1623-4
    KEYSTONE
    ROUND STANDOFF 4-40 BRASS 1/2"
1623-4 数据手册
SWAGE THREADED STANDOFFS ROUND FORCE-FIT STANDOFFS HEX ROUND A broaching-type fastener/standoff for installation in panels and circuit boards .060 (1.52) and thicker made of plastic and other non-ductile materials. Available threaded or with clearance holes. Easy to install, presses into punched or drilled holes. MATERIAL: Stainless Steel per ASTM-A581/A582 HEX O.D. MOUNTING HOLES: .147 (3.7) hole for 2-56 .166 (4.2) hole for 4-40 .213 (5.4) hole for 6-32 THREAD THREAD H TOLERANCE ON MOUNTING HOLES: H +.003/-.000 O.D. O.D. .105 (2.7) .105 (2.7) L.D. L.D. L L .060 [1.52] MAX. For .062 (1.52) thick boards ROUND CAT. NO. 1589-2 1590-2 1591-2 1596-2 2260-2 2261-2 2262-2 2263-2 2264-2 1560A 1790-2 1650-2 1651-2 1623-2 1624-2 1625-2 1792-2 1652-2 1560B 1612-2 1546 1561B 1604-2 1605-2 1608-2 1796-2 1609-2 Threaded HEX CAT NO. H L.D. SHANK HEIGHT ABOVE PANEL DIAMETER 2-56 THREAD × .156 (4.0) O.D. .125 (3.2) .125 (3.2) .187 (4.7) .125 (3.2) .250 (6.4) .125 (3.2) .375 (9.5) .125 (3.2) 4-40 THREAD × .187 (4.7) O.D. .125 (3.2) .139 (3.5) .187 (4.7) .139 (3.5) .250 (6.4) .139 (3.5) .375 (9.5) .139 (3.5) .500 (12.7) .139 (3.5) 4-40 THREAD × .250 (6.4) O.D. .125 (3.2) .187 (4.7) .187 (4.7) .187 (4.7) .250 (6.4) .187 (4.7) .375 (9.5) .187 (4.7) .500 (12.7) .187 (4.7) .625 (15.9) .187 (4.7) .750 (19.1) .187 (4.7) .875 (22.2) .187 (4.7) 1.000 (25.4) .187 (4.7) 6-32 THREAD × .250 (6.4) O.D. .125 (3.2) .187 (4.7) .187 (4.7) .187 (4.7) .250 (6.4) .187 (4.7) .375 (9.5) .187 (4.7) .500 (12.7) .187 (4.7) .625 (15.9) .187 (4.7) .750 (19.1) .187 (4.7) .875 (22.2) .187 (4.7) 1.000 (25.4) .187 (4.7) .060 [1.52] MAX. A A Clear Hole THREADED 1731-2 1734-2 1740-2 1743-2 2270-2 2271-2 2272-2 2273-2 2274-2 1653-2 1746-2 1627-2 1628-2 1629-2 1654-2 1655-2 1749-2 1630-2 1620-2 1752-2 1621-2 1622-2 1758-2 1759-2 1761-2 1775-2 1784-2 L LENGTH .065 (1.7) 065 (1.7) .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) .065 (1.7) .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) CAT. NO. 4860 4861 4862 4863 4864 4865 * 4866 4867 4868 4869 4870 * O.D. .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .281 (7.1) .281 (7.1) .281 (7.1) .281 (7.1) .281 (7.1) A (4.2) (4.7) (4.7) (4.7) (4.7) (4.7) (5.9) (5.9) (5.9) (5.9) (.59) THREAD 2-56 A .184 (4.7) .184 (4.7) .184 (4.7) .184 (4.7) .184 (4.7) .231 (5.9) .231 (5.9) .231 (5.9) .231 (5.9) .231 (5.9) HOLE .165 .184 .184 .184 .184 .184 .231 .231 .231 .231 .231 6-32 *Thread depth .375 (9.5) CLEAR HOLE L LENGTH .065 (1.7) .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) .065 (1.7) .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) CAT. NO. 4850 4851 4852 4853 4854 4855 4856 4857 4858 4859 SWAGE CLEAR HOLE SPACERS O.D. .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .281 (7.1) .281 (7.1) .281 (7.1) .281 (7.1) .281 (7.1) .116 (2.9) For # 4 .143 (3.6) For # 6 SWAGE STAKING TOOLS Precision made staking tool kits are made from .250 (6.4) diameter heat treated steel, zinc plated. Each kit includes the correct swage top staking tool anvil to create a professional appearance. These tools may be used with an arbor press or hand tapped. .250 [6.4] 4-40 SWAGE / FORCE FIT STANDOFFS MATERIAL: Brass, ASTM-B16, Nickel Plate (QQ-N-290) C H .109 [2.8] .187 [4.8] MATERIAL: Brass, ASTM-B16, Nickel Plate (QQ-N-290) For .062 (1.52) thick boards CAT. NO. 5058-2 5060-2 5061-2 5062-2 5059-2 5063-2 5064-2 5065-2 H HEIGHT ABOVE PANEL .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) .125 (3.2) .250 (6.4) .375 (9.5) .500 (12.7) Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com C HOLE .120 (3.0) For # 4 .140 (3.5) For # 6 CAT. NO. STANDOFF DIA. TL-19 .156 (4.0) TL-22 .187 (4.7) TL-20 .250 (6.4) TL-21 .250 (6.4) ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED THREAD 2-56 4-40 4-40 6-32 HOLE SIZE — — — .120 (3.0) www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 77
1623-4 价格&库存
很抱歉,暂时无法提供与“1623-4”相匹配的价格&库存,您可以联系我们找货
