ROB-12504
ROB-12504
    SPARKFUNELECTRONICS
    DUALCHANNEL45DEGREEANGLE
ROB-12504 数据手册
 Dual Channel - 45 Degree Angle ROB - 12504  images are CC BY-NC-SA 3.0 Description: These dual channel 45 degree angle brackets mate directly to Actobotics channels and hub mounts and are useful as attachment points. They share the same 0.5" center hole and 0.77" and 1.5" mounting patterns as the channel. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. https://www.sparkfun.com/products/12504 2/12/2016
ROB-12504 价格&库存
很抱歉,暂时无法提供与“ROB-12504”相匹配的价格&库存,您可以联系我们找货
