69001981
    SCHROFF.PENTAIR.
    CONNECTOR H 15
69001981 数据手册
Main Catalog 24th Edition Main Catalog Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM Equipment Protection Solutions 12/2017 39601-641 © 2012 Pentair Equipment Protection 18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1 10.10.2012 11:15:02 DESIGN WITH CONFIDENCE ® Pentair, together with its Hoffman®, McLean® and Schroff® brands, is a leading manufacturer of products and solutions for the housing, protection and cooling of electrical and electronic assemblies and components. Under the slogan "Design with ­CONFIDENCE®" the company offers the highest standards across the industry for quality, performance and design. Pentair offers a vast diversity of off-the-shelf products as well as modified and customized solutions for applications in the measurement and instrumentation, telecommunications and data processing, energy and industrial, transport and medical industries and for electronic systems for security and defense. When you enter a partnership with Pentair you are drawing on the capabilities of a company that has all the necessary financial and other resources at its disposal to develop, manufacture and assemble application-critical systems to your requirements, down to defined function testing and prompt delivery of the goods anywhere in the world. Regional Headquarters Anoka, MN, USA Boituva, Brazil Straubenhardt, Germany Singapore Shanghai, China Manufacturing and Logistics Locations Pharr, TX, USA Anoka, MN, USA Mt. Sterling, KY, USA Radford, VA, USA Warwick, RI, USA San Diego, CA, USA Boituva, Brazil Melbourne, Australia Reynosa, Mexico Betschdorf, France Straubenhardt, Germany Dzierzoniow, Poland Bangalore, India Qingdao, China Meiwa, Japan Pentair Equipment Protection brands pentairequipmentprotection.com 02 18002_Hautpkatalog_Schroff_EN_AK03.indd 2 17.10.2012 11:18:23 INNOVATIVE, SOPHISTICATED, CUSTOMER-ORIENTED AND WITH GLOBAL PRESENCE: Schroff The Schroff® brand stands for recognized, globally leading developments in electronics packaging components and systems for applications in measurement, instrumentation and control systems, infrastructure, security systems, data communications, telecommunications and automation. Our customeroriented thinking and mode of working is an important element of our business model. At a glance: what sets Schroff products apart: - Certified to global standards - Global availability - Outstanding quality - Innovative solutions - Comprehensive heat management - Large off-the-shelf product program - Modifications to your requirements - Custom new developments - Customer-oriented thinking and operations - Service quality and competence - Extensive testing - Best price-performance ratio Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 3 03 17.10.2012 11:20:01 SIX STEPS TO THE RIGHT PRODUCT 1. APPLICATION The choice of enclosure often depends on the field of application and/or market segment. Does your product require a door, shelves, slide rails or a support arm for a monitor? Is ease of access important? Do you require cooling for your components, redundancy or electromagnetic 2. ENVIRONMENT Environmental conditions are perhaps the most important factor when selecting the correct enclosure. Is it intended for use in, say, telecommunications, industry, measurement and control, infrastructure or security systems, or as a data communications system? You should also consider the main challenges the enclosure will face, such as: - electromagnetic radiation 3. STANDARDS Select an enclosure that satisfies the required standard of protection for the environment and application in question. The evaluation criteria of protection classes such as NEMA, UL, cUL, Telcordia GR-487, CSA, DIN, VDE, GOST, RoHS, CE, IEC, EN, NFF, BN, IEEE, PICMG and VITA are a measure of the capability of an enclosure to shielding? Many details are required to enable you to select the correct enclosure. You can find more technical information about electromagnetic compatibility on page 12.6. - shock and vibration - corrosion - the required loading capacity - dust or sand - fire - extreme temperatures - low atmospheric pressure Deciding these considerations simplifies the choice of the best product for your needs. You can find further information in the appendix on ­pages 12.3-12.6 withstand specific environmental conditions. Note however that these protection classes differ from one another in important aspects. Further technical information is available in the appendix on pages 12.1-12.7 and in our Standards Summary brochure, which you can order from our website www.schroff.biz/catalogues. 04 18002_Hautpkatalog_Schroff_EN_AK03.indd 4 17.10.2012 11:20:24 4. SIZE Several factors must be considered when specifying the size of the enclosure. What materials should it be built from? Where in the enclosure will the assemblies be fitted? Will you be installing devices on a mounting plate? Will you be fitting operating elements to a door? Does your application have specific requirements for the location of the enclosure? 5. MATERIAL Select the most suitable material for your product, taking into consideration the potential environmental risks and possible contamination by harmful substances against which you must protect the enclosure. – steel – stainless steel – aluminum – fiberglass – ABS – polycarbonate – polyester We will then help you select the most suitable surface finish: – electroplating – hot-dip galvanizing – passivation – anodization – paint (various compositions) Further technical information is available in the appendix on pages 12.4-12.5 and in our Standards Summary brochure (pages 26-33), which you can order from our website www.schroff.biz/catalogues. 6. THERMAL MANAGEMENT Faster and more powerful assemblies produce ever more waste heat. Effective thermal management is therefore important to ensure optimum efficiency and service life for the electronic components. While in most cases the central task is to monitor and dissipate the heat generated, there are also circumstances in which heating is necessary. Some basic questions for determining the appropriate cooling method for your application include: Which enclosure surfaces allow heat transfer? How much heat is generated by each installed component? What temperature conditions must be observed? Will your application be used in a closed room or out of doors? Will the cooling device be fitted on the top, the side or within the enclosure? With the help of your Schroff contact, select the most suitable cooling solution from our wide product range in section 4. You will also find more solutions on the Pentair McLean website www.mcleancoolingtech.com or in the McLean catalog, in the "McLean V-Series" and "McLean Thermoelectric Coolers" brochures and in the main Pentair Hoffman catalog, which you can order from www.schroff.biz/catalogues. Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 5 05 17.10.2012 11:20:40 ServicePLUS configuration Simple. Fast. To the ideal product. We help you to build your ideal product out of off-the-shelf components quickly, competently and simply with interactive online configurators, our telephone configuration hotline and Power Search, which lets you select standard components fast www.schroff.co.uk/configuration assembly Built by professionals. Double the benefit. For turnkey products, ServicePLUS assembly lets you keep your attention on your core activity without interruption, while we carry out the complete assembly of all your system components, competently and on time; competently and on time www.schroff.co.uk/assembly modification Minor modifications. Large impact. Quality also means 100% accuracy of fit. We therefore also modify off-the-shelf products to your individual needs, for example, drilled holes, cut-outs, printing and special colors. www.schroff.co.uk/modification solution Simple. Fast. From one source. If it is not possible to use off-the-shelf products, we will create a special custom solution - from development and design through to complete, integrated, functioning systems or even highly specific new developments. www.schroff.co.uk/solution express When fast has to be even faster. In many projects speed is of the essence, and flexibility a decisive criterion. With us you can select your delivery time from a range of express options. support Support. Solution. Availability. ServicePLUS support is our after-sales service and sets up an ongoing relationship with you. We offer a modular range of support options that can be tailored to your specific service requirements. www.schroff.co.uk/support academy Know. Share. Become a partner. With ServicePLUS academy we offer you straightforward access to our specialist knowledge. This includes: • Seminars and training about our products • Modern knowledge transfer using webcasts, white papers and webinars • Technical reports, technical details and CAD drawings available by download www.schroff.co.uk/academy lifecycle We stay with you. For the entire life of the product. With ServicePLUS lifecycle you profit from our flexibly configurable, comprehensive support over the entire life of your products and complete solutions. Select options from our range to your exact needs and create your individual Lifecycle package. www.schroff.co.uk/lifecycle 06 18002_Hautpkatalog_Schroff_EN_AK03.indd 6 17.10.2012 11:20:41 HOW TO CONTACT US Your local contact ALL CONTACT DETAILS FOR YOUR PERSONAL CONTACT PARTNER ARE HERE: Online at www.schroff.biz/contact or in the address list at the end of this catalog. YOUR ONLINE CONTACT WITH SCHROFF At www.schroff.biz you can reach us round the clock. Use the inquiry basket to inquire online about the articles you require, simply and without complication, and receive a quotation within 24 hours. For customers who prefer quick and reliable processing when ordering stock products by authorized and qualified business partners, our distribution partners are the first choice. If you are looking for professional support for adapting our products to your individual needs, contact our value-added resellers. These can of course also supply off-the-shelf products. Decide together with us whether you would like support either from our direct sales department or through our business partners in various countries. See www.schroff.biz/contact for the advantages of the different sales and distribution options. WE WILL ANSWER YOUR INQUIRY WITHIN 24 HOURS Just send us an inquiry or order by e-mail to schroff.uk@pentair.com or to your personal contact. You can naturally also send us a fax. Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 7 07 17.10.2012 11:20:42 HOW TO OBTAIN OUR PRODUCTS ONLINE You will see our oneClick symbol next to many products in this catalogue. By entering the order number at www.schroff.biz/oneclick you can quickly and easily obtain further information about the relevant product. - detailed product description - scope of delivery information - detailed drawings - technical information - user manuals - test reports - downloadable CAD drawings - certificates - test reports You can also use the free text search available at www.schroff.biz under "Search" in the function bar: 5. September 2012 6:12 06 Cabinets – VARISTAR Electronics Apart from the order number, you can also enter product names or other terms. 19'' fixed shelf, 75 kg VARISTAR Electronics  Static load-carrying capacity 75 kg (150 kg with strengthening rail)  Mounting height 1 U, for mounting on four panel/slide mounts  With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing Catalogue D c RAL 7035 For cabinet Usable xf depth surface w x d mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece RAL 7021 Part no. 21130-303 21130-305 23130-310 Note  Cable ducting with cable ties, see page 1.25  Other sizes, see ServicePLUS, page 1.49 xf d c Order Information For further information www.schroff.biz/oneclick To help you get your bearings quickly and simply, all the ordering tables in this catalog are uniformly designed: - The first section contains the ordering information for the product. - The next section, indicated by a separating line, shows suitable accessories. - Order numbers printed in bold are available for shipping in 2 working days; order numbers in ordinary type can be shipped within 10 working days. - Further information, if available, on the product or accessories is shown at the end of the ordering table. 01004067 oneClick search code = Part no. ounts sion 08 18002_Hautpkatalog_Schroff_EN_AK03.indd 8 17.10.2012 11:20:46 Cabinets Overview............................................. 1.0 Varistar Cabinet platform.................. 1.2 Varistar Electronics........................... 1.10 Varistar EMC...................................... 1.54 Varistar Seismic................................ 1.84 Varistar MIL....................................... 1.120 Varistar Data/network systems........ 1.124 Varistar Containment........................ 1.202 LHX 20/40 Air/water heat exchangers..... 1.224 LHX 3 Air/water heat exchangers........... 1.236 Novastar............................................. 1.240 Eurorack............................................ 1.270 Outdoor ............................................. 1.316 Etsirack.............................................. 1.346 19” lab racks...................................... 1.354 PROLINE............................................ 1.362 1 2 Wall mounted case Overview............................................. 2.0 Epcase................................................ 2.36 LAN wall-mounted distributors........ 2.46 Cabinet and wall-mounted case accessories Overview............................................. 3.0 Mechanics.......................................... 3.2 Telescopic slides............................... 3.24 Electrical............................................ 3.29 Monitors, keyboards, monitoring...... 3.44 Socket strips...................................... 3.50 Power control socket strips.............. 3.72 Climate control Overview............................................. 4.0 Cooling concepts/service.................. 4.2 19” fan trays....................................... 4.4 Air filtered fans.................................. 4.20 Accessories........................................ 4.58 Desktop enclosures Overview............................................. 5.0 RatiopacPRO...................................... 5.6 PropacPRO........................................ 5.44 CompacPRO...................................... 5.76 Comptec............................................. 5.100 Accessories........................................ 5.108 Interscale........................................... 5.200 Minipac ............................................. 5.230 5 Subracks/ 19” chassis Overview............................................. 6.0 EuropacPRO...................................... 6.2 EuropacPRO for railroad applications.......................6.70 EuropacPRO industrial applications.. 6.86 EuropacPRO Rugged......................... 6.92 MultipacPRO...................................... 6.112 Inpac.................................................. 6.128 6 Front panels, Plug-in-units, Frame type plug-in-units Overview............................................. 7.0 Front panels....................................... 7.2 Plug-in units...................................... 7.16 Frame type plug-in units................... 7.64 PCB accessories................................ 7.102 Systems Overview............................................. 8.0 AdvancedTCA..................................... 8.2 AdvancedMC carriers........................ 8.26 MicroTCA............................................ 8.36 AdvancedMC modules....................... 8.56 CompactPCI, Serial, PlusIO, PSB..... 8.68 VME, VME64x, VXS, VPX..................... 8.88 Accessories........................................ 8.106 8 Power supply systems Overview............................................. 9.0 19” AC/DC switched-mode PSUs..... 9.2 19” AC/DC linear regulators............. 9.12 19” AC/DC convertors....................... 9.15 19” accessories................................. 9.18 PSUs for MicroTCA............................ 9.20 PSUs for VMEbus.............................. 9.22 PSUs for CompactPCI, VME64x.......... 9.24 9 Backplanes Overview........................................... 10.0 CompactPCI, Serial, PlusIO............ 10.4 PXI.................................................... 10.11 VXS................................................... 10.14 VME64x, VMEbus............................. 10.15 Power............................................... 10.18 Universal.......................................... 10.19 Test adaptors................................... 10.20 10 Connectors, Front panel component systems Overview........................................... 11.0 Connectors...................................... 11.2 Front panel component system...... 11.12 11 Appendix Standards abbreviations................. 12.0 Notes on ordering............................ 12.10 Order number index........................ 12.11 Product index................................... 12.62 12 3 4 7 Main Catalogue Cabinets – Overview Content Cabinets . . . . . . 1 VARISTAR Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 쮿 Cabinet platform for many application areas like electronics, datacom and networking technologies – 19" or metric versions – EMC shielded – Earthquake-proof – Variable cooling concepts – Air-conditioned cabinets – Extensive range of innovative cable routing accessories 쮿 Welded steel frame for static load-carrying capacity of up to 1200 kg 쮿 Type of protection IP 20 or IP 55 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 NOVASTAR 쮿 19" electronics cabinet for applications in the measurement and control, audio and video industries 쮿 Attractive design with visible profile frame, inset cladding parts and full glass doors 쮿 Cabinet height from 6 U to 47 U 쮿 Cabinet width only 553 mm 쮿 Screw fixed aluminium rack for static load-carrying capacity of up to 400 kg 쮿 Type of protection up to IP 40 NEW Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 P 쮿 19" cabinet for electronics applications 쮿 Screw fixed aluminium frame for static load-carrying capacity of up to 400 kg 쮿 Type of protection IP 40 Appendix . . . . . 12 36109003 (01006007 01005001 07011036 00105003 ) 1.2 SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Cabinets – Overview Overview . . . . . . 1.2 Outdoor VARISTAR . . . . . . 1.2 쮿 Aluminium cabinet for outdoor use and to accommodate 19", metric or non-standardized components 쮿 Type of protection IP 55 쮿 Single-wall or double-wall versions 쮿 Static load-carrying capacity up to 400 kg VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR MIL . . . . . . . . . . . . . 1.120 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR Aisle Containments . . . . 1.202 VARISTAR Air/water heat exchanger . . . . . . . 1.224 Z 쮿 Designed for telecommunications applications in accordance with the ETS standard 쮿 Steel construction, 300 mm deep 쮿 Static load-carrying capacity 200 kg 쮿 Type of protection IP 20 NOVASTAR . . . . . 1.240 eurorack . . . . . . . 1.270 Outdoor . . . . . . . . . 1.316 etsirack . . . . . . . . 1.346 Lab racks . . . . . . . 1.354 Lab Racks PROLINE . . . . . . . 1.362 쮿 Open 19" frame for lab applications, stationary or mobile 쮿 Steel construction 쮿 Static load-carrying capacity 200 kg Cabinet Accessories . . . . 3.0 36109004 (41602001 40012001 05601002 01305003) SCHROFF.PENTAIR.CO.UK 1.3 VARISTA RMain Catalogue Cabinets – VARISTAR Content Cabinets . . . . . . 1 VARISTAR Electronics Wall mounted cases . . . . . . . . . 2 쮿 Open cabinets with decorative frame 쮿 19" cabinets with IP 20 or IP 55 protection class Accessories for cabinets and wall mounted cases . 3 쮿 Extensive range of innovative accessories for electronics cabinets Climate control . 4 Electronics cases . . . . . . . . . 5 VARISTAR EMC 쮿 Shielding up to 60 dB at 1 GHz and 40 dB at 3 GHz Subracks/ 19" chassis . . . . 6 쮿 High shielding also when combined with perforated doors or fan top covers 쮿 Individual configuration options with ServicePLUS configuration Front panels, plug-in units . . . 7 Systems . . . . . . . 8 VARISTAR Seismic 쮿 Earthquake-resistant cabinets tested to Bellcore Zone 4 쮿 Individual configuration options with ServicePLUS configuration Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 VARISTAR MIL NEW 쮿 Tested and certified to MIL 901D 쮿 With shock absorbers 쮿 Shielded against high-frequency interference 쮿 IP 55 Appendix . . . . . 12 36108003 (01006007, 01004031, 01007002, 01005018, 01012004) 1.2 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Overview . . . . . . 1.2 VARISTAR Data and networking technology VARISTAR Platform . . . . . . . 1.4 쮿 Wide range of network and server cabinet versions 쮿 Server cabinets with depths up to 1200 mm 쮿 Two standard colors: light grey (RAL 7035) or black grey (RAL 7021) 쮿 Extensive, innovative range of cable routing accessories 쮿 Individual configuration options with ServicePLUS configuration VARISTAR Electronics . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . 1.84 VARISTAR Aisle containments NEW VARISTAR MIL . . . . . . . . . . . . 1.120 쮿 Cold aisle containments 쮿 Modular standard components 쮿 Extensive range of swing and sliding doors VARISTAR Datacom and Networking Technology . . . . 1.124 VARISTAR with air/water heat exchangers VARISTAR Aisle containment . . . . 1.202 LHX 20/40 쮿 Server cabinets with air/water heat exchanger VARISTAR Air/water heat exchangers . . . . . 1.224 쮿 Versions with single or double doors and with automatic door opening Cabinet Accessories . . . . 3.0 LHX 3 쮿 Electronics cabinets with LHX 3 air/water heat exchanger 36108004 (01006006, 01006015, 01012006, 01007015, 01006040) SCHROFF.PENTAIR.CO.UK 1.3 Cabinets – VARISTAR platform Two load-carrying classes, one accessory range: The VARISTAR frames VARISTA R platformMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days VARISTAR is the only cabinet platform that allows identical accessories to be combined with two basic frames. The cabinet is available in Slim-Line (narrow) or Heavy-Duty (robust) profiles. Slim-Line profile The Slim-Line version is based on very thin steel profiles in order to obtain the greatest opening width between the uprights. This frame can accommodate either 19" equipment or metric components to ETS 3000-119-3. With a maximum load of 400 kg* on the 19" plane the frame is still highly robust and suitable for demanding applications in electronics or data and network technology. Heavy-Duty profile 01004035 The Heavy-Duty frame, on the other hand, is designed for use with heavy loads or in regions susceptible to earthquakes. It offers on the one hand maximum stability for a load of up to 800 kg* on the 19" plane and, thanks to its high bending stiffness, can meet the shock and vibration requirements such as occur in railway and traffic signal installations, in the control of rotating machines, on commercial ships or in low-level military installations. In the IEC 61587-2 earthquake test the Heavy-Duty frame qualified for use in Bellcore Zone 3. Equipped with very simple, low-cost strengthening brackets, the VARISTAR Seismic version meets the demands of Bellcore Zone 4. 01006035 Slim-Line profile Static load-carrying capacity Type of protection Shock test 01006034 Heavy-Duty profile 01008062 Heavy-duty profile with strengthening bracket Standard IEC 61587-1 Slim-Line 400 kg * Heavy-Duty 800 kg * IEC 60529 IEC 61587-1 IP 20, IP 55 Maximum acceleration: 5 g Duration: 11 ms Frequency: 5 Hz -100 Hz Acceleration: 1 g IP 20, IP 55 Maximum acceleration: 5 g Duration: 11 ms Frequency: 5 Hz -100 Hz Acceleration: 1 g Standard: up to Bellcore With strengthening: up to Bellcore Zone 3, acceleration: 3 g, Zone 4, acceleration: 5 g, Frequency: 1 Hz ... 5 Hz Frequency: 2 Hz ... 5 Hz 60 dB at 1 GHz, 40 dB at 3 GHz 19" Vibration test IEC 61587-1 Earthquake test IEC 61587-2 EMC shielding Installing options IEC 61587-3 60 dB at 1 GHz, 40 dB at 3 GHz 19" or ETS * Figures for static load-carrying capacity are based on the IEC 61587-1 test procedure. In this procedure the cabinet is standing on the floor under its equipment load and lifted up by its lifting eyes; no significant deformations may occur on the frame or at the 19" panel/slide mounts under maximum carrying capacity. The potential load for the VARISTAR frame is therefore, under normal operating conditions, considerably higher than the test value given under IEC 61587-1. 1.4 SCHROFF PRODUCT CATALOG D 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR platform Decidedly different: The VARISTAR sealing and shielding concept VARISTAR platform Item 1 2 3 4 5 Description Frame Conductive EMC textile gasket with CuNi coating Contact/shielding Rear panel Side panel 2 3 In most shielding designs currently available, conductive seals or springs connect the cover parts to the cabinet frame. The points of contact have thus to be kept conductive and corrosion-free. With VARISTAR, however, the conductive textile gaskets link the cover parts with one another directly, which results in two advantages: A considerably better shielding performance of 60 dB at 1 GHz (and 40 dB at 3 GHz) is obtained than with conventional designs. There is no longer any need for expensive treatment of the frame surface. The textile EMC gasket is also a protection against dust and water to IP 55. If no shielding is required, a rubber gasket is used offering the same protection to IP 55. Both gaskets are fitted to the 45°-angled surface of the exterior of the frame. 4 5 1 Shielding up to 3 GHz [dBµV] 100 90 80 70 60 50 40 1 30 2 20 10 0 0 500 1000 1500 2000 2500 3000 [Mhz] 1: Cabinet with solid door 01004141 01008061 01008005 2: Cabinet with perforated door Smooth-running and absolutely tight: The VARISTAR locking system The latching system also contributes to protection class and shielding. The innovative locking bar accepts a variable number of deadbolts, depending on the cabinet height, to ensure the most even compression of the gaskets. And best of all: Activating the locking bar causes the latches to move in the opposite direction. Thus the frictional forces of the bolts are balanced out and a resulting lopsided vertical force on the door is avoided. The doors close easily and with an absolute seal. EMC doors are fitted with 4-point locking, IP and server doors with 3-point locking. 01005080 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.5 Cabinets – VARISTAR platform Peerless and efficient: The VARISTAR profile (Slim-Line and Heavy-Duty) VARISTA R platform Mounting of the 19" bracket without depth members The VARISTAR profile has fixing holes in all three axes (height, width, depth), following a 25 mm grid. This allows for the greatest variability in the fitting of components and accessories. Thus for example 19" panel/slide mounts may be installed in a 600 mm wide cabinet without additional depth members. This saves costs and provides stability on the 19" plane. The intricately shaped form of the profile offers further new assembly possibilities. Cable eyes, for instance, can be plugged directly into the frame whilst fixing themselves. 01004034 01006105 Self-fixing cable eyes dummy New and well thought out: VARISTAR cable management Schroff has divided the available space in the VARISTAR into zones and given a simple description of the position and use of these zones. The coloured arrows show the direction of the cable ducting. Zone 1 Zone 2 01006087 쮿 In front of the 19" plane 쮿 In this zone the patch cables are ducted horizontally between the distribution fields 1.6 Zone 3 01006088 쮿 On the right and left hand side, next to the 19" plane 쮿 In this zone patch cables are ducted vertically in a kind of channel to the individual components SCHROFF PRODUCT CATALOG D 05/2016 For each zone a range of accessories has been developed to suit the conditions in the cabinet, which simplifies cabling and thus helps to include as many connections as possible in a distribution cabinet. The VARISTAR profile with its many fixing options has thus proved a real boon. Zone 4 01006085 01006086 쮿 Zone 3 is located laterally behind the 쮿 Zone 4 is located in the rear across the cabinet width 19" plane across the cabinet depth; mainly for 800 mm wide cabinets 쮿 Alternative to zone 3 for only 600 mm wide cabinets or when cable 쮿 In this zone entering cable bundles entry is at the rear of the are fixed in the cabinet, parted and cabinet ducted to the rear of the distribution fields ELECTRONICS PROTECTION Cabinets – VARISTAR platform Heat dissipation to exact requirements: cooling concepts for VARISTAR Depending on installed heat dissipation and the surroundings, VARISTAR offers various cooling options and also good conditions for problem-free operation of the installed equipment. Either top cover fans are used to assist the heat dissipation or perforated doors with 78 % air throughput are fitted. Additionally, VARISTAR LHX 20/40 with assembled air/water heat exchanger allows to cool especially strained appliances with water. And that for up to 40 kW per cabinet. 01105057 up to 2 kW 01105056 up to 6 kW 01106027 Fan unit, positioned inside 0100581 up to 40 kW 41003017 78 % air throughput 01005020 Air/water heat exchanger Classic and consistent: VARISTAR colour and design \ As well as its functional aspects, in the development of VARISTAR the design of the individual components and their combined effect on the appearance of the cabinet was always a priority. The cabinet gains its characteristic, unmistakable look from the high narrow door with the memorable hinges and the very thin, almost inconspicuous top cover edge. While rack, base and cover are offered in black grey (RAL 7021) for all standard cabinets, a choice of two colour options are available - even in our standard programme - for side panels, doors and rear panels: Either entirely black grey (RAL 7021), as is the contemporary look in data centres and recording studios. Or in light grey (RAL 7035), whereby an attractive combination of mainly light surfaces with a few dark accents is obtained. Alternatively, VARISTAR can be supplied in many RAL colours within 15 working days, or even as a combination of two special colours. The current range of colours can be seen online at www.schroff.co.uk/modification. 01006037 Colour RAL 7021 (black grey) SCHROFF.PENTAIR.CO.UK 01006036 Colour combination RAL 7035/RAL 7021 (light grey/black grey) Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.7 Cabinets – VARISTAR platform Frame dimensions Height Cabinet height mm 1200 1400 1600 1800 2000 2200 Frame H mm 1192 1392 1592 1792 1992 2192 U 24 29 33 38 42 47 h mm 1102 1302 1502 1702 1902 2102 Width Cabinet width mm 600 800 Frame W mm 592 792 Slim-Line w mm 535 735 Heavy-Duty w mm 502 702 Depth 01005087 Adjustable feet Cabinet depth mm 300 600 800 900 1000 1100 1200 D mm 292 592 792 892 992 1092 1192 Frame d mm 128.8 428.8 628.8 728.8 828.8 928.8 1028.8 d1 mm 150 450 650 750 850 950 1050 d2 mm 175 475 675 775 875 975 1075 01004081 Castors with adjustable feet Locking castors Height of adjustable feet, castors, base/plinth Adjustable feet Locking castors Castors with adjustable feet Base/plinth (feet) Base/plinth, mobile 20 ... 40 mm 85 mm 85 ... 95 mm 112 ... 132 mm 126.5 ... 134.5 mm 01004082 01004156 Base/plinth Mobile base/plinth 0100411001004111 1.8 SCHROFF PRODUCT CATALOG D 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR platform Top cover with cut-out zones D 600 800 900 1000 1100 1200 a - b ✓ ✓ ✓ ✓ ✓ ✓ W = 600 mm c d ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ e ✓ ✓ ✓ a ✓ ✓ ✓ ✓ ✓ b ✓ ✓ ✓ ✓ ✓ ✓ W = 800 mm c d ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ e ✓ ✓ ✓ 01006097 Base plate, multi-piece b w a W c 200 50 D 600 800 900 1000 1100 1200 Cabinet width W mm 600 800 D 50 Depth in mm a 300 300 300 300 300 300 b 200 300 200 300 300 c 200 200 300 Opening width w mm 426 626 01006096 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.9 Varistar ElectronicsMain C atalogue Cabinets – Varistar Electronics Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01008004 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 01009002 19" panel mounts integrated in decorative frame 01005014 All-round gasketing to IP 55 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01009002 Side panels with quick-release fastener, optionally lockable 01005014 3-point locking with contradirectional bolts Appendix . . . . . 12 1.10 SCHROFF E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Overview . . . . 1.10 Varistar ElectronicsMain Catalogue The universal cabinet for electronics 쮿 Selectable stability, static load-carrying capacity up to 800 kg VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Professional solutions for cable ducting 쮿 Variable ventilation concepts, active and passive 쮿 Various versions in ServicePLUS configuration \ VARISTAR Deco VARISTAR IP 20 VARISTAR IP 55 VARISTAR Deco . . 1.12 VARISTAR IP 20 . . 1.13 VARISTAR IP 55 . . 1.14 Accessories Lever handle . . . . . 1.15 Base plate . . . . . . . 1.15 Base/plinth . . . . . . 1.16 Mounting plate . . . 1.17 19" swing frame . . . . . . . . . . . . 1.18 19 panel/slide mount . . . . . . . . . . . 1.19 19" fixing materials kit, M6 . . . . . . . . . . . . . . 1.19 Slide rails . . . . . . . . 1.20 19" shelves . . . . . . 1.21 Depth members . . 1.24 C horizontal rail . . 1.24 Cable tie, Velcro . . . . . . . . . . . 1.25 01004001 쮿 Open at front, with deco frame and integrated 19" panel mounts 01004002 쮿 With glass door and single point locking 01004003 쮿 With glass or steel door and 3-point locking ServicePLUS from page 1.26 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. variants of uprights (Slim-Line, Heavy-Duty) e.g. custom solutions (special sizes) ServicePLUS . . . 1.26 ServicePLUS IP 20 . . . . . . . . . . . . 1.27 ServicePLUS IP 55 . . . . . . . . . . . . 1.39 ServicePLUS Interior configuration . . . . . 1.44 VARISTAR EMC . . .1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . .1.124 VARISTAR air/ water heat exchanger . . . . . . . 1.224 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.11 Cabinets – Varistar Electronics Varistar Deco Varistar Electronics Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Open at front (no door) 쮿 19" panel mounts integrated into decoration frame 쮿 Rear door with single point locking, side panels with quick release fastener 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 4 1 5 2 6 1 7 8 2 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021 Adjustable foot, assembled Raised top cover, St, RAL 7021, with 10 mm air gap all around Decorative frame, Al, integrated 19" panel mounts at the front, RAL 7035 Adapter bracket, St, 2 mm, RAL 7035, front, for assembling shelves and slide rails Rear door, St, 180° hinge, single point locking and key with safety lock, RAL 7035 Side panel, St, with quick-release fastener, RAL 7035 GND/earthing kit, supplied loose Order Information 10 01004001 Height Height H Width W Depth D U mm mm mm 38 1800 600 600 38 1800 600 800 42 2000 600 600 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces Lever handle for single point locking with push button, 1 piece DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for raised top cover PU 4 pieces Part no. 10130-001 10130-002 10130-003 10130-004 23130-077 23130-078 23130-067 25127-995 23130-085 Note W D 20 - 45 H 쮿 Lever handle can be added to rear door 쮿 For more dimensions and versions see ServicePLUS IP 20, starting on page 1.27 쮿 Please order base plate separately, see page 1.15 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01004151 ServicePLUS see page 1.26 1.12 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Varistar IP 20 Varistar Electronic s 쮿 With glazed front door 쮿 Doors with single point locking, side panels with quick release fastener 쮿 Type of protection IP 20 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 4 1 5 1 6 2 7 2 8 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021 Adjustable foot, assembled Raised top cover, St, RAL 7021, with 10 mm air gap all around Front door, glazed, safety glass, 6 mm, 180° hinge, RAL 7035, single point locking, key lock cover Rear door, St, 180° hinge, RAL 7035, single point locking, key with safety lock Side panel, St, quick-release fastener with safety lock, RAL 7035 19" panel/slide mount with EIA cut-outs, St, RAL 7035, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 10 01004002 Height Height H Width W Depth D U mm mm mm 38 1800 600 600 38 1800 600 800 42 2000 600 600 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces Lever handle for single point locking with push button, 1 piece DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for raised top cover PU 4 pieces Part no. 10130-005 10130-006 10130-007 10130-008 23130-077 23130-078 23130-067 25127-995 23130-085 Note W D 20 - 45 H 쮿 Lever handle can be added to the doors 쮿 For other dimensions and versions see ServicePLUS configuration IP 20, from page 1.27 쮿 Please order base plate separately, see page 1.15 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01004152 ServicePLUS see page 1.26 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.13 Cabinets – Varistar Electronics VARISTAR IP 55 쮿 With glazed or steel front door 쮿 Doors with 3-point locking and screw-fixed side panels 쮿 Type of protection IP 55 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 4 1 1 5 6 7 1 2 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021, with all around rubber seals Adjustable foot, assembled Flat top cover, St, RAL 7021 Front door, St or glazed, RAL 7035, 180° hinge, 3-point locking, lever handle Rear panel, screw fixed, St, RAL 7035 Side panel, screw fixed, St, RAL 7035 Base plate, multi-piece, with cover plate, St, RAL 7021, with gasket 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01005006 Height Height H Width W Depth D Description U mm mm mm 42 2000 600 600 With glazed door 42 2000 600 600 With steel door Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces Part no. 10130-021 10130-022 23130-077 23130-078 25127-995 23130-072 Note 쮿 For other dimensions and versions see ServicePLUS configuration IP 55, from page 1.39 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01005014 ServicePLUS see page 1.26 1.14 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Lever handle for single point locking 쮿 For installation instead of key lock insert 쮿 To open press push-button 쮿 DIN profile half cylinder retrofittable Delivery comprises Item 1 2 Qty 1 1 Description Lever handle for single point locking Assembly kit Order Information Description Lever handle for single point locking DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys 01005016 Part no. 23130-067 25127-995 Note 쮿 Other locks such as ASSA, KABA or RONIS available on request Base plate, multi-piece 쮿 The multi-piece base plate is open at the rear 쮿 The opening may be completed – with a filter mat – with a brush strip for the cable entry – with a cover plate Delivery comprises (kit) Item 1 5 Qty 1 1 Description Multi-piece base plate, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01004050 1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter kit Width Depth mm mm 600 600 600 800 Item 2 Cover plate for base plate, multi-piece for 600 mm wide base plate, 200 mm deep, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for 600 mm width base plate, 200 mm deep, incl. assembly kit, 1 piece Item 4 Filter mat white, class M1 in accordance with EN 799-G3, for 600 mm wide base plate, 200 mm deep, incl. assembly kit, 1 piece Part no. 23130-001 23130-002 23130-076 23130-074 23130-075 Note 쮿 Is assembled from inside 쮿 Please order cover plate, brush strip or filter mat separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.15 Cabinets – Varistar Electronics Stationary base 쮿 Static load-carrying capacity 1000 kg 쮿 Removable covers allow cable entry from all sides 쮿 Cannot be used in conjunction with castors 쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm 쮿 Versions – Front/rear trim perforated – Front/rear trim solid Delivery comprises (kit) 2a H 2b 1 2b 2a W D = cabinet depth Item 1 2a 2b 3 Qty 2 2 2 1 Description Support with feet, St, 3 mm Solid trim, St, 1.5 mm, RAL 7021 Perforated trim, St, 1.5 mm, RAL 7021 Assembly kit Order Information D 4 01004110 01004053 For cabinet width W Front/rear trim mm 600 perforated 600 plain Item 4 Side trim height 100 mm, depth 600 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 800 mm, PU 2 pieces Part no. 23130-187 23130-387 23130-169 23130-170 Note 쮿 Please order side trims (item 4) separately Base/plinth, mobile 쮿 Load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 쮿 Plinth height H = 100 mm, with feet adjustable from 126 to 134 mm Delivery comprises Item 1 2 3 4 Qty 1 4 4 1 Description Frame, St, 3 mm, RAL 7021, with adjustable feet Trim, St, 1.5 mm, RAL 7021 Castor Assembly kit Order Information For cabinet width mm 600 600 For cabinet depth mm 600 800 Part no. 23130-208 23130-209 010041110 1006095 1.16 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Mounting plate 쮿 For mounting electrical components and sub-assemblies incl. cabling 쮿 Mounting pitch 25 mm in depth and 50 mm in height for partial-height mounting 쮿 Depth members are required for partial-height mounting 쮿 Static load – 450 kg at full height, mounted to rear – 600 kg at full height, mounted to rear, with additional strengthening brackets Delivery comprises Item 1 2 Qty 1 1 Description Mounting plate, St, 3 mm, zinc-plated Assembly kit Order Information Full height SCHROFF.PENTAIR.CO.UK 010080520 1008053 For partial-height mounting For cabinet height Width mm mm 1200 for partial-height mounting 600 1800 600 2000 600 Strengthening bracket for mounting plate PU 2 pieces Depth member St, 2 mm, for cabinet depth 600 mm, 2 pieces Depth member St, 2 mm, for cabinet depth 800 mm, 2 pieces Part no. 23130-413 23130-405 23130-407 23130-418 23130-081 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.17 Cabinets – Varistar Electronics 19" swing frame 쮿 Can accommodate 19" chassis and 19" subracks 2 쮿 For full height or partial-height mounting 쮿 Pivot point can be selected right or left 쮿 Load-carrying capacity 150 kg h2 h1 Delivery includes (kit) 1 ax. Tm Qty 1 2 2 2 1 Description Swing frame, St, 2 mm, RAL 7021 Support bar, St, 3 mm, RAL 7021 Square lock, 8 mm, incl. 2 keys 120° hinge Assembly kit Order Information 4 3 01005055 Item 1 2 3 4 5 01005059 Swing frame stop For cabinet height Height h1 mm U 900 for partial-height mounting 16 1200 for partial-height mounting 24 1400 for partial-height mounting 29 1600 for partial-height mounting 33 1800 38 2000 42 2200 47 Accessories Swing frame stop max. swing angle 120°, St, zinc-plated, 1 piece Security lock to replace the square lock, PU 1 lock incl. 2 keys Spare key for security lock, 1 piece Height h2 U 12 21 25 30 34 39 43 Part no. 21130-740 21130-741 21130-742 21130-743 21130-744 21130-745 21130-746 23130-158 60113-267 60220-003 Note 쮿 19" swing frames can be assembled: – Directly on the cabinet frame – In 50 mm increments by aid of depth members (depthadjustable) 쮿 For partial-height mounting, depth members are necessary, see page 1.24 01005061 Security lock 41001517 1.18 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19" panel/slide mount with universal pitch (EIA) 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 44,45 44.45 12,75 15,9 65,1 2 76 25 25 49,5 010041120 1004131 Standard assembly dimension xr = xf = 50 mm Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 9,6 42,5 Item 1 01005088 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. Partialheight 8 395 23130-037 23130-027 mounting Partialheight 12 545 23130-038 23130-028 mounting Partialheight 16 745 23130-039 23130-029 mounting Partialheight 20 895 23130-040 23130-030 mounting Partialheight 24 1095 23130-031 23130-021 mounting Partialheight 29 1295 23130-032 23130-022 mounting Partialheight 33 1495 23130-033 23130-023 mounting 1800 38 1695 23130-034 23130-024 2000 42 1895 23130-035 23130-025 Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 25127-997 Note 쮿 For 19" partial-height mounting depth members are necessary 쮿 Metric panel/slide mounts available on request 19" assembly kit, M6 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.19 Cabinets – Varistar Electronics Slide rails 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 Wide support surface (48 mm) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair Delivery comprises 01004056 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load carrying capacity 25 kg For cabinet depth D mm 600 600 800 800 xf c Length L Qty/PU mm 50 50 50 50 mm 500 500 700 700 mm 456 456 656 656 2 10 2 10 Part no. 23130-096 23130-101 23130-097 23130-102 01005086 Static load-carrying capacity 25 kg Order Information Static load carrying capacity 100 kg For cabinet depth D mm 600 600 800 800 c Length L Qty/PU mm 50 50 50 50 mm 500 500 700 700 mm 458 458 658 658 2 10 2 10 Part no. 23130-118 23130-123 23130-119 23130-124 01004058 19” c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth SCHROFF PRODUCT CATALOG E 08/2017 D c xf c - 130 Static load-carrying capacity 100 kg 1.20 xf 01004130 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19'' fixed shelf, 75 kg 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises Item 1 Qty 1 2 1 xr 01004066 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece D d Order Information RAL 7021 Part no. 21130-303 21130-305 23130-310 Note xf w 쮿 Cable ducting with cable ties, see page 1.25 쮿 Other sizes, see ServicePLUS, page 1.49 W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004067 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.21 Cabinets – Varistar Electronics 19'' telescopic shelf, 30 kg 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information D c c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 417 x 482 50 500 22130-343 800 417 x 682 50 700 22130-345 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Full depth RAL 7021 Part no. 21130-343 21130-345 23130-140 Note 쮿 Cable ducting with cable ties, see page 1.25 01004069 Order Information Shortened depth Shortened by 100 mm w For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 417 x 382 50 500 22130-342 800 417 x 582 50 700 22130-344 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-342 21130-344 23130-140 Note D c xr W xf d 쮿 Cable ducting with cable ties, see page 1.25 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension 1.22 SCHROFF PRODUCT CATALOG E 08/2017 01004070 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19'' telescopic shelf, 70 kg 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 Full depth W 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Delivery comprises xr w Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 405 x 482 50 500 22130-353 800 405 x 682 50 700 22130-355 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Order Information 01004069 c = max. pitch for 19" panel/slidemounts 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.25 w Order Information 21130-355 23130-092 23130-140 Shortened by 100 mm D For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 405 x 382 50 500 22130-352 800 405 x 582 50 700 22130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR d c Part no. 21130-353 Note W xr Shortened depth RAL 7021 RAL 7021 Part no. 21130-352 21130-354 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.25 c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004070 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.23 Cabinets – Varistar Electronics Depth member 쮿 For fitting shortened 19" panel/slide mounts and mounting plates 쮿 Cable ducting by means of cable ties and cable eye 50 Delivery comprises 121,2 25 25 100 37,5 36,5 11,5 L - 27 12 Item 1 2 Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information L Description 010041260 1004079 For cabinet depth mm Depth member 600 Depth member 800 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-081 23130-082 21101-151 21101-150 쮿 Cable ducting with cable ties, see page 1.25 coa43697 Cable eye C-profile for the cabinet depth 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut ,5 x Ø6 15 - 11 L 50 Part no. 23130-086 23130-087 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 29,5 L 50 31,5 For cabinet depth Length L mm mm 600 460 800 660 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 piece Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 piece 쮿 Cable ties and Velcro for cable retention rail see page 1.25 75 01504054 1.24 C-profile 01004132 01006071 Cable retention rail SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics C-profile for cabinet width Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-profile Slide nut For cabinet width Length mm mm 600 550 800 750 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-333 23130-334 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.25 75 01006071 01006064 Cable retention rail 01504054 Cable ties, Velcro Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie SCHROFF.PENTAIR.CO.UK 01005078 Velcro Part no. 20118-351 20118-352 20118-353 20118-624 01005079 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.25 Cabinets – Varistar Elektronics ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.27 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drilling, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts Varistar Elektronics ServicePLUS 1.26 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 ServicePLUS: configuration and assembly 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 300, 600 and 800 mm Page 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) Frames, side-by-side mounting kits, adjustable feet, castors 1.28 Side panels, rear panels 1.29 Decorative frames, glazed 1.30 doors 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Steel doors 1.31 Double doors 1.32 Flat top covers, lifting eyes 1.33 Flat top cover assemblies 1.34 with cut-out zones Fan top covers 1.35 Bases/plinths 1.36 Connecting plates for short doors/rear panels 1.37 Interior configuration for IP 20 and IP 55 19" panel/slide mounts 1.44 ETSI panel/slide mounts 1.45 Swing frames 1.46 Mounting plate, stationary 1.47 shelves, 75 kg 01004077 Example configuration (here: row 10) Qty 1 1 2 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece Side panel with quick-release fastener, RAL 7021, PU 2 pieces Safety lock for side panel, PU 4 pieces Rear panel, screw-fixed, RAL 7021, 1 piece Glazed door with single point locking, RAL 7021, IP 20, 1 piece Adjustable feet, PU 4 pieces .......... Order no. 20130-019/05 21130-051/05 23130-132/05 21130-069/05 21130-129/05 23130-079/05 .......... Telescopic shelves, 70 kg 1.48 19" shelves 1 U, fixed 75 kg, telescopic 30 kg 1.49 19" telescopic shelf, 2 U, 70 kg 1.50 Slide rails, depth members 1.51 Cable ductings 1.52 Cable ties, Velcro 1.53 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.27 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Frames, side-by-side mounting kits, adjustable feet, castors Order Information Frame Slim-Line 400 kg Heavy-Duty 800 kg Side-by-side mounting kit IP 20 Side-by-side mounting kit IP 55 (with gasketing) Adjustable feet Castors With 2 jacking feet With adjustable feet Completely in RAL 7021 (black grey) 01004078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004117 01004081 01004082 01004156 for the frame, for the frame, for the frame, side-by-side side-by-side static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: mounting bracket mounting bracket carrying capacity: carrying capacity: carrying capacity: (4 pieces), St, (4 pieces), St; 800 kg, 400 kg, 400 kg, 400 kg, 1000 kg, RAL 7021, incl. St, 1.5 mm, zinc- St, 1.5 mm, zinc- RAL 7021, not in cannot be used cannot be used cannot be used gasketing to combination with plated, with plated, with with base/plinth with base/plinth with base/plinth cover the gap decorative frame central GND/ central GND/ between two earthing point; earthing point; racks; not in please order please order combination with adjustable feet or adjustable feet or decorative frame castors castors separately separately 1 piece 1 piece PU 1 kit PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled supplied loose RAL 7021 RAL 7021 RAL 7021 20130-005 20130-055 20130-006 20130-056 20130-009 20130-059 20130-010 20130-013 20130-060 20130-063 20130-014 20130-064 20130-015 20130-017 20130-065 – 20130-018 20130-068 20130-019 20130-022 20130-069 20130-072 20130-023 20130-073 20130-026 20130-027 20130-077 20130-028 20130-078 20130-032 20130-082 – supplied loose assembled 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-061 23130-062 23130-062 23130-079 23130-079 23130-077 23130-077 23130-078 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.28 RAL 7021 RAL 7021 RAL 7021 29 1400 600 600 20130-005 20130-055 23130-061 23130-062 29 1400 600 800 20130-006 20130-056 33 1600 600 600 20130-009 20130-059 23130-061 23130-062 33 1600 600 800 20130-010 20130-060 38 1800 600 600 20130-013 20130-063 23130-061 23130-062 38 1800 600 800 20130-014 20130-064 38 1800 800 600 20130-015 20130-065 23130-061 23130-062 42 2000 600 300 – 20130-017 23130-061 23130-062 42 2000 600 600 20130-018 20130-068 23130-061 23130-062 42 2000 600 800 20130-019 20130-069 42 2000 800 600 20130-022 20130-072 23130-061 23130-062 42 2000 800 800 20130-023 20130-073 47 2200 600 300 20130-026 – 23130-061 23130-062 47 2200 600 600 20130-027 20130-077 23130-061 23130-062 47 2200 600 800 20130-028 20130-078 47 2200 800 800 20130-032 20130-082 23130-061 23130-062 Other dimensions and configurations online (with basket) at www.schroff.biz/conf SCHROFF PRODUCT CATALOG E 08/2017 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Side panels, rear panels Order Information Side panel With quick release fastener Screw-fixed side panel Lock Rear panel With quick release fastener Screw-fixed rear panel Lock Completely in RAL 7021 (black grey) 01004084 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004072 for quick-release St, 1 mm, incl. fasteners of one GND/earthing, side panel; please order lock 4 locks sufficient separately for 2 side panels 01004083 St, 1 mm, incl. GND/earthing 01004087 01004072 for quick-release St, 1 mm, incl. fasteners of rear GND/earthing, panel please order lock separately 01004085 St, 1 mm, incl. GND/earthing Cabinet dimensions Height No. U mm Width Depth PU 2 pieces PU 4 pieces PU 2 pieces 1 piece PU 2 pieces 1 piece mm mm assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-043 21130-003 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 21130-044 21130-045 21130-046 21130-047 21130-048 21130-047 23130-132 23130-132 23130-132 21130-004 21130-005 21130-006 21130-007 RAL 7021 21130-093 23130-133 21130-063 21130-095 23130-133 21130-065 21130-097 23130-133 21130-067 23130-132 21130-008 21130-007 21130-098 23130-133 21130-068 21130-049 23130-132 21130-009 21130-099 23130-133 21130-069 21130-050 21130-051 23130-132 21130-010 21130-011 21130-099 23130-133 21130-069 21130-100 23130-133 21130-070 21130-101 23130-133 21130-071 21130-101 23130-133 21130-071 21130-102 23130-133 21130-072 21130-050 21130-051 21130-054 21130-055 21130-056 21130-056 23130-132 23130-132 23130-132 23130-132 21130-010 21130-011 21130-014 21130-015 21130-016 21130-016 RAL 7035 RAL 7035 22130-043 22130-003 22130-044 22130-045 22130-046 22130-047 22130-048 22130-047 23130-132 23130-132 23130-132 22130-004 22130-005 22130-006 22130-007 RAL 7035 RAL 7035 22130-093 23130-133 22130-063 22130-095 23130-133 22130-065 22130-097 23130-133 22130-067 23130-132 22130-008 22130-007 22130-098 23130-133 22130-068 22130-049 23130-132 22130-009 22130-099 23130-133 22130-069 22130-050 22130-051 23130-132 22130-010 22130-011 22130-099 23130-133 22130-069 22130-100 23130-133 22130-070 22130-101 23130-133 22130-071 22130-101 23130-133 22130-071 22130-102 23130-133 22130-072 22130-050 22130-051 22130-054 22130-055 22130-056 22130-056 23130-132 23130-132 23130-132 23130-132 22130-010 22130-011 22130-014 22130-015 22130-016 22130-016 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.29 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Decorative frames, glazed doors Order Information Deco frame Deco frame Glazed door Adapter bracket Single point locking Glazed door Lever handle 3-point locking DIN profile half cylinder Completely in RAL 7021 (black grey) 01004086 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Al, 19" plane integrated, front open, incl. GND/earthing, no door can be fitted 01004160 St, 2 mm, for deco frame, for assembly of slide rails and shelves 01004088 St, 1.5 mm, Sekurit glass 6 mm, opening angle 180°, lock cover, incl. GND/ earthing 01004147 with push button for doors with single point locking 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.30 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece PU 1 pair 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-232 23130-221 21130-123 23130-067 21130-183 25127-995 21130-233 23130-222 21130-125 23130-067 21130-185 25127-995 21130-234 23130-223 21130-127 23130-067 21130-187 25127-995 RAL 7021 – – 21130-128 23130-067 21130-188 25127-995 21130-235 23130-224 21130-129 23130-067 21130-189 25127-995 21130-235 23130-224 21130-129 23130-067 21130-189 25127-995 – – 21130-130 23130-067 21130-190 25127-995 21130-236 23130-225 21130-131 23130-067 21130-191 25127-995 21130-236 23130-225 21130-131 23130-067 21130-191 25127-995 – – 21130-132 23130-067 21130-192 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-232 23130-231 22130-123 23130-067 22130-183 25127-995 22130-233 23130-232 22130-125 23130-067 22130-185 25127-995 22130-234 23130-233 22130-127 23130-067 22130-187 25127-995 RAL 7035 – – 22130-128 23130-067 22130-188 25127-995 22130-235 23130-234 22130-129 23130-067 22130-189 25127-995 22130-235 23130-234 22130-129 23130-067 22130-189 25127-995 – – 22130-130 23130-067 22130-190 25127-995 22130-236 23130-235 22130-131 23130-067 22130-191 25127-995 22130-236 23130-235 22130-131 23130-067 22130-191 25127-995 – – 22130-132 23130-067 22130-192 25127-995 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Steel doors Order Information Steel door, single point locking Plain Solid, inner surface with mounting frame Perforated Lever handle Steel door 3-point locking DIN profile half cylinder Completely in RAL 7021 (black grey) 01004089 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) St, 1 mm, opening angle 180°, key, incl. GND/ earthing 01008067 St, 1.5 mm, opening angle 180°, lock cover incl. GND/ earthing, designed to carry extensive cutouts and assemblies 01004090 St, 1.5 mm, opening angle 180°, key, incl. GND/ earthing 01004147 with push button for doors with single point locking 01008085 St, 1.5 mm, opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-108 21130-568 21130-138 23130-067 21130-153 25127-995 21130-110 21130-570 21130-140 23130-067 21130-155 25127-995 21130-112 21130-572 21130-142 23130-067 21130-157 25127-995 21130-113 21130-573 21130-143 23130-067 21130-158 25127-995 21130-114 21130-574 21130-144 23130-067 21130-159 25127-995 21130-114 21130-574 21130-144 23130-067 21130-159 25127-995 21130-115 21130-575 21130-145 23130-067 21130-160 25127-995 21130-116 21130-576 21130-146 23130-067 21130-161 25127-995 21130-116 21130-576 21130-146 23130-067 21130-161 25127-995 21130-117 21130-577 21130-147 23130-067 21130-162 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-108 22130-568 22130-138 23130-067 22130-153 25127-995 22130-110 22130-570 22130-140 23130-067 22130-155 25127-995 22130-112 22130-572 22130-142 23130-067 22130-157 25127-995 22130-113 22130-573 22130-143 23130-067 22130-158 25127-995 22130-114 22130-574 22130-144 23130-067 22130-159 25127-995 22130-114 22130-574 22130-144 23130-067 22130-159 25127-995 22130-115 22130-575 22130-145 23130-067 22130-160 25127-995 22130-116 22130-576 22130-146 23130-067 22130-161 25127-995 22130-116 22130-576 22130-146 23130-067 22130-161 25127-995 22130-117 22130-577 22130-147 23130-067 22130-162 25127-995 RAL 7021 RAL 7035 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.31 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Double doors Order Information Double door, 3-point locking Glazed Perforated DIN profile half cylinder Plain Completely in RAL 7021 (black grey) 01005065 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01005066 01005064 St, 1.5 mm, St, 1.5 mm, frame, St, opening angle opening angle 1.5 mm, 180°, 180°, Securit glass, lever handle with lever handle with 6 mm, push button, incl. push button, incl. opening angle GND/earthing GND/earthing 180°, lever handle with push button, incl. GND/earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-454 21130-213 21130-486 25127-995 21130-456 21130-215 21130-488 25127-995 21130-458 21130-217 21130-490 25127-995 21130-459 21130-218 21130-491 25127-995 21130-460 21130-219 21130-492 25127-995 21130-460 21130-219 21130-492 25127-995 21130-461 21130-220 21130-493 25127-995 21130-462 21130-221 21130-494 25127-995 21130-462 21130-221 21130-494 25127-995 21130-463 21130-222 21130-495 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-454 22130-213 22130-486 25127-995 22130-456 22130-215 22130-488 25127-995 22130-458 22130-217 22130-490 25127-995 22130-459 22130-218 22130-491 25127-995 22130-460 22130-219 22130-492 25127-995 22130-460 22130-219 22130-492 25127-995 22130-461 22130-220 22130-493 25127-995 22130-462 22130-221 22130-494 25127-995 22130-462 22130-221 22130-494 25127-995 22130-463 22130-222 22130-495 25127-995 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Flat top covers, lifting eyes Order Information Flat top cover Plain flush top cover Perforated Spacer Lifting eye Spacer Lifting eye 10 Completely in RAL 7021 (black grey) M12 01004096 St, 1.5 mm, incl. GND/ earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004097 M12 01004100 01004099 01004100 St, 1.5 mm, fully perforated, incl. GND/ earthing for top cover, applications and load in accordance with DIN 582 St, zinc-plated, for raising a top cover by 10 mm for raised flat top cover, application and static loadcarrying capacity in accordance with DIN 582 Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled assembled assembled assembled RAL 7021 RAL 7021 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-242 21130-262 21130-243 21130-263 21130-242 21130-243 21130-262 21130-263 21130-242 21130-262 21130-243 21130-246 21130-263 21130-266 23130-072 23130-068 23130-085 21130-241 21130-261 23130-072 23130-068 23130-085 21130-242 21130-243 21130-262 21130-263 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-246 21130-266 21130-247 21130-241 21130-267 21130-261 21130-242 21130-262 21130-243 21130-247 21130-263 21130-267 RAL 7021 RAL 7021 21130-242 21130-262 21130-243 21130-263 21130-242 21130-243 21130-262 21130-263 21130-242 21130-262 21130-243 21130-246 21130-263 21130-266 23130-072 23130-068 23130-085 21130-241 21130-261 23130-072 23130-068 23130-085 21130-242 21130-243 21130-262 21130-263 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-246 21130-266 21130-247 21130-241 21130-267 21130-261 21130-242 21130-262 21130-243 21130-247 21130-263 21130-267 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.33 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Flat top cover assemblies with cut-out zones Order Information Flat top cover with cut-out zones Top cover assemblies Brush strip Fan insert Thermostat Top cover plate, perforated Edge protection Lifting eye 30 20 40 10 50 0 60 °C Completely in RAL 7021 (black grey) 1000 mm 300 mm M12 300 mm 01004098 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01006092 01004102 W 01108052 D 01009056 230 VAC, nylon, black, one with mains cable St, 1.5 mm, 6 mm St, 1.5 mm, hole diameter, brush strip covers with three fans, 230 VAC incl. GND/ 3 incl. GND/ (SCHUKO/UTE earthing, number a lateral cut-out, 410 m /h, earthing two brush strips plug/ of cut-outs and completely cover a center wired, connecting IEC 60320 C13 dimension cut-out socket), drawings cable IEC 320 adjustment range see page 0 ... 60°C 1.9 41003065 01004100 PVC, 3 m, black, for open cut-out zones for top cover, applications and load in accordance with DIN 582 Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.34 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece PU 2 pieces 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled enclosed loose assembled RAL 7021 RAL 7021 21130-252 21130-253 21130-252 21130-253 21130-252 21130-253 21130-256 RAL 7021 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – – 21130-252 21130-253 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 21130-256 21130-257 – 21130-252 21130-253 21130-257 RAL 7021 21130-252 21130-253 21130-252 21130-253 21130-252 21130-253 21130-256 RAL 7021 RAL 7021 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – – 21130-252 21130-253 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 21130-256 21130-257 – 21130-252 21130-253 21130-257 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Fan top covers Order Information Fan top cover Top cover for 6 fans Replacement fan for fan top Thermostat Speed control Lifting eye 30 20 40 10 50 0 60 °C Completely in RAL 7021 (black grey) 1000 mm 300 mm 300 mm 01005060 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK kta44844 01108052 01105055 01005085 fully wired, for fan top cover, St, 1.5 mm, raised fan with grille for with mains cable 90 ... 264 VAC, applications and top assembly, 230 VAC cover, static load230 VAC, (SCHUKO/UTE input SCHUKO/UTE 3 axial fans, carrying capacity plug/ plug, 230 VAC, 38x119x119 mm, 3 in accordance incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 outlet IEC 60320 C1 with DIN 582 socket), 3 socket; external ND/earthing, h adjustment range NTC sensor 1.5 m connecting cable 0 ... 60°C 2.5 m, SCHUKO/ IEC60320 C12 plug 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 RAL 7021 21130-400 21130-401 21130-400 21130-401 21130-400 21130-401 21130-402 23130-165 20118-750 60715-005 23130-090 – – – – – 21130-400 21130-401 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 – – – – 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 21130-402 21130-403 – 21130-400 21130-401 21130-403 RAL 7021 21130-400 21130-401 21130-400 21130-401 21130-400 21130-401 21130-402 23130-165 20118-750 60715-005 23130-090 – – – – – 21130-400 21130-401 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 – – – – 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 21130-402 21130-403 – 21130-400 21130-401 21130-403 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.35 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Bases/plinths Order Information Base plate Base plate, multipiece Brush strip Base/plinth Dust filter set Cover plate Base/plinth, ventilated Side covers Base/plinth, mobile Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1.36 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004105 01004059 01004106 01004110 support with adjustable feet and 2 trims, perforated, static load-carrying capacity 1000 kg; please order side trims separately 01004053 St, 1.5 mm 01004111 support, St, 3 mm, trim, St, 1.5 mm, static load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg nylon, black 1 piece 1 piece 1 piece PU 1 kit PU 1 pair 1 piece assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-074 filter mat, white, class M1, in accordance with EN 799-G3 St, 1.5 mm, please order gasket IP55 separately St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing ; dimension drawings see page 1.9 1 piece 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-074 23130-135 23130-075 23130-136 23130-194 23130-187 – 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-074 23130-075 23130-076 23130-187 23130-006 23130-134 23130-135 23130-136 23130-194 RAL 7021 RAL 7021 RAL 7021 RAL 7021 23130-002 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 08/2017 23130-074 23130-075 23130-076 23130-187 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-208 23130-170 23130-209 23130-169 23130-166 23130-212 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-170 23130-213 23130-166 23130-169 23130-208 – – 23130-170 23130-209 23130-170 23130-213 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-170 23130-208 23130-209 23130-074 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-166 – 23130-169 23130-170 23130-208 23130-209 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-169 23130-212 23130-170 23130-166 23130-213 23130-169 23130-208 23130-170 23130-170 23130-209 23130-213 – ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Connecting plates for short doors/rear panels Order Information Dimensioning connecting plate door/rear panel Connecting plate for door and rear panel Plain With brush strip Assembly kit Other VARISTAR interior mounting parts Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door 01005063 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01005069 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01004066 01004056 only required if rear panel with quick-release fastener is assembled above the connecting plate 1 piece 1 piece PU 1 kit assembled assembled assembled RAL 7021 RAL 7021 21130-472 21130-473 21130-478 21130-479 rack shelves, 19" shelves, slide rails, cable ducting 23130-164 23130-164 from page 1.44 from page 1.44 RAL 7035 RAL 7035 22130-472 22130-478 23130-164 22130-473 22130-479 23130-164 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.37 Cabinets – Varistar Elektronics ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.39 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drilling, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.38 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 ServicePLUS: configuration and assembly 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 300, 600 and 800 mm Page 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Frames, side-by-side mounting kits, adjustable feet, castors 1.40 Side panels, rear panels, doors, top covers 1.41 Flat top covers, lifting eyes 1.42 Connecting plates for short doors/rear panels 1.43 Interior configuration for IP 20 and IP 55 19" panel/slide mounts 1.44 ETSI panel/slide mounts 1.45 Swing frames 1.46 Mounting plates, stationary shelves, 75 kg 1.47 Telescopic shelves, 70 kg 1.48 19" shelves 1 U, fixed 75 kg, telescopic 30 kg 1.49 19" telescopic shelves, 2 U, 70 kg 1.50 Slide rails, depth members 1.51 Cable ductings 1.52 Cable ties, Velcro 1.53 01004077 Example configuration (here: row 10) Qty 1 1 1 1 1 1 .. Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece IP 55 gasketing kit, 1 piece Side panel, screw-fixed, RAL 7021, PU 2 pieces Rear panel, screw-fixed, RAL 7021, 1 piece Glazed door with 3-point locking, RAL 7021, IP 55, 1 piece Adjustable feet, PU 4 pieces .......... SCHROFF.PENTAIR.CO.UK Part no. 20130-019/05 23130-064/05 21130-011/05 21130-069/05 21130-189/05 23130-079/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.39 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Frames, side-by-side mounting kits, adjustable feet, castors Order Information Frame Slim-Line 400 kg Heavy-Duty 800 kg Gasket kit IP 55 Side-by-side mounting kit IP 55 (with gasketing) Adjustable feet Castors with 2 jacking feet with adjustable feet Completely in RAL 7021 (black grey) 01004078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004157 01004120 01004081 01004082 01004158 for the frame, for the frame, for the frame, side-to-side seals are glued to static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: the frame, so that mounting bracket carrying capacity: carrying capacity: carrying capacity: (4 pieces), St, all cladding parts 800 kg, 400 kg, 400 kg, 400 kg, 1000 kg, RAL 7021, incl. conform to St, 1.5 mm, zinc- St, 1.5 mm, zinccannot be used cannot be used cannot be used gasketing to protection type plated, with plated, with with base/plinth with base/plinth with base/plinth cover the gap IP 55 central GND/ central GND/ between two earthing earthing racks; cannot be point; please point; please used with order adjustable order adjustable decorative frame feet or castors feet or castors separately separately 1 piece 1 piece PU 1 kit PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled RAL 7021 RAL 7021 20130-005 20130-055 20130-006 20130-056 20130-009 20130-059 20130-010 20130-013 20130-060 20130-063 20130-014 20130-064 20130-015 20130-017 20130-065 – 20130-018 20130-068 20130-019 20130-022 20130-069 20130-072 20130-023 20130-073 20130-026 20130-027 20130-077 20130-028 20130-078 20130-032 20130-082 – assembled supplied loose assembled 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-064 23130-062 23130-062 23130-079 23130-079 23130-077 23130-077 23130-078 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.40 RAL 7021 RAL 7021 29 1400 600 600 20130-005 20130-055 23130-064 23130-062 29 1400 600 800 20130-006 20130-056 33 1600 600 600 20130-009 20130-059 23130-064 23130-062 33 1600 600 800 20130-010 20130-060 38 1800 600 600 20130-013 20130-063 23130-064 23130-062 38 1800 600 800 20130-014 20130-064 38 1800 800 600 20130-015 20130-065 23130-064 23130-062 42 2000 600 300 – 20130-017 23130-064 23130-062 42 2000 600 600 20130-018 20130-068 23130-064 23130-062 42 2000 600 800 20130-019 20130-069 42 2000 800 600 20130-022 20130-072 23130-064 23130-062 42 2000 800 800 20130-023 20130-073 47 2200 600 300 20130-026 – 23130-064 23130-062 47 2200 600 600 20130-027 20130-077 23130-064 23130-062 47 2200 600 800 20130-028 20130-078 47 2200 800 800 20130-032 20130-082 23130-064 23130-062 Other dimensions and configurations online (with basket) at www.schroff.biz/conf SCHROFF PRODUCT CATALOG E 08/2017 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Side panels, rear panels, doors, top covers Order Information Screw-fixed side panel Screw-fixed rear panel Glazed door 3-point locking Steel door 3-point locking DIN profile half cylinder Plain flush top cover Flat top cover Lifting eye Completely in RAL 7021 (black grey) M12 01004083 St, 1 mm, incl. GND/earthing 01004085 St, 1 mm, incl. GND/earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing Cabinet dimensions Height No. U mm 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 01004096 01004100 St, 1.5 mm, incl. GND/earthing for top cover, applications and load in compliance with DIN 582 Depth PU 2 pieces 1 piece 1 piece 1 piece 1 piece 1 piece PU 4 pieces mm mm assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 21130-063 21130-183 21130-153 25127-995 21130-065 21130-185 21130-155 25127-995 21130-067 21130-187 21130-157 25127-995 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 01004148 for lever handle, common locking Width Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 01008085 St, 1.5 mm, opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/ earthing 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 21130-003 21130-004 21130-005 21130-006 21130-007 21130-008 21130-007 21130-009 21130-010 21130-011 21130-010 21130-011 21130-014 21130-015 21130-016 21130-016 RAL 7035 22130-003 22130-004 22130-005 22130-006 22130-007 22130-008 22130-007 22130-009 22130-010 22130-011 22130-010 22130-011 22130-014 22130-015 22130-016 22130-016 RAL 7021 21130-242 21130-243 21130-242 21130-243 21130-242 23130-072 23130-072 23130-072 21130-068 21130-188 21130-158 25127-995 21130-243 21130-246 21130-069 21130-189 21130-159 25127-995 21130-241 23130-072 21130-242 21130-243 23130-072 21130-069 21130-189 21130-159 25127-995 21130-070 21130-190 21130-160 25127-995 21130-071 21130-191 21130-161 25127-995 21130-071 21130-191 21130-161 25127-995 21130-072 21130-192 21130-162 25127-995 RAL 7035 RAL 7035 RAL 7035 21130-246 21130-247 21130-241 21130-242 21130-243 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 RAL 7021 22130-063 22130-183 22130-153 25127-995 22130-065 22130-185 22130-155 25127-995 22130-067 22130-187 22130-157 25127-995 21130-242 21130-243 21130-242 21130-243 21130-242 23130-072 23130-072 23130-072 22130-068 22130-188 22130-158 25127-995 21130-243 21130-246 22130-069 22130-189 22130-159 25127-995 21130-241 23130-072 21130-242 21130-243 23130-072 22130-069 22130-189 22130-159 25127-995 22130-070 22130-190 22130-160 25127-995 22130-071 22130-191 22130-161 25127-995 22130-071 22130-191 22130-161 25127-995 22130-072 22130-192 22130-162 25127-995 21130-246 21130-247 21130-241 21130-242 21130-243 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.41 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Flat top covers, lifting eyes Order Information Base plate Base plate, multipiece Cover plate Seal IP 55 Base plate, one-piece, EMC, IP 55 Base/plinth Base/plinth, ventilated Side cover Base/plinth, mobile Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1.42 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004106 01004073 for base plate with cover 01004051 AlZn, 1.5 mm, incl. GND/ earthing, assembly from outside 01004110 support with adjustable feet and 2 trims, perforated, static load-carrying capacity 1000 kg; please order side trims separately 01004053 St, 1.5 mm 01004111 support, St, 3 mm, trim, St, 1.5 mm, static loadcarrying capacity on castors 400 kg, on adjustable feet 1000 kg St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing, dimension drawings see page 1.9 1 piece St, 1.5 mm, please order gasket IP55 separately 1 piece 1 piece 1 piece PU 1 kit PU 1 pair 1 piece assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 AlZn RAL 7021 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-076 23130-073 23130-076 23130-073 23130-076 23130-073 23130-036 23130-073 23130-073 – 23130-076 23130-073 23130-036 23130-073 – 23130-073 23130-076 23130-073 23130-006 23130-076 23130-073 RAL 7021 RAL 7021 23130-002 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 08/2017 23130-076 23130-073 23130-076 23130-073 23130-076 23130-073 21130-281 21130-282 21130-281 21130-282 21130-281 21130-282 21130-283 21130-285 21130-281 21130-282 21130-283 21130-284 21130-285 21130-281 21130-282 23130-187 23130-194 23130-187 23130-187 RAL 7021 21130-282 21130-281 21130-282 21130-281 23130-073 23130-073 21130-285 23130-076 23130-073 21130-281 21130-282 23130-036 23130-073 – 23130-073 23130-073 23130-194 23130-187 AlZn 21130-281 – 23130-076 23130-187 23130-194 23130-036 23130-073 23130-187 21130-284 21130-282 21130-283 23130-076 23130-187 21130-283 21130-284 21130-285 21130-281 21130-282 21130-284 23130-187 23130-187 23130-187 23130-194 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-208 23130-170 23130-209 23130-169 23130-166 23130-212 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-170 23130-213 23130-166 23130-169 23130-208 – – 23130-170 23130-209 23130-170 23130-213 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-170 23130-208 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-187 23130-166 – 23130-187 23130-169 23130-170 23130-208 23130-209 23130-194 23130-187 23130-187 23130-194 23130-169 23130-212 23130-170 23130-166 23130-213 23130-169 23130-208 23130-170 23130-170 23130-209 23130-213 – ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Connecting plates for short doors/rear panels Order Information Dimensioning connecting plate door/rear panel Connecting plate Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK 01005072 St, 1 mm, can door and rear also be fitted in panel must be upper part, selected 400 mm height 400 mm, shorter than the cabinet height; with assembly kit cannot be used with double door 1 piece assembled RAL 7021 21130-504 21130-505 RAL 7035 22130-504 22130-505 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.43 Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" panel/slide mounts Order Information 19" panel/slide mounts EIA Painted RAL 7021 AIZn 19" assembly kit M6 Adapter bracket for reduced width W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) U height identification for 19" panel/ slide mount c D Dimension Standard fitting xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width 01004112 St, 1.75 mm; reduced-width adapter bracket required for 800 mm width; depth members are required for partial-height mounting 00505050 sc128 paper strip, white, assembly kit: serial numbered item 1: screws, from 1 ... 47 H item 2: cage nuts, item 3: washers 01004128 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.44 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF PRODUCT CATALOG E 08/2017 PU 1 pair PU 1 pair PU 4 pieces PU 50 pieces PU 4 pieces assembled assembled assembled supplied loose assembled RAL 7021 AIZn 23130-012 23130-032 25127-997 21101-809 – 23130-013 23130-033 25127-997 21101-809 – 23130-014 23130-034 25127-997 21101-809 – AIZn 23130-014 23130-034 25127-997 21101-809 23130-091 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 23130-091 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 23130-091 RAL 7035 AlZn 23130-022 23130-032 25127-997 21101-809 – 23130-023 23130-033 25127-997 21101-809 – 23130-024 23130-034 25127-997 21101-809 – AlZn 23130-024 23130-034 25127-997 21101-809 23130-091 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 23130-091 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 23130-091 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting ETSI panel/slide mounts Order Information ETSI panel/slide mount Dimensions Panel/slide mount Completely in RAL 7021 (black grey) coa43693 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004114 St, 2 mm, in accordance Al-Zn finish, with ETS 300119suitable only for 3 and IEC 60917-211; Slim-Line frame; shelves available SU = 25 mm on request Cabinet dimensions Height No. U mm Width Depth mm mm Height SU Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 AIZn 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK PU 1 pair assembled 23130-052 23130-053 23130-054 23130-054 23130-055 23130-055 23130-055 23130-056 23130-056 23130-056 AlZn 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 23130-052 23130-053 23130-054 23130-054 23130-055 23130-055 23130-055 23130-056 23130-056 23130-056 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.45 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Swing frames for cabinet width 600 mm Order Information Swing frame Stop 120° Safety lock 01005070 Height U partial height partial height 29 33 38 42 47 Spare key 01005061 01015060 St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) St; for safety reasons a swing frame stop is recommended for swing frame, instead of square lock, incl. 2 keys 01015059 Usable height U Width mm 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces supplied loose 12 600 21130-740 23130-158 60113-267 60220-003 21 600 21130-741 23130-158 60113-267 60220-003 25 30 34 39 43 600 600 600 600 600 21130-742 23130-158 60113-267 60220-003 21130-743 21130-744 23130-158 23130-158 60113-267 60113-267 60220-003 60220-003 21130-745 23130-158 60113-267 60220-003 21130-746 23130-158 60113-267 60220-003 Interior mounting Swing frames for cabinet width 800 mm Order Information Swing frame 120° Swing frame 120° Swing frame 160° Stop 120° Swing frame 160° Swing frame trim Stop 160° Asymmetrical assembly 1 1 2 2 100 200 01005070 Height U partial height partial height 29 33 38 42 47 1.46 01005061 01005070 01005061 Safety lock Symmetrical assembly 100 01005058 01005057 01015060 St; for safety reasons a swing frame stop is recommended St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 160° hinge, square locks incl. 2 keys St, swing frame stop is recommended for safety reasons St, 1.5 mm, RAL 7021, trim (item 1, width 200 mm) incl. handle (item 2) and cutout for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes for swing frame, instead of square lock, incl. 2 keys PU 1 kit assembled 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces assembled 1 piece assembled Usable height U mm St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) 1 piece assembled 12 800 21130-747 23130-158 21130-761 23130-159 – – 60113-267 21 800 21130-748 23130-158 21130-762 23130-159 21130-432 21130-442 60113-267 25 30 34 39 43 800 800 800 800 800 21130-749 21130-750 23130-158 23130-158 21130-763 21130-764 23130-159 23130-159 21130-433 21130-434 21130-443 21130-444 60113-267 60113-267 21130-751 23130-158 21130-765 23130-159 21130-435 21130-445 60113-267 21130-752 21130-753 23130-158 23130-158 21130-766 21130-767 23130-159 23130-159 21130-436 21130-437 21130-446 21130-447 60113-267 60113-267 Width SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Mounting plate, stationary shelves, 75 kg Order Information Mounting plate Full height Height 1200 mm Stationary shelf Full depth Strengthening brackets Stationary shelf Shortened by 100 mm Depth member, 3 rows Completely in RAL 7021 (black grey) 01008052 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01008053 St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear mounted); strengthening bracket increases static load-carrying capacity; please order separately 01008080 St profile, increases static load-carrying capacity of mounting plate to 150 kg 01004142 01004142 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying cap. 75 kg, 1 U, capacity 75 kg, depth 479 mm, 1 U, incl. GND/ incl. GND/ earthing earthing, for recessed installation order depth members 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 2 pieces 1 piece 1 piece PU 1 pair assembled assembled assembled assembled assembled assembled zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 RAL 7021 RAL 7021 AIZn 21130-323 21130-322 23130-081 21130-325 21130-324 23130-082 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-323 21130-322 23130-081 21130-325 21130-333 21130-324 21130-332 23130-082 23130-081 – 23130-413 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 – – – 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 21130-333 21130-332 23130-081 21130-335 21130-334 23130-082 – – – 21130-323 21130-322 23130-081 21130-325 21130-335 21130-324 21130-334 23130-082 23130-082 RAL 7035 RAL 7035 AlZn 22130-323 22130-322 23130-081 22130-325 22130-324 23130-082 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 22130-323 22130-322 23130-081 22130-325 22130-333 22130-324 22130-332 23130-082 23130-081 – 23130-413 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 – – – 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 22130-333 22130-332 23130-081 22130-335 22130-324 23130-082 – – – 22130-323 22130-322 23130-081 22130-325 22130-335 22130-324 22130-334 23130-082 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.47 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Telescopic shelves, 70 kg Order Information Telescopic shelf, 2 U Full depth Shortened by 100 mm Mounting bracket T-bar lock GND/earthing Completely in RAL 7021 (black grey) 01004144 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004145 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately 01005054 St, finish AlZn 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.48 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece 1 piece PU 4 pieces 1 piece PU 1 kit assembled assembled assembled assembled assembled AIZn 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 RAL 7021 RAL 7021 21130-353 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 21130-353 21130-352 21130-355 21130-373 21130-354 21130-372 23130-274 23130-092 23130-140 – – – – – 21130-353 21130-355 21130-352 21130-354 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 – – – 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 21130-373 21130-372 21130-375 21130-374 – – 21130-353 21130-352 21130-355 21130-375 21130-354 21130-374 RAL 7035 RAL 7035 22130-353 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 AlZn RAL 7021 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-353 22130-352 22130-355 22130-373 22130-354 22130-372 23130-274 23130-092 23130-140 – – – – – 22130-353 22130-355 22130-352 22130-354 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 – – – 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-373 22130-372 22130-375 22130-374 – – 22130-353 22130-352 22130-355 22130-375 22130-354 22130-374 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" shelves 1 U, stationary 75 kg, telescopic 30 kg Order Information 19'' stationary shelf, 1 U, 75 kg Full depth Shortened by 100 mm W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Full depth 19'' telescopic shelf, 1 U, 30 kg Shortened by GND/earthing 100 mm c D Dimension Standard fitting 01004118 01004119 01004123 01004122 St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static xf = distance load-carrying load-carrying load-carrying load-carrying from front capacity 30 kg, capacity 30 kg, capacity 75 kg, capacity 75 kg, c = pitch of 19" incl. telescopic incl. telescopic depth 500 mm, depth 600 mm, panel/slide slide; slide; incl. GND/ incl. GND/ mounts please order please order earthing earthing D = cabinet depth GND/earthing kit GND/earthing kit W = cabinet width separately separately 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm RAL 7021 RAL 7021 RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 21130-303 21130-305 21130-302 21130-304 21130-343 21130-345 21130-342 21130-344 RAL 7035 RAL 7035 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 22130-303 22130-305 22130-302 22130-304 22130-343 22130-345 22130-342 22130-344 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled 23130-140 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-302 21130-343 21130-342 23130-140 – – – – – 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-303 21130-302 21130-343 21130-342 – – – – 21130-303 21130-302 21130-343 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-302 21130-343 21130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 23130-140 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-302 22130-343 22130-342 23130-140 – – – – – 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-303 22130-302 22130-343 22130-342 – – – – 22130-303 22130-302 22130-343 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-302 22130-343 22130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.49 Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" telescopic shelf, 2 U, 70 kg Order Information Dimension Standard fitting Telescopic shelf, 2 U, 70 kg W 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width Cabinet dimensions Height No. U mm Width Depth mm mm 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004123 1.50 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004122 01004125 05904052 St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 400 mm, depth 682 mm, incl. telescopic slide, please order, T-bar lock and earthing kit separately 1 piece to lock the telescopic shelf 1 piece PU 1 kit assembled assembled assembled assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 xf mm c mm RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 21130-353 21130-355 21130-352 21130-354 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 22130-353 22130-355 22130-352 22130-354 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 GND/earthing St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 417 mm, depth 482 mm, incl. telescopic slide, please order, T-bar lock and earthing kit separately 1 piece Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 T-bar lock xf Completely in RAL 7021 (black grey) Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Shortened by 100 mm c D Full depth SCHROFF PRODUCT CATALOG E 08/2017 for telescopic shelf 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-355 21130-354 21130-353 21130-352 23130-092 23130-140 – – – – 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 23130-092 23130-140 21130-353 21130-352 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 – – 21130-353 21130-352 21130-355 21130-354 21130-353 21130-352 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-355 22130-354 22130-353 22130-352 23130-092 23130-140 – – – – 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 23130-092 23130-140 22130-353 22130-352 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 – – 22130-353 22130-352 22130-355 22130-354 22130-353 22130-352 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Slide rails, depth members Order Information Slide rail 25 kg Depth member, 3 rows W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Short slide rail 100 kg c D Dimension Standard fitting 01004115 01004154 St, 1.5 mm, St, 2.5 mm, St, 1.5 mm, xf = distance finish AlZn, static zinc-plated, static finish AlZn, static from front load-carrying load-carrying load-carrying c = pitch of 19" capacity 15 kg/ capacity 100 kg/ capacity 25 kg/ panel/slide pair pair pair mounts D = cabinet depth W = cabinet width 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 23130-097 23130-096 23130-119 23130-118 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 23130-097 23130-096 23130-119 23130-118 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK PU 2 pieces PU 2 pieces PU 1 kit PU 1 pair supplied loose supplied loose supplied loose assembled AIZn zinc-plated AIZn 23130-096 23130-118 23130-094 23130-094 AIZn 23130-081 23130-082 23130-081 23130-082 23130-094 23130-081 23130-082 23130-081 23130-096 23130-118 23130-094 23130-099 23130-096 23130-116 23130-118 23130-094 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-099 23130-116 23130-094 – 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 AlZn zinc-plated AlZn 23130-096 23130-118 23130-094 23130-094 23130-094 – 23130-081 23130-082 23130-081 23130-082 AlZn 23130-081 23130-082 23130-081 23130-082 23130-094 23130-081 23130-082 23130-081 23130-096 23130-118 23130-094 23130-099 23130-096 23130-116 23130-118 23130-094 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-099 23130-116 23130-094 – 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 23130-094 – 23130-081 23130-082 23130-081 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.51 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Cable ductings Order Information Cable ducting with C-profile C-rail for cabinet depth C-rail for cabinet width Slide nut Cable shell Cable support for C-rail Completely in RAL 7021 (black grey) 01006109 St, 1.5 mm, finish AlZn 01006107 St, 1.5 mm, finish AlZn 01504054 for C-rail Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) vnt009 for C-rail or for cable support rail, for cable bundles of 42 ... 46 mm, further dimensions see page 1.24 01006110 PA, UL 94 V-0, black, assembly by clipping onto the C-rail Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.52 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 PU 2 pieces PU 2 pieces PU 10 pieces PU 10 pieces PU 5 pieces supplied loose supplied loose supplied loose supplied loose supplied loose AIZn AIZn 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-334 21120-140 20114-731 60118-472 – – – – – 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 – – – – 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-086 23130-087 – 23130-086 23130-087 23130-087 AlZn 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 AlZn 23130-334 21120-140 20114-731 60118-472 – – – – – 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 – – – – 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-086 23130-087 – 23130-086 23130-087 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Cable ties, Velcro Order Information Cable tie Velcro General components Mechanics Completely in RAL 7021 (black grey) from page 3.2 01005078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) plastic, 92 mm x 2.5 mm, further dimensions see page 1.25 01005079 black, length 300 mm, further dimensions see page 1.25 Electrics Cabinet dimensions Height No. U mm Width Depth mm mm PU 25 pieces PU 10 pieces supplied loose supplied loose Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 from page 3.29 Power distribution from page 3.50 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK Climate control from page 4.0 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.53 VARISTAR EMCMain Catalogue Cabinets – VARISTAR EMC Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01008001 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 41003017 Cooling with perforated HF door with high air throughput (78 % open area) 01007004 Cooling with HF fan top cover for up to 6 fans Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01007005 Cable entry in rear section of base plate; sealing by means of sliding plates 01007003 Cable entry by means of HF connection plate Appendix . . . . . 12 1.54 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC Overview . . . . . . 1.54 VARISTAR EMC Main Catalogue Best performance in HF shielding 쮿 Shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz (tested to IEC 61587-3) VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Cable entry to front or rear or via base 쮿 Cooling with perforated front door or with fan top cover 쮿 Standard cabinets available from stock or individually configurable with appropriate accessory range VARISTAR EMC, base plate without cable ducting . . . . 1.55 VARISTAR EMC with perforated door . . . . . . . . . . . . . 1.57 VARISTAR EMC with fan top cover 1.58 VARISTAR EMC Accessories 01005017 01007017 쮿 Versions with/without cable entry through base plate 쮿 With perforated HF front and rear door 쮿 IP 55 쮿 Base plate with cable ducting 01007018 쮿 With fan top cover and perforated base plate with cable entry Base/plinth . . . . . . 1.59 19" swing frame . . . . . . . . . . . 1.60 19" panel/slide mount . . . . . . . . . . 1.61 19" fixing materials kit, M6 . . . . . . . . . . . . . . 1.61 Slide rails . . . . . . . . 1.62 19" shelves . . . . . . 1.63 Depth members . . 1.66 C horizontal rail . . 1.66 Cable tie, Velcro . . . . . . . . . . . 1.67 ServicePLUS . . 1.68 ServicePLUS configuration . . . . 1.69 ServicePLUS from page 1.68 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) www.schroff.biz/ServicePLUS VARISTAR Electronics . . . . . . 1.10 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR air/ water heat exchanger . . . . . . . 1.224 30407004 SCHROFF.PENTAIR.CO.UK 1.55 Cabinets – VARISTAR EMC VARISTAR EMC VARISTA R EMCMain CataloguePart number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days 쮿 Shielding 60 dB at 1 GHz, 40 dB at 3 GHz (tested to IEC 61587-3) 쮿 Type of protection IP 55 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) 쮿 Base plate versions – without cable ducting – with cable ducting Delivery comprises (assembled) 01005017 Item 1 Qty 1 2 3 4 4 1 1 5 1 6 2 7a 7b 1 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with textile gasket all-around Adjustable foot, assembled Flat top cover, St, inner surface AlZn, outside RAL 7021 Front door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate, one-piece, St, 1.5 mm, finish AlZn Base plate with cable ducting, St, 1.5 mm, finish AlZn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information Height Height H U mm 01005015 120 100 Description Base plate without cable entry Base plate with cable 42 2000 600 800 entry Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces 42 [dBµV] Width W Depth D mm mm 2000 600 800 Part no. 10130-020 10130-192 23130-077 23130-078 25127-995 23130-072 80 1 60 2 40 20 Note 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] 1) Shielding without cable ducting 2) Shielding with cable ducting, tested to IEC 61587-3, standard dimensions of test objects 2000 x 600 x 600 mm 01007060 ServicePLUS see page 1.68 1.56 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC VARISTAR EMC with perforated doors VARISTAR EMC 쮿 Shielding 40 dB at 1 GHz (tested to IEC 61587-3) 쮿 Air throughput 78 % 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 4 1 1 5 1 6 2 7 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with textile gasket all around Adjustable foot, assembled Flat top cover, St, inner surface AlZn, outside RAL 7021 Front door, perforated, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, perforated, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate with cable ducting, St, 1.5 mm, finish Al-Zn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01007017 Height Height H Width W Depth D U mm mm mm 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces Part no. 10130-190 23130-077 23130-078 25127-995 23130-072 Note 01007019 Perforation [dBµV] 120 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 100 80 60 40 20 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] Shielding: Tested to IEC 61587-3, standard dimensions of test object 2000 x 600 x 600 mm 01007059 ServicePLUS see page 1.68 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.57 Cabinets – VARISTAR EMC VARISTAR EMC with fan top cover VARISTA R EMC 쮿 Shielding 50 dB at 1 GHz (tested to IEC 61587-3) 쮿 Fan top cover with 3 fans (up to 6 fans can be mounted) 쮿 Perforated base plate with cable ducting 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) 01007018 Item 1 Qty 1 2 3 4 1 4 1 5 1 6 2 7 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with conductive seal all-around Adjustable foot, assembled Raised top cover, St, 1.5 mm, RAL 7021; fan top cover with 3 axial fans, 230 VAC, incl. cabling and GND/ earthing; SCHUKO/UTE plug, cable length 2.5 m, IEC 60320-C13 socket; assembly space for 3 further fans Front door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate with cable ducting, perforated, St, 1.5 mm, finish AlZn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01007004 Fan top cover [dBµV] Height Height H Width W Depth D U mm mm mm 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for fan top PU 4 pieces Part no. 10130-191 23130-077 23130-078 25127-995 23130-090 Note 120 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 100 80 60 40 20 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] Shielding: Tested to IEC 61587-3, standard dimensions of test object 2000 x 600 x 600 mm 01007057 ServicePLUS see page 1.68 1.58 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC Stationary base VARISTAR EMC 쮿 Static load-carrying capacity 1000 kg 쮿 Removable trims allow cable entry from all sides 쮿 Cannot be used in conjunction with castors 쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm 쮿 Versions – Front/rear trim perforated – Front/rear trim solid 2a H 2b 1 2b 2a D = cabinet depth W D 4 01004110 01004053 Delivery comprises (kit) Item 1 2a 2b 3 Qty 2 2 2 1 Description Support with feet, St, 3 mm Solid trim, St, 1.5 mm, RAL 7021 Perforated trim, St, 1.5 mm, RAL 7021 Assembly kit Order Information For cabinet width W Front/rear trim mm 600 perforated 600 solid Item 4 Side trim height 100 mm, depth 800 mm, PU 2 pieces Part no. 23130-187 23130-387 23130-170 Note 쮿 Please order side trims (item 4) separately Base/plinth, mobile VARISTAR EMC 쮿 Load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 쮿 Plinth height H = 100 mm, with feet adjustable from 126 to 134 mm Delivery comprises Item 1 2 3 4 Qty 1 4 4 1 Description Frame, St, 3 mm, RAL 7021, with adjustable feet Trim, St, 1.5 mm, RAL 7021 Castor Assembly kit Order Information For cabinet width mm 600 01004111 SCHROFF.PENTAIR.CO.UK For cabinet depth mm 800 Part no. 23130-209 01006095 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.59 Cabinets – VARISTAR EMC 19" swing frame VARISTA R EMC 쮿 Can accommodate 19" chassis and 19" subracks 2 쮿 For full height or partial-height mounting within cabinets 쮿 Pivot point can be selected right or left 쮿 Load-carrying capacity 150 kg h2 h1 Delivery comprises (kit) 1 Tm ax. Qty 1 2 2 2 1 Description Swing frame, St, 2 mm, RAL 7021 Support bar, St, 3 mm, RAL 7021 Square lock, 8 mm, incl. 2 keys 120° hinge Assembly kit Order Information 4 3 01005055 Maximum mounting depth for swing frame Cabinet Slim-Line Heavy-Duty Item 1 2 3 4 5 01005059 Width 600 mm 220 mm 200 mm For cabinet height Height h1 mm U 900 for partial-height mounting 16 1200 for partial-height mounting 24 1400 for partial-height mounting 29 1600 for partial-height mounting 33 1800 for partial-height mounting 38 2000 42 Swing frame stop max. swing angle 120°, St, zinc-plated, 1 piece Security lock to replace the square lock, PU 1 lock incl. 2 keys Spare key for security lock, 1 piece Height h2 U 12 21 25 30 34 39 Part no. 21130-740 21130-741 21130-742 21130-743 21130-744 21130-745 23130-158 60113-267 60220-003 Note Swing frame stop 쮿 19" swing frames can be assembled: – Directly on the cabinet frame – In 50 mm increments by aid of depth members (depth-adjustable) 쮿 For partial-height mounting, depth members are necessary, see page 1.66 01005061 Security lock 41001517 1.60 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19" panel/slide mount with universal pitch (EIA) VARISTAR EMC 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 44,45 44.45 12,75 15,9 65,1 2 76 25 25 49,5 Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 9,6 42,5 Item 1 01004112 01004131 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. 8 395 23130-037 23130-027 12 545 23130-038 23130-028 16 745 23130-039 23130-029 Partial20 895 23130-040 23130-030 height 24 1095 23130-031 23130-021 mounting 29 1295 23130-032 23130-022 33 1495 23130-033 23130-023 38 1695 23130-034 23130-024 2000 42 1895 23130-035 23130-025 Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 25127-997 Note 쮿 For 19" partial-height mounting depth members are necessary 쮿 Metric panel/slide mounts available on request Standard assembly dimension xr = xf = 50 mm 01005088 19" assembly kit, M6 VARISTAR EMC 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.61 Cabinets – VARISTAR EMC Slide rails VARISTA R EMC 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 Wide support surface (48 mm) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair Delivery comprises 01004056 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load carrying capacity 25 kg For cabinet depth D mm 800 800 01005086 Static load-carrying capacity 25 kg xf c Length L Qty/PU mm 50 50 mm 700 700 mm 656 656 2 10 Part no. 23130-097 23130-102 Order Information Static load carrying capacity 100 kg For cabinet depth D mm 800 800 c Length L Qty/PU mm 50 50 mm 700 700 mm 658 658 2 10 Part no. 23130-119 23130-124 01004058 19” c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth SCHROFF PRODUCT CATALOG E 08/2017 D c xf c - 130 Static load-carrying capacity 100 kg 1.62 xf 01004130 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19'' stationary shelf, 75 kg VARISTAR EMC 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c For cabinet Usable xf c RAL 7035 depth surface w x d mm mm mm mm Part no. 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece D d Order Information RAL 7021 Part no. 21130-305 23130-310 Note w xf 쮿 Cable ducting with cable ties, see page 1.67 쮿 Other sizes, see ServicePLUS, page 1.80 W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004067 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.63 Cabinets – VARISTAR EMC 19'' telescopic shelf, 30 kg VARISTA R EMC 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 800 417 x 682 50 700 22130-345 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR D c d Full depth RAL 7021 Part no. 21130-345 23130-140 xf Note 쮿 Cable ducting with cable ties, see page 1.67 01004069 Order Information Shortened depth Shortened by 100 mm W For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 800 417 x 582 50 700 22130-344 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xr w RAL 7021 Part no. 21130-344 23130-140 D 쮿 Cable ducting with cable ties, see page 1.67 xf d c Note c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly pitch 1.64 SCHROFF PRODUCT CATALOG E 08/2017 01004070 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19'' telescopic shelf, 70 kg VARISTAR EMC 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 W Delivery comprises w Item 1 Qty 1 2 3 2 1 xr Full depth 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 800 405 x 682 50 700 22130-355 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Order Information RAL 7021 Part no. 21130-355 23130-092 23130-140 Note 01004069 c = max. pitch for 19" panel/slide mounts Shortened depth W 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.67 Order Information w Shortened by 100 mm D d c xr For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 800 405 x 582 50 700 22130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-354 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.67 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004070 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.65 Cabinets – VARISTAR EMC Depth member VARISTA R EMC 쮿 For mounting of shortened 19" panel/slide mounts 쮿 Cable ducting by means of cable ties and cable eyes 36,5 11,5 Delivery comprises 50 100 37,5 121,2 25 25 L - 27 Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 12 Description L 01004126 Item 1 2 01004079 Cable eye For cabinet depth mm Depth member 800 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-082 21101-151 21101-150 쮿 Cable ducting with cable ties, see page 1.67 coa43697 C-profile for the cabinet depth VARISTA R EMC 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut 15 ,5 Ø6 50 11 Part no. 23130-087 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note L 쮿 Cable ties and Velcro for cable retention rail see page 1.67 39,5 29,5 L- ,5 x 31 For cabinet depth Length L mm mm 800 660 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces 50 75 01504054 1.66 C-profile 01004132 01006071 Cable retention rail SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC C-profile for cabinet width VARISTAR EMC 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-profile Slide nut For cabinet width Length mm mm 800 750 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-334 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.67 75 01006071 01006064 Cable retention rail 01504054 Cable ties, Velcro VARISTAR EMC 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie 01005078 Velcro Part no. 20118-351 20118-352 20118-353 20118-624 01005079 VARISTAR EMC VARISTAR EMC ServiceP LUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.67 Cabinets – VARISTAR EMC ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.69 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.68 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS VARISTAR ServicePLUS: configuration and assembly VARISTAR EMC ServicePLUS 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 600, 800 and 1000 mm Page 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) Frames, EMC gasketing, side-by-side mounting kits, adjustable feet, castors 1.70 Side panels, rear panels, doors 1.71 쮿 Build your cabinet out of individual components (please suffix each part number with /05) Top covers, fan top covers, 1.72 lifting eyes 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) Bases, plinths 1.73 Connecting plates for short doors/rear panels 1.74 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Interior configuration 19" panel/slide mounts 1.75 ETSI panel/slide mounts 1.76 Swing frames 1.77 Stationary shelves 1.78 Telescopic shelves, 70 kg 1.79 19" shelves 1 U, stationary 1.80 75 kg, telescopic 30 kg 19" telescopic shelves, 2 U, 70 kg 1.81 Slide rails, depth members 1.82 Cable ductings 1.83 01004077 Example configuration (here: row 9) Qty 1 1 1 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece EMC gasketing kit, 1 piece Side panel screw-fixing, EMC, PU 2 pieces Screw-fixed rear panel, EMC, 1 piece Steel door with 4-point locking, EMC, 1 piece Adjustable feet, PU 4 pieces .......... Order no. 20130-019/05 23130-065/05 21130-031/05 21130-084/05 21130-174/05 23130-079/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.69 Cabinets – VARISTAR EMC ServicePLUS VARISTAR EMC Frames, EMC gasketing, side-by-side mounting kits, adjustable feet, castors Order Information Frame Slim-Line 400 kg EMC gasketing kit Heavy-Duty 800 kg Side-by-side mounting kit EMC Adjustable feet Castors With 2 jacking feet With adjustable feet Completely in RAL 7021 (black grey ) 01004078 gaskets are glued static loadstatic loadto the frame, carrying capacity: carrying capacity: through which all 800 kg, 400 kg, the following St, 1.5 mm, zinc- St, 1.5 mm, zinccover parts are plated, with plated, with conductively central GND/ central GND/ linked earthing point; earthing point; please order please order adjustable feet or adjustable feet or castors castors separately separately Colour combinatio n RAL 7035 (light grey)/ RAL 7021 ( black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 01004157 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 01004120 side-by-side mounting brackets (4 pieces), St 01004081 1 piece 1 piece PU 1 kit PU 1 kit PU 4 pieces assembled assembled supplied loose assembled RAL 7021 RAL 7021 20130-055 20130-006 20130-056 20130-009 20130-010 20130-059 20130-060 20130-013 20130-063 20130-014 20130-015 20130-064 20130-065 20130-018 20130-068 20130-019 20130-021 20130-069 20130-071 01004156 for the frame, for the frame, for the frame, static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity: 400 kg, 400 kg, 1000 kg, cannot be used cannot be used cannot be used with base/plinth with base/plinth with base/plinth assembled 20130-005 01004082 PU 4 pieces PU 4 pieces RAL 7021 23130-065 23130-063 23130-079 23130-077 23130-078 23130-065 23130-063 23130-079 23130-077 23130-078 23130-065 23130-063 23130-079 23130-077 23130-078 23130-065 23130-063 23130-079 23130-077 23130-078 23130-065 23130-063 23130-079 23130-077 23130-078 23130-065 23130-063 23130-079 23130-077 23130-078 20130-022 20130-072 20130-023 20130-027 20130-073 20130-077 20130-028 20130-078 23130-065 23130-063 23130-079 23130-077 23130-078 20130-030 20130-032 20130-080 20130-082 23130-065 23130-063 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.70 RAL 7021 RAL 7021 29 1400 600 600 20130-005 20130-055 23130-065 23130-063 29 1400 600 800 20130-006 20130-056 33 1600 600 600 20130-009 20130-059 23130-065 23130-063 33 1600 600 800 20130-010 20130-060 38 1800 600 600 20130-013 20130-063 23130-065 23130-063 38 1800 600 800 20130-014 20130-064 38 1800 800 600 20130-015 20130-065 23130-065 23130-063 42 2000 600 600 20130-018 20130-068 42 2000 600 800 20130-019 20130-069 23130-065 23130-063 42 2000 600 1000 20130-021 20130-071 42 2000 800 600 20130-022 20130-072 23130-065 23130-063 42 2000 800 800 20130-023 20130-073 47 2200 600 600 20130-027 20130-077 47 2200 600 800 20130-028 20130-078 23130-065 23130-063 47 2200 600 1000 20130-030 20130-080 47 2200 800 800 20130-032 20130-082 23130-065 23130-063 Other dimensions and configurations online (with basket) at www.schroff.biz/conf SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS VARISTAR EMC Side panels, rear panels, doors Order Information Side panel, screw fixed, EMC, IP 55 Rear panel, screw fixed, EMC, IP 55 Steel door, 4-point locking Plain, EMC, IP 55 Perforated, EMC DIN profile half cylinder Completely in RAL 7021 (black grey) 01004083 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF.PENTAIR.CO.UK St, 1 mm, painted outside, AlZn inside, incl. GND/ earthing 01004085 St, 1 mm, painted outside, AlZn inside, incl. GND/ earthing 01004092 01004093 St, 1.5 mm, St, 1.5 mm, painted outside, painted outside, AlZn inside, AlZn inside, opening angle opening angle 180°, 180°, lever handle with lever handle with push button, push button, incl. GND/ incl. GND/ earthing earthing 01004148 for lever handle, common locking PU 2 pieces 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 21130-078 21130-168 21130-198 25127-995 21130-080 21130-170 21130-200 25127-995 21130-027 21130-028 21130-082 21130-172 21130-202 25127-995 21130-027 21130-083 21130-173 21130-203 25127-995 21130-030 21130-031 21130-084 21130-174 21130-204 25127-995 21130-085 21130-175 21130-205 25127-995 21130-036 21130-038 21130-086 21130-176 21130-206 25127-995 21130-036 21130-087 21130-177 21130-207 25127-995 RAL 7035 RAL 7035 RAL 7035 RAL 7035 22130-078 22130-168 22130-198 25127-995 22130-080 22130-170 22130-200 25127-995 22130-027 22130-028 22130-082 22130-172 22130-202 25127-995 22130-027 22130-083 22130-173 22130-203 25127-995 22130-030 22130-031 22130-084 22130-174 22130-204 25127-995 22130-085 22130-175 22130-205 25127-995 22130-036 22130-038 22130-086 22130-176 22130-206 25127-995 22130-036 22130-087 22130-177 22130-207 25127-995 21130-023 21130-024 21130-025 21130-026 21130-033 21130-030 21130-031 21130-035 22130-023 22130-024 22130-025 22130-026 22130-033 22130-030 22130-031 22130-035 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.71 Cabinets – VARISTAR EMC ServicePLUS VARISTAR EMC Top covers, fan top covers, lifting eyes Order Information Flat top cover EMC, IP 55 Fan top cover Lifting eye EMC top cover for 6 fans Replacement fan for fan top Thermostat Speed control Lifting eye 30 20 40 10 50 0 60 °C Completely in RAL 7021 (black grey) 1000 mm 300 mm Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.72 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 300 mm M12 01004096 01004090 01008050 kta44844 01108052 01105055 St, 1.5 mm, fully wired, fan with grille for with mains cable RAL 7021; 90 ... 264 VAC, top assembly, 230 VAC with 3 axial fans 230 VAC, (SCHUKO/UTE input SCHUKO/ 230 VAC, plug/ UTE plug, 38x119x119 mm, 3 outlet IEC 60320 incl. cabling and for 50 Hz, 162 m / IEC 60320 C13 socket), C13 socket; GND/earthing, h adjustment range external NTC connector 2.5m, 0 ... 60°C sensor 1.5 m SCHUKO/ IEC 60320 C12 plug 01005085 for fan top cover, applications and static loadcarrying capacity in accordance with DIN 582 St, 1,5 mm, painted outside, AlZn inside, incl. GND/ earthing for top cover, applications and load in accordance with DIN 582 1 piece PU 4 pieces 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled assembled assembled 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 RAL 7021 21130-272 21130-273 21130-272 21130-273 21130-272 21130-273 21130-276 RAL 7021 23130-072 23130-072 23130-072 23130-072 21130-272 21130-273 21130-275 21130-276 21130-277 21130-272 21130-273 21130-275 21130-277 23130-395 23130-396 23130-395 23130-396 23130-395 23130-396 23130-397 23130-395 23130-072 23130-072 23130-396 23130-443 23130-397 23130-398 23130-395 23130-072 23130-396 23130-165 20118-750 60715-005 23130-090 23130-072 23130-443 23130-398 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 RAL 7021 RAL 7021 21130-272 23130-395 21130-273 21130-272 21130-273 21130-272 21130-273 21130-276 23130-072 23130-072 23130-072 23130-072 21130-272 21130-273 21130-275 21130-276 21130-277 21130-272 21130-273 21130-275 21130-277 SCHROFF PRODUCT CATALOG E 08/2017 23130-396 23130-395 23130-396 23130-395 23130-396 23130-397 23130-395 23130-072 23130-072 23130-396 23130-443 23130-397 23130-398 23130-395 23130-072 23130-396 23130-165 20118-750 60715-005 23130-090 23130-072 23130-443 23130-398 23130-165 20118-750 60715-005 23130-090 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS VARISTAR EMC Bases, plinths Order Information Base plate One-piece, EMC, IP 55 With cable ducting, EMC Base/plinth Perforated, with cable ducting, EMC Plain base/plinth Base/plinth, ventilated Side covers Base/plinth, mobile Completely in RAL 7021 (black grey) 01004051 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF.PENTAIR.CO.UK AlZn, 1.5 mm, incl. GND/ earthing, assembly from outside 01004108 AlZn, 1.5 mm, rear opening 60 mm deep, incl. GND/ earthing, assembly from outside 01008051 01004110 support with AlZn, 1.5 mm, adjustable feet incl. GND/ and 2 trims, earthing; loadopening at rear: static for cabinet width carrying capacity 1000 kg; please of 600 mm: order side trims 359 x 60 mm, separately for cabinet width of 800 mm: 559 x 60 mm 01004110 support with adjustable feet and 2 trims, perforated, static load-carrying capacity 1000 kg; please order side trims separately 01004053 St, 1.5 mm 01004111 support, St, 3 mm, trim, St, 1.5 mm, static load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 1 piece 1 piece 1 piece PU 1 kit PU 1 kit PU 1 pair 1 piece assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 assembled RAL 7021 23130-169 23130-208 AlZn AlZn AlZn 21130-281 21130-291 23130-400 21130-282 21130-292 23130-401 21130-281 21130-282 21130-291 21130-292 23130-400 23130-401 21130-281 21130-291 23130-400 21130-282 21130-283 21130-292 21130-293 23130-401 23130-402 21130-281 21130-291 23130-400 21130-282 21130-287 21130-292 21130-296 23130-401 23130-447 23130-387 23130-187 23130-170 23130-209 23130-172 23130-170 23130-211 23130-213 23130-388 23130-194 RAL 7021 RAL 7021 21130-281 21130-291 23130-400 21130-282 21130-283 21130-292 21130-293 23130-401 23130-402 21130-281 21130-291 23130-400 21130-282 21130-287 21130-292 21130-296 23130-401 23130-447 21130-283 21130-293 23130-402 21130-284 21130-281 21130-294 21130-291 23130-403 23130-400 21130-282 21130-292 23130-401 21130-287 21130-284 21130-296 21130-294 23130-447 23130-403 23130-213 23130-208 23130-187 23130-447 23130-403 23130-400 23130-401 23130-212 23130-170 23130-169 23130-387 23130-401 21130-291 21130-292 23130-169 23130-194 21130-296 21130-294 21130-281 21130-282 23130-209 23130-211 23130-388 21130-292 23130-401 23130-208 23130-170 23130-172 23130-187 21130-287 21130-284 21130-292 23130-169 23130-387 21130-282 21130-282 23130-209 23130-212 23130-194 23130-402 AlZn 23130-208 23130-170 23130-169 23130-388 23130-403 23130-400 23130-400 23130-169 23130-187 21130-293 AlZn 23130-208 23130-209 23130-387 21130-294 21130-291 21130-291 23130-209 23130-187 21130-284 21130-281 AlZn 23130-170 23130-169 23130-170 23130-387 21130-283 21130-281 RAL 7021 23130-387 23130-187 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-170 23130-208 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-169 23130-208 23130-170 23130-172 23130-209 23130-211 23130-169 23130-212 23130-170 23130-169 23130-213 23130-208 23130-387 23130-187 23130-387 23130-187 23130-388 23130-194 23130-387 23130-187 23130-388 23130-194 23130-387 23130-187 23130-170 23130-209 23130-194 23130-172 23130-170 23130-211 23130-213 23130-388 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.73 Cabinets – VARISTAR EMC ServicePLUS VARISTAR EMC Connecting plates for short doors/rear panels Order Information Dimensioning connecting plate door/rear panel EMC connecting plate Flat plate, EMC, IP 55 Recessed plate, EMC, IP 55 Completely in RAL 7021 (black grey) 01005077 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) door and rear panel must be selected 400 mm shorter than cabinet height 01005075 flat plate, stainless steel, 1 mm, height 400 mm, mounting can be at top or bottom Cabinet dimensions Height Width Depth U mm mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 1.74 600 800 SCHROFF PRODUCT CATALOG E 08/2017 01005074 frame, stainless steel, 1 mm, mounting can be at top or bottom, height 400 mm, plate recessed by 40 mm, stainless steel, 1 mm 1 piece 1 piece assembled assembled RAL 7021 RAL 7021 21130-578 21130-580 21130-579 21130-581 RAL 7035 RAL 7035 22130-578 22130-580 22130-579 22130-581 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS Interior mounting 19" panel/slide mounts Order Information Dimension 19" panel/slide mounts EIA Painted RAL 7021 19" assembly kit M6 Adapter bracket for reduced width W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) U height identification for 19" panel/slide mount AIZn c D Standard fitting xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width 01004112 St, 1.75 mm; reduced-width adapter bracket required for 800 mm width; depth members are required for partial-height mounting 00505050 sc128 paper strip, white, assembly kit: serial numbered item 1: screws, from 1 ... 47 H item 2: cage nuts, item 3: washers other kit quantities see page 3.17 01004128 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 50 50 50 50 50 50 50 50 50 70 50 150 50 50 50 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 700 500 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF.PENTAIR.CO.UK PU 1 pair PU 1 pair PU 4 pieces PU 50 pieces PU 4 pieces assembled assembled assembled supplied loose assembled RAL 7021 AIZn 23130-012 23130-032 25127-997 21101-809 – 23130-013 23130-033 25127-997 21101-809 – 23130-014 23130-034 25127-997 21101-809 – 23130-014 23130-034 25127-997 21101-809 23130-091 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 23130-091 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 23130-091 RAL 7035 AIZn 23130-022 23130-032 25127-997 21101-809 – 23130-023 23130-033 25127-997 21101-809 – 23130-024 23130-034 25127-997 21101-809 – 23130-024 23130-034 25127-997 21101-809 23130-091 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 23130-091 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 23130-091 AIZn AIZn Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.75 Cabinets – VARISTAR EMC ServicePLUS Interior mounting ETSI panel/slide mounts, mounting plates Order Information ETSI panel/slide mount Dimensions Mounting plates Panel/slide mount Full height Height 1200 mm Strengthening brackets Completely in RAL 7021 (black grey) coa43693 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004114 St, 2 mm, in accordance AlZn finish, with suitable only for ETS 300119-3 and IEC 60917- Slim-Line frame; 211; SU = 25 mm shelves available on request 01008052 01008053 St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear mounted); strengthening bracket increases static load-carrying capacity; please order separately 01008080 St profile, increases static load-carrying capacity of mounting plate to 150 kg Cabinet dimensions Height No. U mm Width Depth mm mm Height SU Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.76 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 SCHROFF PRODUCT CATALOG E 08/2017 PU 1 pair 1 piece 1 piece PU 2 pieces assembled assembled assembled assembled AIZn zinc-plated zinc-plated RAL 7021 23130-052 – 23130-413 23130-418 23130-053 – 23130-413 23130-418 23130-054 23130-405 23130-413 23130-418 23130-054 23130-406 23130-414 23130-418 23130-055 23130-407 23130-413 23130-418 23130-055 23130-408 23130-414 23130-418 23130-056 – 23130-413 23130-418 23130-056 – 23130-414 23130-418 AIZn verzinkt verzinkt RAL 7021 23130-052 – 23130-413 23130-418 23130-053 – 23130-413 23130-418 23130-054 23130-405 23130-413 23130-418 23130-054 23130-406 23130-414 23130-418 23130-055 23130-407 23130-413 23130-418 23130-055 23130-408 23130-414 23130-418 23130-056 – 23130-413 23130-418 23130-056 – 23130-414 23130-418 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS Interior mounting Swing frames for cabinet width 600 mm Order Information Swing frame Stop 120° Safety lock 01005070 Height U partial height partial height 29 33 38 42 47 Width Spare key 01005061 01015060 St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) St; for safety reasons a swing frame stop is recommended for swing frame, instead of square lock, incl. 2 keys 01015059 Usable height U mm 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces supplied loose 12 600 21130-740 23130-158 60113-267 60220-003 21 600 21130-741 23130-158 60113-267 60220-003 25 30 34 39 43 600 600 600 600 600 21130-742 23130-158 60113-267 60220-003 21130-743 21130-744 23130-158 23130-158 60113-267 60113-267 60220-003 60220-003 21130-745 23130-158 60113-267 60220-003 21130-746 23130-158 60113-267 60220-003 Interior mounting Swing frames for cabinet width 800 mm Order Information Swing frame 120° Swing frame 120° Swing frame 160° Stop 120° Swing frame 160° Swing frame trim Stop 160° Asymmetrical assembly 1 1 2 2 100 200 01005070 Height U partial height partial height 29 33 38 42 47 Width St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) 01005061 01005070 01005061 Safety lock Symmetrical assembly 100 01005058 01005057 01015060 St; for safety reasons a swing frame stop is recommended St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 160° hinge, square locks incl. 2 keys St, swing frame stop is recommended for safety reasons St, 1.5 mm, RAL 7021, trim (item 1, width 200 mm) incl. handle (item 2) and cutout for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes for swing frame, instead of square lock, incl. 2 keys Usable height U mm assembled PU 1 kit assembled PU 2 pieces assembled PU 1 kit assembled 1 piece assembled PU 2 pieces assembled 1 piece assembled 12 800 21130-747 23130-158 21130-761 23130-159 – – 60113-267 21 800 21130-748 23130-158 21130-762 23130-159 21130-432 21130-442 60113-267 25 30 34 39 43 800 800 800 800 800 21130-749 21130-750 23130-158 23130-158 21130-763 21130-764 23130-159 23130-159 21130-433 21130-434 21130-443 21130-444 60113-267 60113-267 21130-751 23130-158 21130-765 23130-159 21130-435 21130-445 60113-267 21130-752 21130-753 23130-158 23130-158 21130-766 21130-767 23130-159 23130-159 21130-436 21130-437 21130-446 21130-447 60113-267 60113-267 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.77 Cabinets – VARISTAR EMC ServicePLUS Interior mounting Stationary shelves Order Information Stationary shelf Full depth Stationary shelf Shortened by 100 mm Depth member, 3 rows Completely in RAL 7021 (black grey) 01004142 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004142 01004126 St, 1.5 mm, static St, 1.5 mm, static length 460 mm, St, 1.5 mm, finish load-carrying load-carrying capacity 75 kg, AlZn required for capacity 75 kg, recessed shelf 1 U, depth 479 1 U, incl. GND/ mm, incl. GND/ earthing earthing, for recessed installation please order depth member separately Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.78 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 1 piece 1 piece PU 1 pair assembled assembled assembled RAL 7021 RAL 7021 AIZn 21130-323 21130-322 23130-081 21130-325 21130-323 21130-324 21130-322 23130-082 23130-081 21130-325 21130-324 23130-082 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-333 21130-332 23130-081 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-327 – – 21130-333 21130-335 21130-332 21130-334 23130-081 23130-082 21130-323 21130-322 23130-081 21130-325 21130-327 21130-324 23130-082 – – 21130-335 21130-334 23130-082 RAL 7035 RAL 7035 AIZn 22130-323 22130-322 23130-081 22130-325 22130-323 22130-324 22130-322 23130-082 23130-081 22130-325 22130-324 23130-082 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 22130-333 22130-332 23130-081 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 22130-327 – – 22130-333 22130-335 22130-332 22130-334 23130-081 23130-082 22130-323 22130-322 23130-081 22130-325 22130-327 22130-324 23130-082 – – 22130-335 22130-334 23130-082 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS Interior mounting Telescopic shelves, 70 kg Order Information Telescopic shelf, 2 U Full depth Shortened by 100 mm Mounting bracket T-bar lock GND/earthing Completely in RAL 7021 (black grey) 01004144 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004145 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately 01005054 St, finish AlZn 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 4 pieces 1 piece PU 1 kit assembled assembled assembled assembled assembled AIZn 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 RAL 7021 RAL 7021 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 23130-274 23130-092 23130-140 21130-373 21130-372 23130-274 23130-092 23130-140 21130-353 21130-355 21130-352 21130-354 23130-274 23130-092 23130-140 – – – – – 21130-373 21130-375 21130-372 21130-374 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 21130-353 21130-352 21130-355 21130-354 – – – – – 21130-375 21130-374 23130-274 23130-092 23130-140 AIZn 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 RAL 7035 RAL 7035 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 23130-274 23130-092 23130-140 22130-373 22130-372 23130-274 23130-092 23130-140 22130-353 22130-355 22130-352 22130-354 23130-274 23130-092 23130-140 – – – – – 22130-373 22130-375 22130-372 22130-374 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-353 22130-352 22130-355 22130-354 – – – – – 22130-375 22130-374 23130-274 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.79 Cabinets – VARISTAR EMC ServicePLUS Interior mounting 19" shelves 1 U, stationary 75 kg, telescopic 30 kg Order Information Dimension 19'' stationary shelf, 1 U, 75 kg Full depth 19'' telescopic shelf, 1 U, 30 kg Full depth Shortened by 100 mm GND/earthing W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Shortened by 100 mm c D Standard fitting 01004118 01004119 01004123 01004122 xf = distance from St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying load-carrying load-carrying front capacity 30 kg, capacity 30 kg, capacity 75 kg, capacity 75 kg, c = pitch of 19" incl. telescopic incl. telescopic depth 500 mm, depth 600 mm, panel/slide slide; slide; incl. GND/ incl. GND/ mounts please order please order earthing earthing D = cabinet depth GND/earthing kit GND/earthing kit W = cabinet width separatelyy separately 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm RAL 7021 RAL 7021 RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 21130-303 21130-302 21130-343 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-305 21130-302 21130-304 21130-343 21130-345 21130-342 21130-344 RAL 7035 RAL 7035 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 22130-303 22130-302 22130-343 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-305 22130-302 22130-304 22130-343 22130-345 22130-342 22130-344 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.80 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF PRODUCT CATALOG E 08/2017 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled 23130-140 23130-140 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-303 21130-302 21130-343 21130-342 21130-305 21130-309 21130-304 21130-345 21130-344 – – – 21130-303 21130-302 21130-343 21130-342 21130-303 21130-303 21130-302 21130-302 21130-343 21130-343 21130-342 21130-342 21130-305 21130-304 21130-345 21130-344 21130-309 21130-303 – – – – 21130-302 21130-343 21130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 23130-140 23130-140 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-303 22130-302 22130-343 22130-342 22130-305 22130-309 22130-304 22130-345 22130-344 – – – 22130-303 22130-302 22130-343 22130-342 22130-303 22130-303 22130-302 22130-302 22130-343 22130-343 22130-342 22130-342 22130-305 22130-304 22130-345 22130-344 22130-309 22130-303 – – – – 22130-302 22130-343 22130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS Interior mounting 19" telescopic shelves, 2 U, 70 kg Order Information Dimension Shelf, telescopic, 2 U, 70 kg Full depth T-bar lock GND/earthing W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Shortened by 100 mm c D Standard fitting xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width 01004123 St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 417 mm, depth 482 mm, incl. telescopic slide, please order T-bar lock and earthing kit separately 01004122 St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 400 mm, depth 682 mm, incl. telescopic slide, please order T-bar lock and earthing kit separately 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 21130-353 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 22130-353 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-353 21130-352 21130-355 21130-354 – – 21130-353 21130-352 21130-353 21130-353 21130-352 21130-352 21130-355 21130-354 – – – – 21130-353 21130-352 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-353 22130-352 22130-355 22130-354 – – 22130-353 22130-352 22130-353 22130-353 22130-352 22130-352 22130-355 22130-354 – – – – 22130-353 22130-352 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.81 Cabinets – VARISTAR EMC ServicePLUS Interior mounting Slide rails, depth members Order Information Dimension Slide rail 25 kg Short slide rail 100 kg Depth member, 3 rows c D Standard fitting W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004115 01004154 St, 1.5 mm, St, 2.5 mm, St, 1.5 mm, xf = distance from finish AlZn, static zinc-plated, static finish AlZn, static front load-carrying load-carrying load-carrying c = pitch of 19" capacity 15 kg/ capacity 100 kg/ capacity 25 kg/ panel/slide pair pair pair mounts D = cabinet depth W = cabinet width 01004126 length 460 mm, St, 1.5 mm, finish AlZn required for shortened shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 50 50 50 50 50 50 50 50 50 70 50 150 50 50 70 150 500 700 500 700 500 700 500 500 700 740 500 500 500 700 740 500 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.82 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 SCHROFF PRODUCT CATALOG E 08/2017 PU 2 pieces PU 2 pieces PU 1 kit PU 1 pair supplied loose supplied loose supplied loose assembled AIZn zinc-plated AIZn 23130-096 23130-118 23130-096 23130-118 23130-097 23130-096 23130-119 23130-118 23130-096 23130-118 23130-097 23130-098 23130-119 23130-120 23130-094 23130-094 23130-094 23130-094 AIZn 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-081 23130-094 23130-082 23130-084 23130-096 23130-118 23130-096 23130-096 23130-118 23130-118 23130-097 23130-119 23130-094 23130-082 23130-098 23130-096 23130-120 23130-118 23130-094 23130-084 23130-082 AIZn verzinkt AIZn 23130-096 23130-118 23130-096 23130-118 23130-097 23130-096 23130-119 23130-118 23130-096 23130-118 23130-097 23130-098 23130-119 23130-120 23130-094 23130-094 23130-094 23130-094 23130-094 23130-081 23130-082 23130-081 AIZn 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-081 23130-094 23130-082 23130-084 23130-096 23130-118 23130-096 23130-096 23130-118 23130-118 23130-097 23130-119 23130-094 23130-082 23130-098 23130-096 23130-120 23130-118 23130-094 23130-084 23130-082 23130-094 23130-081 23130-082 23130-081 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS Interior mounting Cable ductings Order Information Cable ducting with C-profile C-rail for cabinet depth C-rail for cabinet width Cable tie Slide nut Velcro General components Cable shell Mechanics Completely in RAL 7021 (black grey) from page 3.2 01006109 St, 1.5 mm, finish AlZn 01006107 St, 1.5 mm, finish AlZn 01504054 for C-rail Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 Depth mm mm 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 for C-rail or for cable support rail, for cable bundles of 42 ... 46 mm ; further dimensions see page 1.66 01005078 plastic, 92 mm x 2.5 mm; further dimensions see page 1.67 01005079 black, length 300 mm Electrics AlZn Width Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 vnt009 600 800 600 800 600 800 600 600 800 1000 600 800 600 800 1000 800 PU 2 pieces PU 2 pieces PU 10 pieces PU 10 pieces PU 25 pieces PU 10 pieces supplied loose supplied loose supplied loose supplied loose supplied loose supplied loose AIZn AIZn 23130-086 23130-333 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-334 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-334 21120-140 20114-731 20118-351 20118-624 23130-087 23130-333 21120-140 20114-731 20118-351 20118-624 23130-089 23130-087 23130-334 21120-140 20114-731 20118-351 20118-624 AIZn AIZn 23130-333 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-334 21120-140 20114-731 20118-351 20118-624 23130-333 21120-140 20114-731 20118-351 20118-624 23130-334 21120-140 20114-731 20118-351 20118-624 23130-087 23130-333 21120-140 20114-731 20118-351 20118-624 23130-089 23130-087 23130-334 21120-140 20114-731 20118-351 20118-624 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-086 23130-087 23130-089 23130-086 23130-087 23130-086 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 from page 3.29 Power distribution from page 3.50 Climate control 23130-086 23130-087 23130-089 23130-086 23130-087 23130-086 from page 4.0 .... SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.83 VARISTAR Seism icMain Catalogue Cabinets – VARISTAR Seismic Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01008007 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 01008062 Welded basic frame with strengthening brackets 01008008 Bellcore test in laboratory Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01008063 Seismic base with NEBS fixing 01005083 Test results Appendix . . . . . 12 1.84 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic Overview . . . . . . 1.84 VARISTAR Seism icMain Catalogue The earthquake-resistant cabinet 쮿 Earthquake resistance tested to Bellcore zone 4 with a dynamic load-carrying capacity of 250 kg 쮿 Customised solutions with higher loading are available VARISTAR Platform . . . . . . . . 1.4 Dimensions . . . . . 1.8 쮿 Optional EMC shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz Seismic cabinets off-the-shelf VARISTAR Seismic 쮿 Earthquake-resistant up to Bellcore Zone 4 IP 20 . . . . . . . . . . . . 1.86 IP 55 and EMC . . . 1.87 쮿 Versions - IP 20 - IP 55 with EMC shielding Accessories 19" panel/slide mount . . . . . . . . . . 1.88 19" fixing materials kit, M6 . . . . . . . . . . . . . 1.88 Slide rails . . . . . . . . 1.89 19" shelves . . . . . . 1.90 Depth members . . 1.93 C horizontal rails . 1.93 Cable ties, Velcro . . . . . . . . . . . 1.95 01005018 ServicePLUS . . . 1.96 IP 20 . . . . . . . . . . . . 1.98 IP 55 . . . . . . . . . . . . 1.102 EMC . . . . . . . . . . . . . 1.106 Interior configuration . . . . 1.110 ServicePLUS from page 1.96 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) www.schroff.biz/ServicePLUS VARISTAR Electronics . . . . . . VARISTAR EMC. . . . . . . . . . . . VARISTAR Datacom and Networking Technology . . . . . . VARISTAR air/ water heat exchanger . . . . . . 1.10 1.54 1.124 1.224 30407004 SCHROFF.PENTAIR.CO.UK 1.85 Cabinets – VARISTAR Seismic VARISTAR Seismic, IP 20 VARISTA R Seis micMain CatalogueP art number in bold face type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days 쮿 Earthquake-resistant up to Bellcore Zone 4 쮿 Dynamic load-carrying capacity of 250 kg 쮿 Doors with 3-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 800 kg (Heavy-Duty) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 1 1 5 6 7 8 1 2 1 2 9 1 Description Welded basic frame, Heavy-Duty, St profile, RAL 7021, with strengthening brackets Earthquake base, St, RAL 7021 Top cover, raised, St, RAL 7021 Front door, St, RAL 7035, 180° hinge, 3-point locking, lever handle Rear panel, screw fixed, St, RAL 7035 Side panel, screw fixed, St, RAL 7035 Base plate, multi-piece, St, RAL 7021, open at the rear 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01005018 Height Height H Width W Depth D U mm mm mm 38 1900 600 800 42 2100 600 600 42 2100 600 800 DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for raised top cover PU 4 pieces Part no. 10130-189 10130-023 10130-188 25127-995 23130-085 Note 쮿 Other dimensions and versions available on request 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.88 Welded basic frame with strengthening brackets Bellcore test 01005084 01005083 ServicePLUS see page 1.96 1.86 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic VARISTAR Seismic, IP 55 and EMC VARISTAR Sei smic 쮿 Earthquake secure (up) to Bellcore Zone 4 쮿 Shielding 60 dB at 1 GHz, 40 dB at 3 GHz (tested to IEC 61587-3) 쮿 Dynamic load-carrying capacity of 250 kg 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 800 kg (Heavy-Duty) Delivery comprises (assembled) Item 1 Qty 1 2 3 1 1 4 1 5 1 6 2 7 8 1 2 9 1 Description Welded basic frame, Heavy-Duty, St profile, RAL 7021, with strengthening brackets Earthquake base, St, RAL 7021 EMC, flat top cover, flush, St, finish AlZn, exterior RAL 7021 Front door, St, finish AlZn, powder-coated RAL 7035, 180° hinge, 4-point locking, lever handle Rear panel, screw fixed, St, finish AlZn, powdercoated RAL 7035 Side panel, screw fixed, St, finish AlZn, powdercoated RAL 7035 Base plate, one-piece, St, finish AlZn 19" panel/slide mount with EIA perforation, St, finish AlZn, front mounted, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01008030 Height Height H Width W Depth D U mm mm mm 42 2100 600 800 DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces Part no. 10130-195 25127-995 23130-072 Note 쮿 Other dimensions and versions available on request 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.88 Shielding: Tested to IEC 61587-3, standard dimensions of test object 2000 x 600 x 600 mm Welded basic frame with strengthening brackets 01005084 [dBµV] 120 100 80 60 40 Bellcore test ServicePLUS see page 1.96 01005083 01007056 20 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.87 Cabinets – VARISTAR Seismic 19" panel/slide mount with universal pitch (EIA) VARISTA R Seis mic 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 44,45 44.45 12,75 15,9 65,1 2 76 25 25 49,5 Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 9,6 42,5 Item 1 01004112 01004131 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. Partialheight 8 395 23130-037 23130-027 mounting Partialheight 12 545 23130-038 23130-028 mounting Partialheight 16 745 23130-039 23130-029 mounting Partialheight 20 895 23130-040 23130-030 mounting Partialheight 24 1095 23130-031 23130-021 mounting 1400 29 1295 23130-032 23130-022 1600 33 1495 23130-033 23130-023 1800 38 1695 23130-034 23130-024 2000 42 1895 23130-035 23130-025 Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 25127-997 Note Standard assembly dimension xr = xf = 50 mm 01005088 쮿 For 19" partial-height mounting depth members are necessary 쮿 Metric panel/slide mounts available on request 19" assembly kit, M6 VARISTA R Seis mic 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 1.88 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic Slide rails VARISTAR Sei smic 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 Wide support surface (48 mm) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair Delivery comprises 01004056 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load-carrying capacity 25 kg For cabinet depth D mm 600 600 800 800 xf mm 50 50 50 50 c mm 500 500 700 700 Length L mm 456 456 656 656 Qty/PU 2 10 2 10 Part no. 23130-096 23130-101 23130-097 23130-102 01005086 Static load-carrying capacity 25 kg Order Information Static load-carrying capacity 100 kg For cabinet depth D mm 600 600 800 800 SCHROFF.PENTAIR.CO.UK Length L mm 458 458 658 658 Qty/PU 2 10 2 10 Part no. 23130-118 23130-123 23130-119 23130-124 D c xf c - 130 c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth c mm 500 500 700 700 01004058 Static load-carrying capacity 100 kg 19” xf mm 50 50 50 50 01004130 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.89 Cabinets – VARISTAR Seismic 19'' stationary shelf, 75 kg VARISTA R Seis mic 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf, PU 1 piece D d Order Information RAL 7021 Part no. 21130-303 21130-305 23130-310 Note xf w 쮿 Cable ducting with cable ties, see page 1.95 쮿 Other sizes, see ServicePLUS, page 1.114 W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension 1.90 SCHROFF PRODUCT CATALOG E 07/2017 01004067 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic 19'' telescopic shelf, 30 kg VARISTAR Sei smic 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information D c c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 417 x 482 50 500 22130-343 800 417 x 682 50 700 22130-345 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-343 21130-345 23130-140 Note xf d Full depth 쮿 Cable ducting with cable ties, see page 1.95 01004069 Order Information Shortened depth Shortened by 100 mm W For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 417 x 382 50 500 22130-342 800 417 x 582 50 700 22130-344 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-342 21130-344 23130-140 Note D c xr w xf d 쮿 Cable ducting with cable ties, see page 1.95 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004070 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.91 Cabinets – VARISTAR Seismic 19'' telescopic shelf, 70 kg VARISTA R Seis mic 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 W Delivery comprises w Item 1 Qty 1 2 3 2 1 xr Full depth 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 405 x 482 50 500 22130-353 800 405 x 682 50 700 22130-355 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Order Information 01004069 Shortened depth RAL 7021 Part no. 21130-353 21130-355 23130-092 23130-140 Note 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.95 W w xr Order Information D For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 405 x 382 50 500 22130-352 800 405 x 582 50 700 22130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR d c Shortened by 100 mm RAL 7021 Part no. 21130-352 21130-354 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.95 c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension 1.92 SCHROFF PRODUCT CATALOG E 07/2017 01004070 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic Depth member VARISTAR Sei smic 쮿 For fitting shortened 19" panel/slide mounts and mounting plates 쮿 Cable ducting by means of cable ties and cable eye 50 Delivery comprises 121,2 25 25 100 37,5 36,5 11,5 L - 27 12 Item 1 2 Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information L 0100412601004079 For cabinet depth Length L mm mm 600 460 800 660 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-081 23130-082 21101-151 21101-150 쮿 Cable ducting with cable ties, see page 1.95 coa43697 Cable eye C-profile for the cabinet depth VARISTAR Sei smic 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut 31,5 ,5 x Ø6 15 50 11 L 50 Part no. 23130-086 23130-087 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 29,5 L- For cabinet depth Length L mm mm 600 460 800 660 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces 쮿 Cable ties and Velcro for cable retention rail see page 1.95 75 01504054 C-profile SCHROFF.PENTAIR.CO.UK 01004132 01006071 Cable retention rail Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.93 Cabinets – VARISTAR Seismic C-profile for cabinet width VARISTA R Seis micMain CatalogueP art number in bold face type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-profile Slide nut For cabinet width Length mm mm 600 550 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-333 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.95 75 01006071 Cable retention rail 1.94 01006064 SCHROFF PRODUCT CATALOG E 07/2017 01504054 ELECTRONICS PROTECTION Cabinet accessories – VARISTAR Seismic Cable ties, Velcro VARISTAR Sei smicMain C ataloguePart number in bold face type: ready for des patch within 2 working daysP art number in normal type: ready for despatch within 10 working days 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie 01005078 Velcro Part no. 20118-351 20118-352 20118-353 20118-624 01005079 VARISTAR EMC VARISTAR Sei smic ServiceP LUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.95 Cabinets – VARISTAR Seismic ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.98 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without supplement modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data, modify and send back solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete construction, cabling (power supply), function testing 쮿 Ready to despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, custom solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.96 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, set-up service, replacement service, spare parts SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS VARISTAR Seismic IP 20, IP 50, EMC ServicePLUS: Configuration Main C atalogue Page 쮿 Dimensions in catalogue: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 600 and 800 mm Seismic IP 20 Frames, side-by-side mounting kits, base/plinth Side panels, rear panels, doors, top covers Base plates, brush strips, filter inserts Connecting plates for short doors/rear panels 쮿 Other dimensions and configurations, sorted by IP 20, IP 55 and EMC online at www.schroff.biz/conf 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 1.98 1.99 1.100 1.101 Seismic IP 55 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Frames, gasketing kits, side-by-side mounting kits, base/plinth Side panels, rear panels, doors, top covers 1.102 1.103 Base plates, gasketing 1.104 Connecting plates for short doors/rear panels 1.105 Seismic EMC Frames, gasketing kits, side-by-side mounting kits, base/plinth Side panels, rear panels, doors, top covers 1.106 1.107 Base plates 1.108 Connecting plates for short doors/rear panels 1.109 Interior configuration Swing frames 1.110 19" panel/slide mounts 1.111 Mounting plates, stationary shelves, 75 kg Telescopic shelves, 70 kg 19" shelves 1 U, stationary 75 kg, telescopic 30 kg 19" telescopic shelves, 2 U, 70 kg Slide rails, depth members 01004077 Example configuration (here: row 12) Qty 1 1 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description Frame heavy duty, St profile, with strengthening brackets, height 2000 mm, width 600 mm, depth 800 mm, 1 piece Side panel, screw fixed, RAL 7021, PU 2 pieces Rear panel, screw-fixed, RAL 7021, 1 piece Steel door with 3-point locking, RAL 7021, IP 55, 1 piece Base/plinth, 1 piece .......... 1.112 1.113 1.114 1.115 1.116 Cable ductings 1.117 Cable ties, Velcro 1.118 ServicePLUS: solution project examples 1.119 Order no. 20130-630/05 21130-011/05 21130-069/05 21130-159/05 23130-455/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.97 Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 20 Frames, side-by-side mounting kits, base/plinth Seismic frame Heavy-Duty 800 kg Side-by-side mounting kit IP 20 104,5 Completely in RAL 7021 (black grey) Base/plinth D W 01009060 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 01004117 01009062 2 support side-by-side St, 1.5 mm, zincmounting bracket profiles, St, 4 mm, plated, with lateral; 2 trims, (4 pieces), St; 8 reinforcing brackets, central RAL 7021, not in St, 4 mm, front/ rear; combination with GND/earthing point, static load- decorative frame height 104.5 mm; static loadcarrying capacity carrying capacity 800 kg 1000 kg 1 piece PU 1 kit 1 piece assembled supplied loose assembled RAL 7021 RAL 7021 20130-617 23130-454 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 23130-061 23130-061 23130-061 23130-061 23130-061 23130-061 23130-061 23130-455 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 20130-633 20130-634 23130-061 23130-454 23130-455 20130-636 23130-061 23130-457 RAL 7021 RAL 7021 20130-617 23130-454 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 23130-061 23130-061 23130-061 23130-061 23130-061 23130-061 23130-061 23130-455 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 20130-633 20130-634 23130-061 23130-454 23130-455 20130-636 23130-061 23130-457 Further dimensions and configurations online at www.schroff.biz/conf 1.98 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 20 Side panels, rear panels, doors, top covers Screw-fixed side panel Screw-fixed rear panel Steel door 3-point locking DIN profile half cylinder Plain flush top cover Flat top cover Lifting eye Completely in RAL 7021 (black grey) M12 01004083 St, 1 mm, incl. GND/earthing 01004085 St, 1 mm, incl. GND/earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK 01008085 01004148 for lever handle, St, 1.5 mm, common locking opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/ earthing 01004096 01004100 St, 1.5 mm, incl. GND/earthing for top cover, applications and load in accordance with DIN 582 PU 2 pieces 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled assembled RAL 7021 21130-003 RAL 7021 RAL 7021 21130-242 21130-063 21130-153 25127-995 21130-065 21130-155 25127-995 21130-066 21130-156 25127-995 21130-067 21130-157 25127-995 21130-068 21130-158 25127-995 21130-069 21130-159 25127-995 21130-070 21130-160 25127-995 21130-015 21130-016 21130-071 21130-161 25127-995 21130-242 21130-243 23130-072 21130-016 21130-072 21130-162 25127-995 21130-247 23130-072 RAL 7035 RAL 7035 RAL 7035 21130-004 21130-005 21130-006 21130-005 21130-006 21130-007 21130-008 21130-007 21130-008 21130-010 21130-011 21130-010 21130-011 22130-003 21130-243 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 RAL 7021 21130-242 22130-063 22130-153 25127-995 22130-065 22130-155 25127-995 22130-066 22130-156 25127-995 22130-067 22130-157 25127-995 22130-068 22130-158 25127-995 22130-069 22130-159 25127-995 22130-070 22130-160 25127-995 22130-015 22130-016 22130-071 22130-161 25127-995 21130-242 21130-243 23130-072 22130-016 22130-072 22130-162 25127-995 21130-247 23130-072 22130-004 22130-005 22130-006 22130-005 22130-006 22130-007 22130-008 22130-007 22130-008 22130-010 22130-011 22130-010 22130-011 21130-243 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.99 Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 20 Base plates, brush strips, filter inserts Base plate Base plate, multipiece Brush strip Dust filter set Cover plate Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width mm Depth mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.100 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 01004105 01004059 01004106 nylon, black 1 piece 1 piece 1 piece assembled assembled assembled assembled RAL 7021 RAL 7021 23130-001 23130-002 23130-074 23130-075 23130-076 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-006 filter mat, white, class M1, in accordance with EN 799-G3 St, 1.5 mm, please order gasket IP55 separately St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing ; Dimension drawings see page 1.9 1 piece RAL 7021 RAL 7021 RAL 7021 23130-001 23130-002 23130-074 23130-075 23130-076 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-074 23130-075 23130-076 23130-034 23130-035 23130-036 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 07/2017 RAL 7021 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 20 Connecting plates for short doors/rear panels Dimensioning connecting plate door/rear panel Connecting plate for door and rear panel Plain With brush strip Assembly kit Other VARISTAR interior mounting parts Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door 01005063 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01005069 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01004066 01004056 e.g. only required if stationary shelves, rear panel 19" shelves, is assembled slide rails, above the cable ducting connecting plate 1 piece 1 piece PU 1 kit assembled assembled assembled RAL 7021 RAL 7021 21130-472 21130-473 21130-478 21130-479 23130-164 23130-164 from page 1.110 from page 1.110 RAL 7035 RAL 7035 22130-472 22130-478 23130-164 22130-473 22130-479 23130-164 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.101 Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 55 Frames, gasketing kits, side-by-side mounting kits, base/plinth Seismic frame Heavy-Duty 800 kg Gasketing kit IP 55 Base/plinth Side-by-side mounting kit IP 55 (with gasket) 104,5 Completely in RAL 7021 (black grey) D W 01009060 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 01004157 01004117 01009062 2 support side-by-side St, 1.5 mm, zinc- seals are glued to the frame, so that mounting bracket profiles, St, 4 mm, plated, with lateral; 2 trims, (4 pieces), St, 8 strengthening all cladding parts St, 4 mm, front/ RAL 7021, incl. conform to brackets, central rear; gasket to cover protection type GND/earthing the gap between height 104.5 mm; IP 55 point, static loadstatic loadtwo racks; not in carrying capacity combination with carrying capacity 800 kg 1000 kg decorative frame 1 piece PU 1 kit PU 1 kit 1 piece assembled assembled supplied loose assembled RAL 7021 RAL 7021 20130-617 23130-454 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-455 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 20130-633 20130-634 23130-064 23130-062 23130-454 23130-455 20130-636 23130-064 23130-062 23130-457 RAL 7021 RAL 7021 20130-617 23130-454 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-064 23130-062 23130-455 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 20130-633 20130-634 23130-064 23130-062 23130-454 23130-455 20130-636 23130-064 23130-062 23130-457 Further dimensions and configurations online at www.schroff.biz/conf 1.102 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 55 Side panels, rear panels, doors, top covers Screw-fixed side panel Screw-fixed rear panel Steel door 3-point locking DIN profile half cylinder Plain flush top cover Flat top cover Lifting eye Completely in RAL 7021 (black grey) M12 01004083 St, 1 mm, incl. GND/earthing 01004085 St, 1 mm, incl. GND/earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK 01008085 01004148 for lever handle, St, 1.5 mm, common locking opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/ earthing 01004096 01004100 St, 1.5 mm, incl. GND/earthing for top cover, applications and load in accordance with DIN 582 PU 2 pieces 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled assembled RAL 7021 21130-003 RAL 7021 RAL 7021 21130-242 21130-063 21130-153 25127-995 21130-065 21130-155 25127-995 21130-066 21130-156 25127-995 21130-067 21130-157 25127-995 21130-068 21130-158 25127-995 21130-069 21130-159 25127-995 21130-070 21130-160 25127-995 21130-015 21130-016 21130-071 21130-161 25127-995 21130-242 21130-243 23130-072 21130-016 21130-072 21130-162 25127-995 21130-247 23130-072 RAL 7035 RAL 7035 RAL 7035 21130-004 21130-005 21130-006 21130-005 21130-006 21130-007 21130-008 21130-007 21130-008 21130-010 21130-011 21130-010 21130-011 22130-003 21130-243 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 RAL 7021 21130-242 22130-063 22130-153 25127-995 22130-065 22130-155 25127-995 22130-066 22130-156 25127-995 22130-067 22130-157 25127-995 22130-068 22130-158 25127-995 22130-069 22130-159 25127-995 22130-070 22130-160 25127-995 22130-015 22130-016 22130-071 22130-161 25127-995 21130-242 21130-243 23130-072 22130-016 22130-072 22130-162 25127-995 21130-247 23130-072 22130-004 22130-005 22130-006 22130-005 22130-006 22130-007 22130-008 22130-007 22130-008 22130-010 22130-011 22130-010 22130-011 21130-243 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.103 Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 55 Base plates, gasketing Base plate Base plate, multipiece Cover plate IP 55 gasket Base plate, one-piece, EMC, IP 55 Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width mm Depth mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.104 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 01004106 01004073 for base plate with cover 01004051 AlZn, 1.5 mm, incl. GND/ earthing, assembly from outside St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing ; Dimension drawings see page 1.9 1 piece St, 1.5 mm, please order IP55 gasket separately 1 piece 1 piece 1 piece assembled assembled assembled assembled RAL 7021 RAL 7021 AlZn 23130-076 23130-073 21130-281 21130-282 23130-076 23130-073 23130-036 23130-073 23130-001 23130-002 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-006 RAL 7021 23130-001 23130-002 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 07/2017 23130-076 23130-073 23130-036 23130-073 23130-076 23130-073 23130-036 23130-073 23130-076 23130-073 23130-036 23130-073 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-284 RAL 7021 AlZn 23130-076 23130-073 21130-281 21130-282 23130-076 23130-073 23130-036 23130-073 23130-076 23130-073 23130-036 23130-073 23130-076 23130-073 23130-036 23130-073 23130-076 23130-073 23130-036 23130-073 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-283 21130-284 21130-281 21130-282 21130-284 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic IP 55 Connecting plates for short doors/rear panels Dimensioning connecting plate door/rear panel Connecting plate Other VARISTAR interior mounting parts Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door 01005072 01004066 01004056 e.g. St, 1 mm, can also be fitted stationary shelves, 19" shelves, in upper part, slide rails, height 400 mm, cable ducting with assembly kit 1 piece assembled RAL 7021 21130-504 21130-505 from page 1.110 RAL 7035 22130-504 22130-505 from page 1.110 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.105 Cabinets – VARISTAR Seismic ServicePLUS Seismic EMC Frames, gasketing kits, side-by-side mounting kits, base/plinth Seismic frame EMC gasketing kit Heavy-Duty 800 kg Side-by-side mounting kit EMC 104,5 Completely in RAL 7021 (black grey) Base/plinth D W 01009060 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 01004157 St, 1.5 mm, zinc- gaskets are glued to the frame, plated, with thus all the 8 strengthening brackets, central following cover parts are GND/earthing conductively point, static loadlinked carrying capacity 800 kg 01004120 side-by-side mounting brackets (4 pieces), St 01009062 2 support profiles, St, 4 mm, lateral; 2 trims, St, 4 mm, front/ rear; height 104.5 mm; static loadcarrying capacity 1000 kg 1 piece PU 1 kit PU 1 kit 1 piece assembled assembled supplied loose assembled RAL 7021 20130-617 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 20130-633 20130-634 20130-636 RAL 7021 RAL 7021 23130-065 23130-063 23130-454 23130-455 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-457 RAL 7021 RAL 7021 20130-617 23130-454 20130-618 20130-621 20130-622 20130-623 20130-624 20130-625 20130-626 20130-627 20130-628 20130-629 20130-630 20130-631 20130-632 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-065 23130-063 23130-455 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 23130-454 23130-455 23130-456 23130-457 20130-633 20130-634 23130-065 23130-063 23130-454 23130-455 20130-636 23130-065 23130-063 23130-457 Further dimensions and configurations online at www.schroff.biz/conf 1.106 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic EMC Side panels, rear panels, doors, top covers Side panel, Rear panel, Steel door, 4-point locking screw fixed, EMC, screw fixed, EMC, Plain, EMC, IP 55 Perforated, EMC DIN profile half IP 55 IP 55 cylinder Flat top cover EMC, IP 55 Lifting eye Completely in RAL 7021 (black grey) M12 01004083 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK St, 1 mm, painted outside, AlZn inside, incl. GND/ earthing 01004085 St, 1 mm, painted outside, AlZn inside, incl. GND/ earthing 01004092 01004093 St, 1.5 mm, St, 1.5 mm, painted outside, painted outside, interior AlZn, interior AlZn, opening angle opening angle 180°, 180°, lever handle with lever handle with push button, incl. push button, incl. GND/earthing GND/earthing 01004148 for lever handle, common locking 01004096 01004090 St, 1.5 mm, exterior painted, interior AlZn, incl. GND/ earthing for top cover, applications and load in accordance with DIN 582 PU 2 pieces 1 piece 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 21130-023 21130-024 21130-078 21130-168 21130-198 25127-995 21130-080 21130-170 21130-200 25127-995 21130-081 21130-171 21130-201 25127-995 21130-082 21130-172 21130-202 25127-995 21130-083 21130-173 21130-203 25127-995 21130-084 21130-174 21130-204 25127-995 21130-085 21130-175 21130-205 25127-995 21130-086 21130-176 21130-206 25127-995 21130-087 21130-177 21130-207 25127-995 21130-025 21130-026 21130-025 21130-026 21130-027 21130-028 21130-027 21130-028 21130-030 21130-031 21130-030 21130-031 21130-035 21130-036 21130-036 RAL 7035 22130-023 RAL 7035 RAL 7021 RAL 7035 21130-272 21130-273 21130-272 21130-273 21130-276 21130-277 21130-272 21130-273 21130-276 21130-277 21130-272 21130-273 21130-276 21130-277 21130-272 21130-273 21130-277 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 RAL 7021 21130-272 22130-078 22130-168 21130-198 25127-995 22130-080 22130-170 21130-200 25127-995 22130-081 22130-171 21130-201 25127-995 22130-082 22130-172 21130-202 25127-995 22130-083 22130-173 21130-203 25127-995 22130-084 22130-174 21130-204 25127-995 22130-085 22130-175 21130-205 25127-995 22130-035 22130-036 22130-086 22130-176 21130-206 25127-995 21130-272 21130-273 23130-072 22130-036 22130-087 22130-177 21130-207 25127-995 21130-277 23130-072 22130-024 22130-025 22130-026 22130-025 22130-026 22130-027 22130-028 22130-027 22130-028 22130-030 22130-031 22130-030 22130-031 21130-273 21130-272 21130-273 21130-276 21130-277 21130-272 21130-273 21130-276 21130-277 21130-272 21130-273 21130-276 21130-277 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.107 Cabinets – VARISTAR Seismic ServicePLUS Seismic EMC Base plates Base plates one-piece, EMC, IP 55 with cable ducting, EMC perforated, with cable ducting, EMC Completely in RAL 7021 (black grey) 01004051 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.108 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 AlZn, 1.5 mm, incl. GND/ earthing, assembly from outside 01004108 AlZn, 1.5 mm, rear opening 60 mm deep, incl. GND/ earthing, assembly from outside 01008051 AlZn, 1.5 mm, incl. GND/ earthing; opening at rear for cabinet width of 600 mm: 359 x 60 mm, for cabinet width of 800 mm: 559 x 60 mm 1 piece 1 piece 1 piece assembled assembled assembled AlZn AlZn AlZn 21130-281 21130-291 23130-400 21130-282 21130-292 23130-401 21130-281 21130-282 21130-291 21130-292 23130-400 23130-401 21130-283 21130-293 23130-402 21130-284 21130-281 21130-294 21130-291 23130-403 23130-400 21130-282 21130-292 23130-401 21130-283 21130-284 21130-293 21130-294 23130-402 23130-403 21130-281 21130-291 23130-400 21130-282 21130-283 21130-292 21130-293 23130-401 23130-402 21130-284 21130-294 23130-403 21130-281 21130-282 21130-291 21130-292 23130-400 23130-401 21130-284 21130-294 23130-403 AlZn AlZn AlZn 21130-281 21130-291 23130-400 21130-282 21130-292 23130-401 21130-281 21130-282 21130-291 21130-292 23130-400 23130-401 21130-283 21130-293 23130-402 21130-284 21130-281 21130-294 21130-291 23130-403 23130-400 21130-282 21130-292 23130-401 21130-283 21130-284 21130-293 21130-294 23130-402 23130-403 21130-281 21130-291 23130-400 21130-282 21130-283 21130-292 21130-293 23130-401 23130-402 21130-284 21130-294 23130-403 21130-281 21130-282 21130-291 21130-292 23130-400 23130-401 21130-284 21130-294 23130-403 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Seismic EMC Connecting plates for short doors/rear panels Dimensioning connecting plate door/rear panel EMC connecting plate Flat plate, EMC, IP 55 Shortened plate, EMC, IP 55 Other VARISTAR interior mounting parts Completely in RAL 7021 (black grey) 01005077 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK door and rear panel must be selected 400 mm shorter than cabinet height 01005075 flat plate, stainless steel, 1 mm, height 400 mm, mounting can be at top or bottom 01005074 01004066 01004056 e.g. frame, stainless steel, stationary shelves, 19" shelves, 1 mm, slide rails, mounting at top cable ducting or bottom, height 400 mm, plate recessed by 40 mm, stainless steel, 1 mm 1 piece 1 piece assembled assembled RAL 7021 RAL 7021 21130-578 21130-580 21130-579 21130-581 RAL 7035 RAL 7035 22130-578 22130-580 22130-579 22130-581 from page 1.110 from page 1.110 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.109 Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Swing frames for cabinet width 600 mm Order Information Swing frame Stop 120° Safety lock 01005070 Height U partial height partial height 29 33 38 42 47 Spare key 01005061 01015060 St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) St; for safety reasons a swing frame stop is recommended for swing frame, instead of square lock, incl. 2 keys 01015059 Usable height U Width mm 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces supplied loose 12 600 21130-740 23130-158 60113-267 60220-003 21 600 21130-741 23130-158 60113-267 60220-003 25 30 34 39 43 600 600 600 600 600 21130-742 23130-158 60113-267 60220-003 21130-743 21130-744 23130-158 23130-158 60113-267 60113-267 60220-003 60220-003 21130-745 23130-158 60113-267 60220-003 21130-746 23130-158 60113-267 60220-003 Interior mounting Swing frames for cabinet width 800 mm Order Information Swing frame 120° Swing frame 120° Swing frame 160° Stop 120° Swing frame 160° Swing frame trim Stop 160° Asymmetrical assembly 1 1 2 2 100 200 01005070 Height U partial height partial height 29 33 38 42 47 1.110 Width St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) 01005061 01005070 01005061 Safety lock Symmetrical assembly 100 01005058 01005057 01015060 St; for safety reasons a swing frame stop is recommended St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 160° hinge, square locks incl. 2 keys St, swing frame stop is recommended for safety reasons St, 1.5 mm, RAL 7021, trim (item 1, width 200 mm) incl. handle (item 2) and cutout for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes for swing frame, instead of square lock, incl. 2 keys Usable height U mm assembled PU 1 kit assembled PU 2 pieces assembled PU 1 kit assembled 1 piece assembled PU 2 pieces assembled 1 piece assembled 12 800 21130-747 23130-158 21130-761 23130-159 – – 60113-267 21 800 21130-748 23130-158 21130-762 23130-159 21130-432 21130-442 60113-267 25 30 34 39 43 800 800 800 800 800 21130-749 21130-750 23130-158 23130-158 21130-763 21130-764 23130-159 23130-159 21130-433 21130-434 21130-443 21130-444 60113-267 60113-267 21130-751 23130-158 21130-765 23130-159 21130-435 21130-445 60113-267 21130-752 21130-753 23130-158 23130-158 21130-766 21130-767 23130-159 23130-159 21130-436 21130-437 21130-446 21130-447 60113-267 60113-267 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Interior mounting 19" panel/slide mounts 19" panel/slide mounts EIA Painted RAL 7021 19" assembly kit M6 Adapter bracket for reduced width W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) U height identification for 19" panel/ slide mount AIZn c D Dimension Standard fitting xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width 01004112 St, 1.75 mm; reduced-width adapter bracket required for 800 mm width; depth members are required for partial-height mounting 00505050 sc128 paper strip, white, assembly kit: serial numbered item 1: screws, from 1 ... 47 U item 2: cage nuts, item 3: washers 01004128 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK PU 1 pair PU 1 pair PU 4 pieces PU 50 pieces PU 4 pieces assembled assembled assembled supplied loose assembled RAL 7021 AIZn 23130-012 23130-032 25127-997 21101-809 – 23130-013 23130-033 25127-997 21101-809 – 23130-013 23130-033 25127-997 21101-809 23130-091 23130-014 23130-034 25127-997 21101-809 – 23130-014 23130-034 25127-997 21101-809 23130-091 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 23130-091 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 23130-091 RAL 7035 AlZn 23130-022 23130-032 25127-997 21101-809 – 23130-023 23130-033 25127-997 21101-809 – 23130-023 23130-033 25127-997 21101-809 23130-091 23130-024 23130-034 25127-997 21101-809 – 23130-024 23130-034 25127-997 21101-809 23130-091 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 23130-091 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 23130-091 AIZn Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.111 Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Mounting plates, stationary shelves, 75 kg Mounting plate Full height Height 1200 mm Strengthening brackets Stationary shelf Full depth Stationary shelf Shortened by 100 mm Depth member, 3 rows Completely in RAL 7021 (black grey) 01008052 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01008053 St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear mounted); strengthening bracket increases static load-carrying capacity; please order separately 01008080 St profile, increases static load-carrying capacity of mounting plate to 150 kg 01004142 01004142 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying cap. 75 kg, 1 U, capacity 75 kg, depth 479 mm, 1 U, incl. GND/ incl. GND/ earthing earthing, for recessed installation order depth members 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.112 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 1 piece 1 piece PU 2 pieces 1 piece 1 piece PU 1 pair assembled assembled assembled assembled assembled assembled zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 RAL 7021 RAL 7021 AIZn 21130-323 21130-322 23130-081 21130-325 21130-324 23130-082 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-333 21130-332 23130-081 21130-335 21130-323 21130-334 21130-322 23130-082 23130-081 21130-325 21130-324 23130-082 21130-333 21130-335 21130-332 21130-334 23130-081 23130-082 21130-323 21130-322 23130-081 21130-325 21130-333 21130-324 21130-332 23130-082 23130-081 21130-335 21130-334 23130-082 21130-322 21130-324 23130-081 23130-082 21130-334 23130-082 – 23130-413 23130-418 21130-323 21130-325 – 23130-414 23130-418 21130-335 zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 RAL 7035 RAL 7035 AlZn 21130-323 21130-322 23130-081 21130-325 21130-324 23130-082 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-333 21130-332 23130-081 21130-335 21130-323 21130-334 21130-322 23130-082 23130-081 21130-325 21130-324 23130-082 21130-333 21130-335 21130-332 21130-334 23130-081 23130-082 21130-323 21130-322 23130-081 21130-325 21130-333 21130-324 21130-332 23130-082 23130-081 21130-335 21130-334 23130-082 21130-322 21130-324 23130-081 23130-082 21130-334 23130-082 – 23130-413 23130-418 21130-323 21130-325 – 23130-414 23130-418 21130-335 SCHROFF PRODUCT CATALOG E 07/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Telescopic shelves, 70 kg Telescopic shelf, 2 U Full depth Shortened by 100 mm Mounting bracket T-bar lock GND/earthing Completely in RAL 7021 (black grey) 01004144 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004145 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately 01005054 St, finish AlZn 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 4 pieces 1 piece PU 1 kit assembled assembled assembled assembled assembled AIZn 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 RAL 7021 RAL 7021 21130-353 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 21130-373 21130-372 21130-375 21130-353 21130-374 21130-352 21130-355 21130-354 21130-373 21130-375 21130-372 21130-374 21130-353 21130-352 21130-355 21130-373 21130-354 21130-372 21130-375 21130-374 21130-353 21130-355 21130-352 21130-354 23130-274 23130-092 23130-140 21130-375 21130-374 23130-274 23130-092 23130-140 AlZn RAL 7035 RAL 7035 22130-353 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 22130-373 22130-372 22130-375 22130-353 22130-374 22130-352 22130-355 22130-354 22130-373 22130-375 22130-372 22130-374 RAL 7021 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-353 22130-352 22130-355 22130-373 22130-354 22130-372 22130-375 22130-374 22130-353 22130-355 22130-352 22130-354 23130-274 23130-092 23130-140 22130-375 22130-374 23130-274 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.113 Cabinets – VARISTAR Seismic ServicePLUS Interior mounting 19" shelves 1 U, stationary 75 kg, telescopic 30 kg 19'' stationary shelf, 1 U, 75 kg Full depth 19'' telescopic shelf, 1 U, 30 kg Full depth Shortened by 100 mm GND/earthing W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Shortened by 100 mm c D Dimension Standard fitting 01004118 01004119 01004123 01004122 St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static xf = distance load-carrying load-carrying load-carrying load-carrying from front capacity 30 kg, capacity 30 kg, capacity 75 kg, capacity 75 kg, c = pitch of 19" incl. telescopic incl. telescopic depth 500 mm, depth 600 mm, panel/slide slide; slide; incl. GND/ incl. GND/ mounts please order please order earthing earthing D = cabinet depth GND/earthing kit GND/earthing kit W = cabinet width separately separately 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm RAL 7021 RAL 7021 RAL 7021 RAL 7021 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 21130-303 21130-302 21130-343 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-305 21130-302 21130-304 21130-343 21130-345 21130-342 21130-344 RAL 7035 RAL 7035 RAL 7035 RAL 7035 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 22130-303 22130-302 22130-343 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-305 22130-302 22130-304 22130-343 22130-345 22130-342 22130-344 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.114 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF PRODUCT CATALOG E 07/2017 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled 21130-303 21130-302 21130-343 21130-342 21130-303 21130-303 21130-302 21130-302 21130-343 21130-343 21130-342 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-303 21130-302 21130-302 21130-343 21130-343 21130-342 21130-342 23130-140 23130-140 23130-140 23130-140 23130-140 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-303 21130-302 21130-343 21130-342 21130-303 21130-305 21130-302 21130-304 21130-343 21130-345 21130-342 21130-344 23130-140 21130-303 21130-302 21130-343 21130-342 23130-140 22130-303 22130-302 22130-343 22130-342 22130-303 22130-303 22130-302 22130-302 22130-343 22130-343 22130-342 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-303 22130-302 22130-302 22130-343 22130-343 22130-342 22130-342 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-303 22130-302 22130-343 22130-342 22130-303 22130-305 22130-302 22130-304 22130-343 22130-345 22130-342 22130-344 23130-140 22130-303 22130-302 22130-343 22130-342 23130-140 23130-140 23130-140 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Interior mounting 19" telescopic shelves, 2 U, 70 kg W 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width Cabinet dimensions Height No. U mm Width Depth mm mm 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK 01004123 GND/earthing 01004122 01004125 05904052 St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 400 mm, depth 682 mm, incl. telescopic slide, please order T-bar lock and earthing kit separately 1 piece to lock the telescopic shelf 1 piece PU 1 kit assembled assembled assembled assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 c mm RAL 7021 RAL 7021 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 21130-353 21130-355 21130-352 21130-354 RAL 7035 RAL 7035 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 22130-353 22130-355 22130-352 22130-354 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 T-bar lock St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 417 mm, depth 482 mm, incl. telescopic slide, please order T-bar lock and earthing kit separately 1 piece xf mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Shortened by 100 mm xf Completely in RAL 7021 (black grey) Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Telescopic shelf, 2 U, 70 kg Full depth c D Dimension Standard fitting 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-355 22130-354 22130-353 22130-353 22130-352 22130-352 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 for telescopic shelf Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.115 Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Slide rails, depth members Slide rail 25 kg Depth member, 3 rows W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Short slide rail 100 kg c D Dimension Standard fitting 01004115 01004154 St, 1.5 mm, St, 2.5 mm, St, 1.5 mm, xf = distance finish AlZn, static zinc-plated, static finish AlZn, static from front load-carrying load-carrying load-carrying c = pitch of 19" capacity 15 kg/ capacity 100 kg/ capacity 25 kg/ panel/slide pair pair pair mounts D = cabinet depth W = cabinet width 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 50 50 50 50 50 150 50 50 50 150 50 50 50 150 50 50 150 500 700 500 700 500 500 500 700 500 500 500 700 500 500 500 700 500 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1.116 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF PRODUCT CATALOG E 07/2017 PU 2 pieces PU 2 pieces PU 1 kit PU 1 pair supplied loose supplied loose supplied loose assembled AIZn zinc-plated AIZn 23130-096 23130-118 23130-096 23130-118 23130-096 23130-096 23130-118 23130-118 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-094 23130-094 23130-094 23130-094 AIZn 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-096 23130-118 23130-097 23130-096 23130-119 23130-118 23130-096 23130-118 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 AlZn zinc-plated AlZn 23130-096 23130-118 23130-096 23130-118 23130-096 23130-096 23130-118 23130-118 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-094 23130-094 23130-094 23130-094 23130-094 23130-094 23130-081 23130-082 23130-081 23130-082 AlZn 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-096 23130-118 23130-097 23130-096 23130-119 23130-118 23130-096 23130-118 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 23130-094 23130-094 23130-081 23130-082 23130-081 23130-082 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Cable ductings Cable ducting with C-profile C-rail for cabinet depth C-rail for cabinet width Slide nut Cable shell Cable support for C-rail Completely in RAL 7021 (black grey) 01006109 St, 1.5 mm, finish AlZn 01006107 St, 1.5 mm, finish AlZn 01504054 for C-rail Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) vnt009 for C-rail or for cable support rail, for cable bundles of 42 ... 46 mm, further dimensions see page 1.93 01006110 PA, UL 94 V-0, black, assembly by clipping onto the C-rail Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 SCHROFF.PENTAIR.CO.UK PU 2 pieces PU 2 pieces PU 10 pieces PU 10 pieces PU 5 pieces supplied loose supplied loose supplied loose supplied loose supplied loose AIZn AIZn 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-087 23130-334 21120-140 20114-731 60118-472 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-087 AlZn 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 AlZn Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.117 Cabinets – VARISTAR Seismic ServicePLUS Interior mounting Cable ties, Velcro Cable tie Velcro General components Mechanics Completely in RAL 7021 (black grey) from page 3.2 01005078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) plastic, 92 mm x 2.5 mm, further dimensions see page 1.95 01005079 black, length 300 mm, further dimensions see page 1.95 Electrics Cabinet dimensions Height No. U mm Width Depth mm mm PU 25 pieces PU 10 pieces supplied loose supplied loose Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 Colour combinations 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 1.118 29 29 33 33 33 33 38 38 38 38 42 42 42 42 47 47 47 1400 1400 1600 1600 1600 1600 1800 1800 1800 1800 2000 2000 2000 2000 2200 2200 2200 600 600 600 600 800 800 600 600 800 800 600 600 800 800 600 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 600 800 800 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 AlZn AlZn 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 SCHROFF PRODUCT CATALOG E 07/2017 from page 3.29 Power distribution from page 3.50 Climate control from page 4.0 ELECTRONICS PROTECTION Cabinets – VARISTAR Seismic ServicePLUS ServicePLUS: solution - project examples VARISTAR Sei smic ServiceP LUS Mobile communications technology 쮿 Slim-Line seismic cabinet with ETSI configuration 쮿 NEBS base mounting 쮿 Dynamic loading: 350 kg 쮿 Shielded version (EMC) 쮿 Complete cabling 쮿 Power distribution 쮿 Special cable entry in top cover 쮿 Doors and side panels with ventilation openings 5430301007023 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.119 VARISTAR MILMain Catalogue Cabinets – VARISTAR MIL Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01012005 01010017 01010069 Economic and uncompromising - a tailored standard Schroff offers robust 19" cabinets that meet the specifications of MIL-S-901D. Their characteristics allow you to meet the most stringent shock and vibration resistance requirements on the high seas: This cabinet was developed on the basis of the VARISTAR platform and impresses with its high integration capability. Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 쮿 High-performance elastomer or wire cable shock absorbers for COTS (commercial off-the-shelf) equipment 쮿 19" standard, in accordance with RoHS 쮿 Various dimensions available (height and depth) Systems . . . . . . . 8 쮿 Wide range of accessories available 쮿 Reduced development and manufacturing costs 쮿 HF shielding 01010068 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 From the qualification ... to the customer solution A cabinet for your individual requirements can be quickly and easily developed. It can be validated by numerical simulation thereby saving lengthy and expensive tests in laboratory. The elastic suspension is specially adapted to the mechanical environment and the resilience of the components. At the same time, the dimensions and weight of the cabinet are tailored to your specific integration requirements. The design is validated using a model that has been calibrated in real tests using a finite element calculation. Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 1.120 01010070 Finite element model - mesh and stress analysis SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR MIL Overview . . . . . . 1.120 VARISTAR MILMain Catalogue VARISTAR MILMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days The cabinet for the most demanding situations 쮿 Certified: Tested to MIL 901D 쮿 Capable of handling extreme stresses: Robust and secure for mobile use; dynamic loadcarrying capacity of 150 kg 쮿 Reliable: Shielded against high-frequency interference 쮿 Not susceptible: Type of protection IP 55 VARISTAR with shock absorbers 쮿 Two versions: 4 shock absorbers at bottom and 2 at top, for wall mounting – With wire cable shock absorbers – with elastomer shock absorbers VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 VARISTAR MIL VARISTAR MIL 901D . . . . . . . . 1.122 쮿 Height 38 U (1800 mm), width 600 mm, depth 800 mm 01012002 ServicePLUS . . . 1.123 ServicePLUS from page 1.123 e.g. special colours e.g. other cabinet dimensions e.g. higher dynamic load carrying capacity e.g. custom solutions VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . 1.54 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR Air/ water heat exchanger . . . . . . 1.224 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.121 Cabinets – VARISTAR MIL MIL 901D cabinets VARISTA R MILMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 Cabinet for extreme mobile situations 쮿 4 shock absorbers at bottom and 2 shock absorbers at top 쮿 Ingress protection IP 55 쮿 EMC protection 쮿 Tested to MIL-STD-901D 쮿 Rear panel horizontally partitioned for fitting of e.g. cable ducting Delivery comprises (assembled) Wire cable shock absorbers 01011001 Elastomer shock absorbers 01012004 Item 1 Qty 1 2 3 1 1 4 1 5 6 7 8 1 1 2 4 9 1 Description Welded basic frame, heavy duty, St profile, RAL 7032, with reinforcement brackets welded on floor frame, 10 mm, St, finish AlZn; base plate, St; 4 shock absorbers; EMC gasket Flat top cover, flush, St, finish AlZn, exterior RAL 7032 Front door, St, finish AlZn, RAL 7032, 180° hinge, 4-point locking, lever handle Rear panel, top, screw fixed, St, finish AlZn, RAL 7032; 2 shock absorbers; Rear panel, centre, screw fixed, St, finish AlZn, RAL 7032 Rear panel, bottom, screw fixed, St, finish AlZn, RAL 7032 Side panel, screw fixed, St, AlZn, RAL 7032 19" panel/slide mount with EIA perforation, St, finish AlZn, depth-adjustable in 25 mm increments GND/earthing kit, assembled Order Information Height U mm Width mm Depth mm 38 1800 600 800 38 1800 600 800 01011003 Wire cable shock absorbers Description With wire cable shock absorbers with elastomer shock absorbers Part no. 10130-198 10130-201 Note 쮿 Other dimensions and versions on request Rear view 1.122 SCHROFF Main catalogue 01012003 www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR MIL solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete construction, cabling (power supply), function test 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk lifecycle We are with you. For the entire product life. the product. