1000 Eaton Boulevard
Cleveland, OH 44122
United States
3000W PowerVerter RV Inverter/Charger with
Hardwire Input/Output
MODEL NUMBER: RV3012OEM
Highlights
12V DC or 120V AC input; 120V
AC output (hardwired)
3000 watts continuous, 4500
watts OverPower™ and 6000
watts DoubleBoost™ inverter
output
3 stage, 35/140 amp selectable
wet/dry cell battery charger
Built-in Isobar® premium AC
surge protection and Auto
Transfer Switching option for
battery backup / UPS operation
Tested to power inverter
standards UL458 (USA) and
CSA (Canada)
High reliability large-transformer
design with protected DC and
AC wiring terminals
Package Includes
Features
RV3012OEM serves as an automotive or stationary DC-to-AC inverter with automatic line-to-battery
transfer and integrated battery charger
Supports 120V AC output from a 120V AC line power source or 12V DC battery source
16.6 millisecond automatic transfer between line and battery power supports UPS protection during
blackouts and voltage fluctuations for equipment compatible with a one cycle transfer time
3000 watts continuous AC output in inverter mode, 4800 watts continuous via dual circuit AC output in
AC mode
Double Boost inverter output supports momentary startup loads up to 200% of the continuous rating for
up to 10 seconds
OverPower inverter output supports longer duration overloads to 150% for 1-60 minutes under ideal
battery and temperature conditions. (For best results, utilize OverPower usage for as short of a duration
as possible, ensure battery bank and cabling is able to provide full nominal DC voltage under load and
allow inverter/charger to fully cool before and after OverPower usage.)
3 stage, selectable 35/140 amp battery charger with adjustable settings for wet/gel battery types offers
fast, reliable battery recharging
Protected hardwire bolt-down input lugs safely accept heavy gauge input wiring from attached battery
bank
Protected hardwire output passes 120V line power or inverter output through to connected equipment.
Includes optional dual-circuit hardwire AC input to enable full charger output from the first 120V 20A
circuit and full AC pass-through from the second 120V 20A input feed
Reliability enhanced large-transformer design tested to UL (USA) and CSA (Canada) standards
Moisture-resistant construction enables vehicular or marine operation in high humidity environments
3 position operating mode switch supports "AUTO" mode to enable automatic transfer between DC and
AC modes, CHARGE-ONLY to maintain a full battery charge when AC is present without auto transfer
and SYSTEM OFF settings
Set of six front panel LEDs display AC/DC operational modes, overload status, DC voltage level,
shutdown status and system fault status
Set of 4 configuration dipswitches support wet/gel battery charging profiles, adjustable 135/145V high
voltage auto transfer during overvoltages and selectable 75/85/95/105V AC low voltage auto transfer
during brownouts
1/4
RV3012OEM Inverter/Charger
Instruction manual with warranty
information
Cleveland, OH 44122
United States
Set of 4 additional configuration dipswitches support 4 levels of charger limiting relative to output load
size, a battery equalization program and battery charger low/high settings
Resettable 30A charger AC input breaker and resettable dual 20A branch-rated AC output breakers and
automatic 2 speed cooling fan protect the inverter from load and temperature related failures
Grounding lug properly connects the inverter/charger system to earth ground or vehicle grounding
system
Automatic overload and thermal shutoff safely turns off inverter as excessive loads or overheating
conditions develop
Front panel remote control connector enables remote off/on switching (requires APSRM4 switch
accessory). Optional APSRM4 accessory also includes user configurable jacks to support inverter
shutoff or startup as a vehicle ignition is engaged
Load sensing control dial enables adjustable load threshold required to automatically turn the inverter
on and off in DC mode as load conditions change
Includes battery temperature sensor with 20-ft. (6.09 m) cable to prolong battery life by adjusting the
charge level based on battery temperature
Automatic Generator Starter jack enables user configuration of automatic generator startup as inverter
batteries drop to 11.5VDC and generator shutoff as inverter batteries are recharged to 14.1VDC
Specifications
OVERVIEW
UPC Code
037332117427
INPUT
Nominal Input Voltage(s) Supported
120V AC
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 282A at 12VDC. AC INPUT: 40 amps total (20A line 1 / 20A line 2) at 120VAC
with full inverter and charger load (25A max charger-only from line 1 / combined input load to support charger and
AC output is automatically controlled
Recommended Electrical Service
DC INPUT: Requires 12VDC input source capable of delivering 290A for the required duration (when used at full
continuous capacity - DC requirements increase during Over-Power and Double-Boost operation).
Input Connection Type
DC INPUT: Set of 4 DC bolt-down terminals (2 red / 2 black). AC INPUT: hardwire (2 input circuits - see manual)
Input Cord Length Details
DC INPUT: User supplies cabling. 0 gauge or larger (see manual). AC INPUT: hardwire
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
Hardwire
Continuous Output Capacity (Watts)
3000
Peak Output Capacity (Watts)
6000
2/4
Cleveland, OH 44122
United States
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 120 VAC (+/-5%).
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 30A input breaker dedicated to the charging system and 2 branch rated 20A output load breakers
BATTERY
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet or gel type batteries
Expandable Runtime
Yes
Expandable Runtime Description
DC System Voltage (VDC)
12
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
35A / 140A (selectable)
LVC (Low Voltage Cut-Off)
10VDC +/-3%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3-position on/off/remote switch enables simple on/off power control plus auto/remote setting that enables distant
on/off control of the inverter system when used in conjunction with APSRM4 accessory (sold separately) in inverter mode. In AC uninterruptible power
mode, "auto/remote" setting enables automatic transfer from line power to battery power - to maintain continuous AC
power to connected loads.
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
450
PHYSICAL
Material of Construction
Steel
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Shipping Dimensions (hwd / in.)
23.20 x 14.90 x 15.40
Shipping Dimensions (hwd / cm)
58.93 x 37.85 x 39.12
Shipping Weight (lbs.)
70.00
Shipping Weight (kg)
31.75
Unit Dimensions (hwd / in.)
9.750 x 11.500 x 16.750
Unit Dimensions (hwd / cm)
24.77 x 29.21 x 42.55
Unit Weight (lbs.)
62.6
Unit Weight (kg)
28.39
3/4
Cleveland, OH 44122
United States
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical - compatible with many computers - verify transfer time compatibility of loads for UPS
applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 75V (user adjustable to 85, 95,
105V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 135V (user adjustable to
145 - see manual)
FEATURES & SPECIFICATIONS
Load Sensing
Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off
and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of
any level, up to 150 watts.
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 458
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
30-month limited warranty
(International)
1-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“RV3012OEM”相匹配的价格&库存,您可以联系我们找货
