1453C
1453C
    HAMMONDMANUFACTURING
    BOXSTEELGRAY11"LX7.12"W
1453C 数据手册
4 3 201.90 mm [7.949 in] 2 57.80 mm [2.276 in] 1 34.93 mm [1.375 in] 247.65 mm [9.750 in] D D 12.69 mm [.500 in] 180.98 mm [7.125 in] 146.05 mm [5.750 in] n3.45 mm [.136 in] 5.05 mm [.199 in] 17.83 mm [.702 in] 5.31 mm [.209 in] TOP OF ASSEMBLY BOTTOM OF ASSEMBLY C C 317.50 mm [12.500 in] 268.43 mm [10.568 in] 180.98 mm [7.125 in] 23.39 mm [.921 in] 1.22 mm [.048 in] 151.18 mm [5.952 in] 177.80 mm [7.000 in] 40.28 mm [1.586 in] B 96° 178.54 mm [7.029 in] 4.27 mm [.168 in] Note: n5.54 mm [.218 in] n5.05 mm [.199 in] 314.60 mm [12.386 in] 260.35 mm [10.250 in] 177.80 mm [7.000 in] n3.61 mm 9X [.142 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES Format. 177.80 mm [7.000 in] 173.43 mm [6.828 in] 1453C Material: 16 ga. Steel bas e, Gray color Cover: 18 ga. Steel vented for cooling Screws : 8 Supplied (#6-32 X 1/4" s elf tap) Feet: 0.75" (19 m m ) Rubber 1.45 mm [.057 in] 9.53 mm [.375 in] 228.60 mm [9.000 in] B 152.40 mm [6.000 in] Screws for Feet: 4 supplied (#8-32 X 3/8" self tap) 5.49 mm [.216 in] A A END VIEW OF EXPLODED ASSEMBLY SIDE VIEW OF EXPLODED ASSEMBLY 4 3 1453C 2 1
1453C 价格&库存
很抱歉,暂时无法提供与“1453C”相匹配的价格&库存,您可以联系我们找货