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts Mobile applications for marine use 쮿 Heavy-Duty seismic cabinet with shock absorbers for use on ships 쮿 Shielded version (EMC) 쮿 Special connection plate for shielded cable entry 쮿 Integrated air filtered fan in the door 쮿 Power distribution 쮿 Customer-specific testing (vibration, EMC, climate) 32403011 SCHROFF.PENTAIR.CO.UK 01008022 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.123 Varistar Datacom /NetworkingMain Catalogue Cabinets – Varistar Datacom/Networking Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01006049 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 01006023 Professional cable management 01006033 Robust pull-out tilt protection Power supply units . . . . . . . . . . 9 01006084 Universal mounting possibility: With a mounting space of 740 mm between front and rear 19" plane in the standard version, around 90 % of all server types can be fitted immediately. Easy installation of servers with special dimensions by additional partial-height mounting and further 19" brackets. Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01006024 Large variety of accessories for all cabling zones 01006032 Heavy load shelves and slide rails Appendix . . . . . 12 1.124 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Overview . . . . . 1.124 VARISTAR Datacom /NetworkingMain Catalogue Made for datacom and cabling technology Varistar Platform 1.4 Dimensions . . . . . 1.8 쮿 Two frames with different stability but identical outer appearance 쮿 Two colour schemes for immediate selection with ServicePLUS 쮿 Wide range of versions and dimensions (depths 600 mm to 1200 mm) 쮿 Unique meander profile with multiple mounting options and new cable management possibilities Varistar NET Varistar NET Plus 01006012 Varistar Server 01006011 쮿 Cabling cabinet with one 19" plane 쮿 Datacom cabinet with two 19" planes and base 쮿 Single and side-by-side cabinets 쮿 Single and side-by-side cabinets 01006014 쮿 Server cabinet with perforated front and rear door, up to 1200 mm deep 쮿 Single and side-by-side cabinets Varistar NET. . . . . Varistar NET Plus Varistar Server . . . Assembly kit . . . . Castors. . . . . . . . . Lifting eye . . . . . . Top cover fan . . . Edge protection . Brush strip . . . . . Base plate . . . . . . Base/plinth . . . . . Tilt protection . . . 19 panel/slide mounts . . . . . . . . . Depth members . Slide rails. . . . . . . 19" shelves . . . . . Electronic locking Zone 1, zone 2 cable management . . . . Zone 3 cable management . . . . Zone 4 cable management . . . . Cable tie, Velcro . . . . . . . . . . Tray for excess cable lengths . . . 1.126 1.130 1.130 1.132 1.132 1.133 1.133 1.136 1.136 1.137 1.139 1.141 1.142 1.143 1.144 1.145 1.148 1.155 1.158 1.161 1.162 1.163 ServicePLUS . . . 1.164 ServicePLUS RAL 7021 . . . . . . . 1.165 ServicePLUS RAL 7035/RAL 7021 . . . 1.189 ServicePLUS from page 1.156 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. variants of uprights (Slim-Line, Heavy-Duty) e.g. custom solutions (special sizes) Varistar Electronics . . . . . Varistar EMC. Varistar Seismic . VARISTAR air/ water heat exchanger . . . . . 1.10 1.54 1.84 1.224 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.EN 1.125 Cabinets – VARISTAR Datacom/Networking Varistar server, 1600 kg VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Server cabinet with perforated doors, airflow rate 78% 5 쮿 Protection class IP 20 3b 쮿 Static load-carrying capacity up to 1600 kg 3a 쮿 Installation of different servers possible 2 쮿 Available in two color schemes – Stone gray RAL 7021 – Light gray RAL 7035 1 Delivery includes Item 1 Qty 1 2 3a 3b 4 1 1 1 1 5 1 6 2 7 4 8 4 9 10 4 1 4 H 6 7 8 W D 20 - 45 9 01014055 1.126 SCHROFF PRODUCT CATALOG E 05/2016 Description Welded basic frame (Slim-Line) from steel profiles, RAL 7021 Flat top cover, St, RAL 7021; with cutouts for brush strips Brush strip for 600 mm and 800 mm widths Brush strip for 800 mm width only Front door, St, with 180° hinges and perforation, 3-point locking and lever handle (can optionally be expanded with DIN profile half cylinder), color RAL 7035 or RAL 7021 (see Ordering Information) Rear double door, St, with 180° hinges and perforation, 3-point locking and lever handle (can optionally be expanded with DIN profile half cylinder), color RAL 7035 or RAL 7021 (see Ordering Information) Side panels, screw fixed, St, with inside locking, color RAL 7035 or RAL 7021 (see Ordering Information) 19" panel/slide mounts, St, mounted in 740 mm intervals, color RAL 7035 or RAL 7021 (see Ordering Information) Cross member, St (to accept 19" panel/slide mounts in 800 mm wide cabinets) Adjustable foot Earthing kit, fitted ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Varistar server, 1600 kg VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days Order Information Heig Height Width W Depth Colour ht H D U mm mm mm 42 2000 600 1200 42 2000 800 1200 Stone gray RAL 7021 47 2200 600 1200 47 2200 800 1200 42 2000 600 1200 42 2000 800 1200 Light gray RAL 7035 47 2200 600 1200 47 2200 800 1200 Accessories DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Spare key Handle with locking insert (6) 1 piece Tip-over protection for floor mounting is screwed to the floor, PU 2 pieces Part no. 10130-234 10130-232 10130-235 10130-233 10130-240 10130-238 10130-241 10130-239 25127-995 60127-018 23130-386 01014056 ServicePLUS see page 1.164 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.127 Cabinets – VARISTAR Datacom/Networking Varistar Colocation VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days 쮿 Colocation cabinets with 2, 3 or 4 divider units to accommodate e.g. servers – Perforated doors (airflow rate 78%) – Multi-point door locking to prevent unauthorized access (Iever handle with key and numeric code) – Access to false floors and cabling only from the appropriate divider unit 쮿 Flexible cabling, possible from above, below, left or right (data and power cables can be run separately) 쮿 Protection class IP 20 쮿 Color RAL 7021 (black gray) Delivery includes Illustration shows cabinet with 3 divider units 01013001 2 Item 1 Qty 1 2 1 3 2 per divider unit 2 per divider unit 2 per divider unit 2 per divider unit 4 per divider unit 2 per divider unit 4 1 4 5 5 6 1 4 7 6 8 3 9 10 7 Description Welded basic frame (Slim-Line) from steel profiles, RAL 7021 Flat top cover, St, RAL 7021, with brush strip (left and right) Front door, rack St, perforated, RAL 7035, 180° hinge, 2-point locking and lever handle (key and numeric code) Rear door, St, perforated, RAL 7021, 180° hinge, 2-point locking and lever handle (key and numeric code) Cable channels, left and right Depth member for fixing false floors and 19" profiles 19" panel, St, RAL 7035, with EIA perforation, depthadjustable in 25 mm increments, standard fitting position 74 mm recessed Base plate can be mounted from inside Adjustable foot Earthing kit, fitted 5 8 9 01013050 Detail of a divider unit 1.128 SCHROFF PRODUCT CATALOG E 05/2016 01013002 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Varistar Colocation VARISTAR Datacom/NetworkingPart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days Order Information 01013051 Height mm 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 Width mm 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 Depth mm 1000 1000 1000 1200 1200 1200 1000 1000 1000 1200 1200 1200 1000 1000 1000 1200 1200 1200 1000 1000 1000 1200 1200 1200 Number of subdivisions 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 2 3 4 Part no. 10130-202 10130-203 10130-204 10130-214 10130-215 10130-216 10130-205 10130-206 10130-207 10130-217 10130-218 10130-219 10130-208 10130-209 10130-210 10130-220 10130-221 10130-222 10130-211 10130-212 10130-213 10130-223 10130-224 10130-225 Note 쮿 Side panel must be ordered separately 쮿 For suitable side panel see page 1.167 쮿 Cable panel, see page 1.160 01013004 Illustration: Cable panel, two-sided through entire cabinet height, cable entry top/bottom Detail: Lever handle with numeric code 01013003 ServicePLUS see page 1.164 SCHROFF.PENTAIR.EN Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.129 Cabinets – VARISTAR Datacom/Networking Varistar NET Plus VARISTA R Datacom/Networking 쮿 Cabling cabinet with two 19" planes and base/plinth 쮿 Type of protection IP 20 쮿 Load-carrying capacity 400 kg according IEC 61587-1 쮿 Available in two versions – Single cabinet (with side panels) – Side-by-side cabinet (with side-by-side mounting kit) Delivery comprises (Completely assembled and earthed) Side-by-side cabinet (without side panel) 1.130 Single cabinet SCHROFF PRODUCT CATALOG E 05/2016 01006011 Item 1 Qty 1 2a 1 2b 1 3 1 4 1 5a 2 5b 6 1 4 7 4 8 1 9 1 10 1 Description Welded basic frame (Slim-Line) from steel profiles, RAL 7021 From cabinet height 42 U/47 U: top cover, St, RAL 7021 with prepunched perforation for subsequent assembly of brush strip, perforated cover plate or fan tray Cabinet height 24 U: top cover, St, RAL 7021, without cut-out zone Front door: frame St, RAL 7035, with safety glass 6 mm and 180° hinge, single point locking and lever handle (optionally with DIN profile half cylinder) Rear door, St, RAL 7035, with 180° hinge, single point locking and lever handle (optionally retrofittable with DIN profile half cylinder) Single cabinet: side panels, St, RAL 7035, with quick-release fastener Side-by-side cabinet: 1 side-by-side mounting kit Adaptor bracket for reduced width, St, finish AlZn, for assembly of 19" panel/slide mounts (only with 800 mm wide cabinets) 19" panel/slide mount, St, RAL 7035, with EIA perforation (800 mm wide cabinets: assembled on the adaptor bracket for reduced width), 600 mm cabinet depth: distance to front door 50 mm, at 800 mm 150 mm, from 900 mm cabinet depth: 70 mm; depth-adjustable in 25 mm increments Base plate for lateral cable ducting, St, RAL 7021, subsequent lateral assembly of brush strip possible Base/plinth, St, RAL 7021, height 100 mm with front and rear ventilation trim, mounted base/plinth trims, integrated feet GND/earthing kit, assembled ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Varistar NET Plus VARISTAR Datacom/Networking Order Information Height Side-by-side cabinet 01005102 Height Width Depth Side-by-side H W D cabinet U mm mm mm Part no. 24 1200 600 600 10130-073 24 1200 600 800 10130-075 24 1200 600 900 10130-077 24 1200 600 1000 10130-079 24 1200 800 600 10130-081 24 1200 800 800 10130-083 24 1200 800 900 10130-085 24 1200 800 1000 10130-087 42 2000 600 600 10130-089 42 2000 600 800 10130-091 42 2000 600 900 10130-093 42 2000 600 1000 10130-095 42 2000 800 600 10130-097 42 2000 800 800 10130-099 42 2000 800 900 10130-101 42 2000 800 1000 10130-103 47 2200 600 600 10130-105 47 2200 600 800 10130-107 47 2200 600 900 10130-109 47 2200 600 1000 10130-111 47 2200 800 600 10130-113 47 2200 800 800 10130-115 47 2200 800 900 10130-117 47 2200 800 1000 10130-119 DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Tilt protection for base mounting is screwed to the floor, PU 2 pieces Single cabinet Part no. 10130-072 10130-074 10130-076 10130-078 10130-080 10130-082 10130-084 10130-086 10130-088 10130-090 10130-092 10130-094 10130-096 10130-098 10130-100 10130-102 10130-104 10130-106 10130-108 10130-110 10130-112 10130-114 10130-116 10130-118 25127-995 23130-386 Note 쮿 The 24 U cabinet has a top cover without prepunched perforation (not suitable for retrofitting with brush strips, fan tray, etc.) 쮿 A standard cabinet can be expanded simply with additional components, see from page 1.189 Single cabinet 01005101 ServicePLUS see page 1.164 SCHROFF.PENTAIR.EN Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.131 Cabinets – VARISTAR Datacom/Networking Assembly kit VARISTA R Datacom/Networking 쮿 For direct assembly of 19" panel/slide mounts, depth members and further components on Varistar frame 쮿 Assembly by clipping in the cage nut into frame or depth member 쮿 Mounting of components possible from the inside as well as from the outside Delivery comprises (Kit) Item 1 2 Qty 50 50 Description Cage nut, St, M5, white zinc-plated Screw, St, M5 x 10, white zinc-plated Order Information Description Assembly kit, earthed Part no. 23130-141 01006065 Castors VARISTA R Datacom/Networking 쮿 For assembly on frame 쮿 Load-carrying capacity 400 kg Delivery comprises Item 1 2 3 Qty 2 2 1 Description Locking castor, PA/St Non-locking castor, PA/St Assembly kit Order Information Description Castors with 2 locking 01004082 Part no. 23130-077 Note 쮿 Not suitable in connection with base/plinth Castors with integrated adjustable feet VARISTA R Datacom/Networking 쮿 For assembly on frame 쮿 Load-carrying capacity 400 kg Delivery comprises Item 1 2 Qty 4 1 Description Castor with adjustable feet Assembly kit Order Information Description Castors with integrated adjustable feet Part no. 23130-078 Note 쮿 Not suitable in connection with base/plinth 01004156 1.132 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Lifting eye, Varistar VARISTAR Datacom/Networking 쮿 Thread M12 쮿 Application and static load-carrying capacity in accordance with DIN 582 (see Technical Info Section, chapter 12) Order Information Description Lifting eye for top cover Qty/PU 4 Part no. 23130-072 Note 쮿 Only suitable with top cover, not usable with raised cover M12 01004100 Fan unit with 3 fans VARISTAR Datacom/Networking 쮿 Suitable for flat top cover with cut-out zones 쮿 Mounting position completely in cabinet interior, no protrusion over top cover 쮿 3 fans fully wired 쮿 Mains connection via SCHUKO/UTE plug IEC 60320 C13 socket Delivery comprises (completely assembled and wired) 01006027 Item 1 2 Qty 1 3 3 4 3 1 Description Fan tray, RAL 7021 Axial fan 230 VAC, fully wired, connects via SCHUKO/UTE plug - IEC 60320-C12 socket Protective grille Assembly kit Order Information Description Qty/PU pieces 1 Part no. Fan unit with 3 fans Accessories Fan with grille, 230 VAC, 38 x 119 x 119 mm, 162 m3/h at 50 Hz, 1 piece Thermostat with mains cable 230 VAC (SCHUKO/UTE plug/ IEC 60320 C13 socket), adjustment range 0 ... 60°C, 1 piece 23130-070 23130-165 20118-750 Technical data of one fan Frequency Voltage Airflow volume Noise pressure level Max. static pressure Max. ambient temperature Power consumption 50 Hz 230 VAC 162 m 3/h 37 dB(A) 73 PA +70 °C 15 W 60 Hz 230 VAC 192 m3/h 41 dB(A) 88 PA +70 °C 14 W 01004102 SCHROFF.PENTAIR.EN Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.133 Cabinets – VARISTAR Flat top cover with cut-out zones VARISTA RMain CatalogPart number i n bold face type: ready for shipping w ithin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Cut-out zones are easy to cut out. 쮿 Cut-outs can be fitted with brush strips, fan units, perforated cover plates or edge protectors Delivery includes Item 1 Qty 1 2 1 Description Flat top cover, St, 1.5 mm, with cut-out zones for cutouts, RAL 7021 GND/earthing kit Order Information 01006097 01006092 01004102 01004103 41003065 Width Depth mm mm 600 600 600 800 600 900 600 1000 600 1100 600 1200 800 600 800 800 800 900 800 1000 800 1100 800 1200 Accessories Brush strip Nylon, black, PU 2 pieces Fan unit with 3 fans with 3 fans, fully assembled and wired, 1 kit Perforated cover plate for top cover with cut-out zones 6 mm perforation, incl. earthing, 1 piece Edge protection PVC, black, 3 m PVC, black, 3 m, 1 piece Part no. RAL 7021 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-544 21130-545 23130-069 23130-070 23130-071 28127-281 Flat top cover construction with Flat top cover construction with brush strips fan insert Flat cop cover construction with Flat top cover construction with cover plate edge protection 1.134 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Flat top cover with cable through-ducting openings Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Includes earthing 쮿 Color RAL 7021 쮿 St, 1.5 mm 쮿 Cutouts must be covered with brush strips, please order these separately Delivery includes 01015052 85 D 449 449 a Item 1 2 Qty 1 1 Description Flat top cover, St, 1.5 mm, with cutouts, RAL 7021 GND/earthing kit Order Information W b a 01015050 Flat top cover construction with brush strips Width W Depth D mm mm 600 1000 600 1100 600 1200 800 1000 800 1100 800 1200 Accessories Brush strip Nylon, black, PU 2 pieces Edge protection PVC, black, 3 m PVC, black, 3 m, 1 piece Part no. 21130-712 21130-713 21130-714 21130-715 21130-716 21130-717 23130-069 28127-281 Note 쮿 Fan insert with 3 fans (23130-070) cannot be used 01015051 Edge protector 41003065 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.135 Cabinets – VARISTAR Datacom/Networking Edge protection PVC, black, 3 m VARISTA R Datacom/Networking 쮿 Suitable for flat top cover with cut-out zones 쮿 To cover the sharp edges of an open cut-out (protects against injury) Order Information Description Edge protection PVC, black, 3 m Part no. 28127-281 41003065 Brush strip VARISTA R Datacom/Networking 쮿 For cable ducting with flat top cover (with cut-out zones) 쮿 600 mm wide top cover: two brush strips cover one centre cut-out 쮿 800 mm wide top cover: brush strip can be used either lengthways or depthways; one brush strip covers a lateral cut-out, two brush strips cover a centre cut-out Order Information Description Brush strip Qty/PU 2 Part no. 23130-069 01006092 Cover plate perforated for top cover with cut-out zones VARISTA R Datacom/Networking 쮿 Suitable for flat top cover (with cut-out zones), screwed-fixed 쮿 Provides heat dissipation from cabinet (with 6 mm perforations) Delivery comprises Item 1 Qty 1 2 1 Description Top cover plate, perforated, 6 mm perforation, St, 1 mm, RAL 7021, incl. GND/earthing Assembly kit Order Information Description Perforated cover plate for top cover with cut-out zones Qty/PU 1 Part no. 23130-071 01009056 1.136 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Base plate, multi-piece VARISTAR Datacom/Networking 쮿 The multi-piece base plate is open at the rear 쮿 The opening may be completed – with a filter mat – with a brush strip for the cable entry – with a cover plate Delivery comprises (kit) Item 1 5 Qty 1 1 Description Multi-piece base plate, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01004050 1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter kit Width Depth mm mm 600 600 600 800 600 900 600 1000 600 1200 800 600 800 800 800 900 800 1000 800 1200 Item 2 Cover plate for multi-piece base plate, for 600 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Item 2 Cover plate for multi-piece base plate, for 800 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Item 3 Brush strip for base plate, for 600 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Item 3 Brush strip for base plate, for 800 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Item 4 Filter mat for base plate, white, class M1 in accordance with EN 799-G3, for 600 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Item 4 Filter mat for base plate, white, class M1 in accordance with EN 799-G3, for 800 mm wide cabinets, 200 mm deep, incl. assembly kit, 1 piece Part no. 23130-001 23130-002 23130-003 23130-004 23130-359 23130-005 23130-006 23130-007 23130-008 23130-361 23130-076 23130-136 23130-074 23130-134 23130-075 23130-135 Note 쮿 Is assembled from inside 쮿 Please order cover plate, brush strip or filter mat separately SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.137 Cabinets – VARISTAR Datacom/Networking Base plate for lateral cable ducting VARISTA R Datacom/Networking 쮿 The base plate is open on the side; the opening can be covered with a brush strip (cabinet width 600 mm) or two brush strips (cabinet width 800 mm) 쮿 Perforated at front for better heat dissipation Delivery comprises Item 1 2 Qty 1 1 Description Base plate, St, 1.5 mm, width 440 mm, RAL 7021 Assembly kit Order Information Cabinet width 600 mm Cabinet width 800 mm 01006061 01006062 For cabinet width W Depth D mm mm 600 / 800 600 600 / 800 800 600 / 800 900 600 / 800 1000 600 / 800 1200 Item 3 Brush strip for base plate for lateral cable ducting, cabinet depth 600 mm, 200 mm wide, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for lateral cable ducting, cabinet depth 800 mm, 200 mm wide, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for lateral cable ducting, cabinet depth 900 mm, 200 mm wide, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for lateral cable ducting, cabinet depth 1000 mm, 200 mm wide, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for lateral cable ducting, cabinet depth 1200 mm, 200 mm wide, incl. assembly kit, 1 piece Part no. 23130-378 23130-353 23130-354 23130-355 23130-357 23130-074 23130-134 23130-374 23130-375 23130-377 Note 쮿 Is assembled from inside 쮿 Please order cover plate, brush strip or filter mat separately 1.138 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Stationary base/plinth VARISTAR Datacom/Networking 쮿 Static load-carrying capacity 1000 kg 쮿 Removable trims allow cable entry from all sides 쮿 Cannot be used in conjunction with castors 쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm 쮿 Versions – Front/rear trim perforated – Front/rear trim solid Delivery comprises ((kit)) 2a H 2b 1 2b Item 1 2a 2b 3 Qty 2 2 2 1 Description Support with feet, St, 3 mm Solid trim, St, 1.5 mm, RAL 7021 Perforated trim, St, 1.5 mm, RAL 7021 Assembly kit Order Information 2a D = cabinet depth W D 4 01004110 01004053 For cabinet width W Front/rear trim mm 600 perforated 600 plain 800 perforated 800 plain Item 4 Side trim height 100 mm, depth 600 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 800 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 900 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 1000 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 1200 mm, PU 2 pieces Part no. 23130-187 23130-387 23130-194 23130-388 23130-169 23130-170 23130-171 23130-172 23130-363 Note 쮿 Please order side trims (item 4) separately SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.139 Cabinets – VARISTAR Datacom/Networking Mobile base/plinth VARISTA R Datacom/Networking 쮿 Load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 쮿 Plinth height H = 100 mm, with feet adjustable from 126 to 134 mm Delivery comprises Item 1 2 3 4 Qty 1 4 4 1 Description Frame, St, 3 mm, RAL 7021, with adjustable feet Trim, St, 1.5 mm, RAL 7021 Castor Assembly kit Order Information 01004111 1.140 SCHROFF PRODUCT CATALOG E 05/2016 01006095 For cabinet width W mm 600 600 600 600 600 800 800 800 800 800 For cabinet depth D mm 600 800 900 1000 1200 600 800 900 1000 1200 Part no. 23130-208 23130-209 23130-210 23130-211 23130-369 23130-212 23130-213 23130-214 23130-215 23130-371 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Telescopic tilt protection VARISTAR Datacom/Networking 쮿 Max. 150 kg at full extension 쮿 Lateral and rear cable entry possible Delivery comprises Item 1 2 Qty 1 1 3 4 1 1 Description Guide plate for tilt protection, St, 2 mm, AlZn Tilt protection, St, 2 mm, RAL 7021, with 2 adjustable feet Bezel, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01006054 For cabinet width W mm 600 600 600 800 800 800 For cabinet depth D mm 900 1000 1200 900 1000 1200 Part no. 23130-345 23130-346 23130-348 23130-349 23130-350 23130-352 Note 쮿 Only for use in conjunction with plinth or mobile plinth 01006058 Tilt protection for floor mounting VARISTAR Datacom/Networking 쮿 For fixing to the floor 쮿 Height adjustable by integrated adjustable feet 쮿 Assembly possible on frame or base/plinth Delivery comprises Item 1 2 Qty 2 2 Description Mounting plate, Al Adjustable foot with outside thread Order Information Description Tilt protection for base mounting Part no. 23130-386 01006091 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.141 Cabinets – VARISTAR Datacom/Networking 19" panel/slide mounts with universal pitch (EIA) VARISTA R Datacom/Networking 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 Item 1 Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 15,9 42,5 44,45 44.45 12,75 9,6 65,1 2 76 25 25 49,5 01004112 01004131 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. Partialheight 8 395 23130-037 23130-027 mounting Partialheight 12 545 23130-038 23130-028 mounting Partialheight 16 745 23130-039 23130-029 mounting Partialheight 20 895 23130-040 23130-030 mounting Partialheight 24 1095 23130-031 23130-021 mounting Partialheight 29 1295 23130-032 23130-022 mounting Partialheight 33 1495 23130-033 23130-023 mounting Partialheight 38 1695 23130-034 23130-024 mounting 2000 42 1895 23130-035 23130-025 2200 47 2095 23130-036 23130-026 Accessories Adaptor bracket for reduced width for mounting of panel/ slide mounts in 800 mm wide cabinets, St, 2 mm, AlZn, PU 4 pieces Heavy-load cross member Length 1,000 mm, PU 4 pieces Heavy-load cross member Length 1100 mm, PU 4 pieces Heavy-load cross member Length 1,200 mm, PU 4 pieces Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 23130-016 23130-091 23130-544 23130-545 23130-546 25127-997 Note 쮿 Please order adaptor bracket for reduced width for 800 mm wide cabinets separately 쮿 For 19" partial-height mounting, depth members are required 쮿 Metric panel/slide mounts available on request 1.142 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Depth members VARISTAR Datacom/Networking 쮿 For mounting of shortened 19" panel/slide mounts 쮿 Cable ducting by means of cable ties and cable eyes Delivery comprises Item 1 2 50 121,2 25 25 100 37,5 36,5 11,5 L - 27 12 L 01004126 01004079 Cable eye Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information For cabinet depth Length L mm mm 600 460 800 660 900 760 1000 860 1200 1060 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-081 23130-082 23130-083 23130-084 23130-365 21101-151 21101-150 Note 쮿 Cable ducting with cable ties see page 1.162 coa43697 19" assembly kit, M6 VARISTAR Datacom/Networking 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.143 Cabinets – VARISTAR Datacom/Networking Slide rails VARISTA R Datacom/Networking 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair D c c - 130 쮿 Wide support surface (48 mm) 19” c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth xf Delivery comprises 01004130 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load carrying capacity 25 kg For cabinet depth mm 600, 800 600, 800 800 800 900, 1000, 1200 900, 1000, 1200 xf mm 50 50 150 150 70 70 c mm 500, 700 500, 700 500 500 740 740 Length L mm 456 456 456 456 699 699 Qty/PU 2 10 2 10 2 10 Part no. 23130-096 23130-101 23130-096 23130-101 23130-098 23130-103 Order Information Static load-carrying capacity 25 kg Static load-carrying capacity 100 kg 01005086 Static load carrying capacity 100 kg For cabinet depth mm 600, 800 600, 800 800 800 900, 1000, 1200 900, 1000, 1200 xf mm 50 50 150 150 70 70 c mm 500, 700 500, 700 500 500 740 740 Length L mm 458 458 458 458 699 699 Qty/PU 2 10 2 10 2 10 Part no. 23130-118 23130-123 23130-118 23130-123 23130-120 23130-125 01004058 Short slide rails VARISTA R Datacom/Networking 쮿 Support for heavy 19" chassis 쮿 To attach on 19" slide mounts 쮿 Static load-carrying capacity max. 15 kg per pair Delivery comprises Item 1 2 sc96xxxx Qty 2 / 10 1 Order Information Description Short slide rail Short slide rail 1.144 SCHROFF PRODUCT CATALOG E 05/2016 Description Short slide rail, St, 1.5 mm, finish AlZn Assembly kit Qty/PU 2 10 Part no. 23130-094 23130-095 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking 19'' fixed shelf, 75 kg VARISTAR Datacom/Networking 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c D For cabinet Usable xf c RAL 7035 depth surface w x d mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 442 150 500 22130-303 900 495 x 682 70 740 22130-309 1000 495 x 682 70 740 22130-309 1200 495 x 682 70 740 22130-309 Strengthening rail for stationary 19" shelf PU 1 piece xf d Order Information w RAL 7021 Part no. 21130-303 21130-303 21130-309 21130-309 21130-309 23130-310 Note W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension 01004067 쮿 Cable ducting with cable ties see page 1.162 쮿 Other sizes see ServicePLUS page 1.165 19" shelf, stationary, depth-adjustable, 1 U VARISTAR Datacom/Networking 쮿 Static load-carrying capacity 68 kg 쮿 Mounting height 1 U 쮿 For mounting on four 19" uprights or four panel/slide mounts D 쮿 Variable mounting dimensions (depth-adjustable) 쮿 2 Versions – Mounting dimension 495 ... 851 mm – Mounting dimension 792 ... 1151 mm 44 441 쮿 2 oval cut-outs for cable ducting 쮿 Colour black, RAL 9005 465 483 Delivery comprises 87928708 Item 1 Qty 1 2 1 Description Shelf, depth-adjustable, width 19", height 1 U, RAL 9005 (black) Fitting materials with user manual Order Information 19" shelf, stationary, depth-adjustable, 1 U Mounting dimension D 495 ... 851 mm Mounting dimension D 792 ... 1151 mm Part no. D19FVT69B D19FVT912B Note 쮿 19" assembly kit see page 1.143 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.145 Cabinets – VARISTAR Datacom/Networking 19'' telescopic shelf, 30 kg VARISTA R Datacom/Networking 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information D c c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 417 x 482 50 500 22130-343 800 417 x 482 150 500 22130-343 GND/earthing for telescopic 19" shelf PU 1 kit, for Varistar RAL 7021 Part no. 21130-343 21130-343 23130-140 Note xf d Full depth 쮿 Cable ducting with cable ties see page 1.162 01004069 Order Information Shortened depth Shortened by 100 mm W For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 417 x 382 50 500 22130-342 800 417 x 382 150 500 22130-342 GND/earthing for telescopic 19" shelf PU 1 kit, for Varistar RAL 7021 Part no. 21130-342 21130-342 23130-140 Note D c xr w xf d 쮿 Cable ducting with cable ties, see page 1.162 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension 1.146 SCHROFF PRODUCT CATALOG E 05/2016 01004070 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking 19'' telescopic shelf, 70 kg VARISTAR Datacom/Networking 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 W Delivery comprises w Item 1 Qty 1 2 3 2 1 xr Full depth 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 405 x 482 50 500 22130-353 800 405 x 482 150 500 22130-353 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for Varistar xf d Order Information 01004069 Shortened depth RAL 7021 Part no. 21130-353 21130-353 23130-092 23130-140 Note 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties see page 1.162 W w xr Order Information D For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 405 x 382 50 500 22130-352 800 405 x 382 150 500 22130-352 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for Varistar d c Shortened by 100 mm RAL 7021 Part no. 21130-352 21130-352 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties see page 1.162 c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.EN 01004070 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.147 Cabinets – VARISTAR Datacom/Networking Lever handle for single point locking VARISTA R Datacom/Networking 쮿 For installation instead of key lock insert 쮿 To open press push-button 쮿 DIN profile half cylinder retrofittable Delivery comprises Item 1 2 Qty 1 1 Description Lever handle for single point locking Assembly kit Order Information Description Lever handle for single point locking DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys 01005016 Part no. 23130-067 25127-995 Note 쮿 Other locks such as ASSA, KABA or RONIS available on request Electronic closing (stand-alone) VARISTA R Datacom/Networking 쮿 Complete package comprising a handle with keyboard (master) and a handle with opening function (slave) plus all necessary electrical connection components 쮿 Suitable for all Varistar cabinet doors with single point or 3-point locking and S2100 door handle cut-out 쮿 Front and rear door can be opened together or separately by means of coding Delivery comprises (Kit) Item 1 Qty 1 2 1 3 1 4 5 6 1 1 1 41003035 4 3 Description Electronic lever handle with keyboard (master) for front door, 4 m connecting cable and ferrules Electronic lever handle, opener (slave) only, for rear door, 4 m connecting cable and ferrules Plug-in power supply AC/DC with Euro plug, input voltage 100 VAC ... 230 VAC, output voltage 12 VDC /700 mA Central unit with case Cable ducting Assembly kit, operating instructions Order Information 2 Description Electronic closing Part no. 20130-598 1 01007054 1.148 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Electronic locking (MLR 3000) VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days 쮿 Electronic door handles for Varistar cabinets 쮿 Modular solution with electronic door locking, reader unit, PSU and administration software 쮿 Integrated visualization, LED display for alarm signals and operating statuses 쮿 Two locking options: standalone and networked 쮿 Access reporting and user management 쮿 Sabotage and vandalism alarm Delivery includes Item 1a Qty 1 1b 1 1c 1 Description Electronic door lock MLR 3000 with lever handle and card reader unit; display with status LEDs; reader (125 kHz-HDI, 13,56 MH5-MIFARE) Card reader unit (supply voltage 12 VDC , 40 mA, (max. 440 mA); Temperature range -20 ... +70 °C Junction (distribution box) 01013014 Order Information Qty/PU piece Electronic locking (MRL3000), 125 KHz-HDI 1 Electronic locking (MRL3000), 13.56 MHz-MIFARE 1 Accessories Part no. 23130-513 23130-565 Electronic door lock MLR1000 (slave), 1 piece 23130-512 PSU for electronic locking 1 piece 23130-515 Gateway for electronic door lock 1 piece 23130-523 Administration Suite Software 1 piece 60130-680 Reader cards for electronic locking, 125 KHz-HDI PU 10 pieces 23130-526 Reader cards for electronic locking, 13.56 MHz-MILFARE PU 10 pieces 23130-566 Standalone function cards, 125 KHz-HDI PU 4 pieces 60130-678 Standalone function cards, 13.56 MHz- MIFAREPU 4 pieces 60130-832 Battery pack for electronic locking 1 piece 60130-729 Desktop reader, 125 KHz-HDI 1 piece 60130-730 Desktop Reader, 13.56 MHz-MIFARE 1 piece 60130-830 LAN OUTPUT CONFIG Description ff hro ff SScchro ff chrooff S Schrroff Sch Sch S ro S ch ff S ch roff S ch roff ch ro ro ff ff Schroff Schroff Schroff Schro ff SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.149 Cabinets – VARISTAR Datacom/Networking Two locking options: standalone and networked Standalone solution: - Lever handle with HID 125 kHz reader unit (Mifare on request) - Reader cards are set up and issued directly on handle using the HID standalone function cards Standalone solution VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days Networked solution: - Access is managed centrally via the network - Reader cards are issued via the management software - The Gateway allows up to 32 door handles to be controlled Networked solution 2 1a 4 3 2a 1a 1a 1b 1c 1b 5 2b 1b LA 01014051 N 01014052 Required number of components for one cabinet with front and rear door (standalone solution) Required number of components for two cabinets with front and rear door (networked solution) Item Description Item Description 1a 1b 2 Electronic door lock MLR3000 Stand-alone card reader unit Power supply unit for door lock Cards (set of 10) HID stand-alone function cards Battery pack (optional) 1a 1b 1c 2a 2b 3 4 5 Electronic door lock MLR3000 Card reader unit Junction Electronic door lock MLR1000 Junction PSU for door lock/gateway Gateway for electronic door lock Access management software, administration suite via network Cards (set of 10) Desktop reader (optional) Battery pack (optional) 1.150 Required number Piece 2 2 1 1 1 SCHROFF PRODUCT CATALOG E 05/2016 Order no. 23130-513 23130-515 23130-512 60130-678 60130-729 Required number Piece Order no. 2 23130-513 2 23130-512 5 1 1 23130-515 23130-523 60130-680 1 1 1 23130-526 23130-730 60130-729 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Electronic door lock MLR1000 VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days 쮿 Electronic door handles for Varistar cabinets 쮿 Integrated visualization, LED display for alarm signals and operating statuses 쮿 Lever handle opens when switch contacts touch Delivery includes Item 1a Qty 1 1b 1 Description Electronic door lock MLR1000 with lever handle, display with multicolor status LED Junction (distribution box), power supply via 12 VDC socket, 40 mA (max. 440 mA); temperature range -20 ... +70 °C Order Information Description 01013014 Electronic door lock MLR1000 Accessories PSU for electronic locking 1 piece Qty/PU piece 1 Part no. 23130-512 23130-515 Battery pack for electronic locking VARISTAR Electroni csMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Battery pack allowing emergency opening of lever handle (MLR 3000) in event of power failure 쮿 Power is supplied to the handle from below, allowing door then to be opened using an authorized access card Delivery includes Item 1 Qty 1 Description Battery pack, 12 V, width 145 mm, height 72 mm, depth 34 mm Order Information Description Battery pack for electronic locking Qty/PU piece 1 Part no. 60130-729 01014001 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.151 Cabinets – VARISTAR Datacom/Networking PSU for electronic locking VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Power adapter to supply lever handle (MLR 3000, MLR1000) and gateway Delivery includes Item 1 Qty 1 Description Power adapter, 230 VAC (IEC 60320-C13 plug), 12 VDC, (cable length 1230 mm) Order Information Description 01014054 Qty/PU piece 1 PSU for electronic locking Accessories Mains cable, IEC IEC 60320 C14 plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 socket, 2.5 m, 1 piece Part no. 23130-515 60197-053 60103-137 62150-191 Reader cards for electronic locking Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Reader cards for electronic locking (MLR3000) Delivery includes ff hro ff SScchhro ff c hrrooff S Scch ff ro S Item 1 Sch S ro S ch ff Scchrroff S h off ch ro ro ff ff Qty 10 Description Reader card for reader unit Order Information Description Reader cards for electronic locking, 125 KHz-HDI Reader cards for electronic locking, 13.56 MHz-MILFARE Qty/PU Part no. PU 10 pieces 23130-526 PU 10 pieces 23130-566 12514051 Standalone function cards Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Code cards for programming standalone locking Delivery includes Item 1 2 3 4 5 Schroff Schroff Schroff Schro ff Qty 1 1 1 1 1 Description Card (unlocking card) Card (locking card) Card (group card) Card (general card) User manual Order Information 12514050 1.152 SCHROFF PRODUCT CATALOG E 05/2016 Description Standalone function cards, 125 KHz-HDI Standalone function cards, 13.56 MHzMIFARE Qty/PU PU 4 pieces 60130-678 Part no. PU 4 pieces 60130-832 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Access management software, Administration Suite VARISTAR Datacom/NetworkingMain CatalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days 쮿 The Administration Suite enables you to document and protect all access to indoor cabinets and enclosures. You have complete control and also have a high level of flexibility 쮿 Alarm management, the possibility of managing systems in different time zones and managing different installations. 쮿 Flexibility, a clear overview and user-friendly design make this software easy to use and an effective management system for data and server cabinets protected with E-LINE by DIRAK 쮿 The integrated web client lets you link any number of users with the administration suite via a web browser. Any device with a browser function (iPad®, tablet computers, iPhone®, Blackberry® etc.) can operate the web client of the administration suite without additional software installation Delivery includes Item 1 Qty 1 Description CD with software and documentation Order Information Description Administration Suite Software Qty/PU piece 1 Part no. 60130-680 01014004 Desktop reader Elec tricsMain C atalogP art number in bold fac e type: ready for shipping within 2 w orking daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Card reader unit for networked solution 쮿 Centralized allocation of reader cards using administration suite software Delivery includes Item 1 Qty 1 2 1 Description Desktop reader, width 107.5 mm, depth 108.5 mm, height 23.75 mm USB connecting cable, length 1800 mm Order Information Description 01014002 SCHROFF.PENTAIR.EN Desktop reader, 125 KHz-HDI Desktop reader, 13.56 MHz-MIFARE Qty/PU piece 1 1 Part no. 60130-730 60130-830 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.153 Cabinets – VARISTAR Datacom/Networking Gateway for electronic locking VARISTA R Datacom/NetworkingMain CatalogPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Connects to Ethernet network Delivery includes OUTPUT CONFIG Item 1 Qty 1 Description Gateway, width 75 mm, depth 70 mm, height 29 mm Order Information Description LAN Gateway for electronic door lock Accessories PSU for electronic locking 1 piece Qty/PU piece 1 Part no. 23130-523 23130-515 01014053 1.154 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Zone 1 cable management VARISTAR Datacom/Networking 쮿 Cable ducting zone 1 is located in the front area of the cabinet, in front of the 19" plane 쮿 In this zone the patch cables are ducted horizontally between the distribution fields Products 쮿 Cable ducting see chapter Cabinet accessories, from page 3.5 쮿 19'' distribution field, Cat 5/6, see chapter Cabinet accessories, page 3.14 01006087 Zone 2 cable management VARISTAR Datacom/Networking 쮿 The cable ducting zone 2 is located on the right and left hand side in the front area of the cabinet, next to the 19" plane 쮿 The patch cables are ducted in a kind of channel to the individual distribution fields and components Products 쮿 Cable eyes see from page 1.156 쮿 Cable brackets for fibre optic cables, see page 1.157 쮿 Shielding panel, see page 1.157 01006088 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.155 Cabinets – VARISTAR Datacom/Networking Cable eye, plastic VARISTA R Datacom/Networking 쮿 For assembly on cabinet uprights in 800 mm wide cabinets 쮿 Simple and fast assembly by clicking into the cabinet profile (without assembly kit) 쮿 Cable ducting laterally in front of the 19" panel/slide mounts 쮿 With additional assembly kit also suitable for lateral assembly on the 19" panel/slide mounts Delivery comprises Item 1 Qty 4 Description Cable eye, PA, UL 94 V-0, black Order Information Illustration shows application (W, D = 100 mm) 01006078 43 For cabinet width W mm mm 600 31 800 100 Accessories Taptite screw M6 Taptite, PU 50 pieces D mm 92 100 Part no. 23130-506 23130-336 23130-285 92 31 W = 31 mm, D = 92 mm 01012085 W, D = 100 mm 01006079 Cable eye, steel VARISTA R Datacom/Networking 쮿 For assembly on cabinet uprights (800 mm cabinet width) or laterally to the 19" panel/slide mounts 쮿 Cable ducting laterally next to and/or in front of the 19" panel/ slide mounts Delivery comprises Item 1 2 3 Qty 4 4 1 Description Bracket, St, zinc-plated, Terminal, Al, die-cast Assembly kit Order Information 01006080 01006081 1.156 SCHROFF PRODUCT CATALOG E 05/2016 For cabinet width mm 800 800 W mm 100 100 D mm 100 180 Part no. 23130-341 23130-342 01006098 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Fibre optic cable ducting VARISTAR Datacom/Networking 쮿 Assembly on 19" panel/slide mounts 쮿 For secure laying of optical fibre cables Delivery comprises Item 1 2 Qty 2 1 Description Fibre optic cable ducting, PA, UL 94 V-0, black Assembly kit Order Information Description Fibre optic cable ducting Part no. 23130-372 01006074 Cover panel, hinged VARISTAR Datacom/Networking 쮿 For use in 2000 mm high and 800 mm wide cabinets 쮿 For lateral covering of e.g. the patch cables 쮿 Optionally with brush strip Delivery comprises Item 1 2 Qty 2 1 Description Cover panel, St, 1 mm, RAL 7021 Assembly kit Order Information Height Width Qty/PU mm mm piece 2000 100 2 Brush strip for cover panel height 2000 mm, PU 2 pieces Part no. 23130-343 23130-379 01006056 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.157 Cabinets – VARISTAR Datacom/Networking Zone 3 cable management VARISTA R Datacom/Networking 쮿 Is located laterally behind zone 2 across the whole cabinet depth 쮿 Fibre optic or copper cables are ducted from cable entry in lateral area of top cover or base plate to rear of distribution fields Products 쮿 C-rail or cable support rail for the cabinet depth see from page 1.159 쮿 Or cable ladder from page 1.160 01006085 Cable support rail for cabinet depth VARISTA R Datacom/Networking 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells (bottom row) and for cable ties, resp. Velcro (top row) Delivery comprises Item 1 2 Qty 2 1 Description Cable support rail, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01006066 L 60 1 For cabinet depth Length L mm mm 600 466.4 800 666.4 900 766.6 1000 866.4 1200 1066.4 Accessories Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Part no. 23130-326 23130-328 23130-329 23130-330 23130-332 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 Note 쮿 Cable ties and Velcro see page 1.162 01006067 1.158 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking C-rail for the cabinet depth VARISTAR Datacom/Networking 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-rail, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut 15 Ø 50 11 L 39,5 29,5 L- ,5 x 31 6,5 50 75 01504054 SCHROFF.PENTAIR.EN C-rail 01004132 For cabinet depth Length L mm mm 600 460 800 660 900 760 1000 860 1200 1060 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 piece Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-086 23130-087 23130-088 23130-089 23130-367 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 쮿 Cable ties and Velcro for cable retention rail see page 1.162 01006071 Cable retention rail Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.159 Cabinets – VARISTAR Datacom/Networking Cable panel VARISTA R Datacom/Networking 쮿 For fitting directly onto the frame 쮿 Fixing of cables with cable ties or Velcro 쮿 Widths 150 mm and 250 mm Delivery comprises Item 1 2 1 Qty 2 1 Description Cable panel with cut-outs, St, 1 mm, RAL 7021 Assembly kit H Order Information 10 W 01006103 For cabinet height U 8 9 12 14 18 20 38 42 47 38 42 47 H mm 446 496 604 670 917 1019 1700 1900 2100 1700 1900 2100 W mm 110 110 110 110 110 110 150 150 150 250 250 250 Part no. 23130-501 23130-504 23130-500 23130-503 23130-499 23130-502 23130-420 23130-421 23130-422 23130-149 23130-150 23130-151 Note 쮿 Cable ties and Velcro see page 1.162 Cable ladder VARISTA R Datacom/Networking 쮿 For mounting in 2000 or 2200 mm high cabinets 쮿 Cables are fixed in place with cable ties or Velcro Delivery includes Item 1 2 1 Qty 2 1 Description Cable ladder, round steel, zinc-plated Assembly kit Order Information H For cabinet height mm 2000 2200 Height H mm 1800 2000 Width mm 300 300 Depth mm 30 30 Part no. 23130-554 23130-555 Note 쮿 Cable ties and Velcro see page 1.162 30 300 01014057 1.160 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Zone 4 cable management VARISTAR Datacom/Networking 쮿 Cable ducting on the inside of the cabinet rear panel across the entire cabinet width 쮿 Top cover openings can be used for cable ducting Products 쮿 C-rail and cable support rail for the cabinet width see from page 1.161 01006086 Cable support rail for cabinet width VARISTAR Datacom/Networking 쮿 For cable ducting in rear area of cabinet 쮿 For cable shells (bottom row) and for cable ties, resp. Velcro (top row) Delivery comprises Item 1 2 Qty 2 1 Description Cable support rail, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01006077 For cabinet width Length L mm mm 600 550 800 750 Accessories Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Part no. 21236-093 23130-312 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 Note 쮿 Cable ties and Velcro see page 1.162 01006076 SCHROFF.PENTAIR.EN Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.161 Cabinets – VARISTAR C-rail for cabinet width VARISTA RMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-rail, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-rail Slide nut For cabinet width Length mm mm 600 550 800 750 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 piece Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-rail, PU 10 pieces Part no. 23130-333 23130-334 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.162 75 01006071 01006064 Cable retention rail 01504054 Cable tie, Velcro MechanicsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie 1.162 01005078 Velcro SCHROFF PRODUCT CATALOG E 05/2016 Part no. 20118-351 20118-352 20118-353 20118-624 01005079 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Deposit for excess cable lengths VARISTAR Datacom/Networking 쮿 For fixing on shelf or depth member 쮿 Height with shelf is 2 U Delivery comprises Item 1 Qty 2 2 1 Description Deposit for excess cable lengths, St, 1.5 mm, height 55 mm, RAL 7021 Assembly kit Order Information Description Deposit for excess cable lengths Part no. 23130-050 Note 쮿 Velcro see page 1.162 쮿 Shelves see from page 1.145 쮿 Depth members see page 1.143 01006068 01006069 VARISTAR Datacom/Networking VARISTAR Datacom/Networking ServiceP LUS SCHROFF.PENTAIR.EN Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.163 Cabinets – VARISTAR Datacom/Networking ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.165 assembly Assembled by professionals. Double benefit! Assembly of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.164 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Varistar RAL 7021 ServicePLUS: Configuration and assembly VARISTAR Datacom/Networking 쮿 Dimensions: – Height: 24 ... 47 U (1200 ... 2200 mm) – Width: 600 and 800 mm – Depth: 600, 800, 900, 1000, 1100 and 1200 mm Page 쮿 Colour: Frame and all covers in black grey (RAL 7021) 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Frames, side-by-side mounting kits, adjustable feet, castors 1.166 Side panels, lateral cable ducting 1.167 Decorative frames, glass doors 1.168 Steel doors 1.169 Double doors, cover panels 1.170 Rear panels, connection plates 1.171 Top covers 1.172 Flat top covers with cutout zones 1.173 Fan top covers 1.174 Base plates 1.175 Bases/plinths 1.176 19" panel/slide mounts 1.177 Swing frames 1.179 Shelves 1.180 19" shelves 1.182 Slide rails 1.184 Cable ducting with C-rails, 1.185 cable support rails Accessories for cabling 1.186 ServicePLUS RAL 7035/ RAL 7021 1.189 01004077 Example configuration (here: row 20) Qty 1 1 2 1 1 1 .. SCHROFF.PENTAIR.EN Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece Side panel with quick release fastener, PU 2 pieces Safety lock for side panel, PU 4 pieces Rear panel screw-fixed, 1 piece Glazed door with single point locking, 1 piece Adjustable feet, PU 4 pieces .......... Order no. 20130-019/05 21130-051/05 23130-132/05 21130-069/05 21130-129/05 23130-079/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.165 Cabinets – VARISTAR Datacom/Networking RAL 7021 Frames, side-by-side mounting kits, adjustable feet, castors Frame Slim-Line 400 kg Heavy-Duty 800 kg 07004078 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.166 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 For dynamic load, static loadcarrying capacity: St, 1.5 mm, zincplated, with 400 kg, central GND/ St, 1.5 mm, zincearthing plated, with point; please central GND/ order adjustable earthing point; feet or castors please order separately adjustable feet or castors separately RAL 7021 1 piece assembled RAL 7021 1 piece assembled 20130-001 20130-002 20130-035 20130-036 20130-578 20130-579 20130-003 20130-004 20130-037 20130-038 20130-005 20130-006 20130-007 20130-008 20130-013 20130-014 20130-015 20130-016 20130-018 20130-019 20130-020 20130-021 20130-580 20130-581 20130-022 20130-023 20130-024 20130-025 20130-582 20130-583 20130-027 20130-028 20130-029 20130-030 20130-584 20130-585 20130-031 20130-032 20130-033 20130-034 20130-586 20130-587 20130-051 20130-052 20130-085 20130-086 20130-588 20130-589 20130-053 20130-054 20130-087 20130-088 20130-055 20130-056 20130-057 20130-058 20130-063 20130-064 20130-065 20130-066 20130-068 20130-069 20130-070 20130-071 20130-590 20130-591 20130-072 20130-073 20130-074 20130-075 20130-592 20130-593 20130-077 20130-078 20130-079 20130-080 20130-594 20130-595 20130-081 20130-082 20130-083 20130-084 20130-596 20130-597 SCHROFF PRODUCT CATALOG E 05/2016 Side-by-side mounting kit IP 20 07004117 side-by-side mounting brackets (4 pieces), St Adjustable feet 01004081 Castors With 2 jacking With adjustable feet feet 01004082 01004156 for the frame, for the frame, for the frame, static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity: 400 kg, 400 kg, 1000 kg, cannot be used cannot be used cannot be used with base/plinth with base/plinth with base/plinth RAL 7021 PU 1 kit supplied loose PU 4 pieces assembled PU 4 pieces assembled PU 4 pieces assembled 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Side panels, lateral cable ducting Side panel With quick Lock release fastener Screw-fixed side panel Side panel Inside locking Cable panel Width 150 mm Lateral cable ducting Cable panel Cable ladder Width 250 mm Width 300 mm H 1 10 01004084 01004072 for quick-release St, 1 mm, incl. fasteners of one GND/earthing, side panel; please order lock 4 locks sufficient separately for 2 side panels Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 RAL 7021 PU 2 pieces assembled 21130-041 21130-042 21130-524 21130-525 PU 4 pieces assembled 23130-132 – – 21130-041 21130-042 21130-524 21130-525 21130-043 21130-044 21130-043 21130-044 21130-047 21130-048 21130-047 21130-048 21130-050 21130-051 21130-052 21130-053 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 – – 21130-050 21130-051 21130-052 21130-053 23130-132 – – 21130-055 21130-056 21130-057 21130-058 23130-132 – – 21130-055 21130-056 21130-057 21130-058 – – 23130-132 01004083 St, 1 mm, incl. GND/earthing RAL 7021 PU 2 pieces assembled 21130-001 21130-002 21130-516 21130-517 21130-532 21130-533 21130-001 21130-002 21130-516 21130-517 21130-003 21130-004 21130-003 21130-004 21130-007 21130-008 21130-007 21130-008 21130-010 21130-011 21130-012 21130-013 21130-534 21130-535 21130-010 21130-011 21130-012 21130-013 21130-534 21130-535 21130-015 21130-016 21130-017 21130-017 21130-536 21130-537 21130-015 21130-016 21130-017 21130-017 21130-536 21130-537 W 01006104 bracket, St, 1 mm, finish AlZn; with retention screws 01006103 St, 1 mm, with cut-outs for cable ties or Velcro see page 1.186 01006075 round steel, zinc-plated, height 1800 mm, for cable ties or Velcro see page 1.186 PU 2 pieces assembled RAL 7021 PU 2 pieces assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled 23130-373 – – – 23130-373 – – – 23130-373 – – – 23130-373 – – – 23130-373 23130-420 23130-149 – 23130-373 23130-420 23130-149 – 23130-373 23130-421 23130-150 23130-554 23130-373 23130-421 23130-150 23130-554 23130-373 23130-422 23130-151 23130-555 23130-373 23130-422 23130-151 23130-555 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.167 Cabinets – VARISTAR Datacom/Networking RAL 7021 Decorative frames, glass doors Deco frame Deco frame Adaptor bracket 01004086 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.168 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004160 Glazed door Single point Lever handle locking 01004088 Glazed door 3-point locking 01004147 with push button for doors with single point locking 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing DIN profile half cylinder 01004148 for lever handle, common locking Al, 19" plane integrated, front open, incl. GND/earthing, no door can be fitted St, 2 mm, for deco frame, for assembly of slide rails and shelves St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lock cover, incl. GND/ earthing RAL 7021 1 piece assembled RAL 7021 PU 1 pair assembled RAL 7021 1 piece assembled 1 piece assembled RAL 7021 1 piece assembled 1 piece assembled 21130-231 23130-230 21130-121 23130-067 21130-181 25127-995 – – 21130-122 23130-067 21130-182 25127-995 21130-232 23130-231 21130-123 23130-067 21130-183 25127-995 – – 21130-124 23130-067 – 25127-995 21130-234 23130-233 21130-127 23130-067 21130-187 25127-995 – – 21130-128 23130-067 21130-188 25127-995 21130-235 23130-234 21130-129 23130-067 21130-189 25127-995 – – 21130-130 23130-067 21130-190 25127-995 21130-236 23130-235 21130-131 23130-067 21130-191 25127-995 – – 21130-132 23130-067 21130-192 25127-995 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Steel doors Steel door, single point locking Plain, with Perforated mounting frame on inner side Plain 01004089 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004089 Lever handle 01004090 01004147 with push button for doors with single point locking Steel door, 3-point locking Plain Perforated 01004090 DIN profile half cylinder 01004093 St, 1.5 mm, St, 1.5 mm, opening angle opening angle 180°, lever handle 180°, with mounting frame with push button, incl. GND/ on inner side, earthing lever handle with push button, incl. GND/ earthing 01004148 for lever handle, common locking St, 1 mm, opening angle 180°, lock cover, incl. GND/ earthing St, 1.5 mm, opening angle 180°, lock cover, incl. GND/ earthing, designed to carry extensive cutouts and assemblies St, 1.5 mm, opening angle 180°, lock cover, incl. GND/ earthing RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 1 piece assembled 21130-106 21130-566 21130-136 23130-067 21130-151 21130-700 25127-995 21130-107 21130-567 21130-137 23130-067 21130-152 21130-701 25127-995 21130-108 21130-568 21130-138 23130-067 21130-153 21130-702 25127-995 21130-109 21130-569 21130-139 23130-067 21130-154 21130-703 25127-995 21130-112 21130-572 21130-142 23130-067 21130-157 21130-706 25127-995 21130-113 21130-573 21130-143 23130-067 21130-158 21130-707 25127-995 21130-114 21130-574 21130-144 23130-067 21130-159 21130-708 25127-995 21130-115 21130-575 21130-145 23130-067 21130-160 21130-709 25127-995 21130-116 21130-576 21130-146 23130-067 21130-161 21130-710 25127-995 21130-117 21130-577 21130-147 23130-067 21130-162 21130-711 25127-995 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.169 Cabinets – VARISTAR Datacom/Networking RAL 7021 Double doors, cover panels Glazed Double door, 3-point locking Plain Perforated DIN profile half cylinder Hinged Cover panel Brush strip for cover panel 90° 01005065 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.170 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01005064 01005066 St, 1.5 mm, St, 1.5 mm, frame, St, opening angle opening angle 1.5 mm, 180°, 180°, Sekurit glass, lever handle with lever handle with 6 mm, push button, push button, opening angle incl. GND/ incl. GND/ 180°, earthing earthing lever handle with push button, incl. GND/ earthing 01004148 01006056 for lever handle, St, 1 mm, to cover common locking the cabling space next to the panel/ slide mounts 01006056 black RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 1 piece assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled 21130-670 21130-657 21130-683 25127-995 – – 21130-671 21130-658 21130-684 25127-995 – – 21130-672 21130-659 21130-685 25127-995 – – 21130-673 21130-660 21130-686 25127-995 – – 21130-676 21130-663 21130-689 25127-995 – – 21130-677 21130-664 21130-690 25127-995 – – 21130-678 21130-665 21130-691 25127-995 – – 21130-679 21130-666 21130-692 25127-995 23130-343 23130-379 21130-680 21130-667 21130-692 25127-995 – – 21130-681 21130-668 21130-694 25127-995 – – SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Rear panels, connection plates Rear panel With quick Lock release fastener 01004087 Screw-fixed rear panel 01004072 for quick-release St, 1 mm, incl. fasteners of rear GND/earthing, panel please order lock separately Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Dimensioning connecting plate door/rear panel 01004085 St, 1 mm, incl. GND/earthing Intermediate plate for door and rear panel Plain With brush strip Assembly kit 01005071 door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door 01005063 01005069 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel only required if rear panel with quick-release fastener is assembled above the connecting plate RAL 7021 1 piece assembled PU 2 pieces assembled RAL 7021 1 piece assembled Width mm RAL 7021 1 piece assembled RAL 7021 1 piece assembled PU 1 kit assembled 21130-091 23130-133 21130-061 – – – – 21130-092 23130-133 21130-062 – – – – 21130-093 23130-133 21130-063 – – – – 21130-094 23130-133 21130-064 – – – – 21130-097 23130-133 21130-067 600 21130-472 21130-478 23130-164 21130-098 23130-133 21130-068 800 21130-473 21130-479 23130-164 21130-099 23130-133 21130-069 600 21130-472 21130-478 23130-164 21130-100 23130-133 21130-070 800 21130-473 21130-479 23130-164 21130-101 23130-133 21130-071 600 21130-472 21130-478 23130-164 21130-102 23130-133 21130-072 800 21130-473 21130-479 23130-164 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.171 Cabinets – VARISTAR Datacom/Networking RAL 7021 Top covers Flat top cover Perforated Plain flush top cover Lifting eye Flat top cover, raised Spacer Lifting eye 10 M12 01004096 St, 1.5 mm, incl. GND/ earthing Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.172 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004097 01005064 for flat top cover, St, 1.5 mm, applications fully perforated, and load in 6 mm perforated, accordance with incl. GND/ DIN 582 earthing RAL 7021 1 piece assembled RAL 7021 1 piece assembled 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-540 21130-541 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-540 21130-541 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-262 21130-263 21130-266 21130-267 21130-262 21130-263 21130-266 21130-267 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-548 21130-549 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-548 21130-549 SCHROFF PRODUCT CATALOG E 05/2016 M12 01004099 St, zinc-plated, for raising a top cover by 10 mm 01005064 for raised flat top cover, applications and load in accordance with DIN 582 PU 4 pieces assembled RAL 7021 PU 4 pieces assembled PU 4 pieces assembled 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Flat top covers with cut-out zones Flat top cover with cable through-ducting openings Flat top cover with cut-out zones Brush strip Fan insert Top cover assemblies Cover plate for Edge protection cut-out zones, perforated W 01015052 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01006093 St, 1.5 mm, incl. GND/ earthing, cutout size 85 mm x 449 mm St, 1.5 mm, incl. GND/ earthing, number of cut-outs and dimension drawings see page 1.9 RAL 7021 1 piece fitted RAL 7021 1 piece assembled – – – 21130-712 21130-713 21130-714 – – – 21130-715 – – – – – – – – – – – 21130-712 21130-713 21130-714 – – – 21130-715 21130-716 21130-717 – – – 21130-712 21130-713 21130-714 – – – 21130-715 21130-716 21130-717 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-252 21130-253 21130-256 21130-257 21130-252 21130-253 21130-256 21130-257 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-544 21130-545 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-544 21130-545 10106092 01004102 230 VAC, nylon, black, one brush strip with three fans, covers a 410 m3/h, lateral cut-out, completely wired, two brush strips connecting cable cover a center IEC 320 cut-out 01009056 St, 1.5 mm, 6 mm hole diameter, incl. GND/ earthing Lifting eye M12 D 41003065 01005064 PVC, 3 m, black, for open cut-out zones for flat top cover, applications and load in accordance with DIN 582 PU 2 pieces assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 1 piece enclosed loose PU 4 pieces assembled 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.173 Cabinets – VARISTAR Datacom/Networking RAL 7021 Fan top covers Top cover for 6 fans Fan for fan top cover Fan top cover Thermostat Speed control Lifting eye 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm 01005060 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.174 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 kta44844 01108052 01105055 fully wired, St, 1.5 mm, raised fan with grille for with mains cable 90 ... 264 VAC, top assembly, 230 VAC cover, 230 VAC, 3 axial fans, (SCHUKO/UTE input SCHUKO/ 230 VAC, plug/ UTE plug, 38x119x119 mm, 3 outlet IEC 60320 incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 socket), C13 socket; ND/earthing, h adjustment range external NTC connecting cable 0 ... 60°C sensor 1.5 m 2.5 m, SCHUKO/ IEC60320 C12 plug RAL 7021 1 piece assembled 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 21130-400 21130-401 21130-402 21130-403 21130-400 21130-401 21130-402 21130-403 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 – – 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 – – SCHROFF PRODUCT CATALOG E 05/2016 01005085 for fan top cover, applications and load in accordance with DIN 582 1 piece assembled 1 piece assembled 1 piece assembled PU 4 pieces assembled 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Base plates Base plate, multipiece 01004104 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing, dimensions see page 1.9 RAL 7021 1 piece assembled 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-360 23130-361 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-360 23130-361 Brush strip 01004105 Base plate Dust filter set Cover plate 01004059 Base plate for lateral cable ducting For cabinet For cabinet Brush strip width 600 mm width 800 mm 01004106 01006072 01006094 nylon, black filter mat, white, class M1, in accordance with EN 799-G3 St, 1.5 mm, please order gasket IP55 separately St, 1.5 mm, one brush strip opening on one side, please order brush strip separately St, 1.5 mm, brush strip opening on both sides, please order brush strip separately 1 piece assembled 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled – 23130-074 23130-075 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-354 23130-355 23130-074 23130-075 23130-076 23130-378 23130-353 – 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-074 23130-075 23130-076 23130-378 23130-353 – 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 – 23130-136 – 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 – – 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-074 23130-134 23130-074 23130-134 23130-075 23130-135 23130-075 23130-135 23130-136 01006072 nylon, black, is assembled laterally, please order one brush strip at cabinet width of 600 mm, but two brush strips at cabinet width of 800 mm 1 piece assembled 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.175 Cabinets – VARISTAR Datacom/Networking RAL 7021 Bases/plinths Base/plinth, ventilated 01004110 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.176 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Base/plinth Side trim Tilt protection, extractable 01004053 01006055 Base/plinth, mobile Base/plinth, Tilt protection, mobile extractable 01004111 01006055 support with adjustable feet and 2 trims, perforated, static loadcarrying capacity 1000 kg; please order side trims separately St, 1.5 mm St, 2 mm, for retrofitting to the base, incl. cover strip support, St, 3 mm, trim, St, 1.5 mm, static loadcarrying capacity on castors 400 kg, on adjustable feet 1000 kg St, 2 mm, for retrofitting to the base, incl. cover strip RAL 7021 PU 1 kit assembled RAL 7021 PU 1 pair assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-208 23130-209 23130-212 23130-213 23130-208 23130-209 23130-212 23130-213 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-370 23130-371 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-370 23130-371 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 SCHROFF PRODUCT CATALOG E 05/2016 – – – – – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – – – – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 19" panel/slide mounts 19" panel/slide mounts EIA Painted RAL 7021 AIZn U height identification for 19" panel/slide mounts 19" assembly kit M6 W xf c D Dimension Standard fitting 01004146 01004112 00505050 sc128 assembly kit: St, 1.75 mm; reduced-width adaptor paper strip, white, xf = distance bracket required for 800 mm width; serial numbered item 1: screws, from front from 1 ... 47 U item 2: cage nuts, depth members are required for c = pitch of 19" item 3: washers partial-height mounting panel/slide mounts D = cabinet depth W = cabinet width Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 RAL 7021 PU 1 pair assembled PU 1 pair assembled PU 4 pieces assembled PU 50 pieces supplied loose 23130-021 23130-031 25127-997 21101-809 23130-021 23130-031 25127-997 21101-809 23130-022 23130-032 25127-997 21101-809 23130-022 23130-032 25127-997 21101-809 23130-024 23130-034 25127-997 21101-809 23130-024 23130-034 25127-997 21101-809 23130-025 23130-035 25127-997 21101-809 23130-025 23130-035 25127-997 21101-809 23130-026 23130-036 25127-997 21101-809 23130-026 23130-036 25127-997 21101-809 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.177 Cabinets – VARISTAR Datacom/Networking RAL 7021 Adapter bracket for reduced width, depth member, cross member Adapter bracket for reduced width Depth member, 3 rows Heavy-load cross member W xf c D Dimension Standard fitting 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width All RAL 7021 (black grey) RAL 7035 (light grey) on request Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.178 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 01004128 01004056 01004056 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets St, 1.5 mm, finish AlZn; only required for partial-height mounting St, 2.5 mm PU 4 pieces assembled PU 1 pair assembled PU 4 pieces fitted C mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 SCHROFF PRODUCT CATALOG E 05/2016 – 23130-091 – 23130-091 – 23130-091 – 23130-091 – 23130-091 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 – – – – 23130-544 – – – – – – – – 23130-544 23130-545 23130-546 – – – – 23130-544 23130-545 23130-546 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Swing frames Swing frame Stop 120° Swing frame trim Asymmetrical Symmetrical assembly assembly 1 1 2 2 100 200 01005070 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01005061 Door opening 160° Hinge 160° Stop 160° Safety lock 100 01005058 01005057 01005061 41001517 is screwed to the St, usable only in for swing frame, instead of connection with swing frame in square lock, 160° hinge, place of the incl. 2 keys swing frame stop 120° hinge is recommended for safety reasons St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys St; for safety reasons a swing frame stop is recommended St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes RAL 7021 1 piece assembled RAL 7021 PU 1 kit assembled RAL 7021 1 piece assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled RAL 7021 PU 1 kit assembled 1 piece assembled 21130-413 23130-158 – – 23130-160 23130-159 60113-267 21130-423 23130-158 21130-432 21130-442 23130-160 23130-159 60113-267 21130-414 23130-158 – – 23130-160 23130-159 60113-267 21130-424 23130-158 21130-433 21130-443 23130-160 23130-159 60113-267 21130-416 23130-158 – – 23130-160 23130-159 60113-267 21130-426 23130-158 21130-435 21130-445 23130-160 23130-159 60113-267 21130-417 23130-158 – – 23130-160 23130-159 60113-267 21130-427 23130-158 21130-436 21130-446 23130-160 23130-159 60113-267 21130-418 23130-158 – – 23130-160 23130-159 60113-267 21130-428 23130-158 21130-437 21130-447 23130-160 23130-159 60113-267 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.179 Cabinets – VARISTAR Datacom/Networking RAL 7021 Fixed shelves Full depth Stationary shelf Shortened by 100 mm 01004142 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.180 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004142 Depth member, 3 rows 01004056 St, 1.5 mm, static loadcarrying capacity 75 kg, 1 U, incl. GND/ earthing St, 1.5 mm, static loadcarrying capacity 75 kg, 1 U, depth 479 mm, incl. GND/ earthing, for recessed installation order depth members separately length 660 mm, St, 1.5 mm, finish AlZn, required for recessed shelf RAL 7021 1 piece assembled RAL 7021 1 piece assembled AIZn PU 1 pair assembled 21130-323 21130-335 21130-336 21130-327 21130-550 21130-551 21130-333 21130-335 21130-336 21130-337 21130-323 21130-325 21130-333 21130-335 21130-323 21130-325 21130-333 21130-335 21130-323 21130-325 21130-326 21130-327 21130-550 21130-551 21130-333 21130-335 21130-336 21130-337 21130-552 21130-553 21130-323 21130-325 21130-326 21130-327 21130-550 21130-551 21130-333 21130-335 21130-336 21130-337 21130-552 21130-553 21130-322 21130-324 – – – – 21130-322 21130-324 – – 21130-322 21130-324 21130-322 21130-324 21130-322 21130-324 21130-322 21130-324 21130-322 21130-324 – – – – 21130-322 21130-324 – – – – 21130-322 21130-324 – – – – 21130-322 21130-324 – – – – 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Telescopic shelves Full depth 01004144 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Shortened by 100 mm Telescopic shelf, 2 U Mounting bracket 01004145 St, 1.5 mm, St, 1.5 mm, static loadstatic loadcarrying carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately RAL 7021 1 piece assembled RAL 7021 1 piece assembled 21130-353 21130-355 – – – – 21130-373 21130-375 – – 21130-353 21130-355 21130-373 21130-375 21130-353 21130-355 21130-373 21130-375 21130-353 21130-355 – – – – 21130-373 21130-375 – – – – 21130-353 21130-355 – – – – 21130-373 21130-375 – – – – 21130-352 21130-354 – – – – 21130-372 21130-374 – – 21130-352 21130-354 21130-372 21130-374 21130-352 21130-354 21130-372 21130-374 21130-352 21130-354 – – – – 21130-372 21130-374 – – – – 21130-352 21130-354 – – – – 21130-372 21130-374 – – – – 01005054 T-bar lock 01004125 GND/earthing 05904052 St, finish AlZn to lock the telescopic shelf for telescopic shelf PU 4 pieces assembled 1 piece assembled 1 piece assembled 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.181 Cabinets – VARISTAR Datacom/Networking RAL 7021 19" shelves, fixed or telescopic, 1 U 19'' telescopic shelf, 1 U, 30 kg Full depth Shortened by GND/earthing 100 mm 01004146 01004118 St, 1.5 mm, xf = distance static loadfrom front carrying capacity c = pitch of 19" 75 kg, panel/slide depth 600 mm, mounts incl. GND/ D = cabinet depth earthing W = cabinet width Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.182 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 Xf Xf xf W Xf Xf c D C C C 19'' stationary shelf, 1 U, 75 kg Full depth Shortened by 100 mm C Dimension Standard fitting c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 SCHROFF PRODUCT CATALOG E 05/2016 01004119 St, 1.5 mm, static loadcarrying capacity 75 kg, depth 500 mm, incl. GND/ earthing 01004123 01004122 St, 1.5 mm, static load-carrying capacity 30 kg, incl. telescopic slide; please order GND/earthing kit separately 05904052 for telescopic shelf RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled PU 1 kit assembled 21130-303 21130-303 21130-309 21130-309 21130-309 21130-309 21130-303 21130-303 21130-309 21130-309 21130-303 21130-303 21130-303 21130-303 21130-303 21130-303 21130-303 21130-303 21130-303 21130-303 21130-309 21130-309 21130-309 21130-309 21130-303 21130-303 21130-309 21130-309 21130-309 21130-309 21130-303 21130-303 21130-309 21130-309 21130-309 21130-309 21130-303 21130-303 21130-309 21130-309 21130-309 21130-309 21130-302 21130-302 – – – – 21130-302 21130-302 – – 21130-302 21130-302 21130-302 21130-302 21130-302 21130-302 21130-302 21130-302 21130-302 21130-302 – – – – 21130-302 21130-302 – – – – 21130-302 21130-302 – – – – 21130-302 21130-302 – – – – 21130-343 21130-343 – – – – 21130-343 21130-343 – – 21130-343 21130-343 21130-343 21130-343 21130-343 21130-343 21130-343 21130-343 21130-343 21130-343 – – – – 21130-343 21130-343 – – – – 21130-343 21130-343 – – – – 21130-343 21130-343 – – – – 21130-342 21130-342 – – – – 21130-342 21130-342 – – 21130-342 21130-342 21130-342 21130-342 21130-342 21130-342 21130-342 21130-342 21130-342 21130-342 – – – – 21130-342 21130-342 – – – – 21130-342 21130-342 – – – – 21130-342 21130-342 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 19'' telescopic shelves, 2 U Full depth Telescopic shelf, 2 U, 70 kg Shortened by T-bar lock 100 mm GND/earthing xf W Xf Xf c D C C Dimension Standard fitting 01004146 01004123 01004122 St, 1.5 mm, static St, 1.5 mm, static xf = distance load-carrying load-carrying from front capacity 70 kg, capacity 70 kg, c = pitch of 19" incl. telescopic incl. telescopic panel/slide slide; slide; mounts Please order Please order D = cabinet depth T-bar lock and W = cabinet width T-bar lock and earthing kit earthing kit separately separately Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 RAL 7021 1 piece assembled RAL 7021 1 piece assembled 21130-353 21130-353 – – – – 21130-353 21130-353 – – 21130-353 21130-353 21130-353 21130-353 21130-353 21130-353 21130-353 21130-353 21130-353 21130-353 – – – – 21130-353 21130-353 – – – – 21130-353 21130-353 – – – – 21130-353 21130-353 – – – – 21130-352 21130-352 – – – – 21130-352 21130-352 – – 21130-352 21130-352 21130-352 21130-352 21130-352 21130-352 21130-352 21130-352 21130-352 21130-352 – – – – 21130-352 21130-352 – – – – 21130-352 21130-352 – – – – 21130-352 21130-352 – – – – 01004125 05904052 to lock the telescopic shelf for telescopic shelf 1 piece assembled PU 1 kit assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.183 Cabinets – VARISTAR Datacom/Networking RAL 7021 Slide rails Dimension Standard fitting Slide rail Short slide rail 100 kg St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair St, 2.5 mm, zinc-plated, static loadcarrying capacity 100 kg/pair AlZn PU 2 pieces PU 10 pieces supplied loose supplied loose zinc-plated PU 2 pieces PU 10 pieces supplied loose supplied loose W xf c D 25 kg 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.184 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 01004056 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 SCHROFF PRODUCT CATALOG E 05/2016 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 01004154 St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair AlZn PU 2 pieces supplied loose PU 10 pieces supplied loose 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Cable ducting with C-rails, cable support rails C-rail for cabinet depth 01006109 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 C-rail for cabinet width Cable ducting with C-rail Slide nut Cable shell 01006107 St, 1.5 mm, finish AlZn St, 1.5 mm, finish AlZn AIZn PU 2 pieces supplied loose AlZn PU 2 pieces supplied loose 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 01504054 vnt009 Cable retention for C-rail 01006110 for C-rail for C-rail or for cable support rail, for cable bundles of 42 ... 46 mm, further dimensions see page 1.162 PA, UL 94 V-0, black, assembly by clipping onto the C-rail PU 10 pieces supplied loose PU 10 pieces supplied loose PU 5 pieces supplied loose 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 Cable support rail For cabinet For cabinet width depth 01006108 01006106 St, 1.5 mm, length 466.4 mm St, 1.5 mm, finish AlZn RAL 7021 PU 2 pieces supplied loose RAL 7021 PU 2 pieces supplied loose 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.185 Cabinets – VARISTAR Datacom/Networking RAL 7021 Accessories for cabling Plastic 31 x 92 mm Cable bracket Plastic 100 x 100 mm Steel 100 x 100 mm Steel 100 x 180 mm 43 92 31 01012085 01006079 Plastic, PA6, plastic, PA6, black; to slot into black, frame to clip onto frame Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.186 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01006081 01006098 St, zinc-plated, to screw onto frame or 19" panel/ slide mount St, zinc-plated, to screw onto frame or 19" panel/ slide mount PU 4 pieces enclosed loose PU 4 pieces supplied loose PU 4 pieces supplied loose PU 4 pieces supplied loose 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 Accessories for cabling Fibre optic cable bracket 01006074 Completely in RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Deposit for excess cable lengths 01006113 Cable tie Velcro 01005078 01005079 St, 1.5 mm, finish AlZn for assembly on shelf or depth member plastic, 92 mm x 2.5 mm, further dimensions see page 1.162 black, length 300 mm, further dimensions see page 1.162 PU 2 pieces supplied loose PU 2 pieces supplied loose PU 25 pieces supplied loose PU 10 pieces supplied loose – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.187 Cabinets – VARISTAR Datacom/Networking configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.189 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.188 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking Varistar RAL 7021/RAL 7035 ServicePLUS: Configuration and assembly VARISTAR Datacom/Networking 쮿 Dimensions: – Height: 24 ... 47 U (1200 ... 2200 mm) – Width: 600 and 800 mm – Depth: 600, 800, 900, 1000, 1100 and 1200 mm Page 쮿 Colour: Frame, top cover, base in black grey (RAL 7021), side panel, door, rear panel in light grey (RAL 7035); differing colours/finishes are indicated 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Frames, side-by-side mounting kits, adjustable feet, castors 1.190 Side panels, lateral cable ducting 1.191 Decorative frames, glass doors 1.192 Steel doors 1.193 Double doors, cover panels 1.194 Rear panels, connection plates 1.195 Top covers 1.196 Flat top covers with cutout zones 1.197 Fan top covers 1.198 Base plates 1.199 Bases/plinths 1.200 19" panel/slide mounts 1.201 Swing frames 1.203 Shelves 1.204 19" shelves 1.206 Slide rails 1.208 Cable ducting with Cprofiles, cable support rails 1.209 Accessories for cabling 1.210 01006114 Example configuration (here: row 20) Qty 1 1 2 1 1 1 .. SCHROFF.PENTAIR.EN Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece Side panel with quick release fastener, PU 2 pieces Safety lock for side panel, PU 4 pieces Rear panel screw-fixed, 1 piece Glazed door with single point locking, 1 piece Adjustable feet, PU 4 pieces .......... Order no. 20130-019/05 22130-051/05 23130-132/05 22130-069/05 22130-129/05 23130-079/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.189 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Frames, side-by-side mounting kits, adjustable feet, castors Frame Slim-Line 400 kg Heavy-Duty 800 kg 01004078 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.190 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 For dynamic load, static loadcarrying capacity: St, 1.5 mm, zincplated, with 400 kg, central GND/ St, 1.5 mm, zincearthing plated, with point; please central GND/ order adjustable earthing feet or castors point; please separately order adjustable feet or castors separately RAL 7021 1 piece assembled RAL 7021 1 piece assembled 20130-001 20130-002 20130-035 20130-036 20130-578 20130-579 20130-003 20130-004 20130-037 20130-038 20130-005 20130-006 20130-007 20130-008 20130-013 20130-014 20130-015 20130-016 20130-018 20130-019 20130-020 20130-021 20130-580 20130-581 20130-022 20130-023 20130-024 20130-025 20130-582 20130-583 20130-027 20130-028 20130-029 20130-030 20130-584 20130-585 20130-031 20130-032 20130-033 20130-034 20130-586 20130-587 20130-051 20130-052 20130-085 20130-086 20130-588 20130-589 20130-053 20130-054 20130-087 20130-088 20130-055 20130-056 20130-057 20130-058 20130-063 20130-064 20130-065 20130-066 20130-068 20130-069 20130-070 20130-071 20130-590 20130-591 20130-072 20130-073 20130-074 20130-075 20130-592 20130-593 20130-077 20130-078 20130-079 20130-080 20130-594 20130-595 20130-081 20130-082 20130-083 20130-084 20130-596 20130-597 SCHROFF PRODUCT CATALOG E 05/2016 Side-by-side mounting kit IP 20 07004120 side-by-side mounting brackets (4 pieces), St Adjustable feet 01004081 Castors With 2 jacking With adjustable feet feet 01004082 01004156 for the frame, for the frame, for the frame, static loadstatic loadstatic loadcarrying capacity: carrying capacity: carrying capacity: 400 kg, 400 kg, 1000 kg, cannot be used cannot be used cannot be used with base/plinth with base/plinth with base/plinth PU 1 kit supplied loose PU 4 pieces assembled PU 4 pieces assembled PU 4 pieces assembled 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 23130-061 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Side panels, lateral cable ducting Side panel With quick Lock release fastener Screw-fixed side panel Side panel Inside locking Cable panel Width 150 mm Lateral cable ducting Cable panel Cable ladder Width 250 mm Width 300 mm H 1 10 01004084 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004072 St, 1 mm, incl. GND/ earthing, please order lock separately for quick-release fasteners of one side panel; 4 locks sufficient for 2 side panels RAL 7035 PU 2 pieces assembled PU 4 pieces assembled 22130-041 22130-042 22130-524 22130-525 – – 22130-041 22130-042 22130-524 22130-525 22130-043 22130-044 22130-043 22130-044 22130-047 22130-048 22130-047 22130-048 22130-050 22130-051 22130-052 22130-053 – – 22130-050 22130-051 22130-052 22130-053 – – 22130-055 22130-056 22130-057 22130-058 – – 22130-055 22130-056 22130-057 22130-058 – – 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 23130-132 01004083 St, 1 mm, incl. GND/ earthing RAL 7035 PU 2 pieces assembled 22130-001 22130-002 22130-516 22130-517 22130-532 22130-533 22130-001 22130-002 22130-516 22130-517 22130-003 22130-004 22130-003 22130-004 22130-007 22130-008 22130-007 22130-008 22130-010 22130-011 22130-012 22130-013 22130-534 22130-535 22130-010 22130-011 22130-012 22130-013 22130-534 22130-535 22130-015 22130-516 22130-517 22130-018 22130-536 22130-537 22130-015 22130-516 22130-517 22130-018 22130-536 22130-537 W 01006104 bracket, St, 1 mm, finish AlZn; with retention screws 01006103 St, 1 mm, with cut-outs for cable ties or Velcro see page 1.210 01006075 round steel, zinc-plated, height 1800 mm, for cable ties or Velcro see page 1.210 PU 2 pieces assembled RAL 7021 PU 2 pieces assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled 23130-373 – – – 23130-373 – – – 23130-373 – – – 23130-373 – – – 23130-373 23130-420 23130-149 – 23130-373 23130-420 23130-149 – 23130-373 23130-421 23130-150 23130-554 23130-373 23130-421 23130-150 23130-554 23130-373 23130-422 23130-151 23130-555 23130-373 23130-422 23130-151 23130-555 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.191 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Decorative frames, glass doors Deco frame Deco frame Adaptor bracket 01004086 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.192 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004160 Glazed door Single point Lever handle locking 01004088 01004147 with push button for doors with single point locking Glazed door 3-point locking 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing DIN profile half cylinder 01004148 for lever handle, common locking Al, 19" plane integrated, front open, incl. GND/ earthing, no door can be fitted St, 2 mm, for deco frame, for assembly of slide rails and shelves St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lock cover, incl. GND/ earthing RAL 7035 1 piece assembled RAL 7035 PU 1 pair assembled RAL 7035 1 piece assembled 1 piece assembled RAL 7035 1 piece assembled 1 piece assembled 22130-231 23130-230 22130-121 23130-067 22130-181 25127-995 – – 22130-122 23130-067 22130-182 25127-995 22130-232 23130-231 22130-123 23130-067 22130-183 25127-995 – – 22130-124 23130-067 22130-184 25127-995 22130-234 23130-233 22130-127 23130-067 22130-187 25127-995 – – 22130-128 23130-067 22130-188 25127-995 22130-235 23130-234 22130-129 23130-067 22130-189 25127-995 – – 22130-130 23130-067 22130-190 25127-995 22130-236 23130-235 22130-131 23130-067 22130-191 25127-995 – – 22130-132 23130-067 22130-192 25127-995 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Steel doors Steel door, single point locking Plain, with Perforated mounting frame on inner side Plain 01004089 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004089 Lever handle 01004090 01004147 with push button for doors with single point locking Steel door, 3-point locking Plain Perforated 01004090 DIN profile half cylinder 01004093 St, 1.5 mm, St, 1.5 mm, opening angle opening angle 180°, lever handle 180°, with mounting frame with push button, incl. GND/ on inner side, earthing lever handle with push button, incl. GND/ earthing 01004148 for lever handle, common locking St, 1 mm, opening angle 180°, lock cover, incl. GND/ earthing St, 1,5 mm, opening angle 180°, lock cover, incl. GND/ earthing, designed to carry extensive cutouts and assemblies St, 1.5 mm, opening angle 180°, lock cover, incl. GND/ earthing RAL 7035 1 piece assembled RAL 7035 1 piece assembled RAL 7035 1 piece assembled 1 piece assembled RAL 7035 1 piece assembled RAL 7035 1 piece assembled 1 piece assembled 22130-106 22130-566 22130-136 23130-067 22130-151 21130-700 25127-995 22130-107 22130-567 22130-137 23130-067 22130-152 21130-701 25127-995 22130-108 22130-568 22130-138 23130-067 22130-153 21130-702 25127-995 22130-109 22130-569 22130-139 23130-067 22130-154 21130-703 25127-995 22130-112 22130-572 22130-142 23130-067 22130-157 21130-706 25127-995 22130-113 22130-573 22130-143 23130-067 22130-158 21130-707 25127-995 22130-114 22130-574 22130-144 23130-067 22130-159 21130-708 25127-995 22130-115 22130-575 22130-145 23130-067 22130-160 21130-709 25127-995 22130-116 22130-576 22130-146 23130-067 22130-161 21130-710 25127-995 22130-117 22130-577 22130-147 23130-067 22130-162 21130-711 25127-995 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.193 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Double doors, cover panels Glazed Double door, 3-point locking Plain Perforated DIN profile half cylinder Hinged Cover panel Brush strip for cover panel 90° 01005065 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.194 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01005064 01005066 St, 1.5 mm, St, 1.5 mm, frame, St, opening angle opening angle 1.5 mm, 180°, 180°, Sekurit glass, lever handle with lever handle with 6 mm, push button, push button, opening angle incl. GND/ incl. GND/ 180°, earthing earthing lever handle with push button, incl. GND/ earthing 01004148 for lever handle, common locking 01006056 St, 1 mm, to cover the cabling space next to the panel/ slide mounts 01006056 black RAL 7035 1 piece assembled RAL 7035 1 piece assembled RAL 7035 1 piece assembled 1 piece assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled 21130-670 21130-657 21130-683 25127-995 – – 21130-671 21130-658 21130-684 25127-995 – – 21130-672 21130-659 21130-685 25127-995 – – 21130-673 21130-660 21130-686 25127-995 – – 21130-676 21130-663 21130-689 25127-995 – – 21130-677 21130-664 21130-690 25127-995 – – 21130-678 21130-665 21130-691 25127-995 – – 21130-679 21130-666 21130-692 25127-995 23130-343 23130-379 21130-680 21130-667 21130-692 25127-995 – – 21130-681 21130-668 21130-694 25127-995 – – SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Rear panels, connection plates Rear panel With quick Lock release fastener 01004087 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004072 Dimensioning connecting plate door/rear panel 01004085 Connecting plate for door and rear panel Plain With brush strip Assembly kit 01005071 01005063 01005069 only required if rear panel with quick-release fastener is assembled above the connecting plate St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel Width mm RAL 7035 1 piece assembled RAL 7035 1 piece assembled PU 1 kit assembled 22130-061 – – – – 23130-133 22130-062 – – – – 22130-093 23130-133 22130-063 – – – – 22130-094 23130-133 22130-064 – – – – 22130-097 23130-133 22130-067 600 22130-472 22130-478 23130-164 22130-098 23130-133 22130-068 800 22130-473 22130-479 23130-164 22130-099 23130-133 22130-069 600 22130-472 22130-478 23130-164 22130-100 23130-133 22130-070 800 22130-473 22130-479 23130-164 22130-101 23130-133 22130-071 600 22130-472 22130-478 23130-164 22130-102 23130-133 22130-072 800 22130-473 22130-479 23130-164 for quick-release fasteners of rear panel St, 1 mm, incl. GND/ earthing RAL 7035 1 piece assembled PU 2 pieces assembled RAL 7035 1 piece assembled 22130-091 23130-133 22130-092 St, 1 mm, incl. GND/ earthing, please order lock separately Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm Screw-fixed rear panel door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.195 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Top covers Flat top cover Perforated Plain flat top cover Lifting eye Flat top cover, raised Spacer Lifting eye 10 M12 01004096 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.196 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004097 St, 1.5 mm, incl. GND/ earthing St, 1.5 mm, fully perforated, incl. GND/ earthing RAL 7021 1 piece assembled RAL 7021 1 piece assembled 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-246 21130-247 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-540 21130-541 21130-242 21130-243 21130-244 21130-245 21130-538 21130-539 21130-246 21130-247 21130-248 21130-249 21130-540 21130-541 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-262 21130-263 21130-266 21130-267 21130-262 21130-263 21130-266 21130-267 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-548 21130-549 21130-262 21130-263 21130-264 21130-265 21130-546 21130-547 21130-266 21130-267 21130-268 21130-269 21130-548 21130-549 SCHROFF PRODUCT CATALOG E 05/2016 01005064 for flat top cover, applications and load in accordance with DIN 582 M12 01004099 St, zinc-plated, for raising a top cover by 10 mm 01005064 for raised flat top cover, applications and load in accordance with DIN 582 PU 4 pieces assembled RAL 7021 PU 4 pieces assembled PU 4 pieces assembled 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Flat top covers with cut-out zones Flat top cover with cable through-ducting openings Flat top cover with cut-out zones Brush strip Fan insert Top cover assemblies Cover plate for Edge protection cut-out zones, perforated Lifting eye M12 01015052 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01006093 St, 1.5 mm, incl. GND/ earthing, cutout size 85 mm x 449 mm St, 1.5 mm, incl. GND/ earthing, number of cutouts and dimension drawings see page 1.9 RAL 7021 1 piece fitted RAL 7021 1 piece assembled – – – 21130-712 21130-713 21130-714 – – – 21130-715 – – – – – – – – – – – 21130-712 21130-713 21130-714 – – – 21130-715 21130-716 21130-717 – – – 21130-712 21130-713 21130-714 – – – 21130-715 21130-716 21130-717 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-252 21130-253 21130-256 21130-257 21130-252 21130-253 21130-256 21130-257 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-544 21130-545 21130-252 21130-253 21130-254 21130-255 21130-542 21130-543 21130-256 21130-257 21130-258 21130-259 21130-544 21130-545 10106092 01004102 230 VAC, nylon, black, one brush strip with three fans, covers a 410 m3/h, lateral cut-out, completely wired, two brush strips connecting cable cover a center IEC 320 cut-out 01009056 St, 1.5 mm, 6 mm hole diameter, incl. GND/earthing W D 41003065 01005064 PVC, 3 m, black, for open cut-out zones for flat top cover, applications and load in accordance with DIN 582 PU 2 pieces assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 1 piece enclosed loose PU 4 pieces assembled 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 23130-069 23130-070 23130-071 28127-281 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.197 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Fan top covers Top cover for 6 fans Fan for fan top cover Fan top cover Thermostat Speed control Lifting eye 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm 01005060 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.198 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 kta44844 01108052 01105055 fully wired, St, 1.5 mm, raised fan with grille for with mains cable 90 ... 264 VAC, top assembly, 230 VAC cover, 230 VAC, 3 axial fans, (SCHUKO/UTE input SCHUKO/ 230 VAC, plug/ UTE plug, 38x119x119 mm, 3 outlet IEC 60320 incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 socket), C13 socket; ND/earthing, h adjustment range external NTC connecting cable 0 ... 60°C sensor 1.5 m 2.5 m, SCHUKO/ IEC60320 C12 plug RAL 7021 1 piece assembled 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 21130-400 21130-401 21130-402 21130-403 21130-400 21130-401 21130-402 21130-403 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 – – 21130-400 21130-401 21130-406 21130-407 – – 21130-402 21130-403 21130-404 21130-405 – – SCHROFF PRODUCT CATALOG E 05/2016 01005085 for fan top cover, applications and load in accordance with DIN 582 1 piece assembled 1 piece assembled 1 piece assembled PU 4 pieces assembled 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Base plates Base plate, multipiece 01004104 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing, dimensions see page 1.9 RAL 7021 1 piece assembled 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-005 23130-006 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-360 23130-361 23130-001 23130-002 23130-003 23130-004 23130-358 23130-359 23130-005 23130-006 23130-007 23130-008 23130-360 23130-361 Brush strip 01004105 Base plate Dust filter set Cover plate 01004059 Base plate for lateral cable ducting For cabinet For cabinet Brush strip width 600 mm width 800 mm 01004106 01006072 01006094 nylon, black filter mat, white, class M1, in accordance with EN 799-G3 St, 1.5 mm, please order gasket IP55 separately St, 1.5 mm, one brush strip opening on one side, please order brush strip separately St, 1.5 mm, brush strip opening on both sides, please order brush strip separately 1 piece assembled 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled – 23130-074 23130-075 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-354 23130-355 23130-074 23130-075 23130-076 23130-378 23130-353 – 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-074 23130-075 23130-076 23130-378 23130-353 – 23130-134 23130-135 23130-136 – 23130-378 23130-353 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 – 23130-136 – 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-076 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 – – 23130-378 23130-353 23130-354 23130-355 23130-356 23130-357 23130-074 23130-134 23130-074 23130-134 23130-075 23130-135 23130-075 23130-135 23130-136 01006072 nylon, black, is assembled laterally, please order one brush strip at cabinet width of 600 mm, but two brush strips at cabinet width of 800 mm 1 piece assembled 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 23130-074 23130-134 23130-374 23130-375 23130-376 23130-377 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.199 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Bases/plinths Base/plinth, ventilated 01004110 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Base/plinth Side trim Tilt protection, extractable 01004053 01006055 Base/plinth, mobile Base/plinth, Tilt protection, mobile extractable 01004156 01006055 support with adjustable feet and 2 trims, perforated, static loadcarrying capacity 1000 kg; please order side trims separately St, 1.5 mm St, 2 mm, for retrofitting to the base, incl. cover strip support, St, 3 mm, trim, St, 1.5 mm, static loadcarrying capacity on castors 400 kg, on adjustable feet 1000 kg St, 2 mm, for retrofitting to the base, incl. cover strip RAL 7021 PU 1 kit assembled RAL 7021 PU 1 pair assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled RAL 7021 1 piece assembled 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 23130-169 23130-170 23130-171 23130-172 23130-362 23130-363 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-208 23130-209 23130-212 23130-213 23130-208 23130-209 23130-212 23130-213 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-370 23130-371 23130-208 23130-209 23130-210 23130-211 23130-368 23130-369 23130-212 23130-213 23130-214 23130-215 23130-370 23130-371 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 23130-187 23130-194 SCHROFF PRODUCT CATALOG E 05/2016 – – – – – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – – – – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 – – 23130-345 23130-346 23130-347 23130-348 – – 23130-349 23130-350 23130-351 23130-352 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 19" panel/slide mounts 19" panel/slide mount EIA RAL 7035 AIZn U height identification for 19" panel/slide mounts 19" assembly kit M6 W xf c D Dimension Standard fitting 01004146 01004112 00505050 sc128 assembly kit: St, 1.75 mm, reduced-width adaptor paper strip, white, xf = distance bracket required for 800 mm width; serial numbered item 1: screws, from front from 1 ... 47 U item 2: cage nuts, depth members are required for c = pitch of 19" item 3: washers partial-height mounting panel/slide mounts D = cabinet depth W = cabinet width Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 RAL 7035 PU 1 pair assembled PU 1 pair assembled PU 4 pieces assembled PU 50 pieces supplied loose 23130-021 23130-031 25127-997 21101-809 23130-021 23130-031 25127-997 21101-809 23130-022 23130-032 25127-997 21101-809 23130-022 23130-032 25127-997 21101-809 23130-024 23130-034 25127-997 21101-809 23130-024 23130-034 25127-997 21101-809 23130-025 23130-035 25127-997 21101-809 23130-025 23130-035 25127-997 21101-809 23130-026 23130-036 25127-997 21101-809 23130-026 23130-036 25127-997 21101-809 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.201 Cabinets – VARISTAR Datacom/Networking RAL 7021 Adapter bracket for reduced width, depth member, cross member Adapter bracket for reduced width Depth member, 3 rows Heavy-load cross member W xf c D Dimension Standard fitting 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width All RAL 7021 (black grey) RAL 7035 (light grey) on request Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.202 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 01004128 01004056 01004056 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets St, 1.5 mm, finish AlZn; only required for partial-height mounting St, 2.5 mm PU 4 pieces assembled PU 1 pair assembled 23130-081 PU 4 pieces fitted C mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 SCHROFF PRODUCT CATALOG E 05/2016 23130-082 – 23130-083 23130-084 23130-364 – 23130-365 23130-091 – 23130-091 – 23130-091 23130-081 23130-082 – – 23130-083 – 23130-084 23130-544 23130-081 23130-082 – 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 – – – 23130-081 23130-082 – 23130-083 23130-084 – 23130-364 23130-091 23130-365 23130-081 – 23130-082 – 23130-083 23130-084 23130-544 23130-364 23130-545 23130-365 23130-546 – 23130-081 23130-082 – 23130-083 23130-084 23130-364 – 23130-365 23130-081 23130-082 23130-091 – – 23130-083 – 23130-084 23130-544 23130-364 23130-365 23130-545 23130-546 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Swing frames Swing frame Stop 120° Swing frame trim Asymmetrical Symmetrical assembly assembly 1 1 2 2 100 200 01005070 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01005061 Door opening 160° Hinge 160° Stop 160° Safety lock 100 01005058 01005057 01005061 41001517 is screwed to the St, usable only in for swing frame, instead of connection with swing frame in square lock, 160° hinge, place of the incl. 2 keys swing frame stop 120° hinge is recommended for safety reasons St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys St; for safety reasons a swing frame stop is recommended St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes RAL 7021 1 piece assembled RAL 7021 PU 1 kit assembled RAL 7021 1 piece assembled RAL 7021 PU 2 pieces assembled PU 2 pieces assembled RAL 7021 PU 1 kit assembled 1 piece assembled 21130-413 23130-158 – – 23130-160 23130-159 60113-267 21130-423 23130-158 21130-432 21130-442 23130-160 23130-159 60113-267 21130-414 23130-158 – – 23130-160 23130-159 60113-267 21130-424 23130-158 21130-433 21130-443 23130-160 23130-159 60113-267 21130-416 23130-158 – – 23130-160 23130-159 60113-267 21130-426 23130-158 21130-435 21130-445 23130-160 23130-159 60113-267 21130-417 23130-158 – – 23130-160 23130-159 60113-267 21130-427 23130-158 21130-436 21130-446 23130-160 23130-159 60113-267 21130-418 23130-158 – – 23130-160 23130-159 60113-267 21130-428 23130-158 21130-437 21130-447 23130-160 23130-159 60113-267 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.203 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Fixed shelves Full depth Stationary shelf Shortened by 100 mm 01004142 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.204 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01004142 Depth member, 3 rows 01004056 St, 1.5 mm, static loadcarrying capacity 75 kg, 1 U, incl. GND/ earthing St, 1.5 mm, static loadcarrying capacity 75 kg, 1 U, depth 479 mm, incl. GND/ earthing, for recessed installation order depth members separately length 660 mm, St, 1.5 mm, finish AlZn, required for recessed shelf RAL 7035 1 piece assembled RAL 7035 1 piece assembled AIZn PU 1 pair assembled 22130-323 22130-325 22130-326 22130-327 22130-550 22130-551 21130-333 21130-335 22130-336 22130-337 22130-323 22130-325 21130-333 21130-335 22130-323 22130-325 21130-333 21130-335 22130-323 22130-325 22130-326 22130-327 22130-550 22130-551 21130-333 21130-335 22130-336 22130-337 22130-552 22130-553 22130-323 22130-325 22130-326 22130-327 22130-550 22130-551 21130-333 21130-335 22130-336 22130-337 22130-552 22130-553 22130-322 22130-324 – – – – 22130-332 22130-334 – – 22130-322 22130-324 22130-332 22130-334 22130-322 22130-324 22130-332 22130-334 22130-322 22130-324 – – – – 22130-332 22130-334 – – – – 22130-322 22130-324 – – – – 22130-332 22130-334 – – – – 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 23130-081 23130-082 23130-083 23130-084 23130-364 23130-365 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Telescopic shelves Full depth 01004144 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Shortened by 100 mm Telescopic shelf, 2 U Mounting bracket 01004145 St, 1.5 mm, St, 1.5 mm, static loadstatic loadcarrying carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately RAL 7035 1 piece assembled RAL 7035 1 piece assembled 22130-353 22130-355 – – – – 22130-373 22130-375 – – 22130-353 22130-355 22130-373 22130-375 22130-353 22130-355 22130-373 22130-375 22130-353 22130-355 – – – – 22130-373 22130-375 – – – – 22130-353 22130-355 – – – – 22130-373 22130-375 – – – – 22130-352 22130-354 – – – – 22130-372 22130-374 – – 22130-352 22130-354 22130-372 22130-374 22130-352 22130-354 22130-372 22130-374 22130-352 22130-354 – – – – 22130-372 22130-374 – – – – 22130-352 22130-354 – – – – 22130-372 22130-374 – – – – 01005054 T-bar lock 01004125 GND/earthing 05904052 St, finish AlZn to lock the telescopic shelf for telescopic shelf PU 4 pieces assembled 1 piece assembled 1 piece assembled 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.205 Cabinets – VARISTAR Datacom/Networking 19" shelves, fixed or telescopic, 1 U 19'' stationary shelf, 1 U, 75 kg Full depth Shortened by 100 mm 19'' telescopic shelf, 1 U, 30 kg Full depth Shortened by GND/earthing 100 mm C Xf Xf xf W Xf Xf c D C C Dimension Standard fitting C RAL 7021 / RAL 7035 01004146 01004118 St, 1.5 mm, xf = distance static loadfrom front carrying capacity c = pitch of 19" 75 kg, panel/slide depth 600 mm, mounts incl. GND/ D = cabinet depth earthing W = cabinet width 01004119 St, 1.5 mm, static loadcarrying capacity 75 kg, depth 500 mm, incl. GND/ earthing 01004123 01004122 St, 1.5 mm, static load-carrying capacity 30 kg, incl. telescopic slide; please order GND/earthing kit separately 05904052 for telescopic shelf Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm xf mm c mm RAL 7035 1 piece assembled RAL 7035 1 piece assembled RAL 7035 1 piece assembled RAL 7035 1 piece assembled PU 1 kit assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 22130-303 22130-303 22130-309 22130-309 22130-309 22130-309 22130-303 22130-303 22130-309 22130-309 22130-303 22130-303 22130-303 22130-303 22130-303 22130-303 22130-303 22130-303 22130-303 22130-303 22130-309 22130-309 22130-309 22130-309 22130-303 22130-303 22130-309 22130-309 22130-309 22130-309 22130-303 22130-303 22130-309 22130-309 22130-309 22130-309 22130-303 22130-303 22130-309 22130-309 22130-309 22130-309 22130-302 22130-302 – – – – 22130-302 22130-302 – – 22130-302 22130-302 22130-302 22130-302 22130-302 22130-302 22130-302 22130-302 22130-302 22130-302 – – – – 22130-302 22130-302 – – – – 22130-302 22130-302 – – – – 22130-302 22130-302 – – – – 22130-343 22130-343 – – – – 22130-343 22130-343 – – 22130-343 22130-343 22130-343 22130-343 22130-343 22130-343 22130-343 22130-343 22130-343 22130-343 – – – – 22130-343 22130-343 – – – – 22130-343 22130-343 – – – – 22130-343 22130-343 – – – – 22130-342 22130-342 – – – – 22130-342 22130-342 – – 22130-342 22130-342 22130-342 22130-342 22130-342 22130-342 22130-342 22130-342 22130-342 22130-342 – – – – 22130-342 22130-342 – – – – 22130-342 22130-342 – – – – 22130-342 22130-342 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – 23130-140 23130-140 – – – – 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.206 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 19'' telescopic shelves, 2 U Full depth Telescopic shelf, 2 U, 70 kg Shortened by T-bar lock 100 mm GND/earthing xf W Xf Xf c D C C Dimension Standard fitting 01004146 01004123 01004122 St, 1.5 mm, static St, 1.5 mm, static xf = distance load-carrying load-carrying from front capacity 70 kg, capacity 70 kg, c = pitch of 19" incl. telescopic incl. telescopic panel/slide slide; Please slide; Please mounts D = cabinet depth order T-bar lock order T-bar lock and earthing kit W = cabinet width and earthing kit separately separately Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 RAL 7035 1 piece assembled RAL 7035 1 piece assembled 22130-353 22130-353 – – – – 22130-353 22130-353 – – 22130-353 22130-353 22130-353 22130-353 22130-353 22130-353 22130-353 22130-353 22130-353 22130-353 – – – – 22130-353 22130-353 – – – – 22130-353 22130-353 – – – – 22130-353 22130-353 – – – – 22130-352 22130-352 – – – – 22130-352 22130-352 – – 22130-352 22130-352 22130-352 22130-352 22130-352 22130-352 22130-352 22130-352 22130-352 22130-352 – – – – 22130-352 22130-352 – – – – 22130-352 22130-352 – – – – 22130-352 22130-352 – – – – 01004125 05904052 to lock the telescopic shelf for telescopic shelf 1 piece assembled PU 1 kit assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.207 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Slide rails Dimension Standard fitting Slide rail Short slide rail 100 kg St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair St, 2.5 mm, zinc-plated, static loadcarrying capacity 100 kg/pair AlZn PU 2 pieces PU 10 pieces supplied loose supplied loose zinc-plated PU 2 pieces PU 10 pieces supplied loose supplied loose W xf c D 25 kg 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.208 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 xf mm 50 150 70 70 70 70 50 150 70 70 50 150 50 150 50 150 50 150 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 50 150 70 70 70 70 01004056 c mm 500 500 740 740 740 740 500 500 740 740 500 500 500 500 500 500 500 500 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 500 500 740 740 740 740 SCHROFF PRODUCT CATALOG E 05/2016 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-096 23130-096 23130-098 23130-098 23130-098 23130-098 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-101 23130-101 23130-103 23130-103 23130-103 23130-103 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-118 23130-118 23130-120 23130-120 23130-120 23130-120 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 23130-123 23130-123 23130-125 23130-125 23130-125 23130-125 01004154 St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair AlZn PU 2 pieces supplied loose PU 10 pieces supplied loose 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 23130-094 23130-095 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Cable ducting with C-rails, cable support rails C-rail for cabinet depth 01006109 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 C-rail for cabinet width Cable ducting with C-rail Slide nut Cable shell 01006107 St, 1.5 mm, finish AlZn St, 1.5 mm, finish AlZn AIZn PU 2 pieces supplied loose AlZn PU 2 pieces supplied loose 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 23130-086 23130-087 23130-088 23130-089 23130-366 23130-367 01504054 vnt009 Cable retention for C-rail 01006110 for C-rail for C-rail or for cable support rail , for cable bundles of 42 ... 46 mm, further dimensions see page 1.162 PA, UL 94 V-0, black, assembly by clipping onto the C-rail PU 10 pieces supplied loose PU 10 pieces supplied loose PU 5 pieces supplied loose 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 Cable support rail For cabinet For cabinet width depth 01006108 01006106 St, 1.5 mm, length 466,4 mm St, 1.5 mm, finish AlZn RAL 7021 PU 2 pieces supplied loose RAL 7021 PU 2 pieces supplied loose 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 23130-326 23130-328 23130-329 23130-330 23130-331 23130-332 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 21236-093 23130-312 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.209 Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Accessories for cabling Plastic 31 x 92 mm Cable bracket Plastic Steel 100 x 100 mm 100 x 100 mm Steel 100 x 180 mm 43 92 31 01012085 01006079 Plastic, PA6, plastic, PA6, black; to slot into black; frame to clip onto frame Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1.210 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 01006081 01006098 St, zinc-plated, to screw onto frame or 19" panel/ slide mount St, zinc-plated, to screw onto frame or 19" panel/ slide mount PU 4 pieces enclosed loose PU 4 pieces supplied loose PU 4 pieces supplied loose PU 4 pieces supplied loose 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 23130-506 – – – 23130-506 23130-336 23130-341 23130-342 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking RAL 7021 / RAL 7035 Accessories for cabling Fibre optic cable bracket 01006074 Colour combination RAL 7035 (light grey)/RAL 7021 (black grey) Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 24 24 24 24 24 24 24 24 24 24 29 29 29 29 38 38 38 38 42 42 42 42 42 42 42 42 42 42 42 42 47 47 47 47 47 47 47 47 47 47 47 47 1200 1200 1200 1200 1200 1200 1200 1200 1200 1200 1400 1400 1400 1400 1800 1800 1800 1800 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 2200 600 600 600 600 600 600 800 800 800 800 600 600 800 800 600 600 800 800 600 600 600 600 600 600 800 800 800 800 800 800 600 600 600 600 600 600 800 800 800 800 800 800 SCHROFF.PENTAIR.EN 600 800 900 1000 1100 1200 600 800 900 1000 600 800 600 800 600 800 600 800 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 600 800 900 1000 1100 1200 Deposit for excess cable lengths 01006113 Cable tie Velcro 01005078 01005079 St, 1.5 mm, finish AlZn for assembly on shelf or depth member plastic, 92 mm x 2.5 mm, further dimensions see page 1.162 black, length 300 mm, further dimensions see page 1.162 PU 2 pieces supplied loose PU 2 pieces supplied loose PU 25 pieces supplied loose PU 10 pieces supplied loose – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 – 23130-050 20118-351 20118-624 23130-372 23130-050 20118-351 20118-624 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.211 Cabinets – VARISTAR Datacom/Networking ServicePLUS Cooling solutions for beginners and experts Cooling solutions for beginners and experts Text With Schroff's aisle containment you can boost the cooling efficiency of your data center considerably while simultaneously cutting the energy costs drastically. Consistently separating cold supply air and warm exhaust air produces a high degree of efficiency. Schroff's containment elements can be easily mounted, also subsequently. The cream of the crop: because they go with most cabinet types, you always profit from our innovative solutions. Schroff's containments - individual applications, safe investments and future-proof Based on the Schroff Varistar cabinet platform, cold aisle containment systems are simple to create This concept may be adapted or refitted to a location's special room conditions and cooling requirements. 01008024 Containments Cold aisle containment Text 01008074 A high degree of efficiency is reached by the homogeneous distribution of cold air in front of the servers. Radiation losses are lower and the existing room climatisation can be used more efficiently via the double floor. If necessary, the cooling capacity in the cold aisle can be expanded with LHX air/water heat exchangers. By relieving the room air-conditioning, redundancy increases. VARISTA R Datacom/Networking ServicePLUS 1.212 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Datacom/Networking ServicePLUS Requirements and solutions for containments Requirements Text 쮿 New data centre for an international bank in a hosting centre 쮿 Constant homogenous cool air for all servers with low energy consumption 쮿 Future proof in cooling, power and cable management 쮿 User friendly for facility management and IT The solution 쮿 Cold aisle containment to reduce energy consumption 쮿 Automated fully double-glazed doors minimise cold air loss 쮿 Perforated base plates throughout for maximum passage of air 쮿 Transparent roof elements allow room lighting to be used 01008025 쮿 Higher positioning of roof elements for increased headroom and sense of space 쮿 Cable duct integrated into roof elements, accessible from cold aisle 쮿 Separate cable panel on cabinet top covers 01008031 SCHROFF.PENTAIR.EN Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.213 VARISTAR containmentMai n C atalogue Cabinets – VARISTAR containment Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 01012006 VARISTAR containmentMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days The Schroff containment system lets you create containment installations without problems. Increase efficiency and cut energy costs 쮿 Consistent separation of cold and hot air 쮿 Overpressure in the containment: Blow-in temperature of air conditioner is almost the same as the temperature in front of the servers 쮿 No temperature layering in front of the 19" plane inside the containment Systems . . . . . . . 8 쮿 No subcooling: possibilities to optimize temperature in data centres 쮿 Higher packing density per cabinet is possible with the same climate control elements 쮿 Low investment with short ROI - no maintenance costs Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 1.202 Cold aisle containment SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Overview . . . . . . 1.202 VARISTAR containmentMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days Containment of VARISTAR cabinets 쮿 쮿 쮿 쮿 Modular standard components enable flexible adaptation to the requirements of your IT Base system simple to combine and modify Minimal investment risk thanks to completely matched climate control system Short implementation time with minimum outlay Varistar containment system 쮿 Preconfigured containment solution from modular standard components (consisting of 6 Varistar server cabinets, RAL 7021, height 2000 mm, width 800 mm, depth 1200 mm) including containment components; containment aisle width 1200 mm) VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 Containment system . . . . . . . . 1.204 쮿 Simple to expand or to use as the configuration basis for your individual containment solution 쮿 Can be delivered in 10 working days 01014007 Doors Doors 쮿 Sliding doors – Mechanical – Electronic Swing doors . . . . . 1.205 Sliding doors, mechanical, Touch variant . . . . 1.205 Sliding door, electronic . . . . . . . 1.207 Top covers Top covers 쮿 Standard solutions for aisle width 1200 mm Top cover elements . . . . . . . . 1.208 쮿 Standard solutions for 2000 mm and 2200 mm high cabinets 쮿 Swing doors 01012073 쮿 For 600 mm and 800 mm wide cabinets 쮿 Integration of cabinets with other dimensions (heights) 쮿 Free aisle height can be raised by 84 mm 01012074 Air partitioning Air partitioning . 1.211 쮿 For server and network cabinets 쮿 For cabinets with different widths and recessed 19" planes 쮿 Solid covers with cable ducting or cable routing (cable fingers, cable channels) 쮿 Halogen-free gasketing UL 94 HF-1 01012055 ServicePLUS from page 1.215 e.g. set-up service and commissioning e.g. custom modifications and developments e.g. free combination of components www.schroff.biz/ServicePLUS ServicePLUS . . . 1.215 VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR Air/water heat exchangers . . . . . . 1.224 30407004 SCHROFF.PENTAIR.CO.UK 1.203 Cabinets – VARISTAR containment Varistar Containment Systems VARISTA R containmentMain C atalogPart number in bold face type: ready for s hippi ng withi n 2 working daysPart number i n normal type: ready for shipping within 1 0 working days 쮿 Preconfigured containment solutions from modular standard components 쮿 Simple to expand or to use as the configuration basis for your individual containment solution 쮿 Consists of 6 Varistar server cabinets (height 2000 mm, width 800 mm, depth 1200 mm) including containment components 쮿 Containment aisle width 1200 mm, all components in RAL 7021 쮿 Can be delivered in 10 working days Delivery includes 01014007 Sliding containment door, mechanical, touch 01012073 Swing containment door 01012070 Item 1 Qty 6 2 3 24 6 4 5 12 6 6 6 7 24 8 24 9 10 11 12 13 12 24 48 4 1 14 1 15 1 16 17 6 2 18 19 20 4 1 1 Description Welded basic frame, Slim-Line, St profile, zincplated, powder-coated, RAL 7021 Adjustable foot Flat top cover, raised, St, RAL 7021, cutouts for brush strip mounting Brush strip for cable entry to flat top cover Front door, St, RAL 7021, with 180° hinges and perforation, 3-point locking and lever handle Rear door, double door, St, RAL 7021, with 180° hinges and perforation, 3-point locking and lever handle Cross member, RAL 7021, to accept 19" panel/slide mounts 19" panel/slide mounts, RAL 7021, mounted at 75 mm intervals Air baffle, St, RAL 7021, with brush strip for cable ducting Central C rail for lateral cable routing in cabinet Steel cable bracket Side panel, screw-fixed, for aisle closure, St, RAL 7021 Sliding containment doors, mechanical, Al extruded frame, 10 mm laminated safety glass, sliding mechanism and rail, fixing materials kit Swing containment doors, St frame, 1.5 mm, with 6 mm single pane safety glass and 180° hinges Top containment covers, frame St, 2 mm, RAL 7021, 7 mm laminated safety glass, length 1200 mm Fixing materials for top cover universal profile Top cover universal profile, Al, length 2400 mm, RAL 7021 Side-by-side mounting kit for cabinets Containment gasketing kit Separator for adjustable cabinet foot Order Information Description Varistar Containment Systems 1.204 SCHROFF PRODUCT CATALOG E 03/2017 Part no. 10130-250 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Swing doors VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days 쮿 Suitable for 2000 and 2200 mm high cabinets 쮿 Double doors suitable for an aisle width of 1200 mm 쮿 2 colours – Black grey (RAL 7021) – Light grey (RAL 7035) Delivery comprises Item 1 Qty 2 2 1 Description Frame St, 1.5 mm; with single pane safety glass 6 mm and 180° hinge, 2-point magnetic locking on main door, bolt on side door to lock into the floor Fixing material kit (for cabinet side) Order Information 01012070 Accessories Description Colour Swing doors RAL 7021 Swing doors RAL 7035 Accessories Door locking PU 1 pieces Door cover mask for unequal aisle heights Part no. 21130-583 22130-583 23130-437 Page 1.216 Note 쮿 Please order suitable door cover masks (above the door) separately 쮿 Optional lever handle with lock on request 01012068 Door cover mask Lock SCHROFF.PENTAIR.CO.UK 01012060 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.205 Cabinets – VARISTAR containment Sliding door, mechanical, Touch variant Main Catalogue 쮿 Suitable for 2000 and 2200 mm high cabinets 쮿 Doors open symmetrically (both wings open at same time); door catch with magnet (door stays open); closes automatically when lightly tapped 쮿 Double doors suitable for an aisle width of 1200 mm 쮿 Colour black grey (RAL 7021) Delivery comprises Item 1 Qty 2 2 3 1 1 Description Sliding door, frame Al extrusion; laminated safety glass 10 mm, sliding gear Slide rail with front trim Fixing material kit (for cabinet side) Order Information 01012073 Accessories Description Sliding door, mechanical, Touch variant version Accessories Reed contact 1 piece Door seal cover for various aisle heights Part no. 21130-060 60130-065 Page 1.217 Note 쮿 Please order suitable door cover maskSs (above the door) separately 01012067 Door cover mask Assembly kit 1.206 01012059 SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Sliding door, electronic VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days 쮿 Suitable for 2000 and 2200 mm high cabinets 쮿 Door is opened/closed using a button (outside and inside); manually in case of power failure 쮿 Double doors suitable for an aisle width of 1200 mm 쮿 Colour black grey (RAL 7021) 쮿 Optional door activation with motion sensor or operator unit with access control Delivery comprises 01012072 Item 1 Qty 2 2 3 1 1 Description Sliding door, frame Al extrusion; laminated safety glass 10 mm, door sliding gear, connector cable and button to operate door Slide rail with front trim Fixing material kit (for cabinet side) Order Information Description Sliding door, electronic Accessories Reed contact 1 piece Battery pack 1 piece Motion detector 1 piece Door seal cover for various aisle heights Part no. 21130-073 60130-065 60130-066 60130-067 Page 1.218 Note 쮿 Please order suitable door cover masks (above the door) separately 쮿 An assembly kit is required for cabinet height 2200 mm with base/plinth, please order separately 쮿 The door system must be maintained and inspected regularly Optional door opening with motion sensor 01010066 Accessories 01012069 Door cover mask Assembly kit SCHROFF.PENTAIR.CO.UK 01012059 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.207 Cabinets – VARISTAR containment Top cover elements Main Catalogue 쮿 Suitable for an aisle width of 1200 mm 쮿 Top cover with safety glass (VSG) 쮿 For cabinet widths 600 and 800 mm 쮿 A top cover profile can raise the aisle height by 84 mm; please order separately 쮿 Top cover can be removed from inside (allows access to lighting and facilitates maintenance works) Delivery comprises 01008024 Item 1 Qty 1 2 1 Description Frame St, 2 mm, RAL 7021; safety glass (VSG) 7 mm, length 1200 mm Fixing material kit Order Information Description For cabinet width mm 600 800 Top cover elements Top cover elements Accessories Top cover profile Length 2400 mm, PU 2 pieces Assembly kit bracket for top cover raising profile, PU 6 pieces Part no. 21130-588 21130-589 21130-594 23130-433 Note 쮿 Where a mechanical sliding door is used, the top cover directly beside the door must be 100 mm narrower, see page 1.205 01012074 Universal profile to raise top cover VARISTA R containmentMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days 쮿 The top cover elements can be raised by 84 mm using a profile 쮿 Integration of cabinets with other dimensions 쮿 The profile has a T-groove on the inside that allows lamps, sensors, etc, to be mounted easily Delivery comprises Item 1 Qty 2 Description Al extrusion, RAL 7021, length 2400 mm Order Information Application with raised top covers 01012051 Description Universal top cover profile,, height 84 mm Accessories Assembly kit Bracket for universal top cover profile, PU 6 pieces Part no. 21130-594 23130-433 Note 쮿 To mount a profile, an assembly kit (2 pieces) is required; please order separately Accessory: Assembly kit to mount universal top cover profile 1.208 01012052 SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Automatic enclosure top covers MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 Automatic containment top covers open automatically in the event of fire so that the sprinkler systems installed above the containment top cover can put out the fire. In normal operation, the top covers are kept closed by electromagnets and open when the floating contact of the fire detection system is opened 쮿 Suitable for an aisle width of 1200 mm 쮿 For cabinet widths of 600 or 800 mm 쮿 Top cover with safety glass, 7 mm 01017054 쮿 With the universal top cover profile, the aisle height can be increased by 84 mm; please order separately 쮿 The top cover can be removed from the inside. When opened, the top cover provides access to lighting and sprinkler systems above the containment system for maintenance work 쮿 Please order the control unit, which can be used to control up to 12 automatic top covers, separately 쮿 A 24 VDC power supply unit is required to operate the system. Please order separately Delivery includes 01017053 Item 1 Qty. 1 2 3 1 1 Description Frame, St, 2 mm, RAL 7021; 7 mm laminated safety glass, length 1200 mm, electromagnet with 1200 mm connection cable T-shaped connecting plug Fixing materials kit Order Information Description Automatic containment top cover, width 600 mm Automatic containment top cover, width 800 mm Accessories Raised top cover Length 2400 mm, PU 2 pieces Assembly kit Bracket for universal top cover profile, PU 6 pieces Control unit for automatic top covers 1 set Power supply for control unit For power distribution of up to 12 automatic top covers, input 100 to 240 VAC, output: 24 VDC, 40 W, 1 piece Connecting/extension cable, 1 m Connecting/extension cable, 2 m Connecting/extension cable, 5 m Part no. 21130-592 21130-593 21130-594 23130-433 23130-205 23130-227 23130-206 23130-207 23130-226 Control unit for automatic top covers MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 Control unit for up to 12 automatic top covers 쮿 Inputs: – External 24 VDC power supply unit required, please order separately – 2 floating contacts for connecting to a fire detection system and another opening/test button 01017002 쮿 Output: 24 VDC connection for the control and voltage supply of up to 12 automatic enclosure top covers, which can be connected in series Order Information Description Control unit for automatic top covers SCHROFF.PENTAIR.CO.UK Part no. 23130-205 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.209 Cabinets – VARISTAR containment Adaptors for cable routing VARISTA R containmentMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days 쮿 Suitable for VARISTAR cabinets and all common cable panel systems Delivery comprises Item 1 Qty 2 Description St profile, RAL 7021 Order Information Description For cabinet depth mm 1000 1200 Cable route adaptor Cable route adaptor Accessories Mounting bracket for cable route adaptor Bracket, St, PU 2 pieces 01012075 Part no. 21130-596 21130-597 21130-598 Note 쮿 Mounting bracket for cable route adaptor is required for containment without universal top cover profile 01012076 Mounting bracket for cable route adaptor 1.210 SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Covers Covers for 800 mm wide cabinets with adapter bracket for reduced width VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days 쮿 All around the front, covers prevent unwanted air shortcircuits, i.e. the mixture of warm exhaust air with cold inbound air 쮿 For cabinet width 600 or 800 mm, for cabinet height 42 or 47 U 쮿 Versions for installation with adapter bracket for reduced width or cross member – Solid covers – Covers for 800 mm wide cabinets with cut-outs for cable routing – Covers with vertical cable fingers for 800 mm wide cabinets – Cable routing with cable channel (hinged cover at front) for 800 m wide cabinets 01012055 Covers solid, width 800 mm 01012054 Cover with lateral cut-outs 01012056 Cover with cable finger/cable channel Covers for 800 mm wide cabinets with cross member Covers, width 800 mm 01015054 Cover with lateral cut-outs 쮿 Suitable divider plates are available for 19" planes mounted with recess (70, 145, 220 mm) 쮿 Network and server cabinets can be arranged side by side 쮿 Gaskets, UL 94 HF-1, -20 °C ... 100° C Delivery comprises Item 1a Qty 2 2 3 4 1 1 1 Description Cover, St, 1 mm, RAL 7021, left/right (at 600 mm width only gaskets instead of covers) Cover, top, St, 1 mm, RAL 7021 Cover, bottom, St, 1 mm, RAL 7021 Fixing material kit, gaskets, user manual 01015055 Order Information Height Covers for front air separation For 600 mm For 800 mm wide cabinets with adapter bracket for reduced wide cabinets width Cover with Cover with Solid cover Cover with cable fingers cable panels lateral cut-outs for cables Part No. Part No. Part No. Part No. Part No. 21130-624 21130-627 21130-629 – – – – 21130-618 21130-631 21130-620 For 800 mm wide cabinets with cross member Solid cover Cover with lateral cut-outs for cables Part No. Part No. U mm 42 2000 for 70 mm recessed 19" plane 23130-550 42 2000 for 145 mm recessed 19" plane 23130-550 42 2000 for 220 mm recessed 19" plane 21130-622 21130-633 21130-623 21130-636 21130-638 23130-550 47 2200 for 70 mm recessed 19" plane 21130-625 21130-628 21130-630 – – 23130-551 47 2200 for 145 mm recessed 19" plane – – 21130-619 21130-632 21130-621 23130-551 47 2200 for 220 mm recessed 19" plane 21130-626 21130-634 21130-635 21130-637 21130-639 23130-551 Accessories Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece Lateral 19" baffle plates for 42 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 70 mm, PU 1 piece Lateral 19" baffle plates for 47 U cabinets, for lateral termination in depth of 145 mm, PU 1 piece Brush strip for closing the open cable through-ducting opening, 1 U, black, PU 6 pieces Clip-on 19" plastic front panels to close the open cable through-ducting opening of the lateral cladding parts , 1 U, black, PU 10 pieces SCHROFF.PENTAIR.CO.UK 23130-558 23130-558 23130-558 23130-559 23130-559 23130-559 21130-640 21130-642 21130-641 21130-643 23130-153 D19BPT1RU Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.211 Cabinets – VARISTAR containment Basic kit for side-to-side-cooled switches VARISTA R containmentP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 Basic kit to divide the 19" plane in the front part of the cabinet and to accept side trims for switches 쮿 For 800 mm wide VARISTAR cabinets 쮿 with 145 mm recessed 19" plane 쮿 Right front bezel with 5 x air inlets; air inlets that are not required can be closed with easy-to-cut gasketing material 쮿 Left front bezel for back-to-back cabling with 3 x 19"/1 U cutouts (please order brush strips and filler panels separately) 쮿 Kit can also be retrofitted to cabinets already installed in rows Delivery includes Item 1 2 3 4 5 6 7 Qty 2 1 1 1 1 6 1 Description Front frame, St, 1 mm, RAL 7021 (for top and bottom) Cover, left, St, 1 mm, RAL 7021 (3 openings) Cover, right, St, 1 mm, RAL 7021 (5 openings) Base, St, 1 mm, AlZn, for Cisco side trim Top cover, St, 1 mm, AlZn, for Cisco side trim Gasketing (can be cut as required for air inlets) Fixing materials kit, gasketing, user manual 01013067 Order Information Cisco switches side trims 01013066 01013060 19" plastic front panels, brush strips to close cable ducting openings For cabinet height For cabinet width U mm mm 42 2000 800 47 2200 800 Accessories Side trims for Cisco switches for Cisco Switch 4503, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 4506, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 4507, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 4510, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 6506, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 6509, side trim AlZn, 1 mm, 1 kit Side trims for Cisco switches for Cisco Switch 6510, side trim AlZn, 1 mm, 1 kit Clip-on 19" plastic front panels to close the open cable through-ducting opening of the lateral cladding parts 1 U, black, PU 10 pieces Brush strip for closing the open cable through-ducting opening 1 U, black, PU 6 pieces Part no. 21130-646 21130-647 23130-490 23130-491 23130-492 23130-493 23130-494 23130-495 23130-496 D19BPT1RU 23130-153 Note 쮿 Please order appropriate quantity and suitable Cisco switch side trims separately 쮿 Cover for lateral cable through-ducting openings (please order brush strip and 19" front panel separately) 1.212 SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR containment Separating walls VARISTAR contai nm entMain C ataloguePart number in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days 쮿 Where cabinets are arranged in rows the separating wall replaces the cabinet side wall 쮿 Mounts laterally, prevents unauthorised access 쮿 For cabinet height 42 or 47 U and cabinet depth 1000 mm or 1200 mm Delivery comprises Item 1 2 Qty 1 1 Description Separating wall, St, 1 mm, finish AlZn Fixing material kit, user manual Order Information For cabinet height U 42 42 47 47 For cabinet depth mm 1000 1200 1000 1200 Part no. 23130-480 23130-481 23130-484 23130-485 01012058 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.213 Cabinets – VARISTAR containment Gasketing Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Gasketing kits to seal front against air short-circuits Delivery comprises Item 1 2 Qty 1 1 Description Gasket, halogen-free User manual Order Information Description Vertical gasket for vertical sealing between 10 cabinets Horizontal gasket for two 600 mm wide cabinets with adjustable feet Horizontal gasket for two 800 mm wide cabinets with adjustable feet Length mm Part no. 3000 23130-475 1200 23130-477 1600 23130-478 VARISTA R containment Vertical gasket 1.214 01012081 Horizontal gasket SCHROFF PRODUCT CATALOG E 03/2017 01012082 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Configuration aid for aisle containment Varistar ServicePLUS c ontainmentMain Catalogue 쮿 For cabinet rows – Cabinet height 2000 and 2200 mm – Aisle width 1200 mm – Cabinet width 600 mm and 800 mm Page Folding doors 1.216 쮿 Once you have selected the desires cabinet containment height, the row number (first column of the configuration tables) guides you through all subsequent configutations pages that apply to these dimensions (see example below) Sliding door (touch), mechanical 1.217 쮿 Assembly on request Automatic sliding doors 1.218 Top covers 1.219 Cable panel adapter, covers beside 19" plane, solid 1.221 쮿 Colour RAL 7021, swing door also in RAL 7035 쮿 Configure your containment system from individual components Covers beside 19" plane, 800 mm, with adapter 1.222 bracket for reduced width Covers with cable ducting, cable finger, cable 1.223 channel 01012065 Cover for various 19" installation depth, separating wall 1.224 Airflow for side-to-sidecooled switches 1.224 Separating wall, gasketing kits 1.226 Configuration of SHX 30 air/water heat exchanger 1.227 Example 6 cabinet containment cells (here: row 6) Qty 6 2 1 1 3 1 1 5 5 2 .. SCHROFF.PENTAIR.CO.UK Description Side-to-side cabinet, 47 U, 2200 mm high, 800 mm wide, 1200 mm deep, with front and rear door, RAL 7021, 1 piece (see chapter VARISTAR data/network systems) Side panel screw fixed, height 47 U - 2200 mm, for cabinet depth 1200 mm, RAL 7021, PU 2 pieces (see chapter VARISTAR data/network systems) Sliding door, mechanical, for cabinet height 2200 mm, aisle height 2102 mm, with adjustable foot + top cover raising element, 1 piece Door cover mask to equalize aisle height, 1 piece Top cover, for cabinet width 800 mm, aisle width 1200 mm, 1 piece Universal top cover profile, length 2400 mm, height 84 mm, PU 2 pieces Assembly kit for universal top cover profile, PU 6 pieces Cover, for lateral termination, 70 mm recessed, PU 1 kit Cover with lateral cutouts, by 145 mm recessed 19" plane, PU 1 kit Cover for lateral termination, depth-offset 70 mm, 1 piece .......... Order no. 10130-233 22130-537 21130-060 21130-612 21130-589 21130-594 23130-433 21130-638 21130-632 21130-643 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.215 Cabinets – Varistar ServicePLUS containment Swing doors Main Catalogue Order Information Swing door RAL 7021 RAL 7035 01012064 Cover 01012063 Frame, St, with single pane safety glass 6 mm and 180° hinge, 3-point loking and lever handle (please order lock separately), door cover mask to equalise aisle height, 1 piece Door locking 01012068 01012060 St, 1.5 mm, RAL 7021; cover to equalise aisle height Door locking mechanism 01012070 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 3 7 42 47 8 1.216 2000 2200 2308 Base/plinth 2392 Base/plinth + raised top cover SCHROFF PRODUCT CATALOG E 03/2017 PU 2 pieces 1 piece 1 piece 1 piece 21130-583 22130-583 – 23130-437 21130-611 21130-612 21130-583 22130-583 23130-437 21130-612 21130-613 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Sliding doors (touch), mechanical Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Order Information Hand operated sliding door, touch RAL 7021 Cover 01012062 Reed contact 01012067 01015001 Door cover mask Prepared for Sliding door, to equalise aisle integration into frame St, with height, 1 piece door boxes, single pane safety magnet detects glass 6 mm, when door is closes opened; connects automatically to door plate 01012062 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 3 7 8 42 47 2000 2200 2308 Base/plinth 2392 Base/plinth + raised top cover SCHROFF.PENTAIR.CO.UK PU 2 pieces 1 piece 1 piece 21130-060 – 60130-065 – 21130-040 21130-060 60130-065 21130-040 21130-059 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.217 Cabinets – Varistar ServicePLUS containment Automatic sliding doors Main Catalogue Order Information Automatic sliding door RAL 7021 Cover 01012061 Reed contact 01012069 Motion detector 01015001 Battery pack 01015003 Prepared for Door cover mask Prepared for Sliding door, to equalise aisle integration into mounting on door frame, St, box, power supply height, 1 piece door boxes, with single pane magnet detects via connector on safety glass door plate when door is 6 mm, opened; connects closes electrically to door plate by pushbutton 01015002 Prepared for integration into door boxes 01012073 For cabinet height H No. U mm Aisle height (lower edge) mm 1 2018 Adjustable feet 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2 3 7 42 47 8 1.218 2000 2200 Raising elements 2308 Base/plinth 2392 Base/plinth + raised top cover SCHROFF PRODUCT CATALOG E 03/2017 PU 2 pieces 1 piece 1 piece 1 piece 1 piece 21130-073 – 60130-065 60130-067 60130-066 60130-065 60130-067 60130-066 – 21130-040 21130-073 21130-040 21130-059 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Top covers Main Catalogue Order Information Top cover 600 mm width Universal profile to raise top cover 800 mm width 01012050 Frame, St; with single pane safety glass 7 mm, aisle width 1200 mm Assembly kit 01012051 01012052 Bracket to mount Al extrusion, the universal top RAL 7021, cover profile length 2400 mm, height 84 mm 01012074 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 3 42 2000 1 piece 21130-588 1 piece 21130-589 PU 2 pieces PU 6 pieces – – 21130-594 23130-433 – – 2108 Base/plinth 4 2192 Base/plinth + raised top cover 21130-594 23130-433 5 2218 Adjustable feet – – 6 2302 Adjustable feet + raised top cover 21130-594 23130-433 – – 21130-594 23130-433 7 8 47 2200 2308 Base/plinth 2392 Base/plinth + raised top cover SCHROFF.PENTAIR.CO.UK 21130-588 21130-589 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.219 Cabinets – Varistar ServicePLUS containment Automatic fan top covers MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days Order Information Automatic top cover 600 mm width 800 mm width Control unit for top covers 01017053 Frame St, 2 mm, RAL 7021; 7 mm laminated safety glass, length 1200 mm, electromagnet with 1200 mm connection cable, T-shaped connecting plug and fixing materials kit 01012074 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 42 2000 6 7 47 8 1.220 2200 Power supply for control unit 01017002 Connection/ extension cable Length 1 m Connection/ extension cable Length 2 m Connection/ extension cable Length 5 m 01617001 01017056 Control unit for up to 12 automatic top covers, inputs: 24 VDC and 2 floating contacts; output: 24 VDC For power distribution of up to 12 automatic top covers, input 100 to 240 VAC, output: 24 VDC, 40 W Cable with plug, 1 m Cable with plug, 2 m Cable with plug, 5 m 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 21130-592 21130-593 23130-205 23130-227 23130-206 23130-207 23130-226 21130-592 21130-593 23130-205 23130-227 23130-206 23130-207 23130-226 SCHROFF PRODUCT CATALOG E 03/2017 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Cable panel adapter, covers beside 19" plane, solid Main Catalogue Order Information Adaptors for cable routing for 1000 mm cabinet depth for 1200 mm cabinet depth Covers beside 19" plane, solid, 600 mm cabinet width Mounting bracket for cable route adaptor for 70 mm recessed 19" plane for 145 mm recessed 19" plane for 220 mm recessed 19" plane Tex t 01012075 01012076 01012053 St profile, RAL 7021; fits to cabinet with a mounting bracket and has drilled holes to bolt on cable panel Bracket, St, 1.5 mm Gasketing on left and right; Cover at top and bottom PU 2 pieces PU 2 pieces PU 2 pieces PU 1 kit PU 1 kit PU 1 kit 21130-596 21130-597 21130-598 21130-624 21130-618 21130-622 21130-596 21130-597 21130-598 21130-625 21130-619 21130-626 01013006 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 7 8 42 47 2000 2200 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.221 Cabinets – Varistar ServicePLUS containment Covers beside 19" plane, 800 mm, with adapter bracket for reduced width Main Catalogue Order Information Cover, beside 19" plane, 800 mm cabinet width for 70 mm for 145 mm for 220 mm recessed recessed recessed 19" plane 19" plane 19" plane Cover with lateral cut-outs for 70 mm recessed 19" plane for 145 mm recessed 19" plane for 220 mm recessed 19" plane Tex t 01012055 Cover left, right, at top and bottom 01012054 Cover with cable routes left and right; cover closed top and bottom 01013006 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 2 3 7 42 47 8 1.222 2000 2200 SCHROFF PRODUCT CATALOG E 03/2017 PU 1 kit PU 1 kit PU 1 kit PU 1 kit PU 1 kit PU 1 kit 21130-627 21130-631 21130-633 21130-629 21130-620 21130-623 21130-628 21130-632 21130-634 21130-630 21130-621 21130-635 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Covers with cable ducting, cable finger, cable channel Main Catalogue Order Information Covers beside 19" plane, 800 mm cabinet width, with cross member Cover, solid Cover with cable ducting openings Cover with cable fingers for 220 mm recessed 19" plane Cover with cable channels Cable panel Lateral cable ducting Tex t 01015054 01015055 Cover with cable ducting left and right; cover at top, bottom solid, for 19" planes recessed to different depths (25 mm increments) 01012056 Support with cable fingers and front covers 01012077 01012078 St, 1 mm, St, width 150 mm; with cable with perforations channel and hinged front cover for cable ties or Velcro-type tape 01013006 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 42 2000 6 7 8 47 2200 SCHROFF.PENTAIR.CO.UK PU 1 kit PU 1 kit PU 1 kit PU 1 kit PU 2 pieces 23130-550 23130-558 21130-636 21130-638 23130-421 23130-551 23130-559 21130-637 21130-639 23130-422 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.223 Cabinets – Varistar ServicePLUS containment 19" plastic front panels, lateral panels Main Catalogue Order Information Closure for cut-outs in covers 19" plastic panels 19" brush strip Lateral panel Depth offset 70 mm Depth offset 145 mm Tex t 01012079 ABS, UL 94 V-0, clips in 01013006 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 7 42 47 8 1.224 2000 2200 01012080 To close the open for sealing the cable routes open cable in lateral ducting openings panels of the lateral trim; 6 brushes, sufficient for 3 cutouts SCHROFF PRODUCT CATALOG E 03/2017 01012057 Al, 2 mm Plastic Lateral panel for unequal 19" mounting depths PU 10 pieces PU 6 pieces 1 piece 1 piece D19BPT1RU 23130-153 21130-640 21130-642 D19BPT1RU 23130-153 21130-641 21130-643 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Airflow for side-to-side-cooled switches Order Information Basic kit for Cisco switches Air circulation from right to left Side trims for Cisco switches Switch 4503 Switch 4506 Switch 4507 Switch 4510 Switch 6506 Switch 6509 Switch 6513 Te xt 01013060 01012051 AlZn, 1 mm; multiple side plates can be fitted one above another; in all cases only one basic kit is required Bezels, top cover and base plate for Cisco side trims 01013006 Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover For cabinet height H No. U 3 7 8 42 47 mm 2000 2200 PU 1 kit SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 21130-646 23130-490 23130-491 23130-492 23130-493 23130-494 23130-495 23130-496 21130-647 23130-490 23130-491 23130-492 23130-493 23130-494 23130-495 23130-496 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.225 Cabinets – Varistar ServicePLUS containment Separating walls, gasketing kits Order Information Separating wall Cabinet depth 1000 mm Vertical gasket Horizontal gasket Cabinet depth 1200 mm For 600 mm wide cabinets For 800 mm wide cabinets Tex t 01012058 St, 1 mm; lateral cabinet mounting, prevents unauthorised access 01012081 PUR flexible foam, colour similar to RAL 7021, UL 94-HF1; for vertical sealing between 10 cabinets, also suitable for base/plinth and to raise top cover 01012082 2 x bracket, St, RAL 7021; PUR flexible foam seal, colour similar to RAL 7021, UL 94-HF1; suitable for horizontal sealing of 2 cabinets to bottom, when adjustable feet are used 01013006 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 7 42 47 8 1.226 2000 2200 SCHROFF PRODUCT CATALOG E 03/2017 1 piece 1 piece PU 1 kit PU 1 kit PU 1 kit 23130-480 23130-481 23130-475 23130-477 23130-478 23130-484 23130-485 23130-475 23130-477 23130-478 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Configuration of SHX 30 air/water heat exchanger Order Information Frame 1000 mm deep SHX 30 air/water heat exchanger, 30 kW 1200 mm deep Water connection at bottom 01013068 Water connection at top and bottom (with condensate pump) 01013076 Rack (VARISTAR Slim-Line), St, RAL 7021; top cover and base plate, front and rear panel; prepared to accommodate SHX 30 air/water heat exchanger 01013077 2 PSUs, redundant power supply 1 PSU 2 PSUs, redundant power supply 01013005 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 42 2000 6 7 8 47 2200 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 10130-226 10130-227 60714-067 60714-068 60714-077 60714-078 10130-228 10130-229 60714-067 60714-068 60714-077 60714-078 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.227 Cabinets – Varistar ServicePLUS containment Configuration of SHX 30 air/water heat exchanger Order Information Gasketing for adjustable feet Base/plinth Side trim for base/plinth Depth 1000 mm Depth 1200 mm min. 2 max. 22 Adjustable feet D 01013069 St, black, for the rack, static loadcarrying capacity 1000 kg. Please order gasketing separately 01013070 100 100 D 300 01013071 Base plinth, St, Polyurethane cover, St, 1.5 mm, gasketing, suitable for front height 100 mm, width 300 mm, and rear, RAL 7021; for closing RAL 7021; please order cover the air gap at the separately front 01013072 St, 1.5 mm, height 100 mm, RAL 7021 01013005 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 2 3 7 42 47 8 1.228 2000 2200 SCHROFF PRODUCT CATALOG E 03/2017 PU 4 pieces PU 2 pieces PU 1 kit PU 2 pieces PU 2 pieces 23130-511 23130-538 23130-507 23130-172 23130-363 23130-511 23130-538 23130-507 23130-172 23130-363 ELECTRONICS PROTECTION Cabinets – Varistar ServicePLUS containment Configuration of SHX 30 air/water heat exchanger Order Information Screw-fixed side panel Depth 1000 mm Separating wall Depth 1200 mm Cabinet depth 1000 mm Cabinet depth 1200 mm 01013073 St, 1 mm, incl. GND/earthing 01013074 St, 1 mm, AlZn; lateral cabinet mounting prevents unauthorized access 01013005 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 2108 Base/plinth 4 2192 Base/plinth + raised top cover 5 2218 Adjustable feet 6 2302 Adjustable feet + raised top cover 2308 Base/plinth 2392 Base/plinth + raised top cover 3 7 8 42 47 2000 2200 SCHROFF.PENTAIR.CO.UK PU 2 pieces PU 2 pieces 1 piece 1 piece 21130-013 21130-535 23130-480 23130-481 21130-018 21130-537 23130-484 23130-485 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.229 Cabinets – Varistar ServicePLUS containment Configuration of SHX 30 air/water heat exchanger Order Information Top cover 300 mm width Raised top cover 01013079 Assembly kit 01012051 01012052 St, 2 mm, RAL 7021, aisle width 1200 mm Al extrusion, RAL 7021, length 2400 mm, height 84 mm Mounting of top cover raising profile 1 piece PU 2 pieces PU 6 pieces – – 21130-594 23130-433 – – 01013005 For cabinet height H No. U mm Aisle height (lower edge) mm Raising elements 1 2018 Adjustable feet 2 2102 Adjustable feet + raised top cover 3 42 2000 21130-648 2108 Base/plinth 4 2192 Base/plinth + raised top cover 21130-594 23130-433 5 2218 Adjustable feet – – 6 2302 Adjustable feet + raised top cover 21130-594 23130-433 – – 21130-594 23130-433 7 8 47 2200 2308 Base/plinth 2392 Base/plinth + raised top cover SCHROFF.PENTAIR.CO.UK 21130-648 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.230 Cabinets – Varistar ServicePLUS containment SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.231 Varistar cabinet-based and row-bas ed coolingMai n C atalogue Cabinets – Varistar cabinet-based and row-based cooling Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 01017025 \ Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 01013005 Front bottom or bottom/top water connection, easy access and greatest possible safety Applications The future for data centers The SHX 30 heat exchanger is especially suitable for use in the following areas: 쮿 Data centers 쮿 19" and blade-server applications Connectors, front panel component system . . . . . . . 11 쮿 Systems with extremely high heat dissipation Appendix . . . . . 12 1.224 01017015 Electronic monitoring unit with display and interfaces SCHROFF PRODUCT CATALOG E 06/2016 01013005 Six powerful, temperaturecontrolled fans. Easy access for maintenance purposes during operation VARISTAR LHX+, the space-independent complete cabinet system for dissipating up to 34 kW of heat. The air/water heat exchanger is installed in the cabinet as complete unit on the left or right side. The horizontal air flow provides for uniform air dissipation over the entire cabinet height. 01017060 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling Overview . . . . . . 1.224 Varistar cabinet-based and row-based coolingMain Catalogue VARISTAR LHX+ with air/water heat exchanger for data centers 쮿 Cooling capacity up to 34 kW VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Complete cabinet solution, static load capacity up to 1600 kg 쮿 Space-independent cooling, high energy efficiency 쮿 Water and air circuits are temperature controlled 쮿 Low noise level 쮿 Fans may be changed individually while the unit is operating With single door VARISTAR SHX+, single door . . . . . . 1.230 VARISTAR SHX+, double door . . . . . 1.231 With double door 01017003 쮿 Cooling capacity up to 34 kW (heat exchanger on left or right) 쮿 Cooling capacity up to 34 kW (heat exchanger on left or right) 01017007 Accessories 쮿 Management system for monitoring LHX+ and other cabinet parameters Accessories Heat exchangers . 1.232 Rack for heat exchanger . . . . . . . 1.234 Adjustable feet . . . 1.235 Base/plinth . . . . . . 1.236 00711020 ServicePLUS e.g. other cabinet dimensions e.g. side-by-side mounting solutions e.g. containment (cold aisle) e.g. custom solutions (special sizes) www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . . 1.124 1.225 Cabinets – Varistar cabinet-based and row-based cooling Varistar cabinet-based and row-based coolingMAIN CATALOG P art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days Optimum temperature for air/water heat exchanger Since the thermal load continues to increase, conventional cooling methods eventually reach their physical limits. It can happen that thermal load limits within a cabinet are such that some height units must go unused. ADVANTAGES The solution: Air/water heat exchangers installed close to the heat source not only increase the cooling capacity per cabinet, but also improve the redundancy of the data center. With intelligent control systems, air conditioners can quickly respond to the working load of the equipment, thereby enabling additional savings. 쮿 Highest cooling capacity in the smallest of spaces Text Air/water heat exchangers installed close to the heat source not only increase the cooling capacity per cabinet, but also improve the redundancy of the data center. With intelligent control systems, air conditioners can quickly respond to the working load of the equipment, thereby enabling additional savings. 쮿 Integrated solutions with spaceindependent thermal transfer 쮿 A wide variety of dimensions are supported, short implementation time and low planning effort Thanks to the Ethernet and Modbus connection, Schroff air/water heat exchangers can be monitored and configured. Operating parameters are easy to specify, and temperature, fan speed and error protocols can be managed remotely. Text 01015011 1.226 SCHROFF PRODUCT CATALOG E 06/2016 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling Varistar cabinet-bas ed and row-based coolingMAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days Integrated heat exchanger Heat exchanger mounted side-by-side In this combination, an active heat exchanger integrated into an 800 mm wide cabinet has the lowest space requirement on the market. The closed system reduces the noise level and controls itself by means of the thermal load. With a cooling capacity of up to 34 kW1), the heat exchanger is suitable for HPC applications. Multiple cabinets can be mounted side-by-side to create a closed system. Thanks to the low space requirement, reduced noise level and ease of creating redundancy, this heat exchanger is well suited also for medium-sized data centers. Active heat exchanger for containment systems with a cooling capacity of up to 34 kW1). This in-row heat exchanger is mounted side-by-side to cabinets within the aisle containment. This enables optimal scalability with regard to planning for the cooling capacity and the redundancy of the system. Text 01017009 LHX+ cabinets mounted side-by-side with integrated heat exchangers 01013005 SHX 30 in-row heat exchanger Integrated heat exchanger: Cooling capacity Dimensions Functions In-row heat exchanger: Cooling capacity Dimensions Functions Up to 34 kW1) Width 800 mm Height 2100 mm Depth 1000 to 1200 mm IP 55 protection on request EMC design on request 1600 kg static load capacity Bottom/top water connections Control system options with an external temperature sensor (Display in four languages) Up to 34 kW Width 300 mm Height 2000 to 2200 mm Depth 1000 to 1200 mm Water connections from bottom/top Control system options with an external temperature sensor Display in four languages 1) Cooling capacity 34 kW at +12 °C water flow temperature, +24 °C cold air temperature, 4.5 m³/h water flow rate; for other conditions refer to the diagram for the cooling capacity SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.227 Cabinets – Varistar cabinet-based and row-based cooling Space-saving, low-noise and energy-efficient Highly efficient and noise-optimized Text The Varistar heat exchanger range impresses customers with its high energy efficiency and cooling capacity. Failure safety and ease of servicing play a special role. The unit itself is designed for long life. Sensitive components with a low MTBF have been consistently dispensed with and necessary wear parts are treated carefully during operation. Fans are positioned in the cold area to significantly increase the service life of the bearings compared to operation in a warm-air area. Additionally, the heat exchanger is equipped as standard with a droplet separator and a condensate management system to prevent the formation of water droplets in the air entry area to the server. Compelling use of space Since the heat exchanger is inserted on one side as a complete module, in a cabinet only 800 mm wide, the 19" plane can be used over its full height, with 42 U (max. 52 U). This saves valuable space in the data center! 01017061 01017060 IN-ROW heat exchanger to cool your indoor aisle containment This in-row heat exchanger is specially designed to cool cabinets with high thermal loads within an aisle containment structure and is included in the row as a modular unit. Depending on the packaging density, you can scale the units optimally and implement redundancy. 26° C 01012083 1.228 SCHROFF PRODUCT CATALOG E 06/2016 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling One heat exchanger for multiple cabinets Redundancy from side-by-side mounting The option of mounting the cooling unit to the left or right of the 19" plane means it is easy to build very variable cooling systems from multiple cabinets. If the full cooling capacity is not needed initially, one unit can supply cold air to multiple cabinets mounted side-by-side. In cabinets mounted side-by-side, the space for the cooling unit is closed with an air baffle. If the necessary cooling capacity increases, the air baffle is removed and an additional cooling unit is inserted. Redundant systems are also very easy to implement. If two cabinets are mounted side-by-side with one heat exchanger each, one unit can take over the cooling of both cabinets up to half of the max. cooling capacity per cabinet. Text 01017015 01017015 One heat exchanger for multiple cabinets For installation and maintenance, the air conditioners of the Varistar series have a very service-friendly design. The water connections are easy to access. Fans can be changed individually and very quickly while the unit is operating. However, if a defined threshold value does arise, either in the cabinet or in the unit itself, each heat exchanger will provide valuable information for maintenance and service work. Fan speeds and temperatures at various positions in the cooling circuit are measured via integrated communication interfaces and can be shown on a display. However, all information (measured values, threshold values, etc) can also be transferred directly into the network management system. Text 쮿 Display 쮿 Bottom or top and bottom water connections 쮿 Hot-swap-capable fans 쮿 Power supplies 쮿 Communication interface 쮿 External temperature sensor 쮿 Interlog interface 01017015 SCHROFF.PENTAIR.CO.UK 01013005 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.229 Cabinets – Varistar cabinet-based and row-based cooling VARISTAR LHX+, cabinet with single door, integrated air conditioner Varistar cabinet-based and row-based coolingMAIN CATALOG P art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Cabinet with air/water heat exchanger with cooling capacity of 34 kW 쮿 Max. static load capacity 1600 kg 쮿 Gasket all around reduces noise and suction of room air Delivery includes (Fully assembled and grounded) Item 1 Qty. 1 2 1 3 1 4 1 5 6 2 1 7 1 8 4 9 2 10 11 4 1 12 13 14 1 1 1 01017003 Description Welded basic frame, Slim-Line, St profile, zinc-plated, RAL 7021, with gasket all around Flat roof, St, RAL 7021 with cable entry point in rear with brush, entry point for water connection in rear, entry points can be sealed with a gasket/cover plate Front door glazed, St frame, RAL 7021, single-pane safety glass 6 mm, 3 x 180° hinge, three-point closure, pivoting lever handle for optional DIN profile half cylinder Rear door, St, RAL 7021, 3 x 180° hinge, three-point closure, pivoting lever handle for optional DIN profile half cylinder Side panel, screwed, St, RAL 7021 Baseplate, St, RAL 7021 with cable entry point in rear with brush, entry point for water connection in rear, entry points can be sealed with a gasket/cover plate Base/plinth 100 mm, with additional center crossmember, St, RAL 7021, removable covers, integrated adjustable feet 19" panel/slide mount with EIA cut-outs, St, RAL 7021, 225 mm recessed in front, c dimension 740 mm distance between front and rear 19" plane Support rail for connecting the air/water heat exchanger and 19" panel/slide mounts, St, RAL 7021 Air baffle, St, RAL 7021 SHX 30 air/water heat exchanger, RAL 7021, 100 to 240 VAC, may be mounted on the left or right, see Order Information Power cable, length 1.5 m Connecting cable for management unit User manual (for online download) Order Information Height U mm 42 2100 42 2100 Width mm 800 800 Depth mm 1200 1200 Heat Water Power exchanger connection supply Left Right Top Top Top and bottom Top and bottom 42 2100 800 1200 Left 42 2100 800 1200 Right Part no. 1 1 10130-300 2 redundant 10130-302 2 redundant 10130-303 Accessories Lifting eye for top cover PU 4 pieces Electronic closing (MLR3000), 13.56 MHz-MIFARE With reader, 1 set Electronic locking (MRL3000), Mifare With reader, 1 set 10130-301 23130-072 23130-513 23130-565 Note 01017059 1.230 SCHROFF PRODUCT CATALOG E 06/2016 쮿 34 kW cooling capacity at +12 °C water flow temperature, +24 °C cold air temperature 쮿 Other dimensions on request ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling VARISTAR LHX+, cabinet with double door, integrated air conditioner MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 Cabinet with air/water heat exchanger with cooling capacity of 34 kW 쮿 Max. static load capacity 1600 kg 쮿 Separate front and rear access doors for air/water heat exchanger 쮿 Gasket all around reduces noise and suction of room air Delivery includes (Fully assembled and grounded) Item Qty. 1 1 01017007 2 1 3 1 4 1 5 6 2 1 7 1 8 4 9 2 10 11 4 1 12 13 14 1 1 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, RAL 7021, with gasket all around Flat roof, St, RAL 7021 with cable entry point in rear with brush, entry point for water connection in rear, entry points can be sealed with a gasket/cover plate Front door, divided asymmetrically, RAL 7021, 3 x 180° hinges, three-point closure, pivoting lever for optional DIN profile half cylinder; in front of the 19" plane, 600 mm, St frame, glazed, singlepane safety glass 6 mm, in front of the heat exchanger, 200 mm, St, with viewing window, single-pane safety glass 6 mm Back door, divided asymmetrically, St, RAL7021, 3 x 180° hinges, three-point closure, pivoting lever for optional DINprofile half cylinder; in front of the 19" plane, 600 mm, in front of the heat exchanger, 200 mm Side panel, screwed, St, RAL 7021 Baseplate, St, RAL 7021, cable entry point in rear, entry point for water connection, entry points can be sealed with gasket/cover plate Base/plinth 100 mm, with additional center crossmember, St, RAL 7021, removable covers, integrated adjustable feet 19" panel/slide mount with EIA cut-outs, St, RAL 7021, 225 mm recessed in front, c dimension 740 mm distance between front and rear 19" plane Support rail for connecting the air/water heat exchanger and 19" panel/slide mounts, St, RAL 7021 Air baffle, St, RAL 7021 SHX 30 air/water heat exchanger, RAL 7021, 100 to 240 VAC, may be mounted on the left or right, see Order Information Power cable, length 1.5 m Connecting cable for management unit User manual (for online download) Order Information Height U mm 42 2100 42 2100 01017058 Width mm 800 800 Depth mm 1200 1200 Heat Water Power exchanger connection supply Left Right Top Top Top and bottom Top and bottom 42 2100 800 1200 Left 42 2100 800 1200 Right Part no. 1 1 10130-304 2 redundant 10130-306 2 redundant 10130-307 Accessories Lifting eye for top cover PU 4 pieces Electronic closing (MLR3000), 13.56 MHz-MIFARE With reader, 1 set Electronic locking (MRL3000), Mifare With reader, 1 set 10130-305 23130-072 23130-513 23130-565 Note 쮿 34 kW cooling capacity at +12 °C water flow temperature, +24 °C cold air temperature 쮿 Other dimensions on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.231 Cabinets – Varistar cabinet-based and row-based cooling SHX 30 air/water heat exchanger 쮿 Air/water heat exchanger with cooling capacity of 34 kW1) Main CatalogueMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Water connection at bottom or bottom/top (with condensate pump) 쮿 1 PSU or 2 PSUs (redundant) 쮿 Fans may be changed individually while the unit is operating 쮿 Drop collector and condensate management Delivery includes Item 1 Qty 1 2 3 4 1 1 Description SHX 30 air/water heat exchanger, RAL 7021, 100 ... 240 VAC Mains cable, 1.5 m Connecting cable for management unit User manual (for online download) Order Information 01017026 SHX 30 air/water heat exchanger, 34 kW1) 1 PSU Water connection at 2 PSUs, redundant power bottom supply 1 PSU Water connection at top and bottom (with 2 PSUs, redundant power condensate pump) supply Accessories Cabinet management basic units Height 44 mm, width 251 mm, depth 53 mm, for monitoring one air/water heat exchanger, max. 16 sensor values, 1 piece Cabinet management basic units Height 44 mm, width 440 mm, depth 134 mm, for monitoring up to max. 8 air/ water heat exchangers, max 128 sensor values, 1 piece Capteur de température à raccorder directement au SHX 30, longueur du câble 2 m, 1 pièce Part No. 60714-067 60714-068 60714-077 60714-078 EMX111 EMX888 60130-724 Note Please order optional management unit separately Rear connections at bottom 01013020 Rear connections at top 01013021 쮿 Cabinet management base unit connects via RJ 45 interface 쮿 Web interface – Automatic detection of connected Varistar SHX 30 air/water heat exchanger – Inlet temperature of servers (parameter can be set via web interface) – Switch on/off of cooler – Adjustment of set temperature and fan speed – Air temperature monitoring at front/rear, fan speed and water inlet temperature – Temperature monitoring/control using an external temperature sensor (please order separately) 쮿 1) Cooling capacity 34 kW at +12 °C water flow temperature, +24 °C cold air temperature, 4.5 m³/h water flow rate; for other conditions refer to the diagram for the cooling capacity Management browser representation 1.232 SCHROFF PRODUCT CATALOG E 06/2016 00711017 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling SHX 30 air/water heat exchanger Graph: cold air temperature against cooling capacity MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days Technical data Cooling capacity Useful cooling capacity Normal temperature 1) Cold air temperature 2) Cooling capacity at different cold water temperatures Fan speed 100% Maximum water flow rate 4.5 m3/h 3) Water inlet temperature 01017062 34 kW1) 18 to 50 °C (adjustable in 0.1 °C increments) Max. control deviation of emergency 4 (factory-preset) cooling can be set to 0–8 K relative to the set value Water circuit Cooling medium 2) Water, water-glycol mix (max. 33%) Water inlet temperature 3) 6 to 18 °C Water flow volume up to 4.5 m 3/h Pressure loss in device at 3.0 m3/h, max. 1.3 bar; 4.5 m3/h, max. 3.1 bar Water conduit Copper Water connection inlet/outlet Rp 1" Condensate drain connection Rp 1/2" Air circuit Max. airflow volume, temperature- 5000 m3/h dependent control Electrical data AC Supply voltage (single phase) 100 to 240 VAC (50 / 60 Hz) Max. current consumption 6 A / 12 A (230 V / 115 V) 1100 W / 750 W Max. power consumption fan speed 100% / Normal operation (fan speed 80%) Pre-fuse (on building side) D 10 A / D 16 A (230 V / 115 V) Interface RS 485 Modbus interface Connection option for external monitoring system RS 232 (SUB-D 9-pin) Serial access Input, terminal block with External temperature sensor 10 potential-free contacts connection General data Ambient temperature: Transport, -25 to 70 °C / 5 to 70 °C storage when fully emptied / when containing 35% glycol / in operation outside of the cabinet Relative humidity for transport and 5 to 95% storage (non-condensing) Heat exchanger dimensions Height 1849 mm, width 189.5 mm, depth 850 mm Heat exchanger weight 110 kg Weight of cabinet with cooling 370 kg module approx. 1) Cooling capacity 34 kW at +12 °C water flow temperature, +24 °C cold air temperature, 4.5 m³/h water flow rate; for other conditions refer to the diagram for the cooling capacity 2) To ensure problem-free operation of the air/water heat exchanger the quality requirements of the water must be maintained; the appropriate anti-corrosion and frost protection agents are dependent on the environment in which the unit is used and on the external chiller (VDI 3803, see also user manual). 3) At water inlet temperatures of < 6 °C und > 15 °C, the control accuracy can no longer be guaranteed. There is also a risk of condensation if the water temperature falls short of the given limits. SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.233 Cabinets – Varistar cabinet-based and row-based cooling Rack for SHX 30 air/water heat exchanger Main CatalogueMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Rack (VARISTAR Slim-Line) to accommodate a SHX 30 air/ water heat exchanger 쮿 Height 2000 or 2200 mm 쮿 Depth 1000 or 1200 mm 쮿 Width 300 mm 쮿 Covers top, bottom, front and rear Delivery includes Item 1 Qty 1 2 1 3 4 5 1 1 1 2 1 3 Description Welded basic rack (Slim-Line) from steel profiles, RAL 7021; earthing stud Flat top cover, St, RAL 7021; with brush strip cut-out (for water) and on the side for cable ducting Front frame, St, RAL 7021 Rear cover, perforated, lockable Base plate, St, RAL 7021; with brush strip cut-out (for water) and on the side for cable ducting Order Information 4 5 01013068 01013080 01013022 Water enters via brush strips; lateral cable ducting for power/data cables 1.234 SCHROFF PRODUCT CATALOG E 06/2016 Height Width Depth mm mm mm 2000 300 1000 2000 300 1200 2200 300 1000 2200 300 1200 Accessories Adjustable feet for the frame, RAL 7021, static loadcarrying capacity 1000 kg, PU 4 pieces Gasketing for adjustable feet Polyurethane foam gasketing, color similar to RAL 7021, length 300 mm, for sealing front and rear, PU 2 pieces Base/plinth Base plinth, St, width 300 mm, height 100 mm; bolts on to rack, PU 2 pieces Side trim St, 1.5 mm, height 100 mm, depth 1000 mm, PU 2 pieces Side trim St, 1.5 mm, height 100 mm, depth 1200 mm, PU 2 pieces Side panel, screw-fixed for IP 55 St, 1 mm, height 2000 mm, depth 1000 mm, 2 pieces Side panel, screw-fixed for IP 55 St, 1 mm, height 2000 mm, depth 1200 mm, 2 pieces Side panel, screw-fixed for IP 55 St, 1 mm, height 2200 mm, depth 1200 mm, 2 pieces Side panel, screw-fixed for IP 55 St, 1 mm, height 2200 mm, depth 1200 mm, 2 pieces Separating wall St, 1 mm, AlZn, height 2000 mm, for depth 1000 mm, 1 piece Separating wall St, 1 mm, AlZn, height 2000 mm, for depth 1200 mm, 1 piece Separating wall St, 1 mm, AlZn, height 2200 mm, for depth 1000 mm, 1 piece Separating wall St, 1 mm, AlZn, height 2200 mm, for depth 1200 mm, 1 piece Part no. 10130-226 10130-227 10130-228 10130-229 23130-511 23130-538 23130-507 23130-172 23130-363 21130-013 21130-535 21130-018 21130-537 23130-480 23130-481 23130-484 23130-485 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling Adjustable feet Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Adjustable feet for direct mounting onto frame 쮿 Static load-carrying capacity 1000 kg Delivery includes Item 1 2 Qty 4 1 Description Adjustable feet, St, polyamide, black Fixing materials kit Order Information MRA44483 Description Adjustable feet Accessories Gasketing for adjustable feet Polyurethane foam gasketing, color similar to RAL 7021, length 300 mm, for sealing front and rear, PU 2 pieces Part no. 23130-511 23130-538 Gasketing for adjustable feet Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 For horizontal sealing at bottom in containments (front and rear) where adjustable feet are used Delivery includes Item 1 Qty 2 Description Gasketing, flexible polyurethane, length 300 mm, color similar to RAL 7021, conforms to UL 94-HF1 Order Information Description Gasketing for adjustable feet Part no. 23130-538 01013070 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.235 Cabinets – Varistar cabinet-based and row-based cooling Base/plinth Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Base for 300 mm wide frame (air/water heat exchanger) 쮿 Base is bolted to the frame at front and rear; please order side trims separately Delivery includes D Item 1 Qty 2 2 1 Description Base, St, 1.5 mm; with built-in feet, width 300 mm, color RAL 7021 Fixing materials kit 100 Order Information 300 01013071 Base/plinth Height Width mm mm 100 300 Accessories Side trim RAL 7021, St, 1.5 mm, height 100 mm, depth 1000 mm, PU 2 pieces Side trim RAL 7021, St, 1.5 mm, height 100 mm, depth 1200 mm, PU 2 pieces Part no. 23130-507 23130-172 23130-363 100 D Accessories: Side covers 01013072 Top cover element for aisle containment (SHX 30 air/ water heat exchanger) Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Suitable for an aisle width of 1200 mm 쮿 Width 300 mm (when fitting directly beside the "Sliding door, mechanical" a 200 mm width must be used) 쮿 Top cover can be removed from inside (allows access to lighting and facilitates maintenance works) 쮿 The universal top cover profile enables the aisle height to be raised by 84 mm and cabinets with other heights can also be integrated. Please order separately Width 300 mm 01013079 Delivery includes Item 1 2 Qty 1 1 Description Top cover, St, 2 mm, RAL 7021, plate length 1200 mm Fixing materials kit Order Information Width Description mm 300 For cabinet width 300 mm (aisle width 1200 mm) Accessories Raised top cover Al extrusion, RAL 7021, length 2400 mm, height 84 mm, PU 2 pieces; raises top cover elements by 84 mm and allows integration of cabinets with other heights Assembly kit Mounting of top cover raising profile, PU 6 pieces 1.236 SCHROFF PRODUCT CATALOG E 06/2016 Part no. 21130-648 21130-594 23130-433 ELECTRONICS PROTECTION Cabinets – Varistar cabinet-based and row-based cooling Management for SHX 30 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Connection of cabinet management basic unit with RJ 45 interface 쮿 Automatic detection of the connected LHX 20/40 air/water heat exchangers 쮿 Monitored parameters: – Inlet temperature of servers (parameter can be set via web interface – Air temperature front (2 parameters) – Air temperature rear (2 parameters) – Fan speed (6 parameters for LHX 20, 7 parameters for LHX 40) – Water inflow temperature (1 parameter) Note 00711017 Browser display 쮿 For cabinet management base unit see page 3.46 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors see from page 3.47 1 LA N 4 2 3 EMX -111 00711020 01011051 5 1 4 LA N 2 3 EMX -888 Item 1 2 3 4 5 01011050 01011050 Description Real-time monitoring of web graphical user interface (GUI) EMX LHX 20/40 Telemonitored temperature and humidity sensors Cabinet management base unit SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.237 VARISTAR LHX 3 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Cabinets – VARISTAR LHX 3 Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 01008029 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 01007010 Air/water heat exchanger in base/ plinth - Extractable - Water connection from rear, optionally from front - Cable ducting to rear, can be sealed with slide covers Advantages: By separating the heat exchanger (in the base/plinth) from the fan (in the top cover), the cold air flows evenly through the cabinet. Reflowing of the warm air to the heat exchanger through channels in the side panels. Applications: Measuring and test devices in industrial areas, e.g.: - Temperature sensitive precision measurements - Engine and transmission test bench Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01007014 Top cover with fan - Fan unit in top cover - Airflow through channels in side panel - Easy maintenance and exchange 01007055 Appendix . . . . . 12 1.236 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR LHX 3 Overview . . . . . . 1.236 VARISTAR LHX 3Mai n C atalogue Air/water heat exchanger for measuring and test equipment 쮿 Complete cabinet to protection class IP 55 with heat exchanger in base/plinth and fan tray in top cover 쮿 Even circulation of cold air within the cabinet, no air short circuits as with side-by-side mounted units VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Cooling capacity up to 3 kW 쮿 Very low noise level of 45 dB(A) VARISTAR LHX 3 \ VARISTAR LHX 3 . 1.238 쮿 Air/water heat exchanger in base/plinth 쮿 Airflow through channels in side panel 쮿 Leakage safety 01007015 VARISTAR LHX 19" chassis, available on request 쮿 Air/water heat exchanger as 19" chassis 쮿 Airflow through channels in rear door (cabinets may be mounted side-by-side) 쮿 Devices with different airflows may be used (e.g. from left to right or from front to rear) 쮿 Variable air outlet in 19" chassis, thus selective direction of cold air 01008088 ServicePLUS e.g. climate control, complete assembly, cabling (power supply), function test e.g. delivery to point of use, erection service, commissioning, replacement service, maintenance, repairs, replacement parts e.g. custom solutions (special sizes) 30407004 SCHROFF.PENTAIR.CO.UK www.schroff.biz/ServicePLUS VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC. . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . . 1.124 1.237 Cabinets – VARISTAR LHX 3 VARISTAR LHX 3 VARISTA R LHX 3 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Cabinet in accordance with protection class IP 55, RAL 7021, with glass front door 쮿 Air/water heat exchanger (3 kW) in base/plinth (extractable) 쮿 Very low noise level of 45 dB(A) 쮿 Static load-carrying capacity 800 kg (Heavy-Duty frame) Delivery comprises (completely assembled and earthed) Item 1 Qty 1 2 3 1 1 4 1 5 1 6 7 2 1 8 4 9 1 10 1 01007015 2 3 Description Welded basic frame, Heavy-Duty, St profile, zinc-plated, RAL 7021, IP 55, with all-round gasket Flat top cover, St, RAL 7021 Radial fan, 230 VAC, assembled on cross member, SCHUKO/UTE connector, cable length 1.5 m Front door, glass, frame RAL 7021, 180° hinge, multi-point locking, lever handle for optional DIN profile half cylinder Rear door, St, RAL 7021, 180° hinge, multi-point interlocking, lever handle for optional DIN profile half cylinder Side panel, screwed, St, RAL 7021, with ventilation duct Base/plinth with base plate, St, RAL 7021, height 200 mm, removable covers at front and rear, integrated feet; cable ducting to rear, can be sealed with slide covers 19" panel/slide mount with EIA cut-outs, St, RAL 7021, 175 mm recessed at front, 500 mm distance between front and rear 19" plane Air/water heat exchanger, 3 kW, RAL 7021; integrated in base/plinth, extractable User manual Order Information 5 Height Usable height Width Depth mm U mm mm 2000 34 600 800 2200 38 600 800 DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Thermostat with mains/line connector, 230 VAC, SCHUKO/ UTE connector, IEC-320 female connector, 1 piece 1 8 4 Part no. 10130-193 10130-194 25127-995 20118-750 Note 쮿 Further dimensions and versions available on request (e.g. with heat exchanger as 19" chassis or with airflow in the rear panel) 쮿 Technical data see page 1.239 6 7 9 01007061 1.238 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR LHX 3 Technical data LHX 3 Technical data LHX 3 Cooling capacity Usable cooling capacity (cooling water inlet temperature 10° C, air exit temperature 20° C) 01007055 A fan sucks in the warm air at the top and leads it downwards through the lateral air channels in the side panels to the air/water heat exchanger. The cold air is let into the cabinet at the bottom. Water circuit Cooling medium 1) Water inlet temperature 2) Water flow volume Max. water pressure Static pressure loss in device at 0.5 m3/h Water conduit Water connection inlet/outlet Connection condensat drain Water 6 ... 16 °C up to 2.0 m3/h 6 bar 0.1 bar Copper Rp 1/2" Ø 10 mm Air circuit Airflow volume 900 m 3/h Electrical data Supply voltage, single phase Current consumption Power consumption Apparent power at full load Protection fuse 230 VAC, 50/60 Hz 0.38 A 85 W 120 VA 2A General Data Cabinet type of protection Ambient temperature during transport Ambient temperature outside of cabinet (during operation) Relative humidity level Noise level at 100 % fan performance Weight: cabinet/heat exchanger Dimensions of air/water heat exchanger Height Width Depth Diagram of LHX 3 characteristics Usable cooling capacity in kW 3 KW IP 55 -25 ... 70 °C 5 ... 70 °C 5 ... 95 % 45.2 dB(A) approx. 115 kg/35 kg 199 mm 464 mm 425 mm (465 mm with handles) 1) For an optimal operation of the air/water heat exchanger the demands on the water quality have to be fulfilled (VDE 3803, please see user manual) 2) If the water inlet temperature falls short of 16 °C the formation of condensation should be anticipated kW 3,0 l VH2O = 400 /h 2,9 2,8 2,7 2,6 2,5 2,4 8 10 12 Incoming water temperature SCHROFF.PENTAIR.CO.UK 14 16 18 °C 01007076 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.239 N ovastarMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days Cabinets – Novastar Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 07011036 Light - slim - robust The base frame, made in lightweight aluminium, is the basis for your individual NOVASTAR. And now you decide: small or large, in standard depth or with extended space for cabling and heat dissipation, whether as a stand-alone solution or stacked one on top of another and bolted together. The NOVASTAR platform concept leaves no wish neglected. And regardless of how you put your NOVASTAR together, the internal dimensions remain consistently compatible with 19" technology. Unwanted spaces in either height or width are now a thing of the past. With a cabinet width of only 553 mm, NOVASTAR is the slimmest of all 19" cabinets. It has a slender, filigreed look, almost like a piece of designer furniture. This impression is further reinforced by the different finishes of the frame and cover trim and the plain, modern fullglass doors. Because of this, NOVASTAR is not only used in offices and laboratories but also in sound and TV studios. And indeed as a collector's item in the occasional home! Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 07011023 Backplanes . . . 10 Simple fitting of side panel without tools 07011025 07011020 07011022 07011007 Door with 180° opening angle thanks to new hinge concept; can be mounted left or right Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 07011028 Extensive selection of castors 1.240 SCHROFF PRODUCT CATALOG E 06/2017 Heavy-Duty frame with lateral groove for mounting e.g. of carrier arm systems ELECTRONICS PROTECTION Cabinets – Novastar Overview . . . . . . 1.240 Novastar Main CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days The inNOVAtive 19" electronics cabinet 쮿 쮿 쮿 쮿 쮿 Type of protection up to IP 40 Bolted, die-cast frame with Al extrusions Cabinet width only 553 mm Static load-carrying capacity up to 400 kg Colours: RAL 7021 or colour combination RAL 7021/ RAL 7035 19" cabinet, with glass door (smoke grey) and rear panel Dimensions . . . . . . 1.243 19" cabinet, door and rear panel combination freely selectable NOVASTAR 19" cabinet with smoke tintend glass door and rear panel . . . . . . . 1.246 Selectable combination of 19" cabinet, door and rear panel . . . . . . . 1.247 Accessories 07011010 07011013 쮿 Height of Slim-Line 12 ... 20 U (load-carrying capacity 200 kg) 쮿 Height of Slim-Line 9 ... 25 U (load-carrying capacity 200 kg) 쮿 Height of Heavy-Duty 38 ... 43 U (load-carrying capacity 400 kg) 쮿 Height of Heavy-Duty 34 ... 47 U (load-carrying capacity 400 kg) 쮿 Depth 600, 800 mm 쮿 Depth 500, 600, 800 mm 쮿 Door and rear panel can be equipped individually Doors and cable ducting systems . . . . . . . . . 1.247 Rear panels and cable ducting systems . . . . . . . . . 1.251 Base plates . . . . . . 1.252 Castors . . . . . . . . . . 1.253 Bases/plinths . . . . 1.254 19" panel/slide mounts . . . . . . . . . . 1.255 Depth members . . 1.255 Slide rails . . . . . . . . 1.256 Shelves . . . . . . . . . 1.258 Support arm system . . . . . . . . . . 1.260 Slide nut . . . . . . . . . 1.260 Standards/Approvals 쮿 External and internal dimensions in accordance with IEC 60297-3-100 쮿 Type of protection IP 40 in accordance with IE 60529 쮿 Earth connections in accordance with DIN EN 50178 / VDE 0160 ServicePLUS from page 1.261 ServicePLUS . . . 