3252
    ADAFRUIT
    BOXPLSTCBLK/CLR2.76"LX1.38"W
3252 数据手册
Raspberry Pi Zero Case PRODUCT ID: 3252 Description This is a basic, classic Pi Zero enclosure with a black base and a clear top. The case is as minimal as it gets, coming in just two pieces of polycarbonate that snap snugly together. This case will keep your Pi Zero safe and secure while also looking super sleek. You can use all of the connectors on the edges of the Pi: mini HDMI, microSD slot, microUSB power, and microUSB port. There's also a cut out to allow a 2x20-pin header to be soldered onto the Pi Zero. The enclosure was designed by Mike Doell – just like our elegant, beautiful, and functional Pi Case for Raspberry Pi Model B. Made of ultra-durable, super-glossy polycarbonate, it is both good looking and tough enough to toss into your pocket, bookbag, or toolbox. It has slim openings for all your cables, an easy-to-access slot for your Micro SD card, slots for your Pi Camera, and a space for your GPIO cable to extend out from the Pi. The Pi sits nicely in the base, latching to the corner pegs, and the lid fits snugly on top. If you want to break-out your Pi you can simply snap off the GPIO slot and add pHATs, Bonnets, GPIO cables and other accessories with ease. This enclosure is only compatible with the Raspberry Pi Zero! It works with both the Zero v1.2 and v1.3 with camera connector. This product comes with 2 polycarbonate pieces. Raspberry Pi Zero computer is **not** included. No other cables or connectors or accessories are included Technical Details Product Dimensions: 70.0mm x 35.0mm x 13.0mm / 2.8" x 1.4" x 0.5" Product Weight: 13.9g / 0.5oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3252”相匹配的价格&库存,您可以联系我们找货
