1000 Eaton Boulevard
Cleveland, OH 44122
United States
Position a 200A fuse link less than 18 in. from the battery in the positive line to protect against highcurrent draw that may occur during inverter failure.
1250W PowerVerter APS 12VDC 120V
Inverter/Charger with Auto Transfer Switching, 2
Outlets
MODEL NUMBER: APS1250
Highlights
Delivers clean 120V AC power
from AC or DC power source
1250W continuous output
power; 2500W peak power
Auto-transfer switching option
for UPS operation
Protects against blackouts,
surges and EMI/RFI line noise
Rugged polycarbonate housing
resists moisture and impact
Package Includes
Portable dual-outlet power source for power applications, such as power tools and computers, as a
vehicle inverter, standalone AC power source or extended-run UPS. Ideal for RVs, fleet vehicles and
emergency vehicles.
Features
Reliable Power for Mobile, Emergency and Remote Sites
● Generates safe, stable, computer-grade 120V AC power from 12V battery bank
Ideal for powering tools, saws, motors, pumps, portable lighting, appliances and computer equipment in
heavy-load conditions
Designed for easy installation in RVs, over-the-road trucks, fleet vehicles and emergency vehicles
Functions as a vehicle inverter, standalone AC power source or extended-run UPS
Features 2 front NEMA 5-15R outlets
Unlimited runtime with variety of user-supplied batteries
Meets Normal and Peak Power Demands
● 1250W of continuous power
1850W of reserve power up to 1 hr.
2500W of peak power up to 10 sec. to accommodate surge power demands during equipment startup
and cycling
Automatic overload detector, built-in cooling fan and resettable AC circuit breaker protect unit from
damage
Automatic Transfer Switching
● Transfer relay switches to inverter power during blackout in 16.6 ms
3-position switch enables Auto, Charge Only or System Off mode
DIP switches configure high and low voltage auto-transfer
1/4
APS1250 1250W PowerVerter
APS 12V DC 120V AC
Inverter/Charger
Owner’s manual
Cleveland, OH 44122
United States
3-Stage 30A Battery Charger
● Serves as battery charger when external 120V AC power is supplied and powering connected
equipment
Protects battery from overcharging and overdischarging
Low-battery protection prevents excessive battery depletion
DIP switches configure wet/gel charging profiles
Optional Remote Control Capability
● RJ45 communication port allows connection of optional remote control module, such as Tripp Lite's
APSRM4
Front-Panel LEDs
● Indicate load level, battery charge level, shutdown status and system fault status
Rugged Polycarbonate Housing
● Resists moisture, vibration and impact
Built-in mounting feet for installation on any rigid horizontal surface
Grounding lug connects unit to earth ground or vehicle grounding system
Built-in 6-ft. (1.83 m) AC power cord with NEMA 5-15P plug connects to AC power source
Specifications
OVERVIEW
UPC Code
037332121653
INPUT
Nominal Input Voltage(s) Supported
120V AC
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 127A at 12V DC. AC INPUT: 12 amps at 120VAC with full inverter and charger
load (6.3A max charger-only)
Recommended Electrical Service
DC INPUT: Requires 12VDC input source capable of delivering 125A for the required duration (when used at full
continuous capacity - DC requirements increase during OverPower and DoubleBoost operation). For automotive
applications, professional hardwire installation with 225A minimum battery system fusing is recommended. AC
INPUT: 120VAC
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: NEMA 5-15P input plug
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
2/4
Cleveland, OH 44122
United States
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
1250
Peak Output Capacity (Watts)
2500
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 120 V AC (+/-5%).
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 8A input breaker dedicated to the charging system and 12A output breaker for AC output loads
BATTERY
Expandable Runtime
Yes
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet, gel or SLA batteries
Expandable Runtime Description
DC System Voltage (VDC)
12
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
30A max, 3 step, float for long term maintenance
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant
on/off control of the inverter system when used in conjunction with optional APSRM4 accessory when used in inverter mode. In AC uninterruptible power
mode, auto/remote setting enables automatic transfer from line power to battery power - to maintain continuous AC
power to connected loads.
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
450
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Receptacle Color
Black
Shipping Dimensions (hwd / in.)
12.60 x 10.60 x 10.20
Shipping Dimensions (hwd / cm)
32.00 x 26.92 x 25.91
Shipping Weight (lbs.)
24.30
Shipping Weight (kg)
11.02
Unit Dimensions (hwd / in.)
7.000 x 8.750 x 9.000
Unit Dimensions (hwd / cm)
17.78 x 22.23 x 22.86
3/4
Cleveland, OH 44122
United States
Unit Weight (lbs.)
23.2
Unit Weight (kg)
10.52
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical - compatible with many computers, servers and networking equipment - verify transfer time
compatibility of loads for UPS applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 75V (user adjustable to 85, 95,
105V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 135V (user adjustable to
145 - see manual)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
1-year limited warranty
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“APS1250”相匹配的价格&库存,您可以联系我们找货