1.261 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. custom solutions (cut-outs) e.g. variants of uprights (Slim-Line, Heavy-Duty) e.g. custom solutions (special sizes) 30407004 SCHROFF.PENTAIR.CO.UK www.schroff.biz/ServicePLUS 1.241 Cabinets – Novastar Novastar configurator NovastarMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shipping within 10 working days With the Schroff brand, Pentair offers a wide range of electronics cabinets and other electronic protection products. Instead of restricting the range to a few standard products, Schroff offers bespoke solutions which fulfill the specific requirements of the application. Schroff configurations are easy-to-operate tools which make it possible to configure and modify products quickly and easily: Design Your Standard. The Novastar configurator is a web-based tool with an intuitive graphical user interface and multilingual menus in English, German, and French. These make configuring Novastar cabinets quick and easy. Individual solutions are just a click away 쮿 Configurations can start with the frame or by modifying readyconfigured or previously configured Novastar cabinets 쮿 Large selection of dimensions, frame types, door types, side panels, top covers, and base plates 쮿 Accessories such as shelves and slide rails can be mounted 쮿 Selection of special cabinet colors 쮿 Cutouts incorporated for switches and connectors or logos, text, and other graphics printed 07017001 Real-time 3D CAD model generation 쮿 Real-time display of configured cabinets with all modifications in several views and adjustable transparency 쮿 The configuration adjusts in real time and offers different mounting options 쮿 Real-time generation of 3D CAD models and/or 2D native CAD files in more than 30 CAD file formats for downloading or for immediate further processing and integration into the user's CAD software 쮿 Real-time generation of a bill of materials with all components of the configured cabinet 쮿 Quotes issued quickly for customized Novastar cabinets and an inquiry is simply a click away Ease of use 쮿 Graphical user interface with drag-and-drop functionality and immediate display of the selected configuration 쮿 Available components are listed as illustrations in the menu for quick access and easy identification 쮿 Intelligent configurator logic indicates where components can be installed, ensures compatibility and shows relevant optional components 쮿 The "U" height scale helps you to position the components correctly 쮿 Components identified with mouse-over functionality 쮿 Components exchanged using simple drag-and-drop functionality or deleted in the bill of materials 쮿 Non-assembled accessories can be added to the bill of materials 쮿 No need to download any programs or apps, or install any software or plug-ins No registration required 쮿 The optional, free user account registration provides access to additional functions 1.242 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Dimension drawings Slim-Line frames Frame 451 451 10 465 84, 5 8 h H 465 553 D 07011094 Frame (top view) 07011093 Main Catalogue 쮿 Lightweight aluminium die-cast frame and lightweight vertical profile 553 467 쮿 Static load-carrying capacity 200 kg, tested in accordance with IEC 61587-1 d Cabinet height U 6 9 12 16 20 25 34 38 43 47 Foot height 8 mm d1 56 33 64 c 56 d1 D 106 60 Frame dimensions Ø8 451 465 w 451 465 w H mm 357 456 589 767 945 1167 1567 1745 1967 2145 h mm 268 401 535 713 890 1112 1513 1690 1913 2090 07011098 Upright at front/rear 50,5 Upright at rear 50,5 30 Frame dimensions Cabinet depth 7 M8 12 19" to 19" plane Floor mounting c mm 407 507 707 807 907 d1 mm 319 419 619 719 819 w mm 515 515 515 515 515 12 07011096 SCHROFF.PENTAIR.CO.UK D mm 500 600 800 900 1000 Adjustable feet, castors, lifting eye, top cover fixing d mm 405 505 705 805 905 19,5 36 33 19,5 36 60 7 84,5 M8 84,5 10 10 30 07011097 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.243 Cabinets – Novastar Dimension drawings Heavy-Duty frames Frame 19" upright 451 451 465 h H 75 84, 8 465 10 553 D 07011095 Frame (top view) 07011092 쮿 Light aluminium die-cast frame and robust vertical profile 553 쮿 Static load-carrying capacity 400 kg, tested in accordance with IEC 61587-1 467 쮿 Lateral groove for mounting accessories Cabinet height U 12 16 20 25 34 38 43 47 Foot height 8 mm d1 d d1 56 60 64 56 c D 106 60 Frame dimensions Ø8 451 465 H mm 589 767 945 1167 1567 1745 1967 2145 h mm 535 713 890 1112 1513 1690 1913 2090 451 465 w 07011100 Frame dimensions 19" front / rear upright Cabinet depth 50,5 30 D mm 500 600 800 900 1000 10 M8 19" to 19" plane Floor mounting c mm 380 480 680 780 880 d1 mm 319 419 619 719 819 w mm 515 515 515 515 515 19,5 60 64 84,5 7 Adjustable feet, castors, lifting eye, top cover fixing d mm 405 505 705 805 905 12 07011099 1.244 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Dimensional drawings Heavy-Duty Universal frames Frame Universal upright 07016081 Frame (top view) 07016002 MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 Light aluminum die-cast frame and robust vertical profile 쮿 Static load-carrying capacity 400 kg, tested to IEC 61587-1 쮿 Lateral groove for mounting built-on accessories Rack dimensions Cabinet height U 12 16 20 25 34 38 43 47 Foot height 8 mm Universal front upright / 19" rear upright 07016082 H mm 589 767 945 1167 1567 1745 1967 2145 H mm 535 713 890 1112 1513 1690 1913 2090 Rack dimensions Cabinet depth D mm 500 600 800 900 1000 Adjustable feet, casters, lift lug, top cover fixing d mm 405 505 705 805 905 19" to 19" plane Base mounting c mm 380 480 680 780 880 d1 mm 319 419 619 719 819 w mm 515 515 515 515 515 07016083 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.245 Cabinets – Novastar 19" cabinet with glass door (smoke grey) and rear panel Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 All uprights (front and rear) with 19" cut-outs 쮿 Flush cladding parts 쮿 Type of protection IP 20 쮿 2 cabinet depths (600 mm, 800 mm), cabinet width 553 mm 쮿 Static load-carrying capacity – Slim-Line 200 kg (12, 16, 20 U) – Heavy-Duty 400 kg (38, 43 U) 쮿 2 colours – RAL 7021 (black grey) throughout – Colour combination: side panels, rear panel RAL 7035 (light grey); frame, top cover RAL 7021 (black grey) Delivery comprises (assembled) 07011010 3 Item 1 Qty 1 2 2 3 4 1 1 5 1 6 7 4 1 Description Frame, uprights Al extrusion with 19" cut-outs, Al die-cast frame, RAL 7021 Side panel, St, 1 mm; light grey (RAL 7035) or black grey (RAL 7021), see Order information; twist-locking catch (Torx T30) Flush top cover, St, 1 mm, RAL 7021 Glazed door, single pane safety glass (ESG) 6 mm, smoke grey, with DIN cylinder safety lock and 2 keys (2233x) Rear panel, St, 1 mm, light grey (RAL 7035) or black grey (RAL 7021), see Order information Foot GND/earthing kit Order Information 2 1 H 8 5 Width W Depth D U mm mm mm Colour RAL 7021 Part no. Colour RAL 7035/RAL 7021 Part no. 16230-019 16230-020 16230-021 16230-022 16230-023 16230-024 16230-025 27230-066 Note D 6 Spacing to 19" plane: Slim-Line: front 33 mm, rear 60 mm; Heavy-Duty: front and rear 60 mm Height H Slim-Line 12 589 553 600 15230-019 16 767 553 600 15230-020 20 945 553 600 15230-021 Heavy-Duty 38 1745 553 600 15230-022 38 1745 553 800 15230-023 43 1967 553 600 15230-024 43 1967 553 800 15230-025 Accessories Lifting eye for flush cover M12 thread, application and load to DIN 582 PU 4 pieces 4 W Usable height 07011050 쮿 Please order base plate, base/plinth, slide rails and shelves separately, see from page 1.254 쮿 Castors see page 1.253 쮿 Other accessories/components see ServicePLUS, from page 1.261 쮿 Dimension drawings see from page 1.243 ServicePLUS see page 1.261 1.246 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar 19" cabinet, door and rear panel combination freely selectable Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 All uprights (front and rear) with 19" cut-outs 쮿 Flush cladding parts 쮿 Type of protection IP 20 쮿 3 cabinet depths (500, 600 and 800 mm), cabinet width 553 mm 쮿 Static load-carrying capacity – Slim-Line 200 kg (9 U to 25 U) – Heavy-Duty 400 kg (34 U to 47 U) 쮿 2 colours – RAL 7021 (black grey) throughout – Colour combination: side panels RAL 7035 (light grey); frame, top cover RAL 7021 (black grey) Delivery comprises (assembled) 07011013 2 8 H 1 D 4 Spacing to 19" plane: Slim-Line: front 33 mm, rear 60 mm; Heavy-Duty: front and rear 60 mm ServicePLUS see page 1.261 SCHROFF.PENTAIR.CO.UK Qty 1 2 2 3 4 5 1 4 1 Description Frame, uprights Al extrusion with 19" cut-outs, Al die-cast frame, RAL 7021 Side panel, St, 1 mm; light grey (RAL 7035) or black grey (RAL 7021), see Order information; twist-locking catch (Torx T30) Flush top cover, St, 1 mm, RAL 7021 Foot GND/earthing kit Order Information 3 W Item 1 07011051 Usable height Height H Width W Depth D U mm mm mm Part no. Colour RAL 7035/RAL 7021 Part no. Slim-Line 9 12 12 16 16 20 20 20 25 25 456 589 589 767 767 945 945 945 1167 1167 553 553 553 553 553 553 553 553 553 553 600 500 600 500 600 500 600 800 600 800 15230-001 16230-001 15230-002 16230-002 15230-003 15230-004 16230-003 16230-004 15230-005 16230-005 15230-006 15230-007 16230-006 16230-007 15230-008 16230-008 15230-009 15230-010 16230-009 16230-010 Colour RAL 7021 Heavy-Duty 34 1567 553 600 15230-011 34 1567 553 800 15230-012 38 1745 553 600 15230-013 38 1745 553 800 15230-014 43 1967 553 600 15230-015 43 1967 553 800 15230-016 47 2145 553 600 15230-017 47 2145 553 800 15230-018 Accessories Lifting eye for flush cover M12 thread, application and load to DIN 582 PU 4 pieces 16230-011 16230-012 16230-013 16230-014 16230-015 16230-016 16230-017 16230-018 27230-066 쮿 Please order doors, rear panel, base plate, base/plinth, slide rails and shelves separately, see from page 1.248 쮿 Castors see page 1.253 쮿 Other accessories/components see ServicePLUS, from page 1.261 쮿 Dimension drawings see from page 1.243 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.247 Cabinets – Novastar Glass door (smoke grey) Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Can be assembled at front and rear 쮿 Opening angle 180° Delivery comprises Item 1 Qty 1 2 1 Description Glass door, single pane safety glass (ESG) 6 mm, smoke grey; safety lock with DIN cylinder and 1 key (2233x); hinges, plastic, black Assembly kit Order Information For cabinet height U 9 12 16 20 25 29 34 38 43 47 Height mm 422 555 733 911 1133 1345 1534 1711 1933 2111 Part no. 27230-002 27230-003 27230-004 27230-005 27230-006 27230-028 27230-007 27230-008 27230-009 27230-010 07011059 Glazed acrylic glass door MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Mounting front or rear 쮿 Opening angle 180° 쮿 Lock with key 쮿 Frame color black gray (RAL 7021) or light gray (RAL 7035) Delivery includes Item 1 2 3 4 Qty. 1 1 1 1 Description Door frame, St, 1.5 mm Acrylic sheet, 2 mm, clear Lock (2233x) with 1 key Fixing materials kit including GND Order Information 07016054 1.248 SCHROFF PRODUCT CATALOG E 06/2017 07016053 For cabinet height For cabinet height U 6 9 12 16 20 25 29 34 38 43 47 Accessories Spare key 1 piece mm 322 456 589 767 945 1167 1345 1567 1745 1967 2145 Colour RAL 7021 Part no. Colour RAL 7035 Part no. 25230-092 26230-092 25230-093 26230-093 25230-094 25230-095 26230-094 26230-095 25230-096 26230-096 25230-097 25230-102 26230-097 26230-102 25230-098 26230-098 25230-099 25230-100 26230-099 26230-100 25230-101 26230-101 60127-018 ELECTRONICS PROTECTION Cabinets – Novastar Steel door Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Can be assembled at front and rear 쮿 Opening angle 180° 쮿 Colour black grey (RAL 7021) or light grey (RAL 7035) Delivery comprises Item 1 Qty 1 2 1 Description Steel door, St, 1.5 mm; safety lock with DIN cylinder and 1 key (2233x); hinges, plastic, black Fixing material kit and GND/earthing kit Order Information 07011060 For cabinet height Height U 9 12 16 20 25 29 34 38 43 47 Accessories Spare key 1 piece mm 422 555 733 911 1133 1345 1534 1711 1933 2111 Colour RAL 7021 Part no. Colour RAL 7035 Part no. 25230-021 25230-022 26230-021 26230-022 25230-023 26230-023 25230-024 25230-025 26230-024 26230-025 25230-030 26230-030 25230-026 25230-027 26230-026 26230-027 25230-028 26230-028 25230-029 26230-029 60127-018 Perforated door MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 Can be mounted at front and rear 쮿 Perforated (60 % ventilation opening) 쮿 Opening angle 180° 쮿 Lock with key (2233X) 쮿 Colors RAL 7035 and RAL 7021 Delivery includes Item 1 Qty. 1 2 3 2 2 1 1 Description Door, perforated, St, 1.5 mm, width 553 mm, 60 % ventilation opening, see order information for color Hinge, 180° opening angle Lock with single key (2233X) Earthing (GND) kit Order Information 07016078 SCHROFF.PENTAIR.CO.UK 07016055 For cabinet height Height U 6 9 12 16 20 25 29 34 38 43 47 Accessories Spare key 1 piece mm 288.4 421.75 555.1 732.9 910.7 1132.95 1310.75 1533 1710.8 1933.05 2110.85 Colour RAL 7021 Part no. Colour RAL 7035 Part no. 25230-081 26230-081 25230-082 25230-083 26230-082 26230-083 25230-084 26230-084 25230-085 25230-086 26230-085 26230-086 25230-091 26230-091 25230-087 25230-088 26230-087 26230-088 25230-089 26230-089 25230-090 26230-090 60127-018 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.249 Cabinets – Novastar Cable ducting combination for steel door Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 For a cable ducting combination a steel door, a door hinge bracket and a frame for cable ducting are required 쮿 Cable ducting can be at top or bottom 쮿 Frame with brush strip for cable ducting is either 3 U or 4 U, depending on cabinet/door height Delivery comprises 2 Item 1 Qty 1 1 2 1 3 1 Description Door hinge bracket, St, 2 mm, RAL 7021 requires 1 U fitting space, mounts above or below the steel door Steel door, St, 1.5 mm, lock (2233x) with 1 key, opening angle 180°, GND/earthing Frame for cable ducting, St, 2.5 mm, with black brush strip, 3 U (for cabinet heights 16, 20, 38, 47 U) 4 U (for cabinet heights 25, 34, 43 U) 3 07011061 Order Information Steel door RAL 7035 RAL 7021 St, 1.5 mm, lock (2233x) with 1 key, openingangle 180, incl. GND/earthing Height (U) 16 20 25 34 38 43 47 Steel door Perforated RAL 7035 RAL 7021 St, 1.5 mm, perforated, opening angle 180°, lock with key (2233X), incl. grounding Glass door Door hinge bracket for doors smoke grey Slim-Line Slim-Line Heavy-Duty 19" plane for front rear front/rear universal upright 33 mm 60 mm 60 mm door hinge bracket, St, 2 mm, RAL 7021 door hinge bracket, St, 2 mm, St, 2 mm, RAL 7021; 1) Height 3 U RAL 7021; mounts above or 2) Height 4 U mounts above or below the door; below the door; requires 1 U assembly space requires 1 U assembly space opening angle 180°, lock with key, glass type: ESG 6 mm, EN 12150 26230-022 26230-023 25230-022 25230-023 26230-084 26230-085 25230-084 25230-085 27230-004 27230-005 27230-060 27230-060 27230-061 27230-061 27230-098 27230-098 26230-024 25230-024 26230-086 25230-086 27230-006 27230-060 27230-061 27230-098 26230-030 26230-026 25230-030 25230-026 26230-087 26230-088 25230-087 25230-088 27230-007 27230-008 27230-060 27230-060 27230-061 27230-061 27230-098 27230-098 26230-027 25230-027 26230-089 25230-089 27230-009 27230-060 27230-061 27230-098 26230-028 25230-028 26230-090 25230-090 27230-010 27230-060 27230-061 27230-098 1) 1) 2) 2) 1) 2) 1) 27230-162 27230-162 27230-163 27230-163 27230-162 27230-163 27230-162 Cable ducting RAL 7035 Screw fixed Height (U) 16 20 25 34 38 43 47 1.250 RAL 7021 RAL 7021 Screw fixed clipped St, 2.5 mm, with black brush strip 1) Height 3 U 2) Height 4 U 1) 1) 2) 2) 1) 2) 1) 20118-391 1) 20118-796 1) 27230-160 20118-391 1) 20118-796 1) 27230-160 20118-390 2) 20118-797 2) 27230-161 20118-390 2) 20118-797 2) 27230-161 20118-391 1) 20118-796 1) 27230-160 20118-390 2) 20118-797 2) 27230-161 20118-391 1) 20118-796 1) 27230-160 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Rear panel Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Twist-locking catch (Torx T30, with 1/4 turn) 쮿 Rear panel: colour black grey (RAL 7021) or light grey (RAL 7035) Delivery comprises Item 1 Qty 1 2 1 Description Rear panel, St, 1 mm, twist-locking catch (Torx T30, with 1/4 turn) Assembly kit Order Information For cabinet height Height U 9 12 16 20 25 29 34 38 43 47 mm 422 555 733 911 1133 1345 1534 1711 1933 2111 Colour RAL 7021 Part no. Colour RAL 7035 Part no. 25230-371 25230-372 26230-371 26230-372 25230-373 26230-373 25230-374 25230-375 26230-374 26230-375 25230-147 26230-147 25230-376 25230-377 26230-376 26230-377 25230-378 26230-378 25230-379 26230-379 07011057 Rear panel with cable ducting frame Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Twist-locking catch (Torx T30, with 1/4 turn) 쮿 Rear panel: colour black grey (RAL 7021) or light grey (RAL 7035) 쮿 Cable ducting frame 3 or 4 U Delivery comprises Item 1 Qty 1 2 1 3 1 4 1 1 2 Order Information 3 07011058 SCHROFF.PENTAIR.CO.UK Description Rear panel, St, 1 mm, colour see Order information; twist-locking catch (Torx T30, with 1/4 turn) Door hinge bracket, St, 2 mm, colour see Order information Frame for cable ducting, St, 1.5 mm, colour see Order information; brush strip; 3 U frame for cable ducting for cabinet heights 16, 20, 38, 47 U; 4 U frame for cable ducting for cabinet heights 25, 34, 43 U Assembly kit and GND/earthing kit For cabinet height U 16 20 25 34 38 43 47 Height mm 733 911 1133 1534 1711 1933 2111 For cabinet width mm 553 553 553 553 553 553 553 Colour RAL 7021 Part no. Colour RAL 7035 Part no. 25230-430 26230-430 25230-434 26230-434 25230-439 25230-448 26230-439 26230-448 25230-452 26230-452 25230-457 25230-461 26230-457 26230-461 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.251 Cabinets – Novastar Base plate, multi-piece MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Floor is open at rear; Opening can be closed with a cover plate or brush strip Delivery includes Item 1 Qty 1 2 1 Description Base plate, St, 1.5 mm, RAL 7021; cable through-ducting opening, width 440 mm, depth 70 mm Assembly kit Order Information 07011073 Accessories 07016050 For cabinet depth For cabinet width mm mm 500 553 600 553 800 553 1000 553 1200 553 Accessories Brush strip Nylon, black, 440 mm x 98 mm, PU 1 piece Solid cover plate for floor, multi-piece, St, 1 mm, 485 mm x 92 mm, RAL 7021, 1 piece Perforated cover plate for floor, multi-piece St, 1 mm, 485 mm x 92 mm, RAL 7021, 1 piece Filter mat cover plate for floor, multi-piece St, 1 mm, 485 mm x 92 mm, RAL 7021, 1 piece Part no. 27230-188 27230-189 27230-190 27230-191 27230-192 27230-079 27230-114 27230-254 27230-255 Note 쮿 Please order cover plate or brush strip separately Base plate, single piece, reinforced, with cutouts for cable ducting MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Heavy-load floor panel 쮿 Load-carrying capacity 50 kg (110 lbs) 쮿 Cutout for cable ducting Delivery includes Item 1 Qty. 1 2 1 Description Base plate, St, 2,5 mm, RAL 7021; cable ducting opening, perforated, width 370 mm, depth 50 mm Fixing materials kit including GND Order Information 07016059 Reinforced brush strip for floor For cabinet depth For cabinet width Qty/PU mm mm piece 500 553 1 600 553 1 800 553 1 900 553 1 1000 553 1 Accessories Brush strip for heavy-load floor panel Nylon, black, width 370 mm, depth 50 mm 1 piece Part no. RAL 7021 25230-149 25230-150 25230-151 25230-152 25230-153 27230-055 Note 07016060 1.252 SCHROFF PRODUCT CATALOG E 07/2017 쮿 Please order brush strip separately ELECTRONICS PROTECTION Cabinets – Novastar Castors Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Castors are fitted to the frame 쮿 Static load-carrying capacity 200 kg, 300 kg or 400 kg depending on version 쮿 Height dependent on version 73 mm, 80 mm, 131 mm or 155 mm 쮿 2 castors without jacking foot, 2 castors with jacking foot Delivery comprises 07011065 Load-carrying capacity 200 kg 07011066 Load-carrying capacity 300 kg, conductive, ESD resistance < 10 kΩ Item 1 2 3 Qty 2 2 1 Description Locking castor, PA/St Non-locking castor, PA/St Assembly kit Order Information Description Loadcarrying capacity kg 200 Castors Castors, conductive, ESD resistance < 10 kΩ 300 to EN 12528 Castors with 400 adjustable feet Castors 400 07011067 Height H Castor diameter mm mm Part no. 73 Ø 50 27230-067 131 Ø 100 27230-110 80 Ø 60 27230-068 155 Ø 125 27230-069 07011068 Load-carrying capacity 400 kg, Load-carrying capacity 400 kg with adjustable feet SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.253 Cabinets – Novastar Base/plinth with cable ducting Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Static load-carrying capacity 400 kg 쮿 Height adjustable 57 .... 67 mm 쮿 Cable ducting (110 x 76 mm) with cover Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 Description Base/plinth, St, 1.5 mm, height 55 mm, RAL 7021; cable ducting 110 mm x 76 mm, with plastic cover Adjustable foot Assembly kit and GND/earthing kit Order Information 07011075 For cabinet width For cabinet depth mm mm 553 500 553 600 553 800 553 900 553 1000 Accessories Brush strip Nylon, black, 110 mm x 76 mm; to cover cable through-ducting opening , 1 piece Part no. 27230-070 27230-071 27230-072 27230-076 27230-080 27230-111 Mobile base/plinth Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Static load-carrying capacity 200 kg 쮿 Base/plinth height H = 100 mm Delivery comprises Item 1 Qty 1 2 1 3 4 4 1 Description Base/plinth, St, 2 mm, black (RAL 7021), with perforation, height = 100 mm Fine-grooved mat, natural rubber, anthracite, 3 mm thick, self-adhesive Castors, St, Ø 55 mm, load-carrying capacity 200 kg Assembly kit Order Information D mm 592 692 892 Part no. 27230-146 27230-147 27230-148 96 37 48 For cabinet depth mm 500 600 800 546 D 07011113 1.254 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Depth members MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 For assembly on cabinet uprights 쮿 Adjustable in 1 U increments Delivery includes Item 1 Qty 1 Description Depth member, St, 1.5 mm, finish AlZn Order Information 56 13,5 For cabinet depth mm 500 600 800 900 1000 D mm 366 466 666 766 866 Part no. 27230-167 27230-168 27230-169 27230-170 27230-171 D 07016067 07011114 19" panel/slide mounts with universal perforation grid (EIA) MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 For fitting to depth members (25 mm grid) 쮿 For recessed installation of 19" components 쮿 Load-carrying capacity 400 kg 쮿 Slide rails can be fitted 쮿 A partial-height 19" mounting is possible with short 19" panel/ slide mounts Delivery includes Item 1 2 Qty 2 1 Description 19" panel/slide mount, St, 2 mm, RAL 7021 Assembly kit Order Information 07011111 19" panel/slide mount mounted on depth members SCHROFF.PENTAIR.CO.UK 07016080 For cabinet height U mm Partial-height 6 mounting 9 456 12 589 16 767 20 945 25 1167 34 1567 38 1745 43 1967 47 2145 Usable height U H mm Part no. 6 267 27230-172 9 12 16 20 25 34 38 43 47 400 534 712 889 1112 1512 1690 1912 2090 27230-173 27230-174 27230-175 27230-176 27230-177 27230-178 27230-179 27230-180 27230-181 쮿 Slide rails see page 1.256 쮿 Depth members are required for fitting, see page 1.255 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.255 Cabinets – Novastar 19" plane for universal upright MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Panel/slide mount for installing on the universal profile 쮿 A 19" plane can be implemented using the panel/slide mount Delivery includes Item 1 2 Qty. 4 1 Description 19" panel/slide mount, St, 2 mm, RAL 7021 Fixing materials kit Order Information Height U 3 4 3U 07016070 Height mm 130 170 Qty/PU piece 2 2 Part no. 27230-162 27230-163 07016071 4U Slide rail Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 For mounting on the vertical cabinet uprights or 19" panel/slide mounts 쮿 Adjustable in 1 U increments 쮿 Static load-carrying capacity 25 kg per pair D Delivery comprises Qty 2 1 Description Slide rail, St, 1.5 mm, finish AlZn Assembly kit 82 Order Information 39 W 07011078 Item 1 2 07011104 For cabinet depth D mm 500 600 800 900 1000 L mm 370 470 670 770 970 x mm 322 422 622 822 922 Part no. 27230-102 27230-103 27230-104 27230-105 27230-106 00205051 1.256 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Heavy-load slide rail MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 For mounting on the vertical cabinet uprights or 19" panel/slide mounts 쮿 Adjustable in 1 U increments 쮿 Static load-carrying capacity 50 kg per pair 쮿 900, 1000 mm depth for server applications Delivery includes Item 1 2 Qty. 2 1 Description Slide rail, St, 2 mm, finish AlZn Fixing materials kit Order Information 07016066 For cabinet depth D L x mm mm mm 500 272 322 600 370 422 800 470 522 900 670 722 1000 870 822 900, 1000 mm for server 740 692 applications Accessories Fixing materials kit for heavy-load slide rail 1 set (4 x M5x12 screws, 4 x M5 cage nuts, screwed in from the inside) Part no. 25230-013 25230-014 25230-015 25230-145 25230-146 25230-148 27230-056 07016084 Short slide rail Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For mounting on the cabinet uprights or 19" panel/slide mounts 쮿 Adjustable in 1 U increments 쮿 Static load-carrying capacity max. 15 kg per pair Delivery comprises Item 1 2 Qty 2 / 10 1 Description Short slide rail, St, 1.5 mm, finish AlZn Assembly kit Order Information Description Short slide rail Short slide rail Qty/PU piece 2 10 Part no. 27230-184 27230-185 07016065 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.257 Cabinets – Novastar Shelf, stationary MAIN CATALOG Part number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Static load-carrying capacity 75 kg 쮿 Mounting height 1 U, for fitting on the vertical cabinet uprights 쮿 Hammer head perforation for fixing cables using cable ties or Velcro-type tape 쮿 900, 1000 mm Tiefe für Server Anwendungen Delivery includes Item 1 2 Qty 1 1 Description Shelf with perforation, St, 1.5 mm, RAL 7021 Assembly kit 07011077 Order Information W W = 553 mm 1.258 SCHROFF PRODUCT CATALOG E 06/2017 D d w 07011105 For cabinet depth D Usable surface w x d mm mm 500 488 x 350 600 488 x 450 800 488 x 650 900 488 x 750 1000 488 x 850 900, 1000 mm für 488 x 740 Serveranwendungen Accessories Cable ties 92 mm x 2.5 mm, PU 25 pieces Cable ties 186 mm x 5 mm, PU 25 pieces Cable ties 360 mm x 5 mm, PU 25 pieces Velcro strip Polyethylen/Polyamide, black, length 300 mm, PU 10 pieces Part no. 27230-051 27230-052 27230-053 27230-088 27230-089 27230-165 20118-351 20118-352 20118-353 20118-624 ELECTRONICS PROTECTION Cabinets – Novastar Telescopic shelf, 70 kg Main Catalogue 쮿 Static load-carrying capacity at full extension 70 kg 쮿 Mounting height 2 U, for fitting to the four vertical uprights 쮿 Incl. telescopic slides 1 쮿 Locking possible with T-bar lock 2 쮿 Hammer head perforation for fixing cables using cable ties or Velcro-type tape 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 4 Delivery comprises Item 1 2 3 Qty 1 2 1 Description Shelf with perforation, St, 1.5 mm, RAL 7021 Telescopic slide Assembly kit 07011089 Full depth Order Information w Full depth D c Cabinet dimensions W x Usable surface xf xf1 c D wxd mm mm mm mm mm 553 x 500 405 x 382 33 60 407 553 x 600 405 x 482 33 60 507 553 x 800 405 x 682 33 60 687 533 x 900, 740 mm für 405 x 582 33 60 787 Serveranwendungen 533 x 1000 405 x 682 33 60 887 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic shelf PU 1 piece xf xf 1 d 60 W Full depth Part no. 21130-357 21130-353 21130-355 27230-108 27230-109 23130-092 21120-189 07011101 Order Information Shortened depth Shortened by 100 mm W Cabinet dimensions W x Usable surface xf xf1 c Shortened by D wxd 100 mm mm mm mm mm mm Part no. 553 x 500 405 x 282 33 60 407 21130-358 553 x 600 405 x 382 33 60 507 21130-352 553 x 800 405 x 582 33 60 687 21130-354 533 x 900, 740 mm für 405 x 582 33 60 787 27230-108 Serveranwendungen 533 x 1000 405 x 682 33 60 887 27230-109 Item 4 T-bar lock for 1 telescopic shelf (can be mounted 23130-092 right or left), 1 piece GND/earthing for telescopic shelf PU 1 piece 21120-189 D xf xf 1 d c 60 w 07011102 c = pitch of 19" profiles; xf, = Slim-Line assembly dimensions; xf1 = Heavy-Duty assembly dimensions SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.259 Cabinets – NOVASTAR Support arm for monitor and keyboard (SysPend®) Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Support arm for mounting of monitor, keyboard and mouse on cabinet 쮿 Fixing is to the side of the Heavy-Duty frame (height adjustable) 쮿 Static load-carrying capacity 3 ... 7 kg 쮿 Support arm: – Height-adjustable 300 mm – Angle of rotation on cabinet 180 ° – Monitor rotation angle 340° (fitted on cabinet 270°) – Monitor tilt angle 60° – Integrated cable routing 쮿 Suitable for industrial applications Delivery comprises 00511006 Item 1 Qty 1 2 1 3 1 4 1 Description Support arm frame, Al extrusion, RAL 7035, rotatable, height adjustable Wall-mounting bracket, for mounting on cabinet or wall, hinged sideways through 180° Keyboard storage point, tiltable upward through 95°, width 480 mm, depth 170 mm; mouse pad: width 150 mm, depth 190 mm Monitor holder for flat-screen units, hinged through 340°, tiltable through 60° (15° forwards, 45° to rear) Order Information Description Qty/PU pieces Support arm for monitor and keyboard 1 (SysPend® ) Accessories Mounting material for cabinet exterior PU 4 pieces 00511004 Support arm fitted with monitor Cable ducting and keyboard Part no. VAMONITOR 27230-144 00511003 Mounting material for cabinet exterior NOVASTARMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For mounting accessories to cabinet exterior (e.g. support arm) 쮿 Slide nut (M6) is simply inserted into the side T-groove of the Heavy-Duty frame Delivery comprises Item 1 2 3 Qty 1 1 1 Description Slide nut M6 Pan head screw M6 x 16 (Torx T30) Nomel washer 6.1 Order Information 06712050 Description Mounting material for cabinet exterior 1.260 SCHROFF PRODUCT CATALOG E 06/2017 Qty/PU pieces 4 Part no. 27230-144 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus ServicePLUS: configuration and assembly Novastar Servi ce Plus Main Catalogue 쮿 Dimensions: – Height: 6 ... 47 U (357 ... 2145 mm) – Width: 553 mm – Depth: 500, 600, 800, 900, 1000 mm Page Frames, gasketing kit, side-by-side mounting kit, 1.262 stacking kit 쮿 3 frame versions: – Slim-Line, static load-carrying capacity 200 kg, height 6 ... 47 U – Heavy-Duty, static load-carrying capacity 400 kg, 19" + Universal, height 16 ... 47 U Castors, adjustable feet 1.263 쮿 Configure your cabinet from individual parts (to have them assembled please add the suffix /05 to each part number) Side panels 1.264 쮿 Once you have selected your cabinet dimensions, the row number (first column of the configuration tables) guides you through all the pages of the configurations possible for these dimensions (see example below) Glass doors, steel doors 1.265 Cable ducting for steel doors 1.266 Rear panels 1.267 Top covers 1.268 Fan top covers, lifting eye, thermostat, speed controller 1.269 Floors 1.270 Base/plinth 1.271 19" panel/slide mounts, depth members, shelves 1.272 Shelves 1.273 Slide rails 1.274 Cable ties, Velcro-type tape 1.275 쮿 The configured cabinet is assembled and is ready for despatch within 10 working days 07011052 Configuration example, assembled (here: row no. 11) Qty 1 1 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description Order no. Frame, Slim-Line, usable height 20 U, height 945 mm, 28230-015/05 width 553 mm, depth 500 mm, 1 piece Side panel, Slim-Line, height 20 U, depth 500 mm, RAL 7035, PU 26230-074/05 2 pieces Glass door (smoke grey), height 20 U, opening angle 180°, width 27230-005/05 553 mm, 1 piece Rear panel, height 20 U, width 553 mm, RAL 7035, PU 1 piece 26230-374/05 Top cover, raised, width 553 mm, depth 500 mm, RAL 7021, 25230-010/05 1 piece .......... .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.261 Cabinets – Novastar Service Plus Frames, gasketing kit, side-by-side mounting kit, stacking kit Frame Slim-Line 200 kg Heavy-Duty 400 kg, 19" 07011053 Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.262 07011054 static loadstatic loadcarrying capacity: carrying capacity: 400 kg, 200 kg, Al extrusion, Al extrusion, RAL 7021, incl. RAL 7021, incl. GND/earthing; GND/earthing; 19" plane 33 mm 19" plane 60 mm at front, at front, 60 mm at rear; 60 mm at rear; please order please order castors or castors or adjustable feet adjustable feet separately separately Heavy-Duty, 400 kg, Universal 07016056 Static loadcarrying capacity: 400 kg, Al profile, RAL 7021, incl. grounding; 19" plane rear 60 mm, castors or adjustable feet ordered separately Gasketing kit for IP 40 07012050 TPE, black; raises ingress protection from IP 20 to IP 40; gaskets are affixed onto the frame Side-by-side mounting kit 07011080 gasket, foam adhesive tape: PU foam anthracite; for joining two adjacent cabinets Stacking kit 07011070 for joining two cabinets positioned one above the other Slide nut for T-groove aza43431 St, M6, for lateral mounting of accessories on the T-groove of the Heavy-Duty frame 1 piece 1 piece 1 piece PU 1 kit PU 1 kit PU 1 kit PU 4 pieces assembled assembled assembled assembled enclosed loose enclosed loose enclosed loose – – 27230-107 20230-409 27230-112 27230-144 – – 27230-107 20230-409 27230-112 27230-144 – – – 28230-056 28230-189 28230-310 28230-370 28230-430 28230-192 28230-193 28230-314 28230-374 28230-434 28230-196 28230-197 28230-319 28230-379 28230-439 28230-200 28230-201 28230-328 28230-388 28230-448 28230-204 28230-205 28230-332 28230-392 28230-452 28230-208 28230-209 28230-337 28230-397 28230-457 28230-212 28230-213 28230-341 28230-401 28230-461 28230-216 28230-217 28230-057 28230-058 28230-059 28230-107 28230-108 28230-109 28230-110 28230-111 28230-112 28230-113 28230-114 28230-115 28230-116 28230-117 28230-118 28230-119 28230-167 28230-168 28230-169 28230-170 28230-171 28230-172 28230-173 28230-174 28230-175 28230-176 28230-177 28230-178 28230-179 28230-180 28230-181 28230-182 28230-183 28230-184 28230-185 28230-186 28230-187 28230-188 28230-052 28230-053 27230-107 20230-409 27230-112 27230-144 27230-107 20230-409 27230-112 27230-144 27230-107 20230-409 27230-112 27230-144 27230-143 20230-409 27230-112 27230-144 27230-143 20230-409 27230-112 27230-144 27230-143 20230-409 27230-112 27230-144 27230-143 20230-409 27230-112 27230-144 27230-143 20230-409 27230-112 27230-144 28230-001 28230-060 28230-004 28230-063 28230-007 28230-066 28230-126 28230-054 28230-055 28230-011 28230-070 28230-130 28230-190 28230-191 28230-015 28230-074 28230-134 28230-194 28230-195 28230-020 28230-079 28230-139 28230-198 28230-199 28230-029 28230-088 28230-148 28230-202 28230-203 28230-033 28230-092 28230-152 28230-206 28230-207 28230-048 28230-097 28230-157 28230-210 28230-211 28230-042 28230-101 28230-162 28230-214 28230-215 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Castors, adjustable feet Castors Load-carrying capacity 200 kg 07011065 Load-carrying capacity 300 kg, conductive 07011066 Adjustable foot Load-carrying capacity 400 kg, Ø 60 mm 07011067 Load-carrying capacity 400 kg, Ø 125 mm 07011068 static loadstatic loadstatic loadstatic loadcarrying capacity carrying capacity carrying capacity carrying capacity 400 kg, 400 kg, 300 kg, height 131 200 kg, height 155 mm, height 80 mm, mm, Ø 100 mm, height 73 mm, Ø 125 mm, Ø 60 mm, 2 castors without Ø 50 mm, 2 castors without 2 castors without jacking foot, 2 castors without jacking foot, jacking foot, 2 castors with jacking foot, 2 castors with 2 castors with jacking foot; 2 castors with jacking foot jacking foot, EN 12528 jacking foot incl. 4 adjustable (resistance feet < 10 kΩ) Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK 07011069 static loadcarrying capacity 400 kg, St, polyamide, black PU 1 kit PU 1 kit PU 1 kit PU 1 kit PU 1 kit assembled assembled assembled assembled assembled 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 27230-067 27230-110 27230-068 27230-069 27230-100 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.263 Cabinets – Novastar Service Plus Side panels Side panel Slim-Line 07011055 Heavy-Duty 07011084 Side panel lock 07011056 07011085 St, 1 mm, with quarter-turn fastener; St, 1 mm, with quarter-turn fastener; incl. GND/earthing incl. GND/earthing Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.264 07011108 2 locks (2233x locking), 2 keys; suitable for 2 side panels RAL 7035 RAL 7021 RAL 7035 RAL 7021 PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces PU 1 kit assembled assembled assembled assembled assembled 26230-070 26230-120 26230-071 26230-121 26230-072 26230-122 26230-172 26230-113 26230-114 26230-073 26230-123 26230-173 26230-115 26230-116 26230-074 26230-124 26230-174 26230-117 26230-118 26230-075 26230-125 26230-175 26230-119 26230-130 26230-076 26230-126 26230-176 26230-131 26230-132 26230-077 26230-127 26230-177 26230-133 26230-134 26230-078 26230-128 26230-178 26230-135 26230-136 26230-079 26230-129 26230-179 26230-137 26230-138 25230-070 25230-120 25230-071 25230-121 25230-072 25230-122 25230-172 25230-113 25230-114 25230-073 25230-123 25230-173 25230-115 25230-116 25230-074 25230-124 25230-174 25230-117 25230-118 25230-075 25230-125 25230-175 25230-119 25230-130 25230-076 25230-126 25230-176 25230-131 25230-132 25230-077 25230-127 25230-177 25230-133 25230-134 25230-078 25230-128 25230-178 25230-135 25230-136 25230-079 25230-129 25230-179 25230-137 25230-138 – – 27230-115 – – 27230-115 26230-222 26230-272 26230-322 26230-067 26230-068 26230-223 26230-273 26230-323 26230-069 26230-080 26230-224 26230-274 26230-324 26230-103 26230-104 26230-225 26230-275 26230-325 26230-105 26230-106 26230-226 26230-276 26230-326 26230-107 26230-108 26230-227 26230-277 26230-327 26230-109 26230-110 26230-228 26230-278 26230-328 26230-111 26230-112 26230-229 26230-279 26230-329 26230-040 26230-041 25230-222 25230-272 25230-322 25230-067 25230-068 25230-223 25230-273 25230-323 25230-069 25230-080 25230-224 25230-274 25230-324 25230-103 25230-104 25230-225 25230-275 25230-325 25230-105 25230-106 25230-226 25230-276 25230-326 25230-107 25230-108 25230-227 25230-277 25230-327 25230-109 25230-110 25230-228 25230-278 25230-328 25230-111 25230-112 25230-229 25230-279 25230-329 25230-040 25230-041 SCHROFF PRODUCT CATALOG E 06/2017 27230-115 27230-115 27230-115 27230-115 27230-115 27230-115 27230-115 27230-115 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Glass doors, steel doors Steel door Steel door Glazed door Glass door Perforated 07011060 07011088 St, 1.5 mm, lock (2233x) with 1 key, opening angle 180, incl. GND/earthing Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK 07016078 St, 1.5 mm, perforated, opening angle 180°, lock with key (2233X), incl. grounding 07011060 Door frame, St, 1.5 mm; acrylic glass, 2 mm; safety lock with 2 keys 07016054 07011059 opening angle 180°, lock with key, glass type: ESG 6 mm, EN 12150 RAL 7035 RAL 7021 RAL 7035 RAL 7021 RAL 7035 RAL 7021 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece smoke grey 1 piece assembled assembled assembled assembled assembled assembled assembled 26230-020 25230-020 26230-081 25230-081 26230-092 25230-092 27230-001 26230-021 25230-021 26230-082 25230-082 26230-093 25230-093 27230-002 26230-022 25230-022 26230-083 25230-083 26230-094 25230-094 27230-003 26230-023 25230-023 26230-084 25230-084 26230-095 25230-095 27230-004 26230-024 25230-024 26230-085 25230-085 26230-096 25230-096 27230-005 26230-025 25230-025 26230-086 25230-086 26230-097 25230-097 27230-006 26230-026 25230-026 26230-087 25230-087 26230-098 25230-098 27230-007 26230-027 25230-027 26230-088 25230-088 26230-099 25230-099 27230-008 26230-028 25230-028 26230-089 25230-089 26230-100 25230-100 27230-009 26230-029 25230-029 26230-090 25230-090 26230-101 25230-101 27230-010 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.265 Cabinets – Novastar Service Plus Cable ducting for steel doors Cable ducting for steel door with door hinge bracket and frame Steel door RAL 7035 Door hinge bracket for doors RAL 7021 07011060 07011088 St, 1.5 mm, lock (2233x) with 1 key, opening angle 180, incl. GND/earthing Slim-Line front Slim-Line rear, Heavy-Duty front/rear, Universal rear Cable ducting frame Heavy-Duty Universal front RAL 7035 screw fixed 07011061 RAL 7021 screw fixed RAL 7021 clipped 07011061 07016073 St, 2.5 mm, with black brush strip 1) Height 3 U 2) Height 4 U door hinge bracket, St, 2 mm, RAL 7021; mounts above or below the door; requires 1 U assembly space Heavy-Duty Universal: Short 19" planes are required to mount the door hinge bracket, see page 1.272 Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.266 RAL 7035 RAL 7021 33 mm 60 mm 60 mm RAL 7035 RAL 7021 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled assembled assembled – – – – – – – – – – – – – – – – – – – – – – – – 26230-022 25230-022 27230-060 27230-061 27230-098 20118-391 26230-023 25230-023 27230-060 27230-061 27230-098 20118-391 26230-024 25230-024 27230-060 27230-061 27230-098 20118-390 26230-030 25230-030 27230-060 27230-061 27230-098 20118-390 26230-026 25230-026 27230-060 27230-061 27230-098 20118-391 26230-027 25230-027 27230-060 27230-061 27230-098 20118-390 26230-028 25230-028 27230-060 27230-061 27230-098 20118-391 SCHROFF PRODUCT CATALOG E 06/2017 1) 1) 2) 2) 1) 2) 1) 1) 20118-796 1) 20118-796 2) 20118-797 2) 20118-797 1) 20118-796 2) 20118-797 1) 20118-796 RAL 7021 1) 27230-160 1) 27230-160 2) 27230-161 2) 27230-161 1) 27230-160 2) 27230-161 1) 27230-160 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Rear panels Rear panel 07011057 Rear panel with cable ducting 07011086 St, 1 mm; 2 twist-locking catches (Torx T30,with1/4 turn); incl. GND/earthing Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK 07011058 07011087 Rear panel lock 07011107 2 rear panel St, 1 mm; 2 twist-locking catches catches with lock (Torx T30, with 1/4 turn), (2233x locking), incl. GND/earthing, cable ducting 2 keys; and door hinge bracket; suitable for a cable ducting can be fitted at top or rear panel bottom, 3 U cable ducting for cabinet height 16, 20, 38, 47 U; 4 U cable ducting for cabinet height 25, 34, 43 U RAL 7035 RAL 7021 RAL 7035 1 piece 1 piece PU 1 kit RAL 7021 PU 1 kit PU 1 kit assembled assembled assembled assembled assembled 26230-370 25230-370 – – 27230-116 26230-371 25230-371 – – 27230-116 26230-372 25230-372 – – 27230-116 26230-373 25230-373 26230-430 25230-430 27230-116 26230-374 25230-374 26230-434 25230-434 27230-116 26230-375 25230-375 26230-439 25230-439 27230-116 26230-376 25230-376 26230-448 25230-448 27230-116 26230-377 25230-377 26230-452 25230-452 27230-116 26230-378 25230-378 26230-457 25230-457 27230-116 26230-379 25230-379 26230-461 25230-461 27230-116 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.267 Cabinets – Novastar Service Plus Top covers Top cover flush Flush 07011063 Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.268 Top cover raised Lifting eye 07011071 St, 1 mm, RAL 7021, incl. GND/ earthing for flush cover; M12, application and load to DIN 582 1 piece assembled 25230-001 25230-002 25230-001 25230-002 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 25230-001 25230-002 25230-003 25230-043 25230-044 SCHROFF PRODUCT CATALOG E 06/2017 Raised 07011064 Lifting eye 07011072 Raised top cover, load-carrying capacity 50 kg 07016077 St, 1 mm, RAL 7021, incl. GND/ earthing, height 31 mm, air gap 10 mm for raised cover or fan top cover; M12, application and load to DIN 582 PU 4 pieces 1 piece PU 4 pieces 1 piece assembled assembled assembled assembled 27230-066 27230-066 27230-066 27230-066 27230-066 27230-066 27230-066 27230-066 27230-066 27230-066 25230-010 25230-011 25230-010 25230-011 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 25230-010 25230-011 25230-012 25230-045 25230-046 27230-065 27230-065 27230-065 27230-065 27230-065 27230-065 27230-065 27230-065 27230-065 27230-065 St, 1 mm, RAL 7021, incl. GND/ earthing, height 31 mm, air gap 10 mm, roof mounting from the inside (outside no screws) 25230-039 25230-038 25230-039 25230-038 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 25230-039 25230-038 25230-037 25230-141 25230-142 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Fan top covers, lifting eye, thermostat, speed controller Fan top cover (fan height 25 mm) Fan top cover Fan with fans 84 ... 90 m³ Fan top cover (fan height 38 mm) Fan top cover Fan with fans 162 ... 172 m³ Lifting eye Thermostat Speed control 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm 07011082 kta44844 07011082 axial fan with St, RAL 7021, incl. St, RAL 7021, incl. protective grille, GND/earthing GND/earthing 230 VAC, 8 W, and cabling; and cabling; 2 fans for 500 mm 2 fans for 500 mm 84 ... 90 m³/h depth, 1 cover depth, 4 cover 29 ... 30 dB(A), cap;3 fans for caps; height 25 mm; 600/800 mm 3 fans for 600/ please order depth, 3 cover 800 mm depth, separately if caps; 0.5 m 3 cover caps; additional fans connector cable, 0.5 m are required IEC C14 plug connector cable, IEC C14 plug Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK kta44844 07011072 axial fan with protective grille, 230 VAC, 15 W, 162 ... 172 m³/h, 37 ... 41 dB(A), height 38 mm; please order separately if additional fans are required for raised cover or fan top cover; M12, application and load to DIN 582 01108052 01105055 with mains cable fully wired, 230 VAC 90 ... 264 VAC, (SCHUKO/UTE input SCHUKO/ plug/IEC 60320 UTE plug, C13 socket), outlet IEC 60320 adjustment range C13 socket; 0 ... 60°C external NTC sensor 1.5 m PU 1 kit 1 piece PU 1 kit 1 piece PU 4 pieces 1 piece 1 piece assembled assembled assembled assembled assembled assembled assembled 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-078 27230-065 20118-750 60715-005 27230-081 27230-082 27230-081 27230-082 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-081 27230-082 27230-083 27230-094 27230-095 27230-077 27230-077 27230-077 27230-077 27230-077 27230-077 27230-077 27230-077 27230-077 27230-077 27230-085 27230-086 27230-085 27230-086 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 27230-085 27230-086 27230-087 27230-096 27230-097 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.269 Cabinets – Novastar Service Plus Floors Base plates Base plate, rear open 07011073 St, 1.5 mm, RAL 7021, incl. GND/ earthing; cable ducting in rear area of cabinet; please order cover or brush strip separately Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.270 Cover plate 07011073 St, 1.5 mm, 485 x 92 mm; to cover the rear floor opening Cover plate Perforated 07016052 St, 1.5 mm, 485 x 92 mm; to cover the rear floor opening Cover plate Filter mat 07016052 St, 1 mm, 485 x 92 mm; to cover the rear floor opening Brush strip 07011073 Nylon, black, 440 x 98 mm; to cover the rear floor opening Base plate, reinforced, with cable ducting Base plate Brush strip 07016059 St, 1.5 mm, RAL 7021; fully closed with pre-cut area for cable ducting opening, width 370 mm, depth 50 mm 07016060 Nylon, black, width 370 mm, depth 50 mm; for covering the rear floor opening 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled montiert 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-114 27230-254 27230-255 27230-079 27230-188 27230-189 27230-188 27230-189 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 27230-188 27230-189 27230-190 27230-191 27230-192 SCHROFF PRODUCT CATALOG E 06/2017 25230-149 25230-150 25230-149 25230-150 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 25230-149 25230-150 25230-151 25230-152 25230-153 27230-055 27230-055 27230-055 27230-055 27230-055 27230-055 27230-055 27230-055 27230-055 27230-055 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Base/plinth Bases/plinths Mobile bases/ plinths Brush strip 96 37 48 With cable ducting 546 07011075 07011077 D 07011113 St, 2 mm, Nylon, black, St, 1.5 mm, 110 mm x 76 mm; fine-grooved mat, RAL 7021, 3 mm, 4 castors, to cover cable height 55 mm; load-carrying through-ducting incl. GND/ capacity 200 kg opening earthing; cable ducting 110 x 76 mm; adjustable feet, adjustable height range 57 mm ... 67 mm Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece assembled assembled assembled 27230-070 27230-071 27230-070 27230-071 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-070 27230-071 27230-072 27230-076 27230-080 27230-111 27230-111 27230-111 27230-111 27230-111 27230-111 27230-111 27230-111 27230-111 27230-111 27230-146 27230-147 27230-146 27230-147 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – 27230-146 27230-147 27230-148 – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.271 Cabinets – Novastar Service Plus 19" panel/slide mounts, depth members, shelves Depth members 07011114 Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.272 19" panel/slide mounts 07011111 19" plane for universal upright 3U 4U 07016070 St, 2 mm, RAL 7021 07011114 St, 1.5 mm, finish AlZn; for mounting 19" pitch profiles 19" panel/slide mounts with universal perforation grid (EIA) PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces assembled assembled assembled assembled 27230-172 27230-162 27230-163 27230-173 27230-162 27230-163 27230-174 27230-162 27230-163 27230-175 27230-162 27230-163 27230-176 27230-162 27230-163 27230-177 27230-162 27230-163 27230-178 27230-162 27230-163 27230-179 27230-162 27230-163 27230-180 27230-162 27230-163 27230-181 27230-162 27230-163 27230-167 27230-168 27230-167 27230-168 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 27230-167 27230-168 27230-169 27230-170 27230-171 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Shelves Stationary shelf 07011077 St, 1.5 mm, RAL 7021, with perforation, static loadcarrying capacity 75 kg Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK Shelf, stationary for server Telescopic shelf, 2 U, 70 kg Full depth 07011077 Shortened by 100 mm 07011101 07011102 St, 1.5 mm, RAL 7021, static loadSt, 1.5 mm, carrying capacity when fully extended RAL 7021, 70 kg, incl. telescopic slide; with perforation, please order T-bar lock and GND/ static loadearthing kit separately carrying capacity 75 kg T-bar lock 01004125 to lock the telescopic shelf GND/earthing aza43284 for telescopic shelf 1 piece 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled assembled 27230-051 27230-052 27230-051 27230-052 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 27230-051 27230-052 27230-053 27230-088 27230-089 – – – – – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 – – – 27230-165 27230-165 21130-357 21130-353 21130-357 21130-353 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-357 21130-353 21130-355 27230-108 27230-109 21130-358 21130-352 21130-358 21130-352 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 21130-358 21130-352 21130-354 – – 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 23130-092 21120-189 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.273 Cabinets – Novastar Service Plus Slide rails Slide rail Slide rail 07011078 St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 1.274 Heavy-load slide rail 07011078 Heavy-load slide rail for server 07011078 St, 1.5 mm, finish AlZn, static load-carrying capacity 50 kg/pair Short slide rail ERA46348 sc96xxxx St, 1.5 mm, finish AlZn, static load-carrying capacity 15 kg/pair PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces PU 10 pieces assembled assembled assembled enclosed loose enclosed loose 27230-102 27230-103 27230-102 27230-103 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 27230-102 27230-103 27230-104 27230-105 27230-106 25230-013 25230-014 25230-013 25230-014 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 25230-013 25230-014 25230-015 25230-145 25230-146 – – – – – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 – – – 25230-148 25230-148 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 27230-184 27230-185 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinets – Novastar Service Plus Cable ties, Velcro-type tape Cable tie Velcro General components Mechanics 01005078 plastic, 92 mm x 2.5 mm; 01005079 black, length 300 mm, from page 3.2 Electrics Cabinet dimensions Height Width Depth No. U mm mm mm 1 6 357 553 500 2 6 357 553 600 3 9 456 553 500 4 9 456 553 600 5 12 589 553 500 6 12 589 553 600 7 12 589 553 800 8 12 589 553 900 9 12 589 553 1000 10 16 767 553 500 11 16 767 553 600 12 16 767 553 800 13 16 767 553 900 14 16 767 553 1000 15 20 945 553 500 16 20 945 553 600 17 20 945 553 800 18 20 945 553 900 19 20 945 553 1000 20 25 1167 553 500 21 25 1167 553 600 22 25 1167 553 800 23 25 1167 553 900 24 25 1167 553 1000 25 34 1567 553 500 26 34 1567 553 600 27 34 1567 553 800 28 34 1567 553 900 29 34 1567 553 1000 30 38 1745 553 500 31 38 1745 553 600 32 38 1745 553 800 33 38 1745 553 900 34 38 1745 553 1000 35 43 1967 553 500 36 43 1967 553 600 37 43 1967 553 800 38 43 1967 553 900 39 43 1967 553 1000 40 47 2145 553 500 41 47 2145 553 600 42 47 2145 553 800 43 47 2145 553 900 44 47 2145 553 1000 SCHROFF.PENTAIR.CO.UK PU 25 pieces PU 10 pieces supplied loose supplied loose 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 from page 3.30 Power distribution 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 from page 3.35 Climate control 20118-351 20118-624 from page 4.0 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.275 P Main CataloguePart num ber in bold face type: ready for despatch w ithin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Cabinets – P Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 00105003 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 19" grid integrated in upright 00105004 Simple solution for shortened doors 00105005 Doors can also be assembled laterally 00105066 Standards/certifications 쮿 External and internal dimensions in accordance with IEC 60297-3-100 쮿 Type of ingress protection: IP 40, in accordance with IEC 60529 쮿 Protective GND/earthing connections in accordance with DIN EN 50178/VDE 0160 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 1.270 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P Overview . . . . . . 1.270 PMain C atalogue 19" electronic cabinet 쮿 Type of ingress protection up to IP 40 Introduction . . . . . 1.272 Dimensions . . . . . 1.274 쮿 Bolted frame, die-castings and aluminium profiles, with inset covers 쮿 Static load-carrying capacity 400 kg 쮿 New colours: RAL 7021 (black grey) or RAL 7021/RAL 7035 (black grey/light grey) colour combination Cabinet with front and rear door Cabinet without front and rear door 00108002 쮿 38 and 43 U 쮿 Depth 600 and 800 mm 쮿 34, 38, 43 and 47 U 쮿 Depth 600 and 800 mm ServicePLUS from page 1.288 e.g. individual configuration and assembly e.g. modifications (special colours or sizes) e.g. variants of uprights e.g. custom solutions (electromagnetically shielded applications) eurorack 00108004 19" cabinets with front and rear door . . . . . . . . . . . . 1.276 19" cabinets without front and rear door . . . . . . . . 1.277 Front/ rear doors . . . . . . 1.278 Door hinge bracket for shortened doors . . . . . . . . . . . 1.279 Base plates . . . . . . 1.280 Bases/plinths . . . . 1.280 Cable ducting with C-profiles . . . . . . . . 1.282 Cable eyes for C-profile . . . . . . . . 1.283 Slide rails . . . . . . . 1.284 Cable ties . . . . . . . 1.283 Fixed/telescopic shelves . . . . . . . . . 1.285 Cable trays . . . . . . 1.287 Cable ties . . . . . . . 1.287 Velcro . . . . . . . . . . 1.287 ServicePLUS 1.288 ServicePLUS configuration 19" 1.289 eurorack . . . . ServicePLUS configuration Universal eurorack . . . . . . . 1.300 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.271 Cabinets – P eurorack - the "classic" Text 00108005 Handsome to behold is this classic among electronics cabinets, and with good reason. Its load-bearing frame consists of a die-cast aluminium frame and aluminium uprights whose fluting gives the impression of classical pillars. Thus in eurorack - and also in NOVASTAR - the cladding parts are not fitted externally on the frame but rather inside between the frame and uprights. Thus they remain visible and give the cabinet its unmistakable look. The cabinet is available in two colour schemes. The basic frame and top cover are always in black grey (RAL 7021). With black grey claddings (side panels, doors and rear panels) you get an entirely black cabinet, as it is the contemporary look in recording studios and data centres. Alternatively, select the cladding components in light grey (RAL 7035). The different colours of the frame and lateral parts give particular emphasis to the aluminium profile. Wholly classical yet timelessly modern! PMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 working days 1.272 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P eurorack - frames 19" frame Universal frame Text 00108058 Unlike with other cabinet concepts, where the height of a cabinet is determined by common mm intervals in its exterior dimen-sions, eurorack is systematically oriented along the interior dimensions, using the height units of the 19" system. 19" components are thus flush in height with the frame and without disruptive gaps. So that likewise no gaps occur in the width there is the 19" frame, with the 19" plane already integrated in the vertical cabinet uprights. When fully equipped with 19" components, the cabinet therefore looks superb without any cover trims, decorative frames or doors. Nevertheless, if a door is required, the eurorack glazed door is a clear design option, with 60 mm space in front of the 19" mounting for assembly. 01008059 If more space is required in front of the 19" plane, the user can fall back on the Universal frame and fit separate 19" panel/slide mounts. These can then be positioned at 25 mm intervals on the depth members. However, 800 mm wide cabinets can also be realised using the Universal frame. For example, equipped with shelves for the greatest possible surface or with components that require more flexibility than 19" technology. Further features Text 00108060 Die-cast frame and frame are bolted; the cabinet can thus be dismantled SCHROFF.PENTAIR.CO.UK 00105066 Because of their symmetrical upright dimensions, doors can also be used on the sides. 00108052 Mobility with mobile base Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.273 Cabinets – P Dimensions 19" frame Height w h H H with feet mm 998 1220 1398 1620 1798 2020 2198 d w d w1 d1 W Usable height h U 20 25 29 34 38 43 47 mm 890.5 1112.5 1290.5 1512.5 1690.5 1912.5 2090.5 d1 Width Cabinet width W mm 600 9 w1 H without feet mm 989 1211 1389 1611 1789 2011 2189 Ø3 0 Upright distance w mm 451 Bolt-on dimension w1 mm 465 Upright distance d mm 382 582 682 Bolt-on dimension d1 mm 396 596 696 Distance between feet w2 mm 502 D 00105057 Depth Cabinet depth D mm 600 800 900 Cdimension c mm 480 680 780 Distance between feet d2 mm 444 644 744 00105058 Upright 60 mm recessed 00106051 1.274 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P Dimensions Universal frame Height H with feet mm 998 1220 1398 1620 1798 2020 2198 h H d d H without feet mm 989 1211 1389 1611 1789 2011 2189 Usable height h U 20 25 29 34 38 43 47 mm 890.5 1112.5 1290.5 1512.5 1690.5 1912.5 2090.5 d1 d1 Width 9 Cabinet width W mm 600 800 w W 0 Ø3 Upright distance w mm 528 728 Distance between feet w2 mm 502 702 D 00105056 Depth Cabinet depth D mm 600 800 900 Upright distance Bolt-on dimension d d1 mm mm 426 440 626 640 726 740 Distance between feet d2 mm 444 644 744 00105059 00106052 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.275 Cabinets – P 19" cabinet with front and rear door 쮿 Front: smoked glass door, rear: steel door 쮿 19" cut-outs in front and rear uprights 쮿 Inset covers 쮿 Type of protection IP 40 쮿 Available in two colour combinations: – Frame, side panels, door and top cover in black grey (RAL 7021) – Frame and top cover in black grey (RAL 7021), side panels and door in light grey (RAL 7035) Delivery comprises (assembled) 00108002 Item 1 Qty 1 2 2 3 4 1 2 5 1 6 1 7 4 Description 19" frame, consisting of 2 Al die-cast frames, RAL 7021, 4 Al extrusion uprights with 19" cut-outs Side panel, St, 1 mm, fixes with 2 side panel catches per panel, colour RAL 7021 (black grey) or RAL 7035 (light grey) see Order information Top cover with vents, St, 1.5 mm, RAL 7021 Trims, St, 1 mm, RAL 7021 (for decorative finishing at the top and at the bottom of the front assembly area) Rear door, St, 1 mm, opening angle 120°, safety lock with 2 keys Colour RAL 7021 Glass door, Sekurit, 6 mm, smoke grey, opening angle 120°, safety lock with 2 keys Foot, Al Order Information Usable Height height H Width W Depth D C Colour RAL 7021 U mm mm mm mm Part no. 38 1798 600 600 480 10117-537 38 1798 600 800 680 10117-538 43 2020 600 600 480 10117-539 43 2020 600 800 680 10117-540 GND/earthing for frame, doors, side panels, top cover and base plate, PU 1 kit Lifting eyes St, zinc-plated, M10, PU 4 pieces Adjustable feet Load-carrying capacity 100 kg/foot, St and PA, black, PU 4 pieces Castors Load-carrying capacity 100 kg/castor, PU 4 pcs Castors Load-carrying capacity 60 kg/castor, PU 4 pcs 00105060 Colour RAL 7021/ RAL 7035 Part no. 10117-533 10117-535 10117-534 10117-536 21101-539 20117-080 21101-201 20117-024 20117-757 Note 쮿 Please order base/plinth separately, see page 1.280 쮿 Other sizes available on ServicePLUS configuration, see from page 1.289 쮿 Please find the new generation of 19" aluminium electronics cabinets under NOVASTAR, page 1.240 00105067 ServicePLUS see page 1.288 1.276 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P 19" cabinet without front and rear door 쮿 Door combination freely selectable 쮿 19" cut-outs in front and rear uprights 쮿 Inset covers 쮿 Available in two colour combinations: – frame, side panels and top cover in black grey (RAL 7021) – frame and top cover in black grey (RAL 7021) side panels in light grey (RAL 7035) Delivery comprises (assembled) Item Qty 1 1 2 2 3 4 1 2 5 4 Description 19" frame, consisting of 2 Al die-cast frames, RAL 7021, 4 Al extrusion uprights with 19" cut-outs Side panel, St, 1 mm, fixes with 2 side panel catches per panel, colour RAL 7021 (black grey) or RAL 7035 (light grey) see Order information Top cover with vents, St, 1.5 mm, RAL 7021 Trim, St, 1 mm, RAL 7021 (for decorative finishing at top and bottom of front assembly area) Foot, Al Order Information 00108004 2 H 4 1 15 2 W Height H Width W Depth D C Colour RAL 7021 U mm mm mm mm Part no. 34 1567 600 600 480 10117-541 34 1567 600 800 680 10117-544 38 1798 600 600 480 10117-542 38 1798 600 800 680 10117-545 43 2020 600 600 480 10117-543 43 2020 600 800 680 10117-546 47 2198 600 800 680 10117-547 GND/earthing for frame, doors, side panels, top cover and base plate, PU 1 kit Lifting eyes St, zinc-plated, M10, PU 4 pieces Adjustable feet Load-carrying capacity 100 kg/foot, St and PA, black, PU 4 pieces Castors Load-carrying capacity 100 kg/castor, PU 4 pcs Castors Load-carrying capacity 60 kg/castor, PU 4 pcs 3 4 Usable height Colour RAL 7021/ RAL 7035 Part no. 10117-527 10117-530 10117-528 10117-531 10117-529 10117-532 10117-548 21101-539 20117-080 21101-201 20117-024 20117-757 Note D 5 00105061 쮿 Please order base/plinth separately, see page 1.280 쮿 Please order front and rear door separately, see page 1.278 쮿 Other sizes available on ServicePLUS configuration, see from page 1.289 쮿 Please find the new generation of 19" aluminium electronics cabinets under NOVASTAR, page 1.240 00105067 ServicePLUS see page 1.288 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.277 Cabinets – P Glass door, 120° opening angle Main Catalogue 쮿 Can be assembled on all four sides 75 쮿 Opening angle 120° Delivery comprises 35 Item 1 2 3 4 Description Glass door, Sekurit, 6 mm, smoke grey Safety lock with 2 keys Hinge, St, 3 mm, black (RAL 9005) Assembly kit Order Information H 20 523 era44522 Qty 1 1 2 1 mra45967 For cabinet height mm 782 945 1167 1290 1567 1798 2020 2198 Usable height U 16 20 25 29 34 38 43 47 H mm 733 911 1133 1311 1534 1711 1934 2111 For cabinet width mm 553 553 553 553 553 553 553 553 Part no. 20117-744 20117-745 20117-746 20117-747 20117-748 20117-749 20117-751 20117-752 쮿 Doors with opening angle 180° see page 1.291 쮿 Further dimensions available on ServicePLUS, see from page 1.291 Steel door, 120° opening angle 쮿 Can be assembled on all four sides 쮿 Opening angle 120° 쮿 Colour black grey (RAL 7021) or light grey (RAL 7035) g .6 un ist . . . e l . e . c .. rvi Se . . . . e . pp ite ma Se s ng ibu ware 7 e r . h ft .. ssc so Au ungs . . . . . n Pla . . . . . ite Se Delivery comprises Item 1 2 3 H 21 523 00105053 a4491c 1.278 SCHROFF PRODUCT CATALOG E 11/2017 Qty 1 1 1 Description Steel door, St, 1 mm Safety lock with 2 keys Assembly kit Order Information For cabinet height Usable height H mm 767 945 1167 1290 1567 1798 2020 2198 U 16 20 25 29 34 38 43 47 mm 733 911 1133 1311 1534 1711 1934 2111 For cabinet width mm 600 600 600 600 600 600 600 600 Colour RAL 7021 Colour RAL 7035 Part no. Part no. 22117-934 21117-184 22117-935 22117-936 21117-185 21117-186 23117-012 21117-187 22117-937 22117-938 21117-188 21117-189 22117-940 21117-190 22117-942 21117-191 쮿 Further dimensions available on ServicePLUS, see from page 1.292 쮿 180° steel door with lever handle see ServicePLUS configuration, page 1.292 ELECTRONICS PROTECTION Cabinets – P Glazed door, 120° opening angle PMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days 쮿 Can be assembled on all four sides 523 쮿 Opening angle 120° 29 46 쮿 Frame colour: black grey (RAL 7021) or light grey (RAL 7035) Delivery comprises Item 1 2 3 4 era44522 mra49568 Description Door frame, Al, 2 mm, RAL 7035 Plexiglass pane, 2 mm, clear Safety lock with 2 keys Assembly kit Order Information For cabinet height mm 782 945 1167 1290 1567 1798 2020 2198 H 21 Qty 1 1 1 1 Usable height H U 16 20 25 29 34 38 43 47 mm 733 911 1133 1311 1534 1711 1934 2111 For cabinet width mm 600 600 600 600 600 600 600 600 Colour RAL 7021 Colour RAL 7035 Part no. Part no. 22117-943 20117-769 22117-944 22117-945 20117-770 20117-771 23117-011 20117-772 22117-946 22117-947 20117-765 20117-766 22117-949 20117-767 22117-951 20117-768 쮿 Further dimensions available on ServicePLUS configuration, see page 1.292 Door hinge bracket for shortened doors P 쮿 For doors which do not cover the full cabinet height 2 쮿 1 U space required (may be mounted above and below the door) 쮿 The clearance can be covered with 19" filler panels or with cable ducting plates 3 U/4 U Delivery comprises (kit) 1HE Item 1 2 3 Qty 1 1 1 Description Door hinge bracket, 19", St, 1.5 mm, RAL 7021 Trim, St, 1 mm, RAL 7021, cover for frame Assembly kit Order Information 1 4 00105068 4 Description Door hinge bracket for shortened doors Item 4 Cable ducting 3 U, RAL 7021, with brush strip and fixing materials kit, 1 piece Item 4 Cable ducting 4 U, RAL 7021, with brush strip and fixing materials kit, 1 piece Part no. 22117-798 20118-796 20118-797 37 55 쮿 19" front panels see chapter Cabinet Accessories, page 3.2 0 Cable ducting plate SCHROFF.PENTAIR.CO.UK 00201507 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.279 Cabinets – P Base plates P 쮿 For covering the base opening, two parts 쮿 Mounting on frame, overlaying Delivery comprises Item 1 Qty 2 2 1 Description Base plate, St, 1.5 mm, RAL 7021, width 469 mm, depth 234 mm (at cabinet depth 600 mm), depth 334 mm (at cabinet depth 800 mm) Assembly kit Order Information For cabinet width mm 600 600 For cabinet depth mm 600 800 Part no. 22117-826 22117-827 00108051 Plain bases/plinths P 쮿 Height 100 mm 쮿 Covers removable from all sides Delivery comprises 3 Item 1 2 4 4 Ø 15 1 2 Qty 4 2 2 1 Description Corner piece, AI die-cast Cover, St, 2.5 mm, RAL 7021, for front and rear Cover, St, 2.5 mm, RAL 7021, for sides Assembly kit Order Information w d ERA44532 00108057 For cabinet width For cabinet depth mm mm 600 600 600 800 Adjustable feet Load-carrying capacity 100 kg/foot, St and PA, black, PU 4 pieces Part no. 22117-830 22117-831 21101-201 Note 쮿 Castors cannot be used with a base/plinth era44553 1.280 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P Bases/plinths with ventilation P 쮿 Height 100 mm 쮿 Covers removable on all sides 쮿 Can be assembled with filter Delivery comprises (Kit) 4 6 Item 1 2 Qty 4 2 3 4 5 2 2 1 Description Corner piece, AI die-cast Cover, St, 2.5 mm, RAL 7021, for front and rear, with vent slots Cover, St, 2.5 mm, RAL 7021, for sides Filter retention Assembly kit Order Information 2 3 1 ERTP0057 For cabinet width For cabinet depth mm mm 600 600 600 800 Filter mat Item 6 for cabinet depth 600 mm, width 600 mm, PU 3 pieces Filter mat Item 6 for cabinet depth 800 mm, width 600 mm, PU 3 pieces Part no. 22117-864 22117-865 60114-514 60114-515 Note 쮿 Filter mat not included, please order separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.281 Cabinets – P Mounting system with C-profiles Mounting system P 쮿 The mounting system serves for assembly of horizontal and vertical mounting planes; C-profiles can be positioned freely by using combination and L-brackets in conjunction with slide nuts 쮿 Slide nuts, cable eyes or cable shells can be inserted directly into the C-profiles Delivery comprises Item 1 Qty see Order Information Description C-profile, St, 1.5 mm, finish AlZn Order Information ertp0020 C-profile/slide nut 25 9 Ø 5,25 30 20 30 10 L 15 5 1 ertp0021 Mounting bracket For cabinet For cabinet For Length L Qty/PU width depth cabinet height mm mm mm mm piece 600 – 450 4 600 800 – 650 4 900 – 750 4 600 – 650 4 800 800 – 650 4 – – 1600 1500 2 – – 1800 1650 2 – – 2000 1900 2 Item 2 Mounting bracket for cabinet upright or depth member assembly, St, 2.5 mm, zinc-plated, PU 4 pieces, incl. assembly kit Item 3 Combination bracket for connection of two C-profiles, St, 2.5 mm, zinc-plated, PU 4 pieces, incl. assembly kit Item 4 L-bracket for edge-to-edge or corner connection of two C-profiles, St, 2.5 mm, zinc-plated, 2 right hand brackets and 2 left hand brackets, incl. assembly kit Item 5 Slide nut for C-profiles, PU 10 pieces Item 5 Slide nut for C-profiles, PU 100 pieces Delivery: supplied loose with cabinet or frame Part no. 22114-455 22114-457 22114-458 22114-457 22114-457 22114-460 22114-461 22114-462 21120-145 21120-146 21120-147 21120-140 21101-127 Part no./35 Note ertp0022 쮿 Please order mounting brackets separately Combination bracket ertp0024 L-bracket ertp024a 1.282 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P Cable eyes for C-profiles P Delivery comprises Item 1 D= W 95 =9 5 75 D= W =4 0 D= Qty 4 45 Description Cable eye, round steel, 6 mm, zinc-plated, with integrated anti-rotation protection Order Information W Description W mm Cable eye for C-profile 120 Cable eye for C-profile 40 Cable eye for C-profile 95 Assembly kit for 4 cable eyes, PU 1 kit =1 20 00507050 00507051 00507052 D mm 45 75 95 Part no. 20118-339 20118-554 20118-340 21101-596 Note 쮿 Please order assembly kit separately Cable shells P 쮿 For mounting of cables on C-profiles and cable support rails Delivery comprises Item 1 Qty 10 Description Cable shell, St, 2 mm, tin-plated, with plastic half shells Order Information For cable bundle d mm 18 ... 22mm 22 ... 26mm 26 ... 30mm 30 ... 34mm 34 ... 38mm 38 ... 42mm 42 ... 46mm 46 ... 50mm b mm 26 30 34 38 45 48 51 54 Part no. 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 vnt009 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.283 Cabinets – P Slide rail P 쮿 For safe and simple installation of heavy 19" subracks 쮿 Can be hung into the upright at 1 U increments 쮿 Load-carrying capacity max. 25 kg per pair Delivery comprises c D Item 1 2 1 Qty 10 1 Description Slide rail for insertion, St, 1.5 mm, surface AlZn Assembly kit Order Information c = pitch of the 19" uprights xf W For cabinet depth mm 600 800 00205059 00205069 Length L mm 420 620 c mm 480 680 xf mm 60 60 Part no. 21127-197 21127-198 Note 쮿 Can only be fitted to 19" upright 쮿 Further dimensions available on ServicePLUS, see from page 1.298 L = length 41003080 Short slide rail P 쮿 For mounting on the vertical cabinet uprights 쮿 Can be hung at 1 U increments 쮿 Static load-carrying capacity 15 kg max per pair Delivery comprises Item 1 2 Qty 2 / 10 1 Description Short slide rail, St, 1,5 mm, finish AlZn Assembly kit Order Information sc96xxxx 1.284 SCHROFF PRODUCT CATALOG E 11/2017 Description Short slide rail Short slide rail Qty/PU 2 10 Part no. 20118-592 20118-593 ELECTRONICS PROTECTION Cabinets – P 19'' fixed shelf, 75 kg P 쮿 Static load-carrying capacity 75 kg 쮿 Mounting height 1 U, for mounting on cabinet uprights, full depth 쮿 With hammer head perforation to fix cable ties Delivery comprises Item 1 2 1 Qty 1 1 Description Shelf, St, 1.5 mm, RAL 7021 Assembly kit incl. GND/earthing kit Order Information 00105054 Cabinet dimensions WxD mm 600 x 600 600 x 800 Usable surface wxd mm 477 x 443 477 x 643 xf xr c mm mm mm 60 60 480 60 60 680 Part no. 22117-842 22117-843 Note 쮿 Further dimensions available on ServicePLUS, see from page 1.299 00105050 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.285 Cabinets – P 19'' telescopic shelf, 70 kg P 쮿 Static load-carrying capacity at full extension 70 kg 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 쮿 Incl. telescopic slides 1 쮿 Locking with T-bar lock possible 2 쮿 Hammer head perforation to fix cable ties 4 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Delivery comprises 00105052 Full depth Item 1 2 3 Qty 1 2 1 Description Shelf with perforation, St, 1.5 mm, RAL 7021 Telescopic slide, 2 U Assembly kit Order Information Full depth Cabinet dimensions Usable surface c WxD wxd mm mm mm 600 x 600 405 x 482 480 600 x 800 405 x 682 680 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic shelf PU 1 kit, for NOVASTAR, eurorack Full depth Part no. 21130-353 21130-355 23130-092 21120-189 00105069 Shortened depth Order Information Shortened by 100 mm Cabinet dimensions Usable surface c Shortened by WxD wxd 100 mm mm mm mm Part no. 600 x 600 405 x 382 480 21130-352 600 x 800 405 x 582 680 21130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted 23130-092 right or left), 1 piece GND/earthing for telescopic shelf PU 1 kit, for NOVASTAR, 21120-189 eurorack c = max. pitch of the slide mounts 1.286 SCHROFF PRODUCT CATALOG E 11/2017 00105070 ELECTRONICS PROTECTION Cabinets – P Cable panels P 쮿 For mounting direct onto the frame, can be recessed with depth members 쮿 Fixing of cables with cable ties or Velcro 쮿 Colour RAL 7021 (black grey) or RAL 7035 (light grey) 쮿 Widths 150 mm and 250 mm 1 Delivery comprises Item 1 2 Qty 2 1 Description Cable panel with cut-outs, St, 1 mm Assembly kit Order Information H For cabinet height H D RAL 7021 U mm mm Part no. 38 1798 150 23117-020 43 1934 150 23117-021 47 2020 150 23117-022 38 1798 250 23117-023 43 1934 250 23117-024 47 2020 250 23117-025 Depth member for 19" eurorack 600 mm cabinet depth, St, 1.5 mm, AlZn, PU 2 pieces Depth member for 19" eurorack 800 mm cabinet depth, St, 1.5 mm, AIZn, PU 2 pieces 10 D 00108050 RAL 7035 Part no. 23117-026 23117-027 23117-028 23117-029 23117-030 23117-031 22117-376 22117-377 Note 쮿 Cable ties, see page 1.287 쮿 Velcro, see page 1.287 Cable ties P Delivery comprises Item 1 Qty 25 Description Cable tie, plastic Order Information Description Cable tie Cable tie Cable tie Part no. 92 mm x 2.5 mm 186 mm x 5 mm 360 mm x 5 mm 20118-351 20118-352 20118-353 01005078 Velcro P 쮿 Length 300 mm (for cable bundles of max. 90 mm diameter) Delivery comprises Item 1 Qty 10 Description Velcro strip, PE/PA, black, length 300 mm Order Information Description Velcro strip Part no. 20118-624 01005079 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.287 Cabinets – P19" ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.289 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 15 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts 19" Servic ePLUS 1.288 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P 19" ServicePLUS eurorack 19" ServicePLUS: configuration and assembly 1 9" ServicePLUSP 쮿 Dimensions: – Height: 20 ... 47 U (998 ... 2198 mm) – Width: 600 mm – Depth: 600, 800 mm Page Frames, side-by-side mounting kit, GND/ earthing, adjustable feet, castors 1.290 Side panels, glass doors 1.291 쮿 Build your cabinet out of individual components (please suffix each part number with /05) Doors 1.292 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) Door hinge bracket, cable 1.293 ducting 쮿 Colours: – Frame, top cover and plinth in black grey (RAL 7021); – Side panels and doors in light grey (RAL 7035) or black grey (RAL 7021) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Flush top covers 1.294 Raised top covers 1.295 Base plates, plinths 1.296 Third 19" plane, lateral cable ducting 1.297 19" slide rails 1.298 19" fixed or telescopic shelves 1.299 Dimensions 19" frame 1.274 ServicePLUS configuration eurorack Universal 1.300 00101534 Example configuration (here: row 14) Qty 1 1 1 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description 19" frame, RAL 7021, height 2020 mm, width 600 mm, depth 800 mm, 1 piece Adjustable foot, PU 4 pieces Side panel, screw fixed, RAL 7035, PU 2 pieces Front glass door, RAL 7035, opening angle 120°, 1 piece Rear steel door, RAL 7035, opening angle 120°, 1 piece DIN profile half cylinder, 1 piece .......... Order no. 22117-779/05 21101-201/05 21117-172/05 20117-751/05 21117-190/05 60114-121/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.289 Cabinets – P19" ServicePLUS eurorack 19" Frames, side-by-side mounting kit, GND/earthing, adjustable feet, castors Order Information 19" frame 19" plane to front and rear era45341 Side-by-side mounting kit GND/earthing Castors Load-carrying capacity 180 kg per kit ERTP0070 serves to bolt 19" frame, together frame Al die-cast, two cabinets; uprights sealing strips are Al extrusion, PU foam RAL 7021, defined pitch between front and rear 19" plane Adjustable feet aza43284 era44553 for frame, door, side panel, top cover, base plate St, PA, black, load-carrying capacity 100 kg per foot Load-carrying capacity 300 kg per kit era44556 assembly directly assembly directly onto frame, onto frame, height H = height H = 110 mm, 93 mm, 2 locking, 2 locking, 2 non2 non-locking lockingcastors castors Cabinet dimensions Width Depth 1 piece 1 piece PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces No. U Height mm mm mm assembled supplied loose assembled assembled enclosed loose enclosed loose 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 22117-977 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20117-156 21101-539 21101-201 20117-757 20117-024 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 22117-978 22117-979 22117-980 22117-981 22117-982 22117-772 22117-773 22117-774 22117-775 22117-776 22117-977 22117-978 22117-979 22117-980 22117-983 22117-981 22117-984 Frame dimensions, see page 1.274 1.290 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P19" ServicePLUS eurorack 19" Side panels, glass doors Order Information Side panel with side-panel catches Side panel with safety lock Glass door Opening angle 120° ERA44517 St, 1 mm, RAL 7035, 2 side panel catches; instead of a side panel, doors can also be mounted laterally Cabinet dimensions Height St, 1 mm, RAL 7021, 2 side panel catches; instead of a side panel, doors can also be mounted laterally ERA44517 St, 1 mm, RAL 7035, 2 safety locks; instead of a side panel, doors can also be mounted laterally St, 1 mm, RAL 7021, 2 safety locks; instead of a side panel, doors can also be mounted laterally mra45967 glazing smoke grey, Sekurit, 6 mm, safety lock with 2 keys DIN profile half cylinder 00101506 glazing smoke grey, Sekurit, 6 mm, lever handle (incl. blank insert) SZA44484 DIN profile half cylinder for lever handle RAL 7035 RAL 7021 RAL 7035 RAL 7021 Width Depth PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled – – 20117-745 – – – – 20117-746 – – 20117-747 22117-239 60114-121 20117-748 22117-227 60114-121 20117-749 22117-228 60114-121 20117-751 22117-229 60114-121 20117-752 22117-230 60114-121 No. U mm mm mm assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 21117-158 22117-993 21117-167 21117-159 22117-994 22117-995 21117-168 22117-996 21117-160 21117-169 22117-997 22117-998 22117-185 22117-186 23117-002 23117-003 21117-161 22117-958 22117-173 23117-004 21117-170 21117-179 22117-959 22117-960 22117-177 22117-181 23117-005 23117-006 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 Glass door Opening angle 180° 21117-162 22117-961 22117-174 23117-007 21117-171 21117-180 22117-962 22117-963 22117-178 22117-182 23117-008 23117-009 21117-163 22117-964 22117-175 22117-968 21117-172 21117-181 22117-965 22117-966 22117-179 22117-592 22117-969 22117-970 21117-164 22117-999 22117-176 23117-010 21117-173 21117-182 22117-967 23117-001 22117-180 22117-593 22117-971 22117-972 Note: Doors can also be assembled laterally, in place of side panels SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.291 Cabinets – P19" ServicePLUS eurorack 19" Doors Order Information Glazed acrylic glass door Steel door Opening angle 120° Opening angle 120° Steel door a4491b frame, Al, 2 mm, frame, Al, 2 mm, RAL 7021; RAL 7021; acrylic glass, acrylic glass, 2 mm, 2 mm, safety lock with safety lock with 2 keys 2 keys Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 1.292 Opening angle 180° 00101506 DIN profile half cylinder 00101504 St, 1 mm, RAL 7035, safety lock with 2 keys St, 1 mm, RAL 7035, safety lock with 2 keys St, 1 mm, RAL 7035, lever handle (incl. blank insert), please order DIN profile half cylinder separately St, 1 mm, RAL 7021, lever handle (incl. blank insert), please order DIN profile half cylinder separately RAL 7021 SZA44484 DIN profile half cylinder for lever handle RAL 7035 RAL 7021 RAL 7035 RAL 7021 RAL 7035 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled assembled 20117-770 22117-944 21117-185 22117-935 – – – 20117-771 22117-945 21117-186 22117-936 – – – 20117-772 23117-011 21117-187 23117-012 22117-201 23117-013 60114-121 20117-765 22117-946 21117-188 22117-937 22117-189 23117-014 60114-121 20117-766 22117-947 21117-189 22117-938 22117-190 23117-015 60114-121 20117-767 22117-949 21117-190 22117-940 22117-191 22117-973 60114-121 20117-768 22117-951 21117-191 22117-942 22117-192 22117-975 60114-121 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P19" ServicePLUS eurorack 19" Door hinge bracket, cable ducting Order Information Door hinge bracket for 19" frame Cable ducting frame 3U 4U 00105068 07011081 St, 2.5 mm, RAL 7021, St, 1.5 mm, with black brush strip for short doors RAL 7021, or rear panels mounting to front or rear, above or below the short door, 1U assembly area, please order 19" cable ducting separately Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece assembled assembled assembled 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 22117-798 20118-796 20118-797 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.293 Cabinets – P19" ServicePLUS eurorack 19" Flush top covers Order Information Flush top cover Plain Louvered Top cover fan for flush louvered top cover Lifting eyes Fan trays without fans Fan for fan tray Thermostat Speed control 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm ERA44525 St, 1 mm, RAL 7021 ERA45344 ERA44560 St, 1 mm, RAL 7030 lifting eye for flush cover, application and static loadcarrying capacity in accordance with DIN 582 ertp0055 St, 1.5 mm, RAL 7021, all 6 openings closed with PE blank plugs, terminal clamp with connecting cable, 2 m, IEC60320 C14 plug KTA44844 axial fan 230 VAC, 8 W, 90 m3/h, height 25 mm, protective grille, plastic, black, flammability UL 94 V-0 01108052 01105055 for air barrier, fully wired, with mains cable 90 ... 264 VAC, 230 VAC input SCHUKO/ UTE plug, (SCHUKO/UTE outlet IEC 60320 plug/ C13 socket; IEC 60320 C13 external NTC socket), sensor 1.5 m adjustment range 0 ... 60°C Cabinet dimensions Width Depth 1 piece 1 piece PU 4 pieces 1 piece 1 piece 1 piece 1 piece No. U Height mm mm mm assembled assembled assembled assembled assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 22117-801 22117-806 22117-802 22117-807 20713-048 20118-750 60715-005 22117-801 22117-802 22117-806 22117-807 20713-048 20118-750 60715-005 22117-801 22117-806 22117-802 22117-801 22117-807 22117-806 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 1.294 22117-802 22117-807 22117-803 22117-801 22117-808 22117-806 22117-802 22117-807 22117-803 22117-801 22117-808 22117-806 22117-802 22117-807 22117-803 22117-801 22117-808 22117-806 22117-802 22117-807 22117-803 22117-808 SCHROFF PRODUCT CATALOG E 11/2017 20117-080 20117-080 20117-080 20117-080 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-823 22117-821 20117-080 22117-822 22117-823 22117-821 20117-080 22117-822 22117-823 22117-821 20117-080 22117-822 22117-823 ELECTRONICS PROTECTION Cabinets – P19" ServicePLUS eurorack 19" Raised top covers Order Information Raised top cover Raised Fan for raised top cover Lifting eyes Fan tray without fan Fan for fan tray Thermostat Speed control 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm ERA44526 ERA44560 St, 1.5 mm, RAL 7021, air gap all round 8 mm, IP 20 lifting eye for raised top cover, application and static loadcarrying capacity in accordance with DIN 582 ertp0055 KTA44844 KTA44844 01108052 01105055 axial fan 230 VAC, axial fan 230 VAC, St, 1.5 mm, fully wired, for air barrier, RAL 7021, 90 ... 264 VAC, with mains cable 15 W, 162 m3/h, 8 W, 90 m3/h, all 6 openings 230 VAC height 38 mm, height 25 mm, input SCHUKO/ closed with PE plastic, black, plastic, black, UTE plug, (SCHUKO/UTE blank plugs, flammability flammability outlet IEC 60320 plug/IEC 60320 terminal UL 94 V-0 UL 94 V-0 C13 socket; C13 socket), clamp with external NTC adjustment range connecting cable, sensor 1.5 m 0 ... 60°C 2 m, IEC-60320 C14 plug Cabinet dimensions Width Depth 1 piece PU 4 pieces 1 piece 1 piece 1 piece 1 piece 1 piece No. U Height mm mm mm assembled assembled assembled assembled assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 22117-811 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 SCHROFF.PENTAIR.CO.UK 22117-812 22117-811 22117-812 22117-811 22117-812 22117-811 22117-812 20150-011 20150-011 20150-011 20150-011 22117-813 22117-811 22117-812 20150-011 22117-813 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-822 22117-823 22117-821 20150-011 22117-813 22117-811 22117-812 22117-822 22117-823 22117-821 22117-813 22117-811 22117-812 22117-821 22117-822 22117-823 22117-821 20150-011 22117-822 22117-823 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.295 Cabinets – P19" ServicePLUS eurorack 19" Base plates, plinths Order Information Base plate Fixed base/plinth , height 100 mm Plain 00108051 St, 1.5 mm, RAL 7021, two parts, mounting on frame With ventilation ERA44532 base, Al die-cast, covers, St, 2.5 mm, RAL 7021 Filter mat ERTP0057 base/plinth, Al die-cast, covers, St, 2.5 mm, RAL 7021, front and rear with ventilation openings; please order filter mat separately ERTP0057 Adjustable feet era44553 filter mat for fixed base/plinth, with ventilation St, PA, black, load-carrying capacity 100 kg per foot Cabinet dimensions Width Depth PU 2 pieces 1 piece 1 piece PU 3 pieces PU 4 pieces No. U Height mm mm mm enclosed loose assembled assembled enclosed loose assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 22117-826 22117-830 22117-864 60114-514 22117-827 22117-831 22117-865 60114-515 22117-826 22117-827 22117-830 22117-831 22117-864 22117-865 60114-514 60114-515 22117-826 22117-830 22117-864 60114-514 22117-827 22117-826 22117-831 22117-830 22117-865 22117-864 60114-515 60114-514 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 1.296 22117-827 22117-831 22117-865 60114-515 22117-828 22117-826 22117-832 22117-830 22117-866 22117-864 – 60114-514 22117-827 22117-831 22117-865 60114-515 22117-828 22117-826 22117-832 22117-830 22117-866 22117-864 – 60114-514 22117-827 22117-831 22117-865 60114-515 22117-828 22117-826 22117-832 22117-830 22117-866 22117-864 – 60114-514 22117-827 22117-831 22117-865 60114-515 22117-828 22117-832 22117-866 – SCHROFF PRODUCT CATALOG E 11/2017 21101-201 21101-201 21101-201 21101-201 21101-201 21101-201 21101-201 ELECTRONICS PROTECTION Cabinets – P19" ServicePLUS eurorack 19" Third 19" plane, lateral cable ducting Order Information 19" panel/slide mount RAL 7021 Depth member AlZn SZA45958 St, 1.5 mm, with 19" cut-outs; to mount a third 19" plane, 1 pair of 19" panel/slide mounts and 2 pairs of depth members are required Width Cable panel Width 250 mm ertp0043 St, 1.5 mm, AlZn, for assembly of the third 19" plane or other components 00108061 St, 1 mm, RAL 7035, with cut-outs for cable ties or Velcro St, 1 mm, RAL 7021, with cut-outs for cable ties or Velcro 00108061 St, 1 mm, RAL 7035, with cut-outs for cable ties or Velcro St, 1 mm, RAL 7021, with cut-outs for cable ties or Velcro RAL 7021 AlZn AlZn RAL 7035 RAL 7021 RAL 7035 RAL 7021 PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces assembled assembled assembled assembled assembled assembled assembled – – – – – – – – – – – – – – – – 23117-026 23117-020 23117-029 23117-023 23117-027 23117-021 23117-030 23117-024 23117-028 23117-022 23117-031 23117-025 No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 Cable panel Width 150 mm Depth Cabinet dimensions Height Lateral cable ducting For 19" eurorack SCHROFF.PENTAIR.CO.UK 23117-017 22117-352 23117-018 22117-353 23117-019 22117-354 22117-835 22117-355 22117-376 22117-377 22117-376 22117-377 22117-376 22117-377 22117-376 22117-377 22117-378 22117-376 22117-836 22117-356 22117-377 22117-378 22117-376 22117-837 22117-357 22117-377 22117-378 22117-376 22117-838 22117-358 22117-377 22117-378 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.297 Cabinets – P19" ServicePLUS eurorack 19" 19" slide rails Order Information Dimensions standard assembly Slide rail Short slide rail 40 kg, depthadjustable W xf c D 25 kg 00205066 xf = distance from front c = pitch of 19" plane D = cabinet depth W = cabinet width 00108056 St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair 41003081 St, 1,5 mm, finish AlZn, static loadcarrying capacity 40 kg/pair, depth-adjustable (c: 675 - 850 mm) sc96xxxx St, 1.5 mm, finish AlZn, static loadcarrying capacity 15 kg/pair Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 1.298 xf mm 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 c mm 480 680 480 680 480 680 480 680 780 480 680 780 480 680 780 480 680 780 PU 2 pieces PU 10 pieces PU 2 pieces PU 2 pieces PU 10 pieces enclosed loose enclosed loose enclosed loose enclosed loose enclosed loose 22127-094 21127-197 – 22127-095 21127-199 28127-001 20118-592 20118-593 22127-094 22127-095 21127-197 21127-199 28127-001 20118-592 20118-593 22127-094 21127-197 – 22127-095 22127-094 21127-199 21127-197 28127-001 20118-592 20118-593 22127-095 21127-198 28127-001 20118-592 20118-593 22127-096 22127-094 21127-199 21127-197 28127-001 22127-095 21127-198 28127-001 20118-592 20118-593 22127-096 22127-094 21127-199 21127-197 28127-001 22127-095 21127-198 28127-001 20118-592 20118-593 22127-096 22127-094 21127-199 21127-197 28127-001 22127-095 21127-198 28127-001 20118-592 20118-593 22127-096 21127-199 28127-001 SCHROFF PRODUCT CATALOG E 11/2017 – – – – – ELECTRONICS PROTECTION Cabinets – P19" ServicePLUS eurorack 19" 19" fixed or telescopic shelves Order Information Fixed shelf, 1 U, 75 kg Full depth Shelf, telescopic, 2 U, 70 kg Recessed by c 100 mm Full depth Shortened by 100 mm T-bar lock GND/earthing W xf c D Dimensions standard assembly 00205066 00105050 St, 1.5 mm, xf = distance from RAL 7021, with front c = pitch of perforation, 19" plane static loadD = cabinet depth carrying capacity W = cabinet 75 kg, incl. GND/ width earthing 00105051 St, 1.5 mm, RAL 7021, with perforation, static loadcarrying capacity 75 kg, incl. GND/ earthing, third 19" plane necessary, please order separately 00105069 00105070 St, 1.5 mm, staic load-carrying capacity 70 kg, incl. telescopic slide; please order T-bar lock and GND/ earthing separately 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 2020 2020 2020 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 800 600 800 600 800 600 800 900 600 800 900 600 800 900 600 800 900 20 20 25 25 29 29 34 34 34 38 38 38 43 43 43 47 47 47 SCHROFF.PENTAIR.CO.UK xf mm 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 c mm 480 680 480 680 480 680 480 680 780 480 680 780 480 680 780 480 680 780 1 piece 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled assembled 22117-842 22117-845 21130-353 21130-352 23130-092 21120-189 22117-843 22117-871 21130-355 21130-354 23130-092 21120-189 22117-842 22117-843 22117-845 22117-871 21130-353 21130-355 21130-352 21130-354 23130-092 23130-092 21120-189 21120-189 22117-842 22117-845 21130-353 21130-352 23130-092 21120-189 22117-843 22117-842 22117-871 22117-845 21130-355 21130-353 21130-354 21130-352 23130-092 23130-092 21120-189 21120-189 22117-843 22117-871 21130-355 21130-354 23130-092 21120-189 22117-844 22117-842 22117-843 22117-845 – – – – 21130-353 21130-352 23130-092 21120-189 22117-843 22117-871 21130-355 21130-354 23130-092 21120-189 22117-844 22117-842 22117-843 22117-845 – – – – 21130-353 21130-352 23130-092 21120-189 22117-843 22117-871 21130-355 21130-354 23130-092 21120-189 22117-844 22117-842 22117-843 22117-845 – – – – 21130-353 21130-352 23130-092 21120-189 22117-843 22117-871 21130-355 21130-354 23130-092 21120-189 22117-844 22117-843 – – – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.299 Cabinets – PUniversal ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.301 assembly Assembled by professionals. Double benefit! Assembly of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 15 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, maintenance, repair, replacement parts, recycling Universal ServicePLUSP 1.300 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – P Universal ServicePLUS eurorack Universal ServicePLUS: configuration and assembly Universal ServicePLUSP 쮿 Dimensions: – Height: 20 ... 47 U (998 ... 2198 mm) – Width: 600, 800 mm – Depth: 600, 800, 900 mm Page 쮿 Colours: – Frame, top cover and plinth in black grey (RAL 7021); – Side panels and doors in light grey (RAL 7035) or black grey (RAL 7021) Frames, side-by-side mounting kit, GND/ earthing, adjustable feet, castors 1.302 Doors 1.303 Door hinge bracket, cable 1.305 ducting 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Flush top covers 1.306 Raised top covers 1.307 Base plates, plinths 1.308 19" panel/slide mounts 1.309 19" slide rails 1.311 Fixed 19" shelves 1.312 Telescopic 19" shelves 1.313 Fixed shelves on Universal cabinet uprights Telescopic shelves on Universal cabinet uprights Dimensions Universal frame 1.314 1.315 1.275 00101534 Example configuration (here: row 17) Qty 1 1 2 2 1 .. SCHROFF.PENTAIR.CO.UK Description Universal frame, RAL 7021, height 2020 mm, width 600 mm, depth 900 mm, 1 piece Adjustable foot, PU 4 pieces Lateral steel door, opening angle 120°, RAL 7035, 1 piece Front, rear glass door, RAL 7035, opening angle 180°, 1 piece DIN profile half cylinder, 1 piece .......... Order no. 22117-792/05 21101-201/05 21117-190/05 22117-229/05 60114-121/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.301 Cabinets – PUniversal ServicePLUS eurorack Universal Frames, side-by-side mounting kit, GND/earthing, adjustable feet, castors Order Information Universal frame (without 19" plane) Side-by-side mounting kit era44489 Universal frame, rack Al die-cast, uprights Al extrusion, 19" plane can be built in 25 mm increments with depth members and depthadjustable 19" panel/slide mounts GND/earthing Castors Load-carrying capacity 180 kg per kit ERTP0070 serves to screw together two cabinets Adjustable feet aza43284 era44553 for frame, door, side panel, top cover, base plate St, PA, black, load-carrying capacity 100 kg per foot Load-carrying capacity 300 kg per kit era44556 assembly directly assembly directly onto frame, onto frame, height height H = 110 mm, H = 93 mm, 2 locking, 2 non- 2 locking, 2 nonlocking castors locking castors Cabinet dimensions Width Depth 1 piece 1 piece PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces No. U Height mm mm mm assembled supplied loose assembled assembled enclosed loose enclosed loose 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-985 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 20117-515 21101-539 21101-201 20117-757 20117-024 22117-796 22117-992 20117-515 21101-539 21101-201 20117-757 20117-024 22117-797 20117-515 21101-539 21101-201 20117-757 20117-024 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 22117-986 22117-987 22117-988 22117-989 22117-990 22117-782 22117-783 22117-784 22117-985 22117-986 22117-787 22117-788 22117-789 22117-790 22117-791 22117-792 22117-793 22117-794 22117-991 Frame dimensions, see page 1.275 1.302 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal Side panels, glass doors Order Information Side panel with side-panel catches Side panel with safety lock Glass door Opening angle 120° ERA44517 St, 1 mm, RAL 7035, 2 side panel catches; instead of a side panel, doors can also be mounted laterally Cabinet dimensions Height St, 1 mm, RAL 7021, 2 side panel catches; instead of a side panel, doors can also be mounted laterally ERA44517 St, 1 mm, RAL 7035, 2 safety locks; instead of a side panel, doors can also be mounted laterally St, 1 mm, RAL 7021, 2 safety locks; instead of a side panel, doors can also be mounted laterally mra45967 glazing smoke grey, Sekurit, 6 mm, safety lock with 2 keys DIN profile half cylinder 00101506 glazing smoke grey, Sekurit, 6 mm, lever handle (incl. blank insert) SZA44484 DIN profile half cylinder for lever handle RAL 7035 RAL 7021 RAL 7035 RAL 7021 Width Depth PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled – – 20117-745 – – – – 20117-746 – – 20117-747 22117-239 60114-121 20117-748 22117-227 60114-121 20117-749 22117-228 60114-121 20117-754 22117-236 60114-121 20117-751 22117-229 60114-121 20117-753 22117-237 60114-121 20117-752 22117-230 60114-121 20117-756 22117-238 60114-121 No. U mm mm mm assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 21117-158 22117-993 21117-167 21117-159 22117-994 22117-995 21117-168 22117-996 21117-160 21117-169 22117-997 22117-998 22117-185 22117-186 23117-002 23117-003 21117-161 22117-958 22117-173 23117-004 21117-170 21117-179 22117-959 22117-960 22117-177 22117-181 23117-005 23117-006 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 Glass door Opening angle 180° 21117-162 22117-961 22117-174 23117-007 21117-171 21117-180 22117-962 22117-963 22117-178 22117-182 23117-008 23117-009 21117-162 22117-961 22117-174 23117-007 21117-171 21117-163 22117-962 22117-964 22117-178 22117-175 23117-008 22117-968 21117-172 22117-965 22117-179 22117-969 21117-181 21117-163 22117-966 22117-964 22117-592 22117-175 22117-970 22117-968 21117-172 22117-965 22117-179 22117-969 21117-164 21117-173 22117-999 22117-967 22117-176 22117-180 23117-010 22117-971 21117-182 23117-001 22117-593 22117-972 21117-173 22117-967 22117-180 22117-971 Note: Doors can also be assembled laterally, in place of side panels SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.303 Cabinets – PUniversal ServicePLUS eurorack Universal Doors Order Information Glazed acrylic glass door Steel door Opening angle 120° Opening angle 120° Steel door a4491b Cabinet dimensions Height Width Depth No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 1.304 Opening angle 180° 00101506 DIN profile half cylinder 00101504 SZA44484 DIN profile half cylinder for lever handle frame, Al, 2 mm, RAL 7035; acrylic glass, 2 mm, safety lock with 2 keys frame, Al, 2 mm, RAL 7021, acrylic glass, 2 mm, safety lock with 2 keys St, 1 mm, RAL 7035, safety lock with 2 keys St, 1 mm, RAL 7021, safety lock with 2 keys St, 1 mm, RAL 7035, lever handle (incl. blank insert), please order DIN profile half cylinder separately St, 1 mm, RAL 7021, lever handle (incl. blank insert), please order DIN profile half cylinder separately RAL 7035 RAL 7021 RAL 7035 RAL 7021 RAL 7035 RAL 7021 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled assembled 20117-770 22117-944 21117-185 22117-935 – – – 20117-771 22117-945 21117-186 22117-936 – – – 20117-772 23117-011 21117-187 23117-012 22117-201 23117-013 60114-121 20117-765 22117-946 21117-188 22117-937 22117-189 23117-014 60114-121 20117-766 22117-947 21117-189 22117-938 22117-190 23117-015 60114-121 20117-775 22117-948 21117-198 22117-939 22117-198 23117-016 60114-121 20117-767 22117-949 21117-190 22117-940 22117-191 22117-973 60114-121 20117-776 22117-950 21117-199 22117-941 22117-199 22117-974 60114-121 20117-768 22117-951 21117-191 22117-942 22117-192 22117-975 60114-121 20117-777 22117-952 21117-200 22117-957 22117-200 22117-976 60114-121 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal Door hinge bracket, cable ducting Order Information Door hinge bracket for Universal frame Cable ducting frame 3U 4U 00105068 St, 1.5 mm, RAL 7021, assembly above or below shortened door, 1 U assembly area, please order 19" panel/ slide mount and cable ducting plate separately SZA45958 St, 2.5 mm, RAL 7021, with black brush strip for short doors or rear panels Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece assembled assembled assembled 22117-799 20118-796 20118-797 22117-799 20118-796 20118-797 22117-799 20118-796 20118-797 22117-799 20118-796 20118-797 22117-799 20118-796 20118-797 – – – 22117-799 20118-796 20118-797 – – – 22117-799 20118-796 20118-797 – – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.305 Cabinets – PUniversal ServicePLUS eurorack Universal Flush top covers Order Information Flush top cover Plain Louvered Top cover fan for flush louvered top cover Lifting eyes Fan tray without fan Fan for fan tray Thermostat Speed control 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm ERA44525 St, 1 mm, RAL 7021 ERA45344 ERA44560 St, 1 mm, RAL 7030 lifting eye for flush cover, application and static loadcarrying capacity in accordance with DIN 582 ertp0055 St, 1.5 mm, RAL 7021, all 6 openings closed with PE blank plugs, terminal clamp with connecting cable, 2 m, IEC 60320 C14 plug KTA44844 01108052 01105055 axial fan 230 VAC, for fan tray, fully wired, with mains cable 90 ... 264 VAC, 8 W, 90 m3/h, 230 VAC height 25 mm, input SCHUKO/ protective grille, UTE plug, (SCHUKO/UTE plastic, black, outlet IEC 60320 plug/IEC 60320 flammability C13 socket; C13 socket), UL 94 V-0 external NTC adjustment range sensor 1.5 m 0 ... 60 °C Cabinet dimensions Width Depth 1 piece 1 piece PU 4 pieces 1 piece 1 piece 1 piece 1 piece No. U Height mm mm mm assembled assembled assembled assembled assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-801 22117-806 22117-802 22117-807 20713-048 20118-750 60715-005 22117-801 22117-802 22117-806 22117-807 20713-048 20118-750 60715-005 22117-801 22117-806 22117-802 22117-801 22117-807 22117-806 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20713-048 20118-750 60715-005 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 1.306 22117-802 22117-807 22117-803 22117-801 22117-808 22117-806 22117-802 22117-807 22117-803 22117-802 22117-808 22117-807 22117-804 22117-809 22117-801 22117-802 22117-806 22117-807 22117-803 22117-808 22117-802 22117-804 22117-807 22117-809 20117-080 20117-080 20117-080 20117-080 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-823 22117-821 20117-080 20117-080 20117-080 22117-822 22117-823 22117-824 22117-825 22117-821 22117-822 22117-823 20117-080 22117-824 22117-825 22117-801 22117-806 22117-802 22117-803 22117-807 22117-808 20117-080 22117-822 22117-823 20713-048 20118-750 60715-005 22117-804 22117-809 20117-080 22117-825 20713-048 20118-750 60715-005 SCHROFF PRODUCT CATALOG E 11/2017 22117-821 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal Raised top covers Order Information Raised top cover Raised Fan for raised top cover Lifting eyes Fan tray without fan Fan for fan tray Thermostat Speed control 30 20 40 10 50 0 60 °C 1000 mm 300 mm 300 mm ERA44526 ERA44560 St, 1.5 mm, RAL 7021, air gap all round 8 mm, IP 20 lifting eye for raised top cover, application and static loadcarrying capacity in accordance with DIN 582 ertp0055 KTA44844 01108052 01105055 axial fan 230 VAC, axial fan 230 VAC, St, 1.5 mm, for fan tray, fully wired, RAL 7021, with mains cable 90 ... 264 VAC, 15 W, 162 m3/h, 8 W, 90 m3/h, all 6 openings 230 VAC height 38 mm, height 25 mm, input SCHUKO/ closed with PE protective grille, protective grille, UTE plug, (SCHUKO/UTE blank plugs, plastic, black, plastic, black, outlet IEC 60320 plug/IEC 60320 terminal clamp flammability flammability C13 socket; C13 socket), with connecting UL 94 V-0 UL 94 V-0 external NTC adjustment range cable, 2 m, IECsensor 1.5 m 0 ... 60°C 60320 C14 plug Cabinet dimensions Width Depth 1 piece PU 4 pieces 1 piece 1 piece 1 piece 1 piece 1 piece No. U Height mm mm mm assembled assembled assembled assembled assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-811 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20713-243 20713-048 20118-750 60715-005 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 SCHROFF.PENTAIR.CO.UK 22117-812 22117-811 22117-812 22117-811 22117-812 22117-811 22117-812 20150-011 20150-011 20150-011 20150-011 22117-813 22117-811 22117-812 22117-813 22117-812 22117-814 22117-811 22117-812 22117-822 22117-821 22117-822 22117-821 22117-822 22117-821 22117-822 22117-823 22117-821 20150-011 20150-011 20150-011 22117-813 22117-812 22117-814 22117-821 22117-822 22117-823 22117-824 22117-825 22117-821 22117-822 22117-823 20150-011 22117-811 22117-824 22117-825 22117-821 22117-812 22117-813 20150-011 22117-824 22117-823 20713-243 20713-048 20118-750 60715-005 22117-814 20150-011 22117-825 20713-243 20713-048 20118-750 60715-005 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.307 Cabinets – PUniversal ServicePLUS eurorack Universal Base plates, plinths Order Information Base plate Fixed base/plinth , height 100 mm Plain 00108051 St, 1.5 mm, RAL 7021, two parts, mounting on frame With ventilation ERA44532 base/plinth, Al die-cast, covers, St, 2.5 mm, RAL 7021 Filter mat ERTP0057 base/plinth, Al die-cast, covers, St, 2.5 mm, RAL 7021, front and rear with ventilation openings ERTP0057 Mobile base/plinth Adjustable feet Base/plinth era44553 filter mat for fixed base/plinth, with ventilation St, PA, black, load-carrying capacity 100 kg per foot Jacking foot era45323 ERA44532 Al die-cast, RAL 7021, static loadcarrying capacity 300 kg, with rubber mat, 4 castors, PA for mobile base, mounted below front, adjustment from above Cabinet dimensions Width Depth PU 2 pieces 1 piece 1 piece PU 3 pieces PU 4 pieces 1 piece PU 2 pieces No. U Height mm mm mm enclosed loose assembled assembled enclosed loose assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-826 22117-830 22117-864 60114-514 22117-827 22117-831 22117-865 60114-515 21101-201 22117-869 20117-503 22117-826 22117-827 22117-830 22117-831 22117-864 22117-865 60114-514 60114-515 21101-201 22117-869 20117-503 22117-826 22117-830 22117-864 60114-514 22117-827 22117-826 22117-831 22117-830 22117-865 22117-864 60114-515 60114-514 21101-201 22117-869 20117-503 21101-201 22117-869 20117-503 22117-827 22117-831 22117-865 60114-515 21101-201 22117-869 20117-503 22117-828 22117-826 22117-832 22117-830 22117-866 22117-864 – – – 60114-514 21101-201 21101-201 22117-869 20117-503 22117-827 22117-831 22117-865 60114-515 21101-201 22117-869 20117-503 22117-828 22117-827 22117-832 22117-833 22117-866 22117-867 – 21101-201 – – 60114-517 22117-829 22117-834 22117-868 60114-518 21101-201 – – 22117-826 22117-827 22117-830 22117-831 22117-864 22117-865 60114-514 60114-515 21101-201 21101-201 22117-869 22117-869 20117-503 20117-503 22117-828 22117-832 22117-866 – 21101-201 – – 22117-827 22117-829 22117-833 22117-834 22117-867 22117-868 60114-517 60114-518 21101-201 – – 22117-827 22117-830 22117-864 60114-514 21101-201 22117-869 20117-503 22117-829 22117-827 22117-831 22117-832 22117-865 22117-866 60114-515 22117-869 20117-503 – 21101-201 21101-201 22117-829 22117-834 22117-868 60114-518 21101-201 – – – – 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 1.308 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal 19" panel/slide mounts Order Information 19" panel/slide mount RAL 7021 Depth member AlZn for 600 mm width SZA45958 St, 1.5 mm, for depth-adjustable fitting: cabinet depth 600 mm: please order depth members, cabinet depth 800 mm: please order reduced-width depth members Width ertp0044 St, 1.5 mm, AIZn St, 2.5 mm, zincplated, RAL 7021, 19" plane at least 110 mm from front edge of cabinet; please order panel/slide mounts (2 pairs) separately RAL 7021 AlZn AlZn RAL 7021 PU 2 pieces PU 2 pieces PU 2 pieces PU 2 pieces assembled assembled assembled assembled 23117-017 22117-352 22117-389 22117-390 – 23117-018 22117-353 23117-019 22117-354 22117-835 22117-355 No. U mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 ERTP0045 Depth Cabinet dimensions Height Reduced width depth member for 800 mm width SCHROFF.PENTAIR.CO.UK 22117-389 22117-390 22117-389 22117-390 22117-389 22117-390 – – – 22117-391 22117-836 22117-356 22117-389 22117-390 – 22117-391 – 22117-836 22117-356 22117-837 22117-357 22117-390 22117-391 22117-837 22117-357 – 22117-839 22117-840 22117-389 – 22117-839 22117-840 22117-389 22117-838 22117-358 22117-390 – 22117-391 22117-838 22117-358 – 22117-840 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.309 Cabinets – PUniversal ServicePLUS eurorack Universal Lateral cable ducting Order Information Lateral cable ducting Cable panel Width 150 mm Cable panel Width 250 mm 00108061 St, 1 mm, RAL 7035, with cut-outs for cable ties or Velcro Width RAL 7035 RAL 7021 RAL 7035 RAL 7021 PU 2 pieces PU 2 pieces PU 2 pieces assembled assembled assembled assembled – – – – – – – – – – – – – – – – 23117-026 23117-020 23117-029 23117-023 23117-026 23117-020 23117-029 23117-023 23117-027 23117-021 23117-030 23117-024 23117-027 23117-021 23117-030 23117-024 23117-028 23117-022 23117-031 23117-025 23117-028 23117-022 23117-031 23117-025 mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 1.310 St, 1 mm, RAL 7021, with cut-outs for cable ties or Velcro PU 2 pieces No. U 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 St, 1 mm, RAL 7035, with cut-outs for cable ties or Velcro Depth Cabinet dimensions Height St, 1 mm, RAL 7021, with cut-outs for cable ties or Velcro 00108061 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal 19" slide rails Order Information Dimensions standard assembly Slide rail Short slide rail 40 kg, depthadjustable W xf c D 25 kg 00205066 00108056 xf = distance from St, 1.5 mm, finish AlZn, static loadcarrying capacity 25 kg/pair, panel/ front slide mounts (2 pairs), please order c = pitch of reduced widthdepth members 19" plane separately D = cabinet depth see page W = cabinet width 1.309 41003081 St, 1.5 mm, finish AlZn, static loadcarrying capacity 40 kg/pair, depth-adjustable (c: 675-850 mm); please order panel/slide mounts (2 pairs) separately see page 1.309 sc96xxxx St, 1.5 mm, finish AlZn, static load-carrying capacity 15 kg/ pair Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 SCHROFF.PENTAIR.CO.UK xf mm 60 60 60 60 60 60 60 60 60 60 60 60 110 110 60 60 60 110 110 60 60 60 110 c mm 480 680 480 680 480 680 480 680 780 480 680 780 380 580 480 680 780 380 580 480 680 780 580 PU 2 pieces PU 10 pieces PU 2 pieces PU 2 pieces PU 10 pieces enclosed loose enclosed loose enclosed loose enclosed loose enclosed loose 22127-094 22127-095 21127-197 21127-198 – 28127-001 20118-592 20118-592 20118-593 20118-593 22127-094 21127-197 – 20118-592 20118-593 22127-095 22127-094 21127-198 21127-197 28127-001 20118-592 20118-592 20118-593 20118-593 22127-095 21127-198 28127-001 20118-592 20118-593 22127-094 22127-095 21127-197 21127-198 – 28127-001 20118-592 20118-592 20118-593 20118-593 22127-096 21127-199 28127-001 20118-592 20118-593 22127-094 22127-095 21127-197 21127-198 – 28127-001 20118-592 20118-592 20118-593 20118-593 22127-096 21127-199 28127-001 20118-592 20118-593 22127-094 25127-575 – 21127-197 20118-592 20118-592 20118-593 20118-593 22127-094 21127-197 – – – 20118-592 20118-593 22127-095 22127-096 21127-198 21127-197 28127-001 28127-001 20118-592 20118-592 20118-593 20118-593 22127-094 – 20118-593 21127-197 21127-197 – – – 20118-592 25127-575 22127-094 20118-592 20118-592 20118-593 20118-593 22127-095 21127-198 28127-001 20118-592 20118-593 22127-096 22127-094 21127-197 21127-197 28127-001 20118-592 20118-592 20118-593 20118-593 – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.311 Cabinets – PUniversal ServicePLUS eurorack Universal Fixed 19" shelves Order Information Fixed shelf, 1 U, 75 kg Full depth Depth member Reduced width Recessed by c - for 600 mm width depth member for 800 mm width 100 mm W xf c D Dimensions standard assembly 00205066 00105050 00105051 St, 1.5 mm, RAL 7021, xf = distance from with perforation, static load-carrying front capacity 75 kg, incl. GND/earthing; c = pitch of 19" panel/slide mounts (2 pairs), plane please order depth members or D = cabinet depth reduced width depth members W = cabinet width separately see page 1.309 ERTP0045 ertp0044 St, 1.5 mm, AIZn St, 2.5 mm, zincplated, RAL 7021, 19" plane at least 110 mm from front edge of cabi-net; please order panel/slide mounts (2 pairs) separately see page 1.309 Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 1.312 xf mm 60 60 60 60 60 60 60 60 60 60 60 60 110 110 60 60 60 110 110 60 60 60 110 c mm 480 680 480 680 480 680 480 680 780 480 680 780 380 580 480 680 780 380 580 480 680 780 580 SCHROFF PRODUCT CATALOG E 11/2017 1 piece 1 piece PU 2 pieces PU 2 pieces assembled assembled assembled assembled 22117-842 22117-843 22117-845 22117-671 22117-389 22117-390 22117-842 22117-845 22117-389 22117-843 22117-842 22117-671 22117-845 22117-390 22117-389 22117-843 22117-671 22117-390 22117-842 22117-843 22117-845 22117-671 22117-389 22117-390 22117-844 22117-843 22117-391 22117-842 22117-843 22117-845 22117-671 22117-389 22117-390 22117-844 22117-843 22117-391 – – – – – – – – – – – – 22117-842 22117-871 – – – – 22117-839 22117-840 22117-842 22117-845 22117-389 22117-843 22117-844 22117-671 22117-843 22117-390 22117-391 – – – 22117-842 – – – – 22117-839 22117-871 22117-842 22117-845 22117-389 22117-843 22117-671 22117-390 22117-844 22117-871 22117-843 22117-391 – – – – – 22117-840 22117-840 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal Telescopic 19" shelves Order Information Shelf, telescopic, 2 U, 70 kg Full depth Shortened by 100 mm T-bar lock GND/earthing c D Dimensions standard assembly xf W 00205066 00105069 00105070 St, 1.5 mm, static load-carrying xf = distance from capacity 70 kg, incl. telescopic slide; front please order T-bar lock and GND/ c = pitch of 19" earthing separately plane D = cabinet depth W = cabinet width 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Width Depth No. U Height mm mm mm 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 SCHROFF.PENTAIR.CO.UK c mm 450 - 550 650 - 750 450 - 550 650 - 750 450 - 550 650 - 750 450 - 550 650 - 750 – 450 - 550 650 - 750 – 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled 21130-353 21130-355 21130-352 21130-354 23130-092 23130-092 21120-189 21120-189 21130-353 21130-352 23130-092 21120-189 21130-355 21130-353 21130-354 21130-352 23130-092 23130-092 21120-189 21120-189 21130-355 21130-354 23130-092 21120-189 21130-353 21130-355 21130-352 21130-354 23130-092 23130-092 21120-189 21120-189 – – – – 21130-353 21130-355 21130-352 21130-354 23130-092 23130-092 21120-189 21120-189 – – – – – – – – – 450 - 550 650 - 750 – 21130-353 21130-352 23130-092 21120-189 21130-355 21130-354 23130-092 21120-189 – – – – – – – – – 450 - 550 450 - 550 – – 21130-353 21130-352 23130-092 21120-189 21130-355 21130-354 23130-092 21120-189 – – – – – – – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.313 Cabinets – PUniversal ServicePLUS eurorack Universal Fixed shelves on universalcabinet uprights Order Information Fixed shelf Full depth Shortened by 100 mm 00106053 00106054 St 1.5 mm, St 1.5 mm, RAL 7021, load- RAL 7021, loadcarrying carrying capacity 75 kg, capacity 75 kg, incl. GND/ incl. GND/ earthing, earthing depth member required, please order separately Depth member ERTP0045 St, 1.5 mm, AIZn Cabinet dimensions Width Depth 1 piece 1 piece No. U Height mm mm mm assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-846 22117-847 22117-851 22117-852 22117-389 22117-390 22117-846 22117-851 22117-389 22117-847 22117-846 22117-852 22117-851 22117-390 22117-389 22117-847 22117-852 22117-390 22117-846 22117-847 22117-851 22117-852 22117-389 22117-390 22117-848 22117-847 22117-391 22117-846 22117-847 22117-851 22117-852 22117-389 22117-390 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 1.314 PU 2 pieces 22117-848 22117-847 22117-391 22117-849 22117-850 22117-853 22117-854 22117-389 22117-390 22117-846 22117-851 22117-389 22117-847 22117-848 22117-852 22117-847 22117-390 22117-391 22117-849 22117-853 22117-389 22117-850 22117-846 22117-854 22117-851 22117-390 22117-389 22117-847 22117-852 22117-390 22117-848 22117-850 22117-847 22117-854 22117-391 22117-390 SCHROFF PRODUCT CATALOG E 11/2017 ELECTRONICS PROTECTION Cabinets – PUniversal ServicePLUS eurorack Universal Telescopic shelves on universal cabinet uprights Order Information Telescopic shelf, Universal eurorack Full depth Shortened by 100 mm Telescopic slides T-bar lock GND/earthing General components Mechanics 00105072 00105073 ERA46351 01004125 to lock the telescopic shelf aza43284 St, 1.5 mm, RAL 7021, please order telescopic slides and T-bar lock separately St, 1.5 mm, RAL 7021, please order telescopic slides and T-bar lock separately St, zinc-plated for telescopic shelf 1 piece 1 piece PU 2 pieces 1 piece PU 1 kit assembled assembled 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 21101-132 21101-178 Electrics Cabinet dimensions Height Width Depth No. U mm mm mm assembled assembled assembled 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 998 998 1220 1220 1398 1398 1620 1620 1620 1798 1798 1798 1798 1798 2020 2020 2020 2020 2020 2198 2198 2198 2198 600 600 600 600 600 600 600 600 600 600 600 600 800 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 800 900 600 800 900 600 800 600 800 900 600 800 600 800 900 800 22117-855 22117-860 22114-340 22117-856 22117-861 22114-342 22117-855 22117-856 22117-860 22117-861 22114-340 22114-342 22117-855 22117-860 22114-340 22117-856 22117-855 22117-861 22117-860 22114-342 22114-340 22117-856 22117-861 22114-342 – – – 22117-855 22117-860 22114-340 22117-856 22117-861 22114-342 20 20 25 25 29 29 34 34 34 38 38 38 38 38 43 43 43 43 43 47 47 47 47 SCHROFF.PENTAIR.CO.UK from page 4.0 – – – 22117-858 22117-862 22114-340 22117-859 22117-863 22114-342 22117-855 22117-856 22117-860 22117-861 22114-340 22114-342 – – – 22117-858 22117-859 22117-862 22117-863 22114-340 22114-342 22117-855 22117-860 22114-340 22117-856 22117-861 22114-342 – – – 22117-859 22117-863 22114-342 21101-132 21101-178 21101-132 21101-178 from page 3.29 Power distribution from page 3.50 Climate control from page 4.0 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.315 OutdoorMain Catalogue Cabinets – Outdoor Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 41602001 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 41603009 The dual wall concept provides a natural airflow between the outer and inner wall, substantially reducing the requirement for additional heat removal. 41603010 Optimal protection from vandalism thanks to a fixing accessible only from within. Easily exchangeable exterior cladding components. 41603005 The gasketing material can be selected to suit the requirements (IP protection, EMC shielding) and may be exchanged subsequently. Power supply units . . . . . . . . . . 9 Standard / Certifications Backplanes . . . 10 쮿 External dimensions in accordance with IEC 619691/2, IEC 6091721 쮿 Internal dimensions in accordance with ETS 300119, part 2 쮿 Type of protection IP 55 in accordance with IEC 60529 쮿 Protective GND/earthing connections in accordance with DIN EN 50178 / VDE 0160 Connectors, front panel component system . . . . . . . 11 쮿 Vibration in accordance with IEC 619693 class 2 Appendix . . . . . 12 1.316 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor Overview . . . . . . 1.316 O utdoorMain Catalogue Outdoor cabinet for the most challenging operating conditions 쮿 High stability up to earthquake resistance 쮿 Weight-saving aluminium construction 쮿 Assembly possibilities with 19", ETSI or other accessories 쮿 Tested thermal concepts available 쮿 IP 55 and security against vandalism COMLINE: single wall Weight-saving aluminium construction. Single wall cabinet ready for wall, pole or ground installation. Optimal for diverse applications in industry, transportation and communication. Versions COMLINE ECL - single access . . . . . . . . . . 1.328 FTTX - single and dual access . . . . . . . . . 1.329 쮿 ECL - single access (front door) 쮿 FTTX - single access (front door) and dual access (front and rear door) 41612054 Unibody Cost-effective inner case with removable outer cladding. This version has advantages especially for small cabinets. If accessed through the front door, it meets the installation requirements. Outdoor Unibody Unibody . . . . . . . . . Unibody VENT . . . . Unibody HEX . . . . . Wall mounting kit 1.322 1.323 1.324 1.325 Versions 쮿 With natural convection 쮿 With fan 쮿 With heat exchanger 41603054 Modular Aluminium profile frame with removable, double-walled cladding. This version has advantages especially for large cabinets and if access from all sides is needed. Outdoor Modular Modular VENT . . . 1.326 Modular HEX . . . . . 1.327 Versions Accessories 쮿 With fan Metric panel/slide mounts . . . . . . . . . . 1.328 19" panel/slide mounts . . . . . . . . . 1.329 쮿 With heat exchanger 41603051 ServicePLUS from page 1.330 e. g. individual configurations also with air conditioners e. g. custom solutions (electrical, thermal, backup power supplies, special sizes) ServicePLUS . . . 1.330 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.317 Cabinets – Outdoor - COMLINE Outdoor COMLINE ECL Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Single wall, lightweight aluminium cabinet 쮿 Heat dissipation through natural convection 쮿 IP 55 쮿 2 versions – With plinth – Without plinth Delivery comprises 41612001 Drawing shows version with with plinth Item 1 2 Qty 1 1 3 4 1 1 5 6 2 1 Description Body, single wall, Al, 2.5 mm, RAL 7035 Front door, Al, 2.5 mm, RAL 7035, 3-point locking, lever handle with DIN profile half cylinder, door opening angle 135°, door retainer at 110°, door hinged on left hand side; electrical door switch Solar shield top cover, Al, 2 mm, RAL 7035 Plinth, Al, 3 mm, height 120 mm (only for version with plinth) 19"/23" panel/slide mounts, St, galvanised, 2.5 mm GND/earthing kit, assembled Order Information Height H Height H Width W Depth D U mm mm mm 12 600 600 500 18 900 600 500 18 900 700 500 25 1200 700 600 Height dimensions without plinth (120 mm) 41612052 45 W + 51 D + 24 Part no. Without plinth Part no. 12349-001 12349-009 12349-002 12349-003 12349-010 12349-011 12349-004 12349-012 Note 쮿 19"/23" panel/slide mount kit see page 1.319 64 Drawing shows version with plinth With plinth 465 D - 37 H 451 Z 120 Z W D Z-Z Drawing shows version with plinth Door opening height = H - 75 mm; door opening width = W - 75 mm 1.318 SCHROFF PRODUCT CATALOG E 05/2016 41612050 ELECTRONICS PROTECTION Cabinets – Outdoor - COMLINE 19"/23" panel/slide mount kit for COMLINE ECL Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 For fitting to depth member (25 mm grid) 쮿 For recessed installation of 19"/23" components 쮿 Slide rails can be fitted 쮿 Load-carrying capacity 400 kg Delivery comprises Item 1 2 Qty 2 1 Description 19"/23" panel/slide mount, St, galvanised, 2.5 mm Assembly kit Order Information For cabinet height U mm 12 600 18 900 18 900 25 1200 For cabinet width mm 600 600 700 700 Part no. 22349-024 22349-025 22349-026 22349-027 41612057 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.319 Cabinets – Outdoor - COMLINE Outdoor COMLINE FTTX Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Single wall, lightweight aluminium cabinet 쮿 Insulated cabinet 쮿 IP 55 쮿 2 versions with plinth – Single access (front door) – Dual access (front and rear door) Delivery comprises Item 1 Qty 1 2 1/2 3 4 5 6 1 2 1 1 41612003 Description Body, Al, 2.5 mm, RAL 7035, single wall side panels, insulation thickness 12 mm, non inflammable; 3 cable entry boots are mounted in base for various sizes of cables, 2 removeable lifting brackets Door, Al, 2.5 mm, RAL 7035, 3-point locking, lever handle with DIN profile half cylinder (1242E), door opening angle 135°, door retainer at 110°, door hinged on left hand side; electrical door switch Plinth, Al, 3 mm, height 140 mm 19"/23" panel/slide mounts, galvanised St, 2.5 mm Document pocket, thermoplastic (part no. ADP2) GND/earthing kit, assembled Order Information Height H 41612053 Single access 567 451 41612054 Dual access D 28 Width W Depth D U mm mm mm 12 600 800 500 25 1200 800 600 Dimensions without plinth (140 mm) Dual access Part no. Single access Part no. 12349-007 12349-005 12349-008 12349-006 Note H H 쮿 19"/23" panel/slide mount kit see page 1.321 쮿 Cable entry see page 1.321 쮿 Spool for fibre optic cables see page 1.321 Z 140 140 Z D 28 Height H W Z-Z 451 567 Dual access Height of door opening = H - 270 mm; width of door opening = W - 100 mm 1.320 41612055 Single access SCHROFF PRODUCT CATALOG E 05/2016 41612056 ELECTRONICS PROTECTION Cabinets – Outdoor - COMLINE 19"/23" panel/slide mount kit for COMLINE FTTX Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 For fitting to depth member (25 mm grid) 쮿 For recessed installation of 19"/23" components 쮿 Slide rails can be fitted 쮿 Load-carrying capacity 400 kg Delivery comprises Item 1 2 Qty 2 1 Description 19"/23" panel/slide mount, St, galvanised, 2.5 mm Assembly kit Order Information For cabinet height U 12 25 For cabinet height mm 600 1200 Usable height U 10 23 Part no. 22349-032 22349-033 41612058 Cable entry Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 For cable ducting through the base of the cabinet Delivery comprises Item 1 Qty 3 Description Cable entry, for cable diameter 30 ... 72 mm, EPDM, RAL 7035 Order Information Cable entry 22349-034 41612059 Spool for fibre optic cables Outdoor - CO MLINEMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days Delivery comprises Item 1 2 Qty 4 4 Description Spool for fibre optic cables, molded from black plastic Screws, M5 Order Information Description Spool for fibre optic cables Part no. TOPTKSPL FTTXMoldedRadiusModules SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.321 Cabinets – Outdoor - Unibody Unibody Outdoor - UnibodyMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 One-piece inner case with removable outer cladding 쮿 Heat dissipation through natural convection, max. 6 W/K 쮿 IP 55 쮿 Double-walled, Al Delivery comprises (assembled) 41603054 T1 B1 Qty 1 2 1 4 5 6 1 1 1 7 8 9 1 4 1 Description Internal case, Al Side panel, Al, RAL 7035 Front door, Al, RAL 7035, 3-point locking, lever handle with DIN profile half cylinder, door opening angle 135°, door retainer at 120°, door hinged on left hand side Rear panel, Al, RAL 7035 Top cover, Al, RAL 7035 Plinth with removable covers (front and sides), height 100 mm Base plate with cable connection plate, Al Depth member for 19" metric panel/slide mounts GND/earthing kit, assembled Order Information Height Height Width Depth U mm mm mm 16 930 700 500 20 1100 700 500 Wall mounting kit 1 kit qW = specific heat dissipation capacity b1 qW W/K 5 6 Part no. 11249-003 11249-005 21249-017 쮿 Please order wall mounting material separately, see page 1.325 쮿 Please order panel/slide mounts separately, see page 1.328 h1 h H t1 Item 1 2 3 25 t2 B T 41603058 H*) mm 930 1100 Text H U 16 20 B mm 700 700 T mm 500 500 h mm 838 1013 b1 mm 536 536 t1 mm 400 400 t2 mm 350 350 h1 mm 736 911 B1 mm 730 730 T1 mm 530 530 t2 = max. 19" assembly dimension *) height without base/plinth (base/plinth height 100 mm) ServicePLUS see page 1.330 1.322 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor - Unibody Unibody VENT Outdoor - Uni body 쮿 One-piece inner case with removable outer cladding 쮿 Forced heat dissipation via fan assembled in side panel, max. 35 W/K 쮿 IP 55 쮿 Double-walled, Al Delivery comprises (assembled) 41603055 T1 B1 Item 1 2 3 Qty 1 2 1 4 5 6 1 1 1 7 8 9 10 1 4 1 1 11 12 1 1 Description Internal case, Al Side panel, Al, RAL 7035 Front door, Al, RAL 7035, 3-point locking, lever handle with DIN profile half cylinder, door opening angle 135°, door retainer at 120°, door hinged on left hand side Rear panel, Al, RAL 7035 Top cover, Al, RAL 7035 Plinth with removable covers (front and sides), height 100 mm Base plate with cable connection plate, Al Depth member for 19" metrical panel/slide mounts GND/earthing kit, assembled Axial fan (side mounted), airflow volume: 360 m3/h, 230 VAC, 50 Hz, noise level less than 53 dB(A), max. pressure: 176 Pa, power consumption: 35 W, mains supply to screw terminal block Filter mat Thermostat, complete with cable Order Information b1 h H t1 h1 25 t2 Height Height Width Depth U mm mm mm 16 930 700 500 20 1100 700 500 25 1330 700 500 Replacement fan 230 VAC 1 piece Air filter for fan 10 pieces Wall mounting kit 1 kit qW = specific heat dissipation capacity qW W/K 35 35 35 Part no. 11249-007 11249-009 11249-012 21149-185 21149-184 21249-017 쮿 Please order wall mounting material separately, see page 1.325 쮿 Please order panel/slide mounts separately, see page 1.328 B T 41605050 H *) mm 930 1100 1330 TextText H U 16 20 25 B mm 700 700 700 T mm 500 500 500 h mm 838 1013 1238 b1 mm 536 536 536 t1 mm 400 400 400 t2 mm 350 350 350 h1 mm 736 911 1136 B1 mm 730 730 730 T1 mm 530 530 530 t2 = max. 19" assembly dimension *) height without base/plinth (base/plinth height 100 mm) Calculation example at 35 W/K: (Values as per ETS 300019-1-4 Class 4.1) Internal temperature 50° C - external temperature 40° C = 10 K. Up to 350 W of dissipation loss can thus be installed. (35 W/K x 10 K). ServicePLUS see page 1.330 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.323 Cabinets – Outdoor - Unibody Unibody HEX Outdoor - Unibody 쮿 One-piece inner case with removable outer cladding 쮿 Forced heat dissipation via integrated heat exchanger in the door, max. 70 W/K 쮿 IP 55 쮿 Double-walled, Al Delivery comprises (assembled) 41603056 T1 B1 Item 1 2 3 Qty 1 2 1 4 5 6 1 1 1 7 8 9 10 1 4 1 1 Description Internal case, Al Side panel, Al, RAL 7035 Front door, Al, RAL 7035, 3-point locking, lever handle with DIN profile half cylinder, door opening angle 135°, door retainer at 120°, door hinged on left hand side Rear panel, Al, RAL 7035 Top cover, Al, RAL 7035 Plinth with removable covers (front and sides), height 100 mm Base plate with cable connection plate Depth member for 19" metric panel/slide mounts GND/earthing kit, assembled Heat exchanger 48 VDC (electronically regulated with alarm outputs), incl. temperature sensor, heater and DC connecting cable with IEC plug, 3 m Order Information b1 25 t2 B T 41605051 H *) mm 1330 TextText H U 25 B mm 700 T mm 600 h mm 1238 b1 mm 536 t1 mm 500 t2 mm 400 h1 mm 1136 t2 = max. 19" assembly dimension *) height without base/plinth (base/plinth height 100 mm) Calculation example at 70 W/K: (Values as per ETS 300019-1-4 Class 4.1) Internal temperature 50° C - external temperature 40° C = 10 K. Up to 700 W of dissipation loss can thus be installed. (70 W/K x 10 K). B1 mm 730 T1 mm 630 Part no. 11249-016 21249-017 Technical data heat exchanger h1 h H t1 Height Height Width Depth qW U mm mm mm W/K 25 1330 700 600 70 Wall mounting kit 1 kit qW = specific heat dissipation capacity, average values Dimensions (height x width x depth) Heater (input voltage/capacity) Specific heat dissipation capacity Fan Input voltage Airflow volume external circuit Airflow volume internal circuit Temperature range Type of protection Weight WT 70 1010 x 465 x 150 mm 230 VAC/1000 W 70 W/K 2 pieces 48 VDC 510 m3/h 600 m3/h -40 ... 50 °C IP 55 21 kg 쮿 Please order wall mounting material separately, see page 1.325 쮿 Please order panel/slide mounts separately, see page 1.328 쮿 Equipment cable for heater in heat exchanger (230VAC, IEC connector), see page 3.38 ServicePLUS see page 1.330 1.324 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor - Unibody Wall mounting for Unibody 쮿 Suitable for all Unibody standard dimensions 50 5 쮿 Cut-out for cable ducting from the top Delivery comprises Qty 2 1 Description Bracket Assembly kit H Item 1 2 Order Information Description Wall mounting kit W Part no. 21249-017 D 41603064 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.325 Cabinets – Outdoor - Modular Modular VENT Outdoor - Modular 쮿 Aluminium profile frame with removable, double-walled cladding 쮿 Forced heat dissipation via fans assembled in the side panel, max. 35 W/K 쮿 IP 55 쮿 Double-walled, Al 쮿 Single door (for 700 mm width), double door (for 1300 mm width) Delivery comprises (assembled) 41603051 Item 1 2 Qty 1 2 3 1 4 1 5 6 7 8 9 10 1 1 1 4 1 1 11 12 1 1 Description Frame, screwed, Al Double skin side panel, Al, inner untreated, outer external RAL 7035 Front door at 700 mm width, double door at 1300 mm width, Al, RAL 7035, 3-point locking, lever handle with DIN half profile cylinder, door opening angle 135°, door retainer at 120°, door hinged on left hand side Double skin rear panel, Al, inner untreated, outer external RAL 7035 External top, Al, RAL 7035 Base/plinth with removable cover, height 100 mm Base plate with cable connection plate, Al Depth member for 19" metric panel/slide mounts Earthing kit, assembled Axial fan (assembled laterally), airflow volume: 360 m3/H, 230 VAC 50 Hz, noise level less than 53 dB(A), max. pressure 176 Pa, power consumption 35 W, mains/line connector with screw terminal block Filter mat Thermostat, complete with cable Order Information 41603059 H *) mm 1330 1510 1510 TextText H U 25 29 29 w mm 1300 700 1300 T mm 600 600 600 h mm 1233 1408 1408 b1 mm 1136 536 1136 t1 mm 500 500 500 t2 mm 450 450 450 h1 mm 1136 1311 1311 B1 mm 1330 730 1330 T1 mm 630 630 630 Height Height Width Depth U mm mm mm 25 1330 1300 600 29 1510 700 600 29 1510 1300 600 Replacement fan 230 VAC 1 piece Air filter for fan 10 pieces qW = specific heat dissipation capacity qW W/K 35 35 35 Part no. 10149-305 10149-306 10149-308 21149-185 21149-184 쮿 Please order panel/slide mounts separately, see page 1.328 t2 = max. 19" assembly dimension *) height without base/plinth (base/plinth height 100 mm) Calculation example at 35 W/K: (Values as per ETS 300019-1-4 Class 4.1) Internal temperature 50° C - external temperature 40° C = 10 K. Up to 350 W of dissipation loss can thus be installed. (35 W/K x 10 K). ServicePLUS see page 1.330 1.326 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor - Modular Modular HEX Outdoor - Modular 쮿 Aluminium profile frame with removable, double-walled cladding 쮿 Forced heat dissipation via integrated heat exchanger in the door, max. 70 W/K 쮿 IP 55 쮿 Double-walled, Al 쮿 Single door (for 700 mm width), double door (for 1300 mm width) Delivery comprises (assembled) 41603052 Item 1 2 Qty 1 2 3 1 4 1 5 6 7 8 9 10 1 1 1 4 1 1 Description Frame, screwed, Al Double skin side panel, Al, inner untreated, outer external RAL 7035 Front door at 700 mm width, double door at 1300 mm width, Al, RAL 7035, 3-point locking, lever handle with DIN half profile cylinder, door opening angle 135°, door retainer at 120°, door hinged on left hand side Double skin rear panel, Al, inner untreated, outer external RAL 7035 External top cover, Al, RAL 7035 Base/plinth with removable cover, height 100 mm Base plate with cable connection plate, Al Depth member for 19" metric panel/slide mounts Earthing kit, assembled Heat exchanger 48 VDC (electronic control with alarm outputs), incl. temperature sensor and heater, DC connecting cable with IEC connector, 3 m Order Information Height Height Width Depth qW U mm mm mm W/K 25 1330 1300 600 70 29 1510 700 700 70 29 1510 1300 600 70 qW = specific heat dissipation capacity, average values Part no. 10149-313 10149-315 10149-316 Technical dataheat exchanger 41605052 H *) mm 1330 1510 1510 TextText H U 25 29 29 B mm 1300 700 1300 T mm 600 700 600 h mm 1233 1408 1408 b1 mm 1136 536 1136 t1 mm 500 600 500 t2 mm 350 450 350 h1 mm 1136 1311 1311 t2 = max. 19" assembly dimension *) height without base/plinth (base/plinth height 100 mm) Calculation example at 70 W/K: (Values as per ETS 300019-1-4 Class 4.1) Internal temperature 50° C - external temperature 40° C = 10 K. Up to 700 W of dissipation loss can thus be installed. (70 W/K x 10 K) B1 mm 1330 730 1330 T1 mm 630 730 630 Dimensions (height x width x depth) Heater (input voltage/capacity) Specific heat dissipation capacity Fans Input voltage Airflow volume external loop Airflow volume inner loop Temperature range Type of protection Weight WT 70 1010 x 465 x 150 mm 230 VAC/1000 W 70 W/K 2 pieces 48 VDC 510 m3/h 600 m3/h -40 ... 50 °C IP 55 21 kg Note 쮿 Please order panel/slide mounts separately, see page 1.328 쮿 Equipment cable for heater in heat exchanger (230VAC, IEC connector), see page 3.38 ServicePLUS see page 1.330 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.327 Cabinets – Outdoor - Accessories Metric panel/slide mounts Outdoor - Accessories 쮿 For fixing metric chassis, subracks, distributor and filler panels to IEC 60917-2-1 쮿 Modular version fixes direct to the frame or to the depth members; Unibody fixes to the depth members Delivery comprises Item 1 Qty 2 2 1 Description Metric panel/slide mounts, bolt-on dimension 515 mm, St, 2 mm, AlZn Assembly kit, incl. GND/earthing Order Information For cabinet height mm Partial-height mounting Partial-height mounting 930 1100 1330 1510 41001548 Usable height SU Length mm AlZn Part no. 16 400 24127-547 21 525 24127-682 28 35 44 51 700 875 1100 1275 24127-686 24127-689 24127-694 24127-697 Note 쮿 Depth members and slide rails for partial-height mounting available on request 1.328 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor - Accessories 19" panel/slide mounts Outdoor - Accessories 쮿 For mounting of 19" chassis, subracks, distribution and filler panels in accordance with IEC 60297-3-100 (DIN 41 494, part 1) 쮿 Assembled directly on the frame or on the depth member for the Modular, for Unibody assembly on depth member Delivery comprises Item 1 2 Qty 2 1 Description 19" panel/slide mount, St, 2 mm, RAL 7035/Al-Zn Assembly kit, incl. GND/earthing Order Information PLA45434 For cabinet height mm Partial-height mounting Partial-height mounting 930 1100 1330 1510 Usable height U 9 12 16 20 25 29 Length mm 400 533 711 889 1111 1289 Part no. 24127-370 24127-484 24127-485 24127-487 24127-489 24127-491 Note 쮿 Depth member for partial-height mounting available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.329 Cabinets – Outdoor ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Enquiry form for outdoor cabinets – Various interior and exterior dimensions – Degree of protection – Determining of the cooling capacity – Cooling concept 쮿 Online configuration: www.schroff.co.uk/configuration solution Simple. Fast. From one source. Integration and custom developments 쮿 Heat simulation on FloTHERM® model and calculations by experts 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, maintenance, repair, replacement parts, recycling Outdoor ServiceP LUS 1.330 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor ServicePLUS Outdoor ServicePLUSMain C atalogue Mobile telephony base station 쮿 Mobile telephony base station with energy supply in one cabinet 쮿 BTS connection via special cable routing in top element 쮿 Based on the "modular" concept, the cabinet can be upgraded with various pre-defined "kits" 쮿 Cooling either via fresh-air inlet (air filtered fan) or, in other cabinet variants, using an air conditioner 41608003 Mobile telephony power supply 쮿 Cabinet for power supply to mobile telephony base stations 쮿 Based on the "modular" cabinet concept with a special top panel design for cabling; can accept both 19" and 21" wide devices 쮿 Heat exchanger in the front door 쮿 AC/DC power distribution installed laterally beside 19" plane 41608004 Wimax 쮿 Base station for Wimax applications 쮿 "Unibody" concept with special base for easy assembly at installation site 쮿 Fresh air inlet via air inlet filter 쮿 Additional components such as cabinet heater and door contact switch factory preinstalled 41608005 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.331 Cabinets – Outdoor ServicePLUS Main Catalogue VDSL fixed network 쮿 VDSL distribution cabinet 쮿 Case based on a "modular" frame and double-walled outer cladding 쮿 Cooling via controlled fans in case top panel. Airflow is only between the double walls; the device area remains sealed 쮿 Separate stainless steel base with space for batteries and cable ducting 41608010 Battery cabinet 쮿 Cabinet to power mobile telephony stations 쮿 Based on the "modular" cabinet concept with the option of accommodating both 19" and 21" wide devices 쮿 Direct cooling via fresh air introduced into the interior via an air filtered fan 쮿 Fitting and connection of additional components e.g. smoke detector, door contact switch etc 41608006 Triple Play 쮿 Distribution cabinet for fibre-optic cables (FTTN/FTTH) 쮿 Ex works with power supply, backup batteries and safety devices 쮿 Design outdoor "Modular" 쮿 Combined cooling with air conditioner and additional internal air circulation 41608007 1.332 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Outdoor ServicePLUS Outdoor ServicePLUSMain C atalogue Meteorology Main Catalogue 쮿 Compact, robust case for recording measured data in thunderstorms and strong winds 쮿 Outdoor "Unibody" for mast mounting 쮿 Climate control based on an additional fan in the gap between the dual walls 쮿 A controllable heater can be added for use in freezing conditions 41603016 Voltage monitoring (railway) Main Catalogue 쮿 Voltage monitoring on overhead cables 쮿 Construction based on "unibody" concept, for wall or mast mounting 쮿 Energy-saving, noiseless cooling by convection between the double walls 41608008 Measurement technology on the rails Main Catalogue 쮿 Safety measurement device to detect the wheel temperature of passing trains 쮿 Positioned very close to the tracks, thus requires robust vibration-proof design to IEC 61963 쮿 Construction based on "modular" concept; the devices are mounted on a swing frame 쮿 Heat dissipation via side-mounted air conditioner 41608009 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.333 ZMain Catalogue Cabinets – Z Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 05601001 05601002 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 ETA43445 Top mounted cabling frame Power supply units . . . . . . . . . . 9 Backplanes . . . 10 eta43459 05605051 Optionally either rear panel or cable supports can be used eta43449 Frame cover with integrated socket Standards/certifications Modifications 쮿 External and internal dimensions in accordance with: IEC 48D and ETS 300119 쮿 Special colours 쮿 Type of protection: IP 20 in accordance with: IEC 60529 쮿 Customised solutions 쮿 Special sizes 쮿 Protective GND/earthing connections in accordance with: DIN EN 50178 / PU 0160 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 1.346 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Z Overview . . . . . . 1.346 ZMain Catalogue Metric frame for public and private telecommunication networks 쮿 In accordance with standards IEC 48 D and ETS 300 119 쮿 Static load-carrying capacity up to 200 kg 쮿 Top mounted cabling frame 쮿 Back-to-back row layout is possible Cabinet from stock 쮿 With perforated front door 쮿 Can be completed on the rear either with rear panel or cable supports etsirack Frames . . . . . . . . . . 1.348 Mounting kit for back-to-back row layout . . . . . . . . . . . 1.349 Rear panel . . . . . . 1.349 Cable support . . . . 1.349 Top mounted cabling frame . . . . 1.350 Mounting socket etsirack . . . . . . . . . 1.350 Metric cable support . . . . . . . . . . 1.351 19" adaptors . . . . . 1.351 05605001 ServicePLUS from page 1.352 e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) ServicePLUS . . . 1.352 Application examples. . . . . . . . 1.353 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.347 Cabinets – Z etsirack frame ZMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days 쮿 Welded rack with metric grid hole spacing to ETS 300119-3 쮿 Static load-carrying capacity 200 kg 쮿 Mounting height 81 SU (1 SU = 25 mm) Delivery comprises (assembled) Item 1 2 Qty 1 1 3 4 5 4 1 1 Description Frame, St, 2 mm, RAL 7035 Front door with perforation, St, 1.5 mm, RAL 7035 with safety lock incl. 2 keys, GND/earthing Adjustable feet, St, zinc-plated, polyamide black Base/plinth, St, 2 mm, RAL 7035 Blanking plug, polyamide, white, for socket cut-out Order Information Height Width Depth Qty mm mm mm 2200 600 300 PU = 1 piece on a palette 2200 600 300 PU = 2 pieces on a palette Side-by-side mounting kit etsirack PU 1 kit Mounting socket etsirack SCHUKO, 230 V/16 A, white, 1 piece Part no. 10125-010 10125-011 21190-793 21101-360 05605001 05605050 eta43442 ServicePLUS see page 1.352 1.348 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Z Mounting kit etsirack for back-to-back row layout Z 쮿 For back-to-back mounting of two frames Delivery comprises Item 1 Qty 4 Description GND/earthing cage nut, washer, 1 screw M6 x 12 Order Information Description Mounting kit etsirack for back-to-back row layout Part no. 21190-793 ETA43447 Rear panel Z Delivery comprises Item 1 2 3 Qty 1 1 1 Description Rear panel, St, 1 mm, RAL 7035 GND/earthing kit (Cu wire 4 mm2 green/yellow) Assembly kit Order Information Description Rear panel eta43459 Part no. 20125-021 eta43444 Cable support Z 쮿 Cable supports may be used in the etsirack in place of a rear panel Delivery comprises Item 1 2 Qty 4 1 Description Cable support, St, 2 mm, RAL 7035 Assembly kit Order Information Description Cable support Part no. 20125-006 05605051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.349 Cabinets – Z Top mounted cabling frame Z 쮿 Extension length of the sliding bars on right and left: max. 536 mm Delivery comprises (Kit) Pos. 1 2 3 4 5 Menge 1 1 1 2 1 Beschreibung Sliding bar on the right, St, 3 mm, zinc-plated Sliding bar on the left, St, 3 mm, zinc-plated Mounting rail, St, 3 mm, zinc-plated Cable retention rail, St, 3 mm, RAL 7035 Assembly kit Order Information Description Top mounted cabling frame Part no. 20125-005 ETA43445 Mounting socket etsirack Z 쮿 SCHUKO, 230 VAC, 16 A Delivery comprises Item 1 2 Qty 1 1 Description Mounting socket, SCHUKO, white Assembly kit Order Information Description Mounting socket etsirack Part no. 21101-360 ETA43449 1.350 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Z Metric equipment shelf Z 쮿 For the installation in metric frames (assembly dimension 515 mm) 쮿 Load carrying capacity 10 kg 쮿 Mounting height 49 mm Delivery comprises Item 1 2 3 Qty 1 1 1 Description Equipment shelf, St, 1.5 mm, RAL 7035 GND/earthing material Assembly kit Order Information Width mm 497 05601501 Depth mm 222 Part no. 20118-686 19" adaptor Z 쮿 The 19" adaptor allows 19" components to be installed in the metric etsirack 쮿 Equal clearances are obtained above and below between the 19" adaptor and the metric height increments Delivery comprises Item 1 2 Qty 2 1 Description 19"/metric adapter, Al extrusion, clear chromated Assembly kit Order Information bza44292 Height U 3 6 45 Clearance mm above/below 8.8 mm each above/below 4.6 mm each none Part no. 20838-084 20838-086 20125-018 Note 쮿 Assembly dimensions and clearances see Internet SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.351 Cabinets – ZServicePLUS modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Special colours solution Simple. Fast. From one source. Integration and custom developments 쮿 Complete construction,cabling, function testing 쮿 Special sizes, custom solutions lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Free delivery to point of use ServicePLUSZ 1.352 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – ZServicePLUS ServicePLUS: Solution - Project examples French Telecom 쮿 With perforated front door 쮿 Special top mounted cabling frame 05605003 German Telecom 쮿 Front door drawn out for more space 쮿 Rear panel included 쮿 Lever handle instead of safety lock 05605003 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.353 1 9" lab racksMain Catalogue Cabinets – 19" lab racks Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 01305003 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Cable ducting on the front and rear side lra45330 vnt007 Large selection of equipment shelves Application/function Power supply units . . . . . . . . . . 9 Backplanes . . . 10 19" lab racks are freely accessible from all sides. Subracks, 19" cases and 19" shelves can be mounted. Two angled steel uprights are screw-fixed on the base part (mobile base/plinth and base plate respectively). The 19" cut-outs of the steel uprights are recessed so far that a flat surface for front panels is created. At the top, the two profiles are connected by a cover plate which gives the rack additional stability. 01505050 Standards/certifications 쮿 Internal and external dimensions in accordance with: IEC 60297-3-100 The base/plinth of the mobile 19" lab rack has two fixed rear castors and two locking castors at the front. The 100 mm roller diameter ensures both good mobility and high stability. A base plate from sheet steel forms the plinth for the stationary 19" lab rack. Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 1.354 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – 19" lab racks Overview . . . . . . 1.354 19 " lab racksMain C atalogue 19" lab rack 쮿 Mobile or stationary 쮿 Various shelves 쮿 Accessories for cable ducting 19" lab racks 19" lab rack, mobile . . . . . . . . . . . 1.356 19" lab rack, stationary . . . . . . . . 1.357 Panel mounts . . . . 1.358 Cable support rail 1.358 C-profiles . . . . . . . . 1.359 Cable eyes for C-profile . . . . . . . . 1.359 19" equipment shelves . . . . . . . . . . 1.361 Slide rails . . . . . . . . 1.361 01305001 Mobile Stationary 쮿 36 U 쮿 24 and 39 U 쮿 Load-carrying capacity up to max. 200 kg 쮿 Load-carrying capacity up to max. 150 kg ServicePLUS from page 1.361 01305002 ServicePLUS . . . 1.361 e.g. modification (special colours) e.g. custom solutions (special sizes) www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.355 Cabinets – 19" lab racks 19" lab rack, mobile 19" lab racksMain CataloguePart number in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 Stationary load-carrying capacity 200 kg at a defined centre of gravity in the centre of the lab rack 쮿 Recommended max. chassis depth 400 mm Delivery comprises (assembled) Item 1 2 3 4 Qty 1 1 2 2 Description 19" frame, St, 2 mm, RAL 7035, with EIA cut-outs Mobile base/plinth, Al, die-cast, RAL 7035 Castor, plastic (PA), with rubber insert Locking castor, plastic (PA), with rubber insert Order Information Description 19" lab rack, mobile, useable height 36 U 19" assembly kit (50 x screws, 50 x washers, 50 x nuts) 19" assembly kit (100 x screws, 100 x washers, 100 x nuts) Part no. 10117-498 21101-809 21101-810 01305001 2 HE 1856 200 492 36 HE 582,3 465 451 1 2 165 3 157 100 60 95 4 710 Side view 600 front dta44089 ServicePLUS see page 1.361 1.356 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – 19" lab racks 19" lab rack, stationary 19" lab racks 쮿 Modular design with base/plinth and cover plate, please order uprights according to desired height separately 쮿 Stationary load-carrying capacity 150 kg, at a defined centre of gravity in the centre of the lab rack 쮿 Recommended max. chassis depth 400 mm Delivery comprises (kit) Item. 1 2 4 Qty 1 1 1 Description Base/plinth, St, 2 mm, RAL 7035 Trim at top, St, 1.5 mm, RAL 7035 Assembly kit Order Information Description Item Base and trim 1+2+4 Uprights (item 3) with EIA perforation, 24 U, RAL 7035, PU 2 pieces Uprights (item 3) with EIA perforation, 39 U, RAL 7035, PU 2 pieces Adjustable feet load-carrying capacity 100 kg per foot, PU 4 pieces Castors load-carrying capacity 150 kg per kit, castor diameter 52 mm, PU 4 pieces (2 locking, 2 non-locking) 19" assembly kit (50 x screws, 50 x washers, 50 x nuts) 19" assembly kit (100 x screws, 100 x washers, 100 x nuts) Part no. 20118-743 20118-741 20118-742 21190-571 20118-462 21101-809 21101-810 Technical data 01305002 582,3 46 200 492 h h mm 1067 1733 H mm 1164 1831 Note 2 H Usable height U 24 39 쮿 Please order uprights separately 465 (19”) 451 3 1 46 1 60 50 45 165,5 46 600 710 Side view front VNT004 ServicePLUS see page 1.361 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.357 Cabinets – 19" lab racks Panel mounts for stationary 19" lab rack 19" lab racks 쮿 Required for fitting of cable retention rails or slide rails on stationary 19" lab rack Delivery comprises Item 1 Qty 2 Description Panel mount without assembly kit, St, 1.5 mm, RAL 7035 Order Information Description Panel mount Panel mount Assembly kit PU 1 kit Height U 24 39 Part no. 20118-744 20118-745 21101-175 Note VNT011 쮿 Please order assembly kit separately Cable support rail 19" lab racks 쮿 For cable ducting and cable strain relief 쮿 Designed for mobile 19" lab rack; with panel mounts also for stationary 19" lab rack Delivery comprises (Kit) Item 1 2 3 Qty 3 2 1 Description C-profile, St, 1.5 mm, zinc-plated Corner piece, St, 2 mm, zinc-plated Assembly kit Order Information Description Cable support rail Part no. 20118-460 Note 쮿 Panel mounts are necessary for assembly on stationary 19" lab racks, please order them separately LRA45330 1.358 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – 19" lab racks C-profile for stationary 19" lab rack 19" lab racks 쮿 For assembly to the vertical uprights on the right and left hand side of the 19" plane; especially suited for cable eyes Delivery comprises Item 1 Qty 2 Description C-profile, St, 1.5 mm, zinc-plated Order Information Height U 24 39 Assembly kit PU 1 kit Length mm 1050 1650 Part no. 20118-461 22114-461 21101-175 Note 쮿 Please order assembly kit separately 쮿 Not suitable on mobile 19" lab racks VNT007 Cable eyes for C-profile 19" lab racks Delivery comprises Item 1 D= W 95 =9 5 75 D= W =4 0 D= Qty 4 45 Description Cable eye, round steel, 6 mm, zinc-plated, with integrated anti-rotation protection Order Information W Description =1 20 00507050 00507051 00507052 W mm Cable eye for C-profile 120 Cable eye for C-profile 40 Cable eye for C-profile 95 Assembly kit for 4 cable eyes, PU 1 kit D mm 45 75 95 Part no. 20118-339 20118-554 20118-340 21101-596 Note 쮿 Please order assembly kit separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.359 Cabinets – 19" lab racks 19" equipment shelf, 1 U 19" lab racks 쮿 Static load-carrying capacity 5 kg 쮿 Mounting height 1 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width Depth mm mm 447 390 19" assembly kit (screw, washer, nut) for one equipment shelf AlZn Part no. RAL 7035 Part no. 20118-781 20118-783 21190-095 00508012 19" equipment shelf, 2 U 19" lab racks 쮿 Static load-carrying capacity 10 kg 쮿 Mounting height 2 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width Depth mm mm 447 238 19" assembly kit (screw, washer, nut) for one equipment shelf RAL 7035 Part no. 20118-785 21190-095 00508002 19" equipment shelf, depth-adjustable, 2 U 19" lab racks 쮿 Static load-carrying capacity 15 kg 쮿 Mounting height 2 U 쮿 Depth-adjustable in 25 mm increments (front protrusion min. 26 mm) Delivery comprises (kit) Item 1 2 Qty 1 2 Description Equipment shelf, St, 1.5 mm Mounting bracket with assembly kit, St, 1.5 mm Order Information 00508009 1.360 SCHROFF PRODUCT CATALOG E 05/2016 Width Depth mm mm 430 250 430 300 430 400 19" assembly kit (screw, washer, nut) for one equipment shelf RAL 7035 Part no. 20118-790 20118-791 21190-095 ELECTRONICS PROTECTION Cabinets – 19" lab racks 19" equipment shelf with front protrusion, 2 U 19" lab racks 쮿 Static load-carrying capacity 25 kg 쮿 Mounting height 2 U 쮿 Forward protrusion min. 168 mm Delivery comprises (kit) Item 1 2 3 Qty 1 2 1 Description Equipment shelf, St, 1.5 mm, RAL 7035 Mounting bracket, strengthened, St, 2/2.5 mm, RAL 7035 Assembly kit incl. GND/earthing kit Order Information Width mm 430 Depth mm 400 Part no. 20119-257 SZA46423 Slide rail, 40 kg 19" lab racks 쮿 For assembly on mobile 19" lab racks; with panel mounts also on stationary 19" lab racks 쮿 Static load-carrying capacity 40 kg per pair Delivery comprises Item 1 Qty 2 / 10 Description Slide rail, St, 2 mm, zinc-plated Order Information DTA44090 Description Slide rail, 40 kg Slide rail, 40 kg Qty/PU 2 10 Part no. 20119-080 20119-106 Note 쮿 Panel mounts are necessary for assembly on stationary 19" labrack, please order separately, see page 1.358 modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Special colours solution Simple. Fast. From one source. Integration and custom developments 쮿 Complete construction,cabling, function testing 쮿 Special sizes, custom solutions lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Free delivery to point of use 19" lab rack Servi cePLUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.361 Hoffman P ROLINEMain Catalogue Cabinets – Hoffman PROLINE Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 41003002 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Mounting pitch 41096005 41096010 Assembly in accordance with ETSI/ 19" standard PC cabinet 41097003 Main C ataloguePart number in bold face type: ready for despatch within 2 worki ng daysPart number in norm al type: ready for despatch within 10 working days Power supply units . . . . . . . . . . 9 Standards/certifications Industrial standards 쮿 Exterior and interior dimensions in accordance with IEC 60297, part 1 and 2 IEC 60917-2-1 쮿 Gasketed assembled enclosure: UL 508A listed; Type 12; File Number E61997 cUL listed per CSA C22.2 No 94; Type 12; File Number E61997, NEMA/EEMAC Type 12, CSA File Number 42186: Type 12, VDE IP 55, IEC 60529, IP 55 쮿 Interior dimensions in accordance with ETS 300119, Part 2 Backplanes . . . 10 쮿 Protective GND/earthing connections in accordance with DIN EN 50178 / PU 0160 Connectors, front panel component system . . . . . . . 11 쮿 EMC assembled enclosure: UL 508A listed; Type 1; File Number E61997, cUL listed per CSA C22.2 No 94; Type 1; File Number E61997, NEMA/EEMAC Type 1, IEC 60529, IP 30 Appendix . . . . . 12 1.362 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinets – Hoffman PROLINE Overview . . . . . . 1.362 Hoffman PROLINEMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days Hoffman PROLINE industrial cabinets 쮿 쮿 쮿 쮿 Overview Cabinets . . . . . . . 1.0 Electrical cabinet and PC cabinet with high stability and ingress protection to IP Welded steel frame with 25 mm increments Interior mounting in accordance with 19" or ETSI standard possible Static load-carrying capacity 600 kg VARISTAR . . . . . . 1.2 VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . 1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR MIL . . . 1.120 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR Aisle Containments . . . . 1.202 VARISTAR Air/ water heat exchanger . . . . . . . 1.224 eurorack . . . . . . . 1.270 Electronics cabinet 41098005 Electrical cabinet 41003001 PC cabinet 41097004 NOVASTAR . . . . . 1.240 Ordering Hoffman PROLINE industrial cabinets can be supplied in any of the following ways to best suit your needs: 쮿 Assembled enclosures – Hoffman PROLINE enclosures are available preconfigured for computer system (PROLINE PC) applications, HMI (PROLINE SY) applications, industrial applications and double-door disconnect (PROLINE DD) applications. These options allow you to select a complete system that includes the frame, side panels, top, base, doors and interior mounting accessories by simply ordering one part number. 쮿 Customer-specific assemblies – Assemble-to-order (A-T-O) programme. Configure your industrial cabinet. Customers can configure an individual cabinet ex stock from a set range of individual components, at no extra cost 쮿 Individual components – If your process is better-suited to receiving individual Hoffman PROLINE parts and completing the assembly yourself, we can accommodate you. Frames and individual components are available for shipment from our warehouse or distributor stock. Outdoor . . . . . . . . 1.316 Hoffman Open Frame Racks . . . 1.334 etsirack . . . . . . . . 1.346 ServicePLUS 쮿 A-T-O (Assemble-to-order): Configuration and assembly of Hoffman PROLINE cabinets (IP 55) 쮿 Detailed documentation and order tables on the Internet under www.schroff.biz/proline 쮿 Further information see Hoffman industrial catalogue www.schroff.biz/industrial SCHROFF.PENTAIR.CO.UK Lab racks . . . . . . . 1.354 Cabinet Accessories . . . . 3.0 1.363 Cabinets – On Board Rack On-board rack On Board RackMAIN CATALOG Part number in bold face type: ready for s hippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days 쮿 For mobile railway applications 쮿 Suitable for ongoing vibrations, shock, high temperatures, and high humidity 쮿 Height 3, 6, and 9 U, width 36 and 84 HP, depth 341.8 mm 쮿 Suitable for 1, 2, or 3 U SNCF subracks (NF F61-005, CF 60-002) 쮿 Rear side is equipped for standard connectors; crossbar can be custom-coded for the SNCF coding pins 쮿 Crossbar with integrated cable channel 쮿 Several racks can be stacked or fitted in rows 쮿 Produced using a welding process, certified to EN 15085 (CL2) Delivery includes Item Qty. 1 1 2 1 Description Welded rack, St, stainless steel, 2 mm, rear middle crossbar User manual Order Information 07117057 1.366 SCHROFF PRODUCT CATALOG E 08/2017 Height Width Depth U HP mm 3 36 341.8 3 84 341.8 6 36 341.8 6 84 341.8 9 36 341.8 9 84 341.8 Accessories Joining and stacking kit for on-board rack PU, 1 set (4 screws, 8 nuts, 4 washers) Mounting kit for on-board rack PU, 1 set (8 x screw M6x30, 8 x clip cage nut) Mounting kit for on-board rack PU, 1 set (50 x screw M6 x 30, 50 x clip cage nut) Mounting kit for on-board rack PU, 1 set (100 x screw M6 x 30, 100 x clip cage nut) Part no. 10170-015 10170-014 10170-013 10170-012 10170-017 10170-016 20170-042 21120-205 21120-206 21120-207 ELECTRONICS PROTECTION Cabinets – On-board rack Joining and stacking kit for on-board rack On-board rackMAIN CATALO GPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Assembly kit, suitable for joining or stacking on-board racks Order Information Description Joining and stacking kit for on-board rack Description PU, 1 set (4 screws, 8 nuts, 4 washers) Part no. 20170-042 06717050 06717051 06717052 Mounting kit for on-board rack MA IN CATALOG Part number in bold face type: ready for shipping withi n 2 working daysP art number in normal type: ready for s hippi ng within 1 0 worki ng days 쮿 For mounting electronic components on the on-board rack 쮿 To ensure standards-compliant grounding at at least one mounting point, use a grounding cage nut and a Nomel washer Delivery includes Item 1 2 00517001 Description Panhead screw, M6 x 30, St, zinc-plated Clip cage nut, M6, St, zinc-plated Order Information Description Mounting kit for on-board rack Mounting kit for on-board rack Mounting kit for on-board rack SCHROFF.PENTAIR.DE Qty/PU piece 8 50 100 Part no. 21120-205 21120-206 21120-207 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 1.367 PROLINE e u g tlo C in a M Wall mounted cases – Overview Content Cabinets . . . . . . 1 For robust industrial environments up to IP 66 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 W Distributor and network case for 10" and 19" applications With hinged side panels Steel, IP 20 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 36108001 (41102004, 41105001, 41107004, 41107005, 41505001, 40505001, 40505002) 0.0 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION PROLINE Main C atalogue Wall mounted cases – Overview Overview . . . . . . 0.0 For data and network systems For data and network systems LAN wall mounted enclosure epcase . . . . . . . . . 2.24 Ideal for fibre optics applications or as copper small distributor, retrofittable with side-by-side modules Steel, IP 20 LAN wall mounted . . . . . . 2.36 Cabinet Accessories . . . 3.0 36108002 (01505002, 01505008, 41801001, 41801017) SCHROFF.PENTAIR.CO.UK 0.1 epcaseW Main Catalogue Wall mounted cases – W Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01505008 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Hinged side panels for easy access 01506002 01505003 Optimum space utilisation due to an additional vertical 19" plane; fans retrofittable Systems . . . . . . . 8 Standards 쮿 Type of protection IP 20 IEC 60529 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Simple design and assembly: mounting, wiring, cladding 01504051 Appendix . . . . . 12 2.24 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W Overview . . . . . 2.24 epcaseWMain C atalogue Low-cost wall mounted case 쮿 Hinged side panels for easy access 쮿 Completely pre-assembled 쮿 Optimum space utilisation through depth-adjustable 19" slide mounts and an additional vertical 19" plane 쮿 Type of protection IP 20 epcase 19" epcase 19" 쮿 19" assembly from 9 ... 20 U 19" wall mounted case . . . . . . . . . . . . 2.26 Fan . . . . . . . . . . . . 2.27 Protective grille . . 2.27 Air filter . . . . . . . . 2.28 Lever handle . . . . . 2.28 19" equipment shelf . . . . . . . . . . . . 2.29 Modem shelf . . . . 2.30 Vertical 19" plane 2.30 Cable eye . . . . . . . . 2.31 Cable support rail 2.31 Short slide rail . . . 2.31 01506001 epcase 10" 쮿 10" assembly from 4 ... 12 U epcase 10" 10" wall mounted case . . . . . . . . . . . . 2.32 Air filter . . . . . . . . . 2.33 Equipment support . . . . . . . . . 2.33 10" front panel . . . 2.34 10" distribution field . . . . . . . . . . . . . 2.34 10" socket strip 1 U, SCHUKO . . . . 2.35 01505006 ServicePLUS . . . 2.46 30407004 ServicePLUS from page 2.46 e.g. special colours, special sizes e.g. air conditioning e.g. fittings, conversions, cut-outs e.g. custom solutions www.schroff.biz/ServicePLUS SCHROFF.PENTAIR.CO.UK 2.25 Wall mounted cases – W 19" wall mounted case epc aseWMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days 쮿 Multi functional 19" wall case with hinged side panels 쮿 Cable entry possible from above or below; the cable entry opening can be sealed with two brush strips each, resp. can be used to assemble fan 쮿 Cable support rail is included and is adjustable in 25 mm increments 쮿 19" panel/slide mounts are depth-adjustable in 25 mm increments 쮿 Type of protection IP 20 Delivery comprises (assembled) Item 1 2 Qty 1 1 3 4 5 6 7 2 1 2 2 1 01506002 Description Basic case, C form, St, 2 mm, RAL 7021 Glazed door with key/lock (key no. 2233), door handle cut-out S2100, frame, St, 1.5 mm, RAL 7035, Sekurit glass 4 mm Side panel, St, 1.5 mm, RAL 7035 Cable support rail, St, RAL 7035 19" slide mounts, St, 2 mm, finish AlZn Brush strip (to cover cable entry opening) Assembly kit for wall mounting Order Information Height Height Width H W Depth D Weight Loadcarrying capacity mm kg kg 18 18 60 18 20 35 18 24 35 85 25 30 18 28 35 85 30 30 85 32 25 85 34 30 85 38 25 E U mm mm mm 9 487 600 300 9 487 600 400 12 612 600 400 12 612 600 500 16 812 600 400 16 812 600 500 16 812 600 600 20 962 600 500 20 962 600 600 GND/earthing, PU 1 kit Brush strip, 1 piece Feet, plastic, black, PU 4 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable tie 92 mm x 2.5 mm, PU 25 pieces 19" assembly kit (screw, washer, nut) (32 x M6 screws x 16, 32 x plastic washers, 32 x cage nuts) Part no. 10236-151 10236-152 10236-156 10236-157 10236-160 10236-161 10236-162 10236-165 10236-166 21236-097 21236-094 21236-089 20114-728 20118-351 21190-435 Note 쮿 Lever handle for single point locking with DIN profile half cylinder is retrofittable, see page 2.28 eca46458 ServicePLUS see page 2.46 2.26 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W Fan with covering grille, 230 VAC epcaseW 쮿 For assembly in cable ducting openings (top/bottom) 쮿 Assembly of fan by clipping in protective grilles 쮿 Connect up to 3 fans via separate connecting cable Delivery comprises Item 1 2 Qty 1 2 Description 230 VAC fan, dimensions 38 x 119 x 119 mm Protective grille, plastic, black Order Information 01503057 Description Part no. Fan with covering grille, 230 VAC 21236-092 Connecting cable for 1 ... 3 fans IEC-320 male 21236-099 connector, 1 piece Thermostat with mains/line connector, 230 VAC, SCHUKO/ 20118-750 UTE connector, IEC-320 female connector, 1 piece Technical data Frequency Voltage Air volume, unrestricted Noise pressure level Max. static pressure Max. ambient temperature Power consumption Connecting cable and earthing for 1 ... 3 fans 01505057 50 Hz 230 VAC 162 m3/h 37 dB(A) 73 Pa +70 °C 15 W 60 Hz 230 VAC 192 m3/h 41 dB(A) 88 Pa +70 °C 14 W Note 쮿 Please order connecting cable separately Protective grille 쮿 For passive cooling 쮿 To cover the opening Delivery comprises Item 1 2 Qty 1 2 Description Protective grille with pins, plastic, black Protective grille with cut-outs, plastic, black Order Information Description Protective grille Part no. 21236-127 01505058 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.27 Wall mounted cases – W Air filter for 19" wall mounted case epc aseW 쮿 Filtering of the inlet air at the case bottom 쮿 Assembly beneath the case, easy filter replacement 쮿 Filter class G3 Delivery comprises Item 1 2 3 Qty 2 3 1 Description Support bracket, St, 1 mm, RAL 7021 Filter mat with round steel frame, filter class G3 Assembly kit Order Information Description Air filter for case depth 300/400 mm Air filter for case depth 500/600 mm Replacement filter mat for case depth 300/400 mm, PU 3 pieces Replacement filter mat for case depth 500/600 mm, PU 3 pieces Part no. 21236-103 21236-104 21236-125 21236-123 01505059 Lever handle for single point locking epc aseW 쮿 For installation instead of key lock insert 쮿 To open press push-button 쮿 DIN profile half cylinder retrofittable Delivery comprises Item 1 2 Qty 1 1 Description Lever handle for single point locking Assembly kit Order Information Description Part no. Lever handle for single point locking 23130-067 DIN profile half cylinder, common locking for lever handle 25127-995 (1 key fits all locks) incl. 2 keys 01005016 Note 쮿 Other locks such as ASSA, KABA or RONIS available on request 2.28 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W 19" equipment shelf, 1 U epcaseW 쮿 Static load-carrying capacity 5 kg 쮿 Mounting height 1 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width Depth mm mm 447 390 19" assembly kit (screw, washer, nut) (4 x M6 screws x 16, 4 x plastic washers, 4 x cage nuts) RAL 7035 Part no. 20118-783 21190-095 00508006 19" equipment shelf, 2 U epcaseW 쮿 Static load-carrying capacity 10 kg 쮿 Mounting height 2 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width Depth mm mm 447 238 19" assembly kit (screw, washer, nut) (4 x M6 screws x 16, 4 x plastic washers, 4 x cage nuts) RAL 7035 Part no. 20118-785 21190-095 00508002 19" equipment shelf, depth-adjustable, 2 U epcaseW 쮿 Static load-carrying capacity 15 kg 쮿 Mounting height 2 U 쮿 Depth-adjustable in 25 mm increments (front protrusion min. 26 mm) Delivery comprises (kit) Item 1 2 Qty 1 2 Description Equipment shelf, St, 1.5 mm Mounting bracket with assembly kit, St, 1.5 mm Order Information 00508009 SCHROFF.PENTAIR.CO.UK Width Depth mm mm 430 250 430 300 19" assembly kit (screw, washer, nut) (4 x M6 screws x 16, 4 x plastic washers, 4 x cage nuts) RAL 7035 Part no. 20118-790 21190-095 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.29 Wall mounted cases – W Modem shelf epc aseW 쮿 For fixing modems and other devices 쮿 Assembly onto the cable support rail or direct onto the case 쮿 Static load-carrying capacity 3 kg Delivery comprises Item 1 2 Qty 1 1 Description Modem shelf, St, 1.5 mm, RAL 7035 Assembly kit Order Information Width mm 200 Depth mm 150 Part no. 21236-122 ECA46468 ECA46469 Vertical 19" plane epc aseW 쮿 For lateral, vertical assembly of 19" components 쮿 Useable for case heights from 12 U Delivery comprises (kit) Item 1 2 3 Qty 1 1 1 Description Vertical 19" plane, St, 2 mm, RAL 7035 Cable support rail, St, RAL 7035 Assembly kit Order Information Height U 3 6 Assembly example with 19" socket strip d mm 167 300 For case depth D mm 300 ... 600 400 ... 600 Part no. 21236-120 21236-121 01505062 ECA46477 2.30 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W Cable eye epcaseW 쮿 For cable fixing/ducting laterally on the panel slide mounts 6 Delivery comprises Item 1 2 36 4 Qty 4 1 Description Cable eye, St, 4 mm, zinc-plated Assembly kit Order Information 34,5 Description Cable eye 56 Part no. 21236-102 01505051 Cable support rail epcaseW 쮿 For strain relief or cable ducting on rear 쮿 Height-adjustable in 25 mm increments Delivery comprises Item 1 2 Qty 1 1 Description Cable support rail, St, 1.5 mm, RAL 7035 Assembly kit Order Information Description Cable support rail Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable tie 92 mm x 2.5 mm, PU 25 pieces Velcro strip Polyethylen/Polyamide, black, length 300 mm, PU 10 pieces Part no. 21236-090 20114-728 20118-351 20118-624 01505052 Note 쮿 A cable support rail is already supplied with the 19" wall mounted case Short slide rail epcaseW 쮿 Support for heavy 19" chassis 쮿 To attach on 19" slide mounts 쮿 Static load-carrying capacity max. 15 kg per pair Delivery comprises Item 1 2 Qty 2 / 10 1 Description Short slide rail, St, 1.5 mm, finish AlZn Assembly kit Order Information Description Short slide rail Short slide rail Qty/PU 2 10 Part no. 23130-094 23130-095 sc96xxxx SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.31 Wall mounted cases – W 10" wall mounted case epc aseW 쮿 Multi-functional 10" wall case with hinged side panels 쮿 Cable entry possible from above or below; the cable entry opening can be sealed with a brush strip 쮿 10" slide mounts are depth-adjustable in 25 mm increments Delivery comprises (assembled) 01505007 Item 1 2 Qty 1 1 3 4 5 6 2 2 2 1 Description Basic case, C-form, St, 2 mm, RAL 7021 Glazed door with key lock (key no. 2233), frame, St, 1.5 mm, RAL 7035, Sekurit glass, 4 mm Side panel, St, 1,5 mm, RAL 7035 10" panel/slide mounts, St, 1.5 mm, finish AlZn Brush strips Assembly kit for wall mounting Order Information Height Height H Width W Depth D Weight U mm mm mm kg 4 262 345 280 5 8 462 345 280 10 12 612 345 280 23 GND/earthing, PU 1 kit Cable tie 92 mm x 2.5 mm, PU 25 pieces 19" assembly kit (screw, washer, nut) (32 x M6 screws x 16, 32 x plastic washers, 32 x cage nuts) Feet, plastic, black, PU 4 pieces Part no. 10238-151 10238-152 10238-153 21236-097 20118-351 21190-435 21236-089 Note 쮿 Lever handle and DIN profile half cylinder cannot be retrofitted eca46478 ServicePLUS see page 2.46 2.32 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W Air filter for 10" wall mounted case epcaseW 쮿 Filtering of the inlet air at the case bottom 쮿 Assembly beneath the case, easy filter replacement 쮿 Filter class G3 Delivery comprises Item 1 2 3 Qty 2 3 1 Description Support bracket, St, 1 mm, RAL 7021 Filter mat with round steel frame, filter class G3 Assembly kit Order Information Description Air filter for 10" wall mounted case Replacement filter mat for 10" wall mounted case PU 3 pieces Part no. 21236-095 21236-126 01506050 Equipment shelf for 10" wall mounted case epcaseW 쮿 Static load-carrying capacity 5 kg 쮿 Mounting height 1 U 쮿 Width 10" (254 mm) Delivery comprises Item 1 2 Qty 1 1 Description Equipment shelf, St, 1.5 mm, RAL 7035 Assembly kit Order Information Width mm 220 Depth mm 150 Part no. 20118-716 00508006 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.33 Wall mounted cases – W 10" distribution field epc aseW 쮿 Distribution field with 8 x RJ 45 ports, category 5 쮿 Height 1 U 쮿 Width 10" (254 mm) Delivery comprises Item 1 2 Qty 1 8 Description Distribution field, St, 1.5 mm, RAL 7035 RJ 45 Port Order Information Description 10" distribution field with 8 x RJ 45 ports Assembly kit PU = 8 × screw, washer, nut Part no. 60118-378 21100-435 01504002 10" front panels epc aseW 쮿 Height 1 U 쮿 Width 10" (254 mm) Delivery comprises Item 1 Qty 1 Description Front panel, St, 1.5 mm, RAL 7035 Order Information Item Description 10" blank front panel, St, 1.5 mm, 1a RAL 7035 10" front panel, 8 ports SC, St, 1.5 mm, 1b RAL 7035 10" front panel, 8 ports ST, St, 1.5 mm, 1c RAL 7035 10" front panel with 3 plastic cable eyes, 1d St, 1.5 mm, RAL 7035 Assembly kit PU = 8 × screw, washer, nut Qty/PU Part no. 1 20118-717 1 20118-713 1 20118-714 1 20118-715 21100-435 01503053 2.34 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – W 10" socket strip, 1 U epcaseW 쮿 Socket strip with four socket inserts 쮿 Bracket for mounting on 10" upright is included Delivery comprises Item 1 Qty 1 2 2 Description Socket strip 10", 1 U, 4 socket inserts, 2 m connecting cable with SCHUKO/UTE connector Mounting bracket for 10" assembly Order Information Description 10" socket strip, 4 SCHUKO socket inserts Socket strip 10", 4 UTE socket inserts Assembly kit PU = 8 × screw, washer, nut Part no. 60110-201 60110-220 21100-435 00704001 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.35 LAN wall mounted Main Catalogue Wall mounted cases – LAN wall mounted Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 41801004 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Door and side panels easily removable 41804001 41801005 Vertical 19" plane, therefore low case depth 41801006 Storage of excess cable length Modularity due to basic case and side-by-side modules Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 VTLW6672 Appendix . . . . . 12 2.36 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – LAN wall mounted Overview . . . . . . 2.36 LAN wall mounted Main Catalogue Slim wall mounted cases 쮿 Ideal as fibre optic cable distributor, 4 U wall distributor or as combination of fibre optic cable, copper and telephone distributor 쮿 Optimal ducting of fibre optic cables 쮿 Door and side panels easily removable 쮿 Upgradeable with side-by-side modules Fibre optic small case Small case 쮿 Prepared to accomodate up to four splicing cassettes Small case . . . . . . 2.38 쮿 Low cabinet depth of 85 mm Cable ducting for fibre cable . . . . . . . 2.38 Insertion plate for splicing cassettes 2.39 Splicing cassette . . . . . . . . . 2.39 41801006 Wall distributor, modular 쮿 Modularity due to basic case and side-by-side modules 쮿 Combination of fibre optic cable, copper or telecommunication applications possible 쮿 Low installation depth of 220 mm due to vertical 19" plane Modular wall mounted distributor Basic case . . . . . . . 2.40 Side-by-side module . . . . . . . . . . 2.41 Basic cable ducting . . . . . . . . . . 2.41 Splicing cassette holder . . . . . . . . . . . 2.42 Splicing cassette . . . . . . . . 2.42 LSA+ bracket . . . . 2.43 Locking insert . . . 2.43 41801017 Wall distributor, 4 U, vertical 쮿 Low installation depth of 220 mm due to vertical 19" plane 쮿 Corner door with lateral acrylic glass 쮿 Fan retrofittable 19" bracket . . . . . . 2.43 Wall mounted 4 U distributor Wall mounted 4 U distributor . . . . . . . 2.44 Cable ducting for fibre cable . . . . . . . 2.45 41802002 ServicePLUS . . . 2.46 ServicePLUS from page 2.46 e.g. special colours, special sizes e.g. air conditioning e.g. fittings, conversions, cut-outs e.g. custom solutions www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 2.37 Wall mounted cases – LAN wall mounted Fibre optic small case LAN wall mounted Main CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days 쮿 For distribution of fibre optic main cables or as office distributor 쮿 Space for max. 48 fibres Delivery comprises (assembled) Item 1 Qty 1 2 3 4 5 2 1 1 1 Description Case, St, 1.5 mm, RAL 7035, 2 cable ducting openings each top and bottom (without cover) Side panel, St, 1 mm, RAL 7035, hinged Door, St, 1 mm, RAL 7035, with locking insert 2233-x Quadruple splicing cassette holder Assembly kit for wall mounting (distance from wall 6.5 mm) Order Information 41801003 Height Width Depth mm mm mm 300 300 85 Item 6 Brush strip for fibre optic small case, self-adhesive, PU 2 pieces Item 7 Cable ducting plate for fibre optic small case, St, 1 mm, zinc-plated, PU 2 pieces Part no. 60239-006 60239-030 60239-025 Note 쮿 To cover cable through-ducting openings please order either brush strip or cable through-ducting plate separately 쮿 Push-on plate for splicing cassette, see page 2.39 쮿 Splicing cassettes, see page 2.39 vtlw6684 ServicePLUS see page 2.46 Cable ducting for fibre cable LAN wall mounted Main Catalogue 쮿 For cable ducting with necessary bending radius 30 Order Information Description Cable ducting for fibre cable, plastic, black, PU 4 pieces 42 .5 Part no. 60239-020 .5 19 41804051 2.38 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – LAN wall mounted Insertion plate for splicing cassettes Main Catalogue 쮿 The splicing cassette is assembled on the push-on plate and subsequently inserted in the splicing cassette holder Delivery comprises Item 1 2 Qty 4 8 Description Push-on plate, St, 1 mm, zinc-plated Holding clip for splicing cassette Order Information 41806050 Item Description Item 1a Push-on plate without cable ducting Item 1b Push-on plate with cable ducting for cable ties Part no. 60239-013 60239-014 1b 1a VTLW6678 Splicing cassette Main Catalogue 쮿 Accepts a maximum of 12 splices to the telecom standard 쮿 Fibre optic cable splicing cassettes to DIN 47662 Delivery comprises Item 1 2 3 Qty 1 1 4 Description Splicing cassette, plastic, cream white Cover, plastic, cream white Cable ties Order Information Splicing cassette VTLW6679 Description Splicing cassette Item 1 Splice holder, PU 10 pieces Item 2 Splice protection sleeve, length 60 mm, PU 6 pieces Part no. 60239-062 21101-122 21101-123 Note 쮿 Please order splice holder and splice protection sleeves separately Splice holder (1), splice protection sleeve (2) SCHROFF.PENTAIR.CO.UK vtlw6680 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.39 Wall mounted cases – LAN wall mounted Wall distributor, modular The modular case system is used as sub or floor level distributor, for fibre optic applications as well as for distribution of copper or telecommunication applications. Text The 220 mm deep basic cases can be extended with side-by-side modules and accessories. 41801002 Basic case Main Catalogue 쮿 To accomodate splicing cassette holders, LSA+ holder and/or 19" bracket 쮿 Room for max. 288 fibres and excess cable lengths of up to 1 m Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 1 Description Case, St, 1.5 mm, RAL 7035, 2 cable ducting openings each top and bottom (without cover) Side panel, St, 1 mm, RAL 7035, hinged Door, St, 1 mm, RAL 7035, with locking insert 2233-x Assembly kit for wall mounting (distance from wall 6.5 mm) Order Information 41801001 Height Width Depth mm mm mm 600 425 220 GND/earthing kit for wall mounted distributor, sufficient for one basic case and two side-by-side modules Brush strip for wall mounted distributor self-adhesive, PU 2 pieces Cable ducting plate for wall mounted distributor PU 2 pieces Part no. 60239-001 60239-060 60239-031 60239-026 VTLW6682 ServicePLUS see page 2.46 2.40 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Wall mounted cases – LAN wall mounted Side-by-side module Main Catalogue 쮿 For side-by-side mounting to basic case, selectively on the right or left 쮿 To accommodate splicing cassette holders or LSA+ holder Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 1 1 Description Side-by-side module, St, 1.5 mm, RAL 7035, 2 cable ducting openings top and bottom Door, St, 1 mm, RAL 7035, with locking insert Door post Assembly kit Order Information Height Width Depth mm mm mm 600 225 220 Brush strip for wall mounted distributor self-adhesive, PU 2 pieces Cable ducting plate for wall mounted distributor PU 2 pieces Part no. 60239-004 60239-031 60239-026 VTLW6673 ServicePLUS see page 2.46 Basic case cable ducting Main Catalogue 쮿 For cable ducting with necessary bending radius 30 쮿 Assembly by inserting into rear panel of case, then given a quarter turn 쮿 Usable in basic case and side-by-side module Order Information 42 .5 D 41804050 Description Basic cable ducting, plastic, black, depth D = 55 mm, PU 4 pieces Part no. 60239-021 Note 쮿 Cannot be used in fibre optic small case nor in 4 U wall mounted distributor SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.41 Wall mounted cases – LAN wall mounted Splicing cassette holder Main Catalogue 쮿 To accommodate 12 splicing cassettes that are also mounted on push-on plates 쮿 Splicing cassette holder is mounted and secured on rear wall of case 쮿 Screw-free fitting Order Information Description Splicing cassette 12-fold, St, 1 mm, zinc-plated, 1 piece holder Item 1a Push-on plate without cable ducting PU 4 pieces Item 1b Push-on plate with cable ducting for cable ties PU 4 pieces Cable tie 92 mm x 2.5 mm, PU 25 pieces Part no. 60239-012 60239-013 60239-014 20118-351 VTLW6677 Note 쮿 Please order push-on plates separately 1b 1a Push-on plates VTLW6678 Splicing cassette Main Catalogue 쮿 Accepts a maximum of 12 splices to the telecom standard 쮿 Fibre optic cable splicing cassettes to DIN 47662 Delivery comprises Item 1 2 3 Qty 1 1 4 Description Splicing cassette, plastic, cream white Cover, plastic, cream white Cable ties Order Information Splicing cassette VTLW6679 Description Splicing cassette Item 1 Splice holder, PU 10 pieces Item 2 Splice protection sleeve, length 60 mm, PU 6 pieces Part no. 60239-062 21101-122 21101-123 Note 쮿 Please order splice holder and splice protection sleeves separately Splice holder (1), splice protection sleeve (2) 2.42 SCHROFF PRODUCT CATALOG E 05/2016 VTLW6679 ELECTRONICS PROTECTION Wall mounted cases – LAN wall mounted Locking insert for basic case and side-by-side module Main Catalogue 쮿 For replacement of basic case or side-by-side module inserts Delivery comprises (assembled) Item 1 2 41804054 Qty 1 2 Description Locking insert Key Order Information Description Locking insert 2233-X (included in basic case) Qty/PU 1 Part no. 60239-051 19" bracket for basic case Main Catalogue 쮿 For constructing a vertical 19" plane (4 U) in the basic case 쮿 Depth-adjustable in 20 mm increments Order Information Description 19" bracket for basic case, St, 1.5 mm, RAL 7035, PU 2 pieces Part no. 60239-035 Note 쮿 Not suitable in fibre optic small case and side-by-side module VTLW6685 LSA+ bracket Main Catalogue 쮿 For retention of LSA+ type connections 쮿 For assembly in basic case or side-by-side module Delivery comprises (kit) Item 1 2 3 4 Qty 2 2 1 1 Description Rail holder, St, 1.5 mm, zinc-plated Rail, stainless steel GND/earthing kit Assembly kit Order Information Description LSA+ bracket Part no. 60239-040 41801501 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.43 Wall mounted cases – LAN wall mounted Wall mounted distributor, 4 U, vertical LAN wall mounted Main Catalogue 쮿 Flat 19" wall mounted case (220 mm deep) for universal cabling systems 쮿 Mounting possibilities for distribution panels (copper and fibre optic) or for active components (e.g. switches), up to a depth of max. 300 mm 쮿 Prepared for fan assembly 쮿 Type of protection IP 20 (when cover plate is closed) Delivery comprises (assembled) 41802002 ServicePLUS see page 2.46 Item 1 Qty 1 2 1 3 1 4 3 5 6 7 1 2 1 8 1 Description Case, St, 1.5 mm, RAL 7035, 2 cable ducting openings each at top and bottom (without cover) Side panel, St, 1 mm, RAL 7035, with ventilation slots (prepared for fan assembly) Corner door, St, 1 mm, RAL 7035, 90° offset, with acrylic glass and lateral lock 2233-x Cover plate for cable ducting openings, supplied loose (plain or with ventilation slots, depending on mounting position) Brush strip, black, supplied loose 19" bracket, St, 1.5 mm, RAL 7035 (4 U, vertical) Assembly kit for wall mounting (distance from wall 6.5 mm) Earthing kit Order Information Height Width Depth mm mm mm 600 425 220 230 VAC fan with covering grille, 1 piece Thermostat mains connection 230 VAC, 1 piece Brush strip for wall mounted distributor self-adhesive, PU 2 pieces 2.44 SCHROFF PRODUCT CATALOG E 05/2016 Part no. 60240-006 20234-822 20118-719 60239-031 ELECTRONICS PROTECTION Wall mounted cases – LAN wall mounted Cable ducting for fibre cable Main Catalogue 쮿 For cable ducting with necessary bending radius 30 Order Information Description Description Cable ducting for fibre cable Plastic, black, PU 4 pieces 42 .5 Part no. 60239-020 .5 19 41804051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.45 Wall-mounted cases ServicePLUS modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Custom drillings, special colours, cut-outs for off-the-shelf products from – 10 pieces with epcase – 25 pieces with CONCEPTLINE, INLINE, QLINE, A48, wall mounted LAN enclosures 쮿 Further information: www.schroff.co.uk/modification solution Simple. Fast. From one source. 쮿 Special sizes, custom solutions, printing from: – 10 pieces with epcase – 25 pieces with CONCEPTLINE, INLINE, wall mounted LAN enclosures – 500 pieces with QLINE, A48 Integration and custom developments 쮿 Integration: components, internal mounting, wiring 쮿 Further information: www.schroff.co.uk/solution Wall-m ounted cases ServicePLUSMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatc h within 10 working days ServicePLUS solution - project examples Plastic case A48 or QLINE 쮿 Plain or glazed doors 쮿 Individual printing, cut-outs, with PG screw fitting or with complete assembly 40508001 Steel case INLINE 쮿 Terminal case or installation case with support rails or mounting plates with customised depth bolts 쮿 Cut-outs and drillings marked with specified printing; paintfree contact area for installed components 40708001 2.46 SCHROFF E 05/2016 ELECTRONICS PROTECTION Wall-mounted cases ServicePLUS ServicePLUS solution - project examples CONCEPTLINE in special colour (RAL 3027) 쮿 Steel case with a high type of protection: IP 66 쮿 Mounting plate with hole grid to fix assemblies 쮿 Lever handle with optional DIN cylinder 41108003 CONCEPTLINE control module 쮿 Vehicle data processor in CONCEPTLINE case (IP 66) 쮿 Internal mounting on basis of europacPRO subrack with individually machined front panels 41108002 CONCEPTLINE communication module 쮿 CONCEPTLINE case with heat exchanger (IP 55) 쮿 Internal mounting on basis of europacPRO subrack and backplane for the digital GSM-R communication network 41108001 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 2.47 PROLINE Main C atalogue Cabinet Accessories – Overview Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Mechanics Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Telescopic slides Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Electrics Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 36108007 (00504002 00509005 00508006 00508008 00505032 00711023 00504006 01495004) 3.0 SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Overview Overview . . . . . . 3.0 Mechanics Monitors, keyboards 19" front panels with cable eyes, cable throughducting . . . . . . . . . 3.2 19" cable tray . . . . 3.9 Cable ductings . . . 3.10 19" equipment shelves . . . . . . . . . . 3.11 19" drawers . . . . . 3.13 19" distribution field . . . . . . . . . . . . . 3.14 19" mounting tray for LSA+ . . . . . . . . . 3.15 19" module support . . . . . . . . . . 3.16 Assembly kit . . . . . 3.17 Cable supports . 3.21 Cable channels . . 3.21 Telescopic slides . . . . . . . . . . 3.22 Electrics Cabinet lights . . . . 3.29 Door contact switches . . . . . . . . 3.32 19" distributors . . 3.33 Small distribution modules . . . . . . . . . 3.34 Supply modules . . 3.34 GND/earthing rails . . . . . . . . . . . . . 3.37 Equipment cables 3.38 Bus bars . . . . . . . . . 3.39 Monitor, keyboard Monitor, keyboard . . . . . . . . 3.44 19" drawer with keyboard . . . . . . . . 3.45 Socket strips with connecting cable SCHUKO . . . . . . . . . 3.52 UTE . . . . . . . . . . . . . 3.55 IEC . . . . . . . . . . . . . . 3.58 BS . . . . . . . . . . . . . . 3.61 US . . . . . . . . . . . . . . 3.62 Switzerland . . . . . 3.63 19" power distributors, 3-phase . . . . . . . . . 3.65 Socket strips, Wieland ® . . . . . . . 3.66 Socket strips Power Control socket strips 3.72 Multimeter . . . . . . 3.74 Telemonitored socket strips . . . . . 3.75 Power management software . . . . . . . . 3.79 36108008 (00510003 00510006 00709018 00711008 00709001 00708032) Mechanik SCHROFF.PENTAIR.CO.UK 3.1 Cabinet Accessories – Mechanics Front Panel Express MechanicsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days We make your front panel. You determine how long it takes us. 쮿 Simple: You configure your front panels direct online. No registration, no program downloads. The price is displayed immediately. 쮿 Fast: You specify your front panel in just a few minutes and we manufacture it from as little as in 2 days. 쮿 Flexible: You determine the quantity and manufacturing time and thus the cost. 쮿 Individual: We make the panels to your specification mechanical processing, painting and printing. 쮿 Practical: We make the job easier for you - if you wish we will also fit the accessories. FRONT PANEL EXPRESS 30402151_e 19" front panels with holes for handles MechanicsMain Catalogue 쮿 19" front panels have additional holes for mounting of handles Delivery comprises Item 1 Qty 1 Description 19" front panel, AI Order Information 00592006 Height H D E U 1 2 3 4 5 6 mm 43.6 88.1 132.5 177.0 221.4 265.9 mm 31.7 76.2 57.1 101.6 146.0 190.4 mm 25 55 88 120 180 180 Front panel, 4 mm, anodised Part no. Front panel, 3 mm, pre-anodised, cut edges plain Part no. 40304-050 40304-051 30219-161 30219-162 40304-052 30219-163 40304-053 40304-054 30219-164 30219-165 40304-055 30219-166 Note 쮿 19" assembly kit, see page 3.17 쮿 Front panel processing to your instructions under www.frontpanelexpress.eu BZA42371 3.2 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics Front handle, one-piece, width 12.2 mm 1U MechanicsMain Catalogue 쮿 Static load-carrying capacity 30 kg/pair 쮿 Bolted from rear Delivery comprises Item 1 Qty 1 Description Front handle, AI extrusion, anodised Order Information Height BZA42316 2 U ... 