1000 Eaton Boulevard
Cleveland, OH 44122
United States
3600W APS INT Series 36VDC 230V
Inverter/Charger with Auto-Transfer Switching,
Line-Interactive AVR
MODEL NUMBER: APSINT3636VR
Highlights
Delivers clean 230V AC power
from AC or DC power source
3600W continuous output
power; 7200W peak power
Auto-transfer switching option
for UPS operation
Corrects brownouts and
overvoltages without using
battery power
Includes Tripp Lite APSRM4
remote control module
Package Includes
Portable line-interactive power source for any type of equipment from power tools to computers as a
vehicle inverter, standalone AC power source or extended-run UPS. Ideal for RVs, commercial and fleet
vehicles and emergency vehicles.
Description
The APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger is a reliable power
source for a wide variety of equipment ranging from power tools, pumps and portable lighting to laptop
computers and sensitive monitoring equipment. With no fumes, fuel or excess noise, it’s an excellent
alternative to generator power.
The DC-to-AC inverter features an automatic line-to-battery transfer switch and integrated charging
system that allow it to work as a vehicle inverter, standalone AC power source or extended-run UPS. It
delivers 3600W of continuous power, 5400W up to one hour or 7200W of peak power up to 10 seconds
during equipment startup or cycling. An automatic overload detector, cooling fan and resettable AC circuit
breakers protect the unit from damage.
Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and construction
equipment, the APSINT3636VR converts stored power from any 36V battery or automotive DC source to
safe, stable, computer-grade AC power for unlimited runtime. When hardwired to an external 230V AC
source, the unit keeps the user-supplied battery charged via a three-stage 7.5/30A selectable charging
system while simultaneously delivering AC power to connected equipment.
When used as a UPS, the APSINT3636VR’s automatic voltage regulation feature protects your equipment
against blackouts, brownouts, surges and line noise. Tripp Lite’s APSRM4 module with “traffic light” LEDs
is included to provide complete remote monitoring and control of the unit.
Features
Reliable Power for Mobile, Emergency and Remote Sites
● Generates safe, stable, computer-grade 230V AC power from 36V battery bank
Ideal for powering tools, saws, motors, pumps, portable lighting, appliances and computer equipment in
heavy-load conditions
construction equipment
Functions as a vehicle inverter, standalone AC power source or extended-run UPS
Unlimited runtime with variety of user-supplied batteries
1/5
Inverter/Charger
APSRM4 remote control module
Owner’s manual
Cleveland, OH 44122
United States
Meets Normal and Peak Power Demands
● 3600W of continuous power
5400W of reserve power up to 1 hr.
7200W of peak power up to 10 sec. to accommodate surge power demands during equipment startup
and cycling
Automatic overload detector, built-in cooling fan and resettable AC circuit breakers protect unit from
damage
High-current DC input terminals for simple hardwired installation
Automatic Voltage Regulation
● Corrects brownouts and overvoltages without using battery power during battery charging and UPS
standby modes
Protects against line noise that can damage equipment or cause data loss
Automatic Transfer Switching
● Transfer relay switches to inverter power during blackout in 20 ms
3-position switch enables Auto, Charge Only or System Off mode
DIP switches configure high and low voltage auto-transfer
3-Stage 7.5/30A Selectable Battery Charger
● Serves as battery charger when external 230V AC power is supplied and powering connected
equipment
Protects battery from overcharging and overdischarging
Low-battery protection prevents excessive battery depletion
DIP switches configure wet/gel charging profiles
Remote Control Capability
● Included Tripp Lite APSRM4 remote control module provides remote monitoring and control of unit
Front-Panel LEDs
● Indicate AC/DC operational modes, overload status, DC voltage level, shutdown status and system fault
status
Rugged Polycarbonate Housing
● Resists moisture, vibration and impact
Mounts on any rigid horizontal surface
Specifications
OVERVIEW
UPC Code
037332095985
INPUT
Nominal Input Voltage(s) Supported
230V AC
2/5
Cleveland, OH 44122
United States
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 114A at 36VDC. AC INPUT: 26 amps at 230VAC with full inverter and charger
load (10.4A max charger-only / combined input load to support charger and AC output is automatically controllable to
66%-33%-0% based on AC output loading using the charger limiting set points - see manual for setting instructions)
Recommended Electrical Service
DC INPUT: Requires 36VDC input source capable of delivering 114A for the required duration (when used at full
continuous capacity - DC requirements increase during OverPower and DoubleBoost operation). For automotive
applications, professional hardwire installation with 300A minimum battery system fusing is recommended.
Input Connection Type
DC INPUT: Set of DC bolt-down terminals. AC INPUT: Hardwire via built in junction box with cover plate
Voltage Compatibility (VAC)
230
Voltage Compatibility (VDC)
36
OUTPUT
Frequency Compatibility
50 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
230V
Output Receptacles
Hardwire
Continuous Output Capacity (Watts)
3600
Peak Output Capacity (Watts)
7200
Output Voltage Regulation
LINE POWER (AC): Maintains 230V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 230 VAC (+/-5%).
Output Frequency Regulation
50 Hz (+/- 0.3 Hz)
Overload Protection
Includes 12A input breaker dedicated to the charging system and 20A output breaker for AC output loads.
BATTERY
Expandable Runtime
Yes
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet or gel type batteries
Expandable Runtime Description
DC System Voltage (VDC)
36
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
30-amp high/7.5A low
VOLTAGE REGULATION
Voltage Regulation Description
Includes automatic voltage regulation to correct brownouts and over-voltages back to usable levels
Overvoltage Correction
Over-voltages are automatically reduced by 10%
Brownout Correction
Brownouts are automatically boosted by 10%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
3/5
Cleveland, OH 44122
United States
Switches
3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant
on/off control of the inverter system when used in conjunction with optional APSRM4 accessory when used in inverter mode. In AC uninterruptible power
mode, "auto/remote" setting enables automatic transfer from line power to battery power - to maintain continuous AC
power to connected loads.
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Shipping Dimensions (hwd / in.)
13.40 x 14.50 x 20.90
Shipping Dimensions (hwd / cm)
34.04 x 36.83 x 53.09
Shipping Weight (lbs.)
64.60
Shipping Weight (kg)
29.30
Unit Dimensions (hwd / in.)
7.000 x 8.500 x 14.000
Unit Dimensions (hwd / cm)
17.78 x 21.59 x 35.56
Unit Weight (lbs.)
58
Unit Weight (kg)
26.31
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
20 milliseconds (typical - compatible with many computers, servers and networking equipment - verify transfer time
compatibility of loads for UPS applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 144V (user adjustable to 163,
182V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 259V (user adjustable to
264 - see manual)
FEATURES & SPECIFICATIONS
Load Sensing
Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off
and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of
any level, up to 150 watts.
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
1-year limited warranty
(International)
2-year limited warranty
4/5
Cleveland, OH 44122
United States
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
