . . .
Edge protection .
Brush strip . . . . .
Base plate . . . . . .
Base/plinth . . . . .
Tilt protection . . .
19 panel/slide
mounts . . . . . . . . .
Depth members .
Slide rails. . . . . . .
19" shelves . . . . .
Electronic locking
Zone 1,
zone 2 cable
management . . . .
Zone 3 cable
management . . . .
Zone 4 cable
management . . . .
Cable tie,
Velcro . . . . . . . . . .
Tray for excess
cable lengths . . .
1.126
1.130
1.130
1.132
1.132
1.133
1.133
1.136
1.136
1.137
1.139
1.141
1.142
1.143
1.144
1.145
1.148
1.155
1.158
1.161
1.162
1.163
ServicePLUS . . . 1.164
ServicePLUS
RAL 7021 . . . . . . . 1.165
ServicePLUS RAL
7035/RAL 7021 . . . 1.189
ServicePLUS from page 1.156
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
e.g. custom solutions (special sizes)
Varistar
Varistar EMC.
Varistar Seismic .
VARISTAR air/
water heat
exchanger . . . . .
1.10
1.54
1.84
1.224
30407004
SCHROFF.PENTAIR.EN
1.125
Varistar server, 1600 kg
VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Server cabinet with perforated doors, airflow rate 78%
5
쮿 Protection class IP 20
3b
쮿 Static load-carrying capacity up to 1600 kg
3a
쮿 Installation of different servers possible
2
쮿 Available in two color schemes
– Stone gray RAL 7021
– Light gray RAL 7035
1
Delivery includes
Item
1
Qty
1
2
3a
3b
4
1
1
1
1
5
1
6
2
7
4
8
4
9
10
4
1
4
H
6
7
8
W
D
20 - 45
9
01014055
1.126
Description
Welded basic frame (Slim-Line) from steel
profiles, RAL 7021
Flat top cover, St, RAL 7021; with cutouts for brush strips
Brush strip for 600 mm and 800 mm widths
Brush strip for 800 mm width only
Front door, St, with 180° hinges and perforation, 3-point
locking and lever handle (can optionally be expanded with
DIN profile half cylinder), color RAL 7035 or RAL 7021
(see Ordering Information)
Rear double door, St, with 180° hinges and perforation,
3-point locking and lever handle (can optionally be
expanded with DIN profile half cylinder), color RAL 7035
or RAL 7021 (see Ordering Information)
Side panels, screw fixed, St, with inside locking, color
RAL 7035 or RAL 7021 (see Ordering Information)
19" panel/slide mounts, St, mounted in 740 mm intervals,
color RAL 7035 or RAL 7021 (see Ordering Information)
Cross member, St (to accept 19" panel/slide mounts in
800 mm wide cabinets)
Adjustable foot
Earthing kit, fitted
VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days
Order Information
Heig Height Width W Depth Colour
ht
H
D
U
mm
mm
mm
42
2000
600
1200
42
2000
800
1200
Stone gray
RAL 7021
47
2200
600
1200
47
2200
800
1200
42
2000
600
1200
42
2000
800
1200
Light gray
RAL 7035
47
2200
600
1200
47
2200
800
1200
Accessories
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Spare key Handle with locking insert (6) 1 piece
Tip-over protection for floor mounting is screwed to the
floor, PU 2 pieces
Part no.
10130-234
10130-232
10130-235
10130-233
10130-240
10130-238
10130-241
10130-239
25127-995
60127-018
23130-386
01014056
ServicePLUS see page 1.164
SCHROFF.PENTAIR.EN
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.127
Varistar Colocation
VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 Colocation cabinets with 2, 3 or 4 divider units to accommodate
e.g. servers
– Perforated doors (airflow rate 78%)
– Multi-point door locking to prevent unauthorized access
(Iever handle with key and numeric code)
– Access to false floors and cabling only from the appropriate
divider unit
쮿 Flexible cabling, possible from above, below, left or right
(data and power cables can be run separately)
쮿 Color RAL 7021 (black gray)
Delivery includes
Illustration shows cabinet with 3 divider units
01013001
2
Item
1
Qty
1
2
1
3
2 per
divider
unit
2 per
divider
unit
2 per
divider
unit
2 per
divider
unit
4 per
divider
unit
2 per
divider
unit
4
1
4
5
5
6
1
4
7
6
8
3
9
10
7
Description
profiles, RAL 7021
Flat top cover, St, RAL 7021, with brush strip
(left and right)
Front door, rack St, perforated, RAL 7035, 180°
hinge, 2-point locking and lever handle (key and
numeric code)
Rear door, St, perforated, RAL 7021, 180° hinge,
2-point locking and lever handle (key and numeric
code)
Cable channels, left and right
Depth member for fixing false floors and 19" profiles
19" panel, St, RAL 7035, with EIA perforation, depthadjustable in 25 mm increments, standard fitting
position 74 mm recessed
Base plate can be mounted from inside
Adjustable foot
5
8
9
01013050
Detail of a divider unit
1.128
01013002
Varistar Colocation
VARISTAR Datacom/NetworkingPart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Order Information
01013051
Height
mm
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
Width
mm
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
Depth
mm
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
1000
1000
1000
1200
1200
1200
Number of
subdivisions
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
2
3
4
Part no.
10130-202
10130-203
10130-204
10130-214
10130-215
10130-216
10130-205
10130-206
10130-207
10130-217
10130-218
10130-219
10130-208
10130-209
10130-210
10130-220
10130-221
10130-222
10130-211
10130-212
10130-213
10130-223
10130-224
10130-225
Note
쮿 Side panel must be ordered separately
쮿 For suitable side panel see page 1.167
쮿 Cable panel, see page 1.160
01013004
Illustration: Cable panel, two-sided through entire cabinet height,
cable entry top/bottom
Detail: Lever handle with
numeric code
01013003
SCHROFF.PENTAIR.EN
Part number in bold face type: ready for despatch within 2 working days
1.129
Varistar NET Plus
쮿 Cabling cabinet with two 19" planes and base/plinth
쮿 Type of protection IP 20
쮿 Load-carrying capacity 400 kg according IEC 61587-1
쮿 Available in two versions
– Single cabinet (with side panels)
– Side-by-side cabinet (with side-by-side mounting kit)
Delivery comprises (Completely assembled and earthed)
Side-by-side cabinet (without side panel)
1.130
Single cabinet
01006011
Item
1
Qty
1
2a
1
2b
1
3
1
4
1
5a
2
5b
6
1
4
7
4
8
1
9
1
10
1
Description
Welded basic frame (Slim-Line) from steel profiles,
RAL 7021
From cabinet height 42 U/47 U:
top cover, St, RAL 7021 with prepunched perforation for
subsequent assembly of brush strip, perforated cover
plate or fan tray
Cabinet height 24 U:
top cover, St, RAL 7021, without cut-out zone
Front door: frame St, RAL 7035, with
safety glass 6 mm and 180° hinge,
single point locking and lever handle
(optionally with DIN profile half cylinder)
Rear door, St, RAL 7035, with 180° hinge,
(optionally retrofittable with DIN profile half cylinder)
Single cabinet: side panels, St, RAL 7035,
with quick-release fastener
Side-by-side cabinet: 1 side-by-side mounting kit
Adaptor bracket for reduced width, St, finish AlZn,
for assembly of 19" panel/slide mounts (only with
19" panel/slide mount, St, RAL 7035, with EIA perforation
(800 mm wide cabinets: assembled on the adaptor
bracket for reduced width),
600 mm cabinet depth: distance to front door 50 mm,
at 800 mm 150 mm,
from 900 mm cabinet depth: 70 mm;
Base plate for lateral cable ducting, St, RAL 7021,
subsequent lateral assembly of brush strip possible
Base/plinth, St, RAL 7021, height 100 mm with front and
rear ventilation trim, mounted base/plinth trims,
integrated feet
Varistar NET Plus
Order Information
Height
01005102
Height Width Depth
Side-by-side
H
W
D
cabinet
U
mm
mm
mm
Part no.
24
1200
600
600
10130-073
24
1200
600
800
10130-075
24
1200
600
900
10130-077
24
1200
600
1000
10130-079
24
1200
800
600
10130-081
24
1200
800
800
10130-083
24
1200
800
900
10130-085
24
1200
800
1000
10130-087
42
2000
600
600
10130-089
42
2000
600
800
10130-091
42
2000
600
900
10130-093
42
2000
600
1000
10130-095
42
2000
800
600
10130-097
42
2000
800
800
10130-099
42
2000
800
900
10130-101
42
2000
800
1000
10130-103
47
2200
600
600
10130-105
47
2200
600
800
10130-107
47
2200
600
900
10130-109
47
2200
600
1000
10130-111
47
2200
800
600
10130-113
47
2200
800
800
10130-115
47
2200
800
900
10130-117
47
2200
800
1000
10130-119
handle (1 key fits all locks) incl. 2 keys
Tilt protection for base mounting is screwed to the
floor, PU 2 pieces
Single cabinet
Part no.
10130-072
10130-074
10130-076
10130-078
10130-080
10130-082
10130-084
10130-086
10130-088
10130-090
10130-092
10130-094
10130-096
10130-098
10130-100
10130-102
10130-104
10130-106
10130-108
10130-110
10130-112
10130-114
10130-116
10130-118
25127-995
23130-386
Note
쮿 The 24 U cabinet has a top cover without prepunched
perforation (not suitable for retrofitting with brush strips,
fan tray, etc.)
쮿 A standard cabinet can be expanded simply with additional
components, see from page 1.189
Single cabinet
01005101
SCHROFF.PENTAIR.EN
1.131
Assembly kit
쮿 For direct assembly of 19" panel/slide mounts, depth members
and further components on Varistar frame
쮿 Assembly by clipping in the cage nut into frame or
depth member
쮿 Mounting of components possible from the inside as well as
from the outside
Delivery comprises (Kit)
Item
1
2
Qty
50
50
Description
Cage nut, St, M5, white zinc-plated
Screw, St, M5 x 10, white zinc-plated
Order Information
Description
Assembly kit, earthed
Part no.
23130-141
01006065
Castors
쮿 For assembly on frame
Delivery comprises
Item
1
2
3
Qty
2
2
1
Description
Locking castor, PA/St
Non-locking castor, PA/St
Assembly kit
Order Information
Description
Castors with 2 locking
01004082
Part no.
23130-077
Note
쮿 Not suitable in connection with base/plinth
Castors with integrated adjustable feet
Delivery comprises
Item
1
2
Qty
4
1
Description
Castor with adjustable feet
Assembly kit
Order Information
Description
Part no.
23130-078
Note
01004156
1.132
Lifting eye, Varistar
쮿 Thread M12
쮿 Application and static load-carrying capacity in accordance with
DIN 582 (see Technical Info Section, chapter 12)
Order Information
Description
Lifting eye for top cover
Qty/PU
4
Part no.
23130-072
Note
쮿 Only suitable with top cover, not usable with raised cover
M12
01004100
Fan unit with 3 fans
쮿 Suitable for flat top cover with cut-out zones
쮿 Mounting position completely in cabinet interior, no protrusion
over top cover
쮿 3 fans fully wired
쮿 Mains connection via SCHUKO/UTE plug IEC 60320 C13 socket
Delivery comprises (completely assembled and wired)
01006027
Item
1
2
Qty
1
3
3
4
3
1
Description
Fan tray, RAL 7021
Axial fan 230 VAC, fully wired,
connects via SCHUKO/UTE plug - IEC 60320-C12 socket
Protective grille
Assembly kit
Order Information
Description
Qty/PU
pieces
1
Part no.
Accessories
Fan with grille, 230 VAC, 38 x 119 x 119 mm, 162 m3/h at 50
Hz, 1 piece
Thermostat with mains cable 230 VAC (SCHUKO/UTE plug/
IEC 60320 C13 socket), adjustment range 0 ... 60°C, 1
piece
23130-070
23130-165
20118-750
Technical data of one fan
Frequency
Voltage
Airflow volume
Noise pressure level
Max. static pressure
Max. ambient temperature
Power consumption
50 Hz
230 VAC
162 m 3/h
37 dB(A)
73 PA
+70 °C
15 W
60 Hz
230 VAC
192 m3/h
41 dB(A)
88 PA
+70 °C
14 W
01004102
SCHROFF.PENTAIR.EN
1.133
Cabinets – VARISTAR
Flat top cover with cut-out zones
VARISTA RMain CatalogPart number i n bold face type: ready for shipping w ithin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Cut-out zones are easy to cut out.
쮿 Cut-outs can be fitted with brush strips, fan units, perforated
cover plates or edge protectors
Delivery includes
Item
1
Qty
1
2
1
Description
Flat top cover, St, 1.5 mm, with cut-out zones for cutouts, RAL 7021
GND/earthing kit
Order Information
01006097
01006092
01004102
01004103
41003065
Width
Depth
mm
mm
600
600
600
800
600
900
600
1000
600
1100
600
1200
800
600
800
800
800
900
800
1000
800
1100
800
1200
Accessories
Brush strip Nylon, black, PU 2 pieces
Fan unit with 3 fans with 3 fans, fully assembled and wired,
1 kit
Perforated cover plate for top cover with
cut-out zones 6 mm perforation, incl. earthing, 1 piece
Edge protection PVC, black, 3 m PVC, black, 3 m, 1 piece
Part no.
RAL 7021
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
23130-069
23130-070
23130-071
28127-281
Flat top cover construction with Flat top cover construction with
brush strips
fan insert
Flat cop cover construction with Flat top cover construction with
cover plate
edge protection
1.134
Cabinets – VARISTAR
Flat top cover with cable through-ducting openings
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Includes earthing
쮿 Color RAL 7021
쮿 St, 1.5 mm
쮿 Cutouts must be covered with brush strips, please order these
separately
Delivery includes
01015052
85
D
449
449
a
Item
1
2
Qty
1
1
Description
Flat top cover, St, 1.5 mm, with cutouts, RAL 7021
GND/earthing kit
Order Information
W
b
a
01015050
Flat top cover construction with brush strips
Width W
Depth D
mm
mm
600
1000
600
1100
600
1200
800
1000
800
1100
800
1200
Accessories
Part no.
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
23130-069
28127-281
Note
쮿 Fan insert with 3 fans (23130-070) cannot be used
01015051
Edge protector
41003065
SCHROFF.PENTAIR.EN
1.135
쮿 To cover the sharp edges of an open cut-out (protects against
injury)
Order Information
Description
Part no.
28127-281
41003065
Brush strip
쮿 For cable ducting with flat top cover (with cut-out zones)
쮿 600 mm wide top cover: two brush strips cover one
centre cut-out
쮿 800 mm wide top cover: brush strip can be used either
lengthways or depthways; one brush strip covers a lateral
cut-out, two brush strips cover a centre cut-out
Order Information
Description
Brush strip
Qty/PU
2
Part no.
23130-069
01006092
Cover plate perforated for top cover with
cut-out zones
쮿 Suitable for flat top cover (with cut-out zones), screwed-fixed
쮿 Provides heat dissipation from cabinet (with 6 mm perforations)
Delivery comprises
Item
1
Qty
1
2
1
Description
Top cover plate, perforated, 6 mm perforation, St, 1 mm,
RAL 7021, incl. GND/earthing
Assembly kit
Order Information
Description
cut-out zones
Qty/PU
1
Part no.
23130-071
01009056
1.136
Base plate, multi-piece
쮿 The multi-piece base plate is open at the rear
쮿 The opening may be completed
– with a filter mat
– with a brush strip for the cable entry
– with a cover plate
Delivery comprises (kit)
Item
1
5
Qty
1
1
Description
Multi-piece base plate, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01004050
1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter
kit
Width
Depth
mm
mm
600
600
600
800
600
900
600
1000
600
1200
800
600
800
800
800
900
800
1000
800
1200
Item 2 Cover plate for multi-piece base plate, for 600 mm
wide cabinets, 200 mm deep, incl. assembly kit, 1 piece
Item 2 Cover plate for multi-piece base plate, for 800 mm
Item 3 Brush strip for base plate, for 600 mm wide
Item 3 Brush strip for base plate, for 800 mm wide
Item 4 Filter mat for base plate, white, class M1 in
accordance with EN 799-G3, for 600 mm wide cabinets,
accordance with EN 799-G3, for 800 mm wide cabinets,
Part no.
23130-001
23130-002
23130-003
23130-004
23130-359
23130-005
23130-006
23130-007
23130-008
23130-361
23130-076
23130-136
23130-074
23130-134
23130-075
23130-135
Note
쮿 Is assembled from inside
쮿 Please order cover plate, brush strip or filter mat separately
SCHROFF.PENTAIR.EN
1.137
쮿 The base plate is open on the side; the opening can be covered
with a brush strip (cabinet width 600 mm) or two brush strips
(cabinet width 800 mm)
쮿 Perforated at front for better heat dissipation
Delivery comprises
Item
1
2
Qty
1
1
Description
Base plate, St, 1.5 mm, width 440 mm, RAL 7021
Assembly kit
Order Information
Cabinet width 600 mm
Cabinet width 800 mm
01006061
01006062
For cabinet width W
Depth D
mm
mm
600 / 800
600
600 / 800
800
600 / 800
900
600 / 800
1000
600 / 800
1200
Item 3 Brush strip for base plate for lateral cable
ducting, cabinet depth 600 mm, 200 mm wide,
ducting, cabinet depth 800 mm, 200 mm wide,
ducting, cabinet depth 900 mm, 200 mm wide,
ducting, cabinet depth 1000 mm, 200 mm wide,
ducting, cabinet depth 1200 mm, 200 mm wide,
Part no.
23130-378
23130-353
23130-354
23130-355
23130-357
23130-074
23130-134
23130-374
23130-375
23130-377
Note
1.138
Stationary base/plinth
쮿 Static load-carrying capacity 1000 kg
쮿 Removable trims allow cable entry from all sides
쮿 Cannot be used in conjunction with castors
쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm
쮿 Versions
– Front/rear trim perforated
– Front/rear trim solid
Delivery comprises ((kit))
2a
H
2b
1
2b
Item
1
2a
2b
3
Qty
2
2
2
1
Description
Support with feet, St, 3 mm
Solid trim, St, 1.5 mm, RAL 7021
Perforated trim, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
2a
D = cabinet depth
W
D
4
01004110
01004053
For cabinet width W
Front/rear trim
mm
600
perforated
600
plain
800
perforated
800
plain
Item 4 Side trim height 100 mm, depth 600 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 800 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 900 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 1000 mm,
PU 2 pieces
Item 4 Side trim height 100 mm, depth 1200 mm,
PU 2 pieces
Part no.
23130-187
23130-387
23130-194
23130-388
23130-169
23130-170
23130-171
23130-172
23130-363
Note
쮿 Please order side trims (item 4) separately
SCHROFF.PENTAIR.EN
1.139
Mobile base/plinth
쮿 Load-carrying capacity on castors 400 kg, on adjustable feet
1000 kg
쮿 Plinth height H = 100 mm, with feet adjustable from 126 to
134 mm
Delivery comprises
Item
1
2
3
4
Qty
1
4
4
1
Description
Frame, St, 3 mm, RAL 7021, with adjustable feet
Trim, St, 1.5 mm, RAL 7021
Castor
Assembly kit
Order Information
01004111
1.140
01006095
For cabinet width W
mm
600
600
600
600
600
800
800
800
800
800
For cabinet depth D
mm
600
800
900
1000
1200
600
800
900
1000
1200
Part no.
23130-208
23130-209
23130-210
23130-211
23130-369
23130-212
23130-213
23130-214
23130-215
23130-371
Telescopic tilt protection
쮿 Max. 150 kg at full extension
쮿 Lateral and rear cable entry possible
Delivery comprises
Item
1
2
Qty
1
1
3
4
1
1
Description
Guide plate for tilt protection, St, 2 mm, AlZn
Tilt protection, St, 2 mm, RAL 7021,
with 2 adjustable feet
Bezel, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01006054
For cabinet width W
mm
600
600
600
800
800
800
For cabinet depth D
mm
900
1000
1200
900
1000
1200
Part no.
23130-345
23130-346
23130-348
23130-349
23130-350
23130-352
Note
쮿 Only for use in conjunction with plinth or mobile plinth
01006058
Tilt protection for floor mounting
쮿 For fixing to the floor
쮿 Height adjustable by integrated adjustable feet
쮿 Assembly possible on frame or base/plinth
Delivery comprises
Item
1
2
Qty
2
2
Description
Mounting plate, Al
Adjustable foot with outside thread
Order Information
Description
Part no.
23130-386
01006091
SCHROFF.PENTAIR.EN
1.141
19" panel/slide mounts with universal pitch (EIA)
쮿 Assembly in 600 mm wide cabinets directly on the frame
쮿 Depth-adjustable in 25 mm increments
쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1)
Delivery comprises
46
5
Item
1
Qty
2
2
1
Description
19" panel/slide mount, St, 1.75 mm, finish AlZn,
Assembly kit, incl. GND/earthing
Order Information
15,9
42,5
44,45
44.45
12,75
9,6
65,1
2
76
25
25
49,5
01004112
01004131
For cabinet Usable Length
AlZn
RAL 7035
height
height
mm
U
mm
Part no.
Part no.
Partialheight
8
395
23130-037 23130-027
mounting
Partialheight
12
545
23130-038 23130-028
mounting
Partialheight
16
745
23130-039 23130-029
mounting
Partialheight
23130-040 23130-030
mounting
Partialheight
24
1095
23130-031 23130-021
mounting
Partialheight
29
1295
23130-032 23130-022
mounting
Partialheight
33
1495
23130-033 23130-023
mounting
Partialheight
38
1695
23130-034 23130-024
mounting
2000
42
1895
23130-035 23130-025
2200
47
2095
23130-036 23130-026
Accessories
Adaptor bracket for reduced width for mounting of panel/
slide mounts in 800 mm wide cabinets, St, 2 mm, AlZn,
PU 4 pieces
Heavy-load cross member Length 1,000 mm, PU 4 pieces
Heavy-load cross member Length 1100 mm, PU 4 pieces
Heavy-load cross member Length 1,200 mm, PU 4 pieces
Dimensioning strip for 19" panel mounts, paper, white,
serial numbered from 1 ... 47 U, PU 4 pieces
RAL 7021
Part no.
23130-017
23130-018
23130-019
23130-020
23130-011
23130-012
23130-013
23130-014
23130-015
23130-016
23130-091
23130-544
23130-545
23130-546
25127-997
Note
쮿 Please order adaptor bracket for reduced width for 800 mm
wide cabinets separately
쮿 For 19" partial-height mounting, depth members are required
쮿 Metric panel/slide mounts available on request
1.142
Depth members
쮿 For mounting of shortened 19" panel/slide mounts
쮿 Cable ducting by means of cable ties and cable eyes
Delivery comprises
Item
1
2
50
121,2
25
25
100
37,5
36,5
11,5
L - 27
12
L
01004126
01004079
Cable eye
Qty
2
1
Description
Depth member, St, 1.5 mm, finish AlZn
Assembly kit incl. GND/earthing
Order Information
For cabinet depth
Length L
mm
mm
600
460
800
660
900
760
1000
860
1200
1060
Cable eye A = 38 mm, B = 25 mm, PU 25 pieces
Cable eye A = 47 mm, B = 50 mm, PU 25 pieces
Part no.
23130-081
23130-082
23130-083
23130-084
23130-365
21101-151
21101-150
Note
쮿 Cable ducting with cable ties see page 1.162
coa43697
19" assembly kit, M6
쮿 For front panels, distribution fields and other components
Delivery comprises
Item
1
2
3
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
Order Information
Description
19" assembly kit (screw, washer, nut)
Qty/PU
50
100
Part no.
21101-809
21101-810
sc128
SCHROFF.PENTAIR.EN
1.143
Slide rails
쮿 For assembly on 19" panel/slide mounts
쮿 Assembly in 1 U increments (snap-in, bolt-on)
쮿 2 versions
– Static load-carrying capacity 25 kg per pair
– Static load-carrying capacity 100 kg per pair
D
c
c - 130
쮿 Wide support surface (48 mm)
19”
c = pitch of the 19" panel/slide mounts
xf = standard dimension
D = cabinet depth
xf
Delivery comprises
01004130
Item
1
Qty
see Order
information
2
1
Description
Slide rail, AlZn, 1.5 mm (static load-carrying
capacity 25 kg), or 2.5 mm (static load-carrying
capacity 100 kg), zinc-plated
Order Information
Static load carrying capacity 25 kg
For cabinet depth
mm
600, 800
600, 800
800
800
900, 1000, 1200
900, 1000, 1200
xf
mm
50
50
150
150
70
70
c
mm
500, 700
500, 700
500
500
740
740
Length L
mm
456
456
456
456
699
699
Qty/PU
2
10
2
10
2
10
Part no.
23130-096
23130-101
23130-096
23130-101
23130-098
23130-103
Order Information
01005086
Static load carrying capacity 100 kg
For cabinet depth
mm
600, 800
600, 800
800
800
900, 1000, 1200
900, 1000, 1200
xf
mm
50
50
150
150
70
70
c
mm
500, 700
500, 700
500
500
740
740
Length L
mm
458
458
458
458
699
699
Qty/PU
2
10
2
10
2
10
Part no.
23130-118
23130-123
23130-118
23130-123
23130-120
23130-125
01004058
Short slide rails
쮿 Support for heavy 19" chassis
쮿 To attach on 19" slide mounts
쮿 Static load-carrying capacity max. 15 kg per pair
Delivery comprises
Item
1
2
sc96xxxx
Qty
2 / 10
1
Order Information
Description
Short slide rail
Short slide rail
1.144
Description
Short slide rail, St, 1.5 mm, finish AlZn
Assembly kit
Qty/PU
2
10
Part no.
23130-094
23130-095
19'' fixed shelf, 75 kg
쮿 Static load-carrying capacity 75 kg
(150 kg with strengthening rail)
쮿 Mounting height 1 U, for mounting on four panel/slide mounts
쮿 With hammer head perforation to fix cable ties
Delivery comprises
xr
01004066
Item
1
Qty
1
2
1
Description
Perforated shelf, St, 1.5 mm
(colour see Order Information)
c
D
For cabinet
Usable
xf
c
RAL 7035
depth
surface w x d
mm
mm
mm mm
Part no.
600
495 x 442
50
500
22130-303
800
495 x 442
150
500
22130-303
900
495 x 682
70
740
22130-309
1000
495 x 682
70
740
22130-309
1200
495 x 682
70
740
22130-309
Strengthening rail for stationary 19" shelf PU 1 piece
xf
d
Order Information
w
RAL 7021
Part no.
21130-303
21130-303
21130-309
21130-309
21130-309
23130-310
Note
W
c = max. pitch of the 19" slide mounts
xf, xr = standard assembly dimension
01004067
쮿 Other sizes see ServicePLUS page 1.165
19" shelf, stationary, depth-adjustable, 1 U
쮿 Static load-carrying capacity 68 kg
쮿 For mounting on four 19" uprights or four panel/slide mounts
D
쮿 Variable mounting dimensions (depth-adjustable)
쮿 2 Versions
– Mounting dimension 495 ... 851 mm
– Mounting dimension 792 ... 1151 mm
44
441
쮿 2 oval cut-outs for cable ducting
쮿 Colour black, RAL 9005
465
483
Delivery comprises
87928708
Item
1
Qty
1
2
1
Description
Shelf, depth-adjustable, width 19", height 1 U,
RAL 9005 (black)
Fitting materials with user manual
Order Information
Mounting dimension D 495 ... 851 mm
Mounting dimension D 792 ... 1151 mm
Part no.
D19FVT69B
D19FVT912B
Note
쮿 19" assembly kit see page 1.143
SCHROFF.PENTAIR.EN
1.145
19'' telescopic shelf, 30 kg
쮿 Static load-carrying capacity at full extension 30 kg
1
쮿 Mounting height 1 U, for mounting on four 19" panel/slide
mounts
2
쮿 Incl. telescopic slides
쮿 Hammer head perforation to fix cable ties
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
01004068
Full depth
W
xr
w
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Telescopic slide
Assembly kit
Order Information
D
c
c
RAL 7035
For cabinet
Usable surface xf
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 482
50
500
22130-343
800
417 x 482
150 500
22130-343
GND/earthing for telescopic 19" shelf PU 1 kit,
for Varistar
RAL 7021
Part no.
21130-343
21130-343
23130-140
Note
xf
d
Full depth
01004069
Order Information
Shortened depth
Shortened by 100 mm
W
For cabinet
Usable surface xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
417 x 382
50
500
22130-342
800
417 x 382
150 500
22130-342
for Varistar
RAL 7021
Part no.
21130-342
21130-342
23130-140
Note
D
c
xr
w
xf
d
쮿 Cable ducting with cable ties, see page 1.162
c = max. pitch of the 19" panel/slide mounts
1.146
01004070
19'' telescopic shelf, 70 kg
1
쮿 Static load-carrying capacity at full extension 70 kg
2
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
4
쮿 Locking with T-bar lock possible
01004071
W
Delivery comprises
w
Item
1
Qty
1
2
3
2
1
xr
Full depth
쮿 2 versions
– Full depth
Description
Telescopic slide
Assembly kit
D
c
Full depth
c
RAL 7035
For cabinet
Usable surface
xf
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 482
50 500 22130-353
800
405 x 482
150 500 22130-353
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
for Varistar
xf
d
Order Information
01004069
Shortened depth
RAL 7021
Part no.
21130-353
21130-353
23130-092
23130-140
Note
쮿 Please order T-bar lock (item 4) separately
W
w
xr
Order Information
D
For cabinet
Usable surface
xf
c
RAL 7035
depth
wxd
mm
mm
mm mm
Part no.
600
405 x 382
50 500 22130-352
800
405 x 382
150 500 22130-352
for Varistar
d
c
Shortened by 100 mm
RAL 7021
Part no.
21130-352
21130-352
23130-092
23130-140
Note
xf
SCHROFF.PENTAIR.EN
01004070
1.147
Lever handle for
쮿 For installation instead of key lock insert
쮿 To open press push-button
쮿 DIN profile half cylinder retrofittable
Delivery comprises
Item
1
2
Qty
1
1
Description
Lever handle for single point locking
Assembly kit
Order Information
Description
01005016
Part no.
23130-067
25127-995
Note
쮿 Other locks such as ASSA, KABA or RONIS available on request
Electronic closing (stand-alone)
쮿 Complete package comprising a handle with keyboard (master)
and a handle with opening function (slave) plus all necessary
electrical connection components
쮿 Suitable for all Varistar cabinet doors with single point or
3-point locking and S2100 door handle cut-out
쮿 Front and rear door can be opened together or separately by
means of coding
Item
1
Qty
1
2
1
3
1
4
5
6
1
1
1
41003035
4
3
Description
Electronic lever handle with keyboard (master) for front
door, 4 m connecting cable and ferrules
Electronic lever handle, opener (slave) only, for rear
Plug-in power supply AC/DC with Euro plug,
input voltage 100 VAC ... 230 VAC,
output voltage 12 VDC /700 mA
Central unit with case
Cable ducting
Assembly kit, operating instructions
Order Information
2
Description
Electronic closing
Part no.
20130-598
1
01007054
1.148
ELECTRONICS PROTECTION
Electronic locking (MLR 3000)
쮿 Electronic door handles for Varistar cabinets
쮿 Modular solution with electronic door locking, reader unit,
PSU and administration software
쮿 Integrated visualization, LED display for alarm signals and
operating statuses
쮿 Two locking options: standalone and networked
쮿 Access reporting and user management
쮿 Sabotage and vandalism alarm
Delivery includes
Item
1a
Qty
1
1b
1
1c
1
Description
Electronic door lock MLR 3000 with lever handle and card
reader unit; display with status LEDs;
reader (125 kHz-HDI, 13,56 MH5-MIFARE)
Card reader unit (supply voltage 12 VDC , 40 mA,
(max. 440 mA); Temperature range -20 ... +70 °C
Junction (distribution box)
01013014
Order Information
Qty/PU
piece
Electronic locking (MRL3000), 125 KHz-HDI
1
Electronic locking (MRL3000), 13.56 MHz-MIFARE 1
Accessories
Part no.
23130-513
23130-565
Electronic door lock MLR1000 (slave),
1 piece
23130-512
PSU for electronic locking 1 piece
23130-515
Gateway for electronic door lock 1 piece
23130-523
Administration Suite Software 1 piece
60130-680
Reader cards for electronic locking,
125 KHz-HDI PU 10 pieces
23130-526
13.56 MHz-MILFARE PU 10 pieces
23130-566
Standalone function cards,
125 KHz-HDI PU 4 pieces
60130-678
13.56 MHz- MIFAREPU 4 pieces
60130-832
Battery pack for electronic locking
1 piece
60130-729
Desktop reader, 125 KHz-HDI 1 piece
60130-730
Desktop Reader, 13.56 MHz-MIFARE
1 piece
60130-830
LAN
OUTPUT CONFIG
Description
ff
hro ff
SScchro
ff
chrooff
S
Schrroff
Sch
Sch
S ro
S ch ff
S ch roff
S ch roff
ch ro
ro ff
ff
Schroff
Schroff
Schroff
Schro
ff
SCHROFF.PENTAIR.EN
1.149
Standalone solution:
- Lever handle with HID 125 kHz reader unit (Mifare on request)
- Reader cards are set up and issued directly on handle using the
HID standalone function cards
Standalone solution
Networked solution:
- Access is managed centrally via the network
- Reader cards are issued via the management software
- The Gateway allows up to 32 door handles to be controlled
Networked solution
2
1a
4
3
2a
1a
1a
1b
1c
1b
5
2b
1b
LA
01014051
N
01014052
Required number of components for one cabinet with front and
rear door (standalone solution)
Required number of components for two cabinets with front and
rear door (networked solution)
Item
Description
Item
Description
1a
1b
2
Electronic door lock MLR3000
Stand-alone card reader unit
Power supply unit for door lock
Cards (set of 10)
HID stand-alone function cards
Battery pack (optional)
1a
1b
1c
2a
2b
3
4
5
Card reader unit
Junction
Junction
PSU for door lock/gateway
Access management software, administration
suite via network
Cards (set of 10)
Desktop reader (optional)
1.150
Required
number
Piece
2
2
1
1
1
Order no.
23130-513
23130-515
23130-512
60130-678
60130-729
Required
number
Piece
Order no.
2
23130-513
2
23130-512
5
1
1
23130-515
23130-523
60130-680
1
1
1
23130-526
23130-730
60130-729
operating statuses
쮿 Lever handle opens when switch contacts touch
Delivery includes
Item
1a
Qty
1
1b
1
Description
Electronic door lock MLR1000 with lever handle,
display with multicolor status LED
Junction (distribution box), power supply via 12 VDC
socket, 40 mA (max. 440 mA); temperature range
-20 ... +70 °C
Order Information
Description
01013014
Accessories
Qty/PU
piece
1
Part no.
23130-512
23130-515
VARISTAR Electroni csMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Battery pack allowing emergency opening of lever handle
(MLR 3000) in event of power failure
쮿 Power is supplied to the handle from below, allowing door then
to be opened using an authorized access card
Delivery includes
Item
1
Qty
1
Description
Battery pack, 12 V, width 145 mm, height 72 mm,
depth 34 mm
Order Information
Description
Qty/PU
piece
1
Part no.
60130-729
01014001
SCHROFF.PENTAIR.EN
1.151
쮿 Power adapter to supply lever handle (MLR 3000, MLR1000) and
gateway
Delivery includes
Item
1
Qty
1
Description
Power adapter, 230 VAC (IEC 60320-C13 plug), 12 VDC,
(cable length 1230 mm)
Order Information
Description
01014054
Qty/PU
piece
1
Accessories
Mains cable, IEC IEC 60320 C14 plug,
IEC 60320 C13 socket, 2.5 m, 1 piece
Mains cable, BS British Standard plug,
Mains cable, SCHUKO/UTE SCHUKO/UTE plug,
IEC 60320 socket, 2.5 m, 1 piece
Part no.
23130-515
60197-053
60103-137
62150-191
Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days
쮿 Reader cards for electronic locking (MLR3000)
Delivery includes
ff
hro ff
SScchhro
ff
c hrrooff
S
Scch
ff
ro
S
Item
1
Sch
S ro
S ch ff
Scchrroff
S h off
ch ro
ro ff
ff
Qty
10
Description
Reader card for reader unit
Order Information
Description
125 KHz-HDI
13.56 MHz-MILFARE
Qty/PU
Part no.
PU 10 pieces
23130-526
PU 10 pieces
23130-566
12514051
쮿 Code cards for programming standalone locking
Delivery includes
Item
1
2
3
4
5
Schroff
Schroff
Schroff
Schro
ff
Qty
1
1
1
1
1
Description
Card (unlocking card)
Card (locking card)
Card (group card)
Card (general card)
User manual
Order Information
12514050
1.152
Description
Standalone function cards, 125 KHz-HDI
Standalone function cards, 13.56 MHzMIFARE
Qty/PU
PU 4 pieces
60130-678
Part no.
PU 4 pieces
60130-832
Access management software, Administration Suite
쮿 The Administration Suite enables you to document and protect
all access to indoor cabinets and enclosures. You have
complete control and also have a high level of flexibility
쮿 Alarm management, the possibility of managing systems in
different time zones and managing different installations.
쮿 Flexibility, a clear overview and user-friendly design make this
software easy to use and an effective management system for
data and server cabinets protected with E-LINE by DIRAK
쮿 The integrated web client lets you link any number of users with
the administration suite via a web browser. Any device with a
browser function (iPad®, tablet computers, iPhone®,
Blackberry® etc.) can operate the web client of the
administration suite without additional software installation
Delivery includes
Item
1
Qty
1
Description
CD with software and documentation
Order Information
Description
Qty/PU
piece
1
Part no.
60130-680
01014004
Desktop reader
Elec tricsMain C atalogP art number in bold fac e type: ready for shipping within 2 w orking daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Card reader unit for networked solution
쮿 Centralized allocation of reader cards using administration
suite software
Delivery includes
Item
1
Qty
1
2
1
Description
Desktop reader, width 107.5 mm, depth 108.5 mm,
height 23.75 mm
USB connecting cable, length 1800 mm
Order Information
Description
01014002
SCHROFF.PENTAIR.EN
Desktop reader, 13.56 MHz-MIFARE
Qty/PU
piece
1
1
Part no.
60130-730
60130-830
1.153
Gateway for electronic locking
쮿 Connects to Ethernet network
Delivery includes
OUTPUT CONFIG
Item
1
Qty
1
Description
Gateway, width 75 mm, depth 70 mm, height 29 mm
Order Information
Description
LAN
Accessories
Qty/PU
piece
1
Part no.
23130-523
23130-515
01014053
1.154
Zone 1 cable management
쮿 Cable ducting zone 1 is located in the front area of the cabinet,
in front of the 19" plane
쮿 In this zone the patch cables are ducted horizontally between
the distribution fields
Products
쮿 Cable ducting see chapter Cabinet accessories, from page 3.5
쮿 19'' distribution field, Cat 5/6, see chapter Cabinet accessories,
page 3.14
01006087
Zone 2 cable management
쮿 The cable ducting zone 2 is located on the right and left hand
side in the front area of the cabinet, next to the 19" plane
쮿 The patch cables are ducted in a kind of channel to the
individual distribution fields and components
Products
쮿 Cable eyes see from page 1.156
쮿 Cable brackets for fibre optic cables, see page 1.157
쮿 Shielding panel, see page 1.157
01006088
SCHROFF.PENTAIR.EN
1.155
Cable eye, plastic
쮿 For assembly on cabinet uprights in 800 mm wide cabinets
쮿 Simple and fast assembly by clicking into the cabinet profile
(without assembly kit)
쮿 Cable ducting laterally in front of the 19" panel/slide mounts
쮿 With additional assembly kit also suitable for lateral assembly
on the 19" panel/slide mounts
Delivery comprises
Item
1
Qty
4
Description
Cable eye, PA, UL 94 V-0, black
Order Information
Illustration shows application (W, D = 100 mm)
01006078
43
For cabinet width
W
mm
mm
600
31
800
100
Accessories
Taptite screw M6 Taptite, PU 50 pieces
D
mm
92
100
Part no.
23130-506
23130-336
23130-285
92
31
W = 31 mm, D = 92 mm
01012085
W, D = 100 mm
01006079
Cable eye, steel
쮿 For assembly on cabinet uprights (800 mm cabinet width) or
laterally to the 19" panel/slide mounts
쮿 Cable ducting laterally next to and/or in front of the 19" panel/
slide mounts
Delivery comprises
Item
1
2
3
Qty
4
4
1
Description
Bracket, St, zinc-plated,
Terminal, Al, die-cast
Assembly kit
Order Information
01006080
01006081
1.156
For cabinet width
mm
800
800
W
mm
100
100
D
mm
100
180
Part no.
23130-341
23130-342
01006098
Fibre optic cable ducting
쮿 Assembly on 19" panel/slide mounts
쮿 For secure laying of optical fibre cables
Delivery comprises
Item
1
2
Qty
2
1
Description
Fibre optic cable ducting, PA, UL 94 V-0, black
Assembly kit
Order Information
Description
Part no.
23130-372
01006074
Cover panel, hinged
쮿 For use in 2000 mm high and 800 mm wide cabinets
쮿 For lateral covering of e.g. the patch cables
쮿 Optionally with brush strip
Delivery comprises
Item
1
2
Qty
2
1
Description
Cover panel, St, 1 mm, RAL 7021
Assembly kit
Order Information
Height
Width
Qty/PU
mm
mm
piece
2000
100
2
Brush strip for cover panel height 2000 mm, PU 2 pieces
Part no.
23130-343
23130-379
01006056
SCHROFF.PENTAIR.EN
1.157
Zone 3 cable management
쮿 Is located laterally behind zone 2 across the whole cabinet
depth
쮿 Fibre optic or copper cables are ducted from cable entry in
lateral area of top cover or base plate to rear of distribution
fields
Products
쮿 C-rail or cable support rail for the cabinet depth see from page
1.159
쮿 Or cable ladder from page 1.160
01006085
Cable support rail for cabinet depth
쮿 For cable ducting in lateral area of cabinet
쮿 For cable shells (bottom row) and for cable ties, resp. Velcro
(top row)
Delivery comprises
Item
1
2
Qty
2
1
Description
Cable support rail, St, 1.5 mm, RAL 7021
Assembly kit
Order Information
01006066
L
60
1
For cabinet depth
Length L
mm
mm
600
466.4
800
666.4
900
766.6
1000
866.4
1200
1066.4
Accessories
Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces
Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces
Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces
Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces
Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces
Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces
Part no.
23130-326
23130-328
23130-329
23130-330
23130-332
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
Note
쮿 Cable ties and Velcro see page 1.162
01006067
1.158
C-rail for the cabinet depth
쮿 For cable shells and cable retention rails
Delivery comprises
Item
1
2
Qty
2
1
Description
C-rail, St, 1.5 mm, AlZn
Order Information
Cable retention rail and cable shell mounted on C-profile
01004129
Slide nut
15
Ø
50
11
L
39,5
29,5
L-
,5
x 31
6,5
50
75
01504054
SCHROFF.PENTAIR.EN
C-rail
01004132
For cabinet depth
Length L
mm
mm
600
460
800
660
900
760
1000
860
1200
1060
Accessories
Cable retention rail for C-rail Width 75 mm,
length 39.5 mm, PU 5 piece
Slide nut for C-profile, PU 10 pieces
Part no.
23130-086
23130-087
23130-088
23130-089
23130-367
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
쮿 Cable ties and Velcro for cable retention rail see page 1.162
01006071
1.159
Cable panel
쮿 For fitting directly onto the frame
쮿 Fixing of cables with cable ties or Velcro
쮿 Widths 150 mm and 250 mm
Delivery comprises
Item
1
2
1
Qty
2
1
Description
Cable panel with cut-outs, St, 1 mm, RAL 7021
Assembly kit
H
Order Information
10
W
01006103
For cabinet height
U
8
9
12
14
18
42
47
38
42
47
H
mm
446
496
604
670
917
1019
1700
1900
2100
1700
1900
2100
W
mm
110
110
110
110
110
110
150
150
150
250
250
250
Part no.
23130-501
23130-504
23130-500
23130-503
23130-499
23130-502
23130-420
23130-421
23130-422
23130-149
23130-150
23130-151
Note
Cable ladder
쮿 For mounting in 2000 or 2200 mm high cabinets
쮿 Cables are fixed in place with cable ties or Velcro
Delivery includes
Item
1
2
1
Qty
2
1
Description
Cable ladder, round steel, zinc-plated
Assembly kit
Order Information
H
For cabinet height
mm
2000
2200
Height H
mm
1800
2000
Width
mm
300
300
Depth
mm
30
30
Part no.
23130-554
23130-555
Note
30
300
01014057
1.160
Zone 4 cable management
쮿 Cable ducting on the inside of the cabinet rear panel across the
entire cabinet width
쮿 Top cover openings can be used for cable ducting
Products
쮿 C-rail and cable support rail for the cabinet width see from page
1.161
01006086
Cable support rail for cabinet width
쮿 For cable ducting in rear area of cabinet
(top row)
Delivery comprises
Item
1
2
Qty
2
1
Description
Assembly kit
Order Information
01006077
For cabinet width
Length L
mm
mm
600
550
800
750
Accessories
Part no.
21236-093
23130-312
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
Note
01006076
SCHROFF.PENTAIR.EN
1.161
Cabinets – VARISTAR
C-rail for cabinet width
VARISTA RMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 For cable ducting in rear or front area of cabinet
Delivery comprises
Item
1
2
Qty
2
1
Description
C-rail, St, 1.5 mm, finish AlZn
Order Information
01006063
C-rail
Slide nut
For cabinet width
Length
mm
mm
600
550
800
750
Accessories
Slide nut for C-rail, PU 10 pieces
Part no.
23130-333
23130-334
60118-472
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
21120-140
Note
39,5
75
01006071
01006064
01504054
Cable tie, Velcro
MechanicsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 Fixing materials kit for cable ducting
Order Information
Description
Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces
Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces
Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces
Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces
Cable tie
1.162
01005078
Velcro
Part no.
20118-351
20118-352
20118-353
20118-624
01005079
Deposit for excess cable lengths
쮿 For fixing on shelf or depth member
쮿 Height with shelf is 2 U
Delivery comprises
Item
1
Qty
2
2
1
Description
Deposit for excess cable lengths, St, 1.5 mm,
height 55 mm, RAL 7021
Assembly kit
Order Information
Description
Part no.
23130-050
Note
쮿 Velcro see page 1.162
쮿 Shelves see from page 1.145
쮿 Depth members see page 1.143
01006068
01006069
VARISTAR Datacom/Networking ServiceP LUS
SCHROFF.PENTAIR.EN
Part number in normal type: ready for despatch within 10 working days
1.163
Cabinets – VARISTAR Datacom/Networking ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined
freely
쮿 Configuration tables from page 1.165
assembly
Assembled by professionals. Double benefit!
Assembly of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Download CAD data and send back with modifications
solution
Simple. Fast. From one source.
쮿 Climate control, complete assembly, cabling (power supply),
function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
academy
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
1.164
lifecycle
replacement parts
Varistar RAL 7021 ServicePLUS: Configuration and assembly
쮿 Dimensions:
– Height: 24 ... 47 U (1200 ... 2200 mm)
– Width: 600 and 800 mm
– Depth: 600, 800, 900, 1000, 1100 and 1200 mm
Page
쮿 Colour: Frame and all covers in black grey (RAL 7021)
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
쮿 Once you have selected the desired cabinet dimensions, the row number
(first column of the configuration tables) will guide you through all
subsequent configuration pages that apply to these dimensions
(see example below)
쮿 The cabinet is assembled by us and ready for despatch within 10 working days
Frames, side-by-side
mounting kits, adjustable
feet, castors
1.166
Side panels, lateral cable
ducting
1.167
Decorative frames,
glass doors
1.168
Steel doors
1.169
Double doors, cover
panels
1.170
Rear panels,
connection plates
1.171
Top covers
1.172
Flat top covers with cutout zones
1.173
Fan top covers
1.174
Base plates
1.175
Bases/plinths
1.176
1.177
Swing frames
1.179
Shelves
1.180
19" shelves
1.182
Slide rails
1.184
Cable ducting with C-rails,
1.185
cable support rails
Accessories for cabling
1.186
ServicePLUS RAL 7035/
RAL 7021
1.189
01004077
Example configuration (here: row 20)
Qty
1
1
2
1
1
1
SCHROFF.PENTAIR.EN
Description
Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece
Side panel with quick release fastener, PU 2 pieces
Safety lock for side panel, PU 4 pieces
Rear panel screw-fixed, 1 piece
Glazed door with single point locking, 1 piece
Adjustable feet, PU 4 pieces
Order no.
20130-019/05
21130-051/05
23130-132/05
21130-069/05
21130-129/05
23130-079/05
1.165
RAL 7021
Frames, side-by-side mounting kits, adjustable feet, castors
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
07004078
Completely in RAL 7021
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.166
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
For dynamic load,
static loadcarrying capacity: St, 1.5 mm, zincplated, with
400 kg,
central GND/
St, 1.5 mm, zincearthing
plated, with
point; please
central GND/
order adjustable
earthing point;
feet or castors
please order
separately
adjustable feet or
castors
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
20130-001
20130-002
20130-035
20130-036
20130-578
20130-579
20130-003
20130-004
20130-037
20130-038
20130-005
20130-006
20130-007
20130-008
20130-013
20130-014
20130-015
20130-016
20130-018
20130-019
20130-020
20130-021
20130-580
20130-581
20130-022
20130-023
20130-024
20130-025
20130-582
20130-583
20130-027
20130-028
20130-029
20130-030
20130-584
20130-585
20130-031
20130-032
20130-033
20130-034
20130-586
20130-587
20130-051
20130-052
20130-085
20130-086
20130-588
20130-589
20130-053
20130-054
20130-087
20130-088
20130-055
20130-056
20130-057
20130-058
20130-063
20130-064
20130-065
20130-066
20130-068
20130-069
20130-070
20130-071
20130-590
20130-591
20130-072
20130-073
20130-074
20130-075
20130-592
20130-593
20130-077
20130-078
20130-079
20130-080
20130-594
20130-595
20130-081
20130-082
20130-083
20130-084
20130-596
20130-597
Side-by-side
mounting kit
IP 20
07004117
side-by-side
mounting
brackets
(4 pieces), St
Adjustable feet
01004081
Castors
With 2 jacking
With adjustable
feet
feet
01004082
01004156
for the frame,
for the frame,
for the frame,
static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity:
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
with base/plinth with base/plinth with base/plinth
RAL 7021
PU 1 kit
supplied loose
PU 4 pieces
assembled
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
RAL 7021
Side panels, lateral cable ducting
Side panel
With quick
Lock
release fastener
Screw-fixed side panel
Side panel
Inside locking
Cable panel
Width 150 mm
Lateral cable ducting
Cable panel
Cable ladder
Width 250 mm
Width 300 mm
H
1
10
01004084
01004072
for quick-release
St, 1 mm, incl.
fasteners of one
GND/earthing,
side panel;
please order lock
4 locks sufficient
separately
for 2 side panels
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
RAL 7021
PU 2 pieces
assembled
21130-041
21130-042
21130-524
21130-525
PU 4 pieces
assembled
23130-132
21130-041
21130-042
21130-524
21130-525
21130-043
21130-044
21130-043
21130-044
21130-047
21130-048
21130-047
21130-048
21130-050
21130-051
21130-052
21130-053
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
21130-050
21130-051
21130-052
21130-053
23130-132
21130-055
21130-056
21130-057
21130-058
23130-132
21130-055
21130-056
21130-057
21130-058
23130-132
01004083
St, 1 mm, incl.
GND/earthing
RAL 7021
PU 2 pieces
assembled
21130-001
21130-002
21130-516
21130-517
21130-532
21130-533
21130-001
21130-002
21130-516
21130-517
21130-003
21130-004
21130-003
21130-004
21130-007
21130-008
21130-007
21130-008
21130-010
21130-011
21130-012
21130-013
21130-534
21130-535
21130-010
21130-011
21130-012
21130-013
21130-534
21130-535
21130-015
21130-016
21130-017
21130-017
21130-536
21130-537
21130-015
21130-016
21130-017
21130-017
21130-536
21130-537
W
01006104
bracket, St,
1 mm,
finish AlZn;
with retention
screws
01006103
St, 1 mm, with cut-outs
for cable ties or Velcro
see page
1.186
01006075
round steel,
zinc-plated,
height 1800 mm,
for cable ties or
Velcro
see page
1.186
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
23130-373
23130-373
23130-373
23130-373
23130-373
23130-420
23130-149
23130-373
23130-420
23130-149
23130-373
23130-421
23130-150
23130-554
23130-373
23130-421
23130-150
23130-554
23130-373
23130-422
23130-151
23130-555
23130-373
23130-422
23130-151
23130-555
1.167
RAL 7021
Decorative frames, glass doors
Deco frame
Deco frame
Adaptor bracket
01004086
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.168
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004160
Glazed door
Single point
Lever handle
locking
01004088
Glazed door
3-point locking
01004147
with push button
for doors with
single point
locking
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
DIN profile half
cylinder
01004148
for lever handle,
common locking
Al, 19" plane
integrated,
front open, incl.
GND/earthing,
no door can be
fitted
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lock cover,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
21130-231
23130-230
21130-121
23130-067
21130-181
25127-995
21130-122
23130-067
21130-182
25127-995
21130-232
23130-231
21130-123
23130-067
21130-183
25127-995
21130-124
23130-067
25127-995
21130-234
23130-233
21130-127
23130-067
21130-187
25127-995
21130-128
23130-067
21130-188
25127-995
21130-235
23130-234
21130-129
23130-067
21130-189
25127-995
21130-130
23130-067
21130-190
25127-995
21130-236
23130-235
21130-131
23130-067
21130-191
25127-995
21130-132
23130-067
21130-192
25127-995
RAL 7021
Steel doors
Steel door, single point locking
Plain, with
Perforated
mounting frame
on inner side
Plain
01004089
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004089
Lever handle
01004090
01004147
with push button
for doors with
single point
locking
Steel door, 3-point locking
Plain
Perforated
01004090
DIN profile half
cylinder
01004093
St, 1.5 mm,
St, 1.5 mm,
opening angle
opening angle
180°, lever handle
180°, with
mounting frame with push button,
incl. GND/
on inner side,
earthing
lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
St, 1 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing,
designed to carry
extensive cutouts and
assemblies
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
21130-106
21130-566
21130-136
23130-067
21130-151
21130-700
25127-995
21130-107
21130-567
21130-137
23130-067
21130-152
21130-701
25127-995
21130-108
21130-568
21130-138
23130-067
21130-153
21130-702
25127-995
21130-109
21130-569
21130-139
23130-067
21130-154
21130-703
25127-995
21130-112
21130-572
21130-142
23130-067
21130-157
21130-706
25127-995
21130-113
21130-573
21130-143
23130-067
21130-158
21130-707
25127-995
21130-114
21130-574
21130-144
23130-067
21130-159
21130-708
25127-995
21130-115
21130-575
21130-145
23130-067
21130-160
21130-709
25127-995
21130-116
21130-576
21130-146
23130-067
21130-161
21130-710
25127-995
21130-117
21130-577
21130-147
23130-067
21130-162
21130-711
25127-995
1.169
RAL 7021
Double doors, cover panels
Glazed
Double door, 3-point locking
Plain
Perforated
DIN profile half
cylinder
Hinged
Cover panel
Brush strip for
cover panel
90°
01005065
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.170
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005064
01005066
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Sekurit glass,
lever handle with lever handle with
6 mm,
push button,
push button,
opening angle
incl. GND/
incl. GND/
180°,
earthing
earthing
lever handle with
push button,
incl. GND/
earthing
01004148
01006056
for lever handle, St, 1 mm, to cover
common locking the cabling space
next to the panel/
slide mounts
01006056
black
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
21130-670
21130-657
21130-683
25127-995
21130-671
21130-658
21130-684
25127-995
21130-672
21130-659
21130-685
25127-995
21130-673
21130-660
21130-686
25127-995
21130-676
21130-663
21130-689
25127-995
21130-677
21130-664
21130-690
25127-995
21130-678
21130-665
21130-691
25127-995
21130-679
21130-666
21130-692
25127-995
23130-343
23130-379
21130-680
21130-667
21130-692
25127-995
21130-681
21130-668
21130-694
25127-995
SCHROFF PRODUCT CATALOG E 05/2016
RAL 7021
Rear panels, connection plates
Rear panel
With quick
Lock
release fastener
01004087
Screw-fixed rear
panel
01004072
for quick-release
St, 1 mm, incl.
fasteners of rear
GND/earthing,
panel
please order lock
separately
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Dimensioning
connecting plate
door/rear panel
01004085
St, 1 mm, incl.
GND/earthing
Intermediate plate for door and rear panel
Plain
With brush strip
Assembly kit
01005071
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
01005063
01005069
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
RAL 7021
1 piece
assembled
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
Width
mm
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
PU 1 kit
assembled
21130-091
23130-133
21130-061
21130-092
23130-133
21130-062
21130-093
23130-133
21130-063
21130-094
23130-133
21130-064
21130-097
23130-133
21130-067
600
21130-472
21130-478
23130-164
21130-098
23130-133
21130-068
800
21130-473
21130-479
23130-164
21130-099
23130-133
21130-069
600
21130-472
21130-478
23130-164
21130-100
23130-133
21130-070
800
21130-473
21130-479
23130-164
21130-101
23130-133
21130-071
600
21130-472
21130-478
23130-164
21130-102
23130-133
21130-072
800
21130-473
21130-479
23130-164
1.171
RAL 7021
Top covers
Flat top cover
Perforated
Plain flush
top cover
Lifting eye
Flat top cover, raised
Spacer
Lifting eye
10
M12
01004096
St, 1.5 mm,
incl. GND/
earthing
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.172
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004097
01005064
for flat top cover,
St, 1.5 mm,
applications
fully perforated,
and load in
6 mm perforated,
accordance with
incl. GND/
DIN 582
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
M12
01004099
St, zinc-plated,
for raising a
top cover by
10 mm
01005064
for raised
flat top cover,
applications
and load in
accordance
with DIN 582
PU 4 pieces
assembled
RAL 7021
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
RAL 7021
Flat top covers with cut-out zones
Flat top cover
with cable
through-ducting
openings
Flat top cover
with cut-out
zones
Brush strip
Fan insert
Top cover assemblies
Cover plate for
Edge protection
cut-out zones,
perforated
W
01015052
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006093
St, 1.5 mm,
incl. GND/
earthing, cutout
size 85 mm x
449 mm
St, 1.5 mm,
incl. GND/
earthing, number
of cut-outs and
dimension
drawings
see page
1.9
RAL 7021
1 piece
fitted
RAL 7021
1 piece
assembled
21130-712
21130-713
21130-714
21130-715
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
10106092
01004102
230 VAC,
nylon, black,
one brush strip
with three fans,
covers a
410 m3/h,
lateral cut-out, completely wired,
two brush strips connecting cable
cover a center
IEC 320
cut-out
01009056
St, 1.5 mm,
6 mm hole
diameter,
incl. GND/
earthing
Lifting eye
M12
D
41003065
01005064
PVC, 3 m, black,
for open
cut-out zones
for flat top cover,
applications
and load
in accordance
with DIN 582
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
enclosed loose
PU 4 pieces
assembled
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
Part number in bold face type: ready for despatch within 2 working days
1.173
RAL 7021
Fan top covers
Top cover for
6 fans
Fan for
fan top cover
Fan top cover
Thermostat
Speed control
Lifting eye
30
10
50
°C
1000 mm
300 mm
300 mm
01005060
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.174
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
kta44844
01108052
01105055
fully wired,
St, 1.5 mm, raised fan with grille for with mains cable
90 ... 264 VAC,
top assembly,
230 VAC
cover,
230 VAC,
3 axial fans,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13
socket),
C13 socket;
ND/earthing,
h
adjustment range
external NTC
connecting cable
0 ... 60°C
sensor 1.5 m
2.5 m, SCHUKO/
IEC60320 C12
plug
RAL 7021
1 piece
assembled
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
01005085
for fan top cover,
applications
and load
in accordance
with DIN 582
1 piece
assembled
1 piece
assembled
1 piece
assembled
PU 4 pieces
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021
Base plates
Base plate, multipiece
01004104
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
St, 1.5 mm, multipiece, opening to
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimensions
see page
1.9
RAL 7021
1 piece
assembled
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
Brush strip
01004105
Base plate
Dust filter set
Cover plate
01004059
Base plate for lateral cable ducting
For cabinet
For cabinet
Brush strip
width 600 mm
width 800 mm
01004106
01006072
01006094
nylon, black
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm,
one brush strip
opening on
one side,
please order
brush strip
separately
St, 1.5 mm,
brush strip
opening on
both sides,
please order
brush strip
separately
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-074
23130-075
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-134
23130-135
23130-136
23130-378
23130-353
23130-354
23130-355
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-136
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-074
23130-134
23130-074
23130-134
23130-075
23130-135
23130-075
23130-135
23130-136
01006072
nylon, black,
is assembled
laterally,
please order
one brush strip
at cabinet width
of 600 mm, but
two brush strips
at cabinet width
of 800 mm
1 piece
assembled
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
1.175
RAL 7021
Bases/plinths
Base/plinth,
ventilated
01004110
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.176
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Base/plinth
Side trim
Tilt protection,
extractable
01004053
01006055
Base/plinth, mobile
Base/plinth,
Tilt protection,
mobile
extractable
01004111
01006055
support with
adjustable feet
and 2 trims,
perforated,
1000 kg;
please order
side trims
separately
St, 1.5 mm
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
RAL 7021
PU 1 kit
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
RAL 7021
19" panel/slide mounts EIA
Painted RAL 7021
AIZn
U height identification for
19" panel/slide
mounts
19" assembly kit
M6
W
xf
c
D
Dimension
Standard fitting
01004146
01004112
00505050
sc128
assembly kit:
St, 1.75 mm; reduced-width adaptor paper strip, white,
xf = distance
bracket required for 800 mm width; serial numbered item 1: screws,
from front
from 1 ... 47 U
item 2: cage nuts,
depth members are required for
c = pitch of 19"
item 3: washers
panel/slide
mounts
D = cabinet depth
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7021
PU 1 pair
assembled
PU 1 pair
assembled
PU 4 pieces
assembled
PU 50 pieces
supplied loose
23130-021
23130-031
25127-997
21101-809
23130-021
23130-031
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
1.177
RAL 7021
Adapter bracket for reduced width, depth member, cross member
Adapter
bracket for
reduced width
Depth member,
3 rows
Heavy-load cross
member
W
xf
c
D
Dimension
Standard fitting
01004146
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
All RAL 7021 (black grey) RAL
7035 (light grey) on request
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.178
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004128
01004056
01004056
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
St, 1.5 mm,
finish AlZn;
only required for
partial-height
mounting
St, 2.5 mm
PU 4 pieces
assembled
PU 1 pair
assembled
PU 4 pieces
fitted
C
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-091
23130-091
23130-091
23130-091
23130-091
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-544
23130-544
23130-545
23130-546
23130-544
23130-545
23130-546
RAL 7021
Swing frames
Swing frame
Stop 120°
Swing frame trim
Asymmetrical
Symmetrical
assembly
assembly
1
1
2
2
100
200
01005070
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005061
Door opening 160°
Hinge 160°
Stop 160°
Safety lock
100
01005058
01005057
01005061
41001517
is screwed to the St, usable only in for swing frame,
instead of
connection with
swing frame in
square lock,
160° hinge,
place of the
incl. 2 keys
swing frame stop
120° hinge
is recommended
for safety reasons
St, 2 mm,
RAL 7021, loadcarrying capacity:
150 kg,
120° hinge,
square locks incl.
2 keys
St; for safety
reasons a swing
frame stop is
recommended
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
RAL 7021
1 piece
assembled
RAL 7021
PU 1 kit
assembled
RAL 7021
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
RAL 7021
PU 1 kit
assembled
1 piece
assembled
21130-413
23130-158
23130-160
23130-159
60113-267
21130-423
23130-158
21130-432
21130-442
23130-160
23130-159
60113-267
21130-414
23130-158
23130-160
23130-159
60113-267
21130-424
23130-158
21130-433
21130-443
23130-160
23130-159
60113-267
21130-416
23130-158
23130-160
23130-159
60113-267
21130-426
23130-158
21130-435
21130-445
23130-160
23130-159
60113-267
21130-417
23130-158
23130-160
23130-159
60113-267
21130-427
23130-158
21130-436
21130-446
23130-160
23130-159
60113-267
21130-418
23130-158
23130-160
23130-159
60113-267
21130-428
23130-158
21130-437
21130-447
23130-160
23130-159
60113-267
1.179
RAL 7021
Fixed shelves
Full depth
Stationary shelf
Shortened by
100 mm
01004142
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.180
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004142
Depth member,
3 rows
01004056
St, 1.5 mm,
75 kg, 1 U,
incl. GND/
earthing
St, 1.5 mm,
75 kg, 1 U,
depth 479 mm,
incl. GND/
earthing,
for recessed
installation order
depth members
separately
length 660 mm,
St, 1.5 mm,
finish AlZn,
required for
recessed shelf
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
AIZn
PU 1 pair
assembled
21130-323
21130-335
21130-336
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-323
21130-325
21130-333
21130-335
21130-323
21130-325
21130-333
21130-335
21130-323
21130-325
21130-326
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-552
21130-553
21130-323
21130-325
21130-326
21130-327
21130-550
21130-551
21130-333
21130-335
21130-336
21130-337
21130-552
21130-553
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
21130-322
21130-324
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
RAL 7021
Telescopic shelves
Full depth
01004144
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Shortened by 100
mm
Telescopic shelf, 2 U
Mounting
bracket
01004145
St, 1.5 mm,
St, 1.5 mm,
carrying
capacity 70/50 kg capacity 70/50 kg
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
telescopic slide, telescopic slide,
please order
please order
mounting bracket mounting bracket
separately
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-353
21130-355
21130-373
21130-375
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
21130-352
21130-354
21130-372
21130-374
01005054
T-bar lock
01004125
GND/earthing
05904052
St, finish AlZn
to lock the
telescopic shelf
for telescopic
shelf
PU 4 pieces
assembled
1 piece
assembled
1 piece
assembled
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
1.181
RAL 7021
19" shelves, fixed or telescopic, 1 U
19'' telescopic shelf, 1 U, 30 kg
Full depth
Shortened by
GND/earthing
100 mm
01004146
01004118
St, 1.5 mm,
xf = distance
static loadfrom front
carrying capacity
c = pitch of 19"
75 kg,
panel/slide
depth 600 mm,
mounts
incl. GND/
D = cabinet depth
earthing
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.182
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
Xf
Xf
xf
W
Xf
Xf
c
D
C
C
C
19'' stationary shelf, 1 U, 75 kg
Full depth
Shortened by
100 mm
C
Dimension
Standard fitting
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
01004119
St, 1.5 mm,
75 kg,
depth 500 mm,
incl. GND/
earthing
01004123
01004122
St, 1.5 mm, static load-carrying
capacity 30 kg, incl. telescopic slide;
please order GND/earthing kit
separately
05904052
for telescopic
shelf
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
PU 1 kit
assembled
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-303
21130-303
21130-309
21130-309
21130-309
21130-309
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-302
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-343
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
21130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
ELECTRONICS PROTECTION
RAL 7021
19'' telescopic shelves, 2 U
Full depth
Telescopic shelf, 2 U, 70 kg
Shortened by
T-bar lock
100 mm
GND/earthing
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
01004146
01004123
01004122
St, 1.5 mm, static St, 1.5 mm, static
xf = distance
load-carrying
load-carrying
from front
capacity 70 kg,
capacity 70 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
panel/slide
slide;
slide;
mounts
Please order
Please order
D = cabinet depth
T-bar lock and
W = cabinet width T-bar lock and
earthing kit
earthing kit
separately
separately
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-353
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
21130-352
01004125
05904052
to lock the
telescopic shelf
for telescopic
shelf
1 piece
assembled
PU 1 kit
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
1.183
RAL 7021
Slide rails
Dimension
Standard fitting
Slide rail
Short slide rail
100 kg
St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair
St, 2.5 mm, zinc-plated, static loadcarrying capacity 100 kg/pair
AlZn
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
zinc-plated
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
W
xf
c
D
25 kg
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.184
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004056
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
01004154
St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair
AlZn
PU 2 pieces
supplied loose
PU 10 pieces
supplied loose
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
RAL 7021
Cable ducting with C-rails, cable support rails
C-rail for
cabinet depth
01006109
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
C-rail for
cabinet width
Slide nut
Cable shell
01006107
St, 1.5 mm,
finish AlZn
St, 1.5 mm,
finish AlZn
AIZn
PU 2 pieces
supplied loose
AlZn
PU 2 pieces
supplied loose
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
01504054
vnt009
Cable retention
for C-rail
01006110
for C-rail
for C-rail or for
cable support
rail, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.162
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
PU 10 pieces
supplied loose
PU 10 pieces
supplied loose
PU 5 pieces
supplied loose
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
Cable support rail
For cabinet
For cabinet width
depth
01006108
01006106
St, 1.5 mm,
length 466.4 mm
St, 1.5 mm,
finish AlZn
RAL 7021
PU 2 pieces
supplied loose
RAL 7021
PU 2 pieces
supplied loose
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
1.185
RAL 7021
Plastic
31 x 92 mm
Cable bracket
Plastic
100 x 100 mm
Steel
100 x 100 mm
Steel
100 x 180 mm
43
92
31
01012085
01006079
Plastic, PA6,
plastic, PA6,
black; to slot into
black,
frame
to clip onto frame
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.186
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006081
01006098
St, zinc-plated,
to screw
onto frame or
19" panel/
slide mount
St, zinc-plated,
to screw onto
frame or
19" panel/
slide mount
PU 4 pieces
enclosed loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
RAL 7021
Fibre optic cable
bracket
01006074
(black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Deposit for
excess cable
lengths
01006113
Cable tie
Velcro
01005078
01005079
St, 1.5 mm,
finish AlZn
for assembly on
shelf or depth
member
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.162
black,
length 300 mm,
further
dimensions
see page
1.162
PU 2 pieces
supplied loose
PU 2 pieces
supplied loose
PU 25 pieces
supplied loose
PU 10 pieces
supplied loose
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
1.187
configuration
freely
쮿 Configuration tables from page 1.189
assembly
Fitting of all mechanical, electrical and
modification
solution
Integration and custom developments
supply), function test
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
reports
쮿 Further information: www.varistar.co.uk
1.188
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
Varistar RAL 7021/RAL 7035 ServicePLUS: Configuration and assembly
쮿 Dimensions:
Page
쮿 Colour: Frame, top cover, base in black grey (RAL 7021),
side panel, door, rear panel in light grey (RAL 7035);
differing colours/finishes are indicated
(see example below)
feet, castors
1.190
Side panels,
1.191
Decorative frames,
glass doors
1.192
Steel doors
1.193
Double doors,
cover panels
1.194
Rear panels,
connection plates
1.195
Top covers
1.196
1.197
Fan top covers
1.198
Base plates
1.199
Bases/plinths
1.200
1.201
Swing frames
1.203
Shelves
1.204
19" shelves
1.206
Slide rails
1.208
Cable ducting with Cprofiles, cable support
rails
1.209
1.210
01006114
Qty
1
1
2
1
1
1
SCHROFF.PENTAIR.EN
Description
800 mm, 1 piece
Order no.
20130-019/05
22130-051/05
23130-132/05
22130-069/05
22130-129/05
23130-079/05
Part number in normal type: ready for despatch within 10 working days
1.189
Cabinets – VARISTAR Datacom/Networking
RAL 7021 / RAL 7035
Frame
Slim-Line
400 kg
Heavy-Duty
800 kg
01004078
Colour combination RAL 7035 (light
grey)/RAL 7021 (black grey)
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.190
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
For dynamic load,
400 kg,
central GND/
plated, with
point; please
central GND/
order adjustable
earthing
feet or castors
point; please
separately
order adjustable
feet or castors
separately
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
20130-001
20130-002
20130-035
20130-036
20130-578
20130-579
20130-003
20130-004
20130-037
20130-038
20130-005
20130-006
20130-007
20130-008
20130-013
20130-014
20130-015
20130-016
20130-018
20130-019
20130-020
20130-021
20130-580
20130-581
20130-022
20130-023
20130-024
20130-025
20130-582
20130-583
20130-027
20130-028
20130-029
20130-030
20130-584
20130-585
20130-031
20130-032
20130-033
20130-034
20130-586
20130-587
20130-051
20130-052
20130-085
20130-086
20130-588
20130-589
20130-053
20130-054
20130-087
20130-088
20130-055
20130-056
20130-057
20130-058
20130-063
20130-064
20130-065
20130-066
20130-068
20130-069
20130-070
20130-071
20130-590
20130-591
20130-072
20130-073
20130-074
20130-075
20130-592
20130-593
20130-077
20130-078
20130-079
20130-080
20130-594
20130-595
20130-081
20130-082
20130-083
20130-084
20130-596
20130-597
Side-by-side
mounting kit
IP 20
07004120
side-by-side
mounting
brackets
(4 pieces), St
Adjustable feet
01004081
Castors
With 2 jacking
With adjustable
feet
feet
01004082
01004156
for the frame,
for the frame,
for the frame,
400 kg,
400 kg,
1000 kg,
cannot be used
cannot be used
cannot be used
PU 1 kit
supplied loose
PU 4 pieces
assembled
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
23130-061
23130-079
23130-077
23130-078
RAL 7021 / RAL 7035
Side panel
With quick
Lock
release fastener
Side panel
Inside locking
Cable panel
Width 150 mm
Cable panel
Cable ladder
Width 250 mm
Width 300 mm
H
1
10
01004084
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004072
St, 1 mm,
incl. GND/
earthing,
please order
lock separately
for quick-release
fasteners of one
side panel;
4 locks sufficient
for 2 side panels
RAL 7035
PU 2 pieces
assembled
PU 4 pieces
assembled
22130-041
22130-042
22130-524
22130-525
22130-041
22130-042
22130-524
22130-525
22130-043
22130-044
22130-043
22130-044
22130-047
22130-048
22130-047
22130-048
22130-050
22130-051
22130-052
22130-053
22130-050
22130-051
22130-052
22130-053
22130-055
22130-056
22130-057
22130-058
22130-055
22130-056
22130-057
22130-058
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
23130-132
01004083
St, 1 mm,
incl. GND/
earthing
RAL 7035
PU 2 pieces
assembled
22130-001
22130-002
22130-516
22130-517
22130-532
22130-533
22130-001
22130-002
22130-516
22130-517
22130-003
22130-004
22130-003
22130-004
22130-007
22130-008
22130-007
22130-008
22130-010
22130-011
22130-012
22130-013
22130-534
22130-535
22130-010
22130-011
22130-012
22130-013
22130-534
22130-535
22130-015
22130-516
22130-517
22130-018
22130-536
22130-537
22130-015
22130-516
22130-517
22130-018
22130-536
22130-537
W
01006104
bracket, St,
1 mm,
finish AlZn;
with retention
screws
01006103
see page
1.210
01006075
round steel,
zinc-plated,
height 1800 mm,
for cable ties or
Velcro
see page
1.210
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
23130-373
23130-373
23130-373
23130-373
23130-373
23130-420
23130-149
23130-373
23130-420
23130-149
23130-373
23130-421
23130-150
23130-554
23130-373
23130-421
23130-150
23130-554
23130-373
23130-422
23130-151
23130-555
23130-373
23130-422
23130-151
23130-555
1.191
RAL 7021 / RAL 7035
Deco frame
Deco frame
Adaptor bracket
01004086
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.192
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004160
Glazed door
Single point
Lever handle
locking
01004088
01004147
with push button
for doors with
single point
locking
Glazed door
3-point locking
01004091
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lever handle with
push button,
incl. GND/
earthing
DIN profile half
cylinder
01004148
for lever handle,
common locking
Al, 19" plane
integrated,
front open,
incl. GND/
earthing,
no door can
be fitted
St, 2 mm,
for deco frame,
for assembly of
slide rails and
shelves
St, 1.5 mm,
Sekurit glass,
6 mm,
opening angle
180°,
lock cover,
incl. GND/
earthing
RAL 7035
1 piece
assembled
RAL 7035
PU 1 pair
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
22130-231
23130-230
22130-121
23130-067
22130-181
25127-995
22130-122
23130-067
22130-182
25127-995
22130-232
23130-231
22130-123
23130-067
22130-183
25127-995
22130-124
23130-067
22130-184
25127-995
22130-234
23130-233
22130-127
23130-067
22130-187
25127-995
22130-128
23130-067
22130-188
25127-995
22130-235
23130-234
22130-129
23130-067
22130-189
25127-995
22130-130
23130-067
22130-190
25127-995
22130-236
23130-235
22130-131
23130-067
22130-191
25127-995
22130-132
23130-067
22130-192
25127-995
RAL 7021 / RAL 7035
Steel doors
Plain, with
Perforated
mounting frame
on inner side
Plain
01004089
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004089
Lever handle
01004090
01004147
with push button
for doors with
single point
locking
Plain
Perforated
01004090
DIN profile half
cylinder
01004093
St, 1.5 mm,
St, 1.5 mm,
opening angle
opening angle
180°, lever handle
180°, with
incl. GND/
on inner side,
earthing
lever handle
with push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
St, 1 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
St, 1,5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing,
designed to carry
assemblies
St, 1.5 mm,
opening angle
180°, lock cover,
incl. GND/
earthing
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
22130-106
22130-566
22130-136
23130-067
22130-151
21130-700
25127-995
22130-107
22130-567
22130-137
23130-067
22130-152
21130-701
25127-995
22130-108
22130-568
22130-138
23130-067
22130-153
21130-702
25127-995
22130-109
22130-569
22130-139
23130-067
22130-154
21130-703
25127-995
22130-112
22130-572
22130-142
23130-067
22130-157
21130-706
25127-995
22130-113
22130-573
22130-143
23130-067
22130-158
21130-707
25127-995
22130-114
22130-574
22130-144
23130-067
22130-159
21130-708
25127-995
22130-115
22130-575
22130-145
23130-067
22130-160
21130-709
25127-995
22130-116
22130-576
22130-146
23130-067
22130-161
21130-710
25127-995
22130-117
22130-577
22130-147
23130-067
22130-162
21130-711
25127-995
1.193
RAL 7021 / RAL 7035
Glazed
Plain
Perforated
DIN profile half
cylinder
Hinged
Cover panel
Brush strip for
cover panel
90°
01005065
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.194
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005064
01005066
St, 1.5 mm,
St, 1.5 mm,
frame, St,
opening angle
opening angle
1.5 mm,
180°,
180°,
Sekurit glass,
6 mm,
push button,
push button,
opening angle
incl. GND/
incl. GND/
180°,
earthing
earthing
lever handle with
push button,
incl. GND/
earthing
01004148
for lever handle,
common locking
01006056
St, 1 mm,
to cover the
cabling space
next to the panel/
slide mounts
01006056
black
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
21130-670
21130-657
21130-683
25127-995
21130-671
21130-658
21130-684
25127-995
21130-672
21130-659
21130-685
25127-995
21130-673
21130-660
21130-686
25127-995
21130-676
21130-663
21130-689
25127-995
21130-677
21130-664
21130-690
25127-995
21130-678
21130-665
21130-691
25127-995
21130-679
21130-666
21130-692
25127-995
23130-343
23130-379
21130-680
21130-667
21130-692
25127-995
21130-681
21130-668
21130-694
25127-995
RAL 7021 / RAL 7035
Rear panel
With quick
Lock
release fastener
01004087
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004072
Dimensioning
connecting plate
door/rear panel
01004085
Connecting plate for door and rear panel
Plain
With brush strip
Assembly kit
01005071
01005063
01005069
only required if
rear panel with
quick-release
fastener is
assembled above
the connecting
plate
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
St, 1 mm,
assembly also
possible at top,
height 400 mm,
please order
assembly kit
separately in
conjunction with
rear panel
Width
mm
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
PU 1 kit
assembled
22130-061
23130-133
22130-062
22130-093
23130-133
22130-063
22130-094
23130-133
22130-064
22130-097
23130-133
22130-067
600
22130-472
22130-478
23130-164
22130-098
23130-133
22130-068
800
22130-473
22130-479
23130-164
22130-099
23130-133
22130-069
600
22130-472
22130-478
23130-164
22130-100
23130-133
22130-070
800
22130-473
22130-479
23130-164
22130-101
23130-133
22130-071
600
22130-472
22130-478
23130-164
22130-102
23130-133
22130-072
800
22130-473
22130-479
23130-164
for quick-release
fasteners of
rear panel
St, 1 mm,
incl. GND/
earthing
RAL 7035
1 piece
assembled
PU 2 pieces
assembled
RAL 7035
1 piece
assembled
22130-091
23130-133
22130-092
St, 1 mm,
incl. GND/
earthing,
please order
lock separately
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
Screw-fixed rear
panel
door and rear
panel must be
selected 400 mm
shorter than the
cabinet height;
cannot be used
with double door
1.195
RAL 7021 / RAL 7035
Top covers
Flat top cover
Perforated
Plain flat
top cover
Lifting eye
Spacer
Lifting eye
10
M12
01004096
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.196
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004097
St, 1.5 mm,
incl. GND/
earthing
St, 1.5 mm,
fully perforated,
incl. GND/
earthing
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-246
21130-247
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-242
21130-243
21130-244
21130-245
21130-538
21130-539
21130-246
21130-247
21130-248
21130-249
21130-540
21130-541
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-266
21130-267
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
21130-262
21130-263
21130-264
21130-265
21130-546
21130-547
21130-266
21130-267
21130-268
21130-269
21130-548
21130-549
SCHROFF PRODUCT CATALOG E 05/2016
01005064
for flat top cover,
applications
and load in
accordance with
DIN 582
M12
01004099
St, zinc-plated,
for raising a
top cover by
10 mm
01005064
for raised
flat top cover,
applications
and load in
accordance
with DIN 582
PU 4 pieces
assembled
RAL 7021
PU 4 pieces
assembled
PU 4 pieces
assembled
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
23130-072
23130-068
23130-085
RAL 7021 / RAL 7035
Flat top cover
with cable
through-ducting
openings
Flat top cover
with cut-out
zones
Brush strip
Fan insert
Cover plate for
Edge protection
cut-out zones,
perforated
Lifting eye
M12
01015052
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006093
St, 1.5 mm,
incl. GND/
earthing, cutout
size 85 mm x 449
mm
St, 1.5 mm,
incl. GND/
earthing,
number of cutouts and
dimension
drawings
see page
1.9
RAL 7021
1 piece
fitted
RAL 7021
1 piece
assembled
21130-712
21130-713
21130-714
21130-715
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-712
21130-713
21130-714
21130-715
21130-716
21130-717
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-256
21130-257
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
21130-252
21130-253
21130-254
21130-255
21130-542
21130-543
21130-256
21130-257
21130-258
21130-259
21130-544
21130-545
10106092
01004102
230 VAC,
nylon, black,
one brush strip
with three fans,
covers a
410 m3/h,
cover a center
IEC 320
cut-out
01009056
St, 1.5 mm,
6 mm hole
diameter, incl.
GND/earthing
W
D
41003065
01005064
PVC, 3 m, black,
for open
cut-out zones
for flat top cover,
applications
and load
in accordance
with DIN 582
PU 2 pieces
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
1 piece
enclosed loose
PU 4 pieces
assembled
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
23130-069
23130-070
23130-071
28127-281
23130-072
1.197
RAL 7021 / RAL 7035
Fan top covers
Top cover for
6 fans
Fan for
fan top cover
Fan top cover
Thermostat
Speed control
Lifting eye
30
10
50
°C
1000 mm
300 mm
300 mm
01005060
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.198
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
kta44844
01108052
01105055
fully wired,
90 ... 264 VAC,
top assembly,
230 VAC
cover,
230 VAC,
3 axial fans,
(SCHUKO/UTE
input SCHUKO/
230 VAC,
plug/
UTE plug,
38x119x119 mm,
3
outlet IEC 60320
socket),
C13 socket;
ND/earthing,
h
adjustment range
external NTC
connecting cable
0 ... 60°C
sensor 1.5 m
2.5 m, SCHUKO/
IEC60320 C12
plug
RAL 7021
1 piece
assembled
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-402
21130-403
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
21130-400
21130-401
21130-406
21130-407
21130-402
21130-403
21130-404
21130-405
01005085
for fan top cover,
applications
and load
in accordance
with DIN 582
1 piece
assembled
1 piece
assembled
1 piece
assembled
PU 4 pieces
assembled
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
23130-165
20118-750
60715-005
23130-090
RAL 7021 / RAL 7035
Base plates
01004104
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
rear 200 mm
deep (no rear
opening with
300 mm cabinet
depth), incl. GND/
earthing,
dimensions
see page
1.9
RAL 7021
1 piece
assembled
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-005
23130-006
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
23130-001
23130-002
23130-003
23130-004
23130-358
23130-359
23130-005
23130-006
23130-007
23130-008
23130-360
23130-361
Brush strip
01004105
Base plate
Dust filter set
Cover plate
01004059
For cabinet
For cabinet
Brush strip
width 600 mm
width 800 mm
01004106
01006072
01006094
nylon, black
filter mat, white,
class M1,
in accordance
with EN 799-G3
St, 1.5 mm,
please order
gasket IP55
separately
St, 1.5 mm,
one brush strip
opening on
one side,
please order
brush strip
separately
St, 1.5 mm,
brush strip
opening on
both sides,
please order
brush strip
separately
1 piece
assembled
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-074
23130-075
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-134
23130-135
23130-136
23130-378
23130-353
23130-354
23130-355
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-074
23130-075
23130-076
23130-378
23130-353
23130-134
23130-135
23130-136
23130-378
23130-353
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-136
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-076
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-378
23130-353
23130-354
23130-355
23130-356
23130-357
23130-074
23130-134
23130-074
23130-134
23130-075
23130-135
23130-075
23130-135
23130-136
01006072
nylon, black,
is assembled
laterally,
please order
one brush strip
at cabinet width
of 600 mm, but
two brush strips
at cabinet width
of 800 mm
1 piece
assembled
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
23130-074
23130-134
23130-374
23130-375
23130-376
23130-377
Part number in bold face type: ready for despatch within 2 working days
1.199
RAL 7021 / RAL 7035
Bases/plinths
Base/plinth,
ventilated
01004110
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Base/plinth
Side trim
Tilt protection,
extractable
01004053
01006055
Base/plinth, mobile
Base/plinth,
Tilt protection,
mobile
extractable
01004156
01006055
support with
adjustable feet
and 2 trims,
perforated,
1000 kg;
please order
side trims
separately
St, 1.5 mm
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
support, St,
3 mm,
trim, St, 1.5 mm,
static loadcarrying
capacity on
castors 400 kg,
on adjustable feet
1000 kg
St, 2 mm,
for retrofitting
to the base,
incl. cover strip
RAL 7021
PU 1 kit
assembled
RAL 7021
PU 1 pair
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
RAL 7021
1 piece
assembled
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-169
23130-170
23130-171
23130-172
23130-362
23130-363
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-212
23130-213
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-208
23130-209
23130-210
23130-211
23130-368
23130-369
23130-212
23130-213
23130-214
23130-215
23130-370
23130-371
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-187
23130-194
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
23130-345
23130-346
23130-347
23130-348
23130-349
23130-350
23130-351
23130-352
RAL 7021 / RAL 7035
19" panel/slide mount EIA
RAL 7035
AIZn
19" panel/slide
mounts
19" assembly kit
M6
W
xf
c
D
Dimension
Standard fitting
01004146
01004112
00505050
sc128
assembly kit:
St, 1.75 mm, reduced-width adaptor paper strip, white,
xf = distance
from front
from 1 ... 47 U
item 2: cage nuts,
c = pitch of 19"
item 3: washers
partial-height mounting
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7035
PU 1 pair
assembled
PU 1 pair
assembled
PU 4 pieces
assembled
PU 50 pieces
supplied loose
23130-021
23130-031
25127-997
21101-809
23130-021
23130-031
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-022
23130-032
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-024
23130-034
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-025
23130-035
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
23130-026
23130-036
25127-997
21101-809
1.201
RAL 7021
Adapter
bracket for
reduced width
Depth member,
3 rows
Heavy-load cross
member
W
xf
c
D
Dimension
Standard fitting
01004146
xf = distance from
front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.202
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004128
01004056
01004056
St, 2 mm,
finish AlZn,
for fixing the
19" panel/slide
mounts in
800 mm wide
cabinets
St, 1.5 mm,
finish AlZn;
only required for
partial-height
mounting
St, 2.5 mm
PU 4 pieces
assembled
PU 1 pair
assembled
23130-081
PU 4 pieces
fitted
C
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-082
23130-083
23130-084
23130-364
23130-365
23130-091
23130-091
23130-091
23130-081
23130-082
23130-083
23130-084
23130-544
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-091
23130-365
23130-081
23130-082
23130-083
23130-084
23130-544
23130-364
23130-545
23130-365
23130-546
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-091
23130-083
23130-084
23130-544
23130-364
23130-365
23130-545
23130-546
RAL 7021 / RAL 7035
Swing frames
Swing frame
Stop 120°
Swing frame trim
Asymmetrical
Symmetrical
assembly
assembly
1
1
2
2
100
200
01005070
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01005061
Door opening 160°
Hinge 160°
Stop 160°
Safety lock
100
01005058
01005057
01005061
41001517
instead of
connection with
swing frame in
square lock,
160° hinge,
place of the
incl. 2 keys
swing frame stop
120° hinge
is recommended
for safety reasons
St, 2 mm,
150 kg,
120° hinge,
square locks
incl. 2 keys
St; for safety
reasons a swing
frame stop is
recommended
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
St, 1.5 mm,
RAL 7021,
trim (item 1, 2 x
width 100 mm)
incl. handle
(item 2)
and cut-out for
cable eyes
RAL 7021
1 piece
assembled
RAL 7021
PU 1 kit
assembled
RAL 7021
1 piece
assembled
RAL 7021
PU 2 pieces
assembled
PU 2 pieces
assembled
RAL 7021
PU 1 kit
assembled
1 piece
assembled
21130-413
23130-158
23130-160
23130-159
60113-267
21130-423
23130-158
21130-432
21130-442
23130-160
23130-159
60113-267
21130-414
23130-158
23130-160
23130-159
60113-267
21130-424
23130-158
21130-433
21130-443
23130-160
23130-159
60113-267
21130-416
23130-158
23130-160
23130-159
60113-267
21130-426
23130-158
21130-435
21130-445
23130-160
23130-159
60113-267
21130-417
23130-158
23130-160
23130-159
60113-267
21130-427
23130-158
21130-436
21130-446
23130-160
23130-159
60113-267
21130-418
23130-158
23130-160
23130-159
60113-267
21130-428
23130-158
21130-437
21130-447
23130-160
23130-159
60113-267
1.203
RAL 7021 / RAL 7035
Fixed shelves
Full depth
Stationary shelf
Shortened by
100 mm
01004142
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.204
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01004142
Depth member,
3 rows
01004056
St, 1.5 mm,
75 kg, 1 U,
incl. GND/
earthing
St, 1.5 mm,
75 kg, 1 U,
depth 479 mm,
incl. GND/
earthing,
for recessed
installation order
depth members
separately
length 660 mm,
St, 1.5 mm,
finish AlZn,
required for
recessed shelf
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
AIZn
PU 1 pair
assembled
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-323
22130-325
21130-333
21130-335
22130-323
22130-325
21130-333
21130-335
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-552
22130-553
22130-323
22130-325
22130-326
22130-327
22130-550
22130-551
21130-333
21130-335
22130-336
22130-337
22130-552
22130-553
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
22130-322
22130-324
22130-332
22130-334
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
23130-081
23130-082
23130-083
23130-084
23130-364
23130-365
RAL 7021 / RAL 7035
Telescopic shelves
Full depth
01004144
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Shortened by
100 mm
Mounting
bracket
01004145
St, 1.5 mm,
St, 1.5 mm,
static loadstatic loadcarrying
carrying
(width 600/
(width 600/
800 mm), incl.
800 mm), incl.
please order
please order
separately
separately
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-353
22130-355
22130-373
22130-375
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
22130-352
22130-354
22130-372
22130-374
01005054
T-bar lock
01004125
GND/earthing
05904052
St, finish AlZn
to lock the
telescopic shelf
for telescopic
shelf
PU 4 pieces
assembled
1 piece
assembled
1 piece
assembled
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
23130-274
23130-092
23130-140
1.205
Full depth
Shortened by
100 mm
Full depth
Shortened by
GND/earthing
100 mm
C
Xf
Xf
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
C
RAL 7021 / RAL 7035
01004146
01004118
St, 1.5 mm,
xf = distance
carrying capacity
c = pitch of 19"
75 kg,
panel/slide
depth 600 mm,
mounts
incl. GND/
D = cabinet depth
earthing
W = cabinet width
01004119
St, 1.5 mm,
75 kg,
depth 500 mm,
incl. GND/
earthing
01004123
01004122
separately
05904052
for telescopic
shelf
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
xf
mm
c
mm
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
PU 1 kit
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-303
22130-303
22130-309
22130-309
22130-309
22130-309
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-302
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-343
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
22130-342
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
23130-140
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.206
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
RAL 7021 / RAL 7035
Full depth
Shortened by
T-bar lock
100 mm
GND/earthing
xf
W
Xf
Xf
c
D
C
C
Dimension
Standard fitting
01004146
01004123
01004122
xf = distance
load-carrying
load-carrying
from front
capacity 70 kg,
capacity 70 kg,
c = pitch of 19"
incl. telescopic
incl. telescopic
panel/slide
slide; Please
slide; Please
mounts
D = cabinet depth order T-bar lock order T-bar lock
and earthing kit
W = cabinet width and earthing kit
separately
separately
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
RAL 7035
1 piece
assembled
RAL 7035
1 piece
assembled
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-353
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
22130-352
01004125
05904052
to lock the
telescopic shelf
for telescopic
shelf
1 piece
assembled
PU 1 kit
assembled
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
23130-092
23130-140
1.207
RAL 7021 / RAL 7035
Slide rails
Dimension
Standard fitting
Slide rail
Short slide rail
100 kg
AlZn
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
zinc-plated
PU 2 pieces
PU 10 pieces
supplied loose
supplied loose
W
xf
c
D
25 kg
01004146
xf = distance
from front
c = pitch of 19"
panel/slide
mounts
D = cabinet depth
W = cabinet width
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.208
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
xf
mm
50
150
70
70
70
70
50
150
70
70
50
150
50
150
50
150
50
150
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
50
150
70
70
70
70
01004056
c
mm
500
500
740
740
740
740
500
500
740
740
500
500
500
500
500
500
500
500
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
500
500
740
740
740
740
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-096
23130-096
23130-098
23130-098
23130-098
23130-098
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-101
23130-101
23130-103
23130-103
23130-103
23130-103
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-118
23130-118
23130-120
23130-120
23130-120
23130-120
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
23130-123
23130-123
23130-125
23130-125
23130-125
23130-125
01004154
AlZn
PU 2 pieces
supplied loose
PU 10 pieces
supplied loose
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
23130-094
23130-095
ELECTRONICS PROTECTION
RAL 7021 / RAL 7035
C-rail for
cabinet depth
01006109
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
C-rail for
cabinet width
Slide nut
Cable shell
01006107
St, 1.5 mm,
finish AlZn
St, 1.5 mm,
finish AlZn
AIZn
PU 2 pieces
supplied loose
AlZn
PU 2 pieces
supplied loose
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
23130-086
23130-087
23130-088
23130-089
23130-366
23130-367
01504054
vnt009
Cable retention
for C-rail
01006110
for C-rail
for C-rail or for
cable support rail
, for cable
bundles of
42 ... 46 mm,
further
dimensions
see page
1.162
PA, UL 94 V-0,
black,
assembly by
clipping onto
the C-rail
PU 10 pieces
supplied loose
PU 10 pieces
supplied loose
PU 5 pieces
supplied loose
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
23130-333
21120-140
20114-731
60118-472
23130-334
21120-140
20114-731
60118-472
Cable support rail
For cabinet
For cabinet width
depth
01006108
01006106
St, 1.5 mm,
length 466,4 mm
St, 1.5 mm,
finish AlZn
RAL 7021
PU 2 pieces
supplied loose
RAL 7021
PU 2 pieces
supplied loose
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
23130-326
23130-328
23130-329
23130-330
23130-331
23130-332
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
21236-093
23130-312
1.209
RAL 7021 / RAL 7035
Accessories for cabling
Plastic
31 x 92 mm
Cable bracket
Plastic
Steel
100 x 100 mm
100 x 100 mm
Steel
100 x 180 mm
43
92
31
01012085
01006079
Plastic, PA6,
plastic, PA6,
black; to slot into
black;
frame
to clip onto frame
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1.210
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
01006081
01006098
St, zinc-plated,
to screw
onto frame or
19" panel/
slide mount
St, zinc-plated,
to screw onto
frame or
19" panel/
slide mount
PU 4 pieces
enclosed loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
PU 4 pieces
supplied loose
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
23130-506
23130-506
23130-336
23130-341
23130-342
RAL 7021 / RAL 7035
Fibre optic cable
bracket
01006074
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
24
24
24
24
24
24
24
24
24
24
29
29
29
29
38
38
38
38
42
42
42
42
42
42
42
42
42
42
42
42
47
47
47
47
47
47
47
47
47
47
47
47
1200
1200
1200
1200
1200
1200
1200
1200
1200
1200
1400
1400
1400
1400
1800
1800
1800
1800
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2000
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
2200
600
600
600
600
600
600
800
800
800
800
600
600
800
800
600
600
800
800
600
600
600
600
600
600
800
800
800
800
800
800
600
600
600
600
600
600
800
800
800
800
800
800
SCHROFF.PENTAIR.EN
600
800
900
1000
1100
1200
600
800
900
1000
600
800
600
800
600
800
600
800
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
600
800
900
1000
1100
1200
Deposit for
excess cable
lengths
01006113
Cable tie
Velcro
01005078
01005079
St, 1.5 mm,
finish AlZn
for assembly on
shelf or depth
member
plastic,
92 mm x 2.5 mm,
further
dimensions
see page
1.162
black,
length 300 mm,
further
dimensions
see page
1.162
PU 2 pieces
supplied loose
PU 2 pieces
supplied loose
PU 25 pieces
supplied loose
PU 10 pieces
supplied loose
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
23130-050
20118-351
20118-624
23130-372
23130-050
20118-351
20118-624
1.211
Cabinets – VARISTAR Datacom/Networking ServicePLUS
Cooling solutions for beginners and experts
Text
With Schroff's aisle containment you can boost the cooling
efficiency of your data center considerably while simultaneously
cutting the energy costs drastically. Consistently separating cold
supply air and warm exhaust air produces a high degree of
efficiency. Schroff's containment elements can be easily
mounted, also subsequently. The cream of the crop: because they
go with most cabinet types, you always profit from our innovative
solutions.
Schroff's containments - individual applications,
safe investments and future-proof
Based on the Schroff Varistar cabinet platform, cold aisle
containment systems are simple to create This concept may be
adapted or refitted to a location's special room conditions and
cooling requirements.
01008024
Containments
Cold aisle containment
Text
01008074
A high degree of efficiency is reached by the homogeneous
distribution of cold air in front of the servers. Radiation losses are
lower and the existing room climatisation can be used more
efficiently via the double floor. If necessary, the cooling capacity in
the cold aisle can be expanded with LHX air/water heat
exchangers. By relieving the room air-conditioning, redundancy
increases.
VARISTA R Datacom/Networking ServicePLUS
1.212
Requirements and solutions for containments
Requirements
Text
쮿 New data centre for an international bank in a hosting centre
쮿 Constant homogenous cool air for all servers with low energy
consumption
쮿 Future proof in cooling, power and cable management
쮿 User friendly for facility management and IT
The solution
쮿 Cold aisle containment to reduce energy consumption
쮿 Automated fully double-glazed doors minimise cold air loss
쮿 Perforated base plates throughout for maximum passage of air
쮿 Transparent roof elements allow room lighting to be used
01008025
쮿 Higher positioning of roof elements for increased headroom
and sense of space
쮿 Cable duct integrated into roof elements, accessible from cold
aisle
쮿 Separate cable panel on cabinet top covers
01008031
SCHROFF.PENTAIR.EN
1.213
VARISTAR containmentMai n C atalogue
Cabinets – VARISTAR containment
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
01012006
VARISTAR containmentMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days
The Schroff containment system lets you create containment installations without problems.
Increase efficiency and cut energy costs
쮿 Consistent separation of cold and hot air
쮿 Overpressure in the containment: Blow-in temperature of air conditioner is almost the same as the
temperature
쮿 No temperature layering in front of the 19" plane inside the containment
Systems . . . . . . . 8
쮿 No subcooling: possibilities to optimize temperature in data centres
쮿 Higher packing density per cabinet is possible with the same climate control elements
쮿 Low investment with short ROI - no maintenance costs
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.202
SCHROFF PRODUCT CATALOG E 03/2017
Overview . . . . . . 1.202
VARISTAR containmentMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days
Containment of VARISTAR cabinets
쮿
쮿
쮿
쮿
Modular standard components enable flexible adaptation to the requirements of your IT
Base system simple to combine and modify
Minimal investment risk thanks to completely matched climate control system
Short implementation time with minimum outlay
Varistar containment system
쮿 Preconfigured containment solution from modular standard
components (consisting of 6 Varistar server cabinets, RAL
7021, height 2000 mm, width 800 mm, depth 1200 mm)
including containment components; containment aisle width
1200 mm)
VARISTAR
Platform . . . . . . . . . 1.4
Dimensions . . . . . . 1.8
Containment
system . . . . . . . . 1.204
쮿 Simple to expand or to use as the configuration basis for your
individual containment solution
쮿 Can be delivered in 10 working days
01014007
Doors
Doors
쮿 Sliding doors
– Mechanical
– Electronic
Swing doors . . . . . 1.205
Sliding doors,
mechanical,
Touch variant . . . . 1.205
Sliding door,
electronic . . . . . . . 1.207
Top covers
Top covers
쮿 Standard solutions for aisle width 1200 mm
Top cover
elements . . . . . . . . 1.208
쮿 Standard solutions for 2000 mm and 2200 mm high cabinets
쮿 Swing doors
01012073
쮿 For 600 mm and 800 mm wide cabinets
쮿 Integration of cabinets with other dimensions (heights)
쮿 Free aisle height can be raised by 84 mm
01012074
Air partitioning
Air partitioning . 1.211
쮿 For server and network cabinets
쮿 For cabinets with different widths and recessed 19" planes
쮿 Solid covers with cable ducting or cable routing
(cable fingers, cable channels)
쮿 Halogen-free gasketing UL 94 HF-1
01012055
ServicePLUS from page 1.215
e.g. set-up service and commissioning
e.g. custom modifications and developments
e.g. free combination of components
www.schroff.biz/ServicePLUS
ServicePLUS . . . 1.215
VARISTAR
Electronics . . . . . . 1.10
VARISTAR
EMC . . . . . . . . . . . . . 1.54
VARISTAR
Seismic . . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR
Air/water heat
exchangers . . . . . . 1.224
30407004
SCHROFF.PENTAIR.CO.UK
1.203
Varistar Containment Systems
VARISTA R containmentMain C atalogPart number in bold face type: ready for s hippi ng withi n 2 working daysPart number i n normal type: ready for shipping within 1 0 working days
쮿 Preconfigured containment solutions from modular standard
components
쮿 Consists of 6 Varistar server cabinets (height 2000 mm, width
800 mm, depth 1200 mm) including containment components
쮿 Containment aisle width 1200 mm, all components in RAL 7021
Delivery includes
01014007
Sliding containment door,
mechanical, touch
01012073
Swing containment door
01012070
Item
1
Qty
6
2
3
24
6
4
5
12
6
6
6
7
24
8
24
9
10
11
12
13
12
24
48
4
1
14
1
15
1
16
17
6
2
18
19
1
1
Description
Welded basic frame, Slim-Line, St profile, zincplated, powder-coated, RAL 7021
Adjustable foot
Flat top cover, raised, St, RAL 7021, cutouts for brush
strip mounting
Brush strip for cable entry to flat top cover
Front door, St, RAL 7021, with 180° hinges and
perforation, 3-point locking and lever handle
Rear door, double door, St, RAL 7021, with 180° hinges
and perforation, 3-point locking and lever handle
Cross member, RAL 7021, to accept 19" panel/slide
mounts
19" panel/slide mounts, RAL 7021, mounted at 75 mm
intervals
Air baffle, St, RAL 7021, with brush strip for cable ducting
Central C rail for lateral cable routing in cabinet
Steel cable bracket
Side panel, screw-fixed, for aisle closure, St, RAL 7021
Sliding containment doors, mechanical, Al extruded
frame, 10 mm laminated safety glass, sliding mechanism
and rail, fixing materials kit
Swing containment doors, St frame, 1.5 mm, with 6 mm
single pane safety glass and 180° hinges
Top containment covers, frame St, 2 mm, RAL 7021,
7 mm laminated safety glass, length 1200 mm
Fixing materials for top cover universal profile
Top cover universal profile, Al, length 2400 mm,
RAL 7021
Side-by-side mounting kit for cabinets
Containment gasketing kit
Separator for adjustable cabinet foot
Order Information
Description
1.204
Part no.
10130-250
Swing doors
VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days
쮿 Suitable for 2000 and 2200 mm high cabinets
쮿 Double doors suitable for an aisle width of 1200 mm
쮿 2 colours
– Black grey (RAL 7021)
– Light grey (RAL 7035)
Delivery comprises
Item
1
Qty
2
2
1
Description
Frame St, 1.5 mm; with single pane safety glass 6 mm
and 180° hinge, 2-point magnetic locking on main door,
bolt on side door to lock into the floor
Fixing material kit (for cabinet side)
Order Information
01012070
Accessories
Description
Colour
Swing doors
RAL 7021
Swing doors
RAL 7035
Accessories
Door locking PU 1 pieces
Door cover mask for unequal aisle heights
Part no.
21130-583
22130-583
23130-437
Page 1.216
Note
쮿 Please order suitable door cover masks (above the door)
separately
쮿 Optional lever handle with lock on request
01012068
Door cover mask
Lock
01012060
Part number in normal type: ready for despatch within 10 working days
1.205
Sliding door, mechanical,
Touch variant
Main Catalogue
쮿 Doors open symmetrically (both wings open at same time);
door catch with magnet (door stays open); closes automatically
when lightly tapped
쮿 Colour black grey (RAL 7021)
Delivery comprises
Item
1
Qty
2
2
3
1
1
Description
Sliding door, frame Al extrusion;
laminated safety glass 10 mm, sliding gear
Slide rail with front trim
Order Information
01012073
Accessories
Description
Sliding door, mechanical, Touch variant version
Accessories
Reed contact 1 piece
Door seal cover for various aisle heights
Part no.
21130-060
60130-065
Page 1.217
Note
쮿 Please order suitable door cover maskSs (above the door)
separately
01012067
Door cover mask
Assembly kit
1.206
01012059
Sliding door, electronic
쮿 Door is opened/closed using a button (outside and inside);
manually in case of power failure
쮿 Optional door activation with motion sensor or
operator unit with access control
Delivery comprises
01012072
Item
1
Qty
2
2
3
1
1
Description
laminated safety glass 10 mm, door sliding gear,
connector cable and button to operate door
Order Information
Description
Accessories
Battery pack 1 piece
Motion detector 1 piece
Part no.
21130-073
60130-065
60130-066
60130-067
Page 1.218
Note
separately
쮿 An assembly kit is required for cabinet height 2200 mm with
base/plinth, please order separately
쮿 The door system must be maintained and inspected regularly
Optional door opening with motion sensor
01010066
Accessories
01012069
Door cover mask
Assembly kit
01012059
1.207
Top cover elements
Main Catalogue
쮿 Suitable for an aisle width of 1200 mm
쮿 Top cover with safety glass (VSG)
쮿 For cabinet widths 600 and 800 mm
쮿 A top cover profile can raise the aisle height by 84 mm;
쮿 Top cover can be removed from inside (allows access to lighting
and facilitates maintenance works)
Delivery comprises
01008024
Item
1
Qty
1
2
1
Description
Frame St, 2 mm, RAL 7021; safety glass (VSG) 7 mm,
length 1200 mm
Fixing material kit
Order Information
Description
For cabinet width
mm
600
800
Top cover elements
Top cover elements
Accessories
Top cover profile Length 2400 mm, PU 2 pieces
Assembly kit bracket for top cover raising profile,
PU 6 pieces
Part no.
21130-588
21130-589
21130-594
23130-433
Note
쮿 Where a mechanical sliding door is used, the top cover
directly beside the door must be 100 mm narrower,
see page 1.205
01012074
Universal profile to raise top cover
VARISTA R containmentMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days
쮿 The top cover elements can be raised by 84 mm using a profile
쮿 The profile has a T-groove on the inside that allows lamps,
sensors, etc, to be mounted easily
Delivery comprises
Item
1
Qty
2
Description
Al extrusion, RAL 7021, length 2400 mm
Order Information
Application with raised top covers
01012051
Description
Universal top cover profile,, height 84 mm
Accessories
Assembly kit
Bracket for universal top cover profile, PU 6 pieces
Part no.
21130-594
23130-433
Note
쮿 To mount a profile, an assembly kit (2 pieces) is required;
Accessory: Assembly kit to
mount universal top cover
profile
1.208
01012052
Automatic enclosure top covers
MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days
쮿 Automatic containment top covers open automatically in the
event of fire so that the sprinkler systems installed above the
containment top cover can put out the fire. In normal operation,
the top covers are kept closed by electromagnets and open
when the floating contact of the fire detection system is opened
쮿 For cabinet widths of 600 or 800 mm
쮿 Top cover with safety glass, 7 mm
01017054
쮿 With the universal top cover profile, the aisle height can be
increased by 84 mm; please order separately
쮿 The top cover can be removed from the inside. When opened,
the top cover provides access to lighting and sprinkler systems
above the containment system for maintenance work
쮿 Please order the control unit, which can be used to control up
to 12 automatic top covers, separately
쮿 A 24 VDC power supply unit is required to operate the system.
Please order separately
Delivery includes
01017053
Item
1
Qty.
1
2
3
1
1
Description
Frame, St, 2 mm, RAL 7021; 7 mm laminated safety glass,
length 1200 mm, electromagnet with 1200 mm
connection cable
T-shaped connecting plug
Fixing materials kit
Order Information
Description
Automatic containment top cover, width 600 mm
Automatic containment top cover, width 800 mm
Accessories
Raised top cover Length 2400 mm, PU 2 pieces
Assembly kit
Control unit for automatic top covers 1 set
Power supply for control unit For power distribution of up
to 12 automatic top covers, input 100 to 240 VAC, output:
24 VDC, 40 W, 1 piece
Connecting/extension cable, 1 m
Connecting/extension cable, 2 m
Connecting/extension cable, 5 m
Part no.
21130-592
21130-593
21130-594
23130-433
23130-205
23130-227
23130-206
23130-207
23130-226
쮿 Control unit for up to 12 automatic top covers
쮿 Inputs:
– External 24 VDC power supply unit required, please order
separately
– 2 floating contacts for connecting to a fire detection system
and another opening/test button
01017002
쮿 Output: 24 VDC connection for the control and voltage supply of
up to 12 automatic enclosure top covers, which can be
connected in series
Order Information
Description
Part no.
23130-205
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.209
Adaptors for cable routing
쮿 Suitable for VARISTAR cabinets and all common cable panel
systems
Delivery comprises
Item
1
Qty
2
Description
St profile, RAL 7021
Order Information
Description
For cabinet depth
mm
1000
1200
Cable route adaptor
Cable route adaptor
Accessories
Mounting bracket for cable route adaptor
Bracket, St, PU 2 pieces
01012075
Part no.
21130-596
21130-597
21130-598
Note
쮿 Mounting bracket for cable route adaptor is required for
containment without universal top cover profile
01012076
1.210
Covers
Covers for 800 mm wide cabinets with adapter bracket for
reduced width
쮿 All around the front, covers prevent unwanted air shortcircuits,
i.e. the mixture of warm exhaust air with cold inbound air
쮿 For cabinet width 600 or 800 mm, for cabinet height 42 or 47 U
쮿 Versions for installation with adapter bracket for reduced width
or cross member
– Solid covers
– Covers for 800 mm wide cabinets with cut-outs for cable
routing
– Covers with vertical cable fingers for 800 mm wide cabinets
– Cable routing with cable channel (hinged cover at front) for
800 m wide cabinets
01012055
Covers solid, width
800 mm
01012054
Cover with lateral
cut-outs
01012056
Cover with cable
finger/cable channel
Covers for 800 mm wide cabinets with cross member
Covers, width 800 mm
01015054
Cover with lateral cut-outs
쮿 Suitable divider plates are available for 19" planes mounted
with
recess (70, 145, 220 mm)
쮿 Network and server cabinets can be arranged side by side
쮿 Gaskets, UL 94 HF-1, -20 °C ... 100° C
Delivery comprises
Item
1a
Qty
2
2
3
4
1
1
1
Description
Cover, St, 1 mm, RAL 7021, left/right
(at 600 mm width only gaskets instead of covers)
Cover, top, St, 1 mm, RAL 7021
Cover, bottom, St, 1 mm, RAL 7021
Fixing material kit, gaskets, user manual
01015055
Order Information
Height
Covers for front air separation
For 600 mm For 800 mm wide cabinets with adapter bracket for reduced
wide cabinets
width
Cover with
Cover with
Solid cover
Cover with
cable fingers cable panels
lateral
cut-outs for
cables
Part No.
Part No.
Part No.
Part No.
Part No.
21130-624
21130-627
21130-629
21130-618
21130-631
21130-620
with cross member
Solid cover
Cover with
lateral
cut-outs for
cables
Part No.
Part No.
U mm
42 2000 for 70 mm recessed 19" plane
23130-550
42 2000 for 145 mm recessed 19" plane
23130-550
42 2000 for 220 mm recessed 19" plane
21130-622
21130-633
21130-623
21130-636
21130-638
23130-550
47 2200 for 70 mm recessed 19" plane
21130-625
21130-628
21130-630
23130-551
47 2200 for 145 mm recessed 19" plane
21130-619
21130-632
21130-621
23130-551
47 2200 for 220 mm recessed 19" plane
21130-626
21130-634
21130-635
21130-637
21130-639
23130-551
Accessories
Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece
Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece
Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece
Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece
Brush strip for closing the open cable through-ducting opening, 1 U, black, PU 6 pieces
Clip-on 19" plastic front panels to close the open cable through-ducting opening of the lateral cladding parts , 1 U, black, PU
10 pieces
23130-558
23130-558
23130-558
23130-559
23130-559
23130-559
21130-640
21130-642
21130-641
21130-643
23130-153
D19BPT1RU
1.211
Basic kit for side-to-side-cooled switches
VARISTA R containmentP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Basic kit to divide the 19" plane in the front part of the cabinet
and to accept side trims for switches
쮿 For 800 mm wide VARISTAR cabinets
쮿 with 145 mm recessed 19" plane
쮿 Right front bezel with 5 x air inlets; air inlets that are not
required can be closed with easy-to-cut gasketing material
쮿 Left front bezel for back-to-back cabling with 3 x 19"/1 U cutouts (please order brush strips and filler panels separately)
쮿 Kit can also be retrofitted to cabinets already installed in rows
Delivery includes
Item
1
2
3
4
5
6
7
Qty
2
1
1
1
1
6
1
Description
Front frame, St, 1 mm, RAL 7021 (for top and bottom)
Cover, left, St, 1 mm, RAL 7021 (3 openings)
Cover, right, St, 1 mm, RAL 7021 (5 openings)
Base, St, 1 mm, AlZn, for Cisco side trim
Top cover, St, 1 mm, AlZn, for Cisco side trim
Gasketing (can be cut as required for air inlets)
Fixing materials kit, gasketing, user manual
01013067
Order Information
Cisco switches side trims
01013066
01013060
19" plastic front panels, brush
strips to close cable ducting
openings
For cabinet height
For cabinet width
U
mm
mm
42
2000
800
47
2200
800
Accessories
Side trims for Cisco switches for Cisco Switch 4503, side
trim AlZn, 1 mm, 1 kit
Side trims for Cisco switches for Cisco Switch 4506, side
Side trims for Cisco switches for Cisco Switch 4507, side
Side trims for Cisco switches for Cisco Switch 4510, side
Side trims for Cisco switches for Cisco Switch 6506, side
Side trims for Cisco switches for Cisco Switch 6509, side
Side trims for Cisco switches for Cisco Switch 6510, side
through-ducting opening of the lateral cladding parts 1
U, black, PU 10 pieces
opening 1 U, black, PU 6 pieces
Part no.
21130-646
21130-647
23130-490
23130-491
23130-492
23130-493
23130-494
23130-495
23130-496
D19BPT1RU
23130-153
Note
쮿 Please order appropriate quantity and suitable Cisco switch
side trims separately
쮿 Cover for lateral cable through-ducting openings (please order
brush strip and 19" front panel separately)
1.212
Separating walls
쮿 Where cabinets are arranged in rows the separating wall
replaces the cabinet side wall
쮿 Mounts laterally, prevents unauthorised access
쮿 For cabinet height 42 or 47 U and
cabinet depth 1000 mm or 1200 mm
Delivery comprises
Item
1
2
Qty
1
1
Description
Separating wall, St, 1 mm, finish AlZn
Fixing material kit, user manual
Order Information
For cabinet height
U
42
42
47
47
For cabinet depth
mm
1000
1200
1000
1200
Part no.
23130-480
23130-481
23130-484
23130-485
01012058
1.213
Gasketing
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 Gasketing kits to seal front against air short-circuits
Delivery comprises
Item
1
2
Qty
1
1
Description
Gasket, halogen-free
User manual
Order Information
Description
Vertical gasket for vertical sealing between
10 cabinets
Horizontal gasket for two 600 mm wide
cabinets with adjustable feet
Horizontal gasket for two 800 mm wide
Length
mm
Part no.
3000
23130-475
1200
23130-477
1600
23130-478
Vertical gasket
1.214
01012081
Horizontal gasket
01012082
Cabinets – Varistar ServicePLUS containment
Configuration aid for aisle containment
Varistar ServicePLUS c ontainmentMain Catalogue
쮿 For cabinet rows
– Cabinet height 2000 and 2200 mm
– Aisle width 1200 mm
– Cabinet width 600 mm and 800 mm
Page
Folding doors
1.216
쮿 Once you have selected the desires cabinet containment height,
the row number (first column of the configuration tables) guides you
through all subsequent configutations pages that apply to these
dimensions (see example below)
Sliding door (touch),
mechanical
1.217
쮿 Assembly on request
Automatic sliding doors
1.218
Top covers
1.219
Cable panel adapter,
covers beside 19" plane,
solid
1.221
쮿 Colour RAL 7021, swing door also in RAL 7035
쮿 Configure your containment system from individual components
Covers beside 19" plane,
800 mm, with adapter
1.222
Covers with cable ducting,
cable finger, cable
1.223
channel
01012065
Cover for various 19"
installation depth,
separating wall
1.224
Airflow for side-to-sidecooled switches
1.224
Separating wall,
gasketing kits
1.226
Configuration of SHX 30
air/water heat exchanger
1.227
Example 6 cabinet containment cells (here: row 6)
Qty
6
2
1
1
3
1
1
5
5
2
Description
Side-to-side cabinet, 47 U, 2200 mm high, 800 mm wide, 1200 mm deep,
with front and rear door, RAL 7021, 1 piece
(see chapter VARISTAR data/network systems)
Side panel screw fixed, height 47 U - 2200 mm, for cabinet depth 1200 mm,
RAL 7021, PU 2 pieces (see chapter VARISTAR data/network systems)
Sliding door, mechanical, for cabinet height 2200 mm, aisle height 2102 mm,
with adjustable foot + top cover raising element, 1 piece
Door cover mask to equalize aisle height, 1 piece
Top cover, for cabinet width 800 mm, aisle width 1200 mm, 1 piece
Universal top cover profile, length 2400 mm, height 84 mm, PU 2 pieces
Assembly kit for universal top cover profile, PU 6 pieces
Cover, for lateral termination, 70 mm recessed, PU 1 kit
Cover with lateral cutouts, by 145 mm recessed 19" plane, PU 1 kit
Cover for lateral termination, depth-offset 70 mm, 1 piece
Order no.
10130-233
22130-537
21130-060
21130-612
21130-589
21130-594
23130-433
21130-638
21130-632
21130-643
1.215
Swing doors
Main Catalogue
Order Information
Swing door
RAL 7021
RAL 7035
01012064
Cover
01012063
Frame, St, with single pane safety
glass 6 mm and 180° hinge,
3-point loking and lever handle
(please order lock separately),
door cover mask to equalise
aisle height,
1 piece
Door locking
01012068
01012060
St, 1.5 mm,
RAL 7021;
cover to equalise
aisle height
Door locking
mechanism
01012070
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
3
7
42
47
8
1.216
2000
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
1 piece
21130-583
22130-583
23130-437
21130-611
21130-612
21130-583
22130-583
23130-437
21130-612
21130-613
Sliding doors (touch), mechanical
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Order Information
Hand operated sliding door, touch
RAL 7021
Cover
01012062
Reed contact
01012067
01015001
Door cover mask
Prepared for
Sliding door,
to equalise aisle
integration into
frame St, with
height, 1 piece
door boxes,
single pane safety
magnet detects
glass 6 mm,
when door is
closes
opened; connects
automatically
to door plate
01012062
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
3
7
8
42
47
2000
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
21130-060
60130-065
21130-040
21130-060
60130-065
21130-040
21130-059
1.217
Main Catalogue
Order Information
RAL 7021
Cover
01012061
Reed contact
01012069
Motion detector
01015001
Battery pack
01015003
Prepared for
Door cover mask
Prepared for
Sliding door,
to equalise aisle
integration into mounting on door
frame, St,
box, power supply
height, 1 piece
door boxes,
with single pane
magnet detects via connector on
safety glass
door plate
when door is
6 mm,
opened; connects
closes electrically
to door plate
by pushbutton
01015002
Prepared for
integration into
door boxes
01012073
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2
3
7
42
47
8
1.218
2000
2200
Raising elements
2308
Base/plinth
2392
Base/plinth +
raised top cover
PU 2 pieces
1 piece
1 piece
1 piece
1 piece
21130-073
60130-065
60130-067
60130-066
60130-065
60130-067
60130-066
21130-040
21130-073
21130-040
21130-059
Top covers
Main Catalogue
Order Information
Top cover
600 mm width
Universal profile
to raise
top cover
800 mm width
01012050
Frame, St; with single pane safety
glass 7 mm,
aisle width 1200 mm
Assembly kit
01012051
01012052
Bracket to mount
Al extrusion,
the universal top
RAL 7021,
cover profile
length 2400 mm,
height 84 mm
01012074
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
3
42
2000
1 piece
21130-588
1 piece
21130-589
PU 2 pieces
PU 6 pieces
21130-594
23130-433
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
21130-594
23130-433
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
21130-594
23130-433
21130-594
23130-433
7
8
47
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
21130-588
21130-589
1.219
Automatic fan top covers
MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days
Order Information
Automatic top cover
600 mm width
800 mm width
Control unit for
top covers
01017053
Frame St, 2 mm, RAL 7021; 7
length 1200 mm,
connection cable,
T-shaped connecting plug and
01012074
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
47
8
1.220
2200
Power supply for
control unit
01017002
Connection/
extension
cable
Length 1 m
Connection/
extension
cable
Length 2 m
Connection/
extension
cable
Length 5 m
01617001
01017056
Control unit for
up to 12
automatic top
covers, inputs: 24 VDC and
2 floating
contacts; output:
24 VDC
For power
distribution of up
to 12 automatic
top covers,
input 100 to
240 VAC,
output: 24 VDC,
40 W
Cable with
plug, 1 m
Cable with
plug, 2 m
Cable with
plug, 5 m
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
21130-592
21130-593
23130-205
23130-227
23130-206 23130-207 23130-226
21130-592
21130-593
23130-205
23130-227
Cable panel adapter, covers beside 19" plane, solid
Main Catalogue
Order Information
for 1000 mm
cabinet depth
for 1200 mm
cabinet depth
Covers beside 19" plane, solid, 600 mm cabinet width
Mounting
bracket for
cable route
adaptor
for 70 mm
recessed 19"
plane
for 145 mm
recessed 19"
plane
for 220 mm
recessed 19"
plane
Tex
t
01012075
01012076
01012053
St profile, RAL 7021;
fits to cabinet with a mounting
bracket
and has drilled holes
to bolt on cable panel
Bracket, St,
1.5 mm
Gasketing on left and right; Cover at top and bottom
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 1 kit
PU 1 kit
PU 1 kit
21130-596
21130-597
21130-598
21130-624
21130-618
21130-622
21130-596
21130-597
21130-598
21130-625
21130-619
21130-626
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
8
42
47
2000
2200
1.221
Covers beside 19" plane, 800 mm, with adapter bracket for reduced width
Main Catalogue
Order Information
Cover, beside 19" plane,
800 mm cabinet width
for 70 mm
for 145 mm
for 220 mm
recessed
recessed
recessed
19" plane
19" plane
19" plane
for 70 mm
recessed
19" plane
for 145 mm
recessed
19" plane
for 220 mm
recessed
19" plane
Tex
t
01012055
Cover left, right, at top and bottom
01012054
Cover with cable routes left and right;
cover closed top and bottom
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
2
3
7
42
47
8
1.222
2000
2200
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
21130-627
21130-631
21130-633
21130-629
21130-620
21130-623
21130-628
21130-632
21130-634
21130-630
21130-621
21130-635
Covers with cable ducting, cable finger, cable channel
Main Catalogue
Order Information
Covers beside 19" plane, 800 mm cabinet width, with
cross member
Cover, solid
Cover with cable ducting
openings
Cover with
cable fingers
for 220 mm
recessed
19" plane
Cover with
cable channels
Cable panel
Lateral cable
ducting
Tex
t
01015054
01015055
Cover with cable ducting left and right; cover at top,
bottom solid, for 19" planes recessed to different depths
(25 mm increments)
01012056
Support with
cable fingers
and front covers
01012077
01012078
St, 1 mm,
St,
width 150 mm;
with cable
with perforations
channel and
hinged front cover for cable ties or
Velcro-type tape
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
8
47
2200
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 2 pieces
23130-550
23130-558
21130-636
21130-638
23130-421
23130-551
23130-559
21130-637
21130-639
23130-422
1.223
19" plastic front panels, lateral panels
Main Catalogue
Order Information
Closure for cut-outs in covers
19" plastic
panels
19" brush strip
Lateral panel
Depth offset
70 mm
Depth offset
145 mm
Tex
t
01012079
ABS, UL 94 V-0,
clips in
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
42
47
8
1.224
2000
2200
01012080
To close the open
for sealing the
cable routes
open cable
in lateral
ducting openings
panels
of the lateral trim;
6 brushes,
sufficient for
3 cutouts
01012057
Al, 2 mm
Plastic
Lateral panel for
unequal 19" mounting depths
PU 10 pieces
PU 6 pieces
1 piece
1 piece
D19BPT1RU
23130-153
21130-640
21130-642
D19BPT1RU
23130-153
21130-641
21130-643
Airflow for side-to-side-cooled switches
Order Information
Basic kit for Cisco
switches
Air circulation
from right to left
Switch 4503
Switch 4506
Switch 4507
Switch 4510
Switch 6506
Switch 6509
Switch 6513
Te
xt
01013060
01012051
AlZn, 1 mm; multiple side plates can be fitted one above another;
in all cases only one basic kit is required
Bezels, top cover
and base plate for
Cisco side trims
01013006
Aisle
height
(lower
edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
For cabinet
height H
No. U
3
7
8
42
47
mm
2000
2200
PU 1 kit
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
21130-646
23130-490 23130-491 23130-492 23130-493 23130-494 23130-495 23130-496
21130-647
1.225
Separating walls, gasketing kits
Order Information
Separating wall
Cabinet depth
1000 mm
Vertical gasket
Horizontal gasket
Cabinet depth
1200 mm
For 600 mm
wide cabinets
For 800 mm
wide cabinets
Tex
t
01012058
St, 1 mm;
lateral cabinet mounting,
01012081
PUR flexible foam,
colour similar to RAL 7021,
UL 94-HF1;
10 cabinets,
also suitable for base/plinth and
to raise top cover
01012082
2 x bracket, St, RAL 7021;
PUR flexible foam seal,
UL 94-HF1;
suitable for horizontal sealing
of 2 cabinets to bottom,
when adjustable feet are used
01013006
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
42
47
8
1.226
2000
2200
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 kit
23130-480
23130-481
23130-475
23130-477
23130-478
23130-484
23130-485
23130-475
23130-477
23130-478
Configuration of SHX 30 air/water heat exchanger
Order Information
Frame
1000 mm deep
SHX 30 air/water heat exchanger, 30 kW
1200 mm deep
Water connection at bottom
01013068
Water connection at top and bottom
(with condensate pump)
01013076
Rack (VARISTAR Slim-Line), St,
RAL 7021; top cover and base plate,
front and rear panel; prepared to
accommodate SHX 30 air/water heat
exchanger
01013077
2 PSUs,
redundant power
supply
1 PSU
2 PSUs,
redundant power
supply
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
42
2000
6
7
8
47
2200
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
10130-226
10130-227
60714-067
60714-068
60714-077
60714-078
10130-228
10130-229
60714-067
60714-068
60714-077
60714-078
1.227
Order Information
Gasketing for
adjustable feet
Base/plinth
Side trim for base/plinth
Depth 1000 mm
Depth 1200 mm
min. 2
max. 22
Adjustable feet
D
01013069
St, black, for the
rack, static loadcarrying capacity
1000 kg. Please
order gasketing
separately
01013070
100
100
D
300
01013071
Base plinth, St,
Polyurethane
cover, St, 1.5 mm,
gasketing,
suitable for front height 100 mm,
width 300 mm,
and rear, RAL
7021; for closing RAL 7021; please
order cover
the air gap at the
separately
front
01013072
St, 1.5 mm, height 100 mm,
RAL 7021
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
2
3
7
42
47
8
1.228
2000
2200
PU 4 pieces
PU 2 pieces
PU 1 kit
PU 2 pieces
PU 2 pieces
23130-511
23130-538
23130-507
23130-172
23130-363
23130-511
23130-538
23130-507
23130-172
23130-363
Order Information
Screw-fixed side panel
Depth 1000 mm
Separating wall
Depth 1200 mm
Cabinet depth
1000 mm
Cabinet depth
1200 mm
01013073
St, 1 mm, incl. GND/earthing
01013074
St, 1 mm, AlZn; lateral cabinet
mounting prevents unauthorized
access
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
2308
Base/plinth
2392
Base/plinth +
raised top cover
3
7
8
42
47
2000
2200
PU 2 pieces
PU 2 pieces
1 piece
1 piece
21130-013
21130-535
23130-480
23130-481
21130-018
21130-537
23130-484
23130-485
1.229
Order Information
Top cover
300 mm width
Raised top cover
01013079
Assembly kit
01012051
01012052
St, 2 mm,
RAL 7021, aisle
width 1200 mm
Al extrusion,
RAL 7021,
length 2400 mm,
height 84 mm
Mounting of top
cover raising
profile
1 piece
PU 2 pieces
PU 6 pieces
21130-594
23130-433
01013005
For cabinet
height H
No. U
mm
Aisle height
(lower edge)
mm
Raising elements
1
2018
Adjustable feet
2
2102
Adjustable feet +
raised top cover
3
42
2000
21130-648
2108
Base/plinth
4
2192
Base/plinth +
raised top cover
21130-594
23130-433
5
2218
Adjustable feet
6
2302
Adjustable feet +
raised top cover
21130-594
23130-433
21130-594
23130-433
7
8
47
2200
2308
Base/plinth
2392
Base/plinth +
raised top cover
21130-648
1.230
1.231
Varistar cabinet-based and row-bas ed coolingMai n C atalogue
Cabinets – Varistar cabinet-based and row-based cooling
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01017025
Front panels,
Power supply
Backplanes . . . 10
01013005
Front bottom or bottom/top water
connection, easy access and
greatest possible safety
Applications
The future for data centers
The SHX 30 heat exchanger is
especially suitable for use in the
following areas:
쮿 Data centers
쮿 19" and blade-server
applications
Connectors, front
panel component
쮿 Systems with extremely high
heat dissipation
1.224
01017015
Electronic monitoring unit with
display and interfaces
SCHROFF PRODUCT CATALOG E 06/2016
01013005
Six powerful, temperaturecontrolled fans. Easy access for
maintenance purposes during
operation
VARISTAR LHX+, the space-independent
complete cabinet system for dissipating
up to 34 kW of heat.
The air/water heat exchanger is installed in the
cabinet as complete unit on the left or right side.
The horizontal air flow provides for
uniform air dissipation over the entire
cabinet height.
01017060
Overview . . . . . . 1.224
Varistar cabinet-based and row-based coolingMain Catalogue
VARISTAR LHX+ with air/water heat exchanger
for data centers
쮿 Cooling capacity up to 34 kW
VARISTAR
쮿 Complete cabinet solution, static load capacity up to 1600 kg
쮿 Space-independent cooling, high energy efficiency
쮿 Water and air circuits are temperature controlled
쮿 Low noise level
쮿 Fans may be changed individually while the unit is operating
With single door
VARISTAR SHX+,
single door . . . . . . 1.230
VARISTAR SHX+,
double door . . . . . 1.231
With double door
01017003
(heat exchanger on left or right)
01017007
Accessories
쮿 Management system for monitoring LHX+ and other cabinet
parameters
Accessories
Heat exchangers . 1.232
Rack for heat
exchanger . . . . . . . 1.234
Adjustable feet . . . 1.235
Base/plinth . . . . . . 1.236
00711020
ServicePLUS
e.g. other cabinet dimensions
e.g. side-by-side mounting solutions
e.g. containment (cold aisle)
e.g. custom solutions (special sizes)
30407004
VARISTAR
VARISTAR
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR
Datacom and
Networking
1.225
Varistar cabinet-based and row-based coolingMAIN CATALOG P art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days
Optimum temperature for air/water heat exchanger
Since the thermal load continues to increase, conventional cooling methods eventually
reach their physical limits. It can happen that thermal load limits within a cabinet are
such that some height units must go unused.
ADVANTAGES
The solution:
Air/water heat exchangers installed close to the heat source not only increase the
cooling capacity per cabinet, but also improve the redundancy of the data center.
With intelligent control systems, air conditioners can quickly respond to the working
load of the equipment, thereby enabling additional savings.
쮿 Highest cooling capacity in the smallest
of spaces
Text
cooling capacity per cabinet, but also improve the redundancy of the data center. With
intelligent control systems, air conditioners can quickly respond to the working load of
쮿 Integrated solutions with spaceindependent thermal transfer
쮿 A wide variety of dimensions are
supported, short implementation time
and low planning effort
Thanks to the Ethernet and Modbus connection, Schroff air/water heat exchangers
can be monitored and configured. Operating parameters are easy to specify, and
temperature, fan speed and error protocols can be managed remotely.
Text
01015011
1.226
Varistar cabinet-bas ed and row-based coolingMAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days
Integrated heat exchanger
Heat exchanger mounted side-by-side
In this combination, an active heat exchanger integrated
into an 800 mm wide cabinet has the lowest space
requirement on the market. The closed system reduces
the noise level and controls itself by means of the thermal
load. With a cooling capacity of up to 34 kW1), the heat
exchanger is suitable for HPC applications. Multiple
cabinets can be mounted side-by-side to create a closed
system. Thanks to the low space requirement, reduced
noise level and ease of creating redundancy, this heat
exchanger is well suited also for medium-sized data
centers.
Active heat exchanger for containment systems with a cooling capacity of
up to 34 kW1). This in-row heat exchanger is mounted side-by-side to
cabinets within the aisle containment. This enables optimal scalability
with regard to planning for the cooling capacity and the redundancy of the
system.
Text
01017009
LHX+ cabinets mounted side-by-side with integrated heat
exchangers
01013005
SHX 30 in-row heat exchanger
Integrated heat exchanger:
Cooling capacity
Dimensions
Functions
In-row heat exchanger:
Cooling capacity
Dimensions
Functions
Up to 34 kW1)
Width 800 mm
Height 2100 mm
Depth 1000 to 1200 mm
IP 55 protection on request EMC
design on request 1600 kg static
load capacity Bottom/top water
connections Control system options
with an external temperature
sensor (Display in four languages)
Up to 34 kW
Width 300 mm
Height 2000 to 2200 mm
Water connections from bottom/top
Control system options with an
external temperature sensor
1) Cooling capacity 34 kW at +12 °C water flow temperature,
+24 °C cold air temperature, 4.5 m³/h water flow rate;
for other conditions refer to the diagram for the cooling capacity
1.227
Space-saving, low-noise and energy-efficient
Highly efficient and noise-optimized
Text
The Varistar heat exchanger range impresses customers with its high
energy efficiency and cooling capacity. Failure safety and ease of
servicing play a special role. The unit itself is designed for long life.
Sensitive components with a low MTBF have been consistently
dispensed with and necessary wear parts are treated carefully during
operation. Fans are positioned in the cold area to significantly increase
the service life of the bearings compared to operation in a warm-air
area. Additionally, the heat exchanger is equipped as standard with a
droplet separator and a condensate management system to prevent the
formation of water droplets in the air entry area to the server.
Compelling use of space
Since the heat exchanger is inserted on one side as a
complete module, in a cabinet only 800 mm wide, the 19"
plane can be used over its full height, with 42 U
(max. 52 U). This saves valuable space in the data center!
01017061
01017060
IN-ROW heat exchanger to cool your indoor aisle
containment
This in-row heat exchanger is specially designed to cool cabinets with
high thermal loads within an aisle containment structure and is
included in the row as a modular unit. Depending on the packaging
density, you can scale the units optimally and implement redundancy.
26°
C
01012083
1.228
One heat exchanger for multiple cabinets
Redundancy from side-by-side mounting
The option of mounting the cooling unit to the left or right of the
19" plane means it is easy to build very variable cooling systems
from multiple cabinets. If the full cooling capacity is not needed
initially, one unit can supply cold air to multiple cabinets mounted
side-by-side. In cabinets mounted side-by-side, the space for the
cooling unit is closed with an air baffle. If the necessary cooling
capacity increases, the air baffle is removed and an additional
cooling unit is inserted.
Redundant systems are also very easy to implement. If two
cabinets are mounted side-by-side with one heat exchanger each,
one unit can take over the cooling of both cabinets up to half of the
max. cooling capacity per cabinet.
Text
01017015
01017015
For installation and maintenance, the air conditioners of the Varistar series have a very service-friendly design. The water connections
are easy to access. Fans can be changed individually and very quickly while the unit is operating. However, if a defined threshold value
does arise, either in the cabinet or in the unit itself, each heat exchanger will provide valuable information for maintenance and service
work. Fan speeds and temperatures at various positions in the cooling circuit are measured via integrated communication interfaces
and can be shown on a display. However, all information (measured values, threshold values, etc) can also be transferred directly into
the network management system.
Text
쮿 Display
쮿 Bottom or top and bottom
water connections
쮿 Hot-swap-capable fans
쮿 Power supplies
쮿 Communication interface
쮿 External temperature sensor
쮿 Interlog interface
01017015
01013005
1.229
VARISTAR LHX+, cabinet with single door, integrated
air conditioner
쮿 Cabinet with air/water heat exchanger with cooling capacity of
34 kW
쮿 Max. static load capacity 1600 kg
쮿 Gasket all around reduces noise and suction of room air
Delivery includes (Fully assembled and grounded)
Item
1
Qty.
1
2
1
3
1
4
1
5
6
2
1
7
1
8
4
9
2
10
11
4
1
12
13
14
1
1
1
01017003
Description
Welded basic frame, Slim-Line, St profile, zinc-plated,
RAL 7021, with gasket all around
Flat roof, St, RAL 7021 with cable entry point in rear with
brush, entry point for water connection in rear, entry
points can be sealed with a gasket/cover plate
Front door glazed, St frame, RAL 7021, single-pane
safety glass 6 mm, 3 x 180° hinge, three-point closure,
pivoting lever handle for optional DIN profile half cylinder
Rear door, St, RAL 7021, 3 x 180° hinge, three-point
closure, pivoting lever handle for optional DIN profile half
cylinder
Side panel, screwed, St, RAL 7021
Baseplate, St, RAL 7021 with cable entry point in rear
with brush, entry point for water connection in rear,
entry points can be sealed with a gasket/cover plate
Base/plinth 100 mm, with additional center
crossmember, St, RAL 7021, removable covers,
integrated adjustable feet
19" panel/slide mount with EIA cut-outs, St, RAL 7021,
225 mm recessed in front, c dimension 740 mm distance
between front and rear 19" plane
Support rail for connecting the air/water heat exchanger
and 19" panel/slide mounts, St, RAL 7021
SHX 30 air/water heat exchanger, RAL 7021, 100
to 240 VAC, may be mounted on the left or right, see Order
Information
Power cable, length 1.5 m
Connecting cable for management unit
User manual (for online download)
Order Information
Height
U mm
42 2100
42 2100
Width
mm
800
800
Depth
mm
1200
1200
Heat
Water
Power
exchanger connection supply
Left
Right
Top
Top
Top and
bottom
Top and
bottom
42 2100 800
1200
Left
42 2100 800
1200
Right
Part no.
1
1
10130-300
2 redundant
10130-302
2 redundant
10130-303
Accessories
Lifting eye for top cover PU 4 pieces
Electronic closing (MLR3000),
13.56 MHz-MIFARE With reader, 1 set
Electronic locking (MRL3000), Mifare With reader, 1 set
10130-301
23130-072
23130-513
23130-565
Note
01017059
1.230
쮿 34 kW cooling capacity at +12 °C water flow temperature,
쮿 Other dimensions on request
VARISTAR LHX+, cabinet with double door, integrated air
conditioner
34 kW
쮿 Separate front and rear access doors for air/water heat
exchanger
Item Qty.
1
1
01017007
2
1
3
1
4
1
5
6
2
1
7
1
8
4
9
2
10
11
4
1
12
13
14
1
1
1
Description
brush, entry point for water connection in rear, entry points
Front door, divided asymmetrically, RAL 7021, 3 x
180° hinges, three-point closure, pivoting lever for optional
DIN profile half cylinder;
in front of the 19" plane, 600 mm, St frame, glazed, singlepane safety glass 6 mm, in front of the heat exchanger,
200 mm, St, with viewing window, single-pane safety glass
6 mm
Back door, divided asymmetrically, St, RAL7021, 3 x 180°
hinges, three-point closure, pivoting lever for optional DINprofile half cylinder; in front of the 19" plane, 600 mm,
in front of the heat exchanger, 200 mm
Baseplate, St, RAL 7021, cable entry point in rear, entry
point for water connection, entry points can be sealed with
gasket/cover plate
crossmember, St, RAL 7021, removable covers, integrated
adjustable feet
SHX 30 air/water heat exchanger, RAL 7021, 100 to 240 VAC,
may be mounted on the left or right, see Order Information
Order Information
Height
U mm
42 2100
42 2100
01017058
Width
mm
800
800
Depth
mm
1200
1200
Heat
Water
Power
Left
Right
Top
Top
Top and
bottom
Top and
bottom
42 2100 800
1200
Left
42 2100 800
1200
Right
Part no.
1
1
10130-304
2 redundant
10130-306
2 redundant
10130-307
Accessories
10130-305
23130-072
23130-513
23130-565
Note
1.231
쮿 Air/water heat exchanger with cooling capacity of 34 kW1)
Main CatalogueMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Water connection at bottom or bottom/top (with condensate
pump)
쮿 1 PSU or 2 PSUs (redundant)
쮿 Drop collector and condensate management
Delivery includes
Item
1
Qty
1
2
3
4
1
1
Description
100 ... 240 VAC
Mains cable, 1.5 m
Order Information
01017026
SHX 30 air/water heat exchanger, 34 kW1)
1 PSU
Water connection at
2 PSUs, redundant power
bottom
supply
1 PSU
and bottom (with
condensate pump)
supply
Accessories
Cabinet management basic units Height 44 mm, width
251 mm, depth 53 mm, for monitoring one air/water heat
exchanger, max. 16 sensor values, 1 piece
440 mm, depth 134 mm, for monitoring up to max. 8 air/
water heat exchangers, max 128 sensor values, 1 piece
Capteur de température à raccorder directement au
SHX 30, longueur du câble 2 m, 1 pièce
Part No.
60714-067
60714-068
60714-077
60714-078
EMX111
EMX888
60130-724
Note
Please order optional management unit separately
Rear connections at bottom
01013020
Rear connections at top
01013021
쮿 Cabinet management base unit connects via RJ 45 interface
쮿 Web interface
– Automatic detection of connected Varistar SHX 30 air/water
heat exchanger
– Inlet temperature of servers (parameter can be set via web
interface)
– Switch on/off of cooler
– Adjustment of set temperature and fan speed
– Air temperature monitoring at front/rear, fan speed and
water inlet temperature
– Temperature monitoring/control using an external
temperature sensor (please order separately)
쮿 1) Cooling capacity 34 kW at +12 °C water flow temperature, +24 °C cold
air temperature, 4.5 m³/h water flow rate; for other conditions refer to
Management browser representation
1.232
00711017
Graph: cold air temperature against cooling capacity
Technical data
Cooling capacity
Useful cooling capacity
Normal temperature
1) Cold air temperature
2) Cooling capacity at different cold water temperatures
Fan speed 100%
Maximum water flow rate 4.5 m3/h
3) Water inlet temperature
01017062
34 kW1)
18 to 50 °C (adjustable in 0.1 °C
increments)
Max. control deviation of emergency 4 (factory-preset)
cooling can be set to 0–8 K relative to
the set value
Water circuit
Cooling medium 2)
Water, water-glycol mix
(max. 33%)
Water inlet temperature 3)
6 to 18 °C
Water flow volume
up to 4.5 m 3/h
Pressure loss in device at
3.0 m3/h, max. 1.3 bar; 4.5 m3/h,
max. 3.1 bar
Water conduit
Copper
Water connection inlet/outlet
Rp 1"
Condensate drain connection
Rp 1/2"
Air circuit
Max. airflow volume, temperature- 5000 m3/h
dependent control
Electrical data AC
Supply voltage (single phase)
100 to 240 VAC (50 / 60 Hz)
Max. current consumption
6 A / 12 A (230 V / 115 V)
1100 W / 750 W
Max. power consumption
fan speed 100% / Normal
operation (fan speed 80%)
Pre-fuse (on building side)
D 10 A / D 16 A (230 V / 115 V)
Interface
RS 485 Modbus interface
Connection option for external
monitoring system
RS 232 (SUB-D 9-pin)
Serial access
Input, terminal block with
10 potential-free contacts
connection
General data
Ambient temperature: Transport,
-25 to 70 °C / 5 to 70 °C
storage when fully emptied / when
containing 35% glycol / in operation
outside of the cabinet
Relative humidity for transport and 5 to 95%
storage (non-condensing)
Heat exchanger dimensions
Height 1849 mm, width 189.5 mm,
depth 850 mm
Heat exchanger weight
110 kg
Weight of cabinet with cooling
370 kg
module approx.
2) To ensure problem-free operation of the air/water heat exchanger the quality
requirements of the water must be maintained; the appropriate anti-corrosion and
frost protection agents are dependent on the environment in which the unit is used
and on the external chiller (VDI 3803, see also user manual).
3) At water inlet temperatures of < 6 °C und > 15 °C, the control accuracy can no
longer be guaranteed. There is also a risk of condensation if the water temperature
falls short of the given limits.
1.233
Rack for SHX 30 air/water heat exchanger
쮿 Rack (VARISTAR Slim-Line) to accommodate a SHX 30 air/
쮿 Height 2000 or 2200 mm
쮿 Depth 1000 or 1200 mm
쮿 Width 300 mm
쮿 Covers top, bottom, front and rear
Delivery includes
Item
1
Qty
1
2
1
3
4
5
1
1
1
2
1
3
Description
Welded basic rack (Slim-Line) from steel
profiles, RAL 7021; earthing stud
Flat top cover, St, RAL 7021; with brush strip cut-out
(for water) and on the side for cable ducting
Front frame, St, RAL 7021
Rear cover, perforated, lockable
Base plate, St, RAL 7021; with brush strip cut-out (for
Order Information
4
5
01013068
01013080
01013022
Water enters via brush strips; lateral cable ducting for power/data
cables
1.234
Height
Width
Depth
mm
mm
mm
2000
300
1000
2000
300
1200
2200
300
1000
2200
300
1200
Accessories
Adjustable feet for the frame, RAL 7021, static loadcarrying capacity 1000 kg, PU 4 pieces
Gasketing for adjustable feet Polyurethane foam
gasketing, color similar to RAL 7021, length 300 mm, for
sealing front and rear, PU 2 pieces
Base/plinth Base plinth, St, width 300 mm, height 100 mm;
bolts on to rack, PU 2 pieces
Side trim St, 1.5 mm, height 100 mm, depth 1000 mm,
PU 2 pieces
Side trim St, 1.5 mm, height 100 mm, depth 1200 mm,
PU 2 pieces
Side panel, screw-fixed for IP 55 St, 1 mm,
height 2000 mm, depth 1000 mm, 2 pieces
height 2000 mm, depth 1200 mm, 2 pieces
height 2200 mm, depth 1200 mm, 2 pieces
Separating wall St, 1 mm, AlZn, height 2000 mm,
for depth 1000 mm, 1 piece
for depth 1200 mm, 1 piece
Separating wall St, 1 mm, AlZn, height 2200 mm,
Part no.
10130-226
10130-227
10130-228
10130-229
23130-511
23130-538
23130-507
23130-172
23130-363
21130-013
21130-535
21130-018
21130-537
23130-480
23130-481
23130-484
23130-485
ELECTRONICS PROTECTION
Adjustable feet
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Adjustable feet for direct mounting onto frame
쮿 Static load-carrying capacity 1000 kg
Delivery includes
Item
1
2
Qty
4
1
Description
Adjustable feet, St, polyamide, black
Order Information
MRA44483
Description
Adjustable feet
Accessories
Part no.
23130-511
23130-538
쮿 For horizontal sealing at bottom in containments (front and
rear) where adjustable feet are used
Delivery includes
Item
1
Qty
2
Description
Gasketing, flexible polyurethane, length 300 mm, color
similar to RAL 7021, conforms to UL 94-HF1
Order Information
Description
Part no.
23130-538
01013070
1.235
Base/plinth
Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days
쮿 Base for 300 mm wide frame (air/water heat exchanger)
쮿 Base is bolted to the frame at front and rear; please order side
trims separately
Delivery includes
D
Item
1
Qty
2
2
1
Description
Base, St, 1.5 mm; with built-in feet, width 300 mm, color
RAL 7021
100
Order Information
300
01013071
Base/plinth
Height
Width
mm
mm
100
300
Accessories
Side trim RAL 7021, St, 1.5 mm, height 100 mm,
depth 1000 mm, PU 2 pieces
depth 1200 mm, PU 2 pieces
Part no.
23130-507
23130-172
23130-363
100
D
Accessories: Side covers
01013072
Top cover element for aisle containment (SHX 30 air/
쮿 Width 300 mm (when fitting directly beside the "Sliding door,
mechanical" a 200 mm width must be used)
쮿 The universal top cover profile enables the aisle height to be
raised by 84 mm and cabinets with other heights can also be
integrated. Please order separately
Width 300 mm
01013079
Delivery includes
Item
1
2
Qty
1
1
Description
Top cover, St, 2 mm, RAL 7021, plate length 1200 mm
Order Information
Width Description
mm
300
For cabinet width 300 mm (aisle width 1200 mm)
Accessories
Raised top cover Al extrusion, RAL 7021, length 2400 mm,
height 84 mm, PU 2 pieces; raises top cover elements by
84 mm and allows integration of cabinets with other
heights
Assembly kit Mounting of top cover raising profile,
PU 6 pieces
1.236
Part no.
21130-648
21130-594
23130-433
Management for SHX 30
쮿 Connection of cabinet management basic unit with RJ 45
interface
쮿 Automatic detection of the connected LHX 20/40 air/water heat
exchangers
쮿 Monitored parameters:
interface
– Air temperature front (2 parameters)
– Air temperature rear (2 parameters)
– Fan speed
(6 parameters for LHX 20, 7 parameters for LHX 40)
– Water inflow temperature (1 parameter)
Note
00711017
Browser display
쮿 For cabinet management base unit see page 3.46
쮿 Sensors (temperature, humidity, differential pressure,
airflow...) and hub for connecting multiple sensors see from
page 3.47
1
LA
N
4
2
3
EMX -111
00711020
01011051
5
1
4
LA
N
2
3
EMX -888
Item
1
2
3
4
5
01011050
01011050
Description
Real-time monitoring of web graphical user interface (GUI)
EMX
LHX 20/40
Telemonitored temperature and humidity sensors
Part number in bold face type: ready for despatch within 2 working days
1.237
VARISTAR LHX 3 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
Cabinets – VARISTAR LHX 3
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01008029
Front panels,
01007010
Air/water heat exchanger in base/
plinth
- Extractable
- Water connection from rear,
optionally from front
- Cable ducting to rear, can be
sealed with slide covers
Advantages:
By separating the heat exchanger
(in the base/plinth) from the fan
(in the top cover), the cold air flows
evenly through the cabinet.
Reflowing of the warm air to the
heat exchanger through channels
in the side panels.
Applications:
Measuring and test devices in
industrial areas, e.g.:
- Temperature sensitive precision
measurements
- Engine and transmission test
bench
Power supply
Backplanes . . . 10
Connectors, front
panel component
01007014
Top cover with fan
- Fan unit in top cover
- Airflow through channels in side
panel
- Easy maintenance and exchange
01007055
1.236
SCHROFF PRODUCT CATALOG E 05/2016
Overview . . . . . . 1.236
VARISTAR LHX 3Mai n C atalogue
Air/water heat exchanger for measuring and test equipment
쮿 Complete cabinet to protection class IP 55 with heat exchanger
in base/plinth and fan tray in top cover
쮿 Even circulation of cold air within the cabinet, no air short circuits as with
side-by-side mounted units
VARISTAR
쮿 Cooling capacity up to 3 kW
쮿 Very low noise level of 45 dB(A)
VARISTAR LHX 3
VARISTAR LHX 3 . 1.238
쮿 Air/water heat exchanger in base/plinth
쮿 Airflow through channels in side panel
쮿 Leakage safety
01007015
VARISTAR LHX 19" chassis, available on request
쮿 Air/water heat exchanger as 19" chassis
쮿 Airflow through channels in rear door (cabinets may be
mounted side-by-side)
쮿 Devices with different airflows may be used (e.g. from left to
right or from front to rear)
쮿 Variable air outlet in 19" chassis, thus selective direction of
cold air
01008088
ServicePLUS
e.g. climate control, complete assembly,
cabling (power supply), function test
e.g. delivery to point of use, erection service,
commissioning, replacement service,
maintenance, repairs, replacement parts
30407004
VARISTAR
VARISTAR
EMC. . . . . . . . . . . . . 1.54
VARISTAR
VARISTAR
Datacom and
Networking
1.237
VARISTAR LHX 3
VARISTA R LHX 3 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Cabinet in accordance with protection class IP 55, RAL 7021,
with glass front door
쮿 Air/water heat exchanger (3 kW) in base/plinth (extractable)
쮿 Static load-carrying capacity 800 kg (Heavy-Duty frame)
Delivery comprises (completely assembled and earthed)
Item
1
Qty
1
2
3
1
1
4
1
5
1
6
7
2
1
8
4
9
1
10
1
01007015
2
3
Description
Welded basic frame, Heavy-Duty, St profile, zinc-plated,
RAL 7021, IP 55, with all-round gasket
Radial fan, 230 VAC, assembled on cross member,
SCHUKO/UTE connector, cable length 1.5 m
Front door, glass, frame RAL 7021, 180° hinge,
multi-point locking, lever handle for optional
Rear door, St, RAL 7021, 180° hinge, multi-point
interlocking, lever handle for optional DIN profile half
cylinder
Side panel, screwed, St, RAL 7021, with ventilation duct
Base/plinth with base plate, St, RAL 7021, height
200 mm, removable covers at front and rear, integrated
feet; cable ducting to rear, can be sealed with slide
covers
175 mm recessed at front, 500 mm distance between
Air/water heat exchanger, 3 kW, RAL 7021; integrated
in base/plinth, extractable
User manual
Order Information
5
Height
Usable height
Width
Depth
mm
U
mm
mm
2000
34
600
800
2200
38
600
800
DIN profile half cylinder, common locking for lever handle
(1 key fits all locks) incl. 2 keys
Thermostat with mains/line connector, 230 VAC, SCHUKO/
UTE connector, IEC-320 female connector, 1 piece
1
8
4
Part no.
10130-193
10130-194
25127-995
20118-750
Note
쮿 Further dimensions and versions available on request (e.g. with
heat exchanger as 19" chassis or with airflow in the rear panel)
쮿 Technical data see page 1.239
6
7
9
01007061
1.238
Technical data LHX 3
Cooling capacity
Usable cooling capacity
(cooling water inlet temperature 10° C,
air exit temperature 20° C)
01007055
A fan sucks in the warm air at the top and leads it downwards
through the lateral air channels in the side panels to the air/water
heat exchanger. The cold air is let into the cabinet at the bottom.
Water circuit
Cooling medium 1)
Water inlet temperature 2)
Water flow volume
Max. water pressure
Static pressure loss in device at 0.5 m3/h
Water conduit
Connection condensat drain
Water
6 ... 16 °C
up to 2.0 m3/h
6 bar
0.1 bar
Copper
Rp 1/2"
Ø 10 mm
Air circuit
Airflow volume
900 m 3/h
Electrical data
Supply voltage, single phase
Current consumption
Power consumption
Apparent power at full load
Protection fuse
230 VAC, 50/60 Hz
0.38 A
85 W
120 VA
2A
General Data
Cabinet type of protection
Ambient temperature during transport
Ambient temperature outside of cabinet
(during operation)
Relative humidity level
Noise level at 100 % fan performance
Weight: cabinet/heat exchanger
Dimensions of air/water heat exchanger
Height
Width
Depth
Diagram of LHX 3 characteristics
Usable cooling capacity in kW
3 KW
IP 55
-25 ... 70 °C
5 ... 70 °C
5 ... 95 %
45.2 dB(A)
approx. 115 kg/35 kg
199 mm
464 mm
425 mm
(465 mm with handles)
1) For an optimal operation of the air/water heat exchanger the demands on the
water quality have to be fulfilled (VDE 3803, please see user manual)
2) If the water inlet temperature falls short of 16 °C the formation of condensation
should be anticipated
kW
3,0
l
VH2O = 400 /h
2,9
2,8
2,7
2,6
2,5
2,4
8
10
12
Incoming water temperature
14
16
18
°C
01007076
1.239
N ovastarMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
Cabinets – Novastar
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
07011036
Light - slim - robust
The base frame, made in lightweight aluminium, is the
basis for your individual NOVASTAR. And now you
decide: small or large, in standard depth or with
extended space for cabling and heat dissipation,
whether as a stand-alone solution or stacked one on
top of another and bolted together.
The NOVASTAR platform concept leaves no wish
neglected. And regardless of how you put your
NOVASTAR together, the internal dimensions remain
consistently compatible with 19" technology. Unwanted
spaces in either height or width are now a thing of the
past.
With a cabinet width of only 553 mm, NOVASTAR is the
slimmest of all 19" cabinets. It has a slender, filigreed
look, almost like a piece of designer furniture. This
impression is further reinforced by the different finishes
of the frame and cover trim and the plain, modern fullglass doors.
Because of this, NOVASTAR is not only used in offices
and laboratories but also in sound and TV studios. And
indeed as a collector's item in the occasional home!
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
07011023
Backplanes . . . 10
Simple fitting of side panel
without tools
07011025
07011020
07011022
07011007
Door with 180° opening angle thanks to new hinge concept;
can be mounted left or right
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
07011028
Extensive selection of castors
1.240
SCHROFF PRODUCT CATALOG E 06/2017
Heavy-Duty frame with lateral groove
for mounting e.g. of carrier arm systems
Cabinets – Novastar
Overview . . . . . . 1.240
Novastar
Main CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
The inNOVAtive 19" electronics cabinet
쮿
쮿
쮿
쮿
쮿
Type of protection up to IP 40
Bolted, die-cast frame with Al extrusions
Cabinet width only 553 mm
Static load-carrying capacity up to 400 kg
Colours: RAL 7021 or colour combination RAL 7021/ RAL 7035
19" cabinet,
with glass door (smoke grey) and rear panel
Dimensions . . . . . . 1.243
19" cabinet,
door and rear panel combination freely selectable
NOVASTAR
19" cabinet with
smoke tintend
glass door and
rear panel . . . . . . . 1.246
Selectable
combination of 19"
cabinet, door and
rear panel . . . . . . . 1.247
Accessories
07011010
07011013
쮿 Height of Slim-Line 12 ... 20 U (load-carrying
capacity 200 kg)
쮿 Height of Slim-Line 9 ... 25 U (load-carrying
capacity 200 kg)
쮿 Height of Heavy-Duty 38 ... 43 U (load-carrying
capacity 400 kg)
쮿 Height of Heavy-Duty 34 ... 47 U (load-carrying
capacity 400 kg)
쮿 Depth 600, 800 mm
쮿 Depth 500, 600, 800 mm
쮿 Door and rear panel can be equipped individually
Doors and
cable ducting
systems . . . . . . . . . 1.247
Rear panels and
cable ducting
systems . . . . . . . . . 1.251
Base plates . . . . . . 1.252
Castors . . . . . . . . . . 1.253
Bases/plinths . . . . 1.254
19" panel/slide
mounts . . . . . . . . . . 1.255
Depth members . . 1.255
Slide rails . . . . . . . . 1.256
Shelves . . . . . . . . . 1.258
Support arm
system . . . . . . . . . . 1.260
Slide nut . . . . . . . . . 1.260
Standards/Approvals
쮿 External and internal dimensions in accordance with IEC 60297-3-100
쮿 Type of protection IP 40 in accordance with IE 60529
쮿 Earth connections in accordance with DIN EN 50178 / VDE 0160
ServicePLUS from page 1.261
ServicePLUS . . . 1.261
e.g. individual configuration and assembly
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (cut-outs)
e.g. variants of uprights (Slim-Line, Heavy-Duty)
30407004
SCHROFF.PENTAIR.CO.UK
www.schroff.biz/ServicePLUS
1.241
Cabinets – Novastar
Novastar configurator
NovastarMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shipping within 10 working days
With the Schroff brand, Pentair offers a wide range of electronics
cabinets and other electronic protection products. Instead of
restricting the range to a few standard products, Schroff offers
bespoke solutions which fulfill the specific requirements of the
application. Schroff configurations are easy-to-operate tools
which make it possible to configure and modify products quickly
and easily: Design Your Standard.
The Novastar configurator is a web-based tool with an intuitive
graphical user interface and multilingual menus in English,
German, and French. These make configuring Novastar cabinets
quick and easy.