6 U A E clear anodised Part no. U mm mm 1 41 25 10501-116 2 69 55 10501-004 3 102 88 10501-005 4 132 120 10501-006 5 194 180 10501-007 6 249 235 10501-008 Accessories Panhead screw pozidrive self-locking, M5 × 12, zinc-plated, PU 100 pieces black anodised Part no. – 10501-025 10501-026 10501-027 10501-028 10501-029 21100-788 Delivery is exclusively in Standard Pack Quantity (SPQ): Minimum order quantity 10 front handles or a multiple thereof Note 쮿 Please order panhead screws separately BZA42327 Front handle, multi-part, width 12 mm MechanicsMain Catalogue 쮿 Static load-carrying capacity 10 kg/pair 쮿 In three parts, middle section in Al extrusion, end pieces in glass fibre reinforced plastic 쮿 Bolts on from front Delivery comprises (kit) Item 1 2 Qty 1 2 Description Front handle, AL extrusion, anodised End piece, PA, black Order Information Height A E U mm mm 3 102 88 4 134 120 5 194 180 6 249 235 Accessories Panhead screw pozidrive self-locking, M5 × 12, zinc-plated, PU 100 pieces Part no. 10502-057 10502-059 10502-063 10502-065 21100-788 Delivery is exclusively in Standard Pack Quantity (SPQ): Minimum order quantity 10 front handles or a multiple thereof A3-227 Note 쮿 Please order panhead screws separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.3 Cabinet Accessories – Mechanics 19" front panels MechanicsMain Catalogue 쮿 Al anodised, colours light grey (RAL 7035) or black grey (RAL 7021) Delivery comprises Item 1 Qty 1 Description 19" front panel, AI, 3 mm/4 mm 00504002 sza42889 Order Information Height H D X1 X2 Mounting holes U 1 2 3 4 5 6 7 8 9 10 mm 43.6 88.1 132.5 177.0 221.4 265.9 310.3 354.8 399.2 443.7 mm 31.7 76.2 57.1 101.6 146.0 190.4 234.9 279.4 323.8 368.3 mm – – – – – – 88.9 101.6 101.6 101.6 mm – – – – – – 57.1 76.2 120.6 165.1 pieces 4 4 4 4 4 4 8 8 8 8 3 mm thick, RAL 7021 Part no. 3 mm thick, RAL 7035 Part no. 3 mm, Al anodised, cut edges plain Part no. 4 mm, Al anodised Part no. 30118-948 30118-299 30219-098 40304-074 30118-949 30118-950 30118-301 30118-302 30219-101 30219-104 40304-075 40304-076 30118-951 30118-303 30219-107 40304-077 30118-952 30118-953 30118-304 30118-305 30219-110 30219-113 40304-078 40304-079 30118-954 30118-306 30219-137 40304-080 30118-955 30118-956 30118-307 30118-308 30219-138 30219-143 40304-081 40304-082 30118-957 30118-309 30219-144 40304-083 Delivery: supplied loose with cabinet or frame Part no./35 Note 쮿 19" assembly kit see page 3.17 쮿 Front panel processing to your instructions under www.frontpanelexpress.eu 3.4 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics Clip-on 19" plastic front panels MechanicsMain Catalogue 쮿 Simple fitting by clipping onto the 19" plane 쮿 Attractive design 쮿 Two colors: light gray or black 쮿 6 U front panels can be snapped off in 1, 2 or 3 U increments without tools Delivery includes Item 1 Qty 10 Description Clip-on 19" plastic front panels, ABS, antistatic, UL 94 V-0 Order Information 00507003 Height U 1 1 2 2 6 6 Height mm 43.6 43.6 88.1 88.1 270.0 270.0 Description black light grey black light grey black light grey Delivery: supplied loose with cabinet or frame Part No. D19BPT1RU 87927991 D19BPT2RU 87927992 23130-560 23130-561 Part no./35 00507004 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.5 Cabinet Accessories – Mechanics 19" vented front panel MechanicsMain Catalogue 쮿 Al anodised, Al untreated, light grey (RAL 7035) or black grey (RAL 7021) Delivery comprises Item 1 Qty 1 Description 19" vented front panel, AI, 2.5 mm Note 쮿 19" assembly kit see page 3.17 00504005 00502509 Order Information Height U 1 2 3 H mm 43.6 88.1 132.5 A mm 31.7 76.2 57.1 B mm 11.2 16.6 13.5 C mm 16.9 50.7 101.4 RAL 7021 Part no. RAL 7035 Part no. Al anodised Part no. Al untreated Part no. 30118-962 30118-963 30702-056 30702-057 30702-047 30702-048 30702-044 30702-045 30118-964 30702-058 30702-049 30702-046 Delivery: supplied loose with cabinet or frame Part no./35 19" vented front grille, 2 U MechanicsMain Catalogue Delivery comprises (kit) Item 1 2 3 Qty 1 1 1 Description Front grille, plastic, black Filter Retention bracket, St, 1 mm, hot-dip aluminized Order Information Description 19" vented front grille, 2 U Accessories Replacement filter for 19" vented front grille 2 U, PU 3 pieces Delivery: supplied loose with cabinet or frame Part no. 60715-049 60715-050 Part no./35 Note 02892009 3.6 SCHROFF PRODUCT CATALOG E 05/2017 쮿 19" assembly kit see page 3.17 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" front panel for cable eyes Main Catalogue 쮿 19" front panel to accommodate cable eyes (to mount the eyes, insert and rotate them 45°) Delivery comprises Item 1 Qty 1 Description 19" front panel, 1 U, St, 1.5 mm Order Information Height H U 1 Height H mm 43.6 RAL 7021 Part no. RAL 7035 Part no. 20118-762 20118-761 Delivery: supplied loose with cabinet or frame Part no./35 00509001 Note 쮿 Please order cable eyes separately 쮿 19" assembly kit, see page 3.17 Plastic cable eye Main Catalogue 30 쮿 Simple to fit cable eyes: insert and rotate them 45° Order Information 42 Plastic cable eyes mounted on 19" front panel D .5 00506020 41804050 Plastic cable eye Depth D = 55 mm, with clip, PU 5 pieces Depth D = 100 mm, with clip, PU 5 pieces 60118-458 60118-459 Part no. Delivery: supplied loose with cabinet or frame Part no./35 44 Steel cable eye Main Catalogue 쮿 Simple to fit cable eyes: insert and rotate them 45° 44 Order Information 115 11,5 30 Steel cable eyes mounted on 19" front panel 00506019 00506050 Steel cable eye Round steel 5 mm, width 44 mm, depth 115 mm, PU 5 pieces Delivery: supplied loose with cabinet or frame Part no. 60118-457 Part no./35 44 Double steel cable eye Main Catalogue 44 쮿 Simple to fit cable eyes: insert and rotate them 45° Order Information D 11,5 30 Rubber pad mounted on double steel cable eyes 00509005 00509050 45° Double steel cable eye Round steel 5 mm, width 44 mm, depth D = 80 mm, PU 5 pieces Round steel 5 mm, width 44 mm, depth D = 115 mm, PU 5 pieces Accessories Rubber pad for double steel cable eye for depth D = 80 mm, PU 5 pieces Rubber pad for double steel cable eye for depth D = 115 mm, PU 5 pieces Delivery: supplied loose with cabinet or frame To fix cable eye to front panel: insert and rotate it 45° (example with plastic cable eye) SCHROFF.PENTAIR.CO.UK Part no. 60118-473 60118-474 60118-475 60118-476 Part no./35 41806051 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.7 Cabinet Accessories – Mechanics 19" front panel with cable ducting and cable through ducting Delivery comprises MechanicsMain Catalogue Item 1 Qty 2 Description 19" front panel with integrated cable ducting, St, 1.5 mm, 78 mm deep Order Information Height U mm 1 43.6 2 88.1 Description 2 oval cable ducting openings, 150 x 32 mm 2 oval cable ducting openings, 150 x 76 mm RAL 7035 Part no. RAL 7021 Part no. 20118-757 20118-758 20118-759 20118-760 Delivery: supplied loose with cabinet or frame Part no./35 Note 쮿 19" assembly kit, see page 3.17 00506016 19" cable through ducting MechanicsMain Catalogue 쮿 Mounting height 1 U or 2 U Delivery comprises Item 1 Qty 2 Description 19" cable ducting, St, 1.5 mm Order Information Height Height Description U mm Cable ducting 1 43.6 opening 27.5 x 438 mm Cable ducting 2 88.1 opening 72.0 x 438 mm Delivery: supplied loose with cabinet or frame RAL 7021 Part no. RAL 7035 Part no. 20118-767 20118-734 20118-768 20118-736 Part no./35 Note 01696006 3.8 SCHROFF PRODUCT CATALOG E 05/2017 쮿 19" assembly kit see page 3.17 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" cable ducting with brush strip MechanicsMain Catalogue 쮿 Mounting height 1 U 쮿 No threading necessary Delivery comprises Item 1 Qty 2 Description Al extrusion with brush strip (plastic, black), crimped Order Information Description 19" cable ducting with brush strip Part no. 60118-437 Delivery: supplied loose with cabinet or frame Part no./35 Note 쮿 19" assembly kit see page 3.17 01604007 19" cable tray, 2 U MechanicsMain Catalogue 쮿 Load-carrying capacity 15 kg 쮿 Installation height 2 U 쮿 Depth adjustable in 25 mm grid increments, forward protrusion min. 91 mm, max. 191 mm Delivery comprises (Kit) Item 1 2 Qty 1 2 Description 19" cable tray, 2 U, St, 1.5 mm Mounting bracket, St, 1.5 mm Order Information Width mm 430 Depth mm 450 Delivery: supplied loose with cabinet or frame 00507001 RAL 7021 Part no. RAL 7035 Part no. 20118-795 20118-794 Part no./35 Note 쮿 19" assembly kit see page 3.17 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.9 Cabinet Accessories – Mechanics Cable manager, horizontal MechanicsMain Catalogue 쮿 Excellent horizontal cable ducting for large cable volumes 쮿 The cables are held with robust, rounded cable fingers 쮿 Quick access to cables (cover hinges upwards, downwards or comes off completely) 쮿 Simple to fit: clip in then screw down 쮿 1 and 2 U versions 쮿 Versions for front and rear cable routing 40011010 Front Front and rear 40011006 쮿 Optimal cabling from horizontal to vertical Delivery comprises Item 1 2 Qty 1 1 Description Cable manager, plastic, black Fitting material with user manual Order Information Description Front H H 89073653 89073654 Front and rear Height H U mm Front 1 44,5 Front 2 88,9 Front and rear 2 88,9 Width mm 483.00 483.00 483.00 Depth mm 152 mm 152 mm 229 mm + 152 mm Part no. DCHS1 DCHS2 DCHD2 Note 쮿 19" assembly kit see page 3.17 40011009 Application Cable manager with hinged cover 3.10 40011007 40011008 Top view, cable manager with cable fingers front and rear SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" equipment shelf, 1 U MechanicsMain Catalogue 쮿 Static load-carrying capacity 5 kg 쮿 Mounting height 1 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width mm 447 Depth mm 390 AlZn Part no. RAL 7021 Part no. RAL 7035 Part no. 20118-781 20118-782 20118-783 Delivery: supplied loose with cabinet or frame Part no./35 쮿 19" assembly kit, see page 3.17 00508007 19" equipment shelf, 2 U MechanicsMain Catalogue 쮿 Static load-carrying capacity 10 kg 쮿 Mounting height 2 U Delivery comprises Item 1 Qty 1 Description Equipment shelf, St, 1.5 mm Order Information Width mm 447 Depth mm 238 RAL 7021 Part no. RAL 7035 Part no. 20118-784 20118-785 Delivery: supplied loose with cabinet or frame Part no./35 쮿 19" assembly kit, see page 3.17 00508003 19" equipment shelf, depth-adjustable, 2 U MechanicsMain Catalogue 쮿 Static load-carrying capacity 15 kg 쮿 Installation height 2 U 쮿 Depth adjustable in 25 mm grid increments, forward protrusion min. 26 mm Delivery comprises (kit) Item 1 2 Qty 1 2 Description Equipment shelf, St, 1.5 mm Mounting bracket with assembly kit, St, 1.5 mm Order Information 00508010 Width mm 430 430 430 Depth mm 250 300 400 Delivery: supplied loose with cabinet or frame RAL 7021 Part no. RAL 7035 Part no. 20118-786 20118-787 20118-790 20118-788 20118-791 Part no./35 쮿 19" assembly kit, see page 3.17 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.11 Cabinet Accessories – Mechanics 19" shelf, stationary, depth-adjustable, 1U Mechanics 쮿 Static load-carrying capacity 68 kg 쮿 Mounting height 1 U 쮿 For mounting on four 19" posts or four 19" panel/slide mounts 쮿 Variable mounting dimensions (depth-adjustable from 19" angle to 19" angle) 쮿 2 versions – Mounting dimensions 495 ... 851 mm – Mounting dimensions 792 ... 1151 mm 쮿 2 oval cut-outs for cable ducting 쮿 Colour black, RAL 9005 Delivery comprises Shelf with variable mounting dimensions Item 1 Qty 1 2 1 40011016 Description Shelf, depth-adjustable, width 19", RAL 9005 (black); shelf is suspended on 19" upright or 19" panel/slide mount Fitting material with user manual Order Information 19" shelf, stationary, depth-adjustable, 1 U Mounting dimensions D 495 ... 851 mm Mounting dimensions D 792 ... 1151 mm D 44 441 Part no. D19FVT69B D19FVT912B Note 쮿 19" assembly kit see page 3.17 465 483 89073664 3.12 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" drawer MechanicsMain Catalogue 쮿 Height 1, 2 or 3 U 쮿 Static load-carrying capacity 15 kg 쮿 Optional writing surface Delivery comprises ((assembled)) Item 1 1 Qty 1 2 Description 19" drawer with lock (2 keys) Assembly kit Order Information Height H 00506009 43 9 0 45 Front panel anodised Part no. Front panel RAL 7021 Part no. U mm mm 1 41.6 30 20110-061 20110-180 2 86.0 73 20110-062 20110-181 3 130.5 117 20110-063 20110-182 Accessories Writing surface for 19" drawer St, 1 mm, RAL 7035, 1 piece Front panel RAL 7035 Part no. 20110-054 20110-055 20110-056 20110-060 Delivery: supplied loose with cabinet or frame Part no./35 HE h H 40 3 2 41 Height h 50 ~3 19" drawer sza44206sza46122 Writing surface 19" keyboard drawer, 2 U MechanicsMain Catalogue 쮿 For keyboards up to 425 mm width, 210 mm depth, 45 mm height 쮿 IP 40 when closed Delivery comprises Item 1 Qty 1 2 3 4 2 1 2 Description Keyboard drawer with hinged front panel, AI, anodised (incl. locking) Telescopic slide, St, zinc-plated Keyboard chassis, St, 2.5 mm, RAL 7030 Front horizontal rail, Al extrusion, anodised Order Information 005002 210 Delivery: supplied loose with cabinet or frame Part no. 10822-009 60126-118 Part no./35 Note 425 쮿 Without keyboard 쮿 19" assembly kit, see page 3.17 88,1 180 Description 19" keyboard drawer, 2 U Accessories Lock for 19" keyboard drawer 1 × lock incl. 2 keys 40 ~2 A41263 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.13 Cabinet Accessories – Mechanics 19'' distribution field, Cat 6 MechanicsMain Catalogue 쮿 1 U distribution field with 24 x RJ45 ports 쮿 For use in communications networks, in accordance with ISO/IEC 11801 (as at 03/95) 쮿 Meets the specifications for EN 50 173 (as at 07/95) 쮿 Easy to fit thanks to dual insulation displacement technique (LSA+/110) 쮿 Case can be opened and closed without tools, with quickrelease fastener Delivery comprises (assembled) 01604002 Distribution field Cat 6 Item 1 2 Qty 1 3 3 24 Description 19" case, shielded, St, RAL 7035, 1 U, with earthing stud Backplanes with 8 x dual insulation displacement technique for AWG 22--24 cables and 8 x RJ45 sockets Cable ties Order Information Description 19'' distribution field, Cat 6 Part no. 60118-435 Delivery: supplied loose with cabinet or frame Part no./35 Note 쮿 19" assembly kit see page 3.17 Document pocket MechanicsMain Catalogue 쮿 For storage of documents and circuit diagrams 쮿 Assembly with double sided adhesive tape Delivery comprises Item 1 2 Steel, DIN A4 Plastic, DIN A4 00506004 00506005 Qty 1 1 Description Document pocket Adhesive tape Order Information Description Steel, DIN A4, RAL 7035 Plastic, DIN A4, grey Plastic, DIN A3, grey Dimensions H × W × D mm 180 × 336 × 34 195 × 356 × 21 305 × 305 × 25 Delivery: supplied loose with cabinet or frame Plastic, DIN A3 3.14 SCHROFF PRODUCT CATALOG E 05/2017 Part no. 21126-271 60100-302 ADP2 Part no./35 00506006 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" mounting tray for LSA+ MechanicsMain Catalogue 쮿 Mounting height 3 U 쮿 For retention of up to 15 LSA+ guide rails Delivery comprises (kit) Item 1 2 Qty 1 2 Description 19" mounting tray, St, 1.5 mm, finish AlZn Flange cover, Al, anodised Order Information Description 19" mounting tray for LSA+ Part no. 21493-079 Delivery: supplied loose with cabinet or frame 00506008 Part no./35 Note 쮿 19" assembly kit see page 3.17 VTA45668 19" mounting bracket MechanicsMain Catalogue 쮿 Mounting height 1 U 쮿 For fixing cable channels and system rails (e.g. LSA+ or Infra+) 쮿 Mounting plane set back by optionally 70 or 170 mm relative to the 19" plane Delivery comprises Item 1 Qty 1 Description 19" mounting bracket, St, 1.5 mm, RAL 7035 Order Information Description 00506007 19" mounting bracket 19" mounting bracket Delivery: supplied loose with cabinet or frame Depth mm 70 170 Part no. 30118-802 30118-803 Part no./35 Note 쮿 19" assembly kit see page 3.17 SC30 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.15 Cabinet Accessories – Mechanics 19'' module support, 3 U MechanicsMain Catalogue 쮿 For assembly of partial width front panels with SUB-D-, ST type 3 or FDDI cut-outs D 쮿 Available in two versions – without strain relief rail – with strain relief rail 3 2 쮿 Optional front panels, Al, 2.5 mm, RAL 7035 Delivery comprises (kit) 1 Item 1 2 3 4 Qty 1 2 2 1 5 1 Description 19" module support, 3 U, Al Threaded inserts with thread M2.5 Gland plate, St, 1 mm, RAL 7035 Strain relief rail, St, 1.5 mm, RAL 7035 (only for version with strain relief) Assembly kit Order Information Description 36 11,4 R 3,4 25 3,1 20,5 36 20,5 11,4 R 3,4 3,1 25 44,3 25 20,5 3,1 R 3,4 00508057 11,4 005080510050805200508053 Front panel Sub-D 9-pin Height U Depth D mm 19" module support without 3 40 strain relief 19" module support with strain relief 3 115 Accessories Front panel 3 U, 4 HP, 1 piece Front panel 3 U, 7 HP, 1 piece Front panel 3 U, 14 HP, 1 piece Front panel 3 U, 28 HP, 1 piece Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 1 x 9-pin, 1 piece Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 2 x 9-pin, 1 piece Front panel Sub-D 9-pin 3 U, 4 HP, cut-out 3 x 9-pin, 1 piece Front panel Sub-D 25-pin 3 U, 4 HP, cut-out 1 x 25-pin, 1 piece Front panel Sub-D 25-pin 3 U, 4 HP, cut-out 2 x 25-pin, 1 piece Quick release fastener for front panel assembly, PU 100 pieces Delivery: supplied loose with cabinet or frame Part no. 20118-630 20118-631 30118-328 30118-329 30118-330 30118-331 30118-338 30118-336 30118-332 30118-334 30118-335 21100-586 Part no./35 Note 11,4 R 3,4 FRONT PANEL EXPRESS 47 3,1 42,5 55,7 R 3,4 47 42,5 3,1 쮿 Please order front panels or quick-release fastener separately 쮿 19" assembly kit, see page 3.17 쮿 Front panel processing to your instructions under www.frontpanelexpress.eu 11,4 Front panel Sub-D 25-pin 3.16 SCHROFF PRODUCT CATALOG E 05/2017 0050805400508055 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics 19" assembly kit M6 MechanicsMain Catalogue 쮿 For mounting of front panels, distribution fields or other components on the frame, slide mounts or depth members with square cut-outs 쮿 For standard GND/earthing use a GND/earthing nut and a nomel washer on at least one attachment point Delivery comprises Item 1 2 3 4 5 Without GND/earthing sc128 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated GND/earthing cage nut, M6, St, zinc-plated Nomel washer, St, zinc-plated, internal diameter 6.1 mm, external diameter 12.2 mm Order Information Item 1+2+3 1+2+3 1+2+3 1+2+3 1 1 1 2 2 3 3 4 4 5 Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Panhead screw M6, zinc-plated Panhead screw M6, zinc-plated Panhead screw M6, zinc-plated, black Plastic washer Plastic washer Cage nut M6 Cage nut M6 GND/earthing cage nut M6 GND/earthing cage nut M6 Nomel washer for GND/earthing, M6 Delivery: supplied loose with cabinet or frame With GND/earthing SCHROFF.PENTAIR.CO.UK Qty/PU 4 32 50 100 50 100 100 50 100 50 100 10 100 100 Part no. 21190-095 21190-435 21101-809 21101-810 21100-021 21100-022 21100-650 21100-015 21100-016 21100-003 21100-004 21120-131 21120-132 21101-173 Part no./35 00504053 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.17 Cabinet Accessories – Mechanics Cage nut M4/M5 MechanicsMain Catalogue 쮿 For assembly of special parts (in square holes), which require a thread diameter of M4 or M5 쮿 For standard GND/earthing use a GND/earthing nut and a nomel washer on at least one attachment point Order Information Description Cage nut M4 Cage nut GND/earthing cage nut bza42733 Cage nut M4 00503050 GND/earthing cage nut M4 GND/earthing cage nut M4 Nomel washer M4 for GND/ earthing Cage nut M5 Cage nut M5 Nomel washer 00502512 GND/earthing cage nut M5 GND/earthing cage nut M5 Nomel washer M5 for GND/ earthing Description St, zinc-plated, for material thickness of 1.8 to 2.6 mm St, zinc-plated, for material thickness of 1.8 to 2.6 mm St, zinc-plated, for material thickness 1.8 to 2.6 mm St, zinc-plated, for material thickness 1.8 to 2.6 mm St, zinc-plated, inner diameter 4.1 mm, external diameter 8 mm St, zinc-plated, for material thickness of 1.8 to 2.6 mm St, zinc-plated, for material thickness of 1.8 to 2.6 mm St, zinc-plated, for material thickness 1.8 to 2.6 mm St, zinc-plated, for material thickness 1.8 to 2.6 mm St, zinc-plated, inner diameter 5.1 mm, external diameter 10.2 mm Delivery: supplied loose with cabinet or frame 3.18 SCHROFF PRODUCT CATALOG E 05/2017 Qty/PU Part no. 50 21100-001 100 21100-002 10 21120-127 100 21120-128 100 21120-148 50 21100-215 100 21100-216 10 21120-129 100 21120-130 100 21120-149 Part no./35 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics Square nut M6 MechanicsMain Catalogue 쮿 For precise, anti-twist secure mounting without clearance 쮿 For standard GND/earthing use a square GND/earthing nut and a nomel washer on at least one attachment point Order Information Description bza42735 Square nut Description St, zinc-plated, for material thickness of 3.7 Square nut M6 mm St, zinc-plated, for Square nut M6 material thickness of 3.7 mm St, zinc-plated, for Square GND/ material thickness of 1.5 earthing nut M6 mm St, zinc-plated, for Square GND/ material thickness of 3.5 earthing nut M6 mm St, zinc-plated, inner Nomel washer for diameter 6.1 mm, external GND/earthing, M6 diameter 12.2 mm Qty/PU Part no. 50 21100-558 100 21101-007 50 21101-172 50 21101-171 100 21101-173 Delivery: supplied loose with cabinet or frame Part no./35 06704051 Square GND/earthing nut Mounting aid for cage nuts MechanicsMain Catalogue 쮿 To fit/remove cage nuts Order Information Description Mounting aid for cage nuts Delivery: supplied loose with cabinet or frame Qty/PU 1 Part no. 21127-990 Part no./35 06708057 A) B) 2) 1) 06708056 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.19 Cabinet Accessories – Mechanics Sandwich cable clamping for C profiles MechanicsMain Catalogue 쮿 Cable ducting in up to 5 planes 쮿 For cable diameter of 4 ... 7 mm, usable width 190 mm Delivery comprises (Kit) Item 1 Qty 6 2 3 4 10 10 1 Description Pressure plate, 15 x 250 mm, St, 2.5 mm, chromated and zinc-plated, bolt spacing 200 mm Rubber strip Spacer M6 for cable diameter of 4 ... 7 mm Assembly kit Order Information Description Sandwich cable clamping for C profiles 20118-740 Part no. Delivery: supplied loose with cabinet or frame Part no./35 01695039 Cable ties MechanicsMain Catalogue Delivery comprises Item 1 Qty 25 Description Cable tie, plastic Order Information Description Cable ties Cable ties Cable ties Part no. 186 mm x 5 mm 360 mm x 5 mm 92 mm x 2.5 mm Delivery: supplied loose with cabinet or frame 20118-352 20118-353 20118-351 Part no./35 01005078 Velcro MechanicsMain Catalogue 쮿 Length 300 mm (for cable bundles of max. 90 mm diameter) Order Information Description Velcro strip, Polyethylen/Polyamide, black, length 300 mm, PU 10 pieces Delivery: supplied loose with cabinet or frame Part no. 20118-624 Part no./35 01005079 3.20 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics Cable support MechanicsMain Catalogue 쮿 For cable support on pull-out devices and chassis 쮿 Cable fixing with cable ties 쮿 2 versions: – Cable support with return spring for a uniform cabling matched to the extraction movements – Cable support without return spring, connected directly to pull-out part Order Information Description Qty/PU Cable support with return spring 1 Cable support without return spring 1 Accessories Cable ties 92 mm x 2.5 mm, PU 25 pieces Delivery: supplied loose with cabinet or frame Cable support with return spring Part no. 20118-729 20118-706 20118-351 Part no./35 00592015 Technical data Cable support with return spring Load-carrying capacity 2 kg Extension length 730 mm Space requirement in 25 mm retracted position Material St, square tube, 16 mm2, zinc-plated Cable support without return spring 5 kg 720 mm 25 mm St profile, 1 mm, zincplated Note 쮿 19" assembly kit see page 3.17 Cable support without return spring 00592016 Cable channel MechanicsMain Catalogue 쮿 For cable ducting in lateral and rear cabinet areas 쮿 For mounting on cabinet uprights, depth members or C-profiles Delivery comprises Item 1 Qty 1 Description Cable channel, 2 m, plastic, grey Order Information Depth D Width W Length mm mm mm 60 30 2000 60 60 2000 Accessories Assembly kit for cable channel (4 brackets, screws, washers, nuts, cage nuts) Delivery: supplied loose with cabinet or frame Part no. 60103-011 60103-010 21100-123 Part no./35 Note 쮿 Please order assembly kit for cable channel separately SC78 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.21 Cabinet Accessories – Mechanics Simple telescopic slide for assembly of subracks in cabinets MechanicsMain Catalogue 쮿 For mounting 84 HP wide subracks in the 19" plane 쮿 Loading capacity: 25 kg per pair 쮿 The guiding profile is matched to the fixing dimension in the cabinet (it is bolted to the 19" profile of the cabinet); the adaptor rail is matched to the depth and fixing dimension on the subrack (it is inserted into the guiding profile like a telescopic slide) 쮿 Safety note: No protection against extraction, no stop at full extension 06101006 Telescopic slides with guiding profile for fitting in cabinets MechanicsMain Catalogue Delivery comprises (kit) Item 1 2 Qty 2 1 Description C-profile, AI Assembly kit Order Information 1 For cabinet range 3 3 Xr 06108072 VARISTAR VARISTAR VARISTAR VARISTAR VARISTAR VARISTAR eurorack eurorack eurorack Novastar Novastar Novastar Lab rack Depth D mm 600 800 900 1000 1100 1200 600 800 900 500 600 800 250 xf mm 50 50 50 50 50 50 60 60 60 33 33 33 0 xr mm 50 50 50 50 50 50 60 60 60 60 60 60 0 Delivery: supplied loose with cabinet or frame C mm 500 700 800 900 1000 1100 480 680 780 407 507 707 250 c1 mm 369 569 669 769 869 969 397 597 697 350 450 650 162 Part no. 24562-464 24562-466 24562-467 24562-468 24562-472 24562-473 24562-449 24562-451 24562-452 24562-460 24562-461 24562-474 24562-446 Part no./35 Note 450 D c Xf c1 쮿 Adapter rail see page 3.23 465 06108082 xf, xr: Distance of 19" plane to cabinet edge (front, rear) c: Distance of 19" planes from each other, c1: Fixing dimension of guiding profile on 19" panel/slide mounts 3.22 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Mechanics Telescopic slides with adaptor rail for subracks MechanicsMain Catalogue 쮿 The rail serves for fixing the subrack on the guiding profile when mounted into a cabinet Delivery comprises (kit) Item 3 4 1 3 Qty 2 1 Description Al extrusion, incl. M4 threaded insert Assembly kit Order Information For subrack depth mm 175 235 295 355 415 475 Part no. 24562-453 24562-454 24562-455 24562-456 24562-457 24562-458 Delivery: supplied loose with cabinet or frame 3 06108072 Part no./35 Note 쮿 Suitable guiding profile see page 3.22 Measuring tape MechanicsMain Catalogue 쮿 Measuring tape with cm, U-, HP-division (length 2 m) 쮿 Plastic case, metal tape measure with automatic retraction Order Information Description Tape measure Qty/PU 1 Part no. 89009-001 32506001 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.23 Cabinet Accessories – Telescopic slides Dimensioning of telescopic slides Calculation of the load-carrying capacity The stated load-carrying capacity P is valid provided that the centre of gravity is in the centre of the extraction (Y/2). For a different position of the centre of gravity (Y1) please use the following formula: Load-carrying capacity P(Y1) = ½ P Y/Y1 (but max. P) Example: Load-carrying capacity P = 45 kg, Extension length Y = 250 mm Position of centre of gravity Y1 = 150 mm Result: P(Y1) = ½ P Y/Y1 = ½ x 45 kg x 250/150 = 37.5 kg 00505053 Calculation of the maximum installation width (w) Text For each telescopic slide the maximum installation width (w) for one shelf or drawer is given. This is the maximum clearance available between the telescopic slides when they are fitted in a 19" cabinet. 00505060 Mounting on 19" panel/slide mounts Text In 19" cabinets, telescopic slides are mounted on the front and rear 19" panel/slide mounts. The length (L) must therefore be matched with the distance between the 19" brackets (depthwise). For this the required 19" pitch (c) is given for each cabinet. 00505061 Telesc opic slides 3.24 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Telescopic slides Telescopic slide, narrow, for subrack Teles copic sli desMA IN CATALOG Part number in bold face type: ready for shipping within 2 working daysP art number in normal type: ready for s hippi ng withi n 1 0 worki ng days 쮿 Suitable for 84 HP width subracks (type F, type H, type L) 쮿 Locks at full extension 쮿 Hinged 쮿 Extension length > 100 % 쮿 Rail width 7.5 mm 쮿 Maximum clear width of extension/drawer w = 84 HP (435 mm) Delivery includes 00516001 Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information W k = rail width 7.5 mm, w = max. installation width 84 HP (435 mm) 00505060 xf c D Length L Extension length Y Loadcarrying capacity P kg 15 15 mm mm 356 See table Technical data 559 See table Technical data Accessories Fixing materials kit for Varistar, to mount 2 telescopic slides, PU 1 kit Fixing materials kit for Novastar, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame 01004146 C dimensions: Varistar 500 mm and 700 mm, Novastar 507 mm to 707 mm Part no. 60110-441 60110-440 21120-193 21120-194 Part no./35 Technical data Length L mm 356 559 Extension length Y Varistar SL/HD mm 350 553 Novastar SL mm 362 565 Novastar HD mm 352 555 Note 쮿 To mount on 19" plane please order assembly kit separately 175,00 235,00 275,00 295,00 355,00 415,00 475,00 00515050 Screw-on position for telescopic slide on side panel of subrack SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.25 Cabinet Accessories – Telescopic slides Universal telescopic slide, 1 U Main Catalogue 쮿 Static load-carrying capacity per pair 23 - 39 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 Can be removed 쮿 Extension length > 100 % 쮿 Rail width k = 9.7 mm, max. installation width of extension/drawer w = 429 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00505011 0050506000505055 k = rail width, w = max. installation width L 356 406 457 508 559 610 660 711 B 92.1 92.1 92.1 92.1 92.1 92.1 92.1 92.1 Load-carrying capacity P kg 39 36 34 32 29 27 23 23 mm 356 406 457 508 559 610 660 711 Accessories Assembly kit For VARISTAR, for assembly of 2 telescopic slides, PU 1 kit Assembly kit For eurorack, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for NOVASTAR, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame Dimensions table A 29.5 29.5 29.5 89.9 89.9 89.9 7.4 7.4 Extension length Y mm 381 432 483 533 584 635 686 737 C 184.2 184.2 184.2 184.2 184.2 184.2 184.2 184.2 Internal part D E 276.2 276.2 276.2 276.2 368.3 276.2 368.3 276.2 368.3 276.2 368.3 276.2 368.3 F 460.4 460.4 G 552.4 552.4 X 349.3 349.3 349.3 501.7 501.7 501.7 603.3 603.3 External part O P Q 304.6 317.3 330.0 355.4 368.1 380.8 406.4 419.1 431.8 457.4 470.1 482.8 508.1 520.8 533.5 558.6 571.3 584.0 609.4 622.1 634.8 660.2 672.9 685.6 Part no. 20110-090 20110-091 20110-092 20110-093 20110-094 20110-095 20110-096 20110-097 21120-158 21120-159 21120-160 Part no./35 Note 쮿 To mount on 19" plane please order assembly kit separately 쮿 Universal telescopic rails can also be fitted without additional components in non-standard applications, thus also in other than 19" cabinets 00505055 3.26 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Telescopic slides Universal telescopic slide, 2 U Main Catalogue 쮿 Static load-carrying capacity per pair 46 - 61 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 Locking at full extension 쮿 Extension length > 100 % 쮿 Rail width k = 16 mm, max. installation width of extension/drawer w = 417 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00505010 0050506000505054 k = rail width, w = max. installation width Dimensions table Length L 305 356 406 457 508 559 610 660 711 A 76.2 101.6 127.0 127.0 152.4 177.8 177.8 203.2 228.6 Internal part B C 177.8 254.0 203.2 304.8 228.6 355.6 279.4 406.4 304.8 457.2 330.2 508.0 381.0 558.8 406.4 609.6 431.8 660.4 SCHROFF.PENTAIR.CO.UK X 305.0 356.0 406.0 457.0 508.0 559.0 610.0 660.0 711.0 D 76.2 88.9 127.0 127.0 152.4 177.8 177.8 203.2 228.6 External part E F 190.5 241.3 215.9 292.1 241.3 342.9 292.1 393.7 317.5 444.5 342.9 495.3 393.7 546.1 419.1 596.9 444.5 647.7 Extension length Y mm 330 381 432 483 533 584 635 686 737 Load-carrying capacity P kg 61 60 58 57 55 52 50 48 46 mm 305 356 406 457 508 559 610 660 711 Accessories Assembly kit For VARISTAR, for assembly of 2 telescopic slides, PU 1 kit Assembly kit For eurorack, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for NOVASTAR, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame G 266.7 317.5 368.3 419.1 469.9 520.7 571.5 622.3 673.1 Part no. 20110-100 20110-101 20110-102 20110-103 20110-104 20110-105 20110-106 20110-107 20110-108 21120-158 21120-159 21120-160 Part no./35 Note 쮿 To mount on 19" plane please order assembly kit separately 쮿 Universal telescopic rails can also be fitted without additional components in non-standard applications, thus also in other than 19" cabinets Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.27 Cabinet Accessories – Telescopic slides Slim universal telescopic slide, 2U Main Catalogue 쮿 Static load-carrying capacity per pair 46 - 57 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 Locking at full extension 쮿 Extension length > 110 % 쮿 Rail width k = 9.7 mm, max. installation width of extension/drawer w = 429 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00505009 0050506000505059 k = rail width, w = max. installation width 356 406 457 508 559 584 610 A 101.6 127.0 127.0 152.4 203.2 203.2 203.2 Internal part w C 184.2 304.8 209.6 355.6 235.0 406.4 260.4 457.2 412.8 508.0 431.8 533.4 438.2 558.8 X 356.0 406.0 457.0 508.0 559.0 584.0 610.0 Load-carrying capacity P kg 57 55 55 55 46 46 46 mm 356 406 457 508 559 584 610 Accessories Assembly kit for VARISTAR, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for eurorack, for assembly of 2 telescopic slides, PU 1 kit Telescopic slides mounting kit for NOVASTAR, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame Dimensions table Length L Extension length Y mm 432 483 533 584 635 660 686 D 101.6 127.0 152.4 152.4 177.8 177.8 203.2 External part E 228.6 254.0 279.4 330.2 355.6 381.0 381.0 Part no. 20110-071 20110-072 20110-073 20110-074 20110-075 20110-076 20110-077 21120-161 21120-162 21120-163 Part no./35 Note F 330.2 381.0 431.8 482.6 533.4 558.8 584.2 쮿 To mount on 19" plane please order assembly kit separately 쮿 Universal telescopic rails can also be fitted without additional components in non-standard applications, thus also in other than 19" cabinets 00505059 3.28 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Telescopic slides Heavy load universal telescopic slide, 2 U Main Catalogue 쮿 Static load-carrying capacity per pair 72 - 100 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 End stop damped 쮿 Extension length > 100 % 쮿 Rail width k = 19.1 mm, max. installation width of extension/drawer w = 411 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00508011 k = rail width, w = max. installation width 0050506000507053 Y mm 473.5 573.5 423,5 473.5 523,5 573.5 623,5 673.5 723,5 Load-carrying capacity P kg 77 83 88 94 100 94 88 72 mm 300 350 400 450 500 550 600 700 Accessories Assembly kit for VARISTAR, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for eurorack, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for NOVASTAR, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame Dimensions table Length L mm 300 350 400 450 500 550 600 650 700 Extension length Y mm 473 573 423 473 523 573 623 723 A 128 128 160 160 192 192 256 SCHROFF.PENTAIR.CO.UK Inner part (mm) B X 300 350 160 400 160 450 192 500 192 550 256 600 256 650 288 700 C 192 224 288 320 384 416 480 544 576 External part (mm) E F 224 256 320 160 352 160 416 192 448 192 512 256 576 256 608 288 Part no. 20110-190 20110-191 20110-192 20110-193 20110-194 20110-195 20110-196 20110-198 21120-164 21120-165 21120-166 Part no./35 Note G 192 192 224 224 288 288 320 쮿 To mount on 19" plane please order assembly kit separately 쮿 Universal telescopic rails can also be fitted without additional components in non-standard applications, thus also in other than 19" cabinets Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.29 Cabinet Accessories – Electrics Cabinet light for 19" assembly ElectricsMain Catalogue 쮿 With mains on/off switch 쮿 Mounting height 1 U Delivery comprises Item 1 Qty 1 1 1 Description 19" cabinet light with fluorescent tube and mains switch, 1 U, IEC 60320 C14 plug Assembly kit Order Information 00504006 Description Cabinet light for 19" assembly Accessories Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, IEC IEC 60320 C14 plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 socket, 2.5 m, 1 piece Door contact switch, cabled SCHUKO/UTE, "German 3-wire", earthed/grounded plug, IEC 60320 C13 socket, 1 piece Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 20118-746 60103-137 60197-053 62150-191 20118-753 Part no./05 Part no./35 Technical data Mains/line voltage Performance Illuminant Connection Assembly Dimensions 230 VAC 14 W Fluorescent tube T8, base G13, diameter 26 mm, length 360 mm IEC 60320 C14 plug 19" plane Height 40 mm, width 483 mm, depth 100 mm Note 쮿 Please order mains cable or door contact switch separately 3.30 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics Cabinet light for frame assembly Main Catalogue 쮿 With mains on/off switch 쮿 VDE approved, non-interference Delivery comprises Item 1 Qty 1 2 1 3 1 Description Incandescent light (plastic case) with connecting cable, IEC 60320 C13 plug and mains switch Mounting angle, height 51 mm, width 309 mm, depth 29 mm Assembly kit Order Information 01695011 Description Cabinet light for frame assembly Accessories Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, IEC IEC 60320 C14 plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece Door contact switch, cabled SCHUKO/UTE, "German 3-wire", earthed/grounded plug, IEC 60320 C13 socket, 1 piece Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 20118-747 60103-137 60197-053 62150-191 20118-753 Part no./05 Part no./35 Technical data SZA45584 Mains/line voltage Performance Illuminant Connection Assembly Dimensions 230 VAC 35 W Light bulb S14s, diameter 30 mm, length 300 mm IEC 60320 C14 plug With mounting bracket for the cabinet frame Height 35 mm, width 309 mm, depth 51 mm Note 쮿 Please order mains cable or door contact switch separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.31 Cabinet Accessories – Electrics Cabinet light for magnetic mounting Main Catalogue 쮿 With mains on/off switch 쮿 With integrated SCHUKO or UTE socket, 230 VAC, 16 A Delivery comprises Item 1 Qty 1 Description Cabinet light (plastic case) with connecting cable, IEC 60320 C14 plug, integrated mains switch and socket Order Information Description Cabinet light for magnet mounting with UTE socket Cabinet light for magnet mounting, with SCHUKO socket Accessories Mains cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, IEC IEC 60320 C14 plug, IEC 60320 C13 socket, 2.5 m, 1 piece Mains cable, SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 socket, 2.5 m, 1 piece Door contact switch, cabled SCHUKO/UTE, "German 3-wire", earthed/grounded plug, IEC 60320 C13 socket, 1 piece Delivery: supplied loose with cabinet or frame Part no. 20118-748 20118-749 60103-137 60197-053 62150-191 20118-753 Part no./35 007_1000 Technical data Mains/line voltage Performance Illuminant Connection Socket Assembly Dimensions 230 VAC 11 W Compact fluorescent lamp PL-S, G23 base, diameter 13 mm, length 200 mm IEC 60320 C14 plug 250 VAC, 16 A Magnet Height 355 mm, width 65 mm, depth 65 mm Note 쮿 Please order mains cable or door contact switch separately 3.32 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics LED light for cabinet mounting Elec tricsMAIN CATALO GPart number i n bold face type: ready for shipping wi thin 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Energy efficient: consumes only 5 W 쮿 Bright: output equivalent to 95 W 쮿 Maintenance-free, long service life 쮿 Easy installation with magnetic mounting 쮿 Integrated, auto-sensing circuitry for 90 ... 260 VAC or 20 ... 60 VDC voltages 쮿 Versions with on/off switch or built-in infrared motion sensor 쮿 Optional accessories: 1 U bracket for 19" installation, clip holders for clip fixing, power cables (preassembled) and connectors (male/female) Order Information LED light for cabinet mounting Description Input 00516004 Technical data Input Input voltage Power consumption Current Color Luminosity Lamp type Light color Service life Mounting Casing Dimensions Weight Operating temperature Storage temperature Operating/Storage humidty Protection type Protection class AC DC 90 ... 230 VAC 20 ... 60 VDC max. 5 W max. 5 W max. 2.5 A / 240 VAC max. 2.5 A / 60 VDC white blue 400 Lm at 120° (1200 Lm at 360° or equivalent 95 W light bulb) LED, angle of radiation 120° Daylight, color temperature: 6000 K to 7000 K 60000 h at +20 °C (+68 °F) Magnetic mounting Plastic, transparent Length 351 mm (13.8"), Diameter 32 mm (1.3") 0.2 kg | 0.5 lbs -30 to +60 °C (-22 to +140 °F) -40 to +85 °C (-40 to +185 °F) max. 90 % RH (non-condensing) IP 20 II (double insulated) III (12 VDC, extra-low voltage) Input voltage V 90 ... 260 VAC 90 ... 260 VAC 20 ... 60 VDC 20 ... 60 VDC With IR motion sensor AC With on/off switch AC With IR motion sensor DC With on/off switch DC Accessories Input cable for AC, length 2.0 m / 78.7 inch, 1 piece Input cable for DC, length 2.0 m / 78.7 inch, 1 piece Extension cable for AC, length 1.0 m / 39,4 inch, 1 piece Extension cable for DC, length 1.0 m / 39,4 inch, 1 piece Connection cable with IEC 60320 C18 connector for AC, length 0,5 m / 19,7 inch, 1 piece Female connector for AC, 1 piece Female connector for DC, 1 piece Male connector for AC, 1 piece Male connector for DC, 1 piece Bracket 19" 1 U, RAL 7021 (black) 1 piece Bracket 19" 1 U, RAL 7035 (grey) 1 piece Clip kit PU 2 pieces SCHROFF.PENTAIR.CO.UK Qty/PU piece 1 1 1 1 Part no. 60118-542 60118-543 60118-544 60118-545 60118-546 60118-547 60118-548 60118-549 60130-114 60118-550 60118-551 60118-552 60118-553 20118-807 20118-808 20118-809 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.33 Cabinet Accessories – Electrics Door contact switch Main Catalogue Delivery comprises Item 1 2 3 Qty 1 1 4 4 1 Description Door contact switch (without connecting cable) PG screw fitting M20 x 1.5 for cable diameter 6 ... 12 mm Mounting angle for cabinet assembly (VARISTAR, PROLINE, eurorack) Assembly kit Order Information Description Door contact switch Part no. 20118-738 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no./05 Part no./35 00505029 Door contact switch, cabled Main Catalogue 쮿 Connection to cabinet light via IEC 60320 C13 socket 쮿 Connection with mains supply via SCHUKO/UTE connector 쮿 Easy handling by plug and play (completely wired) Delivery comprises (completely wired) Item 1 Qty 1 2 3 1 4 4 1 Description Door contact switch with connecting cable to IEC 60320 C13 socket, plug and mains connection SCHUKO/UTE, fully wired PG screw fitting M20 x 1.5 for cable diameter 6 ... 12 mm Mounting angle for cabinet assembly (VARISTAR, PROLINE, eurorack) Assembly kit Order Information 00505028 Description Door contact switch, cabled Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 20118-753 Part no./05 Part no./35 00501501 3.34 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics 19" distribution box Main Catalogue 쮿 For installation of power distribution modules on DIN profile rails (DIN 43880) 쮿 With cable support rail on the rear side, strain relief with clamps 쮿 Two neutral conductors for terminal clamps from 4 ... 35 mm2 Delivery comprises (assembled) 01495004 Item 1 2 Qty 1 1 3 2 4 1 5 6 7 1 1 2 8 1 9 1 Description Case, 2 parts, 3 U/84 HP, AlZn Front panel with cut-out for power distribution module, St, 1 mm, RAL 7035 Neutral conductors for terminal clamps, Cu, 200 x 3 x 10 mm, zinc-plated, insulated mounting DIN profile rail, St, zinc-plated, depth-adjustable with spacing bolts Cable support rail for clamps, zinc-plated Brush strip, plastic, black, for cable entry Sealing strip, fibre glass reinforced Polyester, for unused module positions GND/earthing conductor, Cu, 1.5 mm2, green/yellow, length 360 mm Label strip Order Information sza45585 Connection clamp Description 19" distribution box 19" distribution box (with packaging for overseas shipping) Accessories Terminal clamps for 19" distribution box 4 mm 2, yellow/ green, PU 10 pieces Terminal clamps for 19" distribution box 4 mm 2, blue (N),PU 10 pieces Terminal clamps for 19" distribution box 16 mm2, yellow/ green (PE),PU 10 pieces Terminal clamps for 19" distribution box 16 mm2, blue (N),PU 10 pieces Terminal clamps for 19" distribution box 35 mm2, yellow/ green (PE),PU 10 pieces Terminal clamps for 19" distribution box 35 mm2, blue (N),PU 10 pieces Clamps for 19" distribution box, PU 14 pieces Delivery: supplied loose with cabinet or frame Part No. 60118-434 60118-521 21101-529 21101-532 21101-530 21101-533 21101-531 21101-534 21190-753 Part no./35 Note 01695012 쮿 19" assembly kit, see page 3.17 쮿 Power distribution module, see page 3.36 Clamps 01695034 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.35 Cabinet Accessories – Electrics Small distribution module Main Catalogue 쮿 For the installation of power distribution modules on DIN profile rails (DIN 43880) Delivery comprises Item 1 Qty 1 2 3 4 1 1 1 Description Small distribution module, plastic, light grey, with integrated DIN profile rail Mounting plate for cabinet mounting, Al, 2.5 mm Cover strip, plastic, light grey, for unused module spaces Assembly kit for cabinet assembly Order Information Description Small distribution module 01695010 Part no. 20118-538 Delivery: supplied loose with cabinet or frame Part no./35 Note 쮿 Power distribution module, see page 3.36 SZA45586 Power distribution modules in accordance with DIN 43880 쮿 For fitting into 19" distribution box or small distribution module 쮿 Snaps onto DIN profile rail Order Information Description 01695005 Circuit breakers Circuit breaker 1 x 16 A Circuit breaker 3 x 16 A FI safety switch, 16 A, 30 mA SCHUKO socket 250 V, 16 A UTE socket 250 V, 16 A Delivery: supplied loose with cabinet or frame FI safety switch 3.36 Socket SCHROFF PRODUCT CATALOG E 05/2017 Width mm 17.7 53.5 46 44 44 Part no. 20119-355 20119-356 20119-354 20119-357 20119-358 Part no./35 0169500401695003 ELECTRONICS PROTECTION Cabinet Accessories – Electrics Distribution box Main Catalogue Delivery comprises Item 1 2 3 4 Qty 1 1 1 1 Description Distribution box, plastic, light grey Terminal strip, 5-pin, for cable cross section 2.5 mm2 Mounting plate, Al, 2.5 mm, for cabinet assembly Assembly kit for cabinet assembly Order Information Description Distribution box Part no. 20118-536 Delivery: supplied loose with cabinet or frame Part no./35 01695009 Distribution box with SCHUKO socket Main Catalogue Delivery comprises Item 1 Qty 1 2 1 3 1 Description Distribution box with SCHUKO socket, plastic, light grey, with terminal strip for cable cross section up to 4 mm2 Mounting plate 90 x 100 mm, AlZn, 1.5 mm, for assembly on cabinet uprights, 19" profiles and depth members Assembly kit for cabinet assembly Order Information Description Distribution box with SCHUKO socket Delivery: supplied loose with cabinet or frame 01604004 Part no. 20118-280 Part no./35 sc107 Mounting plate for single sockets Main Catalogue 쮿 For common surface sockets Delivery comprises Item 1 2 Qty 1 1 Description Mounting plate, Al, 2.5 mm, for cabinet assembly Assembly kit for cabinet assembly Order Information Description Mounting plate for single sockets Delivery: supplied loose with cabinet or frame Part no. 20118-537 Part no./35 Note 쮿 Surface socket not included in Schroff product range ela44796 GND/earthing clamp Main Catalogue 쮿 IBM-compatible GND/earthing terminal for connecting a cabinet to the building GND/earth 쮿 Maximum cable cross-section 100 mm2 쮿 Surface tin-plated, in accordance with IBM Ref. No. 4716804 Order Information Description GND/earthing clamp, incl. assembly kit 20118-030 Part no. Delivery: supplied loose with cabinet or frame Part no./35 sc27 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.37 Cabinet Accessories – Electrics GND/earthing rail Main Catalogue 쮿 To connect GND/earthing wire and stranded conductors by means of terminal clamps 쮿 Fixing insulated from the frame Delivery comprises Item 1 2 3 Qty 1 2 1 Description Rail, Cu, cross section 35 mm2 Rail support block for max. 2 rails, plastic Assembly kit for cabinet assembly Order Information sc5 Length mm 200 480 1000 1910 Accessories Additional second GND/earthing rail, length 200 mm, 1 piece Additional second GND/earthing rail, length 480 mm, 1 piece Terminal clamps for GND/earthing rail, cable cross section 4 mm 2,PU 20 pieces Terminal clamps for GND/earthing rail, cable cross section 16 mm2,PU 10 pieces Terminal clamps for GND/earthing rail, cable cross section 35 mm2,PU 5 pieces Delivery: supplied loose with cabinet or frame Part no. 20118-281 20118-282 20118-265 20118-266 60118-145 60118-144 20118-366 20118-365 20118-364 Part no./35 Note 쮿 Please order terminal clamps or second rail separately GND/earthing rail, flat strip Main Catalogue 쮿 To screw on GND/earthing cables with ring tags 쮿 Threaded fixing points M5 in intervals of 20 mm 쮿 Fixing insulated from the frame Delivery comprises Item 1 Qty 1 2 3 2 1 Description Rail, brass, untreated, 1000 x 15 x 3 mm, fixing points M5 in intervals of 20 mm Rail support block, plastic Assembly kit for cabinet assembly Order Information SC6 Description Qty/PU GND/earthing rail, flat strip 1 GND/earthing rail, flat strip 10 Accessories Item 4 Panhead screw M5 x 10, St, zinc-plated, PU 100 pieces Delivery: supplied loose with cabinet or frame Part no. 20118-590 20118-591 21120-150 Part no./35 Note 쮿 Please order panhead screw M5 to screw on GND/earth cable separately 3.38 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics Mains cables Main Catalogue 쮿 Applications: – Fans, cabinet lights, etc. – Industrial PC connections – Uninterruptible power supplies – Systems Delivery comprises Item 1 Qty 1 Description Mains cable, PVC, max. 250 VAC, max. 10 A AZA43067 Order Information Plug, mains/line side Socket IEC 60320 C13, equipment side Length mm Colour For application in black Germany, France, Austria, Norway, The Netherlands, Sweden, Finland, Spain, Portugal, Turkey, Greece, Belgium, Luxemburg Approvals/ certifications Part no. SCHUKO/UTE 2500 grey (to DIN 47732) aza43071 AZA43068 62150-191 60103-131 2500 grey (to DIN 47732) 2500 black Great Britain, Ireland 60103-137 2000 black USA, Canada 60103-141 60704-020 aza43072 BS AZA43069 aza43071 USA AZA43070 AZA43071 IEC 60320 C14 500 1000 00503051 Delivery: supplied loose with cabinet or frame SCHROFF.PENTAIR.CO.UK AZA43071 2500 60110-360 black worldwide IEC 60320 60110-361 60197-053 Part no./35 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.39 Cabinet Accessories – Electrics Busbar 3 and 4 pole Main Catalogue 쮿 Vertical current distribution in cabinets 쮿 Can be sawn off to required length 쮿 Connections: FASTON connector 6.3 x 0.8 mm Delivery comprises (assembled) Item 1 Qty 1 2 3 3 (4) 2 Description Insulating body for 4 inner conductors, length 1855 mm, PVC Inner conductor, pushed in Fixing with insulating block, pushed in, PA 6, black, Order Information Description 00892013 Material Length mm 1855 1855 1855 3 pole E-Cu tin-plated 4 pole E-Cu tin-plated 4 pole Brass untreated Accessories Item 3 Fixing with insulating block PVC, black, PU 10 pieces with assembly kit Item 5 Mounting angle for cabinet assembly St, 1.5 mm, finish AlZn, PU 4 pieces Part no. 20100-018 20100-017 20100-015 20100-019 20100-029 Technical data 00892015 Mains voltage Nominal current CuZn conductor Nominal current Cu conductor Conductor resistance Max. temperature of rail Flammability of insulation body 500 VAC (50 Hz) 32 A (TU = 40 °C) 63 A (TU = 40 °C) 6.8 mΩ/m (brass), 1.9 mΩ/m (Cu) 70 °C UL 94-V0 Note 쮿 After cutting to length, please order fixings with insulating block separately AZA42396 Fixing with insulating block for busbar 3, 4 pole AZA42393 Mounting angle for cabinet assembly aza40567 3.40 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics Busbar 1 and 2 pole Main Catalogue 쮿 Vertical current distribution in cabinet 쮿 Can be sawn off to required length 쮿 Connections FASTON 6.3 x 0.8 mm Delivery comprises (assembled) Item 1 Qty 1 2 3 1 (2) 2 Description Insulating body for 2 inner conductors, length 1900 mm, PVC Inner conductor, pushed in Insulating block, glued in, PA 6, grey Order Information 00892013 Description Material 1 pole 2 pole 2 pole 2 pole E-Cu tin-plated E-Cu tin-plated Brass untreated Brass tin-plated Length mm 1900 1900 1900 1900 Part no. 20100-010 20100-008 20100-006 20100-007 Technical data Mains voltage Isolation voltage Nominal current CuZn conductor Cu conductor Breakdown voltage/test voltage Conductor cross-section Conductor resistance Max. temperature of rail Flammability of insulation body 500 VAC (50 Hz) 750 V 50 A (TU=20°C), 32 A (TU=50°C) 100 A (TU=20°C), 60 A (TU=50°C) 2500 V/2 kV/1 min 18 mm² 4 mΩ/m (brass), 1 mΩ/m (Cu) 70 °C UL 94 V-0 쮿 For mounting please order insulating block or mounting angle separately, see page 3.42 00892014 A4_561 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.41 Cabinet Accessories – Electrics Mounting bracket for busbar 1, 2 pole Main Catalogue 쮿 Mounting of 1 to 3 busbars in full length (max. 6 conductors) 쮿 After cutting to length, glue in new insulating blocks 쮿 Numbers 1...12 are stamped on for conductor identification Delivery comprises Item 1 2 Qty 4 8 Description Mounting bracket, plastic, Noryl, black Screw with cross recess, St, M4 x 30, zinc-plated Order Information Description Mounting bracket for bus bar 1, 2-pole Accessories Item 3 Insulating block for shortened busbar, 1 or 2-pole Item 4 Identification label with transparent cover, PU per 10 pieces Item 5 Mounting angle for cabinet assembly St, 1.5 mm, finish AlZn, PU 4 pieces Part no. 20100-028 20100-009 20100-013 20100-029 Note 쮿 To ensure stability, mounting brackets should be fitted at 500 mm intervals A4-562 A4-565 00505051 Mounting with insulating block for busbar 1, 2 pole Main Catalogue 쮿 Easy and space saving assembly of shortened busbars 2 쮿 With integrated insulating block 쮿 Mounting in rows possible 15 30 Delivery comprises 6,2 Item 1 2 1 Qty 4 4 Description Fixing with insulating block, Noryl, black Screw, M4 x 25, St, zinc-plated Order Information 10 15 ela44253 Description Fixing with insulating block for busbar 1 or 2 pole Mounting angle for cabinet assembly St, 1.5 mm, finish AlZn, PU 4 pieces Part no. 20100-030 20100-029 Note 쮿 M6 screw, washer and nut for row mounting not included ELA44254 3.42 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Electrics Contact protection for bus bar 1 ... 4 pole Main Catalogue 쮿 Cover for the inner conductor (between the connectors) 쮿 Can be shortened at any size Delivery comprises Item 1 Qty 1 Description Protection against contact for busbar, length 1 m Order Information Description Protection against contact for busbar Length m 1 Part no. 60100-398 A4-566 Insulating block for busbar 1 ... 4 pole Main Catalogue 쮿 The insulating block breaks multiple circuits within one rail Delivery comprises Item 1 Qty 10 Description Insulating block, PVC Ø 4 x 20 mm Order Information Description Insulating block for busbar 1 ... 4 pole Part no. 20100-021 A4-1961c SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.43 Cabinet Accessories – Electrics Power connector 63 A for busbar 1 ... 4 pole Main Catalogue 쮿 Nominal current max. 63 A at 40 °C 쮿 Cable cross section max. 16 mm² 쮿 Power supply protected against direct contact Delivery comprises Item 1 Qty 1 2 1 Description Power connector, ABS/E-Cu, tin-plated, ABS, self-extinguishing Allen key, St, zinc-plated Order Information Description Power connector 63 A for busbar 1 ... 4 pole ela44252 Part no. 60100-478 Note 쮿 Power connector requires two FASTON slots Power connector 125 A for busbar 1 ... 4 pole Main Catalogue 쮿 Nominal current max. 125 A at 40°C 쮿 Cable cross section max. 25 mm² 쮿 Power supply protected against direct contact Delivery comprises Item 1 Qty 1 Description Power connector, PA, halogen-free, copper plate, connected Order Information Description Power connector 125 A for busbar 1 ... 4 pole Part no. 60100-575 Note 쮿 Power connector requires three FASTON slots 00505052 3.44 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Monitor, keyboard Monitor, keyboard, touchpad, 1 U Monitor, keyboardMain Catalogue 쮿 Pull-out 17" TFT colour monitor chassis, 1 U (resolution 1280 x 1024, SXGA; connects to VGA interface) 쮿 Keyboard with German, English or French keyboard layout (connects via PS2 or USB) 쮿 Integral touchpad (connects via PS2 or USB) 쮿 Voltage supply: Wide-range input (nominal mains voltage 110 to 240 VAC), Voltage supply 12, 24 and 48 VDC on request 쮿 Depth-adjustable mounting for different pitches of server panel/slide mounts; Mounting depth (dimension c = spacing of 19" profiles): 560 ... 800 mm (smaller mounting depths on request) 00510003 쮿 Further versions on request – With trackball or numeric pad – Keyboard layouts for Arabic, Belgian, Danish, US English, Finnish, Italian, Portuguese, Russian, Swedish, Swiss, Spanish and Czech – With DVI connection Delivery comprises (assembled and wired) Front view Rear view 00510002 00510005 Detail of keyboard, touchpad 00510004 Item 1 Qty 1 2 1 3 4 5 1 1 2 6 7 1 1 Description 1 U chassis, pull-out, RAL 9005 black; 17" monitor, keyboard and touchpad; Monitor connection via VGA (SUB-D 15), keyboard and touchpad via either PS/2 or USB Mains supply cable, length 2 m, SCHUKO/UTE plug ... IEC 60320-C13 socket Connecting cable for mouse PS/2 - PS2, length 2 m Connecting cable for keyboard PS/2 - PS2, length 2 m Connecting cable for keyboard and mouse USB - USB, length 2 m Connecting cable for monitor SUB-D 15, length 2 m Assembly kit and user manual Order Information Technical data Mains voltage Power consumption Monitor 110 ... 240 VAC (50 Hz ... 60 Hz) Active max 30 W, standby < 1 W 17", TFT display, resolution 1280 x 1024 (SXGA), 16.7 million colours, contrast 1000:1, brightness 350 cd/cm², viewing angle 160°, Operating life LED backlight 30000 h, on-screen menu; cConnection by 15-pin H-DSUB socket Keyboard 83 keys (numeric pad integrated), connects to computer via PS/2 or USB Touchpad Industry standard, width 62 mm, height 46 mm, connects to computer via PS/2 or USB Dimensions (with closed Height 1 U (44 mm), width 19" (483 mm), depth without monitor) handle 495 mm, depth with handle 535 mm Dimensions (with open Height 380 mm, width 483 mm, depth min. 1000 mm monitor, fully extracted) (depending on mounting depth) Extraction depth 500 mm Operating / storage 0 ... 50 °C / temperature -20 ... 60 °C Operating / storage 5 ... 90 % / 5 ... 90 % humidity Shock non operating 50 g / 11 ms Vibration non operating 1.5 g / 10-300 Hz Weight 13 kg MTBF 35000 h SCHROFF.PENTAIR.CO.UK Description Qty/PU pieces 1 1 1 German keyboard layout English keyboard layout French keyboard layout Accessories Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Part no. 60118-518 60118-519 60118-520 60103-137 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no./05 Part no./35 Note 쮿 Adaption to other mains connections see page 3.39 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.45 Cabinet Accessories – Monitor, keyboard 19" drawer with keyboard (touchpad) Main Catalog 쮿 Pull-out 1 U drawer with industrial keyboard including function keys, numeric keypad and touchpad; end stop when fully pulled out 쮿 Connects to PS/2 or USB interface with adaptor (please order separately) 쮿 Colour light grey (RAL 8035) or black grey (RAL 7021) Delivery includes (assembled and wired) Item 1 Qty 1 Description 19" drawer with front panel 1 U; keyboard with PS/2 plug, cable length 1.5 m, touchpad 62 x 46 mm Order Information 00510008 Height Width Depth Description RAL 7035 U mm mm Part no. German keyboard 1 482 334 60118-522 layout French keyboard 1 482 334 60118-524 layout UK keyboard 1 482 334 60118-525 layout USA keyboard 1 482 334 60118-523 layout Accessories Adaptor, 2 x PS/2 – USB PS/2 socket – USB plug, length 160 mm, 1 piece RAL 7021 Part no. 60118-526 60118-528 60118-529 60118-527 60118-515 Note 쮿 Please order adaptor, 2 x PS/2 sockets to connect to USB port of computer separately 쮿 19" assembly kit, see page 3.17 Main Catalogue Drawer: Front view, keyboard closed/pulled out Adaptor, 2 x PS/2 – USB 3.46 SCHROFF PRODUCT CATALOG E 05/2017 00510050 00507002 ELECTRONICS PROTECTION Cabinet Accessories – Management Cabinet management basic units ManagementMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 Monitoring and management of air/water heat exchanger, environmental parameters and access 쮿 Local display, Ethernet interface and web interface 쮿 2 versions – EMX 111 Monitoring for one air/water heat exchanger and up to max. 16 sensor values – EMX 888 (19" case): Monitoring for up to 8 air/water heat exchangers and up to max. 128 sensor values EMX 111 00711020 Delivery comprises Item 1 Qty 1 2 1 3 4 13 2 1 1 Description Cabinet management basic unit; integrated power supply unit, 230 VAC, IEC C13 socket Mains cable IEC C13 on SCHUKO/UTE, cable restrainer with clip Mounting bracket Serial interface cable with DB9F connection, black User manual Order Information EMX 888 00711023 Height H mm U 44 – 44 1 Width W mm 251 440 – 19" Depth D mm 53 134 Part no. EMX111 EMX888 Interfaces Rear view EMX 888 00711021 EMX111 1 EMX888 8 1 8 1 8 1 1 1 1 1 1 1 2 1 Description RJ 12 socket, connection point for environmental sensors RJ 45 socket (RS 485; connecting point for air/ water heat exchanger) RJ 45 socket, connection for asset management strips RJ 45 socket, connection point for network (Ethernet) USB socket, host USB socket, device Potential-free contacts RS 232 socket, serial interface Note 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors, see from page 3.48 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.47 Cabinet Accessories – Management Sensors Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 The sensors are connected to the base unit via a RJ12 interface 쮿 The sensors connected are detected automatically Order Information Description Measurements Input Connection Qty/PU pieces Part no. Temperature sensor 1 x temperature Cable length 3 m 1 60110-313 Temperature/ humidity combi sensor 1 x temperature 1 x humidity Cable length 3 m 1 60110-314 Two temperature/ humidity combi sensors 2 x temperature 2 x humidity Cable length 3 m + 3 m 1 60110-315 Two temperature sensors and one temperature/ humidity combi sensor 3 x temperature 1 x humidity Cable length 3 m + 3 m + 3m 1 DPX-T3H1 Dual potential-free contact sensor – Cable length 0.5 m 1 DPX-CC2-TR Differential pressure and temperature sensor 1 x pressure 1 x temperature Cable length 3 m 1 DPX-T1DP1 Airflow sensor 1 x air circulation Cable length 3 m 1 DPX-AF1 00709002 00709002 00709003 00711022 00711018 00711019 00712002 Note 쮿 Other sensors e.g. smoke detector, vibrations, leakage, etc. on request 3.48 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION Cabinet Accessories – Management Hub to accept 4 sensors Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Connections (signals and power) are via RJ12 plug on the power control socket strip or on the cabinet management system 쮿 A maximum of 4 sensors can be connected, thus up to 16 variables (depending on sensors) can be transmitted (temperature sensor, temperature/humidity combi sensor, differential pressure, potential-free contacts, airflow sensor) Delivery comprises 00709011 Item 1 2 Qty 1 1 3 4 5 4 1 2 Description Case, height 18 mm, width 106 mm, depth 37 mm RJ12 socket to connect to socket strip or cabinet management system (IN; for power supply and data transmission) RJ12 socket for connecting sensors (OUT) Connecting cable, RJ12 plug – RJ12 plug, length 1 m Mounting angle, St, 2 mm, RAL 7035 Order Information Description Hub to accept 4 sensors (max. 16 parameters) SCHROFF.PENTAIR.CO.UK Part no. 60110-316 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.49 Socket stripsMain Catalogue Cabinet Accessories – Socket strips Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 00704002 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Single-phase and three-phase strips Systems . . . . . . . 8 00704003 Strips with fixed connecting cables or with Wieland® GST 18 connecting system 00704004 \\ \ Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Broad range of functional elements up to master-slave 00704005 19" power distribution for 3 phases, 2 performance classes 00708047 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 3.50 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips Overview . . . . . . 3.50 Soc ket stripsMain C atalogue Socket strips 쮿 Modular, compact construction with many function elements Socket strips with connecting cable SCHUKO 쮿 Mains input via cable and country-specific plug or via Wieland® GST18 system SCHUKO socket strips . . . . . . . . . . . 3.52 쮿 Horizontal mounting on the 19" plane (1 U) or vertically on the cabinet frame SCHUKO socket strips, master-slave . . . . 3.53 쮿 Multiphase supply via three-phase strips or IEC power distributor SCHUKO socket strips, 3 circuits . . . . . . . . 3.54 UTE UTE socket strips 3.55 Socket strips in 1 U Al extrusion 쮿 Hard wired connecting cable with country-specific mains plug or Wieland® GST18 쮿 Country-specific sockets: IEC, SCHUKO, UTE, British Standard, USA or Swiss versions 쮿 Functional elements: Fault current, overcurrent and transient protection, interference suppression filter with display 쮿 Single-phase and three-phase feed UTE socket strips, master-slave . . . . 3.56 UTE socket strips, 3 circuits . . . . . . . . 3.57 IEC IEC socket strips, C13 . . . . . . . . . . . . . 3.58 IEC socket strips, C19 . . . . . . . . . . . . . 3.59 IEC socket strips, C19, 3 phase . . . . . 3.60 SCHUKO/ IEC Socket strips with with 2 supply cables . . . . . . . . . . . 3.61 BS BS socket strips . . . . . 3.62 US USA socket strips 3.63 Switzerland 00704005 00708032 Socket strips Swiss version . . . . 3.64 19" power distributor, 3-phase 쮿 3-phase distributor to connect single phase consumers or socket strips 쮿 Input 3-phase 400 VAC (32 A or 63 A) 쮿 Output with IEC 60320-C19 sockets – 6 × 230 VAC in 32 A/phase version – 9 × 230 VAC in 63 A/phase version 쮿 Overcurrent protection for each output Socket strips, Wieland ® SCHUKO socket strips, Wieland ® . . . . . . . 3.67 UTE socket strips, Wieland ® . . . . . . . 3.68 IEC socket strips, Wieland ® . . . . . . . . 3.69 Connector cable for Wieland® . . . . 3.70 00708033 19" power distributor ServicePLUS from page 3.71 3-phase . . . . . . . . . 3.71 e.g. individual configuration of design, sockets, power connection, functional elements (filter, overcurrent and overvoltage protection, etc.) ServicePLUS . . . 3.71 Power Control socket strips . . . 3.72 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 3.51 Cabinet Accessories – Socket strips SCHUKO socket strip Socket stripsMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 Socket strips with SCHUKO sockets, with either switch or function elements 쮿 Installation height 1 U 쮿 Connecting cable 2 m with SCHUKO/UTE plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal or vertical mounting 쮿 230 V, 16 A 쮿 In accordance with DIN 57620, VDE 0620 00705001 DTA44115 Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements SCHUKO sockets (35° rotated, PA, RAL 7035), illuminated switch and functional elements, for type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with SCHUKO/UTE connector, PVC, encapsulated Mounting bracket, PA, RAL 7035 (only with 10", 19" version) 00704051 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 Order Information Description SCHUKO SCHUKO - with switch SCHUKO with functional elements Sockets 3 4 9 12 15 19 8 12 15 19 6 6 6 7 8 6 9 Length Inch – 10" 19" – – – 19" – – – 19" 19" 19" 19" 19" 19" – Length mm 184 210 438.5 947.5 1202 1753 438.5 947.5 1202 1753 438.5 438.5 438.5 438.5 438.5 438.5 947.5 Depth mm 44 44 44 44 44 44 44 44 44 44 88 75 88 44 44 44 44 Switch Functional element Part no. – – – – – – X X X X – – – – – – – – – – – – – – – – – Fault current protection Overcurrent protection Fault current protection, overcurrent protection Mains suppression filter Transient protection Transient protection, mains suppression filter Transient protection Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame 60110-200 60110-201 60110-202 60110-203 60110-204 60110-205 60110-206 60110-207 60110-208 60110-209 60110-216 60110-212 60110-217 60110-214 60110-210 60110-266 60110-211 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 3.52 SCHROFF PRODUCT CATALOG E 05/2016 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf ELECTRONICS PROTECTION Cabinet Accessories – Socket strips SCHUKO socket strip, Master-Slave Socket strips 쮿 When the master unit is switched on the slave outlets are connected to the mains (switch threshold adjustable) 쮿 Mounting height 1 U 쮿 Connecting cable 2 m with SCHUKO/UTE plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal or vertical mounting 쮿 110 ... 230 V, 16 A 쮿 In accordance with DIN 57620 00704007 DTA44115 Delivery comprises (assembled) Item 1 2 3 4 Qty 1 6 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets SCHUKO sockets (35° rotated, PA, RAL 7035) End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with SCHUKO/UTE connector, PVC, encapsulated Mounting bracket, PA, RAL 7035 Order Information Sockets Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 6 Length Inch 19" Length mm 438.5 Depth mm 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no. 60110-270 Part no./05 Part no./35 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.53 Cabinet Accessories – Socket strips SCHUKO socket strip, 3-phase Socket strips 쮿 Socket strips with SCHUKO sockets, 3-phase 쮿 Installation height 1 U 쮿 Connecting cable 2 m, open end with ferrules 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Vertical mounting 쮿 3 phases, 16 A per phase 쮿 In accordance with DIN 57620 00704008 DTA44115 Delivery comprises (assembled) Item 1 2 Qty 1 9 3 4 2 1 Description Al extrusion, 1 U, anodised, for sockets SCHUKO sockets (35° rotated, PA, RAL 7035), 3 phases x 3 sockets, different colours End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 5G 2.5 mm2, open end with ferrules Order Information Sockets 9 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00502502 Height U 1 Length mm 608.5 Depth mm 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 60110-219 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf 3.54 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips UTE socket strip Socket strips 쮿 Socket strip with SCHUKO sockets, either with switch or functional elements 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, with SCHUKO/UTE plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 230 V, 16 A 쮿 In accordance with NFC 61-303 00705002 DTA44116 Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements UTE sockets (35° rotated, PA, RAL 7035), illuminated switch and functional elements, for type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with SCHUKO/UTE connector, PVC, encapsulated Mounting bracket, PA, RAL 7035 (only with 10", 19" version) 00704051 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 Order Information Description Socket strip 10", 4 UTE sockets UTE with switch UTE with functional element Sockets 4 9 12 15 19 8 12 6 6 6 7 8 6 Length Inch 10" 19" – – – 19" – 19" 19" 19" 19" 19" 19'' Length mm 210 438.5 947.5 1202 1753 438.5 947.5 438.5 438.5 438.5 438.5 438.5 438.5 Depth mm 44 44 44 44 44 44 44 88 75 88 44 44 44 Switch Functional element – – – – – X X – – – – – – – – – – – – – Fault current protection Overcurrent protection Fault current protection, overcurrent protection Mains suppression filter Transient protection Transient protection, mains suppression filter Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 60110-220 60110-221 60110-222 60110-223 60110-224 60110-225 60110-226 60110-230 60110-228 60110-231 60110-229 60110-227 60110-267 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.55 Cabinet Accessories – Socket strips UTE socket strip, master-slave Socket strips 쮿 When the master unit is switched on, the slave outputs are connected to the mains (switch threshold adjustable) 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, with SCHUKO/UTE plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 230 V, 16 A 쮿 In accordance with NFC 61-303 00704006 DTA44116 Delivery comprises (assembled) Item 1 2 3 4 Qty 1 6 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets UTE sockets (35° rotated, PA, RAL 7035) End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with SCHUKO/UTE connector, PVC, encapsulated Mounting bracket, PA, RAL 7035 Order Information Sockets Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 6 Length Inch 19" Length mm 438.5 Depth mm 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 60110-232 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf 3.56 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips UTE socket strip, 3-phase Socket strips 쮿 Socket strips with UTE sockets, 3-phase 쮿 Installation height 1 U 쮿 Connecting cable 2 m, open end with ferrules 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Vertical mounting 쮿 3 phases, 16 A per phase 쮿 In accordance with NFC 61-303 00704010 DTA44116 Delivery comprises (assembled) Item 1 2 Qty 1 9 3 4 2 1 Description Al extrusion, 1 U, anodised, for sockets UTE sockets (35° rotated, PA, RAL 7035), 3 phases x 3 sockets, different colours End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 5G 2.5 mm2, open end with ferrules Order Information Sockets 9 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00502502 Height U 1 Length mm 608.5 Depth mm 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no. 60110-233 Part no./05 Part no./35 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.57 Cabinet Accessories – Socket strips IEC socket strip, C13 쮿 Socket strips with IEC 60320-C13 sockets 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, open end with ferrules 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 230 V, 10 A 쮿 In accordance with IEC 60320 00710010 dta44118 Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, to accommodate the sockets and function elements IEC 60320-C13 sockets (PA, RAL 7035), quantity see Order information End piece, PA, RAL 7035 Connecting cable, 2 m, black, open end with ferrules, H05VV-F 3G 1.5 mm2 Mounting bracket, PA, RAL 7035, (on 19" versions only) Order Information Sockets Item 6: bracket for vertical mounting 00704051 8 12 16 Length Inch 19" 19" – Length mm 438.5 438.5 608.5 Depth mm 44 44 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Strain relief provided by locking tabs ServicePLUS see page 3.71 3.58 SCHROFF PRODUCT CATALOG E 05/2016 00708036 Part no. 60110-290 60110-291 60110-292 Part no./05 Part no./35 Accessories Locking tab for IEC 60320-C13 connector PU 12 pieces Item 6 Mounting bracket for socket strips for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Mains cable, IEC : for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 0.5 m, 1 piece Mains cable, IEC : for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 1 m, 1 piece 60110-362 20110-068 23130-010 60110-360 60110-361 Note 쮿 Please order bracket for vertical mounting separately 쮿 IEC socket strips, telemonitored and remote-controlled see page 3.75 쮿 IEC socket strips with universal connections (Wieland®connectors) see page 3.67 쮿 Individual online configuration www.schroff.biz/conf ELECTRONICS PROTECTION Cabinet Accessories – Socket strips IEC socket strip, C19 Main Catalogue 쮿 Socket strips with C19 IEC sockets (8 or 12 pieces) 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, with connector in accordance with IEC 60309 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Vertical mounting (19" version horizontal or vertical) 쮿 230 V, 32 A (with 2 x 16 A fuse), 16 A (without fuse) Delivery comprises Item 1 00709015 00709050 Qty 1 2 3 4 5 2 1 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements Sockets, IEC 60320 C19 (PA, RAL 7035), for type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, 2 m, with IEC 60309 connector Mounting bracket, PA, RAL 7035, only for 19" versions Order Information Sockets IEC 60320 C19 8 12 12 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 Length Length Depth Input Inch mm mm 230 VAC, 19" 438.5 44 16 A 230 VAC, – 947.5 44 16 A 230 VAC, – 947.5 44 32 A Fuse Part no. – 60110-280 – 60110-282 2 x 16 A 60110-281 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no./05 Part no./35 20110-068 23130-010 Note 쮿 Please order bracket for vertical mounting separately 쮿 19" assembly kit see page 3.17 쮿 Individual online configuration www.schroff.biz/conf SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.59 Cabinet Accessories – Socket strips IEC socket strip, 3 phase Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Socket strips with IEC sockets in accordance with IEC 60320 (C13 or C13/C19) 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, 3 phase, with connector plug in accordance with IEC 60309 (16 A or 32 A) 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Vertical mounting 쮿 400 V, 32 A (with 6 x 16 A fuse), 16 A (without fuse) Delivery comprises Item 1 00709019 DTA44118 00709050 C13 C19 Qty 1 Description Al extrusion, 1 U, anodised, for sockets and functional elements Sockets IEC 60320 (PA, RAL 7035), type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, 2 m, with IEC 60309 connector 2 3 4 2 1 Order Information Input 400 VAC, 16 A 400 VAC, 16 A 400 VAC, 32 A Length mm Depth Output mm Fuse 947.5 44 – 60110-283 947.5 44 – 60110-284 1753 44 6 x 16 A 60110-285 18 x IEC C13 18 x IEC C13, 6 x IEC C19 24 x IEC C13, 6 x IEC C19 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00502502 Part no. Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order bracket for vertical mounting separately 쮿 19" assembly kit see page 3.17 쮿 Individual online configuration www.schroff.biz/conf 3.60 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips Socket strips with 2 supply cables, SCHUKO and IEC, 3 phase Socket stripsPart num ber in bold face type: ready for despatch wi thin 2 working daysPart number in norm al type: ready for despatch within 10 working days 쮿 Socket strips with IEC 60320-C13 sockets and SCHUKO sockets 쮿 Mounting height 1 U 쮿 Two connector cables (halved in direction of length), 3 m (with open end), 2 x 3 phase, 400 VAC (red, black, white area) 쮿 Socket strips can be rotated in all directions (in 90° increments) during installation 쮿 Horizontal and vertical assembly possible Delivery includes 00712005 DTA44118 C13 DTA44115 SCHUKO Item 1 2 Qty 1 3 4 2 1 Description Al extrusion, 1 U, anodized, for socket inserts Socket inserts, IEC 60320 (PA, RAL 7035), type and quantity see Order information Endpiece, PA, RAL 7035 Connector cable, 2 x 2 m, open cable end for laying Order Information Input Length mm Depth mm 400 VAC, 16 A 1848.5 44 400 VAC, 16 A 1848.5 44 Output 36 x IEC C13 + 12 x SCHUKO 48 x IEC C13 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame 00704051 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no. 60110-286 60110-287 Part no./05 Part no./35 20110-068 23130-010 Note ServicePLUS see page 3.71 SCHROFF.PENTAIR.CO.UK 쮿 Fixing bracket for vertical mounting, only required for fitting into 47 U cabinet, please order separately Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.61 Cabinet Accessories – Socket strips BS socket strip Socket strips 쮿 Socket strips with British Standard sockets, optionally with switch 쮿 Installation height 1 U 쮿 Supply cable 2 m with BS plug (fuse integrated) 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 230 V, 13 A 쮿 In accordance with BS 1363 00705004 DTA44117 Delivery comprises (assembled) Item 1 Qty 1 2 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements BS sockets (PA, RAL 7035) and switch (illuminated), type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with BS connector (integrated 13 A fuse), PVC, encapsulated Mounting bracket, PA, RAL 7035, only for 19" versions Order Information Description Sockets BS BS BS with switch 7 10 6 Length Inch 19" – 19" Length mm 438.5 947.5 438.5 Depth mm 44 44 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. 60110-243 60110-244 60110-245 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf 3.62 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips USA socket strip Socket strips 쮿 Socket strips with USA sockets, alternatively with switch 쮿 Mounting height 1 U 쮿 Connecting cable 2 m, with USA plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 115 V, 15 A 쮿 In accordance with UL-498 00705005 DTA44797 Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements USA sockets (PA, RAL 7035) and switch (illuminated), for type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with USA socket, PVC, encapsulated Mounting bracket, PA, RAL 7035, only for 19" versions Order Information Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 Description Socket inserts US US US with switch 11 15 11 Length Inch 19" – 19" Length mm 438.5 947.5 438.5 Depth mm 44 44 44 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no. 60110-240 60110-241 60110-242 Part no./05 Part no./35 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.63 Cabinet Accessories – Socket strips Swiss socket strip Socket strips 쮿 Socket strips with sockets, Swiss version, optionally with switch 쮿 Installation height 1 U 쮿 Connecting cable 2 m with Swiss version plug 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting 쮿 230 V, 10 A 쮿 In accordance with SEV.IEC 60884 00705006 DTA44124 Delivery comprises (assembled) Item 1 Qty 1 2 3 4 2 1 5 2 Description Al extrusion, 1 U, anodised, for sockets and functional elements Sockets, Swiss version (PA, RAL 7035), switch (illuminated), for type and quantity see Order information End piece, PA, RAL 7035 Supply cable, black, 2 m, 05VV-F 3G 1.0 mm2, with plug (Swiss version), PVC, moulded Mounting bracket, PA, RAL 7035 Order Information Item 6: bracket for vertical mounting ServicePLUS see page 3.71 00704051 Description Sockets 10 Length Inch 19" Length mm 438.5 Depth mm 44 Swiss version Swiss version with switch 60110-453 9 19" 438.5 44 60110-454 Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Part no. Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 20110-068 23130-010 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Individual online configuration www.schroff.biz/conf 3.64 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips Socket strips with power measurement readout on local display Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Socket strips with Schuko or IEC 60320-C13 sockets 쮿 Integrated measurement and display via local display unit 쮿 Mounting height 1 U 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal and vertical mounting Delivery comprises 00711014 3 2 1 . P kW Hz dta44118 dta44115 V ° 4 5 A 6 Item 1 Qty 1 2 3 4 2 1 5 7 2 1 Order Information Height Length U mm 1 kWh 7 00711050 1: Phase indication (P1) - shows measured phase values 2: Frequency (Hz) - current mains frequency 3: Power measurement (kW) - actual power being consumed by consumers taking phase shift into consideration (power consumption of connected devices) 4: Mains voltage (V) - current voltage of mains to which the measurement unit is currently connected 5: Phase angle (°) - phase shift in the mains supply 6: Current (A) - current now being drawn by the connected devices 7: Kilowatt-hours (kWh) - energy meter to record the energy consumption of the connected equipment Description Al extrusion, 1 U, anodised, to accept the sockets and display Sockets, PA, for type and quantity see Order information End piece, PA, RAL 7035 Connecting cable, black, 2 m, 05VV-F 3G 1.5 mm2, with SCHUKO/UTE connector, PVC, encapsulated Mounting bracket, PA, RAL 7035 User manual 1 Measure- Depth Number of outputs ments mm 7 x SCHUKO, I, V, P, f, "German 3-wire", 19" 438.5 44 cos phi earthed/grounded I, V, P, f, 44 8 x IEC C13 19" 438.5 cos phi Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Part no. 60110-294 60110-296 Part no./05 Part no./35 20110-068 23130-010 00704051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.65 Cabinet Accessories – Socket strips 19" power distributor , 3-phase Main Catalogue 쮿 3-phase distributor for connecting to single-phase consumers or socket strips 쮿 Input 3-phase 400 VAC (32 A or 63 A) 쮿 Output via IEC 60320-C19 sockets – 6 × 230 VAC in 32 A/phase version – 9 × 230 VAC in 63 A/phase version 쮿 Overcurrent protection for each output 00708033 Delivery comprises (assembled) Item 1 Qty 1 2 6/9 3 6/9 4 2 Description 19" power distributor, 3 U, St, 1.5 mm, RAL 7021, with cable fitting M32, plastic, white Socket inserts IEC 60320-C19, with plug retaining clip, quantity see Order information Overcurrent protection switch, 16 A, quantity see Order information Handle, Al, black, incl. assembly kit (supplied loose) Order Information 00708035 Overcurrent protection switch (per phase and output socket) Height Width mm mm Depth mm 131 484 250 131 484 250 Output Input 6 (2 × 230 VAC per phase) 9 (3 × 230 VAC per phase) 3 × 32 A (400 VAC) 3 × 63 A (400 VAC) Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame Rear: Plug retaining clip and cable fitting 00708034 Accessories Mains cable, IEC 60320 C20 plug, Wieland® socket to connect 19" power distributor to Wieland®sockets length 1 m, 1 piece Mains cable, IEC 60320 C20 plug, Wieland® socket to connect 19" power distributor to Wieland®sockets length 1 m, 1 piece Mains cable, IEC 60320 C20 plug, Wieland® socket to connect 19" power distributor to Wieland®sockets length 5 m, 1 piece Part no. 60110-365 60110-366 Part no./05 Part no./35 60110-326 60110-327 60110-328 Note 쮿 SCHUKO socket strip see page 3.67 쮿 UTE socket strip see page 3.68 쮿 IEC socket strip see page 3.69 Mains cable for Wieland® socket strips 00708041 ServicePLUS see page 3.71 3.66 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips SCHUKO socket strip with Wieland® input Main Catalogue 쮿 Installation height 1 U 쮿 Input via Wieland® GST 18 plug 쮿 Output via SCHUKO sockets 쮿 Versions with or without overcurrent protection 쮿 Sockets in white, black or red 쮿 Socket strips can be rotated through all four directions (in 90° increments) during installation 쮿 Horizontal or vertical mounting 쮿 In accordance with DIN 57620 00708044 DTA44115 Delivery comprises Item 1 Qty 1 2 6/8 3 4 5 2 1 2 00708037 Overcurrent protection switch Description Al extrusion, 1 U, anodised, length 438.5 mm, depth 44 mm, height 44.45; to accept the sockets Sockets (rotated 35°, polyamide), quantity and colour see Order information End piece, PA, RAL 7035 Wieland connecting socket® GST 18 Mounting bracket, PA, RAL 7035 Note 쮿 Please order bracket for vertical mounting seperately 쮿 Mains connection cables, see page 3.70 쮿 19" power distributor for connection of multiple socket strips, see page 3.66 쮿 Individual online configuration www.schroff.biz/conf Item 6: bracket for vertical mounting 00704051 ServicePLUS see page 3.71 Order Information Description SCHUKO, white, Wieland®,with over-current protection switch SCHUKO, black, Wieland®,with over-current protection switch SCHUKO, red, Wieland®,with over-current protection switch SCHUKO, white, Wieland® SCHUKO, black, Wieland® SCHUKO, red, Wieland® Sockets Length Inch 6 19" 6 19" 6 19" 8 19" 8 19" 8 19" Length mm 438.5 438.5 438.5 438.5 438.5 438.5 Depth mm 44 44 44 44 44 44 Functional element Overcurrent protection Overcurrent protection Overcurrent protection – – – Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame 60110-352 60110-353 60110-354 60110-343 60110-344 60110-345 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces SCHROFF.PENTAIR.CO.UK Part no. 20110-068 23130-010 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.67 Cabinet Accessories – Socket strips UTE socket strip with Wieland® connection Main Catalogue 쮿 Installation height 1 U 쮿 Input via Wieland® GST 18 plug 쮿 Output via UTE sockets 쮿 Versions with or without overcurrent protection 쮿 Sockets in white, black or red 쮿 Socket strips can be rotated through all four directions (in 90° increments) during fitting 쮿 Horizontal or vertical mounting 쮿 In accordance with NFC 61-303 00708045 DTA44116 Delivery comprises Overcurrent protection switch Item 1 Qty 1 2 6/8 3 4 5 2 1 2 00708048 Description Al extrusion, 1 U, anodised, length 438.5 mm, depth 44 mm, height 44.45; to accept the sockets Socket inserts (rotated 35°, polyamide), quantity and colour see Order information End piece, PA, RAL 7035 Wieland connecting socket® GST 18 Mounting bracket, PA, RAL 7035 Note 쮿 Please order mounting bracket for vertical mounting separately 쮿 Mains connection cables see page 3.70 쮿 19" power distributor to connect multiple socket strips see page 3.66 쮿 Individual online configuration www.schroff.biz/conf 00704051 Item 6: bracket for vertical mounting ServicePLUS see page 3.71 Order Information Description Sockets UTE, white, Wieland®, with over-current protection switch UTE, black, Wieland ®, with over-current protection switch UTE, red, Wieland®, with over-current protection switch UTE, white, Wieland® UTE, black, Wieland ® UTE, red, Wieland® 6 6 6 8 8 8 Length Inch 19" 19" 19" 19" 19" 19" Length mm 438.5 438.5 438.5 438.5 438.5 438.5 Depth mm 44 44 44 44 44 44 Functional element Overcurrent protection Overcurrent protection Overcurrent protection – – – Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame SCHROFF PRODUCT CATALOG E 05/2016 60110-355 60110-356 60110-357 60110-346 60110-347 60110-348 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces 3.68 Part no. 20110-068 23130-010 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips IEC socket strip with Wieland® connection Main Catalogue 쮿 Installation height 1 U 쮿 Input via Wieland®GST 18 plug 쮿 Output via IEC 60320 C-13 sockets 쮿 Versions with or without overcurrent protection 쮿 Socket inserts in white, black or red 쮿 Socket strips can be rotated through all four directions (in 90° increments) during fitting 쮿 Horizontal or vertical mounting 쮿 In accordance with IEC 60320 00708046 dta44118 Delivery comprises Strain relief provided by locking tabs 00708036 Item 1 Qty 1 2 6/12 3 4 5 2 1 2 Description Al extrusion, 1 U, anodised, length 438.5 mm, depth 44 mm, height 44.45; to accept the sockets Sockets (rotated 35°, polyamide), quantity and colour see Order information End piece, PA, RAL 7035 Wieland connecting socket® GST 18 Mounting bracket, PA, RAL 7035 Note Overcurrent protection switch 쮿 Please order mounting bracket for vertical mounting separately 쮿 Mains connection cables see page 3.70 쮿 19" power distributor to connect multiple socket strips see page 3.66 쮿 Individual online configuration www.schroff.biz/conf 00708049 00704051 Item 6: bracket for vertical mounting Order Information Description Sockets IEC, white, Wieland®, with over-current protection switch IEC, black, Wieland® , with over-current protection switch IEC, red, Wieland® , with over-current protection switch IEC, white, Wieland® IEC, black, Wieland® IEC, red, Wieland® 6 6 6 12 12 12 Length Inch 19" 19" 19" 19" 19" 19" Length mm 438.5 438.5 438.5 438.5 438.5 438.5 Depth mm 44 44 44 44 44 44 Functional element Overcurrent protection Overcurrent protection Overcurrent protection – – – Delivery: fitted in cabinet or on frame Delivery: supplied loose with cabinet or frame 60110-349 60110-350 60110-351 60110-340 60110-341 60110-342 Part no./05 Part no./35 Accessories Item 6 Mounting bracket for one socket strip for vertical mounting, St, 2 mm, PU 2 pieces Mounting plate for mounting of two socket strips side by side for vertical mounting, St, 2 mm, height 70 mm, depth 135 mm, PU 2 pieces Locking tab for IEC 60320-C13 connector PU 12 pieces Mains cable, IEC for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 0.5 m, 1 piece Mains cable, IEC for locking tab IEC 60320-C14 plug, IEC 60320 C13 socket, 1 m, 1 piece SCHROFF.PENTAIR.CO.UK Part no. 20110-068 23130-010 60110-362 60110-360 60110-361 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.69 Cabinet Accessories – Socket strips Connecting cables for Wieland® socket strips Main Catalogue 쮿 Enables simple connection to current supply (e.g. for socket strips) 쮿 Different connecting plugs 쮿 Different cable lengths available Delivery comprises Pos. 1 Menge Beschreibung 1 Connecting cable, 1.5 mm2, black, input, output and cable lengths see Order information Order Information 00708031 ServicePLUS see page 3.71 Input Open end Open end Open end IEC 60309 IEC 60309 IEC 60309 IEC 60320 C20 IEC 60320 C20 IEC 60320 C20 SCHUKO (German 3-wire earthed) / UTE SCHUKO (German 3-wire earthed) / UTE BS plug BS plug Current A 16 16 16 16 16 16 16 16 16 Output Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Wieland® GST 18 Length m 1 2.5 5 1 2.5 5 1 2.5 5 Part no. 16 Wieland® GST 18 1 60110-329 16 Wieland® GST 18 2.5 60110-330 13 13 Wieland® GST 18 Wieland® GST 18 1 2.5 60110-331 60110-320 60110-321 60110-322 60110-323 60110-324 60110-325 60110-326 60110-327 60110-328 60110-332 Note 쮿 Other inputs, outputs and cable lengths available on request 쮿 Individual online configuration www.schroff.biz/conf 3.70 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Cabinet Accessories – Socket strips Three phase power distribution with 19" power distributor and socket strips with Wieland® connection 2 4 쮿 Modular construction 1 6 쮿 Connection of 19" power distributor (3-phase) in cabinet requires an electrician 쮿 Simple cabling of socket strips with plug-and-play functionality Cabling example Item 1 2 3 4 5 6 3 5 6 Description 19" power distributor 3-phase current connecting cable Socket strips with Wieland® connection, red Socket strips with Wieland® connection, black Mains cable, from 19" power distributor to socket strip Mains cable, from socket strip to consumer (e.g. server) 3 01008070 configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Configuration – Various constructions (lengths) – Various sockets – Various mains connector cables – Single and multi-phase – Combinations of functions (interference suppression filters, residual current circuit breakers, overcurrent protection, transient protection) 쮿 Online configuration: www.schroff.co.uk/configuration solution Simple. Fast. From one source. Integration and customised developments 쮿 Integration in cabinet incl. cabling and function test 쮿 Customised solutions SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.71 P ower Control socket stri ps Cabinet Accessories – Power Control socket strips Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 00711001 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Display 00715001 Interfaces 00711009 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 00708013 Telemonitoring and parametrisation with web-based user interface Event logging 00708014 P ower Control socket stri ps ServiceP LUSMain CatalogP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days Appendix . . . . . 12 3.72 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinet Accessories – Power Control socket strips Overview . . . . .. 3.72 Power Control s ocket stripsMain Catalog Power Management 쮿 Monitoring of power, current and voltage of the entire socket strip or for each separate socket insert 쮿 Telemonitoring and local indication via display 쮿 Remote control of individual inserts (switch on/off) 쮿 Programmable sequential switch-on/off of individual inserts 쮿 Individual user access authorisations for each socket insert Multimeter 쮿 Measurement of current, voltage, apparent power, true power and power factor per phase or outlet Multimeter . . . . . . . 3.74 쮿 Data sent to network or shown on local display 00715002 Telemonitored socket strips 쮿 Measurement of current, voltage, apparent power, true power and power factor per phase or outlet 쮿 Data sent to network or shown on local display Telemonitored (per phase) socket strips . . . ........ 3.75 쮿 Measurement at phase level and switch function on request Telemonitored and remote-controlled socket strips 쮿 Measurement of current, voltage, apparent power, true power and energy consumption at outlet level Remotecontrolled socket strips, telemonitored on each phase . . .. 3.76 쮿 Data sent to network or shown on local display 쮿 Remote-controlled switch-on/off of individual outputs 00715006 Environmental sensors Remotecontrolled socket strips, telemonitored on each outlet . . . . 3.77 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors, see from page 3.49 Power management software . . . . . . . . 3.78 00715007 ServicePLUS from page 3.79 ServicePLUS . . .. 3.79 e.g. individual configuration (dimensions, socket inserts, mains supply) www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 3.73 Cabinet Accessories – Power Control socket strips Telemonitored multimeter Power C ontrol socket stripsMain C atalogPart number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Inline meter, 1 U, 19" case with 19" mounting brackets 쮿 Measures current, voltage and power (apparent and true power) per phase and total 쮿 Local display of current and voltage per phase and sum values 쮿 Ethernet interface and web interface 쮿 4 consumers or socket strips can be connected; input via IEC 60320 C20 plug; outlet via IEC 60320 C19 sockets 쮿 Mains input via C13 socket conforming to IEC 60320 Front view 00715002 쮿 To record temperature, humidity etc, environmental sensors can be connected Delivery includes Rear view 00715003 Item 1 Qty 1 2 3 4 1 2 1 Description Case, black, width 440.0 mm, display and control keys, interfaces on front and rear Mains cable, C13 socket to IEC 60320, cable length 1.5 m 19" mounting bracket, length 305 mm, St, 1 mm, black Cable support rail Order Information Height Width Depth Input U mm mm 1 440.0 183 4 × IEC C20 Accessories Temperature sensor Cable length 3 m, 1 piece Temperature/ humidity combi sensor Cable length 3 m, 1 piece Two temperature/ humidity combi sensors Cable length 2 x 3 m, 2 pieces Dual potential-free contact sensor Cable length x m, 1 piece Two temperature sensors and one temperature/ humidity combi sensor Cable length 3 x 3 m, 1 piece Differential pressure and temperature sensor Cable length 3 m, 1 piece Airflow sensor Cable length 3 m, 1 piece Hub to accept 4 sensors connecting cable 1 m, assembly kit, 1 piece Number of outputs 4 × IEC C19 Output current A 16 Part no. 60110-446 60110-313 60110-314 60110-315 DPX-CC2-TR DPX-T3H1 DPX-T1DP1 DPX-AF1 60110-316 Note 쮿 3-phase version on request 쮿 User manual and current firmware is available for download: Please enter order number at www.schroff.biz/ oneclick/ 쮿 For power management software see page 3.78 쮿 Suitable socket strips see Socket Strips chapter, page 3.58 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors, see from page 3.48 쮿 19" assembly kit, see page 3.17 3.74 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinet Accessories – Power Control socket strips Telemonitored (per phase) socket strips Main Catalog 쮿 Measurement of current, voltage and power (apparent and true power) per phase and sum value 쮿 Local display of current and voltage per phase and sum value 쮿 Ethernet interface and web interface 쮿 Outlets to IEC 60320 with C13 sockets (230 VAC, 10 A) and C19 sockets (230 VAC, 16 A) 쮿 Mains supply 230 VAC/400 VAC, 16 A or 32 A plug, cable length 3m 쮿 With magnetic circuit breakers to UL 489 (for 32 A version) 쮿 To record temperature, humidity etc, environmental sensors can be connected Delivery includes Item 1 Qty 1 2 3 1 1 00711001 Display, interface Description Socket strip, black, with interfaces, socket inserts and display, mains cable length 3 m Fixing materials kit User manual 00711009 Order Information Length Height Depth Input mm Inch mm mm 440 19" 44 133.0 230 VAC, 16 A, 1-phase, IEC 60320 C20 1298 – 52 43.0 230 VAC, 16 A, 1-phase, IEC 60320 C20 1539 – 52 53.0 230 VAC, 32 A, 1-phase, IEC 60309 1780 – 55 52 400 VAC, 32 A, 3-phase, IEC 60309 Accessories Temperature sensor Cable length 3 m, 1 piece Temperature/ humidity combi sensor Cable length 3 m, 1 piece Two temperature/ humidity combi sensors Cable length 2 x 3 m, 2 pieces Dual potential-free contact sensor Cable length x m, 1 piece Two temperature sensors and one temperature/ humidity combi sensor Cable length 3 x 3 m, 1 piece Differential pressure and temperature sensor Cable length 3 m, 1 piece Airflow sensor Cable length 3 m, 1 piece Hub to accept 4 sensors connecting cable 1 m, assembly kit, 1 piece Number of outputs 8 x IEC C13 24 x IEC C13 20 x IEC C13, 4 x IEC C19 24 x IEC C13, 12 x IEC C19 Part no. 60110-306 60110-307 60110-308 60110-455 60110-313 60110-314 60110-315 DPX-CC2-TR DPX-T3H1 DPX-T1DP1 DPX-AF1 60110-316 Note 쮿 Versions with additional switching function on request 쮿 Interface description, user manual, current firmware: To download please enter part number at www.schroff.biz/ oneclick/ 쮿 For power management software see page 3.78 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors see from page 3.48 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.75 Cabinet Accessories – Power Control socket strips Remote-controlled socket strips, telemonitored on each phase Power C ontrol socket stripsMain C atalogPart number in bold face type: ready for s hippi ng within 2 working daysPart number i n normal type: ready for shipping within 10 working days 쮿 Measures current, voltage and power (apparent and true power) per phase and total 쮿 Local display of current and voltage per phase and sum values 쮿 Remote-controlled on/off switching of connected consumers 쮿 Ethernet interface and web interface 쮿 Outlets to IEC 60320 with C13 sockets (230 VAC, 10 A) and C19 sockets (230 VAC, 16 A) 쮿 Mains supply 230 VAC/ 400 VAC, 16 A or 32 A plug, cable length 3 m 쮿 With magnetic circuit breakers to UL 489 (for 32 A version) 쮿 To record temperature, humidity etc, environmental sensors can be connected Delivery includes 00711001 Display, interface Item 1 Qty 1 2 3 1 1 Description Socket strip, black, with interfaces, socket inserts and display, mains cable length 3 m Fixing materials kit User manual 00711009 Order Information Length Height Depth Input mm Inch mm mm 440 19" 44 133 230 VAC, 16 A, 1-phase, IEC 60320 C20 1297 – 52 65 230 VAC, 16 A, 1-phase, IEC 60320 C20 1539 – 52 65 230 VAC, 32 A, 1-phase, IEC 60309 1780 – 52 65 400 VAC, 32 A, 3-phase, IEC 60309 Accessories Temperature sensor Cable length 3 m, 1 piece Temperature/ humidity combi sensor Cable length 3 m, 1 piece Two temperature/ humidity combi sensors Cable length 2 x 3 m, 2 pieces Dual potential-free contact sensor Cable length x m, 1 piece Two temperature sensors and one temperature/ humidity combi sensor Cable length 3 x 3 m, 1 piece Differential pressure and temperature sensor Cable length 3 m, 1 piece Airflow sensor Cable length 3 m, 1 piece Hub to accept 4 sensors connecting cable 1 m, assembly kit, 1 piece Number of outputs Part no. 8 x IEC C13 24 x IEC C13 20 x IEC C13, 4 x IEC C19 24 x IEC C13, 12 x IEC C19 60110-447 60110-449 60110-448 60110-450 60110-313 60110-314 60110-315 DPX-CC2-TR DPX-T3H1 DPX-T1DP1 DPX-AF1 60110-316 Note 쮿 Interface description, user manual, current firmware: To download please enter part number at www.schroff.biz/ oneclick/ 쮿 For power management software see page 3.78 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors see from page 3.48 3.76 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinet Accessories – Power Control socket strips Remote-controlled socket strips, telemonitored on each outlet Power C ontrol soc ket stripsMain C atalogPart number in bold face type: ready for shipping within 2 working daysP art number in normal type: ready for s hippi ng withi n 1 0 worki ng days 쮿 Remote-controlled on/off switching of connected consumers 쮿 Measures current, voltage and power (apparent and true power) per outlet, phase and total 쮿 Local display of current and voltage per outlet, phase and total 쮿 Ethernet interface and web interface 쮿 Outlets to IEC 60320 with C13 sockets (230 VAC, 10 A) and C19 sockets (230 VAC, 16 A) 쮿 Mains input 230 VAC, 32 A plug to IEC 60309, cable length 3 m 쮿 With magnetic circuit breakers to UL 489 쮿 To record temperature, humidity etc, environmental sensors can be connected Delivery includes Item 1 Qty 1 2 3 1 1 00715009 Description Socket strip, black, with interfaces, socket inserts and display, mains cable length 3 m Fixing materials kit User manual Order Information Length Height Depth Input mm Inch mm mm 440 19" 44 183 230 VAC, 16 A, 1 1539 – 52 65 230 VAC 32 A, 1-phase, IEC 60309 1539 – 52 65 230 VAC, 32 A, 1-phase, IEC 60309 1539 – 52 65 400 VAC, 32 A, 3-phase, IEC 60309 Accessories Temperature sensor Cable length 3 m, 1 piece Temperature/ humidity combi sensor Cable length 3 m, 1 piece Two temperature/ humidity combi sensors Cable length 2 x 3 m, 2 pieces Dual potential-free contact sensor Cable length x m, 1 piece Two temperature sensors and one temperature/ humidity combi sensor Cable length 3 x 3 m, 1 piece Differential pressure and temperature sensor Cable length 3 m, 1 piece Airflow sensor Cable length 3 m, 1 piece Hub to accept 4 sensors connecting cable 1 m, assembly kit, 1 piece Number of outputs 8 x IEC C13 20 x IEC C13 20 x IEC C13, 4 x IEC C19 21 x IEC C13, 3 x IEC C19 Part no. 60110-442 60110-443 60110-444 60110-445 60110-313 60110-314 60110-315 DPX-CC2-TR DPX-T3H1 DPX-T1DP1 DPX-AF1 60110-316 Note 쮿 Differential current measurement available on request 쮿 Interface description, user manual, current firmware: To download please enter part number at www.schroff.biz/ oneclick/ 쮿 For power management software see page 3.78 쮿 Sensors (temperature, humidity, differential pressure, airflow...) and hub for connecting multiple sensors see from page 3.48 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.77 Cabinet Accessories – Power Control socket strips Power management software Energy management with Power IQ® 쮿 Centralised administration with mass configuration, firmware administration and designation of outputs Main Catalog 1 LA N 2 4 쮿 Create energy, cost and active current reports at levels from individual plugs or IT devices through to the entire data centre 7 쮿 Export graphical data 쮿 Aggregate data from different manufacturers 3 Order Information Description Power management software 6 Part no. on request 8 9 5 01009050 Cabling example Item 1 2 3 4 5 6 7 8 9 3.78 Description Real-time monitoring of web graphical user interface (GUI) Existing customer server or an optionally available hardware system on which the software is installed Telemonitored and remote-controlled socket strip, available with IEC C13 and C19 socket inserts Linking of items 1, 2 and 3 to LAN CEE power connection cable available with 230 VAC (16 A or 32 A) or 400 VAC (16 A and 32 A) supply Local display Telemonitored environmental sensors Connection of sensors to socket strip Mains cable, from socket strip to consumer (e.g. server) SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Cabinet Accessories – Power Control socket strips ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Configuration options – Various constructions (height, length) – Various mains supply cables – Single phase and multiphase 쮿 Measurement at phase level and switch functions 쮿 Online configuration: www.schroff.co.uk/configuration solution Simple. Fast. From one source. Integration and custom developments 쮿 Cabinet integration, complete construction incl. cabling and function test 쮿 Customised solutions, e.g. software modifications Power C ontrol soc ket strips ServicePLUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 3.79 Main Catalogue Climate control – Overview Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 19" fans 쮿 Pusher fans 쮿 Circulation fans 쮿 Cooling capacity up to 2000 W Climate control . 4 Electronics cases . . . . . . . . . 5 Air filtered fans Subracks/ 19" chassis . . . . 6 쮿 Simple to fit - just clips in 쮿 Protection type up to IP 55 쮿 Airflow volume up to 770 m3/h Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Accessories Backplanes . . . 10 쮿 쮿 쮿 쮿 Heaters Speed control Thermostats Hygrostats Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 36108005 (01192002, 01192009, 01194003, 01108012 00902001 00908001) 4.0 SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Climate control – Overview Overview . . . . . . 4.0 Cooling concepts . . . . . . . . 4.2 Air/water heat exchangers 쮿 Complete cabinet solutions 쮿 For industry and data centers 쮿 Cooling capacities up to 40 kW 19" fan trays . . . 4.4 Air filtered fans . . . . . . . . . . . . 4.20 Accessories Heaters . . . . . . . . . . Fans . . . . . . . . . . . . Speed control . . . . Thermostats . . . . . Hygrostats . . . . . . . 4.56 4.59 4.60 4.61 4.64 Air/water heat exchangers . . . . 1.224 36108006 (01108004 01108002 01102004 00505033 01008020 01006040) SCHROFF.PENTAIR.CO.UK 4.1 Climate control – Service Products / cooling concepts Text Product Closed cabinet Raised cover, ventilation slots Perforated doors 19" circulation fan, top cover fan Cooling principle 01105060 Description Type of protection Noise level approx. Environmental conditions Cooling capacity approx. 1) 01105058 01105056 01105057 Natural convection through thermal radiation Free convection through top opening Free convection through openings in doors/rear panels Cooling with air ≤ IP 55 0 Ti > Ta < 500 W ≤ IP 20 0 Ti > Ta 500 W ... 800 W ≤ IP 20 55 ... 65 dB(A) Ti > Ta 500 W ... 6000 W 2) ≤ IP 20 34 ... 67 dB(A) Ti > Ta < 2000 W 1) depending on cabinet size, electronic components, location and room cooling concept 2) > 800 W are only possible with own, active cooling through components like servers, etc. Ti = cabinet inner temperature Ta = cabinet ambient temperature Thermal simulation ServiceMA IN CATALOG Project support through state-of-the-art simulation technology As the packing density and integration density of components increases, the transport of waste heat rapidly becomes more difficult. Analyzing heat transport through thermal paste, flow and heat radiation makes it possible to identify hot spots as early as the design phase. We use state-of-the-art numerical analyses and simulation methods to accomplish this. This allows the analysis and optimization of cooling concepts for anything from an assembly to an entire cabinet system at the preliminary stage. Our cooling specialists would be happy to assist you in finding the right cooling concept for your project Your advantage: 쮿 Analyzing in detail to eliminate thermal problems at the preliminary stage 쮿 Ensuring the high efficiency and reliability of your systems 쮿 Reducing the number of expensive prototypes and tests 쮿 Reducing expenses and development costs 01103050 4.2 SCHROFF PRODUCT CATALOG E 06/2017 ELECTRONICS PROTECTION Climate control – Service Products/cooling concepts Text Product Air filtered fans Air conditioners Air/water heat exchanger Air/water heat exchanger (LHX 3) (LHX 20/40) Cooling principle 01102050 Description Type of protection Noise level Environmental conditions Cooling capacity approx. 1) 01105061 01007055 01005081 Cooling with air Cooling with coolant Cooling with water Cooling with water ≤ IP 55 39 ... 71 dB(A) Ti > Ta < 1500 W ≥ IP 55 60 ... 81 dB(A) Ta ≤ 55 °C < 17000 W ≥ IP 55 45.2 dB(A) Ta ≤ 70 °C < 3000 W ≥ IP 55 50 ... 70 dB(A) Ta ≤ 70 °C < 40000 W 1) depending on cabinet size, electronic components, location and room cooling concept Ti = cabinet inner temperature Ta = cabinet ambient temperature Servic e Optimal test equipment Servic eMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days Being part of the Pentair group, Schroff and McLean look back on 50 years of experience and are reknown around the world for their expertise in efficient cooling of industrial facilities and equipment. Based on our own laboratory test chambers with the most modern equipement in Europe, America and Asia: 쮿 Walk-in climate chamber to test and optimize completely integrated cabinets and systems under different conditions 쮿 Smaller climate chambers to test components 쮿 Airflow and air resistance measurements in a wind tunnel 쮿 Noise level measurements 쮿 Tests in accordance with DIN EN 60529 to determine the type of protection (IP) Climate bay testing schroff.pentair.com/en/schroff-na 01112001 Outstanding standard products, flexible custom solutions, global technical support and service add up to a ’cool’ combination! Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.3 1 9" fan traysMain Catalogue Climate control – 19" fan trays Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01102012 Standards/Approvals Subracks/ 19" chassis . . . . 6 쮿 Mechanical protection to DIN EN ISO 13857 Contact protection to DIN EN ISO 13857 Electrical safety to EN 60335 part 1 Plastics self-extinguishing to UL 94 V0 쮿 19" assembly area in accordance with: IEC 60297-3-101 Airflow Front panels, plug-in units . . . 7 Vertical airflow (continual warming) Diverted airflow (effective cooling) Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 01109055 With vertical airflow the air becomes steadily warmer as it rises through the cabinet. Connectors, front panel component system . . . . . . . 11 01109054 By using the 1 U airflow element, air is introduced from the front and extracted to the rear. Now all subassemblies receive the same cooling air. Appendix . . . . . 12 4.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays Overview . . . . . . 4.4 19 " fan traysMain Catalogue 19" fan trays 쮿 To cool single components and assemblies in 19" cabinets 쮿 High airflow rate for directed heat removal 쮿 With axial or radial fans 쮿 For voltages 230 VAC, 115 VAC or 24 VDC 쮿 CE- approvals 19" fans 19" fans 쮿 19" circulation fan, height 1 U 1 U with/without front switch . . . . . . 4.6 쮿 230 VAC, 115 VAC and 24 VDC 1 U speedcontrolled and monitored . . . . . . . 4.8 쮿 Up to 1000 m3/h 쮿 With/without mains switch or with temperature-dependent speed control 01109002 19" pusher fans 19" blower units 쮿 Tangential fan, height 2 U Pusher fan, 2 U with tangential blower . . . . . . . . . . 4.9 쮿 230 VAC and 115 VAC 쮿 Up to 320 m3/h 01192009 쮿 19" pusher fan, height 2 U 쮿 230 VAC and 115 VAC Pressure fan, 2 U, (160, 220 mm deep) . . . . . . . . . . . . 4.10 쮿 Up to 530 m3/h 01194005 쮿 19" pusher fan, height 3 U Pusher fan, 3 U. . . 4.12 쮿 230 VAC and 115 VAC 쮿 Up to 570 m3/h ServicePLUS configuration . . . . 4.14 쮿 Variable air outlet with/without pipe connection, upward or to rear Accessories 01102017 19" airflow element . . . . . . . . . 4.15 AC fans . . . . . . . . . . 4.16 ServicePLUS from page 4.19 DC fans . . . . . . . . . . 4.16 e.g. other airflow capacities e.g. supply voltages e.g. other dimensions e.g. custom solutions ServicePLUS . . . 4.19 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 4.5 Climate control – 19" fan trays 19" fan 1 U 19" fan traysMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number in normal type: ready for des patch within 1 0 working days 쮿 Mechanical strain relief for mains cables 쮿 Can be adapted to subracks 쮿 Contact protection in accordance with DIN EN ISO 13857 Delivery comprises (ready to connect) 01194002 Item 1 Qty 1 2 3a 3/6 1 b3 1 Description 19" circulation fan, 1 U, cover/base plate, St, 1 mm, finish AlZn, with perforation; front panel 1 U, AI, 3 mm, anodised Fan, see Order Information AC with IEC connector (mains input IEC 60320), incl. safety clamp for mechanical strain relief DC version with connecting cable, cable length 2.5 m 43,5 Order Information 436 137 81 24 VDC Part no. 115 VAC Part no. 230 VAC Part no. 10713-103 10713-102 10713-100 10713-107 10713-106 10713-104 20713-240 20713-244 20713-243 85 193 137 330 KTA44857 KTA44858 Replacement fan 1 piece 483 KTA44306 Side panel connecting bracket between europacPRO subrack and fan, including fixing material kit, PU 4 pieces Equipment cable SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, USA USA plug, IEC 60320 socket, 2 m, 1 piece 21101-954 60103-131 60103-137 60103-141 ServicePLUS see page 4.19 Technical data Voltage Frequency in Hz Number of fans Airflow volume in m3/h (3/6 fans) Noise level in dB(A) (3/6 fans) Power consumption in W (3/6 fans) Max. stat. pressure in Pa Permissible ambient temperature in °C Lifespan in h L1040 °C Lifespan in h L1055 °C 230 VAC 50 440/845 56.5/59.4 45/90 73 60 3/6 520/1000 60.2/62.9 42/84 88 115 VAC 50 60 3/6 440/845 520/1000 56.5/59.4 60.2/62.9 46.5/93 43.5/87 73 88 –40 ... +70 °C 43500 20000 24 VCDC 3/6 506/970 60.5/63.3 24/48 68 Note 쮿 Fan dimensioning see page 4.18 쮿 Replacement fans see chapter Climate control - Accessories 쮿 Versions with multiple fans see ServicePLUS configuration page 4.14 4.6 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays 19" fan 1 U with front switch 19" fan trays 쮿 Front-mounted illuminated mains switch on AC devices, coupled with additional rear mains outlet; mechanical strain relief for mains input and mains output cables 쮿 Can be adapted to subracks 쮿 Contact protection in accordance with DIN EN ISO 13857 Delivery comprises (ready to connect) 01194003 Item 1 Qty 1 2 3a 3/6 1 b3 1 Description 19" circulation fan, 1 U, top/base plate, St, 1 mm, finish AlZn, with perforation; front panel 1 U, AI, 3 mm, anodised Fan, see Order Information AC version with mains switch, illuminated green; plug (mains input IEC 60320) incl. safety clamp for mechanical strain relief; coupled mains output socket (IEC 60320) DC version with mains switch and connecting cable, cable length 2.5 m Order Information 01197002 24 VDC Part no. 115 VAC Part no. 230 VAC Part no. 10713-111 10713-110 10713-108 10713-115 10713-114 10713-112 20713-240 20713-244 20713-243 43,5 KTA44857 436 137 81 KTA44858 85 193 137 330 Replacement fan 1 piece 483 KTA45963 Side panel connecting bracket between europacPRO subrack and fan, including fixing material kit, PU 4 pieces Equipment cable SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, USA USA plug, IEC 60320 socket, 2 m, 1 piece Mains cable, IEC IEC 60320 C14 plug, IEC 60320 C13 socket, 2.5 m, 1 piece 21101-954 60103-131 60103-137 60103-141 60197-053 ServicePLUS see page 4.19 Technical data Voltage Frequency in Hz Number of fans Airflow volume in m3/h (3/6 fans) Noise level in dB(A) (3/6 fans) Power consumption in W (3/6 fans) Max. stat. pressure in Pa Permissible ambient temperature in °C Lifespan in h L1040 °C Lifespan in h L1055 °C 230 VAC 50 440/845 56.5/59.4 45/90 73 60 3/6 520/1000 60.2/62.9 42/84 88 115 VAC 50 60 3/6 440/845 520/1000 56.5/59.4 60.2/62.9 46.5/93 43.5/87 73 88 –40 ... +70 °C 43500 20000 24 VDC 3/6 506/970 60.5/63.3 24/48 68 쮿 Fan dimensioning, see page 4.18 쮿 Replacement fans, see chapter Climate control - Accessories 쮿 Versions with multiple fans see ServicePLUS configuration page 4.14 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.7 Climate control – 19" fan trays 19" fan 1 U, with speed control and function monitoring 19" fan trays 쮿 Low noise through temperature dependent airflow volume 쮿 Range selectable: 20 ... 40 °C and 30 ... 50 °C 쮿 External sensor, at sensor breakage max speed will be set automatically 쮿 Function control with LEDs and via potential-free contact 쮿 Contact protection in accordance with DIN EN ISO 13857 쮿 2 versions, 24 VDC or 230 VAC Delivery comprises (ready for connection) Qty 1 2 3 4 3/6 1 1 Description 19" circulation fan, 1 U; cover/base plate, St, 1 mm, finish Al-Zn, with perforation front panel 1 U, AI, 3 mm, anodised DC fan, see Order information Connecting cable, length 2.5 m, open-ended Temperature sensor for speed control, NTC resistor, cable length 1.5 m 01198001 43,5 Photo shows 19" fan unit with 3 fans, without switch Item 1 436 137 Order Information 81 D1 137 D2 D 24 VDC Without switch D 230 VAC With switch Without switch mm Part No. mm Part No. Part No. 193 10713-099 250 19713-121 – 330 10713-098 397 – 19713-006 85 D1 KTA44857 D2 483 KTA44858 01107050 Airflow capacity with one fan [m³/h] 200 180 160 140 120 100 80 60 40 20 0 0 Accessories Filter mat, class G 2 for 3 fans, PU 3 pieces Filter mat, class G 2 for 6 fans, PU 3 pieces 60713-169 60713-170 Technical data 10 20 30 40 50 60 [°C] 01112050 Monitoring signal Voltage AC version (fans 24 VDC) Voltage DC version Number of fans Max. airflow volume in m3/h Noise level in dB(A) Max. stat. pressure in Pa Power consumption in W Permissible ambient temperature °C Life in h L1040 °C 86 ... 260 VAC 24 VDC (21 ... 27) 3 6 467 895 63.5 66.4 70 70 15.9 31.8 W –20 ... +65 °C 70000 Technical data Regulation/monitoring Control range Sensor Sensor connector Signal at kta43400 n = rotating speed, S = signal, nA = speed threshold value "Alarm" Signalling Changeover switch between 20 ... 40 °C and 30 ... 50 °C External NTC resistor, cable length 1.5 m Rear-mounted plug contact, max. rotation speed in case of sensor breakage Speed < 30 % nominal speed; switch-on delay < 4 s, signal delay < 1 s (see monitoring signal) Display via LEDs; potential-free contact (changeover), switching capacity 5 W, max. switching voltage 170 V, open collector on request 쮿 Fan dimensioning see page 4.18 ServicePLUS see page 4.19 4.8 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays Pusher fan, 2 U, with tangential fan 19" fan trays 쮿 High airflow volume 쮿 Integrated filter mat 쮿 2 versions: - LE1: 19" bolt-on dimension, fan unit is wider than 19" - LE2: 19" reduced width, for easy assembly Delivery comprises (ready to connect) 01192009 Item 1 Qty 1 2 3 1 1 Description Blower unit 2 U, with grille, PA 6.6, UL 94 V-0, front grille 2 U, PPO, UL 94 V-0; filter mat, synthetic fibre, filter class G 2 Fan Terminal block Order Information Description A3532 LE1: Pusher fan 2 U, tangential blower LE2: Pusher fan 2 U, tangential blower Spare filter mat PU 10 pieces 115 VAC Part no. 230 VAC Part no. 60713-003 60713-001 60713-004 60713-002 20705-008 Dimensions Voltage Frequency in Hz Airflow volume in m3/h Noise level in dB(A) Max. stat. pressure in Pa Power consumption in W Permissible ambient temperature in °C Lifespan in h 115 VAC 230 VAC 50 60 50 60 320 330 320 330 59 62 59 62 65 70 65 70 30 40 37 46 –20 ... +65 °C 30000 Note 쮿 24 VDCon request 쮿 Fan dimensioning, see page 4.18 01103056 ServicePLUS see page 4.19 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.9 Climate control – 19" fan trays 19" pusher fan 2 U (depth 160 mm or 220 mm) 19" fan trays 쮿 Integrated air deflector prevents heat buildup in the assemblies mounted below 쮿 Optionally with rear additional fan, 2 U, for active cooling of assemblies beneath the pusher fan 쮿 Can be adapted to subracks 쮿 Contact protection in accordance with DIN EN ISO 13857 01194005 Delivery comprises (ready to connect) Item 1 Qty 1 2 3a 3 1 3b 1 3c 1 Description 19" pusher fan 2 U, case, St, 1 mm, finish AI-Zn; front grille 2 U, PPO, UL 94 V-0 Filter mat, synthetic fibre, filter class G 2 Fan AC-version with plug (mains input, IEC 60320), incl. safety clamp, mechanical strain relief for mains input cable; socket to connect an optional supplementary fan Wide AC input range with DC fans, version as 3 a, additionally speed-controlled and monitored DC version with connecting cable, cable length 2.5 m Note 쮿 Supplementary fan for AC version see page 4.11 쮿 Fan dimensioning, see page 4.18 01103054A3527V ServicePLUS see page 4.19 Order Information Description Front panel Al, anodised 86 ... 260 VAC (fan 24 VDC) 515 m3/h Part no. 24 VDC 515 m3/h Part no. Front panel, plastic, black 115 VAC 115 VAC 230 VAC 230 VAC 300/330 m 3/h 445/530 m3/h 300/330 m3/h 445/530 m 3/h Part no. Part no. Part no. Part no. For board depth 160 mm 19713-540 10713-537 10713-520 10713-536 For board depth 220 mm – 10713-529 – – Replacement fan piece 20713-240 20713-240 20713-147 20713-244 Equipment cable SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable USA USA plug, IEC 60320 socket, 2 m, 1 piece Side panel connecting bracket between europac subrack, including fixing material kit Side panel connecting bracket between europacPRO subrack and fan, including fixing material kit, PU 4 pieces Spare filter mat PU 3 pieces 10713-518 10713-534 – 20700-001 10713-526 20713-243 60103-131 60103-137 60103-141 21101-104 21101-954 60713-501 Technical data with 3 fans Voltage Frequency in MHz Airflow volume in m3/h Noise level in dB(A) Max. stat. pressure in Pa Power consumption in W Permissible ambient temperature in °C Life in h, 1) at 40 °C, 2) at 55 °C 4.10 24 VDC 515 59.8 68 24 –20 ... +70 °C 20000 2) SCHROFF PRODUCT CATALOG E 05/2016 24 VDC 115 VAC 230 VAC 515 59.8 68 24 –20 ... +70 °C 20000 2) 50 300 52.2 41 42 50 300 52.2 41 42 60 50 60 330 445 530 56.1 55.2 58.2 41 78 88 33 46.5 43.5 –40 ... +70 °C 50000 1) 200002) 60 50 60 330 445 530 56.1 55.2 58.5 41 78 88 33 45 42 –40 ... +70 °C 50000 1) 20000 2) ELECTRONICS PROTECTION Climate control – 19" fan trays Supplementary fans with housing for pusher fan 2 U 19" fan trays 쮿 Extra 2 U useable space: By using a built-on fan, components mounted below the 19" pusher fan can be cooled 쮿 No additional voltage supply necessary: connection is via 19" pusher fan, 2 U 쮿 Contact protection in accordance with DIN EN ISO 13857 Delivery comprises (ready to fit and connect) 01194006 Item 1 2 3 Qty 1 4 1 Description Housing with grille, St, 1 mm, finish AIZn Fan Cable with plug (electrical connection via socket on 19" blower fan); safety clamp (mechanical strain relief for mains input cable) Order Information Description Supplementary fans with housing for pusher fan 2 U 115 VAC Part no. 230 VAC Part no. 10713-532 10713-530 Technical data with 3 fans KTA44447 Voltage Frequency in MHz Airflow volume in m3/h Noise level in dB(A) Max. stat. pressure in Pa Permissible ambient temperature in °C Power consumption in W Life in h at 55 °C 115 VAC 50 60 130 155 51 54 44 62 -40 ... +70 30 24 20000 230 VAC 50 60 130 155 51 54 44 62 -40 ... +70 27 21 20000 Note 쮿 24 VDC version available on request 쮿 Fan dimensioning see page 4.18 01103055 ServicePLUS see page 4.19 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.11 Climate control – 19" fan trays 19" pusher fan 3 U 19" fan trays With cover plates, this pusher fan can be re-fitted to different cooling concepts 쮿 Ventilation directed accurately to the electronics 쮿 Air infeed from front, air exits at the top rear of cabinet (guided upwards by cover plates or via hoses to rear and upwards) 쮿 Contact protection in accordance with DIN EN ISO 13857 Delivery comprises (ready for connection) Item 1 Qty 1 2 3 1 1 01102017 Description Case, St, 1 mm, AIZn; perforated hinged front panel, Al, 2.5 mm; filter mat, synthetic fibre, filter class G 2 in accordance with DIN EN 779 Radial fan with mains fuse Plug (mains input, IEC 60320); safety clamp, mechanical strain relief for mains input cable Order Information Description 115 VAC Part no. 230 VAC Part no. 19" pusher fan 3 U 10713-547 Accessories Equipment cable SCHUKO/UTE SCHUKO/UTE plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, BS British Standard plug, IEC 60320 C13 socket, 2.5 m, 1 piece Equipment cable, USA USA plug, IEC 60320 socket, 2 m, 1 piece Side panel connecting bracket between europac subrack and fan, including fixing material kit, PU 4 pieces Side panel connecting bracket between europacPRO subrack and fan, including fixing material kit, PU 4 pieces Spare filter mat PU 3 pieces 10713-546 60103-131 60103-137 60103-141 21101-958 21101-954 60713-868 Technical data 01103052 ServicePLUS see page 4.19 Voltage Frequency in MHz Airflow volume in m3/h Noise level per fan in dB(A) Max. stat. pressure in Pa Power consumption in W Max. ambient temperatures in °C Life in h at 55 °C 115 VAC 50 60 510 570 62 64 320 410 55 65 -20 ... +50 20000 230 VAC 50 60 510 570 62 64 320 410 58 75 -20 ... +50 20000 Note 쮿 Wide input voltage range 90 V ... 260 VAC available on request 쮿 Temperature control and function monitoring (alarm via RS 232) on request 쮿 Air deflector plates for other cooling concepts see page 4.13 쮿 Fan dimensioning see page 4.18 4.12 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays Air deflector plate for 19" pusher fan 3 U 19" fan trays 쮿 For 19" pusher fan 3 U Order Information Item 7 8 9 10 Description Air deflector plate to front, St, 1 mm, finish AlZn Air outlet to rear: upper cover plate, without perforation, 1 mm, finish AlZn Air deflector plate with hose connection on upper rear, external diameter 80 mm, St, 1 mm, finish AlZn Air deflector plate with hose connection to rear, external diameter 80 mm, St, 1 mm, finish AlZn Qty/PU Part no. 1 20713-504 1 20713-505 1 20713-503 1 20713-502 01103053 ServicePLUS see page 4.19 Connecting cable with connector socket 19" fan trays 쮿 Connecting cable with connector for AC fans (25 mm and 38 mm height) and DC fans (38 mm height), cable length 1 m Delivery comprises Item 1 KTA43091 Qty 1 Description Cable, PVC (2 x 0.75 mm²), 1 m long, with 2 FASTON connectors 2.8 x 0.5 mm, DIN 46343 T1 Order Information Description Connecting cable with plug SCHROFF.PENTAIR.CO.UK Part no. 21101-246 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.13 Climate control – 19" fan trays ServicePLUS: Configuration with assembly 19" fan trays 쮿 You can plan and build up your product yourself using the order information table below 쮿 Dimensions of fan trays – Height 1 U – Width 19" – Depth 193, 300, 467, 604 mm for 3, 6, 9 or 12 fans 쮿 Create your 19" fan trays from individual parts (assembled within 10 working days) Example configuration Qty 1 1 1 6 01102012 Description Housing, 1 piece Front panel with switch, AC, 1 piece Filter mat, 1 piece Fan, AC, height 25 mm; mounted at position 1, 3, 5, 7, 9, 11 Order no. 20713-213 20713-231/05 60713-246/05 20700-001/05 Order Information Fan height a44537 Fan housing 1) AC (230 V) DC AC (230 V) DC cover/base plate, St, 1 mm, finish AlZn, with perforation 1 U, Al, 3 mm, anodised; includes cable harness 1 U, Al, 3 mm, anodised; connecting cable, 2.5 m; includes cable harness 1 U, Al, 3 mm, anodised; mains switch, illuminated green; includes cable harness 1 U, Al, 3 mm, anodised; mains switch, illuminated green; connecting cable, 2.5 m; includes cable harness can only be fitted where fan height is 25 mm mm Front panel without switch Front panel with switch Filter mat G 2 Fans 1 piece 1 piece 1 piece 1 piece 1 piece PU 3 pieces see page 25 20713-212 20713-220/ 05 20713-224/ 05 20713-228/ 05 20713-236/ 05 60713-243 4.16 38 20713-216 20713-220/ 05 20713-224/ 05 20713-228/ 05 20713-236/ 05 – 4.16 25 20713-213 20713-221/ 05 20713-225/ 05 20713-229/ 05 20713-237/ 05 60713-244 4.16 38 20713-217 20713-221/ 05 20713-225/ 05 20713-229/ 05 20713-237/ 05 – 4.16 25 20713-214 20713-222/ 05 20713-226/ 05 20713-230/ 05 20713-238/ 05 60713-245 4.16 38 20713-218 20713-222/ 05 20713-226/ 05 20713-230/ 05 20713-238/ 05 – 4.16 25 20713-215 20713-223/ 05 20713-227/ 05 20713-231/ 05 20713-239/ 05 60713-246 4.16 38 20713-219 20713-223/ 05 20713-227/ 05 20713-231/ 05 20713-239/ 05 – 4.16 KTA44857 KTA44858 kta44859 kta44860 1) Fan housing cannot be ordered without fans Note 쮿 Unused fan mounting positions are covered with foam material 쮿 Versions for 115 V or with switch available on request 쮿 Fan dimensioning see page 4.18 4.14 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays 1 U air deflector chassis for 19" fan trays 19" fan trays 쮿 Optimised cooling together with 19" fan trays 쮿 Vertical buildup of heat is avoided by means of improved airflow 쮿 Fitting options: – One fan tray: cool air is drawn in from the front and guided upwards – Two fan trays: cool air is drawn in from the front, directed upwards and guided to the rear (see application diagram) 쮿 Versions: – With solid front panel to direct airflow – With perforated front panel to allow air to flow in/out 쮿 Optional filter mat, simple to swap during operation 01109001 1 U air deflector chassis (bottom) with 1 U fan tray (top) 01109002 Delivery comprises (assembled) Item 1 Qty 1 2 2 3a 1 3b 1 4 1 Description Air deflector plate, St, 1 mm, finish Zincor, width 432.8 mm (without side panel) Side panel, St, 1.5 mm, finish Zincor; with 19" mounting bracket, powder-coated (see Order information for colour) Front panel, perforated, St, 1.5 mm, finish Zincor, powder-coated (see Order information for colour); two quick-release fasteners, black Front panel, solid, St, 1.5 mm, finish Zincor, powdercoated (see Order information for colour); two quick-release fasteners, black Assembly kit Order Information 1 U air deflector chassis Depth Colour for mm 19" fan trays Part no. Front panel, perforated Part no. Front panel, solid 193 RAL 7035 for single-row fan trays 193 RAL 9005 (3 fans) 193 RAL 9006 330 RAL 7035 for double-row fan 330 RAL 9005 trays (6 fans) 330 RAL 9006 Accessories Filter mat, class G 2 for 3 fans, PU 3 pieces Filter mat, class G 2 for 6 fans, PU 3 pieces 10713-140 10713-142 10713-146 10713-148 10713-144 10713-150 10713-141 10713-143 10713-147 10713-149 10713-145 10713-151 60713-169 60713-331 01109051 Application: air deflector chassis mounted below 19" fan tray, guides the cool air upwards from front; second air deflector chassis at top guides the warm air to the rear SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.15 Climate control – 19" fan trays AC fans/replacement fans 19" fan trays Delivery comprises Item 1 Qty 1 Description Fan (width 119 mm, depth 119 mm) Order Information Description Height Airflow volume mm m3/h Type A 25 84 Type B 25 108 Type C 38 162 Assembly kit for fan PU 1 kit 115 VAC Part no. 230 VAC Part no. 20713-146 20713-142 20713-147 20713-244 20700-001 20713-243 21102-013 Dimensions AC fans 01108005 Type Frequency in Hz Airflow volume in m3/h Noise level per fan in dB(A) Max. static pressure in Pa Max. ambient temperature in °C Power consumption in W Dimensions: height in mm (width 119 mm × depth 119 mm) Type A 50 60 84 90 29 30 23 21 70 70 8 7 25 Type B 50 60 108 120 34 38 41 41 70 70 14 11 25 Type C 50 60 162 192 37 41 73 88 70 70 15 14 38 쮿 Please order connecting cable separately, see page 4.13 쮿 Please order protective grille separately, see page 4.17 DC fans/replacement fans 19" fan trays Delivery comprises Item 1a 1b Qty 1 1 Description Fan, height 38 mm, with plug connection Fan, height 25.5 mm, connecting cable, length 55 mm, connector with 2 x FASTON connectors (2.8 x 0.8 mm) Order Information Height Airflow volume Power consumption mm m3/h W 25.5 171 5.3 38 184 8 38 184 8 38 184 8 Assembly kit for fan PU 1 kit Input voltage V 24 12 24 48 Part no. 20713-172 20713-241 20713-240 20713-242 21102-013 01108005 Technical data DC fans Voltage in VDC Dimensions: height in mm (width 119 mm × depth 119 mm) Airflow volume in m3/h Noise level per fan in dB(A) Max. stat. pressure in Pa Max. ambient temperature in °C Power consumption in W 24 25 12 38 24 38 48 38 171 41.5 50.5 70 7 184 42 68 70 8 184 42 68 70 8 184 42 68 70 8 쮿 Please order connecting cable for 38 mm high fans separately, see page 4.13 쮿 Please order protective grille separately, see page 4.17 4.16 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays Protective grille to snap-in 19" fan trays 쮿 Protective grille for direct mounting on AC and DC fans Delivery comprises Qty 1 Ø 50 105 119 Item 1 Description Fibre glass reinforced plastic (PA), black, in accordance with DIN 31001, UL 94 V-0 Order Information Description Protective grille, plastic, to snap-in 105 Part no. 60225-052 6,5 Ø9 119 min. 9 13,5 3,8 01108053 Protective grille, plastic, to screw-on 19" fan trays 쮿 Protective grille for AC and DC fans 쮿 Grille may be mounted on a front panel or the wall of the housing Item 1 Ø 50 127 113,5 Delivery comprises Qty 1 Description Fibre glass reinforced plastic (PA), black, in accordance with DIN 31001, UL 94 V-0 Order Information 113,5 Description Protective grille, plastic, to screw-on Assembly kit for plastic grille (4 screws, 4 washers, 4 nuts M4), PU 1 set 6,5 Ø8 21102-014 90° Ø 4,5 127 Part no. 60225-053 3,8 01108054 Protective grille, metal, to screw-on 19" fan trays 쮿 Protective grille for direct mounting on AC and DC fans 4,7 쮿 Optimised noise level and air resistance Item 1 104,7 115,0 Delivery comprises Qty 1 Description St, 1 mm Order Information 104,7 115,0 Description Protective grille, metal, to screw-on Assembly kit for metal grille (4 screws, 4 washers, 4 nuts M4), PU 1 set 1,8 5,5 Part no. 60197-019 21102-015 01109050 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.17 Climate control – 19" fan trays 19" fan trays 19" fan dimensioning V (m3/h) For local heat dissipation, the airflow volume required to expel the heat produced is calculated. Note The cabinet ventilation is not taken into account here. The required airflow volume is calculated as follows: V= (f x Pv)/ΔT Pv (W) The air constant f = 3.3 m3K/Wh. ΔT is the temperature difference between the ambient temperature of the sub-assembly and that of the air drawn in. Example of readings - Pv = 600 W - air sucked in: 25 °C - permissible ambient temperature of the sub-assembly = 30 °C A41771 1. ΔT = Ti – Tu = 30 °C – 25 °C = 5 K 2. From Pv = 600 W to the curve for ΔT =5 K 3. From the intersection point to the airflow volume V = 400 m3/h 4.18 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – 19" fan trays ServicePLUS assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 No additional charge modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data, send modifications to us 쮿 Ready for dispatch within 10 working days 쮿 Ready for dispatch within 15 working days 19" fan trays ServiceP LUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.19 Ai r filtered fanMain Catalogue Climate control – Air filtered fan Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 01105012 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Simple to fit without tools by clipping in (can also be bolted) 01108014 Easy tool-less change of filter mat 01108015 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 01108016 Connectors, front panel component system . . . . . . . 11 Fluted filter to increase degree of ingress protection from IP 54 to IP 55 01108013 Easy tool-less wiring with spring clamp connector Ai r filtered fan Appendix . . . . . 12 4.20 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Air filtered fan Overview . . . . . 4.20 Air filtered fanMain C atalogue Air filtered fans, ingress protection from IP 54 to IP 55 in accordance with IEC 60529 쮿 Simple to fit without tools by clipping in (can also be bolted) How to dimension air filtered fans . . 4.22 쮿 Easy conversion from pressure to suction operation Reading example . 4.22 쮿 Easy tool-less change of filter mat EMC solutions . . . 4.22 쮿 7 performance classes with 6 different assembly dimensions Air filtered fans 쮿 Airflow capacity of 25 m3/h ... 770 m3/h (FL 100 ... FL 600) 쮿 3 supply voltages (230 VAC, 115 VAC, 24 VDC) 쮿 Outlet/inlet filter 쮿 Fluted filter to increase degree of ingress protection from IP 54 to IP 55 Air filtered fans FL 100 . . . . . . . . . . 4.23 FL 200 . . . . . . . . . . 4.24 FL 225 . . . . . . . . . . 4.25 FL 250 . . . . . . . . . . 4.26 FL 300 . . . . . . . . . . 4.27 FL 500 . . . . . . . . . . 4.28 FL 600 . . . . . . . . . . 4.29 쮿 Side by side mounting of several air filtered fans is possible Air filtered fans Outlet/inlet filters Fluted filters 01108017 01108026 01108016 ServicePLUS e.g. special colours e.g. other cabinet dimensions e.g. EMC solutions e.g. custom solutions www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 4.21 Climate control – Air filtered fans Air filtered fan calculations To establish the size of the air-filtered fan required, calculate the air throughput necessary to dissipate the amount of heat contained in the cabinet. The necessary airflow volume (at sea level) is calculated thus: V = f x (PV - PS ) / ∆T with V = airflow volume f = air constant = 3.3 m³ K/Wh PV = thermal power loss (sum of heat emitted by the equipment in the cabinet) PS = radiant power (heat that is radiated from the cabinet without additional ventilation) ∆T = temperature difference between the air drawn in (ambient temperature Tu) and the exhaust air (internal cabinet temperature Ti), ∆T = Ti -Tu 01108017 Reading example The devices in the cabinet produce e.g. a power loss of 840 W. Of these 840 W, the cabinet releases 340 W to the environment via its surfaces. The air sucked in from outside the cabinet has a temperature of 20 °C. A maximum temperature of 40 °C is to be permitted in the cabinet. So which air filtered fan should be employed? 1. PV = 840 W, PS = 340 W, read-off point PV - PS = 500 W 2. ∆T = Ti - Ta = 40 °C - 20 °C = 20 °C = 20 K 3. On the characteristic for 20 K we obtain, at PV - PS = 500 W, a minimum necessary airflow volume of V = 80 m³/h. 4. An FL 250 air filtered fan should be used that gives an airflow volume of 131 m³/h or, if used in combination with the FLA 250 exhaust filter, of 95 m³/h. FL 100 + FLA 100 FL 100 FL 200 + FLA 200 FL 200 FL 225 + FLA 225 FL 225 FL 250 + FLA 250 FL 250 FL 300 + FLA 300 FL 300 FL 500 + FLA 500 FL 500 FL 600 + FLA 600 FL 600 kta45245 EMC solutions 4 Air filtered fansMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 EMC shielding in accordance with your requirements 쮿 Customised developments Delivery comprises 3 Item 1 2 3 4 2 1 Description Protective fan grille Fan EMC hood FLA outlet/inlet filter 01108070 4.22 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Air filtered fans Air filtered fan FL 100 쮿 Airflow volume 25 m3/h Air filtered fansPart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, NEMA type 12 쮿 Simple to fit without tools by clipping in Delivery comprises (completely assembled) 01108018 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G 3 (EN 779) Fan 2 wire connection, length 310 mm Order Information Description 24 VDC Part no. 115 VAC Part no. Air filtered fan FL 100 60715-142 60715-141 Air outlet/inlet filter FLA 100 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 100 and FLA 100, filter class G 3 (EN 779), PU 5 pieces 230 VAC Part no. 60715-140 60715-156 60715-182 Technical data 01108019 Air outlet/inlet filter FLA 100 Voltage Frequency Airflow volume with filter (free blowing) Combination FL + FLA Max. static pressure Noise level (in accordance with EN ISO 3741, 50 Hz) Operating temperatures Power consumption Filter efficiency MTBF at 40 °C Approvals 230 VAC 50/60 Hz 25/29 m3/h 115 VAC 50/60 Hz 25/29 m3/h 24 VDC DC 25 m3/h 16/18 m3/h 38 Pa 33 dB(A) 16/18 m3/h 38 Pa 33 dB(A) 16 m3/h 38 Pa 33 dB(A) –15 ... +55 °C –15 ... +55 °C 12/11 W 11/11 W 88 % 88 % 40000 h 40000 h CE, UL, cUL, GOST –15 ... +55 °C 2.4 W 88 % 80000 h Note 01108020 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 109 109 92 92 Replacement filter IP 54 92 92 109 109 62 4 4 01108057 19 01108058 Air filtered fan FL 100 Air outlet/inlet filter FLA 100 Sheet thicknesses 1 ... 2 mm - cut-out 92 x 92 mm; Sheet thicknesses >2 ... 3 mm - cut-out 93 x 93 mm SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.23 Climate control – Air filtered fans Air filtered fan FL 200 쮿 Airflow volume 61 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 쮿 Simple to fit without tools by clipping in (can also be bolted) Delivery comprises (Completely assembled) 01108018 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G3 (EN 779) Fan Connection AC (terminal strip), connection DC (2 wires, 310 mm long) Order Information Description Air outlet/inlet filter FLA 200 Fluted filter IP 55 01108019 01108021 01108020 125 125 115 VAC Part no. Air filtered fan FL 200 60715-145 60715-144 Air outlet/inlet filter FLA 200 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 200 and FLA 200, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 200 and FLA 200, filter class G 4 (EN 779), PU 5 pieces 230 VAC Part no. 60715-143 60715-157 60715-183 60715-187 Technical data Replacement filter IP 54 Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 61/70 m3/h 115 VAC 50/60 Hz 61/70 m 3/h 24 VDC DC 61 m 3/h 56/64 m3/h 56/64 m3/h 56 m 3/h 44/52 m3/h 40/46 m3/h 60 Pa 57 Pa 44 dB(A) 44/52 m 3/h 40/46 m3/h 60 Pa 57 Pa 44 dB(A) 44 m 3/h 40 m 3/h 60 Pa 61 Pa 44 dB(A) 15 ... +55 °C -5 ... +55 °C 19/18 W 20/20 W 83 % 83 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST -25 ... +55 °C 5W 83 % 91 % 80000 h Note 145 145 24 VDC Part no. 125 125 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 145 145 70 5 5 26 01108059 01108060 Air filtered fan FL 200 Air outlet/inlet filter FLA 200 Sheet thicknesses 1 ... 2 mm - cut-out 125 x 125 mm; Sheet thicknesses >2 ... 3 mm - cut-out 126 x 126 mm 4.24 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Air filtered fans Air filtered fan FL 225 쮿 Airflow volume 110 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 Delivery comprises (completely assembled) Item 1 Qty 1 2 3 4 1 1 1 01108022 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G 3 (EN 779) Fan Connection AC (terminal block), DC (spring terminal strip) Order Information Description 115 VAC Part no. 230 VAC Part no. Air filtered fan FL 225 60715-147 Air outlet/inlet filter FLA 225 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 225 and FLA 225, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 225 and FLA 225, filter class G 4 (EN 779), PU 5 pieces Air outlet/inlet filter FLA 225 Replacement filter IP 54 Fluted filter IP 55 01108019 01108021 01108020 60715-146 60715-158 60715-184 60715-188 Technical data Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level (in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 110/125 m3/h 115 VAC 50/60 Hz 110/125 m 3/h 100/110 m3/h 100/110 m 3/h 82/93 m3/h 55/64 m3/h 66 Pa 61 Pa 40 dB(A) 83/92 m 3/h 55/64 m 3/h 66 Pa 61 Pa 40 dB(A) –15 ... +55 °C –15 ... +55 °C 19/18 W 20/20 W 88 % 88 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST Note 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 01108061 01108062 Air filtered fan FL 225 Air outlet/inlet filter FLA 225 Sheet thicknesses 1 ... 2 mm - cut-out 177 x 177 mm; Sheet thicknesses >2 ... 3 mm - cut-out 178 x 178 mm SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.25 Climate control – Air filtered fans Air filtered fan FL 250 쮿 Airflow volume 156 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 쮿 Simple to fit without tools by clipping in (can also be bolted) Delivery comprises (completely assembled) 01108022 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G 3 (EN 779) Fan Connection spring terminal strip Order Information Description 115 VAC Part no. Air filtered fan FL 250 60715-149 Air outlet/inlet filter FLA 250/300 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 250/300 and FLA 250/300, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 250/300 and FLA 250/300, filter class G 4 (EN 779), PU 5 pieces Air outlet/inlet filter FLA 250/300 Fluted filter IP 55 01108019 01108021 01108020 223 223 Replacement filter IP 54 60715-148 60715-159 60715-185 60715-189 Technical data Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level (in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 156/171 m3/h 115 VAC 50/60 Hz 151/170 m3/h 145/160 m3/h 140/160 m3/h 116/127 m3/h 109/113 m3/h 52 Pa 49 Pa 40 dB(A) 116/127 m3/h 109/113 m3/h 52 Pa 49 Pa 40 dB(A) –15 ... +55 °C –15 ... +55 °C 18/17 W 18/17 W 88 % 88 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST Note 252 252 230 VAC Part no. 223 223 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 252 252 6 97 6 38 01108063 01108064 Air filtered fan FL 250 Air outlet/inlet filter FLA 250/300 Sheet thicknesses 1 ... 2 mm - cut-out 223 x 223 mm; Sheet thicknesses >2 ... 3 mm - cut-out 224 x 224 mm 4.26 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Air filtered fans Air filtered fan FL 300 쮿 Airflow volume 256 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 쮿 Simple to fit without tools by clipping in (can also be bolted) Delivery comprises (completely assembled) 01108024 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G 3 (EN 779) Fan Connection spring terminal strip Order Information Description 115 VAC Part no. Air filtered fan FL 300 60715-151 Air outlet/inlet filter FLA 250/300 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 250/300 and FLA 250/300, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 250/300 and FLA 250/300, filter class G 4 (EN 779), PU 5 pieces Air outlet/inlet filter FLA 250/300 Fluted filter IP 55 01108019 01108021 01108020 223 223 Replacement filter IP 54 60715-150 60715-159 60715-185 60715-189 Technical data Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level (in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 256/292 m3/h 115 VAC 50/60 Hz 256/292 m3/h 233/265 m3/h 233/265 m3/h 231/265 m3/h 180/207 m3/h 116 Pa 112 Pa 42 dB(A) 231/265 m3/h 180/207 m3/h 116 Pa 112 Pa 42 dB(A) –15 ... +55 °C –15 ... +55 °C 45/39 W 40/40 W 88 % 88 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST Note 252 252 230 VAC Part no. 223 223 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 252 252 6 113 6 38 01108065 01108064 Air filtered fan FL 300 Air outlet/inlet filter FLA 250/350 Sheet thicknesses 1 ... 2 mm - cut-out 223 x 223 mm; Sheet thicknesses >2 ... 3 mm - cut-out 224 x 224 mm SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.27 Climate control – Air filtered fans Air filtered fan FL 500 쮿 Airflow volume 480 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 쮿 Simple to fit without tools by clipping in (can also be bolted) Delivery comprises (completely assembled) 01108025 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing UL 94 V-0 Filter, filter class G3 (EN 779) Fan Connection spring terminal strip Order Information Description 230 VAC Part no. 115 VAC Part no. Air filtered fan FL 500 60715-153 Air outlet/inlet filter FLA 500/600 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 500/600 and FLA 500/600, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 500/600 and FLA 500/600, filter class G 4 (EN 779), PU 5 pieces Air outlet/inlet filter FLA 500/600 Fluted filter IP 55 01108019 01108021 01108020 291 291 Replacement filter IP 54 60715-152 60715-160 60715-186 60715-190 Technical data Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level (in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 505/505 m3/h 115 VAC 50/60 Hz 505/505 m3/h 480/480 m3/h 480/480 m3/h 380/380 m3/h 370/370 m3/h 76 Pa 74 Pa 54 dB(A) 380/380 m3/h 370/370 m3/h 76 Pa 74 Pa 54 dB(A) –15 ... +55 °C –15 ... +55 °C 65/80 W 75/90 W 88 % 88 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST 320 320 Note 291 291 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 320 320 ,5 150 6,5 6,5 5 39, 01108067 01108068 Air filtered fan FL 500/600 Air outlet/inlet filter FLA 500/600 Sheet thicknesses 1 ... 2 mm - cut-out 223 x 223 mm; Sheet thicknesses >2 ... 3 mm - cut-out 224 x 224 mm 4.28 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Air filtered fans Air filtered fan FL 600 쮿 Airflow volume 640 m3/h Air filtered fans 쮿 Converts simply from push to pull operation 쮿 Ingress protection IP 54, with fluted filter IP 55, NEMA type 12 쮿 Simple to fit without tools by clipping in (can also be bolted) Delivery comprises (completely assembled) 01108025 Item 1 Qty 1 2 3 4 1 1 1 Description Front grille and case, plastic, ABS, RAL 7035, self-extinguishing, UL 94 V-0 Filter, filter class G 3 (EN 779) Fan Connection spring terminal strip Order Information Description 230 VAC Part no. 115 VAC Part no. Air filtered fan FL 600 60715-155 Air outlet/inlet filter FLA 500/600 (items 1 + 2 included), 1 piece Replacement filter IP 54 for FL 500/600 and FLA 500/600, filter class G 3 (EN 779), PU 5 pieces Fluted filter IP 55 for FL 500/600 and FLA 500/600, filter class G 4 (EN 779), PU 5 pieces Air outlet/inlet filter FLA 500/600 Fluted filter IP 55 01108019 01108021 01108020 291 291 Replacement filter IP 54 60715-154 60715-160 60715-186 60715-190 Technical data Voltage Frequency Airflow volume with IP 54 filter (free blowing) Airflow volume with IP 55 filter (free blowing) Combination FL + FLA IP 54 Combination FL + FLA IP 55 Max. static pressure IP 54 Max. static pressure IP 55 Noise level in accordance with EN ISO 3741, 50 Hz) Max. ambient temperature Power consumption Filter efficiency IP 54 Filter efficiency IP 55 MTBF at 40 °C Approvals 230 VAC 50/60 Hz 770/785 m3/h 115 VAC 50/60 Hz 770/785 m 3/h 640/653 m3/h 640/653 m 3/h 490/501 m3/h 445/445 m3/h 134 Pa 132 Pa 63 dB(A) 490/501 m 3/h 445/445 m 3/h 134 Pa 132 Pa 63 dB(A) –15 ... +55 °C –15 ... +55 °C 115/150 W 110/160 W 88 % 88 % 91 % 91 % 40000 h 40000 h CE, UL, cUL, GOST Note 320 320 쮿 Mounting for sheet thicknesses from 1 to 3 mm 쮿 Multiple fan solution on request 쮿 Dimensions, cut-outs and tolerances see user manual 291 291 320 320 ,5 150 6,5 6,5 5 39, 01108067 01108068 Air filtered fan FL 500/600 Air outlet/inlet filter FLA 500/600 Sheet thicknesses 1 ... 2 mm - cut-out 223 x 223 mm; Sheet thicknesses >2 ... 3 mm - cut-out 224 x 224 mm SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.29 Climate control – Accessories Heaters from 10 W to 150 W AccessoriesMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Compact heater without fan 쮿 Simple and fast assembly with clip-on attachment 쮿 Broad range voltage input AC/DC 120 ... 240 V 쮿 Low surface temperature, protective insulation, and temperature limitation with PTC resistance Delivery includes (completely assembled) 10 / 20 W 01116002 50 / 100 / 150 W 01116001 Dimension drawing Item 1 Qty 1 2 1 3 1 Description Heater element, voltage AC/DC 100 ... 240 V; PTC resistor, self-regulating Heating body housing, plastic UL94 V-0; type of fixing: Clip for 35 mm DIN rail EN 60715 Connection: 2-pin (10 W, 20 W) and/or 4-pin (50 W, 100 W, 150 W) terminal, 2.5 mm², torque 0.8 Nm max. Order Information Description 10 W 20 W 50 W 100 W 150 W Part no. 60715-220 60715-221 60715-222 60715-223 60715-224 Note 10 / 20 W 01116054 50 / 100 / 150 W 01116053 쮿 Thermostat for heating see page 4.65 쮿 Hygrostat see page 4.68 Technical data Heater output in W Max. switch-on current in A Pre-fuse, delay-action in A Type of protection Class of protection Dimensions H × W × D in mm Weight in kg Connection Surface temperature in °C Test seal Mounting 4.58 10 W 20 W 50 W 100 W 10 20 50 100 1.0 2.5 2.5 4.5 2.0 4.0 4.0 8.0 IP 20 IP 20 IP 20 IP 20 II II II II 98 × 38 × 75 98 × 38 × 75 110 × 60 × 90 110 × 60 × 90 0.2 0.3 0.3 0.3 2-pin terminal, 2.5 mm², torque 0.8 Nm 4-pin terminal, 2.5 mm², torque 0.8 Nm < + 80°C, with exception of above mesh surface CE, UL, VDE, EAC, RoHS Clip-on attachment for 35 mm DIN rail (EN 60715) SCHROFF PRODUCT CATALOG E 05/2016 150 W 150 8.0 10.0 IP 20 II 150 × 60 × 90 0.5 ELECTRONICS PROTECTION Climate control – Accessories Heaters with heater fans from 150 W to 400 W Access ori esMAIN CATA LO GPart number in bold face type: ready for shipping wi thin 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Compact heater with fan, small, compact design with high heater output 쮿 Simple and fast assembly with clip-on attachment or bolt fixing 쮿 Dynamic heating up and temperature limitation by PTC technology 쮿 Quiet Delivery includes (completely assembled) Item 1 Qty 1 2 1 3 4 1 1 01116004 Dimension drawing Clip attachment Description Heater element, voltage 230 VAC, resistor (PTC resistance) self-regulating Heating body housing, plastic UL94 V-0; type of fixing: Clip for 35 mm DIN rail EN 60715 Axial fan, airflow from bottom to top Connection: 2-pin terminal, 2.5 mm², torque 0.8 Nm max. Order Information Description 150 W 250 W 400 W Part no. 60715-225 60715-226 60715-227 Note 쮿 Thermostat for heating see page 4.65 쮿 Hygrostat see page 4.68 01116050 01116051 Technical data Heater output in W Max. switch-on current in A Pre-fuse, delay-action in A Axial fan, free blowing output Type of protection Class of protection Dimensions H × W × D in mm Weight in kg Surface temperature in °C 150 W 250 W 150 250 9.0 12 10 10 13.8 m²/h 45 m²/h IP 20 IP 20 II II 75 × 65× 90 90 × 85 × 111 0.3 0.5 < + 50°C, with exception of above mesh surface Connection Test seal Mounting 2-pin terminal, 2.5 mm², torque 0.8 Nm max. CE, UL, VDE, EAC, RoHS Clip-on attachment for 35 mm DIN rail (EN 60715) SCHROFF.PENTAIR.CO.UK 400 W 400 15 16 45 m²/h IP 20 II 90 × 85 × 111 0.5 < + 65°C, with exception of above mesh surface Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 4.59 Climate control – Accessories Heaters from 30 W to 150 W AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 Radiator heater (without fan) 쮿 Simple and fast assembly with clip-on attachment and presson terminal connection 쮿 Wide input voltage range 110 ... 250 VAC 쮿 Temperature limiting with PTC resistor Delivery comprises (completely assembled) Item 1 Qty 1 2 1 3 1 01102004 Description Heater element, voltage range 110 ... 250 VAC; resistor (PTC) self-regulating Heating body, Al extrusion, anodised Fixing: clip for 35 mm DIN rail EN 50022 Connection: type 30, with connecting cable (3 x 0.5 mm2, 300 mm long, black); type 45, 100, 150 with press-on terminal connection (for stranded/rigid wire 3 x 0.5 ... 2.5 mm2) D 47 W H 20 39 01113050 Support rail 00508013 Order Information 30 Description Part no. Heaters from 30 W to 150 W 60715-020 Support rail DIN rail EN 50022 (35 mm), length 215 mm, 1 piece 45 Part no. 100 Part no. 150 Part no. 60715-021 60715-023 60715-030 20715-001 Technical data Heater output in W Surface temperature in °C Max. switch-on current in A Type of protection Class of protection Dimensions H × W × D in mm Weight in kg Test seal Assembly 30 W 45 W 30 45 approx. 100 approx. 105 3,0 3,5 IP 54 IP 20 I I 70 × 25 × 50 69 × 70 × 50 0.2 0.3 VDE, CE, UL (File E150057) CE, UL (File E150057) Clip-on attachment for 35 mm DIN rail (EN 50022) 100 W 100 approx. 130 4.0 IP 20 I 144 × 70 × 50 0.5 CE, UL (File E150057) 150 W 150 approx.140 9,0 IP 20 I 224 × 70 × 50 0.7 CE, UL (File E150057) Note 쮿 Thermostat for heating see page 4.65 쮿 Hygrostat see page 4.68 4.60 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Accessories Heater fans 475/550 W Access ori es 쮿 Heater with fan and thermostat 쮿 Simple and fast assembly with clip-on attachment 쮿 3-pin terminal clamp, separate heater/fan connection 쮿 Thermostat from 0 ... 60 °C 쮿 Temperature limiting with PTC resistor Delivery comprises (completely assembled) 01108030 Item 1 Qty 1 2 3 4 1 1 1 Description Plastic housing, polycarbonate (RAL 9002, grey white), clip for 35 mm DIN rail EN 50022 Heater element, 230 VAC, resistor (PTC) self-regulating Thermostat 230 VAC fan Description Heater 475 W Heater 550 W Support rail DIN rail EN 50022 (35 mm), length 215 mm, 1 piece 165 160 Order Information Part no. 60715-017 60715-018 20715-001 Technical data Voltage range Frequency Heater output Air capacity of axial fan Current at switch-on approx. Weight Heater element Connection 128 124 100 01108069 Thermostat Control lamp of control system Temperature control Type of protection Class of protection Assembly Dimensions Support rail SCHROFF.PENTAIR.CO.UK 230 VAC 50 Hz 60 Hz 50 Hz 60 Hz 475 W 550 W 550 W 650 W 35 m3/h 39 m 3/h 45 m3/h 50 m3/h 11 A 13 A 0.9 kg 1.1 kg Resistor (PTC), self-regulating 3-pin connecting terminal, 2.5 mm2, separate connection heating/fan Adjustment range 0 ... 60 °C Glow lamp In the event of fan failure IP 20 II Clip-on attachment for 35 mm DIN rail (EN 50022) Height 165 mm, width 100 mm, depth 128 mm 00508013 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.61 Climate control – Accessories Heater fan 400 W, modular Accessories 쮿 Modular system consisting of: heater element, fan, protective grille and connecting cable 쮿 Fan not included in delivery extent; please order fan with desired air capacity separately 쮿 Simple and fast assembly with clip-on attachment 쮿 Overheating protection through thermal switch Delivery comprises (completely assembled) Example of a complete heater unit: 1: heater, 2: fan, 3: protective grille, 4: connection cable 01108007 Item 1 2 3 4 Qty 1 1 1 1 Description Heater element, high-performance cartridge Connecting cable fan - heating distributor, length 0.3 m GND/earth cable, ring tag - open end, length 0.3 m Clip-on attachment for DIN rail with assembly kit Order Information Description 115 VAC Part no. Heater fan 400 W, modular 60715-028 Support rail DIN rail EN 50022 (35 mm), length 215 mm, 1 piece 230 VAC Part no. 60715-029 20715-001 Technical data Heater element 01108006 Voltage range Current at switch-on Heater output Air capacity m 3/h Surface temperature with fan Type of protection Class of protection Dimensions: height x width x depth in mm Assembly 115 VAC 230 VAC 3.5 A 1.8 A 400 W Please choose desired fan Approx. 140 °C IP 20 I, with GND/earthing 22 x 120 x 160 Clip for 35 mm DIN rail EN 50022 Note 쮿 쮿 쮿 쮿 Support rail 4.62 SCHROFF PRODUCT CATALOG E 05/2016 Attention: Danger of overheating, never use heater without fan Fan see page 4.63 Thermostat for heating see page 4.65 Hygrostat see page 4.68 00508013 ELECTRONICS PROTECTION Climate control – Accessories AC fans for heating 400 W Access ori es 쮿 The fan is screwed below the heater and the cable is connected to the heater (please order connecting cable and protective grille separately) Delivery comprises Item 1 Qty 1 Description Fan (width 119 mm, depth 119 mm) Order Information 01108005 Connecting cable Height Airflow volume 115 V AC mm m3/h Part no. Type A 25 84 20713-146 Type B 25 108 20713-147 Type C 38 162 20713-244 PVC (2 x 0.75 mm²), 1 m long with 2 Faston connectors 2.8 x 0.5 mm to DIN 46343 T1, 1 piece Protective grille, metal, to screw-on 230 VAC Part no. 20713-142 20700-001 20713-243 21101-246 60197-019 Dimensions AC fans KTA43091 4,7 Type Frequency in Hz Airflow volume in m3/h Noise level per fan in dB(A) Max. static pressure in Pa Max. ambient temperature in °C Power consumption in W Dimensions: height in mm (width 119 mm × depth 119 mm) Type A 50 60 84 90 29 30 23 21 70 70 8 7 25 Type B 50 60 108 120 34 38 41 41 70 70 14 11 25 Type C 50 60 162 192 37 41 73 88 70 70 15 14 38 쮿 Please order connection cable and protective grille separately 104,7 115,0 Note 104,7 115,0 Protective grille SCHROFF.PENTAIR.CO.UK 1,8 5,5 01108055 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.63 Climate control – Accessories Speed control for fans with C13 plug Accessories 쮿 Suitable for all AC fans and fan units (up to 300 W) with IEC 60320 C13 plug (plug & play) 쮿 Simple to mount on the support rail provided 쮿 Simple adjustment of switch-on temperature (with knob and digital display) 쮿 External sensor can be fitted at a desired measurement point 01111001 쮿 Open-collector output (parametrisable) – Alarm output (active/passive) – DC fans (PWM output) – Remote display (via optional digital display with front panel) Delivery comprises Speed controller with connecting cables 01111002 Item 1 Qty 1 2 3 4 5 6 1 1 1 1 1 Description Speed controller; input/output voltages 115 ... 240 V AC, see Technical Data Temperature sensor, cable length 1.5 m Fan cable, 2 m, with IEC 60320 socket Mains cable, 3 m, with connecting plug Support rail, St, zinc-plated (EN 50022) Assembly kit Order Information Speed control for fans with C13 plug Part no. Mains cable SCHUKO/UTE plug 60715-005 Mains cable IEC 60320 C13 plug 60715-006 Accessories Thermostat with digital display 230 VAC , 1 piece Page 4.67 Thermostat with digital display 115 VAC , 1 piece Page 4.67 Connecting cable for DC fans or alarm output Length 2 m, 60715-007 2-wire (0.34 mm2), 1 piece 01105055 Block diagram 01111050 Speed varies in relation to temperature Technical data Voltage range Frequency Power consumption Display Max. connection power Max. continuous current Adjustment range Fan speed frequency Sensor Sensor connection In case of sensor failure Fan connection Open-collector output Mains connection Mechanics Dimensions Environmental conditions 115 ... 240 VAC (90 ... 264 VAC) 48 ... 62 Hz max. 4 VA LCD display, height 13 mm, red 300 W (230 VAC), 150 W (115 VAC) 1.3 A +20 ... +60 °C with potentiometer 25 ... 100 % External NTC resistor AMP plug contact and cable, 1.5 m, 2 x 0.22 mm Max. speed Cable 2 m with C13 IEC 60320 socket AMP plug contact, programmable function, Vmax. 30 VDC, Imax. 30 mA Cable 3 m with plug Case, IP 30, plastic, weight 0.5 kg, mounts on horizontal rail with lip DIN EN 50022 Width 120 mm, height 70 mm, depth 25 mm 0 ... 60°C, max. 85 % rel. humidity, non-condensing Note 쮿 Thermostat with digital display, see page 4.67 01111051 4.64 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Accessories Thermostat with integrated temperature sensor Access ori es 쮿 To control fans or heaters 쮿 Adjustment range 5 ... 60 °C 쮿 Individual adaptation with three separate components: thermostat (for cooling or heating), assembly material, connecting cable (IEC connector or ferrules) 쮿 2 versions – for heating – for cooling Delivery comprises 01108004 3 2 20 Description 40 0 60 50 °C 1 4 01108050 01108009 Adjustment range Switching temperature difference Sensing element Contact resistance Lifespan Max. switch performance Connection Case Dimensions Assembly Weight Operating/storage temperature Protection class Connection cable: 2-pin, ferrules - 3-pin, ferrules SCHROFF.PENTAIR.CO.UK Part no. for heating 60715-137 21120-178 62150-201 62150-264 Dimensions Thermostat Connection cable: 2-pin, ferrules - IEC socket Part no. for cooling Thermostat with integrated temperature 60715-136 sensor Accessories Item 3 DIN rail (EN 50022) 35 mm; length 75 mm; with fixing materials kit, PU 1 set Item 4 Connection cable, SCHUKO/UTE connector, cable length 1.5 m; connection on thermostat/hygrostat, 2-pin, ferrules; connection on fan IEC socket; 1 piece Item 4 Connection cable, SCHUKO/UTE connector, cable length 1.5 m; connection on thermostat/hygrostat, 2-pin, ferrules; connection on fan/heater, 3-pin, ferrules, 1 piece 30 10 1 Description Thermostat, width 33 mm, height 60 mm, depth 43 mm; clip-on attachment for 35 mm DIN rail EN 50022, switched voltage 120 ... 250 VAC User manual Order Information 33 43 60 Item Qty 1 1 for cooling (make contact), blue control button 0 ... 60 °C 7 K (± 4 K tolerance) for heating (break contact), red control button Thermobimetal (snap-action contact) 100000 cycles 10 A at 250 VAC, 15 A at 120 VAC; 30 W at DC voltage 2-pin clamp, up to 2.5 mm 2, torque max. 0.5 Nm Plastic, in accordance with UL 94 V-0, light grey Height 60 mm, width 33 mm, depth 43 mm Clip for 35 mm DIN rail, EN 50022 40 g -20 ... +80 °C/-45 ... +80 °C IP 20 01108010 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.65 Climate control – Accessories Thermostat with integrated temperature sensor AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 To control heaters or fans 쮿 Adjustment range 5 ... 60 °C Delivery comprises Item Qty 1 1 2 3 4 5 1 1 1 1 Description Thermostat with clip-on attachment for 35 mm DIN rail EN 50022, voltage 200 ... 250 VAC and 100 ... 130 VAC Support rail, length 200 mm Connection cable, length 1.5 m Strain relief Assembly kit for cabinet assembly Order Information Description Thermostat with integrated temperature sensor 01102008 Part no. 20715-002 Technical data Dimensions Adjustment range Switch difference Supply voltage Contact load (ohmic load/inductive load) Contacts Type of assembly Height: 75 mm, width: 75 mm, depth: 25 mm 5 ... 60 °C 0,5 K 200 ... 250 VAC Heat (terminals 1 - 2) 10 A / 4 A Cool (terminals 1 - 3) 5 A / 2 A Changeover contact, single pole Bolt-on, snap mounting for slide rail Thermostat with external temperature sensor Accessories 쮿 To control heaters or fans 쮿 External sensor can be positioned near the critical sub-assembly 쮿 Adjustment range 20 ... 60 °C, switch difference 3 ... 10 K Delivery comprises Item Qty 1 1 2 3 01102007 1 1 Description Thermostat with external temperature sensor, sensor length approx. 1.7 m Mounting plate for cabinet assembly, Al, 2.5 mm Assembly kit Order Information Description Thermostat with external temperature sensor Part no. 20715-003 Technical data Dimension (height x width x depth) Adjustment range Switching difference Mains/line voltage Contact load (ohmic load/inductive load) Contacts Assembly 4.66 SCHROFF PRODUCT CATALOG E 05/2016 93 mm x 68 mm x 44 mm 20 ... 60 °C 3 ... 10 K 90 ... 260 VAC 24 A/10 A Change-over, single pin Screw-fixed ELECTRONICS PROTECTION Climate control – Accessories Thermostat with digital display Access ori es 쮿 Adjustment range from -50 to +100 °C (switch difference 0 ... 10 °C) 쮿 Display switchable from °C to °F 쮿 Programmable (secured against unauthorised operation) 쮿 3-character red segment display Order Information 01197001 Front panel 1 U Description Thermostat with digital display, 230 VAC Thermostat with digital display, 115 VAC Front panel 1 U, RAL 7035 with cut-out for thermostat Front panel 1 U, anodised with cut-out for thermostat Front panel 1 U, RAL 7021 with cut-out for thermostat Part no. 60715-132 60715-133 30118-315 30118-267 30118-360 Technical data Operating voltage Power consumption Dimensions SZA45550 SCHROFF.PENTAIR.CO.UK 115 VAC or 230 VAC Approx. 3.5 W Height: 35 mm, width: 76 mm, depth: 59 mm Assembly cut-out 28.8 × 70.5 mm Adjustment range –50 ... +100 °C Switch difference 0 ... 10 K selectable Data safeguarding at power failure Non-volatile memory Contact load 8 A/3 A (ohmic/inductive load) (ohmic load/inductive load) Input/sensor PTC resistance, -55 ... +120 °C, cable length 3 m Contacts Relay, changeover contact, single pin Protection class to front IP 54 Connection Screw-on terminals, 2.5 mm2 Fixing With clamping bracket Type of assembly Can be screwed on Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.67 Climate control – Accessories Hygrostat AccessoriesMAIN C ATALO GPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 Adjustable or fixed relative air humidity 쮿 Switches fan or heaters when the set value is reached 쮿 Visual display 쮿 Integrated LED lights up when the connected consumer is switched on 쮿 Individual adaptation with three separate components: Hygrostat, assembly material, connecting cable (input with SCHUKO/UTE connector; output with IEC connector or open end) please order separately 01116006 Hygrostat with adjustable and permanently set relative humidity 3 64,5 2 3 4 1 Description Hygrostat, width 42 mm, height 64.5 mm, depth 38 mm; clip-on attachment for 35 mm DIN rail EN 50022 User manual Order Information rF/ R 65 H % 1 Item Qty 1 1 2 42 38 Delivery includes (assembled) 5 1 4 01108051 Description Hygrostat, fixed, 65 % air humidity Hygrostat, adjustable, 40 ... 90 % air humidity Accessories DIN rail (EN 50022) Item 3 35 mm; length 75 mm; with fixing materials kit, PU 1 set Connection cable Item 4 SCHUKO/UTE connector, cable length 1.5 m; connection on thermostat/hygrostat, 2-pin, ferrules; connection on fan IEC socket; 1 piece Connection cable Item 4 SCHUKO/UTE connector, cable length 1.5 m; connection on thermostat/hygrostat, 2-pin, ferrules; connection on fan/heater, 3-pin, ferrules, 1 piece Part no. 60715-138 60715-213 21120-178 62150-201 62150-264 Technical data Supply voltage Default setting for relative air humidity Switch difference 01108009 connecting cable, connection cable, 2-pole, ferrule - IEC-(female) connector; input jack; bush; socket 230 VAC, 50/60 Hz 65 % fixed 40 ... 90% adjustable 5 % air humidity (w 1 % air humidity tolerance at 25 °C) Switch contact Changeover contact (relay) Lifespan > 50,000 cycles Max. switching capacity 8 A (16 A for 10 s) Mains supply 2-pin terminal, up to 2.5 mm2, torque max. 0.5 Nm Output change-over relay 3-pin terminal, up to 2.5 mm2, torque max. 0.5 Nm Case Plastic, in accordance with UL 94 V-0, light gray Dimensions Height 64.5 mm, width 42 mm, depth 38 mm Type of assembly Clip for 35 mm DIN rail, EN 50022 Weight 65 g Operating/storage 0 ... +60 °C/-20 ... +70 °C temperature Max. storage humidity 90 % air humidity (non-condensing) Type of protection IP 20 01108010 connecting cable, connection cable, 2-pole, ferrules - ferrules 4.68 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Climate control – Accessories IEC input plug Access ori es 쮿 For connection of fans 쮿 Bolted housing made of heat-resistant plastic (UL 94 V-0) 쮿 10 A/250 VAC, protection class I Order Information Description IEC input plug Part no. 60715-046 KTA45246 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 4.69 Climate control – Service Products / cooling concepts Text Product Closed cabinet Raised cover, ventilation slots Perforated doors 19" circulation fan, top cover fan Cooling principle 01105060 Description Type of protection Noise level approx. Environmental conditions Cooling capacity approx. 1) 01105058 01105056 01105057 Natural convection through thermal radiation Free convection through top opening Free convection through openings in doors/rear panels Cooling with air ≤ IP 55 0 Ti > Ta < 500 W ≤ IP 20 0 Ti > Ta 500 W ... 800 W ≤ IP 20 55 ... 65 dB(A) Ti > Ta 500 W ... 6000 W 2) ≤ IP 20 34 ... 67 dB(A) Ti > Ta < 2000 W 1) depending on cabinet size, electronic components, location and room cooling concept 2) > 800 W are only possible with own, active cooling through components like servers, etc. Ti = cabinet inner temperature Ta = cabinet ambient temperature FloTHERM simulation ServiceMain Catalogue Project support from simulation software FloTHERM simulation software allows to detect hot spots and problem areas from the concept phase. Cooling concepts for assemblies through to complete case/cabinet systems can thus be analysed in advance. Our FloTHERM experts support you in developing your concept. Your advantage: 쮿 Extensive analyses eliminate problems during the concept/ prototype phase 쮿 Short development times 쮿 High performance and reliability for your systems 01103050 4.2 SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Climate control – Service Products/cooling concepts Text Product Air filtered fans Air conditioners Air/water heat exchanger Air/water heat exchanger (LHX 3) (LHX 20/40) Cooling principle 01102050 Description Type of protection Noise level Environmental conditions Cooling capacity approx. 1) 01105061 01007055 01005081 Cooling with air Cooling with coolant Cooling with water Cooling with water ≤ IP 55 39 ... 71 dB(A) Ti > Ta < 1500 W ≥ IP 55 60 ... 81 dB(A) Ta ≤ 55 °C < 17000 W ≥ IP 55 45.2 dB(A) Ta ≤ 70 °C < 3000 W ≥ IP 55 50 ... 70 dB(A) Ta ≤ 70 °C < 40000 W 1) depending on cabinet size, electronic components, location and room cooling concept Ti = cabinet inner temperature Ta = cabinet ambient temperature Servic e Optimal test equipment Servic eMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days Being part of the Pentair group, Schroff and McLean look back on 50 years of experience and are reknown around the world for their expertise in efficient cooling of industrial facilities and equipment. Based on our own laboratory test chambers with the most modern equipement in Europe, America and Asia: 쮿 Walk-in climate chamber to test and optimize completely integrated cabinets and systems under different conditions 쮿 Smaller climate chambers to test components 쮿 Airflow and air resistance measurements in a wind tunnel 쮿 Noise level measurements 쮿 Tests in accordance with DIN EN 60529 to determine the type of protection (IP) Climate bay testing SCHROFF.PENTAIR.CO.UK 01112001 Outstanding standard products, flexible custom solutions, global technical support and service add up to a ’cool’ combination! Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 4.3 PROLINE OverviewMain Catalogue Desk-top cases – Overview Content Cabinets . . . . . . 1 Y The universal case with 19" compatible dimensions e.g. for CompactPCI and VME64x applications - Aluminium case - Height 2 ... 7 U - High EMC shielding Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 i The robust case for 19" compatible or custom electronics assemblies - Aluminium case with aluminium frame front - Height 2 ... 6 U - High EMC shielding Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 5.0 Downloads und weitere wichtige Informationen finden Sie im Internet unter www.schroff.biz SCHROFF PRODUCT CATALOG E 05/2016 361009005 (12304003 10005004 05802001 06803006 05809001) ELECTRONICS PROTECTION Desk-top cases – Overview Overview . . . . . . 5.0 OverviewMain C atalogue b Introduction . . . . 5.2 Desk-top or portable case Design alternative to propacPRO - Front and rear frame in aluminium - Aluminium case - Height 2 ... 6 U - For 19" components or individual electronics assemblies ServicePLUS . . . 5.4 ratiopacPRO . . . 5.6 propacPRO . . . . 5.44 compacPRO . . . . 5.76 comptec . . . . . . . 5.100 Accessories Handles . . . . . . . . . 5.108 Strap handles . . . . 5.111 Tip-up carrying handles . . . . . . . . . . 5.112 J Accessories Case to house 19" subracks or 19" chassis - Case with aluminium frame to front and rear - High stability - Height 3 ... 12 U - Identical front and rear - Internal mounting up to 40 kg - Protection class IP 20 Folding handles . . 5.113 Tray handles . . . . . 5.114 Feet . . . . . . . . . . . . 5.115 ServicePLUS . . . 5.4 36109006 (02004001 02202003 05806006 02992004 05806008) SCHROFF.PENTAIR.CO.UK 5.1 Desk-top cases – Introduction Case types: Desk-top enclosure/19" case Introduc tionMain CataloguePart num ber in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days Desk-top enclosures Our desk-top cases are used to house PCBs (euroboards) or individual components The choice is yours: 쮿 ratiopacPRO, the universal case with 19" compatible dimensions and high EMC shielding, e.g. for CompactPCI and VME64x applications Desk-top enclosure, ratiopacPRO 01810002 19" case, comptec 02202004 쮿 propacPRO, the robust case with high EMC shielding for 19"-compatible or custom electronics assemblies 쮿 compacPRO, Desk-top or portable case for unshielded applications 19" cases Our comptec cases are comparable with small cabinets and are used to house 19" components such as subracks, 19" fan trays or 19" front panels All desk-top enclosures have a very low weight owing to the materials used and are also suitable for mobile use Applications for desk-top enclosures Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days The most important user domains for desk-top enclosures are: 쮿 Fitting with euroboards in accordance with IEC 60297 쮿 Fitting with individual electrical or mechanical components, e.g.on mounting plates 02004079 05809004 05809004 Example above: for euroboards, below: for individual installation One product platform and extensive accessories Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Practical technology without time-consuming assembly. The modular product platform of these cases allows a wide range of possible uses with only a small number of components. The intelligent design of all components results in an astonishingly quick and easy assembly of the components. 05806008 05806006 With our PRO product platform we offer you full compatibility of all individual components and accessories, also with our europacPRO subracks. Standard desk-top enclosures can also be adapted easily and with little effort for mobile applications. 02005003 5.2 SCHROFF PRODUCT CATALOG E 05/2016 02005006 ELECTRONICS PROTECTION Desk-top cases – Introduction Forms of delivery for desk-top enclosures Introducti onMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days Supplied in space-saving packs. Simply unpack parts and screw together - done. Depending on the kit chosen the threaded insert, the perforated rail or the EMC gasket is pre-assembled on the horizontal rail. We offer you three forms of delivery: 쮿 Pre-assembled kit for use with 160 mm deep euroboards, frame fitted, cladding parts and guide rails supplied loose. 쮿 Pre-assembled kit for individual configuration, frame assembled, cladding parts supplied loose. 쮿 Ready assembled cases to your specifications. With our ServicePLUS option you can order ready-assembled cases, with drilled holes and cut-outs and individual front panels if necessary even by express service. 06104001 Flat pack delivery to save space Guide rail Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Guide rails form the interface between the mechanics of the case and the electronics assembled (PCBs, plug-in units, frame type plug-in units, drive unit modules, etc.). Robust snap-in fixings on the plastic rails assure that the components are held securely, even when exposed to vibrations. 11 7 79 3 77 81 Guide rails can also be screwed on. 1 75 5 73 9 1 83 06108084 EMC and ESD dB 120 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Our case product platforms offer standard solutions for achieving electromagnetic compatibility (EMC) and to avoid electrostatic interference (ESD) 100 쮿 Shielding on the front and rear of the case is effected by front panels with EMC gaskets 80 60 쮿 To prevent electrostatic discharge when inserting PCBs, ESD contacts are clipped into the guide rails. These provide a conductive connection between board and case earth/ground 40 20 쮿 Test reports are available on our website www.schroff.biz for download 0 30 400 800 1200 1600 2000 Mhz Shielding Position of the ESD clip SCHROFF.PENTAIR.CO.UK 06108081 04503050 5.3 Desk-top cases – ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable, without extra costs modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 CAD data are available for you to download and further modify from our website www.schroff.biz 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days solution Simple. Fast. From one source. Integration and custom developments 쮿 Flowtherm simulation to calculate heat paths; verification in our own climate lab 쮿 Special sizes, custom solutions express When fast has to be faster. Delivery time to customer's request 쮿 ServicePLUS assembly ready for despatch within 10 working days 쮿 ServicePLUS modification and ServicePLUS solution ready for despatch within 15 working days academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars held centrally or at your site. 쮿 CAD drawings, test reports, user manuals ServicePLUSMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – ServicePLUS Application examples Text Application: ratiopacPRO-air case in special colour, shielded board cage, filter mat top and bottom Application: compacPRO case, modified Application: compacPRO case with fitted horizontal rail with lip and folding front panel Application: inpac case with hinged and modified front and rear panels SCHROFF.PENTAIR.CO.UK 01809001 02009001 02009002 02109001 Application: ratiopacPRO-air case with processed front and rear panels Application: compacPRO case with fitted horizontal rail with lip and hinged front panel Application: compacPRO with tip-up carrying handle and front panel (without visible screws) Application: propacPRO, EMC case in special colour with mounting plates for individual construction 01809003 02009003 02009004 05809005 5.5 Desk-top cases – Introduction Case types: Desk-top enclosure/19" case Introduc tionMain CataloguePart num ber in bold face type: ready for despatc h within 2 working daysPart number in norm al type: ready for despatch wi thin 10 working days Desk-top enclosures Our desk-top cases are used to house PCBs (euroboards) or individual components The choice is yours: 쮿 ratiopacPRO, the universal case with 19" compatible dimensions and high EMC shielding, e.g. for CompactPCI and VME64x applications Desk-top enclosure, ratiopacPRO 01810002 19" case, comptec 02202004 쮿 propacPRO, the robust case with high EMC shielding for 19"-compatible or custom electronics assemblies 쮿 compacPRO, Desk-top or portable case for unshielded applications 19" cases Our comptec cases are comparable with small cabinets and are used to house 19" components such as subracks, 19" fan trays or 19" front panels All desk-top enclosures have a very low weight owing to the materials used and are also suitable for mobile use Applications for desk-top enclosures Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days The most important user domains for desk-top enclosures are: 쮿 Fitting with euroboards in accordance with IEC 60297 쮿 Fitting with individual electrical or mechanical components, e.g.on mounting plates 02004079 05809004 05809004 Example above: for euroboards, below: for individual installation One product platform and extensive accessories Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Practical technology without time-consuming assembly. The modular product platform of these cases allows a wide range of possible uses with only a small number of components. The intelligent design of all components results in an astonishingly quick and easy assembly of the components. 05806008 05806006 With our PRO product platform we offer you full compatibility of all individual components and accessories, also with our europacPRO subracks. Standard desk-top enclosures can also be adapted easily and with little effort for mobile applications. 02005003 5.2 SCHROFF PRODUCT CATALOG E 05/2016 02005006 ELECTRONICS PROTECTION Desk-top cases – Introduction Forms of delivery for desk-top enclosures Introducti onMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days Supplied in space-saving packs. Simply unpack parts and screw together - done. Depending on the kit chosen the threaded insert, the perforated rail or the EMC gasket is pre-assembled on the horizontal rail. We offer you three forms of delivery: 쮿 Pre-assembled kit for use with 160 mm deep euroboards, frame fitted, cladding parts and guide rails supplied loose. 쮿 Pre-assembled kit for individual configuration, frame assembled, cladding parts supplied loose. 쮿 Ready assembled cases to your specifications. With our ServicePLUS option you can order ready-assembled cases, with drilled holes and cut-outs and individual front panels if necessary even by express service. 06104001 Flat pack delivery to save space Guide rail Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Guide rails form the interface between the mechanics of the case and the electronics assembled (PCBs, plug-in units, frame type plug-in units, drive unit modules, etc.). Robust snap-in fixings on the plastic rails assure that the components are held securely, even when exposed to vibrations. 11 7 79 3 77 81 Guide rails can also be screwed on. 1 75 5 73 9 1 83 06108084 EMC and ESD dB 120 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Our case product platforms offer standard solutions for achieving electromagnetic compatibility (EMC) and to avoid electrostatic interference (ESD) 100 쮿 Shielding on the front and rear of the case is effected by front panels with EMC gaskets 80 60 쮿 To prevent electrostatic discharge when inserting PCBs, ESD contacts are clipped into the guide rails. These provide a conductive connection between board and case earth/ground 40 20 쮿 Test reports are available on our website www.schroff.biz for download 0 30 400 800 1200 1600 2000 Mhz Shielding Position of the ESD clip SCHROFF.PENTAIR.CO.UK 06108081 04503050 5.3 Desk-top cases – ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable, without extra costs modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 CAD data are available for you to download and further modify from our website www.schroff.biz 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days solution Simple. Fast. From one source. Integration and custom developments 쮿 Flowtherm simulation to calculate heat paths; verification in our own climate lab 쮿 Special sizes, custom solutions express When fast has to be faster. Delivery time to customer's request 쮿 ServicePLUS assembly ready for despatch within 10 working days 쮿 ServicePLUS modification and ServicePLUS solution ready for despatch within 15 working days academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars held centrally or at your site. 쮿 CAD drawings, test reports, user manuals ServicePLUSMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – ServicePLUS Application examples Text Application: ratiopacPRO-air case in special colour, shielded board cage, filter mat top and bottom Application: compacPRO case, modified Application: compacPRO case with fitted horizontal rail with lip and folding front panel Application: inpac case with hinged and modified front and rear panels SCHROFF.PENTAIR.CO.UK 01809001 02009001 02009002 02109001 Application: ratiopacPRO-air case with processed front and rear panels Application: compacPRO case with fitted horizontal rail with lip and hinged front panel Application: compacPRO with tip-up carrying handle and front panel (without visible screws) Application: propacPRO, EMC case in special colour with mounting plates for individual construction 01809003 02009003 02009004 05809005 5.5 Y Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days Desk-top cases – Y Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 06800002 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 ratiopacPRO Designed for insertion/extractor handles in accordance with IEC 60297-3-102 and IEEE 1101.10 for CompactPCI and VME64x applications 06801005 ratiopacPRO air Designed for insertion/extractor handles in accordance with IEC 60297-3-102 and IEEE 1101.10 for CompactPCI and VME64x applications; 1 U extra for ventilation (1/2 U top, 1/2 U bottom) Standards 쮿 Inner and outer dimensions in accordance with: IEC 60297-3-101 / IEEE 1101.1 IEC 60297-3-102 / IEEE 1101.10/11 쮿 Type of protection IP20 in accordance with IEC 60529 쮿 Earthing connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A1 쮿 EMC testing in accordance with VG 95373 part 15 06812001 Case with mounting plate 06800015 Prepared for CompactPCI and VME64x applications Appendix . . . . . 12 5.6 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y Overview . . . . . . 5.6 YMain C atalogue The universal case with 19" compatible dimensions e.g. for CompactPCI, VME64x and other applications 쮿 Base level of shielding in basic versions upwards, additional EMC shielding can be retrofitted 쮿 Symmetrical construction, identical front and rear (identical board cage for ratiopacPRO and ratiopacPRO air) 쮿 Converts simply from desktop to 19" rack-mounted case and back 쮿 No visible screws; cladding parts removable without tools ratiopacPRO Complete cases . . Dimensions . . . . . . Cases . . . . . . . . . . . Tower cases . . . . . ratiopacPRO air ratiopacPRO Cases . . . . . . . . . . . Complete cases . . Dimensions . . . . . . Radial fan units . . EMC gasketing . . . 쮿 Case with cover strip, front handles or 19" brackets (height 2 U ... 6 U) Accessories 쮿 Complete case with cover strip and pre-mounted components, with basic shielding (height 3 U, 6 U), additional EMC shielding retrofittable 쮿 Tower case (width 4 U) 06800005 ratiopacPRO air 쮿 ratiopacPRO air with additional 1 U height for ventilation 쮿 Case with cover strips, front handles or 19" brackets (height 4 U, 5 U, 7 U) 쮿 Complete case with cover strips and pre-mounted components, with basic shielding (height 4 U, 7 U), additional EMC shielding retrofittable 06803002 5.8 5.9 5.10 5.12 5.14 5.13 5.16 5.17 5.18 Front panels . . . . . 