1704
    KEYSTONE
    SHOULDER SCREW KNOB 1/4-20
1704 数据手册
R TI F I ED PANEL HARDWARE 2 T Y CE 900 ISO Q I UAL STAINLESS STEEL CAPTIVE PANEL SCREWS MATERIAL: Stainless Steel per ASTM-A581/A-582 CAT. NO. 8700 8701 8702 8703 8704 8705 TH'D 4-40 4-40 4-40 6-32 6-32 6-32 W +.005 -.000 .036 .036 .036 .045 .045 .045 S.L. +.010 .375 .500 .625 .375 .500 .625 S.D. +.005 .078 .078 .078 .095 .095 .095 CAT. NO. 8706 8707 8708 8709 8710 8711 TH'D 4-40 4-40 4-40 6-32 6-32 6-32 T.L. +.000 -.015 .125 .125 .125 .218 .218 .218 S.D. +.005 .078 .078 .078 .095 .095 .095 S.L. ±.010 .171 .296 .421 .187 .312 .437 P.D. +000 -.010 .078 .078 .078 .095 .095 .095 P.L. ±.015 .078 .078 .078 .093 .093 .093 SHAFT LOCKS (1/8" & 1/4") MATERIAL: Brass, ASTM-B16, Nickel Plate per QQ-N-290 CAT. NO. 1700 CAT. NO. 1701 CAT. NO. 1702 PRECISION PANEL NUTS PANEL BEARINGS STANDARD AND MINIATURE MATERIAL: Brass, Nickel Plated (QQ-N-290). Supplied unassembled. CAT. NO. 1705 1706 A .253 .128 B .437 .343 C .500 .437 D .437 .375 E 3/8-32 Standard 1/4-32 Miniature THUMB SCREWS For quick removal of panel from chassis. Other variations available MATERIAL: Brass, Nickel Plated (QQ-N-290) CAT. NO. 1708 1709 1710 FOR Mounting Mini. Control Vol. Control Switch Switch Ring Filter THREAD 1/4-32 1/4-32 3/8-32 15/32-32 15/32-32 5/16-32 DIAMETER 3/8 Hex 5/16 Hex 1/2 Hex 9/16 Hex 5/8 Knurled 3/8 Hex THICKNESS 3/32" 5/64" 3/32" 5/64" 1/16" 3/32" MATERIAL: Brass, Nickel Plated (QQ-N-290). Two set screws hold shaft securely. Supplied unassembled. STAINLESS STEEL CAPTIVE SCREW For quick removal of panel from chassis. Other variations available MATERIAL: Stainless Steel per ASTM-A581/A582 56 CAT. NO. 1448 1449 1456 1458 1459 1472 1/4" - 1/4" SHAFT COUPLING THREAD 6-32 8-32 10-32 CAT. NO. 1704 For Volume Controls, Switches, Capacitors, Tip Jacks, etc. MATERIAL: Brass, Nickel Plated (QQ-N-290). CAT. NO. 1453 VOLUME CONTROL EXTENDERS For 1/4" volume control shafts having 3/8-32 threaded bushings. MATERIAL: Brass, Nickel Plated (QQ-N-290). B CAT. NO. A 1464 .625 .250 1465 .625 .375 1466 .687 .500 1467 .750 .250 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com
很抱歉,暂时无法提供与“1704”相匹配的价格&库存,您可以联系我们找货
