DWT60100XX
DWT60100XX
    TRIPPLITE
    TV WALL MOUNT
DWT60100XX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Tilt Wall Mount for 60" to 100" TVs and Monitors, UL Certified MODEL NUMBER: DWT60100XX Highlights ● Fits most flat-panel displays from 60 to 100 in. ● Hangs out of sight for a sleek, professional appearance ● -15° to +15° tilt capability for wide range of motion ● Supports up to 350 lbs (158.8 kgs) Package Includes Low-profile mount hangs a flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants. Tilts to provide optimal viewing angles. Description The VESA-compliant DWT60100XX Tilt Wall Mount allows you to mount your flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants, it fits most flat-panel displays from 60 to 100 inches. A -15° to +15° tilt capability minimizes glare and provides comfortable viewing from multiple angles. Low-profile mount is concealed behind the display to give a sleek, professional appearance. Display brackets with connected straps adjust to compensate for off-center wall studs. Durable all-metal frame with scratch-resistant powder-coated finish supports up to 350 lbs (158.8 kgs). Mounting hardware included. Conforms to VESA-compliant displays with any of the following mounting hole patterns: 100 x 100 mm, 100 x 200 mm, 200 x 100 mm, 200 x 200 mm, 200 x 300 mm, 200 x 400mm, 200 x 500 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 300 x 500 mm, 300 x 600 mm, 300 x 700 mm, 300 x 800 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm, 400 x 500 mm, 400 x 600 mm, 400 x 700 mm, 400 x 800 mm, 500 x 200 mm, 500 x 300 mm, 500 x 400 mm, 500 x 500 mm, 500 x 600 mm, 500 x 600 mm, 500 x 700 mm, 500 x 800 mm, 600 x 300 mm, 600 x 400 mm, 600 x 500 mm, 600 x 600 mm, 600 x 700 mm, 600 x 800 mm, 700 x 300 mm, 700 x 400 mm, 700 x 500 mm, 700 x 600 mm, 700 x 700 mm, 700 x 800 mm, 800 x 300 mm, 800 x 400 mm, 800 x 500 mm, 800 x 600 mm, 800 x 700 mm, 800 x 800 mm, 900 x 400 mm, 900 x 500 mm, 900 x 600 mm, 900 x 700 mm, 900 x 800 mm, 1000 x 400 mm, 1000 x 500 mm, 1000 x 600 mm, 1000 x 700 mm and 1000 x 800 mm Features Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from 60 to 100 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsMounts out of sight behind display for sleek, professional appearanceMounting hardware includedTested in accordance with UL Standard 2442 Convenient One-Touch Adjustment-15° to +15° tilt capability provides comfortable viewing from multiple anglesImproves viewing angles in applications where audience is below the display Durable Metal ConstructionSupports up to 350 lbs (158.8 kgs)Adjustable display brackets with connected straps compensate for off-center wall studsScratch-resistant powder-coated finish VESA ComplianceSupports the following VESA mounting hole patterns: 100 x 100 mm, 100 x 200 mm, 200 x 100 mm, 200 x 200 mm, 200 x 300 mm, 200 x 400mm, 200 x 500 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 300 x 500 mm, 300 x 600 mm, 300 x 700 mm, 300 x 800 mm, 400 x 200 mm, 400 x 1/3 ● Wall plate ● Mounting template ● (2) Adapter brackets ● (2) Tilt adjusting knobs ● (4) M5 x 14 screws ● (4) M6 x 14 screws ● (4) M6 x 30 screws ● (4) M8 x 20 screws ● (4) M8 x 30 screws ● (4) Washers ● (8) Small spacers ● (4) Big spacers ● (6) Anchor bolts ● (6) Concrete anchors ● (6) D6 washers ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States 300 mm, 400 x 400 mm, 400 x 500 mm, 400 x 600 mm, 400 x 700 mm, 400 x 800 mm, 500 x 200 mm, 500 x 300 mm, 500 x 400 mm, 500 x 500 mm, 500 x 600 mm, 500 x 600 mm, 500 x 700 mm, 500 x 800 mm, 600 x 300 mm, 600 x 400 mm, 600 x 500 mm, 600 x 600 mm, 600 x 700 mm, 600 x 800 mm, 700 x 300 mm, 700 x 400 mm, 700 x 500 mm, 700 x 600 mm, 700 x 700 mm, 700 x 800 mm, 800 x 300 mm, 800 x 400 mm, 800 x 500 mm, 800 x 600 mm, 800 x 700 mm, 800 x 800 mm, 900 x 400 mm, 900 x 500 mm, 900 x 600 mm, 900 x 700 mm, 900 x 800 mm, 1000 x 400 mm, 1000 x 500 mm, 1000 x 600 mm, 1000 x 700 mm and 1000 x 800 mm Specifications OVERVIEW UPC Code 037332186683 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 1000x400; 1000x500; 1000x600; 1000x700; 1000x800; 100x100; 100x200; 200x100; 200x200; 200x300; 200x400; 200x500; 300x200; 300x300; 300x400; 300x500; 300x600; 300x700; 300x800; 400x200; 400x300; 400x400; 400x500; 400x600; 400x700; 400x800; 500x200; 500x300; 500x400; 500x500; 500x600; 500x700; 500x800; 600x300; 600x400; 600x500; 600x600; 600x700; 600x800; 700x300; 700x400; 700x500; 700x600; 700x700; 700x800; 800x300; 800x400; 800x500; 800x600; 800x700; 800x800; 900x400; 900x500; 900x600; 900x700; 900x800 Motion Tilt Mounting Location Wall Degrees of Motion -15/+15 Tilt Minimum Screen Size (in.) 60 Minimum Screen Size (cm) 152.4 Maximum Screen Size (in.) 100 Maximum Screen Size (cm) 254 Maximum Weight Capacity (lbs.) 350 Maximum Weight Capacity (kg) 159 Number of Displays 1 Shipping Dimensions (hwd / in.) 2.70 x 9.20 x 46.60 Shipping Dimensions (hwd / cm) 6.86 x 23.37 x 118.36 Shipping Weight (lbs.) 21.40 Shipping Weight (kg) 9.71 Unit Dimensions (hwd / in.) 32.760 x 44.880 x 5.120 Unit Dimensions (hwd / cm) 83.2 x 113.0 x 113.0 Unit Weight (lbs.) 17.36 Unit Weight (kg) 7.87 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock No STANDARDS & COMPLIANCE Product Certifications UL 2442 Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DWT60100XX 价格&库存
很抱歉,暂时无法提供与“DWT60100XX”相匹配的价格&库存,您可以联系我们找货