5.21 Rear panels . . . . . . 5.22 Feet . . . . . . . . . . . . . 5.23 Air filters . . . . . . . . 5.23 GND/earthing kit 5.24 Front handles . . . . 5.24 19" brackets . . . . . 5.25 Cable holder. . . . . 5.26 Compartment seals. . . . . . . . . . . . . 5.26 Strap handles . . . . 5.26 Tip-up carrying handles . . . . . . . . . 5.27 Assembly kit. . . . . 5.28 Fitting position of horizontal rails . . . 5.29 Horizontal rails. . . 5.31 Threaded inserts, perforated strips, insulation strips . . 5.35 Z-rails, perforated rails. . . . . . . . . . . . . 5.35 Divider plates . . . . 5.36 Mounting plates . . 5.37 Horizontal board assembly . . . . . . . . 5.38 Combined mounting . . . . . . . . 5.39 Guide rails and ESD clips . . . . . . . . 5.40 ServicePLUS . . . 5.4 ServicePLUS from page 5.4 e.g. modifications (special colours or sizes) e.g. custom solutions (cut-outs in top cover, base plate or side panels) e.g. assembly service from 1 piece www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 5.7 Desk-top cases – Y ratiopacPRO complete cases YMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 Desk-top enclosure with pre-configured components, in accordance to IEC 60297-3-101; prepared for 19" components, e.g. plug-in units and euroboards 쮿 Ventilation slit in base plate 쮿 Rear panel perforated Delivery comprises (in kit form) 06812003 11 15 10 “X” Item Qty without EMC 1 2 2 2 3 4 with EMC 2 2 4 Description 4 4 4 5 2 2 6 7 1 6/8 1 6/8 8 9 10 11 – 4 1 2 4 4 1 2 12 4 4 14 – 1 15 – 4 16 17 – 1 4 1 4, 7, 8,16 “Y” “Z” 5, 7, 9 6, 7, 9 1 2 3 15 11 12 01802050 “X” “Y” 9 4 9 7 7 16 “Z” 7 5 8 6 01808055 A-A Order Information Height H Width W Depth D U 3 3 3 3 3 3 3 6 6 6 6 6 HP 28 42 42 63 84 84 84 42 63 84 84 84 mm 255.5 255.5 315.5 315.5 315.5 375.5 435.5 315.5 315.5 315.5 375.5 435.5 Unshielded Part no. EMC shielded Part no. 24572-001 24572-002 24572-050 24572-051 24572-003 24572-052 24572-004 24572-005 24572-053 24572-054 H A Side panel, AI, 2 mm, passivated Side plate, Al, 1 mm, visible surfaces RAL 9006 Cover strip, Al die-cast, RAL 7016, pre-fitted only on EMC version Horizontal rail, type H-LD, Al, visible surfaces RAL 7016 Horizontal rail, centre (top/bottom), type H-ST, Al Horizontal rail, centre (on 6 U only), type ST, Al 3 U/6 U: threaded inserts, St, pre-mounted, for indirect backplane mounting with insulation strips Perforated strip, Al, 1 mm, pre-fitted Insulation strip, PBT, UL 94 V-0 Rear panel, perforated, Al, 2.5 mm Top cover and base plate, Al, 1 mm, internal surfaces conductive, visible surfaces RAL 9006, with GND/earthing connection, base plate with honeycomb grid ventilation Case foot with anti-slip protection, UL 94 V-0, PC black EMC support profile for side panel, pre-mounted (kit) EMC contact strip for cover plate, pre-mounted (kit) EMC contact strip front panel - horizontal rails GND/earthing kit, assembly kit W W - 21.4 D - 20 7.5 A D 01808051 3U A-A A W W - 21.4 7.5 H A ServicePLUS see page 5.4 5.8 SCHROFF PRODUCT CATALOG E 09/2017 24572-055 24572-007 24572-015 24572-056 24572-064 24572-016 24572-065 24572-017 24572-018 24572-066 24572-067 24572-019 24572-068 Note D - 20 D 01808052 6U 24572-006 쮿 쮿 쮿 쮿 Dimension drawings and mounting depths see page 5.9 Components see page 5.18 Front handles and 19" mounting brackets from page 5.24 Guide rails from page 5.40 ELECTRONICS PROTECTION Desk-top cases – Y Dimension drawings RatiopacPRO Text rppr6637 RatiopacPRO with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle Dimensions table RatiopacPRO Height H in U in mm 2 3 4 5 6 88.10 132.55 177.00 221.45 265.90 Width h in mm 67.90 112.35 156.80 201.25 245.70 w W w1 Depth w2 w in HP in mm in mm in mm in mm 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 28 42 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 342.42 448.90 164.42 235.54 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 355.42 462.10 177.62 248.74 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 375.92 482.60 198.12 269.24 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 320.62 427.30 142.82 213.94 63 342.42 355.42 375.92 320.62 84 448.90 462.10 482.60 427.30 D d Total depth in mm Useable depth in mm 255.5 235.5 315.5 295.5 375.5 355.5 435.5 415.5 495.5 475.5 D1 Plug-in depth in mm 175.5 235.5 175.5 235.5 295.5 175.5 235.5 295.5 355.5 175.5 235.5 295.5 355.5 175.5 235.5 295.5 355.5 d2 Board depth in mm 160 220 160 220 280 160 220 280 340 160 220 280 340 160 220 280 340 Components mountable in 15 mm depth grid SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.9 Desk-top cases – Y RatiopacPRO case YMain CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days 쮿 Cases for individual assembly with 19" standard components or specific internal mounting, e.g. with mounting plate 쮿 Unshielded (EMC shielding retrofittable) 쮿 Symmetrical design, identical front and rear side 3a: Bezel 01805050 01805051 01805052 01813051 3b: Front handle 3c: 19" mounting 3d: 19" mounting bracket bracket with front handle 쮿 Four versions: – Bezels – Front handles – 19" mounting brackets – 19" mounting brackets with front handles 쮿 For board depth 160 mm, 220 mm, 280 mm, and 340 mm (depending on case depth) Delivery comprises (kit) Item 1 2 Qty 2 2 3 3a 3b 3c 2 2 2 2 3d 2 4 4 1 11 2 2 12 13 4 1 11 4 3 Description Side panel, AI, 2 mm, chromated Side plate, Al, 1 mm, visible surfaces powder-coated, RAL 9006 Rear trim, Al die-cast, powder-coated, RAL 7016 Bezel, Al die-cast, powder-coated, RAL 7016 Front handle, Al die-cast, powder-coated, RAL 7016 19" mounting bracket, Al diecast, powder-coated, RAL 7016 19" mounting bracket with front handle, Al diecast, powder-coated, RAL 7016 Horizontal rail, type H-LD, Al, visible surfaces powder-coated, RAL 7016 Top cover and base plate, Al, 1 mm, inner sides conductive, visible surfaces powder-coated, RAL 9006, with GND/earthing connections, base plate with honeycomb grid ventilation Case foot with anti-slip protection, UL 94 V-0, PC black Fixing materials kit 3a, 3b, 3c or 3d according to selection 3a (3b/3c/3d) Drawing with front cover strip ServicePLUS see page 5.4 5.10 SCHROFF PRODUCT CATALOG E 09/2017 Note 쮿 Order information, see following page 11 Order Information 12 Accessories Earthing kit CU wire, 1.5 mm2, PVC sleeve, green/yellow, 1 kit Al diecast foot with tip-up silver, 1 piece (SPQ 10) Plastic tip-up foot silver, similar to RAL 9006, PU 4 pieces 01813065 Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces Stacking aid silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid anthracite, similar to RAL 7016, PA, UL 94 V0, PU 4 pieces 24571-380 10603-002 20603-001 20603-002 20603-004 20603-003 ELECTRONICS PROTECTION Desk-top cases – Y RatiopacPRO case Cover strips Width W Depth D HP mm 28 28 42 42 42 63 63 63 84 84 84 84 84 Case height H 2U Part no. Part no. Part no. 255.5 315.5 255.5 315.5 255.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 495.5 24572-500 24572-503 24571-002 24571-005 24571-050 24571-053 24572-117 24572-120 24572-261 24572-264 24571-098 24571-101 24572-510 24571-014 24571-062 24572-129 24572-273 24571-110 24572-513 24572-514 24571-017 24571-018 24571-065 24571-066 24572-132 24572-133 24572-276 24572-277 24571-113 24571-114 28 28 42 42 42 63 63 63 84 84 84 84 84 Part no. Side panel subdivision (1 U-3 U-1 U) (3 U-2 U) Part no. 24572-520 24571-026 24571-074 24572-141 24572-285 24571-122 24572-523 24572-524 24571-029 24571-030 24571-077 24571-078 24572-144 24572-145 24572-288 24572-289 24571-125 24571-126 24572-530 24571-038 24571-086 24572-153 24572-297 24571-134 24572-533 24572-534 24571-041 24571-042 24571-089 24571-090 24572-156 24572-157 24572-300 24572-301 24571-137 24571-138 24572-535 24571-043 24571-091 24572-158 24572-302 24571-139 24572-536 24571-044 24571-092 24572-159 24572-303 24571-140 255.5 315.5 255.5 315.5 375.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 495.5 – – – – – – – – – – – – – 24571-702 24571-750 24572-213 24572-357 24571-798 24571-705 24571-714 24571-753 24571-762 24572-216 24572-225 24572-360 24572-369 24571-801 24571-810 24571-717 24571-765 24572-228 24572-372 24571-813 24571-718 24571-726 24571-766 24571-774 24572-229 24572-237 24572-373 24572-381 24571-814 24571-822 24571-729 24571-777 24572-240 24572-384 24571-825 24571-730 24571-738 24571-778 24571-786 24572-241 24572-249 24572-385 24572-393 24571-826 24571-834 24571-741 24571-789 24572-252 24572-396 24571-837 24571-742 24571-743 24571-790 24571-791 24572-253 24572-254 24572-397 24572-398 24571-838 24571-839 24571-744 24571-792 24572-255 24572-399 24571-840 84 255.5 24572-570 24571-438 24571-486 24572-201 24572-345 24571-534 84 315.5 24572-573 24571-441 24571-489 24572-204 24572-348 24571-537 84 375.5 24572-574 24571-442 24571-490 24572-205 24572-349 24571-538 84 435.5 24572-575 24571-443 24571-491 24572-206 24572-350 24571-539 84 495.5 24572-576 24571-444 24571-492 24572-207 24572-351 24571-540 19" mounting brackets with 84 front handles 255.5 24572-620 24572-630 24572-640 – – 24572-660 84 315.5 24572-623 24572-633 24572-643 – – 24572-663 84 375.5 24572-624 24572-634 24572-644 – – 24572-664 84 435.5 24572-625 24572-635 24572-645 – – 24572-665 84 495.5 24572-626 24572-636 24572-646 – – 24572-666 RPPR6629 Front handles 01805050 19" mounting brackets 01805052 01813051 Note 쮿 Dimension drawings and mounting depths see page 5.9 쮿 Components see page 5.18 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.11 Desk-top cases – Y ratiopacPRO tower with 4 U width Y 쮿 Symmetrical design, identical front and rear side 쮿 Mounting space 4 U, 84 HP, depth 475 mm 쮿 Case based on ratiopacPRO 쮿 Unshielded (EMC shielding retrofittable) Delivery comprises (in kit form) Item 1 2 Qty 2 4 3 4 4 2 5 1 6 2 7 1 06802001 5 1 Order Information 3 Width U 4 2 3 Description Base/top cover, Al, 2 mm, passivated Horizontal rail, type H-LD, Al, visible surface powder-coated, RAL 7016 Cover, Al die-cast, RAL 7016 Lateral cover plate, Al, 1 mm, with GND/earthing connection, visible surfaces powder-coated, internal surface conductive, RAL 9006 Top cover plate, Al, 1 mm, visible surface powder-coated, RAL 9006 Case foot with anti-slip protection, Al, powder-coated, RAL 7016 Assembly kit Part no. 24571-395 Note 쮿 Components see page 5.18 4 4 6 495.5 475.5 2) 462.25 448.7 427.3 177 156,81) 221,5 1) = open space between the horizontal rails 2) = max. mounting depth 01802054 ServicePLUS see page 5.4 5.12 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Yair ratiopacPRO air complete cases airY 쮿 The case has 2 x 1/2 U clearance for ventilation 쮿 Case with cover strip; with pre-mounted components for euroboards and backplane with insulation strip; no visible screws 쮿 Symmetrical design, identical front and rear honeycomb grid ventilation in top cover and base plate 06811001 Delivery comprises (in kit form) 13 Item Qty without EMC 1 2 2 2 3 4 11 15 10 “X” 4, 7, 8, 16 “Y” “Z” 5, 7, 9 쮿 Available in two versions: – unshielded (EMC shielding retrofittable) – with EMC shielding fitted 6, 7, 9 14 1 4 4 5 6 7 2 1 6/8 8 9 10 11 – 4 1 2 12 4 13 14 15 16 17 2 – – – 1 18 1 2 17 11 3 15 12 13 01802052 “X” “Y” 9 4 9 7 7 16 “Z” 7 5 8 6 01808055 A-A h H A Description with EMC 2 Side panel, AI, 2 mm, passivated 2 Side plate, Al, 1 mm, visible surface RAL 9006 4 Cover, die-cast zinc, RAL 7016, pre-mounted on EMC version only 4 Horizontal rail, type H-LD, Al, visible surface RAL 7016 2 Horizontal rail, centre (top/bottom), type H-ST, Al 1 Horizontal rail, centre (on 6 U only), type ST, Al 6/8 4 U/7 U: threaded inserts, St, pre-mounted, for indirect backplane mounting with insulation strips 4 Perforated strip, pre-mounted 4 Insulation strip, PBT, UL 94 V-0 1 Rear panel, Al, 2.5 mm 2 Top cover and base plate with honeycomb grid ventilation, Al, 1 mm, internal surface conductive, visible surface RAL 9006, with GND/earthing connection 4 Case foot with anti-slip protection, UL 94 V-0, PC, black 2 Air filter 1 EMC support profile for side panel, fitted (kit) 4 EMC contact strip for cover plate, pre-mounted (kit) 4 EMC contact strip front panel - horizontal rails 1 Compartment seal, PE foam, self-adhesive, temperature range -20 °C ... +85 °C 1 GND/earthing kit, assembly kit Order Information D w 7.5 A 01808053 3U A-A h w 7.5 A H A D 01808054 6U ServicePLUS see page 5.4 SCHROFF.PENTAIR.CO.UK Case height H U 4 4 4 4 4 4 4 7 7 7 7 7 PCB height h U 3 3 3 3 3 3 3 6 6 6 6 6 Width w HP 28 42 42 63 84 84 84 42 63 84 84 84 Depth D mm 255.5 255.5 315.5 315.5 315.5 375.5 435.5 315.5 315.5 315.5 375.5 435.5 Unshielded Part no. EMC shielded Part no. 24572-025 24572-074 24572-026 24572-027 24572-075 24572-076 24572-028 24572-077 24572-029 24572-030 24572-078 24572-079 24572-031 24572-080 24572-040 24572-041 24572-088 24572-089 24572-042 24572-090 24572-043 24572-044 24572-091 24572-092 Note 쮿 쮿 쮿 쮿 Dimension drawings and mounting depths see page 5.16 Components see page 5.18 Front handles and 19" mounting brackets from page 5.24 Guide rails from page 5.40 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.13 Desk-top cases – Yair RatiopacPRO air case airY 쮿 The case has 2 x 1/2 U clearances for ventilation beneath and above the board cage 쮿 Cases for individual assembly with 19" standard components or specific internal mounting, e.g. with mounting plate 쮿 Unshielded (EMC shielding retrofittable) 06801005 쮿 Symmetrical design, identical front and rear side 쮿 For board depth 160 mm, 220 mm, 280 mm, and 340 mm (depending on case depth) 쮿 Online download of 3D CAD data 쮿 Four versions: – Bezels – Front handles – 19" mounting brackets – With 19" mounting brackets and front handles 3a: Bezel 01805055 01805056 01805057 01813057 3b: Front handle 3c: 19" mounting 3d: 19" mounting bracket bracket with front handle 13 11 Delivery comprises (in kit form) Item 1 2 Qty 2 2 3 3a 3b 3c 2 2 2 2 3d 2 4 4 11 2 12 13 14 4 2 1 4 3a (3b/3c/3d) 3 1 2 Description Side panel, AI, 2 mm, chromated Side plate, Al, 1 mm, visible surfaces powder-coated, RAL 9006 Rear trim, Al die-cast, powder-coated, RAL 7016 Bezel, Al die-cast, powder-coated, RAL 7016 Front handle, Al die-cast, powder-coated, RAL 7016 19" mounting angle, Al die-cast, powder-coated, RAL 7016 19" mounting bracket with front handle, Al diecast, powder-coated, RAL 7016 Horizontal rail, type H-LD, Al, visible surfaces powder-coated, RAL 7016 1 Top cover and base plate, Al, 1 mm, internal surfaces conductive,visible surfaces powder-coated, RAL 9006, with GND/earthing connection, top cover and base plate withventilation comb Case foot with anti-slip protection, UL 94 V-0, PC black Air filters Fixing materials kit 3a, 3b, 3c or 3d according to selection Note 11 쮿 Order information see following page 12 13 Drawing with front cover strip ServicePLUS see page 5.4 5.14 SCHROFF PRODUCT CATALOG E 09/2017 01813066 Order Information Accessories Earthing kit CU wire, 1.5 mm2, PVC sleeve, green/yellow, 1 kit Al diecast foot with tip-up silver, 1 piece (SPQ 10) Plastic tip-up foot silver, similar to RAL 9006, PU 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces Stacking aid silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid anthracite, similar to RAL 7016, PA, UL 94 V-0, PU 4 pieces 24571-380 10603-002 20603-001 20603-002 20603-004 20603-003 ELECTRONICS PROTECTION Desk-top cases – Yair RatiopacPRO air case Width W Depth D 4U Case height H 5U PCB height h 7U 3 1 Bezels 01805055 Front handles HP 28 28 42 42 42 63 63 63 63 84 84 84 84 84 28 28 42 42 42 42 63 63 63 84 84 84 84 84 mm 255.5 315.5 255.5 315.5 375.5 255.5 315.5 375.5 435.5 255.5 315.5 375.5 435.5 495.5 255.5 315.5 255.5 315.5 375.5 435.5 315.5 375.5 435.5 255.5 315.5 375.5 435.5 495.5 84 Part no. Part no. Part no. 24571-146 24571-149 24571-194 24571-197 24571-242 24571-245 24571-158 24571-206 24571-254 24571-161 24571-162 24571-209 24571-210 24571-257 24571-258 24571-170 24571-218 24571-266 24571-173 24571-174 24571-221 24571-222 24571-269 24571-270 24571-175 24571-223 24571-271 24571-182 24571-185 24571-230 24571-233 24571-278 24571-281 24571-186 24571-234 24571-282 24571-187 24571-188 24571-235 24571-236 24571-283 24571-284 24571-846 24571-894 24571-942 24571-849 24571-858 24571-897 24571-906 24571-945 24571-954 24571-861 24571-909 24571-957 24571-862 24571-863 24571-910 24571-911 24571-958 24571-959 24571-873 24571-921 24571-969 24571-874 24571-875 24571-922 24571-923 24571-970 24571-971 24571-882 24571-930 24571-978 24571-885 24571-886 24571-933 24571-934 24571-981 24571-982 24571-887 24571-935 24571-983 24571-888 24571-936 24571-984 255.5 24571-582 24571-630 24571-678 84 315.5 24571-585 24571-633 24571-681 84 375.5 24571-586 24571-634 24571-682 84 435.5 24571-587 24571-635 24571-683 01805057 84 495.5 24571-588 24571-636 24571-684 With 19" mounting brackets and front handles 84 255.5 24572-670 – 24572-690 84 315.5 24572-673 – 24572-693 84 375.5 24572-674 – 24572-694 84 435.5 24572-675 – 24572-695 84 495.5 24572-676 – 24572-696 01805056 19" mounting brackets 01805057 Note 쮿 Dimension drawings and mounting depths see page 5.16 쮿 Components see page 5.18 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.15 Desk-top cases – Yair RatiopacPRO air dimension drawings Text 01805058 RatiopacPRO air with A - bezel; B - front handle; C - 19" mounting bracket; D - 19" mounting bracket with front handle Dimensions table RatiopacPRO air Text Height H in U in mm 4 5 7 Width H 177.00 221.45 310.35 in mm 112.35 156.80 245.70 W Depth W1 W2 in HP in mm in mm in mm in mm 28 42 63 84 42 63 84 42 63 84 177.62 248.74 355.42 462.10 248.74 355.42 462.10 248.74 355.42 462.10 198.12 269.24 375.92 482.60 269.24 375.92 482.60 269.24 375.92 482.60 142.82 213.94 320.62 427.30 213.94 320.62 427.30 213.94 320.62 427.30 164.42 235.54 342.42 448.90 235.54 342.42 448.90 235.54 342.42 448.90 D w d Total depth in mm Usable depth in mm 255.5 235.5 315.5 295.5 375.5 355.5 435.5 415.5 495.5 475.5 D1 d2 Plug-in depth in mm 175 235 175 235 295 175 235 295 355 175 235 Board depth in mm 160 220 160 220 280 160 220 280 340 160 220 295 355 280 340 175 160 235 220 295 355 280 340 Components mountable in 15 mm depth grid 5.16 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Yair Radial fan unit for ratiopacPRO air Main Catalogue 쮿 Only 1/2 U height 쮿 Ball-bearing radial fans 쮿 Fan holder in 4 widths and 2 depths 쮿 Air capacity 36 m³/h (free blowing) per fan 쮿 Air exhaust via perforation in cover plate 쮿 No mechanical modification to case necessary 쮿 Simple mounting 2 쮿 No restriction to rear mounting space Delivery comprises (Kit) 1 4 Item 1 Qty 1 2 1-3 3 1 4 5 1 1 3 12309050 W 26,5 Description Fan support, Al, 1.5 mm, with crimp sockets for mounting the fans Radial fan, ball bearing, 12 VDC; airflow volume (50 Hz) 36 m³/h, free blowing; power consumption 6.7 W; connecting cable 300 mm, without plug (AWG 26); noise level in dB (A): 47.0; max. static pressure in Pa: 190; max. ambient temperature: 60 °C; fan housing and rotor: UL 94 V-0 Compartment seal, PE foam, UL 94, self-adhesive, temperature range -20 °C ... +85 °C Terminal clamp, UL 90 V-0 Assembly kit D Order Information 70 8 Depth D: 129.8 / 189.9 mm for 160 mm / 220 mm euroboards 12309051 Width Width HP 28 42 63 84 mm 146.87 218.00 324.67 431.35 Number of fans 1 1 2 3 Part no. for PCB depth 160 mm 220 mm 24572-404 24572-408 24572-405 24572-406 24572-409 24572-410 24572-407 24572-411 Note 쮿 Further configurations available on request 쮿 Fans with tacho signal available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.17 Desk-top cases – Y/ -air EMC sealing front/rear panel to side panel / -ai rY 쮿 For vertical EMC shielding between sub-assemblies and side panel 쮿 Scope of delivery sufficient for one case Delivery comprises (kit) 1 Item 1 2 Qty 4 2 2 3 1 Description EMC support profile, Al extrusion EMC sealing (textile), core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information rppr6639 For case height U 2, 3-air 3, 4-air 4, 5-air 6, 7-air 5, 6-air Part no. 24571-334 24571-331 24571-332 24571-333 24571-335 EMC sealing side panel to cover plate / -ai rY 쮿 For horizontal EMC shielding between side panels and cover plates 쮿 Scope of delivery sufficient for one case Delivery comprises (kit) Item 1 Qty 4 Description Contact strip, stainless steel Order Information Depth mm 255 315 375 435 495 Part no. 24571-338 24571-339 24571-340 24571-341 24571-342 RPPR6640 5.18 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air EMC sealing front/rear panel to horizontal rail Main Catalogue 쮿 The contact strip is clipped onto the horizontal rail and sets up the contact to front panel or rear panel 쮿 Can be used for rear horizontal rails (H-VT, L-VT) and all front horizontal rails Delivery comprises Item 1 Qty Description 10/100 Stainless steel EMC gasket Order Information rppr6739 Width HP 28 42 63 84 84 Width mm 131.78 202.9 304.8 416.3 416.3 Qty/PU 10 10 10 10 100 Part no. 24560-229 24560-231 24560-233 24560-235 24560-236 EMC sealing horizontal rail to horizontal rail / -airY 쮿 For shielding of two horizontal rails located directly above each other with vertical division of the mounting height Delivery comprises Item 1 2 Qty 1 2 Description Cover strip, Al, 1 mm Contact spring, St, stainless Order Information BPA46548 Assembly tool SCHROFF.PENTAIR.CO.UK BZA45877 Length HP 20 28 40 42 63 84 Assembly tool for EMC sealing, St, stainless (horizontal rails),1 piece Part no. 24562-520 24562-528 24562-540 24562-542 24562-563 24562-584 24560-271 aza45937 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.19 Desk-top cases – Y/ -air EMC front/rear panel, slotted, shielded / -ai rYMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days 쮿 No screws required for fixing 쮿 Special horizontal rails cover the edges of the front panel (top and bottom) and prevent bowing of the front panel Delivery comprises (Kit) H W 01811055 Item 1 Qty 1 2 3 4 5 6 2 4 2 3 1 Description Full-width front panel, Al, 2.5 mm, front: anodised, rear: colour passivated Horizontal rail, front; special for this front panel EMC support profile Contact strip horizontal rail - front panel EMC textile gasket Fixing material kit, user manual Order Information Front panel/horizontal rail 01811056 For case height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air Height H mm 84.0 84.0 84.0 84.0 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 For case width HP 28 42 63 84 28 42 63 84 28 42 63 84 Width W mm 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 Part no. 24572-599 24572-600 24572-601 24572-602 24572-603 24572-604 24572-605 24572-606 24572-607 24572-608 24572-609 24572-610 Note 쮿 To obtain a shielded case, all EMC sealings must be fitted (front panel/rear panel - side panel; side panel - cover plate; front panel/rear panel - horizontal rail; horizontal rail horizontal rail) 쮿 EMC sealing see from page 5.18 5.20 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Full-width front panel, slotted, unshielded / -airY 쮿 Front panels can also be used as rear panels 쮿 No screws required for fixing 쮿 Inserted between side panel and castings such as trim, 19" mounting bracket or handle Delivery comprises Item 1 Qty 1 Description Front panel, Al, 2.5 mm, front: anodised, rear: colour passivated Order Information 06801502 For case height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 5, 6-air 5, 6-air 5, 6-air 5, 6-air 6, 7-air 6, 7-air 6, 7-air 6, 7-air Height H For case width Width W mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 217.3 217.3 217.3 217.3 261.8 261.8 261.8 261.8 HP 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 28 42 63 84 mm 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 141.9 213.2 319.7 426.4 Part no. 34571-617 34571-618 34571-619 34571-620 34571-605 34571-606 34571-607 34571-608 34571-609 34571-610 34571-611 34571-612 34571-621 34571-622 34571-623 34571-624 34571-613 34571-614 34571-615 34571-616 Note 쮿 Screw-fixed front panels see chapter Front panels, page 7.4 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.21 Desk-top cases – Y/ -air Rear panels with ventilation slots 7,2 쮿 Two versions: unshielded, Al, 2.5 mm; shieldable, Al extrusion (textile EMC seal, retrofittable) ø 5,9 x 3,3 3 3,2 / -ai rY Z 25 쮿 Mounting on horizontal rails (top and bottom) Delivery comprises B 7,45 W 3 H Item 1 2,5 3,7 3,7 W - 2,58 01802055 2,5 Unshielded Description Rear panel, Al, 2.5 mm, front: anodised, rear: iridescent green chromated; unshielded or shieldable with EMC seal (textile) Order Information 7,45 Shieldable Qty 1 01804050 Height U 2, 3-air 2, 3-air 2, 3-air 2, 3-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 5, 6-air 5, 6-air 5, 6-air 5, 6-air 6, 7-air 6, 7-air 6, 7-air 6, 7-air H mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 217.3 217.3 217.3 217.3 261.8 261.8 261.8 261.8 Width W HP mm 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 B mm – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 unshielded Part no. shieldable Part no. 30849-007 30849-014 20848-679 20848-680 30849-015 20848-681 30849-016 30849-008 20848-682 20848-633 30849-021 20848-634 30849-022 30849-023 20848-635 20848-636 30849-009 20848-656 30849-028 30849-029 20848-657 20848-658 30849-030 20848-659 30849-011 20848-744 30849-171 30849-172 20848-745 20848-746 30849-173 20848-747 30849-010 30849-035 20848-640 20848-641 30849-036 20848-642 30849-037 20848-643 쮿 Please order textile EMC seals separately 쮿 Assembly parts see page Chapter 7, Front panels 쮿 Rear/front panels without perforation see Chapter 7, Front panels 쮿 Rear panels with fan available on request Textile EMC seals Front panels Delivery comprises Item 1 Qty Description 10/100 Textile EMC seal, core: foam, sleeve: textile cladding with CuNi coating Order Information 04602054 5.22 SCHROFF PRODUCT CATALOG E 09/2017 Height U 2, 3-air 3, 4-air 3, 4-air 4, 5-air 5, 6-air 6, 7-air 6, 7-air Height mm 52 97 97 142 187 232 232 Qty/PU pieces 10 100 10 10 10 100 10 Part no. 21101-857 21101-854 21101-853 21101-858 21101-978 21101-856 21101-855 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Tip-up feet and stacking aid/design element / -airY 쮿 Can be used instead of standard feet 쮿 Carrying capacity: 25 kg per foot 쮿 Mounting holes in bottom of casing Delivery comprises ((kit)) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Tip-up foot 01802075 Description Tip-up foot, silver, similar to RAL 9006 Tip-up foot, anthracite, similar to RAL 7016 Stacking aid/design element silver, similar to RAL 9006, PA, UL 94 V-0, PU 4 pieces Stacking aid/design element anthracite, similar to RAL 7016, PA, UL 94 V-0, PU 4 pieces Part no. 20603-001 20603-002 20603-004 20603-003 Note 쮿 Tip-up feet are required to mount the stacking aid Stacking aid/design element 01802076 Air filters for ratiopacPRO air / -airY 쮿 Retrofit mounting without reworking and tools 쮿 Filter replacement without opening the case, IP protection retained Delivery comprises (kit) Item 1 2 3 Qty 1 1 1 Description Filter holder, Al, 1 mm, powder-coated, RAL 9006 Filter mat, synthetic fibre Self-adhesive fixings Order Information For case width HP 28 42 63 84 Air filter Part no. Replacement filter 1 piece Part no. 24571-325 64571-033 24571-326 64571-034 24571-327 24571-328 64571-035 64571-036 쮿 To optimise the air supply, tip-up feet must be fitted to the case, see page 5.23 rppr6658 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.23 Desk-top cases – Y/ -air Earthing kit / -ai rY 쮿 Forms the GND/earthing connections between side panels, base plate, top cover and rear panel 쮿 Protective GND/earthing connections in accordance with: – DIN EN 50178/VDE 0160 – DIN EN 60950/VDE 0805 – DIN EN 61010-1/VDE 0411 part 1 – DIN EN 61010-1A2/VDE 0411 part 1/A1 쮿 VDE tested Order Information Description GND/earthing kit, Cu wire 1.5 mm2, PVC sleeve, green/yellow Part no. 24571-380 aza43284 5.24 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y Front handles for retrofitting Y 쮿 For conversion of cases with cover strip, 19" mounting bracket or 19" mounting bracket with front handle Delivery comprises Item 1 Qty 2 Description Front handle, Al die-cast, powder-coated, RAL 7016 Order Information Front handle for RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 5 U RatiopacPRO 6 U RatiopacPRO air 3/4 U RatiopacPRO air 4/5 U RatiopacPRO air 6/7 U RPPR6651 Part no. 24571-301 24571-302 24571-993 24571-303 24571-304 24571-305 24571-306 19" mounting brackets for retrofitting Y 쮿 For conversion of cases with cover strip, front handle or 19" mounting bracket with front handle Delivery comprises Qty 2 Description 19" mounting bracket, Al diecast, powder-coated, RAL 7016 Order Information RPPR6652 19" mounting angle RatiopacPRO 2 U RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 5 U RatiopacPRO 6 U RatiopacPRO air 4 U RatiopacPRO air 5 U RatiopacPRO air 7 U Part no. 24571-994 24571-295 24571-296 24571-992 24571-297 24571-298 24571-299 24571-300 19" mounting bracket with front handle for conversion YMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days 쮿 For conversion of cases with cover strip, front handle or 19" mounting bracket Delivery comprises Qty 2 Description 19" mounting bracket with front handle, Al diecast, powder-coated, RAL 7016 Order Information 01813056 SCHROFF.PENTAIR.CO.UK 19" mounting angle RatiopacPRO 2 U RatiopacPRO 3 U RatiopacPRO 4 U RatiopacPRO 6 U RatiopacPRO air 4 U RatiopacPRO air 7 U Part no. 24572-700 24572-701 24572-702 24572-704 24572-705 24572-707 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.25 Desk-top cases – Y/ -air Cable holder Delivery comprises 46 9 26,5 19 Ø4 14 17 Ø3 ,4 Ø3 Qty 2 2 1 3 1 Description Cable bracket, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drilled holes each per bracket are needed in rear panel Assembly kit Order Information Ø 4,4 20,2 02908053 Item 1 02908052 Description Cable holder Part no. 24575-800 Air baffles for ratiopacPRO air / -ai rY 쮿 The air baffle (item 1) closes the space (1/2 U) between the rear horizontal rail and base plate Delivery comprises (in kit form) Item 1 Qty 1 Description Compartment seal, PE foam, UL 94 HF 1 + HF 2, self-adhesive, temperature range: -40 °C ... +85 °C Order Information For case width HP 42 63 84 Length mm 218.4 325.1 431.8 Part no. 20833-351 20833-352 20833-353 Note 01805059 쮿 Fan rear panel available on request 쮿 Radial fan unit see page 5.17 Strap handles / -ai rY 쮿 Retrofittable without mechanical modifications to the case 쮿 Static load-carrying capacity 20 kg Delivery comprises (kit) Item 1 Qty 1 2 3 4 1 2 1 Description Handle, steel spring, plastic-sheathed (flexible plastic), RAL 7016 Side plate, Al, visible surfaces powder-coated, RAL 9006 Adaptor, Al die-cast Assembly kit Order Information For case depth 06801515 5.26 SCHROFF PRODUCT CATALOG E 09/2017 mm 315 375 435 For case height 3 U, 4 U air Part no. For case height4 HE, 5 Uair Part no. 24571-308 24571-309 24571-314 24571-315 24571-310 24571-316 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Tip-up carrying handles / -airY 쮿 Retrofittable without mechanical modifications to the case 쮿 Adjustable in 30° increments 쮿 Static load-carrying capacity 30 kg Delivery comprises (kit) Item 1 2 3 4 5 06803006 RPA43897 For case height U 3, 4, 4-air, 5-air 3, 4, 4-air, 5-air 3, 4, 4-air, 5-air For case width HP 42 63 84 A mm 283,4 390,1 496,8 B mm 279,4 386,1 492,8 C mm 247,4 354,1 460,8 D mm 115 195 195 Qty 1 1 2 2 2 Description Carrying bar, Al extrusion, powder coated, RAL 9006 Handle shell, ABS, UL 94 V-0, RAL 7016 Tip-up protection, ABS, UL 94 V-0, RAL 7016 Notch device, Al die-cast Cover cap, ABS, UL 94 V-0, RAL 7016 Order Information For case height For case width For case depth U 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 3, 4-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air 4, 5-air HP 42 42 42 42 42 63 63 63 63 63 84 84 84 84 84 42 42 42 42 42 63 63 63 63 63 84 84 84 84 84 mm 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 255 315 375 435 495 Tip-up carrying handle Part no. Assembly kit 24571-320 24571-352 24571-320 24571-320 24571-353 24571-354 Part no. 24571-320 24571-355 24571-320 24571-321 24571-356 24571-352 24571-321 24571-353 24571-321 24571-321 24571-354 24571-355 24571-321 24571-356 24571-322 24571-322 24571-352 24571-353 24571-322 24571-354 24571-322 24571-322 24571-355 24571-356 24571-320 24571-359 24571-320 24571-320 24571-360 24571-361 24571-320 24571-362 24571-320 24571-321 24571-363 24571-359 24571-321 24571-360 24571-321 24571-321 24571-361 24571-362 24571-321 24571-363 24571-322 24571-322 24571-359 24571-360 24571-322 24571-361 24571-322 24571-322 24571-362 24571-363 Note 쮿 Cannot be used in conjunction with front handles 쮿 Assembly kit is required for tip-up carrying handle, please order separately rpa43898 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.27 Desk-top cases – Y/ -air Torx panhead screws / -ai rY Order Information AZA45923 Description Application Material Dimension Qty/PU Part no. Countersunk screw with Torx For horizontal rail to side panel, with GND/ earthing function St, zinc-plated M4 х 14 100 24571-371 Countersunk screw with Torx For horizontal rail to side panel, if guide rail is bolted onto slot 1 St, zinc-plated M4 х 10 100 24571-372 Nut Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Order Information Description Application Material Dimension Qty/PU Part no. Square nut For fixing: parts to side panels, support profiles, mounting plates St, zinc-plated M4 100 Dimension Qty/PU T8 1 64560-026 T20 1 64560-027 1 24560-271 1 24560-270 24560-140 AZA45921 Assembly tools Order Information Description Application Part no. Torx screwdriver AZA45925 Assembly tool for horizontal rails Exclusively to fix stainless steel – EMC gaskets in horizontal rails aza45938 For mounting stainless steel Assembly tool for front EMC contact strips on front panels panels with lateral slot – aza45937 5.28 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Mounting position ratiopacPRO horizontal rails/central rails front rear Text 2U front rear 3U H-LD H-LD H-LD H-LD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-LD H-LD H-LD H-LD 01805060 01802057 4 U (3 U + 1 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-LD H-LD 01802058 5 U (1 U + 3 U + 1 U) H-LD H-LD H-LD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-LD 5 U (3 U + 2 U) H-KD / H-LD / L-KD H-LD H-LD 01805061 6U H-LD H-LD H-LD H-LD 01805062 6 U (2 x 3 U) H-LD H-LD 233,35 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 ST / VT / MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD H-LD H-LD 01802059 01802060 H-LD H-ST L-ST H-KD H-VT L-VT L-KD H-MZ L-MZ ST VT MZ Horizontal rails can be bolted on in 15 mm depth grid SCHROFF.PENTAIR.CO.UK 01808050 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.29 Desk-top cases – Y/ -air Mounting position ratiopacPRO air horizontal rails/central rails front rear Text front rear 4-air U (1/2 U + 3 U + 1/2 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD 01802061 5-air U (1/2 U + 3 U + 1U +1/2 U) H-LD H-LD 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-KD / H-LD / L-KD H-LD H-LD 01802062 7-air U (1/2 U + 6 U + 1/2 U) H-LD 7-air U (1/2 U + 3 U + 3U 1/2 U) H-LD H-LD H-LD 233,35 100 H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ ST / VT / MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ 100 H-KD / H-LD / L-KD H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-LD H-LD H-LD H-LD 01802063 H-LD H-ST L-ST H-KD H-VT L-VT L-KD H-MZ L-MZ Horizontal rails can be bolted on in 15 mm depth grid 5.30 01802064 SCHROFF PRODUCT CATALOG E 09/2017 ST VT MZ 01808050 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Front horizontal rails Order Information With long lip for insertion/extraction of CompactPCI and VME64x boards "heavy" Type H-LD long lip "heavy" Type H-KD short lip bza44980 Usable length HP Length mm 28 147.32 42 218.44 63 325.12 84 431.80 M4 × 10, St, zinc-plated, necessary if guide rail is screwed to slot 1, PU 100 pieces Threaded inserts see page 06197008 06197009 Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-228 34560-242 34560-328 34560-342 34560-263 34560-363 34560-284 34560-384 24571-372 24571-372 5.35 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.31 Desk-top cases – Y/ -air Rear horizontal rails Main Catalogue Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 "heavy" Type H-ST standard 06105074 Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx panhead screw, 4 x 10 Perforated rail for connector mounting with insulation strip see page Z-rail for connector mounting without insulation strip see page Insulation strips see page Threaded inserts see page For direct fixing of connectors to EN 60603-2 (DIN 41612) 04400002 "heavy" Type H-VT long lip 06197011 04400003 "heavy" Type H-MZ with Z-rail 06197013 06197015 Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings Al extrusion, anodised finish, contact surface conducting, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-528 34560-728 34560-928 34560-542 34560-742 34560-942 34560-563 34560-584 34560-763 34560-784 34560-963 34560-984 24571-372 24571-372 24571-372 5.35 – – 5.35 – – 5.35 5.35 – 5.35 – 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg 5.32 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Horizontal rails rear, centre Main Catalogue Order Information For indirect mounting of backplanes via insulation strip For direct backplane mounting 04400001 Type ST 06108090 For direct fixing of connectors to EN 60603-2 (DIN 41612) 04400002 Type VT 06197016 04400003 Type MZ 06197017 06197018 Al extrusion, finish anodised, Al extrusion, finish anodised, Al extrusion, finish anodised, conductive contact surface; conductive contact surface; conductive contact surface; horizontal rail type AB (AB = support) horizontal rail type AB (AB = support) horizontal rail type AB (AB = support) is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards; is required to fix the 80 mm rear I/O boards; without marking without marking without marking Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx panhead screw, 4 x 10 Insulation strips see page Threaded inserts see page 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34561-028 34561-042 34561-128 34561-142 34561-228 34561-242 34561-063 34561-163 34561-263 34561-084 24571-372 34561-184 24571-372 34561-284 24571-372 5.35 5.35 – 5.35 – 5.35 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.33 Desk-top cases – Y/ -air Horizontal rails (type AB) for rear I/O guide rails Main Catalogue Order Information For CompactPCI in rear I/O area 12,75 AB H - ST 9,75 15 12,75 H - KD 3 06108009 Type AB H - ST AB H - KD 06108069 06197019 Al extrusion, finish anodised, conductive contact surface; horizontal rail type AB (AB = support) is required to fix the 80 mm rear I/O boards; without marking Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to side panel 1 piece (SPQ 10)1) 34561-520 34561-528 34561-540 34561-542 34561-563 34561-584 34561-501 24560-130 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 All horizontal rails without print 쮿 1000 mm version without M4 thread in end 5.34 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Threaded inserts, perforated strips, insulation strips Threaded insert M2.5 M3 Perforated strip (item 1) Insulation strip 5 2 5,0 8 06103056 Required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.66 BZA45853 For centring shielded plug-in units, Al, 1 mm, please order fixing grub screw separately BZ6749 For insulated mounting of backplane; PBT UL 94 V-0, grey Usable length Length Length Length HP mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm 1 piece (SPQ 10)1) mm PU 10 pieces2) 28 146.82 34561-328 – 147.12 30845-197 144.20 24560-828 42 217.94 – 218.24 210.40 34561-342 30845-211 24560-842 63 324.62 – 324.92 316.88 34561-363 30845-232 24560-863 84 431.30 34561-384 34561-484 431.60 30845-253 428.64 24560-884 Accessories Grub screw M2.5 x 8, PU – – – 21100-276 100 pieces Grub screw M2.5 x 9, PU – – – 21101-359 100 pieces Grub screw M3 x 8, PU – 21100-646 – – 100 pieces 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Z-rails, perforated rails Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 5 12,7 5 9,7 BZA45850 BZA45848 12,7 3,0 5 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Torx panhead screw, to fix connector to perforated rail,, M2.5 × 7, PU 100 piecesItem 3 Torx panhead screw, to fix perforated rail to horizontal rail, M2.5 × 10, PU 100 pieces Item 2 SCHROFF.PENTAIR.CO.UK 06708051 For connector mounting with ST horizontal rails, please order threaded insert and screw separately For connector mounting with ST horizontal rails, please order threaded insert and screw separately For connector mounting with VT horizontal rails, please order threaded insert and screw separately 1 piece PU 4 pieces 30822-047 1 piece – – 30822-065 30822-089 30819-783 30819-808 20822-047 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 30822-033 20822-049 20822-050 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.35 Desk-top cases – Y/ -air Divider plates Order Information Divider plates Mounting position for stainless Mounting position for steel EMC gasket textile EMC gasket front rear front bpa45911 rear 06105078 Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space requirement on component side 2 mm; mounting direction varies with shielding design (EMC stainless steel or textile gasket); retrofitting the divider plate in an already-assembled subrack/case will first require dismantling of the horizontal rails; where front panels are unshielded, both mounting directions are possible bpa45912 Height U 3 3 6 6 5.36 Depth mm 160 220 160 220 A mm 158.3 218.3 158.3 218.3 B mm 135.0 195.0 135.0 195.0 SCHROFF PRODUCT CATALOG E 09/2017 H mm 113.5 113.5 246.9 246.9 1 piece 34562-761 34562-762 34562-763 34562-764 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Mounting plates Order Information Mounting plate Assembly strip for partial widths bpa45875 bpa46557 Al, 1.5 mm; for mounting over partial St, 2 mm, zinc-plated; is bolted from width, please order assembly strips front to rear onto the horizontal rails; to fix mounting plates separately 06812002 Width Board lengths HP mm mm 28 146.88 160 28 146.88 220 28 146.88 280 28 146.88 340 42 217.99 160 42 217.99 220 42 217.99 280 42 217.99 340 63 324.67 160 63 324.67 220 63 324.67 280 63 324.67 340 84 431.35 160 84 431.35 220 84 431.35 280 84 431.35 340 Assembly kit for mounting plate PU 1 kit (Torx countersunk screw M4 x 5, St, zincplated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for assembly strips of mounting plate Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces 1 piece 1 piece 34562-745 34562-749 30840-021 30840-033 34562-753 30840-045 34562-757 34562-746 30840-057 30840-021 34562-750 30840-033 34562-754 34562-758 30840-045 30840-057 34562-747 30840-021 34562-751 34562-755 30840-033 30840-045 34562-759 30840-057 34562-748 34562-752 30840-021 30840-033 34562-756 30840-045 34562-760 30840-057 24560-184 – – 24560-146 Note 쮿 Please order fixing material for assembly of mounting plate separately 쮿 A guide rail can be mounted on the first and last slot position 쮿 4.4" and "reinforced" guide rails cannot be used SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.37 Desk-top cases – Y/ -air Horizontal board installation Order Information Horizontal board installation Front frame for EMC shielding Board cage 27 3.9 8= 54 Front frame, unshielded TE 06102073 ,98 =5 4T E bpa45913 H 273 h w bza43061 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 TE space required; please order front frame for EMC shielding separately 2 horizontal covers, AI, 2.5 mm, front anodised, rear iridescent green chromated; 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the subassemblies Al, 2.5 mm, clear anodised; front frame with cut-out, clear internal width w = 266.35 mm PU 1 kit PU 1 kit 1 piece bpa45914 Height U Usable height h HP Other dimensions and options 3 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Horizontal rail, rear Assembly tool, for mounting the EMC gasket (stainless steel) * For direct backplane mounting Note 쮿 Please order front frame separately 5.38 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Combined mountings (6 U and 2 x 3 U one above the other) Order Information Combined mounting Horizontal and vertical subdivision (incl. front panel for stainless steel EMC gasket) Alternative front panels for combined mounting Unshielded front Front panel for panel, 6 U, 2 HP textile EMC gasket, item 6 6 U, 2 HP item 6 Splitting extrusion For combined mounting Item 2 2 4 2 1,3 1,3 4 6 bpa46549 bza42182 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Countersunk screw with Torx M4 × 14, zinc-plated, PU 100 pieces fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces fixing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer, 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces bpa46549 bpa46549 bza45857 Item 1: 2 front horizontal rails (HKD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zinc-plated; item 4: Zn diecast support member; item 6: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket (84:0 without items 4, 6) Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, die-cast zinc; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 (SPQ 5) 1 piece (SPQ 5)1) 1 piece 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 – 24562-420 24562-440 24562-442 24562-463 24562-484 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accept Euroboards (100 mm high) and double Euroboards (233.35 mm high) Note 쮿 Please order EMC gasketing kit for horizontal rails separately, see page 5.19 쮿 Please order perforated strips for horizontal rails separately, see page 5.35 쮿 Please order rear centre horizontal rail separately, see page 5.33 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.39 Desk-top cases – Y/ -air Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Standard For plug-in units and frame type plug-in units With DIN connector fixing as standard Storage temperature from -40 °C ... 130 °C 06101001 Board lengths mm 70 70 160 220 280 340 160 220 Groove width mm 2 2 2 2 2 2 2.5 2.5 06101501 Up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards 100 x 160 mm or 100 x 220 mm only PU 10 pieces2) – – 1 pair (SPQ 10)1) – – 24560-351 64560-074 24560-353 24560-379 64560-075 Colour mm red grey red red red red red red – – – – 24560-380 – – Accessories Retention screw, PU 100 pieces 24560-141 ESD clip, PU 50 pieces 24560-255 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 5.40 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Guide rails type "accessories", one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plate Guide rail type "Accessories" strengthened "Accessories" For heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... +130 °C 06102002 Board lengths mm 100 160 160 220 220 Groove width mm 2 2 2 2 2 280 2 340 2 400 2 160 220 280 340 400 2.5 2.5 2.5 2.5 2.5 bza46554 06102005 Up to 220 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94V-0, red; support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces2) – 1 piece (SPQ 50)1) – 24560-373 Colour mm red red grey red grey red/ silver red/ silver red/ silver silver silver silver silver silver 64560-076 1 piece (SPQ 10)1) – – – – 34562-881 24560-374 64560-078 – – – 34562-882 24560-375 64560-080 34562-883 24560-376 – 34562-884 – – 34562-885 – – – – – – – – – – 34564-881 34564-882 24560-141 24560-141 24560-157 34564-883 34564-884 34564-885 Accessories Retention screw, PU 100 pieces ESD clip, PU 50 pieces Board locking C, red, PU 10 pieces Board handle C, red, PU 10 piecesdescription Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page 24560-255 – 24560-377 – 24560-378 – 60817-228 – 6.43 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.41 Desk-top cases – Y/ -air Guide rails for CompactPCI, VME64x with coding, 4.4" PCBs, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into1.5 mm thick plates For CompactPCI, VME64x with coding In accordance with IEEE 1101.10 and Offset 0.1" for power supply units in IEC 60297-3-103 accordance with IEEE 1101.10 and IEC 60297-3-103 For 4.4" PCBs Storage temperature from -40 °C ... 130 °C 06106001 Board lengths mm 70 70 160 160 160 220 220 220 160 220 220 280 280 340 340 Groove width mm 2 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 2.5 2.5 Colour mm red grey red grey green red grey green red red grey red grey red grey 06106002 06104009 One-piece for groove width 2 mm, PBT, UL 94 V-0; multi-piece at groove width 2,5 mm, end-piece PBT, UL 94 V-0, center piece Al profile PBT, UL 94 V-0, for installation of power supplies in CompactPCI systems or plug-in units with SMD placement One-piece, PBT, UL 94 V-0; for 4.4" PCBs or drive units PU 10 pieces2) PU 10 pieces2) PU 10 pieces 24560-355 – – – – – – 24560-360 24560-356 24560-358 – – – – – 24560-359 24560-361 – – 24560-362 24561-332 24561-342 – – – – – – – – – – 24560-255 – – 24560-256 24560-256 – 24560-141 24560-141 24560-158 20817-501 20817-501 – 24561-330 24561-340 24561-331 24561-341 – – – – – – – – – Accessories ESD clip, PU 50 pieces ESD clips, for alignment pin, PU 50 pieces Retention screw, PU 100 pieces Coding peg, PU 100 pieces 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 Note 쮿 Reinforcement for plastic profiles (PVC) > 280 mm depth available on request 5.42 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – Y/ -air Air baffle for slots Main Catalogue Order Information Air baffle without front panel Air baffle with front panel U front panel front panel with lateral for textile EMC gasket groove for stainless steel EMC gasket 06108085 06108087 Air baffle, Al, 1 mm; front panel, Al, 2.5 mm, front anodised, rear conductive; EMC gasket (stainless steel); fixing material kit prevents an air short- circuit where slots are unoccupied; is pushed into the groove of the guide rails Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06108088 Air deflector, Al, 1 mm, front panel, Al extrusion, 2.5 mm, front anodised, rear conductive; EMC gasket (textile); fixing material kit prevents an air short-circuit where slots are unoccupied; is pushed into the groove of the guide rails 06101507 Depth Width mm HP 160 4 160 4 160 8 160 8 160 12 160 12 220 4 220 4 220 8 220 8 220 12 220 12 Assembly tool for EMC gasket (stainless steel), 1 piece Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 1 piece 1 piece 34562-823 20848-712 20848-728 34562-826 34562-833 20848-720 20848-714 20848-736 20848-730 34562-836 20848-722 20848-738 34562-843 34562-846 20848-716 20848-724 20848-732 20848-740 34562-824 20848-713 20848-729 34562-827 34562-834 20848-721 20848-715 20848-737 20848-731 34562-837 20848-723 20848-739 34562-844 34562-847 20848-717 20848-725 20848-733 20848-741 – 24560-270 – Note 쮿 Air baffle for 280 mm deep and for 80 mm rear I/O boards available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.43 i Main Catalogue Desk-top cases – i Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 05809001 Subracks/ 19" chassis . . . . 6 05806052 Front panels, plug-in units . . . 7 Easy access provided by removable cladding parts Extremely robust one-piece die-cast frame 05806050 05806055 Non-sensitive, scratch-resistant finish through powder coating Low weight 05806056 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 05806054 Wide accessory programme with acrylic glass front hoods, carrying handles, ... Assembly possibility for euroboards and backplanes 05806053 EMC version 05806051 VDE-compliant GND/earthing noa44075 Backplanes . . . 10 Standards 쮿 Internal dimensions in accordance with IEC 60297-3-101 Connectors, front panel component system . . . . . . . 11 쮿 Ingress protection IP 20 in accordance with IEC 60529 쮿 EMC test in accordance with VG 95373 part 15 쮿 Protective GND/earth connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A1 Appendix . . . . . 12 5.44 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top cases – i Overview . . . . 5.44 Aluminium case for 19" components to IEC 60297-3-100 or individual electronics assemblies iMain C atalogue 쮿 Front frame and side panels in aluminium 쮿 Extensive accessories, matched to portable applications 쮿 Basic level shielding from basic versions up, extended EMC shielding retrofittable 쮿 Design alternative to compacPRO Desktop cases 쮿 Complete case (pre-assembled) – Prepared for 19" components to IEC 60297 for installation of euroboards – Basic level shielding from basic versions up, extended EMC shielding retrofittable – Height 3 U, 6 U propacPRO Complete cases 3, 6 U, unshielded/ shielded . . . . . . . . 5.46 Cases 2, 3 U . . . . . 5.50 Cases 4, 6 U . . . . . 5.51 Cases for tip-up carrying handle 3, 4 U. . . . . . . . . . . . . 5.52 Dimensions . . . . . . 5.53 쮿 Cases – Pre-assembled cases as basis for individual components or 19" components (IEC 60297) – Basic level shielding from basic versions up, extended EMC shielding retrofittable – Height: 2 U, 3 U, 4 U, 6 U – 3 U and 4 U cases prepared for tip-up carrying handle EMC shielding . . . 5.55 Accessories Front panels . . . . . 5.54 Rear panels . . . . . . 5.55 Design elements . 5.58 Lateral covers . . . 5.59 Handles . . . . . . . . . 5.60 Air filters . . . . . . . . 5.61 05809003 05806003 Hoods . . . . . . . . . . . 5.62 Accessories Mounting plates . . 5.64 GND/earthing kit . 5.65 Cable holder . . . . 5.65 Mounting position horizontal/central rails . . . . . . . . . . . . . 5.66 Horizontal rails . 5.67 Threaded inserts . 5.68 Z-rails, perforated rails . . 5.69 Combined mounting . . . . . . . . 5.70 05809002 Horizontal board assembly . . . . . . . . 5.71 Tip-up feet . . . . . . . 5.72 ServicePLUS from page 5.4 Guide rails and ESD clips . . . . . . . . 5.73 Divider plates . . . . 5.75 e.g. modifications (special colours, special depths, cut-outs in top cover, base plate or side panels) e.g. assembly service from 1 piece Air flow barrier . . . 5.75 www.schroff.biz/ServicePLUS ServicePLUS . . 5.4 30407004 SCHROFF.PENTAIR.CO.UK 5.45 Desk-top enclosure – i Complete case, EMC shielded iMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Rear panel with vent slots Delivery comprises (Items 1-7, 9 and 10 fitted) Item 1 2 Qty 3U 1 2 6U 1 4 3 1 1 4 1 1 5 2 2 6 7 - 2 2 8 4 4 9 2 2 10a 2 2 5 10b 2 2 7 11 2 2 12 - 1 13 1 1 14 2 2 15 10/ 20 10/ 20 16 17 1 1 1 1 05809004 3U Description 13 3 12 10 b 11 14 2 1 9 6 15 10 a 4 8 9 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) ServicePLUS see page 5.4 5.46 SCHROFF PRODUCT CATALOG E 09/2017 05806106 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006, with EMC side panel gasketing Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot when case is used in vertical position Adaptor bracket (only at 6 U) Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Lateral trim, Al extrusion, visible surface painted, RAL 7016 with EMC sealing (textile) Horizontal rail, Al extrusion, with threaded insert, St, M2.5; perforated strip, Al, 1 mm, EMC contact strip between front panel - horizontal rail - cover plate Horizontal rail, Al extrusion, with threaded insert, St, M2.5; EMC contact strip between rear panel horizontal rail - cover plate Centre horizontal rail top/bottom, Al extrusion, with threaded insert, St, M2.5 and insulation strip, PBT, UL 94 V-0 (for indirect backplane mounting); enclosed loose Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with perforation, Al, 2.5 mm, anodised, with EMC sealing (textile) affixed EMC support profile rear, Al extrusion, EMC sealing (textile) affixed Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit ELECTRONICS PROTECTION Desk-top enclosure – i Complete cases, EMC shielded Main Catalogue 155,5 289,0 Usable width W2 W2 HP mm 28 147.3 28 147.3 42 218.4 42 218.4 42 218.4 63 325.1 63 325.1 63 325.1 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 130,0 262,8 Order Information W2 112,3 245,7 W1 05809051 Width W1 W1 mm 185.9 185.9 257 257 257 363.7 363.7 363.7 470.3 470.3 470.3 470.3 470.3 470.3 470.3 Depth D D mm 266 326 266 326 386 266 326 386 266 326 386 446 506 326 446 Height U 3 3 3 3 3 3 3 3 3 3 3 3 3 6 6 Part no. 24576-101 24576-102 24576-103 24576-104 24576-105 24576-106 24576-107 24576-108 24576-109 24576-110 24576-111 24576-112 24576-113 24576-121 24576-122 Note 쮿 Dimension drawings of side panel see from page 5.53 3U 6U SCHROFF.PENTAIR.CO.UK 05806060 05806062 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.47 Desk-top enclosure – i Complete cases, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Rear panel perforated Delivery comprises (Items 1-7, 9 and 10 fitted) Item 1 2 3 Qty 3U 1 2 1 6U 1 4 1 Description 4 1 1 5 2 2 6 7 - 2 2 8 4 4 9 2 2 10 2 2 11 2 2 12 - 1 13 1 1 14 15 4 10/ 20 1 1 4 10/ 20 1 1 05809004 3U Maximum mounting depth = D - 45 (Distance: front panel - rear panel) 05806105 16 17 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Adaptor bracket (only at 6 U) Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Lateral trim, Al extrusion, visible surface painted, RAL 7016 with EMC sealing (textile) Horizontal rail, Al extrusion, with threaded insert, St, M2.5 Rear horizontal rail, Al extrusion, with threaded insert, St, M2.5 and insulation strips, PBT, UL 94 V-0 (for indirect backplane mounting) Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with perforation, Al, anodised, 2 mm at 28, 42 and 63 HP, 2.5 mm at 84 HP Support member for rear panel, Zn die-cast Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit ServicePLUS see page 5.4 5.48 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Complete cases, unshielded Order Information Main Catalogue W1 155,5 289,0 130,0 262,8 112,3 245,7 W2 05809051 Usable width W2 W2 HP mm 28 147.3 28 147.3 42 218.4 42 218.4 42 218.4 63 325.1 63 325.1 63 325.1 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 84 431.8 Width W1 Depth D Height mm 185.9 185.9 257 257 257 363.7 363.7 363.7 470.3 470.3 470.3 470.3 470.3 470.3 470.3 mm 266 326 266 326 386 266 326 386 266 326 386 446 506 326 446 U 3 3 3 3 3 3 3 3 3 3 3 3 3 6 6 Part no. 24576-001 24576-002 24576-003 24576-004 24576-005 24576-006 24576-007 24576-008 24576-009 24576-010 24576-011 24576-012 24576-013 24576-021 24576-022 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) Note 쮿 Dimension drawings of side panel see from page 5.53 3U 6U SCHROFF.PENTAIR.CO.UK 05806060 05806062 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.49 Desk-top enclosure – i Cases, 2 and 3 U, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing Delivery comprises (kit, items 1 - 5 fitted) 05806001 Item 1 2 3 Qty 1 2 1 4 1 5 2 6 7 4 1 Description Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Order Information 05806057 05806077 Cross-section 2 U, 3 U Usable width Width W1 Depth D 2U W2 W2 Part no. HP mm mm mm 28 147.3 185.9 266 – 28 147.3 185.9 326 – 42 218.4 257 266 14576-021 42 218.4 257 326 14576-023 42 218.4 257 386 – 63 325.1 363.7 266 14576-041 63 325.1 363.7 326 14576-043 63 325.1 363.7 386 14576-045 84 431.8 470.3 266 – 84 431.8 470.3 326 – 84 431.8 470.3 386 – 84 431.8 470.3 446 – 84 431.8 470.3 506 – Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/yellow, links side panels, base, cover and rear panel, PU 1 piece 3U Part no. 14576-101 14576-103 14576-121 14576-123 14576-125 14576-141 14576-143 14576-145 14576-161 14576-163 14576-165 14576-167 14576-169 21102-001 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) Note 쮿 Case, 3 U with side panel for tip-up carrying handle, see page 5.52 쮿 Dimensions see page 5.48 쮿 Dimensions side panel, see page 5.53 2U 05806059 3U 05806060 ServicePLUS see page 5.4 5.50 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Cases, 4 and 6 U, unshielded Main Catalogue 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing Delivery comprises (kit, items 1 - 6 fitted) Item 05806003 1 2 3 Qty 4U 1 2 1 6U 1 4 1 Description 4 1 1 5 2 2 6 7 – 2 2 2 8 4 4 9 1 1 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006 Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Adaptor bracket, Al Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Order Information 05806058 05806078 Usable width Width W1 Depth D 4U W2 W2 Part no. HP mm mm mm 42 218.4 257 266 14576-221 42 218.4 257 326 14576-223 63 325.1 363.7 266 14576-241 63 325.1 363.7 326 14576-243 63 325.1 363.7 386 14576-245 63 325.1 363.7 446 14576-247 84 431.8 470.3 326 – 84 431.8 470.3 386 14576-265 84 431.8 470.3 446 14576-267 84 431.8 470.3 506 14576-269 Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/yellow, links side panels, base, cover and rear panel, PU 1 piece 6U Part no. – – – – – – 14576-463 14576-465 14576-467 14576-469 21102-001 Maximum mounting depth = D - 45 (Distance: front panel - rear panel) Note 쮿 Case, 4 U with side panel for tip-up carrying handle, see page 5.52 쮿 Dimensions side panel, see page 5.53 05806061 4U 6U 05806062 ServicePLUS see page 5.4 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.51 Desk-top enclosure – i 3 U and 4 U cases, unshielded, with holes for tip-up carrying handle iMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Desk-top case with pre-configured components, in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 Ventilation slots in base plate 쮿 Prepared for GND/earthing 쮿 Prepared for fitting of tip-up carrying handle Delivery comprises (kit, items 1 - 6 fitted) Item 05812006 1 2 Qty 3U 1 2 4U 1 4 Description 3 1 1 4 1 1 5 2 2 6 – 2 7 4 4 8 1 1 3 5 2 1 4 Order Information 7 05812050 W1 155,5 200,0 112,3 156,8 130,0 174,0 W2 05812051 D 69,0 D 32,5 69,0 17,0 17,0 Ø 4,6 17,0 Ø 4,6 Usable width Width W1 Depth D 3U W2 W2 Part no. HP mm mm mm 42 218.4 257.0 326 14577-123 42 218.4 257.0 386 14577-125 63 325.1 363.7 326 14577-143 63 325.1 363.7 386 14577-145 84 431.8 470.3 326 14577-163 84 431.8 470.3 386 14577-165 Accessories GND/earthing kit Cu wire 1.5 mm2, PVC sleeve, green/yellow, links side panels, base, cover and rear panel , PU 1 piece Tip-up carrying handle for 42 HP case width, PU 1 kit Tip-up carrying handle for 63 HP case width, PU 1 kit Tip-up carrying handle for 84 HP case width, PU 1 kit 4U Part no. 14577-223 – 14577-243 14577-245 – 14577-265 21102-001 24576-071 24576-072 24576-073 Note 195,3 11,4 쮿 Dimensions see page 5.48 쮿 Dimensions side panel, see page 5.53 15 Ø 4,6 Ø 4,6 4 4 3U 7,2 15 7,2 33,05 150,9 121,95 Ø 10,4 Ø 10,4 121,95 32,5 17,0 Frame, Al die-cast, powder-coated, RAL 7016 Side panel, Al extrusion, powder-coated, RAL 9006; with drill holes for tip-up carrying handle Cover plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, internal surface conductive, visible surface powder-coated, RAL 9006, with GND/earthing tag, base plate with 4 rows of ventilation slots End piece for rear, ABS, RAL 7016, UL 94 V-0; can be used as a foot for use in vertical position Cover trim for side panel, Al extrusion, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit 05812052 4U 05812053 ServicePLUS see page 5.4 5.52 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Dimensions Extruded side panel 2 U Extruded side panel 3 U Text 05806079 Extruded side panel 4 U, right 05806080 Extruded side panel 4 U, left 05806081 Extruded side panel 6 U 05806082 Dimensions table For case depth D d n mm 266 326 386 446 506 mm 221.6 281.6 341.6 401.6 461.6 mm 210 270 330 390 450 14 18 22 26 30 Note A side panel for case 6 U consists of 2 pieces 3 U extruded side panels Side panel with horizontal rail D 12,25 05806083 SCHROFF.PENTAIR.CO.UK e = D - 62,1 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 05806107 5.53 Desk-top enclosure – i Front panel, unshielded, for mounting on case frame Main Catalogue Delivery comprises Item 1 Qty 1 2 1 Description Full-width front panel, Al, 2 mm (on 84 HP = 2.5 mm), anodised, cut edges plain Assembly kit Order Information 05806063 For case height U 2 2 2 3 3 3 3 4 4 4 6 For case width HP 42 63 84 28 42 63 84 42 63 84 84 A B C D Part no. mm 238.7 345.4 452.0 167.6 238.7 345.4 452.0 238.7 345.4 452.0 452.0 mm 230.0 336.7 443.3 158.9 230.0 336.7 443.3 230.0 336.7 443.3 443.3 mm 74.0 74.0 74.0 118.5 118.5 118.5 118.5 162.9 162.9 162.9 251.8 mm 84.0 84.0 84.0 128.5 128.5 128.5 128.5 172.9 172.9 172.9 261.8 20850-128 20850-129 20850-130 20850-134 20850-135 20850-136 20850-137 20850-142 20850-143 20850-144 20850-158 쮿 EMC front panel see chapter Front Panels, page 7.7 PPA43756 Front panel, 1 U, unshielded, for 4 U case, for mounting on horizontal rails Main Catalogue Delivery comprises Item 1 Qty 1 Description Front panel, Al, 2.5 mm, front anodised, rear iridescent green chromated Order Information Width HP 28 42 63 84 A mm 141.9 213.0 319.7 426.4 B mm 127.0 198.1 304.8 411.5 C mm – 101.6 157.5 203.2 Front panel Part no. 20850-423 20850-424 20850-425 20850-426 Note 05806064 쮿 Please order items 2, 3 and 4 separately Width HP 28 42 63 84 05806065 5.54 SCHROFF PRODUCT CATALOG E 09/2017 Item 2 EMC gasket, front panel/horizontal rail PU 10 pieces Part no. Item 3 EMC gasketing kit horizontal rails, 1 piece Part no. Item 4 Horizontal rail type H-KD, 1 piece (SPQ 10)1) Part no. 24560-229 24560-231 24562-528 24562-542 34560-228 34560-242 24560-233 24562-563 34560-263 24560-235 24562-584 34560-284 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof ELECTRONICS PROTECTION Desk-top enclosure – i Rear panel, perforated, for mounting on horizontal rails 7,2 쮿 Two versions: unshielded, Al, 2.5 mm shieldable, Al extrusion (textile EMC gasketing retrofittable) ø 5,9 x 3,3 3 Delivery comprises Item 1 Qty 1 H 25 3,2 Main Catalogue Z Description Rear panel, Al, 2.5 mm, front: anodised, rear: iridescent green chromated; unshielded or shieldable with EMC sealing (textile) B 7,45 W 3 Order Information 7,45 2,5 01802055 01804050 Unshielded Shieldable 2,5 3,7 3,7 W - 2,58 01802055 Height U 2 2 2 2 3 3 3 3 4 4 4 4 6 6 6 6 쮿 쮿 쮿 쮿 H mm 84 84 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 261.8 261.8 261.8 261.8 Width W HP mm 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 28 141.9 42 213 63 319.7 84 426.4 B mm – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 – 101.6 157.5 208.3 h mm 78 78 78 78 122.4 122.4 122.4 122.4 166.9 166.9 166.9 166.9 255.8 255.8 255.8 255.8 unshielded Part no. shieldable Part no. 30849-007 30849-014 20848-679 20848-680 30849-015 20848-681 30849-016 30849-008 20848-682 20848-633 30849-021 20848-634 30849-022 30849-023 20848-635 20848-636 30849-009 20848-656 30849-028 30849-029 20848-657 20848-658 30849-030 20848-659 30849-010 30849-035 20848-640 20848-641 30849-036 20848-642 30849-037 20848-643 Please order textile EMC gasket separately EMC gasket rear panel - horizontal rail see page 5.65 Horizontal rails see page 5.67 Assembly parts see page 6.63 Textile EMC gasket Main Catalogue 쮿 The textile EMC gasket is glue fixed laterally on the front panel, always in the groove on the right-hand side of the profile 쮿 Temperature range -40 °C ... +70 °C Delivery comprises () Item 1 Qty Description 10/100 Textile EMC gasket, core: foam, sleeve: textile cladding with CuNi coating Order Information 04602054 SCHROFF.PENTAIR.CO.UK Height U 2 3 3 4 6 6 Height mm 52 97 97 142 232 232 Qty/PU pieces 10 100 10 10 100 10 Part no. 21101-857 21101-854 21101-853 21101-858 21101-856 21101-855 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.55 Desk-top enclosure – i Rear panel, unshielded, for mounting on case frame Main Catalogue 쮿 Mounting with support brackets on case (right and left) 쮿 Versions with and without perforation Delivery comprises Item 1 Qty 1 2 3 4 1 Description Full-width rear panel, Al, anodised, cut edges blank 28, 42, 63 HP = 2 mm thickness 84 HP = 2.5 mm thickness Support member, Zn die-cast Assembly kit Order Information 05806066 Height H Width W U 2 2 2 3 3 3 3 4 4 4 6 mm 84 84 84 128.5 128.5 128.5 128.5 172.9 172.9 172.9 261.8 HP 42 63 84 28 42 63 84 42 63 84 84 w mm 213 320 426 142 213 320 426 213 320 426 426 mm 190 298 406 118 190 298 406 190 298 406 406 With perforation Part no. Without perforation Part no. 24576-144 24576-145 24576-044 24576-045 24576-146 24576-046 24576-147 24576-148 24576-047 24576-048 24576-149 24576-049 24576-150 24576-152 24576-050 24576-052 24576-153 24576-053 24576-154 24576-158 24576-054 24576-058 ppa43882 Rear panel, shielded, for mounting on case frame Main Catalogue 쮿 Mounts on case (left, right) 쮿 Without perforation Delivery comprises Item 1 Qty 1 2 2 3 2 4 1 Description Full-width EMC rear panel, Al 1.5 mm, passivated, with GND/earthing connection (Faston 6.3 mm) Textile EMC gasketing, for mounting top and bottom, core: foam, sleeve: textile cladding with CuNi coating Textile EMC gasketing, for mounting left and right, core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information 05806067 5.56 SCHROFF PRODUCT CATALOG E 09/2017 Height U 2 2 3 3 3 3 4 4 4 6 H mm 101.5 101.5 146 146 146 146 190.4 190.4 190.4 279.3 Height h mm 84 84 128.4 128.4 128.4 128.4 172.9 172.9 172.9 261.8 Width W HP mm 42 217.9 63 324.6 28 146.8 42 217.9 63 324.6 84 431.3 42 217.9 63 324.6 84 431.3 84 431.3 w mm 213 319.7 141.9 213 319.7 426.4 213 319.7 426.4 426.4 Part no. 24576-244 24576-245 24576-247 24576-248 24576-249 24576-250 24576-252 24576-253 24576-254 24576-258 ELECTRONICS PROTECTION Desk-top enclosure – i Front panel, hinged, shielded, for mounting on horizontal rails Main Catalogue 쮿 Front panel with textile EMC gasketing 쮿 Hinges can be fitted left or right 쮿 Suitable for europacPRO subrack and ratiopacPRO, compacPRO and propacPRO cases Delivery comprises (kit) 2 1 3 5 05806102 Item 1 Qty 1 2 3 2 1 4 1 Description Front panel, hinged, Al, 2.5 mm, front anodised, rear iridescent green chromated Hinge, Zn die-cast, chrome-plated Textile EMC gasket core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information Height Width H h W w U HP mm mm mm mm 3 84 128.4 89.9 426.4 203.2 6 84 261.8 223.2 426.4 203.2 Item 5, Horizontal rail Type H-VT heavy duty, recessed mounting 84 HP, 1 piece (SPQ 10) Part no. 20848-611 20848-617 34560-784 Note 05806097 쮿 Usable width reduced by 2 HP (hinged side) 쮿 Horizontal rail (item 5) for front panel mounting is required, please order separately 쮿 Lateral trim is necessary, please order separately, see page 5.59 04602081 EMC side panel gasket Main Catalogue 쮿 For EMC shielding between side panel and top cover or base plate (sufficient for at least 1 case) Order Information Item 1 Description Qty/PU Sealing cord, silicone, silver coated, 1 Ø 2.4 mm, length 2.1 m Part no. 30850-354 05806068 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.57 Desk-top enclosure – i Design elements Main Catalogue 쮿 To individualise case design Delivery comprises Qty 1 1 Description Design element, Al extrusion, powder-coated Assembly kit Order Information Description Width Form 1 05809002 HP Light grey RAL 7035 Part no. Brilliant blue RAL 5007 Part no. 42 20850-184 20850-299 63 20850-185 20850-300 84 20850-186 20850-301 42 20850-190 20850-315 63 20850-191 20850-316 84 20850-192 20850-317 42 20850-196 20850-331 63 20850-197 20850-332 84 20850-198 20850-333 PPA43761 Form 2 PPA43762 Form 3 PPA43763 Note 쮿 Size 28 HP and further colours available on request 쮿 Cannot be combined with front hood 5.58 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Trim, front, for EMC shielding Main Catalogue 쮿 For lateral covering of frame and for producing a continuous front with front panels and plug-in units 쮿 Serves for lateral shielding of side panels simultaneously Delivery comprises (kit) Item 1 Qty 2 2 3 1 1 Description Lateral trim, Al extrusion, visible surface painted RAL 7016 Textile EMC gasket Assembly kit Order Information 05806069 For case height U 2 3 4 6 h mm 84 128.5 172.9 261.8 Part no. 24576-017 24576-117 24576-217 24576-417 Trim, rear, for EMC shielding Main Catalogue 쮿 For vertical EMC shielding between shielded front panels and side panel Delivery comprises Item 1 2 3 Qty 2 1 1 Description EMC contact strip, Al extrusion Textile EMC gasket Assembly kit Order Information Height U 2 3 4 6 05806103 SCHROFF.PENTAIR.CO.UK Height mm 65.55 110 154.45 243.35 Part no. 24576-018 24576-118 24576-218 24576-418 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.59 Desk-top enclosure – i Tip-up carrying handle Main Catalogue 쮿 With powder-coated carrying bar 쮿 Can be locked in 30° increments 쮿 Load-carrying capacity 20 kg Delivery comprises (Kit) Item 1 2 Qty 1 2 3 4 2 1 Description Carrying bar, Al extrusion, powder-coated, RAL 7016 Handle side part, Zn, die-cast, powder-coated, length 180 mm Safety insert, St, 1.5 mm, black Assembly kit for side panel mounting Order Information For case width HP 28 42 63 84 Part no. 24576-070 24576-071 24576-072 24576-073 05806101 Note 쮿 To fit the tip-up carrying handle, holes must be drilled in the side panel 쮿 Readily prepared cases (3 U and 4 U), for mounting the tip-up carrying handle see page 5.52 Strap handle Main Catalogue 쮿 Load-carrying capacity: 20 kg Delivery comprises (Kit) Item 1 Qty 1 2 3 2 1 Description Band, spring steel, handle, flexible plastic, grey, RAL 7016 Cover, grey, RAL 7016 Assembly kit Order Information Description Strap handle with adaptor Part no. 20850-249 Note 쮿 Holes must be drilled into the side panels to fix the strap handle 쮿 Side panels with holes already drilled available on request 쮿 Usable from case depth of D = 326 mm 05806098 5.60 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Air filter Main Catalogue 쮿 Subsequent mounting possible without modification or tools 쮿 Filter change without opening the case, IP protection code not affected Delivery comprises (Kit) Item 1 2 3 Qty 1 1 1 Description Filter holder, Al, 1 mm, powder-coated, RAL 9006 Filter mat, synthetic fibre Velcro Order Information For case width Air filter HP Part no. 28 24576-093 42 24576-094 63 24576-095 84 24576-096 Tip-up foot in plastic silver, similar to RAL 9006, 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces 2 3 1 Replacement filter 1 piece Part no. 64571-033 64571-034 64571-035 64571-036 20603-001 20603-002 Note 05806070 SCHROFF.PENTAIR.CO.UK 쮿 For optimum ventilation feet must be fixed to the case, please order separately Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.61 Desk-top enclosure – i Front hood 3 U Main Catalogue 쮿 From acrylic glass, hinged, removable 쮿 Mounting of hinges at top or bottom 쮿 Lock (max. 2) retrofittable 쮿 Lateral cover (item 5) also serves as vertical EMC shielding of side panels Delivery comprises (kit) Item 1 2 3 4 5 Qty 1 2 2 2 2 6 1 Description Hood, PMMA, tinted blue grey, acrylic glass, 3 mm Hinge, PC, UL 94 V-0, RAL 7016 Handle, PC, UL 94 V-0, RAL 7016 Retainer, UL 94 V-0, PC, RAL 7016 Lateral trim, Al extrusion, visible surface painted RAL 7016 Assembly kit Order Information 05806071 16 180 11 ° 14 7,2 3 Lock for front hood 5.62 SCHROFF PRODUCT CATALOG E 09/2017 Part no. 24576-080 24576-081 24576-082 24576-083 60850-171 20603-001 20603-002 Note 1) 1) Front panel For case width HP 28 42 63 84 Lock for front hood Locking cylinder, key, assembly kit, PU 1 kit Plastic tip-up foot silver, similar to RAL 9006, 4 pieces Plastic tip-up foot anthracite, similar to RAL 7016, 4 pieces 05806072 쮿 Cannot be combined with design elements 쮿 Other heights available on request 쮿 Before assembly of hood feet must be fixed to case; please order separately 05806073 ELECTRONICS PROTECTION Desk-top enclosure – i Foot for rear hood iMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Increases the distance between rear panel and parking surface (when used vertically) 쮿 Simplifies cable routing 쮿 Increased shock and vibration damping 쮿 Required for mounting rear hood Delivery comprises Item 1 1 Qty 2 1 Description Foot, PU foam Assembly kit Order Information For cabinet height U 3 4 ppa45113 Height H mm 147.9 192.3 Part no. 24576-393 24576-394 ppa45106 Rear hood Main Catalogue Delivery comprises (kit) Item 1 2 Qty 1 1 Description Hood, Al, 1 mm, RAL 9006, fixing with knurled screws Assembly kit Order Information Height Width A B C D E U HP mm mm mm mm mm 3 42 246 230 213 145.9 64 3 63 352.7 336.7 319.7 145.9 64 3 84 459.4 443.4 426.4 145.9 64 4 63 352.7 336.7 319.7 190.4 108.5 4 84 459.4 443.4 426.4 190.4 108.5 Foot for rear hood for case height 3 U, PU foam, black, PU 2 pieces Foot for rear hood for case height 4 U, PU foam, black, PU 2 pieces Part no. 24576-086 24576-087 24576-088 24576-091 24576-092 24576-393 24576-394 05806075 Note 쮿 To fit the rear hood, feet must be fitted to the rear panel; please order separately 05806076 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.63 Desk-top enclosure – i Mounting plates Order Information Mounting plate for fixing of heavy components Fixing strip for partial widths Mounting plate over full width: mounting is onto the side panels Mounting plate over partial width: mounting is onto one side panel and a fixing strip or onto 2 fixing strips 05812001 06102501 Al, 1.5 mm; for mounting over partial width, please order fixing strips separately Width W W Board lengths HP mm mm 42 217.99 160 42 217.99 220 63 324.67 160 63 324.67 220 84 431.35 160 84 431.35 220 84 431.35 340 Assembly kit for mounting plate, PU 1 kit (Torx countersunk screw M4 x 5, St, zinc-plated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for fixing strips for partial width mounting plates, Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces M2.5 × 5, St, zinc-plated, PU 100 pieces 05806100 St, 2 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates 1 piece 1 piece 34562-746 30840-021 34562-750 34562-747 30840-033 30840-021 34562-751 30840-033 34562-748 34562-752 30840-021 30840-033 34562-760 30840-057 24560-184 – – 24560-146 Note 쮿 쮿 쮿 쮿 Please order assembly kit for mounting plate separately Fixing strips required for partial width, please order separately Other versions on request Dimensions side panel with horizontal rail see page 5.53 06103057 propacPRO: D = board length - 47.5 mm; n = 1 for 160 mm board length; n = 2 for 220 mm board length; n=4 for 340 mm board length 5.64 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i EMC gasket, stainless steel, between front/rear panel and horizontal rail Main Catalogue 쮿 The EMC contact strip is clipped onto the horizontal rail and forms a conductive link to front or rear panel 쮿 Can be used for front/rear horizontal rails type VT (recessed) Delivery comprises Item 1 Qty 10/100 Description EMC gasket, St, stainless Order Information 05806109 Width HP 28 42 63 84 84 Length mm 131.78 202.9 304.5 416.56 416.56 Qty/PU pieces 10 10 10 10 100 Part no. 24560-229 24560-231 24560-233 24560-235 24560-236 GND/earthing kit Main Catalogue 쮿 Protective GND/earthing connections in accordance with: – DIN EN 50178/VDE 0160 – DIN EN 60950/VDE 0805 – DIN EN 61010-1/VDE 0411 part 1 – DIN EN 61010-1A2/VDE 0411 part 1A1 쮿 VDE tested Order Information Description GND/earthing kit, Cu wire 1.5 mm 2, PVC sleeve, green/ yellow, links side panels, base and rear panel, 1 piece Part no. 21102-001 aza43284 Cable holder Main Catalogue Delivery comprises 02908053 Qty 2 2 1 3 1 Part no. 24575-800 26,5 9 Description Cable holder, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drill holes each per holder are needed in rear panel Assembly kit Order Information Description Cable holder 46 19 Item 1 14 17 Ø3 Ø4 ,4 Ø3 Ø 4,4 20,2 02908052 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.65 Desk-top enclosure – i Mounting position horizontal/central rails 2U Text H - VT H - VT H - VT H - VT 05806084 3U H - VT H-VT H-ST H-KD H-MZ H - VT ST H - ST H - VT H - MZ H - VT H - VT 05806085 4 U (3 + 1) 05809050 "Z" (EMC shielding with 2 horizontal rails) H - VT H - VT H - ST H - VT H - MZ 2 x H - KD H - VT H - VT 05806086 6U 06106051 6 U (2 x 3) H - VT H - VT H - VT H - VT H - ST H - VT H - MZ H - ST H - VT H - MZ “Z” “Z” 2 x H - KD ST H - ST H - VT H - MZ H - ST H - VT H - MZ H - VT H - VT H - VT 05806087 5.66 SCHROFF PRODUCT CATALOG E 09/2017 H - ST H - VT H - MZ H - VT 05806088 ELECTRONICS PROTECTION Desk-top enclosure – i Horizontal rails to front/centre/rear Main Catalogue Order Information For indiect backplane fixing with insulation strip 04400001 "heavy" Type H-ST standard 06197011 Al extrusion, anodised finish, conductive surface, with printed HP markings For direct backplane fixing For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) 04400002 "heavy" Type H-VT long lip Stainless steel Horizontal rail EMC gasket type H-VT robust, with EMC gasket between horizontal rail and horizontal rail 04400003 "heavy" Type H-MZ with Z-rail 06197013 Al extrusion, anodised finish, conductive surface, with printed HP markings Front horizontal rails 06197015 Al extrusion, anodised finish, conductive surface, with printed HP markings 06106052 bza45877 "heavy" Type H-KD short lip 06197008 Al extrusion, anodised finish, conductive surface, with printed HP markings Usable length Length HP mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 28 147.32 34560-528 34560-728 34560-928 34560-228 42 218.44 34560-542 34560-742 34560-942 34560-242 63 325.12 34560-563 34560-763 34560-963 34560-263 84 431.80 34560-584 34560-784 34560-984 34560-284 Torx panhead screw , M4 × 14, 24571-371 24571-371 24571-371 24571-371 St, zinc-plated, PU 100 pieces Torx panhead screw , M 4 × 10, St, zinc-plated, necessary if – – 24571-372 24571-372 guide rail is screwed to slot 1, PU 100 pieces Perforated rail for connector mounting with insulation strip 5.69 – – – see page Z-rail for connector mounting 5.69 – – – without insulation strip see page Insulation strips see page – 5.68 – – Threaded inserts see page 5.68 5.68 5.68 5.68 item 1: metal strip, Al, 1 mm, item 2: EMC stainless steel gasket; for shielding of 2 horizontal rails positioned directly one above the other if assembly area is divided vertically horizontal rail: Al extrusion, anodised, conductive contact surface for cover plates on shielded cases PU 1 kit 1 piece 24562-528 24576-028 24562-542 24576-042 24562-563 24562-584 24576-063 24576-084 – 24571-371 – 24571-372 – – – – – – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Note 쮿 Further horizontal rails see from page 6.27 쮿 Fitting options see page 5.66 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.67 Desk-top enclosure – i Horizontal rails, centre, type ST-C Main Catalogue 쮿 For indirect backplane mounting (with insulation strip) 쮿 For 6 U propacPRO case Delivery comprises (kit, item 1 to 4 are pre-mounted) Item Qty 1 1 2 3 4 5 2 2 2 4 Description Horizontal rail, Al extrusion, anodised, contact surfaces conductive Adaptor plate, Al Threaded insert, M2.5, St, zinc-plated Countersunk screw, M4 x 14 Pan head screw, M4 x 6 Order Information Usable width Length HP mm 84 431.8 Insulation strip 84 HP, PBT UL 94 V-0, grey, PU 10 pieces Part no. 24575-474 24560-884 05806089 Threaded inserts, perforated strips, insulation strips Order Information Threaded insert M2.5 M3 Perforated strip (item 1) Insulation strip 5 2 5 ,0 8 06103056 required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.64 BZA45853 BZ6749 for centring shielded plug-in units, Al, 1 mm, please order grub screw separately for insulated backplane mounting; PBT UL 94 V-0, grey Threaded insert Perforated strip Insulation strip Usable length Length Length Length HP mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm 1 piece (SPQ 10)1) mm PU 10 pieces 28 146.82 – 147.12 144.20 34561-328 30845-197 24560-828 42 217.94 – 218.24 210.40 34561-342 30845-211 24560-842 63 324.62 34561-363 – 324.92 30845-232 316.88 24560-863 84 431.30 431.60 428.64 34561-384 34561-484 30845-253 24560-884 Accessories Grub screw M2.5 x 8, – – – 21100-276 PU 100 pieces Grub screw M2.5 x 9, – – 21101-359 – PU 100 pieces Grub screw M3 x 8, PU 100 pieces – – – 21100-646 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU 5.68 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Z-rails, perforated rails Order Information Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 75 12, 5 9 ,7 BZA45850 BZA45848 75 12, 3 ,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Item 3, Torx panhead screw to fix connector to perforated rail,, M2.5 × 7, PU 100 pieces Item 2, Torx panhead screw, to fix perforated rail to horizontal rail, M2.5 × 10, PU 100 pieces SCHROFF.PENTAIR.CO.UK 06708051 for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on VT horizontal rails, please order threaded insert and screw separately 1 piece 1 piece – – PU 4 pieces 30822-033 20822-049 30822-047 30822-065 30819-783 20822-050 20822-047 30822-089 30819-808 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.69 Desk-top enclosure – i Combined mounting (6 U and 2 x 3 U one above the other) Order Information Combined mounting Horizontal and Unshielded Front panel for vertical subdivision front panel, 6 U, 2 HP textile EMC gasket, (incl. front panel for 6 U, 2 HP item 5 stainless steel EMC gasket) item 5 bza45819 05806108 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Torx countersunk screw M4 × 14, zinc-plated, PU 100 pieces for fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces for fixing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces 06102501 Splitting extrusion for combined mounting item 2 06102501 06102501 item 1: 2 front horizontal rails (H-KD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zinc-plated; item 4: Zn die-cast support member; item 5: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket; 84:0 without items 4, 5 Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, Zn die-cast; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 (SPQ 5) 1 piece (SPQ 5)1) 1 piece 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 – 24562-420 24562-440 24562-442 24562-463 24562-484 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accept euroboards (100 mm high) and double euroboards (233.35 mm high) Note 쮿 Please order EMC gasketing kit for horizontal rails separately, see page 6.54 쮿 Please order perforated strips for horizontal rails separately, see page 5.68 쮿 Please order rear centre horizontal rail separately, see page 5.68 5.70 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Horizontal board mounting Order Information Horizontal board mounting Front frame for EMC gasketing Board cage Front frame, unshielded 27 3.9 8= 54 TE 05806091 05806092 (1 TE = 1 HP, 1 HE = 1 U) Other dimensions and options ,98 =5 4T E bpa45913 bza43061 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 HP space required; please order front frame for EMC gasketing separately 2 horizontal trims, AI 2.5 mm, front anodised, rear iridescent green chromated; 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the sub-assemblies Al, 2.5 mm, clear anodised; front frame with cut-out, clear internal width w = 266.35 mm PU 1 kit PU 1 kit 1 piece Height H U Usable height h HP 3 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Assembly tool, for mounting the EMC gasket (stainless steel) Horizontal rail, rear H 273 h w * For direct backplane mounting SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.71 Desk-top enclosure – i Plastic tip-up feet Main Catalogue 쮿 Static load-carrying capacity 25 kg per foot 쮿 Tip-up feet can be used instead of the pre-mounted case feet 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description 05806093 Part no. anthracite, similar to Plastic tip-up foot RAL 7016, 4 pieces silver, similar to Plastic tip-up foot RAL 9006, 4 pieces Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces 20603-002 20603-001 21101-211 21100-211 21100-207 02906050 Tip-up feet made of die-cast aluminium 쮿 Can be used instead of the round standard feet 쮿 Fixing holes provided in bottom of case 쮿 Secure case stance with slip-proof rubber inserts 쮿 Load carrying capacity: 50 kg per foot, max. case weight 40 kg Order Information 41 20 Ø3,1 15,5 Ø4,6 15 16,6 1 AZA43836 Description Qty Foot with tip-up, 1 piece (SPQ 10)1) Al die-cast, silver Foot without tip-up, 1 piece (SPQ 10)1) Al die-cast, silver Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-002 10603-001 21101-211 21100-211 21100-207 1) Part no. comprises 1 piece; delivery is in standard pack quantity (SPQ): please order a minimum of 10 feet or a multiple Ø7,8 Note 20 쮿 Delivery is in standard pack multiples; pricing is per individual item 02908051 5.72 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Guide rails for plug-in units and frame type plug-in units, one-piece, groove width 2 mm Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Standard For plug-in units and frame type plug-in units With DIN connector fixing as standard Storage temperature from -40 °C ... 130 °C 06102001 06101501 up to 220 mm length, PBT, UL 94 V-0; multi-piece from 280 mm length, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards, 100 x 160 mm or 100 x 220 mm only PU 10 pieces – – 1 pair (SPQ 10)1) – – 24560-351 64560-074 24560-353 64560-075 24560-379 24560-380 6.40 – – 6.40 Retention screw, PU 100 pieces 24560-141 24560-141 ESD clip, PU 50 pieces description see page 6.41 24560-255 24560-255 Board Groove Colour lengths width mm mm mm 70 2 red 70 2 grey 160 2 red 220 2 red 280 2 red 340 2 red Dimension drawings see page Accessories 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.73 Desk-top enclosure – i Guide rails type "accessories", one-piece, groove width 2 mm and 2.5 mm Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plates Guide rails "Accessories" Guide rails "Accessories" strengthened Guide rails for heavy modules, Al extrusion, silver, robust version storage temperature from -40 °C ... +130 °C 06102002 Board lengths mm 100 160 160 220 220 Groove width mm 2 2 2 2 2 06102005 06102005 up to 280 mm length, PBT, UL 94 V-0; multi-piece from 280 mm length, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94 V-0, red support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces – 1 piece (SPQ 50) – 24560-373 Colour mm red red grey red grey red/ 280 2 silver red/ 340 2 silver 400 2 silver 160 2.5 silver 220 2.5 silver 280 2.5 silver 340 2.5 silver 400 2.5 silver Dimension drawings see page 64560-076 1 piece (SPQ 50)1) – – – – 34562-881 24560-374 64560-078 – – – 34562-882 24560-375 64560-080 34562-883 24560-376 – 34562-884 – – – – – 6.40 – – – – – – 6.40 34562-885 34564-881 24560-141 24560-141 24560-157 24560-255 24560-255 – 24560-377 24560-377 – 24560-378 24560-378 – 60817-228 60817-228 – 6.41 6.41 – 34564-882 34564-883 34564-884 34564-885 6.40 Accessories Retention screw, PU 100 pieces ESD clip, PU 50 pieces description see page 6.41 Board locking C, red, PU 10 pieces, description see page 6.41 Board handle C, red, PU 10 pieces, description see page 6.41 Identification strips for board handle, red, PU 1 sheet = 438 pieces, description see page 6.41 Coding see page 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 5.74 SCHROFF PRODUCT CATALOG E 09/2017 ELECTRONICS PROTECTION Desk-top enclosure – i Divider plate Order Information Divider plate Mounting position when stainless steel Mounting position when EMC gasket is used textile EMC gasket is used front rear front rear bpa45911 06105078 Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space requirement on component side 2 mm; mounting direction varies with shielding design (EMC stainless steel or textile gasket); retrofitting the divider plate in an already-assembled subrack/case will first require dismantling of the horizontal rails; where front panels are unshielded, both mounting directions are possible bpa45912 Height U 3 3 6 6 Depth mm 160 220 160 220 A mm 158.3 218.3 158.3 218.3 B mm 135.0 195.0 135.0 195.0 H mm 113.5 113.5 246.9 246.9 PU 10 pieces 34562-761 34562-762 34562-763 34562-764 Air baffle for slots Order Information Air baffle without front panel Air baffle with front panel U front panel for textile EMC gasket 06108085 Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06108088 Air deflector, Al, 1 mm, front panel, Al extrusion, 2.5 mm, front anodised, rear conductive; EMC textile gasket, fixing materials kit prevents an air short-circuit where slots are unoccupied; is pushed into the groove of the guide rails 06101507 Depth mm 160 160 160 160 160 160 220 220 220 220 220 220 Width HP 4 4 8 8 12 12 4 4 8 8 12 12 SCHROFF.PENTAIR.CO.UK Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 1 piece 34562-823 20848-728 34562-826 20848-736 34562-833 34562-836 20848-730 20848-738 34562-843 20848-732 34562-846 34562-824 20848-740 20848-729 34562-827 20848-737 34562-834 34562-837 20848-731 20848-739 34562-844 20848-733 34562-847 20848-741 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.75 bMain Catalogue Desk-top cases – b Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 02004009 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Flexible expansion options, for 19" components e.g. plug-in unit units, or for individual expansion 02004079 Standards 쮿 Interior dimensions in accordance with: IEC 60297-3-101 쮿 Type of protection IP 20 in accordance with IEC 60529 Connectors, front panel component system . . . . . . . 11 쮿 GND/earth connections in accordance with: DIN EN 50178 / VDE 0160 DIN EN 60950 / VDE 0805 DIN EN 61010-1 / VDE 0411 part 1 DIN EN 61010-1A2 / VDE 0411 part 1/A12 Appendix . . . . . 12 5.76 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Overview . . . 5.76 bMain Catalogue Robust desk-top case for 19" components in accordance with IEC 60297-3-10x or for individual electronics assemblies 쮿 Front and rear identical, depth-symmetrical construction 쮿 Highly robust thanks to die-cast frame (front/rear) 쮿 Side panel with integrated handle function Desk-top cases compacPRO 쮿 Complete case – Pre-configured case, prepared for 19" components – Case height 3 U and 6 U Complete cases 3, 6 U . . . . . . . . . . 5.78 Cases 2, 3, 4 U . . 5.79 6 U cases . . . . . . . 5.80 Accessories Filler angle . . . . . 5.81 Cable holder . . . . 5.81 쮿 Case – Case height 2 U, 3 U, 4 U and 6 U Front panel/rear panel . . . . . . . . . . 5.82 Rear feet . . . . . . . 5.83 Edge protection. 5.83 Hood . . . . . . . . . . 5.84 Front door . . . . . 5.85 Handle . . . . . . . . 5.86 GND/earthing . . . 5.86 Feet . . . . . . . . . . 5.87 Horizontal rail . 02009005 02004006 5.88 Threaded inserts 5.90 Extensive accessory range Guide rails and ESD clips . . . . . . . 5.92 Mounting plates . 5.94 Combined mounting . . . . . . 5.95 Horizontal board assembly . . . . . . 5.96 Air flow barrier . . 5.97 Dimensions . . . . . 5.98 02004002 ServicePLUS . . 5.4 ServicePLUS from page 5.4 e.g. modifications (special colours, special depths, outs in top cover, base plate or side panels) e.g. assembly service from 1 piece cut- www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 5.77 Desk-top cases – b Complete cases 3 and 6 U bMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 Desk-top case with pre-configured components in accordance with IEC 60297-3-101; prepared for 19" components such as plug-in units and euroboards 쮿 For backplane mounting with insulation strips 쮿 Ventilation slots in base plate 쮿 Ventilation slots in rear panel Delivery comprises (Kit, items 1, 2, 6, 8 fitted) Item 1 2 3 Qty 3U 2 2 1 6U 4 2 1 Description 4 1 1 5 6 4 2 4 7 8 2 2 2 2 9 2 2 10 - 1 11 1 1 12 10/ 20 1 1 10/ 20 1 1 02009005 20 20 5 h H D w W 02004054 13 14 3 Side panel, Al extrusion, powder-coated, RAL 7016 Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Side plate powder-coated, RAL 9006, Al, 0.8 mm Tip-up foot with anti-slip protection, PA, RAL 7016, UL 94 V-0 Cover bracket, Al extrusion, anodised, cut edges plain Horizontal rail, Al extrusion, with threaded insert, St, M2.5 Rear horizontal rail, Al extrusion, with threaded insert, St, M2.5 and insulation strip, PBT, UL 94 V-0 (for indirect backplane mounting) Centre horizontal rail, Al extrusion, anodised, conductive surfaces, with two threaded inserts, St, M2.5 and two insulation strips, PBT, UL 94 V-0 Rear panel with 1 row of ventilation slots, Al, anodised, 2 mm for 28, 42 and 63 HP, 2.5 mm for 84 HP Guide rail for 160 mm board length, PBT, UL 94 V-0, 28/42 HP 10 pieces, 63/84 HP 20 pieces GND/earthing kit Assembly kit, also allows the fitting of a full-width front panel Order Information 9 Height H Usable width Part no. w w U mm mm HP mm 3 186 271 28 148 14575-114 3 186 331 28 148 14575-115 3 257 271 42 219 14575-134 3 257 331 42 219 14575-135 3 257 391 42 219 14575-136 3 364 271 63 326 14575-154 3 364 331 63 326 14575-155 3 364 391 63 326 14575-156 3 471 271 84 432 14575-174 3 471 331 84 432 14575-175 3 471 391 84 432 14575-176 3 471 511 84 432 14575-178 6 471 391 84 432 14575-476 6 471 451 84 432 14575-477 Maximum mounting depth = D - 21 (open space: front panel - rear panel) 1 10 2 11 5 12 8 4 7 6 02008050 Width W Depth D Note 쮿 Dimensions of case, side panel see from page 5.98 ServicePLUS see page 5.4 5.78 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Cases 2, 3 and 4 U b 쮿 Desk-top case, pre-configures, for individual assembly 쮿 For backplane mounting with insulation strips 쮿 Ventilation slots in base plate Delivery comprises (Kit, items 1 and 2 fitted) Item 1 2 3 Qty 2 2 1 4 1 5 6 7 4 8 1 02004005 Description Side panel, Al extrusion, powder-coated, RAL 7016 Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing connection Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated RAL 9006, with earthing connection Case foot with anti-slip protection, PC, black Fixing adaptor for cover plate, prefitted Assembly kit, also allows the fitting of a full-width front panel, two cover brackets or a rear panel Order Information 20 20 5 h H D w W 02004054 3 2 1 Height Usable width U HP 2 42 2 42 2 42 2 84 2 84 2 84 3 28 3 28 3 42 3 42 3 42 3 63 3 63 3 63 3 84 3 84 3 84 3 84 3 84 4 42 4 42 4 63 4 63 4 63 4 84 4 84 4 84 4 84 Width W mm 257 257 257 471 471 471 186 186 257 257 257 364 364 364 471 471 471 471 471 257 257 364 364 364 471 471 471 471 Width w mm 219 219 219 432 432 432 148 148 219 219 219 326 326 326 432 432 432 432 432 219 219 326 326 326 432 432 432 432 Height H mm 102.6 102.6 102.6 102.6 102.6 102.6 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 147.1 191.6 191.6 191.6 191.6 191.6 191.6 191.6 191.6 191.6 Height h mm 84.4 84.4 84.4 84.4 84.4 84.4 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 129.3 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 173.8 Depth D mm 271 331 391 271 331 391 271 331 271 331 391 271 331 391 271 331 391 451 511 271 331 271 331 391 331 391 451 511 Part no. 14575-023 14575-025 14575-027 14575-063 14575-065 14575-067 14575-103 14575-105 14575-123 14575-125 14575-127 14575-143 14575-145 14575-147 14575-163 14575-165 14575-167 14575-169 14575-171 14575-223 14575-225 14575-243 14575-245 14575-247 14575-265 14575-267 14575-269 14575-271 6 4 5 02004053 ServicePLUS see page 5.4 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.79 Desk-top cases – b 6 U cases b 쮿 Desk-top case, pre-configured, for individual assembly 쮿 For backplane mounting with insulation strips 쮿 Ventilation slots in base plate Delivery comprises (Kit items 1, 2 and 5 fitted) 02004006 Item 1 Qty 4 2 3 2 1 4 1 5 6 7 8 2 4 8 1 Description Side panel parts, Al extrusion, powder-coated, RAL 7016, 2 x 3 U Frame, Al die-cast, powder-coated, RAL 7016 Cover plate, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Base plate with 4 rows of ventilation slots, Al, 1.5 mm, powder-coated, RAL 9006, with GND/earthing tag Side plate, Al, 0.8 mm, powder-coated, RAL 9006 Case foot with anti-slip protection, PC, black Fixing adaptor for cover plate, prefitted Assembly kit also allows the fitting of a full-width front panel, two cover brackets or a rear panel Order Information Usable width Width W Width w Height H HP mm mm mm 63 364 326 280.5 63 364 326 280.5 84 471 432 280.5 84 471 432 280.5 84 471 432 280.5 84 471 432 280.5 84 471 432 280.5 3 2 1 Height h mm 262.9 262.9 262.9 262.9 262.9 262.9 262.9 Depth D mm 331 391 271 331 391 451 511 Part no. 14575-445 14575-447 14575-463 14575-465 14575-467 14575-469 14575-471 5 7 4 6 02004055 20 20 5 h H D w W 02004056 ServicePLUS see page 5.4 5.80 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Filler angle b 쮿 To cover the sides of the frame and to create a continuous front plane with plug-in units and partial-width front panels 쮿 This filler angle is recommended when fitting horizontal rails Delivery comprises Item 1 Qty 2 Description Filler angle, Al extrusion, anodised, cut edges plain Order Information 02005002 Height U 2 3 4 6 Part no. 24575-019 24575-119 24575-219 24575-419 Note 쮿 Fixing material is supplied with case 02004062 Cable holder Access ori esI/B Delivery comprises (kit) Item 1 Qty 2 2 1 3 1 Description Cable bracket, ABS, UL V-94 0, RAL 7016, detent for cables between 8 mm and 12 mm Drilling template, two drill holes each per bracket are needed in rear panel Assembly kit Order Information 02908053 46 Part no. 24575-800 9 26,5 19 Description Cable holder 14 17 Ø3 Ø4 ,4 Ø3 Ø 4,4 20,2 02908052 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.81 Desk-top cases – b Front panel and rear panel b 쮿 Front panels and rear panels are screwed on front or rear frame of case Delivery comprises (kit) Item 1 Qty 1 2 1 Description Rear panel with 4 rows of ventilation slots, AI, anodised, cut edges plain; 28, 42, 63 HP = 2 mm thick; 84 HP = 2.5 mm thick Front panel, Al, anodised, cut edges plain, 3 mm thick Order Information Height Width Height Height Width H h B U HP mm mm mm 2 42 84 66 238.7 2 84 84 66 452.1 3 28 128.4 100 167.5 3 42 128.4 100 238.7 3 63 128.4 100 345.4 3 84 128.4 100 452.1 4 42 172.9 144.5 238.7 4 63 172.9 144.5 345.4 4 84 172.9 144.5 452.1 6 63 261.8 233.4 345.4 6 84 261.8 233.4 452.1 02005001 Rear panel/front panel Rear panel Front panel b mm 226.3 439.7 155.1 226.3 333.1 439.7 226.3 333.1 439.7 333.1 439.7 Part no. Part no. 30823-015 30823-209 30823-512 30823-215 30823-021 30823-254 30823-024 30823-257 30823-027 30823-224 30823-515 30823-260 30823-033 30823-269 30823-036 30823-227 30823-518 30823-272 30823-045 30823-230 30823-521 30823-284 Note CPA30656 쮿 Assembly kit to fix one rear and one front panel is included with the case 쮿 Cable holder and rear feet, see from page 5.81 Front panel/rear panel with hidden fixing b Delivery comprises (kit) Item Qty 1 1 2 4 Description Front panel, Al, anodised, cut edges plain, 2.5 mm Fixing bracket Order Information Height U 2 2 3 3 3 3 4 4 4 6 6 Width HP 42 84 28 42 63 84 42 63 84 63 84 Height H Height h Width B mm mm mm 84.0 66.0 238.7 84.0 66.0 452.1 128.4 100.0 167.5 128.4 100.0 238.7 128.4 100.0 345.4 128.4 100.0 452.1 172.9 144.5 238.7 172.9 144.5 345.4 172.9 144.5 452.1 261.8 233.4 345.4 261.8 233.4 452.1 Part no. b mm 226.3 439.7 155.1 226.3 333.1 439.7 226.3 333.1 439.7 333.1 439.7 24575-035 24575-075 24575-115 24575-135 24575-155 24575-175 24575-235 24575-255 24575-275 24575-455 24575-475 Note 02004061 5.82 SCHROFF PRODUCT CATALOG E 10/2017 쮿 Cable holder and rear feet see from page 5.81 ELECTRONICS PROTECTION Desk-top cases – b Rear foot with rubber insert b Delivery comprises Item 1 2 Qty 2 1 Description Foot with rubber insert, PC, UL 94 V-0, RAL 7016 Fixing material Order Information For case height U 3 4 A mm 139 183.5 Part no. 24575-114 24575-214 02005004 A ø 4.2 23 8.5 16.5 02004063 Edge protection/rear foot b Delivery comprises Item 1 2 Qty 2 1 Description Edge protection, PU foam, black Assembly kit Order Information For case height U 3 4 A mm 159.1 203.6 B mm 114.0 159.0 C mm 100.0 144.5 Part no. 20823-675 20823-676 20,2 A B C Ø8 Ø 4,5 02005005 A A 5 27 27,5 35 SCHROFF.PENTAIR.CO.UK A-A 02908054 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.83 Desk-top cases – b Rear foot for hood b Delivery comprises Item 1 2 Description Foot, PU foam, black, 75° shore Fixing material Order Information D B A M6 Qty 2 1 Height U 3 4 M6 45 30 02004065 A mm 133.5 177.8 B mm 95 139.5 D mm 65 95 Part no. 20823-668 20823-669 쮿 Rear panel, see page 5.82 B Dimensions for modifying the rear panel 27.55 8 x 6.1 02004066 Hood b Delivery comprises Item 1 Qty 1 2 1 Description Hood, ABS, RAL 7016, wall thickness < 4 mm, fixing with knurled screws Assembly kit Order Information Height Width A U HP mm 3 42 267 3 63 373.5 3 84 480 Cable support PC, black, UL 94 V-0, PU 2 pieces 02005006 56 ø 5.5 41.6 41.6 A 10 24575-136 24575-156 24575-176 20823-674 Note 쮿 Cable support can only be fitted in conjunction with rear foot for hood 쮿 To fit the hood, the rear panel and the rear foot for hood must be mounted on the case 쮿 Rear panel, see page 5.82 쮿 Rear foot for hood see page 5.84 10° 156.5 4 Part no. 61.5 02004064 Cable support A4-512 5.84 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Front door, acrylic glass, hinged b 쮿 Assembly of the hinge to top or bottom 쮿 With snap-on latch 쮿 Lock retrofittable Delivery comprises (kit) Item 1 2 3 4 5 Qty 2 1 1 2 1 Description Side part, Al die-cast, powder-coated, RAL 7016 Front door, PMMA, tinted blue-grey, acrylic glass, 3 mm Snap-on latch, PC, UL 94 V-0, black Spacer plate, Al, 3 mm, passivated Assembly kit Order Information 02005003 Height Width U HP 3 42 3 63 3 84 Lock for front door cylinder, 2 keys, assembly parts Part no. 24575-137 24575-157 24575-177 21100-647 Dimensions table Height U 3 3 3 b TE 42 63 84 H mm 139,50 139,50 139,50 h mm 128,40 128,40 128,40 B mm 229,60 336,40 443,00 02004069 Front door, hinged a4-2265 1) Front panel SCHROFF.PENTAIR.CO.UK a4-225 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.85 Desk-top cases – b Tip-up carrying handle b 쮿 With powder-coated handle bar 쮿 Handle bar adjustable in 30 degree increments by pressing button 쮿 Load-carrying capacity 20 kg Delivery comprises (kit) Item 1 2 Qty 1 2 3 4 2 1 Description Carrying bar, AI profile, powder-coated, RAL 7016 Lateral section of handle, Zn die-cast, powder coated, length 180 mm Safety insert, St, 1.5 mm, black Fixing material incl. drilling template for side panel Order Information 02004002 a 68.5 b 180 c For case height U 2 2 3, 4 3, 4 3, 4 3, 4 Width HP 42 84 28 42 63 84 Part no. 24575-038 24575-078 24575-118 24575-138 24575-158 24575-178 Dimensions Case width HP 28 42 63 84 4x a mm 249.32 320.44 427.12 533.80 b mm 180.32 251.44 358.12 464.80 c mm 202.72 273.84 380.52 487,20 30° 4x 30° 02004080 GND/earthing kit Main Catalogue 쮿 Protective GND/earth connections in accordance with DIN EN 50178/VDE 0160, DIN EN 60950/VDE 0805, DIN EN 61010-1/VDE 0411 part 1, DIN EN 61010-1A2 /VDE 0411 part 1/A1 VDE inpection requested Order Information Description GND/earthing kit, CU wire 1.5 mm 2, PVC covered, green/yellow, links side panel, base plate, cover and rear panel Qty/PU 1 Part no. 24575-801 aza43284 5.86 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Plastic tip-up feet 쮿 Static load-carrying capacity 25 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 01802075 02006050 Al die-cast tip-up foot 쮿 Static load-carrying capacity 50 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Order Information 15,5 Ø4,6 Part no. 10603-001 10603-002 21101-211 21100-211 21100-207 1) Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 15 16,6 1 AZA43836 41 20 Ø3,1 Description Qty Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Accessories Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces 20 Ø7,8 02908051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.87 Desk-top cases – b Mounting position horizontal/central rail Case, 2 U Case, 3 U + 4 U Text H-VT H-VT H-VT H-ST / H-VT / H-MZ H-ST / H-VT / H-MZ H-VT H-VT H-VT H-VT H-VT 02004073 Case, 6 U 02004074 Case 2 x 3 U (6 U) H-VT H-VT H-VT H-VT H-ST / H-VT / H-MZ ST-C H-KD H-ST / H-VT / H-MZ H-ST / H-VT / H-MZ H-VT H-VT H-VT 02004076 H-VT 02004077 Horizontal rails H-ST H-VT H-MZ 02004078 5.88 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Horizontal rails to front/centre/rear Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 "heavy" Type H-ST standard 04400002 "heavy" Type H-VT long lip 06197011 Usable length Length HP mm 28 147.32 42 218.44 63 325.12 84 431.80 Torx countersunk screw, , M4 × 14, St, zinc-plated, PU 100 pieces Torx countersunk screw, , M4 × 10, St, zinc-plated, required if guide rail is screwed to slot 1, PU 100 pieces Z-rail for connector mounting without insulation strip see page Insulation strips see page Threaded inserts see page For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) Front horizontal rails 04400003 "heavy" Type H-MZ with Z-rail 06197013 "heavy" Type H-KD short lip 06197015 06197008 Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34560-528 34560-728 34560-928 34560-228 34560-542 34560-563 34560-742 34560-763 34560-942 34560-963 34560-242 34560-263 34560-584 34560-784 34560-984 34560-284 24571-371 24571-371 24571-371 24571-371 – – 24571-372 24571-372 5.91 – – – – 5.90 5.90 5.90 – 5.90 – 5.90 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof Note 쮿 Further horizontal rails, see from page 6.27 쮿 Fitting options, see page 5.88 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.89 Desk-top cases – b Horizontal rail, centre, type ST-C b 쮿 For indirect backplane mounting (with insulation strip) 쮿 For 6 U compacPRO case Delivery comprises (Kit, items 1 to 4 are pre-mounted) Item Qty 1 1 2 3 4 5 1 3 Description Horizontal rail, Al extrusion, anodised, contact surfaces conductive Adaptor plate, Al Threaded insert, M2.5, St, zinc-plated Countersunk screw, M4 x 14 Panhead screw, M4 x 6 2 2 2 4 2 Order Information 4 Usable width HP 63 84 Length mm 325.1 431.8 Part no. 24575-454 24575-474 5 02005050 Threaded inserts, perforated strips, insulation strips Order Information Threaded insert Insulation strip M2.5 M3 5 2 5,0 8 06103056 required for fixing the front panel to the horizontal rail; St, zinc-plated; Use collar screw 12.3 mm, see page 6.64 BZ6749 for insulated mounting of backplane; PBT UL 94 V-0, grey Threaded insert Insulation strip Usable length Length Length HP mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm PU 10 pieces 28 146.82 34561-328 – 144.20 24560-828 42 217.94 – 210.40 34561-342 24560-842 63 324.62 – 316.88 34561-363 24560-863 84 431.30 34561-384 34561-484 428.64 24560-884 Accessories Grub screw M2.5 x 8, PU 100 pieces – – 21100-276 Grub screw M3 x 8, PU 100 pieces – 21100-646 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU 5.90 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Z-rails, perforated rails Order Information Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 12,7 5 9,7 BZA45850 BZA45848 5 75 12, 3,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 28 142.24 42 213.36 60 304.80 84 426.70 Item 3, Torx panhead screw to fix connector to perforated rail,, M2.5 × 7, PU 100 pieces Item 2, Torx panhead screw, to fix perforated rails to horizontal rail, M2.5 × 10, PU 100 pieces SCHROFF.PENTAIR.CO.UK 06708051 for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on ST horizontal rails, please order threaded insert and screw separately for connector mounting on VT horizontal rails, please order threaded insert and screw separately 1 piece 1 piece – – PU 4 pieces 30822-033 20822-049 30822-047 30822-065 30819-783 20822-050 20822-047 30822-089 30819-808 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.91 Desk-top cases – b Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates standard For plug-in units and frame type plug-in units standard, with DIN connector fixing Storage temperature from -40 °C ... 130 °C 06102002 06101501 up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards, 100 x 160 mm or 100 x 220 mm only PU 10 pieces – – 1 pair (SPQ 10)1) – – 24560-351 64560-074 24560-353 64560-075 24560-379 24560-380 – – 6.40 – – – – 6.40 Retention screw, PU 100 pieces 24560-141 24560-141 ESD clip, PU 50 pieces 24560-255 24560-255 Board Groove Colour length width mm mm mm 70 2 red 70 2 grey 160 2 red 220 2 red 280 2 red 340 2 red 160 2.5 red 220 2.5 red Dimension drawings see page Accessories 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.41 5.92 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Guide rails type "accessory", one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plate Guide rails type accessory, strengthened accessory for heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... +130 °C 06102002 Board length mm 100 160 160 220 220 Groove width mm 2 2 2 2 2 bza46554 06102005 up to 280 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94V-0, middle section Al extrusion PBT UL 94 V?0, red support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces – 1 piece (SPQ 50) – 24560-373 Colour mm red red grey red grey red/ 280 2 silver red/ 340 2 silver red/ 400 2 silver 160 2.5 silver 220 2.5 silver 280 2.5 silver 340 2.5 silver 400 2.5 silver Dimension drawings see page 64560-076 1 piece (SPQ 10)1) – – – – 34562-881 24560-374 64560-078 – – – 34562-882 24560-375 64560-080 34562-883 24560-376 – 34562-884 – – 34562-885 – – – – – 6.40 – – – – – 6.40 34564-881 34564-882 24560-141 24560-141 24560-157 24560-255 24560-255 – 24560-377 24560-377 – 24560-378 24560-378 – 60817-228 60817-228 – 34564-883 34564-884 34564-885 6.40 Accessories Retention screw, PU 100 pieces ESD clip, PU 50 pieces Board locking C, red, PU 10 pieces Board handleC , red, PU 10 piecesdescription Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page see page 6.41 – 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Further guide rails see page 6.35 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.93 Desk-top cases – b Mounting plates Main Catalogue Order Information Mounting plate for fixing of heavy components Assembly strip for partial widths Mounting plate over full width: mounting is onto the side panels; mounting plate over partial width: mounting is onto one side panel and fixing strip or onto 2 fixing strips 06102501 Width W Board length HP W mm 28 146.88 160 28 146.88 220 28 146.88 280 28 146.88 340 42 217.99 160 42 217.99 220 42 217.99 280 42 217.99 340 63 324.67 160 63 324.67 220 63 324.67 280 63 324.67 340 84 431.35 160 84 431.35 220 84 431.35 280 84 431.35 340 Assembly kit for mounting plate PU 1 kit (Torx countersunk screw M4 x 5, St, zinc-plated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; M4 square nut, St, zinc-plated, 10 pieces) Assembly kit for assembly strips of mounting plate, Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces M2.5 × 5, St, zinc-plated, PU 100 pieces 05806100 Al, 1.5 mm; for mounting over partial width, please order assembly strips separately St, 2 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates 34562-745 30840-021 34562-749 34562-753 30840-033 30840-045 34562-757 30840-057 34562-746 30840-021 34562-750 34562-754 30840-033 30840-045 34562-758 30840-057 34562-747 34562-751 30840-021 30840-033 34562-755 30840-045 34562-759 34562-748 30840-057 30840-021 34562-752 30840-033 34562-756 34562-760 30840-045 30840-057 24560-184 – – 24560-146 Note 쮿 For installation and assembly of heavier components 쮿 The mounting plate is as wide as the case and is fixed to the side panels 쮿 A guide rail can be mounted on the first and last slot positions 쮿 4.4" and "strengthened" guide rails cannot be used 5.94 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Combined mountings (6 U and 2 x 3 U one above the other) Order Information Combined mounting: horizontal and vertical unshielded front panel for textile subdivision front panel, 6 U, 2 HP EMC gasket, 6 U, (incl. front panel for stainless 2 HP item 6 steel EMC gasket) item 6 bza45819 05806108 Width pitch T1:T2 HP 20:62 40:42 42:40 63:19 84:0 Torx countersunk screw M4 × 14, zinc-plated, PU 100 pieces fixing splitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces finxing horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, plastic PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces 06102501 Splitting extrusion for combined mounting Item 2 06102501 06102501 item 1: 2 front horizontal rails (H-KD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded insert, St, zinc-plated; item 4: Zn die-cast support member; item 6: front panel 2 HP, 6 U, shielded; with EMC stainless steel gasket (84:0 without items 4, 6) Al, 2.5 mm, front anodised, rear iridescent green chromated Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, die-cast zinc; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted PU 1 kit 1 piece (SPQ 5) 1 piece (SPQ 5)1) 1 piece 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 – 24562-420 24562-440 24562-442 24562-463 24562-484 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accept Euroboards (100 mm high) and double Euroboards (233.35 mm high) Note 쮿 Please order perforated strips for horizontal rails separately, see page 5.90 쮿 Please order rear centre horizontal rail separately, see page 5.89 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.95 Desk-top cases – b Horizontal board installation Order Information Horizontal board installation Front frame for EMC shielding Board cage 27 3.9 8= 54 Front frame, unshielded TE 05806091 05806092 H = usable height (1 TE = 1 HP, 1 HE = 1 U) ,98 =5 4T E bpa45913 H 273 h w bza43061 Struts die-cast zinc; horizontal rails front and rear; threaded insert, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 HP space required; please order front frame for EMC shielding separately 2 horizontal covers, AI 2.5 mm, front anodised, rear iridescent green chromated; 2 vertical trims, Al extrusion, clear passivated; stainless steel EMC gasket; front frame forms the contact between subrack and the subassemblies Al, 2.5 mm, clear anodised; front frame with cut-out, clear internal width w = 266.35 mm PU 1 kit PU 1 kit 1 piece Height U Usable height h HP Other dimensions and options 3 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Horizontal rail, rear Assembly tool, for mounting the EMC gasket (stainless steel) * For direct backplane mounting 5.96 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b Air baffle for slots Order Information Air baffle without front panel 06108085 Al, 1 mm, incl. assembly kit; prevents an air short circuit in unoccupied slot positions; is pushed into the groove of the guide rails 06101507 Depth mm 160 160 160 160 160 160 220 220 220 220 220 220 Width HP 4 4 8 8 12 12 4 4 8 8 12 12 SCHROFF.PENTAIR.CO.UK Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 34562-823 34562-833 34562-836 34562-843 34562-846 34562-824 34562-827 34562-834 34562-837 34562-844 34562-847 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.97 Desk-top cases – b Dimensions Extruded side panel 2 U Extruded side panel 3 U Text 19.5 19.5 A Z 15 M4 Z Y N x 15 = B ø 8.5 3 N x 15 = B Z ø 8.5 Y 4.6 ø 4.6 Y M4 M4 4.6 Y 15 ø 4.6 Z M4 3 49 132.55 121.95 99.95 24 88.1 77.5 55.5 A 02004057 02004058 Extruded side panel 4 U Extruded side panel 6 U A 19.5 19.5 AA 49 49 93 49 177 166.4 144.4 132.55 132.55 121.95 121.95 99.95 99.95 19.5 15 M4 ZZ Y N x 15 = B ø 8.5 33 Y 15 15 Z M4 M4 YY NNxx15 15==BB YY 4.6 4.6 ø 4.6 M4 4.6 øø8.5 8.5 øø4.6 4.6 02004059 ZZ M 44 M 3 49 49 132.55 132.55 121.95 121.95 99.95 99.95 265.9 265.9 Z 02004060 Dimensions For case depth mm 271 331 391 451 511 Max. mounting depth mm 250 310 370 430 490 Dimensions A in mm 231 291 351 411 471 B in mm 15 15 = 225 19 15 = 285 23 15 = 345 27 15 = 405 31 15 = 465 Note Side panel for 6 U case consists of two 3 U extruded side panels 5.98 SCHROFF PRODUCT CATALOG E 10/2017 ELECTRONICS PROTECTION Desk-top cases – b SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.99 J Main Catalogue Desk-top cases – J Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 02202003 Standards Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 쮿 Internal dimensions in accordance with IEC 60297-3-100 쮿 Type of protection IP 20 in accordance with IEC 60529 쮿 Protective ground connections in accordance with: DIN EN 50178/VDE 0160 DIN EN 60950/VDE 0805 DIN EN 61010-1/VDE 0411 part 1 DIN EN 61010-1A2/VDE 0411 part 1/A1 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 5.100 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – J Overview . . . . . . 5.100 J Case to accept 19" subracks or 19" chassis 쮿 Internal assemblies of up to 40 kg 쮿 Up to six rows of ventilation slots in the base plate for optimal air inlet 쮿 High stability 쮿 Front and rear identical, depth-symmetrical construction 쮿 With handle strip or recessed grip Case comptec 쮿 Al die-cast frame front and rear 3, 4 U, St . . . . . . . . . 5.102 쮿 Top cover and base plate can be subsequently removed 6, 7, 9 U, St . . . . . . 5.103 9, 12 U, Al . . . . . . . . 5.104 쮿 Top cover and base plate fitted with hidden GND/earth connections 쮿 Case height 3, 4, 6, 7 and 9 U (cladding parts in steel) 쮿 Case height 9 U and 12 U (cladding parts in aluminium) Accessories Folding handle . . . 5.105 Slide rails . . . . . . . . 5.105 Earthing kit . . . . . . 5.106 Assembly kit . . . . . 5.106 Tip-up feet . . . . . . . 5.107 02202004 Text 02202005 ServicePLUS from page 5.4 ServicePLUS . . . 5.4 e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) e.g. assembly service from 1 piece www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 5.101 Desk-top cases – J 19" case, 3 U, 4 U JMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Desk-top case (pre-fitted) 쮿 Top cover, base plate and rear panel in steel 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slits in base plate 쮿 Ventilation gills in rear panel 쮿 Side panel with integral handle function Delivery comprises (kit) 02202001 7 Qty 1 1 2 1 8 1 9 1 10 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side panel, Al extrusion, RAL 7016 Cover plate, Al, 1 mm, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, RAL 9006, with GND/earthing tag Rear panel, St, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Items 1, 2, 5 and 9 fitted. 9 1 Item 1 2 5 7 2 Order Information 5 8 10 CTTP0001 Front view Height H h Depth D U 3 3 3 4 4 4 mm 13.0 13.0 13.0 13.0 13.0 13.0 mm 300 400 500 300 400 500 mm 153 153 153 198 198 198 Usable depth d mm 276 376 476 276 376 476 Width B mm 520 520 520 520 520 520 Part no. 10225-601 10225-612 10225-623 10225-602 10225-613 10225-624 Note H HE 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page. 5.107 쮿 Please order slide rails separately, see page 5.105 h b B h = case foot height, HE = U, internal usable height CTA30677 Side view Usable width b = B - 69 mm, h = height of case foot CTA42313 ServicePLUS see page 5.4 5.102 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – J 19" case, 6 U, 7 U, 9U J 쮿 Desk-top case (pre-fitted) 쮿 With handle shell 쮿 Top cover, base plate and rear panel in steel 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slits in rear panel and base Delivery comprises (kit) 02202002 7 9 3 1 6 Item 1 2 3 4 5 Qty 1 1 2 2 2 6 2 7 8 9 10 1 1 1 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side profile at top, Al extrusion, RAL 7016 Side profile at bottom, Al extrusion, RAL 7016 Side panel, St, 1.5 mm, RAL 9006, with GND/earthing tag Handle shell, PC, RAL 7016, UL 94 V-0, load-carrying capacity: 60 kg/pair Cover plate, St, 1 mm, RAL 9006, with GND/earthing tag Base plate, St, 1 mm, RAL 9006, with GND/earthing tag Rear panel, St, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit Items 1, 2, 3, 4, 5, 6 and 9 fitted. 5 Order Information 2 4 8 10 CTTP0002 H HE Front view Height H h Depth D U 6 6 6 6 7 7 7 9 9 9 mm 13 13 13 13 13 13 13 13 13 13 mm 300 400 500 600 400 500 600 400 500 600 mm 286 286 286 286 331 331 331 420 420 420 Usable depth d mm 276 376 476 576 376 476 576 376 476 576 Width B mm 520 520 520 520 520 520 520 520 520 520 Part no. 10225-604 10225-615 10225-626 10225-637 10225-616 10225-627 10225-638 10225-618 10225-629 10225-640 h Note b B h = case foot height, HE = U, internal usable height CTA30676 Side view Usable depth d = D - 24 mm 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page 5.107 쮿 Please order slide rails separately, see page 5.105 쮿 Handle shell, item 6, can be replaced by a folding handle, see page 5.105 CTA42312 ServicePLUS see page 5.4 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.103 Desk-top cases – J 19" cases 9 and 12 U, aluminium J 쮿 Desk-top case (pre-fitted) 쮿 With handle shell 쮿 Top cover, base plate and rear panel in Al 쮿 Front and rear frames in die-cast Al 쮿 Ventilation slots in base plate 쮿 Air vents in rear panel Delivery comprises (kit) 02202006 7 Item 1 2 3 4 5 Qty 1 1 2 2 2 6 2 7 8 9 10 1 1 1 4 11 1 Description Front frame, Al die-cast, RAL 7016, with 19" grid Rear frame, Al die-cast, RAL 7016, with 19" grid Side profile at top, Al extrusion, RAL 7016 Side profile at bottom, Al extrusion, RAL 7016 Side panel, Al, 1.5 mm, RAL 9006, with GND/earthing tag Handle shell, PC, RAL 7016, UL 94 V-0, load-carrying capacity: 60 kg/pair Cover plate, Al, 1 mm, RAL 9006, with GND/earthing tag Base plate, Al, 1 mm, RAL 9006, with GND/earthing tag Rear panel, Al, 1 mm, RAL 9006, with GND/earthing tag Case foot with anti-slip protection, PC, black, UL 94 V-0 Assembly kit 9 3 6 1 5 2 Items 1, 2, 3, 4, 5, 6 and 9 fitted. 4 Order Information 8 10 CTTP0003 h H HE Front view Height H h Depth D U 9 9 9 12 12 12 mm 13 13 13 13 13 13 mm 400 500 600 400 500 600 mm 420 420 420 553 553 553 Usable depth d mm 376 476 576 376 476 576 Width B mm 520 520 520 520 520 520 Part no. 10225-667 10225-682 10225-693 10225-670 10225-685 10225-696 Note b B Usable width b = B - 69 mm, h = height of case foot CTA30679 Side view Usable depth d = D - 24 mm 쮿 Please order GND/earthing kit separately, see page 5.106 쮿 The case foot, item 10, can be replaced by a tip-up foot, see page 5.107 쮿 Please order slide rails separately, see page 5.105 쮿 Handle shell, item 6, can be replaced by a folding handle, see page 5.105 CTA42314 ServicePLUS see page 5.4 5.104 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – J Folding handle J 쮿 Folding handles can be used instead of the pre-fitted handle shells 쮿 Load-carrying capacity: 50 kg/pair Delivery comprises (kit) Item 1 2 Qty 2 1 Description Folding handle, AI die-cast, RAL 7016 Assembly kit Order Information Description Folding handle Part no. 20225-439 CTTP0006 Slide rails J 쮿 Slide rails are suitable as support for 19" subracks and 19" chassis Delivery comprises Item 1 Qty 1 Description Slide rail, Al extrusion, anodised, cut edges plain, static load-carrying capacity 10 kg Order Information For case depth mm 300 400 500 600 Part no. 30225-089 30225-090 30225-091 30225-092 Note 쮿 2 slide rails are required per subrack or 19" chassis 쮿 Slide rail cannot be used for shielded 19" subracks; special slide rails available on request CTTP0005 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.105 Desk-top cases – J GND/earthing kit J 쮿 The GND/earthing kit allows VDE compliant earthing of cases in accordance with: EN 50178/VDE 0160 EN 60950/VDE 0805 EN 61010-1/VDE 0411 part 1 EN 61010-1A2/VDE 0411 part 1/A 쮿 VDE tested Delivery comprises (kit) Item 1 Qty 1 Description GND/earthing kit, Cu wire, 1.5 mm2, PVC sheathing, green/yellow, connects side panels, cover, base plate and rear panel Order Information Description aza43284 GND/earthing kit for cases with steel covers GND/earthing kit for cases with aluminium covers Up to 4 U Part no. bigger than 4 U Part no. 21100-490 21100-448 – 21100-347 19" fixing J 쮿 For fitting subracks or 19" chassis in a comptec case 쮿 For fixing 19" front panels Delivery comprises Item 1 2 3 Description Screw M6 × 16, zinc-plated with Pozidrive Cage nut M6, zinc-plated Plastic washer, ABS, black Order Information SC128XXX Description PU = 8 × screw, washer, nut PU = 50 each of M6 screw, washer and cage nut PU = 100 each of M6 screw, washer and cage nut Part no. 21100-435 21101-809 21101-810 06108055 5.106 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – J Plastic tip-up feet J 쮿 Static load-carrying capacity 25 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 01802075 Tip-up foot in die-cast Al J 쮿 Static load-carrying capacity 50 kg per foot 쮿 Tip-up feet can be used instead of the case feet fitted as standard 쮿 Fixing holes provided in bottom of case Order Information Description Qty Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-002 10603-001 21101-211 21100-211 21100-207 1) Part no. comprises 1 piece; delivery is in standard pack quantity (SPQ): please order a minimum of 10 feet or a multiple AZA43836 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.107 Desk-top cases – Accessories Contents AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 06002052 05895003 02992004 aza43835 02992003 32506001 쮿 쮿 쮿 쮿 쮿 쮿 쮿 쮿 Front handles see page 5.108 Strap handles see page 5.111 Tip-up carrying handles, see page 5.112 Folding handles see page 5.113 Tray handle see page 5.114 Feet, see page 5.115 Screwdriver (Torx) 5.117 Measuring tape, see page 5.117 Front handle, one-piece, width 7 mm AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 Static load-carrying capacity 10 kg/pair 쮿 Bolted from rear Delivery comprises (kit) Item 1 Qty 1 Description Front handle, Al extrusion, anodised Order Information A mm 48 98 E mm 40 90 Part no. 10501-001 10501-002 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. BZA42318 Front handle, one-piece, width 9 mm Accessories 쮿 Static load-carrying capacity 30 kg/pair 쮿 Bolted from rear Delivery comprises (kit) Item 1 Qty 1 Description Front handle, Al extrusion, anodised Order Information Description Front handle Pozidrive countersunk screw 14 × 10, zinc-plated, PU 100 pieces Part no. 10501-003 21101-381 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. BZA42330 5.108 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – Accessories Front handle, one-piece, width 10 mm Main Catalogue 쮿 Static load-carrying capacity 30 kg/pair 40 4 10 h Delivery comprises (kit) Item 1 2 H Ø 8,4 Ø 4,4 10 쮿 Bolted from front 8 H=1U H≥2U 02905050 Qty 2 1 Description Front handle, Al extrusion, anodised Assembly kit Order Information Height H U 1 2 3 4 5 Height H mm 40 69 113 157.45 201.9 Height h mm 28 53 97.5 141.9 186.4 Part no. 20860-256 20860-257 20860-258 20860-259 20860-260 02905051 Front handle, one-piece, width 12.2 mm 1U Main Catalogue 쮿 Static load-carrying capacity 30 kg/pair 쮿 Bolted from rear Delivery comprises Item 1 Qty 1 Description Front handle, AI extrusion, anodised Order Information BZA42316 2 U ... 6 U A E clear anodised mm mm Part no. 41 25 10501-116 57.5 44.5 10501-016 69 55 10501-004 102 88 10501-005 132 120 10501-006 146.4 133.4 10501-018 194 180 10501-007 249 235 10501-008 Panhead pozidrive screw self-locking, M5 × 12, zinc-plated, PU 100 pieces Torx countersunk screw M5 × 12, zinc-plated, 100 pieces black anodised Part no. – – 10501-025 10501-026 10501-027 – 10501-028 10501-029 21100-788 24560-183 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. Note BZA42327 SCHROFF.PENTAIR.CO.UK 쮿 Please order panhead screws separately Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.109 Desk-top cases – Accessories Front handle, multi-piece, width 12 mm 쮿 Static load-carrying capacity 10 kg/pair 쮿 In three parts, middle section in Al extrusion, end pieces in glass fibre reinforced plastic 쮿 Bolts on from front Delivery comprises (kit) Item 1 2 Qty 1 2 Description Front handle, Al extrusion, anodised End piece, PA, black Order Information A E mm mm 87.5 73.5 102.0 88 134.0 120 194.0 180 249 235 Panhead screw pozidrive self-locking, M5 × 12, zinc-plated, PU 100 pieces A3-227 Part no. 10502-050 10502-057 10502-059 10502-063 10502-065 21100-788 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 front handles or a multiple. Pricing is per individual item. Note 쮿 Please order panhead screws separately Front handle, multi-piece, width 12 mm Accessories Order Information 12 Description Qty/PU Item 1, front handle, Al extrusion, 1 anodised,1 m long Item 2, end piece, PA, black, 1 2 pieces each required Panhead pozidrive screw self-locking, M5 × 12, zinc-plated, PU 100 pieces 2 Part no. 30502-051 60502-003 21100-788 1000 1 40 02908050 Item 1: front handle; item 2: end piece 5.110 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – Accessories Strap handle, width 25 mm Access ori es 쮿 Static load-carrying capacity 20 kg Delivery comprises (kit) Item 1 Qty 1 2 3 2 1 Description Band, spring steel, handle, flexible plastic, grey, RAL 7016 Cover, grey, RAL 7016 Assembly kit Order Information Length mm 230 Part no. 20850-249 05895003 02902050 Strap handle, width 22 mm Access ori es 쮿 Static load-carrying capacity 20 kg Delivery comprises (kit) Item 1 2 3 Qty 1 2 1 Description Band, spring steel, plastic-coated, black Cover cap, St, chrome-plated Assembly kit Order Information 02992006 Length 240 mm/170 mm Length mm 170 240 Part no. 10504-002 10504-003 BZA42368 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.111 Desk-top cases – Accessories Tip-up carrying handle in separate parts AccessoriesMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 Static load-carrying capacity 25 kg (with handle bars of 450 mm length) 02992002 02992001 Lateral handle parts Accessories 쮿 Handle can be adjusted in 30° grid by pressing button Delivery comprises (kit) Item 1 2 3 4 Qty 2 2 2 1 Description Lateral parts, die-cast zinc, painted (chrome decor) Safety inserts, St, 1.5 mm, black Adaptor/locking brackets Assembly kit Order Information 02992002 Length mm 180 250 Part no. 10502-297 10502-296 A4-2361 Handle bar Accessories Delivery comprises (kit) Item 1 Qty 1 Description Handle bar, AI, black anodised Order Information Length mm 1000 Part no. 30502-191 02992001 A4-2367 5.112 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – Accessories Folding metal handle Access ori es 쮿 Static load-carrying capacity 30 kg/pair 쮿 For case ingress protection to IP 40 쮿 Locks in folded and opened positions 쮿 Equal cut-out for fitting in front of or behind case wall Delivery comprises (kit) 02992004 Item 1 2 Qty 1 1 Description Handle, Al die-cast, RAL 9005, black Handle shell, Al die-cast, RAL 9006, silver Order Information Description Folding metal handle Part no. 20505-032 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. A4-2369 A4-2370 Folding plastic handle Access ori es 쮿 Static load-carrying capacity 20 kg/pair 쮿 For case ingress protection to IP 40 쮿 Locks in folded and opened positions 쮿 External mounting only Delivery comprises (kit) 02992005 Folding plastic handle Item 1 2 3 Qty 1 1 1 Description Handle, PA, light grey Handle shell, PA, dark grey Assembly kit Order Information Description Folding plastic handle Part no. 10505-014 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. A2-123 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.113 Desk-top cases – Accessories Tray handle Accessories 쮿 Static load-carrying capacity 30 kg/pair Delivery comprises Item 1 Qty 1 Description Handle shell, PC, UL 94 V-0 Order Information Colour Size 1 for material thickness 1.5 mm Part no. black 60229-004 Spring clip PU 20 pieces Spring clip PU 100 pieces 02992003 Size 2 for material thickness 1.5 mm Part no. 60225-012 21100-089 21100-093 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order a minimum of 10 tray handles or a multiple. Pricing is per individual item. Note 쮿 Please order spring clips for fixing to the case separately Required: – for handle size 1: 2 spring clips – for handle size 2: 3 spring clips Size 1, case cut-out 49 × 104 mm Size 2, case cut-out 73 × 171 mm 5.114 SCHROFF PRODUCT CATALOG E 05/2016 A3-0670a A3-0670b ELECTRONICS PROTECTION Desk-top cases – Accessories Plastic foot Access ori es Delivery comprises Pos. 1 Menge 1 Beschreibung Plastic foot, PC, UL 94 V-0, black Order Information Description Dimensions A B C mm mm mm For material thickness 1 ... 3 16 7.2 4 For material thickness 1.5 ... 3 21 15 7 Hole diameter mm 7 7.7 Part no. 60224-009 60224-011 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 50 pieces or a multiple. Pricing is per individual item. A4-330 Note 쮿 Foot is inserted into mounting hole and then fixed by pressing in the expanding pin Rubber foot Access ori es Order Information Dimensions Height Hole diameter mm mm 10 25 15 26 Material Colour Qty Rubber Rubber grey grey 1 1 Part no. 60200-001 60200-027 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 50 pieces or a multiple. Pricing is per individual item. A4-2315 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.115 Desk-top cases – Accessories Plastic tip-up foot Accessories 쮿 Static load-carrying capacity 25 kg per foot 78,4 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case Order Information 47 Description 38,4 13,9 20 Ø3,1 Ø4,8 grey Part no. Foot with tip-up, PA, UL 94 HB 1 10603-023 Foot without tip-up, PA, UL 94 HB 1 10603-024 Pozidrive flathead screw M4 × 10, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces black Part no. 10603-025 10603-026 21100-513 21100-211 21100-207 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order a minimum of 10 feet or a multiple. Pricing is per individual item. 5 13,3 15,8 1 AZA43835 Qty/PU Note 14 쮿 Please order assembly kit separately. 02912050 Plastic tip-up feet Accessories 쮿 Static load-carrying capacity 25 kg per foot 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case Delivery comprises (kit) Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description RAL 7016 anthracite Part no. RAL 9006 silver Part no. Plastic tip-up foot 20603-002 20603-001 01802075 02906050 5.116 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Desk-top cases – Accessories Al die-cast tip-up foot Access ori es 쮿 Static load-carrying capacity 50 kg per foot 쮿 Can be used instead of standard feet 쮿 Fixing holes provided in bottom of case Order Information Description Qty Foot without tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Foot with tip-up, Al die-cast, silver 1 piece (SPQ 10)1) Accessories Cheesehead screw with slot M4 × 12, St, zinc-plated, PU 100 pieces Hexagon nut M4, St, zinc-plated, PU 100 pieces Spring washer A4, St, zinc-plated, PU 100 pieces Part no. 10603-001 10603-002 21101-211 21100-211 21100-207 1) Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. AZA43836 Screwdriver Retention partsMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 T8: For mounting guide rails to horizontal rails 쮿 T20: For mounting horizontal rails and rear hoods to side panels, cover plates, support brackets and front handles Order Information Torx screwdriver M2.5 M4 Qty/PU pieces 1 1 T 8 Torx T 20 Torx Part no. 64560-026 64560-027 AZA45925 Measuring tape Main Catalogue 쮿 Measuring tape with cm, U-, HP-division (lenght 2 m) 쮿 Plastic cases, metal measuring tape with automatic collection Order Information Description Measuring tape Qty/PU 1 Part no. 89009-001 32506001 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.117 Small Form Factor Cases – Interscale Interscale passive or convection cooled InterscaleMain CatalogPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shipping within 10 working days 쮿 Available plain or perforated for forced cooling with fans 쮿 Modular case consisting of 4 easy to assemble parts 쮿 Integrated EMC protection 쮿 Ingress protection IP 30 (plain version) 쮿 Color RAL 7016 쮿 Small form factor or 19" rack mount 02613002 쮿 Rigid construction only requires two screws 쮿 Other dimensions, cutout shapes or locations, and screen printing available Delivery includes (assembled) Item Qty 1 1 2 3 4 5 1 1 1 1 02613014 2 2 4 1 3 Description Base with 2 side panels (plain or perforated), St, 1 mm, AlZn coated, RAL 7016 (anthracite gray); 19"-angle, 1,5 mm St, AlZn coated, RAL 7016 (only on 19" version case) Top cover, Al, 1 mm, RAL 7016 Front panel, Al, 1 mm, RAL 7016 Rear panel, Al, 1 mm, RAL 7016 User manual 4 1 3 02613050 Plain case 02613051 Perforated case Order Information Desktop cases 19" cases Height Width Depth U mm 1 43.65 1 43.65 1 43.65 1 43.65 1 43.65 1 43.65 1 43.65 2 88.10 2 88.10 2 88.10 2 88.10 2 88.10 3 132.55 3 132.55 3 132.55 Accessories mm 132.55 132.55 221.45 221.45 310.35 399.25 399.25 221.45 221.45 310.35 399.25 399.25 310.35 399.25 399.25 mm 132.55 177.00 177.00 221.45 221.45 221.45 310.35 177.00 221.45 221.45 221.45 310.35 221.45 221.45 310.35 Desktop case plain Desktop case perforated Part no. Part no. 14820-133 – 14820-134 14820-154 – 14825-154 14820-155 14825-155 14820-175 14820-195 14825-175 14825-195 14820-197 14825-197 14820-254 14820-255 14825-254 14825-255 14820-275 14825-275 14820-295 14820-297 14825-295 14825-297 14820-375 14825-375 14820-395 14820-397 14825-395 14825-397 Height Width Depth U 1 1 2 2 3 3 mm 443.70 443.70 443.70 443.70 443.70 443.70 mm 221.45 310.35 221.45 310.35 221.45 310.35 mm 43.65 43.65 88.10 88.10 132.55 132.55 19" case plain 19" case perforated Part no. Part no. 14821-105 14826-105 14821-107 14821-205 14826-107 14826-205 14821-207 14826-207 14821-305 14821-307 14826-305 14826-307 Fan mount with fans, 80 mm height Page 5.124 Stacking aid Clip for horizontal rail mounting Page 5.129 Rubber feet Page 5.130 Wall or Desktop mounting bracket Page 5.129 Plastic feet Page 5.131 Plastic tip-up feet Page 5.130 Assembly tool Page 5.131 5.122 SCHROFF PRODUCT CATALOG E 12/2017 Page 5.130 ELECTRONICS PROTECTION Small Form Factor Cases – Interscale Interscalefor Embedded NUC Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Perforated side panels for passive cooling (convection) 쮿 Compliant with the SDT.03 embeddedNUC standard http://www.sget.org/standards.html 쮿 Modular case consisting of 3 easy to assemble parts; body, top cover and front panel 쮿 Rigid construction requires only two screws 쮿 Board mounting studs installed 쮿 Integrated EMC protection 쮿 Color RAL 7016 02615019 쮿 Max. heat dissipation without fan about 8 Watt 쮿 Cutouts specific for IES (http://en.ies.de/) MB95 embedded NUC board 쮿 Other dimensions, cutout shapes or locations and screen printing available Delivery includes (assembled) Item Qty 1 1 2 3 1 1 4 4 5 1 Description Base with 2 side panels (perforated) and rear panel, Al, 1 mm, RAL 7016 (anthracite gray) Top cover, Al, 1 mm, RAL 7016 Front panel, Al, 1 mm, RAL 7016 Pre-installed studs with M2.5 Torx T8 screws for board mounting User manual Order Information Height Width mm mm 34.00 112.00 Accessories Horizontal rail mounting bracket Wall or Desktop mounting bracket Rubber feet Assembly tool Screwdriver Depth mm 106.50 Part no. 14820-701 Page 5.129 Page 5.129 Page 5.130 Page 5.131 Page 5.131 Note 쮿 Only the listed Interscale accessories are compatible SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 5.123 Small Form Factor Cases – Interscale Fan mount with fans, 80 mm height InterscaleMA IN CATALOG Part number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 worki ng days 쮿 Fan mount for installation in the Interscale Delivery includes (assembled) Item 1a 1b 2a 2b 3 4 1 fan 02617001 2 fans 02617002 Qty. 1 1 1 2 1 1 Description Fan mount (1 fan), height 83 mm, width 83 mm Fan mount (2 fans), height 83 mm, width 165 mm Fan, 80 mm height, 80 mm width, 25.4 mm depth Fan, 80 mm height, 80 mm width, 25.4 mm depth Mounting material 4 x M3x6 countersunk screw Fan attachment (with cord) Order Information Description 1 fan 2 fans Qty/PU piece 1 1 Qty Part no. PU 1 kit PU 1 kit 24830-101 24830-102 Technical data of one fan Voltage [VDC] Dimensions H x W x D (mm) Air capacity (free blowing) [m3/h] Noise level [dB (A)] Max. stat. pressure [Pa] Max. ambient temperatures [°C] 5.124 SCHROFF PRODUCT CATALOG E 12/2017 12 80 x 80 x 25.4 109.44 44.62 95.41 70 ELECTRONICS PROTECTION Small Form Factor Cases – Interscale Interscale for embedded NUC, conduction cooled Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Integrated heat sink on top cover with 5 mm heat fins 쮿 Compliant with the SDT.03 embeddedNUC standard http://www.sget.org/standards.html 쮿 Modular case consisting of 3 easy to assemble parts; body, top cover and front panel 쮿 Rigid construction requires only two screws 쮿 Board mounting studs installed 쮿 Integrated EMC protection 쮿 Color RAL 7016 쮿 Cutouts specific for IES (http://en.ies.de/) MB95 embedded NUC board Application: Case with connectors 02615021 쮿 Other dimensions, cutout shapes or locations, and screen printing available Delivery includes (assembled) Item Qty 1 1 2 3 1 1 4 4 5 1 Description Base with 2 side panels and rear panel, Al, 1 mm, RAL 7016 (anthracite gray) Top cover with integrated heat sink, Al, 1 mm, RAL 7016 Front panel, Al, 1 mm, RAL 7016 Pre-installed M2.5 studs with Torx T8 screws for board mounting User manual Order Information Application: Case with connectors 02615009 Height Width Depth mm mm mm 43.65 112.00 106.50 Accessories Flexible Heat Conductor (FHC), 20 mm Aesthetic Design Elements Rubber feet Assembly tool Screwdriver Part no. 14830-002 Page 5.127 Page 5.127 Page 5.130 Page 5.131 Page 5.131 Note 쮿 Only the listed Interscale accessories are compatible SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 5.125 Small Form Factor Cases – Interscale Interscale for Mini-ITX, conduction cooled Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Integrated heat sink on top cover with 10 mm or 20 mm heat fins 쮿 Modular case consisting of 3 easy to assemble parts; body, top cover and front panel 쮿 Rigid construction requires only four screws 쮿 Board mounting studs installed 쮿 Integrated EMC protection 쮿 Color RAL 7016 쮿 Cutout for Mini ITX I/O panel, power connector (Phoenix Contact, 0710028) and power switch (Schurter, MCS 18 Front) 쮿 Other dimensions, cutout shapes or locations, and screen printing available Delivery includes (assembled) Application: Case with connectors 02615011 Item Qty 1 1 2 3 1 1 4 4 5 1 Description Base with 2 side panels and rear panel, Al, 1 mm, RAL 7016 (anthracite gray) Top cover with integrated heat sink, Al, 1 mm, RAL 7016 Front panel, Al, 1 mm, RAL 7016 Pre-installed M2.5 studs with Torx T8 screws for board mounting User manual Order Information Height Application: Case with connectors 02615010 Width Depth mm mm mm 94.00 184.00 189.00 Accessories Flexible Heat Conductor (FHC), 70 mm Aesthetic Design Elements Horizontal rail mounting bracket Wall or Desktop mounting bracket Plastic tip-up feet Rubber feet Assembly tool Screwdriver With 10 mm fins Part no. With 20 mm fins Part no. 14830-005 14830-006 Page 5.128 Page 5.127 Page 5.129 Page 5.129 Page 5.130 Page 5.130 Page 5.131 Page 5.131 Note 쮿 Only the listed Interscale accessories are compatible 5.126 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Small Form Factor Cases – Interscale Accessories Aesthetic Design Elements for conduction cooled Intersc ale AccessoriesMain C atalogPart number in bold face type: ready for s hippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days 쮿 Designs created to compliment the various heat fin heights 쮿 Compatible with all Interscale C enclosures Delivery includes Item 1 Qty 2 Description Aesthetic design element, Al For Mini-ITX case 02615007 For embedded NUC case Order Information For case width mm Colour, finish 5 mm Heat fin height 10 mm 20 mm Part no. Part no. Part no. 112 Blue (RAL 5010) 24830-010 – – 112 Red (RAL 3027) 24830-011 – – 112 Siver (RAL 9006) 24830-012 – – 184 Blue (RAL 5010) – 24830-013 24830-016 184 Red (RAL 3027) – 24830-014 24830-017 184 Silver (RAL 9006) – 24830-015 24830-018 Flexible Heat Conductor (FHC), 20 mm Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Patent pending conduction cooling solution for small form factor electronics 쮿 Conductor block expands/contracts vertically to compensate for tolerance stack up and optimizes surface contact and pressure along the thermal path; eliminates the need for a thermal gap pad 쮿 Provides industry leading conduction cooling performance, 10 % improvement over current conduction cooling methods 쮿 Designed for Intel, AMD, Via, Freescale, NVidia and Texas Instrument processors that employ a BGA socket 쮿 Secured to PCB with thermally conductive adhesive tape 02615016 쮿 Compatible with Interscale C enclosures Delivery includes (assembled) Item Qty 1 1 2 1 Description Flexible heat conductor, assembled; thermal grease included Adhesive tape, thermally conductive Order Information Height 19.75 ± 1.5 mm SCHROFF.PENTAIR.CO.UK Width mm 22 Depth mm 22 Part no. 24830-005 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 5.127 Small Form Factor Cases – Interscale Accessories Flexible Heat Conductor (FHC), 70 mm Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Patent pending conduction cooling solution for small form factor electronics 쮿 Conductor block expands/contracts vertically to compensate for tolerance stack up, and optimizes surface contact and pressure along the thermal path; eliminates the need for a thermal gap pad 쮿 Provides industry leading conduction cooling performance, 70 % improvement over current conduction cooling methods 쮿 Designed for ATX/ITX/Mini ITX & COM using Intel core-i processors and AMD processors with the following sockets: Intel: LGA775, LGA1150, LGA1155, LGA1156, LGA1366, LGA2011 AMD: AM2, AM2(+), AM3, AM3(+), FM1, FM2, FM2(+) 쮿 Secured to PCB with mounting brackets, sold seperately 쮿 Compatible with Interscale C enclosures 02615017 Item Qty 1 1 2 1 Description Flexible heat conductor, assembled; thermal grease included Frame, Al Order Information Height Width mm 50 Depth mm 50 68.50 ± 2.5 mm Accessories Intel mounting brackets for 70 mm FHC AMD mounting brackets for 70 mm FHC Part no. 24830-001 24830-002 24830-003 Note 쮿 Please order the mounting bracket (Intel or AMD, listed under accessories) to assemble the FHC to the board Mounting brackets for 70 mm FHC Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Designed to secure the 70 mm Flexible Heat Conductor to PCB 쮿 Utilizes keep out zones to not interfere with other board components 쮿 Designed for ATX/ITX/Mini ITX & COM using Intel core-i processors and AMD processors with the following sockets: Intel: LGA775, LGA1150, LGA1155, LGA1156, LGA1366, LGA2011 AMD: AM2, AM2(+), AM3, AM3(+), FM1, FM2, FM2(+) Delivery includes (assembled) Item 1 Qty 1 Description Mounting bracket with associated hardware Order Information Description Intel mounting brackets for 70 mm FHC AMD mounting brackets for 70 mm FHC Bracket for Intel 5.128 02615053 Application: Intel mounting bracket SCHROFF PRODUCT CATALOG E 12/2017 Part no. 24830-002 24830-003 02615054 ELECTRONICS PROTECTION Small Form Factor Cases – Interscale Accessories Clip for horizontal rail mounting Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 The clip can be used to fix the case to a horizontal rail 쮿 The clip is bolted to the case instead of the feet and can then be fitted onto the rail Delivery includes Item 1 Qty 2 2 3 2 1 Description Clip, Al profile, clear anodized, width 30 mm, 52 mm, snap mounting for 35 mm DIN rails EN 50022; M4 selfclinching nut Screw, T20, M4 x 6 User manual Order Information Description 02613069 02613070 Example: Clip for horizontal rail mounted on case Clip for horizontal rail mounting Qty/PU piece 2 Part no. 24820-002 Note 쮿 Not compatible with embedded NUC cases or Interscale 19" cases Wall or Desktop mounting bracket Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Bracket for wall or desktop mounting 쮿 Provides 14 mm clearance from mounting surface for cable management 쮿 Able to assemble / disassemble case while mounted Delivery includes Item 1 Qty 4 Description Mounting bracket, St, 1.5 mm, finish AlZn Order Information Description Wall or Desktop mounting bracket Qty/PU piece 4 Part no. 24820-005 Note 02615052 SCHROFF.PENTAIR.CO.UK Example: Mounting bracket mounted on the case 02615051 쮿 Not compatible with embedded NUC cases or Interscale 19" cases Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 5.129 Small Form Factor Cases – Interscale Accessories Plastic tip-up feet 쮿 Can be used instead of standard feet 쮿 Carrying capacity: 25 kg per foot 쮿 Mounting holes in bottom of casing Delivery includes (kit) 01810004 Item 1 2 3 4 Qty 4 4 2 1 Description Foot, PA, UL 94 V-0 Anti-slip protection, TPE Tip-up device, PA, UL 94 V-0 Assembly kit Order Information Description Qty/PU piece 4 Tip-up feet, anthracite, similar to RAL 7016 Part no. 20603-002 Note 쮿 Not compatible with embedded NUC cases or Interscale 19" cases Application example 02613008 02906050 Stacking aid 쮿 Stacking aid is clipped onto tip-up feet (please order tip-up feet separately) Delivery includes (kit) Item 1 Qty 4 Description Stacking aid, PA ,UL 94 V-0 Order Information Description 01810005 Qty/PU piece 4 02613020 Application example Interscale Stacking aid, anthracite, similar to RAL 7016 Accessories Plastic tip-up feet anthracite, similar to RAL 7016, 4 pieces Part no. 20603-003 20603-002 Note 쮿 A plastic tip-up feet are required for mounting, please order separately 쮿 Not compatible with Interscale 19" cases, Interscale for embedded NUC cases or Interscale conduction cooled cases Rubber feet 쮿 Toolless installation; secures via adhesive 쮿 Compatible with all Interscale cases Delivery includes (assembled) Item 1 Qty 4 Description Rubber feet, height 2.2 mm, Ø 7.9 mm Order Information 02615020 5.130 SCHROFF PRODUCT CATALOG E 12/2017 Description Rubber feet Part no. 21102-025 ELECTRONICS PROTECTION Small Form Factor Cases – Interscale Accessories Plastic feet 쮿 Plastic feet with rubberized base 쮿 Toolless installation; fixed by pressing in the expanding pin Delivery includes Item 1 Qty 1 Description Plastic foot, PC, UL 94 V-0, black, with anti-slip protection Order Information 02613010 Dimensions A mm 16 A4-330 Illustration shows mounting of feet Hole diameter B mm 7.2 C mm 4 Description Qty Part no. Plastic feet SPQ 50 1) 60224-009 Plastic feet PU 4 2) 24820-004 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) PU - Part no. includes one packing unit (PU); delivery is exclusively made in PU Note mm 7 쮿 Not compatible with Interscale 19" cases, Interscale for embedded NUC cases or Interscale conduction cooled cases Assembly tool 쮿 Plastic tool with bit can be used for bolting together and opening the case 쮿 Compatible with all Interscale M and C enclosures Delivery includes Item 1 2 02613064 Qty 1 1 Description Assembly tool (plastic) Bit, Torx, T10 Order Information Description Assembly tool Part no. 24820-001 Screwdriver 쮿 Used for securing PCBs to studs 쮿 Compatible with all Interscale M and Interscale C enclosures Order Information Description Torx screwdriver, M2.5, T 8 Torx Part no. 64560-026 AZA45925 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 5.131 m inipacMain Catalogue Small Form Factor Cases – minipac Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 04812001 Subracks/ 19" chassis . . . . 6 Small aluminium extrusion cases to hold PCBs 쮿 For applications e.g. in industry, railway technology, test and measurement, communications and network technology Fixing options Front panels, plug-in units . . . 7 Systems . . . . . . . 8 04812006 04811015 04812003 04812023 04812024 04812025 04812026 04812027 04812028 Various dimensions/colours Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Individual shapes Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 m inipacMain CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days 5.138 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Small Form Factor Cases – minipac Overview . . . . . . 5.138 Convenient small case - flexible enough for all your requirements mi nipacMain C ataloguePart number in bold face type: ready for des patch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days 쮿 To accomodate standardised and non-standardised PCBs 쮿 As desktop enclosure, for bolting (e.g. to a mounting plate) or for mounting on DIN support rail (DIN 43880) 쮿 High level of heat dissipation through large aluminimum surface of case 쮿 High stability 쮿 Type of protection: IP 40 Trapezium shape Trapezium shape . . . . . . . . . . 5.140 쮿 Accommodates up to 3 PCBs of different heights 50, 60 or 65 mm and board depth 100 or 160 mm 쮿 As desktop enclosure, for wall mounting or for mounting on DIN support rail (DIN 43880) 04811014 Rectangular shape 쮿 Accommodates up to 4 standardised PCBs in euroboard format, height 100 mm (3 U) or up to 8 non-standardised PCBs, height 60 mm and board depth 160 mm Rectagonal shape 5.141 쮿 Versions as desktop enclosure or for wall mounting 04812002 Individual cases in aluminium extrusion our minipac variety to your specifications 쮿 Other case lengths 쮿 Other case shapes 쮿 Cut-outs for lamps, switches, connectors, cable ducting, etc. 쮿 Individual printing of cover plates 쮿 Surface finish anodised or powder-coated 30407004 ANEL PRESS P T N EX FRO 30402151 SCHROFF.PENTAIR.CO.UK 5.139 Small Form Factor Cases – minipac Trapezium shape minipacMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Accommodates 3 non-standardised PCBs (height 50, 60 and 65 mm, depth 100/160 mm) 쮿 PCB thickness 1.6 mm, spacing 15.24 mm (3 HP) 쮿 Different versions – Wall mounting – For mounting on a DIN support rail (DIN 43880) – Desktop version Delivery comprises Item 1 2 3 Qty 1 2 1 Description Case, trapeziform, Al extrusion Lateral cover plate, 2.5 mm, anodised Fixing material kit, user manual Order Information 46,1 15,24 2 04812004 53, 1 50, 4 60, 4 65, 4 74, 2 04811053 Dimensions of body tube Description Length mm Case, trapeziform, Al extrusion, black anodised; lateral cover plates anodised, thickness 2.5 mm (no mounting option) Case, trapeziform, Al extrusion, black anodised, lateral cover plates anodised, thickness 2.5 mm (for wall mounting on long side of trapezoid) Case, trapeziform, Al extrusion, anodised; lateral cover plates anodised, thickness 2.5 mm (for wall mounting on short side of trapezium) Case, trapeziform, Al extrusion, black anodised; for DIN support rail mounting (DIN 43880); lateral cover plates anodised, thickness 2.5 mm (for mounting on a DIN support rail, DIN 43880) Accessories Rubber foot for desktop version, PU 4 pieces Part no. 100.5 24814-008 100.5 24814-010 100.5 24814-011 160.5 24814-014 21102-025 Note 2,5 쮿 On request: - Other case lengths - Cut-outs for LEDs, switches, connectors or couplings (USB, SUB-D) - Individual printing on cover plate D 47, 54,2 41,7 26,4 75,6 25 6,4 3 1 52 5 04812053 Desktop version 2,5 Wall mounting (on short side of trapezoid) 04812052 75,6 25 88,1 26,4 3,9 D 47, 6,4 3 1 52 2,5 Wall mounting (on long side of trapezoid) 5.140 5 2,5 04812051 04812057 For mounting on a DIN support rail (DIN 43880) SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Small Form Factor Cases – minipac Rectangular shape minipacMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days 쮿 Accommodates 4 standardised PCBs (height 100 mm, depth 160 mm) or rotated by 90° to accomodate 8 non-standardised PCBs (height 60 mm, depth 160 mm) 쮿 PCB thickness 1.6 mm, spacing 15.24 mm (2 HP) 쮿 Different versions – Wall mounting – Desktop version Delivery comprises Item 1 2 3 04812002 Qty 1 2 1 Description Case, rectangular, Al extrusion Lateral cover plate, 2.5 mm, anodised Fixing material kit, user manual Order Information Description 2 70,3 10,16 Case, rectangular, Al extrusion, black anodised; lateral cover plates anodised, thickness 2.5 mm (desktop version) Case, rectangular, Al extrusion, anodised; lateral cover plates anodised, thickness 2.5 mm (for wall mounting on long side) Case, rectangular, Al extrusion, anodised; lateral cover plates anodised, thickness 2.5 mm (for wall mounting on short side) Accessories Rubber foot for desktop version, PU 4 pieces ,6 60,6 100 2 10, 16 110 , D 9 Length mm Part no. 160.5 24814-024 160.5 24814-025 160.5 24814-027 21102-025 Note 04812050 Dimensions of body tube 71, D 6,4 3 1 D 7 26,4 112,3 112,3 25 쮿 On request: - Other case lengths - Cut-outs for LEDs, switches, connectors or couplings (USB, SUB-D) - Individual printing on cover plate 76, 2 2,5 04812056 Desktop version 2,5 Wall mounting (on long side of rectangle) 04812055 71,7 26,4 25 6,4 3 1 D 116 , 8 2,5 Wall mounting (on short side of rectangle) SCHROFF.PENTAIR.CO.UK 04812054 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.141 PROLINE Overview Main Catalogue Subracks/19" chassis – Overview Content Cabinets . . . . . . 1 D Wall mounted cases . . . . . . . . . 2 19" subrack with high flexibility in accordance with IEC 60297-3-103 and IEEE 1101.10/11 For different applications: Accessories for cabinets and wall mounted cases . 3 Climate control . 4 쮿 Kits, individual configuration and an extensive accessory range 쮿 Industrial applications 쮿 Shock and vibration resistance up to 5 g, e.g. for mobile railway applications 쮿 Shock and vibration resistance up to 25 g for rugged environments, e.g. mobile military applications Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 6.0 Downloads und weitere wichtige Informationen finden Sie im Internet unter www.schroff.biz SCHROFF PRODUCT CATALOG E 05/2016 36106005 (06109001 06108006 06112002 06112020) ELECTRONICS PROTECTION Subracks/19" chassis – Overview Overview . . . . . 6.0 O 19" chassis for non-standard components and horizontal board construction Versions in aluminium and steel plate (AlZn coated) Kits from stock or to individual configuration europacPRO . . . 6.2 multipac . . . . . . 6.112 inpac . . . . . . . . . . 6.128 Application examples europacPRO . . . 6.69 Subracks for mobile railway applications . . . . 6.70 multipac . . . . . . 6.112 F 19" chassis with high mechanical stability Flexible construction for standard board formats or individual solutions Can be used as a desk-top enclosure 36106006 (06002001 SCHROFF.PENTAIR.CO.UK 06002003 02192004) 6.1 DMain type: Part despatch number ready CataloguePart within for indes normal 1 0patch worki num type: within ngber days ready in2 bold working forfacedays Subracks – D Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 europacPRO standard 쮿 19" subrack with high flexibility 쮿 EMC shielding upgradable 쮿 In accordance with IEC 60297-3-103 and IEEE 1101.10/11 쮿 Kit from stock or individual configuration Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 europacPRO for mobile railway applications 쮿 Over and above the europacPRO standard range additional shock and vibration properties for up to 5 g in accordance with the standards: – IEC 61587-1, EN 50155 – BN 411002 and BN 411003 – NF F 61-005 / NF F 60-002 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 36112001 (06109001 06103001 06108006) 6.2 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION D Subracks – D Overview . . . . 6.2 europacPRO for industrial applications 쮿 Over and above the europacPRO standard range additional kits for wall mounting or for installation of supply modules to DIN 43880 Introduction . . . . 6.4 europacPRO . . . 6.6 europacPRO for rugged applications 쮿 Over and above the europacPRO standard range additional shock and vibration properties for up to 25 g in accordance with the standards: MIL 167, IEC 61587 DL 3, MIL 810 G, MIL 901 Subracks for mobile railway applications . . . . 6.70 europacPRO for industrial applications . . . . 6.86 europacPRO for rugged applications . . . . 6.92 europacPRO accessories 쮿 Extensive range of accessories for europacPRO products 쮿 Side panels, horizontal rails, guide rails, cover plates, front/rear covers, handles and shielding components 쮿 Interior assembly: combined mounting 6 or 2 x 3 U, horizontal board mounting, mounting plates, panel mounting, central locking, telescopic slides, divider plates, air deflectors, 19" module support and extensive fixing material kit Accessories . . . . 6.17 36112002 (01494031 06112002 06112001 06112020) SCHROFF.PENTAIR.CO.UK 6.3 6.3 Subracks – DIntroduction Platform-based standard solutions for individual requirements Practical technology without time-consuming assembly. The modular europacPRO product platform allows a wide range of possible applications with only a few components. The intelligent design of all components results in remarkably simple and fast management in assembly and components. Simple assembly with europacPRO kits: Two ways of reaching your desired product: Text 쮿 Kits 쮿 Individual configuration Individual configuration: 06107001 Delivered in space-saving flat packs. The threaded inserts or EMC gasket (depending on selected kit) are already pre-mounted on the horizontal rail. 06109052 You design your subrack as you wish, then receive it fully assembled via our ServicePLUS assembly service (even for orders of just one). We can also carry out individual modifications and cut-outs; and when time is short can do so very fast via ServicePLUS express. Introducti onDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatch within 10 working days Horizontal rails and side panels for different load-carrying classes Horizontal rails are available for three load classes: Text 쮿 "light" (load up to approx. 7.5 kg) 쮿 "heavy" (load > 7.5 kg) Light 06197007 Heavy 06197008 Rugged 06112004 쮿 "rugged" (load 15 kg) Side panels for 4 different load classes 쮿 Light: low-cost version with built-in 19" mounting bracket 쮿 Flexible: with separate, depth-adjustable 19" mounting bracket 쮿 Heavy: with integrated, tox-cold welded 19" mounting bracket, e.g. for shock and vibration environments up to 5 g Type Light 06197002 Type Flexible 06197003 쮿 Rugged: with integrated, tox-cold welded 19" mounting bracket and higher material thicknesses for extreme mechanical stresses, e.g. for increased shock and vibration environments up to 25 g 쮿 The combination of the 3 horizontal rail variants with the 4 types of side panel results in an almost unlimited variety of potential applications for various market requirements Type Heavy 6.4 06197004 SCHROFF Main catalogue Type Rugged www.schroff.biz E 05/2016 06112021 ELECTRONICS PROTECTION Subracks – DIntroduction Guide rails from plastic and aluminium profiles Main CataloguePart number in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days Guide rails form the interface between the subrack mechanics and the assemblies (boards, plug-in units, frame type plug-in units, drive unit modules, ...). Robust snap-in fixings on the plastic rails assure a secure grip, even when exposed to vibrations. In the case of H and R-type horizontal rails the guide rails can also be bolted on. For extreme stresses, guide rails in aluminium extrusion are used. To ensure that the wrong subassembly is not inserted into the wrong space we offer a mechanical coding to IEEE 1101.10/11 and IEC 60297-3-103. The continuous numbering on the horizontal rail (from 28 HP) and the markings on the guide rails facilitate quick fitting in the correct position. 06112052 06111059 We offer the appropriate adaptors for accommodating VPX or CompactPCI boards with strengthening frame or conductioncooled assemblies (CCA) installed in a subrack. Electromagnetic shielding and ESD The product platform europacPRO offers a variety of off-the-shelf solutions to assure electromagnetic compatibility (EMC) and to avoid electrostatic discharge (ESD). dB 120 Text 100 80 60 40 20 0 30 400 800 1200 1600 2000 Mhz 06108081 Two shielding concepts It can't be more secure! Two types of shielding concepts to front/rear of the subrack allow the use all Schroff frontpanels. The shielding at the front of the subrack is by means of stainless steel or textile EMC gaskets. Stainless steel gasket Textile gasket 06108074 06108073 ESD (electrostatic discharge) To avoid electrostatic discharge when inserting PCBs, ESD contacts are clipped into the guide rails. These establish a conductive connection between PCB and subrack-earth. Under IEC 60297-3-101 two ESD areas are defined on the euroboard. The ESD clips of the guide rail of the europacPRO subrack allow the assembly of both following variants: 쮿 ESD area (bottom and top) over the complete board length 쮿 ESD area (bottom/top) begins at the front from 70 mm to end of board) 04503050 06103052 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.5 DMain Catalogue Subracks – D Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 06197001 \ Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Different horizontal rails for various applications 06112014 04602002 The IEEE handles and shielded front panels are designed for the construction of CompactPCI and VME64x subrack systems Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Standards/certifications 쮿 Inner and outer dimensions meet: IEC 60297-3-100, -101, - 102, -103, -104, -105 IEEE 1101.1 and IEEE 1101.10/11 EMC dB curve 120 100 쮿 Type of protection IP 20 to IEC 60529 80 쮿 EMC testing to IEC 61587-3 60 쮿 Shock and vibration test reports: German "Bahn" standards BN 411002, BN 411003; NF F 60002, NF F 67012 IEC 61587-2, EN 50155 40 쮿 Nuclear plants KTA 1401 06 Sequential numbering on horizontal rails (> 28 HP) and markings on the guide rails provide quick optical positioning aids. ESD clips can be used at front or rear, to protect electronics from electrostatic discharge 20 0 30 400 800 1200 1600 2000 Mhz 06108081 Appendix . . . . . 12 6.6 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – D Overview . . . . . 6.6 19" subracks DMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Kits or individual configuration 쮿 One product and accessories platform for every kind of customer requirement and application 쮿 Suitable for CompactPCI and VME64x insertion and extractor handles 쮿 EMC shielding can easily be retrofitted if needed 쮿 Shock and vibration resistant up to 5 g 쮿 3D PDF or CAD 3D data available for download Kits 쮿 All required parts available under one order number, some pre-fitted 쮿 Most popular dimensions and versions available from stock Introduction. . . . 6.4 Kits Light . . . . . . . . . . . . 6.8 Flexible . . . . . . . . . . 6.9 Heavy . . . . . . . . . . . 6.14 CompactPCI. . . . . . 6.16 쮿 For installed loads up to 7.5 kg, up to 11 kg and up to 15 kg 쮿 As unshielded or shielded version 쮿 Supplied as space-saving flat-pack ServicePLUS . . . 6.16 06102008 ServicePLUS individual configuration 쮿 Single parts may individually be configured, respectively assembled on request (from quantity 1) 쮿 Very wide range of variants in heigth, width and depth 쮿 Guide rails for different applications 쮿 EMC shielding material to improve EMC performance 쮿 Interior assembly options with mounting plate or combined mounting (3 + 6 U segments) 06105058 쮿 Other accessories and assembly kits ServicePLUS configuration Side panels . . . . . . Horizontal rails, threaded inserts, perforated strips . Guide rails . . . . . . . Cover plates . . . . . EMC shielding . . . Interior assemblies . . . . . . Assembly kits . . . . 6.21 6.29 6.37 6.44 6.54 6.59 6.65 Application examples . . . . . . 6.71 Subracks for mobile railway applications . . . . 6.70 ServicePLUS from page 6.16 e.g. individual configuration and assembly e.g. modification (cut-outs) e.g. downloads (CAD drawings, user manuals, test reports) e.g. custom solutions europacPRO for industrial applications . . . . 6.86 europacPRO for rugged applications . . . . 6.92 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 6.7 Subracks – D Kit, "light", unshielded, for backplane mounting DMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days 쮿 Subrack with side panel type L ("light") with firmly fixed 19" brackets 쮿 Rear horizontal rails for backplane mounting with insulation strip 쮿 Installed load up to 7.5 kg 쮿 Cost-optimised Delivery comprises (Kit) 06111002 1 2b + 3 + 4 2c + 3 + 4 5 Item 1 Qty 3U 2 6U 2 Description 2a 2b 2c 3 4 5 2 2 4 2 1 2 2 1 6 4 1 Side panel type L, Al, 2 mm, passivated, with built-in 19" support bracket Front horizontal rail (L-KD) Rear horizontal rail (L-ST) Rear horizontal rail centre (ST) Threaded insert, front and rear (pre-fitted) Insulation strip (pre-fitted) Fixing material kit, user manual Order Information 2a + 3 1 5 06111056 6U Height U 3 3 3 6 6 6 Width HP 84 84 84 84 84 84 Depth D mm 175 235 295 175 235 295 Depth D1 mm 175 175/235 175/235/295 175 175/235 175/235/295 Part no. 24564-131 24564-132 24564-133 24564-431 24564-432 24564-433 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips Depth D2 mm 160 220 280 ESD clips for guide rails PU 50 pieces D2 D1 Qty/PU piece 10 10 10 Part no. 24560-351 24560-353 24560-379 24560-255 Cover plates for insertion in horizontal rails (type L) D 06108051 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Depth D2 mm 160 220 Width HP 84 84 Qty/PU piece 2 2 Part no. 24561-051 24561-052 Note 쮿 Subrack is not prepared for shielding 쮿 ServicePLUS configuration from page 6.16 04400001 Rear horizontal rail for backplane mounting with insulation strip ServicePLUS see page 6.16 6.8 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – D Kit, "flexible", unshielded, for connector mounting Part number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days 쮿 Subrack with side panel type F ("flexible"), 19" bracket is depth-adjustable 쮿 Rear horizontal rails for connector mounting (IEC 60603-2 / DIN 41612) 쮿 Installed load up to 11 kg Delivery comprises (kit) Item 1 Qty 3U 2 6U 2 Description 2 3a 3b 3c 4 5 2 2 2 2 1 2 2 2 1 2 1 06105001 Photo: 3 U subrack 2 3b 3c 1 19" support bracket, Al extrusion, for EMC gasket (St, stainless) Side panel type F, Al, 2 mm Front horizontal rail (L-KD) Rear horizontal rail (L-MZ) for connector mounting Centre horizontal rail (MZ) Threaded insert to front (pre-fitted) Fixing material kit, user manual Order Information 5 2 3a + 4 1 5 6U 06105054 Height U 3 3 3 3 6 6 6 6 Width HP 84 84 84 84 84 84 84 84 Depth D mm 175 235 295 355 175 235 295 355 Depth D1 mm 175 175/235 175/235/295 175/235/295/355 175 175/235 175/235/295 175/235/295/340 Part no. 24563-191 24563-192 24563-193 24563-194 24563-491 24563-492 24563-493 24563-494 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips Depth D2 mm 160 220 280 340 ESD clip for guide rails PU 50 pieces D2 D1 Qty/PU piece 10 10 10 10 Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 Cover plates for insertion in horizontal rails (type L) D 06108050 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Depth D2 mm 160 220 Width HP 84 84 Qty/PU piece 2 2 Part no. 24561-051 24561-052 Note 쮿 ServicePLUS configuration from page 6.16 04400003 Horizontal rail to rear for connector mounting ServicePLUS see page 6.16 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.9 Subracks – D Subrack kit, unshielded for connector, assembly on slide rail Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 working days 쮿 Subrack can be used with slide rails 쮿 Subrack with side panel type F ("flexible"), 19" bracket is depth-adjustable 쮿 Horizontal rails, rear, for connector mounting (IEC 60603-2 / DIN 41612) 쮿 Installed load up to 11 kg Delivery includes (Kit, flat pack) Item 06105001 Photo: 3 U subrack 2 3b 3c 1 5 6U 2 Description 2 3a 3b 3c 4 5 2 2 2 2 1 2 2 2 1 2 1 19" support bracket, Al extrusion, for EMC sealing (St, stainless) Side panel type F, Al, 2 mm Front horizontal rail (L-KD) Rear horizontal rail (L-MZ) for connector mounting Center horizontal rail (MZ) Threaded insert to front (pre-fitted) Fixing materials kit, user manual Order Information 2 3a + 4 1 5 06105054 6U 1 Qty 3U 2 Height U 3 3 3 6 6 6 Width HP 84 84 84 84 84 84 Depth D mm 235 295 355 235 295 355 Depth D1 mm 175/235 175/235/295 175/235/295/355 175/235 175/235/295 175/235/295/355 Part no. 24553-192 24553-193 24553-194 24553-492 24553-493 24553-494 Accessories 19" fixing material kit (screw, washer, nut) (8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips Depth D2 Qty/PU mm piece 160 10 220 10 280 10 ESD clip for guide rails Spring steel, tin-plated, silver, PU 50 pieces D2 D1 D D=overall depth, D1=insertion depth, D2=board depth = D1 - 15 mm 06108050 Part no. 24560-351 24560-353 24560-379 24560-255 Cover plates for insertion into horizontal rail type L Depth D2 mm 160 220 Width HP 84 84 Qty/PU piece 2 2 Part no. 24561-051 24561-052 Note 쮿 Alternative product for older europac lab and europacRational subrack series 쮿 ServicePLUS configuration from page 6.18 Rear horizontal rail for connector mounting 6.10 SCHROFF PRODUCT CATALOG E 03/2016 04400003 ELECTRONICS PROTECTION Subracks – DKits Subrack kit, unshielded, flexible for backplane, assembly on slide rail KitsDMain CatalogPart num ber in bold face type: ready for shipping within 2 worki ng days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Subrack can be used with slide rails 쮿 Subrack with side panel type F ("flexible"), 19" bracket is depth-adjustable 쮿 Rear horizontal rails for backplane mounting with insulation strip 쮿 Installed load up to 11 kg Delivery includes (Kit, flat pack) Item 06102007 Photo: 3 U subrack 6U 2 3b + 4 + 5 3c + 4 + 5 1 1 Qty 3U 2 6U 2 Description 2 3a 3b 3c 4 5 6 2 2 2 4 2 1 2 2 2 1 6 4 1 19" support bracket, Al extrusion, for EMC sealing (St, stainless) Side panel type F, Al, 2 mm Front horizontal rail (L-KD) Rear horizontal rail (L-ST) for backplane mounting Rear center horizontal rail (ST) Threaded inserts, front and rear (pre-fitted) Insulation strip (pre-fitted) Fixing materials kit, user manual Order Information 6 Height U 3 3 3 6 6 6 2 3a + 4 1 6 06102081 Width HP 84 84 84 84 84 84 Depth D mm 235 295 355 235 295 355 Depth D1 mm 175/235 175/235/295 175/235/295/355 175/235 175/235/295 175/235/295/355 Part no. 24553-132 24553-133 24553-134 24553-432 24553-433 24553-434 Accessories 19" fixing material kit (screw, washer, nut) (8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips Depth D2 Qty/PU mm piece 160 10 220 10 280 10 340 10 ESD clip for guide rails Spring steel, tin-plated, silver, PU 50 pieces D2 D1 D D=overall depth, D1=insertion depth, D2=board depth = D1 - 15 mm 06108051 Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 Cover plates for insertion into horizontal rail type L Depth D2 mm 160 220 Width HP 84 84 Qty/PU piece 2 2 Part no. 24561-051 24561-052 Note 쮿 Alternative product for older europac lab and europacRational subrack series 쮿 ServicePLUS configuration from page 6.18 Rear horizontal rail for backplane mounting with insulation strip SCHROFF.PENTAIR.CO.UK 04400001 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 6.11 Subracks – DKits Kit, "flexible", unshielded, for backplane mounting Main Catalogue 쮿 Subrack with side panel type F ("flexible"), 19" bracket is depth-adjustable 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Installed load up to 11 kg Delivery comprises (kit) Item 1 Qty 3U 2 6U 2 Description 2 3a 3b 3c 4 5 6 2 2 2 4 2 1 2 2 2 1 6 4 1 06102007 2 3b + 4 + 5 3c + 4 + 5 1 6 Order Information 2 3a + 4 1 6 6U 19" support bracket, Al extrusion, for EMC stainless steel gasket Side panel type F, Al, 2 mm Front horizontal rail (L-KD) Rear horizontal rail (L-ST) for backplane mounting Rear horizontal rail centre (ST) Threaded insert, front and rear (pre-fitted) Insulation strip (pre-fitted) Fixing material kit, user manual 06102081 Height U 3 3 3 3 3 3 6 6 6 6 6 6 Width HP 84 84 84 84 84 84 84 84 84 84 84 84 Depth D mm 175 235 295 355 415 475 175 235 295 355 415 475 Depth D1 mm 175 175/235 175/235/295 175/235/295/355 175/235/295/355 175/235/295/355 175 175/235 175/235/295 175/235/295/355 175/235/295/355 175/235/295/355 Part no. 24563-131 24563-132 24563-133 24563-134 24563-135 24563-136 24563-431 24563-432 24563-433 24563-434 24563-435 24563-436 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips D2 D1 D 06108051 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Depth D2 mm 160 220 280 340 ESD clip for guide rails PU 50 pieces Qty/PU piece 10 10 10 10 Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 Cover plates for insertion in horizontal rails (type L) Depth D2 mm 160 220 Width HP 84 84 Qty/PU piece 2 2 Part no. 24561-051 24561-052 Note 04400001 Rear horizontal rail for backplane mounting with insulation strip 쮿 ServicePLUS configuration from page 6.16 ServicePLUS see page 6.16 6.12 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DKits Kit, "flexible", shielded, for backplane mounting Main Catalogue 쮿 Subrack with side panel type F ("flexible"), 19" bracket is depth-adjustable 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz, assuming that the front is closed with shielded front panels 쮿 Installed load up to 11 kg Delivery comprises ((kit)) 06102008 7 3 4c + 5 + 6 4 + 5 + 11 1 4a + 5 9 4b + 5 + 6 2 4 + 5 + 11 7 10 6U 06102075 Item 1 2 3 4 4a 4b Qty 3U 2 2 2 2 2 2 6U 2 2 2 2 2 2 4c 5 6 7 8 9 10 11 12 6 2 2 1 1 1 2 1 1 8 4 2 1 1 1 2 1 D1 D 06113056 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm 19" support bracket for EMC textile gasket Rear corner profile for EMC textile gasket Side panel type F Front horizontal rail (L-KD) Rear horizontal rail (L-KD) Rear horizontal rail (L-ST) for backplane mounting with insulation strip Centre horizontal rail (ST) Threaded insert (pre-fitted) Insulation strip, fixed EMC cover plate EMC gasketing material (pre-fitted) Rear panel Fixing material kit Perforated strip (pre-fitted) User manual Order Information Height U 3 3 3 3 3 6 6 6 6 6 D2 Description Width HP 84 84 84 84 84 84 84 84 84 84 Depth D mm 235 295 355 415 475 235 295 355 415 475 Depth D1 mm 175/235 175/235/295 175/235/295 175/235/295 175/235/295 175/235 175/235/295 175/235/295 175/235/295 175/235/295 Part no. 24563-142 24563-143 24563-144 24563-145 24563-146 24563-442 24563-443 24563-444 24563-445 24563-446 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips 04400001 Rear horizontal rail for backplane mounting with insulation strip Depth D2 mm 160 220 280 340 ESD clip for guide rails PU 50 pieces Qty/PU piece 10 10 10 10 Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 Note 쮿 ServicePLUS configuration from page 6.16 ServicePLUS see page 6.16 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 6.13 Subracks – DKits Kit, 'heavy', unshielded, for backplane mounting Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Subrack with side panel type H ("heavy"), 19" bracket is firmly fixed to side panel (tox-cold welded) 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shock and vibration resistance up to 5 g 쮿 Installed load up to 15 kg 쮿 Versions with/without front handles 06102007 Without front handle 06111003 With front handle Delivery comprises (Kit) Item 1 6 1 Qty 3U 2 6U 2 Description 2a 2b 2c 3 4 5 6 2 2 4 2 1 2 2 2 1 6 4 1 2 2b + 3 + 4 2c + 3 + 4 5 2a + 3 Side panel type H, Al, 2 mm, passivated, with 19" support bracket (tox-cold welded) for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-ST) Rear horizontal rail centre (H-ST) Threaded insert, front and rear (pre-fitted) Insulation strip (pre-fitted) Fixing material kit, user manual Front handle (on version with front handle only) Order Information 1 5 6U 06111057 Height Width Depth D Depth D1 U HP mm mm 3 3 3 3 6 6 6 6 84 84 84 84 84 84 84 84 175 235 295 355 175 235 295 355 175 175/235 175/235/295 175/235/295/355 175 175/235 175/235/295 175/235/295/355 Part no. with front handle Part no. without front handle 24567-161 24567-162 24563-161 24563-162 24567-163 24563-163 24567-164 24567-461 24563-164 24563-461 24567-462 24563-462 24567-463 24567-464 24563-463 24563-464 Accessories D2 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) D1 D 06108052 D = overall depth, D1 = insertion depth, D2 = board depth 04400001 Rear horizontal rail for backplane mounting with insulation strip ServicePLUS see page 6.16 21100-435 Guide rails (standard), ESD clips Depth D2 Qty/PU mm piece 160 10 220 10 280 10 340 10 ESD clip for guide rails PU 50 pieces Torx panhead screw , for extra bolting of the guide rails, 2.5 × 9.3, zinc-plated, PU 100 pieces; torque max. 0.2 Nm Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 24560-141 Cover plates for bolting to side panel Depth D2 mm 160 220 280 340 Width HP 84 84 84 84 Qty/PU piece 2 2 2 2 Part no. 24560-078 24560-079 24560-080 24560-081 Note 쮿 ServicePLUS configuration from page 6.16 6.14 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DKits Kit, "heavy", shielded, for backplane mounting Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Subrack with side panel type H ("heavy"), 19" bracket is firmly fixed to side panel (tox-cold welded) 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz, assuming that the front is closed with sealed front panels 쮿 Shock and vibration resistance up to 5 g 쮿 Installed load up to 15 kg Without front handle 06102008 06111001 With front handle 쮿 Versions with/without front handles Delivery comprises (Kit) 7 Item 1 Qty 3U 2 6U 2 2 3 3a 3b 3c 4 5 6 7 8 9 10 11 2 2 2 2 6 2 2 2 1 1 1 2 2 2 2 2 1 8 2 4 2 1 1 1 2 3b + 4 + 6 3+4+5 Description 3c + 4 + 6 11 1 3a + 4 9 2 3+4+5 10 7 11 6U 06111058 Side panel type H, Al, 2 mm, passivated, with 19" support bracket (tox-cold welded); for textile EMC gasket Rear corner profile for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-KD) Rear horizontal rail (H-ST) Rear horizontal rail centre (ST) Threaded insert (pre-fitted) Perforated strip (pre-fitted) Insulation strip (pre-fitted) EMC cover plate EMC gasketing material (pre-fitted) EMC rear panel Fixing material kit, user manual Front handle (on version with front handle only) Order Information D2 D1 D 06113055 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Height U Width HP Depth D mm Depth D1 mm 3 3 3 6 6 6 84 84 84 84 84 84 235 295 355 235 295 355 175/235 175/235/295 175/235/295 175/235 175/235/295 175/235/295 Part no. with front handle Part no. without front handle 24567-172 24563-172 24567-173 24567-174 24563-173 24563-174 24567-472 24563-472 24567-473 24567-474 24563-473 24563-474 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips 04400001 Rear horizontal rail for backplane mounting with insulation strip ServicePLUS see page 6.16 SCHROFF.PENTAIR.CO.UK Depth D2 Qty/PU mm piece 160 10 220 10 280 10 ESD clip for guide rails PU 50 pieces Torx panhead screw , for extra bolting of the guide rails, 2.5 × 9.3, zinc-plated, PU 100 pieces; torque max. 0.2 Nm Part no. 24560-351 24560-353 24560-379 24560-255 24560-141 Note 쮿 ServicePLUS configuration from page 6.16 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.15 Subracks – DKits Kit, for CompactPCI, for backplane mounting, without rear I/O, shielded Main Catalogue 쮿 Subrack with side panel type F ("flexible") for CompactPCI plug-in units with high insertion and withdrawal forces 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz, assuming that the front is covered with shielded front panels 쮿 Installed load up to 11 kg Delivery comprises (kit) 06102009 6U 7 3 4d + 5 + 6 1 9 2 4a + 5 + 11 7 10 4b + 5 4c + 5 + 6 06102078 Item 1 2 3 4 4a 4b 4c Qty 3U 2 2 2 1 1 2 2 6U 2 2 2 2 2 2 Description 4d 5 6 7 8 9 10 11 12 6 2 2 1 1 1 2 1 1 8 4 2 1 1 1 2 1 19" support bracket for EMC textile gasket Rear corner profile for EMC textile gasket Side panel type F Front horizontal rail (H-KD) Front horizontal rail IEEE (H-LD) Rear horizontal rail (L-KD) Rear horizontal rail (H-ST), for backplane mounting with insulation strip Centre horizontal rail (ST) Threaded insert (pre-fitted) Insulation strip (pre-fitted) EMC cover plate EMC gasketing material (pre-fitted) Rear panel Fixing material kit Perforated strip (pre-fitted in item 4+4a) User manual Order Information Height U 3 6 Width HP 84 84 Depth D mm 235 235 Depth D1 mm 175 175 Part no. 24563-152 24563-452 Accessories D2 D1 D 06113055 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Guide rail with coding, red 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces Guide rail with coding, grey 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces Guide rail with coding, green, offset 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces ESD clip for guide rails PU 50 pieces ESD clip for alignment pin of CPCI/VME64x handle PU 50 pieces Torx panhead screw 2.5 × 9.3, zinc-plated, PU 100 pieces; torque max. 0.2 Nm Coding peg PC, UL 94 V-0, RAL 7035, PU 100 pieces 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 24560-356 24560-358 24560-359 24560-255 24560-256 24560-141 20817-501 21100-435 Note 쮿 ServicePLUS configuration from page 6.16 04400001 Rear horizontal rail for backplane mounting with insulation strip ServicePLUS see page 6.16 6.16 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DKits Kit, for CompactPCI, for backplane mounting, for rear I/O, shielded Main Catalogue 쮿 Subrack with side panel type F ("flexible") for CompactPCI plug-in units with high insertion and withdrawal forces 쮿 For rear I/O boards (depth 80 mm) 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz, assuming that the front is covered with shielded front panels 쮿 Installed load up to 11 kg 06108007 Delivery comprises (kit) Item 6U 7 3 4d + 5 + 6 11 1 2 3 4 4a 4b 4c Qty 3U 2 2 2 1 1 2 2 6U 2 2 2 2 2 2 Description 4d 5 6 7 8 9 10 11 12 6 2 2 1 1 2 2 1 1 8 4 2 1 1 2 2 1 1 2 4a + 5 + 10 7 9 4b + 5 + 10 4c + 5 + 6 06105076 19" support bracket for EMC textile gasket Rear corner profile for EMC textile gasket Side panel type F Front horizontal rail (H-KD) Front horizontal rail IEEE (H-LD) Rear horizontal rail (H-KD) Rear horizontal rail (H-ST), with insulation strip for backplane mounting Centre horizontal rail (ST) Threaded insert (pre-fitted) Insulation strip, fixed EMC cover plate EMC gasketing material (pre-fitted) Fixing material kit Perforated strip (pre-fitted) Horizontal rail type AB User manual Order Information Height U 3 6 Width HP 84 84 Depth D mm 275 275 Depth D1 mm 175 175 Depth D3 mm 80 80 Part no. 24563-157 24563-457 Accessories D2 D3 D1 D D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm, D3 = rear I/O board depth 04400001 06108075 Rear horizontal rail for backplane mounting with insulation strip Guide rail with coding, red 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces Guide rail with coding, grey 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces Guide rail with coding, green, offset 160 mm deep, PBT, UL 94 V-0, groove width 2 mm, PU 10 pieces ESD clip for guide rails PU 50 pieces ESD clip for alignment pin of CPCI/VME64x handle PU 50 pieces Guide rail with coding, red 70 mm deep, PU 10 pieces Guide rail with coding, grey 70 mm deep, PU 10 pieces Torx panhead screw 2.5 × 9.3, zinc-plated, PU 100 pieces; torque max. 0.2 Nm Coding peg PC, UL 94 V-0, RAL 7035, PU 100 pieces 19" fixing material kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 24560-356 24560-358 24560-359 24560-255 24560-256 24560-355 24560-360 24560-141 20817-501 21100-435 Note 쮿 ServicePLUS configuration from page 6.16 ServicePLUS see page 6.16 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.17 Subracks – DServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 6.19 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable from quantity 1 modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Custom modifications from quantity 1 solution Simple. Fast. From one source. Integration and custom developments 쮿 Special sizes (depth and width) 쮿 Ready for despatch within 5 working days 쮿 Ready for despatch within 10 working days 쮿 Individual heat dissipation concepts 쮿 Ready for despatch within 10 working days express When fast has to be faster. Delivery time to customer's request 쮿 Express logistics academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, CAD drawings, test reports, user reports ServicePLUS 6.18 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Overview of individual components for shielded or unshielded subracks 4 2 1 6 5c 3 5b 2 5a 06108086 Item Description Item 1 Side panel 1 ServicePLUSDPart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Description Establishes the height and depth of the subrack; Al, 2 mm, with universal hole positions for assembly of accessories. Three versions: The "flexible" one with separate 19" brackets as well as two others with integrated 19" brackets for "light" and "heavy" applications. page 6.21 Item 2 Horizontal rail Establishes the width of the subrack; Al extrusion, with defined hole positions for guide rails, grooves for threaded inserts, M4 thread, functional rail shapes, basically differing with regard to their mechanical loading capacity: “light“ (load up to 7.5 kg) and “heavy“ (load > 7.5 kg). Item 3 Guide rails Act as interface between subracks and boards, for different board formats, are available in plastic or metal, optionally codable and can be fitted with ESD clips to allow electrostatic discharge, also optionally. 