Individual solutions are just a click away
쮿 Configurations can start with the frame or by modifying readyconfigured or previously configured Novastar cabinets
쮿 Large selection of dimensions, frame types, door types, side panels,
top covers, and base plates
쮿 Accessories such as shelves and slide rails can be mounted
쮿 Selection of special cabinet colors
쮿 Cutouts incorporated for switches and connectors or logos, text, and
other graphics printed
07017001
Real-time 3D CAD model generation
쮿 Real-time display of configured cabinets with all modifications in
several views and adjustable transparency
쮿 The configuration adjusts in real time and offers different mounting
options
쮿 Real-time generation of 3D CAD models and/or 2D native CAD files in
more than 30 CAD file formats for downloading or for immediate
further processing and integration into the user's CAD software
쮿 Real-time generation of a bill of materials with all components of the
configured cabinet
쮿 Quotes issued quickly for customized Novastar cabinets and an inquiry
is simply a click away
Ease of use
쮿 Graphical user interface with drag-and-drop functionality and
immediate display of the selected configuration
쮿 Available components are listed as illustrations in the menu for quick
access and easy identification
쮿 Intelligent configurator logic indicates where components can be
installed, ensures compatibility and shows relevant optional
components
쮿 The "U" height scale helps you to position the components correctly
쮿 Components identified with mouse-over functionality
쮿 Components exchanged using simple drag-and-drop functionality or
deleted in the bill of materials
쮿 Non-assembled accessories can be added to the bill of materials
쮿 No need to download any programs or apps, or install any software or
plug-ins No registration required
쮿 The optional, free user account registration provides access to
additional functions
1.242
Cabinets – Novastar
Dimension drawings Slim-Line frames
Frame
451
451
10
465
84,
5
8
h
H
465
553
D
07011094
Frame (top view)
07011093
Main Catalogue
쮿 Lightweight aluminium die-cast frame and lightweight vertical
profile
553
467
쮿 Static load-carrying capacity 200 kg, tested in accordance with
IEC 61587-1
d
Cabinet height
U
6
9
12
16
34
38
43
47
Foot height 8 mm
d1
56
33
64
c
56
d1
D
106
60
Frame dimensions
Ø8
451
465
w
451
465
w
H
mm
357
456
589
767
945
1167
1567
1745
1967
2145
h
mm
268
401
535
713
890
1112
1513
1690
1913
2090
07011098
Upright at front/rear
50,5
Upright at rear
50,5
30
Frame dimensions
Cabinet
depth
7
M8
12
19" to
19" plane
Floor mounting
c
mm
407
507
707
807
907
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
12
07011096
D
mm
500
600
800
900
1000
Adjustable feet,
castors, lifting eye,
top cover fixing
d
mm
405
505
705
805
905
19,5
36
33
19,5
36
60
7
84,5
M8
84,5
10
10
30
07011097
1.243
Cabinets – Novastar
Dimension drawings Heavy-Duty frames
Frame
19" upright
451
451
465
h
H
75
84,
8
465
10
553
D
07011095
Frame (top view)
07011092
쮿 Light aluminium die-cast frame and robust vertical profile
553
쮿 Static load-carrying capacity 400 kg, tested in accordance with
IEC 61587-1
467
쮿 Lateral groove for mounting accessories
Cabinet height
U
12
16
34
38
43
47
Foot height 8 mm
d1
d
d1
56
60
64
56
c
D
106
60
Frame dimensions
Ø8
451
465
H
mm
589
767
945
1167
1567
1745
1967
2145
h
mm
535
713
890
1112
1513
1690
1913
2090
451
465
w
07011100
Frame dimensions
19" front / rear upright
Cabinet
depth
50,5
30
D
mm
500
600
800
900
1000
10
M8
19" to
19" plane
Floor mounting
c
mm
380
480
680
780
880
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
19,5
60
64
84,5
7
Adjustable feet,
top cover fixing
d
mm
405
505
705
805
905
12
07011099
1.244
Cabinets – Novastar
Dimensional drawings Heavy-Duty Universal frames
Frame
Universal upright
07016081
Frame (top view)
07016002
MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days
쮿 Light aluminum die-cast frame and robust vertical profile
쮿 Static load-carrying capacity 400 kg, tested to IEC 61587-1
쮿 Lateral groove for mounting built-on accessories
Rack dimensions
Cabinet height
U
12
16
34
38
43
47
Foot height 8 mm
Universal front upright / 19" rear upright
07016082
H
mm
589
767
945
1167
1567
1745
1967
2145
H
mm
535
713
890
1112
1513
1690
1913
2090
Rack dimensions
Cabinet
depth
D
mm
500
600
800
900
1000
Adjustable feet,
casters, lift lug, top
cover fixing
d
mm
405
505
705
805
905
19" to 19"
plane
Base mounting
c
mm
380
480
680
780
880
d1
mm
319
419
619
719
819
w
mm
515
515
515
515
515
07016083
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.245
Cabinets – Novastar
19" cabinet with glass door (smoke grey) and rear panel
쮿 All uprights (front and rear) with 19" cut-outs
쮿 Flush cladding parts
쮿 Type of protection IP 20
쮿 2 cabinet depths (600 mm, 800 mm), cabinet width 553 mm
– Slim-Line 200 kg (12, 16, 20 U)
– Heavy-Duty 400 kg (38, 43 U)
쮿 2 colours
– RAL 7021 (black grey) throughout
– Colour combination: side panels, rear panel RAL 7035 (light
grey); frame, top cover RAL 7021 (black grey)
Delivery comprises (assembled)
07011010
3
Item
1
Qty
1
2
2
3
4
1
1
5
1
6
7
4
1
Description
Frame, uprights Al extrusion with 19" cut-outs,
Al die-cast frame, RAL 7021
Side panel, St, 1 mm; light grey (RAL 7035) or
black grey (RAL 7021), see Order information;
twist-locking catch (Torx T30)
Flush top cover, St, 1 mm, RAL 7021
Glazed door, single pane safety glass (ESG) 6 mm, smoke
grey, with DIN cylinder safety lock and 2 keys (2233x)
Rear panel, St, 1 mm, light grey (RAL 7035) or
Foot
GND/earthing kit
Order Information
2
1
H
8
5
Width
W
Depth
D
U
mm
mm
mm
Colour
RAL 7021
Part no.
Colour
RAL 7035/RAL
7021
Part no.
16230-019
16230-020
16230-021
16230-022
16230-023
16230-024
16230-025
27230-066
Note
D
6
Spacing to 19" plane:
Slim-Line: front 33 mm, rear 60 mm;
Heavy-Duty: front and rear 60 mm
Height
H
Slim-Line
12
589
553
600
15230-019
16
767
553
600
15230-020
553
600
15230-021
Heavy-Duty
38
1745
553
600
15230-022
38
1745
553
800
15230-023
43
1967
553
600
15230-024
43
1967
553
800
15230-025
Accessories
Lifting eye for flush cover M12 thread, application and load
to DIN 582 PU 4 pieces
4
W
Usable
height
07011050
쮿 Please order base plate, base/plinth, slide rails and shelves
separately, see from page 1.254
쮿 Castors see page 1.253
쮿 Other accessories/components see ServicePLUS,
from page 1.261
쮿 Dimension drawings see from page 1.243
ServicePLUS see page 1.261
1.246
Cabinets – Novastar
19" cabinet, door and rear panel combination freely
selectable
쮿 3 cabinet depths (500, 600 and 800 mm), cabinet width 553 mm
– Slim-Line 200 kg (9 U to 25 U)
– Heavy-Duty 400 kg (34 U to 47 U)
쮿 2 colours
– Colour combination: side panels RAL 7035 (light grey);
07011013
2
8
H
1
D
4
Qty
1
2
2
3
4
5
1
4
1
Description
Foot
GND/earthing kit
Order Information
3
W
Item
1
07011051
Usable height Height H Width
W
Depth
D
U
mm
mm
mm
Part no.
Colour
RAL 7035/RAL
7021
Part no.
Slim-Line
9
12
12
16
16
25
456
589
589
767
767
945
945
945
1167
1167
553
553
553
553
553
553
553
553
553
553
600
500
600
500
600
500
600
800
600
800
15230-001
16230-001
15230-002
16230-002
15230-003
15230-004
16230-003
16230-004
15230-005
16230-005
15230-006
15230-007
16230-006
16230-007
15230-008
16230-008
15230-009
15230-010
16230-009
16230-010
Colour
RAL 7021
Heavy-Duty
34
1567
553
600
15230-011
34
1567
553
800
15230-012
38
1745
553
600
15230-013
38
1745
553
800
15230-014
43
1967
553
600
15230-015
43
1967
553
800
15230-016
47
2145
553
600
15230-017
47
2145
553
800
15230-018
Accessories
16230-011
16230-012
16230-013
16230-014
16230-015
16230-016
16230-017
16230-018
27230-066
쮿 Please order doors, rear panel, base plate, base/plinth, slide
rails and shelves separately, see from page 1.248
from page 1.261
Part number in normal type: ready for despatch within 10 working days
1.247
Cabinets – Novastar
Glass door (smoke grey)
쮿 Can be assembled at front and rear
쮿 Opening angle 180°
Delivery comprises
Item
1
Qty
1
2
1
Description
Glass door, single pane safety glass (ESG) 6 mm, smoke
grey; safety lock with DIN cylinder and 1 key (2233x);
hinges, plastic, black
Assembly kit
Order Information
For cabinet height
U
9
12
16
29
34
38
43
47
Height
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Part no.
27230-002
27230-003
27230-004
27230-005
27230-006
27230-028
27230-007
27230-008
27230-009
27230-010
07011059
Glazed acrylic glass door
쮿 Mounting front or rear
쮿 Lock with key
쮿 Frame color black gray (RAL 7021) or light gray (RAL 7035)
Delivery includes
Item
1
2
3
4
Qty.
1
1
1
1
Description
Door frame, St, 1.5 mm
Acrylic sheet, 2 mm, clear
Lock (2233x) with 1 key
Fixing materials kit including GND
Order Information
07016054
1.248
07016053
For cabinet height
For cabinet height
U
6
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
322
456
589
767
945
1167
1345
1567
1745
1967
2145
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-092
26230-092
25230-093
26230-093
25230-094
25230-095
26230-094
26230-095
25230-096
26230-096
25230-097
25230-102
26230-097
26230-102
25230-098
26230-098
25230-099
25230-100
26230-099
26230-100
25230-101
26230-101
60127-018
Cabinets – Novastar
Steel door
쮿 Colour black grey (RAL 7021) or light grey (RAL 7035)
Delivery comprises
Item
1
Qty
1
2
1
Description
Steel door, St, 1.5 mm; safety lock with DIN cylinder and
1 key (2233x); hinges, plastic, black
Fixing material kit and GND/earthing kit
Order Information
07011060
For cabinet height
Height
U
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-021
25230-022
26230-021
26230-022
25230-023
26230-023
25230-024
25230-025
26230-024
26230-025
25230-030
26230-030
25230-026
25230-027
26230-026
26230-027
25230-028
26230-028
25230-029
26230-029
60127-018
Perforated door
쮿 Can be mounted at front and rear
쮿 Perforated (60 % ventilation opening)
쮿 Lock with key (2233X)
쮿 Colors RAL 7035 and RAL 7021
Delivery includes
Item
1
Qty.
1
2
3
2
2
1
1
Description
Door, perforated, St, 1.5 mm, width 553 mm, 60 %
ventilation opening, see order information for color
Hinge, 180° opening angle
Lock with single key (2233X)
Earthing (GND) kit
Order Information
07016078
07016055
For cabinet height
Height
U
6
9
12
16
29
34
38
43
47
Accessories
Spare key 1 piece
mm
288.4
421.75
555.1
732.9
910.7
1132.95
1310.75
1533
1710.8
1933.05
2110.85
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-081
26230-081
25230-082
25230-083
26230-082
26230-083
25230-084
26230-084
25230-085
25230-086
26230-085
26230-086
25230-091
26230-091
25230-087
25230-088
26230-087
26230-088
25230-089
26230-089
25230-090
26230-090
60127-018
1.249
Cabinets – Novastar
Cable ducting combination for steel door
쮿 For a cable ducting combination a steel door, a door hinge
bracket and a frame for cable ducting are required
쮿 Cable ducting can be at top or bottom
쮿 Frame with brush strip for cable ducting is either 3 U or 4 U,
depending on cabinet/door height
Delivery comprises
2
Item
1
Qty
1
1
2
1
3
1
Description
Door hinge bracket, St, 2 mm, RAL 7021
requires 1 U fitting space,
mounts above or below the steel door
Steel door, St, 1.5 mm, lock (2233x) with 1 key,
opening angle 180°, GND/earthing
Frame for cable ducting, St, 2.5 mm,
with black brush strip,
3 U (for cabinet heights 16, 20, 38, 47 U)
4 U (for cabinet heights 25, 34, 43 U)
3
07011061
Order Information
Steel door
RAL 7035
RAL 7021
1 key, openingangle 180,
incl. GND/earthing
Height
(U)
16
34
38
43
47
Steel door
Perforated
RAL 7035
RAL 7021
St, 1.5 mm, perforated, opening
angle 180°, lock with key
(2233X), incl. grounding
Glass door
Door hinge bracket for doors
smoke grey
Slim-Line
Slim-Line
Heavy-Duty
19" plane for
front
rear
front/rear
universal upright
33 mm
60 mm
60 mm
door hinge bracket, St, 2 mm, RAL 7021
St, 2 mm, RAL 7021; 1) Height 3 U
RAL 7021;
mounts above or 2) Height 4 U
mounts above or below the door;
below the door;
requires 1 U assembly space
requires 1 U
assembly space
opening angle
180°,
lock with key,
glass type:
ESG 6 mm,
EN 12150
26230-022
26230-023
25230-022
25230-023
26230-084
26230-085
25230-084
25230-085
27230-004
27230-005
27230-060
27230-060
27230-061
27230-061
27230-098
27230-098
26230-024
25230-024
26230-086
25230-086
27230-006
27230-060
27230-061
27230-098
26230-030
26230-026
25230-030
25230-026
26230-087
26230-088
25230-087
25230-088
27230-007
27230-008
27230-060
27230-060
27230-061
27230-061
27230-098
27230-098
26230-027
25230-027
26230-089
25230-089
27230-009
27230-060
27230-061
27230-098
26230-028
25230-028
26230-090
25230-090
27230-010
27230-060
27230-061
27230-098
1)
1)
2)
2)
1)
2)
1)
27230-162
27230-162
27230-163
27230-163
27230-162
27230-163
27230-162
Cable ducting
RAL 7035
Screw fixed
Height
(U)
16
34
38
43
47
1.250
RAL 7021
RAL 7021
Screw fixed
clipped
St, 2.5 mm,
1) Height 3 U
2) Height 4 U
1)
1)
2)
2)
1)
2)
1)
20118-391 1) 20118-796 1) 27230-160
20118-390 2) 20118-797 2) 27230-161
Cabinets – Novastar
Rear panel
쮿 Twist-locking catch (Torx T30, with 1/4 turn)
쮿 Rear panel: colour black grey (RAL 7021) or
Delivery comprises
Item
1
Qty
1
2
1
Description
Rear panel, St, 1 mm, twist-locking catch (Torx T30,
with 1/4 turn)
Assembly kit
Order Information
For cabinet height
Height
U
9
12
16
29
34
38
43
47
mm
422
555
733
911
1133
1345
1534
1711
1933
2111
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-371
25230-372
26230-371
26230-372
25230-373
26230-373
25230-374
25230-375
26230-374
26230-375
25230-147
26230-147
25230-376
25230-377
26230-376
26230-377
25230-378
26230-378
25230-379
26230-379
07011057
Rear panel with cable ducting frame
쮿 Cable ducting frame 3 or 4 U
Delivery comprises
Item
1
Qty
1
2
1
3
1
4
1
1
2
Order Information
3
07011058
Description
Rear panel, St, 1 mm, colour see Order information;
twist-locking catch (Torx T30, with 1/4 turn)
Door hinge bracket, St, 2 mm, colour see Order
information
Frame for cable ducting, St, 1.5 mm, colour see Order
information; brush strip;
3 U frame for cable ducting for cabinet heights
16, 20, 38, 47 U;
4 U frame for cable ducting for cabinet heights
25, 34, 43 U
Assembly kit and GND/earthing kit
For cabinet
height
U
16
34
38
43
47
Height
mm
733
911
1133
1534
1711
1933
2111
For cabinet
width
mm
553
553
553
553
553
553
553
Colour
RAL 7021
Part no.
Colour
RAL 7035
Part no.
25230-430
26230-430
25230-434
26230-434
25230-439
25230-448
26230-439
26230-448
25230-452
26230-452
25230-457
25230-461
26230-457
26230-461
1.251
Cabinets – Novastar
Base plate, multi-piece
쮿 Floor is open at rear; Opening can be closed with a cover plate
or brush strip
Delivery includes
Item
1
Qty
1
2
1
Description
Base plate, St, 1.5 mm, RAL 7021; cable through-ducting
opening, width 440 mm, depth 70 mm
Assembly kit
Order Information
07011073
Accessories
07016050
For cabinet depth
For cabinet width
mm
mm
500
553
600
553
800
553
1000
553
1200
553
Accessories
Brush strip Nylon, black, 440 mm x 98 mm, PU 1 piece
Solid cover plate for floor, multi-piece, St, 1 mm,
485 mm x 92 mm, RAL 7021, 1 piece
Perforated cover plate for floor, multi-piece St, 1 mm,
Filter mat cover plate for floor, multi-piece St, 1 mm,
Part no.
27230-188
27230-189
27230-190
27230-191
27230-192
27230-079
27230-114
27230-254
27230-255
Note
쮿 Please order cover plate or brush strip separately
Base plate, single piece, reinforced, with cutouts for
cable ducting
쮿 Heavy-load floor panel
쮿 Load-carrying capacity 50 kg (110 lbs)
쮿 Cutout for cable ducting
Delivery includes
Item
1
Qty.
1
2
1
Description
Base plate, St, 2,5 mm, RAL 7021;
cable ducting opening, perforated, width 370 mm,
depth 50 mm
Order Information
07016059
Reinforced brush strip for floor
For cabinet depth
For cabinet width
Qty/PU
mm
mm
piece
500
553
1
600
553
1
800
553
1
900
553
1
1000
553
1
Accessories
Brush strip for heavy-load floor panel Nylon, black, width
370 mm, depth 50 mm 1 piece
Part no.
RAL 7021
25230-149
25230-150
25230-151
25230-152
25230-153
27230-055
Note
07016060
1.252
SCHROFF PRODUCT CATALOG E 07/2017
쮿 Please order brush strip separately
Cabinets – Novastar
Castors
쮿 Castors are fitted to the frame
쮿 Static load-carrying capacity 200 kg, 300 kg or 400 kg
depending on version
쮿 Height dependent on version 73 mm, 80 mm, 131 mm or
155 mm
쮿 2 castors without jacking foot, 2 castors with jacking foot
Delivery comprises
07011065
Load-carrying capacity 200 kg
07011066
Load-carrying capacity 300 kg,
conductive,
ESD resistance < 10 kΩ
Item
1
2
3
Qty
2
2
1
Description
Locking castor, PA/St
Non-locking castor, PA/St
Assembly kit
Order Information
Description
Loadcarrying
capacity
kg
200
Castors
Castors, conductive,
ESD resistance < 10 kΩ 300
to EN 12528
Castors with
400
adjustable feet
Castors
400
07011067
Height H Castor
diameter
mm
mm
Part no.
73
Ø 50
27230-067
131
Ø 100
27230-110
80
Ø 60
27230-068
155
Ø 125
27230-069
07011068
Load-carrying capacity 400 kg, Load-carrying capacity 400 kg
with adjustable feet
1.253
Cabinets – Novastar
Base/plinth with cable ducting
쮿 Height adjustable 57 .... 67 mm
쮿 Cable ducting (110 x 76 mm) with cover
Item
1
Qty
1
2
3
4
1
Description
Base/plinth, St, 1.5 mm, height 55 mm, RAL 7021;
cable ducting 110 mm x 76 mm, with plastic cover
Adjustable foot
Order Information
07011075
For cabinet width
For cabinet depth
mm
mm
553
500
553
600
553
800
553
900
553
1000
Accessories
Brush strip Nylon, black, 110 mm x 76 mm; to cover cable
through-ducting opening , 1 piece
Part no.
27230-070
27230-071
27230-072
27230-076
27230-080
27230-111
Mobile base/plinth
쮿 Base/plinth height H = 100 mm
Delivery comprises
Item
1
Qty
1
2
1
3
4
4
1
Description
Base/plinth, St, 2 mm, black (RAL 7021), with perforation,
height = 100 mm
Fine-grooved mat, natural rubber, anthracite, 3 mm
thick, self-adhesive
Castors, St, Ø 55 mm, load-carrying capacity 200 kg
Assembly kit
Order Information
D
mm
592
692
892
Part no.
27230-146
27230-147
27230-148
96
37
48
For cabinet depth
mm
500
600
800
546
D
07011113
1.254
Cabinets – Novastar
Depth members
쮿 For assembly on cabinet uprights
쮿 Adjustable in 1 U increments
Delivery includes
Item
1
Qty
1
Description
Depth member, St, 1.5 mm, finish AlZn
Order Information
56
13,5
For cabinet depth
mm
500
600
800
900
1000
D
mm
366
466
666
766
866
Part no.
27230-167
27230-168
27230-169
27230-170
27230-171
D
07016067
07011114
19" panel/slide mounts with universal perforation grid
(EIA)
쮿 For fitting to depth members (25 mm grid)
쮿 For recessed installation of 19" components
쮿 Load-carrying capacity 400 kg
쮿 Slide rails can be fitted
쮿 A partial-height 19" mounting is possible with short 19" panel/
slide mounts
Delivery includes
Item
1
2
Qty
2
1
Description
19" panel/slide mount, St, 2 mm, RAL 7021
Assembly kit
Order Information
07011111
19" panel/slide mount mounted
on depth members
07016080
For cabinet height
U
mm
Partial-height
6
mounting
9
456
12 589
16 767
20 945
25 1167
34 1567
38 1745
43 1967
47 2145
Usable height
U
H
mm
Part no.
6
267
27230-172
9
12
16
34
38
43
47
400
534
712
889
1112
1512
1690
1912
2090
27230-173
27230-174
27230-175
27230-176
27230-177
27230-178
27230-179
27230-180
27230-181
쮿 Slide rails see page 1.256
쮿 Depth members are required for fitting, see page 1.255
1.255
Cabinets – Novastar
19" plane for universal upright
쮿 Panel/slide mount for installing on the universal profile
쮿 A 19" plane can be implemented using the panel/slide mount
Delivery includes
Item
1
2
Qty.
4
1
Description
Order Information
Height
U
3
4
3U
07016070
Height
mm
130
170
Qty/PU
piece
2
2
Part no.
27230-162
27230-163
07016071
4U
Slide rail
쮿 For mounting on the vertical cabinet uprights or 19" panel/slide
mounts
쮿 Static load-carrying capacity 25 kg per pair
D
Delivery comprises
Qty
2
1
Description
Slide rail, St, 1.5 mm, finish AlZn
Assembly kit
82
Order Information
39
W
07011078
Item
1
2
07011104
For cabinet depth D
mm
500
600
800
900
1000
L
mm
370
470
670
770
970
x
mm
322
422
622
822
922
Part no.
27230-102
27230-103
27230-104
27230-105
27230-106
00205051
1.256
Cabinets – Novastar
Heavy-load slide rail
mounts
쮿 Static load-carrying capacity 50 kg per pair
쮿 900, 1000 mm depth for server applications
Delivery includes
Item
1
2
Qty.
2
1
Description
Slide rail, St, 2 mm, finish AlZn
Order Information
07016066
For cabinet depth D
L
x
mm
mm
mm
500
272
322
600
370
422
800
470
522
900
670
722
1000
870
822
900, 1000 mm for server
740
692
applications
Accessories
Fixing materials kit for heavy-load slide rail 1 set (4 x
M5x12 screws, 4 x M5 cage nuts, screwed in from the
inside)
Part no.
25230-013
25230-014
25230-015
25230-145
25230-146
25230-148
27230-056
07016084
Short slide rail
쮿 For mounting on the cabinet uprights or 19" panel/slide mounts
쮿 Static load-carrying capacity max. 15 kg per pair
Delivery comprises
Item
1
2
Qty
2 / 10
1
Description
Short slide rail, St, 1.5 mm, finish AlZn
Assembly kit
Order Information
Description
Short slide rail
Short slide rail
Qty/PU
piece
2
10
Part no.
27230-184
27230-185
07016065
1.257
Cabinets – Novastar
Shelf, stationary
쮿 Static load-carrying capacity 75 kg
쮿 Mounting height 1 U, for fitting on the vertical cabinet uprights
쮿 Hammer head perforation for fixing cables using cable ties or
Velcro-type tape
쮿 900, 1000 mm Tiefe für Server Anwendungen
Delivery includes
Item
1
2
Qty
1
1
Description
Shelf with perforation, St, 1.5 mm, RAL 7021
Assembly kit
07011077
Order Information
W
W = 553 mm
1.258
D
d
w
07011105
For cabinet depth D
Usable surface w x d
mm
mm
500
488 x 350
600
488 x 450
800
488 x 650
900
488 x 750
1000
488 x 850
900, 1000 mm für
488 x 740
Serveranwendungen
Accessories
Cable ties 92 mm x 2.5 mm, PU 25 pieces
Cable ties 186 mm x 5 mm, PU 25 pieces
Cable ties 360 mm x 5 mm, PU 25 pieces
Velcro strip Polyethylen/Polyamide, black,
length 300 mm, PU 10 pieces
Part no.
27230-051
27230-052
27230-053
27230-088
27230-089
27230-165
20118-351
20118-352
20118-353
20118-624
Cabinets – Novastar
Telescopic shelf, 70 kg
Main Catalogue
쮿 Static load-carrying capacity at full extension 70 kg
쮿 Mounting height 2 U, for fitting to the four vertical uprights
쮿 Incl. telescopic slides
1
쮿 Locking possible with T-bar lock
2
Velcro-type tape
쮿 2 versions
– Full depth
– Depth shortened by 100 mm for rear cable ducting
4
Delivery comprises
Item
1
2
3
Qty
1
2
1
Description
Telescopic slide
Assembly kit
07011089
Full depth
Order Information
w
Full depth
D
c
Cabinet dimensions W x Usable surface xf
xf1 c
D
wxd
mm
mm
mm mm mm
553 x 500
405 x 382
33 60 407
553 x 600
405 x 482
33 60 507
553 x 800
405 x 682
33 60 687
533 x 900, 740 mm für
405 x 582
33 60 787
Serveranwendungen
533 x 1000
405 x 682
33 60 887
Item 4 T-bar lock for 1 telescopic shelf (can be mounted
right or left), 1 piece
GND/earthing for telescopic shelf PU 1 piece
xf
xf 1
d
60
W
Full depth
Part no.
21130-357
21130-353
21130-355
27230-108
27230-109
23130-092
21120-189
07011101
Order Information
Shortened depth
Shortened by 100 mm
W
xf1 c
Shortened by
D
wxd
100 mm
mm
mm
mm mm mm
Part no.
553 x 500
405 x 282
33 60 407 21130-358
553 x 600
405 x 382
33 60 507 21130-352
553 x 800
405 x 582
33 60 687 21130-354
405 x 582
33 60 787 27230-108
Serveranwendungen
533 x 1000
405 x 682
33 60 887 27230-109
23130-092
21120-189
D
xf
xf 1
d
c
60
w
07011102
c = pitch of 19" profiles; xf, = Slim-Line assembly dimensions;
xf1 = Heavy-Duty assembly dimensions
1.259
Cabinets – NOVASTAR
Support arm for monitor and keyboard (SysPend®)
쮿 Support arm for mounting of monitor, keyboard and mouse on
cabinet
쮿 Fixing is to the side of the Heavy-Duty frame (height adjustable)
쮿 Static load-carrying capacity 3 ... 7 kg
쮿 Support arm:
– Height-adjustable 300 mm
– Angle of rotation on cabinet 180 °
– Monitor rotation angle 340° (fitted on cabinet 270°)
– Monitor tilt angle 60°
– Integrated cable routing
쮿 Suitable for industrial applications
Delivery comprises
00511006
Item
1
Qty
1
2
1
3
1
4
1
Description
Support arm frame, Al extrusion, RAL 7035, rotatable,
height adjustable
Wall-mounting bracket, for mounting on cabinet or wall,
hinged sideways through 180°
Keyboard storage point, tiltable upward through 95°,
width 480 mm, depth 170 mm;
mouse pad: width 150 mm, depth 190 mm
Monitor holder for flat-screen units, hinged through
340°, tiltable through 60° (15° forwards, 45° to rear)
Order Information
Description
Qty/PU
pieces
1
(SysPend® )
Accessories
Mounting material for cabinet exterior PU 4 pieces
00511004
Support arm fitted with monitor Cable ducting
and keyboard
Part no.
VAMONITOR
27230-144
00511003
NOVASTARMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 For mounting accessories to cabinet exterior (e.g. support arm)
쮿 Slide nut (M6) is simply inserted into the side T-groove of the
Heavy-Duty frame
Delivery comprises
Item
1
2
3
Qty
1
1
1
Description
Slide nut M6
Pan head screw M6 x 16 (Torx T30)
Nomel washer 6.1
Order Information
06712050
Description
1.260
Qty/PU
pieces
4
Part no.
27230-144
Cabinets – Novastar Service Plus
ServicePLUS: configuration and assembly
Novastar Servi ce Plus Main Catalogue
쮿 Dimensions:
– Height: 6 ... 47 U (357 ... 2145 mm)
– Width: 553 mm
– Depth: 500, 600, 800, 900, 1000 mm
Page
Frames, gasketing kit,
side-by-side mounting kit, 1.262
stacking kit
쮿 3 frame versions:
– Slim-Line, static load-carrying capacity 200 kg, height 6 ... 47 U
– Heavy-Duty, static load-carrying capacity 400 kg,
19" + Universal, height 16 ... 47 U
Castors, adjustable feet
1.263
쮿 Configure your cabinet from individual parts (to have them assembled
please add the suffix /05 to each part number)
Side panels
1.264
쮿 Once you have selected your cabinet dimensions, the row number
(first column of the configuration tables) guides you through all the pages
of the configurations possible for these dimensions (see example below)
Glass doors, steel doors
1.265
Cable ducting for steel
doors
1.266
Rear panels
1.267
Top covers
1.268
Fan top covers, lifting eye,
thermostat, speed
controller
1.269
Floors
1.270
Base/plinth
1.271
depth members, shelves
1.272
Shelves
1.273
Slide rails
1.274
Cable ties, Velcro-type
tape
1.275
쮿 The configured cabinet is assembled and is ready for despatch
07011052
Configuration example, assembled (here: row no. 11)
Qty
1
1
1
1
1
Description
Order no.
Frame, Slim-Line, usable height 20 U, height 945 mm,
28230-015/05
width 553 mm, depth 500 mm, 1 piece
Side panel, Slim-Line, height 20 U, depth 500 mm, RAL 7035, PU 26230-074/05
2 pieces
Glass door (smoke grey), height 20 U, opening angle 180°, width 27230-005/05
553 mm, 1 piece
Rear panel, height 20 U, width 553 mm, RAL 7035, PU 1 piece
26230-374/05
Top cover, raised, width 553 mm, depth 500 mm, RAL 7021,
25230-010/05
1 piece
1.261
Frames, gasketing kit, side-by-side mounting kit, stacking kit
Frame
Slim-Line
200 kg
Heavy-Duty
400 kg,
19"
07011053
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.262
07011054
static loadstatic loadcarrying capacity: carrying capacity:
400 kg,
200 kg,
Al extrusion,
Al extrusion,
RAL 7021, incl.
RAL 7021, incl.
GND/earthing;
GND/earthing;
19" plane 33 mm 19" plane 60 mm
at front,
at front,
60 mm at rear;
60 mm at rear;
please order
please order
castors or
castors or
adjustable feet
adjustable feet
separately
separately
Heavy-Duty,
400 kg,
Universal
07016056
Static loadcarrying
capacity: 400 kg,
Al profile,
RAL 7021,
incl. grounding;
19" plane
rear 60 mm,
castors or
adjustable feet
ordered
separately
Gasketing kit
for IP 40
07012050
TPE, black;
raises ingress
protection from
IP 20 to IP 40;
gaskets are
affixed onto the
frame
Side-by-side
mounting kit
07011080
gasket, foam
adhesive tape: PU
foam anthracite;
for joining
two adjacent
cabinets
Stacking kit
07011070
for joining two
cabinets
positioned one
above the other
Slide nut
for T-groove
aza43431
St, M6, for lateral
mounting of
accessories on
the T-groove of
the Heavy-Duty
frame
1 piece
1 piece
1 piece
PU 1 kit
PU 1 kit
PU 1 kit
PU 4 pieces
assembled
assembled
assembled
assembled
enclosed loose
enclosed loose
enclosed loose
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
28230-056
28230-189
28230-310
28230-370
28230-430
28230-192
28230-193
28230-314
28230-374
28230-434
28230-196
28230-197
28230-319
28230-379
28230-439
28230-200
28230-201
28230-328
28230-388
28230-448
28230-204
28230-205
28230-332
28230-392
28230-452
28230-208
28230-209
28230-337
28230-397
28230-457
28230-212
28230-213
28230-341
28230-401
28230-461
28230-216
28230-217
28230-057
28230-058
28230-059
28230-107
28230-108
28230-109
28230-110
28230-111
28230-112
28230-113
28230-114
28230-115
28230-116
28230-117
28230-118
28230-119
28230-167
28230-168
28230-169
28230-170
28230-171
28230-172
28230-173
28230-174
28230-175
28230-176
28230-177
28230-178
28230-179
28230-180
28230-181
28230-182
28230-183
28230-184
28230-185
28230-186
28230-187
28230-188
28230-052
28230-053
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
27230-107
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
27230-143
20230-409
27230-112
27230-144
28230-001
28230-060
28230-004
28230-063
28230-007
28230-066
28230-126
28230-054
28230-055
28230-011
28230-070
28230-130
28230-190
28230-191
28230-015
28230-074
28230-134
28230-194
28230-195
28230-020
28230-079
28230-139
28230-198
28230-199
28230-029
28230-088
28230-148
28230-202
28230-203
28230-033
28230-092
28230-152
28230-206
28230-207
28230-048
28230-097
28230-157
28230-210
28230-211
28230-042
28230-101
28230-162
28230-214
28230-215
Castors
Load-carrying
capacity 200 kg
07011065
Load-carrying
capacity 300 kg,
conductive
07011066
Adjustable foot
Load-carrying
capacity 400 kg,
Ø 60 mm
07011067
Load-carrying
capacity 400 kg,
Ø 125 mm
07011068
static loadstatic loadstatic loadstatic loadcarrying capacity carrying capacity carrying capacity carrying capacity
400 kg,
400 kg,
300 kg, height 131
200 kg,
height 155 mm,
height 80 mm,
mm, Ø 100 mm,
height 73 mm,
Ø 125 mm,
Ø 60 mm,
2 castors without
Ø 50 mm,
2 castors without 2 castors without
jacking foot,
2 castors without
jacking foot,
jacking foot,
2 castors with
jacking foot,
2 castors with
2 castors with
jacking foot;
2 castors with
jacking foot
jacking foot,
EN 12528
jacking foot
incl. 4 adjustable
(resistance
feet
< 10 kΩ)
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07011069
400 kg,
St, polyamide,
black
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
PU 1 kit
assembled
assembled
assembled
assembled
assembled
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
27230-067
27230-110
27230-068
27230-069
27230-100
1.263
Side panels
Side panel
Slim-Line
07011055
Heavy-Duty
07011084
Side panel lock
07011056
07011085
St, 1 mm, with quarter-turn fastener; St, 1 mm, with quarter-turn fastener;
incl. GND/earthing
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.264
07011108
2 locks
(2233x locking),
2 keys;
suitable for
2 side panels
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 1 kit
assembled
assembled
assembled
assembled
assembled
26230-070
26230-120
26230-071
26230-121
26230-072
26230-122
26230-172
26230-113
26230-114
26230-073
26230-123
26230-173
26230-115
26230-116
26230-074
26230-124
26230-174
26230-117
26230-118
26230-075
26230-125
26230-175
26230-119
26230-130
26230-076
26230-126
26230-176
26230-131
26230-132
26230-077
26230-127
26230-177
26230-133
26230-134
26230-078
26230-128
26230-178
26230-135
26230-136
26230-079
26230-129
26230-179
26230-137
26230-138
25230-070
25230-120
25230-071
25230-121
25230-072
25230-122
25230-172
25230-113
25230-114
25230-073
25230-123
25230-173
25230-115
25230-116
25230-074
25230-124
25230-174
25230-117
25230-118
25230-075
25230-125
25230-175
25230-119
25230-130
25230-076
25230-126
25230-176
25230-131
25230-132
25230-077
25230-127
25230-177
25230-133
25230-134
25230-078
25230-128
25230-178
25230-135
25230-136
25230-079
25230-129
25230-179
25230-137
25230-138
27230-115
27230-115
26230-222
26230-272
26230-322
26230-067
26230-068
26230-223
26230-273
26230-323
26230-069
26230-080
26230-224
26230-274
26230-324
26230-103
26230-104
26230-225
26230-275
26230-325
26230-105
26230-106
26230-226
26230-276
26230-326
26230-107
26230-108
26230-227
26230-277
26230-327
26230-109
26230-110
26230-228
26230-278
26230-328
26230-111
26230-112
26230-229
26230-279
26230-329
26230-040
26230-041
25230-222
25230-272
25230-322
25230-067
25230-068
25230-223
25230-273
25230-323
25230-069
25230-080
25230-224
25230-274
25230-324
25230-103
25230-104
25230-225
25230-275
25230-325
25230-105
25230-106
25230-226
25230-276
25230-326
25230-107
25230-108
25230-227
25230-277
25230-327
25230-109
25230-110
25230-228
25230-278
25230-328
25230-111
25230-112
25230-229
25230-279
25230-329
25230-040
25230-041
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
27230-115
Steel door
Steel door
Glazed door
Glass door
Perforated
07011060
07011088
opening angle 180,
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07016078
angle 180°, lock with key (2233X),
incl. grounding
07011060
Door frame, St, 1.5 mm;
acrylic glass, 2 mm;
safety lock with 2 keys
07016054
07011059
opening angle
180°,
lock with key,
glass type:
ESG 6 mm,
EN 12150
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
smoke grey
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
26230-020
25230-020
26230-081
25230-081
26230-092
25230-092
27230-001
26230-021
25230-021
26230-082
25230-082
26230-093
25230-093
27230-002
26230-022
25230-022
26230-083
25230-083
26230-094
25230-094
27230-003
26230-023
25230-023
26230-084
25230-084
26230-095
25230-095
27230-004
26230-024
25230-024
26230-085
25230-085
26230-096
25230-096
27230-005
26230-025
25230-025
26230-086
25230-086
26230-097
25230-097
27230-006
26230-026
25230-026
26230-087
25230-087
26230-098
25230-098
27230-007
26230-027
25230-027
26230-088
25230-088
26230-099
25230-099
27230-008
26230-028
25230-028
26230-089
25230-089
26230-100
25230-100
27230-009
26230-029
25230-029
26230-090
25230-090
26230-101
25230-101
27230-010
1.265
Cable ducting for steel doors
Cable ducting for steel door with door hinge bracket and frame
Steel door
RAL 7035
RAL 7021
07011060
07011088
key, opening angle 180,
incl. GND/earthing
Slim-Line
front
Slim-Line
rear,
Heavy-Duty
front/rear,
Universal rear
Cable ducting frame
Heavy-Duty
Universal
front
RAL 7035
screw fixed
07011061
RAL 7021
screw fixed
RAL 7021
clipped
07011061
07016073
St, 2.5 mm,
1) Height 3 U
2) Height 4 U
door hinge bracket, St, 2 mm, RAL 7021;
Heavy-Duty Universal: Short 19" planes
are required to mount the door hinge bracket,
see page 1.272
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.266
RAL 7035
RAL 7021
33 mm
60 mm
60 mm
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
assembled
26230-022
25230-022
27230-060
27230-061
27230-098
20118-391
26230-023
25230-023
27230-060
27230-061
27230-098
20118-391
26230-024
25230-024
27230-060
27230-061
27230-098
20118-390
26230-030
25230-030
27230-060
27230-061
27230-098
20118-390
26230-026
25230-026
27230-060
27230-061
27230-098
20118-391
26230-027
25230-027
27230-060
27230-061
27230-098
20118-390
26230-028
25230-028
27230-060
27230-061
27230-098
20118-391
1)
1)
2)
2)
1)
2)
1)
1)
20118-796
1)
20118-796
2)
20118-797
2)
20118-797
1)
20118-796
2)
20118-797
1)
20118-796
RAL 7021
1)
27230-160
1)
27230-160
2)
27230-161
2)
27230-161
1)
27230-160
2)
27230-161
1)
27230-160
Rear panels
Rear panel
07011057
07011086
St, 1 mm; 2 twist-locking catches
(Torx T30,with1/4 turn);
incl. GND/earthing
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
07011058
07011087
Rear panel lock
07011107
2 rear panel
catches with lock
(Torx T30, with 1/4 turn),
(2233x locking),
incl. GND/earthing, cable ducting
2 keys;
and door hinge bracket;
suitable for a
cable ducting can be fitted at top or
rear panel
bottom, 3 U cable ducting for cabinet
height 16, 20, 38, 47 U; 4 U cable
ducting for cabinet height 25, 34, 43 U
RAL 7035
RAL 7021
RAL 7035
1 piece
1 piece
PU 1 kit
RAL 7021
PU 1 kit
PU 1 kit
assembled
assembled
assembled
assembled
assembled
26230-370
25230-370
27230-116
26230-371
25230-371
27230-116
26230-372
25230-372
27230-116
26230-373
25230-373
26230-430
25230-430
27230-116
26230-374
25230-374
26230-434
25230-434
27230-116
26230-375
25230-375
26230-439
25230-439
27230-116
26230-376
25230-376
26230-448
25230-448
27230-116
26230-377
25230-377
26230-452
25230-452
27230-116
26230-378
25230-378
26230-457
25230-457
27230-116
26230-379
25230-379
26230-461
25230-461
27230-116
1.267
Top covers
Top cover flush
Flush
07011063
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.268
Top cover raised
Lifting eye
07011071
St, 1 mm,
RAL 7021,
incl. GND/
earthing
for flush cover;
M12, application
and load to
DIN 582
1 piece
assembled
25230-001
25230-002
25230-001
25230-002
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
25230-001
25230-002
25230-003
25230-043
25230-044
Raised
07011064
Lifting eye
07011072
Raised top cover,
load-carrying
capacity 50 kg
07016077
St, 1 mm,
RAL 7021,
incl. GND/
earthing,
height 31 mm,
air gap 10 mm
for raised cover
or fan top cover;
M12, application
and load to
DIN 582
PU 4 pieces
1 piece
PU 4 pieces
1 piece
assembled
assembled
assembled
assembled
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
27230-066
25230-010
25230-011
25230-010
25230-011
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
25230-010
25230-011
25230-012
25230-045
25230-046
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
27230-065
St, 1 mm,
RAL 7021,
incl. GND/
earthing,
height 31 mm,
air gap 10 mm,
roof mounting
from the inside
(outside no
screws)
25230-039
25230-038
25230-039
25230-038
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
25230-039
25230-038
25230-037
25230-141
25230-142
Fan top covers, lifting eye, thermostat, speed controller
Fan top cover
(fan height 25 mm)
Fan top cover
Fan
with fans
84 ... 90 m³
Fan top cover
(fan height 38 mm)
Fan top cover
Fan
with fans
162 ... 172 m³
Lifting eye
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
07011082
kta44844
07011082
axial fan with
St, RAL 7021, incl.
St, RAL 7021, incl.
protective grille,
GND/earthing
GND/earthing
230 VAC, 8 W,
and cabling;
and cabling;
2 fans for 500 mm
2 fans for 500 mm
84 ... 90 m³/h
depth, 1 cover
depth, 4 cover
29 ... 30 dB(A),
cap;3 fans for
caps;
height 25 mm;
600/800 mm
3 fans for
600/
please order
depth, 3 cover
800 mm depth,
separately if
caps; 0.5 m
3 cover caps;
additional fans
connector cable,
0.5 m
are required
IEC C14 plug
connector cable,
IEC C14 plug
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
kta44844
07011072
axial fan with
protective grille,
230 VAC, 15 W,
162 ... 172 m³/h,
37 ... 41 dB(A),
height 38 mm;
please order
separately if
additional fans
are required
for raised cover
or fan top cover;
M12, application
and load to
DIN 582
01108052
01105055
with mains cable
fully wired,
230 VAC
90 ... 264 VAC,
(SCHUKO/UTE
input SCHUKO/
plug/IEC 60320
UTE plug,
C13 socket),
outlet IEC 60320
adjustment range
C13 socket;
0 ... 60°C
external NTC
sensor 1.5 m
PU 1 kit
1 piece
PU 1 kit
1 piece
PU 4 pieces
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-078
27230-065
20118-750
60715-005
27230-081
27230-082
27230-081
27230-082
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-081
27230-082
27230-083
27230-094
27230-095
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-077
27230-085
27230-086
27230-085
27230-086
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
27230-085
27230-086
27230-087
27230-096
27230-097
1.269
Floors
Base plates
Base plate,
rear open
07011073
St, 1.5 mm,
RAL 7021,
incl. GND/
earthing;
cable ducting in
rear area of
cabinet; please
order cover or
brush strip
separately
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.270
Cover plate
07011073
St, 1.5 mm,
485 x 92 mm;
to cover the rear
floor opening
Cover plate
Perforated
07016052
St, 1.5 mm,
485 x 92 mm;
to cover the rear
floor opening
Cover plate
Filter mat
07016052
St, 1 mm,
485 x 92 mm; to
cover the rear
floor opening
Brush strip
07011073
Nylon, black,
440 x 98 mm;
to cover the rear
floor opening
Base plate, reinforced,
with cable ducting
Base plate
Brush strip
07016059
St, 1.5 mm,
RAL 7021;
fully closed with
pre-cut area for
cable ducting
opening,
width 370 mm,
depth 50 mm
07016060
Nylon, black,
width 370 mm,
depth 50 mm; for
covering the rear
floor opening
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
montiert
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-114
27230-254
27230-255
27230-079
27230-188
27230-189
27230-188
27230-189
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
27230-188
27230-189
27230-190
27230-191
27230-192
25230-149
25230-150
25230-149
25230-150
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
25230-149
25230-150
25230-151
25230-152
25230-153
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
27230-055
ELECTRONICS PROTECTION
Base/plinth
Bases/plinths
Mobile bases/
plinths
Brush strip
96
37
48
With cable
ducting
546
07011075
07011077
D
07011113
St, 2 mm,
Nylon, black,
St, 1.5 mm,
110 mm x 76 mm; fine-grooved mat,
RAL 7021,
3 mm, 4 castors,
to cover cable
height 55 mm;
load-carrying
through-ducting
incl. GND/
capacity 200 kg
opening
earthing;
cable ducting
110 x 76 mm;
adjustable feet,
adjustable height
range
57 mm ... 67 mm
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1 piece
1 piece
1 piece
assembled
assembled
assembled
27230-070
27230-071
27230-070
27230-071
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-070
27230-071
27230-072
27230-076
27230-080
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-111
27230-146
27230-147
27230-146
27230-147
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
27230-146
27230-147
27230-148
Part number in bold face type: ready for despatch within 2 working days
1.271
19" panel/slide mounts, depth members, shelves
Depth members
07011114
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.272
19" panel/slide
mounts
07011111
3U
4U
07016070
St, 2 mm, RAL 7021
07011114
St, 1.5 mm,
finish AlZn;
for mounting
19" pitch profiles
19" panel/slide
mounts with
universal
perforation grid
(EIA)
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
27230-172
27230-162
27230-163
27230-173
27230-162
27230-163
27230-174
27230-162
27230-163
27230-175
27230-162
27230-163
27230-176
27230-162
27230-163
27230-177
27230-162
27230-163
27230-178
27230-162
27230-163
27230-179
27230-162
27230-163
27230-180
27230-162
27230-163
27230-181
27230-162
27230-163
27230-167
27230-168
27230-167
27230-168
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
27230-167
27230-168
27230-169
27230-170
27230-171
Shelves
Stationary shelf
07011077
St, 1.5 mm,
RAL 7021,
with perforation,
75 kg
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
Shelf, stationary
for server
Telescopic shelf, 2 U, 70 kg
Full depth
07011077
Shortened by
100 mm
07011101
07011102
St, 1.5 mm, RAL 7021,
static loadSt, 1.5 mm,
carrying capacity when fully extended
RAL 7021,
70 kg, incl. telescopic slide;
with perforation,
please order T-bar lock
and GND/
static loadearthing kit separately
carrying capacity
75 kg
T-bar lock
01004125
to lock the
telescopic shelf
GND/earthing
aza43284
for telescopic
shelf
1 piece
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
assembled
27230-051
27230-052
27230-051
27230-052
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-051
27230-052
27230-053
27230-088
27230-089
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
27230-165
21130-357
21130-353
21130-357
21130-353
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-357
21130-353
21130-355
27230-108
27230-109
21130-358
21130-352
21130-358
21130-352
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
21130-358
21130-352
21130-354
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
23130-092
21120-189
1.273
Slide rails
Slide rail
Slide rail
07011078
St, 1.5 mm,
finish AlZn,
25 kg/pair
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
1.274
Heavy-load
slide rail
07011078
Heavy-load
slide rail
for server
07011078
St, 1.5 mm, finish AlZn,
50 kg/pair
Short slide rail
ERA46348
sc96xxxx
15 kg/pair
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
assembled
assembled
assembled
enclosed loose
enclosed loose
27230-102
27230-103
27230-102
27230-103
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
27230-102
27230-103
27230-104
27230-105
27230-106
25230-013
25230-014
25230-013
25230-014
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-013
25230-014
25230-015
25230-145
25230-146
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
25230-148
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
27230-184
27230-185
SCHROFF PRODUCT CATALOG E 06/2017
Cable ties, Velcro-type tape
Cable tie
Velcro
General
components
Mechanics
01005078
plastic,
92 mm x 2.5 mm;
01005079
black,
length 300 mm,
from page
3.2
Electrics
Cabinet dimensions
Height
Width Depth
No. U
mm mm
mm
1
6
357
553
500
2
6
357
553
600
3
9
456
553
500
4
9
456
553
600
5
12 589
553
500
6
12 589
553
600
7
12 589
553
800
8
12 589
553
900
9
12 589
553
1000
10 16 767
553
500
11 16 767
553
600
12 16 767
553
800
13 16 767
553
900
14 16 767
553
1000
15 20 945
553
500
16 20 945
553
600
17 20 945
553
800
18 20 945
553
900
19 20 945
553
1000
20 25 1167 553
500
21 25 1167 553
600
22 25 1167 553
800
23 25 1167 553
900
24 25 1167 553
1000
25 34 1567 553
500
26 34 1567 553
600
27 34 1567 553
800
28 34 1567 553
900
29 34 1567 553
1000
30 38 1745 553
500
31 38 1745 553
600
32 38 1745 553
800
33 38 1745 553
900
34 38 1745 553
1000
35 43 1967 553
500
36 43 1967 553
600
37 43 1967 553
800
38 43 1967 553
900
39 43 1967 553
1000
40 47 2145 553
500
41 47 2145 553
600
42 47 2145 553
800
43 47 2145 553
900
44 47 2145 553
1000
SCHROFF.PENTAIR.CO.UK
PU 25 pieces
PU 10 pieces
supplied loose
supplied loose
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.30
Power
distribution
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
from page
3.35
Climate control
20118-351
20118-624
from page
4.0
20118-351
20118-624
20118-351
20118-624
20118-351
20118-624
1.275
P Main CataloguePart num ber in bold face type: ready for despatch w ithin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Cabinets – P
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
00105003
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
19" grid integrated in upright
00105004
Simple solution for shortened
doors
00105005
Doors can also be assembled
laterally
00105066
Standards/certifications
쮿 External and internal dimensions in accordance
with
IEC 60297-3-100
쮿 Type of ingress protection: IP 40, in accordance with
IEC 60529
쮿 Protective GND/earthing connections in accordance
with DIN EN 50178/VDE 0160
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
1.270
SCHROFF PRODUCT CATALOG E 11/2017
Cabinets – P
Overview . . . . . . 1.270
PMain C atalogue
19" electronic cabinet
쮿 Type of ingress protection up to IP 40
Introduction . . . . . 1.272
Dimensions . . . . . 1.274
쮿 Bolted frame, die-castings and aluminium profiles,
with inset covers
쮿 Static load-carrying capacity 400 kg
쮿 New colours: RAL 7021 (black grey) or
RAL 7021/RAL 7035 (black grey/light grey) colour combination
Cabinet with
front and rear door
Cabinet without
front and rear door
00108002
쮿 38 and 43 U
쮿 Depth 600 and 800 mm
쮿 34, 38, 43 and 47 U
ServicePLUS from page 1.288
e.g. individual configuration and assembly
e.g. modifications (special colours or sizes)
e.g. variants of uprights
e.g. custom solutions (electromagnetically shielded
applications)
eurorack
00108004
19" cabinets with
front and rear
door . . . . . . . . . . . . 1.276
19" cabinets
without front and
rear door . . . . . . . . 1.277
Front/
rear doors . . . . . . 1.278
Door hinge
bracket for
shortened
doors . . . . . . . . . . . 1.279
Base plates . . . . . . 1.280
Bases/plinths . . . . 1.280
Cable ducting with
C-profiles . . . . . . . . 1.282
Cable eyes for
C-profile . . . . . . . . 1.283
Slide rails . . . . . . . 1.284
Cable ties . . . . . . . 1.283
Fixed/telescopic
shelves . . . . . . . . . 1.285
Cable trays . . . . . . 1.287
Cable ties . . . . . . . 1.287
Velcro . . . . . . . . . . 1.287
ServicePLUS
1.288
ServicePLUS
configuration 19"
1.289
eurorack . . . .
ServicePLUS
configuration
Universal
eurorack . . . . . . . 1.300
www.schroff.biz/ServicePLUS
30407004
1.271
Cabinets – P
eurorack - the "classic"
Text
00108005
Handsome to behold is this classic among electronics cabinets,
and with good reason. Its load-bearing frame consists of a
die-cast aluminium frame and aluminium uprights whose fluting
gives the impression of classical pillars. Thus in eurorack - and
also in NOVASTAR - the cladding parts are not fitted externally on
the frame but rather inside between the frame and uprights. Thus
they remain visible and give the cabinet its unmistakable look.
The cabinet is available in two colour schemes.
The basic frame and top cover are always in black grey
(RAL 7021). With black grey claddings (side panels, doors and rear
panels) you get an entirely black cabinet, as it is the
contemporary look in recording studios and data centres.
Alternatively, select the cladding components in light grey
(RAL 7035). The different colours of the frame and lateral parts
give particular emphasis to the aluminium profile.
Wholly classical yet timelessly modern!
PMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 working days
1.272
Cabinets – P
eurorack - frames
19" frame
Universal frame
Text
00108058
Unlike with other cabinet concepts, where the height of a cabinet
is determined by common mm intervals in its exterior
dimen-sions, eurorack is systematically oriented along the
interior dimensions, using the height units of the 19" system.
19" components are thus flush in height with the frame and
without disruptive gaps.
So that likewise no gaps occur in the width there is the 19" frame,
with the 19" plane already integrated in the vertical cabinet
uprights. When fully equipped with 19" components, the cabinet
therefore looks superb without any cover trims, decorative
frames or doors.
Nevertheless, if a door is required, the eurorack glazed door is a
clear design option, with 60 mm space in front of the 19" mounting
for assembly.
01008059
If more space is required in front of the 19" plane, the user can fall
back on the Universal frame and fit separate 19" panel/slide
mounts. These can then be positioned at 25 mm intervals on the
depth members.
However, 800 mm wide cabinets can also be realised using the
Universal frame. For example, equipped with shelves for the
greatest possible surface or with components that require more
flexibility than 19" technology.
Further features
Text
00108060
Die-cast frame and frame are bolted;
the cabinet can thus be dismantled
00105066
Because of their symmetrical upright
dimensions, doors can also be used
on the sides.
00108052
Mobility with mobile base
Part number in normal type: ready for despatch within 10 working days
1.273
Cabinets – P
Dimensions 19" frame
Height
w
h
H
H with feet
mm
998
1220
1398
1620
1798
2020
2198
d
w
d
w1
d1
W
Usable height h
U
29
34
38
43
47
mm
890.5
1112.5
1290.5
1512.5
1690.5
1912.5
2090.5
d1
Width
Cabinet
width
W
mm
600
9
w1
H without feet
mm
989
1211
1389
1611
1789
2011
2189
Ø3
Upright
distance
w
mm
451
Bolt-on
dimension
w1
mm
465
Upright
distance
d
mm
382
582
682
Bolt-on
dimension
d1
mm
396
596
696
Distance
between feet
w2
mm
502
D
00105057
Depth
Cabinet
depth
D
mm
600
800
900
Cdimension
c
mm
480
680
780
Distance
between feet
d2
mm
444
644
744
00105058
Upright 60 mm recessed
00106051
1.274
Cabinets – P
Dimensions Universal frame
Height
H with feet
mm
998
1220
1398
1620
1798
2020
2198
h
H
d
d
H without feet
mm
989
1211
1389
1611
1789
2011
2189
Usable height h
U
29
34
38
43
47
mm
890.5
1112.5
1290.5
1512.5
1690.5
1912.5
2090.5
d1
d1
Width
9
Cabinet width
W
mm
600
800
w
W
Ø3
Upright distance
w
mm
528
728
Distance between feet
w2
mm
502
702
D
00105056
Depth
Cabinet depth
D
mm
600
800
900
Upright distance Bolt-on
dimension
d
d1
mm
mm
426
440
626
640
726
740
Distance
between feet
d2
mm
444
644
744
00105059
00106052
1.275
Cabinets – P
19" cabinet with front and rear door
쮿 Front: smoked glass door, rear: steel door
쮿 19" cut-outs in front and rear uprights
쮿 Inset covers
쮿 Type of protection IP 40
쮿 Available in two colour combinations:
– Frame, side panels, door and top cover in black grey
(RAL 7021)
– Frame and top cover in black grey (RAL 7021),
side panels and door in light grey (RAL 7035)
Delivery comprises (assembled)
00108002
Item
1
Qty
1
2
2
3
4
1
2
5
1
6
1
7
4
Description
19" frame, consisting of 2 Al die-cast frames, RAL 7021,
4 Al extrusion uprights with 19" cut-outs
Side panel, St, 1 mm, fixes with 2 side panel catches per
panel, colour RAL 7021 (black grey) or RAL 7035 (light
grey) see Order information
Top cover with vents, St, 1.5 mm, RAL 7021
Trims, St, 1 mm, RAL 7021 (for decorative finishing at the
top and at the bottom of the front assembly area)
Rear door, St, 1 mm, opening angle 120°,
safety lock with 2 keys Colour RAL 7021
Glass door, Sekurit, 6 mm, smoke grey, opening angle
120°, safety lock with 2 keys
Foot, Al
Order Information
Usable Height
height H
Width W Depth D C
Colour
RAL 7021
U
mm
mm
mm
mm
Part no.
38
1798
600
600
480
10117-537
38
1798
600
800
680
10117-538
43
2020
600
600
480
10117-539
43
2020
600
800
680
10117-540
GND/earthing for frame, doors, side panels, top cover and
base plate, PU 1 kit
Lifting eyes St, zinc-plated, M10, PU 4 pieces
Adjustable feet Load-carrying capacity 100 kg/foot, St and
PA, black, PU 4 pieces
Castors Load-carrying capacity 100 kg/castor, PU 4 pcs
Castors Load-carrying capacity 60 kg/castor, PU 4 pcs
00105060
Colour
RAL 7021/
RAL 7035
Part no.
10117-533
10117-535
10117-534
10117-536
21101-539
20117-080
21101-201
20117-024
20117-757
Note
쮿 Please order base/plinth separately, see page 1.280
쮿 Other sizes available on ServicePLUS configuration,
see from page 1.289
쮿 Please find the new generation of 19" aluminium electronics
cabinets under NOVASTAR, page 1.240
00105067
ServicePLUS see page 1.288
1.276
Cabinets – P
19" cabinet without front and rear door
쮿 Door combination freely selectable
쮿 Inset covers
– frame, side panels and top cover in black grey (RAL 7021)
– frame and top cover in black grey (RAL 7021) side panels
Item Qty
1
1
2
2
3
4
1
2
5
4
Description
Trim, St, 1 mm, RAL 7021 (for decorative finishing at top
and bottom of front assembly area)
Foot, Al
Order Information
00108004
2
H
4
1
15
2
W
Height
H
Width W Depth D C
Colour
RAL 7021
U
mm
mm
mm
mm
Part no.
34
1567
600
600
480
10117-541
34
1567
600
800
680
10117-544
38
1798
600
600
480
10117-542
38
1798
600
800
680
10117-545
43
2020
600
600
480
10117-543
43
2020
600
800
680
10117-546
47
2198
600
800
680
10117-547
3
4
Usable
height
Colour
RAL 7021/
RAL 7035
Part no.
10117-527
10117-530
10117-528
10117-531
10117-529
10117-532
10117-548
21101-539
20117-080
21101-201
20117-024
20117-757
Note
D
5
00105061
쮿 Please order front and rear door separately, see page 1.278
see from page 1.289
00105067
1.277
Cabinets – P
Glass door, 120° opening angle
Main Catalogue
쮿 Can be assembled on all four sides
75
쮿 Opening angle 120°
Delivery comprises
35
Item
1
2
3
4
Description
Safety lock with 2 keys
Hinge, St, 3 mm, black (RAL 9005)
Assembly kit
Order Information
H
era44522
Qty
1
1
2
1
mra45967
For cabinet
height
mm
782
945
1167
1290
1567
1798
2020
2198
Usable
height
U
16
29
34
38
43
47
H
mm
733
911
1133
1311
1534
1711
1934
2111
For cabinet
width
mm
553
553
553
553
553
553
553
553
Part no.
20117-744
20117-745
20117-746
20117-747
20117-748
20117-749
20117-751
20117-752
쮿 Doors with opening angle 180° see page 1.291
쮿 Further dimensions available on ServicePLUS, see from page
1.291
Steel door, 120° opening angle
쮿 Colour black grey (RAL 7021) or light grey (RAL 7035)
g
.6
un
ist . . .
e
l
e
c
rvi
Se . . . .
e
pp
ite
ma
Se
s
ng
ibu ware 7
e
r
h ft
ssc so
Au ungs . . . .
n
Pla . . . .
ite
Se
Delivery comprises
Item
1
2
3
H
21
523
00105053 a4491c
1.278
Qty
1
1
1
Description
Steel door, St, 1 mm
Assembly kit
Order Information
For cabinet
height
Usable
height
H
mm
767
945
1167
1290
1567
1798
2020
2198
U
16
29
34
38
43
47
mm
733
911
1133
1311
1534
1711
1934
2111
For
cabinet
width
mm
600
600
600
600
600
600
600
600
Colour
RAL 7021
Colour
RAL 7035
Part no.
Part no.
22117-934
21117-184
22117-935
22117-936
21117-185
21117-186
23117-012
21117-187
22117-937
22117-938
21117-188
21117-189
22117-940
21117-190
22117-942
21117-191
see from page 1.292
쮿 180° steel door with lever handle see ServicePLUS
configuration, page 1.292
Cabinets – P
Glazed door, 120° opening angle
PMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
523
29
46
쮿 Frame colour: black grey (RAL 7021) or light grey (RAL 7035)
Delivery comprises
Item
1
2
3
4
era44522
mra49568
Description
Door frame, Al, 2 mm, RAL 7035
Plexiglass pane, 2 mm, clear
Assembly kit
Order Information
For
cabinet
height
mm
782
945
1167
1290
1567
1798
2020
2198
H
21
Qty
1
1
1
1
Usable
height
H
U
16
29
34
38
43
47
mm
733
911
1133
1311
1534
1711
1934
2111
For
cabinet
width
mm
600
600
600
600
600
600
600
600
Colour
RAL 7021
Colour
RAL 7035
Part no.
Part no.
22117-943
20117-769
22117-944
22117-945
20117-770
20117-771
23117-011
20117-772
22117-946
22117-947
20117-765
20117-766
22117-949
20117-767
22117-951
20117-768
쮿 Further dimensions available on ServicePLUS configuration,
see page 1.292
Door hinge bracket for shortened doors
P
쮿 For doors which do not cover the full cabinet height
2
쮿 1 U space required (may be mounted above and below the door)
쮿 The clearance can be covered with 19" filler panels or with
cable ducting plates 3 U/4 U
Delivery comprises (kit)
1HE
Item
1
2
3
Qty
1
1
1
Description
Door hinge bracket, 19", St, 1.5 mm, RAL 7021
Trim, St, 1 mm, RAL 7021, cover for frame
Assembly kit
Order Information
1
4
00105068
4
Description
Item 4 Cable ducting 3 U, RAL 7021, with brush strip and
fixing materials kit, 1 piece
Item 4 Cable ducting 4 U, RAL 7021, with brush strip and
Part no.
22117-798
20118-796
20118-797
37
55
쮿 19" front panels see chapter Cabinet Accessories, page 3.2
Cable ducting plate
00201507
1.279
Cabinets – P
Base plates
P
쮿 For covering the base opening, two parts
쮿 Mounting on frame, overlaying
Delivery comprises
Item
1
Qty
2
2
1
Description
Base plate, St, 1.5 mm, RAL 7021, width 469 mm,
depth 234 mm (at cabinet depth 600 mm),
depth 334 mm (at cabinet depth 800 mm)
Assembly kit
Order Information
For cabinet width
mm
600
600
For cabinet depth
mm
600
800
Part no.
22117-826
22117-827
00108051
Plain bases/plinths
P
쮿 Height 100 mm
쮿 Covers removable from all sides
Delivery comprises
3
Item
1
2
4
4
Ø 15
1
2
Qty
4
2
2
1
Description
Corner piece, AI die-cast
Cover, St, 2.5 mm, RAL 7021, for front and rear
Cover, St, 2.5 mm, RAL 7021, for sides
Assembly kit
Order Information
w
d
ERA44532
00108057
For cabinet width
For cabinet depth
mm
mm
600
600
600
800
St and PA, black, PU 4 pieces
Part no.
22117-830
22117-831
21101-201
Note
쮿 Castors cannot be used with a base/plinth
era44553
1.280
Cabinets – P
Bases/plinths with ventilation
P
쮿 Height 100 mm
쮿 Covers removable on all sides
쮿 Can be assembled with filter
Delivery comprises (Kit)
4
6
Item
1
2
Qty
4
2
3
4
5
2
2
1
Description
Cover, St, 2.5 mm, RAL 7021, for front and rear, with vent
slots
Filter retention
Assembly kit
Order Information
2
3
1
ERTP0057
For cabinet width
For cabinet depth
mm
mm
600
600
600
800
Filter mat Item 6 for cabinet depth 600 mm,
width 600 mm, PU 3 pieces
Filter mat Item 6 for cabinet depth 800 mm,
Part no.
22117-864
22117-865
60114-514
60114-515
Note
쮿 Filter mat not included, please order separately
1.281
Cabinets – P
Mounting system with C-profiles
Mounting system
P
쮿 The mounting system serves for assembly of horizontal and
vertical mounting planes; C-profiles can be positioned freely by
using combination and L-brackets in conjunction with slide
nuts
쮿 Slide nuts, cable eyes or cable shells can be inserted directly
into the C-profiles
Delivery comprises
Item
1
Qty
see Order
Information
Description
C-profile, St, 1.5 mm, finish AlZn
Order Information
ertp0020
C-profile/slide nut
25
9
Ø 5,25
30
10
L
15
5
1
ertp0021
Mounting bracket
For cabinet For cabinet For
Length L Qty/PU
width
depth
cabinet
height
mm
mm
mm
mm
piece
600
450
4
600
800
650
4
900
750
4
600
650
4
800
800
650
4
1600
1500
2
1800
1650
2
2000
1900
2
Item 2 Mounting bracket for cabinet upright or depth
member assembly, St, 2.5 mm, zinc-plated, PU 4 pieces,
incl. assembly kit
Item 3 Combination bracket for connection of
two C-profiles, St, 2.5 mm, zinc-plated, PU 4 pieces,
incl. assembly kit
Item 4 L-bracket for edge-to-edge or corner
connection of two C-profiles, St, 2.5 mm, zinc-plated, 2
right hand brackets and 2 left hand brackets, incl.
assembly kit
Item 5 Slide nut for C-profiles, PU 10 pieces
Item 5 Slide nut for C-profiles, PU 100 pieces
Delivery: supplied loose with cabinet or frame
Part no.
22114-455
22114-457
22114-458
22114-457
22114-457
22114-460
22114-461
22114-462
21120-145
21120-146
21120-147
21120-140
21101-127
Part no./35
Note
ertp0022
쮿 Please order mounting brackets separately
Combination bracket
ertp0024
L-bracket
ertp024a
1.282
Cabinets – P
Cable eyes for C-profiles
P
Delivery comprises
Item
1
D=
W
95
=9
5
75
D=
W
=4
D=
Qty
4
45
Description
Cable eye, round steel, 6 mm, zinc-plated, with
integrated anti-rotation protection
Order Information
W
Description
W
mm
Cable eye for C-profile
120
40
95
Assembly kit for 4 cable eyes, PU 1 kit
=1
00507051
00507052
D
mm
45
75
95
Part no.
20118-339
20118-554
20118-340
21101-596
Note
쮿 Please order assembly kit separately
Cable shells
P
쮿 For mounting of cables on C-profiles and cable support rails
Delivery comprises
Item
1
Qty
10
Description
Cable shell, St, 2 mm, tin-plated, with plastic half shells
Order Information
For cable bundle d
mm
18 ... 22mm
22 ... 26mm
26 ... 30mm
30 ... 34mm
34 ... 38mm
38 ... 42mm
42 ... 46mm
46 ... 50mm
b
mm
26
30
34
38
45
48
51
54
Part no.
20118-775
20118-776
20118-777
20114-728
20114-729
20114-730
20114-731
20118-778
vnt009
1.283
Cabinets – P
Slide rail
P
쮿 For safe and simple installation of heavy
19" subracks
쮿 Can be hung into the upright at 1 U increments
쮿 Load-carrying capacity max. 25 kg per pair
Delivery comprises
c
D
Item
1
2
1
Qty
10
1
Description
Slide rail for insertion, St, 1.5 mm, surface AlZn
Assembly kit
Order Information
c = pitch of the 19" uprights
xf
W
For cabinet depth
mm
600
800
00205059
00205069
Length L
mm
420
620
c
mm
480
680
xf
mm
60
60
Part no.
21127-197
21127-198
Note
쮿 Can only be fitted to 19" upright
see from page 1.298
L = length
41003080
Short slide rail
P
쮿 For mounting on the vertical cabinet uprights
쮿 Can be hung at 1 U increments
쮿 Static load-carrying capacity 15 kg max per pair
Delivery comprises
Item
1
2
Qty
2 / 10
1
Description
Short slide rail, St, 1,5 mm, finish AlZn
Assembly kit
Order Information
sc96xxxx
1.284
Description
Short slide rail
Short slide rail
Qty/PU
2
10
Part no.
20118-592
20118-593
Cabinets – P
19'' fixed shelf, 75 kg
P
쮿 Mounting height 1 U, for mounting on cabinet uprights,
full depth
쮿 With hammer head perforation to fix cable ties
Delivery comprises
Item
1
2
1
Qty
1
1
Description
Shelf, St, 1.5 mm, RAL 7021
Assembly kit incl. GND/earthing kit
Order Information
00105054
Cabinet dimensions
WxD
mm
600 x 600
600 x 800
Usable surface
wxd
mm
477 x 443
477 x 643
xf
xr
c
mm mm mm
60
60
480
60
60
680
Part no.
22117-842
22117-843
Note
see from page 1.299
00105050
1.285
Cabinets – P
19'' telescopic shelf, 70 kg
P
쮿 Mounting height 2 U, for mounting on four 19" panel/slide
mounts
1
쮿 Locking with T-bar lock possible
2
쮿 Hammer head perforation to fix cable ties
4
쮿 2 versions
– Full depth
Delivery comprises
00105052
Full depth
Item
1
2
3
Qty
1
2
1
Description
Telescopic slide, 2 U
Assembly kit
Order Information
Full depth
Cabinet dimensions
Usable surface
c
WxD
wxd
mm
mm
mm
600 x 600
405 x 482
480
600 x 800
405 x 682
680
GND/earthing for telescopic shelf PU 1 kit, for
NOVASTAR, eurorack
Full depth
Part no.
21130-353
21130-355
23130-092
21120-189
00105069
Shortened depth
Order Information
Shortened by 100 mm
Cabinet dimensions
Usable surface
c
Shortened by
WxD
wxd
100 mm
mm
mm
mm
Part no.
600 x 600
405 x 382
480
21130-352
600 x 800
405 x 582
680
21130-354
23130-092
GND/earthing for telescopic shelf PU 1 kit, for NOVASTAR,
21120-189
eurorack
c = max. pitch of the slide mounts
1.286
00105070
Cabinets – P
Cable panels
P
쮿 For mounting direct onto the frame, can be recessed with depth
members
쮿 Fixing of cables with cable ties or Velcro
쮿 Colour RAL 7021 (black grey) or RAL 7035 (light grey)
쮿 Widths 150 mm and 250 mm
1
Delivery comprises
Item
1
2
Qty
2
1
Description
Cable panel with cut-outs, St, 1 mm
Assembly kit
Order Information
H
For cabinet height H
D
RAL 7021
U
mm
mm
Part no.
38
1798
150
23117-020
43
1934
150
23117-021
47
2020
150
23117-022
38
1798
250
23117-023
43
1934
250
23117-024
47
2020
250
23117-025
Depth member for 19" eurorack 600 mm cabinet depth,
St, 1.5 mm, AlZn, PU 2 pieces
Depth member for 19" eurorack 800 mm cabinet depth,
St, 1.5 mm, AIZn, PU 2 pieces
10
D
00108050
RAL 7035
Part no.
23117-026
23117-027
23117-028
23117-029
23117-030
23117-031
22117-376
22117-377
Note
쮿 Cable ties, see page 1.287
쮿 Velcro, see page 1.287
Cable ties
P
Delivery comprises
Item
1
Qty
25
Description
Cable tie, plastic
Order Information
Description
Cable tie
Cable tie
Cable tie
Part no.
92 mm x 2.5 mm
186 mm x 5 mm
360 mm x 5 mm
20118-351
20118-352
20118-353
01005078
Velcro
P
쮿 Length 300 mm (for cable bundles of max. 90 mm diameter)
Delivery comprises
Item
1
Qty
10
Description
Velcro strip, PE/PA, black, length 300 mm
Order Information
Description
Velcro strip
Part no.
20118-624
01005079
1.287
Cabinets – P19" ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined
freely
쮿 Configuration tables from page 1.289
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 Without extra cost
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Download CAD data and send back with modifications
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Climate control, complete assembly, cabling (power
supply), function test
쮿 Online configuration: www.schroff.co.uk/configuration
쮿 Ready for despatch within 10 working days
쮿 Ready for despatch within 15 working days
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
replacement parts
19" Servic ePLUS
1.288
Cabinets – P 19" ServicePLUS
eurorack 19" ServicePLUS: configuration and assembly
1 9" ServicePLUSP
쮿 Dimensions:
– Height: 20 ... 47 U (998 ... 2198 mm)
– Width: 600 mm
– Depth: 600, 800 mm
Page
Frames, side-by-side
mounting kit, GND/
earthing, adjustable feet,
castors
1.290
Side panels, glass doors
1.291
쮿 Build your cabinet out of individual components
(please suffix each part number with /05)
Doors
1.292
쮿 Once you have selected the desired cabinet dimensions, the row
number (first column of the configuration tables) will guide you
through all subsequent configuration pages that apply to these
Door hinge bracket, cable
1.293
ducting
쮿 Colours:
– Frame, top cover and plinth in black grey (RAL 7021);
– Side panels and doors in light grey (RAL 7035)
or black grey (RAL 7021)
쮿 The cabinet is assembled by us and
Flush top covers
1.294
Raised top covers
1.295
Base plates, plinths
1.296
Third 19" plane, lateral
cable ducting
1.297
19" slide rails
1.298
19" fixed or telescopic
shelves
1.299
1.274
ServicePLUS
configuration
eurorack Universal
1.300
00101534
Example configuration (here: row 14)
Qty
1
1
1
1
1
1
Description
19" frame, RAL 7021, height 2020 mm, width 600 mm, depth 800 mm, 1 piece
Adjustable foot, PU 4 pieces
Side panel, screw fixed, RAL 7035, PU 2 pieces
Front glass door, RAL 7035, opening angle 120°, 1 piece
Rear steel door, RAL 7035, opening angle 120°, 1 piece
DIN profile half cylinder, 1 piece
Order no.
22117-779/05
21101-201/05
21117-172/05
20117-751/05
21117-190/05
60114-121/05
1.289
eurorack 19"
Frames, side-by-side mounting kit, GND/earthing, adjustable feet, castors
Order Information
19" frame
19" plane to front
and rear
era45341
Side-by-side
mounting kit
GND/earthing
Castors
Load-carrying
capacity 180 kg
per kit
ERTP0070
serves to bolt
19" frame,
together
frame Al die-cast,
two cabinets;
uprights
sealing strips are
Al extrusion,
PU foam
RAL 7021, defined
pitch between
front and rear 19"
plane
Adjustable feet
aza43284
era44553
for frame, door,
side panel, top
cover, base plate
St, PA, black,
load-carrying
capacity 100 kg
per foot
Load-carrying
capacity 300 kg
per kit
era44556
assembly directly assembly directly
onto frame,
onto frame,
height H =
height H =
110 mm,
93 mm, 2 locking,
2 locking, 2 non2 non-locking
lockingcastors
castors
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
assembled
supplied loose
assembled
assembled
enclosed loose
enclosed loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-977
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
20117-156
21101-539
21101-201
20117-757
20117-024
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
22117-978
22117-979
22117-980
22117-981
22117-982
22117-772
22117-773
22117-774
22117-775
22117-776
22117-977
22117-978
22117-979
22117-980
22117-983
22117-981
22117-984
Frame dimensions, see page 1.274
1.290
eurorack 19"
Order Information
Side panel
with side-panel catches
Side panel
with safety lock
Glass door
Opening angle
120°
ERA44517
St, 1 mm,
RAL 7035,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
ERA44517
St, 1 mm,
RAL 7035,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
St, 1 mm,
RAL 7021,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
mra45967
glazing
smoke grey,
Sekurit, 6 mm,
safety lock with
2 keys
DIN profile half
cylinder
00101506
glazing
smoke grey,
Sekurit, 6 mm,
lever handle
(incl. blank
insert)
SZA44484
DIN profile half
cylinder for lever
handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
Width
Depth
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
20117-745
20117-746
20117-747
22117-239
60114-121
20117-748
22117-227
60114-121
20117-749
22117-228
60114-121
20117-751
22117-229
60114-121
20117-752
22117-230
60114-121
No. U
mm
mm
mm
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
21117-158
22117-993
21117-167
21117-159
22117-994
22117-995
21117-168
22117-996
21117-160
21117-169
22117-997
22117-998
22117-185
22117-186
23117-002
23117-003
21117-161
22117-958
22117-173
23117-004
21117-170
21117-179
22117-959
22117-960
22117-177
22117-181
23117-005
23117-006
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
Glass door
Opening angle
180°
21117-162
22117-961
22117-174
23117-007
21117-171
21117-180
22117-962
22117-963
22117-178
22117-182
23117-008
23117-009
21117-163
22117-964
22117-175
22117-968
21117-172
21117-181
22117-965
22117-966
22117-179
22117-592
22117-969
22117-970
21117-164
22117-999
22117-176
23117-010
21117-173
21117-182
22117-967
23117-001
22117-180
22117-593
22117-971
22117-972
Note: Doors can also be assembled laterally, in place of side panels
1.291
eurorack 19"
Doors
Order Information
Glazed acrylic glass door
Steel door
Opening angle 120°
Opening angle 120°
Steel door
a4491b
frame, Al, 2 mm, frame, Al, 2 mm,
RAL 7021;
RAL 7021;
acrylic glass,
acrylic glass,
2 mm,
2 mm,
safety lock with
safety lock with
2 keys
2 keys
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.292
Opening angle 180°
00101506
DIN profile half
cylinder
00101504
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
St, 1 mm,
RAL 7021,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
RAL 7021
SZA44484
DIN profile half
cylinder for
lever handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
20117-770
22117-944
21117-185
22117-935
20117-771
22117-945
21117-186
22117-936
20117-772
23117-011
21117-187
23117-012
22117-201
23117-013
60114-121
20117-765
22117-946
21117-188
22117-937
22117-189
23117-014
60114-121
20117-766
22117-947
21117-189
22117-938
22117-190
23117-015
60114-121
20117-767
22117-949
21117-190
22117-940
22117-191
22117-973
60114-121
20117-768
22117-951
21117-191
22117-942
22117-192
22117-975
60114-121
eurorack 19"
Door hinge bracket, cable ducting
Order Information
Door hinge
bracket for
19" frame
Cable ducting frame
3U
4U
00105068
07011081
St, 1.5 mm,
with black brush strip for short doors
RAL 7021,
or rear panels
mounting to front
or rear,
above or below
the short door,
1U
assembly area,
please order
19" cable ducting
separately
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1 piece
1 piece
1 piece
assembled
assembled
assembled
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
22117-798
20118-796
20118-797
1.293
eurorack 19"
Flush top covers
Order Information
Flush top cover
Plain
Louvered
Top cover fan for flush louvered top cover
Lifting eyes
Fan trays without
fans
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44525
St, 1 mm, RAL
7021
ERA45344
ERA44560
St, 1 mm, RAL
7030
lifting eye for
flush cover,
application and
static loadcarrying capacity
in accordance
with DIN 582
ertp0055
St, 1.5 mm,
RAL 7021,
all 6 openings
closed with PE
blank plugs,
terminal
clamp with
connecting
cable, 2 m, IEC60320 C14 plug
KTA44844
axial fan 230 VAC,
8 W, 90 m3/h,
height 25 mm,
protective grille,
plastic, black,
flammability
UL 94 V-0
01108052
01105055
for air barrier,
fully wired,
with mains cable
90 ... 264 VAC,
230 VAC
input SCHUKO/
UTE plug,
(SCHUKO/UTE
outlet IEC 60320
plug/
C13 socket;
IEC 60320 C13
external NTC
socket),
sensor 1.5 m
adjustment range
0 ... 60°C
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-801
22117-806
22117-802
22117-807
20713-048
20118-750
60715-005
22117-801
22117-802
22117-806
22117-807
20713-048
20118-750
60715-005
22117-801
22117-806
22117-802
22117-801
22117-807
22117-806
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.294
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-808
20117-080
20117-080
20117-080
20117-080
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
22117-821
20117-080
22117-822
22117-823
eurorack 19"
Raised top covers
Order Information
Raised top cover
Raised
Fan for raised top cover
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44526
ERA44560
St, 1.5 mm,
RAL 7021,
air gap all round
8 mm, IP 20
lifting eye for
raised top cover,
application and
in accordance
with DIN 582
ertp0055
KTA44844
KTA44844
01108052
01105055
axial fan 230 VAC, axial fan 230 VAC,
St, 1.5 mm,
fully wired,
for air barrier,
RAL 7021,
90 ... 264 VAC,
with mains cable
15 W, 162 m3/h,
8 W, 90 m3/h,
all 6 openings
230 VAC
height 38 mm,
height 25 mm,
input SCHUKO/
closed with PE
plastic, black,
plastic, black,
UTE plug,
(SCHUKO/UTE
blank plugs,
flammability
flammability
outlet IEC 60320
plug/IEC 60320
terminal
UL 94 V-0
UL 94 V-0
C13 socket;
C13 socket),
clamp with
external NTC
adjustment range
connecting cable,
sensor 1.5 m
0 ... 60°C
2 m, IEC-60320
C14 plug
Cabinet dimensions
Width
Depth
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-811
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
22117-812
22117-811
22117-812
22117-811
22117-812
22117-811
22117-812
20150-011
20150-011
20150-011
20150-011
22117-813
22117-811
22117-812
20150-011
22117-813
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-822
22117-823
22117-821
20150-011
22117-813
22117-811
22117-812
22117-822
22117-823
22117-821
22117-813
22117-811
22117-812
22117-821
22117-822
22117-823
22117-821
20150-011
22117-822
22117-823
1.295
eurorack 19"
Order Information
Base plate
Fixed base/plinth , height 100 mm
Plain
00108051
St, 1.5 mm,
RAL 7021,
two parts,
mounting on
frame
With ventilation
ERA44532
base, Al die-cast,
covers, St,
2.5 mm,
RAL 7021
Filter mat
ERTP0057
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021,
front and rear
with ventilation
openings;
please order
filter mat
separately
ERTP0057
Adjustable feet
era44553
filter mat for fixed
base/plinth,
with ventilation
St, PA, black,
load-carrying
capacity 100 kg
per foot
Cabinet dimensions
Width
Depth
PU 2 pieces
1 piece
1 piece
PU 3 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
enclosed loose
assembled
assembled
enclosed loose
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
22117-826
22117-830
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
22117-826
22117-830
22117-864
60114-514
22117-827
22117-826
22117-831
22117-830
22117-865
22117-864
60114-515
60114-514
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.296
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
22117-828
22117-832
22117-866
21101-201
21101-201
21101-201
21101-201
21101-201
21101-201
21101-201
eurorack 19"
Third 19" plane, lateral cable ducting
Order Information
RAL 7021
Depth member
AlZn
SZA45958
St, 1.5 mm, with 19" cut-outs;
to mount a third 19" plane,
1 pair of 19" panel/slide mounts
and 2 pairs of depth members are
required
Width
Cable panel
Width 250 mm
ertp0043
St, 1.5 mm, AlZn,
for assembly of
the third 19"
plane or other
components
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
RAL 7021
AlZn
AlZn
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
assembled
assembled
assembled
23117-026
23117-020
23117-029
23117-023
23117-027
23117-021
23117-030
23117-024
23117-028
23117-022
23117-031
23117-025
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
Cable panel
Width 150 mm
Depth
Cabinet dimensions
Height
Lateral cable ducting
For 19" eurorack
23117-017
22117-352
23117-018
22117-353
23117-019
22117-354
22117-835
22117-355
22117-376
22117-377
22117-376
22117-377
22117-376
22117-377
22117-376
22117-377
22117-378
22117-376
22117-836
22117-356
22117-377
22117-378
22117-376
22117-837
22117-357
22117-377
22117-378
22117-376
22117-838
22117-358
22117-377
22117-378
1.297
eurorack 19"
19" slide rails
Order Information
Dimensions
standard
assembly
Slide rail
Short slide rail
40 kg, depthadjustable
W
xf
c
D
25 kg
00205066
xf = distance from
front
c = pitch of 19"
plane
D = cabinet depth
W = cabinet width
00108056
St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair
41003081
St, 1,5 mm,
finish AlZn,
40 kg/pair,
depth-adjustable
(c: 675 - 850 mm)
sc96xxxx
St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
1.298
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
480
680
780
480
680
780
PU 2 pieces
PU 10 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
enclosed loose
enclosed loose
enclosed loose
enclosed loose
enclosed loose
22127-094
21127-197
22127-095
21127-199
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-199
28127-001
20118-592
20118-593
22127-094
21127-197
22127-095
22127-094
21127-199
21127-197
28127-001
20118-592
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-199
21127-197
28127-001
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
21127-199
28127-001
eurorack 19"
19" fixed or telescopic shelves
Order Information
Fixed shelf, 1 U, 75 kg
Full depth
Shelf, telescopic, 2 U, 70 kg
Recessed by c 100 mm
Full depth
Shortened by
100 mm
T-bar lock
GND/earthing
W
xf
c
D
Dimensions
standard
assembly
00205066
00105050
St, 1.5 mm,
xf = distance from
RAL 7021, with
front c = pitch of
perforation,
19" plane
static loadD = cabinet depth
carrying capacity
W = cabinet
75 kg, incl. GND/
width
earthing
00105051
St, 1.5 mm,
RAL 7021, with
perforation,
75 kg, incl. GND/
earthing,
third 19" plane
necessary,
please order
separately
00105069
00105070
St, 1.5 mm, staic load-carrying
capacity 70 kg, incl. telescopic slide;
please order T-bar lock and GND/
earthing separately
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
2020
2020
2020
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
800
600
800
600
800
600
800
900
600
800
900
600
800
900
600
800
900
25
29
29
34
34
34
38
38
38
43
43
43
47
47
47
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
480
680
780
480
680
780
1 piece
1 piece
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
assembled
assembled
22117-842
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-842
22117-843
22117-845
22117-871
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
22117-842
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-842
22117-871
22117-845
21130-355
21130-353
21130-354
21130-352
23130-092
23130-092
21120-189
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-842
22117-843
22117-845
21130-353
21130-352
23130-092
21120-189
22117-843
22117-871
21130-355
21130-354
23130-092
21120-189
22117-844
22117-843
1.299
Cabinets – PUniversal ServicePLUS
configuration
freely
쮿 Configuration tables from page 1.301
assembly
Assembly of all mechanical, electrical and
modification
solution
academy
reports
lifecycle
maintenance, repair, replacement parts, recycling
Universal ServicePLUSP
1.300
Cabinets – P Universal ServicePLUS
eurorack Universal ServicePLUS: configuration and assembly
쮿 Dimensions:
– Width: 600, 800 mm
– Depth: 600, 800, 900 mm
Page
쮿 Colours:
mounting kit, GND/
castors
1.302
Doors
1.303
1.305
ducting
dimensions (see example below)
Flush top covers
1.306
Raised top covers
1.307
1.308
1.309
19" slide rails
1.311
Fixed 19" shelves
1.312
Telescopic 19" shelves
1.313
Fixed shelves on
Universal
cabinet uprights
Telescopic shelves on
Universal
cabinet uprights
Dimensions
Universal frame
1.314
1.315
1.275
00101534
Example configuration (here: row 17)
Qty
1
1
2
2
1
Description
Universal frame, RAL 7021, height 2020 mm, width 600 mm, depth 900 mm, 1
piece
Lateral steel door, opening angle 120°, RAL 7035, 1 piece
Front, rear glass door, RAL 7035, opening angle 180°, 1 piece
Order no.
22117-792/05
21101-201/05
21117-190/05
22117-229/05
60114-121/05
1.301
eurorack Universal
Order Information
Universal frame
(without 19"
plane)
Side-by-side
mounting kit
era44489
Universal frame,
rack Al die-cast,
uprights
Al extrusion,
19" plane can be
built in 25 mm
increments with
depth members
and depthadjustable
19" panel/slide
mounts
GND/earthing
Castors
Load-carrying
capacity 180 kg
per kit
ERTP0070
serves to screw
together
two cabinets
Adjustable feet
aza43284
era44553
for frame,
door, side panel,
top cover,
base plate
St, PA, black,
load-carrying
capacity
100 kg per foot
Load-carrying
capacity 300 kg
per kit
era44556
onto frame,
onto frame,
height
height
H = 110 mm,
H = 93 mm,
2 locking, 2 non- 2 locking, 2 nonlocking castors
locking castors
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 1 kit
PU 4 pieces
PU 4 pieces
PU 4 pieces
No. U
Height
mm
mm
mm
assembled
supplied loose
assembled
assembled
enclosed loose
enclosed loose
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-985
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
20117-515
21101-539
21101-201
20117-757
20117-024
22117-796
22117-992
20117-515
21101-539
21101-201
20117-757
20117-024
22117-797
20117-515
21101-539
21101-201
20117-757
20117-024
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
22117-986
22117-987
22117-988
22117-989
22117-990
22117-782
22117-783
22117-784
22117-985
22117-986
22117-787
22117-788
22117-789
22117-790
22117-791
22117-792
22117-793
22117-794
22117-991
Frame dimensions, see page 1.275
1.302
eurorack Universal
Order Information
Side panel
Side panel
with safety lock
Glass door
Opening angle
120°
ERA44517
St, 1 mm,
RAL 7035,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
2 side panel
catches;
instead of a side
panel, doors can
also be mounted
laterally
ERA44517
St, 1 mm,
RAL 7035,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
St, 1 mm,
RAL 7021,
2 safety locks;
instead of a side
panel, doors can
also be mounted
laterally
mra45967
glazing
smoke grey,
Sekurit, 6 mm,
safety lock with
2 keys
DIN profile half
cylinder
00101506
glazing
smoke grey,
Sekurit, 6 mm,
lever handle
(incl. blank
insert)
SZA44484
DIN profile half
cylinder for lever
handle
RAL 7035
RAL 7021
RAL 7035
RAL 7021
Width
Depth
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
20117-745
20117-746
20117-747
22117-239
60114-121
20117-748
22117-227
60114-121
20117-749
22117-228
60114-121
20117-754
22117-236
60114-121
20117-751
22117-229
60114-121
20117-753
22117-237
60114-121
20117-752
22117-230
60114-121
20117-756
22117-238
60114-121
No. U
mm
mm
mm
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
21117-158
22117-993
21117-167
21117-159
22117-994
22117-995
21117-168
22117-996
21117-160
21117-169
22117-997
22117-998
22117-185
22117-186
23117-002
23117-003
21117-161
22117-958
22117-173
23117-004
21117-170
21117-179
22117-959
22117-960
22117-177
22117-181
23117-005
23117-006
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
Glass door
Opening angle
180°
21117-162
22117-961
22117-174
23117-007
21117-171
21117-180
22117-962
22117-963
22117-178
22117-182
23117-008
23117-009
21117-162
22117-961
22117-174
23117-007
21117-171
21117-163
22117-962
22117-964
22117-178
22117-175
23117-008
22117-968
21117-172
22117-965
22117-179
22117-969
21117-181
21117-163
22117-966
22117-964
22117-592
22117-175
22117-970
22117-968
21117-172
22117-965
22117-179
22117-969
21117-164
21117-173
22117-999
22117-967
22117-176
22117-180
23117-010
22117-971
21117-182
23117-001
22117-593
22117-972
21117-173
22117-967
22117-180
22117-971
1.303
eurorack Universal
Doors
Order Information
Steel door
Opening angle 120°
Opening angle 120°
Steel door
a4491b
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.304
Opening angle 180°
00101506
DIN profile half
cylinder
00101504
SZA44484
DIN profile half
cylinder for
lever handle
frame, Al, 2 mm,
RAL 7035;
acrylic glass,
2 mm,
safety lock with
2 keys
frame, Al, 2 mm,
RAL 7021,
acrylic glass,
2 mm,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
safety lock with
2 keys
St, 1 mm,
RAL 7021,
safety lock with
2 keys
St, 1 mm,
RAL 7035,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
St, 1 mm,
RAL 7021,
lever handle
(incl. blank
insert), please
order DIN profile
half cylinder
separately
RAL 7035
RAL 7021
RAL 7035
RAL 7021
RAL 7035
RAL 7021
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
1 piece
assembled
assembled
assembled
assembled
assembled
assembled
assembled
20117-770
22117-944
21117-185
22117-935
20117-771
22117-945
21117-186
22117-936
20117-772
23117-011
21117-187
23117-012
22117-201
23117-013
60114-121
20117-765
22117-946
21117-188
22117-937
22117-189
23117-014
60114-121
20117-766
22117-947
21117-189
22117-938
22117-190
23117-015
60114-121
20117-775
22117-948
21117-198
22117-939
22117-198
23117-016
60114-121
20117-767
22117-949
21117-190
22117-940
22117-191
22117-973
60114-121
20117-776
22117-950
21117-199
22117-941
22117-199
22117-974
60114-121
20117-768
22117-951
21117-191
22117-942
22117-192
22117-975
60114-121
20117-777
22117-952
21117-200
22117-957
22117-200
22117-976
60114-121
ELECTRONICS PROTECTION
eurorack Universal
Order Information
Door hinge
bracket for
Universal frame
Cable ducting frame
3U
4U
00105068
St, 1.5 mm,
RAL 7021,
assembly above
or below
shortened door,
1 U assembly
area, please
order 19" panel/
slide mount and
cable ducting
plate separately
SZA45958
short doors or rear panels
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1 piece
1 piece
1 piece
assembled
assembled
assembled
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
22117-799
20118-796
20118-797
1.305
eurorack Universal
Flush top covers
Order Information
Flush top cover
Plain
Louvered
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44525
St, 1 mm,
RAL 7021
ERA45344
ERA44560
St, 1 mm,
RAL 7030
lifting eye for
flush cover,
application and
in accordance
with DIN 582
ertp0055
St, 1.5 mm,
RAL 7021,
all 6 openings
closed with PE
blank plugs,
terminal clamp
with connecting
cable, 2 m,
IEC 60320
C14 plug
KTA44844
01108052
01105055
axial fan 230 VAC,
for fan tray,
fully wired,
with mains cable
90 ... 264 VAC,
8 W, 90 m3/h,
230 VAC
height 25 mm,
input SCHUKO/
protective grille,
UTE plug,
(SCHUKO/UTE
plastic, black,
outlet IEC 60320
plug/IEC 60320
flammability
C13 socket;
C13 socket),
UL 94 V-0
external NTC
adjustment range
sensor 1.5 m
0 ... 60 °C
Cabinet dimensions
Width
Depth
1 piece
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-801
22117-806
22117-802
22117-807
20713-048
20118-750
60715-005
22117-801
22117-802
22117-806
22117-807
20713-048
20118-750
60715-005
22117-801
22117-806
22117-802
22117-801
22117-807
22117-806
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.306
22117-802
22117-807
22117-803
22117-801
22117-808
22117-806
22117-802
22117-807
22117-803
22117-802
22117-808
22117-807
22117-804
22117-809
22117-801
22117-802
22117-806
22117-807
22117-803
22117-808
22117-802
22117-804
22117-807
22117-809
20117-080
20117-080
20117-080
20117-080
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20117-080
20117-080
20117-080
22117-822
22117-823
22117-824
22117-825
22117-821
22117-822
22117-823
20117-080
22117-824
22117-825
22117-801
22117-806
22117-802
22117-803
22117-807
22117-808
20117-080
22117-822
22117-823
20713-048
20118-750
60715-005
22117-804
22117-809
20117-080
22117-825
20713-048
20118-750
60715-005
22117-821
eurorack Universal
Raised top covers
Order Information
Raised top cover
Raised
Lifting eyes
Fan tray without
fan
Fan for fan tray
Thermostat
Speed control
30
10
50
°C
1000 mm
300 mm
300 mm
ERA44526
ERA44560
St, 1.5 mm,
RAL 7021,
air gap all round
8 mm, IP 20
lifting eye for
raised top cover,
application and
in accordance
with DIN 582
ertp0055
KTA44844
01108052
01105055
St, 1.5 mm,
for fan tray,
fully wired,
RAL 7021,
with mains cable
90 ... 264 VAC,
15 W, 162 m3/h,
8 W, 90 m3/h,
all 6 openings
230 VAC
height 38 mm,
height 25 mm,
input SCHUKO/
closed with PE
protective grille, protective grille,
UTE plug,
(SCHUKO/UTE
blank plugs,
plastic, black,
plastic, black,
outlet IEC 60320
plug/IEC 60320
terminal clamp
flammability
flammability
C13 socket;
C13 socket),
with connecting
UL 94 V-0
UL 94 V-0
external NTC
adjustment range
cable, 2 m, IECsensor 1.5 m
0 ... 60°C
60320 C14 plug
Cabinet dimensions
Width
Depth
1 piece
PU 4 pieces
1 piece
1 piece
1 piece
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
assembled
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-811
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
20713-243
20713-048
20118-750
60715-005
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
22117-812
22117-811
22117-812
22117-811
22117-812
22117-811
22117-812
20150-011
20150-011
20150-011
20150-011
22117-813
22117-811
22117-812
22117-813
22117-812
22117-814
22117-811
22117-812
22117-822
22117-821
22117-822
22117-821
22117-822
22117-821
22117-822
22117-823
22117-821
20150-011
20150-011
20150-011
22117-813
22117-812
22117-814
22117-821
22117-822
22117-823
22117-824
22117-825
22117-821
22117-822
22117-823
20150-011
22117-811
22117-824
22117-825
22117-821
22117-812
22117-813
20150-011
22117-824
22117-823
20713-243
20713-048
20118-750
60715-005
22117-814
20150-011
22117-825
20713-243
20713-048
20118-750
60715-005
Part number in bold face type: ready for despatch within 2 working days
1.307
eurorack Universal
Order Information
Base plate
Plain
00108051
St, 1.5 mm,
RAL 7021,
two parts,
mounting on
frame
With ventilation
ERA44532
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021
Filter mat
ERTP0057
base/plinth,
Al die-cast,
covers, St,
2.5 mm,
RAL 7021,
front and rear
with ventilation
openings
ERTP0057
Mobile base/plinth
Adjustable feet
Base/plinth
era44553
base/plinth,
with ventilation
St, PA, black,
load-carrying
capacity 100 kg
per foot
Jacking foot
era45323
ERA44532
Al die-cast,
RAL 7021,
300 kg,
with rubber mat,
4 castors, PA
for mobile base,
mounted below
front,
adjustment from
above
Cabinet dimensions
Width
Depth
PU 2 pieces
1 piece
1 piece
PU 3 pieces
PU 4 pieces
1 piece
PU 2 pieces
No. U
Height
mm
mm
mm
enclosed loose
assembled
assembled
enclosed loose
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-826
22117-830
22117-864
60114-514
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
21101-201
22117-869
20117-503
22117-826
22117-830
22117-864
60114-514
22117-827
22117-826
22117-831
22117-830
22117-865
22117-864
60114-515
60114-514
21101-201
22117-869
20117-503
21101-201
22117-869
20117-503
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-828
22117-826
22117-832
22117-830
22117-866
22117-864
60114-514
21101-201
21101-201
22117-869
20117-503
22117-827
22117-831
22117-865
60114-515
21101-201
22117-869
20117-503
22117-828
22117-827
22117-832
22117-833
22117-866
22117-867
21101-201
60114-517
22117-829
22117-834
22117-868
60114-518
21101-201
22117-826
22117-827
22117-830
22117-831
22117-864
22117-865
60114-514
60114-515
21101-201
21101-201
22117-869
22117-869
20117-503
20117-503
22117-828
22117-832
22117-866
21101-201
22117-827
22117-829
22117-833
22117-834
22117-867
22117-868
60114-517
60114-518
21101-201
22117-827
22117-830
22117-864
60114-514
21101-201
22117-869
20117-503
22117-829
22117-827
22117-831
22117-832
22117-865
22117-866
60114-515
22117-869
20117-503
21101-201
21101-201
22117-829
22117-834
22117-868
60114-518
21101-201
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.308
eurorack Universal
Order Information
RAL 7021
Depth member
AlZn
for 600 mm width
SZA45958
St, 1.5 mm, for depth-adjustable
fitting:
cabinet depth 600 mm:
please order depth members,
cabinet depth 800 mm: please order
reduced-width depth members
Width
ertp0044
St, 1.5 mm, AIZn St, 2.5 mm, zincplated, RAL 7021,
19" plane at least
110 mm from
front edge of
cabinet;
please order
panel/slide
mounts (2 pairs)
separately
RAL 7021
AlZn
AlZn
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
23117-017
22117-352
22117-389
22117-390
23117-018
22117-353
23117-019
22117-354
22117-835
22117-355
No. U
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
ERTP0045
Depth
Cabinet dimensions
Height
Reduced width
depth member
for 800 mm width
22117-389
22117-390
22117-389
22117-390
22117-389
22117-390
22117-391
22117-836
22117-356
22117-389
22117-390
22117-391
22117-836
22117-356
22117-837
22117-357
22117-390
22117-391
22117-837
22117-357
22117-839
22117-840
22117-389
22117-839
22117-840
22117-389
22117-838
22117-358
22117-390
22117-391
22117-838
22117-358
22117-840
1.309
eurorack Universal
Order Information
Cable panel
Width 150 mm
Cable panel
Width 250 mm
00108061
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
Width
RAL 7035
RAL 7021
RAL 7035
RAL 7021
PU 2 pieces
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
23117-026
23117-020
23117-029
23117-023
23117-026
23117-020
23117-029
23117-023
23117-027
23117-021
23117-030
23117-024
23117-027
23117-021
23117-030
23117-024
23117-028
23117-022
23117-031
23117-025
23117-028
23117-022
23117-031
23117-025
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
1.310
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
PU 2 pieces
No. U
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
St, 1 mm,
RAL 7035,
with cut-outs for
cable ties or
Velcro
Depth
Cabinet dimensions
Height
St, 1 mm,
RAL 7021,
with cut-outs for
cable ties or
Velcro
00108061
eurorack Universal
19" slide rails
Order Information
Dimensions
standard
assembly
Slide rail
Short slide rail
W
xf
c
D
25 kg
00205066
00108056
xf = distance from St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair, panel/
front
slide mounts (2 pairs), please order
c = pitch of
reduced widthdepth members
19" plane
separately
D = cabinet depth
see page
W = cabinet width
1.309
41003081
St, 1.5 mm, finish
40 kg/pair,
depth-adjustable
(c: 675-850 mm);
please order
panel/slide
mounts (2 pairs)
separately
see page
1.309
sc96xxxx
static load-carrying capacity 15 kg/
pair
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
SCHROFF.PENTAIR.CO.UK
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
110
110
60
60
60
110
110
60
60
60
110
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
380
580
480
680
780
380
580
480
680
780
580
PU 2 pieces
PU 10 pieces
PU 2 pieces
PU 2 pieces
PU 10 pieces
enclosed loose
enclosed loose
enclosed loose
enclosed loose
enclosed loose
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-094
21127-197
20118-592
20118-593
22127-095
22127-094
21127-198
21127-197
28127-001
20118-592
20118-592
20118-593
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-096
21127-199
28127-001
20118-592
20118-593
22127-094
22127-095
21127-197
21127-198
28127-001
20118-592
20118-592
20118-593
20118-593
22127-096
21127-199
28127-001
20118-592
20118-593
22127-094
25127-575
21127-197
20118-592
20118-592
20118-593
20118-593
22127-094
21127-197
20118-592
20118-593
22127-095
22127-096
21127-198
21127-197
28127-001
28127-001
20118-592
20118-592
20118-593
20118-593
22127-094
20118-593
21127-197
21127-197
20118-592
25127-575
22127-094
20118-592
20118-592
20118-593
20118-593
22127-095
21127-198
28127-001
20118-592
20118-593
22127-096
22127-094
21127-197
21127-197
28127-001
20118-592
20118-592
20118-593
20118-593
1.311
eurorack Universal
Fixed 19" shelves
Order Information
Full depth
Depth member
Reduced width
Recessed by c - for 600 mm width depth member
for 800 mm width
100 mm
W
xf
c
D
Dimensions
standard
assembly
00205066
00105050
00105051
xf = distance from
with perforation, static load-carrying
front
capacity 75 kg, incl. GND/earthing;
c = pitch of 19"
panel/slide mounts (2 pairs),
plane
please order depth members or
D = cabinet depth
reduced width depth members
W = cabinet width
separately
see page
1.309
ERTP0045
ertp0044
19" plane at least
110 mm from
front edge of
cabi-net; please
order panel/slide
mounts (2 pairs)
separately
see page
1.309
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.312
xf
mm
60
60
60
60
60
60
60
60
60
60
60
60
110
110
60
60
60
110
110
60
60
60
110
c
mm
480
680
480
680
480
680
480
680
780
480
680
780
380
580
480
680
780
380
580
480
680
780
580
SCHROFF PRODUCT CATALOG E 11/2017
1 piece
1 piece
PU 2 pieces
PU 2 pieces
assembled
assembled
assembled
assembled
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-842
22117-845
22117-389
22117-843
22117-842
22117-671
22117-845
22117-390
22117-389
22117-843
22117-671
22117-390
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-844
22117-843
22117-391
22117-842
22117-843
22117-845
22117-671
22117-389
22117-390
22117-844
22117-843
22117-391
22117-842
22117-871
22117-839
22117-840
22117-842
22117-845
22117-389
22117-843
22117-844
22117-671
22117-843
22117-390
22117-391
22117-842
22117-839
22117-871
22117-842
22117-845
22117-389
22117-843
22117-671
22117-390
22117-844
22117-871
22117-843
22117-391
22117-840
22117-840
eurorack Universal
Order Information
Full depth
Shortened by
100 mm
T-bar lock
GND/earthing
c
D
Dimensions
standard
assembly
xf
W
00205066
00105069
00105070
St, 1.5 mm, static load-carrying
xf = distance from
front
c = pitch of 19"
earthing separately
plane
D = cabinet depth
W = cabinet width
01004125
to lock the
telescopic shelf
05904052
for telescopic
shelf
Cabinet dimensions
Width
Depth
No. U
Height
mm
mm
mm
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
c
mm
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
450 - 550
650 - 750
1 piece
1 piece
1 piece
PU 1 kit
assembled
assembled
assembled
assembled
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
21130-353
21130-352
23130-092
21120-189
21130-355
21130-353
21130-354
21130-352
23130-092
23130-092
21120-189
21120-189
21130-355
21130-354
23130-092
21120-189
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
21130-353
21130-355
21130-352
21130-354
23130-092
23130-092
21120-189
21120-189
450 - 550
650 - 750
21130-353
21130-352
23130-092
21120-189
21130-355
21130-354
23130-092
21120-189
450 - 550
450 - 550
21130-353
21130-352
23130-092
21120-189
21130-355
21130-354
23130-092
21120-189
Part number in normal type: ready for despatch within 10 working days
1.313
eurorack Universal
Fixed shelves on universalcabinet uprights
Order Information
Fixed shelf
Full depth
Shortened by
100 mm
00106053
00106054
St 1.5 mm,
St 1.5 mm,
RAL 7021, load- RAL 7021, loadcarrying
carrying
capacity 75 kg,
capacity 75 kg,
incl. GND/
incl. GND/
earthing,
earthing
depth member
required,
please order
separately
Depth member
ERTP0045
St, 1.5 mm, AIZn
Cabinet dimensions
Width
Depth
1 piece
1 piece
No. U
Height
mm
mm
mm
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
22117-846
22117-851
22117-389
22117-847
22117-846
22117-852
22117-851
22117-390
22117-389
22117-847
22117-852
22117-390
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
22117-848
22117-847
22117-391
22117-846
22117-847
22117-851
22117-852
22117-389
22117-390
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
1.314
PU 2 pieces
22117-848
22117-847
22117-391
22117-849
22117-850
22117-853
22117-854
22117-389
22117-390
22117-846
22117-851
22117-389
22117-847
22117-848
22117-852
22117-847
22117-390
22117-391
22117-849
22117-853
22117-389
22117-850
22117-846
22117-854
22117-851
22117-390
22117-389
22117-847
22117-852
22117-390
22117-848
22117-850
22117-847
22117-854
22117-391
22117-390
eurorack Universal
Telescopic shelves on universal cabinet uprights
Order Information
Telescopic shelf, Universal eurorack
Full depth
Shortened by
100 mm
Telescopic slides
T-bar lock
GND/earthing
General
components
Mechanics
00105072
00105073
ERA46351
01004125
to lock the
telescopic shelf
aza43284
St, 1.5 mm,
RAL 7021,
please order
telescopic slides
and T-bar lock
separately
St, 1.5 mm,
RAL 7021,
please order
telescopic slides
and T-bar lock
separately
St, zinc-plated
for telescopic
shelf
1 piece
1 piece
PU 2 pieces
1 piece
PU 1 kit
assembled
assembled
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
21101-132
21101-178
Electrics
Cabinet dimensions
Height
Width
Depth
No. U
mm
mm
mm
assembled
assembled
assembled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
998
998
1220
1220
1398
1398
1620
1620
1620
1798
1798
1798
1798
1798
2020
2020
2020
2020
2020
2198
2198
2198
2198
600
600
600
600
600
600
600
600
600
600
600
600
800
800
600
600
600
800
800
600
600
600
800
600
800
600
800
600
800
600
800
900
600
800
900
600
800
600
800
900
600
800
600
800
900
800
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
22117-855
22117-856
22117-860
22117-861
22114-340
22114-342
22117-855
22117-860
22114-340
22117-856
22117-855
22117-861
22117-860
22114-342
22114-340
22117-856
22117-861
22114-342
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
25
29
29
34
34
34
38
38
38
38
38
43
43
43
43
43
47
47
47
47
from page
4.0
22117-858
22117-862
22114-340
22117-859
22117-863
22114-342
22117-855
22117-856
22117-860
22117-861
22114-340
22114-342
22117-858
22117-859
22117-862
22117-863
22114-340
22114-342
22117-855
22117-860
22114-340
22117-856
22117-861
22114-342
22117-859
22117-863
22114-342
21101-132
21101-178
21101-132
21101-178
from page
3.29
Power
distribution
from page
3.50
Climate control
from page
4.0
1.315
OutdoorMain Catalogue
Cabinets – Outdoor
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
41602001
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
41603009
The dual wall concept provides a
natural airflow between the outer
and inner wall, substantially
reducing the requirement for
additional heat removal.
41603010
Optimal protection from vandalism
thanks to a fixing accessible only
from within. Easily exchangeable
exterior cladding components.
41603005
The gasketing material can be
selected to suit the requirements
(IP protection, EMC shielding) and
may be exchanged subsequently.
Power supply
units . . . . . . . . . . 9
Standard / Certifications
Backplanes . . . 10
쮿 External dimensions in accordance with IEC 619691/2, IEC 6091721
쮿 Internal dimensions in accordance with ETS 300119, part 2
쮿 Type of protection IP 55 in accordance with IEC 60529
쮿 Protective GND/earthing connections in accordance with DIN EN 50178 / VDE 0160
Connectors, front
panel component
system . . . . . . . 11
쮿 Vibration in accordance with IEC 619693 class 2
Appendix . . . . . 12
1.316
SCHROFF PRODUCT CATALOG E 05/2016
Cabinets – Outdoor
Overview . . . . . . 1.316
O utdoorMain Catalogue
Outdoor cabinet for the most challenging operating conditions
쮿 High stability up to earthquake resistance
쮿 Weight-saving aluminium construction
쮿 Assembly possibilities with 19", ETSI or other accessories
쮿 Tested thermal concepts available
쮿 IP 55 and security against vandalism
COMLINE: single wall
Weight-saving aluminium construction. Single wall cabinet
ready for wall, pole or ground installation. Optimal for diverse
applications in industry, transportation and communication.
Versions
COMLINE
ECL - single
access . . . . . . . . . . 1.328
FTTX - single
and dual
access . . . . . . . . . 1.329
쮿 ECL - single access (front door)
쮿 FTTX - single access (front door) and dual access
(front and rear door)
41612054
Unibody
Cost-effective inner case with removable outer cladding.
This version has advantages especially for small cabinets.
If accessed through the front door, it meets the installation
requirements.
Outdoor Unibody
Unibody . . . . . . . . .
Unibody VENT . . . .
Unibody HEX . . . . .
Wall mounting kit
1.322
1.323
1.324
1.325
Versions
쮿 With natural convection
쮿 With fan
쮿 With heat exchanger
41603054
Modular
Aluminium profile frame with removable, double-walled
cladding.
This version has advantages especially for large cabinets and if
access from all sides is needed.
Outdoor Modular
Modular VENT . . . 1.326
Modular HEX . . . . . 1.327
Versions
Accessories
쮿 With fan
Metric panel/slide
mounts . . . . . . . . . . 1.328
19" panel/slide
mounts . . . . . . . . . 1.329
41603051
ServicePLUS from page 1.330
e. g. individual configurations also with air
conditioners
e. g. custom solutions (electrical, thermal,
backup power supplies, special sizes)
ServicePLUS . . . 1.330
www.schroff.biz/ServicePLUS
30407004
1.317
Cabinets – Outdoor - COMLINE
Outdoor COMLINE ECL
Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Single wall, lightweight aluminium cabinet
쮿 Heat dissipation through natural convection
쮿 IP 55
쮿 2 versions
– With plinth
– Without plinth
Delivery comprises
41612001
Drawing shows version with with plinth
Item
1
2
Qty
1
1
3
4
1
1
5
6
2
1
Description
Body, single wall, Al, 2.5 mm, RAL 7035
Front door, Al, 2.5 mm, RAL 7035, 3-point locking,
lever handle with DIN profile half cylinder,
door opening angle 135°, door retainer at 110°,
door hinged on left hand side;
electrical door switch
Solar shield top cover, Al, 2 mm, RAL 7035
Plinth, Al, 3 mm, height 120 mm (only for version with
plinth)
19"/23" panel/slide mounts, St, galvanised, 2.5 mm
GND/earthing kit, assembled
Order Information
Height H
Height H
Width W
Depth D
U
mm
mm
mm
12
600
600
500
18
900
600
500
18
900
700
500
25
1200
700
600
Height dimensions without plinth (120 mm)
41612052
45
W + 51
D + 24
Part no.
Without
plinth
Part no.
12349-001
12349-009
12349-002
12349-003
12349-010
12349-011
12349-004
12349-012
Note
쮿 19"/23" panel/slide mount kit see page 1.319
64
Drawing shows version with plinth
With plinth
465
D - 37
H
451
Z
120
Z
W
D
Z-Z
Door opening height = H - 75 mm;
door opening width = W - 75 mm
1.318
41612050
19"/23" panel/slide mount kit for
COMLINE ECL
Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
쮿 For fitting to depth member (25 mm grid)
쮿 For recessed installation of 19"/23" components
쮿 Slide rails can be fitted
쮿 Load-carrying capacity 400 kg
Delivery comprises
Item
1
2
Qty
2
1
Description
19"/23" panel/slide mount, St, galvanised, 2.5 mm
Assembly kit
Order Information
For cabinet height
U
mm
12
600
18
900
18
900
25
1200
For cabinet width
mm
600
600
700
700
Part no.
22349-024
22349-025
22349-026
22349-027
41612057
1.319
Outdoor COMLINE FTTX
쮿 Insulated cabinet
쮿 IP 55
쮿 2 versions with plinth
– Single access (front door)
– Dual access (front and rear door)
Delivery comprises
Item
1
Qty
1
2
1/2
3
4
5
6
1
2
1
1
41612003
Description
Body, Al, 2.5 mm, RAL 7035, single wall side panels,
insulation thickness 12 mm, non inflammable; 3 cable
entry boots are mounted in base for various sizes of
cables, 2 removeable lifting brackets
Door, Al, 2.5 mm, RAL 7035, 3-point locking,
lever handle with DIN profile half cylinder (1242E),
door retainer at 110°, door hinged on left hand side;
Plinth, Al, 3 mm, height 140 mm
19"/23" panel/slide mounts, galvanised St, 2.5 mm
Document pocket, thermoplastic (part no. ADP2)
Order Information
Height H
41612053
Single access
567
451
41612054
Dual access
D
28
Width W
Depth D
U
mm
mm
mm
12
600
800
500
25
1200
800
600
Dimensions without plinth (140 mm)
Dual access
Part no.
Single
access
Part no.
12349-007
12349-005
12349-008
12349-006
Note
H
H
쮿 19"/23" panel/slide mount kit see page 1.321
쮿 Cable entry see page 1.321
쮿 Spool for fibre optic cables see page 1.321
Z
140
140
Z
D
28
Height H
W
Z-Z
451
567
Dual access
Height of door opening = H - 270 mm;
width of door opening = W - 100 mm
1.320
41612055
Single access
41612056
COMLINE FTTX
Delivery comprises
Item
1
2
Qty
2
1
Description
Assembly kit
Order Information
For cabinet height
U
12
25
For cabinet height
mm
600
1200
Usable height
U
10
23
Part no.
22349-032
22349-033
41612058
Cable entry
쮿 For cable ducting through the base of the cabinet
Delivery comprises
Item
1
Qty
3
Description
Cable entry, for cable diameter 30 ... 72 mm, EPDM,
RAL 7035
Order Information
Cable entry
22349-034
41612059
Delivery comprises
Item
1
2
Qty
4
4
Description
Spool for fibre optic cables, molded from black plastic
Screws, M5
Order Information
Description
Part no.
TOPTKSPL
FTTXMoldedRadiusModules
1.321
Cabinets – Outdoor - Unibody
Unibody
Outdoor - UnibodyMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 One-piece inner case with removable outer cladding
쮿 Heat dissipation through natural convection, max. 6 W/K
쮿 IP 55
쮿 Double-walled, Al
Delivery comprises (assembled)
41603054
T1
B1
Qty
1
2
1
4
5
6
1
1
1
7
8
9
1
4
1
Description
Internal case, Al
Side panel, Al, RAL 7035
Front door, Al, RAL 7035, 3-point locking, lever handle
with DIN profile half cylinder, door opening angle 135°,
door retainer at 120°, door hinged on left hand side
Rear panel, Al, RAL 7035
Top cover, Al, RAL 7035
Plinth with removable covers (front and sides),
height 100 mm
Base plate with cable connection plate, Al
Depth member for 19" metric panel/slide mounts
Order Information
Height
Height
Width
Depth
U
mm
mm
mm
16
930
700
500
700
500
Wall mounting kit 1 kit
qW = specific heat dissipation capacity
b1
qW
W/K
5
6
Part no.
11249-003
11249-005
21249-017
쮿 Please order wall mounting material separately, see page
1.325
쮿 Please order panel/slide mounts separately, see page 1.328
h1
h
H
t1
Item
1
2
3
25
t2
B
T
41603058
H*)
mm
930
1100
Text
H
U
16
B
mm
700
700
T
mm
500
500
h
mm
838
1013
b1
mm
536
536
t1
mm
400
400
t2
mm
350
350
h1
mm
736
911
B1
mm
730
730
T1
mm
530
530
t2 = max. 19" assembly dimension
*) height without base/plinth (base/plinth height 100 mm)
ServicePLUS see page 1.330
1.322
Unibody VENT
Outdoor - Uni body
쮿 Forced heat dissipation via fan assembled in side panel, max.
35 W/K
쮿 IP 55
쮿 Double-walled, Al
41603055
T1
B1
Item
1
2
3
Qty
1
2
1
4
5
6
1
1
1
7
8
9
10
1
4
1
1
11
12
1
1
Description
Internal case, Al
height 100 mm
Depth member for 19" metrical panel/slide mounts
Axial fan (side mounted), airflow volume: 360 m3/h,
230 VAC, 50 Hz, noise level less than 53 dB(A), max.
pressure: 176 Pa, power consumption: 35 W, mains
supply to screw terminal block
Filter mat
Thermostat, complete with cable
Order Information
b1
h
H
t1
h1
25
t2
Height
Height
Width
Depth
U
mm
mm
mm
16
930
700
500
700
500
25
1330
700
500
Replacement fan 230 VAC 1 piece
Air filter for fan 10 pieces
qW
W/K
35
35
35
Part no.
11249-007
11249-009
11249-012
21149-185
21149-184
21249-017
1.325
B
T
41605050
H *)
mm
930
1100
1330
TextText
H
U
16
B
mm
700
700
700
T
mm
500
500
500
h
mm
838
1013
1238
b1
mm
536
536
536
t1
mm
400
400
400
t2
mm
350
350
350
h1
mm
736
911
1136
B1
mm
730
730
730
T1
mm
530
530
530
Calculation example at 35 W/K:
(Values as per ETS 300019-1-4 Class 4.1)
Internal temperature 50° C - external temperature 40° C = 10 K.
Up to 350 W of dissipation loss can thus be installed.
(35 W/K x 10 K).
1.323
Unibody HEX
Outdoor - Unibody
쮿 Forced heat dissipation via integrated heat exchanger in the
door, max. 70 W/K
쮿 IP 55
쮿 Double-walled, Al
41603056
T1
B1
Item
1
2
3
Qty
1
2
1
4
5
6
1
1
1
7
8
9
10
1
4
1
1
Description
Internal case, Al
height 100 mm
Heat exchanger 48 VDC (electronically regulated with
alarm outputs), incl. temperature sensor, heater and DC
connecting cable with IEC plug, 3 m
Order Information
b1
25
t2
B
T
41605051
H *)
mm
1330
TextText
H
U
25
B
mm
700
T
mm
600
h
mm
1238
b1
mm
536
t1
mm
500
t2
mm
400
h1
mm
1136
Calculation example at 70 W/K:
Up to 700 W of dissipation loss can thus be installed.
(70 W/K x 10 K).
B1
mm
730
T1
mm
630
Part no.
11249-016
21249-017
Technical data heat exchanger
h1
h
H
t1
Height
Height
Width
Depth
qW
U
mm
mm
mm
W/K
25
1330
700
600
70
qW = specific heat dissipation capacity, average values
Dimensions (height x width x depth)
Heater
(input voltage/capacity)
Specific heat dissipation capacity
Fan
Input voltage
Airflow volume external circuit
Airflow volume internal circuit
Temperature range
Type of protection
Weight
WT 70
1010 x 465 x 150 mm
230 VAC/1000 W
70 W/K
2 pieces
48 VDC
510 m3/h
600 m3/h
-40 ... 50 °C
IP 55
21 kg
1.325
쮿 Equipment cable for heater in heat exchanger (230VAC,
IEC connector), see page 3.38
1.324
Wall mounting for Unibody
쮿 Suitable for all Unibody standard dimensions
50
5
쮿 Cut-out for cable ducting from the top
Delivery comprises
Qty
2
1
Description
Bracket
Assembly kit
H
Item
1
2
Order Information
Description
Wall mounting kit
W
Part no.
21249-017
D
41603064
1.325
Cabinets – Outdoor - Modular
Modular VENT
Outdoor - Modular
쮿 Aluminium profile frame with removable, double-walled
cladding
쮿 Forced heat dissipation via fans assembled in the side panel,
max. 35 W/K
쮿 IP 55
쮿 Double-walled, Al
쮿 Single door (for 700 mm width), double door (for 1300 mm
width)
41603051
Item
1
2
Qty
1
2
3
1
4
1
5
6
7
8
9
10
1
1
1
4
1
1
11
12
1
1
Description
Frame, screwed, Al
Double skin side panel, Al, inner untreated,
outer external RAL 7035
Front door at 700 mm width, double door at 1300 mm
width, Al, RAL 7035, 3-point locking, lever handle with
DIN half profile cylinder, door opening angle 135°, door
Double skin rear panel, Al, inner untreated, outer
external RAL 7035
External top, Al, RAL 7035
Base/plinth with removable cover, height 100 mm
Earthing kit, assembled
Axial fan (assembled laterally),
airflow volume: 360 m3/H, 230 VAC 50 Hz,
noise level less than 53 dB(A), max. pressure 176 Pa,
power consumption 35 W,
mains/line connector with screw terminal block
Filter mat
Order Information
41603059
H *)
mm
1330
1510
1510
TextText
H
U
25
29
29
w
mm
1300
700
1300
T
mm
600
600
600
h
mm
1233
1408
1408
b1
mm
1136
536
1136
t1
mm
500
500
500
t2
mm
450
450
450
h1
mm
1136
1311
1311
B1
mm
1330
730
1330
T1
mm
630
630
630
Height
Height
Width
Depth
U
mm
mm
mm
25
1330
1300
600
29
1510
700
600
29
1510
1300
600
qW
W/K
35
35
35
Part no.
10149-305
10149-306
10149-308
21149-185
21149-184
(35 W/K x 10 K).
1.326
Modular HEX
Outdoor - Modular
cladding
door, max. 70 W/K
쮿 IP 55
쮿 Double-walled, Al
width)
41603052
Item
1
2
Qty
1
2
3
1
4
1
5
6
7
8
9
10
1
1
1
4
1
1
Description
Frame, screwed, Al
Double skin side panel, Al, inner untreated, outer
external RAL 7035
external RAL 7035
External top cover, Al, RAL 7035
Heat exchanger 48 VDC (electronic control with alarm
outputs), incl. temperature sensor and heater,
DC connecting cable with IEC connector, 3 m
Order Information
Height
Height
Width
Depth
qW
U
mm
mm
mm
W/K
25
1330
1300
600
70
29
1510
700
700
70
29
1510
1300
600
70
Part no.
10149-313
10149-315
10149-316
Technical dataheat exchanger
41605052
H *)
mm
1330
1510
1510
TextText
H
U
25
29
29
B
mm
1300
700
1300
T
mm
600
700
600
h
mm
1233
1408
1408
b1
mm
1136
536
1136
t1
mm
500
600
500
t2
mm
350
450
350
h1
mm
1136
1311
1311
(70 W/K x 10 K)
B1
mm
1330
730
1330
T1
mm
630
730
630
Heater (input voltage/capacity)
Fans
Input voltage
Airflow volume external loop
Airflow volume inner loop
Temperature range
Type of protection
Weight
WT 70
1010 x 465 x 150 mm
230 VAC/1000 W
70 W/K
2 pieces
48 VDC
510 m3/h
600 m3/h
-40 ... 50 °C
IP 55
21 kg
Note
1.327
Cabinets – Outdoor - Accessories
Metric panel/slide mounts
쮿 For fixing metric chassis, subracks, distributor and filler panels
to IEC 60917-2-1
쮿 Modular version fixes direct to the frame or to the depth
members; Unibody fixes to the depth members
Delivery comprises
Item
1
Qty
2
2
1
Description
Metric panel/slide mounts, bolt-on dimension
515 mm, St, 2 mm, AlZn
Assembly kit, incl. GND/earthing
Order Information
For cabinet height
mm
Partial-height
mounting
Partial-height
mounting
930
1100
1330
1510
41001548
Usable height
SU
Length
mm
AlZn
Part no.
16
400
24127-547
21
525
24127-682
28
35
44
51
700
875
1100
1275
24127-686
24127-689
24127-694
24127-697
Note
쮿 Depth members and slide rails for partial-height mounting
available on request
1.328
쮿 For mounting of 19" chassis, subracks,
distribution and filler panels in accordance with
IEC 60297-3-100 (DIN 41 494, part 1)
쮿 Assembled directly on the frame or on the depth member for
the Modular, for Unibody assembly on depth member
Delivery comprises
Item
1
2
Qty
2
1
Description
19" panel/slide mount, St, 2 mm, RAL 7035/Al-Zn
Order Information
PLA45434
For cabinet height
mm
Partial-height mounting
930
1100
1330
1510
Usable height
U
9
12
16
29
Length
mm
400
533
711
889
1111
1289
Part no.
24127-370
24127-484
24127-485
24127-487
24127-489
24127-491
Note
쮿 Depth member for partial-height mounting available on request
1.329
Cabinets – Outdoor ServicePLUS
configuration
Simple. Fast. For the product you want.
Components can be varied and combined freely
쮿 Enquiry form for outdoor cabinets
– Various interior and exterior dimensions
– Degree of protection
– Determining of the cooling capacity
– Cooling concept
쮿 Online configuration: www.schroff.co.uk/configuration
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Heat simulation on FloTHERM® model and calculations by
experts
쮿 Special sizes, customised solutions
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, white papers, CAD drawings, test reports, user
reports
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product lifecycle
쮿 Delivery to point of use, installation service, exchange service,
Outdoor ServiceP LUS
1.330
Outdoor ServicePLUSMain C atalogue
Mobile telephony base station
쮿 Mobile telephony base station with energy supply in one cabinet
쮿 BTS connection via special cable routing in top element
쮿 Based on the "modular" concept, the cabinet can be upgraded
with various pre-defined "kits"
쮿 Cooling either via fresh-air inlet (air filtered fan) or, in other
cabinet variants, using an air conditioner
41608003
Mobile telephony power supply
쮿 Cabinet for power supply to mobile telephony base stations
쮿 Based on the "modular" cabinet concept with a special top panel design for cabling; can accept both 19" and 21" wide devices
쮿 Heat exchanger in the front door
쮿 AC/DC power distribution installed laterally beside 19" plane
41608004
Wimax
쮿 Base station for Wimax applications
쮿 "Unibody" concept with special base for easy assembly at
installation site
쮿 Fresh air inlet via air inlet filter
쮿 Additional components such as cabinet heater and door contact
switch factory preinstalled
41608005
1.331
Main Catalogue
VDSL fixed network
쮿 VDSL distribution cabinet
쮿 Case based on a "modular" frame and double-walled outer
cladding
쮿 Cooling via controlled fans in case top panel. Airflow is only
between the double walls; the device area remains sealed
쮿 Separate stainless steel base with space for batteries and cable
ducting
41608010
Battery cabinet
쮿 Cabinet to power mobile telephony stations
쮿 Based on the "modular" cabinet concept with the option of
accommodating both 19" and 21" wide devices
쮿 Direct cooling via fresh air introduced into the interior via an air
filtered fan
쮿 Fitting and connection of additional components e.g. smoke
detector, door contact switch etc
41608006
Triple Play
쮿 Distribution cabinet for fibre-optic cables (FTTN/FTTH)
쮿 Ex works with power supply, backup batteries and safety
devices
쮿 Design outdoor "Modular"
쮿 Combined cooling with air conditioner and additional internal
air circulation
41608007
1.332
Meteorology
Main Catalogue
쮿 Compact, robust case for recording measured data in
thunderstorms and strong winds
쮿 Outdoor "Unibody" for mast mounting
쮿 Climate control based on an additional fan in the gap between
the dual walls
쮿 A controllable heater can be added for use in freezing
conditions
41603016
Voltage monitoring (railway)
Main Catalogue
쮿 Voltage monitoring on overhead cables
쮿 Construction based on "unibody" concept, for wall or mast
mounting
쮿 Energy-saving, noiseless cooling by convection between the
double walls
41608008
Measurement technology on the rails
Main Catalogue
쮿 Safety measurement device to detect the wheel temperature
of passing trains
쮿 Positioned very close to the tracks, thus requires robust
vibration-proof design to IEC 61963
쮿 Construction based on "modular" concept; the devices are
mounted on a swing frame
쮿 Heat dissipation via side-mounted air conditioner
41608009
1.333
ZMain Catalogue
Cabinets – Z
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
05601001 05601002
Front panels,
ETA43445
Top mounted cabling frame
Power supply
Backplanes . . . 10
eta43459 05605051
Optionally either rear panel or
cable supports can be used
eta43449
Frame cover with integrated
socket
Standards/certifications
Modifications
쮿 External and internal dimensions in accordance
with:
IEC 48D and ETS 300119
쮿 Special colours
쮿 Type of protection:
IP 20 in accordance with: IEC 60529
쮿 Customised solutions
쮿 Special sizes
with:
DIN EN 50178 / PU 0160
Connectors, front
panel component
1.346
Cabinets – Z
Overview . . . . . . 1.346
ZMain Catalogue
Metric frame for public and private
telecommunication networks
쮿 In accordance with standards IEC 48 D and ETS 300 119
쮿 Static load-carrying capacity up to 200 kg
쮿 Top mounted cabling frame
쮿 Back-to-back row layout is possible
Cabinet from stock
쮿 With perforated front door
쮿 Can be completed on the rear either with rear panel or
cable supports
etsirack
Frames . . . . . . . . . . 1.348
Mounting kit for
back-to-back row
layout . . . . . . . . . . . 1.349
Rear panel . . . . . . 1.349
Cable support . . . . 1.349
Top mounted
cabling frame . . . . 1.350
Mounting socket
etsirack . . . . . . . . . 1.350
Metric cable
support . . . . . . . . . . 1.351
19" adaptors . . . . . 1.351
05605001
ServicePLUS from page 1.352
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (special sizes)
ServicePLUS . . . 1.352
Application
examples. . . . . . . . 1.353
30407004
1.347
Cabinets – Z
etsirack frame
ZMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
쮿 Welded rack with metric grid hole spacing to ETS 300119-3
쮿 Static load-carrying capacity 200 kg
쮿 Mounting height 81 SU (1 SU = 25 mm)
Item
1
2
Qty
1
1
3
4
5
4
1
1
Description
Frame, St, 2 mm, RAL 7035
Front door with perforation, St, 1.5 mm, RAL 7035 with
safety lock incl. 2 keys, GND/earthing
Adjustable feet, St, zinc-plated, polyamide black
Base/plinth, St, 2 mm, RAL 7035
Blanking plug, polyamide, white, for socket cut-out
Order Information
Height Width
Depth Qty
mm
mm
mm
2200
600
300
PU = 1 piece on a palette
2200
600
300
PU = 2 pieces on a palette
Side-by-side mounting kit etsirack PU 1 kit
Mounting socket etsirack SCHUKO, 230 V/16 A, white,
1 piece
Part no.
10125-010
10125-011
21190-793
21101-360
05605001
05605050
eta43442
ServicePLUS see page 1.352
1.348
Cabinets – Z
Mounting kit etsirack for back-to-back row layout
Z
쮿 For back-to-back mounting of two frames
Delivery comprises
Item
1
Qty
4
Description
GND/earthing cage nut, washer, 1 screw M6 x 12
Order Information
Description
Part no.
21190-793
ETA43447
Rear panel
Z
Delivery comprises
Item
1
2
3
Qty
1
1
1
Description
Rear panel, St, 1 mm, RAL 7035
GND/earthing kit (Cu wire 4 mm2 green/yellow)
Assembly kit
Order Information
Description
Rear panel
eta43459
Part no.
20125-021
eta43444
Cable support
Z
쮿 Cable supports may be used in the etsirack in place of
a rear panel
Delivery comprises
Item
1
2
Qty
4
1
Description
Cable support, St, 2 mm, RAL 7035
Assembly kit
Order Information
Description
Cable support
Part no.
20125-006
05605051
1.349
Cabinets – Z
Z
쮿 Extension length of the sliding bars on right and left:
max. 536 mm
Delivery comprises (Kit)
Pos.
1
2
3
4
5
Menge
1
1
1
2
1
Beschreibung
Sliding bar on the right, St, 3 mm, zinc-plated
Sliding bar on the left, St, 3 mm, zinc-plated
Mounting rail, St, 3 mm, zinc-plated
Cable retention rail, St, 3 mm, RAL 7035
Assembly kit
Order Information
Description
Part no.
20125-005
ETA43445
Z
쮿 SCHUKO, 230 VAC, 16 A
Delivery comprises
Item
1
2
Qty
1
1
Description
Mounting socket, SCHUKO, white
Assembly kit
Order Information
Description
Part no.
21101-360
ETA43449
1.350
Cabinets – Z
Metric equipment shelf
Z
쮿 For the installation in metric frames
(assembly dimension 515 mm)
쮿 Load carrying capacity 10 kg
쮿 Mounting height 49 mm
Delivery comprises
Item
1
2
3
Qty
1
1
1
Description
Equipment shelf, St, 1.5 mm, RAL 7035
GND/earthing material
Assembly kit
Order Information
Width
mm
497
05601501
Depth
mm
222
Part no.
20118-686
19" adaptor
Z
쮿 The 19" adaptor allows 19" components to be installed in the
metric etsirack
쮿 Equal clearances are obtained above and below between the
19" adaptor and the metric height increments
Delivery comprises
Item
1
2
Qty
2
1
Description
19"/metric adapter, Al extrusion, clear chromated
Assembly kit
Order Information
bza44292
Height
U
3
6
45
Clearance
mm
above/below 8.8 mm each
above/below 4.6 mm each
none
Part no.
20838-084
20838-086
20125-018
Note
쮿 Assembly dimensions and clearances see Internet
1.351
Cabinets – ZServicePLUS
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Special colours
solution
쮿 Complete construction,cabling, function testing
쮿 Special sizes, custom solutions
lifecycle
쮿 Free delivery to point of use
ServicePLUSZ
1.352
ServicePLUS: Solution - Project examples
French Telecom
쮿 Special top mounted cabling frame
05605003
German Telecom
쮿 Front door drawn out for more space
쮿 Rear panel included
쮿 Lever handle instead of safety lock
05605003
1.353
1 9" lab racksMain Catalogue
Cabinets – 19" lab racks
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01305003
Front panels,
Cable ducting on the front and rear side
lra45330 vnt007
Large selection of equipment shelves
Application/function
Power supply
Backplanes . . . 10
19" lab racks are freely accessible from all sides. Subracks, 19" cases
and 19" shelves can be mounted. Two angled steel uprights are
screw-fixed on the base part (mobile base/plinth and base plate
respectively). The 19" cut-outs of the steel uprights are recessed so far
that a flat surface for front panels is created. At the top, the two profiles
are connected by a cover plate which gives the rack additional stability.
01505050
쮿 Internal and external dimensions
in accordance with:
IEC 60297-3-100
The base/plinth of the mobile 19" lab rack has two fixed rear castors and
two locking castors at the front. The 100 mm roller diameter ensures
both good mobility and high stability.
A base plate from sheet steel forms the plinth for the stationary 19" lab
rack.
Connectors, front
panel component
1.354
Overview . . . . . . 1.354
19 " lab racksMain C atalogue
19" lab rack
쮿 Mobile or stationary
쮿 Various shelves
쮿 Accessories for cable ducting
19" lab racks
19" lab rack,
mobile . . . . . . . . . . . 1.356
19" lab rack,
stationary . . . . . . . . 1.357
Panel mounts . . . . 1.358
Cable support rail 1.358
C-profiles . . . . . . . . 1.359
Cable eyes for
C-profile . . . . . . . . 1.359
19" equipment
shelves . . . . . . . . . . 1.361
Slide rails . . . . . . . . 1.361
01305001
Mobile
Stationary
쮿 36 U
쮿 24 and 39 U
쮿 Load-carrying capacity up to max.
200 kg
150 kg
ServicePLUS from page 1.361
01305002
ServicePLUS . . . 1.361
e.g. modification (special colours)
30407004
1.355
19" lab rack, mobile
19" lab racksMain CataloguePart number in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
쮿 Stationary load-carrying capacity 200 kg at a defined centre of
gravity in the centre of the lab rack
쮿 Recommended max. chassis depth 400 mm
Item
1
2
3
4
Qty
1
1
2
2
Description
19" frame, St, 2 mm, RAL 7035, with EIA cut-outs
Mobile base/plinth, Al, die-cast, RAL 7035
Castor, plastic (PA), with rubber insert
Locking castor, plastic (PA), with rubber insert
Order Information
Description
19" lab rack, mobile, useable height 36 U
19" assembly kit (50 x screws, 50 x washers, 50 x nuts)
19" assembly kit
(100 x screws, 100 x washers, 100 x nuts)
Part no.
10117-498
21101-809
21101-810
01305001
2 HE
1856
200
492
36 HE
582,3
465
451
1
2
165
3
157
100
60
95
4
710
Side view
600
front
dta44089
ServicePLUS see page 1.361
1.356
19" lab rack, stationary
19" lab racks
쮿 Modular design with base/plinth and cover plate,
please order uprights according to desired height separately
쮿 Stationary load-carrying capacity 150 kg, at a defined centre of
Delivery comprises (kit)
Item.
1
2
4
Qty
1
1
1
Description
Trim at top, St, 1.5 mm, RAL 7035
Assembly kit
Order Information
Description
Item
Base and trim
1+2+4
Uprights (item 3) with EIA perforation, 24 U, RAL 7035,
PU 2 pieces
Uprights (item 3) with EIA perforation, 39 U, RAL 7035,
PU 2 pieces
Adjustable feet load-carrying capacity 100 kg per foot,
PU 4 pieces
Castors load-carrying capacity 150 kg per kit, castor
diameter 52 mm, PU 4 pieces (2 locking, 2 non-locking)
19" assembly kit
Part no.
20118-743
20118-741
20118-742
21190-571
20118-462
21101-809
21101-810
Technical data
01305002
582,3
46
200
492
h
h
mm
1067
1733
H
mm
1164
1831
Note
2
H
Usable height
U
24
39
쮿 Please order uprights separately
465 (19”)
451
3
1
46
1
60
50
45
165,5
46
600
710
Side view
front
VNT004
1.357
Panel mounts for stationary 19" lab rack
19" lab racks
쮿 Required for fitting of cable retention rails or slide rails on
Delivery comprises
Item
1
Qty
2
Description
Panel mount without assembly kit, St, 1.5 mm, RAL 7035
Order Information
Description
Panel mount
Panel mount
Assembly kit PU 1 kit
Height
U
24
39
Part no.
20118-744
20118-745
21101-175
Note
VNT011
쮿 Please order assembly kit separately
Cable support rail
19" lab racks
쮿 For cable ducting and cable strain relief
쮿 Designed for mobile 19" lab rack;
with panel mounts also for stationary 19" lab rack
Item
1
2
3
Qty
3
2
1
Description
C-profile, St, 1.5 mm, zinc-plated
Corner piece, St, 2 mm, zinc-plated
Assembly kit
Order Information
Description
Cable support rail
Part no.
20118-460
Note
쮿 Panel mounts are necessary for assembly on stationary
19" lab racks, please order them separately
LRA45330
1.358
C-profile for stationary 19" lab rack
19" lab racks
쮿 For assembly to the vertical uprights on the right and left hand
side of the 19" plane; especially suited for cable eyes
Delivery comprises
Item
1
Qty
2
Description
Order Information
Height
U
24
39
Length
mm
1050
1650
Part no.
20118-461
22114-461
21101-175
Note
쮿 Not suitable on mobile 19" lab racks
VNT007
Cable eyes for C-profile
19" lab racks
Delivery comprises
Item
1
D=
W
95
=9
5
75
D=
W
=4
D=
Qty
4
45
Description
Cable eye, round steel, 6 mm, zinc-plated,
with integrated anti-rotation protection
Order Information
W
Description
=1
00507051
00507052
W
mm
Cable eye for C-profile
120
40
95
Assembly kit for 4 cable eyes, PU 1 kit
D
mm
45
75
95
Part no.
20118-339
20118-554
20118-340
21101-596
Note
1.359
19" equipment shelf, 1 U
19" lab racks
쮿 Static load-carrying capacity 5 kg
쮿 Mounting height 1 U
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
Depth
mm
mm
447
390
19" assembly kit (screw, washer, nut)
for one equipment shelf
AlZn
Part no.
RAL 7035
Part no.
20118-781
20118-783
21190-095
00508012
19" equipment shelf, 2 U
19" lab racks
쮿 Static load-carrying capacity 10 kg
쮿 Mounting height 2 U
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
Depth
mm
mm
447
238
19" assembly kit (screw, washer, nut) for one equipment
shelf
RAL 7035
Part no.
20118-785
21190-095
00508002
19" equipment shelf, depth-adjustable, 2 U
19" lab racks
쮿 Static load-carrying capacity 15 kg
쮿 Depth-adjustable in 25 mm increments
(front protrusion min. 26 mm)
Item
1
2
Qty
1
2
Description
Mounting bracket with assembly kit, St, 1.5 mm
Order Information
00508009
1.360
Width
Depth
mm
mm
430
250
430
300
430
400
shelf
RAL 7035
Part no.
20118-790
20118-791
21190-095
19" equipment shelf with front protrusion, 2 U
19" lab racks
쮿 Static load-carrying capacity 25 kg
쮿 Forward protrusion min. 168 mm
Item
1
2
3
Qty
1
2
1
Description
Mounting bracket, strengthened, St, 2/2.5 mm, RAL 7035
Assembly kit incl. GND/earthing kit
Order Information
Width
mm
430
Depth
mm
400
Part no.
20119-257
SZA46423
Slide rail, 40 kg
19" lab racks
쮿 For assembly on mobile 19" lab racks; with panel mounts also
on stationary 19" lab racks
쮿 Static load-carrying capacity 40 kg per pair
Delivery comprises
Item
1
Qty
2 / 10
Description
Slide rail, St, 2 mm, zinc-plated
Order Information
DTA44090
Description
Slide rail, 40 kg
Slide rail, 40 kg
Qty/PU
2
10
Part no.
20119-080
20119-106
Note
쮿 Panel mounts are necessary for assembly on stationary 19"
labrack, please order separately, see page 1.358
modification
colours for off-the-shelf products
쮿 Special colours
solution
lifecycle
19" lab rack Servi cePLUS
1.361
Hoffman P ROLINEMain Catalogue
Cabinets – Hoffman PROLINE
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
41003002
Front panels,
Mounting pitch
41096005
41096010
Assembly in accordance with ETSI/
19" standard
PC cabinet
41097003
Main C ataloguePart number in bold face type: ready for despatch within 2 worki ng daysPart number in norm al type: ready for despatch within 10 working days
Power supply
Industrial standards
쮿 Exterior and interior dimensions in accordance with
IEC 60297, part 1 and 2 IEC 60917-2-1
쮿 Gasketed assembled enclosure:
UL 508A listed; Type 12; File Number E61997
cUL listed per CSA C22.2 No 94; Type 12;
File Number E61997,
NEMA/EEMAC Type 12, CSA File Number 42186:
Type 12,
VDE IP 55, IEC 60529, IP 55
쮿 Interior dimensions in accordance with ETS 300119,
Part 2
Backplanes . . . 10
with DIN EN 50178 / PU 0160
Connectors, front
panel component
쮿 EMC assembled enclosure:
UL 508A listed; Type 1; File Number E61997,
cUL listed per CSA C22.2 No 94; Type 1;
File Number E61997,
NEMA/EEMAC Type 1,
IEC 60529,
IP 30
1.362
Overview . . . . . . 1.362
Hoffman PROLINEMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days
Hoffman PROLINE industrial cabinets
쮿
쮿
쮿
쮿
Overview
Cabinets . . . . . . . 1.0
Electrical cabinet and PC cabinet with high stability and ingress protection to IP
Welded steel frame with 25 mm increments
Interior mounting in accordance with 19" or ETSI standard possible
Static load-carrying capacity 600 kg
VARISTAR . . . . . . 1.2
VARISTAR
Electronics . . . . . . 1.10
VARISTAR EMC . . 1.54
VARISTAR
Seismic . . . . . . . . . 1.84
VARISTAR MIL . . . 1.120
VARISTAR
Datacom and
Networking
Technology . . . . . . 1.124
VARISTAR Aisle
Containments . . . . 1.202
VARISTAR Air/
water heat
exchanger . . . . . . . 1.224
eurorack . . . . . . . 1.270
Electronics cabinet
41098005
Electrical cabinet
41003001
PC cabinet
41097004
NOVASTAR . . . . . 1.240
Ordering
Hoffman PROLINE industrial cabinets can be supplied in any of the following ways to best suit your needs:
쮿 Assembled enclosures
– Hoffman PROLINE enclosures are available preconfigured for computer system (PROLINE PC)
applications, HMI (PROLINE SY) applications, industrial applications and double-door disconnect
(PROLINE DD) applications. These options allow you to select a complete system that includes the frame,
side panels, top, base, doors and interior mounting accessories by simply ordering one part number.
쮿 Customer-specific assemblies
– Assemble-to-order (A-T-O) programme. Configure your industrial cabinet.
Customers can configure an individual cabinet ex stock from a set range of individual components,
at no extra cost
쮿 Individual components
– If your process is better-suited to receiving individual Hoffman PROLINE parts and completing the
assembly yourself, we can accommodate you. Frames and individual components are
available for shipment from our warehouse or distributor stock.
Outdoor . . . . . . . . 1.316
Hoffman Open
Frame Racks . . . 1.334
etsirack . . . . . . . . 1.346
ServicePLUS
쮿 A-T-O (Assemble-to-order): Configuration and
assembly of Hoffman PROLINE cabinets (IP 55)
쮿 Detailed documentation and order tables on
the Internet under www.schroff.biz/proline
쮿 Further information see Hoffman industrial catalogue
www.schroff.biz/industrial
Lab racks . . . . . . . 1.354
Cabinet
Accessories . . . . 3.0
1.363
Cabinets – On Board Rack
On-board rack
On Board RackMAIN CATALOG Part number in bold face type: ready for s hippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days
쮿 For mobile railway applications
쮿 Suitable for ongoing vibrations, shock, high temperatures,
and high humidity
쮿 Height 3, 6, and 9 U, width 36 and 84 HP, depth 341.8 mm
쮿 Suitable for 1, 2, or 3 U SNCF subracks
(NF F61-005, CF 60-002)
쮿 Rear side is equipped for standard connectors; crossbar can
be custom-coded for the SNCF coding pins
쮿 Crossbar with integrated cable channel
쮿 Several racks can be stacked or fitted in rows
쮿 Produced using a welding process, certified to EN 15085 (CL2)
Delivery includes
Item Qty.
1
1
2
1
Description
Welded rack, St, stainless steel, 2 mm,
rear middle crossbar
User manual
Order Information
07117057
1.366
SCHROFF PRODUCT CATALOG E 08/2017
Height
Width
Depth
U
HP
mm
3
36
341.8
3
84
341.8
6
36
341.8
6
84
341.8
9
36
341.8
9
84
341.8
Accessories
Joining and stacking kit for on-board rack PU, 1 set
(4 screws, 8 nuts, 4 washers)
Mounting kit for on-board rack PU, 1 set (8 x screw M6x30,
8 x clip cage nut)
Mounting kit for on-board rack PU, 1 set (50 x screw
M6 x 30, 50 x clip cage nut)
Mounting kit for on-board rack PU, 1 set (100 x screw
M6 x 30, 100 x clip cage nut)
Part no.
10170-015
10170-014
10170-013
10170-012
10170-017
10170-016
20170-042
21120-205
21120-206
21120-207
Cabinets – On-board rack
On-board rackMAIN CATALO GPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Assembly kit, suitable for joining or stacking on-board racks
Order Information
Description
for on-board rack
Description
PU, 1 set (4 screws, 8 nuts, 4
washers)
Part no.
20170-042
06717050
06717051
06717052
MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days
쮿 For mounting electronic components on the on-board rack
쮿 To ensure standards-compliant grounding at at least one
mounting point, use a grounding cage nut and a Nomel washer
Delivery includes
Item
1
2
00517001
Description
Panhead screw, M6 x 30, St, zinc-plated
Clip cage nut, M6, St, zinc-plated
Order Information
Description
SCHROFF.PENTAIR.DE
Qty/PU
piece
8
50
100
Part no.
21120-205
21120-206
21120-207
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
1.367
PROLINE
e
u
g
tlo
C
in
a
M
Wall mounted cases – Overview
Content
For robust industrial environments up to IP 66
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
W
Distributor and network case for 10" and
19" applications
With hinged side panels
Steel, IP 20
Climate control . 4
Electronics
Subracks/
Front panels,
Power supply
Backplanes . . . 10
Connectors, front
panel component
36108001 (41102004, 41105001, 41107004, 41107005, 41505001, 40505001, 40505002)
0.0
SCHROFF Main catalogue
www.schroff.biz E 05/2016
PROLINE
Main C atalogue
Overview . . . . . . 0.0
For data and network systems
systems
LAN wall mounted enclosure
epcase . . . . . . . . . 2.24
Ideal for fibre optics applications or as copper small
distributor, retrofittable with side-by-side modules
Steel, IP 20
LAN wall
mounted . . . . . . 2.36
Cabinet
Accessories . . . 3.0
36108002 (01505002, 01505008, 41801001, 41801017)
0.1
epcaseW Main Catalogue
Wall mounted cases – W
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01505008
Subracks/
Front panels,
Hinged side panels for easy access
01506002
01505003
Optimum space utilisation due to an additional vertical
19" plane; fans retrofittable
Standards
쮿 Type of protection IP 20
IEC 60529
Power supply
Backplanes . . . 10
Connectors, front
panel component
Simple design and assembly: mounting, wiring, cladding
01504051
2.24
Overview . . . . . 2.24
epcaseWMain C atalogue
Low-cost wall mounted case
쮿 Hinged side panels for easy access
쮿 Completely pre-assembled
쮿 Optimum space utilisation through depth-adjustable 19" slide mounts and
an additional vertical 19" plane
epcase 19"
epcase 19"
쮿 19" assembly from 9 ... 20 U
19" wall mounted
case . . . . . . . . . . . . 2.26
Fan . . . . . . . . . . . . 2.27
Protective grille . . 2.27
Air filter . . . . . . . . 2.28
Lever handle . . . . . 2.28
19" equipment
shelf . . . . . . . . . . . . 2.29
Modem shelf . . . . 2.30
Vertical 19" plane 2.30
Cable eye . . . . . . . . 2.31
Cable support rail 2.31
Short slide rail . . . 2.31
01506001
epcase 10"
쮿 10" assembly from 4 ... 12 U
epcase 10"
10" wall mounted
case . . . . . . . . . . . . 2.32
Air filter . . . . . . . . . 2.33
Equipment
support . . . . . . . . . 2.33
10" front panel . . . 2.34
10" distribution
field . . . . . . . . . . . . . 2.34
10" socket strip
1 U, SCHUKO . . . . 2.35
01505006
ServicePLUS . . . 2.46
30407004
ServicePLUS from page 2.46
e.g. special colours, special sizes
e.g. air conditioning
e.g. fittings, conversions, cut-outs
2.25
19" wall mounted case
epc aseWMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days
쮿 Multi functional 19" wall case with hinged side panels
쮿 Cable entry possible from above or below;
the cable entry opening can be sealed with two brush strips
each, resp. can be used to assemble fan
쮿 Cable support rail is included and is adjustable in 25 mm
increments
쮿 19" panel/slide mounts are depth-adjustable in 25 mm
increments
Item
1
2
Qty
1
1
3
4
5
6
7
2
1
2
2
1
01506002
Description
Basic case, C form, St, 2 mm, RAL 7021
Glazed door with key/lock (key no. 2233),
door handle cut-out S2100, frame, St, 1.5 mm, RAL 7035,
Sekurit glass 4 mm
Side panel, St, 1.5 mm, RAL 7035
Cable support rail, St, RAL 7035
19" slide mounts, St, 2 mm, finish AlZn
Brush strip (to cover cable entry opening)
Assembly kit for wall mounting
Order Information
Height Height Width
H
W
Depth
D
Weight Loadcarrying
capacity
mm kg
kg
18
18
60
18
18
24
35
85
25
30
18
28
35
85
30
30
85
32
25
85
34
30
85
38
25
E
U
mm
mm
mm
9
487
600
300
9
487
600
400
12
612
600
400
12
612
600
500
16
812
600
400
16
812
600
500
16
812
600
600
600
500
600
600
GND/earthing, PU 1 kit
Brush strip, 1 piece
Feet, plastic, black, PU 4 pieces
Cable shell for cable bundle 30 ... 34 mm,
PU 10 pieces
Cable tie 92 mm x 2.5 mm, PU 25 pieces
19" assembly kit (screw, washer, nut) (32 x M6
screws x 16, 32 x plastic washers, 32 x cage nuts)
Part no.
10236-151
10236-152
10236-156
10236-157
10236-160
10236-161
10236-162
10236-165
10236-166
21236-097
21236-094
21236-089
20114-728
20118-351
21190-435
Note
쮿 Lever handle for single point locking with DIN profile half
cylinder is retrofittable, see page 2.28
eca46458
ServicePLUS see page 2.46
2.26
ELECTRONICS PROTECTION
Fan with covering grille, 230 VAC
epcaseW
쮿 For assembly in cable ducting openings (top/bottom)
쮿 Assembly of fan by clipping in protective grilles
쮿 Connect up to 3 fans via separate connecting cable
Delivery comprises
Item
1
2
Qty
1
2
Description
230 VAC fan, dimensions 38 x 119 x 119 mm
Protective grille, plastic, black
Order Information
01503057
Description
Part no.
21236-092
Connecting cable for 1 ... 3 fans IEC-320 male
21236-099
connector, 1 piece
Thermostat with mains/line connector, 230 VAC, SCHUKO/
20118-750
UTE connector, IEC-320 female connector, 1 piece
Technical data
Frequency
Voltage
Air volume, unrestricted
Noise pressure level
Max. static pressure
Max. ambient temperature
Power consumption
Connecting cable and earthing for 1 ... 3 fans
01505057
50 Hz
230 VAC
162 m3/h
37 dB(A)
73 Pa
+70 °C
15 W
60 Hz
230 VAC
192 m3/h
41 dB(A)
88 Pa
+70 °C
14 W
Note
쮿 Please order connecting cable separately
Protective grille
쮿 For passive cooling
쮿 To cover the opening
Delivery comprises
Item
1
2
Qty
1
2
Description
Protective grille with pins, plastic, black
Protective grille with cut-outs, plastic, black
Order Information
Description
Protective grille
Part no.
21236-127
01505058
2.27
Air filter for 19" wall mounted case
epc aseW
쮿 Filtering of the inlet air at the case bottom
쮿 Assembly beneath the case, easy filter replacement
쮿 Filter class G3
Delivery comprises
Item
1
2
3
Qty
2
3
1
Description
Support bracket, St, 1 mm, RAL 7021
Filter mat with round steel frame, filter class G3
Assembly kit
Order Information
Description
Air filter for case depth 300/400 mm
Air filter for case depth 500/600 mm
Replacement filter mat for case depth 300/400 mm,
PU 3 pieces
Replacement filter mat for case depth 500/600 mm,
PU 3 pieces
Part no.
21236-103
21236-104
21236-125
21236-123
01505059
epc aseW
쮿 For installation instead of key lock insert
쮿 To open press push-button
쮿 DIN profile half cylinder retrofittable
Delivery comprises
Item
1
2
Qty
1
1
Description
Assembly kit
Order Information
Description
Part no.
23130-067
DIN profile half cylinder, common locking for lever handle
25127-995
(1 key fits all locks) incl. 2 keys
01005016
Note
쮿 Other locks such as ASSA, KABA or RONIS available on request
2.28
epcaseW
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
Depth
mm
mm
447
390
19" assembly kit (screw, washer, nut) (4 x M6
screws x 16, 4 x plastic washers, 4 x cage nuts)
RAL 7035
Part no.
20118-783
21190-095
00508006
epcaseW
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
Depth
mm
mm
447
238
RAL 7035
Part no.
20118-785
21190-095
00508002
epcaseW
Item
1
2
Qty
1
2
Description
Order Information
00508009
Width
Depth
mm
mm
430
250
430
300
RAL 7035
Part no.
20118-790
21190-095
2.29
Modem shelf
epc aseW
쮿 For fixing modems and other devices
쮿 Assembly onto the cable support rail or direct onto the case
쮿 Static load-carrying capacity 3 kg
Delivery comprises
Item
1
2
Qty
1
1
Description
Modem shelf, St, 1.5 mm, RAL 7035
Assembly kit
Order Information
Width
mm
200
Depth
mm
150
Part no.
21236-122
ECA46468 ECA46469
Vertical 19" plane
epc aseW
쮿 For lateral, vertical assembly of 19" components
쮿 Useable for case heights from 12 U
Item
1
2
3
Qty
1
1
1
Description
Vertical 19" plane, St, 2 mm, RAL 7035
Assembly kit
Order Information
Height
U
3
6
Assembly example with 19" socket strip
d
mm
167
300
For case depth D
mm
300 ... 600
400 ... 600
Part no.
21236-120
21236-121
01505062
ECA46477
2.30
Cable eye
epcaseW
쮿 For cable fixing/ducting laterally on the panel slide mounts
6
Delivery comprises
Item
1
2
36
4
Qty
4
1
Description
Cable eye, St, 4 mm, zinc-plated
Assembly kit
Order Information
34,5
Description
Cable eye
56
Part no.
21236-102
01505051
Cable support rail
epcaseW
쮿 For strain relief or cable ducting on rear
쮿 Height-adjustable in 25 mm increments
Delivery comprises
Item
1
2
Qty
1
1
Description
Cable support rail, St, 1.5 mm, RAL 7035
Assembly kit
Order Information
Description
Cable support rail
Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces
Velcro strip Polyethylen/Polyamide, black, length 300 mm,
PU 10 pieces
Part no.
21236-090
20114-728
20118-351
20118-624
01505052
Note
쮿 A cable support rail is already supplied with the
Short slide rail
epcaseW
쮿 Support for heavy 19" chassis
쮿 To attach on 19" slide mounts
쮿 Static load-carrying capacity max. 15 kg per pair
Delivery comprises
Item
1
2
Qty
2 / 10
1
Description
Short slide rail, St, 1.5 mm, finish AlZn
Assembly kit
Order Information
Description
Short slide rail
Short slide rail
Qty/PU
2
10
Part no.
23130-094
23130-095
sc96xxxx
Part number in bold face type: ready for despatch within 2 working days
2.31
10" wall mounted case
epc aseW
쮿 Multi-functional 10" wall case with hinged side panels
the cable entry opening can be sealed with a brush strip
쮿 10" slide mounts are depth-adjustable in 25 mm increments
01505007
Item
1
2
Qty
1
1
3
4
5
6
2
2
2
1
Description
Basic case, C-form, St, 2 mm, RAL 7021
Glazed door with key lock (key no. 2233),
Sekurit glass, 4 mm
Side panel, St, 1,5 mm, RAL 7035
10" panel/slide mounts, St, 1.5 mm, finish AlZn
Brush strips
Order Information
Height
Height H Width W
Depth D
Weight
U
mm
mm
mm
kg
4
262
345
280
5
8
462
345
280
10
12
612
345
280
23
Part no.
10238-151
10238-152
10238-153
21236-097
20118-351
21190-435
21236-089
Note
쮿 Lever handle and DIN profile half cylinder cannot be retrofitted
eca46478
2.32
Air filter for 10" wall mounted case
epcaseW
쮿 Filter class G3
Delivery comprises
Item
1
2
3
Qty
2
3
1
Description
Assembly kit
Order Information
Description
Replacement filter mat for 10" wall mounted case
PU 3 pieces
Part no.
21236-095
21236-126
01506050
Equipment shelf for 10" wall mounted case
epcaseW
쮿 Width 10" (254 mm)
Delivery comprises
Item
1
2
Qty
1
1
Description
Assembly kit
Order Information
Width
mm
220
Depth
mm
150
Part no.
