1000 Eaton Boulevard
Cleveland, OH 44122
United States
100W PowerVerter Ultra-Compact Car Inverter
with Outlet, 12V CLA Receptacle, and 2 USB
Charging Ports
Highlights
Charges multiple electronic
devices in your vehicle
Features AC outlet, 12V CLA,
2.1A USB port and 1.0A USB
port
Plugs into your vehicle’s
cigarette lighter socket
Built-in interior cooling fan
Durable plastic housing
MODEL NUMBER: PV100USB
Package Includes
Charge and/or power multiple electronic devices—including smartphones, laptops, tablets, GPS units,
DVD players, MP3 players, camping equipment and mobile office equipment—on the go in your car, truck,
boat or RV.
Description
The PV100USB 100W PowerVerter® Ultra-Compact Car Inverter provides 100 watts of portable power for
charging and operating multiple devices in your car, truck, boat or RV. It converts 12V DC power into
standard 120V AC power to run a wide variety of electronics, such as smartphones, laptops, tablets, GPS
units, game systems, portable TVs, DVD players and MP3 players, as well as low-power lights, camping
accessories, battery rechargers for small battery-operated power tools and mobile office equipment.
The PV100USB features an AC outlet, a 12V cigarette lighter socket, a 2.1A USB port and a 1.0A USB
port. Just plug the DC input jack with convenient 3-ft. (0.91 m) cord into the 12V cigarette lighter socket in
your vehicle, and the unit is ready to operate. Easy-to-read front LED lets you know the inverter is
receiving power from the battery.
To prevent you from running down your car battery, the PV100USB turns off automatically when the input
voltage falls to 10V. Likewise, the unit will also shut down if it gets too hot (for instance, because your
connected devices exceed 100 watts). A built-in ventilation fan keeps the interior cool during extended
use. The durable plastic housing is engineered to withstand the rigors of road trips, campouts, business
trips and family vacations. No maintenance is required.
Features
Powers and Charges Up to 4 Devices
● Converts 12V DC battery power to standard 120V AC power
Runs smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players, MP3
players and other electronics
Features AC outlet, 12V cigarette lighter socket, 2.1A USB port and 1.0A USB port
Outputs 100 watts (continuous); 200 watts (peak)
Easy to Use
● DC jack plugs into the cigarette lighter socket in your car, truck, boat or RV
Flexible 3-ft. (0.91 m) cord allows devices to run in the back seat
Front LED indicates the unit is receiving power from the battery
1/3
Warranty information
Owner’s Manual
Cleveland, OH 44122
United States
Premium Construction
● Durable plastic housing built to withstand rigors of travel
Built-in ventilation fan keeps the interior cool during extended use
Automatic low-voltage shutoff prevents deep vehicle battery discharge at 10V
No maintenance required
Specifications
OVERVIEW
UPC Code
037332187888
INPUT
Input Connection Type
12VDC cigarette lighter input plug connection
Voltage Compatibility (VDC)
12
Input Cord Length (ft.)
3
Input Cord Length (m)
0.91
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(1) 5-15R
Continuous Output Capacity (Watts)
100
Peak Output Capacity (Watts)
200
Output Frequency Regulation
60 Hz (+/- 3 Hz)
Overload Protection
12A fuse
BATTERY
DC System Voltage (VDC)
12
CHARGING
Charging Ports / Amps
(1) 1A; (1) 2.1A
PHYSICAL
Material of Construction
Plastic
Shipping Dimensions (hwd / in.)
4.13 x 1.81 x 5.51
Shipping Dimensions (hwd / cm)
10.50 x 4.60 x 14.00
2/3
Cleveland, OH 44122
United States
Shipping Weight (lbs.)
0.80
Shipping Weight (kg)
0.37
Unit Dimensions (hwd / in.)
3.937 x 1.614 x 3.268
Unit Dimensions (hwd / cm)
10.0x4.10x8.30
Unit Weight (lbs.)
.538
Unit Weight (kg)
0.24
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