6.37 Item 4 Cover plates Provide mechanical protection and/or EMC shielding and are perforated. 6.44 Item 5 Rear/front Rear hood (5a) or front panel (5b) with corner profile (5c) act as support for EMC shielding gaskets used in conjunction with shielded front panels. Note: Rear hood and corner profile cannot be fitted simultaneously. 6.49 Item 6 Handles Can be mounted on the 19" brackets. 6.27 – EMC shielding (without illustration) Extensive component range for specific shielding of subracks with respect to their application. 6.54 – Interior assemblies (without illustration) Universal assemblies, e.g. for horizontal and vertical assembly and for mounting plates. 6.59 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.29 6.19 Subracks – DServicePLUS Subrack dimensions Main Catalogue e1 e1 e2 e1 e1 쮿 Dimensions in accordance with international standards EC 60297-3-100, IEEE 1101.1/.10/.11; please see the Schroff Standards Summary for details 쮿 Side panels – Aluminium, 2 mm – Round holes for mounting horizontal rails (depth grid 15 mm) – Impressions on the inner side of the side panel act as an anti-rotation guard and positioning aid for the horizontal rails – Square holes (6 x 6 mm) provide universal fixing for components such as backplane shielding; version without square holes available on request 20304051 Depth grid The depth grid is 15 mm, the mounting holes in the side panel are decisive for the configurability of individual components; thus any combination of various individual parts is possible 06197003 Side panel 3 U, 6 U and 9 U 3 and 6 U side panels have the same hole positions (the 6 U is a doubling vertically of the 3 U); thus subdivisions can be made in the vertical dimension (6 U: 2 x 3 U; 9 U: 3 x 3 U) 06108008 Side panel 4 U 4 U side panels have the same hole positions as 3 U and additionally 1 U (above or beneath the 3 U installation); this height allows the construction of a 3 U unit with 1 U clearance for cabling or airflow 06108011 6.20 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Side panels Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Aluminium 쮿 Round holes for mounting horizontal rails (depth grid 15 mm) 쮿 Impressions on the inner side of the side panel act as an anti-rotation guard and positioning aid for the horizontal rails 쮿 Square holes (6 x 6 mm) provide universal fixing for components such as backplane shielding; version without square holes available on request Side panel - horizontal rail assembly 06108062 쮿 Only one type of screw driver is needed for the assembly (torx panhead screw, M4 x 14; torque side panel - horizontal rail 2.4 Nm; torque side panel - cover plate 1.3 Nm) 쮿 4 versions of the side panel: – Type F = flexible – Type H = heavy – Type L = light – Type R = rugged Note 쮿 Type R - rugged side panels see "Rugged Subracks" section, page 6.97 Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Type F (flexible) 쮿 Universal version: 19" bracket (please order separately) can be fitted variably to front, rear or depth-offset 쮿 Heights: 3, 4, 6 and 9 U Depths: 175, 235, 275, 277.75, 295, 355, 415 and 475 mm; Other dimensions on request 쮿 2 EMC shielding concepts for the front/rear: stainless steel or textile EMC gasket 06197003 쮿 Installed load up to 11 kg Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Type H (heavy) 쮿 19" bracket is tox-cold welded to side panel; particularly designed for mechanically demanding environments (vibration resistance, applications requiring high levels of shock and vibration, e.g. IEC 61587-2) 쮿 Heights: 3 and 6 U Depths: 175, 235, 295 and 355 mm Other dimensions on request 06197004 쮿 2 EMC shielding concepts for the front/rear: with stainless steel or textile EMC gasekt 쮿 Installed load up to 15 kg Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Type L (light) 쮿 Side panel with moulded 19" bracket, for standard applications, unshielded 쮿 Particularly cost-effective version (not suitable for EMC applications) 쮿 Heights: 3 and 6 U Depths: 175, 235 and 295 mm Other dimensions on request 06197002 SCHROFF.PENTAIR.CO.UK 쮿 Installed load up to 7.5 kg Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.21 Subracks – DServicePLUS Side panels type F for stainless steel gasket Main Catalogue Order Information Side panel type F 19" bracket without handle holes 06197003 bza45819 with lateral without grooves for 19" bracket, stainless steel Al, 2 mm, EMC gasket, passivated, Al extrusion, please order rear side etched, 19“ bracket front anodised and corner profile separately 06108070 06108062 Height Depth U mm 1 piece PU 1 pair 3 175 34560-185 3 235 34560-187 3 275 1) 34579-300 3 277.75 2) 34579-002 24560-197 3 295 34560-189 3 355 34560-191 3 415 34560-193 3 475 34560-195 4 175 3) 34560-285 4 235 3) 34560-287 4 295 3) 34560-289 24560-297 4 355 3) 34560-291 4 415 3) 34560-293 4 475 3) 34560-295 6 175 34560-485 6 235 34560-487 6 275 1) 34579-038 6 277.75 2) 34579-012 6 295 34560-489 24560-497 6 355 34560-491 6 415 34560-493 6 475 34560-495 6 970 34560-496 9 175 34560-785 9 235 34560-787 9 295 34560-789 24560-797 9 355 34560-791 9 415 34560-793 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 24560-130 side panel Screw, M4 x 10, required if guide rails are screwed to slot 1, 24560-155 24560-155 PU 100 pieces 1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U 19" bracket with handle holes 06106050 19" bracket depthadjustable EMC gasket (stainless steel) 06102501 BGA45760 Rear angle Side panel connection BZA46573 BPA45867 with lateral grooves for stainless steel EMC gasket, Al extrusion, rear side etched, front anodised please order front handles separately, see page 6.27 Al extrusion, passivated inserted laterally into the grooves of the front panel Al extrusion, surface clear passivated; with lateral grooves for stainless steel EMC gasekt; rear hood cannot be mounted simultaneously Zn die-cast, incl. fixing material kit, for connecting two by two side panels (on top of each other) PU 1 pair PU 1 pair PU 10 pieces PU 1 pair PU 4 pieces 24560-198 24560-199 21101-705 24561-198 21101-954 24560-298 24560-299 21101-713 24561-298 21101-954 24560-498 24560-499 21101-707 24561-498 21101-954 24560-798 24560-799 21101-709 24561-798 21101-954 24560-130 24560-130 – 24560-130 – 24560-155 24560-155 – 24560-155 – 쮿 View of side panels 3, 4, 6, 9 U see page 6.20 6.22 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Side panels type F for textile EMC gasket Main Catalogue Order Information Side panel type F Illustration shows standard assembly, not VME or CompactPCI bus with rear I/O 06197003 19" bracket without handle holes bza45819 Al extrusion without for textile 19" bracket, EMC gasket Al, 2 mm, rear side etched, passivated, front anodised please order 19“ bracket and corner profile separately 19" bracket depthadjustable 19" bracket with handle holes 06106050 EMC gasket (textile) 06102501 04602054 Rear angle Side panel connection BZA46573 BPA45867 Al extrusion for textile EMC gasket, rear side etched, front anodised, please order front handles separately, see page 6.27 Al extrusion, passivated textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0 Al extrusion, etched; for textile EMC gasket Zn die-cast, incl. fixing material kit, for connecting two by two side panels (on top of each other) PU 1 pair PU 1 pair PU 10 pieces PU 1 pair PU 4 pieces 24564-198 24560-199 21101-853 24564-199 21101-954 24564-298 24560-299 21101-858 24564-299 21101-954 24564-498 24560-499 21101-855 24564-499 21101-954 24564-798 24560-799 21101-859 24564-799 21101-954 24560-130 24560-130 – 24560-130 – 24560-155 24560-155 – 24560-155 – 06108054 06108062 Height Depth U mm 1 piece PU 1 pair 3 175 34560-185 3 235 34560-187 3 275 1) 34579-300 3 277.75 2) 34579-002 24564-197 3 295 34560-189 3 355 34560-191 3 415 34560-193 3 475 34560-195 4 175 3) 34560-285 4 235 3) 34560-287 4 295 3) 34560-289 24564-297 4 355 3) 34560-291 4 415 3) 34560-293 4 475 3) 34560-295 6 175 34560-485 6 235 34560-487 6 275 1) 34579-038 6 277.75 2) 34579-012 6 295 34560-489 24564-497 6 355 34560-491 6 415 34560-493 6 475 34560-495 6 970 34560-496 9 175 34560-785 9 235 34560-787 9 295 34560-789 24564-797 9 355 34560-791 9 415 34560-793 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 24560-130 side panel Screw, M4 x 10, required if guide rails are screwed to slot 1, 24560-155 24560-155 PU 100 pieces 1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.23 Subracks – DServicePLUS Side panels type H for stainless steel EMC gasket Main Catalogue Order Information Side panel type H for stainless steel EMC gasket without with EMC gasket handle holes handle holes (stainless steel) 06197004 for high mechanical demands, 19" bracket, tox-cold welded, Al, 2 mm, clear passivated, front anodised 06108070 06108062 Height Depth 06107001 for high mechanical demands, 19" bracket, tox-cold welded, Al, 2 mm, clear passivated, front anodised, please order front handles separately see page 6.27 U mm PU 1 pair PU 1 pair 3 175 24566-125 24567-125 3 235 24566-127 24567-127 3 275 1) – – 3 277.75 2) – – 3 295 24566-129 24567-129 3 355 24566-131 24567-131 3 415 – – 3 475 – – 4 175 3) 4 235 3) 4 295 3) – – 4 355 3) 4 415 3) 4 475 3) 6 175 24566-425 24567-425 6 235 24566-427 24567-427 6 275 1) – – 6 277.75 2) – – 6 295 24566-429 24567-429 6 355 24566-431 24567-431 6 415 – – 6 475 – – 6 970 – – 9 175 9 235 – – 9 295 9 355 9 415 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 24560-130 side panel Screw, M4 x 10, required if 24560-155 24560-155 guide rails are screwed to slot 1, PU 100 pieces 1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U 6.24 SCHROFF PRODUCT CATALOG E 03/2016 Rear angle BGA45760 Side panel connection BZA46573 BPA45867 inserted laterally into the grooves of the front panel Al extrusion, surface clear passivated; with lateral grooves for stainless steel EMC gasekt; rear hood cannot be mounted simultaneously Zn die-cast, incl. fixing material kit, for connecting two by two side panels (on top of each other) PU 10 pieces PU 1 pair PU 4 pieces 21101-705 24561-198 21101-954 – – – 21101-707 24561-498 21101-954 – – – – 24560-130 – – 24560-155 – ELECTRONICS PROTECTION Subracks – DServicePLUS Side panels type H for textile EMC gasket Main Catalogue Order Information Side panel type H for textile EMC gasket without with EMC gasket handle holes handle holes (textile) Illustration shows standard assembly, not VME or CompactPCI bus with rear I/O 06108070 06108062 Height Depth 06197004 for high mechanical demands, 19" bracket, tox-cold welded, Al, 2 mm, clear passivated, front anodised 06107001 for high mechanical demands, 19" bracket, tox-cold welded, Al, 2 mm, clear passivated, front anodised, please order front handles separately see page 6.27 U mm PU 1 pair PU 1 pair 3 175 24564-145 24566-145 3 235 24564-147 24566-147 3 275 1) – – 3 277.75 2) – – 3 295 24564-149 24566-149 3 355 24564-151 24566-151 3 415 – – 3 475 – – 4 175 3) 4 235 3) 4 295 3) – – 4 355 3) 4 415 3) 4 475 3) 6 175 24564-445 24566-445 6 235 24564-447 24566-447 6 275 1) – – 6 277.75 2) – – 6 295 24564-449 24566-449 6 355 24564-451 24566-451 6 415 – – 6 475 – – 6 970 – – 9 175 9 235 – – 9 295 9 355 9 415 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 24560-130 side panel Screw, M4 x 10, required if guide rails are screwed to slot 1, 24560-155 24560-155 PU 100 pieces 1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U SCHROFF.PENTAIR.CO.UK Rear angle 04602054 Side panel connection BZA46573 BPA45867 textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0 Al extrusion, etched; for textile EMC gasket Zn die-cast, incl. fixing material kit, for connecting two by two side panels (on top of each other) PU 10 pieces PU 1 pair PU 4 pieces 21101-853 24564-199 21101-954 – – – 21101-855 24564-499 21101-954 – – – – 24560-130 – – 24560-155 – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.25 Subracks – DServicePLUS Side panels type L Main Catalogue Order Information Side panel type L 06197002 Al, 2 mm, passivated Front cover Collar screw with slot for assembly of front cover BZA45810 for decorative finish of 19" bracket, Al, 2 mm, anodised Sleeves for assembly of front cover 06708055 Side panel connection 00508056 BPA45867 M6 x 16, St, nickel-plated PPE, black Zn die-cast, incl. fixing material kit, for connecting two by two side panels (on top of each other) PU 100 pieces PU 100 pieces PU 4 pieces 21100-565 21100-566 21101-954 – – – 21100-565 21100-566 21101-954 – – – – – – – – – 06108062 Height Depth U mm 1 piece 3 175 34561-185 3 235 34561-187 3 275 1) – 3 277.75 2) – 34561-197 3 295 34561-189 3 355 – 3 415 – 3 475 – 4 175 3) 4 235 3) 4 295 3) – – 4 355 3) 4 415 3) 4 475 3) 6 175 34561-485 6 235 34561-487 6 275 1) – 6 277.75 2) – 6 295 34561-489 34561-497 6 355 – 6 415 – 6 475 – 6 970 – 9 175 9 235 – – 9 295 9 355 9 415 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 – side panel Screw, M4 x 10, required if guide rails are screwed to slot 1, 24560-155 – PU 100 pieces 1) CompactPCI 2) VME64x 3) Grid holes of side panel 3 + 1 U 6.26 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Front handles, wall-mounting brackets Main Catalogue Order Information Wall-mounting bracket E HE 12 H H E 12 ,2 Universal front handle HE Front handle clear anodised black anodised 40 AI extrusion, anodised load-carrying capacity 30 kg 06102068 40 06102069 3 parts: Al extrusion, clear anodised, 2 end pieces, plastic, PA, black; width 12 mm, depth 40 mm load-carrying capacity 10 kg 06104063 Al, 2.5 mm, passivated; bolted to subrack in place of the 19" bracket Height Depth H E U mm mm mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 3 175 102 88.0 3 235 102 88.0 3 275 102 88.0 3 277.75 102 88.0 10501-005 10501-026 10502-057 3 295 102 88.0 3 355 102 88.0 3 415 102 88.0 3 475 102 88.0 4 175 146 133.4 4 235 146 133.4 4 295 146 133.4 – 10501-018 10502-060 4 355 146 133.4 4 415 146 133.4 4 475 146 133.4 6 175 249 235.0 6 235 249 235.0 6 275 249 235.0 6 277.75 249 235.0 6 295 249 235.0 10501-008 10501-029 10502-065 6 355 249 235.0 6 415 249 235.0 6 475 249 235.0 6 970 249 235.0 9 175 249 235.0 9 235 249 235.0 9 295 249 235.0 10501-008 10501-029 10502-065 9 355 249 235.0 9 415 249 235.0 Screw M5 x 12, PU 100 pieces 24560-183 24560-183 24560-183 Screw M5 x 12, PU 4 pieces 24560-182 24560-182 24560-182 Screw, M4 x 14, PU 100 pieces – – – 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple SCHROFF.PENTAIR.CO.UK PU 1 pair 24562-197 24562-297 24562-497 24562-797 – – 24560-130 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.27 Subracks – DServicePLUS Horizontal rails Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Aluminium profile, surface anodised, conductive contact surfaces for EMC gaskets 쮿 The horizontal rail is marked with sequential numbering (for sizes > 28 HP) to facilitate positioning of the guide rails light 06197007 heavy 06197008 06112004 rugged 쮿 Horizontal rails are fixed to the side panel using M4 bolts with torx 20 drive 쮿 There are 3 different horizontal rails for different loading levels – light, for up to 7.5 kg – heavy, for 7.5 kg to 15 kg – rugged, for 15 kg to approx. 60 kg Mounting position of the horizontal rails PCB as deep as side panel front Cabling space behind backplane rear front Rear I/O installation (CompactPCI, VME64x applications) front rear rear H-KD 3U L-KD H-KD L-KD H-KD L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-KD H-KD L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ H-KD AB H-ST / H-VT H-LD D2 D = D1 H-LD D1 D1 D D 160, 220, 280 mm, .... 06112081 160, 220, 280 mm, .... 06112083 160 mm/80 mm 06112085 L-KD H-KD L-KD H-KD L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ ST / VT / MZ ST / VT / MZ 6U=3U+3U D3 D2 D2 L-KD H-KD L-KD L-OD L-KD L-OD AB AB L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-KD H-KD L-KD H-KD D2 D2 D1 D = D1 D 160, 220, 280 mm, .... 06112088 160, 220, 280 mm, .... 06112087 H-LD 6U L-KD H-KD H-ST / H-VT L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ ST / VT / MZ L-KD H-KD ST / VT / MZ AB L-KD H-KD L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ L-ST / L-VT / L-MZ H-ST / H-VT / H-MZ H-LD H-ST / H-VT H-LD H-LD D2 D1 D1 D = D1 D D 160, 220, 280 mm, .... 6.28 06112082 160, 220, 280 mm, .... SCHROFF PRODUCT CATALOG E 03/2016 D3 D2 D2 06112084 160 mm/80 mm 06112086 ELECTRONICS PROTECTION Subracks – DServicePLUS Front horizontal rails Assembly 3 U, 2 x 3 U, 6 U "light" (L) 3 U/6 U Short lip "heavy" (H) "heavy" (H) 06197007 06197008 Short lip 06197009 Long lip 10 H - LD 3 3 12,75 15 3 12,75 15 12,75 15 3 HE/U 3/6 HE/U 6U 3/6 HE/U 6 HE/U H - KD H - KD L - KD 3 12,75 bza44980 bza44974 H - LD H - KD L - KD 06105060 06105061 06108063 2x3U L - KD 12,75 3 H - KD 12,75 15 3 12,75 15 L - KD H - KD H - LD L - KD H - KD H - KD 3U 3U 3 H - KD 10 L - KD bza44972 H - KD 06105062 H - LD 06105063 06108064 2 x 3 U, 6 U L - KD 3 12,75 H - KD 3 10 12,75 15 H - LD 3 6U L - OD 06105059 L - OD L - OD L - OD L - KD H - KD 06105064 12,75 15 L - OD L - OD H - LD 06105065 06108065 L-OD = Light - without lip, L-KD = Light - short lip, H-KD = Heavy - short lip, H-LD = Heavy - long lip SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.29 Subracks – DServicePLUS Front horizontal rails Main Catalogue Order Information "light" Type L-OD without lip bza44980 With HP markings from 28 HP, Al extrusion, anodised finish, conductive contact surface "light" Type L-KD short lip 06197006 With long lip for insertion/ extraction of CompactPCI and VME64x boards "heavy" Type H-LD long lip "heavy" Type H-KD short lip 06197007 06197008 06197009 Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings Al extrusion, anodised finish, conductive contact surface, with printed HP markings without lip: 2 x 3 U installation and continuous 6 U front panel short lip: horizontal rail and front panel form a single plane short lip: horizontal rail and front panel form a single plane long lip: for insertion/extraction of CompactPCI or VME64x boards Usable length HP Length mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 20 28 40 42 63 84 – 106.68 147.32 208.28 218.44 325.12 431.80 1000 34560-020 34560-120 34560-220 34560-320 34560-028 34560-128 34560-228 34560-328 34560-040 34560-042 34560-140 34560-142 34560-240 34560-242 34560-340 34560-342 34560-063 34560-163 34560-263 34560-363 34560-084 34560-001 34560-184 34560-101 34560-284 34560-201 34560-384 34560-301 Screw, M4 x 14, PU 100 pieces 24560-130 24560-130 24560-130 24560-130 – – 24560-155 24560-155 6.35 6.35 6.35 6.35 Screw, M4 x 10, required if guide rails are screwed to slot 1, PU 100 pieces Threaded inserts see page 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 1000 mm version without M4 thread to front, without printed markings and without notch for 19"-bracket 쮿 Rugged horizontal rails with 3 fixing holes see section "Rugged Subracks", page 6.99 6.30 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Rear horizontal rails Indirect backplane mounting (with insulation strip) Direct backplane mounting Connector fitting with Z Text 04400001 12,75 3 12,75 L - ST 9,75 04400002 04400003 3 12,75 L - VT L - MZ VT MZ 3 "light" ST L - ST L - VT L - MZ 06105072 15 12,75 3 15 H - ST 9,75 06105073 12,75 06105071 3 15 H - VT H - MZ VT MZ 12,75 3 "heavy" ST H - ST ST = standard, L = light, H = heavy SCHROFF.PENTAIR.CO.UK H - VT 06108066 H - MZ VT = depth-offset, L = light, H = heavy 06108067 MZ = with Z-rail, L = light, H = heavy Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 06108068 6.31 Subracks – DServicePLUS Rear horizontal rails, top and bottom Main Catalogue Order Information For indirect backplane mounting with insulation strip For direct backplane mounting 04400001 "light" Type L-ST standard 06105074 With HP markings from 28 HP, Al extrusion, anodised finish, conductive surface 06197010 Al extrusion, anodised surface, conductive contact surface, with printed HP markings "heavy" Type H-ST standard 04400002 "light" Type L-VT + 3 mm 06197011 Al extrusion, anodised surface, conductive contact surface, with printed HP markings For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) 06197011 Al extrusion, anodised surface, conductive contact surface, with printed HP markings "heavy" Type H-VT + 3 mm 06197009 Al extrusion, anodised surface, conductive contact surface, with printed HP markings 04400003 "light" Type L-MZ with Z-rail 06197014 Al extrusion, anodised surface, conductive contact surface, with printed HP markings "heavy" Type H-MZ with Z-rail 06197015 Al extrusion, anodised surface, conductive contact surface, with printed HP markings Usable length Length 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) HP mm 20 106.68 34560-420 34560-520 34560-620 34560-720 34560-820 34560-920 28 147.32 34560-428 34560-528 34560-628 34560-728 34560-828 34560-928 40 208.28 34560-440 34560-540 34560-640 34560-740 34560-840 34560-940 42 218.44 34560-442 34560-542 34560-642 34560-742 34560-842 34560-942 63 325.12 34560-463 34560-563 34560-663 34560-763 34560-863 34560-963 84 431.80 34560-484 34560-584 34560-684 34560-784 34560-884 34560-984 – 1000 – 34560-401 34560-501 34560-601 34560-701 34560-801 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to 24560-130 24560-130 24560-130 24560-130 24560-130 24560-130 side panel Screw, M4 x 10, required if guide rails are screwed to slot 1, – – – 24560-155 24560-155 24560-155 PU 100 pieces Perforated rail for connector mounting with insulation strip 6.36 6.36 – – – – see page Z-rail for connector mounting 6.36 6.36 – – – – without insulation strip see page Insulation strips see page 6.35 6.35 – – – – Threaded inserts see page 6.35 6.35 6.35 6.35 6.35 6.35 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 1000 mm version without M4 thread to front, without printed markings and without notch for 19"-bracket 쮿 Rugged horizontal rails with 3 fixing holes see section "Rugged Subracks", page 6.99 6.32 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Rear horizontal rails, centre, for 6 U Main Catalogue Order Information For indirect backplane mounting with insulation strip For direct backplane mounting 04400001 04400002 Typ ST 06108090 Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to side panel Insulation strips see page Threaded inserts see page For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) Typ VT 06197016 04400003 Typ MZ 06197017 06197018 Al extrusion, anodised surface, conductive contact surface, without printed markings Al extrusion, anodised surface, conductive contact surface, without printed markings Al extrusion, anodised surface, conductive contact surface, without printed markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34561-020 34561-028 34561-120 34561-128 34561-220 34561-228 34561-040 34561-140 34561-240 34561-042 34561-063 34561-142 34561-163 34561-242 34561-263 34561-084 34561-184 34561-284 34561-001 34561-101 34561-201 24560-130 24560-130 24560-130 6.35 6.35 – 6.35 – 6.35 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 All horizontal rails without printed markings 쮿 1000 mm version without M4 thread to front SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.33 Subracks – DServicePLUS Horizontal rails (type AB) for rear I/O applications Main Catalogue Order Information For CompactPCI in rear I/O area 12,75 AB H - ST 9,75 15 12,75 H - KD 3 06108009 Typ AB H - ST AB H - KD 06108069 06197019 Al extrusion, anodised surface, conductive contact surface; horizontal rail type AB (AB = support) is required to fix the 80 mm rear I/O boards; without printed markings Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Screw, M4 x 14, PU 100 pieces, for fastening horizontal rail to side panel 1 piece (SPQ 10)1) 34561-520 34561-528 34561-540 34561-542 34561-563 34561-584 34561-501 24560-130 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "light": loading capacity up to approx. 7.5 kg; "heavy": loading capacity > 7.5 kg Note 쮿 All horizontal rails without printed markings 쮿 1000 mm version without M4 thread to front 6.34 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Threaded inserts, perforated strips, insulation strips Main Catalogue Order Information Threaded insert M2.5 M3 Perforated strip (item 1) Insulation strip 5 2 5 ,0 8 06103056 required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.66 Usable length HP Threaded insert Length mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) – – – – – BZA45853 for centring shielded plug-in units, Al, 1 mm, please order grub screw separately Perforated strip Length mm 1 piece (SPQ 10)1) BZ6749 for insulated backplane mounting; PBT UL 94 V-0, grey Insulation strip Length mm 20 106.18 34561-320 106.48 30845-189 101.50 28 146.82 147.12 144.20 34561-328 30845-197 40 207.78 208.08 205.12 34561-340 30845-209 42 217.94 34561-342 218.24 30845-211 210.40 63 324.62 324.92 316.88 34561-363 30845-232 84 431.30 431.60 428.64 34561-384 34561-484 30845-253 196 1000.26 34565-196 – 1000.56 34565-396 Accessories Grub screw M2.5 x 8, 21100-276 – – PU 100 pieces Grub screw M2.5 x 9, – – 21101-359 PU 100 pieces Grub screw M3 x 8, – – 21100-646 PU 100 pieces 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU SCHROFF.PENTAIR.CO.UK PU 10 pieces 24560-820 24560-828 24560-840 24560-842 24560-863 24560-884 – – – – Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.35 Subracks – DServicePLUS Z-rails, perforated rails Main Catalogue Order Information Z-rail for connectors DIN EN 60603-2, DIN 41612 31-pin, DIN 41617 item 1 Perforated rail EN 606032, DIN 41612 item 1 172,5 175,5 172,5 BZA45849 75 12, 5 9 ,7 BZA45850 BZA45848 5 7 12, 3 ,0 2 2 1 1 3 3 06708063 Usable length Length HP mm 20 101.60 28 142.24 40 203.20 42 213.36 60 304.80 84 426.72 Item 3, torx panhead screw to fix connector to perforated rail,, M2.5 × 7, PU 100 pieces Item 2, torx panhead screw, to fix perforated rails to horizontal rail, M2.5 × 10, PU 100 pieces 6.36 SCHROFF PRODUCT CATALOG E 03/2016 06708051 for connector mounting on ST horizontal rails, please order threaded inserts and screw separately for connector mounting on ST horizontal rails, please order threaded inserts and screw separately for connector mounting on VT horizontal rails, please order threaded inserts and screw separately 1 piece 1 piece – – PU 4 pieces 30822-025 30822-033 30822-045 20822-051 30819-763 20822-049 20822-046 30822-047 – 20822-050 30822-065 30822-089 30819-783 30819-808 20822-047 20822-048 24560-147 24560-147 24560-147 24560-148 24560-148 24560-148 ELECTRONICS PROTECTION Subracks – DServicePLUS Guide rails Main Catalogue Guide rails form the interface between the subrack mechanics and the sub-assemblies (PCBs, plug-in units, frame-type plug-in units, ...). 3,55 0,3 DIN 41612 Guide rails for standard applications are 2 HP wide. Guide rails with coding (e.g. for CompactPCI or VME64bus applications) are 4 HP wide. There are groove widths of 2 mm and 2.5 mm. The guide rails are clipped into the rectangular cut-outs of the horizontal rails. They can additionally be bolted to the horizontal rail (type H only) for higher shock and vibration requirements. 4,07 The printed HP markings on the horizontal rail (28 HP and above) allow the rails to be fitted in the correct position easily (position of sub-assembly = "number in viewing window" or in front of the arrow marking on the guide rails). 5,08 3,55 2,54 Front view: position of guide rails to connector (EN 60603-2/ DIN 41612) 06108083 Applications for guide rails For plug-in units and frame-type plug-in units (with front panels) (standard type) 06102001 For plug-in units and frame type plug-in units or for PCBs without their own front panel (accessory type or robust version) 06102002 06102005 For CompactPCI or VME64x plug-in units (type IEEE with coding; frame-type plug-in units cannot be fitted) 06106001 For plug-in drive unit modules or PCBs in 4.4" (111.7 mm) height (type 4.4") 06104009 Rugged guide rails to accommodate conduction cooled assembly (CCA) adaptor 06112022 SCHROFF.PENTAIR.CO.UK Accessories: - ESD clip - Keying/coding pegs - Board locking Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.37 Subracks – DServicePLUS Guide rails for plug-in units and modules, one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information For plug-in units and frame type plug-in units standard type Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates standard type, with DIN connector fixing Storage temperature from -40 °C ... 130 °C 06102001 06101501 up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0 PBT, UL 94 V-0, red, connector is clipped directly onto the guide rails; for euroboards only, 100 x 160 mm or 100 x 220 mm PU 10 pieces2) – – 1 piece (SPQ 50)1) 34579-230 34579-231 1 pair (SPQ 10)1) – – 24560-351 64560-001 64560-074 24560-353 24560-379 64560-002 64560-075 24560-380 – – – – 64560-096 64560-098 – – – – Retention screw, PU 100 pieces; Torque max. 0.2 Nm 24560-141 – 24560-141 ESD clip, PU 50 pieces 24560-255 Board length Groove width mm mm 70 2 70 2 160 2 220 2 280 2 340 2 160 2.5 220 2.5 Colour mm red grey red red red red red red Accessories 24560-255 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 6.38 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Guide rails type "accessory", one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Guide rails "Accessories" with DIN connector mounting accessory type accessory type, strengthened for heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... +130 °C 06102002 up to 280 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94 V-0, middle section Al extrusion Board length mm 100 160 160 220 220 280 340 400 160 220 280 340 400 Groove width mm 2 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 Colour red red grey/silver red grey/silver red/silver red/silver red/silver silver silver silver silver silver 06102005 06102005 06102005 PBT, UL 94 V-0, connector is bolted directly onto the guide rails, only suitable for euroboards 100 x 160 mm or 100 x 220 mm PBT UL 94 V-0, red; support beam of guide rails adds to strengthening Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces2) – 1 piece (SPQ 50) 64560-082 PU 10 pairs2) – 1 piece (SPQ 50) – 24560-373 24560-274 24560-276 64560-076 – 64560-005 64560-055 1 piece (SPQ 10)1) – – – 34562-881 24560-374 64560-006 24560-275 64560-078 – – 64560-166 24560-277 – 24560-375 – – – – – – – – 64560-080 – – – – – – – 34562-884 – – – – – – – – – – – – – – 34562-882 34562-883 24560-141 24560-141 24560-141 24560-141 24560-157 24560-255 24560-255 24560-255 24560-255 – 24560-377 24560-377 24560-377 24560-377 – 24560-378 24560-378 24560-378 24560-378 – 60817-228 60817-228 60817-228 60817-228 – 24560-376 34562-885 34564-881 34564-882 34564-883 34564-884 34564-885 Accessories Retention screw, PU 100 pieces; torque max. 0.2 Nm ESD clip, PU 50 pieces Board locking C, red, PU 10 pieces Board handle C, red, PU 10 pieces Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page 6.43 – 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.39 Subracks – DServicePLUS Guide rails for CompactPCI, VME64x with coding, 4.4" PCBs, groove width 2 mm and 2.5 mm Main Catalogue Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into1.5 mm thick plates For CompactPCI, VME64x with coding In accordance with IEEE 1101.10 Offset 0.1" for power supply units and IEC 60297-3-103 in accordance with IEEE 1101.10 and IEC 60297-3-103 For 4.4" PCBs Storage temperature from -40 °C ... 130 °C 06106001 Board length mm 70 70 160 160 160 220 220 220 160 220 220 280 280 340 340 Groove width mm 2 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 2.5 2.5 Colour mm red grey red grey green red grey green red red grey red grey red grey 04611009 06106002 One-piece, PBT, UL 94 V-0; for 4.4" PCBs or drive unit modules One-piece for groove width 2 mm, PBT, UL 94 V-0; multi-piece at groove width 2,5 mm, end-piece PBT, UL 94 V-0, center piece Al PBT, UL 94 V-0 PU 10 pieces 1 piece (SPQ 50)1) PU 10 pieces 1 piece (SPQ 50)1) PU 10 pieces 1 piece (SPQ 50)1) 24560-355 64560-085 24560-360 24560-356 64560-086 64560-089 – – 24560-361 64560-143 64560-090 – – – – – – 24560-358 – – – – – – – – – – 24560-359 64560-071 – – – – 64560-091 – – 24560-362 64560-144 – – – – – – – – – – – – – – – – – – 24561-332 24561-342 – – – – – – – – – – – – – – – – – – 24560-255 24560-255 – – – – 24560-256 24560-256 24560-256 24560-256 – – 24560-141 24560-141 24560-141 24560-141 24560-158 24560-158 20817-501 20817-501 20817-501 20817-501 – – 24561-330 24561-340 24561-331 24561-341 64560-092 PBT, UL 94 V-0, for installation of power supplies in CompactPCI systems or plug-in units with SMD placement 06104009 64560-072 64560-145 64560-146 – – – – – Accessories ESD clip, PU 50 pieces ESD clips, for alignment pin, PU 50 pieces Retention screw, PU 100 pieces; torque max. 0.2 Nm Coding peg, PU 100 pieces 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 6.40 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Subracks – DServicePLUS Guide rails, multi-piece, groove width 2 mm Main Catalogue Order Information PCBs: Fixed lengths for 160, 220, 280, 340 mm; length 1000 mm for special dimensions For plug-in units and modules standard type Accessories type For 4.4" PCBs Mounting: pluggable into horizontal rails Storage temperature : End piece -40°C ... +130°C PVC profile 0°C ... +60°C 06106004 Description End piece, red, 1 pair Al extrusion, for 160 mm board length Al extrusion, for 220 mm board length Al extrusion, for 280 mm board length Al extrusion, for 340 mm board length Al extrusion, for any board length Plastic extrusion, for any board length 06106005 06106006 end piece, PBT, UL 94 V-0, middle section Al extrusion end piece, PBT, UL 94 V-0, middle section plastic extrusion (PVC, RAL 7035) end piece, PBT, UL 94 V-0, middle section Al extrusion end piece, PBT, UL 94 V-0, middle section plastic extrusion (PVC, RAL 7035) end piece, PBT, UL 94 V-0, middle section Al extrusion end piece, PBT, UL 94 V-0, middle section plastic extrusion (PVC, RAL 7035) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 2 64560-004 64560-004 64560-008 64560-008 64560-057 64560-057 95 2 34560-891 34564-891 34560-891 34564-891 34560-891 34564-891 155 2 34560-892 34564-892 34560-892 34564-892 34560-892 34564-892 215 2 34560-893 34564-893 34560-893 34564-893 34560-893 34564-893 275 2 34560-894 – 34560-894 – 34560-894 – 1000 2 34560-900 – 34560-900 – 34560-900 – 1000 2 – 34564-900 – 34564-900 – 34564-900 24560-255 24560-255 24560-255 24560-255 – – 24560-141 24560-141 24560-141 24560-141 24560-158 24560-158 – – – – 24560-377 24560-377 24560-378 24560-378 – – – – – – 60817-228 60817-228 – – – – – – Length Groove width mm mm Accessories ESD clip, PU 50 pieces Retention screw, PU 100 pieces; torque max. 0.2 Nm Board locking C, red, PU 10 pieces Board handle C, red, PU 10 pieces Identification strips for board handle, red, PU 1 sheet = 438 pieces Coding see page see page 6.43 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.43 Note 쮿 Strengthening for middle section (plastic extrusion) available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.41 Subracks – DServicePLUS Dimension drawings of guide rails Standard Robust version D2 D2 A4 C 6,7 8,7 C B B D D bza45808 For accessories A1 C C 6,55 A1 B B D D bza45808 CompactPCI, VME64x bza46552 4.4" (111.7 mm) D2 A3 C C 0,8 A2 2,85 6,55 D2 8,55 19,95 D2 8,55 6,55 8,55 D2 B B D D 06105068 Dimensions table Board length L mm 70 100 160 220 280 340 400 06105074 For accessories, strengthened 7,9 6,55 8,55 A 06105069 Text A mm 71.5 101.5 161.5 221.5 281.5 341.5 401.5 A1 mm 47.9 77.9 137.9 197.9 257.9 317.9 377.9 A2 mm 59.39 89.39 149.39 209.39 269.39 322.39 389.39 A3 mm 63 93 153 213 273 333 393 Dimensions A4 mm 49 79 139 199 259 319 379 B mm 45 75 135 195 255 315 375 C mm 30 60 120 180 240 300 360 D mm 60 90 150 210 270 330 390 A, A1, A2, A3, A4: Length of rail B: Pitch of snap-in fixing C: Pitch of guide rail retention screws D: Pitch of horizontal rail retention screws 6.42 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Subracks – DServicePLUS Guide rail accessories Main Catalogue Order Information ESD clips, CompactPCI/VME 64 alignment pin for guide rails Coding for subracks Keying/coding block for Keying/coding guide rails accessory type for CompactPCI, VME64x handles to IEEE 1011.10 and IEC 60297-3-103 06103052 06103051 PBT, UL 94 V-0, Spring steel, tin-plated, ESD clip, keying/coding block is clipped into the for alignment pin in accordance with IEEE; horizontal rail next to the guide rail; can be plugged into the guide rails with coding and into the keying/coding block; please order keying/coding pegs separately provides conductive contact between the alignment pin of the insertion/extractor handle (IEL or IET handle) and the horizontal rail Assembly above below 04612052 Keying/coding peg, PBTP, UL 94 V-0, RAL 7035 The keying/coding pegs prevent plug-in units to be mounted in wrong slots. They are inserted in the chambers of the codable card guides as well as in the insertion/extractor handles IEL or IET (4 possible positions), resulting in 64 codings per card guide; when coding the upper and lower card guide, 4096 codings will result; Colour red grey silver red grey silver PU 50 pieces 1 piece (SPQ 50) – – 34579-232 PU 100 pieces – 34579-233 20817-501 24560-256 – – – 34579-234 – – 34579-235 20817-501 24560-256 – – 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Guide rail accessories Main Catalogue Order Information ESD clips for guide rails Board locking C for PCBs without front panel; for accessory type guide rails 04503050 Spring steel, tin-plated, provides conductive contact between board and horizontal rail, on both the solder side and the component side Assembly mm above/below Colour SCHROFF.PENTAIR.CO.UK PCB handle C for board locking; for accessory type guide rails 04805050 PBT, UL 94 V-0, red, to fix the PCB in the subrack (also slot 1), can also be used without board handle, minimum distance 3 HP Identification strips 04805051 06108076 Polyester film, 31 x 4 mm, PBT, UL 94 V-0, red, self-adhesive, white/matt insertion/extraction function with connection to board locking (1 A4 sheet contains 438 pieces) (also slot 1), mounting directly behind front panel (above and below), minimum distance 3 HP silver red red PU 50 pieces PU 10 pieces PU 10 pieces white/matt 1 piece 24560-255 24560-377 24560-378 60817-228 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.43 Subracks – DServicePLUS Shielding for top and bottom Main Catalogue Cover plates can be used for electromagnetic shielding (with EMC contact springs) or as mechanical protection (without EMC springs) Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Cover plates for mechanical protection 쮿 Cover plates are inserted into the grooves of the front and rear horizontal rails, type L "light" see page 6.45 06108077 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Cover plates with EMC shielding and mechanical protection EMC cover plates for top and bottom 쮿 Inserted in the groove of the front and rear horizontal rails; shielding with contact springs, lateral contact by bolting the bracket to the side panel 쮿 Used when standard-depth PCBs (160, 220, 280, ...) are fitted see page 6.46 06102084 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Universal EMC cover plates for top and bottom 쮿 Inserted in the groove of the front and rear horizontal rails; shielding with contact springs, lateral contact by bolting to the side panel with special contact springs 쮿 Used when PCBs with special dimensions are fitted see page 6.47 06105082 6.44 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Cover plates for mechanical protection (insertion into horizontal rail type L Order Information Cover plates for insertion into horizontal rail type L 1 06108058 Perforated Al plate, 1.2 mm, hole diameter 3.8 mm, AI, untreated, perforation degree 60 %; for insertion into the groove of the light horizontal rails (type L) 06197010 Width HP 42 63 84 84 Depth mm 175 175 175 235 Application PU 1 pair 160 mm board depth 160 mm board depth 160 mm board depth 220 mm board depth 24561-031 24561-041 24561-051 24561-052 Note 쮿 Other dimensions on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.45 Subracks – DServicePLUS EMC cover plates and mechanical protection 쮿 Cover plate for bolting to side panel 쮿 Used when standard-depth PCBs (160, 220, 280, ...) are fitted Order Information Cover plate for bolting to side panel Stainless steel EMC gasket, between cover plate and horizontal rail d = D - 25 3 HE / U 160 / 220 / 280 D 06102082 AI, 1.0 mm, hole diameter 4.0 mm, passivated, perforation degree 58 %, incl. fixing screws; for shielding 4 stainless steel EMC gaskets are required per subrack 06106052 stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails 06197010 Width HP 42 42 42 42 42 63 63 63 63 84 84 84 84 84 84 84 84 Depth mm 175 235 275 277.75 295 175 235 275 295 175 235 275 277.75 295 355 415 475 Application PU 1 pair 160 mm board depth 160, 220 mm board depth 160, 220 mm board depth CompactPCI (275 mm) 160, 220 mm board depth VME64x (277.75 mm) 160, 220, 280 mm board depth 160 mm board depth 160, 220 mm board depth 160, 220 mm board depth CompactPCI (275 mm) 160, 220, 280 mm board depth 160 mm board depth 160, 220 mm board depth 160, 220 mm board depth CompactPCI (275 mm) 160, 220 mm board depth VME64x (277.75 mm) 160, 220, 280 mm board depth 160, 220, 280 mm board depth 160, 220, 280 mm board depth 160, 220, 280 mm board depth PU 10 pieces PU 100 pieces 24560-241 – 24560-243 – 24560-245 24560-246 24560-064 24560-065 24560-061 24579-090 24560-066 24560-071 24560-072 24560-062 24560-073 24560-078 24560-079 24560-063 24579-092 24560-080 24560-081 24560-082 24560-083 Assembly tool, for EMC gasket, stainless steel (horizontal rails), 1 piece – 24560-271 Note 쮿 Cover plates without perforation available on request 6.46 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Universal EMC cover plates and mechanical protection 쮿 Used when PCBs with special dimensions are fitted Order Information Universal cover plate Stainless steel EMC gasket, between cover plate and horizontal rail d = D - 25 3 HE / U 160 / 220 / 280 D AI, 1.0 mm, hole diameter 4.0 mm, passivated, perforation degree 58 %, incl. lateral EMC sealing, incl. fixing screws 06108079 06106052 stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails 06105082 Width HP 42 42 42 63 63 63 84 84 84 84 84 84 Depth mm 175 235 295 175 235 295 175 235 295 355 415 475 Application PU 1 pair 160 mm board depth 160, 220 mm board depth 160, 220, 280 mm board depth 160 mm board depth 160, 220 mm board depth 160, 220, 280 mm board depth 160 mm board depth 160, 220 mm board depth 160, 220, 280 mm board depth 160, 220, 280 mm board depth 160, 220, 280 mm board depth 160, 220, 280 mm board depth Assembly tool, for EMC gasket, stainless steel (horizontal rails), 1 piece SCHROFF.PENTAIR.CO.UK PU 10 pieces PU 100 pieces 24560-241 – 24560-243 – 24560-245 24560-246 24560-031 24560-032 24560-033 24560-041 24560-042 24560-043 24560-051 24560-052 24560-053 24560-054 24560-055 24560-056 – 24560-271 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.47 Subracks – DServicePLUS Cover/shielding to front and rear Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 The front and rear sides of the subrack can be shielded by a hinged front panel or by a fixed front panel and 19" brackets 쮿 The rear can be shielded with a front panel and a corner profile Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Rear hood BZA45814 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Front panel for front and rear 06112089 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Front panel, hinged/pivoted 135° 06112090 6.48 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Rear hood for 3 U and 6 U subracks (for stainless steel EMC gasket) Order Information Rear hood Stainless steel EMC gasket, between cover plate and horizontal rail bza45819 Al, 1 mm, clear passivated; 60 mm additional side panel depth required (board depth + 60 mm); for shielding please order EMC gasket for horizontal rail separately; cannot be used simultaneously with rear corner profile 06106052 stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails bza45814 Height U 3 3 6 6 Torx panhead screw, M4 × 6, St, zinc-plated, PU 100 pieces Width HP 42 84 63 84 1 piece PU 10 pieces 34561-750 34561-752 24560-241 24560-245 PU 100 pieces – 34561-763 24560-243 – 34561-764 24560-245 24560-246 24560-246 24560-135 – – 24560-271 Assembly tool, for EMC gasket, stainless steel (horizontal rails), 1 piece Note 쮿 Other dimensions of rear hood available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.49 Subracks – DServicePLUS Front/rear panels, unshielded FRONT PANEL EXPRESS Order Information Front panel pre-anodised, cut edges plain anodised Front anodised, rear iridescent green chromated Al, 2.5 mm Al, 2.5 mm Al, 2.5 mm 04292001 Height U Height mm Width HP 1 1 1 1 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 9 9 9 9 9 44.45 44.45 44.45 44.45 84.0 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 172.9 172.9 172.9 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 395.1 395.1 395.1 395.1 395.1 28 42 63 84 84 2 3 4 5 6 7 8 10 12 14 21 28 42 63 84 42 63 84 2 4 5 6 7 8 10 12 14 16 21 28 42 63 84 4 8 10 12 84 1 piece – – – – 30818-271 1 piece (SPQ 5)1) – – – – – – – – – – – – – – – – – 30810-433 30818-272 30818-310 30818-331 1 piece – – – – 30807-416 1 piece (SPQ 5)1) – – – – – – – – – – – – – – – – – 30810-432 30807-508 – – – – – – 30807-494 30808-067 – – – – – – – – – – – – 30818-747 30818-518 30818-556 30818-577 – – – – – – – – 30818-352 – – 30818-434 30818-598 – – – – – 1 piece 20850-423 20850-424 20850-425 20850-426 30847-461 1 piece (SPQ 5)1) – – – – – – – – – – – – – – – – – 30847-470 30847-471 – – – – – – 30838-081 30838-102 – – – – – – – – – – – – – – – – – – 30818-741 – – – – – – – – – – – – 30847-472 30838-124 30807-764 30807-771 – – – – – – – – 30838-162 30838-183 – – – 30818-273 30818-274 30818-275 30818-276 30818-277 30818-279 30818-281 30818-282 30818-289 30818-296 30807-506 – – 30807-596 – – – 30818-522 30818-524 30818-526 30818-528 30818-530 30818-535 30818-542 30807-776 – – – – – 30807-481 30807-510 30807-482 30807-509 30807-484 30807-483 30807-485 30807-501 30807-487 30807-496 – – – – – 30807-753 – 30807-758 – 30807-757 30807-766 30838-123 30847-463 30847-464 30847-465 30838-204 30838-043 30838-044 30838-045 30838-046 30838-047 30838-049 30838-051 30838-053 30838-060 30838-067 30838-125 30838-126 30838-127 30838-128 30838-130 30838-132 30838-134 30838-136 30838-141 30838-148 – – – – 30847-476 30847-480 30847-556 – 30847-482 30847-484 쮿Front panel assembly kits, sleeves, collar screws, quick-release fasteners see page 6.65 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 6.50 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Front/rear panels shieldable with stainless steel EMC gasket FRONT PANEL EXPRESS Order Information Front panel Front panel for shielding with EMC gasket (stainless steel) Stainless steel EMC gasket Al, 2.5 mm, front anodized, rear iridescent green inserted laterally into the grooves of the front panel, chromated, 2 alignment pins pressed-in, St, stainless suited for temperatures above 70 °C 04292001 Height Height Width U mm HP 2 84 84 3 128.4 2 3 128.4 3 3 128.4 4 3 128.4 5 3 128.4 6 3 128.4 7 3 128.4 8 3 128.4 10 3 128.4 12 3 128.4 14 3 128.4 21 3 128.4 28 3 128.4 42 3 128.4 63 3 128.4 84 4 172.9 42 4 172.9 63 4 172.9 84 6 261.8 2 6 261.8 4 6 261.8 5 6 261.8 6 6 261.8 7 6 261.8 8 6 261.8 10 6 261.8 12 6 261.8 14 6 261.8 16 6 261.8 21 6 261.8 28 6 261.8 42 6 261.8 63 6 261.8 84 9 395.1 84 Assembly tool, for stainless steel EMC gasket 1 piece 30846-588 1 piece (SPQ 5)1) – – – – – – – – – – – – – 30846-864 20846-437 – – – – – – 20846-438 30846-676 30846-681 30846-682 30846-683 21101-776 21101-705 21101-706 21101-713 21101-714 21101-707 21101-708 20846-426 20846-427 20846-428 20846-429 20846-430 20846-431 20846-432 20846-433 20846-434 20846-436 30846-865 20846-453 – – – – 30846-771 30846-859 PU 100 pieces 21101-775 20846-425 – – – – – – – – – – – – 20846-454 PU 10 pieces 20846-443 20846-444 20846-445 20846-446 20846-447 20846-448 20846-449 20846-450 20846-456 20846-451 20846-452 21101-709 21101-710 24560-270 쮿Front panel assembly kits, sleeves, collar screws, quick-release fasteners see page 6.65 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.51 Subracks – DServicePLUS Front/rear panels shieldable with textile EMC gasket FRONT PANEL EXPRESS Order Information Front panel Front panel for shielding with EMC sealing (textile) Textile EMC gasket Al extrusion, 2.5 mm, front anodised,rear conductive; 3, 6 U with alignment pin (not 84 HP) textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0 04292001 Height U 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 9 Height mm 84 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 172.9 172.9 172.9 172.9 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 395.1 Width HP 84 2 3 4 5 6 7 8 10 12 14 21 28 42 63 84 28 42 63 84 2 4 5 6 7 8 10 12 14 16 21 28 42 63 84 84 1 piece 1 piece (SPQ 5)1) 20848-262 – – 30849-001 – 30849-004 – – 30848-354 30848-378 – 30848-380 – – 30848-382 30848-356 – 30848-386 – – 30848-358 20848-013 – 20848-020 – 20848-047 20848-027 – 20848-068 – 20848-097 – – 20848-268 20848-269 – 20848-270 20848-271 – – – 30849-002 – – 30848-355 30848-379 – 30848-381 – – 30848-383 30848-357 – 30848-387 – – 30848-359 20848-106 – 20848-108 – – 20848-113 20848-120 20848-139 – 20848-160 20848-189 – – 20848-280 – PU 10 pieces – PU 100 pieces 21101-853 21101-854 21101-858 – 21101-855 21101-856 21101-859 21101-904 21101-856 쮿Front panel assembly kits, sleeves, collar screws, quick-release fasteners see page 6.65 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 6.52 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Front panels, hinged and pivoted Main Catalogue Order Information Front panel, bottom-hinged shielded unshielded Front panel, pivoted 04295001 Height Width U 3 3 3 3 4 4 4 6 6 6 6 HP 28 42 63 84 42 63 84 28 42 63 84 Al, 2.5 mm, Al, 2.5 mm, anodised, cut edges plain; front anodised, hinge, Zn die-cast, rear iridescent green nickel-plated; chromated; 2 x sleeve, PA; hinge, Zn die-cast, 2 knurled screws nickel-plated; M2.5 x 12.3, St, 2 x sleeve, PA; 2 x knurled nickel-plated screws M2.5 x 12.3, St, nickel-plated; 1 x textile EMC gasket 04295002 Al, 2.5 mm, front anodised, rear iridescent green chromated; hinge, die-cast zinc, chrome-plated; textile EMC gasket 1 piece 1 piece 1 piece 20848-608 20848-599 20838-280 20838-271 – – 20848-600 20838-272 – 20848-601 20848-605 20838-273 20838-277 20848-611 – 20848-606 20838-278 – 20848-607 20848-696 20838-279 – – – 20848-602 20838-274 – 20848-603 20848-604 20838-275 20838-276 – 20848-617 Note 쮿 Front panel can be removed in opened position (> 135°) SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.53 Subracks – DServicePLUS Shielding is required between the following components of a subrack 쮿 Front panel/rear panel and horizontal rail, see page 6.55 쮿 Front panel and 19" bracket/corner profile or in case of depth-offset installation, see page 6.55 쮿 Cover plate/horizontal rail, see page 6.44 쮿 Cover plate/side panel, see from page 6.44 쮿 Horizontal rail/horizontal rail in combined mounting (3 U + 3 U and 6 U), see page 6.59 쮿 Shielding for backplane and side panel see page 6.55 EMC shielding concepts 쮿 Shielding concepts in accordance with IEEE and IEC 쮿 Shielding effectiveness has been determined in various series of measurements in accordance with IEC 61587-3 and can be found online together with the relevant standard product 쮿 The combined use of stainless steel and textile EMC gaskets is functionally possible without any problems Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days EMC shielding concept with EMC textile gaskets 쮿 The seal is affixed to the left-hand side of the subrack (viewed from front) or to the front panel profile, respectively 쮿 An EMC gasket with CuNi coating assures a long-term high level of shielding, typically 40 dB at 2 GHz 쮿 Temperature-resistant adhesive layer is protected by a removable film 쮿 Rear shielding is obtained using front panels or a rear hood 쮿 Temperature range -40° C ... +70° C 06108073 쮿 Note: rear hood and corner profile cannot be used simultaneously Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days EMC shielding concept with stainless steel EMC gaskets) 쮿 Symmetrical arrangement of EMC gaskets on the left and right hand sides of subrack and front panel 쮿 Shielding: typically 40 dB at 2 GHz 쮿 Can be used for temperatures above +70° C 쮿 Note: rear hood and corner profile cannot be used simultaneously 06108074 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Front panel shielding concept 쮿 Front panels are available for textile or stainless steel EMC gasket options 쮿 Alignment pins are pressed-in in the front panel to position the gaskets securely and to compress them evenly 쮿 An alignment pin positions the perforated strip in the horizontal rail 쮿 Alignment pin and perforated strip provide an optimal positioning of the shielded assemblies; the front panels are not forced sideways by the shielding elements (Schroff patent) 06112091 6.54 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS EMC gaskets between front/rear panel and horizontal rail Order Information Stainless steel EMC gasket between front panel/rear panel and horizontal rail 06102053 stainless steel; for front and rear horizontal rails (type VT) 06102053 Width HP 28 42 63 84 Depth mm 131.8 202.9 304.5 416.6 PU 10 pieces 24560-231 24560-233 PU 100 pieces – – – 24560-235 24560-236 24560-229 Main Catalogue EMC gaskets between front panel and 19" bracket/corner profile Order Information Stainless steel EMC gasket between front panel/rear panel and 19" bracket/corner profile Textile EMC gasket between front panel/rear panel and 19" bracket/corner profile 06105077 06105077 06108070 inserted laterally into the grooves of the front panel Height U 3 4 6 9 Depth mm 97.5 142.5 232.5 365.0 06102056 06108054 textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0 PU 10 pieces PU 100 pieces PU 10 pieces PU 100 pieces 21101-705 21101-706 21101-853 21101-854 21101-713 21101-707 21101-714 21101-708 21101-858 21101-855 21101-856 21101-709 21101-710 21101-859 21101-904 – Assembly tool, for stainless steel EMC gasket 24560-270 – SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.55 Subracks – DServicePLUS EMC gaskets between horizontal rail and horizontal rail Order Information Stainless steel EMC gasket between horizontal rail and horizontal rail bza45877 Item 1: cover strip, Al, 1 mm, item 2: 2 x EMC seals (stainless steel); for shielding of 2 horizontal rails positioned directly one above the other if assembly area is divided vertically bpa46548 Width HP 20 28 40 42 63 84 Depth mm 107.0 147.0 208.0 218.0 325.0 431.0 PU 1 kit 24562-520 24562-528 24562-540 24562-542 24562-563 24562-584 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple EMC gaskets between front panel and side panel (depth-offset installation) Order Information Stainless steel EMC gasket between front panel and side panel (depth-offset installation) Textile EMC gasket between front panel and side panel (depth-offset installation) 1 1 2 2 bpa45884 Item 1: 2 x support profiles, Al extrusion; item 2: 2 x stainless steel EMC gasket; fixing material kit for vertical EMC shielding between depth-offset shielded front panels and side panel Height U 3 4 6 Depth mm 97.5 142.5 187.5 Assembly tool, for stainless steel EMC gasket 06102058 Item 1: 2 x support profiles, Al extrusion; item 2: 1 x EMC textile gasket; fixing material kit for vertical EMC shielding between depth-offset shielded front panels and side panel PU 1 kit PU 1 kit 24562-199 24560-180 24562-299 24562-499 24560-280 24560-480 24560-270 – Main Catalogue 6.56 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS EMC gaskets between backplane and side panel Order Information Stainless steel EMC gasket between backplane and side panel (depth-offset installation) bpa45916 2 x support profile, AI extrusion, 2 x EMC gasket (stainless steel) Fixing materials kit and user manual; for vertical EMC shielding between shielded backplane and side panel; dimensions (84 HP): A = 425.8 mm, B < 429.9 mm, C = 429.8 mm, D = 431.8 mm 06108078 Height U 3 6 PU 1 kit 24561-199 24561-499 쮿 With an appropriate design the backplane can be used as shielding rear panel; for that purpose a rear horizontal rail (type L-VT or H-VT) for depth-offset installation must be used to ensure the horizontal contact 쮿 For vertical contact the support profile can be fixed to the europacPRO side panel (depth grid 30 mm) Main Catalogue SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.57 Subracks – DServicePLUS Special interior mounting parts Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 쮿 쮿 쮿 쮿 쮿 쮿 쮿 6.58 SCHROFF PRODUCT CATALOG E 03/2016 Combined mounting: 3 U + 3 U and 6 U, see page 6.59 Horizontal board mounting, see page 6.60 Mounting plates, see page 6.61 Central locking for PCBs, see page 6.62 Divider plates, see page 6.62 Air baffles, see page 6.63 Telescopic slides, see page 6.64 Fixing parts (bolts, nuts, assembly tools), see page 6.63 ELECTRONICS PROTECTION Subracks – DServicePLUS Combined mounting (6 U and 2 x 3 U one above the other) Main Catalogue Order Information Combined mounting: Alternative front panels for combined mounting front panel for unshielded textile EMC gasket, front panel, 6 U, 2 HP 6 U, 2 HP item 6 item 6 horizontal and vertical subdivision (incl. front panel for stainless steel EMC gasket) Splitting extrusion for combined mounting item 2 2 4 2 1,3 1,3 4 6 bpa46549 bza42182 Width pitch T1:T2 bpa46550 bpa45857 Al, 2.5 mm, U-profile with notch, 6 U, 2 HP 6 U, die-cast zinc; splitting extrusion is inserted in the grid holes of the horizontal rail; the splitting extrusion can be bolted 1 (SPQ 5) 1 piece (SPQ 5)1) 1 piece 30847-472 30849-140 64560-010 – – – 24560-145 – – – 24560-179 – 21101-101 21101-101 – – 21101-102 21101-102 – – 21101-121 21101-121 – – – 21101-855 – Note see below 2) HP 20:62 40:42 42:40 63:19 84:0 Torx countersunk screw M4 × 14, zinc-plated, PU 100 pieces to fixsplitting extrusion/horizontal rail Panhead screw M2.5 × 10, St, zinc-plated, PU 100 pieces to fix horizontal rail/splitting extrusion Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0 PU 10 pieces bpa46550 Al, 2.5 mm, front anodised, rear iridescent green chromated Item 1: 2 front horizontal rails (HKD), Al extrusion, anodised; item 2: 2 rear horizontal rails (AB), Al extrusion, anodised; item 3: threaded inserts, St, zinc-plated; item 4: Zn die-cast support members; item 6: front panel 2 HP, 6 U, with EMC stainless steel gasket; 84:0 without items 4, 5 PU 1 kit 24562-420 24562-440 24562-442 24562-463 24562-484 2) The following guide rails cannot be used: type "accessory", type "accessory, strengthened" and type "for 4.4" PCB" 쮿 Subdivision of the 6 U assembly area into: – 2x3U – 1x6U 쮿 Designed to accomodate euroboards (100 mm high) and double euroboards (233.35 mm high) Note 쮿 Please order EMC gasketing kit for horizontal rails separately, see page 6.56 쮿 Please order perforated strips for horizontal rails separately, see page 6.35 쮿 Please order rear centre horizontal rail separately, see page 6.33 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.59 Subracks – DServicePLUS Horizontal board mounting in 3 or 4 U subrack Main Catalogue Order Information Board cage Horizontal board mounting in 3 or 4 U subrack Front frame for Front frame, unshielded EMC shielding 27 3.9 8= 54 TE 06102073 =5 4T E bpa45913 H ,98 h w 273 bza43061 Struts, die-cast zinc; horizontal rails front and rear; threaded inserts, St, zinc-plated; fixing material kit; for horizontal mounting of double-height euroboards in 3 or 4 U high subracks/cases; 54 HP space required; please order front frame for EMC shielding separately 2 horizontal covers, AI 2.5 mm, front anodised, rear iridescent green chromated; 2 vertical trims, Al extrusion, passivated; stainless steel EMC gasket; front frame provides the contact between subrack and the sub-assemblies Al, 2.5 mm, clear anodised; front frame with cut-out, clear internal width w = 266.35 mm PU 1 kit PU 1 kit 1 piece (1 TE = 1 HP, 1 HE = 1 U) bpa45914 Mounting variants Height U Usable height h HP 3 20 24564-117 24564-109 34564-108 3 20 24564-118 24564-109 34564-109 4 28 24564-217 24564-209 34564-208 – 24560-270 – Horizontal rail, front Horizontal rail, rear Assembly tool, for stainless steel EMC gasket * For direct backplane mounting Note 쮿 Please order front frame for EMC shielding separately 6.60 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Mounting plates Order Information Mounting plate can be used in combination with cover plate Mounting plate for use without cover plate Fixing strip for partial widths 06108080 bpa45875 Al, 1.5 mm; AI, 1.5 mm; for mounting over partial width, mounting is only possible over the entire width between the side panels; please order fixing strips separately width of mounting plate = W - 9.71 mm bpa46557 St, 2.5 mm, zinc-plated; is bolted from front to rear onto the horizontal rails; to fix mounting plates bpa45875 Width W W Board length HP mm mm 28 146.88 160 28 146.88 220 28 146.88 280 28 146.88 340 42 217.99 160 42 217.99 220 42 217.99 280 42 217.99 340 63 324.67 160 63 324.67 220 63 324.67 280 63 324.67 340 84 431.35 160 84 431.35 220 84 431.35 280 84 431.35 340 Assembly kit for mounting plate, PU 1 kit (Torx countersunk screw M4 x 5, St, zinc-plated, 12 pieces; screw M4 x 6, St, zinc-plated, 10 pieces; square nut M4, St, zinc-plated, 10 pieces) Assembly kit for fixing strips for partial width mounting plates Torx screw M2.5 × 5, St, zinc-plated, PU 100 pieces 1 piece 1 piece 1 piece 34563-001 34562-745 30840-021 34563-009 34562-749 30840-033 – – 34562-753 34562-757 30840-045 30840-057 34563-002 34562-746 30840-021 34563-014 34562-750 34562-754 30840-033 30840-045 – – 34562-758 30840-057 34563-003 34563-019 34562-747 34562-751 30840-021 30840-033 – – 34562-755 30840-045 34562-759 34562-748 30840-057 30840-021 34563-004 34563-024 34562-752 30840-033 – – 34562-756 34562-760 30840-045 30840-057 24560-184 24560-184 – – – 24560-146 Note 쮿 For installation and fixing of heavy components 쮿 In addition to the mounting plate, (EMC) cover plates can also be fitted to the subrack 쮿 The mounting plate is as wide as the subrack or system case and is fixed to the side panels 쮿 A guide rail can be fitted on the first and last slot 쮿 Guide rails type "4.4" and type "strengthened" cannot be used SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.61 Subracks – DServicePLUS Central locking Order Information Central locking for PCBs without front panels 5 6 7 1 2 3 4 06197010 Width HP 84 bza45819 Item 1: central rail, AI, anodised; item 2: ID cardboard, white; item 3: transparent cover strip, plastic; item 4: 2 x knurled screw; item 5: 2 x slide nut; item 6: 2 x hexagon nut M2.5; item 7: rubber gasket; central locking allows joint locking of PCBs and serves as identification strip; can be fitted to front and rear horizontal rails, suitable for 84 HP width Length mm 426.0 1 piece 24560-167 Main Catalogue Divider plate Order Information Divider plate Mounting position when stainless steel Mounting position when EMC gasket is used textile EMC gasket is used front rear front bpa45911 rear 06105078 Stainless steel, 1 mm, is mounted by clipping onto horizontal rail, space requirement on component side 2 mm; mounting direction varies with shielding design (EMC stainless steel or textile gasket); retrofitting the divider plate in an already-assembled subrack/case will first require dismantling of the horizontal rails; where front panels are unshielded, both mounting directions are possible bpa45912 Height U 3 3 6 6 Depth mm 160 220 160 220 A mm 158.3 218.3 158.3 218.3 B mm 135.0 195.0 135.0 195.0 H mm 113.5 113.5 246.9 246.9 PU 10 pieces 34562-761 34562-762 34562-763 34562-764 Main Catalogue 6.62 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Air baffles for slots Order Information Air baffle without front panel Air baffle with front panel Front panel with lateral groove U front panel for stainless steel EMC gasket for textile EMC gasket 06108085 06108087 Air baffle, Al, 1 mm; front panel, Al, 2.5 mm, front anodised, rear conductive; stainless steel EMC gasket; fixing material kit prevents an air short circuit in unused slot positions; is pushed into the groove of the guide rail Al, 1 mm, incl. fixing material kit; prevents an air short circuit in unused slot positions; is pushed into the groove of the guide rail 06108088 Air baffle, Al, 1 mm, front panel, Al extrusion, 2.5 mm, front anodised, rear conductive; textile EMC gasket, fixing material kit prevents an air short circuit in unused slot positions; is pushed into the groove ofthe guide rail 06101507 Depth mm 160 160 160 160 160 160 220 220 220 220 220 220 Width HP 4 4 8 8 12 12 4 4 8 8 12 12 Assembly tool for stainless steel EMC gasket, 1 piece Height U 3 6 3 6 3 6 3 6 3 6 3 6 1 piece 1 piece 1 piece 34562-823 20848-712 20848-728 34562-826 34562-833 20848-720 20848-714 20848-736 20848-730 34562-836 20848-722 20848-738 34562-843 34562-846 20848-716 20848-724 20848-732 20848-740 34562-824 20848-713 20848-729 34562-827 34562-834 20848-721 20848-715 20848-737 20848-731 34562-837 20848-723 20848-739 34562-844 34562-847 20848-717 20848-725 20848-733 20848-741 – 24560-270 – Note 쮿 Air baffle for 280 mm deep and for 80 mm rear I/O boards available on request Main Catalogue SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.63 Subracks – DServicePLUS Simple telescopic slide for assembly of subracks in cabinets 쮿 For mounting 84 HP wide subracks in the 19" plane 쮿 Loading capacity: 25 kg per pair 쮿 The guiding profile is matched to the fixing dimension in the cabinet (it is bolted to the 19" profile of the cabinet); the adaptor rail is matched to the depth and fixing dimension on the subrack (it is inserted into the guiding profile like a telescopic slide) 쮿 Safety note: No protection against extraction, no stop at full extension 06101006 Order Information Telescopic slides with guiding profile for fitting in cabinets Telescopic slides with adaptor rail for subracks Xr Order Information 1 450 D c Xf c1 3 465 3 06108082 06108072 Description Depth D xf xr C c1 Part no. mm mm mm mm mm VARISTAR 600 50 50 500 369 24562-464 VARISTAR 800 50 50 700 569 24562-466 VARISTAR 900 50 50 800 669 24562-467 VARISTAR 1000 50 50 900 769 24562-468 VARISTAR 1100 50 50 1000 869 24562-472 VARISTAR 1200 50 50 1100 969 24562-473 eurorack 600 60 60 480 397 24562-449 eurorack 800 60 60 680 597 24562-451 eurorack 900 60 60 780 697 24562-452 NOVASTAR 500 33 60 407 350 24562-460 NOVASTAR 600 33 60 507 450 24562-461 NOVASTAR 800 33 60 707 650 24562-474 Lab rack 250 0 0 250 162 24562-446 xf, xr: Distance of 19" plane to cabinet edge (front, rear) c: Distance of 19" planes from each other, c1: Fixing dimension of guiding profile on 19" panel/slide mounts For subrack depth mm Part no. 175 24562-453 235 24562-454 295 24562-455 355 24562-456 415 24562-457 475 24562-458 Main Catalogue 6.64 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Assembly parts 쮿 Quick-release fasteners 쮿 Sleeves 쮿 Screws 쮿 Cage nuts 쮿 Tools Quick-release fasteners 쮿 Vibration and shock proof 쮿 1/4 rotary lock with defined stop 쮿 Detection of locking position through slot position Delivery comprises Qty 1 1 Description Locking pin, St, locking, Zn die-cast Press-in sleeve, POM Order Information 06702062 Item 1 1 2 2 Description With slotted head, grey With slotted head, black With knurled and slotted head, grey With knurled and slotted head, black Qty/PU 100 100 100 100 Part no. 21101-847 21101-848 21101-849 21101-850 Note Quick-release fasteners: mounting without threaded inserts Sleeves Order Information Item 2 2 1 1 1 1 1 Description Plastic sleeve, PA, grey Plastic sleeve, PA, black Metal sleeve, brass, nickel-plated Metal sleeve, brass, nickel-plated Metal sleeve, brass, black Metal sleeve, stainless steel Metal sleeve, stainless steel Qty/PU 100 100 10 100 100 10 100 Part no. 21100-464 21100-591 21100-659 21100-660 21100-886 21100-661 21100-662 Note 쮿 Metal sleeves must be pressed-in in front panels 쮿 Sleeve does not fit in 2 HP wide front panels 06702061 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.65 Subracks – DServicePLUS Collar screws Order Information Description Application Material Dimension Qty/PU Part no. St, nickel-plated M2.5 х 12.3 100 21101-101 St, zinc-plated, black M2.5 х 12.3 100 21101-102 St, nickel-plated M2.5 х 12.3 100 21101-782 St, zinc-plated, black M2.5 х 12.3 100 21101-783 Brass, nickelplated M2.5 х 12.3 100 21101-749 For mounting of front panels when using Brass, nickelthreaded inserts for horizontal rails with long lip plated M2.5 х 12.3 100 21101-909 Collar screw with For mounting of front panels when using pozidrive/slot threaded inserts AZA46586 Torx collar screw For mounting of front panels when using threaded inserts AZA45941 For mounting of front panels when using threaded inserts Collar screw with knurled head aza45929 Torx screws, self-forming Order Information Description Application Material Dimension Qty/PU Part no. Torx panhead screw, self-forming For extra-robust Al guide rails; torque max. 0.2 Nm St, zinc flake coating, black 2.5 х 7.3 100 24560-157 St, zinc-plated 2.5 х 7.7 100 24560-158 06707058 Torx countersunk For 4.4" board height, guide rail on horizontal rail, europacPRO, ratiopacPRO; screw, torque max. 0.2 Nm self-forming 06707058 Torx panhead screw, self-forming For plastic guide rail on horizontal rail; for panel bracket on horizontal rail; torque max. 0.2 Nm St, zinc-plated 2.5 х 9.3 100 24560-141 Torx panhead screw, self-locking For plastic guide rails on horizontal rails St, zinc-plated 2.5 × 9.3 100 21500-039 Torx panhead screw For 6 U support member, backplane mounting, centre horizontal rail St, zinc-plated 2.5 × 10 100 24560-179 06707058 06707058 06707058 6.66 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Countersunk screws Order Information Description Torx screw AZA46585 Application Material Dimension Qty/PU Part no. For support profiles europacPRO, ratiopacPRO St, zinc-plated M4 х 5 100 24560-139 For mixed board assembly and assembly of shortened horizontal rail on support member, with GND/earthing function St, zinc-plated M4 х 14 100 24560-145 Torx panhead screws Order Information Description Application Material Dimension Qty/PU Part no. For Z-rails and connector assembly St, nickel-plated M2.5 х 7 100 24560-147 For perforated rails St, nickel-plated M2.5 х 10 100 24560-148 St, nickel-plated M2.5 х 12 100 24560-161 St, nickel-plated M2.5 х 14 100 24560-162 Torx panhead screw For backplane mounting aza45940 Washer For insulated backplane mounting Plastic, PA 2.8 х 6.3 х 2 100 21101-964 Screw + plastic washer (PA) For backplane mounting St, nickel-plated M2.5 х 12 100 21100-777 To bolt on support bracket, rear hood, corner profile on side panel, lengthening bracket St, zinc-plated and connecting bracket M4 х 6 100 24560-135 To bolt-on cover plate or mounting plate, with GND/earthing function St, zinc-plated M4 х 6 100 24560-151 To bolt-on cover plate or mounting plate, St, zinc-plated with GND/earthing function, self-forming thread M4 × 6 100 21101-884 For horizontal rail on side panel if guide rails are bolted to slot 1 St, zinc-plated M4 х 10 100 24560-155 For horizontal rail on side panel, with GND/earthing function St, zinc-plated M4 × 14 10 24560-131 For horizontal rail on side panel, with GND/earthing function St, zinc-plated M4 х 14 100 24560-130 aza45178 aza45940 aza45940 Torx panhead screw 06707058 aza45940 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.67 Subracks – DServicePLUS Grub screws Order Information Description Application Material Dimension Qty/PU M2.5 х 9 100 21101-359 For threaded inserts M2.5 St, nickel-plated M2.5 х 8 100 21100-276 For threaded inserts M3 St, zinc-plated M3.0 х 8 100 21100-646 Dimension Qty/PU M4 100 For threaded inserts M2.5 and perforated strips Stainless steel Grub screw Part no. 06702053 Square nuts Order Information Description Application Material Square nut For fixing: parts to side panels, support profiles, St, zinc-plated mounting plates Part no. 24560-140 AZA45921 Assembly kits 쮿 For assembly of subracks in cabinets or 19" cases 쮿 For assembly of desk-top cases in cabinets by means of 19" brackets Delivery comprises (kit) Item 1 2 3 Qty 1 1 1 Description Pozidrive screw M6 × 16, zinc-plated Plastic washer, ABS, black Cage nut M6, zinc-plated SC128XXX Order Information Description PU = 8 × screw, washer, nut PU = 50 each of M6 screw, washer and cage nut PU = 100 each of M6 screw, washer and cage nut Part no. 21100-435 21101-809 21101-810 쮿 For 19" brackets with material thickness of 1.5 mm, see "Assembly kits" in chapter Cabinet accessories 6.68 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Slide, to accomodate 2 nuts 쮿 The slide is pushed into the groove of the horizontal rail to front or rear (type VT) Delivery comprises (kit) Item 1 2 Qty 1 2 Description Slide, PBT, red, UL 94 V-0 Nut, M2.5, St, zinc-plated Order Information Description Slide nut kit 1 Slide nut kit 2 Part no. 100 slides/200 nuts 12 slides/24 nuts 24560-165 24560-166 Note 쮿 Nuts used in item 3 suitable for: – hinged front panels, 84 HP – front or rear panels, 84 HP 쮿 Nuts used in item 4 suitable for: – hinged front panels 쮿 Nuts used in item 3 and 4 suitable for: – two front panels 06702060 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.69 Subracks – DServicePLUS Assembly tools Main Catalogue Order Information Description Application Dimension Qty/PU Part no. T 8 torx T8 1 64560-026 T 20 torx T20 1 64560-027 Assembly tool Exclusively to fix stainless steel EMC gaskets in horizontal rails – 1 24560-271 Assembly tool To fix stainless steel EMC gaskets on front panels with lateral slots – 1 24560-270 Torx screwdriver AZA45925 aza45938 aza45937 Note 쮿 Assembly tool to insert keying/coding pegs in guide rails is available on request Tape measure 쮿 Measuring tape with cm, U-, HP-division (length 2 m) 쮿 Plastic housing, metal measuring tape with automatic collection Order Information Description Tape measure Qty/PU piece 1 Part no. 89009-001 Main Catalogue 32506001 6.70 SCHROFF PRODUCT CATALOG E 03/2016 ELECTRONICS PROTECTION Subracks – DServicePLUS Application examples Application: Transportation/defense sectors Text 06108006 쮿 Mounting frame to accomodate a 36 HP wide railway subrack, frame from stainless steel 쮿 Robust assembly by double bolt-on fixing 06103001 쮿 Lateral ducting in cabinet 쮿 Combined mounting 6 U+ 2 x 3 U Application: Measurement, control and instrumentation sectors 쮿 Combined mounting with 2 x 3 U in 6 U 06108002 쮿 Subrack with additional telescopic fan unit 06108003 쮿 Adaptation at bottom and top integrated into the side panel 쮿 Divider plate to separate different sections 쮿 Installation with strengthened guide rails Application: Telecoms sectors 06112023 쮿 Shielded subrack for special applications with mounting plate, cover and base plate 쮿 Mounting plate for heavy assemblies SCHROFF.PENTAIR.CO.UK 쮿 Subrack with plastic cable ducting for fibre optic cables 06101005 쮿 Terminal area at top Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.71 for railway applicationsDMain Catalogue Subracks – Dfor railway applications Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 F_2015161_06104008 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 06108013 An alignment pin to NFF standard allows the easy installation of the subracks 06108014 Lateral support bars to NFF standard facilitate insertion of subrack into the (cabinet) frame 06108015 The 19" bracket is firmly fixed to the side panel (tox-cold welded) and is especially suited for high mechanical stresses(vibration resistance) Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 06108016 The double 19“ screwing position adds to additionally safety (NFF standard) Connectors, front panel component system . . . . . . . 11 06108017 The cut-out in the side panel allows to retrofit the threaded insert, also if the side panels are already assembled 06108015 The rear brackets have two functions: - push-in aid and - transport protection for the connectors The removable rear hood allows a fast cabling between backplane and connector Appendix . . . . . 12 6.70 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Overview . . . . 6.70 for railway applicationsDMain Catalogue 19" subrack for mobile rail applications 쮿 Shock and vibration resistance to IEC 61587-1, EN 50155, NF F 61-005 / NF F 60-002, BN 411002 and BN 411003 쮿 Versions for CompactPCI applications 쮿 Best suited for high mechanical demands BN 411002, 411003 subracks 쮿 Height 3 U and 6 U 쮿 Width 84 HP BN 411002/-003 subracks unshielded . . . . . . . 6.73 shielded . . . . . . . . . 6.74 쮿 Unshielded and shielded versions 06102008 EN 50155 subrack 쮿 Height 3 U and 6 U 쮿 Width 84 HP 쮿 Unshielded and shielded versions EN 50155 subracks unshielded . . . . . . . 6.75 shielded . . . . . . . . . 6.76 shielded, for CompactPCI . . . . . 6.77 쮿 Shielded versions for CompactPCI applications 06104006 SNCF subrack 쮿 Height 3 U and 6 U 쮿 Width 9 T (36 HP) and 21 T (84 HP) 쮿 Unshielded and shielded versions 쮿 Shielded versions for CompactPCI applications SNCF subracks unshielded . . . . . . . 6.78 shielded . . . . . . . . . 6.79 shielded, for CompactPCI . . . . . 6.80 Accessories Guide rails . . . . . . . 6.81 Cover plates . . . . . 6.82 General accessories in europacPRO section . . . . . . . . . . 6.17 06104003 ServicePLUS . . . 6.84 ServicePLUS from page 6.84 e.g. modification (cut-outs) e.g. downloads (CAD drawings, user manuals, test reports) e.g. custom solutions (special depths, electromagnetically shielded applications) www.schroff.biz/ServicePLUS Application examples . . . . . . . . 6.85 europacPRO . . . 6.6 europacPRO for industrial applications . . . . 6.86 europacPRO for rugged applications . . . . 6.92 30407004 SCHROFF.PENTAIR.CO.UK 6.71 Subracks – Dfor railway applications Subrack for mobile rail applications Solid mechanical construction Electronics for mobile applications require robust mechanical construction that can withstand extreme environmental conditions. Our enclosure solutions protect the housed electronics thanks to their high mechanical strength and thus are an important element for secure and trouble-free operation of the entire system. Only dependability, down to the last detail, can make complex safety tasks achievable - and also economic. Text TGV_Eurostart1 Shock and vibration resistance Schroff products assure shock and vibration resistance in mobile applications e.g. by suitable material thicknesses and fixing elements. Tested with typical loads, they offer the best conditions for secure and reliable functioning in individual applications and projects. Certification of mechanics High-quality, robust and durable products are an important component for the certification of a complete application in accordance with the European Railway Standard DIN EN 50155, the German Railway Standards BN 411002 and BN 411003 and the French Railway Standards NF F 61-005 and NF F 60-002. Note fer = ferroviaire (French) = railway 1 T = 4 HP = 20.32 mm Railway Technology brochure A large amount of general information on our railway systems solutions can be found at www.schroff.co.uk/railway/ and in our "Railway Systems" brochure. Y-Achse_001a1 , SNCF_Logo, 30407002 TÜV test report 30608002 scb_bn411002_d1 for railway applicationsDMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days 6.72 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Kit, unshielded, 'heavy', for backplane mounting Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Subrack with side panel type H ("heavy"), 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Tested to German Railway Standards BN 411002, BN 411003 쮿 Versions with/without front handles 06102007 Without front handle 06111003 With front handle Delivery comprises (Kit) Item 1 Qty 3U 2 6U 2 2a 2b 2c 3 4 5 6 2 2 4 2 1 2 2 2 1 6 4 1 2 1 6 Description 2b + 3 + 4 2c + 3 + 4 5 2a + 3 Side panel type H, Al, 2 mm, passivated, with 19" support bracket (tox-cold welded) for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-ST) Rear horizontal rail centre (H-ST) Threaded inserts, front and rear (pre-fitted) Insulation strip (pre-fitted) Fixing material kit, user manual Front handle (on version with front handle only) Order Information Height Width Depth D Depth D1 U HP mm mm 1 5 6U 06111057 3 3 3 3 6 6 6 6 84 84 84 84 84 84 84 84 175 235 295 355 175 235 295 355 175 175/235 175/235/295 175/235/295/355 175 175/235 175/235/295 175/235/295/355 Part no. with front handle Part no. without front handle 24567-161 24567-162 24563-161 24563-162 24567-163 24563-163 24567-164 24567-461 24563-164 24563-461 24567-462 24563-462 24567-463 24567-464 24563-463 24563-464 Accessories D2 19" assembly kit (screw, washer, nut) (8 × screws, 8 × plastic washers, 8 × cage nuts) D1 21100-435 Guide rails (standard), ESD clips D 06108052 D=overall depth, D1=insertion depth, D2=board depth = D1 - 15 mm Depth D2 Qty/PU mm pieces 160 10 220 10 280 10 340 10 ESD clip for guide rails PU 50 pieces Torx panhead screw , for extra bolting of the guide rails, 2.5 × 9.3, zinc-plated, PU 100 pieces Part no. 24560-351 24560-353 24560-379 24560-380 24560-255 24560-141 Note 04400001 Rear horizontal rail for backplane mounting with insulation strip 쮿 쮿 쮿 쮿 Perforated rails, cover plates and assembly kit from page 6.34 Textile EMC gaskets see page 6.21 Further accessories from page 6.17 ServicePLUS configuration from page 6.84 ServicePLUS see page 6.84 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.73 Subracks – Dfor railway applications Kit, shielded, "heavy", for backplane mounting Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Subrack with side panel type H ("heavy"), 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 Horizontal rail rear for backplane mounting with insulating strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz (in accordance with VG 95373, part 15 or IEC 61587, part 3), under the condition that the front is closed with shielded front panels Without front handle 06102008 06111001 With front handle 쮿 Tested to German Railway Standards BN 411002, BN 411003 쮿 Versions with/without front handles 7 Delivery comprises (Kit) 3b + 4 + 6 Item 1 Qty 3U 2 6U 2 2 3 3a 3b 3c 4 5 6 7 8 9 10 11 2 2 2 2 6 2 2 2 1 1 1 2 2 2 2 2 1 8 2 4 2 1 1 1 2 3+4+5 3c + 4 + 6 11 Description 1 3a + 4 9 2 3+4+5 10 7 11 6U 06111058 Side panel type H, Al, 2 mm, passivated, with 19" support bracket (tox-cold welded); for textile EMC gasket Rear corner profile for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-KD) Rear horizontal rail (H-ST) Rear horizontal rail centre (H-ST) Threaded insert (pre-fitted) Perforated strip (pre-mounted) Insulation strip (pre-fitted) EMC cover plate EMC gasketing material (pre-fitted) EMC rear panel Fixing material kit, user manual Front handle (on version with front handle only) Order Information D2 D1 D 06108060 D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm Height Width Depth D U HP mm Depth D1 mm 3 3 3 6 6 6 175/235 175/235/295 175/235/295 175/235 175/235/295 175/235/295 84 84 84 84 84 84 235 295 355 235 295 355 Part no. with front handle Part no. without front handle 24567-172 24563-172 24567-173 24563-173 24567-174 24567-472 24563-174 24563-472 24567-473 24563-473 24567-474 24563-474 Accessories 19" assembly kit (screw, washer, nut) ( 8 × screws, 8 × plastic washers, 8 × cage nuts) 21100-435 Guide rails (standard), ESD clips 04400001 Rear horizontal rail for backplane mounting with insulation strip ServicePLUS see page 6.84 6.74 SCHROFF PRODUCT CATALOG E 05/2016 Depth D2 Qty/PU mm pieces 160 10 220 10 280 10 ESD clip for guide rails PU 50 pieces Torx panhead screw , for extra bolting of the guide rails, 2.5 × 9.3, zinc-plated, PU 100 pieces Part no. 24560-351 24560-353 24560-379 24560-255 24560-141 쮿 Perforated rail for connectors see page 6.34 쮿 Further accessories from page 6.17 쮿 ServicePLUS configuration from page 6.84 ELECTRONICS PROTECTION Subracks – Dfor railway applications Kit, EN 50155, unshielded Main Catalogue 쮿 Subrack in robust "heavy" version, 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 Tested to EN 50155 쮿 3 U and 6 U, 84 HP, 235 mm deep, for 220 mm board depth Delivery comprises (kit) 06104005 3U 1 2a + 3 4 Item Qty 3U 1 2 6U 2 2 2a 2b 3 4 5 6 2 2 1 6 2 1 1 2 2 4 2 1 1 Description Side panel type H with 19" support bracket (tox-cold welded); prepared for EMC textile gasket Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Threaded inserts Handles Assembly kit with self-locking screws User manual Order Information 1 2+3 06104056 6U 1 2a + 3 2b + 3 Height Width Depth U HP mm 3 84 235 6 84 235 Accessories Guide rail, standard, 220 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces, see page 6.36 Panhead screw with Torx M2.5 x 9.3, St, zinc-plated, self-locking, PU 100 pieces ESD clip for guide rails PU 50 pieces Cover plate for screw-fixing onto side panel width 84 HP, depth 220 mm, PU 1 kit 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-077 21500-078 24560-353 21500-039 24560-255 21500-037 24566-109 Note 4 쮿 Test reports online 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 1 2+3 06104057 ServicePLUS see page 6.84 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.75 Subracks – Dfor railway applications Kit, EN 50155, shielded Main Catalogue 쮿 Subrack in robust "heavy" version, 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 Tested to EN 50155 쮿 3 U and 6 U, 84 HP, 235 mm deep, for 220 mm board depth Delivery comprises (kit) 06104006 3U 7 5 2a + 3 1 7 8 1 2+3+4 Item Qty 3U 1 2 6U 2 2 2a 2b 3 4 5 6 7 8 9 10 2 2 1 6 2 2 1 2 2 1 1 2 2 4 2 2 1 1 2 1 1 Description Side panel type H with 19" support bracket (tox-cold welded); for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Threaded inserts Perforated strip EMC cover plate 235 T EMC gasketing kit Backplane kit – EMC shielding material Handles Assembly kit with self-locking screws User manual Order Information 8 06104058 6U 5 7 2a + 3 2b + 3 7 1 8 Height Width Depth U HP mm 3 84 235 6 84 235 Accessories Guide rail, standard, 220 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces, see page 6.36 Panhead screw with Torx M2.5 x 9.3, St, zinc-plated, self-locking, PU 100 pieces ESD clip for guide rails PU 50 pieces 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-079 21500-080 24560-353 21500-039 24560-255 24566-109 Note 1 2+3+4 쮿 Test reports online 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 8 2a + 3 06104059 ServicePLUS see page 6.84 6.76 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Kit, EN 50155, shielded, for CompactPCI applications Main Catalogue 쮿 Subrack in robust "heavy" version, 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 Tested to EN 50155 쮿 3 U and 6 U, 84 HP, 235 mm deep, for 160 mm board depth 쮿 Subrack in accordance with IEEE 1101.10 Delivery comprises (kit) 06104007 3U 7 5 2a + 3 1 7 8 2 + 3 +4 1 2c +3 +4 Item Qty 3U 1 2 6U 2 2 2a 2b 2c 3 4 5 6 7 8 9 10 2 1 2 6 2 2 1 2 2 1 1 1 2 1 4 2 2 1 1 2 1 1 Description Side panel type H with 19" support bracket (tox-cold welded); for textile EMC gasket Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Front horizontal rail (H-LD) Threaded inserts Perforated strip EMC cover plate, 175 T EMC gasketing kit Backplane kit – EMC shielding material Handles Assembly kit with self-locking screws User manual Order Information 8 06104060 6U 5 2a + 3 2b + 3 1 7 Height Width Depth U HP mm 3 84 235 6 84 235 Accessories 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-081 21500-082 24566-109 Note 쮿 Please order guide rails and ESD clips separately, see page 6.81 쮿 Test reports online 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 7 8 1 2c + 3 + 4 8 06104061 ServicePLUS see page 6.84 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.77 Subracks – Dfor railway applications Kit, SNCF, unshielded Main Catalogue 쮿 Subrack, robust "heavy" version, 19" bracket is firmly connected to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 SNCF listed, europacPRO-fer, tested to NF F 61-005 and NF F 60-002 쮿 3 U and 6 U, 9 HP and 21 HP, 320 mm deep, for 220 mm board depth Delivery comprises (kit) 06104002 3U 2 7 4a + 5 1 6 7 8 3 2 4+5 1 06104050 6U 2 7 4a + 5 1 4b + 5 6 8 7 3 2 4+5 1 4a + 5 06104051 Coding peg Item 1 Qty 3U 2 6U 2 Description 2 3 4 4a 4b 5 6 7 8 9 10 2 2 2 2 4 1 2 2 1 1 2 2 2 2 1 6 2 4 2 1 1 Side panel type H with 19" support bracket (tox-cold welded); prepared for textile EMC gasket Side panel extension Ducting external Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Threaded inserts Rear frame 3 U, 21 T Protective bracket SNCF Handle Assembly kit with self-locking screws User manual Order Information Width Height Depth mm U mm 36 HP (9 T) 3 320 36 HP (9 T) 6 320 84 HP (21 T) 3 320 84 HP (21 T) 6 320 Accessories Guide rail, standard, 220 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces, see page 6.36 Panhead screw with Torx M2.5 x 9.3, St, zinc-plated, self-locking, PU 100 pieces ESD clip for guide rails PU 50 pieces Coding peg for rear frame, St, white zinc-plated, 1 piece 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-067 21500-070 21500-029 21500-027 24560-353 21500-039 24560-255 60895-018 24566-109 Note 쮿 fer = ferroviaire = French Railways, 1 T = 4 HP = 20.32 mm 쮿 Receptacle/mounting frame for subracks, stainless steel, 9 T or 21 T on request 쮿 Test reports online 쮿 Cover plates for bolting on to side panel see page 6.82 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 06104062 ServicePLUS see page 6.84 6.78 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Kit, SNCF, shielded Main Catalogue 쮿 Subrack, robust "heavy" version, 19" bracket is firmly fixed to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 SNCF listed, europacPRO-fer, tested to NF F 61-005 and NF F 60-002 쮿 3 U and 6 U, 9 T and 21 T, 320 mm deep, for 220 mm board depth 06104003 3U 4a + 5 12 7 8 11 10 1 12 13 3 2 4+5+6 1 06104052 6U 12 4a + 5 8 7 4b + 5 11 10 1 12 13 3 2 4+5+6 1 4a + 5 06104053 Coding peg Delivery comprises (kit) Item 1 Qty 3U 2 6U 2 Description 2 3 4 4a 4b 5 6 7 8 9 10 11 12 13 14 15 2 2 2 2 4 2 2 2 1 1 1 2 2 1 1 2 2 2 2 1 6 2 2 2 1 2 2 4 2 1 1 Side panel type H with 19" support bracket (tox-cold welded); for textile EMC gasket Side panel extension Ducting external Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Threaded inserts Perforated strip EMC cover plate 235 T Rear cover plate, 55 T EMC gasketing kit Backplane kit – EMC shielding material Rear frame, 3 U, 21 T Protective bracket SNCF Handles Assembly kit with self-locking screws User manual Order Information Width Height U 3 6 3 6 Depth mm 320 320 320 320 36 HP (9 T) 36 HP (9 T) 84 HP (21 T) 84 HP (21 T) Accessories Guide rail, standard, 220 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces, see page 6.36 Panhead screw with Torx M2.5 x 9.3, St, zinc-plated, self-locking, PU 100 pieces ESD clip for guide rails PU 50 pieces Coding peg for rear frame, St, white zinc-plated, 1 piece 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-068 21500-071 21500-030 21500-028 24560-353 21500-039 24560-255 60895-018 24566-109 Note 06104062 ServicePLUS see page 6.84 SCHROFF.PENTAIR.CO.UK 쮿 fer = ferroviaire = French Railways, 1 T = 4 HP = 20.32 mm 쮿 Receptacle/mounting frame for subracks, stainless steel, 9 T or 21 T on request 쮿 Test reports online 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.79 Subracks – Dfor railway applications Kit, SNCF, shielded, for CompactPCI applications Main Catalogue 쮿 Subrack, robust "heavy" version, 19" bracket is firmly fixed to side panel (tox-cold welded) 쮿 For mobile railway applications 쮿 SNCF listed, europacPRO-fer, tested to NF F 61-005 and NF F 60-002 쮿 3 U and 6 U, 9 HP and 21 HP, 320 mm deep, for 160 mm board depth 쮿 CompactPCI subrack conforming to 1101.10 06104004 3U 4a + 5 12 7 8 11 10 1 12 13 3 2 4+5+6 1 4c + 5 + 6 06104054 6U 12 8 4a + 5 4b + 5 7 11 Delivery comprises (kit) Item Qty 3U 1 2 6U 2 2 3 4 4a 4b 4c 5 6 7 8 9 10 11 12 13 14 15 2 2 2 1 2 6 2 2 2 1 2 2 4 2 1 1 2 2 1 2 1 4 2 2 2 1 1 1 2 2 1 1 Description Side panel type H with 19" support bracket (tox-cold welded); for textile EMC gasket Side panel extension Ducting external Front horizontal rail (H-KD) Rear horizontal rail (H-VT) Rear centre horizontal rail (VT) Front horizontal rail (H-LD) Threaded inserts Perforated strip EMC cover plate, 175 T Rear cover plate, 55 T EMC gasketing kit Backplane kit – EMC shielding material Rear frame, 3 U, 21 T Protective bracket SNCF Handles Assembly kit with self-locking screws User manual Order Information 10 Width 12 13 1 3 2 4c + 5 + 6 1 4a + 5 06104055 Coding peg 06104062 Height U 3 6 3 6 Depth mm 320 320 320 320 36 HP (9 T) 36 HP (9 T) 84 HP (21 T) 84 HP (21 T) Accessories Coding peg for rear frame, St, white zinc-plated, 1 piece 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 21500-069 21500-072 21500-047 21500-046 60895-018 24566-109 Note 쮿 Please order guide rails and ESD clips separately, see page 6.81 쮿 fer = ferroviaire = French Railways, 1 T = 4 HP = 20.32 mm 쮿 Receptacle/mounting frame for subracks, stainless steel, 9 T or 21 T on request 쮿 Test reports online 쮿 ServicePLUS configuration see from page 6.84 쮿 Further accessories see from page 6.17 ServicePLUS see page 6.84 6.80 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Guide rails Main Catalogue 쮿 Material PBT, UL 94 V-0, red, groove width 2 mm, for 1.6 mm board thickness Order Information Description Depth mm Guide rails, accessories, 160 160 mm deep Guide rails, standard, 220 mm deep 220 ESD clip for guide rails PU 50 pieces Qty/PU Part no. 10 24560-351 10 24560-353 24560-255 06102001 Guide rails with coding for CompactPCI and VME64x Main Catalogue 쮿 The guide rails conform to IEC 60297-3-100 and IEEE 1101.10/11, are 4 HP wide and can be fitted with keying/coding pegs 쮿 Material PBT UL 94 V-0, groove width 2 mm, for board thickness 1.6 mm 쮿 Colour: – red (CPU board) – grey (periphery board) – green (CompactPCI power supply unit, 0.1" offset) Order Information Description 06102003 Guide rails on horizontal rail type H Guide rails with coding, red Guide rails with coding, grey Guide rails with coding, green, offset Depth mm 160 160 160 Qty/PU 10 10 10 Panhead screw with Torx M2.5 x 9.3, St, zinc-plated, self-locking, PU 100 pieces ESD clip for guide rails PU 50 pieces ESD clip for alignment pin of CPCI/VME64x handle PU 50 pieces Coding peg PC, UL 94 V-0, RAL 7035, PU 100 pieces 04505050 ESD clip for alignment pin Part no. 24560-356 24560-358 24560-359 21500-039 24560-255 24560-256 20817-501 쮿 More guide rails see page 6.36 쮿 For inserter/extractor handle type IEL/IET for CompactPCI or VME64x applications see Subracks/Plug-in units section, page 7.18 06103052 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.81 Subracks – Dfor railway applications Cover plate for screw-fixing onto side panel Main Catalogue 쮿 Suitable for use with all horizontal rails 쮿 Cover plate for mounting of 160 mm, 220 mm or 280 mm deep PCBs 쮿 Lateral notch to mount the horizontal rails in depths of 160 mm or 220 mm 쮿 Shielding by optional EMC stainless steel contact strips between cover plate and horizontal rail Delivery comprises Item 1 Qty 2 2 16/32 Description Cover plate, Al, 1.0 mm, clear chromated, hole diameter 4.0 mm, (no perforation at 55 mm depth) Torx M4 x 6 pentaform bolts, St, zinc-plated Order Information 06102084 d = D - 25 3 HE / U 160 / 220 / 280 Width HP 84 84 84 36 36 36 Depth D mm 55 175 235 55 175 220 Application – 160 160, 220 – 160 160, 220 Part no. 21500-038 21500-048 21500-037 21500-123 21500-124 21500-122 Note 쮿 4 stainless steel EMC gaskets are necessary per subrack, see page 6.82 D 06102082 Side view for 175 mm and 235 mm depths EMC gasket (stainless steel) between cover plate and horizontal rail Main Catalogue 쮿 Stainless steel gasket is clipped into horizontal rail and forms the contact cover plate X 쮿 Fits all horizontal rails X Order Information Width Length Qty/PU HP mm pieces 42 182.4 10 63 284.0 10 84 395.7 10 84 395.7 100 Assembly tool For mounting of EMC sealing, St, stainless, in horizontal rails, 1 piece X X X 06102052 Assembly tool Part no. 24560-241 24560-243 24560-245 24560-246 24560-271 Note 쮿 When a rear hood is used, the stainless steel EMC gasket ensures the conductive connection between horizontal rail and rear hood aza45938 6.82 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor railway applications Coding peg for rear frame (NFF standard) Main Catalogue Order Information Description Coding peg, St, white zinc-plated Qty/PU 1 Part no. 60895-018 06104062 Rear hood for 3 U and 6 U subracks (for stainless steel EMC gasket) Order Information Rear hood Stainless steel EMC gasket, between cover plate and horizontal rail bza45819 06106052 Al, 1 mm, clear passivated; 60 mm additional side panel depth required (board depth + 60 mm); for shielding please order EMC gasket for horizontal rail separately; cannot be used simultaneously with rear corner profile stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails 1 piece PU 10 pieces 34561-750 24560-241 bza45814 Height Width U HP 3 42 3 84 6 63 6 84 Torx panhead screw, M4 × 6, St, zincplated, PU 100 pieces 34561-752 24560-245 34561-763 34561-764 24560-243 24560-245 24560-135 – – 24560-271 Assembly tool, For EMC gasket, stainless steel (horizontal rails), 1 piece Note 쮿 Other dimensions of rear hood available on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.83 Subracks – for railway applications ServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Configuration tables from page 6.17 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable from quantity 1 modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Custom modifications from quantity 1 solution Simple. Fast. From one source. Integration and custom developments 쮿 Special sizes (depth and width) 쮿 Ready for despatch within 5 working days 쮿 Ready for despatch within 10 working days 쮿 Individual heat dissipation concepts 쮿 Ready for despatch within 10 working days express When fast has to be faster. Delivery time to customer's request 쮿 Express logistics academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, CAD drawings, test reports, user reports for railway applications ServicePLUS 6.84 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – for railway applications ServicePLUS Application examples Text Application: Subrack receptacle/mounting frame Application: Signalling control systems Application: Control system SCHROFF.PENTAIR.CO.UK 06108006 41108002 Csee_DSCN2296 Application: Automatic train control system Application: Mobile telephony system Application: Train control system Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 06108020 41108001 01004031 6.85 for industri al applic ationsDMain Catalogue Subracks – Dfor industrial applications Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 06112008 Main C ataloguePart number in bold face type: ready for despatch within 2 worki ng daysPart number in norm al type: ready for despatch within 10 working days We package your euroboards - even for applications in harsh industrial environments 쮿 A wide range in different dimensions, with finishes for the most diverse applications Subracks/ 19" chassis . . . . 6 쮿 In accordance with the IEC 60297-3-101 and IEEE 1101.1 standards 쮿 Tested to IEC 61587, VG 95373 T15, EN 50155, BN 411002, NF F 67-012, NF F 60-002 쮿 Delivered as a kit in space-saving package or individually assembled and fitted to your specifications Front panels, plug-in units . . . 7 Applications Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Subracks for mounting on mounting plate incl. connection field Connectors, front panel component system . . . . . . . 11 06112009 Subracks with special adaptation 06112010 Main C ataloguePart number in bold face type: ready for despatch within 2 worki ng daysPart number in norm al type: ready for despatch within 10 working days Appendix . . . . . 12 6.86 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor industrial applications Overview . . . . . . 6.86 for industrial applicationsDMai n C atalogue Subrack for industrial applications 쮿 Accommodates electronic boards in industrial applications 쮿 Mounting frame for power distribution modules (connectors, RCD switches, ...) 쮿 Bracket for panel mounting Subrack for mounting on a mounting plate Introduction . . . . 6.4 Subrack for wall mounting . . 6.88 쮿 Height 3 U, width 28 HP, depth 205 mm 쮿 For mounting on mounting plate 쮿 For direct mounting of backplanes or to fit DIN plugs, DIN 41612/EN 60603-2 06112002 Module support 쮿 Height 3 U, width 84 HP, depth 115 mm Module support 6.89 쮿 Power distribution modules to mount on lipped horizontal rail in accordance with DIN 43880 01494031 Bracket for mounting subracks in a panel 쮿 Bracket widths 42 and 84 HP Bracket for panel mounting 6.90 06197021 Accessories 쮿 Accessories (e.g. lipped rail adaptor, horizontal rails) ServicePLUS from page 6.18 / 6.84 e.g. modification (cut-outs) e.g. downloads (CAD drawings, user manuals, test reports) e.g. custom solutions (special depths, electromagnetically shielded applications) www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK Accessories . . . . 6.91 ServicePLUS . . . 6.18 Application examples . . . . . . . . 6.85 europacPRO . . . 6.6 Subracks for mobile railway applications . . . . 6.70 europacPRO for rugged applications . . . . 6.92 6.87 Subracks – Dfor industrial applications europacPRO subrack, unshielded for industrial appli cationsDMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Subrack to mount on the wall or on mounting plate 쮿 For mounting of euroboards to IEC 60297-3-101 in size 3 U, 160 mm deep 쮿 Versions – For connector mounting (DIN 41612, EN 60602-3), with/without rear panel – For backplane mounting, with/without rear hood Delivery comprises 06112001 Illustration shows subrack without rear hood 2b / 2c / 4 5 6 2a / 4 1 Item 1 Qty 2 2a 2b 2c 3 4 5 6 7 2 2 2 2 2/4 2 1 1 Order Information Description 3 06112050 D2 With rear panel, for 3 28 205 175 connector mounting Without rear panel, for 3 28 205 175 connector mounting With rear panel, for direct 3 28 205 175 backplane fixing Without rear panel, for 3 28 205 175 direct backplane fixing Accessories Guide rails, accessories, 160 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces Front panels Front panel with handle Part no. 24563-110 24563-109 24563-108 24563-107 24560-351 Page 7.5 Page 7.16 쮿 EMC version on request D Connector/backplane mounting; D=overall depth, D1=insertion depth, D2=board depth = D1 - 15 mm 6.88 Height Width Depth Depth D D1 U HP mm mm Note D1 Horizontal rail to rear for connector mounting Description Side panel, 3 U, Al, 2 mm with integrated wall-mounting bracket Front horizontal rail (L-KD) Rear horizontal rail (L-RC) for backplane mounting Rear horizontal rail (L-MZ) for connector mounting Rear angle Threaded insert, St, zinc-plated Cover plate, pushed in Rear hood, Al, 1 mm (only for version with rear hood) Fixing materials kit, user manual 04400003 06112051 04400002 Horizontal rail to rear for direct backplane mounting SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Dfor industrial applications 19" module support, support rail to DIN 43880, hood Main Catalogue Order Information 19" module support to accommodate power distribution modules Support rails to DIN 43880 Front panel for 19" module support 128,4 46,2 3 Hood 42 6,4 39 5 2 1 bla43467 01494031 06105080 06111053 3 U, 84 HP, Al, 2.5 mm, 2 adaptor brackets, Al, 2 mm; 3 U, 84 HP, 115.5 mm deep; front anodised, support rail, St, 2 side panels AI, 2 mm; rear iridescent green zinc-plated, (35/7.5 mm); 2 horizontal rails with short lip chromated; for width 84 HP (430.5 mm); (L-KD), Al extrusion, GND/earth connection 6.3 mm surface anodised, FASTON; contact surfaces conductive; Mounted in module support or (cut-out 395 mm x 46.2 mm); subrack on the side panel 2 threaded inserts, St, two blanking plates, zinc-plated; plastic, polyester, GND/earthing kit; colour similar to RAL 7035; fixing material kit; to cover unused module slots Please order support rail separately BLA43492 Al, 1 mm, with brush strip; is bolted to the rear of the module support; GND/earthing kit PU 1 kit PU 1 kit 1 piece 1 piece 24563-100 24565-100 24563-096 24564-100 Accessories 쮿 Power distribution modules see page 3.34 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.89 Subracks – Dfor industrial applications Bracket for panel mounting Main Catalogue Order Information Bracket (mounting angle) 06105067 Al extrusion, anodised; serves as front visual cover of subrack at top and bottom when fitted into a panel; screwed in from the front with the horizontal rail; 2 brackets and 4 screws are required per subrack 06197021 Usable width Length HP mm 42 269.2 84 482.6 Torx panhead screw 2.5 × 9.3, zinc-plated, PU 100 pieces 1 piece 34561-777 34561-779 24560-141 Note 쮿 Further widths available on request Assembly cut-out 06105066 Dimensions table U HP 3 3 3 6 6 6 42 63 84 42 63 84 6.90 A mm 237.0 343.0 450.0 237.0 343.0 450.0 B mm 145.0 145.0 145.0 278.5 278.5 278.5 C mm 252.0 358.5 465.0 252.0 358.5 465.0 D mm 57.15 57.15 57.15 190.5 190.5 190.5 SCHROFF PRODUCT CATALOG E 05/2016 E mm 269.2 375.9 482.6 269.2 375.9 482.6 F mm 179.4 179.4 179.4 312.7 312.7 312.7 ELECTRONICS PROTECTION Subracks – Dfor industrial applications Adaptor for horizontal rail mounting Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For mounting e.g. small subracks, small wall mounted cases, frame type plug-in units or PSUs on a horizontal rail with lip 쮿 Adaptor is bolted to the desired product and can then be clipped to the lipped horizontal rail (DIN 43880) Delivery comprises Item 1 1 Qty 1 1 Description Adaptor, Al extrusion, length 160 mm Assembly kit Order Information Description Adaptor for horizontal rail mounting Part no. 11000-002 04812021 Example: Lipped horizontal rail adaptor for 19" PSU SCHROFF.PENTAIR.CO.UK 11395007 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.91 ruggedDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in normal type: ready for despatch within 10 working days Subracks – Drugged Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 06112020 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 06112004 Systems . . . . . . . 8 "rugged" horizontal rail with 3 hole fixing for increased stability (+60 % compared to 2 hole fixing of "heavy" horizontal rail) Special adaptor rails allow conducted cooled assemblies to be fitted 06112052 Y-axis_001a1 Shock and vibration resistant in all three axial directions Standards/Approvals Power supply units . . . . . . . . . . 9 쮿 Internal and external dimensions in accordance with: IEC 60297-3-100, -101, - 102, -103, -104, -105, IEEE 1101.1, IEEE 1101.10/11 쮿 Type of protection IP 20, in accordance with IEC 60529 Backplanes . . . 10 쮿 EMC testing to IEC 61587-3 쮿 Shock and vibration test report; MIL 167, IEC 61587 DL 3, MIL 810 G, MIL 901 dB 120 100 80 60 40 20 Connectors, front panel component system . . . . . . . 11 Note 쮿 Other finishes e.g. yellow chromated on request 쮿 Subrack with telescopic slides can be adapted for cabinet mounting on request 0 30 400 800 1200 1600 2000 Mhz EMC curve 06108081 Appendix . . . . . 12 6.92 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged Overview . . . . . . 6.92 19" subracks ruggedDMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days 쮿 Shock and vibration resistant up to 25 g 쮿 Kits or individually configured subracks 쮿 A product and accessory platform for the most different customers’ requirements and applications 쮿 Suitable for CompactPCI and VMEbus insertion and extractor handles 쮿 EMC shielding can easily be retrofitted 쮿 3D PDF or CAD 3D data available for download Kits Introduction . . . . 6.4 Kits . . . . . . . . . . . . 6.94 쮿 All required parts are available under one part number, even partly assembled 쮿 Most popular versions and dimensions available from stock 쮿 For installed loads over 15 kg up to 60 kg 쮿 Supplied as a space-saving flat pack 06112017 ServicePLUS individual configuration 쮿 Single parts may individually be configured, respectively assembled on request (from quantity 1) Individual configuration . . . 6.97 쮿 Wide range of variants in heigth, width and depth 쮿 Guide rails for different applications 쮿 EMC shielding material to improve EMC performance 쮿 Other accessories and assembly kits 06105058 ServicePLUS from page 6.95 e.g. modification (cut-outs) e.g. downloads (CAD drawings, user manuals, test reports) e.g. custom solutions (special depths, electromagnetically shielded applications) ServicePLUS . . . . 6.95 Application examples . . . . . . . . . 6.71 europacPRO . . . . 6.6 www.schroff.biz/ServicePLUS 30407004 Subracks for mobile railway applications . . . . 6.70 europacPRO for industrial applications . . . . 6.86 SCHROFF.PENTAIR.CO.UK 6.93 Subracks – Drugged Re Kit, rugged, shielded, for backplane mounting ruggedDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatc h within 10 working days 쮿 Subrack with robust side panel and horizontal rail, type R "rugged" 쮿 Rear horizontal rail for backplane mounting with insulation strip 쮿 Shielding typically 40 dB at 1 GHz, 30 dB at 2 GHz (as per VG 95373, part 15), on condition that the front is closed with sealed front panels 쮿 Shock and vibration resistant to 25 g 06112017 Illustration shows 3 U subrack Delivery comprises (Kit) Item 1 Qty 3U 2 6U 2 Description 2 3 4 4a 4b 4c 4d 5 6 7 8 9 10 2 2 1 1 2 2 6 2 2 2 1 1 2 2 2 2 2 1 8 2 4 2 1 1 8 4c + 5 + 7 4d + 7 4 +5 + 6 4b + 5 1 9 2 3 1 4a + 5 + 6 8 06112055 6U D2 D1 D D = overall depth, D1 = insertion depth, D2 = board depth = D1 - 15 mm 06112054 Side panel type R, Al, 3 mm, clear passivated, with 19" support bracket 3.5 mm (tox-cold welded); for EMC gasketing (textile) Front handle incl. fixing material kit Rear corner profile for EMC gasketing (textile) Front horizontal rail (R-KD) Front horizontal rail (R-LD) Rear horizontal rail (H-KD) Rear horizontal rail, centre (R-ST) Rear horizontal rail, centre (ST) Threaded insert (pre-fitted) Perforated strip (pre-fitted) Insulation strip (pre-fitted) EMC cover plate, rugged, with top cover locking EMC rear panel EMC gasketing material, fixing material kit, user manual Order Information Height Width Depth D Depth D1 U HP mm mm 3 84 295 175 6 84 295 175 Accessories Guide rails, accessories, 160 mm deep PBT, UL 94 V-0, red, groove width 2 mm, PU 10 pieces Torx panhead screw 2.5 × 9.3, zinc-plated, PU 100 pieces; torque max. 0.2 Nm ESD clip for guide rails PU 50 pieces Guide rail accessories for heavy PCBs, extra strong Al extrusion, groove width 2 mm, 160 mm deep, 1 piece (SPQ 10) Torx pan head screw 2.5 × 7.3, zinc flake coating, black, 100 pieces; torque max. 0.2 Nm Adaptor to accomodate conduction cooled assemblies (CCA) for VPX applications, 160 mm deep, PU 1 pair; includes fixing material kit Adaptor to accomodate conduction cooled assemblies (CCA) for CompactPCI applications, 160 mm deep, PU 1 pair; includes fixing material kit 19" dual fixing materials kit suitable for a subrack with double fixing holes (bolts, washers and nuts), PU 1 kit Part no. 24567-149 24567-449 24560-351 24560-141 24560-255 34562-881 24560-157 24566-004 24566-005 24566-109 Note 04400001 Rear horizontal rail for backplane mounting with insulation strip 6.94 SCHROFF PRODUCT CATALOG E 05/2016 쮿 Test reports online 쮿 For further accessories see from page 6.19 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 6.96 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable from quantity 1 modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Custom modifications from quantity 1 solution Simple. Fast. From one source. Integration and custom developments 쮿 Special sizes (depth and width) 쮿 Ready for despatch within 5 working days 쮿 Ready for despatch within 10 working days 쮿 Individual heat dissipation concepts 쮿 Ready for dispatch within 10 working days express When fast has to be faster. Delivery time to customer's request 쮿 Express logistics academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, CAD drawings, test reports, user reports rugged Servi cePLUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.95 Subracks – Drugged ServicePLUS Overview of individual components for shielded or unshielded subracks 4 2 1 6 5c 3 5b 2 5a 06108086 1 Part number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days Item Description Description page Item 1 Side panels Establish the height and depth of the subrack; Al, 3 mm, with universal hole positions for mounting of accessories 6.97 Item 2 Horizontal rails Establish the width of the subrack; Al extrusion, with defined hole positions for guide rails, grooves for threaded inserts, M4 thread at front, functional rail shapes, basically differing with regard to their mechanical loading capacity: rugged loading up to 15 kg 6.98 Item 3 Guide rails Guide rails act as interface between subracks and boards, for different board formats, are available in plastic or metal, optionally codable and optionally can be fitted with ESD clip to allow electrostatic discharge 6.105 Item 4 Cover plates Provide mechanical protection and/or EMC shielding and are perforated 6.108 Item 5 Rear/front Rear hood (5a) or front panel (5b) with corner profile (5c) as support for EMC shielding gaskets used in conjunction with shielded front panels; Note: rear hood and corner profile cannot be fitted simultaneously 6.49 Item 6 Handles Handles can be mounted on the 19" brackets 6.97 – EMC shielding (without illustration) Extensive component range for specific shielding of subrack according to your application 6.110 – Internal mounting (without Universal assemblies, e.g. for horizontal and vertical mounting and for mounting plates illustration) 6.96 SCHROFF PRODUCT CATALOG E 05/2016 6.109 6.60 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS Side panel type R, EMC sealing, corner profile, front handle rugged Servi cePLUSDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days Order Information EMC textile gasket Corner profile, rugged Front handle 120 Side panel type R for textile gasket 06112059 04602054 06112058 06112057 Side panel, Al 3 mm, tox-cold welded with 19" Al bracket, 3.5 mm with handle hole, clear passivated, front anodised; please order front handles separately Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, temperature range -40 ... 70 °C Al extrusion, 3 mm, finish clear passivated; with lateral grooves for EMC stainless steel gasket; rear hood cannot be used simultaneously Die-cast Al profile, powder-coated, RAL 9006; load-carrying capacity 30 kg, fixing material kit PU 1 pair PU 10 pieces PU 1 pair PU 1 kit 21101-853 24566-199 24566-010 21101-855 24566-499 24566-010 06112054 06112056 Height Depth U mm 3 175 3 235 3 275 3 277.75 3 295 3 355 6 175 6 235 6 275 6 277.75 6 295 6 355 Fixing material kits see page 6.103 24568-145 24568-147 24568-143 24568-144 24568-149 24568-151 24568-445 24568-447 24568-443 24568-444 24568-449 24568-451 Side panel, type R 쮿 For high mechanical demands up to 25 g (vibration resistance, shock and vibration requirements to e.g. IEC 61587-DL 3) 쮿 19" bracket is fixed firmly to side panel (tox-cold welded) 쮿 Height 3 U and 6 U 쮿 Depths 175, 235, 275, 277.75, 295 and 355 mm 쮿 EMC shielding concept for front/rear with EMC textile gasket 쮿 Other dimensions on request SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.97 Subracks – Drugged ServicePLUS Mounting position of horizontal rail/central rails 3 U (board depth 160, 220, 280 mm) 6 U (board depth 160, 220, 280 mm) R-LD R-ST / R-VT R-KD ST / VT R-ST / R-VT R-LD R-ST / R-VT D2 D = D1 R-LD D2 D = D1 06112061 3 U (board depth 160, 220, 280 mm) 06112062 6 U (board depth 160, 220, 280 mm) R-LD H-KD R-ST / R-VT R-KD H-KD ST / VT H-KD R-ST / R-VT R-ST / R-VT R-LD D2 R-LD H-KD D1 D2 D D1 D 06112063 3 U (for CompactPCI/VME64x applications) 06112064 6 U (for CompactPCI/VME64x applications) R-LD H-LD H-ST / H-VT R-KD H-KD AB H-ST / H-VT AB R-LD H-LD H-ST / H-VT D3 D2 R-LD D1 H-LD D3 D2 D D1 D 06112065 Horizontal rails R-ST 06112070 R-VT 06112066 H-ST 06112071 H-VT 06112072 ST 06112073 VT 06112074 06112075 Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 6.98 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS W Front horizontal rails Main Catalogue Order Information With long lip for insertion/ extraction of CompactPCI and VME64x boards With long lip for insertion/ extraction of CompactPCI and VME64x boards With short lip With short lip "rugged" Type R-LD long lip "heavy" Type H-LD long lip "rugged" Type R-KD short lip "heavy" Type H-KD short lip bza44980 With HP markings from 28 HP, Al extrusion, anodised finish, conductive contact surface Usable length HP Length mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Cover strips to cover the horizontal rail perforations Al, untreated, 0.8 mm, length 431.5 mm, 1 piece (SPQ 10) Threaded inserts see page Fixing material kits see page 06112004 06197008 06112013 06197008 Al extrusion, anodised finish, conductive contact surface, with HP markings Al extrusion, anodised finish, conductive contact surface, with HP markings Al extrusion, anodised finish, conductive contact surface, with HP markings Al extrusion, anodised finish, conductive contact surface, with HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34566-320 34560-320 34566-220 34560-220 34566-328 34560-328 34566-228 34560-228 34566-340 34566-342 34560-340 34560-342 34566-240 34566-242 34560-240 34560-242 34566-363 34560-363 34566-263 34560-263 34566-384 34566-301 34560-384 34560-301 34566-284 34566-201 34560-284 34560-201 34566-184 – 34566-184 – 6.104 6.103 6.104 6.103 6.104 6.103 6.104 6.103 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "heavy" load > 7.5 kg; "rugged" load > 15 kg; Note 쮿 1000 mm version without M4 thread to front, without printing and without notch for 19"-bracket 쮿 EMC gasket see page 6.56 쮿 For further horizontal rails see page 6.29 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.99 Subracks – Drugged ServicePLUS Rear horizontal rails Main Catalogue Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 "rugged" Type R-ST Standard 06105074 With HP markings from 28 HP, Al extrusion, anodised finish, conductive contact surface Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Insulation strips see page Threaded inserts see page Fixing material kits see page "heavy" Type H-ST standard 06112005 Al extrusion, anodised finish, conductive contact surface, with HP markings 04400002 "rugged" Type R-VT recessed installation 06197011 Al extrusion, anodised finish, conductive contact surface, with HP markings For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612) "heavy" Type H-VT recessed installation 06112006 Al extrusion, anodised finish, conductive contact surface, with HP markings 04400003 "heavy" Type H-MZ with Z-rail 06197013 Al extrusion, anodised finish, conductive contact surface, with HP markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 06197015 Al extrusion, anodised finish, conductive contact surface, with HP markings 1 piece (SPQ 10)1) 34566-520 34566-528 34560-520 34560-528 34566-720 34566-728 34560-720 34560-728 34560-920 34560-928 34566-540 34560-540 34566-740 34560-740 34560-940 34566-542 34566-563 34560-542 34560-563 34566-742 34566-763 34560-742 34560-763 34560-942 34560-963 34566-584 34560-584 34566-784 34560-784 34560-984 34566-501 34560-501 34566-701 34560-701 6.104 6.104 6.103 6.104 6.104 6.103 – 6.104 6.103 – 6.104 6.103 – – 6.104 6.103 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "heavy" load > 7.5 kg; "rugged" load > 15 kg; Note 쮿 1000 mm version without M4 thread to front, without printing and without notch for 19"-bracket 쮿 EMC gasket see page 6.56 쮿 For further horizontal rails see page 6.29 6.100 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS Rear horizontal rails, centre, for 6 U Main Catalogue Order Information For indirect backplane fixing with insulation strip For direct backplane fixing 04400001 04400002 Type ST 06108090 Usable length Length HP mm 20 106.68 28 147.32 40 208.28 42 218.44 63 325.12 84 431.80 – 1000 Insulation strips see page Threaded inserts see page Fixing material kits see page For direct fixing of connectors in accordance with EN 60603-2 (DIN 41612 Type VT 06197016 04400003 Type MZ 06197017 06197018 Al extrusion, finish anodised, conductive contact surface; without markings Al extrusion, finish anodised, conductive contact surface; without markings Al extrusion, finish anodised, conductive contact surface; without markings 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) 34561-020 34561-028 34561-120 34561-128 34561-220 34561-228 34561-040 34561-140 34561-240 34561-042 34561-063 34561-142 34561-163 34561-242 34561-263 34561-084 34561-184 34561-284 34561-001 34561-101 34561-201 6.104 6.104 6.103 – 6.104 6.103 – 6.104 6.103 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "heavy" load > 7.5 kg; "rugged" load > 15 kg; Note 쮿 All horizontal rails without printed markings 쮿 1000 mm version without M4 thread to front SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.101 Subracks – Drugged ServicePLUS Horizontal rails (type AB) for rear I/O applications Main Catalogue Order Information For CompactPCI in rear I/O area 12,75 AB H - ST 9,75 15 12,75 H - KD 3 06108009 Type AB H - ST AB H - KD 06108069 06197019 Al extrusion, finish anodised, conductive contact surface; horizontal rail type AB (AB = support) is required to fix the guide rails for the 80 mm rear I/O boards; without markings Usable length HP 20 28 40 42 63 84 – Fixing material kits see page Length mm 106.68 147.32 208.28 218.44 325.12 431.80 1000 1 piece (SPQ 10)1) 34561-520 34561-528 34561-540 34561-542 34561-563 34561-584 34561-501 6.103 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple "heavy" load > 7.5 kg; "rugged" load > 15 kg; Note 쮿 All horizontal rails without printed markings 쮿 1000 mm version without M4 thread in end 6.102 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS Screws overview Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Description Material Countersunk screw, with thread locking compound Application: Rugged side panel to horizontal rail; for area of tox-cold welded brackets and corner profiles except when guide rail is fitted to slot 1 Dimension Qty/PU Part no. Stainless steel M4 x 18 100 24566-100 Countersunk screw, with thread locking compound Application: Rugged side panel to horizontal rail; for area of tox-cold welded brackets and corner profiles if guide rail is fitted to slot 1 Stainless steel M4 х 14 100 24566-101 Panhead screw, with thread locking compound Application: Rugged side panel to horizontal rail; not for area of tox-cold welded brackets and corner profiles except when guide rail is fitted to slot 1 Stainless steel M4 х 14 100 24566-102 Panhead screw, with thread locking compound Application: Rugged side panel to horizontal rail; not for area of tox-cold welded brackets and corner profiles if guide rail is fitted to slot 1 Stainless steel M4 х 10 100 24566-103 Panhead screw, with thread locking compound Application: Rugged side panel to cover plate, not for area of tox-cold welded brackets and corner profiles Stainless steel M4 х 8 100 24566-104 Torx countersunk screw , with thread locking compound Application: : Rugged side panel to cover plate, for area of tox-cold welded brackets and corner profiles Stainless steel M4 х 10 100 24566-106 Torx countersunk screw, with thread locking compound Application: Rugged side panel to corner profile; in EMC-shielded subracks and to increase robustness Stainless steel M4 х 7 100 24566-105 Square nut Application: Rugged side panel to corner profile; in EMC-shielded subracks and to increase robustness Zinc-plated steel 100 24560-140 06712051 06712051 aza45940 06712053 06712053 06708053 06708053 M4 AZA45921 Note 쮿 Stainless steel screws; with organic surface layer (silver) SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.103 Subracks – Drugged Threaded inserts, perforated strips, insulation strips Main Catalogue Order Information Threaded insert M2.5 M3 Perforated strip Item 1 Insulation strip 5 2 5 ,0 8 06103056 BZA45853 Usable length HP Threaded insert Perforated strip Length Length mm 1 piece (SPQ 10)1) 1 piece (SPQ 10)1) mm 20 28 40 42 63 84 196 106.18 146.82 207.78 217.94 324.62 431.30 1000.26 – – – – – 34561-328 34561-340 34561-342 34561-363 34561-384 34565-196 34561-484 – for insulated mounting of backplane; PBT UL 94 V-0, grey for centring shielded plug-in units, Al, 1 mm, please order grub screw separately required for fixing the front panel to the horizontal rail; St, zinc-plated; use collar screw 12.3 mm, see page 6.66 34561-320 BZ6749 106.48 147.12 208.08 218.24 324.92 431.60 1000.26 1 piece (SPQ 10)1) 30845-189 30845-197 30845-209 30845-211 30845-232 30845-253 34565-396 Insulation strip Length mm 101.50 144.20 205.12 210.40 316.88 428.64 PU 10 pieces 24560-820 24560-828 24560-840 24560-842 24560-863 24560-884 – Accessories Grub screw M2.5 x 8, 21100-276 – – – – PU 100 pieces Grub screw M2.5 x 9, – – – – 21101-359 PU 100 pieces Grub screw M3 x 8, – – – – 21100-646 PU 100 pieces 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple Part no. includes one packing unit (PU); delivery is exclusively made in PU – – – 19" dual fixing materials kit ruggedDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days Part number in norm al type: ready for despatc h within 10 working days 쮿 For fixing a subrack with dual fixing holes to 19" mounting brackets (e.g. rugged and railroad subracks) 4 Delivery comprises 1 Item 1 2 3 4 1 2/3 2/3 Qty 4 8 8 8 4 Description Double washer, stainless steel M6 x 16 (Torx 30 drive) M6 x 16 (Pozidrive) Cage nut KM6 User manual Order Information Description 19" dual fixing materials kit Part no. 24566-109 06113052 6.104 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged Adaptor to accommodate conduction cooled assemblies (CCA) Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Order Information Adaptor to accomodate conduction cooled assemblies (CCA) in subracks 06112022 Al die-cast, silver, can be screw-fixed, 0.8" pitch; suitable for heavy and rugged horizontal rails, incl. fixing material kit Board length mm 160 VPX PU 1 pair CompactPCI PU 1 pair 24566-004 24566-005 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Guide rails for plug-in units and frame type plug-in units, one-piece, groove width 2 mm and 2.5 mm Main Catalogue Order Information For plug-in units and frame type plug-in units "Standard" Assembly Plastic guide rail - can be clipped into Al extruded horizontal rails - can be clipped into 1.5 mm thick plates Storage temperature from -40 °C ... 130 °C 06102001 Board length Groove width Colour mm 70 70 160 220 280 340 160 220 mm 2 2 2 2 2 2 2.5 2.5 mm red grey red red red red red red up to 220 mm length, PBT, UL 94 V-0; from 280 mm length, multi-piece, end piece PBT, UL 94 V-0, central section Al extrusion PBT, UL 94 V-0 PU 10 pieces2) – – 1 piece (SPQ 50)1) 24560-351 24560-353 64560-001 64560-002 24560-379 – – 24560-380 34579-230 34579-231 – – 64560-096 Retention screw, PU 100 pieces; Torque max. 0.2 Nm 24560-141 24560-141 ESD clip, PU 50 pieces 24560-255 24560-255 64560-098 Accessories 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.107 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.105 Subracks – Drugged ServicePLUS Guide rails for heavy assemblies, CompactPCI, VME64x rugged Servic ePLUSDMAIN CATA LO GPart number in bold face type: ready for shipping wi thin 2 working daysPart number in norm al type: ready for shipping within 10 working days Order Information Assembly - can be clipped into Al extruded horizontal rails - can be clipped into1.5 mm thick plates For CompactPCI, VME64x with coding In accordance with IEEE 1101.10 and Offset 0.1" for power supply units in IEC 60297-3-103 accordance with IEEE 1101.10 and IEC 60297-3-103 For heavy modules, Al extrusion, silver, robust version Storage temperature from -40 °C ... 130 °C 06106001 Board length mm 70 70 160 160 160 220 220 160 220 220 280 280 Groove width mm 2 2 2 2 2 2 2 2.5 2.5 2.5 2.5 2.5 Colour mm red grey red grey green grey green grey red grey red grey 06106002 06102005 One-piece for groove width 2 mm, PBT, UL 94 V-0; multi-piece for groove width 2.5 mm, end piece PBT, UL 94 V-0, middle section Al extrusion PBT, UL 94 V-0, for installation of power supplies in CompactPCI systems or plug-in units with SMD placement Al extrusion; is screwed to horizontal rail "heavy" with retention screws PU 10 pieces 2) PU 10 pieces 2) 1 piece (SPQ 10)1) 24560-355 24560-360 – – – – – – – 24560-356 24560-358 – – – – 34562-881 24560-359 – 34562-882 24561-331 24561-341 – – – – – – – 24560-255 – – 24560-256 24560-256 – 24560-141 24560-141 24560-157 20817-501 20817-501 – 24561-330 24561-340 34562-883 34564-881 – 34564-882 – 34564-883 Accessories ESD clips, PU 50 pieces ESD clips, for alignment pin, PU 50 pieces Retention screw, PU 100 pcs.; torque max. 0.2 Nm Coding peg, PU 100 pieces 1) SPQ (standard pack quantity): Order number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple thereof 2) Order number includes one packaging unit (PU); delivery is exclusively made in PU Description of accessories see from page 6.107 6.106 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS Guide rail accessories Main Catalogue Order Information ESD clips, CompactPCI/VME 64 alignment pin for guide rails Coding for plug-in components Keying/coding for CompactPCI, VME64x handles to IEEE 1011.10 and IEC 60297-3-103 06103052 04612052 Keying/coding peg, PBTP, UL 94 V-0, RAL 7035: Spring steel, tin-plated, ESD clip, for alignment pin in accordance The keying/coding pegs prevent plug-in units with IEEE; can be plugged into the guide rails with coding and into to be mounted in wrong slots. the keying/coding block; provides conductive contact between the They are inserted in the chambers of the guide pin of the inserter/ extractor handle (IEL or IET handle) and codable card guides as well as in the insertion/extraction handles the horizontal rail IEL or IET (4 possible positions), resulting in 64 codings per card guide; when coding the upper and lower card guide, 4096 codings will result; PU 50 pieces 2) Assembly At the top/ at the bottom PU 100 pieces 2) 24560-256 20817-501 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Guide rail accessories Main Catalogue Order Information ESD clip for guide rails 04503050 Spring steel, tin-plated, ensures conductive contact between board and horizontal rail, on both the solder side and the component side Colour Assembly above/below SCHROFF.PENTAIR.CO.UK silver PU 50 pieces 24560-255 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 6.107 Subracks – Drugged ServicePLUS Cover plates for bolting to rugged side panel Order Information Cover plate for bolting to side panel Stainless steel EMC gasket, between cover plate and horizontal rail D2 D1 D 06112054 Perforated Al plate, 1.2 mm, hole diameter 4.0 mm, passivated, perforation ratio 58 %, incl. retention screws; 4 stainless steel EMC contact strips per subrack are required for shielding, please order separately 06106052 Stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails 06197010 Width HP 84 84 84 Depth D mm 175 235 295 84 275 84 277.75 84 295 84 355 Application PU 1 pair 160 mm board depth (D2) 220 mm board depth (D2) 280 mm board depth (D2) 160 mm board depth (D2) CompactPCI, 80 mm rear I/O 160 mm board depth (D2) CompactPCI, 80 mm rear I/O 160 mm board depth (D2), approx. 120 mm clearance behind backplane 220 mm board depth (D2), approx. 120 mm clearance behind backplane PU 10 pieces PU 100 pieces 24560-245 24560-246 24566-007 – – – 24560-271 24560-271 24568-004 24568-008 24568-012 24568-032 24568-036 24568-016 24568-020 Accessories Cover plate latch, additional securing for rugged cover plate, PU 4 pieces Assembly tool, to fit EMC gasket, stainless steel, for horizontal rails, 1 piece rugged Servic ePLUSDMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days Note 쮿 Cover plates without perforation available on request 쮿 Mounting position of horizontal rails, see page 6.98 6.108 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS Combined mounting (6 U and 2 x 3 U one above the other) Main Catalogue Order Information Rugged struts Front panel for textile EMC gasket, 6 U, 2 HP Item 6 for combined mounting 06112077 bpa46550 6 U, die-cast zinc; fixing material kit Al, 2.5 mm, U-profile with notch, 6 U, 2 HP PU 2 pieces 1 piece (SPQ 5)1) 24566-400 30849-140 – 21101-101 – 21101-102 – 21101-121 – 21101-855 06112076 Height U 6 Accessories Pozidrive/slotted collar screw M2.5 x 12.3, St, nickel-plated, PU 100 pieces Pozidrive/slotted collar screw M2.5, black, zinc-plated, PU 100 pieces Washer 2.7 x 5 x 1, PA 6, PU 100 pieces Textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0, PU 10 pieces Note 쮿 Rugged horizontal rails in various lengths, see page 6.99 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.109 Subracks – Drugged ServicePLUS EMC gaskets between front/rear panel and horizontal rail Order Information Stainless steel EMC gasket between front panel/rear panel and horizontal rail 06102053 stainless steel; for front and rear horizontal rails (type VT) 06102053 Width HP 28 42 63 84 Depth mm 131.8 202.9 304.5 416.6 PU 10 pieces 24560-231 24560-233 PU 100 pieces – – – 24560-235 24560-236 24560-229 Main Catalogue EMC gaskets between front panel and 19" bracket/corner profile Order Information Textile EMC gasket between front panel/rear panel and 19" bracket/corner profile 06102056 06108054 textile gasket, core: foam, sleeve: textile cladding with CuNi coating, UL 94 V-0C 06105077 Height U 3 6 Depth mm 97.5 232.5 PU 10 pieces PU 100 pieces 21101-853 21101-855 21101-854 21101-856 Main Catalogue 6.110 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Subracks – Drugged ServicePLUS EMC gasket between horizontal rail and cover plate Order Information Stainless steel EMC gasket, between cover plate and horizontal rail X X 06106052 stainless steel EMC gasket, clips into the horizontal rail and forms the contact with the cover plate; suitable for all horizontal rails X X X 06102052 Width HP 42 84 Depth mm 202.9 416.6 PU 10 pieces Assembly tool, to fit EMC gasket, stainless steel, for horizontal rails, 1 piece 24560-241 PU 100 pieces – 24560-245 24560-246 24560-271 24560-271 rugged Servi cePLUSDMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days EMC gasket between backplane and side panel Order Information Stainless steel EMC gasket between backplane and side panel (depth-offset installation) bpa45916 2 x support profile, Al extrusion, 2 x stainless steel EMC gasket; for vertical EMC shielding between depth-offset shielded backplane and side panel: dimensions for 84 HP A = 425.8 mm, B < 429.9 mm, C = 429.8 mm, D = 431.8 mm 06108078 Height Depth U mm 3 97.5 6 187.5 Torx countersunk screw M4 × 7, St, zinc-plated, PU 100 pieces Square nut M4, St, zinc-plated, PU 100 piece With appropriate design, the backplane can be used as shielded rear wall of the rack; in this case a rear horizontal rail (L-type VT or H-VT) must be used for deeper installation to ensure the horizontal contact. SCHROFF.PENTAIR.CO.UK PU 1 kit 24561-199 24561-499 24566-105 24560-140 For vertical contact the support profile can be fixed in the standard way to the europacPRO side panel (depth grid 30 mm Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.111 OMain Catalogue 19" chassis – O Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 06005001 Standards/certifications 쮿 Exterior dimensions in accordance with: IEC 60297-3-100, 101, 105 Subracks/ 19" chassis . . . . 6 쮿 Ingress protection IP 20 in accordance with IEC 60529 쮿 EMC testing in accordance with VG 95373 part 15 or IEC 61587 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Handles can be bolted on from front 06008009 High stability with aluminium profile side panel 06008010 Mounting plate for fitting heavy components 06008011 Top cover and base plate in 3 versions Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Plain 06008003 Perforated 06008005 06008004 For standardised board mounting Appendix . . . . . 12 6.112 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – O Overview . . . . .. 6.112 OMain Catalogue The ideal solution for electronic devices in the most compact dimensions 쮿 Aluminium or steel (AlZn coated) designs 쮿 For standardised 19" board mounting or for installation of non-standardised components 쮿 EMC shielding upgradable 쮿 Mounting service and customized machining with ServicePLUS 19" complete chassis 쮿 2 materials – Steel plate (AlZn coated) – Aluminium 쮿 3 top cover versions – Top cover/base plate, solid – Top cover/base plate, perforated (aluminium version) – Top cover/base plate for standardised PCBs (aluminium version) 19" complete chassis (St) . . . . . . 6.114 19" complete chassis (Al) . . . . . . 6.115 06008005 19" chassis, individually configured from separate parts 쮿 For non-standardised assemblies with mounting plate 쮿 For standardised board assembly 쮿 Customised solutions 19" chassis for nonstandardised assembly . . . . . . .. 6.120 19" chassis for standardised assembly . . . . . . .. 6.122 06008001 Accessories Guide rails . . . . . .. 6.124 Telescopic slides 1 U . . . . . . . . . . . . 6.125 Telescopic slides 2U............ .. 6.126 ServicePLUS from page 6.118 e.g. individual configuration and assembly e.g. modification (cut-outs) e.g. downloads (CAD drawings, user manuals, test reports) e.g. custom solutions (special sizes) 30407004 SCHROFF.PENTAIR.CO.UK www.schroff.biz/ServicePLUS ServicePLUS . . . 6.118 Application examples. . . . . . . . 6.127 EL FRONT PANEXPRESS 6.113 19" chassis – O 19" complete chassis from steel with plain top cover and base plate OMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch withi n 1 0 working days 쮿 Complete chassis, St (AIZn coated) with Al extrusion front panel 쮿 Detachable rear panel for easy machining 쮿 EMV shielding approx. 20 dB(A) at 1 GHz without additional shielding; > 40 dB(A) at 1 GHz with optional EMC gasketing 쮿 In accordance with standard IEC 60297-3-101 쮿 In the 1 U version 19" and ATX power supplies can be assembled up to a clearance of 40 mm Delivery comprises (Kit) 06002003 4 Item 1 Qty 1 2 3 4 5 1 1 1 1 Description Front panel, Al extrusion, 3 mm; in 1 U: front anodised, rear etched; from 2 U: front and rear side of front panels clear passivated Base body, plain, St, 1 mm, (AIZn coated) Rear panel, St, 1 mm (AIZn coated) Cover, plain, St, 1 mm (AIZn coated) Assembly kit Order Information 2 3 h b 1 H T h = clear height (overall) (H - 3.0 mm) b = clear installation width = 447 mm 06002051 Height Height H Depth T U mm mm 1 43.7 220 1 43.7 280 1 43.7 340 2 88.1 280 2 88.1 340 Accessories Front handles incl. assembly kit for 1 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 2 U, Al extrusion, anodised, PU 2 pieces EMC sealing to close the gap at the front between case and front panel, 2 saw tooth gaskets, stainless steel, PU 1 piece Part no. 20860-120 20860-121 20860-122 20860-126 20860-127 20860-256 20860-257 20860-132 Note 쮿 Further versions with steel front panel (pizza box) available on request 쮿 Telescopic slides cannot be used 쮿 No special EMC version available 쮿 Standardised internal mounting kits cannot be used Front handle 06002052 ServicePLUS see page 6.118 6.114 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – O 19" complete chassis from aluminium with plain top cover and base plate O 쮿 Complete chassis from aluminium 쮿 Detachable rear panel for easy machining 쮿 EMC shielding of approx. 30 dB(A) at 1 GHz (without additonal shielding material) 쮿 In accordance with standard IEC 60297-3-100, -101, -105 쮿 In the 1 U version 19" and ATX power supplies can be assembled up to a clearance of 35 mm Delivery comprises (Kit) 06008003 4 Item 1 Qty 1 2 3 4 5 1 1 1 2 6 1 Description Front panel, Al extrusion, 3 mm; in 1 U: front anodised, rear etched; from 2 U: front and rear side of front panels clear passivated Rear panel, Al, 2 mm, etched Base plate, plain, Al, 1 mm Cover plate, plain, Al, 1 mm Side panel, Al extrusion, raw; with grooves for threaded insert (2 × 7); 5 U, two-piece, 3+2 U Assembly kit Order Information 3 2 5 b h 1 H T h = clear height (overall) (H - 8.1 mm) width = 403 mm Front handle 06002052 ServicePLUS see page 6.118 06008052 b = clear installation Height Height H Depth T U mm mm 1 43.7 220 1 43.7 280 2 88.1 280 2 88.1 340 3 132.6 280 3 132.6 340 3 132.6 400 4 177.0 340 4 177.0 400 4 177.0 460 5 221.5 460 EMC gasketing kit Silicone/nickel gasket 2100 mm for contacting side panel/cover plate; seal, stainless steel, for front panel/cover plate, 1 kit Front handles incl. assembly kit for 1 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 2 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 3 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 4 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 5 U, Al extrusion, anodised, PU 2 pieces Part no. Kit 20860-601 20860-602 20860-605 20860-606 20860-607 20860-608 20860-609 20860-612 20860-613 20860-614 20860-615 20860-130 20860-256 20860-257 20860-258 20860-259 20860-260 Note 쮿 Threaded inserts to push into the side panel see page 6.121 쮿 Telescopic slides to mount into cabinet see page 6.125 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.115 19" chassis – O 19" complete chassis from aluminium with perforated top cover and base plate O 쮿 Complete chassis from aluminium 쮿 Detachable rear panel for easy machining 쮿 In the 1 U version 19" and ATX power supplies can be assembled up to a clearance of 35 mm 쮿 EMC shielding of approx. 30 dB(A) at 1 GHz (without additonal shielding material) 쮿 In accordance with standard IEC 60297-3-100, -101, -105 Delivery comprises (kit) Item 1 Qty 1 2 3 4 5 1 1 1 2 6 1 06008005 4 3 2 5 b h 1 H T h = clear height (overall) (H - 8.1 mm) width = 403 mm Front handle 06008051 b = clear installation 06002052 ServicePLUS see page 6.118 Description Front panel, Al extrusion, 3 mm; in 1 U: front anodised, rear etched; from 2 U: front and rear side of front panels clear passivated Rear panel, Al, 2 mm, etched Base plate, perforated, Al, 1 mm Cover plate, perforated, Al, 1 mm Side panel, Al extrusion, raw; with grooves for threaded insert (2 × 7); 5 U, two-piece, 3+2 U Assembly kit Order Information Height Height H Depth T U mm mm 1 43.7 220 1 43.7 280 2 88.1 280 2 88.1 340 3 132.6 280 3 132.6 340 3 132.6 400 4 177.0 340 4 177.0 400 4 177.0 460 5 221.5 460 EMC gasketing kit Silicone/nickel gasket 2100 mm for contacting side panel/cover plate; seal, stainless steel, for front panel/cover plate, 1 kit Front handles incl. assembly kit for 1 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 2 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 3 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 4 U, Al extrusion, anodised, PU 2 pieces Front handles incl. assembly kit for 5 U, Al extrusion, anodised, PU 2 pieces Part no. 20860-621 20860-622 20860-625 20860-626 20860-627 20860-628 20860-629 20860-632 20860-633 20860-634 20860-635 20860-130 20860-256 20860-257 20860-258 20860-259 20860-260 Note 쮿 Threaded inserts to push into the side panel see page 6.121 쮿 Telescopic slides to mount into cabinet see page 6.125 6.116 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – O 19" complete chassis from aluminium, for assembly of euroboards O 쮿 Complete chassis from aluminium 쮿 Detachable rear panel for easy machining 쮿 EMC shielding of approx. 30 dB(A) at 1 GHz (without additonal shielding material) 쮿 In accordance with standard IEC 60297-3-100, -101, -105 쮿 In the 1 U version 19" and ATX power supplies can be assembled up to a clearance of 35 mm Delivery comprises (Kit) 06008004 4 3 2 5 b h 1 H T h = clear height (overall) (H - 8.1 mm) width = 403 mm 06008050 b = clear installation Item 1 Qty 1 2 3 1 1 4 1 5 2 6 1 Description Front panel Al extrusion, 3 mm; in 1 U: front anodised, rear etched; from 2 U: front and rear side of front panels clear passivated Rear panel, Al, 2 mm, etched Base plate, Al, 1 mm; with drilled holes for horizontal mounting of euroboards Cover plate, Al, 1 mm; with drilled holes for horizontal mounting of euroboards Side panel, Al extrusion, raw; with grooves for threaded insert (2 × 7) Assembly kit Order Information Height Height H Depth T U mm mm 1 43.7 220 1 43.7 280 2 88.1 280 EMC gasketing kit PU 1 kit Front handles for 1 U PU 2 pieces Front handles for 2 U PU 2 pieces Euroboard mounting kit for EN 60603 connector for 1 U PU 1 kit Euroboard mounting kit for EN 60603 connector for 2 U PU 1 kit Euroboard mounting kit for insulated backplane mounting for 1 U PU 1 kit Euroboard mounting kit for insulated backplane mounting for 2 U PU 1 kit Part no. 20860-641 20860-642 20860-645 20860-130 20860-256 20860-257 20860-115 20860-117 20860-116 20860-118 Note Front handle 06002052 쮿 Threaded inserts to push into the side panel see page 6.121 쮿 Guide rails see page 6.124 쮿 Telescopic slides to mount into cabinet see page 6.125 ServicePLUS see page 6.118 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.117 19" chassis – OServicePLUS configuration Simple. Fast. For the product you want. Components can be varied and combined freely 쮿 Configuration tables from page 6.119 쮿 Online configuration: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Professional and reliable from quantity 1 modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Custom modifications from quantity 1 solution Simple. Fast. From one source. Integration and custom developments 쮿 Special sizes (depth and width) 쮿 Ready for despatch within 5 working days 쮿 Ready for despatch within 10 working days 쮿 Individual heat dissipation concepts 쮿 Ready for dispatch within 10 working days express When fast has to be faster. Delivery time to customer's request 쮿 Express logistics academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, CAD drawings, test reports, user reports ServicePLUS 6.118 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – OServicePLUS How to configure 19" aluminium chassis ServicePLUS 쮿 Select height and depth of the basic kit 쮿 Select further components For non-standardised assemblies (1 ... 5 U) 쮿 Mounting plate 쮿 Top cover/base plate 쮿 Front handles 쮿 EMC gasketing kit 쮿 Telescopic slides Note 쮿 Non-standardised assemblies see from page 6.120 06006001 For standardised assemblies (1, 2 U) in accordance with IEC 60297 -3-100, -101, -105 쮿 Top cover/base plate for horizontal board mounting 쮿 Internal connector or backplane fitting 쮿 Front handles 쮿 EMC gasketing kit 쮿 Telescopic slide Note 쮿 Standardised assemblies from page 6.122 06002001 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.119 19" chassis – OServicePLUS Individual components 19" chassis for non-standardised assemblies 쮿 Please select: – Height and depth of basic kit (1 ... 5 U, item 1+2+5) – Mounting plate – Top cover/base plate (item 3+4) – Front handles – EMC gasketing kit – Telescopic slides 쮿 In accordance with IEC 60297-3-105 Order Information Basic kit Mounting plate plain Top cover/base plate perforated 4 3 2 5 b h 1 H T 06008052 h = clear height (overall) (H - 8.1 mm) b = clear installation width = 403 mm Height U 1 1 1 2 2 2 3 3 3 3 4 4 4 4 5 6.120 Height mm 43.7 43.7 43.7 88.1 88.1 88.1 132.6 132.6 132.6 132.6 177.0 177.0 177.0 177.0 221.5 Width HP 84 84 84 84 84 84 84 84 84 84 84 84 84 84 84 Depth mm 220 280 340 220 280 340 280 340 400 460 280 340 400 460 460 06002004 1 x Al front panel, 3 mm; 2 x extruded Al side panels; 1 x Al rear panel, 2 mm, incl. fixing material kit 06002058 Al plate, 2 mm; threaded insert, St, 2 mm, zinc-plated, height 7 mm, length 431.3 mm, M3 hole clearance 1 HP = 5.08 mm; for heavy equipment 06002053 is inserted into the basic kit, Al, 1 mm, passivated; please order EMC gasketing kit separately 06007050 is inserted into the basic kit, Al, 1 mm, passivated; hole diameter 4 mm, perforation ratio 58 % Depth PU 1 kit mm 1 piece 1 piece 1 piece 20860-201 20860-202 150 210 270 150 210 270 210 270 330 390 210 270 330 390 390 20860-107 20860-108 30860-501 30860-502 30860-510 30860-511 20860-109 30860-503 30860-512 20860-107 20860-108 30860-501 30860-502 30860-510 30860-511 20860-203 20860-210 20860-211 20860-212 20860-219 20860-220 20860-221 20860-222 20860-228 20860-229 20860-230 20860-231 20860-240 SCHROFF PRODUCT CATALOG E 05/2017 20860-109 30860-503 30860-512 20860-108 20860-109 30860-502 30860-503 30860-511 30860-512 20860-110 30860-504 30860-513 20860-111 20860-108 30860-505 30860-502 30860-514 30860-511 20860-109 30860-503 30860-512 20860-110 20860-111 30860-504 30860-505 30860-513 30860-514 20860-111 30860-505 30860-514 ELECTRONICS PROTECTION 19" chassis – OServicePLUS Individual components 19" chassis for non-standardised assemblies Order Information Front handles Threaded insert M3 for extruded side panel 06002052 Height U 1 1 1 2 2 2 3 3 3 3 4 4 4 4 5 Height mm 43.7 43.7 43.7 88.1 88.1 88.1 132.6 132.6 132.6 132.6 177.0 177.0 177.0 177.0 221.5 Width HP 84 84 84 84 84 84 84 84 84 84 84 84 84 84 84 Depth D mm 220 280 340 220 280 340 280 340 400 460 280 340 400 460 460 EMC gasketing kit Shielding upgrade of approx. 30 dB 06007051 Assembly kit for telescopic slides esa44237 06094004 Assembly kit and adaptor Gasket 2100 mm, bracket for the silicone/nickel, for contacting cabinets VARISTAR, side panel/ top cover and eurorack, minirack; base plate; for mounting the sawtooth gasket 400 mm; 19in. chassis on stainless steel, for contacting telescopic slides; front panel/ top cover and please order telescopic slides base plate separately see page 6.125 Al extrusion, anodised, incl. assembly kit see page 5.108 St, 2 mm, zinc-plated, height 7 mm, length 431.3 mm, M3 hole clearance 1 HP = 5.08 mm PU 2 pieces 1 piece PU 1 kit PU 1 kit 30821-589 20860-130 20860-131 20860-256 20860-257 20860-258 20860-259 20860-260 Note 쮿 Further sizes available on request 쮿 Al extrusion side panels up to 1000 mm length available on request 쮿 Telescopic slides see page 6.125 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.121 19" chassis – OServicePLUS Individual components 19" chassis for standardised 19" assemblies 쮿 Please select – Height and depth of basic kit (1, 2 U, items 1+2+5) – Top cover/base plate for horizontal board mounting (items 3+4) – Internal mounting for connector or backplane – Front handles – EMC gasketing kit – Telescopic slides 쮿 In accordance with IEC 60297-3-100, 101, 105 Order Information Basic kit Top cover/base plate Mounting of euroboards for EN 60603 connectors for insulated backplane assembly 4 3 2 5 b 6 HE / 6 U 6 HE / 6 U h 1 3 HE / 3 U 3 HE / 3 U H T 06008052 h = clear height (overall) (H - 8.1 mm) b = clear installation width = 403 mm Height U 1 1 1 2 2 2 6.122 Height mm 43.7 43.7 43.7 88.1 88.1 88.1 Width HP 84 84 84 84 84 84 Depth D mm 220 280 340 220 280 340 06002004 1 x Al front panel, 3 mm; 2 x extruded Al side panels; 1 x Al rear panel, 2 mm, incl. fixing material kit 06008053 Al, 1 mm; with drilled holes for horizontal mounting of euroboards 06003050 2 x front horizontal rails, 2 x rear horizontal rails with Z, 2 x threaded inserts; Sufficient for one 3 U board or one 6 U board 06003051 2 x front horizontal rails, 2 x rear horizontal rails, 4 x threaded inserts, 4 x insulation strips PBT, UL 94; Sufficient for one 3 U board or one 6 U board (6 HP for 1 U, 15 HP for 2 U) PU 1 kit 1 piece PU 1 kit PU 1 kit 20860-201 30860-519 20860-115 20860-116 20860-202 20860-203 30860-520 30860-521 20860-115 20860-115 20860-116 20860-116 20860-210 30860-519 20860-117 20860-118 20860-211 20860-212 30860-520 30860-521 20860-117 20860-117 20860-118 20860-118 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – OServicePLUS Individual components 19" chassis for standardised 19" assemblies Order Information Front handles Threaded insert M3 for extruded side panel 06002052 Height U 1 1 1 2 2 2 Height mm 43.7 43.7 43.7 88.1 88.1 88.1 Width HP 84 84 84 84 84 84 Depth D mm 220 280 340 220 280 340 EMC gasketing kit for shielding upgrade of approx. 30 dB 06007051 Assembly kit for fixing on telescopic slides esa44237 06094004 Assembly kit and adaptor Gasket 2100 mm, bracket for the silicone/nickel, for contacting cabinets VARISTAR, side panel/ top cover and eurorack, minirack; base plate; for mounting the sawtooth gasket 400 mm; 19in. chassis on stainless steel, for contacting telescopic slides; front panel/ top cover and please order telescopic slides base plate separately see page 6.125 Al extrusion, anodised, incl. assembly kit see page 5.108 St, 2 mm, zinc-plated, height 7 mm, length 431.3 mm, M3 hole clearance 1 HP = 5.08 mm PU 2 pieces 1 piece PU 1 kit PU 1 kit 30821-589 20860-130 20860-131 20860-256 20860-257 Note 쮿 Further sizes available on request 쮿 Al extrusion side panels up to 1000 mm length available on request 쮿 Telescopic slides see page 6.125 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.123 19" chassis – OServicePLUS Guide rails for boards without front panels, one-piece, groove width 2 mm Order Information Guide rails "Accessories" Assembly - can be clipped into horizontal rails in Al extrusion - can be clipped into 1.5 mm thick plate Storage temperature from -40 °C ... +130 °C 06102002 up to 280 mm length, PBT, UL 94 V-0; > 280 mm length, multi-piece, end piece PBT, UL 94 V-0, middle section Al extrusion Board length mm 160 220 280 340 Groove width mm 2 2 2 2 Colour mm red red red red PU 10 pieces 2) 24560-373 24560-374 24560-375 24560-376 Retention screw, PU 100 pieces 24560-141 2) Part no. includes one packing unit (PU); delivery is exclusively made in PU Guide rail accessories Order Information ESD clip for guide rails Board locking for PCBs without front panel 04503050 Spring steel, tin-plated, ensures conductive contact between board and horizontal rail, on both the solder side and the component side 6.124 Board handle for board locking 04805050 PBT, UL 94 V-0, red, to fix the PCB in the subrack (also slot 1), can also be used without board handle, minimum distance 3 HP Identification strips for board handle 04805051 06108076 Polyester film, 31 x 4 mm, PBT, UL 94 V-0, red, insertion/ self-adhesive, white/matt extraction function with (1 A4 sheet contains 438 pieces) connection to board locking PBT, UL 94 V-0 (also slot 1), mounting directly behind front panel (upper and lower), minimum distance 3 HP PU 50 pieces PU 10 pieces PU 10 pieces 1 piece 24560-255 24560-377 24560-378 60817-228 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – OServicePLUS Universal 1 U telescopic slide ServicePLUS 쮿 Static load-carrying capacity per pair 23 - 39 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 Can be removed 쮿 Extension length > 100 % 쮿 Rail width k = 9.7 mm, max. installation width of extension/drawer w = 429 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00505011 mm 356 406 457 508 559 610 660 711 Extension length Y mm 381 432 483 533 584 635 686 737 Load-carrying capacity P kg 39 36 34 32 29 27 23 23 Part no. 20110-090 20110-091 20110-092 20110-093 20110-094 20110-095 20110-096 20110-097 Note 쮿 For mounting into Schroff cabinets please order assembly kit separately, see page 6.123 00505060 k = rail width, w = max. installation width Dimensions table L 356 406 457 508 559 610 660 711 A 29.5 29.5 29.5 89.9 89.9 89.9 7.4 7.4 B 92.1 92.1 92.1 92.1 92.1 92.1 92.1 92.1 C 184.2 184.2 184.2 184.2 184.2 184.2 184.2 184.2 Internal part D E 276.2 276.2 276.2 276.2 368.3 276.2 368.3 276.2 368.3 276.2 368.3 276.2 368.3 F 460.4 460.4 G 552.4 552.4 X 349.3 349.3 349.3 501.7 501.7 501.7 603.3 603.3 External part O P Q 304.6 317.3 330.0 355.4 368.1 380.8 406.4 419.1 431.8 457.4 470.1 482.8 508.1 520.8 533.5 558.6 571.3 584.0 609.4 622.1 634.8 660.2 672.9 685.6 00505055 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.125 19" chassis – OServicePLUS Universal 2 U, slim telescopic slide Main Catalogue 쮿 Static load-carrying capacity per pair 46 - 57 kg 쮿 Lateral mounting on the 19" uprights (19" plane remains free for fixing the extension/drawer) 쮿 Locking at full extension 쮿 Extension length > 110 % 쮿 Rail width k = 9,7 mm, max. installation width of extension/drawer w = 429 mm Delivery comprises Item 1 Qty 2 Description Telescopic slide, St, zinc-plated Order Information Length L 00505009 0050506000505059 k = rail width, w = max. installation width 356 406 457 508 559 584 610 A 101.6 127.0 127.0 152.4 203.2 203.2 203.2 Internal part w C 184.2 304.8 209.6 355.6 235.0 406.4 260.4 457.2 412.8 508.0 431.8 533.4 438.2 558.8 X 356.0 406.0 457.0 508.0 559.0 584.0 610.0 Load-carrying capacity P kg 57 55 55 55 46 46 46 mm 356 406 457 508 559 584 610 Accessories Assembly kit for VARISTAR, for assembly of 2 telescopic slides, PU 1 kit Assembly kit for eurorack, for assembly of 2 telescopic slides, PU 1 kit Telescopic slides mounting kit for NOVASTAR, to mount 2 telescopic slides, PU 1 kit Delivery: supplied loose with cabinet or frame Dimensions table Length L Extension length Y mm 432 483 533 584 635 660 686 D 101.6 127.0 152.4 152.4 177.8 177.8 203.2 External part E 228.6 254.0 279.4 330.2 355.6 381.0 381.0 Part no. 20110-071 20110-072 20110-073 20110-074 20110-075 20110-076 20110-077 21120-161 21120-162 21120-163 Part no./35 Note F 330.2 381.0 431.8 482.6 533.4 558.8 584.2 쮿 To mount on 19" plane please order assembly kit separately 쮿 Universal telescopic rails can also be fitted without additional components in non-standard applications, thus also in other than 19" cabinets 00505059 6.126 SCHROFF PRODUCT CATALOG E 05/2017 ELECTRONICS PROTECTION 19" chassis – OServicePLUS Customised solutions Text Application: Different cut-outs Application: 2 U version with 2 x 3 U assembly Application: 1 U multipacPRO complete from steel plate; front panel in aluminium with cut-outs SCHROFF.PENTAIR.CO.UK 06002006 06002005 06108007 Application: Combined 3 U and 6 U assembly 06002007 06008006 Application: 1 U multipacPRO (pizza box) complete from steel plate; 19" brackets can be removed if required Application: 1 U multipacPRO complete from steel plate; printed 19" front panel in aluminium with cut-outs Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 06101008 6.127 FMai n C atalogue 19" chassis – F Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 02192001 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Robust 19" chassis, also for board assembly Systems . . . . . . . 8 02192005 Assembly with boards and hinged front panel 02196001 Standards 쮿 External dimensions in accordance with: IEC 60297-3-101 쮿 Ingress protection IP 20 to IEC 60529 Power supply units . . . . . . . . . . 9 쮿 GND/earthing connectors to: DIN EN 50178/VDE 0160 DIN EN 60950/VDE 0805 DIN EN 61010-1/VDE 0411 part 1 DIN EN 61010-1A2/VDE 0411 part 1/A1 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 6.128 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION 19" chassis – F Overview . . . . . . . 6.128 FMain Catalogue 19" chassis with high mechanical stability 쮿 Also usable as desk-top case 쮿 Robust cases from aluminium die-cast frames to front and rear 쮿 Flexible assembly for standardised board formats or individually, e.g. for mounting plates 쮿 Cost benefit with mounting service and custom processing in ServicePLUS 19" chassis/desk-top enclosure inpac 쮿 2 U, 3 U, 4 U and 6 U heights 19" chassis . . . . . . . 6.130 Accessories Full-width front panels . . . . . . . . . . . 6.131 Full-width rear panels . . . . . . . . . . . 6.131 Support rails . . . . . 6.132 Horizontal rails . . . 6.132 Front handles . . . . 6.133 02192002 GND/ earthing kit . . . . . . 6.133 inpac built into 19"cabinet Text Guide rails . . . . . . . 6.134 Dimensions . . . . . . 6.136 02192003 ServicePLUS . . 6.118 ServicePLUS from page 6.118 e.g. individual configuration and assembly from 1 piece e.g. printing e.g. cut-outs in front or rear panels or cover plates e.g. modification (special colours) e.g. custom solutions (special depths, electromagnetically shielded applications) 30407004 SCHROFF.PENTAIR.CO.UK www.schroff.biz/ServicePLUS 6.129 19" chassis – F 19" chassis FMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days 쮿 For assembly with 19" components or individually with mounting plates 쮿 Three rows ventilation slots in base for air inlet Delivery comprises (Kit) 02192006 Item 1 Qty 2 2 1 3 4 1 1 5 1 6 7 4 1 Description Side panel, Al extrusion, RAL 7030, at 6 U: 2 Al corner profiles, 1 divider plate (steel plate) Front frame, Al die-cast, RAL 7030, rear side with counterbores for drill holes to mount handles and front panels Rear frame, Al die-cast, RAL 7030 Cover plate, St, 1 mm, RAL 7035, plastic-coated, with GND/earthing connection Base plate, St, 1 mm, RAL 7035, plastic-coated, with GND/earthing connection Case foot with anti-slip protection, PC, UL 94 V-0 Assembly kit Order Information ipa30632 h1 = useable height Height H U 2 2 2 3 3 3 3 4 4 4 4 6 6 Height H mm 88.0 88.0 88.0 132.5 132.5 132.5 132.5 177.0 177.0 177.0 177.0 265.9 265.9 h mm 86.0 86.0 86.0 130.5 130.5 130.5 130.5 174.5 174.5 174.5 174.5 263.5 263.5 h1 mm 57.5 57.5 57.5 102.0 102.0 102.0 102.0 146.5 146.5 146.5 146.5 235.4 235.4 h2 mm 76.2 76.2 76.2 57.1 57.1 57.1 57.1 101.6 101.6 101.6 101.6 190.5 190.5 Depth D mm 254.5 314.5 374.5 254.5 314.5 374.5 434.5 254.5 314.5 374.5 434.5 374.5 434.5 Part no. 10828-071 10828-072 10828-073 10828-051 10828-052 10828-053 10828-054 10828-056 10828-057 10828-058 10828-059 10828-068 10828-069 IPA30635 Note 쮿 Max. installation space when fitting 19" components is 75 HP 쮿 Scope of delivery includes screws to fix rear and front panels IPA30704 IPA30706 ServicePLUS see page 6.118 6.130 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION 19" chassis – F Front panel F Delivery comprises Item 1 Qty 1 Description Front panel, Al, 2.5 mm, anodised, cut edges untreated Order Information Height U 2 3 4 6 IPA42082 Height H mm 76.0 120.5 165.0 253.8 h1 mm 65.6 110.0 154.5 243.4 Part no. 30828-055 30828-058 30828-061 30828-067 Note 쮿 The assembly kit for the front panel is included with the 19" chassis Front panel, bottom-hinged F Delivery comprises Item 1 Ø 5,9 x 3,3 Qty 1 Description Front panel, hinged, Al, 2.5 mm, anodised, cut edges untreated Order Information Height Height H h1 U mm mm 2 76.0 54.5 3 120.5 99.0 4 165.0 143.5 6 253.8 232.3 Hinge for front panel PPE, UL 94 V-0, PU 1 kit (includes fixing material kit and 2 collar screws) ipa42083 Part no. 30828-085 30828-088 30828-091 30828-097 20828-028 Note 쮿 Please order hinge for front panel separately Rear panel with ventilation openings F Delivery comprises (kit) Item 1 Qty 1 Description Rear panel, incl. assembly kit, Al, 2.5 mm, anodised, cut edges untreated Order Information Height U 2 3 4 6 IPA42086 Height H mm 76.0 120.5 165.0 253.8 h1 mm 65.6 110.0 154.5 243.4 h2 mm – – – 30 Part no. 30828-070 30828-073 30828-076 30828-082 Note 쮿 The scope of delivery of the 19" chassis includes an assembly kit for the front panel SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.131 19" chassis – F Support rail for guide rails F 쮿 4 support rails to fix PCBs with guide rails 2 쮿 Support rail can also be used to fix a custom mounting plate 3 Order Information 1 Item Description front support rail, St, 1.5 mm, blue-passivated, 1 1 piece rear support rail, St, 1.5 mm, blue-passivated, 2 1 piece Accessories Guide rail 160 mm (Item 3), PBT, UL 94 V-0, with integrated fixture for connector to EN 60603 (DIN 41612), PU 1 pair Guide rail 220 mm (Item 3), PBT, UL 94 V-0, with integrated fixture for connector to EN 60603 (DIN 41612), PU 1 pair Screw for mounting of support rails, M4 × 8, flathead bolts with posidrive, PU 100 pieces 4T E IPA30639 Part no. 30828-165 30828-174 60817-078 60817-079 21100-677 쮿 Guide rails see page 6.134 a3-308xx Dimension drawing top: Front support rail, dimension drawing bottom: rear support rail; 1) bush M4, pressed-in Horizontal rail for guide rails, backplane and connector mounting F 쮿 4 horizontal rails to fix guide rails (for PCBs) and for backplane or connector mounting 3 2 쮿 Useable width 75 HP 1 h Order Information 2 1 Item 1: horizontal rail, item 2: Z-rail, item 3: threaded insert h U 2 3 4 6 Bolt-on dimension of backplane mm 75.40 119.80 164.30 252.90 2) bush M4, pressed-in 6.132 IPA30640 SCHROFF PRODUCT CATALOG E 05/2016 Item Description Qty/PU Horizontal rail 75 HP, Al extrusion, 1 1 anodised Accessories Z-rail (item 2), Al extrusion, anodised, 1 piece Threaded insert (item 3), St, zinc-plated (blue), 1 piece Screw to fix horizontal rails, M4 × 8, Pozidrive flathead screw, 100 pieces Cheesehead screw with slot M2.5 × 6, DIN 84, PU 100 pieces M2.5 × 6, DIN 84, 100 pieces Part no. 30828-128 30814-513 30819-604 21100-677 21100-146 Note 쮿 Threaded inserts cannot be used at front 쮿 For backplane mounting, threaded inserts are required in the rear horizontal rails 쮿 For connector mounting, threaded inserts and Z-rails are required in the rear horizontal rails 쮿 Guide rails see page 6.134 A4-587 ELECTRONICS PROTECTION 19" chassis – F Front handles F 쮿 Load-carrying capacity 35 kg per pair Delivery comprises (kit) Item 1 Qty 2 Description Front handle, Al die-cast, powder-coated, RAL 7030, incl. assembly kit Order Information Height U 3 4 6 IPA30636 Part no. 20828-127 20828-128 20828-129 27 44 02108050 GND/earthing kit F 쮿 The GND/earthing kit allows VDE-compliant earthing of the case to: – DIN EN 50178/VDE 0160 – DIN EN 60950/VDE 0805 – DIN EN 61010-1/VDE 0411 Part 1 – DIN EN 61010-1A2/VDE 0411 Part 1/A 쮿 VDE inspection has been carried out Order Information Description Qty/PU GND/earthing kit, Cu wire, 1.5 mm 2, PVC sleeve, green/yellow, links side panels, top cover, base 1 plate and rear panel Part no. 21100-814 aza43284 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.133 19" chassis – F Guide rails 04292012 Order Information a4-2744X Board lengths mm mm 100 160 160 180 220 220 280 340 400 Groove width mm mm 2 2 2.5 2 2 2.5 2 2 2 A42744b a42744c bza44247 a4-2744d Light version, snap-in Standard version, snap-in Version with board fixing, snap-in Version with board fixing, bolt-on Version for heavy load-carrying capacity, snap-in Version with ESD clip Universal version with Al middle section, bolt-on Part no. Part no. Part no. Part no. Part no. Part no. Part no. 1 piece (SPQ 50)1) 1 piece (SPQ 50)1) 1 piece (SPQ 50)1) 1 piece (SPQ 50)1) 1 piece (SPQ 50)1) Qty/PU 1 piece Qty/PU 1 piece – 60817-064 60817-015 60817-103 – 60817-001 – 60817-053 – 60817-102 – 20817-368 – – – 60817-076 – – – – – – – – 60817-149 60817-026 60817-016 – 60817-083 – 60817-085 – 20817-369 – – – – – – 60817-098 – – – – – – – – – – 60817-080 – – – – 20825-120 – – – – – – 20825-121 – 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple Accessories Spring clip PPE, UL 94 V-0, red, PU 10 pieces Spring clip PPE, UL 94 V-0, red, PU 100 pieces Assembly parts for 50 guide rails PU (100 screws, 100 nuts) 21100-553 21100-553 – – 21100-554 21100-554 – – – – 21101-990 – – 21101-990 Note 쮿 For a detailed description of the guide rails see our website; please enter part number in "oneclick" search 6.134 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION 19" chassis – F PCB handle A 쮿 To be mounted behind front panel, for PCB thickness 1.6 mm 쮿 Insertion and extraction function 쮿 Can be labelled Order Information Item Description B4-2728 Material Colour 1 PCB handle A PBT, UL 94 V-0 red 2 Pivot pin DIN 7 Stainless steel – Identification Polyester film, mattstrip self-adhesive silver 3 Qty/PU 1 piece (SPQ 10) 100 Part no. 60817-096 100 21100-672 21100-671 SPQ (Standard Pack Quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity: Please order at least 10 pieces PCB handles or a multiple BZA42727 BZA42724 PCB retainer A 쮿 Can also be used without PCB handle 쮿 Application on top and bottom horizontal rail Order Information Item Description PCB retainer A for 4 top and bottom C4-2728 Material PPE, UL 94 V-0 Colour Qty 1 piece red (SPQ 10) Part no. 60817-097 SPQ (Standard Pack Quantity): Part number includes 1 piece, but delivery is exclusively made in Standard Pack Quantity: Please order at least 10 pieces PCB retainers or a multiple PCB retainer B 쮿 Can be used on upper and lower horizontal rail, for PCB thickness 1.6 mm 쮿 Can also be used without PCB handle 쮿 Can also be used with guide blocks Order Information Item 4 BZA46428 4a Description PCB retainer,bottom Material Colour PPE, UL 9 red 4 V-0 PPE, UL 9 black PCB securing top 4 V-0 Qty 1 piece (SPQ 10) 1 piece (SPQ 10) Part no. 60817-054 60817-071 SPQ (Standard Pack Quantity): Part number includes 1 piece, but delivery is exclusively made in Standard Pack Quantity: Please order at least 10 pieces PCB retainers or a multiple SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.135 19" chassis – F Dimensions 19" front frame A3--306 Section A-A There are counterbores at the rear side of the front frame which can be drilled if required: 1) For handle mounting 2) For mounting of partial-width front panel (grid 5.08 mm) 19" rear frame A3-305 Section A-A Dimensions table Height in U 2 3 4 6 6.136 H 88,0 132.5 177.0 265.9 Text HR 86,0 130.5 175.0 263.9 h 57,5 102.5 146.5 235.4 SCHROFF PRODUCT CATALOG E 05/2016 h1 77,3 121.8 166.3 255.2 h2 69,8 114.3 158.8 247.7 h3 25,0 90,0 134.5 233.4 h4 76.2 57.1 101.6 190.4 h5 65,5 110.0 154.5 243.4 h6 68,0 112,5 157,0 245,9 h7 68,4 112.8 157.3 245,9 ELECTRONICS PROTECTION 19" chassis – F Dimensions Side panel “Y” Y A3--304a Detail "Y" A3--304b Dimensions table Height in U 2 2 2 3 3 3 4 4 4 6 6 6 H 82,6 82,6 82,6 127.0 127.0 127.0 171,0 171,0 171,0 260,4 260,4 260,4 SCHROFF.PENTAIR.CO.UK Text h1 – – – 24,0 24,0 24,0 68,5 68,5 68,5 157,1 157,1 157,1 h2 68,0 68,0 68,0 112,5 112,5 112,5 157,0 157,0 157,0 245,9 245,9 245,9 h3 71,4 71,4 71,4 115,8 115,8 115,8 160,3 160,3 160,3 248,9 248,9 248,9 h4 59,0 59,0 59,0 103,5 103,5 103,5 148,0 148,0 148,0 236,5 236,5 236,5 L 220,5 280,5 340,5 220,5 280,5 340,5 220,5 280,5 340,5 220,5 280,5 340,5 L1 140,5 200,5 260,5 140,5 200,5 260,5 140,5 200,5 260,5 140,5 200,5 260,5 (n) 17,0 23,0 29,0 17,0 23,0 29,0 17,0 23,0 29,0 17,0 23,0 29,0 Y 170 230 290 170 230 290 170 230 290 170 230 290 T 254,5 314,5 374,5 254,5 314,5 374,5 254,5 314,5 374,5 254,5 314,5 374,5 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 6.137 Main CataloguePart num ber in bold face type: ready for despatch within 2 w orking daysPart num ber in normal type: ready for despatch within 1 0 working days Front panels, plug-in units, frame-type plug-in units Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Front panels 쮿 Extensive standard range 쮿 Individual modification to customer requirements: drill holes, cut-outs 쮿 Individual printing 쮿 Front Panel Express Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Plug-in units 쮿 Front panels with handles in various designs – Extensive standard range – Individual modification to customer requirements: drill holes, cut-outs – Individual printing – Front Panel Express Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 7.0 SCHROFF Main catalogue Downloads und weitere wichtige Informationen finden Sie im Internet unter www.schroff.biz www.schroff.biz E 05/2016 36106003 (09292001 04612001) ELECTRONICS PROTECTION Front panels, plug-in units, frame-type plug-in units Frame-type plug-in units 쮿 쮿 쮿 쮿 To hold and protect PCBs High stability Outstanding cooling With or without EMC shielding Overview . . . . . . 7.0 Front panels . . 7.2 Plug-in units . . 7.16 Frame type plug-in units . . 7.64 minipac . . . . . . . 7.98 PCB accessories . . . 7.102 minipac Assembly material . . . . . . . 7.107 쮿 Convenient small case - flexible enough for all your requirements 쮿 To accommodate nonstandardised or standardised PCBs 쮿 As desktop enclosure, for wall mounting or mounting on a DIN support rail Modules to mount drive units see chapter System Accessories . . 8.110 Accessories 쮿 Brackets, handles, covers 쮿 Assembly material 쮿 Tools 36106004 (04802002 04812001 11092008 04995001) SCHROFF.PENTAIR.CO.UK 7.1 Front panelsMai n C atalogue Front panels Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 04292001 Standards 쮿 IEC 60297-3-101/IEEE 1101.1/10 ServicePLUS Subracks/ 19" chassis . . . . 6 e.g. individual colouring e.g. customised cut-outs e.g. printing e.g. mounting service e.g. special dimensions Front panels, plug-in units . . . 7 www.frontpanelexpress.eu 30407004 EL FRONT PANE XPRESS Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 32304003 04210001 04603009 Appendix . . . . . 12 7.2 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panels Overview . . . . . . 7.2 Front panels Front panels for fitting in subracks, cases and systems 쮿 Extensive standard range with various finishes and materials (aluminium or stainless steel) 쮿 Front Panel Express: Fast delivery service of customised versions (from 2 days) 쮿 EMC shielding retrofittable Main Catalogue Front panels, unshielded Front panels 쮿 Aluminium, clear anodised Unshielded . . . . . . 7.4 쮿 Aluminium, clear pre-anodised, cut edge untreated EMC stainless steel gaskets . . . . 7.6 쮿 Aluminium, front anodised, rear iridescent green chromated Shieldable . . . . . . . 7.5 Assembly tool . . . . 7.6 쮿 Other finishes on request 04292001 Front panels shieldable, flat Text 쮿 With lateral grooves to fit EMC gaskets (stainless steel) 쮿 Compatible with the shielded U profile version Front panels Shieldable (U profile) . . . . . . . . 7.7 04600006 Front panels, shieldable, U profile Text EMC textile gasket . . . . . . . . . . . 7.6 쮿 With lateral groove to fix a textile self-adhesive EMC gasket Further front panels 쮿 Compatible with the shielded flat version Hinged, shielded . 7.9 쮿 High robustness through U profile Hinged . . . . . . . . . . 7.8 For D-Sub connectors . . . . . . 7.10 For Coax connectors . . . . . . 7.11 3 U with GND/ earthing . . . . . . . . . 7.11 04602004 Further front panels Text Mezzanine front panels . . . . . . . . . . . 7.12 쮿 Hinged/folding front panels 쮿 Front panels with GND/earthing Assembly kit . . . . . 7.107 쮿 Mezzanine front panels AdvancedTCA front panels . . . . . . 8.12 쮿 AdvancedTCA front panels MicroTCA front panels . . . . . . . . . . . 8.65 쮿 MicroTCA front panels AdvancedMC front panels . . . . . . . . . . . 8.60 쮿 AdvancedMC front panels 04295001 04295002 SCHROFF.PENTAIR.CO.UK 7.3 Front panels Front panels, unshielded Front panelsMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatch within 10 working days 쮿 Front panel, Al, 2.5 mm B b1 9.8 7.45 쮿 Versions: – Al, anodised – Al, anodised, cut edges plain – Al, front anodised, rear iridescent green chromated b2 H H 3 7.45 Note 3 3.3 쮿 Other sizes and finishes available on request 쮿 Please order fixing material separately, see chapter Assemply parts, page 7.107 2 HP 2.5 2.5 ø 5.9 04602084 04602051 > 2 HP Order Information Height H Width B b1 b2 U 1 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 9 HP 84 84 2 3 4 5 6 7 8 10 12 14 21 28 42 63 84 84 2 4 5 6 7 8 10 12 14 16 21 28 42 63 84 84 mm 426.4 426.4 9.8 14.9 20.0 25.0 30.1 35.2 40.3 50.5 60.6 70.8 106.3 141.9 213.0 319.7 426.4 426.4 9.8 20.0 25.0 30.1 35.2 40.3 50.5 60.6 70.8 80.9 106.3 141.9 213.0 319.7 426.4 426.4 mm 411.5 411.5 – – – – – – 25.4 2) 35.6 45.7 55.9 91.4 127.0 198.1 304.8 411.5 411.5 – – – – – 25.4 2) 35.6 45.7 55.9 66.0 91.4 127.0 198.1 304.8 411.5 411.5 mm 203.2 203.2 – – – – – – – – – – – – 101.6 2) 157.5 203.2 203.2 – – – – – – – – – – – – 101.6 2) 157.5 203.2 203.2 mm 39.5 84.0 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 172.9 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 395.1 Qty 1) 1 1 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 Anodised, cut edges plain Part no. Anodised Part no. Front anodised, rear colorless chromated Part no. – 30818-271 – 30807-416 20850-426 30847-461 30810-433 30810-432 30847-470 30818-272 30818-273 30807-508 30807-481 30847-471 30838-043 30818-274 30807-510 30838-044 30818-275 30818-276 30807-482 30807-509 30838-045 30838-046 30818-277 30807-484 30838-047 30818-279 30818-281 30807-483 30807-485 30838-049 30838-051 30818-282 30807-501 30838-053 30818-289 30818-296 30807-487 30807-496 30838-060 30838-067 30818-310 30807-494 30838-081 30818-331 30818-352 30808-067 30807-506 30838-102 30838-123 30818-434 30807-596 30847-465 30818-747 30818-518 30818-741 30807-778 30847-472 30838-124 30818-519 30807-777 30838-125 30818-520 30818-521 30807-752 – 30838-126 30838-127 30818-522 30807-779 30838-128 30818-524 30818-526 30807-753 30807-755 30838-130 30838-132 30818-528 30807-758 30838-134 30818-530 30818-535 30807-780 30807-757 30838-136 30838-141 30818-542 30807-766 30838-148 30818-556 30818-577 30807-764 30807-771 30838-162 30838-183 30818-598 30807-776 30838-204 – – 30847-556 1) SPQ (standard pack quantity): Part number includes 1 piece, but delivery is exclusively made in standard pack quantity (SPQ); please order at least the SPQ quantity or a multiple 2) This dimension is only available for "front anodised, rear iridescent green chromated" version 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 7.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panels Front panels, shieldable Front panels M 2.5 1.8 7.45 X 쮿 Front panel, Al, 2.5 mm, front anodised, rear iridescent green chromated, 2 alignment pins pressed-in, stainless steel X 쮿 Shielding with stainless steel EMC gasket 10.7 9.8 Order Information H R 11 0.65 Y 2.5 1 2.5 3 1.8 Y 04602052 2 HP 5.08 b2 X H 3 7.45 B b1 Height H U mm Width B HP mm b1 mm b2 mm 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 9 84 2 3 4 5 6 7 8 10 12 14 21 28 42 63 84 84 2 4 5 6 7 8 10 12 14 16 21 28 42 63 84 84 411.5 – – – – – – 25.4 35.6 45.7 55.9 91.4 127 198.1 304.8 411.5 411.5 – – – – – 25.4 35.6 45.7 55.9 66 91.4 127 198.1 304.8 411.5 411.5 203.2 – – – – – – – – – – – – 101.6 157.5 203.2 203.2 – – – – – – – – – – – – 101.6 157.5 203.2 203.2 84 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 172.9 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 395.1 426.4 9.8 14.9 20 25 30.1 35.2 40.3 50.5 60.6 70.8 106.3 141.9 213 319.7 426.4 426.4 9.8 20 25 30.1 35.2 40.3 50.5 60.6 70.8 80.9 106.3 141.9 213 319.7 426.4 426.4 Alignment pin – – x x x x x x x x x x x x x – – – x x x x x x x x x x x x x – – Qty 1 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 Part no. 30846-588 30846-864 20846-425 20846-426 20846-427 20846-428 20846-429 20846-430 20846-431 20846-432 20846-433 20846-434 20846-436 20846-437 20846-438 30846-676 30846-683 30846-865 20846-443 20846-444 20846-445 20846-446 20846-447 20846-448 20846-449 20846-450 20846-456 20846-451 20846-452 20846-453 20846-454 30846-771 30846-859 3.3 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 5 pieces or a multiple. Pricing is per individual item. ø 5.9 Note Y 2.5 5 ø 2.5 > 2 HP SCHROFF.PENTAIR.CO.UK 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 쮿 Please order stainless steel EMC gasket separately, see page 7.6 04608154 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 7.5 Front panels Stainless steel EMC gasket Front panels 쮿 The stainless steel EMC gaskets are inserted into the lateral slots of the shieldable front panels (2 pieces per front panel) Delivery comprises Item 1 Qty Description 10/100 EMC gasket (stainless steel) Order Information bga45760 Montagewerkzeug Height Height Qty/PU U mm 2 52 10 3 97 10 3 97 100 4 142 10 4 142 100 5 187 10 5 187 100 6 232 10 6 232 100 9 367 10 9 367 100 Assembly tool for EMC gasket (stainless steel), 1 piece Part no. 21101-775 21101-705 21101-706 21101-713 21101-714 21101-777 21101-778 21101-707 21101-708 21101-709 21101-710 24560-270 Note 쮿 Please order assembly tool separately aza45937 Textile EMC gasket 쮿 Textile EMC gasket is glued laterally on the front panel, in the groove of the right-hand profile 쮿 2 temperature ranges – Temperature range -40... +70 °C – Temperature range -40... +85 °C Delivery includes Item 1 04602054 EMC characteristic (typical, green) B1 (red): -40 ... -70 °C, B2 (blue): -40 ... -85 °C Qty see Order Information Description EMC textile gasket, core: TPE foam (-40... +70 °C), Core: silicon with hollow chamber (-40... +85 °C), sleeve: textile cladding with CuNi coating Order Information Height Height Qty/PU U mm piece 2 3 3 4 5 6 6 9 9 52 97 97 142 187 232 232 365 365 10 10 100 10 10 10 100 10 100 Part no. Part no. Temperature range -40... +70 °C Temperature range -40... +85 °C 21101-857 21101-853 21102-857 21102-853 21101-854 21102-854 21101-858 21101-978 21102-858 21102-978 21101-855 21102-855 21101-856 21101-859 21102-856 21102-859 21101-904 – 04614052 7.6 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panels Front panels, U profile, shieldable 2 HP 3U 7.45 5.08 Front panels 쮿 High stability through U profile 9.8 7.45 5.08 14.9 쮿 Front panel, U profile, Al, front anodised, rear conductive, 2 alignment pins pressed-in, stainless steel 쮿 Differerences in the finish between 2 ... 12 HP and 14 ... 84 HP 3 3 3.3 H H Order Information X Y 2.5 2.5 ø 5.9 X Y ø 2.5 Y X Y 6.2 2.5 5 2.5 6.2 2.5 5 2.5 6.2 6.2 ø 2.5 X 04608155 04608158 > 3 HP 7.45 B b1 b2 3.3 H 3 5.08 Height H Width B U mm HP mm b1 mm b2 mm 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 9 411.5 – – – – – – 25.4 35.6 45.7 55.9 66 91.4 127 198.1 304.8 411.5 411.5 – – – – – 25.4 35.6 45.7 55.9 66 91.4 127 198.1 304.8 411.5 411.5 203.2 – – – – – – – – – – – – – 101.6 157.5 203.2 203.2 – – – – – – – – – – – – 101.6 157.5 208.3 203.2 84 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 128.4 172.9 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 261.8 395.1 84 2 3 4 5 6 7 8 10 12 14 16 21 28 42 63 84 84 2 4 5 6 7 8 10 12 14 16 21 28 42 63 84 84 426.4 9.8 14.9 20 25 30.1 35.2 40.3 50.5 60.6 70.8 80.9 106.3 141.9 213 319.7 426.4 426.4 9.8 20 25 30.1 35.2 40.3 50.5 60.6 70.8 80.9 106.3 141.9 213 319.7 426.4 426.4 Alignment pin – x x x x x x x x x x x x x x x – – x x x x x x x x x x x x x x – – Qty 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 (SPQ 5)1) 1 1 1 1 Part no. 20848-262 30849-001 30849-004 30848-354 30848-378 30848-380 30848-382 30848-356 30848-386 30848-358 20848-013 20848-015 20848-020 20848-027 20848-047 20848-068 20848-097 20848-271 30849-002 30848-355 30848-379 30848-381 30848-383 30848-357 30848-387 30848-359 20848-106 20848-108 20848-113 20848-120 20848-139 20848-160 20848-189 20848-280 1) Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 5 pieces or a multiple. Pricing is per individual item. ø 5.9 B - 2.53 Note 쮿 Differences in finish between 2 ... 12 HP and 14 ... 84 HP – 2 ... 12 HP: one-part U-profile – 14 ... 84 HP: multi-part U-profile (front panel with crimped profiles) 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 쮿 Please order textile EMC gasket separately, see page 7.6 Y 2.5 Z X Y 6.2 2.5 2.5 5 6.2 ø 2.5 04608156 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 7.7 Front panels Front panels, bottom-hinged Front panels 쮿 Suitable for subracks (europacPRO) and cases (ratiopacPRO, propacPRO, compacPRO) 쮿 Front panel can be unhinged at 135° (not ratiopacPRO) opening angle 쮿 The useable width is not restricted 쮿 Mounts on the horizontal rails 쮿 2 versions: – unshielded – shielded, U front panel with textile EMC gasket 04295001 Delivery comprises (kit) Item 1 1a 2 3 4 5 6 Qty Description Unshielded Shielded 1 Front panel, hinged, Al, 2.5 mm, anodised, cut edges plain 1 Front panel, U profile, hinged, Al, 2.5 mm, front anodised, rear iridescent green chromated 2 3 Hinge, Zn die-cast, nickel-plated 2 3 Sleeve, PA 2 3 Knurled screw M2.5 x 12.3, nickel-plated 1 EMC textile gasket, core: foam, sleeve: textile cladding with CuNi coating 1 1 Assembly kit 04602080 Unshielded Note A B 쮿 Unshielded: Dimension C for 84 HP only C 7.45 2.5 15.6 16 8.2 M 2.5 3 H 3 ø5.9 x 3.3 3.1 D B - 25.4 X Y 6.2 Y 2.5 2.5 6.2 X 04602079 Shielded Order Information Dimensions Height Width A U HP mm 3 28 141.9 3 42 213.0 3 63 319.7 3 84 426.4 4 42 213.0 4 63 319.7 4 84 426.4 6 28 141.9 6 42 213.0 6 63 319.7 6 84 426.4 1) Dimension with unshielded front panel 7.8 B mm 127.0 198.1 304.8 411.5 198.1 304.8 411.5 127.0 198.1 304.8 411.5 SCHROFF PRODUCT CATALOG E 05/2016 C mm – 101.6 157.5 208.3 1) 101.6 157.5 208.3 1) – 101.6 157.5 208.3 1) D mm – 86.4 137.2 193.0 86.4 137.2 193.0 – 86.4 137.2 193.0 H mm 128.4 128.4 128.4 128.4 172.9 172.9 172.9 261.8 261.8 261.8 261.8 Shielded Part no. Unshielded Part no. 20848-608 20838-280 20848-599 20838-271 20848-600 20848-601 20838-272 20838-273 20848-605 20838-277 20848-606 20848-607 20838-278 20838-279 20848-696 – 20848-602 20838-274 20848-603 20848-604 20838-275 20838-276 ELECTRONICS PROTECTION Front panels Front panel, hinged, shielded Front panels 쮿 Suitable for subracks (europacPRO) and cases (ratiopacPRO, propacPRO, compacPRO) 쮿 Mounts on horizontal rails 쮿 Front panel with textile EMC gasket 쮿 Hinges can be fitted on left or right Delivery comprises (kit) 04295002 Item 1 Qty 1 2 3 2 1 4 1 Description Front panel, hinged, Al, 2.5 mm, front anodised, rear iridescent green chromated Hinge, Zn die-cast, chrome-plated Textile EMC gasket, core: foam, sleeve: textile cladding with CuNi coating Assembly kit Order Information Height U 3 6 H mm 128.4 261.8 h mm 89.9 223.2 W mm 426.4 426.4 w mm 203.2 203.2 Part no. 20848-611 20848-617 06106053 04602081 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 7.9 Front panels Front panels for D-Sub connectors Front panels X 쮿 3 U/4 HP X X 쮿 Aluminium, front anodised, rear irisdescent green chromated Delivery comprises Item 1a 1b 15.7 29.6 51,7 36.1 44.3 72.1 쮿 Shielding through: stainless steel EMC or textile EMC gasket (please order separately) 1c 04608141 04608142 04608143 Cut-out 9-pin Description Front panel, Al, 2.5 mm, front anodised, rear irisdescent green chromated Front panel, Al, 2.5 mm, front anodised, rear iridescent green chromated; for EMC stainless steel gasket Front panel, U profile, Al, 2.5 mm, front anodised, rear conductive; for EMC gasket (textile) Order Information X Cut-out X Qty Unshielded Part no. 1a 51.8 1 × 9-polig 47.6 2 × 9-polig 21.7 3 × 9-polig 1 × 15-polig 04608144 04608145 Cut-out 15-pin 1 × 25-polig X X 2 × 15-polig 2 × 25-polig 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) For EMC gasket Stainless steel Textile Part no. Part no. 1b 1c 30118-341 30118-348 30849-749 30118-344 30118-351 30849-750 30118-347 30118-354 30849-751 30118-342 30118-349 30849-752 30118-345 30118-352 30849-753 30118-343 30118-350 30849-754 30118-346 30118-353 30849-755 55.5 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 5 pieces or a multiple. Pricing is per individual item. 13 40.7 Note 04608146 04608147 1.8 Unshielded Y 1 2.5 2,5 20 1.8 0.65 Y X 10.7 20 2,5 Cut-out 25-pin 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 쮿 Please order stainless steel EMC gasket separately, see page 7.6 쮿 Please order textile EMC gasket separately, see page 7.6 R 11 EMC gasket, stainless steel Z1 6,2 2,5 2,5 For textile EMC gasket 7.10 Z2 6,2 20 Z2 2,5 Z1 04608150 04608151 04608149 04608148 04808152 04808153 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panels Front panels for Coax connectors Front panels 쮿 3 U/4 HP 쮿 Aluminium, 2.5 mm, front anodised, rear irisdescent green chromated Order Information Description Cut-out 4 x Coax, unshielded Qty/PU 1 Part no. 30118-355 Note 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 04602057 Front panels 3 U with GND/earthing connection Front panels 쮿 Earthed front panel (protection class 1) Delivery comprises (items 1 – 3 assembled) Item 1 Qty 1 2 3 4 4 4 1 Description Front panel 3 U, Al, 2.5 mm, front anodised, rear iridescent green chromated with GND/earthing connection Plastic sleeve, PA, grey Collar screws, M2.5 x 11 and 12.3 Pozidrive, St, nickel-plated GND/earthing kit, length of GND/earthing cable 320 mm Order Information 02998001 Height U 3 3 3 3 3 Width HP 7 14 21 28 42 Qty 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 piece (SPQ 5) 1 Part no. 20119-159 20119-160 20119-161 20119-162 20119-163 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 5 pieces or a multiple. Pricing is per individual item. Note 쮿 Please order fixing material (sleeves, collar screws) separately, see page 7.107 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 7.11 Front panels PMC Mezzanine front panels Front panelsMain C atalogPart number in bold face type: ready for shippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days 쮿 Based on PCI 2.2 specification (PCI = Peripheral Component Interface) 쮿 In accordance with PMC mezzanine specification IEEE P 1386 04615054 PMC mezzanine front panel kit, shielded, with trapezoidal extractor handle Type 1 Front panels 쮿 PMC= PCI Mezzanine Card 쮿 For module size 194 x 74 mm2 쮿 In accordance with specification IEEE P1386 (CMC= Common Mezzanine Card) 5 쮿 6 U/4 HP front panel with stainless steel EMC gasket and front handles Delivery includes (assembled) Item 3 5 6 3 Qty 1 1 2 Description PMC front panel, Al extrusion, 6 U, 4 HP, clear passivated EMC gasket (St, stainless) Trapeziform extraxtor handle, type 1 Order Information Item Description 3+5+6 Front panel with 2 cut-outs Accessories Spacer to mount PMC and FMC mezzanine boards Voltage keying/coding pin for PMC mezzanine boards 6 Item 3: front panel, item 5: EMC gasket, item 6: front handle 7.12 SCHROFF PRODUCT CATALOG E 05/2016 MPA44845 PMC cover for front panel cutouts for EMC shielding, PMC gasket for mezzanine front panels PMC gasket for mezzanine front panels Part No. 20897-950 see page 7.15 see page 7.15 see page 7.13 see page 7.13 ELECTRONICS PROTECTION Front panels PMC cutout cover for EMC protection Front panels 15.1 쮿 EMC cover to close unused cut-outs in the PMC mezzanine front panels 쮿 Material stainless steel, 0.2 mm 쮿 Colour: black or bright Order Information Colour Black Bright 73.7 71.5 9 Qty 1 piece (SPQ 10) 1 piece (SPQ 10) Part no. 60835-024 60835-022 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 4.1 3 12.9 04610028 Item 9: EMC cover; Item 3: front panel MPA44847 PMC bezel for mezzanine front panels Front panels 쮿 Mezzanine front panel is fitted into PMC front panel cut-outs; EMC shielding with conductive O-ring 2.5 2.25 12.7 쮿 Material: – Aluminium extrusion (anodised, contact surfaces conductive) – Zinc die-cast (untreated, black or chrome-plated, matt) 12.0 74 69.5 Delivery comprises (kit) M 2.5 Item 4 Qty 1 7 1 Description PMC bezel for mezzanine front panel, Zn die-cast or Al extrusion EMC gasket (O-ring), Cho-Seal Order Information PMC mezzaninefront panel 9.9 4 10.9 7 04610029 SCHROFF.PENTAIR.CO.UK mpa44846 Qty/PU with EMC gasket Part no. Material Al extrusion, anodised, 1 20835-598 contact surfaces conductive Al extrusion, anodised, 10 20835-889 contact surfaces conductive Zn die-cast, untreated 1 20835-890 Zn die-cast, untreated 10 20835-893 Zinc die-cast, black, chromated 1 20835-922 Zinc die-cast, black, chromated 10 20835-924 Zinc die-cast, chrome-plated, matt 1 20835-923 Zinc die-cast, chrome-plated, matt 10 20835-928 Cheesehead screw M2.5 × 5 mm, PU 100 pieces EMC gasket O-ring, 1 piece (Standard Pack Quantity 10 pieces) without EMC gasket Part no. – 20835-899 – 20835-896 – 20835-931 – 20835-929 21100-624 60835-021 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 7.13 Front panels FMC mezzanine front panels Front panelsMain C atalogPart number in bold face type: ready for shippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days 쮿 FMC = FPGA mezzanine card 쮿 For standard defined I/O mezzanine modules which connect to carrier cards 쮿 For single 69.0 x 76.5 mm or double 139.0 x 76.5 mm modules 쮿 In accordance with Vita 57.1 specification 04615052 FMC mezzanine front panel kit, shielded, with IEL handle Front panelsMain C atalogPart number in bold face type: ready for shippi ng withi n 2 working daysP art number i n normal type: ready for s hipping within 1 0 working days 쮿 3 U or 6 U, 4 HP, U-shaped front panels with textile gasketing 5 3 쮿 1 or 3 FMC cutouts (depending on height) 4 쮿 1 or 2 IEL front handles (depending on height) 쮿 EMC shielded, both the front panel and the FMC bezels 1 1 Delivery includes (assembled) 4,5 Item 2 4,5 2 1 Qty 3U 1 6U 1 Description 2 3 1 1 1 2 4 5 6 1 1 1 3 3 1 FMC front panel, U profile, Al, 4 HP, front anodized, rear conductive, 3 U has 1 cut out, 6 U has 3 cut outs EMC textile gasket for front panel IEL handle (handel, black, RAL 9005; button, light grey, RAL 7035) FMC bezel for front panel cut outs EMC gasket (O-ring) Assembly kit Order Information 3 04615050 7.14 SCHROFF PRODUCT CATALOG E 05/2016 Height U 3 6 Accessories Spacer to mount PMC mezzanine boards Part no. 20836-253 20836-254 see page 7.15 ELECTRONICS PROTECTION Front panels EMC bezel for FMC Mezzanine front panel cut-outs Front panels Main CatalogPart number in bold face type: ready for shi pping within 2 working daysP art number in normal type: ready for shipping withi n 1 0 worki ng days 쮿 FMC bezel is fitted into FMC Mezzanine front panel cut-outs 10 쮿 Shielding for FMC bezels with an optional conductive O-ring, please order separately 12, 2,5 8 04610029 4 Order Information 56,55 61,05 58,45 12 쮿 Material, Al extrusion (anodised, contact surface conductive) Description ,5 M2 04615051 04615053 Item Qty/PU piece EMC bezel for FMC Mezzanine front 4 10 panel cut outs Accessories EMC gasket for mezzanine front panel item 5 , O-ring, (VITA 57.1), 1 piece (standard pack quantity 10 pieces) Cheesehead screw M2.5 × 5 mm, PU 100 pieces Part no. 20835-849 60835-077 21100-624 Front panel express solution 5 Spacer to mount PMC and FMC mezzanine boards 5.8 Front panels 10 쮿 To provide a standoff between mezzanine boards per the IEEE P1386 or VITA 57.1 specification and the carrier card Order Information Description Spacer M 2.5 5 MPA44850 mpa44437 Spacer within PMC application Item 10 Material St, zinc-plated Qty 1 piece (SPQ 10) Part no. 60897-278 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 04615055 Voltage keying/coding pin for PMC mezzanine boards 5.8 Front panels 13.5 쮿 To prevent accidental damage when fitting mezzanine boards, keying/coding pins are bolted to the VMEbus boards to distinguish between 3.3 V and 5 V operation. The mezzanine boards have a hole drilled in the appropriate position. The keying/coding pin thus ensures that only mezzanine boards with the same operating voltage can be inserted. For doubleheight euroboards 2 pieces are required. 