20118-716
00508006
2.33
10" distribution field
epc aseW
쮿 Distribution field with 8 x RJ 45 ports, category 5
쮿 Height 1 U
Delivery comprises
Item
1
2
Qty
1
8
Description
Distribution field, St, 1.5 mm, RAL 7035
RJ 45 Port
Order Information
Description
10" distribution field with 8 x RJ 45 ports
Assembly kit PU = 8 × screw, washer, nut
Part no.
60118-378
21100-435
01504002
10" front panels
epc aseW
쮿 Height 1 U
Delivery comprises
Item
1
Qty
1
Description
Front panel, St, 1.5 mm, RAL 7035
Order Information
Item Description
10" blank front panel, St, 1.5 mm,
1a
RAL 7035
10" front panel, 8 ports SC, St, 1.5 mm,
1b
RAL 7035
10" front panel, 8 ports ST, St, 1.5 mm,
1c
RAL 7035
10" front panel with 3 plastic cable eyes,
1d
Qty/PU
Part no.
1
20118-717
1
20118-713
1
20118-714
1
20118-715
21100-435
01503053
2.34
10" socket strip, 1 U
epcaseW
쮿 Socket strip with four socket inserts
쮿 Bracket for mounting on 10" upright is included
Delivery comprises
Item
1
Qty
1
2
2
Description
Socket strip 10", 1 U, 4 socket inserts,
2 m connecting cable with SCHUKO/UTE connector
Mounting bracket for 10" assembly
Order Information
Description
10" socket strip, 4 SCHUKO socket inserts
Socket strip 10", 4 UTE socket inserts
Part no.
60110-201
60110-220
21100-435
00704001
2.35
LAN wall mounted Main Catalogue
Wall mounted cases – LAN wall mounted
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
41801004
Subracks/
Front panels,
Door and side panels easily
removable
41804001
41801005
Vertical 19" plane, therefore low
case depth
41801006
Storage of excess cable length
Modularity due to basic case and side-by-side modules
Power supply
Backplanes . . . 10
Connectors, front
panel component
VTLW6672
2.36
Overview . . . . . . 2.36
Slim wall mounted cases
쮿 Ideal as fibre optic cable distributor, 4 U wall distributor or as combination of
fibre optic cable, copper and telephone distributor
쮿 Optimal ducting of fibre optic cables
쮿 Door and side panels easily removable
쮿 Upgradeable with side-by-side modules
Fibre optic small case
Small case
쮿 Prepared to accomodate up to four splicing cassettes
Small case . . . . . . 2.38
쮿 Low cabinet depth of 85 mm
Cable ducting for
fibre cable . . . . . . . 2.38
Insertion plate for
splicing cassettes 2.39
Splicing
cassette . . . . . . . . . 2.39
41801006
Wall distributor, modular
쮿 Modularity due to basic case and side-by-side modules
쮿 Combination of fibre optic cable, copper or
telecommunication applications possible
쮿 Low installation depth of 220 mm due to vertical 19" plane
Modular wall mounted
distributor
Basic case . . . . . . . 2.40
Side-by-side
module . . . . . . . . . . 2.41
Basic cable
ducting . . . . . . . . . . 2.41
Splicing cassette
holder . . . . . . . . . . . 2.42
Splicing
cassette . . . . . . . . 2.42
LSA+ bracket . . . . 2.43
Locking insert . . . 2.43
41801017
Wall distributor, 4 U, vertical
쮿 Corner door with lateral acrylic glass
쮿 Fan retrofittable
19" bracket . . . . . . 2.43
Wall mounted
4 U distributor
Wall mounted 4 U
distributor . . . . . . . 2.44
Cable ducting for
fibre cable . . . . . . . 2.45
41802002
30407004
2.37
LAN wall mounted Main CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
쮿 For distribution of fibre optic main cables or as office distributor
쮿 Space for max. 48 fibres
Item
1
Qty
1
2
3
4
5
2
1
1
1
Description
Case, St, 1.5 mm, RAL 7035, 2 cable ducting openings
each top and bottom (without cover)
Side panel, St, 1 mm, RAL 7035, hinged
Door, St, 1 mm, RAL 7035, with locking insert 2233-x
Quadruple splicing cassette holder
(distance from wall 6.5 mm)
Order Information
41801003
Height
Width
Depth
mm
mm
mm
300
300
85
Item 6 Brush strip for fibre optic small case,
self-adhesive, PU 2 pieces
Item 7 Cable ducting plate for fibre optic small case,
St, 1 mm, zinc-plated, PU 2 pieces
Part no.
60239-006
60239-030
60239-025
Note
쮿 To cover cable through-ducting openings please order either
brush strip or cable through-ducting plate separately
쮿 Push-on plate for splicing cassette, see page 2.39
쮿 Splicing cassettes, see page 2.39
vtlw6684
Cable ducting for fibre cable
쮿 For cable ducting with necessary bending radius
30
Order Information
Description
Cable ducting for fibre cable, plastic, black, PU 4 pieces
42
.5
Part no.
60239-020
.5
19
41804051
2.38
Insertion plate for splicing cassettes
Main Catalogue
쮿 The splicing cassette is assembled on the push-on plate and
subsequently inserted in the splicing cassette holder
Delivery comprises
Item
1
2
Qty
4
8
Description
Push-on plate, St, 1 mm, zinc-plated
Holding clip for splicing cassette
Order Information
41806050
Item
Description
Item 1a Push-on plate without cable ducting
Item 1b Push-on plate with cable ducting for cable ties
Part no.
60239-013
60239-014
1b
1a
VTLW6678
Splicing cassette
Main Catalogue
쮿 Accepts a maximum of 12 splices to the telecom standard
쮿 Fibre optic cable splicing cassettes to DIN 47662
Delivery comprises
Item
1
2
3
Qty
1
1
4
Description
Splicing cassette, plastic, cream white
Cover, plastic, cream white
Cable ties
Order Information
Splicing cassette
VTLW6679
Description
Splicing cassette
Item 1 Splice holder, PU 10 pieces
Item 2 Splice protection sleeve, length 60 mm,
PU 6 pieces
Part no.
60239-062
21101-122
21101-123
Note
쮿 Please order splice holder and splice protection sleeves
separately
Splice holder (1), splice protection sleeve (2)
SCHROFF.PENTAIR.CO.UK
vtlw6680
2.39
The modular case system is used as sub or floor level distributor,
for fibre optic applications as well as for distribution of copper or
telecommunication applications.
Text
The 220 mm deep basic cases can be extended with side-by-side
modules and accessories.
41801002
Basic case
Main Catalogue
쮿 To accomodate splicing cassette holders, LSA+ holder and/or
19" bracket
쮿 Room for max. 288 fibres and excess cable lengths of up to 1 m
Item
1
Qty
1
2
3
4
2
1
1
Description
Order Information
41801001
Height
Width
Depth
mm
mm
mm
600
425
220
GND/earthing kit for wall mounted distributor,
sufficient for one basic case and two side-by-side modules
Brush strip for wall mounted distributor self-adhesive,
PU 2 pieces
Cable ducting plate for wall mounted distributor
PU 2 pieces
Part no.
60239-001
60239-060
60239-031
60239-026
VTLW6682
2.40
Side-by-side module
Main Catalogue
쮿 For side-by-side mounting to basic case, selectively on the right
or left
쮿 To accommodate splicing cassette holders or LSA+ holder
Item
1
Qty
1
2
3
4
1
1
1
Description
Side-by-side module, St, 1.5 mm, RAL 7035, 2 cable
ducting openings top and bottom
Door post
Assembly kit
Order Information
Height
Width
Depth
mm
mm
mm
600
225
220
PU 2 pieces
Part no.
60239-004
60239-031
60239-026
VTLW6673
Basic case cable ducting
Main Catalogue
30
쮿 Assembly by inserting into rear panel of case, then given
a quarter turn
쮿 Usable in basic case and side-by-side module
Order Information
42
.5
D
41804050
Description
Basic cable ducting, plastic, black, depth D = 55 mm,
PU 4 pieces
Part no.
60239-021
Note
쮿 Cannot be used in fibre optic small case nor in
4 U wall mounted distributor
2.41
Splicing cassette holder
Main Catalogue
쮿 To accommodate 12 splicing cassettes that are also mounted
on push-on plates
쮿 Splicing cassette holder is mounted and secured on rear wall of
case
쮿 Screw-free fitting
Order Information
Description
Splicing cassette
12-fold, St, 1 mm, zinc-plated, 1 piece
holder
PU 4 pieces
PU 4 pieces
Part no.
60239-012
60239-013
60239-014
20118-351
VTLW6677
Note
쮿 Please order push-on plates separately
1b
1a
Push-on plates
VTLW6678
Splicing cassette
Main Catalogue
Delivery comprises
Item
1
2
3
Qty
1
1
4
Description
Cable ties
Order Information
Splicing cassette
VTLW6679
Description
Splicing cassette
PU 6 pieces
Part no.
60239-062
21101-122
21101-123
Note
separately
2.42
VTLW6679
Locking insert for basic case and
side-by-side module
Main Catalogue
쮿 For replacement of basic case or side-by-side module inserts
Item
1
2
41804054
Qty
1
2
Description
Locking insert
Key
Order Information
Description
Locking insert 2233-X
(included in basic case)
Qty/PU
1
Part no.
60239-051
19" bracket for basic case
Main Catalogue
쮿 For constructing a vertical 19" plane (4 U) in the basic case
쮿 Depth-adjustable in 20 mm increments
Order Information
Description
19" bracket for basic case, St, 1.5 mm, RAL 7035,
PU 2 pieces
Part no.
60239-035
Note
쮿 Not suitable in fibre optic small case and side-by-side module
VTLW6685
LSA+ bracket
Main Catalogue
쮿 For retention of LSA+ type connections
쮿 For assembly in basic case or side-by-side module
Item
1
2
3
4
Qty
2
2
1
1
Description
Rail holder, St, 1.5 mm, zinc-plated
Rail, stainless steel
GND/earthing kit
Assembly kit
Order Information
Description
LSA+ bracket
Part no.
60239-040
41801501
Part number in normal type: ready for despatch within 10 working days
2.43
Wall mounted distributor, 4 U, vertical
쮿 Flat 19" wall mounted case (220 mm deep) for universal cabling
systems
쮿 Mounting possibilities for distribution panels (copper and fibre
optic) or for active components (e.g. switches), up to a depth of
max. 300 mm
쮿 Prepared for fan assembly
쮿 Type of protection IP 20 (when cover plate is closed)
41802002
Item
1
Qty
1
2
1
3
1
4
3
5
6
7
1
2
1
8
1
Description
each at top and bottom (without cover)
Side panel, St, 1 mm, RAL 7035, with ventilation slots
(prepared for fan assembly)
Corner door, St, 1 mm, RAL 7035, 90° offset,
with acrylic glass and lateral lock 2233-x
Cover plate for cable ducting openings, supplied loose
(plain or with ventilation slots, depending on mounting
position)
Brush strip, black, supplied loose
19" bracket, St, 1.5 mm, RAL 7035 (4 U, vertical)
Earthing kit
Order Information
Height
Width
Depth
mm
mm
mm
600
425
220
230 VAC fan with covering grille, 1 piece
Thermostat mains connection 230 VAC, 1 piece
PU 2 pieces
2.44
Part no.
60240-006
20234-822
20118-719
60239-031
Main Catalogue
30
Order Information
Description
Description
Cable ducting for fibre cable Plastic, black, PU 4 pieces
42
.5
Part no.
60239-020
.5
19
41804051
2.45
Wall-mounted cases ServicePLUS
modification
쮿 Custom drillings, special colours, cut-outs for off-the-shelf
products from
– 10 pieces with epcase
– 25 pieces with CONCEPTLINE, INLINE, QLINE, A48,
wall mounted LAN enclosures
쮿 Further information: www.schroff.co.uk/modification
solution
쮿 Special sizes, custom solutions, printing from:
– 500 pieces with QLINE, A48
쮿 Integration: components, internal mounting, wiring
쮿 Further information: www.schroff.co.uk/solution
Wall-m ounted cases ServicePLUSMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatc h within 10 working days
ServicePLUS solution - project examples
Plastic case A48 or QLINE
쮿 Plain or glazed doors
쮿 Individual printing, cut-outs, with PG screw fitting or
with complete assembly
40508001
Steel case INLINE
쮿 Terminal case or installation case with support rails or
mounting plates with customised depth bolts
쮿 Cut-outs and drillings marked with specified printing; paintfree contact area for installed components
40708001
2.46
SCHROFF E 05/2016
CONCEPTLINE in special colour (RAL 3027)
쮿 Steel case with a high type of protection: IP 66
쮿 Mounting plate with hole grid to fix assemblies
쮿 Lever handle with optional DIN cylinder
41108003
CONCEPTLINE control module
쮿 Vehicle data processor in CONCEPTLINE case (IP 66)
쮿 Internal mounting on basis of europacPRO subrack with
individually machined front panels
41108002
CONCEPTLINE communication module
쮿 CONCEPTLINE case with heat exchanger (IP 55)
쮿 Internal mounting on basis of europacPRO subrack and
backplane for the digital GSM-R communication network
41108001
2.47
PROLINE
Main C atalogue
Cabinet Accessories – Overview
Content
Wall mounted
Mechanics
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
Front panels,
Telescopic slides
Power supply
Backplanes . . . 10
Electrics
Connectors, front
panel component
36108007 (00504002 00509005 00508006 00508008 00505032 00711023 00504006 01495004)
3.0
SCHROFF Further information: www.varistar.de E 05/2016
Overview . . . . . . 3.0
Mechanics
Monitors, keyboards
19" front panels
with cable eyes,
cable throughducting . . . . . . . . . 3.2
19" cable tray . . . . 3.9
Cable ductings . . . 3.10
19" equipment
shelves . . . . . . . . . . 3.11
19" drawers . . . . . 3.13
19" distribution
field . . . . . . . . . . . . . 3.14
19" mounting tray
for LSA+ . . . . . . . . . 3.15
19" module
support . . . . . . . . . . 3.16
Assembly kit . . . . . 3.17
Cable supports . 3.21
Cable channels . . 3.21
Telescopic
slides . . . . . . . . . . 3.22
Electrics
Cabinet lights . . . . 3.29
Door contact
switches . . . . . . . . 3.32
19" distributors . . 3.33
Small distribution
modules . . . . . . . . . 3.34
Supply modules . . 3.34
GND/earthing
rails . . . . . . . . . . . . . 3.37
Equipment cables 3.38
Bus bars . . . . . . . . . 3.39
Monitor, keyboard
Monitor,
keyboard . . . . . . . . 3.44
19" drawer with
keyboard . . . . . . . . 3.45
Socket strips with
connecting cable
SCHUKO . . . . . . . . . 3.52
UTE . . . . . . . . . . . . . 3.55
IEC . . . . . . . . . . . . . . 3.58
BS . . . . . . . . . . . . . . 3.61
US . . . . . . . . . . . . . . 3.62
Switzerland . . . . . 3.63
19" power
distributors,
3-phase . . . . . . . . . 3.65
Socket strips,
Wieland ® . . . . . . . 3.66
Socket strips
Power Control
socket strips
3.72
Multimeter . . . . . . 3.74
Telemonitored
socket strips . . . . . 3.75
Power
management
software . . . . . . . . 3.79
36108008 (00510003 00510006 00709018 00711008 00709001 00708032)
Mechanik
3.1
Cabinet Accessories – Mechanics
Front Panel Express
MechanicsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
We make your front panel.
You determine how long it takes us.
쮿 Simple: You configure your front panels direct online.
No registration, no program downloads.
The price is displayed immediately.
쮿 Fast: You specify your front panel in just a few minutes and we manufacture it from as little as in 2 days.
쮿 Flexible: You determine the quantity and manufacturing time and thus the cost.
쮿 Individual: We make the panels to your specification mechanical processing, painting and printing.
쮿 Practical: We make the job easier for you - if you wish we will
also fit the accessories.
FRONT PANEL
EXPRESS
30402151_e
19" front panels with holes for handles
쮿 19" front panels have additional holes for mounting of handles
Delivery comprises
Item
1
Qty
1
Description
19" front panel, AI
Order Information
00592006
Height
H
D
E
U
1
2
3
4
5
6
mm
43.6
88.1
132.5
177.0
221.4
265.9
mm
31.7
76.2
57.1
101.6
146.0
190.4
mm
25
55
88
120
180
180
Front panel,
4 mm, anodised
Part no.
Front panel, 3 mm,
pre-anodised,
cut edges plain
Part no.
40304-050
40304-051
30219-161
30219-162
40304-052
30219-163
40304-053
40304-054
30219-164
30219-165
40304-055
30219-166
Note
쮿 19" assembly kit, see page 3.17
쮿 Front panel processing to your instructions under
www.frontpanelexpress.eu
BZA42371
3.2
SCHROFF PRODUCT CATALOG E 05/2017
Front handle, one-piece, width 12.2 mm
1U
쮿 Static load-carrying capacity 30 kg/pair
쮿 Bolted from rear
Delivery comprises
Item
1
Qty
1
Description
Front handle, AI extrusion, anodised
Order Information
Height
BZA42316
2 U ... 6 U
A
E
clear
anodised
Part no.
U
mm
mm
1
41
25
10501-116
2
69
55
10501-004
3
102
88
10501-005
4
132
120
10501-006
5
194
180
10501-007
6
249
235
10501-008
Accessories
Panhead screw pozidrive
self-locking, M5 × 12, zinc-plated, PU 100 pieces
black
anodised
Part no.
10501-025
10501-026
10501-027
10501-028
10501-029
21100-788
Delivery is exclusively in Standard Pack Quantity (SPQ): Minimum
order quantity 10 front handles or a multiple thereof
Note
쮿 Please order panhead screws separately
BZA42327
Front handle, multi-part, width 12 mm
쮿 Static load-carrying capacity 10 kg/pair
쮿 In three parts, middle section in Al extrusion, end pieces in
glass fibre reinforced plastic
쮿 Bolts on from front
Item
1
2
Qty
1
2
Description
Front handle, AL extrusion, anodised
End piece, PA, black
Order Information
Height
A
E
U
mm
mm
3
102
88
4
134
120
5
194
180
6
249
235
Accessories
Part no.
10502-057
10502-059
10502-063
10502-065
21100-788
A3-227
Note
3.3
19" front panels
쮿 Al anodised, colours light grey (RAL 7035) or
black grey (RAL 7021)
Delivery comprises
Item
1
Qty
1
Description
19" front panel, AI, 3 mm/4 mm
00504002
sza42889
Order Information
Height
H
D
X1
X2
Mounting holes
U
1
2
3
4
5
6
7
8
9
10
mm
43.6
88.1
132.5
177.0
221.4
265.9
310.3
354.8
399.2
443.7
mm
31.7
76.2
57.1
101.6
146.0
190.4
234.9
279.4
323.8
368.3
mm
88.9
101.6
101.6
101.6
mm
57.1
76.2
120.6
165.1
pieces
4
4
4
4
4
4
8
8
8
8
3 mm thick,
RAL 7021
Part no.
3 mm thick,
RAL 7035
Part no.
3 mm, Al anodised,
cut edges plain
Part no.
4 mm,
Al anodised
Part no.
30118-948
30118-299
30219-098
40304-074
30118-949
30118-950
30118-301
30118-302
30219-101
30219-104
40304-075
40304-076
30118-951
30118-303
30219-107
40304-077
30118-952
30118-953
30118-304
30118-305
30219-110
30219-113
40304-078
40304-079
30118-954
30118-306
30219-137
40304-080
30118-955
30118-956
30118-307
30118-308
30219-138
30219-143
40304-081
40304-082
30118-957
30118-309
30219-144
40304-083
Delivery: supplied loose with cabinet or frame
Part no./35
Note
쮿 19" assembly kit see page 3.17
3.4
Clip-on 19" plastic front panels
쮿 Simple fitting by clipping onto the 19" plane
쮿 Attractive design
쮿 Two colors: light gray or black
쮿 6 U front panels can be snapped off in 1, 2 or 3 U increments
without tools
Delivery includes
Item
1
Qty
10
Description
Clip-on 19" plastic front panels, ABS, antistatic, UL 94 V-0
Order Information
00507003
Height
U
1
1
2
2
6
6
Height
mm
43.6
43.6
88.1
88.1
270.0
270.0
Description
black
light grey
black
light grey
black
light grey
Part No.
D19BPT1RU
87927991
D19BPT2RU
87927992
23130-560
23130-561
Part no./35
00507004
3.5
19" vented front panel
쮿 Al anodised, Al untreated, light grey (RAL 7035) or
Delivery comprises
Item
1
Qty
1
Description
19" vented front panel, AI, 2.5 mm
Note
00504005
00502509
Order Information
Height
U
1
2
3
H
mm
43.6
88.1
132.5
A
mm
31.7
76.2
57.1
B
mm
11.2
16.6
13.5
C
mm
16.9
50.7
101.4
RAL 7021
Part no.
RAL 7035
Part no.
Al anodised
Part no.
Al untreated
Part no.
30118-962
30118-963
30702-056
30702-057
30702-047
30702-048
30702-044
30702-045
30118-964
30702-058
30702-049
30702-046
Part no./35
19" vented front grille, 2 U
Item
1
2
3
Qty
1
1
1
Description
Front grille, plastic, black
Filter
Retention bracket, St, 1 mm, hot-dip aluminized
Order Information
Description
Accessories
Replacement filter for 19" vented front grille 2 U,
PU 3 pieces
Part no.
60715-049
60715-050
Part no./35
Note
02892009
3.6
19" front panel for cable eyes
Main Catalogue
쮿 19" front panel to accommodate cable eyes
(to mount the eyes, insert and rotate them 45°)
Delivery comprises
Item
1
Qty
1
Description
19" front panel, 1 U, St, 1.5 mm
Order Information
Height H
U
1
Height H
mm
43.6
RAL 7021
Part no.
RAL 7035
Part no.
20118-762
20118-761
Part no./35
00509001
Note
쮿 Please order cable eyes separately
Plastic cable eye
Main Catalogue
30
쮿 Simple to fit cable eyes: insert and rotate them 45°
Order Information
42
Plastic cable eyes mounted on
19" front panel
D
.5
00506020
41804050
Plastic cable eye
Depth D = 55 mm, with clip, PU 5 pieces
Depth D = 100 mm, with clip, PU 5 pieces
60118-458
60118-459
Part no.
Part no./35
44
Steel cable eye
Main Catalogue
44
Order Information
115
11,5
30
Steel cable eyes mounted on
19" front panel
00506019
00506050
Steel cable eye
Round steel 5 mm, width 44 mm, depth 115 mm,
PU 5 pieces
Part no.
60118-457
Part no./35
44
Double steel cable eye
Main Catalogue
44
Order Information
D
11,5
30
Rubber pad mounted on
double steel cable eyes
00509005
00509050
45°
Round steel 5 mm, width 44 mm, depth D = 80 mm,
PU 5 pieces
Round steel 5 mm, width 44 mm, depth D = 115 mm,
PU 5 pieces
Accessories
Rubber pad for double steel cable eye
for depth D = 80 mm, PU 5 pieces
Rubber pad for double steel cable eye for depth D = 115
mm, PU 5 pieces
To fix cable eye to front panel: insert and rotate it 45°
(example with plastic cable eye)
Part no.
60118-473
60118-474
60118-475
60118-476
Part no./35
41806051
3.7
19" front panel with cable ducting and cable through
ducting
Delivery comprises
Item
1
Qty
2
Description
19" front panel with integrated cable ducting, St, 1.5 mm,
78 mm deep
Order Information
Height
U mm
1
43.6
2
88.1
Description
2 oval cable ducting
openings, 150 x 32 mm
openings, 150 x 76 mm
RAL 7035
Part no.
RAL 7021
Part no.
20118-757
20118-758
20118-759
20118-760
Part no./35
Note
00506016
19" cable through ducting
쮿 Mounting height 1 U or 2 U
Delivery comprises
Item
1
Qty
2
Description
19" cable ducting, St, 1.5 mm
Order Information
Height Height Description
U
mm
Cable ducting
1
43.6
opening 27.5 x 438 mm
Cable ducting
2
88.1
opening 72.0 x 438 mm
RAL 7021
Part no.
RAL 7035
Part no.
20118-767
20118-734
20118-768
20118-736
Part no./35
Note
01696006
3.8
19" cable ducting with brush strip
쮿 No threading necessary
Delivery comprises
Item
1
Qty
2
Description
Al extrusion with brush strip (plastic, black), crimped
Order Information
Description
Part no.
60118-437
Part no./35
Note
01604007
19" cable tray, 2 U
쮿 Load-carrying capacity 15 kg
쮿 Installation height 2 U
쮿 Depth adjustable in 25 mm grid increments,
forward protrusion min. 91 mm, max. 191 mm
Item
1
2
Qty
1
2
Description
19" cable tray, 2 U, St, 1.5 mm
Mounting bracket, St, 1.5 mm
Order Information
Width
mm
430
Depth
mm
450
00507001
RAL 7021
Part no.
RAL 7035
Part no.
20118-795
20118-794
Part no./35
Note
3.9
Cable manager, horizontal
쮿 Excellent horizontal cable ducting for large cable volumes
쮿 The cables are held with robust, rounded cable fingers
쮿 Quick access to cables (cover hinges upwards, downwards or
comes off completely)
쮿 Simple to fit: clip in then screw down
쮿 1 and 2 U versions
쮿 Versions for front and rear cable routing
40011010
Front
Front and rear
40011006
쮿 Optimal cabling from horizontal to vertical
Delivery comprises
Item
1
2
Qty
1
1
Description
Cable manager, plastic, black
Fitting material with user manual
Order Information
Description
Front
H
H
89073653
89073654
Front and rear
Height H
U
mm
Front
1
44,5
Front
2
88,9
Front and rear 2
88,9
Width
mm
483.00
483.00
483.00
Depth
mm
152 mm
152 mm
229 mm + 152 mm
Part no.
DCHS1
DCHS2
DCHD2
Note
40011009
Application
Cable manager with hinged
cover
3.10
40011007
40011008
Top view, cable manager with
cable fingers front and rear
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
mm
447
Depth
mm
390
AlZn
Part no.
RAL 7021
Part no.
RAL 7035
Part no.
20118-781
20118-782
20118-783
Part no./35
00508007
Delivery comprises
Item
1
Qty
1
Description
Order Information
Width
mm
447
Depth
mm
238
RAL 7021
Part no.
RAL 7035
Part no.
20118-784
20118-785
Part no./35
00508003
forward protrusion min. 26 mm
Item
1
2
Qty
1
2
Description
Order Information
00508010
Width
mm
430
430
430
Depth
mm
250
300
400
RAL 7021
Part no.
RAL 7035
Part no.
20118-786
20118-787
20118-790
20118-788
20118-791
Part no./35
3.11
19" shelf, stationary, depth-adjustable,
1U
Mechanics
쮿 Static load-carrying capacity 68 kg
쮿 For mounting on four 19" posts or four 19" panel/slide mounts
쮿 Variable mounting dimensions (depth-adjustable from
19" angle to 19" angle)
쮿 2 versions
– Mounting dimensions 495 ... 851 mm
– Mounting dimensions 792 ... 1151 mm
쮿 2 oval cut-outs for cable ducting
쮿 Colour black, RAL 9005
Delivery comprises
Shelf with variable mounting dimensions
Item
1
Qty
1
2
1
40011016
Description
Shelf, depth-adjustable, width 19", RAL 9005 (black);
shelf is suspended on 19" upright or
Order Information
19" shelf, stationary, depth-adjustable, 1 U
Mounting dimensions D 495 ... 851 mm
Mounting dimensions D 792 ... 1151 mm
D
44
441
Part no.
D19FVT69B
D19FVT912B
Note
465
483
89073664
3.12
19" drawer
쮿 Height 1, 2 or 3 U
쮿 Optional writing surface
Delivery comprises ((assembled))
Item
1
1
Qty
1
2
Description
19" drawer with lock (2 keys)
Assembly kit
Order Information
Height H
00506009
43
9
Front panel
anodised
Part no.
Front panel
RAL 7021
Part no.
U
mm mm
1
41.6 30
20110-061
20110-180
2
86.0 73
20110-062
20110-181
3
130.5 117
20110-063
20110-182
Accessories
Writing surface for 19" drawer St, 1 mm, RAL 7035,
1 piece
Front panel
RAL 7035
Part no.
20110-054
20110-055
20110-056
20110-060
Part no./35
HE
h
H
40
3
2
41
Height h
50
~3
19" drawer
sza44206sza46122
Writing surface
19" keyboard drawer, 2 U
쮿 For keyboards up to 425 mm width, 210 mm depth,
45 mm height
쮿 IP 40 when closed
Delivery comprises
Item
1
Qty
1
2
3
4
2
1
2
Description
Keyboard drawer with hinged front panel, AI, anodised
(incl. locking)
Telescopic slide, St, zinc-plated
Keyboard chassis, St, 2.5 mm, RAL 7030
Front horizontal rail, Al extrusion, anodised
Order Information
005002
210
Part no.
10822-009
60126-118
Part no./35
Note
425
쮿 Without keyboard
88,1
180
Description
Accessories
Lock for 19" keyboard drawer 1 × lock incl. 2 keys
40
~2
A41263
3.13
19'' distribution field, Cat 6
쮿 1 U distribution field with 24 x RJ45 ports
쮿 For use in communications networks, in accordance with
ISO/IEC 11801 (as at 03/95)
쮿 Meets the specifications for EN 50 173 (as at 07/95)
쮿 Easy to fit thanks to dual insulation displacement technique
(LSA+/110)
쮿 Case can be opened and closed without tools, with quickrelease fastener
Delivery comprises (assembled)
01604002
Distribution field Cat 6
Item
1
2
Qty
1
3
3
24
Description
19" case, shielded, St, RAL 7035, 1 U, with earthing stud
Backplanes with 8 x dual insulation displacement
technique for AWG 22--24 cables and 8 x RJ45 sockets
Cable ties
Order Information
Description
Part no.
60118-435
Part no./35
Note
Document pocket
쮿 For storage of documents and circuit diagrams
쮿 Assembly with double sided adhesive tape
Delivery comprises
Item
1
2
Steel, DIN A4
Plastic, DIN A4
00506004 00506005
Qty
1
1
Description
Document pocket
Adhesive tape
Order Information
Description
Steel, DIN A4, RAL 7035
Plastic, DIN A4, grey
Plastic, DIN A3, grey
Dimensions H × W × D
mm
180 × 336 × 34
195 × 356 × 21
305 × 305 × 25
Plastic, DIN A3
3.14
Part no.
21126-271
60100-302
ADP2
Part no./35
00506006
19" mounting tray for LSA+
쮿 Mounting height 3 U
쮿 For retention of up to 15 LSA+ guide rails
Item
1
2
Qty
1
2
Description
19" mounting tray, St, 1.5 mm, finish AlZn
Flange cover, Al, anodised
Order Information
Description
Part no.
21493-079
00506008
Part no./35
Note
VTA45668
19" mounting bracket
쮿 For fixing cable channels and system rails (e.g. LSA+ or Infra+)
쮿 Mounting plane set back by optionally 70 or 170 mm relative to
the 19" plane
Delivery comprises
Item
1
Qty
1
Description
19" mounting bracket, St, 1.5 mm, RAL 7035
Order Information
Description
00506007
Depth
mm
70
170
Part no.
30118-802
30118-803
Part no./35
Note
SC30
3.15
19'' module support, 3 U
쮿 For assembly of partial width front panels with SUB-D-,
ST type 3 or FDDI cut-outs
D
쮿 Available in two versions
– without strain relief rail
– with strain relief rail
3
2
쮿 Optional front panels, Al, 2.5 mm, RAL 7035
1
Item
1
2
3
4
Qty
1
2
2
1
5
1
Description
19" module support, 3 U, Al
Threaded inserts with thread M2.5
Gland plate, St, 1 mm, RAL 7035
Strain relief rail, St, 1.5 mm, RAL 7035
(only for version with strain relief)
Assembly kit
Order Information
Description
36
11,4
R 3,4
25
3,1
20,5
36
20,5
11,4
R 3,4
3,1
25
44,3
25
20,5
3,1
R 3,4
00508057
11,4
005080510050805200508053
Front panel Sub-D 9-pin
Height
U
Depth D
mm
19" module support without
3
40
strain relief
19" module support with strain relief 3
115
Accessories
Front panel 3 U, 4 HP, 1 piece
Front panel 3 U, 7 HP, 1 piece
Front panel 3 U, 14 HP, 1 piece
Front panel 3 U, 28 HP, 1 piece
Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 1 x 9-pin,
1 piece
Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 2 x 9-pin,
1 piece
Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 3 x 9-pin,
1 piece
Front panel Sub-D 25-pin 3 U, 4 HP, cut-out 1 x 25-pin,
1 piece
Front panel Sub-D 25-pin 3 U, 4 HP, cut-out 2 x 25-pin,
1 piece
Quick release fastener for front panel assembly,
PU 100 pieces
Part no.
20118-630
20118-631
30118-328
30118-329
30118-330
30118-331
30118-338
30118-336
30118-332
30118-334
30118-335
21100-586
Part no./35
Note
11,4
R 3,4
FRONT PANEL
EXPRESS
47
3,1
42,5
55,7
R 3,4
47
42,5
3,1
쮿 Please order front panels or quick-release fastener separately
11,4
3.16
0050805400508055
19" assembly kit M6
쮿 For mounting of front panels, distribution fields or other
components on the frame, slide mounts or depth members
with square cut-outs
쮿 For standard GND/earthing use a GND/earthing nut and a
nomel washer on at least one attachment point
Delivery comprises
Item
1
2
3
4
5
Without GND/earthing
sc128
Description
Panhead screw, M6 x 16, St, zinc-plated
Plastic washer, black
Cage nut, M6, St, zinc-plated
GND/earthing cage nut, M6, St, zinc-plated
Nomel washer, St, zinc-plated, internal diameter 6.1 mm,
external diameter 12.2 mm
Order Information
Item
1+2+3
1+2+3
1+2+3
1+2+3
1
1
1
2
2
3
3
4
4
5
Description
Panhead screw M6, zinc-plated
Panhead screw M6, zinc-plated, black
Plastic washer
Plastic washer
Cage nut M6
Cage nut M6
GND/earthing cage nut M6
Nomel washer for GND/earthing, M6
With GND/earthing
Qty/PU
4
32
50
100
50
100
100
50
100
50
100
10
100
100
Part no.
21190-095
21190-435
21101-809
21101-810
21100-021
21100-022
21100-650
21100-015
21100-016
21100-003
21100-004
21120-131
21120-132
21101-173
Part no./35
00504053
3.17
Cage nut M4/M5
쮿 For assembly of special parts (in square holes), which require a
thread diameter of M4 or M5
a nomel washer on at least one attachment point
Order Information
Description
Cage nut M4
Cage nut
bza42733
Cage nut M4
00503050
GND/earthing
cage nut M4
GND/earthing
cage nut M4
Nomel washer
M4 for GND/
earthing
Cage nut M5
Cage nut M5
Nomel washer
00502512
GND/earthing
cage nut M5
GND/earthing
cage nut M5
Nomel washer
M5 for GND/
earthing
Description
St, zinc-plated, for material
thickness of 1.8 to 2.6 mm
thickness 1.8 to 2.6 mm
St, zinc-plated,
inner diameter 4.1 mm,
external diameter 8 mm
St, zinc-plated,
inner diameter 5.1 mm,
external diameter 10.2 mm
3.18
Qty/PU
Part no.
50
21100-001
100
21100-002
10
21120-127
100
21120-128
100
21120-148
50
21100-215
100
21100-216
10
21120-129
100
21120-130
100
21120-149
Part no./35
Square nut M6
쮿 For precise, anti-twist secure mounting without clearance
쮿 For standard GND/earthing use a square GND/earthing nut and
Order Information
Description
bza42735
Square nut
Description
material thickness of 3.7
Square nut M6
mm
Square nut M6
mm
Square GND/
material thickness of 1.5
earthing nut M6
mm
Square GND/
material thickness of 3.5
earthing nut M6
mm
St, zinc-plated, inner
Nomel washer for
diameter 6.1 mm, external
GND/earthing, M6
diameter 12.2 mm
Qty/PU
Part no.
50
21100-558
100
21101-007
50
21101-172
50
21101-171
100
21101-173
Part no./35
06704051
Square GND/earthing nut
Mounting aid for cage nuts
쮿 To fit/remove cage nuts
Order Information
Description
Qty/PU
1
Part no.
21127-990
Part no./35
06708057
A)
B)
2)
1)
06708056
3.19
Sandwich cable clamping for C profiles
쮿 Cable ducting in up to 5 planes
쮿 For cable diameter of 4 ... 7 mm, usable width 190 mm
Item
1
Qty
6
2
3
4
10
10
1
Description
Pressure plate, 15 x 250 mm, St, 2.5 mm, chromated and
zinc-plated, bolt spacing 200 mm
Rubber strip
Spacer M6 for cable diameter of 4 ... 7 mm
Assembly kit
Order Information
Description
20118-740
Part no.
Part no./35
01695039
Cable ties
Delivery comprises
Item
1
Qty
25
Description
Cable tie, plastic
Order Information
Description
Cable ties
Cable ties
Cable ties
Part no.
186 mm x 5 mm
360 mm x 5 mm
92 mm x 2.5 mm
20118-352
20118-353
20118-351
Part no./35
01005078
Velcro
쮿 Length 300 mm (for cable bundles of max. 90 mm diameter)
Order Information
Description
Velcro strip, Polyethylen/Polyamide, black,
length 300 mm, PU 10 pieces
Part no.
20118-624
Part no./35
01005079
3.20
Cable support
쮿 For cable support on pull-out devices and chassis
쮿 Cable fixing with cable ties
쮿 2 versions:
– Cable support with return spring for a uniform cabling
matched to the extraction movements
– Cable support without return spring, connected directly to
pull-out part
Order Information
Description
Qty/PU
1
1
Accessories
Cable ties 92 mm x 2.5 mm, PU 25 pieces
Part no.
20118-729
20118-706
20118-351
Part no./35
00592015
Technical data
Cable support with
return spring
Load-carrying capacity 2 kg
Extension length
730 mm
Space requirement in 25 mm
retracted position
Material
St, square tube,
16 mm2, zinc-plated
return spring
5 kg
720 mm
25 mm
St profile, 1 mm, zincplated
Note
00592016
Cable channel
쮿 For cable ducting in lateral and rear cabinet areas
쮿 For mounting on cabinet uprights, depth members or C-profiles
Delivery comprises
Item
1
Qty
1
Description
Cable channel, 2 m, plastic, grey
Order Information
Depth D
Width W
Length
mm
mm
mm
60
30
2000
60
60
2000
Accessories
Assembly kit for cable channel
(4 brackets, screws, washers, nuts, cage nuts)
Part no.
60103-011
60103-010
21100-123
Part no./35
Note
쮿 Please order assembly kit for cable channel separately
SC78
3.21
Simple telescopic slide for assembly of subracks
in cabinets
쮿 For mounting 84 HP wide subracks in the 19" plane
쮿 Loading capacity: 25 kg per pair
쮿 The guiding profile is matched to the fixing dimension in the
cabinet (it is bolted to the 19" profile of the cabinet); the adaptor
rail is matched to the depth and fixing dimension on the subrack
(it is inserted into the guiding profile like a telescopic slide)
쮿 Safety note:
No protection against extraction, no stop at full extension
06101006
Telescopic slides with guiding profile for fitting in
cabinets
Item
1
2
Qty
2
1
Description
C-profile, AI
Assembly kit
Order Information
1
For cabinet
range
3
3
Xr
06108072
VARISTAR
VARISTAR
VARISTAR
VARISTAR
VARISTAR
VARISTAR
eurorack
eurorack
eurorack
Novastar
Novastar
Novastar
Lab rack
Depth D
mm
600
800
900
1000
1100
1200
600
800
900
500
600
800
250
xf
mm
50
50
50
50
50
50
60
60
60
33
33
33
xr
mm
50
50
50
50
50
50
60
60
60
60
60
60
C
mm
500
700
800
900
1000
1100
480
680
780
407
507
707
250
c1
mm
369
569
669
769
869
969
397
597
697
350
450
650
162
Part no.
24562-464
24562-466
24562-467
24562-468
24562-472
24562-473
24562-449
24562-451
24562-452
24562-460
24562-461
24562-474
24562-446
Part no./35
Note
450
D
c
Xf
c1
쮿 Adapter rail see page 3.23
465
06108082
xf, xr: Distance of 19" plane to cabinet edge (front, rear)
c: Distance of 19" planes from each other,
c1: Fixing dimension of guiding profile on 19" panel/slide mounts
3.22
Telescopic slides with adaptor rail for subracks
쮿 The rail serves for fixing the subrack on the guiding profile
when mounted into a cabinet
Item
3
4
1
3
Qty
2
1
Description
Al extrusion, incl. M4 threaded insert
Assembly kit
Order Information
For subrack depth
mm
175
235
295
355
415
475
Part no.
24562-453
24562-454
24562-455
24562-456
24562-457
24562-458
3
06108072
Part no./35
Note
쮿 Suitable guiding profile see page 3.22
Measuring tape
쮿 Measuring tape with cm, U-, HP-division (length 2 m)
쮿 Plastic case, metal tape measure with automatic retraction
Order Information
Description
Tape measure
Qty/PU
1
Part no.
89009-001
32506001
3.23
Cabinet Accessories – Telescopic slides
Dimensioning of telescopic slides
Calculation of the load-carrying capacity
The stated load-carrying capacity P is valid provided that the
centre of gravity is in the centre of the extraction (Y/2).
For a different position of the centre of gravity (Y1) please use the
following formula:
Load-carrying capacity P(Y1) = ½ P Y/Y1 (but max. P)
Example:
Load-carrying capacity P = 45 kg,
Extension length Y = 250 mm
Position of centre of gravity Y1 = 150 mm
Result:
P(Y1) = ½ P Y/Y1 = ½ x 45 kg x 250/150 = 37.5 kg
00505053
Calculation of the maximum installation width (w)
Text
For each telescopic slide the maximum installation width (w) for
one shelf or drawer is given. This is the maximum clearance
available between the telescopic slides when they are fitted in a
19" cabinet.
00505060
Mounting on 19" panel/slide mounts
Text
In 19" cabinets, telescopic slides are mounted on the front and
rear 19" panel/slide mounts.
The length (L) must therefore be matched with the distance
between the 19" brackets (depthwise). For this the required
19" pitch (c) is given for each cabinet.
00505061
Telesc opic slides
3.24
Telescopic slide, narrow, for subrack
Teles copic sli desMA IN CATALOG Part number in bold face type: ready for shipping within 2 working daysP art number in normal type: ready for s hippi ng withi n 1 0 worki ng days
쮿 Suitable for 84 HP width subracks (type F, type H, type L)
쮿 Locks at full extension
쮿 Hinged
쮿 Extension length > 100 %
쮿 Rail width 7.5 mm
쮿 Maximum clear width of extension/drawer w = 84 HP (435 mm)
Delivery includes
00516001
Item
1
Qty
2
Description
Order Information
W
k = rail width 7.5 mm,
w = max. installation width
84 HP (435 mm)
00505060
xf
c
D
Length L Extension length Y
Loadcarrying
capacity P
kg
15
15
mm
mm
356
See table Technical data
559
Accessories
Fixing materials kit for Varistar, to mount 2 telescopic
slides, PU 1 kit
Fixing materials kit for Novastar, to mount 2 telescopic
slides, PU 1 kit
01004146
C dimensions:
Varistar 500 mm and 700 mm,
Novastar 507 mm to 707 mm
Part no.
60110-441
60110-440
21120-193
21120-194
Part no./35
Technical data
Length L
mm
356
559
Extension length Y
Varistar SL/HD
mm
350
553
Novastar SL
mm
362
565
Novastar HD
mm
352
555
Note
쮿 To mount on 19" plane please order assembly kit separately
175,00
235,00
275,00
295,00
355,00
415,00
475,00
00515050
Screw-on position for telescopic slide on side panel of subrack
3.25
Universal telescopic slide, 1 U
Main Catalogue
쮿 Static load-carrying capacity per pair 23 - 39 kg
쮿 Lateral mounting on the 19" uprights (19" plane remains free
for fixing the extension/drawer)
쮿 Can be removed
쮿 Rail width k = 9.7 mm,
max. installation width of extension/drawer w = 429 mm
Delivery comprises
Item
1
Qty
2
Description
Order Information
Length L
00505011
0050506000505055
k = rail width, w = max. installation width
L
356
406
457
508
559
610
660
711
B
92.1
92.1
92.1
92.1
92.1
92.1
92.1
92.1
Load-carrying
capacity P
kg
39
36
34
32
29
27
23
23
mm
356
406
457
508
559
610
660
711
Accessories
Assembly kit For VARISTAR, for assembly of 2 telescopic
slides, PU 1 kit
Assembly kit For eurorack, for assembly of
2 telescopic slides, PU 1 kit
Assembly kit for NOVASTAR, to mount
Dimensions table
A
29.5
29.5
29.5
89.9
89.9
89.9
7.4
7.4
Extension length
Y
mm
381
432
483
533
584
635
686
737
C
184.2
184.2
184.2
184.2
184.2
184.2
184.2
184.2
Internal part
D
E
276.2 276.2 276.2 276.2 368.3
276.2 368.3
276.2 368.3
276.2 368.3
276.2 368.3
F
460.4
460.4
G
552.4
552.4
X
349.3
349.3
349.3
501.7
501.7
501.7
603.3
603.3
External part
O
P
Q
304.6 317.3 330.0
355.4 368.1 380.8
406.4 419.1 431.8
457.4 470.1 482.8
508.1 520.8 533.5
558.6 571.3 584.0
609.4 622.1 634.8
660.2 672.9 685.6
Part no.
20110-090
20110-091
20110-092
20110-093
20110-094
20110-095
20110-096
20110-097
21120-158
21120-159
21120-160
Part no./35
Note
쮿 Universal telescopic rails can also be fitted without additional
components in non-standard applications, thus also in other
than 19" cabinets
00505055
3.26
Universal telescopic slide, 2 U
Main Catalogue
쮿 Static load-carrying capacity per pair 46 - 61 kg
쮿 Locking at full extension
쮿 Rail width k = 16 mm,
max. installation width of extension/drawer w = 417 mm
Delivery comprises
Item
1
Qty
2
Description
Order Information
Length L
00505010
0050506000505054
Dimensions table
Length L
305
356
406
457
508
559
610
660
711
A
76.2
101.6
127.0
127.0
152.4
177.8
177.8
203.2
228.6
Internal part
B
C
177.8
254.0
203.2
304.8
228.6
355.6
279.4
406.4
304.8
457.2
330.2
508.0
381.0
558.8
406.4
609.6
431.8
660.4
X
305.0
356.0
406.0
457.0
508.0
559.0
610.0
660.0
711.0
D
76.2
88.9
127.0
127.0
152.4
177.8
177.8
203.2
228.6
External part
E
F
190.5
241.3
215.9
292.1
241.3
342.9
292.1
393.7
317.5
444.5
342.9
495.3
393.7
546.1
419.1
596.9
444.5
647.7
Extension length
Y
mm
330
381
432
483
533
584
635
686
737
Load-carrying
capacity P
kg
61
60
58
57
55
52
50
48
46
mm
305
356
406
457
508
559
610
660
711
Accessories
slides, PU 1 kit
G
266.7
317.5
368.3
419.1
469.9
520.7
571.5
622.3
673.1
Part no.
20110-100
20110-101
20110-102
20110-103
20110-104
20110-105
20110-106
20110-107
20110-108
21120-158
21120-159
21120-160
Part no./35
Note
than 19" cabinets
3.27
Slim universal telescopic slide,
2U
Main Catalogue
쮿 Static load-carrying capacity per pair 46 - 57 kg
쮿 Extension length > 110 %
Delivery comprises
Item
1
Qty
2
Description
Order Information
Length L
00505009
0050506000505059
356
406
457
508
559
584
610
A
101.6
127.0
127.0
152.4
203.2
203.2
203.2
Internal part
w
C
184.2
304.8
209.6
355.6
235.0
406.4
260.4
457.2
412.8
508.0
431.8
533.4
438.2
558.8
X
356.0
406.0
457.0
508.0
559.0
584.0
610.0
Load-carrying
capacity P
kg
57
55
55
55
46
46
46
mm
356
406
457
508
559
584
610
Accessories
Assembly kit for VARISTAR, for assembly of
Assembly kit for eurorack, for assembly of
Telescopic slides mounting kit for NOVASTAR, to mount 2
Dimensions table
Length L
Extension length
Y
mm
432
483
533
584
635
660
686
D
101.6
127.0
152.4
152.4
177.8
177.8
203.2
External part
E
228.6
254.0
279.4
330.2
355.6
381.0
381.0
Part no.
20110-071
20110-072
20110-073
20110-074
20110-075
20110-076
20110-077
21120-161
21120-162
21120-163
Part no./35
Note
F
330.2
381.0
431.8
482.6
533.4
558.8
584.2
than 19" cabinets
00505059
3.28
Heavy load universal telescopic slide, 2 U
Main Catalogue
쮿 Static load-carrying capacity per pair 72 - 100 kg
쮿 End stop damped
쮿 Rail width k = 19.1 mm,
max. installation width of extension/drawer w = 411 mm
Delivery comprises
Item
1
Qty
2
Description
Order Information
Length L
00508011
0050506000507053
Y
mm
473.5
573.5
423,5
473.5
523,5
573.5
623,5
673.5
723,5
Load-carrying
capacity P
kg
77
83
88
94
100
94
88
72
mm
300
350
400
450
500
550
600
700
Accessories
to mount 2 telescopic slides, PU 1 kit
Dimensions table
Length L
mm
300
350
400
450
500
550
600
650
700
Extension length
Y
mm
473
573
423
473
523
573
623
723
A
128
128
160
160
192
192
256
Inner part (mm)
B
X
300
350
160
400
160
450
192
500
192
550
256
600
256
650
288
700
C
192
224
288
320
384
416
480
544
576
External part (mm)
E
F
224
256
320
160
352
160
416
192
448
192
512
256
576
256
608
288
Part no.
20110-190
20110-191
20110-192
20110-193
20110-194
20110-195
20110-196
20110-198
21120-164
21120-165
21120-166
Part no./35
Note
G
192
192
224
224
288
288
320
than 19" cabinets
3.29
Cabinet Accessories – Electrics
Cabinet light for 19" assembly
ElectricsMain Catalogue
쮿 With mains on/off switch
Delivery comprises
Item
1
Qty
1
1
1
Description
19" cabinet light with fluorescent tube and mains
switch, 1 U, IEC 60320 C14 plug
Assembly kit
Order Information
00504006
Description
Accessories
Equipment cable, BS British Standard plug, IEC 60320 C13
socket, 2.5 m, 1 piece
Mains cable, IEC IEC 60320 C14 plug,
IEC 60320 C13 socket, 2.5 m, 1 piece
Equipment cable, SCHUKO/UTE SCHUKO/UTE plug, IEC
60320 socket, 2.5 m, 1 piece
Door contact switch, cabled SCHUKO/UTE,
"German 3-wire", earthed/grounded plug,
IEC 60320 C13 socket, 1 piece
Delivery: fitted in cabinet or on frame
Part no.
20118-746
60103-137
60197-053
62150-191
20118-753
Part no./05
Part no./35
Technical data
Mains/line voltage
Performance
Illuminant
Connection
Assembly
Dimensions
230 VAC
14 W
Fluorescent tube T8, base G13, diameter 26 mm,
length 360 mm
IEC 60320 C14 plug
19" plane
Height 40 mm, width 483 mm, depth 100 mm
Note
쮿 Please order mains cable or door contact switch separately
3.30
Cabinet light for frame assembly
Main Catalogue
쮿 VDE approved, non-interference
Delivery comprises
Item
1
Qty
1
2
1
3
1
Description
Incandescent light (plastic case) with connecting cable,
IEC 60320 C13 plug and mains switch
Mounting angle, height 51 mm, width 309 mm,
depth 29 mm
Assembly kit
Order Information
01695011
Description
Accessories
Part no.
20118-747
60103-137
60197-053
62150-191
20118-753
Part no./05
Part no./35
Technical data
SZA45584
Mains/line
voltage
Performance
Illuminant
Connection
Assembly
Dimensions
230 VAC
35 W
Light bulb S14s, diameter 30 mm, length 300 mm
IEC 60320 C14 plug
With mounting bracket for the cabinet frame
Height 35 mm, width 309 mm, depth 51 mm
Note
3.31
Cabinet light for magnetic mounting
Main Catalogue
쮿 With integrated SCHUKO or UTE socket, 230 VAC, 16 A
Delivery comprises
Item
1
Qty
1
Description
Cabinet light (plastic case) with connecting cable,
IEC 60320 C14 plug, integrated mains switch and socket
Order Information
Description
Cabinet light for magnet mounting with UTE socket
Cabinet light for magnet mounting, with SCHUKO socket
Accessories
Mains cable, BS British Standard plug,
Mains cable, SCHUKO/UTE SCHUKO/UTE plug,
IEC 60320 socket, 2.5 m, 1 piece
Part no.
20118-748
20118-749
60103-137
60197-053
62150-191
20118-753
Part no./35
007_1000
Technical data
Mains/line voltage
Performance
Illuminant
Connection
Socket
Assembly
Dimensions
230 VAC
11 W
Compact fluorescent lamp PL-S, G23 base,
diameter 13 mm, length 200 mm
IEC 60320 C14 plug
250 VAC, 16 A
Magnet
Height 355 mm, width 65 mm, depth 65 mm
Note
3.32
LED light for cabinet mounting
Elec tricsMAIN CATALO GPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Energy efficient: consumes only 5 W
쮿 Bright: output equivalent to 95 W
쮿 Maintenance-free, long service life
쮿 Easy installation with magnetic mounting
쮿 Integrated, auto-sensing circuitry for 90 ... 260 VAC or
20 ... 60 VDC voltages
쮿 Versions with on/off switch or built-in infrared motion sensor
쮿 Optional accessories: 1 U bracket for 19" installation,
clip holders for clip fixing, power cables (preassembled) and
connectors (male/female)
Order Information
Description
Input
00516004
Technical data
Input
Input voltage
Power consumption
Current
Color
Luminosity
Lamp type
Light color
Service life
Mounting
Casing
Dimensions
Weight
Operating temperature
Storage temperature
Operating/Storage humidty
Protection type
Protection class
AC
DC
90 ... 230 VAC
20 ... 60 VDC
max. 5 W
max. 5 W
max. 2.5 A / 240 VAC
max. 2.5 A / 60 VDC
white
blue
400 Lm at 120° (1200 Lm at 360° or equivalent
95 W light bulb)
LED, angle of radiation 120°
Daylight, color temperature: 6000 K to 7000 K
60000 h at +20 °C (+68 °F)
Magnetic mounting
Plastic, transparent
Length 351 mm (13.8"), Diameter 32 mm (1.3")
0.2 kg | 0.5 lbs
-30 to +60 °C (-22 to +140 °F)
-40 to +85 °C (-40 to +185 °F)
max. 90 % RH (non-condensing)
IP 20
II (double insulated)
III (12 VDC, extra-low
voltage)
Input voltage
V
90 ... 260 VAC
90 ... 260 VAC
20 ... 60 VDC
20 ... 60 VDC
With IR motion sensor AC
With on/off switch
AC
With IR motion sensor DC
With on/off switch
DC
Accessories
Input cable for AC, length 2.0 m / 78.7 inch,
1 piece
Input cable for DC, length 2.0 m / 78.7 inch,
1 piece
Extension cable for AC, length 1.0 m /
39,4 inch, 1 piece
Extension cable for DC, length 1.0 m /
39,4 inch, 1 piece
Connection cable with IEC 60320 C18
connector for AC, length 0,5 m / 19,7 inch,
1 piece
Female connector for AC, 1 piece
Female connector for DC, 1 piece
Male connector for AC, 1 piece
Male connector for DC, 1 piece
Bracket 19" 1 U, RAL 7021 (black) 1 piece
Bracket 19" 1 U, RAL 7035 (grey) 1 piece
Clip kit PU 2 pieces
Qty/PU
piece
1
1
1
1
Part no.
60118-542
60118-543
60118-544
60118-545
60118-546
60118-547
60118-548
60118-549
60130-114
60118-550
60118-551
60118-552
60118-553
20118-807
20118-808
20118-809
3.33
Door contact switch
Main Catalogue
Delivery comprises
Item
1
2
3
Qty
1
1
4
4
1
Description
Door contact switch (without connecting cable)
PG screw fitting M20 x 1.5 for cable diameter 6 ... 12 mm
Mounting angle for cabinet assembly (VARISTAR,
PROLINE, eurorack)
Assembly kit
Order Information
Description
Door contact switch
Part no.
20118-738
Part no./05
Part no./35
00505029
Main Catalogue
쮿 Connection to cabinet light via IEC 60320 C13 socket
쮿 Connection with mains supply via SCHUKO/UTE connector
쮿 Easy handling by plug and play (completely wired)
Delivery comprises (completely wired)
Item
1
Qty
1
2
3
1
4
4
1
Description
Door contact switch with connecting cable to
IEC 60320 C13 socket, plug and mains connection
SCHUKO/UTE, fully wired
PROLINE, eurorack)
Assembly kit
Order Information
00505028
Description
Part no.
20118-753
Part no./05
Part no./35
00501501
3.34
19" distribution box
Main Catalogue
쮿 For installation of power distribution modules on DIN profile
rails (DIN 43880)
쮿 With cable support rail on the rear side, strain relief with
clamps
쮿 Two neutral conductors for terminal clamps from 4 ... 35 mm2
01495004
Item
1
2
Qty
1
1
3
2
4
1
5
6
7
1
1
2
8
1
9
1
Description
Case, 2 parts, 3 U/84 HP, AlZn
Front panel with cut-out for power distribution module,
St, 1 mm, RAL 7035
Neutral conductors for terminal clamps,
Cu, 200 x 3 x 10 mm, zinc-plated, insulated mounting
DIN profile rail, St, zinc-plated, depth-adjustable with
spacing bolts
Cable support rail for clamps, zinc-plated
Brush strip, plastic, black, for cable entry
Sealing strip, fibre glass reinforced Polyester, for unused
module positions
GND/earthing conductor, Cu, 1.5 mm2, green/yellow,
length 360 mm
Label strip
Order Information
sza45585
Connection clamp
Description
19" distribution box (with packaging for overseas shipping)
Accessories
Terminal clamps for 19" distribution box 4 mm 2, yellow/
green, PU 10 pieces
blue (N),PU 10 pieces
Terminal clamps for 19" distribution box 16 mm2, yellow/
green (PE),PU 10 pieces
Terminal clamps for 19" distribution box 35 mm2, yellow/
Clamps for 19" distribution box, PU 14 pieces
Part No.
60118-434
60118-521
21101-529
21101-532
21101-530
21101-533
21101-531
21101-534
21190-753
Part no./35
Note
01695012
쮿 Power distribution module, see page 3.36
Clamps
01695034
Part number in normal type: ready for shipping within 10 working days
3.35
Small distribution module
Main Catalogue
쮿 For the installation of power distribution modules on DIN
profile rails (DIN 43880)
Delivery comprises
Item
1
Qty
1
2
3
4
1
1
1
Description
Small distribution module, plastic, light grey, with
integrated DIN profile rail
Mounting plate for cabinet mounting, Al, 2.5 mm
Cover strip, plastic, light grey, for unused module spaces
Assembly kit for cabinet assembly
Order Information
Description
01695010
Part no.
20118-538
Part no./35
Note
SZA45586
Power distribution modules in accordance with
DIN 43880
쮿 For fitting into 19" distribution box or small distribution module
쮿 Snaps onto DIN profile rail
Order Information
Description
01695005
Circuit breakers
Circuit breaker 1 x 16 A
Circuit breaker 3 x 16 A
FI safety switch, 16 A, 30 mA
SCHUKO socket 250 V, 16 A
UTE socket 250 V, 16 A
FI safety switch
3.36
Socket
Width
mm
17.7
53.5
46
44
44
Part no.
20119-355
20119-356
20119-354
20119-357
20119-358
Part no./35
0169500401695003
Distribution box
Main Catalogue
Delivery comprises
Item
1
2
3
4
Qty
1
1
1
1
Description
Distribution box, plastic, light grey
Terminal strip, 5-pin, for cable cross section 2.5 mm2
Mounting plate, Al, 2.5 mm, for cabinet assembly
Order Information
Description
Distribution box
Part no.
20118-536
Part no./35
01695009
Distribution box with SCHUKO socket
Main Catalogue
Delivery comprises
Item
1
Qty
1
2
1
3
1
Description
Distribution box with SCHUKO socket, plastic, light grey,
with terminal strip for cable cross section up to 4 mm2
Mounting plate 90 x 100 mm, AlZn, 1.5 mm, for assembly
on cabinet uprights, 19" profiles and depth members
Order Information
Description
01604004
Part no.
20118-280
Part no./35
sc107
Mounting plate for single sockets
Main Catalogue
쮿 For common surface sockets
Delivery comprises
Item
1
2
Qty
1
1
Description
Order Information
Description
Part no.
20118-537
Part no./35
Note
쮿 Surface socket not included in Schroff product range
ela44796
GND/earthing clamp
Main Catalogue
쮿 IBM-compatible GND/earthing terminal for connecting a cabinet to the building GND/earth
쮿 Maximum cable cross-section 100 mm2
쮿 Surface tin-plated, in accordance with IBM Ref. No. 4716804
Order Information
Description
GND/earthing clamp, incl. assembly kit
20118-030
Part no.
Part no./35
sc27
3.37
GND/earthing rail
Main Catalogue
쮿 To connect GND/earthing wire and stranded conductors by
means of terminal clamps
쮿 Fixing insulated from the frame
Delivery comprises
Item
1
2
3
Qty
1
2
1
Description
Rail, Cu, cross section 35 mm2
Rail support block for max. 2 rails, plastic
Order Information
sc5
Length
mm
200
480
1000
1910
Accessories
Additional second GND/earthing rail, length 200 mm,
1 piece
Additional second GND/earthing rail, length 480 mm,
1 piece
Terminal clamps for GND/earthing rail, cable cross
section 4 mm 2,PU 20 pieces
section 16 mm2,PU 10 pieces
section 35 mm2,PU 5 pieces
Part no.
20118-281
20118-282
20118-265
20118-266
60118-145
60118-144
20118-366
20118-365
20118-364
Part no./35
Note
쮿 Please order terminal clamps or second rail separately
GND/earthing rail, flat strip
Main Catalogue
쮿 To screw on GND/earthing cables with ring tags
쮿 Threaded fixing points M5 in intervals of 20 mm
Delivery comprises
Item
1
Qty
1
2
3
2
1
Description
Rail, brass, untreated, 1000 x 15 x 3 mm, fixing points M5
Rail support block, plastic
Order Information
SC6
Description
Qty/PU
1
10
Accessories
Item 4 Panhead screw M5 x 10, St, zinc-plated,
PU 100 pieces
Part no.
20118-590
20118-591
21120-150
Part no./35
Note
쮿 Please order panhead screw M5 to screw on GND/earth cable
separately
3.38
Mains cables
Main Catalogue
쮿 Applications:
– Fans, cabinet lights, etc.
– Industrial PC connections
– Uninterruptible power supplies
– Systems
Delivery comprises
Item
1
Qty
1
Description
Mains cable, PVC, max. 250 VAC, max. 10 A
AZA43067
Order Information
Plug, mains/line side
Socket IEC 60320 C13,
equipment side
Length
mm
Colour
For application in
black
Germany,
France,
Austria,
Norway,
The Netherlands,
Sweden,
Finland,
Spain,
Portugal,
Turkey,
Greece,
Belgium,
Luxemburg
Approvals/
certifications
Part no.
SCHUKO/UTE
2500
grey
(to DIN 47732)
aza43071
AZA43068
62150-191
60103-131
2500
grey
(to DIN 47732)
2500
black
Great Britain,
Ireland
60103-137
2000
black
USA,
Canada
60103-141
60704-020
aza43072
BS
AZA43069
aza43071
USA
AZA43070
AZA43071
IEC 60320 C14
500
1000
00503051
AZA43071
2500
60110-360
black
worldwide
IEC 60320
60110-361
60197-053
Part no./35
3.39
Busbar 3 and 4 pole
Main Catalogue
쮿 Vertical current distribution in cabinets
쮿 Can be sawn off to required length
쮿 Connections: FASTON connector 6.3 x 0.8 mm
Item
1
Qty
1
2
3
3 (4)
2
Description
Insulating body for 4 inner conductors, length 1855 mm,
PVC
Inner conductor, pushed in
Fixing with insulating block, pushed in,
PA 6, black,
Order Information
Description
00892013
Material
Length
mm
1855
1855
1855
3 pole
E-Cu tin-plated
4 pole
E-Cu tin-plated
4 pole
Brass untreated
Accessories
Item 3 Fixing with insulating block PVC, black,
PU 10 pieces with assembly kit
Item 5 Mounting angle for cabinet assembly St, 1.5 mm,
finish AlZn, PU 4 pieces
Part no.
20100-018
20100-017
20100-015
20100-019
20100-029
Technical data
00892015
Mains voltage
Nominal current CuZn conductor
Nominal current Cu conductor
Conductor resistance
Max. temperature of rail
Flammability of insulation body
500 VAC (50 Hz)
32 A (TU = 40 °C)
63 A (TU = 40 °C)
6.8 mΩ/m (brass), 1.9 mΩ/m (Cu)
70 °C
UL 94-V0
Note
쮿 After cutting to length, please order fixings with insulating
block separately
AZA42396
Fixing with insulating block for busbar 3, 4 pole
AZA42393
aza40567
3.40
ELECTRONICS PROTECTION
Busbar 1 and 2 pole
Main Catalogue
쮿 Connections FASTON 6.3 x 0.8 mm
Item
1
Qty
1
2
3
1 (2)
2
Description
Insulating body for 2 inner conductors, length 1900 mm,
PVC
Insulating block, glued in, PA 6, grey
Order Information
00892013
Description
Material
1 pole
2 pole
2 pole
2 pole
E-Cu tin-plated
E-Cu tin-plated
Brass untreated
Brass tin-plated
Length
mm
1900
1900
1900
1900
Part no.
20100-010
20100-008
20100-006
20100-007
Technical data
Mains voltage
Isolation voltage
Cu conductor
Breakdown voltage/test voltage
Conductor cross-section
500 VAC (50 Hz)
750 V
50 A (TU=20°C), 32 A (TU=50°C)
100 A (TU=20°C), 60 A (TU=50°C)
2500 V/2 kV/1 min
18 mm²
4 mΩ/m (brass), 1 mΩ/m (Cu)
70 °C
UL 94 V-0
쮿 For mounting please order insulating block or mounting angle
separately, see page 3.42
00892014
A4_561
3.41
Mounting bracket for busbar 1, 2 pole
Main Catalogue
쮿 Mounting of 1 to 3 busbars in full length (max. 6 conductors)
쮿 After cutting to length, glue in new insulating blocks
쮿 Numbers 1...12 are stamped on for conductor identification
Delivery comprises
Item
1
2
Qty
4
8
Description
Mounting bracket, plastic, Noryl, black
Screw with cross recess, St, M4 x 30, zinc-plated
Order Information
Description
Mounting bracket for bus bar 1, 2-pole
Accessories
Item 3 Insulating block for shortened busbar, 1 or 2-pole
Item 4 Identification label with transparent cover,
PU per 10 pieces
Part no.
20100-028
20100-009
20100-013
20100-029
Note
쮿 To ensure stability, mounting brackets should be fitted at
500 mm intervals
A4-562
A4-565
00505051
Mounting with insulating block for
busbar 1, 2 pole
Main Catalogue
쮿 Easy and space saving assembly of shortened busbars
2
쮿 With integrated insulating block
쮿 Mounting in rows possible
15
30
Delivery comprises
6,2
Item
1
2
1
Qty
4
4
Description
Fixing with insulating block, Noryl, black
Screw, M4 x 25, St, zinc-plated
Order Information
10
15
ela44253
Description
Fixing with insulating block for busbar 1 or 2 pole
Part no.
20100-030
20100-029
Note
쮿 M6 screw, washer and nut for row mounting not included
ELA44254
3.42
Contact protection for bus bar
1 ... 4 pole
Main Catalogue
쮿 Cover for the inner conductor (between the connectors)
쮿 Can be shortened at any size
Delivery comprises
Item
1
Qty
1
Description
Protection against contact for busbar, length 1 m
Order Information
Description
Length
m
1
Part no.
60100-398
A4-566
Insulating block for busbar 1 ... 4 pole
Main Catalogue
쮿 The insulating block breaks multiple circuits within one rail
Delivery comprises
Item
1
Qty
10
Description
Insulating block, PVC Ø 4 x 20 mm
Order Information
Description
Part no.
20100-021
A4-1961c
3.43
Power connector 63 A for busbar 1 ... 4 pole
Main Catalogue
쮿 Nominal current max. 63 A at 40 °C
쮿 Cable cross section max. 16 mm²
쮿 Power supply protected against direct contact
Delivery comprises
Item
1
Qty
1
2
1
Description
Power connector, ABS/E-Cu, tin-plated, ABS,
self-extinguishing
Allen key, St, zinc-plated
Order Information
Description
ela44252
Part no.
60100-478
Note
쮿 Power connector requires two FASTON slots
Power connector 125 A for busbar 1 ... 4 pole
Main Catalogue
쮿 Nominal current max. 125 A at 40°C
쮿 Cable cross section max. 25 mm²
Delivery comprises
Item
1
Qty
1
Description
Power connector, PA, halogen-free, copper plate,
connected
Order Information
Description
Part no.
60100-575
Note
쮿 Power connector requires three FASTON slots
00505052
3.44
Cabinet Accessories – Monitor, keyboard
Monitor, keyboard, touchpad, 1 U
Monitor, keyboardMain Catalogue
쮿 Pull-out 17" TFT colour monitor chassis, 1 U
(resolution 1280 x 1024, SXGA; connects to VGA interface)
쮿 Keyboard with German, English or French keyboard layout
(connects via PS2 or USB)
쮿 Integral touchpad (connects via PS2 or USB)
쮿 Voltage supply:
Wide-range input (nominal mains voltage 110 to 240 VAC),
Voltage supply 12, 24 and 48 VDC on request
쮿 Depth-adjustable mounting for different pitches of server
panel/slide mounts;
Mounting depth (dimension c = spacing of 19" profiles):
560 ... 800 mm (smaller mounting depths on request)
00510003
쮿 Further versions on request
– With trackball or numeric pad
– Keyboard layouts for Arabic, Belgian, Danish, US English,
Finnish, Italian, Portuguese, Russian, Swedish, Swiss,
Spanish and Czech
– With DVI connection
Delivery comprises (assembled and wired)
Front view
Rear view
00510002
00510005
Detail of keyboard, touchpad
00510004
Item
1
Qty
1
2
1
3
4
5
1
1
2
6
7
1
1
Description
1 U chassis, pull-out, RAL 9005 black;
17" monitor, keyboard and touchpad;
Monitor connection via VGA (SUB-D 15),
keyboard and touchpad via either PS/2 or USB
Mains supply cable, length 2 m,
SCHUKO/UTE plug ... IEC 60320-C13 socket
Connecting cable for mouse PS/2 - PS2, length 2 m
Connecting cable for keyboard PS/2 - PS2, length 2 m
Connecting cable for keyboard and mouse USB - USB,
length 2 m
Connecting cable for monitor SUB-D 15, length 2 m
Assembly kit and user manual
Order Information
Technical data
Mains voltage
Power consumption
Monitor
110 ... 240 VAC (50 Hz ... 60 Hz)
Active max 30 W, standby < 1 W
17", TFT display, resolution 1280 x 1024 (SXGA),
16.7 million colours, contrast 1000:1,
brightness 350 cd/cm², viewing angle 160°,
Operating life LED backlight 30000 h, on-screen menu;
cConnection by 15-pin H-DSUB socket
Keyboard
83 keys (numeric pad integrated), connects to computer
via PS/2 or USB
Touchpad
Industry standard, width 62 mm, height 46 mm, connects
to computer via PS/2 or USB
Dimensions (with closed Height 1 U (44 mm), width 19" (483 mm), depth without
monitor)
handle 495 mm, depth with handle 535 mm
Dimensions (with open Height 380 mm, width 483 mm, depth min. 1000 mm
monitor, fully extracted) (depending on mounting depth)
Extraction depth
500 mm
Operating / storage
0 ... 50 °C /
temperature
-20 ... 60 °C
Operating / storage
5 ... 90 % / 5 ... 90 %
humidity
Shock
non operating 50 g / 11 ms
Vibration
non operating 1.5 g / 10-300 Hz
Weight
13 kg
MTBF
35000 h
Description
Qty/PU
pieces
1
1
1
German keyboard layout
English keyboard layout
Accessories
Part no.
60118-518
60118-519
60118-520
60103-137
Part no./05
Part no./35
Note
쮿 Adaption to other mains connections see page 3.39
3.45
19" drawer with keyboard (touchpad)
Main Catalog
쮿 Pull-out 1 U drawer with industrial keyboard including
function keys, numeric keypad and touchpad;
end stop when fully pulled out
쮿 Connects to PS/2 or USB interface with adaptor
(please order separately)
쮿 Colour light grey (RAL 8035) or black grey (RAL 7021)
Delivery includes (assembled and wired)
Item
1
Qty
1
Description
19" drawer with front panel 1 U; keyboard with PS/2 plug,
cable length 1.5 m, touchpad 62 x 46 mm
Order Information
00510008
Height Width Depth Description
RAL 7035
U
mm
mm
Part no.
German keyboard
1
482
334
60118-522
layout
French keyboard
1
482
334
60118-524
layout
UK keyboard
1
482
334
60118-525
layout
USA keyboard
1
482
334
60118-523
layout
Accessories
Adaptor, 2 x PS/2 – USB PS/2 socket – USB plug, length
160 mm, 1 piece
RAL 7021
Part no.
60118-526
60118-528
60118-529
60118-527
60118-515
Note
쮿 Please order adaptor, 2 x PS/2 sockets to connect to USB port
of computer separately
Main Catalogue
Drawer: Front view, keyboard closed/pulled out
3.46
00510050
00507002
Cabinet Accessories – Management
Cabinet management basic units
ManagementMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Monitoring and management of air/water heat exchanger,
environmental parameters and access
쮿 Local display, Ethernet interface and web interface
쮿 2 versions
– EMX 111 Monitoring for one air/water heat exchanger and up
to max. 16 sensor values
– EMX 888 (19" case): Monitoring for up to 8 air/water heat
exchangers and up to max. 128 sensor values
EMX 111
00711020
Delivery comprises
Item
1
Qty
1
2
1
3
4
13
2
1
1
Description
Cabinet management basic unit; integrated power supply
unit, 230 VAC, IEC C13 socket
Mains cable IEC C13 on SCHUKO/UTE, cable restrainer
with clip
Mounting bracket
Serial interface cable with DB9F connection, black
User manual
Order Information
EMX 888
00711023
Height H
mm
U
44
44
1
Width W
mm
251
440
19"
Depth D
mm
53
134
Part no.
EMX111
EMX888
Interfaces
Rear view EMX 888
00711021
EMX111
1
EMX888
8
1
8
1
8
1
1
1
1
1
1
1
2
1
Description
RJ 12 socket, connection point for environmental
sensors
RJ 45 socket (RS 485; connecting point for air/
water heat exchanger)
RJ 45 socket, connection for asset management
strips
RJ 45 socket, connection point for network
(Ethernet)
USB socket, host
USB socket, device
Potential-free contacts
RS 232 socket, serial interface
Note
쮿 Sensors (temperature, humidity, differential pressure,
airflow...) and hub for connecting multiple sensors, see from
page 3.48
Part number in bold face type: ready for despatch within 2 working days
3.47
Sensors
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 The sensors are connected to the base unit via a RJ12 interface
쮿 The sensors connected are detected automatically
Order Information
Description
Measurements
Input Connection
Qty/PU
pieces
Part no.
Temperature sensor
1 x temperature
Cable length 3 m
1
60110-313
Temperature/
humidity combi sensor
1 x temperature
1 x humidity
Cable length 3 m
1
60110-314
Two temperature/
humidity combi sensors
2 x temperature
2 x humidity
Cable length 3 m + 3 m
1
60110-315
Two temperature sensors and
one temperature/
3 x temperature
1 x humidity
Cable length 3 m + 3 m +
3m
1
DPX-T3H1
Dual potential-free contact
sensor
Cable length 0.5 m
1
DPX-CC2-TR
Differential pressure and
temperature sensor
1 x pressure
1 x temperature
Cable length 3 m
1
DPX-T1DP1
Airflow sensor
1 x air circulation
Cable length 3 m
1
DPX-AF1
00709002
00709002
00709003
00711022
00711018
00711019
00712002
Note
쮿 Other sensors e.g. smoke detector, vibrations, leakage, etc.
on request
3.48
Hub to accept
4 sensors
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Connections (signals and power) are via RJ12 plug on the
power control socket strip or on the cabinet management
system
쮿 A maximum of 4 sensors can be connected, thus up to 16
variables (depending on sensors) can be transmitted
(temperature sensor, temperature/humidity combi sensor,
differential pressure, potential-free contacts, airflow sensor)
Delivery comprises
00709011
Item
1
2
Qty
1
1
3
4
5
4
1
2
Description
Case, height 18 mm, width 106 mm, depth 37 mm
RJ12 socket to connect to socket strip or cabinet
management system (IN; for power supply and data
transmission)
RJ12 socket for connecting sensors (OUT)
Connecting cable, RJ12 plug – RJ12 plug, length 1 m
Mounting angle, St, 2 mm, RAL 7035
Order Information
Description
Hub to accept 4 sensors (max. 16 parameters)
SCHROFF.PENTAIR.CO.UK
Part no.
60110-316
3.49
Socket stripsMain Catalogue
Cabinet Accessories – Socket strips
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
00704002
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Single-phase and three-phase strips
Systems . . . . . . . 8
00704003
Strips with fixed connecting cables or with
Wieland® GST 18 connecting system
00704004
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Broad range of functional elements up to
master-slave
00704005
19" power distribution for 3 phases,
2 performance classes
00708047
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
3.50
SCHROFF PRODUCT CATALOG E 05/2016
Overview . . . . . . 3.50
Soc ket stripsMain C atalogue
Socket strips
쮿 Modular, compact construction with many function elements
Socket strips with
connecting cable
SCHUKO
쮿 Mains input via cable and country-specific plug or via Wieland® GST18 system
SCHUKO socket
strips . . . . . . . . . . . 3.52
쮿 Horizontal mounting on the 19" plane (1 U) or vertically on the cabinet frame
SCHUKO
socket strips,
master-slave . . . . 3.53
쮿 Multiphase supply via three-phase strips or IEC power distributor
SCHUKO
socket strips,
3 circuits . . . . . . . . 3.54
UTE
UTE socket strips 3.55
Socket strips in 1 U Al extrusion
쮿 Hard wired connecting cable with country-specific mains plug
or Wieland® GST18
쮿 Country-specific sockets: IEC, SCHUKO, UTE,
British Standard, USA or Swiss versions
쮿 Functional elements: Fault current, overcurrent and transient
protection, interference suppression filter with display
쮿 Single-phase and three-phase feed
UTE socket strips,
master-slave . . . . 3.56
UTE socket strips,
3 circuits . . . . . . . . 3.57
IEC
IEC socket strips,
C13 . . . . . . . . . . . . . 3.58
IEC socket strips,
C19 . . . . . . . . . . . . . 3.59
IEC socket strips,
C19, 3 phase . . . . . 3.60
SCHUKO/ IEC
Socket strips with
with 2 supply
cables . . . . . . . . . . . 3.61
BS
BS
socket strips . . . . . 3.62
US
USA socket strips 3.63
Switzerland
00704005 00708032
Socket strips
Swiss version . . . . 3.64
19" power distributor, 3-phase
쮿 3-phase distributor to connect single phase consumers or
socket strips
쮿 Input 3-phase 400 VAC (32 A or 63 A)
쮿 Output with IEC 60320-C19 sockets
– 6 × 230 VAC in 32 A/phase version
– 9 × 230 VAC in 63 A/phase version
쮿 Overcurrent protection for each output
Socket strips, Wieland
SCHUKO
socket strips,
Wieland ® . . . . . . . 3.67
UTE socket strips,
Wieland ® . . . . . . . 3.68
IEC socket strips,
Wieland ® . . . . . . . . 3.69
Connector cable
for Wieland® . . . . 3.70
00708033
ServicePLUS from page 3.71
3-phase . . . . . . . . . 3.71
e.g. individual configuration of design, sockets,
power connection, functional elements (filter,
overcurrent and overvoltage protection, etc.)
ServicePLUS . . . 3.71
Power Control
socket strips . . . 3.72
www.schroff.biz/ServicePLUS
30407004
3.51
SCHUKO socket strip
Socket stripsMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
쮿 Socket strips with SCHUKO sockets,
with either switch or function elements
쮿 Installation height 1 U
쮿 Connecting cable 2 m with SCHUKO/UTE plug
쮿 Socket strips can be rotated through all four directions
(in 90° increments) during installation
쮿 Horizontal or vertical mounting
쮿 230 V, 16 A
쮿 In accordance with DIN 57620, VDE 0620
00705001
DTA44115
Item
1
Qty
1
2
3
4
2
1
5
2
Description
Al extrusion, 1 U, anodised, for sockets and functional
elements
SCHUKO sockets (35° rotated, PA, RAL 7035), illuminated
switch and functional elements, for type and quantity see
Order information
End piece, PA, RAL 7035
Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2,
with SCHUKO/UTE connector, PVC, encapsulated
Mounting bracket, PA, RAL 7035
(only with 10", 19" version)
00704051
Item 6: bracket for vertical mounting
ServicePLUS see page 3.71
Order Information
Description
SCHUKO
SCHUKO - with switch
SCHUKO with
functional elements
Sockets
3
4
9
12
15
19
8
12
15
19
6
6
6
7
8
6
9
Length
Inch
10"
19"
19"
19"
19"
19"
19"
19"
19"
Length
mm
184
210
438.5
947.5
1202
1753
438.5
947.5
1202
1753
438.5
438.5
438.5
438.5
438.5
438.5
947.5
Depth
mm
44
44
44
44
44
44
44
44
44
44
88
75
88
44
44
44
44
Switch
Functional element
Part no.
X
X
X
X
Fault current protection
Fault current protection, overcurrent protection
Mains suppression filter
Transient protection
Transient protection, mains suppression filter
60110-200
60110-201
60110-202
60110-203
60110-204
60110-205
60110-206
60110-207
60110-208
60110-209
60110-216
60110-212
60110-217
60110-214
60110-210
60110-266
60110-211
Part no./05
Part no./35
Accessories
Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces
Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm,
PU 2 pieces
20110-068
23130-010
Note
3.52
쮿 Please order mounting bracket for vertical mounting
separately
쮿 Individual online configuration www.schroff.biz/conf
SCHUKO socket strip, Master-Slave
Socket strips
쮿 When the master unit is switched on the slave outlets are
connected to the mains (switch threshold adjustable)
쮿 110 ... 230 V, 16 A
00704007
DTA44115
Item
1
2
3
4
Qty
1
6
2
1
5
2
Description
Order Information
Sockets
00704051
6
Length
Inch
19"
Length
mm
438.5
Depth
mm
44
Accessories
depth 135 mm, PU 2 pieces
Part no.
60110-270
Part no./05
Part no./35
20110-068
23130-010
Note
separately
Part number in normal type: ready for despatch within 10 working days
3.53
SCHUKO socket strip, 3-phase
Socket strips
쮿 Socket strips with SCHUKO sockets, 3-phase
쮿 Connecting cable 2 m, open end with ferrules
쮿 Vertical mounting
쮿 3 phases, 16 A per phase
00704008
DTA44115
Item
1
2
Qty
1
9
3
4
2
1
Description
SCHUKO sockets (35° rotated, PA, RAL 7035), 3 phases x
3 sockets, different colours
Connecting cable, black, 2 m, 05VV-F 5G 2.5 mm2,
Order Information
Sockets
9
00502502
Height
U
1
Length
mm
608.5
Depth
mm
44
Part no.
60110-219
Part no./05
Part no./35
Accessories
20110-068
23130-010
Note
separately
3.54
UTE socket strip
Socket strips
쮿 Socket strip with SCHUKO sockets, either with switch or
functional elements
쮿 Connecting cable 2 m, with SCHUKO/UTE plug
쮿 Horizontal and vertical mounting
쮿 230 V, 16 A
쮿 In accordance with NFC 61-303
00705002
DTA44116
Item
1
Qty
1
2
3
4
2
1
5
2
Description
elements
UTE sockets (35° rotated, PA, RAL 7035), illuminated
Order information
Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with
00704051
Order Information
Description
Socket strip 10",
4 UTE sockets
UTE with switch
UTE with functional element
Sockets
4
9
12
15
19
8
12
6
6
6
7
8
6
Length
Inch
10"
19"
19"
19"
19"
19"
19"
19"
19''
Length
mm
210
438.5
947.5
1202
1753
438.5
947.5
438.5
438.5
438.5
438.5
438.5
438.5
Depth
mm
44
44
44
44
44
44
44
88
75
88
44
44
44
Switch
Functional element
X
X
Part no.
60110-220
60110-221
60110-222
60110-223
60110-224
60110-225
60110-226
60110-230
60110-228
60110-231
60110-229
60110-227
60110-267
Part no./05
Part no./35
Accessories
PU 2 pieces
20110-068
23130-010
Note
separately
3.55
UTE socket strip, master-slave
Socket strips
쮿 When the master unit is switched on, the slave outputs are
쮿 230 V, 16 A
00704006
DTA44116
Item
1
2
3
4
Qty
1
6
2
1
5
2
Description
Order Information
Sockets
00704051
6
Length
Inch
19"
Length
mm
438.5
Depth
mm
44
Part no.
60110-232
Part no./05
Part no./35
Accessories
20110-068
23130-010
Note
separately
3.56
UTE socket strip, 3-phase
Socket strips
쮿 Socket strips with UTE sockets, 3-phase
쮿 Vertical mounting
00704010
DTA44116
Item
1
2
Qty
1
9
3
4
2
1
Description
3 phases x 3 sockets, different colours
Order Information
Sockets
9
00502502
Height
U
1
Length
mm
608.5
Depth
mm
44
Accessories
Part no.
60110-233
Part no./05
Part no./35
20110-068
23130-010
Note
separately
3.57
IEC socket strip, C13
쮿 Socket strips with IEC 60320-C13 sockets
쮿 230 V, 10 A
쮿 In accordance with IEC 60320
00710010
dta44118
Item
1
Qty
1
2
3
4
2
1
5
2
Description
Al extrusion, 1 U, anodised, to accommodate the sockets
and function elements
IEC 60320-C13 sockets (PA, RAL 7035), quantity see
Order information
Connecting cable, 2 m, black, open end with ferrules,
H05VV-F 3G 1.5 mm2
Mounting bracket, PA, RAL 7035,
(on 19" versions only)
Order Information
Sockets
00704051
8
12
16
Length
Inch
19"
19"
Length
mm
438.5
438.5
608.5
Depth
mm
44
44
44
Strain relief provided by locking tabs
3.58
00708036
Part no.
60110-290
60110-291
60110-292
Part no./05
Part no./35
Accessories
Locking tab for IEC 60320-C13 connector PU 12 pieces
Item 6 Mounting bracket for socket strips for vertical
Mains cable, IEC : for locking tab IEC 60320-C14 plug,
IEC 60320 C13 socket, 0.5 m, 1 piece
IEC 60320 C13 socket, 1 m, 1 piece
60110-362
20110-068
23130-010
60110-360
60110-361
Note
쮿 Please order bracket for vertical mounting separately
쮿 IEC socket strips, telemonitored and remote-controlled see
page 3.75
쮿 IEC socket strips with universal connections
(Wieland®connectors) see page 3.67
IEC socket strip, C19
Main Catalogue
쮿 Socket strips with C19 IEC sockets (8 or 12 pieces)
쮿 Connecting cable 2 m, with connector in accordance with
IEC 60309
쮿 Vertical mounting (19" version horizontal or vertical)
쮿 230 V, 32 A (with 2 x 16 A fuse), 16 A (without fuse)
Delivery comprises
Item
1
00709015
00709050
Qty
1
2
3
4
5
2
1
2
Description
elements
Sockets, IEC 60320 C19 (PA, RAL 7035),
for type and quantity see Order information
Connecting cable, 2 m, with IEC 60309 connector
only for 19" versions
Order Information
Sockets
IEC 60320 C19
8
12
12
00704051
Length Length Depth Input
Inch
mm
mm
230 VAC,
19"
438.5
44
16 A
230 VAC,
947.5
44
16 A
230 VAC,
947.5
44
32 A
Fuse
Part no.
60110-280
60110-282
2 x 16 A
60110-281
Accessories
Part no./05
Part no./35
20110-068
23130-010
Note
3.59
IEC socket strip, 3 phase
쮿 Socket strips with IEC sockets in accordance with IEC 60320
(C13 or C13/C19)
쮿 Connecting cable 2 m, 3 phase, with connector plug in
accordance with IEC 60309 (16 A or 32 A)
쮿 Vertical mounting
쮿 400 V, 32 A (with 6 x 16 A fuse), 16 A (without fuse)
Delivery comprises
Item
1
00709019
DTA44118
00709050
C13
C19
Qty
1
Description
elements
Sockets IEC 60320 (PA, RAL 7035), type and quantity see
Order information
2
3
4
2
1
Order Information
Input
400 VAC,
16 A
400 VAC,
16 A
400 VAC,
32 A
Length
mm
Depth Output
mm
Fuse
947.5
44
60110-283
947.5
44
60110-284
1753
44
6 x 16 A
60110-285
18 x IEC C13
18 x IEC C13,
6 x IEC C19
24 x IEC C13,
6 x IEC C19
00502502
Part no.
Part no./05
Part no./35
Accessories
20110-068
23130-010
Note
3.60
Socket strips with 2 supply cables, SCHUKO and IEC,
3 phase
Socket stripsPart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days
쮿 Socket strips with IEC 60320-C13 sockets and SCHUKO sockets
쮿 Two connector cables (halved in direction of length), 3 m (with
open end), 2 x 3 phase, 400 VAC (red, black, white area)
쮿 Socket strips can be rotated in all directions (in 90° increments)
during installation
쮿 Horizontal and vertical assembly possible
Delivery includes
00712005
DTA44118
C13
DTA44115
SCHUKO
Item
1
2
Qty
1
3
4
2
1
Description
Al extrusion, 1 U, anodized, for socket inserts
Socket inserts, IEC 60320 (PA, RAL 7035), type and
Endpiece, PA, RAL 7035
Connector cable, 2 x 2 m, open cable end for laying
Order Information
Input
Length
mm
Depth
mm
400 VAC, 16 A
1848.5
44
400 VAC, 16 A
1848.5
44
Output
36 x IEC C13 + 12
x SCHUKO
48 x IEC C13
Delivery: supplied loose with cabinet or frame
00704051
Accessories
Part no.
60110-286
60110-287
Part no./05
Part no./35
20110-068
23130-010
Note
쮿 Fixing bracket for vertical mounting, only required for fitting
into 47 U cabinet, please order separately
3.61
BS socket strip
Socket strips
쮿 Socket strips with British Standard sockets, optionally with
switch
쮿 Supply cable 2 m with BS plug (fuse integrated)
쮿 230 V, 13 A
쮿 In accordance with BS 1363
00705004
DTA44117
Item
1
Qty
1
2
00704051
3
4
2
1
5
2
Description
elements
BS sockets (PA, RAL 7035) and switch (illuminated),
BS connector (integrated 13 A fuse), PVC, encapsulated
Mounting bracket, PA, RAL 7035, only for 19" versions
Order Information
Description
Sockets
BS
BS
BS with switch
7
10
6
Length
Inch
19"
19"
Length
mm
438.5
947.5
438.5
Depth
mm
44
44
44
Part no.
60110-243
60110-244
60110-245
Part no./05
Part no./35
Accessories
20110-068
23130-010
Note
separately
3.62
USA socket strip
Socket strips
쮿 Socket strips with USA sockets, alternatively with switch
쮿 Connecting cable 2 m, with USA plug
쮿 115 V, 15 A
쮿 In accordance with UL-498
00705005
DTA44797
Item
1
Qty
1
2
3
4
2
1
5
2
Description
elements
USA sockets (PA, RAL 7035) and switch (illuminated),
with USA socket, PVC, encapsulated
Order Information
00704051
Description
Socket
inserts
US
US
US with switch
11
15
11
Length
Inch
19"
19"
Length
mm
438.5
947.5
438.5
Depth
mm
44
44
44
Accessories
Part no.
60110-240
60110-241
60110-242
Part no./05
Part no./35
20110-068
23130-010
Note
separately
3.63
Swiss socket strip
Socket strips
쮿 Socket strips with sockets, Swiss version, optionally with switch
쮿 Connecting cable 2 m with Swiss version plug
쮿 230 V, 10 A
쮿 In accordance with SEV.IEC 60884
00705006
DTA44124
Item
1
Qty
1
2
3
4
2
1
5
2
Description
elements
Sockets, Swiss version (PA, RAL 7035), switch
(illuminated), for type and quantity see Order information
Supply cable, black, 2 m, 05VV-F 3G 1.0 mm2,
with plug (Swiss version), PVC, moulded
Order Information
00704051
Description
Sockets
10
Length
Inch
19"
Length
mm
438.5
Depth
mm
44
Swiss version
Swiss version
with switch
60110-453
9
19"
438.5
44
60110-454
Part no.
Part no./05
Part no./35
Accessories
20110-068
23130-010
Note
separately
3.64
Socket strips with power measurement readout on local
display
쮿 Socket strips with Schuko or IEC 60320-C13 sockets
쮿 Integrated measurement and display via local display unit
Delivery comprises
00711014
3
2
1
P
kW
Hz
dta44118
dta44115
V
4
5
A
6
Item
1
Qty
1
2
3
4
2
1
5
7
2
1
Order Information
Height Length
U
mm
1
kWh
7
00711050
1: Phase indication (P1) - shows measured phase values
2: Frequency (Hz) - current mains frequency
3: Power measurement (kW) - actual power being consumed by consumers
taking phase shift into consideration (power consumption of connected devices)
4: Mains voltage (V) - current voltage of mains to which the measurement unit is
currently connected
5: Phase angle (°) - phase shift in the mains supply
6: Current (A) - current now being drawn by the connected devices
7: Kilowatt-hours (kWh) - energy meter to record the energy consumption of the
connected equipment
Description
Al extrusion, 1 U, anodised, to accept the sockets and
display
Sockets, PA, for type and quantity see Order information
User manual
1
Measure- Depth Number of outputs
ments
mm
7 x SCHUKO,
I, V, P, f,
"German 3-wire",
19" 438.5
44
cos phi
earthed/grounded
I, V, P, f,
44
8 x IEC C13
19" 438.5
cos phi
Accessories
Part no.
60110-294
60110-296
Part no./05
Part no./35
20110-068
23130-010
00704051
3.65
19" power distributor , 3-phase
Main Catalogue
쮿 3-phase distributor for connecting to single-phase consumers
or socket strips
쮿 Output via IEC 60320-C19 sockets
00708033
Item
1
Qty
1
2
6/9
3
6/9
4
2
Description
19" power distributor, 3 U, St, 1.5 mm, RAL 7021,
with cable fitting M32, plastic, white
Socket inserts IEC 60320-C19, with plug retaining clip,
Overcurrent protection switch, 16 A, quantity see Order
information
Handle, Al, black, incl. assembly kit (supplied loose)
Order Information
00708035
Overcurrent protection switch (per phase and output socket)
Height Width
mm
mm
Depth
mm
131
484
250
131
484
250
Output
Input
6 (2 × 230 VAC
per phase)
9 (3 × 230 VAC
per phase)
3 × 32 A (400
VAC)
3 × 63 A (400
VAC)
Rear: Plug retaining clip and cable fitting
00708034
Accessories
Mains cable, IEC 60320 C20 plug, Wieland® socket to
connect 19" power distributor to Wieland®sockets
length 1 m, 1 piece
length 1 m, 1 piece
length 5 m, 1 piece
Part no.
60110-365
60110-366
Part no./05
Part no./35
60110-326
60110-327
60110-328
Note
쮿 SCHUKO socket strip see page 3.67
쮿 UTE socket strip see page 3.68
쮿 IEC socket strip see page 3.69
Mains cable for Wieland® socket strips
00708041
3.66
SCHUKO socket strip with
Wieland® input
Main Catalogue
쮿 Input via Wieland® GST 18 plug
쮿 Output via SCHUKO sockets
쮿 Versions with or without overcurrent protection
쮿 Sockets in white, black or red
00708044
DTA44115
Delivery comprises
Item
1
Qty
1
2
6/8
3
4
5
2
1
2
00708037
Description
Al extrusion, 1 U, anodised, length 438.5 mm,
depth 44 mm, height 44.45; to accept the sockets
Sockets (rotated 35°, polyamide), quantity and colour
Wieland connecting socket® GST 18
Note
쮿 Please order bracket for vertical mounting seperately
쮿 Mains connection cables, see page 3.70
쮿 19" power distributor for connection of multiple socket strips,
see page 3.66
00704051
Order Information
Description
SCHUKO, white, Wieland®,with over-current protection switch
SCHUKO, black, Wieland®,with over-current protection switch
SCHUKO, red, Wieland®,with over-current protection switch
Sockets Length
Inch
6
19"
6
19"
6
19"
8
19"
8
19"
8
19"
Length
mm
438.5
438.5
438.5
438.5
438.5
438.5
Depth
mm
44
44
44
44
44
44
Functional element
60110-352
60110-353
60110-354
60110-343
60110-344
60110-345
Part no./05
Part no./35
Accessories
PU 2 pieces
Part no.
20110-068
23130-010
3.67
UTE socket strip with Wieland®
connection
Main Catalogue
쮿 Output via UTE sockets
(in 90° increments) during fitting
00708045
DTA44116
Delivery comprises
Item
1
Qty
1
2
6/8
3
4
5
2
1
2
00708048
Description
Socket inserts (rotated 35°, polyamide), quantity and
colour see Order information
Note
separately
쮿 Mains connection cables see page 3.70
쮿 19" power distributor to connect multiple socket strips see
page 3.66
00704051
Order Information
Description
Sockets
UTE, white, Wieland®, with over-current protection switch
UTE, black, Wieland ®, with over-current protection switch
UTE, red, Wieland®, with over-current protection switch
UTE, red, Wieland®
6
6
6
8
8
8
Length
Inch
19"
19"
19"
19"
19"
19"
Length
mm
438.5
438.5
438.5
438.5
438.5
438.5
Depth
mm
44
44
44
44
44
44
Functional element
60110-355
60110-356
60110-357
60110-346
60110-347
60110-348
Part no./05
Part no./35
Accessories
PU 2 pieces
3.68
Part no.
20110-068
23130-010
IEC socket strip with Wieland®
connection
Main Catalogue
쮿 Input via Wieland®GST 18 plug
쮿 Output via IEC 60320 C-13 sockets
쮿 Socket inserts in white, black or red
00708046
dta44118
Delivery comprises
00708036
Item
1
Qty
1
2
6/12
3
4
5
2
1
2
Description
Sockets (rotated 35°, polyamide), quantity and colour see
Order information
Note
separately
page 3.66
00708049
00704051
Order Information
Description
Sockets
IEC, white, Wieland®, with over-current protection switch
IEC, black, Wieland® , with over-current protection switch
IEC, red, Wieland® , with over-current protection switch
IEC, red, Wieland®
6
6
6
12
12
12
Length
Inch
19"
19"
19"
19"
19"
19"
Length
mm
438.5
438.5
438.5
438.5
438.5
438.5
Depth
mm
44
44
44
44
44
44
Functional element
60110-349
60110-350
60110-351
60110-340
60110-341
60110-342
Part no./05
Part no./35
Accessories
Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces
Mains cable, IEC for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 0.5 m, 1 piece
Mains cable, IEC for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 1 m, 1 piece
Part no.
20110-068
23130-010
60110-362
60110-360
60110-361
3.69
Connecting cables for Wieland® socket strips
Main Catalogue
쮿 Enables simple connection to current supply (e.g. for socket
strips)
쮿 Different connecting plugs
쮿 Different cable lengths available
Delivery comprises
Pos.
1
Menge Beschreibung
1
Connecting cable, 1.5 mm2, black, input, output and
cable lengths see Order information
Order Information
00708031
Input
Open end
Open end
Open end
IEC 60309
IEC 60309
IEC 60309
IEC 60320 C20
IEC 60320 C20
IEC 60320 C20
SCHUKO
(German 3-wire
earthed) / UTE
SCHUKO
(German 3-wire
earthed) / UTE
BS plug
BS plug
Current
A
16
16
16
16
16
16
16
16
16
Output
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Wieland® GST 18
Length
m
1
2.5
5
1
2.5
5
1
2.5
5
Part no.
16
Wieland® GST 18
1
60110-329
16
Wieland® GST 18
2.5
60110-330
13
13
Wieland® GST 18
Wieland® GST 18
1
2.5
60110-331
60110-320
60110-321
60110-322
60110-323
60110-324
60110-325
60110-326
60110-327
60110-328
60110-332
Note
쮿 Other inputs, outputs and cable lengths available on request
3.70
Three phase power distribution with 19" power distributor and
socket strips with Wieland® connection
2
4
쮿 Modular construction
1
6
쮿 Connection of 19" power distributor (3-phase) in cabinet
requires an electrician
쮿 Simple cabling of socket strips with plug-and-play functionality
Cabling example
Item
1
2
3
4
5
6
3
5
6
Description
3-phase current connecting cable
Socket strips with Wieland® connection, red
Socket strips with Wieland® connection, black
Mains cable, from 19" power distributor to socket strip
Mains cable, from socket strip to consumer (e.g. server)
3
01008070
configuration
Simple. Fast. For the product you want.
Components can be varied and combined freely
쮿 Configuration
– Various constructions (lengths)
– Various sockets
– Various mains connector cables
– Single and multi-phase
– Combinations of functions (interference suppression filters,
residual current circuit breakers, overcurrent protection,
transient protection)
쮿 Online configuration: www.schroff.co.uk/configuration
solution
Simple. Fast. From one source.
Integration and customised developments
쮿 Integration in cabinet incl. cabling and function test
쮿 Customised solutions
3.71
P ower Control socket stri ps
Cabinet Accessories – Power Control socket strips
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
00711001
Front panels,
Display
00715001
Interfaces
00711009
Power supply
Backplanes . . . 10
Connectors, front
panel component
00708013
Telemonitoring and parametrisation with web-based
user interface
Event logging
00708014
P ower Control socket stri ps ServiceP LUSMain CatalogP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days
3.72
SCHROFF PRODUCT CATALOG E 06/2017
Overview . . . .
3.72
Power Control s ocket stripsMain Catalog
Power Management
쮿 Monitoring of power, current and voltage of the entire
socket strip or for each separate socket insert
쮿 Telemonitoring and local indication via display
쮿 Remote control of individual inserts (switch on/off)
쮿 Programmable sequential switch-on/off of individual inserts
쮿 Individual user access authorisations for each socket insert
Multimeter
쮿 Measurement of current, voltage, apparent power, true power
and power factor per phase or outlet
Multimeter . . . . . .
3.74
쮿 Data sent to network or shown on local display
00715002
Telemonitored socket strips
Telemonitored
(per phase)
socket strips . . .
3.75
쮿 Measurement at phase level and switch function on request
Telemonitored and remote-controlled socket strips
and energy consumption at outlet level
Remotecontrolled
socket strips,
telemonitored
on each phase . .
3.76
쮿 Remote-controlled switch-on/off of individual outputs
00715006
Environmental sensors
Remotecontrolled
socket strips,
telemonitored
on each outlet . . .
3.77
page 3.49
Power
management
software . . . . . . . . 3.78
00715007
ServicePLUS from page 3.79
ServicePLUS . .
3.79
e.g. individual configuration (dimensions,
socket inserts, mains supply)
30407004
3.73
Telemonitored multimeter
Power C ontrol socket stripsMain C atalogPart number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days
쮿 Inline meter, 1 U, 19" case with 19" mounting brackets
쮿 Measures current, voltage and power (apparent and true
power) per phase and total
쮿 Local display of current and voltage per phase and sum values
쮿 Ethernet interface and web interface
쮿 4 consumers or socket strips can be connected; input via
IEC 60320 C20 plug; outlet via IEC 60320 C19 sockets
쮿 Mains input via C13 socket conforming to IEC 60320
Front view
00715002
쮿 To record temperature, humidity etc, environmental sensors
can be connected
Delivery includes
Rear view
00715003
Item
1
Qty
1
2
3
4
1
2
1
Description
Case, black, width 440.0 mm, display and control keys,
interfaces on front and rear
Mains cable, C13 socket to IEC 60320, cable length 1.5 m
19" mounting bracket, length 305 mm, St, 1 mm, black
Cable support rail
Order Information
Height
Width
Depth
Input
U
mm
mm
1
440.0
183
4 × IEC C20
Accessories
Temperature sensor Cable length 3 m, 1 piece
Temperature/
humidity combi sensor Cable length 3 m, 1 piece
Two temperature/
humidity combi sensors Cable length 2 x 3 m, 2 pieces
Dual potential-free contact sensor Cable length x m, 1 piece
Two temperature sensors and one temperature/
humidity combi sensor Cable length 3 x 3 m, 1 piece
Differential pressure and temperature sensor Cable length 3 m, 1 piece
Airflow sensor Cable length 3 m, 1 piece
Hub to accept 4 sensors connecting cable 1 m, assembly kit, 1 piece
Number of outputs
4 × IEC C19
Output current
A
16
Part no.
60110-446
60110-313
60110-314
60110-315
DPX-CC2-TR
DPX-T3H1
DPX-T1DP1
DPX-AF1
60110-316
Note
쮿 3-phase version on request
쮿 User manual and current firmware is available for
download: Please enter order number at www.schroff.biz/
oneclick/
쮿 For power management software see page 3.78
쮿 Suitable socket strips see Socket Strips chapter, page 3.58
page 3.48
쮿 19" assembly kit, see page 3.17
3.74
Telemonitored (per phase) socket strips
Main Catalog
쮿 Measurement of current, voltage and power (apparent and true
power) per phase and sum value
쮿 Outlets to IEC 60320 with C13 sockets (230 VAC, 10 A) and
C19 sockets (230 VAC, 16 A)
쮿 Mains supply 230 VAC/400 VAC, 16 A or 32 A plug, cable length
3m
쮿 With magnetic circuit breakers to UL 489 (for 32 A version)
can be connected
Delivery includes
Item
1
Qty
1
2
3
1
1
00711001
Display, interface
Description
Socket strip, black, with interfaces, socket inserts and
display, mains cable length 3 m
User manual
00711009
Order Information
Length
Height
Depth
Input
mm
Inch
mm
mm
440
19"
44
133.0
230 VAC, 16 A, 1-phase, IEC 60320 C20
1298
52
43.0
1539
52
53.0
230 VAC, 32 A, 1-phase, IEC 60309
1780
55
52
400 VAC, 32 A, 3-phase, IEC 60309
Accessories
Temperature/
Two temperature/
Number of outputs
8 x IEC C13
24 x IEC C13
20 x IEC C13, 4 x IEC C19
24 x IEC C13, 12 x IEC C19
Part no.
60110-306
60110-307
60110-308
60110-455
60110-313
60110-314
60110-315
DPX-CC2-TR
DPX-T3H1
DPX-T1DP1
DPX-AF1
60110-316
Note
쮿 Versions with additional switching function on request
쮿 Interface description, user manual, current firmware: To
download please enter part number at www.schroff.biz/
oneclick/
airflow...) and hub for connecting multiple sensors see from
page 3.48
3.75
Remote-controlled socket strips, telemonitored on each
phase
쮿 Remote-controlled on/off switching of connected consumers
쮿 Mains supply 230 VAC/ 400 VAC, 16 A or 32 A plug, cable length 3
m
can be connected
Delivery includes
00711001
Display, interface
Item
1
Qty
1
2
3
1
1
Description
User manual
00711009
Order Information
Length
Height
Depth
Input
mm
Inch
mm
mm
440
19"
44
133
1297
52
65
1539
52
65
1780
52
65
Accessories
Temperature/
Two temperature/
Number of outputs
Part no.
8 x IEC C13
24 x IEC C13
60110-447
60110-449
60110-448
60110-450
60110-313
60110-314
60110-315
DPX-CC2-TR
DPX-T3H1
DPX-T1DP1
DPX-AF1
60110-316
Note
oneclick/
page 3.48
3.76
outlet
Power C ontrol soc ket stripsMain C atalogPart number in bold face type: ready for shipping within 2 working daysP art number in normal type: ready for s hippi ng withi n 1 0 worki ng days
power) per outlet, phase and total
쮿 Local display of current and voltage per outlet, phase and total
쮿 Mains input 230 VAC, 32 A plug to IEC 60309, cable length 3 m
can be connected
Delivery includes
Item
1
Qty
1
2
3
1
1
00715009
Description
User manual
Order Information
Length
Height
Depth
Input
mm
Inch
mm
mm
440
19"
44
183
230 VAC, 16 A, 1
1539
52
65
230 VAC 32 A, 1-phase, IEC 60309
1539
52
65
1539
52
65
Accessories
Temperature/
Two temperature/
Number of outputs
8 x IEC C13
20 x IEC C13
21 x IEC C13, 3 x IEC C19
Part no.
60110-442
60110-443
60110-444
60110-445
60110-313
60110-314
60110-315
DPX-CC2-TR
DPX-T3H1
DPX-T1DP1
DPX-AF1
60110-316
Note
쮿 Differential current measurement available on request
oneclick/
page 3.48
3.77
Power management software
Energy management with Power IQ®
쮿 Centralised administration with mass configuration, firmware
administration and designation of outputs
Main Catalog
1
LA
N
2
4
쮿 Create energy, cost and active current reports at levels from
individual plugs or IT devices through to the entire data centre
7
쮿 Export graphical data
쮿 Aggregate data from different manufacturers
3
Order Information
Description
6
Part no.
on request
8
9
5
01009050
Cabling example
Item
1
2
3
4
5
6
7
8
9
3.78
Description
Real-time monitoring of web graphical user interface (GUI)
Existing customer server or an optionally available hardware system on
which the software is installed
Telemonitored and remote-controlled socket strip, available with IEC C13
and C19 socket inserts
Linking of items 1, 2 and 3 to LAN
CEE power connection cable available with 230 VAC (16 A or 32 A) or 400 VAC
(16 A and 32 A) supply
Local display
Telemonitored environmental sensors
Connection of sensors to socket strip
Cabinet Accessories – Power Control socket strips ServicePLUS
configuration
쮿 Configuration options
– Various constructions (height, length)
– Various mains supply cables
– Single phase and multiphase
쮿 Measurement at phase level and switch functions
solution
Integration and custom developments
쮿 Cabinet integration, complete construction incl. cabling and
function test
쮿 Customised solutions, e.g. software modifications
Power C ontrol soc ket strips ServicePLUS
3.79
Main Catalogue
Climate control – Overview
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
19" fans
쮿 Pusher fans
쮿 Circulation fans
쮿 Cooling capacity up to 2000 W
Climate control . 4
Electronics
Air filtered fans
Subracks/
쮿 Simple to fit - just clips in
쮿 Protection type up to IP 55
쮿 Airflow volume up to 770 m3/h
Front panels,
Power supply
Accessories
Backplanes . . . 10
쮿
쮿
쮿
쮿
Heaters
Speed control
Thermostats
Hygrostats
Connectors, front
panel component
36108005 (01192002, 01192009, 01194003, 01108012 00902001 00908001)
4.0
SCHROFF Further information: www.varistar.de E 05/2016
Overview . . . . . . 4.0
Cooling
concepts . . . . . . . . 4.2
Air/water heat exchangers
쮿 Complete cabinet solutions
쮿 For industry and data centers
쮿 Cooling capacities up to 40 kW
19" fan trays . . . 4.4
Air filtered
fans . . . . . . . . . . . . 4.20
Accessories
Heaters . . . . . . . . . .
Fans . . . . . . . . . . . .
Speed control . . . .
Thermostats . . . . .
Hygrostats . . . . . . .
4.56
4.59
4.60
4.61
4.64
Air/water heat
exchangers . . . . 1.224
36108006 (01108004 01108002 01102004 00505033 01008020 01006040)
4.1
Climate control – Service
Products / cooling concepts
Text
Product
Closed cabinet
Raised cover,
ventilation slots
Perforated doors
19" circulation fan,
top cover fan
Cooling principle
01105060
Description
Type of protection
Noise level approx.
Environmental conditions
Cooling capacity approx. 1)
01105058
01105056
01105057
Natural convection
through thermal radiation
Free convection
through top opening
Free convection
through openings
in doors/rear panels
Cooling with air
≤ IP 55
Ti > Ta
< 500 W
≤ IP 20
Ti > Ta
500 W ... 800 W
≤ IP 20
55 ... 65 dB(A)
Ti > Ta
500 W ... 6000 W 2)
≤ IP 20
34 ... 67 dB(A)
Ti > Ta
< 2000 W
1) depending on cabinet size, electronic components, location and room cooling concept
2) > 800 W are only possible with own, active cooling through components like servers, etc.
Ti = cabinet inner temperature Ta = cabinet ambient temperature
Thermal simulation
ServiceMA IN CATALOG
Project support through state-of-the-art simulation technology
As the packing density and integration density of components
increases, the transport of waste heat rapidly becomes more
difficult. Analyzing heat transport through thermal paste, flow and
heat radiation makes it possible to identify hot spots as early as the
design phase. We use state-of-the-art numerical analyses and
simulation methods to accomplish this. This allows the analysis
and optimization of cooling concepts for anything from an
assembly to an entire cabinet system at the preliminary stage.
Our cooling specialists would be happy to assist you in finding the
right cooling concept for your project
Your advantage:
쮿 Analyzing in detail to eliminate thermal problems at the
preliminary stage
쮿 Ensuring the high efficiency and reliability of your systems
쮿 Reducing the number of expensive prototypes and tests
쮿 Reducing expenses and development costs
01103050
4.2
Products/cooling concepts
Text
Product
Air filtered fans
Air conditioners
Air/water heat exchanger Air/water heat exchanger
(LHX 3)
(LHX 20/40)
Cooling principle
01102050
Description
Type of protection
Noise level
01105061
01007055
01005081
Cooling
with
air
Cooling
with
coolant
Cooling
with
water
Cooling
with
water
≤ IP 55
39 ... 71 dB(A)
Ti > Ta
< 1500 W
≥ IP 55
60 ... 81 dB(A)
Ta ≤ 55 °C
< 17000 W
≥ IP 55
45.2 dB(A)
Ta ≤ 70 °C
< 3000 W
≥ IP 55
50 ... 70 dB(A)
Ta ≤ 70 °C
< 40000 W
Servic e
Optimal test equipment
Servic eMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
Being part of the Pentair group, Schroff and McLean look back on
50 years of experience and are reknown around the world for their
expertise in efficient cooling of industrial facilities and equipment.
Based on our own laboratory test chambers with the most modern
equipement in Europe, America and Asia:
쮿 Walk-in climate chamber to test and optimize completely
integrated cabinets and systems under different conditions
쮿 Smaller climate chambers to test components
쮿 Airflow and air resistance measurements in a wind tunnel
쮿 Noise level measurements
쮿 Tests in accordance with DIN EN 60529 to determine the
type of protection (IP)
Climate bay testing
schroff.pentair.com/en/schroff-na
01112001
Outstanding standard products, flexible custom solutions, global
technical support and service add up to a ’cool’ combination!
4.3
1 9" fan traysMain Catalogue
Climate control – 19" fan trays
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
01102012
Standards/Approvals
Subracks/
쮿 Mechanical protection to DIN EN ISO 13857
Contact protection to DIN EN ISO 13857
Electrical safety to EN 60335 part 1
Plastics self-extinguishing to UL 94 V0
쮿 19" assembly area in accordance with:
IEC 60297-3-101
Airflow
Front panels,
Vertical airflow
(continual warming)
Diverted airflow
(effective cooling)
Power supply
Backplanes . . . 10
01109055
With vertical airflow the air becomes steadily warmer
as it rises through the cabinet.
Connectors, front
panel component
01109054
By using the 1 U airflow element, air is introduced from
the front and extracted to the rear. Now all subassemblies receive the same cooling air.
4.4
Overview . . . . . . 4.4
19 " fan traysMain Catalogue
19" fan trays
쮿 To cool single components and assemblies in 19" cabinets
쮿 High airflow rate for directed heat removal
쮿 With axial or radial fans
쮿 For voltages 230 VAC, 115 VAC or 24 VDC
쮿 CE- approvals
19" fans
19" fans
쮿 19" circulation fan, height 1 U
1 U with/without
front switch . . . . . . 4.6
쮿 230 VAC, 115 VAC and 24 VDC
1 U speedcontrolled and
monitored . . . . . . . 4.8
쮿 Up to 1000 m3/h
쮿 With/without mains switch or with temperature-dependent
speed control
01109002
19" pusher fans
19" blower units
쮿 Tangential fan, height 2 U
Pusher fan, 2 U
with tangential
blower . . . . . . . . . . 4.9
쮿 230 VAC and 115 VAC
쮿 Up to 320 m3/h
01192009
쮿 19" pusher fan, height 2 U
Pressure fan, 2 U,
(160, 220 mm
deep) . . . . . . . . . . . . 4.10
쮿 Up to 530 m3/h
01194005
쮿 19" pusher fan, height 3 U
Pusher fan, 3 U. . . 4.12
쮿 Up to 570 m3/h
ServicePLUS
configuration . . . . 4.14
쮿 Variable air outlet with/without pipe connection, upward or to
rear
Accessories
01102017
19" airflow
element . . . . . . . . . 4.15
AC fans . . . . . . . . . . 4.16
ServicePLUS from page 4.19
DC fans . . . . . . . . . . 4.16
e.g. other airflow capacities
e.g. supply voltages
e.g. other dimensions
e.g. custom solutions
ServicePLUS . . . 4.19
30407004
4.5
19" fan 1 U
19" fan traysMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days
쮿 Mechanical strain relief for mains cables
쮿 Can be adapted to subracks
쮿 Contact protection in accordance with DIN EN ISO 13857
Delivery comprises (ready to connect)
01194002
Item
1
Qty
1
2
3a
3/6
1
b3
1
Description
19" circulation fan, 1 U,
cover/base plate, St, 1 mm, finish AlZn, with perforation;
front panel 1 U, AI, 3 mm, anodised
Fan, see Order Information
AC with IEC connector (mains input IEC 60320),
incl. safety clamp for mechanical strain relief
DC version with connecting cable, cable length 2.5 m
43,5
Order Information
436
137
81
24 VDC
Part no.
115 VAC
Part no.
230 VAC
Part no.
10713-103
10713-102
10713-100
10713-107
10713-106
10713-104
20713-240
20713-244
20713-243
85
193
137
330
KTA44857
KTA44858
Replacement fan 1 piece
483
KTA44306
Side panel connecting bracket between europacPRO
subrack and fan, including fixing material kit, PU 4 pieces
Equipment cable SCHUKO/UTE SCHUKO/UTE plug,
IEC 60320 C13 socket, 2.5 m, 1 piece
Equipment cable, BS British Standard plug,
Equipment cable, USA USA plug,
IEC 60320 socket, 2 m, 1 piece
21101-954
60103-131
60103-137
60103-141
ServicePLUS see page 4.19
Technical data
Voltage
Frequency in Hz
Number of fans
Airflow volume in m3/h (3/6 fans)
Noise level in dB(A) (3/6 fans)
Power consumption in W (3/6 fans)
Max. stat. pressure in Pa
Permissible ambient temperature in °C
Lifespan in h L1040 °C
Lifespan in h L1055 °C
230 VAC
50
440/845
56.5/59.4
45/90
73
60
3/6
520/1000
60.2/62.9
42/84
88
115 VAC
50
60
3/6
440/845
520/1000
56.5/59.4
60.2/62.9
46.5/93
43.5/87
73
88
–40 ... +70 °C
43500
20000
24 VCDC
3/6
506/970
60.5/63.3
24/48
68
Note
쮿 Fan dimensioning see page 4.18
쮿 Replacement fans see chapter Climate control - Accessories
쮿 Versions with multiple fans see ServicePLUS configuration
page 4.14
4.6
19" fan 1 U with front switch
19" fan trays
쮿 Front-mounted illuminated mains switch on AC devices,
coupled with additional rear mains outlet; mechanical strain
relief for mains input and mains output cables
01194003
Item
1
Qty
1
2
3a
3/6
1
b3
1
Description
19" circulation fan, 1 U, top/base plate, St, 1 mm,
AC version with mains switch, illuminated green;
plug (mains input IEC 60320) incl. safety clamp for
mechanical strain relief;
coupled mains output socket (IEC 60320)
DC version with mains switch and connecting cable,
cable length 2.5 m
Order Information
01197002
24 VDC
Part no.
115 VAC
Part no.
230 VAC
Part no.
10713-111
10713-110
10713-108
10713-115
10713-114
10713-112
20713-240
20713-244
20713-243
43,5
KTA44857
436
137
81
KTA44858
85
193
137
330
483
KTA45963
Mains cable, IEC IEC 60320 C14 plug,
21101-954
60103-131
60103-137
60103-141
60197-053
Technical data
Voltage
Frequency in Hz
Number of fans
230 VAC
50
440/845
56.5/59.4
45/90
73
60
3/6
520/1000
60.2/62.9
42/84
88
115 VAC
50
60
3/6
440/845
520/1000
56.5/59.4
60.2/62.9
46.5/93
43.5/87
73
88
–40 ... +70 °C
43500
20000
24 VDC
3/6
506/970
60.5/63.3
24/48
68
쮿 Fan dimensioning, see page 4.18
쮿 Replacement fans, see chapter Climate control - Accessories
page 4.14
4.7
19" fan 1 U, with
speed control and function monitoring
19" fan trays
쮿 Low noise through temperature dependent airflow volume
쮿 Range selectable: 20 ... 40 °C and 30 ... 50 °C
쮿 External sensor, at sensor breakage max speed will be set
automatically
쮿 Function control with LEDs and via potential-free contact
쮿 2 versions, 24 VDC or 230 VAC
Delivery comprises (ready for connection)
Qty
1
2
3
4
3/6
1
1
Description
19" circulation fan, 1 U; cover/base plate, St, 1 mm,
finish Al-Zn, with perforation front panel 1 U, AI, 3 mm,
anodised
DC fan, see Order information
Connecting cable, length 2.5 m, open-ended
Temperature sensor for speed control, NTC resistor,
cable length 1.5 m
01198001
43,5
Photo shows 19" fan unit with 3 fans, without switch
Item
1
436
137
Order Information
81
D1
137
D2
D
24 VDC
Without switch D
230 VAC
With switch
Without switch
mm
Part No.
mm
Part No.
Part No.
193
10713-099
250
19713-121
330
10713-098
397
19713-006
85
D1
KTA44857
D2
483
KTA44858
01107050
Airflow capacity with one fan
[m³/h]
200
180
160
140
120
100
80
60
40
Accessories
Filter mat, class G 2 for 3 fans, PU 3 pieces
Filter mat, class G 2 for 6 fans, PU 3 pieces
60713-169
60713-170
Technical data
10
40
50
60 [°C]
01112050
Monitoring signal
Voltage AC version (fans 24 VDC)
Voltage DC version
Number of fans
Max. airflow volume in m3/h
Permissible ambient temperature °C
Life in h L1040 °C
86 ... 260 VAC
24 VDC (21 ... 27)
3
6
467
895
63.5
66.4
70
70
15.9
31.8 W
–20 ... +65 °C
70000
Technical data Regulation/monitoring
Control range
Sensor
Sensor
connector
Signal at
kta43400
n = rotating speed, S = signal, nA = speed threshold value "Alarm"
Signalling
Changeover switch between 20 ... 40 °C and 30 ... 50 °C
External NTC resistor, cable length 1.5 m
Rear-mounted plug contact, max. rotation speed in case
of sensor breakage
Speed < 30 % nominal speed; switch-on delay < 4 s, signal
delay < 1 s (see monitoring signal)
Display via LEDs; potential-free contact (changeover),
switching capacity 5 W, max. switching voltage 170 V,
open collector on request
4.8
Pusher fan, 2 U, with tangential fan
19" fan trays
쮿 High airflow volume
쮿 Integrated filter mat
쮿 2 versions:
- LE1: 19" bolt-on dimension, fan unit is wider than 19"
- LE2: 19" reduced width, for easy assembly
01192009
Item
1
Qty
1
2
3
1
1
Description
Blower unit 2 U, with grille, PA 6.6, UL 94 V-0,
front grille 2 U, PPO, UL 94 V-0;
filter mat, synthetic fibre, filter class G 2
Fan
Terminal block
Order Information
Description
A3532
LE1: Pusher fan 2 U, tangential blower
LE2: Pusher fan 2 U, tangential blower
Spare filter mat PU 10 pieces
115 VAC
Part no.
230 VAC
Part no.
60713-003
60713-001
60713-004
60713-002
20705-008
Dimensions
Voltage
Frequency in Hz
Lifespan in h
115 VAC
230 VAC
50
60
50
60
320
330
320
330
59
62
59
62
65
70
65
70
30
40
37
46
–20 ... +65 °C
30000
Note
쮿 24 VDCon request
01103056
4.9
19" pusher fan 2 U
(depth 160 mm or 220 mm)
19" fan trays
쮿 Integrated air deflector prevents heat buildup in the assemblies
mounted below
쮿 Optionally with rear additional fan, 2 U, for active cooling of
assemblies beneath the pusher fan
01194005
Item
1
Qty
1
2
3a
3
1
3b
1
3c
1
Description
19" pusher fan 2 U, case, St, 1 mm, finish AI-Zn;
front grille 2 U, PPO, UL 94 V-0 Filter mat, synthetic fibre,
filter class G 2
Fan
AC-version with plug (mains input, IEC 60320), incl. safety
clamp, mechanical strain relief for mains input cable;
socket to connect an optional supplementary fan
Wide AC input range with DC fans, version as 3 a,
additionally speed-controlled and monitored
Note
쮿 Supplementary fan for AC version see page 4.11
01103054A3527V
Order Information
Description
Front panel Al, anodised
86 ... 260 VAC (fan 24 VDC)
515 m3/h
Part no.
24 VDC
515 m3/h
Part no.
Front panel, plastic, black
115 VAC
115 VAC
230 VAC
230 VAC
300/330 m 3/h 445/530 m3/h 300/330 m3/h 445/530 m 3/h
Part no.
Part no.
Part no.
Part no.
For board depth 160 mm
19713-540
10713-537
10713-520
10713-536
For board depth 220 mm
10713-529
Replacement fan piece
20713-240
20713-240
20713-147
20713-244
Equipment cable SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece
Equipment cable BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece
Equipment cable USA USA plug, IEC 60320 socket, 2 m, 1 piece
Side panel connecting bracket between europac subrack, including fixing material kit
Side panel connecting bracket between europacPRO subrack and fan, including fixing material kit, PU 4 pieces
Spare filter mat PU 3 pieces
10713-518
10713-534
20700-001
10713-526
20713-243
60103-131
60103-137
60103-141
21101-104
21101-954
60713-501
Technical data with 3 fans
Voltage
Frequency in MHz
Life in h, 1) at 40 °C, 2) at 55 °C
4.10
24 VDC
515
59.8
68
24
–20 ... +70 °C
20000 2)
24 VDC
115 VAC
230 VAC
515
59.8
68
24
–20 ... +70 °C
20000 2)
50
300
52.2
41
42
50
300
52.2
41
42
60
50
60
330
445
530
56.1
55.2
58.2
41
78
88
33
46.5
43.5
–40 ... +70 °C
50000 1)
200002)
60
50
60
330
445
530
56.1
55.2
58.5
41
78
88
33
45
42
–40 ... +70 °C
50000 1)
20000 2)
Supplementary fans with housing
for pusher fan 2 U
19" fan trays
쮿 Extra 2 U useable space:
By using a built-on fan, components mounted below the
19" pusher fan can be cooled
쮿 No additional voltage supply necessary: connection is via
19" pusher fan, 2 U
Delivery comprises (ready to fit and connect)
01194006
Item
1
2
3
Qty
1
4
1
Description
Housing with grille, St, 1 mm, finish AIZn
Fan
Cable with plug (electrical connection via socket on
19" blower fan); safety clamp (mechanical strain relief
for mains input cable)
Order Information
Description
Supplementary fans with housing for
pusher fan 2 U
115 VAC
Part no.
230 VAC
Part no.
10713-532
10713-530
KTA44447
Voltage
Frequency in MHz
Life in h at 55 °C
115 VAC
50
60
130
155
51
54
44
62
-40 ... +70
30
24
20000
230 VAC
50
60
130
155
51
54
44
62
-40 ... +70
27
21
20000
Note
쮿 24 VDC version available on request
01103055
4.11
19" pusher fan 3 U
19" fan trays
With cover plates, this pusher fan can be re-fitted to different
cooling concepts
쮿 Ventilation directed accurately to the electronics
쮿 Air infeed from front, air exits at the top rear of cabinet (guided
upwards by cover plates or via hoses to rear and upwards)
Item
1
Qty
1
2
3
1
1
01102017
Description
Case, St, 1 mm, AIZn; perforated hinged front panel, Al,
2.5 mm; filter mat, synthetic fibre, filter class G 2 in
accordance with DIN EN 779
Radial fan with mains fuse
Plug (mains input, IEC 60320); safety clamp, mechanical
Order Information
Description
115 VAC
Part no.
230 VAC
Part no.
19" pusher fan 3 U
10713-547
Accessories
Equipment cable, BS British Standard plug, IEC 60320 C13
10713-546
60103-131
60103-137
60103-141
21101-958
21101-954
60713-868
Technical data
01103052
Voltage
Frequency in MHz
Noise level per fan in dB(A)
Max. ambient temperatures in °C
Life in h at 55 °C
115 VAC
50
60
510
570
62
64
320
410
55
65
-20 ... +50
20000
230 VAC
50
60
510
570
62
64
320
410
58
75
-20 ... +50
20000
Note
쮿 Wide input voltage range 90 V ... 260 VAC available on request
쮿 Temperature control and function monitoring (alarm via
RS 232) on request
쮿 Air deflector plates for other cooling concepts see page 4.13
4.12
Air deflector plate for 19" pusher fan 3 U
19" fan trays
쮿 For 19" pusher fan 3 U
Order Information
Item
7
8
9
10
Description
Air deflector plate to front, St, 1 mm,
finish AlZn
Air outlet to rear: upper cover plate,
without perforation, 1 mm, finish AlZn
Air deflector plate with hose connection
on upper rear, external diameter 80 mm,
to rear, external diameter 80 mm, St, 1
mm, finish AlZn
Qty/PU
Part no.
1
20713-504
1
20713-505
1
20713-503
1
20713-502
01103053
Connecting cable with connector socket
19" fan trays
쮿 Connecting cable with connector for AC fans (25 mm and
38 mm height) and DC fans (38 mm height), cable length 1 m
Delivery comprises
Item
1
KTA43091
Qty
1
Description
Cable, PVC (2 x 0.75 mm²), 1 m long, with 2 FASTON
connectors 2.8 x 0.5 mm, DIN 46343 T1
Order Information
Description
Connecting cable with plug
Part no.
21101-246
4.13
ServicePLUS: Configuration with assembly
19" fan trays
쮿 You can plan and build up your product yourself using the order
information table below
쮿 Dimensions of fan trays
– Height 1 U
– Width 19"
– Depth 193, 300, 467, 604 mm
for 3, 6, 9 or 12 fans
쮿 Create your 19" fan trays from individual parts (assembled
within 10 working days)
Example configuration
Qty
1
1
1
6
01102012
Description
Housing, 1 piece
Front panel with switch, AC, 1 piece
Filter mat, 1 piece
Fan, AC, height 25 mm;
mounted at position 1, 3, 5, 7, 9, 11
Order no.
20713-213
20713-231/05
60713-246/05
20700-001/05
Order Information
Fan height
a44537
Fan housing
1)
AC (230 V)
DC
AC (230 V)
DC
cover/base
plate, St, 1 mm,
finish AlZn,
with perforation
1 U, Al, 3 mm,
anodised;
includes cable
harness
1 U, Al, 3 mm,
anodised;
connecting
cable, 2.5 m;
includes cable
harness
1 U, Al, 3 mm,
anodised;
mains switch,
illuminated
green; includes
cable harness
1 U, Al, 3 mm,
anodised;
mains switch,
illuminated
green;
connecting
cable, 2.5 m;
includes cable
harness
can only be
fitted where fan
height is 25 mm
mm
Front panel without switch
Filter mat G 2
Fans
1 piece
1 piece
1 piece
1 piece
1 piece
PU 3 pieces
see page
25
20713-212
20713-220/
05
20713-224/
05
20713-228/
05
20713-236/
05
60713-243
4.16
38
20713-216
20713-220/
05
20713-224/
05
20713-228/
05
20713-236/
05
4.16
25
20713-213
20713-221/
05
20713-225/
05
20713-229/
05
20713-237/
05
60713-244
4.16
38
20713-217
20713-221/
05
20713-225/
05
20713-229/
05
20713-237/
05
4.16
25
20713-214
20713-222/
05
20713-226/
05
20713-230/
05
20713-238/
05
60713-245
4.16
38
20713-218
20713-222/
05
20713-226/
05
20713-230/
05
20713-238/
05
4.16
25
20713-215
20713-223/
05
20713-227/
05
20713-231/
05
20713-239/
05
60713-246
4.16
38
20713-219
20713-223/
05
20713-227/
05
20713-231/
05
20713-239/
05
4.16
KTA44857
KTA44858
kta44859
kta44860
1) Fan housing cannot be ordered without fans
Note
쮿 Unused fan mounting positions are covered with foam material
쮿 Versions for 115 V or with switch available on request
4.14
ELECTRONICS PROTECTION
1 U air deflector chassis for
19" fan trays
19" fan trays
쮿 Optimised cooling together with 19" fan trays
쮿 Vertical buildup of heat is avoided by means of improved airflow
쮿 Fitting options:
– One fan tray: cool air is drawn in from the front and guided
upwards
– Two fan trays: cool air is drawn in from the front, directed
upwards and guided to the rear (see application diagram)
쮿 Versions:
– With solid front panel to direct airflow
– With perforated front panel to allow air to flow in/out
쮿 Optional filter mat, simple to swap during operation
01109001
1 U air deflector chassis (bottom) with 1 U fan tray (top)
01109002
Delivery comprises (assembled)
Item
1
Qty
1
2
2
3a
1
3b
1
4
1
Description
Air deflector plate, St, 1 mm, finish Zincor,
width 432.8 mm (without side panel)
Side panel, St, 1.5 mm, finish Zincor; with 19" mounting
bracket, powder-coated (see Order information for
colour)
Front panel, perforated, St, 1.5 mm, finish Zincor,
powder-coated (see Order information for colour);
two quick-release fasteners, black
Front panel, solid, St, 1.5 mm, finish Zincor, powdercoated (see Order information for colour);
Assembly kit
Order Information
1 U air deflector chassis Depth Colour
for
mm
19" fan trays
Part no.
Front panel,
perforated
Part no.
Front panel,
solid
193
RAL 7035
for single-row fan trays
193
RAL 9005
(3 fans)
193
RAL 9006
330
RAL 7035
for double-row fan
330
RAL 9005
trays (6 fans)
330
RAL 9006
Accessories
10713-140
10713-142
10713-146
10713-148
10713-144
10713-150
10713-141
10713-143
10713-147
10713-149
10713-145
10713-151
60713-169
60713-331
01109051
Application: air deflector chassis mounted below 19" fan tray,
guides the cool air upwards from front; second air deflector
chassis at top guides the warm air to the rear
4.15
AC fans/replacement fans
19" fan trays
Delivery comprises
Item
1
Qty
1
Description
Fan (width 119 mm, depth 119 mm)
Order Information
Description
Height Airflow volume
mm
m3/h
Type A
25
84
Type B
25
108
Type C
38
162
Assembly kit for fan PU 1 kit
115 VAC
Part no.
230 VAC
Part no.
20713-146
20713-142
20713-147
20713-244
20700-001
20713-243
21102-013
Dimensions AC fans
01108005
Type
Frequency in Hz
Max. static pressure in Pa
Max. ambient temperature in °C
Dimensions: height in mm
(width 119 mm × depth 119 mm)
Type A
50 60
84 90
29 30
23 21
70 70
8
7
25
Type B
50 60
108 120
34 38
41 41
70 70
14 11
25
Type C
50 60
162 192
37 41
73 88
70 70
15 14
38
쮿 Please order connecting cable separately, see page 4.13
쮿 Please order protective grille separately, see page 4.17
DC fans/replacement fans
19" fan trays
Delivery comprises
Item
1a
1b
Qty
1
1
Description
Fan, height 38 mm, with plug connection
Fan, height 25.5 mm, connecting cable, length 55 mm,
connector with 2 x FASTON connectors (2.8 x 0.8 mm)
Order Information
Power
consumption
mm
m3/h
W
25.5
171
5.3
38
184
8
38
184
8
38
184
8
Input
voltage
V
24
12
24
48
Part no.
20713-172
20713-241
20713-240
20713-242
21102-013
01108005
Technical data DC fans
Voltage in VDC
24
25
12
38
24
38
48
38
171
41.5
50.5
70
7
184
42
68
70
8
184
42
68
70
8
184
42
68
70
8
쮿 Please order connecting cable for 38 mm high fans separately,
see page 4.13
4.16
Protective grille to snap-in
19" fan trays
쮿 Protective grille for direct mounting on AC and DC fans
Delivery comprises
Qty
1
Ø 50
105
119
Item
1
Description
Fibre glass reinforced plastic (PA), black, in accordance
with DIN 31001, UL 94 V-0
Order Information
Description
Protective grille, plastic, to snap-in
105
Part no.
60225-052
6,5
Ø9
119
min. 9
13,5
3,8
01108053
Protective grille, plastic, to screw-on
19" fan trays
쮿 Protective grille for AC and DC fans
쮿 Grille may be mounted on a front panel or the wall of the
housing
Item
1
Ø 50
127
113,5
Delivery comprises
Qty
1
Description
Order Information
113,5
Description
Assembly kit for plastic grille (4 screws, 4 washers, 4 nuts
M4), PU 1 set
6,5
Ø8
21102-014
90°
Ø 4,5
127
Part no.
60225-053
3,8
01108054
Protective grille, metal, to screw-on
19" fan trays
4,7
쮿 Optimised noise level and air resistance
Item
1
104,7
115,0
Delivery comprises
Qty
1
Description
St, 1 mm
Order Information
104,7
115,0
Description
Assembly kit for metal grille (4 screws, 4 washers, 4 nuts
M4), PU 1 set
1,8
5,5
Part no.
60197-019
21102-015
01109050
4.17
19" fan trays
19" fan dimensioning
V (m3/h)
For local heat dissipation, the airflow volume required to expel
the heat produced is calculated.
Note
The cabinet ventilation is not taken into account here.
The required airflow volume is calculated as follows:
V= (f x Pv)/ΔT
Pv (W)
The air constant f = 3.3 m3K/Wh.
ΔT is the temperature difference between the ambient
temperature of the sub-assembly and that of the air drawn in.
Example of readings
- Pv = 600 W
- air sucked in: 25 °C
- permissible ambient temperature of the sub-assembly = 30 °C
A41771
1. ΔT = Ti – Tu = 30 °C – 25 °C = 5 K
2. From Pv = 600 W to the curve for ΔT =5 K
3. From the intersection point to the airflow volume V = 400 m3/h
4.18
Climate control – 19" fan trays ServicePLUS
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and
electronic components by our specialists
쮿 No additional charge
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours
for off-the-shelf products
쮿 Download CAD data, send modifications to us
쮿 Ready for dispatch within 10 working days
쮿 Ready for dispatch within 15 working days
19" fan trays ServiceP LUS
4.19
Ai r filtered fanMain Catalogue
Climate control – Air filtered fan
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
01105012
Front panels,
Simple to fit without tools by clipping in
(can also be bolted)
01108014
Easy tool-less change of filter mat
01108015
Power supply
Backplanes . . . 10
01108016
Connectors, front
panel component
Fluted filter to increase degree of ingress protection
from IP 54 to IP 55
01108013
Easy tool-less wiring with spring clamp connector
Ai r filtered fan
4.20
Overview . . . . . 4.20
Air filtered fanMain C atalogue
Air filtered fans, ingress protection from IP 54 to IP 55
in accordance with IEC 60529
쮿 Simple to fit without tools by clipping in (can also be bolted)
How to dimension
air filtered fans . . 4.22
쮿 Easy conversion from pressure to suction operation
Reading example . 4.22
쮿 Easy tool-less change of filter mat
EMC solutions . . . 4.22
쮿 7 performance classes with 6 different assembly dimensions
Air filtered fans
쮿 Airflow capacity of 25 m3/h ... 770 m3/h (FL 100 ... FL 600)
쮿 3 supply voltages (230 VAC, 115 VAC, 24 VDC)
쮿 Outlet/inlet filter
쮿 Fluted filter to increase degree of ingress protection from
IP 54 to IP 55
Air filtered fans
FL 100 . . . . . . . . . . 4.23
FL 200 . . . . . . . . . . 4.24
FL 225 . . . . . . . . . . 4.25
FL 250 . . . . . . . . . . 4.26
FL 300 . . . . . . . . . . 4.27
FL 500 . . . . . . . . . . 4.28
FL 600 . . . . . . . . . . 4.29
쮿 Side by side mounting of several air filtered fans is possible
Air filtered fans
Outlet/inlet filters
Fluted filters
01108017
01108026
01108016
ServicePLUS
e.g. special colours
e.g. other cabinet dimensions
e.g. EMC solutions
30407004
4.21
Climate control – Air filtered fans
Air filtered fan calculations
To establish the size of the air-filtered fan required, calculate the air
throughput necessary to dissipate the amount of heat contained in the
cabinet.
The necessary airflow volume (at sea level) is calculated thus:
V = f x (PV - PS ) / ∆T with
V = airflow volume
f = air constant = 3.3 m³ K/Wh
PV = thermal power loss
(sum of heat emitted by the equipment in the cabinet)
PS = radiant power
(heat that is radiated from the cabinet
without additional ventilation)
∆T = temperature difference between the air drawn in (ambient
temperature Tu) and the exhaust air (internal cabinet temperature Ti),
∆T = Ti -Tu
01108017
Reading example
The devices in the cabinet produce e.g. a power loss of 840 W. Of these
840 W, the cabinet releases 340 W to the environment via its surfaces. The
air sucked in from outside the cabinet has a temperature of 20 °C.
A maximum temperature of 40 °C is to be permitted in the cabinet.
So which air filtered fan should be employed?
1. PV = 840 W, PS = 340 W, read-off point PV - PS = 500 W
2. ∆T = Ti - Ta = 40 °C - 20 °C = 20 °C = 20 K
3. On the characteristic for 20 K we obtain, at PV - PS = 500 W,
a minimum necessary airflow volume of V = 80 m³/h.
4. An FL 250 air filtered fan should be used that gives an airflow volume
of 131 m³/h or, if used in combination with the FLA 250 exhaust filter,
of 95 m³/h.
FL 100 + FLA 100
FL 100
FL 200 + FLA 200
FL 200
FL 225 + FLA 225
FL 225
FL 250 + FLA 250
FL 250
FL 300 + FLA 300
FL 300
FL 500 + FLA 500
FL 500
FL 600 + FLA 600
FL 600
kta45245
EMC solutions
4
Air filtered fansMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 EMC shielding in accordance with your requirements
쮿 Customised developments
Delivery comprises
3
Item
1
2
3
4
2
1
Description
Protective fan grille
Fan
EMC hood
FLA outlet/inlet filter
01108070
4.22
Air filtered fan FL 100
쮿 Airflow volume 25 m3/h
Air filtered fansPart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Converts simply from push to pull operation
쮿 Ingress protection IP 54, NEMA type 12
Delivery comprises (completely assembled)
01108018
Item
1
Qty
1
2
3
4
1
1
1
Description
Front grille and case, plastic, ABS, RAL 7035,
self-extinguishing, UL 94 V-0
Filter, filter class G 3 (EN 779)
Fan
2 wire connection, length 310 mm
Order Information
Description
24 VDC
Part no.
115 VAC
Part no.
60715-142
60715-141
Air outlet/inlet filter FLA 100
(items 1 + 2 included), 1 piece
Replacement filter IP 54 for FL 100 and FLA 100,
filter class G 3 (EN 779), PU 5 pieces
230 VAC
Part no.
60715-140
60715-156
60715-182
Technical data
01108019
Voltage
Frequency
Airflow volume with filter
(free blowing)
Combination FL + FLA
Noise level (in accordance
with EN ISO 3741, 50 Hz)
Operating temperatures
Power consumption
Filter efficiency
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
25/29 m3/h
115 VAC
50/60 Hz
25/29 m3/h
24 VDC
DC
25 m3/h
16/18 m3/h
38 Pa
33 dB(A)
16/18 m3/h
38 Pa
33 dB(A)
16 m3/h
38 Pa
33 dB(A)
–15 ... +55 °C –15 ... +55 °C
12/11 W
11/11 W
88 %
88 %
40000 h
40000 h
CE, UL, cUL, GOST
–15 ... +55 °C
2.4 W
88 %
80000 h
Note
01108020
쮿 Mounting for sheet thicknesses from 1 to 3 mm
쮿 Multiple fan solution on request
쮿 Dimensions, cut-outs and tolerances see user manual
109
109
92
92
92
92
109
109
62
4
4
01108057
19
01108058
Sheet thicknesses 1 ... 2 mm - cut-out 92 x 92 mm;
Sheet thicknesses >2 ... 3 mm - cut-out 93 x 93 mm
SCHROFF.PENTAIR.CO.UK
Part number in bold face type: ready for despatch within 2 working days
4.23
Air filtered fan FL 200
쮿 Airflow volume 61 m3/h
Air filtered fans
쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12
Delivery comprises (Completely assembled)
01108018
Item
1
Qty
1
2
3
4
1
1
1
Description
Filter, filter class G3 (EN 779)
Fan
Connection AC (terminal strip),
connection DC (2 wires, 310 mm long)
Order Information
Description
Air outlet/inlet filter FLA 200
Fluted filter IP 55
01108019 01108021
01108020
125
125
115 VAC
Part no.
60715-145
60715-144
Replacement filter IP 54 for FL 200 and FLA 200,
Fluted filter IP 55 for FL 200 and FLA 200,
filter class G 4 (EN 779), PU 5 pieces
230 VAC
Part no.
60715-143
60715-157
60715-183
60715-187
Technical data
Voltage
Frequency
Airflow volume with
IP 54 filter (free blowing)
Airflow volume with
IP 55 filter (free blowing)
Combination FL + FLA IP 54
Combination FL + FLA IP 55
Max. static pressure IP 54
Max. static pressure IP 55
Noise level in accordance
Power consumption
Filter efficiency IP 54
Filter efficiency IP 55
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
61/70 m3/h
115 VAC
50/60 Hz
61/70 m 3/h
24 VDC
DC
61 m 3/h
56/64 m3/h
56/64 m3/h
56 m 3/h
44/52 m3/h
40/46 m3/h
60 Pa
57 Pa
44 dB(A)
44/52 m 3/h
40/46 m3/h
60 Pa
57 Pa
44 dB(A)
44 m 3/h
40 m 3/h
60 Pa
61 Pa
44 dB(A)
15 ... +55 °C -5 ... +55 °C
19/18 W
20/20 W
83 %
83 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
-25 ... +55 °C
5W
83 %
91 %
80000 h
Note
145
145
24 VDC
Part no.
125
125
145
145
70
5
5
26
01108059 01108060
Sheet thicknesses 1 ... 2 mm - cut-out 125 x 125 mm;
Sheet thicknesses >2 ... 3 mm - cut-out 126 x 126 mm
4.24
SCHROFF PRODUCT CATALOG E 05/2016
Air filtered fan FL 225
쮿 Airflow volume 110 m3/h
Air filtered fans
Item
1
Qty
1
2
3
4
1
1
1
01108022
Description
Fan
Connection AC (terminal block),
DC (spring terminal strip)
Order Information
Description
115 VAC
Part no.
230 VAC
Part no.
60715-147
Air outlet/inlet filter FLA 225
Replacement filter IP 54 for FL 225 and FLA 225,
Fluted filter IP 55 for FL 225 and FLA 225,
Fluted filter IP 55
01108019 01108021
01108020
60715-146
60715-158
60715-184
60715-188
Technical data
Voltage
Frequency
Airflow volume with IP 54 filter
(free blowing)
Airflow volume with IP 55 filter
(free blowing)
Noise level (in accordance with
EN ISO 3741, 50 Hz)
Power consumption
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
110/125 m3/h
115 VAC
50/60 Hz
110/125 m 3/h
100/110 m3/h
100/110 m 3/h
82/93 m3/h
55/64 m3/h
66 Pa
61 Pa
40 dB(A)
83/92 m 3/h
55/64 m 3/h
66 Pa
61 Pa
40 dB(A)
–15 ... +55 °C
–15 ... +55 °C
19/18 W
20/20 W
88 %
88 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
Note
01108061 01108062
Sheet thicknesses 1 ... 2 mm - cut-out 177 x 177 mm;
Sheet thicknesses >2 ... 3 mm - cut-out 178 x 178 mm
4.25
Air filtered fan FL 250
쮿 Airflow volume 156 m3/h
Air filtered fans
01108022
Item
1
Qty
1
2
3
4
1
1
1
Description
Fan
Connection spring terminal strip
Order Information
Description
115 VAC
Part no.
60715-149
Air outlet/inlet filter FLA 250/300
Replacement filter IP 54 for FL 250/300 and
FLA 250/300, filter class G 3 (EN 779), PU 5 pieces
Fluted filter IP 55 for FL 250/300 and FLA 250/300,
Fluted filter IP 55
01108019 01108021
01108020
223
223
60715-148
60715-159
60715-185
60715-189
Technical data
Voltage
Frequency
(free blowing)
(free blowing)
EN ISO 3741, 50 Hz)
Power consumption
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
156/171 m3/h
115 VAC
50/60 Hz
151/170 m3/h
145/160 m3/h
140/160 m3/h
116/127 m3/h
109/113 m3/h
52 Pa
49 Pa
40 dB(A)
116/127 m3/h
109/113 m3/h
52 Pa
49 Pa
40 dB(A)
18/17 W
18/17 W
88 %
88 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
Note
252
252
230 VAC
Part no.
223
223
252
252
6
97
6
38
01108063 01108064
Sheet thicknesses 1 ... 2 mm - cut-out 223 x 223 mm;
Sheet thicknesses >2 ... 3 mm - cut-out 224 x 224 mm
4.26
Air filtered fan FL 300
쮿 Airflow volume 256 m3/h
Air filtered fans
01108024
Item
1
Qty
1
2
3
4
1
1
1
Description
Front grille and case, plastic ABS, RAL 7035,
Fan
Order Information
Description
115 VAC
Part no.
60715-151
Fluted filter IP 55
01108019 01108021
01108020
223
223
60715-150
60715-159
60715-185
60715-189
Technical data
Voltage
Frequency
(free blowing)
(free blowing)
EN ISO 3741, 50 Hz)
Power consumption
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
256/292 m3/h
115 VAC
50/60 Hz
256/292 m3/h
233/265 m3/h
233/265 m3/h
231/265 m3/h
180/207 m3/h
116 Pa
112 Pa
42 dB(A)
231/265 m3/h
180/207 m3/h
116 Pa
112 Pa
42 dB(A)
45/39 W
40/40 W
88 %
88 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
Note
252
252
230 VAC
Part no.
223
223
252
252
6
113
6
38
01108065 01108064
Air outlet/inlet filter FLA 250/350
Part number in normal type: ready for despatch within 10 working days
4.27
Air filtered fan FL 500
쮿 Airflow volume 480 m3/h
Air filtered fans
01108025
Item
1
Qty
1
2
3
4
1
1
1
Description
self-extinguishing UL 94 V-0
Fan
Order Information
Description
230 VAC
Part no.
115 VAC
Part no.
60715-153
Air outlet/inlet filter FLA 500/600
Replacement filter IP 54 for FL 500/600 and
FLA 500/600, filter class G 3 (EN 779), PU 5 pieces
Fluted filter IP 55 for FL 500/600 and FLA 500/600,
Fluted filter IP 55
01108019 01108021
01108020
291
291
60715-152
60715-160
60715-186
60715-190
Technical data
Voltage
Frequency
(free blowing)
(free blowing)
EN ISO 3741, 50 Hz)
Power consumption
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
505/505 m3/h
115 VAC
50/60 Hz
505/505 m3/h
480/480 m3/h
480/480 m3/h
380/380 m3/h
370/370 m3/h
76 Pa
74 Pa
54 dB(A)
380/380 m3/h
370/370 m3/h
76 Pa
74 Pa
54 dB(A)
–15 ... +55 °C
–15 ... +55 °C
65/80 W
75/90 W
88 %
88 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
320
320
Note
291
291
320
320
,5
150
6,5
6,5
5
39,
01108067 01108068
Air filtered fan FL 500/600
4.28
Air filtered fan FL 600
쮿 Airflow volume 640 m3/h
Air filtered fans
01108025
Item
1
Qty
1
2
3
4
1
1
1
Description
Fan
Order Information
Description
230 VAC
Part no.
115 VAC
Part no.
60715-155
Fluted filter IP 55
01108019 01108021
01108020
291
291
60715-154
60715-160
60715-186
60715-190
Technical data
Voltage
Frequency
(free blowing)
(free blowing)
Noise level in accordance with
EN ISO 3741, 50 Hz)
Power consumption
MTBF at 40 °C
Approvals
230 VAC
50/60 Hz
770/785 m3/h
115 VAC
50/60 Hz
770/785 m 3/h
640/653 m3/h
640/653 m 3/h
490/501 m3/h
445/445 m3/h
134 Pa
132 Pa
63 dB(A)
490/501 m 3/h
445/445 m 3/h
134 Pa
132 Pa
63 dB(A)
–15 ... +55 °C
–15 ... +55 °C
115/150 W
110/160 W
88 %
88 %
91 %
91 %
40000 h
40000 h
CE, UL, cUL, GOST
Note
320
320
291
291
320
320
,5
150
6,5
6,5
5
39,
01108067 01108068
4.29
Climate control – Accessories
Heaters from 10 W to 150 W
AccessoriesMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Compact heater without fan
쮿 Simple and fast assembly with clip-on attachment
쮿 Broad range voltage input AC/DC 120 ... 240 V
쮿 Low surface temperature, protective insulation, and
temperature limitation with PTC resistance
Delivery includes (completely assembled)
10 / 20 W
01116002
50 / 100 / 150 W
01116001
Dimension drawing
Item
1
Qty
1
2
1
3
1
Description
Heater element, voltage AC/DC 100 ... 240 V;
PTC resistor, self-regulating
Heating body housing, plastic UL94 V-0; type of fixing:
Clip for 35 mm DIN rail EN 60715
Connection: 2-pin (10 W, 20 W) and/or 4-pin (50 W, 100 W,
150 W) terminal, 2.5 mm², torque 0.8 Nm max.
Order Information
Description
10 W
20 W
50 W
100 W
150 W
Part no.
60715-220
60715-221
60715-222
60715-223
60715-224
Note
10 / 20 W
01116054
50 / 100 / 150 W
01116053
쮿 Thermostat for heating see page 4.65
쮿 Hygrostat see page 4.68
Technical data
Heater output in W
Max. switch-on current in A
Pre-fuse, delay-action in A
Type of protection
Class of protection
Dimensions H × W × D in mm
Weight in kg
Connection
Surface temperature in °C
Test seal
Mounting
4.58
10 W
20 W
50 W
100 W
10
100
1.0
2.5
2.5
4.5
2.0
4.0
4.0
8.0
IP 20
IP 20
IP 20
IP 20
II
II
II
II
98 × 38 × 75
98 × 38 × 75
110 × 60 × 90
110 × 60 × 90
0.2
0.3
0.3
0.3
2-pin terminal, 2.5 mm², torque 0.8 Nm
4-pin terminal, 2.5 mm², torque 0.8 Nm
< + 80°C, with exception of above mesh surface
CE, UL, VDE, EAC, RoHS
Clip-on attachment for 35 mm DIN rail (EN 60715)
150 W
150
8.0
10.0
IP 20
II
150 × 60 × 90
0.5
Heaters with heater fans from 150 W to 400 W
Access ori esMAIN CATA LO GPart number in bold face type: ready for shipping wi thin 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 Compact heater with fan, small, compact design with high
heater output
쮿 Simple and fast assembly with clip-on attachment or bolt fixing
쮿 Dynamic heating up and temperature limitation by PTC
technology
쮿 Quiet
Item
1
Qty
1
2
1
3
4
1
1
01116004
Dimension drawing
Clip attachment
Description
Heater element, voltage 230 VAC, resistor (PTC
resistance) self-regulating
Axial fan, airflow from bottom to top
Connection: 2-pin terminal, 2.5 mm², torque 0.8 Nm max.
Order Information
Description
150 W
250 W
400 W
Part no.
60715-225
60715-226
60715-227
Note
01116050
01116051
Technical data
Heater output in W
Axial fan, free blowing output
Type of protection
Class of protection
Weight in kg
150 W
250 W
150
250
9.0
12
10
10
13.8 m²/h
45 m²/h
IP 20
IP 20
II
II
75 × 65× 90
90 × 85 × 111
0.3
0.5
< + 50°C, with exception of above mesh surface
Connection
Test seal
Mounting
400 W
400
15
16
45 m²/h
IP 20
II
90 × 85 × 111
0.5
< + 65°C, with exception of above
mesh surface
Part number in normal type: ready for shipping within 10 working days
4.59
Heaters from 30 W to 150 W
AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
쮿 Radiator heater (without fan)
쮿 Simple and fast assembly with clip-on attachment and presson terminal connection
쮿 Wide input voltage range 110 ... 250 VAC
쮿 Temperature limiting with PTC resistor
Item
1
Qty
1
2
1
3
1
01102004
Description
Heater element, voltage range 110 ... 250 VAC;
resistor (PTC) self-regulating
Heating body, Al extrusion, anodised
Fixing: clip for 35 mm DIN rail EN 50022
Connection:
type 30, with connecting cable
(3 x 0.5 mm2, 300 mm long, black);
type 45, 100, 150 with press-on terminal connection
(for stranded/rigid wire 3 x 0.5 ... 2.5 mm2)
D
47
W
H
01113050
Support rail
00508013
Order Information
30
Description
Part no.
60715-020
Support rail DIN rail EN 50022 (35 mm), length 215 mm, 1 piece
45
Part no.
100
Part no.
150
Part no.
60715-021
60715-023
60715-030
20715-001
Technical data
Heater output in W
Type of protection
Class of protection
Weight in kg
Test seal
Assembly
30 W
45 W
30
45
approx. 100
approx. 105
3,0
3,5
IP 54
IP 20
I
I
70 × 25 × 50
69 × 70 × 50
0.2
0.3
VDE, CE, UL (File E150057) CE, UL (File E150057)
Clip-on attachment for 35 mm DIN rail (EN 50022)
100 W
100
approx. 130
4.0
IP 20
I
144 × 70 × 50
0.5
150 W
150
approx.140
9,0
IP 20
I
224 × 70 × 50
0.7
Note
4.60
Heater fans 475/550 W
Access ori es
쮿 Heater with fan and thermostat
쮿 3-pin terminal clamp, separate heater/fan connection
쮿 Thermostat from 0 ... 60 °C
01108030
Item
1
Qty
1
2
3
4
1
1
1
Description
Plastic housing, polycarbonate
(RAL 9002, grey white),
Heater element, 230 VAC, resistor (PTC) self-regulating
Thermostat
230 VAC fan
Description
Heater 475 W
Heater 550 W
1 piece
165
160
Order Information
Part no.
60715-017
60715-018
20715-001
Technical data
Voltage range
Frequency
Heater output
Air capacity of axial fan
Current at switch-on approx.
Weight
Heater element
Connection
128
124
100
01108069
Thermostat
Control lamp of control
system
Temperature control
Type of protection
Class of protection
Assembly
Dimensions
Support rail
230 VAC
50 Hz
60 Hz
50 Hz
60 Hz
475 W
550 W
550 W
650 W
35 m3/h 39 m 3/h 45 m3/h 50 m3/h
11 A
13 A
0.9 kg
1.1 kg
Resistor (PTC), self-regulating
3-pin connecting terminal, 2.5 mm2,
separate connection heating/fan
Adjustment range 0 ... 60 °C
Glow lamp
In the event of fan failure
IP 20
II
(EN 50022)
Height 165 mm, width 100 mm,
depth 128 mm
00508013
4.61
Heater fan 400 W, modular
Accessories
쮿 Modular system consisting of:
heater element, fan, protective grille and connecting cable
쮿 Fan not included in delivery extent; please order fan with
desired air capacity separately
쮿 Overheating protection through thermal switch
Example of a complete heater unit:
1: heater, 2: fan, 3: protective grille, 4: connection cable
01108007
Item
1
2
3
4
Qty
1
1
1
1
Description
Heater element, high-performance cartridge
Connecting cable fan - heating distributor, length 0.3 m
GND/earth cable, ring tag - open end, length 0.3 m
Clip-on attachment for DIN rail with assembly kit
Order Information
Description
115 VAC
Part no.
60715-028
1 piece
230 VAC
Part no.
60715-029
20715-001
Technical data
Heater element
01108006
Voltage range
Heater output
Air capacity m 3/h
Surface temperature with fan
Type of protection
Class of protection
Dimensions:
height x width x depth in mm
Assembly
115 VAC
230 VAC
3.5 A
1.8 A
400 W
Please choose desired fan
Approx. 140 °C
IP 20
I, with GND/earthing
22 x 120 x 160
Clip for 35 mm DIN rail EN 50022
Note
쮿
쮿
쮿
쮿
Support rail
4.62
Attention: Danger of overheating, never use heater without fan
Fan see page 4.63
00508013
AC fans for heating 400 W
Access ori es
쮿 The fan is screwed below the heater and the cable is connected
to the heater (please order connecting cable and protective
grille separately)
Delivery comprises
Item
1
Qty
1
Description
Order Information
01108005
Connecting cable
Height
Airflow volume
115 V AC
mm
m3/h
Part no.
Type A
25
84
20713-146
Type B
25
108
20713-147
Type C
38
162
20713-244
PVC (2 x 0.75 mm²), 1 m long with 2 Faston connectors
2.8 x 0.5 mm to DIN 46343 T1, 1 piece
230 VAC
Part no.
20713-142
20700-001
20713-243
21101-246
60197-019
Dimensions AC fans
KTA43091
4,7
Type
Frequency in Hz
Type A
50 60
84 90
29 30
23 21
70 70
8
7
25
Type B
50 60
108 120
34 38
41 41
70 70
14 11
25
Type C
50 60
162 192
37 41
73 88
70 70
15 14
38
쮿 Please order connection cable and protective grille separately
104,7
115,0
Note
104,7
115,0
Protective grille
1,8
5,5
01108055
4.63
Speed control for fans
with C13 plug
Accessories
쮿 Suitable for all AC fans and fan units (up to 300 W) with
IEC 60320 C13 plug (plug & play)
쮿 Simple to mount on the support rail provided
쮿 Simple adjustment of switch-on temperature (with knob and
digital display)
쮿 External sensor can be fitted at a desired measurement point
01111001
쮿 Open-collector output (parametrisable)
– Alarm output (active/passive)
– DC fans (PWM output)
– Remote display (via optional digital display with front panel)
Delivery comprises
Speed controller with connecting cables
01111002
Item
1
Qty
1
2
3
4
5
6
1
1
1
1
1
Description
Speed controller; input/output voltages 115 ... 240 V AC,
see Technical Data
Temperature sensor, cable length 1.5 m
Fan cable, 2 m, with IEC 60320 socket
Mains cable, 3 m, with connecting plug
Support rail, St, zinc-plated (EN 50022)
Assembly kit
Order Information
Speed control for fans with C13 plug
Part no.
