1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-in-1 Ultra-Compact Inverter with Mobile
Charging
MODEL NUMBER: PV4IN1
Highlights
Ideal for smartphones, tablets,
laptops, GPS units and MP3
players
Includes a 2.1A USB-A charging
port and a retractable 24 in.
Micro-USB charging cord
Comes with handy travel pouch
and four charging adapters
Durable plastic housing
withstands rigors of travel
Package Includes
Features four different inputs to charge and power mobile devices and portable electronics from a
standard wall socket, a vehicle’s 12V CLA socket, a USB power source or a 9V battery.
Description
The PV4IN1 charges and powers mobile devices such as phones or tablets anywhere, any time. This
inverter includes a fold-down plug to charge directly from an AC wall outlet, a plug to charge from a
vehicle’s 12V CLA outlet, a 5V USB-A input cord and a 9V battery input for short-term emergency power
(battery not included).
To charge your device, just connect it to the USB output port or the retractable 24 in. Micro-USB charging
cord. To make it easy to charge any mobile device, the PV4IN1 includes four charging adapters: Apple®
30-pin, Nokia® 2 mm, Sony® PSP® and USB Mini-B. For on-the-road portability, the included travel
pouch holds the inverter and the adapters.
Features
4 Ways to Power and Charge Multiple Devices
Powers and charges smartphones, laptops, tablets, GPS units or MP3 players
Fold-down NEMA 1-15P plug provides charging power to the unit directly from an AC wall outlet
CLA plug lets you convert 12V DC power to standard 120V power from the battery in a car, truck, RV or
boat
USB-A input allows the unit to draw power from a USB source, such as a computer or a USB wall
socket
9V battery input can be used as a short-term emergency power source (battery not included)
2 Output Ports for Easy Charging of Any Mobile Device
● Built-in connections provide a USB-A charging port and a 24 in. retractable Micro-USB charging cord
Delivers a total of 2.1A to all devices being charged at the same time
Charge a wide variety of devices with the four included adapters: Apple® 30-pin, Nokia® 2 mm, Sony®
PSP® and USB Mini-B; the adapters connect directly to the Micro-USB charging cord
LED indicates when the unit is plugged in and ready to provide power
Ready for Travel and Made to Last
1/3
PV4IN1 Mobile Charger
Travel Pouch
Four Charging Adapters
Owner’s Manual
Cleveland, OH 44122
United States
Convenient travel pouch keeps the inverter and all adapters together and close at hand
Durable plastic housing stands up to the rigors of travel for years of dependable use
No maintenance required
Specifications
OVERVIEW
UPC Code
037332191823
INPUT
Input Connection Type
12VDC cigarette lighter input plug connection
Voltage Compatibility (VDC)
12
Input Plug Type
NEMA 5-15P
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(1) 5-15R
Continuous Output Capacity (Watts)
100
BATTERY
DC System Voltage (VDC)
5V (USB type A), 9V Battery, 12V (CLA Adapter)
CHARGING
Charging Ports / Amps
(1) 2.1A
PHYSICAL
Material of Construction
Plastic
Shipping Dimensions (hwd / in.)
2.00 x 3.90 x 5.90
Shipping Dimensions (hwd / cm)
5.08 x 9.91 x 14.99
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
Unit Dimensions (hwd / in.)
1.160 x 3.480 x 4.570
Unit Dimensions (hwd / cm)
2.95 x 8.84 x 11.61
Unit Weight (lbs.)
.55
Unit Weight (kg)
0.25
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PV4IN1”相匹配的价格&库存,您可以联系我们找货