7 5 M 2.5 Order Information 5 MPZU6325 Description Keying/ coding pin 5 V/3.3 V Item Material Qty St, zinc11 1 piece (SPQ 10) plated Part no. 60827-026 Delivery is exclusively made in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 06710007 SCHROFF.PENTAIR.CO.UK Application mpa44437 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 7.15 Main C atalogue Plug-in units Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 04612001 P lug-in unitsMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for des patch within 1 0 working days Plug-in units as kits or from individual parts Subracks/ 19" chassis . . . . 6 쮿 Handles in different designs for various applications 쮿 Inserter/extractor handles for forces up to 1500 N 쮿 Upgradable EMC shielding Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Standards 쮿 IEC 60297-3-101 / IEEE 1101.1/11 IEC 60297-3-102 / IEEE 1101.10 IEC 60297-3-103 IEC 1296 Power supply units . . . . . . . . . . 9 ServicePLUS e.g. individual configuration and assembly e.g. modifications (special colours or sizes) e.g. custom solutions with modification to the plug-in units Backplanes . . . 10 www.frontpanelexpress.eu 30407004 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 7.16 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Plug-in units Handles for plug-in units Overview . . . . . . 7.17 Kit Page Individual components Page For CompactPCI and VME64x applications Inserter/extractor handle, type IEL/IET, allows keying/coding and insertion/extraction forces up to 700 N per pair 7.18 7.20 Plug-in units with injector and extractor handles For CompactPCI and VME64x applications . . . . . 7.18 04602005 For VPX, VXS, CompactPCI and VME64x applications For VPX, VXS, CompactPCI and VME64x applications . . . . . 7.30 7.30 7.31 7.33 7.35 For e.g. VMEbus applications type 2 . . . . . . . . . . . . 7.33 7.40 7.42 For e.g. VMEbus applications type 1 . . . . . . . . . . . . 7.40 – 7.46 For Multibus® II applications . . . . 7.46 For plug-in units in accordance with IEC 60297 – 7.48 For plug-in units in accordance with IEC 60297 – 7.51 For plug-in units in accordance with IEC 60297 7.54 7.56 7.64 – Inserter/extractor handle, type XL, allows keying/coding and insertion/extraction forces up to 1500 N per pair 04605005 For e.g. VMEbus applications Trapeziform extractor handle, type 2 04604059 For e.g. VMEbus applications Trapeziform extractor handle, type 1 04692005 For Multibus® II applications Extractor handle, multibus type II, IEC 60297 04692011 Extractor handle in key form 1 For plug-in units in accordance with IEC 60297 . . . 7.48 04692008 Extractor handle in key form 2 For plug-in units in accordance with IEC 60297 . . . 7.51 04692010 Static handle For plug-in units in accordance with IEC 60297 . . . 7.54 04692003 Accessories for plug-in units Mechanical protection for static trapeziform handle and fixing materials kit Accessories for plug-in units . . . . . 7.62 PCB cover . . . . . . . 7.64 04692004 SCHROFF.PENTAIR.CO.UK 7.17 Plug-in units – for CompactPCI, VME64x Plug-in units with IEL inserter/extractor handle for CompactPCI/VME64x applications Kits 3U for CompactPCI, VME6 4xMain CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days 쮿 In accordance with IEEE 1101.10 and IEC 60297-3-102 쮿 Codable to IEC 60297-3-103/ IEEE 1101.10 쮿 Front panel shielded 쮿 Suitable for insertion and extraction forces up to 700 N (per pair) 쮿 Suitable for fitting microswitches Delivery comprises (kit) Item 04602073 6U Qty Description 1 3U 190 VAC, TA = 0 ... 50 °C 쮿 Customised front panel available via www.frontpanelexpress.eu 쮿 Further accessories see page 9.16 Connection Output + V1 Output + V1 Sense line + V1 Sense line 0 V1 Output 0 V1 Output 0 V1 – – – CSB Output OK – L N PE 댷 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.5 Power supplies – 19" AC/DC switch-mode PSUs maxpower 180 W, single Main Catalogue 쮿 Wide input voltage range 90 ... 254 VAC and 100 ... 360 VDC with active Power Factor Correction (PFC) 쮿 Single output voltage 쮿 Integrated active decoupling for redundancy operation 쮿 Active Current Share Bus (CSB) 쮿 Signalling: Output voltage OK 쮿 Efficiency up to 87 % Delivery comprises Qty 1 11308005 Description 19" compatible power supply height 3 U width A: 8 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) Order Information Voltage Current Power Description V A W 5 30 150 MAX 180-105 12 13 156 MAX 180-112 15 11 165 MAX 180-115 24 7 168 MAX 180-124 Front panel 8 HP, Al extrusion, front anodised, rear iridescent green chromated, shielded with fixed textile gasket, incl. assembly kit, 1 piece Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13100-150 13100-151 13100-152 13100-153 31006-677 69001-733 60800-123 Note 쮿 Please order front panel separately 쮿 Output data for mains voltage > 190 VAC, TA = 0 ... 50 °C 쮿 Customised front panels available via www.frontpanelexpress.eu 쮿 Further accessories see page 9.16 DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 9.6 Connection Output + V1 Output + V1 Sense + V1 Sense 0V V1 Output 0V V1 Output 0V V1 Output + V1 Output 0V V1 Test CSB DC output OK – L N PE 댷 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – 19" AC/DC switch-mode PSUs maxpower 100 W, dual Main Catalogue 쮿 Wide input voltage range 90 ... 254 VAC and 100 ... 360 VDC with active power-factor correction (PFC) 쮿 High power density 쮿 2 output voltages 쮿 Efficiency up to 80% C US Delivery comprises Qty 1 Description 19"-compatible power-supply unit height: 3 U width A: 8 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) 11300010 Order Information Voltage Current Power Description V A W V1: 5 I1: 9 93 MAX 2512 V2: 12 I2: 4 V1: 5 I1: 9 93 MAX 2524 V2: 24 I2: 2 V1: 12 I1: 4.2 101 MAX 212 V2: -12 I2: 4.2 V1: 15 I1: 3.4 102 MAX 215 V2: -15 I2: 3.4 Front panel 8 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13100-112 13100-114 13100-115 13100-116 21006-945 21101-705 69001-733 60800-123 Note DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 SCHROFF.PENTAIR.CO.UK Connection – – – – – – Output + V1 Output 0 V1 Output + V2 Output 0 V2 – – L N PE 댷 쮿 Please order front panel separately 쮿 Output data for mains voltage > 190 VAC, TA = 0 ... 50 °C 쮿 Customised front panels available via www.frontpanelexpress.eu 쮿 Further accessories see page 9.16 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.7 Power supplies – 19" AC/DC switch-mode PSUs maxpower 100 W, triple Main Catalogue 쮿 Wide input voltage range 90 ... 254 VAC and 100 ... 360 VDC with active power-factor correction (PFC) 쮿 High power density 쮿 3 output voltages 쮿 Signalling: Output voltage OK C US Delivery comprises Qty 1 11300011 Description 19" compatible power supply height 3 U width A: 8 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) Order Information Voltage Current Power Description V A W V1: 5 I1: 8 V2: 12 I2: 2.5 100 MAX 312 V3: -12 I3: 2.5 V1: 5 I1: 8 V2: 15 I2: 2 100 MAX 315 V3: -15 I3: 2 Front panel 8 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13100-122 13100-123 21006-945 21101-705 69001-733 60800-123 Note DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 9.8 쮿 Please order front panel separately 쮿 Output data for mains voltage > 190 VAC, TA = 0 ... 50 °C 쮿 Customised front panels available via www.frontpanelexpress.eu 쮿 Further accessories see page 9.16 Connection Output + V1 Output + V1 Sense line + V1 Sense line 0V V1 Output 0V V1,2 Output 0V V1,2 Output + V2 Output 0V V1,2 Output 0V V3 Output – V3 Output OK – L N PE 댷 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – 19" AC/DC switch-mode PSUs maxpower 130 W, triple Main Catalogue 쮿 Wide input voltage range 90 ... 254 VAC and 100 ... 360 VDC with active Power Factor Correction (PFC) 쮿 3 output voltages 쮿 Signalling: Output voltage OK C US Delivery comprises Qty 1 Description 19" compatible power supply height 3 U width A: 12 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) 11399009 Order Information Voltage Current Power Description V A W V1: 5 I1: 16 V2: 12 I2: 2.8 132 SEG 312 V3: -12 I3: 1.4 I1: 16 V1: 5 V2: 15 I2: 2.2 132 SEG 315 V3: -15 I3: 1.1 Front panel 12 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13100-078 13100-079 21006-946 21101-705 69001-733 60800-123 Note 쮿 Please order front panel separately 쮿 Output data for mains voltage > 190 VAC, TA = 0 ... 50 °C 쮿 Customised front panel available via www.frontpanelexpress.eu 쮿 Further accessories see page 9.16 DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 SCHROFF.PENTAIR.CO.UK Connection Output + V1 Output + V1 Sense + V1 Sense 0V V1 Output 0V V1,2,3 Output 0V V1,2,3 Output + V2 Output 0V V1,2,3 Output 0V V1,2,3 Output – V3 Output OK – L N PE 댷 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.9 Power supplies – 19" AC/DC linear regulators Linear regulators, single 19" AC/DC linear regulators 쮿 Mains/line voltage 230 VAC (can be switched to 115 VAC with mains/line voltage conversion kit) 쮿 High control accuracy, low residual ripple and low interference, suitable for medical applications (8 mm safety clearances) 쮿 PSM, PSG – Output voltage can be remote controlled externally (1 ... 10 V) – Switching of control curve for sensitive loads (U/I - Fold Back) – Current measurement via shunt Delivery comprises 11397001 Qty 1 Description 19" compatible power supply height 3 U width A: 6, 10, 14 HP depth 171.93 mm (160 mm deep boards) connector H 15 M (fitted) keying/coding peg (fitted) Order Information DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 9.10 PSK single Sense line + V1 Output + V Output + 0 V1 Sense line 0 V1 – – – – – – – L N PE 댷 PSM, PSG single Sense line + V1 Output + V Output +0 V1 Sense line 0 V1 Optional: redundancy diode External on/off GND V remote input + Vc V-shunt + Vs V-shunt – Vs – – L N PE 댷 SCHROFF PRODUCT CATALOG E 04/2017 Voltage Current Power Width Description V A W HP 5 1.5 8 6 PSK 105 5 4 20 10 PSM 105 5 6 30 14 PSG 105 12 1.1 13 6 PSK 112 12 2.8 31 10 PSM 112 12 4.2 50 14 PSG 112 15 1 15 6 PSK 115 15 2.2 33 10 PSM 115 15 3.5 53 14 PSG 115 24 0.6 16 6 PSK 124 24 1.5 36 10 PSM 124 24 2.5 60 14 PSG 124 Front panel for PSK 6 HP, 1 piece Front panel for PSM 10 HP, 1 piece Front panel for PSG 14 HP, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Mains voltage conversion kit 230 V to 115 V, 1 piece Part no. 13105-001 13105-006 13105-011 13105-002 13105-007 13105-012 13105-003 13105-008 13105-013 13105-004 13105-009 13105-014 21005-475 21005-473 21005-474 21101-705 69001-733 60800-123 43105-999 Note 쮿 Please order front panel separately (Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit) 쮿 PSK without case 쮿 Output data at TA = 0 ... 50 °C 쮿 Further accessories see page 9.16 ELECTRONICS PROTECTION Power supplies – 19" AC/DC linear regulators Linear regulators, dual Main Catalogue 쮿 Mains/line voltage 230 VAC (can be switched to 115 VAC with mains/line voltage conversion kit) 쮿 2 output voltages, galvanically separated 쮿 High control accuracy, low residual ripple and very low interference 쮿 Suited for medical applications (8 mm safety clearances) Delivery comprises Qty 1 Description 19" compatible power supply Height 3 U Width A: 6, 10, 14 HP Depth 171.93 mm (160 mm board depth) Connector H 15M Coding strip (fitted) 11300001 Order Information DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 SCHROFF.PENTAIR.CO.UK Connection Sense line + V1 Output + V1 Output 0 V1 Sense line 0 V1 Sense line + V2 Output + V2 Output 0 V2 Sense line 0 V2 – – – – L N PE 댷 Voltage Current Power Width Description V A W HP V1: 5 I1: 1.4 14 10 PSM 205 V2: 5 I2: 1.4 V1: 12 I1: 0.4 10 6 PSK 212 V2: 12 I2: 0.4 V1: 12 I1: 1 24 10 PSM 212 V2: 12 I2: 1 V1: 12 I1: 1.5 36 14 PSG 212 V2: 12 I2: 1.5 V1: 15 I1: 0.4 12 6 PSK 215 V2: 15 I2: 0.4 V1: 15 I1: 1 30 10 PSM 215 V2: 15 I2: 1 V1: 15 I1: 1.5 45 14 PSG 215 V2: 15 I2: 1.5 V1: 24 I1: 1.2 58 14 PSG 224 V2: 24 I2: 1.2 Front panel for PSK 6 HP, 1 piece Front panel for PSM 10 HP, 1 piece Front panel for PSG 14 HP, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Mains voltage conversion kit 230 V to 115 V, 1 piece Part no. 13105-021 13105-017 13105-022 13105-027 13105-018 13105-023 13105-028 13105-029 21005-476 21005-477 21005-478 21101-705 69001-733 60800-123 43105-999 Note 쮿 Please order front panel separately (Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit) 쮿 PSK without case 쮿 Output data at TA = 0 ... 50 °C 쮿 Further accessories see page 9.16 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.11 Power supplies – 19" AC/DC linear regulators Linear regulators, triple Main Catalogue 쮿 Mains/line voltage 230 VAC (can be switched to 115 VAC with mains/line voltage conversion kit) 쮿 3 output voltages, galvanically separated 쮿 High control accuracy, low residual ripple and very low interference 쮿 Suited for medical applications (8 mm safety clearances) Delivery comprises Qty 1 11300002 Description 19" compatible power supply height 3 U width A: 6, 10, 14 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) Order Information Voltage Current Power Width Description V A W HP V1: 5 I1: 0.5 V2: 12 I2: 0.2 8 6 PSK 312 V3: 12 I3: 0.2 I1: 1.5 V1: 5 V2: 12 I2: 0.5 20 10 PSM 312 V3: 12 I3: 0.5 V1: 5 I 1: 3 V2: 12 I 2: 1 39 14 PSG 312 V3: 12 I 3: 1 Front panel for PSK 6 HP, 1 piece Front panel for PSM 10 HP, 1 piece Front panel for PSG 14 HP, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Mains voltage conversion kit 230 V to 115 V, 1 piece DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 9.12 Connection Sense line + V1(PSM, PSG) Output + V1 Output 0 V1 Sense line 0 V1(PSM, PSG) Output + V2 Output 0 V2 Output + V3 Output 0 V3 Data save Power failure 0 V for pin 20, 22 – L N PE 댷 SCHROFF PRODUCT CATALOG E 04/2017 Part no. 13105-051 13105-052 13105-053 21005-470 21005-451 21005-439 21101-705 69001-733 60800-123 43105-999 Note 쮿 Please order front panel separately (Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit) 쮿 PSK without case 쮿 Output data at TA = 0 ... 50 °C 쮿 Further accessories see page 9.16 ELECTRONICS PROTECTION Power supplies – 19" DC/DC converters coolpower 100 W, single 19" DC/DC converters 쮿 Wide input voltage range from 20 to 72 VDC 쮿 High power density 쮿 Single output voltage, redundancy diode fitted 쮿 External ON/OFF 쮿 Galvanic separation between primary and secondary circuits 쮿 Passive current-share operation Delivery comprises Qty 1 Description 19" compatible power supply height 3 U width A: 6 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) 11301001 Order Information Voltage Current Power Description V A W 5 1) 20 100 CPDC 105 12 1) 8.5 102 CPDC 112 15 1) 6.7 100 CPDC 115 24 2) 4.5 108 CPDC 212 1) Front panel 6 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece 2) Front panel 6 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13103-002 13103-003 13103-004 13103-007 21006-955 21006-956 21101-705 69001-733 60800-123 Note DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 5, 12, 15 V Connection Output + V1 Output + V1 Sense line + V0 Sense line 0V V1 Output 0V V1 Output 0V V1 Internally engaged Output OK Ext. ON/OFF* +VE 0V VE PE 댷 SCHROFF.PENTAIR.CO.UK Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 24 V Connection Output + 24 ... 30 V via diode 쮿 Please order front panel separately 쮿 Power supply with CPDC 212, dual output voltages 24, 30 V (2 x 12 V, 2 x 15 V) 쮿 Front panel for 13103-007: 21006-956 쮿 For higher input voltages (100 ... 360 VDC) see maxpower single, page 9.4 쮿 Further accessories see page 9.16 Output 0 V Output 0 V Output 0 V Internally engaged Internally engaged Internally engaged Internally engaged +VE 0V VE PE 댷 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.13 Power supplies – 19" DC/DC converters coolpower 100 W, dual Main Catalogue 쮿 Wide input voltage range from 20 to 72 VDC 쮿 High power density 쮿 2 output voltages (or single output voltage 24 – 30 V via internal redundancy diode V1D) 쮿 Galvanic separation between primary and secondary circuit Delivery comprises Qty 1 11302003 Description 19" compatible power supply height 3 U width A: 6 HP depth 171.93 mm (160 mm board depth) connector H 15 M coding strip (fitted) Order Information Voltage Current Power Description min. ... max. V A W V1: 12 ... 15 I1: 4.5 108 CPDC 212 V2: -12 ...-15 I2: 4.5 Front panel 6 HP, Al, front anodised, rear iridescent green chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13103-007 21006-956 21101-705 69001-733 60800-123 Note 11302053 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 9.14 쮿 Please order front panel separately 쮿 1 output voltage via output pins V1D 24 V ... 30 V, I1D 4.5 A, 108 W 쮿 Output data at TA = 50 °C 쮿 Adjustment range 12 V ... 15 V 쮿 For higher input voltages (100 ... 360 VDC), see maxpower single, page 9.7 쮿 Further accessories see page 9.16 Connection Output + V1D Output + V1D Output + V1D Output – V2 Output – V2 Output – V2 Output + V1 Output V1/V2 0 V Output V1/V2 0 V Output – V2 – – Input +Vi Input 0 V PE 댷 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – 19" DC/DC converters coolpower 100 W, triple Main Catalogue 쮿 Wide input voltage range from 20 to 72 VDC 쮿 High power density 쮿 3 output voltages, galvanically separated 쮿 Galvanic separation between primary and secondary circuit 쮿 External ON/OFF Delivery comprises Qty 1 Description 19" compatible power supply height 3 U width A: 6 HP depth 171.93 mm (160 mm deep boards) connector H15M (fitted) keying/coding peg (fitted) 11302004 Order Information Voltage Current Power Description min. ... max. V A W V1: 5 I1: 10 V2: 12 ...15 I 2: 2 98 CPDC 312 V3: 12 ...15 I 3: 2 Front panel 6 HP, Al, front anodised, rear colourless chromated, with vertical grooves for EMC gaskets, incl. assembly kit, 1 piece EMC gaskets (stainless steel) 3 U, 97 mm, stainless steel, two pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13103-016 21006-957 21101-705 69001-733 60800-123 Note DIJM0084 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 SCHROFF.PENTAIR.CO.UK Connection Output + V Output + V1 Sense line + V2 Sense line V1 0 V Output V1 0 V Output V1 0 V Output + V2 Output V2 0 V Output + V3 Output V3 0 V – External ON/OFF Input +Vi Input 0 V PE 댷 Please order front panel separately Output data at TA = 50 °C Adjustment range V2, V3 12 ... 15 V Input voltage 100 ... 360 VDC, see maxpower triple, page 9.8 쮿 Further accessories see page 9.16 쮿 쮿 쮿 쮿 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.15 Power supplies – Accessories Accessories 쮿 For slimpower, maxpower, coolpower and linear regulators 쮿 Z-rail (item 6) 쮿 Mating connector female H 15 F (item 1) 쮿 Coding (item 2) 쮿 Wall/horizontal rail mounting PSA45379 Z-rail, 4 HP Accessories 쮿 For bolting a H15 F connector to the rear horizontal rail/case (item 6) 쮿 Provides the standard plug-in depth of the PSUs Order Information Description Z-rail, 4 HP (20.32 mm) Qty/PU 1 Part no. 30822-166 Note 쮿 Two Z-rails are required per connector A3-420 Connector H 15 F Main Catalogue 쮿 Connector EN 60603 (DIN 41612) H15 F for 6.3 mm FASTON 쮿 In 19" power supply units the H 15 male connector is fitted, PIN 32 with capacitive earthing contact 쮿 Compatible with connector H15 M of e.g. 19" plug-in equipment Order Information Item 1 Description Type H Qty/PU 1 Part no. 69001-733 05592018 9.16 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – Accessories Keying/coding Access ori es 쮿 Mechanical coding prevents a PSU being fitted on the wrong slot, space requirement 4 HP 쮿 Coding: – Female strip (item 2), fitted on PSU (except slimpower) – Coding strip (item 1) mounts on the Z/horizontal rail – Placement of coding pins (item 3) in the coding strip (item 1) – Removal of studs at the appropriate place in the female strip 쮿 With 2 coding pins there are 66 coding possibilities 1 Order Information 3 Description Keying/coding strip, Crastin (UL 94 V-0) 1 piece, keying/coding pins, Crastin (UL 94 V-0), 2 pieces Part no. 60800-123 1 2 2 A4-2424 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.17 Power supplies – Accessories Wall/horizontal rail mounting Accessories 쮿 Suitable for 19"-compatible 3 U PSUs 쮿 2 mounting options – Wall mounting bracket can be fitted in any position with screws and PSU is inserted – Horizontal rail adaptor is bolted to wall mounting bracket, then the 19" PSU can be clipped to a horizontal rail Order Information Item Description 1 Wall mounting bracket, St 2 Horizontal rail adaptor bracket, Al Connector H 15 F FASTON connection, 1 piece Qty/PU 1 1 Part no. 11000-001 11000-002 69001-733 11395007 2 1 9.18 SCHROFF PRODUCT CATALOG E 04/2017 PSA45389 ELECTRONICS PROTECTION Power supplies – MicroTCA AC/DC, double full-size, with power management (EMMC) Mi croTCA MAIN CATALOGPart number in bold face type: ready for s hippi ng within 2 working daysPart number in normal type: ready for shipping within 10 working days 쮿 Mains input at front with wide input voltage range for AC voltages with IEC locking system 쮿 Construction compatible with AdvancedMC double full-size 쮿 Supports N+1 and 2+2 redundancy, load sharing and hot swap 쮿 Power management for 16 current channel (12 AMC, 2 CU and 2 MCHs) 쮿 High efficiency 쮿 Visual performance display The MTCA PSU 600 is an exceptionally efficient power module (PM) for MicroTCA® applications. This 600W power supply is the most efficient available in double-width full-size format. This PM's integrated management controller makes it ideally suited for use in complex communications systems running the latest generations of processors and an increased number of AMC modules. The MTCA PSU 600 provides the power required for 12 AMCs, 2 Cooling Units (CUs) and 2 MicroTCA® Carrier Hubs (MCHs). 11316001 Delivery includes Qty. 1 Description PSU for MicroTCA Double height (148.3 mm) Full-size width (6 HP) Depth 186.65 mm Connector MicroTCA Power Front panel with handle and EMC gasket (fitted) Order Information Voltage V V1: 12 V2: 3.3 SCHROFF.PENTAIR.CO.UK Current A I1: 6.8 I2: 0.18 Power W Description 600 MTCA PSU 600 Part no. 11098-547 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.19 Power supplies – for MicroTCA AC/DC, double full-size, without management for MicroTCAMain CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number i n normal type: ready for despatch within 1 0 working days 쮿 Wide input voltage range 90 ... 264 VAC 쮿 Active power factor correction 쮿 Construction compatible with AdvancedMC double full-size 쮿 Single-wire current share cable for redundancy operation 쮿 2 output voltages, 12 V and 3.3 V 쮿 Corresponds to EMC class B as per EN 55022 쮿 Without MicroTCA power management controller 쮿 Mains input at front Delivery comprises Qty 1 11309004 L G N 170 143,5 143,5 Order Information Voltage V V1: 12 V2: 3.3 V1: 12 V2: 3.3 181,8 LED 1,2 Description PSU for MicroTCA height double (148.3 mm) width full-size (6 HP) depth 186.65 mm connector Molex SSI front panel with handle and EMC gasket (fitted) Current A I1: 25 I2: 3 I1: 45.8 I2: 3 Power W Description Part no. 300 MCA 300 AC 11098-392 550 MCA 550 AC 11098-416 Note 쮿 Output data for TA = -25 ... 55 °C with forced cooling of 20 cfm 쮿 Connector FCI 51720-10202402AA or Molex 87631-2019 28,2 31 11312050 9.20 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – for VMEbus AC/DC, 19", 6 U, triple for VMEbusMain Catalogue 쮿 Wide input voltage range 90 ... 264 VAC and 130 ... 350 VDC with active power factor correction (PFC) 쮿 3 output voltages 쮿 VMEbus signalling C US Delivery comprises Qty 1 Description 19" compatible power supply height 6 U width A: 8, 12 HP depth 171.93 mm (160 mm board depth) front panel with handles (fitted) connector H 15 M (2 pieces) coding strip (2 pieces, fitted) Order Information 11301002 Voltage Current Power Width Description V A W HP V1: 5 I1: 20 V2: 12 I 2: 4 150 (60) 8 MPS 015 V3: -12 I 3: 3 V1: 5 I1: 28 V2: 12 I 2: 7 224 (84) 12 MPS 022 V3: -12 I 3: 3 V1: 5 I1: 28 V2: 15 I2: 5.6 224 (84) 12 MPS 022/15 V3: -15 I3: 2.4 EMC gaskets (stainless steel) 6 U, 232 mm, stainless steel, 2 pieces necessary per front panel, PU 10 pieces Connector H 15 F Mating connector (female) for wiring inputs/outputs (6.3 mm FASTON), 1 piece Coding PU (1 keying/coding strip, 2 pieces keying/coding pins) Part no. 13100-205 13100-203 13100-204 21101-707 69001-733 60800-123 Note 쮿 Output data at TA = 0 ... 40 °C 쮿 Values in brackets: Output power V2 + V3 쮿 Further accessories see page 9.16 PSA44726 Connector pin-out Pin 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 Connection x1 (at top) Output + V1 Output + V1 Output + V1 Output + V1 Output + V1 Sense line + V1 Output - V3 Output 0 V1,2,3 Output 0 V1,2,3 Output 0 V1,2,3 Output 0 V1,2,3 Output 0 V1,2,3 Output + V2 Output + V2 Sense line 0 V1 SCHROFF.PENTAIR.CO.UK Connection x2 (at bottom) ACFAIL SYSRESET – Current Share Bus Shutdown 4 ... 28 V GND Shutdown – – – – – – L N PE y Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 9.21 Power supplies – for VMEbus AC/DC, open frame, triple Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 For VME applications 쮿 Wide input voltage range 85 ... 264 VAC 쮿 3 output voltages 쮿 High performance 쮿 Output power 444 ... 800 W C US Delivery comprises Qty 1 11405002 Photo shows MP6 PSUs 4,3 S L O T S L O T S L O T S L O T 5 4 3 2 1 49,2 S L O T 23,9 63,5 19 127 38,1 171,5 17,3 63,5 * M 4 (4x) 19,1 d Order Information Voltage Current Power Description V A W V1: 5 I1: 60 V2: 12 1) I2: 10 444 2) MP4 2E-4LL-00 I 3: 4 V3: 12 V1: 5 I1: 60 V2: 12 I2: 17 MP6 2E-1L-1L-00 708 3) V3: 12 I3: 17 V1: 5 I1: 120 V2: 12 1) I2: 10 744 3) MP6 3E-4LL-00 I 3: 4 V3: 12 I1: 120 V1: 5 V2: 12 1) I2: 17 MP6 3E-1L-1L-00 800 3) I3: 17 V3: 12 Accessories Set of connectors with all input/output connectors, PU 1 kit d mm Part no. 254.0 11098-267 279.4 11098-266 279.4 11098-140 279.4 11098-231 21009-038 1) 10 % base load necessary, sum of 12 V outputs max. 144 W 2) Output max. 400 W at 85 VAC ... 180 VAC 3) Output max. 600 W at 85 VAC ... 180 VAC 3,7 171,5 Description Open frame PSU 19,1 127 101,6 Note M 4 (4x) # 8 - 32 (4x) 171,5 * Assembly holes identical on both sides 9.22 SCHROFF PRODUCT CATALOG E 04/2017 쮿 쮿 쮿 쮿 쮿 Output data at -20 °C ... +50 °C Input: AC 85 ... 264 V (47 ... 440 Hz), DC 120 ... 350 V Output voltages adjustable, w10 % Signalling: Input ok, DC output ok Other output voltages available on request 29,1 11412050 ELECTRONICS PROTECTION Power supplies – for CompactPCI Serial 19" switched-mode power supply for CompactPCI Serial for C ompactPC I SerialMain CatalogPart num ber in bold face type: ready for shipping within 2 working daysPart number in norm al type: ready for shipping within 10 working days 쮿 19" pluggable PSU for CompactPCI Serial applications 쮿 Very wide input voltage range for both AC and DC 쮿 Active power factor correction and active current-share function 쮿 N+1 redundancy, hot swap 쮿 Output signaling: PS present, power failure, PO ON and enable 쮿 I2C interface 쮿 Temperature monitoring 쮿 Sense line 쮿 UL, cUL and DEMKO certificates, CE-compliant 11315001 Pro du Bau ktio ar n üb t ge er pr wac üf t ht US d re ito on m ed n io test ct du Type Pro TUV C SUD Delivery includes Qty 1 Description 19"-compatible PSU Height 3 U Width 8 HP 160 mm board depth PwrBlade connector (fitted) Front panel with handle and EMC contact strip (fitted) Order Information Voltage Current Power Input voltage V A W V1: 12 I1: 25 300 AC: 90 ... 264 V V2: 5 I2: 2.5 Accessories CompactPCI Serial power backplane, 3 U, 8 HP, 1 slot 1 piece SCHROFF.PENTAIR.CO.UK Part no. 11098-538 23098-397 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.23 Power supplies – for CompactPCI and VME64x AC/DC, 19", 3 U, quad for CompactPCI and VME64 xMain Catalogue 쮿 Wide input voltage range 90 ... 264 VAC with power factor correction (PFC) 쮿 4 output voltages 쮿 Connector P 47 쮿 Redundant operation with Current Share Bus (CSB), hot-swap 쮿 CompactPCI signalling Pro du Bau ktio ar n üb t ge er pr wac üf t ht US d re ito on m ed n io test ct du Type Pro TUV C SUD Delivery comprises Qty 1 11302005 Description 19" compatible power supply height 3 U width A 8 HP depth 171.93 mm (160 mm board depth) connector P 47 front panel with handles and EMC gasket fitted Order Information Voltage Current Power Description V A W V1: 5 I1: 40 V2: 3.3 I2: 40 250 CPCI 250 AC V3: 12 I3: 5.5 V4: -12 I4: 2 Power backplane with P47 connector 3 U, width 39.6 mm, 1 × connector position P47, 1 piece Power backplane with P47 connector 3 U, width 80.3 mm, 2 x connector positions P47 (side-by-side), 1 piece Power backplane with P47 connector 6 U, width 39.6 mm, 1 × connector position P47, top, 1 piece Power backplane with P47 connector 6 U, width 39.6 mm, 2 × connector position P47, one above the other, 1 piece Guide rail with keying/coding, groove width 2.0 mm, with 0.1" offset Standard pack quantity 50 pieces Part no. 13100-141 23098-105 23098-115 23098-116 23098-117 64560-071 Note 쮿 Output data at TA = 0 ... 50 °C with forced air cooling of 2 m/s 쮿 47-pin CompactPCI connector to PICMG 2.11 specification 11302052 9.24 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – for CompactPCI and VME64x AC/DC, 19", 6 U, quad Main Catalogue 쮿 Wide input voltage range 90 ... 264 VAC with power factor correction (PFC) 쮿 4 output voltages 쮿 Connector P 47 쮿 Redundant operation with Current Share Bus (CSB), hot-swap 쮿 CompactPCI signalling C US Delivery comprises Qty 1 11308007 Order Information Voltage Current Power Description V A W V1: 5 I1: 50 V2: 3.3 I2: 60 500 CPCI 500 AC V3: 12 I3: 12 V4: -12 I4: 4 Power backplane with P47 connector 6 U, width 39.6 mm, 1 × connector position P47, top, 1 piece Guide rail with keying/coding, groove width 2.0 mm, with 0.1" offset , Standard pack quantity 50 pieces 233,35 261,75 A Description 19" compatible power supply height 6 U width A: 8 HP depth 171.93 mm (160 mm board depth) connector P 47 front panel with handles and textile EMC gasket fitted Part no. 13100-145 23098-116 64560-071 Note 쮿 Output data at TA = -25 ... 55 °C with forced air cooling of 1.5 m/s 쮿 47-pin CompactPCI connector to PICMG 2.11 specification 233,5 x 160 mm 2,5 171,93 11302051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 9.25 Power supplies – for CompactPCI and VME64x AC/DC, open frame, 300 W, quad for CompactPCI and VME64 x 쮿 For CompactPCI and VME64x applications 쮿 Wide input voltage range 85 ... 264 VAC 쮿 4 output voltages 쮿 High performance, efficiency typically 85 % 쮿 Output power 300 W 쮿 Signalling: Output voltage OK C US Delivery comprises Qty 1 11408002 A Description Open frame power supply, dimensions 36 x 99 x 173 mm; weight 850 g Order Information Voltage 159,1 6-32UNC 2B 18 28,8 35,6 A Voltage Current Power Description min. ... max. V V A W V1: 5 4.75 ... 5.25 I1: 40 V2: 3.3 3.14 ...3.46 I2: 40 300 EF306-433 – V3: 12 I3: 4 – V4: 12 I4: 1.5 Set of connectors with all input and output plugs, PU 1 kit Part no. 11098-316 21009-039 쮿 쮿 쮿 쮿 쮿 63,5 98,0 Note Output data at -5 °C ... 50 °C Output voltages 5 V and 3.3 V adjustable, w 10 % Forced cooling at 2 m/s (230 lfm) required With remote-control function Ext. ON/OFF With auxiliary supply 5 V/ 5 mA 6-32UNC 2B 162,6 172,7 13 11408050 9.26 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – for CompactPCI and VME64x AC/DC, open frame, 600 W, quad for C ompactPC I and VME64 xMain CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For CompactPCI and VME64x applications 쮿 Wide input voltage range 85 ... 264 VAC 쮿 4 output voltages 쮿 High performance C US Delivery comprises Qty 1 Description Open frame PSU Order Information 11405001 Photo shows 11098-212 4,3 S L O T S L O T S L O T S L O T 5 4 3 2 1 49,2 S L O T 23,9 63,5 19 127 38,1 63,5 * M 4 (4x) Voltage Current Power Description d V A W mm V1: 5 I1: 60 V2: 3.3 I2: 35 560 2) MP4 2E-1D-4LL-00 254.0 V3: 12 I3: 10 V4: 12 I4: 4 I1: 60 V1: 5 V2: 3.3 I2: 60 642 3) MP6 2D-2E-4LL-00 279.4 V3: 12 I3: 10 V4: 12 I4: 4 Accessories Set of connectors with all input and output plugs, PU 1 kit Part no. 11098-212 11098-207 21009-039 1) 10 % base load necessary, sum of 12 V outputs max. 144 W 2) Output max. 400 W at 85 VAC ... 180 VAC 3) Output max. 600 W at 85 VAC ... 180 VAC Note 171,5 d 3,7 19,1 101,6 171,5 Output data at -20 °C ... 50 °C Input: AC 85 ... 264 V (47 ... 440 Hz), DC 120 ... 350 V Output voltages adjustable, w10 % Signalling: Input ok, DC output ok Other output voltages available on request 127 17,3 쮿 쮿 쮿 쮿 쮿 19,1 M 4 (4x) # 8 - 32 (4x) 171,5 * Assembly holes identical on both sides SCHROFF.PENTAIR.CO.UK 29,1 11412050 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 9.27 Power supplies – for CompactPCI and VME64x DC/DC, 19", 3 U, quad for CompactPCI and VME64 xMain Catalogue 쮿 Input voltage 48 VDC (36 ... 75 VDC) 쮿 4 output voltages 쮿 Connector P 47 쮿 Redundant outputs with Current Share Bus (CSB), hot-swap 쮿 CompactPCI signalling Pro du Bau ktio ar n üb t ge er pr wac üf t ht US d re ito on m ed n io test ct du Type Pro TUV C SUD Delivery comprises Qty 1 11302005 Description 19" compatible power supply height 3 U width A: 8 HP depth 171.93 mm (160 mm board depth) connector P 47 front panel with handle and EMC contact strips (fitted) Order Information Voltage Current Power Description V A W V1: 5 I1: 40 V2: 3.3 I2: 40 250 CPCI 250 DC V3: 12 I3: 5.5 V4: -12 I4: 2 Power backplane with P47 connector 3 U, width 39.6 mm, 1 × connector position P47, 1 piece Power backplane with P47 connector 3 U, width 80.3 mm, 2 x connector positions P47 (side-by-side), 1 piece Power backplane with P47 connector 6 U, width 39.6 mm, 1 × connector position P47, top, 1 piece Power backplane with P47 connector 6 U, width 39.6 mm, 2 × connector position P47, one above the other, 1 piece Guide rail with keying/coding, groove width 2.0 mm, with 0.1" offset Standard pack quantity 50 pieces Part no. 13100-142 23098-105 23098-115 23098-116 23098-117 64560-071 Note 쮿 Output data at TA = 0 ... 50 °C, with forced air cooling of 2 m/s 쮿 47-pin CompactPCI connector to PICMG 2.11 specification 11302052 9.28 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – for CompactPCI and VME64x DC/DC, 19", 6 U, quad Main Catalogue 쮿 Input voltage range 48 VDC (36 ... 72 VDC) 쮿 4 output voltages 쮿 Connector P 47 쮿 Redundant outputs with Current Share Bus (CSB), hot-swap 쮿 Compact PCI signalling C US Delivery comprises Qty 1 Description 19" compatible power supply height 3 U width A: 8 HP depth 171.93 mm (160 mm deep boards) connector P 47 (fitted) front panel with handles and EMC contact strip (fitted) Order Information 11303002 Part no. 13100-146 23098-116 64560-071 Note 233,35 261,75 A Voltage Current Power Description V A W V1: 5 I1: 50 V2: 3.3 I2: 60 500 CPCI DC-6U-500 V3: 12 I3: 12 V4: -12 I4: 4 Power backplane with P47 connector 6 U, width 39.6 mm, 1 × connector position P47, top, 1 piece Guide rail with keying/coding, groove width 2.0 mm, with 0.1" offset Standard pack quantity 50 pieces 쮿 Output data at TA = -10 ... 55 °C with forced air cooling of 2 m/s 쮿 47-pin CompactPCI connector to PICMG 2.11 specification 233,5 x 160 mm 2,5 171,93 11302051 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 9.29 Power supplies – ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configurations, based on our standard range of AC/DC or DC/DC converters – Number of output voltages – Heights, widths, depths 쮿 Online configuration enquiries: www.schroff.co.uk/configuration assembly Assembled by professionals. Double benefit! Front panel and handle mounting 쮿 Front panel mounting modification Small changes. Large impact. Modification of off-the-shelf products 쮿 Minor modifications, e.g. other set output voltages, protective finishes solution Simple. Fast. From one source. Integration and custom developments 쮿 Development and design to customer specification; manufacture of prototypes, pre-production and production series, certification academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Training, test reports, user reports, certificates, user manuals for download lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Repair, fast and straightforward, via online RMA form ServicePLUS 9.30 SCHROFF PRODUCT CATALOG E 04/2017 ELECTRONICS PROTECTION Power supplies – ServicePLUS Application examples and special devices created to customer specifications Text 11308002 11309004 Application: Redundant and uninterruptible 19" DC power supply units Application: AC/DC switch-mode power supply for telecommunications applications Application: DC/DC converter for railway applications SCHROFF.PENTAIR.CO.UK 11309003 11309005 11309002 Application: AC/DC switch-mode PSU for power supply to video monitoring systems 11309001 Application: AC/DC linear regulator for communications systems (defence systems) Application: DC/DC converter for supply power to fans (with monitoring) Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11309005 9.31 Main C atalogue Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in norm al type: ready for despatch within 10 working days Backplanes Content Cabinets . . . . . . 1 CompactPCI Serial Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 CompactPCI PlusIO Climate control . 4 CompactPCI backplanes and bridges Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 CompactPCI, PSB and H.110 backplanes Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 PXI backplanes Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 VPX backplanes Appendix . . . . . 12 36106009 (10506003 10506002 10502001 10508008 10.0 SCHROFF PRODUCT CATALOG E 12/2017 12406002 12406001 12406004 12402004) ELECTRONICS PROTECTION Main CatalogueP art number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 1 0 working days Backplanes Overview . . . . . . 10.0 Backplanes . . . . . . 10.2 CompactPCI VXS backplanes Serial . . . . . . . . . . . . 10.4 Plus I/O . . . . . . . . . 10.6 System slot right . 10.7 System slot left . . 10.8 Packet switching, H.110 backplanes . . . . . . 10.9 Bridge . . . . . . . . . . . 10.10 Secondary, system slot right . 10.11 PXI VME64x backplanes Backplanes . . . . . . 10.12 VPX . . . . . . . . . . . . 10.13 VXS . . . . . . . . . . . . 10.16 VME backplanes VME64 extension . . . . . . 10.15 VMEbus Monolithic J1/J2 . 10.17 J1 (3 U) . . . . . . . . . . 10.18 J2 (3 U) . . . . . . . . . . 10.19 Power backplanes With P47 connector . . . . . . . 10.20 Power Piggyback 10.20 Universal backplanes Backplane with/ without throughconnected signal lines . . . . . . . . . . . . . 10.21 Power and universal backplanes Test adaptors Types B, C, D, E, F, H, M . . . . . . . . . . . . . 10.22 For VMEbus . . . . . . 10.26 Board guides . . . . 10.28 Type/board versions . . . . . . . . 10.29 Dimensions test adaptors. . . . . 10.29 Test adaptors Assembly material . . . . . . . . . 10.30 ServicePLUS . . . 10.31 36106010 (12402005 12606003 12406003 12606005 12096003 11902001 11192004 11100013 11100010) SCHROFF.PENTAIR.CO.UK 10.1 Backplanes Our competence in overview Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days Comprehensive standard backplane programme AdvancedTCA - MicroTCA - CompactPCI - VME - Schroff offers you an extensive standard backplane programme that is already ideally matched to your requirements. Should you still not find your backplane in our range, we can develop or modify to create your tailor-made backplane, quickly and on attractive terms. All our developing and manufacturing is done in-house and competent personnel are available at any time to deal with technical questions, quotes and project support. Custom backplane Custom development to customer requirements From minor modifications to our standard backplanes through to specific form factors and connection topologies, Schroff has the right solution for you One contact partner as customer interface Project management Competent personnel are available at any time for technical questions, quotes, project support and after-sales care. If you wish, we are also happy to help you generate the specification for your custom backplane. Contact at an early stage between our technical staff and our customers helps us to develop cost-optimised projects that meet all our customers' requirements. Many years of experience 50 years of experience, continual fundamental research and innovation in the backplane sector. Active participation in standards committees and in the specification of new system architectures and high-speed transmission technologies. Development Modern design tools Modern simulation tools and measurement equipment plus inhouse developed high-performance test adaptors. Development of new technologies and topologies using high-speed measurements performed in-house. Layout Test laboratory 10.2 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes Our competence in overview Main Catalogue Modern machine facilities in Straubenhardt Solder paste printing is one of the quality-defining process steps in backplane manufacture. This solder-paste printer, based on innovative inkjet technology, allows fast, flexible and highly dependable solder paste printing. Since the process dispenses with the ’stencils’ required by other methods, the printing program can be changed in a very short time. This means that small batches can also be printed cost-effectively. Solder paste printing Our modern SMD placement machines support a wide spectrum of components with a high placement performance. Small and large production runs can be implemented flexibly and time-efficiently. Vapour-phase soldering, also known as vapour-phase reflow, is currently the most universal and most reliable soldering process. It is ideally suited to all types of SMD component and carrier material. The homogenous temperature distribution of the carrier medium allows the widest variety of sub-assemblies, from Flexprints to multilayer boards, to be soldered reliably without danger of overheating. Automatic optical inspection (AOI) There is also the option of processing conventional components with our wave-soldering system. Automatic optical inspection (AOI) is an optical test procedure for sub-assemblies equipped with components. Highly-developed image processing systems reliably detect faulty soldered joints and wrongly placed or missing components. Connector mounting Connectors are pressed into the backplane fully automatically. The press-in technique allows quick and economic mounting of the connector without subjecting the PCB to thermal stress. The press-in action creates a gas-tight, dependably electrically conductive and mechanically strong connection. Intelligent force/ displacement measuring during the press-in action ensures consistent high quality. Backplanes that are subject to particular climatic stresses can be coated with a protective lacquer (conformal coating). This coating protects the backplane from e.g. corrosion and mould. The fluorescent characteristic of the protective coating enables the coating to be checked for completeness or damage under UV light. Conformal coating No backplane leaves our production facility without 100% testing. All backplanes are subjected to extensive electrical testing before despatch. An automatic process checks the entire backplane for continuity and short circuits. This testing also covers passive and simple active components such as resistors, capacitors and diodes and the description and testing of I2C EEPROMS or bus terminations. For this Schroff has a comprehensive automated and semi-automated testing facility. Electrical final test SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 10.3 Backplanes – CompactPCI Serial CompactPCI Serial backplanes Com pac tP CI SerialMain CatalogP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days 쮿 Conforms to PICMG CompactPCI Serial (CPCI-S.0 R2.0) specification 쮿 1 system slot and 0 ... 8 peripheral slots 쮿 Supports PCIe (Gen3), USB 2.0 and USB 3.0, S-ATA (II & Rev. 3.0) and Ethernet (10GBase-T) 쮿 PCIe: Up to two 8 x lanes and up to six 4 x lanes 쮿 Powerbugs for +12 V payload voltage and Minifit plug for +5 V standby voltage 쮿 Utility connector on rear of backplane 쮿 Mechanical centering and keying/coding strip in stainless steel on every fully equipped front and rear slot 쮿 PICMG 2.9 IPMB plug can be fitted on request Delivery includes Item 1 2 Qty 1 1 Description Backplane Screw kit, M4 x 6, with lock washer; for connecting power to powerbugs 12415020 Order Information Height U 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 10.4 Number System Topology of slots slot GbE 1 – – 1 – – 1 – Rear I/O on RP6 1 – Rear I/O on RP6 2 Left Full mesh 2 Left Full mesh 3 Left Full mesh 3 Left Full mesh 3 Right Full mesh 3 Right Full mesh 4 Left Full mesh 4 Left Full mesh 4 Right Full mesh 4 Right Full mesh 5 Left Full mesh 5 Left Full mesh 5 Right Full mesh 5 Right Full mesh 5 Right Full mesh 5 Right Full mesh 6 Right Single star 6 Right Single star 7 Left Single star 7 Left Single star 7 Right Single star 7 Right Single star 8 Left Single star 8 Left Single star 9 Left Single star 9 Left Single star 9 Right Single star 9 Right Single star 9 Left Full mesh 9 Left Full mesh I/O at rear Yes No Yes No Yes No No Yes Yes No Yes No No Yes Yes No Yes No Yes No No Yes No Yes No Yes No Yes Yes No Yes No Yes No SCHROFF PRODUCT CATALOG E 12/2017 Width mm 19.3 19.3 19.3 19.3 39.6 39.6 60.0 60.0 60.0 60.0 80.3 80.3 80.3 80.3 100.6 100.6 100.6 100.6 159.9 159.9 120.9 120.9 141.2 141.2 141.2 141.2 161.6 161.6 181.9 181.9 181.9 181.9 181.9 191.9 Description J1 plug for power, J2...J5, RP2...RP5 for rear I/O J1 plug for power J1 plug for power, J2...J6, RP2...RP6 for rear I/O J1 plug for power, J6, RP6 for rear I/O For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications For Ethernet single star and full-mesh applications Additional slot for one CompactPCI Serial PSU (3 U, 8 HP) Additional slot for one CompactPCI Serial PSU (3 U, 8 HP) For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications For Ethernet single-star applications Part no. 23007-661 23007-621 23007-681 23007-641 23007-682 23007-642 23007-643 23007-683 23007-693 23007-653 23007-684 23007-644 23007-654 23007-694 23007-685 23007-645 23007-695 23007-655 23007-615 23007-605 23007-636 23007-676 23007-627 23007-667 23007-637 23007-677 23007-628 23007-668 23007-669 23007-629 23007-679 23007-639 23007-689 23007-649 ELECTRONICS PROTECTION Backplanes – CompactPCI Serial CompactPCI Serial power backplane Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Power backplane for pluggable PSUs with FCI Power Blade plug 쮿 3 U, 8 HP, 1 PSU connector 쮿 Separate inputs for AC and DC with Fastons 쮿 Connector for 12 V, 5 V standby, utility signals, current sharing, power button, serial console to a UPS and digital I/O at the rear 쮿 Optionally, the PICMG 2.9 SMBus plug and additional powerbugs for 12 V and 5 V standby can be fitted 쮿 Geographical address can be set by means of a DIP switch Delivery includes Item 1 12415019 Qty 1 Description CompactPCI Serial power backplane Order Information Height U 3 Number of slots 1 Width mm 38.9 Part no. 23098-397 12415021 Application: Power backplane (left), CompactPCI Serial backplane (right) and connection via power adapter board (below) Accessories for CompactPCI backplanes Main CatalogPart num ber in bold face type: ready for shipping within 2 working days Part number in norm al type: ready for shi pping within 1 0 working days 쮿 Cable sets for connecting power and status signals of CompactPCI Serial backplanes and power backplanes 쮿 Power adapter boards for simple connection of 12 V main supply voltage between CompactPCI Serial backplanes and power backplanes Order Information Accessories Utility cable, single conductors, 600 mm, 1 x 10-pin Micro-Match 1 piece Utility flat ribbon cable, 650 mm, 4 x 10-pin Micro-Match 1 piece Standby cable, single conductors, 600 mm, 1 x 4-pin Microfit to 2 x ring cable eye 1 piece Standby cable, single conductors, 400 mm, 3 x 4-pin Microfit 1 piece Current-sharing flat ribbon cable, 150 mm, 2 x 4-pin Micro-Match 1 piece Power connection cable, for 1-slot backplane, single conductors, 600 mm, 1 x 6-pin Microfit to 2 x ring cable eye and 1 x 4-pin Microfit 1 piece Power connection cable, backplane to backplane, single conductors, 300 mm, 2 x ring cable eye to 2 x ring cable eye 1 piece AC input cable, single conductors, 500 mm, 3 x blade receptacles, open end 1 piece DC input cable, single conductors, 500 mm, 3 x blade receptacles, open end 1 piece CompactPCI Serial power backplane, 3 U, 8 HP, 1 slot 1 piece Power adapter board, 3 x V1, 3 x V2, 121212 1 piece Power adapter board, 2 x V1, 2 x V2, 1212 1 piece Power adapter board, 3 x V1, 3 x V2, 122121 1 piece Power adapter board, 2 x V1, 2 x V2, 1221 1 piece SCHROFF.PENTAIR.CO.UK 23204-852 23204-875 23204-853 23204-866 23204-867 23204-869 23204-879 23204-880 23204-881 23098-397 23098-399 23098-400 23098-401 23098-402 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.5 Backplanes – CompactPCI CompactPCI PlusIO Com pac tP CIMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days 쮿 In accordance with: – PICMG 2.0 R3.0 CompactPCI Core Specification – PICMG 2.1 R2.0 Hot-Swap Specification – PICMG 2.9 R1.0 System Management Bus Specification – PICMG 2.10 R1.0 Keying Specification – PICMG 2.30 R1.0 CompactPCI PlusIO specification – PICMG CompactPCI Serial (CPCI-S.0 R1.0) specification 쮿 System slot in accordance with PICMG 2.30, 32-bit CPCI bus on P1, PCIe, S-ATA, USB & Ethernet on P2 쮿 CompactPCI peripheral slots, 32 bit with rear I/O on P2 쮿 CompactPCI Serial peripheral slots with PCIe x1, S-ATA and USB 쮿 Full-mesh Ethernet on system slot and 2 CompactPCI Serial slots, supports 1000Base-T and 10GBase-T 12411009 Photo shows 23007-601 쮿 Rear I/O on the CompactPCI Serial slots available on request 쮿 V(I/O) can be set to 3.3 V or 5 V (preset to 5 V) Delivery comprises Item 1 2 Qty 1 1 Description Backplane Set of screws, M4x6, with lock washer; to attach the power connection cable to the power bugs Order Information Number of slots Width mm 102.2 161.3 Height U 3 3 3 CPCI + 2 CPCI Serial 4 CPCI + 4 CPCI Serial Accessories SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Kit to convert V I/O to 3.3 V 8 coding tabs, yellow, coding key, PU 1 kit Utility cable MicroMatch with single conductors, length 600 mm, 1 piece Utility cable MicroMatch with flat ribbon cable, length 600 mm, 1 piece Screws, washers for backplane mounting 23204-113 21101-658 23204-812 23204-811 Page 10.30 6-J6 1-P2 1-P1 2-P2 3-P1 23007-601 1000BaseT PCIe, SATA, USB2.0 2-P1 New P2 pinout 3-P2 4-P2 (PICMG 2.30 CPCI PlusIO) 5-J6 4-P1 23007-602 12409053 Topology shows 23007-601 Legacy CPCI 32-bit P2 Rear I/O connector Part no. Rear I/O optional at all CPCI Serial Slots 5-J1 Legacy CPCI 32-bit P1 connector 6-J1 7-J1 8-J1 CPCI Serial base connector 1 2 3 4 PERIPHERAL PERIPHERAL PERIPHERAL SYSTEM CPCI CPCI PlusIO PICMG 2.30 5 6 7 CPCI Serial Front view 10.6 8 SCHROFF PRODUCT CATALOG E 12/2017 12409051 ELECTRONICS PROTECTION Backplanes – CompactPCI CompactPCI backplane with system slot right Com pactP CIMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days 쮿 In accordance with – PICMG 2.0 R3.0 CompactPCI Core specification – PICMG 2.1 R2.0 Hot Swap specification – PICMG 2.9 R1.0 System Management Bus specification – PICMG 2.10 R1.0 Keying specification 쮿 Versions: 3 U 32-bit and 64-bit, 6 U 64-bit, with system slot right 쮿 V(I/O) adjustable to +3.3 V or +5 V (see photo) 쮿 Backplanes up to 5 slot are 66 MHz capable, 6 to 8 slot backplanes are set for 33 MHz operation 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Digital GND can be connected to/isolated from chassis GND by means of screws Photo shows 23006-816 12408001 쮿 Infeed of supply voltages via powerbugs (ring tag M4), FASTONs 쮿 Utility plug for status signals (SMCQ) 쮿 Intelligent platform management bus (IPMB) connector to PICMG 2.9 Delivery comprises a: V(I/O) bridge; b: Utility connector; c: IPMB connector ServicePLUS see page 10.31 12408002 Item 1 Qty 1 2 1 Description CompactPCI backplane with coding tab and V(I/O) bridge, fitted Set of 6 M4 bolts, with lock washer; for power connection Note 쮿 4 to 7 slot backplanes can be used as primary backplane with bridge 쮿 Types marked with an asterisk * are available on request 쮿 CompactPCI backplanes and secondary bridges see from page 10.10 Order Information Number Width of slots mm 3 U, 32-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. 3 U, 64-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. 1 19.3 23006-331 23006-811 23006-331 23006-811 2 39.6 23006-332 23006-812 –* –* 3 60.0 23006-303 23006-813 23006-353 23006-833 4 80.3 23006-334 23006-814 23006-354 23006-834 5 100.6 23006-301 23006-815 23006-355 23006-835 6 121.0 23006-336 23006-816 –* –* 7 141.2 23006-337 23006-817 –* –* 8 161.6 23006-300 23006-818 23006-358 23006-838 Accessories Kit to convert V I/O to 3.3 V 8 coding tabs, yellow, coding key, PU 1 kit Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece Termination adaptor, 64-bit bus for 8 slot CompactPCI backplane, 1 piece SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Power Piggyback usable with backplanes with 3 slots and up, 1 piece Power backplane with P47 connector Screws, washers for backplane mounting SCHROFF.PENTAIR.CO.UK 6 U, 64-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. –* –* 23006-372 23006-373 23006-862 23006-863 23006-374 23006-864 23006-375 23006-376 23006-865 23006-866 23006-377 23006-867 23006-378 23006-868 21101-658 23204-115 23204-116 23006-931 23204-113 23098-100 Page 10.20 Page 10.30 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 10.7 Backplanes – CompactPCI CompactPCI backplane with system slot left Com pac tP CIMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days 쮿 In accordance with – PICMG 2.0 R3.0 CompactPCI Core specification – PICMG 2.1 R2.0 Hot Swap specification – PICMG 2.9 R1.0 System Management Bus specification – PICMG 2.10 R1.0 Keying specification 쮿 Versions: 3 U 32-bit and 64-bit, 6 HE 64-bit, with system slot left 쮿 V(I/O) adjustable to +3.3 V or +5 V (see photo) 쮿 Backplanes up to 5 slots are 66 MHz capable; 6 to 8 slot backplanes are set for 33 MHz operation 쮿 Outer layers act as GND surfaces 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Multiple backplanes can be placed together without loss of slots Photo shows 23006-816 12408001 쮿 Digital GND can be connected to/isolated from chassis-GND by means of screws 쮿 Infeed of supply voltages via powerbugs (ring tag M4), FASTONs 쮿 Utility plug for status signals (SMCQ) 쮿 Intelligent platform management bus (IPMB) connector to PICMG 2.9 Delivery comprises a: V(I/O) bridge; b: Utility connector; c: IPMB connector 12408002 Item 1 2 Qty 1 1 Description CompactPCI backplane Set of M4x6 bolts, with lock washer; for power connection Note ServicePLUS see page 10.31 쮿 4 to 7 slot backplanes can be used as primary backplane with bridge (bridge for system slot left available on request) 쮿 Types marked with an asterisk * are available on request Order Information Number of slots Width mm 3 U, 32-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. 3 U, 64-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. 1 19.3 23006-331 23006-811 23006-331 23006-811 2 39.6 –* –* 23006-422 23006-732 3 39.6 –* –* 23006-423 23006-733 4 80.3 –* –* 23006-424 23006-734 5 100.6 23006-405 23006-715 –* –* 6 121.0 23006-406 23006-716 – – 8 161.6 23006-408 23006-718 23006-428 23006-738 Accessories Kit to convert V I/O to 3.3 V 8 coding tabs, yellow, coding key, PU 1 kit Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece Termination adaptor, 64-bit bus for 8 slot CompactPCI backplane, 1 piece SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Screws, washers for backplane mounting 10.8 SCHROFF PRODUCT CATALOG E 12/2017 6 U, 64-bit, CompactPCI backplane 3.3 V V(I/O) 5 V V(I/O) Part no. Part no. –* –* –* 23006-443 –* 23006-763 23006-444 23006-764 23006-445 –* 23006-765 –* 23006-448 23006-768 21101-658 23204-115 23204-116 23006-931 23204-113 Page 10.30 ELECTRONICS PROTECTION Backplanes – CompactPCI CompactPCI, packaging switching and H.110 backplane Com pactP CIMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days 쮿 In accordance with – PICMG 2.0 R3.0 CompactPCI Core specification – PICMG 2.1 R2.0 Hot Swap specification – PICMG 2.9 R1.0 System Management Bus specification – PICMG 2.10 R1.0 Keying specification – PICMG 2.5 Computer Telephony specification (H.110) – PICMG 2.16 CompactPCI Packet Switching Backplanes – PICMG 2.11 CompactPCI Power Interface specification 쮿 Various versions – CompactPCI, Packet Switching, H.110 – Backplanes for horizontal installation and backplanes for horizontal installation including slots for plug-in power supply (P47) 쮿 V(I/O) can be set to +3.3 V or +5 V Photo shows 23006-797, 9 U ServicePLUS see page 10.31 12405002 쮿 Backplanes up to 5 slots are 66 MHz capable, 6 to 8 slot backplanes are set for 33 MHz operation 쮿 Outer layers act as GND surfaces 쮿 Outstanding high frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Digital GND can be connected to/isolated from chassis GND by means of screws 쮿 Utility plug for status signals 쮿 Intelligent platform management bus (IPMB) connector to PICMG 2.9 Delivery comprises Item 1 2 Qty 1 1 Description CompactPCI backplane Set of M4x6 bolts, with lock washer; for power connection Note 쮿 Types marked with an asterisk * are available on request Order Information Number of slots 2 2 2 4 4 6 CompactPCI backplanes Power connector Data connection System slot left, for horizontal mounting System slot left, for horizontal mounting System slot left, for horizontal mounting System slot left, for horizontal mounting System slot left, for horizontal mounting System slot left, for horizontal mounting 64-bit CompactPCI bus 64-bit CompactPCI bus 64-bit CompactPCI bus 64-bit CompactPCI bus 64-bit CompactPCI bus 64-bit CompactPCI bus 23006-792 6 System slot left, for horizontal mounting 64-bit CompactPCI bus 23006-796 8 System slot left, for horizontal mounting 64-bit CompactPCI bus 23006-797 8 System slot left, for horizontal mounting ATX (male) connector Mini-fit 10-pin 1 x P47 Mini-fit 24-pin 2 x P47 Mini-fit 24 pin 2 x P47 (optional third connector) 2 x P47 (optional third and fourth connectors) 2 x P47 (optional third and fourth connectors) 8 System slot right, for 6 U CompactPCI system, power input without loss of slot space SCHROFF.PENTAIR.CO.UK Powerbugs 64-bit CompactPCI bus, H.110 bus, PSB 64-bit CompactPCI bus, H.110 bus Part no. 23006-793 23006-794 23006-799 23006-795 23006-798 23006-611 23006-601 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 10.9 Backplanes – CompactPCI CompactPCI bridges Com pac tP CIMai n C ataloguePart number in bold face type: ready for des patch within 2 working days P art number in normal type: ready for despatch within 10 working days 쮿 In accordance with – PICMG 2.6 CompactPCI Bridging Specification – PCI 2.1 PCI Local Bus Specification, Rev. 2.1 쮿 Bridge mounted on rear of backplane, hence no loss of slots 쮿 Very compact and low bridge shape, no interference with rear transition boards 쮿 Schroff CompactPCI backplanes with system slot right are used as primary backplane 쮿 The 32-bit bridge is 33 MHz capable and the 64-bit bridge is 33/66 MHz capable 쮿 Bridges are designed for primary backplanes with system slot right; bridges for system slot left available on request 쮿 A summary of possible backplane/bridge combinations can be found on the Schroff website Photo shows 32-bit and 64-bit bridges 12402002 Delivery comprises Item 1 ServicePLUS see page 8.112 Qty 1 Description Bridge Order Information Description CompactPCI bridge, 32 bit, 33 MHz, for system slot right Part no. 23006-920 Note 쮿 32-bit system slot left on request 쮿 64-bit system slot left on request 10.10 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes – CompactPCI CompactPCI secondary backplanes, system slot to right Com pactP CIMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 working days 쮿 In accordance with – PICMG 2.0 R3.0 CompactPCI Core Specification – PICMG 2.1 R2.0 Hot-swap Specification – PICMG 2.9 R1.0 System Management Bus Specification PICMG 2.10 R1.0 Keying Specification 쮿 Secondary backplane for use behind the bridge 쮿 A summary of possible backplane/bridge combinations can be found on the Schroff website 쮿 Secondary backplanes can also be used as tertiary backplanes; change of geographical address see user manual Delivery comprises Item 1 2 Qty 1 1 Description CompactPCI backplane Kit screws M4 x 6, with lock washers, for power connection Order Information Photo shows primary and secondary backplane with inserted bridge and fitted rear transition board ServicePLUS see page 8.112 12401021 Number of slots Height U 3 3 Description 4 32-bit 7 32-bit Accessories Screws, washers for backplane mounting Part no. 23006-824 23006-827 Page 10.30 Note 쮿 Other configurations available on request or via www.schroff.co.uk/configuration SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 10.11 Backplanes – PXI PXI backplanes PXIMain Catalogue 쮿 In accordance with – PXI Specification R 2.0 – PICMG 2.0 R3.0 CompactPCI Core Specification – PICMG 2.1 R2.0 Hot-swap Specification – PICMG 2.9 R1.0 System Management Bus Specification – PICMG 2.10 R1.0 Keying Specification 쮿 64-bit CompactPCI bus and PXI bus on the P2 plane 쮿 Clock generated on the backplane; feeding in an external clock is possible, the backplane switches automatically between the two clocks 쮿 Backplanes with up to 5 slots are capable of 66 MHz, 6 to 8 slot backplanes are set to 33 MHz operation 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors Photo shows 23006-578 12402004 쮿 Utility connector for status signals 쮿 Intelligent platform management bus (IPMB) connector to PICMG 2.9 Delivery comprises ServicePLUS see page 8.112 Item 1 2 Qty 1 1 Description PXI backplane Kit screws M4 x 6, with lock washer, for power connection Order Information Number of slots System slot 5 left 7 left 8 left 4 left Accessories Screws, washers for backplane mounting 5 V V(I/O) Part no. primary primary primary tertiary 23006-575 23006-577 23006-578 23006-594 Page 10.30 Note 쮿 Other configurations available on request or via www.schroff.co.uk/configuration 10.12 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes – VPX VPX backplane, 3 U VPXMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days 쮿 In accordance with: – VITA 46.0 VPX base standard – VITA 46.3 Serial RapidIO on VPX – VITA 46.4 PCI Express on VPX Fabric Connector – VITA 46.7 Ethernet on VPX Fabric Connector – VITA 46.11 System Management on VPX – Version with rear I/O: VITA 46.10 Rear Transition Module for VPX 쮿 JTAG connections 쮿 3 U, 5 slot, 0.8” slot pitch, full mesh topology to VITA 46.21 distributed switching on VPX rule 4 – 5 with additional slot for power supply VPX backplane, 3 U, 5 slot, with rear I/O 10513002 쮿 3 U, 7 slot, conforms additionally to VITA 65 OpenVPX – 6 payload slots, 1 switch slot with 1.0” slot pitch, single star topology conforming to BKP3-CEN07-15.2.3-3 – Switch slot to SLT3-SWH-6F6U-14.4.1 – Payload slots to SLT3-PAY-2F2U-14.2.3 쮿 M4 power studs for power supply, max. 22 A per slot for each voltage 쮿 Lockable aux utility and sense connectors 쮿 DIP switch for system slot settings Order Information Description VPX backplane, 3 U, 7 slot, without rear I/O 10512002 Width mm Slot pitch Open VPX backplane, 3 U, 7 121.9 1,0" slot, without rear I/O Open VPX backplane, 3 U, 176.0 1,0" 7 slot, with rear I/O VPX backplane, 3 U, 5 slot, 121.9 0,8" without rear I/O VPX backplane, 3 U, 5 slot, 176.0 0,8" with rear I/O Accessories Screws, washers for backplane mounting Backplane type Part no. Single star 23001-814 Single star 23001-815 Full Mesh 23001-812 Full Mesh 23001-813 Page 10.30 Note 쮿 Backplane to VITA 46.10; rear transition modules on request 10508004 Backplane mounting: a: conductive, b: isolated ServicePLUS see page 10.31 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 10.13 Backplanes – VMEbus Keying and alignment for VPX backplanes VMEbusMain C atalogP art number in bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping within 10 working days 쮿 Conforms to VITA 46.0 쮿 Keying and alignment for VPX backplane slots with slot spacings 0.8, 0.85 or 1" 쮿 Different versions for air-cooled and conduction-cooled systems 쮿 Air-cooled systems additionally contain stiffening beads that also prevent incorrect insertion of a VPX board (as per VITA 46.0 section 7.9) 쮿 Applications for versions with and without rear I/O 쮿 For board thicknesses 3.6 ... 5.5 mm and 5.5... 7.5 mm 쮿 Simple to fit into the fixing holes provided on every VPX backplane 쮿 One packaging unit contains all components to completely populate 10 slots Delivery includes Item 1 12402004 ServicePLUS see page 8.112 10.14 SCHROFF PRODUCT CATALOG E 12/2017 Qty 10 Description Keying and alignment for one VPX slot Order Information Height Description Type U 3 3 3 3 3 3 3 3 6 6 6 6 6 6 6 6 Without Rear I/O Without Rear I/O With rear I/O With rear I/O Without Rear I/O Without Rear I/O With rear I/O With rear I/O Without Rear I/O Without Rear I/O With rear I/O With rear I/O Without Rear I/O Without Rear I/O With rear I/O With rear I/O Air-cooled Air-cooled Air-cooled Air-cooled Conduction cooled Conduction cooled Conduction cooled Conduction cooled Air-cooled Air-cooled Air-cooled Air-cooled Conduction cooled Conduction cooled Conduction cooled Conduction cooled Board thickness mm 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 3.6 ... 5.5 5.5 ... 7.5 Part no. 20836-550 20836-551 20836-552 20836-553 20836-558 20836-559 20836-560 20836-561 20836-554 20836-555 20836-556 20836-557 20836-562 20836-563 20836-564 20836-565 ELECTRONICS PROTECTION Backplanes – VME64 extension Monolithic VME64x backplanes (6 U) VME64 extension Main C atalogue 쮿 In accordance with: ANSI/VITA 1-1994 VME64 Standard ANSI/VITA 1.1-1997 VME64 Extension Standard ANSI/VITA 1.5-2003 VME2eSST Specification ANSI/VITA 1.7-2003 Increased Current Level ANSI/VITA 38 System Management on VME 쮿 Monolithic backplane, 6 U with J1 and J2 plane 쮿 Termination passive 쮿 Electronic automatic daisy chain (EDC) 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Connection or isolation between the digital GND and chassis GND can be effected via the screw fittings (see photo) 쮿 Supply voltages can be applied via powerbugs (ring tag M4) or FASTON 쮿 Utility connector for status signals 10502001 Photo shows 23001-551 쮿 System management bus (SMB) connector in accordance with VITA38 쮿 Connector for additional voltages V1/V2 (see photo) Delivery comprises Item 1 2 Qty 1 1 Description VME64x backplane Kit screws M4 × 6, with lock washer; for power connection Order Information Number of slots Backplane mounting: a: conductive, b: isolated Connector for additional voltages V1/V2 10508004 10508007 Width Height Without P0 mm U Part no. 2 39.1 6 23001-502 3 59.5 6 23001-503 4 79.8 6 23001-504 5 100.2 6 23001-505 6 120.5 6 23001-506 7 140.8 6 23001-507 8 161.1 6 23001-508 10 201.8 6 23001-510 11 222.0 6 23001-511 12 242.4 6 23001-512 15 303.4 6 23001-515 16 323.7 6 23001-516 20 405.0 6 23001-520 21 425.3 6 23001-521 Accessories SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece Screws, washers for backplane mounting With P0 Part no. 23001-532 23001-533 23001-534 23001-535 23001-536 23001-537 23001-538 23001-540 23001-541 23001-542 23001-545 23001-546 23001-550 23001-551 23204-113 23204-115 23204-116 Page 10.30 ServicePLUS see page 10.31 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.15 Backplanes – VXS VXS VXSMain Catalogue 쮿 In accordance with ANSI/VITA 41 VXS VMEbus Switched Serial Standard ANSI/VITA 1-1994 VME64 Standard ANSI/VITA 1.1-1997 VME64 Extension Standard ANSI/VITA 1.5-2003 VME2eSST Specification ANSI/VITA 1.7-2003 Increased Current Level ANSI/VITA 38 System Management on VME 쮿 Parallel VMEbus on J1 and J2, serial data connections on P0 쮿 MultiGig RT2 connector on P0 position for data transfer rates up to 10 Gbps per differential pair 쮿 Dual star, star and ring topologies 쮿 Keying and alignment pins to avoid mechanical and electrical damage 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Supply voltages can be applied via powerbugs (ring tag M4), FASTONs or P47 connectors Photo shows 23001-701 10506004 쮿 Utility connector for status signals 쮿 System management bus (SMB) connector in accordance with VITA38 쮿 Connector for additional voltages V1/V2 Delivery comprises Item 1 2 Qty 1 1 Description VXS backplane Set of M4x6 bolts, with lock washer; for power connection Order Information Photo shows 23001-704 High-speed connector with keying and alignment pin 10508002 Number Width Height Description of slots mm U 1 VXS switch slot and 3 VXS 4 80.3 6 payload slots 4 VME64x slots, 3 VXS payload slots, ring connected, 7 151.4 6 1 slot for 2 x 3 U PSUs, without VXS rear I/O 2 VXS switch slots and 10 VXS 12 242.0 6 payload slots 2 VXS switch slots and 18 VXS 20 405.4 6 payload slots Accessories SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece Keying and alignment pin for VXS Payload slot with RTM, PU 10 pieces Keying and alignment pin for VXS Payload slot without RTM, PU 10 pieces Keying and alignment pin for VXS Switch slots, PU 10 pieces Screws, washers for backplane mounting Part no. 23001-704 23001-701 23001-712 23001-720 23204-113 23204-115 23204-116 20817-900 20817-969 20817-970 Page 10.30 10508009 ServicePLUS see page 10.31 10.16 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes – VMEbus Monolithic J1/J2 backplane (6 U) VMEbusMain C atalogue 쮿 In accordance with ANSI/VITA 1-1994 VME64 standard 쮿 Monolithic backplane, 6 U with J1 and J2 plane 쮿 Active/passive termination switchable via jumpers; passive termination preset (see photo) 쮿 Electronic automatic daisy chain (EDC) 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Linking/separation of digital and chassis GNDs by means of a screw connection (see photo) 쮿 Supply voltages provided via power bugs (ring tag M4) or FASTON 쮿 Two utility connectors for status signals, two different configurations (see photo) Delivery comprises 10506003 Photo shows 23001-069 Item 1 2 Qty 1 1 Description VME monolithic J1/J2 backplane Kit screws M4x6, with lock washer, for power connection Order Information Number of slots Backplane mounting: a: conductive, b: isolated 10508004 Width mm 59.5 79.8 100.2 120.5 140.8 161.1 181.4 201.8 242.4 405.0 425.3 Height U 6 6 6 6 6 6 6 6 6 6 6 Utility connector 2 3 MicroMatch 4 MicroMatch 5 MicroMatch 6 MicroMatch 7 MicroMatch 8 MicroMatch 9 SMCQ 10 MicroMatch 12 MicroMatch 20 SMCQ 21 MicroMatch Accessories Utility cable MicroMatch with single conductors, length 600 mm, 1 piece Utility cable MicroMatch with flat ribbon cable, length 600 mm, 1 piece Utility cable SMCQ with flat ribbon cable, length 350 mm, 2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm, 2 × 12-pin female connector, 1 piece Screws, washers for backplane mounting Part no. 23001-063 23001-064 23001-065 23001-066 23001-067 23001-068 23001-069 23001-070 23001-072 23001-080 23001-081 23204-812 23204-811 23204-115 23204-116 Page 10.30 Note 쮿 Other configurations available on request or via www.schroff.co.uk/configuration c: termination switchover active/passive, d: utility connector 1, e: utility connector 2 MicroMatch, f: utility connector 2 SMCQ 10509001 ServicePLUS see page 10.31 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.17 Backplanes – VMEbus J1 backplane (3 U) Main Catalogue 쮿 In accordance with ANSI/VITA 1-1994 VME64 standard 쮿 3 U with J1 plane 쮿 Active/passive termination switchable via jumpers; passive termination preset (see photo) 쮿 Electronic automatic daisy chain (EDC) 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Linking/separation of digital and chassis GNDs by means of a screw connection (see photo) 쮿 Supply voltages provided via power bugs (ring tag M4) or FASTON 쮿 Two utility connectors for status signals, two different configurations (see photo) 10506001 Photo shows 23001-020 Delivery comprises Item 1 2 Qty 1 1 Description VME J1 backplane Kit screws M4x6, with lock washer; for power connection Order Information Number of slots Backplane mounting: a: conductive, b: isolated c: termination switchover active/passive, d: utility connector 1, e: utility connector 2 MicroMatch, f: utility connector 2 SMCQ 10508004 10509001 Width mm 20.2 39.1 59.7 79.8 100.2 120.5 140.8 161.1 181.4 199.2 242.4 303.4 341.4 364.3 405.0 425.3 Height U 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Utility connector 2 1 2 MicroMatch 3 MicroMatch 4 MicroMatch 5 MicroMatch 6 MicroMatch 7 SMCQ 8 MicroMatch 9 MicroMatch 10 SMCQ 12 SMCQ 15 MicroMatch 17 MicroMatch 18 MicroMatch 20 MicroMatch 21 MicroMatch Accessories Utility cable MicroMatch with single conductors, length 600 mm, 1 piece Utility cable MicroMatch with flat ribbon cable, length 600 mm, 1 piece Utility cable SMCQ with flat ribbon cable, length 350 mm,2 × 12-pin female connector, 1 piece Utility cable SMCQ with flat ribbon cable, length 600 mm,2 × 12-pin female connector, 1 piece Screws, washers for backplane mounting Part no. 23001-001 23001-002 23001-003 23001-004 23001-005 23001-006 23001-007 23001-008 23001-009 23001-010 23001-012 23001-015 23001-017 23001-018 23001-020 23001-021 23204-812 23204-811 23204-115 23204-116 Page 10.30 ServicePLUS see page 10.31 10.18 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes – VMEbus J2 backplane (3 U) Main Catalogue 쮿 In accordance with ANSI/VITA 1-1994 VME64 standard 쮿 3 U with J2 plane 쮿 Termination passive 쮿 Outstanding high-frequency noise suppression and very high MTBF values due to ceramic capacitors 쮿 Multiple backplanes can be placed side by side without loss of slot space 쮿 Connection or isolation between the digital GND and chassis GND can be effected via the screw fittings (see photo) 쮿 Supply voltages can be provided via powerbugs (ring tag M4) or FASTONs (see photo) Delivery comprises 10506002 Photo shows 23001-046 Item 1 2 Qty 1 1 Description VME J2 backplane Set of 6 M4 bolts, with lock washer; for power connection Order Information Number of slots Width mm 40.4 59.7 79.8 100.2 199.2 321.3 425.3 Height U 3 3 3 3 3 3 3 2 3 4 5 10 16 21 Accessories Screws, washers for backplane mounting Backplane mounting: a: conductive, b: isolated Part no. 23001-032 23001-033 23001-034 23001-035 23001-040 23001-046 23001-051 Page 10.30 10508004 10508006 Supply voltage feed: c: cable with blade receptacle pushed onto FASTON d: cable with ring tag screwed to powerbug, with M4 screw and lock washer ServicePLUS see page 10.31 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.19 Backplanes Power backplane with P47 connector Com pac tP CIMAIN CATALO GP art number i n bold face type: ready for shipping within 2 working daysPart num ber in normal type: ready for shipping wi thin 10 working days 쮿 In accordance with: PICMG 2.11 R1.0 CompactPCI Power Interface specification and PICMG 2.9 R1.0 System Management Bus specification 쮿 Single, parallel or redundant operation possible 쮿 Direct current outlets for high currents with virtually no voltage reduction 쮿 Geographical address adjustable 쮿 Power supply over crimp contacts insertable into the plug, no supply voltage on the backplane 쮿 Power cable available as an accessory 쮿 DC outlets with powerbugs for extremely low drops in voltage Delivery includes Item 1 2 Qty. 1 1 Description Power backplane with P47 connector Set, combination screw M4 x 6 in accordance with DIN 6900 Order Information 01917001 ServicePLUS see page 10.31 Width Width Number of Power Height slots connector HP mm U 8 39.6 1 1 x P47 3 16 80.3 2 2 x P47 3 8 39.6 1 1 x P47 6 8 39.6 1 2 x P47 6 Accessories Power cable 3-wire, 500 mm, 1 piece Utility/sense cable Flat ribbon cable, length 350 mm, 2 x 12-pin female connector, 1 piece Utility/sense cable Flat ribbon cable, length 600 mm, 2 x 12-pin female connector, 1 piece SM bus/IPMB cable 4 individual wires with SMB plug to open end, length 750 mm, 1 piece Current-sharing flat ribbon cable, 150 mm, 2 x 4-pin MicroMatch 1 piece Utility cable MicroMatch with single conductors, length 600 mm, 1 piece Utility cable MicroMatch with flat ribbon cable, length 600 mm, 1 piece Part no. 23098-393 23098-394 23098-395 23098-396 23204-110 23204-115 23204-116 23204-113 23204-867 23204-812 23204-811 Power piggyback 쮿 Allows connection of pluggable power supplies, e.g. ATX PSUs, to CompactPCI backplanes 쮿 Simply mounts on the PSU screw connections on the rear of Schroff CompactPCI backplanes Delivery comprises Item 1 Qty 1 Description Power piggyback Order Information Description Power piggyback Qty/PU 1 Part no. 23098-100 12401002 10.20 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Backplanes Universal backplanes UniversalMain Catalogue With through-connected signal lines 쮿 Power supply at each connector position (row 1 + 32) 쮿 Adaptation fields for power connections on 2-layer backplanes 쮿 Two versions: – 60 signal lines, through-connected from connector to connector (C64), row „b“ can be freely wired (2 layers with C96 connector), wire-wrap – 90 signal lines, through-connected from connector to connector Without through-connected signal lines 쮿 Individual wiring of connectors is possible since signal lines are not through-connected 쮿 Power supply at each connector position (row 1 + 32) 쮿 Adaptation fields for connections Universal backplanes with through-connected signal lines, 10 and 21 slot 12096003 Delivery comprises Item 1 2 3 4 Qty 1 10 3 1 Description Universal backplane Bridges, grid 5.08 mm Jumpers 10-pin header Order Information with through-connected signal lines 12006001 Universal backplanes without through-connected signal lines, 21 slots ServicePLUS see page 10.31 Number Slot of slots pitch HP 10 4 10 4 10 4 14 3 21 4 21 4 21 4 21 4 28 3 28 3 28 3 Width No. of layers HP 42 2 42 2 42 4 42 2 84 2 84 2 84 2 84 4 84 2 84 2 84 2 Connector type No. of signal lines C64F C96F C96F C64F C64F C96F – C96F C64F C96F – 60 60 90 60 60 60 60 90 60 60 60 Part no. 23007-010 23007-040 23007-410 23007-114 23007-021 23007-051 23007-081 23007-421 23007-128 23007-158 23007-188 Connector "-": not equipped, 96 solder points Order Information without through-connected signal lines Number of slots Slot pitch HP 4 Width HP 84 21 Accessories Screws, washers for backplane mounting SCHROFF.PENTAIR.CO.UK No. of layers 2 Part no. 23007-222 Page 10.30 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.21 Test adaptors Test adaptors, type B Main Catalogue 쮿 For DIN 41612 connectors, type B 쮿 Measuring field for current and voltage measurement (U/I), (a) 쮿 Header with pin diameter 0.6 mm for wire wrap (b) 쮿 Outer pin rows (pin 1a, c and pin 32a, c) with wider tracks for power supply (2 A per track) Delivery comprises Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Photo shows 23021-607 11100018 Connector type B64 B64 Height U 3 3 For board depth mm 160 220 Backplane Measuring type field for 1L 1L U/I U/I Part no. 23021-607 23021-651 Note 쮿 Detailed dimensions and test adaptor types see page 10.29 쮿 6/9 U test adaptors see page 10.27 a: Measuring field for current and voltage measurement b: Header for wire wrap 11100019 ServicePLUS see page 10.31 10.22 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Test adaptors Test adaptors, type C Main Catalogue 쮿 For DIN 41612 connectors, type C 쮿 2 different measuring fields: – current and voltage measurement (U/I): pluggable test bridges – voltage measurement (U): soldered test bridges 쮿 Connector type C64: Header with pin diameter 0.6 mm for wire wrap 쮿 Connector type C96: Slot for second test unit or terminator board (b) 쮿 Outer pin rows (C96: pin 1a, b, c and pin 32a, b, c; C64: pin 1a, c and pin 32a, c) with wider tracks for power supply (2 A per track) Delivery comprises Photo shows 23021-609 11100003 Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Connector type a: Measuring field for current and voltage measurement b: Connector position for a second test object ServicePLUS see page 10.31 11100004 Height U 3 3 6 3 3 3 3 3 3 3 3 6 6 6 6 C 64 C 64 C 64 C 96 C 96 C 96 C 96 C 96 C 96 C 96 C 96 C 96 C 96 C 96 C 96 For board depth mm 160 220 160 160 160 160 220 220 280 280 340 160 160 220 280 Backplane Measuring type field for 1L 2L 1L 2L 2L 4L 2L 4L 2L 4L 4L 2L 4L 2L 2L U/I U/I U/I U U/I U/I U/I U/I U/I U/I U/I U/I U/I U/I U/I Part no. 23021-608 23021-652 23022-601 23021-603 23021-609 23021-610 23021-653 23021-654 23021-700 23021-701 23021-750 23022-602 23022-603 23022-652 23022-700 Note 쮿 Detailed dimensions and test adaptor types see page 10.29 쮿 6/9 U test adaptors see page 10.27 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.23 Test adaptors Test adaptors, type D Main Catalogue 쮿 For DIN 41612 connectors, type D 쮿 2 different measuring fields: – current and voltage measurement (U/I): pluggable test bridges – voltage measurement (U): soldered test bridges 쮿 Header with pin diameter 0.6 mm for wire wrap (b) 쮿 Outer pin rows (pin 1a, c and pin 16a, c) with wider tracks for power supply (2 A per track) Delivery comprises Photo shows 23021-611 11100005 Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Connector type D32 D32 D32 Height For board depth U mm 3 160 3 160 3 220 Backplane type Measuring field for 1L 1L 1L U/I U U/I Part no. 23021-611 23021-604 23021-655 Note a: Measuring field for current and voltage measurement b: Header for wire wrap 11100006 쮿 Test adaptor type D cannot be used in combination with the adapter of other types 쮿 Detailed dimensions and test adaptor types see page 10.29 Test adaptors, type E Main Catalogue 쮿 For DIN 41612 connectors, type E 쮿 Measuring field for current and voltage measurement (U/I), (a) 쮿 Header with pin diameter 0.6 mm for wire wrap (b) 쮿 Outer pin rows (pin 1a, c, e and pin 31a, c, e) with wider tracks for power supply (2 A per track) Delivery comprises Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Photo shows 23021-656 11107001 Connector type E48 Height For board depth U mm 3 220 Backplane type Measuring field for 2L U/I Part no. 23021-656 Note 쮿 Detailed dimensions and test adaptor types see page 10.29 쮿 6/9 U test adaptors see page 10.27 a: Measuring field for current and voltage measurement b: Header for wire wrap 10.24 SCHROFF PRODUCT CATALOG E 12/2017 11107002 ELECTRONICS PROTECTION Test adaptors Test adaptors, type F Main Catalogue 쮿 For DIN 41612 connectors, type F 쮿 2 different measuring fields: – current and voltage measurement (U/I): pluggable test bridges – voltage measurement (V): soldered test bridges 쮿 Header with pin diameter 0.6 mm for wire wrap (b) 쮿 Outer pin rows (pin 1a, c, e and pin 16a, c, e) with wider tracks for power supply (2 A per track) Delivery comprises Photo shows 23021-613 11100008 Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement bridges Order Information Connector type F48 F48 F48 F48 Height For board depth U mm 3 160 3 160 6 160 3 220 Backplane type Measuring field for 2L 2L 2L 2L U U/I U/I U/I Part no. 23021-605 23021-613 23022-604 23021-657 Note a: Measuring field for current and voltage measurement b: Header for wire wrap 11100009 쮿 Detailed dimensions and test adaptor types see page 10.29 쮿 Further 6/9 U test adaptors see page 10.27 Test adaptors, type M Test adaptorsMai n C atalogue 쮿 For DIN 41612 connectors, type M 쮿 2 versions: - M (F/H): with high-current contacts (H) - M (C/coax): with coaxial connector contact 쮿 Measuring field versions for current and voltage measurement (U/I): – M (F/H): F: measurement lugs (a) and measurement pins (b) with jumpers H: test bridges (c) (diameter 4 mm) – M (C/coax): C: test bridges pluggable, header with pin diameter 0.6 mm for wire wrap Photo shows 23021-616 11100013 Delivery comprises Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Connector type M (F24/H7) M (F24/H7) 11100014 Test adaptor M (F24/H7), a: Measurement lugs, b: Measuring pin with jumper, c: Test bridge, diameter 4 mm SCHROFF.PENTAIR.CO.UK Height For board depth U mm 3 160 3 220 Backplane type Measuring field for 2L 2L U/I U/I Part no. 23021-616 23021-660 Note 쮿 Detailed dimensions and test adaptor types see page 10.29 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.25 Test adapters Test adaptors for VMEbus Main Catalogue 쮿 Layout of conductive tracks and layer build-up match the requirements of the VME bus 쮿 Measuring field version for current and voltage measurement (V/I), (a) 쮿 Additional measuring pins, e.g. for the probe tips of an oscilloscope (b) 쮿 1 pin position for second test object, 1 pin position for terminator board 쮿 Voltage supply lines are designed for 2 A 쮿 6 U test adaptors consist of two 3 U test adaptors linked via an intermediate adaptor Delivery comprises Item 1 Qty 1 2 10 Description Test adaptor with fitted guide rails and equipped test bridges Replacement test bridges Order Information Photo shows 6 U test adaptor 11192004 Height U 3 3 3 3 6 6 6 For board depth mm 160 160 220 220 160 220 280 Connector type P1 P2 C96 – – C96 C96 – – C96 C96 C96 C96 C96 C96 C96 Part no. 23021-001 23021-100 23021-002 23021-101 23022-002 23022-004 23022-010 P1 = system bus, P2 = I/O bus Note 쮿 9 U test adaptor see page 10.27 Dimensions table VMEbus test adaptors a: measuring field for current and voltage measurement b: Measuring pin, e.g. for test prod 11196001 Board height 3U 6U F (mm) 123.65 257 For board depth A (mm) 160 mm 423 220 mm 483 280 mm 543 A = overall length, B = extension Dimensional drawing of test adaptor G (mm) 100 233.35 B (mm) 350 410 470 C (mm) 237 297 417 D (mm) 175.24 235.24 355.24 taa43143 ServicePLUS see page 10.31 10.26 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Test adapters 6/9 U test adaptors 6U Main Catalogue 쮿 Suitable for types B, C, D, E, F 쮿 6 U test adaptor can be made from: – 2 × equal length 3 U test adaptors (3/4) – 1 × intermediate adaptor 6 U (1) or – 1 × 3 U test adaptor (3/4) – 1 × bare board (item 2 without connector) – 1 × intermediate adaptor 6 U (1) A4-2550 9U 쮿 9 U test adaptor can be made from: – 3 × equal length 3 U test adaptors (3/4) – 2 × intermediate adaptor 9 U (1) or – 2 × 3 U test adaptors (3/4) – 1 × bare board (item 2 without connector) – 2 × intermediate adaptor 9 U (1) or other combinations test adaptor item 4, type x bare board: item 3 Delivery comprises (kit) Item 1 Qty 6U 1 9U 2 Description 2 – 2 Intermediate adaptor, St, 1.5 mm, grey, incl. assembly kit Board stiffener Order Information Description For board depth For test adaptor depth (dimension B) mm 290 350 410 470 350 mm 6U 160 6U 220 6U 280 6U 340 9U 220 Accessories Bare board (item 2) 3 U, 160 mm deep without connector, 1 piece Bare board (item 2) 3 U, 220 mm deep without connector, 1 piece BPTE6567 SCHROFF.PENTAIR.CO.UK Part no. 20800-224 20800-168 20800-278 20800-279 23040-001 23040-006 23040-007 Note 쮿 Test adaptor type D cannot be combined with other types 쮿 Test adaptor depth (dimension B) of VMEbus test adaptors see page 10.26 쮿 Test adaptor depth (dimension B) at type B, C, D, E, F, see page 10.29 Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.27 Test adapters Board guides Main Catalogue 쮿 To hold and lock modules that have to be tested (for replacement purposes only, board guides are included in delivery of all test adaptors) 쮿 Versions – Short board guide with/without locking lever – Long board guide with/without locking lever Order Information Description Type: short, with locking lever Type: short, without locking lever Type: long, with locking lever Type: long, without locking lever Top: with locking lever, left short, right long; bottom: without locking lever, left short, right long Short board guide Qty/PU 2 1 2 2 Part no. 60800-834 60800-032 20800-212 20800-213 11192009 A4-1908 A4-2411 Short board guide without locking lever A, B, see "Dimensions test adaptors" Long board guide without locking lever 10.28 SCHROFF PRODUCT CATALOG E 12/2017 A4-2551 ELECTRONICS PROTECTION Test adapters Types/board versions Epoxy fibreglass EP-GC02 to DIN 40802 (FR4). Outlying connections (e.g. pins 1a, b, c and pins 32a, b, c) each have a wider PCB track or large-surface tracks on inner layers – e.g. for shielding, Vcc, GND. Type 1L 2L 4L PCB single-sided, laminated (suitable for up to 2 MHz) PCB, double-sided, laminated and through-connected (suitable for up to approx. 8 MHz) Multi-layer, 4-layer (suitable for above 8 MHz): Multi-layer technology with large-area inner layers (signal–surface–surface–signal). In the coax version the large-area inner layers can be soldered to the desired pins by means of power links. \ Dimensions test adaptors 쮿 Types B, C, E, F, H and M Board height 3U 6U Board depth 160 mm 220 mm 280 mm 340 mm F mm 123.00 257.00 G mm 100.00 233.35 A mm 363 423 483 543 B mm 290 350 410 470 C mm 190 250 310 370 D mm 175.24 235.24 355.24 415.24 taa43143 1) 2) 3) 4) 5) 6) Board guide Measuring field Mounting bracket with extraction aid Test adaptor Male connector Female connector SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.29 Test adapters Panhead screws Description Torx panhead screw aza45940 Screw + securing washer Application Material Dimension Qty/PU For backplane fixing St, nickel-plated M2.5 х 12 100 24560-161 Part no. For backplane fixing St, nickel-plated M2.5 х 14 100 24560-162 For backplane fixing St, nickel-plated M2.5 х 16 100 24560-163 For backplane fixing St, nickel-plated M2.5 х 12 100 21100-777 06702051 10.30 SCHROFF PRODUCT CATALOG E 12/2017 ELECTRONICS PROTECTION Test adapters – ServicePLUS configuration Simple. Fast. For the product you want. Equipped to customer specification 쮿 Appropriate solutions from our standard range or individual solutions 쮿 Equipping options: e.g.: do not equip unused connectors, VME with ADC or MDC, set CPCI to 3.3 V, … 쮿 Online configuration enquiry: www.schroff.co.uk/configuration modification Small changes. Large impact. Small design alterations to off-the-shelf products 쮿 Minor modifications to our standard-backplane designs, customized modifications 쮿 Conformal coating solution Simple. Fast. From one source. System integration and custom developments 쮿 Development, simulation and design to customer specification; Production of prototypes, pilot series and production series 쮿 Simulation and testing academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Test reports, user reports, user manuals for download ServicePLUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for shipping within 2 working days Part number in normal type: ready for shipping within 10 working days 10.31 PROLINE Main C atalogue FPCS front element system Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front element systems Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Busbars Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 05092001 00892005 36103009 11.0 SCHROFF Main catalogue www.schroff.biz E 07/2016 ELECTRONICS PROTECTION FPCS front element system Overview . . . . . .11.0 Connectors/ busbars . . . . . . . 11.2 Front element systems . . . . . . . 11.12 Electrical components see europacPRO subrack section 6.65 Connectors Electrical components 05596002 01494031 36103009 SCHROFF.PENTAIR.CO.UK 11.1 Main C atalogue Connectors, busbars Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 05592002 Standards Modifications 쮿 Connectors in accordance with: IEC 60603-2 / DIN 41612 Extended delivery program Requirements classes DIN 41612, Part 5 Requirements class 1 - 500 connector cycles - 250 connector cycles, 21 day gas test with 10 ppm SO2, measurement of contact resistance - 250 connector cycles, then visual inspection, no abrasion of contact surface down to the base metal, no impairment of function Requirements class 2 - 400 connector cycles - 200 connector cycles, 4 day gas test with 10 ppm SO2, measurement of contact resistance - 200 connector cycles, then visual inspection, no abrasion of contact surface down to the base metal, no impairment of function 쮿 Connectors to IEC 60603-2 with requirements classes 1, 3 and defence equipment standard Minimum quantity: 300 pieces 쮿 Connectors with selective contacts Minimum quantity: 500 pieces 쮿 Complementary types to standard IEC 60603-2 („half“ type) Minimum quantity: 300 pieces 쮿 Not catalogued connectors to IEC 60603-2 Minimum quantity: 300 pieces Note: Prices and delivery times available on request Requirements class 3 - 50 connector cycles, no gas test, then visual inspection, no impairment to function Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Requirements class VG 95 324, part 1 - 500 connector cycles, then 1 day gas test with 10 000 ppm SO2 and 1 day gas test with 10 000 ppm H2S, then visual inspection, no abrasion of contact surface down to base metal, no impairment of function Appendix . . . . . 12 11.2 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Connectors, busbars Overview . . . . . . 11.3 Connectors Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days General technical data Contamination level 1 None or dry, non-conductive contamination. Contamination has no effect. Contamination level 2 Non-conductive contamination only. Occasional transient conductivity due to condensation may occur. Contamination levels 3 and 4 are not taken into account as they do not apply to the connectors listed in this catalogue. The minimum creepage distances represented in the table relate to the CTI values of insulation group III a/b. Text 25 32 0.125 0.14 0.50 0.53 50 63 80 100 125 160 200 250 320 400 500 630 800 1000 0.18 1.2 0.2 1.25 0.22 1.30 0.25 1.40 0.28 1.50 0.32 1.60 0.42 2.00 0.56 2.50 0.75 3.20 1.0 4.0 0.3 5.0 1.8 6.3 2.4 8.0 3.2 10 Operating current The current-carrying capacity of connectors is restricted by the thermal loading capacity of the materials, the contact elements - including connections - and insulation elements. The derating curve applies therefore for currents that may flow continuously (not intermittently) and simultaneously through each contact element of the connector without exceeding the maximum acceptable temperature. Measurement and control procedures in accordance with DIN 41 640, part 3. Text Keying/coding pegs for codable female connectors . . . . . . 11.7 PCB strengthening . . . . 11.8 Connectors, 3-pin . . . . . . . . . . . . 11.9 4-pin for Faston connector 6.3 x 0.8 mm . . . . . 11.10 PCB busbars . . . . . 11.11 Busbars . . . . . . . . . 11.11 Type H Operating current Operating current Keying/coding . . . . 11.7 Ambient temperature Type D, E, F, G Ambient temperature Ambient temperature Type H Operating current Type D, E, F, G Operating current 11.4 Blank connector housings/locking levers . . . . . . . . . . . 11.6 Busbars Derating diagrams Type B, C, R Connector types Keying/coding strips . . . . . . . . . . . . 11.8 Reference voltage, minimum creepage distance and contamination level Reference voltage 12.5 V UACeff or U Minimum creepage distance in mm - Contamination level 1 0.09 - Contamination level 2 0.42 Connectors Ambient temperature Ambient temperature sva42501 sva42502 sva42503 sva42504 sva42505 Main Catalogue SCHROFF.PENTAIR.CO.UK 11.3 Accessories – Connectors Overview of types, connectors EN 60603 (DIN 41612) Order Information Description Number of Row contacts assignment Type B Type C b a Drawing: View of rear of plug Male connector c b a Type R Type D c a b c c (b) a 1 2 3 4 5 6 1 2 3 4 5 6 1 2 3 4 5 6 1 2 3 4 5 6 2 28 29 30 31 32 28 29 30 31 32 28 29 30 31 32 28 29 30 31 32 28 05508052 05508053 05508054 a 4 6 8 30 32 05509052 05508055 1 piece 1 piece 1 piece 1 piece 1 piece – 69001-826 – – – – 69001-831 – – 69001-821 69001-816 – – – – a, c a, c a, b, c – – – 69001-691 69001-685 69001-679 – – – – – – – – – a, c – – – – 69001-697 – – – – – – – – – – – – – – – – – – – 32 64 64 96 a, c a, b a, c a, b, c Wire-wrap pins, length 13 mm, 0.6 mm x 0.6 mm, straight; 32 64 96 Wire-wrap pins, length 20 mm, 1 mm x 1 mm, straight; 32 Solder pins, length 3 mm, 0.6 mm x 0.6 mm; angled Type C for ribbon cables 69001-801 – – – – Female connector 64 a, b 64 a, c 96 a, b, c 64 a, c Solder pins, length 3 mm, 0.6 mm x 0.6 mm, angled 96 a, b, c 64 a, c Solder pins, length 4 mm, Ø 0.6 mm, straight 96 a, b, c Solder eye, length 5.5 mm 32 a, c Snap-on/screw-on for 64-pin cable 64 a, c Spring contacts for crimping, 0.14 - 0.5 mm2, 50 pieces Spring contacts for crimping, 0.75 - 1.5 mm2, 50 pieces Torx panhead screw M2.5 × 7, PU 100 pieces, for direct mounting on z-rail Solder pins, length 2.5 mm, Ø 0.6 mm, straight Technical Data Connector pitch Current load max. at 20 °C Test voltage Ueff contact-contact Test voltage Ueff contact-earth Contact resistance Coding on the connector Separate coding Contact surface Air gap contact-contact Creepage distances contact-contact Insertion and withdrawal forces 69001-664 – – – – – – – – – – 69001-693 69001-696 24560-147 Type B – – 69001-976 69001-728 – – – – – – – – 24560-147 24560-147 24560-147 21100-293 21100-294 24560-147 Type C Type C for ribbon cables 2.54 mm 1 A 1 kV – – – yes solidly gold-plated – – Type R Type D 69001-678 69001-677 – – – – 2.54 mm 2.54 mm 2 A 2 A 1 kV 1 kV 1.55 kV 1.55 kV ≤ 20 mΩ ≤ 20 mΩ – – yes yes solidly solidly gold-plated gold-plated >1.2 mm >1.2 mm >1.2 mm >1.2 mm 32-pin < 30 N; 64-pin < 60 N; 96-pin < 90 N 69005-596 64-pin < 60 N 2.54 mm 2 A 1 kV 1.55 kV ≤ 20 mΩ – yes solidly gold-plated >1.2 mm >1.2 mm 64-pin < 60 N; 96-pin < 90 N 69001-698 – 5.08 mm 6 A 1.55 kV 1.55 kV ≤ 20 mΩ – yes solidly gold-plated >1.6 mm >3.0 mm 32-pin < 40 N Note 쮿 Connectors are compliant with requirements class 2 ConnectorsMain CatalogueP art number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days 11.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Accessories – Connectors Overview of types, connectors EN 60603 (DIN 41612) Order Information Description Number of Row contacts assignment Drawing: View of rear of plug Male connector Solder pins, length 2.9 mm, 0.6 mm x 0.6 mm; angled Solder pins, length 3 mm, 1.2 mm x 0.8 mm; angled; connector pins not protruding Solder pins, recessed, length 2.9 mm, 1.2 mm x 0.8 mm; angled FASTON connector 6.3 mm x 0.8 mm; straight Solder pins, length 2.9 mm, FØ 0.6 mm, H Ø 1.6 mm; angled Type E Type F e c a Type G d b z 2 4 6 8 10 12 2 4 6 8 10 12 24 26 28 30 32 24 26 28 30 32 05509050 d f d b z 2 4 6 8 10 12 14 05509051 Type H Mixed type (M), type F and type H z z 6 4 32 8 28 10 30 26 24 14 26 28 30 32 d 20 20 16 14 ... ... 24 26 28 30 32 05508056 05508057 4 2 z b d 1 piece 1 piece 1 piece 1 piece 1 piece – – 69001-851 69001-853 – – – – – – – – – – – 69001-846 – 69001-856 – – – – – z, d – – – 69001-865 – 15 z, d – – – 69001-860 – 15 z, d – – – 69001-866 – 24+7-pin z, b, d – – – – 69001-905 32 48 48 64 z, b a, c, e z, b, d z, b, d, f – 69001-717 – – – – – – – 24+7-pin 32 32 48 48 64 z, b z, d a, c, e z, b, d z, b, d, f 15 – 69001-879 05508057 Female connector Wire-wrap pins, length 22 mm, 1 mm x 1 mm; straight F: Wire-wrap pins, length 22 mm, 1 mm x 1 mm; H: FASTON connector 6.3 mm x 0.8 mm; straight Solder pins, length 4 mm, 0.8 mm x 0.8 mm; straight Solder pins, length 4.5 mm, 0.4 mm x 0.6 mm; straight Solder pins, length 10 mm, 0.8 mm x 0.8 mm; straight Wiring with FASTON connector 6.3 mm x 0.8 mm; straight Solder eyes, length 9.5 mm – – 69001-711 – 69001-723 – – – – z, b, d – – – – 69001-755 15 z, d – – – 69001-981 – 48 z, b, d – 69001-884 – – – 15 z, d – – – 69001-980 – 15 z, d – – – 69001-733 – 32 32 48 z, b z, d z, b, d – – – 69001-718 69001-722 69001-712 – – – – – – – – – – – – – 69001-944 24560-147 24560-147 24560-147 24560-147 24560-147 Type E Type F Type G Type H Mixed type (M), type F and type H 5.08 mm 10.16mm 6 A 15 A 1.55 kV 3.10 kV 2.50 kV 3.10 kV ≤ 20 mΩ ≤ 8 mΩ – – yes yes solidly hard gold-plated silver-plated >1.6 mm >4.5 mm >3.0 mm >8.0 mm F: Solder eyes; H: FASTON connector 24+7-pin z, b, d 6.3 mm x 0.8 mm; straight Torx panhead screw M2.5 × 7, PU 100 pieces, for direct mounting on z-rail Technical Data Connector pitch Current load max. at 20 °C Test voltage Ueff contact-contact Test voltage Ueff contact-earth Contact resistance Coding on the connector Separate coding Contact surface Air gap contact-contact Creepage distances contact-contact Insertion and withdrawal forces – 69001-877 5.08 mm 6 A 1.55 kV 1.55 kV ≤ 20 mΩ – yes solidly gold-plated >1.6 mm >3.0 mm 48-pin < 75 N 5.08 mm 5.08 mm 6 A 6 A 1.55 kV 1.55 kV 2.50 kV 2.50 kV ≤ 20 mΩ ≤ 20 mΩ – – yes yes solidly solidly gold-plated gold-plated >1.6 mm >1.6 mm >3.0 mm >3.0 mm 32-pin < 50 N 64-pin < 100 N 48-pin < 75 N 10.16 mm 15 A 3.10 kV 3.10 kV ≤ 8 mΩ yes yes hard silver-plated >4.5 mm >8.0 mm 15-pin < 90 N 24+7-pin < 85 N Note 쮿 Connectors are compliant with requirements class 2 Connectors SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.5 Accessories – Connectors Blank connector housings/locking levers 쮿 For types C and R 쮿 The connector housing is fixed to the board with screws; it is pushed over wire wrap posts (e.g. on the rear of backplanes) and thereby forms a male connector 쮿 Locking levers can be used e.g. to lock terminator boards or I/O connectors in place Order Information Item A4_2449 1 2 2 4 4 Description Housing with M 2.5 nuts, for posts 0.6 × 0.6 × 17 mm, backplane thickness 3.2 mm Housing with M 2.5 nuts, for posts 0.6 × 0.6 × 13 mm, backplane thickness 3.2 mm Housing with M 2.5 nuts, for posts 0.6 × 0.6 × 13 mm, backplane thickness 1.6 mm Locking lever for type R, grey Locking lever for type C, black Qty/PU Part no. 1 29090-001 1 29090-002 1 29001-019 1 1 69001-995 69001-106 Note 쮿 29090-001 is the replacement product for 69001-210 and 29001-015 쮿 29090-002 is the replacement product for 69001-814 and 29001-016 쮿 29001-019 is the replacement product for 69001-311 A3_401 11.6 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Accessories – Connectors Keying/coding pegs for codable female connectors Connectors 쮿 For female connector type H 쮿 Without loss of space 쮿 Max. 70 keying/coding possibilities 쮿 The keying/coding pegs are plugged into the female connector; the corresponding keying/coding fields (situated opposite) of the male connectors are broken out Order Information Description Keying/coding pegs, PBTP, UL 94 V-0 A4-2481 Qty/PU 40 Part no. 21101-252 Keying/coding 쮿 Keying/coding prevents plug-in units becoming mixed up 쮿 Keying/coding for type H – Fixing direct onto plug by means of keying/coding peg in the female connector 쮿 Keying/coding for all types in accordance with EN 60603 (DIN 41612) – Fixing via additional mounting of keying/coding strips Keying/coding pegs Part no. For female connector Part no. 69001-733 21101-252 69001-980 69001-981 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.7 Accessories – Connectors Keying/coding strips Connectors 쮿 For all types in accordance with EN 60603 (DIN 41612) 쮿 Used with plug-in units to prevent mix-up 쮿 Space for plugs with keying/coding strip: – 4 HP for types B, C, D, F, H – 5 HP for types E, G 쮿 66 keying/coding possibilities when two coding pins are used 쮿 924 keying/coding possibilities when six coding pins are used Order Information Item Description Contact strip PBTP, UL 94 V-0, 10 pieces, female strip, PBTP, UL 94 V-0, 10 pieces, 1, 2, 3 keying/coding pins, PBTP, UL 94 V-0, 20 pieces 1, 2, 3 Spacer element for types E, G 3 Keying/coding pin Assembly kit Screw M2.5 × 18, PU 100 pieces Qty/PU Part no. 1 20800-042 20 100 20800-036 20800-078 21100-404 Note A4-2424 쮿 For connectors types E and G spacers are always required PCB strengthening (9 U) 쮿 Protects large PCBs from bending 쮿 Creates an additional crossbar (in accordance with IEEE recommendations, P 896, Nubus, Multibus® II etc.) that links all connectors 쮿 Fixing points match connectors in accordance with EN 60603 (DIN 41612), types B, R, C and D Delivery comprises (kit) LKA42609 Item 1 Qty 1 2 3 6 6 Description PCB strengthening, Al extrusion, anodised, cut edges plain; separator, stainless steel, riveted on Cheesehead screw M 2,5 × 12, St, nickel-plated Washer 2.6, St, nickel-plated Order Information Description For 9 U PCBs Height H mm 361.6 Part no. 20809-441 LKA42593 11.8 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Accessories – Connectors Connectors, 3-pin Connectors 쮿 Used for mains/line voltage supplies 쮿 Male connector with advanced earth protection contact (B) Order Information Item Description Qty/PU 1 2 1 1 69001-651 1 30812-002 3 Male connector Female connector strip Mounting plate for fixing in subrack, socket terminal strip mounts on z-rail (with threaded holes to EN 60603, DIN 41612) Part no. 69001-652 05592043 Technical data Dimensional drawing of multi-pin connector A4-5316 Nominal current per contact Air gap Creepage distance Test voltage Contact resistance Connection Ambient temperature Contact pins, sockets Housing material Flammability Dimensional drawing of socket terminal strip 10 A ≥ 4.4 mm ≥ 7.6 mm 3 kV (eff) approx. 10 mΩ Solder eye connection up to 1 mm 23 °C ... 130 °C galvanically silver-plated Keripol R gray (type 802 as per DIN 16911) UL 94-HB 05009052 3 2 3: Mounting plate 2: Socket terminal strip SCHROFF.PENTAIR.CO.UK A4-5317 A4--2486a Dimension drawing of mounting plate Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.9 Accessories – Horizontal busbars Busbar, 4-pole, for Faston connectors, 6.3 x 0.8 mm Horizontal busbarsMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch within 1 0 worki ng days 쮿 24 connection points (4-poles, 6 connectors each) 쮿 To supply mains voltage to 19" subracks 쮿 Fixing in HP grid increments (spacing 15 HP), external dimension < 17 HP Delivery comprises Item 1 00811001 5 x 10,15 (50,8) Qty 1 Description Busbar, 4-pole (for 6 Faston connectors 6.3 x 0.8 mm Order Information Description Busbar, 4-pole, for Faston connectors, 6.3 x 0.8 mm 3 x 5,08 5,08 10,16 0,8 Technical data 11,6 20 8 6,3 69001-073 21,2 85,8 10,9 4,2 Operating voltage Test voltage: Bar – Bar Test voltage: Pin – Earth Operating current at 20 °C per pin (= 6 connections) Temperature range Material: Faston, busbars Material: insulating body Connector type Connection pitch 75,8 Part no. 69001-073 5 00811050 250 VAC 3.5 kVeff 5.0 kVeff ∑ l ≤ 35 A -40 °C ... +100 °C CuZn, surface tin-plated PC/ABS, UL 94-V0 for Fastons 6.3 × 0.8 mm, 4-pin, 6 Fastons per pin 5.08 × 10.16 mm Note 쮿 Other lengths, 2-pole and 3-pole versions, brass contacts available on request 11.10 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Accessories – Horizontal busbars PCB busbars Main Catalogue 쮿 Power distribution on printed circuit boards and backplanes 쮿 Fault elimination 쮿 Increases the stiffness of PCBs Order Information Width B HP 3 3 4 4 5 5 00892008 Length L mm 220.3 342.3 210.2 332.1 210.2 337.2 Dimension A mm 14 × 15.24 = 213.36 22 × 15.24 = 335.28 10 × 20.32 = 203.2 16 × 20.32 = 325.12 8 × 25.4 = 203.2 13 × 25.4 = 330.2 Part no. 30925-001 30925-002 30925-003 30925-004 30925-005 30925-006 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Technical data Conductor material Pin dimensions Max. operating current DC resistance E-Cu, tin-plated 0.8 x 1.0 mm 30 A 2.5 mΩ/m Note 쮿 Special designs available on request A41743 Solder strip conductor Main Catalogue 쮿 Efficient linking of connections in the same grid and with the same potential 쮿 Also suitable for EN 60603 (DIN 41612) connectors with wire-wrap pin Order Information Connection type A mm Wire-wrap pins 1.14 0.6 × 0.6 mm Wire-wrap pins 1.65 1.0 × 1.0 mm B mm C mm D mm n Qty/PU Part no. 0.9 2.54 2.3 168 1 60800-064 1.4 5.08 3.2 84 1 60800-080 Technical data 00892016 Conductor material Max. operating current wire-wrap pins 0.6 × 0.6 mm Max. operating current wire-wrap pins 1.0 × 1.0 mm E-Cu F30, tin-plated ≤4A ≤4A AZA42390 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.11 Front panel component sys temMain Catalogue Front panel component system Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 05092001 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 05092004 Components are pre-mounted in plastic bodies that can be arranged in rows; horizontal grid (3 planes) and vertical grid (8 or 16 planes) Systems . . . . . . . 8 05092008 A mounting frame with integrated PCB bracket fixes the front elements and forms the mechanical link between PCB, front elements and front panel Front element system in use 05092002 Standards Power supply units . . . . . . . . . . 9 쮿 IEC 60297-3-101 IEC 60603 (DIN 41494 part 8) Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 Appendix . . . . . 12 11.12 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panel component system Overview . . . . . . 11.12 Front panel com ponent system Main Catalogue Operating and display elements for front panels 쮿 Pre-assembled front element components 쮿 Mounting frames with integrated PCB brackets 쮿 Assembled front elements can be soldered in one step 쮿 Subsequent front panel mounting Front panel component system Single LEDs . . . . . . 11.14 Double LEDs . . . . . 11.16 Technical data LEDs . . . . . . . . . . . . 11.17 Test sockets . . . . . 11.18 Make-break socket . . . . . . . . . . . 11.19 Technical data for test and makebreak sockets and fuse holders . . . . . 11.20 LEDs (light-emitting diodes) 05092009 Test and make-break sockets 05092005 Potentiometers . . 11.21 Mounting frames . 11.22 Drilling template . 11.23 Design aids . . . . . . 11.24 Potentiometers Mounting frames with integrated PCB brackets SCHROFF.PENTAIR.CO.UK 05092007 Fuse holders 05092006 05092008 11.13 Front panel component system Single LED, long type, Ø 3.2 mm Front panel component systemMain C ataloguePart number in bold face type: ready for des patch within 2 working daysP art number in normal type: ready for despatch within 10 working days 쮿 Long type for mounting planes 1, 2 and 3 Order Information Description Colour 1 Part no. 2 Part no. 3 Part no. Low current LED Low current LED Low current LED Standard LED Standard LED Standard LED red yellow green red yellow green 69004-240 69004-242 69004-258 69004-262 69004-259 69004-263 69004-241 69004-260 69004-261 69004-059 69004-065 69004-060 69004-066 69004-061 69004-067 69004-062 69004-063 69004-064 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 1, 2, 3 = mounting planes A3-195 쮿 Dimensions of connecting pins: 0.5 × 0.5 mm (mounting plane 1) 0.63 × 0.63 mm (mounting planes 2 and 3) 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.17 Single LED, short type, Ø 3.2 mm Front panel component system 쮿 Short type for mounting plane 1 Order Information Colour Low current LED Part no. Standard LED Part no. red yellow green 69004-264 69004-121 69004-266 69004-123 69004-265 69004-122 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 쮿 Dimensions of connecting pins: 0.5 × 0.5 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.17 1 = mounting plane 11.14 SCHROFF PRODUCT CATALOG E 05/2016 A3-214 ELECTRONICS PROTECTION Front panel component system Single LED, long type, Ø 5 mm Front panel c omponent system 쮿 Long type for mounting plane 1, 2 and 3 Order Information Description Colour 1 Part no. 2 Part no. 3 Part no. Low current LED Low current LED Low current LED Standard LED Standard LED Standard LED red yellow green red yellow green 69004-250 69004-249 69004-251 69004-256 69004-252 69004-257 69004-253 69004-254 69004-255 69004-050 69004-056 69004-051 69004-057 69004-052 69004-058 69004-053 69004-054 69004-055 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 1, 2, 3 = mounting plane SCHROFF.PENTAIR.CO.UK A1-194 쮿 Dimensions of connecting pins: 0.5 × 0.5 mm (mounting plane 1) 0.63 × 0.63 mm (mounting planes 2 and 3) 쮿 Required front panel drill hole: Ø 8 mm 쮿 Technical data see page 11.17 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.15 Front panel component system Double LED, long type, Ø 3.2 mm Front panel component system 쮿 Long type for mounting plane 1 and 2 Order Information 1, 2 = mounting plane A3-196 Description Colour Low current LED Low current LED Low current LED Low current LED Low current LED Low current LED Standard LED Standard LED Standard LED Standard LED Standard LED Standard LED red/red (Y/Z) green/green (Y/Z) yellow/yellow (Y/Z) red/green (Y/Z) red/yellow (Y/Z) yellow/green (Y/Z) red/red (Y/Z) green/green (Y/Z) yellow/yellow (Y/Z) red/green (Y/Z) red/yellow (Y/Z) yellow/green (Y/Z) 1 Part no. 2 Part no. 69004-274 69004-276 69004-275 69004-277 69004-278 69004-279 69004-280 69004-282 69004-281 – 69004-284 – 69004-068 69004-071 69004-069 69004-072 69004-074 69004-075 69004-077 69004-080 69004-078 – 69004-083 – Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 쮿 Dimensions of connecting pins: 0.63 × 0.63 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.17 Double LED, short type, Ø 3.2 mm Front panel component system 쮿 Short type for mounting plane 1 Order Information Colour red/red (Y/Z) yellow/yellow (Y/Z) green/green (Y/Z) red/green (Y/Z) red/yellow (Y/Z) yellow/green (Y/Z) Low current LED Part no. Standard LED Part no. 69004-286 69004-124 69004-288 69004-126 69004-287 69004-289 69004-125 69004-127 69004-290 69004-128 69004-291 69004-129 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 쮿 Dimensions of connecting pins: 0.5 × 0.5 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.17 1 = mounting plane 11.16 SCHROFF PRODUCT CATALOG E 05/2016 A3-217 ELECTRONICS PROTECTION Front panel component system \ Dimensions LEDs A = standard LED B = low current LED Absolute maximum data Ta = 25 °C Reverse voltage V On-state current mA Power dissipation mW Forward current mA (t < 10 μs) Forward voltage V – type (10 mA/2 mA) – max. (10 mA/2 mA) Luminous intensity mcd – at 2 mA – at 10 mA 1) – at 20 mA 1) Wavelength nm (10 mA/2 mA) Thermal resistance °C/W Angle of reflected beam Storage temperature Operating temperature Solder temperature Insulating body Flammability of insulation body A B red, Ø 3.2 mm 5 3 25 30 100 75 100 75 A B red, Ø 5 mm 5 3 25 30 100 75 100 75 A B yellow, Ø 3.2 mm 5 3 25 30 100 75 100 75 A B yellow, Ø 5 mm 5 3 25 30 100 75 100 75 A B green, Ø 3.2 mm 5 3 25 30 100 75 100 75 A B green, Ø 5 mm 5 3 25 30 100 75 100 75 2.1 2.1 2.1 2.1 2.1 2.2 2.1 2.2 2.1 2.2 2.1 2.2 3 – 3 1.5 3 – 3 3.1 3 – 3 1.4 3 – 3 3.2 3 – 3 2 3 – 3 3.3 1.8 3.6 635 13.4 26.8 650 2.2 4.4 635 25.1 48.2 650 2.7 5.4 585 13.4 28.7 585 3.4 6.8 585 28.6 60.8 585 3.2 6.4 565 24.6 54.9 563 3.9 7.8 565 25.7 54.6 563 400 470 350 390 400 470 350 390 400 470 350 390  50° –55 ... +100 °C –55 ... +100 °C (low-current LED)/–40 ... +85 °C (Standard-LED) 260 °C/max. 5 sec (processing advice for wave soldering: protect plastic body against solder wave) PBT (Crastin) UL 94 V-0 1) The low current LEDs can be used from 2 to 20 mA (without reduction of lifespan), which means that a significantly higher luminosity can be achieved. SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.17 Front panel component system Test socket, Ø 2 mm Long type Front panel component system 쮿 Long type for mounting plane 1, 2 and 3 쮿 Short type for mounting plane 1 Order Information For application in Long type Short type 1 Part no. 2 Part no. 3 Part no. 69004-086 69004-087 69004-088 69004-130 – – Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 1, 2, 3 = mounting plane A3-199b 쮿 Dimensions of connecting pins: 0.3 × 0.6 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.20 Short type 1 = mounting plane Note KA943 Double test socket, Ø 2 mm Long type Front panel component system 쮿 Long type for mounting plane 1, 2 and 3 쮿 Short type for mounting plane 1 Order Information For application in Long type Short type 1 Part no. 2 Part no. 3 Part no. 69004-089 69004-090 69004-091 69004-131 – – Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. 1, 2, 3 = mounting plane 05009050 Short type 1 = mounting plane 11.18 SCHROFF PRODUCT CATALOG E 05/2016 Note 쮿 Dimensions of connecting pins: 0.3 × 0.6 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.20 05009051 ELECTRONICS PROTECTION Front panel component system Double make-break socket, Ø 2 mm Front panel c omponent system 쮿 Long type for mounting plane 1 쮿 Gold-plated contacts 쮿 Can also be used as test socket Order Information For application in Long type Part no. 69004-095 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 1 1 = mounting plane SCHROFF.PENTAIR.CO.UK A3-200 쮿 Dimensions of connecting pins: 0.3 × 0.6 mm 쮿 Required front panel drill hole: Ø 4 mm 쮿 Technical data see page 11.20 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.19 Front panel component system Fuse holder Front panel component system 쮿 Long type for mounting plane 1 쮿 For glass fuse inserts 5 x 20 mm to DIN 41 571, 250 VAC, 6.3 A 쮿 Contacts silver-plated Order Information Description Long type Part no. 69004-098 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. A3-200a Note 쮿 Dimensions of connecting pins: 0.7 × 0.6 mm 쮿 Required front panel drill hole: Ø 9 mm \ Technical data for test sockets, fuse holders Test socket/make-break socket Operating voltage Operating current Test voltage Temperature range Solder temperature Contact material Contact surface Insulating body Climatic use category Flammability 1) Double test socket/ Fuse holder double make-break socket ≤ 30 VAC ≤ 250 VAC ≤ 60 VDC/AC ≤1A ≤1A ≤ 6.3 A 1 kV/50 Hz 1 kV/50 Hz – –25 ... +70 °C –25 ... +70 °C –25 ... +70 °C 260 °C/max. 5 sec (processing advice for wave soldering: protect plastic body against solder wave) Copper alloy Copper alloy Copper alloy Selectively gold-plated Selectively gold-plated Silver-plated PBT (Crastin) PBT (Crastin) PBT (Crastin) HSF 1) to DIN 40 040 HSF 1) to DIN 40 040 HSF 1) to DIN 40 040 UL 94 V-0 UL 94 V-0 UL 94 V-0 H = –25 °C; S = +70 °C; F = 75 % air humidity, no condensation 11.20 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Front panel component system Cermet potentiometers Front panel c omponent system 쮿 Short type for mounting plane 1 Order Information Resistance kΩ 1 5 20 100 Part no. 69004-169 69004-165 69004-161 69004-155 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Technical data A3-275 Pins 1 and 2 low-ohmic when left-hinged; pins 2 and 3 low-ohmic when right-hinged Operating voltage Operating current Load capacity Test voltage Resistance tolerance Electrical rotation angle Insulation resistance change Contact resistance change Torque at initial turning Storage temperature Operating temperature Service life (full rotation) Service life at 0.5 Watt load Solder temperature Insulating body Flammability Resistance of gasket to cleaning Temperature coefficient ≤ 200 VDC/ AC ≤ 100 mA 0.5 Watt at Ta = 70 °C 500 V/50 Hz  10 % 230°  5° 100 MΩ 3 Ω or 3 %, use largest value 0.021 Nm –55 ... +125 °C –25 ... +70 °C 200 cycles 1000 h at Ta = 70 °C 260 °C/max. 5 sec (processing advice for wave soldering: protect plastic body against solder wave) PBT (Crastin) UL 94 V-0 85 °C max. 1 min.  100 ppm/K Note 쮿 쮿 쮿 쮿 SCHROFF.PENTAIR.CO.UK Dimensions of connecting pins: 0.45 × 0.45 mm Required front panel drill hole: Ø 8 mm When left-hinged: pins 1 and 2 low-ohmic When right-hinged: pins 2 and 3 low-ohmic Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.21 Accessories Front panel component system Mounting frames with PCB bracket for mounting planes Front panel component system 쮿 With 2 threaded female connectors M 2.5 쮿 Material PBT 쮿 Flammability UL 94 V-0 Order Information Description Mounting frame for mounting plane 1 Mounting frame for mounting planes 1 and 2 Mounting frame for mounting planes 1, 2 and 3 Mounting frame for mounting plane 1 KA942a Part no. 69004-043 69004-044 69004-045 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Note 쮿 Mounting frames nos. 69004-043, 69004-044 and 69004-045 cannot be used in conjunction with the aluminium profile handle for front panels Mounting frame for mounting planes 1 and 2 Mounting frame for mounting planes 1, 2 and 3 11.22 SCHROFF PRODUCT CATALOG E 05/2016 KA942b KA942c ELECTRONICS PROTECTION Accessories Front panel component system Mounting frame with PCB bracket for frame type plug-in units Front panel c omponent system 쮿 With 2 grub screws for fixing on PCBs 쮿 Board thickness max. 1.6 mm 쮿 Drilled hole for fixing board max. 2.8 mm Order Information Description Support frame with board support for frame type plug-in units Part no. 69004-046 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. Mounting frame for mounting plane 1 KA942d Drilling template Front panel c omponent system 쮿 Design aid for processing of front panels Order Information Description Drilling template Material EPGC 02 (fibreglass reinforced Epoxy) Part no. 69004-042 Delivery is exclusively in Standard Pack Quantity (SPQ): Please order at least 10 pieces or a multiple. Pricing is per individual item. A4_276 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.23 Accessories Front panel component system Design aids Conmponent side of PCB Front of front panel 1) 2) 3) 2) 1) 2) PCB Component mounting limit FEA45510 3) Front panel FEA45511 Placement example E1 = first mounting plane E2 = second mounting plane E3 = third mounting plane 11.24 SCHROFF PRODUCT CATALOG E 05/2016 ELA40278 ELECTRONICS PROTECTION Accessories Front panel component system Design aids PCB tracks View solder side Short type LED, Ø 3.2 mm View solder side Long type LED, Ø 3.2 mm Double LED, Ø 3.2 mm A4_277a A4_277b Test socket, Ø 2 mm Double test socket, Ø 2 mm A3_215a Double LED, Ø 3.2 mm A3_205a A3_205b LED, Ø 5 mm A3_215b Test socket, Ø 2 mm A4_272 A3_205c Double test socket, Ø 2 mm Potentiometer FEA45990 Make/break socket, Ø 2 mm A4_273 A2_114a Double make-break socket, Ø 2 mm Fuse holder A2_114b Dimensions of connecting pins 0.5 × 0.5 mm 0.63 × 0.63 mm 0.3 × 0.6 mm 0.7 × 0.6 mm 0.4 × 0.6 mm 0.45 × 0.45 mm Text A2_114d Recommended hole Ø 1.0 mm  0.05 1.1 mm  0.05 0.9 mm  0.05 1.1 mm  0.05 0.9 mm  0.05 0.7 mm  0.05 Solder eyes Ø 2.1 mm  0.1 2.2 mm  0.2 2.0 mm  0.2 2.1 mm  0.2 2.0 mm  0.2 1.8 mm  0.2 PCB tracks width min. 0.6 mm Grid 2.54 mm SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 11.25 Appendix 30403001 Quality - Environment - Safety StandardsMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days Continously improving our processes and therefore the quality of the Schroff products - that is the subject of the QES (Quality Environment - Safety) management system. In order to achieve these targets, a strategy has been developed which includes all departments of the company. This integral QES management system is documented in a manual and validated through audits and systematically coordinated inspections. Above all, the system is based on the motivation of the entire workforce which is promoted through exemplary working conditions and efficient training activities. 30403050 For you, the total of all these activities provides: highest quality and reliability - worldwide. All Schroff and Pentair Equipment Protection production sites are accredited in accordance with DIN EN ISO 9001:2008. The environmental management system of Schroff GmbH Germany, Schroff SAS France as well as Schroff UK Ltd. in Great Britain are additionally accredited in accordance with DIN EN ISO 14001:2004. Besides this, the security management system of Schroff GmbH is accredited in accordance with BS OSHAS 18001:2007. Dynamic processes in all batch sizes 20398001 12.0 SCHROFF PRODUCT CATALOG E 05/2016 This necessitates an ingenious production system. Schroff consciously places its trust in personal commitment. "Cellular" production is integrated into the Schroff production process. Highly-competent and responsible employees work in small, clearly defined production cells. ELECTRONICS PROTECTION Appendix Experience – to the benefit of the customer Certifications Underwriters Laboratories  Self-extinguishing plastics  Type of protection NEMA 12 30402052 European Organisation for Nuclear Research  europacPRO subracks approved to CERN Spec No. 385 CERN_5C Railway applications  DB europacPRO for railway applications, approved for electronic equipment in rolling stock (BN 411003)  SNCF (Société Nationale des Chemins de Fer) There are many levels to Schroff's commitment which then lead to this "additional" benefit. For example, continuous dialogue with customers and suppliers throughout the world is integrated into design and production. Our involvement in international standardisation committees also ensures the up-to-date nature of the product standards or influences these in advance. Added to this there is the experience of Schroff's Electronics division. This is where power supplies, backplanes and modular microcomputer systems are produced. We know what installing electronics means. We make use of this experience throughout the entire company. This is why all of the necessary tests are genuinely carried out under practical conditions. For you as customer, this means: Safety, reduced test times and therefore lower costs. Quality also means dialogue Dialogue with you, because our responsibility for quality is comprehensive and does not stop at the loading ramp. You measure the value of our products. So please let us know if you are not satisfied with our services or products. Of course, we would also be pleased to hear from you if you are satisfied. An excerpt from the manual "Quality-environment-safety management system": The Schroff team's goal is to contribute towards the success of its customers with top products and service. All Schroff employees are responsible for the continuous improvement of the products and services. National and international standardisation institutions ANSI/EIA TÜV Product Service  19” blower units  19” fans BSI CENELEC CSA DIN DKE 30406050 Institute of German Electronics Engineers  Protective GND/earthing connections  Socket strips ECL EEMAC ETSI IEC LOGOVDE IEEE European Union EMC guideline 89/336/EWG  VMEbus plug-in units  Power supplies 30402051 NEMA NFPA UL VITA (VMEbus International Trade Association) PICMG (PCI Industrial Computer Manufacturers Group)  Systems  Backplanes SCHROFF.PENTAIR.CO.UK USA GB EU CAN D D GB CAN EU Int. USA USA CAN USA American National Standards Institute/ Electronic Industry Association British Standards Association European Committee for Electrotechnical Standardization Canadian Standards Association Deutsches Institut für Normung e.V. (German Standards Institute) German Electrical Engineering Committee in DIN and VDE British Standards Institution Technical Subcommittee Electrical/Electronic Manufacturers Association of Canada European Telecommunications Standardisations Institute International Electrotechnical Commission Institute of Electrical and Electronics Engineers National Electrical Manufacturers Association Electrical/Electronic Manufacturers Association of Canada Underwriters Laboratories Inc. VDE D Institute of German Electronics Engineers VDI D Association of German Engineers Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.1 Normen Appendix – Standards Mechanical design StandardsMain C ataloguePart number in bold face type: ready for despatch within 2 worki ng days Part number in norm al type: ready for despatc h within 10 w orking days 20303001 12.2 SCHROFF PRODUCT CATALOG E 05/2016 19" system 25 mm system Cabinets Cases IEC 60297-3-100 IEC 60917-2-1 Subracks System enclosures IEC 60297-3-100 IEC 60297-3-101 IEC 60297-3-102 IEC 60297-3-103 IEC 60297-3-104 IEEE 1101.1 IEEE 1101.10 IEEE 1101.11 IEC 60917-2-2 19" chassis IEC 60297-3-105 - Plug-in units Frame type plug-in units IEC 60297-3-101 IEC 60297-3-102 IEC 60297-3-103 IEC 60297-3-104 IEEE 1101.1 IEEE 1101.10 IEEE 1101.11 IEC 60917-2-2 PCBs IEC 60297-3-101 IEC 60297-3-104 IEEE 1101.1 IEC 60097 Connectors IEC 60603-2 IEC 61076-4-101 IEC 61076-4-100 Front elements DIN 41494 part 8 - Backplanes IEC 60297-3-101 IEC 60297-3-104 IEEE 1101.1 IEEE 1101.11 IEC 60917-2-2 ELECTRONICS PROTECTION Appendix – Standards Shock and vibration test DIN IEC 61587-1 EN 60068-2-6 (vibration, sinusoidal) EN 60068-2-27 (shock) Text These tests simulate conditions which devices must fulfil as minimum requirement during operation and transportation. Tests with 3, 6 and 9 U dummies provided valuable experiences that have been integrated into the design of the Schroff subracks. For extreme strains – such as e.g. during mobile use in rolling stock – a separate product family "europac PRO for railway applications" has been developed and confirmed by approval testing to the German Railway Standards BN 411 002 and BN 411 003 and French Railway Standards NF F 61-005/NF F 60-002 as well as EN 50155. Similar test conditions and degrees of severity for vibration and shock stability are contained in IEC 61587-1. Varistar cabinets have been designed with high physical stresses in mind. Of particular importance in this respect is the bending stiffness of the frame. The specially developed hollow-chamber profile achieves the DL5 and DL6 requirement classes for static and dynamic loads, and thus also the highest shock and vibration resistance to IEC 61587-1, with minimal cost of material. DIN IEC 61587-2 In dynamic tests for stability under earthquake conditions, the Varistar Heavy-Duty cabinet proved its suitability for worldwide use. The seismic tests, carried out under IEC 61587-2, certify the cabinet platform's earthquake resistance up to Bellcore Zone 3. By further reinforcing the cabinet frame with small corner brackets, earthquake resistance is assured up to Bellcore Zone 4. 06109002 SCHROFF.PENTAIR.CO.UK 01008018 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.3 Appendix – Standards IP degrees of protection Types of protection (IP code): IEC 60529 DIN VDE 0470 part 1 The degrees of protection of this standard define the  Protection of persons against hazardous parts in the enclosure  Protection against access of foreign bodies  Protection against ingress of water Protection against contact and access IP 1st digit Contact 0 no protection Protection against water IP 2nd digit Foreign body no protection Ø 1 with large parts of the body (back of the hand) 0 no protection 1 vertically falling drops of water Main CatalogueP art number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days >50 large foreign bodies, diameter greater than or equal to 50 mm NOA44107 Ø 2 with the finger NOA44099 >12,5 medium-size foreign bodies, diameter greater than or equal to 12 mm 2 slantwise falling drops of water up to 15° against the vertical NOA44108 NOA44100 Ø >2,5 3 with tools and wires, diameter greater than or equal to 2.5 mm small foreign bodies, diameter greater than or equal to 2.5 mm 3 spraying water up to 60° angle against the vertical NOA44109 4 with tools and wires, diameter greater than or equal to 1 mm grain-shaped foreign bodies, diameter greater than or equal to 1 mm NOA44101 4 splash water from all sides NOA44102 NOA44110 5 complete protection dust deposit 5 jets of water NOA44103 NOA44111 6 complete protection ingress of dust 6 powerful jets of water NOA44104 Example: IP 21 2 1 7 partial immersion The first digit means Contact protection with the finger and foreign bodies larger than 12.5 mm in diameter. The second digit means The device is protected against vertically falling drops of water. NOA44105 8 total immersion NOA44106 12.4 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Appendix – Standards Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Flammability of plastics  Standardised test processes  Classification in accordance with UL 94 Note The specification of the UL listing of plastics on the order pages refers to the material used and not to the product Criteria UL 94 HB  Burn distance  102 mm  Flame spread rate  38.1 mm with 3.2 mm thick sample body  76.2 mm with 1.6 mm thick sample body ASTM D 635 Test structure  Sample body horizontal  Bunsen burner flame at the free end  Flame height 25 mm  Ignition flame 30 s, partially FPCS burner position  3 sample bodies 127  12.7  3.2 (1.6) mm UL94A UL 94-5 V  Afterflame time  60 s  No droplets UL 94: Test process 94-5 V  Sample body vertical  Bunsen burner flame at lower edge/corner  Flame height 127 mm  Inner flame cone 38 mm, touches lower edge/corner  5  5 s flame application, pause every 5 s  2 sets each containing 5 sample bodies 127  12.7  (application thickness) mm UL94B UL 94 V-0  Burning time 10 s  Total burning time 50 s  No flaming droplets DIN VDE 0304 part 3 Process FV UL 94 V-1  Burning time 30 s  Total burning time  250 s  No flaming droplets UL94C  Sample body vertical  Bunsen burner flame at the free end  Flame height 20  2 mm  Ignition flame 10 s, after extinguishing of sample, a further 10 s  10 sample bodies 125  13  31) mm 1) If necessary, also 0.8, 1.6, 6.0 and 6.4 mm UL 94 V-2  Burning time  30 s  Total burning time  250 s  Flaming droplets 1) Bunsen burner Sample body 3) Measurement mark 4) Wire screen 2) SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.5 Appendix – Standards Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days  Protective GND/earthing connection from the frame to the covers  Central connection with IEC 320 connector Protective GND/earthing connection Measures to protect persons against contact with dangerous voltages. NOA44075 NOA44184  Rear front panel chromated for surface contact to the enclosure  ESD spring in guide rail 2 1 ESD Electrostatic discharge – measures to deflect electrostatic discharge in order to protect electronics against interference impulses and the destruction of components. ESD or electrostatic discharge describes the appearance form of the discharge of static electricity. The human being is electrically discharged onto an earthed point. NOA44069 Under unfavourable conditions, human beings may carry a charge of up 20 kV. This voltage is discharged with a very rapid impulse. 20309050 EMV/EMC  Contact strip between frame and top cover  Contact strip between plug-in units The abbreviation of the definitions EMV / EMC stands for Elektromagnetische Verträglichkeit or electromagnetic compatibility. These are defined as follows: Electromagnetic compatibility is the ability of a piece of electrical equipment to function in a satisfactory manner in its NOA44073 electromagnetic environment, without influencing this environment, to which other pieces of equipment may also belong, more than is permissible. NOA44183 EMP The generic term EMP or electromagnetic pulse incorporates three different forms of electromagnetic pulses. These include:  LEMP: lightning electromagnetic pulse (e.g. lightning strike)  SEMP: switching electromagnetic pulse (e.g. switching processes in electrical energy systems)  NEMP: nuclear electromagnetic pulse (nuclear explosion) 12.6 SCHROFF PRODUCT CATALOG E 05/2016 ELECTRONICS PROTECTION Appendix – Standards The CE symbol All electrical and electronic devices or systems marketed in the EU after 01.01.1996 must display the CE symbol. 30402051 However, the CE symbol is not a form of special EMC certification. It encompasses different standards for various products. With the CE symbol, the manufacturer or importer confirms the conformity of his products to the EU standard. However, responsibility for the declaration of conformity is borne by the manufacturer or importer, unlike, for example, in the case of the TÜV or GS symbol, where conformity is tested by a responsible body. The owner must therefore ensure that his device displays the CE symbol, and is only allowed to use this device in the specified environment, e.g. in industrial or domestic applications. Important The affixation of the CE symbol is the personal responsibility of each manufacturer. It is not assigned by an official body. The CE symbol only provides the consumer with indirect protection; it is predominantly affixed to the product for the official body monitoring the market. Liability and responsibility In the field of electromagnetic compatibility, the manufacturer certifies that his product is in accordance with the European EMC standard by affixing the CE symbol. The guidelines are monitored by the (German) Federal Office of Postal and Telecommunication Services (BAPT). Adherence to the protection requirements is checked by random sampling. In the event of non-adherence, the product may be withdrawn from the market and a high fine imposed. In addition to the EMC standard, the product liability legislation also applies in this case. Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days Shielded products (EMC) Systems and devices which are used in Europe must adhere to the EMC standard regarding interference emission and interference resistance. In case the pre-specified limit values are exceeded, a remedy may be provided by a shielded case. In this case, various measures are available for reducing interference emission or for improving interference resistance. However, attention must also be paid to the special insertion of cables and wires into the case. Otherwise, the suppression characteristics of the enclosure cannot be guaranteed. When testing a device or system with regard to electromagnetic compatibility, the interconnection between various standards must be taken into consideration. The basis of the EMC measurement is the Product Standard. If this does not exist, the valid Generic Standard must be applied. Also to be considered for EMC measurements is the Basic Standard, to which reference is made in the individual Product and Generic Standards. Shielded cases Basically, no EMC standards apply to "empty" electronics enclosures, because only if corresponding electrical devices have been installed can the overall system emit electromagnetic interference or be influenced by external emissions. Schroff system solutions Schroff enclosure systems are manufactured entirely from metal, and basically have good EMC characteristics. The conductivity of surfaces in EMC shielded enclosures is additionally ensured by galvanic coating. The individual components are contacted via a EMC gaskets, such as, for example, stainless steel springs, and large surface conductive connections of the individual components. When designing shielded enclosures, special requirements are also made on cable ducting and ventilation. An complete shielded system can only be assessed if these two parameters are taken into account. Shielding and measurement procedures Shielding specifies the rate by which the intensity of electromagnetic radiation is reduced on passage through an enclosure. This is specified in the logarithmic measuring unit dB. Shielding measurements for Schroff enclosures are carried out by an independent institute. Shielding is measured in accordance with the measurement procedure VG 95373, part 15 (German defence standard). This procedure is currently being transformed into a civilian standard. An additional measurement procedure to MIL-STD 285 (American military standard) also exists. This procedure was principally developed for measuring material shielding, therefore it is only suitable to a limited degree for measuring electronics enclosures, such as cabinets, cases and subracks. SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.7 Abkürzungen Abkürzungen allgemein allgemein Appendix – Abbreviations A ABS AC Acryl(-glas) AD ADC Al AlZn ANSI AT AdvancedTCA Be BN BS(I) °C Ampere, electric current Acrylonitrile-butadiene-styrene Alternating current (single phase current) Plastic (glass) Address data bus Automatic daisy chaining Aluminium Aluminium zinc alloy for finishes American National Standards Institute PC backplane AT standard Advanced Telecom Computing Architecture Beryllium (German) Federal Railway Standard British Standards (Institution) Degree Celsius (= 1/1.8 × [°F-32] = K – 273.15 °C) C 15 Steel CE Conformité Européenne, corresponds to EU guidelines CENELEC European Committee for Electrotechnical Standardisation CERN European Organisation for Nuclear Research cfm Cubic feet per minute (airflow capacity) Ck 75 Steel CSA Canadian Standards Association CTI Comparative figure for creepage formation in insulating materials Cu Copper CuBe Copper-beryllium CuSn Bronze CuZn Brass D, d Depth DB Deutsche Bahn AG dB(A) Decibels, volume level DC Direct current DIL Dual-in-line DIN Deutsche Industrie Norm (German industry standard) DKE Deutsche Eletrotechnische Kommission im DIN und VDE (German electrotechnical commission) ECL British Standards Institution Technical Subcommittee E-Cu Electrolytic copper EEMAC Electrical/Electronic Manufacturers Association of Canada Earthing contact Socket/plug with protection contact; standard in D, NL, S, P, A, N, SF, E, TR, GR, L EIA Electronic Industry Association EMC (EMV) Electromagnetic compatibility EMP Electromagnetic pulse EMI Electromagnetic interference EN European standard EPGC Fiberglass reinforced epoxy Epgl. Epoxy-fiberglass mat ESD Electrostatic discharge ESG Tempered, single-glass pane to EN 12150 12.8 SCHROFF PRODUCT CATALOG E 05/2016 ETS(I) European Telecommunications Standards (Institute) EU Filter classes to DIN 24 185, part 100 F Degree Fahrenheit (= 1.8 × °C + 32) FI Fault current FKD Lower/upper limit temperature and moisture to DIN 40 040 FPCS Front panel component system FR Flammability rating (to NEMA) G10Fr4 Fiberglass, fire-resistant GD-Zn Zinc die-cast GND Ground/earthing GS Approved safety h Hour H, h Height H2S Hydrogen sulphide HF HF/high-frequency HP = TE = unit of division (1 HP = 5.08 mm) HPL High Pressure Laminate (melamine resin-coated laminated sheet) HSF Lower/upper limit temperature and moisture to DIN 40 037 Hz Hertz, frequency of the alternating voltage IC Integrated Circuit IEC International Electrotechnical Commission IEEE Institute of Electrical and Electronic Engineers Inch Linear measure, 1" = 25.4 mm IP Ingress Protection ISA Industrial Standard Architecture (industrial standard for PCs) ISO International Standards Organisation J1 VME system bus, 3 U, top J1/J2 VME system bus, 6 U, Monolithic J2 VME system bus, 6 U, bottom K Kelvin (= °C + 273,15 °C) LBX Local bus extension for Multibus® II LED Light emitting diode lfm Linear foot per minute; airflow 1 lfm = 304.8 mm/min = 5.08 mm/s = 0.00508 m/s LGA Bavarian regional trade office M Metric thread m3/h Airflow volume MBLT Multiplexed block transfer in the VMEbus for increasing the transmission rate mcd Millicandela MDC Manual daisy chaining with jumper for VME/VXIbus mep Metric equipment practice MHz Megahertz (frequency) mm Millimeter Monolithic J1/J2 backplane, 6 U mp1, mp2, mp3 Measuring units in metric system, 1 mp1 = 25 mm, 1 mp2 = 5 mm, 1 mp3 = 2.5 mm ms Millisecond MTBF Mean time between failure AbbreviationsMain CataloguePart number i n bold face type: ready for despatch within 2 working daysPart num ber in normal type: ready for despatch withi n 1 0 worki ng days ELECTRONICS PROTECTION Appendix – Abbreviations n N NEMA NF NFPA NTC OVP PA Pa Pb PBT (P) PC PCI PE PG PICMG Pin PMC PMMA POM PP PPE ppm PPO PS PSB PTC PU PU(R) Pv PVC RAL RAL 7016 RAL 7021 RAL 7030 RAL 7032 RAL 7035 RAL 9005 RAL 9006 Sekurit(-glas) ServicePLUS SEV SI SIPS Slot SMD SNCF SNMP Sn SO2 SPQ St SU SW Speed (rpm) Newton National Electrical Manufacturers Association Norme Française (French standard) Electrical/Electronics Manufacturers Association of Canada Negative temperature coefficient Over-voltage protection Polyamide Pascal Lead Polybutylen terephthalat Personal computer or polycarbonate Periphery component interface Polyethylene Steel conduit thread PCI Industrial Computers Manufacturers Group (www.PICMG.com) Connection, contact PCI Mezzanine Card Polymethyl methacrylat Polyoxymethylene Polypropylene Polyphenylene ether Parts per million Polyphenyl oxide, corresponds to PPE Polystyrene Parallel system bus for Multibus® II Positive temperature coefficient Packaging unit Polyurethane Installed energy loss Polyvinyl chloride Colour standard Anthracite grey Black grey Stone grey Pebble grey Light grey Black White aluminum Safety glass SCHROFF rapid assembly service Association of Swiss electrical engineers Overcurrent Standard industrial PC system Plug-in position for board Surface mounted device Société Nationale des Chemins de Fer Simple network management protocol Tin Sulphur dioxide Standard pack quantity Steel System unit (1 SU = 25 mm) Wrench size across flats SCHROFF.PENTAIR.CO.UK Ta/Tu TSG-PS TTL TÜV U UL Ambient temperature Thermoplastic structure foaming, polystyrene Transistor-transistor logic German technical supervisory association = HE = height unit (1 U = 44.45 mm) Underwriters Laboratories Inc. (USA safety regulations) American fire protection standard Safety of information technology appliances including electrical office equipment Unified National Coarse (inch thread) Union technique de l’électricité, here: socket/ socket strip type for France and Belgium Airflow capacity Volt, voltage Volt-ampere, power consumption, (apparent power) Institute of German electronics engineers Verein Deutscher Ingenieure e.V. Defence equipment (standard) VMEbus International Trade Association (www.vita.com) Versa Module Europe, system bus VME subsystem bus Peak-peak voltage VMEbus extension for instrumentation Stainless steel Watt, power output Width Pre-galvanised steel plate with special surface treatment Zinc Zinc-leaded alloy Abbrevi ationsMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days UL 94 ... UL 60950-1 UNC UTE V° V VA VDE VDI VG Standard VITA VMEbus VSB Vss VXI V2A W W, w Zincor Zn ZnPb Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.9 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 1.356 10130-025 1.127 10130-069 1.127 10130-113 1.129 10130-157 1.131 10117-527 1.277 10130-026 1.127 10130-070 1.127 10130-114 1.129 10130-158 1.131 10117-528 1.277 10130-027 1.127 10130-071 1.127 10130-115 1.129 10130-159 1.131 10117-529 1.277 10130-028 1.127 10130-072 1.129 10130-116 1.129 10130-160 1.131 10117-530 1.277 10130-029 1.127 10130-073 1.129 10130-117 1.129 10130-161 1.131 10117-531 1.277 10130-030 1.127 10130-074 1.129 10130-118 1.129 10130-162 1.131 10117-532 1.277 10130-031 1.127 10130-075 1.129 10130-119 1.129 10130-163 1.131 10117-533 1.276 10130-032 1.127 10130-076 1.129 10130-120 1.131 10130-164 1.131 10117-534 1.276 10130-033 1.127 10130-077 1.129 10130-121 1.131 10130-165 1.131 10117-535 1.276 10130-034 1.127 10130-078 1.129 10130-122 1.131 10130-166 1.131 10117-536 1.276 10130-035 1.127 10130-079 1.129 10130-123 1.131 10130-167 1.131 10117-537 1.276 10130-036 1.127 10130-080 1.129 10130-124 1.131 10130-168 1.131 10117-538 1.276 10130-037 1.127 10130-081 1.129 10130-125 1.131 10130-169 1.131 10117-539 1.276 10130-038 1.127 10130-082 1.129 10130-126 1.131 10130-170 1.131 10117-540 1.276 10130-039 1.127 10130-083 1.129 10130-127 1.131 10130-171 1.131 10117-541 1.277 10130-040 1.127 10130-084 1.129 10130-128 1.131 10130-172 1.131 10117-542 1.277 10130-041 1.127 10130-085 1.129 10130-129 1.131 10130-173 1.131 10117-543 1.277 10130-042 1.127 10130-086 1.129 10130-130 1.131 10130-174 1.131 10117-544 1.277 10130-043 1.127 10130-087 1.129 10130-131 1.131 10130-175 1.131 10117-545 1.277 10130-044 1.127 10130-088 1.129 10130-132 1.131 10130-176 1.131 10117-546 1.277 10130-045 1.127 10130-089 1.129 10130-133 1.131 10130-177 1.131 10117-547 1.277 10130-046 1.127 10130-090 1.129 10130-134 1.131 10130-178 1.131 10117-548 1.277 10130-047 1.127 10130-091 1.129 10130-135 1.131 10130-179 1.131 10125-010 1.348 10130-048 1.127 10130-092 1.129 10130-136 1.131 10130-180 1.131 10125-011 1.348 10130-049 1.127 10130-093 1.129 10130-137 1.131 10130-181 1.131 10130-001 1.12 10130-050 1.127 10130-094 1.129 10130-138 1.131 10130-182 1.131 10130-002 1.12 10130-051 1.127 10130-095 1.129 10130-139 1.131 10130-183 1.131 10130-003 1.12 10130-052 1.127 10130-096 1.129 10130-140 1.131 10130-184 1.131 10130-004 1.12 10130-053 1.127 10130-097 1.129 10130-141 1.131 10130-185 1.131 10130-005 1.13 10130-054 1.127 10130-098 1.129 10130-142 1.131 10130-186 1.131 10130-006 1.13 10130-055 1.127 10130-099 1.129 10130-143 1.131 10130-187 1.131 1.13 10130-056 1.127 10130-100 1.129 10130-144 1.131 10130-188 1.86 10130-008 1.13 10130-057 1.127 10130-101 1.129 10130-145 1.131 10130-189 1.86 10130-012 1.228 10130-058 1.127 10130-102 1.129 10130-146 1.131 10130-190 1.57 10130-013 1.229 10130-059 1.127 10130-103 1.129 10130-147 1.131 10130-191 1.58 10130-014 1.230 10130-060 1.127 10130-104 1.129 10130-148 1.131 10130-192 1.56 10130-016 1.228 10130-061 1.127 10130-105 1.129 10130-149 1.131 10130-193 1.238 10130-017 1.229 10130-062 1.127 10130-106 1.129 10130-150 1.131 10130-194 1.238 10130-018 1.230 10130-063 1.127 10130-107 1.129 10130-151 1.131 10130-195 1.87 10130-020 1.56 10130-064 1.127 10130-108 1.129 10130-152 1.131 10130-198 1.122 10130-021 1.14 10130-065 1.127 10130-109 1.129 10130-153 1.131 10130-199 1.232 10130-022 1.14 10130-066 1.127 10130-110 1.129 10130-154 1.131 10130-200 1.232 10130-023 1.86 10130-067 1.127 10130-111 1.129 10130-155 1.131 10130-201 1.122 10130-024 1.127 10130-068 1.127 10130-112 1.129 10130-156 1.131 10149-305 1.326 10117-498 10130-007 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.11 Appendix Part no. Page Part no. Part no. Page Part no. 10149-306 1.326 10501-005 10149-308 1.326 10501-005 3.3 10603-001 5.107 10713-532 4.11 11098-416 8.51 5.109 10603-001 5.117 10713-534 4.10 11098-416 9.18 10149-313 1.327 10501-005 6.25 10603-001 5.72 10713-536 4.10 11098-438 8.38 10149-315 1.327 10501-006 3.3 10603-001 5.87 10713-537 4.10 11098-438 8.39 10149-316 1.327 10501-006 5.109 10603-002 5.107 10713-546 4.12 11098-438 8.52 10225-601 5.102 10501-007 3.3 10603-002 5.117 10713-547 4.12 11098-438 9.19 10225-602 5.102 10501-007 5.109 10603-002 5.72 10822-009 3.13 11249-003 1.322 10225-604 5.103 10501-008 3.3 10603-002 5.87 10822-009 3.46 11249-005 1.322 10225-612 5.102 10501-008 5.109 10603-023 5.116 10828-051 6.130 11249-007 1.323 10225-613 5.102 10501-008 6.25 10603-024 5.116 10828-052 6.130 11249-009 1.323 10225-615 5.103 10501-016 5.109 10603-025 5.116 10828-053 6.130 11249-012 1.323 10225-616 5.103 10501-018 5.109 10603-026 5.116 10828-054 6.130 11249-016 1.324 10225-618 5.103 10501-018 6.25 10713-098 4.8 10828-056 6.130 1130-583 1.204 10225-623 5.102 10501-025 3.3 10713-099 4.8 10828-057 6.130 11592-500 8.9 10225-624 5.102 10501-025 5.109 10713-100 4.6 10828-058 6.130 11592-503 8.9 10225-626 5.103 10501-026 3.3 10713-102 4.6 10828-059 6.130 11596-088 8.4 10225-627 5.103 10501-026 5.109 10713-103 4.6 10828-068 6.130 11596-090 8.5 10225-629 5.103 10501-026 6.25 10713-104 4.6 10828-069 6.130 11596-107 8.5 10225-637 5.103 10501-027 3.3 10713-106 4.6 10828-071 6.130 11596-160 8.6 10225-638 5.103 10501-027 5.109 10713-107 4.6 10828-072 6.130 11596-161 8.6 10225-640 5.103 10501-028 3.3 10713-108 4.7 10828-073 6.130 11596-300 8.7 10225-667 5.104 10501-028 5.109 10713-110 4.7 10836-045 8.102 11596-303 8.7 10225-670 5.104 10501-029 3.3 10713-111 4.7 10836-050 8.101 11850-011 8.43 10225-682 5.104 10501-029 5.109 10713-112 4.7 10836-060 8.103 11850-013 8.47 10225-685 5.104 10501-029 6.25 10713-114 4.7 10849-001 8.28 11850-017 8.42 10225-693 5.104 10501-116 3.3 10713-115 4.7 10849-002 8.29 11850-018 8.44 10225-696 5.104 10501-116 5.109 10713-140 4.15 10849-005 8.45 11850-020 8.40 10236-151 2.26 10502-050 5.110 10713-141 4.15 10849-009 8.32 11850-021 8.38 10236-152 2.26 10502-057 3.3 10713-142 4.15 10849-011 8.33 11890-035 8.39 10236-156 2.26 10502-057 5.110 10713-143 4.15 11000-001 9.17 11990-100 8.10 10236-157 2.26 10502-057 6.25 10713-144 4.15 11000-002 6.91 11990-101 8.10 10236-160 2.26 10502-059 3.3 10713-145 4.15 11000-002 7.96 11990-600 8.8 10236-161 2.26 10502-059 5.110 10713-146 4.15 11000-002 9.17 11990-601 8.8 10236-162 2.26 10502-060 6.25 10713-147 4.15 11098-140 9.21 11990-603 8.8 10236-165 2.26 10502-063 3.3 10713-148 4.15 11098-207 9.25 12349-001 1.318 10236-166 2.26 10502-063 5.110 10713-149 4.15 11098-212 9.25 12349-002 1.318 10238-151 2.32 10502-065 3.3 10713-150 4.15 11098-231 9.21 12349-003 1.318 10238-152 2.32 10502-065 5.110 10713-151 4.15 11098-266 9.21 12349-004 1.318 10238-153 2.32 10502-065 6.25 10713-518 4.10 11098-267 9.21 12349-005 1.320 10501-001 5.108 10502-296 5.112 10713-520 4.10 11098-316 9.24 12349-006 1.320 10501-002 5.108 10502-297 5.112 10713-526 4.10 11098-392 8.40 12349-007 1.320 10501-003 5.108 10504-002 5.111 10713-528 4.10 11098-392 8.51 12349-008 1.320 10501-004 3.3 10504-003 5.111 10713-529 4.10 11098-392 9.18 12349-009 1.318 10501-004 5.109 10505-014 5.113 10713-530 4.11 11098-416 8.40 12349-010 1.318 12.12 SCHROFF Main catalogue Page www.schroff.biz E 05/2016 Page Part no. Page ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 12349-011 1.318 12505-023 2.10 12506-169 2.5 13100-152 9.6 14575-123 5.79 12349-012 1.318 12505-024 2.10 12506-170 2.5 13100-153 9.6 14575-125 5.79 12403-150 2.23 12505-025 2.10 12506-171 2.5 13100-203 9.20 14575-127 5.79 12403-151 2.23 12505-028 2.10 12506-172 2.5 13100-204 9.20 14575-134 5.78 12403-152 2.23 12505-029 2.10 12506-173 2.5 13100-205 9.20 14575-135 5.78 12403-153 2.23 12505-032 2.10 12506-174 2.5 13103-002 9.13 14575-136 5.78 12403-154 2.23 12505-071 2.11 12506-175 2.5 13103-003 9.13 14575-143 5.79 12403-155 2.23 12505-073 2.11 12506-176 2.5 13103-004 9.13 14575-145 5.79 12403-156 2.23 12505-074 2.11 12506-177 2.5 13103-007 9.13 14575-147 5.79 12405-120 2.10 12505-081 2.11 13100-041 9.3 13103-007 9.14 14575-154 5.78 12405-120 2.11 12505-083 2.11 13100-043 9.3 13103-016 9.15 14575-155 5.78 12405-120 2.13 12505-084 2.11 13100-044 9.3 13105-001 9.10 14575-156 5.78 12406-400 2.4 12505-085 2.11 13100-045 9.3 13105-002 9.10 14575-163 5.79 12406-400 2.5 12505-086 2.11 13100-046 9.3 13105-003 9.10 14575-165 5.79 12406-411 2.6 12506-003 2.4 13100-078 9.9 13105-004 9.10 14575-167 5.79 12406-411 2.7 12506-004 2.4 13100-079 9.9 13105-006 9.10 14575-169 5.79 12406-418 2.6 12506-005 2.4 13100-102 9.4 13105-007 9.10 14575-171 5.79 12406-418 2.7 12506-010 2.4 13100-103 9.4 13105-008 9.10 14575-174 5.78 12406-419 2.6 12506-011 2.4 13100-104 9.4 13105-009 9.10 14575-175 5.78 12406-419 2.7 12506-012 2.4 13100-105 9.4 13105-011 9.10 14575-176 5.78 12406-450 2.7 12506-013 2.4 13100-112 9.7 13105-012 9.10 14575-178 5.78 12406-451 2.7 12506-014 2.4 13100-114 9.7 13105-013 9.10 14575-223 5.79 12406-452 2.7 12506-015 2.4 13100-115 9.7 13105-014 9.10 14575-225 5.79 12406-454 2.7 12506-017 2.4 13100-116 9.7 13105-017 9.11 14575-243 5.79 12406-730 2.6 12506-018 2.4 13100-122 9.8 13105-018 9.11 14575-245 5.79 12406-801 2.6 12506-019 2.4 13100-123 9.8 13105-021 9.11 14575-247 5.79 12406-802 2.6 12506-020 2.4 13100-133 9.5 13105-022 9.11 14575-265 5.79 12406-810 2.6 12506-022 2.4 13100-134 9.5 13105-023 9.11 14575-267 5.79 12406-812 2.6 12506-030 2.4 13100-136 9.2 13105-027 9.11 14575-269 5.79 12406-813 2.6 12506-031 2.4 13100-137 9.2 13105-028 9.11 14575-271 5.79 12406-814 2.6 12506-032 2.4 13100-138 9.2 13105-029 9.11 14575-445 5.80 12406-815 2.6 12506-033 2.4 13100-139 9.2 13105-051 9.12 14575-447 5.80 12406-816 2.6 12506-041 2.4 13100-141 8.102 13105-052 9.12 14575-463 5.80 12406-818 2.6 12506-054 2.4 13100-141 8.103 13105-053 9.12 14575-465 5.80 12406-819 2.6 12506-055 2.4 13100-141 8.77 14575-023 5.79 14575-467 5.80 12406-821 2.6 12506-160 2.5 13100-141 8.86 14575-025 5.79 14575-469 5.80 12505-001 2.10 12506-161 2.5 13100-141 8.87 14575-027 5.79 14575-471 5.80 12505-002 2.10 12506-162 2.5 13100-141 8.96 14575-063 5.79 14575-476 5.78 12505-003 2.10 12506-163 2.5 13100-141 9.22 14575-065 5.79 14575-477 5.78 12505-004 2.10 12506-164 2.5 13100-142 9.26 14575-067 5.79 14576-021 5.50 12505-005 2.10 12506-165 2.5 13100-145 9.23 14575-103 5.79 14576-023 5.50 12505-020 2.10 12506-166 2.5 13100-146 9.27 14575-105 5.79 14576-041 5.50 12505-021 2.10 12506-167 2.5 13100-150 9.6 14575-114 5.78 14576-043 5.50 12505-022 2.10 12506-168 2.5 13100-151 9.6 14575-115 5.78 14576-045 5.50 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.13 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 14576-101 5.50 15230-009 1.245 19713-540 4.10 20110-073 6.126 20110-197 3.28 14576-103 5.50 15230-010 1.245 20100-006 3.40 20110-074 3.27 20110-198 3.28 14576-121 5.50 15230-011 1.245 20100-007 3.40 20110-074 6.126 20114-728 1.150 14576-123 5.50 15230-012 1.245 20100-008 3.40 20110-075 3.27 20114-728 1.151 14576-125 5.50 15230-013 1.245 20100-009 3.41 20110-075 6.126 20114-728 1.153 14576-141 5.50 15230-014 1.245 20100-010 3.40 20110-076 3.27 20114-728 1.154 14576-143 5.50 15230-015 1.245 20100-013 3.41 20110-076 6.126 20114-728 1.24 14576-145 5.50 15230-016 1.245 20100-015 3.39 20110-077 3.27 20114-728 1.25 14576-161 5.50 15230-017 1.245 20100-017 3.39 20110-077 6.126 20114-728 1.283 14576-163 5.50 15230-018 1.245 20100-018 3.39 20110-090 3.25 20114-728 1.66 14576-165 5.50 15230-019 1.244 20100-019 3.39 20110-090 6.125 20114-728 1.67 14576-167 5.50 15230-020 1.244 20100-021 3.42 20110-091 3.25 20114-728 1.93 14576-169 5.50 15230-021 1.244 20100-028 3.41 20110-091 6.125 20114-728 1.94 14576-221 5.51 15230-022 1.244 20100-029 3.39 20110-092 3.25 20114-728 2.26 14576-223 5.51 15230-023 1.244 20100-029 3.41 20110-092 6.125 20114-728 2.31 14576-241 5.51 15230-024 1.244 20100-030 3.41 20110-093 3.25 20114-729 1.150 14576-243 5.51 15230-025 1.244 20110-054 3.13 20110-093 6.125 20114-729 1.151 14576-245 5.51 16230-001 1.245 20110-055 3.13 20110-094 3.25 20114-729 1.153 14576-247 5.51 16230-002 1.245 20110-056 3.13 20110-094 6.125 20114-729 1.154 14576-265 5.51 16230-003 1.245 20110-060 3.13 20110-095 3.25 20114-729 1.24 14576-267 5.51 16230-004 1.245 20110-061 3.13 20110-095 6.125 20114-729 1.25 14576-269 5.51 16230-005 1.245 20110-062 3.13 20110-096 3.25 20114-729 1.283 14576-463 5.51 16230-006 1.245 20110-063 3.13 20110-096 6.125 20114-729 1.66 14576-465 5.51 16230-007 1.245 20110-068 3.52 20110-097 3.25 20114-729 1.67 14576-467 5.51 16230-008 1.245 20110-068 3.53 20110-097 6.125 20114-729 1.93 14576-469 5.51 16230-009 1.245 20110-068 3.54 20110-100 3.26 20114-729 1.94 14577-123 5.52 16230-010 1.245 20110-068 3.55 20110-101 3.26 20114-730 1.150 14577-125 5.52 16230-011 1.245 20110-068 3.56 20110-102 3.26 20114-730 1.151 14577-143 5.52 16230-012 1.245 20110-068 3.57 20110-103 3.26 20114-730 1.153 14577-145 5.52 16230-013 1.245 20110-068 3.58 20110-104 3.26 20114-730 1.154 14577-163 5.52 16230-014 1.245 20110-068 3.59 20110-105 3.26 20114-730 1.24 14577-165 5.52 16230-015 1.245 20110-068 3.60 20110-106 3.26 20114-730 1.25 14577-223 5.52 16230-016 1.245 20110-068 3.61 20110-107 3.26 20114-730 1.283 14577-243 5.52 16230-017 1.245 20110-068 3.62 20110-108 3.26 20114-730 1.66 14577-245 5.52 16230-018 1.245 20110-068 3.63 20110-180 3.13 20114-730 1.67 14577-265 5.52 16230-019 1.244 20110-068 3.64 20110-181 3.13 20114-730 1.93 15230-001 1.245 16230-020 1.244 20110-068 3.66 20110-182 3.13 20114-730 1.94 15230-002 1.245 16230-021 1.244 20110-068 3.67 20110-190 3.28 20114-731 1.117 15230-003 1.245 16230-022 1.244 20110-068 3.68 20110-191 3.28 20114-731 1.150 15230-004 1.245 16230-023 1.244 20110-071 3.27 20110-192 3.28 20114-731 1.151 15230-005 1.245 16230-024 1.244 20110-071 6.126 20110-193 3.28 20114-731 1.153 15230-006 1.245 16230-025 1.244 20110-072 3.27 20110-194 3.28 20114-731 1.154 15230-007 1.245 19713-006 4.8 20110-072 6.126 20110-195 3.28 20114-731 1.176 15230-008 1.245 19713-121 4.8 20110-073 3.27 20110-196 3.28 20114-731 1.198 12.14 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. 20114-731 1.24 20117-753 1.303 20118-351 1.177 20118-554 1.359 20118-745 1.358 20114-731 1.25 20117-754 1.303 20118-351 1.199 20118-590 3.37 20118-746 3.29 20114-731 1.283 20117-756 1.303 20118-351 1.25 20118-591 3.37 20118-747 3.30 20114-731 1.52 20117-757 1.276 20118-351 1.253 20118-592 1.284 20118-748 3.31 20114-731 1.66 20117-757 1.277 20118-351 1.269 20118-592 1.298 20118-749 3.31 20114-731 1.67 20117-757 1.290 20118-351 1.287 20118-592 1.311 20118-750 1.133 20114-731 1.83 20117-757 1.302 20118-351 1.53 20118-593 1.284 20118-750 1.166 20114-731 1.93 20117-765 1.279 20118-351 1.67 20118-593 1.298 20118-750 1.188 20114-731 1.94 20117-765 1.292 20118-351 1.83 20118-593 1.311 20118-750 1.238 20117-024 1.276 20117-765 1.304 20118-351 1.95 20118-624 1.118 20118-750 1.265 20117-024 1.277 20117-766 1.279 20118-351 2.26 20118-624 1.154 20118-750 1.294 20117-024 1.290 20117-766 1.292 20118-351 2.31 20118-624 1.177 20118-750 1.295 20117-024 1.302 20117-766 1.304 20118-351 2.32 20118-624 1.199 20118-750 1.306 20117-080 1.276 20117-767 1.279 20118-351 2.42 20118-624 1.25 20118-750 1.307 20117-080 1.277 20117-767 1.292 20118-351 3.20 20118-624 1.253 20118-750 1.34 20117-080 1.294 20117-767 1.304 20118-351 3.21 20118-624 1.269 20118-750 1.35 20117-080 1.306 20117-768 1.279 20118-352 1.154 20118-624 1.287 20118-750 1.72 20117-156 1.290 20117-768 1.292 20118-352 1.25 20118-624 1.53 20118-750 2.27 20117-503 1.281 20117-768 1.304 20118-352 1.253 20118-624 1.67 20118-753 3.29 20117-503 1.296 20117-769 1.279 20118-352 1.287 20118-624 1.83 20118-753 3.30 20117-503 1.308 20117-770 1.279 20118-352 1.67 20118-624 1.95 20118-753 3.31 20117-515 1.302 20117-770 1.292 20118-352 1.95 20118-624 2.31 20118-753 3.32 20117-744 1.278 20117-770 1.304 20118-352 3.20 20118-624 3.20 20118-757 1.343 20117-745 1.278 20117-771 1.279 20118-353 1.154 20118-630 3.16 20118-757 3.8 20117-745 1.291 20117-771 1.292 20118-353 1.25 20118-631 3.16 20118-758 1.343 20117-745 1.303 20117-771 1.304 20118-353 1.253 20118-686 1.351 20118-758 3.8 20117-746 1.278 20117-772 1.279 20118-353 1.287 20118-706 3.21 20118-759 1.343 20117-746 1.291 20117-772 1.292 20118-353 1.67 20118-713 2.34 20118-759 3.8 20117-746 1.303 20117-772 1.304 20118-353 1.95 20118-714 2.34 20118-760 1.343 20117-747 1.278 20117-775 1.304 20118-353 3.20 20118-715 2.34 20118-760 3.8 20117-747 1.291 20117-776 1.304 20118-364 3.37 20118-716 2.33 20118-761 1.342 20117-747 1.303 20117-777 1.304 20118-365 3.37 20118-717 2.34 20118-761 3.7 20117-748 1.278 20118-030 3.36 20118-366 3.37 20118-719 2.44 20118-762 1.342 20117-748 1.291 20118-265 3.37 20118-390 1.247 20118-729 3.21 20118-762 3.7 20117-748 1.303 20118-266 3.37 20118-390 1.262 20118-734 1.343 20118-767 1.343 20117-749 1.278 20118-280 3.35 20118-391 1.247 20118-734 3.8 20118-767 3.8 20117-749 1.291 20118-281 3.37 20118-391 1.262 20118-736 1.343 20118-768 1.343 20117-749 1.303 20118-282 3.37 20118-460 1.358 20118-736 3.8 20118-768 3.8 20117-751 1.278 20118-339 1.283 20118-461 1.359 20118-738 3.32 20118-775 1.150 20117-751 1.291 20118-339 1.359 20118-462 1.357 20118-740 3.20 20118-775 1.151 20117-751 1.303 20118-340 1.283 20118-536 3.35 20118-741 1.357 20118-775 1.153 20117-752 1.278 20118-340 1.359 20118-537 3.36 20118-742 1.357 20118-775 1.154 20117-752 1.291 20118-351 1.118 20118-538 3.34 20118-743 1.357 20118-775 1.24 20117-752 1.303 20118-351 1.154 20118-554 1.283 20118-744 1.358 20118-775 1.25 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part no. Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.15 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 20118-775 1.283 20118-783 1.360 20119-257 1.361 20130-014 1.180 20130-027 1.158 20118-775 1.66 20118-783 2.29 20119-354 3.34 20130-014 1.28 20130-027 1.180 20118-775 1.67 20118-783 3.11 20119-355 3.34 20130-014 1.40 20130-027 1.28 20118-775 1.93 20118-784 1.345 20119-356 3.34 20130-014 1.70 20130-027 1.40 20118-775 1.94 20118-784 3.11 20119-357 3.34 20130-015 1.158 20130-027 1.70 20118-776 1.150 20118-785 1.345 20119-358 3.34 20130-015 1.180 20130-028 1.158 20118-776 1.151 20118-785 1.360 20125-005 1.350 20130-015 1.28 20130-028 1.180 20118-776 1.153 20118-785 2.29 20125-006 1.349 20130-015 1.40 20130-028 1.28 20118-776 1.154 20118-785 3.11 20125-018 1.351 20130-015 1.70 20130-028 1.40 20118-776 1.24 20118-786 1.345 20125-021 1.349 20130-016 1.158 20130-028 1.70 20118-776 1.25 20118-786 3.11 20130-001 1.158 20130-016 1.180 20130-029 1.158 20118-776 1.283 20118-787 1.345 20130-001 1.180 20130-017 1.28 20130-029 1.180 20118-776 1.66 20118-787 3.11 20130-002 1.158 20130-017 1.40 20130-030 1.158 20118-776 1.67 20118-788 1.345 20130-002 1.180 20130-018 1.158 20130-030 1.180 20118-776 1.93 20118-788 3.11 20130-003 1.158 20130-018 1.180 20130-030 1.70 20118-776 1.94 20118-789 1.345 20130-003 1.180 20130-018 1.28 20130-031 1.158 20118-777 1.150 20118-789 1.360 20130-004 1.158 20130-018 1.40 20130-031 1.180 20118-777 1.151 20118-789 2.29 20130-004 1.180 20130-018 1.70 20130-032 1.158 20118-777 1.153 20118-789 3.11 20130-005 1.158 20130-019 1.158 20130-032 1.180 20118-777 1.154 20118-790 1.345 20130-005 1.180 20130-019 1.180 20130-032 1.28 20118-777 1.24 20118-790 1.360 20130-005 1.28 20130-019 1.28 20130-032 1.40 20118-777 1.25 20118-790 2.29 20130-005 1.40 20130-019 1.40 20130-032 1.70 20118-777 1.283 20118-790 3.11 20130-005 1.70 20130-019 1.70 20130-033 1.158 20118-777 1.66 20118-791 1.345 20130-006 1.158 20130-020 1.158 20130-033 1.180 20118-777 1.67 20118-791 1.360 20130-006 1.180 20130-020 1.180 20130-034 1.158 20118-777 1.93 20118-791 3.11 20130-006 1.28 20130-021 1.158 20130-034 1.180 20118-777 1.94 20118-796 1.247 20130-006 1.40 20130-021 1.180 20130-035 1.158 20118-778 1.150 20118-796 1.262 20130-006 1.70 20130-021 1.70 20130-035 1.180 20118-778 1.151 20118-796 1.279 20130-007 1.158 20130-022 1.158 20130-036 1.158 20118-778 1.153 20118-796 1.293 20130-007 1.180 20130-022 1.180 20130-036 1.180 20118-778 1.154 20118-796 1.305 20130-008 1.158 20130-022 1.28 20130-037 1.158 20118-778 1.24 20118-797 1.247 20130-008 1.180 20130-022 1.40 20130-037 1.180 20118-778 1.25 20118-797 1.262 20130-009 1.28 20130-022 1.70 20130-038 1.158 20118-778 1.283 20118-797 1.279 20130-009 1.40 20130-023 1.158 20130-038 1.180 20118-778 1.66 20118-797 1.293 20130-009 1.70 20130-023 1.180 20130-051 1.158 20118-778 1.67 20118-797 1.305 20130-010 1.28 20130-023 1.28 20130-051 1.180 20118-778 1.93 20119-080 1.361 20130-010 1.40 20130-023 1.40 20130-052 1.158 20118-778 1.94 20119-106 1.361 20130-010 1.70 20130-023 1.70 20130-052 1.180 20118-781 1.345 20119-159 7.11 20130-013 1.158 20130-024 1.158 20130-053 1.158 20118-781 1.360 20119-160 7.11 20130-013 1.180 20130-024 1.180 20130-053 1.180 20118-781 3.11 20119-161 7.11 20130-013 1.28 20130-025 1.158 20130-054 1.158 20118-782 1.345 20119-162 7.11 20130-013 1.40 20130-025 1.180 20130-054 1.180 20118-782 3.11 20119-163 7.11 20130-013 1.70 20130-026 1.28 20130-055 1.158 20118-783 1.345 20119-257 1.344 20130-014 1.158 20130-026 1.40 20130-055 1.180 12.16 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. 20130-055 1.28 20130-055 1.40 20130-055 20130-069 1.70 20130-084 1.158 20130-595 1.158 20130-631 1.106 20130-070 1.158 20130-084 1.180 20130-595 1.180 20130-631 1.98 1.70 20130-070 1.180 20130-085 1.158 20130-596 1.158 20130-632 1.102 20130-056 1.158 20130-071 1.158 20130-085 1.180 20130-596 1.180 20130-632 1.106 20130-056 1.180 20130-071 1.180 20130-086 1.158 20130-597 1.158 20130-632 1.98 20130-056 1.28 20130-071 1.70 20130-086 1.180 20130-597 1.180 20130-633 1.102 20130-056 1.40 20130-072 1.158 20130-087 1.158 20130-598 1.146 20130-633 1.106 20130-056 1.70 20130-072 1.180 20130-087 1.180 20130-617 1.102 20130-633 1.98 20130-057 1.158 20130-072 1.28 20130-088 1.158 20130-617 1.106 20130-634 1.102 20130-057 1.180 20130-072 1.40 20130-088 1.180 20130-617 1.98 20130-634 1.106 20130-058 1.158 20130-072 1.70 20130-578 1.158 20130-618 1.102 20130-634 1.98 20130-058 1.180 20130-073 1.158 20130-578 1.180 20130-618 1.106 20130-636 1.102 20130-059 1.28 20130-073 1.180 20130-579 1.158 20130-618 1.98 20130-636 1.106 20130-059 1.40 20130-073 1.28 20130-579 1.180 20130-621 1.102 20130-636 1.98 20130-059 1.70 20130-073 1.40 20130-580 1.158 20130-621 1.106 20150-011 1.295 20130-060 1.28 20130-073 1.70 20130-580 1.180 20130-621 1.98 20150-011 1.307 20130-060 1.40 20130-074 1.158 20130-581 1.158 20130-622 1.102 20225-167 5.114 20130-060 1.70 20130-074 1.180 20130-581 1.180 20130-622 1.106 20225-439 5.105 20130-063 1.158 20130-075 1.158 20130-582 1.158 20130-622 1.98 20230-409 1.258 20130-063 1.180 20130-075 1.180 20130-582 1.180 20130-623 1.102 20505-032 5.113 20130-063 1.28 20130-077 1.158 20130-583 1.158 20130-623 1.106 20603-001 5.107 20130-063 1.40 20130-077 1.180 20130-583 1.180 20130-623 1.98 20603-001 5.116 20130-063 1.70 20130-077 1.28 20130-584 1.158 20130-624 1.102 20603-001 5.23 20130-064 1.158 20130-077 1.40 20130-584 1.180 20130-624 1.106 20603-001 5.61 20130-064 1.180 20130-077 1.70 20130-585 1.158 20130-624 1.98 20603-001 5.62 20130-064 1.28 20130-078 1.158 20130-585 1.180 20130-625 1.102 20603-001 5.72 20130-064 1.40 20130-078 1.180 20130-586 1.158 20130-625 1.106 20603-001 5.87 20130-064 1.70 20130-078 1.28 20130-586 1.180 20130-625 1.98 20603-002 5.107 20130-065 1.158 20130-078 1.40 20130-587 1.158 20130-626 1.102 20603-002 5.116 20130-065 1.180 20130-078 1.70 20130-587 1.180 20130-626 1.106 20603-002 5.23 20130-065 1.28 20130-079 1.158 20130-588 1.158 20130-626 1.98 20603-002 5.61 20130-065 1.40 20130-079 1.180 20130-588 1.180 20130-627 1.102 20603-002 5.62 20130-065 1.70 20130-080 1.158 20130-589 1.158 20130-627 1.106 20603-002 5.72 20130-066 1.158 20130-080 1.180 20130-589 1.180 20130-627 1.98 20603-002 5.87 20130-066 1.180 20130-080 1.70 20130-590 1.158 20130-628 1.102 20603-003 5.23 20130-068 1.158 20130-081 1.158 20130-590 1.180 20130-628 1.106 20603-004 5.23 20130-068 1.180 20130-081 1.180 20130-591 1.158 20130-628 1.98 20700-001 4.10 20130-068 1.28 20130-082 1.158 20130-591 1.180 20130-629 1.102 20700-001 4.16 20130-068 1.40 20130-082 1.180 20130-592 1.158 20130-629 1.106 20700-001 4.61 20130-068 1.70 20130-082 1.28 20130-592 1.180 20130-629 1.98 20705-008 4.9 20130-069 1.158 20130-082 1.40 20130-593 1.158 20130-630 1.102 20713-048 1.294 20130-069 1.180 20130-082 1.70 20130-593 1.180 20130-630 1.106 20713-048 1.295 20130-069 1.28 20130-083 1.158 20130-594 1.158 20130-630 1.98 20713-048 1.306 20130-069 1.40 20130-083 1.180 20130-594 1.180 20130-631 1.102 20713-048 1.307 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.17 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 20713-142 4.16 20713-243 4.7 20808-080 7.55 20809-441 7.105 20817-452 7.39 20713-142 4.61 20713-244 4.10 20808-081 7.55 20809-495 7.61 20817-456 7.39 20713-146 4.16 20713-244 4.16 20808-082 7.55 20809-496 7.61 20817-457 7.39 20713-146 4.61 20713-244 4.6 20808-083 7.55 20809-497 7.61 20817-458 7.39 20713-147 4.10 20713-244 4.61 20808-083 7.75 20809-498 7.61 20817-459 7.39 20713-147 4.16 20713-244 4.7 20808-084 7.55 20809-502 7.60 20817-501 5.42 20713-147 4.61 20713-502 4.13 20808-085 7.55 20809-507 7.53 20817-501 6.106 20713-172 4.16 20713-503 4.13 20808-085 7.75 20809-511 7.61 20817-501 6.107 20713-212 4.14 20713-504 4.13 20808-086 7.55 20809-512 7.61 20817-501 6.14 20713-213 4.14 20713-505 4.13 20808-086 7.75 20809-513 7.61 20817-501 6.15 20713-214 4.14 20715-001 4.58 20808-087 7.55 20809-516 7.60 20817-501 6.38 20713-215 4.14 20715-001 4.59 20808-087 7.75 20809-529 7.90 20817-501 6.41 20713-216 4.14 20715-001 4.60 20808-088 7.55 20809-530 7.90 20817-501 6.81 20713-217 4.14 20715-003 4.64 20808-088 7.75 20809-531 7.90 20817-501 7.23 20713-218 4.14 20800-032 7.105 20808-089 7.55 20809-532 7.90 20817-606 7.18 20713-219 4.14 20800-036 11.8 20808-089 7.75 20809-533 7.90 20817-606 7.23 20713-220/05 4.14 20800-042 11.8 20808-090 7.55 20809-534 7.90 20817-612 7.20 20713-221/05 4.14 20800-078 11.8 20808-091 7.55 20809-536 7.90 20817-613 7.20 20713-222/05 4.14 20800-168 10.26 20808-091 7.75 20809-537 7.90 20817-614 7.20 20713-223/05 4.14 20800-212 10.27 20808-092 7.55 20809-538 7.90 20817-615 7.20 20713-224/05 4.14 20800-213 10.27 20808-137 7.49 20809-539 7.90 20817-620 7.20 20713-225/05 4.14 20800-224 10.26 20809-281 7.55 20809-540 7.90 20817-621 7.20 20713-226/05 4.14 20800-278 10.26 20809-282 7.55 20809-541 7.90 20817-622 7.20 20713-227/05 4.14 20800-279 10.26 20809-283 7.55 20810-605 8.110 20817-623 7.20 20713-228/05 4.14 20808-003 7.55 20809-284 7.55 20810-611 8.110 20817-652 7.21 20713-229/05 4.14 20808-004 7.55 20809-285 7.55 20817-325 7.46 20817-653 7.21 20713-230/05 4.14 20808-004 7.75 20809-286 7.55 20817-326 7.46 20817-654 7.21 20713-231/05 4.14 20808-009 7.55 20809-287 7.55 20817-327 7.41 20817-655 7.21 20713-236/05 4.14 20808-012 7.55 20809-288 7.55 20817-328 7.41 20817-660 7.21 20713-237/05 4.14 20808-060 7.55 20809-289 7.55 20817-329 7.41 20817-661 7.21 20713-238/05 4.14 20808-061 7.55 20809-290 7.55 20817-330 7.41 20817-662 7.21 20713-239/05 4.14 20808-062 7.55 20809-291 7.55 20817-345 7.46 20817-663 7.21 20713-240 4.10 20808-062 7.75 20809-292 7.55 20817-346 7.46 20817-682 7.20 20713-240 4.16 20808-063 7.55 20809-293 7.55 20817-368 6.134 20817-683 7.20 20713-240 4.6 20808-064 7.55 20809-294 7.55 20817-369 6.134 20817-684 7.20 20713-240 4.7 20808-064 7.75 20809-295 7.55 20817-443 7.39 20817-685 7.20 20713-241 4.16 20808-065 7.55 20809-329 7.61 20817-444 7.39 20817-690 7.20 20713-242 4.16 20808-065 7.75 20809-357 7.61 20817-445 7.39 20817-691 7.20 20713-243 1.295 20808-066 7.55 20809-359 7.61 20817-446 7.39 20817-692 7.20 20713-243 1.307 20808-066 7.75 20809-371 7.60 20817-447 7.39 20817-693 7.20 20713-243 4.10 20808-067 7.55 20809-371 7.61 20817-448 7.39 20817-706 7.21 20713-243 4.16 20808-067 7.75 20809-396 7.55 20817-449 7.39 20817-707 7.21 20713-243 4.6 20808-068 7.55 20809-397 7.55 20817-450 7.39 20817-708 7.21 20713-243 4.61 20808-068 7.75 20809-441 11.8 20817-451 7.39 20817-709 7.21 12.18 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 20817-714 7.21 20818-026 7.53 20823-674 5.84 20838-001 7.91 20846-430 6.49 20817-715 7.21 20818-027 7.53 20823-675 5.83 20838-002 7.91 20846-430 7.5 20817-716 7.21 20818-028 7.53 20823-676 5.83 20838-003 7.91 20846-431 6.49 20817-717 7.21 20818-029 7.53 20825-120 6.134 20838-004 7.91 20846-431 7.5 20817-829 7.34 20818-120 7.53 20825-121 6.134 20838-005 7.91 20846-432 6.49 20817-831 7.34 20818-121 8.15 20828-028 6.131 20838-006 7.91 20846-432 7.5 20817-833 7.34 20818-122 8.15 20828-127 6.133 20838-084 1.351 20846-433 6.49 20817-853 8.32 20818-123 8.15 20828-128 6.133 20838-086 1.351 20846-433 7.5 20817-853 8.33 20818-124 8.15 20828-129 6.133 20838-093 7.91 20846-434 6.49 20817-853 8.34 20818-140 8.12 20829-003 7.44 20838-094 7.91 20846-434 7.5 20817-854 7.34 20818-140 8.13 20829-004 7.44 20838-095 7.91 20846-436 6.49 20817-856 7.34 20818-140 8.14 20829-011 7.44 20838-096 7.91 20846-436 7.5 20817-858 7.34 20818-140 8.15 20833-351 5.26 20838-097 7.91 20846-437 6.49 20817-860 7.32 20818-145 8.15 20833-352 5.26 20838-098 7.91 20846-437 7.5 20817-861 7.32 20818-146 8.15 20833-353 5.26 20838-271 6.51 20846-438 6.49 20817-862 7.32 20818-147 8.15 20835-188 8.111 20838-271 7.8 20846-438 7.5 20817-863 7.32 20818-148 8.15 20835-598 7.13 20838-272 6.51 20846-443 6.49 20817-864 7.32 20818-160 8.12 20835-889 7.13 20838-272 7.8 20846-443 7.5 20817-865 7.32 20818-161 8.12 20835-890 7.13 20838-273 6.51 20846-444 6.49 20817-866 7.32 20818-162 7.53 20835-893 7.13 20838-273 7.8 20846-444 7.5 20817-867 7.32 20818-163 8.13 20835-896 7.13 20838-274 6.51 20846-445 6.49 20817-868 7.32 20818-164 8.13 20835-899 7.13 20838-274 7.8 20846-445 7.5 20817-869 7.32 20818-169 8.12 20835-922 7.13 20838-275 6.51 20846-446 6.49 20817-870 7.32 20818-170 8.12 20835-923 7.13 20838-275 7.8 20846-446 7.5 20817-871 7.32 20822-046 6.34 20835-924 7.13 20838-276 6.51 20846-447 6.49 20817-872 7.32 20822-047 5.35 20835-928 7.13 20838-276 7.8 20846-447 7.5 20817-873 7.32 20822-047 5.69 20835-929 7.13 20838-277 6.51 20846-448 6.49 20817-874 7.29 20822-047 5.91 20835-931 7.13 20838-277 7.8 20846-448 7.5 20817-877 7.29 20822-047 6.34 20836-145 8.95 20838-278 6.51 20846-449 6.49 20817-900 10.14 20822-048 5.35 20836-220 8.100 20838-278 7.8 20846-449 7.5 20817-909 8.32 20822-048 5.69 20836-223 8.100 20838-279 6.51 20846-450 6.49 20817-909 8.33 20822-048 5.91 20836-235 8.102 20838-279 7.8 20846-450 7.5 20817-909 8.34 20822-048 6.34 20836-235 8.103 20838-280 6.51 20846-451 6.49 20817-969 10.14 20822-049 5.35 20836-245 8.96 20838-280 7.8 20846-451 7.5 20817-970 10.14 20822-049 5.69 20836-310 8.90 20846-425 6.49 20846-452 6.49 20818-017 7.53 20822-049 5.91 20836-415 8.91 20846-425 7.5 20846-452 7.5 20818-018 7.53 20822-049 6.34 20836-416 8.97 20846-426 6.49 20846-453 6.49 20818-019 7.53 20822-050 5.35 20836-444 8.104 20846-426 7.5 20846-453 7.5 20818-020 7.53 20822-050 5.69 20836-715 8.92 20846-427 6.49 20846-454 6.49 20818-021 7.53 20822-050 5.91 20836-716 8.93 20846-427 7.5 20846-454 7.5 20818-022 7.53 20822-050 6.34 20836-717 8.98 20846-428 6.49 20846-456 6.49 20818-023 7.53 20822-051 6.34 20836-815 8.94 20846-428 7.5 20846-456 7.5 20818-024 7.53 20823-668 5.84 20836-820 8.99 20846-429 6.49 20848-013 6.50 20818-025 7.53 20823-669 5.84 20836-855 8.100 20846-429 7.5 20848-013 7.7 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.19 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 20848-015 7.7 20848-489 7.38 20848-633 5.22 20848-681 5.22 20848-729 5.75 20848-020 6.50 20848-490 7.38 20848-633 5.55 20848-681 5.55 20848-729 6.61 20848-020 7.7 20848-491 7.38 20848-634 5.22 20848-682 5.22 20848-730 5.43 20848-027 6.50 20848-492 7.38 20848-634 5.55 20848-682 5.55 20848-730 5.75 20848-027 7.7 20848-494 7.38 20848-635 5.22 20848-686 7.31 20848-730 6.61 20848-047 6.50 20848-496 7.38 20848-635 5.55 20848-687 7.31 20848-731 5.43 20848-047 7.7 20848-497 7.38 20848-636 5.22 20848-688 7.31 20848-731 5.75 20848-068 6.50 20848-498 7.38 20848-636 5.55 20848-689 7.31 20848-731 6.61 20848-068 7.7 20848-585 7.18 20848-640 5.22 20848-690 7.31 20848-732 5.43 20848-097 6.50 20848-587 7.18 20848-640 5.55 20848-691 7.31 20848-732 5.75 20848-097 7.7 20848-589 7.18 20848-641 5.22 20848-692 7.31 20848-732 6.61 20848-106 6.50 20848-590 7.18 20848-641 5.55 20848-693 7.31 20848-733 5.43 20848-106 7.7 20848-591 7.18 20848-642 5.22 20848-694 7.31 20848-733 5.75 20848-108 6.50 20848-592 7.18 20848-642 5.55 20848-695 7.31 20848-733 6.61 20848-108 7.7 20848-594 7.18 20848-643 5.22 20848-696 6.51 20848-736 5.43 20848-113 6.50 20848-596 7.18 20848-643 5.55 20848-696 7.8 20848-736 5.75 20848-113 7.7 20848-597 7.18 20848-656 5.22 20848-712 5.43 20848-736 6.61 20848-120 6.50 20848-598 7.18 20848-656 5.55 20848-712 6.61 20848-738 5.43 20848-120 7.7 20848-599 6.51 20848-657 5.22 20848-713 5.43 20848-738 5.75 20848-139 6.50 20848-599 7.8 20848-657 5.55 20848-713 6.61 20848-738 6.61 20848-139 7.7 20848-600 6.51 20848-658 5.22 20848-714 5.43 20848-739 5.43 20848-160 6.50 20848-600 7.8 20848-658 5.55 20848-714 6.61 20848-739 5.75 20848-160 7.7 20848-601 6.51 20848-659 5.22 20848-715 5.43 20848-739 6.61 20848-189 6.50 20848-601 7.8 20848-659 5.55 20848-715 6.61 20848-740 5.43 20848-189 7.7 20848-602 6.51 20848-663 7.52 20848-716 5.43 20848-740 5.75 20848-227 7.19 20848-602 7.8 20848-664 7.52 20848-716 6.61 20848-740 6.61 20848-228 7.19 20848-603 6.51 20848-665 7.52 20848-717 5.43 20848-741 5.43 20848-230 7.19 20848-603 7.8 20848-666 7.52 20848-717 6.61 20848-741 5.75 20848-232 7.19 20848-604 6.51 20848-667 7.52 20848-720 5.43 20848-741 6.61 20848-243 7.19 20848-604 7.8 20848-668 7.52 20848-720 6.61 20848-744 5.22 20848-244 7.19 20848-605 6.51 20848-669 7.52 20848-721 5.43 20848-745 5.22 20848-246 7.19 20848-605 7.8 20848-670 7.52 20848-721 6.61 20848-746 5.22 20848-248 7.19 20848-606 6.51 20848-671 7.52 20848-722 5.43 20848-747 5.22 20848-262 6.50 20848-606 7.8 20848-672 7.52 20848-722 6.61 20848-751 7.18 20848-262 7.7 20848-607 6.51 20848-673 7.52 20848-723 5.43 20848-752 7.18 20848-268 6.50 20848-607 7.8 20848-674 7.52 20848-723 6.61 20849-008 8.30 20848-269 6.50 20848-608 6.51 20848-675 7.52 20848-724 5.43 20849-009 8.30 20848-270 6.50 20848-608 7.8 20848-676 7.52 20848-724 6.61 20849-010 8.30 20848-271 6.50 20848-611 5.57 20848-677 7.52 20848-725 5.43 20849-011 8.30 20848-271 7.7 20848-611 6.51 20848-678 7.52 20848-725 6.61 20849-016 8.63 20848-280 6.50 20848-611 7.9 20848-679 5.22 20848-728 5.43 20849-017 8.63 20848-280 7.7 20848-617 5.57 20848-679 5.55 20848-728 5.75 20849-018 8.63 20848-485 7.38 20848-617 6.51 20848-680 5.22 20848-728 6.61 20849-021 8.30 20848-487 7.38 20848-617 7.9 20848-680 5.55 20848-729 5.43 20849-021 8.34 12.20 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. 20849-022 8.63 20849-236 8.30 20850-185 5.58 20860-126 6.114 20860-258 5.109 20849-023 8.63 20849-236 8.31 20850-186 5.58 20860-127 6.114 20860-258 6.115 20849-024 8.63 20849-242 8.34 20850-190 5.58 20860-130 6.115 20860-258 6.116 20849-025 8.63 20849-248 8.63 20850-191 5.58 20860-130 6.116 20860-258 6.121 20849-106 8.63 20849-249 8.63 20850-192 5.58 20860-130 6.117 20860-259 5.109 20849-107 8.63 20849-250 8.63 20850-196 5.58 20860-130 6.121 20860-259 6.115 20849-115 8.38 20849-251 8.63 20850-197 5.58 20860-130 6.123 20860-259 6.116 20849-115 8.39 20849-268 8.59 20850-198 5.58 20860-131 6.121 20860-259 6.121 20849-115 8.40 20849-269 8.59 20850-249 5.111 20860-131 6.123 20860-260 5.109 20849-115 8.48 20849-270 8.59 20850-249 5.60 20860-201 6.120 20860-260 6.115 20849-127 8.59 20849-271 8.59 20850-299 5.58 20860-201 6.122 20860-260 6.116 20849-128 8.59 20849-288 8.58 20850-300 5.58 20860-202 6.120 20860-260 6.121 20849-129 8.59 20849-289 8.58 20850-301 5.58 20860-202 6.122 20860-601 6.115 20849-130 8.59 20849-290 8.58 20850-315 5.58 20860-203 6.120 20860-602 6.115 20849-131 8.59 20849-291 8.58 20850-316 5.58 20860-203 6.122 20860-605 6.115 20849-132 8.59 20849-304 8.63 20850-317 5.58 20860-210 6.120 20860-606 6.115 20849-151 8.61 20849-305 8.63 20850-331 5.58 20860-210 6.122 20860-607 6.115 20849-152 8.61 20849-312 8.59 20850-332 5.58 20860-211 6.120 20860-608 6.115 20849-153 8.61 20849-313 8.59 20850-333 5.58 20860-211 6.122 20860-609 6.115 20849-154 8.61 20849-332 8.58 20850-423 5.54 20860-212 6.120 20860-612 6.115 20849-155 8.61 20849-333 8.58 20850-423 6.48 20860-212 6.122 20860-613 6.115 20849-156 8.61 20849-334 8.58 20850-424 5.54 20860-219 6.120 20860-614 6.115 20849-166 8.34 20849-335 8.58 20850-424 6.48 20860-220 6.120 20860-615 6.115 20849-194 8.49 20849-348 8.66 20850-425 5.54 20860-221 6.120 20860-621 6.116 20849-195 8.49 20849-349 8.66 20850-425 6.48 20860-222 6.120 20860-622 6.116 20849-196 8.49 20849-350 8.66 20850-426 5.54 20860-228 6.120 20860-625 6.116 20849-197 8.49 20849-351 8.66 20850-426 6.48 20860-229 6.120 20860-626 6.116 20849-198 8.49 20849-352 8.66 20850-426 7.4 20860-230 6.120 20860-627 6.116 20849-199 8.49 20849-353 8.66 20860-107 6.120 20860-231 6.120 20860-628 6.116 20849-200 8.49 20849-355 8.66 20860-108 6.120 20860-240 6.120 20860-629 6.116 20849-201 8.49 20849-356 8.66 20860-109 6.120 20860-256 5.109 20860-632 6.116 20849-202 8.49 20849-357 8.66 20860-110 6.120 20860-256 6.114 20860-633 6.116 20849-209 8.58 20850-128 5.54 20860-111 6.120 20860-256 6.115 20860-634 6.116 20849-209 8.59 20850-129 5.54 20860-115 6.117 20860-256 6.116 20860-635 6.116 20849-209 8.62 20850-130 5.54 20860-115 6.122 20860-256 6.117 20860-641 6.117 20849-209 8.67 20850-134 5.54 20860-116 6.117 20860-256 6.121 20860-642 6.117 20849-213 8.65 20850-135 5.54 20860-116 6.122 20860-256 6.123 20860-645 6.117 20849-214 8.65 20850-136 5.54 20860-117 6.117 20860-257 5.109 20897-950 7.12 20849-235 8.28 20850-137 5.54 20860-117 6.122 20860-257 6.114 21005-439 9.12 20849-235 8.29 20850-142 5.54 20860-118 6.117 20860-257 6.115 21005-451 9.12 20849-235 8.30 20850-143 5.54 20860-118 6.122 20860-257 6.116 21005-470 9.12 20849-235 8.31 20850-144 5.54 20860-120 6.114 20860-257 6.117 21005-473 9.10 20849-236 8.28 20850-158 5.54 20860-121 6.114 20860-257 6.121 21005-474 9.10 20849-236 8.29 20850-184 5.58 20860-122 6.114 20860-257 6.123 21005-475 9.10 SCHROFF.PENTAIR.CO.UK Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.21 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21005-476 9.11 21100-207 5.72 21100-435 6.73 21100-646 5.35 21100-748 7.107 21005-477 9.11 21100-207 5.87 21100-435 6.74 21100-646 5.68 21100-748 7.108 21005-478 9.11 21100-211 5.107 21100-435 6.75 21100-646 5.90 21100-748 7.35 21006-943 9.3 21100-211 5.116 21100-435 6.76 21100-646 6.104 21100-748 7.42 21006-943 9.4 21100-211 5.117 21100-435 6.77 21100-646 6.33 21100-748 7.47 21006-945 9.7 21100-211 5.72 21100-435 6.78 21100-646 6.66 21100-748 7.50 21006-945 9.8 21100-211 5.87 21100-435 6.79 21100-646 7.111 21100-748 7.57 21006-946 9.9 21100-215 3.18 21100-435 6.8 21100-647 5.85 21100-748 7.78 21006-954 9.5 21100-216 3.18 21100-435 6.80 21100-648 7.109 21100-748 7.93 21006-955 9.13 21100-268 7.108 21100-435 6.9 21100-649 7.109 21100-749 7.108 21006-956 9.13 21100-276 5.35 21100-448 5.106 21100-650 3.17 21100-777 10.28 21006-956 9.14 21100-276 5.68 21100-459 7.104 21100-659 6.63 21100-777 6.65 21006-957 9.15 21100-276 5.90 21100-459 7.111 21100-659 7.107 21100-777 7.110 21006-959 9.2 21100-276 6.104 21100-464 6.63 21100-660 6.63 21100-788 3.3 21009-038 9.21 21100-276 6.33 21100-464 7.107 21100-660 7.107 21100-788 5.109 21009-039 9.24 21100-276 6.66 21100-464 7.22 21100-660 7.57 21100-788 5.110 21009-039 9.25 21100-276 7.111 21100-464 7.35 21100-661 6.63 21100-788 7.110 21100-001 3.18 21100-289 7.92 21100-464 7.42 21100-661 7.107 21100-814 6.133 21100-002 3.18 21100-293 11.4 21100-464 7.47 21100-662 6.63 21100-886 6.63 21100-003 3.17 21100-294 11.4 21100-464 7.50 21100-662 7.107 21101-007 3.19 21100-004 3.17 21100-347 5.106 21100-464 7.57 21100-662 7.22 21101-069 7.104 21100-015 3.17 21100-359 7.111 21100-464 7.78 21100-662 7.35 21101-069 7.110 21100-016 3.17 21100-359 7.55 21100-464 7.93 21100-662 7.42 21101-069 7.57 21100-021 3.17 21100-359 7.93 21100-476 7.55 21100-662 7.47 21101-101 5.39 21100-022 3.17 21100-404 11.8 21100-490 5.106 21100-662 7.50 21101-101 5.70 21100-076 7.103 21100-429 7.109 21100-500 7.109 21100-662 7.57 21101-101 5.95 21100-089 5.114 21100-429 7.22 21100-507 7.109 21100-671 6.135 21101-101 6.109 21100-093 5.114 21100-429 7.35 21100-507 7.93 21100-672 6.135 21101-101 6.57 21100-105 7.92 21100-429 7.42 21100-513 5.116 21100-677 6.132 21101-101 6.64 21100-112 7.92 21100-429 7.47 21100-515 7.103 21100-710 7.42 21101-101 7.107 21100-123 3.21 21100-429 7.50 21100-515 7.109 21100-710 7.47 21101-101 7.108 21100-142 7.111 21100-429 7.57 21100-515 7.93 21100-710 7.50 21101-101 7.22 21100-144 7.104 21100-429 7.93 21100-542 7.109 21100-710 7.57 21101-101 7.35 21100-144 7.111 21100-431 7.92 21100-553 6.134 21100-711 8.111 21101-101 7.42 21100-144 7.42 21100-435 2.34 21100-554 6.134 21100-712 7.109 21101-101 7.47 21100-144 7.47 21100-435 2.35 21100-558 3.19 21100-712 8.111 21101-101 7.50 21100-144 7.50 21100-435 5.106 21100-565 6.24 21100-719 7.46 21101-101 7.57 21100-144 7.57 21100-435 6.10 21100-566 6.24 21100-721 7.111 21101-101 7.78 21100-146 6.132 21100-435 6.11 21100-569 7.103 21100-721 7.22 21101-101 7.93 21100-146 7.103 21100-435 6.12 21100-574 8.111 21100-721 7.35 21101-102 5.39 21100-150 7.93 21100-435 6.13 21100-586 3.16 21100-721 7.42 21101-102 5.70 21100-207 5.107 21100-435 6.14 21100-591 6.63 21100-721 7.47 21101-102 5.95 21100-207 5.116 21100-435 6.15 21100-591 7.107 21100-721 7.50 21101-102 6.109 21100-207 5.117 21100-435 6.66 21100-624 7.13 21100-721 7.57 21101-102 6.57 12.22 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. 