Mains cable SCHUKO/UTE plug
60715-005
Mains cable IEC 60320 C13 plug
60715-006
Accessories
Thermostat with digital display 230 VAC , 1 piece
Page 4.67
Thermostat with digital display 115 VAC , 1 piece
Page 4.67
Connecting cable for DC fans or alarm output Length 2 m,
60715-007
2-wire (0.34 mm2), 1 piece
01105055
Block diagram
01111050
Speed varies in relation to temperature
Technical data
Voltage range
Frequency
Power consumption
Display
Max. connection power
Max. continuous
current
Adjustment range
Fan speed frequency
Sensor
Sensor connection
In case of sensor failure
Fan connection
Mains connection
Mechanics
Dimensions
Environmental
conditions
115 ... 240 VAC (90 ... 264 VAC)
48 ... 62 Hz
max. 4 VA
LCD display, height 13 mm, red
300 W (230 VAC), 150 W (115 VAC)
1.3 A
+20 ... +60 °C with potentiometer
25 ... 100 %
AMP plug contact and cable, 1.5 m, 2 x 0.22 mm
Max. speed
Cable 2 m with C13 IEC 60320 socket
AMP plug contact, programmable function,
Vmax. 30 VDC, Imax. 30 mA
Cable 3 m with plug
Case, IP 30, plastic, weight 0.5 kg, mounts on
horizontal rail with lip DIN EN 50022
Width 120 mm, height 70 mm, depth 25 mm
0 ... 60°C, max. 85 % rel. humidity,
non-condensing
Note
쮿 Thermostat with digital display, see page 4.67
01111051
4.64
Thermostat with integrated temperature sensor
Access ori es
쮿 To control fans or heaters
쮿 Adjustment range 5 ... 60 °C
쮿 Individual adaptation with three separate components:
thermostat (for cooling or heating), assembly material,
connecting cable (IEC connector or ferrules)
쮿 2 versions
– for heating
– for cooling
Delivery comprises
01108004
3
2
Description
40
50
°C
1
4
01108050
01108009
Adjustment range
Switching
temperature
difference
Sensing element
Contact resistance
Lifespan
Max. switch
performance
Connection
Case
Dimensions
Assembly
Weight
Operating/storage
temperature
Protection class
Connection cable: 2-pin, ferrules - 3-pin, ferrules
Part no.
for heating
60715-137
21120-178
62150-201
62150-264
Dimensions
Thermostat
Connection cable: 2-pin, ferrules - IEC socket
Part no.
for cooling
60715-136
sensor
Accessories
Item 3 DIN rail (EN 50022) 35 mm; length 75 mm;
with fixing materials kit, PU 1 set
Item 4 Connection cable, SCHUKO/UTE connector, cable
length 1.5 m; connection on thermostat/hygrostat, 2-pin,
ferrules; connection on fan IEC socket; 1 piece
cable length 1.5 m; connection on thermostat/hygrostat,
2-pin, ferrules; connection on fan/heater, 3-pin, ferrules,
1 piece
30
10
1
Description
Thermostat, width 33 mm, height 60 mm, depth 43 mm;
clip-on attachment for 35 mm DIN rail EN 50022,
switched voltage 120 ... 250 VAC
User manual
Order Information
33
43
60
Item Qty
1
1
for cooling
(make contact),
blue control button
0 ... 60 °C
7 K (± 4 K tolerance)
for heating
(break contact),
red control button
Thermobimetal (snap-action contact)
100000 cycles
10 A at 250 VAC, 15 A at 120 VAC;
30 W at DC voltage
2-pin clamp, up to 2.5 mm 2,
torque max. 0.5 Nm
Plastic, in accordance with UL 94 V-0, light grey
Height 60 mm, width 33 mm, depth 43 mm
Clip for 35 mm DIN rail, EN 50022
40 g
-20 ... +80 °C/-45 ... +80 °C
IP 20
01108010
4.65
쮿 To control heaters or fans
Delivery comprises
Item Qty
1
1
2
3
4
5
1
1
1
1
Description
Thermostat with clip-on attachment for 35 mm DIN rail
EN 50022, voltage 200 ... 250 VAC and 100 ... 130 VAC
Support rail, length 200 mm
Connection cable, length 1.5 m
Strain relief
Assembly kit for cabinet assembly
Order Information
Description
01102008
Part no.
20715-002
Technical data
Dimensions
Adjustment range
Switch difference
Supply voltage
Contact load
(ohmic load/inductive load)
Contacts
Type of assembly
Height: 75 mm, width: 75 mm, depth:
25 mm
5 ... 60 °C
0,5 K
200 ... 250 VAC
Heat (terminals 1 - 2) 10 A / 4 A
Cool (terminals 1 - 3) 5 A / 2 A
Changeover contact, single pole
Bolt-on, snap mounting for slide rail
Thermostat with external temperature sensor
Accessories
쮿 External sensor can be positioned near the critical
sub-assembly
쮿 Adjustment range 20 ... 60 °C, switch difference 3 ... 10 K
Delivery comprises
Item Qty
1
1
2
3
01102007
1
1
Description
Thermostat with external temperature sensor,
sensor length approx. 1.7 m
Mounting plate for cabinet assembly, Al, 2.5 mm
Assembly kit
Order Information
Description
Part no.
20715-003
Technical data
Dimension (height x width x depth)
Adjustment range
Switching difference
Mains/line voltage
Contact load (ohmic load/inductive load)
Contacts
Assembly
4.66
93 mm x 68 mm x 44 mm
20 ... 60 °C
3 ... 10 K
90 ... 260 VAC
24 A/10 A
Change-over, single pin
Screw-fixed
Access ori es
쮿 Adjustment range from -50 to +100 °C
(switch difference 0 ... 10 °C)
쮿 Display switchable from °C to °F
쮿 Programmable (secured against unauthorised operation)
쮿 3-character red segment display
Order Information
01197001
Front panel 1 U
Description
Thermostat with digital display, 230 VAC
Thermostat with digital display, 115 VAC
Front panel 1 U, RAL 7035 with cut-out for thermostat
Front panel 1 U, anodised with cut-out for thermostat
Front panel 1 U, RAL 7021 with cut-out for thermostat
Part no.
60715-132
60715-133
30118-315
30118-267
30118-360
Technical data
Operating voltage
Power consumption
Dimensions
SZA45550
115 VAC or 230 VAC
Approx. 3.5 W
Height: 35 mm, width: 76 mm,
depth: 59 mm
Assembly cut-out
28.8 × 70.5 mm
Adjustment range
–50 ... +100 °C
Switch difference
0 ... 10 K selectable
Data safeguarding at power failure Non-volatile memory
Contact load
8 A/3 A (ohmic/inductive load)
Input/sensor
PTC resistance,
-55 ... +120 °C, cable length 3 m
Contacts
Relay, changeover contact, single pin
Protection class to front
IP 54
Connection
Screw-on terminals, 2.5 mm2
Fixing
With clamping bracket
Type of assembly
Can be screwed on
4.67
Hygrostat
쮿 Adjustable or fixed relative air humidity
쮿 Switches fan or heaters when the set value is reached
쮿 Visual display
쮿 Integrated LED lights up when the connected consumer is
switched on
Hygrostat, assembly material, connecting cable (input with
SCHUKO/UTE connector; output with IEC connector or open
end) please order separately
01116006
Hygrostat with adjustable and permanently set relative humidity
3
64,5
2
3
4
1
Description
Hygrostat, width 42 mm, height 64.5 mm, depth 38 mm;
User manual
Order Information
rF/
R
65 H
1
Item Qty
1
1
2
42
38
Delivery includes (assembled)
5
1
4
01108051
Description
Hygrostat, fixed, 65 % air humidity
Hygrostat, adjustable, 40 ... 90 % air humidity
Accessories
DIN rail (EN 50022) Item 3 35 mm; length 75 mm;
Connection cable Item 4 SCHUKO/UTE connector, cable
1 piece
Part no.
60715-138
60715-213
21120-178
62150-201
62150-264
Technical data
Supply voltage
Default setting for
Switch difference
01108009
connecting cable, connection cable, 2-pole, ferrule - IEC-(female)
connector; input jack; bush; socket
230 VAC, 50/60 Hz
65 % fixed
40 ... 90% adjustable
5 % air humidity (w 1 % air humidity tolerance
at 25 °C)
Switch contact
Changeover contact (relay)
Lifespan
> 50,000 cycles
Max. switching capacity
8 A (16 A for 10 s)
Mains supply
2-pin terminal, up to 2.5 mm2, torque max. 0.5
Nm
Output change-over relay 3-pin terminal, up to 2.5 mm2, torque max. 0.5
Nm
Case
gray
Dimensions
Height 64.5 mm, width 42 mm, depth 38 mm
Type of assembly
Weight
65 g
Operating/storage
0 ... +60 °C/-20 ... +70 °C
temperature
Max. storage humidity
90 % air humidity (non-condensing)
Type of protection
IP 20
01108010
connecting cable, connection cable, 2-pole, ferrules - ferrules
4.68
IEC input plug
Access ori es
쮿 For connection of fans
쮿 Bolted housing made of heat-resistant plastic (UL 94 V-0)
쮿 10 A/250 VAC, protection class I
Order Information
Description
IEC input plug
Part no.
60715-046
KTA45246
4.69
Text
Product
Closed cabinet
Raised cover,
ventilation slots
Perforated doors
top cover fan
Cooling principle
01105060
Description
Type of protection
Noise level approx.
01105058
01105056
01105057
Natural convection
Free convection
through top opening
Free convection
through openings
Cooling with air
≤ IP 55
Ti > Ta
< 500 W
≤ IP 20
Ti > Ta
500 W ... 800 W
≤ IP 20
55 ... 65 dB(A)
Ti > Ta
500 W ... 6000 W 2)
≤ IP 20
34 ... 67 dB(A)
Ti > Ta
< 2000 W
FloTHERM simulation
ServiceMain Catalogue
Project support from simulation software
FloTHERM simulation software allows to detect hot spots and
problem areas from the concept phase.
Cooling concepts for assemblies through to complete
case/cabinet systems can thus be analysed in advance.
Our FloTHERM experts support you in developing your
concept.
Your advantage:
쮿 Extensive analyses eliminate problems during the concept/
prototype phase
쮿 Short development times
쮿 High performance and reliability for your systems
01103050
4.2
Text
Product
Air filtered fans
Air conditioners
(LHX 3)
(LHX 20/40)
Cooling principle
01102050
Description
Type of protection
Noise level
01105061
01007055
01005081
Cooling
with
air
Cooling
with
coolant
Cooling
with
water
Cooling
with
water
≤ IP 55
39 ... 71 dB(A)
Ti > Ta
< 1500 W
≥ IP 55
60 ... 81 dB(A)
Ta ≤ 55 °C
< 17000 W
≥ IP 55
45.2 dB(A)
Ta ≤ 70 °C
< 3000 W
≥ IP 55
50 ... 70 dB(A)
Ta ≤ 70 °C
< 40000 W
Servic e
Climate bay testing
01112001
4.3
PROLINE
OverviewMain Catalogue
Desk-top cases – Overview
Content
Cabinets . . . . . . 1
Y
The universal case with 19" compatible
dimensions e.g. for CompactPCI and VME64x
applications
- Aluminium case
- Height 2 ... 7 U
- High EMC shielding
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
i
The robust case for 19" compatible or custom
electronics assemblies
- Aluminium case with aluminium frame front
- Height 2 ... 6 U
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
5.0
Downloads und weitere wichtige Informationen finden Sie
im Internet unter www.schroff.biz
361009005 (12304003 10005004 05802001 06803006 05809001)
Overview . . . . . . 5.0
OverviewMain C atalogue
b
Introduction . . . . 5.2
Desk-top or portable case
Design alternative to propacPRO
- Front and rear frame in aluminium
- Aluminium case
- Height 2 ... 6 U
- For 19" components or individual electronics
assemblies
ServicePLUS . . . 5.4
ratiopacPRO . . . 5.6
propacPRO . . . . 5.44
compacPRO . . . . 5.76
comptec . . . . . . . 5.100
Accessories
Handles . . . . . . . . . 5.108
Strap handles . . . . 5.111
Tip-up carrying
handles . . . . . . . . . . 5.112
J
Accessories
Case to house
19" subracks or 19" chassis
- Case with aluminium frame to
front and rear
- High stability
- Height 3 ... 12 U
- Identical front and rear
- Internal mounting up to 40 kg
- Protection class IP 20
Folding handles . . 5.113
Tray handles . . . . . 5.114
Feet . . . . . . . . . . . . 5.115
36109006 (02004001 02202003 05806006 02992004 05806008)
5.1
Desk-top cases – Introduction
Case types: Desk-top enclosure/19" case
Introduc tionMain CataloguePart num ber in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days
Desk-top enclosures
Our desk-top cases are used to house PCBs (euroboards) or
individual components
The choice is yours:
쮿 ratiopacPRO, the universal case with 19" compatible
dimensions and high EMC shielding,
e.g. for CompactPCI and VME64x applications
Desk-top enclosure,
ratiopacPRO
01810002
19" case, comptec
02202004
쮿 propacPRO, the robust case with high EMC shielding for
19"-compatible or custom electronics assemblies
쮿 compacPRO, Desk-top or portable case for unshielded
applications
19" cases
Our comptec cases are comparable with small cabinets and are
used to house 19" components such as subracks, 19" fan trays
or 19" front panels
All desk-top enclosures have a very low weight owing to the
materials used and are also suitable for mobile use
Applications for desk-top enclosures
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
The most important user domains for desk-top enclosures are:
쮿 Fitting with euroboards in accordance with IEC 60297
쮿 Fitting with individual electrical or mechanical components,
e.g.on mounting plates
02004079 05809004 05809004
Example above: for euroboards, below: for individual installation
One product platform and extensive accessories
쮿 Practical technology without time-consuming assembly. The
modular product platform of these cases allows a wide range
of possible uses with only a small number of components.
The intelligent design of all components results in an
astonishingly quick and easy assembly of the components.
05806008
05806006
With our PRO product platform we offer you full compatibility
of all individual components and accessories, also with our
europacPRO subracks.
Standard desk-top enclosures can also be adapted easily and
with little effort for mobile applications.
02005003
5.2
02005006
Forms of delivery for desk-top enclosures
Introducti onMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days
Supplied in space-saving packs. Simply unpack parts and screw
together - done.
Depending on the kit chosen the threaded insert, the perforated
rail or the EMC gasket is pre-assembled on the horizontal rail.
We offer you three forms of delivery:
쮿 Pre-assembled kit for use with 160 mm deep euroboards,
frame fitted, cladding parts and guide rails supplied loose.
쮿 Pre-assembled kit for individual configuration, frame
assembled, cladding parts supplied loose.
쮿 Ready assembled cases to your specifications. With our
ServicePLUS option you can order ready-assembled cases,
with drilled holes and cut-outs and individual front panels if necessary even by express service.
06104001
Flat pack delivery to save space
Guide rail
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Guide rails form the interface between the mechanics of the
case and the electronics assembled (PCBs, plug-in units,
frame type plug-in units, drive unit modules, etc.).
Robust snap-in fixings on the plastic rails assure that the
components are held securely, even when exposed to
vibrations.
11
7
79
3
77
81
Guide rails can also be screwed on.
1
75
5
73
9
1
83
06108084
EMC and ESD
dB
120
쮿 Our case product platforms offer standard solutions for
achieving electromagnetic compatibility (EMC) and to avoid
electrostatic interference (ESD)
100
쮿 Shielding on the front and rear of the case is effected by front
panels with EMC gaskets
80
60
쮿 To prevent electrostatic discharge when inserting PCBs, ESD
contacts are clipped into the guide rails. These provide a
conductive connection between board and case earth/ground
40
쮿 Test reports are available on our website www.schroff.biz for
download
400
800
1200
1600
2000
Mhz
Shielding
Position of the ESD clip
06108081
04503050
5.3
Desk-top cases – ServicePLUS
configuration
Simple. Fast. For the product you want.
Components can be varied and combined freely
쮿 Online configuration: www.schroff.co.uk/configuration
assembly
쮿 Professional and reliable, without extra costs
modification
쮿 CAD data are available for you to download and further
modify from our website www.schroff.biz
쮿 Ready for despatch within 10 working days
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Flowtherm simulation to calculate heat paths; verification in
our own climate lab
쮿 Special sizes, custom solutions
express
When fast has to be faster.
Delivery time to customer's request
쮿 ServicePLUS assembly ready for despatch within 10 working
days
쮿 ServicePLUS modification and ServicePLUS solution ready
for despatch within 15 working days
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars held centrally or at your site.
쮿 CAD drawings, test reports, user manuals
ServicePLUSMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days
5.4
Application examples
Text
Application: ratiopacPRO-air case in special colour,
shielded board cage, filter mat top and bottom
Application: compacPRO case, modified
Application: compacPRO case with fitted horizontal rail
with lip and folding front panel
Application: inpac case with hinged and modified
front and rear panels
01809001
02009001
02009002
02109001
Application: ratiopacPRO-air case with processed
with lip and hinged front panel
Application: compacPRO with tip-up carrying handle and
front panel (without visible screws)
Application: propacPRO, EMC case in special colour with
mounting plates for individual construction
01809003
02009003
02009004
05809005
5.5
Desk-top enclosures
Desk-top enclosure,
ratiopacPRO
01810002
19" case, comptec
02202004
applications
19" cases
or 19" front panels
05806008
05806006
02005003
5.2
02005006
together - done.
06104001
Guide rail
vibrations.
11
7
79
3
77
81
1
75
5
73
9
1
83
06108084
EMC and ESD
dB
120
100
80
60
40
download
400
800
1200
1600
2000
Mhz
Shielding
06108081
04503050
5.3
configuration
assembly
modification
solution
our own climate lab
express
days
academy
5.4
Text
01809001
02009001
02009002
02109001
01809003
02009003
02009004
05809005
5.5
Y Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Desk-top cases – Y
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
06800002
Subracks/
Front panels,
Power supply
Backplanes . . . 10
Connectors, front
panel component
ratiopacPRO
Designed for insertion/extractor handles in accordance with
IEC 60297-3-102 and IEEE 1101.10 for CompactPCI and
VME64x applications
06801005
ratiopacPRO air
accordance with IEC 60297-3-102 and
IEEE 1101.10 for CompactPCI and VME64x
applications; 1 U extra for ventilation
(1/2 U top, 1/2 U bottom)
Standards
쮿 Inner and outer dimensions in accordance with:
IEC 60297-3-101 / IEEE 1101.1
IEC 60297-3-102 / IEEE 1101.10/11
쮿 Type of protection IP20 in accordance with
IEC 60529
쮿 Earthing connections in accordance with:
DIN EN 50178 / VDE 0160
DIN EN 60950 / VDE 0805
DIN EN 61010-1 / VDE 0411 part 1
DIN EN 61010-1A2 / VDE 0411 part 1/A1
쮿 EMC testing in accordance with VG 95373 part 15
06812001
Case with mounting plate
06800015
Prepared for CompactPCI and
VME64x applications
5.6
SCHROFF PRODUCT CATALOG E 09/2017
Desk-top cases – Y
Overview . . . . . . 5.6
YMain C atalogue
The universal case with 19" compatible dimensions
e.g. for CompactPCI, VME64x and other applications
쮿 Base level of shielding in basic versions upwards,
additional EMC shielding can be retrofitted
쮿 Symmetrical construction, identical front and rear
(identical board cage for ratiopacPRO and ratiopacPRO air)
쮿 Converts simply from desktop to 19" rack-mounted case and back
쮿 No visible screws; cladding parts removable without tools
ratiopacPRO
Complete cases . .
Dimensions . . . . . .
Cases . . . . . . . . . . .
Tower cases . . . . .
ratiopacPRO air
ratiopacPRO
Complete cases . .
Radial fan units . .
EMC gasketing . . .
쮿 Case with cover strip, front handles or 19" brackets
(height 2 U ... 6 U)
Accessories
쮿 Complete case with cover strip and pre-mounted components,
with basic shielding (height 3 U, 6 U), additional EMC shielding
retrofittable
쮿 Tower case (width 4 U)
06800005
ratiopacPRO air
쮿 ratiopacPRO air with additional 1 U height for ventilation
쮿 Case with cover strips, front handles or 19" brackets
(height 4 U, 5 U, 7 U)
쮿 Complete case with cover strips and pre-mounted
components, with basic shielding (height 4 U, 7 U),
additional EMC shielding retrofittable
06803002
5.8
5.9
5.10
5.12
5.14
5.13
5.16
5.17
5.18
Front panels . . . . . 5.21
Rear panels . . . . . . 5.22
Feet . . . . . . . . . . . . . 5.23
Air filters . . . . . . . . 5.23
GND/earthing kit 5.24
Front handles . . . . 5.24
19" brackets . . . . . 5.25
Cable holder. . . . . 5.26
Compartment
seals. . . . . . . . . . . . . 5.26
Strap handles . . . . 5.26
Tip-up carrying
handles . . . . . . . . . 5.27
Assembly kit. . . . . 5.28
Fitting position of
horizontal rails . . . 5.29
Horizontal rails. . . 5.31
Threaded inserts,
perforated strips,
insulation strips . . 5.35
Z-rails, perforated
rails. . . . . . . . . . . . . 5.35
Divider plates . . . . 5.36
Mounting plates . . 5.37
Horizontal board
assembly . . . . . . . . 5.38
Combined
mounting . . . . . . . . 5.39
Guide rails and
ESD clips . . . . . . . . 5.40
ServicePLUS from page 5.4
e.g. modifications (special colours or sizes)
e.g. custom solutions (cut-outs in top cover,
base plate or side panels)
e.g. assembly service from 1 piece
www.schroff.biz/ServicePLUS
30407004
5.7
Desk-top cases – Y
ratiopacPRO complete cases
YMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
쮿 Desk-top enclosure with pre-configured components, in
accordance to IEC 60297-3-101; prepared for 19" components,
e.g. plug-in units and euroboards
쮿 Ventilation slit in base plate
쮿 Rear panel perforated
Delivery comprises (in kit form)
06812003
11
15
10
“X”
Item Qty
without
EMC
1
2
2
2
3
4
with
EMC
2
2
4
Description
4
4
4
5
2
2
6
7
1
6/8
1
6/8
8
9
10
11
4
1
2
4
4
1
2
12
4
4
14
1
15
4
16
17
1
4
1
4, 7, 8,16
“Y”
“Z”
5, 7, 9
6, 7, 9
1
2
3
15
11
12
01802050
“X”
“Y”
9
4
9
7
7
16
“Z”
7
5
8
6
01808055
A-A
Order Information
Height H
Width W
Depth D
U
3
3
3
3
3
3
3
6
6
6
6
6
HP
28
42
42
63
84
84
84
42
63
84
84
84
mm
255.5
255.5
315.5
315.5
315.5
375.5
435.5
315.5
315.5
315.5
375.5
435.5
Unshielded
Part no.
EMC
shielded
Part no.
24572-001
24572-002
24572-050
24572-051
24572-003
24572-052
24572-004
24572-005
24572-053
24572-054
H
A
Side panel, AI, 2 mm, passivated
Side plate, Al, 1 mm, visible surfaces RAL 9006
Cover strip, Al die-cast, RAL 7016, pre-fitted
only on EMC version
Horizontal rail, type H-LD, Al, visible surfaces
RAL 7016
Horizontal rail, centre (top/bottom), type H-ST,
Al
Horizontal rail, centre (on 6 U only), type ST, Al
3 U/6 U: threaded inserts, St, pre-mounted,
for indirect backplane mounting with insulation
strips
Perforated strip, Al, 1 mm, pre-fitted
Insulation strip, PBT, UL 94 V-0
Rear panel, perforated, Al, 2.5 mm
Top cover and base plate, Al, 1 mm, internal
surfaces conductive, visible surfaces RAL 9006,
with GND/earthing connection,
base plate with honeycomb grid ventilation
Case foot with anti-slip protection, UL 94 V-0,
PC black
EMC support profile for side panel,
pre-mounted (kit)
EMC contact strip for cover plate,
pre-mounted (kit)
EMC contact strip front panel - horizontal rails
GND/earthing kit, assembly kit
W
W - 21.4
D - 20
7.5
A
D
01808051
3U
A-A
A
W
W - 21.4
7.5
H
A
ServicePLUS see page 5.4
5.8
24572-055
24572-007
24572-015
24572-056
24572-064
24572-016
24572-065
24572-017
24572-018
24572-066
24572-067
24572-019
24572-068
Note
D - 20
D
01808052
6U
24572-006
쮿
쮿
쮿
쮿
Dimension drawings and mounting depths see page 5.9
Components see page 5.18
Front handles and 19" mounting brackets from page 5.24
Guide rails from page 5.40
Desk-top cases – Y
Dimension drawings RatiopacPRO
Text
rppr6637
RatiopacPRO with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle
Dimensions table RatiopacPRO
Height
H
in U in mm
2
3
4
5
6
88.10
132.55
177.00
221.45
265.90
Width
h
in mm
67.90
112.35
156.80
201.25
245.70
w
W
w1
Depth
w2
w
in HP in mm
in mm
in mm
in mm
28
42
63
84
28
42
63
84
28
42
63
84
28
42
63
84
28
42
164.42
235.54
342.42
448.90
164.42
235.54
342.42
448.90
164.42
235.54
342.42
448.90
164.42
235.54
342.42
448.90
164.42
235.54
177.62
248.74
355.42
462.10
177.62
248.74
355.42
462.10
177.62
248.74
355.42
462.10
177.62
248.74
355.42
462.10
177.62
248.74
198.12
269.24
375.92
482.60
198.12
269.24
375.92
482.60
198.12
269.24
375.92
482.60
198.12
269.24
375.92
482.60
198.12
269.24
142.82
213.94
320.62
427.30
142.82
213.94
320.62
427.30
142.82
213.94
320.62
427.30
142.82
213.94
320.62
427.30
142.82
213.94
63
342.42
355.42
375.92
320.62
84
448.90
462.10
482.60
427.30
D
d
Total depth
in mm
Useable depth
in mm
255.5
235.5
315.5
295.5
375.5
355.5
435.5
415.5
495.5
475.5
D1
Plug-in depth
in mm
175.5
235.5
175.5
235.5
295.5
175.5
235.5
295.5
355.5
175.5
235.5
295.5
355.5
175.5
235.5
295.5
355.5
d2
Board depth
in mm
160
220
160
220
280
160
220
280
340
160
220
280
340
160
220
280
340
Components mountable in 15 mm depth grid
5.9
Desk-top cases – Y
RatiopacPRO case
쮿 Cases for individual assembly with 19" standard components or
specific internal mounting, e.g. with mounting plate
쮿 Unshielded (EMC shielding retrofittable)
쮿 Symmetrical design, identical front and rear side
3a: Bezel
01805050
01805051
01805052
01813051
3b: Front handle 3c: 19" mounting 3d: 19" mounting
bracket
bracket with front
handle
쮿 Four versions:
– Bezels
– Front handles
– 19" mounting brackets
– 19" mounting brackets with front handles
쮿 For board depth 160 mm, 220 mm, 280 mm, and 340 mm
(depending on case depth)
Delivery comprises (kit)
Item
1
2
Qty
2
2
3
3a
3b
3c
2
2
2
2
3d
2
4
4
1
11
2
2
12
13
4
1
11
4
3
Description
Side panel, AI, 2 mm, chromated
Side plate, Al, 1 mm, visible surfaces powder-coated,
RAL 9006
Rear trim, Al die-cast, powder-coated, RAL 7016
Bezel, Al die-cast, powder-coated, RAL 7016
Front handle, Al die-cast, powder-coated, RAL 7016
19" mounting bracket, Al diecast, powder-coated,
RAL 7016
19" mounting bracket with front handle, Al diecast,
Top cover and base plate, Al, 1 mm, inner sides
conductive, visible surfaces powder-coated, RAL 9006,
with GND/earthing connections, base plate with
Case foot with anti-slip protection, UL 94 V-0, PC black
Fixing materials kit
3a, 3b, 3c or 3d according to selection
3a (3b/3c/3d)
Drawing with front cover strip
5.10
Note
쮿 Order information, see following page
11
Order Information
12
Accessories
Earthing kit CU wire, 1.5 mm2, PVC sleeve, green/yellow, 1
kit
Al diecast foot with tip-up silver, 1 piece (SPQ 10)
Plastic tip-up foot silver, similar to RAL 9006, PU 4 pieces
01813065
Plastic tip-up foot anthracite, similar to RAL 7016,
4 pieces
Stacking aid silver, similar to RAL 9006, PA, UL 94 V-0,
PU 4 pieces
Stacking aid anthracite, similar to RAL 7016, PA, UL 94 V0, PU 4 pieces
24571-380
10603-002
20603-001
20603-002
20603-004
20603-003
Desk-top cases – Y
RatiopacPRO case
Cover strips
Width
W
Depth
D
HP
mm
28
28
42
42
42
63
63
63
84
84
84
84
84
Case height H
2U
Part no.
Part no.
Part no.
255.5
315.5
255.5
315.5
255.5
255.5
315.5
375.5
255.5
315.5
375.5
435.5
495.5
24572-500
24572-503
24571-002
24571-005
24571-050
24571-053
24572-117
24572-120
24572-261
24572-264
24571-098
24571-101
24572-510
24571-014
24571-062
24572-129
24572-273
24571-110
24572-513
24572-514
24571-017
24571-018
24571-065
24571-066
24572-132
24572-133
24572-276
24572-277
24571-113
24571-114
28
28
42
42
42
63
63
63
84
84
84
84
84
Part no.
Side panel subdivision
(1 U-3 U-1 U)
(3 U-2 U)
Part no.
24572-520
24571-026
24571-074
24572-141
24572-285
24571-122
24572-523
24572-524
24571-029
24571-030
24571-077
24571-078
24572-144
24572-145
24572-288
24572-289
24571-125
24571-126
24572-530
24571-038
24571-086
24572-153
24572-297
24571-134
24572-533
24572-534
24571-041
24571-042
24571-089
24571-090
24572-156
24572-157
24572-300
24572-301
24571-137
24571-138
24572-535
24571-043
24571-091
24572-158
24572-302
24571-139
24572-536
24571-044
24571-092
24572-159
24572-303
24571-140
255.5
315.5
255.5
315.5
375.5
255.5
315.5
375.5
255.5
315.5
375.5
435.5
495.5
24571-702
24571-750
24572-213
24572-357
24571-798
24571-705
24571-714
24571-753
24571-762
24572-216
24572-225
24572-360
24572-369
24571-801
24571-810
24571-717
24571-765
24572-228
24572-372
24571-813
24571-718
24571-726
24571-766
24571-774
24572-229
24572-237
24572-373
24572-381
24571-814
24571-822
24571-729
24571-777
24572-240
24572-384
24571-825
24571-730
24571-738
24571-778
24571-786
24572-241
24572-249
24572-385
24572-393
24571-826
24571-834
24571-741
24571-789
24572-252
24572-396
24571-837
24571-742
24571-743
24571-790
24571-791
24572-253
24572-254
24572-397
24572-398
24571-838
24571-839
24571-744
24571-792
24572-255
24572-399
24571-840
84
255.5
24572-570
24571-438
24571-486
24572-201
24572-345
24571-534
84
315.5
24572-573
24571-441
24571-489
24572-204
24572-348
24571-537
84
375.5
24572-574
24571-442
24571-490
24572-205
24572-349
24571-538
84
435.5
24572-575
24571-443
24571-491
24572-206
24572-350
24571-539
84
495.5
24572-576
24571-444
24571-492
24572-207
24572-351
24571-540
84
front handles
255.5
24572-620
24572-630
24572-640
24572-660
84
315.5
24572-623
24572-633
24572-643
24572-663
84
375.5
24572-624
24572-634
24572-644
24572-664
84
435.5
24572-625
24572-635
24572-645
24572-665
84
495.5
24572-626
24572-636
24572-646
24572-666
RPPR6629
Front handles
01805050
01805052
01813051
Note
쮿 Dimension drawings and mounting depths see page 5.9
쮿 Components see page 5.18
5.11
Desk-top cases – Y
ratiopacPRO tower with 4 U width
Y
쮿 Mounting space 4 U, 84 HP, depth 475 mm
쮿 Case based on ratiopacPRO
Item
1
2
Qty
2
4
3
4
4
2
5
1
6
2
7
1
06802001
5
1
Order Information
3
Width
U
4
2
3
Description
Base/top cover, Al, 2 mm, passivated
Cover, Al die-cast, RAL 7016
Lateral cover plate, Al, 1 mm, with GND/earthing
connection, visible surfaces powder-coated, internal
surface conductive, RAL 9006
Top cover plate, Al, 1 mm, visible surface powder-coated,
RAL 9006
Case foot with anti-slip protection, Al, powder-coated,
RAL 7016
Assembly kit
Part no.
24571-395
Note
4
4
6
495.5
475.5 2)
462.25
448.7
427.3
177
156,81)
221,5
1) = open space between the horizontal rails
2) = max. mounting depth
01802054
5.12
Desk-top cases – Yair
ratiopacPRO air complete cases
airY
쮿 The case has 2 x 1/2 U clearance for ventilation
쮿 Case with cover strip; with pre-mounted components for
euroboards and backplane with insulation strip; no visible
screws
쮿 Symmetrical design, identical front and rear honeycomb grid
ventilation in top cover and base plate
06811001
13
Item Qty
without
EMC
1
2
2
2
3
4
11
15
10
“X”
4, 7, 8, 16
“Y”
“Z”
5, 7, 9
쮿 Available in two versions:
– unshielded (EMC shielding retrofittable)
– with EMC shielding fitted
6, 7, 9
14
1
4
4
5
6
7
2
1
6/8
8
9
10
11
4
1
2
12
4
13
14
15
16
17
2
1
18
1
2
17
11
3
15
12
13
01802052
“X”
“Y”
9
4
9
7
7
16
“Z”
7
5
8
6
01808055
A-A
h
H
A
Description
with
EMC
2
2
Side plate, Al, 1 mm, visible surface RAL 9006
4
Cover, die-cast zinc, RAL 7016, pre-mounted on
EMC version only
4
visible surface RAL 7016
2
Horizontal rail, centre (top/bottom), type H-ST, Al
1
6/8 4 U/7 U: threaded inserts, St, pre-mounted,
strips
4
Perforated strip, pre-mounted
4
1
Rear panel, Al, 2.5 mm
2
Top cover and base plate with honeycomb grid
ventilation, Al, 1 mm, internal surface conductive,
visible surface RAL 9006, with GND/earthing
connection
4
PC, black
2
Air filter
1
EMC support profile for side panel, fitted (kit)
4
EMC contact strip for cover plate, pre-mounted (kit)
4
1
Compartment seal, PE foam, self-adhesive,
temperature range -20 °C ... +85 °C
1
Order Information
D
w
7.5
A
01808053
3U
A-A
h
w
7.5
A
H
A
D
01808054
6U
Case
height H
U
4
4
4
4
4
4
4
7
7
7
7
7
PCB height h
U
3
3
3
3
3
3
3
6
6
6
6
6
Width
w
HP
28
42
42
63
84
84
84
42
63
84
84
84
Depth
D
mm
255.5
255.5
315.5
315.5
315.5
375.5
435.5
315.5
315.5
315.5
375.5
435.5
Unshielded
Part no.
EMC
shielded
Part no.
24572-025
24572-074
24572-026
24572-027
24572-075
24572-076
24572-028
24572-077
24572-029
24572-030
24572-078
24572-079
24572-031
24572-080
24572-040
24572-041
24572-088
24572-089
24572-042
24572-090
24572-043
24572-044
24572-091
24572-092
Note
쮿
쮿
쮿
쮿
Dimension drawings and mounting depths see page 5.16
5.13
RatiopacPRO air case
airY
쮿 The case has 2 x 1/2 U clearances for ventilation beneath and
above the board cage
06801005
쮿 Online download of 3D CAD data
쮿 Four versions:
– Bezels
– Front handles
– With 19" mounting brackets and front handles
3a: Bezel
01805055
01805056
01805057
01813057
bracket
bracket with front
handle
13
11
Item
1
2
Qty
2
2
3
3a
3b
3c
2
2
2
2
3d
2
4
4
11
2
12
13
14
4
2
1
4
3a (3b/3c/3d)
3
1
2
Description
RAL 9006
19" mounting angle, Al die-cast, powder-coated,
RAL 7016
1 Top cover and base plate, Al, 1 mm, internal surfaces
conductive,visible surfaces powder-coated, RAL 9006,
with GND/earthing connection, top cover and base plate
withventilation comb
Air filters
Note
11
쮿 Order information see following page
12
13
5.14
01813066
Order Information
Accessories
kit
4 pieces
PU 4 pieces
PA, UL 94 V-0, PU 4 pieces
24571-380
10603-002
20603-001
20603-002
20603-004
20603-003
Width W
Depth D
4U
Case height H
5U
PCB height h
7U
3
1
Bezels
01805055
Front handles
HP
28
28
42
42
42
63
63
63
63
84
84
84
84
84
28
28
42
42
42
42
63
63
63
84
84
84
84
84
mm
255.5
315.5
255.5
315.5
375.5
255.5
315.5
375.5
435.5
255.5
315.5
375.5
435.5
495.5
255.5
315.5
255.5
315.5
375.5
435.5
315.5
375.5
435.5
255.5
315.5
375.5
435.5
495.5
84
Part no.
Part no.
Part no.
24571-146
24571-149
24571-194
24571-197
24571-242
24571-245
24571-158
24571-206
24571-254
24571-161
24571-162
24571-209
24571-210
24571-257
24571-258
24571-170
24571-218
24571-266
24571-173
24571-174
24571-221
24571-222
24571-269
24571-270
24571-175
24571-223
24571-271
24571-182
24571-185
24571-230
24571-233
24571-278
24571-281
24571-186
24571-234
24571-282
24571-187
24571-188
24571-235
24571-236
24571-283
24571-284
24571-846
24571-894
24571-942
24571-849
24571-858
24571-897
24571-906
24571-945
24571-954
24571-861
24571-909
24571-957
24571-862
24571-863
24571-910
24571-911
24571-958
24571-959
24571-873
24571-921
24571-969
24571-874
24571-875
24571-922
24571-923
24571-970
24571-971
24571-882
24571-930
24571-978
24571-885
24571-886
24571-933
24571-934
24571-981
24571-982
24571-887
24571-935
24571-983
24571-888
24571-936
24571-984
255.5
24571-582
24571-630
24571-678
84
315.5
24571-585
24571-633
24571-681
84
375.5
24571-586
24571-634
24571-682
84
435.5
24571-587
24571-635
24571-683
01805057
84
495.5
24571-588
24571-636
24571-684
front handles
84
255.5
24572-670
24572-690
84
315.5
24572-673
24572-693
84
375.5
24572-674
24572-694
84
435.5
24572-675
24572-695
84
495.5
24572-676
24572-696
01805056
01805057
Note
쮿 Dimension drawings and mounting depths see page 5.16
5.15
RatiopacPRO air dimension drawings
Text
01805058
RatiopacPRO air with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle
Dimensions table RatiopacPRO air
Text
Height
H
in U in mm
4
5
7
Width
H
177.00
221.45
310.35
in mm
112.35
156.80
245.70
W
Depth
W1
W2
in HP in mm
in mm
in mm
in mm
28
42
63
84
42
63
84
42
63
84
177.62
248.74
355.42
462.10
248.74
355.42
462.10
248.74
355.42
462.10
198.12
269.24
375.92
482.60
269.24
375.92
482.60
269.24
375.92
482.60
142.82
213.94
320.62
427.30
213.94
320.62
427.30
213.94
320.62
427.30
164.42
235.54
342.42
448.90
235.54
342.42
448.90
235.54
342.42
448.90
D
w
d
Total depth
in mm
Usable depth
in mm
255.5
235.5
315.5
295.5
375.5
355.5
435.5
415.5
495.5
475.5
D1
d2
Plug-in depth
in mm
175
235
175
235
295
175
235
295
355
175
235
Board depth
in mm
160
220
160
220
280
160
220
280
340
160
220
295
355
280
340
175
160
235
220
295
355
280
340
5.16
ELECTRONICS PROTECTION
Radial fan unit for ratiopacPRO air
Main Catalogue
쮿 Only 1/2 U height
쮿 Ball-bearing radial fans
쮿 Fan holder in 4 widths and 2 depths
쮿 Air capacity 36 m³/h (free blowing) per fan
쮿 Air exhaust via perforation in cover plate
쮿 No mechanical modification to case necessary
쮿 Simple mounting
2
쮿 No restriction to rear mounting space
Delivery comprises (Kit)
1
4
Item
1
Qty
1
2
1-3
3
1
4
5
1
1
3
12309050
W
26,5
Description
Fan support, Al, 1.5 mm, with crimp sockets for
mounting the fans
Radial fan, ball bearing, 12 VDC;
airflow volume (50 Hz) 36 m³/h, free blowing;
power consumption 6.7 W;
connecting cable 300 mm, without plug (AWG 26);
noise level in dB (A): 47.0;
max. static pressure in Pa: 190;
max. ambient temperature: 60 °C;
fan housing and rotor: UL 94 V-0
Compartment seal, PE foam, UL 94, self-adhesive,
Terminal clamp, UL 90 V-0
Assembly kit
D
Order Information
70
8
Depth D: 129.8 / 189.9 mm for 160 mm / 220 mm euroboards
12309051
Width
Width
HP
28
42
63
84
mm
146.87
218.00
324.67
431.35
Number of
fans
1
1
2
3
Part no.
for PCB depth
160 mm
220 mm
24572-404
24572-408
24572-405
24572-406
24572-409
24572-410
24572-407
24572-411
Note
쮿 Further configurations available on request
쮿 Fans with tacho signal available on request
5.17
Desk-top cases – Y/ -air
EMC sealing front/rear panel to side panel
/ -ai rY
쮿 For vertical EMC shielding between sub-assemblies and side
panel
쮿 Scope of delivery sufficient for one case
1
Item
1
2
Qty
4
2
2
3
1
Description
EMC support profile, Al extrusion
EMC sealing (textile), core: foam,
sleeve: textile cladding with CuNi coating
Assembly kit
Order Information
rppr6639
For case height
U
2, 3-air
3, 4-air
4, 5-air
6, 7-air
5, 6-air
Part no.
24571-334
24571-331
24571-332
24571-333
24571-335
EMC sealing side panel to cover plate
/ -ai rY
쮿 For horizontal EMC shielding between side panels and cover
plates
Item
1
Qty
4
Description
Contact strip, stainless steel
Order Information
Depth
mm
255
315
375
435
495
Part no.
24571-338
24571-339
24571-340
24571-341
24571-342
RPPR6640
5.18
EMC sealing front/rear panel to horizontal rail
Main Catalogue
쮿 The contact strip is clipped onto the horizontal rail and sets up
the contact to front panel or rear panel
쮿 Can be used for rear horizontal rails (H-VT, L-VT) and all front
horizontal rails
Delivery comprises
Item
1
Qty
Description
10/100 Stainless steel EMC gasket
Order Information
rppr6739
Width
HP
28
42
63
84
84
Width
mm
131.78
202.9
304.8
416.3
416.3
Qty/PU
10
10
10
10
100
Part no.
24560-229
24560-231
24560-233
24560-235
24560-236
EMC sealing horizontal rail to horizontal rail
/ -airY
쮿 For shielding of two horizontal rails located directly above each
other with vertical division of the mounting height
Delivery comprises
Item
1
2
Qty
1
2
Description
Cover strip, Al, 1 mm
Contact spring, St, stainless
Order Information
BPA46548
Assembly tool
BZA45877
Length
HP
40
42
63
84
Assembly tool for EMC sealing,
St, stainless (horizontal rails),1 piece
Part no.
24562-520
24562-528
24562-540
24562-542
24562-563
24562-584
24560-271
aza45937
5.19
EMC front/rear panel, slotted, shielded
/ -ai rYMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days
쮿 No screws required for fixing
쮿 Special horizontal rails cover the edges of the front panel
(top and bottom) and prevent bowing of the front panel
H
W
01811055
Item
1
Qty
1
2
3
4
5
6
2
4
2
3
1
Description
Full-width front panel, Al, 2.5 mm,
front: anodised, rear: colour passivated
Horizontal rail, front; special for this front panel
EMC support profile
Contact strip horizontal rail - front panel
EMC textile gasket
Fixing material kit, user manual
Order Information
Front panel/horizontal rail
01811056
For case
height
U
2, 3-air
2, 3-air
2, 3-air
2, 3-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
Height H
mm
84.0
84.0
84.0
84.0
128.4
128.4
128.4
128.4
172.9
172.9
172.9
172.9
For case
width
HP
28
42
63
84
28
42
63
84
28
42
63
84
Width W
mm
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
Part no.
24572-599
24572-600
24572-601
24572-602
24572-603
24572-604
24572-605
24572-606
24572-607
24572-608
24572-609
24572-610
Note
쮿 To obtain a shielded case, all EMC sealings must be fitted
(front panel/rear panel - side panel; side panel - cover plate;
front panel/rear panel - horizontal rail; horizontal rail horizontal rail)
쮿 EMC sealing see from page 5.18
5.20
Full-width front panel, slotted, unshielded
/ -airY
쮿 Front panels can also be used as rear panels
쮿 Inserted between side panel and castings such as trim,
19" mounting bracket or handle
Delivery comprises
Item
1
Qty
1
Description
Front panel, Al, 2.5 mm,
Order Information
06801502
For case
height
U
2, 3-air
2, 3-air
2, 3-air
2, 3-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
5, 6-air
5, 6-air
5, 6-air
5, 6-air
6, 7-air
6, 7-air
6, 7-air
6, 7-air
Height H
For case width Width W
mm
84
84
84
84
128.4
128.4
128.4
128.4
172.9
172.9
172.9
172.9
217.3
217.3
217.3
217.3
261.8
261.8
261.8
261.8
HP
28
42
63
84
28
42
63
84
28
42
63
84
28
42
63
84
28
42
63
84
mm
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
141.9
213.2
319.7
426.4
Part no.
34571-617
34571-618
34571-619
34571-620
34571-605
34571-606
34571-607
34571-608
34571-609
34571-610
34571-611
34571-612
34571-621
34571-622
34571-623
34571-624
34571-613
34571-614
34571-615
34571-616
Note
쮿 Screw-fixed front panels see chapter Front panels, page 7.4
5.21
Rear panels with ventilation slots
7,2
쮿 Two versions:
unshielded, Al, 2.5 mm;
shieldable, Al extrusion (textile EMC seal, retrofittable)
ø 5,9 x 3,3
3
3,2
/ -ai rY
Z
25
쮿 Mounting on horizontal rails (top and bottom)
Delivery comprises
B
7,45
W
3
H
Item
1
2,5
3,7
3,7
W - 2,58
01802055
2,5
Unshielded
Description
Rear panel, Al, 2.5 mm, front: anodised, rear: iridescent
green chromated; unshielded or shieldable with
EMC seal (textile)
Order Information
7,45
Shieldable
Qty
1
01804050
Height
U
2, 3-air
2, 3-air
2, 3-air
2, 3-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
5, 6-air
5, 6-air
5, 6-air
5, 6-air
6, 7-air
6, 7-air
6, 7-air
6, 7-air
H
mm
84
84
84
84
128.4
128.4
128.4
128.4
172.9
172.9
172.9
172.9
217.3
217.3
217.3
217.3
261.8
261.8
261.8
261.8
Width W
HP mm
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
B
mm
101.6
157.5
208.3
101.6
157.5
208.3
101.6
157.5
208.3
101.6
157.5
208.3
101.6
157.5
208.3
unshielded
Part no.
shieldable
Part no.
30849-007
30849-014
20848-679
20848-680
30849-015
20848-681
30849-016
30849-008
20848-682
20848-633
30849-021
20848-634
30849-022
30849-023
20848-635
20848-636
30849-009
20848-656
30849-028
30849-029
20848-657
20848-658
30849-030
20848-659
30849-011
20848-744
30849-171
30849-172
20848-745
20848-746
30849-173
20848-747
30849-010
30849-035
20848-640
20848-641
30849-036
20848-642
30849-037
20848-643
쮿 Please order textile EMC seals separately
쮿 Assembly parts see page Chapter 7, Front panels
쮿 Rear/front panels without perforation see Chapter 7,
Front panels
쮿 Rear panels with fan available on request
Textile EMC seals
Front panels
Delivery comprises
Item
1
Qty
Description
10/100 Textile EMC seal, core: foam,
Order Information
04602054
5.22
Height
U
2, 3-air
3, 4-air
3, 4-air
4, 5-air
5, 6-air
6, 7-air
6, 7-air
Height
mm
52
97
97
142
187
232
232
Qty/PU
pieces
10
100
10
10
10
100
10
Part no.
21101-857
21101-854
21101-853
21101-858
21101-978
21101-856
21101-855
Tip-up feet and stacking aid/design element
/ -airY
쮿 Can be used instead of standard feet
쮿 Carrying capacity: 25 kg per foot
쮿 Mounting holes in bottom of casing
Delivery comprises ((kit))
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Anti-slip protection, TPE
Tip-up device, PA, UL 94 V-0
Assembly kit
Order Information
Tip-up foot
01802075
Description
Tip-up foot, silver, similar to RAL 9006
Tip-up foot, anthracite, similar to RAL 7016
Stacking aid/design element silver, similar to RAL 9006,
Stacking aid/design element anthracite, similar to
RAL 7016, PA, UL 94 V-0, PU 4 pieces
Part no.
20603-001
20603-002
20603-004
20603-003
Note
쮿 Tip-up feet are required to mount the stacking aid
01802076
Air filters for ratiopacPRO air
/ -airY
쮿 Retrofit mounting without reworking and tools
쮿 Filter replacement without opening the case, IP protection
retained
Item
1
2
3
Qty
1
1
1
Description
Filter holder, Al, 1 mm, powder-coated, RAL 9006
Filter mat, synthetic fibre
Self-adhesive fixings
Order Information
For case width
HP
28
42
63
84
Air filter
Part no.
Replacement
filter 1 piece
Part no.
24571-325
64571-033
24571-326
64571-034
24571-327
24571-328
64571-035
64571-036
쮿 To optimise the air supply, tip-up feet must be fitted to the case,
see page 5.23
rppr6658
5.23
Earthing kit
/ -ai rY
쮿 Forms the GND/earthing connections between side panels,
base plate, top cover and rear panel
쮿 Protective GND/earthing connections in accordance with:
– DIN EN 50178/VDE 0160
– DIN EN 60950/VDE 0805
– DIN EN 61010-1/VDE 0411 part 1
– DIN EN 61010-1A2/VDE 0411 part 1/A1
쮿 VDE tested
Order Information
Description
GND/earthing kit, Cu wire 1.5 mm2, PVC sleeve,
green/yellow
Part no.
24571-380
aza43284
5.24
Desk-top cases – Y
Front handles for retrofitting
Y
쮿 For conversion of cases with cover strip, 19" mounting bracket
or 19" mounting bracket with front handle
Delivery comprises
Item
1
Qty
2
Description
Order Information
Front handle for
RatiopacPRO 3 U
RatiopacPRO 4 U
RatiopacPRO 5 U
RatiopacPRO 6 U
RatiopacPRO air 3/4 U
RatiopacPRO air 4/5 U
RatiopacPRO air 6/7 U
RPPR6651
Part no.
24571-301
24571-302
24571-993
24571-303
24571-304
24571-305
24571-306
19" mounting brackets for retrofitting
Y
쮿 For conversion of cases with cover strip, front handle or 19"
Delivery comprises
Qty
2
Description
19" mounting bracket, Al diecast, powder-coated, RAL 7016
Order Information
RPPR6652
19" mounting angle
RatiopacPRO 2 U
RatiopacPRO 3 U
RatiopacPRO 4 U
RatiopacPRO 5 U
RatiopacPRO 6 U
RatiopacPRO air 4 U
RatiopacPRO air 5 U
RatiopacPRO air 7 U
Part no.
24571-994
24571-295
24571-296
24571-992
24571-297
24571-298
24571-299
24571-300
19" mounting bracket with front handle for conversion
YMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
mounting bracket
Delivery comprises
Qty
2
Description
Order Information
01813056
SCHROFF.PENTAIR.CO.UK
19" mounting angle
RatiopacPRO 2 U
RatiopacPRO 3 U
RatiopacPRO 4 U
RatiopacPRO 6 U
RatiopacPRO air 4 U
RatiopacPRO air 7 U
Part no.
24572-700
24572-701
24572-702
24572-704
24572-705
24572-707
Part number in bold face type: ready for despatch within 2 working days
5.25
Cable holder
Delivery comprises
46
9
26,5
19
Ø4
14
17
Ø3
,4
Ø3
Qty
2
2
1
3
1
Description
Cable bracket, ABS, UL V-94 0, RAL 7016,
detent for cables between 8 mm and 12 mm
Drilling template, two drilled holes each per bracket are
needed in rear panel
Assembly kit
Order Information
Ø 4,4
20,2
02908053
Item
1
02908052
Description
Cable holder
Part no.
24575-800
Air baffles for ratiopacPRO air
/ -ai rY
쮿 The air baffle (item 1) closes the space (1/2 U) between the rear
horizontal rail and base plate
Item
1
Qty
1
Description
Compartment seal, PE foam, UL 94 HF 1 + HF 2,
self-adhesive, temperature range: -40 °C ... +85 °C
Order Information
For case width
HP
42
63
84
Length
mm
218.4
325.1
431.8
Part no.
20833-351
20833-352
20833-353
Note
01805059
쮿 Fan rear panel available on request
쮿 Radial fan unit see page 5.17
Strap handles
/ -ai rY
쮿 Retrofittable without mechanical modifications to the case
쮿 Static load-carrying capacity 20 kg
Item
1
Qty
1
2
3
4
1
2
1
Description
Handle, steel spring, plastic-sheathed (flexible plastic),
RAL 7016
Side plate, Al, visible surfaces powder-coated, RAL 9006
Adaptor, Al die-cast
Assembly kit
Order Information
For case depth
06801515
5.26
mm
315
375
435
For case height 3 U,
4 U air
Part no.
For case height4
HE, 5 Uair
Part no.
24571-308
24571-309
24571-314
24571-315
24571-310
24571-316
Tip-up carrying handles
/ -airY
쮿 Adjustable in 30° increments
쮿 Static load-carrying capacity 30 kg
Item
1
2
3
4
5
06803006
RPA43897
For case height
U
3, 4, 4-air, 5-air
3, 4, 4-air, 5-air
3, 4, 4-air, 5-air
For case width
HP
42
63
84
A
mm
283,4
390,1
496,8
B
mm
279,4
386,1
492,8
C
mm
247,4
354,1
460,8
D
mm
115
195
195
Qty
1
1
2
2
2
Description
Carrying bar, Al extrusion, powder coated, RAL 9006
Handle shell, ABS, UL 94 V-0, RAL 7016
Tip-up protection, ABS, UL 94 V-0, RAL 7016
Notch device, Al die-cast
Cover cap, ABS, UL 94 V-0, RAL 7016
Order Information
For case
height
For case
width
For case
depth
U
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
3, 4-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
4, 5-air
HP
42
42
42
42
42
63
63
63
63
63
84
84
84
84
84
42
42
42
42
42
63
63
63
63
63
84
84
84
84
84
mm
255
315
375
435
495
255
315
375
435
495
255
315
375
435
495
255
315
375
435
495
255
315
375
435
495
255
315
375
435
495
Tip-up
carrying
handle
Part no.
Assembly kit
24571-320
24571-352
24571-320
24571-320
24571-353
24571-354
Part no.
24571-320
24571-355
24571-320
24571-321
24571-356
24571-352
24571-321
24571-353
24571-321
24571-321
24571-354
24571-355
24571-321
24571-356
24571-322
24571-322
24571-352
24571-353
24571-322
24571-354
24571-322
24571-322
24571-355
24571-356
24571-320
24571-359
24571-320
24571-320
24571-360
24571-361
24571-320
24571-362
24571-320
24571-321
24571-363
24571-359
24571-321
24571-360
24571-321
24571-321
24571-361
24571-362
24571-321
24571-363
24571-322
24571-322
24571-359
24571-360
24571-322
24571-361
24571-322
24571-322
24571-362
24571-363
Note
쮿 Cannot be used in conjunction with front handles
쮿 Assembly kit is required for tip-up carrying handle, please order separately
rpa43898
5.27
Torx panhead screws
/ -ai rY
Order Information
AZA45923
Description
Application
Material
Dimension
Qty/PU
Part no.
Countersunk
screw with Torx
For horizontal rail to side panel, with GND/
earthing function
St,
zinc-plated
M4 х 14
100
24571-371
Countersunk
screw with Torx
For horizontal rail to side panel, if guide rail is
bolted onto slot 1
St,
zinc-plated
M4 х 10
100
24571-372
Nut
Order Information
Description
Application
Material
Dimension
Qty/PU
Part no.
Square nut
For fixing: parts to side panels, support profiles,
mounting plates
St,
zinc-plated
M4
100
Dimension
Qty/PU
T8
1
64560-026
T20
1
64560-027
1
24560-271
1
24560-270
24560-140
AZA45921
Assembly tools
Order Information
Description
Application
Part no.
Torx screwdriver
AZA45925
Assembly tool for
horizontal rails
Exclusively to fix stainless steel
EMC gaskets in horizontal rails
aza45938
For mounting stainless steel
Assembly tool for front
EMC contact strips on front
panels
panels with lateral slot
aza45937
5.28
Mounting position ratiopacPRO
horizontal rails/central rails
front
rear
Text
2U
front
rear
3U
H-LD
H-LD
H-LD
H-LD
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
100
H-LD
H-LD
H-LD
H-LD
01805060
01802057
4 U (3 U + 1 U)
H-LD
H-LD
100
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-KD / H-LD / L-KD
H-LD
H-LD
01802058
5 U (1 U + 3 U + 1 U)
H-LD
H-LD
H-LD
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
100
H-LD
5 U (3 U + 2 U)
H-KD / H-LD / L-KD
H-LD
H-LD
01805061
6U
H-LD
H-LD
H-LD
H-LD
01805062
6 U (2 x 3 U)
H-LD
H-LD
233,35
100
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-KD / H-LD / L-KD
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
100
ST / VT / MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-LD
H-LD
H-LD
H-LD
01802059
01802060
H-LD
H-ST
L-ST
H-KD
H-VT
L-VT
L-KD
H-MZ
L-MZ
ST
VT
MZ
Horizontal rails can be bolted on in 15 mm depth grid
01808050
5.29
Mounting position ratiopacPRO air
front
rear
Text
front
rear
4-air U (1/2 U + 3 U + 1/2 U)
H-LD
H-LD
100
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-LD
H-LD
01802061
5-air U (1/2 U + 3 U + 1U +1/2 U)
H-LD
H-LD
100
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-KD / H-LD / L-KD
H-LD
H-LD
01802062
7-air U (1/2 U + 6 U + 1/2 U)
H-LD
7-air U (1/2 U + 3 U + 3U 1/2 U)
H-LD
H-LD
H-LD
233,35
100
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
ST / VT / MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
100
H-KD / H-LD / L-KD
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-LD
H-LD
H-LD
H-LD
01802063
H-LD
H-ST
L-ST
H-KD
H-VT
L-VT
L-KD
H-MZ
L-MZ
5.30
01802064
ST
VT
MZ
01808050
Front horizontal rails
Order Information
With long lip for insertion/extraction of CompactPCI
and VME64x boards
"heavy"
Type H-LD
long lip
"heavy"
Type H-KD
short lip
bza44980
Usable length
HP
Length
mm
28
147.32
42
218.44
63
325.12
84
431.80
M4 × 10, St, zinc-plated,
necessary if guide rail is
screwed to slot 1, PU 100 pieces
Threaded inserts see page
06197008
06197009
Al extrusion, anodised finish, contact surface conducting,
with printed HP markings
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34560-228
34560-242
34560-328
34560-342
34560-263
34560-363
34560-284
34560-384
24571-372
24571-372
5.35
5.35
1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a
multiple thereof
"light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg
5.31
Rear horizontal rails
Main Catalogue
Order Information
For indirect backplane fixing
For direct backplane fixing
04400001
"heavy"
Type H-ST
standard
06105074
Usable length
Length
HP
mm
28
147.32
42
218.44
63
325.12
84
431.80
Torx panhead screw, 4 x 10
Perforated rail for connector
mounting with insulation strip
see page
Z-rail for connector mounting
without insulation strip see page
Insulation strips see page
For direct fixing of connectors to
EN 60603-2 (DIN 41612)
04400002
"heavy"
Type H-VT
long lip
06197011
04400003
"heavy"
Type H-MZ
with Z-rail
06197013
06197015
surface conducting, with printed HP
markings
markings
markings
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34560-528
34560-728
34560-928
34560-542
34560-742
34560-942
34560-563
34560-584
34560-763
34560-784
34560-963
34560-984
24571-372
24571-372
24571-372
5.35
5.35
5.35
5.35
5.35
5.35
multiple thereof
5.32
Horizontal rails rear, centre
Main Catalogue
Order Information
For indirect mounting of backplanes
via insulation strip
For direct backplane mounting
04400001
Type ST
06108090
04400002
Type VT
06197016
04400003
Type MZ
06197017
06197018
Al extrusion, finish anodised,
conductive contact surface;
horizontal rail type AB (AB = support)
is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards;
without marking
without marking
without marking
Usable length
Length
HP
mm
28
147.32
42
218.44
63
325.12
84
431.80
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34561-028
34561-042
34561-128
34561-142
34561-228
34561-242
34561-063
34561-163
34561-263
34561-084
24571-372
34561-184
24571-372
34561-284
24571-372
5.35
5.35
5.35
5.35
multiple thereof
5.33
Horizontal rails (type AB) for rear I/O guide rails
Main Catalogue
Order Information
For CompactPCI in rear I/O area
12,75
AB
H - ST
9,75
15 12,75
H - KD
3
06108009
Type AB
H - ST
AB
H - KD
06108069
06197019
without marking
Usable length
Length
HP
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail
to side panel
1 piece (SPQ 10)1)
34561-520
34561-528
34561-540
34561-542
34561-563
34561-584
34561-501
24560-130
multiple thereof
Note
쮿 All horizontal rails without print
쮿 1000 mm version without M4 thread in end
5.34
Threaded inserts, perforated strips, insulation strips
Threaded insert
M2.5
M3
Perforated strip
(item 1)
Insulation strip
5
2
5,0
8
06103056
Required for fixing the front panel to the horizontal rail; St,
zinc-plated; use collar screw 12.3 mm, see page
6.66
BZA45853
For centring shielded plug-in units,
Al, 1 mm, please order fixing grub screw
separately
BZ6749
For insulated mounting of backplane;
PBT UL 94 V-0, grey
Usable length
Length
Length
Length
HP
mm
1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm
PU 10 pieces2)
28
146.82
34561-328
147.12
30845-197
144.20
24560-828
42
217.94
218.24
210.40
34561-342
30845-211
24560-842
63
324.62
324.92
316.88
34561-363
30845-232
24560-863
84
431.30
34561-384
34561-484
431.60
30845-253
428.64
24560-884
Accessories
Grub screw M2.5 x 8, PU
21100-276
100 pieces
Grub screw M2.5 x 9, PU
21101-359
100 pieces
Grub screw M3 x 8, PU
21100-646
100 pieces
the SPQ quantity or a multiple thereof
2) Part no. includes one packing unit (PU); delivery is exclusively made in PU
Z-rails, perforated rails
Z-rail for connectors
DIN EN 60603-2, DIN 41612
31-pin, DIN 41617
item 1
Perforated rail
EN 606032, DIN 41612
item 1
172,5
175,5
172,5
BZA45849
5
12,7
5
9,7
BZA45850
BZA45848
12,7
3,0
5
2
2
1
1
3
3
06708063
Usable length
Length
HP
mm
28
142.24
42
213.36
60
304.80
84
426.70
Torx panhead screw, to fix connector to
perforated rail,, M2.5 × 7, PU 100 piecesItem 3
Torx panhead screw, to fix perforated rail to
horizontal rail, M2.5 × 10, PU 100 pieces Item 2
06708051
For connector mounting with ST
horizontal rails, please order
threaded insert and screw
separately
separately
For connector mounting with VT
separately
1 piece
PU 4 pieces
30822-047
1 piece
30822-065
30822-089
30819-783
30819-808
20822-047
20822-048
24560-147
24560-147
24560-147
24560-148
24560-148
24560-148
30822-033
20822-049
20822-050
5.35
Divider plates
Order Information
Divider plates
Mounting position for stainless
steel EMC gasket
textile EMC gasket
front
rear
front
bpa45911
rear
06105078
Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space
requirement on component side 2 mm; mounting direction varies with
shielding design (EMC stainless steel or textile gasket); retrofitting the
divider plate in an already-assembled subrack/case will first
require dismantling of the horizontal rails; where front panels are
unshielded, both mounting directions are possible
bpa45912
Height
U
3
3
6
6
5.36
Depth
mm
160
220
160
220
A
mm
158.3
218.3
158.3
218.3
B
mm
135.0
195.0
135.0
195.0
H
mm
113.5
113.5
246.9
246.9
1 piece
34562-761
34562-762
34562-763
34562-764
Mounting plates
Order Information
Mounting plate
Assembly strip for partial widths
bpa45875
bpa46557
Al, 1.5 mm; for mounting over partial St, 2 mm, zinc-plated; is bolted from
width, please order assembly strips front to rear onto the horizontal rails;
to fix mounting plates
separately
06812002
Width
Board lengths
HP
mm
mm
28
146.88
160
28
146.88
220
28
146.88
280
28
146.88
340
42
217.99
160
42
217.99
220
42
217.99
280
42
217.99
340
63
324.67
160
63
324.67
220
63
324.67
280
63
324.67
340
84
431.35
160
84
431.35
220
84
431.35
280
84
431.35
340
Assembly kit for mounting plate
PU 1 kit (Torx countersunk screw M4 x 5, St, zincplated, 12 pieces; screw M4 x 6, St, zinc-plated,
10 pieces; M4 square nut, St, zinc-plated,
10 pieces)
Assembly kit for assembly strips of mounting
plate
Torx screw
M2.5 × 5, St, zinc-plated, PU 100 pieces
1 piece
1 piece
34562-745
34562-749
30840-021
30840-033
34562-753
30840-045
34562-757
34562-746
30840-057
30840-021
34562-750
30840-033
34562-754
34562-758
30840-045
30840-057
34562-747
30840-021
34562-751
34562-755
30840-033
30840-045
34562-759
30840-057
34562-748
34562-752
30840-021
30840-033
34562-756
30840-045
34562-760
30840-057
24560-184
24560-146
Note
쮿 Please order fixing material for assembly of mounting plate
separately
쮿 A guide rail can be mounted on the first and last slot position
쮿 4.4" and "reinforced" guide rails cannot be used
5.37
Horizontal board installation
Order Information
Front frame for EMC shielding
Board cage
27
3.9
8=
54
Front frame, unshielded
TE
06102073
,98
=5
4T
E
bpa45913
H
273
h
w
bza43061
Struts die-cast zinc;
horizontal rails front and rear;
threaded insert, St, zinc-plated;
fixing material kit;
for horizontal mounting of
double-height euroboards in
3 or 4 U high subracks/cases;
54 TE space required; please
order front frame for EMC
shielding separately
2 horizontal covers,
AI, 2.5 mm, front anodised,
rear iridescent green chromated;
2 vertical trims, Al extrusion,
clear passivated;
stainless steel EMC gasket;
front frame forms the contact
between subrack and the subassemblies
Al, 2.5 mm, clear anodised;
front frame with cut-out,
clear internal width w =
266.35 mm
PU 1 kit
PU 1 kit
1 piece
bpa45914
Height
U
Usable
height h
HP
Other dimensions and options
3
24564-109
34564-108
3
24564-109
34564-109
4
28
24564-217
24564-209
34564-208
24560-270
Horizontal rail,
front
Horizontal rail,
rear
Assembly tool, for mounting the
EMC gasket (stainless steel)
* For direct backplane mounting
Note
쮿 Please order front frame separately
5.38
Combined mountings (6 U and 2 x 3 U one above the other)
Order Information
Combined mounting
Horizontal and vertical
subdivision (incl. front panel for
stainless steel EMC gasket)
Alternative front panels for
combined mounting
Unshielded front
Front panel for
panel, 6 U, 2 HP
textile EMC gasket,
item 6
6 U, 2 HP
item 6
Splitting extrusion
For combined
mounting
Item 2
2
4
2
1,3
1,3
4
6
bpa46549
bza42182
Width pitch T1:T2
HP
20:62
40:42
42:40
63:19
84:0
Countersunk screw with Torx
M4 × 14, zinc-plated, PU 100 pieces
fixing splitting extrusion/horizontal rail
Panhead screw
M2.5 × 10, St, zinc-plated, PU 100 pieces
fixing horizontal rail/splitting extrusion
Pozidrive/slotted collar screw
M2.5 x 12.3, St, nickel-plated, PU 100 pieces
M2.5, black, zinc-plated, PU 100 pieces
Washer, 2.7 x 5 x 1, plastic PA 6, PU 100 pieces
Textile gasket, core: foam,
sleeve: textile cladding with CuNi coating,
UL 94 V-0, PU 10 pieces
bpa46549
bpa46549
bza45857
Item 1: 2 front horizontal rails (HKD), Al extrusion, anodised;
item 2: 2 rear horizontal rails (AB),
item 3: threaded insert, St,
zinc-plated;
item 4: Zn diecast support member;
item 6: front panel 2 HP, 6 U,
shielded; with EMC stainless steel
gasket (84:0 without items 4, 6)
Al, 2.5 mm,
front anodised,
chromated
Al, 2.5 mm, U-profile
with notch, 6 U, 2 HP
6 U, die-cast zinc;
splitting extrusion is
inserted in the
grid holes of the
horizontal rail;
the splitting extrusion
can be bolted
PU 1 kit
1 (SPQ 5)
1 piece (SPQ 5)1)
1 piece
30847-472
30849-140
64560-010
24560-145
24560-179
21101-101
21101-101
21101-102
21101-102
21101-121
21101-121
21101-855
24562-420
24562-440
24562-442
24562-463
24562-484
multiple thereof
쮿 Subdivision of the 6 U assembly area into:
– 2x3U
– 1x6U
쮿 Designed to accept Euroboards (100 mm high) and double
Euroboards (233.35 mm high)
Note
쮿 Please order EMC gasketing kit for horizontal rails separately,
see page 5.19
쮿 Please order perforated strips for horizontal rails separately,
see page 5.35
쮿 Please order rear centre horizontal rail separately, see page
5.33
5.39
Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm
Main Catalogue
Order Information
Assembly
- can be clipped into Al extruded
horizontal rails
- can be clipped into 1.5 mm thick
plates
Standard
For plug-in units and frame type plug-in units
With DIN connector fixing as standard
Storage temperature
from -40 °C ... 130 °C
06101001
Board
lengths
mm
70
70
160
220
280
340
160
220
Groove
width
mm
2
2
2
2
2
2
2.5
2.5
06101501
Up to 220 mm length, PBT, UL 94 V-0; from 280 mm length,
multi-piece, end piece PBT, UL 94 V-0,
central section Al extrusion
PBT, UL 94 V-0, red,
connector is clipped directly onto the guide rails;
for euroboards 100 x 160 mm or 100 x 220 mm only
PU 10 pieces2)
1 pair (SPQ 10)1)
24560-351
64560-074
24560-353
24560-379
64560-075
Colour
mm
red
grey
red
red
red
red
red
red
24560-380
Accessories
Retention screw,
PU 100 pieces
24560-141
ESD clip, PU 50 pieces
24560-255
multiple thereof
Description of accessories see from page 6.43
5.40
Guide rails type "accessories", one-piece,
Main Catalogue
Order Information
Assembly
- can be clipped into horizontal rails
in Al extrusion
plate
Guide rail type
"Accessories" strengthened
"Accessories"
For heavy modules,
Al extrusion, silver,
robust version
Storage temperature
from -40 °C ... +130 °C
06102002
Board
lengths
mm
100
160
160
220
220
Groove
width
mm
2
2
2
2
2
280
2
340
2
400
2
160
220
280
340
400
2.5
2.5
2.5
2.5
2.5
bza46554
06102005
> 280 mm length, multi-piece,
end piece PBT, UL 94V-0,
middle section Al extrusion
PBT UL 94V-0, red;
support beam of guide rails
adds to strengthening
Al extrusion; is screwed to horizontal rail
"heavy" with retention screws
PU 10 pieces2)
1 piece (SPQ 50)1)
24560-373
Colour
mm
red
red
grey
red
grey
red/
silver
red/
silver
red/
silver
silver
silver
silver
silver
silver
64560-076
1 piece (SPQ 10)1)
34562-881
24560-374
64560-078
34562-882
24560-375
64560-080
34562-883
24560-376
34562-884
34562-885
34564-881
34564-882
24560-141
24560-141
24560-157
34564-883
34564-884
34564-885
Accessories
Retention screw,
PU 100 pieces
Board locking C, red,
PU 10 pieces
Board handle C, red,
PU 10 piecesdescription
Identification strips for board
handle, red, PU 1 sheet =
438 pieces
Coding see page
24560-255
24560-377
24560-378
60817-228
6.43
please order at least the SPQ quantity or a multiple thereof
5.41
Guide rails for CompactPCI, VME64x with coding,
4.4" PCBs, groove width 2 mm and 2.5 mm
Main Catalogue
Order Information
Assembly
horizontal rails
- can be clipped into1.5 mm thick
plates
For CompactPCI, VME64x with coding
In accordance with IEEE 1101.10 and Offset 0.1" for power supply units in
IEC 60297-3-103
IEC 60297-3-103
For 4.4" PCBs
Storage temperature
06106001
Board
lengths
mm
70
70
160
160
160
220
220
220
160
220
220
280
280
340
340
Groove
width
mm
2
2
2
2
2
2
2
2
2.5
2.5
2.5
2.5
2.5
2.5
2.5
Colour
mm
red
grey
red
grey
green
red
grey
green
red
red
grey
red
grey
red
grey
06106002
06104009
One-piece for groove width 2 mm, PBT,
UL 94 V-0;
multi-piece at groove width 2,5 mm,
end-piece PBT, UL 94 V-0,
center piece Al profile
PBT, UL 94 V-0,
for installation of power supplies in
CompactPCI systems or
plug-in units with SMD placement
One-piece, PBT, UL 94 V-0;
for 4.4" PCBs or drive units
PU 10 pieces2)
PU 10 pieces2)
PU 10 pieces
24560-355
24560-360
24560-356
24560-358
24560-359
24560-361
24560-362
24561-332
24561-342
24560-255
24560-256
24560-256
24560-141
24560-141
24560-158
20817-501
20817-501
24561-330
24561-340
24561-331
24561-341
Accessories
ESD clips, for alignment pin,
PU 50 pieces
Retention screw, PU 100 pieces
Coding peg, PU 100 pieces
multiple thereof
Note
쮿 Reinforcement for plastic profiles (PVC) > 280 mm depth
5.42
Air baffle for slots
Main Catalogue
Order Information
Air baffle
without front panel
Air baffle with front panel
U front panel
front panel with lateral
for textile EMC gasket
groove for stainless steel
EMC gasket
06108085
06108087
Air baffle, Al, 1 mm;
front anodised, rear conductive;
EMC gasket (stainless steel);
fixing material kit prevents an air
short- circuit where slots are
unoccupied;
is pushed into the groove
of the guide rails
Al, 1 mm, incl. assembly kit;
prevents an air short circuit in
unoccupied slot positions;
of the guide rails
06108088
Air deflector, Al, 1 mm,
front panel, Al extrusion, 2.5 mm,
EMC gasket (textile);
short-circuit where slots are
unoccupied;
of the guide rails
06101507
Depth
Width
mm
HP
160
4
160
4
160
8
160
8
160
12
160
12
220
4
220
4
220
8
220
8
220
12
220
12
Assembly tool
for EMC gasket (stainless steel),
1 piece
Height
U
3
6
3
6
3
6
3
6
3
6
3
6
1 piece
1 piece
1 piece
34562-823
20848-712
20848-728
34562-826
34562-833
20848-720
20848-714
20848-736
20848-730
34562-836
20848-722
20848-738
34562-843
34562-846
20848-716
20848-724
20848-732
20848-740
34562-824
20848-713
20848-729
34562-827
34562-834
20848-721
20848-715
20848-737
20848-731
34562-837
20848-723
20848-739
34562-844
34562-847
20848-717
20848-725
20848-733
20848-741
24560-270
Note
쮿 Air baffle for 280 mm deep and for 80 mm rear I/O boards
5.43
i Main Catalogue
Desk-top cases – i
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
05809001
Subracks/
05806052
Front panels,
Easy access provided by
removable cladding parts
Extremely robust
one-piece die-cast
frame
05806050
05806055
Non-sensitive,
scratch-resistant finish
through powder coating
Low weight
05806056
Power supply
05806054
Wide accessory
programme with acrylic
glass front hoods,
carrying handles, ...
Assembly possibility
for euroboards and
backplanes
05806053
EMC version
05806051
VDE-compliant
GND/earthing
noa44075
Backplanes . . . 10
Standards
쮿 Internal dimensions in accordance with
IEC 60297-3-101
Connectors, front
panel component
쮿 Ingress protection IP 20 in accordance with
IEC 60529
쮿 EMC test in accordance with VG 95373 part 15
쮿 Protective GND/earth connections in accordance
with:
5.44
Desk-top cases – i
Overview . . . . 5.44
Aluminium case for 19" components to IEC 60297-3-100
or individual electronics assemblies
iMain C atalogue
쮿 Front frame and side panels in aluminium
쮿 Extensive accessories, matched to portable applications
쮿 Basic level shielding from basic versions up,
extended EMC shielding retrofittable
쮿 Design alternative to compacPRO
Desktop cases
쮿 Complete case (pre-assembled)
– Prepared for 19" components to IEC 60297 for installation
of euroboards
– Basic level shielding from basic versions up, extended
– Height 3 U, 6 U
propacPRO
Complete cases 3,
6 U, unshielded/
shielded . . . . . . . . 5.46
Cases 2, 3 U . . . . . 5.50
Cases 4, 6 U . . . . . 5.51
Cases for tip-up
carrying handle 3,
4 U. . . . . . . . . . . . . 5.52
Dimensions . . . . . . 5.53
쮿 Cases
– Pre-assembled cases as basis for individual components
or 19" components (IEC 60297)
– Height: 2 U, 3 U, 4 U, 6 U
– 3 U and 4 U cases prepared for tip-up carrying handle
EMC shielding . . . 5.55
Accessories
Front panels . . . . . 5.54
Rear panels . . . . . . 5.55
Design elements . 5.58
Lateral covers . . . 5.59
Handles . . . . . . . . . 5.60
Air filters . . . . . . . . 5.61
05809003 05806003
Hoods . . . . . . . . . . . 5.62
Accessories
Mounting plates . . 5.64
GND/earthing kit . 5.65
Cable holder . . . . 5.65
Mounting position
horizontal/central
rails . . . . . . . . . . . . . 5.66
Horizontal rails .
5.67
Threaded inserts . 5.68
Z-rails,
perforated rails . . 5.69
Combined
mounting . . . . . . . . 5.70
05809002
Horizontal board
assembly . . . . . . . . 5.71
Tip-up feet . . . . . . . 5.72
Guide rails and
ESD clips . . . . . . . . 5.73
Divider plates . . . . 5.75
e.g. modifications (special colours, special depths,
cut-outs in top cover, base plate or side panels)
Air flow barrier . . . 5.75
ServicePLUS . . 5.4
30407004
5.45
Desk-top enclosure – i
Complete case,
EMC shielded
iMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Desk-top case with pre-configured components, in accordance
with IEC 60297-3-101; prepared for 19" components such as
쮿 Ventilation slots in base plate
쮿 Rear panel with vent slots
Delivery comprises (Items 1-7, 9 and 10 fitted)
Item
1
2
Qty
3U
1
2
6U
1
4
3
1
1
4
1
1
5
2
2
6
7
2
2
8
4
4
9
2
2
10a
2
2
5
10b
2
2
7
11
2
2
12
1
13
1
1
14
2
2
15
10/
17
1
1
1
1
05809004
3U
Description
13
3
12
10 b
11
14
2
1
9
6
15
10 a
4
8
9
Maximum mounting depth = D - 45
(Distance: front panel - rear panel)
5.46
05806106
Frame, Al die-cast, powder-coated, RAL 7016
Side panel, Al extrusion, powder-coated, RAL 9006,
with EMC side panel gasketing
Cover plate, Al, 1 mm, internal surface conductive,
visible surface powder-coated, RAL 9006,
with GND/earthing tag
Base plate, Al, 1 mm, internal surface conductive,
visible surface powder-coated, RAL 9006, with
GND/earthing tag, base plate with 4 rows of
ventilation slots
End piece for rear, ABS, RAL 7016, UL 94 V-0;
can be used as a foot when case is used in vertical
position
Adaptor bracket (only at 6 U)
Cover trim for side panel, Al extrusion,
Case foot with anti-slip protection, PC, black,
UL 94 V-0
Lateral trim, Al extrusion, visible surface painted,
RAL 7016 with EMC sealing (textile)
Horizontal rail, Al extrusion, with threaded insert,
St, M2.5; perforated strip, Al, 1 mm, EMC contact strip
between front panel - horizontal rail - cover plate
St, M2.5; EMC contact strip between rear panel horizontal rail - cover plate
Centre horizontal rail top/bottom, Al extrusion,
with threaded insert, St, M2.5 and insulation strip,
PBT, UL 94 V-0
(for indirect backplane mounting); enclosed loose
Centre horizontal rail, Al extrusion, anodised,
conductive surfaces, with two threaded inserts,
St, M2.5 and two insulation strips, PBT, UL 94 V-0
Rear panel with perforation, Al, 2.5 mm, anodised,
with EMC sealing (textile) affixed
EMC support profile rear, Al extrusion,
Guide rail for 160 mm board length, PBT, UL 94 V-0,
28/42 HP 10 pieces,
63/84 HP 20 pieces
GND/earthing kit
Assembly kit
Complete cases, EMC shielded
Main Catalogue
155,5
289,0
Usable width
W2
W2
HP
mm
28
147.3
28
147.3
42
218.4
42
218.4
42
218.4
63
325.1
63
325.1
63
325.1
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
130,0
262,8
Order Information
W2
112,3
245,7
W1
05809051
Width W1
W1
mm
185.9
185.9
257
257
257
363.7
363.7
363.7
470.3
470.3
470.3
470.3
470.3
470.3
470.3
Depth D
D
mm
266
326
266
326
386
266
326
386
266
326
386
446
506
326
446
Height
U
3
3
3
3
3
3
3
3
3
3
3
3
3
6
6
Part no.
24576-101
24576-102
24576-103
24576-104
24576-105
24576-106
24576-107
24576-108
24576-109
24576-110
24576-111
24576-112
24576-113
24576-121
24576-122
Note
쮿 Dimension drawings of side panel see from page 5.53
3U
6U
05806060
05806062
5.47
Complete cases,
unshielded
Main Catalogue
Item
1
2
3
Qty
3U
1
2
1
6U
1
4
1
Description
4
1
1
5
2
2
6
7
2
2
8
4
4
9
2
2
10
2
2
11
2
2
12
1
13
1
1
14
15
4
10/
1
4
10/
1
05809004
3U
05806105
16
17
GND/earthing tag
ventilation slots
can be used as a foot for use in vertical position
UL 94 V-0
St, M2.5
Rear horizontal rail, Al extrusion, with threaded
insert, St, M2.5 and insulation strips, PBT, UL 94 V-0
Rear panel with perforation, Al, anodised, 2 mm
at 28, 42 and 63 HP, 2.5 mm at 84 HP
Support member for rear panel, Zn die-cast
28/42 HP 10 pieces, 63/84 HP 20 pieces
GND/earthing kit
Assembly kit
5.48
Complete cases, unshielded
Order Information
Main Catalogue
W1
155,5
289,0
130,0
262,8
112,3
245,7
W2
05809051
Usable width
W2
W2
HP
mm
28
147.3
28
147.3
42
218.4
42
218.4
42
218.4
63
325.1
63
325.1
63
325.1
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
84
431.8
Width W1
Depth D
Height
mm
185.9
185.9
257
257
257
363.7
363.7
363.7
470.3
470.3
470.3
470.3
470.3
470.3
470.3
mm
266
326
266
326
386
266
326
386
266
326
386
446
506
326
446
U
3
3
3
3
3
3
3
3
3
3
3
3
3
6
6
Part no.
24576-001
24576-002
24576-003
24576-004
24576-005
24576-006
24576-007
24576-008
24576-009
24576-010
24576-011
24576-012
24576-013
24576-021
24576-022
Note
3U
6U
05806060
05806062
5.49
Cases, 2 and 3 U, unshielded
Main Catalogue
쮿 Prepared for GND/earthing
Delivery comprises (kit, items 1 - 5 fitted)
05806001
Item
1
2
3
Qty
1
2
1
4
1
5
2
6
7
4
1
Description
Base plate, Al, 1 mm, internal surface conductive, visible
surface powder-coated, RAL 9006, with GND/earthing
tag, base plate with 4 rows of ventilation slots
Case foot with anti-slip protection, PC, black, UL 94 V-0
Assembly kit
Order Information
05806057
05806077
Cross-section 2 U, 3 U
Usable width
Width W1
Depth D
2U
W2
W2
Part no.
HP
mm
mm
mm
28
147.3
185.9
266
28
147.3
185.9
326
42
218.4
257
266
14576-021
42
218.4
257
326
14576-023
42
218.4
257
386
63
325.1
363.7
266
14576-041
63
325.1
363.7
326
14576-043
63
325.1
363.7
386
14576-045
84
431.8
470.3
266
84
431.8
470.3
326
84
431.8
470.3
386
84
431.8
470.3
446
84
431.8
470.3
506
Accessories
GND/earthing kit Cu wire 1.5 mm2, PVC sleeve,
green/yellow, links side panels, base, cover and rear
panel, PU 1 piece
3U
Part no.
14576-101
14576-103
14576-121
14576-123
14576-125
14576-141
14576-143
14576-145
14576-161
14576-163
14576-165
14576-167
14576-169
21102-001
Note
쮿 Case, 3 U with side panel for tip-up carrying handle,
see page 5.52
쮿 Dimensions see page 5.48
쮿 Dimensions side panel, see page 5.53
2U
05806059
3U
05806060
5.50
Cases, 4 and 6 U, unshielded
Main Catalogue
Delivery comprises (kit, items 1 - 6 fitted)
Item
05806003
1
2
3
Qty
4U
1
2
1
6U
1
4
1
Description
4
1
1
5
2
2
6
7
2
2
2
8
4
4
9
1
1
ventilation slots
Adaptor bracket, Al
UL 94 V-0
Assembly kit
Order Information
05806058
05806078
Usable width
Width W1
Depth D
4U
W2
W2
Part no.
HP
mm
mm
mm
42
218.4
257
266
14576-221
42
218.4
257
326
14576-223
63
325.1
363.7
266
14576-241
63
325.1
363.7
326
14576-243
63
325.1
363.7
386
14576-245
63
325.1
363.7
446
14576-247
84
431.8
470.3
326
84
431.8
470.3
386
14576-265
84
431.8
470.3
446
14576-267
84
431.8
470.3
506
14576-269
Accessories
panel, PU 1 piece
6U
Part no.
14576-463
14576-465
14576-467
14576-469
21102-001
Note
쮿 Case, 4 U with side panel for tip-up carrying handle,
see page 5.52
05806061
4U
6U
05806062
Part number in normal type: ready for despatch within 10 working days
5.51
3 U and 4 U cases, unshielded,
with holes for tip-up carrying handle
쮿 Prepared for fitting of tip-up carrying handle
Item
05812006
1
2
Qty
3U
1
2
4U
1
4
Description
3
1
1
4
1
1
5
2
2
6
2
7
4
4
8
1
1
3
5
2
1
4
Order Information
7
05812050
W1
155,5
200,0
112,3
156,8
130,0
174,0
W2
05812051
D
69,0
D
32,5
69,0
17,0
17,0
Ø 4,6
17,0
Ø 4,6
Usable width
Width W1
Depth D
3U
W2
W2
Part no.
HP
mm
mm
mm
42
218.4
257.0
326
14577-123
42
218.4
257.0
386
14577-125
63
325.1
363.7
326
14577-143
63
325.1
363.7
386
14577-145
84
431.8
470.3
326
14577-163
84
431.8
470.3
386
14577-165
Accessories
panel , PU 1 piece
Tip-up carrying handle for 42 HP case width, PU 1 kit
Tip-up carrying handle for 63 HP case width, PU 1 kit
Tip-up carrying handle for 84 HP case width, PU 1 kit
4U
Part no.
14577-223
14577-243
14577-245
14577-265
21102-001
24576-071
24576-072
24576-073
Note
195,3
11,4
15
Ø 4,6
Ø 4,6
4
4
3U
7,2
15
7,2
33,05
150,9
121,95
Ø 10,4
Ø 10,4
121,95
32,5
17,0
Side panel, Al extrusion, powder-coated, RAL 9006;
with drill holes for tip-up carrying handle
with GND/earthing tag, base plate with 4 rows of
ventilation slots
UL 94 V-0
Assembly kit
05812052
4U
05812053
5.52
Dimensions
Extruded side panel 2 U
Extruded side panel 3 U
Text
05806079
Extruded side panel 4 U, right
05806080
Extruded side panel 4 U, left
05806081
Extruded side panel 6 U
05806082
Dimensions table
For case depth
D
d
n
mm
266
326
386
446
506
mm
221.6
281.6
341.6
401.6
461.6
mm
210
270
330
390
450
14
18
22
26
30
Note
A side panel for case 6 U consists of 2 pieces 3 U extruded side panels
Side panel with horizontal rail
D
12,25
05806083
e = D - 62,1
05806107
5.53
Front panel, unshielded,
for mounting on case frame
Main Catalogue
Delivery comprises
Item
1
Qty
1
2
1
Description
Full-width front panel, Al, 2 mm (on 84 HP = 2.5 mm),
anodised, cut edges plain
Assembly kit
Order Information
05806063
For case
height
U
2
2
2
3
3
3
3
4
4
4
6
For case
width
HP
42
63
84
28
42
63
84
42
63
84
84
A
B
C
D
Part no.
mm
238.7
345.4
452.0
167.6
238.7
345.4
452.0
238.7
345.4
452.0
452.0
mm
230.0
336.7
443.3
158.9
230.0
336.7
443.3
230.0
336.7
443.3
443.3
mm
74.0
74.0
74.0
118.5
118.5
118.5
118.5
162.9
162.9
162.9
251.8
mm
84.0
84.0
84.0
128.5
128.5
128.5
128.5
172.9
172.9
172.9
261.8
20850-128
20850-129
20850-130
20850-134
20850-135
20850-136
20850-137
20850-142
20850-143
20850-144
20850-158
쮿 EMC front panel see chapter Front Panels, page 7.7
PPA43756
Front panel, 1 U, unshielded, for 4 U case,
for mounting on horizontal rails
Main Catalogue
Delivery comprises
Item
1
Qty
1
Description
Front panel, Al, 2.5 mm, front anodised,
Order Information
Width
HP
28
42
63
84
A
mm
141.9
213.0
319.7
426.4
B
mm
127.0
198.1
304.8
411.5
C
mm
101.6
157.5
203.2
Front panel
Part no.
20850-423
20850-424
20850-425
20850-426
Note
05806064
쮿 Please order items 2, 3 and 4 separately
Width
HP
28
42
63
84
05806065
5.54
SCHROFF PRODUCT CATALOG E 09/2017
Item 2
EMC gasket, front
panel/horizontal
rail PU 10 pieces
Part no.
Item 3
EMC gasketing kit
horizontal rails,
1 piece
Part no.
Item 4
Horizontal rail
type H-KD,
1 piece (SPQ 10)1)
Part no.
24560-229
24560-231
24562-528
24562-542
34560-228
34560-242
24560-233
24562-563
34560-263
24560-235
24562-584
34560-284
7,2
쮿 Two versions: unshielded, Al, 2.5 mm
shieldable, Al extrusion (textile EMC gasketing retrofittable)
ø 5,9 x 3,3
3
Delivery comprises
Item
1
Qty
1
H
25
3,2
Main Catalogue
Z
Description
front: anodised, rear: iridescent green chromated;
unshielded or shieldable with EMC sealing (textile)
B
7,45
W
3
Order Information
7,45
2,5
01802055
01804050
Unshielded
Shieldable
2,5
3,7
3,7
W - 2,58
01802055
Height
U
2
2
2
2
3
3
3
3
4
4
4
4
6
6
6
6
쮿
쮿
쮿
쮿
H
mm
84
84
84
84
128.4
128.4
128.4
128.4
172.9
172.9
172.9
172.9
261.8
261.8
261.8
261.8
Width W
HP
mm
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
28
141.9
42
213
63
319.7
84
426.4
B
mm
101.6
157.5
208.3
101.6
157.5
208.3
101.6
157.5
208.3
101.6
157.5
208.3
h
mm
78
78
78
78
122.4
122.4
122.4
122.4
166.9
166.9
166.9
166.9
255.8
255.8
255.8
255.8
unshielded
Part no.
shieldable
Part no.
30849-007
30849-014
20848-679
20848-680
30849-015
20848-681
30849-016
30849-008
20848-682
20848-633
30849-021
20848-634
30849-022
30849-023
20848-635
20848-636
30849-009
20848-656
30849-028
30849-029
20848-657
20848-658
30849-030
20848-659
30849-010
30849-035
20848-640
20848-641
30849-036
20848-642
30849-037
20848-643
Please order textile EMC gasket separately
EMC gasket rear panel - horizontal rail see page 5.65
Horizontal rails see page 5.67
Assembly parts see page 6.63
Textile EMC gasket
Main Catalogue
쮿 The textile EMC gasket is glue fixed laterally on the front panel,
always in the groove on the right-hand side of the profile
쮿 Temperature range -40 °C ... +70 °C
Delivery comprises ()
Item
1
Qty
Description
10/100 Textile EMC gasket, core: foam,
Order Information
04602054
Height
U
2
3
3
4
6
6
Height
mm
52
97
97
142
232
232
Qty/PU
pieces
10
100
10
10
100
10
Part no.
21101-857
21101-854
21101-853
21101-858
21101-856
21101-855
5.55
Rear panel, unshielded,
Main Catalogue
쮿 Mounting with support brackets on case (right and left)
쮿 Versions with and without perforation
Delivery comprises
Item
1
Qty
1
2
3
4
1
Description
Full-width rear panel, Al, anodised, cut edges blank
28, 42, 63 HP = 2 mm thickness
84 HP = 2.5 mm thickness
Support member, Zn die-cast
Assembly kit
Order Information
05806066
Height
H
Width W
U
2
2
2
3
3
3
3
4
4
4
6
mm
84
84
84
128.5
128.5
128.5
128.5
172.9
172.9
172.9
261.8
HP
42
63
84
28
42
63
84
42
63
84
84
w
mm
213
320
426
142
213
320
426
213
320
426
426
mm
190
298
406
118
190
298
406
190
298
406
406
With
perforation
Part no.
Without
perforation
Part no.
24576-144
24576-145
24576-044
24576-045
24576-146
24576-046
24576-147
24576-148
24576-047
24576-048
24576-149
24576-049
24576-150
24576-152
24576-050
24576-052
24576-153
24576-053
24576-154
24576-158
24576-054
24576-058
ppa43882
Rear panel, shielded,
Main Catalogue
쮿 Mounts on case (left, right)
쮿 Without perforation
Delivery comprises
Item
1
Qty
1
2
2
3
2
4
1
Description
Full-width EMC rear panel, Al 1.5 mm, passivated,
with GND/earthing connection (Faston 6.3 mm)
Textile EMC gasketing, for mounting top and bottom,
core: foam,
Textile EMC gasketing, for mounting left and right,
core: foam,
Assembly kit
Order Information
05806067
5.56
Height
U
2
2
3
3
3
3
4
4
4
6
H
mm
101.5
101.5
146
146
146
146
190.4
190.4
190.4
279.3
Height h
mm
84
84
128.4
128.4
128.4
128.4
172.9
172.9
172.9
261.8
Width W
HP
mm
42
217.9
63
324.6
28
146.8
42
217.9
63
324.6
84
431.3
42
217.9
63
324.6
84
431.3
84
431.3
w
mm
213
319.7
141.9
213
319.7
426.4
213
319.7
426.4
426.4
Part no.
24576-244
24576-245
24576-247
24576-248
24576-249
24576-250
24576-252
24576-253
24576-254
24576-258
Front panel, hinged, shielded,
Main Catalogue
쮿 Front panel with textile EMC gasketing
쮿 Hinges can be fitted left or right
쮿 Suitable for europacPRO subrack and ratiopacPRO,
compacPRO and propacPRO cases
2
1
3
5
05806102
Item
1
Qty
1
2
3
2
1
4
1
Description
Front panel, hinged, Al, 2.5 mm,
front anodised, rear iridescent green chromated
Hinge, Zn die-cast, chrome-plated
Textile EMC gasket
core: foam, sleeve: textile cladding with CuNi coating
Assembly kit
Order Information
Height Width
H
h
W
w
U
HP
mm
mm
mm
mm
3
84
128.4
89.9
426.4
203.2
6
84
261.8
223.2
426.4
203.2
Item 5, Horizontal rail Type H-VT heavy duty, recessed
mounting 84 HP, 1 piece (SPQ 10)
Part no.
20848-611
20848-617
34560-784
Note
05806097
쮿 Usable width reduced by 2 HP (hinged side)
쮿 Horizontal rail (item 5) for front panel mounting is required,
쮿 Lateral trim is necessary, please order separately,
see page 5.59
04602081
Main Catalogue
쮿 For EMC shielding between side panel and top cover or base
plate (sufficient for at least 1 case)
Order Information
Item
1
Description
Qty/PU
Sealing cord, silicone, silver coated,
1
Ø 2.4 mm, length 2.1 m
Part no.
30850-354
05806068
5.57
Design elements
Main Catalogue
쮿 To individualise case design
Delivery comprises
Qty
1
1
Description
Design element, Al extrusion, powder-coated
Assembly kit
Order Information
Description
Width
Form 1
05809002
HP
Light grey
RAL 7035
Part no.
Brilliant blue
RAL 5007
Part no.
42
20850-184
20850-299
63
20850-185
20850-300
84
20850-186
20850-301
42
20850-190
20850-315
63
20850-191
20850-316
84
20850-192
20850-317
42
20850-196
20850-331
63
20850-197
20850-332
84
20850-198
20850-333
PPA43761
Form 2
PPA43762
Form 3
PPA43763
Note
쮿 Size 28 HP and further colours available on request
쮿 Cannot be combined with front hood
5.58
Trim, front, for EMC shielding
Main Catalogue
쮿 For lateral covering of frame and for producing a continuous
front with front panels and plug-in units
쮿 Serves for lateral shielding of side panels simultaneously
Delivery comprises (kit)
Item
1
Qty
2
2
3
1
1
Description
visible surface painted RAL 7016
Textile EMC gasket
Assembly kit
Order Information
05806069
For case height
U
2
3
4
6
h
mm
84
128.5
172.9
261.8
Part no.
24576-017
24576-117
24576-217
24576-417
Trim, rear, for EMC shielding
Main Catalogue
쮿 For vertical EMC shielding between shielded front panels and
side panel
Delivery comprises
Item
1
2
3
Qty
2
1
1
Description
EMC contact strip, Al extrusion
Textile EMC gasket
Assembly kit
Order Information
Height
U
2
3
4
6
05806103
Height
mm
65.55
110
154.45
243.35
Part no.
24576-018
24576-118
24576-218
24576-418
5.59
Main Catalogue
쮿 With powder-coated carrying bar
쮿 Can be locked in 30° increments
쮿 Load-carrying capacity 20 kg
Item
1
2
Qty
1
2
3
4
2
1
Description
Carrying bar, Al extrusion, powder-coated, RAL 7016
Handle side part, Zn, die-cast, powder-coated,
length 180 mm
Safety insert, St, 1.5 mm, black
Assembly kit for side panel mounting
Order Information
For case width
HP
28
42
63
84
Part no.
24576-070
24576-071
24576-072
24576-073
05806101
Note
쮿 To fit the tip-up carrying handle, holes must be drilled in the
side panel
쮿 Readily prepared cases (3 U and 4 U), for mounting the tip-up
carrying handle see page 5.52
Strap handle
Main Catalogue
쮿 Load-carrying capacity: 20 kg
Item
1
Qty
1
2
3
2
1
Description
Band, spring steel,
handle, flexible plastic, grey, RAL 7016
Cover, grey, RAL 7016
Assembly kit
Order Information
Description
Strap handle with adaptor
Part no.
20850-249
Note
쮿 Holes must be drilled into the side panels to fix the strap handle
쮿 Side panels with holes already drilled available on request
쮿 Usable from case depth of D = 326 mm
05806098
5.60
Air filter
Main Catalogue
쮿 Subsequent mounting possible without modification or tools
쮿 Filter change without opening the case, IP protection code not
affected
Item
1
2
3
Qty
1
1
1
Description
Velcro
Order Information
For case width
Air filter
HP
Part no.
28
24576-093
42
24576-094
63
24576-095
84
24576-096
Tip-up foot in plastic silver, similar to RAL 9006,
4 pieces
Plastic tip-up foot anthracite, similar to RAL 7016,
4 pieces
2
3
1
Replacement
filter 1 piece
Part no.
64571-033
64571-034
64571-035
64571-036
20603-001
20603-002
Note
05806070
쮿 For optimum ventilation feet must be fixed to the case, please
order separately
5.61
Front hood 3 U
Main Catalogue
쮿 From acrylic glass, hinged, removable
쮿 Mounting of hinges at top or bottom
쮿 Lock (max. 2) retrofittable
쮿 Lateral cover (item 5) also serves as vertical EMC shielding of
side panels
Item
1
2
3
4
5
Qty
1
2
2
2
2
6
1
Description
Hood, PMMA, tinted blue grey, acrylic glass, 3 mm
Hinge, PC, UL 94 V-0, RAL 7016
Handle, PC, UL 94 V-0, RAL 7016
Retainer, UL 94 V-0, PC, RAL 7016
RAL 7016
Assembly kit
Order Information
05806071
16
180
11
14
7,2
3
Lock for front hood
5.62
Part no.
24576-080
24576-081
24576-082
24576-083
60850-171
20603-001
20603-002
Note
1)
1) Front panel
For case width
HP
28
42
63
84
Lock for front hood Locking cylinder, key, assembly kit, PU
1 kit
Plastic tip-up foot silver, similar to RAL 9006, 4 pieces
4 pieces
05806072
쮿 Cannot be combined with design elements
쮿 Other heights available on request
쮿 Before assembly of hood feet must be fixed to case;
05806073
Foot for rear hood
iMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Increases the distance between rear panel and parking surface
(when used vertically)
쮿 Simplifies cable routing
쮿 Increased shock and vibration damping
쮿 Required for mounting rear hood
Delivery comprises
Item
1
1
Qty
2
1
Description
Foot, PU foam
Assembly kit
Order Information
For cabinet height
U
3
4
ppa45113
Height H
mm
147.9
192.3
Part no.
24576-393
24576-394
ppa45106
Rear hood
Main Catalogue
Item
1
2
Qty
1
1
Description
Hood, Al, 1 mm, RAL 9006, fixing with knurled screws
Assembly kit
Order Information
Height Width A
B
C
D
E
U
HP
mm
mm
mm
mm
mm
3
42
246
230
213
145.9 64
3
63
352.7 336.7 319.7 145.9 64
3
84
459.4 443.4 426.4 145.9 64
4
63
352.7 336.7 319.7 190.4 108.5
4
84
459.4 443.4 426.4 190.4 108.5
Foot for rear hood for case height 3 U, PU foam, black, PU
2 pieces
Foot for rear hood for case height 4 U, PU foam, black, PU
2 pieces
Part no.
24576-086
24576-087
24576-088
24576-091
24576-092
24576-393
24576-394
05806075
Note
쮿 To fit the rear hood, feet must be fitted to the rear panel;
05806076
5.63
Mounting plates
Order Information
Mounting plate for fixing of heavy components
Fixing strip for partial widths
Mounting plate over full width:
mounting is onto the side panels
Mounting plate over partial width:
mounting is onto one side panel and a fixing strip or
onto 2 fixing strips
05812001
06102501
Al, 1.5 mm; for mounting over partial width,
please order fixing strips separately
Width W
W
Board lengths
HP
mm
mm
42
217.99
160
42
217.99
220
63
324.67
160
63
324.67
220
84
431.35
160
84
431.35
220
84
431.35
340
Assembly kit for mounting plate, PU 1 kit
(Torx countersunk screw M4 x 5, St, zinc-plated,
10 pieces)
Assembly kit for fixing strips for partial width
mounting plates, Torx screw M2.5 × 5, St,
05806100
is bolted from front to rear onto the horizontal rails;
1 piece
1 piece
34562-746
30840-021
34562-750
34562-747
30840-033
30840-021
34562-751
30840-033
34562-748
34562-752
30840-021
30840-033
34562-760
30840-057
24560-184
24560-146
Note
쮿
쮿
쮿
쮿
Please order assembly kit for mounting plate separately
Fixing strips required for partial width, please order separately
Other versions on request
Dimensions side panel with horizontal rail see page 5.53
06103057
propacPRO:
D = board length - 47.5 mm; n = 1 for 160 mm board length;
n = 2 for 220 mm board length; n=4 for 340 mm board length
5.64
EMC gasket, stainless steel,
between front/rear panel and horizontal rail
Main Catalogue
쮿 The EMC contact strip is clipped onto the horizontal rail and
forms a conductive link to front or rear panel
쮿 Can be used for front/rear horizontal rails type VT (recessed)
Delivery comprises
Item
1
Qty
10/100
Description
EMC gasket, St, stainless
Order Information
05806109
Width
HP
28
42
63
84
84
Length
mm
131.78
202.9
304.5
416.56
416.56
Qty/PU
pieces
10
10
10
10
100
Part no.
24560-229
24560-231
24560-233
24560-235
24560-236
GND/earthing kit
Main Catalogue
– DIN EN 61010-1A2/VDE 0411 part 1A1
쮿 VDE tested
Order Information
Description
GND/earthing kit, Cu wire 1.5 mm 2, PVC sleeve, green/
yellow, links side panels, base and rear panel, 1 piece
Part no.
21102-001
aza43284
Cable holder
Main Catalogue
Delivery comprises
02908053
Qty
2
2
1
3
1
Part no.
24575-800
26,5
9
Description
Cable holder, ABS, UL V-94 0, RAL 7016,
Drilling template, two drill holes each per holder are
Assembly kit
Order Information
Description
Cable holder
46
19
Item
1
14
17
Ø3
Ø4
,4
Ø3
Ø 4,4
20,2
02908052
5.65
Mounting position horizontal/central rails
2U
Text
H - VT
H - VT
H - VT
H - VT
05806084
3U
H - VT
H-VT
H-ST
H-KD
H-MZ
H - VT
ST
H - ST
H - VT
H - MZ
H - VT
H - VT
05806085
4 U (3 + 1)
05809050
"Z" (EMC shielding with 2 horizontal rails)
H - VT
H - VT
H - ST
H - VT
H - MZ
2 x H - KD
H - VT
H - VT
05806086
6U
06106051
6 U (2 x 3)
H - VT
H - VT
H - VT
H - VT
H - ST
H - VT
H - MZ
H - ST
H - VT
H - MZ
“Z”
“Z”
2 x H - KD
ST
H - ST
H - VT
H - MZ
H - ST
H - VT
H - MZ
H - VT
H - VT
H - VT
05806087
5.66
H - ST
H - VT
H - MZ
H - VT
05806088
Horizontal rails to front/centre/rear
Main Catalogue
Order Information
For indiect
backplane fixing
with insulation
strip
04400001
"heavy"
Type H-ST
standard
06197011
Al extrusion,
anodised finish,
conductive surface,
with printed HP
markings
For direct
backplane fixing
connectors in
accordance with
EN 60603-2
(DIN 41612)
04400002
"heavy"
Type H-VT
long lip
Stainless steel
Horizontal rail
EMC gasket
type H-VT robust,
with EMC gasket
between
horizontal rail and
horizontal rail
04400003
"heavy"
Type H-MZ
with Z-rail
06197013
Al extrusion,
anodised finish,
conductive surface,
with printed HP
markings
Front horizontal
rails
06197015
Al extrusion,
anodised finish,
conductive surface,
with printed HP
markings
06106052
bza45877
"heavy"
Type H-KD
short lip
06197008
Al extrusion,
anodised finish,
conductive surface,
with printed HP
markings
Usable length
Length
HP
mm
1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1)
28
147.32
34560-528
34560-728
34560-928
34560-228
42
218.44
34560-542
34560-742
34560-942
34560-242
63
325.12
34560-563
34560-763
34560-963
34560-263
84
431.80
34560-584
34560-784
34560-984
34560-284
Torx panhead screw , M4 × 14,
24571-371
24571-371
24571-371
24571-371
Torx panhead screw , M 4 × 10,
St, zinc-plated, necessary if
24571-372
24571-372
guide rail is screwed to slot 1,
PU 100 pieces
5.69
see page
5.69
5.68
5.68
5.68
5.68
5.68
item 1: metal strip,
Al, 1 mm,
item 2: EMC
stainless steel
gasket; for shielding
of 2 horizontal rails
positioned directly
one above the other if
assembly area is
divided vertically
horizontal rail:
Al extrusion,
anodised,
conductive contact
surface
for cover plates on
shielded cases
PU 1 kit
1 piece
24562-528
24576-028
24562-542
24576-042
24562-563
24562-584
24576-063
24576-084
24571-371
24571-372
multiple thereof
Note
쮿 Further horizontal rails see from page 6.27
쮿 Fitting options see page 5.66
5.67
Horizontal rails, centre, type ST-C
Main Catalogue
쮿 For indirect backplane mounting (with insulation strip)
쮿 For 6 U propacPRO case
Delivery comprises (kit, item 1 to 4 are pre-mounted)
Item Qty
1
1
2
3
4
5
2
2
2
4
Description
Horizontal rail, Al extrusion, anodised, contact surfaces
conductive
Adaptor plate, Al
Threaded insert, M2.5, St, zinc-plated
Countersunk screw, M4 x 14
Pan head screw, M4 x 6
Order Information
Usable width
Length
HP
mm
84
431.8
Insulation strip 84 HP, PBT UL 94 V-0, grey, PU 10 pieces
Part no.
24575-474
24560-884
05806089
Order Information
Threaded insert
M2.5
M3
Perforated strip
(item 1)
Insulation strip
5
2
5 ,0
8
06103056
required for fixing the front panel to the
horizontal rail; St, zinc-plated;
6.64
BZA45853
BZ6749
for centring shielded
plug-in units, Al, 1 mm,
please order
grub screw separately
for insulated
backplane mounting;
PBT UL 94 V-0, grey
Threaded insert
Perforated strip
Insulation strip
Usable length Length
Length
Length
HP
mm
PU 10 pieces
28
146.82
147.12
144.20
34561-328
30845-197
24560-828
42
217.94
218.24
210.40
34561-342
30845-211
24560-842
63
324.62
34561-363
324.92
30845-232
316.88
24560-863
84
431.30
431.60
428.64
34561-384
34561-484
30845-253
24560-884
Accessories
21100-276
PU 100 pieces
21101-359
PU 100 pieces
Grub screw M3 x 8, PU 100 pieces
21100-646
5.68
ELECTRONICS PROTECTION
Order Information
31-pin, DIN 41617
item 1
Perforated rail
item 1
172,5
175,5
172,5
BZA45849
75
12,
5
9 ,7
BZA45850
BZA45848
75
12,
3 ,0
2
2
1
1
3
3
06708063
Usable length
Length
HP
mm
28
142.24
42
213.36
60
304.80
84
426.70
Item 3, Torx panhead screw
to fix connector to perforated rail,, M2.5 × 7,
PU 100 pieces
Item 2, Torx panhead screw,
to fix perforated rail to horizontal rail, M2.5 × 10,
PU 100 pieces
06708051
for connector mounting on
ST horizontal rails,
please order threaded insert and
screw separately
screw separately
VT horizontal rails,
screw separately
1 piece
1 piece
PU 4 pieces
30822-033
20822-049
30822-047
30822-065
30819-783
20822-050
20822-047
30822-089
30819-808
20822-048
24560-147
24560-147
24560-147
24560-148
24560-148
24560-148
5.69
Combined mounting (6 U and 2 x 3 U one above the other)
Order Information
Combined mounting
Horizontal and
Unshielded
Front panel for
vertical subdivision
front panel, 6 U, 2 HP textile EMC gasket,
6 U, 2 HP
item 5
item 5
bza45819
05806108
Width pitch T1:T2
HP
20:62
40:42
42:40
63:19
84:0
for fixing splitting extrusion/horizontal rail
Panhead screw
for fixing horizontal rail/splitting extrusion
Washer
06102501
Splitting extrusion
for combined
mounting
item 2
06102501
06102501
item 1: 2 front horizontal rails (H-KD),
zinc-plated;
item 4: Zn die-cast support member;
item 5: front panel 2 HP, 6 U,
shielded;
with EMC stainless steel gasket;
84:0 without items 4, 5
Al, 2.5 mm,
front anodised,
chromated
Al, 2.5 mm,
U-profile with notch,
6 U, 2 HP
6 U, Zn die-cast;
inserted in the grid
holes of the
horizontal rail;
can be bolted
PU 1 kit
1 (SPQ 5)
1 piece (SPQ 5)1)
1 piece
30847-472
30849-140
64560-010
24560-145
24560-179
21101-101
21101-101
21101-102
21101-102
21101-121
21101-121
21101-855
24562-420
24562-440
24562-442
24562-463
24562-484
– 2x3U
– 1x6U
쮿 Designed to accept euroboards (100 mm high) and double
euroboards (233.35 mm high)
Note
see page 6.54
see page 5.68
see page 5.68
5.70
Horizontal board mounting
Order Information
Front frame for
EMC gasketing
Board cage
27
3.9
8=
54
TE
05806091
05806092
(1 TE = 1 HP, 1 HE = 1 U)
,98
=5
4T
E
bpa45913
bza43061
3 or 4 U high
subracks/cases;
54 HP space required; please
gasketing separately
2 horizontal trims,
AI 2.5 mm, front anodised,
clear passivated;
contact between subrack and the
sub-assemblies
w = 266.35 mm
PU 1 kit
PU 1 kit
1 piece
Height H
U
Usable
height h
HP
3
24564-109
34564-108
3
24564-109
34564-109
4
28
24564-217
24564-209
34564-208
24560-270
Horizontal rail,
front
Horizontal rail,
rear
H
273
h
w
5.71
Plastic tip-up feet
Main Catalogue
쮿 Static load-carrying capacity 25 kg per foot
쮿 Tip-up feet can be used instead of the pre-mounted case feet
쮿 Fixing holes provided in bottom of case
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Assembly kit
Order Information
Description
05806093
Part no.
Plastic tip-up foot
RAL 7016, 4 pieces
silver, similar to
Plastic tip-up foot
RAL 9006, 4 pieces
Cheesehead screw with slot M4 × 12, St, zinc-plated,
PU 100 pieces
Hexagon nut M4, St, zinc-plated, PU 100 pieces
Spring washer A4, St, zinc-plated, PU 100 pieces
20603-002
20603-001
21101-211
21100-211
21100-207
02906050
Tip-up feet made of die-cast aluminium
쮿 Can be used instead of the round standard feet
쮿 Secure case stance with slip-proof rubber inserts
쮿 Load carrying capacity: 50 kg per foot, max. case weight 40 kg
Order Information
41
Ø3,1
15,5
Ø4,6
15
16,6
1
AZA43836
Description
Qty
Foot with tip-up,
1 piece (SPQ 10)1)
Al die-cast, silver
Foot without tip-up,
1 piece (SPQ 10)1)
Al die-cast, silver
PU 100 pieces
Part no.
10603-002
10603-001
21101-211
21100-211
21100-207
1) Part no. comprises 1 piece;
delivery is in standard pack quantity (SPQ):
please order a minimum of 10 feet or a multiple
Ø7,8
Note
쮿 Delivery is in standard pack multiples;
pricing is per individual item
02908051
5.72
Guide rails for plug-in units and frame type plug-in units, one-piece, groove width 2 mm
Order Information
Assembly
horizontal rails
plates
Standard
Storage temperature
06102001
06101501
up to 220 mm length, PBT, UL 94 V-0;
multi-piece from 280 mm length,
for euroboards, 100 x 160 mm or 100 x 220 mm only
PU 10 pieces
1 pair (SPQ 10)1)
24560-351
64560-074
24560-353
64560-075
24560-379
24560-380
6.40
6.40
Retention screw,
PU 100 pieces
24560-141
24560-141
description see page 6.41
24560-255
24560-255
Board
Groove
Colour
lengths
width
mm
mm
mm
70
2
red
70
2
grey
160
2
red
220
2
red
280
2
red
340
2
red
Dimension drawings see page
Accessories
multiple thereof
Further guide rails see page 6.35
5.73
Guide rails type "accessories", one-piece, groove width 2 mm and 2.5 mm
Order Information
Assembly
in Al extrusion
plates
Guide rails
"Accessories"
Guide rails
Guide rails
for heavy modules,
robust version
storage temperature
06102002
Board
lengths
mm
100
160
160
220
220
Groove
width
mm
2
2
2
2
2
06102005
06102005
up to 280 mm length, PBT, UL 94 V-0;
PBT UL 94 V-0,
red support beam of guide rails adds to
strengthening
PU 10 pieces
1 piece (SPQ 50)
24560-373
Colour
mm
red
red
grey
red
grey
red/
280
2
silver
red/
340
2
silver
400
2
silver
160
2.5
silver
220
2.5
silver
280
2.5
silver
340
2.5
silver
400
2.5
silver
64560-076
1 piece (SPQ 50)1)
34562-881
24560-374
64560-078
34562-882
24560-375
64560-080
34562-883
24560-376
34562-884
6.40
6.40
34562-885
34564-881
24560-141
24560-141
24560-157
24560-255
24560-255
24560-377
24560-377
24560-378
24560-378
60817-228
60817-228
6.41
6.41
34564-882
34564-883
34564-884
34564-885
6.40
Accessories
Retention screw,
PU 100 pieces
PU 10 pieces,
PU 10 pieces,
handle, red,
PU 1 sheet = 438 pieces,
Coding see page
5.74
Divider plate
Order Information
Divider plate
Mounting position when stainless steel
EMC gasket is used
textile EMC gasket is used
front
rear
front
rear
bpa45911
06105078
space requirement on component side 2 mm;
mounting direction varies with shielding design (EMC stainless steel or textile gasket);
retrofitting the divider plate in an already-assembled subrack/case
will first require dismantling of the horizontal rails;
where front panels are unshielded, both mounting directions are possible
bpa45912
Height
U
3
3
6
6
Depth
mm
160
220
160
220
A
mm
158.3
218.3
158.3
218.3
B
mm
135.0
195.0
135.0
195.0
H
mm
113.5
113.5
246.9
246.9
PU 10 pieces
34562-761
34562-762
34562-763
34562-764
Order Information
Air baffle
without front panel
U front panel for textile EMC gasket
06108085
prevents an air short circuit in unoccupied slot positions;
is pushed into the groove of the guide rails
06108088
EMC textile gasket, fixing materials kit prevents an air
short-circuit where slots are unoccupied;
06101507
Depth
mm
160
160
160
160
160
160
220
220
220
220
220
220
Width
HP
4
4
8
8
12
12
4
4
8
8
12
12
Height
U
3
6
3
6
3
6
3
6
3
6
3
6
1 piece
1 piece
34562-823
20848-728
34562-826
20848-736
34562-833
34562-836
20848-730
20848-738
34562-843
20848-732
34562-846
34562-824
20848-740
20848-729
34562-827
20848-737
34562-834
34562-837
20848-731
20848-739
34562-844
20848-733
34562-847
20848-741
5.75
bMain Catalogue
Desk-top cases – b
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
02004009
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Flexible expansion options, for 19" components e.g. plug-in unit units, or for individual expansion
02004079
Standards
쮿 Interior dimensions in accordance with: IEC 60297-3-101
쮿 Type of protection IP 20 in accordance with IEC 60529
Connectors, front
panel component
system . . . . . . . 11
쮿 GND/earth connections in accordance with:
DIN EN 50178 / VDE 0160
DIN EN 60950 / VDE 0805
DIN EN 61010-1 / VDE 0411 part 1
DIN EN 61010-1A2 / VDE 0411 part 1/A12
Appendix . . . . . 12
5.76
SCHROFF PRODUCT CATALOG E 10/2017
Desk-top cases – b
Overview . . . 5.76
bMain Catalogue
Robust desk-top case for 19" components in accordance with
IEC 60297-3-10x or for individual electronics assemblies
쮿 Front and rear identical, depth-symmetrical construction
쮿 Highly robust thanks to die-cast frame (front/rear)
쮿 Side panel with integrated handle function
Desk-top cases
compacPRO
쮿 Complete case
– Pre-configured case, prepared for 19" components
– Case height 3 U and 6 U
Complete cases
3, 6 U . . . . . . . . . . 5.78
Cases 2, 3, 4 U . . 5.79
6 U cases . . . . . . . 5.80
Accessories
Filler angle . . . . . 5.81
Cable holder . . . . 5.81
쮿 Case
– Case height 2 U, 3 U, 4 U and 6 U
Front panel/rear
panel . . . . . . . . . . 5.82
Rear feet . . . . . . . 5.83
Edge protection. 5.83
Hood . . . . . . . . . . 5.84
Front door . . . . . 5.85
Handle . . . . . . . . 5.86
GND/earthing . . . 5.86
Feet . . . . . . . . . . 5.87
Horizontal rail .
02009005 02004006
5.88
Threaded inserts 5.90
Extensive accessory range
Guide rails and
ESD clips . . . . . . . 5.92
Mounting plates . 5.94
Combined
mounting . . . . . . 5.95
Horizontal board
assembly . . . . . . 5.96
Air flow barrier . . 5.97
Dimensions . . . . . 5.98
02004002
ServicePLUS . . 5.4
ServicePLUS from page 5.4
e.g. assembly service from 1 piece
cut-
www.schroff.biz/ServicePLUS
30407004
5.77
Desk-top cases – b
Complete cases 3 and 6 U
bMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
쮿 Desk-top case with pre-configured components in accordance
plug-in units and euroboards
쮿 For backplane mounting with insulation strips
쮿 Ventilation slots in rear panel
Delivery comprises (Kit, items 1, 2, 6, 8 fitted)
Item
1
2
3
Qty
3U
2
2
1
6U
4
2
1
Description
4
1
1
5
6
4
2
4
7
8
2
2
2
2
9
2
2
10
1
11
1
1
12
10/
1
10/
1
02009005
h
H
D
w
W
02004054
13
14
3
Side panel, Al extrusion, powder-coated, RAL 7016
Cover plate, Al, 1.5 mm, powder-coated, RAL 9006,
Base plate with 4 rows of ventilation slots, Al, 1.5 mm,
powder-coated, RAL 9006, with GND/earthing tag
Side plate powder-coated, RAL 9006, Al, 0.8 mm
Tip-up foot with anti-slip protection, PA, RAL 7016,
UL 94 V-0
Cover bracket, Al extrusion, anodised, cut edges plain
Horizontal rail, Al extrusion, with threaded insert, St,
M2.5
insert, St, M2.5 and insulation strip, PBT, UL 94 V-0
conductive surfaces, with two threaded inserts, St,
Rear panel with 1 row of ventilation slots, Al,
anodised, 2 mm for 28, 42 and 63 HP,
2.5 mm for 84 HP
GND/earthing kit
Assembly kit, also allows the fitting of a full-width
front panel
Order Information
9
Height H
Usable width
Part no.
w
w
U
mm
mm
HP
mm
3
186
271
28
148
14575-114
3
186
331
28
148
14575-115
3
257
271
42
219
14575-134
3
257
331
42
219
14575-135
3
257
391
42
219
14575-136
3
364
271
63
326
14575-154
3
364
331
63
326
14575-155
3
364
391
63
326
14575-156
3
471
271
84
432
14575-174
3
471
331
84
432
14575-175
3
471
391
84
432
14575-176
3
471
511
84
432
14575-178
6
471
391
84
432
14575-476
6
471
451
84
432
14575-477
Maximum mounting depth = D - 21 (open space: front panel - rear panel)
1
10
2
11
5
12
8
4
7
6
02008050
Width W
Depth D
Note
쮿 Dimensions of case, side panel see from page 5.98
ServicePLUS see page 5.4
5.78
Desk-top cases – b
Cases 2, 3 and 4 U
b
쮿 Desk-top case, pre-configures, for individual assembly
Delivery comprises (Kit, items 1 and 2 fitted)
Item
1
2
3
Qty
2
2
1
4
1
5
6
7
4
8
1
02004005
Description
powder-coated RAL 9006, with earthing connection
Fixing adaptor for cover plate, prefitted
Assembly kit, also allows the fitting of a full-width front
panel, two cover brackets or a rear panel
Order Information
h
H
D
w
W
02004054
3
2
1
Height Usable
width
U
HP
2
42
2
42
2
42
2
84
2
84
2
84
3
28
3
28
3
42
3
42
3
42
3
63
3
63
3
63
3
84
3
84
3
84
3
84
3
84
4
42
4
42
4
63
4
63
4
63
4
84
4
84
4
84
4
84
Width
W
mm
257
257
257
471
471
471
186
186
257
257
257
364
364
364
471
471
471
471
471
257
257
364
364
364
471
471
471
471
Width
w
mm
219
219
219
432
432
432
148
148
219
219
219
326
326
326
432
432
432
432
432
219
219
326
326
326
432
432
432
432
Height
H
mm
102.6
102.6
102.6
102.6
102.6
102.6
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
147.1
191.6
191.6
191.6
191.6
191.6
191.6
191.6
191.6
191.6
Height
h
mm
84.4
84.4
84.4
84.4
84.4
84.4
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
129.3
173.8
173.8
173.8
173.8
173.8
173.8
173.8
173.8
173.8
Depth
D
mm
271
331
391
271
331
391
271
331
271
331
391
271
331
391
271
331
391
451
511
271
331
271
331
391
331
391
451
511
Part no.
14575-023
14575-025
14575-027
14575-063
14575-065
14575-067
14575-103
14575-105
14575-123
14575-125
14575-127
14575-143
14575-145
14575-147
14575-163
14575-165
14575-167
14575-169
14575-171
14575-223
14575-225
14575-243
14575-245
14575-247
14575-265
14575-267
14575-269
14575-271
6
4
5
02004053
SCHROFF.PENTAIR.CO.UK
Part number in bold face type: ready for despatch within 2 working days
5.79
Desk-top cases – b
6 U cases
b
쮿 Desk-top case, pre-configured, for individual assembly
Delivery comprises (Kit items 1, 2 and 5 fitted)
02004006
Item
1
Qty
4
2
3
2
1
4
1
5
6
7
8
2
4
8
1
Description
Side panel parts, Al extrusion, powder-coated,
RAL 7016, 2 x 3 U
Side plate, Al, 0.8 mm, powder-coated, RAL 9006
Assembly kit also allows the fitting of a full-width front
Order Information
Usable width Width W Width w Height
H
HP
mm
mm
mm
63
364
326
280.5
63
364
326
280.5
84
471
432
280.5
84
471
432
280.5
84
471
432
280.5
84
471
432
280.5
84
471
432
280.5
3
2
1
Height
h
mm
262.9
262.9
262.9
262.9
262.9
262.9
262.9
Depth
D
mm
331
391
271
331
391
451
511
Part no.
14575-445
14575-447
14575-463
14575-465
14575-467
14575-469
14575-471
5
7
4
6
02004055
h
H
D
w
W
02004056
5.80
Desk-top cases – b
Filler angle
b
쮿 To cover the sides of the frame and to create a continuous front
plane with plug-in units and partial-width front panels
쮿 This filler angle is recommended when fitting horizontal rails
Delivery comprises
Item
1
Qty
2
Description
Filler angle, Al extrusion, anodised, cut edges plain
Order Information
02005002
Height
U
2
3
4
6
Part no.
24575-019
24575-119
24575-219
24575-419
Note
쮿 Fixing material is supplied with case
02004062
Cable holder
Access ori esI/B
Item
1
Qty
2
2
1
3
1
Description
Cable bracket, ABS, UL V-94 0, RAL 7016,
detent for cables between 8 mm and 12 mm
Drilling template, two drill holes each per bracket are
needed in rear panel
Assembly kit
Order Information
02908053
46
Part no.
24575-800
9
26,5
19
Description
Cable holder
14
17
Ø3
Ø4
,4
Ø3
Ø 4,4
20,2
02908052
5.81
Desk-top cases – b
Front panel and rear panel
b
쮿 Front panels and rear panels are screwed on front or rear
frame of case
Item
1
Qty
1
2
1
Description
Rear panel with 4 rows of ventilation slots, AI, anodised,
cut edges plain; 28, 42, 63 HP = 2 mm thick;
Front panel, Al, anodised, cut edges plain, 3 mm thick
Order Information
Height Width Height Height Width
H
h
B
U
HP
mm
mm
mm
2
42
84
66
238.7
2
84
84
66
452.1
3
28
128.4
100
167.5
3
42
128.4
100
238.7
3
63
128.4
100
345.4
3
84
128.4
100
452.1
4
42
172.9
144.5 238.7
4
63
172.9
144.5 345.4
4
84
172.9
144.5 452.1
6
63
261.8
233.4 345.4
6
84
261.8
233.4 452.1
02005001
Rear panel/front panel
Rear panel Front panel
b
mm
226.3
439.7
155.1
226.3
333.1
439.7
226.3
333.1
439.7
333.1
439.7
Part no.
Part no.
30823-015 30823-209
30823-512 30823-215
30823-021 30823-254
30823-024 30823-257
30823-027 30823-224
30823-515 30823-260
30823-033 30823-269
30823-036 30823-227
30823-518 30823-272
30823-045 30823-230
30823-521 30823-284
Note
CPA30656
쮿 Assembly kit to fix one rear and one front panel is included with
the case
쮿 Cable holder and rear feet, see from page 5.81
Front panel/rear panel with hidden fixing
b
Item Qty
1
1
2
4
Description
Front panel, Al, anodised, cut edges plain, 2.5 mm
Fixing bracket
Order Information
Height
U
2
2
3
3
3
3
4
4
4
6
6
Width
HP
42
84
28
42
63
84
42
63
84
63
84
Height H Height h Width
B
mm
mm
mm
84.0
66.0
238.7
84.0
66.0
452.1
128.4
100.0
167.5
128.4
100.0
238.7
128.4
100.0
345.4
128.4
100.0
452.1
172.9
144.5
238.7
172.9
144.5
345.4
172.9
144.5
452.1
261.8
233.4
345.4
261.8
233.4
452.1
Part no.
b
mm
226.3
439.7
155.1
226.3
333.1
439.7
226.3
333.1
439.7
333.1
439.7
24575-035
24575-075
24575-115
24575-135
24575-155
24575-175
24575-235
24575-255
24575-275
24575-455
24575-475
Note
02004061
5.82
쮿 Cable holder and rear feet see from page 5.81
Desk-top cases – b
Rear foot with rubber insert
b
Delivery comprises
Item
1
2
Qty
2
1
Description
Foot with rubber insert, PC, UL 94 V-0, RAL 7016
Fixing material
Order Information
For case height
U
3
4
A
mm
139
183.5
Part no.
24575-114
24575-214
02005004
A
ø 4.2
23
8.5
16.5
02004063
Edge protection/rear foot
b
Delivery comprises
Item
1
2
Qty
2
1
Description
Edge protection, PU foam, black
Assembly kit
Order Information
For case height
U
3
4
A
mm
159.1
203.6
B
mm
114.0
159.0
C
mm
100.0
144.5
Part no.
20823-675
20823-676
20,2
A
B
C
Ø8
Ø 4,5
02005005
A
A
5
27
27,5
35
A-A
02908054
5.83
Desk-top cases – b
Rear foot for hood
b
Delivery comprises
Item
1
2
Description
Foot, PU foam, black, 75° shore
Fixing material
Order Information
D
B
A
M6
Qty
2
1
Height
U
3
4
M6
45
30
02004065
A
mm
133.5
177.8
B
mm
95
139.5
D
mm
65
95
Part no.
20823-668
20823-669
쮿 Rear panel, see page 5.82
B
Dimensions for modifying the rear panel
27.55
8 x 6.1
02004066
Hood
b
Delivery comprises
Item
1
Qty
1
2
1
Description
Hood, ABS, RAL 7016, wall thickness < 4 mm,
Assembly kit
Order Information
Height
Width
A
U
HP
mm
3
42
267
3
63
373.5
3
84
480
Cable support PC, black, UL 94 V-0, PU 2 pieces
02005006
56
ø 5.5
41.6
41.6
A
10
24575-136
24575-156
24575-176
20823-674
Note
쮿 Cable support can only be fitted in conjunction with rear foot for
hood
쮿 To fit the hood, the rear panel and the rear foot for hood must
be mounted on the case
쮿 Rear foot for hood see page 5.84
10°
156.5
4
Part no.
61.5
02004064
Cable support
A4-512
5.84
Desk-top cases – b
Front door, acrylic glass, hinged
b
쮿 Assembly of the hinge to top or bottom
쮿 With snap-on latch
쮿 Lock retrofittable
Item
1
2
3
4
5
Qty
2
1
1
2
1
Description
Side part, Al die-cast, powder-coated, RAL 7016
Front door, PMMA, tinted blue-grey, acrylic glass, 3 mm
Snap-on latch, PC, UL 94 V-0, black
Spacer plate, Al, 3 mm, passivated
Assembly kit
Order Information
02005003
Height
Width
U
HP
3
42
3
63
3
84
Lock for front door cylinder, 2 keys, assembly parts
Part no.
24575-137
24575-157
24575-177
21100-647
Dimensions table
Height
U
3
3
3
b
TE
42
63
84
H
mm
139,50
139,50
139,50
h
mm
128,40
128,40
128,40
B
mm
229,60
336,40
443,00
02004069
Front door, hinged
a4-2265
1) Front panel
a4-225
5.85
Desk-top cases – b
b
쮿 With powder-coated handle bar
쮿 Handle bar adjustable in 30 degree increments by pressing
button
Item
1
2
Qty
1
2
3
4
2
1
Description
Carrying bar, AI profile, powder-coated, RAL 7016
Lateral section of handle, Zn die-cast, powder coated,
length 180 mm
Fixing material incl. drilling template for side panel
Order Information
02004002
a
68.5
b
180
c
For case height
U
2
2
3, 4
3, 4
3, 4
3, 4
Width
HP
42
84
28
42
63
84
Part no.
24575-038
24575-078
24575-118
24575-138
24575-158
24575-178
Dimensions
Case width
HP
28
42
63
84
4x
a
mm
249.32
320.44
427.12
533.80
b
mm
180.32
251.44
358.12
464.80
c
mm
202.72
273.84
380.52
487,20
30°
4x
30°
02004080
GND/earthing kit
Main Catalogue
쮿 Protective GND/earth connections in accordance with
DIN EN 50178/VDE 0160,
DIN EN 60950/VDE 0805,
DIN EN 61010-1/VDE 0411 part 1,
DIN EN 61010-1A2 /VDE 0411 part 1/A1
VDE inpection requested
Order Information
Description
GND/earthing kit, CU wire 1.5 mm 2,
PVC covered, green/yellow, links side panel,
base plate, cover and rear panel
Qty/PU
1
Part no.
24575-801
aza43284
5.86
Desk-top cases – b
Plastic tip-up feet
쮿 Tip-up feet can be used instead of the case feet fitted as
standard
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Anti-slip protection, TPE
Tip-up device, PA, UL 94 V-0
Assembly kit
Order Information
Description
RAL 7016
anthracite
Part no.
RAL 9006
silver
Part no.
Plastic tip-up foot
20603-002
20603-001
01802075 02006050
Al die-cast tip-up foot
쮿 Static load-carrying capacity 50 kg per foot
standard
Order Information
15,5
Ø4,6
Part no.
10603-001
10603-002
21101-211
21100-211
21100-207
1) Delivery is exclusively in Standard Pack Quantity (SPQ):
Please order at least 10 pieces or a multiple. Pricing is per
individual item.
15
16,6
1
AZA43836
41
Ø3,1
Description
Qty
Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1)
Foot with tip-up, Al die-cast, silver
1 piece (SPQ 10)1)
Accessories
PU 100 pieces
Ø7,8
02908051
5.87
Desk-top cases – b
Case, 2 U
Case, 3 U + 4 U
Text
H-VT
H-VT
H-VT
H-ST / H-VT / H-MZ
H-ST / H-VT / H-MZ
H-VT
H-VT
H-VT
H-VT
H-VT
02004073
Case, 6 U
02004074
Case 2 x 3 U (6 U)
H-VT
H-VT
H-VT
H-VT
H-ST / H-VT / H-MZ
ST-C
H-KD
H-ST / H-VT / H-MZ
H-ST / H-VT / H-MZ
H-VT
H-VT
H-VT
02004076
H-VT
02004077
Horizontal rails
H-ST
H-VT
H-MZ
02004078
5.88
Desk-top cases – b
Order Information
For indirect backplane fixing
For direct backplane fixing
04400001
"heavy"
Type H-ST
standard
04400002
"heavy"
Type H-VT
long lip
06197011
Usable length
Length
HP
mm
28
147.32
42
218.44
63
325.12
84
431.80
Torx countersunk screw, ,
M4 × 14, St, zinc-plated,
PU 100 pieces
M4 × 10, St, zinc-plated,
required if guide rail is screwed
to slot 1, PU 100 pieces
Z-rail for connector mounting
without insulation strip see page
Insulation strips see page
Threaded inserts see page
For direct fixing of
connectors in
accordance with
EN 60603-2 (DIN 41612)
Front horizontal rails
04400003
"heavy"
Type H-MZ
with Z-rail
06197013
"heavy"
Type H-KD
short lip
06197015
06197008
Al extrusion, anodised finish,
conductive contact surface,
with printed HP markings
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34560-528
34560-728
34560-928
34560-228
34560-542
34560-563
34560-742
34560-763
34560-942
34560-963
34560-242
34560-263
34560-584
34560-784
34560-984
34560-284
24571-371
24571-371
24571-371
24571-371
24571-372
24571-372
5.91
5.90
5.90
5.90
5.90
5.90
1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a
multiple thereof
Note
쮿 Further horizontal rails, see from page 6.27
쮿 Fitting options, see page 5.88
5.89
Desk-top cases – b
Horizontal rail, centre, type ST-C
b
쮿 For 6 U compacPRO case
Delivery comprises (Kit, items 1 to 4 are pre-mounted)
Item Qty
1
1
2
3
4
5
1
3
Description
conductive
Adaptor plate, Al
Panhead screw, M4 x 6
2
2
2
4
2
Order Information
4
Usable width
HP
63
84
Length
mm
325.1
431.8
Part no.
24575-454
24575-474
5
02005050
Threaded inserts, perforated strips, insulation strips
Order Information
Threaded insert
Insulation strip
M2.5
M3
5
2
5,0
8
06103056
required for fixing the front panel to the horizontal rail;
St, zinc-plated; Use collar screw 12.3 mm, see page
6.64
BZ6749
for insulated mounting of backplane;
PBT UL 94 V-0, grey
Threaded insert
Insulation strip
Usable length
Length
Length
HP
mm
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
mm
PU 10 pieces
28
146.82
34561-328
144.20
24560-828
42
217.94
210.40
34561-342
24560-842
63
324.62
316.88
34561-363
24560-863
84
431.30
34561-384
34561-484
428.64
24560-884
Accessories
Grub screw M2.5 x 8, PU 100 pieces
21100-276
21100-646
2) Part no. includes one packing unit (PU); delivery is exclusively made in PU
5.90
Desk-top cases – b
Z-rails, perforated rails
Order Information
Z-rail for connectors
DIN EN 60603-2, DIN 41612
31-pin, DIN 41617
item 1
Perforated rail
EN 606032, DIN 41612
item 1
172,5
175,5
172,5
BZA45849
12,7
5
9,7
BZA45850
BZA45848
5
75
12,
3,0
2
2
1
1
3
3
06708063
Usable length
Length
HP
mm
28
142.24
42
213.36
60
304.80
84
426.70
PU 100 pieces
to fix perforated rails to horizontal rail, M2.5 × 10,
PU 100 pieces
06708051
for connector mounting on ST
horizontal rails, please order
threaded insert and screw
separately
separately
for connector mounting on VT
separately
1 piece
1 piece
PU 4 pieces
30822-033
20822-049
30822-047
30822-065
30819-783
20822-050
20822-047
30822-089
30819-808
20822-048
24560-147
24560-147
24560-147
24560-148
24560-148
24560-148
5.91
Desk-top cases – b
Order Information
Assembly
horizontal rails
plates
standard
standard, with DIN connector fixing
Storage temperature
06102002
06101501
from 280 mm length, multi-piece, end piece PBT, UL 94 V-0,
PU 10 pieces
1 pair (SPQ 10)1)
24560-351
64560-074
24560-353
64560-075
24560-379
24560-380
6.40
6.40
Retention screw,
PU 100 pieces
24560-141
24560-141
24560-255
24560-255
Board
Groove
Colour
length
width
mm
mm
mm
70
2
red
70
2
grey
160
2
red
220
2
red
280
2
red
340
2
red
160
2.5
red
220
2.5
red
Accessories
multiple thereof
Description of accessories see from page 6.41
5.92
Desk-top cases – b
Guide rails type "accessory", one-piece,
Main Catalogue
Order Information
Assembly
in Al extrusion
plate
Guide rails type
accessory, strengthened
accessory
for heavy modules,
robust version
Storage temperature
06102002
Board
length
mm
100
160
160
220
220
Groove
width
mm
2
2
2
2
2
bza46554
06102005
PBT UL 94 V?0,
strengthening
Al extrusion;
is screwed to horizontal rail "heavy"
PU 10 pieces
1 piece (SPQ 50)
24560-373
Colour
mm
red
red
grey
red
grey
red/
280
2
silver
red/
340
2
silver
red/
400
2
silver
160
2.5
silver
220
2.5
silver
280
2.5
silver
340
2.5
silver
400
2.5
silver
64560-076
1 piece (SPQ 10)1)
34562-881
24560-374
64560-078
34562-882
24560-375
64560-080
34562-883
24560-376
34562-884
34562-885
6.40
6.40
34564-881
34564-882
24560-141
24560-141
24560-157
24560-255
24560-255
24560-377
24560-377
24560-378
24560-378
60817-228
60817-228
34564-883
34564-884
34564-885
6.40
Accessories
Retention screw,
PU 100 pieces
PU 10 pieces
Board handleC , red,
438 pieces
Coding see page
see page 6.41
5.93
Desk-top cases – b
Mounting plates
Main Catalogue
Order Information
Assembly strip for partial widths
mounting is onto the side panels;
mounting plate over partial width:
mounting is onto one side panel and fixing strip or
06102501
Width W
Board length
HP
W
mm
28
146.88
160
28
146.88
220
28
146.88
280
28
146.88
340
42
217.99
160
42
217.99
220
42
217.99
280
42
217.99
340
63
324.67
160
63
324.67
220
63
324.67
280
63
324.67
340
84
431.35
160
84
431.35
220
84
431.35
280
84
431.35
340
PU 1 kit (Torx countersunk screw M4 x 5, St,
zinc-plated, 12 pieces; screw M4 x 6, St,
zinc-plated, 10 pieces; M4 square nut, St,
zinc-plated, 10 pieces)
Assembly kit for assembly strips of
mounting plate,
Torx screw M2.5 × 5, St, zinc-plated,
PU 100 pieces
M2.5 × 5, St, zinc-plated, PU 100 pieces
05806100
please order assembly strips separately
St, 2 mm, zinc-plated;
to fix mounting plates
34562-745
30840-021
34562-749
34562-753
30840-033
30840-045
34562-757
30840-057
34562-746
30840-021
34562-750
34562-754
30840-033
30840-045
34562-758
30840-057
34562-747
34562-751
30840-021
30840-033
34562-755
30840-045
34562-759
34562-748
30840-057
30840-021
34562-752
30840-033
34562-756
34562-760
30840-045
30840-057
24560-184
24560-146
Note
쮿 For installation and assembly of heavier components
쮿 The mounting plate is as wide as the case and is fixed
to the side panels
쮿 A guide rail can be mounted on the first and last slot positions
쮿 4.4" and "strengthened" guide rails cannot be used
5.94
Desk-top cases – b
Combined mountings (6 U and 2 x 3 U one above the other)
Order Information
Combined mounting:
horizontal and vertical
unshielded
subdivision
front panel, 6 U, 2 HP EMC gasket, 6 U,
(incl. front panel for stainless
2 HP
item 6
steel EMC gasket)
item 6
bza45819
05806108
Width pitch T1:T2
HP
20:62
40:42
42:40
63:19
84:0
M4 × 14, zinc-plated, PU 100 pieces
Panhead screw
M2.5 × 10, St, zinc-plated, PU 100 pieces
finxing horizontal rail/splitting extrusion
Pozidrive/slotted collar screw
M2.5 x 12.3, St, nickel-plated, PU 100 pieces
M2.5, black, zinc-plated, PU 100 pieces
Washer
2.7 x 5 x 1, plastic PA 6, PU 100 pieces
Textile gasket, core: foam,
sleeve: textile cladding with CuNi coating,
UL 94 V-0, PU 10 pieces
06102501
Splitting extrusion
for combined
mounting
Item 2
06102501
06102501
Al extrusion, anodised;
item 2: 2 rear horizontal rails (AB),
item 3: threaded insert, St,
zinc-plated;
item 6: front panel 2 HP, 6 U,
shielded; with EMC stainless steel
gasket (84:0 without items 4, 6)
Al, 2.5 mm,
front anodised,
chromated
Al, 2.5 mm, U-profile
with notch, 6 U, 2 HP
6 U, die-cast zinc;
splitting extrusion is
holes of the
horizontal rail;
the splitting extrusion
can be bolted
PU 1 kit
1 piece (SPQ 5)
1 piece (SPQ 5)1)
1 piece
30847-472
30849-140
64560-010
24560-145
24560-179
21101-101
21101-101
21101-102
21101-102
21101-121
21101-121
21101-855
24562-420
24562-440
24562-442
24562-463
24562-484
쮿 Subdivision of the 6 U assembly area into:
– 2x3U
– 1x6U
쮿 Designed to accept Euroboards (100 mm high) and double
Euroboards (233.35 mm high)
Note
쮿 Please order perforated strips for horizontal rails separately,
see page 5.90
쮿 Please order rear centre horizontal rail separately,
see page 5.89
5.95
Desk-top cases – b
Horizontal board installation
Order Information
Front frame for EMC shielding
Board cage
27
3.9
8=
54
Front frame, unshielded
TE
05806091
05806092
H = usable height (1 TE = 1 HP, 1 HE = 1 U)
,98
=5
4T
E
bpa45913
H
273
h
w
bza43061
Struts die-cast zinc;
horizontal rails front and rear;
threaded insert, St, zinc-plated;
fixing material kit;
for horizontal mounting of
double-height euroboards in 3 or
4 U high subracks/cases;
please order front frame for EMC
shielding separately
2 horizontal covers, AI 2.5 mm,
front anodised,
rear iridescent green chromated;
2 vertical trims, Al extrusion,
clear passivated;
stainless steel EMC gasket;
front frame forms the contact
between subrack and the subassemblies
Al, 2.5 mm, clear anodised;
front frame with cut-out,
clear internal width
w = 266.35 mm
PU 1 kit
PU 1 kit
1 piece
Height
U
Usable
height h
HP
Other dimensions and options
3
24564-109
34564-108
3
24564-109
34564-109
4
28
24564-217
24564-209
34564-208
24560-270
Horizontal rail,
front
Horizontal rail,
rear
Assembly tool, for mounting the
* For direct backplane mounting
5.96
Desk-top cases – b
Order Information
Air baffle
without front panel
06108085
Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions;
06101507
Depth
mm
160
160
160
160
160
160
220
220
220
220
220
220
Width
HP
4
4
8
8
12
12
4
4
8
8
12
12
Height
U
3
6
3
6
3
6
3
6
3
6
3
6
1 piece
34562-823
34562-833
34562-836
34562-843
34562-846
34562-824
34562-827
34562-834
34562-837
34562-844
34562-847
5.97
Desk-top cases – b
Dimensions
Text
19.5
19.5
A
Z
15
M4
Z
Y
N x 15 = B
ø 8.5
3
N x 15 = B
Z
ø 8.5
Y
4.6
ø 4.6
Y
M4
M4
4.6
Y
15
ø 4.6
Z
M4
3
49
132.55
121.95
99.95
24
88.1
77.5
55.5
A
02004057
02004058
A
19.5
19.5
AA
49
49
93
49
177
166.4
144.4
132.55
132.55
121.95
121.95
99.95
99.95
19.5
15
M4
ZZ
Y
N x 15 = B
ø 8.5
33
Y
15
15
Z
M4
M4
YY
NNxx15
15==BB
YY
4.6
4.6
ø 4.6
M4
4.6
øø8.5
8.5
øø4.6
4.6
02004059
ZZ
M 44
M
3
49
49
132.55
132.55
121.95
121.95
99.95
99.95
265.9
265.9
Z
02004060
Dimensions
For case depth
mm
271
331
391
451
511
Max. mounting
depth
mm
250
310
370
430
490
Dimensions
A in mm
231
291
351
411
471
B in mm
15 15 = 225
19 15 = 285
23 15 = 345
27 15 = 405
31 15 = 465
Note
Side panel for 6 U case consists of two 3 U extruded side panels
5.98
Desk-top cases – b
5.99
J Main Catalogue
Desk-top cases – J
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
02202003
Standards
Subracks/
Front panels,
IEC 60297-3-100
IEC 60529
쮿 Protective ground connections in accordance with:
DIN EN 61010-1A2/VDE 0411 part 1/A1
Power supply
Backplanes . . . 10
Connectors, front
panel component
5.100
SCHROFF PRODUCT CATALOG E 05/2016
Desk-top cases – J
Overview . . . . . . 5.100
J
Case to accept 19" subracks or 19" chassis
쮿 Internal assemblies of up to 40 kg
쮿 Up to six rows of ventilation slots in the base plate for optimal air inlet
쮿 High stability
쮿 With handle strip or recessed grip
Case
comptec
쮿 Al die-cast frame front and rear
3, 4 U, St . . . . . . . . . 5.102
쮿 Top cover and base plate can be subsequently removed
6, 7, 9 U, St . . . . . . 5.103
9, 12 U, Al . . . . . . . . 5.104
쮿 Top cover and base plate fitted with hidden GND/earth
connections
쮿 Case height 3, 4, 6, 7 and 9 U
(cladding parts in steel)
쮿 Case height 9 U and 12 U
(cladding parts in aluminium)
Accessories
Folding handle . . . 5.105
Slide rails . . . . . . . . 5.105
Earthing kit . . . . . . 5.106
Assembly kit . . . . . 5.106
Tip-up feet . . . . . . . 5.107
02202004
Text
02202005
ServicePLUS . . . 5.4
e.g. modifications (cut-outs, special colours)
e.g. custom solutions (special sizes)
30407004
5.101
Desk-top cases – J
19" case, 3 U, 4 U
JMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Desk-top case (pre-fitted)
쮿 Top cover, base plate and rear panel in steel
쮿 Front and rear frames in die-cast Al
쮿 Ventilation slits in base plate
쮿 Ventilation gills in rear panel
쮿 Side panel with integral handle function
02202001
7
Qty
1
1
2
1
8
1
9
1
10
4
11
1
Description
Front frame, Al die-cast, RAL 7016, with 19" grid
Rear frame, Al die-cast, RAL 7016, with 19" grid
Side panel, Al extrusion, RAL 7016
Cover plate, Al, 1 mm, RAL 9006,
Base plate, Al, 1 mm, RAL 9006,
Rear panel, St, 1 mm, RAL 9006,
UL 94 V-0
Assembly kit
Items 1, 2, 5 and 9 fitted.
9
1
Item
1
2
5
7
2
Order Information
5
8
10
CTTP0001
Front view
Height H
h
Depth D
U
3
3
3
4
4
4
mm
13.0
13.0
13.0
13.0
13.0
13.0
mm
300
400
500
300
400
500
mm
153
153
153
198
198
198
Usable
depth d
mm
276
376
476
276
376
476
Width B
mm
520
520
520
520
520
520
Part no.
10225-601
10225-612
10225-623
10225-602
10225-613
10225-624
Note
H
HE
쮿 Please order GND/earthing kit separately, see page 5.106
쮿 The case foot, item 10, can be replaced by a tip-up foot,
see page. 5.107
쮿 Please order slide rails separately, see page 5.105
h
b
B
h = case foot height, HE = U, internal usable height
CTA30677
Side view
Usable width b = B - 69 mm, h = height of case foot
CTA42313
5.102
Desk-top cases – J
19" case, 6 U, 7 U, 9U
J
쮿 With handle shell
쮿 Ventilation slits in rear panel and base
02202002
7
9
3
1
6
Item
1
2
3
4
5
Qty
1
1
2
2
2
6
2
7
8
9
10
1
1
1
4
11
1
Description
Side profile at top, Al extrusion, RAL 7016
Side profile at bottom, Al extrusion, RAL 7016
Side panel, St, 1.5 mm, RAL 9006,
Handle shell, PC, RAL 7016, UL 94 V-0,
load-carrying capacity: 60 kg/pair
Cover plate, St, 1 mm, RAL 9006, with GND/earthing tag
Base plate, St, 1 mm, RAL 9006, with GND/earthing tag
Rear panel, St, 1 mm, RAL 9006, with GND/earthing tag
UL 94 V-0
Assembly kit
Items 1, 2, 3, 4, 5, 6 and 9 fitted.
5
Order Information
2
4
8
10
CTTP0002
H
HE
Front view
Height H
h
Depth D
U
6
6
6
6
7
7
7
9
9
9
mm
13
13
13
13
13
13
13
13
13
13
mm
300
400
500
600
400
500
600
400
500
600
mm
286
286
286
286
331
331
331
420
420
420
Usable
depth d
mm
276
376
476
576
376
476
576
376
476
576
Width B
mm
520
520
520
520
520
520
520
520
520
520
Part no.
10225-604
10225-615
10225-626
10225-637
10225-616
10225-627
10225-638
10225-618
10225-629
10225-640
h
Note
b
B
CTA30676
Side view
Usable depth d = D - 24 mm
see page 5.107
쮿 Handle shell, item 6, can be replaced by a folding handle,
see page 5.105
CTA42312
5.103
Desk-top cases – J
19" cases 9 and 12 U, aluminium
J
쮿 With handle shell
쮿 Top cover, base plate and rear panel in Al
쮿 Ventilation slots in base plate
쮿 Air vents in rear panel
02202006
7
Item
1
2
3
4
5
Qty
1
1
2
2
2
6
2
7
8
9
10
1
1
1
4
11
1
Description
Side panel, Al, 1.5 mm, RAL 9006,
Cover plate, Al, 1 mm, RAL 9006, with GND/earthing tag
Base plate, Al, 1 mm, RAL 9006, with GND/earthing tag
Rear panel, Al, 1 mm, RAL 9006, with GND/earthing tag
UL 94 V-0
Assembly kit
9
3
6
1
5
2
4
Order Information
8
10
CTTP0003
h
H
HE
Front view
Height H
h
Depth D
U
9
9
9
12
12
12
mm
13
13
13
13
13
13
mm
400
500
600
400
500
600
mm
420
420
420
553
553
553
Usable
depth d
mm
376
476
576
376
476
576
Width B
mm
520
520
520
520
520
520
Part no.
10225-667
10225-682
10225-693
10225-670
10225-685
10225-696
Note
b
B
CTA30679
Side view
see page 5.107
see page 5.105
CTA42314
5.104
Desk-top cases – J
Folding handle
J
쮿 Folding handles can be used instead of the pre-fitted
handle shells
쮿 Load-carrying capacity: 50 kg/pair
Item
1
2
Qty
2
1
Description
Folding handle, AI die-cast, RAL 7016
Assembly kit
Order Information
Description
Folding handle
Part no.
20225-439
CTTP0006
Slide rails
J
쮿 Slide rails are suitable as support for 19" subracks and
19" chassis
Delivery comprises
Item
1
Qty
1
Description
Slide rail, Al extrusion, anodised, cut edges plain,
static load-carrying capacity 10 kg
Order Information
For case depth
mm
300
400
500
600
Part no.
30225-089
30225-090
30225-091
30225-092
Note
쮿 2 slide rails are required per subrack or 19" chassis
쮿 Slide rail cannot be used for shielded 19" subracks; special
slide rails available on request
CTTP0005
5.105
Desk-top cases – J
GND/earthing kit
J
쮿 The GND/earthing kit allows VDE compliant earthing of cases in
accordance with:
EN 50178/VDE 0160
EN 60950/VDE 0805
쮿 VDE tested
Item
1
Qty
1
Description
GND/earthing kit, Cu wire, 1.5 mm2, PVC sheathing,
green/yellow, connects side panels, cover, base plate
and rear panel
Order Information
Description
aza43284
GND/earthing kit for cases with
steel covers
aluminium covers
Up to 4 U
Part no.
bigger than 4 U
Part no.
21100-490
21100-448
21100-347
19" fixing
J
쮿 For fitting subracks or 19" chassis in a comptec case
쮿 For fixing 19" front panels
Delivery comprises
Item
1
2
3
Description
Screw M6 × 16, zinc-plated with Pozidrive
Cage nut M6, zinc-plated
Plastic washer, ABS, black
Order Information
SC128XXX
Description
PU = 8 × screw, washer, nut
PU = 50 each of M6 screw, washer and cage nut
PU = 100 each of M6 screw, washer and cage nut
Part no.
21100-435
21101-809
21101-810
06108055
5.106
Desk-top cases – J
Plastic tip-up feet
J
standard
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Assembly kit
Order Information
Description
RAL 7016
anthracite
Part no.
RAL 9006
silver
Part no.
Plastic tip-up foot
20603-002
20603-001
01802075
Tip-up foot in die-cast Al
J
standard
Order Information
Description
Qty
1 piece (SPQ 10)1)
PU 100 pieces
Part no.
10603-002
10603-001
21101-211
21100-211
21100-207
AZA43836
5.107
Desk-top cases – Accessories
Contents
AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
06002052
05895003
02992004
aza43835
02992003
32506001
쮿
쮿
쮿
쮿
쮿
쮿
쮿
쮿
Front handles see page 5.108
Strap handles see page 5.111
Tip-up carrying handles, see page 5.112
Folding handles see page 5.113
Tray handle see page 5.114
Feet, see page 5.115
Screwdriver (Torx) 5.117
Measuring tape, see page 5.117
Front handle, one-piece, width 7 mm
쮿 Static load-carrying capacity 10 kg/pair
쮿 Bolted from rear
Item
1
Qty
1
Description
Front handle, Al extrusion, anodised
Order Information
A
mm
48
98
E
mm
40
90
Part no.
10501-001
10501-002
Pricing is per individual item.
BZA42318
Front handle, one-piece, width 9 mm
Accessories
쮿 Static load-carrying capacity 30 kg/pair
쮿 Bolted from rear
Item
1
Qty
1
Description
Order Information
Description
Front handle
Pozidrive countersunk screw 14 × 10, zinc-plated,
PU 100 pieces
Part no.
10501-003
21101-381
Please order at least 10 front handles or a multiple.
BZA42330
5.108
Front handle, one-piece, width 10 mm
Main Catalogue
40
4
10
h
Item
1
2
H
Ø 8,4
Ø 4,4
10
쮿 Bolted from front
8
H=1U
H≥2U
02905050
Qty
2
1
Description
Assembly kit
Order Information
Height H
U
1
2
3
4
5
Height H
mm
40
69
113
157.45
201.9
Height h
mm
28
53
97.5
141.9
186.4
Part no.
20860-256
20860-257
20860-258
20860-259
20860-260
02905051
Front handle, one-piece, width 12.2 mm
1U
Main Catalogue
쮿 Bolted from rear
Delivery comprises
Item
1
Qty
1
Description
Front handle, AI extrusion, anodised
Order Information
BZA42316
2 U ... 6 U
A
E
clear anodised
mm
mm
Part no.
41
25
10501-116
57.5
44.5
10501-016
69
55
10501-004
102
88
10501-005
132
120
10501-006
146.4
133.4
10501-018
194
180
10501-007
249
235
10501-008
Panhead pozidrive screw self-locking, M5 × 12,
Torx countersunk screw M5 × 12, zinc-plated,
100 pieces
black anodised
Part no.
10501-025
10501-026
10501-027
10501-028
10501-029
21100-788
24560-183
Please order at least 10 front handles or a multiple. Pricing is per
individual item.
Note
BZA42327
쮿 Please order panhead screws separately
5.109
Front handle, multi-piece, width 12 mm
쮿 In three parts, middle section in Al extrusion, end pieces in
glass fibre reinforced plastic
쮿 Bolts on from front
Item
1
2
Qty
1
2
Description
End piece, PA, black
Order Information
A
E
mm
mm
87.5
73.5
102.0
88
134.0
120
194.0
180
249
235
Panhead screw pozidrive self-locking, M5 × 12,
A3-227
Part no.
10502-050
10502-057
10502-059
10502-063
10502-065
21100-788
Note
Accessories
Order Information
12
Description
Qty/PU
Item 1, front handle, Al extrusion,
1
anodised,1 m long
Item 2, end piece, PA, black,
1
2 pieces each required
2
Part no.
30502-051
60502-003
21100-788
1000
1
40
02908050
Item 1: front handle; item 2: end piece
5.110
Strap handle, width 25 mm
Access ori es
쮿 Static load-carrying capacity 20 kg
Item
1
Qty
1
2
3
2
1
Description
Band, spring steel,
Assembly kit
Order Information
Length
mm
230
Part no.
20850-249
05895003
02902050
Strap handle, width 22 mm
Access ori es
Item
1
2
3
Qty
1
2
1
Description
Band, spring steel, plastic-coated, black
Cover cap, St, chrome-plated
Assembly kit
Order Information
02992006
Length 240 mm/170 mm
Length
mm
170
240
Part no.
10504-002
10504-003
BZA42368
Part number in normal type: ready for despatch within 10 working days
5.111
Tip-up carrying handle in separate parts
(with handle bars of 450 mm length)
02992002
02992001
Lateral handle parts
Accessories
쮿 Handle can be adjusted in 30° grid by pressing button
Item
1
2
3
4
Qty
2
2
2
1
Description
Lateral parts, die-cast zinc, painted (chrome decor)
Safety inserts, St, 1.5 mm, black
Adaptor/locking brackets
Assembly kit
Order Information
02992002
Length
mm
180
250
Part no.
10502-297
10502-296
A4-2361
Handle bar
Accessories
Item
1
Qty
1
Description
Handle bar, AI, black anodised
Order Information
Length
mm
1000
Part no.
30502-191
02992001
A4-2367
5.112
Folding metal handle
Access ori es
쮿 For case ingress protection to IP 40
쮿 Locks in folded and opened positions
쮿 Equal cut-out for fitting in front of or behind case wall
02992004
Item
1
2
Qty
1
1
Description
Handle, Al die-cast, RAL 9005, black
Handle shell, Al die-cast, RAL 9006, silver
Order Information
Description
Part no.
20505-032
Delivery is exclusively in Standard Pack Quantity (SPQ): Please
order at least 10 pieces or a multiple. Pricing is per individual
item.
A4-2369
A4-2370
Folding plastic handle
Access ori es
쮿 Static load-carrying capacity 20 kg/pair
쮿 External mounting only
02992005
Item
1
2
3
Qty
1
1
1
Description
Handle, PA, light grey
Handle shell, PA, dark grey
Assembly kit
Order Information
Description
Part no.
10505-014
individual item.
A2-123
5.113
Tray handle
Accessories
Delivery comprises
Item
1
Qty
1
Description
Handle shell, PC, UL 94 V-0
Order Information
Colour
Size 1 for material thickness
1.5 mm
Part no.
black
60229-004
Spring clip PU 20 pieces
Spring clip PU 100 pieces
02992003
Size 2 for material thickness
1.5 mm
Part no.
60225-012
21100-089
21100-093
Please order a minimum of 10 tray handles or a multiple.
Note
쮿 Please order spring clips for fixing to the case separately
Required:
– for handle size 1: 2 spring clips
– for handle size 2: 3 spring clips
Size 1, case cut-out 49 × 104 mm
Size 2, case cut-out 73 × 171 mm
5.114
A3-0670a
A3-0670b
Plastic foot
Access ori es
Delivery comprises
Pos.