21101-102 6.64 21101-102 7.108 21101-104 21101-219 7.35 21101-705 6.53 21101-775 6.49 21101-850 7.107 21101-220 7.110 21101-705 7.6 21101-775 7.6 21101-853 5.22 4.10 21101-220 7.22 21101-705 7.91 21101-776 6.49 21101-853 5.55 21101-106 7.108 21101-220 7.42 21101-705 9.10 21101-778 7.6 21101-853 6.110 21101-121 5.39 21101-220 7.47 21101-705 9.11 21101-782 6.64 21101-853 6.21 21101-121 5.70 21101-220 7.50 21101-705 9.12 21101-782 7.108 21101-853 6.23 21101-121 5.95 21101-221 7.110 21101-705 9.13 21101-783 6.64 21101-853 6.50 21101-121 6.109 21101-221 7.57 21101-705 9.14 21101-783 7.108 21101-853 6.53 21101-121 6.57 21101-222 7.110 21101-705 9.15 21101-809 1.111 21101-853 6.97 21101-121 7.111 21101-222 7.57 21101-705 9.2 21101-809 1.141 21101-853 7.19 21101-122 2.39 21101-239 7.55 21101-705 9.3 21101-809 1.169 21101-853 7.33 21101-122 2.42 21101-239 7.78 21101-705 9.4 21101-809 1.19 21101-853 7.40 21101-123 2.39 21101-246 4.13 21101-705 9.5 21101-809 1.191 21101-853 7.54 21101-123 2.42 21101-246 4.61 21101-705 9.7 21101-809 1.337 21101-853 7.6 21101-127 1.282 21101-252 11.7 21101-705 9.8 21101-809 1.338 21101-853 7.75 21101-132 1.315 21101-314 7.110 21101-705 9.9 21101-809 1.356 21101-853 8.111 21101-150 1.141 21101-323 7.108 21101-706 6.49 21101-809 1.357 21101-854 5.22 21101-150 1.24 21101-359 5.35 21101-706 6.53 21101-809 1.44 21101-854 5.55 21101-150 1.66 21101-359 5.68 21101-706 7.6 21101-809 1.61 21101-854 6.110 21101-150 1.93 21101-359 6.104 21101-707 6.20 21101-809 1.75 21101-854 6.50 21101-151 1.141 21101-359 6.33 21101-707 6.22 21101-809 1.88 21101-854 6.53 21101-151 1.24 21101-359 6.66 21101-707 6.49 21101-809 3.17 21101-854 7.19 21101-151 1.66 21101-359 7.111 21101-707 6.53 21101-809 5.106 21101-854 7.33 21101-151 1.93 21101-360 1.348 21101-707 7.6 21101-809 6.66 21101-854 7.40 21101-171 3.19 21101-360 1.350 21101-707 9.20 21101-810 1.141 21101-854 7.54 21101-172 3.19 21101-381 5.108 21101-708 6.49 21101-810 1.19 21101-854 7.6 21101-173 3.17 21101-529 3.33 21101-708 6.53 21101-810 1.337 21101-854 7.75 21101-173 3.19 21101-530 3.33 21101-708 7.6 21101-810 1.338 21101-854 8.111 21101-175 1.358 21101-531 3.33 21101-709 6.20 21101-810 1.356 21101-855 5.22 21101-175 1.359 21101-532 3.33 21101-709 6.49 21101-810 1.357 21101-855 5.39 21101-178 1.315 21101-533 3.33 21101-709 6.53 21101-810 1.61 21101-855 5.55 21101-201 1.276 21101-534 3.33 21101-709 7.6 21101-810 1.88 21101-855 5.70 21101-201 1.277 21101-539 1.276 21101-710 6.49 21101-810 3.17 21101-855 5.95 21101-201 1.280 21101-539 1.277 21101-710 6.53 21101-810 5.106 21101-855 6.109 21101-201 1.290 21101-539 1.290 21101-710 7.6 21101-810 6.66 21101-855 6.110 21101-201 1.296 21101-539 1.302 21101-713 6.20 21101-836 2.10 21101-855 6.21 21101-201 1.302 21101-596 1.283 21101-713 6.49 21101-836 2.11 21101-855 6.23 21101-201 1.308 21101-596 1.359 21101-713 6.53 21101-847 6.63 21101-855 6.53 21101-211 5.107 21101-658 10.5 21101-713 7.6 21101-847 7.107 21101-855 6.57 21101-211 5.117 21101-658 10.6 21101-714 6.49 21101-848 6.63 21101-855 6.97 21101-211 5.72 21101-658 10.7 21101-714 6.53 21101-848 7.107 21101-855 7.19 21101-211 5.87 21101-705 6.20 21101-714 7.6 21101-849 6.63 21101-855 7.29 21101-219 7.110 21101-705 6.22 21101-749 6.64 21101-849 7.107 21101-855 7.33 21101-219 7.22 21101-705 6.49 21101-749 7.108 21101-850 6.63 21101-855 7.40 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.23 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21101-855 7.54 21101-954 6.20 21117-170 1.303 21120-131 3.17 21126-271 3.14 21101-855 7.6 21101-954 6.21 21117-171 1.291 21120-132 3.17 21127-197 1.284 21101-855 7.75 21101-954 6.22 21117-171 1.303 21120-140 1.117 21127-197 1.298 21101-855 8.111 21101-954 6.23 21117-172 1.291 21120-140 1.151 21127-197 1.311 21101-855 6.50 21101-954 6.24 21117-172 1.303 21120-140 1.154 21127-198 1.284 21101-856 5.22 21101-958 4.12 21117-173 1.291 21120-140 1.176 21127-198 1.298 21101-856 5.55 21101-964 6.65 21117-173 1.303 21120-140 1.198 21127-198 1.311 21101-856 6.110 21101-964 7.111 21117-179 1.291 21120-140 1.24 21127-199 1.298 21101-856 6.50 21101-978 5.22 21117-179 1.303 21120-140 1.25 21127-199 1.311 21101-856 6.53 21101-978 7.6 21117-180 1.291 21120-140 1.282 21127-990 3.19 21101-856 7.19 21101-990 6.134 21117-180 1.303 21120-140 1.52 21130-001 1.159 21101-856 7.29 21102-001 5.50 21117-181 1.291 21120-140 1.66 21130-002 1.159 21101-856 7.33 21102-001 5.51 21117-181 1.303 21120-140 1.67 21130-003 1.103 21101-856 7.40 21102-001 5.52 21117-182 1.291 21120-140 1.83 21130-003 1.159 21101-856 7.54 21102-001 5.65 21117-182 1.303 21120-140 1.93 21130-003 1.29 21101-856 7.6 21102-007 7.62 21117-184 1.278 21120-140 1.94 21130-003 1.41 21101-856 7.75 21102-008 7.62 21117-185 1.278 21120-145 1.282 21130-003 1.99 21101-856 8.111 21102-013 4.16 21117-185 1.292 21120-146 1.282 21130-004 1.103 21101-857 5.22 21102-014 4.17 21117-185 1.304 21120-147 1.282 21130-004 1.159 21101-857 5.55 21102-015 4.17 21117-186 1.278 21120-148 3.18 21130-004 1.29 21101-857 7.6 21102-024 8.65 21117-186 1.292 21120-149 3.18 21130-004 1.41 21101-858 5.22 21102-025 7.100 21117-186 1.304 21120-150 3.37 21130-004 1.99 21101-858 5.55 21102-025 7.101 21117-187 1.278 21120-158 3.25 21130-005 1.103 21101-858 6.21 21117-158 1.291 21117-187 1.292 21120-158 3.26 21130-005 1.29 21101-858 6.50 21117-158 1.303 21117-187 1.304 21120-159 3.25 21130-005 1.41 21101-858 6.53 21117-159 1.291 21117-188 1.278 21120-159 3.26 21130-005 1.99 21101-858 7.6 21117-159 1.303 21117-188 1.292 21120-160 3.25 21130-006 1.103 21101-859 6.21 21117-160 1.291 21117-188 1.304 21120-160 3.26 21130-006 1.29 21101-859 6.50 21117-160 1.303 21117-189 1.278 21120-161 3.27 21130-006 1.41 21101-859 6.53 21117-161 1.291 21117-189 1.292 21120-161 6.126 21130-006 1.99 21101-859 7.6 21117-161 1.303 21117-189 1.304 21120-162 3.27 21130-007 1.103 21101-884 6.65 21117-162 1.291 21117-190 1.278 21120-162 6.126 21130-007 1.159 21101-904 6.50 21117-162 1.303 21117-190 1.292 21120-163 3.27 21130-007 1.29 21101-904 6.53 21117-163 1.291 21117-190 1.304 21120-163 6.126 21130-007 1.41 21101-904 7.6 21117-163 1.303 21117-191 1.278 21120-164 3.28 21130-007 1.99 21101-906 7.108 21117-164 1.291 21117-191 1.292 21120-165 3.28 21130-008 1.103 21101-909 6.64 21117-164 1.303 21117-191 1.304 21120-166 3.28 21130-008 1.159 21101-909 7.108 21117-167 1.291 21117-198 1.304 21120-178 4.63 21130-008 1.29 21101-914 7.63 21117-167 1.303 21117-199 1.304 21120-178 4.66 21130-008 1.41 21101-937 7.92 21117-168 1.291 21117-200 1.304 21120-189 1.254 21130-008 1.99 21101-954 4.10 21117-168 1.303 21120-127 3.18 21120-189 1.267 21130-009 1.29 21101-954 4.12 21117-169 1.291 21120-128 3.18 21120-189 1.286 21130-009 1.41 21101-954 4.6 21117-169 1.303 21120-129 3.18 21120-189 1.299 21130-010 1.103 21101-954 4.7 21117-170 1.291 21120-130 3.18 21120-189 1.313 21130-010 1.159 12.24 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. 21130-010 1.29 21130-036 1.71 21130-067 1.99 21130-092 1.163 21130-128 1.30 21130-010 1.41 21130-038 1.71 21130-068 1.29 21130-093 1.163 21130-129 1.160 21130-010 1.99 21130-041 1.159 21130-068 1.103 21130-093 1.29 21130-129 1.30 21130-011 1.103 21130-042 1.159 21130-068 1.163 21130-094 1.163 21130-130 1.160 21130-011 1.159 21130-043 1.159 21130-068 1.41 21130-095 1.29 21130-130 1.30 21130-011 1.29 21130-043 1.29 21130-068 1.99 21130-097 1.163 21130-131 1.160 21130-011 1.41 21130-044 1.159 21130-069 1.103 21130-097 1.29 21130-131 1.30 21130-011 1.99 21130-044 1.29 21130-069 1.163 21130-098 1.163 21130-132 1.160 21130-012 1.159 21130-045 1.29 21130-069 1.29 21130-098 1.29 21130-132 1.30 21130-013 1.159 21130-046 1.29 21130-069 1.41 21130-099 1.163 21130-136 1.161 21130-014 1.29 21130-047 1.159 21130-069 1.99 21130-099 1.29 21130-137 1.161 21130-014 1.41 21130-047 1.29 21130-070 1.103 21130-100 1.163 21130-138 1.161 21130-015 1.103 21130-048 1.159 21130-070 1.163 21130-100 1.29 21130-138 1.31 21130-015 1.159 21130-048 1.29 21130-070 1.29 21130-101 1.163 21130-139 1.161 21130-015 1.29 21130-049 1.29 21130-070 1.41 21130-101 1.29 21130-140 1.31 21130-015 1.41 21130-050 1.159 21130-070 1.99 21130-102 1.163 21130-142 1.161 21130-015 1.99 21130-050 1.29 21130-071 1.103 21130-102 1.29 21130-142 1.31 21130-016 1.103 21130-051 1.159 21130-071 1.163 21130-106 1.161 21130-143 1.161 21130-016 1.159 21130-051 1.29 21130-071 1.29 21130-107 1.161 21130-143 1.31 21130-016 1.29 21130-052 1.159 21130-071 1.41 21130-108 1.161 21130-144 1.161 21130-016 1.41 21130-053 1.159 21130-071 1.99 21130-108 1.31 21130-144 1.31 21130-016 1.99 21130-054 1.29 21130-072 1.103 21130-109 1.161 21130-145 1.161 21130-017 1.159 21130-055 1.159 21130-072 1.163 21130-110 1.31 21130-145 1.31 21130-018 1.159 21130-055 1.29 21130-072 1.29 21130-112 1.161 21130-146 1.161 21130-023 1.107 21130-056 1.159 21130-072 1.41 21130-112 1.31 21130-146 1.31 21130-023 1.71 21130-056 1.29 21130-072 1.99 21130-113 1.161 21130-147 1.161 21130-024 1.107 21130-057 1.159 21130-078 1.107 21130-113 1.31 21130-147 1.31 21130-024 1.71 21130-058 1.159 21130-078 1.71 21130-114 1.161 21130-151 1.161 21130-025 1.107 21130-061 1.163 21130-080 1.107 21130-114 1.31 21130-152 1.161 21130-025 1.71 21130-062 1.163 21130-080 1.71 21130-115 1.161 21130-153 1.103 21130-026 1.107 21130-063 1.103 21130-081 1.107 21130-115 1.31 21130-153 1.161 21130-026 1.71 21130-063 1.163 21130-082 1.107 21130-116 1.161 21130-153 1.31 21130-027 1.107 21130-063 1.29 21130-082 1.71 21130-116 1.31 21130-153 1.41 21130-027 1.71 21130-063 1.41 21130-083 1.107 21130-117 1.161 21130-153 1.99 21130-028 1.107 21130-063 1.99 21130-083 1.71 21130-117 1.31 21130-154 1.161 21130-028 1.71 21130-064 1.163 21130-084 1.107 21130-121 1.160 21130-155 1.103 21130-030 1.107 21130-065 1.103 21130-084 1.71 21130-122 1.160 21130-155 1.31 21130-030 1.71 21130-065 1.29 21130-085 1.107 21130-123 1.160 21130-155 1.41 21130-031 1.107 21130-065 1.41 21130-085 1.71 21130-123 1.30 21130-155 1.99 21130-031 1.71 21130-065 1.99 21130-086 1.107 21130-124 1.160 21130-157 1.103 21130-033 1.71 21130-067 1.103 21130-086 1.71 21130-125 1.30 21130-157 1.161 21130-035 1.107 21130-067 1.163 21130-087 1.107 21130-127 1.160 21130-157 1.31 21130-035 1.71 21130-067 1.29 21130-087 1.71 21130-127 1.30 21130-157 1.41 21130-036 1.107 21130-067 1.41 21130-091 1.163 21130-128 1.160 21130-157 1.99 SCHROFF.PENTAIR.CO.UK Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.25 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21130-158 1.103 21130-183 1.160 21130-214 1.162 21130-246 1.186 21130-265 1.186 21130-158 1.161 21130-183 1.30 21130-215 1.32 21130-246 1.33 21130-266 1.164 21130-158 1.31 21130-183 1.41 21130-217 1.162 21130-246 1.41 21130-266 1.186 21130-158 1.41 21130-185 1.30 21130-217 1.32 21130-246 1.99 21130-266 1.33 21130-158 1.99 21130-185 1.41 21130-218 1.162 21130-247 1.103 21130-267 1.164 21130-159 1.103 21130-187 1.160 21130-218 1.32 21130-247 1.164 21130-267 1.186 21130-159 1.161 21130-187 1.30 21130-219 1.162 21130-247 1.186 21130-267 1.33 21130-159 1.31 21130-187 1.41 21130-219 1.32 21130-247 1.33 21130-268 1.164 21130-159 1.41 21130-188 1.160 21130-220 1.162 21130-247 1.41 21130-268 1.186 21130-159 1.99 21130-188 1.30 21130-220 1.32 21130-247 1.99 21130-269 1.164 21130-160 1.103 21130-188 1.41 21130-221 1.162 21130-248 1.164 21130-269 1.186 21130-160 1.161 21130-189 1.160 21130-221 1.32 21130-248 1.186 21130-272 1.107 21130-160 1.31 21130-189 1.30 21130-222 1.162 21130-249 1.164 21130-272 1.72 21130-160 1.41 21130-189 1.41 21130-222 1.32 21130-249 1.186 21130-273 1.107 21130-160 1.99 21130-190 1.160 21130-231 1.160 21130-252 1.165 21130-273 1.72 21130-161 1.103 21130-190 1.30 21130-232 1.160 21130-252 1.187 21130-275 1.72 21130-161 1.161 21130-190 1.41 21130-232 1.30 21130-252 1.34 21130-276 1.107 21130-161 1.31 21130-191 1.160 21130-233 1.30 21130-253 1.165 21130-276 1.72 21130-161 1.41 21130-191 1.30 21130-234 1.160 21130-253 1.187 21130-277 1.107 21130-161 1.99 21130-191 1.41 21130-234 1.30 21130-253 1.34 21130-277 1.72 21130-162 1.103 21130-192 1.160 21130-235 1.160 21130-254 1.165 21130-281 1.104 21130-162 1.161 21130-192 1.30 21130-235 1.30 21130-254 1.187 21130-281 1.108 21130-162 1.31 21130-192 1.41 21130-236 1.160 21130-255 1.165 21130-281 1.42 21130-162 1.41 21130-198 1.107 21130-236 1.30 21130-255 1.187 21130-281 1.73 21130-162 1.99 21130-198 1.71 21130-241 1.33 21130-256 1.165 21130-282 1.104 21130-168 1.107 21130-200 1.107 21130-241 1.41 21130-256 1.187 21130-282 1.108 21130-168 1.71 21130-200 1.71 21130-242 1.103 21130-256 1.34 21130-282 1.42 21130-170 1.107 21130-201 1.107 21130-242 1.164 21130-257 1.165 21130-282 1.73 21130-170 1.71 21130-202 1.107 21130-242 1.186 21130-257 1.187 21130-283 1.104 21130-171 1.107 21130-202 1.71 21130-242 1.33 21130-257 1.34 21130-283 1.108 21130-172 1.107 21130-203 1.107 21130-242 1.41 21130-258 1.165 21130-283 1.42 21130-172 1.71 21130-203 1.71 21130-242 1.99 21130-258 1.187 21130-283 1.73 21130-173 1.107 21130-204 1.107 21130-243 1.103 21130-259 1.165 21130-284 1.104 21130-173 1.71 21130-204 1.71 21130-243 1.164 21130-259 1.187 21130-284 1.108 21130-174 1.107 21130-205 1.107 21130-243 1.186 21130-261 1.33 21130-284 1.42 21130-174 1.71 21130-205 1.71 21130-243 1.33 21130-262 1.164 21130-284 1.73 21130-175 1.107 21130-206 1.107 21130-243 1.41 21130-262 1.186 21130-285 1.42 21130-175 1.71 21130-206 1.71 21130-243 1.99 21130-262 1.33 21130-287 1.73 21130-176 1.107 21130-207 1.107 21130-244 1.164 21130-263 1.164 21130-291 1.108 21130-176 1.71 21130-207 1.71 21130-244 1.186 21130-263 1.186 21130-291 1.73 21130-177 1.107 21130-211 1.162 21130-245 1.164 21130-263 1.33 21130-292 1.108 21130-177 1.71 21130-212 1.162 21130-245 1.186 21130-264 1.164 21130-292 1.73 21130-181 1.160 21130-213 1.162 21130-246 1.103 21130-264 1.186 21130-293 1.108 21130-182 1.160 21130-213 1.32 21130-246 1.164 21130-265 1.164 21130-293 1.73 12.26 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21130-294 1.108 21130-327 1.78 21130-345 1.91 21130-354 1.50 21130-401 1.166 21130-294 1.73 21130-332 1.112 21130-352 1.113 21130-354 1.65 21130-401 1.188 21130-296 1.73 21130-332 1.171 21130-352 1.115 21130-354 1.79 21130-401 1.35 21130-302 1.114 21130-332 1.47 21130-352 1.145 21130-354 1.81 21130-402 1.166 21130-302 1.173 21130-332 1.78 21130-352 1.172 21130-354 1.92 21130-402 1.188 21130-302 1.49 21130-333 1.112 21130-352 1.174 21130-355 1.113 21130-402 1.35 21130-302 1.80 21130-333 1.171 21130-352 1.23 21130-355 1.115 21130-403 1.166 21130-303 1.114 21130-333 1.47 21130-352 1.254 21130-355 1.145 21130-403 1.188 21130-303 1.143 21130-333 1.78 21130-352 1.267 21130-355 1.172 21130-403 1.35 21130-303 1.173 21130-334 1.112 21130-352 1.286 21130-355 1.23 21130-404 1.166 21130-303 1.21 21130-334 1.171 21130-352 1.299 21130-355 1.254 21130-404 1.188 21130-303 1.49 21130-334 1.47 21130-352 1.313 21130-355 1.267 21130-405 1.166 21130-303 1.80 21130-334 1.78 21130-352 1.48 21130-355 1.286 21130-405 1.188 21130-303 1.90 21130-335 1.112 21130-352 1.50 21130-355 1.299 21130-406 1.166 21130-304 1.114 21130-335 1.171 21130-352 1.79 21130-355 1.313 21130-406 1.188 21130-304 1.49 21130-335 1.47 21130-352 1.81 21130-355 1.48 21130-407 1.166 21130-304 1.80 21130-335 1.78 21130-352 1.92 21130-355 1.50 21130-407 1.188 21130-305 1.114 21130-336 1.171 21130-353 1.113 21130-355 1.65 21130-412 1.110 21130-305 1.21 21130-337 1.171 21130-353 1.115 21130-355 1.79 21130-412 1.18 21130-305 1.49 21130-342 1.114 21130-353 1.145 21130-355 1.81 21130-412 1.46 21130-305 1.63 21130-342 1.144 21130-353 1.172 21130-355 1.92 21130-412 1.60 21130-305 1.80 21130-342 1.173 21130-353 1.174 21130-357 1.254 21130-412 1.77 21130-305 1.90 21130-342 1.22 21130-353 1.23 21130-357 1.267 21130-413 1.110 21130-309 1.143 21130-342 1.49 21130-353 1.254 21130-358 1.254 21130-413 1.170 21130-309 1.173 21130-342 1.80 21130-353 1.267 21130-358 1.267 21130-413 1.18 21130-309 1.80 21130-342 1.91 21130-353 1.286 21130-372 1.113 21130-413 1.192 21130-322 1.112 21130-343 1.114 21130-353 1.299 21130-372 1.172 21130-413 1.46 21130-322 1.171 21130-343 1.144 21130-353 1.313 21130-372 1.48 21130-413 1.60 21130-322 1.47 21130-343 1.173 21130-353 1.48 21130-372 1.79 21130-413 1.77 21130-322 1.78 21130-343 1.22 21130-353 1.50 21130-373 1.113 21130-414 1.110 21130-323 1.112 21130-343 1.49 21130-353 1.79 21130-373 1.172 21130-414 1.170 21130-323 1.171 21130-343 1.80 21130-353 1.81 21130-373 1.48 21130-414 1.18 21130-323 1.47 21130-343 1.91 21130-353 1.92 21130-373 1.79 21130-414 1.192 21130-323 1.78 21130-344 1.114 21130-354 1.113 21130-374 1.113 21130-414 1.46 21130-324 1.112 21130-344 1.22 21130-354 1.115 21130-374 1.172 21130-414 1.60 21130-324 1.171 21130-344 1.49 21130-354 1.145 21130-374 1.48 21130-414 1.77 21130-324 1.47 21130-344 1.64 21130-354 1.172 21130-374 1.79 21130-415 1.110 21130-324 1.78 21130-344 1.80 21130-354 1.23 21130-375 1.113 21130-415 1.18 21130-325 1.112 21130-344 1.91 21130-354 1.254 21130-375 1.172 21130-415 1.46 21130-325 1.171 21130-345 1.114 21130-354 1.267 21130-375 1.48 21130-415 1.60 21130-325 1.47 21130-345 1.22 21130-354 1.286 21130-375 1.79 21130-415 1.77 21130-325 1.78 21130-345 1.49 21130-354 1.299 21130-400 1.166 21130-416 1.110 21130-326 1.171 21130-345 1.64 21130-354 1.313 21130-400 1.188 21130-416 1.170 21130-327 1.171 21130-345 1.80 21130-354 1.48 21130-400 1.35 21130-416 1.18 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.27 Appendix Part no. Page Part no. Page Part no. Page Part no. 21130-416 1.192 21130-428 1.192 21130-445 1.110 21130-479 21130-416 1.46 21130-428 1.46 21130-445 1.170 21130-484 21130-416 1.60 21130-428 1.77 21130-445 1.192 21130-485 21130-416 1.77 21130-432 1.110 21130-445 1.46 21130-417 1.110 21130-432 1.170 21130-445 21130-417 1.170 21130-432 1.192 21130-417 1.18 21130-432 21130-417 1.192 21130-417 Part no. Page 1.37 21130-543 1.187 1.162 21130-544 1.165 1.162 21130-544 1.187 21130-486 1.162 21130-545 1.165 1.77 21130-486 1.32 21130-545 1.187 21130-446 1.110 21130-487 1.162 21130-546 1.164 1.46 21130-446 1.170 21130-488 1.32 21130-546 1.186 21130-432 1.77 21130-446 1.192 21130-490 1.162 21130-547 1.164 1.46 21130-433 1.110 21130-446 1.46 21130-490 1.32 21130-547 1.186 21130-417 1.60 21130-433 1.170 21130-446 1.77 21130-491 1.162 21130-548 1.164 21130-417 1.77 21130-433 1.192 21130-447 1.110 21130-491 1.32 21130-548 1.186 21130-418 1.110 21130-433 1.46 21130-447 1.170 21130-492 1.162 21130-549 1.164 21130-418 1.170 21130-433 1.77 21130-447 1.192 21130-492 1.32 21130-549 1.186 21130-418 1.192 21130-434 1.110 21130-447 1.46 21130-493 1.162 21130-550 1.171 21130-418 1.46 21130-434 1.46 21130-447 1.77 21130-493 1.32 21130-551 1.171 21130-418 1.77 21130-434 1.77 21130-452 1.162 21130-494 1.162 21130-552 1.171 21130-422 1.110 21130-435 1.110 21130-453 1.162 21130-494 1.32 21130-553 1.171 21130-422 1.46 21130-435 1.170 21130-454 1.162 21130-495 1.162 21130-554 1.161 21130-422 1.77 21130-435 1.192 21130-454 1.32 21130-495 1.32 21130-555 1.161 21130-423 1.110 21130-435 1.46 21130-455 1.162 21130-504 1.105 21130-556 1.161 21130-423 1.170 21130-435 1.77 21130-456 1.32 21130-504 1.43 21130-557 1.161 21130-423 1.192 21130-436 1.110 21130-458 1.162 21130-505 1.105 21130-557 1.183 21130-423 1.46 21130-436 1.170 21130-458 1.32 21130-505 1.43 21130-560 1.161 21130-423 1.77 21130-436 1.192 21130-459 1.162 21130-516 1.159 21130-561 1.161 21130-424 1.110 21130-436 1.46 21130-459 1.32 21130-517 1.159 21130-562 1.161 21130-424 1.170 21130-436 1.77 21130-460 1.162 21130-524 1.159 21130-563 1.161 21130-424 1.192 21130-437 1.110 21130-460 1.32 21130-525 1.159 21130-564 1.161 21130-424 1.46 21130-437 1.170 21130-461 1.162 21130-532 1.159 21130-565 1.161 21130-424 1.77 21130-437 1.192 21130-461 1.32 21130-533 1.159 21130-566 1.161 21130-425 1.110 21130-437 1.46 21130-462 1.162 21130-534 1.159 21130-567 1.161 21130-425 1.46 21130-437 1.77 21130-462 1.32 21130-535 1.159 21130-568 1.161 21130-425 1.77 21130-442 1.110 21130-463 1.162 21130-536 1.159 21130-568 1.31 21130-426 1.110 21130-442 1.170 21130-463 1.32 21130-537 1.159 21130-569 1.161 21130-426 1.170 21130-442 1.192 21130-472 1.101 21130-538 1.164 21130-570 1.31 21130-426 1.192 21130-442 1.46 21130-472 1.163 21130-538 1.186 21130-572 1.161 21130-426 1.46 21130-442 1.77 21130-472 1.37 21130-539 1.164 21130-572 1.31 21130-426 1.77 21130-443 1.110 21130-473 1.101 21130-539 1.186 21130-573 1.161 21130-427 1.110 21130-443 1.170 21130-473 1.163 21130-540 1.164 21130-573 1.31 21130-427 1.170 21130-443 1.192 21130-473 1.37 21130-540 1.186 21130-574 1.161 21130-427 1.192 21130-443 1.46 21130-478 1.101 21130-541 1.164 21130-574 1.31 21130-427 1.46 21130-443 1.77 21130-478 1.163 21130-541 1.186 21130-575 1.161 21130-427 1.77 21130-444 1.110 21130-478 1.37 21130-542 1.165 21130-575 1.31 21130-428 1.110 21130-444 1.46 21130-479 1.101 21130-542 1.187 21130-576 1.161 21130-428 1.170 21130-444 1.77 21130-479 1.163 21130-543 1.165 21130-576 1.31 12.28 SCHROFF Main catalogue www.schroff.biz E 05/2016 Page ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21130-577 1.161 21130-615 1.215 21130-637 1.221 21236-097 2.32 21500-082 6.77 21130-577 1.31 21130-616 1.205 21130-638 1.210 21236-099 2.27 21500-122 6.82 21130-578 1.109 21130-616 1.215 21130-638 1.221 21236-102 2.31 21500-123 6.82 21130-578 1.74 21130-617 1.205 21130-639 1.210 21236-103 2.28 21500-124 6.82 21130-579 1.109 21130-617 1.215 21130-639 1.221 21236-104 2.28 21591-079 8.17 21130-579 1.74 21130-618 1.210 21130-640 1.210 21236-120 2.30 21591-097 8.17 21130-580 1.109 21130-618 1.220 21130-640 1.222 21236-121 2.30 21591-099 8.17 21130-580 1.74 21130-619 1.210 21130-641 1.210 21236-122 2.30 21591-104 8.17 21130-581 1.109 21130-619 1.220 21130-641 1.222 21236-123 2.28 21591-107 8.17 21130-581 1.74 21130-620 1.210 21130-642 1.210 21236-125 2.28 21594-144 8.23 21130-583 1.204 1.214 21130-620 1.221 21130-642 1.222 21236-126 2.33 21594-144 8.9 21130-585 1.206 21130-621 1.210 21130-643 1.210 21236-127 2.27 21596-002 8.7 21130-585 1.216 21130-621 1.221 21130-643 1.222 21249-017 1.322 21596-003 8.20 21130-588 1.208 21130-622 1.210 21149-184 1.323 21249-017 1.323 21596-003 8.7 21130-588 1.218 21130-622 1.220 21149-184 1.326 21249-017 1.324 21596-008 8.17 21130-589 1.208 21130-623 1.210 21149-185 1.323 21249-017 1.325 21596-012 8.18 21130-589 1.218 21130-623 1.221 21149-185 1.326 21493-079 3.15 21596-020 8.21 21130-590 1.205 21130-624 1.210 21190-095 1.360 21500-027 6.78 21596-020 8.8 21130-590 1.215 21130-624 1.220 21190-095 2.29 21500-028 6.79 21596-020 8.9 21130-591 1.205 21130-625 1.210 21190-095 3.17 21500-029 6.78 21596-022 8.23 21130-591 1.215 21130-625 1.220 21190-435 2.26 21500-030 6.79 21596-022 8.7 21130-594 1.208 21130-626 1.210 21190-435 2.32 21500-037 6.75 21596-023 8.25 21130-594 1.218 21130-626 1.220 21190-435 2.7 21500-037 6.82 21596-023 8.7 21130-596 1.209 21130-627 1.210 21190-435 3.17 21500-038 6.82 21596-023 8.8 21130-596 1.219 21130-627 1.220 21190-571 1.357 21500-039 6.64 21596-023 8.9 21130-597 1.209 21130-628 1.210 21190-753 3.33 21500-039 6.75 21596-025 8.24 21130-597 1.219 21130-628 1.220 21190-793 1.348 21500-039 6.76 21596-025 8.9 21130-598 1.209 21130-629 1.210 21190-793 1.349 21500-039 6.78 21596-026 8.24 21130-598 1.219 21130-629 1.221 21191-207 8.20 21500-039 6.79 21596-026 8.8 21130-610 1.207 21130-630 1.210 21191-207 8.21 21500-039 6.81 21596-026 8.9 21130-610 1.217 21130-630 1.221 21191-207 8.6 21500-046 6.80 21596-077 8.5 21130-611 1.214 21130-631 1.210 21191-207 8.7 21500-047 6.80 21596-077 8.6 21130-611 1.215 21130-631 1.220 21191-207 8.8 21500-048 6.82 21596-138 8.8 21130-611 1.216 21130-632 1.210 21191-207 8.9 21500-067 6.78 21596-140 8.24 21130-611 1.217 21130-632 1.220 21236-089 2.26 21500-068 6.79 21596-140 8.8 21130-612 1.214 21130-633 1.210 21236-089 2.32 21500-069 6.80 21596-140 8.9 21130-612 1.216 21130-633 1.220 21236-090 2.31 21500-070 6.78 21596-236 8.22 21130-612 1.217 21130-634 1.210 21236-092 2.27 21500-071 6.79 21596-236 8.7 21130-613 1.214 21130-634 1.220 21236-093 1.153 21500-072 6.80 21596-273 8.7 21130-613 1.216 21130-635 1.210 21236-093 1.176 21500-077 6.75 21596-274 8.7 21130-613 1.217 21130-635 1.221 21236-093 1.198 21500-078 6.75 21596-278 8.8 21130-614 1.205 21130-636 1.210 21236-094 2.26 21500-079 6.76 21596-300 8.10 21130-614 1.215 21130-636 1.221 21236-095 2.33 21500-080 6.76 21596-300 8.18 21130-615 1.205 21130-637 1.210 21236-097 2.26 21500-081 6.77 21596-300 8.5 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.29 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 21596-300 8.6 21850-069 8.62 22114-455 1.282 22117-227 1.291 22117-593 1.303 21596-300 8.7 21850-070 8.62 22114-457 1.282 22117-227 1.303 22117-671 1.299 21596-300 8.8 21850-071 8.62 22114-458 1.282 22117-228 1.291 22117-671 1.312 21596-300 8.9 21850-081 8.46 22114-460 1.282 22117-228 1.303 22117-772 1.290 21596-301 8.10 21850-095 8.53 22114-461 1.282 22117-229 1.291 22117-773 1.290 21596-301 8.18 21850-102 8.64 22114-461 1.359 22117-229 1.303 22117-774 1.290 21596-301 8.6 21850-103 8.64 22114-462 1.282 22117-230 1.291 22117-775 1.290 21596-301 8.7 21850-104 8.64 22117-173 1.291 22117-230 1.303 22117-776 1.290 21596-301 8.8 21850-105 8.64 22117-173 1.303 22117-236 1.303 22117-777 1.290 21596-301 8.9 21850-106 8.64 22117-174 1.291 22117-237 1.303 22117-778 1.290 21596-324 8.14 21850-107 8.64 22117-174 1.303 22117-238 1.303 22117-779 1.290 21596-325 8.14 21850-108 8.65 22117-175 1.291 22117-239 1.291 22117-780 1.290 21596-327 8.8 21850-109 8.65 22117-175 1.303 22117-239 1.303 22117-781 1.290 21596-327 8.9 21850-112 8.53 22117-176 1.291 22117-352 1.297 22117-782 1.302 21596-370 8.4 21850-113 8.54 22117-176 1.303 22117-352 1.309 22117-783 1.302 21596-370 8.5 21850-114 8.54 22117-177 1.291 22117-353 1.297 22117-784 1.302 21596-376 8.13 21850-115 8.55 22117-177 1.303 22117-353 1.309 22117-785 1.302 21596-376 8.15 21850-116 8.55 22117-178 1.291 22117-354 1.297 22117-786 1.302 21596-515 8.23 21850-117 8.55 22117-178 1.303 22117-354 1.309 22117-787 1.302 21596-515 8.4 21850-118 8.55 22117-179 1.291 22117-355 1.297 22117-788 1.302 21596-515 8.5 21850-119 8.55 22117-179 1.303 22117-355 1.309 22117-789 1.302 21596-571 8.38 21850-120 8.55 22117-180 1.291 22117-356 1.297 22117-790 1.302 21596-571 8.39 21990-057 8.21 22117-180 1.303 22117-356 1.309 22117-791 1.302 21596-571 8.43 21990-057 8.6 22117-181 1.291 22117-357 1.297 22117-792 1.302 21596-571 8.44 21990-058 8.20 22117-181 1.303 22117-357 1.309 22117-793 1.302 21596-571 8.45 21990-058 8.6 22117-182 1.291 22117-358 1.297 22117-794 1.302 21596-571 8.50 21990-059 8.23 22117-182 1.303 22117-358 1.309 22117-796 1.302 21596-572 8.38 21990-059 8.6 22117-185 1.291 22117-376 1.287 22117-797 1.302 21596-572 8.39 21990-184 8.22 22117-185 1.303 22117-376 1.297 22117-798 1.279 21596-572 8.43 21990-184 8.8 22117-186 1.291 22117-377 1.287 22117-798 1.293 21596-572 8.44 21990-224 8.10 22117-186 1.303 22117-377 1.297 22117-799 1.305 21596-572 8.45 21990-224 8.21 22117-189 1.292 22117-378 1.297 22117-801 1.294 21596-572 8.50 21990-225 8.10 22117-189 1.304 22117-389 1.309 22117-801 1.306 21850-033 8.55 21990-225 8.21 22117-190 1.292 22117-389 1.312 22117-802 1.294 21850-034 8.55 21990-226 8.10 22117-190 1.304 22117-389 1.314 22117-802 1.306 21850-036 8.54 21990-226 8.25 22117-191 1.292 22117-390 1.309 22117-803 1.294 21850-037 8.55 21990-227 8.10 22117-191 1.304 22117-390 1.312 22117-803 1.306 21850-038 8.53 21990-227 8.22 22117-192 1.292 22117-390 1.314 22117-804 1.306 21850-045 8.46 21990-228 8.10 22117-192 1.304 22117-391 1.309 22117-806 1.294 21850-046 8.41 21990-228 8.23 22117-198 1.304 22117-391 1.312 22117-806 1.306 21850-057 8.62 21990-229 8.10 22117-199 1.304 22117-391 1.314 22117-807 1.294 21850-066 8.62 21990-229 8.23 22117-200 1.304 22117-592 1.291 22117-807 1.306 21850-067 8.62 22114-340 1.315 22117-201 1.292 22117-592 1.303 22117-808 1.294 21850-068 8.62 22114-342 1.315 22117-201 1.304 22117-593 1.291 22117-808 1.306 12.30 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 22117-809 1.306 22117-835 1.309 22117-866 1.296 22117-949 1.304 22117-979 1.290 22117-811 1.295 22117-836 1.297 22117-866 1.308 22117-950 1.304 22117-980 1.290 22117-811 1.307 22117-836 1.309 22117-867 1.308 22117-951 1.279 22117-981 1.290 22117-812 1.295 22117-837 1.297 22117-868 1.308 22117-951 1.292 22117-982 1.290 22117-812 1.307 22117-837 1.309 22117-869 1.281 22117-951 1.304 22117-983 1.290 22117-813 1.295 22117-838 1.297 22117-869 1.296 22117-952 1.304 22117-984 1.290 22117-813 1.307 22117-838 1.309 22117-869 1.308 22117-957 1.304 22117-985 1.302 22117-814 1.307 22117-839 1.309 22117-934 1.278 22117-958 1.291 22117-986 1.302 22117-821 1.294 22117-839 1.312 22117-935 1.278 22117-958 1.303 22117-987 1.302 22117-821 1.295 22117-840 1.309 22117-935 1.292 22117-959 1.291 22117-988 1.302 22117-821 1.306 22117-840 1.312 22117-935 1.304 22117-959 1.303 22117-989 1.302 22117-821 1.307 22117-842 1.285 22117-936 1.278 22117-960 1.291 22117-990 1.302 22117-822 1.294 22117-842 1.299 22117-936 1.292 22117-960 1.303 22117-991 1.302 22117-822 1.295 22117-842 1.312 22117-936 1.304 22117-961 1.291 22117-992 1.302 22117-822 1.306 22117-843 1.285 22117-937 1.278 22117-961 1.303 22117-993 1.291 22117-822 1.307 22117-843 1.299 22117-937 1.292 22117-962 1.291 22117-993 1.303 22117-823 1.294 22117-843 1.312 22117-937 1.304 22117-962 1.303 22117-994 1.291 22117-823 1.295 22117-844 1.299 22117-938 1.278 22117-963 1.291 22117-994 1.303 22117-823 1.306 22117-844 1.312 22117-938 1.292 22117-963 1.303 22117-995 1.291 22117-823 1.307 22117-845 1.299 22117-938 1.304 22117-964 1.291 22117-995 1.303 22117-824 1.306 22117-845 1.312 22117-939 1.304 22117-964 1.303 22117-996 1.291 22117-824 1.307 22117-846 1.314 22117-940 1.278 22117-965 1.291 22117-996 1.303 22117-825 1.306 22117-847 1.314 22117-940 1.292 22117-965 1.303 22117-997 1.291 22117-825 1.307 22117-848 1.314 22117-940 1.304 22117-966 1.291 22117-997 1.303 22117-826 1.280 22117-849 1.314 22117-941 1.304 22117-966 1.303 22117-998 1.291 22117-826 1.296 22117-850 1.314 22117-942 1.278 22117-967 1.291 22117-998 1.303 22117-826 1.308 22117-851 1.314 22117-942 1.292 22117-967 1.303 22117-999 1.291 22117-827 1.280 22117-852 1.314 22117-942 1.304 22117-968 1.291 22117-999 1.303 22117-827 1.296 22117-853 1.314 22117-943 1.279 22117-968 1.303 22127-094 1.298 22117-827 1.308 22117-854 1.314 22117-944 1.279 22117-969 1.291 22127-094 1.311 22117-828 1.296 22117-855 1.315 22117-944 1.292 22117-969 1.303 22127-095 1.298 22117-828 1.308 22117-856 1.315 22117-944 1.304 22117-970 1.291 22127-095 1.311 22117-829 1.308 22117-858 1.315 22117-945 1.279 22117-970 1.303 22127-096 1.298 22117-830 1.280 22117-859 1.315 22117-945 1.292 22117-971 1.291 22127-096 1.311 22117-830 1.296 22117-860 1.315 22117-945 1.304 22117-971 1.303 22130-001 1.181 22117-830 1.308 22117-861 1.315 22117-946 1.279 22117-972 1.291 22130-002 1.181 22117-831 1.280 22117-862 1.315 22117-946 1.292 22117-972 1.303 22130-003 1.103 22117-831 1.296 22117-863 1.315 22117-946 1.304 22117-973 1.292 22130-003 1.181 22117-831 1.308 22117-864 1.281 22117-947 1.279 22117-973 1.304 22130-003 1.29 22117-832 1.296 22117-864 1.296 22117-947 1.292 22117-975 1.292 22130-003 1.41 22117-832 1.308 22117-864 1.308 22117-947 1.304 22117-975 1.304 22130-003 1.99 22117-833 1.308 22117-865 1.281 22117-948 1.304 22117-976 1.304 22130-004 1.103 22117-834 1.308 22117-865 1.296 22117-949 1.279 22117-977 1.290 22130-004 1.181 22117-835 1.297 22117-865 1.308 22117-949 1.292 22117-978 1.290 22130-004 1.29 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.31 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 22130-004 1.41 22130-016 1.41 22130-053 1.181 22130-071 1.99 22130-108 1.31 22130-004 1.99 22130-016 1.99 22130-054 1.29 22130-072 1.103 22130-109 1.183 22130-005 1.103 22130-017 1.181 22130-055 1.181 22130-072 1.185 22130-110 1.31 22130-005 1.29 22130-018 1.181 22130-055 1.29 22130-072 1.29 22130-112 1.183 22130-005 1.41 22130-023 1.107 22130-056 1.181 22130-072 1.41 22130-112 1.31 22130-005 1.99 22130-023 1.71 22130-056 1.29 22130-072 1.99 22130-113 1.183 22130-006 1.103 22130-024 1.107 22130-057 1.181 22130-078 1.107 22130-113 1.31 22130-006 1.29 22130-024 1.71 22130-058 1.181 22130-078 1.71 22130-114 1.183 22130-006 1.41 22130-025 1.107 22130-061 1.185 22130-080 1.107 22130-114 1.31 22130-006 1.99 22130-025 1.71 22130-062 1.185 22130-080 1.71 22130-115 1.183 22130-007 1.103 22130-026 1.107 22130-063 1.103 22130-081 1.107 22130-115 1.31 22130-007 1.181 22130-026 1.71 22130-063 1.185 22130-082 1.107 22130-116 1.183 22130-007 1.29 22130-027 1.107 22130-063 1.29 22130-082 1.71 22130-116 1.31 22130-007 1.41 22130-027 1.71 22130-063 1.41 22130-083 1.107 22130-117 1.183 22130-007 1.99 22130-028 1.107 22130-063 1.99 22130-083 1.71 22130-117 1.31 22130-008 1.103 22130-028 1.71 22130-064 1.185 22130-084 1.107 22130-121 1.182 22130-008 1.181 22130-030 1.107 22130-065 1.103 22130-084 1.71 22130-122 1.182 22130-008 1.29 22130-030 1.71 22130-065 1.29 22130-085 1.107 22130-123 1.182 22130-008 1.41 22130-031 1.107 22130-065 1.41 22130-085 1.71 22130-123 1.30 22130-008 1.99 22130-031 1.71 22130-065 1.99 22130-086 1.107 22130-124 1.182 22130-009 1.29 22130-033 1.71 22130-067 1.103 22130-086 1.71 22130-125 1.30 22130-009 1.41 22130-035 1.107 22130-067 1.185 22130-087 1.107 22130-127 1.182 22130-010 1.103 22130-035 1.71 22130-067 1.29 22130-087 1.71 22130-127 1.30 22130-010 1.181 22130-036 1.107 22130-067 1.41 22130-091 1.185 22130-128 1.182 22130-010 1.29 22130-036 1.71 22130-067 1.99 22130-092 1.185 22130-128 1.30 22130-010 1.41 22130-038 1.71 22130-068 1.103 22130-093 1.185 22130-129 1.182 22130-010 1.99 22130-041 1.181 22130-068 1.29 22130-093 1.29 22130-129 1.30 22130-011 1.103 22130-042 1.181 22130-068 1.185 22130-094 1.185 22130-130 1.182 22130-011 1.181 22130-043 1.181 22130-068 1.41 22130-095 1.29 22130-130 1.30 22130-011 1.29 22130-043 1.29 22130-068 1.99 22130-097 1.185 22130-131 1.182 22130-011 1.41 22130-044 1.181 22130-069 1.103 22130-097 1.29 22130-131 1.30 22130-011 1.99 22130-044 1.29 22130-069 1.185 22130-098 1.185 22130-132 1.182 22130-012 1.181 22130-045 1.29 22130-069 1.29 22130-098 1.29 22130-132 1.30 22130-013 1.181 22130-046 1.29 22130-069 1.41 22130-099 1.185 22130-136 1.183 22130-014 1.29 22130-047 1.181 22130-069 1.99 22130-099 1.29 22130-137 1.183 22130-014 1.41 22130-047 1.29 22130-070 1.103 22130-100 1.185 22130-138 1.183 22130-015 1.103 22130-048 1.181 22130-070 1.185 22130-100 1.29 22130-138 1.31 22130-015 1.181 22130-048 1.29 22130-070 1.29 22130-101 1.185 22130-139 1.183 22130-015 1.29 22130-049 1.29 22130-070 1.41 22130-101 1.29 22130-140 1.31 22130-015 1.41 22130-050 1.181 22130-070 1.99 22130-102 1.185 22130-142 1.183 22130-015 1.99 22130-050 1.29 22130-071 1.103 22130-102 1.29 22130-142 1.31 22130-016 1.103 22130-051 1.181 22130-071 1.185 22130-106 1.183 22130-143 1.183 22130-016 1.181 22130-051 1.29 22130-071 1.29 22130-107 1.183 22130-143 1.31 22130-016 1.29 22130-052 1.181 22130-071 1.41 22130-108 1.183 22130-144 1.183 12.32 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. 22130-144 1.31 22130-162 1.103 22130-198 1.107 22130-145 1.183 22130-162 1.183 22130-198 1.71 22130-302 1.80 22130-333 1.193 22130-303 1.114 22130-333 1.47 22130-145 1.31 22130-162 1.31 22130-200 1.71 22130-303 1.143 22130-333 1.78 22130-146 1.183 22130-162 1.41 22130-201 1.107 22130-303 1.195 22130-334 1.112 22130-146 1.31 22130-162 1.99 22130-202 1.71 22130-303 1.21 22130-334 1.193 22130-147 1.183 22130-168 1.107 22130-203 1.71 22130-303 1.49 22130-334 1.47 22130-147 1.31 22130-168 1.71 22130-204 1.71 22130-303 1.80 22130-334 1.78 22130-151 1.183 22130-170 1.71 22130-205 1.107 22130-303 1.90 22130-335 1.112 22130-152 1.183 22130-171 1.107 22130-205 1.71 22130-304 1.114 22130-335 1.193 22130-153 1.103 22130-172 1.71 22130-206 1.107 22130-304 1.49 22130-335 1.47 22130-153 1.183 22130-173 1.71 22130-206 1.71 22130-304 1.80 22130-335 1.78 22130-153 1.31 22130-174 1.71 22130-207 1.107 22130-305 1.114 22130-336 1.193 22130-153 1.41 22130-175 1.107 22130-207 1.71 22130-305 1.21 22130-337 1.193 22130-153 1.99 22130-175 1.71 22130-211 1.184 22130-305 1.49 22130-342 1.114 22130-154 1.183 22130-176 1.107 22130-212 1.184 22130-305 1.63 22130-342 1.144 22130-155 1.103 22130-176 1.71 22130-213 1.184 22130-305 1.80 22130-342 1.195 22130-155 1.31 22130-177 1.107 22130-213 1.32 22130-305 1.90 22130-342 1.22 22130-155 1.41 22130-177 1.71 22130-214 1.184 22130-309 1.143 22130-342 1.49 22130-155 1.99 22130-181 1.182 22130-215 1.32 22130-309 1.195 22130-342 1.80 22130-157 1.103 22130-182 1.182 22130-217 1.184 22130-309 1.80 22130-342 1.91 22130-157 1.183 22130-183 1.182 22130-217 1.32 22130-322 1.112 22130-343 1.114 22130-157 1.31 22130-183 1.30 22130-218 1.184 22130-322 1.193 22130-343 1.144 22130-157 1.41 22130-183 1.41 22130-218 1.32 22130-322 1.47 22130-343 1.195 22130-157 1.99 22130-184 1.182 22130-219 1.184 22130-322 1.78 22130-343 1.22 22130-158 1.103 22130-185 1.30 22130-219 1.32 22130-323 1.112 22130-343 1.49 22130-158 1.183 22130-185 1.41 22130-220 1.184 22130-323 1.193 22130-343 1.80 22130-158 1.31 22130-187 1.182 22130-220 1.32 22130-323 1.47 22130-343 1.91 22130-158 1.41 22130-187 1.30 22130-221 1.184 22130-323 1.78 22130-344 1.114 22130-158 1.99 22130-187 1.41 22130-221 1.32 22130-324 1.112 22130-344 1.22 22130-159 1.103 22130-188 1.182 22130-222 1.184 22130-324 1.193 22130-344 1.49 22130-159 1.183 22130-188 1.30 22130-222 1.32 22130-324 1.47 22130-344 1.64 22130-159 1.31 22130-188 1.41 22130-231 1.182 22130-324 1.78 22130-344 1.80 22130-159 1.41 22130-189 1.182 22130-232 1.182 22130-325 1.112 22130-344 1.91 22130-159 1.99 22130-189 1.30 22130-232 1.30 22130-325 1.193 22130-345 1.114 22130-160 1.103 22130-189 1.41 22130-233 1.30 22130-325 1.47 22130-345 1.22 22130-160 1.183 22130-190 1.182 22130-234 1.182 22130-325 1.78 22130-345 1.49 22130-160 1.31 22130-190 1.30 22130-234 1.30 22130-326 1.193 22130-345 1.64 22130-160 1.41 22130-190 1.41 22130-235 1.182 22130-327 1.193 22130-345 1.80 22130-160 1.99 22130-191 1.182 22130-235 1.30 22130-327 1.78 22130-345 1.91 22130-161 1.103 22130-191 1.30 22130-236 1.182 22130-332 1.112 22130-352 1.113 22130-161 1.183 22130-191 1.41 22130-236 1.30 22130-332 1.193 22130-352 1.115 22130-161 1.31 22130-192 1.182 22130-302 1.114 22130-332 1.47 22130-352 1.145 22130-161 1.41 22130-192 1.30 22130-302 1.195 22130-332 1.78 22130-352 1.194 22130-161 1.99 22130-192 1.41 22130-302 1.49 22130-333 1.112 22130-352 1.196 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.33 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 22130-352 1.23 22130-373 1.194 22130-486 1.32 22130-568 1.183 23001-018 10.16 22130-352 1.48 22130-373 1.48 22130-487 1.184 22130-568 1.31 23001-020 10.16 22130-352 1.50 22130-373 1.79 22130-488 1.32 22130-569 1.183 23001-021 10.16 22130-352 1.79 22130-374 1.113 22130-490 1.184 22130-570 1.31 23001-032 10.17 22130-352 1.81 22130-374 1.194 22130-490 1.32 22130-572 1.183 23001-033 10.17 22130-352 1.92 22130-374 1.48 22130-491 1.184 22130-572 1.31 23001-034 10.17 22130-353 1.113 22130-374 1.79 22130-491 1.32 22130-573 1.183 23001-040 10.17 22130-353 1.115 22130-375 1.113 22130-492 1.184 22130-573 1.31 23001-046 10.17 22130-353 1.145 22130-375 1.194 22130-492 1.32 22130-574 1.183 23001-051 10.17 22130-353 1.194 22130-375 1.48 22130-493 1.184 22130-574 1.31 23001-063 10.15 22130-353 1.196 22130-375 1.79 22130-493 1.32 22130-575 1.183 23001-064 10.15 22130-353 1.23 22130-452 1.184 22130-494 1.184 22130-575 1.31 23001-065 10.15 22130-353 1.48 22130-453 1.184 22130-494 1.32 22130-576 1.183 23001-066 10.15 22130-353 1.50 22130-454 1.184 22130-495 1.184 22130-576 1.31 23001-067 10.15 22130-353 1.79 22130-454 1.32 22130-495 1.32 22130-577 1.183 23001-068 10.15 22130-353 1.81 22130-455 1.184 22130-504 1.105 22130-577 1.31 23001-069 10.15 22130-353 1.92 22130-456 1.32 22130-504 1.43 22130-578 1.109 23001-070 10.15 22130-354 1.113 22130-458 1.184 22130-505 1.105 22130-578 1.74 23001-072 10.15 22130-354 1.115 22130-458 1.32 22130-505 1.43 22130-579 1.109 23001-075 10.15 22130-354 1.145 22130-459 1.184 22130-516 1.181 22130-579 1.74 23001-080 10.15 22130-354 1.194 22130-459 1.32 22130-517 1.181 22130-580 1.109 23001-081 10.15 22130-354 1.23 22130-460 1.184 22130-524 1.181 22130-580 1.74 23001-502 10.13 22130-354 1.48 22130-460 1.32 22130-525 1.181 22130-581 1.109 23001-503 10.13 22130-354 1.50 22130-461 1.184 22130-532 1.181 22130-581 1.74 23001-504 10.13 22130-354 1.65 22130-461 1.32 22130-533 1.181 22130-583 1.204 23001-505 10.13 22130-354 1.79 22130-462 1.184 22130-534 1.181 22130-583 1.214 23001-506 10.13 22130-354 1.81 22130-462 1.32 22130-535 1.181 22349-024 1.319 23001-507 10.13 22130-354 1.92 22130-463 1.184 22130-536 1.181 22349-025 1.319 23001-508 10.13 22130-355 1.113 22130-463 1.32 22130-537 1.181 22349-026 1.319 23001-510 10.13 22130-355 1.115 22130-472 1.101 22130-550 1.193 22349-027 1.319 23001-511 10.13 22130-355 1.145 22130-472 1.185 22130-551 1.193 22349-032 1.321 23001-512 10.13 22130-355 1.194 22130-472 1.37 22130-552 1.193 22349-033 1.321 23001-515 10.13 22130-355 1.23 22130-473 1.101 22130-553 1.193 22349-034 1.321 23001-516 10.13 22130-355 1.48 22130-473 1.185 22130-554 1.183 23001-001 10.16 23001-520 10.13 22130-355 1.50 22130-473 1.37 22130-555 1.183 23001-002 10.16 23001-521 10.13 22130-355 1.65 22130-478 1.101 22130-556 1.183 23001-003 10.16 23001-532 10.13 22130-355 1.79 22130-478 1.185 22130-560 1.183 23001-004 10.16 23001-533 10.13 22130-355 1.81 22130-478 1.37 22130-561 1.183 23001-005 10.16 23001-534 10.13 22130-355 1.92 22130-479 1.101 22130-562 1.183 23001-006 10.16 23001-535 10.13 22130-372 1.113 22130-479 1.185 22130-563 1.183 23001-007 10.16 23001-536 10.13 22130-372 1.194 22130-479 1.37 22130-564 1.183 23001-009 10.16 23001-537 10.13 22130-372 1.48 22130-484 1.184 22130-565 1.183 23001-010 10.16 23001-538 10.13 22130-372 1.79 22130-485 1.184 22130-566 1.183 23001-015 10.16 23001-540 10.13 22130-373 1.113 22130-486 1.184 22130-567 1.183 23001-017 10.16 23001-541 10.13 12.34 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 23001-542 10.13 23006-575 10.11 23006-857 10.10 23021-608 10.21 23098-117 9.22 23001-545 10.13 23006-577 10.11 23006-862 10.6 23021-609 10.21 23098-117 9.26 23001-546 10.13 23006-578 10.11 23006-863 10.6 23021-610 10.21 23117-001 1.291 23001-550 10.13 23006-587 10.11 23006-864 10.6 23021-611 10.22 23117-001 1.303 23001-551 10.13 23006-594 10.11 23006-865 10.6 23021-613 10.23 23117-002 1.291 23001-701 10.14 23006-597 10.11 23006-866 10.6 23021-615 10.24 23117-002 1.303 23001-704 10.14 23006-601 10.8 23006-867 10.6 23021-616 10.23 23117-003 1.291 23001-712 10.14 23006-611 10.8 23006-868 10.6 23021-621 10.24 23117-003 1.303 23001-720 10.14 23006-615 10.8 23006-884 10.10 23021-651 10.20 23117-004 1.291 23001-812 10.12 23006-621 10.8 23006-887 10.10 23021-652 10.21 23117-004 1.303 23001-813 10.12 23006-715 10.7 23006-920 10.9 23021-653 10.21 23117-005 1.291 23001-814 10.12 23006-716 10.7 23006-922 10.9 23021-654 10.21 23117-005 1.303 23001-815 10.12 23006-718 10.7 23006-924 10.11 23021-655 10.22 23117-006 1.291 23006-300 10.6 23006-732 10.7 23006-931 10.6 23021-656 10.22 23117-006 1.303 23006-301 10.6 23006-734 10.7 23006-931 10.7 23021-657 10.23 23117-007 1.291 23006-303 10.6 23006-736 10.7 23007-010 10.19 23021-658 10.24 23117-007 1.303 23006-331 10.6 23006-738 10.7 23007-021 10.19 23021-660 10.23 23117-008 1.291 23006-331 10.7 23006-763 10.7 23007-040 10.19 23021-700 10.21 23117-008 1.303 23006-332 10.6 23006-764 10.7 23007-051 10.19 23021-701 10.21 23117-009 1.291 23006-334 10.6 23006-765 10.7 23007-081 10.19 23021-750 10.21 23117-009 1.303 23006-336 10.6 23006-768 10.7 23007-114 10.19 23022-002 10.25 23117-010 1.291 23006-337 10.6 23006-792 10.8 23007-128 10.19 23022-004 10.25 23117-010 1.303 23006-353 10.6 23006-793 10.8 23007-158 10.19 23022-010 10.25 23117-011 1.279 23006-354 10.6 23006-794 10.8 23007-188 10.19 23022-601 10.21 23117-011 1.292 23006-355 10.6 23006-795 10.8 23007-222 10.19 23022-602 10.21 23117-011 1.304 23006-358 10.6 23006-796 10.8 23007-410 10.19 23022-603 10.21 23117-012 1.278 23006-372 10.6 23006-797 10.8 23007-421 10.19 23022-604 10.23 23117-012 1.292 23006-373 10.6 23006-798 10.8 23007-601 10.5 23022-652 10.21 23117-012 1.304 23006-374 10.6 23006-799 10.8 23007-602 10.5 23022-700 10.21 23117-013 1.292 23006-375 10.6 23006-811 10.6 23007-611 10.4 23040-001 10.26 23117-013 1.304 23006-376 10.6 23006-811 10.7 23007-612 10.4 23098-100 10.18 23117-014 1.292 23006-377 10.6 23006-812 10.6 23007-613 10.4 23098-100 10.6 23117-014 1.304 23006-378 10.6 23006-813 10.6 23007-614 10.4 23098-105 10.18 23117-015 1.292 23006-405 10.7 23006-814 10.6 23007-624 10.4 23098-105 9.22 23117-015 1.304 23006-406 10.7 23006-815 10.6 23007-625 10.4 23098-105 9.26 23117-016 1.304 23006-408 10.7 23006-816 10.6 23021-001 10.25 23098-115 10.18 23117-017 1.297 23006-422 10.7 23006-817 10.6 23021-002 10.25 23098-115 9.22 23117-017 1.309 23006-424 10.7 23006-818 10.6 23021-100 10.25 23098-115 9.26 23117-018 1.297 23006-426 10.7 23006-824 10.10 23021-101 10.25 23098-116 10.18 23117-018 1.309 23006-428 10.7 23006-827 10.10 23021-103 10.25 23098-116 9.22 23117-019 1.297 23006-443 10.7 23006-833 10.6 23021-603 10.21 23098-116 9.23 23117-019 1.309 23006-444 10.7 23006-834 10.6 23021-604 10.22 23098-116 9.26 23117-020 1.287 23006-445 10.7 23006-835 10.6 23021-605 10.23 23098-116 9.27 23117-020 1.297 23006-448 10.7 23006-838 10.6 23021-607 10.20 23098-117 10.18 23117-020 1.310 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.35 Appendix Part no. Page Part no. 23117-021 1.287 23130-002 1.15 23130-012 1.75 23130-020 1.61 23130-027 1.19 23117-021 1.297 23130-002 1.167 23130-012 1.88 23130-020 1.88 23130-027 1.61 23117-021 1.310 23130-002 1.189 23130-013 1.111 23130-021 1.140 23130-027 1.88 23117-022 1.287 23130-002 1.36 23130-013 1.140 23130-021 1.19 23130-028 1.140 23117-022 1.297 23130-002 1.42 23130-013 1.19 23130-021 1.191 23130-028 1.19 23117-022 1.310 23130-003 1.135 23130-013 1.44 23130-021 1.61 23130-028 1.61 23117-023 1.287 23130-003 1.167 23130-013 1.61 23130-021 1.88 23130-028 1.88 23117-023 1.297 23130-003 1.189 23130-013 1.75 23130-022 1.111 23130-029 1.140 23117-023 1.310 23130-004 1.135 23130-013 1.88 23130-022 1.140 23130-029 1.19 23117-024 1.287 23130-004 1.167 23130-014 1.111 23130-022 1.19 23130-029 1.61 23117-024 1.297 23130-004 1.189 23130-014 1.140 23130-022 1.191 23130-029 1.88 23117-024 1.310 23130-005 1.100 23130-014 1.169 23130-022 1.44 23130-030 1.140 23117-025 1.287 23130-005 1.104 23130-014 1.19 23130-022 1.61 23130-030 1.19 23117-025 1.297 23130-005 1.135 23130-014 1.44 23130-022 1.75 23130-030 1.61 23117-025 1.310 23130-005 1.167 23130-014 1.61 23130-022 1.88 23130-030 1.88 23117-026 1.287 23130-005 1.189 23130-014 1.75 23130-023 1.111 23130-031 1.140 23117-026 1.297 23130-005 1.36 23130-014 1.88 23130-023 1.140 23130-031 1.169 23117-026 1.310 23130-005 1.42 23130-015 1.111 23130-023 1.19 23130-031 1.19 23117-027 1.287 23130-006 1.100 23130-015 1.140 23130-023 1.44 23130-031 1.191 23117-027 1.297 23130-006 1.104 23130-015 1.169 23130-023 1.61 23130-031 1.61 23117-027 1.310 23130-006 1.135 23130-015 1.19 23130-023 1.75 23130-031 1.88 23117-028 1.287 23130-006 1.167 23130-015 1.44 23130-023 1.88 23130-032 1.111 23117-028 1.297 23130-006 1.189 23130-015 1.61 23130-024 1.111 23130-032 1.140 23117-028 1.310 23130-006 1.36 23130-015 1.75 23130-024 1.140 23130-032 1.169 23117-029 1.287 23130-006 1.42 23130-015 1.88 23130-024 1.19 23130-032 1.19 23117-029 1.297 23130-007 1.135 23130-016 1.111 23130-024 1.191 23130-032 1.191 23117-029 1.310 23130-007 1.167 23130-016 1.140 23130-024 1.44 23130-032 1.44 23117-030 1.287 23130-007 1.189 23130-016 1.169 23130-024 1.61 23130-032 1.61 23117-030 1.297 23130-008 1.135 23130-016 1.44 23130-024 1.75 23130-032 1.75 23117-030 1.310 23130-008 1.167 23130-016 1.75 23130-024 1.88 23130-032 1.88 23117-031 1.287 23130-008 1.189 23130-017 1.140 23130-025 1.111 23130-033 1.111 23117-031 1.297 23130-009 1.36 23130-017 1.19 23130-025 1.140 23130-033 1.140 23117-031 1.310 23130-009 1.42 23130-017 1.61 23130-025 1.19 23130-033 1.19 23130-001 1.100 23130-011 1.140 23130-017 1.88 23130-025 1.191 23130-033 1.44 23130-001 1.104 23130-011 1.169 23130-018 1.140 23130-025 1.44 23130-033 1.61 23130-001 1.135 23130-011 1.19 23130-018 1.19 23130-025 1.61 23130-033 1.75 23130-001 1.15 23130-011 1.61 23130-018 1.61 23130-025 1.75 23130-033 1.88 23130-001 1.167 23130-011 1.88 23130-018 1.88 23130-025 1.88 23130-034 1.111 23130-001 1.189 23130-012 1.111 23130-019 1.140 23130-026 1.111 23130-034 1.140 23130-001 1.36 23130-012 1.140 23130-019 1.19 23130-026 1.140 23130-034 1.169 23130-001 1.42 23130-012 1.169 23130-019 1.61 23130-026 1.191 23130-034 1.19 23130-002 1.100 23130-012 1.19 23130-019 1.88 23130-026 1.44 23130-034 1.191 23130-002 1.104 23130-012 1.44 23130-020 1.140 23130-026 1.75 23130-034 1.44 23130-002 1.135 23130-012 1.61 23130-020 1.19 23130-027 1.140 23130-034 1.61 12.36 SCHROFF Main catalogue Page Part no. www.schroff.biz E 05/2016 Page Part no. Page Part no. Page ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. 23130-034 1.75 23130-056 1.45 23130-072 1.164 23130-077 1.180 23130-082 1.191 23130-034 1.88 23130-056 1.76 23130-072 1.165 23130-077 1.28 23130-082 1.193 23130-035 1.111 23130-061 1.158 23130-072 1.186 23130-077 1.40 23130-082 1.24 23130-035 1.140 23130-061 1.180 23130-072 1.187 23130-077 1.56 23130-082 1.47 23130-035 1.169 23130-061 1.28 23130-072 1.228 23130-077 1.57 23130-082 1.51 23130-035 1.19 23130-061 1.98 23130-072 1.229 23130-077 1.58 23130-082 1.66 23130-035 1.191 23130-062 1.102 23130-072 1.230 23130-077 1.70 23130-082 1.78 23130-035 1.44 23130-062 1.28 23130-072 1.232 23130-078 1.12 23130-082 1.82 23130-035 1.61 23130-062 1.40 23130-072 1.33 23130-078 1.13 23130-082 1.93 23130-035 1.75 23130-063 1.106 23130-072 1.34 23130-078 1.132 23130-083 1.141 23130-035 1.88 23130-063 1.70 23130-072 1.41 23130-078 1.14 23130-083 1.169 23130-036 1.111 23130-064 1.102 23130-072 1.56 23130-078 1.158 23130-083 1.191 23130-036 1.140 23130-064 1.40 23130-072 1.57 23130-078 1.180 23130-084 1.141 23130-036 1.169 23130-065 1.106 23130-072 1.72 23130-078 1.28 23130-084 1.169 23130-036 1.191 23130-065 1.70 23130-072 1.87 23130-078 1.40 23130-084 1.191 23130-036 1.44 23130-067 1.12 23130-072 1.99 23130-078 1.56 23130-084 1.82 23130-036 1.75 23130-067 1.13 23130-073 1.104 23130-078 1.57 23130-085 1.12 23130-037 1.140 23130-067 1.15 23130-073 1.42 23130-078 1.58 23130-085 1.13 23130-037 1.19 23130-067 1.160 23130-074 1.100 23130-078 1.70 23130-085 1.164 23130-037 1.61 23130-067 1.161 23130-074 1.135 23130-079 1.158 23130-085 1.186 23130-037 1.88 23130-067 1.182 23130-074 1.136 23130-079 1.180 23130-085 1.33 23130-038 1.140 23130-067 1.183 23130-074 1.15 23130-079 1.28 23130-085 1.86 23130-038 1.19 23130-067 1.30 23130-074 1.167 23130-079 1.40 23130-086 1.117 23130-038 1.61 23130-067 1.31 23130-074 1.189 23130-079 1.70 23130-086 1.151 23130-038 1.88 23130-067 2.28 23130-074 1.36 23130-081 1.112 23130-086 1.176 23130-039 1.140 23130-068 1.164 23130-075 1.100 23130-081 1.116 23130-086 1.198 23130-039 1.19 23130-068 1.186 23130-075 1.135 23130-081 1.141 23130-086 1.24 23130-039 1.61 23130-068 1.33 23130-075 1.15 23130-081 1.169 23130-086 1.52 23130-039 1.88 23130-069 1.134 23130-075 1.167 23130-081 1.17 23130-086 1.83 23130-040 1.140 23130-069 1.165 23130-075 1.189 23130-081 1.171 23130-086 1.93 23130-040 1.19 23130-069 1.187 23130-075 1.36 23130-081 1.191 23130-087 1.117 23130-040 1.61 23130-069 1.34 23130-076 1.100 23130-081 1.193 23130-087 1.151 23130-040 1.88 23130-070 1.133 23130-076 1.104 23130-081 1.24 23130-087 1.176 23130-050 1.155 23130-070 1.165 23130-076 1.135 23130-081 1.47 23130-087 1.198 23130-050 1.177 23130-070 1.187 23130-076 1.15 23130-081 1.51 23130-087 1.24 23130-050 1.199 23130-070 1.34 23130-076 1.167 23130-081 1.78 23130-087 1.52 23130-052 1.45 23130-071 1.134 23130-076 1.189 23130-081 1.82 23130-087 1.66 23130-052 1.76 23130-071 1.165 23130-076 1.36 23130-081 1.93 23130-087 1.83 23130-053 1.45 23130-071 1.187 23130-076 1.42 23130-082 1.112 23130-087 1.93 23130-053 1.76 23130-071 1.34 23130-077 1.12 23130-082 1.116 23130-088 1.151 23130-054 1.45 23130-072 1.103 23130-077 1.13 23130-082 1.141 23130-088 1.176 23130-054 1.76 23130-072 1.107 23130-077 1.132 23130-082 1.169 23130-088 1.198 23130-055 1.45 23130-072 1.133 23130-077 1.14 23130-082 1.17 23130-089 1.151 23130-055 1.76 23130-072 1.14 23130-077 1.158 23130-082 1.171 23130-089 1.176 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.37 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 23130-089 1.198 23130-096 1.142 23130-120 1.142 23130-140 1.172 23130-160 1.192 23130-089 1.83 23130-096 1.175 23130-120 1.175 23130-140 1.173 23130-160 1.46 23130-090 1.166 23130-096 1.197 23130-120 1.197 23130-140 1.174 23130-160 1.77 23130-090 1.188 23130-096 1.20 23130-120 1.82 23130-140 1.194 23130-164 1.101 23130-090 1.35 23130-096 1.51 23130-123 1.142 23130-140 1.195 23130-164 1.163 23130-090 1.58 23130-096 1.82 23130-123 1.175 23130-140 1.196 23130-164 1.185 23130-090 1.72 23130-096 1.89 23130-123 1.197 23130-140 1.22 23130-164 1.37 23130-091 1.111 23130-097 1.116 23130-123 1.20 23130-140 1.23 23130-165 1.133 23130-091 1.140 23130-097 1.20 23130-123 1.89 23130-140 1.48 23130-165 1.158 23130-091 1.169 23130-097 1.51 23130-124 1.20 23130-140 1.49 23130-165 1.159 23130-091 1.191 23130-097 1.62 23130-124 1.62 23130-140 1.50 23130-165 1.166 23130-091 1.44 23130-097 1.82 23130-124 1.89 23130-140 1.64 23130-165 1.188 23130-091 1.75 23130-097 1.89 23130-125 1.142 23130-140 1.65 23130-165 1.190 23130-092 1.113 23130-098 1.142 23130-125 1.175 23130-140 1.79 23130-165 1.35 23130-092 1.115 23130-098 1.175 23130-125 1.197 23130-140 1.80 23130-165 1.72 23130-092 1.145 23130-098 1.197 23130-132 1.159 23130-140 1.81 23130-166 1.36 23130-092 1.172 23130-098 1.82 23130-132 1.181 23130-140 1.91 23130-166 1.42 23130-092 1.174 23130-099 1.51 23130-132 1.29 23130-140 1.92 23130-169 1.137 23130-092 1.194 23130-101 1.142 23130-133 1.163 23130-141 1.132 23130-169 1.16 23130-092 1.196 23130-101 1.175 23130-133 1.185 23130-149 1.152 23130-169 1.168 23130-092 1.23 23130-101 1.197 23130-133 1.29 23130-149 1.159 23130-169 1.190 23130-092 1.254 23130-101 1.20 23130-134 1.100 23130-149 1.181 23130-169 1.36 23130-092 1.267 23130-101 1.89 23130-134 1.135 23130-150 1.152 23130-169 1.42 23130-092 1.286 23130-102 1.20 23130-134 1.136 23130-150 1.159 23130-169 1.73 23130-092 1.299 23130-102 1.62 23130-134 1.167 23130-150 1.181 23130-170 1.137 23130-092 1.313 23130-102 1.89 23130-134 1.189 23130-151 1.152 23130-170 1.16 23130-092 1.48 23130-103 1.142 23130-134 1.36 23130-151 1.159 23130-170 1.168 23130-092 1.50 23130-103 1.175 23130-135 1.100 23130-151 1.181 23130-170 1.190 23130-092 1.65 23130-103 1.197 23130-135 1.135 23130-153 1.210 23130-170 1.36 23130-092 1.79 23130-116 1.51 23130-135 1.167 23130-153 1.222 23130-170 1.42 23130-092 1.81 23130-118 1.116 23130-135 1.189 23130-158 1.110 23130-170 1.59 23130-092 1.92 23130-118 1.142 23130-135 1.36 23130-158 1.170 23130-170 1.73 23130-094 1.116 23130-118 1.175 23130-136 1.100 23130-158 1.18 23130-171 1.137 23130-094 1.142 23130-118 1.197 23130-136 1.104 23130-158 1.192 23130-171 1.168 23130-094 1.175 23130-118 1.20 23130-136 1.135 23130-158 1.46 23130-171 1.190 23130-094 1.197 23130-118 1.51 23130-136 1.167 23130-158 1.60 23130-172 1.137 23130-094 1.51 23130-118 1.82 23130-136 1.189 23130-158 1.77 23130-172 1.168 23130-094 1.82 23130-118 1.89 23130-136 1.36 23130-159 1.110 23130-172 1.190 23130-094 2.31 23130-119 1.116 23130-136 1.42 23130-159 1.170 23130-172 1.73 23130-095 1.142 23130-119 1.20 23130-140 1.113 23130-159 1.192 23130-187 1.137 23130-095 1.175 23130-119 1.51 23130-140 1.114 23130-159 1.46 23130-187 1.16 23130-095 1.197 23130-119 1.62 23130-140 1.115 23130-159 1.77 23130-187 1.168 23130-095 2.31 23130-119 1.82 23130-140 1.144 23130-160 1.110 23130-187 1.190 23130-096 1.116 23130-119 1.89 23130-140 1.145 23130-160 1.170 23130-187 1.36 12.38 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. 23130-187 1.42 23130-214 1.168 23130-329 1.150 23130-345 1.190 23130-362 1.168 23130-187 1.59 23130-214 1.190 23130-329 1.176 23130-346 1.139 23130-362 1.190 23130-187 1.73 23130-215 1.138 23130-329 1.198 23130-346 1.168 23130-363 1.137 23130-194 1.137 23130-215 1.168 23130-330 1.150 23130-346 1.190 23130-363 1.168 23130-194 1.168 23130-215 1.190 23130-330 1.176 23130-347 1.168 23130-363 1.190 23130-194 1.190 23130-220 1.160 23130-330 1.198 23130-347 1.190 23130-364 1.169 23130-194 1.36 23130-221 1.160 23130-331 1.176 23130-348 1.139 23130-364 1.191 23130-194 1.42 23130-221 1.30 23130-331 1.198 23130-348 1.168 23130-365 1.141 23130-194 1.73 23130-222 1.30 23130-332 1.150 23130-348 1.190 23130-365 1.169 23130-208 1.138 23130-223 1.160 23130-332 1.176 23130-349 1.139 23130-365 1.191 23130-208 1.16 23130-223 1.30 23130-332 1.198 23130-349 1.168 23130-366 1.176 23130-208 1.168 23130-224 1.160 23130-333 1.117 23130-349 1.190 23130-366 1.198 23130-208 1.190 23130-224 1.30 23130-333 1.154 23130-350 1.139 23130-367 1.151 23130-208 1.36 23130-225 1.160 23130-333 1.176 23130-350 1.168 23130-367 1.176 23130-208 1.42 23130-225 1.30 23130-333 1.198 23130-350 1.190 23130-367 1.198 23130-208 1.73 23130-230 1.182 23130-333 1.25 23130-351 1.168 23130-368 1.168 23130-209 1.138 23130-231 1.182 23130-333 1.52 23130-351 1.190 23130-368 1.190 23130-209 1.16 23130-231 1.30 23130-333 1.83 23130-352 1.139 23130-369 1.138 23130-209 1.168 23130-232 1.30 23130-333 1.94 23130-352 1.168 23130-369 1.168 23130-209 1.190 23130-233 1.182 23130-334 1.117 23130-352 1.190 23130-369 1.190 23130-209 1.36 23130-233 1.30 23130-334 1.154 23130-353 1.136 23130-370 1.168 23130-209 1.42 23130-234 1.182 23130-334 1.176 23130-353 1.167 23130-370 1.190 23130-209 1.59 23130-234 1.30 23130-334 1.198 23130-353 1.189 23130-371 1.138 23130-209 1.73 23130-235 1.182 23130-334 1.25 23130-354 1.136 23130-371 1.168 23130-210 1.138 23130-235 1.30 23130-334 1.52 23130-354 1.167 23130-371 1.190 23130-210 1.168 23130-274 1.113 23130-334 1.67 23130-354 1.189 23130-372 1.149 23130-210 1.190 23130-274 1.172 23130-334 1.83 23130-355 1.136 23130-372 1.177 23130-211 1.138 23130-274 1.194 23130-335 1.152 23130-355 1.167 23130-372 1.199 23130-211 1.168 23130-274 1.48 23130-335 1.159 23130-355 1.189 23130-373 1.159 23130-211 1.190 23130-274 1.79 23130-335 1.181 23130-356 1.167 23130-373 1.181 23130-211 1.73 23130-285 1.148 23130-336 1.148 23130-356 1.189 23130-374 1.136 23130-212 1.138 23130-310 1.143 23130-336 1.177 23130-357 1.136 23130-374 1.167 23130-212 1.168 23130-310 1.21 23130-336 1.199 23130-357 1.167 23130-374 1.189 23130-212 1.190 23130-310 1.63 23130-341 1.148 23130-357 1.189 23130-375 1.136 23130-212 1.36 23130-310 1.90 23130-341 1.177 23130-358 1.167 23130-375 1.167 23130-212 1.42 23130-312 1.153 23130-341 1.199 23130-358 1.189 23130-375 1.189 23130-212 1.73 23130-312 1.176 23130-342 1.148 23130-359 1.135 23130-376 1.167 23130-213 1.138 23130-312 1.198 23130-342 1.177 23130-359 1.167 23130-376 1.189 23130-213 1.168 23130-326 1.150 23130-342 1.199 23130-359 1.189 23130-377 1.136 23130-213 1.190 23130-326 1.176 23130-343 1.149 23130-360 1.167 23130-377 1.167 23130-213 1.36 23130-326 1.198 23130-343 1.162 23130-360 1.189 23130-377 1.189 23130-213 1.42 23130-328 1.150 23130-343 1.184 23130-361 1.135 23130-378 1.136 23130-213 1.73 23130-328 1.176 23130-345 1.139 23130-361 1.167 23130-378 1.167 23130-214 1.138 23130-328 1.198 23130-345 1.168 23130-361 1.189 23130-378 1.189 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part no. Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.39 Appendix Part no. Page Part no. Part no. Page Part no. Page Part no. 23130-379 1.149 23130-414 23130-379 1.162 23130-414 1.47 23130-477 1.223 23207-021 8.106 24560-080 6.12 1.76 23130-478 1.211 23207-022 8.107 24560-080 6.44 23130-379 1.184 23130-418 1.112 23130-478 1.223 23207-022 8.87 24560-081 6.12 23130-386 1.127 23130-418 1.17 23130-480 1.211 23207-028 8.106 24560-081 6.44 23130-386 1.129 23130-418 1.47 23130-480 1.223 23207-115 1.228 24560-082 6.44 23130-386 1.131 23130-418 1.76 23130-481 1.211 23207-115 1.229 24560-083 6.44 23130-386 1.139 23130-420 1.152 23130-481 1.223 23207-115 1.230 24560-130 5.34 23130-387 1.137 23130-420 1.159 23130-484 1.211 23207-115 1.234 24560-130 6.20 23130-387 1.16 23130-420 1.181 23130-484 1.223 24127-485 1.329 24560-130 6.21 23130-387 1.59 23130-421 1.152 23130-485 1.211 24127-487 1.329 24560-130 6.22 23130-387 1.73 23130-421 1.159 23130-485 1.223 24127-489 1.329 24560-130 6.23 23130-388 1.137 23130-421 1.181 23204-113 10.13 24127-491 1.329 24560-130 6.24 23130-388 1.73 23130-421 1.221 23204-113 10.14 24127-682 1.328 24560-130 6.25 23130-395 1.72 23130-422 1.152 23204-113 10.4 24127-686 1.328 24560-130 6.28 23130-396 1.72 23130-422 1.159 23204-113 10.5 24127-689 1.328 24560-130 6.30 23130-397 1.72 23130-422 1.181 23204-113 10.6 24127-694 1.328 24560-130 6.31 23130-398 1.72 23130-422 1.221 23204-113 10.7 24127-697 1.328 24560-130 6.32 23130-400 1.108 23130-433 1.208 23204-115 10.13 24496-120 8.110 24560-130 6.65 23130-400 1.73 23130-433 1.218 23204-115 10.14 24496-122 8.110 24560-130 7.110 23130-401 1.108 23130-437 1.204 23204-115 10.15 24560-031 6.45 24560-131 6.65 23130-401 1.73 23130-437 1.214 23204-115 10.16 24560-032 6.45 24560-135 6.47 23130-402 1.108 23130-443 1.72 23204-115 10.6 24560-033 6.45 24560-135 6.65 23130-402 1.73 23130-447 1.73 23204-115 10.7 24560-041 6.45 24560-135 6.83 23130-403 1.108 23130-453 1.206 23204-116 10.13 24560-042 6.45 24560-135 7.110 23130-403 1.73 23130-453 1.207 23204-116 10.14 24560-043 6.45 24560-139 6.55 23130-405 1.112 23130-453 1.216 23204-116 10.15 24560-051 6.45 24560-139 6.65 23130-405 1.17 23130-453 1.217 23204-116 10.16 24560-052 6.45 24560-139 7.109 23130-405 1.47 23130-454 1.102 23204-116 10.6 24560-053 6.45 24560-140 5.28 23130-405 1.76 23130-454 1.106 23204-116 10.7 24560-054 6.45 24560-140 6.103 23130-406 1.112 23130-454 1.98 23204-187 8.10 24560-055 6.45 24560-140 6.111 23130-406 1.47 23130-455 1.102 23204-187 8.18 24560-056 6.45 24560-140 6.55 23130-406 1.76 23130-455 1.106 23204-187 8.6 24560-061 6.44 24560-140 6.66 23130-407 1.112 23130-455 1.98 23204-187 8.7 24560-062 6.44 24560-140 7.111 23130-407 1.17 23130-456 1.102 23204-187 8.8 24560-063 6.44 24560-141 5.40 23130-407 1.47 23130-456 1.106 23204-187 8.9 24560-064 6.44 24560-141 5.41 23130-407 1.76 23130-456 1.98 23204-811 10.15 24560-065 6.44 24560-141 5.42 23130-408 1.112 23130-457 1.102 23204-811 10.16 24560-066 6.44 24560-141 5.73 23130-408 1.47 23130-457 1.106 23204-811 10.4 24560-071 6.44 24560-141 5.74 23130-408 1.76 23130-457 1.98 23204-811 10.5 24560-072 6.44 24560-141 5.92 23130-413 1.112 23130-473 1.205 23204-812 10.15 24560-073 6.44 24560-141 5.93 23130-413 1.17 23130-473 1.215 23204-812 10.16 24560-078 6.12 24560-141 6.105 23130-413 1.47 23130-475 1.211 23204-812 10.4 24560-078 6.44 24560-141 6.106 23130-413 1.76 23130-475 1.223 23204-812 10.5 24560-079 6.12 24560-141 6.12 23130-414 1.112 23130-477 1.211 23204-835 8.50 24560-079 6.44 24560-141 6.124 12.40 SCHROFF Main catalogue Page www.schroff.biz E 05/2016 Page ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. 24560-141 6.13 24560-155 6.23 24560-183 5.109 24560-141 6.14 24560-155 6.24 24560-183 6.25 24560-243 6.83 24560-255 6.9 24560-245 6.108 24560-255 6.94 24560-141 6.15 24560-155 6.28 24560-184 5.37 24560-245 6.111 24560-256 5.42 24560-141 6.36 24560-155 6.30 24560-184 5.64 24560-245 6.44 24560-256 6.106 24560-141 6.37 24560-155 6.65 24560-184 5.94 24560-245 6.45 24560-256 6.107 24560-141 6.38 24560-155 7.110 24560-184 6.59 24560-245 6.47 24560-256 6.14 24560-141 6.39 24560-157 5.41 24560-197 6.20 24560-245 6.82 24560-256 6.15 24560-141 6.64 24560-157 5.74 24560-198 6.20 24560-245 6.83 24560-256 6.38 24560-141 6.73 24560-157 5.93 24560-199 6.20 24560-246 6.108 24560-256 6.41 24560-141 6.74 24560-157 6.106 24560-199 6.21 24560-246 6.111 24560-256 6.81 24560-141 6.90 24560-157 6.37 24560-229 5.19 24560-246 6.44 24560-270 5.28 24560-141 6.94 24560-157 6.64 24560-229 5.54 24560-246 6.45 24560-270 5.38 24560-141 7.110 24560-157 6.94 24560-229 5.65 24560-246 6.47 24560-270 5.43 24560-145 5.39 24560-157 7.110 24560-229 6.110 24560-246 6.82 24560-270 5.71 24560-145 5.70 24560-158 5.42 24560-229 6.53 24560-255 5.40 24560-270 5.96 24560-145 5.95 24560-158 6.38 24560-231 5.19 24560-255 5.41 24560-270 6.49 24560-145 6.57 24560-158 6.39 24560-231 5.54 24560-255 5.42 24560-270 6.53 24560-145 6.65 24560-158 6.64 24560-231 5.65 24560-255 5.73 24560-270 6.54 24560-145 7.109 24560-158 7.109 24560-231 6.110 24560-255 5.74 24560-270 6.58 24560-146 5.37 24560-159 7.110 24560-231 6.53 24560-255 5.92 24560-270 6.61 24560-146 5.64 24560-159 7.22 24560-233 5.19 24560-255 5.93 24560-270 7.6 24560-146 5.94 24560-159 7.35 24560-233 5.54 24560-255 6.10 24560-270 7.91 24560-146 6.59 24560-161 10.28 24560-233 5.65 24560-255 6.105 24560-271 5.19 24560-147 11.4 24560-161 6.65 24560-233 6.110 24560-255 6.106 24560-271 5.28 24560-147 11.5 24560-161 7.110 24560-233 6.53 24560-255 6.107 24560-271 6.108 24560-147 5.35 24560-162 10.28 24560-235 5.19 24560-255 6.11 24560-271 6.111 24560-147 5.69 24560-162 6.65 24560-235 5.54 24560-255 6.12 24560-271 6.44 24560-147 5.91 24560-162 7.110 24560-235 5.65 24560-255 6.124 24560-271 6.45 24560-147 6.34 24560-163 10.28 24560-235 6.110 24560-255 6.13 24560-271 6.47 24560-147 6.65 24560-164 7.22 24560-235 6.53 24560-255 6.14 24560-271 6.82 24560-147 7.110 24560-164 7.35 24560-236 5.19 24560-255 6.15 24560-271 6.83 24560-147 7.22 24560-165 6.67 24560-236 5.65 24560-255 6.36 24560-280 6.54 24560-148 5.35 24560-166 6.67 24560-236 6.110 24560-255 6.37 24560-297 6.20 24560-148 5.69 24560-167 6.60 24560-236 6.53 24560-255 6.38 24560-298 6.20 24560-148 5.91 24560-178 7.78 24560-241 6.111 24560-255 6.39 24560-299 6.20 24560-148 6.34 24560-178 7.79 24560-241 6.44 24560-255 6.41 24560-299 6.21 24560-148 6.65 24560-179 5.39 24560-241 6.45 24560-255 6.73 24560-351 5.40 24560-148 7.110 24560-179 5.70 24560-241 6.47 24560-255 6.74 24560-351 5.73 24560-148 7.78 24560-179 5.95 24560-241 6.82 24560-255 6.75 24560-351 5.92 24560-151 6.65 24560-179 6.57 24560-241 6.83 24560-255 6.76 24560-351 6.10 24560-151 7.110 24560-179 6.64 24560-243 6.44 24560-255 6.78 24560-351 6.105 24560-155 6.20 24560-179 7.78 24560-243 6.45 24560-255 6.79 24560-351 6.11 24560-155 6.21 24560-180 6.54 24560-243 6.47 24560-255 6.8 24560-351 6.12 24560-155 6.22 24560-182 6.25 24560-243 6.82 24560-255 6.81 24560-351 6.13 SCHROFF.PENTAIR.CO.UK Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.41 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 24560-351 6.36 24560-359 6.14 24560-378 6.37 24560-840 6.104 24561-341 6.106 24560-351 6.73 24560-359 6.15 24560-378 6.39 24560-840 6.33 24561-341 6.38 24560-351 6.74 24560-359 6.38 24560-378 6.41 24560-842 5.35 24561-342 5.42 24560-351 6.8 24560-359 6.81 24560-378 7.102 24560-842 5.68 24561-342 6.38 24560-351 6.81 24560-360 5.42 24560-379 5.40 24560-842 5.90 24561-498 6.20 24560-351 6.88 24560-360 6.106 24560-379 5.73 24560-842 6.104 24561-498 6.22 24560-351 6.9 24560-360 6.15 24560-379 5.92 24560-842 6.33 24561-499 6.111 24560-351 6.94 24560-360 6.38 24560-379 6.10 24560-863 5.35 24561-499 6.55 24560-353 5.40 24560-361 5.42 24560-379 6.105 24560-863 5.68 24561-798 6.20 24560-353 5.73 24560-361 6.38 24560-379 6.11 24560-863 5.90 24562-197 6.25 24560-353 5.92 24560-362 5.42 24560-379 6.12 24560-863 6.104 24562-199 6.54 24560-353 6.10 24560-362 6.38 24560-379 6.13 24560-863 6.33 24562-297 6.25 24560-353 6.105 24560-373 5.41 24560-379 6.36 24560-884 5.35 24562-299 6.54 24560-353 6.11 24560-373 5.74 24560-379 6.73 24560-884 5.68 24562-420 5.39 24560-353 6.12 24560-373 5.93 24560-379 6.74 24560-884 5.90 24562-420 5.70 24560-353 6.13 24560-373 6.124 24560-379 6.8 24560-884 6.104 24562-420 5.95 24560-353 6.36 24560-373 6.37 24560-379 6.9 24560-884 6.33 24562-420 6.57 24560-353 6.73 24560-374 5.41 24560-380 5.40 24561-031 6.43 24562-440 5.39 24560-353 6.74 24560-374 5.74 24560-380 5.73 24561-041 6.43 24562-440 5.70 24560-353 6.75 24560-374 5.93 24560-380 5.92 24561-051 6.10 24562-440 5.95 24560-353 6.76 24560-374 6.124 24560-380 6.10 24561-051 6.43 24562-440 6.57 24560-353 6.78 24560-374 6.37 24560-380 6.105 24561-051 6.8 24562-442 5.39 24560-353 6.79 24560-375 5.41 24560-380 6.11 24561-051 6.9 24562-442 5.70 24560-353 6.8 24560-375 5.74 24560-380 6.12 24561-052 6.10 24562-442 5.95 24560-353 6.81 24560-375 5.93 24560-380 6.36 24561-052 6.43 24562-442 6.57 24560-353 6.9 24560-375 6.124 24560-380 6.73 24561-052 6.8 24562-446 3.22 24560-355 5.42 24560-375 6.37 24560-380 6.9 24561-052 6.9 24562-446 6.62 24560-355 6.106 24560-376 5.41 24560-381 7.104 24561-198 6.20 24562-449 3.22 24560-355 6.15 24560-376 5.74 24560-480 6.54 24561-198 6.22 24562-449 6.62 24560-355 6.38 24560-376 5.93 24560-497 6.20 24561-199 6.111 24562-451 3.22 24560-356 5.42 24560-376 6.124 24560-498 6.20 24561-199 6.55 24562-451 6.62 24560-356 6.106 24560-376 6.37 24560-499 6.20 24561-298 6.20 24562-452 3.22 24560-356 6.14 24560-377 5.41 24560-499 6.21 24561-330 5.42 24562-452 6.62 24560-356 6.15 24560-377 5.74 24560-797 6.20 24561-330 6.106 24562-453 3.23 24560-356 6.38 24560-377 5.93 24560-798 6.20 24561-330 6.38 24562-453 6.62 24560-356 6.81 24560-377 6.124 24560-799 6.20 24561-331 5.42 24562-454 3.23 24560-358 5.42 24560-377 6.37 24560-799 6.21 24561-331 6.106 24562-454 6.62 24560-358 6.106 24560-377 6.39 24560-820 6.104 24561-331 6.38 24562-455 3.23 24560-358 6.14 24560-377 6.41 24560-820 6.33 24561-332 5.42 24562-455 6.62 24560-358 6.15 24560-377 7.102 24560-828 5.35 24561-332 6.38 24562-456 3.23 24560-358 6.38 24560-378 5.41 24560-828 5.68 24561-340 5.42 24562-456 6.62 24560-358 6.81 24560-378 5.74 24560-828 5.90 24561-340 6.106 24562-457 3.23 24560-359 5.42 24560-378 5.93 24560-828 6.104 24561-340 6.38 24562-457 6.62 24560-359 6.106 24560-378 6.124 24560-828 6.33 24561-341 5.42 24562-458 3.23 12.42 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. 24562-458 6.62 24562-563 6.54 24563-432 6.10 24564-132 6.8 24566-102 6.103 24562-460 3.22 24562-584 5.19 24563-433 6.10 24564-133 6.8 24566-103 6.103 24562-460 6.62 24562-584 5.54 24563-434 6.10 24564-145 6.23 24566-104 6.103 24562-461 3.22 24562-584 5.67 24563-435 6.10 24564-147 6.23 24566-105 6.103 24562-461 6.62 24562-584 6.54 24563-436 6.10 24564-149 6.23 24566-105 6.111 24562-463 5.39 24562-797 6.25 24563-442 6.11 24564-151 6.23 24566-106 6.103 24562-463 5.70 24563-096 6.89 24563-443 6.11 24564-197 6.21 24566-125 6.22 24562-463 5.95 24563-100 6.89 24563-444 6.11 24564-198 6.21 24566-127 6.22 24562-463 6.57 24563-107 6.88 24563-445 6.11 24564-199 6.21 24566-129 6.22 24562-464 3.22 24563-108 6.88 24563-446 6.11 24564-199 6.23 24566-131 6.22 24562-464 6.62 24563-109 6.88 24563-452 6.14 24564-209 5.38 24566-145 6.23 24562-466 3.22 24563-110 6.88 24563-457 6.15 24564-209 5.71 24566-147 6.23 24562-466 6.62 24563-131 6.10 24563-461 6.12 24564-209 5.96 24566-149 6.23 24562-467 3.22 24563-132 6.10 24563-461 6.73 24564-209 6.58 24566-151 6.23 24562-467 6.62 24563-133 6.10 24563-462 6.12 24564-217 5.38 24566-199 6.97 24562-468 3.22 24563-134 6.10 24563-462 6.73 24564-217 5.71 24566-400 6.109 24562-468 6.62 24563-135 6.10 24563-463 6.12 24564-217 5.96 24566-425 6.22 24562-472 3.22 24563-136 6.10 24563-463 6.73 24564-217 6.58 24566-427 6.22 24562-472 6.62 24563-142 6.11 24563-464 6.12 24564-297 6.21 24566-429 6.22 24562-473 3.22 24563-143 6.11 24563-464 6.73 24564-298 6.21 24566-431 6.22 24562-473 6.62 24563-144 6.11 24563-472 6.13 24564-299 6.21 24566-445 6.23 24562-474 3.22 24563-145 6.11 24563-472 6.74 24564-431 6.8 24566-447 6.23 24562-474 6.62 24563-146 6.11 24563-473 6.13 24564-432 6.8 24566-449 6.23 24562-484 5.39 24563-152 6.14 24563-473 6.74 24564-433 6.8 24566-451 6.23 24562-484 5.70 24563-157 6.15 24563-474 6.13 24564-445 6.23 24566-499 6.97 24562-484 5.95 24563-161 6.12 24563-474 6.74 24564-447 6.23 24567-125 6.22 24562-484 6.57 24563-161 6.73 24563-491 6.9 24564-449 6.23 24567-127 6.22 24562-497 6.25 24563-162 6.12 24563-492 6.9 24564-451 6.23 24567-129 6.22 24562-499 6.54 24563-162 6.73 24563-493 6.9 24564-497 6.21 24567-131 6.22 24562-520 5.19 24563-163 6.12 24563-494 6.9 24564-498 6.21 24567-149 6.94 24562-520 6.54 24563-163 6.73 24564-100 6.89 24564-499 6.21 24567-161 6.12 24562-528 5.19 24563-164 6.12 24564-109 5.38 24564-499 6.23 24567-161 6.73 24562-528 5.54 24563-164 6.73 24564-109 5.71 24564-797 6.21 24567-162 6.12 24562-528 5.67 24563-172 6.13 24564-109 5.96 24564-798 6.21 24567-162 6.73 24562-528 6.54 24563-172 6.74 24564-109 6.58 24564-799 6.21 24567-163 6.12 24562-540 5.19 24563-173 6.13 24564-117 5.38 24565-100 6.89 24567-163 6.73 24562-540 6.54 24563-173 6.74 24564-117 5.71 24566-004 6.105 24567-164 6.12 24562-542 5.19 24563-174 6.13 24564-117 5.96 24566-004 6.94 24567-164 6.73 24562-542 5.54 24563-174 6.74 24564-117 6.58 24566-005 6.105 24567-172 6.13 24562-542 5.67 24563-191 6.9 24564-118 5.38 24566-005 6.94 24567-172 6.74 24562-542 6.54 24563-192 6.9 24564-118 5.71 24566-007 6.108 24567-173 6.13 24562-563 5.19 24563-193 6.9 24564-118 5.96 24566-010 6.97 24567-173 6.74 24562-563 5.54 24563-194 6.9 24564-118 6.58 24566-100 6.103 24567-174 6.13 24562-563 5.67 24563-431 6.10 24564-131 6.8 24566-101 6.103 24567-174 6.74 SCHROFF.PENTAIR.CO.UK Page Part no. Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days Page 12.43 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 24567-425 6.22 24571-029 5.11 24571-186 5.15 24571-309 5.26 24571-380 5.24 24567-427 6.22 24571-030 5.11 24571-187 5.15 24571-310 5.26 24571-395 5.12 24567-429 6.22 24571-038 5.11 24571-188 5.15 24571-314 5.26 24571-438 5.11 24567-431 6.22 24571-041 5.11 24571-194 5.15 24571-315 5.26 24571-441 5.11 24567-449 6.94 24571-042 5.11 24571-197 5.15 24571-316 5.26 24571-442 5.11 24567-461 6.12 24571-043 5.11 24571-206 5.15 24571-320 5.27 24571-443 5.11 24567-461 6.73 24571-044 5.11 24571-209 5.15 24571-321 5.27 24571-444 5.11 24567-462 6.12 24571-050 5.11 24571-210 5.15 24571-322 5.27 24571-486 5.11 24567-462 6.73 24571-053 5.11 24571-218 5.15 24571-325 5.23 24571-489 5.11 24567-463 6.12 24571-062 5.11 24571-221 5.15 24571-326 5.23 24571-490 5.11 24567-463 6.73 24571-065 5.11 24571-222 5.15 24571-327 5.23 24571-491 5.11 24567-464 6.12 24571-066 5.11 24571-223 5.15 24571-328 5.23 24571-492 5.11 24567-464 6.73 24571-074 5.11 24571-230 5.15 24571-331 5.18 24571-534 5.11 24567-472 6.13 24571-077 5.11 24571-233 5.15 24571-332 5.18 24571-537 5.11 24567-472 6.74 24571-078 5.11 24571-234 5.15 24571-333 5.18 24571-538 5.11 24567-473 6.13 24571-086 5.11 24571-235 5.15 24571-334 5.18 24571-539 5.11 24567-473 6.74 24571-089 5.11 24571-236 5.15 24571-335 5.18 24571-540 5.11 24567-474 6.13 24571-090 5.11 24571-242 5.15 24571-338 5.18 24571-582 5.15 24567-474 6.74 24571-091 5.11 24571-245 5.15 24571-339 5.18 24571-585 5.15 24568-004 6.108 24571-092 5.11 24571-254 5.15 24571-340 5.18 24571-586 5.15 24568-008 6.108 24571-098 5.11 24571-257 5.15 24571-341 5.18 24571-587 5.15 24568-012 6.108 24571-101 5.11 24571-258 5.15 24571-342 5.18 24571-588 5.15 24568-016 6.108 24571-110 5.11 24571-266 5.15 24571-349 5.24 24571-630 5.15 24568-020 6.108 24571-113 5.11 24571-269 5.15 24571-350 5.24 24571-633 5.15 24568-032 6.108 24571-114 5.11 24571-270 5.15 24571-351 5.24 24571-634 5.15 24568-036 6.108 24571-122 5.11 24571-271 5.15 24571-352 5.27 24571-635 5.15 24568-143 6.97 24571-125 5.11 24571-278 5.15 24571-353 5.27 24571-636 5.15 24568-144 6.97 24571-126 5.11 24571-281 5.15 24571-354 5.27 24571-678 5.15 24568-145 6.97 24571-134 5.11 24571-282 5.15 24571-355 5.27 24571-681 5.15 24568-147 6.97 24571-137 5.11 24571-283 5.15 24571-356 5.27 24571-682 5.15 24568-149 6.97 24571-138 5.11 24571-284 5.15 24571-359 5.27 24571-683 5.15 24568-151 6.97 24571-139 5.11 24571-295 5.25 24571-360 5.27 24571-684 5.15 24568-443 6.97 24571-140 5.11 24571-296 5.25 24571-361 5.27 24571-702 5.11 24568-444 6.97 24571-146 5.15 24571-297 5.25 24571-362 5.27 24571-705 5.11 24568-445 6.97 24571-149 5.15 24571-298 5.25 24571-363 5.27 24571-714 5.11 24568-447 6.97 24571-158 5.15 24571-299 5.25 24571-371 5.28 24571-717 5.11 24568-449 6.97 24571-161 5.15 24571-300 5.25 24571-371 5.67 24571-718 5.11 24568-451 6.97 24571-162 5.15 24571-301 5.25 24571-371 5.89 24571-726 5.11 24571-002 5.11 24571-170 5.15 24571-302 5.25 24571-372 5.28 24571-729 5.11 24571-005 5.11 24571-173 5.15 24571-303 5.25 24571-372 5.31 24571-730 5.11 24571-014 5.11 24571-174 5.15 24571-304 5.25 24571-372 5.32 24571-738 5.11 24571-017 5.11 24571-175 5.15 24571-305 5.25 24571-372 5.33 24571-741 5.11 24571-018 5.11 24571-182 5.15 24571-306 5.25 24571-372 5.67 24571-742 5.11 24571-026 5.11 24571-185 5.15 24571-308 5.26 24571-372 5.89 24571-743 5.11 12.44 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 24571-744 5.11 24571-909 5.15 24572-029 5.13 24572-159 5.11 24572-385 5.11 24571-750 5.11 24571-910 5.15 24572-030 5.13 24572-201 5.11 24572-393 5.11 24571-753 5.11 24571-911 5.15 24572-031 5.13 24572-204 5.11 24572-396 5.11 24571-762 5.11 24571-921 5.15 24572-040 5.13 24572-205 5.11 24572-397 5.11 24571-765 5.11 24571-922 5.15 24572-041 5.13 24572-206 5.11 24572-398 5.11 24571-766 5.11 24571-923 5.15 24572-042 5.13 24572-207 5.11 24572-399 5.11 24571-774 5.11 24571-930 5.15 24572-043 5.13 24572-213 5.11 24572-404 5.17 24571-777 5.11 24571-933 5.15 24572-044 5.13 24572-216 5.11 24572-405 5.17 24571-778 5.11 24571-934 5.15 24572-050 5.8 24572-225 5.11 24572-406 5.17 24571-786 5.11 24571-935 5.15 24572-051 5.8 24572-228 5.11 24572-407 5.17 24571-789 5.11 24571-936 5.15 24572-052 5.8 24572-229 5.11 24572-408 5.17 24571-790 5.11 24571-942 5.15 24572-053 5.8 24572-237 5.11 24572-409 5.17 24571-791 5.11 24571-945 5.15 24572-054 5.8 24572-240 5.11 24572-410 5.17 24571-792 5.11 24571-954 5.15 24572-055 5.8 24572-241 5.11 24572-411 5.17 24571-798 5.11 24571-957 5.15 24572-056 5.8 24572-249 5.11 24572-500 5.11 24571-801 5.11 24571-958 5.15 24572-064 5.8 24572-252 5.11 24572-503 5.11 24571-810 5.11 24571-959 5.15 24572-065 5.8 24572-253 5.11 24572-510 5.11 24571-813 5.11 24571-969 5.15 24572-066 5.8 24572-254 5.11 24572-513 5.11 24571-814 5.11 24571-970 5.15 24572-067 5.8 24572-255 5.11 24572-514 5.11 24571-822 5.11 24571-971 5.15 24572-068 5.8 24572-261 5.11 24572-520 5.11 24571-825 5.11 24571-978 5.15 24572-074 5.13 24572-264 5.11 24572-523 5.11 24571-826 5.11 24571-981 5.15 24572-075 5.13 24572-273 5.11 24572-524 5.11 24571-834 5.11 24571-982 5.15 24572-076 5.13 24572-276 5.11 24572-530 5.11 24571-837 5.11 24571-983 5.15 24572-077 5.13 24572-277 5.11 24572-533 5.11 24571-838 5.11 24571-984 5.15 24572-078 5.13 24572-285 5.11 24572-534 5.11 24571-839 5.11 24571-992 5.25 24572-079 5.13 24572-288 5.11 24572-535 5.11 24571-840 5.11 24571-993 5.25 24572-080 5.13 24572-289 5.11 24572-536 5.11 24571-846 5.15 24571-994 5.25 24572-088 5.13 24572-297 5.11 24572-570 5.11 24571-849 5.15 24572-001 5.8 24572-089 5.13 24572-300 5.11 24572-573 5.11 24571-858 5.15 24572-002 5.8 24572-090 5.13 24572-301 5.11 24572-574 5.11 24571-861 5.15 24572-003 5.8 24572-091 5.13 24572-302 5.11 24572-575 5.11 24571-862 5.15 24572-004 5.8 24572-092 5.13 24572-303 5.11 24572-576 5.11 24571-863 5.15 24572-005 5.8 24572-117 5.11 24572-345 5.11 24572-599 5.20 24571-873 5.15 24572-006 5.8 24572-120 5.11 24572-348 5.11 24572-600 5.20 24571-874 5.15 24572-007 5.8 24572-129 5.11 24572-349 5.11 24572-601 5.20 24571-875 5.15 24572-015 5.8 24572-132 5.11 24572-350 5.11 24572-602 5.20 24571-882 5.15 24572-016 5.8 24572-133 5.11 24572-351 5.11 24572-603 5.20 24571-885 5.15 24572-017 5.8 24572-141 5.11 24572-357 5.11 24572-604 5.20 24571-886 5.15 24572-018 5.8 24572-144 5.11 24572-360 5.11 24572-605 5.20 24571-887 5.15 24572-019 5.8 24572-145 5.11 24572-369 5.11 24572-606 5.20 24571-888 5.15 24572-025 5.13 24572-153 5.11 24572-372 5.11 24572-607 5.20 24571-894 5.15 24572-026 5.13 24572-156 5.11 24572-373 5.11 24572-608 5.20 24571-897 5.15 24572-027 5.13 24572-157 5.11 24572-381 5.11 24572-609 5.20 24571-906 5.15 24572-028 5.13 24572-158 5.11 24572-384 5.11 24572-610 5.20 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.45 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 24575-019 5.81 24576-009 5.49 24576-105 5.47 24579-033 8.78 24812-006 7.87 24575-035 5.82 24576-010 5.49 24576-106 5.47 24579-033 8.79 24812-007 7.87 24575-038 5.86 24576-011 5.49 24576-107 5.47 24579-033 8.80 24812-010 7.87 24575-075 5.82 24576-012 5.49 24576-108 5.47 24579-033 8.81 24812-012 7.87 24575-078 5.86 24576-013 5.49 24576-109 5.47 24579-033 8.82 24812-014 7.87 24575-114 5.83 24576-017 5.59 24576-110 5.47 24579-033 8.92 24812-055 7.87 24575-115 5.82 24576-018 5.59 24576-111 5.47 24579-037 7.63 24812-056 7.87 24575-118 5.86 24576-021 5.49 24576-112 5.47 24579-038 7.63 24812-057 7.87 24575-119 5.81 24576-022 5.49 24576-113 5.47 24579-039 7.63 24812-060 7.87 24575-135 5.82 24576-028 5.67 24576-117 5.59 24579-042 8.108 24812-062 7.87 24575-136 5.84 24576-042 5.67 24576-118 5.59 24579-043 8.108 24812-064 7.87 24575-137 5.85 24576-044 5.56 24576-121 5.47 24579-058 8.111 24812-100 7.77 24575-138 5.86 24576-045 5.56 24576-122 5.47 24579-059 8.111 24812-101 7.77 24575-155 5.82 24576-046 5.56 24576-144 5.56 24579-074 8.109 24812-162 7.73 24575-156 5.84 24576-047 5.56 24576-145 5.56 24579-077 8.76 24812-164 7.73 24575-157 5.85 24576-048 5.56 24576-146 5.56 24579-078 8.77 24812-171 7.73 24575-158 5.86 24576-049 5.56 24576-147 5.56 24579-079 8.76 24812-201 7.79 24575-175 5.82 24576-050 5.56 24576-148 5.56 24579-080 8.77 24812-202 7.78 24575-176 5.84 24576-052 5.56 24576-149 5.56 24579-081 8.76 24812-208 7.70 24575-177 5.85 24576-053 5.56 24576-150 5.56 24579-082 8.77 24812-210 7.70 24575-178 5.86 24576-054 5.56 24576-152 5.56 24579-090 6.44 24812-212 7.70 24575-214 5.83 24576-058 5.56 24576-153 5.56 24579-092 6.44 24812-214 7.70 24575-219 5.81 24576-063 5.67 24576-154 5.56 24579-105 8.78 24812-221 7.70 24575-235 5.82 24576-071 5.52 24576-158 5.56 24579-105 8.81 24812-228 7.70 24575-255 5.82 24576-072 5.52 24576-217 5.59 24579-106 8.77 24812-242 7.70 24575-275 5.82 24576-073 5.52 24576-218 5.59 24579-112 8.86 24812-258 7.70 24575-419 5.81 24576-080 5.62 24576-244 5.56 24579-135 8.86 24812-260 7.70 24575-454 5.90 24576-081 5.62 24576-245 5.56 24579-212 8.78 24812-262 7.70 24575-455 5.82 24576-082 5.62 24576-247 5.56 24579-212 8.81 24812-264 7.70 24575-474 5.68 24576-083 5.62 24576-248 5.56 24579-225 8.84 24812-271 7.70 24575-474 5.90 24576-084 5.67 24576-249 5.56 24579-225 8.85 24812-278 7.70 24575-475 5.82 24576-086 5.63 24576-250 5.56 24579-230 8.109 24812-292 7.70 24575-800 5.26 24576-087 5.63 24576-252 5.56 24579-250 8.79 24812-301 7.79 24575-800 5.65 24576-088 5.63 24576-253 5.56 24579-260 8.80 24812-302 7.78 24575-800 5.81 24576-091 5.63 24576-254 5.56 24579-400 8.74 24812-308 7.70 24575-801 5.86 24576-092 5.63 24576-258 5.56 24579-405 8.73 24812-310 7.70 24576-001 5.49 24576-093 5.61 24576-393 5.63 24579-415 8.70 24812-312 7.70 24576-002 5.49 24576-094 5.61 24576-394 5.63 24579-420 8.71 24812-314 7.70 24576-003 5.49 24576-095 5.61 24576-417 5.59 24579-602 8.84 24812-321 7.70 24576-004 5.49 24576-096 5.61 24576-418 5.59 24579-604 8.83 24812-328 7.70 24576-005 5.49 24576-101 5.47 24579-026 8.82 24579-605 8.75 24812-342 7.70 24576-006 5.49 24576-102 5.47 24579-028 8.87 24579-606 8.72 24812-358 7.70 24576-007 5.49 24576-103 5.47 24579-030 8.81 24579-612 8.85 24812-360 7.70 24576-008 5.49 24576-104 5.47 24579-031 8.78 24812-005 7.87 24812-362 7.70 12.46 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 24812-364 7.70 24812-721 7.71 24813-055 7.86 24813-460 7.68 24813-860 7.69 24812-371 7.70 24812-728 7.71 24813-056 7.86 24813-462 7.68 24813-862 7.69 24812-378 7.70 24812-742 7.71 24813-057 7.86 24813-464 7.68 24813-864 7.69 24812-392 7.70 24812-758 7.71 24813-060 7.86 24813-471 7.68 24813-871 7.69 24812-401 7.77 24812-760 7.71 24813-062 7.86 24813-478 7.68 24813-878 7.69 24812-402 7.78 24812-762 7.71 24813-064 7.86 24813-492 7.68 24813-892 7.69 24812-408 7.70 24812-764 7.71 24813-164 7.72 24813-505 7.86 24813-908 7.69 24812-410 7.70 24812-771 7.71 24813-171 7.72 24813-506 7.86 24813-910 7.69 24812-412 7.70 24812-778 7.71 24813-208 7.68 24813-507 7.86 24813-912 7.69 24812-414 7.70 24812-792 7.71 24813-210 7.68 24813-510 7.86 24813-914 7.69 24812-421 7.70 24812-808 7.71 24813-212 7.68 24813-512 7.86 24813-921 7.69 24812-428 7.70 24812-810 7.71 24813-214 7.68 24813-514 7.86 24813-928 7.69 24812-442 7.70 24812-812 7.71 24813-221 7.68 24813-555 7.86 24813-942 7.69 24812-458 7.70 24812-814 7.71 24813-228 7.68 24813-556 7.86 24813-958 7.69 24812-460 7.70 24812-821 7.71 24813-242 7.68 24813-557 7.86 24813-960 7.69 24812-462 7.70 24812-828 7.71 24813-258 7.68 24813-560 7.86 24813-962 7.69 24812-464 7.70 24812-842 7.71 24813-260 7.68 24813-562 7.86 24813-964 7.69 24812-471 7.70 24812-858 7.71 24813-262 7.68 24813-564 7.86 24813-971 7.69 24812-478 7.70 24812-860 7.71 24813-264 7.68 24813-614 7.72 24813-978 7.69 24812-492 7.70 24812-862 7.71 24813-271 7.68 24813-621 7.72 24813-992 7.69 24812-501 7.78 24812-864 7.71 24813-278 7.68 24813-664 7.72 24814-008 7.100 24812-505 7.87 24812-871 7.71 24813-292 7.68 24813-671 7.72 24814-010 7.100 24812-506 7.87 24812-878 7.71 24813-308 7.68 24813-708 7.69 24814-011 7.100 24812-507 7.87 24812-892 7.71 24813-310 7.68 24813-710 7.69 24814-014 7.100 24812-510 7.87 24812-908 7.71 24813-312 7.68 24813-712 7.69 24814-024 7.101 24812-512 7.87 24812-910 7.71 24813-314 7.68 24813-714 7.69 24814-025 7.101 24812-514 7.87 24812-912 7.71 24813-321 7.68 24813-721 7.69 24814-027 7.101 24812-555 7.87 24812-914 7.71 24813-328 7.68 24813-728 7.69 25127-575 1.311 24812-556 7.87 24812-921 7.71 24813-342 7.68 24813-742 7.69 25127-995 1.103 24812-557 7.87 24812-928 7.71 24813-358 7.68 24813-758 7.69 25127-995 1.107 24812-560 7.87 24812-942 7.71 24813-360 7.68 24813-760 7.69 25127-995 1.12 24812-562 7.87 24812-958 7.71 24813-362 7.68 24813-762 7.69 25127-995 1.127 24812-564 7.87 24812-960 7.71 24813-364 7.68 24813-764 7.69 25127-995 1.129 24812-600 7.79 24812-962 7.71 24813-371 7.68 24813-771 7.69 25127-995 1.13 24812-612 7.73 24812-964 7.71 24813-378 7.68 24813-778 7.69 25127-995 1.131 24812-614 7.73 24812-971 7.71 24813-392 7.68 24813-792 7.69 25127-995 1.14 24812-621 7.73 24812-978 7.71 24813-408 7.68 24813-808 7.69 25127-995 1.15 24812-662 7.73 24812-992 7.71 24813-410 7.68 24813-810 7.69 25127-995 1.160 24812-664 7.73 24813-005 7.86 24813-412 7.68 24813-812 7.69 25127-995 1.161 24812-671 7.73 24813-006 7.86 24813-414 7.68 24813-814 7.69 25127-995 1.162 24812-708 7.71 24813-007 7.86 24813-421 7.68 24813-821 7.69 25127-995 1.182 24812-710 7.71 24813-010 7.86 24813-428 7.68 24813-828 7.69 25127-995 1.183 24812-712 7.71 24813-012 7.86 24813-442 7.68 24813-842 7.69 25127-995 1.184 24812-714 7.71 24813-014 7.86 24813-458 7.68 24813-858 7.69 25127-995 1.228 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.47 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 25127-995 1.229 25230-024 1.247 25230-175 1.260 25230-379 1.263 26230-029 1.246 25127-995 1.230 25230-024 1.261 25230-176 1.260 25230-430 1.248 26230-029 1.261 25127-995 1.232 25230-024 1.262 25230-177 1.260 25230-430 1.263 26230-030 1.247 25127-995 1.238 25230-025 1.246 25230-178 1.260 25230-434 1.248 26230-030 1.262 25127-995 1.30 25230-025 1.261 25230-179 1.260 25230-434 1.263 26230-070 1.260 25127-995 1.31 25230-026 1.246 25230-223 1.260 25230-439 1.248 26230-071 1.260 25127-995 1.32 25230-026 1.247 25230-224 1.260 25230-439 1.263 26230-072 1.260 25127-995 1.41 25230-026 1.261 25230-225 1.260 25230-448 1.248 26230-073 1.260 25127-995 1.56 25230-026 1.262 25230-226 1.260 25230-448 1.263 26230-074 1.260 25127-995 1.57 25230-027 1.246 25230-227 1.260 25230-452 1.248 26230-075 1.260 25127-995 1.58 25230-027 1.247 25230-228 1.260 25230-452 1.263 26230-076 1.260 25127-995 1.71 25230-027 1.261 25230-229 1.260 25230-457 1.248 26230-077 1.260 25127-995 1.86 25230-027 1.262 25230-273 1.260 25230-457 1.263 26230-078 1.260 25127-995 1.87 25230-028 1.246 25230-274 1.260 25230-461 1.248 26230-079 1.260 25127-995 1.99 25230-028 1.247 25230-275 1.260 25230-461 1.263 26230-120 1.260 25127-995 2.28 25230-028 1.261 25230-276 1.260 26230-020 1.261 26230-121 1.260 25127-997 1.111 25230-028 1.262 25230-277 1.260 26230-021 1.246 26230-122 1.260 25127-997 1.140 25230-029 1.246 25230-278 1.260 26230-021 1.261 26230-123 1.260 25127-997 1.169 25230-029 1.261 25230-279 1.260 26230-022 1.246 26230-124 1.260 25127-997 1.19 25230-030 1.247 25230-323 1.260 26230-022 1.247 26230-125 1.260 25127-997 1.191 25230-030 1.262 25230-324 1.260 26230-022 1.261 26230-126 1.260 25127-997 1.337 25230-070 1.260 25230-325 1.260 26230-022 1.262 26230-127 1.260 25127-997 1.44 25230-071 1.260 25230-326 1.260 26230-023 1.246 26230-128 1.260 25127-997 1.61 25230-072 1.260 25230-327 1.260 26230-023 1.247 26230-129 1.260 25127-997 1.75 25230-073 1.260 25230-328 1.260 26230-023 1.261 26230-172 1.260 25127-997 1.88 25230-074 1.260 25230-329 1.260 26230-023 1.262 26230-173 1.260 25230-001 1.264 25230-075 1.260 25230-370 1.263 26230-024 1.246 26230-174 1.260 25230-002 1.264 25230-076 1.260 25230-371 1.248 26230-024 1.247 26230-175 1.260 25230-003 1.264 25230-077 1.260 25230-371 1.263 26230-024 1.261 26230-176 1.260 25230-010 1.264 25230-078 1.260 25230-372 1.248 26230-024 1.262 26230-177 1.260 25230-011 1.264 25230-079 1.260 25230-372 1.263 26230-025 1.246 26230-178 1.260 25230-012 1.264 25230-120 1.260 25230-373 1.248 26230-025 1.261 26230-179 1.260 25230-020 1.261 25230-121 1.260 25230-373 1.263 26230-026 1.246 26230-223 1.260 25230-021 1.246 25230-122 1.260 25230-374 1.248 26230-026 1.247 26230-224 1.260 25230-021 1.261 25230-123 1.260 25230-374 1.263 26230-026 1.261 26230-225 1.260 25230-022 1.246 25230-124 1.260 25230-375 1.248 26230-026 1.262 26230-226 1.260 25230-022 1.247 25230-125 1.260 25230-375 1.263 26230-027 1.246 26230-227 1.260 25230-022 1.261 25230-126 1.260 25230-376 1.248 26230-027 1.247 26230-228 1.260 25230-022 1.262 25230-127 1.260 25230-376 1.263 26230-027 1.261 26230-229 1.260 25230-023 1.246 25230-128 1.260 25230-377 1.248 26230-027 1.262 26230-273 1.260 25230-023 1.247 25230-129 1.260 25230-377 1.263 26230-028 1.246 26230-274 1.260 25230-023 1.261 25230-172 1.260 25230-378 1.248 26230-028 1.247 26230-275 1.260 25230-023 1.262 25230-173 1.260 25230-378 1.263 26230-028 1.261 26230-276 1.260 25230-024 1.246 25230-174 1.260 25230-379 1.248 26230-028 1.262 26230-277 1.260 12.48 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 26230-278 1.260 27230-002 1.261 27230-079 1.266 27230-147 1.266 28230-070 1.258 26230-279 1.260 27230-003 1.246 27230-081 1.265 27230-148 1.250 28230-074 1.258 26230-323 1.260 27230-003 1.261 27230-082 1.265 27230-148 1.266 28230-079 1.258 26230-324 1.260 27230-004 1.246 27230-083 1.265 27230-200 1.251 28230-088 1.258 26230-325 1.260 27230-004 1.261 27230-085 1.265 27230-200 1.267 28230-092 1.258 26230-326 1.260 27230-005 1.246 27230-086 1.265 27230-201 1.251 28230-097 1.258 26230-327 1.260 27230-005 1.261 27230-087 1.265 27230-201 1.267 28230-101 1.258 26230-328 1.260 27230-006 1.246 27230-091 1.249 27230-202 1.251 28230-126 1.258 26230-329 1.260 27230-006 1.261 27230-091 1.266 27230-202 1.267 28230-130 1.258 26230-370 1.263 27230-007 1.246 27230-092 1.249 27230-203 1.251 28230-134 1.258 26230-371 1.248 27230-007 1.261 27230-092 1.266 27230-203 1.267 28230-139 1.258 26230-371 1.263 27230-008 1.246 27230-093 1.249 27230-204 1.251 28230-148 1.258 26230-372 1.248 27230-008 1.261 27230-093 1.266 27230-204 1.267 28230-152 1.258 26230-372 1.263 27230-009 1.246 27230-100 1.259 27230-205 1.251 28230-157 1.258 26230-373 1.248 27230-009 1.261 27230-102 1.252 27230-205 1.267 28230-162 1.258 26230-373 1.263 27230-010 1.246 27230-102 1.268 27230-206 1.251 28230-310 1.258 26230-374 1.248 27230-010 1.261 27230-103 1.252 27230-206 1.267 28230-314 1.258 26230-374 1.263 27230-051 1.253 27230-103 1.268 27230-207 1.251 28230-319 1.258 26230-375 1.248 27230-051 1.267 27230-104 1.252 27230-207 1.267 28230-328 1.258 26230-375 1.263 27230-052 1.253 27230-104 1.268 27230-208 1.251 28230-332 1.258 26230-376 1.248 27230-052 1.267 27230-110 1.259 27230-208 1.267 28230-337 1.258 26230-376 1.263 27230-053 1.253 27230-111 1.250 27230-209 1.251 28230-341 1.258 26230-377 1.248 27230-053 1.267 27230-111 1.266 27230-209 1.267 28230-370 1.258 26230-377 1.263 27230-060 1.247 27230-112 1.258 28127-001 1.298 28230-374 1.258 26230-378 1.248 27230-060 1.262 27230-114 1.249 28127-001 1.311 28230-379 1.258 26230-378 1.263 27230-061 1.247 27230-114 1.266 28127-240 1.196 28230-388 1.258 26230-379 1.248 27230-061 1.262 27230-115 1.260 28127-241 1.174 28230-392 1.258 26230-379 1.263 27230-065 1.264 27230-116 1.263 28127-281 1.134 28230-397 1.258 26230-430 1.248 27230-065 1.265 27230-121 1.251 28127-281 1.165 28230-401 1.258 26230-430 1.263 27230-066 1.244 27230-121 1.267 28127-281 1.187 28230-430 1.258 26230-434 1.248 27230-066 1.245 27230-122 1.251 28127-281 1.34 28230-434 1.258 26230-434 1.263 27230-066 1.264 27230-122 1.267 28230-001 1.258 28230-439 1.258 26230-439 1.248 27230-067 1.259 27230-123 1.251 28230-004 1.258 28230-448 1.258 26230-439 1.263 27230-068 1.259 27230-123 1.267 28230-007 1.258 28230-452 1.258 26230-448 1.248 27230-069 1.259 27230-125 1.252 28230-011 1.258 28230-457 1.258 26230-448 1.263 27230-070 1.250 27230-125 1.268 28230-015 1.258 28230-461 1.258 26230-452 1.248 27230-070 1.266 27230-126 1.252 28230-020 1.258 29001-019 11.6 26230-452 1.263 27230-071 1.250 27230-126 1.268 28230-029 1.258 29090-001 11.6 26230-457 1.248 27230-071 1.266 27230-143 1.258 28230-033 1.258 29090-002 11.6 26230-457 1.263 27230-072 1.250 27230-144 1.255 28230-042 1.258 30118-267 4.65 26230-461 1.248 27230-072 1.266 27230-144 1.258 28230-048 1.258 30118-299 3.4 26230-461 1.263 27230-077 1.265 27230-146 1.250 28230-060 1.258 30118-301 3.4 27230-001 1.261 27230-078 1.265 27230-146 1.266 28230-063 1.258 30118-302 3.4 27230-002 1.246 27230-079 1.249 27230-147 1.250 28230-066 1.258 30118-303 3.4 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.49 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 30118-304 3.4 30118-962 3.6 30807-485 6.48 30809-635 7.91 30818-274 6.48 30118-305 3.4 30118-963 3.6 30807-485 7.4 30809-636 7.91 30818-274 7.4 30118-306 3.4 30118-964 3.6 30807-487 6.48 30809-637 7.91 30818-275 6.48 30118-307 3.4 30219-098 3.4 30807-487 7.4 30809-638 7.91 30818-275 7.4 30118-308 3.4 30219-101 3.4 30807-494 6.48 30809-639 7.91 30818-276 6.48 30118-309 3.4 30219-104 3.4 30807-494 7.4 30809-640 7.91 30818-276 7.4 30118-315 4.65 30219-107 3.4 30807-496 6.48 30809-641 7.91 30818-277 6.48 30118-328 3.16 30219-110 3.4 30807-496 7.4 30809-642 7.91 30818-277 7.4 30118-329 3.16 30219-113 3.4 30807-501 6.48 30809-643 7.91 30818-279 6.48 30118-330 3.16 30219-137 3.4 30807-501 7.4 30809-644 7.91 30818-279 7.4 30118-331 3.16 30219-138 3.4 30807-506 6.48 30809-645 7.91 30818-281 6.48 30118-332 3.16 30219-143 3.4 30807-506 7.4 30809-646 7.91 30818-281 7.4 30118-334 3.16 30219-144 3.4 30807-508 6.48 30809-667 7.91 30818-282 6.48 30118-335 3.16 30219-161 3.2 30807-508 7.4 30809-668 7.91 30818-282 7.4 30118-336 3.16 30219-162 3.2 30807-509 6.48 30809-669 7.91 30818-289 6.48 30118-338 3.16 30219-163 3.2 30807-509 7.4 30809-670 7.91 30818-289 7.4 30118-341 7.10 30219-164 3.2 30807-510 6.48 30809-671 7.91 30818-296 6.48 30118-342 7.10 30219-165 3.2 30807-510 7.4 30809-672 7.91 30818-296 7.4 30118-343 7.10 30219-166 3.2 30807-752 7.4 30809-673 7.91 30818-310 6.48 30118-344 7.10 30225-089 5.105 30807-753 6.48 30809-674 7.91 30818-310 7.4 30118-345 7.10 30225-090 5.105 30807-753 7.4 30809-675 7.91 30818-331 6.48 30118-346 7.10 30225-091 5.105 30807-755 7.4 30809-676 7.91 30818-331 7.4 30118-347 7.10 30225-092 5.105 30807-757 6.48 30809-677 7.91 30818-352 6.48 30118-348 7.10 30502-051 5.110 30807-757 7.4 30809-678 7.91 30818-352 7.4 30118-349 7.10 30502-191 5.112 30807-758 6.48 30809-679 7.91 30818-434 6.48 30118-350 7.10 30702-044 3.6 30807-758 7.4 30809-680 7.91 30818-434 7.4 30118-351 7.10 30702-045 3.6 30807-764 6.48 30809-681 7.91 30818-518 6.48 30118-352 7.10 30702-046 3.6 30807-764 7.4 30809-682 7.91 30818-518 7.4 30118-353 7.10 30702-047 3.6 30807-766 6.48 30809-698 7.91 30818-519 7.4 30118-354 7.10 30702-048 3.6 30807-766 7.4 30809-699 7.91 30818-520 7.4 30118-355 7.11 30702-049 3.6 30807-771 6.48 30809-700 7.92 30818-521 7.4 30118-360 4.65 30702-056 3.6 30807-771 7.4 30809-701 7.92 30818-522 6.48 30118-802 3.15 30702-057 3.6 30807-776 6.48 30810-432 6.48 30818-522 7.4 30118-803 3.15 30702-058 3.6 30807-776 7.4 30810-432 7.4 30818-524 6.48 30118-948 3.4 30807-416 6.48 30807-777 7.4 30810-433 6.48 30818-524 7.4 30118-949 3.4 30807-416 7.4 30807-778 7.4 30810-433 7.4 30818-526 6.48 30118-950 3.4 30807-481 6.48 30807-779 7.4 30812-002 11.9 30818-526 7.4 30118-951 3.4 30807-481 7.4 30807-780 7.4 30814-513 6.132 30818-528 6.48 30118-952 3.4 30807-482 6.48 30808-067 6.48 30818-271 6.48 30818-528 7.4 30118-953 3.4 30807-482 7.4 30808-067 7.4 30818-271 7.4 30818-530 6.48 30118-954 3.4 30807-483 6.48 30808-871 7.106 30818-272 6.48 30818-530 7.4 30118-955 3.4 30807-483 7.4 30808-871 7.56 30818-272 7.4 30818-535 6.48 30118-956 3.4 30807-484 6.48 30809-428 7.55 30818-273 6.48 30818-535 7.4 30118-957 3.4 30807-484 7.4 30809-571 7.61 30818-273 7.4 30818-542 6.48 12.50 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 30818-542 7.4 30823-024 5.82 30838-046 7.4 30838-183 7.4 30846-683 6.49 30818-556 6.48 30823-027 5.82 30838-047 6.48 30838-204 6.48 30846-683 7.5 30818-556 7.4 30823-033 5.82 30838-047 7.4 30838-204 7.4 30846-771 6.49 30818-577 6.48 30823-036 5.82 30838-049 6.48 30840-021 5.37 30846-771 7.5 30818-577 7.4 30823-045 5.82 30838-049 7.4 30840-021 5.64 30846-859 6.49 30818-598 6.48 30823-209 5.82 30838-051 6.48 30840-021 5.94 30846-859 7.5 30818-598 7.4 30823-215 5.82 30838-051 7.4 30840-021 6.59 30846-864 6.49 30818-741 6.48 30823-224 5.82 30838-053 6.48 30840-033 5.37 30846-864 7.5 30818-741 7.4 30823-227 5.82 30838-053 7.4 30840-033 5.64 30846-865 6.49 30818-747 6.48 30823-230 5.82 30838-060 6.48 30840-033 5.94 30846-865 7.5 30818-747 7.4 30823-254 5.82 30838-060 7.4 30840-033 6.59 30847-461 6.48 30819-604 6.132 30823-257 5.82 30838-067 6.48 30840-045 5.37 30847-461 7.4 30819-763 6.34 30823-260 5.82 30838-067 7.4 30840-045 5.94 30847-463 6.48 30819-783 5.35 30823-269 5.82 30838-081 6.48 30840-045 6.59 30847-464 6.48 30819-783 5.69 30823-272 5.82 30838-081 7.4 30840-057 5.37 30847-465 6.48 30819-783 5.91 30823-284 5.82 30838-102 6.48 30840-057 5.64 30847-465 7.4 30819-783 6.34 30823-512 5.82 30838-102 7.4 30840-057 5.94 30847-470 6.48 30819-808 5.35 30823-515 5.82 30838-123 6.48 30840-057 6.59 30847-470 7.4 30819-808 5.69 30823-518 5.82 30838-123 7.4 30845-189 6.104 30847-471 6.48 30819-808 5.91 30823-521 5.82 30838-124 6.48 30845-189 6.33 30847-471 7.4 30819-808 6.34 30828-055 6.131 30838-124 7.4 30845-197 5.35 30847-472 5.39 30821-589 6.121 30828-058 6.131 30838-125 6.48 30845-197 5.68 30847-472 5.70 30821-589 6.123 30828-061 6.131 30838-125 7.4 30845-197 6.104 30847-472 5.95 30822-025 6.34 30828-067 6.131 30838-126 6.48 30845-197 6.33 30847-472 6.48 30822-033 5.35 30828-070 6.131 30838-126 7.4 30845-209 6.104 30847-472 6.57 30822-033 5.69 30828-073 6.131 30838-127 6.48 30845-209 6.33 30847-472 7.4 30822-033 5.91 30828-076 6.131 30838-127 7.4 30845-211 5.35 30847-476 6.48 30822-033 6.34 30828-082 6.131 30838-128 6.48 30845-211 5.68 30847-480 6.48 30822-045 6.34 30828-085 6.131 30838-128 7.4 30845-211 6.104 30847-482 6.48 30822-047 5.35 30828-088 6.131 30838-130 6.48 30845-211 6.33 30847-484 6.48 30822-047 5.69 30828-091 6.131 30838-130 7.4 30845-232 5.35 30847-556 6.48 30822-047 5.91 30828-097 6.131 30838-132 6.48 30845-232 5.68 30847-556 7.4 30822-047 6.34 30828-128 6.132 30838-132 7.4 30845-232 6.104 30847-602 7.54 30822-065 5.35 30828-165 6.132 30838-134 6.48 30845-232 6.33 30847-603 7.54 30822-065 5.69 30828-174 6.132 30838-134 7.4 30845-253 5.35 30847-604 7.54 30822-065 5.91 30829-001 7.44 30838-136 6.48 30845-253 5.68 30847-605 7.54 30822-065 6.34 30829-007 7.44 30838-136 7.4 30845-253 6.104 30847-606 7.54 30822-089 5.35 30838-043 6.48 30838-141 6.48 30845-253 6.33 30847-607 7.54 30822-089 5.69 30838-043 7.4 30838-141 7.4 30846-588 6.49 30847-608 7.54 30822-089 5.91 30838-044 6.48 30838-148 6.48 30846-588 7.5 30847-609 7.54 30822-089 6.34 30838-044 7.4 30838-148 7.4 30846-676 6.49 30847-625 7.54 30822-166 9.16 30838-045 6.48 30838-162 6.48 30846-676 7.5 30847-626 7.54 30823-015 5.82 30838-045 7.4 30838-162 7.4 30846-681 6.49 30847-627 7.54 30823-021 5.82 30838-046 6.48 30838-183 6.48 30846-682 6.49 30847-628 7.54 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.51 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 30847-630 7.54 30848-327 7.19 30848-380 6.50 30849-010 5.22 30849-140 5.70 30847-631 7.54 30848-327 7.33 30848-380 7.7 30849-010 5.55 30849-140 5.95 30847-659 7.40 30848-328 7.19 30848-381 6.50 30849-011 5.22 30849-140 6.109 30847-660 7.40 30848-328 7.33 30848-381 7.7 30849-014 5.22 30849-140 6.57 30847-661 7.40 30848-329 7.19 30848-382 6.50 30849-014 5.55 30849-153 7.29 30847-662 7.40 30848-329 7.33 30848-382 7.7 30849-015 5.22 30849-154 7.29 30847-663 7.40 30848-330 7.19 30848-383 6.50 30849-015 5.55 30849-155 7.29 30847-664 7.40 30848-330 7.33 30848-383 7.7 30849-016 5.22 30849-156 7.29 30847-665 7.40 30848-331 7.19 30848-386 6.50 30849-016 5.55 30849-157 7.29 30847-666 7.40 30848-331 7.33 30848-386 7.7 30849-021 5.22 30849-158 7.29 30847-667 7.40 30848-333 7.19 30848-387 6.50 30849-021 5.55 30849-171 5.22 30847-668 7.40 30848-333 7.33 30848-387 7.7 30849-022 5.22 30849-172 5.22 30847-669 7.40 30848-335 7.19 30848-426 7.19 30849-022 5.55 30849-173 5.22 30847-670 7.40 30848-335 7.33 30848-427 7.19 30849-023 5.22 30849-402 8.60 30847-671 7.40 30848-336 7.19 30848-428 7.19 30849-023 5.55 30849-403 8.60 30847-672 7.40 30848-336 7.33 30848-429 7.19 30849-028 5.22 30849-404 8.60 30848-300 7.19 30848-337 7.19 30848-430 7.19 30849-028 5.55 30849-405 8.60 30848-300 7.33 30848-337 7.33 30848-431 7.19 30849-029 5.22 30849-406 8.60 30848-301 7.19 30848-338 7.19 30848-432 7.19 30849-029 5.55 30849-407 8.60 30848-301 7.33 30848-338 7.33 30848-461 7.40 30849-030 5.22 30849-658 8.60 30848-304 7.19 30848-339 7.19 30848-463 7.40 30849-030 5.55 30849-670 8.60 30848-304 7.33 30848-339 7.33 30848-465 7.40 30849-035 5.22 30849-682 8.60 30848-305 7.19 30848-340 7.19 30848-466 7.40 30849-035 5.55 30849-694 8.60 30848-305 7.33 30848-340 7.33 30848-467 7.40 30849-036 5.22 30849-708 8.60 30848-312 7.19 30848-342 7.19 30848-468 7.40 30849-036 5.55 30849-714 8.60 30848-312 7.33 30848-342 7.33 30848-470 7.40 30849-037 5.22 30849-749 7.10 30848-313 7.19 30848-344 7.19 30848-472 7.40 30849-037 5.55 30849-750 7.10 30848-313 7.33 30848-344 7.33 30848-473 7.40 30849-086 7.54 30849-751 7.10 30848-314 7.19 30848-354 6.50 30848-474 7.40 30849-087 7.54 30849-752 7.10 30848-314 7.33 30848-354 7.7 30848-867 7.19 30849-088 7.54 30849-753 7.10 30848-315 7.19 30848-355 6.50 30848-869 7.19 30849-089 7.54 30849-754 7.10 30848-315 7.33 30848-355 7.7 30848-985 7.19 30849-090 7.54 30849-755 7.10 30848-316 7.19 30848-356 6.50 30849-001 6.50 30849-091 7.54 30850-354 5.57 30848-316 7.33 30848-356 7.7 30849-001 7.7 30849-092 7.54 30860-501 6.120 30848-317 7.19 30848-357 6.50 30849-002 6.50 30849-093 7.54 30860-502 6.120 30848-317 7.33 30848-357 7.7 30849-002 7.7 30849-097 7.54 30860-503 6.120 30848-318 7.19 30848-358 6.50 30849-004 6.50 30849-098 7.54 30860-504 6.120 30848-318 7.33 30848-358 7.7 30849-004 7.7 30849-099 7.54 30860-505 6.120 30848-319 7.19 30848-359 6.50 30849-007 5.22 30849-100 7.54 30860-510 6.120 30848-319 7.33 30848-359 7.7 30849-007 5.55 30849-101 7.54 30860-511 6.120 30848-320 7.19 30848-378 6.50 30849-008 5.22 30849-102 7.54 30860-512 6.120 30848-320 7.33 30848-378 7.7 30849-008 5.55 30849-103 7.54 30860-513 6.120 30848-321 7.19 30848-379 6.50 30849-009 5.22 30849-104 7.54 30860-514 6.120 30848-321 7.33 30848-379 7.7 30849-009 5.55 30849-140 5.39 30860-519 6.122 12.52 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 30860-520 6.122 34560-185 6.21 34560-287 6.21 34560-495 6.20 34560-728 6.100 30860-521 6.122 34560-187 6.20 34560-289 6.20 34560-495 6.21 34560-728 6.30 30925-001 11.11 34560-187 6.21 34560-289 6.21 34560-496 6.20 34560-740 6.100 30925-002 11.11 34560-189 6.20 34560-291 6.20 34560-496 6.21 34560-740 6.30 30925-003 11.11 34560-189 6.21 34560-291 6.21 34560-501 6.100 34560-742 5.32 30925-004 11.11 34560-191 6.20 34560-293 6.20 34560-501 6.30 34560-742 5.67 30925-005 11.11 34560-191 6.21 34560-293 6.21 34560-520 6.100 34560-742 5.89 30925-006 11.11 34560-193 6.20 34560-295 6.20 34560-520 6.30 34560-742 6.100 31006-677 9.6 34560-193 6.21 34560-295 6.21 34560-528 5.32 34560-742 6.30 31591-422 8.15 34560-195 6.20 34560-301 6.28 34560-528 5.67 34560-763 5.32 31596-423 8.15 34560-195 6.21 34560-301 6.99 34560-528 5.89 34560-763 5.67 31596-575 8.15 34560-201 6.28 34560-320 6.28 34560-528 6.100 34560-763 5.89 31596-576 8.15 34560-201 6.99 34560-320 6.99 34560-528 6.30 34560-763 6.100 31596-791 8.13 34560-220 6.28 34560-328 5.31 34560-540 6.100 34560-763 6.30 31596-792 8.13 34560-220 6.99 34560-328 6.28 34560-540 6.30 34560-784 5.32 31596-899 8.13 34560-228 5.31 34560-328 6.99 34560-542 5.32 34560-784 5.57 31596-900 8.13 34560-228 5.54 34560-340 6.28 34560-542 5.67 34560-784 5.67 32405-024 2.13 34560-228 5.67 34560-340 6.99 34560-542 5.89 34560-784 5.89 32405-025 2.13 34560-228 5.89 34560-342 5.31 34560-542 6.100 34560-784 6.100 32405-026 2.13 34560-228 6.28 34560-342 6.28 34560-542 6.30 34560-784 6.30 32405-027 2.13 34560-228 6.99 34560-342 6.99 34560-563 5.32 34560-785 6.20 32405-028 2.13 34560-240 6.28 34560-363 5.31 34560-563 5.67 34560-785 6.21 32405-029 2.13 34560-240 6.99 34560-363 6.28 34560-563 5.89 34560-787 6.20 32405-033 2.13 34560-242 5.31 34560-363 6.99 34560-563 6.100 34560-787 6.21 32405-034 2.13 34560-242 5.54 34560-384 5.31 34560-563 6.30 34560-789 6.20 32405-035 2.13 34560-242 5.67 34560-384 6.28 34560-584 5.32 34560-789 6.21 32405-038 2.13 34560-242 5.89 34560-384 6.99 34560-584 5.67 34560-791 6.20 32405-039 2.13 34560-242 6.28 34560-401 6.30 34560-584 5.89 34560-791 6.21 32405-040 2.13 34560-242 6.99 34560-420 6.30 34560-584 6.100 34560-793 6.20 34560-001 6.28 34560-263 5.31 34560-428 6.30 34560-584 6.30 34560-793 6.21 34560-020 6.28 34560-263 5.54 34560-440 6.30 34560-601 6.30 34560-801 6.30 34560-028 6.28 34560-263 5.67 34560-442 6.30 34560-620 6.30 34560-820 6.30 34560-040 6.28 34560-263 5.89 34560-463 6.30 34560-628 6.30 34560-828 6.30 34560-042 6.28 34560-263 6.28 34560-484 6.30 34560-640 6.30 34560-840 6.30 34560-063 6.28 34560-263 6.99 34560-485 6.20 34560-642 6.30 34560-842 6.30 34560-084 6.28 34560-284 5.31 34560-485 6.21 34560-663 6.30 34560-863 6.30 34560-101 6.28 34560-284 5.54 34560-487 6.20 34560-684 6.30 34560-884 6.30 34560-120 6.28 34560-284 5.67 34560-487 6.21 34560-701 6.100 34560-891 6.39 34560-128 6.28 34560-284 5.89 34560-489 6.20 34560-701 6.30 34560-892 6.39 34560-140 6.28 34560-284 6.28 34560-489 6.21 34560-720 6.100 34560-893 6.39 34560-142 6.28 34560-284 6.99 34560-491 6.20 34560-720 6.30 34560-894 6.39 34560-163 6.28 34560-285 6.20 34560-491 6.21 34560-728 5.32 34560-900 6.39 34560-184 6.28 34560-285 6.21 34560-493 6.20 34560-728 5.67 34560-920 6.100 34560-185 6.20 34560-287 6.20 34560-493 6.21 34560-728 5.89 34560-920 6.30 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.53 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 34560-928 5.32 34561-128 5.33 34561-340 6.33 34561-584 6.102 34562-753 6.59 34560-928 5.67 34561-128 6.101 34561-342 5.35 34561-584 6.32 34562-754 5.37 34560-928 5.89 34561-128 6.31 34561-342 5.68 34561-750 6.47 34562-754 5.94 34560-928 6.100 34561-140 6.101 34561-342 5.90 34561-750 6.83 34562-754 6.59 34560-928 6.30 34561-140 6.31 34561-342 6.104 34561-752 6.47 34562-755 5.37 34560-940 6.100 34561-142 5.33 34561-342 6.33 34561-752 6.83 34562-755 5.94 34560-940 6.30 34561-142 6.101 34561-363 5.35 34561-763 6.47 34562-755 6.59 34560-942 5.32 34561-142 6.31 34561-363 5.68 34561-763 6.83 34562-756 5.37 34560-942 5.67 34561-163 5.33 34561-363 5.90 34561-764 6.47 34562-756 5.94 34560-942 5.89 34561-163 6.101 34561-363 6.104 34561-764 6.83 34562-756 6.59 34560-942 6.100 34561-163 6.31 34561-363 6.33 34561-777 6.90 34562-757 5.37 34560-942 6.30 34561-184 5.33 34561-384 5.35 34561-779 6.90 34562-757 5.94 34560-963 5.32 34561-184 6.101 34561-384 5.68 34562-745 5.37 34562-757 6.59 34560-963 5.67 34561-184 6.31 34561-384 5.90 34562-745 5.94 34562-758 5.37 34560-963 5.89 34561-185 6.24 34561-384 6.104 34562-745 6.59 34562-758 5.94 34560-963 6.100 34561-187 6.24 34561-384 6.33 34562-746 5.37 34562-758 6.59 34560-963 6.30 34561-189 6.24 34561-484 5.35 34562-746 5.64 34562-759 5.37 34560-984 5.32 34561-197 6.24 34561-484 5.68 34562-746 5.94 34562-759 5.94 34560-984 5.67 34561-201 6.101 34561-484 5.90 34562-746 6.59 34562-759 6.59 34560-984 5.89 34561-201 6.31 34561-484 6.104 34562-747 5.37 34562-760 5.37 34560-984 6.100 34561-220 6.101 34561-484 6.33 34562-747 5.64 34562-760 5.64 34560-984 6.30 34561-220 6.31 34561-485 6.24 34562-747 5.94 34562-760 5.94 34561-001 6.101 34561-228 5.33 34561-487 6.24 34562-747 6.59 34562-760 6.59 34561-001 6.31 34561-228 6.101 34561-489 6.24 34562-748 5.37 34562-761 5.36 34561-020 6.101 34561-228 6.31 34561-497 6.24 34562-748 5.64 34562-761 5.75 34561-020 6.31 34561-240 6.101 34561-501 5.34 34562-748 5.94 34562-761 6.60 34561-028 5.33 34561-240 6.31 34561-501 6.102 34562-748 6.59 34562-762 5.36 34561-028 6.101 34561-242 5.33 34561-501 6.32 34562-749 5.37 34562-762 5.75 34561-028 6.31 34561-242 6.101 34561-520 5.34 34562-749 5.94 34562-762 6.60 34561-040 6.101 34561-242 6.31 34561-520 6.102 34562-749 6.59 34562-763 5.36 34561-040 6.31 34561-263 5.33 34561-520 6.32 34562-750 5.37 34562-763 5.75 34561-042 5.33 34561-263 6.101 34561-528 5.34 34562-750 5.64 34562-763 6.60 34561-042 6.101 34561-263 6.31 34561-528 6.102 34562-750 5.94 34562-764 5.36 34561-042 6.31 34561-284 5.33 34561-528 6.32 34562-750 6.59 34562-764 5.75 34561-063 5.33 34561-284 6.101 34561-540 5.34 34562-751 5.37 34562-764 6.60 34561-063 6.101 34561-284 6.31 34561-540 6.102 34562-751 5.64 34562-823 5.43 34561-063 6.31 34561-320 6.104 34561-540 6.32 34562-751 5.94 34562-823 5.75 34561-084 5.33 34561-320 6.33 34561-542 5.34 34562-751 6.59 34562-823 5.97 34561-084 6.101 34561-328 5.35 34561-542 6.102 34562-752 5.37 34562-823 6.61 34561-084 6.31 34561-328 5.68 34561-542 6.32 34562-752 5.64 34562-824 5.43 34561-101 6.101 34561-328 5.90 34561-563 5.34 34562-752 5.94 34562-824 5.75 34561-101 6.31 34561-328 6.104 34561-563 6.102 34562-752 6.59 34562-824 5.97 34561-120 6.101 34561-328 6.33 34561-563 6.32 34562-753 5.37 34562-824 6.61 34561-120 6.31 34561-340 6.104 34561-584 5.34 34562-753 5.94 34562-826 5.43 12.54 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Part no. Page 34562-826 5.75 34562-881 6.94 34564-881 6.106 34566-528 34562-826 5.97 34562-882 5.41 34564-881 6.37 34566-540 6.100 34579-234 6.41 6.100 34579-235 6.41 34562-826 6.61 34562-882 5.74 34564-882 5.41 34566-542 6.100 34579-300 6.20 34562-827 5.43 34562-882 5.93 34564-882 5.74 34566-563 6.100 34579-300 6.21 34562-827 5.75 34562-882 6.106 34564-882 5.93 34566-584 6.100 34812-100 7.76 34562-827 5.97 34562-882 6.37 34564-882 6.106 34566-701 6.100 34812-102 7.76 34562-827 6.61 34562-883 5.41 34564-882 6.37 34566-720 6.100 34812-103 7.76 34562-833 5.43 34562-883 5.74 34564-883 5.41 34566-728 6.100 34812-108 7.75 34562-833 5.75 34562-883 5.93 34564-883 5.74 34566-740 6.100 34812-110 7.75 34562-833 5.97 34562-883 6.106 34564-883 5.93 34566-742 6.100 34812-112 7.75 34562-833 6.61 34562-883 6.37 34564-883 6.106 34566-763 6.100 34812-114 7.75 34562-834 5.43 34562-884 5.41 34564-883 6.37 34566-784 6.100 34812-121 7.75 34562-834 5.75 34562-884 5.74 34564-884 5.41 34571-605 5.21 34812-128 7.75 34562-834 5.97 34562-884 5.93 34564-884 5.74 34571-606 5.21 34812-142 7.75 34562-834 6.61 34562-884 6.106 34564-884 5.93 34571-607 5.21 34812-200 7.76 34562-836 5.43 34562-884 6.37 34564-884 6.37 34571-608 5.21 34812-208 7.77 34562-836 5.75 34562-885 5.41 34564-885 5.41 34571-609 5.21 34812-210 7.77 34562-836 5.97 34562-885 5.74 34564-885 5.74 34571-610 5.21 34812-212 7.77 34562-836 6.61 34562-885 5.93 34564-885 5.93 34571-611 5.21 34812-214 7.77 34562-837 5.43 34562-885 6.106 34564-885 6.37 34571-612 5.21 34812-221 7.77 34562-837 5.75 34562-885 6.37 34564-891 6.39 34571-613 5.21 34812-228 7.77 34562-837 5.97 34563-001 6.59 34564-892 6.39 34571-614 5.21 34812-242 7.77 34562-837 6.61 34563-002 6.59 34564-893 6.39 34571-615 5.21 34812-308 7.77 34562-843 5.43 34563-003 6.59 34564-900 6.39 34571-616 5.21 34812-310 7.77 34562-843 5.75 34563-004 6.59 34565-196 6.104 34571-617 5.21 34812-312 7.77 34562-843 5.97 34563-009 6.59 34565-196 6.33 34571-618 5.21 34812-314 7.77 34562-843 6.61 34563-014 6.59 34565-396 6.104 34571-619 5.21 34812-321 7.77 34562-844 5.43 34563-019 6.59 34565-396 6.33 34571-620 5.21 34812-328 7.77 34562-844 5.75 34563-024 6.59 34566-201 6.99 34571-621 5.21 34812-342 7.77 34562-844 5.97 34564-108 5.38 34566-220 6.99 34571-622 5.21 34812-408 7.76 34562-844 6.61 34564-108 5.71 34566-228 6.99 34571-623 5.21 34812-410 7.76 34562-846 5.43 34564-108 5.96 34566-240 6.99 34571-624 5.21 34812-412 7.76 34562-846 5.75 34564-108 6.58 34566-242 6.99 34579-002 6.20 34812-414 7.76 34562-846 5.97 34564-109 5.38 34566-263 6.99 34579-002 6.21 34812-421 7.76 34562-846 6.61 34564-109 5.71 34566-284 6.99 34579-012 6.20 34812-428 7.76 34562-847 5.43 34564-109 5.96 34566-301 6.99 34579-012 6.21 34812-442 7.76 34562-847 5.75 34564-109 6.58 34566-320 6.99 34579-038 6.20 34812-600 7.76 34562-847 5.97 34564-208 5.38 34566-328 6.99 34579-038 6.21 34812-601 7.76 34562-847 6.61 34564-208 5.71 34566-340 6.99 34579-230 6.105 34812-603 7.76 34562-881 5.41 34564-208 5.96 34566-342 6.99 34579-230 6.36 34812-608 7.75 34562-881 5.74 34564-208 6.58 34566-363 6.99 34579-231 6.105 34812-610 7.75 34562-881 5.93 34564-881 5.41 34566-384 6.99 34579-231 6.36 34812-612 7.75 34562-881 6.106 34564-881 5.74 34566-501 6.100 34579-232 6.41 34812-614 7.75 34562-881 6.37 34564-881 5.93 34566-520 6.100 34579-233 6.41 34812-621 7.75 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.55 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 34812-628 7.75 34813-212 7.77 40304-050 3.2 60103-141 4.12 60110-266 3.52 34812-642 7.75 34813-214 7.77 40304-051 3.2 60103-141 4.6 60110-267 3.55 34812-701 7.76 34813-221 7.77 40304-052 3.2 60103-141 4.7 60110-270 3.53 34812-708 7.77 34813-228 7.77 40304-053 3.2 60110-200 3.52 60110-280 3.59 34812-710 7.77 34813-242 7.77 40304-054 3.2 60110-201 2.35 60110-281 3.59 34812-712 7.77 34813-408 7.76 40304-055 3.2 60110-201 3.52 60110-282 3.59 34812-714 7.77 34813-410 7.76 40304-074 3.4 60110-202 3.52 60110-283 3.60 34812-721 7.77 34813-412 7.76 40304-075 3.4 60110-203 3.52 60110-284 3.60 34812-728 7.77 34813-414 7.76 40304-076 3.4 60110-204 3.52 60110-285 3.60 34812-742 7.77 34813-421 7.76 40304-077 3.4 60110-205 3.52 60110-290 3.58 34812-808 7.77 34813-428 7.76 40304-078 3.4 60110-206 3.52 60110-291 3.58 34812-810 7.77 34813-442 7.76 40304-079 3.4 60110-207 3.52 60110-292 3.58 34812-812 7.77 34813-600 7.76 40304-080 3.4 60110-208 3.52 60110-293 3.64 34812-814 7.77 34813-601 7.76 40304-081 3.4 60110-209 3.52 60110-294 3.64 34812-821 7.77 34813-603 7.76 40304-082 3.4 60110-210 3.52 60110-295 3.64 34812-828 7.77 34813-608 7.75 40304-083 3.4 60110-211 3.52 60110-296 3.64 34812-842 7.77 34813-610 7.75 43105-999 9.10 60110-212 3.52 60110-300 3.77 34812-908 7.77 34813-612 7.75 43105-999 9.11 60110-214 3.52 60110-301 3.77 34812-910 7.77 34813-614 7.75 43105-999 9.12 60110-216 3.52 60110-302 3.77 34812-912 7.77 34813-621 7.75 60100-302 3.14 60110-217 3.52 60110-303 3.78 34812-914 7.77 34813-628 7.75 60100-398 3.42 60110-219 3.54 60110-304 3.78 34812-921 7.77 34813-642 7.75 60100-478 3.43 60110-220 2.35 60110-305 3.78 34812-928 7.77 34813-701 7.76 60100-559 3.43 60110-220 3.55 60110-306 3.75 34812-942 7.77 34813-708 7.77 60103-010 3.21 60110-221 3.55 60110-307 3.75 34812-958 7.76 34813-710 7.77 60103-011 3.21 60110-222 3.55 60110-308 3.75 34812-960 7.76 34813-712 7.77 60103-131 1.234 60110-223 3.55 60110-309 3.75 34812-962 7.76 34813-714 7.77 60103-131 3.38 60110-224 3.55 60110-310 3.76 34812-964 7.76 34813-721 7.77 60103-131 4.10 60110-225 3.55 60110-313 3.48 34812-971 7.76 34813-728 7.77 60103-131 4.12 60110-226 3.55 60110-314 3.48 34812-978 7.76 34813-742 7.77 60103-131 4.6 60110-227 3.55 60110-315 3.48 34812-992 7.76 34813-908 7.77 60103-131 4.7 60110-228 3.55 60110-316 3.49 34813-100 7.76 34813-910 7.77 60103-137 1.234 60110-229 3.55 60110-320 3.69 34813-102 7.76 34813-912 7.77 60103-137 3.29 60110-230 3.55 60110-321 3.69 34813-103 7.76 34813-914 7.77 60103-137 3.30 60110-231 3.55 60110-322 3.69 34813-108 7.75 34813-921 7.77 60103-137 3.31 60110-232 3.56 60110-323 3.69 34813-110 7.75 34813-928 7.77 60103-137 3.38 60110-233 3.57 60110-324 3.69 34813-112 7.75 34813-942 7.77 60103-137 3.44 60110-240 3.62 60110-325 3.69 34813-114 7.75 34813-958 7.76 60103-137 4.10 60110-241 3.62 60110-326 3.65 34813-121 7.75 34813-960 7.76 60103-137 4.12 60110-242 3.62 60110-326 3.69 34813-128 7.75 34813-962 7.76 60103-137 4.6 60110-243 3.61 60110-327 3.65 34813-142 7.75 34813-964 7.76 60103-137 4.7 60110-244 3.61 60110-327 3.69 34813-200 7.76 34813-971 7.76 60103-141 1.234 60110-245 3.61 60110-328 3.65 34813-208 7.77 34813-978 7.76 60103-141 3.38 60110-246 3.63 60110-328 3.69 34813-210 7.77 34813-992 7.76 60103-141 4.10 60110-247 3.63 60110-329 3.69 12.56 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Part no. Page Part no. Page 60110-330 3.69 60114-514 1.281 60118-476 60110-331 3.69 60114-514 1.296 60118-476 1.342 60239-025 2.38 60715-017 4.59 3.7 60239-026 2.40 60715-018 4.59 60110-332 3.69 60114-514 1.308 60118-515 3.45 60239-026 2.41 60715-020 4.58 60110-340 3.68 60114-515 1.281 60118-518 3.44 60239-030 2.38 60715-021 4.58 60110-341 3.68 60114-515 1.296 60118-519 3.44 60239-031 2.40 60715-023 4.58 60110-342 3.68 60114-515 1.308 60118-520 3.44 60239-031 2.41 60715-028 4.60 60110-343 3.66 60114-517 1.308 60126-118 3.13 60239-031 2.44 60715-029 4.60 60110-344 3.66 60114-518 1.308 60126-118 3.46 60239-035 2.43 60715-030 4.58 60110-345 3.66 60118-144 3.37 60197-019 4.17 60239-040 2.43 60715-046 4.67 60110-346 3.67 60118-145 3.37 60197-019 4.61 60239-051 2.43 60715-049 3.6 60110-347 3.67 60118-339 3.45 60197-053 1.234 60239-060 2.40 60715-050 3.6 60110-348 3.67 60118-340 3.45 60197-053 3.29 60239-062 2.39 60715-132 4.65 60110-349 3.68 60118-341 3.45 60197-053 3.30 60239-062 2.42 60715-133 4.65 60110-350 3.68 60118-342 3.45 60197-053 3.31 60240-006 2.44 60715-136 4.63 60110-351 3.68 60118-343 3.45 60197-053 3.38 60502-003 5.110 60715-137 4.63 60110-352 3.66 60118-344 3.45 60197-053 4.7 60704-020 3.38 60715-138 4.66 60110-353 3.66 60118-345 3.45 60200-001 5.115 60713-001 4.9 60715-139 4.66 60110-354 3.66 60118-346 3.45 60200-027 5.115 60713-002 4.9 60715-140 4.23 60110-355 3.67 60118-434 3.33 60220-003 1.110 60713-003 4.9 60715-141 4.23 60110-356 3.67 60118-435 3.14 60220-003 1.18 60713-004 4.9 60715-142 4.23 60110-357 3.67 60118-457 1.342 60220-003 1.46 60713-169 4.15 60715-143 4.24 60110-360 3.38 60118-457 3.7 60220-003 1.60 60713-169 4.8 60715-144 4.24 60110-360 3.58 60118-458 1.342 60220-003 1.77 60713-170 4.8 60715-145 4.24 60110-360 3.68 60118-458 3.7 60224-009 5.115 60713-243 4.14 60715-146 4.25 60110-361 3.38 60118-459 1.342 60224-011 5.115 60713-244 4.14 60715-147 4.25 60110-361 3.58 60118-459 3.7 60225-012 5.114 60713-245 4.14 60715-148 4.26 60110-361 3.68 60118-472 1.117 60225-015 5.114 60713-246 4.14 60715-149 4.26 60110-362 3.58 60118-472 1.151 60225-052 4.17 60713-331 4.15 60715-150 4.27 60110-362 3.68 60118-472 1.154 60225-053 4.17 60713-501 4.10 60715-151 4.27 60110-365 3.65 60118-472 1.176 60229-001 5.114 60713-600 8.78 60715-152 4.28 60110-366 3.65 60118-472 1.198 60229-002 5.114 60713-600 8.81 60715-153 4.28 60110-370 3.74 60118-472 1.24 60229-003 5.114 60713-868 4.12 60715-154 4.29 60110-371 3.74 60118-472 1.25 60229-004 5.114 60715-005 1.166 60715-155 4.29 60113-267 1.110 60118-472 1.52 60239-001 2.40 60715-005 1.188 60715-156 4.23 60113-267 1.170 60118-472 1.66 60239-004 2.41 60715-005 1.265 60715-157 4.24 60113-267 1.18 60118-472 1.67 60239-006 2.38 60715-005 1.294 60715-158 4.25 60113-267 1.192 60118-472 1.93 60239-012 2.42 60715-005 1.295 60715-159 4.26 60113-267 1.46 60118-472 1.94 60239-013 2.39 60715-005 1.306 60715-159 4.27 60113-267 1.60 60118-473 1.342 60239-013 2.42 60715-005 1.307 60715-160 4.28 60113-267 1.77 60118-473 3.7 60239-014 2.39 60715-005 1.35 60715-160 4.29 60114-121 1.291 60118-474 1.342 60239-014 2.42 60715-005 1.72 60715-182 4.23 60114-121 1.292 60118-474 3.7 60239-020 2.38 60715-005 4.62 60715-183 4.24 60114-121 1.303 60118-475 1.342 60239-020 2.45 60715-006 4.62 60715-184 4.25 60114-121 1.304 60118-475 3.7 60239-021 2.41 60715-007 4.62 60715-185 4.26 SCHROFF.PENTAIR.CO.UK Page Part no. Page Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.57 Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 60715-185 4.27 60807-183 7.56 60835-022 7.13 64560-027 5.28 64560-166 6.37 60715-186 4.28 60807-203 7.106 60835-024 7.13 64560-055 6.37 64571-033 5.23 60715-186 4.29 60807-203 7.56 60850-171 5.62 64560-057 6.39 64571-033 5.61 60715-187 4.24 60807-211 7.106 60895-018 6.78 64560-071 6.38 64571-034 5.23 60715-188 4.25 60807-211 7.56 60895-018 6.79 64560-071 9.22 64571-034 5.61 60715-189 4.26 60817-001 6.134 60895-018 6.80 64560-071 9.23 64571-035 5.23 60715-189 4.27 60817-015 6.134 60895-018 6.83 64560-071 9.26 64571-035 5.61 60715-190 4.28 60817-016 6.134 60897-278 7.14 64560-071 9.27 64571-036 5.23 60715-190 4.29 60817-026 6.134 61000-007 7.62 64560-072 6.38 64571-036 5.61 60800-032 10.27 60817-050 7.104 61000-012 7.62 64560-074 5.40 69000-007 7.104 60800-039 7.104 60817-051 7.104 61000-177 7.62 64560-074 5.73 69000-969 7.104 60800-045 7.104 60817-052 7.104 62150-191 3.29 64560-074 5.92 69001-073 11.10 60800-064 11.11 60817-053 6.134 62150-191 3.30 64560-074 6.36 69001-106 11.6 60800-080 11.11 60817-054 6.135 62150-191 3.31 64560-075 5.40 69001-651 11.9 60800-123 9.10 60817-055 7.103 62150-191 3.38 64560-075 5.73 69001-652 11.9 60800-123 9.11 60817-064 6.134 62150-201 4.63 64560-075 5.92 69001-664 11.4 60800-123 9.12 60817-067 7.103 62150-201 4.66 64560-075 6.36 69001-677 11.4 60800-123 9.13 60817-071 6.135 62150-264 4.63 64560-076 5.41 69001-678 11.4 60800-123 9.14 60817-072 7.103 62150-264 4.66 64560-076 5.74 69001-679 11.4 60800-123 9.15 60817-076 6.134 62405-001 2.12 64560-076 5.93 69001-685 11.4 60800-123 9.17 60817-078 6.132 62405-002 2.12 64560-076 6.37 69001-691 11.4 60800-123 9.20 60817-079 6.132 62405-003 2.12 64560-078 5.41 69001-693 11.4 60800-123 9.3 60817-080 6.134 62405-004 2.12 64560-078 5.74 69001-696 11.4 60800-123 9.4 60817-083 6.134 62405-010 2.12 64560-078 5.93 69001-697 11.4 60800-123 9.5 60817-085 6.134 62405-011 2.12 64560-078 6.37 69001-698 11.4 60800-123 9.6 60817-096 6.135 62405-012 2.12 64560-080 5.41 69001-711 11.5 60800-123 9.7 60817-097 6.135 62405-013 2.12 64560-080 5.74 69001-712 11.5 60800-123 9.8 60817-098 6.134 62406-096 2.4 64560-080 5.93 69001-717 11.5 60800-123 9.9 60817-102 6.134 62406-096 2.5 64560-080 6.37 69001-718 11.5 60800-834 10.27 60817-103 6.134 64560-001 6.105 64560-082 6.37 69001-722 11.5 60807-011 7.106 60817-149 6.134 64560-001 6.36 64560-085 6.38 69001-723 11.5 60807-011 7.50 60817-228 5.41 64560-002 6.105 64560-086 6.38 69001-728 11.4 60807-011 7.56 60817-228 5.74 64560-002 6.36 64560-089 6.38 69001-733 11.5 60807-181 7.106 60817-228 5.93 64560-004 6.39 64560-090 6.38 69001-733 11.7 60807-181 7.22 60817-228 6.124 64560-005 6.37 64560-091 6.38 69001-733 9.10 60807-181 7.35 60817-228 6.37 64560-006 6.37 64560-092 6.38 69001-733 9.11 60807-181 7.42 60817-228 6.39 64560-008 6.39 64560-096 6.105 69001-733 9.12 60807-181 7.47 60817-228 6.41 64560-010 5.39 64560-096 6.36 69001-733 9.13 60807-181 7.50 60817-228 7.102 64560-010 5.70 64560-098 6.105 69001-733 9.14 60807-181 7.56 60817-340 7.23 64560-010 5.95 64560-098 6.36 69001-733 9.15 60807-183 7.106 60817-341 7.23 64560-010 6.57 64560-143 6.38 69001-733 9.16 60807-183 7.42 60827-026 7.14 64560-026 5.117 64560-144 6.38 69001-733 9.17 60807-183 7.47 60829-008 7.44 64560-026 5.28 64560-145 6.38 69001-733 9.2 60807-183 7.50 60835-021 7.13 64560-027 5.117 64560-146 6.38 69001-733 9.20 12.58 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Appendix Part no. Page Part no. Page Part no. Page Part no. Page Part no. Page 69001-733 9.3 69004-058 11.15 69004-241 11.14 A12106CHSCFG 2.22 DV10D7 1.340 69001-733 9.4 69004-059 11.14 69004-242 11.14 A12106CHSCFGW 2.22 E4DR19FM45U 1.337 69001-733 9.5 69004-060 11.14 69004-249 11.15 A12SPK10C 2.23 EC3D7 1.340 69001-733 9.6 69004-061 11.14 69004-250 11.15 A14128CHSCFG 2.22 EC6D7 1.340 69001-733 9.7 69004-062 11.14 69004-251 11.15 A14128CHSCFGW 2.22 ECT19 1.341 69001-733 9.8 69004-063 11.14 69004-252 11.15 A14SPK12C 2.23 EDR19FM45U 1.336 69001-733 9.9 69004-064 11.14 69004-253 11.15 A16148CHSCFG 2.22 EJ2DR 1.336 69001-755 11.5 69004-065 11.14 69004-254 11.15 A16148CHSCFGW 2.22 EJ2DR 1.337 69001-801 11.4 69004-066 11.14 69004-255 11.15 A16SPK14C 2.23 EJ2DR 1.338 69001-816 11.4 69004-067 11.14 69004-256 11.15 A181610CHSCFG 2.22 EMX111 3.47 69001-821 11.4 69004-068 11.16 69004-257 11.15 A181610CHSCFGW 2.22 EMX888 3.47 69001-826 11.4 69004-069 11.16 69004-258 11.14 A18SPK16C 2.23 ES1224B 1.336 69001-831 11.4 69004-071 11.16 69004-259 11.14 A664CHSCFG 2.22 ES1224B 1.338 69001-846 11.5 69004-072 11.16 69004-260 11.14 A664CHSCFGW 2.22 ES1224B250 1.336 69001-851 11.5 69004-074 11.16 69004-261 11.14 A6SPK6C 2.23 ES1224B250 1.338 69001-853 11.5 69004-075 11.16 69004-262 11.14 A864CHSCFG 2.22 EWFT 1.336 69001-856 11.5 69004-077 11.16 69004-263 11.14 A864CHSCFGW 2.22 EWFT 1.337 69001-860 11.5 69004-078 11.16 69004-264 11.14 A8SPK6C 2.23 EWFT 1.341 69001-865 11.5 69004-080 11.16 69004-265 11.14 ADP2 3.14 LMK20 2.12 69001-866 11.5 69004-083 11.16 69004-266 11.14 AL48 2.22 LMK30 2.12 69001-877 11.5 69004-086 11.18 69004-274 11.16 ANMV6 2.16 LMK40 2.12 69001-879 11.5 69004-087 11.18 69004-275 11.16 ANMV6 2.18 P4SPOOL 1.336 69001-884 11.5 69004-088 11.18 69004-276 11.16 CMFK 2.4 P4SPOOL 1.337 69001-905 11.5 69004-089 11.18 69004-277 11.16 CMFK 2.5 P4SPOOL 1.341 69001-944 11.5 69004-090 11.18 69004-278 11.16 D19BPT1RU 1.210 Q12126PCD 2.18 69001-976 11.4 69004-091 11.18 69004-279 11.16 D19BPT1RU 1.222 Q12129PCD 2.18 69001-980 11.5 69004-095 11.19 69004-280 11.16 D19BPT1RU 3.5 Q1286PCD 2.18 69001-980 11.7 69004-098 11.20 69004-281 11.16 D19BPT2RU 3.5 Q1289PCD 2.18 69001-981 11.5 69004-121 11.14 69004-282 11.16 D19FVT69B 1.143 Q1686PCD 2.18 69001-981 11.7 69004-122 11.14 69004-284 11.16 D19FVT69B 1.344 Q1689PCD 2.18 69001-995 11.6 69004-123 11.14 69004-286 11.16 D19FVT69B 3.12 Q20129PCD 2.18 69004-042 11.23 69004-124 11.16 69004-287 11.16 D19FVT912B 1.143 Q20158PCD 2.18 69004-043 11.22 69004-125 11.16 69004-288 11.16 D19FVT912B 1.344 Q202013PCICC 2.16 69004-044 11.22 69004-126 11.16 69004-289 11.16 D19FVT912B 3.12 Q202018PCICC 2.16 69004-045 11.22 69004-127 11.16 69004-290 11.16 DCHD2 1.339 Q2020PI 2.17 69004-046 11.23 69004-128 11.16 69004-291 11.16 DCHD2 3.10 Q241612PCD 2.18 69004-050 11.15 69004-129 11.16 69005-596 11.4 DCHS1 1.339 Q24169PCD 2.18 69004-051 11.15 69004-130 11.18 89009-001 3.23 DCHS1 3.10 Q302013PCI 2.16 69004-052 11.15 69004-131 11.18 89009-001 5.117 DCHS2 1.339 Q302013PCICC 2.16 69004-053 11.15 69004-155 11.21 89009-001 6.68 DCHS2 3.10 Q302018PCI 2.16 69004-054 11.15 69004-161 11.21 89009-001 7.113 DPX-AF1 3.48 Q3020PI 2.17 69004-055 11.15 69004-165 11.21 A1086CHSCFG 2.22 DPX-CC2-TR 3.48 Q303013PCI 2.16 69004-056 11.15 69004-169 11.21 A1086CHSCFGW 2.22 DPX-T1DP1 3.48 Q303013PCICC 2.16 69004-057 11.15 69004-240 11.14 A10SPK8C 2.23 DPX-T3H1 3.48 Q303018PCI 2.16 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.59 Appendix Part no. Page Part no. Page Q303018PCICC 2.16 TX528326100 4.49 Q3030PI 2.17 TX528348100 4.49 Q402013PCI 2.16 VAMONITOR 1.255 Q402018PCICC 2.16 Q4020PI 2.17 Q403013PCI 2.16 Q403013PCICC 2.16 Q403018PCI 2.16 Q403018PCICC 2.16 Q4030PI 2.17 Q554PCD 2.18 Q886PCD 2.18 QBIK 2.17 QDEHK 2.18 QDMFK 2.18 QIDR351505 2.17 QIDR352505 2.17 QIDR353505 2.17 QIHK 2.16 QIMFK 2.16 QIPDF 2.17 T150126G150 4.32 T200226G150 4.33 T290426G150 4.34 T430626G150 4.35 T430826G150 4.36 T431026G150 4.37 T501226G150 4.38 T531926G150 4.39 T622226G150 4.40 T703626G150 4.41 T706026G150 4.42 TE090624010 4.52 TE121024010 4.53 TE121048010 4.53 TE162024010 4.54 TE162048010 4.54 TOPTKSPL Page Part no. Page Part no. Page 1.321 TX231426100 4.46 TX231448100 4.46 TX332826100 4.47 TX332848100 4.47 TX385626100 4.48 TX385648100 4.48 12.60 Part no. SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Stichwortverzeichnis Produc day s t indexMain CataloguePart number in bold face type: ready for despatch within 2 working daysPart number in normal type: ready for despatch within 10 working Appendix 10", 19" A 10" wall mounted case, epcase. . . . . . . . . . . . . . . . . . . . 2.32 19" cabinet accessories 19" assembly kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.17 19" cable ducting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.8 19" cable trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.9 19" distribution field . . . . . . . . . . . . . . . . . . . . . . . . . . 3.14 19" drawers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.13 19" equipment shelves . . . . . . . . . . . . . . . . . . . . . . . . 3.11 19" front panels, filler panels . . . . . . . . . . . . . . . . . . . . 3.2 19" module support . . . . . . . . . . . . . . . . . . . . . . . . . . 3.16 19" mounting brackets . . . . . . . . . . . . . . . . . . . . . . . . 3.15 19" mounting trays . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.15 19" panel/slide mounts . . . . . . . . . . . see panel/slide mounts 19" vented front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.6 19" chassis inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.128 multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.112 19" fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4 19" fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6 19" lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354 19" wall mounted cases CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.2 epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.24 12.62 SCHROFF Main Catalogue www.schroff.biz E 05/2016 A48, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . 2.20 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.8 AC fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.16 AC input module with filter . . . . . . . . . . . . . . . . . . . . . . 8.111 AC mains switching for VARISTAR LHX 20 . . . . . . . . . 1.234 AC/DC 19" compatible linear regulators . . . . . . . . . . . . 9.10 AC/DC switched mode power supplies 19" compatible . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.2 Open Frame . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.21 Accessories Busbars . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.39, 11.10 Climate control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.58 Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.2 Electrics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.32 FPCS front panel component system . . . . . . . . . . . . 11.12 for cabinets and wall mounted cases . . . . . . . . . . . . . . 3.0 for desktop enclosures . . . . . . . . . . . . . . . . . . . . . . . 5.108 for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102 for power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16 for systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.106 Mechanics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2 Monitors, keyboards . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44 Power control socket strips . . . . . . . . . . . . . . . . . . . . . 3.72 Socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.50, 3.72 Telescopic slides . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.24 Addresses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.78 Adjustable feet for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302 for VARISTAR . . . . . . . . . . . 1.28, 1.40, 1.70, 1.166, 1.190 AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26 AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.56 AdvancedTCA Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.2 Air baffles for pusher fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.9 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26 Air conditioners . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1 TX series, GLIMAGUARD air/air heat exchangers . . . 4.44 TE series, Peltier, thermoelectric coolers . . . . . . . . . . 4.50 T series air conditioners. . . . . . . . . . . . . . . . . . . . . . . . 4.30 Air/air heat exchangers, CLIMAGUARD serie . . . . . . . . 4.44 Air filters for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.23 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.28, 2.33 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.55 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.61 for ratiopacPRO air . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.23 Air filtered fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.20 ELECTRONICS PROTECTION Appendix B Air/water heat exchangers VARISTAR LHX . . . 1.224, 1.236 Assembly cases, INLINE . . . . . . . . . . . . . . . . . . . . . . . . . 2.11 Assembly material for frame type plug-in units . 7.77, 7.92 Assembly tool . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.112 SCHROFF.PENTAIR.CO.UK Backplanes AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19 CompactPCI, Serial, PlusIO . . . . . . . . . . . . . . . . . . . . . 10.4 Dual star, full mesh . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0 Power piggyback . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.18 PXI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11 Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20 VME/VME64x bus . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13 VXS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13 Base plates for eurorack . . . . . . . . . . . . . . . . . . . . 1.280, 1.296, 1.308 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.249, 1.266 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.120 for VARISTAR . . . . . 1.15, 1.36, 1.73, 1.137, 1.175, 1.199 Bases/plinths for eurorack . . . . . . . . . . . . . . . . . . . . 1.280, 1.296, 1.308 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.250, 1.266 for VARISTAR 1.16, 1.36, 1.59, 1.73, 1.139, 1.176, 1.200 Bridges CompactPCI, PXI . . . . . . . . . . . . . . . . . . . . . . . . 10.11 Brush strip for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . 1.104 BS (British Standard) socket strip . . . . . . . . . . . . . . . . . 3.56 Busbars Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.39 for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.10 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.63 Appendix C C profile rails for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.359 for VARISTAR . . . . . . . . . . . . . . . 1.24, 1.66, 1.159, 1.162 Cabinets Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 Aisle containment . . . . . . . . . . . . . . . . . . . . . . 1.200, 1.202 etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.346 eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.270 Lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354 LHX with air/water heat exchanger . . . . . . . . . . . . . 1.224 NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.240 NET, cabling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.126 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 Outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.316 Open frame racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334 PROLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.362 Server cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.130 VARISTAR platform . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 Cable brackets, for VARISTAR . . . . . . . . . . . . . . 1.186, 1.210 Cable channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.21 Cable ducting Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.8 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.305 for LAN wall mounted enclosures . . . . . . 2.38, 2.41, 2.45 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.247, 1.262 for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.51, 1.83, 1.155 with C profile, VARISTAR . . . . . . . . . . . . . . . 1.185, 1.209 Cable eyes for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.359 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.31 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.283 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.24 Cable holders for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.81 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.65 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26 Cable ladder for VARISTAR . . . . . . . . . . . . . . . . . . . . . 1.160 Cable retention for C profiles . . . . . . . . . . . . . . . . . . . . . 3.20 Cable shells for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.283 for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.24, 1.66, 1.162 Cable support . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.21 Cable support rails for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.358 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.31 for VARISTAR . . . . . . . . . 1.24, 1.66, 1.161, 1.161, 1.209 Cable ties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.20 12.64 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Cable trays Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.9 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.287 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.160 for excess cable length for VARISTAR . . . . . . . . . . . 1.163 CAD drawings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 Cage nuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.18 Carriers, AdvancedMC . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26 Carrying handles for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.108 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.86 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.60 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26 Cases Desktop cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.0 minipac, small cases . . . . . . . . . . . . . . . . . . . . . . . . . . 7.98 Wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0 Castors for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.259 for VARISTAR . . . . . 1.28, 1.40, 1.70, 1.132, 1.166, 1.190 CE Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.7 Cermet potentiometer, FPCS (front panel component systems) . . . . . . . . . . 11.21 Certifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 Chassis Data Module (CDM) for AdvancedTCA . . . . . . 8.25 Chassis Monitoring Module (CMM) . . . . . . . . . . . . . . . 8.107 Circulation fans . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6 Clamp case, INLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.10 Clamp distributor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.34 CLIMAGUARD, TX series, air/air heat exchangers . . . . 4.44 Climate control, overview . . . . . . . . . . . . . . . . . . . . . . . . . 4.0 Clip-on plastic front panels for cabinets . . . . . . . . . . . . . 3.5 Cold aisle containment, for cabinets . . . . . . . . 1.200, 1.202 Combined mounting, for europacPRO . . . . . . . . . . . . . . 6.57 COMLINE, outdoor cabinets . . . . . . . . . . . . . . . . . . . . . 1.318 compacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.76 CompactPCI Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.4 Bridges . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11 for telecom applications . . . . . . . . . . . . . . . . . . . . . . . 8.86 Overview, chapter Systems . . . . . . . . . . . . . . . . . . . . 8.68 Power supply, AC/DC . . . . . . . . . . . . . . . . . . . . . . . . . 9.22 CompactPCI Serial, CompactPCI PlusIO Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.4 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.70, 8.73 ELECTRONICS PROTECTION Appendix D comptec, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.100 CONCEPTLINE, wall mounted cases . . . . . . . . . . . . . . . . 2.2 Connecting cables for fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.13 for Wieland connectors . . . . . . . . . . . . . . . . . . . . . . . 3.69 Schuko/UTE, BS, USA, IEC . . . . . . . . . . . . . . . . . . . 3.38 Connection plates for VARISTAR . . . . . . . . . . 1.37, 1.43, 1.74, 1.171, 1.195 Connectors Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.2 H 15 F . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16, 11.4 Housings for connectors . . . . . . . . . . . . . . . . . . . . . . 11.6 Types B, C, R, D, H, E, F, G, H, M . . . . . . . . . . . . . . 11.4 Containment, for cabinet aisles . . . . . . . . . . . 1.200, 1.202 Conventional carriers, AdvancedMC . . . . . . . . . . . . . . 8.32 Cooling concepts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2 Covers for filler modules, AdvancedMC modules . . . . . . . . . 8.66 for slots . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.61 Cover panels, for VARISTAR . . . . . . . . . 1.157, 1.169, 1.154 Cover plates for europacPRO subracks . . . . . . . . . . . . . . . . . . . . . 6.118 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.76 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.104 Cube, MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38 Cutaway carriers, AdvancedMC . . . . . . . . . . . . . . . . . . . 8.28 SCHROFF.PENTAIR.CO.UK DC fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.16 DC/DC converters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.13 Decorative frames, for VARISTAR . . . . . . 1.30, 1.130, 1.192 Depth members for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.309 for VARISTAR . . . . . . . . . . . 1.24, 1.51, 1.66, 1.83, 1.143 Desktop cases Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.108 compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.76 comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.100 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.0 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5 propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.44 ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.6 Dimension drawings compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.98 for cantilever extractor handle . . . . . . . . . . . . . . . . . . 7.43 for cantilever extractor handle type 2 . . . . . . . . . . . . . 7.44 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.274 for extractor handle for Multibus . . . . . . . . . . . . . . . . . 7.45 for extractor handle in key form . . . . . . . . . . . . . . . . . . 7.48 for extractor handle in key form 2 . . . . . . . . . . . . . . . . 7.51 for frame type plug-in units . . . . . . . . . . . . . . . . . 7.80, 7.88 for front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.25 for heavy duty XL insertion/extractor handle . . . . . . . 7.30 for HF frame type plug-in units . . . . . . . . . . . . . . . . . . 7.94 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.136 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.242 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.53 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.9 for ratiopacPRO air . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.16 for static cantilever handle . . . . . . . . . . . . . . . . . . . . . . 7.58 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.8 Guide rails . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.40 Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20 DIN rail mounting, for power supplies . . . . . . . . . . . . . . 9.17 Distribution box, for accessories . . . . . . . . . . . . . . . . . . 3.36 Distribution cabinet, VARISTAR NET . . . . . . . . . . . . . . 1.126 Distribution fields Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.14 for epcase 10" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.34 Divider plates for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.60 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.75 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.36 Document pocket, for cabinets . . . . . . . . . . . . . . . . . . . . 3.14 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.65 Appendix E 70 Doors for aisle containment . . . . . . . . . . . . . . . . . . . . . . . . . . 1.204 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.85 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.292, 1.304 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.246, 1.261 for VARISTAR . . . . . . . . . 1.31, 1.71, 1.130, 1.192, 1.204 Door hinge brackets for eurorack . . . . . . 1.279, 1.293, 1.293 Double doors, for VARISTAR . . . . . . . . . . . 1.32, 1.170, 1.194 Drawer with keyboard . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.45 Drilling template, front panel component system . . . . 11.23 Drive unit cables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.110 Drive units for systems . . . . . . . . . . . . . . . . . . . . . . . . . . 8.108 Dual star backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19 12.66 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Earthquake resistant cabinet, VARISTAR . . . . . . . . . . . 1.84 Edge protection for VARISTAR . . . . . . . . . . . . . . . . . . . . 1.104 Electronics cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . 1.10 Embedded systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0 EMC cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . 1.54 EMC gasketing for cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.70 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.53 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.121 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.55 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.65 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.23 for subracks for mobile railway applications . . . . . . . . 6.82 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.70 Front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.6, 7.8 Systems - Accessories . . . . . . . . . . . . . . . . . . . . . . . 8.106 Environmental protection . . . . . . . . . . . . . . . . . . . . . . . . 12.0 epcase, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . 2.24 Equipment cables, cabinet accessories . . . . . . . . . . . . 3.38 Equipment shelves Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.11 for 19" lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.29, 2.33 for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.351 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.47 ESD clips, for guide rails . . . . . . . . . . . . . . . . . . . . . . . . 6.41 ETSI panel/slide mounts for VARISTAR . . . . . . . . 1.45, 1.76 etsirack Overview cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.346 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.353 europacPRO Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18 EMC shielding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.52 for industrial applications . . . . . . . . . . . . . . . . . . . . . . . 6.86 for mobile railway applications . . . . . . . . . . . . . . . . . . . 6.70 for rugged applications. . . . . . . . . . . . . . . . . . . . . . . . . 6.92 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2 Project examples . . . . . . . . . . . . . . . . . . . . . . . 6.69, 6.85 Shielding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.42 eurorack, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.270 Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 Extractor handles Cantilever . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.37, 7.43 for Multibus . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.44 in key form . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.46, 7.48 Systems - Accessories . . . . . . . . . . . . . . . . . . . . . . . 8.106 ELECTRONICS PROTECTION Appendix F Fans for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.27 Supplementary fan for pusher fans . . . . . . . . . . . . . . 4.13 Fan Control Module (FCM) . . . . . . . . . . . . . . . . . . . . . . 8.106 Fan trays for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.21 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.53 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4 Selection guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.19 Fibre optic cable ducting for VARISTAR . 1.157, 1.186, 1.210 Fibre optic small case . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.38 Field Replaceable Units for AdvancedTCA, MicroTCA . . . . . . . . . . . . . . 8.20, 8.53 Filler modules, AdvancedMC, MicroTCA . . . . . . . . . . . . 8.16 Flat top covers, for VARISTAR . . . . . 1.35, 1.72, 1.172, 1.196 FloTHERM simulation, climate control . . . . . . . . . . . . . . . 4.2 FPCS (front panel component systems) . . . . . . . . . . . . 11.12 Frames for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.348 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.258 for VARISTAR . . . . . . . . . . 1.28, 1.40, 1.70, 1.166, 1.190 Lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.356 Open frame racks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334 Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.64, 7.86 Front handles for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.108 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25 for front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.3 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.133 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.121 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.25 Front hood for propacPRO . . . . . . . . . . . . . . . . . . . . . . . 5.62 Front panel component systems (FPCS) . . . . . . . . . . . 11.12 SCHROFF.PENTAIR.CO.UK Front panels Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2 Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6, 3.2 for AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . 8.60 for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.12 for cable ducting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.7 for cable eyes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.7 for cantilever extractor handles . . . . . . . . . . . . . 7.33, 7.40 for Coax connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.11 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.82 for D-Sub connectors . . . . . . . . . . . . . . . . . . . . . . . . . . 7.10 for epcase, 10" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.34 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.48 for europacPRO, hinged . . . . . . . . . . . . . . . . . . . . . . . 6.52 for extractor handle in key form . . . . . . . . . . . . . 7.46, 7.48 for static cantilever handles . . . . . . . . . . . . . . . . . . . . . 7.54 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . 7.76 for HF frame type plug-in units . . . . . . . . . . . . . . . . . . . 7.91 for IEL/IET insertion/extractor handles . . . . . . . . . . . . . 7.19 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.131 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.16 for Multibus . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.44 for PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.54 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.21 hinged, bottom-hinged . . . . . . . . . . . . . . . . . . . . . 7.8, 7.9 Mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2 shieldable, unshielded, U profile . . . . . . . . . 7.4 , 7.5, 7.7 Systems - Accessories . . . . . . . . . . . . . . . . . . . . . . . . 8.106 with GND/earthing connection . . . . . . . . . . . . . . . . . . 7.11 with holes for handles . . . . . . . . . . . . . . . . . . . . . . . . . . 3.2 Full mesh backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.19 Full-width front panels for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.131 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.54 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.21 Fuse holder, front panel component systems) . . . . . . 11.20 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.67 Appendix G H Gasketing kit, for VARISTAR EMC . . . . . . . . . . . . . . . . . . 1.70 Glass doors for eurorack . . . . . . . . . 1.278, 1.291, 1.292, 1.303, 1.303 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.246, 1.261 for VARISTAR . . . . . . . . . . . . . . . 1.30, 1.41, 1.168, 1.192 Glazed doors for eurorack . . . . . . . . . . . . . . . . . . . . 1.279, 1.291, 1.291 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.246, 1.261 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . 1.30, 1.41 GND/earthing clamp, for cabinets . . . . . . . . . . . . . . . . . 3.36 GND/earthing kits for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.86 for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.106 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.133 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.65 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.24 Grub screws, for europacPRO . . . . . . . . . . . . . . . . . . . . 6.66 Guide rails. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.40 for AdvancedMC compact and full-size modules . . . . 8.34 for AdvancedMC mid-size modules . . . . . . . . . . . . . . 8.34 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.92 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.35 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.76 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.134 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.49 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.124 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.73 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.40 for subracks for railway applications . . . . . . . . . . . . . 6.81 for test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.27 with keying/coding for CompactPCI and VME64x . . . . 6.35 12.68 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Handles Cantilever extractor handle . . . . . . . . . . . . . . . . 7.37, 7.43 Extractor handle for Multibus . . . . . . . . . . . . . . . . . . . 7.44 Extractor handle in key-form . . . . . . . . . . . . . . . 7.46, 7.48 Folding handle for comptec . . . . . . . . . . . . . . . . . . . . 5.105 for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.13 for AdvancedTCA modules . . . . . . . . . . . . . . . . . . . . . 8.58 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.76 for front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.3 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.60 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.24 Heavy duty XL insertion/extractor handle . . . . . . . . . . 7.30 IEL, IET . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.20, 7.21 PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102 Static cantilever handle . . . . . . . . . . . . . . . . . . . . . . . . 7.55 Tip-up carrying handle . . . . . . . . . . . . . . . . . . . . . . . 5.112 Tray handle . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.114 Heat dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0 Heaters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.58 Heat exchangers Air/air heat exchangers . . . . . . . . . . . . . . . . . . . . . . . . 4.44 Air/water heat exchangers . . . . . . . . . . . . . . . 1.224, 1.236 HF frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.90 Horizontal board assembly europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.58 propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.71 ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.38 Horizontal rails Assembly position compacPRO. . . . . . . . . . . . . . . . . . 5.88 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.89 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.132 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.67 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.31 Hygrostats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.66 ELECTRONICS PROTECTION Appendix I Identification strips for IEL, IET insertion/extractor handles . . . . . . . . . . . . 7.23 for PCB handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.41 IEA handles, for AdvancedTCA . . . . . . . . . . . . . . . . . . . . 8.13 IEC socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . 3.68, 3.58 IEL handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.20 IET handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.21 INLINE, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . 2.8 inpac, 19" chassis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.128 Insulation strips compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.90 europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.33 propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.68 ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.35 Internet . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 IP codes (ingress protection) . . . . . . . . . . . . . . . . . . . . . 12.4 ISO 9001/14001 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0 SCHROFF.PENTAIR.CO.UK K Keyboard drawers . . . . . . . . . . . . . . . . . . . . . . . . . 3.13, Keyboards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keying/coding for CompactPCI, VME64x handles . . . . . . . . . . . . . . . for connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . for IEL/IET insertion/extractor handles . . . . . . . . . . . . . block for guide rails . . . . . . . . . . . . . . . . . . . . . . . . . . . pegs for codable spring contact strips . . . . . . . . . . . . . pegs for connector . . . . . . . . . . . . . . . . . . . . . . . . . . . . pin for subracks for railway applications . . . . . . . . . . . Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 3.46 3.44 6.41 11.7 7.23 6.40 11.7 11.8 6.83 12.69 Appendix LSA+ bracketfor LAN wall-mounted enclosures 2.53 L M Lab racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.354 LAN wall mounted enclosures Basic cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.40 Fibre optic small cases . . . . . . . . . . . . . . . . . . . . . . . . 2.38 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.36 Lateral cable ducting for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.310 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . 1.167, 1.191 LEDs, FPCS (front panel component systems) . . . . . . 11.14 Lever handles for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.28 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.15 LHX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.224 Lifting eyes, for VARISTAR . . . . . . . . . . . . . . . . . 1.35, 1.133 Lights, for cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.29 Light pipe . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.58 Linear regulators, 19" compatible . . . . . . . . . . . . . . . . . 9.10 Locking levers for connectors . . . . . . . . . . . . . . . . . . . . 11.6 LSA+ bracket, for LAN wall mounted enclosures . . . . 2.43 12.70 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Mains switching . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.234 Make-brake socket, FPCS . . . . . . . . . . . . . . . . . . . . . . . 11.19 Management for VARISTAR LHX . . . . . . . . . . . . . . . . . 1.235 Master slave SCHUKO socket strip . . . . . . . . . . . . . . . . . . . . . . . . . 3.53 UTE socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67 Mezzanine front panel, for systems . . . . . . . . . . . . . . . . 7.14 MIL VARISTAR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.120 Micro switches for IEL insertion/extractor handle . . . . . . . . . . . . . . . . 7.23 for AdvancedMC compact and full-size modules . . . . 8.67 for AdvancedMC mid-size modules . . . . . . . . . . . . . . 8.34 for AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . 8.67 MicroTCA Carrier Hub (MCH) . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.36 Power supplies. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.18 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38 minipac, small cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.98 minirack . . . . . . . . . . . . . . . . . . . . . . see NOVASTAR cabinets Modem support, for epcase . . . . . . . . . . . . . . . . . . . . . . 2.33 Modular, outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . 1.326 Module support/slide rails for europacPRO , europacPRO rugged . . . . . . . . . . . . 6.89 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.132 for QLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.17 Module supports, cabinet accessories . . . . . . . . . . . . . 3.16 Modules or plug-in units Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.64 Front panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.0 Plug-in units . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.16 PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.12 Monitors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44 Mounting aid, for cage nuts . . . . . . . . . . . . . . . . . . . . . . 3.19 Mounting brackets, cabinet accessories . . . . . . . . . . . . 3.15 Mounting plates for A48 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.23 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.94 for CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.6 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.59 for INLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.13 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.120 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.64 for QLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.17 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.37 for single socket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.36 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . 1.17, 1.47, 1.78 ELECTRONICS PROTECTION Appendix N Mounting system with C profiles for eurorack . . . . . . 1.282 Mounting tray for LSA+ . . . . . . . . . . . . . . . . . . . . . . . . . 3.15 multipacPRO Overview 19" subracks . . . . . . . . . . . . . . . . . . . . . . . 6.112 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.127 SCHROFF.PENTAIR.CO.UK Networking cabinet, VARISTAR . . . . . . . . . . . . . . . . . . NOVASTAR, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . Nuts 19" assembly parts, cage nuts . . . . . . . . . . . . . . . . . . M2.5, M4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.126 1.240 3.19 7.111 12.71 Appendix O P OHSAS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0 Open frame racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.334 Order notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8, 12.10 Outdoor cabinets Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.316 COMLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.318 Modular . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.326 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.331 Unibody . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.322 12.72 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Panel mounts for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.358 for CONCEPTLINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.7 Panel/slide mounts for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.297, 1.309 for outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . 1.328 for VARISTAR . 1.19, 1.44, 1.61, 1.75, 1.142, 1.177, 1.201 Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . see front panels Part number table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.11 PCBs Assembly parts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.107 Board fixing for frame type plug-in units . . . . . . . . . . . 7.78 Covers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.62, 7.105 Handle for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.135 Handle for PCB retainer . . . . . . . . . . . . . . . . . . . . . . . 6.41 Handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.106 Handles, retainers . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.102 Pocket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.105 Reinforcement . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.97 Retainer for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.135 Retainer for PCBs . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.41 Strengthening for connectors . . . . . . . . . . . . . . . . . . . 11.8 Peltier thermoelectric coolers . . . . . . . . . . . . . . . . . . . . . 4.50 Perforated strips, for europacPRO . . . . . . . . . . . . . . . . . 6.33 Plastic feet, for cases . . . . . . . . . . . . . . . . . . . . . . . . . . 5.116 Plug-in units Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.16 with cantilever extractor handle . . . . . . . . . . . . . . . . . 7.38 with cantilever extractor handle type 2 . . . . . . . . . . . . 7.32 with fixed extractor handle . . . . . . . . . . . . . . . . . . . . . 7.53 with IEL insertion/extractor handle . . . . . . . . . . . . . . . 7.18 with mechanical shielding . . . . . . . . . . . . . . . . . . . . . . 7.60 PMC mezzanine, Modules, front panels . . . . . . . . . . . . . 7.12 Potential adjustment rail, cabinet accessories . . . . . . . 3.37 Potential distributor, for busbars . . . . . . . . . . . . . . . . . 11.10 Power backplane, with P47 connector . . . . . . . . . . . . . 10.18 Power connector, cabinet accessories. . . . . . . . . . . . . . 3.39 Power control socket strips . . . . . . . . . . . . . . . . . . . . . . . 3.72 Power distribution modules, cabinet accessories . . . . 3.34 Power distributors, socket strips . . . . . . . . . . . . . . . . . . 3.70 Power entry modules for AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.20 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.50 ELECTRONICS PROTECTION Appendix Q Power supplies AC/DC linear regulators . . . . . . . . . . . . . . . . . . . . . . . 9.10 AC/DC switched mode units . . . . . . . . . . . . . . . . . . . . . 9.2 Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16 CompactPCI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.22 Connector H 15 F . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.16 DC/DC converters . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.13 for MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.18 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.0 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.29 Wall mounting/DIN rail assembly . . . . . . . . . . . . . . . . 9.17 Project examples AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . 8.35 Desktop cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5 etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.353 europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.69, 6.85 multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.127 Outdoor cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.331 Power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.29 Subracks for railway applications . . . . . . . . . . . . . . . . 6.85 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.113 VARISTAR Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . 1.119 PROLINE, cabinets . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.362 propacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.44 Protective grilles Fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.13 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.27 Pull-handle mechanism, for AdvancedMC modules . . . 8.58 PXI Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11 Bridges . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.11 SCHROFF.PENTAIR.CO.UK QLINE, wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . 2.16 Quality . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0 Quick-release fastener, for front panels . . . . . . . . . . . . 7.107 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.73 Appendix R S Radial fan unit for ratiopacPRO air . . . . . . . . . . . . . . . . . 5.17 ratiopacPRO, cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.6 Rear hood for europacPRO subracks . . . . . . . . . . . . . . . 6.47 Rear panels for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.82 for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.349 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.48 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . . 7.77 for HF frame type plug-in units . . . . . . . . . . . . . . . . . . 7.91 for inpac . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.131 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.248, 1.263 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.55 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.20 for VARISTAR . . . . . . . . . . 1.29, 1.41, 1.71, 1.171, 1.195 12.74 SCHROFF Main Catalogue www.schroff.biz E 05/2016 SCHUKO socket strips . . . . . . . . . . . . . . . . . . . . . . 3.52, 3.67 Screws Collar screws, countersunk screws, panhead screws, grub screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.64, 7.107 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.64 Search function . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 Seismic, VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.84 Server cabinet, VARISTAR . . . . . . . . . . . . . . . . . . . . . . 1.130 Service offers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 ServicePLUS AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . 8.35 AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . 8.67 Air conditioners . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.43 Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.29 Cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4 etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.352 europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16 europacPRO rugged . . . . . . . . . . . . . . . . . . . . . . . . . . 6.95 eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.288, 1.300 Fan trays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.19 Frame type plug-in units . . . . . . . . . . . . . . . . . . . . . . . 7.74 Lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360 MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112 NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.256 multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.118 Outdoor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.330 Power control socket strips . . . . . . . . . . . . . . . . . . . . . 3.72 Power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.28 Socket strips . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.71 Subracks for railway applications . . . . . . . . . . . . . . . . 6.84 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112 VARISTAR Datacom/Networking . . . . . . . . . . . . . . . 1.164 VARISTAR Electronis . . . . . . . . . . . . . . . . . . . . . . . . . 1.26 VARISTAR EMC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.68 VARISTAR LHX with air/water heat exchanger . . . . . 1.224, 1.236 VARISTAR NET . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.164 VARISTAR Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . 1.96 VARISTAR Server . . . . . . . . . . . . . . . . . . . . . . . . . . 1.164 Wall mounted cases . . . . . . . . . . . . . . . . . . . . . . . . . . 2.46 Shelf alarm display for AdvancedTCA . . . . . . . . . . . . . . 8.24 Shelf alarm panel for AdvancedTCA . . . . . . . . . . . . . . . 8.23 Shelf manager for AdvancedTCA . . . . . . . . . . . . . . . . . . 8.18 Shelves for eurorack . . . . . . . . . . . . . . . . . . . . . 1.285, 1.299, 1.312 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . 1.253, 1.267 for VARISTAR . 1.21, 1.49, 1.63, 1.80, 1.145, 1.182, 1.206 for VARISTAR . . . . . . . . . . . . . . . . 1.47, 1.78, 1.180, 1.204 ELECTRONICS PROTECTION Appendix Short slide rails for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.31 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.284 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.252, 1.268 for VARISTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.144 Side panels for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.291, 1.303 for frame type plug-in units . . . . . . . . . . . . . . . . . . . . 7.76 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.260 for VARISTAR . . . . . . . . . . . . . . . 1.29, 1.41, 1.167, 1.191 Side-by-side mounting for etsirack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.349 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.290, 1.302 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.260 for VARISTAR . . . . . . . . . . 1.28, 1.40, 1.70, 1.166, 1.190 Sleeves for front panels . . . . . . . . . . . . . . . . . . . . . . . . . 7.107 Slide nuts for HF frame type plug-in units . . . . . . . . . . 7.92 Slide rails for 19" lab rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.360 for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.105 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.31 for eurorack . . . . . . . . . . . . . . . . . . . . . 1.284, 1.298, 1.311 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.252, 1.268 for VARISTAR 1.20, 1.51, 1.62, 1.82, 1.144, 1.184, 1.208 Slides for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . 6.71 Socket strips BS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.56 for epcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.32 IEC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.58 IEC, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.68 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.50 SCHUKO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.52 SCHUKO, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.72 Swiss version . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.63 USA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.62 UTE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.55 UTE, Wieland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67 Solder side cover for PCBs, for systems . . . . . . . . . . . . 7.62 Spacers for PMC mezzanine . . . . . . . . . . . . . . . . . . . . . . 7.14 Splicing casettes, splicing casette holders . . . . . 2.39, 2.42 Stacking aid for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . 5.23 Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.0 Management for VARISTAR LHX . . . . . . . . . . . . . . . . . 1.235 SCHROFF.PENTAIR.CO.UK Steel doors for eurorack . . . . . . . . . . . . . . . . . . . . . 1.278, 1.292, 1.292 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . 1.246, 1.261 for VARISTAR . . . . . . . . . . 1.31, 1.41, 1.71, 1.169, 1.193 Strap handles for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.111 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.60 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.26 Strip conductors for busbars . . . . . . . . . . . . . . . . . . . . . 11.11 Struts for AdvancedMC carriers . . . . . . . . . . . . . . . . . . 8.34 Subrack systems . . . . . . . . . . . . . . . . . . see chapter Systems Subracks Assembly service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2 for assembly of connectors . . . . . . . . . . . . . . . . . . . . . 6.9 for backplane mounting . . . . . . . . . . . . . . . . . . . . 6.8, 6.73 for CompactPCI applications . . . . . . . . . . . . . . . . . . . . 6.14 for industrial applications . . . . . . . . . . . . . . . . . . . . . . . 6.86 for railway applications . . . . . . . . . . . . . . . . . . . . . . . . . 6.70 für rugged applications . . . . . . . . . . . . . . . . . . . . . . . . . 6.92 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.0 Project examples . . . . . . . . . . . . . . . . . . . . . . . 6.69, 6.85 Support arm for monitor and keyboard, NOVASTAR . . 1.255 Swing frames for VARISTAR . . . . . 1.18, 1.46, 1.60, 1.77, 1.179, 1.203 Systems Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.106 AdvancedMC carriers . . . . . . . . . . . . . . . . . . . . . . . . . . 8.26 AdvancedMC modules . . . . . . . . . . . . . . . . . . . . . . . . . 8.56 AdvancedTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.2 CompactPCI, Serial, PlusIO . . . . . . . . . . . . . . . . . . . . . 8.68 Express service . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.112 MicroTCA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.38 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0 Project examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.113 VME64x/VXS/VME . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.88 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 12.75 Appendix T U Tape measure with HP, U and cm division . . . . . . . . . . 3.23 Telemonitored socket strips . . . . . . . . . . . . . . . . . . . . . 3.72 Telescopic slides Cabinet accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 3.25 for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.62 for multipacPRO . . . . . . . . . . . . . . . . . . . . . . . 6.121, 6.125 Selection guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.24 Test adaptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.20 Test reports . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 Test sockets for front panel component systems . . . . 11.18 Thermoelectric coolers, Peltier, TE series . . . . . . . . . . . . 4.50 Thermostats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.63 Threaded inserts compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.90 europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.33 multipacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.121 propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.68 ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.35 Tip-over protection for VARISTAR . . . . . . . . . . . . . . . . 1.108 Tip-up carrying handles for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.112 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.86 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.60 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.27 Tip-up feet for cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.116 for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.87 for comptec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.107 for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.72 for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.23 Top covers for cabinet aisle containment . . . . . . . . . . . . . . . . . . . 1.208 for eurorack . . . . . . . . . . . . . . . . . . . . . . . . . . 1.294, 1.306 for NOVASTAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.264 for VARISTAR . . . . . . . . . . . 1.33, 1.41, 1.72, 1.172, 1.196 Touchpad . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.44 Tower housing ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . 5.12 Tray for excess cable lenghts for VARISTAR . . 1.186, 1.210 Tray handle for cases . . . . . . . . . . . . . . . . . . . . . . . . . . 5.114 Trim/panel mounting for europacPRO . . . . . . . . . . . . . 6.90 T series, air conditioners. . . . . . . . . . . . . . . . . . . . . . . . . . 4.30 TE series, Peltier, thermoelectric coolers . . . . . . . . . . . . 4.50 Tubular rivets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.111 TX series, CLIMAGUARD, air/air heat exchangers . . . . . 4.44 12.76 SCHROFF Main Catalogue www.schroff.biz E 05/2016 Unibody, outdoor cabinets. . . . . . . . . . . . . . . . . . . . . . . 1.322 USA socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.62 User manuals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 UTE socket strip . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.67, 3.55 ELECTRONICS PROTECTION Appendix V VARISTAR Cabinets Air/water heat exchangers LHX . . . . . . . . . . . . . . . . . 1.224 Containment . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.202 Datacom/Networking . . . . . . . . . . . . . . . . . . . . . . . . . 1.124 Deco, with deco frame . . . . . . . . . . . . . . . . . . . . . . . . . 1.12 Electronics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.10 EMC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.54 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 IP 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.13 IP 55 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.14 Networking cabinet . . . . . . . . . . . . . . . . . . . . . . . . . . 1.126 MIL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.120 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 Platform . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 Project examples Seismic . . . . . . . . . . . . . . . . . . . . . 1.119 Seismic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.84 Server . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.130 Velcro, cabinet accessories . . . . . . . . . . . . . . . . . . . . . . 3.20 Vented top cover for VARISTAR . . . . . . . . . 1.35, 1.72, 1.133, 1.174, 1.198 VME64x/VXS/VME Backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.13 Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.88 Voltage keying/coding pin for PMC mezzanine . . . . . . 7.14 VXS backplanes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.14 W Wall mounted cases Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 A48, fibreglass reinforced plastic, IP 66 . . . . . . . . . . . . 2.20 CONCEPTLINE, steel, IP 66 . . . . . . . . . . . . . . . . . . . . 2.2 epcase, 10"/19" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.32 epcase, steel, IP 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.24 INLINE, steel, IP 66 . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.8 LAN wall mounted enclosures . . . . . . . . . . . . . . . . . . . 2.36 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.0 QLINE, plastic, IP 67 . . . . . . . . . . . . . . . . . . . . . . . . . . 2.16 Wall mounting for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25 for outdoor applications . . . . . . . . . . . . . . . . . . . . . . . 1.325 for power supplies . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.17 Washers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.111 Water-cooled cabinet VARISTAR LHX . . . . . . . 1.224, 1.236 Wieland SCHUKO, IEC, UTE socket strips .. . 3.66, 3.67, 3.68 Z Z rails for compacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . for europacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . for propacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . for ratiopacPRO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 5.91 6.34 5.69 5.35 12.77 Adressen_Katalogrueckseite_FM9.fm Seite 78 Donnerstag, 11. Oktober 2012 3:36 15 Stichwortverzeichnis Adressen Hauptkatalog Hauptkatalog Bestell-Nr. in Fettdruck: versandfertig innerhalb von 2 Arbeitstagen Bestell-Nr. in Normalschrift: versandfertig innerhalb von 10 Arbeitstagen Europe Austria Voltohm GmbH Frutzstraße 4 6832 Sulz, Vorarlberg Tel.: +43 5522 494 20 Fax: +43 5522 421 41 info@voltohm.at www.voltohm.at Germany Schroff GmbH Langenalber Straße 96 - 100 75334 Straubenhardt Tel.: +49 (0) 7082 - 794-0 Fax: +49 (0) 7082 - 794-200 schroff.de@pentair.com www.schroff.de Lithuania UAB SOMI RT Ukmerges St. 283A, 06313 Vilnius Tel.: +370 5 270 90 00 Fax: +370 5 270 90 66 info@somi.lt www.somirt.lt Slovakia E-comps s.r.o. Nobelova 30 831 02 Bratislava Tel.: +421 2 44 63 48 15 Fax: +421 2 44 63 48 16 info@e-comps.sk www.e-comps.sk Belarus Conektro UE Ostroshitskaya St. 4, ground floor 220125 Minsk Tel.: +375 17 265 6741 Fax: +375 17 265 6744 schroff@conektro.by www.conektro.by Great Britain Schroff UK Ltd. Unit 4, Grovelands Business Centre, Boundary Way Hemel Hempstead, Hertfordshire, HP2 7TE Tel.: +44 (0) 1442 24 04 71 Fax: +44 (0) 1442 21 35 08 schroff.uk@pentair.com www.schroff.co.uk Netherlands Koning & Hartman BV Industrial Electronics, Energieweg 1 2627 AP Delft Tel.: +31 (0) 15 260 9906 Fax: +31 (0) 15 260 9194 salesdesk.ie@koningenhartman.com www.koningenhartman.com Slovenia IC Elektronika d.o.o. Vodovodna 100 1000 Ljubljana Tel.: +386 (0) 1 568 01 37 Fax: +386 (0) 1 568 91 07 info@ic-elect.si www.ic-elect.si Norway Elfa Distrelec AS Sandakerveien 76 F 0483 Oslo Tel.: +47 2312 49 00 Fax: +47 2312 49 20 norge@elfa.se www.elfa.se Spain Cenvalsa Calle Ulises 104 28043 Madrid Tel.: +34 (91) 721 60 10 sismecanic@cenval.es www.cenval.es Belgium Koning & Hartman BV Woluwelaan 31 1800 Vilvoorde Tel.: +32 (0) 2 257 02 00 Fax: +32 (0) 2 257 02 02 salesdesk.belgium @koningenhartman.com www.koningenhartman.com Czech Republic ZTC electronic Praha, s.r.o. P. O. Box 34 14900 Prague 415 Tel.: +420 2 67 91 00 82 Fax: +420 2 67 91 06 41 ztc@ztc.cz, www.ztc.cz Croatia Chronos Info D. O. O. Medvedgradska 35 1000 Zagreb Tel.: +385 (0)1 466 70 59 Fax: +385 (0)1 466 69 77 chronos@chronos.hr www.chronos.hr Denmark Wexoe A/S Lejrvej 31 3500 Værløse Tel.: +45 45 46 58 00 Fax: +45 45 46 58 01 wexoe@wexoe.dk www.wexoe.dk Finland Elfa Distrelec OY Sockenbackavägen 14 00380 Helsingfors Tel.: +358 9 560 50 0 Fax: +358 9 560 50 100 tilaukset@elfa.se www.elfa.se France Schroff SAS Z.I. 4, rue du Marais Boîte Postale 16 67660 Betschdorf Tel.: +33 (0) 3 88 90 64 90 Fax: +33 (0) 3 88 90 64 88 schroff.fr@pentair.com www.schroff.fr 12.78 10/2012 Greece SUPERCHIP Ltd. 18 K. Paleologou Str. 18233 Ag. Ioannis Renti Athens Tel.: +30 210 5222 600 Fax: +30 210 5222 060 info@superchip.gr www.superchip.gr Hungary NB Electronic Kft. Kaszásdülö u. 2. 1033 Budapest Tel.: +36 (06) 1 387 14 55 Fax: +36 (06) 1 453 08 26 nbelectronic@nbelectronic.hu www.nbelectronic.hu Ireland EPS Ltd. Unit 17 Kinsealy Business Park, Kinsealy Co Dublin Tel.: +353 1 803 89 18 Fax: +353 1 803 89 19 info@epsglobal.com www.electronicproductservices.com Israel Ram Nir Electronic Packaging & Services 4 Ben-Gurion Str. Nes Ziona 74030 Tel.: +972 8 930 37 77 Fax: +972 8 940 12 86 ramdevelopment@ ramdevelopment.com www.ramdevelopment.com Italy Schroff S.r.l. Via Brughiera 1 20010 Pregnana Milanese (MI) Tel.: +39 02 932 714-1 Fax: +39 02 932 714-891 schroff.it@pentair.com www.schroff-italia.it Latvia LAPP MILTRONIC SIA Ulbrokas street 44a Riga 1021 Tel.: +371 6750 1900 Fax: +371 6750 1909 info@lappmiltronic.lv www.lappmiltronic.lv Poland Pentair Poland Sp.z o.o. ul. Marynarska 21 02-674 Warsaw Tel.: +48 22 607 06 16 Fax: +48 22 607 06 21 schroff.pl@pentair.com www.schroff.pl Sweden Schroff Scandinavia AB Flygfältsgatan 11 P. O. Box 2003 12821 Skarpnäck Tel.: +46 (0) 8 683 61 00 Fax: +46 (0) 8 683 61 99 schroff.se@pentair.com www.schroff.se Portugal ARESTEL Componentes e Praceta Torres do Restelo no. 10 1400-401 Lisbon Tel.: +351 21 303 08 50 Fax: +351 21 301 62 21 telecom@arestel.pt www.arestel.pt Switzerland Rotronic AG Grindelstr. 6 8303 Bassersdorf Tel.: + 41 (0) 44 838 12 12 Fax: + 41 (0) 44 837 00 74 ime@rotronic.ch www.rotronic.ch Russia Schroff Russia, Proezd #607, Building 30, Office 512, 123458 Moscow Tel. +7 (495) 730 52 53 Fax. +7 (495) 730 52 53 schroff.ru@pentair.com Turkey Schroff GmbH Turkey Liaison Office 34303 Ikitelli Istanbul Tel.: + 90 (0) 212 444 16 46 Fax: + 90 (0) 212 494 47 95 ediz.yanikoglu@pentair.com www.schroff.biz PROSOFT Ltd. 108, Profsouznaya Str. 117437 Moscow Tel.: +7 (495) 234 06 36 Fax: +7 (495) 234 06 40 info@prosoft.ru www.prosoft.ru Spectr RS Ltd. 12, Mebelnaya str., Office 402 197374 Saint Petersburg Tel./Fax: +7 (812) 640-41-90 office@spectr-rs.ru www.spectr-rs.ru ITC Electronics Ltd. Ziryanovskaya, 53 630102 Novosibirsk Tel.: +7 (383) 328 1 328 Fax: +7 (383) 328 1 281 nsk@itc-electronics.com www.itc-electronics.com ОVERTIME nab. Chernoi Rechki 41 i 197342 Saint Petersburg Tel.: +7 (812) 327 34 86 Fax: +7 (812) 327 34 85 serg@overtime.ru www.overtime.ru Ukraine Megatrade BC "Grand Step" 24D, Polyova St. 03056 Kiev Tel.: +380 44 538 00 06 Fax: +380 44 538 00 16 office@megatrade.com.ua www.megatrade.com.ua VD MAIS Michaila Dontsa St. 6 03061 Kiev Tel.: +380 44 220 01 01 Fax: +380 44 220 02 02 info@vdmais.kiev.ua www.vdmais.kiev.ua Adressen_Katalogrueckseite_FM9.fm Seite 79 Donnerstag, 11. Oktober 2012 3:36 15 Asia Bahrain Pentair Equipment Protection Al-Khobar 31952 P. O. Box 3298 Tel.: +966 54 8088 774 ala.shehadah@pentair.com www.schroff.biz China Pentair Equipment Protection China Shanghai Office Yan An West Road 1118, Longment Building, Room 905 Changning District Shanghai, PC 200052 Tel.: +86 (0) 21 3211 4588 ext.285 Fax: +86 (0) 21 3460 6017 sales.china@pentair.com www.ptpc.com www.schroff.biz U.A.E Pentair Middle East P.O.Box 7709 2202 - 2204, 22nd Floor, API World Tower, Sheikh Zayed Road Dubai Tel.: +971 4 3781700 Fax: +971 4 3781777 tp.mea@pentair.com www.schroff.biz Hong Kong Alberta Electronic Company Ltd. Unit B, 28/F, Legend Tower, 7 Shing Yip St., Kwun Tong, Kowloon Tel.: +852 2334 27 88 Fax: +852 2303 00 23 sales.china@pentair.com www.alberta.com.hk India Pentair Equipment Protection India Pvt. Ltd., Unit 1, Factory 2, Sai Lakshmi Industrial Campus Kannamangala, Bidarahalli Hobli, Whitefield - Hoskote Road Bangalore 560067 Tel.: +91 80 671 52 000 contact.marketing@pentair.com www.schroff.biz Indonesia P.T. Nego Electrindo Ruko Mega Grosir Cempaka MAS Blok I, No. 20-22, Jl. Let. Jend. Suprato Jakarta 10640 Tel.: +62 21 4288 22 55 Fax: +62 21 4288 22 66 sales@negoelectrindo.co.id www.negoelectrindo.co.id Japan Schroff K.K., Nisso No. 13, Bldg. 4F 2-5-1 Shinyokohama, Kohoku-ku Yokohama-shi, Kanagawa 222-0033 Tel.: +81 (0)45 476 02 81 Fax: +81 (0)45 476 02 89 sales@schroff.co.jp www.schroff.co.jp Kazakhstan ITC Electronics Ltd. Prospekt Raiymbeka 221a/4 050016 Almaty Tel.: +7 (727) 279 71 17 Fax: +7 (727) 233 93 44 almaty@itc-electronics.com www.itc-electronics.com Korea ARA Electronics Co. Ltd. 501 Daeryung Techno-Town 1 327-24 Kasan-dong Kumchon-gu 153-023 Seoul Tel.: +82 2 855 54 00 Fax: +82 2 855 34 90 office@ara.co.kr www.ara.co.kr Singapore Hoffman Schroff Pte. Ltd. 18 Boon Lay Way #04-110/111 Tradehub 21 Singapore 609966 Tel.: +65 6795 22 13 Fax: +65 6795 22 19 hoffmanschroff@pacific.net.sg www.schroff.biz Taiwan Lumax International Corp. Ltd. 12 F, No. 3-1, Park Street Taipei 11503 Tel.: +886 2 2788 36 56 Fax: +886 2 2782 73 69 vincentma@elumax.com www.elumax.com Thailand Pisanu Engineering Co., Ltd. 800/43-45 Soi Trakul Suk Asoke Dindaeng Road Dindaeng Bangkok 10400 Tel.: +662 245 9113 Fax: +662 246 9220 ecsales@pisanu.co.th www.pisanu.co.th Saudi Arabia Pentair Equipment Protection P. O. Box 3298 Al-Khobar 31952 Tel.: +966 54 8088 774 ala.shehadah@pentair.com www.schroff.biz Americas United States of America Pentair Equipment Protection 2100 Hoffman Way Anoka, MN 55303 Tel.: +1 (763) 421-2240 www.pentairtechnicalproducts.com Pentair Equipment Protection 170 Commerce Drive Warwick, RI 02886 Tel.: +1 (401) 732-3770 Fax: +1 (401) 738-7988 Toll free (800) 451-8755 schroff.us@pentair.com www.schroff.us Central and South America Pentair Equipment Protection Rua João Marcon, 165 18550.000, Boituva - SP, Brazil Tel.: +55 (15) 3363 9101 Fax: +55 (15) 3363 9104 www.taunus.com.br Australia Australia SOANAR Pty. Ltd. 320, Victoria Rd. Rydalmere, Sydney NSW 2116 Tel.: +61 2 8832 3000 Fax: +61 2 8832 3030 schroff@soanar.com www.soanar.com Dedicated Systems Australia Pty Ltd. 5A / 5-11 Glen Osmond Road Eastwood SA 5063 Adelaide Tel.: +61 8 8299 9333 Fax: +61 8 8299 9344 sales@dedicatedsystems.com.au www.dedicatedsystems.com.au Pentair Water Australia Pty. Ltd. 1-21 Monash Drive Dandenong South, VIC 3175 Tel.: +61 3 9709 5800 Fax: +61 3 9709 5885 glenn.brooks@pentair.com www.pentairwater.com.au New Zealand Soanar New Zealand 16-18 Fisher Crescent Mount Wellington Auckland 1060 Tel.: +64 9 258 5133 Fax: +64 9 259 4115 schroff@soanar.com www.soanar.com Africa South Africa Actum Electronics (PTY) LTD Unit A8, The Stables Business Park No 13, 3rd Road Linbro Park, 2064 Tel.: +27 (0) 11 608 3001 Fax: +27 (0) 11 608 1918 sales@actum.co.za www.actum.co.za 10/2012 12.79 Main Catalog 24th Edition Main Catalog Schroff gmbh, LangenaLber StraSSe 96–100, D-75334 StraubenharDt WWW.SCHROFF.PENTAIR.CO.UK Equipment Protection Solutions 24th Edition | October 2012 39601-641 © 2016 Pentair equipment Protection 18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1 10.10.2012 11:15:02
69001981 价格&库存
很抱歉,暂时无法提供与“69001981”相匹配的价格&库存,您可以联系我们找货
    • 1+221.879971+27.52411
    • 5+189.595775+23.51927
    • 10+177.1845110+21.97966
    • 25+162.0138725+20.09775
    • 50+151.4077750+18.78207
    • 100+148.41729100+18.41110
    库存:12