1
Menge
1
Beschreibung
Plastic foot, PC, UL 94 V-0, black
Order Information
Description
Dimensions
A
B
C
mm mm mm
For material thickness 1 ... 3 16 7.2 4
For material thickness 1.5 ... 3 21 15 7
Hole
diameter
mm
7
7.7
Part no.
60224-009
60224-011
Please order at least 50 pieces or a multiple. Pricing is per
individual item.
A4-330
Note
쮿 Foot is inserted into mounting hole and then fixed by pressing
in the expanding pin
Rubber foot
Access ori es
Order Information
Dimensions
Height
Hole diameter
mm
mm
10
25
15
26
Material
Colour
Qty
Rubber
Rubber
grey
grey
1
1
Part no.
60200-001
60200-027
individual item.
A4-2315
5.115
Plastic tip-up foot
Accessories
78,4
쮿 Can be used instead of standard feet
Order Information
47
Description
38,4
13,9
Ø3,1
Ø4,8
grey
Part no.
Foot with tip-up, PA, UL 94 HB
1
10603-023
Foot without tip-up, PA, UL 94 HB 1
10603-024
Pozidrive flathead screw M4 × 10, St,
black
Part no.
10603-025
10603-026
21100-513
21100-211
21100-207
Please order a minimum of 10 feet or a multiple.
5
13,3
15,8
1
AZA43835
Qty/PU
Note
14
쮿 Please order assembly kit separately.
02912050
Plastic tip-up feet
Accessories
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Assembly kit
Order Information
Description
RAL 7016
anthracite
Part no.
RAL 9006
silver
Part no.
Plastic tip-up foot
20603-002
20603-001
01802075 02906050
5.116
Access ori es
Order Information
Description
Qty
1 piece (SPQ 10)1)
Accessories
PU 100 pieces
Part no.
10603-001
10603-002
21101-211
21100-211
21100-207
individual item.
AZA43836
Screwdriver
Retention partsMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 T8: For mounting guide rails to horizontal rails
쮿 T20: For mounting horizontal rails and rear hoods to side panels, cover plates, support brackets and front handles
Order Information
Torx screwdriver
M2.5
M4
Qty/PU
pieces
1
1
T 8 Torx
T 20 Torx
Part no.
64560-026
64560-027
AZA45925
Measuring tape
Main Catalogue
쮿 Measuring tape with cm, U-, HP-division (lenght 2 m)
쮿 Plastic cases, metal measuring tape with automatic collection
Order Information
Description
Measuring tape
Qty/PU
1
Part no.
89009-001
32506001
5.117
Small Form Factor Cases – Interscale
Interscale passive or convection cooled
InterscaleMain CatalogPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shipping within 10 working days
쮿 Available plain or perforated for forced cooling with fans
쮿 Modular case consisting of 4 easy to assemble parts
쮿 Integrated EMC protection
쮿 Ingress protection IP 30 (plain version)
쮿 Color RAL 7016
쮿 Small form factor or 19" rack mount
02613002
쮿 Rigid construction only requires two screws
쮿 Other dimensions, cutout shapes or locations, and screen
printing available
Delivery includes (assembled)
Item
Qty
1
1
2
3
4
5
1
1
1
1
02613014
2
2
4
1
3
Description
Base with 2 side panels (plain or perforated), St, 1 mm,
AlZn coated, RAL 7016 (anthracite gray);
19"-angle, 1,5 mm St, AlZn coated,
RAL 7016 (only on 19" version case)
Top cover, Al, 1 mm, RAL 7016
Front panel, Al, 1 mm, RAL 7016
Rear panel, Al, 1 mm, RAL 7016
User manual
4
1
3
02613050
Plain case
02613051
Perforated case
Order Information
Desktop cases
19" cases
Height
Width
Depth
U mm
1 43.65
1 43.65
1 43.65
1 43.65
1 43.65
1 43.65
1 43.65
2 88.10
2 88.10
2 88.10
2 88.10
2 88.10
3 132.55
3 132.55
3 132.55
Accessories
mm
132.55
132.55
221.45
221.45
310.35
399.25
399.25
221.45
221.45
310.35
399.25
399.25
310.35
399.25
399.25
mm
132.55
177.00
177.00
221.45
221.45
221.45
310.35
177.00
221.45
221.45
221.45
310.35
221.45
221.45
310.35
Desktop case
plain
Desktop case
perforated
Part no.
Part no.
14820-133
14820-134
14820-154
14825-154
14820-155
14825-155
14820-175
14820-195
14825-175
14825-195
14820-197
14825-197
14820-254
14820-255
14825-254
14825-255
14820-275
14825-275
14820-295
14820-297
14825-295
14825-297
14820-375
14825-375
14820-395
14820-397
14825-395
14825-397
Height
Width
Depth
U
1
1
2
2
3
3
mm
443.70
443.70
443.70
443.70
443.70
443.70
mm
221.45
310.35
221.45
310.35
221.45
310.35
mm
43.65
43.65
88.10
88.10
132.55
132.55
19" case
plain
19" case
perforated
Part no.
Part no.
14821-105
14826-105
14821-107
14821-205
14826-107
14826-205
14821-207
14826-207
14821-305
14821-307
14826-305
14826-307
Fan mount with fans, 80 mm height
Page 5.124
Stacking aid
Clip for horizontal rail mounting
Page 5.129
Rubber feet
Page 5.130
Wall or Desktop mounting bracket
Page 5.129
Plastic feet
Page 5.131
Plastic tip-up feet
Page 5.130
Assembly tool
Page 5.131
5.122
SCHROFF PRODUCT CATALOG E 12/2017
Page 5.130
Interscalefor Embedded NUC
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Perforated side panels for passive cooling (convection)
쮿 Compliant with the SDT.03 embeddedNUC standard
http://www.sget.org/standards.html
쮿 Modular case consisting of 3 easy to assemble parts; body, top
cover and front panel
쮿 Rigid construction requires only two screws
쮿 Board mounting studs installed
쮿 Color RAL 7016
02615019
쮿 Max. heat dissipation without fan about 8 Watt
쮿 Cutouts specific for IES (http://en.ies.de/) MB95 embedded
NUC board
쮿 Other dimensions, cutout shapes or locations and screen
printing available
Item
Qty
1
1
2
3
1
1
4
4
5
1
Description
Base with 2 side panels (perforated) and rear panel, Al,
1 mm, RAL 7016 (anthracite gray)
Pre-installed studs with M2.5 Torx T8 screws for board
mounting
User manual
Order Information
Height
Width
mm
mm
34.00
112.00
Accessories
Horizontal rail mounting bracket
Rubber feet
Assembly tool
Screwdriver
Depth
mm
106.50
Part no.
14820-701
Page 5.129
Page 5.129
Page 5.130
Page 5.131
Page 5.131
Note
쮿 Only the listed Interscale accessories are compatible
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
5.123
InterscaleMA IN CATALOG Part number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 worki ng days
쮿 Fan mount for installation in the Interscale
Item
1a
1b
2a
2b
3
4
1 fan
02617001
2 fans
02617002
Qty.
1
1
1
2
1
1
Description
Fan mount (1 fan), height 83 mm, width 83 mm
Fan mount (2 fans), height 83 mm, width 165 mm
Fan, 80 mm height, 80 mm width, 25.4 mm depth
Mounting material 4 x M3x6 countersunk screw
Fan attachment (with cord)
Order Information
Description
1 fan
2 fans
Qty/PU
piece
1
1
Qty
Part no.
PU 1 kit
PU 1 kit
24830-101
24830-102
Technical data of one fan
Voltage [VDC]
Dimensions H x W x D (mm)
Air capacity (free blowing) [m3/h]
Noise level [dB (A)]
Max. stat. pressure [Pa]
Max. ambient temperatures [°C]
5.124
12
80 x 80 x 25.4
109.44
44.62
95.41
70
Interscale for embedded NUC, conduction cooled
쮿 Integrated heat sink on top cover with 5 mm heat fins
쮿 Color RAL 7016
NUC board
Application: Case with connectors
02615021
printing available
Item
Qty
1
1
2
3
1
1
4
4
5
1
Description
Base with 2 side panels and rear panel, Al, 1 mm,
Top cover with integrated heat sink, Al, 1 mm, RAL 7016
Pre-installed M2.5 studs with Torx T8 screws for board
mounting
User manual
Order Information
02615009
Height
Width
Depth
mm
mm
mm
43.65
112.00
106.50
Accessories
Flexible Heat Conductor (FHC), 20 mm
Aesthetic Design Elements
Rubber feet
Assembly tool
Screwdriver
Part no.
14830-002
Page 5.127
Page 5.127
Page 5.130
Page 5.131
Page 5.131
Note
5.125
Interscale for Mini-ITX, conduction cooled
Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days
쮿 Integrated heat sink on top cover with 10 mm or 20 mm heat fins
쮿 Rigid construction requires only four screws
쮿 Color RAL 7016
쮿 Cutout for Mini ITX I/O panel,
power connector (Phoenix Contact, 0710028) and
power switch (Schurter, MCS 18 Front)
printing available
02615011
Item
Qty
1
1
2
3
1
1
4
4
5
1
Description
mounting
User manual
Order Information
Height
02615010
Width
Depth
mm
mm
mm
94.00
184.00
189.00
Accessories
Flexible Heat Conductor (FHC), 70 mm
Plastic tip-up feet
Rubber feet
Assembly tool
Screwdriver
With 10 mm
fins
Part no.
With 20 mm
fins
Part no.
14830-005
14830-006
Page 5.128
Page 5.127
Page 5.129
Page 5.129
Page 5.130
Page 5.130
Page 5.131
Page 5.131
Note
5.126
Small Form Factor Cases – Interscale Accessories
Aesthetic Design Elements for conduction cooled
Intersc ale AccessoriesMain C atalogPart number in bold face type: ready for s hippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days
쮿 Designs created to compliment the various heat fin heights
쮿 Compatible with all Interscale C enclosures
Delivery includes
Item
1
Qty
2
Description
Aesthetic design element, Al
For Mini-ITX
case
02615007
For embedded
NUC case
Order Information
For
case
width
mm
Colour, finish
5 mm
Heat fin height
10 mm
20 mm
Part no.
Part no.
Part no.
112
Blue (RAL 5010)
24830-010
112
Red (RAL 3027)
24830-011
112
Siver (RAL 9006)
24830-012
184
Blue (RAL 5010)
24830-013
24830-016
184
Red (RAL 3027)
24830-014
24830-017
184
Silver (RAL 9006)
24830-015
24830-018
쮿 Patent pending conduction cooling solution for small form
factor electronics
쮿 Conductor block expands/contracts vertically to compensate
for tolerance stack up and optimizes surface contact and
pressure along the thermal path; eliminates the need for a
thermal gap pad
쮿 Provides industry leading conduction cooling performance,
10 % improvement over current conduction cooling methods
쮿 Designed for Intel, AMD, Via, Freescale, NVidia and Texas
Instrument processors that employ a BGA socket
쮿 Secured to PCB with thermally conductive adhesive tape
02615016
쮿 Compatible with Interscale C enclosures
Item
Qty
1
1
2
1
Description
Flexible heat conductor, assembled; thermal grease
included
Adhesive tape, thermally conductive
Order Information
Height
19.75 ± 1.5 mm
Width
mm
22
Depth
mm
22
Part no.
24830-005
5.127
factor electronics
for tolerance stack up, and optimizes surface contact and
thermal gap pad
70 % improvement over current conduction cooling methods
쮿 Designed for ATX/ITX/Mini ITX & COM using Intel core-i
processors and AMD processors with the following sockets:
Intel: LGA775, LGA1150, LGA1155, LGA1156, LGA1366, LGA2011
AMD: AM2, AM2(+), AM3, AM3(+), FM1, FM2, FM2(+)
쮿 Secured to PCB with mounting brackets, sold seperately
02615017
Item
Qty
1
1
2
1
Description
included
Frame, Al
Order Information
Height
Width
mm
50
Depth
mm
50
68.50 ± 2.5 mm
Accessories
Intel mounting brackets for 70 mm FHC
AMD mounting brackets for 70 mm FHC
Part no.
24830-001
24830-002
24830-003
Note
쮿 Please order the mounting bracket (Intel or AMD, listed under
accessories) to assemble the FHC to the board
Mounting brackets for 70 mm FHC
쮿 Designed to secure the 70 mm Flexible Heat Conductor to PCB
쮿 Utilizes keep out zones to not interfere with other board
components
LGA2011 AMD: AM2, AM2(+), AM3, AM3(+), FM1, FM2, FM2(+)
Item
1
Qty
1
Description
Mounting bracket with associated hardware
Order Information
Description
Bracket for Intel
5.128
02615053
Application: Intel mounting bracket
Part no.
24830-002
24830-003
02615054
쮿 The clip can be used to fix the case to a horizontal rail
쮿 The clip is bolted to the case instead of the feet and can then be
fitted onto the rail
Delivery includes
Item
1
Qty
2
2
3
2
1
Description
Clip, Al profile, clear anodized, width 30 mm, 52 mm,
snap mounting for 35 mm DIN rails EN 50022; M4 selfclinching nut
Screw, T20, M4 x 6
User manual
Order Information
Description
02613069
02613070
Example: Clip for horizontal rail mounted on
case
Qty/PU
piece
2
Part no.
24820-002
Note
쮿 Not compatible with embedded NUC cases or Interscale
19" cases
쮿 Bracket for wall or desktop mounting
쮿 Provides 14 mm clearance from mounting surface for cable
management
쮿 Able to assemble / disassemble case while mounted
Delivery includes
Item
1
Qty
4
Description
Mounting bracket, St, 1.5 mm, finish AlZn
Order Information
Description
Qty/PU
piece
4
Part no.
24820-005
Note
02615052
Example: Mounting bracket
mounted on the case
02615051
19" cases
5.129
Plastic tip-up feet
쮿 Carrying capacity: 25 kg per foot
쮿 Mounting holes in bottom of casing
Delivery includes (kit)
01810004
Item
1
2
3
4
Qty
4
4
2
1
Description
Foot, PA, UL 94 V-0
Assembly kit
Order Information
Description
Qty/PU
piece
4
Tip-up feet, anthracite, similar to RAL 7016
Part no.
20603-002
Note
19" cases
Application example
02613008
02906050
Stacking aid
쮿 Stacking aid is clipped onto tip-up feet (please order tip-up feet
separately)
Item
1
Qty
4
Description
Stacking aid, PA ,UL 94 V-0
Order Information
Description
01810005
Qty/PU
piece
4
02613020
Application example Interscale
Stacking aid, anthracite, similar to RAL 7016
Accessories
Plastic tip-up feet anthracite, similar to RAL 7016,
4 pieces
Part no.
20603-003
20603-002
Note
쮿 A plastic tip-up feet are required for mounting, please order
separately
쮿 Not compatible with Interscale 19" cases, Interscale for
embedded NUC cases or Interscale conduction cooled cases
Rubber feet
쮿 Toolless installation; secures via adhesive
쮿 Compatible with all Interscale cases
Item
1
Qty
4
Description
Rubber feet, height 2.2 mm, Ø 7.9 mm
Order Information
02615020
5.130
Description
Rubber feet
Part no.
21102-025
Plastic feet
쮿 Plastic feet with rubberized base
쮿 Toolless installation; fixed by pressing in the expanding pin
Delivery includes
Item
1
Qty
1
Description
Plastic foot, PC, UL 94 V-0, black, with anti-slip
protection
Order Information
02613010
Dimensions
A
mm
16
A4-330
Illustration shows mounting of
feet
Hole diameter
B
mm
7.2
C
mm
4
Description
Qty
Part no.
Plastic feet
SPQ 50 1)
60224-009
Plastic feet
PU 4 2)
24820-004
1) SPQ (standard pack quantity): Part number includes 1 piece, but
please order at least the SPQ quantity or a multiple
2) PU - Part no. includes one packing unit (PU); delivery is exclusively
made in PU
Note
mm
7
Assembly tool
쮿 Plastic tool with bit can be used for bolting together and
opening the case
쮿 Compatible with all Interscale M and C enclosures
Delivery includes
Item
1
2
02613064
Qty
1
1
Description
Assembly tool (plastic)
Bit, Torx, T10
Order Information
Description
Assembly tool
Part no.
24820-001
Screwdriver
쮿 Used for securing PCBs to studs
쮿 Compatible with all Interscale M and Interscale C enclosures
Order Information
Description
Torx screwdriver, M2.5, T 8 Torx
Part no.
64560-026
AZA45925
5.131
m inipacMain Catalogue
Small Form Factor Cases – minipac
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
04812001
Subracks/
Small aluminium extrusion cases to hold PCBs
쮿 For applications e.g. in industry, railway technology, test and measurement, communications and network
technology
Fixing options
Front panels,
04812006
04811015
04812003
04812023
04812024
04812025
04812026
04812027
04812028
Various dimensions/colours
Power supply
Backplanes . . . 10
Individual shapes
Connectors, front
panel component
m inipacMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days
5.138
Overview . . . . . . 5.138
Convenient small case - flexible enough for all your requirements
mi nipacMain C ataloguePart number in bold face type: ready for des patch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days
쮿 To accomodate standardised and non-standardised PCBs
쮿 As desktop enclosure, for bolting (e.g. to a mounting plate) or
for mounting on DIN support rail (DIN 43880)
쮿 High level of heat dissipation through large aluminimum surface of case
쮿 High stability
쮿 Type of protection: IP 40
Trapezium shape
Trapezium
shape . . . . . . . . . . 5.140
쮿 Accommodates up to 3 PCBs of different heights 50, 60 or 65 mm and board depth 100 or 160 mm
쮿 As desktop enclosure, for wall mounting or for mounting on
04811014
Rectangular shape
쮿 Accommodates up to 4 standardised PCBs in euroboard
format, height 100 mm (3 U) or up to 8 non-standardised PCBs,
height 60 mm and board depth 160 mm
Rectagonal shape 5.141
쮿 Versions as desktop enclosure or for wall mounting
04812002
Individual cases in aluminium extrusion our minipac variety to your specifications
쮿 Other case lengths
쮿 Other case shapes
쮿 Cut-outs for lamps, switches, connectors, cable ducting, etc.
쮿 Individual printing of cover plates
쮿 Surface finish anodised or powder-coated
30407004
ANEL PRESS
P
T
N
EX
FRO
30402151
5.139
Trapezium shape
minipacMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Accommodates 3 non-standardised PCBs (height 50, 60 and 65
mm, depth 100/160 mm)
쮿 PCB thickness 1.6 mm, spacing 15.24 mm (3 HP)
쮿 Different versions
– Wall mounting
– For mounting on a DIN support rail (DIN 43880)
– Desktop version
Delivery comprises
Item
1
2
3
Qty
1
2
1
Description
Case, trapeziform, Al extrusion
Lateral cover plate, 2.5 mm, anodised
Fixing material kit, user manual
Order Information
46,1
15,24
2
04812004
53,
1
50,
4
60,
4
65,
4
74,
2
04811053
Dimensions of body tube
Description
Length
mm
Case, trapeziform, Al extrusion, black anodised;
lateral cover plates anodised, thickness 2.5 mm
(no mounting option)
Case, trapeziform, Al extrusion, black anodised,
(for wall mounting on long side of trapezoid)
Case, trapeziform, Al extrusion, anodised;
(for wall mounting on short side of trapezium)
for DIN support rail mounting (DIN 43880);
(for mounting on a DIN support rail, DIN 43880)
Accessories
Rubber foot for desktop version, PU 4 pieces
Part no.
100.5
24814-008
100.5
24814-010
100.5
24814-011
160.5
24814-014
21102-025
Note
2,5
쮿 On request:
- Other case lengths
- Cut-outs for LEDs, switches, connectors or couplings
(USB, SUB-D)
- Individual printing on cover plate
D
47,
54,2
41,7
26,4
75,6
25
6,4 3
1
52
5
04812053
Desktop version
2,5
Wall mounting
(on short side of trapezoid)
04812052
75,6
25
88,1
26,4
3,9
D
47,
6,4 3
1
52
2,5
Wall mounting
(on long side of trapezoid)
5.140
5
2,5
04812051
04812057
rail (DIN 43880)
ELECTRONICS PROTECTION
Rectangular shape
minipacMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 Accommodates 4 standardised PCBs
(height 100 mm, depth 160 mm) or rotated by 90° to
accomodate 8 non-standardised PCBs (height 60 mm,
depth 160 mm)
쮿 PCB thickness 1.6 mm, spacing 15.24 mm (2 HP)
– Wall mounting
– Desktop version
Delivery comprises
Item
1
2
3
04812002
Qty
1
2
1
Description
Case, rectangular, Al extrusion
Order Information
Description
2
70,3
10,16
Case, rectangular, Al extrusion, black anodised;
(desktop version)
Case, rectangular, Al extrusion, anodised;
(for wall mounting on long side)
(for wall mounting on short side)
Accessories
,6
60,6
100
2
10,
16
110
D
9
Length
mm
Part no.
160.5
24814-024
160.5
24814-025
160.5
24814-027
21102-025
Note
04812050
71,
D
6,4 3
1
D
7
26,4
112,3
112,3
25
쮿 On request:
(USB, SUB-D)
76,
2
2,5
04812056
Desktop version
2,5
Wall mounting
(on long side of rectangle)
04812055
71,7
26,4
25
6,4 3
1
D
116
8
2,5
Wall mounting (on short side of rectangle)
04812054
5.141
PROLINE
Overview Main Catalogue
Subracks/19" chassis – Overview
Content
D
Wall mounted
19" subrack with high flexibility
in accordance with IEC 60297-3-103 and IEEE 1101.10/11
For different applications:
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
쮿 Kits, individual configuration and an extensive accessory range
쮿 Industrial applications
쮿 Shock and vibration resistance up to 5 g, e.g. for mobile railway applications
쮿 Shock and vibration resistance up to 25 g for rugged environments, e.g. mobile
military applications
Electronics
Subracks/
Front panels,
Power supply
Backplanes . . . 10
Connectors, front
panel component
6.0
Downloads und weitere wichtige Informationen finden Sie
im Internet unter www.schroff.biz
36106005 (06109001 06108006 06112002 06112020)
Overview . . . . . 6.0
O
19" chassis for non-standard components and horizontal board construction
Versions in aluminium and steel plate (AlZn coated)
Kits from stock or to individual configuration
europacPRO . . . 6.2
multipac . . . . . . 6.112
inpac . . . . . . . . . . 6.128
Application examples
europacPRO . . . 6.69
Subracks for
mobile railway
applications . . . . 6.70
F
19" chassis with high mechanical stability
Flexible construction for standard board formats or individual solutions
Can be used as a desk-top enclosure
36106006 (06002001
06002003 02192004)
6.1
DMain
type:
Part
despatch
number
ready
CataloguePart
within
for
indes
normal
1 0patch
worki
num
type:
within
ngber
days
ready
in2 bold
working
forfacedays
Subracks – D
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
europacPRO standard
쮿 19" subrack with high flexibility
쮿 EMC shielding upgradable
쮿 In accordance with IEC 60297-3-103 and
IEEE 1101.10/11
쮿 Kit from stock or individual configuration
Electronics
Subracks/
Front panels,
europacPRO for mobile railway applications
쮿 Over and above the europacPRO standard range additional
shock and vibration properties for up to 5 g in accordance
with the standards:
– IEC 61587-1, EN 50155
– BN 411002 and BN 411003
– NF F 61-005 / NF F 60-002
Power supply
Backplanes . . . 10
Connectors, front
panel component
36112001 (06109001 06103001 06108006)
6.2
SCHROFF Main catalogue
www.schroff.biz E 05/2016
D
Subracks – D
Overview . . . . 6.2
europacPRO for industrial applications
additional kits for wall mounting or for installation of
supply modules to DIN 43880
Introduction . . . . 6.4
europacPRO for rugged applications
shock and vibration properties for up to 25 g in accordance
with the standards:
MIL 167, IEC 61587 DL 3, MIL 810 G, MIL 901
Subracks for
mobile railway
europacPRO for
industrial
applications . . . . 6.86
europacPRO for
rugged
applications . . . . 6.92
europacPRO accessories
쮿 Extensive range of accessories for
europacPRO products
쮿 Side panels, horizontal rails, guide rails,
cover plates, front/rear covers, handles
and shielding components
쮿 Interior assembly: combined mounting 6 or
2 x 3 U, horizontal board mounting,
mounting plates, panel mounting, central
locking, telescopic slides, divider plates,
air deflectors, 19" module support and
extensive fixing material kit
Accessories . . . . 6.17
36112002 (01494031 06112002 06112001 06112020)
6.3
6.3
Subracks – DIntroduction
Platform-based standard solutions for individual requirements
Practical technology without time-consuming assembly. The
modular europacPRO product platform allows a wide range of
possible applications with only a few components. The intelligent
design of all components results in remarkably simple and fast
management in assembly and components.
Simple assembly with europacPRO kits:
Two ways of reaching your desired product:
Text
쮿 Kits
쮿 Individual configuration
Individual configuration:
06107001
Delivered in space-saving flat packs. The threaded inserts or
EMC gasket (depending on selected kit) are already pre-mounted
on the horizontal rail.
06109052
You design your subrack as you wish, then receive it fully
assembled via our ServicePLUS assembly service (even for orders
of just one). We can also carry out individual modifications and
cut-outs; and when time is short can do so very fast via
ServicePLUS express.
Introducti onDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatch within 10 working days
Horizontal rails and side panels for different load-carrying classes
Horizontal rails are available for three load classes:
Text
쮿 "light" (load up to approx. 7.5 kg)
쮿 "heavy" (load > 7.5 kg)
Light
06197007
Heavy
06197008
Rugged
06112004
쮿 "rugged" (load 15 kg)
Side panels for 4 different load classes
쮿 Light: low-cost version with built-in 19" mounting bracket
쮿 Flexible: with separate, depth-adjustable 19" mounting bracket
쮿 Heavy: with integrated, tox-cold welded 19" mounting bracket,
e.g. for shock and vibration environments up to 5 g
Type Light
06197002
Type Flexible
06197003
쮿 Rugged: with integrated, tox-cold welded 19" mounting bracket
and higher material thicknesses for extreme mechanical
stresses, e.g. for increased shock and vibration environments
up to 25 g
쮿 The combination of the 3 horizontal rail variants with the 4 types
of side panel results in an almost unlimited variety of potential
applications for various market requirements
Type Heavy
6.4
06197004
Type Rugged
06112021
Guide rails from plastic and aluminium profiles
Guide rails form the interface between the subrack mechanics and
the assemblies (boards, plug-in units, frame type plug-in units,
drive unit modules, ...).
Robust snap-in fixings on the plastic rails assure a secure grip,
even when exposed to vibrations. In the case of H and R-type
horizontal rails the guide rails can also be bolted on. For extreme
stresses, guide rails in aluminium extrusion are used.
To ensure that the wrong subassembly is not inserted into the
wrong space we offer a mechanical coding to IEEE 1101.10/11 and
IEC 60297-3-103.
The continuous numbering on the horizontal rail (from 28 HP) and
the markings on the guide rails facilitate quick fitting in the correct
position.
06112052
06111059
We offer the appropriate adaptors for accommodating VPX or
CompactPCI boards with strengthening frame or conductioncooled assemblies (CCA) installed in a subrack.
Electromagnetic shielding and ESD
The product platform europacPRO offers a variety of off-the-shelf
solutions to assure electromagnetic compatibility (EMC) and to
avoid electrostatic discharge (ESD).
dB
120
Text
100
80
60
40
400
800
1200
1600
2000
Mhz
06108081
Two shielding concepts
It can't be more secure!
Two types of shielding concepts to front/rear of the subrack allow
the use all Schroff frontpanels.
The shielding at the front of the subrack is by means of stainless
steel or textile EMC gaskets.
Stainless steel gasket
Textile gasket
06108074 06108073
ESD (electrostatic discharge)
To avoid electrostatic discharge when inserting PCBs, ESD
contacts are clipped into the guide rails. These establish a
conductive connection between PCB and subrack-earth.
Under IEC 60297-3-101 two ESD areas are defined on the
euroboard. The ESD clips of the guide rail of the europacPRO
subrack allow the assembly of both following variants:
쮿 ESD area (bottom and top) over the complete board length
쮿 ESD area (bottom/top) begins at the front from 70 mm to
end of board)
04503050 06103052
6.5
DMain Catalogue
Subracks – D
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
06197001
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Different horizontal rails for
various applications
06112014
04602002
The IEEE handles and shielded
front panels are designed for the
construction of CompactPCI and
VME64x subrack systems
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
Standards/certifications
쮿 Inner and outer dimensions meet:
IEC 60297-3-100, -101, - 102, -103, -104, -105
IEEE 1101.1 and IEEE 1101.10/11
EMC
dB curve
120
100
쮿 Type of protection IP 20 to IEC 60529
80
쮿 EMC testing to IEC 61587-3
60
쮿 Shock and vibration test reports:
German "Bahn" standards BN 411002, BN 411003;
NF F 60002, NF F 67012
IEC 61587-2, EN 50155
40
쮿 Nuclear plants KTA 1401
06
Sequential numbering on
horizontal
rails (> 28 HP) and markings on
the guide rails provide quick optical
positioning aids. ESD clips can be
used at front or rear, to protect
electronics from electrostatic
discharge
400
800
1200
1600
2000
Mhz
06108081
Appendix . . . . . 12
6.6
SCHROFF PRODUCT CATALOG E 03/2016
Subracks – D
Overview . . . . . 6.6
19" subracks
DMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Kits or individual configuration
쮿 One product and accessories platform for every kind of
customer requirement and application
쮿 Suitable for CompactPCI and VME64x insertion and extractor handles
쮿 EMC shielding can easily be retrofitted if needed
쮿 Shock and vibration resistant up to 5 g
쮿 3D PDF or CAD 3D data available for download
Kits
쮿 All required parts available under one order number,
some pre-fitted
쮿 Most popular dimensions and versions available from stock
Introduction. . . . 6.4
Kits
Light . . . . . . . . . . . . 6.8
Flexible . . . . . . . . . . 6.9
Heavy . . . . . . . . . . . 6.14
CompactPCI. . . . . . 6.16
쮿 For installed loads up to 7.5 kg, up to 11 kg and up to 15 kg
쮿 As unshielded or shielded version
쮿 Supplied as space-saving flat-pack
ServicePLUS . . . 6.16
06102008
ServicePLUS individual configuration
쮿 Single parts may individually be configured, respectively
assembled on request (from quantity 1)
쮿 Very wide range of variants in heigth, width and depth
쮿 Guide rails for different applications
쮿 EMC shielding material to improve EMC performance
쮿 Interior assembly options with mounting plate or combined
mounting (3 + 6 U segments)
06105058
쮿 Other accessories and assembly kits
ServicePLUS
configuration
Side panels . . . . . .
Horizontal rails,
threaded inserts,
perforated strips .
Guide rails . . . . . . .
Cover plates . . . . .
EMC shielding . . .
Interior
assemblies . . . . . .
Assembly kits . . . .
6.21
6.29
6.37
6.44
6.54
6.59
6.65
Application
examples . . . . . . 6.71
Subracks for
mobile railway
ServicePLUS from page 6.16
e.g. individual configuration and assembly
e.g. modification (cut-outs)
e.g. downloads (CAD drawings,
user manuals, test reports)
europacPRO for
industrial
europacPRO for
rugged
www.schroff.biz/ServicePLUS
30407004
SCHROFF.PENTAIR.CO.UK
6.7
Subracks – D
Kit, "light", unshielded,
for backplane mounting
DMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
쮿 Subrack with side panel type L ("light") with firmly fixed
19" brackets
쮿 Rear horizontal rails for backplane mounting with insulation
strip
쮿 Installed load up to 7.5 kg
쮿 Cost-optimised
Delivery comprises (Kit)
06111002
1
2b + 3 + 4
2c + 3 + 4
5
Item
1
Qty
3U
2
6U
2
Description
2a
2b
2c
3
4
5
2
2
4
2
1
2
2
1
6
4
1
Side panel type L, Al, 2 mm, passivated,
with built-in 19" support bracket
Front horizontal rail (L-KD)
Rear horizontal rail (L-ST)
Rear horizontal rail centre (ST)
Threaded insert, front and rear (pre-fitted)
Insulation strip (pre-fitted)
Order Information
2a + 3
1
5
06111056
6U
Height
U
3
3
3
6
6
6
Width
HP
84
84
84
84
84
84
Depth D
mm
175
235
295
175
235
295
Depth D1
mm
175
175/235
175/235/295
175
175/235
175/235/295
Part no.
24564-131
24564-132
24564-133
24564-431
24564-432
24564-433
Accessories
19" assembly kit (screw, washer, nut) (
8 × screws, 8 × plastic washers, 8 × cage nuts)
21100-435
Guide rails (standard), ESD clips
Depth D2
mm
160
220
280
ESD clips for guide rails PU 50 pieces
D2
D1
Qty/PU
piece
10
10
10
Part no.
24560-351
24560-353
24560-379
24560-255
Cover plates for insertion in horizontal rails (type L)
D
06108051
D = overall depth, D1 = insertion depth,
D2 = board depth = D1 - 15 mm
Depth D2
mm
160
220
Width
HP
84
84
Qty/PU
piece
2
2
Part no.
24561-051
24561-052
Note
쮿 Subrack is not prepared for shielding
쮿 ServicePLUS configuration from page 6.16
04400001
Rear horizontal rail for backplane mounting with insulation strip
ServicePLUS see page 6.16
6.8
Subracks – D
Kit, "flexible", unshielded,
Part number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days
쮿 Subrack with side panel type F ("flexible"),
19" bracket is depth-adjustable
쮿 Rear horizontal rails for connector mounting
(IEC 60603-2 / DIN 41612)
쮿 Installed load up to 11 kg
Delivery comprises (kit)
Item
1
Qty
3U
2
6U
2
Description
2
3a
3b
3c
4
5
2
2
2
2
1
2
2
2
1
2
1
06105001
Photo: 3 U subrack
2
3b
3c
1
19" support bracket, Al extrusion, for EMC gasket
(St, stainless)
Side panel type F, Al, 2 mm
Rear horizontal rail (L-MZ) for connector mounting
Centre horizontal rail (MZ)
Threaded insert to front (pre-fitted)
Order Information
5
2
3a + 4
1
5
6U
06105054
Height
U
3
3
3
3
6
6
6
6
Width
HP
84
84
84
84
84
84
84
84
Depth D
mm
175
235
295
355
175
235
295
355
Depth D1
mm
175
175/235
175/235/295
175/235/295/355
175
175/235
175/235/295
175/235/295/340
Part no.
24563-191
24563-192
24563-193
24563-194
24563-491
24563-492
24563-493
24563-494
Accessories
21100-435
Depth D2
mm
160
220
280
340
ESD clip for guide rails PU 50 pieces
D2
D1
Qty/PU
piece
10
10
10
10
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
D
06108050
Depth D2
mm
160
220
Width
HP
84
84
Qty/PU
piece
2
2
Part no.
24561-051
24561-052
Note
04400003
Horizontal rail to rear for connector mounting
6.9
Subracks – D
Subrack kit, unshielded for connector,
assembly on slide rail
쮿 Subrack can be used with slide rails
쮿 Subrack with side panel type F ("flexible"), 19" bracket is
depth-adjustable
쮿 Horizontal rails, rear, for connector mounting
Delivery includes (Kit, flat pack)
Item
06105001
Photo: 3 U subrack
2
3b
3c
1
5
6U
2
Description
2
3a
3b
3c
4
5
2
2
2
2
1
2
2
2
1
2
1
19" support bracket, Al extrusion, for EMC sealing
(St, stainless)
Center horizontal rail (MZ)
Fixing materials kit, user manual
Order Information
2
3a + 4
1
5
06105054
6U
1
Qty
3U
2
Height
U
3
3
3
6
6
6
Width
HP
84
84
84
84
84
84
Depth D
mm
235
295
355
235
295
355
Depth D1
mm
175/235
175/235/295
175/235/295/355
175/235
175/235/295
175/235/295/355
Part no.
24553-192
24553-193
24553-194
24553-492
24553-493
24553-494
Accessories
19" fixing material kit (screw, washer, nut) (8 × screws,
21100-435
Depth D2
Qty/PU
mm
piece
160
10
220
10
280
10
ESD clip for guide rails Spring steel, tin-plated, silver, PU
50 pieces
D2
D1
D
D=overall depth, D1=insertion depth,
D2=board depth = D1 - 15 mm
06108050
Part no.
24560-351
24560-353
24560-379
24560-255
Cover plates for insertion into
horizontal rail type L
Depth D2
mm
160
220
Width
HP
84
84
Qty/PU
piece
2
2
Part no.
24561-051
24561-052
Note
쮿 Alternative product for older europac lab and europacRational
subrack series
쮿 ServicePLUS configuration from page 6.18
Rear horizontal rail for connector mounting
6.10
04400003
Subracks – DKits
Subrack kit, unshielded, flexible for backplane,
KitsDMain CatalogPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shi pping within 1 0 working days
depth-adjustable
strip
Item
06102007
Photo: 3 U subrack
6U
2
3b + 4 + 5
3c + 4 + 5
1
1
Qty
3U
2
6U
2
Description
2
3a
3b
3c
4
5
6
2
2
2
4
2
1
2
2
2
1
6
4
1
(St, stainless)
Rear horizontal rail (L-ST) for backplane mounting
Rear center horizontal rail (ST)
Threaded inserts, front and rear (pre-fitted)
Order Information
6
Height
U
3
3
3
6
6
6
2
3a + 4
1
6
06102081
Width
HP
84
84
84
84
84
84
Depth D
mm
235
295
355
235
295
355
Depth D1
mm
175/235
175/235/295
175/235/295/355
175/235
175/235/295
175/235/295/355
Part no.
24553-132
24553-133
24553-134
24553-432
24553-433
24553-434
Accessories
(8 × screws, 8 × plastic washers, 8 × cage nuts)
21100-435
Depth D2
Qty/PU
mm
piece
160
10
220
10
280
10
340
10
50 pieces
D2
D1
D
06108051
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
Depth D2
mm
160
220
Width
HP
84
84
Qty/PU
piece
2
2
Part no.
24561-051
24561-052
Note
subrack series
strip
04400001
6.11
Subracks – DKits
Main Catalogue
쮿 Rear horizontal rail for backplane mounting with insulation
strip
Item
1
Qty
3U
2
6U
2
Description
2
3a
3b
3c
4
5
6
2
2
2
4
2
1
2
2
2
1
6
4
1
06102007
2
3b + 4 + 5
3c + 4 + 5
1
6
Order Information
2
3a + 4
1
6
6U
for EMC stainless steel gasket
06102081
Height
U
3
3
3
3
3
3
6
6
6
6
6
6
Width
HP
84
84
84
84
84
84
84
84
84
84
84
84
Depth D
mm
175
235
295
355
415
475
175
235
295
355
415
475
Depth D1
mm
175
175/235
175/235/295
175/235/295/355
175/235/295/355
175/235/295/355
175
175/235
175/235/295
175/235/295/355
175/235/295/355
175/235/295/355
Part no.
24563-131
24563-132
24563-133
24563-134
24563-135
24563-136
24563-431
24563-432
24563-433
24563-434
24563-435
24563-436
Accessories
21100-435
D2
D1
D
06108051
Depth D2
mm
160
220
280
340
Qty/PU
piece
10
10
10
10
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
Depth D2
mm
160
220
Width
HP
84
84
Qty/PU
piece
2
2
Part no.
24561-051
24561-052
Note
04400001
6.12
Subracks – DKits
Kit, "flexible", shielded,
Main Catalogue
strip
쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz,
assuming that the front is closed with shielded front panels
Delivery comprises ((kit))
06102008
7
3
4c + 5 + 6
4 + 5 + 11
1
4a + 5
9
4b + 5 + 6
2
4 + 5 + 11
7
10
6U
06102075
Item
1
2
3
4
4a
4b
Qty
3U
2
2
2
2
2
2
6U
2
2
2
2
2
2
4c
5
6
7
8
9
10
11
12
6
2
2
1
1
1
2
1
1
8
4
2
1
1
1
2
1
D1
D
06113056
19" support bracket for EMC textile gasket
Rear corner profile for EMC textile gasket
Side panel type F
Rear horizontal rail (L-KD)
Centre horizontal rail (ST)
Threaded insert (pre-fitted)
Insulation strip, fixed
EMC cover plate
EMC gasketing material (pre-fitted)
Rear panel
Fixing material kit
Perforated strip (pre-fitted)
User manual
Order Information
Height
U
3
3
3
3
3
6
6
6
6
6
D2
Description
Width
HP
84
84
84
84
84
84
84
84
84
84
Depth D
mm
235
295
355
415
475
235
295
355
415
475
Depth D1
mm
175/235
175/235/295
175/235/295
175/235/295
175/235/295
175/235
175/235/295
175/235/295
175/235/295
175/235/295
Part no.
24563-142
24563-143
24563-144
24563-145
24563-146
24563-442
24563-443
24563-444
24563-445
24563-446
Accessories
21100-435
04400001
Depth D2
mm
160
220
280
340
Qty/PU
piece
10
10
10
10
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
Note
6.13
Subracks – DKits
Kit, 'heavy', unshielded,
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 Subrack with side panel type H ("heavy"),
19" bracket is firmly fixed to side panel (tox-cold welded)
strip
쮿 Installed load up to 15 kg
쮿 Versions with/without front handles
06102007
Without front handle
06111003
With front handle
Item
1
6
1
Qty
3U
2
6U
2
Description
2a
2b
2c
3
4
5
6
2
2
4
2
1
2
2
2
1
6
4
1
2
2b + 3 + 4
2c + 3 + 4
5
2a + 3
Side panel type H, Al, 2 mm, passivated,
with 19" support bracket (tox-cold welded)
for textile EMC gasket
Front horizontal rail (H-KD)
Rear horizontal rail (H-ST)
Rear horizontal rail centre (H-ST)
Front handle (on version with front handle only)
Order Information
1
5
6U
06111057
Height Width Depth D Depth D1
U
HP
mm
mm
3
3
3
3
6
6
6
6
84
84
84
84
84
84
84
84
175
235
295
355
175
235
295
355
175
175/235
175/235/295
175/235/295/355
175
175/235
175/235/295
175/235/295/355
Part no.
with front
handle
Part no.
without front
handle
24567-161
24567-162
24563-161
24563-162
24567-163
24563-163
24567-164
24567-461
24563-164
24563-461
24567-462
24563-462
24567-463
24567-464
24563-463
24563-464
Accessories
D2
D1
D
06108052
D = overall depth, D1 = insertion depth, D2 = board depth
04400001
21100-435
Depth D2
Qty/PU
mm
piece
160
10
220
10
280
10
340
10
Torx panhead screw , for extra bolting of the guide rails,
2.5 × 9.3, zinc-plated, PU 100 pieces;
torque max. 0.2 Nm
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
24560-141
Cover plates for bolting to side panel
Depth D2
mm
160
220
280
340
Width
HP
84
84
84
84
Qty/PU
piece
2
2
2
2
Part no.
24560-078
24560-079
24560-080
24560-081
Note
6.14
Subracks – DKits
Kit, "heavy", shielded,
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
strip
assuming that the front is closed with sealed front panels
06102008
06111001
With front handle
7
Item
1
Qty
3U
2
6U
2
2
3
3a
3b
3c
4
5
6
7
8
9
10
11
2
2
2
2
6
2
2
2
1
1
1
2
2
2
2
2
1
8
2
4
2
1
1
1
2
3b + 4 + 6
3+4+5
Description
3c + 4 + 6
11
1
3a + 4
9
2
3+4+5
10
7
11
6U
06111058
with 19" support bracket (tox-cold welded);
Rear corner profile for textile EMC gasket
Rear horizontal rail (H-KD)
EMC cover plate
EMC rear panel
Order Information
D2
D1
D
06113055
Height
U
Width
HP
Depth D
mm
Depth D1
mm
3
3
3
6
6
6
84
84
84
84
84
84
235
295
355
235
295
355
175/235
175/235/295
175/235/295
175/235
175/235/295
175/235/295
Part no.
with front
handle
Part no.
without front
handle
24567-172
24563-172
24567-173
24567-174
24563-173
24563-174
24567-472
24563-472
24567-473
24567-474
24563-473
24563-474
Accessories
21100-435
04400001
Depth D2
Qty/PU
mm
piece
160
10
220
10
280
10
torque max. 0.2 Nm
Part no.
24560-351
24560-353
24560-379
24560-255
24560-141
Note
6.15
Subracks – DKits
Kit, for CompactPCI, for backplane mounting,
without rear I/O, shielded
Main Catalogue
쮿 Subrack with side panel type F ("flexible") for CompactPCI
plug-in units with high insertion and withdrawal forces
strip
assuming that the front is covered with shielded front panels
06102009
6U
7
3
4d + 5 + 6
1
9
2
4a + 5 + 11
7
10
4b + 5
4c + 5 + 6
06102078
Item
1
2
3
4
4a
4b
4c
Qty
3U
2
2
2
1
1
2
2
6U
2
2
2
2
2
2
Description
4d
5
6
7
8
9
10
11
12
6
2
2
1
1
1
2
1
1
8
4
2
1
1
1
2
1
Side panel type F
Front horizontal rail IEEE (H-LD)
Rear horizontal rail (H-ST), for backplane mounting
EMC cover plate
Rear panel
Fixing material kit
Perforated strip (pre-fitted in item 4+4a)
User manual
Order Information
Height
U
3
6
Width
HP
84
84
Depth D
mm
235
235
Depth D1
mm
175
175
Part no.
24563-152
24563-452
Accessories
D2
D1
D
06113055
Guide rail with coding, red 160 mm deep,
PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces
Guide rail with coding, grey 160 mm deep,
Guide rail with coding, green, offset 160 mm deep,
ESD clip for alignment pin of CPCI/VME64x handle
PU 50 pieces
Torx panhead screw 2.5 × 9.3, zinc-plated,
PU 100 pieces; torque max. 0.2 Nm
Coding peg PC, UL 94 V-0, RAL 7035, PU 100 pieces
24560-356
24560-358
24560-359
24560-255
24560-256
24560-141
20817-501
21100-435
Note
04400001
6.16
Subracks – DKits
for rear I/O, shielded
Main Catalogue
쮿 For rear I/O boards (depth 80 mm)
strip
06108007
Item
6U
7
3
4d + 5 + 6
11
1
2
3
4
4a
4b
4c
Qty
3U
2
2
2
1
1
2
2
6U
2
2
2
2
2
2
Description
4d
5
6
7
8
9
10
11
12
6
2
2
1
1
2
2
1
1
8
4
2
1
1
2
2
1
1
2
4a + 5 + 10
7
9
4b + 5 + 10
4c + 5 + 6
06105076
Side panel type F
with insulation strip for backplane mounting
EMC cover plate
Fixing material kit
Horizontal rail type AB
User manual
Order Information
Height
U
3
6
Width
HP
84
84
Depth D
mm
275
275
Depth D1
mm
175
175
Depth D3
mm
80
80
Part no.
24563-157
24563-457
Accessories
D2
D3
D1
D
D2 = board depth = D1 - 15 mm, D3 = rear I/O board depth
04400001
06108075
PU 50 pieces
Guide rail with coding, red 70 mm deep, PU 10 pieces
Guide rail with coding, grey 70 mm deep, PU 10 pieces
Torx panhead screw 2.5 × 9.3, zinc-plated, PU 100 pieces;
torque max. 0.2 Nm
24560-356
24560-358
24560-359
24560-255
24560-256
24560-355
24560-360
24560-141
20817-501
21100-435
Note
6.17
Subracks – DServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined freely
쮿 Configuration tables from page 6.19
쮿 Online configuration: www.schroff.co.uk/configuration
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and electronic
components by our specialists
쮿 Professional and reliable from quantity 1
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Custom modifications from quantity 1
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Special sizes (depth and width)
쮿 Ready for despatch within 5 working days
쮿 Ready for despatch within 10 working days
쮿 Individual heat dissipation concepts
express
When fast has to be faster.
Delivery time to customer's request
쮿 Express logistics
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, CAD drawings, test reports, user reports
ServicePLUS
6.18
Overview of individual components for shielded or unshielded subracks
4
2
1
6
5c
3
5b
2
5a
06108086
Item
Description
Item 1
Side panel
1
ServicePLUSDPart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Description
Establishes the height and depth of the subrack;
Al, 2 mm, with universal hole positions for assembly of accessories.
Three versions: The "flexible" one with separate 19" brackets as well as two others with integrated
19" brackets for "light" and "heavy" applications.
page
6.21
Item 2
Horizontal rail
Establishes the width of the subrack;
Al extrusion, with defined hole positions for guide rails, grooves for threaded inserts, M4 thread,
functional rail shapes, basically differing with regard to their mechanical loading capacity:
“light“ (load up to 7.5 kg) and “heavy“ (load > 7.5 kg).
Item 3
Guide rails
Act as interface between subracks and boards,
for different board formats, are available in plastic or metal,
optionally codable and can be fitted with ESD clips to allow electrostatic discharge, also optionally.
6.37
Item 4
Cover plates
Provide mechanical protection and/or EMC shielding and are perforated.
6.44
Item 5
Rear/front
Rear hood (5a) or front panel (5b) with corner profile (5c) act as support for EMC shielding gaskets used
in conjunction with shielded front panels.
Note: Rear hood and corner profile cannot be fitted simultaneously.
6.49
Item 6
Handles
Can be mounted on the 19" brackets.
6.27
EMC shielding
(without
illustration)
Extensive component range for specific shielding of subracks with respect to their application.
6.54
Interior
assemblies
(without
illustration)
Universal assemblies, e.g. for horizontal and vertical assembly and for mounting plates.
6.59
6.29
6.19
Subrack dimensions
Main Catalogue
e1
e1
e2
e1
e1
쮿 Dimensions in accordance with international standards
EC 60297-3-100, IEEE 1101.1/.10/.11; please see the
Schroff Standards Summary for details
쮿 Side panels
– Aluminium, 2 mm
– Round holes for mounting horizontal rails (depth grid
15 mm)
– Impressions on the inner side of the side panel act as an
anti-rotation guard and positioning aid for the horizontal
rails
– Square holes (6 x 6 mm) provide universal fixing for
components such as backplane shielding; version without
square holes available on request
20304051
Depth grid
The depth grid is 15 mm, the mounting holes in the side panel are
decisive for the configurability of individual components; thus any
combination of various individual parts is possible
06197003
Side panel 3 U, 6 U and 9 U
3 and 6 U side panels have the same hole positions (the 6 U is a
doubling vertically of the 3 U); thus subdivisions can be made in
the vertical dimension (6 U: 2 x 3 U; 9 U: 3 x 3 U)
06108008
Side panel 4 U
4 U side panels have the same hole positions as 3 U and
additionally 1 U (above or beneath the 3 U installation);
this height allows the construction of a 3 U unit with 1 U clearance
for cabling or airflow
06108011
6.20
Side panels
쮿 Aluminium
쮿 Round holes for mounting horizontal rails (depth grid 15 mm)
쮿 Impressions on the inner side of the side panel act as an
anti-rotation guard and positioning aid for the horizontal rails
쮿 Square holes (6 x 6 mm) provide universal fixing for
version without square holes available on request
Side panel - horizontal rail assembly
06108062
쮿 Only one type of screw driver is needed for the assembly
(torx panhead screw, M4 x 14; torque side panel - horizontal
rail 2.4 Nm; torque side panel - cover plate 1.3 Nm)
쮿 4 versions of the side panel:
– Type F = flexible
– Type H = heavy
– Type L = light
– Type R = rugged
Note
쮿 Type R - rugged side panels see "Rugged Subracks" section,
page 6.97
Type F (flexible)
쮿 Universal version: 19" bracket (please order separately) can be
fitted variably to front, rear or depth-offset
쮿 Heights: 3, 4, 6 and 9 U
Depths: 175, 235, 275, 277.75, 295, 355, 415 and 475 mm;
Other dimensions on request
쮿 2 EMC shielding concepts for the front/rear:
stainless steel or textile EMC gasket
06197003
Type H (heavy)
쮿 19" bracket is tox-cold welded to side panel; particularly
designed for mechanically demanding environments (vibration
resistance, applications requiring high levels of shock and
vibration, e.g. IEC 61587-2)
쮿 Heights: 3 and 6 U
Depths: 175, 235, 295 and 355 mm
06197004
with stainless steel or textile EMC gasekt
Type L (light)
쮿 Side panel with moulded 19" bracket,
for standard applications, unshielded
쮿 Particularly cost-effective version
(not suitable for EMC applications)
Depths: 175, 235 and 295 mm
06197002
6.21
Side panels type F for stainless steel gasket
Main Catalogue
Order Information
Side panel
type F
19" bracket
without
handle holes
06197003
bza45819
with lateral
without
grooves for
19" bracket,
stainless steel
Al, 2 mm,
EMC gasket,
passivated,
Al extrusion,
please order
rear side etched,
19“ bracket
front anodised
and corner profile
separately
06108070 06108062
Height
Depth
U
mm
1 piece
PU 1 pair
3
175
34560-185
3
235
34560-187
3
275
1)
34579-300
3
277.75
2)
34579-002
24560-197
3
295
34560-189
3
355
34560-191
3
415
34560-193
3
475
34560-195
4
175
3)
34560-285
4
235
3)
34560-287
4
295
3)
34560-289
24560-297
4
355
3)
34560-291
4
415
3)
34560-293
4
475
3)
34560-295
6
175
34560-485
6
235
34560-487
6
275
1)
34579-038
6
277.75
2)
34579-012
6
295
34560-489
24560-497
6
355
34560-491
6
415
34560-493
6
475
34560-495
6
970
34560-496
9
175
34560-785
9
235
34560-787
9
295
34560-789
24560-797
9
355
34560-791
9
415
34560-793
Screw, M4 x 14, PU 100 pieces,
for fastening horizontal rail to
24560-130
24560-130
side panel
Screw, M4 x 10, required if
guide rails are screwed to slot 1,
24560-155
24560-155
PU 100 pieces
1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U
19" bracket
with
handle holes
06106050
19" bracket
depthadjustable
EMC gasket
(stainless
steel)
06102501
BGA45760
Rear angle
Side panel
connection
BZA46573
BPA45867
with lateral
grooves for
stainless steel
EMC gasket,
Al extrusion,
rear side etched,
front anodised
please order
front handles
separately,
see page
6.27
Al extrusion,
passivated
inserted laterally
into the grooves
of the front panel
Al extrusion,
surface clear
passivated;
with lateral
grooves for
stainless steel
EMC gasekt;
rear hood cannot
be mounted
simultaneously
Zn die-cast,
incl. fixing
material kit,
for connecting
two by two
side panels
(on top of each
other)
PU 1 pair
PU 1 pair
PU 10 pieces
PU 1 pair
PU 4 pieces
24560-198
24560-199
21101-705
24561-198
21101-954
24560-298
24560-299
21101-713
24561-298
21101-954
24560-498
24560-499
21101-707
24561-498
21101-954
24560-798
24560-799
21101-709
24561-798
21101-954
24560-130
24560-130
24560-130
24560-155
24560-155
24560-155
쮿 View of side panels 3, 4, 6, 9 U see page 6.20
6.22
Side panels type F for textile EMC gasket
Main Catalogue
Order Information
Side panel
type F
Illustration shows standard
assembly, not VME or
CompactPCI bus with rear I/O
06197003
19" bracket
without
handle holes
bza45819
Al extrusion
without
for textile
19" bracket,
EMC gasket
Al, 2 mm,
rear side etched,
passivated,
front anodised
please order
19“ bracket
and corner profile
separately
19" bracket
depthadjustable
19" bracket
with
handle holes
06106050
EMC gasket
(textile)
06102501
04602054
Rear angle
Side panel
connection
BZA46573
BPA45867
Al extrusion
for textile
EMC gasket,
rear side etched,
front anodised,
please order
front handles
separately,
see page
6.27
Al extrusion,
passivated
textile gasket,
core: foam,
sleeve: textile
cladding with
CuNi coating,
UL 94 V-0
Al extrusion,
etched;
for textile
EMC gasket
Zn die-cast,
incl. fixing
material kit,
for connecting
two by two
side panels
(on top of each
other)
PU 1 pair
PU 1 pair
PU 10 pieces
PU 1 pair
PU 4 pieces
24564-198
24560-199
21101-853
24564-199
21101-954
24564-298
24560-299
21101-858
24564-299
21101-954
24564-498
24560-499
21101-855
24564-499
21101-954
24564-798
24560-799
21101-859
24564-799
21101-954
24560-130
24560-130
24560-130
24560-155
24560-155
24560-155
06108054 06108062
Height
Depth
U
mm
1 piece
PU 1 pair
3
175
34560-185
3
235
34560-187
3
275
1)
34579-300
3
277.75
2)
34579-002
24564-197
3
295
34560-189
3
355
34560-191
3
415
34560-193
3
475
34560-195
4
175
3)
34560-285
4
235
3)
34560-287
4
295
3)
34560-289
24564-297
4
355
3)
34560-291
4
415
3)
34560-293
4
475
3)
34560-295
6
175
34560-485
6
235
34560-487
6
275
1)
34579-038
6
277.75
2)
34579-012
6
295
34560-489
24564-497
6
355
34560-491
6
415
34560-493
6
475
34560-495
6
970
34560-496
9
175
34560-785
9
235
34560-787
9
295
34560-789
24564-797
9
355
34560-791
9
415
34560-793
24560-130
24560-130
side panel
24560-155
24560-155
PU 100 pieces
6.23
Side panels type H for stainless steel EMC gasket
Main Catalogue
Order Information
Side panel type H for stainless steel EMC gasket
without
with
EMC gasket
handle holes
handle holes
(stainless steel)
06197004
for high
mechanical
demands,
19" bracket,
tox-cold welded,
Al, 2 mm,
clear passivated,
front anodised
06108070 06108062
Height
Depth
06107001
for high
mechanical
demands,
19" bracket,
tox-cold welded,
Al, 2 mm,
clear passivated,
front anodised,
please order
front handles
separately
see page
6.27
U
mm
PU 1 pair
PU 1 pair
3
175
24566-125
24567-125
3
235
24566-127
24567-127
3
275
1)
3
277.75
2)
3
295
24566-129
24567-129
3
355
24566-131
24567-131
3
415
3
475
4
175
3)
4
235
3)
4
295
3)
4
355
3)
4
415
3)
4
475
3)
6
175
24566-425
24567-425
6
235
24566-427
24567-427
6
275
1)
6
277.75
2)
6
295
24566-429
24567-429
6
355
24566-431
24567-431
6
415
6
475
6
970
9
175
9
235
9
295
9
355
9
415
24560-130
24560-130
side panel
24560-155
24560-155
PU 100 pieces
6.24
Rear angle
BGA45760
Side panel
connection
BZA46573
BPA45867
inserted laterally
into the grooves
of the front panel
Al extrusion,
surface clear
passivated;
with lateral
grooves for
stainless steel
EMC gasekt;
rear hood cannot
be mounted
simultaneously
Zn die-cast,
incl. fixing
material kit,
for connecting
two by two
side panels
(on top of each
other)
PU 10 pieces
PU 1 pair
PU 4 pieces
21101-705
24561-198
21101-954
21101-707
24561-498
21101-954
24560-130
24560-155
Side panels type H for textile EMC gasket
Main Catalogue
Order Information
Side panel type H for textile EMC gasket
without
with
EMC gasket
handle holes
handle holes
(textile)
06108070 06108062
Height
Depth
06197004
for high
mechanical
demands,
19" bracket,
tox-cold welded,
Al, 2 mm,
clear passivated,
front anodised
06107001
for high
mechanical
demands,
19" bracket,
tox-cold welded,
Al, 2 mm,
clear passivated,
front anodised,
please order
front handles
separately
see page
6.27
U
mm
PU 1 pair
PU 1 pair
3
175
24564-145
24566-145
3
235
24564-147
24566-147
3
275
1)
3
277.75
2)
3
295
24564-149
24566-149
3
355
24564-151
24566-151
3
415
3
475
4
175
3)
4
235
3)
4
295
3)
4
355
3)
4
415
3)
4
475
3)
6
175
24564-445
24566-445
6
235
24564-447
24566-447
6
275
1)
6
277.75
2)
6
295
24564-449
24566-449
6
355
24564-451
24566-451
6
415
6
475
6
970
9
175
9
235
9
295
9
355
9
415
24560-130
24560-130
side panel
24560-155
24560-155
PU 100 pieces
Rear angle
04602054
Side panel
connection
BZA46573
BPA45867
textile gasket,
core: foam,
sleeve: textile
cladding with
CuNi coating,
UL 94 V-0
Al extrusion,
etched;
for textile
EMC gasket
Zn die-cast,
incl. fixing
material kit,
for connecting
two by two
side panels
(on top of each
other)
PU 10 pieces
PU 1 pair
PU 4 pieces
21101-853
24564-199
21101-954
21101-855
24564-499
21101-954
24560-130
24560-155
6.25
Side panels type L
Main Catalogue
Order Information
Side panel
type L
06197002
Al, 2 mm,
passivated
Front cover
Collar screw
with slot
for assembly
of front cover
BZA45810
for decorative
finish
of 19" bracket,
Al, 2 mm,
anodised
Sleeves
for assembly
of front cover
06708055
Side panel
connection
00508056
BPA45867
M6 x 16, St,
nickel-plated
PPE, black
Zn die-cast,
incl. fixing
material kit,
for connecting
two by two
side panels
(on top of each
other)
PU 100 pieces
PU 100 pieces
PU 4 pieces
21100-565
21100-566
21101-954
21100-565
21100-566
21101-954
06108062
Height
Depth
U
mm
1 piece
3
175
34561-185
3
235
34561-187
3
275
1)
3
277.75
2)
34561-197
3
295
34561-189
3
355
3
415
3
475
4
175
3)
4
235
3)
4
295
3)
4
355
3)
4
415
3)
4
475
3)
6
175
34561-485
6
235
34561-487
6
275
1)
6
277.75
2)
6
295
34561-489
34561-497
6
355
6
415
6
475
6
970
9
175
9
235
9
295
9
355
9
415
24560-130
side panel
24560-155
PU 100 pieces
6.26
Front handles, wall-mounting brackets
Main Catalogue
Order Information
Wall-mounting bracket
E
HE
12
H
H
E
12
,2
Universal front handle
HE
Front handle
clear anodised
black anodised
40
AI extrusion, anodised
load-carrying capacity 30 kg
06102068
40
06102069
3 parts: Al extrusion,
clear anodised,
2 end pieces, plastic, PA, black;
width 12 mm, depth 40 mm
load-carrying capacity 10 kg
06104063
Al, 2.5 mm, passivated;
bolted to subrack in place of
the 19" bracket
Height Depth
H
E
U
mm
mm
mm
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
3
175
102
88.0
3
235
102
88.0
3
275
102
88.0
3
277.75 102
88.0
10501-005
10501-026
10502-057
3
295
102
88.0
3
355
102
88.0
3
415
102
88.0
3
475
102
88.0
4
175
146
133.4
4
235
146
133.4
4
295
146
133.4
10501-018
10502-060
4
355
146
133.4
4
415
146
133.4
4
475
146
133.4
6
175
249
235.0
6
235
249
235.0
6
275
249
235.0
6
277.75 249
235.0
6
295
249
235.0
10501-008
10501-029
10502-065
6
355
249
235.0
6
415
249
235.0
6
475
249
235.0
6
970
249
235.0
9
175
249
235.0
9
235
249
235.0
9
295
249
235.0
10501-008
10501-029
10502-065
9
355
249
235.0
9
415
249
235.0
Screw M5 x 12, PU 100 pieces
24560-183
24560-183
24560-183
Screw M5 x 12, PU 4 pieces
24560-182
24560-182
24560-182
1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ);
PU 1 pair
24562-197
24562-297
24562-497
24562-797
24560-130
6.27
Horizontal rails
쮿 Aluminium profile, surface anodised, conductive contact
surfaces for EMC gaskets
쮿 The horizontal rail is marked with sequential numbering
(for sizes > 28 HP) to facilitate positioning of the guide rails
light
06197007
heavy
06197008
06112004
rugged
쮿 Horizontal rails are fixed to the side panel using M4 bolts with
torx 20 drive
쮿 There are 3 different horizontal rails for different loading levels
– light, for up to 7.5 kg
– heavy, for 7.5 kg to 15 kg
– rugged, for 15 kg to approx. 60 kg
Mounting position of the horizontal rails
PCB as deep as side panel
front
Cabling space behind backplane
rear
front
Rear I/O installation
(CompactPCI, VME64x applications)
front
rear
rear
H-KD
3U
L-KD
H-KD
L-KD
H-KD
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-KD
H-KD
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
H-KD
AB
H-ST / H-VT
H-LD
D2
D = D1
H-LD
D1
D1
D
D
160, 220, 280 mm, ....
06112081
06112083
160 mm/80 mm
06112085
L-KD
H-KD
L-KD
H-KD
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
ST / VT / MZ
ST / VT / MZ
6U=3U+3U
D3
D2
D2
L-KD
H-KD
L-KD
L-OD
L-KD
L-OD
AB
AB
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-KD
H-KD
L-KD
H-KD
D2
D2
D1
D = D1
D
06112088
06112087
H-LD
6U
L-KD
H-KD
H-ST / H-VT
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
ST / VT / MZ
L-KD
H-KD
ST / VT / MZ
AB
L-KD
H-KD
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
L-ST / L-VT / L-MZ
H-ST / H-VT / H-MZ
H-LD
H-ST / H-VT
H-LD
H-LD
D2
D1
D1
D = D1
D
D
6.28
06112082
D3
D2
D2
06112084
160 mm/80 mm
06112086
Front horizontal rails
Assembly 3 U, 2 x 3 U, 6 U
"light" (L)
3 U/6 U
Short lip
"heavy" (H)
"heavy" (H)
06197007
06197008
Short lip
06197009
Long lip
10
H - LD
3
3
12,75
15
3
12,75 15
12,75
15
3 HE/U
3/6 HE/U
6U
3/6 HE/U
6 HE/U
H - KD
H - KD
L - KD
3
12,75
bza44980 bza44974
H - LD
H - KD
L - KD
06105060
06105061
06108063
2x3U
L - KD
12,75
3
H - KD
12,75 15
3
12,75 15
L - KD
H - KD
H - LD
L - KD
H - KD
H - KD
3U
3U
3
H - KD
10
L - KD
bza44972
H - KD
06105062
H - LD
06105063
06108064
2 x 3 U, 6 U
L - KD
3
12,75
H - KD
3
10
12,75 15
H - LD
3
6U
L - OD
06105059
L - OD
L - OD
L - OD
L - KD
H - KD
06105064
12,75
15
L - OD
L - OD
H - LD
06105065
06108065
L-OD = Light - without lip, L-KD = Light - short lip, H-KD = Heavy - short lip, H-LD = Heavy - long lip
6.29
Main Catalogue
Order Information
"light"
Type L-OD
without lip
bza44980
With HP markings from 28 HP,
Al extrusion, anodised finish,
conductive contact surface
"light"
Type L-KD
short lip
06197006
With long lip for insertion/
extraction of CompactPCI
and VME64x boards
"heavy"
Type H-LD
long lip
"heavy"
Type H-KD
short lip
06197007
06197008
06197009
conductive contact surface,
with printed HP markings
without lip:
2 x 3 U installation and
continuous 6 U front panel
short lip:
horizontal rail and front panel
form a single plane
short lip:
form a single plane
long lip:
for insertion/extraction of
CompactPCI or VME64x boards
Usable length
HP
Length
mm
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
40
42
63
84
106.68
147.32
208.28
218.44
325.12
431.80
1000
34560-020
34560-120
34560-220
34560-320
34560-028
34560-128
34560-228
34560-328
34560-040
34560-042
34560-140
34560-142
34560-240
34560-242
34560-340
34560-342
34560-063
34560-163
34560-263
34560-363
34560-084
34560-001
34560-184
34560-101
34560-284
34560-201
34560-384
34560-301
24560-130
24560-130
24560-130
24560-130
24560-155
24560-155
6.35
6.35
6.35
6.35
PU 100 pieces
Threaded inserts see page
"light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg
Note
쮿 1000 mm version without M4 thread to front,
without printed markings and without notch for 19"-bracket
쮿 Rugged horizontal rails with 3 fixing holes
see section "Rugged Subracks", page 6.99
6.30
Indirect backplane mounting
(with insulation strip)
Direct backplane mounting
Connector fitting with Z
Text
04400001
12,75
3
12,75
L - ST
9,75
04400002
04400003
3
12,75
L - VT
L - MZ
VT
MZ
3
"light"
ST
L - ST
L - VT
L - MZ
06105072
15
12,75
3
15
H - ST
9,75
06105073
12,75
06105071
3
15
H - VT
H - MZ
VT
MZ
12,75
3
"heavy"
ST
H - ST
ST = standard, L = light, H = heavy
H - VT
06108066
H - MZ
VT = depth-offset, L = light, H = heavy
06108067
MZ = with Z-rail, L = light, H = heavy
06108068
6.31
Rear horizontal rails, top and bottom
Main Catalogue
Order Information
For indirect backplane mounting
For direct backplane mounting
04400001
"light"
Type L-ST
standard
06105074
With HP markings from 28 HP, Al
conductive surface
06197010
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
"heavy"
Type H-ST
standard
04400002
"light"
Type L-VT
+ 3 mm
06197011
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
For direct fixing of connectors in
accordance with
EN 60603-2 (DIN 41612)
06197011
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
"heavy"
Type H-VT
+ 3 mm
06197009
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
04400003
"light"
Type L-MZ
with Z-rail
06197014
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
"heavy"
Type H-MZ
with Z-rail
06197015
Al extrusion,
anodised surface,
conductive contact
surface,
with printed HP
markings
Usable length
Length
1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1)
HP
mm
34560-420
34560-520
34560-620
34560-720
34560-820
34560-920
28
147.32
34560-428
34560-528
34560-628
34560-728
34560-828
34560-928
40
208.28
34560-440
34560-540
34560-640
34560-740
34560-840
34560-940
42
218.44
34560-442
34560-542
34560-642
34560-742
34560-842
34560-942
63
325.12
34560-463
34560-563
34560-663
34560-763
34560-863
34560-963
84
431.80
34560-484
34560-584
34560-684
34560-784
34560-884
34560-984
1000
34560-401
34560-501
34560-601
34560-701
34560-801
24560-130
24560-130
24560-130
24560-130
24560-130
24560-130
side panel
24560-155
24560-155
24560-155
PU 100 pieces
Perforated rail for connector
6.36
6.36
see page
Z-rail for connector mounting
6.36
6.36
without insulation strip see page
Insulation strips see page
6.35
6.35
6.35
6.35
6.35
6.35
6.35
6.35
Note
6.32
Rear horizontal rails, centre, for 6 U
Main Catalogue
Order Information
04400001
04400002
Typ ST
06108090
Usable length
Length
HP
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
side panel
in accordance with
Typ VT
06197016
04400003
Typ MZ
06197017
06197018
Al extrusion, anodised surface,
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34561-020
34561-028
34561-120
34561-128
34561-220
34561-228
34561-040
34561-140
34561-240
34561-042
34561-063
34561-142
34561-163
34561-242
34561-263
34561-084
34561-184
34561-284
34561-001
34561-101
34561-201
24560-130
24560-130
24560-130
6.35
6.35
6.35
6.35
Note
쮿 All horizontal rails without printed markings
6.33
Horizontal rails (type AB) for rear I/O applications
Main Catalogue
Order Information
For CompactPCI in rear I/O area
12,75
AB
H - ST
9,75
15 12,75
H - KD
3
06108009
Typ AB
H - ST
AB
H - KD
06108069
06197019
conductive contact surface;
horizontal rail type AB (AB = support)
is required to fix the 80 mm rear I/O boards;
Usable length
Length
HP
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
for fastening horizontal rail to side panel
1 piece (SPQ 10)1)
34561-520
34561-528
34561-540
34561-542
34561-563
34561-584
34561-501
24560-130
Note
6.34
Threaded inserts, perforated strips, insulation strips
Main Catalogue
Order Information
Threaded insert
M2.5
M3
Perforated strip
(item 1)
Insulation strip
5
2
5 ,0
8
06103056
required for fixing the front panel to the horizontal rail;
St, zinc-plated; use collar screw 12.3 mm, see page
6.66
Usable length
HP
Threaded insert
Length
mm
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
BZA45853
for centring shielded plug-in units,
Al, 1 mm, please order grub screw
separately
Perforated strip
Length
mm
1 piece
(SPQ 10)1)
BZ6749
for insulated backplane mounting;
PBT UL 94 V-0, grey
Insulation strip
Length
mm
34561-320
106.48
30845-189
101.50
28
146.82
147.12
144.20
34561-328
30845-197
40
207.78
208.08
205.12
34561-340
30845-209
42
217.94
34561-342
218.24
30845-211
210.40
63
324.62
324.92
316.88
34561-363
30845-232
84
431.30
431.60
428.64
34561-384
34561-484
30845-253
196
1000.26
34565-196
1000.56
34565-396
Accessories
Grub screw M2.5 x 8,
21100-276
PU 100 pieces
Grub screw M2.5 x 9,
21101-359
PU 100 pieces
Grub screw M3 x 8,
21100-646
PU 100 pieces
2) Part no. includes one packing unit (PU); delivery is exclusively made in PU
PU 10 pieces
24560-820
24560-828
24560-840
24560-842
24560-863
24560-884
6.35
Z-rails, perforated rails
Main Catalogue
Order Information
Z-rail for connectors
DIN EN 60603-2, DIN 41612
31-pin, DIN 41617
item 1
Perforated rail
EN 606032, DIN 41612
item 1
172,5
175,5
172,5
BZA45849
75
12,
5
9 ,7
BZA45850
BZA45848
5
7
12,
3 ,0
2
2
1
1
3
3
06708063
Usable length
Length
HP
mm
28
142.24
40
203.20
42
213.36
60
304.80
84
426.72
Item 3, torx panhead screw
to fix connector to perforated rail,, M2.5 × 7,
PU 100 pieces
Item 2, torx panhead screw,
to fix perforated rails to horizontal rail, M2.5 × 10,
PU 100 pieces
6.36
06708051
for connector mounting on ST
horizontal rails,
please order threaded inserts
and screw separately
horizontal rails,
for connector mounting on VT
horizontal rails,
1 piece
1 piece
PU 4 pieces
30822-025
30822-033
30822-045
20822-051
30819-763
20822-049
20822-046
30822-047
20822-050
30822-065
30822-089
30819-783
30819-808
20822-047
20822-048
24560-147
24560-147
24560-147
24560-148
24560-148
24560-148
Guide rails
Main Catalogue
and the sub-assemblies (PCBs, plug-in units, frame-type plug-in
units, ...).
3,55
0,3
DIN 41612
Guide rails for standard applications are 2 HP wide. Guide rails
with coding (e.g. for CompactPCI or VME64bus applications)
are 4 HP wide.
There are groove widths of 2 mm and 2.5 mm.
The guide rails are clipped into the rectangular cut-outs of the
horizontal rails. They can additionally be bolted to the horizontal
rail (type H only) for higher shock and vibration requirements.
4,07
The printed HP markings on the horizontal rail (28 HP and above)
allow the rails to be fitted in the correct position easily (position of
sub-assembly = "number in viewing window" or in front of the
arrow
marking on the guide rails).
5,08
3,55
2,54
Front view: position of guide rails to connector (EN 60603-2/
DIN 41612)
06108083
Applications for guide rails
For plug-in units and frame-type plug-in units (with front panels)
(standard type)
06102001
For plug-in units and frame type plug-in units or
for PCBs without their own front panel
(accessory type or robust version)
06102002
06102005
For CompactPCI or VME64x plug-in units
(type IEEE with coding; frame-type plug-in units cannot be fitted)
06106001
For plug-in drive unit modules or PCBs in 4.4" (111.7 mm) height
(type 4.4")
06104009
Rugged guide rails to accommodate conduction cooled assembly (CCA)
adaptor
06112022
Accessories:
- ESD clip
- Keying/coding pegs
- Board locking
6.37
Guide rails for plug-in units and modules, one-piece,
groove width 2 mm and 2.5 mm
Main Catalogue
Order Information
standard type
Assembly
- can be clipped into Al extruded
horizontal rails
- can be clipped into 1.5 mm thick
plates
standard type,
with DIN connector fixing
Storage temperature
from -40 °C ... 130 °C
06102001
06101501
up to 220 mm length, PBT, UL 94 V-0;
from 280 mm length, multi-piece, end
piece PBT, UL 94 V-0,
central section Al extrusion
PBT, UL 94 V-0
PBT, UL 94 V-0, red,
connector is clipped directly
onto the guide rails;
for euroboards only,
100 x 160 mm or 100 x 220 mm
PU 10 pieces2)
1 piece (SPQ 50)1)
34579-230
34579-231
1 pair (SPQ 10)1)
24560-351
64560-001
64560-074
24560-353
24560-379
64560-002
64560-075
24560-380
64560-096
64560-098
Retention screw, PU 100
pieces; Torque max. 0.2
Nm
24560-141
24560-141
ESD clip, PU 50 pieces
24560-255
Board length Groove
width
mm
mm
70
2
70
2
160
2
220
2
280
2
340
2
160
2.5
220
2.5
Colour
mm
red
grey
red
red
red
red
red
red
Accessories
24560-255
Description of accessories see from page 6.43
6.38
Guide rails type "accessory", one-piece,
Main Catalogue
Order Information
Assembly
horizontal rails
plates
Guide rails
"Accessories"
with DIN connector
mounting
accessory type
accessory type,
strengthened
for heavy modules,
Al extrusion, silver,
robust version
Storage temperature
from -40 °C ... +130 °C
06102002
up to 280 mm length, PBT, UL 94 V-0;
end piece PBT, UL 94 V-0,
middle section Al extrusion
Board
length
mm
100
160
160
220
220
280
340
400
160
220
280
340
400
Groove
width
mm
2
2
2
2
2
2
2
2
2.5
2.5
2.5
2.5
2.5
Colour
red
red
grey/silver
red
grey/silver
red/silver
red/silver
red/silver
silver
silver
silver
silver
silver
06102005
06102005
06102005
PBT, UL 94 V-0,
connector is bolted
directly onto the guide
rails, only suitable for
euroboards
100 x 160 mm or
100 x 220 mm
PBT UL 94 V-0, red;
support beam of guide
rails
adds to strengthening
Al extrusion;
is screwed to
horizontal rail "heavy"
with retention screws
PU 10 pieces2)
1 piece (SPQ 50)
64560-082
PU 10 pairs2)
1 piece (SPQ 50)
24560-373
24560-274
24560-276
64560-076
64560-005
64560-055
1 piece (SPQ 10)1)
34562-881
24560-374
64560-006
24560-275
64560-078
64560-166
24560-277
24560-375
64560-080
34562-884
34562-882
34562-883
24560-141
24560-141
24560-141
24560-141
24560-157
24560-255
24560-255
24560-255
24560-255
24560-377
24560-377
24560-377
24560-377
24560-378
24560-378
24560-378
24560-378
60817-228
60817-228
60817-228
60817-228
24560-376
34562-885
34564-881
34564-882
34564-883
34564-884
34564-885
Accessories
Retention screw,
PU 100 pieces;
torque max. 0.2 Nm
Board locking C, red,
PU 10 pieces
Board handle C, red,
PU 10 pieces
Identification strips for
board handle, red,
PU 1 sheet = 438 pieces
Coding see page
6.43
6.39
Guide rails for CompactPCI, VME64x with coding,
4.4" PCBs, groove width 2 mm and 2.5 mm
Main Catalogue
Order Information
Assembly
horizontal rails
- can be clipped into1.5 mm thick
plates
For CompactPCI, VME64x with coding
In accordance with IEEE 1101.10
Offset 0.1" for power supply units
and IEC 60297-3-103
in accordance with IEEE 1101.10
and IEC 60297-3-103
For 4.4" PCBs
Storage temperature
06106001
Board
length
mm
70
70
160
160
160
220
220
220
160
220
220
280
280
340
340
Groove
width
mm
2
2
2
2
2
2
2
2
2.5
2.5
2.5
2.5
2.5
2.5
2.5
Colour
mm
red
grey
red
grey
green
red
grey
green
red
red
grey
red
grey
red
grey
04611009
06106002
One-piece, PBT, UL 94 V-0;
for 4.4" PCBs or drive unit modules
One-piece for groove
width 2 mm, PBT,
UL 94 V-0;
multi-piece at groove
width 2,5 mm,
end-piece PBT,
UL 94 V-0,
center piece Al
PBT, UL 94 V-0
PU 10 pieces
1 piece (SPQ 50)1)
PU 10 pieces
1 piece (SPQ 50)1)
PU 10 pieces
1 piece (SPQ 50)1)
24560-355
64560-085
24560-360
24560-356
64560-086
64560-089
24560-361
64560-143
64560-090
24560-358
24560-359
64560-071
64560-091
24560-362
64560-144
24561-332
24561-342
24560-255
24560-255
24560-256
24560-256
24560-256
24560-256
24560-141
24560-141
24560-141
24560-141
24560-158
24560-158
20817-501
20817-501
20817-501
20817-501
24561-330
24561-340
24561-331
24561-341
64560-092
PBT, UL 94 V-0,
for installation of power supplies in
CompactPCI systems or
plug-in units with SMD placement
06104009
64560-072
64560-145
64560-146
Accessories
ESD clips, for alignment pin,
PU 50 pieces
Retention screw, PU 100 pieces;
torque max. 0.2 Nm
Coding peg, PU 100 pieces
6.40
SCHROFF PRODUCT CATALOG E 08/2017
Guide rails, multi-piece, groove width 2 mm
Main Catalogue
Order Information
PCBs:
Fixed lengths for 160, 220, 280, 340 mm;
length 1000 mm for special dimensions
For plug-in units and modules
standard type
Accessories type
For 4.4" PCBs
Mounting: pluggable into horizontal rails
Storage temperature :
End piece -40°C ... +130°C
PVC profile 0°C ... +60°C
06106004
Description
End piece, red, 1 pair
Al extrusion, for
160 mm board length
Al extrusion, for
220 mm board length
Al extrusion, for
280 mm board length
Al extrusion, for
340 mm board length
Al extrusion,
for any board length
Plastic extrusion,
06106005
06106006
end piece, PBT,
UL 94 V-0,
middle section
Al extrusion
end piece, PBT,
UL 94 V-0,
middle section
plastic extrusion
(PVC, RAL 7035)
end piece, PBT,
UL 94 V-0,
middle section
Al extrusion
end piece, PBT,
UL 94 V-0,
middle section
plastic extrusion
(PVC, RAL 7035)
end piece, PBT,
UL 94 V-0,
middle section
Al extrusion
end piece, PBT,
UL 94 V-0,
middle section
plastic extrusion
(PVC, RAL 7035)
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
1 piece
(SPQ 10)1)
2
64560-004
64560-004
64560-008
64560-008
64560-057
64560-057
95
2
34560-891
34564-891
34560-891
34564-891
34560-891
34564-891
155
2
34560-892
34564-892
34560-892
34564-892
34560-892
34564-892
215
2
34560-893
34564-893
34560-893
34564-893
34560-893
34564-893
275
2
34560-894
34560-894
34560-894
1000
2
34560-900
34560-900
34560-900
1000
2
34564-900
34564-900
34564-900
24560-255
24560-255
24560-255
24560-255
24560-141
24560-141
24560-141
24560-141
24560-158
24560-158
24560-377
24560-377
24560-378
24560-378
60817-228
60817-228
Length Groove
width
mm
mm
Accessories
torque max. 0.2 Nm
Board locking C, red, PU 10 pieces
Board handle C, red, PU 10 pieces
Identification strips for board handle,
red,
Coding see page
see page 6.43
please order at least the SPQ quantity or a multiple
Note
쮿 Strengthening for middle section (plastic extrusion)
6.41
Dimension drawings of guide rails
Standard
Robust version
D2
D2
A4
C
6,7
8,7
C
B
B
D
D
bza45808
For accessories
A1
C
C
6,55
A1
B
B
D
D
bza45808
CompactPCI, VME64x
bza46552
4.4" (111.7 mm)
D2
A3
C
C
0,8
A2
2,85
6,55
D2
8,55
19,95
D2
8,55
6,55
8,55
D2
B
B
D
D
06105068
Dimensions table
Board length
L
mm
70
100
160
220
280
340
400
06105074
For accessories, strengthened
7,9
6,55
8,55
A
06105069
Text
A
mm
71.5
101.5
161.5
221.5
281.5
341.5
401.5
A1
mm
47.9
77.9
137.9
197.9
257.9
317.9
377.9
A2
mm
59.39
89.39
149.39
209.39
269.39
322.39
389.39
A3
mm
63
93
153
213
273
333
393
Dimensions
A4
mm
49
79
139
199
259
319
379
B
mm
45
75
135
195
255
315
375
C
mm
30
60
120
180
240
300
360
D
mm
60
90
150
210
270
330
390
A, A1, A2, A3, A4: Length of rail
B: Pitch of snap-in fixing
C: Pitch of guide rail retention screws
D: Pitch of horizontal rail retention screws
6.42
Guide rail accessories
Main Catalogue
Order Information
ESD clips, CompactPCI/VME 64
alignment pin for guide rails
Coding for subracks
Keying/coding block for
Keying/coding
guide rails accessory type
for CompactPCI, VME64x handles
to IEEE 1011.10 and
IEC 60297-3-103
06103052
06103051
PBT, UL 94 V-0,
Spring steel, tin-plated, ESD clip,
keying/coding block is clipped into the
for alignment pin in accordance with IEEE;
horizontal rail next to the guide rail;
can be plugged into the guide rails with
coding and into the keying/coding block; please order keying/coding pegs separately
provides conductive contact between the
alignment pin of the insertion/extractor
handle (IEL or IET handle)
and the horizontal rail
Assembly
above
below
04612052
Keying/coding peg, PBTP, UL 94 V-0,
RAL 7035
The keying/coding pegs prevent plug-in
units to be mounted in wrong slots.
They are inserted in the chambers of the
codable card guides as well as in the
insertion/extractor handles IEL or IET
(4 possible positions),
resulting in 64 codings per card guide;
when coding the upper and lower card
guide, 4096 codings will result;
Colour
red
grey
silver
red
grey
silver
PU 50 pieces
1 piece (SPQ 50)
34579-232
PU 100 pieces
34579-233
20817-501
24560-256
34579-234
34579-235
20817-501
24560-256
Main Catalogue
Order Information
Board locking C for PCBs
without front panel;
for accessory type
guide rails
04503050
between board and
horizontal rail,
on both the solder side and the
component side
Assembly
mm
above/below
Colour
PCB handle C
for board locking;
for accessory type
guide rails
04805050
to fix the PCB in the subrack
(also slot 1),
can also be used without
board handle,
minimum distance 3 HP
04805051
06108076
Polyester film, 31 x 4 mm,
self-adhesive, white/matt
insertion/extraction function
with connection to board locking (1 A4 sheet contains 438 pieces)
(also slot 1), mounting directly
behind front panel (above and
below), minimum distance 3 HP
silver
red
red
PU 50 pieces
PU 10 pieces
PU 10 pieces
white/matt
1 piece
24560-255
24560-377
24560-378
60817-228
Part number in bold face type: ready for despatch within 2 working days
6.43
Shielding for top and bottom
Main Catalogue
Cover plates can be used for electromagnetic shielding
(with EMC contact springs) or as mechanical protection
(without EMC springs)
Cover plates for mechanical protection
쮿 Cover plates are inserted into the grooves of the front and rear
horizontal rails, type L "light"
see page 6.45
06108077
Cover plates with EMC shielding and mechanical protection
EMC cover plates for top and bottom
쮿 Inserted in the groove of the front and rear horizontal rails;
shielding with contact springs, lateral contact by bolting the
bracket to the side panel
쮿 Used when standard-depth PCBs (160, 220, 280, ...) are fitted
see page 6.46
06102084
Universal EMC cover plates for top and bottom
shielding with contact springs, lateral contact by bolting to the
side panel with special contact springs
쮿 Used when PCBs with special dimensions are fitted
see page 6.47
06105082
6.44
ELECTRONICS PROTECTION
(insertion into horizontal rail type L
Order Information
Cover plates
for insertion into
1
06108058
Perforated Al plate, 1.2 mm,
hole diameter 3.8 mm,
AI, untreated,
perforation degree 60 %;
for insertion into the groove of the
light horizontal rails (type L)
06197010
Width
HP
42
63
84
84
Depth
mm
175
175
175
235
Application
PU 1 pair
160 mm board depth
160 mm board depth
160 mm board depth
220 mm board depth
24561-031
24561-041
24561-051
24561-052
Note
쮿 Other dimensions on request
6.45
EMC cover plates and mechanical protection
쮿 Cover plate for bolting to side panel
Order Information
Cover plate
Stainless steel EMC gasket, between cover
plate and horizontal rail
d = D - 25
3 HE / U
160 / 220 / 280
D
06102082
AI, 1.0 mm, hole diameter 4.0 mm,
passivated, perforation degree 58 %,
incl. fixing screws;
for shielding 4 stainless steel EMC gaskets
are required per subrack
06106052
stainless steel EMC gasket,
clips into the horizontal rail and
forms the contact with the cover plate;
suitable for all horizontal rails
06197010
Width
HP
42
42
42
42
42
63
63
63
63
84
84
84
84
84
84
84
84
Depth
mm
175
235
275
277.75
295
175
235
275
295
175
235
275
277.75
295
355
415
475
Application
PU 1 pair
160 mm board depth
160, 220 mm board depth
160, 220 mm board depth CompactPCI (275 mm)
160, 220 mm board depth VME64x (277.75 mm)
160, 220, 280 mm board depth
160 mm board depth
160 mm board depth
PU 10 pieces
PU 100 pieces
24560-241
24560-243
24560-245
24560-246
24560-064
24560-065
24560-061
24579-090
24560-066
24560-071
24560-072
24560-062
24560-073
24560-078
24560-079
24560-063
24579-092
24560-080
24560-081
24560-082
24560-083
Assembly tool, for EMC gasket,
stainless steel (horizontal rails), 1 piece
24560-271
Note
쮿 Cover plates without perforation available on request
6.46
Universal EMC cover plates and mechanical protection
Order Information
Universal cover plate
d = D - 25
3 HE / U
160 / 220 / 280
D
incl. lateral EMC sealing,
incl. fixing screws
06108079
06106052
06105082
Width
HP
42
42
42
63
63
63
84
84
84
84
84
84
Depth
mm
175
235
295
175
235
295
175
235
295
355
415
475
Application
PU 1 pair
160 mm board depth
160 mm board depth
160 mm board depth
PU 10 pieces
PU 100 pieces
24560-241
24560-243
24560-245
24560-246
24560-031
24560-032
24560-033
24560-041
24560-042
24560-043
24560-051
24560-052
24560-053
24560-054
24560-055
24560-056
24560-271
6.47
Cover/shielding to front and rear
쮿 The front and rear sides of the subrack can be shielded by a
hinged front panel or by a fixed front panel and 19" brackets
쮿 The rear can be shielded with a front panel and a corner profile
Rear hood
BZA45814
Front panel for front and rear
06112089
Front panel, hinged/pivoted
135°
06112090
6.48
Rear hood for 3 U and 6 U subracks
(for stainless steel EMC gasket)
Order Information
Rear hood
bza45819
Al, 1 mm, clear passivated;
60 mm additional side panel depth
required (board depth + 60 mm);
for shielding please order EMC gasket
for horizontal rail separately;
cannot be used simultaneously with
rear corner profile
06106052
bza45814
Height
U
3
3
6
6
Torx panhead screw, M4 × 6,
St, zinc-plated, PU 100 pieces
Width
HP
42
84
63
84
1 piece
PU 10 pieces
34561-750
34561-752
24560-241
24560-245
PU 100 pieces
34561-763
24560-243
34561-764
24560-245
24560-246
24560-246
24560-135
24560-271
Note
쮿 Other dimensions of rear hood available on request
6.49
Front/rear panels, unshielded
FRONT PANEL
EXPRESS
Order Information
Front panel
pre-anodised,
cut edges plain
anodised
Front anodised,
rear iridescent green
chromated
Al, 2.5 mm
Al, 2.5 mm
Al, 2.5 mm
04292001
Height
U
Height
mm
Width
HP
1
1
1
1
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
4
4
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
9
9
9
9
9
44.45
44.45
44.45
44.45
84.0
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
172.9
172.9
172.9
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
395.1
395.1
395.1
395.1
395.1
28
42
63
84
84
2
3
4
5
6
7
8
10
12
14
21
28
42
63
84
42
63
84
2
4
5
6
7
8
10
12
14
16
21
28
42
63
84
4
8
10
12
84
1 piece
30818-271
1 piece
(SPQ 5)1)
30810-433
30818-272
30818-310
30818-331
1 piece
30807-416
1 piece
(SPQ 5)1)
30810-432
30807-508
30807-494
30808-067
30818-747
30818-518
30818-556
30818-577
30818-352
30818-434
30818-598
1 piece
20850-423
20850-424
20850-425
20850-426
30847-461
1 piece
(SPQ 5)1)
30847-470
30847-471
30838-081
30838-102
30818-741
30847-472
30838-124
30807-764
30807-771
30838-162
30838-183
30818-273
30818-274
30818-275
30818-276
30818-277
30818-279
30818-281
30818-282
30818-289
30818-296
30807-506
30807-596
30818-522
30818-524
30818-526
30818-528
30818-530
30818-535
30818-542
30807-776
30807-481
30807-510
30807-482
30807-509
30807-484
30807-483
30807-485
30807-501
30807-487
30807-496
30807-753
30807-758
30807-757
30807-766
30838-123
30847-463
30847-464
30847-465
30838-204
30838-043
30838-044
30838-045
30838-046
30838-047
30838-049
30838-051
30838-053
30838-060
30838-067
30838-125
30838-126
30838-127
30838-128
30838-130
30838-132
30838-134
30838-136
30838-141
30838-148
30847-476
30847-480
30847-556
30847-482
30847-484
쮿Front panel assembly kits, sleeves, collar screws, quick-release fasteners see page 6.65
6.50
Front/rear panels shieldable with stainless steel EMC gasket
FRONT PANEL
EXPRESS
Order Information
Front panel
Front panel
for shielding with EMC gasket (stainless steel)
Al, 2.5 mm, front anodized, rear iridescent green
inserted laterally into the grooves of the front panel,
chromated, 2 alignment pins pressed-in, St, stainless
suited for temperatures above 70 °C
04292001
Height
Height
Width
U
mm
HP
2
84
84
3
128.4
2
3
128.4
3
3
128.4
4
3
128.4
5
3
128.4
6
3
128.4
7
3
128.4
8
3
128.4
10
3
128.4
12
3
128.4
14
3
128.4
21
3
128.4
28
3
128.4
42
3
128.4
63
3
128.4
84
4
172.9
42
4
172.9
63
4
172.9
84
6
261.8
2
6
261.8
4
6
261.8
5
6
261.8
6
6
261.8
7
6
261.8
8
6
261.8
10
6
261.8
12
6
261.8
14
6
261.8
16
6
261.8
21
6
261.8
28
6
261.8
42
6
261.8
63
6
261.8
84
9
395.1
84
Assembly tool, for stainless steel EMC gasket
1 piece
30846-588
1 piece (SPQ 5)1)
30846-864
20846-437
20846-438
30846-676
30846-681
30846-682
30846-683
21101-776
21101-705
21101-706
21101-713
21101-714
21101-707
21101-708
20846-426
20846-427
20846-428
20846-429
20846-430
20846-431
20846-432
20846-433
20846-434
20846-436
30846-865
20846-453
30846-771
30846-859
PU 100 pieces
21101-775
20846-425
20846-454
PU 10 pieces
20846-443
20846-444
20846-445
20846-446
20846-447
20846-448
20846-449
20846-450
20846-456
20846-451
20846-452
21101-709
21101-710
24560-270
6.51
Front/rear panels shieldable with textile EMC gasket
FRONT PANEL
EXPRESS
Order Information
Front panel
Front panel
for shielding with EMC sealing (textile)
Textile EMC gasket
Al extrusion, 2.5 mm, front anodised,rear
conductive; 3, 6 U with alignment pin (not 84 HP)
textile gasket, core: foam,
sleeve: textile cladding with CuNi coating,
UL 94 V-0
04292001
Height
U
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
4
4
4
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
9
Height
mm
84
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
172.9
172.9
172.9
172.9
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
395.1
Width
HP
84
2
3
4
5
6
7
8
10
12
14
21
28
42
63
84
28
42
63
84
2
4
5
6
7
8
10
12
14
16
21
28
42
63
84
84
1 piece
1 piece (SPQ 5)1)
20848-262
30849-001
30849-004
30848-354
30848-378
30848-380
30848-382
30848-356
30848-386
30848-358
20848-013
20848-020
20848-047
20848-027
20848-068
20848-097
20848-268
20848-269
20848-270
20848-271
30849-002
30848-355
30848-379
30848-381
30848-383
30848-357
30848-387
30848-359
20848-106
20848-108
20848-113
20848-120
20848-139
20848-160
20848-189
20848-280
PU 10 pieces
PU 100 pieces
21101-853
21101-854
21101-858
21101-855
21101-856
21101-859
21101-904
21101-856
6.52
Front panels, hinged and pivoted
Main Catalogue
Order Information
Front panel, bottom-hinged
shielded
unshielded
Front panel, pivoted
04295001
Height
Width
U
3
3
3
3
4
4
4
6
6
6
6
HP
28
42
63
84
42
63
84
28
42
63
84
Al, 2.5 mm,
Al, 2.5 mm,
anodised, cut edges plain;
front anodised,
hinge, Zn die-cast,
nickel-plated;
chromated;
2 x sleeve, PA;
hinge, Zn die-cast,
2 knurled screws
nickel-plated;
M2.5 x 12.3, St,
2 x sleeve, PA; 2 x knurled
nickel-plated
screws
M2.5 x 12.3,
St, nickel-plated;
1 x textile EMC gasket
04295002
Al, 2.5 mm,
front anodised, rear iridescent green chromated;
hinge, die-cast zinc, chrome-plated;
textile EMC gasket
1 piece
1 piece
1 piece
20848-608
20848-599
20838-280
20838-271
20848-600
20838-272
20848-601
20848-605
20838-273
20838-277
20848-611
20848-606
20838-278
20848-607
20848-696
20838-279
20848-602
20838-274
20848-603
20848-604
20838-275
20838-276
20848-617
Note
쮿 Front panel can be removed in opened position (> 135°)
6.53
Shielding is required between the following components of a subrack
쮿 Front panel/rear panel and horizontal rail, see page 6.55
쮿 Front panel and 19" bracket/corner profile or in case of
depth-offset installation, see page 6.55
쮿 Cover plate/horizontal rail, see page 6.44
쮿 Cover plate/side panel, see from page 6.44
쮿 Horizontal rail/horizontal rail in combined mounting
(3 U + 3 U and 6 U), see page 6.59
쮿 Shielding for backplane and side panel see page 6.55
쮿 Shielding concepts in accordance with IEEE and IEC
쮿 Shielding effectiveness has been determined in various series
of measurements in accordance with IEC 61587-3 and can be
found online together with the relevant standard product
쮿 The combined use of stainless steel and textile EMC gaskets
is functionally possible without any problems
EMC shielding concept with EMC textile gaskets
쮿 The seal is affixed to the left-hand side of the subrack
(viewed from front) or to the front panel profile, respectively
쮿 An EMC gasket with CuNi coating assures a long-term
high level of shielding, typically 40 dB at 2 GHz
쮿 Temperature-resistant adhesive layer is protected by a
removable film
쮿 Rear shielding is obtained using front panels or a rear hood
쮿 Temperature range -40° C ... +70° C
06108073
쮿 Note: rear hood and corner profile cannot be used
simultaneously
EMC shielding concept with stainless steel EMC
gaskets)
쮿 Symmetrical arrangement of EMC gaskets on the left and right
hand sides of subrack and front panel
쮿 Shielding: typically 40 dB at 2 GHz
쮿 Can be used for temperatures above +70° C
simultaneously
06108074
Front panel shielding concept
쮿 Front panels are available for textile or stainless steel EMC
gasket options
쮿 Alignment pins are pressed-in in the front panel to position the
gaskets securely and to compress them evenly
쮿 An alignment pin positions the perforated strip in the horizontal
rail
쮿 Alignment pin and perforated strip provide an optimal
positioning of the shielded assemblies; the front panels are
not forced sideways by the shielding elements (Schroff patent)
06112091
6.54
SCHROFF PRODUCT CATALOG E 03/2016
EMC gaskets between front/rear panel and horizontal rail
Order Information
between front panel/rear panel and horizontal rail
06102053
stainless steel; for front and rear horizontal rails (type VT)
06102053
Width
HP
28
42
63
84
Depth
mm
131.8
202.9
304.5
416.6
PU 10 pieces
24560-231
24560-233
PU 100 pieces
24560-235
24560-236
24560-229
Main Catalogue
EMC gaskets between front panel and 19" bracket/corner profile
Order Information
Textile EMC gasket
06105077
06105077
06108070
of the front panel
Height
U
3
4
6
9
Depth
mm
97.5
142.5
232.5
365.0
06102056
06108054
UL 94 V-0
PU 10 pieces
PU 100 pieces
PU 10 pieces
PU 100 pieces
21101-705
21101-706
21101-853
21101-854
21101-713
21101-707
21101-714
21101-708
21101-858
21101-855
21101-856
21101-709
21101-710
21101-859
21101-904
24560-270
SCHROFF.PENTAIR.CO.UK
6.55
EMC gaskets between horizontal rail and horizontal rail
Order Information
bza45877
Item 1: cover strip, Al, 1 mm,
item 2: 2 x EMC seals (stainless steel);
for shielding of 2 horizontal rails positioned directly one above the other
if assembly area is divided vertically
bpa46548
Width
HP
40
42
63
84
Depth
mm
107.0
147.0
208.0
218.0
325.0
431.0
PU 1 kit
24562-520
24562-528
24562-540
24562-542
24562-563
24562-584
EMC gaskets between front panel and side panel
(depth-offset installation)
Order Information
Textile EMC gasket
1
1
2
2
bpa45884
Item 1: 2 x support profiles, Al extrusion;
item 2: 2 x stainless steel EMC gasket;
fixing material kit for vertical EMC shielding between
depth-offset shielded front panels and side panel
Height
U
3
4
6
Depth
mm
97.5
142.5
187.5
EMC gasket
06102058
item 2: 1 x EMC textile gasket;
PU 1 kit
PU 1 kit
24562-199
24560-180
24562-299
24562-499
24560-280
24560-480
24560-270
Main Catalogue
6.56
EMC gaskets between backplane and side panel
Order Information
between backplane and side panel (depth-offset installation)
bpa45916
2 x support profile, AI extrusion,
2 x EMC gasket (stainless steel)
Fixing materials kit and user manual;
for vertical EMC shielding between shielded backplane and side panel;
dimensions (84 HP):
A = 425.8 mm,
B < 429.9 mm,
C = 429.8 mm,
D = 431.8 mm
06108078
Height
U
3
6
PU 1 kit
24561-199
24561-499
쮿 With an appropriate design the backplane can be used as
shielding rear panel; for that purpose a rear horizontal rail
(type L-VT or H-VT) for depth-offset installation must be used
to ensure the horizontal contact
쮿 For vertical contact the support profile can be fixed to the
europacPRO side panel (depth grid 30 mm)
Main Catalogue
Part number in normal type: ready for despatch within 10 working days
6.57
Special interior mounting parts
쮿
쮿
쮿
쮿
쮿
쮿
쮿
쮿
6.58
Combined mounting: 3 U + 3 U and 6 U, see page 6.59
Horizontal board mounting, see page 6.60
Mounting plates, see page 6.61
Central locking for PCBs, see page 6.62
Divider plates, see page 6.62
Air baffles, see page 6.63
Telescopic slides, see page 6.64
Fixing parts (bolts, nuts, assembly tools), see page 6.63
Combined mounting (6 U and 2 x 3 U one above the other)
Main Catalogue
Order Information
Combined mounting:
Alternative front panels for
combined mounting
front panel for
unshielded
textile EMC gasket,
front panel,
6 U, 2 HP
6 U, 2 HP
item 6
item 6
subdivision
(incl. front panel for stainless
steel EMC gasket)
Splitting extrusion
for combined
mounting
item 2
2
4
2
1,3
1,3
4
6
bpa46549
bza42182
Width pitch T1:T2
bpa46550
bpa45857
Al, 2.5 mm,
U-profile with notch,
6 U, 2 HP
6 U, die-cast zinc;
splitting extrusion
is inserted in the
grid holes of the
horizontal rail;
the splitting extrusion
can be bolted
1 (SPQ 5)
1 piece (SPQ 5)1)
1 piece
30847-472
30849-140
64560-010
24560-145
24560-179
21101-101
21101-101
21101-102
21101-102
21101-121
21101-121
21101-855
Note see below 2)
HP
20:62
40:42
42:40
63:19
84:0
Torx countersunk screw
M4 × 14, zinc-plated, PU 100 pieces
to fixsplitting extrusion/horizontal rail
Panhead screw
M2.5 × 10, St, zinc-plated, PU 100 pieces
to fix horizontal rail/splitting extrusion
Pozidrive/slotted collar screw
M2.5 x 12.3, St,
nickel-plated, PU 100 pieces
M2.5, black, zinc-plated, PU 100 pieces
Washer
2.7 x 5 x 1, PA 6, PU 100 pieces
Textile gasket, core: foam,
UL 94 V-0
PU 10 pieces
bpa46550
Al, 2.5 mm,
front anodised,
chromated
Item 1: 2 front horizontal rails (HKD),
Al extrusion, anodised;
item 2: 2 rear horizontal rails (AB),
item 3: threaded inserts, St,
zinc-plated;
item 4: Zn die-cast support
members;
item 6: front panel 2 HP, 6 U,
with EMC stainless steel gasket;
84:0 without items 4, 5
PU 1 kit
24562-420
24562-440
24562-442
24562-463
24562-484
2) The following guide rails cannot be used: type "accessory", type "accessory, strengthened" and type "for 4.4" PCB"
쮿 Subdivision of the 6 U assembly area into:
– 2x3U
– 1x6U
쮿 Designed to accomodate euroboards (100 mm high) and
double euroboards (233.35 mm high)
Note
쮿 Please order EMC gasketing kit for horizontal rails separately,
see page 6.56
쮿 Please order perforated strips for horizontal rails separately,
see page 6.35
쮿 Please order rear centre horizontal rail separately,
see page 6.33
6.59
Horizontal board mounting in 3 or 4 U subrack
Main Catalogue
Order Information
Board cage
Front frame for
Front frame, unshielded
EMC shielding
27
3.9
8=
54
TE
06102073
=5
4T
E
bpa45913
H
,98
h
w
273
bza43061
Struts, die-cast zinc;
horizontal rails front and rear;
threaded inserts, St, zinc-plated;
fixing material kit;
for horizontal mounting of
double-height euroboards in
3 or 4 U high subracks/cases;
54 HP space required;
please order front frame for EMC
shielding separately
2 horizontal covers, AI 2.5 mm,
front anodised,
2 vertical trims, Al extrusion,
passivated;
front frame provides the contact
between subrack and the
sub-assemblies
Al, 2.5 mm, clear anodised;
front frame with cut-out,
clear internal width w =
266.35 mm
PU 1 kit
PU 1 kit
1 piece
(1 TE = 1 HP, 1 HE = 1 U)
bpa45914
Mounting variants
Height
U
Usable
height h
HP
3
24564-109
34564-108
3
24564-109
34564-109
4
28
24564-217
24564-209
34564-208
24560-270
Horizontal rail,
front
Horizontal rail,
rear
EMC gasket
* For direct backplane mounting
Note
쮿 Please order front frame for EMC shielding separately
6.60
Mounting plates
Order Information
Mounting plate
can be used in combination with
cover plate
Mounting plate
for use without cover plate
Fixing strip for partial widths
06108080
bpa45875
Al, 1.5 mm;
AI, 1.5 mm;
for mounting over partial width,
mounting is only possible over the
entire width between the side panels; please order fixing strips separately
width of mounting plate
= W - 9.71 mm
bpa46557
St, 2.5 mm, zinc-plated;
is bolted from front to rear
onto the horizontal rails;
to fix mounting plates
bpa45875
Width W
W
Board length
HP
mm
mm
28
146.88
160
28
146.88
220
28
146.88
280
28
146.88
340
42
217.99
160
42
217.99
220
42
217.99
280
42
217.99
340
63
324.67
160
63
324.67
220
63
324.67
280
63
324.67
340
84
431.35
160
84
431.35
220
84
431.35
280
84
431.35
340
Assembly kit for mounting plate, PU 1 kit
(Torx countersunk screw M4 x 5, St,
zinc-plated, 12 pieces;
screw M4 x 6, St, zinc-plated, 10 pieces;
square nut M4, St, zinc-plated, 10 pieces)
Assembly kit for fixing strips for partial width
mounting plates
Torx screw M2.5 × 5, St, zinc-plated,
PU 100 pieces
1 piece
1 piece
1 piece
34563-001
34562-745
30840-021
34563-009
34562-749
30840-033
34562-753
34562-757
30840-045
30840-057
34563-002
34562-746
30840-021
34563-014
34562-750
34562-754
30840-033
30840-045
34562-758
30840-057
34563-003
34563-019
34562-747
34562-751
30840-021
30840-033
34562-755
30840-045
34562-759
34562-748
30840-057
30840-021
34563-004
34563-024
34562-752
30840-033
34562-756
34562-760
30840-045
30840-057
24560-184
24560-184
24560-146
Note
쮿 For installation and fixing of heavy components
쮿 In addition to the mounting plate, (EMC) cover plates
can also be fitted to the subrack
쮿 The mounting plate is as wide as the subrack or system case
and is fixed to the side panels
쮿 A guide rail can be fitted on the first and last slot
쮿 Guide rails type "4.4" and type "strengthened" cannot be used
6.61
Central locking
Order Information
Central locking
for PCBs without front panels
5
6
7
1
2
3
4
06197010
Width
HP
84
bza45819
Item 1: central rail, AI, anodised;
item 2: ID cardboard, white;
item 3: transparent cover strip, plastic;
item 4: 2 x knurled screw;
item 5: 2 x slide nut;
item 6: 2 x hexagon nut M2.5;
item 7: rubber gasket;
central locking allows joint locking of PCBs and serves as identification strip;
can be fitted to front and rear horizontal rails,
suitable for 84 HP width
Length
mm
426.0
1 piece
24560-167
Main Catalogue
Divider plate
Order Information
Divider plate
Mounting position when stainless steel
EMC gasket is used
textile EMC gasket is used
front
rear
front
bpa45911
rear
06105078
Stainless steel, 1 mm, is mounted by clipping onto horizontal rail,
space requirement on component side 2 mm;
mounting direction varies with shielding design (EMC stainless steel or textile gasket);
retrofitting the divider plate in an already-assembled subrack/case
will first require dismantling of the horizontal rails;
where front panels are unshielded, both mounting directions are possible
bpa45912
Height
U
3
3
6
6
Depth
mm
160
220
160
220
A
mm
158.3
218.3
158.3
218.3
B
mm
135.0
195.0
135.0
195.0
H
mm
113.5
113.5
246.9
246.9
PU 10 pieces
34562-761
34562-762
34562-763
34562-764
Main Catalogue
6.62
Air baffles for slots
Order Information
Air baffle
without front panel
Air baffle with front panel
Front panel with lateral groove
U front panel
06108085
06108087
Air baffle, Al, 1 mm;
front panel, Al, 2.5 mm,
front anodised, rear conductive;
fixing material kit prevents
an air short circuit in unused
slot positions;
is pushed into the groove
of the guide rail
Al, 1 mm, incl. fixing material kit;
prevents an air short circuit in
unused slot positions;
of the guide rail
06108088
Air baffle, Al, 1 mm,
front panel, Al extrusion, 2.5 mm,
textile EMC gasket,
slot positions;
ofthe guide rail
06101507
Depth
mm
160
160
160
160
160
160
220
220
220
220
220
220
Width
HP
4
4
8
8
12
12
4
4
8
8
12
12
Assembly tool
for stainless steel EMC gasket,
1 piece
Height
U
3
6
3
6
3
6
3
6
3
6
3
6
1 piece
1 piece
1 piece
34562-823
20848-712
20848-728
34562-826
34562-833
20848-720
20848-714
20848-736
20848-730
34562-836
20848-722
20848-738
34562-843
34562-846
20848-716
20848-724
20848-732
20848-740
34562-824
20848-713
20848-729
34562-827
34562-834
20848-721
20848-715
20848-737
20848-731
34562-837
20848-723
20848-739
34562-844
34562-847
20848-717
20848-725
20848-733
20848-741
24560-270
Note
쮿 Air baffle for 280 mm deep and for 80 mm rear I/O boards
Main Catalogue
6.63
Simple telescopic slide for assembly of
subracks in cabinets
쮿 For mounting 84 HP wide subracks in the 19" plane
쮿 Loading capacity: 25 kg per pair
쮿 The guiding profile is matched to the fixing dimension in the
cabinet (it is bolted to the 19" profile of the cabinet); the adaptor
rail is matched to the depth and fixing dimension on the subrack
(it is inserted into the guiding profile like a telescopic slide)
쮿 Safety note:
No protection against extraction, no stop at full extension
06101006
Order Information
Telescopic slides with guiding profile for fitting in cabinets
Telescopic slides with adaptor rail for subracks
Xr
Order Information
1
450
D
c
Xf
c1
3
465
3
06108082
06108072
Description
Depth D xf
xr
C
c1
Part no.
mm
mm
mm
mm
mm
VARISTAR
600
50
50
500
369
24562-464
VARISTAR
800
50
50
700
569
24562-466
VARISTAR
900
50
50
800
669
24562-467
VARISTAR
1000
50
50
900
769
24562-468
VARISTAR
1100
50
50
1000 869
24562-472
VARISTAR
1200
50
50
1100 969
24562-473
eurorack
600
60
60
480
397
24562-449
eurorack
800
60
60
680
597
24562-451
eurorack
900
60
60
780
697
24562-452
NOVASTAR
500
33
60
407
350
24562-460
NOVASTAR
600
33
60
507
450
24562-461
NOVASTAR
800
33
60
707
650
24562-474
Lab rack
250
162
24562-446
xf, xr: Distance of 19" plane to cabinet edge (front, rear)
c: Distance of 19" planes from each other,
c1: Fixing dimension of guiding profile on 19" panel/slide mounts
For subrack depth
mm
Part no.
175
24562-453
235
24562-454
295
24562-455
355
24562-456
415
24562-457
475
24562-458
Main Catalogue
6.64
Assembly parts
쮿 Quick-release fasteners
쮿 Sleeves
쮿 Screws
쮿 Cage nuts
쮿 Tools
쮿 Vibration and shock proof
쮿 1/4 rotary lock with defined stop
쮿 Detection of locking position through slot position
Delivery comprises
Qty
1
1
Description
Locking pin, St, locking, Zn die-cast
Press-in sleeve, POM
Order Information
06702062
Item
1
1
2
2
Description
With slotted head, grey
With slotted head, black
With knurled and slotted head, grey
With knurled and slotted head, black
Qty/PU
100
100
100
100
Part no.
21101-847
21101-848
21101-849
21101-850
Note
Quick-release fasteners: mounting without threaded inserts
Sleeves
Order Information
Item
2
2
1
1
1
1
1
Description
Plastic sleeve, PA, grey
Plastic sleeve, PA, black
Metal sleeve, brass, nickel-plated
Metal sleeve, brass, black
Metal sleeve, stainless steel
Qty/PU
100
100
10
100
100
10
100
Part no.
21100-464
21100-591
21100-659
21100-660
21100-886
21100-661
21100-662
Note
쮿 Metal sleeves must be pressed-in in front panels
쮿 Sleeve does not fit in 2 HP wide front panels
06702061
6.65
Subracks – DServicePLUS
Collar screws
Order Information
Description
Application
Material
Dimension
Qty/PU
Part no.
St, nickel-plated
M2.5 х 12.3
100
21101-101
St, zinc-plated,
black
M2.5 х 12.3
100
21101-102
St, nickel-plated
M2.5 х 12.3
100
21101-782
St, zinc-plated,
black
M2.5 х 12.3
100
21101-783
Brass, nickelplated
M2.5 х 12.3
100
21101-749
For mounting of front panels when using
Brass, nickelthreaded inserts for horizontal rails with long lip plated
M2.5 х 12.3
100
21101-909
Collar screw with For mounting of front panels when using
pozidrive/slot
threaded inserts
AZA46586
Torx collar screw
threaded inserts
AZA45941
threaded inserts
Collar screw with
knurled head
aza45929
Torx screws, self-forming
Order Information
Description
Application
Material
Dimension
Qty/PU
Part no.
Torx panhead
screw,
self-forming
For extra-robust Al guide rails;
torque max. 0.2 Nm
St, zinc flake
coating, black
2.5 х 7.3
100
24560-157
St, zinc-plated
2.5 х 7.7
100
24560-158
06707058
Torx countersunk For 4.4" board height, guide rail on horizontal
rail, europacPRO, ratiopacPRO;
screw,
torque max. 0.2 Nm
self-forming
06707058
Torx panhead
screw,
self-forming
For plastic guide rail on horizontal rail;
for panel bracket on horizontal rail;
torque max. 0.2 Nm
St, zinc-plated
2.5 х 9.3
100
24560-141
Torx panhead
screw,
self-locking
For plastic guide rails on horizontal rails
St, zinc-plated
2.5 × 9.3
100
21500-039
Torx panhead
screw
For 6 U support member, backplane mounting,
St, zinc-plated
2.5 × 10
100
24560-179
06707058
06707058
06707058
6.66
Countersunk screws
Order Information
Description
Torx screw
AZA46585
Application
Material
Dimension
Qty/PU
Part no.
For support profiles europacPRO, ratiopacPRO
St, zinc-plated
M4 х 5
100
24560-139
For mixed board assembly and assembly of
shortened horizontal rail on support member,
with GND/earthing function
St, zinc-plated
M4 х 14
100
24560-145
Torx panhead screws
Order Information
Description
Application
Material
Dimension
Qty/PU
Part no.
For Z-rails and connector assembly
St, nickel-plated
M2.5 х 7
100
24560-147
For perforated rails
St, nickel-plated
M2.5 х 10
100
24560-148
St, nickel-plated
M2.5 х 12
100
24560-161
St, nickel-plated
M2.5 х 14
100
24560-162
Torx panhead
screw
For backplane mounting
aza45940
Washer
For insulated backplane mounting
Plastic, PA
2.8 х 6.3 х 2
100
21101-964
Screw +
plastic washer
(PA)
St, nickel-plated
M2.5 х 12
100
21100-777
To bolt on support bracket, rear hood,
corner profile on side panel, lengthening bracket St, zinc-plated
and connecting bracket
M4 х 6
100
24560-135
To bolt-on cover plate or mounting plate,
St, zinc-plated
M4 х 6
100
24560-151
St, zinc-plated
with GND/earthing function, self-forming thread
M4 × 6
100
21101-884
For horizontal rail on side panel
if guide rails are bolted to slot 1
St, zinc-plated
M4 х 10
100
24560-155
For horizontal rail on side panel,
St, zinc-plated
M4 × 14
10
24560-131
St, zinc-plated
M4 х 14
100
24560-130
aza45178
aza45940
aza45940
Torx panhead
screw
06707058
aza45940
6.67
Grub screws
Order Information
Description
Application
Material
Dimension
Qty/PU
M2.5 х 9
100
21101-359
For threaded inserts M2.5
St, nickel-plated M2.5 х 8
100
21100-276
For threaded inserts M3
St, zinc-plated
M3.0 х 8
100
21100-646
Dimension
Qty/PU
M4
100
For threaded inserts M2.5 and perforated strips Stainless steel
Grub screw
Part no.
06702053
Square nuts
Order Information
Description
Application
Material
Square nut
For fixing: parts to side panels, support profiles,
St, zinc-plated
mounting plates
Part no.
24560-140
AZA45921
Assembly kits
쮿 For assembly of subracks in cabinets or 19" cases
쮿 For assembly of desk-top cases in cabinets by means of
19" brackets
Delivery comprises (kit)
Item
1
2
3
Qty
1
1
1
Description
Pozidrive screw M6 × 16, zinc-plated
Plastic washer, ABS, black
Cage nut M6, zinc-plated
SC128XXX
Order Information
Description
PU = 8 × screw, washer, nut
PU = 50 each of M6 screw, washer and cage nut
PU = 100 each of M6 screw, washer and cage nut
Part no.
21100-435
21101-809
21101-810
쮿 For 19" brackets with material thickness of 1.5 mm,
see "Assembly kits" in chapter Cabinet accessories
6.68
Slide, to accomodate 2 nuts
쮿 The slide is pushed into the groove of the horizontal rail
to front or rear (type VT)
Item
1
2
Qty
1
2
Description
Slide, PBT, red, UL 94 V-0
Nut, M2.5, St, zinc-plated
Order Information
Description
Slide nut kit 1
Slide nut kit 2
Part no.
100 slides/200 nuts
12 slides/24 nuts
24560-165
24560-166
Note
쮿 Nuts used in item 3 suitable for:
– hinged front panels, 84 HP
– front or rear panels, 84 HP
쮿 Nuts used in item 4 suitable for:
쮿 Nuts used in item 3 and 4 suitable for:
– two front panels
06702060
6.69
Assembly tools
Main Catalogue
Order Information
Description
Application
Dimension
Qty/PU
Part no.
T 8 torx
T8
1
64560-026
T 20 torx
T20
1
64560-027
Assembly tool
Exclusively to fix stainless steel
EMC gaskets in horizontal rails
1
24560-271
Assembly tool
To fix stainless steel EMC
gaskets on front panels
with lateral slots
1
24560-270
Torx screwdriver
AZA45925
aza45938
aza45937
Note
쮿 Assembly tool to insert keying/coding pegs in guide rails
is available on request
Tape measure
쮿 Measuring tape with cm, U-, HP-division (length 2 m)
쮿 Plastic housing, metal measuring tape with automatic collection
Order Information
Description
Tape measure
Qty/PU
piece
1
Part no.
89009-001
Main Catalogue
32506001
6.70
Application examples
Application: Transportation/defense sectors
Text
06108006
쮿 Mounting frame to accomodate a 36 HP wide railway subrack,
frame from stainless steel
쮿 Robust assembly by double bolt-on fixing
06103001
쮿 Lateral ducting in cabinet
쮿 Combined mounting 6 U+ 2 x 3 U
Application: Measurement, control and instrumentation sectors
쮿 Combined mounting with 2 x 3 U in 6 U
06108002
쮿 Subrack with additional telescopic fan unit
06108003
쮿 Adaptation at bottom and top integrated into the side panel
쮿 Divider plate to separate different sections
쮿 Installation with strengthened guide rails
Application: Telecoms sectors
06112023
쮿 Shielded subrack for special applications with mounting plate,
cover and base plate
쮿 Mounting plate for heavy assemblies
쮿 Subrack with plastic cable ducting for fibre optic cables
06101005
쮿 Terminal area at top
6.71
for railway applicationsDMain Catalogue
Subracks – Dfor railway applications
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
F_2015161_06104008
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
06108013
An alignment pin to NFF standard
allows the easy installation of the
subracks
06108014
Lateral support bars to NFF
standard facilitate insertion of
subrack into the (cabinet) frame
06108015
The 19" bracket is firmly fixed to the
side panel (tox-cold welded) and is
especially suited for high
mechanical stresses(vibration
resistance)
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
Backplanes . . . 10
06108016
The double 19“ screwing position
adds to additionally safety (NFF
standard)
Connectors, front
panel component
system . . . . . . . 11
06108017
The cut-out in the side panel allows
to retrofit the threaded insert, also
if the side panels are already
assembled
06108015
The rear brackets have two
functions:
- push-in aid and
- transport protection for the
connectors
The removable rear hood allows a
fast cabling between backplane and
connector
Appendix . . . . . 12
6.70
SCHROFF PRODUCT CATALOG E 05/2016
Overview . . . . 6.70
19" subrack for mobile rail applications
쮿 Shock and vibration resistance to IEC 61587-1, EN 50155,
NF F 61-005 / NF F 60-002, BN 411002 and BN 411003
쮿 Versions for CompactPCI applications
쮿 Best suited for high mechanical demands
BN 411002, 411003 subracks
쮿 Height 3 U and 6 U
쮿 Width 84 HP
BN 411002/-003
subracks
unshielded . . . . . . . 6.73
shielded . . . . . . . . . 6.74
쮿 Unshielded and shielded versions
06102008
EN 50155 subrack
쮿 Width 84 HP
EN 50155 subracks
unshielded . . . . . . . 6.75
shielded . . . . . . . . . 6.76
shielded, for
CompactPCI . . . . . 6.77
쮿 Shielded versions for CompactPCI applications
06104006
SNCF subrack
쮿 Width 9 T (36 HP) and 21 T (84 HP)
SNCF subracks
unshielded . . . . . . . 6.78
shielded . . . . . . . . . 6.79
shielded, for
CompactPCI . . . . . 6.80
Accessories
Guide rails . . . . . . . 6.81
Cover plates . . . . . 6.82
General
accessories in
europacPRO
section . . . . . . . . . . 6.17
06104003
ServicePLUS . . . 6.84
ServicePLUS from page 6.84
e.g. modification (cut-outs)
e.g. downloads (CAD drawings, user manuals,
test reports)
e.g. custom solutions (special depths,
electromagnetically shielded applications)
www.schroff.biz/ServicePLUS
Application
examples . . . . . . . . 6.85
europacPRO . . . 6.6
europacPRO for
industrial
applications . . . . 6.86
europacPRO for
rugged
applications . . . . 6.92
30407004
6.71
Subrack for mobile rail applications
Solid mechanical construction
Electronics for mobile applications require robust mechanical
construction that can withstand extreme environmental
conditions. Our enclosure solutions protect the housed
electronics thanks to their high mechanical strength and thus are
an important element for secure and trouble-free operation of the
entire system. Only dependability, down to the last detail, can
make complex safety tasks achievable - and also economic.
Text
TGV_Eurostart1
Schroff products assure shock and vibration resistance in mobile
applications e.g. by suitable material thicknesses and fixing
elements. Tested with typical loads, they offer the best conditions
for secure and reliable functioning in individual applications and
projects.
Certification of mechanics
High-quality, robust and durable products are an important
component for the certification of a complete application in
accordance with the European Railway Standard DIN EN 50155,
the German Railway Standards BN 411002 and BN 411003
and the French Railway Standards NF F 61-005 and NF F 60-002.
Note
fer = ferroviaire (French) = railway
1 T = 4 HP = 20.32 mm
Railway Technology brochure
A large amount of general information on our railway systems
solutions can be found at www.schroff.co.uk/railway/ and in our
"Railway Systems" brochure.
Y-Achse_001a1 , SNCF_Logo, 30407002
TÜV test report
30608002
scb_bn411002_d1
for railway applicationsDMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days
6.72
Kit, unshielded, 'heavy',
for backplane mounting
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Subrack with side panel type H ("heavy"),
19" bracket is firmly connected to side panel
(tox-cold welded)
쮿 Rear horizontal rail for backplane mounting with insulation
strip
쮿 Tested to German Railway Standards BN 411002, BN 411003
쮿 Versions with/without front handles
06102007
Without front handle
06111003
With front handle
Delivery comprises (Kit)
Item
1
Qty
3U
2
6U
2
2a
2b
2c
3
4
5
6
2
2
4
2
1
2
2
2
1
6
4
1
2
1
6
Description
2b + 3 + 4
2c + 3 + 4
5
2a + 3
Side panel type H, Al, 2 mm, passivated,
with 19" support bracket (tox-cold welded)
for textile EMC gasket
Front horizontal rail (H-KD)
Rear horizontal rail (H-ST)
Rear horizontal rail centre (H-ST)
Threaded inserts, front and rear (pre-fitted)
Insulation strip (pre-fitted)
Fixing material kit, user manual
Front handle (on version with front handle only)
Order Information
Height Width Depth D Depth D1
U
HP
mm
mm
1
5
6U
06111057
3
3
3
3
6
6
6
6
84
84
84
84
84
84
84
84
175
235
295
355
175
235
295
355
175
175/235
175/235/295
175/235/295/355
175
175/235
175/235/295
175/235/295/355
Part no.
with front
handle
Part no.
without front
handle
24567-161
24567-162
24563-161
24563-162
24567-163
24563-163
24567-164
24567-461
24563-164
24563-461
24567-462
24563-462
24567-463
24567-464
24563-463
24563-464
Accessories
D2
19" assembly kit (screw, washer, nut) (8 × screws,
8 × plastic washers, 8 × cage nuts)
D1
21100-435
Guide rails (standard), ESD clips
D
06108052
D=overall depth, D1=insertion depth,
D2=board depth = D1 - 15 mm
Depth D2
Qty/PU
mm
pieces
160
10
220
10
280
10
340
10
ESD clip for guide rails PU 50 pieces
Torx panhead screw , for extra bolting of the guide rails,
2.5 × 9.3, zinc-plated, PU 100 pieces
Part no.
24560-351
24560-353
24560-379
24560-380
24560-255
24560-141
Note
04400001
strip
쮿
쮿
쮿
쮿
Perforated rails, cover plates and assembly kit from page 6.34
Textile EMC gaskets see page 6.21
Further accessories from page 6.17
ServicePLUS configuration from page 6.84
ServicePLUS see page 6.84
6.73
Kit, shielded, "heavy", for backplane mounting
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
(tox-cold welded)
쮿 Horizontal rail rear for backplane mounting with insulating
strip
쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz
(in accordance with VG 95373, part 15 or IEC 61587, part 3), under the condition that the front is closed with shielded front panels
06102008
06111001
With front handle
7
3b + 4 + 6
Item
1
Qty
3U
2
6U
2
2
3
3a
3b
3c
4
5
6
7
8
9
10
11
2
2
2
2
6
2
2
2
1
1
1
2
2
2
2
2
1
8
2
4
2
1
1
1
2
3+4+5
3c + 4 + 6
11
Description
1
3a + 4
9
2
3+4+5
10
7
11
6U
06111058
with 19" support bracket (tox-cold welded);
Rear corner profile for textile EMC gasket
Rear horizontal rail (H-KD)
Threaded insert (pre-fitted)
Perforated strip (pre-mounted)
EMC cover plate
EMC gasketing material (pre-fitted)
EMC rear panel
Order Information
D2
D1
D
06108060
D = overall depth, D1 = insertion depth,
D2 = board depth = D1 - 15 mm
U
HP
mm
Depth D1
mm
3
3
3
6
6
6
175/235
175/235/295
175/235/295
175/235
175/235/295
175/235/295
84
84
84
84
84
84
235
295
355
235
295
355
Part no.
with front
handle
Part no.
without front
handle
24567-172
24563-172
24567-173
24563-173
24567-174
24567-472
24563-174
24563-472
24567-473
24563-473
24567-474
24563-474
Accessories
8 × screws, 8 × plastic washers, 8 × cage nuts)
21100-435
04400001
strip
6.74
Depth D2
Qty/PU
mm
pieces
160
10
220
10
280
10
Part no.
24560-351
24560-353
24560-379
24560-255
24560-141
쮿 Perforated rail for connectors see page 6.34
쮿 Further accessories from page 6.17
쮿 ServicePLUS configuration from page 6.84
Kit, EN 50155, unshielded
Main Catalogue
쮿 Subrack in robust "heavy" version,
19" bracket is firmly connected to side panel (tox-cold welded)
쮿 For mobile railway applications
쮿 Tested to EN 50155
쮿 3 U and 6 U, 84 HP, 235 mm deep, for 220 mm board depth
06104005
3U
1
2a + 3
4
Item Qty
3U
1
2
6U
2
2
2a
2b
3
4
5
6
2
2
1
6
2
1
1
2
2
4
2
1
1
Description
Side panel type H with 19" support bracket (tox-cold
welded); prepared for EMC textile gasket
Rear horizontal rail (H-VT)
Rear centre horizontal rail (VT)
Threaded inserts
Handles
Assembly kit with self-locking screws
User manual
Order Information
1
2+3
06104056
6U
1
2a + 3
2b + 3
Height
Width
Depth
U
HP
mm
3
84
235
6
84
235
Accessories
Guide rail, standard, 220 mm deep
PBT, UL 94 V-0, red, groove width
2 mm, PU 10 pieces, see page 6.36
Panhead screw with Torx
M2.5 x 9.3, St, zinc-plated, self-locking,
PU 100 pieces
Cover plate for screw-fixing onto side panel width 84 HP,
depth 220 mm, PU 1 kit
19" dual fixing materials kit suitable for a subrack with
double fixing holes (bolts, washers and nuts), PU 1 kit
Part no.
21500-077
21500-078
24560-353
21500-039
24560-255
21500-037
24566-109
Note
4
쮿 Test reports online
쮿 ServicePLUS configuration see from page 6.84
쮿 Further accessories see from page 6.17
1
2+3
06104057
6.75
Kit, EN 50155, shielded
Main Catalogue
06104006
3U
7
5
2a + 3
1
7
8
1
2+3+4
Item Qty
3U
1
2
6U
2
2
2a
2b
3
4
5
6
7
8
9
10
2
2
1
6
2
2
1
2
2
1
1
2
2
4
2
2
1
1
2
1
1
Description
welded); for textile EMC gasket
Threaded inserts
Perforated strip
EMC cover plate 235 T
EMC gasketing kit
Backplane kit – EMC shielding material
Handles
User manual
Order Information
8
06104058
6U
5
7
2a + 3
2b + 3
7
1
8
Height
Width
Depth
U
HP
mm
3
84
235
6
84
235
Accessories
PU 100 pieces
Part no.
21500-079
21500-080
24560-353
21500-039
24560-255
24566-109
Note
1
2+3+4
8
2a + 3
06104059
6.76
Kit, EN 50155, shielded, for CompactPCI applications
Main Catalogue
쮿 3 U and 6 U, 84 HP, 235 mm deep, for 160 mm board depth
쮿 Subrack in accordance with IEEE 1101.10
06104007
3U
7
5
2a + 3
1
7
8
2 + 3 +4
1
2c +3 +4
Item Qty
3U
1
2
6U
2
2
2a
2b
2c
3
4
5
6
7
8
9
10
2
1
2
6
2
2
1
2
2
1
1
1
2
1
4
2
2
1
1
2
1
1
Description
Front horizontal rail (H-LD)
Threaded inserts
Perforated strip
EMC cover plate, 175 T
EMC gasketing kit
Handles
User manual
Order Information
8
06104060
6U
5
2a + 3
2b + 3
1
7
Height
Width
Depth
U
HP
mm
3
84
235
6
84
235
Accessories
Part no.
21500-081
21500-082
24566-109
Note
쮿 Please order guide rails and ESD clips separately,
see page 6.81
7
8
1
2c + 3 + 4
8
06104061
6.77
Kit, SNCF, unshielded
Main Catalogue
쮿 Subrack, robust "heavy" version,
(tox-cold welded)
쮿 SNCF listed, europacPRO-fer,
tested to NF F 61-005 and NF F 60-002
쮿 3 U and 6 U, 9 HP and 21 HP, 320 mm deep, for 220 mm board
depth
06104002
3U
2
7
4a + 5
1
6
7
8
3
2
4+5
1
06104050
6U
2
7
4a + 5
1
4b + 5
6
8
7
3
2
4+5
1
4a + 5
06104051
Coding peg
Item
1
Qty
3U
2
6U
2
Description
2
3
4
4a
4b
5
6
7
8
9
10
2
2
2
2
4
1
2
2
1
1
2
2
2
2
1
6
2
4
2
1
1
welded); prepared for textile EMC gasket
Side panel extension
Ducting external
Threaded inserts
Rear frame 3 U, 21 T
Protective bracket SNCF
Handle
User manual
Order Information
Width
Height
Depth
mm
U
mm
36 HP (9 T)
3
320
36 HP (9 T)
6
320
84 HP (21 T)
3
320
84 HP (21 T)
6
320
Accessories
PU 100 pieces
Coding peg for rear frame, St, white zinc-plated, 1 piece
Part no.
21500-067
21500-070
21500-029
21500-027
24560-353
21500-039
24560-255
60895-018
24566-109
Note
쮿 fer = ferroviaire = French Railways,
쮿 Receptacle/mounting frame for subracks, stainless steel,
9 T or 21 T on request
쮿 Cover plates for bolting on to side panel see page 6.82
06104062
6.78
Kit, SNCF, shielded
Main Catalogue
19" bracket is firmly fixed to side panel
(tox-cold welded)
쮿 3 U and 6 U, 9 T and 21 T, 320 mm deep, for 220 mm board depth
06104003
3U
4a + 5
12
7
8
11
10
1
12
13
3
2
4+5+6
1
06104052
6U
12
4a + 5
8
7
4b + 5
11
10
1
12
13
3
2
4+5+6
1
4a + 5
06104053
Coding peg
Item
1
Qty
3U
2
6U
2
Description
2
3
4
4a
4b
5
6
7
8
9
10
11
12
13
14
15
2
2
2
2
4
2
2
2
1
1
1
2
2
1
1
2
2
2
2
1
6
2
2
2
1
2
2
4
2
1
1
Ducting external
Threaded inserts
Perforated strip
Rear cover plate, 55 T
EMC gasketing kit
Rear frame, 3 U, 21 T
Handles
User manual
Order Information
Width
Height
U
3
6
3
6
Depth
mm
320
320
320
320
36 HP (9 T)
36 HP (9 T)
84 HP (21 T)
84 HP (21 T)
Accessories
PU 100 pieces
Part no.
21500-068
21500-071
21500-030
21500-028
24560-353
21500-039
24560-255
60895-018
24566-109
Note
06104062
6.79
Kit, SNCF, shielded,
Main Catalogue
(tox-cold welded)
쮿 3 U and 6 U, 9 HP and 21 HP, 320 mm deep, for 160 mm board
depth
쮿 CompactPCI subrack conforming to 1101.10
06104004
3U
4a + 5
12
7
8
11
10
1
12
13
3
2
4+5+6
1
4c + 5 + 6
06104054
6U
12
8
4a + 5
4b + 5
7
11
Item Qty
3U
1
2
6U
2
2
3
4
4a
4b
4c
5
6
7
8
9
10
11
12
13
14
15
2
2
2
1
2
6
2
2
2
1
2
2
4
2
1
1
2
2
1
2
1
4
2
2
2
1
1
1
2
2
1
1
Description
Ducting external
Threaded inserts
Perforated strip
EMC gasketing kit
Handles
User manual
Order Information
10
Width
12
13
1
3
2
4c + 5 + 6
1
4a + 5
06104055
Coding peg
06104062
Height
U
3
6
3
6
Depth
mm
320
320
320
320
36 HP (9 T)
36 HP (9 T)
84 HP (21 T)
84 HP (21 T)
Accessories
Part no.
21500-069
21500-072
21500-047
21500-046
60895-018
24566-109
Note
see page 6.81
6.80
Guide rails
Main Catalogue
쮿 Material PBT, UL 94 V-0, red, groove width 2 mm,
for 1.6 mm board thickness
Order Information
Description
Depth
mm
Guide rails, accessories,
160
160 mm deep
Guide rails, standard, 220 mm deep 220
Qty/PU
Part no.
10
24560-351
10
24560-353
24560-255
06102001
Guide rails with coding for CompactPCI
and VME64x
Main Catalogue
쮿 The guide rails conform to IEC 60297-3-100 and
IEEE 1101.10/11, are 4 HP wide and can be fitted with
keying/coding pegs
쮿 Material PBT UL 94 V-0, groove width 2 mm, for board
thickness 1.6 mm
쮿 Colour:
– red (CPU board)
– grey (periphery board)
– green (CompactPCI power supply unit, 0.1" offset)
Order Information
Description
06102003
Guide rails on horizontal rail type H
Guide rails with coding, red
Guide rails with coding, grey
Guide rails with coding, green, offset
Depth
mm
160
160
160
Qty/PU
10
10
10
PU 100 pieces
ESD clip for alignment pin of CPCI/VME64x handle
PU 50 pieces
Coding peg PC, UL 94 V-0, RAL 7035, PU 100 pieces
04505050
Part no.
24560-356
24560-358
24560-359
21500-039
24560-255
24560-256
20817-501
쮿 More guide rails see page 6.36
쮿 For inserter/extractor handle type IEL/IET for CompactPCI or
VME64x applications see Subracks/Plug-in units section,
page 7.18
06103052
6.81
Main Catalogue
쮿 Suitable for use with all horizontal rails
쮿 Cover plate for mounting of 160 mm, 220 mm or 280 mm deep
PCBs
쮿 Lateral notch to mount the horizontal rails in depths of 160 mm
or 220 mm
쮿 Shielding by optional EMC stainless steel contact strips
between cover plate and horizontal rail
Delivery comprises
Item
1
Qty
2
2
16/32
Description
Cover plate, Al, 1.0 mm, clear chromated,
(no perforation at 55 mm depth)
Torx M4 x 6 pentaform bolts, St, zinc-plated
Order Information
06102084
d = D - 25
3 HE / U
160 / 220 / 280
Width
HP
84
84
84
36
36
36
Depth D
mm
55
175
235
55
175
220
Application
160
160, 220
160
160, 220
Part no.
21500-038
21500-048
21500-037
21500-123
21500-124
21500-122
Note
쮿 4 stainless steel EMC gaskets are necessary per subrack,
see page 6.82
D
06102082
Side view for 175 mm and 235 mm depths
EMC gasket (stainless steel) between cover plate and
horizontal rail
Main Catalogue
쮿 Stainless steel gasket is clipped into horizontal rail and forms
the contact cover plate
X
쮿 Fits all horizontal rails
X
Order Information
Width
Length
Qty/PU
HP
mm
pieces
42
182.4
10
63
284.0
10
84
395.7
10
84
395.7
100
Assembly tool For mounting of
EMC sealing, St, stainless, in horizontal rails,
1 piece
X
X
X
06102052
Assembly tool
Part no.
24560-241
24560-243
24560-245
24560-246
24560-271
Note
쮿 When a rear hood is used, the stainless steel EMC gasket
ensures the conductive connection between horizontal rail and
rear hood
aza45938
6.82
Coding peg for rear frame (NFF standard)
Main Catalogue
Order Information
Description
Coding peg, St, white zinc-plated
Qty/PU
1
Part no.
60895-018
06104062
Order Information
Rear hood
horizontal rail
bza45819
06106052
60 mm additional side panel depth required
for shielding please order EMC gasket for
rear corner profile
1 piece
PU 10 pieces
34561-750
24560-241
bza45814
Height
Width
U
HP
3
42
3
84
6
63
6
84
Torx panhead screw, M4 × 6, St, zincplated, PU 100 pieces
34561-752
24560-245
34561-763
34561-764
24560-243
24560-245
24560-135
24560-271
Assembly tool, For EMC gasket,
Note
6.83
Subracks – for railway applications ServicePLUS
configuration
Simple. Fast. For the product you want.
Components can be varied and combined freely
쮿 Configuration tables from page 6.17
쮿 Online configuration: www.schroff.co.uk/configuration
assembly
Assembled by professionals. Double benefit!
Fitting of all mechanical, electrical and electronic
components by our specialists
쮿 Professional and reliable from quantity 1
modification
Small changes. Large impact.
Custom drillings, cut-outs and special colours for
off-the-shelf products
쮿 Custom modifications from quantity 1
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Special sizes (depth and width)
쮿 Ready for despatch within 5 working days
쮿 Ready for despatch within 10 working days
쮿 Individual heat dissipation concepts
express
When fast has to be faster.
Delivery time to customer's request
쮿 Express logistics
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Seminars, CAD drawings, test reports, user reports
6.84
Text
Application: Subrack receptacle/mounting frame
Application: Signalling control systems
Application: Control system
06108006
41108002
Csee_DSCN2296
Application: Automatic train control system
Application: Mobile telephony system
Application: Train control system
06108020
41108001
01004031
6.85
for industri al applic ationsDMain Catalogue
Subracks – Dfor industrial applications
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
06112008
Main C ataloguePart number in bold face type: ready for despatch within 2 worki ng daysPart number in norm al type: ready for despatch within 10 working days
We package your euroboards - even for applications in harsh industrial environments
쮿 A wide range in different dimensions, with finishes for the most diverse applications
Subracks/
쮿 In accordance with the IEC 60297-3-101 and IEEE 1101.1 standards
쮿 Tested to IEC 61587, VG 95373 T15, EN 50155, BN 411002, NF F 67-012, NF F 60-002
쮿 Delivered as a kit in space-saving package or individually assembled and fitted to your specifications
Front panels,
Applications
Power supply
Backplanes . . . 10
Subracks for mounting on mounting plate incl.
connection field
Connectors, front
panel component
06112009
Subracks with special adaptation
06112010
6.86
Overview . . . . . . 6.86
for industrial applicationsDMai n C atalogue
Subrack for industrial applications
쮿 Accommodates electronic boards in industrial applications
쮿 Mounting frame for power distribution modules (connectors, RCD switches, ...)
쮿 Bracket for panel mounting
Subrack for mounting on a mounting plate
Introduction . . . . 6.4
Subrack for
wall mounting . . 6.88
쮿 Height 3 U, width 28 HP, depth 205 mm
쮿 For mounting on mounting plate
쮿 For direct mounting of backplanes or to fit DIN plugs,
DIN 41612/EN 60603-2
06112002
Module support
쮿 Height 3 U, width 84 HP, depth 115 mm
Module support 6.89
쮿 Power distribution modules to mount on lipped horizontal rail
in accordance with DIN 43880
01494031
Bracket for mounting subracks in a panel
쮿 Bracket widths 42 and 84 HP
Bracket for
panel mounting 6.90
06197021
Accessories
쮿 Accessories (e.g. lipped rail adaptor, horizontal rails)
ServicePLUS from page 6.18 / 6.84
test reports)
30407004
Accessories . . . . 6.91
ServicePLUS . . . 6.18
Application
Subracks for
mobile railway
applications . . . . 6.70
europacPRO
for rugged
6.87
europacPRO subrack,
unshielded
for industrial appli cationsDMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 Subrack to mount on the wall or on mounting plate
쮿 For mounting of euroboards to IEC 60297-3-101 in size 3 U,
160 mm deep
쮿 Versions
– For connector mounting (DIN 41612, EN 60602-3),
with/without rear panel
– For backplane mounting, with/without rear hood
Delivery comprises
06112001
Illustration shows subrack without rear hood
2b / 2c / 4
5
6
2a / 4
1
Item
1
Qty
2
2a
2b
2c
3
4
5
6
7
2
2
2
2
2/4
2
1
1
Order Information
Description
3
06112050
D2
With rear panel, for
3
28
205
175
connector mounting
Without rear panel, for
3
28
205
175
connector mounting
With rear panel, for direct
3
28
205
175
backplane fixing
3
28
205
175
direct backplane fixing
Accessories
Guide rails, accessories, 160 mm deep PBT, UL 94 V-0,
red, groove width 2 mm, PU 10 pieces
Front panels
Front panel with handle
Part no.
24563-110
24563-109
24563-108
24563-107
24560-351
Page 7.5
Page 7.16
쮿 EMC version on request
D
Connector/backplane mounting;
6.88
Height Width Depth Depth
D
D1
U
HP
mm
mm
Note
D1
Horizontal rail to rear for
connector mounting
Description
Side panel, 3 U, Al, 2 mm with integrated wall-mounting
bracket
Front horizontal rail (L-KD)
Rear horizontal rail (L-RC) for backplane mounting
Rear horizontal rail (L-MZ) for connector mounting
Rear angle
Threaded insert, St, zinc-plated
Cover plate, pushed in
Rear hood, Al, 1 mm (only for version with rear hood)
Fixing materials kit, user manual
04400003
06112051
04400002
Horizontal rail to rear for direct
backplane mounting
19" module support, support rail to DIN 43880, hood
Main Catalogue
Order Information
19" module support
to accommodate power
Support rails to DIN 43880
Front panel for
19" module support
128,4
46,2
3
Hood
42
6,4
39
5
2
1
bla43467
01494031
06105080
06111053
3 U, 84 HP, Al, 2.5 mm,
2 adaptor brackets, Al, 2 mm;
3 U, 84 HP, 115.5 mm deep;
front anodised,
support rail, St,
2 side panels AI, 2 mm;
zinc-plated, (35/7.5 mm);
2 horizontal rails with short lip
chromated;
for width 84 HP (430.5 mm);
(L-KD), Al extrusion,
GND/earth connection 6.3 mm
surface anodised,
FASTON;
contact surfaces conductive; Mounted in module support or
(cut-out 395 mm x 46.2 mm);
subrack on the side panel
2 threaded inserts, St,
two blanking plates,
zinc-plated;
plastic, polyester,
GND/earthing kit;
colour similar to RAL 7035;
to cover unused module slots
Please order support rail
separately
BLA43492
Al, 1 mm, with brush strip;
is bolted to the rear of the
module support;
GND/earthing kit
PU 1 kit
PU 1 kit
1 piece
1 piece
24563-100
24565-100
24563-096
24564-100
Accessories
쮿 Power distribution modules see page 3.34
6.89
Main Catalogue
Order Information
Bracket (mounting angle)
06105067
Al extrusion, anodised; serves as front visual cover of
subrack at top and bottom when fitted into a panel;
screwed in from the front with the horizontal rail;
2 brackets and 4 screws are required per subrack
06197021
Usable width
Length
HP
mm
42
269.2
84
482.6
Torx panhead screw
1 piece
34561-777
34561-779
24560-141
Note
쮿 Further widths available on request
Assembly cut-out
06105066
Dimensions table
U
HP
3
3
3
6
6
6
42
63
84
42
63
84
6.90
A
mm
237.0
343.0
450.0
237.0
343.0
450.0
B
mm
145.0
145.0
145.0
278.5
278.5
278.5
C
mm
252.0
358.5
465.0
252.0
358.5
465.0
D
mm
57.15
57.15
57.15
190.5
190.5
190.5
E
mm
269.2
375.9
482.6
269.2
375.9
482.6
F
mm
179.4
179.4
179.4
312.7
312.7
312.7
Adaptor for horizontal rail mounting
쮿 For mounting e.g. small subracks, small wall mounted cases,
frame type plug-in units or PSUs on a horizontal rail with lip
쮿 Adaptor is bolted to the desired product and can then be clipped
to the lipped horizontal rail (DIN 43880)
Delivery comprises
Item
1
1
Qty
1
1
Description
Adaptor, Al extrusion, length 160 mm
Assembly kit
Order Information
Description
Part no.
11000-002
04812021
Example: Lipped horizontal rail adaptor for 19" PSU
11395007
6.91
ruggedDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days
Subracks – Drugged
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
06112020
Subracks/
Front panels,
06112004
"rugged" horizontal rail with 3 hole
fixing for increased stability (+60 %
compared to 2 hole fixing of
"heavy" horizontal rail)
Special adaptor rails allow
conducted cooled assemblies
to be fitted
06112052
Y-axis_001a1
Shock and vibration resistant in all
three axial directions
Standards/Approvals
Power supply
쮿 Internal and external dimensions in accordance
with:
IEC 60297-3-100, -101, - 102, -103, -104, -105,
IEEE 1101.1, IEEE 1101.10/11
쮿 Type of protection IP 20, in accordance with
IEC 60529
Backplanes . . . 10
쮿 EMC testing to IEC 61587-3
쮿 Shock and vibration test report;
MIL 167, IEC 61587 DL 3,
MIL 810 G, MIL 901
dB
120
100
80
60
40
Connectors, front
panel component
Note
쮿 Other finishes e.g. yellow chromated on request
쮿 Subrack with telescopic slides can be adapted for
cabinet mounting on request
400
800
1200
1600
2000
Mhz
EMC curve
06108081
6.92
Subracks – Drugged
Overview . . . . . . 6.92
19" subracks
ruggedDMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
쮿 Shock and vibration resistant up to 25 g
쮿 Kits or individually configured subracks
쮿 A product and accessory platform for the most different customers’ requirements and
applications
쮿 Suitable for CompactPCI and VMEbus insertion and extractor handles
쮿 EMC shielding can easily be retrofitted
쮿 3D PDF or CAD 3D data available for download
Kits
Kits . . . . . . . . . . . . 6.94
쮿 All required parts are available under one part number,
even partly assembled
쮿 Most popular versions and dimensions available from stock
쮿 For installed loads over 15 kg up to 60 kg
쮿 Supplied as a space-saving flat pack
06112017
ServicePLUS individual configuration
쮿 Single parts may individually be configured, respectively
assembled on request (from quantity 1)
Individual
configuration . . . 6.97
쮿 Wide range of variants in heigth, width and depth
쮿 Guide rails for different applications
쮿 EMC shielding material to improve EMC performance
쮿 Other accessories and assembly kits
06105058
ServicePLUS from page 6.95
user manuals, test reports)
ServicePLUS . . . . 6.95
Application
examples . . . . . . . . . 6.71
europacPRO . . . . 6.6
30407004
Subracks for
mobile railway
europacPRO for
industrial
6.93
Subracks – Drugged
Re
Kit, rugged, shielded,
ruggedDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatc h within 10 working days
쮿 Subrack with robust side panel and horizontal rail, type R
"rugged"
strip
쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz (as per
VG 95373, part 15), on condition that the front is closed with
sealed front panels
쮿 Shock and vibration resistant to 25 g
06112017
Illustration shows 3 U subrack
Item
1
Qty
3U
2
6U
2
Description
2
3
4
4a
4b
4c
4d
5
6
7
8
9
10
2
2
1
1
2
2
6
2
2
2
1
1
2
2
2
2
2
1
8
2
4
2
1
1
8
4c + 5 + 7
4d + 7
4 +5 + 6
4b + 5
1
9
2
3
1
4a + 5 + 6
8
06112055
6U
D2
D1
D
06112054
Side panel type R, Al, 3 mm, clear passivated,
with 19" support bracket 3.5 mm (tox-cold welded);
for EMC gasketing (textile)
Front handle incl. fixing material kit
Rear corner profile for EMC gasketing (textile)
Front horizontal rail (R-KD)
Front horizontal rail (R-LD)
Rear horizontal rail, centre (R-ST)
Rear horizontal rail, centre (ST)
Perforated strip (pre-fitted)
EMC cover plate, rugged, with top cover locking
EMC rear panel
EMC gasketing material, fixing material kit,
user manual
Order Information
Height
Width
Depth D
Depth D1
U
HP
mm
mm
3
84
295
175
6
84
295
175
Accessories
PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces
Torx panhead screw 2.5 × 9.3, zinc-plated,
PU 100 pieces; torque max. 0.2 Nm
Guide rail accessories for heavy PCBs, extra strong Al
extrusion, groove width 2 mm, 160 mm deep,
1 piece (SPQ 10)
Torx pan head screw 2.5 × 7.3, zinc flake coating, black,
Adaptor to accomodate conduction cooled assemblies
(CCA) for VPX applications, 160 mm deep, PU 1 pair;
includes fixing material kit
(CCA) for CompactPCI applications, 160 mm deep,
PU 1 pair; includes fixing material kit
Part no.
24567-149
24567-449
24560-351
24560-141
24560-255
34562-881
24560-157
24566-004
24566-005
24566-109
Note
04400001
strip
6.94
쮿 For further accessories see from page 6.19
Subracks – Drugged ServicePLUS
configuration
Simple. Fast. To the ideal product.
쮿 Configuration tables from page 6.96
assembly
modification
solution
쮿 Ready for dispatch within 10 working days
express
쮿 Express logistics
academy
rugged Servi cePLUS
Part number in bold face type: ready for despatch within 2 working days
6.95
Overview of individual components for shielded or unshielded subracks
4
2
1
6
5c
3
5b
2
5a
06108086
1
Part number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
Item
Description
Description
page
Item 1
Side panels
Establish the height and depth of the subrack;
Al, 3 mm, with universal hole positions for mounting of accessories
6.97
Item 2
Horizontal rails
Establish the width of the subrack;
Al extrusion, with defined hole positions for guide rails, grooves for threaded inserts, M4 thread at front,
functional rail shapes, basically differing with regard to their mechanical loading capacity:
rugged loading up to 15 kg
6.98
Item 3
Guide rails
Guide rails act as interface between subracks and boards, for different board formats,
are available in plastic or metal, optionally codable and optionally can be fitted with ESD clip to allow
electrostatic discharge
6.105
Item 4
Cover plates
Provide mechanical protection and/or EMC shielding and are perforated
6.108
Item 5
Rear/front
Rear hood (5a) or front panel (5b) with corner profile (5c) as support for EMC shielding gaskets used
in conjunction with shielded front panels;
Note: rear hood and corner profile cannot be fitted simultaneously
6.49
Item 6
Handles
Handles can be mounted on the 19" brackets
6.97
EMC shielding
(without
illustration)
Extensive component range for specific shielding of subrack according to your application
6.110
Internal mounting
(without
Universal assemblies, e.g. for horizontal and vertical mounting and for mounting plates
illustration)
6.96
6.109
6.60
ELECTRONICS PROTECTION
Side panel type R, EMC sealing, corner profile, front handle
rugged Servi cePLUSDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days
Order Information
EMC textile gasket
Corner profile, rugged
Front handle
120
Side panel type R for textile
gasket
06112059
04602054
06112058
06112057
Side panel, Al 3 mm,
tox-cold welded with
19" Al bracket,
3.5 mm with handle hole,
clear passivated,
front anodised;
please order front handles
separately
with CuNi coating,
UL 94 V-0,
temperature range -40 ... 70 °C
Al extrusion, 3 mm,
finish clear passivated;
with lateral grooves for
rear hood cannot be used
simultaneously
Die-cast Al profile,
powder-coated, RAL 9006;
load-carrying capacity 30 kg,
fixing material kit
PU 1 pair
PU 10 pieces
PU 1 pair
PU 1 kit
21101-853
24566-199
24566-010
21101-855
24566-499
24566-010
06112054 06112056
Height
Depth
U
mm
3
175
3
235
3
275
3
277.75
3
295
3
355
6
175
6
235
6
275
6
277.75
6
295
6
355
Fixing material kits see page 6.103
24568-145
24568-147
24568-143
24568-144
24568-149
24568-151
24568-445
24568-447
24568-443
24568-444
24568-449
24568-451
Side panel, type R
쮿 For high mechanical demands up to 25 g (vibration resistance,
shock and vibration requirements to e.g. IEC 61587-DL 3)
쮿 19" bracket is fixed firmly to side panel (tox-cold welded)
쮿 Depths 175, 235, 275, 277.75, 295 and 355 mm
쮿 EMC shielding concept for front/rear with EMC textile gasket
쮿 Other dimensions on request
6.97
Mounting position of horizontal rail/central rails
3 U (board depth 160, 220, 280 mm)
6 U (board depth 160, 220, 280 mm)
R-LD
R-ST / R-VT
R-KD
ST / VT
R-ST / R-VT
R-LD
R-ST / R-VT
D2
D = D1
R-LD
D2
D = D1
06112061
06112062
R-LD
H-KD
R-ST / R-VT
R-KD
H-KD
ST / VT
H-KD
R-ST / R-VT
R-ST / R-VT
R-LD
D2
R-LD
H-KD
D1
D2
D
D1
D
06112063
3 U (for CompactPCI/VME64x applications)
06112064
6 U (for CompactPCI/VME64x applications)
R-LD
H-LD
H-ST / H-VT
R-KD
H-KD
AB
H-ST / H-VT
AB
R-LD
H-LD
H-ST / H-VT
D3
D2
R-LD
D1
H-LD
D3
D2
D
D1
D
06112065
Horizontal rails
R-ST
06112070
R-VT
06112066
H-ST
06112071
H-VT
06112072
ST
06112073
VT
06112074
06112075
6.98
W
Front horizontal rails
Main Catalogue
Order Information
With long lip for insertion/
extraction of CompactPCI
and VME64x boards
and VME64x boards
With short lip
With short lip
"rugged"
Type R-LD
long lip
"heavy"
Type H-LD
long lip
"rugged"
Type R-KD
short lip
"heavy"
Type H-KD
short lip
bza44980
With HP markings from 28 HP,
Al extrusion, anodised finish,
conductive contact surface
Usable length
HP
Length
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
Cover strips to
cover the
horizontal rail
perforations
Al, untreated,
0.8 mm, length
431.5 mm, 1 piece
(SPQ 10)
Threaded inserts see page
06112004
06197008
06112013
06197008
conductive contact surface,
with HP markings
with HP markings
with HP markings
with HP markings
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34566-320
34560-320
34566-220
34560-220
34566-328
34560-328
34566-228
34560-228
34566-340
34566-342
34560-340
34560-342
34566-240
34566-242
34560-240
34560-242
34566-363
34560-363
34566-263
34560-263
34566-384
34566-301
34560-384
34560-301
34566-284
34566-201
34560-284
34560-201
34566-184
34566-184
6.104
6.103
6.104
6.103
6.104
6.103
6.104
6.103
1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ);
please order at least the SPQ quantity or a multiple
"heavy" load > 7.5 kg; "rugged" load > 15 kg;
Note
쮿 1000 mm version without M4 thread to front,
without printing and without notch for 19"-bracket
쮿 EMC gasket see page 6.56
쮿 For further horizontal rails see page 6.29
6.99
Rear horizontal rails
Main Catalogue
Order Information
For indirect backplane fixing
with insulation strip
For direct backplane fixing
04400001
"rugged"
Type R-ST
Standard
06105074
Usable length
Length
HP
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
Insulation strips see page
"heavy"
Type H-ST
standard
06112005
Al extrusion,
anodised finish,
conductive
contact surface,
with HP markings
04400002
"rugged"
Type R-VT
recessed
installation
06197011
Al extrusion,
anodised finish,
conductive
contact surface,
with HP markings
For direct fixing of connectors
in accordance with
EN 60603-2 (DIN 41612)
"heavy"
Type H-VT
recessed
installation
06112006
Al extrusion,
anodised finish,
conductive
contact surface,
with HP markings
04400003
"heavy"
Type H-MZ
with Z-rail
06197013
Al extrusion,
anodised finish,
conductive
contact surface,
with HP markings
1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1)
06197015
with HP markings
1 piece (SPQ 10)1)
34566-520
34566-528
34560-520
34560-528
34566-720
34566-728
34560-720
34560-728
34560-920
34560-928
34566-540
34560-540
34566-740
34560-740
34560-940
34566-542
34566-563
34560-542
34560-563
34566-742
34566-763
34560-742
34560-763
34560-942
34560-963
34566-584
34560-584
34566-784
34560-784
34560-984
34566-501
34560-501
34566-701
34560-701
6.104
6.104
6.103
6.104
6.104
6.103
6.104
6.103
6.104
6.103
6.104
6.103
Note
6.100
Rear horizontal rails, centre, for 6 U
Main Catalogue
Order Information
04400001
04400002
Type ST
06108090
Usable length
Length
HP
mm
28
147.32
40
208.28
42
218.44
63
325.12
84
431.80
1000
in accordance with
Type VT
06197016
04400003
Type MZ
06197017
06197018
Al extrusion, finish anodised,
conductive contact surface;
without markings
without markings
without markings
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
1 piece (SPQ 10)1)
34561-020
34561-028
34561-120
34561-128
34561-220
34561-228
34561-040
34561-140
34561-240
34561-042
34561-063
34561-142
34561-163
34561-242
34561-263
34561-084
34561-184
34561-284
34561-001
34561-101
34561-201
6.104
6.104
6.103
6.104
6.103
6.104
6.103
Note
쮿 All horizontal rails without printed markings
6.101
Horizontal rails (type AB) for rear I/O applications
Main Catalogue
Order Information
For CompactPCI in rear I/O area
12,75
AB
H - ST
9,75
15 12,75
H - KD
3
06108009
Type AB
H - ST
AB
H - KD
06108069
06197019
Al extrusion, finish anodised, conductive contact surface;
horizontal rail type AB (AB = support) is required to fix
the guide rails for the 80 mm rear I/O boards;
without markings
Usable length
HP
40
42
63
84
Length
mm
106.68
147.32
208.28
218.44
325.12
431.80
1000
1 piece (SPQ 10)1)
34561-520
34561-528
34561-540
34561-542
34561-563
34561-584
34561-501
6.103
Note
쮿 1000 mm version without M4 thread in end
6.102
Screws overview
Description
Material
Countersunk screw, with thread locking compound
Application: Rugged side panel to horizontal rail;
for area of tox-cold welded brackets and corner profiles
except when guide rail is fitted to slot 1
Dimension
Qty/PU
Part no.
Stainless steel M4 x 18
100
24566-100
if guide rail is fitted to slot 1
Stainless steel M4 х 14
100
24566-101
Panhead screw, with thread locking compound
not for area of tox-cold welded brackets and corner profiles
100
24566-102
Stainless steel M4 х 10
100
24566-103
Application: Rugged side panel to cover plate,
Stainless steel M4 х 8
100
24566-104
Torx countersunk screw , with thread locking compound
Application: : Rugged side panel to cover plate,
100
24566-106
Torx countersunk screw, with thread locking compound
Application: Rugged side panel to corner profile;
in EMC-shielded subracks and to increase robustness
Stainless steel M4 х 7
100
24566-105
Square nut
Zinc-plated
steel
100
24560-140
06712051
06712051
aza45940
06712053
06712053
06708053
06708053
M4
AZA45921
Note
쮿 Stainless steel screws; with organic surface layer (silver)
6.103
Subracks – Drugged
Threaded inserts, perforated strips, insulation strips
Main Catalogue
Order Information
Threaded insert
M2.5
M3
Perforated strip
Item 1
Insulation strip
5
2
5 ,0
8
06103056
BZA45853
Usable length
HP
Threaded insert
Perforated strip
Length
Length
mm
1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm
40
42
63
84
196
106.18
146.82
207.78
217.94
324.62
431.30
1000.26
34561-328
34561-340
34561-342
34561-363
34561-384
34565-196
34561-484
for insulated mounting of backplane;
PBT UL 94 V-0, grey
for centring shielded plug-in units,
Al, 1 mm, please order grub screw
separately
required for fixing the front panel to the horizontal rail;
St, zinc-plated; use collar screw 12.3 mm,
see page
6.66
34561-320
BZ6749
106.48
147.12
208.08
218.24
324.92
431.60
1000.26
1 piece
(SPQ 10)1)
30845-189
30845-197
30845-209
30845-211
30845-232
30845-253
34565-396
Insulation strip
Length
mm
101.50
144.20
205.12
210.40
316.88
428.64
PU 10 pieces
24560-820
24560-828
24560-840
24560-842
24560-863
24560-884
Accessories
Grub screw M2.5 x 8,
21100-276
PU 100 pieces
Grub screw M2.5 x 9,
21101-359
PU 100 pieces
Grub screw M3 x 8,
21100-646
PU 100 pieces
Part no. includes one packing unit (PU); delivery is exclusively made in PU
쮿 For fixing a subrack with dual fixing holes to 19" mounting
brackets (e.g. rugged and railroad subracks)
4
Delivery comprises
1
Item
1
2
3
4
1
2/3
2/3
Qty
4
8
8
8
4
Description
Double washer, stainless steel
M6 x 16 (Torx 30 drive)
M6 x 16 (Pozidrive)
Cage nut KM6
User manual
Order Information
Description
Part no.
24566-109
06113052
6.104
Subracks – Drugged
Adaptor to accommodate conduction cooled assemblies (CCA)
Order Information
Adaptor to accomodate conduction cooled assemblies (CCA) in subracks
06112022
Al die-cast, silver, can be screw-fixed, 0.8" pitch;
suitable for heavy and rugged horizontal rails, incl. fixing material kit
Board length
mm
160
VPX
PU 1 pair
CompactPCI
PU 1 pair
24566-004
24566-005
2) Part no. includes one packing unit (PU); delivery is exclusively made in PU
Guide rails for plug-in units and frame type plug-in units, one-piece,
groove width 2 mm and 2.5 mm
Main Catalogue
Order Information
For plug-in units and frame type plug-in units
"Standard"
Assembly
Plastic guide rail
- can be clipped into Al extruded horizontal rails
- can be clipped into 1.5 mm thick plates
Storage temperature
from -40 °C ... 130 °C
06102001
Board length
Groove width
Colour
mm
70
70
160
220
280
340
160
220
mm
2
2
2
2
2
2
2.5
2.5
mm
red
grey
red
red
red
red
red
red
up to 220 mm length, PBT, UL 94 V-0;
from 280 mm length, multi-piece, end piece PBT,
UL 94 V-0,
central section Al extrusion
PBT, UL 94 V-0
PU 10 pieces2)
1 piece (SPQ 50)1)
24560-351
24560-353
64560-001
64560-002
24560-379
24560-380
34579-230
34579-231
64560-096
Retention screw, PU 100 pieces;
Torque max. 0.2 Nm
24560-141
24560-141
ESD clip, PU 50 pieces
24560-255
24560-255
64560-098
Accessories
Description of accessories see from page 6.107
SCHROFF.PENTAIR.CO.UK
6.105
Guide rails for heavy assemblies, CompactPCI, VME64x
rugged Servic ePLUSDMAIN CATA LO GPart number in bold face type: ready for shipping wi thin 2 working daysPart number in norm al type: ready for shipping within 10 working days
Order Information
Assembly
horizontal rails
- can be clipped into1.5 mm thick
plates
For CompactPCI, VME64x with coding
In accordance with IEEE 1101.10 and Offset 0.1" for power supply units in
IEC 60297-3-103
IEC 60297-3-103
For heavy modules,
Al extrusion, silver,
robust version
Storage temperature
06106001
Board
length
mm
70
70
160
160
160
220
220
160
220
220
280
280
Groove
width
mm
2
2
2
2
2
2
2
2.5
2.5
2.5
2.5
2.5
Colour
mm
red
grey
red
grey
green
grey
green
grey
red
grey
red
grey
06106002
06102005
One-piece for groove width 2 mm, PBT,
UL 94 V-0;
multi-piece for groove width 2.5 mm,
end piece PBT, UL 94 V-0,
middle section Al extrusion
PBT, UL 94 V-0,
for installation of power supplies in
CompactPCI systems or
plug-in units with SMD placement
Al extrusion;
is screwed to
horizontal rail "heavy"
with retention screws
PU 10 pieces 2)
PU 10 pieces 2)
1 piece (SPQ 10)1)
24560-355
24560-360
24560-356
24560-358
34562-881
24560-359
34562-882
24561-331
24561-341
24560-255
24560-256
24560-256
24560-141
24560-141
24560-157
20817-501
20817-501
24561-330
24561-340
34562-883
34564-881
34564-882
34564-883
Accessories
ESD clips, PU 50 pieces
ESD clips, for alignment pin,
PU 50 pieces
Retention screw, PU 100 pcs.;
torque max. 0.2 Nm
Coding peg, PU 100 pieces
1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ);
please order at least the SPQ quantity or a multiple thereof
2) Order number includes one packaging unit (PU); delivery is exclusively made in PU
6.106
Main Catalogue
Order Information
ESD clips, CompactPCI/VME 64 alignment pin for guide
rails
Coding for plug-in components
Keying/coding
for CompactPCI, VME64x handles to IEEE 1011.10
and IEC 60297-3-103
06103052
04612052
Keying/coding peg, PBTP, UL 94 V-0, RAL 7035:
Spring steel, tin-plated, ESD clip, for alignment pin in accordance
The keying/coding pegs prevent plug-in units
with IEEE; can be plugged into the guide rails with coding and into
to be mounted in wrong slots.
the keying/coding block; provides conductive contact between the
They are inserted in the chambers of the
guide pin of the inserter/ extractor handle (IEL or IET handle) and
codable card guides as well as in the insertion/extraction handles
the horizontal rail
IEL or IET (4 possible positions),
resulting in 64 codings per card guide;
when coding the upper and lower card guide,
4096 codings will result;
PU 50 pieces 2)
Assembly
At the top/
at the bottom
PU 100 pieces 2)
24560-256
20817-501
Main Catalogue
Order Information
04503050
Spring steel, tin-plated, ensures conductive contact
between board and horizontal rail,
on both the solder side and the component side
Colour
Assembly
above/below
silver
PU 50 pieces
24560-255
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
6.107
Cover plates for bolting to rugged side panel
Order Information
Cover plate
for bolting to side panel
Stainless steel EMC gasket, between cover
D2
D1
D
06112054
Perforated Al plate, 1.2 mm,
hole diameter 4.0 mm, passivated,
perforation ratio 58 %, incl. retention screws;
4 stainless steel EMC contact strips per
subrack are required for shielding,
please order separately
06106052
clips into the horizontal rail and
forms the contact with the cover plate;
suitable for all horizontal rails
06197010
Width
HP
84
84
84
Depth D
mm
175
235
295
84
275
84
277.75
84
295
84
355
Application
PU 1 pair
160 mm board depth (D2)
220 mm board depth (D2)
280 mm board depth (D2)
160 mm board depth (D2) CompactPCI,
80 mm rear I/O
80 mm rear I/O
160 mm board depth (D2), approx.
120 mm clearance behind backplane
220 mm board depth (D2), approx.
PU 10 pieces
PU 100 pieces
24560-245
24560-246
24566-007
24560-271
24560-271
24568-004
24568-008
24568-012
24568-032
24568-036
24568-016
24568-020
Accessories
Cover plate latch, additional securing
for rugged cover plate,
PU 4 pieces
Assembly tool, to fit EMC gasket,
stainless steel, for horizontal rails,
1 piece
rugged Servic ePLUSDMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
Note
쮿 Cover plates without perforation available on request
쮿 Mounting position of horizontal rails, see page 6.98
6.108
Combined mounting (6 U and 2 x 3 U one above the other)
Main Catalogue
Order Information
Rugged struts
Front panel for textile EMC gasket,
6 U, 2 HP
Item 6
for combined mounting
06112077
bpa46550
6 U, die-cast zinc; fixing material kit
Al, 2.5 mm,
U-profile with notch,
6 U, 2 HP
PU 2 pieces
1 piece (SPQ 5)1)
24566-400
30849-140
21101-101
21101-102
21101-121
21101-855
06112076
Height
U
6
Accessories
Pozidrive/slotted collar screw
M2.5 x 12.3, St, nickel-plated, PU 100 pieces
M2.5, black, zinc-plated, PU 100 pieces
Washer
2.7 x 5 x 1, PA 6, PU 100 pieces
Textile gasket,
core: foam,
sleeve: textile cladding with CuNi coating,
UL 94 V-0, PU 10 pieces
Note
쮿 Rugged horizontal rails in various lengths, see page 6.99
6.109
EMC gaskets between front/rear panel and horizontal rail
Order Information
between front panel/rear panel and horizontal rail
06102053
stainless steel; for front and rear horizontal rails (type VT)
06102053
Width
HP
28
42
63
84
Depth
mm
131.8
202.9
304.5
416.6
PU 10 pieces
24560-231
24560-233
PU 100 pieces
24560-235
24560-236
24560-229
Main Catalogue
EMC gaskets between front panel and 19" bracket/corner profile
Order Information
Textile EMC gasket
between front panel/rear panel and 19" bracket/corner profile
06102056
06108054
textile gasket,
core: foam,
UL 94 V-0C
06105077
Height
U
3
6
Depth
mm
97.5
232.5
PU 10 pieces
PU 100 pieces
21101-853
21101-855
21101-854
21101-856
Main Catalogue
6.110
EMC gasket between horizontal rail and cover plate
Order Information
Stainless steel EMC gasket, between cover plate and horizontal rail
X
X
06106052
X
X
X
06102052
Width
HP
42
84
Depth
mm
202.9
416.6
PU 10 pieces
1 piece
24560-241
PU 100 pieces
24560-245
24560-246
24560-271
24560-271
EMC gasket between backplane and side panel
Order Information
between backplane and side panel (depth-offset installation)
bpa45916
2 x support profile, Al extrusion, 2 x stainless steel EMC gasket;
for vertical EMC shielding between depth-offset shielded backplane and side panel:
dimensions for 84 HP
A = 425.8 mm, B < 429.9 mm, C = 429.8 mm, D = 431.8 mm
06108078
Height
Depth
U
mm
3
97.5
6
187.5
M4 × 7, St, zinc-plated, PU 100 pieces
Square nut
M4, St, zinc-plated, PU 100 piece
With appropriate design, the backplane can be used as shielded
rear wall of the rack; in this case a rear horizontal rail (L-type VT or
H-VT) must be used for deeper installation to ensure the horizontal
contact.
PU 1 kit
24561-199
24561-499
24566-105
24560-140
For vertical contact the support profile can be fixed in the
standard way to the europacPRO side panel (depth grid 30 mm
6.111
OMain Catalogue
19" chassis – O
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
06005001
Standards/certifications
쮿 Exterior dimensions in accordance with: IEC 60297-3-100, 101, 105
Subracks/
쮿 Ingress protection IP 20 in accordance with IEC 60529
쮿 EMC testing in accordance with VG 95373 part 15 or IEC 61587
Front panels,
Power supply
Handles can be bolted on from
front
06008009
High stability with aluminium
profile side panel
06008010
Mounting plate for fitting heavy
components
06008011
Top cover and base plate in 3 versions
Backplanes . . . 10
Connectors, front
panel component
Plain
06008003
Perforated
06008005
06008004
For standardised board mounting
6.112
SCHROFF PRODUCT CATALOG E 05/2017
19" chassis – O
Overview . . . .
6.112
OMain Catalogue
The ideal solution for electronic devices in the most compact dimensions
쮿 Aluminium or steel (AlZn coated) designs
쮿 For standardised 19" board mounting or for installation of non-standardised components
쮿 EMC shielding upgradable
쮿 Mounting service and customized machining with ServicePLUS
19" complete chassis
쮿 2 materials
– Steel plate (AlZn coated)
– Aluminium
쮿 3 top cover versions
– Top cover/base plate, solid
– Top cover/base plate, perforated (aluminium version)
– Top cover/base plate for standardised PCBs (aluminium
version)
19" complete
chassis (St) . . . . .
6.114
19" complete
chassis (Al) . . . . .
6.115
06008005
19" chassis, individually configured from separate parts
쮿 For non-standardised assemblies with mounting plate
쮿 For standardised board assembly
쮿 Customised solutions
19" chassis for
nonstandardised
assembly . . . . . .
6.120
19" chassis for
standardised
6.122
06008001
Accessories
6.124
Telescopic slides
1 U . . . . . . . . . . . . 6.125
Telescopic slides
2U............
6.126
ServicePLUS from page 6.118
e.g. individual configuration and assembly
test reports)
e.g. custom solutions (special sizes)
30407004
ServicePLUS . .
6.118
Application
examples. . . . . . .
6.127
EL
FRONT PANEXPRESS
6.113
19" chassis – O
19" complete chassis from steel with
plain top cover and base plate
OMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days
쮿 Complete chassis, St (AIZn coated) with
Al extrusion front panel
쮿 Detachable rear panel for easy machining
쮿 EMV shielding approx. 20 dB(A) at 1 GHz without additional
shielding; > 40 dB(A) at 1 GHz with optional EMC gasketing
쮿 In accordance with standard IEC 60297-3-101
쮿 In the 1 U version 19" and ATX power supplies can be assembled
up to a clearance of 40 mm
06002003
4
Item
1
Qty
1
2
3
4
5
1
1
1
1
Description
Front panel, Al extrusion, 3 mm;
in 1 U: front anodised, rear etched;
from 2 U: front and rear side of front panels clear
passivated
Base body, plain, St, 1 mm, (AIZn coated)
Rear panel, St, 1 mm (AIZn coated)
Cover, plain, St, 1 mm (AIZn coated)
Assembly kit
Order Information
2
3
h
b
1
H
T
h = clear height (overall) (H - 3.0 mm)
b = clear installation width = 447 mm
06002051
Height
Height H
Depth T
U
mm
mm
1
43.7
220
1
43.7
280
1
43.7
340
2
88.1
280
2
88.1
340
Accessories
Front handles incl. assembly kit for 1 U, Al extrusion,
anodised, PU 2 pieces
Front handles incl. assembly kit for 2 U, Al extrusion,
EMC sealing to close the gap at the front between case and
front panel, 2 saw tooth gaskets, stainless
steel, PU 1 piece
Part no.
20860-120
20860-121
20860-122
20860-126
20860-127
20860-256
20860-257
20860-132
Note
쮿 Further versions with steel front panel (pizza box) available on
request
쮿 Telescopic slides cannot be used
쮿 No special EMC version available
쮿 Standardised internal mounting kits cannot be used
Front handle
06002052
ServicePLUS see page 6.118
6.114
19" chassis – O
19" complete chassis from aluminium with
O
쮿 Complete chassis from aluminium
쮿 EMC shielding of approx. 30 dB(A) at 1 GHz
(without additonal shielding material)
쮿 In accordance with standard IEC 60297-3-100, -101, -105
assembled up to a clearance of 35 mm
06008003
4
Item
1
Qty
1
2
3
4
5
1
1
1
2
6
1
Description
passivated
Rear panel, Al, 2 mm, etched
Base plate, plain, Al, 1 mm
Cover plate, plain, Al, 1 mm
Side panel, Al extrusion, raw; with grooves for threaded
insert (2 × 7); 5 U, two-piece, 3+2 U
Assembly kit
Order Information
3
2
5
b
h
1
H
T
h = clear height (overall) (H - 8.1 mm)
width = 403 mm
Front handle
06002052
06008052
Height
Height H
Depth T
U
mm
mm
1
43.7
220
1
43.7
280
2
88.1
280
2
88.1
340
3
132.6
280
3
132.6
340
3
132.6
400
4
177.0
340
4
177.0
400
4
177.0
460
5
221.5
460
EMC gasketing kit Silicone/nickel gasket 2100 mm for
contacting side panel/cover plate; seal, stainless steel,
for front panel/cover plate, 1 kit
Front handles incl. assembly kit for 3 U, Al extrusion,
Front handles incl. assembly kit for 4 U, Al extrusion,
Front handles incl. assembly kit for 5 U, Al extrusion,
Part no.
Kit
20860-601
20860-602
20860-605
20860-606
20860-607
20860-608
20860-609
20860-612
20860-613
20860-614
20860-615
20860-130
20860-256
20860-257
20860-258
20860-259
20860-260
Note
쮿 Threaded inserts to push into the side panel see page 6.121
쮿 Telescopic slides to mount into cabinet see page 6.125
6.115
19" chassis – O
perforated top cover and base plate
O
Item
1
Qty
1
2
3
4
5
1
1
1
2
6
1
06008005
4
3
2
5
b
h
1
H
T
width = 403 mm
Front handle
06008051
06002052
Description
passivated
Base plate, perforated, Al, 1 mm
Cover plate, perforated, Al, 1 mm
Assembly kit
Order Information
Height
Height H
Depth T
U
mm
mm
1
43.7
220
1
43.7
280
2
88.1
280
2
88.1
340
3
132.6
280
3
132.6
340
3
132.6
400
4
177.0
340
4
177.0
400
4
177.0
460
5
221.5
460
Part no.
20860-621
20860-622
20860-625
20860-626
20860-627
20860-628
20860-629
20860-632
20860-633
20860-634
20860-635
20860-130
20860-256
20860-257
20860-258
20860-259
20860-260
Note
6.116
19" chassis – O
19" complete chassis from aluminium, for assembly of
euroboards
O
06008004
4
3
2
5
b
h
1
H
T
width = 403 mm
06008050
Item
1
Qty
1
2
3
1
1
4
1
5
2
6
1
Description
Front panel Al extrusion, 3 mm;
passivated
Base plate, Al, 1 mm; with drilled holes for horizontal
Cover plate, Al, 1 mm; with drilled holes for horizontal
insert (2 × 7)
Assembly kit
Order Information
Height
Height H
Depth T
U
mm
mm
1
43.7
220
1
43.7
280
2
88.1
280
EMC gasketing kit PU 1 kit
Front handles for 1 U PU 2 pieces
Front handles for 2 U PU 2 pieces
Euroboard mounting kit for EN 60603 connector
for 1 U PU 1 kit
for 2 U PU 1 kit
Euroboard mounting kit for insulated backplane
mounting for 1 U PU 1 kit
mounting for 2 U PU 1 kit
Part no.
20860-641
20860-642
20860-645
20860-130
20860-256
20860-257
20860-115
20860-117
20860-116
20860-118
Note
Front handle
06002052
쮿 Guide rails see page 6.124
6.117
19" chassis – OServicePLUS
configuration
쮿 Configuration tables from page 6.119
assembly
modification
solution
express
쮿 Express logistics
academy
ServicePLUS
6.118
How to configure 19" aluminium chassis
ServicePLUS
쮿 Select height and depth of the basic kit
쮿 Select further components
For non-standardised assemblies (1 ... 5 U)
쮿 Mounting plate
쮿 Top cover/base plate
쮿 Front handles
쮿 EMC gasketing kit
쮿 Telescopic slides
Note
쮿 Non-standardised assemblies see from page 6.120
06006001
For standardised assemblies (1, 2 U) in accordance with
IEC 60297 -3-100, -101, -105
쮿 Top cover/base plate for horizontal board mounting
쮿 Internal connector or backplane fitting
쮿 Front handles
쮿 EMC gasketing kit
쮿 Telescopic slide
Note
쮿 Standardised assemblies from page 6.122
06002001
6.119
Individual components 19" chassis for non-standardised assemblies
쮿 Please select:
– Height and depth of basic kit (1 ... 5 U, item 1+2+5)
– Mounting plate
– Top cover/base plate (item 3+4)
– Front handles
– EMC gasketing kit
– Telescopic slides
쮿 In accordance with IEC 60297-3-105
Order Information
Basic kit
Mounting plate
plain
perforated
4
3
2
5
b
h
1
H
T
06008052
b = clear installation width = 403 mm
Height
U
1
1
1
2
2
2
3
3
3
3
4
4
4
4
5
6.120
Height
mm
43.7
43.7
43.7
88.1
88.1
88.1
132.6
132.6
132.6
132.6
177.0
177.0
177.0
177.0
221.5
Width
HP
84
84
84
84
84
84
84
84
84
84
84
84
84
84
84
Depth
mm
220
280
340
220
280
340
280
340
400
460
280
340
400
460
460
06002004
1 x Al front panel, 3 mm;
2 x extruded Al side panels;
1 x Al rear panel, 2 mm,
06002058
Al plate, 2 mm;
threaded insert, St, 2 mm,
zinc-plated, height 7 mm,
length 431.3 mm,
M3 hole clearance
1 HP = 5.08 mm;
for heavy equipment
06002053
is inserted into the basic kit,
Al, 1 mm, passivated;
please order EMC gasketing
kit separately
06007050
hole diameter 4 mm,
Depth
PU 1 kit
mm
1 piece
1 piece
1 piece
20860-201
20860-202
150
210
270
150
210
270
210
270
330
390
210
270
330
390
390
20860-107
20860-108
30860-501
30860-502
30860-510
30860-511
20860-109
30860-503
30860-512
20860-107
20860-108
30860-501
30860-502
30860-510
30860-511
20860-203
20860-210
20860-211
20860-212
20860-219
20860-220
20860-221
20860-222
20860-228
20860-229
20860-230
20860-231
20860-240
20860-109
30860-503
30860-512
20860-108
20860-109
30860-502
30860-503
30860-511
30860-512
20860-110
30860-504
30860-513
20860-111
20860-108
30860-505
30860-502
30860-514
30860-511
20860-109
30860-503
30860-512
20860-110
20860-111
30860-504
30860-505
30860-513
30860-514
20860-111
30860-505
30860-514
Order Information
Front handles
Threaded insert M3 for
extruded side panel
06002052
Height
U
1
1
1
2
2
2
3
3
3
3
4
4
4
4
5
Height
mm
43.7
43.7
43.7
88.1
88.1
88.1
132.6
132.6
132.6
132.6
177.0
177.0
177.0
177.0
221.5
Width
HP
84
84
84
84
84
84
84
84
84
84
84
84
84
84
84
Depth D
mm
220
280
340
220
280
340
280
340
400
460
280
340
400
460
460
EMC gasketing kit
Shielding upgrade of
approx. 30 dB
06007051
Assembly kit
for telescopic slides
esa44237
06094004
Assembly kit and adaptor
Gasket 2100 mm,
bracket for the
silicone/nickel, for contacting
cabinets VARISTAR,
side panel/ top cover and
eurorack, minirack;
base plate;
for mounting the
sawtooth gasket 400 mm;
19in. chassis on
stainless steel, for contacting
telescopic slides;
front panel/ top cover and
please order telescopic slides
base plate
separately
see page
6.125
Al extrusion, anodised,
incl. assembly kit
see page
5.108
St, 2 mm, zinc-plated,
height 7 mm,
length 431.3 mm,
M3 hole clearance
1 HP = 5.08 mm
PU 2 pieces
1 piece
PU 1 kit
PU 1 kit
30821-589
20860-130
20860-131
20860-256
20860-257
20860-258
20860-259
20860-260
Note
쮿 Further sizes available on request
쮿 Al extrusion side panels up to 1000 mm length available on
request
쮿 Telescopic slides see page 6.125
6.121
19" chassis for standardised 19" assemblies
쮿 Please select
– Height and depth of basic kit (1, 2 U, items 1+2+5)
– Top cover/base plate for horizontal board mounting
(items 3+4)
– Internal mounting for connector or backplane
– Front handles
– EMC gasketing kit
– Telescopic slides
쮿 In accordance with IEC 60297-3-100, 101, 105
Order Information
Basic kit
Mounting of euroboards
for EN 60603 connectors
assembly
4
3
2
5
b
6 HE / 6 U
6 HE / 6 U
h
1
3 HE / 3 U
3 HE / 3 U
H
T
06008052
Height
U
1
1
1
2
2
2
6.122
Height
mm
43.7
43.7
43.7
88.1
88.1
88.1
Width
HP
84
84
84
84
84
84
Depth D
mm
220
280
340
220
280
340
06002004
06008053
horizontal mounting of
euroboards
06003050
2 x front horizontal rails,
2 x rear horizontal rails with
Z, 2 x threaded inserts;
Sufficient for one 3 U board
or one 6 U board
06003051
2 x rear horizontal rails,
4 x threaded inserts,
4 x insulation strips PBT,
UL 94;
or one 6 U board
(6 HP for 1 U, 15 HP for 2 U)
PU 1 kit
1 piece
PU 1 kit
PU 1 kit
20860-201
30860-519
20860-115
20860-116
20860-202
20860-203
30860-520
30860-521
20860-115
20860-115
20860-116
20860-116
20860-210
30860-519
20860-117
20860-118
20860-211
20860-212
30860-520
30860-521
20860-117
20860-117
20860-118
20860-118
Order Information
Front handles
extruded side panel
06002052
Height
U
1
1
1
2
2
2
Height
mm
43.7
43.7
43.7
88.1
88.1
88.1
Width
HP
84
84
84
84
84
84
Depth D
mm
220
280
340
220
280
340
EMC gasketing kit
for shielding upgrade of
approx. 30 dB
06007051
Assembly kit
for fixing on
telescopic slides
esa44237
06094004
Gasket 2100 mm,
bracket for the
cabinets VARISTAR,
eurorack, minirack;
base plate;
for mounting the
19in. chassis on
telescopic slides;
base plate
separately
see page
6.125
incl. assembly kit
see page
5.108
height 7 mm,
length 431.3 mm,
M3 hole clearance
1 HP = 5.08 mm
PU 2 pieces
1 piece
PU 1 kit
PU 1 kit
30821-589
20860-130
20860-131
20860-256
20860-257
Note
request
6.123
Guide rails for boards without front panels, one-piece,
groove width 2 mm
Order Information
Guide rails
"Accessories"
Assembly
- can be clipped into horizontal rails
in Al extrusion
plate
Storage temperature
from -40 °C ... +130 °C
06102002
up to 280 mm length, PBT, UL 94 V-0;
> 280 mm length, multi-piece, end piece PBT, UL 94 V-0,
Board
length
mm
160
220
280
340
Groove
width
mm
2
2
2
2
Colour
mm
red
red
red
red
PU 10 pieces
2)
24560-373
24560-374
24560-375
24560-376
Retention screw,
PU 100 pieces
24560-141
Order Information
Board locking for PCBs
without front panel
04503050
component side
6.124
Board handle for board locking
04805050
to fix the PCB in the subrack
(also slot 1),
can also be used without
board handle,
minimum distance 3 HP
Identification strips
for board handle
04805051
06108076
Polyester film, 31 x 4 mm,
PBT, UL 94 V-0, red, insertion/
self-adhesive, white/matt
extraction function with
(1 A4 sheet contains 438 pieces)
connection to board locking
PBT, UL 94 V-0
(also slot 1), mounting directly
behind front panel (upper and
lower), minimum distance 3 HP
PU 50 pieces
PU 10 pieces
PU 10 pieces
1 piece
24560-255
24560-377
24560-378
60817-228
Universal 1 U telescopic slide
ServicePLUS
쮿 Static load-carrying capacity per pair 23 - 39 kg
쮿 Lateral mounting on the 19" uprights (19" plane remains free
for fixing the extension/drawer)
쮿 Can be removed
쮿 Extension length > 100 %
쮿 Rail width k = 9.7 mm,
max. installation width of extension/drawer w = 429 mm
Delivery comprises
Item
1
Qty
2
Description
Telescopic slide, St, zinc-plated
Order Information
Length L
00505011
mm
356
406
457
508
559
610
660
711
Extension length
Y
mm
381
432
483
533
584
635
686
737
Load-carrying
capacity P
kg
39
36
34
32
29
27
23
23
Part no.
20110-090
20110-091
20110-092
20110-093
20110-094
20110-095
20110-096
20110-097
Note
쮿 For mounting into Schroff cabinets please order assembly kit
separately, see page 6.123
00505060
k = rail width, w = max. installation width
Dimensions table
L
356
406
457
508
559
610
660
711
A
29.5
29.5
29.5
89.9
89.9
89.9
7.4
7.4
B
92.1
92.1
92.1
92.1
92.1
92.1
92.1
92.1
C
184.2
184.2
184.2
184.2
184.2
184.2
184.2
184.2
Internal part
D
E
276.2 276.2 276.2 276.2 368.3
276.2 368.3
276.2 368.3
276.2 368.3
276.2 368.3
F
460.4
460.4
G
552.4
552.4
X
349.3
349.3
349.3
501.7
501.7
501.7
603.3
603.3
External part
O
P
Q
304.6 317.3 330.0
355.4 368.1 380.8
406.4 419.1 431.8
457.4 470.1 482.8
508.1 520.8 533.5
558.6 571.3 584.0
609.4 622.1 634.8
660.2 672.9 685.6
00505055
6.125
Universal 2 U, slim telescopic slide
Main Catalogue
쮿 Static load-carrying capacity per pair 46 - 57 kg
쮿 Locking at full extension
쮿 Extension length > 110 %
쮿 Rail width k = 9,7 mm,
Delivery comprises
Item
1
Qty
2
Description
Order Information
Length L
00505009
0050506000505059
356
406
457
508
559
584
610
A
101.6
127.0
127.0
152.4
203.2
203.2
203.2
Internal part
w
C
184.2
304.8
209.6
355.6
235.0
406.4
260.4
457.2
412.8
508.0
431.8
533.4
438.2
558.8
X
356.0
406.0
457.0
508.0
559.0
584.0
610.0
Load-carrying
capacity P
kg
57
55
55
55
46
46
46
mm
356
406
457
508
559
584
610
Accessories
Assembly kit for VARISTAR,
for assembly of 2 telescopic slides, PU 1 kit
Assembly kit for eurorack,
Telescopic slides mounting kit for NOVASTAR,
to mount 2 telescopic slides, PU 1 kit
Delivery: supplied loose with cabinet or frame
Dimensions table
Length L
Extension length
Y
mm
432
483
533
584
635
660
686
D
101.6
127.0
152.4
152.4
177.8
177.8
203.2
External part
E
228.6
254.0
279.4
330.2
355.6
381.0
381.0
Part no.
20110-071
20110-072
20110-073
20110-074
20110-075
20110-076
20110-077
21120-161
21120-162
21120-163
Part no./35
Note
F
330.2
381.0
431.8
482.6
533.4
558.8
584.2
쮿 To mount on 19" plane please order assembly kit separately
쮿 Universal telescopic rails can also be fitted without additional
components in non-standard applications, thus also in other
than 19" cabinets
00505059
6.126
Text
Application: Different cut-outs
Application: 2 U version with 2 x 3 U assembly
Application: 1 U multipacPRO complete from steel plate;
front panel in aluminium with cut-outs
06002006
06002005
06108007
Application: Combined 3 U and 6 U assembly
06002007
06008006
Application: 1 U multipacPRO (pizza box) complete from steel
plate; 19" brackets can be removed if required
printed 19" front panel in aluminium with cut-outs
06101008
6.127
FMai n C atalogue
19" chassis – F
Content
Cabinets . . . . . . 1
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
cases . . . . . . . . . 5
02192001
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
Robust 19" chassis, also for board assembly
Systems . . . . . . . 8
02192005
Assembly with boards and hinged front panel
02196001
Standards
쮿 External dimensions in accordance with:
IEC 60297-3-101
쮿 Ingress protection IP 20 to IEC 60529
Power supply
units . . . . . . . . . . 9
쮿 GND/earthing connectors to:
DIN EN 50178/VDE 0160
DIN EN 60950/VDE 0805
DIN EN 61010-1/VDE 0411 part 1
DIN EN 61010-1A2/VDE 0411 part 1/A1
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
Appendix . . . . . 12
6.128
SCHROFF PRODUCT CATALOG E 05/2016
19" chassis – F
Overview . . . . . . . 6.128
FMain Catalogue
19" chassis with high mechanical stability
쮿 Also usable as desk-top case
쮿 Robust cases from aluminium die-cast frames to front and rear
쮿 Flexible assembly for standardised board formats or individually,
e.g. for mounting plates
쮿 Cost benefit with mounting service and custom processing in ServicePLUS
19" chassis/desk-top enclosure
inpac
쮿 2 U, 3 U, 4 U and 6 U heights
19" chassis . . . . . . . 6.130
Accessories
Full-width front
panels . . . . . . . . . . . 6.131
Full-width rear
Support rails . . . . . 6.132
Horizontal rails . . . 6.132
Front handles . . . . 6.133
02192002
GND/
earthing kit . . . . . . 6.133
inpac built into 19"cabinet
Text
Guide rails . . . . . . . 6.134
Dimensions . . . . . . 6.136
02192003
ServicePLUS . . 6.118
e.g. individual configuration and assembly from
1 piece
e.g. printing
e.g. cut-outs in front or rear panels or cover plates
e.g. modification (special colours)
e.g. custom solutions (special depths,
electromagnetically shielded applications)
30407004
www.schroff.biz/ServicePLUS
6.129
19" chassis – F
19" chassis
FMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days
쮿 For assembly with 19" components or individually with
mounting plates
쮿 Three rows ventilation slots in base for air inlet
Delivery comprises (Kit)
02192006
Item
1
Qty
2
2
1
3
4
1
1
5
1
6
7
4
1
Description
Side panel, Al extrusion, RAL 7030,
at 6 U: 2 Al corner profiles,
1 divider plate (steel plate)
Front frame, Al die-cast, RAL 7030, rear side with
counterbores for drill holes to mount handles and
front panels
Rear frame, Al die-cast, RAL 7030
Cover plate, St, 1 mm, RAL 7035, plastic-coated,
with GND/earthing connection
Base plate, St, 1 mm, RAL 7035, plastic-coated,
Case foot with anti-slip protection, PC, UL 94 V-0
Assembly kit
Order Information
ipa30632
h1 = useable height
Height H
U
2
2
2
3
3
3
3
4
4
4
4
6
6
Height H
mm
88.0
88.0
88.0
132.5
132.5
132.5
132.5
177.0
177.0
177.0
177.0
265.9
265.9
h
mm
86.0
86.0
86.0
130.5
130.5
130.5
130.5
174.5
174.5
174.5
174.5
263.5
263.5
h1
mm
57.5
57.5
57.5
102.0
102.0
102.0
102.0
146.5
146.5
146.5
146.5
235.4
235.4
h2
mm
76.2
76.2
76.2
57.1
57.1
57.1
57.1
101.6
101.6
101.6
101.6
190.5
190.5
Depth D
mm
254.5
314.5
374.5
254.5
314.5
374.5
434.5
254.5
314.5
374.5
434.5
374.5
434.5
Part no.
10828-071
10828-072
10828-073
10828-051
10828-052
10828-053
10828-054
10828-056
10828-057
10828-058
10828-059
10828-068
10828-069
IPA30635
Note
쮿 Max. installation space when fitting 19" components is 75 HP
쮿 Scope of delivery includes screws to fix rear and front panels
IPA30704
IPA30706
6.130
19" chassis – F
Front panel
F
Delivery comprises
Item
1
Qty
1
Description
Front panel, Al, 2.5 mm, anodised, cut edges
untreated
Order Information
Height
U
2
3
4
6
IPA42082
Height H
mm
76.0
120.5
165.0
253.8
h1
mm
65.6
110.0
154.5
243.4
Part no.
30828-055
30828-058
30828-061
30828-067
Note
쮿 The assembly kit for the front panel is included with the 19"
chassis
Front panel, bottom-hinged
F
Delivery comprises
Item
1
Ø 5,9 x 3,3
Qty
1
Description
Front panel, hinged, Al, 2.5 mm, anodised, cut edges
untreated
Order Information
Height
Height H
h1
U
mm
mm
2
76.0
54.5
3
120.5
99.0
4
165.0
143.5
6
253.8
232.3
Hinge for front panel PPE, UL 94 V-0,
PU 1 kit (includes fixing material kit and 2 collar screws)
ipa42083
Part no.
30828-085
30828-088
30828-091
30828-097
20828-028
Note
쮿 Please order hinge for front panel separately
Rear panel with ventilation openings
F
Delivery comprises (kit)
Item
1
Qty
1
Description
Rear panel, incl. assembly kit, Al, 2.5 mm, anodised,
cut edges untreated
Order Information
Height
U
2
3
4
6
IPA42086
Height H
mm
76.0
120.5
165.0
253.8
h1
mm
65.6
110.0
154.5
243.4
h2
mm
30
Part no.
30828-070
30828-073
30828-076
30828-082
Note
쮿 The scope of delivery of the 19" chassis includes an assembly
6.131
19" chassis – F
Support rail for guide rails
F
쮿 4 support rails to fix PCBs with guide rails
2
쮿 Support rail can also be used to fix a custom mounting plate
3
Order Information
1
Item
Description
front support rail, St, 1.5 mm, blue-passivated,
1
1 piece
rear support rail, St, 1.5 mm, blue-passivated,
2
1 piece
Accessories
Guide rail 160 mm (Item 3), PBT, UL 94 V-0, with
integrated fixture for connector to EN 60603 (DIN 41612),
PU 1 pair
Guide rail 220 mm (Item 3), PBT, UL 94 V-0, with
PU 1 pair
Screw for mounting of support rails, M4 × 8, flathead bolts
with posidrive, PU 100 pieces
4T
E
IPA30639
Part no.
30828-165
30828-174
60817-078
60817-079
21100-677
쮿 Guide rails see page 6.134
a3-308xx
Dimension drawing top: Front support rail,
dimension drawing bottom: rear support rail;
1) bush M4, pressed-in
Horizontal rail for guide rails,
backplane and connector mounting
F
쮿 4 horizontal rails to fix guide rails (for PCBs) and for backplane
3
2
쮿 Useable width 75 HP
1
h
Order Information
2
1
Item 1: horizontal rail, item 2: Z-rail, item 3: threaded insert
h
U
2
3
4
6
Bolt-on dimension of backplane
mm
75.40
119.80
164.30
252.90
2) bush M4, pressed-in
6.132
IPA30640
Item Description
Qty/PU
Horizontal rail 75 HP, Al extrusion,
1
1
anodised
Accessories
Z-rail (item 2), Al extrusion, anodised, 1 piece
Threaded insert (item 3), St, zinc-plated (blue), 1 piece
Screw to fix horizontal rails, M4 × 8,
Pozidrive flathead screw, 100 pieces
Cheesehead screw with slot M2.5 × 6, DIN 84,
PU 100 pieces M2.5 × 6, DIN 84, 100 pieces
Part no.
30828-128
30814-513
30819-604
21100-677
21100-146
Note
쮿 Threaded inserts cannot be used at front
쮿 For backplane mounting, threaded inserts are required in the
쮿 For connector mounting, threaded inserts and Z-rails are
required in the rear horizontal rails
A4-587
19" chassis – F
Front handles
F
쮿 Load-carrying capacity 35 kg per pair
Item
1
Qty
2
Description
Front handle, Al die-cast, powder-coated, RAL 7030,
incl. assembly kit
Order Information
Height
U
3
4
6
IPA30636
Part no.
20828-127
20828-128
20828-129
27
44
02108050
GND/earthing kit
F
쮿 The GND/earthing kit allows VDE-compliant earthing of the
case to:
– DIN EN 50178/VDE 0160
– DIN EN 60950/VDE 0805
– DIN EN 61010-1/VDE 0411 Part 1
– DIN EN 61010-1A2/VDE 0411 Part 1/A
쮿 VDE inspection has been carried out
Order Information
Description
Qty/PU
GND/earthing kit, Cu wire, 1.5 mm 2, PVC sleeve,
green/yellow, links side panels, top cover, base 1
plate and rear panel
Part no.
21100-814
aza43284
6.133
19" chassis – F
Guide rails
04292012
Order Information
a4-2744X
Board
lengths
mm
mm
100
160
160
180
220
220
280
340
400
Groove
width
mm
mm
2
2
2.5
2
2
2.5
2
2
2
A42744b
a42744c
bza44247
a4-2744d
Light version,
snap-in
Standard
version,
snap-in
Version with
board fixing,
snap-in
Version with
board fixing,
bolt-on
Version for
heavy
load-carrying
capacity,
snap-in
Version with
ESD clip
Universal
version with
Al middle
section,
bolt-on
Part no.
Part no.
Part no.
Part no.
Part no.
Part no.
Part no.
1 piece (SPQ
50)1)
1 piece (SPQ
50)1)
1 piece (SPQ
50)1)
1 piece (SPQ
50)1)
1 piece (SPQ
50)1)
Qty/PU
1 piece
Qty/PU
1 piece
60817-064
60817-015
60817-103
60817-001
60817-053
60817-102
20817-368
60817-076
60817-149
60817-026
60817-016
60817-083
60817-085
20817-369
60817-098
60817-080
20825-120
20825-121
Accessories
Spring clip PPE, UL 94 V-0, red, PU 10 pieces
Spring clip PPE, UL 94 V-0, red, PU 100 pieces
Assembly parts for 50 guide rails PU (100 screws, 100 nuts)
21100-553
21100-553
21100-554
21100-554
21101-990
21101-990
Note
쮿 For a detailed description of the guide rails see our website;
please enter part number in "oneclick" search
6.134
19" chassis – F
PCB handle A
쮿 To be mounted behind front panel, for PCB thickness 1.6 mm
쮿 Insertion and extraction function
쮿 Can be labelled
Order Information
Item Description
B4-2728
Material
Colour
1
PCB handle A PBT, UL 94 V-0 red
2
Pivot pin DIN 7 Stainless steel –
Identification Polyester film, mattstrip
self-adhesive silver
3
Qty/PU
1 piece
(SPQ 10)
100
Part no.
60817-096
100
21100-672
21100-671
SPQ (Standard Pack Quantity): Part number includes 1 piece,
but delivery is exclusively made in standard pack quantity:
Please order at least 10 pieces PCB handles or a multiple
BZA42727 BZA42724
PCB retainer A
쮿 Can also be used without PCB handle
쮿 Application on top and bottom horizontal rail
Order Information
Item Description
PCB retainer A for
4
top and bottom
C4-2728
Material
PPE,
UL 94 V-0
Colour Qty
1 piece
red
(SPQ 10)
Part no.
60817-097
but delivery is exclusively made in Standard Pack Quantity:
Please order at least 10 pieces PCB retainers or a multiple
PCB retainer B
쮿 Can be used on upper and lower horizontal rail,
쮿 Can also be used with guide blocks
Order Information
Item
4
BZA46428
4a
Description
PCB
retainer,bottom
Material
Colour
PPE, UL 9
red
4 V-0
PPE, UL 9
black
PCB securing top
4 V-0
Qty
1 piece
(SPQ 10)
1 piece
(SPQ 10)
Part no.
60817-054
60817-071
6.135
19" chassis – F
Dimensions
19" front frame
A3--306
Section A-A
There are counterbores at the rear side of the front frame which can be drilled if required:
1) For handle mounting
2) For mounting of partial-width front panel (grid 5.08 mm)
19" rear frame
A3-305
Section A-A
Dimensions table
Height
in U
2
3
4
6
6.136
H
88,0
132.5
177.0
265.9
Text
HR
86,0
130.5
175.0
263.9
h
57,5
102.5
146.5
235.4
h1
77,3
121.8
166.3
255.2
h2
69,8
114.3
158.8
247.7
h3
25,0
90,0
134.5
233.4
h4
76.2
57.1
101.6
190.4
h5
65,5
110.0
154.5
243.4
h6
68,0
112,5
157,0
245,9
h7
68,4
112.8
157.3
245,9
19" chassis – F
Dimensions
Side panel
“Y”
Y
A3--304a
Detail "Y"
A3--304b
Dimensions table
Height
in U
2
2
2
3
3
3
4
4
4
6
6
6
H
82,6
82,6
82,6
127.0
127.0
127.0
171,0
171,0
171,0
260,4
260,4
260,4
Text
h1
24,0
24,0
24,0
68,5
68,5
68,5
157,1
157,1
157,1
h2
68,0
68,0
68,0
112,5
112,5
112,5
157,0
157,0
157,0
245,9
245,9
245,9
h3
71,4
71,4
71,4
115,8
115,8
115,8
160,3
160,3
160,3
248,9
248,9
248,9
h4
59,0
59,0
59,0
103,5
103,5
103,5
148,0
148,0
148,0
236,5
236,5
236,5
L
220,5
280,5
340,5
220,5
280,5
340,5
220,5
280,5
340,5
220,5
280,5
340,5
L1
140,5
200,5
260,5
140,5
200,5
260,5
140,5
200,5
260,5
140,5
200,5
260,5
(n)
17,0
23,0
29,0
17,0
23,0
29,0
17,0
23,0
29,0
17,0
23,0
29,0
Y
170
230
290
170
230
290
170
230
290
170
230
290
T
254,5
314,5
374,5
254,5
314,5
374,5
254,5
314,5
374,5
254,5
314,5
374,5
6.137
Main CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days
Front panels, plug-in units, frame-type plug-in units
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Front panels
쮿 Extensive standard range
쮿 Individual modification to customer
requirements:
drill holes, cut-outs
쮿 Individual printing
쮿 Front Panel Express
Climate control . 4
Electronics
Subracks/
Plug-in units
쮿 Front panels with handles in various designs
– Extensive standard range
– Individual modification to customer requirements: drill holes, cut-outs
– Individual printing
– Front Panel Express
Front panels,
Power supply
Backplanes . . . 10
Connectors, front
panel component
7.0
SCHROFF Main catalogue
Downloads und weitere wichtige Informationen finden Sie
im Internet unter www.schroff.biz
www.schroff.biz E 05/2016
36106003 (09292001 04612001)
Frame-type plug-in units
쮿
쮿
쮿
쮿
To hold and protect PCBs
High stability
Outstanding cooling
With or without EMC shielding
Overview . . . . . . 7.0
Front panels . . 7.2
Plug-in units . . 7.16
Frame type
plug-in units . . 7.64
minipac . . . . . . . 7.98
PCB
accessories . . . 7.102
minipac
Assembly
material . . . . . . . 7.107
쮿 Convenient small case - flexible
enough for all your requirements
쮿 To accommodate nonstandardised or standardised
PCBs
쮿 As desktop enclosure, for wall
mounting or mounting on a DIN
support rail
Modules to mount
drive units
see chapter
System
Accessories . . 8.110
Accessories
쮿 Brackets, handles, covers
쮿 Assembly material
쮿 Tools
36106004 (04802002 04812001 11092008 04995001)
7.1
Front panelsMai n C atalogue
Front panels
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
04292001
Standards
쮿 IEC 60297-3-101/IEEE 1101.1/10
ServicePLUS
Subracks/
e.g. individual colouring
e.g. customised cut-outs
e.g. printing
e.g. mounting service
e.g. special dimensions
Front panels,
www.frontpanelexpress.eu
30407004
EL
FRONT PANE
XPRESS
Power supply
Backplanes . . . 10
Connectors, front
panel component
32304003
04210001 04603009
7.2
Front panels
Overview . . . . . . 7.2
Front panels
Front panels for fitting in subracks, cases and systems
쮿 Extensive standard range with various finishes and materials
(aluminium or stainless steel)
쮿 Front Panel Express:
Fast delivery service of customised versions (from 2 days)
쮿 EMC shielding retrofittable
Main Catalogue
Front panels, unshielded
Front panels
쮿 Aluminium, clear anodised
Unshielded . . . . . . 7.4
쮿 Aluminium, clear pre-anodised, cut edge untreated
EMC stainless
steel gaskets . . . . 7.6
쮿 Aluminium, front anodised, rear iridescent green
chromated
Shieldable . . . . . . . 7.5
Assembly tool . . . . 7.6
쮿 Other finishes on request
04292001
Front panels shieldable, flat
Text
쮿 With lateral grooves to fit EMC gaskets (stainless steel)
쮿 Compatible with the shielded U profile version
Front panels
Shieldable
(U profile) . . . . . . . . 7.7
04600006
Front panels, shieldable, U profile
Text
EMC textile
gasket . . . . . . . . . . . 7.6
쮿 With lateral groove to fix a textile self-adhesive
EMC gasket
Further front panels
쮿 Compatible with the shielded flat version
Hinged, shielded . 7.9
쮿 High robustness through U profile
Hinged . . . . . . . . . . 7.8
For D-Sub
connectors . . . . . . 7.10
For Coax
connectors . . . . . . 7.11
3 U with GND/
earthing . . . . . . . . . 7.11
04602004
Text
Mezzanine front
panels . . . . . . . . . . . 7.12
쮿 Hinged/folding front panels
쮿 Front panels with GND/earthing
Assembly kit . . . . . 7.107
쮿 Mezzanine front panels
AdvancedTCA
front panels . . . . . . 8.12
쮿 AdvancedTCA front panels
MicroTCA front
panels . . . . . . . . . . . 8.65
쮿 MicroTCA front panels
AdvancedMC front
panels . . . . . . . . . . . 8.60
쮿 AdvancedMC front panels
04295001 04295002
7.3
Front panels
Front panelsMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatch within 10 working days
쮿 Front panel, Al, 2.5 mm
B
b1
9.8
7.45
쮿 Versions:
– Al, anodised
– Al, anodised, cut edges plain
– Al, front anodised, rear iridescent green chromated
b2
H
H
3
7.45
Note
3
3.3
쮿 Other sizes and finishes available on request
쮿 Please order fixing material separately, see chapter Assemply
parts, page 7.107
2 HP
2.5
2.5
ø 5.9
04602084
04602051
> 2 HP
Order Information
Height H
Width
B
b1
b2
U
1
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
9
HP
84
84
2
3
4
5
6
7
8
10
12
14
21
28
42
63
84
84
2
4
5
6
7
8
10
12
14
16
21
28
42
63
84
84
mm
426.4
426.4
9.8
14.9
20.0
25.0
30.1
35.2
40.3
50.5
60.6
70.8
106.3
141.9
213.0
319.7
426.4
426.4
9.8
20.0
25.0
30.1
35.2
40.3
50.5
60.6
70.8
80.9
106.3
141.9
213.0
319.7
426.4
426.4
mm
411.5
411.5
25.4 2)
35.6
45.7
55.9
91.4
127.0
198.1
304.8
411.5
411.5
25.4 2)
35.6
45.7
55.9
66.0
91.4
127.0
198.1
304.8
411.5
411.5
mm
203.2
203.2
101.6 2)
157.5
203.2
203.2
101.6 2)
157.5
203.2
203.2
mm
39.5
84.0
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
172.9
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
395.1
Qty
1)
1
1
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
Anodised,
cut edges plain
Part no.
Anodised
Part no.
Front anodised, rear
colorless chromated
Part no.
30818-271
30807-416
20850-426
30847-461
30810-433
30810-432
30847-470
30818-272
30818-273
30807-508
30807-481
30847-471
30838-043
30818-274
30807-510
30838-044
30818-275
30818-276
30807-482
30807-509
30838-045
30838-046
30818-277
30807-484
30838-047
30818-279
30818-281
30807-483
30807-485
30838-049
30838-051
30818-282
30807-501
30838-053
30818-289
30818-296
30807-487
30807-496
30838-060
30838-067
30818-310
30807-494
30838-081
30818-331
30818-352
30808-067
30807-506
30838-102
30838-123
30818-434
30807-596
30847-465
30818-747
30818-518
30818-741
30807-778
30847-472
30838-124
30818-519
30807-777
30838-125
30818-520
30818-521
30807-752
30838-126
30838-127
30818-522
30807-779
30838-128
30818-524
30818-526
30807-753
30807-755
30838-130
30838-132
30818-528
30807-758
30838-134
30818-530
30818-535
30807-780
30807-757
30838-136
30838-141
30818-542
30807-766
30838-148
30818-556
30818-577
30807-764
30807-771
30838-162
30838-183
30818-598
30807-776
30838-204
30847-556
2) This dimension is only available for "front anodised, rear iridescent green chromated" version
쮿 Please order fixing material (sleeves, collar screws) separately,
see page 7.107
7.4
Front panels
Front panels
M 2.5
1.8
7.45
X
쮿 Front panel, Al, 2.5 mm, front anodised, rear iridescent green
chromated, 2 alignment pins pressed-in, stainless steel
X
쮿 Shielding with stainless steel EMC gasket
10.7
9.8
Order Information
H
R 11
0.65
Y
2.5
1
2.5
3
1.8
Y
04602052
2 HP
5.08
b2
X
H
3
7.45
B
b1
Height H
U mm
Width B
HP
mm
b1
mm
b2
mm
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
9
84
2
3
4
5
6
7
8
10
12
14
21
28
42
63
84
84
2
4
5
6
7
8
10
12
14
16
21
28
42
63
84
84
411.5
25.4
35.6
45.7
55.9
91.4
127
198.1
304.8
411.5
411.5
25.4
35.6
45.7
55.9
66
91.4
127
198.1
304.8
411.5
411.5
203.2
101.6
157.5
203.2
203.2
101.6
157.5
203.2
203.2
84
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
172.9
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
395.1
426.4
9.8
14.9
30.1
35.2
40.3
50.5
60.6
70.8
106.3
141.9
213
319.7
426.4
426.4
9.8
30.1
35.2
40.3
50.5
60.6
70.8
80.9
106.3
141.9
213
319.7
426.4
426.4
Alignment
pin
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
Qty
1
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
Part no.
30846-588
30846-864
20846-425
20846-426
20846-427
20846-428
20846-429
20846-430
20846-431
20846-432
20846-433
20846-434
20846-436
20846-437
20846-438
30846-676
30846-683
30846-865
20846-443
20846-444
20846-445
20846-446
20846-447
20846-448
20846-449
20846-450
20846-456
20846-451
20846-452
20846-453
20846-454
30846-771
30846-859
3.3
Delivery is exclusively made in Standard Pack Quantity (SPQ):
Please order at least 5 pieces or a multiple.
Pricing is per individual item.
ø 5.9
Note
Y
2.5
5
ø 2.5
> 2 HP
see page 7.107
쮿 Please order stainless steel EMC gasket separately,
see page 7.6
04608154
Part number in normal type: ready for despatch within 10 working days
7.5
Front panels
Front panels
쮿 The stainless steel EMC gaskets are inserted into the lateral
slots of the shieldable front panels (2 pieces per front panel)
Delivery comprises
Item
1
Qty
Description
10/100 EMC gasket (stainless steel)
Order Information
bga45760
Montagewerkzeug
Height
Height
Qty/PU
U
mm
2
52
10
3
97
10
3
97
100
4
142
10
4
142
100
5
187
10
5
187
100
6
232
10
6
232
100
9
367
10
9
367
100
Assembly tool for EMC gasket (stainless steel), 1 piece
Part no.
21101-775
21101-705
21101-706
21101-713
21101-714
21101-777
21101-778
21101-707
21101-708
21101-709
21101-710
24560-270
Note
쮿 Please order assembly tool separately
aza45937
Textile EMC gasket
쮿 Textile EMC gasket is glued laterally on the front panel,
in the groove of the right-hand profile
쮿 2 temperature ranges
– Temperature range -40... +70 °C
– Temperature range -40... +85 °C
Delivery includes
Item
1
04602054
EMC characteristic (typical, green)
B1 (red): -40 ... -70 °C, B2 (blue): -40 ... -85 °C
Qty
see Order
Information
Description
EMC textile gasket,
core: TPE foam (-40... +70 °C),
Core: silicon with hollow chamber (-40... +85 °C),
Order Information
Height Height Qty/PU
U
mm
piece
2
3
3
4
5
6
6
9
9
52
97
97
142
187
232
232
365
365
10
10
100
10
10
10
100
10
100
Part no.
Part no.
Temperature range
-40... +70 °C
Temperature range
-40... +85 °C
21101-857
21101-853
21102-857
21102-853
21101-854
21102-854
21101-858
21101-978
21102-858
21102-978
21101-855
21102-855
21101-856
21101-859
21102-856
21102-859
21101-904
04614052
7.6
Front panels
Front panels, U profile, shieldable
2 HP
3U
7.45
5.08
Front panels
쮿 High stability through U profile
9.8
7.45
5.08
14.9
쮿 Front panel, U profile, Al, front anodised, rear conductive,
쮿 Differerences in the finish between 2 ... 12 HP and 14 ... 84 HP
3
3
3.3
H
H
Order Information
X Y
2.5
2.5
ø 5.9
X
Y
ø 2.5
Y
X
Y
6.2
2.5
5
2.5
6.2
2.5
5
2.5
6.2
6.2
ø 2.5
X
04608155
04608158
> 3 HP
7.45
B
b1
b2
3.3
H
3
5.08
Height H Width B
U mm HP
mm
b1
mm
b2
mm
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
9
411.5
25.4
35.6
45.7
55.9
66
91.4
127
198.1
304.8
411.5
411.5
25.4
35.6
45.7
55.9
66
91.4
127
198.1
304.8
411.5
411.5
203.2
101.6
157.5
203.2
203.2
101.6
157.5
208.3
203.2
84
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
128.4
172.9
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
261.8
395.1
84
2
3
4
5
6
7
8
10
12
14
16
21
28
42
63
84
84
2
4
5
6
7
8
10
12
14
16
21
28
42
63
84
84
426.4
9.8
14.9
30.1
35.2
40.3
50.5
60.6
70.8
80.9
106.3
141.9
213
319.7
426.4
426.4
9.8
30.1
35.2
40.3
50.5
60.6
70.8
80.9
106.3
141.9
213
319.7
426.4
426.4
Alignment
pin
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
Qty
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1 (SPQ 5)1)
1
1
1
1
Part no.
20848-262
30849-001
30849-004
30848-354
30848-378
30848-380
30848-382
30848-356
30848-386
30848-358
20848-013
20848-015
20848-020
20848-027
20848-047
20848-068
20848-097
20848-271
30849-002
30848-355
30848-379
30848-381
30848-383
30848-357
30848-387
30848-359
20848-106
20848-108
20848-113
20848-120
20848-139
20848-160
20848-189
20848-280
1) Delivery is exclusively made in Standard Pack Quantity (SPQ):
ø 5.9
B - 2.53
Note
쮿 Differences in finish between 2 ... 12 HP and 14 ... 84 HP
– 2 ... 12 HP: one-part U-profile
– 14 ... 84 HP: multi-part U-profile (front panel with crimped
profiles)
see page 7.107
쮿 Please order textile EMC gasket separately, see page 7.6
Y
2.5
Z
X
Y
6.2
2.5
2.5
5
6.2
ø 2.5
04608156
7.7
Front panels
Front panels, bottom-hinged
Front panels
쮿 Suitable for subracks (europacPRO) and cases (ratiopacPRO,
propacPRO, compacPRO)
쮿 Front panel can be unhinged at 135° (not ratiopacPRO)
opening angle
쮿 The useable width is not restricted
쮿 Mounts on the horizontal rails
쮿 2 versions:
– unshielded
– shielded, U front panel with textile EMC gasket
04295001
Item
1
1a
2
3
4
5
6
Qty
Description
Unshielded Shielded
1
1
Front panel, U profile, hinged,
2
3
Hinge, Zn die-cast, nickel-plated
2
3
Sleeve, PA
2
3
Knurled screw M2.5 x 12.3, nickel-plated
1
EMC textile gasket, core: foam,
1
1
Assembly kit
04602080
Unshielded
Note
A
B
쮿 Unshielded: Dimension C for 84 HP only
C
7.45
2.5
15.6
16
8.2
M 2.5
3
H
3
ø5.9 x 3.3
3.1
D
B - 25.4
X
Y
6.2
Y
2.5
2.5
6.2
X
04602079
Shielded
Order Information
Dimensions
Height
Width
A
U
HP
mm
3
28
141.9
3
42
213.0
3
63
319.7
3
84
426.4
4
42
213.0
4
63
319.7
4
84
426.4
6
28
141.9
6
42
213.0
6
63
319.7
6
84
426.4
1) Dimension with unshielded front panel
7.8
B
mm
127.0
198.1
304.8
411.5
198.1
304.8
411.5
127.0
198.1
304.8
411.5
C
mm
101.6
157.5
208.3 1)
101.6
157.5
208.3 1)
101.6
157.5
208.3 1)
D
mm
86.4
137.2
193.0
86.4
137.2
193.0
86.4
137.2
193.0
H
mm
128.4
128.4
128.4
128.4
172.9
172.9
172.9
261.8
261.8
261.8
261.8
Shielded
Part no.
Unshielded
Part no.
20848-608
20838-280
20848-599
20838-271
20848-600
20848-601
20838-272
20838-273
20848-605
20838-277
20848-606
20848-607
20838-278
20838-279
20848-696
20848-602
20838-274
20848-603
20848-604
20838-275
20838-276
Front panels
shielded
Front panels
쮿 Mounts on horizontal rails
쮿 Front panel with textile EMC gasket
쮿 Hinges can be fitted on left or right
04295002
Item
1
Qty
1
2
3
2
1
4
1
Description
Hinge, Zn die-cast, chrome-plated
Textile EMC gasket,
core: foam, sleeve: textile cladding with CuNi coating
Assembly kit
Order Information
Height
U
3
6
H
mm
128.4
261.8
h
mm
89.9
223.2
W
mm
426.4
426.4
w
mm
203.2
203.2
Part no.
20848-611
20848-617
06106053
04602081
Part number in bold face type: ready for despatch within 2 working days
7.9
Front panels
Front panels for D-Sub connectors
Front panels
X
쮿 3 U/4 HP
X
X
쮿 Aluminium, front anodised, rear irisdescent green chromated
Delivery comprises
Item
1a
1b
15.7
29.6
51,7
36.1
44.3
72.1
쮿 Shielding through: stainless steel EMC or textile EMC gasket
(please order separately)
1c
04608141 04608142 04608143
Cut-out 9-pin
Description
Front panel, Al, 2.5 mm, front anodised, rear irisdescent green
chromated
chromated; for EMC stainless steel gasket
Front panel, U profile, Al, 2.5 mm, front anodised,
rear conductive; for EMC gasket (textile)
Order Information
X
Cut-out
X
Qty
Unshielded
Part no.
1a
51.8
1 × 9-polig
47.6
2 × 9-polig
21.7
3 × 9-polig
1 × 15-polig
04608144 04608145
Cut-out 15-pin
1 × 25-polig
X
X
2 × 15-polig
2 × 25-polig
1 piece
(SPQ 5)
1 piece
(SPQ 5)
1 piece
(SPQ 5)
1 piece
(SPQ 5)
1 piece
(SPQ 5)
1 piece
(SPQ 5)
1 piece
(SPQ 5)
For EMC gasket
Stainless steel
Textile
Part no.
Part no.
1b
1c
30118-341
30118-348
30849-749
30118-344
30118-351
30849-750
30118-347
30118-354
30849-751
30118-342
30118-349
30849-752
30118-345
30118-352
30849-753
30118-343
30118-350
30849-754
30118-346
30118-353
30849-755
55.5
13
40.7
Note
04608146 04608147
1.8
Unshielded
Y
1
2.5
2,5
0.65
Y
X
10.7
Cut-out 25-pin
see page 7.107
see page 7.6
R 11
EMC gasket, stainless steel
Z1
6,2
2,5
2,5
For textile EMC gasket
7.10
Z2
6,2
Z2
2,5
Z1
04608150 04608151 04608149 04608148 04808152 04808153
ELECTRONICS PROTECTION
Front panels
Front panels for Coax connectors
Front panels
쮿 3 U/4 HP
쮿 Aluminium, 2.5 mm, front anodised, rear irisdescent green
chromated
Order Information
Description
Cut-out 4 x Coax, unshielded
Qty/PU
1
Part no.
30118-355
Note
see page 7.107
04602057
Front panels 3 U with GND/earthing connection
Front panels
쮿 Earthed front panel (protection class 1)
Delivery comprises (items 1 – 3 assembled)
Item
1
Qty
1
2
3
4
4
4
1
Description
Front panel 3 U, Al, 2.5 mm, front anodised, rear
iridescent green chromated with GND/earthing
connection
Plastic sleeve, PA, grey
Collar screws, M2.5 x 11 and 12.3 Pozidrive, St,
nickel-plated
GND/earthing kit, length of GND/earthing cable 320 mm
Order Information
02998001
Height
U
3
3
3
3
3
Width
HP
7
14
21
28
42
Qty
1 piece (SPQ 5)
1 piece (SPQ 5)
1 piece (SPQ 5)
1 piece (SPQ 5)
1
Part no.
20119-159
20119-160
20119-161
20119-162
20119-163
Note
see page 7.107
7.11
Front panels
PMC Mezzanine front panels
Front panelsMain C atalogPart number in bold face type: ready for shippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days
쮿 Based on PCI 2.2 specification
(PCI = Peripheral Component Interface)
쮿 In accordance with PMC mezzanine specification IEEE P 1386
04615054
PMC mezzanine front panel kit, shielded, with
trapezoidal extractor handle Type 1
Front panels
쮿 PMC= PCI Mezzanine Card
쮿 For module size 194 x 74 mm2
쮿 In accordance with specification IEEE P1386
(CMC= Common Mezzanine Card)
5
쮿 6 U/4 HP front panel with stainless steel EMC gasket and
front handles
Delivery includes (assembled)
Item
3
5
6
3
Qty
1
1
2
Description
PMC front panel, Al extrusion, 6 U, 4 HP, clear passivated
EMC gasket (St, stainless)
Trapeziform extraxtor handle, type 1
Order Information
Item
Description
3+5+6
Front panel with 2 cut-outs
Accessories
Spacer to mount PMC and FMC mezzanine boards
Voltage keying/coding pin for PMC mezzanine boards
6
Item 3: front panel, item 5: EMC gasket, item 6: front handle
7.12
MPA44845
PMC cover for front panel cutouts for EMC shielding, PMC
gasket for mezzanine front panels
PMC gasket for mezzanine front panels
Part No.
20897-950
see page
7.15
see page
7.15
see page
7.13
see page
7.13
Front panels
PMC cutout cover for
EMC protection
Front panels
15.1
쮿 EMC cover to close unused cut-outs in the PMC mezzanine
front panels
쮿 Material stainless steel, 0.2 mm
쮿 Colour: black or bright
Order Information
Colour
Black
Bright
73.7
71.5
9
Qty
1 piece (SPQ 10)
1 piece (SPQ 10)
Part no.
60835-024
60835-022
Please order at least 10 pieces or a multiple.
4.1
3
12.9
04610028
Item 9: EMC cover; Item 3: front panel
MPA44847
PMC bezel for mezzanine
front panels
Front panels
쮿 Mezzanine front panel is fitted into PMC front panel
cut-outs; EMC shielding with conductive O-ring
2.5
2.25
12.7
쮿 Material:
– Aluminium extrusion (anodised, contact surfaces
conductive)
– Zinc die-cast (untreated, black or chrome-plated, matt)
12.0
74
69.5
M 2.5
Item
4
Qty
1
7
1
Description
PMC bezel for mezzanine front panel,
Zn die-cast or Al extrusion
EMC gasket (O-ring), Cho-Seal
Order Information
PMC mezzaninefront panel
9.9
4
10.9
7
04610029
mpa44846
Qty/PU
with EMC
gasket
Part no.
Material
1
20835-598
contact surfaces conductive
10
20835-889
Zn die-cast, untreated
1
20835-890
10
20835-893
Zinc die-cast, black, chromated
1
20835-922
10
20835-924
Zinc die-cast, chrome-plated, matt 1
20835-923
Zinc die-cast, chrome-plated, matt 10
20835-928
Cheesehead screw M2.5 × 5 mm, PU 100 pieces
EMC gasket O-ring, 1 piece
(Standard Pack Quantity 10 pieces)
without EMC
gasket
Part no.
20835-899
20835-896
20835-931
20835-929
21100-624
60835-021
7.13
Front panels
FMC mezzanine front panels
쮿 FMC = FPGA mezzanine card
쮿 For standard defined I/O mezzanine modules which connect to
carrier cards
쮿 For single 69.0 x 76.5 mm or
double 139.0 x 76.5 mm modules
쮿 In accordance with Vita 57.1 specification
04615052
FMC mezzanine front panel kit, shielded, with IEL
handle
쮿 3 U or 6 U, 4 HP, U-shaped front panels with textile gasketing
5
3
쮿 1 or 3 FMC cutouts (depending on height)
4
쮿 1 or 2 IEL front handles (depending on height)
쮿 EMC shielded, both the front panel and the FMC bezels
1
1
4,5
Item
2
4,5
2
1
Qty
3U
1
6U
1
Description
2
3
1
1
1
2
4
5
6
1
1
1
3
3
1
FMC front panel, U profile, Al, 4 HP,
front anodized, rear conductive,
3 U has 1 cut out, 6 U has 3 cut outs
EMC textile gasket for front panel
IEL handle (handel, black, RAL 9005;
button, light grey, RAL 7035)
FMC bezel for front panel cut outs
EMC gasket (O-ring)
Assembly kit
Order Information
3
04615050
7.14
Height
U
3
6
Accessories
Spacer to mount PMC mezzanine boards
Part no.
20836-253
20836-254
see page
7.15
Front panels
EMC bezel for FMC Mezzanine front panel
cut-outs
Front panels Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 worki ng days
쮿 FMC bezel is fitted into FMC Mezzanine front panel cut-outs
10
쮿 Shielding for FMC bezels with an optional conductive O-ring,
12, 2,5
8
04610029
4
Order Information
56,55
61,05
58,45
12
쮿 Material, Al extrusion (anodised, contact surface conductive)
Description
,5
M2
04615051
04615053
Item
Qty/PU
piece
4
10
panel cut outs
Accessories
EMC gasket for mezzanine front panel item 5 , O-ring,
(VITA 57.1), 1 piece (standard pack quantity 10 pieces)
Part no.
20835-849
60835-077
21100-624
Front panel express solution
5
5.8
Front panels
10
쮿 To provide a standoff between mezzanine boards per the
IEEE P1386 or VITA 57.1 specification and the carrier card
Order Information
Description
Spacer
M 2.5
5
MPA44850
mpa44437
Spacer within PMC application
Item
10
Material
St, zinc-plated
Qty
1 piece (SPQ 10)
Part no.
60897-278
04615055
5.8
Front panels
13.5
쮿 To prevent accidental damage when fitting mezzanine boards,
keying/coding pins are bolted to the VMEbus boards to
distinguish between 3.3 V and 5 V operation. The mezzanine
boards have a hole drilled in the appropriate position. The
keying/coding pin thus ensures that only mezzanine boards
with the same operating voltage can be inserted. For doubleheight euroboards 2 pieces are required.
7
5
M 2.5
Order Information
5
MPZU6325
Description
Keying/
coding pin 5 V/3.3 V
Item Material Qty
St, zinc11
1 piece (SPQ 10)
plated
Part no.
60827-026
06710007
Application
mpa44437
7.15
Main C atalogue
Plug-in units
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
04612001
P lug-in unitsMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for des patch within 1 0 working days
Plug-in units as kits or from individual parts
Subracks/
쮿 Handles in different designs for various applications
쮿 Inserter/extractor handles for forces up to 1500 N
쮿 Upgradable EMC shielding
Front panels,
Standards
쮿 IEC 60297-3-101 / IEEE 1101.1/11
IEC 60297-3-102 / IEEE 1101.10
IEC 60297-3-103
IEC 1296
Power supply
ServicePLUS
e.g. modifications (special colours or sizes)
e.g. custom solutions with modification
to the plug-in units
Backplanes . . . 10
30407004
Connectors, front
panel component
7.16
Plug-in units
Handles for plug-in units
Overview . . . . . . 7.17
Kit
Page
Individual
components
Page
For CompactPCI and VME64x applications
Inserter/extractor handle, type IEL/IET, allows
keying/coding and insertion/extraction forces
up to 700 N per pair
7.18
7.20
Plug-in units with injector
and extractor handles
For CompactPCI
and VME64x
applications . . . . . 7.18
04602005
For VPX, VXS, CompactPCI and VME64x
applications
For VPX, VXS,
CompactPCI and
VME64x
applications . . . . . 7.30
7.30
7.31
7.33
7.35
For e.g. VMEbus
applications
type 2 . . . . . . . . . . . . 7.33
7.40
7.42
For e.g. VMEbus
applications
type 1 . . . . . . . . . . . . 7.40
7.46
For Multibus®
II applications . . . . 7.46
For plug-in units in accordance with
IEC 60297
7.48
IEC 60297
7.51
IEC 60297
7.54
7.56
7.64
Inserter/extractor handle, type XL, allows
up to 1500 N per pair
04605005
For e.g. VMEbus applications
Trapeziform extractor handle, type 2
04604059
Trapeziform extractor handle, type 1
04692005
For Multibus® II applications
Extractor handle, multibus type II, IEC 60297
04692011
Extractor handle in key form 1
For plug-in units
in accordance
with IEC 60297 . . . 7.48
04692008
Extractor handle in key form 2
For plug-in units
in accordance
with IEC 60297 . . . 7.51
04692010
Static handle
For plug-in units
in accordance
with IEC 60297 . . . 7.54
04692003
Accessories for plug-in units
Mechanical protection for static trapeziform
handle and fixing materials kit
Accessories for
plug-in units . . . . . 7.62
PCB cover . . . . . . . 7.64
04692004
7.17
Plug-in units – for CompactPCI, VME64x
Plug-in units with IEL inserter/extractor handle for
CompactPCI/VME64x applications
Kits
3U
for CompactPCI, VME6 4xMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
쮿 In accordance with IEEE 1101.10 and IEC 60297-3-102
쮿 Codable to IEC 60297-3-103/ IEEE 1101.10
쮿 Front panel shielded
쮿 Suitable for insertion and extraction forces up to 700 N
(per pair)
쮿 Suitable for fitting microswitches
Item
04602073
6U
Qty
Description
1
3U
190 VAC, TA = 0 ... 50 °C
쮿 Customised front panel available via
쮿 Further accessories see page 9.16
Connection
Output + V1
Output + V1
Sense line + V1
Sense line 0 V1
Output 0 V1
Output 0 V1
CSB
Output OK
L
N
PE 댷
9.5
Power supplies – 19" AC/DC switch-mode PSUs
maxpower 180 W, single
Main Catalogue
쮿 Wide input voltage range 90 ... 254 VAC and 100 ... 360 VDC with
active Power Factor Correction (PFC)
쮿 Single output voltage
쮿 Integrated active decoupling for redundancy operation
쮿 Active Current Share Bus (CSB)
쮿 Signalling: Output voltage OK
쮿 Efficiency up to 87 %
Delivery comprises
Qty
1
11308005
Description
19" compatible power supply
height 3 U
width A: 8 HP
depth 171.93 mm (160 mm board depth)
connector H 15 M
coding strip (fitted)
Order Information
Voltage
Current
Power
Description
V
A
W
5
30
150
MAX 180-105
12
13
156
MAX 180-112
15
11
165
MAX 180-115
24
7
168
MAX 180-124
Front panel 8 HP, Al extrusion, front anodised, rear
iridescent green chromated, shielded with fixed textile
gasket, incl. assembly kit, 1 piece
Connector H 15 F Mating connector (female) for wiring
inputs/outputs (6.3 mm FASTON), 1 piece
Coding PU (1 keying/coding strip, 2 pieces keying/coding
pins)
Part no.
13100-150
13100-151
13100-152
13100-153
31006-677
69001-733
60800-123
Note
쮿 Please order front panel separately
쮿 Output data for mains voltage > 190 VAC, TA = 0 ... 50 °C
쮿 Customised front panels available via
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
9.6
Connection
Output + V1
Output + V1
Sense + V1
Sense 0V V1
Output 0V V1
Output 0V V1
Output + V1
Output 0V V1
Test
CSB
DC output OK
L
N
PE 댷
SCHROFF PRODUCT CATALOG E 04/2017
maxpower 100 W, dual
Main Catalogue
active power-factor correction (PFC)
쮿 High power density
쮿 2 output voltages
쮿 Efficiency up to 80%
C
US
Delivery comprises
Qty
1
Description
19"-compatible power-supply unit
height: 3 U
width A: 8 HP
connector H 15 M
11300010
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 9
93
MAX 2512
V2: 12
I2: 4
V1: 5
I1: 9
93
MAX 2524
V2: 24
I2: 2
V1: 12
I1: 4.2
101
MAX 212
V2: -12
I2: 4.2
V1: 15
I1: 3.4
102
MAX 215
V2: -15
I2: 3.4
Front panel 8 HP, Al, front anodised, rear iridescent green
chromated, with vertical grooves for EMC gaskets,
EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel,
two pieces necessary per front panel, PU 10 pieces
pins)
Part no.
13100-112
13100-114
13100-115
13100-116
21006-945
21101-705
69001-733
60800-123
Note
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
SCHROFF.PENTAIR.CO.UK
Connection
Output + V1
Output 0 V1
Output + V2
Output 0 V2
L
N
PE 댷
Part number in bold face type: ready for shipping within 2 working days
Part number in normal type: ready for shipping within 10 working days
9.7
maxpower 100 W, triple
Main Catalogue
쮿 3 output voltages
C
US
Delivery comprises
Qty
1
11300011
Description
height 3 U
width A: 8 HP
connector H 15 M
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 8
V2: 12
I2: 2.5
100
MAX 312
V3: -12
I3: 2.5
V1: 5
I1: 8
V2: 15
I2: 2
100
MAX 315
V3: -15
I3: 2
pins)
Part no.
13100-122
13100-123
21006-945
21101-705
69001-733
60800-123
Note
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
9.8
Connection
Output + V1
Output + V1
Sense line + V1
Sense line 0V V1
Output 0V V1,2
Output 0V V1,2
Output + V2
Output 0V V1,2
Output 0V V3
Output – V3
Output OK
L
N
PE 댷
maxpower 130 W, triple
Main Catalogue
쮿 3 output voltages
C
US
Delivery comprises
Qty
1
Description
height 3 U
width A: 12 HP
connector H 15 M
11399009
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 16
V2: 12
I2: 2.8
132
SEG 312
V3: -12
I3: 1.4
I1: 16
V1: 5
V2: 15
I2: 2.2
132
SEG 315
V3: -15
I3: 1.1
Front panel 12 HP, Al, front anodised, rear iridescent green
pins)
Part no.
13100-078
13100-079
21006-946
21101-705
69001-733
60800-123
Note
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
Connection
Output + V1
Output + V1
Sense + V1
Sense 0V V1
Output 0V V1,2,3
Output 0V V1,2,3
Output + V2
Output 0V V1,2,3
Output 0V V1,2,3
Output – V3
Output OK
L
N
PE 댷
9.9
Power supplies – 19" AC/DC linear regulators
Linear regulators, single
쮿 Mains/line voltage 230 VAC (can be switched to 115 VAC with
mains/line voltage conversion kit)
쮿 High control accuracy, low residual ripple and low interference,
suitable for medical applications (8 mm safety clearances)
쮿 PSM, PSG
– Output voltage can be remote controlled externally
(1 ... 10 V)
– Switching of control curve for sensitive loads
(U/I - Fold Back)
– Current measurement via shunt
Delivery comprises
11397001
Qty
1
Description
height 3 U
width A: 6, 10, 14 HP
depth 171.93 mm (160 mm deep boards)
connector H 15 M (fitted)
keying/coding peg (fitted)
Order Information
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
9.10
PSK single
Sense line + V1
Output + V
Output + 0 V1
Sense line 0 V1
L
N
PE 댷
PSM, PSG single
Sense line + V1
Output + V
Output +0 V1
Sense line 0 V1
Optional: redundancy diode
External on/off
GND
V remote input + Vc
V-shunt + Vs
V-shunt – Vs
L
N
PE 댷
Voltage
Current Power
Width
Description
V
A
W
HP
5
1.5
8
6
PSK 105
5
4
PSM 105
5
6
30
14
PSG 105
12
1.1
13
6
PSK 112
12
2.8
31
10
PSM 112
12
4.2
50
14
PSG 112
15
1
15
6
PSK 115
15
2.2
33
10
PSM 115
15
3.5
53
14
PSG 115
24
0.6
16
6
PSK 124
24
1.5
36
10
PSM 124
24
2.5
60
14
PSG 124
Front panel for PSK 6 HP, 1 piece
Front panel for PSM 10 HP, 1 piece
Front panel for PSG 14 HP, 1 piece
pins)
Mains voltage conversion kit 230 V to 115 V, 1 piece
Part no.
13105-001
13105-006
13105-011
13105-002
13105-007
13105-012
13105-003
13105-008
13105-013
13105-004
13105-009
13105-014
21005-475
21005-473
21005-474
21101-705
69001-733
60800-123
43105-999
Note
쮿 Please order front panel separately (Al, front anodised,
rear iridescent green chromated, with vertical grooves for
EMC gaskets, incl. assembly kit)
쮿 PSK without case
쮿 Output data at TA = 0 ... 50 °C
Linear regulators, dual
Main Catalogue
쮿 2 output voltages, galvanically separated
쮿 High control accuracy, low residual ripple and very low
interference
쮿 Suited for medical applications (8 mm safety clearances)
Delivery comprises
Qty
1
Description
Height 3 U
Width A: 6, 10, 14 HP
Depth 171.93 mm (160 mm board depth)
Connector H 15M
Coding strip (fitted)
11300001
Order Information
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
Connection
Sense line + V1
Output + V1
Output 0 V1
Sense line 0 V1
Sense line + V2
Output + V2
Output 0 V2
Sense line 0 V2
L
N
PE 댷
Voltage
Current Power
Width Description
V
A
W
HP
V1: 5
I1: 1.4
14
10
PSM 205
V2: 5
I2: 1.4
V1: 12
I1: 0.4
10
6
PSK 212
V2: 12
I2: 0.4
V1: 12
I1: 1
24
10
PSM 212
V2: 12
I2: 1
V1: 12
I1: 1.5
36
14
PSG 212
V2: 12
I2: 1.5
V1: 15
I1: 0.4
12
6
PSK 215
V2: 15
I2: 0.4
V1: 15
I1: 1
30
10
PSM 215
V2: 15
I2: 1
V1: 15
I1: 1.5
45
14
PSG 215
V2: 15
I2: 1.5
V1: 24
I1: 1.2
58
14
PSG 224
V2: 24
I2: 1.2
pins)
Part no.
13105-021
13105-017
13105-022
13105-027
13105-018
13105-023
13105-028
13105-029
21005-476
21005-477
21005-478
21101-705
69001-733
60800-123
43105-999
Note
쮿 PSK without case
9.11
Linear regulators, triple
Main Catalogue
쮿 3 output voltages, galvanically separated
interference
Delivery comprises
Qty
1
11300002
Description
height 3 U
connector H 15 M
Order Information
Voltage
Current Power
Width Description
V
A
W
HP
V1: 5
I1: 0.5
V2: 12
I2: 0.2
8
6
PSK 312
V3: 12
I3: 0.2
I1: 1.5
V1: 5
V2: 12
I2: 0.5
PSM 312
V3: 12
I3: 0.5
V1: 5
I 1: 3
V2: 12
I 2: 1
39
14
PSG 312
V3: 12
I 3: 1
pins)
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
9.12
Connection
Sense line + V1(PSM, PSG)
Output + V1
Output 0 V1
Sense line 0 V1(PSM, PSG)
Output + V2
Output 0 V2
Output + V3
Output 0 V3
Data save
Power failure
0 V for pin 20, 22
L
N
PE 댷
Part no.
13105-051
13105-052
13105-053
21005-470
21005-451
21005-439
21101-705
69001-733
60800-123
43105-999
Note
쮿 PSK without case
Power supplies – 19" DC/DC converters
coolpower 100 W, single
쮿 Wide input voltage range from 20 to 72 VDC
쮿 Single output voltage, redundancy diode fitted
쮿 External ON/OFF
쮿 Galvanic separation between primary and secondary circuits
쮿 Passive current-share operation
Delivery comprises
Qty
1
Description
height 3 U
width A: 6 HP
connector H 15 M
11301001
Order Information
Voltage
Current
Power
Description
V
A
W
5 1)
CPDC 105
12 1)
8.5
102
CPDC 112
15 1)
6.7
100
CPDC 115
24 2)
4.5
108
CPDC 212
1) Front panel 6 HP, Al, front anodised, rear iridescent
green chromated, with vertical grooves for EMC gaskets,
2) Front panel 6 HP, Al, front anodised, rear iridescent
pins)
Part no.
13103-002
13103-003
13103-004
13103-007
21006-955
21006-956
21101-705
69001-733
60800-123
Note
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
5, 12, 15 V
Connection
Output + V1
Output + V1
Sense line + V0
Sense line 0V V1
Output 0V V1
Output 0V V1
Internally engaged
Output OK
Ext. ON/OFF*
+VE
0V VE
PE 댷
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
24 V
Connection
Output + 24 ... 30 V
via diode
쮿 Power supply with CPDC 212, dual output voltages 24, 30 V
(2 x 12 V, 2 x 15 V)
쮿 Front panel for 13103-007: 21006-956
쮿 For higher input voltages (100 ... 360 VDC) see
maxpower single, page 9.4
Output 0 V
Output 0 V
Output 0 V
Internally engaged
Internally engaged
Internally engaged
Internally engaged
+VE
0V VE
PE 댷
9.13
coolpower 100 W, dual
Main Catalogue
쮿 2 output voltages (or single output voltage 24 – 30 V via internal
redundancy diode V1D)
Delivery comprises
Qty
1
11302003
Description
height 3 U
width A: 6 HP
connector H 15 M
Order Information
Voltage
Current
Power
Description
min. ... max.
V
A
W
V1: 12 ... 15
I1: 4.5
108
CPDC 212
V2: -12 ...-15 I2: 4.5
Front panel 6 HP, Al, front anodised, rear iridescent green
pins)
Part no.
13103-007
21006-956
21101-705
69001-733
60800-123
Note
11302053
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
9.14
쮿 1 output voltage via output pins V1D 24 V ... 30 V,
I1D 4.5 A, 108 W
쮿 Output data at TA = 50 °C
쮿 Adjustment range 12 V ... 15 V
쮿 For higher input voltages (100 ... 360 VDC), see
maxpower single, page 9.7
Connection
Output + V1D
Output + V1D
Output + V1D
Output – V2
Output – V2
Output – V2
Output + V1
Output V1/V2 0 V
Output V1/V2 0 V
Output – V2
Input +Vi
Input 0 V
PE 댷
coolpower 100 W, triple
Main Catalogue
쮿 External ON/OFF
Delivery comprises
Qty
1
Description
height 3 U
width A: 6 HP
connector H15M (fitted)
11302004
Order Information
Voltage
Current
Power
Description
min. ... max.
V
A
W
V1: 5
I1: 10
V2: 12 ...15
I 2: 2
98
CPDC 312
V3: 12 ...15
I 3: 2
Front panel 6 HP, Al, front anodised, rear colourless
pins)
Part no.
13103-016
21006-957
21101-705
69001-733
60800-123
Note
DIJM0084
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
Connection
Output + V
Output + V1
Sense line + V2
Sense line V1 0 V
Output V1 0 V
Output V1 0 V
Output + V2
Output V2 0 V
Output + V3
Output V3 0 V
External ON/OFF
Input +Vi
Input 0 V
PE 댷
Adjustment range V2, V3 12 ... 15 V
Input voltage 100 ... 360 VDC, see
maxpower triple, page 9.8
쮿
쮿
쮿
쮿
9.15
Power supplies – Accessories
Accessories
쮿 For slimpower, maxpower, coolpower and linear regulators
쮿 Z-rail (item 6)
쮿 Mating connector female H 15 F (item 1)
쮿 Coding (item 2)
쮿 Wall/horizontal rail mounting
PSA45379
Z-rail, 4 HP
Accessories
쮿 For bolting a H15 F connector to the rear horizontal rail/case
(item 6)
쮿 Provides the standard plug-in depth of the PSUs
Order Information
Description
Z-rail, 4 HP (20.32 mm)
Qty/PU
1
Part no.
30822-166
Note
쮿 Two Z-rails are required per connector
A3-420
Connector H 15 F
Main Catalogue
쮿 Connector EN 60603 (DIN 41612) H15 F for 6.3 mm FASTON
쮿 In 19" power supply units the H 15 male connector is fitted,
PIN 32 with capacitive earthing contact
쮿 Compatible with connector H15 M of e.g. 19" plug-in equipment
Order Information
Item
1
Description
Type H
Qty/PU
1
Part no.
69001-733
05592018
9.16
Keying/coding
Access ori es
쮿 Mechanical coding prevents a PSU being fitted on the wrong
slot, space requirement 4 HP
쮿 Coding:
– Female strip (item 2), fitted on PSU (except slimpower)
– Coding strip (item 1) mounts on the Z/horizontal rail
– Placement of coding pins (item 3) in the coding strip (item 1)
– Removal of studs at the appropriate place in the female strip
쮿 With 2 coding pins there are 66 coding possibilities
1
Order Information
3
Description
Keying/coding strip, Crastin (UL 94 V-0) 1 piece,
keying/coding pins, Crastin (UL 94 V-0), 2 pieces
Part no.
60800-123
1
2
2
A4-2424
9.17
Accessories
쮿 Suitable for 19"-compatible 3 U PSUs
쮿 2 mounting options
– Wall mounting bracket can be fitted in any position with
screws and PSU is inserted
– Horizontal rail adaptor is bolted to wall mounting bracket,
then the 19" PSU can be clipped to a horizontal rail
Order Information
Item Description
1
Wall mounting bracket, St
2
Horizontal rail adaptor bracket, Al
Connector H 15 F FASTON connection, 1 piece
Qty/PU
1
1
Part no.
11000-001
11000-002
69001-733
11395007
2
1
9.18
PSA45389
Power supplies – MicroTCA
AC/DC, double full-size, with power
management (EMMC)
Mi croTCA MAIN CATALOGPart number in bold face type: ready for s hippi ng within 2 working daysPart number in normal type: ready for shipping within 10 working days
쮿 Mains input at front with wide input voltage range for AC
voltages with IEC locking system
쮿 Construction compatible with AdvancedMC double full-size
쮿 Supports N+1 and 2+2 redundancy, load sharing and hot swap
쮿 Power management for 16 current channel (12 AMC, 2 CU and
2 MCHs)
쮿 High efficiency
쮿 Visual performance display
The MTCA PSU 600 is an exceptionally efficient power module (PM)
for MicroTCA® applications. This 600W power supply is the most
efficient available in double-width full-size format. This PM's
integrated management controller makes it ideally suited for
use in complex communications systems running the latest
generations of processors and an increased number of AMC
modules. The MTCA PSU 600 provides the power required for
12 AMCs, 2 Cooling Units (CUs) and 2 MicroTCA® Carrier Hubs
(MCHs).
11316001
Delivery includes
Qty.
1
Description
PSU for MicroTCA
Double height (148.3 mm)
Full-size width (6 HP)
Depth 186.65 mm
Connector MicroTCA Power
Front panel with handle and EMC gasket (fitted)
Order Information
Voltage
V
V1: 12
V2: 3.3
Current
A
I1: 6.8
I2: 0.18
Power
W
Description
600
MTCA PSU 600
Part no.
11098-547
9.19
Power supplies – for MicroTCA
without management
for MicroTCAMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days
쮿 Wide input voltage range 90 ... 264 VAC
쮿 Active power factor correction
쮿 Single-wire current share cable for redundancy operation
쮿 2 output voltages, 12 V and 3.3 V
쮿 Corresponds to EMC class B as per EN 55022
쮿 Without MicroTCA power management controller
Delivery comprises
Qty
1
11309004
L
G
N
170
143,5
143,5
Order Information
Voltage
V
V1: 12
V2: 3.3
V1: 12
V2: 3.3
181,8
LED
1,2
Description
PSU for MicroTCA
height double (148.3 mm)
width full-size (6 HP)
depth 186.65 mm
connector Molex SSI
front panel with handle and EMC gasket (fitted)
Current
A
I1: 25
I2: 3
I1: 45.8
I2: 3
Power
W
Description
Part no.
300
MCA 300 AC
11098-392
550
MCA 550 AC
11098-416
Note
쮿 Output data for TA = -25 ... 55 °C with forced cooling of 20 cfm
쮿 Connector FCI 51720-10202402AA or Molex 87631-2019
28,2
31
11312050
9.20
Power supplies – for VMEbus
AC/DC, 19", 6 U, triple
for VMEbusMain Catalogue
쮿 Wide input voltage range 90 ... 264 VAC and 130 ... 350 VDC with
active power factor correction (PFC)
쮿 3 output voltages
쮿 VMEbus signalling
C
US
Delivery comprises
Qty
1
Description
height 6 U
width A: 8, 12 HP
front panel with handles (fitted)
connector H 15 M (2 pieces)
coding strip (2 pieces, fitted)
Order Information
11301002
Voltage
Current Power
Width
Description
V
A
W
HP
V1: 5
I1: 20
V2: 12
I 2: 4
150 (60)
8
MPS 015
V3: -12
I 3: 3
V1: 5
I1: 28
V2: 12
I 2: 7
224 (84)
12
MPS 022
V3: -12
I 3: 3
V1: 5
I1: 28
V2: 15
I2: 5.6
224 (84)
12
MPS 022/15
V3: -15
I3: 2.4
EMC gaskets (stainless steel) 6 U, 232 mm, stainless steel,
2 pieces necessary per front panel, PU 10 pieces
pins)
Part no.
13100-205
13100-203
13100-204
21101-707
69001-733
60800-123
Note
쮿 Output data at TA = 0 ... 40 °C
쮿 Values in brackets: Output power V2 + V3
PSA44726
Connector pin-out
Pin
4
6
8
10
12
14
16
18
24
26
28
30
32
Connection
x1 (at top)
Output + V1
Output + V1
Output + V1
Output + V1
Output + V1
Sense line + V1
Output - V3
Output 0 V1,2,3
Output 0 V1,2,3
Output 0 V1,2,3
Output 0 V1,2,3
Output 0 V1,2,3
Output + V2
Output + V2
Sense line 0 V1
Connection
x2 (at bottom)
ACFAIL
SYSRESET
Current Share Bus
Shutdown 4 ... 28 V
GND Shutdown
L
N
PE y
9.21
AC/DC, open frame, triple
Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
쮿 For VME applications
쮿 Wide input voltage range 85 ... 264 VAC
쮿 3 output voltages
쮿 High performance
쮿 Output power 444 ... 800 W
C
US
Delivery comprises
Qty
1
11405002
Photo shows MP6 PSUs
4,3
S
L
O
T
S
L
O
T
S
L
O
T
S
L
O
T
5
4
3
2
1
49,2
S
L
O
T
23,9
63,5
19
127
38,1
171,5
17,3
63,5
* M 4 (4x)
19,1
d
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 60
V2: 12 1) I2: 10
444 2)
MP4 2E-4LL-00
I 3: 4
V3: 12
V1: 5
I1: 60
V2: 12
I2: 17
MP6 2E-1L-1L-00
708 3)
V3: 12
I3: 17
V1: 5
I1: 120
V2: 12 1) I2: 10
744 3)
MP6 3E-4LL-00
I 3: 4
V3: 12
I1: 120
V1: 5
V2: 12 1) I2: 17
MP6 3E-1L-1L-00
800 3)
I3: 17
V3: 12
Accessories
Set of connectors with all input/output connectors,
PU 1 kit
d
mm
Part no.
254.0
11098-267
279.4
11098-266
279.4
11098-140
279.4
11098-231
21009-038
1) 10 % base load necessary, sum of 12 V outputs max. 144 W
2) Output max. 400 W at 85 VAC ... 180 VAC
3) Output max. 600 W at 85 VAC ... 180 VAC
3,7
171,5
Description
Open frame PSU
19,1
127
101,6
Note
M 4 (4x)
# 8 - 32 (4x)
171,5
* Assembly holes identical on both sides
9.22
쮿
쮿
쮿
쮿
쮿
Output data at -20 °C ... +50 °C
Input: AC 85 ... 264 V (47 ... 440 Hz), DC 120 ... 350 V
Output voltages adjustable, w10 %
Signalling: Input ok, DC output ok
Other output voltages available on request
29,1
11412050
Power supplies – for CompactPCI Serial
19" switched-mode power supply for CompactPCI Serial
for C ompactPC I SerialMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days
쮿 19" pluggable PSU for CompactPCI Serial applications
쮿 Very wide input voltage range for both AC and DC
쮿 Active power factor correction and active current-share
function
쮿 N+1 redundancy, hot swap
쮿 Output signaling: PS present, power failure, PO ON and enable
쮿 I2C interface
쮿 Temperature monitoring
쮿 Sense line
쮿 UL, cUL and DEMKO certificates, CE-compliant
11315001
Pro
du
Bau ktio
ar n üb
t ge er
pr wac
üf
t ht
US
d
re
ito
on
m ed
n
io test
ct
du Type
Pro
TUV
C
SUD
Delivery includes
Qty
1
Description
19"-compatible PSU
Height 3 U
Width 8 HP
160 mm board depth
PwrBlade connector (fitted)
Front panel with handle and EMC contact strip (fitted)
Order Information
Voltage
Current Power
Input voltage
V
A
W
V1: 12
I1: 25
300
AC: 90 ... 264 V
V2: 5
I2: 2.5
Accessories
CompactPCI Serial power backplane, 3 U, 8 HP, 1 slot
1 piece
Part no.
11098-538
23098-397
9.23
Power supplies – for CompactPCI and VME64x
AC/DC, 19", 3 U, quad
for CompactPCI and VME64 xMain Catalogue
쮿 Wide input voltage range 90 ... 264 VAC with power factor
correction (PFC)
쮿 4 output voltages
쮿 Connector P 47
쮿 Redundant operation with Current Share Bus (CSB), hot-swap
쮿 CompactPCI signalling
Pro
du
Bau ktio
ar n üb
t ge er
pr wac
üf
t ht
US
d
re
ito
on
m ed
n
io test
ct
du Type
Pro
TUV
C
SUD
Delivery comprises
Qty
1
11302005
Description
height 3 U
width A 8 HP
connector P 47
front panel with handles and EMC gasket fitted
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 40
V2: 3.3
I2: 40
250
CPCI 250 AC
V3: 12
I3: 5.5
V4: -12
I4: 2
Power backplane with P47 connector 3 U, width 39.6 mm,
1 × connector position P47, 1 piece
Power backplane with P47 connector 3 U, width 80.3 mm,
2 x connector positions P47 (side-by-side), 1 piece
Power backplane with P47 connector 6 U, width 39.6 mm,
1 × connector position P47, top, 1 piece
2 × connector position P47, one above the other, 1 piece
Guide rail with keying/coding, groove width 2.0 mm, with
0.1" offset Standard pack quantity 50 pieces
Part no.
13100-141
23098-105
23098-115
23098-116
23098-117
64560-071
Note
쮿 Output data at TA = 0 ... 50 °C with forced air cooling of 2 m/s
쮿 47-pin CompactPCI connector to PICMG 2.11 specification
11302052
9.24
AC/DC, 19", 6 U, quad
Main Catalogue
correction (PFC)
쮿 4 output voltages
쮿 Connector P 47
C
US
Delivery comprises
Qty
1
11308007
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 50
V2: 3.3
I2: 60
500
CPCI 500 AC
V3: 12
I3: 12
V4: -12
I4: 4
0.1" offset , Standard pack quantity 50 pieces
233,35
261,75
A
Description
height 6 U
width A: 8 HP
connector P 47
front panel with handles and textile EMC gasket fitted
Part no.
13100-145
23098-116
64560-071
Note
쮿 Output data at TA = -25 ... 55 °C with forced air cooling
of 1.5 m/s
233,5 x 160 mm
2,5
171,93
11302051
9.25
AC/DC, open frame, 300 W, quad
쮿 For CompactPCI and VME64x applications
쮿 4 output voltages
쮿 High performance, efficiency typically 85 %
쮿 Output power 300 W
C
US
Delivery comprises
Qty
1
11408002
A
Description
Open frame power supply,
dimensions 36 x 99 x 173 mm; weight 850 g
Order Information
Voltage
159,1
6-32UNC 2B
18
28,8
35,6
A
Voltage
Current Power Description
min. ... max.
V
V
A
W
V1: 5
4.75 ... 5.25
I1: 40
V2: 3.3
3.14 ...3.46
I2: 40
300
EF306-433
V3: 12
I3: 4
V4: 12
I4: 1.5
Set of connectors with all input and output plugs,
PU 1 kit
Part no.
11098-316
21009-039
쮿
쮿
쮿
쮿
쮿
63,5
98,0
Note
Output data at -5 °C ... 50 °C
Output voltages 5 V and 3.3 V adjustable, w 10 %
Forced cooling at 2 m/s (230 lfm) required
With remote-control function Ext. ON/OFF
With auxiliary supply 5 V/ 5 mA
6-32UNC 2B
162,6
172,7
13
11408050
9.26
AC/DC, open frame, 600 W, quad
for C ompactPC I and VME64 xMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days
쮿 4 output voltages
쮿 High performance
C
US
Delivery comprises
Qty
1
Description
Open frame PSU
Order Information
11405001
Photo shows 11098-212
4,3
S
L
O
T
S
L
O
T
S
L
O
T
S
L
O
T
5
4
3
2
1
49,2
S
L
O
T
23,9
63,5
19
127
38,1
63,5
* M 4 (4x)
Voltage Current Power Description
d
V
A
W
mm
V1: 5
I1: 60
V2: 3.3
I2: 35
560 2) MP4 2E-1D-4LL-00 254.0
V3: 12
I3: 10
V4: 12
I4: 4
I1: 60
V1: 5
V2: 3.3
I2: 60
642 3) MP6 2D-2E-4LL-00 279.4
V3: 12
I3: 10
V4: 12
I4: 4
Accessories
Set of connectors with all input and output plugs, PU 1 kit
Part no.
11098-212
11098-207
21009-039
Note
171,5
d
3,7
19,1
101,6
171,5
Output data at -20 °C ... 50 °C
127
17,3
쮿
쮿
쮿
쮿
쮿
19,1
M 4 (4x)
# 8 - 32 (4x)
171,5
29,1
11412050
9.27
DC/DC, 19", 3 U, quad
쮿 Input voltage 48 VDC (36 ... 75 VDC)
쮿 4 output voltages
쮿 Connector P 47
쮿 Redundant outputs with Current Share Bus (CSB), hot-swap
Pro
du
Bau ktio
ar n üb
t ge er
pr wac
üf
t ht
US
d
re
ito
on
m ed
n
io test
ct
du Type
Pro
TUV
C
SUD
Delivery comprises
Qty
1
11302005
Description
height 3 U
width A: 8 HP
connector P 47
front panel with handle and EMC contact strips (fitted)
Order Information
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 40
V2: 3.3
I2: 40
250
CPCI 250 DC
V3: 12
I3: 5.5
V4: -12
I4: 2
Part no.
13100-142
23098-105
23098-115
23098-116
23098-117
64560-071
Note
쮿 Output data at TA = 0 ... 50 °C, with forced air cooling of 2 m/s
11302052
9.28
DC/DC, 19", 6 U, quad
Main Catalogue
쮿 Input voltage range 48 VDC (36 ... 72 VDC)
쮿 4 output voltages
쮿 Connector P 47
쮿 Compact PCI signalling
C
US
Delivery comprises
Qty
1
Description
height 3 U
width A: 8 HP
connector P 47 (fitted)
front panel with handles and EMC contact strip (fitted)
Order Information
11303002
Part no.
13100-146
23098-116
64560-071
Note
233,35
261,75
A
Voltage
Current
Power
Description
V
A
W
V1: 5
I1: 50
V2: 3.3
I2: 60
500
CPCI DC-6U-500
V3: 12
I3: 12
V4: -12
I4: 4
쮿 Output data at TA = -10 ... 55 °C with forced air cooling of 2 m/s
233,5 x 160 mm
2,5
171,93
11302051
9.29
Power supplies – ServicePLUS
configuration
Simple. Fast. To the ideal product.
Components can be varied and combined freely
쮿 Configurations, based on our standard range of AC/DC or
DC/DC converters
– Number of output voltages
– Heights, widths, depths
쮿 Online configuration enquiries:
www.schroff.co.uk/configuration
assembly
Assembled by professionals. Double benefit!
Front panel and handle mounting
쮿 Front panel mounting
modification
Small changes. Large impact.
Modification of off-the-shelf products
쮿 Minor modifications, e.g. other set output voltages, protective
finishes
solution
Simple. Fast. From one source.
Integration and custom developments
쮿 Development and design to customer specification;
manufacture of prototypes, pre-production and production
series, certification
academy
Knowledge. Sharing. Partnerships.
Knowledge transfer and partnership
쮿 Training, test reports, user reports, certificates, user manuals
for download
lifecycle
We are with you. For the entire product life.
Flexible support throughout the product
lifecycle
쮿 Repair, fast and straightforward, via online RMA form
ServicePLUS
9.30
Application examples and special devices created to customer specifications
Text
11308002 11309004
Application: Redundant and uninterruptible 19" DC power supply
units
Application: AC/DC switch-mode power supply for
telecommunications applications
Application: DC/DC converter for railway applications
11309003
11309005
11309002
Application: AC/DC switch-mode PSU for power supply to video
monitoring systems
11309001
Application: AC/DC linear regulator for communications systems
(defence systems)
Application: DC/DC converter for supply power to fans (with
monitoring)
11309005
9.31
Main C atalogue
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days
Backplanes
Content
Cabinets . . . . . . 1
CompactPCI Serial
Wall mounted
cases . . . . . . . . . 2
Accessories for
cabinets and wall
mounted cases . 3
CompactPCI PlusIO
Climate control . 4
CompactPCI backplanes
and bridges
Electronics
cases . . . . . . . . . 5
Subracks/
19" chassis . . . . 6
Front panels,
plug-in units . . . 7
CompactPCI,
PSB and H.110
backplanes
Systems . . . . . . . 8
Power supply
units . . . . . . . . . . 9
PXI backplanes
Backplanes . . . 10
Connectors, front
panel component
system . . . . . . . 11
VPX backplanes
Appendix . . . . . 12
36106009 (10506003 10506002 10502001 10508008
10.0
SCHROFF PRODUCT CATALOG E 12/2017
12406002 12406001 12406004 12402004)
Main CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 1 0 working days
Backplanes
Overview . . . . . . 10.0
Backplanes . . . . . . 10.2
CompactPCI
VXS backplanes
Serial . . . . . . . . . . . . 10.4
Plus I/O . . . . . . . . . 10.6
System slot right . 10.7
System slot left . . 10.8
Packet
switching, H.110
backplanes . . . . . . 10.9
Bridge . . . . . . . . . . . 10.10
Secondary,
system slot right . 10.11
PXI
VME64x
backplanes
Backplanes . . . . . . 10.12
VPX . . . . . . . . . . . . 10.13
VXS . . . . . . . . . . . . 10.16
VME backplanes
VME64
extension . . . . . . 10.15
VMEbus
Monolithic J1/J2 . 10.17
J1 (3 U) . . . . . . . . . . 10.18
J2 (3 U) . . . . . . . . . . 10.19
Power backplanes
With P47
connector . . . . . . . 10.20
Power Piggyback 10.20
Universal backplanes
Backplane with/
without throughconnected signal
lines . . . . . . . . . . . . . 10.21
Power and
universal
backplanes
Test adaptors
Types B, C, D, E, F,
H, M . . . . . . . . . . . . . 10.22
For VMEbus . . . . . . 10.26
Board guides . . . . 10.28
Type/board
versions . . . . . . . . 10.29
Dimensions
test adaptors. . . . . 10.29
Test adaptors
Assembly
material . . . . . . . . . 10.30
ServicePLUS . . . 10.31
36106010 (12402005 12606003 12406003 12606005 12096003 11902001 11192004 11100013 11100010)
10.1
Backplanes
Our competence in overview
Comprehensive standard backplane programme
AdvancedTCA - MicroTCA - CompactPCI - VME - Schroff offers you
an extensive standard backplane programme that is already
ideally matched to your requirements. Should you still not find
your backplane in our range, we can develop or modify to create
your tailor-made backplane, quickly and on attractive terms.
All our developing and manufacturing is done in-house and
competent personnel are available at any time to deal with
technical questions, quotes and project support.
Custom backplane
Custom development to customer requirements
From minor modifications to our standard backplanes through to
specific form factors and connection topologies, Schroff has the
right solution for you
One contact partner as customer interface
Project management
Competent personnel are available at any time for technical
questions, quotes, project support and after-sales care. If you
wish, we are also happy to help you generate the specification
for your custom backplane. Contact at an early stage between
our technical staff and our customers helps us to develop
cost-optimised projects that meet all our customers'
requirements.
Many years of experience
50 years of experience, continual fundamental research and
innovation in the backplane sector. Active participation in
standards committees and in the specification of new system
architectures and high-speed transmission technologies.
Development
Modern design tools
Modern simulation tools and measurement equipment plus inhouse developed high-performance test adaptors. Development
of new technologies and topologies using high-speed
measurements performed in-house.
Layout
Test laboratory
10.2
Backplanes
Main Catalogue
Modern machine facilities in Straubenhardt
Solder paste printing is one of the quality-defining process steps
in backplane manufacture. This solder-paste printer, based on
innovative inkjet technology, allows fast, flexible and highly
dependable solder paste printing. Since the process dispenses
with the ’stencils’ required by other methods, the printing
program
can be changed in a very short time. This means that small
batches can also be printed cost-effectively.
Our modern SMD placement machines support a wide
spectrum of components with a high placement performance.
Small and large production runs can be implemented flexibly
and time-efficiently.
Vapour-phase soldering, also known as vapour-phase reflow,
is currently the most universal and most reliable soldering
process.
It is ideally suited to all types of SMD component and carrier
material. The homogenous temperature distribution of the carrier
medium allows the widest variety of sub-assemblies, from
Flexprints to multilayer boards, to be soldered reliably without
danger of overheating.
Automatic optical inspection (AOI)
There is also the option of processing conventional components
with our wave-soldering system.
Automatic optical inspection (AOI) is an optical test procedure
for sub-assemblies equipped with components. Highly-developed
image processing systems reliably detect faulty soldered joints
and wrongly placed or missing components.
Connector mounting
Connectors are pressed into the backplane fully automatically.
The press-in technique allows quick and economic mounting
of the connector without subjecting the PCB to thermal stress.
The press-in action creates a gas-tight, dependably electrically
conductive and mechanically strong connection. Intelligent force/
displacement measuring during the press-in action ensures
consistent high quality.
Backplanes that are subject to particular climatic stresses can be
coated with a protective lacquer (conformal coating). This
coating protects the backplane from e.g. corrosion and mould.
The fluorescent characteristic of the protective coating enables
the coating to be checked for completeness or damage under UV
light.
Conformal coating
No backplane leaves our production facility without 100% testing.
All backplanes are subjected to extensive electrical testing before
despatch. An automatic process checks the entire backplane for
continuity and short circuits. This testing also covers passive and
simple active components such as resistors, capacitors and
diodes
and the description and testing of I2C EEPROMS or bus
terminations. For this Schroff has a comprehensive automated
and semi-automated testing facility.
Electrical final test
10.3
Backplanes – CompactPCI Serial
CompactPCI Serial backplanes
Com pac tP CI SerialMain CatalogP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days
쮿 Conforms to PICMG CompactPCI Serial (CPCI-S.0 R2.0)
specification
쮿 1 system slot and 0 ... 8 peripheral slots
쮿 Supports PCIe (Gen3), USB 2.0 and USB 3.0,
S-ATA (II & Rev. 3.0) and Ethernet (10GBase-T)
쮿 PCIe: Up to two 8 x lanes and up to six 4 x lanes
쮿 Powerbugs for +12 V payload voltage and Minifit plug for +5 V
standby voltage
쮿 Utility connector on rear of backplane
쮿 Mechanical centering and keying/coding strip in stainless steel
on every fully equipped front and rear slot
쮿 PICMG 2.9 IPMB plug can be fitted on request
Delivery includes
Item
1
2
Qty
1
1
Description
Backplane
Screw kit, M4 x 6, with lock washer; for connecting power
to powerbugs
12415020
Order Information
Height
U
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
10.4
Number System Topology
of slots slot
GbE
1
1
1
Rear I/O on RP6
1
Rear I/O on RP6
2
Left
Full mesh
2
Left
Full mesh
3
Left
Full mesh
3
Left
Full mesh
3
Right
Full mesh
3
Right
Full mesh
4
Left
Full mesh
4
Left
Full mesh
4
Right
Full mesh
4
Right
Full mesh
5
Left
Full mesh
5
Left
Full mesh
5
Right
Full mesh
5
Right
Full mesh
5
Right
Full mesh
5
Right
Full mesh
6
Right
Single star
6
Right
Single star
7
Left
Single star
7
Left
Single star
7
Right
Single star
7
Right
Single star
8
Left
Single star
8
Left
Single star
9
Left
Single star
9
Left
Single star
9
Right
Single star
9
Right
Single star
9
Left
Full mesh
9
Left
Full mesh
I/O at
rear
Yes
No
Yes
No
Yes
No
No
Yes
Yes
No
Yes
No
No
Yes
Yes
No
Yes
No
Yes
No
No
Yes
No
Yes
No
Yes
No
Yes
Yes
No
Yes
No
Yes
No
Width
mm
19.3
19.3
19.3
19.3
39.6
39.6
60.0
60.0
60.0
60.0
80.3
80.3
80.3
80.3
100.6
100.6
100.6
100.6
159.9
159.9
120.9
120.9
141.2
141.2
141.2
141.2
161.6
161.6
181.9
181.9
181.9
181.9
181.9
191.9
Description
J1 plug for power, J2...J5, RP2...RP5 for rear I/O
J1 plug for power
J1 plug for power, J2...J6, RP2...RP6 for rear I/O
J1 plug for power, J6, RP6 for rear I/O
For Ethernet single star and full-mesh applications
Additional slot for one CompactPCI Serial PSU (3 U, 8 HP)
For Ethernet single-star applications
Part no.
23007-661
23007-621
23007-681
23007-641
23007-682
23007-642
23007-643
23007-683
23007-693
23007-653
23007-684
23007-644
23007-654
23007-694
23007-685
23007-645
23007-695
23007-655
23007-615
23007-605
23007-636
23007-676
23007-627
23007-667
23007-637
23007-677
23007-628
23007-668
23007-669
23007-629
23007-679
23007-639
23007-689
23007-649
Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days
쮿 Power backplane for pluggable PSUs with FCI Power Blade
plug
쮿 3 U, 8 HP, 1 PSU connector
쮿 Separate inputs for AC and DC with Fastons
쮿 Connector for 12 V, 5 V standby, utility signals, current sharing,
power button, serial console to a UPS and digital I/O at the rear
쮿 Optionally, the PICMG 2.9 SMBus plug and additional
powerbugs for 12 V and 5 V standby can be fitted
쮿 Geographical address can be set by means of a DIP switch
Delivery includes
Item
1
12415019
Qty
1
Description
Order Information
Height
U
3
Number of slots
1
Width
mm
38.9
Part no.
23098-397
12415021
Application: Power backplane (left), CompactPCI Serial backplane
(right) and connection via power adapter board (below)
Accessories for CompactPCI backplanes
쮿 Cable sets for connecting power and status signals of
CompactPCI Serial backplanes and power backplanes
쮿 Power adapter boards for simple connection of 12 V main
supply voltage between CompactPCI Serial backplanes and
power backplanes
Order Information
Accessories
Utility cable, single conductors, 600 mm, 1 x 10-pin Micro-Match 1 piece
Utility flat ribbon cable, 650 mm, 4 x 10-pin Micro-Match 1 piece
Standby cable, single conductors, 600 mm, 1 x 4-pin Microfit to 2 x ring cable eye 1 piece
Standby cable, single conductors, 400 mm, 3 x 4-pin Microfit 1 piece
Current-sharing flat ribbon cable, 150 mm, 2 x 4-pin Micro-Match 1 piece
Power connection cable, for 1-slot backplane, single conductors, 600 mm, 1 x 6-pin Microfit to 2 x ring cable eye and 1 x 4-pin Microfit
1 piece
Power connection cable, backplane to backplane, single conductors, 300 mm, 2 x ring cable eye to 2 x ring cable eye 1 piece
AC input cable, single conductors, 500 mm, 3 x blade receptacles, open end 1 piece
DC input cable, single conductors, 500 mm, 3 x blade receptacles, open end 1 piece
CompactPCI Serial power backplane, 3 U, 8 HP, 1 slot 1 piece
Power adapter board, 3 x V1, 3 x V2, 121212 1 piece
Power adapter board, 2 x V1, 2 x V2, 1212 1 piece
Power adapter board, 3 x V1, 3 x V2, 122121 1 piece
Power adapter board, 2 x V1, 2 x V2, 1221 1 piece
23204-852
23204-875
23204-853
23204-866
23204-867
23204-869
23204-879
23204-880
23204-881
23098-397
23098-399
23098-400
23098-401
23098-402
10.5
CompactPCI PlusIO
Com pac tP CIMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days
쮿 In accordance with:
– PICMG 2.0 R3.0 CompactPCI Core Specification
– PICMG 2.1 R2.0 Hot-Swap Specification
– PICMG 2.9 R1.0 System Management Bus Specification
– PICMG 2.10 R1.0 Keying Specification
– PICMG 2.30 R1.0 CompactPCI PlusIO specification
– PICMG CompactPCI Serial (CPCI-S.0 R1.0) specification
쮿 System slot in accordance with PICMG 2.30,
32-bit CPCI bus on P1, PCIe, S-ATA, USB & Ethernet on P2
쮿 CompactPCI peripheral slots, 32 bit with rear I/O on P2
쮿 CompactPCI Serial peripheral slots with PCIe x1, S-ATA
and USB
쮿 Full-mesh Ethernet on system slot and 2 CompactPCI Serial
slots, supports 1000Base-T and 10GBase-T
12411009
Photo shows 23007-601
쮿 Rear I/O on the CompactPCI Serial slots available on request
쮿 V(I/O) can be set to 3.3 V or 5 V (preset to 5 V)
Delivery comprises
Item
1
2
Qty
1
1
Description
Backplane
Set of screws, M4x6, with lock washer; to attach the
power connection cable to the power bugs
Order Information
Number of slots
Width
mm
102.2
161.3
Height
U
3
3
3 CPCI + 2 CPCI Serial
4 CPCI + 4 CPCI Serial
Accessories
SM bus/IPMB cable 4 individual wires with SMB plug to
open end, length 750 mm, 1 piece
Kit to convert V I/O to 3.3 V 8 coding tabs, yellow, coding
key, PU 1 kit
Utility cable MicroMatch with single conductors,
length 600 mm, 1 piece
Utility cable MicroMatch with flat ribbon cable,
Screws, washers for backplane mounting
23204-113
21101-658
23204-812
23204-811
Page 10.30
6-J6
1-P2
1-P1
2-P2
3-P1
23007-601
1000BaseT
PCIe, SATA, USB2.0
2-P1
New P2 pinout
3-P2
4-P2
(PICMG 2.30 CPCI PlusIO)
5-J6
4-P1
23007-602
12409053
Topology shows 23007-601
Legacy CPCI 32-bit P2
Rear I/O connector
Part no.
Rear I/O optional at
all CPCI Serial Slots
5-J1
Legacy CPCI 32-bit P1 connector
6-J1
7-J1
8-J1
CPCI Serial base connector
1
2
3
4
PERIPHERAL
PERIPHERAL
PERIPHERAL
SYSTEM
CPCI
CPCI PlusIO
PICMG 2.30
5
6
7
CPCI Serial
Front view
10.6
8
12409051
CompactPCI backplane with
system slot right
Com pactP CIMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days
– PICMG 2.0 R3.0 CompactPCI Core specification
– PICMG 2.1 R2.0 Hot Swap specification
– PICMG 2.9 R1.0 System Management Bus specification
– PICMG 2.10 R1.0 Keying specification
쮿 Versions: 3 U 32-bit and 64-bit, 6 U 64-bit, with system slot right
쮿 V(I/O) adjustable to +3.3 V or +5 V (see photo)
쮿 Backplanes up to 5 slot are 66 MHz capable,
6 to 8 slot backplanes are set for 33 MHz operation
쮿 Outstanding high-frequency noise suppression and very high
MTBF values due to ceramic capacitors
쮿 Digital GND can be connected to/isolated from chassis GND
by means of screws
Photo shows 23006-816
12408001
쮿 Infeed of supply voltages via powerbugs (ring tag M4),
FASTONs
쮿 Utility plug for status signals (SMCQ)
쮿 Intelligent platform management bus (IPMB) connector to
PICMG 2.9
Delivery comprises
a: V(I/O) bridge; b: Utility connector; c: IPMB connector
ServicePLUS see page 10.31
12408002
Item
1
Qty
1
2
1
Description
CompactPCI backplane with coding tab and
V(I/O) bridge, fitted
Set of 6 M4 bolts, with lock washer; for power connection
Note
쮿 4 to 7 slot backplanes can be used as primary backplane with
bridge
쮿 Types marked with an asterisk * are available on request
쮿 CompactPCI backplanes and secondary bridges see from page
10.10
Order Information
Number Width
of slots mm
3 U, 32-bit, CompactPCI backplane
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
3 U, 64-bit, CompactPCI backplane
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
1
19.3
23006-331
23006-811
23006-331
23006-811
2
39.6
23006-332
23006-812
3
60.0
23006-303
23006-813
23006-353
23006-833
4
80.3
23006-334
23006-814
23006-354
23006-834
5
100.6
23006-301
23006-815
23006-355
23006-835
6
121.0
23006-336
23006-816
7
141.2
23006-337
23006-817
8
161.6
23006-300
23006-818
23006-358
23006-838
Accessories
Kit to convert V I/O to 3.3 V 8 coding tabs, yellow, coding key, PU 1 kit
Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece
Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece
Termination adaptor, 64-bit bus for 8 slot CompactPCI backplane, 1 piece
SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece
Power Piggyback usable with backplanes with 3 slots and up, 1 piece
6 U, 64-bit, CompactPCI backplane
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
23006-372
23006-373
23006-862
23006-863
23006-374
23006-864
23006-375
23006-376
23006-865
23006-866
23006-377
23006-867
23006-378
23006-868
21101-658
23204-115
23204-116
23006-931
23204-113
23098-100
Page 10.20
Page 10.30
10.7
with system slot left
쮿 Versions: 3 U 32-bit and 64-bit, 6 HE 64-bit, with system slot left
쮿 Backplanes up to 5 slots are 66 MHz capable;
쮿 Outer layers act as GND surfaces
쮿 Multiple backplanes can be placed together without loss of
slots
12408001
쮿 Digital GND can be connected to/isolated from chassis-GND
by means of screws
FASTONs
PICMG 2.9
Delivery comprises
12408002
Item
1
2
Qty
1
1
Description
Set of M4x6 bolts, with lock washer; for power connection
Note
bridge (bridge for system slot left available on request)
Order Information
Number
of slots
Width
mm
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
1
19.3
23006-331
23006-811
23006-331
23006-811
2
39.6
23006-422
23006-732
3
39.6
23006-423
23006-733
4
80.3
23006-424
23006-734
5
100.6
23006-405
23006-715
6
121.0
23006-406
23006-716
8
161.6
23006-408
23006-718
23006-428
23006-738
Accessories
10.8
3.3 V V(I/O)
5 V V(I/O)
Part no.
Part no.
23006-443
23006-763
23006-444
23006-764
23006-445
23006-765
23006-448
23006-768
21101-658
23204-115
23204-116
23006-931
23204-113
Page 10.30
CompactPCI, packaging switching and
H.110 backplane
– PICMG 2.5 Computer Telephony specification (H.110)
– PICMG 2.16 CompactPCI Packet Switching Backplanes
– PICMG 2.11 CompactPCI Power Interface specification
쮿 Various versions
– CompactPCI, Packet Switching, H.110
– Backplanes for horizontal installation and backplanes for
horizontal installation including slots for plug-in power
supply (P47)
쮿 V(I/O) can be set to +3.3 V or +5 V
Photo shows 23006-797, 9 U
12405002
쮿 Backplanes up to 5 slots are 66 MHz capable,
쮿 Outstanding high frequency noise suppression and very high
by means of screws
PICMG 2.9
Delivery comprises
Item
1
2
Qty
1
1
Description
Note
Order Information
Number of
slots
2
2
2
4
4
6
Power connector
Data connection
System slot left, for horizontal mounting
64-bit CompactPCI bus
23006-792
6
23006-796
8
23006-797
8
ATX (male) connector
Mini-fit 10-pin
1 x P47
Mini-fit 24-pin
2 x P47
Mini-fit 24 pin
2 x P47 (optional third
connector)
2 x P47 (optional third and fourth
connectors)
connectors)
8
System slot right, for 6 U CompactPCI system,
power input without loss of slot space
Powerbugs
64-bit CompactPCI bus,
H.110 bus, PSB
H.110 bus
Part no.
23006-793
23006-794
23006-799
23006-795
23006-798
23006-611
23006-601
Part number in normal type: ready for despatch within 10 working days
10.9
CompactPCI bridges
– PICMG 2.6 CompactPCI Bridging Specification
– PCI 2.1 PCI Local Bus Specification, Rev. 2.1
쮿 Bridge mounted on rear of backplane, hence no loss of slots
쮿 Very compact and low bridge shape, no interference with rear
transition boards
쮿 Schroff CompactPCI backplanes with system slot right
are used as primary backplane
쮿 The 32-bit bridge is 33 MHz capable and the 64-bit bridge is
33/66 MHz capable
쮿 Bridges are designed for primary backplanes with system slot
right; bridges for system slot left available on request
쮿 A summary of possible backplane/bridge combinations can be
found on the Schroff website
Photo shows 32-bit and 64-bit bridges
12402002
Delivery comprises
Item
1
ServicePLUS see page 8.112
Qty
1
Description
Bridge
Order Information
Description
CompactPCI bridge, 32 bit, 33 MHz, for system slot right
Part no.
23006-920
Note
쮿 32-bit system slot left on request
쮿 64-bit system slot left on request
10.10
CompactPCI secondary backplanes,
system slot to right
– PICMG 2.1 R2.0 Hot-swap Specification
쮿 Secondary backplane for use behind the bridge
쮿 Secondary backplanes can also be used as tertiary backplanes;
change of geographical address see user manual
Delivery comprises
Item
1
2
Qty
1
1
Description
Kit screws M4 x 6, with lock washers, for power
connection
Order Information
Photo shows primary and secondary backplane with inserted
bridge and fitted rear transition board
12401021
Number of slots
Height
U
3
3
Description
4
32-bit
7
32-bit
Accessories
Part no.
23006-824
23006-827
Page 10.30
Note
쮿 Other configurations available on request or via
10.11
Backplanes – PXI
PXI backplanes
PXIMain Catalogue
– PXI Specification R 2.0
쮿 64-bit CompactPCI bus and PXI bus on the P2 plane
쮿 Clock generated on the backplane; feeding in an external clock
is possible, the backplane switches automatically between the
two clocks
쮿 Backplanes with up to 5 slots are capable of 66 MHz,
6 to 8 slot backplanes are set to 33 MHz operation
very high MTBF values due to ceramic capacitors
Photo shows 23006-578
12402004
쮿 Utility connector for status signals
to PICMG 2.9
Delivery comprises
Item
1
2
Qty
1
1
Description
PXI backplane
Kit screws M4 x 6, with lock washer, for power
connection
Order Information
Number of slots
System slot
5
left
7
left
8
left
4
left
Accessories
5 V V(I/O)
Part no.
primary
primary
primary
tertiary
23006-575
23006-577
23006-578
23006-594
Page 10.30
Note
10.12
Backplanes – VPX
VPX backplane, 3 U
VPXMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
– VITA 46.0 VPX base standard
– VITA 46.3 Serial RapidIO on VPX
– VITA 46.4 PCI Express on VPX Fabric Connector
– VITA 46.7 Ethernet on VPX Fabric Connector
– VITA 46.11 System Management on VPX
– Version with rear I/O: VITA 46.10 Rear Transition Module for
VPX
쮿 JTAG connections
쮿 3 U, 5 slot, 0.8” slot pitch, full mesh topology to VITA 46.21
distributed switching on VPX rule 4 – 5 with additional slot for
power supply
VPX backplane, 3 U, 5 slot, with rear I/O
10513002
쮿 3 U, 7 slot, conforms additionally to VITA 65 OpenVPX
– 6 payload slots, 1 switch slot with 1.0” slot pitch,
single star topology conforming to BKP3-CEN07-15.2.3-3
– Switch slot to SLT3-SWH-6F6U-14.4.1
– Payload slots to SLT3-PAY-2F2U-14.2.3
쮿 M4 power studs for power supply, max. 22 A per slot for each
voltage
쮿 Lockable aux utility and sense connectors
쮿 DIP switch for system slot settings
Order Information
Description
VPX backplane, 3 U, 7 slot, without rear I/O
10512002
Width
mm
Slot
pitch
Open VPX backplane, 3 U, 7
121.9
1,0"
176.0
1,0"
7 slot, with rear I/O
121.9
0,8"
without rear I/O
176.0
0,8"
with rear I/O
Accessories
Backplane
type
Part no.
Single star
23001-814
Single star
23001-815
Full Mesh
23001-812
Full Mesh
23001-813
Page 10.30
Note
쮿 Backplane to VITA 46.10; rear transition modules on request
10508004
Backplane mounting: a: conductive, b: isolated
10.13
Backplanes – VMEbus
Keying and alignment for VPX backplanes
VMEbusMain C atalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days
쮿 Conforms to VITA 46.0
쮿 Keying and alignment for VPX backplane slots with slot
spacings 0.8, 0.85 or 1"
쮿 Different versions for air-cooled and conduction-cooled
systems
쮿 Air-cooled systems additionally contain stiffening beads that
also prevent incorrect insertion of a VPX board (as per VITA 46.0
section 7.9)
쮿 Applications for versions with and without rear I/O
쮿 For board thicknesses 3.6 ... 5.5 mm and 5.5... 7.5 mm
쮿 Simple to fit into the fixing holes provided on every VPX
backplane
쮿 One packaging unit contains all components to completely
populate 10 slots
Delivery includes
Item
1
12402004
10.14
Qty
10
Description
Keying and alignment for one VPX slot
Order Information
Height Description
Type
U
3
3
3
3
3
3
3
3
6
6
6
6
6
6
6
6
Without Rear I/O
Without Rear I/O
With rear I/O
With rear I/O
Without Rear I/O
Without Rear I/O
With rear I/O
With rear I/O
Without Rear I/O
Without Rear I/O
With rear I/O
With rear I/O
Without Rear I/O
Without Rear I/O
With rear I/O
With rear I/O
Air-cooled
Air-cooled
Air-cooled
Air-cooled
Conduction cooled
Conduction cooled
Conduction cooled
Conduction cooled
Air-cooled
Air-cooled
Air-cooled
Air-cooled
Conduction cooled
Conduction cooled
Conduction cooled
Conduction cooled
Board
thickness
mm
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
3.6 ... 5.5
5.5 ... 7.5
Part no.
20836-550
20836-551
20836-552
20836-553
20836-558
20836-559
20836-560
20836-561
20836-554
20836-555
20836-556
20836-557
20836-562
20836-563
20836-564
20836-565
ELECTRONICS PROTECTION
Backplanes – VME64 extension
Monolithic VME64x backplanes (6 U)
VME64 extension Main C atalogue
ANSI/VITA 1-1994 VME64 Standard
ANSI/VITA 1.1-1997 VME64 Extension Standard
ANSI/VITA 1.5-2003 VME2eSST Specification
ANSI/VITA 1.7-2003 Increased Current Level
ANSI/VITA 38 System Management on VME
쮿 Monolithic backplane, 6 U with J1 and J2 plane
쮿 Termination passive
쮿 Electronic automatic daisy chain (EDC)
쮿 Connection or isolation between the digital GND and chassis
GND can be effected via the screw fittings (see photo)
쮿 Supply voltages can be applied via powerbugs (ring tag M4)
or FASTON
10502001
Photo shows 23001-551
쮿 System management bus (SMB) connector in accordance with
VITA38
쮿 Connector for additional voltages V1/V2 (see photo)
Delivery comprises
Item
1
2
Qty
1
1
Description
VME64x backplane
Kit screws M4 × 6, with lock washer;
Order Information
Number of
slots
10508004
10508007
Width
Height
Without P0
mm
U
Part no.
2
39.1
6
23001-502
3
59.5
6
23001-503
4
79.8
6
23001-504
5
100.2
6
23001-505
6
120.5
6
23001-506
7
140.8
6
23001-507
8
161.1
6
23001-508
10
201.8
6
23001-510
11
222.0
6
23001-511
12
242.4
6
23001-512
15
303.4
6
23001-515
16
323.7
6
23001-516
6
23001-520
21
425.3
6
23001-521
Accessories
With P0
Part no.
23001-532
23001-533
23001-534
23001-535
23001-536
23001-537
23001-538
23001-540
23001-541
23001-542
23001-545
23001-546
23001-550
23001-551
23204-113
23204-115
23204-116
Page 10.30
10.15
Backplanes – VXS
VXS
VXSMain Catalogue
ANSI/VITA 41 VXS VMEbus Switched Serial Standard
쮿 Parallel VMEbus on J1 and J2, serial data connections on P0
쮿 MultiGig RT2 connector on P0 position for data transfer rates
up to 10 Gbps per differential pair
쮿 Dual star, star and ring topologies
쮿 Keying and alignment pins to avoid mechanical and electrical
damage
쮿 Supply voltages can be applied via powerbugs (ring tag M4),
FASTONs or P47 connectors
Photo shows 23001-701
10506004
VITA38
Delivery comprises
Item
1
2
Qty
1
1
Description
VXS backplane
Order Information
Photo shows 23001-704
High-speed connector with keying and alignment pin
10508002
Number Width Height Description
of slots mm
U
1 VXS switch slot and 3 VXS
4
80.3
6
payload slots
4 VME64x slots, 3 VXS payload
slots, ring connected,
7
151.4 6
1 slot for 2 x 3 U PSUs,
without VXS rear I/O
2 VXS switch slots and 10 VXS
12
242.0 6
payload slots
2 VXS switch slots and 18 VXS
payload slots
Accessories
Keying and alignment pin for VXS Payload slot with RTM,
PU 10 pieces
Keying and alignment pin for VXS Payload slot without
RTM, PU 10 pieces
Keying and alignment pin for VXS Switch slots, PU
10 pieces
Part no.
23001-704
23001-701
23001-712
23001-720
23204-113
23204-115
23204-116
20817-900
20817-969
20817-970
Page 10.30
10508009
10.16
Backplanes – VMEbus
Monolithic J1/J2 backplane (6 U)
VMEbusMain C atalogue
쮿 In accordance with ANSI/VITA 1-1994 VME64 standard
쮿 Active/passive termination switchable via jumpers;
passive termination preset (see photo)
쮿 Linking/separation of digital and chassis GNDs by means of
a screw connection (see photo)
쮿 Supply voltages provided via power bugs (ring tag M4) or
FASTON
쮿 Two utility connectors for status signals,
two different configurations (see photo)
Delivery comprises
10506003
Photo shows 23001-069
Item
1
2
Qty
1
1
Description
VME monolithic J1/J2 backplane
Kit screws M4x6, with lock washer, for power connection
Order Information
Number of
slots
10508004
Width
mm
59.5
79.8
100.2
120.5
140.8
161.1
181.4
201.8
242.4
405.0
425.3
Height
U
6
6
6
6
6
6
6
6
6
6
6
Utility connector 2
3
MicroMatch
4
MicroMatch
5
MicroMatch
6
MicroMatch
7
MicroMatch
8
MicroMatch
9
SMCQ
10
MicroMatch
12
MicroMatch
SMCQ
21
MicroMatch
Accessories
length 350 mm, 2 × 12-pin female connector, 1 piece
length 600 mm, 2 × 12-pin female connector, 1 piece
Part no.
23001-063
23001-064
23001-065
23001-066
23001-067
23001-068
23001-069
23001-070
23001-072
23001-080
23001-081
23204-812
23204-811
23204-115
23204-116
Page 10.30
Note
c: termination switchover active/passive,
d: utility connector 1, e: utility connector 2
MicroMatch, f: utility connector 2 SMCQ
10509001
10.17
Backplanes – VMEbus
J1 backplane (3 U)
Main Catalogue
쮿 3 U with J1 plane
FASTON
쮿 Two utility connectors for status signals, two different
10506001
Photo shows 23001-020
Delivery comprises
Item
1
2
Qty
1
1
Description
VME J1 backplane
Kit screws M4x6, with lock washer; for power connection
Order Information
Number of
slots
10508004
10509001
Width
mm
20.2
39.1
59.7
79.8
100.2
120.5
140.8
161.1
181.4
199.2
242.4
303.4
341.4
364.3
405.0
425.3
Height
U
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
Utility connector 2
1
2
MicroMatch
3
MicroMatch
4
MicroMatch
5
MicroMatch
6
MicroMatch
7
SMCQ
8
MicroMatch
9
MicroMatch
10
SMCQ
12
SMCQ
15
MicroMatch
17
MicroMatch
18
MicroMatch
MicroMatch
21
MicroMatch
Accessories
Part no.
23001-001
23001-002
23001-003
23001-004
23001-005
23001-006
23001-007
23001-008
23001-009
23001-010
23001-012
23001-015
23001-017
23001-018
23001-020
23001-021
23204-812
23204-811
23204-115
23204-116
Page 10.30
10.18
Backplanes – VMEbus
J2 backplane (3 U)
Main Catalogue
쮿 3 U with J2 plane
쮿 Multiple backplanes can be placed side by side without loss
of slot space
쮿 Supply voltages can be provided via powerbugs (ring tag M4)
or FASTONs (see photo)
Delivery comprises
10506002
Photo shows 23001-046
Item
1
2
Qty
1
1
Description
VME J2 backplane
Order Information
Number of slots
Width
mm
40.4
59.7
79.8
100.2
199.2
321.3
425.3
Height
U
3
3
3
3
3
3
3
2
3
4
5
10
16
21
Accessories
Part no.
23001-032
23001-033
23001-034
23001-035
23001-040
23001-046
23001-051
Page 10.30
10508004
10508006
Supply voltage feed:
c: cable with blade receptacle pushed onto FASTON
d: cable with ring tag screwed to powerbug, with M4 screw and
lock washer
10.19
Backplanes
Com pac tP CIMAIN CATALO GP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days
쮿 In accordance with: PICMG 2.11 R1.0 CompactPCI Power
Interface specification and PICMG 2.9 R1.0 System
쮿 Single, parallel or redundant operation possible
쮿 Direct current outlets for high currents with virtually no voltage
reduction
쮿 Geographical address adjustable
쮿 Power supply over crimp contacts insertable into the plug, no
supply voltage on the backplane
쮿 Power cable available as an accessory
쮿 DC outlets with powerbugs for extremely low drops in voltage
Delivery includes
Item
1
2
Qty.
1
1
Description
Set, combination screw M4 x 6 in accordance with
DIN 6900
Order Information
01917001
Width Width Number of
Power
Height
slots
connector
HP
mm
U
8
39.6
1
1 x P47
3
16
80.3
2
2 x P47
3
8
39.6
1
1 x P47
6
8
39.6
1
2 x P47
6
Accessories
Power cable 3-wire, 500 mm, 1 piece
Utility/sense cable Flat ribbon cable, length 350 mm,
2 x 12-pin female connector, 1 piece
Utility/sense cable Flat ribbon cable, length 600 mm,
Current-sharing flat ribbon cable, 150 mm, 2 x 4-pin MicroMatch 1 piece
Part no.
23098-393
23098-394
23098-395
23098-396
23204-110
23204-115
23204-116
23204-113
23204-867
23204-812
23204-811
Power piggyback
쮿 Allows connection of pluggable power supplies, e.g. ATX PSUs,
to CompactPCI backplanes
쮿 Simply mounts on the PSU screw connections on the rear of
Delivery comprises
Item
1
Qty
1
Description
Power piggyback
Order Information
Description
Power piggyback
Qty/PU
1
Part no.
23098-100
12401002
10.20
Backplanes
UniversalMain Catalogue
With through-connected signal lines
쮿 Power supply at each connector position (row 1 + 32)
쮿 Adaptation fields for power connections on 2-layer backplanes
쮿 Two versions:
– 60 signal lines, through-connected from connector to
connector (C64), row „b“ can be freely wired (2 layers with
C96 connector), wire-wrap
– 90 signal lines, through-connected from connector to
connector
Without through-connected signal lines
쮿 Individual wiring of connectors is possible since signal lines
are not through-connected
쮿 Adaptation fields for connections
Universal backplanes with through-connected signal lines,
10 and 21 slot
12096003
Delivery comprises
Item
1
2
3
4
Qty
1
10
3
1
Description
Universal backplane
Bridges, grid 5.08 mm
Jumpers
10-pin header
Order Information
12006001
Universal backplanes without through-connected signal lines,
21 slots
Number Slot
of slots pitch
HP
10
4
10
4
10
4
14
3
21
4
21
4
21
4
21
4
28
3
28
3
28
3
Width No. of
layers
HP
42
2
42
2
42
4
42
2
84
2
84
2
84
2
84
4
84
2
84
2
84
2
Connector
type
No. of signal
lines
C64F
C96F
C96F
C64F
C64F
C96F
C96F
C64F
C96F
60
60
90
60
60
60
60
90
60
60
60
Part no.
23007-010
23007-040
23007-410
23007-114
23007-021
23007-051
23007-081
23007-421
23007-128
23007-158
23007-188
Connector "-": not equipped, 96 solder points
Order Information
Number of
slots
Slot pitch
HP
4
Width
HP
84
21
Accessories
No. of layers
2
Part no.
23007-222
Page 10.30
10.21
Test adaptors
Test adaptors, type B
Main Catalogue
쮿 For DIN 41612 connectors, type B
쮿 Measuring field for current and voltage measurement (U/I), (a)
쮿 Header with pin diameter 0.6 mm for wire wrap (b)
쮿 Outer pin rows (pin 1a, c and pin 32a, c) with wider
tracks for power supply (2 A per track)
Delivery comprises
Item
1
Qty
1
2
10
Description
Test adaptor with fitted guide rails and equipped
test bridges
Replacement test bridges
Order Information
Photo shows 23021-607
11100018
Connector
type
B64
B64
Height
U
3
3
For board
depth
mm
160
220
Backplane Measuring
type
field for
1L
1L
U/I
U/I
Part no.
23021-607
23021-651
Note
쮿 Detailed dimensions and test adaptor types see page 10.29
쮿 6/9 U test adaptors see page 10.27
a: Measuring field for current and voltage measurement
b: Header for wire wrap
11100019
10.22
Test adaptors
Test adaptors, type C
Main Catalogue
쮿 For DIN 41612 connectors, type C
쮿 2 different measuring fields:
– current and voltage measurement (U/I):
pluggable test bridges
– voltage measurement (U):
soldered test bridges
쮿 Connector type C64:
쮿 Connector type C96:
Slot for second test unit or terminator board (b)
쮿 Outer pin rows (C96: pin 1a, b, c and pin 32a, b, c;
C64: pin 1a, c and pin 32a, c) with wider tracks for
Delivery comprises
Photo shows 23021-609
11100003
Item
1
Qty
1
2
10
Description
test bridges
Order Information
Connector
type
b: Connector position for a second test object
11100004
Height
U
3
3
6
3
3
3
3
3
3
3
3
6
6
6
6
C 64
C 64
C 64
C 96
C 96
C 96
C 96
C 96
C 96
C 96
C 96
C 96
C 96
C 96
C 96
For board
depth
mm
160
220
160
160
160
160
220
220
280
280
340
160
160
220
280
Backplane Measuring
type
field for
1L
2L
1L
2L
2L
4L
2L
4L
2L
4L
4L
2L
4L
2L
2L
U/I
U/I
U/I
U
U/I
U/I
U/I
U/I
U/I
U/I
U/I
U/I
U/I
U/I
U/I
Part no.
23021-608
23021-652
23022-601
23021-603
23021-609
23021-610
23021-653
23021-654
23021-700
23021-701
23021-750
23022-602
23022-603
23022-652
23022-700
Note
10.23
Test adaptors
Test adaptors, type D
Main Catalogue
쮿 For DIN 41612 connectors, type D
쮿 Outer pin rows (pin 1a, c and pin 16a, c) with wider tracks for
Delivery comprises
Photo shows 23021-611
11100005
Item
1
Qty
1
2
10
Description
test bridges
Order Information
Connector
type
D32
D32
D32
Height For board
depth
U
mm
3
160
3
160
3
220
Backplane
type
Measuring
field for
1L
1L
1L
U/I
U
U/I
Part no.
23021-611
23021-604
23021-655
Note
11100006
쮿 Test adaptor type D cannot be used in combination with the
adapter of other types
Test adaptors, type E
Main Catalogue
쮿 For DIN 41612 connectors, type E
쮿 Outer pin rows (pin 1a, c, e and pin 31a, c, e) with wider tracks
Delivery comprises
Item
1
Qty
1
2
10
Description
test bridges
Order Information
Photo shows 23021-656
11107001
Connector
type
E48
Height For board
depth
U
mm
3
220
Backplane
type
Measuring
field for
2L
U/I
Part no.
23021-656
Note
10.24
11107002
Test adaptors
Test adaptors, type F
Main Catalogue
쮿 For DIN 41612 connectors, type F
– voltage measurement (V):
쮿 Outer pin rows (pin 1a, c, e and pin 16a, c, e) with wider tracks
Delivery comprises
Photo shows 23021-613
11100008
Item
1
Qty
1
2
10
Description
test bridges
Replacement bridges
Order Information
Connector
type
F48
F48
F48
F48
Height For board
depth
U
mm
3
160
3
160
6
160
3
220
Backplane
type
Measuring
field for
2L
2L
2L
2L
U
U/I
U/I
U/I
Part no.
23021-605
23021-613
23022-604
23021-657
Note
11100009
쮿 Further 6/9 U test adaptors see page 10.27
Test adaptors, type M
Test adaptorsMai n C atalogue
쮿 For DIN 41612 connectors, type M
쮿 2 versions:
- M (F/H): with high-current contacts (H)
- M (C/coax): with coaxial connector contact
쮿 Measuring field versions for current and voltage measurement
(U/I):
– M (F/H):
F: measurement lugs (a) and
measurement pins (b) with jumpers
H: test bridges (c) (diameter 4 mm)
– M (C/coax):
C: test bridges pluggable,
header with pin diameter 0.6 mm for wire wrap
Photo shows 23021-616
11100013
Delivery comprises
Item
1
Qty
1
2
10
Description
test bridges
Order Information
Connector
type
M (F24/H7)
M (F24/H7)
11100014
Test adaptor M (F24/H7), a: Measurement lugs,
b: Measuring pin with jumper, c: Test bridge, diameter 4 mm
SCHROFF.PENTAIR.CO.UK
Height For board
depth
U
mm
3
160
3
220
Backplane
type
Measuring
field for
2L
2L
U/I
U/I
Part no.
23021-616
23021-660
Note
Part number in bold face type: ready for shipping within 2 working days
10.25
Test adapters
Test adaptors for VMEbus
Main Catalogue
쮿 Layout of conductive tracks and layer build-up match the
requirements of the VME bus
쮿 Measuring field version for current and voltage measurement
(V/I), (a)
쮿 Additional measuring pins, e.g. for the probe tips of an
oscilloscope (b)
쮿 1 pin position for second test object,
1 pin position for terminator board
쮿 Voltage supply lines are designed for 2 A
쮿 6 U test adaptors consist of two 3 U test adaptors
linked via an intermediate adaptor
Delivery comprises
Item
1
Qty
1
2
10
Description
test bridges
Order Information
Photo shows 6 U test adaptor
11192004
Height
U
3
3
3
3
6
6
6
For board depth
mm
160
160
220
220
160
220
280
Connector type
P1
P2
C96
C96
C96
C96
C96
C96
C96
C96
C96
C96
Part no.
23021-001
23021-100
23021-002
23021-101
23022-002
23022-004
23022-010
P1 = system bus, P2 = I/O bus
Note
쮿 9 U test adaptor see page 10.27
Dimensions table VMEbus test adaptors
a: measuring field for current and voltage measurement
b: Measuring pin, e.g. for test prod
11196001
Board height
3U
6U
F (mm)
123.65
257
For board depth
A (mm)
160 mm
423
220 mm
483
280 mm
543
A = overall length, B = extension
Dimensional drawing of test adaptor
G (mm)
100
233.35
B (mm)
350
410
470
C (mm)
237
297
417
D (mm)
175.24
235.24
355.24
taa43143
10.26
Test adapters
6/9 U test adaptors
6U
Main Catalogue
쮿 Suitable for types B, C, D, E, F
쮿 6 U test adaptor can be made from:
– 2 × equal length 3 U test adaptors (3/4)
– 1 × intermediate adaptor 6 U (1)
or
– 1 × 3 U test adaptor (3/4)
– 1 × bare board (item 2 without connector)
A4-2550
9U
쮿 9 U test adaptor can be made from:
– 3 × equal length 3 U test adaptors (3/4)
– 2 × intermediate adaptor 9 U (1)
or
– 2 × 3 U test adaptors (3/4)
or other combinations
test adaptor item 4, type x
bare board: item 3
Delivery comprises (kit)
Item
1
Qty
6U
1
9U
2
Description
2
2
Intermediate adaptor, St, 1.5 mm, grey,
incl. assembly kit
Board stiffener
Order Information
Description
For board depth
For test adaptor
depth (dimension B)
mm
290
350
410
470
350
mm
6U
160
6U
220
6U
280
6U
340
9U
220
Accessories
Bare board (item 2) 3 U, 160 mm deep without connector, 1
piece
Bare board (item 2) 3 U, 220 mm deep without connector, 1
piece
BPTE6567
Part no.
20800-224
20800-168
20800-278
20800-279
23040-001
23040-006
23040-007
Note
쮿 Test adaptor type D cannot be combined with other types
쮿 Test adaptor depth (dimension B) of VMEbus test adaptors
see page 10.26
쮿 Test adaptor depth (dimension B) at type B, C, D, E, F,
see page 10.29
10.27
Test adapters
Board guides
Main Catalogue
쮿 To hold and lock modules that have to be tested (for
replacement purposes only, board guides are included
in delivery of all test adaptors)
쮿 Versions
– Short board guide with/without locking lever
– Long board guide with/without locking lever
Order Information
Description
Type: short, with locking lever
Type: short, without locking lever
Type: long, with locking lever
Type: long, without locking lever
Top: with locking lever, left short, right long;
bottom: without locking lever, left short, right long
Short board guide
Qty/PU
2
1
2
2
Part no.
60800-834
60800-032
20800-212
20800-213
11192009
A4-1908
A4-2411
Short board guide without locking lever
A, B, see "Dimensions test adaptors"
Long board guide without locking lever
10.28
A4-2551
Test adapters
Types/board versions
Epoxy fibreglass EP-GC02 to DIN 40802 (FR4).
Outlying connections (e.g. pins 1a, b, c and pins 32a, b, c) each
have a wider PCB track or large-surface tracks on inner layers –
e.g. for shielding, Vcc, GND.
Type
1L
2L
4L
PCB single-sided, laminated (suitable for up to 2 MHz)
PCB, double-sided, laminated and through-connected
(suitable for up to approx. 8 MHz)
Multi-layer, 4-layer (suitable for above 8 MHz):
Multi-layer technology with large-area inner layers
(signal–surface–surface–signal).
In the coax version the large-area inner layers can be
soldered to the desired pins by means of power links.
쮿 Types B, C, E, F, H and M
Board height
3U
6U
Board depth
160 mm
220 mm
280 mm
340 mm
F
mm
123.00
257.00
G
mm
100.00
233.35
A
mm
363
423
483
543
B
mm
290
350
410
470
C
mm
190
250
310
370
D
mm
175.24
235.24
355.24
415.24
taa43143
1)
2)
3)
4)
5)
6)
Board guide
Measuring field
Mounting bracket with extraction aid
Test adaptor
Male connector
Female connector
10.29
Test adapters
Panhead screws
Description
Torx panhead
screw
aza45940
Screw +
securing washer
Application
Material
Dimension
Qty/PU
For backplane fixing
St, nickel-plated
M2.5 х 12
100
24560-161
Part no.
St, nickel-plated
M2.5 х 14
100
24560-162
St, nickel-plated
M2.5 х 16
100
24560-163
St, nickel-plated
M2.5 х 12
100
21100-777
06702051
10.30
Test adapters – ServicePLUS
configuration
Simple. Fast. For the product you want.
Equipped to customer specification
쮿 Appropriate solutions from our standard range or individual
solutions
쮿 Equipping options: e.g.: do not equip unused connectors,
VME with ADC or MDC, set CPCI to 3.3 V, …
쮿 Online configuration enquiry:
modification
Small design alterations to off-the-shelf
products
쮿 Minor modifications to our standard-backplane designs,
customized modifications
쮿 Conformal coating
solution
System integration and custom developments
쮿 Development, simulation and design to customer specification;
Production of prototypes, pilot series and production series
쮿 Simulation and testing
academy
쮿 Test reports, user reports, user manuals for download
ServicePLUS
10.31
PROLINE
Main C atalogue
FPCS front element system
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
Front element systems
Front panels,
Power supply
Backplanes . . . 10
Busbars
Connectors, front
panel component
05092001 00892005 36103009
11.0
SCHROFF Main catalogue
www.schroff.biz E 07/2016
Overview . . . . . .11.0
Connectors/
busbars . . . . . . . 11.2
Front element
systems . . . . . . . 11.12
Electrical
components
see
europacPRO
subrack section 6.65
Connectors
Electrical components
05596002 01494031 36103009
11.1
Main C atalogue
Connectors, busbars
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
Subracks/
Front panels,
Power supply
05592002
Standards
Modifications
쮿 Connectors in accordance with:
IEC 60603-2 / DIN 41612
Extended delivery program
Requirements classes DIN 41612, Part 5
Requirements class 1
- 500 connector cycles
- 250 connector cycles, 21 day gas test with
10 ppm SO2, measurement of contact resistance
- 250 connector cycles, then visual inspection,
no abrasion of contact surface down to the base
metal, no impairment of function
Requirements class 2
- 400 connector cycles
- 200 connector cycles, 4 day gas test with
- 200 connector cycles, then visual inspection,
쮿 Connectors to IEC 60603-2
with requirements classes 1, 3 and
defence equipment standard
Minimum quantity: 300 pieces
쮿 Connectors with selective contacts
Minimum quantity: 500 pieces
쮿 Complementary types to standard IEC 60603-2
(„half“ type)
쮿 Not catalogued connectors to IEC 60603-2
Note:
Prices and delivery times available on request
Requirements class 3
- 50 connector cycles, no gas test, then visual
inspection, no impairment to function
Backplanes . . . 10
Connectors, front
panel component
Requirements class VG 95 324, part 1
- 500 connector cycles, then 1 day gas test with
10 000 ppm SO2 and 1 day gas test with 10 000 ppm
H2S, then visual inspection, no abrasion of contact
surface down to base metal, no impairment of
function
11.2
SCHROFF PRODUCT CATALOG E 05/2016
Connectors, busbars
Overview . . . . . . 11.3
Connectors Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days
General technical data
Contamination level 1
None or dry, non-conductive contamination.
Contamination has no effect.
Contamination level 2
Non-conductive contamination only.
Occasional transient conductivity due to condensation
may occur.
Contamination levels 3 and 4 are not taken into account
as they do not apply to the connectors listed in this
catalogue.
The minimum creepage distances represented in the
table relate to the CTI values of insulation group III a/b.
Text
25
32
0.125 0.14
0.50 0.53
50
63
80
100
125
160
200
250
320
400
500
630
800
1000
0.18
1.2
0.2
1.25
0.22
1.30
0.25
1.40
0.28
1.50
0.32
1.60
0.42
2.00
0.56
2.50
0.75
3.20
1.0
4.0
0.3
5.0
1.8
6.3
2.4
8.0
3.2
10
Operating current
The current-carrying capacity of connectors is restricted by the thermal loading
capacity of the materials, the contact elements - including connections - and
insulation elements.
The derating curve applies therefore for currents that may flow continuously
(not intermittently) and simultaneously through each contact element of the
connector without exceeding the maximum acceptable temperature.
Measurement and control procedures in accordance with DIN 41 640, part 3.
Text
Keying/coding
pegs for codable
female
connectors . . . . . . 11.7
PCB
strengthening . . . . 11.8
Connectors,
3-pin . . . . . . . . . . . . 11.9
4-pin for Faston
connector
6.3 x 0.8 mm . . . . . 11.10
PCB busbars . . . . . 11.11
Busbars . . . . . . . . . 11.11
Type H
Operating current
Operating current
Keying/coding . . . . 11.7
Ambient temperature
Type D, E, F, G
Ambient temperature
Ambient temperature
Type H
Operating current
Type D, E, F, G
Operating current
11.4
Blank connector
housings/locking
levers . . . . . . . . . . . 11.6
Busbars
Derating diagrams
Type B, C, R
Connector types
Keying/coding
strips . . . . . . . . . . . . 11.8
Reference voltage, minimum creepage distance and
contamination level
Reference voltage
12.5
V UACeff or U
Minimum creepage
distance in mm
- Contamination level 1 0.09
- Contamination level 2 0.42
Connectors
Ambient temperature
Ambient temperature
sva42501 sva42502 sva42503 sva42504 sva42505
Main Catalogue
11.3
Accessories – Connectors
Overview of types, connectors EN 60603 (DIN 41612)
Order Information
Description
Number of
Row
contacts assignment
Type B
Type C
b a
Drawing: View of rear of plug
Male connector
c b a
Type R
Type D
c
a b c
c (b) a
1
2
3
4
5
6
1
2
3
4
5
6
1
2
3
4
5
6
1
2
3
4
5
6
2
28
29
30
31
32
28
29
30
31
32
28
29
30
31
32
28
29
30
31
32
28
05508052
05508053
05508054
a
4
6
8
30
32
05509052
05508055
1 piece
1 piece
1 piece
1 piece
1 piece
69001-826
69001-831
69001-821
69001-816
a, c
a, c
a, b, c
69001-691
69001-685
69001-679
a, c
69001-697
32
64
64
96
a, c
a, b
a, c
a, b, c
Wire-wrap pins, length 13 mm,
0.6 mm x 0.6 mm, straight;
32
64
96
Wire-wrap pins, length 20 mm,
1 mm x 1 mm, straight;
32
Solder pins, length 3 mm, 0.6 mm x 0.6 mm;
angled
Type C for ribbon
cables
69001-801
Female connector
64
a, b
64
a, c
96
a, b, c
64
a, c
0.6 mm x 0.6 mm, angled
96
a, b, c
64
a, c
Solder pins, length 4 mm,
Ø 0.6 mm, straight
96
a, b, c
Solder eye, length 5.5 mm
32
a, c
Snap-on/screw-on for 64-pin cable
64
a, c
Spring contacts for crimping, 0.14 - 0.5 mm2, 50 pieces
Spring contacts for crimping, 0.75 - 1.5 mm2, 50 pieces
Torx panhead screw M2.5 × 7, PU 100 pieces, for direct mounting on z-rail
Solder pins, length 2.5 mm,
Ø 0.6 mm, straight
Technical Data
Connector pitch
Current load max. at 20 °C
Test voltage Ueff contact-contact
Test voltage Ueff contact-earth
Contact resistance
Coding on the connector
Separate coding
Contact surface
Air gap contact-contact
Creepage distances contact-contact
Insertion and withdrawal forces
69001-664
69001-693
69001-696
24560-147
Type B
69001-976
69001-728
24560-147
24560-147
24560-147
21100-293
21100-294
24560-147
Type C
Type C for
ribbon cables
2.54 mm
1
A
1 kV
yes
solidly
gold-plated
Type R
Type D
69001-678
69001-677
2.54 mm
2.54 mm
2
A
2
A
1 kV
1 kV
1.55 kV
1.55 kV
≤ 20 mΩ
≤ 20 mΩ
yes
yes
solidly
solidly
gold-plated
gold-plated
>1.2 mm
>1.2 mm
>1.2 mm
>1.2 mm
32-pin < 30 N; 64-pin < 60 N;
96-pin < 90 N
69005-596
64-pin < 60 N
2.54 mm
2
A
1 kV
1.55 kV
≤ 20 mΩ
yes
solidly
gold-plated
>1.2 mm
>1.2 mm
64-pin < 60 N;
96-pin < 90 N
69001-698
5.08 mm
6
A
1.55 kV
1.55 kV
≤ 20 mΩ
yes
solidly
gold-plated
>1.6 mm
>3.0 mm
32-pin < 40 N
Note
쮿 Connectors are compliant with requirements class 2
ConnectorsMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
11.4
Order Information
Description
Number of
Row
contacts assignment
Male connector
Solder pins, length 2.9 mm,
0.6 mm x 0.6 mm; angled
1.2 mm x 0.8 mm; angled;
connector pins not protruding
Solder pins, recessed, length 2.9 mm,
FASTON connector 6.3 mm x 0.8 mm;
straight
FØ 0.6 mm, H Ø 1.6 mm; angled
Type E
Type F
e c a
Type G
d b z
2
4
6
8
10
12
2
4
6
8
10
12
24
26
28
30
32
24
26
28
30
32
05509050
d
f d b z
2
4
6
8
10
12
14
05509051
Type H
Mixed type (M),
type F and type H
z
z
6
4
32
8
28
10
30
26
24
14
26
28
30
32
d
14
24
26
28
30
32
05508056
05508057
4
2
z b d
1 piece
1 piece
1 piece
1 piece
1 piece
69001-851
69001-853
69001-846
69001-856
z, d
69001-865
15
z, d
69001-860
15
z, d
69001-866
24+7-pin
z, b, d
69001-905
32
48
48
64
z, b
a, c, e
z, b, d
z, b, d, f
69001-717
24+7-pin
32
32
48
48
64
z, b
z, d
a, c, e
z, b, d
z, b, d, f
15
69001-879
05508057
Female connector
Wire-wrap pins, length 22 mm,
1 mm x 1 mm; straight
F: Wire-wrap pins, length 22 mm,
1 mm x 1 mm; H: FASTON connector
6.3 mm x 0.8 mm; straight
0.8 mm x 0.8 mm; straight
Solder pins, length 4.5 mm,
0.4 mm x 0.6 mm; straight
Solder pins, length 10 mm,
Wiring with FASTON connector
Solder eyes, length 9.5 mm
69001-711
69001-723
z, b, d
69001-755
15
z, d
69001-981
48
z, b, d
69001-884
15
z, d
69001-980
15
z, d
69001-733
32
32
48
z, b
z, d
z, b, d
69001-718
69001-722
69001-712
69001-944
24560-147
24560-147
24560-147
24560-147
24560-147
Type E
Type F
Type G
Type H
Mixed type (M),
type F and type H
5.08 mm
10.16mm
6 A
15 A
1.55 kV
3.10 kV
2.50 kV
3.10 kV
≤ 20 mΩ
≤ 8 mΩ
yes
yes
solidly
hard
gold-plated silver-plated
>1.6 mm
>4.5 mm
>3.0 mm
>8.0 mm
F: Solder eyes; H: FASTON connector
24+7-pin z, b, d
z-rail
Technical Data
Connector pitch
Contact resistance
Separate coding
Contact surface
69001-877
5.08 mm
6 A
1.55 kV
1.55 kV
≤ 20 mΩ
yes
solidly
gold-plated
>1.6 mm
>3.0 mm
48-pin < 75 N
5.08 mm
5.08 mm
6 A
6 A
1.55 kV
1.55 kV
2.50 kV
2.50 kV
≤ 20 mΩ
≤ 20 mΩ
yes
yes
solidly
solidly
gold-plated
gold-plated
>1.6 mm
>1.6 mm
>3.0 mm
>3.0 mm
32-pin < 50 N
64-pin < 100 N
48-pin < 75 N
10.16 mm
15 A
3.10 kV
3.10 kV
≤ 8 mΩ
yes
yes
hard
silver-plated
>4.5 mm
>8.0 mm
15-pin < 90 N
24+7-pin < 85 N
Note
Connectors
Part number in bold face type: ready for despatch within 2 working days
11.5
Blank connector housings/locking levers
쮿 For types C and R
쮿 The connector housing is fixed to the board with screws; it is
pushed over wire wrap posts (e.g. on the rear of backplanes)
and thereby forms a male connector
쮿 Locking levers can be used e.g. to lock terminator boards or
I/O connectors in place
Order Information
Item
A4_2449
1
2
2
4
4
Description
Housing with M 2.5 nuts,
for posts 0.6 × 0.6 × 17 mm,
backplane thickness 3.2 mm
for posts 0.6 × 0.6 × 13 mm,
backplane thickness 1.6 mm
Locking lever for type R, grey
Locking lever for type C, black
Qty/PU
Part no.
1
29090-001
1
29090-002
1
29001-019
1
1
69001-995
69001-106
Note
쮿 29090-001 is the replacement product for 69001-210 and
29001-015
쮿 29090-002 is the replacement product for 69001-814 and
29001-016
쮿 29001-019 is the replacement product for 69001-311
A3_401
11.6
Keying/coding pegs for codable female connectors
Connectors
쮿 For female connector type H
쮿 Without loss of space
쮿 Max. 70 keying/coding possibilities
쮿 The keying/coding pegs are plugged into the female connector;
the corresponding keying/coding fields (situated opposite) of
the male connectors are broken out
Order Information
Description
Keying/coding pegs, PBTP, UL 94 V-0
A4-2481
Qty/PU
40
Part no.
21101-252
Keying/coding
쮿 Keying/coding prevents plug-in units becoming mixed up
쮿 Keying/coding for type H
– Fixing direct onto plug by means of keying/coding peg in the
female connector
쮿 Keying/coding for all types in accordance with EN 60603
(DIN 41612)
– Fixing via additional mounting of keying/coding strips
Keying/coding pegs
Part no.
Part no.
69001-733
21101-252
69001-980
69001-981
11.7
Keying/coding strips
Connectors
쮿 For all types in accordance with EN 60603 (DIN 41612)
쮿 Used with plug-in units to prevent mix-up
쮿 Space for plugs with keying/coding strip:
– 4 HP for types B, C, D, F, H
– 5 HP for types E, G
쮿 66 keying/coding possibilities when two coding pins are used
쮿 924 keying/coding possibilities when six coding pins are used
Order Information
Item
Description
Contact strip PBTP, UL 94 V-0, 10 pieces,
female strip, PBTP, UL 94 V-0, 10 pieces,
1, 2, 3
keying/coding pins, PBTP, UL 94 V-0,
20 pieces
1, 2, 3 Spacer element for types E, G
3
Keying/coding pin
Assembly kit Screw M2.5 × 18, PU 100 pieces
Qty/PU
Part no.
1
20800-042
20800-036
20800-078
21100-404
Note
A4-2424
쮿 For connectors types E and G spacers are always required
PCB strengthening (9 U)
쮿 Protects large PCBs from bending
쮿 Creates an additional crossbar (in accordance with IEEE
recommendations, P 896, Nubus, Multibus® II etc.) that links
all connectors
쮿 Fixing points match connectors in accordance with
EN 60603 (DIN 41612), types B, R, C and D
LKA42609
Item
1
Qty
1
2
3
6
6
Description
PCB strengthening, Al extrusion, anodised, cut edges
plain; separator, stainless steel, riveted on
Cheesehead screw M 2,5 × 12, St, nickel-plated
Washer 2.6, St, nickel-plated
Order Information
Description
For 9 U PCBs
Height H
mm
361.6
Part no.
20809-441
LKA42593
11.8
Connectors, 3-pin
Connectors
쮿 Used for mains/line voltage supplies
쮿 Male connector with advanced earth protection contact (B)
Order Information
Item Description
Qty/PU
1
2
1
1
69001-651
1
30812-002
3
Male connector
Female connector strip
Mounting plate for fixing in subrack,
socket terminal strip mounts on z-rail
(with threaded holes to EN 60603,
DIN 41612)
Part no.
69001-652
05592043
Technical data
Dimensional drawing of multi-pin connector
A4-5316
Nominal current per contact
Air gap
Creepage distance
Test voltage
Contact resistance
Connection
Ambient temperature
Contact pins, sockets
Housing material
Flammability
Dimensional drawing of socket terminal strip
10 A
≥ 4.4 mm
≥ 7.6 mm
3 kV (eff)
approx. 10 mΩ
Solder eye connection up to 1 mm
23 °C ... 130 °C
galvanically silver-plated
Keripol R gray
(type 802 as per DIN 16911)
UL 94-HB
05009052
3
2
3: Mounting plate
2: Socket terminal strip
A4-5317
A4--2486a
Dimension drawing of mounting plate
11.9
Accessories – Horizontal busbars
Busbar, 4-pole, for Faston connectors, 6.3 x 0.8 mm
Horizontal busbarsMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days
쮿 24 connection points (4-poles, 6 connectors each)
쮿 To supply mains voltage to 19" subracks
쮿 Fixing in HP grid increments (spacing 15 HP), external
dimension < 17 HP
Delivery comprises
Item
1
00811001
5 x 10,15 (50,8)
Qty
1
Description
Busbar, 4-pole (for 6 Faston connectors
6.3 x 0.8 mm
Order Information
Description
3 x 5,08
5,08
10,16
0,8
Technical data
11,6
6,3
69001-073
21,2
85,8
10,9
4,2
Operating voltage
Test voltage: Bar – Bar
Test voltage: Pin – Earth
Operating current at 20 °C per pin
(= 6 connections)
Temperature range
Material: Faston, busbars
Material: insulating body
Connector type
Connection pitch
75,8
Part no.
69001-073
5
00811050
250 VAC
3.5 kVeff
5.0 kVeff
∑ l ≤ 35 A
-40 °C ... +100 °C
CuZn, surface tin-plated
PC/ABS, UL 94-V0
for Fastons 6.3 × 0.8 mm,
4-pin, 6 Fastons per pin
5.08 × 10.16 mm
Note
쮿 Other lengths, 2-pole and 3-pole versions, brass contacts
11.10
PCB busbars
Main Catalogue
쮿 Power distribution on printed circuit boards and backplanes
쮿 Fault elimination
쮿 Increases the stiffness of PCBs
Order Information
Width B
HP
3
3
4
4
5
5
00892008
Length L
mm
220.3
342.3
210.2
332.1
210.2
337.2
Dimension A
mm
14 × 15.24 = 213.36
22 × 15.24 = 335.28
10 × 20.32 = 203.2
16 × 20.32 = 325.12
8 × 25.4 = 203.2
13 × 25.4 = 330.2
Part no.
30925-001
30925-002
30925-003
30925-004
30925-005
30925-006
Delivery is exclusively in Standard Pack Quantity (SPQ): Please
order at least 10 pieces or a multiple. Pricing is per individual
item.
Technical data
Conductor material
Pin dimensions
Max. operating current
DC resistance
E-Cu, tin-plated
0.8 x 1.0 mm
30 A
2.5 mΩ/m
Note
쮿 Special designs available on request
A41743
Solder strip conductor
Main Catalogue
쮿 Efficient linking of connections in the same grid and with the
same potential
쮿 Also suitable for EN 60603 (DIN 41612) connectors with
wire-wrap pin
Order Information
Connection
type
A
mm
Wire-wrap pins
1.14
0.6 × 0.6 mm
Wire-wrap pins
1.65
1.0 × 1.0 mm
B
mm
C
mm
D
mm
n
Qty/PU
Part no.
0.9
2.54
2.3
168
1
60800-064
1.4
5.08
3.2
84
1
60800-080
Technical data
00892016
Conductor material
wire-wrap pins 0.6 × 0.6 mm
wire-wrap pins 1.0 × 1.0 mm
E-Cu F30, tin-plated
≤4A
≤4A
AZA42390
11.11
Front panel component sys temMain Catalogue
Front panel component system
Content
Wall mounted
Accessories for
cabinets and wall
mounted cases . 3
Climate control . 4
Electronics
05092001
Subracks/
Front panels,
05092004
Components are pre-mounted in
plastic bodies that can be arranged
in rows; horizontal grid (3 planes)
and vertical grid (8 or 16 planes)
05092008
A mounting frame with integrated
PCB bracket fixes the front
elements and forms the
mechanical link between PCB, front
elements and front panel
Front element system in use
05092002
Standards
Power supply
쮿 IEC 60297-3-101
IEC 60603 (DIN 41494 part 8)
Backplanes . . . 10
Connectors, front
panel component
11.12
Overview . . . . . . 11.12
Front panel com ponent system Main Catalogue
Operating and display elements for front panels
쮿 Pre-assembled front element components
쮿 Mounting frames with integrated PCB brackets
쮿 Assembled front elements can be soldered in one step
쮿 Subsequent front panel mounting
system
Single LEDs . . . . . . 11.14
Double LEDs . . . . . 11.16
Technical data
LEDs . . . . . . . . . . . . 11.17
Test sockets . . . . . 11.18
Make-break
socket . . . . . . . . . . . 11.19
Technical data for
test and makebreak sockets and
fuse holders . . . . . 11.20
LEDs (light-emitting diodes)
05092009
Test and make-break sockets
05092005
Potentiometers . . 11.21
Mounting frames . 11.22
Drilling template . 11.23
Design aids . . . . . . 11.24
Potentiometers
PCB brackets
05092007
Fuse holders
05092006
05092008
11.13
Single LED, long type, Ø 3.2 mm
Front panel component systemMain C ataloguePart number in bold face type: ready for des patch within 2 working daysP art number in normal type: ready for despatch within 10 working days
쮿 Long type for mounting planes 1, 2 and 3
Order Information
Description
Colour
1
Part no.
2
Part no.
3
Part no.
Low current LED
Low current LED
Low current LED
Standard LED
Standard LED
Standard LED
red
yellow
green
red
yellow
green
69004-240
69004-242
69004-258
69004-262
69004-259
69004-263
69004-241
69004-260
69004-261
69004-059
69004-065
69004-060
69004-066
69004-061
69004-067
69004-062
69004-063
69004-064
Please order at least 10 pieces or a multiple. Pricing is per
individual item.
Note
1, 2, 3 = mounting planes
A3-195
쮿 Dimensions of connecting pins:
0.5 × 0.5 mm (mounting plane 1)
0.63 × 0.63 mm (mounting planes 2 and 3)
쮿 Required front panel drill hole: Ø 4 mm
쮿 Technical data see page 11.17
Single LED, short type, Ø 3.2 mm
쮿 Short type for mounting plane 1
Order Information
Colour
Low current LED
Part no.
Standard LED
Part no.
red
yellow
green
69004-264
69004-121
69004-266
69004-123
69004-265
69004-122
individual item.
Note
쮿 Dimensions of connecting pins: 0.5 × 0.5 mm
1 = mounting plane
11.14
A3-214
Single LED, long type, Ø 5 mm
Front panel c omponent system
쮿 Long type for mounting plane 1, 2 and 3
Order Information
Description
Colour
1
Part no.
2
Part no.
3
Part no.
Low current LED
Low current LED
Low current LED
Standard LED
Standard LED
Standard LED
red
yellow
green
red
yellow
green
69004-250
69004-249
69004-251
69004-256
69004-252
69004-257
69004-253
69004-254
69004-255
69004-050
69004-056
69004-051
69004-057
69004-052
69004-058
69004-053
69004-054
69004-055
individual item.
Note
A1-194
쮿 Required front panel drill hole: Ø 8 mm
11.15
Double LED, long type, Ø 3.2 mm
쮿 Long type for mounting plane 1 and 2
Order Information
1, 2 = mounting plane
A3-196
Description
Colour
Low current LED
Low current LED
Low current LED
Low current LED
Low current LED
Low current LED
Standard LED
Standard LED
Standard LED
Standard LED
Standard LED
Standard LED
red/red (Y/Z)
green/green (Y/Z)
yellow/yellow (Y/Z)
red/green (Y/Z)
red/yellow (Y/Z)
yellow/green (Y/Z)
red/red (Y/Z)
green/green (Y/Z)
yellow/yellow (Y/Z)
red/green (Y/Z)
red/yellow (Y/Z)
yellow/green (Y/Z)
1
Part no.
2
Part no.
69004-274
69004-276
69004-275
69004-277
69004-278
69004-279
69004-280
69004-282
69004-281
69004-284
69004-068
69004-071
69004-069
69004-072
69004-074
69004-075
69004-077
69004-080
69004-078
69004-083
individual item.
Note
쮿 Dimensions of connecting pins: 0.63 × 0.63 mm
Double LED, short type, Ø 3.2 mm
Order Information
Colour
red/red (Y/Z)
yellow/yellow (Y/Z)
green/green (Y/Z)
red/green (Y/Z)
red/yellow (Y/Z)
yellow/green (Y/Z)
Low current LED
Part no.
Standard LED
Part no.
69004-286
69004-124
69004-288
69004-126
69004-287
69004-289
69004-125
69004-127
69004-290
69004-128
69004-291
69004-129
individual item.
Note
1 = mounting plane
11.16
A3-217
Dimensions LEDs
A = standard LED
B = low current LED
Absolute maximum data
Ta = 25 °C
Reverse voltage V
On-state current mA
Power dissipation mW
Forward current mA
(t < 10 μs)
Forward voltage V
– type (10 mA/2 mA)
– max. (10 mA/2 mA)
Luminous intensity mcd
– at 2 mA
– at 10 mA 1)
– at 20 mA 1)
Wavelength nm
(10 mA/2 mA)
Thermal resistance °C/W
Angle of reflected beam
Storage temperature
Operating temperature
Solder temperature
Insulating body
Flammability of insulation body
A
B
red, Ø 3.2 mm
5
3
25
30
100
75
100
75
A
B
red, Ø 5 mm
5
3
25
30
100
75
100
75
A
B
yellow, Ø 3.2 mm
5
3
25
30
100
75
100
75
A
B
yellow, Ø 5 mm
5
3
25
30
100
75
100
75
A
B
green, Ø 3.2 mm
5
3
25
30
100
75
100
75
A
B
green, Ø 5 mm
5
3
25
30
100
75
100
75
2.1
2.1
2.1
2.1
2.1
2.2
2.1
2.2
2.1
2.2
2.1
2.2
3
3
1.5
3
3
3.1
3
3
1.4
3
3
3.2
3
3
2
3
3
3.3
1.8
3.6
635
13.4
26.8
650
2.2
4.4
635
25.1
48.2
650
2.7
5.4
585
13.4
28.7
585
3.4
6.8
585
28.6
60.8
585
3.2
6.4
565
24.6
54.9
563
3.9
7.8
565
25.7
54.6
563
400
470
350
390
400
470
350
390
400
470
350
390
50°
–55 ... +100 °C
–55 ... +100 °C (low-current LED)/–40 ... +85 °C (Standard-LED)
260 °C/max. 5 sec (processing advice for wave soldering: protect plastic body against solder wave)
PBT (Crastin)
UL 94 V-0
1) The low current LEDs can be used from 2 to 20 mA
(without reduction of lifespan), which means that a significantly
higher luminosity can be achieved.
11.17
Test socket, Ø 2 mm
Long type
Order Information
For application in
Long type
Short type
1
Part no.
2
Part no.
3
Part no.
69004-086
69004-087
69004-088
69004-130
individual item.
A3-199b
쮿 Dimensions of connecting pins: 0.3 × 0.6 mm
쮿 Technical data see page 11.20
Short type
1 = mounting plane
Note
KA943
Double test socket, Ø 2 mm
Long type
Order Information
For application in
Long type
Short type
1
Part no.
2
Part no.
3
Part no.
69004-089
69004-090
69004-091
69004-131
individual item.
05009050
Short type
1 = mounting plane
11.18
Note
05009051
Double make-break socket, Ø 2 mm
쮿 Gold-plated contacts
쮿 Can also be used as test socket
Order Information
For application in
Long type
Part no.
69004-095
individual item.
Note
1
1 = mounting plane
A3-200
11.19
Fuse holder
쮿 For glass fuse inserts 5 x 20 mm to DIN 41 571, 250 VAC, 6.3 A
쮿 Contacts silver-plated
Order Information
Description
Long type
Part no.
69004-098
item.
A3-200a
Note
쮿 Dimensions of connecting pins: 0.7 × 0.6 mm
쮿 Required front panel drill hole: Ø 9 mm
Technical data for test sockets, fuse holders
Test socket/make-break socket
Operating voltage
Operating current
Test voltage
Temperature range
Solder temperature
Contact material
Contact surface
Insulating body
Climatic use
category
Flammability
1)
Double test socket/
Fuse holder
double make-break socket
≤ 30 VAC
≤ 250 VAC
≤ 60 VDC/AC
≤1A
≤1A
≤ 6.3 A
1 kV/50 Hz
1 kV/50 Hz
–25 ... +70 °C
–25 ... +70 °C
–25 ... +70 °C
Copper alloy
Copper alloy
Copper alloy
Selectively gold-plated
Silver-plated
PBT (Crastin)
PBT (Crastin)
PBT (Crastin)
HSF 1) to DIN 40 040
UL 94 V-0
UL 94 V-0
UL 94 V-0
H = –25 °C; S = +70 °C; F = 75 % air humidity, no condensation
11.20
Cermet potentiometers
Order Information
Resistance
kΩ
1
5
Part no.
69004-169
69004-165
69004-161
69004-155
individual item.
Technical data
A3-275
Pins 1 and 2 low-ohmic when left-hinged;
pins 2 and 3 low-ohmic when right-hinged
Operating voltage
Operating current
Load capacity
Test voltage
Resistance tolerance
Electrical rotation angle
Insulation resistance change
Contact resistance change
Torque at initial turning
Storage temperature
Service life (full rotation)
Service life at 0.5 Watt load
Solder temperature
Insulating body
Flammability
Resistance of gasket to cleaning
Temperature coefficient
≤ 200 VDC/ AC
≤ 100 mA
0.5 Watt at Ta = 70 °C
500 V/50 Hz
10 %
230° 5°
100 MΩ
3 Ω or 3 %, use largest value
0.021 Nm
–55 ... +125 °C
–25 ... +70 °C
200 cycles
1000 h at Ta = 70 °C
PBT (Crastin)
UL 94 V-0
85 °C max. 1 min.
100 ppm/K
Note
쮿
쮿
쮿
쮿
Dimensions of connecting pins: 0.45 × 0.45 mm
When left-hinged: pins 1 and 2 low-ohmic
When right-hinged: pins 2 and 3 low-ohmic
11.21
Accessories Front panel component system
Mounting frames with PCB bracket for mounting planes
쮿 With 2 threaded female connectors M 2.5
쮿 Material PBT
쮿 Flammability UL 94 V-0
Order Information
Description
Mounting frame for mounting plane 1
Mounting frame for mounting planes 1 and 2
Mounting frame for mounting planes 1, 2 and 3
KA942a
Part no.
69004-043
69004-044
69004-045
individual item.
Note
쮿 Mounting frames nos. 69004-043, 69004-044 and 69004-045
cannot be used in conjunction with the aluminium profile handle for front panels
11.22
KA942b
KA942c
Mounting frame with PCB bracket for frame type plug-in
units
쮿 With 2 grub screws for fixing on PCBs
쮿 Board thickness max. 1.6 mm
쮿 Drilled hole for fixing board max. 2.8 mm
Order Information
Description
Support frame with board support for frame type plug-in
units
Part no.
69004-046
individual item.
KA942d
Drilling template
쮿 Design aid for processing of front panels
Order Information
Description
Drilling
template
Material
EPGC 02 (fibreglass reinforced Epoxy)
Part no.
69004-042
individual item.
A4_276
11.23
Design aids
Conmponent side of PCB
Front of front panel
1)
2)
3)
2)
1)
2)
PCB
Component mounting limit
FEA45510
3)
Front panel
FEA45511
Placement example
E1 = first mounting plane
E2 = second mounting plane
E3 = third mounting plane
11.24
ELA40278
Design aids
PCB tracks
View solder side
Short type
LED,
Ø 3.2 mm
View solder side
Long type
LED,
Ø 3.2 mm
Double LED,
Ø 3.2 mm
A4_277a
A4_277b
Test socket,
Ø 2 mm
Double test socket,
Ø 2 mm
A3_215a
Double LED,
Ø 3.2 mm
A3_205a
A3_205b
LED,
Ø 5 mm
A3_215b
Test socket,
Ø 2 mm
A4_272
A3_205c
Double test socket,
Ø 2 mm
Potentiometer
FEA45990
Make/break socket,
Ø 2 mm
A4_273
A2_114a
Ø 2 mm
Fuse holder
A2_114b
Dimensions of
connecting pins
0.5 × 0.5 mm
0.63 × 0.63 mm
0.3 × 0.6 mm
0.7 × 0.6 mm
0.4 × 0.6 mm
0.45 × 0.45 mm
Text
A2_114d
Recommended
hole Ø
1.0 mm 0.05
1.1 mm 0.05
0.9 mm 0.05
1.1 mm 0.05
0.9 mm 0.05
0.7 mm 0.05
Solder eyes Ø
2.1 mm 0.1
2.2 mm 0.2
2.0 mm 0.2
2.1 mm 0.2
2.0 mm 0.2
1.8 mm 0.2
PCB tracks width min. 0.6 mm
Grid 2.54 mm
11.25
Appendix
30403001
Quality - Environment - Safety
StandardsMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days
Continously improving our processes and therefore the quality
of the Schroff products - that is the subject of the QES (Quality Environment - Safety) management system.
In order to achieve these targets, a strategy has been developed
which includes all departments of the company.
This integral QES management system is documented in a manual
and validated through audits and systematically coordinated
inspections. Above all, the system is based on the motivation of the
entire workforce which is promoted through exemplary working
conditions and efficient training activities.
30403050
For you, the total of all these activities provides: highest quality
and reliability - worldwide.
All Schroff and Pentair Equipment Protection production sites are
accredited in accordance with DIN EN ISO 9001:2008.
The environmental management system of Schroff GmbH
Germany, Schroff SAS France as well as Schroff UK Ltd. in
Great Britain are additionally accredited in accordance with
DIN EN ISO 14001:2004. Besides this, the security management
system of Schroff GmbH is accredited in accordance with
BS OSHAS 18001:2007.
Dynamic processes in all batch sizes
20398001
12.0
This necessitates an ingenious production system. Schroff
consciously places its trust in personal commitment.
"Cellular" production is integrated into the Schroff production
process. Highly-competent and responsible employees work
in small, clearly defined production cells.
Appendix
Experience – to the benefit of the customer
Certifications
Underwriters Laboratories
Self-extinguishing plastics
Type of protection NEMA 12
30402052
European Organisation for Nuclear
Research
europacPRO subracks approved to
CERN Spec No. 385
CERN_5C
Railway applications
DB
europacPRO for railway applications,
approved for electronic equipment in
rolling stock (BN 411003)
SNCF
(Société Nationale des Chemins de Fer)
There are many levels to Schroff's commitment which then lead
to this "additional" benefit. For example, continuous dialogue
with customers and suppliers throughout the world is integrated
into design and production. Our involvement in international
standardisation committees also ensures the up-to-date nature
of the product standards or influences these in advance.
Added to this there is the experience of Schroff's Electronics
division. This is where power supplies, backplanes and modular
microcomputer systems are produced. We know what installing
electronics means. We make use of this experience throughout
the entire company. This is why all of the necessary tests are
genuinely carried out under practical conditions.
For you as customer, this means:
Safety, reduced test times and therefore lower costs.
Quality also means dialogue
Dialogue with you, because our responsibility for quality is
comprehensive and does not stop at the loading ramp.
You measure the value of our products. So please let us
know if you are not satisfied with our services or products.
Of course, we would also be pleased to hear from you if you
are satisfied.
An excerpt from the manual
"Quality-environment-safety management system":
The Schroff team's goal is to contribute towards the success of its
customers with top products and service. All Schroff employees
are responsible for the continuous improvement of the products
and services.
National and international
standardisation institutions
ANSI/EIA
TÜV Product Service
19” blower units
19” fans
BSI
CENELEC
CSA
DIN
DKE
30406050
Institute of German Electronics
Engineers
Protective GND/earthing connections
Socket strips
ECL
EEMAC
ETSI
IEC
LOGOVDE
IEEE
European Union
EMC guideline 89/336/EWG
VMEbus plug-in units
Power supplies
30402051
NEMA
NFPA
UL
VITA (VMEbus International Trade
Association)
PICMG (PCI Industrial Computer
Manufacturers Group)
Systems
Backplanes
USA
GB
EU
CAN
D
D
GB
CAN
EU
Int.
USA
USA
CAN
USA
American National Standards Institute/
Electronic Industry Association
British Standards Association
European Committee for Electrotechnical
Standardization
Canadian Standards Association
Deutsches Institut für Normung e.V.
(German Standards Institute)
German Electrical Engineering Committee
in DIN and VDE
British Standards Institution
Technical Subcommittee
Electrical/Electronic Manufacturers
Association of Canada
European Telecommunications
Standardisations Institute
International Electrotechnical Commission
Institute of Electrical and
Electronics Engineers
National Electrical Manufacturers
Association
Underwriters Laboratories Inc.
VDE
D
Institute of German Electronics Engineers
VDI
D
Association of German Engineers
12.1
Normen
Appendix – Standards
Mechanical design
20303001
12.2
19" system
25 mm system
Cabinets
Cases
IEC 60297-3-100
IEC 60917-2-1
Subracks
System enclosures
IEC 60297-3-100
IEC 60297-3-101
IEC 60297-3-102
IEC 60297-3-103
IEC 60297-3-104
IEEE 1101.1
IEEE 1101.10
IEEE 1101.11
IEC 60917-2-2
19" chassis
IEC 60297-3-105
Plug-in units
Frame type plug-in
units
IEC 60297-3-101
IEC 60297-3-102
IEC 60297-3-103
IEC 60297-3-104
IEEE 1101.1
IEEE 1101.10
IEEE 1101.11
IEC 60917-2-2
PCBs
IEC 60297-3-101
IEC 60297-3-104
IEEE 1101.1
IEC 60097
Connectors
IEC 60603-2
IEC 61076-4-101
IEC 61076-4-100
Front elements
DIN 41494 part 8
Backplanes
IEC 60297-3-101
IEC 60297-3-104
IEEE 1101.1
IEEE 1101.11
IEC 60917-2-2
Shock and vibration test
DIN IEC 61587-1
EN 60068-2-6 (vibration, sinusoidal)
EN 60068-2-27 (shock)
Text
These tests simulate conditions which devices must fulfil as
minimum requirement during operation and transportation.
Tests with 3, 6 and 9 U dummies provided valuable experiences
that have been integrated into the design of the Schroff subracks.
For extreme strains – such as e.g. during mobile use in rolling
stock
– a separate product family "europac PRO for railway applications"
has been developed and confirmed by approval testing to the
German Railway Standards BN 411 002 and BN 411 003 and
French Railway Standards NF F 61-005/NF F 60-002 as well as
EN 50155.
Similar test conditions and degrees of severity for vibration
and shock stability are contained in IEC 61587-1.
Varistar cabinets have been designed with high physical
stresses in mind. Of particular importance in this respect is
the bending stiffness of the frame. The specially developed
hollow-chamber profile achieves the DL5 and DL6 requirement
classes for static and dynamic loads, and thus also the highest
shock and vibration resistance to IEC 61587-1, with minimal
cost of material.
DIN IEC 61587-2
In dynamic tests for stability under earthquake conditions,
the Varistar Heavy-Duty cabinet proved its suitability for
worldwide use. The seismic tests, carried out under IEC 61587-2,
certify the cabinet platform's earthquake resistance up to
Bellcore Zone 3.
By further reinforcing the cabinet frame with small corner
brackets, earthquake resistance is assured up to Bellcore Zone
4.
06109002
01008018
12.3
IP degrees of protection
Types of protection (IP code):
IEC 60529
DIN VDE 0470 part 1
The degrees of protection of this standard define the
Protection of persons against hazardous parts in the
enclosure
Protection against access of foreign bodies
Protection against ingress of water
Protection against contact and access
IP
1st
digit
Contact
no protection
Protection against water
IP
2nd
digit
Foreign body
no protection
Ø
1
with large parts of
the body
(back of the hand)
no protection
1
vertically falling drops
of water
Main CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days
>50
large foreign bodies,
diameter greater than
or equal to 50 mm
NOA44107
Ø
2
with the finger
NOA44099
>12,5
medium-size
foreign bodies,
or equal to 12 mm
2
slantwise falling drops
of water up to 15°
against the vertical
NOA44108
NOA44100
Ø >2,5
3
with tools and wires,
or equal to 2.5 mm
small foreign bodies,
or equal to 2.5 mm
3
spraying water
up to 60° angle
NOA44109
4
or equal to 1 mm
grain-shaped
foreign bodies,
or equal to 1 mm
NOA44101
4
splash water
from all sides
NOA44102
NOA44110
5
complete protection
dust deposit
5
jets of water
NOA44103
NOA44111
6
complete protection
ingress of dust
6
powerful jets of water
NOA44104
Example: IP 21
2
1
7
partial immersion
The first digit means
Contact protection with the finger
and foreign bodies larger than 12.5 mm
in diameter.
The second digit means
The device is protected against vertically falling
drops of water.
NOA44105
8
total immersion
NOA44106
12.4
Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days
Flammability of plastics
Standardised test processes
Classification in accordance with UL 94
Note
The specification of the UL listing of plastics on the order pages
refers to the material used and not to the product
Criteria
UL 94 HB
Burn distance 102 mm
Flame spread rate
38.1 mm with 3.2 mm
thick sample body
76.2 mm with 1.6 mm
thick sample body
ASTM D 635
Test structure
Sample body horizontal
Bunsen burner flame at the
free end
Flame height 25 mm
Ignition flame 30 s, partially
FPCS burner position
3 sample bodies
127 12.7 3.2 (1.6) mm
UL94A
UL 94-5 V
Afterflame time 60 s
No droplets
UL 94:
Test process
94-5 V
Sample body vertical
lower edge/corner
Flame height 127 mm
Inner flame cone 38 mm,
touches lower edge/corner
5 5 s flame application,
pause every 5 s
2 sets each containing
5 sample bodies
127 12.7 (application
thickness) mm
UL94B
UL 94 V-0
Burning time 10 s
Total burning time 50 s
No flaming droplets
DIN VDE 0304 part 3
Process FV
UL 94 V-1
Burning time 30 s
Total burning time 250 s
No flaming droplets
UL94C
free end
Flame height 20 2 mm
Ignition flame 10 s,
after extinguishing of
sample, a further 10 s
10 sample bodies
125 13 31) mm
1) If necessary, also 0.8, 1.6, 6.0
and 6.4 mm
UL 94 V-2
Burning time 30 s
Flaming droplets
1)
Bunsen burner
Sample body
3) Measurement mark
4) Wire screen
2)
Part number in normal type: ready for despatch within 10 working days
12.5
Protective GND/earthing connection from the frame to the
covers
Central connection with IEC 320 connector
Measures to protect persons against
contact with dangerous voltages.
NOA44075
NOA44184
Rear front panel chromated for surface contact to the
enclosure
ESD spring in guide rail
2
1
ESD
Electrostatic discharge – measures
to deflect electrostatic discharge in
order to protect electronics against
interference impulses and the
destruction of components.
ESD or electrostatic discharge
describes the appearance form of
the discharge of static electricity.
The human being is electrically
discharged onto an earthed point.
NOA44069
Under unfavourable conditions, human beings may carry a charge
of up 20 kV. This voltage is discharged with a very rapid impulse.
20309050
EMV/EMC
Contact strip between frame and top cover
Contact strip between plug-in units
The abbreviation of the definitions
EMV / EMC stands for
Elektromagnetische Verträglichkeit
or electromagnetic compatibility.
These are defined as follows:
Electromagnetic compatibility is the
ability of a piece of electrical
equipment to function in a
satisfactory manner in its
NOA44073
electromagnetic environment,
without influencing this environment,
to which other pieces of equipment may also belong, more than is
permissible.
NOA44183
EMP
The generic term EMP or electromagnetic pulse incorporates
three different forms of electromagnetic pulses.
These include:
LEMP: lightning electromagnetic pulse (e.g. lightning strike)
SEMP: switching electromagnetic pulse (e.g. switching
processes in electrical energy systems)
NEMP: nuclear electromagnetic pulse (nuclear explosion)
12.6
The CE symbol
All electrical and electronic devices or systems
marketed in the EU after 01.01.1996 must
display the CE symbol.
30402051
However, the CE symbol is not a form of special
EMC certification. It encompasses different
standards for various products.
With the CE symbol, the manufacturer or importer confirms the
conformity of his products to the EU standard.
However, responsibility for the declaration of conformity is borne
by the manufacturer or importer, unlike, for example, in the case
of the TÜV or GS symbol, where conformity is tested by a
responsible body. The owner must therefore ensure that his
device displays the CE symbol, and is only allowed to use this
device in the specified environment, e.g. in industrial or domestic
applications.
Important
The affixation of the CE symbol is the personal responsibility of
each manufacturer. It is not assigned by an official body. The
CE symbol only provides the consumer with indirect protection;
it is predominantly affixed to the product for the official body
monitoring the market.
Liability and responsibility
In the field of electromagnetic compatibility, the manufacturer
certifies that his product is in accordance with the European
EMC standard by affixing the CE symbol.
The guidelines are monitored by the (German) Federal Office
of Postal and Telecommunication Services (BAPT). Adherence
to the protection requirements is checked by random sampling.
In the event of non-adherence, the product may be withdrawn
from the market and a high fine imposed. In addition to the EMC
standard, the product liability legislation also applies in this case.
Shielded products (EMC)
Systems and devices which are used in Europe must adhere to the
EMC standard regarding interference emission and interference
resistance.
In case the pre-specified limit values are exceeded, a remedy
may be provided by a shielded case. In this case, various
measures are available for reducing interference emission or for
improving interference resistance.
However, attention must also be paid to the special insertion of
cables and wires into the case. Otherwise, the suppression
characteristics of the enclosure cannot be guaranteed.
When testing a device or system with regard to electromagnetic
compatibility, the interconnection between various standards must
be taken into consideration. The basis of the EMC measurement is
the Product Standard. If this does not exist, the valid Generic
Standard must be applied.
Also to be considered for EMC measurements is the Basic
Standard, to which reference is made in the individual Product and
Generic Standards.
Shielded cases
Basically, no EMC standards apply to "empty" electronics
enclosures, because only if corresponding electrical devices
have been installed can the overall system emit electromagnetic
interference or be influenced by external emissions.
Schroff system solutions
Schroff enclosure systems are manufactured entirely from metal,
and basically have good EMC characteristics. The conductivity of
surfaces in EMC shielded enclosures is additionally ensured by
galvanic coating.
The individual components are contacted via a EMC gaskets,
such as, for example, stainless steel springs, and large surface
conductive connections of the individual components.
When designing shielded enclosures, special requirements are
also made on cable ducting and ventilation. An complete shielded
system can only be assessed if these two parameters are taken
into account.
Shielding and measurement procedures
Shielding specifies the rate by which the intensity of
electromagnetic radiation is reduced on passage through
an enclosure. This is specified in the logarithmic measuring
unit dB. Shielding measurements for Schroff enclosures
are carried out by an independent institute.
Shielding is measured in accordance with the measurement
procedure VG 95373, part 15 (German defence standard).
This procedure is currently being transformed into a civilian
standard.
An additional measurement procedure to MIL-STD 285
(American military standard) also exists. This procedure
was principally developed for measuring material shielding,
therefore it is only suitable to a limited degree for measuring
electronics enclosures, such as cabinets, cases and subracks.
12.7
Abkürzungen
Abkürzungen allgemein
allgemein
Appendix – Abbreviations
A
ABS
AC
Acryl(-glas)
AD
ADC
Al
AlZn
ANSI
AT
AdvancedTCA
Be
BN
BS(I)
°C
Ampere, electric current
Acrylonitrile-butadiene-styrene
Alternating current (single phase current)
Plastic (glass)
Address data bus
Automatic daisy chaining
Aluminium
Aluminium zinc alloy for finishes
PC backplane AT standard
Advanced Telecom Computing Architecture
Beryllium
(German) Federal Railway Standard
British Standards (Institution)
Degree Celsius
(= 1/1.8 × [°F-32] = K – 273.15 °C)
C 15
Steel
CE
Conformité Européenne,
corresponds to EU guidelines
CENELEC
Standardisation
CERN
Research
cfm
Cubic feet per minute (airflow capacity)
Ck 75
Steel
CSA
CTI
Comparative figure for creepage formation in
insulating materials
Cu
Copper
CuBe
Copper-beryllium
CuSn
Bronze
CuZn
Brass
D, d
Depth
DB
Deutsche Bahn AG
dB(A)
Decibels, volume level
DC
Direct current
DIL
Dual-in-line
DIN
Deutsche Industrie Norm (German industry
standard)
DKE
Deutsche Eletrotechnische Kommission im DIN
und VDE (German electrotechnical commission)
ECL
British Standards Institution Technical
Subcommittee
E-Cu
Electrolytic copper
EEMAC
Electrical/Electronic Manufacturers Association
of Canada
Earthing contact Socket/plug with protection contact; standard in D,
NL, S, P, A, N, SF, E, TR, GR, L
EIA
EMC (EMV)
EMP
Electromagnetic pulse
EMI
Electromagnetic interference
EN
European standard
EPGC
Fiberglass reinforced epoxy
Epgl.
Epoxy-fiberglass mat
ESD
ESG
Tempered, single-glass pane to EN 12150
12.8
ETS(I)
European Telecommunications Standards
(Institute)
EU
Filter classes to DIN 24 185, part 100
F
Degree Fahrenheit (= 1.8 × °C + 32)
FI
Fault current
FKD
Lower/upper limit temperature and moisture to
DIN 40 040
FPCS
FR
Flammability rating (to NEMA)
G10Fr4
Fiberglass, fire-resistant
GD-Zn
Zinc die-cast
GND
Ground/earthing
GS
Approved safety
h
Hour
H, h
Height
H2S
Hydrogen sulphide
HF
HF/high-frequency
HP
= TE = unit of division (1 HP = 5.08 mm)
HPL
High Pressure Laminate
(melamine resin-coated laminated sheet)
HSF
DIN 40 037
Hz
Hertz, frequency of the alternating voltage
IC
Integrated Circuit
IEC
IEEE
Institute of Electrical and Electronic Engineers
Inch
Linear measure, 1" = 25.4 mm
IP
Ingress Protection
ISA
Industrial Standard Architecture (industrial
standard for PCs)
ISO
International Standards Organisation
J1
VME system bus, 3 U, top
J1/J2
VME system bus, 6 U, Monolithic
J2
VME system bus, 6 U, bottom
K
Kelvin (= °C + 273,15 °C)
LBX
Local bus extension for Multibus® II
LED
Light emitting diode
lfm
Linear foot per minute; airflow
1 lfm = 304.8 mm/min = 5.08 mm/s
= 0.00508 m/s
LGA
Bavarian regional trade office
M
Metric thread
m3/h
Airflow volume
MBLT
Multiplexed block transfer in the VMEbus for
increasing the transmission rate
mcd
Millicandela
MDC
Manual daisy chaining with jumper
for VME/VXIbus
mep
Metric equipment practice
MHz
Megahertz (frequency)
mm
Millimeter
Monolithic
J1/J2 backplane, 6 U
mp1, mp2, mp3 Measuring units in metric system,
1 mp1 = 25 mm, 1 mp2 = 5 mm,
1 mp3 = 2.5 mm
ms
Millisecond
MTBF
Mean time between failure
AbbreviationsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days
ELECTRONICS PROTECTION
n
N
NEMA
NF
NFPA
NTC
OVP
PA
Pa
Pb
PBT (P)
PC
PCI
PE
PG
PICMG
Pin
PMC
PMMA
POM
PP
PPE
ppm
PPO
PS
PSB
PTC
PU
PU(R)
Pv
PVC
RAL
RAL 7016
RAL 7021
RAL 7030
RAL 7032
RAL 7035
RAL 9005
RAL 9006
Sekurit(-glas)
ServicePLUS
SEV
SI
SIPS
Slot
SMD
SNCF
SNMP
Sn
SO2
SPQ
St
SU
SW
Speed (rpm)
Newton
National Electrical Manufacturers Association
Norme Française (French standard)
Electrical/Electronics Manufacturers
Negative temperature coefficient
Over-voltage protection
Polyamide
Pascal
Lead
Polybutylen terephthalat
Personal computer or polycarbonate
Periphery component interface
Polyethylene
Steel conduit thread
PCI Industrial Computers Manufacturers Group
(www.PICMG.com)
Connection, contact
PCI Mezzanine Card
Polymethyl methacrylat
Polyoxymethylene
Polypropylene
Polyphenylene ether
Parts per million
Polyphenyl oxide, corresponds to PPE
Polystyrene
Parallel system bus for Multibus® II
Positive temperature coefficient
Packaging unit
Polyurethane
Installed energy loss
Polyvinyl chloride
Colour standard
Anthracite grey
Black grey
Stone grey
Pebble grey
Light grey
Black
White aluminum
Safety glass
SCHROFF rapid assembly service
Association of Swiss electrical engineers
Overcurrent
Standard industrial PC system
Plug-in position for board
Surface mounted device
Simple network management protocol
Tin
Sulphur dioxide
Standard pack quantity
Steel
System unit (1 SU = 25 mm)
Wrench size across flats
Ta/Tu
TSG-PS
TTL
TÜV
U
UL
Ambient temperature
Thermoplastic structure foaming, polystyrene
Transistor-transistor logic
German technical supervisory association
= HE = height unit (1 U = 44.45 mm)
(USA safety regulations)
American fire protection standard
Safety of information technology appliances
including electrical office equipment
Unified National Coarse (inch thread)
Union technique de l’électricité, here: socket/
socket strip type for France and Belgium
Airflow capacity
Volt, voltage
Volt-ampere, power consumption,
(apparent power)
Institute of German electronics engineers
Verein Deutscher Ingenieure e.V.
Defence equipment (standard)
VMEbus International Trade Association
(www.vita.com)
Versa Module Europe, system bus
VME subsystem bus
Peak-peak voltage
VMEbus extension for instrumentation
Stainless steel
Watt, power output
Width
Pre-galvanised steel plate with special surface
treatment
Zinc
Zinc-leaded alloy
Abbrevi ationsMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days
UL 94 ...
UL 60950-1
UNC
UTE
V°
V
VA
VDE
VDI
VG Standard
VITA
VMEbus
VSB
Vss
VXI
V2A
W
W, w
Zincor
Zn
ZnPb
12.9
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
1.356
10130-025
1.127
10130-069
1.127
10130-113
1.129
10130-157
1.131
10117-527
1.277
10130-026
1.127
10130-070
1.127
10130-114
1.129
10130-158
1.131
10117-528
1.277
10130-027
1.127
10130-071
1.127
10130-115
1.129
10130-159
1.131
10117-529
1.277
10130-028
1.127
10130-072
1.129
10130-116
1.129
10130-160
1.131
10117-530
1.277
10130-029
1.127
10130-073
1.129
10130-117
1.129
10130-161
1.131
10117-531
1.277
10130-030
1.127
10130-074
1.129
10130-118
1.129
10130-162
1.131
10117-532
1.277
10130-031
1.127
10130-075
1.129
10130-119
1.129
10130-163
1.131
10117-533
1.276
10130-032
1.127
10130-076
1.129
10130-120
1.131
10130-164
1.131
10117-534
1.276
10130-033
1.127
10130-077
1.129
10130-121
1.131
10130-165
1.131
10117-535
1.276
10130-034
1.127
10130-078
1.129
10130-122
1.131
10130-166
1.131
10117-536
1.276
10130-035
1.127
10130-079
1.129
10130-123
1.131
10130-167
1.131
10117-537
1.276
10130-036
1.127
10130-080
1.129
10130-124
1.131
10130-168
1.131
10117-538
1.276
10130-037
1.127
10130-081
1.129
10130-125
1.131
10130-169
1.131
10117-539
1.276
10130-038
1.127
10130-082
1.129
10130-126
1.131
10130-170
1.131
10117-540
1.276
10130-039
1.127
10130-083
1.129
10130-127
1.131
10130-171
1.131
10117-541
1.277
10130-040
1.127
10130-084
1.129
10130-128
1.131
10130-172
1.131
10117-542
1.277
10130-041
1.127
10130-085
1.129
10130-129
1.131
10130-173
1.131
10117-543
1.277
10130-042
1.127
10130-086
1.129
10130-130
1.131
10130-174
1.131
10117-544
1.277
10130-043
1.127
10130-087
1.129
10130-131
1.131
10130-175
1.131
10117-545
1.277
10130-044
1.127
10130-088
1.129
10130-132
1.131
10130-176
1.131
10117-546
1.277
10130-045
1.127
10130-089
1.129
10130-133
1.131
10130-177
1.131
10117-547
1.277
10130-046
1.127
10130-090
1.129
10130-134
1.131
10130-178
1.131
10117-548
1.277
10130-047
1.127
10130-091
1.129
10130-135
1.131
10130-179
1.131
10125-010
1.348
10130-048
1.127
10130-092
1.129
10130-136
1.131
10130-180
1.131
10125-011
1.348
10130-049
1.127
10130-093
1.129
10130-137
1.131
10130-181
1.131
10130-001
1.12
10130-050
1.127
10130-094
1.129
10130-138
1.131
10130-182
1.131
10130-002
1.12
10130-051
1.127
10130-095
1.129
10130-139
1.131
10130-183
1.131
10130-003
1.12
10130-052
1.127
10130-096
1.129
10130-140
1.131
10130-184
1.131
10130-004
1.12
10130-053
1.127
10130-097
1.129
10130-141
1.131
10130-185
1.131
10130-005
1.13
10130-054
1.127
10130-098
1.129
10130-142
1.131
10130-186
1.131
10130-006
1.13
10130-055
1.127
10130-099
1.129
10130-143
1.131
10130-187
1.131
1.13
10130-056
1.127
10130-100
1.129
10130-144
1.131
10130-188
1.86
10130-008
1.13
10130-057
1.127
10130-101
1.129
10130-145
1.131
10130-189
1.86
10130-012
1.228
10130-058
1.127
10130-102
1.129
10130-146
1.131
10130-190
1.57
10130-013
1.229
10130-059
1.127
10130-103
1.129
10130-147
1.131
10130-191
1.58
10130-014
1.230
10130-060
1.127
10130-104
1.129
10130-148
1.131
10130-192
1.56
10130-016
1.228
10130-061
1.127
10130-105
1.129
10130-149
1.131
10130-193
1.238
10130-017
1.229
10130-062
1.127
10130-106
1.129
10130-150
1.131
10130-194
1.238
10130-018
1.230
10130-063
1.127
10130-107
1.129
10130-151
1.131
10130-195
1.87
10130-020
1.56
10130-064
1.127
10130-108
1.129
10130-152
1.131
10130-198
1.122
10130-021
1.14
10130-065
1.127
10130-109
1.129
10130-153
1.131
10130-199
1.232
10130-022
1.14
10130-066
1.127
10130-110
1.129
10130-154
1.131
10130-200
1.232
10130-023
1.86
10130-067
1.127
10130-111
1.129
10130-155
1.131
10130-201
1.122
10130-024
1.127
10130-068
1.127
10130-112
1.129
10130-156
1.131
10149-305
1.326
10117-498
10130-007
12.11
Appendix
Part no.
Page
Part no.
Part no.
Page
Part no.
10149-306
1.326
10501-005
10149-308
1.326
10501-005
3.3
10603-001
5.107
10713-532
4.11
11098-416
8.51
5.109
10603-001
5.117
10713-534
4.10
11098-416
9.18
10149-313
1.327
10501-005
6.25
10603-001
5.72
10713-536
4.10
11098-438
8.38
10149-315
1.327
10501-006
3.3
10603-001
5.87
10713-537
4.10
11098-438
8.39
10149-316
1.327
10501-006
5.109
10603-002
5.107
10713-546
4.12
11098-438
8.52
10225-601
5.102
10501-007
3.3
10603-002
5.117
10713-547
4.12
11098-438
9.19
10225-602
5.102
10501-007
5.109
10603-002
5.72
10822-009
3.13
11249-003
1.322
10225-604
5.103
10501-008
3.3
10603-002
5.87
10822-009
3.46
11249-005
1.322
10225-612
5.102
10501-008
5.109
10603-023
5.116
10828-051
6.130
11249-007
1.323
10225-613
5.102
10501-008
6.25
10603-024
5.116
10828-052
6.130
11249-009
1.323
10225-615
5.103
10501-016
5.109
10603-025
5.116
10828-053
6.130
11249-012
1.323
10225-616
5.103
10501-018
5.109
10603-026
5.116
10828-054
6.130
11249-016
1.324
10225-618
5.103
10501-018
6.25
10713-098
4.8
10828-056
6.130
1130-583
1.204
10225-623
5.102
10501-025
3.3
10713-099
4.8
10828-057
6.130
11592-500
8.9
10225-624
5.102
10501-025
5.109
10713-100
4.6
10828-058
6.130
11592-503
8.9
10225-626
5.103
10501-026
3.3
10713-102
4.6
10828-059
6.130
11596-088
8.4
10225-627
5.103
10501-026
5.109
10713-103
4.6
10828-068
6.130
11596-090
8.5
10225-629
5.103
10501-026
6.25
10713-104
4.6
10828-069
6.130
11596-107
8.5
10225-637
5.103
10501-027
3.3
10713-106
4.6
10828-071
6.130
11596-160
8.6
10225-638
5.103
10501-027
5.109
10713-107
4.6
10828-072
6.130
11596-161
8.6
10225-640
5.103
10501-028
3.3
10713-108
4.7
10828-073
6.130
11596-300
8.7
10225-667
5.104
10501-028
5.109
10713-110
4.7
10836-045
8.102
11596-303
8.7
10225-670
5.104
10501-029
3.3
10713-111
4.7
10836-050
8.101
11850-011
8.43
10225-682
5.104
10501-029
5.109
10713-112
4.7
10836-060
8.103
11850-013
8.47
10225-685
5.104
10501-029
6.25
10713-114
4.7
10849-001
8.28
11850-017
8.42
10225-693
5.104
10501-116
3.3
10713-115
4.7
10849-002
8.29
11850-018
8.44
10225-696
5.104
10501-116
5.109
10713-140
4.15
10849-005
8.45
11850-020
8.40
10236-151
2.26
10502-050
5.110
10713-141
4.15
10849-009
8.32
11850-021
8.38
10236-152
2.26
10502-057
3.3
10713-142
4.15
10849-011
8.33
11890-035
8.39
10236-156
2.26
10502-057
5.110
10713-143
4.15
11000-001
9.17
11990-100
8.10
10236-157
2.26
10502-057
6.25
10713-144
4.15
11000-002
6.91
11990-101
8.10
10236-160
2.26
10502-059
3.3
10713-145
4.15
11000-002
7.96
11990-600
8.8
10236-161
2.26
10502-059
5.110
10713-146
4.15
11000-002
9.17
11990-601
8.8
10236-162
2.26
10502-060
6.25
10713-147
4.15
11098-140
9.21
11990-603
8.8
10236-165
2.26
10502-063
3.3
10713-148
4.15
11098-207
9.25
12349-001
1.318
10236-166
2.26
10502-063
5.110
10713-149
4.15
11098-212
9.25
12349-002
1.318
10238-151
2.32
10502-065
3.3
10713-150
4.15
11098-231
9.21
12349-003
1.318
10238-152
2.32
10502-065
5.110
10713-151
4.15
11098-266
9.21
12349-004
1.318
10238-153
2.32
10502-065
6.25
10713-518
4.10
11098-267
9.21
12349-005
1.320
10501-001
5.108
10502-296
5.112
10713-520
4.10
11098-316
9.24
12349-006
1.320
10501-002
5.108
10502-297
5.112
10713-526
4.10
11098-392
8.40
12349-007
1.320
10501-003
5.108
10504-002
5.111
10713-528
4.10
11098-392
8.51
12349-008
1.320
10501-004
3.3
10504-003
5.111
10713-529
4.10
11098-392
9.18
12349-009
1.318
10501-004
5.109
10505-014
5.113
10713-530
4.11
11098-416
8.40
12349-010
1.318
12.12
Page
www.schroff.biz E 05/2016
Page
Part no.
Page
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
12349-011
1.318
12505-023
2.10
12506-169
2.5
13100-152
9.6
14575-123
5.79
12349-012
1.318
12505-024
2.10
12506-170
2.5
13100-153
9.6
14575-125
5.79
12403-150
2.23
12505-025
2.10
12506-171
2.5
13100-203
9.20
14575-127
5.79
12403-151
2.23
12505-028
2.10
12506-172
2.5
13100-204
9.20
14575-134
5.78
12403-152
2.23
12505-029
2.10
12506-173
2.5
13100-205
9.20
14575-135
5.78
12403-153
2.23
12505-032
2.10
12506-174
2.5
13103-002
9.13
14575-136
5.78
12403-154
2.23
12505-071
2.11
12506-175
2.5
13103-003
9.13
14575-143
5.79
12403-155
2.23
12505-073
2.11
12506-176
2.5
13103-004
9.13
14575-145
5.79
12403-156
2.23
12505-074
2.11
12506-177
2.5
13103-007
9.13
14575-147
5.79
12405-120
2.10
12505-081
2.11
13100-041
9.3
13103-007
9.14
14575-154
5.78
12405-120
2.11
12505-083
2.11
13100-043
9.3
13103-016
9.15
14575-155
5.78
12405-120
2.13
12505-084
2.11
13100-044
9.3
13105-001
9.10
14575-156
5.78
12406-400
2.4
12505-085
2.11
13100-045
9.3
13105-002
9.10
14575-163
5.79
12406-400
2.5
12505-086
2.11
13100-046
9.3
13105-003
9.10
14575-165
5.79
12406-411
2.6
12506-003
2.4
13100-078
9.9
13105-004
9.10
14575-167
5.79
12406-411
2.7
12506-004
2.4
13100-079
9.9
13105-006
9.10
14575-169
5.79
12406-418
2.6
12506-005
2.4
13100-102
9.4
13105-007
9.10
14575-171
5.79
12406-418
2.7
12506-010
2.4
13100-103
9.4
13105-008
9.10
14575-174
5.78
12406-419
2.6
12506-011
2.4
13100-104
9.4
13105-009
9.10
14575-175
5.78
12406-419
2.7
12506-012
2.4
13100-105
9.4
13105-011
9.10
14575-176
5.78
12406-450
2.7
12506-013
2.4
13100-112
9.7
13105-012
9.10
14575-178
5.78
12406-451
2.7
12506-014
2.4
13100-114
9.7
13105-013
9.10
14575-223
5.79
12406-452
2.7
12506-015
2.4
13100-115
9.7
13105-014
9.10
14575-225
5.79
12406-454
2.7
12506-017
2.4
13100-116
9.7
13105-017
9.11
14575-243
5.79
12406-730
2.6
12506-018
2.4
13100-122
9.8
13105-018
9.11
14575-245
5.79
12406-801
2.6
12506-019
2.4
13100-123
9.8
13105-021
9.11
14575-247
5.79
12406-802
2.6
12506-020
2.4
13100-133
9.5
13105-022
9.11
14575-265
5.79
12406-810
2.6
12506-022
2.4
13100-134
9.5
13105-023
9.11
14575-267
5.79
12406-812
2.6
12506-030
2.4
13100-136
9.2
13105-027
9.11
14575-269
5.79
12406-813
2.6
12506-031
2.4
13100-137
9.2
13105-028
9.11
14575-271
5.79
12406-814
2.6
12506-032
2.4
13100-138
9.2
13105-029
9.11
14575-445
5.80
12406-815
2.6
12506-033
2.4
13100-139
9.2
13105-051
9.12
14575-447
5.80
12406-816
2.6
12506-041
2.4
13100-141
8.102
13105-052
9.12
14575-463
5.80
12406-818
2.6
12506-054
2.4
13100-141
8.103
13105-053
9.12
14575-465
5.80
12406-819
2.6
12506-055
2.4
13100-141
8.77
14575-023
5.79
14575-467
5.80
12406-821
2.6
12506-160
2.5
13100-141
8.86
14575-025
5.79
14575-469
5.80
12505-001
2.10
12506-161
2.5
13100-141
8.87
14575-027
5.79
14575-471
5.80
12505-002
2.10
12506-162
2.5
13100-141
8.96
14575-063
5.79
14575-476
5.78
12505-003
2.10
12506-163
2.5
13100-141
9.22
14575-065
5.79
14575-477
5.78
12505-004
2.10
12506-164
2.5
13100-142
9.26
14575-067
5.79
14576-021
5.50
12505-005
2.10
12506-165
2.5
13100-145
9.23
14575-103
5.79
14576-023
5.50
12505-020
2.10
12506-166
2.5
13100-146
9.27
14575-105
5.79
14576-041
5.50
12505-021
2.10
12506-167
2.5
13100-150
9.6
14575-114
5.78
14576-043
5.50
12505-022
2.10
12506-168
2.5
13100-151
9.6
14575-115
5.78
14576-045
5.50
SCHROFF.PENTAIR.CO.UK
12.13
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
14576-101
5.50
15230-009
1.245
19713-540
4.10
20110-073
6.126
20110-197
3.28
14576-103
5.50
15230-010
1.245
20100-006
3.40
20110-074
3.27
20110-198
3.28
14576-121
5.50
15230-011
1.245
20100-007
3.40
20110-074
6.126
20114-728
1.150
14576-123
5.50
15230-012
1.245
20100-008
3.40
20110-075
3.27
20114-728
1.151
14576-125
5.50
15230-013
1.245
20100-009
3.41
20110-075
6.126
20114-728
1.153
14576-141
5.50
15230-014
1.245
20100-010
3.40
20110-076
3.27
20114-728
1.154
14576-143
5.50
15230-015
1.245
20100-013
3.41
20110-076
6.126
20114-728
1.24
14576-145
5.50
15230-016
1.245
20100-015
3.39
20110-077
3.27
20114-728
1.25
14576-161
5.50
15230-017
1.245
20100-017
3.39
20110-077
6.126
20114-728
1.283
14576-163
5.50
15230-018
1.245
20100-018
3.39
20110-090
3.25
20114-728
1.66
14576-165
5.50
15230-019
1.244
20100-019
3.39
20110-090
6.125
20114-728
1.67
14576-167
5.50
15230-020
1.244
20100-021
3.42
20110-091
3.25
20114-728
1.93
14576-169
5.50
15230-021
1.244
20100-028
3.41
20110-091
6.125
20114-728
1.94
14576-221
5.51
15230-022
1.244
20100-029
3.39
20110-092
3.25
20114-728
2.26
14576-223
5.51
15230-023
1.244
20100-029
3.41
20110-092
6.125
20114-728
2.31
14576-241
5.51
15230-024
1.244
20100-030
3.41
20110-093
3.25
20114-729
1.150
14576-243
5.51
15230-025
1.244
20110-054
3.13
20110-093
6.125
20114-729
1.151
14576-245
5.51
16230-001
1.245
20110-055
3.13
20110-094
3.25
20114-729
1.153
14576-247
5.51
16230-002
1.245
20110-056
3.13
20110-094
6.125
20114-729
1.154
14576-265
5.51
16230-003
1.245
20110-060
3.13
20110-095
3.25
20114-729
1.24
14576-267
5.51
16230-004
1.245
20110-061
3.13
20110-095
6.125
20114-729
1.25
14576-269
5.51
16230-005
1.245
20110-062
3.13
20110-096
3.25
20114-729
1.283
14576-463
5.51
16230-006
1.245
20110-063
3.13
20110-096
6.125
20114-729
1.66
14576-465
5.51
16230-007
1.245
20110-068
3.52
20110-097
3.25
20114-729
1.67
14576-467
5.51
16230-008
1.245
20110-068
3.53
20110-097
6.125
20114-729
1.93
14576-469
5.51
16230-009
1.245
20110-068
3.54
20110-100
3.26
20114-729
1.94
14577-123
5.52
16230-010
1.245
20110-068
3.55
20110-101
3.26
20114-730
1.150
14577-125
5.52
16230-011
1.245
20110-068
3.56
20110-102
3.26
20114-730
1.151
14577-143
5.52
16230-012
1.245
20110-068
3.57
20110-103
3.26
20114-730
1.153
14577-145
5.52
16230-013
1.245
20110-068
3.58
20110-104
3.26
20114-730
1.154
14577-163
5.52
16230-014
1.245
20110-068
3.59
20110-105
3.26
20114-730
1.24
14577-165
5.52
16230-015
1.245
20110-068
3.60
20110-106
3.26
20114-730
1.25
14577-223
5.52
16230-016
1.245
20110-068
3.61
20110-107
3.26
20114-730
1.283
14577-243
5.52
16230-017
1.245
20110-068
3.62
20110-108
3.26
20114-730
1.66
14577-245
5.52
16230-018
1.245
20110-068
3.63
20110-180
3.13
20114-730
1.67
14577-265
5.52
16230-019
1.244
20110-068
3.64
20110-181
3.13
20114-730
1.93
15230-001
1.245
16230-020
1.244
20110-068
3.66
20110-182
3.13
20114-730
1.94
15230-002
1.245
16230-021
1.244
20110-068
3.67
20110-190
3.28
20114-731
1.117
15230-003
1.245
16230-022
1.244
20110-068
3.68
20110-191
3.28
20114-731
1.150
15230-004
1.245
16230-023
1.244
20110-071
3.27
20110-192
3.28
20114-731
1.151
15230-005
1.245
16230-024
1.244
20110-071
6.126
20110-193
3.28
20114-731
1.153
15230-006
1.245
16230-025
1.244
20110-072
3.27
20110-194
3.28
20114-731
1.154
15230-007
1.245
19713-006
4.8
20110-072
6.126
20110-195
3.28
20114-731
1.176
15230-008
1.245
19713-121
4.8
20110-073
3.27
20110-196
3.28
20114-731
1.198
12.14
SCHROFF Main catalogue
Appendix
Part no.
Page
Part no.
20114-731
1.24
20117-753
1.303
20118-351
1.177
20118-554
1.359
20118-745
1.358
20114-731
1.25
20117-754
1.303
20118-351
1.199
20118-590
3.37
20118-746
3.29
20114-731
1.283
20117-756
1.303
20118-351
1.25
20118-591
3.37
20118-747
3.30
20114-731
1.52
20117-757
1.276
20118-351
1.253
20118-592
1.284
20118-748
3.31
20114-731
1.66
20117-757
1.277
20118-351
1.269
20118-592
1.298
20118-749
3.31
20114-731
1.67
20117-757
1.290
20118-351
1.287
20118-592
1.311
20118-750
1.133
20114-731
1.83
20117-757
1.302
20118-351
1.53
20118-593
1.284
20118-750
1.166
20114-731
1.93
20117-765
1.279
20118-351
1.67
20118-593
1.298
20118-750
1.188
20114-731
1.94
20117-765
1.292
20118-351
1.83
20118-593
1.311
20118-750
1.238
20117-024
1.276
20117-765
1.304
20118-351
1.95
20118-624
1.118
20118-750
1.265
20117-024
1.277
20117-766
1.279
20118-351
2.26
20118-624
1.154
20118-750
1.294
20117-024
1.290
20117-766
1.292
20118-351
2.31
20118-624
1.177
20118-750
1.295
20117-024
1.302
20117-766
1.304
20118-351
2.32
20118-624
1.199
20118-750
1.306
20117-080
1.276
20117-767
1.279
20118-351
2.42
20118-624
1.25
20118-750
1.307
20117-080
1.277
20117-767
1.292
20118-351
3.20
20118-624
1.253
20118-750
1.34
20117-080
1.294
20117-767
1.304
20118-351
3.21
20118-624
1.269
20118-750
1.35
20117-080
1.306
20117-768
1.279
20118-352
1.154
20118-624
1.287
20118-750
1.72
20117-156
1.290
20117-768
1.292
20118-352
1.25
20118-624
1.53
20118-750
2.27
20117-503
1.281
20117-768
1.304
20118-352
1.253
20118-624
1.67
20118-753
3.29
20117-503
1.296
20117-769
1.279
20118-352
1.287
20118-624
1.83
20118-753
3.30
20117-503
1.308
20117-770
1.279
20118-352
1.67
20118-624
1.95
20118-753
3.31
20117-515
1.302
20117-770
1.292
20118-352
1.95
20118-624
2.31
20118-753
3.32
20117-744
1.278
20117-770
1.304
20118-352
3.20
20118-624
3.20
20118-757
1.343
20117-745
1.278
20117-771
1.279
20118-353
1.154
20118-630
3.16
20118-757
3.8
20117-745
1.291
20117-771
1.292
20118-353
1.25
20118-631
3.16
20118-758
1.343
20117-745
1.303
20117-771
1.304
20118-353
1.253
20118-686
1.351
20118-758
3.8
20117-746
1.278
20117-772
1.279
20118-353
1.287
20118-706
3.21
20118-759
1.343
20117-746
1.291
20117-772
1.292
20118-353
1.67
20118-713
2.34
20118-759
3.8
20117-746
1.303
20117-772
1.304
20118-353
1.95
20118-714
2.34
20118-760
1.343
20117-747
1.278
20117-775
1.304
20118-353
3.20
20118-715
2.34
20118-760
3.8
20117-747
1.291
20117-776
1.304
20118-364
3.37
20118-716
2.33
20118-761
1.342
20117-747
1.303
20117-777
1.304
20118-365
3.37
20118-717
2.34
20118-761
3.7
20117-748
1.278
20118-030
3.36
20118-366
3.37
20118-719
2.44
20118-762
1.342
20117-748
1.291
20118-265
3.37
20118-390
1.247
20118-729
3.21
20118-762
3.7
20117-748
1.303
20118-266
3.37
20118-390
1.262
20118-734
1.343
20118-767
1.343
20117-749
1.278
20118-280
3.35
20118-391
1.247
20118-734
3.8
20118-767
3.8
20117-749
1.291
20118-281
3.37
20118-391
1.262
20118-736
1.343
20118-768
1.343
20117-749
1.303
20118-282
3.37
20118-460
1.358
20118-736
3.8
20118-768
3.8
20117-751
1.278
20118-339
1.283
20118-461
1.359
20118-738
3.32
20118-775
1.150
20117-751
1.291
20118-339
1.359
20118-462
1.357
20118-740
3.20
20118-775
1.151
20117-751
1.303
20118-340
1.283
20118-536
3.35
20118-741
1.357
20118-775
1.153
20117-752
1.278
20118-340
1.359
20118-537
3.36
20118-742
1.357
20118-775
1.154
20117-752
1.291
20118-351
1.118
20118-538
3.34
20118-743
1.357
20118-775
1.24
20117-752
1.303
20118-351
1.154
20118-554
1.283
20118-744
1.358
20118-775
1.25
Page
Part no.
Page
Part no.
Page
Part no.
Page
12.15
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
20118-775
1.283
20118-783
1.360
20119-257
1.361
20130-014
1.180
20130-027
1.158
20118-775
1.66
20118-783
2.29
20119-354
3.34
20130-014
1.28
20130-027
1.180
20118-775
1.67
20118-783
3.11
20119-355
3.34
20130-014
1.40
20130-027
1.28
20118-775
1.93
20118-784
1.345
20119-356
3.34
20130-014
1.70
20130-027
1.40
20118-775
1.94
20118-784
3.11
20119-357
3.34
20130-015
1.158
20130-027
1.70
20118-776
1.150
20118-785
1.345
20119-358
3.34
20130-015
1.180
20130-028
1.158
20118-776
1.151
20118-785
1.360
20125-005
1.350
20130-015
1.28
20130-028
1.180
20118-776
1.153
20118-785
2.29
20125-006
1.349
20130-015
1.40
20130-028
1.28
20118-776
1.154
20118-785
3.11
20125-018
1.351
20130-015
1.70
20130-028
1.40
20118-776
1.24
20118-786
1.345
20125-021
1.349
20130-016
1.158
20130-028
1.70
20118-776
1.25
20118-786
3.11
20130-001
1.158
20130-016
1.180
20130-029
1.158
20118-776
1.283
20118-787
1.345
20130-001
1.180
20130-017
1.28
20130-029
1.180
20118-776
1.66
20118-787
3.11
20130-002
1.158
20130-017
1.40
20130-030
1.158
20118-776
1.67
20118-788
1.345
20130-002
1.180
20130-018
1.158
20130-030
1.180
20118-776
1.93
20118-788
3.11
20130-003
1.158
20130-018
1.180
20130-030
1.70
20118-776
1.94
20118-789
1.345
20130-003
1.180
20130-018
1.28
20130-031
1.158
20118-777
1.150
20118-789
1.360
20130-004
1.158
20130-018
1.40
20130-031
1.180
20118-777
1.151
20118-789
2.29
20130-004
1.180
20130-018
1.70
20130-032
1.158
20118-777
1.153
20118-789
3.11
20130-005
1.158
20130-019
1.158
20130-032
1.180
20118-777
1.154
20118-790
1.345
20130-005
1.180
20130-019
1.180
20130-032
1.28
20118-777
1.24
20118-790
1.360
20130-005
1.28
20130-019
1.28
20130-032
1.40
20118-777
1.25
20118-790
2.29
20130-005
1.40
20130-019
1.40
20130-032
1.70
20118-777
1.283
20118-790
3.11
20130-005
1.70
20130-019
1.70
20130-033
1.158
20118-777
1.66
20118-791
1.345
20130-006
1.158
20130-020
1.158
20130-033
1.180
20118-777
1.67
20118-791
1.360
20130-006
1.180
20130-020
1.180
20130-034
1.158
20118-777
1.93
20118-791
3.11
20130-006
1.28
20130-021
1.158
20130-034
1.180
20118-777
1.94
20118-796
1.247
20130-006
1.40
20130-021
1.180
20130-035
1.158
20118-778
1.150
20118-796
1.262
20130-006
1.70
20130-021
1.70
20130-035
1.180
20118-778
1.151
20118-796
1.279
20130-007
1.158
20130-022
1.158
20130-036
1.158
20118-778
1.153
20118-796
1.293
20130-007
1.180
20130-022
1.180
20130-036
1.180
20118-778
1.154
20118-796
1.305
20130-008
1.158
20130-022
1.28
20130-037
1.158
20118-778
1.24
20118-797
1.247
20130-008
1.180
20130-022
1.40
20130-037
1.180
20118-778
1.25
20118-797
1.262
20130-009
1.28
20130-022
1.70
20130-038
1.158
20118-778
1.283
20118-797
1.279
20130-009
1.40
20130-023
1.158
20130-038
1.180
20118-778
1.66
20118-797
1.293
20130-009
1.70
20130-023
1.180
20130-051
1.158
20118-778
1.67
20118-797
1.305
20130-010
1.28
20130-023
1.28
20130-051
1.180
20118-778
1.93
20119-080
1.361
20130-010
1.40
20130-023
1.40
20130-052
1.158
20118-778
1.94
20119-106
1.361
20130-010
1.70
20130-023
1.70
20130-052
1.180
20118-781
1.345
20119-159
7.11
20130-013
1.158
20130-024
1.158
20130-053
1.158
20118-781
1.360
20119-160
7.11
20130-013
1.180
20130-024
1.180
20130-053
1.180
20118-781
3.11
20119-161
7.11
20130-013
1.28
20130-025
1.158
20130-054
1.158
20118-782
1.345
20119-162
7.11
20130-013
1.40
20130-025
1.180
20130-054
1.180
20118-782
3.11
20119-163
7.11
20130-013
1.70
20130-026
1.28
20130-055
1.158
20118-783
1.345
20119-257
1.344
20130-014
1.158
20130-026
1.40
20130-055
1.180
12.16
Appendix
Part no.
Page
Part no.
Page
Part no.
20130-055
1.28
20130-055
1.40
20130-055
20130-069
1.70
20130-084
1.158
20130-595
1.158
20130-631
1.106
20130-070
1.158
20130-084
1.180
20130-595
1.180
20130-631
1.98
1.70
20130-070
1.180
20130-085
1.158
20130-596
1.158
20130-632
1.102
20130-056
1.158
20130-071
1.158
20130-085
1.180
20130-596
1.180
20130-632
1.106
20130-056
1.180
20130-071
1.180
20130-086
1.158
20130-597
1.158
20130-632
1.98
20130-056
1.28
20130-071
1.70
20130-086
1.180
20130-597
1.180
20130-633
1.102
20130-056
1.40
20130-072
1.158
20130-087
1.158
20130-598
1.146
20130-633
1.106
20130-056
1.70
20130-072
1.180
20130-087
1.180
20130-617
1.102
20130-633
1.98
20130-057
1.158
20130-072
1.28
20130-088
1.158
20130-617
1.106
20130-634
1.102
20130-057
1.180
20130-072
1.40
20130-088
1.180
20130-617
1.98
20130-634
1.106
20130-058
1.158
20130-072
1.70
20130-578
1.158
20130-618
1.102
20130-634
1.98
20130-058
1.180
20130-073
1.158
20130-578
1.180
20130-618
1.106
20130-636
1.102
20130-059
1.28
20130-073
1.180
20130-579
1.158
20130-618
1.98
20130-636
1.106
20130-059
1.40
20130-073
1.28
20130-579
1.180
20130-621
1.102
20130-636
1.98
20130-059
1.70
20130-073
1.40
20130-580
1.158
20130-621
1.106
20150-011
1.295
20130-060
1.28
20130-073
1.70
20130-580
1.180
20130-621
1.98
20150-011
1.307
20130-060
1.40
20130-074
1.158
20130-581
1.158
20130-622
1.102
20225-167
5.114
20130-060
1.70
20130-074
1.180
20130-581
1.180
20130-622
1.106
20225-439
5.105
20130-063
1.158
20130-075
1.158
20130-582
1.158
20130-622
1.98
20230-409
1.258
20130-063
1.180
20130-075
1.180
20130-582
1.180
20130-623
1.102
20505-032
5.113
20130-063
1.28
20130-077
1.158
20130-583
1.158
20130-623
1.106
20603-001
5.107
20130-063
1.40
20130-077
1.180
20130-583
1.180
20130-623
1.98
20603-001
5.116
20130-063
1.70
20130-077
1.28
20130-584
1.158
20130-624
1.102
20603-001
5.23
20130-064
1.158
20130-077
1.40
20130-584
1.180
20130-624
1.106
20603-001
5.61
20130-064
1.180
20130-077
1.70
20130-585
1.158
20130-624
1.98
20603-001
5.62
20130-064
1.28
20130-078
1.158
20130-585
1.180
20130-625
1.102
20603-001
5.72
20130-064
1.40
20130-078
1.180
20130-586
1.158
20130-625
1.106
20603-001
5.87
20130-064
1.70
20130-078
1.28
20130-586
1.180
20130-625
1.98
20603-002
5.107
20130-065
1.158
20130-078
1.40
20130-587
1.158
20130-626
1.102
20603-002
5.116
20130-065
1.180
20130-078
1.70
20130-587
1.180
20130-626
1.106
20603-002
5.23
20130-065
1.28
20130-079
1.158
20130-588
1.158
20130-626
1.98
20603-002
5.61
20130-065
1.40
20130-079
1.180
20130-588
1.180
20130-627
1.102
20603-002
5.62
20130-065
1.70
20130-080
1.158
20130-589
1.158
20130-627
1.106
20603-002
5.72
20130-066
1.158
20130-080
1.180
20130-589
1.180
20130-627
1.98
20603-002
5.87
20130-066
1.180
20130-080
1.70
20130-590
1.158
20130-628
1.102
20603-003
5.23
20130-068
1.158
20130-081
1.158
20130-590
1.180
20130-628
1.106
20603-004
5.23
20130-068
1.180
20130-081
1.180
20130-591
1.158
20130-628
1.98
20700-001
4.10
20130-068
1.28
20130-082
1.158
20130-591
1.180
20130-629
1.102
20700-001
4.16
20130-068
1.40
20130-082
1.180
20130-592
1.158
20130-629
1.106
20700-001
4.61
20130-068
1.70
20130-082
1.28
20130-592
1.180
20130-629
1.98
20705-008
4.9
20130-069
1.158
20130-082
1.40
20130-593
1.158
20130-630
1.102
20713-048
1.294
20130-069
1.180
20130-082
1.70
20130-593
1.180
20130-630
1.106
20713-048
1.295
20130-069
1.28
20130-083
1.158
20130-594
1.158
20130-630
1.98
20713-048
1.306
20130-069
1.40
20130-083
1.180
20130-594
1.180
20130-631
1.102
20713-048
1.307
Page
Part no.
Page
Part no.
Page
12.17
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
20713-142
4.16
20713-243
4.7
20808-080
7.55
20809-441
7.105
20817-452
7.39
20713-142
4.61
20713-244
4.10
20808-081
7.55
20809-495
7.61
20817-456
7.39
20713-146
4.16
20713-244
4.16
20808-082
7.55
20809-496
7.61
20817-457
7.39
20713-146
4.61
20713-244
4.6
20808-083
7.55
20809-497
7.61
20817-458
7.39
20713-147
4.10
20713-244
4.61
20808-083
7.75
20809-498
7.61
20817-459
7.39
20713-147
4.16
20713-244
4.7
20808-084
7.55
20809-502
7.60
20817-501
5.42
20713-147
4.61
20713-502
4.13
20808-085
7.55
20809-507
7.53
20817-501
6.106
20713-172
4.16
20713-503
4.13
20808-085
7.75
20809-511
7.61
20817-501
6.107
20713-212
4.14
20713-504
4.13
20808-086
7.55
20809-512
7.61
20817-501
6.14
20713-213
4.14
20713-505
4.13
20808-086
7.75
20809-513
7.61
20817-501
6.15
20713-214
4.14
20715-001
4.58
20808-087
7.55
20809-516
7.60
20817-501
6.38
20713-215
4.14
20715-001
4.59
20808-087
7.75
20809-529
7.90
20817-501
6.41
20713-216
4.14
20715-001
4.60
20808-088
7.55
20809-530
7.90
20817-501
6.81
20713-217
4.14
20715-003
4.64
20808-088
7.75
20809-531
7.90
20817-501
7.23
20713-218
4.14
20800-032
7.105
20808-089
7.55
20809-532
7.90
20817-606
7.18
20713-219
4.14
20800-036
11.8
20808-089
7.75
20809-533
7.90
20817-606
7.23
20713-220/05
4.14
20800-042
11.8
20808-090
7.55
20809-534
7.90
20817-612
7.20
20713-221/05
4.14
20800-078
11.8
20808-091
7.55
20809-536
7.90
20817-613
7.20
20713-222/05
4.14
20800-168
10.26
20808-091
7.75
20809-537
7.90
20817-614
7.20
20713-223/05
4.14
20800-212
10.27
20808-092
7.55
20809-538
7.90
20817-615
7.20
20713-224/05
4.14
20800-213
10.27
20808-137
7.49
20809-539
7.90
20817-620
7.20
20713-225/05
4.14
20800-224
10.26
20809-281
7.55
20809-540
7.90
20817-621
7.20
20713-226/05
4.14
20800-278
10.26
20809-282
7.55
20809-541
7.90
20817-622
7.20
20713-227/05
4.14
20800-279
10.26
20809-283
7.55
20810-605
8.110
20817-623
7.20
20713-228/05
4.14
20808-003
7.55
20809-284
7.55
20810-611
8.110
20817-652
7.21
20713-229/05
4.14
20808-004
7.55
20809-285
7.55
20817-325
7.46
20817-653
7.21
20713-230/05
4.14
20808-004
7.75
20809-286
7.55
20817-326
7.46
20817-654
7.21
20713-231/05
4.14
20808-009
7.55
20809-287
7.55
20817-327
7.41
20817-655
7.21
20713-236/05
4.14
20808-012
7.55
20809-288
7.55
20817-328
7.41
20817-660
7.21
20713-237/05
4.14
20808-060
7.55
20809-289
7.55
20817-329
7.41
20817-661
7.21
20713-238/05
4.14
20808-061
7.55
20809-290
7.55
20817-330
7.41
20817-662
7.21
20713-239/05
4.14
20808-062
7.55
20809-291
7.55
20817-345
7.46
20817-663
7.21
20713-240
4.10
20808-062
7.75
20809-292
7.55
20817-346
7.46
20817-682
7.20
20713-240
4.16
20808-063
7.55
20809-293
7.55
20817-368
6.134
20817-683
7.20
20713-240
4.6
20808-064
7.55
20809-294
7.55
20817-369
6.134
20817-684
7.20
20713-240
4.7
20808-064
7.75
20809-295
7.55
20817-443
7.39
20817-685
7.20
20713-241
4.16
20808-065
7.55
20809-329
7.61
20817-444
7.39
20817-690
7.20
20713-242
4.16
20808-065
7.75
20809-357
7.61
20817-445
7.39
20817-691
7.20
20713-243
1.295
20808-066
7.55
20809-359
7.61
20817-446
7.39
20817-692
7.20
20713-243
1.307
20808-066
7.75
20809-371
7.60
20817-447
7.39
20817-693
7.20
20713-243
4.10
20808-067
7.55
20809-371
7.61
20817-448
7.39
20817-706
7.21
20713-243
4.16
20808-067
7.75
20809-396
7.55
20817-449
7.39
20817-707
7.21
20713-243
4.6
20808-068
7.55
20809-397
7.55
20817-450
7.39
20817-708
7.21
20713-243
4.61
20808-068
7.75
20809-441
11.8
20817-451
7.39
20817-709
7.21
12.18
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
20817-714
7.21
20818-026
7.53
20823-674
5.84
20838-001
7.91
20846-430
6.49
20817-715
7.21
20818-027
7.53
20823-675
5.83
20838-002
7.91
20846-430
7.5
20817-716
7.21
20818-028
7.53
20823-676
5.83
20838-003
7.91
20846-431
6.49
20817-717
7.21
20818-029
7.53
20825-120
6.134
20838-004
7.91
20846-431
7.5
20817-829
7.34
20818-120
7.53
20825-121
6.134
20838-005
7.91
20846-432
6.49
20817-831
7.34
20818-121
8.15
20828-028
6.131
20838-006
7.91
20846-432
7.5
20817-833
7.34
20818-122
8.15
20828-127
6.133
20838-084
1.351
20846-433
6.49
20817-853
8.32
20818-123
8.15
20828-128
6.133
20838-086
1.351
20846-433
7.5
20817-853
8.33
20818-124
8.15
20828-129
6.133
20838-093
7.91
20846-434
6.49
20817-853
8.34
20818-140
8.12
20829-003
7.44
20838-094
7.91
20846-434
7.5
20817-854
7.34
20818-140
8.13
20829-004
7.44
20838-095
7.91
20846-436
6.49
20817-856
7.34
20818-140
8.14
20829-011
7.44
20838-096
7.91
20846-436
7.5
20817-858
7.34
20818-140
8.15
20833-351
5.26
20838-097
7.91
20846-437
6.49
20817-860
7.32
20818-145
8.15
20833-352
5.26
20838-098
7.91
20846-437
7.5
20817-861
7.32
20818-146
8.15
20833-353
5.26
20838-271
6.51
20846-438
6.49
20817-862
7.32
20818-147
8.15
20835-188
8.111
20838-271
7.8
20846-438
7.5
20817-863
7.32
20818-148
8.15
20835-598
7.13
20838-272
6.51
20846-443
6.49
20817-864
7.32
20818-160
8.12
20835-889
7.13
20838-272
7.8
20846-443
7.5
20817-865
7.32
20818-161
8.12
20835-890
7.13
20838-273
6.51
20846-444
6.49
20817-866
7.32
20818-162
7.53
20835-893
7.13
20838-273
7.8
20846-444
7.5
20817-867
7.32
20818-163
8.13
20835-896
7.13
20838-274
6.51
20846-445
6.49
20817-868
7.32
20818-164
8.13
20835-899
7.13
20838-274
7.8
20846-445
7.5
20817-869
7.32
20818-169
8.12
20835-922
7.13
20838-275
6.51
20846-446
6.49
20817-870
7.32
20818-170
8.12
20835-923
7.13
20838-275
7.8
20846-446
7.5
20817-871
7.32
20822-046
6.34
20835-924
7.13
20838-276
6.51
20846-447
6.49
20817-872
7.32
20822-047
5.35
20835-928
7.13
20838-276
7.8
20846-447
7.5
20817-873
7.32
20822-047
5.69
20835-929
7.13
20838-277
6.51
20846-448
6.49
20817-874
7.29
20822-047
5.91
20835-931
7.13
20838-277
7.8
20846-448
7.5
20817-877
7.29
20822-047
6.34
20836-145
8.95
20838-278
6.51
20846-449
6.49
20817-900
10.14
20822-048
5.35
20836-220
8.100
20838-278
7.8
20846-449
7.5
20817-909
8.32
20822-048
5.69
20836-223
8.100
20838-279
6.51
20846-450
6.49
20817-909
8.33
20822-048
5.91
20836-235
8.102
20838-279
7.8
20846-450
7.5
20817-909
8.34
20822-048
6.34
20836-235
8.103
20838-280
6.51
20846-451
6.49
20817-969
10.14
20822-049
5.35
20836-245
8.96
20838-280
7.8
20846-451
7.5
20817-970
10.14
20822-049
5.69
20836-310
8.90
20846-425
6.49
20846-452
6.49
20818-017
7.53
20822-049
5.91
20836-415
8.91
20846-425
7.5
20846-452
7.5
20818-018
7.53
20822-049
6.34
20836-416
8.97
20846-426
6.49
20846-453
6.49
20818-019
7.53
20822-050
5.35
20836-444
8.104
20846-426
7.5
20846-453
7.5
20818-020
7.53
20822-050
5.69
20836-715
8.92
20846-427
6.49
20846-454
6.49
20818-021
7.53
20822-050
5.91
20836-716
8.93
20846-427
7.5
20846-454
7.5
20818-022
7.53
20822-050
6.34
20836-717
8.98
20846-428
6.49
20846-456
6.49
20818-023
7.53
20822-051
6.34
20836-815
8.94
20846-428
7.5
20846-456
7.5
20818-024
7.53
20823-668
5.84
20836-820
8.99
20846-429
6.49
20848-013
6.50
20818-025
7.53
20823-669
5.84
20836-855
8.100
20846-429
7.5
20848-013
7.7
Part number in bold face type: ready for despatch within 2 working days
12.19
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
20848-015
7.7
20848-489
7.38
20848-633
5.22
20848-681
5.22
20848-729
5.75
20848-020
6.50
20848-490
7.38
20848-633
5.55
20848-681
5.55
20848-729
6.61
20848-020
7.7
20848-491
7.38
20848-634
5.22
20848-682
5.22
20848-730
5.43
20848-027
6.50
20848-492
7.38
20848-634
5.55
20848-682
5.55
20848-730
5.75
20848-027
7.7
20848-494
7.38
20848-635
5.22
20848-686
7.31
20848-730
6.61
20848-047
6.50
20848-496
7.38
20848-635
5.55
20848-687
7.31
20848-731
5.43
20848-047
7.7
20848-497
7.38
20848-636
5.22
20848-688
7.31
20848-731
5.75
20848-068
6.50
20848-498
7.38
20848-636
5.55
20848-689
7.31
20848-731
6.61
20848-068
7.7
20848-585
7.18
20848-640
5.22
20848-690
7.31
20848-732
5.43
20848-097
6.50
20848-587
7.18
20848-640
5.55
20848-691
7.31
20848-732
5.75
20848-097
7.7
20848-589
7.18
20848-641
5.22
20848-692
7.31
20848-732
6.61
20848-106
6.50
20848-590
7.18
20848-641
5.55
20848-693
7.31
20848-733
5.43
20848-106
7.7
20848-591
7.18
20848-642
5.22
20848-694
7.31
20848-733
5.75
20848-108
6.50
20848-592
7.18
20848-642
5.55
20848-695
7.31
20848-733
6.61
20848-108
7.7
20848-594
7.18
20848-643
5.22
20848-696
6.51
20848-736
5.43
20848-113
6.50
20848-596
7.18
20848-643
5.55
20848-696
7.8
20848-736
5.75
20848-113
7.7
20848-597
7.18
20848-656
5.22
20848-712
5.43
20848-736
6.61
20848-120
6.50
20848-598
7.18
20848-656
5.55
20848-712
6.61
20848-738
5.43
20848-120
7.7
20848-599
6.51
20848-657
5.22
20848-713
5.43
20848-738
5.75
20848-139
6.50
20848-599
7.8
20848-657
5.55
20848-713
6.61
20848-738
6.61
20848-139
7.7
20848-600
6.51
20848-658
5.22
20848-714
5.43
20848-739
5.43
20848-160
6.50
20848-600
7.8
20848-658
5.55
20848-714
6.61
20848-739
5.75
20848-160
7.7
20848-601
6.51
20848-659
5.22
20848-715
5.43
20848-739
6.61
20848-189
6.50
20848-601
7.8
20848-659
5.55
20848-715
6.61
20848-740
5.43
20848-189
7.7
20848-602
6.51
20848-663
7.52
20848-716
5.43
20848-740
5.75
20848-227
7.19
20848-602
7.8
20848-664
7.52
20848-716
6.61
20848-740
6.61
20848-228
7.19
20848-603
6.51
20848-665
7.52
20848-717
5.43
20848-741
5.43
20848-230
7.19
20848-603
7.8
20848-666
7.52
20848-717
6.61
20848-741
5.75
20848-232
7.19
20848-604
6.51
20848-667
7.52
20848-720
5.43
20848-741
6.61
20848-243
7.19
20848-604
7.8
20848-668
7.52
20848-720
6.61
20848-744
5.22
20848-244
7.19
20848-605
6.51
20848-669
7.52
20848-721
5.43
20848-745
5.22
20848-246
7.19
20848-605
7.8
20848-670
7.52
20848-721
6.61
20848-746
5.22
20848-248
7.19
20848-606
6.51
20848-671
7.52
20848-722
5.43
20848-747
5.22
20848-262
6.50
20848-606
7.8
20848-672
7.52
20848-722
6.61
20848-751
7.18
20848-262
7.7
20848-607
6.51
20848-673
7.52
20848-723
5.43
20848-752
7.18
20848-268
6.50
20848-607
7.8
20848-674
7.52
20848-723
6.61
20849-008
8.30
20848-269
6.50
20848-608
6.51
20848-675
7.52
20848-724
5.43
20849-009
8.30
20848-270
6.50
20848-608
7.8
20848-676
7.52
20848-724
6.61
20849-010
8.30
20848-271
6.50
20848-611
5.57
20848-677
7.52
20848-725
5.43
20849-011
8.30
20848-271
7.7
20848-611
6.51
20848-678
7.52
20848-725
6.61
20849-016
8.63
20848-280
6.50
20848-611
7.9
20848-679
5.22
20848-728
5.43
20849-017
8.63
20848-280
7.7
20848-617
5.57
20848-679
5.55
20848-728
5.75
20849-018
8.63
20848-485
7.38
20848-617
6.51
20848-680
5.22
20848-728
6.61
20849-021
8.30
20848-487
7.38
20848-617
7.9
20848-680
5.55
20848-729
5.43
20849-021
8.34
12.20
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
20849-022
8.63
20849-236
8.30
20850-185
5.58
20860-126
6.114
20860-258
5.109
20849-023
8.63
20849-236
8.31
20850-186
5.58
20860-127
6.114
20860-258
6.115
20849-024
8.63
20849-242
8.34
20850-190
5.58
20860-130
6.115
20860-258
6.116
20849-025
8.63
20849-248
8.63
20850-191
5.58
20860-130
6.116
20860-258
6.121
20849-106
8.63
20849-249
8.63
20850-192
5.58
20860-130
6.117
20860-259
5.109
20849-107
8.63
20849-250
8.63
20850-196
5.58
20860-130
6.121
20860-259
6.115
20849-115
8.38
20849-251
8.63
20850-197
5.58
20860-130
6.123
20860-259
6.116
20849-115
8.39
20849-268
8.59
20850-198
5.58
20860-131
6.121
20860-259
6.121
20849-115
8.40
20849-269
8.59
20850-249
5.111
20860-131
6.123
20860-260
5.109
20849-115
8.48
20849-270
8.59
20850-249
5.60
20860-201
6.120
20860-260
6.115
20849-127
8.59
20849-271
8.59
20850-299
5.58
20860-201
6.122
20860-260
6.116
20849-128
8.59
20849-288
8.58
20850-300
5.58
20860-202
6.120
20860-260
6.121
20849-129
8.59
20849-289
8.58
20850-301
5.58
20860-202
6.122
20860-601
6.115
20849-130
8.59
20849-290
8.58
20850-315
5.58
20860-203
6.120
20860-602
6.115
20849-131
8.59
20849-291
8.58
20850-316
5.58
20860-203
6.122
20860-605
6.115
20849-132
8.59
20849-304
8.63
20850-317
5.58
20860-210
6.120
20860-606
6.115
20849-151
8.61
20849-305
8.63
20850-331
5.58
20860-210
6.122
20860-607
6.115
20849-152
8.61
20849-312
8.59
20850-332
5.58
20860-211
6.120
20860-608
6.115
20849-153
8.61
20849-313
8.59
20850-333
5.58
20860-211
6.122
20860-609
6.115
20849-154
8.61
20849-332
8.58
20850-423
5.54
20860-212
6.120
20860-612
6.115
20849-155
8.61
20849-333
8.58
20850-423
6.48
20860-212
6.122
20860-613
6.115
20849-156
8.61
20849-334
8.58
20850-424
5.54
20860-219
6.120
20860-614
6.115
20849-166
8.34
20849-335
8.58
20850-424
6.48
20860-220
6.120
20860-615
6.115
20849-194
8.49
20849-348
8.66
20850-425
5.54
20860-221
6.120
20860-621
6.116
20849-195
8.49
20849-349
8.66
20850-425
6.48
20860-222
6.120
20860-622
6.116
20849-196
8.49
20849-350
8.66
20850-426
5.54
20860-228
6.120
20860-625
6.116
20849-197
8.49
20849-351
8.66
20850-426
6.48
20860-229
6.120
20860-626
6.116
20849-198
8.49
20849-352
8.66
20850-426
7.4
20860-230
6.120
20860-627
6.116
20849-199
8.49
20849-353
8.66
20860-107
6.120
20860-231
6.120
20860-628
6.116
20849-200
8.49
20849-355
8.66
20860-108
6.120
20860-240
6.120
20860-629
6.116
20849-201
8.49
20849-356
8.66
20860-109
6.120
20860-256
5.109
20860-632
6.116
20849-202
8.49
20849-357
8.66
20860-110
6.120
20860-256
6.114
20860-633
6.116
20849-209
8.58
20850-128
5.54
20860-111
6.120
20860-256
6.115
20860-634
6.116
20849-209
8.59
20850-129
5.54
20860-115
6.117
20860-256
6.116
20860-635
6.116
20849-209
8.62
20850-130
5.54
20860-115
6.122
20860-256
6.117
20860-641
6.117
20849-209
8.67
20850-134
5.54
20860-116
6.117
20860-256
6.121
20860-642
6.117
20849-213
8.65
20850-135
5.54
20860-116
6.122
20860-256
6.123
20860-645
6.117
20849-214
8.65
20850-136
5.54
20860-117
6.117
20860-257
5.109
20897-950
7.12
20849-235
8.28
20850-137
5.54
20860-117
6.122
20860-257
6.114
21005-439
9.12
20849-235
8.29
20850-142
5.54
20860-118
6.117
20860-257
6.115
21005-451
9.12
20849-235
8.30
20850-143
5.54
20860-118
6.122
20860-257
6.116
21005-470
9.12
20849-235
8.31
20850-144
5.54
20860-120
6.114
20860-257
6.117
21005-473
9.10
20849-236
8.28
20850-158
5.54
20860-121
6.114
20860-257
6.121
21005-474
9.10
20849-236
8.29
20850-184
5.58
20860-122
6.114
20860-257
6.123
21005-475
9.10
Page
Part no.
Page
12.21
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21005-476
9.11
21100-207
5.72
21100-435
6.73
21100-646
5.35
21100-748
7.107
21005-477
9.11
21100-207
5.87
21100-435
6.74
21100-646
5.68
21100-748
7.108
21005-478
9.11
21100-211
5.107
21100-435
6.75
21100-646
5.90
21100-748
7.35
21006-943
9.3
21100-211
5.116
21100-435
6.76
21100-646
6.104
21100-748
7.42
21006-943
9.4
21100-211
5.117
21100-435
6.77
21100-646
6.33
21100-748
7.47
21006-945
9.7
21100-211
5.72
21100-435
6.78
21100-646
6.66
21100-748
7.50
21006-945
9.8
21100-211
5.87
21100-435
6.79
21100-646
7.111
21100-748
7.57
21006-946
9.9
21100-215
3.18
21100-435
6.8
21100-647
5.85
21100-748
7.78
21006-954
9.5
21100-216
3.18
21100-435
6.80
21100-648
7.109
21100-748
7.93
21006-955
9.13
21100-268
7.108
21100-435
6.9
21100-649
7.109
21100-749
7.108
21006-956
9.13
21100-276
5.35
21100-448
5.106
21100-650
3.17
21100-777
10.28
21006-956
9.14
21100-276
5.68
21100-459
7.104
21100-659
6.63
21100-777
6.65
21006-957
9.15
21100-276
5.90
21100-459
7.111
21100-659
7.107
21100-777
7.110
21006-959
9.2
21100-276
6.104
21100-464
6.63
21100-660
6.63
21100-788
3.3
21009-038
9.21
21100-276
6.33
21100-464
7.107
21100-660
7.107
21100-788
5.109
21009-039
9.24
21100-276
6.66
21100-464
7.22
21100-660
7.57
21100-788
5.110
21009-039
9.25
21100-276
7.111
21100-464
7.35
21100-661
6.63
21100-788
7.110
21100-001
3.18
21100-289
7.92
21100-464
7.42
21100-661
7.107
21100-814
6.133
21100-002
3.18
21100-293
11.4
21100-464
7.47
21100-662
6.63
21100-886
6.63
21100-003
3.17
21100-294
11.4
21100-464
7.50
21100-662
7.107
21101-007
3.19
21100-004
3.17
21100-347
5.106
21100-464
7.57
21100-662
7.22
21101-069
7.104
21100-015
3.17
21100-359
7.111
21100-464
7.78
21100-662
7.35
21101-069
7.110
21100-016
3.17
21100-359
7.55
21100-464
7.93
21100-662
7.42
21101-069
7.57
21100-021
3.17
21100-359
7.93
21100-476
7.55
21100-662
7.47
21101-101
5.39
21100-022
3.17
21100-404
11.8
21100-490
5.106
21100-662
7.50
21101-101
5.70
21100-076
7.103
21100-429
7.109
21100-500
7.109
21100-662
7.57
21101-101
5.95
21100-089
5.114
21100-429
7.22
21100-507
7.109
21100-671
6.135
21101-101
6.109
21100-093
5.114
21100-429
7.35
21100-507
7.93
21100-672
6.135
21101-101
6.57
21100-105
7.92
21100-429
7.42
21100-513
5.116
21100-677
6.132
21101-101
6.64
21100-112
7.92
21100-429
7.47
21100-515
7.103
21100-710
7.42
21101-101
7.107
21100-123
3.21
21100-429
7.50
21100-515
7.109
21100-710
7.47
21101-101
7.108
21100-142
7.111
21100-429
7.57
21100-515
7.93
21100-710
7.50
21101-101
7.22
21100-144
7.104
21100-429
7.93
21100-542
7.109
21100-710
7.57
21101-101
7.35
21100-144
7.111
21100-431
7.92
21100-553
6.134
21100-711
8.111
21101-101
7.42
21100-144
7.42
21100-435
2.34
21100-554
6.134
21100-712
7.109
21101-101
7.47
21100-144
7.47
21100-435
2.35
21100-558
3.19
21100-712
8.111
21101-101
7.50
21100-144
7.50
21100-435
5.106
21100-565
6.24
21100-719
7.46
21101-101
7.57
21100-144
7.57
21100-435
6.10
21100-566
6.24
21100-721
7.111
21101-101
7.78
21100-146
6.132
21100-435
6.11
21100-569
7.103
21100-721
7.22
21101-101
7.93
21100-146
7.103
21100-435
6.12
21100-574
8.111
21100-721
7.35
21101-102
5.39
21100-150
7.93
21100-435
6.13
21100-586
3.16
21100-721
7.42
21101-102
5.70
21100-207
5.107
21100-435
6.14
21100-591
6.63
21100-721
7.47
21101-102
5.95
21100-207
5.116
21100-435
6.15
21100-591
7.107
21100-721
7.50
21101-102
6.109
21100-207
5.117
21100-435
6.66
21100-624
7.13
21100-721
7.57
21101-102
6.57
12.22
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
21101-102
6.64
21101-102
7.108
21101-104
21101-219
7.35
21101-705
6.53
21101-775
6.49
21101-850
7.107
21101-220
7.110
21101-705
7.6
21101-775
7.6
21101-853
5.22
4.10
21101-220
7.22
21101-705
7.91
21101-776
6.49
21101-853
5.55
21101-106
7.108
21101-220
7.42
21101-705
9.10
21101-778
7.6
21101-853
6.110
21101-121
5.39
21101-220
7.47
21101-705
9.11
21101-782
6.64
21101-853
6.21
21101-121
5.70
21101-220
7.50
21101-705
9.12
21101-782
7.108
21101-853
6.23
21101-121
5.95
21101-221
7.110
21101-705
9.13
21101-783
6.64
21101-853
6.50
21101-121
6.109
21101-221
7.57
21101-705
9.14
21101-783
7.108
21101-853
6.53
21101-121
6.57
21101-222
7.110
21101-705
9.15
21101-809
1.111
21101-853
6.97
21101-121
7.111
21101-222
7.57
21101-705
9.2
21101-809
1.141
21101-853
7.19
21101-122
2.39
21101-239
7.55
21101-705
9.3
21101-809
1.169
21101-853
7.33
21101-122
2.42
21101-239
7.78
21101-705
9.4
21101-809
1.19
21101-853
7.40
21101-123
2.39
21101-246
4.13
21101-705
9.5
21101-809
1.191
21101-853
7.54
21101-123
2.42
21101-246
4.61
21101-705
9.7
21101-809
1.337
21101-853
7.6
21101-127
1.282
21101-252
11.7
21101-705
9.8
21101-809
1.338
21101-853
7.75
21101-132
1.315
21101-314
7.110
21101-705
9.9
21101-809
1.356
21101-853
8.111
21101-150
1.141
21101-323
7.108
21101-706
6.49
21101-809
1.357
21101-854
5.22
21101-150
1.24
21101-359
5.35
21101-706
6.53
21101-809
1.44
21101-854
5.55
21101-150
1.66
21101-359
5.68
21101-706
7.6
21101-809
1.61
21101-854
6.110
21101-150
1.93
21101-359
6.104
21101-707
6.20
21101-809
1.75
21101-854
6.50
21101-151
1.141
21101-359
6.33
21101-707
6.22
21101-809
1.88
21101-854
6.53
21101-151
1.24
21101-359
6.66
21101-707
6.49
21101-809
3.17
21101-854
7.19
21101-151
1.66
21101-359
7.111
21101-707
6.53
21101-809
5.106
21101-854
7.33
21101-151
1.93
21101-360
1.348
21101-707
7.6
21101-809
6.66
21101-854
7.40
21101-171
3.19
21101-360
1.350
21101-707
9.20
21101-810
1.141
21101-854
7.54
21101-172
3.19
21101-381
5.108
21101-708
6.49
21101-810
1.19
21101-854
7.6
21101-173
3.17
21101-529
3.33
21101-708
6.53
21101-810
1.337
21101-854
7.75
21101-173
3.19
21101-530
3.33
21101-708
7.6
21101-810
1.338
21101-854
8.111
21101-175
1.358
21101-531
3.33
21101-709
6.20
21101-810
1.356
21101-855
5.22
21101-175
1.359
21101-532
3.33
21101-709
6.49
21101-810
1.357
21101-855
5.39
21101-178
1.315
21101-533
3.33
21101-709
6.53
21101-810
1.61
21101-855
5.55
21101-201
1.276
21101-534
3.33
21101-709
7.6
21101-810
1.88
21101-855
5.70
21101-201
1.277
21101-539
1.276
21101-710
6.49
21101-810
3.17
21101-855
5.95
21101-201
1.280
21101-539
1.277
21101-710
6.53
21101-810
5.106
21101-855
6.109
21101-201
1.290
21101-539
1.290
21101-710
7.6
21101-810
6.66
21101-855
6.110
21101-201
1.296
21101-539
1.302
21101-713
6.20
21101-836
2.10
21101-855
6.21
21101-201
1.302
21101-596
1.283
21101-713
6.49
21101-836
2.11
21101-855
6.23
21101-201
1.308
21101-596
1.359
21101-713
6.53
21101-847
6.63
21101-855
6.53
21101-211
5.107
21101-658
10.5
21101-713
7.6
21101-847
7.107
21101-855
6.57
21101-211
5.117
21101-658
10.6
21101-714
6.49
21101-848
6.63
21101-855
6.97
21101-211
5.72
21101-658
10.7
21101-714
6.53
21101-848
7.107
21101-855
7.19
21101-211
5.87
21101-705
6.20
21101-714
7.6
21101-849
6.63
21101-855
7.29
21101-219
7.110
21101-705
6.22
21101-749
6.64
21101-849
7.107
21101-855
7.33
21101-219
7.22
21101-705
6.49
21101-749
7.108
21101-850
6.63
21101-855
7.40
Page
12.23
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21101-855
7.54
21101-954
6.20
21117-170
1.303
21120-131
3.17
21126-271
3.14
21101-855
7.6
21101-954
6.21
21117-171
1.291
21120-132
3.17
21127-197
1.284
21101-855
7.75
21101-954
6.22
21117-171
1.303
21120-140
1.117
21127-197
1.298
21101-855
8.111
21101-954
6.23
21117-172
1.291
21120-140
1.151
21127-197
1.311
21101-855
6.50
21101-954
6.24
21117-172
1.303
21120-140
1.154
21127-198
1.284
21101-856
5.22
21101-958
4.12
21117-173
1.291
21120-140
1.176
21127-198
1.298
21101-856
5.55
21101-964
6.65
21117-173
1.303
21120-140
1.198
21127-198
1.311
21101-856
6.110
21101-964
7.111
21117-179
1.291
21120-140
1.24
21127-199
1.298
21101-856
6.50
21101-978
5.22
21117-179
1.303
21120-140
1.25
21127-199
1.311
21101-856
6.53
21101-978
7.6
21117-180
1.291
21120-140
1.282
21127-990
3.19
21101-856
7.19
21101-990
6.134
21117-180
1.303
21120-140
1.52
21130-001
1.159
21101-856
7.29
21102-001
5.50
21117-181
1.291
21120-140
1.66
21130-002
1.159
21101-856
7.33
21102-001
5.51
21117-181
1.303
21120-140
1.67
21130-003
1.103
21101-856
7.40
21102-001
5.52
21117-182
1.291
21120-140
1.83
21130-003
1.159
21101-856
7.54
21102-001
5.65
21117-182
1.303
21120-140
1.93
21130-003
1.29
21101-856
7.6
21102-007
7.62
21117-184
1.278
21120-140
1.94
21130-003
1.41
21101-856
7.75
21102-008
7.62
21117-185
1.278
21120-145
1.282
21130-003
1.99
21101-856
8.111
21102-013
4.16
21117-185
1.292
21120-146
1.282
21130-004
1.103
21101-857
5.22
21102-014
4.17
21117-185
1.304
21120-147
1.282
21130-004
1.159
21101-857
5.55
21102-015
4.17
21117-186
1.278
21120-148
3.18
21130-004
1.29
21101-857
7.6
21102-024
8.65
21117-186
1.292
21120-149
3.18
21130-004
1.41
21101-858
5.22
21102-025
7.100
21117-186
1.304
21120-150
3.37
21130-004
1.99
21101-858
5.55
21102-025
7.101
21117-187
1.278
21120-158
3.25
21130-005
1.103
21101-858
6.21
21117-158
1.291
21117-187
1.292
21120-158
3.26
21130-005
1.29
21101-858
6.50
21117-158
1.303
21117-187
1.304
21120-159
3.25
21130-005
1.41
21101-858
6.53
21117-159
1.291
21117-188
1.278
21120-159
3.26
21130-005
1.99
21101-858
7.6
21117-159
1.303
21117-188
1.292
21120-160
3.25
21130-006
1.103
21101-859
6.21
21117-160
1.291
21117-188
1.304
21120-160
3.26
21130-006
1.29
21101-859
6.50
21117-160
1.303
21117-189
1.278
21120-161
3.27
21130-006
1.41
21101-859
6.53
21117-161
1.291
21117-189
1.292
21120-161
6.126
21130-006
1.99
21101-859
7.6
21117-161
1.303
21117-189
1.304
21120-162
3.27
21130-007
1.103
21101-884
6.65
21117-162
1.291
21117-190
1.278
21120-162
6.126
21130-007
1.159
21101-904
6.50
21117-162
1.303
21117-190
1.292
21120-163
3.27
21130-007
1.29
21101-904
6.53
21117-163
1.291
21117-190
1.304
21120-163
6.126
21130-007
1.41
21101-904
7.6
21117-163
1.303
21117-191
1.278
21120-164
3.28
21130-007
1.99
21101-906
7.108
21117-164
1.291
21117-191
1.292
21120-165
3.28
21130-008
1.103
21101-909
6.64
21117-164
1.303
21117-191
1.304
21120-166
3.28
21130-008
1.159
21101-909
7.108
21117-167
1.291
21117-198
1.304
21120-178
4.63
21130-008
1.29
21101-914
7.63
21117-167
1.303
21117-199
1.304
21120-178
4.66
21130-008
1.41
21101-937
7.92
21117-168
1.291
21117-200
1.304
21120-189
1.254
21130-008
1.99
21101-954
4.10
21117-168
1.303
21120-127
3.18
21120-189
1.267
21130-009
1.29
21101-954
4.12
21117-169
1.291
21120-128
3.18
21120-189
1.286
21130-009
1.41
21101-954
4.6
21117-169
1.303
21120-129
3.18
21120-189
1.299
21130-010
1.103
21101-954
4.7
21117-170
1.291
21120-130
3.18
21120-189
1.313
21130-010
1.159
12.24
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
21130-010
1.29
21130-036
1.71
21130-067
1.99
21130-092
1.163
21130-128
1.30
21130-010
1.41
21130-038
1.71
21130-068
1.29
21130-093
1.163
21130-129
1.160
21130-010
1.99
21130-041
1.159
21130-068
1.103
21130-093
1.29
21130-129
1.30
21130-011
1.103
21130-042
1.159
21130-068
1.163
21130-094
1.163
21130-130
1.160
21130-011
1.159
21130-043
1.159
21130-068
1.41
21130-095
1.29
21130-130
1.30
21130-011
1.29
21130-043
1.29
21130-068
1.99
21130-097
1.163
21130-131
1.160
21130-011
1.41
21130-044
1.159
21130-069
1.103
21130-097
1.29
21130-131
1.30
21130-011
1.99
21130-044
1.29
21130-069
1.163
21130-098
1.163
21130-132
1.160
21130-012
1.159
21130-045
1.29
21130-069
1.29
21130-098
1.29
21130-132
1.30
21130-013
1.159
21130-046
1.29
21130-069
1.41
21130-099
1.163
21130-136
1.161
21130-014
1.29
21130-047
1.159
21130-069
1.99
21130-099
1.29
21130-137
1.161
21130-014
1.41
21130-047
1.29
21130-070
1.103
21130-100
1.163
21130-138
1.161
21130-015
1.103
21130-048
1.159
21130-070
1.163
21130-100
1.29
21130-138
1.31
21130-015
1.159
21130-048
1.29
21130-070
1.29
21130-101
1.163
21130-139
1.161
21130-015
1.29
21130-049
1.29
21130-070
1.41
21130-101
1.29
21130-140
1.31
21130-015
1.41
21130-050
1.159
21130-070
1.99
21130-102
1.163
21130-142
1.161
21130-015
1.99
21130-050
1.29
21130-071
1.103
21130-102
1.29
21130-142
1.31
21130-016
1.103
21130-051
1.159
21130-071
1.163
21130-106
1.161
21130-143
1.161
21130-016
1.159
21130-051
1.29
21130-071
1.29
21130-107
1.161
21130-143
1.31
21130-016
1.29
21130-052
1.159
21130-071
1.41
21130-108
1.161
21130-144
1.161
21130-016
1.41
21130-053
1.159
21130-071
1.99
21130-108
1.31
21130-144
1.31
21130-016
1.99
21130-054
1.29
21130-072
1.103
21130-109
1.161
21130-145
1.161
21130-017
1.159
21130-055
1.159
21130-072
1.163
21130-110
1.31
21130-145
1.31
21130-018
1.159
21130-055
1.29
21130-072
1.29
21130-112
1.161
21130-146
1.161
21130-023
1.107
21130-056
1.159
21130-072
1.41
21130-112
1.31
21130-146
1.31
21130-023
1.71
21130-056
1.29
21130-072
1.99
21130-113
1.161
21130-147
1.161
21130-024
1.107
21130-057
1.159
21130-078
1.107
21130-113
1.31
21130-147
1.31
21130-024
1.71
21130-058
1.159
21130-078
1.71
21130-114
1.161
21130-151
1.161
21130-025
1.107
21130-061
1.163
21130-080
1.107
21130-114
1.31
21130-152
1.161
21130-025
1.71
21130-062
1.163
21130-080
1.71
21130-115
1.161
21130-153
1.103
21130-026
1.107
21130-063
1.103
21130-081
1.107
21130-115
1.31
21130-153
1.161
21130-026
1.71
21130-063
1.163
21130-082
1.107
21130-116
1.161
21130-153
1.31
21130-027
1.107
21130-063
1.29
21130-082
1.71
21130-116
1.31
21130-153
1.41
21130-027
1.71
21130-063
1.41
21130-083
1.107
21130-117
1.161
21130-153
1.99
21130-028
1.107
21130-063
1.99
21130-083
1.71
21130-117
1.31
21130-154
1.161
21130-028
1.71
21130-064
1.163
21130-084
1.107
21130-121
1.160
21130-155
1.103
21130-030
1.107
21130-065
1.103
21130-084
1.71
21130-122
1.160
21130-155
1.31
21130-030
1.71
21130-065
1.29
21130-085
1.107
21130-123
1.160
21130-155
1.41
21130-031
1.107
21130-065
1.41
21130-085
1.71
21130-123
1.30
21130-155
1.99
21130-031
1.71
21130-065
1.99
21130-086
1.107
21130-124
1.160
21130-157
1.103
21130-033
1.71
21130-067
1.103
21130-086
1.71
21130-125
1.30
21130-157
1.161
21130-035
1.107
21130-067
1.163
21130-087
1.107
21130-127
1.160
21130-157
1.31
21130-035
1.71
21130-067
1.29
21130-087
1.71
21130-127
1.30
21130-157
1.41
21130-036
1.107
21130-067
1.41
21130-091
1.163
21130-128
1.160
21130-157
1.99
Page
Part no.
Part number in normal type: ready for despatch within 10 working days
Page
12.25
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21130-158
1.103
21130-183
1.160
21130-214
1.162
21130-246
1.186
21130-265
1.186
21130-158
1.161
21130-183
1.30
21130-215
1.32
21130-246
1.33
21130-266
1.164
21130-158
1.31
21130-183
1.41
21130-217
1.162
21130-246
1.41
21130-266
1.186
21130-158
1.41
21130-185
1.30
21130-217
1.32
21130-246
1.99
21130-266
1.33
21130-158
1.99
21130-185
1.41
21130-218
1.162
21130-247
1.103
21130-267
1.164
21130-159
1.103
21130-187
1.160
21130-218
1.32
21130-247
1.164
21130-267
1.186
21130-159
1.161
21130-187
1.30
21130-219
1.162
21130-247
1.186
21130-267
1.33
21130-159
1.31
21130-187
1.41
21130-219
1.32
21130-247
1.33
21130-268
1.164
21130-159
1.41
21130-188
1.160
21130-220
1.162
21130-247
1.41
21130-268
1.186
21130-159
1.99
21130-188
1.30
21130-220
1.32
21130-247
1.99
21130-269
1.164
21130-160
1.103
21130-188
1.41
21130-221
1.162
21130-248
1.164
21130-269
1.186
21130-160
1.161
21130-189
1.160
21130-221
1.32
21130-248
1.186
21130-272
1.107
21130-160
1.31
21130-189
1.30
21130-222
1.162
21130-249
1.164
21130-272
1.72
21130-160
1.41
21130-189
1.41
21130-222
1.32
21130-249
1.186
21130-273
1.107
21130-160
1.99
21130-190
1.160
21130-231
1.160
21130-252
1.165
21130-273
1.72
21130-161
1.103
21130-190
1.30
21130-232
1.160
21130-252
1.187
21130-275
1.72
21130-161
1.161
21130-190
1.41
21130-232
1.30
21130-252
1.34
21130-276
1.107
21130-161
1.31
21130-191
1.160
21130-233
1.30
21130-253
1.165
21130-276
1.72
21130-161
1.41
21130-191
1.30
21130-234
1.160
21130-253
1.187
21130-277
1.107
21130-161
1.99
21130-191
1.41
21130-234
1.30
21130-253
1.34
21130-277
1.72
21130-162
1.103
21130-192
1.160
21130-235
1.160
21130-254
1.165
21130-281
1.104
21130-162
1.161
21130-192
1.30
21130-235
1.30
21130-254
1.187
21130-281
1.108
21130-162
1.31
21130-192
1.41
21130-236
1.160
21130-255
1.165
21130-281
1.42
21130-162
1.41
21130-198
1.107
21130-236
1.30
21130-255
1.187
21130-281
1.73
21130-162
1.99
21130-198
1.71
21130-241
1.33
21130-256
1.165
21130-282
1.104
21130-168
1.107
21130-200
1.107
21130-241
1.41
21130-256
1.187
21130-282
1.108
21130-168
1.71
21130-200
1.71
21130-242
1.103
21130-256
1.34
21130-282
1.42
21130-170
1.107
21130-201
1.107
21130-242
1.164
21130-257
1.165
21130-282
1.73
21130-170
1.71
21130-202
1.107
21130-242
1.186
21130-257
1.187
21130-283
1.104
21130-171
1.107
21130-202
1.71
21130-242
1.33
21130-257
1.34
21130-283
1.108
21130-172
1.107
21130-203
1.107
21130-242
1.41
21130-258
1.165
21130-283
1.42
21130-172
1.71
21130-203
1.71
21130-242
1.99
21130-258
1.187
21130-283
1.73
21130-173
1.107
21130-204
1.107
21130-243
1.103
21130-259
1.165
21130-284
1.104
21130-173
1.71
21130-204
1.71
21130-243
1.164
21130-259
1.187
21130-284
1.108
21130-174
1.107
21130-205
1.107
21130-243
1.186
21130-261
1.33
21130-284
1.42
21130-174
1.71
21130-205
1.71
21130-243
1.33
21130-262
1.164
21130-284
1.73
21130-175
1.107
21130-206
1.107
21130-243
1.41
21130-262
1.186
21130-285
1.42
21130-175
1.71
21130-206
1.71
21130-243
1.99
21130-262
1.33
21130-287
1.73
21130-176
1.107
21130-207
1.107
21130-244
1.164
21130-263
1.164
21130-291
1.108
21130-176
1.71
21130-207
1.71
21130-244
1.186
21130-263
1.186
21130-291
1.73
21130-177
1.107
21130-211
1.162
21130-245
1.164
21130-263
1.33
21130-292
1.108
21130-177
1.71
21130-212
1.162
21130-245
1.186
21130-264
1.164
21130-292
1.73
21130-181
1.160
21130-213
1.162
21130-246
1.103
21130-264
1.186
21130-293
1.108
21130-182
1.160
21130-213
1.32
21130-246
1.164
21130-265
1.164
21130-293
1.73
12.26
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21130-294
1.108
21130-327
1.78
21130-345
1.91
21130-354
1.50
21130-401
1.166
21130-294
1.73
21130-332
1.112
21130-352
1.113
21130-354
1.65
21130-401
1.188
21130-296
1.73
21130-332
1.171
21130-352
1.115
21130-354
1.79
21130-401
1.35
21130-302
1.114
21130-332
1.47
21130-352
1.145
21130-354
1.81
21130-402
1.166
21130-302
1.173
21130-332
1.78
21130-352
1.172
21130-354
1.92
21130-402
1.188
21130-302
1.49
21130-333
1.112
21130-352
1.174
21130-355
1.113
21130-402
1.35
21130-302
1.80
21130-333
1.171
21130-352
1.23
21130-355
1.115
21130-403
1.166
21130-303
1.114
21130-333
1.47
21130-352
1.254
21130-355
1.145
21130-403
1.188
21130-303
1.143
21130-333
1.78
21130-352
1.267
21130-355
1.172
21130-403
1.35
21130-303
1.173
21130-334
1.112
21130-352
1.286
21130-355
1.23
21130-404
1.166
21130-303
1.21
21130-334
1.171
21130-352
1.299
21130-355
1.254
21130-404
1.188
21130-303
1.49
21130-334
1.47
21130-352
1.313
21130-355
1.267
21130-405
1.166
21130-303
1.80
21130-334
1.78
21130-352
1.48
21130-355
1.286
21130-405
1.188
21130-303
1.90
21130-335
1.112
21130-352
1.50
21130-355
1.299
21130-406
1.166
21130-304
1.114
21130-335
1.171
21130-352
1.79
21130-355
1.313
21130-406
1.188
21130-304
1.49
21130-335
1.47
21130-352
1.81
21130-355
1.48
21130-407
1.166
21130-304
1.80
21130-335
1.78
21130-352
1.92
21130-355
1.50
21130-407
1.188
21130-305
1.114
21130-336
1.171
21130-353
1.113
21130-355
1.65
21130-412
1.110
21130-305
1.21
21130-337
1.171
21130-353
1.115
21130-355
1.79
21130-412
1.18
21130-305
1.49
21130-342
1.114
21130-353
1.145
21130-355
1.81
21130-412
1.46
21130-305
1.63
21130-342
1.144
21130-353
1.172
21130-355
1.92
21130-412
1.60
21130-305
1.80
21130-342
1.173
21130-353
1.174
21130-357
1.254
21130-412
1.77
21130-305
1.90
21130-342
1.22
21130-353
1.23
21130-357
1.267
21130-413
1.110
21130-309
1.143
21130-342
1.49
21130-353
1.254
21130-358
1.254
21130-413
1.170
21130-309
1.173
21130-342
1.80
21130-353
1.267
21130-358
1.267
21130-413
1.18
21130-309
1.80
21130-342
1.91
21130-353
1.286
21130-372
1.113
21130-413
1.192
21130-322
1.112
21130-343
1.114
21130-353
1.299
21130-372
1.172
21130-413
1.46
21130-322
1.171
21130-343
1.144
21130-353
1.313
21130-372
1.48
21130-413
1.60
21130-322
1.47
21130-343
1.173
21130-353
1.48
21130-372
1.79
21130-413
1.77
21130-322
1.78
21130-343
1.22
21130-353
1.50
21130-373
1.113
21130-414
1.110
21130-323
1.112
21130-343
1.49
21130-353
1.79
21130-373
1.172
21130-414
1.170
21130-323
1.171
21130-343
1.80
21130-353
1.81
21130-373
1.48
21130-414
1.18
21130-323
1.47
21130-343
1.91
21130-353
1.92
21130-373
1.79
21130-414
1.192
21130-323
1.78
21130-344
1.114
21130-354
1.113
21130-374
1.113
21130-414
1.46
21130-324
1.112
21130-344
1.22
21130-354
1.115
21130-374
1.172
21130-414
1.60
21130-324
1.171
21130-344
1.49
21130-354
1.145
21130-374
1.48
21130-414
1.77
21130-324
1.47
21130-344
1.64
21130-354
1.172
21130-374
1.79
21130-415
1.110
21130-324
1.78
21130-344
1.80
21130-354
1.23
21130-375
1.113
21130-415
1.18
21130-325
1.112
21130-344
1.91
21130-354
1.254
21130-375
1.172
21130-415
1.46
21130-325
1.171
21130-345
1.114
21130-354
1.267
21130-375
1.48
21130-415
1.60
21130-325
1.47
21130-345
1.22
21130-354
1.286
21130-375
1.79
21130-415
1.77
21130-325
1.78
21130-345
1.49
21130-354
1.299
21130-400
1.166
21130-416
1.110
21130-326
1.171
21130-345
1.64
21130-354
1.313
21130-400
1.188
21130-416
1.170
21130-327
1.171
21130-345
1.80
21130-354
1.48
21130-400
1.35
21130-416
1.18
12.27
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
21130-416
1.192
21130-428
1.192
21130-445
1.110
21130-479
21130-416
1.46
21130-428
1.46
21130-445
1.170
21130-484
21130-416
1.60
21130-428
1.77
21130-445
1.192
21130-485
21130-416
1.77
21130-432
1.110
21130-445
1.46
21130-417
1.110
21130-432
1.170
21130-445
21130-417
1.170
21130-432
1.192
21130-417
1.18
21130-432
21130-417
1.192
21130-417
Part no.
Page
1.37
21130-543
1.187
1.162
21130-544
1.165
1.162
21130-544
1.187
21130-486
1.162
21130-545
1.165
1.77
21130-486
1.32
21130-545
1.187
21130-446
1.110
21130-487
1.162
21130-546
1.164
1.46
21130-446
1.170
21130-488
1.32
21130-546
1.186
21130-432
1.77
21130-446
1.192
21130-490
1.162
21130-547
1.164
1.46
21130-433
1.110
21130-446
1.46
21130-490
1.32
21130-547
1.186
21130-417
1.60
21130-433
1.170
21130-446
1.77
21130-491
1.162
21130-548
1.164
21130-417
1.77
21130-433
1.192
21130-447
1.110
21130-491
1.32
21130-548
1.186
21130-418
1.110
21130-433
1.46
21130-447
1.170
21130-492
1.162
21130-549
1.164
21130-418
1.170
21130-433
1.77
21130-447
1.192
21130-492
1.32
21130-549
1.186
21130-418
1.192
21130-434
1.110
21130-447
1.46
21130-493
1.162
21130-550
1.171
21130-418
1.46
21130-434
1.46
21130-447
1.77
21130-493
1.32
21130-551
1.171
21130-418
1.77
21130-434
1.77
21130-452
1.162
21130-494
1.162
21130-552
1.171
21130-422
1.110
21130-435
1.110
21130-453
1.162
21130-494
1.32
21130-553
1.171
21130-422
1.46
21130-435
1.170
21130-454
1.162
21130-495
1.162
21130-554
1.161
21130-422
1.77
21130-435
1.192
21130-454
1.32
21130-495
1.32
21130-555
1.161
21130-423
1.110
21130-435
1.46
21130-455
1.162
21130-504
1.105
21130-556
1.161
21130-423
1.170
21130-435
1.77
21130-456
1.32
21130-504
1.43
21130-557
1.161
21130-423
1.192
21130-436
1.110
21130-458
1.162
21130-505
1.105
21130-557
1.183
21130-423
1.46
21130-436
1.170
21130-458
1.32
21130-505
1.43
21130-560
1.161
21130-423
1.77
21130-436
1.192
21130-459
1.162
21130-516
1.159
21130-561
1.161
21130-424
1.110
21130-436
1.46
21130-459
1.32
21130-517
1.159
21130-562
1.161
21130-424
1.170
21130-436
1.77
21130-460
1.162
21130-524
1.159
21130-563
1.161
21130-424
1.192
21130-437
1.110
21130-460
1.32
21130-525
1.159
21130-564
1.161
21130-424
1.46
21130-437
1.170
21130-461
1.162
21130-532
1.159
21130-565
1.161
21130-424
1.77
21130-437
1.192
21130-461
1.32
21130-533
1.159
21130-566
1.161
21130-425
1.110
21130-437
1.46
21130-462
1.162
21130-534
1.159
21130-567
1.161
21130-425
1.46
21130-437
1.77
21130-462
1.32
21130-535
1.159
21130-568
1.161
21130-425
1.77
21130-442
1.110
21130-463
1.162
21130-536
1.159
21130-568
1.31
21130-426
1.110
21130-442
1.170
21130-463
1.32
21130-537
1.159
21130-569
1.161
21130-426
1.170
21130-442
1.192
21130-472
1.101
21130-538
1.164
21130-570
1.31
21130-426
1.192
21130-442
1.46
21130-472
1.163
21130-538
1.186
21130-572
1.161
21130-426
1.46
21130-442
1.77
21130-472
1.37
21130-539
1.164
21130-572
1.31
21130-426
1.77
21130-443
1.110
21130-473
1.101
21130-539
1.186
21130-573
1.161
21130-427
1.110
21130-443
1.170
21130-473
1.163
21130-540
1.164
21130-573
1.31
21130-427
1.170
21130-443
1.192
21130-473
1.37
21130-540
1.186
21130-574
1.161
21130-427
1.192
21130-443
1.46
21130-478
1.101
21130-541
1.164
21130-574
1.31
21130-427
1.46
21130-443
1.77
21130-478
1.163
21130-541
1.186
21130-575
1.161
21130-427
1.77
21130-444
1.110
21130-478
1.37
21130-542
1.165
21130-575
1.31
21130-428
1.110
21130-444
1.46
21130-479
1.101
21130-542
1.187
21130-576
1.161
21130-428
1.170
21130-444
1.77
21130-479
1.163
21130-543
1.165
21130-576
1.31
12.28
Page
ELECTRONICS PROTECTION
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21130-577
1.161
21130-615
1.215
21130-637
1.221
21236-097
2.32
21500-082
6.77
21130-577
1.31
21130-616
1.205
21130-638
1.210
21236-099
2.27
21500-122
6.82
21130-578
1.109
21130-616
1.215
21130-638
1.221
21236-102
2.31
21500-123
6.82
21130-578
1.74
21130-617
1.205
21130-639
1.210
21236-103
2.28
21500-124
6.82
21130-579
1.109
21130-617
1.215
21130-639
1.221
21236-104
2.28
21591-079
8.17
21130-579
1.74
21130-618
1.210
21130-640
1.210
21236-120
2.30
21591-097
8.17
21130-580
1.109
21130-618
1.220
21130-640
1.222
21236-121
2.30
21591-099
8.17
21130-580
1.74
21130-619
1.210
21130-641
1.210
21236-122
2.30
21591-104
8.17
21130-581
1.109
21130-619
1.220
21130-641
1.222
21236-123
2.28
21591-107
8.17
21130-581
1.74
21130-620
1.210
21130-642
1.210
21236-125
2.28
21594-144
8.23
21130-583
1.204 1.214
21130-620
1.221
21130-642
1.222
21236-126
2.33
21594-144
8.9
21130-585
1.206
21130-621
1.210
21130-643
1.210
21236-127
2.27
21596-002
8.7
21130-585
1.216
21130-621
1.221
21130-643
1.222
21249-017
1.322
21596-003
8.20
21130-588
1.208
21130-622
1.210
21149-184
1.323
21249-017
1.323
21596-003
8.7
21130-588
1.218
21130-622
1.220
21149-184
1.326
21249-017
1.324
21596-008
8.17
21130-589
1.208
21130-623
1.210
21149-185
1.323
21249-017
1.325
21596-012
8.18
21130-589
1.218
21130-623
1.221
21149-185
1.326
21493-079
3.15
21596-020
8.21
21130-590
1.205
21130-624
1.210
21190-095
1.360
21500-027
6.78
21596-020
8.8
21130-590
1.215
21130-624
1.220
21190-095
2.29
21500-028
6.79
21596-020
8.9
21130-591
1.205
21130-625
1.210
21190-095
3.17
21500-029
6.78
21596-022
8.23
21130-591
1.215
21130-625
1.220
21190-435
2.26
21500-030
6.79
21596-022
8.7
21130-594
1.208
21130-626
1.210
21190-435
2.32
21500-037
6.75
21596-023
8.25
21130-594
1.218
21130-626
1.220
21190-435
2.7
21500-037
6.82
21596-023
8.7
21130-596
1.209
21130-627
1.210
21190-435
3.17
21500-038
6.82
21596-023
8.8
21130-596
1.219
21130-627
1.220
21190-571
1.357
21500-039
6.64
21596-023
8.9
21130-597
1.209
21130-628
1.210
21190-753
3.33
21500-039
6.75
21596-025
8.24
21130-597
1.219
21130-628
1.220
21190-793
1.348
21500-039
6.76
21596-025
8.9
21130-598
1.209
21130-629
1.210
21190-793
1.349
21500-039
6.78
21596-026
8.24
21130-598
1.219
21130-629
1.221
21191-207
8.20
21500-039
6.79
21596-026
8.8
21130-610
1.207
21130-630
1.210
21191-207
8.21
21500-039
6.81
21596-026
8.9
21130-610
1.217
21130-630
1.221
21191-207
8.6
21500-046
6.80
21596-077
8.5
21130-611
1.214
21130-631
1.210
21191-207
8.7
21500-047
6.80
21596-077
8.6
21130-611
1.215
21130-631
1.220
21191-207
8.8
21500-048
6.82
21596-138
8.8
21130-611
1.216
21130-632
1.210
21191-207
8.9
21500-067
6.78
21596-140
8.24
21130-611
1.217
21130-632
1.220
21236-089
2.26
21500-068
6.79
21596-140
8.8
21130-612
1.214
21130-633
1.210
21236-089
2.32
21500-069
6.80
21596-140
8.9
21130-612
1.216
21130-633
1.220
21236-090
2.31
21500-070
6.78
21596-236
8.22
21130-612
1.217
21130-634
1.210
21236-092
2.27
21500-071
6.79
21596-236
8.7
21130-613
1.214
21130-634
1.220
21236-093
1.153
21500-072
6.80
21596-273
8.7
21130-613
1.216
21130-635
1.210
21236-093
1.176
21500-077
6.75
21596-274
8.7
21130-613
1.217
21130-635
1.221
21236-093
1.198
21500-078
6.75
21596-278
8.8
21130-614
1.205
21130-636
1.210
21236-094
2.26
21500-079
6.76
21596-300
8.10
21130-614
1.215
21130-636
1.221
21236-095
2.33
21500-080
6.76
21596-300
8.18
21130-615
1.205
21130-637
1.210
21236-097
2.26
21500-081
6.77
21596-300
8.5
12.29
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
21596-300
8.6
21850-069
8.62
22114-455
1.282
22117-227
1.291
22117-593
1.303
21596-300
8.7
21850-070
8.62
22114-457
1.282
22117-227
1.303
22117-671
1.299
21596-300
8.8
21850-071
8.62
22114-458
1.282
22117-228
1.291
22117-671
1.312
21596-300
8.9
21850-081
8.46
22114-460
1.282
22117-228
1.303
22117-772
1.290
21596-301
8.10
21850-095
8.53
22114-461
1.282
22117-229
1.291
22117-773
1.290
21596-301
8.18
21850-102
8.64
22114-461
1.359
22117-229
1.303
22117-774
1.290
21596-301
8.6
21850-103
8.64
22114-462
1.282
22117-230
1.291
22117-775
1.290
21596-301
8.7
21850-104
8.64
22117-173
1.291
22117-230
1.303
22117-776
1.290
21596-301
8.8
21850-105
8.64
22117-173
1.303
22117-236
1.303
22117-777
1.290
21596-301
8.9
21850-106
8.64
22117-174
1.291
22117-237
1.303
22117-778
1.290
21596-324
8.14
21850-107
8.64
22117-174
1.303
22117-238
1.303
22117-779
1.290
21596-325
8.14
21850-108
8.65
22117-175
1.291
22117-239
1.291
22117-780
1.290
21596-327
8.8
21850-109
8.65
22117-175
1.303
22117-239
1.303
22117-781
1.290
21596-327
8.9
21850-112
8.53
22117-176
1.291
22117-352
1.297
22117-782
1.302
21596-370
8.4
21850-113
8.54
22117-176
1.303
22117-352
1.309
22117-783
1.302
21596-370
8.5
21850-114
8.54
22117-177
1.291
22117-353
1.297
22117-784
1.302
21596-376
8.13
21850-115
8.55
22117-177
1.303
22117-353
1.309
22117-785
1.302
21596-376
8.15
21850-116
8.55
22117-178
1.291
22117-354
1.297
22117-786
1.302
21596-515
8.23
21850-117
8.55
22117-178
1.303
22117-354
1.309
22117-787
1.302
21596-515
8.4
21850-118
8.55
22117-179
1.291
22117-355
1.297
22117-788
1.302
21596-515
8.5
21850-119
8.55
22117-179
1.303
22117-355
1.309
22117-789
1.302
21596-571
8.38
21850-120
8.55
22117-180
1.291
22117-356
1.297
22117-790
1.302
21596-571
8.39
21990-057
8.21
22117-180
1.303
22117-356
1.309
22117-791
1.302
21596-571
8.43
21990-057
8.6
22117-181
1.291
22117-357
1.297
22117-792
1.302
21596-571
8.44
21990-058
8.20
22117-181
1.303
22117-357
1.309
22117-793
1.302
21596-571
8.45
21990-058
8.6
22117-182
1.291
22117-358
1.297
22117-794
1.302
21596-571
8.50
21990-059
8.23
22117-182
1.303
22117-358
1.309
22117-796
1.302
21596-572
8.38
21990-059
8.6
22117-185
1.291
22117-376
1.287
22117-797
1.302
21596-572
8.39
21990-184
8.22
22117-185
1.303
22117-376
1.297
22117-798
1.279
21596-572
8.43
21990-184
8.8
22117-186
1.291
22117-377
1.287
22117-798
1.293
21596-572
8.44
21990-224
8.10
22117-186
1.303
22117-377
1.297
22117-799
1.305
21596-572
8.45
21990-224
8.21
22117-189
1.292
22117-378
1.297
22117-801
1.294
21596-572
8.50
21990-225
8.10
22117-189
1.304
22117-389
1.309
22117-801
1.306
21850-033
8.55
21990-225
8.21
22117-190
1.292
22117-389
1.312
22117-802
1.294
21850-034
8.55
21990-226
8.10
22117-190
1.304
22117-389
1.314
22117-802
1.306
21850-036
8.54
21990-226
8.25
22117-191
1.292
22117-390
1.309
22117-803
1.294
21850-037
8.55
21990-227
8.10
22117-191
1.304
22117-390
1.312
22117-803
1.306
21850-038
8.53
21990-227
8.22
22117-192
1.292
22117-390
1.314
22117-804
1.306
21850-045
8.46
21990-228
8.10
22117-192
1.304
22117-391
1.309
22117-806
1.294
21850-046
8.41
21990-228
8.23
22117-198
1.304
22117-391
1.312
22117-806
1.306
21850-057
8.62
21990-229
8.10
22117-199
1.304
22117-391
1.314
22117-807
1.294
21850-066
8.62
21990-229
8.23
22117-200
1.304
22117-592
1.291
22117-807
1.306
21850-067
8.62
22114-340
1.315
22117-201
1.292
22117-592
1.303
22117-808
1.294
21850-068
8.62
22114-342
1.315
22117-201
1.304
22117-593
1.291
22117-808
1.306
12.30
www.schroff.biz E 05/2016
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
22117-809
1.306
22117-835
1.309
22117-866
1.296
22117-949
1.304
22117-979
1.290
22117-811
1.295
22117-836
1.297
22117-866
1.308
22117-950
1.304
22117-980
1.290
22117-811
1.307
22117-836
1.309
22117-867
1.308
22117-951
1.279
22117-981
1.290
22117-812
1.295
22117-837
1.297
22117-868
1.308
22117-951
1.292
22117-982
1.290
22117-812
1.307
22117-837
1.309
22117-869
1.281
22117-951
1.304
22117-983
1.290
22117-813
1.295
22117-838
1.297
22117-869
1.296
22117-952
1.304
22117-984
1.290
22117-813
1.307
22117-838
1.309
22117-869
1.308
22117-957
1.304
22117-985
1.302
22117-814
1.307
22117-839
1.309
22117-934
1.278
22117-958
1.291
22117-986
1.302
22117-821
1.294
22117-839
1.312
22117-935
1.278
22117-958
1.303
22117-987
1.302
22117-821
1.295
22117-840
1.309
22117-935
1.292
22117-959
1.291
22117-988
1.302
22117-821
1.306
22117-840
1.312
22117-935
1.304
22117-959
1.303
22117-989
1.302
22117-821
1.307
22117-842
1.285
22117-936
1.278
22117-960
1.291
22117-990
1.302
22117-822
1.294
22117-842
1.299
22117-936
1.292
22117-960
1.303
22117-991
1.302
22117-822
1.295
22117-842
1.312
22117-936
1.304
22117-961
1.291
22117-992
1.302
22117-822
1.306
22117-843
1.285
22117-937
1.278
22117-961
1.303
22117-993
1.291
22117-822
1.307
22117-843
1.299
22117-937
1.292
22117-962
1.291
22117-993
1.303
22117-823
1.294
22117-843
1.312
22117-937
1.304
22117-962
1.303
22117-994
1.291
22117-823
1.295
22117-844
1.299
22117-938
1.278
22117-963
1.291
22117-994
1.303
22117-823
1.306
22117-844
1.312
22117-938
1.292
22117-963
1.303
22117-995
1.291
22117-823
1.307
22117-845
1.299
22117-938
1.304
22117-964
1.291
22117-995
1.303
22117-824
1.306
22117-845
1.312
22117-939
1.304
22117-964
1.303
22117-996
1.291
22117-824
1.307
22117-846
1.314
22117-940
1.278
22117-965
1.291
22117-996
1.303
22117-825
1.306
22117-847
1.314
22117-940
1.292
22117-965
1.303
22117-997
1.291
22117-825
1.307
22117-848
1.314
22117-940
1.304
22117-966
1.291
22117-997
1.303
22117-826
1.280
22117-849
1.314
22117-941
1.304
22117-966
1.303
22117-998
1.291
22117-826
1.296
22117-850
1.314
22117-942
1.278
22117-967
1.291
22117-998
1.303
22117-826
1.308
22117-851
1.314
22117-942
1.292
22117-967
1.303
22117-999
1.291
22117-827
1.280
22117-852
1.314
22117-942
1.304
22117-968
1.291
22117-999
1.303
22117-827
1.296
22117-853
1.314
22117-943
1.279
22117-968
1.303
22127-094
1.298
22117-827
1.308
22117-854
1.314
22117-944
1.279
22117-969
1.291
22127-094
1.311
22117-828
1.296
22117-855
1.315
22117-944
1.292
22117-969
1.303
22127-095
1.298
22117-828
1.308
22117-856
1.315
22117-944
1.304
22117-970
1.291
22127-095
1.311
22117-829
1.308
22117-858
1.315
22117-945
1.279
22117-970
1.303
22127-096
1.298
22117-830
1.280
22117-859
1.315
22117-945
1.292
22117-971
1.291
22127-096
1.311
22117-830
1.296
22117-860
1.315
22117-945
1.304
22117-971
1.303
22130-001
1.181
22117-830
1.308
22117-861
1.315
22117-946
1.279
22117-972
1.291
22130-002
1.181
22117-831
1.280
22117-862
1.315
22117-946
1.292
22117-972
1.303
22130-003
1.103
22117-831
1.296
22117-863
1.315
22117-946
1.304
22117-973
1.292
22130-003
1.181
22117-831
1.308
22117-864
1.281
22117-947
1.279
22117-973
1.304
22130-003
1.29
22117-832
1.296
22117-864
1.296
22117-947
1.292
22117-975
1.292
22130-003
1.41
22117-832
1.308
22117-864
1.308
22117-947
1.304
22117-975
1.304
22130-003
1.99
22117-833
1.308
22117-865
1.281
22117-948
1.304
22117-976
1.304
22130-004
1.103
22117-834
1.308
22117-865
1.296
22117-949
1.279
22117-977
1.290
22130-004
1.181
22117-835
1.297
22117-865
1.308
22117-949
1.292
22117-978
1.290
22130-004
1.29
SCHROFF.PENTAIR.CO.UK
12.31
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
22130-004
1.41
22130-016
1.41
22130-053
1.181
22130-071
1.99
22130-108
1.31
22130-004
1.99
22130-016
1.99
22130-054
1.29
22130-072
1.103
22130-109
1.183
22130-005
1.103
22130-017
1.181
22130-055
1.181
22130-072
1.185
22130-110
1.31
22130-005
1.29
22130-018
1.181
22130-055
1.29
22130-072
1.29
22130-112
1.183
22130-005
1.41
22130-023
1.107
22130-056
1.181
22130-072
1.41
22130-112
1.31
22130-005
1.99
22130-023
1.71
22130-056
1.29
22130-072
1.99
22130-113
1.183
22130-006
1.103
22130-024
1.107
22130-057
1.181
22130-078
1.107
22130-113
1.31
22130-006
1.29
22130-024
1.71
22130-058
1.181
22130-078
1.71
22130-114
1.183
22130-006
1.41
22130-025
1.107
22130-061
1.185
22130-080
1.107
22130-114
1.31
22130-006
1.99
22130-025
1.71
22130-062
1.185
22130-080
1.71
22130-115
1.183
22130-007
1.103
22130-026
1.107
22130-063
1.103
22130-081
1.107
22130-115
1.31
22130-007
1.181
22130-026
1.71
22130-063
1.185
22130-082
1.107
22130-116
1.183
22130-007
1.29
22130-027
1.107
22130-063
1.29
22130-082
1.71
22130-116
1.31
22130-007
1.41
22130-027
1.71
22130-063
1.41
22130-083
1.107
22130-117
1.183
22130-007
1.99
22130-028
1.107
22130-063
1.99
22130-083
1.71
22130-117
1.31
22130-008
1.103
22130-028
1.71
22130-064
1.185
22130-084
1.107
22130-121
1.182
22130-008
1.181
22130-030
1.107
22130-065
1.103
22130-084
1.71
22130-122
1.182
22130-008
1.29
22130-030
1.71
22130-065
1.29
22130-085
1.107
22130-123
1.182
22130-008
1.41
22130-031
1.107
22130-065
1.41
22130-085
1.71
22130-123
1.30
22130-008
1.99
22130-031
1.71
22130-065
1.99
22130-086
1.107
22130-124
1.182
22130-009
1.29
22130-033
1.71
22130-067
1.103
22130-086
1.71
22130-125
1.30
22130-009
1.41
22130-035
1.107
22130-067
1.185
22130-087
1.107
22130-127
1.182
22130-010
1.103
22130-035
1.71
22130-067
1.29
22130-087
1.71
22130-127
1.30
22130-010
1.181
22130-036
1.107
22130-067
1.41
22130-091
1.185
22130-128
1.182
22130-010
1.29
22130-036
1.71
22130-067
1.99
22130-092
1.185
22130-128
1.30
22130-010
1.41
22130-038
1.71
22130-068
1.103
22130-093
1.185
22130-129
1.182
22130-010
1.99
22130-041
1.181
22130-068
1.29
22130-093
1.29
22130-129
1.30
22130-011
1.103
22130-042
1.181
22130-068
1.185
22130-094
1.185
22130-130
1.182
22130-011
1.181
22130-043
1.181
22130-068
1.41
22130-095
1.29
22130-130
1.30
22130-011
1.29
22130-043
1.29
22130-068
1.99
22130-097
1.185
22130-131
1.182
22130-011
1.41
22130-044
1.181
22130-069
1.103
22130-097
1.29
22130-131
1.30
22130-011
1.99
22130-044
1.29
22130-069
1.185
22130-098
1.185
22130-132
1.182
22130-012
1.181
22130-045
1.29
22130-069
1.29
22130-098
1.29
22130-132
1.30
22130-013
1.181
22130-046
1.29
22130-069
1.41
22130-099
1.185
22130-136
1.183
22130-014
1.29
22130-047
1.181
22130-069
1.99
22130-099
1.29
22130-137
1.183
22130-014
1.41
22130-047
1.29
22130-070
1.103
22130-100
1.185
22130-138
1.183
22130-015
1.103
22130-048
1.181
22130-070
1.185
22130-100
1.29
22130-138
1.31
22130-015
1.181
22130-048
1.29
22130-070
1.29
22130-101
1.185
22130-139
1.183
22130-015
1.29
22130-049
1.29
22130-070
1.41
22130-101
1.29
22130-140
1.31
22130-015
1.41
22130-050
1.181
22130-070
1.99
22130-102
1.185
22130-142
1.183
22130-015
1.99
22130-050
1.29
22130-071
1.103
22130-102
1.29
22130-142
1.31
22130-016
1.103
22130-051
1.181
22130-071
1.185
22130-106
1.183
22130-143
1.183
22130-016
1.181
22130-051
1.29
22130-071
1.29
22130-107
1.183
22130-143
1.31
22130-016
1.29
22130-052
1.181
22130-071
1.41
22130-108
1.183
22130-144
1.183
12.32
SCHROFF Main catalogue
Appendix
Part no.
Page
Part no.
Page
Part no.
22130-144
1.31
22130-162
1.103
22130-198
1.107
22130-145
1.183
22130-162
1.183
22130-198
1.71
22130-302
1.80
22130-333
1.193
22130-303
1.114
22130-333
1.47
22130-145
1.31
22130-162
1.31
22130-200
1.71
22130-303
1.143
22130-333
1.78
22130-146
1.183
22130-162
1.41
22130-201
1.107
22130-303
1.195
22130-334
1.112
22130-146
1.31
22130-162
1.99
22130-202
1.71
22130-303
1.21
22130-334
1.193
22130-147
1.183
22130-168
1.107
22130-203
1.71
22130-303
1.49
22130-334
1.47
22130-147
1.31
22130-168
1.71
22130-204
1.71
22130-303
1.80
22130-334
1.78
22130-151
1.183
22130-170
1.71
22130-205
1.107
22130-303
1.90
22130-335
1.112
22130-152
1.183
22130-171
1.107
22130-205
1.71
22130-304
1.114
22130-335
1.193
22130-153
1.103
22130-172
1.71
22130-206
1.107
22130-304
1.49
22130-335
1.47
22130-153
1.183
22130-173
1.71
22130-206
1.71
22130-304
1.80
22130-335
1.78
22130-153
1.31
22130-174
1.71
22130-207
1.107
22130-305
1.114
22130-336
1.193
22130-153
1.41
22130-175
1.107
22130-207
1.71
22130-305
1.21
22130-337
1.193
22130-153
1.99
22130-175
1.71
22130-211
1.184
22130-305
1.49
22130-342
1.114
22130-154
1.183
22130-176
1.107
22130-212
1.184
22130-305
1.63
22130-342
1.144
22130-155
1.103
22130-176
1.71
22130-213
1.184
22130-305
1.80
22130-342
1.195
22130-155
1.31
22130-177
1.107
22130-213
1.32
22130-305
1.90
22130-342
1.22
22130-155
1.41
22130-177
1.71
22130-214
1.184
22130-309
1.143
22130-342
1.49
22130-155
1.99
22130-181
1.182
22130-215
1.32
22130-309
1.195
22130-342
1.80
22130-157
1.103
22130-182
1.182
22130-217
1.184
22130-309
1.80
22130-342
1.91
22130-157
1.183
22130-183
1.182
22130-217
1.32
22130-322
1.112
22130-343
1.114
22130-157
1.31
22130-183
1.30
22130-218
1.184
22130-322
1.193
22130-343
1.144
22130-157
1.41
22130-183
1.41
22130-218
1.32
22130-322
1.47
22130-343
1.195
22130-157
1.99
22130-184
1.182
22130-219
1.184
22130-322
1.78
22130-343
1.22
22130-158
1.103
22130-185
1.30
22130-219
1.32
22130-323
1.112
22130-343
1.49
22130-158
1.183
22130-185
1.41
22130-220
1.184
22130-323
1.193
22130-343
1.80
22130-158
1.31
22130-187
1.182
22130-220
1.32
22130-323
1.47
22130-343
1.91
22130-158
1.41
22130-187
1.30
22130-221
1.184
22130-323
1.78
22130-344
1.114
22130-158
1.99
22130-187
1.41
22130-221
1.32
22130-324
1.112
22130-344
1.22
22130-159
1.103
22130-188
1.182
22130-222
1.184
22130-324
1.193
22130-344
1.49
22130-159
1.183
22130-188
1.30
22130-222
1.32
22130-324
1.47
22130-344
1.64
22130-159
1.31
22130-188
1.41
22130-231
1.182
22130-324
1.78
22130-344
1.80
22130-159
1.41
22130-189
1.182
22130-232
1.182
22130-325
1.112
22130-344
1.91
22130-159
1.99
22130-189
1.30
22130-232
1.30
22130-325
1.193
22130-345
1.114
22130-160
1.103
22130-189
1.41
22130-233
1.30
22130-325
1.47
22130-345
1.22
22130-160
1.183
22130-190
1.182
22130-234
1.182
22130-325
1.78
22130-345
1.49
22130-160
1.31
22130-190
1.30
22130-234
1.30
22130-326
1.193
22130-345
1.64
22130-160
1.41
22130-190
1.41
22130-235
1.182
22130-327
1.193
22130-345
1.80
22130-160
1.99
22130-191
1.182
22130-235
1.30
22130-327
1.78
22130-345
1.91
22130-161
1.103
22130-191
1.30
22130-236
1.182
22130-332
1.112
22130-352
1.113
22130-161
1.183
22130-191
1.41
22130-236
1.30
22130-332
1.193
22130-352
1.115
22130-161
1.31
22130-192
1.182
22130-302
1.114
22130-332
1.47
22130-352
1.145
22130-161
1.41
22130-192
1.30
22130-302
1.195
22130-332
1.78
22130-352
1.194
22130-161
1.99
22130-192
1.41
22130-302
1.49
22130-333
1.112
22130-352
1.196
Page
Part no.
Page
Part no.
Page
12.33
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
22130-352
1.23
22130-373
1.194
22130-486
1.32
22130-568
1.183
23001-018
10.16
22130-352
1.48
22130-373
1.48
22130-487
1.184
22130-568
1.31
23001-020
10.16
22130-352
1.50
22130-373
1.79
22130-488
1.32
22130-569
1.183
23001-021
10.16
22130-352
1.79
22130-374
1.113
22130-490
1.184
22130-570
1.31
23001-032
10.17
22130-352
1.81
22130-374
1.194
22130-490
1.32
22130-572
1.183
23001-033
10.17
22130-352
1.92
22130-374
1.48
22130-491
1.184
22130-572
1.31
23001-034
10.17
22130-353
1.113
22130-374
1.79
22130-491
1.32
22130-573
1.183
23001-040
10.17
22130-353
1.115
22130-375
1.113
22130-492
1.184
22130-573
1.31
23001-046
10.17
22130-353
1.145
22130-375
1.194
22130-492
1.32
22130-574
1.183
23001-051
10.17
22130-353
1.194
22130-375
1.48
22130-493
1.184
22130-574
1.31
23001-063
10.15
22130-353
1.196
22130-375
1.79
22130-493
1.32
22130-575
1.183
23001-064
10.15
22130-353
1.23
22130-452
1.184
22130-494
1.184
22130-575
1.31
23001-065
10.15
22130-353
1.48
22130-453
1.184
22130-494
1.32
22130-576
1.183
23001-066
10.15
22130-353
1.50
22130-454
1.184
22130-495
1.184
22130-576
1.31
23001-067
10.15
22130-353
1.79
22130-454
1.32
22130-495
1.32
22130-577
1.183
23001-068
10.15
22130-353
1.81
22130-455
1.184
22130-504
1.105
22130-577
1.31
23001-069
10.15
22130-353
1.92
22130-456
1.32
22130-504
1.43
22130-578
1.109
23001-070
10.15
22130-354
1.113
22130-458
1.184
22130-505
1.105
22130-578
1.74
23001-072
10.15
22130-354
1.115
22130-458
1.32
22130-505
1.43
22130-579
1.109
23001-075
10.15
22130-354
1.145
22130-459
1.184
22130-516
1.181
22130-579
1.74
23001-080
10.15
22130-354
1.194
22130-459
1.32
22130-517
1.181
22130-580
1.109
23001-081
10.15
22130-354
1.23
22130-460
1.184
22130-524
1.181
22130-580
1.74
23001-502
10.13
22130-354
1.48
22130-460
1.32
22130-525
1.181
22130-581
1.109
23001-503
10.13
22130-354
1.50
22130-461
1.184
22130-532
1.181
22130-581
1.74
23001-504
10.13
22130-354
1.65
22130-461
1.32
22130-533
1.181
22130-583
1.204
23001-505
10.13
22130-354
1.79
22130-462
1.184
22130-534
1.181
22130-583
1.214
23001-506
10.13
22130-354
1.81
22130-462
1.32
22130-535
1.181
22349-024
1.319
23001-507
10.13
22130-354
1.92
22130-463
1.184
22130-536
1.181
22349-025
1.319
23001-508
10.13
22130-355
1.113
22130-463
1.32
22130-537
1.181
22349-026
1.319
23001-510
10.13
22130-355
1.115
22130-472
1.101
22130-550
1.193
22349-027
1.319
23001-511
10.13
22130-355
1.145
22130-472
1.185
22130-551
1.193
22349-032
1.321
23001-512
10.13
22130-355
1.194
22130-472
1.37
22130-552
1.193
22349-033
1.321
23001-515
10.13
22130-355
1.23
22130-473
1.101
22130-553
1.193
22349-034
1.321
23001-516
10.13
22130-355
1.48
22130-473
1.185
22130-554
1.183
23001-001
10.16
23001-520
10.13
22130-355
1.50
22130-473
1.37
22130-555
1.183
23001-002
10.16
23001-521
10.13
22130-355
1.65
22130-478
1.101
22130-556
1.183
23001-003
10.16
23001-532
10.13
22130-355
1.79
22130-478
1.185
22130-560
1.183
23001-004
10.16
23001-533
10.13
22130-355
1.81
22130-478
1.37
22130-561
1.183
23001-005
10.16
23001-534
10.13
22130-355
1.92
22130-479
1.101
22130-562
1.183
23001-006
10.16
23001-535
10.13
22130-372
1.113
22130-479
1.185
22130-563
1.183
23001-007
10.16
23001-536
10.13
22130-372
1.194
22130-479
1.37
22130-564
1.183
23001-009
10.16
23001-537
10.13
22130-372
1.48
22130-484
1.184
22130-565
1.183
23001-010
10.16
23001-538
10.13
22130-372
1.79
22130-485
1.184
22130-566
1.183
23001-015
10.16
23001-540
10.13
22130-373
1.113
22130-486
1.184
22130-567
1.183
23001-017
10.16
23001-541
10.13
12.34
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
23001-542
10.13
23006-575
10.11
23006-857
10.10
23021-608
10.21
23098-117
9.22
23001-545
10.13
23006-577
10.11
23006-862
10.6
23021-609
10.21
23098-117
9.26
23001-546
10.13
23006-578
10.11
23006-863
10.6
23021-610
10.21
23117-001
1.291
23001-550
10.13
23006-587
10.11
23006-864
10.6
23021-611
10.22
23117-001
1.303
23001-551
10.13
23006-594
10.11
23006-865
10.6
23021-613
10.23
23117-002
1.291
23001-701
10.14
23006-597
10.11
23006-866
10.6
23021-615
10.24
23117-002
1.303
23001-704
10.14
23006-601
10.8
23006-867
10.6
23021-616
10.23
23117-003
1.291
23001-712
10.14
23006-611
10.8
23006-868
10.6
23021-621
10.24
23117-003
1.303
23001-720
10.14
23006-615
10.8
23006-884
10.10
23021-651
10.20
23117-004
1.291
23001-812
10.12
23006-621
10.8
23006-887
10.10
23021-652
10.21
23117-004
1.303
23001-813
10.12
23006-715
10.7
23006-920
10.9
23021-653
10.21
23117-005
1.291
23001-814
10.12
23006-716
10.7
23006-922
10.9
23021-654
10.21
23117-005
1.303
23001-815
10.12
23006-718
10.7
23006-924
10.11
23021-655
10.22
23117-006
1.291
23006-300
10.6
23006-732
10.7
23006-931
10.6
23021-656
10.22
23117-006
1.303
23006-301
10.6
23006-734
10.7
23006-931
10.7
23021-657
10.23
23117-007
1.291
23006-303
10.6
23006-736
10.7
23007-010
10.19
23021-658
10.24
23117-007
1.303
23006-331
10.6
23006-738
10.7
23007-021
10.19
23021-660
10.23
23117-008
1.291
23006-331
10.7
23006-763
10.7
23007-040
10.19
23021-700
10.21
23117-008
1.303
23006-332
10.6
23006-764
10.7
23007-051
10.19
23021-701
10.21
23117-009
1.291
23006-334
10.6
23006-765
10.7
23007-081
10.19
23021-750
10.21
23117-009
1.303
23006-336
10.6
23006-768
10.7
23007-114
10.19
23022-002
10.25
23117-010
1.291
23006-337
10.6
23006-792
10.8
23007-128
10.19
23022-004
10.25
23117-010
1.303
23006-353
10.6
23006-793
10.8
23007-158
10.19
23022-010
10.25
23117-011
1.279
23006-354
10.6
23006-794
10.8
23007-188
10.19
23022-601
10.21
23117-011
1.292
23006-355
10.6
23006-795
10.8
23007-222
10.19
23022-602
10.21
23117-011
1.304
23006-358
10.6
23006-796
10.8
23007-410
10.19
23022-603
10.21
23117-012
1.278
23006-372
10.6
23006-797
10.8
23007-421
10.19
23022-604
10.23
23117-012
1.292
23006-373
10.6
23006-798
10.8
23007-601
10.5
23022-652
10.21
23117-012
1.304
23006-374
10.6
23006-799
10.8
23007-602
10.5
23022-700
10.21
23117-013
1.292
23006-375
10.6
23006-811
10.6
23007-611
10.4
23040-001
10.26
23117-013
1.304
23006-376
10.6
23006-811
10.7
23007-612
10.4
23098-100
10.18
23117-014
1.292
23006-377
10.6
23006-812
10.6
23007-613
10.4
23098-100
10.6
23117-014
1.304
23006-378
10.6
23006-813
10.6
23007-614
10.4
23098-105
10.18
23117-015
1.292
23006-405
10.7
23006-814
10.6
23007-624
10.4
23098-105
9.22
23117-015
1.304
23006-406
10.7
23006-815
10.6
23007-625
10.4
23098-105
9.26
23117-016
1.304
23006-408
10.7
23006-816
10.6
23021-001
10.25
23098-115
10.18
23117-017
1.297
23006-422
10.7
23006-817
10.6
23021-002
10.25
23098-115
9.22
23117-017
1.309
23006-424
10.7
23006-818
10.6
23021-100
10.25
23098-115
9.26
23117-018
1.297
23006-426
10.7
23006-824
10.10
23021-101
10.25
23098-116
10.18
23117-018
1.309
23006-428
10.7
23006-827
10.10
23021-103
10.25
23098-116
9.22
23117-019
1.297
23006-443
10.7
23006-833
10.6
23021-603
10.21
23098-116
9.23
23117-019
1.309
23006-444
10.7
23006-834
10.6
23021-604
10.22
23098-116
9.26
23117-020
1.287
23006-445
10.7
23006-835
10.6
23021-605
10.23
23098-116
9.27
23117-020
1.297
23006-448
10.7
23006-838
10.6
23021-607
10.20
23098-117
10.18
23117-020
1.310
12.35
Appendix
Part no.
Page
Part no.
23117-021
1.287
23130-002
1.15
23130-012
1.75
23130-020
1.61
23130-027
1.19
23117-021
1.297
23130-002
1.167
23130-012
1.88
23130-020
1.88
23130-027
1.61
23117-021
1.310
23130-002
1.189
23130-013
1.111
23130-021
1.140
23130-027
1.88
23117-022
1.287
23130-002
1.36
23130-013
1.140
23130-021
1.19
23130-028
1.140
23117-022
1.297
23130-002
1.42
23130-013
1.19
23130-021
1.191
23130-028
1.19
23117-022
1.310
23130-003
1.135
23130-013
1.44
23130-021
1.61
23130-028
1.61
23117-023
1.287
23130-003
1.167
23130-013
1.61
23130-021
1.88
23130-028
1.88
23117-023
1.297
23130-003
1.189
23130-013
1.75
23130-022
1.111
23130-029
1.140
23117-023
1.310
23130-004
1.135
23130-013
1.88
23130-022
1.140
23130-029
1.19
23117-024
1.287
23130-004
1.167
23130-014
1.111
23130-022
1.19
23130-029
1.61
23117-024
1.297
23130-004
1.189
23130-014
1.140
23130-022
1.191
23130-029
1.88
23117-024
1.310
23130-005
1.100
23130-014
1.169
23130-022
1.44
23130-030
1.140
23117-025
1.287
23130-005
1.104
23130-014
1.19
23130-022
1.61
23130-030
1.19
23117-025
1.297
23130-005
1.135
23130-014
1.44
23130-022
1.75
23130-030
1.61
23117-025
1.310
23130-005
1.167
23130-014
1.61
23130-022
1.88
23130-030
1.88
23117-026
1.287
23130-005
1.189
23130-014
1.75
23130-023
1.111
23130-031
1.140
23117-026
1.297
23130-005
1.36
23130-014
1.88
23130-023
1.140
23130-031
1.169
23117-026
1.310
23130-005
1.42
23130-015
1.111
23130-023
1.19
23130-031
1.19
23117-027
1.287
23130-006
1.100
23130-015
1.140
23130-023
1.44
23130-031
1.191
23117-027
1.297
23130-006
1.104
23130-015
1.169
23130-023
1.61
23130-031
1.61
23117-027
1.310
23130-006
1.135
23130-015
1.19
23130-023
1.75
23130-031
1.88
23117-028
1.287
23130-006
1.167
23130-015
1.44
23130-023
1.88
23130-032
1.111
23117-028
1.297
23130-006
1.189
23130-015
1.61
23130-024
1.111
23130-032
1.140
23117-028
1.310
23130-006
1.36
23130-015
1.75
23130-024
1.140
23130-032
1.169
23117-029
1.287
23130-006
1.42
23130-015
1.88
23130-024
1.19
23130-032
1.19
23117-029
1.297
23130-007
1.135
23130-016
1.111
23130-024
1.191
23130-032
1.191
23117-029
1.310
23130-007
1.167
23130-016
1.140
23130-024
1.44
23130-032
1.44
23117-030
1.287
23130-007
1.189
23130-016
1.169
23130-024
1.61
23130-032
1.61
23117-030
1.297
23130-008
1.135
23130-016
1.44
23130-024
1.75
23130-032
1.75
23117-030
1.310
23130-008
1.167
23130-016
1.75
23130-024
1.88
23130-032
1.88
23117-031
1.287
23130-008
1.189
23130-017
1.140
23130-025
1.111
23130-033
1.111
23117-031
1.297
23130-009
1.36
23130-017
1.19
23130-025
1.140
23130-033
1.140
23117-031
1.310
23130-009
1.42
23130-017
1.61
23130-025
1.19
23130-033
1.19
23130-001
1.100
23130-011
1.140
23130-017
1.88
23130-025
1.191
23130-033
1.44
23130-001
1.104
23130-011
1.169
23130-018
1.140
23130-025
1.44
23130-033
1.61
23130-001
1.135
23130-011
1.19
23130-018
1.19
23130-025
1.61
23130-033
1.75
23130-001
1.15
23130-011
1.61
23130-018
1.61
23130-025
1.75
23130-033
1.88
23130-001
1.167
23130-011
1.88
23130-018
1.88
23130-025
1.88
23130-034
1.111
23130-001
1.189
23130-012
1.111
23130-019
1.140
23130-026
1.111
23130-034
1.140
23130-001
1.36
23130-012
1.140
23130-019
1.19
23130-026
1.140
23130-034
1.169
23130-001
1.42
23130-012
1.169
23130-019
1.61
23130-026
1.191
23130-034
1.19
23130-002
1.100
23130-012
1.19
23130-019
1.88
23130-026
1.44
23130-034
1.191
23130-002
1.104
23130-012
1.44
23130-020
1.140
23130-026
1.75
23130-034
1.44
23130-002
1.135
23130-012
1.61
23130-020
1.19
23130-027
1.140
23130-034
1.61
12.36
Page
Part no.
Page
Part no.
Page
Part no.
Page
Appendix
Part no.
Page
Part no.
Page
Part no.
23130-034
1.75
23130-056
1.45
23130-072
1.164
23130-077
1.180
23130-082
1.191
23130-034
1.88
23130-056
1.76
23130-072
1.165
23130-077
1.28
23130-082
1.193
23130-035
1.111
23130-061
1.158
23130-072
1.186
23130-077
1.40
23130-082
1.24
23130-035
1.140
23130-061
1.180
23130-072
1.187
23130-077
1.56
23130-082
1.47
23130-035
1.169
23130-061
1.28
23130-072
1.228
23130-077
1.57
23130-082
1.51
23130-035
1.19
23130-061
1.98
23130-072
1.229
23130-077
1.58
23130-082
1.66
23130-035
1.191
23130-062
1.102
23130-072
1.230
23130-077
1.70
23130-082
1.78
23130-035
1.44
23130-062
1.28
23130-072
1.232
23130-078
1.12
23130-082
1.82
23130-035
1.61
23130-062
1.40
23130-072
1.33
23130-078
1.13
23130-082
1.93
23130-035
1.75
23130-063
1.106
23130-072
1.34
23130-078
1.132
23130-083
1.141
23130-035
1.88
23130-063
1.70
23130-072
1.41
23130-078
1.14
23130-083
1.169
23130-036
1.111
23130-064
1.102
23130-072
1.56
23130-078
1.158
23130-083
1.191
23130-036
1.140
23130-064
1.40
23130-072
1.57
23130-078
1.180
23130-084
1.141
23130-036
1.169
23130-065
1.106
23130-072
1.72
23130-078
1.28
23130-084
1.169
23130-036
1.191
23130-065
1.70
23130-072
1.87
23130-078
1.40
23130-084
1.191
23130-036
1.44
23130-067
1.12
23130-072
1.99
23130-078
1.56
23130-084
1.82
23130-036
1.75
23130-067
1.13
23130-073
1.104
23130-078
1.57
23130-085
1.12
23130-037
1.140
23130-067
1.15
23130-073
1.42
23130-078
1.58
23130-085
1.13
23130-037
1.19
23130-067
1.160
23130-074
1.100
23130-078
1.70
23130-085
1.164
23130-037
1.61
23130-067
1.161
23130-074
1.135
23130-079
1.158
23130-085
1.186
23130-037
1.88
23130-067
1.182
23130-074
1.136
23130-079
1.180
23130-085
1.33
23130-038
1.140
23130-067
1.183
23130-074
1.15
23130-079
1.28
23130-085
1.86
23130-038
1.19
23130-067
1.30
23130-074
1.167
23130-079
1.40
23130-086
1.117
23130-038
1.61
23130-067
1.31
23130-074
1.189
23130-079
1.70
23130-086
1.151
23130-038
1.88
23130-067
2.28
23130-074
1.36
23130-081
1.112
23130-086
1.176
23130-039
1.140
23130-068
1.164
23130-075
1.100
23130-081
1.116
23130-086
1.198
23130-039
1.19
23130-068
1.186
23130-075
1.135
23130-081
1.141
23130-086
1.24
23130-039
1.61
23130-068
1.33
23130-075
1.15
23130-081
1.169
23130-086
1.52
23130-039
1.88
23130-069
1.134
23130-075
1.167
23130-081
1.17
23130-086
1.83
23130-040
1.140
23130-069
1.165
23130-075
1.189
23130-081
1.171
23130-086
1.93
23130-040
1.19
23130-069
1.187
23130-075
1.36
23130-081
1.191
23130-087
1.117
23130-040
1.61
23130-069
1.34
23130-076
1.100
23130-081
1.193
23130-087
1.151
23130-040
1.88
23130-070
1.133
23130-076
1.104
23130-081
1.24
23130-087
1.176
23130-050
1.155
23130-070
1.165
23130-076
1.135
23130-081
1.47
23130-087
1.198
23130-050
1.177
23130-070
1.187
23130-076
1.15
23130-081
1.51
23130-087
1.24
23130-050
1.199
23130-070
1.34
23130-076
1.167
23130-081
1.78
23130-087
1.52
23130-052
1.45
23130-071
1.134
23130-076
1.189
23130-081
1.82
23130-087
1.66
23130-052
1.76
23130-071
1.165
23130-076
1.36
23130-081
1.93
23130-087
1.83
23130-053
1.45
23130-071
1.187
23130-076
1.42
23130-082
1.112
23130-087
1.93
23130-053
1.76
23130-071
1.34
23130-077
1.12
23130-082
1.116
23130-088
1.151
23130-054
1.45
23130-072
1.103
23130-077
1.13
23130-082
1.141
23130-088
1.176
23130-054
1.76
23130-072
1.107
23130-077
1.132
23130-082
1.169
23130-088
1.198
23130-055
1.45
23130-072
1.133
23130-077
1.14
23130-082
1.17
23130-089
1.151
23130-055
1.76
23130-072
1.14
23130-077
1.158
23130-082
1.171
23130-089
1.176
Page
Part no.
Page
Part no.
Part number in bold face type: ready for despatch within 2 working days
Page
12.37
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
23130-089
1.198
23130-096
1.142
23130-120
1.142
23130-140
1.172
23130-160
1.192
23130-089
1.83
23130-096
1.175
23130-120
1.175
23130-140
1.173
23130-160
1.46
23130-090
1.166
23130-096
1.197
23130-120
1.197
23130-140
1.174
23130-160
1.77
23130-090
1.188
23130-096
1.20
23130-120
1.82
23130-140
1.194
23130-164
1.101
23130-090
1.35
23130-096
1.51
23130-123
1.142
23130-140
1.195
23130-164
1.163
23130-090
1.58
23130-096
1.82
23130-123
1.175
23130-140
1.196
23130-164
1.185
23130-090
1.72
23130-096
1.89
23130-123
1.197
23130-140
1.22
23130-164
1.37
23130-091
1.111
23130-097
1.116
23130-123
1.20
23130-140
1.23
23130-165
1.133
23130-091
1.140
23130-097
1.20
23130-123
1.89
23130-140
1.48
23130-165
1.158
23130-091
1.169
23130-097
1.51
23130-124
1.20
23130-140
1.49
23130-165
1.159
23130-091
1.191
23130-097
1.62
23130-124
1.62
23130-140
1.50
23130-165
1.166
23130-091
1.44
23130-097
1.82
23130-124
1.89
23130-140
1.64
23130-165
1.188
23130-091
1.75
23130-097
1.89
23130-125
1.142
23130-140
1.65
23130-165
1.190
23130-092
1.113
23130-098
1.142
23130-125
1.175
23130-140
1.79
23130-165
1.35
23130-092
1.115
23130-098
1.175
23130-125
1.197
23130-140
1.80
23130-165
1.72
23130-092
1.145
23130-098
1.197
23130-132
1.159
23130-140
1.81
23130-166
1.36
23130-092
1.172
23130-098
1.82
23130-132
1.181
23130-140
1.91
23130-166
1.42
23130-092
1.174
23130-099
1.51
23130-132
1.29
23130-140
1.92
23130-169
1.137
23130-092
1.194
23130-101
1.142
23130-133
1.163
23130-141
1.132
23130-169
1.16
23130-092
1.196
23130-101
1.175
23130-133
1.185
23130-149
1.152
23130-169
1.168
23130-092
1.23
23130-101
1.197
23130-133
1.29
23130-149
1.159
23130-169
1.190
23130-092
1.254
23130-101
1.20
23130-134
1.100
23130-149
1.181
23130-169
1.36
23130-092
1.267
23130-101
1.89
23130-134
1.135
23130-150
1.152
23130-169
1.42
23130-092
1.286
23130-102
1.20
23130-134
1.136
23130-150
1.159
23130-169
1.73
23130-092
1.299
23130-102
1.62
23130-134
1.167
23130-150
1.181
23130-170
1.137
23130-092
1.313
23130-102
1.89
23130-134
1.189
23130-151
1.152
23130-170
1.16
23130-092
1.48
23130-103
1.142
23130-134
1.36
23130-151
1.159
23130-170
1.168
23130-092
1.50
23130-103
1.175
23130-135
1.100
23130-151
1.181
23130-170
1.190
23130-092
1.65
23130-103
1.197
23130-135
1.135
23130-153
1.210
23130-170
1.36
23130-092
1.79
23130-116
1.51
23130-135
1.167
23130-153
1.222
23130-170
1.42
23130-092
1.81
23130-118
1.116
23130-135
1.189
23130-158
1.110
23130-170
1.59
23130-092
1.92
23130-118
1.142
23130-135
1.36
23130-158
1.170
23130-170
1.73
23130-094
1.116
23130-118
1.175
23130-136
1.100
23130-158
1.18
23130-171
1.137
23130-094
1.142
23130-118
1.197
23130-136
1.104
23130-158
1.192
23130-171
1.168
23130-094
1.175
23130-118
1.20
23130-136
1.135
23130-158
1.46
23130-171
1.190
23130-094
1.197
23130-118
1.51
23130-136
1.167
23130-158
1.60
23130-172
1.137
23130-094
1.51
23130-118
1.82
23130-136
1.189
23130-158
1.77
23130-172
1.168
23130-094
1.82
23130-118
1.89
23130-136
1.36
23130-159
1.110
23130-172
1.190
23130-094
2.31
23130-119
1.116
23130-136
1.42
23130-159
1.170
23130-172
1.73
23130-095
1.142
23130-119
1.20
23130-140
1.113
23130-159
1.192
23130-187
1.137
23130-095
1.175
23130-119
1.51
23130-140
1.114
23130-159
1.46
23130-187
1.16
23130-095
1.197
23130-119
1.62
23130-140
1.115
23130-159
1.77
23130-187
1.168
23130-095
2.31
23130-119
1.82
23130-140
1.144
23130-160
1.110
23130-187
1.190
23130-096
1.116
23130-119
1.89
23130-140
1.145
23130-160
1.170
23130-187
1.36
12.38
Appendix
Part no.
Page
Part no.
23130-187
1.42
23130-214
1.168
23130-329
1.150
23130-345
1.190
23130-362
1.168
23130-187
1.59
23130-214
1.190
23130-329
1.176
23130-346
1.139
23130-362
1.190
23130-187
1.73
23130-215
1.138
23130-329
1.198
23130-346
1.168
23130-363
1.137
23130-194
1.137
23130-215
1.168
23130-330
1.150
23130-346
1.190
23130-363
1.168
23130-194
1.168
23130-215
1.190
23130-330
1.176
23130-347
1.168
23130-363
1.190
23130-194
1.190
23130-220
1.160
23130-330
1.198
23130-347
1.190
23130-364
1.169
23130-194
1.36
23130-221
1.160
23130-331
1.176
23130-348
1.139
23130-364
1.191
23130-194
1.42
23130-221
1.30
23130-331
1.198
23130-348
1.168
23130-365
1.141
23130-194
1.73
23130-222
1.30
23130-332
1.150
23130-348
1.190
23130-365
1.169
23130-208
1.138
23130-223
1.160
23130-332
1.176
23130-349
1.139
23130-365
1.191
23130-208
1.16
23130-223
1.30
23130-332
1.198
23130-349
1.168
23130-366
1.176
23130-208
1.168
23130-224
1.160
23130-333
1.117
23130-349
1.190
23130-366
1.198
23130-208
1.190
23130-224
1.30
23130-333
1.154
23130-350
1.139
23130-367
1.151
23130-208
1.36
23130-225
1.160
23130-333
1.176
23130-350
1.168
23130-367
1.176
23130-208
1.42
23130-225
1.30
23130-333
1.198
23130-350
1.190
23130-367
1.198
23130-208
1.73
23130-230
1.182
23130-333
1.25
23130-351
1.168
23130-368
1.168
23130-209
1.138
23130-231
1.182
23130-333
1.52
23130-351
1.190
23130-368
1.190
23130-209
1.16
23130-231
1.30
23130-333
1.83
23130-352
1.139
23130-369
1.138
23130-209
1.168
23130-232
1.30
23130-333
1.94
23130-352
1.168
23130-369
1.168
23130-209
1.190
23130-233
1.182
23130-334
1.117
23130-352
1.190
23130-369
1.190
23130-209
1.36
23130-233
1.30
23130-334
1.154
23130-353
1.136
23130-370
1.168
23130-209
1.42
23130-234
1.182
23130-334
1.176
23130-353
1.167
23130-370
1.190
23130-209
1.59
23130-234
1.30
23130-334
1.198
23130-353
1.189
23130-371
1.138
23130-209
1.73
23130-235
1.182
23130-334
1.25
23130-354
1.136
23130-371
1.168
23130-210
1.138
23130-235
1.30
23130-334
1.52
23130-354
1.167
23130-371
1.190
23130-210
1.168
23130-274
1.113
23130-334
1.67
23130-354
1.189
23130-372
1.149
23130-210
1.190
23130-274
1.172
23130-334
1.83
23130-355
1.136
23130-372
1.177
23130-211
1.138
23130-274
1.194
23130-335
1.152
23130-355
1.167
23130-372
1.199
23130-211
1.168
23130-274
1.48
23130-335
1.159
23130-355
1.189
23130-373
1.159
23130-211
1.190
23130-274
1.79
23130-335
1.181
23130-356
1.167
23130-373
1.181
23130-211
1.73
23130-285
1.148
23130-336
1.148
23130-356
1.189
23130-374
1.136
23130-212
1.138
23130-310
1.143
23130-336
1.177
23130-357
1.136
23130-374
1.167
23130-212
1.168
23130-310
1.21
23130-336
1.199
23130-357
1.167
23130-374
1.189
23130-212
1.190
23130-310
1.63
23130-341
1.148
23130-357
1.189
23130-375
1.136
23130-212
1.36
23130-310
1.90
23130-341
1.177
23130-358
1.167
23130-375
1.167
23130-212
1.42
23130-312
1.153
23130-341
1.199
23130-358
1.189
23130-375
1.189
23130-212
1.73
23130-312
1.176
23130-342
1.148
23130-359
1.135
23130-376
1.167
23130-213
1.138
23130-312
1.198
23130-342
1.177
23130-359
1.167
23130-376
1.189
23130-213
1.168
23130-326
1.150
23130-342
1.199
23130-359
1.189
23130-377
1.136
23130-213
1.190
23130-326
1.176
23130-343
1.149
23130-360
1.167
23130-377
1.167
23130-213
1.36
23130-326
1.198
23130-343
1.162
23130-360
1.189
23130-377
1.189
23130-213
1.42
23130-328
1.150
23130-343
1.184
23130-361
1.135
23130-378
1.136
23130-213
1.73
23130-328
1.176
23130-345
1.139
23130-361
1.167
23130-378
1.167
23130-214
1.138
23130-328
1.198
23130-345
1.168
23130-361
1.189
23130-378
1.189
Page
Part no.
Page
Part no.
Page
Part no.
Page
12.39
Appendix
Part no.
Page
Part no.
Part no.
Page
Part no.
Page
Part no.
23130-379
1.149
23130-414
23130-379
1.162
23130-414
1.47
23130-477
1.223
23207-021
8.106
24560-080
6.12
1.76
23130-478
1.211
23207-022
8.107
24560-080
6.44
23130-379
1.184
23130-418
1.112
23130-478
1.223
23207-022
8.87
24560-081
6.12
23130-386
1.127
23130-418
1.17
23130-480
1.211
23207-028
8.106
24560-081
6.44
23130-386
1.129
23130-418
1.47
23130-480
1.223
23207-115
1.228
24560-082
6.44
23130-386
1.131
23130-418
1.76
23130-481
1.211
23207-115
1.229
24560-083
6.44
23130-386
1.139
23130-420
1.152
23130-481
1.223
23207-115
1.230
24560-130
5.34
23130-387
1.137
23130-420
1.159
23130-484
1.211
23207-115
1.234
24560-130
6.20
23130-387
1.16
23130-420
1.181
23130-484
1.223
24127-485
1.329
24560-130
6.21
23130-387
1.59
23130-421
1.152
23130-485
1.211
24127-487
1.329
24560-130
6.22
23130-387
1.73
23130-421
1.159
23130-485
1.223
24127-489
1.329
24560-130
6.23
23130-388
1.137
23130-421
1.181
23204-113
10.13
24127-491
1.329
24560-130
6.24
23130-388
1.73
23130-421
1.221
23204-113
10.14
24127-682
1.328
24560-130
6.25
23130-395
1.72
23130-422
1.152
23204-113
10.4
24127-686
1.328
24560-130
6.28
23130-396
1.72
23130-422
1.159
23204-113
10.5
24127-689
1.328
24560-130
6.30
23130-397
1.72
23130-422
1.181
23204-113
10.6
24127-694
1.328
24560-130
6.31
23130-398
1.72
23130-422
1.221
23204-113
10.7
24127-697
1.328
24560-130
6.32
23130-400
1.108
23130-433
1.208
23204-115
10.13
24496-120
8.110
24560-130
6.65
23130-400
1.73
23130-433
1.218
23204-115
10.14
24496-122
8.110
24560-130
7.110
23130-401
1.108
23130-437
1.204
23204-115
10.15
24560-031
6.45
24560-131
6.65
23130-401
1.73
23130-437
1.214
23204-115
10.16
24560-032
6.45
24560-135
6.47
23130-402
1.108
23130-443
1.72
23204-115
10.6
24560-033
6.45
24560-135
6.65
23130-402
1.73
23130-447
1.73
23204-115
10.7
24560-041
6.45
24560-135
6.83
23130-403
1.108
23130-453
1.206
23204-116
10.13
24560-042
6.45
24560-135
7.110
23130-403
1.73
23130-453
1.207
23204-116
10.14
24560-043
6.45
24560-139
6.55
23130-405
1.112
23130-453
1.216
23204-116
10.15
24560-051
6.45
24560-139
6.65
23130-405
1.17
23130-453
1.217
23204-116
10.16
24560-052
6.45
24560-139
7.109
23130-405
1.47
23130-454
1.102
23204-116
10.6
24560-053
6.45
24560-140
5.28
23130-405
1.76
23130-454
1.106
23204-116
10.7
24560-054
6.45
24560-140
6.103
23130-406
1.112
23130-454
1.98
23204-187
8.10
24560-055
6.45
24560-140
6.111
23130-406
1.47
23130-455
1.102
23204-187
8.18
24560-056
6.45
24560-140
6.55
23130-406
1.76
23130-455
1.106
23204-187
8.6
24560-061
6.44
24560-140
6.66
23130-407
1.112
23130-455
1.98
23204-187
8.7
24560-062
6.44
24560-140
7.111
23130-407
1.17
23130-456
1.102
23204-187
8.8
24560-063
6.44
24560-141
5.40
23130-407
1.47
23130-456
1.106
23204-187
8.9
24560-064
6.44
24560-141
5.41
23130-407
1.76
23130-456
1.98
23204-811
10.15
24560-065
6.44
24560-141
5.42
23130-408
1.112
23130-457
1.102
23204-811
10.16
24560-066
6.44
24560-141
5.73
23130-408
1.47
23130-457
1.106
23204-811
10.4
24560-071
6.44
24560-141
5.74
23130-408
1.76
23130-457
1.98
23204-811
10.5
24560-072
6.44
24560-141
5.92
23130-413
1.112
23130-473
1.205
23204-812
10.15
24560-073
6.44
24560-141
5.93
23130-413
1.17
23130-473
1.215
23204-812
10.16
24560-078
6.12
24560-141
6.105
23130-413
1.47
23130-475
1.211
23204-812
10.4
24560-078
6.44
24560-141
6.106
23130-413
1.76
23130-475
1.223
23204-812
10.5
24560-079
6.12
24560-141
6.12
23130-414
1.112
23130-477
1.211
23204-835
8.50
24560-079
6.44
24560-141
6.124
12.40
Page
Page
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
24560-141
6.13
24560-155
6.23
24560-183
5.109
24560-141
6.14
24560-155
6.24
24560-183
6.25
24560-243
6.83
24560-255
6.9
24560-245
6.108
24560-255
6.94
24560-141
6.15
24560-155
6.28
24560-184
5.37
24560-245
6.111
24560-256
5.42
24560-141
6.36
24560-155
6.30
24560-184
5.64
24560-245
6.44
24560-256
6.106
24560-141
6.37
24560-155
6.65
24560-184
5.94
24560-245
6.45
24560-256
6.107
24560-141
6.38
24560-155
7.110
24560-184
6.59
24560-245
6.47
24560-256
6.14
24560-141
6.39
24560-157
5.41
24560-197
6.20
24560-245
6.82
24560-256
6.15
24560-141
6.64
24560-157
5.74
24560-198
6.20
24560-245
6.83
24560-256
6.38
24560-141
6.73
24560-157
5.93
24560-199
6.20
24560-246
6.108
24560-256
6.41
24560-141
6.74
24560-157
6.106
24560-199
6.21
24560-246
6.111
24560-256
6.81
24560-141
6.90
24560-157
6.37
24560-229
5.19
24560-246
6.44
24560-270
5.28
24560-141
6.94
24560-157
6.64
24560-229
5.54
24560-246
6.45
24560-270
5.38
24560-141
7.110
24560-157
6.94
24560-229
5.65
24560-246
6.47
24560-270
5.43
24560-145
5.39
24560-157
7.110
24560-229
6.110
24560-246
6.82
24560-270
5.71
24560-145
5.70
24560-158
5.42
24560-229
6.53
24560-255
5.40
24560-270
5.96
24560-145
5.95
24560-158
6.38
24560-231
5.19
24560-255
5.41
24560-270
6.49
24560-145
6.57
24560-158
6.39
24560-231
5.54
24560-255
5.42
24560-270
6.53
24560-145
6.65
24560-158
6.64
24560-231
5.65
24560-255
5.73
24560-270
6.54
24560-145
7.109
24560-158
7.109
24560-231
6.110
24560-255
5.74
24560-270
6.58
24560-146
5.37
24560-159
7.110
24560-231
6.53
24560-255
5.92
24560-270
6.61
24560-146
5.64
24560-159
7.22
24560-233
5.19
24560-255
5.93
24560-270
7.6
24560-146
5.94
24560-159
7.35
24560-233
5.54
24560-255
6.10
24560-270
7.91
24560-146
6.59
24560-161
10.28
24560-233
5.65
24560-255
6.105
24560-271
5.19
24560-147
11.4
24560-161
6.65
24560-233
6.110
24560-255
6.106
24560-271
5.28
24560-147
11.5
24560-161
7.110
24560-233
6.53
24560-255
6.107
24560-271
6.108
24560-147
5.35
24560-162
10.28
24560-235
5.19
24560-255
6.11
24560-271
6.111
24560-147
5.69
24560-162
6.65
24560-235
5.54
24560-255
6.12
24560-271
6.44
24560-147
5.91
24560-162
7.110
24560-235
5.65
24560-255
6.124
24560-271
6.45
24560-147
6.34
24560-163
10.28
24560-235
6.110
24560-255
6.13
24560-271
6.47
24560-147
6.65
24560-164
7.22
24560-235
6.53
24560-255
6.14
24560-271
6.82
24560-147
7.110
24560-164
7.35
24560-236
5.19
24560-255
6.15
24560-271
6.83
24560-147
7.22
24560-165
6.67
24560-236
5.65
24560-255
6.36
24560-280
6.54
24560-148
5.35
24560-166
6.67
24560-236
6.110
24560-255
6.37
24560-297
6.20
24560-148
5.69
24560-167
6.60
24560-236
6.53
24560-255
6.38
24560-298
6.20
24560-148
5.91
24560-178
7.78
24560-241
6.111
24560-255
6.39
24560-299
6.20
24560-148
6.34
24560-178
7.79
24560-241
6.44
24560-255
6.41
24560-299
6.21
24560-148
6.65
24560-179
5.39
24560-241
6.45
24560-255
6.73
24560-351
5.40
24560-148
7.110
24560-179
5.70
24560-241
6.47
24560-255
6.74
24560-351
5.73
24560-148
7.78
24560-179
5.95
24560-241
6.82
24560-255
6.75
24560-351
5.92
24560-151
6.65
24560-179
6.57
24560-241
6.83
24560-255
6.76
24560-351
6.10
24560-151
7.110
24560-179
6.64
24560-243
6.44
24560-255
6.78
24560-351
6.105
24560-155
6.20
24560-179
7.78
24560-243
6.45
24560-255
6.79
24560-351
6.11
24560-155
6.21
24560-180
6.54
24560-243
6.47
24560-255
6.8
24560-351
6.12
24560-155
6.22
24560-182
6.25
24560-243
6.82
24560-255
6.81
24560-351
6.13
Page
Part no.
Page
12.41
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
24560-351
6.36
24560-359
6.14
24560-378
6.37
24560-840
6.104
24561-341
6.106
24560-351
6.73
24560-359
6.15
24560-378
6.39
24560-840
6.33
24561-341
6.38
24560-351
6.74
24560-359
6.38
24560-378
6.41
24560-842
5.35
24561-342
5.42
24560-351
6.8
24560-359
6.81
24560-378
7.102
24560-842
5.68
24561-342
6.38
24560-351
6.81
24560-360
5.42
24560-379
5.40
24560-842
5.90
24561-498
6.20
24560-351
6.88
24560-360
6.106
24560-379
5.73
24560-842
6.104
24561-498
6.22
24560-351
6.9
24560-360
6.15
24560-379
5.92
24560-842
6.33
24561-499
6.111
24560-351
6.94
24560-360
6.38
24560-379
6.10
24560-863
5.35
24561-499
6.55
24560-353
5.40
24560-361
5.42
24560-379
6.105
24560-863
5.68
24561-798
6.20
24560-353
5.73
24560-361
6.38
24560-379
6.11
24560-863
5.90
24562-197
6.25
24560-353
5.92
24560-362
5.42
24560-379
6.12
24560-863
6.104
24562-199
6.54
24560-353
6.10
24560-362
6.38
24560-379
6.13
24560-863
6.33
24562-297
6.25
24560-353
6.105
24560-373
5.41
24560-379
6.36
24560-884
5.35
24562-299
6.54
24560-353
6.11
24560-373
5.74
24560-379
6.73
24560-884
5.68
24562-420
5.39
24560-353
6.12
24560-373
5.93
24560-379
6.74
24560-884
5.90
24562-420
5.70
24560-353
6.13
24560-373
6.124
24560-379
6.8
24560-884
6.104
24562-420
5.95
24560-353
6.36
24560-373
6.37
24560-379
6.9
24560-884
6.33
24562-420
6.57
24560-353
6.73
24560-374
5.41
24560-380
5.40
24561-031
6.43
24562-440
5.39
24560-353
6.74
24560-374
5.74
24560-380
5.73
24561-041
6.43
24562-440
5.70
24560-353
6.75
24560-374
5.93
24560-380
5.92
24561-051
6.10
24562-440
5.95
24560-353
6.76
24560-374
6.124
24560-380
6.10
24561-051
6.43
24562-440
6.57
24560-353
6.78
24560-374
6.37
24560-380
6.105
24561-051
6.8
24562-442
5.39
24560-353
6.79
24560-375
5.41
24560-380
6.11
24561-051
6.9
24562-442
5.70
24560-353
6.8
24560-375
5.74
24560-380
6.12
24561-052
6.10
24562-442
5.95
24560-353
6.81
24560-375
5.93
24560-380
6.36
24561-052
6.43
24562-442
6.57
24560-353
6.9
24560-375
6.124
24560-380
6.73
24561-052
6.8
24562-446
3.22
24560-355
5.42
24560-375
6.37
24560-380
6.9
24561-052
6.9
24562-446
6.62
24560-355
6.106
24560-376
5.41
24560-381
7.104
24561-198
6.20
24562-449
3.22
24560-355
6.15
24560-376
5.74
24560-480
6.54
24561-198
6.22
24562-449
6.62
24560-355
6.38
24560-376
5.93
24560-497
6.20
24561-199
6.111
24562-451
3.22
24560-356
5.42
24560-376
6.124
24560-498
6.20
24561-199
6.55
24562-451
6.62
24560-356
6.106
24560-376
6.37
24560-499
6.20
24561-298
6.20
24562-452
3.22
24560-356
6.14
24560-377
5.41
24560-499
6.21
24561-330
5.42
24562-452
6.62
24560-356
6.15
24560-377
5.74
24560-797
6.20
24561-330
6.106
24562-453
3.23
24560-356
6.38
24560-377
5.93
24560-798
6.20
24561-330
6.38
24562-453
6.62
24560-356
6.81
24560-377
6.124
24560-799
6.20
24561-331
5.42
24562-454
3.23
24560-358
5.42
24560-377
6.37
24560-799
6.21
24561-331
6.106
24562-454
6.62
24560-358
6.106
24560-377
6.39
24560-820
6.104
24561-331
6.38
24562-455
3.23
24560-358
6.14
24560-377
6.41
24560-820
6.33
24561-332
5.42
24562-455
6.62
24560-358
6.15
24560-377
7.102
24560-828
5.35
24561-332
6.38
24562-456
3.23
24560-358
6.38
24560-378
5.41
24560-828
5.68
24561-340
5.42
24562-456
6.62
24560-358
6.81
24560-378
5.74
24560-828
5.90
24561-340
6.106
24562-457
3.23
24560-359
5.42
24560-378
5.93
24560-828
6.104
24561-340
6.38
24562-457
6.62
24560-359
6.106
24560-378
6.124
24560-828
6.33
24561-341
5.42
24562-458
3.23
12.42
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
24562-458
6.62
24562-563
6.54
24563-432
6.10
24564-132
6.8
24566-102
6.103
24562-460
3.22
24562-584
5.19
24563-433
6.10
24564-133
6.8
24566-103
6.103
24562-460
6.62
24562-584
5.54
24563-434
6.10
24564-145
6.23
24566-104
6.103
24562-461
3.22
24562-584
5.67
24563-435
6.10
24564-147
6.23
24566-105
6.103
24562-461
6.62
24562-584
6.54
24563-436
6.10
24564-149
6.23
24566-105
6.111
24562-463
5.39
24562-797
6.25
24563-442
6.11
24564-151
6.23
24566-106
6.103
24562-463
5.70
24563-096
6.89
24563-443
6.11
24564-197
6.21
24566-125
6.22
24562-463
5.95
24563-100
6.89
24563-444
6.11
24564-198
6.21
24566-127
6.22
24562-463
6.57
24563-107
6.88
24563-445
6.11
24564-199
6.21
24566-129
6.22
24562-464
3.22
24563-108
6.88
24563-446
6.11
24564-199
6.23
24566-131
6.22
24562-464
6.62
24563-109
6.88
24563-452
6.14
24564-209
5.38
24566-145
6.23
24562-466
3.22
24563-110
6.88
24563-457
6.15
24564-209
5.71
24566-147
6.23
24562-466
6.62
24563-131
6.10
24563-461
6.12
24564-209
5.96
24566-149
6.23
24562-467
3.22
24563-132
6.10
24563-461
6.73
24564-209
6.58
24566-151
6.23
24562-467
6.62
24563-133
6.10
24563-462
6.12
24564-217
5.38
24566-199
6.97
24562-468
3.22
24563-134
6.10
24563-462
6.73
24564-217
5.71
24566-400
6.109
24562-468
6.62
24563-135
6.10
24563-463
6.12
24564-217
5.96
24566-425
6.22
24562-472
3.22
24563-136
6.10
24563-463
6.73
24564-217
6.58
24566-427
6.22
24562-472
6.62
24563-142
6.11
24563-464
6.12
24564-297
6.21
24566-429
6.22
24562-473
3.22
24563-143
6.11
24563-464
6.73
24564-298
6.21
24566-431
6.22
24562-473
6.62
24563-144
6.11
24563-472
6.13
24564-299
6.21
24566-445
6.23
24562-474
3.22
24563-145
6.11
24563-472
6.74
24564-431
6.8
24566-447
6.23
24562-474
6.62
24563-146
6.11
24563-473
6.13
24564-432
6.8
24566-449
6.23
24562-484
5.39
24563-152
6.14
24563-473
6.74
24564-433
6.8
24566-451
6.23
24562-484
5.70
24563-157
6.15
24563-474
6.13
24564-445
6.23
24566-499
6.97
24562-484
5.95
24563-161
6.12
24563-474
6.74
24564-447
6.23
24567-125
6.22
24562-484
6.57
24563-161
6.73
24563-491
6.9
24564-449
6.23
24567-127
6.22
24562-497
6.25
24563-162
6.12
24563-492
6.9
24564-451
6.23
24567-129
6.22
24562-499
6.54
24563-162
6.73
24563-493
6.9
24564-497
6.21
24567-131
6.22
24562-520
5.19
24563-163
6.12
24563-494
6.9
24564-498
6.21
24567-149
6.94
24562-520
6.54
24563-163
6.73
24564-100
6.89
24564-499
6.21
24567-161
6.12
24562-528
5.19
24563-164
6.12
24564-109
5.38
24564-499
6.23
24567-161
6.73
24562-528
5.54
24563-164
6.73
24564-109
5.71
24564-797
6.21
24567-162
6.12
24562-528
5.67
24563-172
6.13
24564-109
5.96
24564-798
6.21
24567-162
6.73
24562-528
6.54
24563-172
6.74
24564-109
6.58
24564-799
6.21
24567-163
6.12
24562-540
5.19
24563-173
6.13
24564-117
5.38
24565-100
6.89
24567-163
6.73
24562-540
6.54
24563-173
6.74
24564-117
5.71
24566-004
6.105
24567-164
6.12
24562-542
5.19
24563-174
6.13
24564-117
5.96
24566-004
6.94
24567-164
6.73
24562-542
5.54
24563-174
6.74
24564-117
6.58
24566-005
6.105
24567-172
6.13
24562-542
5.67
24563-191
6.9
24564-118
5.38
24566-005
6.94
24567-172
6.74
24562-542
6.54
24563-192
6.9
24564-118
5.71
24566-007
6.108
24567-173
6.13
24562-563
5.19
24563-193
6.9
24564-118
5.96
24566-010
6.97
24567-173
6.74
24562-563
5.54
24563-194
6.9
24564-118
6.58
24566-100
6.103
24567-174
6.13
24562-563
5.67
24563-431
6.10
24564-131
6.8
24566-101
6.103
24567-174
6.74
Page
Part no.
Part number in normal type: ready for despatch within 10 working days
Page
12.43
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
24567-425
6.22
24571-029
5.11
24571-186
5.15
24571-309
5.26
24571-380
5.24
24567-427
6.22
24571-030
5.11
24571-187
5.15
24571-310
5.26
24571-395
5.12
24567-429
6.22
24571-038
5.11
24571-188
5.15
24571-314
5.26
24571-438
5.11
24567-431
6.22
24571-041
5.11
24571-194
5.15
24571-315
5.26
24571-441
5.11
24567-449
6.94
24571-042
5.11
24571-197
5.15
24571-316
5.26
24571-442
5.11
24567-461
6.12
24571-043
5.11
24571-206
5.15
24571-320
5.27
24571-443
5.11
24567-461
6.73
24571-044
5.11
24571-209
5.15
24571-321
5.27
24571-444
5.11
24567-462
6.12
24571-050
5.11
24571-210
5.15
24571-322
5.27
24571-486
5.11
24567-462
6.73
24571-053
5.11
24571-218
5.15
24571-325
5.23
24571-489
5.11
24567-463
6.12
24571-062
5.11
24571-221
5.15
24571-326
5.23
24571-490
5.11
24567-463
6.73
24571-065
5.11
24571-222
5.15
24571-327
5.23
24571-491
5.11
24567-464
6.12
24571-066
5.11
24571-223
5.15
24571-328
5.23
24571-492
5.11
24567-464
6.73
24571-074
5.11
24571-230
5.15
24571-331
5.18
24571-534
5.11
24567-472
6.13
24571-077
5.11
24571-233
5.15
24571-332
5.18
24571-537
5.11
24567-472
6.74
24571-078
5.11
24571-234
5.15
24571-333
5.18
24571-538
5.11
24567-473
6.13
24571-086
5.11
24571-235
5.15
24571-334
5.18
24571-539
5.11
24567-473
6.74
24571-089
5.11
24571-236
5.15
24571-335
5.18
24571-540
5.11
24567-474
6.13
24571-090
5.11
24571-242
5.15
24571-338
5.18
24571-582
5.15
24567-474
6.74
24571-091
5.11
24571-245
5.15
24571-339
5.18
24571-585
5.15
24568-004
6.108
24571-092
5.11
24571-254
5.15
24571-340
5.18
24571-586
5.15
24568-008
6.108
24571-098
5.11
24571-257
5.15
24571-341
5.18
24571-587
5.15
24568-012
6.108
24571-101
5.11
24571-258
5.15
24571-342
5.18
24571-588
5.15
24568-016
6.108
24571-110
5.11
24571-266
5.15
24571-349
5.24
24571-630
5.15
24568-020
6.108
24571-113
5.11
24571-269
5.15
24571-350
5.24
24571-633
5.15
24568-032
6.108
24571-114
5.11
24571-270
5.15
24571-351
5.24
24571-634
5.15
24568-036
6.108
24571-122
5.11
24571-271
5.15
24571-352
5.27
24571-635
5.15
24568-143
6.97
24571-125
5.11
24571-278
5.15
24571-353
5.27
24571-636
5.15
24568-144
6.97
24571-126
5.11
24571-281
5.15
24571-354
5.27
24571-678
5.15
24568-145
6.97
24571-134
5.11
24571-282
5.15
24571-355
5.27
24571-681
5.15
24568-147
6.97
24571-137
5.11
24571-283
5.15
24571-356
5.27
24571-682
5.15
24568-149
6.97
24571-138
5.11
24571-284
5.15
24571-359
5.27
24571-683
5.15
24568-151
6.97
24571-139
5.11
24571-295
5.25
24571-360
5.27
24571-684
5.15
24568-443
6.97
24571-140
5.11
24571-296
5.25
24571-361
5.27
24571-702
5.11
24568-444
6.97
24571-146
5.15
24571-297
5.25
24571-362
5.27
24571-705
5.11
24568-445
6.97
24571-149
5.15
24571-298
5.25
24571-363
5.27
24571-714
5.11
24568-447
6.97
24571-158
5.15
24571-299
5.25
24571-371
5.28
24571-717
5.11
24568-449
6.97
24571-161
5.15
24571-300
5.25
24571-371
5.67
24571-718
5.11
24568-451
6.97
24571-162
5.15
24571-301
5.25
24571-371
5.89
24571-726
5.11
24571-002
5.11
24571-170
5.15
24571-302
5.25
24571-372
5.28
24571-729
5.11
24571-005
5.11
24571-173
5.15
24571-303
5.25
24571-372
5.31
24571-730
5.11
24571-014
5.11
24571-174
5.15
24571-304
5.25
24571-372
5.32
24571-738
5.11
24571-017
5.11
24571-175
5.15
24571-305
5.25
24571-372
5.33
24571-741
5.11
24571-018
5.11
24571-182
5.15
24571-306
5.25
24571-372
5.67
24571-742
5.11
24571-026
5.11
24571-185
5.15
24571-308
5.26
24571-372
5.89
24571-743
5.11
12.44
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
24571-744
5.11
24571-909
5.15
24572-029
5.13
24572-159
5.11
24572-385
5.11
24571-750
5.11
24571-910
5.15
24572-030
5.13
24572-201
5.11
24572-393
5.11
24571-753
5.11
24571-911
5.15
24572-031
5.13
24572-204
5.11
24572-396
5.11
24571-762
5.11
24571-921
5.15
24572-040
5.13
24572-205
5.11
24572-397
5.11
24571-765
5.11
24571-922
5.15
24572-041
5.13
24572-206
5.11
24572-398
5.11
24571-766
5.11
24571-923
5.15
24572-042
5.13
24572-207
5.11
24572-399
5.11
24571-774
5.11
24571-930
5.15
24572-043
5.13
24572-213
5.11
24572-404
5.17
24571-777
5.11
24571-933
5.15
24572-044
5.13
24572-216
5.11
24572-405
5.17
24571-778
5.11
24571-934
5.15
24572-050
5.8
24572-225
5.11
24572-406
5.17
24571-786
5.11
24571-935
5.15
24572-051
5.8
24572-228
5.11
24572-407
5.17
24571-789
5.11
24571-936
5.15
24572-052
5.8
24572-229
5.11
24572-408
5.17
24571-790
5.11
24571-942
5.15
24572-053
5.8
24572-237
5.11
24572-409
5.17
24571-791
5.11
24571-945
5.15
24572-054
5.8
24572-240
5.11
24572-410
5.17
24571-792
5.11
24571-954
5.15
24572-055
5.8
24572-241
5.11
24572-411
5.17
24571-798
5.11
24571-957
5.15
24572-056
5.8
24572-249
5.11
24572-500
5.11
24571-801
5.11
24571-958
5.15
24572-064
5.8
24572-252
5.11
24572-503
5.11
24571-810
5.11
24571-959
5.15
24572-065
5.8
24572-253
5.11
24572-510
5.11
24571-813
5.11
24571-969
5.15
24572-066
5.8
24572-254
5.11
24572-513
5.11
24571-814
5.11
24571-970
5.15
24572-067
5.8
24572-255
5.11
24572-514
5.11
24571-822
5.11
24571-971
5.15
24572-068
5.8
24572-261
5.11
24572-520
5.11
24571-825
5.11
24571-978
5.15
24572-074
5.13
24572-264
5.11
24572-523
5.11
24571-826
5.11
24571-981
5.15
24572-075
5.13
24572-273
5.11
24572-524
5.11
24571-834
5.11
24571-982
5.15
24572-076
5.13
24572-276
5.11
24572-530
5.11
24571-837
5.11
24571-983
5.15
24572-077
5.13
24572-277
5.11
24572-533
5.11
24571-838
5.11
24571-984
5.15
24572-078
5.13
24572-285
5.11
24572-534
5.11
24571-839
5.11
24571-992
5.25
24572-079
5.13
24572-288
5.11
24572-535
5.11
24571-840
5.11
24571-993
5.25
24572-080
5.13
24572-289
5.11
24572-536
5.11
24571-846
5.15
24571-994
5.25
24572-088
5.13
24572-297
5.11
24572-570
5.11
24571-849
5.15
24572-001
5.8
24572-089
5.13
24572-300
5.11
24572-573
5.11
24571-858
5.15
24572-002
5.8
24572-090
5.13
24572-301
5.11
24572-574
5.11
24571-861
5.15
24572-003
5.8
24572-091
5.13
24572-302
5.11
24572-575
5.11
24571-862
5.15
24572-004
5.8
24572-092
5.13
24572-303
5.11
24572-576
5.11
24571-863
5.15
24572-005
5.8
24572-117
5.11
24572-345
5.11
24572-599
5.20
24571-873
5.15
24572-006
5.8
24572-120
5.11
24572-348
5.11
24572-600
5.20
24571-874
5.15
24572-007
5.8
24572-129
5.11
24572-349
5.11
24572-601
5.20
24571-875
5.15
24572-015
5.8
24572-132
5.11
24572-350
5.11
24572-602
5.20
24571-882
5.15
24572-016
5.8
24572-133
5.11
24572-351
5.11
24572-603
5.20
24571-885
5.15
24572-017
5.8
24572-141
5.11
24572-357
5.11
24572-604
5.20
24571-886
5.15
24572-018
5.8
24572-144
5.11
24572-360
5.11
24572-605
5.20
24571-887
5.15
24572-019
5.8
24572-145
5.11
24572-369
5.11
24572-606
5.20
24571-888
5.15
24572-025
5.13
24572-153
5.11
24572-372
5.11
24572-607
5.20
24571-894
5.15
24572-026
5.13
24572-156
5.11
24572-373
5.11
24572-608
5.20
24571-897
5.15
24572-027
5.13
24572-157
5.11
24572-381
5.11
24572-609
5.20
24571-906
5.15
24572-028
5.13
24572-158
5.11
24572-384
5.11
24572-610
5.20
12.45
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
24575-019
5.81
24576-009
5.49
24576-105
5.47
24579-033
8.78
24812-006
7.87
24575-035
5.82
24576-010
5.49
24576-106
5.47
24579-033
8.79
24812-007
7.87
24575-038
5.86
24576-011
5.49
24576-107
5.47
24579-033
8.80
24812-010
7.87
24575-075
5.82
24576-012
5.49
24576-108
5.47
24579-033
8.81
24812-012
7.87
24575-078
5.86
24576-013
5.49
24576-109
5.47
24579-033
8.82
24812-014
7.87
24575-114
5.83
24576-017
5.59
24576-110
5.47
24579-033
8.92
24812-055
7.87
24575-115
5.82
24576-018
5.59
24576-111
5.47
24579-037
7.63
24812-056
7.87
24575-118
5.86
24576-021
5.49
24576-112
5.47
24579-038
7.63
24812-057
7.87
24575-119
5.81
24576-022
5.49
24576-113
5.47
24579-039
7.63
24812-060
7.87
24575-135
5.82
24576-028
5.67
24576-117
5.59
24579-042
8.108
24812-062
7.87
24575-136
5.84
24576-042
5.67
24576-118
5.59
24579-043
8.108
24812-064
7.87
24575-137
5.85
24576-044
5.56
24576-121
5.47
24579-058
8.111
24812-100
7.77
24575-138
5.86
24576-045
5.56
24576-122
5.47
24579-059
8.111
24812-101
7.77
24575-155
5.82
24576-046
5.56
24576-144
5.56
24579-074
8.109
24812-162
7.73
24575-156
5.84
24576-047
5.56
24576-145
5.56
24579-077
8.76
24812-164
7.73
24575-157
5.85
24576-048
5.56
24576-146
5.56
24579-078
8.77
24812-171
7.73
24575-158
5.86
24576-049
5.56
24576-147
5.56
24579-079
8.76
24812-201
7.79
24575-175
5.82
24576-050
5.56
24576-148
5.56
24579-080
8.77
24812-202
7.78
24575-176
5.84
24576-052
5.56
24576-149
5.56
24579-081
8.76
24812-208
7.70
24575-177
5.85
24576-053
5.56
24576-150
5.56
24579-082
8.77
24812-210
7.70
24575-178
5.86
24576-054
5.56
24576-152
5.56
24579-090
6.44
24812-212
7.70
24575-214
5.83
24576-058
5.56
24576-153
5.56
24579-092
6.44
24812-214
7.70
24575-219
5.81
24576-063
5.67
24576-154
5.56
24579-105
8.78
24812-221
7.70
24575-235
5.82
24576-071
5.52
24576-158
5.56
24579-105
8.81
24812-228
7.70
24575-255
5.82
24576-072
5.52
24576-217
5.59
24579-106
8.77
24812-242
7.70
24575-275
5.82
24576-073
5.52
24576-218
5.59
24579-112
8.86
24812-258
7.70
24575-419
5.81
24576-080
5.62
24576-244
5.56
24579-135
8.86
24812-260
7.70
24575-454
5.90
24576-081
5.62
24576-245
5.56
24579-212
8.78
24812-262
7.70
24575-455
5.82
24576-082
5.62
24576-247
5.56
24579-212
8.81
24812-264
7.70
24575-474
5.68
24576-083
5.62
24576-248
5.56
24579-225
8.84
24812-271
7.70
24575-474
5.90
24576-084
5.67
24576-249
5.56
24579-225
8.85
24812-278
7.70
24575-475
5.82
24576-086
5.63
24576-250
5.56
24579-230
8.109
24812-292
7.70
24575-800
5.26
24576-087
5.63
24576-252
5.56
24579-250
8.79
24812-301
7.79
24575-800
5.65
24576-088
5.63
24576-253
5.56
24579-260
8.80
24812-302
7.78
24575-800
5.81
24576-091
5.63
24576-254
5.56
24579-400
8.74
24812-308
7.70
24575-801
5.86
24576-092
5.63
24576-258
5.56
24579-405
8.73
24812-310
7.70
24576-001
5.49
24576-093
5.61
24576-393
5.63
24579-415
8.70
24812-312
7.70
24576-002
5.49
24576-094
5.61
24576-394
5.63
24579-420
8.71
24812-314
7.70
24576-003
5.49
24576-095
5.61
24576-417
5.59
24579-602
8.84
24812-321
7.70
24576-004
5.49
24576-096
5.61
24576-418
5.59
24579-604
8.83
24812-328
7.70
24576-005
5.49
24576-101
5.47
24579-026
8.82
24579-605
8.75
24812-342
7.70
24576-006
5.49
24576-102
5.47
24579-028
8.87
24579-606
8.72
24812-358
7.70
24576-007
5.49
24576-103
5.47
24579-030
8.81
24579-612
8.85
24812-360
7.70
24576-008
5.49
24576-104
5.47
24579-031
8.78
24812-005
7.87
24812-362
7.70
12.46
ELECTRONICS PROTECTION
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
24812-364
7.70
24812-721
7.71
24813-055
7.86
24813-460
7.68
24813-860
7.69
24812-371
7.70
24812-728
7.71
24813-056
7.86
24813-462
7.68
24813-862
7.69
24812-378
7.70
24812-742
7.71
24813-057
7.86
24813-464
7.68
24813-864
7.69
24812-392
7.70
24812-758
7.71
24813-060
7.86
24813-471
7.68
24813-871
7.69
24812-401
7.77
24812-760
7.71
24813-062
7.86
24813-478
7.68
24813-878
7.69
24812-402
7.78
24812-762
7.71
24813-064
7.86
24813-492
7.68
24813-892
7.69
24812-408
7.70
24812-764
7.71
24813-164
7.72
24813-505
7.86
24813-908
7.69
24812-410
7.70
24812-771
7.71
24813-171
7.72
24813-506
7.86
24813-910
7.69
24812-412
7.70
24812-778
7.71
24813-208
7.68
24813-507
7.86
24813-912
7.69
24812-414
7.70
24812-792
7.71
24813-210
7.68
24813-510
7.86
24813-914
7.69
24812-421
7.70
24812-808
7.71
24813-212
7.68
24813-512
7.86
24813-921
7.69
24812-428
7.70
24812-810
7.71
24813-214
7.68
24813-514
7.86
24813-928
7.69
24812-442
7.70
24812-812
7.71
24813-221
7.68
24813-555
7.86
24813-942
7.69
24812-458
7.70
24812-814
7.71
24813-228
7.68
24813-556
7.86
24813-958
7.69
24812-460
7.70
24812-821
7.71
24813-242
7.68
24813-557
7.86
24813-960
7.69
24812-462
7.70
24812-828
7.71
24813-258
7.68
24813-560
7.86
24813-962
7.69
24812-464
7.70
24812-842
7.71
24813-260
7.68
24813-562
7.86
24813-964
7.69
24812-471
7.70
24812-858
7.71
24813-262
7.68
24813-564
7.86
24813-971
7.69
24812-478
7.70
24812-860
7.71
24813-264
7.68
24813-614
7.72
24813-978
7.69
24812-492
7.70
24812-862
7.71
24813-271
7.68
24813-621
7.72
24813-992
7.69
24812-501
7.78
24812-864
7.71
24813-278
7.68
24813-664
7.72
24814-008
7.100
24812-505
7.87
24812-871
7.71
24813-292
7.68
24813-671
7.72
24814-010
7.100
24812-506
7.87
24812-878
7.71
24813-308
7.68
24813-708
7.69
24814-011
7.100
24812-507
7.87
24812-892
7.71
24813-310
7.68
24813-710
7.69
24814-014
7.100
24812-510
7.87
24812-908
7.71
24813-312
7.68
24813-712
7.69
24814-024
7.101
24812-512
7.87
24812-910
7.71
24813-314
7.68
24813-714
7.69
24814-025
7.101
24812-514
7.87
24812-912
7.71
24813-321
7.68
24813-721
7.69
24814-027
7.101
24812-555
7.87
24812-914
7.71
24813-328
7.68
24813-728
7.69
25127-575
1.311
24812-556
7.87
24812-921
7.71
24813-342
7.68
24813-742
7.69
25127-995
1.103
24812-557
7.87
24812-928
7.71
24813-358
7.68
24813-758
7.69
25127-995
1.107
24812-560
7.87
24812-942
7.71
24813-360
7.68
24813-760
7.69
25127-995
1.12
24812-562
7.87
24812-958
7.71
24813-362
7.68
24813-762
7.69
25127-995
1.127
24812-564
7.87
24812-960
7.71
24813-364
7.68
24813-764
7.69
25127-995
1.129
24812-600
7.79
24812-962
7.71
24813-371
7.68
24813-771
7.69
25127-995
1.13
24812-612
7.73
24812-964
7.71
24813-378
7.68
24813-778
7.69
25127-995
1.131
24812-614
7.73
24812-971
7.71
24813-392
7.68
24813-792
7.69
25127-995
1.14
24812-621
7.73
24812-978
7.71
24813-408
7.68
24813-808
7.69
25127-995
1.15
24812-662
7.73
24812-992
7.71
24813-410
7.68
24813-810
7.69
25127-995
1.160
24812-664
7.73
24813-005
7.86
24813-412
7.68
24813-812
7.69
25127-995
1.161
24812-671
7.73
24813-006
7.86
24813-414
7.68
24813-814
7.69
25127-995
1.162
24812-708
7.71
24813-007
7.86
24813-421
7.68
24813-821
7.69
25127-995
1.182
24812-710
7.71
24813-010
7.86
24813-428
7.68
24813-828
7.69
25127-995
1.183
24812-712
7.71
24813-012
7.86
24813-442
7.68
24813-842
7.69
25127-995
1.184
24812-714
7.71
24813-014
7.86
24813-458
7.68
24813-858
7.69
25127-995
1.228
12.47
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
25127-995
1.229
25230-024
1.247
25230-175
1.260
25230-379
1.263
26230-029
1.246
25127-995
1.230
25230-024
1.261
25230-176
1.260
25230-430
1.248
26230-029
1.261
25127-995
1.232
25230-024
1.262
25230-177
1.260
25230-430
1.263
26230-030
1.247
25127-995
1.238
25230-025
1.246
25230-178
1.260
25230-434
1.248
26230-030
1.262
25127-995
1.30
25230-025
1.261
25230-179
1.260
25230-434
1.263
26230-070
1.260
25127-995
1.31
25230-026
1.246
25230-223
1.260
25230-439
1.248
26230-071
1.260
25127-995
1.32
25230-026
1.247
25230-224
1.260
25230-439
1.263
26230-072
1.260
25127-995
1.41
25230-026
1.261
25230-225
1.260
25230-448
1.248
26230-073
1.260
25127-995
1.56
25230-026
1.262
25230-226
1.260
25230-448
1.263
26230-074
1.260
25127-995
1.57
25230-027
1.246
25230-227
1.260
25230-452
1.248
26230-075
1.260
25127-995
1.58
25230-027
1.247
25230-228
1.260
25230-452
1.263
26230-076
1.260
25127-995
1.71
25230-027
1.261
25230-229
1.260
25230-457
1.248
26230-077
1.260
25127-995
1.86
25230-027
1.262
25230-273
1.260
25230-457
1.263
26230-078
1.260
25127-995
1.87
25230-028
1.246
25230-274
1.260
25230-461
1.248
26230-079
1.260
25127-995
1.99
25230-028
1.247
25230-275
1.260
25230-461
1.263
26230-120
1.260
25127-995
2.28
25230-028
1.261
25230-276
1.260
26230-020
1.261
26230-121
1.260
25127-997
1.111
25230-028
1.262
25230-277
1.260
26230-021
1.246
26230-122
1.260
25127-997
1.140
25230-029
1.246
25230-278
1.260
26230-021
1.261
26230-123
1.260
25127-997
1.169
25230-029
1.261
25230-279
1.260
26230-022
1.246
26230-124
1.260
25127-997
1.19
25230-030
1.247
25230-323
1.260
26230-022
1.247
26230-125
1.260
25127-997
1.191
25230-030
1.262
25230-324
1.260
26230-022
1.261
26230-126
1.260
25127-997
1.337
25230-070
1.260
25230-325
1.260
26230-022
1.262
26230-127
1.260
25127-997
1.44
25230-071
1.260
25230-326
1.260
26230-023
1.246
26230-128
1.260
25127-997
1.61
25230-072
1.260
25230-327
1.260
26230-023
1.247
26230-129
1.260
25127-997
1.75
25230-073
1.260
25230-328
1.260
26230-023
1.261
26230-172
1.260
25127-997
1.88
25230-074
1.260
25230-329
1.260
26230-023
1.262
26230-173
1.260
25230-001
1.264
25230-075
1.260
25230-370
1.263
26230-024
1.246
26230-174
1.260
25230-002
1.264
25230-076
1.260
25230-371
1.248
26230-024
1.247
26230-175
1.260
25230-003
1.264
25230-077
1.260
25230-371
1.263
26230-024
1.261
26230-176
1.260
25230-010
1.264
25230-078
1.260
25230-372
1.248
26230-024
1.262
26230-177
1.260
25230-011
1.264
25230-079
1.260
25230-372
1.263
26230-025
1.246
26230-178
1.260
25230-012
1.264
25230-120
1.260
25230-373
1.248
26230-025
1.261
26230-179
1.260
25230-020
1.261
25230-121
1.260
25230-373
1.263
26230-026
1.246
26230-223
1.260
25230-021
1.246
25230-122
1.260
25230-374
1.248
26230-026
1.247
26230-224
1.260
25230-021
1.261
25230-123
1.260
25230-374
1.263
26230-026
1.261
26230-225
1.260
25230-022
1.246
25230-124
1.260
25230-375
1.248
26230-026
1.262
26230-226
1.260
25230-022
1.247
25230-125
1.260
25230-375
1.263
26230-027
1.246
26230-227
1.260
25230-022
1.261
25230-126
1.260
25230-376
1.248
26230-027
1.247
26230-228
1.260
25230-022
1.262
25230-127
1.260
25230-376
1.263
26230-027
1.261
26230-229
1.260
25230-023
1.246
25230-128
1.260
25230-377
1.248
26230-027
1.262
26230-273
1.260
25230-023
1.247
25230-129
1.260
25230-377
1.263
26230-028
1.246
26230-274
1.260
25230-023
1.261
25230-172
1.260
25230-378
1.248
26230-028
1.247
26230-275
1.260
25230-023
1.262
25230-173
1.260
25230-378
1.263
26230-028
1.261
26230-276
1.260
25230-024
1.246
25230-174
1.260
25230-379
1.248
26230-028
1.262
26230-277
1.260
12.48
www.schroff.biz E 05/2016
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
26230-278
1.260
27230-002
1.261
27230-079
1.266
27230-147
1.266
28230-070
1.258
26230-279
1.260
27230-003
1.246
27230-081
1.265
27230-148
1.250
28230-074
1.258
26230-323
1.260
27230-003
1.261
27230-082
1.265
27230-148
1.266
28230-079
1.258
26230-324
1.260
27230-004
1.246
27230-083
1.265
27230-200
1.251
28230-088
1.258
26230-325
1.260
27230-004
1.261
27230-085
1.265
27230-200
1.267
28230-092
1.258
26230-326
1.260
27230-005
1.246
27230-086
1.265
27230-201
1.251
28230-097
1.258
26230-327
1.260
27230-005
1.261
27230-087
1.265
27230-201
1.267
28230-101
1.258
26230-328
1.260
27230-006
1.246
27230-091
1.249
27230-202
1.251
28230-126
1.258
26230-329
1.260
27230-006
1.261
27230-091
1.266
27230-202
1.267
28230-130
1.258
26230-370
1.263
27230-007
1.246
27230-092
1.249
27230-203
1.251
28230-134
1.258
26230-371
1.248
27230-007
1.261
27230-092
1.266
27230-203
1.267
28230-139
1.258
26230-371
1.263
27230-008
1.246
27230-093
1.249
27230-204
1.251
28230-148
1.258
26230-372
1.248
27230-008
1.261
27230-093
1.266
27230-204
1.267
28230-152
1.258
26230-372
1.263
27230-009
1.246
27230-100
1.259
27230-205
1.251
28230-157
1.258
26230-373
1.248
27230-009
1.261
27230-102
1.252
27230-205
1.267
28230-162
1.258
26230-373
1.263
27230-010
1.246
27230-102
1.268
27230-206
1.251
28230-310
1.258
26230-374
1.248
27230-010
1.261
27230-103
1.252
27230-206
1.267
28230-314
1.258
26230-374
1.263
27230-051
1.253
27230-103
1.268
27230-207
1.251
28230-319
1.258
26230-375
1.248
27230-051
1.267
27230-104
1.252
27230-207
1.267
28230-328
1.258
26230-375
1.263
27230-052
1.253
27230-104
1.268
27230-208
1.251
28230-332
1.258
26230-376
1.248
27230-052
1.267
27230-110
1.259
27230-208
1.267
28230-337
1.258
26230-376
1.263
27230-053
1.253
27230-111
1.250
27230-209
1.251
28230-341
1.258
26230-377
1.248
27230-053
1.267
27230-111
1.266
27230-209
1.267
28230-370
1.258
26230-377
1.263
27230-060
1.247
27230-112
1.258
28127-001
1.298
28230-374
1.258
26230-378
1.248
27230-060
1.262
27230-114
1.249
28127-001
1.311
28230-379
1.258
26230-378
1.263
27230-061
1.247
27230-114
1.266
28127-240
1.196
28230-388
1.258
26230-379
1.248
27230-061
1.262
27230-115
1.260
28127-241
1.174
28230-392
1.258
26230-379
1.263
27230-065
1.264
27230-116
1.263
28127-281
1.134
28230-397
1.258
26230-430
1.248
27230-065
1.265
27230-121
1.251
28127-281
1.165
28230-401
1.258
26230-430
1.263
27230-066
1.244
27230-121
1.267
28127-281
1.187
28230-430
1.258
26230-434
1.248
27230-066
1.245
27230-122
1.251
28127-281
1.34
28230-434
1.258
26230-434
1.263
27230-066
1.264
27230-122
1.267
28230-001
1.258
28230-439
1.258
26230-439
1.248
27230-067
1.259
27230-123
1.251
28230-004
1.258
28230-448
1.258
26230-439
1.263
27230-068
1.259
27230-123
1.267
28230-007
1.258
28230-452
1.258
26230-448
1.248
27230-069
1.259
27230-125
1.252
28230-011
1.258
28230-457
1.258
26230-448
1.263
27230-070
1.250
27230-125
1.268
28230-015
1.258
28230-461
1.258
26230-452
1.248
27230-070
1.266
27230-126
1.252
28230-020
1.258
29001-019
11.6
26230-452
1.263
27230-071
1.250
27230-126
1.268
28230-029
1.258
29090-001
11.6
26230-457
1.248
27230-071
1.266
27230-143
1.258
28230-033
1.258
29090-002
11.6
26230-457
1.263
27230-072
1.250
27230-144
1.255
28230-042
1.258
30118-267
4.65
26230-461
1.248
27230-072
1.266
27230-144
1.258
28230-048
1.258
30118-299
3.4
26230-461
1.263
27230-077
1.265
27230-146
1.250
28230-060
1.258
30118-301
3.4
27230-001
1.261
27230-078
1.265
27230-146
1.266
28230-063
1.258
30118-302
3.4
27230-002
1.246
27230-079
1.249
27230-147
1.250
28230-066
1.258
30118-303
3.4
SCHROFF.PENTAIR.CO.UK
12.49
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
30118-304
3.4
30118-962
3.6
30807-485
6.48
30809-635
7.91
30818-274
6.48
30118-305
3.4
30118-963
3.6
30807-485
7.4
30809-636
7.91
30818-274
7.4
30118-306
3.4
30118-964
3.6
30807-487
6.48
30809-637
7.91
30818-275
6.48
30118-307
3.4
30219-098
3.4
30807-487
7.4
30809-638
7.91
30818-275
7.4
30118-308
3.4
30219-101
3.4
30807-494
6.48
30809-639
7.91
30818-276
6.48
30118-309
3.4
30219-104
3.4
30807-494
7.4
30809-640
7.91
30818-276
7.4
30118-315
4.65
30219-107
3.4
30807-496
6.48
30809-641
7.91
30818-277
6.48
30118-328
3.16
30219-110
3.4
30807-496
7.4
30809-642
7.91
30818-277
7.4
30118-329
3.16
30219-113
3.4
30807-501
6.48
30809-643
7.91
30818-279
6.48
30118-330
3.16
30219-137
3.4
30807-501
7.4
30809-644
7.91
30818-279
7.4
30118-331
3.16
30219-138
3.4
30807-506
6.48
30809-645
7.91
30818-281
6.48
30118-332
3.16
30219-143
3.4
30807-506
7.4
30809-646
7.91
30818-281
7.4
30118-334
3.16
30219-144
3.4
30807-508
6.48
30809-667
7.91
30818-282
6.48
30118-335
3.16
30219-161
3.2
30807-508
7.4
30809-668
7.91
30818-282
7.4
30118-336
3.16
30219-162
3.2
30807-509
6.48
30809-669
7.91
30818-289
6.48
30118-338
3.16
30219-163
3.2
30807-509
7.4
30809-670
7.91
30818-289
7.4
30118-341
7.10
30219-164
3.2
30807-510
6.48
30809-671
7.91
30818-296
6.48
30118-342
7.10
30219-165
3.2
30807-510
7.4
30809-672
7.91
30818-296
7.4
30118-343
7.10
30219-166
3.2
30807-752
7.4
30809-673
7.91
30818-310
6.48
30118-344
7.10
30225-089
5.105
30807-753
6.48
30809-674
7.91
30818-310
7.4
30118-345
7.10
30225-090
5.105
30807-753
7.4
30809-675
7.91
30818-331
6.48
30118-346
7.10
30225-091
5.105
30807-755
7.4
30809-676
7.91
30818-331
7.4
30118-347
7.10
30225-092
5.105
30807-757
6.48
30809-677
7.91
30818-352
6.48
30118-348
7.10
30502-051
5.110
30807-757
7.4
30809-678
7.91
30818-352
7.4
30118-349
7.10
30502-191
5.112
30807-758
6.48
30809-679
7.91
30818-434
6.48
30118-350
7.10
30702-044
3.6
30807-758
7.4
30809-680
7.91
30818-434
7.4
30118-351
7.10
30702-045
3.6
30807-764
6.48
30809-681
7.91
30818-518
6.48
30118-352
7.10
30702-046
3.6
30807-764
7.4
30809-682
7.91
30818-518
7.4
30118-353
7.10
30702-047
3.6
30807-766
6.48
30809-698
7.91
30818-519
7.4
30118-354
7.10
30702-048
3.6
30807-766
7.4
30809-699
7.91
30818-520
7.4
30118-355
7.11
30702-049
3.6
30807-771
6.48
30809-700
7.92
30818-521
7.4
30118-360
4.65
30702-056
3.6
30807-771
7.4
30809-701
7.92
30818-522
6.48
30118-802
3.15
30702-057
3.6
30807-776
6.48
30810-432
6.48
30818-522
7.4
30118-803
3.15
30702-058
3.6
30807-776
7.4
30810-432
7.4
30818-524
6.48
30118-948
3.4
30807-416
6.48
30807-777
7.4
30810-433
6.48
30818-524
7.4
30118-949
3.4
30807-416
7.4
30807-778
7.4
30810-433
7.4
30818-526
6.48
30118-950
3.4
30807-481
6.48
30807-779
7.4
30812-002
11.9
30818-526
7.4
30118-951
3.4
30807-481
7.4
30807-780
7.4
30814-513
6.132
30818-528
6.48
30118-952
3.4
30807-482
6.48
30808-067
6.48
30818-271
6.48
30818-528
7.4
30118-953
3.4
30807-482
7.4
30808-067
7.4
30818-271
7.4
30818-530
6.48
30118-954
3.4
30807-483
6.48
30808-871
7.106
30818-272
6.48
30818-530
7.4
30118-955
3.4
30807-483
7.4
30808-871
7.56
30818-272
7.4
30818-535
6.48
30118-956
3.4
30807-484
6.48
30809-428
7.55
30818-273
6.48
30818-535
7.4
30118-957
3.4
30807-484
7.4
30809-571
7.61
30818-273
7.4
30818-542
6.48
12.50
SCHROFF Main catalogue
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
30818-542
7.4
30823-024
5.82
30838-046
7.4
30838-183
7.4
30846-683
6.49
30818-556
6.48
30823-027
5.82
30838-047
6.48
30838-204
6.48
30846-683
7.5
30818-556
7.4
30823-033
5.82
30838-047
7.4
30838-204
7.4
30846-771
6.49
30818-577
6.48
30823-036
5.82
30838-049
6.48
30840-021
5.37
30846-771
7.5
30818-577
7.4
30823-045
5.82
30838-049
7.4
30840-021
5.64
30846-859
6.49
30818-598
6.48
30823-209
5.82
30838-051
6.48
30840-021
5.94
30846-859
7.5
30818-598
7.4
30823-215
5.82
30838-051
7.4
30840-021
6.59
30846-864
6.49
30818-741
6.48
30823-224
5.82
30838-053
6.48
30840-033
5.37
30846-864
7.5
30818-741
7.4
30823-227
5.82
30838-053
7.4
30840-033
5.64
30846-865
6.49
30818-747
6.48
30823-230
5.82
30838-060
6.48
30840-033
5.94
30846-865
7.5
30818-747
7.4
30823-254
5.82
30838-060
7.4
30840-033
6.59
30847-461
6.48
30819-604
6.132
30823-257
5.82
30838-067
6.48
30840-045
5.37
30847-461
7.4
30819-763
6.34
30823-260
5.82
30838-067
7.4
30840-045
5.94
30847-463
6.48
30819-783
5.35
30823-269
5.82
30838-081
6.48
30840-045
6.59
30847-464
6.48
30819-783
5.69
30823-272
5.82
30838-081
7.4
30840-057
5.37
30847-465
6.48
30819-783
5.91
30823-284
5.82
30838-102
6.48
30840-057
5.64
30847-465
7.4
30819-783
6.34
30823-512
5.82
30838-102
7.4
30840-057
5.94
30847-470
6.48
30819-808
5.35
30823-515
5.82
30838-123
6.48
30840-057
6.59
30847-470
7.4
30819-808
5.69
30823-518
5.82
30838-123
7.4
30845-189
6.104
30847-471
6.48
30819-808
5.91
30823-521
5.82
30838-124
6.48
30845-189
6.33
30847-471
7.4
30819-808
6.34
30828-055
6.131
30838-124
7.4
30845-197
5.35
30847-472
5.39
30821-589
6.121
30828-058
6.131
30838-125
6.48
30845-197
5.68
30847-472
5.70
30821-589
6.123
30828-061
6.131
30838-125
7.4
30845-197
6.104
30847-472
5.95
30822-025
6.34
30828-067
6.131
30838-126
6.48
30845-197
6.33
30847-472
6.48
30822-033
5.35
30828-070
6.131
30838-126
7.4
30845-209
6.104
30847-472
6.57
30822-033
5.69
30828-073
6.131
30838-127
6.48
30845-209
6.33
30847-472
7.4
30822-033
5.91
30828-076
6.131
30838-127
7.4
30845-211
5.35
30847-476
6.48
30822-033
6.34
30828-082
6.131
30838-128
6.48
30845-211
5.68
30847-480
6.48
30822-045
6.34
30828-085
6.131
30838-128
7.4
30845-211
6.104
30847-482
6.48
30822-047
5.35
30828-088
6.131
30838-130
6.48
30845-211
6.33
30847-484
6.48
30822-047
5.69
30828-091
6.131
30838-130
7.4
30845-232
5.35
30847-556
6.48
30822-047
5.91
30828-097
6.131
30838-132
6.48
30845-232
5.68
30847-556
7.4
30822-047
6.34
30828-128
6.132
30838-132
7.4
30845-232
6.104
30847-602
7.54
30822-065
5.35
30828-165
6.132
30838-134
6.48
30845-232
6.33
30847-603
7.54
30822-065
5.69
30828-174
6.132
30838-134
7.4
30845-253
5.35
30847-604
7.54
30822-065
5.91
30829-001
7.44
30838-136
6.48
30845-253
5.68
30847-605
7.54
30822-065
6.34
30829-007
7.44
30838-136
7.4
30845-253
6.104
30847-606
7.54
30822-089
5.35
30838-043
6.48
30838-141
6.48
30845-253
6.33
30847-607
7.54
30822-089
5.69
30838-043
7.4
30838-141
7.4
30846-588
6.49
30847-608
7.54
30822-089
5.91
30838-044
6.48
30838-148
6.48
30846-588
7.5
30847-609
7.54
30822-089
6.34
30838-044
7.4
30838-148
7.4
30846-676
6.49
30847-625
7.54
30822-166
9.16
30838-045
6.48
30838-162
6.48
30846-676
7.5
30847-626
7.54
30823-015
5.82
30838-045
7.4
30838-162
7.4
30846-681
6.49
30847-627
7.54
30823-021
5.82
30838-046
6.48
30838-183
6.48
30846-682
6.49
30847-628
7.54
12.51
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
30847-630
7.54
30848-327
7.19
30848-380
6.50
30849-010
5.22
30849-140
5.70
30847-631
7.54
30848-327
7.33
30848-380
7.7
30849-010
5.55
30849-140
5.95
30847-659
7.40
30848-328
7.19
30848-381
6.50
30849-011
5.22
30849-140
6.109
30847-660
7.40
30848-328
7.33
30848-381
7.7
30849-014
5.22
30849-140
6.57
30847-661
7.40
30848-329
7.19
30848-382
6.50
30849-014
5.55
30849-153
7.29
30847-662
7.40
30848-329
7.33
30848-382
7.7
30849-015
5.22
30849-154
7.29
30847-663
7.40
30848-330
7.19
30848-383
6.50
30849-015
5.55
30849-155
7.29
30847-664
7.40
30848-330
7.33
30848-383
7.7
30849-016
5.22
30849-156
7.29
30847-665
7.40
30848-331
7.19
30848-386
6.50
30849-016
5.55
30849-157
7.29
30847-666
7.40
30848-331
7.33
30848-386
7.7
30849-021
5.22
30849-158
7.29
30847-667
7.40
30848-333
7.19
30848-387
6.50
30849-021
5.55
30849-171
5.22
30847-668
7.40
30848-333
7.33
30848-387
7.7
30849-022
5.22
30849-172
5.22
30847-669
7.40
30848-335
7.19
30848-426
7.19
30849-022
5.55
30849-173
5.22
30847-670
7.40
30848-335
7.33
30848-427
7.19
30849-023
5.22
30849-402
8.60
30847-671
7.40
30848-336
7.19
30848-428
7.19
30849-023
5.55
30849-403
8.60
30847-672
7.40
30848-336
7.33
30848-429
7.19
30849-028
5.22
30849-404
8.60
30848-300
7.19
30848-337
7.19
30848-430
7.19
30849-028
5.55
30849-405
8.60
30848-300
7.33
30848-337
7.33
30848-431
7.19
30849-029
5.22
30849-406
8.60
30848-301
7.19
30848-338
7.19
30848-432
7.19
30849-029
5.55
30849-407
8.60
30848-301
7.33
30848-338
7.33
30848-461
7.40
30849-030
5.22
30849-658
8.60
30848-304
7.19
30848-339
7.19
30848-463
7.40
30849-030
5.55
30849-670
8.60
30848-304
7.33
30848-339
7.33
30848-465
7.40
30849-035
5.22
30849-682
8.60
30848-305
7.19
30848-340
7.19
30848-466
7.40
30849-035
5.55
30849-694
8.60
30848-305
7.33
30848-340
7.33
30848-467
7.40
30849-036
5.22
30849-708
8.60
30848-312
7.19
30848-342
7.19
30848-468
7.40
30849-036
5.55
30849-714
8.60
30848-312
7.33
30848-342
7.33
30848-470
7.40
30849-037
5.22
30849-749
7.10
30848-313
7.19
30848-344
7.19
30848-472
7.40
30849-037
5.55
30849-750
7.10
30848-313
7.33
30848-344
7.33
30848-473
7.40
30849-086
7.54
30849-751
7.10
30848-314
7.19
30848-354
6.50
30848-474
7.40
30849-087
7.54
30849-752
7.10
30848-314
7.33
30848-354
7.7
30848-867
7.19
30849-088
7.54
30849-753
7.10
30848-315
7.19
30848-355
6.50
30848-869
7.19
30849-089
7.54
30849-754
7.10
30848-315
7.33
30848-355
7.7
30848-985
7.19
30849-090
7.54
30849-755
7.10
30848-316
7.19
30848-356
6.50
30849-001
6.50
30849-091
7.54
30850-354
5.57
30848-316
7.33
30848-356
7.7
30849-001
7.7
30849-092
7.54
30860-501
6.120
30848-317
7.19
30848-357
6.50
30849-002
6.50
30849-093
7.54
30860-502
6.120
30848-317
7.33
30848-357
7.7
30849-002
7.7
30849-097
7.54
30860-503
6.120
30848-318
7.19
30848-358
6.50
30849-004
6.50
30849-098
7.54
30860-504
6.120
30848-318
7.33
30848-358
7.7
30849-004
7.7
30849-099
7.54
30860-505
6.120
30848-319
7.19
30848-359
6.50
30849-007
5.22
30849-100
7.54
30860-510
6.120
30848-319
7.33
30848-359
7.7
30849-007
5.55
30849-101
7.54
30860-511
6.120
30848-320
7.19
30848-378
6.50
30849-008
5.22
30849-102
7.54
30860-512
6.120
30848-320
7.33
30848-378
7.7
30849-008
5.55
30849-103
7.54
30860-513
6.120
30848-321
7.19
30848-379
6.50
30849-009
5.22
30849-104
7.54
30860-514
6.120
30848-321
7.33
30848-379
7.7
30849-009
5.55
30849-140
5.39
30860-519
6.122
12.52
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
30860-520
6.122
34560-185
6.21
34560-287
6.21
34560-495
6.20
34560-728
6.100
30860-521
6.122
34560-187
6.20
34560-289
6.20
34560-495
6.21
34560-728
6.30
30925-001
11.11
34560-187
6.21
34560-289
6.21
34560-496
6.20
34560-740
6.100
30925-002
11.11
34560-189
6.20
34560-291
6.20
34560-496
6.21
34560-740
6.30
30925-003
11.11
34560-189
6.21
34560-291
6.21
34560-501
6.100
34560-742
5.32
30925-004
11.11
34560-191
6.20
34560-293
6.20
34560-501
6.30
34560-742
5.67
30925-005
11.11
34560-191
6.21
34560-293
6.21
34560-520
6.100
34560-742
5.89
30925-006
11.11
34560-193
6.20
34560-295
6.20
34560-520
6.30
34560-742
6.100
31006-677
9.6
34560-193
6.21
34560-295
6.21
34560-528
5.32
34560-742
6.30
31591-422
8.15
34560-195
6.20
34560-301
6.28
34560-528
5.67
34560-763
5.32
31596-423
8.15
34560-195
6.21
34560-301
6.99
34560-528
5.89
34560-763
5.67
31596-575
8.15
34560-201
6.28
34560-320
6.28
34560-528
6.100
34560-763
5.89
31596-576
8.15
34560-201
6.99
34560-320
6.99
34560-528
6.30
34560-763
6.100
31596-791
8.13
34560-220
6.28
34560-328
5.31
34560-540
6.100
34560-763
6.30
31596-792
8.13
34560-220
6.99
34560-328
6.28
34560-540
6.30
34560-784
5.32
31596-899
8.13
34560-228
5.31
34560-328
6.99
34560-542
5.32
34560-784
5.57
31596-900
8.13
34560-228
5.54
34560-340
6.28
34560-542
5.67
34560-784
5.67
32405-024
2.13
34560-228
5.67
34560-340
6.99
34560-542
5.89
34560-784
5.89
32405-025
2.13
34560-228
5.89
34560-342
5.31
34560-542
6.100
34560-784
6.100
32405-026
2.13
34560-228
6.28
34560-342
6.28
34560-542
6.30
34560-784
6.30
32405-027
2.13
34560-228
6.99
34560-342
6.99
34560-563
5.32
34560-785
6.20
32405-028
2.13
34560-240
6.28
34560-363
5.31
34560-563
5.67
34560-785
6.21
32405-029
2.13
34560-240
6.99
34560-363
6.28
34560-563
5.89
34560-787
6.20
32405-033
2.13
34560-242
5.31
34560-363
6.99
34560-563
6.100
34560-787
6.21
32405-034
2.13
34560-242
5.54
34560-384
5.31
34560-563
6.30
34560-789
6.20
32405-035
2.13
34560-242
5.67
34560-384
6.28
34560-584
5.32
34560-789
6.21
32405-038
2.13
34560-242
5.89
34560-384
6.99
34560-584
5.67
34560-791
6.20
32405-039
2.13
34560-242
6.28
34560-401
6.30
34560-584
5.89
34560-791
6.21
32405-040
2.13
34560-242
6.99
34560-420
6.30
34560-584
6.100
34560-793
6.20
34560-001
6.28
34560-263
5.31
34560-428
6.30
34560-584
6.30
34560-793
6.21
34560-020
6.28
34560-263
5.54
34560-440
6.30
34560-601
6.30
34560-801
6.30
34560-028
6.28
34560-263
5.67
34560-442
6.30
34560-620
6.30
34560-820
6.30
34560-040
6.28
34560-263
5.89
34560-463
6.30
34560-628
6.30
34560-828
6.30
34560-042
6.28
34560-263
6.28
34560-484
6.30
34560-640
6.30
34560-840
6.30
34560-063
6.28
34560-263
6.99
34560-485
6.20
34560-642
6.30
34560-842
6.30
34560-084
6.28
34560-284
5.31
34560-485
6.21
34560-663
6.30
34560-863
6.30
34560-101
6.28
34560-284
5.54
34560-487
6.20
34560-684
6.30
34560-884
6.30
34560-120
6.28
34560-284
5.67
34560-487
6.21
34560-701
6.100
34560-891
6.39
34560-128
6.28
34560-284
5.89
34560-489
6.20
34560-701
6.30
34560-892
6.39
34560-140
6.28
34560-284
6.28
34560-489
6.21
34560-720
6.100
34560-893
6.39
34560-142
6.28
34560-284
6.99
34560-491
6.20
34560-720
6.30
34560-894
6.39
34560-163
6.28
34560-285
6.20
34560-491
6.21
34560-728
5.32
34560-900
6.39
34560-184
6.28
34560-285
6.21
34560-493
6.20
34560-728
5.67
34560-920
6.100
34560-185
6.20
34560-287
6.20
34560-493
6.21
34560-728
5.89
34560-920
6.30
12.53
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
34560-928
5.32
34561-128
5.33
34561-340
6.33
34561-584
6.102
34562-753
6.59
34560-928
5.67
34561-128
6.101
34561-342
5.35
34561-584
6.32
34562-754
5.37
34560-928
5.89
34561-128
6.31
34561-342
5.68
34561-750
6.47
34562-754
5.94
34560-928
6.100
34561-140
6.101
34561-342
5.90
34561-750
6.83
34562-754
6.59
34560-928
6.30
34561-140
6.31
34561-342
6.104
34561-752
6.47
34562-755
5.37
34560-940
6.100
34561-142
5.33
34561-342
6.33
34561-752
6.83
34562-755
5.94
34560-940
6.30
34561-142
6.101
34561-363
5.35
34561-763
6.47
34562-755
6.59
34560-942
5.32
34561-142
6.31
34561-363
5.68
34561-763
6.83
34562-756
5.37
34560-942
5.67
34561-163
5.33
34561-363
5.90
34561-764
6.47
34562-756
5.94
34560-942
5.89
34561-163
6.101
34561-363
6.104
34561-764
6.83
34562-756
6.59
34560-942
6.100
34561-163
6.31
34561-363
6.33
34561-777
6.90
34562-757
5.37
34560-942
6.30
34561-184
5.33
34561-384
5.35
34561-779
6.90
34562-757
5.94
34560-963
5.32
34561-184
6.101
34561-384
5.68
34562-745
5.37
34562-757
6.59
34560-963
5.67
34561-184
6.31
34561-384
5.90
34562-745
5.94
34562-758
5.37
34560-963
5.89
34561-185
6.24
34561-384
6.104
34562-745
6.59
34562-758
5.94
34560-963
6.100
34561-187
6.24
34561-384
6.33
34562-746
5.37
34562-758
6.59
34560-963
6.30
34561-189
6.24
34561-484
5.35
34562-746
5.64
34562-759
5.37
34560-984
5.32
34561-197
6.24
34561-484
5.68
34562-746
5.94
34562-759
5.94
34560-984
5.67
34561-201
6.101
34561-484
5.90
34562-746
6.59
34562-759
6.59
34560-984
5.89
34561-201
6.31
34561-484
6.104
34562-747
5.37
34562-760
5.37
34560-984
6.100
34561-220
6.101
34561-484
6.33
34562-747
5.64
34562-760
5.64
34560-984
6.30
34561-220
6.31
34561-485
6.24
34562-747
5.94
34562-760
5.94
34561-001
6.101
34561-228
5.33
34561-487
6.24
34562-747
6.59
34562-760
6.59
34561-001
6.31
34561-228
6.101
34561-489
6.24
34562-748
5.37
34562-761
5.36
34561-020
6.101
34561-228
6.31
34561-497
6.24
34562-748
5.64
34562-761
5.75
34561-020
6.31
34561-240
6.101
34561-501
5.34
34562-748
5.94
34562-761
6.60
34561-028
5.33
34561-240
6.31
34561-501
6.102
34562-748
6.59
34562-762
5.36
34561-028
6.101
34561-242
5.33
34561-501
6.32
34562-749
5.37
34562-762
5.75
34561-028
6.31
34561-242
6.101
34561-520
5.34
34562-749
5.94
34562-762
6.60
34561-040
6.101
34561-242
6.31
34561-520
6.102
34562-749
6.59
34562-763
5.36
34561-040
6.31
34561-263
5.33
34561-520
6.32
34562-750
5.37
34562-763
5.75
34561-042
5.33
34561-263
6.101
34561-528
5.34
34562-750
5.64
34562-763
6.60
34561-042
6.101
34561-263
6.31
34561-528
6.102
34562-750
5.94
34562-764
5.36
34561-042
6.31
34561-284
5.33
34561-528
6.32
34562-750
6.59
34562-764
5.75
34561-063
5.33
34561-284
6.101
34561-540
5.34
34562-751
5.37
34562-764
6.60
34561-063
6.101
34561-284
6.31
34561-540
6.102
34562-751
5.64
34562-823
5.43
34561-063
6.31
34561-320
6.104
34561-540
6.32
34562-751
5.94
34562-823
5.75
34561-084
5.33
34561-320
6.33
34561-542
5.34
34562-751
6.59
34562-823
5.97
34561-084
6.101
34561-328
5.35
34561-542
6.102
34562-752
5.37
34562-823
6.61
34561-084
6.31
34561-328
5.68
34561-542
6.32
34562-752
5.64
34562-824
5.43
34561-101
6.101
34561-328
5.90
34561-563
5.34
34562-752
5.94
34562-824
5.75
34561-101
6.31
34561-328
6.104
34561-563
6.102
34562-752
6.59
34562-824
5.97
34561-120
6.101
34561-328
6.33
34561-563
6.32
34562-753
5.37
34562-824
6.61
34561-120
6.31
34561-340
6.104
34561-584
5.34
34562-753
5.94
34562-826
5.43
12.54
Appendix
Part no.
Page
Part no.
Page
Part no.
Part no.
Page
34562-826
5.75
34562-881
6.94
34564-881
6.106
34566-528
34562-826
5.97
34562-882
5.41
34564-881
6.37
34566-540
6.100
34579-234
6.41
6.100
34579-235
6.41
34562-826
6.61
34562-882
5.74
34564-882
5.41
34566-542
6.100
34579-300
6.20
34562-827
5.43
34562-882
5.93
34564-882
5.74
34566-563
6.100
34579-300
6.21
34562-827
5.75
34562-882
6.106
34564-882
5.93
34566-584
6.100
34812-100
7.76
34562-827
5.97
34562-882
6.37
34564-882
6.106
34566-701
6.100
34812-102
7.76
34562-827
6.61
34562-883
5.41
34564-882
6.37
34566-720
6.100
34812-103
7.76
34562-833
5.43
34562-883
5.74
34564-883
5.41
34566-728
6.100
34812-108
7.75
34562-833
5.75
34562-883
5.93
34564-883
5.74
34566-740
6.100
34812-110
7.75
34562-833
5.97
34562-883
6.106
34564-883
5.93
34566-742
6.100
34812-112
7.75
34562-833
6.61
34562-883
6.37
34564-883
6.106
34566-763
6.100
34812-114
7.75
34562-834
5.43
34562-884
5.41
34564-883
6.37
34566-784
6.100
34812-121
7.75
34562-834
5.75
34562-884
5.74
34564-884
5.41
34571-605
5.21
34812-128
7.75
34562-834
5.97
34562-884
5.93
34564-884
5.74
34571-606
5.21
34812-142
7.75
34562-834
6.61
34562-884
6.106
34564-884
5.93
34571-607
5.21
34812-200
7.76
34562-836
5.43
34562-884
6.37
34564-884
6.37
34571-608
5.21
34812-208
7.77
34562-836
5.75
34562-885
5.41
34564-885
5.41
34571-609
5.21
34812-210
7.77
34562-836
5.97
34562-885
5.74
34564-885
5.74
34571-610
5.21
34812-212
7.77
34562-836
6.61
34562-885
5.93
34564-885
5.93
34571-611
5.21
34812-214
7.77
34562-837
5.43
34562-885
6.106
34564-885
6.37
34571-612
5.21
34812-221
7.77
34562-837
5.75
34562-885
6.37
34564-891
6.39
34571-613
5.21
34812-228
7.77
34562-837
5.97
34563-001
6.59
34564-892
6.39
34571-614
5.21
34812-242
7.77
34562-837
6.61
34563-002
6.59
34564-893
6.39
34571-615
5.21
34812-308
7.77
34562-843
5.43
34563-003
6.59
34564-900
6.39
34571-616
5.21
34812-310
7.77
34562-843
5.75
34563-004
6.59
34565-196
6.104
34571-617
5.21
34812-312
7.77
34562-843
5.97
34563-009
6.59
34565-196
6.33
34571-618
5.21
34812-314
7.77
34562-843
6.61
34563-014
6.59
34565-396
6.104
34571-619
5.21
34812-321
7.77
34562-844
5.43
34563-019
6.59
34565-396
6.33
34571-620
5.21
34812-328
7.77
34562-844
5.75
34563-024
6.59
34566-201
6.99
34571-621
5.21
34812-342
7.77
34562-844
5.97
34564-108
5.38
34566-220
6.99
34571-622
5.21
34812-408
7.76
34562-844
6.61
34564-108
5.71
34566-228
6.99
34571-623
5.21
34812-410
7.76
34562-846
5.43
34564-108
5.96
34566-240
6.99
34571-624
5.21
34812-412
7.76
34562-846
5.75
34564-108
6.58
34566-242
6.99
34579-002
6.20
34812-414
7.76
34562-846
5.97
34564-109
5.38
34566-263
6.99
34579-002
6.21
34812-421
7.76
34562-846
6.61
34564-109
5.71
34566-284
6.99
34579-012
6.20
34812-428
7.76
34562-847
5.43
34564-109
5.96
34566-301
6.99
34579-012
6.21
34812-442
7.76
34562-847
5.75
34564-109
6.58
34566-320
6.99
34579-038
6.20
34812-600
7.76
34562-847
5.97
34564-208
5.38
34566-328
6.99
34579-038
6.21
34812-601
7.76
34562-847
6.61
34564-208
5.71
34566-340
6.99
34579-230
6.105
34812-603
7.76
34562-881
5.41
34564-208
5.96
34566-342
6.99
34579-230
6.36
34812-608
7.75
34562-881
5.74
34564-208
6.58
34566-363
6.99
34579-231
6.105
34812-610
7.75
34562-881
5.93
34564-881
5.41
34566-384
6.99
34579-231
6.36
34812-612
7.75
34562-881
6.106
34564-881
5.74
34566-501
6.100
34579-232
6.41
34812-614
7.75
34562-881
6.37
34564-881
5.93
34566-520
6.100
34579-233
6.41
34812-621
7.75
Page
Part no.
Page
Part number in bold face type: ready for despatch within 2 working days
12.55
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
34812-628
7.75
34813-212
7.77
40304-050
3.2
60103-141
4.12
60110-266
3.52
34812-642
7.75
34813-214
7.77
40304-051
3.2
60103-141
4.6
60110-267
3.55
34812-701
7.76
34813-221
7.77
40304-052
3.2
60103-141
4.7
60110-270
3.53
34812-708
7.77
34813-228
7.77
40304-053
3.2
60110-200
3.52
60110-280
3.59
34812-710
7.77
34813-242
7.77
40304-054
3.2
60110-201
2.35
60110-281
3.59
34812-712
7.77
34813-408
7.76
40304-055
3.2
60110-201
3.52
60110-282
3.59
34812-714
7.77
34813-410
7.76
40304-074
3.4
60110-202
3.52
60110-283
3.60
34812-721
7.77
34813-412
7.76
40304-075
3.4
60110-203
3.52
60110-284
3.60
34812-728
7.77
34813-414
7.76
40304-076
3.4
60110-204
3.52
60110-285
3.60
34812-742
7.77
34813-421
7.76
40304-077
3.4
60110-205
3.52
60110-290
3.58
34812-808
7.77
34813-428
7.76
40304-078
3.4
60110-206
3.52
60110-291
3.58
34812-810
7.77
34813-442
7.76
40304-079
3.4
60110-207
3.52
60110-292
3.58
34812-812
7.77
34813-600
7.76
40304-080
3.4
60110-208
3.52
60110-293
3.64
34812-814
7.77
34813-601
7.76
40304-081
3.4
60110-209
3.52
60110-294
3.64
34812-821
7.77
34813-603
7.76
40304-082
3.4
60110-210
3.52
60110-295
3.64
34812-828
7.77
34813-608
7.75
40304-083
3.4
60110-211
3.52
60110-296
3.64
34812-842
7.77
34813-610
7.75
43105-999
9.10
60110-212
3.52
60110-300
3.77
34812-908
7.77
34813-612
7.75
43105-999
9.11
60110-214
3.52
60110-301
3.77
34812-910
7.77
34813-614
7.75
43105-999
9.12
60110-216
3.52
60110-302
3.77
34812-912
7.77
34813-621
7.75
60100-302
3.14
60110-217
3.52
60110-303
3.78
34812-914
7.77
34813-628
7.75
60100-398
3.42
60110-219
3.54
60110-304
3.78
34812-921
7.77
34813-642
7.75
60100-478
3.43
60110-220
2.35
60110-305
3.78
34812-928
7.77
34813-701
7.76
60100-559
3.43
60110-220
3.55
60110-306
3.75
34812-942
7.77
34813-708
7.77
60103-010
3.21
60110-221
3.55
60110-307
3.75
34812-958
7.76
34813-710
7.77
60103-011
3.21
60110-222
3.55
60110-308
3.75
34812-960
7.76
34813-712
7.77
60103-131
1.234
60110-223
3.55
60110-309
3.75
34812-962
7.76
34813-714
7.77
60103-131
3.38
60110-224
3.55
60110-310
3.76
34812-964
7.76
34813-721
7.77
60103-131
4.10
60110-225
3.55
60110-313
3.48
34812-971
7.76
34813-728
7.77
60103-131
4.12
60110-226
3.55
60110-314
3.48
34812-978
7.76
34813-742
7.77
60103-131
4.6
60110-227
3.55
60110-315
3.48
34812-992
7.76
34813-908
7.77
60103-131
4.7
60110-228
3.55
60110-316
3.49
34813-100
7.76
34813-910
7.77
60103-137
1.234
60110-229
3.55
60110-320
3.69
34813-102
7.76
34813-912
7.77
60103-137
3.29
60110-230
3.55
60110-321
3.69
34813-103
7.76
34813-914
7.77
60103-137
3.30
60110-231
3.55
60110-322
3.69
34813-108
7.75
34813-921
7.77
60103-137
3.31
60110-232
3.56
60110-323
3.69
34813-110
7.75
34813-928
7.77
60103-137
3.38
60110-233
3.57
60110-324
3.69
34813-112
7.75
34813-942
7.77
60103-137
3.44
60110-240
3.62
60110-325
3.69
34813-114
7.75
34813-958
7.76
60103-137
4.10
60110-241
3.62
60110-326
3.65
34813-121
7.75
34813-960
7.76
60103-137
4.12
60110-242
3.62
60110-326
3.69
34813-128
7.75
34813-962
7.76
60103-137
4.6
60110-243
3.61
60110-327
3.65
34813-142
7.75
34813-964
7.76
60103-137
4.7
60110-244
3.61
60110-327
3.69
34813-200
7.76
34813-971
7.76
60103-141
1.234
60110-245
3.61
60110-328
3.65
34813-208
7.77
34813-978
7.76
60103-141
3.38
60110-246
3.63
60110-328
3.69
34813-210
7.77
34813-992
7.76
60103-141
4.10
60110-247
3.63
60110-329
3.69
12.56
Appendix
Part no.
Page
Part no.
Part no.
Page
Part no.
Page
60110-330
3.69
60114-514
1.281
60118-476
60110-331
3.69
60114-514
1.296
60118-476
1.342
60239-025
2.38
60715-017
4.59
3.7
60239-026
2.40
60715-018
4.59
60110-332
3.69
60114-514
1.308
60118-515
3.45
60239-026
2.41
60715-020
4.58
60110-340
3.68
60114-515
1.281
60118-518
3.44
60239-030
2.38
60715-021
4.58
60110-341
3.68
60114-515
1.296
60118-519
3.44
60239-031
2.40
60715-023
4.58
60110-342
3.68
60114-515
1.308
60118-520
3.44
60239-031
2.41
60715-028
4.60
60110-343
3.66
60114-517
1.308
60126-118
3.13
60239-031
2.44
60715-029
4.60
60110-344
3.66
60114-518
1.308
60126-118
3.46
60239-035
2.43
60715-030
4.58
60110-345
3.66
60118-144
3.37
60197-019
4.17
60239-040
2.43
60715-046
4.67
60110-346
3.67
60118-145
3.37
60197-019
4.61
60239-051
2.43
60715-049
3.6
60110-347
3.67
60118-339
3.45
60197-053
1.234
60239-060
2.40
60715-050
3.6
60110-348
3.67
60118-340
3.45
60197-053
3.29
60239-062
2.39
60715-132
4.65
60110-349
3.68
60118-341
3.45
60197-053
3.30
60239-062
2.42
60715-133
4.65
60110-350
3.68
60118-342
3.45
60197-053
3.31
60240-006
2.44
60715-136
4.63
60110-351
3.68
60118-343
3.45
60197-053
3.38
60502-003
5.110
60715-137
4.63
60110-352
3.66
60118-344
3.45
60197-053
4.7
60704-020
3.38
60715-138
4.66
60110-353
3.66
60118-345
3.45
60200-001
5.115
60713-001
4.9
60715-139
4.66
60110-354
3.66
60118-346
3.45
60200-027
5.115
60713-002
4.9
60715-140
4.23
60110-355
3.67
60118-434
3.33
60220-003
1.110
60713-003
4.9
60715-141
4.23
60110-356
3.67
60118-435
3.14
60220-003
1.18
60713-004
4.9
60715-142
4.23
60110-357
3.67
60118-457
1.342
60220-003
1.46
60713-169
4.15
60715-143
4.24
60110-360
3.38
60118-457
3.7
60220-003
1.60
60713-169
4.8
60715-144
4.24
60110-360
3.58
60118-458
1.342
60220-003
1.77
60713-170
4.8
60715-145
4.24
60110-360
3.68
60118-458
3.7
60224-009
5.115
60713-243
4.14
60715-146
4.25
60110-361
3.38
60118-459
1.342
60224-011
5.115
60713-244
4.14
60715-147
4.25
60110-361
3.58
60118-459
3.7
60225-012
5.114
60713-245
4.14
60715-148
4.26
60110-361
3.68
60118-472
1.117
60225-015
5.114
60713-246
4.14
60715-149
4.26
60110-362
3.58
60118-472
1.151
60225-052
4.17
60713-331
4.15
60715-150
4.27
60110-362
3.68
60118-472
1.154
60225-053
4.17
60713-501
4.10
60715-151
4.27
60110-365
3.65
60118-472
1.176
60229-001
5.114
60713-600
8.78
60715-152
4.28
60110-366
3.65
60118-472
1.198
60229-002
5.114
60713-600
8.81
60715-153
4.28
60110-370
3.74
60118-472
1.24
60229-003
5.114
60713-868
4.12
60715-154
4.29
60110-371
3.74
60118-472
1.25
60229-004
5.114
60715-005
1.166
60715-155
4.29
60113-267
1.110
60118-472
1.52
60239-001
2.40
60715-005
1.188
60715-156
4.23
60113-267
1.170
60118-472
1.66
60239-004
2.41
60715-005
1.265
60715-157
4.24
60113-267
1.18
60118-472
1.67
60239-006
2.38
60715-005
1.294
60715-158
4.25
60113-267
1.192
60118-472
1.93
60239-012
2.42
60715-005
1.295
60715-159
4.26
60113-267
1.46
60118-472
1.94
60239-013
2.39
60715-005
1.306
60715-159
4.27
60113-267
1.60
60118-473
1.342
60239-013
2.42
60715-005
1.307
60715-160
4.28
60113-267
1.77
60118-473
3.7
60239-014
2.39
60715-005
1.35
60715-160
4.29
60114-121
1.291
60118-474
1.342
60239-014
2.42
60715-005
1.72
60715-182
4.23
60114-121
1.292
60118-474
3.7
60239-020
2.38
60715-005
4.62
60715-183
4.24
60114-121
1.303
60118-475
1.342
60239-020
2.45
60715-006
4.62
60715-184
4.25
60114-121
1.304
60118-475
3.7
60239-021
2.41
60715-007
4.62
60715-185
4.26
Page
Part no.
Page
12.57
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
60715-185
4.27
60807-183
7.56
60835-022
7.13
64560-027
5.28
64560-166
6.37
60715-186
4.28
60807-203
7.106
60835-024
7.13
64560-055
6.37
64571-033
5.23
60715-186
4.29
60807-203
7.56
60850-171
5.62
64560-057
6.39
64571-033
5.61
60715-187
4.24
60807-211
7.106
60895-018
6.78
64560-071
6.38
64571-034
5.23
60715-188
4.25
60807-211
7.56
60895-018
6.79
64560-071
9.22
64571-034
5.61
60715-189
4.26
60817-001
6.134
60895-018
6.80
64560-071
9.23
64571-035
5.23
60715-189
4.27
60817-015
6.134
60895-018
6.83
64560-071
9.26
64571-035
5.61
60715-190
4.28
60817-016
6.134
60897-278
7.14
64560-071
9.27
64571-036
5.23
60715-190
4.29
60817-026
6.134
61000-007
7.62
64560-072
6.38
64571-036
5.61
60800-032
10.27
60817-050
7.104
61000-012
7.62
64560-074
5.40
69000-007
7.104
60800-039
7.104
60817-051
7.104
61000-177
7.62
64560-074
5.73
69000-969
7.104
60800-045
7.104
60817-052
7.104
62150-191
3.29
64560-074
5.92
69001-073
11.10
60800-064
11.11
60817-053
6.134
62150-191
3.30
64560-074
6.36
69001-106
11.6
60800-080
11.11
60817-054
6.135
62150-191
3.31
64560-075
5.40
69001-651
11.9
60800-123
9.10
60817-055
7.103
62150-191
3.38
64560-075
5.73
69001-652
11.9
60800-123
9.11
60817-064
6.134
62150-201
4.63
64560-075
5.92
69001-664
11.4
60800-123
9.12
60817-067
7.103
62150-201
4.66
64560-075
6.36
69001-677
11.4
60800-123
9.13
60817-071
6.135
62150-264
4.63
64560-076
5.41
69001-678
11.4
60800-123
9.14
60817-072
7.103
62150-264
4.66
64560-076
5.74
69001-679
11.4
60800-123
9.15
60817-076
6.134
62405-001
2.12
64560-076
5.93
69001-685
11.4
60800-123
9.17
60817-078
6.132
62405-002
2.12
64560-076
6.37
69001-691
11.4
60800-123
9.20
60817-079
6.132
62405-003
2.12
64560-078
5.41
69001-693
11.4
60800-123
9.3
60817-080
6.134
62405-004
2.12
64560-078
5.74
69001-696
11.4
60800-123
9.4
60817-083
6.134
62405-010
2.12
64560-078
5.93
69001-697
11.4
60800-123
9.5
60817-085
6.134
62405-011
2.12
64560-078
6.37
69001-698
11.4
60800-123
9.6
60817-096
6.135
62405-012
2.12
64560-080
5.41
69001-711
11.5
60800-123
9.7
60817-097
6.135
62405-013
2.12
64560-080
5.74
69001-712
11.5
60800-123
9.8
60817-098
6.134
62406-096
2.4
64560-080
5.93
69001-717
11.5
60800-123
9.9
60817-102
6.134
62406-096
2.5
64560-080
6.37
69001-718
11.5
60800-834
10.27
60817-103
6.134
64560-001
6.105
64560-082
6.37
69001-722
11.5
60807-011
7.106
60817-149
6.134
64560-001
6.36
64560-085
6.38
69001-723
11.5
60807-011
7.50
60817-228
5.41
64560-002
6.105
64560-086
6.38
69001-728
11.4
60807-011
7.56
60817-228
5.74
64560-002
6.36
64560-089
6.38
69001-733
11.5
60807-181
7.106
60817-228
5.93
64560-004
6.39
64560-090
6.38
69001-733
11.7
60807-181
7.22
60817-228
6.124
64560-005
6.37
64560-091
6.38
69001-733
9.10
60807-181
7.35
60817-228
6.37
64560-006
6.37
64560-092
6.38
69001-733
9.11
60807-181
7.42
60817-228
6.39
64560-008
6.39
64560-096
6.105
69001-733
9.12
60807-181
7.47
60817-228
6.41
64560-010
5.39
64560-096
6.36
69001-733
9.13
60807-181
7.50
60817-228
7.102
64560-010
5.70
64560-098
6.105
69001-733
9.14
60807-181
7.56
60817-340
7.23
64560-010
5.95
64560-098
6.36
69001-733
9.15
60807-183
7.106
60817-341
7.23
64560-010
6.57
64560-143
6.38
69001-733
9.16
60807-183
7.42
60827-026
7.14
64560-026
5.117
64560-144
6.38
69001-733
9.17
60807-183
7.47
60829-008
7.44
64560-026
5.28
64560-145
6.38
69001-733
9.2
60807-183
7.50
60835-021
7.13
64560-027
5.117
64560-146
6.38
69001-733
9.20
12.58
Appendix
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
Part no.
Page
69001-733
9.3
69004-058
11.15
69004-241
11.14
A12106CHSCFG
2.22
DV10D7
1.340
69001-733
9.4
69004-059
11.14
69004-242
11.14
A12106CHSCFGW
2.22
E4DR19FM45U
1.337
69001-733
9.5
69004-060
11.14
69004-249
11.15
A12SPK10C
2.23
EC3D7
1.340
69001-733
9.6
69004-061
11.14
69004-250
11.15
A14128CHSCFG
2.22
EC6D7
1.340
69001-733
9.7
69004-062
11.14
69004-251
11.15
A14128CHSCFGW
2.22
ECT19
1.341
69001-733
9.8
69004-063
11.14
69004-252
11.15
A14SPK12C
2.23
EDR19FM45U
1.336
69001-733
9.9
69004-064
11.14
69004-253
11.15
A16148CHSCFG
2.22
EJ2DR
1.336
69001-755
11.5
69004-065
11.14
69004-254
11.15
A16148CHSCFGW
2.22
EJ2DR
1.337
69001-801
11.4
69004-066
11.14
69004-255
11.15
A16SPK14C
2.23
EJ2DR
1.338
69001-816
11.4
69004-067
11.14
69004-256
11.15
A181610CHSCFG
2.22
EMX111
3.47
69001-821
11.4
69004-068
11.16
69004-257
11.15
A181610CHSCFGW
2.22
EMX888
3.47
69001-826
11.4
69004-069
11.16
69004-258
11.14
A18SPK16C
2.23
ES1224B
1.336
69001-831
11.4
69004-071
11.16
69004-259
11.14
A664CHSCFG
2.22
ES1224B
1.338
69001-846
11.5
69004-072
11.16
69004-260
11.14
A664CHSCFGW
2.22
ES1224B250
1.336
69001-851
11.5
69004-074
11.16
69004-261
11.14
A6SPK6C
2.23
ES1224B250
1.338
69001-853
11.5
69004-075
11.16
69004-262
11.14
A864CHSCFG
2.22
EWFT
1.336
69001-856
11.5
69004-077
11.16
69004-263
11.14
A864CHSCFGW
2.22
EWFT
1.337
69001-860
11.5
69004-078
11.16
69004-264
11.14
A8SPK6C
2.23
EWFT
1.341
69001-865
11.5
69004-080
11.16
69004-265
11.14
ADP2
3.14
LMK20
2.12
69001-866
11.5
69004-083
11.16
69004-266
11.14
AL48
2.22
LMK30
2.12
69001-877
11.5
69004-086
11.18
69004-274
11.16
ANMV6
2.16
LMK40
2.12
69001-879
11.5
69004-087
11.18
69004-275
11.16
ANMV6
2.18
P4SPOOL
1.336
69001-884
11.5
69004-088
11.18
69004-276
11.16
CMFK
2.4
P4SPOOL
1.337
69001-905
11.5
69004-089
11.18
69004-277
11.16
CMFK
2.5
P4SPOOL
1.341
69001-944
11.5
69004-090
11.18
69004-278
11.16
D19BPT1RU
1.210
Q12126PCD
2.18
69001-976
11.4
69004-091
11.18
69004-279
11.16
D19BPT1RU
1.222
Q12129PCD
2.18
69001-980
11.5
69004-095
11.19
69004-280
11.16
D19BPT1RU
3.5
Q1286PCD
2.18
69001-980
11.7
69004-098
11.20
69004-281
11.16
D19BPT2RU
3.5
Q1289PCD
2.18
69001-981
11.5
69004-121
11.14
69004-282
11.16
D19FVT69B
1.143
Q1686PCD
2.18
69001-981
11.7
69004-122
11.14
69004-284
11.16
D19FVT69B
1.344
Q1689PCD
2.18
69001-995
11.6
69004-123
11.14
69004-286
11.16
D19FVT69B
3.12
Q20129PCD
2.18
69004-042
11.23
69004-124
11.16
69004-287
11.16
D19FVT912B
1.143
Q20158PCD
2.18
69004-043
11.22
69004-125
11.16
69004-288
11.16
D19FVT912B
1.344
Q202013PCICC
2.16
69004-044
11.22
69004-126
11.16
69004-289
11.16
D19FVT912B
3.12
Q202018PCICC
2.16
69004-045
11.22
69004-127
11.16
69004-290
11.16
DCHD2
1.339
Q2020PI
2.17
69004-046
11.23
69004-128
11.16
69004-291
11.16
DCHD2
3.10
Q241612PCD
2.18
69004-050
11.15
69004-129
11.16
69005-596
11.4
DCHS1
1.339
Q24169PCD
2.18
69004-051
11.15
69004-130
11.18
89009-001
3.23
DCHS1
3.10
Q302013PCI
2.16
69004-052
11.15
69004-131
11.18
89009-001
5.117
DCHS2
1.339
Q302013PCICC
2.16
69004-053
11.15
69004-155
11.21
89009-001
6.68
DCHS2
3.10
Q302018PCI
2.16
69004-054
11.15
69004-161
11.21
89009-001
7.113
DPX-AF1
3.48
Q3020PI
2.17
69004-055
11.15
69004-165
11.21
A1086CHSCFG
2.22
DPX-CC2-TR
3.48
Q303013PCI
2.16
69004-056
11.15
69004-169
11.21
A1086CHSCFGW
2.22
DPX-T1DP1
3.48
Q303013PCICC
2.16
69004-057
11.15
69004-240
11.14
A10SPK8C
2.23
DPX-T3H1
3.48
Q303018PCI
2.16
12.59
Appendix
Part no.
Page
Part no.
Page
Q303018PCICC
2.16
TX528326100
4.49
Q3030PI
2.17
TX528348100
4.49
Q402013PCI
2.16
VAMONITOR
1.255
Q402018PCICC
2.16
Q4020PI
2.17
Q403013PCI
2.16
Q403013PCICC
2.16
Q403018PCI
2.16
Q403018PCICC
2.16
Q4030PI
2.17
Q554PCD
2.18
Q886PCD
2.18
QBIK
2.17
QDEHK
2.18
QDMFK
2.18
QIDR351505
2.17
QIDR352505
2.17
QIDR353505
2.17
QIHK
2.16
QIMFK
2.16
QIPDF
2.17
T150126G150
4.32
T200226G150
4.33
T290426G150
4.34
T430626G150
4.35
T430826G150
4.36
T431026G150
4.37
T501226G150
4.38
T531926G150
4.39
T622226G150
4.40
T703626G150
4.41
T706026G150
4.42
TE090624010
4.52
TE121024010
4.53
TE121048010
4.53
TE162024010
4.54
TE162048010
4.54
TOPTKSPL
Page
Part no.
Page
Part no.
Page
1.321
TX231426100
4.46
TX231448100
4.46
TX332826100
4.47
TX332848100
4.47
TX385626100
4.48
TX385648100
4.48
12.60
Part no.
Stichwortverzeichnis
Produc
day
s t indexMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working
Appendix
10", 19"
A
10" wall mounted case, epcase. . . . . . . . . . . . . . . . . . . . 2.32
19" cabinet accessories
19" assembly kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.17
19" cable ducting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.8
19" cable trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.9
19" distribution field . . . . . . . . . . . . . . . . . . . . . . . . . . 3.14
19" drawers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.13
19" equipment shelves . . . . . . . . . . . . . . . . . . . . . . . . 3.11
19" front panels, filler panels . . . . . . . . . . . . . . . . . . . . 3.2
19" module support . . . . . . . . . . . . . . . . . . . . . . . . . . 3.16
19" mounting brackets . . . . . . . . . . . . . . . . . . . . . . . . 3.15
19" mounting trays . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.15
19" panel/slide mounts . . . . . . . . . . . see panel/slide mounts
19" vented front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.6
19" chassis
inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.128
multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.112
19" fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4
19" fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6
19" lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354
19" wall mounted cases
CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.2
epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.24
12.62
SCHROFF Main Catalogue
A48, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . 2.20
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.8
AC fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.16
AC input module with filter . . . . . . . . . . . . . . . . . . . . . . 8.111
AC mains switching for VARISTAR LHX 20 . . . . . . . . . 1.234
AC/DC 19" compatible linear regulators . . . . . . . . . . . . 9.10
AC/DC switched mode power supplies
19" compatible . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.2
Open Frame . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.21
Accessories
Busbars . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.39, 11.10
Climate control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.58
Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.2
Electrics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.32
FPCS front panel component system . . . . . . . . . . . . 11.12
for cabinets and wall mounted cases . . . . . . . . . . . . . . 3.0
for desktop enclosures . . . . . . . . . . . . . . . . . . . . . . . 5.108
for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102
for power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16
for systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.106
Mechanics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2
Monitors, keyboards . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44
Power control socket strips . . . . . . . . . . . . . . . . . . . . . 3.72
Socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.50, 3.72
Telescopic slides . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.24
Addresses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.78
Adjustable feet
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302
for VARISTAR . . . . . . . . . . . 1.28, 1.40, 1.70, 1.166, 1.190
AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26
AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.56
AdvancedTCA
Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.2
Air baffles
for pusher fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.9
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26
Air conditioners . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1
TX series, GLIMAGUARD air/air heat exchangers . . . 4.44
TE series, Peltier, thermoelectric coolers . . . . . . . . . . 4.50
T series air conditioners. . . . . . . . . . . . . . . . . . . . . . . . 4.30
Air/air heat exchangers, CLIMAGUARD serie . . . . . . . . 4.44
Air filters
for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.23
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.28, 2.33
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.55
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.61
for ratiopacPRO air . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.23
Air filtered fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.20
Appendix
B
Air/water heat exchangers VARISTAR LHX . . . 1.224, 1.236
Assembly cases, INLINE . . . . . . . . . . . . . . . . . . . . . . . . . 2.11
Assembly material for frame type plug-in units . 7.77, 7.92
Assembly tool . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.112
Backplanes
AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19
CompactPCI, Serial, PlusIO . . . . . . . . . . . . . . . . . . . . . 10.4
Dual star, full mesh . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0
Power piggyback . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.18
PXI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11
Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20
VME/VME64x bus . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13
VXS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13
Base plates
for eurorack . . . . . . . . . . . . . . . . . . . . 1.280, 1.296, 1.308
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.249, 1.266
for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.120
for VARISTAR . . . . . 1.15, 1.36, 1.73, 1.137, 1.175, 1.199
Bases/plinths
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.250, 1.266
for VARISTAR 1.16, 1.36, 1.59, 1.73, 1.139, 1.176, 1.200
Bridges CompactPCI, PXI . . . . . . . . . . . . . . . . . . . . . . . . 10.11
Brush strip for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . 1.104
BS (British Standard) socket strip . . . . . . . . . . . . . . . . . 3.56
Busbars
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.39
for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.10
Part number in normal type: ready for despatch within 10 working days
12.63
Appendix
C
C profile rails
for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.359
for VARISTAR . . . . . . . . . . . . . . . 1.24, 1.66, 1.159, 1.162
Cabinets
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0
Aisle containment . . . . . . . . . . . . . . . . . . . . . . 1.200, 1.202
etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.346
eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.270
Lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354
LHX with air/water heat exchanger . . . . . . . . . . . . . 1.224
NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.240
NET, cabling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.126
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0
Outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.316
Open frame racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334
PROLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.362
Server cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.130
VARISTAR platform . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2
Cable brackets, for VARISTAR . . . . . . . . . . . . . . 1.186, 1.210
Cable channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.21
Cable ducting
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.8
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.305
for LAN wall mounted enclosures . . . . . . 2.38, 2.41, 2.45
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.247, 1.262
for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.51, 1.83, 1.155
with C profile, VARISTAR . . . . . . . . . . . . . . . 1.185, 1.209
Cable eyes
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.31
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.283
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.24
Cable holders
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.81
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.65
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26
Cable ladder for VARISTAR . . . . . . . . . . . . . . . . . . . . . 1.160
Cable retention for C profiles . . . . . . . . . . . . . . . . . . . . . 3.20
Cable shells
for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.24, 1.66, 1.162
Cable support . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.21
Cable support rails
for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.358
for VARISTAR . . . . . . . . . 1.24, 1.66, 1.161, 1.161, 1.209
Cable ties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.20
12.64
Cable trays
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.9
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.287
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.160
for excess cable length for VARISTAR . . . . . . . . . . . 1.163
CAD drawings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
Cage nuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.18
Carriers, AdvancedMC . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26
Carrying handles
for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.108
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.86
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.60
Cases
Desktop cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.0
minipac, small cases . . . . . . . . . . . . . . . . . . . . . . . . . . 7.98
Wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0
Castors
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.259
for VARISTAR . . . . . 1.28, 1.40, 1.70, 1.132, 1.166, 1.190
CE Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.7
Cermet potentiometer,
FPCS (front panel component systems) . . . . . . . . . . 11.21
Certifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
Chassis Data Module (CDM) for AdvancedTCA . . . . . . 8.25
Chassis Monitoring Module (CMM) . . . . . . . . . . . . . . . 8.107
Circulation fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6
Clamp case, INLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.10
Clamp distributor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.34
CLIMAGUARD, TX series, air/air heat exchangers . . . . 4.44
Climate control, overview . . . . . . . . . . . . . . . . . . . . . . . . . 4.0
Clip-on plastic front panels for cabinets . . . . . . . . . . . . . 3.5
Cold aisle containment, for cabinets . . . . . . . . 1.200, 1.202
Combined mounting, for europacPRO . . . . . . . . . . . . . . 6.57
COMLINE, outdoor cabinets . . . . . . . . . . . . . . . . . . . . . 1.318
compacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.76
CompactPCI
Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.4
Bridges . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11
for telecom applications . . . . . . . . . . . . . . . . . . . . . . . 8.86
Overview, chapter Systems . . . . . . . . . . . . . . . . . . . . 8.68
Power supply, AC/DC . . . . . . . . . . . . . . . . . . . . . . . . . 9.22
CompactPCI Serial, CompactPCI PlusIO
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.70, 8.73
Appendix
D
comptec, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.100
CONCEPTLINE, wall mounted cases . . . . . . . . . . . . . . . . 2.2
Connecting cables
for fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.13
for Wieland connectors . . . . . . . . . . . . . . . . . . . . . . . 3.69
Schuko/UTE, BS, USA, IEC . . . . . . . . . . . . . . . . . . . 3.38
Connection plates
for VARISTAR . . . . . . . . . . 1.37, 1.43, 1.74, 1.171, 1.195
Connectors
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.2
H 15 F . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16, 11.4
Housings for connectors . . . . . . . . . . . . . . . . . . . . . . 11.6
Types B, C, R, D, H, E, F, G, H, M . . . . . . . . . . . . . . 11.4
Containment, for cabinet aisles . . . . . . . . . . . 1.200, 1.202
Conventional carriers, AdvancedMC . . . . . . . . . . . . . . 8.32
Cooling concepts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2
Covers
for filler modules, AdvancedMC modules . . . . . . . . . 8.66
for slots . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.61
Cover panels, for VARISTAR . . . . . . . . . 1.157, 1.169, 1.154
Cover plates
for europacPRO subracks . . . . . . . . . . . . . . . . . . . . . 6.118
for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.76
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.104
Cube, MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38
Cutaway carriers, AdvancedMC . . . . . . . . . . . . . . . . . . . 8.28
DC fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.16
DC/DC converters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.13
Decorative frames, for VARISTAR . . . . . . 1.30, 1.130, 1.192
Depth members
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.309
for VARISTAR . . . . . . . . . . . 1.24, 1.51, 1.66, 1.83, 1.143
Desktop cases
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.108
compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.76
comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.100
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.0
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5
propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.44
ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.6
Dimension drawings
compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.98
for cantilever extractor handle . . . . . . . . . . . . . . . . . . 7.43
for cantilever extractor handle type 2 . . . . . . . . . . . . . 7.44
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.274
for extractor handle for Multibus . . . . . . . . . . . . . . . . . 7.45
for extractor handle in key form . . . . . . . . . . . . . . . . . . 7.48
for extractor handle in key form 2 . . . . . . . . . . . . . . . . 7.51
for frame type plug-in units . . . . . . . . . . . . . . . . . 7.80, 7.88
for front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.25
for heavy duty XL insertion/extractor handle . . . . . . . 7.30
for HF frame type plug-in units . . . . . . . . . . . . . . . . . . 7.94
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.136
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.242
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.53
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.9
for ratiopacPRO air . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.16
for static cantilever handle . . . . . . . . . . . . . . . . . . . . . . 7.58
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.8
Guide rails . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.40
Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20
DIN rail mounting, for power supplies . . . . . . . . . . . . . . 9.17
Distribution box, for accessories . . . . . . . . . . . . . . . . . . 3.36
Distribution cabinet, VARISTAR NET . . . . . . . . . . . . . . 1.126
Distribution fields
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.14
for epcase 10" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.34
Divider plates
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.60
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.75
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.36
Document pocket, for cabinets . . . . . . . . . . . . . . . . . . . . 3.14
12.65
Appendix
E
70
Doors
for aisle containment . . . . . . . . . . . . . . . . . . . . . . . . . . 1.204
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.85
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.292, 1.304
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.246, 1.261
for VARISTAR . . . . . . . . . 1.31, 1.71, 1.130, 1.192, 1.204
Door hinge brackets for eurorack . . . . . . 1.279, 1.293, 1.293
Double doors, for VARISTAR . . . . . . . . . . . 1.32, 1.170, 1.194
Drawer with keyboard . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.45
Drilling template, front panel component system . . . . 11.23
Drive unit cables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.110
Drive units for systems . . . . . . . . . . . . . . . . . . . . . . . . . . 8.108
Dual star backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19
12.66
Earthquake resistant cabinet, VARISTAR . . . . . . . . . . . 1.84
Edge protection for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.104
Electronics cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . 1.10
Embedded systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0
EMC cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . 1.54
EMC gasketing
for cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.70
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.53
for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.121
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.55
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.23
for subracks for mobile railway applications . . . . . . . . 6.82
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.70
Front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.6, 7.8
Systems - Accessories . . . . . . . . . . . . . . . . . . . . . . . 8.106
Environmental protection . . . . . . . . . . . . . . . . . . . . . . . . 12.0
epcase, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . 2.24
Equipment cables, cabinet accessories . . . . . . . . . . . . 3.38
Equipment shelves
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.11
for 19" lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.29, 2.33
for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.351
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.47
ESD clips, for guide rails . . . . . . . . . . . . . . . . . . . . . . . . 6.41
ETSI panel/slide mounts for VARISTAR . . . . . . . . 1.45, 1.76
etsirack
Overview cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.346
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.353
europacPRO
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18
EMC shielding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.52
for industrial applications . . . . . . . . . . . . . . . . . . . . . . . 6.86
for mobile railway applications . . . . . . . . . . . . . . . . . . . 6.70
for rugged applications. . . . . . . . . . . . . . . . . . . . . . . . . 6.92
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2
Project examples . . . . . . . . . . . . . . . . . . . . . . . 6.69, 6.85
Shielding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.42
eurorack, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.270
Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6
Extractor handles
Cantilever . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.37, 7.43
for Multibus . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.44
in key form . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.46, 7.48
ELECTRONICS PROTECTION
Appendix
F
Fans
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.27
Supplementary fan for pusher fans . . . . . . . . . . . . . . 4.13
Fan Control Module (FCM) . . . . . . . . . . . . . . . . . . . . . . 8.106
Fan trays
for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.21
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.53
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4
Selection guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.19
Fibre optic cable ducting for VARISTAR . 1.157, 1.186, 1.210
Fibre optic small case . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.38
Field Replaceable Units
for AdvancedTCA, MicroTCA . . . . . . . . . . . . . . 8.20, 8.53
Filler modules, AdvancedMC, MicroTCA . . . . . . . . . . . . 8.16
Flat top covers, for VARISTAR . . . . . 1.35, 1.72, 1.172, 1.196
FloTHERM simulation, climate control . . . . . . . . . . . . . . . 4.2
FPCS (front panel component systems) . . . . . . . . . . . . 11.12
Frames
for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.348
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.258
for VARISTAR . . . . . . . . . . 1.28, 1.40, 1.70, 1.166, 1.190
Lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.356
Open frame racks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334
Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.64, 7.86
Front handles
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25
for front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.3
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.133
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.25
Front hood for propacPRO . . . . . . . . . . . . . . . . . . . . . . . 5.62
Front panel component systems (FPCS) . . . . . . . . . . . 11.12
Front panels
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2
Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6, 3.2
for AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . 8.60
for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.12
for cable ducting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.7
for cable eyes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.7
for cantilever extractor handles . . . . . . . . . . . . . 7.33, 7.40
for Coax connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.11
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.82
for D-Sub connectors . . . . . . . . . . . . . . . . . . . . . . . . . . 7.10
for epcase, 10" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.34
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.48
for europacPRO, hinged . . . . . . . . . . . . . . . . . . . . . . . 6.52
for extractor handle in key form . . . . . . . . . . . . . 7.46, 7.48
for static cantilever handles . . . . . . . . . . . . . . . . . . . . . 7.54
for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . 7.76
for HF frame type plug-in units . . . . . . . . . . . . . . . . . . . 7.91
for IEL/IET insertion/extractor handles . . . . . . . . . . . . . 7.19
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.131
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.16
for Multibus . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.44
for PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.54
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.21
hinged, bottom-hinged . . . . . . . . . . . . . . . . . . . . . 7.8, 7.9
Mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2
shieldable, unshielded, U profile . . . . . . . . . 7.4 , 7.5, 7.7
Systems - Accessories . . . . . . . . . . . . . . . . . . . . . . . . 8.106
with GND/earthing connection . . . . . . . . . . . . . . . . . . 7.11
with holes for handles . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2
Full mesh backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19
Full-width front panels
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.54
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.21
Fuse holder, front panel component systems) . . . . . . 11.20
12.67
Appendix
G
H
Gasketing kit, for VARISTAR EMC . . . . . . . . . . . . . . . . . . 1.70
Glass doors
for eurorack . . . . . . . . . 1.278, 1.291, 1.292, 1.303, 1.303
for VARISTAR . . . . . . . . . . . . . . . 1.30, 1.41, 1.168, 1.192
Glazed doors
for eurorack . . . . . . . . . . . . . . . . . . . . 1.279, 1.291, 1.291
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . 1.30, 1.41
GND/earthing clamp, for cabinets . . . . . . . . . . . . . . . . . 3.36
GND/earthing kits
for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.106
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.133
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.24
Grub screws, for europacPRO . . . . . . . . . . . . . . . . . . . . 6.66
Guide rails. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.40
for AdvancedMC compact and full-size modules . . . . 8.34
for AdvancedMC mid-size modules . . . . . . . . . . . . . . 8.34
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.92
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.35
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.134
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.49
for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.124
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.73
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.40
for subracks for railway applications . . . . . . . . . . . . . 6.81
for test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.27
with keying/coding for CompactPCI and VME64x . . . . 6.35
12.68
www.schroff.biz E 05/2016
Handles
Cantilever extractor handle . . . . . . . . . . . . . . . . 7.37, 7.43
Extractor handle for Multibus . . . . . . . . . . . . . . . . . . . 7.44
Extractor handle in key-form . . . . . . . . . . . . . . . 7.46, 7.48
Folding handle for comptec . . . . . . . . . . . . . . . . . . . . 5.105
for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.13
for AdvancedTCA modules . . . . . . . . . . . . . . . . . . . . . 8.58
Heavy duty XL insertion/extractor handle . . . . . . . . . . 7.30
IEL, IET . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.20, 7.21
PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102
Static cantilever handle . . . . . . . . . . . . . . . . . . . . . . . . 7.55
Tip-up carrying handle . . . . . . . . . . . . . . . . . . . . . . . 5.112
Tray handle . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.114
Heat dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0
Heaters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.58
Heat exchangers
Air/air heat exchangers . . . . . . . . . . . . . . . . . . . . . . . . 4.44
Air/water heat exchangers . . . . . . . . . . . . . . . 1.224, 1.236
HF frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.90
Horizontal board assembly
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.58
propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.71
ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.38
Horizontal rails
Assembly position compacPRO. . . . . . . . . . . . . . . . . . 5.88
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.89
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26
for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.132
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.67
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.31
Hygrostats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.66
Appendix
I
Identification strips
for IEL, IET insertion/extractor handles . . . . . . . . . . . . 7.23
for PCB handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.41
IEA handles, for AdvancedTCA . . . . . . . . . . . . . . . . . . . . 8.13
IEC socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . 3.68, 3.58
IEL handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.20
IET handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.21
INLINE, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . 2.8
inpac, 19" chassis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.128
Insulation strips
compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.90
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.33
propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.68
ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.35
Internet . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
IP codes (ingress protection) . . . . . . . . . . . . . . . . . . . . . 12.4
ISO 9001/14001 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0
SCHROFF.PENTAIR.CO.UK
K
Keyboard drawers . . . . . . . . . . . . . . . . . . . . . . . . . 3.13,
Keyboards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Keying/coding
for CompactPCI, VME64x handles . . . . . . . . . . . . . . .
for connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
block for guide rails . . . . . . . . . . . . . . . . . . . . . . . . . . .
pegs for codable spring contact strips . . . . . . . . . . . . .
pegs for connector . . . . . . . . . . . . . . . . . . . . . . . . . . . .
pin for subracks for railway applications . . . . . . . . . . .
3.46
3.44
6.41
11.7
7.23
6.40
11.7
11.8
6.83
12.69
Appendix
LSA+ bracketfor LAN wall-mounted enclosures 2.53
L
M
Lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354
Basic cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.40
Fibre optic small cases . . . . . . . . . . . . . . . . . . . . . . . . 2.38
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.36
Lateral cable ducting
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.310
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . 1.167, 1.191
LEDs, FPCS (front panel component systems) . . . . . . 11.14
Lever handles
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.28
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.15
LHX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.224
Lifting eyes, for VARISTAR . . . . . . . . . . . . . . . . . 1.35, 1.133
Lights, for cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.29
Light pipe . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.58
Linear regulators, 19" compatible . . . . . . . . . . . . . . . . . 9.10
Locking levers for connectors . . . . . . . . . . . . . . . . . . . . 11.6
LSA+ bracket, for LAN wall mounted enclosures . . . . 2.43
12.70
Mains switching . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.234
Make-brake socket, FPCS . . . . . . . . . . . . . . . . . . . . . . . 11.19
Management for VARISTAR LHX . . . . . . . . . . . . . . . . . 1.235
Master slave
SCHUKO socket strip . . . . . . . . . . . . . . . . . . . . . . . . . 3.53
UTE socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67
Mezzanine front panel, for systems . . . . . . . . . . . . . . . . 7.14
MIL VARISTAR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.120
Micro switches
for IEL insertion/extractor handle . . . . . . . . . . . . . . . . 7.23
for AdvancedMC compact and full-size modules . . . . 8.67
for AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . 8.67
MicroTCA
Carrier Hub (MCH) . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.36
Power supplies. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.18
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38
minipac, small cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.98
minirack . . . . . . . . . . . . . . . . . . . . . . see NOVASTAR cabinets
Modem support, for epcase . . . . . . . . . . . . . . . . . . . . . . 2.33
Modular, outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . 1.326
Module support/slide rails
for europacPRO , europacPRO rugged . . . . . . . . . . . . 6.89
for QLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.17
Module supports, cabinet accessories . . . . . . . . . . . . . 3.16
Modules or plug-in units
Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.64
Front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.0
Plug-in units . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.16
PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12
Monitors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44
Mounting aid, for cage nuts . . . . . . . . . . . . . . . . . . . . . . 3.19
Mounting brackets, cabinet accessories . . . . . . . . . . . . 3.15
Mounting plates
for A48 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.23
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.94
for CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.6
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.59
for INLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.13
for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.120
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.64
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.37
for single socket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.36
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . 1.17, 1.47, 1.78
Appendix
N
Mounting system with C profiles for eurorack . . . . . . 1.282
Mounting tray for LSA+ . . . . . . . . . . . . . . . . . . . . . . . . . 3.15
multipacPRO
Overview 19" subracks . . . . . . . . . . . . . . . . . . . . . . . 6.112
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.127
Networking cabinet, VARISTAR . . . . . . . . . . . . . . . . . .
NOVASTAR, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . .
Nuts
19" assembly parts, cage nuts . . . . . . . . . . . . . . . . . .
M2.5, M4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1.126
1.240
3.19
7.111
12.71
Appendix
O
P
OHSAS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0
Open frame racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334
Order notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8, 12.10
Outdoor cabinets
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.316
COMLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.318
Modular . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.326
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.331
Unibody . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.322
12.72
Panel mounts
for CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.7
Panel/slide mounts
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.309
for outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . 1.328
for VARISTAR . 1.19, 1.44, 1.61, 1.75, 1.142, 1.177, 1.201
Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . see front panels
Part number table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.11
PCBs
Assembly parts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.107
Board fixing for frame type plug-in units . . . . . . . . . . . 7.78
Covers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.62, 7.105
Handle for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.135
Handle for PCB retainer . . . . . . . . . . . . . . . . . . . . . . . 6.41
Handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.106
Handles, retainers . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102
Pocket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.105
Reinforcement . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.97
Retainer for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.135
Retainer for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.41
Strengthening for connectors . . . . . . . . . . . . . . . . . . . 11.8
Peltier thermoelectric coolers . . . . . . . . . . . . . . . . . . . . . 4.50
Perforated strips, for europacPRO . . . . . . . . . . . . . . . . . 6.33
Plastic feet, for cases . . . . . . . . . . . . . . . . . . . . . . . . . . 5.116
Plug-in units
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.16
with cantilever extractor handle . . . . . . . . . . . . . . . . . 7.38
with cantilever extractor handle type 2 . . . . . . . . . . . . 7.32
with fixed extractor handle . . . . . . . . . . . . . . . . . . . . . 7.53
with IEL insertion/extractor handle . . . . . . . . . . . . . . . 7.18
with mechanical shielding . . . . . . . . . . . . . . . . . . . . . . 7.60
PMC mezzanine, Modules, front panels . . . . . . . . . . . . . 7.12
Potential adjustment rail, cabinet accessories . . . . . . . 3.37
Potential distributor, for busbars . . . . . . . . . . . . . . . . . 11.10
Power backplane, with P47 connector . . . . . . . . . . . . . 10.18
Power connector, cabinet accessories. . . . . . . . . . . . . . 3.39
Power control socket strips . . . . . . . . . . . . . . . . . . . . . . . 3.72
Power distribution modules, cabinet accessories . . . . 3.34
Power distributors, socket strips . . . . . . . . . . . . . . . . . . 3.70
Power entry modules
for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.20
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.50
Appendix
Q
Power supplies
AC/DC linear regulators . . . . . . . . . . . . . . . . . . . . . . . 9.10
AC/DC switched mode units . . . . . . . . . . . . . . . . . . . . . 9.2
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16
CompactPCI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.22
Connector H 15 F . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16
DC/DC converters . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.13
for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.18
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.0
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.29
Wall mounting/DIN rail assembly . . . . . . . . . . . . . . . . 9.17
Project examples
AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . 8.35
Desktop cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5
etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.353
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.69, 6.85
multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.127
Outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.331
Power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.29
Subracks for railway applications . . . . . . . . . . . . . . . . 6.85
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.113
VARISTAR Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . 1.119
PROLINE, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.362
propacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.44
Protective grilles
Fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.13
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.27
Pull-handle mechanism, for AdvancedMC modules . . . 8.58
PXI
Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11
QLINE, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . 2.16
Quality . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0
Quick-release fastener, for front panels . . . . . . . . . . . . 7.107
12.73
Appendix
R
S
Radial fan unit for ratiopacPRO air . . . . . . . . . . . . . . . . . 5.17
ratiopacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.6
Rear hood for europacPRO subracks . . . . . . . . . . . . . . . 6.47
Rear panels
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.82
for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.349
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.48
for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.77
for HF frame type plug-in units . . . . . . . . . . . . . . . . . . 7.91
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.248, 1.263
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.20
for VARISTAR . . . . . . . . . . 1.29, 1.41, 1.71, 1.171, 1.195
12.74
SCHUKO socket strips . . . . . . . . . . . . . . . . . . . . . . 3.52, 3.67
Screws
Collar screws, countersunk screws, panhead screws,
grub screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.64, 7.107
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.64
Search function . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
Seismic, VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.84
Server cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . . 1.130
Service offers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6
ServicePLUS
AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . 8.67
Air conditioners . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.43
Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.29
Cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4
etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.352
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16
europacPRO rugged . . . . . . . . . . . . . . . . . . . . . . . . . . 6.95
eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.288, 1.300
Fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.19
Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.74
Lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360
MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112
NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.256
multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.118
Outdoor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.330
Power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.28
Socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.71
Subracks for railway applications . . . . . . . . . . . . . . . . 6.84
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112
VARISTAR Datacom/Networking . . . . . . . . . . . . . . . 1.164
VARISTAR Electronis . . . . . . . . . . . . . . . . . . . . . . . . . 1.26
VARISTAR EMC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.68
VARISTAR LHX
with air/water heat exchanger . . . . . 1.224, 1.236
VARISTAR NET . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.164
VARISTAR Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . 1.96
VARISTAR Server . . . . . . . . . . . . . . . . . . . . . . . . . . 1.164
Wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . . 2.46
Shelf alarm display for AdvancedTCA . . . . . . . . . . . . . . 8.24
Shelf alarm panel for AdvancedTCA . . . . . . . . . . . . . . . 8.23
Shelf manager for AdvancedTCA . . . . . . . . . . . . . . . . . . 8.18
Shelves
for eurorack . . . . . . . . . . . . . . . . . . . . . 1.285, 1.299, 1.312
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . 1.253, 1.267
for VARISTAR . 1.21, 1.49, 1.63, 1.80, 1.145, 1.182, 1.206
for VARISTAR . . . . . . . . . . . . . . . . 1.47, 1.78, 1.180, 1.204
Appendix
Short slide rails
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.284
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.252, 1.268
for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.144
Side panels
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.291, 1.303
for frame type plug-in units . . . . . . . . . . . . . . . . . . . . 7.76
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.260
for VARISTAR . . . . . . . . . . . . . . . 1.29, 1.41, 1.167, 1.191
Side-by-side mounting
for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.349
Sleeves for front panels . . . . . . . . . . . . . . . . . . . . . . . . . 7.107
Slide nuts for HF frame type plug-in units . . . . . . . . . . 7.92
Slide rails
for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360
for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.105
for eurorack . . . . . . . . . . . . . . . . . . . . . 1.284, 1.298, 1.311
for VARISTAR 1.20, 1.51, 1.62, 1.82, 1.144, 1.184, 1.208
Slides for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . 6.71
Socket strips
BS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.56
for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.32
IEC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.58
IEC, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.68
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.50
SCHUKO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.52
SCHUKO, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.72
Swiss version . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.63
USA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.62
UTE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.55
UTE, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67
Solder side cover for PCBs, for systems . . . . . . . . . . . . 7.62
Spacers for PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . 7.14
Splicing casettes, splicing casette holders . . . . . 2.39, 2.42
Stacking aid for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . 5.23
Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0
Steel doors
for eurorack . . . . . . . . . . . . . . . . . . . . . 1.278, 1.292, 1.292
for VARISTAR . . . . . . . . . . 1.31, 1.41, 1.71, 1.169, 1.193
Strap handles
for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.111
Strip conductors for busbars . . . . . . . . . . . . . . . . . . . . . 11.11
Struts for AdvancedMC carriers . . . . . . . . . . . . . . . . . . 8.34
Subrack systems . . . . . . . . . . . . . . . . . . see chapter Systems
Subracks
Assembly service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2
for assembly of connectors . . . . . . . . . . . . . . . . . . . . . 6.9
for backplane mounting . . . . . . . . . . . . . . . . . . . . 6.8, 6.73
for CompactPCI applications . . . . . . . . . . . . . . . . . . . . 6.14
for railway applications . . . . . . . . . . . . . . . . . . . . . . . . . 6.70
für rugged applications . . . . . . . . . . . . . . . . . . . . . . . . . 6.92
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.0
Support arm for monitor and keyboard, NOVASTAR . . 1.255
Swing frames
for VARISTAR . . . . . 1.18, 1.46, 1.60, 1.77, 1.179, 1.203
Systems
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.106
AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26
AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . . 8.56
AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.2
CompactPCI, Serial, PlusIO . . . . . . . . . . . . . . . . . . . . . 8.68
Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112
MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0
Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.113
VME64x/VXS/VME . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.88
12.75
Appendix
T
U
Tape measure with HP, U and cm division . . . . . . . . . . 3.23
Telemonitored socket strips . . . . . . . . . . . . . . . . . . . . . 3.72
Telescopic slides
Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.25
for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.62
for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . 6.121, 6.125
Selection guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.24
Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20
Test reports . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
Test sockets for front panel component systems . . . . 11.18
Thermoelectric coolers, Peltier, TE series . . . . . . . . . . . . 4.50
Thermostats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.63
Threaded inserts
europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.33
multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.121
propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.68
Tip-over protection for VARISTAR . . . . . . . . . . . . . . . . 1.108
Tip-up carrying handles
for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.112
for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.27
Tip-up feet
for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.116
for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.87
for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.107
for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.72
Top covers
for cabinet aisle containment . . . . . . . . . . . . . . . . . . . 1.208
for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.294, 1.306
for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.264
for VARISTAR . . . . . . . . . . . 1.33, 1.41, 1.72, 1.172, 1.196
Touchpad . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44
Tower housing ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . 5.12
Tray for excess cable lenghts for VARISTAR . . 1.186, 1.210
Tray handle for cases . . . . . . . . . . . . . . . . . . . . . . . . . . 5.114
Trim/panel mounting for europacPRO . . . . . . . . . . . . . 6.90
T series, air conditioners. . . . . . . . . . . . . . . . . . . . . . . . . . 4.30
TE series, Peltier, thermoelectric coolers . . . . . . . . . . . . 4.50
Tubular rivets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.111
TX series, CLIMAGUARD, air/air heat exchangers . . . . . 4.44
12.76
Unibody, outdoor cabinets. . . . . . . . . . . . . . . . . . . . . . . 1.322
USA socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.62
User manuals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8
UTE socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67, 3.55
Appendix
V
VARISTAR Cabinets
Air/water heat exchangers LHX . . . . . . . . . . . . . . . . . 1.224
Containment . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.202
Datacom/Networking . . . . . . . . . . . . . . . . . . . . . . . . . 1.124
Deco, with deco frame . . . . . . . . . . . . . . . . . . . . . . . . . 1.12
Electronics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.10
EMC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.54
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4
IP 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.13
IP 55 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.14
Networking cabinet . . . . . . . . . . . . . . . . . . . . . . . . . . 1.126
MIL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.120
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2
Platform . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4
Project examples Seismic . . . . . . . . . . . . . . . . . . . . . 1.119
Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.84
Server . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.130
Velcro, cabinet accessories . . . . . . . . . . . . . . . . . . . . . . 3.20
Vented top cover
for VARISTAR . . . . . . . . . 1.35, 1.72, 1.133, 1.174, 1.198
VME64x/VXS/VME
Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13
Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.88
Voltage keying/coding pin for PMC mezzanine . . . . . . 7.14
VXS backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.14
W
Wall mounted cases
A48, fibreglass reinforced plastic, IP 66 . . . . . . . . . . . . 2.20
CONCEPTLINE, steel, IP 66 . . . . . . . . . . . . . . . . . . . . 2.2
epcase, 10"/19" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.32
epcase, steel, IP 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.24
INLINE, steel, IP 66 . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.8
LAN wall mounted enclosures . . . . . . . . . . . . . . . . . . . 2.36
Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0
QLINE, plastic, IP 67 . . . . . . . . . . . . . . . . . . . . . . . . . . 2.16
Wall mounting
for outdoor applications . . . . . . . . . . . . . . . . . . . . . . . 1.325
for power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.17
Washers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.111
Water-cooled cabinet VARISTAR LHX . . . . . . . 1.224, 1.236
Wieland SCHUKO, IEC, UTE socket strips .. . 3.66, 3.67, 3.68
Z
Z rails
5.91
6.34
5.69
5.35
12.77
Adressen_Katalogrueckseite_FM9.fm Seite 78 Donnerstag, 11. Oktober 2012 3:36 15
Adressen
Hauptkatalog
Hauptkatalog
Bestell-Nr. in Fettdruck: versandfertig innerhalb von 2 Arbeitstagen
Bestell-Nr. in Normalschrift: versandfertig innerhalb von 10 Arbeitstagen
Europe
Austria
Voltohm GmbH
Frutzstraße 4
6832 Sulz, Vorarlberg
Tel.: +43 5522 494 20
Fax: +43 5522 421 41
info@voltohm.at
www.voltohm.at
Germany
Schroff GmbH
Langenalber Straße 96 - 100
75334 Straubenhardt
Tel.: +49 (0) 7082 - 794-0
Fax: +49 (0) 7082 - 794-200
schroff.de@pentair.com
www.schroff.de
Lithuania
UAB SOMI RT
Ukmerges St. 283A,
06313 Vilnius
Tel.: +370 5 270 90 00
Fax: +370 5 270 90 66
info@somi.lt
www.somirt.lt
Slovakia
E-comps s.r.o.
Nobelova 30
831 02 Bratislava
Tel.: +421 2 44 63 48 15
Fax: +421 2 44 63 48 16
info@e-comps.sk
www.e-comps.sk
Belarus
Conektro UE
Ostroshitskaya St. 4, ground floor
220125 Minsk
Tel.: +375 17 265 6741
Fax: +375 17 265 6744
schroff@conektro.by
www.conektro.by
Great Britain
Schroff UK Ltd.
Unit 4, Grovelands Business Centre,
Boundary Way
Hemel Hempstead,
Hertfordshire, HP2 7TE
Tel.: +44 (0) 1442 24 04 71
Fax: +44 (0) 1442 21 35 08
schroff.uk@pentair.com
www.schroff.co.uk
Netherlands
Koning & Hartman BV
Industrial Electronics, Energieweg 1
2627 AP Delft
Tel.: +31 (0) 15 260 9906
Fax: +31 (0) 15 260 9194
salesdesk.ie@koningenhartman.com
www.koningenhartman.com
Slovenia
IC Elektronika d.o.o.
Vodovodna 100
1000 Ljubljana
Tel.: +386 (0) 1 568 01 37
Fax: +386 (0) 1 568 91 07
info@ic-elect.si
www.ic-elect.si
Norway
Elfa Distrelec AS
Sandakerveien 76 F
0483 Oslo
Tel.: +47 2312 49 00
Fax: +47 2312 49 20
norge@elfa.se
www.elfa.se
Spain
Cenvalsa
Calle Ulises 104
28043 Madrid
Tel.: +34 (91) 721 60 10
sismecanic@cenval.es
www.cenval.es
Belgium
Koning & Hartman BV
Woluwelaan 31
1800 Vilvoorde
Tel.: +32 (0) 2 257 02 00
Fax: +32 (0) 2 257 02 02
salesdesk.belgium
Czech Republic
ZTC electronic Praha, s.r.o.
P. O. Box 34
14900 Prague 415
Tel.: +420 2 67 91 00 82
Fax: +420 2 67 91 06 41
ztc@ztc.cz, www.ztc.cz
Croatia
Chronos Info D. O. O.
Medvedgradska 35
1000 Zagreb
Tel.: +385 (0)1 466 70 59
Fax: +385 (0)1 466 69 77
chronos@chronos.hr
www.chronos.hr
Denmark
Wexoe A/S
Lejrvej 31
3500 Værløse
Tel.: +45 45 46 58 00
Fax: +45 45 46 58 01
wexoe@wexoe.dk
www.wexoe.dk
Finland
Elfa Distrelec OY
Sockenbackavägen 14
00380 Helsingfors
Tel.: +358 9 560 50 0
Fax: +358 9 560 50 100
tilaukset@elfa.se
www.elfa.se
France
Schroff SAS
Z.I. 4, rue du Marais
Boîte Postale 16
67660 Betschdorf
Tel.: +33 (0) 3 88 90 64 90
Fax: +33 (0) 3 88 90 64 88
schroff.fr@pentair.com
www.schroff.fr
12.78
10/2012
Greece
SUPERCHIP Ltd.
18 K. Paleologou Str.
18233 Ag. Ioannis Renti
Athens
Tel.: +30 210 5222 600
Fax: +30 210 5222 060
info@superchip.gr
www.superchip.gr
Hungary
NB Electronic Kft.
Kaszásdülö u. 2.
1033 Budapest
Tel.: +36 (06) 1 387 14 55
Fax: +36 (06) 1 453 08 26
nbelectronic@nbelectronic.hu
www.nbelectronic.hu
Ireland
EPS Ltd.
Unit 17
Kinsealy Business Park,
Kinsealy
Co Dublin
Tel.: +353 1 803 89 18
Fax: +353 1 803 89 19
info@epsglobal.com
www.electronicproductservices.com
Israel
Ram Nir
Electronic Packaging & Services
4 Ben-Gurion Str.
Nes Ziona 74030
Tel.: +972 8 930 37 77
Fax: +972 8 940 12 86
ramdevelopment@
ramdevelopment.com
www.ramdevelopment.com
Italy
Schroff S.r.l.
Via Brughiera 1
20010 Pregnana Milanese (MI)
Tel.: +39 02 932 714-1
Fax: +39 02 932 714-891
schroff.it@pentair.com
www.schroff-italia.it
Latvia
LAPP MILTRONIC SIA
Ulbrokas street 44a
Riga 1021
Tel.: +371 6750 1900
Fax: +371 6750 1909
info@lappmiltronic.lv
www.lappmiltronic.lv
Poland
Pentair Poland Sp.z o.o.
ul. Marynarska 21
02-674 Warsaw
Tel.: +48 22 607 06 16
Fax: +48 22 607 06 21
schroff.pl@pentair.com
www.schroff.pl
Sweden
Schroff Scandinavia AB
Flygfältsgatan 11
P. O. Box 2003
12821 Skarpnäck
Tel.: +46 (0) 8 683 61 00
Fax: +46 (0) 8 683 61 99
schroff.se@pentair.com
www.schroff.se
Portugal
ARESTEL Componentes e
Praceta Torres do Restelo no. 10
1400-401 Lisbon
Tel.: +351 21 303 08 50
Fax: +351 21 301 62 21
telecom@arestel.pt
www.arestel.pt
Switzerland
Rotronic AG
Grindelstr. 6
8303 Bassersdorf
Tel.: + 41 (0) 44 838 12 12
Fax: + 41 (0) 44 837 00 74
ime@rotronic.ch
www.rotronic.ch
Russia
Schroff Russia, Proezd #607,
Building 30, Office 512,
123458 Moscow
Tel. +7 (495) 730 52 53
Fax. +7 (495) 730 52 53
schroff.ru@pentair.com
Turkey
Schroff GmbH Turkey Liaison Office
34303 Ikitelli
Istanbul
Tel.: + 90 (0) 212 444 16 46
Fax: + 90 (0) 212 494 47 95
ediz.yanikoglu@pentair.com
www.schroff.biz
PROSOFT Ltd.
108, Profsouznaya Str.
117437 Moscow
Tel.: +7 (495) 234 06 36
Fax: +7 (495) 234 06 40
info@prosoft.ru
www.prosoft.ru
Spectr RS Ltd.
12, Mebelnaya str., Office 402
197374 Saint Petersburg
Tel./Fax: +7 (812) 640-41-90
office@spectr-rs.ru
www.spectr-rs.ru
ITC Electronics Ltd.
Ziryanovskaya, 53
630102 Novosibirsk
Tel.: +7 (383) 328 1 328
Fax: +7 (383) 328 1 281
nsk@itc-electronics.com
www.itc-electronics.com
ОVERTIME
nab. Chernoi Rechki 41 i
197342 Saint Petersburg
Tel.: +7 (812) 327 34 86
Fax: +7 (812) 327 34 85
serg@overtime.ru
www.overtime.ru
Ukraine
Megatrade
BC "Grand Step"
24D, Polyova St.
03056 Kiev
Tel.: +380 44 538 00 06
Fax: +380 44 538 00 16
office@megatrade.com.ua
www.megatrade.com.ua
VD MAIS
Michaila Dontsa St. 6
03061 Kiev
Tel.: +380 44 220 01 01
Fax: +380 44 220 02 02
info@vdmais.kiev.ua
www.vdmais.kiev.ua
Adressen_Katalogrueckseite_FM9.fm Seite 79 Donnerstag, 11. Oktober 2012 3:36 15
Asia
Bahrain
Pentair Equipment Protection
Al-Khobar 31952
P. O. Box 3298
Tel.: +966 54 8088 774
ala.shehadah@pentair.com
www.schroff.biz
China
Pentair Equipment Protection China
Shanghai Office
Yan An West Road 1118,
Longment Building, Room 905
Changning District
Shanghai, PC 200052
Tel.: +86 (0) 21 3211 4588 ext.285
Fax: +86 (0) 21 3460 6017
sales.china@pentair.com
www.ptpc.com
www.schroff.biz
U.A.E
Pentair Middle East
P.O.Box 7709
2202 - 2204, 22nd Floor,
API World Tower,
Sheikh Zayed Road
Dubai
Tel.: +971 4 3781700
Fax: +971 4 3781777
tp.mea@pentair.com
www.schroff.biz
Hong Kong
Alberta Electronic Company Ltd.
Unit B, 28/F, Legend Tower,
7 Shing Yip St.,
Kwun Tong,
Kowloon
Tel.: +852 2334 27 88
Fax: +852 2303 00 23
www.alberta.com.hk
India
Pentair Equipment Protection India
Pvt. Ltd., Unit 1, Factory 2,
Sai Lakshmi Industrial Campus
Kannamangala, Bidarahalli Hobli,
Whitefield - Hoskote Road
Bangalore 560067
Tel.: +91 80 671 52 000
contact.marketing@pentair.com
www.schroff.biz
Indonesia
P.T. Nego Electrindo
Ruko Mega Grosir Cempaka MAS
Blok I, No. 20-22,
Jl. Let. Jend. Suprato
Jakarta 10640
Tel.: +62 21 4288 22 55
Fax: +62 21 4288 22 66
sales@negoelectrindo.co.id
www.negoelectrindo.co.id
Japan
Schroff K.K., Nisso No. 13, Bldg. 4F
2-5-1 Shinyokohama, Kohoku-ku
Yokohama-shi, Kanagawa 222-0033
Tel.: +81 (0)45 476 02 81
Fax: +81 (0)45 476 02 89
sales@schroff.co.jp
www.schroff.co.jp
Kazakhstan
Prospekt Raiymbeka 221a/4
050016 Almaty
Tel.: +7 (727) 279 71 17
Fax: +7 (727) 233 93 44
almaty@itc-electronics.com
Korea
ARA Electronics Co. Ltd.
501 Daeryung Techno-Town 1
327-24 Kasan-dong Kumchon-gu
153-023 Seoul
Tel.: +82 2 855 54 00
Fax: +82 2 855 34 90
office@ara.co.kr
www.ara.co.kr
Singapore
Hoffman Schroff Pte. Ltd.
18 Boon Lay Way
#04-110/111 Tradehub 21
Singapore 609966
Tel.: +65 6795 22 13
Fax: +65 6795 22 19
hoffmanschroff@pacific.net.sg
www.schroff.biz
Taiwan
Lumax International Corp. Ltd.
12 F, No. 3-1, Park Street
Taipei 11503
Tel.: +886 2 2788 36 56
Fax: +886 2 2782 73 69
vincentma@elumax.com
www.elumax.com
Thailand
Pisanu Engineering Co., Ltd.
800/43-45 Soi Trakul Suk
Asoke Dindaeng Road
Dindaeng
Bangkok 10400
Tel.: +662 245 9113
Fax: +662 246 9220
ecsales@pisanu.co.th
www.pisanu.co.th
Saudi Arabia
P. O. Box 3298
Al-Khobar 31952
www.schroff.biz
Americas
United States of America
2100 Hoffman Way
Anoka, MN 55303
Tel.: +1 (763) 421-2240
www.pentairtechnicalproducts.com
170 Commerce Drive
Warwick, RI 02886
Tel.: +1 (401) 732-3770
Fax: +1 (401) 738-7988
Toll free (800) 451-8755
schroff.us@pentair.com
www.schroff.us
Central and South America
Rua João Marcon, 165
18550.000, Boituva - SP, Brazil
Tel.: +55 (15) 3363 9101
Fax: +55 (15) 3363 9104
www.taunus.com.br
Australia
Australia
SOANAR Pty. Ltd.
320, Victoria Rd.
Rydalmere,
Sydney NSW 2116
Tel.: +61 2 8832 3000
Fax: +61 2 8832 3030
schroff@soanar.com
www.soanar.com
Dedicated Systems
Australia Pty Ltd.
5A / 5-11 Glen Osmond Road
Eastwood SA 5063
Adelaide
Tel.: +61 8 8299 9333
Fax: +61 8 8299 9344
sales@dedicatedsystems.com.au
www.dedicatedsystems.com.au
Pentair Water Australia Pty. Ltd.
1-21 Monash Drive
Dandenong South, VIC 3175
Tel.: +61 3 9709 5800
Fax: +61 3 9709 5885
glenn.brooks@pentair.com
www.pentairwater.com.au
New Zealand
Soanar New Zealand
16-18 Fisher Crescent
Mount Wellington
Auckland 1060
Tel.: +64 9 258 5133
Fax: +64 9 259 4115
schroff@soanar.com
www.soanar.com
Africa
South Africa
Actum Electronics (PTY) LTD
Unit A8, The Stables Business Park
No 13, 3rd Road
Linbro Park, 2064
Tel.: +27 (0) 11 608 3001
Fax: +27 (0) 11 608 1918
sales@actum.co.za
www.actum.co.za
10/2012
12.79
Main Catalog
24th Edition
Main Catalog
Schroff gmbh, LangenaLber StraSSe 96–100, D-75334 StraubenharDt WWW.SCHROFF.PENTAIR.CO.UK
Equipment Protection Solutions
24th Edition | October 2012
39601-641 © 2016 Pentair equipment Protection
18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1
10.10.2012 11:15:02
